Результаты поиска по тегам 'каталог кадиллак'.
Найдено 12 результатов
  1. 04 - ТРАНСМИССИЯ - ТОРМОЗ (6D00-054) - 2008 DM69 ТРАНСМИССИЯ TO КРЕПЛЕНИЕ ДВИГАТЕЛЯ (AUTOMATIC MYB) ↓ 12603197 PLATE, A/TRNS FLEX 12603197 PLATE, A/TRNS FLEX 12603197 PLATE, A/TRNS FLEX 12597210 PIN, TRANS LOC 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] teamcadillac.ru 24242043 БОЛТ, TRANS CONV CVR (M6X1X18/M6X1X14) 24222918 COVER, TRANS CONV 24222918 COVER, TRANS (0.679) 24205900 COVER, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] (6D04-030) - 2008 DM69 ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР ↓ 18012741 SWITCH, BRK FLUID LVL IND (*KIT1) (ACDelco #18012741) 22688449 CAP, BRK M/CYL RSVR (INCLS 3) (*KIT1) [КРЫШКА БАЧКА ТОРМОЗНОЙ ЖИДКОСТИ] not found DIAPHRAGM, BRK M/CYL RSVR (ЧАСТЬ OF 2) (*KIT1) not found PIN, BRK M/CYL RSVR (ЧАСТЬ OF 5) (*KIT1) 18046711 RESERVOIR, BRK M/CYL (INCLS 4, 6, 7) (*KIT1) (ACDelco #18046711) not found SEAL, BRK M/CYL RSVR (ЧАСТЬ OF 5) (*KIT1) not found SEAL, BRK M/CYL RSVR (ЧАСТЬ OF 5) (*KIT1) not found RETAINER, BRK M/CYL PRIM PSTN SPR (*KIT1) not found PISTON, BRK M/CYL PRIM (*KIT1) not found SEAL, BRK M/CYL SECD PSTN PRIM (*KIT1) not found RETAINER, BRK M/CYL SECD PSTN SPR (*KIT1) not found SEAL, BRK M/CYL (*KIT1) teamcadillac.ru not found PISTON, BRK M/CYL SECD (*KIT1) not found ПРУЖИНА, BRK M/CYL SECD PSTN (*KIT1) not found BODY, BRK M/CYL (*KIT1) 15267509 CYLINDER, BRK MAS (INCLS 1-15) [БЛОК ЦИЛИНДРОВ] (6D04-033) - 2008 DM69 ТОРМОЗНОЙ УСИЛИТЕЛЬ ↓ 15267511 BOOSTER, P/B (INCLS 2-5) [ГИДРОУСИЛИТЕЛЬ ТОРМОЗНОЙ СИСТЕМЫ] not found GROMMET, P/B BOOS VAC CHK VLV (ЧАСТЬ OF 1, 3) 18022219 VALVE KIT, P/B BOOS VAC CHK (ЧАСТЬ OF 1) (INCLS 2) (BLACK) (INCLS VLV & GROM) (ACDelco #179-1266) 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 1) (0.80 IN) (PUSH IN) 15849743 ROD, BRK PED PUSH (ЧАСТЬ OF 1) (6D04-047) - 2008 DM69 ТОРМОЗНАЯ ПЕДАЛЬ ↓ not found REINFORCEMENT, STRG COL SUPT BRKT 25785092 BARRIER, BRK PED BRKT SND teamcadillac.ru 25913292 BARRIER, BRK PED BRKT SND not found BRACKET, BRK PED (ЧАСТЬ OF 13) not found ГАЙКА, BRK PED BRKT BR (ЧАСТЬ OF 13) 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (ЧАСТЬ OF 13) (ACDelco #11517518) [БОЛТ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] not found STUD, BRK PED BRKT (ЧАСТЬ OF 13) not found BRACKET, BRK PED (ЧАСТЬ OF 13) 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 13) (0.80 IN) (PUSH IN) 15849743 ROD, BRK PED PUSH (ЧАСТЬ OF 13) 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 13) 25771615 COVER, BRK PED (ЧАСТЬ OF 13) 15254562 PEDAL, BRK (W/BRKT) (INCLS 3-5, 7-12, 14-19) 15254563 PEDAL, BRK (W/BRKT) (INCLS 3-5, 7-12, 14-19) 25814705 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 13) (INCLS 19) [ДАТЧИК] not found PIN, BRK PED PUSH ROD (ЧАСТЬ OF 13) not found PIN, BRK PED PIV (ЧАСТЬ OF 13) 15594358 BUSHING, BRK PED PIV (ЧАСТЬ OF 13) (0.831) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 13) 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 13, 14) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] (6D04-053) - 2008-2010 DM69 6-ТИ СКОРОСТНАЯ МКПП ЧАСТЬ 1 (MV7) ASM ↓ 24242917 ТРАНСМИССИЯ, MAN [ТРАНСМИССИЯ] (6D04-054) - 2008-2010 DM69 6-ТИ СКОРОСТНАЯ МКПП ЧАСТЬ 2 (MV7) CASE COMPONENTS ↓ 89058852 БОЛТ, CLU ACTR (M6X1.0X20) 89048559 БОЛТ, CLU ACTR (M8X1.25X20) (4.104) 89058759 CASE, TRANS INTER (INCLS 8, 9) 89058774 BEARING, SHFT CONT SHF (ЧАСТЬ OF 7) (4.408) 89058791 PIN, TRANS INTER CASE LOC (ЧАСТЬ OF 7) 19178542 CASE, TRANS FRT (INCLS 12-16) 89058833 SEAL, MAIN SHF (ЧАСТЬ OF 11) not found SHIELD, INPUT SHF BRG OIL (ЧАСТЬ OF 11) 89058791 PIN, TRANS INTER CASE LOC (ЧАСТЬ OF 11) 89059311 PIN, TRANS CASE LOC (ЧАСТЬ OF 11) 89059312 PLUG, TRANS CASE HOLE (ЧАСТЬ OF 11) not found TROUGH, TRANS RR CASE OIL 89058837 SLINGER, INPUT SHF BRG OIL 89058839 TROUGH, M/TRNS OIL 89058840 TROUGH, TRANS INTER CASE OIL not found RETAINER, CNTR GR BRG 89058820 RETAINER, CNTR GR BRG (4.352) 89058760 CASE, TRANS RR (INCLS 24-26) teamcadillac.ru not found BUSHING, SHFT SHF (ЧАСТЬ OF 23) 89058774 BEARING, SHFT SHF (ЧАСТЬ OF 23) 89058791 PIN, TRANS INTER CASE LOC (ЧАСТЬ OF 23) 89058853 БОЛТ, TRANS INTER CASE (M10X1.25X40) (4.104) 89058854 БОЛТ, TRANS INTER CASE (M10X1.25X80) (4.104) 89059319 GASKET, TRANS RR CASE 89058843 PLUG, CLU HSG HOLE 89059313 VENT, M/TRNS 89059314 SEAL, REV IDLER GR SHF (O RING) (ACDelco #89059314) 89048245 GASKET, TRANS OIL DRN PLUG (ACDelco #89048245) 19132842 PLUG, TRANS OIL DRN (4.510) 89059315 БОЛТ, REV IDLER GR SHF RET 19132971 PLUG, SHFT SHF DTNT 89048559 БОЛТ, TRANS INTER CASE OIL TROUGH (M8X1.25X20) (4.104) 89058855 БОЛТ, CNTR GR BRG RET (M8X1.25X25) 89058860 DETENT, SHFT SHF 89059329 DETENT, SHFT SHF (CAM) 19178544 ПРУЖИНА, SHFT SHF DTNT 89048248 PLUG, TRANS OIL FIL 89048248 PLUG, TRANS OIL FIL (4.104) 19178541 EXTENSION, TRANS (INCLS 87, 88) 89058838 SLINGER, INPUT SHF BRG OIL (ЗАДНИЙ) (ЧАСТЬ OF 86) 19180996 SEAL, SHFT CONT SHF (ЧАСТЬ OF 86) 89058835 SEAL, RR ВЫХОДНОЙ SHF 88972750 БОЛТ, TRANS EXTN (M8X1.25X40) (8.900) 19178540 FLANGE, TRANS PROP SHF 19132973 ГАЙКА, PROP SHF TRANS FLG 89058775 BEARING, REV IDLER GR 89058836 SEAL, PROP SHF TRANS FLG FLUID 89058790 SHAFT, REV IDLER GR 89058789 GEAR, REV IDLER 89059321 SWITCH, B/U LP (ACDelco #D2271C) 89059318 RETAINER, B/U LP SW 89058851 SENSOR, M/TRNS ВЫХОДНОЙ SPD (4.337) 89058851 SENSOR, M/TRNS ВЫХОДНОЙ SPD 89058852 БОЛТ, VEH SPD SEN (M6X1.0X20) (0.780) 89058852 БОЛТ, VEH SPD SEN (M6X1.0X20) (0.780) 24242161 CYLINDER, CLU ACTR [ЦИЛИНДР] 89048245 GASKET, TRANS OIL FILL PLUG (ACDelco #89048245) (6D04-055) - 2008-2010 DM69 6-ТИ СКОРОСТНАЯ МКПП ЧАСТЬ 3 (MV7) ВХОДНОЙ И ВЫХОНОЙ ВАЛ COMPONENTS ↓ 89058782 BEARING, RR ВЫХОДНОЙ MAIN SHF RR 89058801 RING, 3RD GR BLOCKING 89058812 SLINGER, MAIN SHF BRG OIL (4.345) 19178534 SHAFT, RR MAIN 19132975 WASHER, 3RD GR THR 89058805 HUB, 3RD & 4TH GR SYN 19132845 SLEEVE, 3RD & 4TH GR SYN 19178535 INSERT, 3RD & 4TH GR SYN 89058792 RING, 4TH GR BLOCKING 19132849 ПРУЖИНА, 3RD & 4TH GR SYN 89058806 HUB, 5TH & 6TH GR SYN 89058810 BALL, 3RD & 4TH GR SYN DTNT 89058776 BEARING, INPUT SHF (RADIAL BALL) 89058777 BEARING, 4TH GR 89058779 BEARING, 6TH GR 89058778 BEARING, 3RD GR 89058780 BEARING, INPUT SHF (ROLLER) (ROLLER) 89058781 BEARING, RR ВЫХОДНОЙ SHF FRT 89059345 RING KIT, 3RD & 4TH GR RET 89059346 RING KIT, 5TH & 6TH GR SYN RET 89059347 RING KIT, 6TH GR RET 89059348 RING KIT, INPUT SHF BRG RET 89058813 RING, INPUT SHF BRG RET 89058863 SPACER, 6TH GR BRG 89058861 SPACER, 3RD & 4TH GR 89058864 SPACER, RR MAIN SHF RR BRG 89048344 PIN, GR THR WA LOC (4.419) 19178537 GEAR, 3RD 19178538 GEAR, 4TH 19178536 GEAR, 6TH 19178539 SHAFT, INPUT teamcadillac.ru 89058773 GEAR, VEH SPD SEN DRV 89048423 BALL, SPEEDO DRV GR LOC 89058810 BALL, 5TH GR SYN DTNT 19178535 INSERT, 5TH & 6TH GR SYN not found ПРУЖИНА, 5TH & 6TH GR SYN 19132849 ПРУЖИНА, 5TH & 6TH GR SYN 19132845 SLEEVE, 5TH & 6TH GR SYN 89058792 RING, 6TH GR BLOCKING (4.383) 89058792 RING, 5TH GR BLOCKING (6D04-056) - 2008-2010 DM69 6-ТИ СКОРОСТНАЯ МКПП ЧАСТЬ 4 (MV7) COUNTERSHAFT COMPONENTS ↓ 89058794 RING SET, 1ST GR BLOCKING (INCLS 96-98) not found CONE, 1ST GR SYN INR (ЧАСТЬ OF 95) not found CONE, 1ST GR SYN OTR (ЧАСТЬ OF 95) not found RING, 1ST GR OTR BLOCKING (ЧАСТЬ OF 95) 89058786 GEAR, REV GR DRV 89058865 BUSHING, REV GR BRG 89058807 HUB, 1ST & 2ND GR SYN 89058803 SLEEVE, 1ST & 2ND GR SYN 89058808 INSERT, 1ST & 2ND GR SYN 89058809 INSERT, REV GR SYN 89058793 RING, REV GR BLOCKING 89058811 ПРУЖИНА, 1ST & 2ND GR SYN 89058804 SLEEVE, REV GR SYN 89058810 BALL, 1ST & 2ND GR SYN DTNT 89058783 BEARING, CNTR GR FRT 89058785 BEARING, REV GR 89058787 BEARING, 1ST GR 89058788 BEARING, 2ND GR 89058784 BEARING, CNTR GR RR 89059343 RING, CNTR GR FRT BRG RET not found RING KIT, 1ST & 2ND GR SYN HUB RET 89059344 RING KIT, 1ST & 2ND GR SYN HUB RET 89058822 RETAINER, CNTR GR FRT BRG 89048423 BALL, REV GR THR WA LOC (4.345) 89048329 ПРУЖИНА, REV GR SYN (4.384) 89058770 GEAR, 1ST 19178532 GEAR, 2ND 19178533 GEAR, CNTR teamcadillac.ru 89058769 GEAR, REV 89058794 RING SET, 2ND GR BLOCKING (INCLS 905-907) not found