Maxim Опубликовано: 23 октября 2017 Жалоба Share Опубликовано: 23 октября 2017 http://www.rockauto.com/en/catalog/cadillac,2015,ats,2.0l+l4+turbocharged,3307660,brake+&+wheel+hub,brake+pad,1684 Данные с РОКАВТО! ЭКОНОМ ВАРИАНТ BOSCH BC1659 Bosch QuietCast Ceramic Pads w/ Hardware Info Rear; For use without spreader spring Choose: [Wholesaler Closeout - Private Label Pkg. - 30 Day Warranty] (Only 1 Remaining) ($12.90) $12.90 CENTRIC 30010010 Premium Semi-Met Pads w/Shims Info Front; Brembo Front Calipers $17.79 POWER STOP 161659 Evolution Ceramic Info Rear (Only 4 Remaining) $18.22 CENTRIC 30110010 Premium Ceramic Pads w/Shims Info Front; Brembo Front Calipers $19.69 POWER STOP 161467 Evolution Ceramic Info Front; JE5 Brakes; Standard Calipers $20.79 CENTRIC 30116590 Premium Ceramic Pads w/Shims Info Rear $21.79 POWER STOP 171659 Z17 Evolution Plus; Evolution Plus Pads w/ Hardware Info Rear $21.79 MONROE DX1659 {Click Info Button for Alternate/OEM Part Numbers} Monroe Brakes Total Solution Semi-Metallic; Includes Hardware Kit Info Rear; w/ Brembo Brakes; w/ Performance Package $23.79 POWER STOP 161001 {#161050} Evolution Ceramic Info Front; JE55 Brakes; Brembo Calipers $23.79 POWER STOP 171467 Z17 Evolution Plus; Evolution Plus Pads w/ Hardware Info Front; JE5 Brakes; Standard Calipers $23.79 WAGNER QC1659 ThermoQuiet Includes Hardware Installation Kit Info Rear; Heavy Duty Brakes; OE Ceramic $23.79 WAGNER MX1050 ThermoQuiet Includes Hardware Installation Kit Info Front; Performance Brake; OE Semi-Metallic $23.99 BOSCH BP1467 Bosch QuietCast Pads Info Front; Std Brakes $24.79 CENTRIC 10416590 Posi-Quiet Metallic w/Shims and Hardware Info Rear $24.79 CENTRIC 10410010 Posi-Quiet Metallic w/Shims Info Front; Brembo Front Calipers $24.79 MONROE CX1659 {Click Info Button for Alternate/OEM Part Numbers} Monroe Brakes Total Solution Ceramic; Includes Hardware Kit Info Rear; w/o Brembo Calipers; w/o Performance Package $24.79 MONROE DX1001 {Click Info Button for Alternate/OEM Part Numbers} Monroe Brakes Total Solution Semi-Metallic Info Front; w/ Brembo Brakes; w/ Performance Package $24.79 POWER STOP 171001 Z17 Evolution Plus; Evolution Plus Pads w/ Hardware Info Front; JE55 Brakes; Brembo Calipers $24.79 CENTRIC 10516590 Posi-Quiet Ceramic w/Shims and Hardware Info Rear $25.79 BENDIX CFC1467 Bendix Premium Copper Free Ceramic BPR; Hardware Included Info Front; w/o Performance Brakes; w/o Brembo Front Brakes; OE Pad Material Is Ceramic $25.89 BENDIX CFC1659 Bendix Premium Copper Free Ceramic BPR; Hardware Included Info Rear; OE Pad Material Is Ceramic $26.79 MONROE CX1001 {Click Info Button for Alternate/OEM Part Numbers} Monroe Brakes Total Solution Ceramic Info Front; w/ Brembo Brakes; w/ Performance Package $26.79 BOSCH BP1001 Bosch QuietCast Pads Info Front; BREMBO CALIPER $27.89 BENDIX CFC1050 Bendix Premium Copper Free Ceramic BPR; Hardware Included Info Front; w/ Performance Brakes; w/ Brembo Front Brakes; OE Pad Material Is Semi-Metallic $28.79 CENTRIC 10610010 Posi-Quiet Extended Wear w/Shims; Posi-Quiet Extended Wear w/Shims Info Front; Brembo Front Calipers $28.89 CENTRIC 30114670 Premium Ceramic Pads w/Shims Info Front; Std Brakes (JE5) $29.79 ACDELCO 17D1467CH Professional; Ceramic; w/Hardware Info Front; Except Heavy Duty Brakes $30.79 BOSCH BC1001 Bosch QuietCast Ceramic Pads Info Front; BREMBO CALIPER $30.79 CENTRIC 10510010 Posi-Quiet Ceramic w/Shims; Posi-Quiet Ceramic w/Shims Info Front; Brembo Front Calipers $31.79 CENTRIC 10614670 Posi-Quiet Extended Wear w/Shims and Hardware Info Front; Std Brakes (JE5) $31.99 ACDELCO 17D1659MH Professional; Semi Metallic; w/Hardware Info Rear $33.79 ACDELCO 17D1659CH Professional; Ceramic; w/Hardware Info Rear $34.79 WAGNER QC1467 ThermoQuiet