RING, 2ND GR OTR BLOCKING (ЧАСТЬ OF 904) not found CONE, 2ND GR SYN OTR (ЧАСТЬ OF 904) not found CONE, 2ND GR SYN INR (ЧАСТЬ OF 904) 89059343 RING, CNTR GR FRT BRG RET (6D04-057) - 2008-2010 DM69 6-ТИ СКОРОСТНАЯ МКПП ЧАСТЬ 5 (MV7) SHIFT FORKS ↓ 19180997 JOINT, M/TRNS SHFT LVR ROD UNIVERSAL 19180067 PIN, M/TRNS SHFT LVR not found RETAINER, M/TRNS SEL SHF LVR ROD GROM 89059340 BRACKET, SHFT CONT LVR 89059331 CAM, SHFT SHF DTNT 89058762 FORK, 1ST & 2ND SHFT (INCLS BUSHINGS) 89058763 FORK, 3RD & 4TH SHFT (INCLS INSERTS) 89059342 ARM, CONT SEL 89058825 PIN, CONT SEL ARM 89058764 FORK, 5TH & 6TH SHFT (INCLS INSERTS) 89059332 LEVER, SHFT 19132858 LEVER, INTL SHFT CONT 19132857 LEVER, SEL CONT 89058830 SHAFT, 1ST & 2ND SHFT 89059333 SHAFT, 3RD & 4TH SHFT 89059335 SHAFT, 5TH & 6TH SHFT 19132859 SHAFT, REV SHFT 89058832 LEVER, SHFT SHF DTNT 89058765 FORK, REV SHFT (INCLS INSERTS) 89058829 SHAFT, SHFT CONT teamcadillac.ru 89059329 DETENT, SHFT SHF (CAM) (CAM) 89048287 БОЛТ, 3RD & 4TH SHFT FORK 89048272 PIN, SEL CONT LVR (4.008) 89048289 PIN, REV SHFT FORK (4.303) 89059339 ROLLER, SHFT SHF DTNT 19178531 ПРУЖИНА, SHFT DTNT BALL 19178544 ПРУЖИНА, SHFT SHF DTNT 89058857 БОЛТ, SHFT SHF DTNT LVR (M8X1.0X21.2) 89059338 PIN, SHFT SHF INTLK (M4X11.2) 89059337 PIN, SHFT SHF INTLK (M6X13.6) 89048292 BALL, SHFT DTNT 89058858 БОЛТ, SHFT CONT LVR BRKT (M8X1.25X32) 89058824 RETAINER, SEL CONT LVR PIN 89059316 PIN, SHFT SHF (4.408) 89058842 WEIGHT, SHFT LVR C/BAL (EXTERNAL) (4.105) 89059320 BLOCK, SHFT CONT SHF 89048272 PIN, SHFT LVR (4.008) 89048272 PIN, 1ST & 2ND SHFT FORK (4.008) 89048287 БОЛТ, 5TH & 6TH SHFT FORK (6D04-063) - 2008-2009 DM69 КОРПУС КП КРЕПЛЕНИЕ (ПОЛНОПРИВОДНЫЙ MX7) ↓ teamcadillac.ru 24231525 GASKET, TRFER CASE 24249544 CASE, TRFER (W/GEARS) 11589341 БОЛТ - HFH, M10X1.5X69.9, 28.35 THD, 22.3 OD, 10.9, GMW3359, M-PT. (TRFER CASE) [БОЛТ] 19179016 DAMPENER, TRFER CASE VIB (AT RR OF CASE) (6D04-072) - 2008-2009 DM69 ТОРМОЗНЫЕ МАГИСТРАЛИ-ПЕРЕДНИЕ (ЗАДНИЙ КОЛЕСО DRIVE MN6,MX0) ↓ 15904905 PIPE, BRK PRESS MOD VLV FRT [ТРУБКА ТОРМОЗНОЙ СИСТЕМЫ] 15904915 SPACER, FRT BRK PIPE not found CYLINDER, BRK MAS (СМ. ГРУППУ 04.000 "ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 15904908 PIPE, BRK PRESS MOD VLV RR [НАСОС В СБОРЕ] not found БОЛТ, FRT BRK HOSE (ЧАСТЬ OF 8, 20) 21012386 WASHER, FRT BRK HOSE (ЧАСТЬ OF 8, 20) (10.3X14.5X1.61) (COPPER) (ACDelco #21012386) [ШАЙБА 10 ММ] 11516546 БОЛТ, HFL, M8X1.25X50, 37.2 THD, 18 OD, 10.9, PZO 7114M (FRT S/ABS) 15818105 HOSE, FRT BRK (INCLS 5, 6, 9, 10) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ] teamcadillac.ru 11569742 RETAINER, FRT BRK HOSE (ЧАСТЬ OF 8, 20) (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] not found BRACKET, FRT BRK HOSE (ЧАСТЬ OF 8) 11514623 БОЛТ, HEX W/CON WA, M6X1X20 (FRT BRK HOSE) 11569751 ГАЙКА, HX TUBE INVERTED FLARE, M10X1X16, SAE1010, GMW4707M (FRT BRK PIPE) [ШАЙБА] 88983905 PIPE, BRK (3/16" X 16 FT) (BULK TUBING) (NYLON COATING) [ТРУБКА ТОРМОЗНОЙ СИСТЕМЫ] 25957289 RETAINER, FRT BRK PIPE (4 TUBE W/TREE) 15904901 RETAINER, FRT BRK PIPE (STAR SHAPED 3 TUBE W/TREE) [КРОНШТЕЙН] 12477665 PROTECTOR, FRT BRK PIPE (FOR 1/4" PIPE) (HT SHRINK) not found VALVE, BRK PRESS MOD (W/ELEK BRK & TRACT CONT MDL) (СМ. ГРУППУ 04.000 "КЛАПАН РЕГУЛИРОВКИ ДАВЛЕНИЯ В ТОРМОЗНОЙ СИСТЕМЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11569750 ГАЙКА, HX FLARED TUBE, M12X1.0X17, 5.3 TUBE, SAE1010, GMW4707M (FRT BRK PIPE) [ФИТИНГ ТРУБКИ ТОРМОЗНОЙ СИСТЕМЫ] not found BRACKET, FRT BRK HOSE (ЧАСТЬ OF 20) 15818106 HOSE, FRT BRK (INCLS 5, 6, 9, 19) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ] (6D04-073) - 2008-2009 DM69 ТОРМОЗНЫЕ МАГИСТРАЛИ-ПЕРЕДНИЕ (ПОЛНОПРИВОДНЫЙ MX7) ↓ 15904910 PIPE, BRK PRESS MOD VLV RR [ТРУБКА] 15904915 SPACER, FRT BRK PIPE not found CYLINDER, BRK MAS (СМ. ГРУППУ 04.000 "ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 15904907 PIPE, BRK PRESS MOD VLV FRT [НАСОС В СБОРЕ] 11570052 FITTING, FRT BRK HOSE (ЧАСТЬ OF 7) (M10X1X27.5, 16.9THD) (4.671) 21012386 WASHER, FRT BRK HOSE (ЧАСТЬ OF 7) (10.3X14.5X1.61) (COPPER) (ACDelco #21012386) [ШАЙБА 10 ММ] teamcadillac.ru 25928987 HOSE, FRT BRK (INCLS 5, 6) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ] 25928988 HOSE, FRT BRK (INCLS 5, 6) 11516521 БОЛТ, HFH M6X1X20, 9.8, 7114M, DOG PT, 14.2 OD (FRT BRK HOSE) 11569742 RETAINER, FRT BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 11569751 ГАЙКА, HX TUBE INVERTED FLARE, M10X1X16, SAE1010, GMW4707M (FRT BRK PIPE) [ШАЙБА] 88983905 PIPE, BRK (3/16" X 16 FT) (BULK TUBING) (NYLON COATING) [ТРУБКА ТОРМОЗНОЙ СИСТЕМЫ] 15904902 RETAINER, FRT BRK PIPE (UPSIDE DOWN 3 TUBE CLIP W/O TREE) [КРОНШТЕЙН] 15904903 RETAINER, FRT BRK PIPE (UPSIDE DOWN 3 TUBE WITH TREE) [КРОНШТЕЙН] 12477665 PROTECTOR, FRT BRK PIPE (FOR 1/4" PIPE) (HT SHRINK) 88964150 PROTECTOR, FRT BRK PIPE (FOR 3/16" PIPE) (HT SHRINK) 15904901 RETAINER, FRT BRK PIPE (STAR SHAPED 3 TUBE W/TREE) [КРОНШТЕЙН] not found VALVE, BRK PRESS MOD (W/ELEK BRK & TRACT CONT MDL) (СМ. ГРУППУ 04.000 "КЛАПАН РЕГУЛИРОВКИ ДАВЛЕНИЯ В ТОРМОЗНОЙ СИСТЕМЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11569750 ГАЙКА, HX FLARED TUBE, M12X1.0X17, 5.3 TUBE, SAE1010, GMW4707M (FRT BRK PIPE) [ФИТИНГ ТРУБКИ ТОРМОЗНОЙ СИСТЕМЫ] (6D04-074) - 2008 DM69 ТОРМОЗНЫЕ МАГИСТРАЛИ-ЗАДНИЕ ↓ 15818185 HOSE, RR BRK (INCLS 2, 3, 5, 6) [ТРУБКА] 21012386 WASHER, RR BRK HOSE (ЧАСТЬ OF 1, 12) (10.3X14.5X1.61) (COPPER) (ACDelco #21012386) [ШАЙБА 10 ММ] not found БОЛТ, RR BRK HOSE (ЧАСТЬ OF 1, 12) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (RR BRK HOSE BRKT) [ГАЙКА М6] not found BRACKET, RR BRK HOSE (ЧАСТЬ OF 1) 11569742 RETAINER, RR BRK HOSE (ЧАСТЬ OF 1) (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 11569742 RETAINER, RR BRK HOSE (ЧАСТЬ OF 1) (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 11569751 ГАЙКА, HX TUBE INVERTED FLARE, M10X1X16, SAE1010, GMW4707M (RR BRK PIPE) [ШАЙБА] 88983905 PIPE, BRK (3/16" X 16 FT) (BULK TUBING) (NYLON COATING) [ТРУБКА ТОРМОЗНОЙ СИСТЕМЫ] 15194329 CLIP, RR BRK PIPE (27X35X15) 88964150 PROTECTOR, FRT BRK PIPE (FOR 3/16" PIPE) (HT SHRINK) 15818187 HOSE, RR BRK (INCLS 2, 3) [ТРУБКА] 25607191 RETAINER, BRK PIPE (21.5X10.0MM) (HOLDS (2) 4.68-4.82 TUBES) 25607191 RETAINER, BRK PIPE (21.5X10.0MM) (HOLDS (2) 4.68-4.82 TUBES) 15870391 RETAINER, BRK & FUEL PIPE (HOLDS FOUR LINES) 15870391 RETAINER, BRK & FUEL PIPE (HOLDS FOUR LINES) (3.162) 11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (FUEL FLTR BRKT) [БОЛТ М8] 15223307 RETAINER, BRK & FUEL PIPE (2 FUEL/VAPOR LINES) 15223307 RETAINER, BRK & FUEL PIPE (2 FUEL/VAPOR LINES) (3.162) teamcadillac.ru 15223304 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (HOLDS FOUR LINES) (3.890) 15223306 RETAINER, BRK & FUEL PIPE (2 FUEL/VAPORS LINE & 2 BRAKE LINES) 15223306 RETAINER, BRK & FUEL PIPE (2 FUEL/VAPORS LINE & 2 BRAKE LINES) (3.162) 88964150 PROTECTOR, BRK PIPE (FOR 3/16" PIPE) (HT SHRINK) 15223308 RETAINER, BRK & FUEL PIPE (ATTACHES TO BRKT) 15223308 RETAINER, BRK & FUEL PIPE (ATTACHES TO BRKT) (3.162) 25761218 BRACKET, FUEL PIPE 11514623 БОЛТ, HEX W/CON WA, M6X1X20 (FUEL FEED & EVAP EMIS & RTN PIPE CLIP BRKT) 25957289 RETAINER, FRT BRK PIPE (4 TUBE W/TREE) 11569750 ГАЙКА, HX FLARED TUBE, M12X1.0X17, 5.3 TUBE, SAE1010, GMW4707M (FRT BRK PIPE) [ФИТИНГ ТРУБКИ ТОРМОЗНОЙ СИСТЕМЫ] not found VALVE, BRK PRESS MOD (W/ELEK BRK & TRACT CONT MDL) (СМ. ГРУППУ 04.000 "КЛАПАН РЕГУЛИРОВКИ ДАВЛЕНИЯ В ТОРМОЗНОЙ СИСТЕМЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6D04-076) - 2008-2009 DM69 СТОЯНОЧНЫЙ ТОРМОЗ SYSTEM ↓ 15836531 REINFORCEMENT, PARK BRK LVR BRKT (INCLS 2) 11610157 ГАЙКА, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (ЧАСТЬ OF 1) (10.701) [ГАЙКА М4] 25880964 HANDLE, PARK BRK REL 11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (PARK BRK REL HDL) [ВИНТ] 25791543 CABLE, PARK BRK REL (ЧАСТЬ OF 6) 25885037 LEVER, PARK BRK (INCLS 5, 7-9) not found PAD, PARK BRK LVR PED (ЧАСТЬ OF 6) 10369646 БОЛТ, PARK BRK IND SW (ЧАСТЬ OF 6) 22654577 SWITCH, PARK BRK IND (ЧАСТЬ OF 6) (ACDelco #22654577) [ВКЛЮЧАТЕЛЬ] 15242114 CABLE, PARK BRK INTER (INCLS 