Includes Hardware Installation Kit Info Front; Except Performance Brake; OE Ceramic $34.79 ACDELCO 17D1050M {#19137367} Professional; Semi Metallic Info Front; w/ Heavy Duty Brakes $37.79 CENTRIC 10514670 Posi-Quiet Ceramic w/Shims and Hardware Info Front; Std Brakes (JE5) $37.79 CENTRIC 10414670 Posi-Quiet Metallic w/Shims and Hardware Info Front; Std Brakes (JE5) $39.89 CENTRIC 10010010 OE Formula Info Front; Brembo Front Calipers $40.79 RAYBESTOS PGD1050M Professional Grade; Metallic Info Front; w/ Heavy Duty Brakes (Only 2 Remaining) $41.79 MONROE CX1467 {Click Info Button for Alternate/OEM Part Numbers} Monroe Brakes Total Solution Ceramic; Includes Hardware Kit Info Front; w/o Brembo Brakes; w/o Performance Package (Only 7 Remaining) $44.79 ACDELCO 1711114 {#22857904} GM Original Equipment Info FitsRear; HEAVY DUTY BRAKES; Except Performance Brake Lining (JE2); EXCLUDES RETAINEROr Rear; Sedan; Base Model; Front & Rear Antilock Brakes (JE5); Except Performance Brake Lining (JE2); EXCLUDES RETAINER $56.79 ACDELCO 22799077 {#1711150} GM Original Equipment Info Front; Base Model; Front & Rear Antilock Brakes (JE5) $66.99 ACDELCO 1711113 {#22857909} GM Original Equipment Info FitsRear; Sedan; Heavy Duty Brakes, ACCESSORY BRAKE UPGRADE package 1(5JL)OrRear; Sedan; PERFORMANCE BRAKE LINING(JE2), Heavy Duty BrakesOr Rear; Sedan; Base Model; Front & Rear Antilock Brakes (JE5)OrRear; Coupe; PERFORMANCE BRAKE LINING(JE2), Front & Rear Antilock Brakes (JE5), Heavy Duty Brakes, Value Added Rear Suspension (VRN) $91.79 ACDELCO 1711165 {Click Info Button for Alternate/OEM Part Numbers} GM Original Equipment Info Front; HEAVY DUTY BRAKES; Except Performance Brake Lining (JE2) $109.79 ACDELCO 1711107 {#22791925} GM Original Equipment Info FitsFront; PERFORMANCE BRAKE LINING(JE2); SERVICE COMPONENT OF PARTS package 23167611OrFront; Heavy Duty Brakes, PERFORMANCE BRAKE LINING(JE2)OrFront; NORTH AMERICA(MAH); EXCEPT ACCESSORY BRAKE ROTORS - PERFORMANCE(VVX); SERVICE COMPONENT OF PARTS package 23495615 ВАРИАНТ ГОНОЧНЫЙ CENTRIC 30810010 StopTech Street Info Front; Brembo Front Calipers $28.79 AKEBONO ACT1659 {#22857904, 22857909} ProACT Ultra Premium Ceramic Pad w/ Premium Stainless Hardware Info Rear; OE Pad Material Is Ceramic $46.79 CENTRIC 30910010 StopTech Sport Info Front; Brembo Front Calipers $57.79 POWER STOP Z261001 {#Z261050} Z26 New Formulation; Street Performance Pads w/ Hardware & Brake Lube Info Front; JE55 Brakes; Brembo Calipers $57.79 POWER STOP Z261659 Z26 New Formulation; Street Performance Pads w/ Hardware & Brake Lube Info Rear $57.79 AKEBONO ACT1522 {#13356286} ProACT Ultra Premium Ceramic Pad Info Front; w/Standard Brakes; Akebono is the OE Manufacturer; OE Pad Material is Ceramic ТОРМОЗНЫЕ ДИСКИ - УСИЛЕННАЯ СЕРИЯ Размеры переднего диска! http://www.rockauto.com/en/catalog/cadillac,2015,ats,2.0l+l4+turbocharged,3307660,brake+&+wheel+hub,rotor,1896 WAGNER BD180593E Black E-Coat on non-braking surface to prevent rust and corrosion Info Front; 300mm Diameter Rotor; Brake Code: JE5 $53.79 CENTRIC 12562135 High Carbon Alloy Brake Disc Info Rear $57.79 WAGNER BD180595E Black E-Coat on non-braking surface to prevent rust and corrosion Info Front; 321mm Diameter Rotor; Brembo Front Caliper $59.79 CENTRIC 12562136 High Carbon Alloy Brake Disc Info Front; Std Brakes (JE5) $62.79 CENTRIC 12562138 High Carbon Alloy Brake Disc Info Front; Brembo Front Calipers Ссылка на комментарий Поделиться на других сайтах More sharing options...
Семён Опубликовано: 13 марта 2018 Жалоба Share Опубликовано: 13 марта 2018 Да это же праздник какой-то!Отправлено с моего iPhone используя Cadillac Team Russia Maxim отреагировал на это 1 Ссылка на комментарий Поделиться на других сайтах More sharing options...