14) [КАБЕЛЬ] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (PARK BRK INTER CBL GDE) [ГАЙКА М6] 11518625 БОЛТ, PAN, M10X1.5X35, 33.5THD, 20 O.D., 10.9, 6138M (PARK BRK INTER CBL GDE) 20774147 CABLE, PARK BRK RR 20823796 CONNECTOR, PARK BRK CBL (ЧАСТЬ OF 10) teamcadillac.ru 11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (I/P LWR BRKT) [ВИНТ] 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (PARK BRK REL HDL BRKT) [ВИНТ М4] (6D04-077) - 2008-2009 DM69 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (MYB, ПОЛНОПРИВОДНЫЙ MX7, EXC EXTRA CAPACITY V03, HEAVY DUTY V08) ↓ 24237658 SEAL, TRANS FLUID CLR PIPE FTG (SEALS ONE PIPE) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ] 15251488 SEAL, TRANS FLUID CLR HOSE (ЧАСТЬ OF 4) (SEALS TWO ТРУБКИ) [УПЛОТНЕНИЕ] 11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) [БОЛТ, М8Х1.25Х31.5] 15853683 HOSE, TRANS FLUID CLR (INCLS 2, 6, 7, 10) [ТРУБКА] teamcadillac.ru 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 10405874 CLIP, TRANS FLUID CLR HOSE (ЧАСТЬ OF 4) (LESS MNTG TAB) (HOLDS TWO 9.5 DIA TUBES) 15052228 CЛАМПА, TRANS FLUID CLR HOSE (ЧАСТЬ OF 4) (PLASTIC RETAINER) (ACDelco #15052228) [ФИТИНГ ТРУБОПРОВОДА] not found FITTING, TRANS FLUID CLR PIPE not found RETAINER, TRANS FLUID CLR PIPE FTG not found BRACKET, TRANS OIL CLR INL & OTLT PIPE (ЧАСТЬ OF 4) (6D04-078) - 2008 DM69 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (MYB, ЗАДНИЙ КОЛЕСО DRIVE MX0, EXC EXTRA CAPACITY V03, HEAVY DUTY V08) ↓ 24237658 SEAL, TRANS FLUID CLR PIPE FTG (SEALS ONE PIPE) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ] 15251488 SEAL, TRANS FLUID CLR HOSE (ЧАСТЬ OF 3) (SEALS TWO ТРУБКИ) [УПЛОТНЕНИЕ] 15267714 HOSE, TRANS FLUID CLR (INCLS 2, 5, 6, 9) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] teamcadillac.ru 11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) [БОЛТ, М8Х1.25Х31.5] 10405874 CLIP, TRANS FLUID CLR HOSE (ЧАСТЬ OF 3) (LESS MNTG TAB) (HOLDS TWO 9.5 DIA TUBES) 15052228 CЛАМПА, TRANS FLUID CLR HOSE (ЧАСТЬ OF 3) (PLASTIC RETAINER) (ACDelco #15052228) [ФИТИНГ ТРУБОПРОВОДА] not found FITTING, TRANS FLUID CLR PIPE not found RETAINER, TRANS FLUID CLR PIPE FTG not found BRACKET, TRANS OIL CLR INL & OTLT PIPE (ЧАСТЬ OF 3) 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] (6D04-079) - 2008-2009 DM69 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (MYB, ПОЛНОПРИВОДНЫЙ MX7, EXTRA CAPACITY V03, HEAVY DUTY V08) ↓ 25829909 COOLER, TRANS FLUID AUX (INCLS 13-15) (ACDelco #25829909) [ОХЛАДИТЕЛЬ] teamcadillac.ru not found RETAINER, TRANS FLUID CLR PIPE FTG 25830126 CLIP, TRANS FLUID CLR PIPE not found BRACKET, TRANS OIL CLR INL & OTLT PIPE (ЧАСТЬ OF 8) 24237658 SEAL, TRANS FLUID CLR PIPE FTG (SEALS ONE PIPE) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ] 15251488 SEAL, TRANS FLUID CLR HOSE (ЧАСТЬ OF 8) (SEALS TWO ТРУБКИ) [УПЛОТНЕНИЕ] 11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) [БОЛТ, М8Х1.25Х31.5] 25829902 HOSE, TRANS FLUID CLR (INCLS 4, 6, 11) [ШЛАНГ] 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 10405874 CLIP, TRANS FLUID CLR HOSE (LESS MNTG TAB) (HOLDS TWO 9.5 DIA TUBES) 15052228 CЛАМПА, TRANS FLUID CLR HOSE (ЧАСТЬ OF 8) (PLASTIC RETAINER) (ACDelco #15052228) [ФИТИНГ ТРУБОПРОВОДА] 25829910 PIPE, TRANS FLUID AUX CLR (INCLS 17) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 19129762 FITTING, TRANS FLUID CLR PIPE (ЧАСТЬ OF 1) [СОЕДИНИТЕЛЬ] 24205103 RETAINER, TRANS FLUID AUX CLR (ЧАСТЬ OF 1) (EXPANDING ПРУЖИНА WIRE) (ACDelco #24205103) [СТОПОРНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ] 10405874 CLIP, TRANS FLUID CLR HOSE (ЧАСТЬ OF 1) (LESS MNTG TAB) (HOLDS TWO 9.5 DIA TUBES) 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 15052228 CAP, TRANS FLUID CLR PIPE CONN (ЧАСТЬ OF 12) (PLASTIC RETAINER) (ACDelco #15052228) [ФИТИНГ ТРУБОПРОВОДА] not found FITTING, TRANS FLUID CLR PIPE (6D04-080) - 2008 DM69 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (MYB, ЗАДНИЙ КОЛЕСО DRIVE MX0, EXTRA CAPACITY V03, HEAVY DUTY V08) ↓ 25829909 COOLER, TRANS FLUID AUX (INCLS 13-15) (ACDelco #25829909) [ОХЛАДИТЕЛЬ] not found RETAINER, TRANS FLUID CLR PIPE FTG 25830126 CLIP, TRANS FLUID CLR PIPE 11516149 ГАЙКА, U, 8X1.25, MULTI THD, .08'-4.0' THK PNL, PZ (TRANS FLUID CLR HOSE CLIP BRKT) [ГАЙКА М8] 24237658 SEAL, TRANS FLUID CLR PIPE FTG (SEALS ONE PIPE) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ] 15251488 SEAL, TRANS FLUID CLR HOSE (ЧАСТЬ OF 8) (SEALS TWO ТРУБКИ) [УПЛОТНЕНИЕ] 11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) [БОЛТ, М8Х1.25Х31.5] teamcadillac.ru 25829896 HOSE, TRANS FLUID CLR (INCLS 6, 9, 11, 19) [ШЛАНГ] 10405874 CLIP, TRANS FLUID CLR HOSE (ЧАСТЬ OF 8) (LESS MNTG TAB) (HOLDS TWO 9.5 DIA TUBES) 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] not found BRACKET, TRANS OIL CLR INL & OTLT PIPE (ЧАСТЬ OF 8) 25829910 PIPE, TRANS FLUID AUX CLR (INCLS 17) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 19129762 FITTING, TRANS FLUID CLR PIPE (ЧАСТЬ OF 1) [СОЕДИНИТЕЛЬ] 24205103 RETAINER, TRANS FLUID AUX CLR (ЧАСТЬ OF 1) (EXPANDING ПРУЖИНА WIRE) (ACDelco #24205103) [СТОПОРНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ] not found CLIP, TRANS FLUID CLR HOSE (ЧАСТЬ OF 1) 11570324 БОЛТ, TRANS FLUID CLR (M6X1X14, 9 THD) (9.190) 15052228 CAP, TRANS FLUID CLR PIPE CONN (ЧАСТЬ OF 12) (PLASTIC RETAINER) (ACDelco #15052228) [ФИТИНГ ТРУБОПРОВОДА] not found FITTING, TRANS FLUID CLR PIPE 15052228 CЛАМПА, TRANS FLUID CLR HOSE (ЧАСТЬ OF 8) (PLASTIC RETAINER) (ACDelco #15052228) [ФИТИНГ ТРУБОПРОВОДА] (6D04-081) - 2008 DM69 BRAKES-ВЕНТИЛЯЦИЯ ↓ 25940079 EXTENSION, FRT BPR FASCIA (СМ. ГРУППУ 07.000 "БАМПЕР ПЕРЕДНИЙ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/HOLE) [ПОДКРЫЛОК] 25940080 EXTENSION, FRT BPR FASCIA (СМ. ГРУППУ 07.000 "БАМПЕР ПЕРЕДНИЙ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/HOLE) [БОКОВАЯ ПАНЕЛЬ БАМПЕРА] 15272166 DUCT, FRT BRK CLPR CLG (CONNECTS TO FRT WHL EXTN) [ТРУБКА ВОЗДУХОВОДА] 15272167 DUCT, FRT BRK CLPR CLG (CONNECTS TO FRT FASCIA) [ТРУБКА] 15272168 DUCT, FRT BRK CLPR CLG (CONNECTS TO FRT FASCIA) [ТРУБКА] 20772527 DUCT, FRT BRK CLPR CLG (CONNECTS TO FRT FASCIA) [ВОЗДУХОЗАБОРНИК ТОРМОЗНОЙ СИСТЕМЫ] 20772528 DUCT, FRT BRK CLPR CLG (CONNECTS TO FRT FASCIA) [ВОЗДУХОЗАБОРНИК ТОРМОЗНОЙ СИСТЕМЫ] 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (FRT FOG LP BRKT) [ВИНТ М4] 25536302 ГАЙКА, FRT BPR UPR FASCIA (4.2 X 1.41) (TAPPING NUT) (3.430) [ПРИЖИМНАЯ ПЛАСТИНА ПАНЕЛИ КУЗОВА] 15272157 BEZEL, FRT FOG LP (FOR VEHICLES BUILT W/FRONT BRAKE ОХЛАЖДЕНИЕ DUCTS) (ON VEH BUILT BEFORE 3/31/08 OR IF REPLACED BEZEL HAS OPENINGS/SLOTSMUST ALSO ORDER 25961369) 15904574 BEZEL, FRT FOG LP [НАКЛАДКА ПАНЕЛИ БАМПЕРА] 15904575 BEZEL, FRT FOG LP [ОКАНТОВКА ПРОТИВОТУМАННОЙ ФАРЫ] 25961369 BEZEL, FRT FOG LP (FOR VEHICLES BUILT W/ FRONT BRAKE ОХЛАЖДЕНИЕ DUCTS) (ON VEH BUILT BEFORE 3/31/08 OR IF REPLACED BEZEL HAS OPENINGS/SLOTS, MUST ALSO ORDER 25961370) 10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (FRT BRK CLPR CLG DUCT) [ПИСТОН КРЕПЛЕНИЯ ОБЛИЦОВКИ БАМПЕРА (NYLON)] teamcadillac.ru 11561857 CLIP, FRT FOG LP ADJ БОЛТ RET (BLACK) (14.13 X 11 X 8.6) (7.831) (6D04-082) - 2008-2009 DM69 УПРАВЛЕНИЕ АКПП/АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) ↓ 25887055 PLATE, F/FLR CNSL TRANS SHFT OPG TR (INCLS 2, 3, 13-15) [РАМКА РЫЧАГА ПЕРЕКЛЮЧЕНИЯ ПЕРЕДАЧ] 25801116 INDICATOR, A/TRNS CONT (ЧАСТЬ OF 1) 11509231 SCREW, RD HD C/R TAP, M4.2X1.41X13.0, GM6010M STL, GM813M NICKEL ORGANIC (ЧАСТЬ OF 1) [ВИНТ М6Х12] teamcadillac.ru 25907978 CONTROL, A/TRNS (INCLS 5-8) [БЛОК УПРАВЛЕНИЯ] 25907978 CONTROL, A/TRNS (INCLS 5-8) (4.004) [БЛОК УПРАВЛЕНИЯ] 25907979 CONTROL, A/TRNS (INCLS 5-8) [БЛОК УПРАВЛЕНИЯ] 25907979 CONTROL, A/TRNS (INCLS 5-8) (4.004) [БЛОК УПРАВЛЕНИЯ] 25907980 CONTROL, A/TRNS (INCLS 5-8) [БЛОК УПРАВЛЕНИЯ] 25907980 CONTROL, A/TRNS (INCLS 5-8) (4.004) [БЛОК УПРАВЛЕНИЯ] 25907981 CONTROL, A/TRNS (INCLS 5-8) [БЛОК УПРАВЛЕНИЯ] 25907981 CONTROL, A/TRNS (INCLS 5-8) (4.004) [БЛОК УПРАВЛЕНИЯ] 25907982 CONTROL, A/TRNS (INCLS 5-8) [БЛОК УПРАВЛЕНИЯ] 25907982 CONTROL, A/TRNS (INCLS 5-8) (4.004) [БЛОК УПРАВЛЕНИЯ] 25908000 CONTROL, A/TRNS (INCLS 5-8) [БЛОК УПРАВЛЕНИЯ] 25908000 CONTROL, A/TRNS (INCLS 5-8) (4.004) [БЛОК УПРАВЛЕНИЯ] 25824055 KNOB, A/TRNS CONT LVR (ЧАСТЬ OF 4) (INCLS 6) (COCOA) (ALL LEATHER) 25824057 KNOB, A/TRNS CONT LVR (ЧАСТЬ OF 4) (INCLS 6) (EBONY) (SIDE EBONY LEATHER MIDDLE FIGURED SAPELE) 25824059 KNOB, A/TRNS CONT LVR (ЧАСТЬ OF 4) (INCLS 6) (COCOA) (SIDE COCOA LEATHER MIDDLE FIGURED SAPELE) 25824060 KNOB, A/TRNS CONT LVR (ЧАСТЬ OF 4) (INCLS 6) (EBONY) (ALL LEATHER) 11570687 БОЛТ, A/TRNS CONT LVR KNOB (ЧАСТЬ OF 4, 5) 25824062 BOOT, A/TRNS CONT (ЧАСТЬ OF 4) (EBONY) 25824064 BOOT, A/TRNS CONT (ЧАСТЬ OF 4) (COCOA) 25824053 BASE, A/TRNS CONT (ЧАСТЬ OF 4) 25824054 BASE, A/TRNS CONT (ЧАСТЬ OF 4) 11514603 ГАЙКА, M10X1.5 15MM SOCKET (A/TRNS RANGE SEL LVR) [ШАЙБА] 11519095 NUT-ACORN HEX, M8X1.0, 15MM THK, 9, 6047M, W/DOME. (A/TRNS RANGE SEL LVR) [ГАЙКА] 15780844 LINK, A/TRNS RANGE SEL LVR 15780845 LINK, A/TRNS RANGE SEL LVR 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL ROD ADJ) [ГАЙКА М6] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL LVR CBL BRKT) [ГАЙКА М6] 11610112 CLIP, F/FLR CNSL TR PLT (TR PLT TO SI PNL) (ЧАСТЬ OF 1) (10.4 X 13 X 9) (14.683) not found БОЛТ, F/FLR CNSL CVR (ЧАСТЬ OF 1) not found COVER, F/FLR CNSL FRT (ЧАСТЬ OF 1) (6D04-083) - 2008-2010 DM69 УПРАВЛЕНИЕ АКППS/РУЧНАЯ ТРАНСМИССИЯ (MV7) ↓ 25806639 KNOB, M/TRNS CONT LVR (W/BOOT & W/SHFT PATT) (INCLS 13) 25806640 KNOB, M/TRNS CONT LVR (W/BOOT & W/SHFT PATT) (INCLS 13) 25887053 PLATE, F/FLR CNSL TRANS SHFT OPG TR (INCLS 9, 10, 12) 15794036 PLATE, M/TRNS CONT MT 15794035 CONTROL, M/TRNS (W/SHFT PATT) [БЛОК УПРАВЛЕНИЯ] 21996990 PIN, M/TRNS CONT SHF EQLZR LVR (SHIFTER END) 25708836 RETAINER, M/TRNS SHFT LVR 25753853 PIN, M/TRNS CONT SHF EQLZR LVR (TRANS END) teamcadillac.ru 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (M/TRNS CONT BRKT) [ГАЙКА М6] 11509231 SCREW, RD HD C/R TAP, M4.2X1.41X13.0, GM6010M STL, GM813M NICKEL ORGANIC (ЧАСТЬ OF 2) [ВИНТ М6Х12] not found COVER, F/FLR CNSL FRT (ЧАСТЬ OF 2) 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (M/TRNS CONT BRKT) 11570189 CLIP, F/FLR CNSL TR PLT (ЧАСТЬ OF 2) 11610112 CLIP, F/FLR CNSL TR PLT (TR PLT TO SI PNL) (ЧАСТЬ OF 2) (10.4 X 13 X 9) (14.683) not found CAP, M/TRNS SEL LVR (ЧАСТЬ OF 1) (6D04-084) - 2008-2009 DM69 ТОРМОЗНОЙ УСИЛИТЕЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (LP1/2.8T,LY7/3.6-7) ↓ not found CYLINDER, BRK MAS (СМ. ГРУППУ 04.000 "ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] not found REINFORCEMENT, P/B BOOS (ЧАСТЬ OF PANEL, AIR INL GRL - 12.800) 10125439 RIVET, FLAT HD, 3 LEG EXPANSION, M4.8 SHAFT, 23.5 LG, 9.8 O.D., AL (AIR INL GRL PNL) [ЗАКЛЕПКА D=4.8 ММ] not found CYLINDER, CLU MAS (СМ. ГРУППУ 00.000 "ПЕДАЛЬ СЦЕПЛЕНИЯ-ЦИЛИНДРЫ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 24245109 CYLINDER, CLU MAS (СМ. ГРУППУ 00.000 "ПЕДАЛЬ СЦЕПЛЕНИЯ-ЦИЛИНДРЫ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ЦИЛИНДР] 25873484 HOSE, P/B BOOS VAC (ACDelco #176-1497) 25873484 HOSE, P/B BOOS VAC (ACDelco #176-1497) 25923501 HOSE, P/B BOOS VAC not found BOOSTER, P/B (СМ. ГРУППУ 04.000 "ТОРМОЗНОЙ УСИЛИТЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25675835 BRACKET, BRK PED BRKT 15849744 BOOT, BRK PED PUSH ROD 25697461 RETAINER, BRK PED PUSH ROD BOOT 25785092 BARRIER, BRK PED BRKT SND 25913292 BARRIER, BRK PED BRKT SND not found PEDAL, BRK (W/BRKT) (СМ. ГРУППУ 04.000 "ТОРМОЗНАЯ ПЕДАЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11514519 ГАЙКА, BRK PED BRKT (M8X1.25, 7.32 THK) (9510M, ZF) (8.915) [ГАЙКА] not found REINFORCEMENT, P/B BOOS (СМ. ГРУППУ 10.000 "СТЕКЛООЧИСТИТЕЛЬ-ВЕТРОВОГО СТЕКЛА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6D04-085) - 2008 DM69 КЛАПАН РЕГУЛИРОВКИ ДАВЛЕНИЯ В ТОРМОЗНОЙ СИСТЕМЕ ↓ 25853512 МОДУЛЬ, ELEK BRK & TRACT CONT [МОДУЛЬ] 25854972 БОЛТ, ELEK BRK CONT MDL (ECU TO HCU ATTACH) (M4X0.7X19.5, 10THD) not found БОЛТ, ELEK BRK CONT MDL BRKT (*KIT1) teamcadillac.ru not found INSULATOR, BRK PRESS MOD VLV BRKT (*KIT1) not found INSULATOR, BRK PRESS MOD VLV (*KIT1) 15298281 VALVE, BRK PRESS MOD [КЛАПАН] 15286358 INSULATOR KIT, BRK PRESS MOD VLV (INCLS 3-5) (6D04-086) - 2008 DM69 ЭЛЕКТРИЧЕСКАЯ СИСТЕМА АБС ↓ 25996837 SENSOR, FRT WHL SPD (INCLS 2, 3, 6) 15158259 CLIP, WHL SPD SEN WIRE (ЧАСТЬ OF 1, 15) (12.0MM HOLE) 15158261 CLIP, WHL SPD SEN WIRE (ЧАСТЬ OF 1) (11MM HOLE) not found HARNESS, ENG WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/ДВИГАТЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found VALVE, BRK PRESS MOD (W/ELEK BRK & TRACT CONT MDL) (СМ. ГРУППУ 04.000 "BRAKE CONTROL МОДУЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 15715954 CLIP, WHL SPD SEN WIRE (ЧАСТЬ OF 1) (TREE FITS 6.5 HOLE) (HOLDS (1) 10.5MM GROMMET ROUTING (1) 6.35 SPD SEN CBL) 11516521 БОЛТ, HFH M6X1X20, 9.8, 7114M, DOG PT, 14.2 OD (FRT WHL SPD SEN) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (VEH YAW SEN & LATL ACCLRM) teamcadillac.ru 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (VEH YAW SEN & LATL ACCLRM) [БОЛТ М6] not found HARNESS, BODY WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/КУЗОВ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 15845467 SENSOR, VEH YAW (W/VEH LATL ACCLRM) (LABELED 15845467) [ДАТЧИК] 25866179 SENSOR, RR WHL SPD (INCLS 14) 11516521 БОЛТ, HFH M6X1X20, 9.8, 7114M, DOG PT, 14.2 OD (RR WHL SPD SEN) 10317605 CLIP, WHL SPD SEN WIRE (ЧАСТЬ OF 12) (6.8MM HOLE) (9.242) [ЗАЖИМ ДАТЧИКА АБС] 15855539 SENSOR, FRT WHL SPD (INCLS 2, 16, 17) 10317605 CLIP, WHL SPD SEN WIRE (ЧАСТЬ OF 15) (6.8MM HOLE) (9.242) [ЗАЖИМ ДАТЧИКА АБС] not found BRACKET, FRT WHL SPD SEN WIRE (ЧАСТЬ OF 15) 25820819 BRACKET, FRT WHL SPD SEN WIRE (ЧАСТЬ OF 15) 11570352 ГАЙКА, HEX JAM M12X1.75X6, GM510 (5) STL, GMW14100. (WHL SPD SEN BRKT) (6D04-087) - 2008-2009 DM69 УПРАВЛЕНИЕ АКППS/КОРПУС КП (ПОЛНОПРИВОДНЫЙ MX7) ↓ 24244602 МОДУЛЬ, TRFER CASE SHFT CONT [МОДУЛЬ] not found HARNESS, I/P WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found INSULATOR, I/P (СМ. ГРУППУ 10.000 "ПРИБОРНАЯ ПАНЕЛЬ ЧАСТЬ 1" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (BLACK) teamcadillac.ru 11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (I/P INSL) [ВИНТ] 11609370 БОЛТ-HWH, M4.2X1.41X20, HI - LOW THD, , OD 12, 6010 STL, GMW4205, TAP (I/P INSL) (9.667) (6D04-088) - 2008 DM69 ТОРМОЗНОЙ УСИЛИТЕЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (LLT/3.6V) ↓ 15267511 BOOSTER, P/B (СМ. ГРУППУ 04.000 "ТОРМОЗНОЙ УСИЛИТЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ГИДРОУСИЛИТЕЛЬ ТОРМОЗНОЙ СИСТЕМЫ] 25675835 BRACKET, BRK PED BRKT 15849744 BOOT, BRK PED PUSH ROD 25697461 RETAINER, BRK PED PUSH ROD BOOT 25785092 BARRIER, BRK PED BRKT SND 25913292 BARRIER, BRK PED BRKT SND not found PEDAL, BRK (W/BRKT) (СМ. ГРУППУ 04.000 "ТОРМОЗНАЯ ПЕДАЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 15267509 CYLINDER, BRK MAS (СМ. ГРУППУ 04.000 "ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [БЛОК ЦИЛИНДРОВ] 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] 11570167 STUD, P/B BOOS PUMP BRKT (STUD-STRAIGHT, M12X1.75X32.25, M12X1.75X23, 80 OAL, 10.9, E11 TORX) 25806500 BRACKET, VAC PUMP [ВАКУУМНЫЙ НАСОС] 11516075 ГАЙКА, HFH SELF LK, M6X1, 7.7THK, 14.2 O.D., 9, PZOR (P/B BOOS PUMP) [ГАЙКА ВЫПУСКНОЙ СИСТЕМЫ D=6ММ] 11514598 ГАЙКА, HEX FLANGE, M12X1.75X12, 26 OD, 10, 7111M, (P/B BOOS PUMP) [ГАЙКА М12] 11518075 БОЛТ, HFH, THD 22, OD 17, 8.8, GMW14C-PT, HDR POINT (P/B BOOS PUMP) [ВИНТ М10] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (P/S FLUID RSVR) teamcadillac.ru 11589303 БОЛТ-HFH, M6X1X38, 30 THD, 14.2 OD, 8.8 STL, GMW3359, M-PT (P/B BOOS PUMP) 15797569 PUMP, P/B BOOS AUX [НАСОС В СБОРЕ] 20774507 RESERVOIR, P/S FLUID (СМ. ГРУППУ 06.000 "НАСОС РУЛЕВОГО УПРАВЛЕНИЯ LINES" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25926187 HOSE, P/B BOOS VAC (INCLS 21) 25926187 HOSE, P/B BOOS VAC (INCLS 21) not found CЛАМПА, P/B BOOS HSG (ЧАСТЬ OF 20) not found SPACER, P/B BOOS PUMP (*KIT1) not found INSULATOR, P/B BOOS PUMP (*KIT1) 25775922 INSULATOR KIT, P/B BOOS PUMP (INCLS 22, 23) (ON PUMP) (6D04-089) - 2008 DM69 СТОЯНОЧНЫЙ ТОРМОЗ ASM ↓ 15853380 PLATE, RR BRK BKG (17" ТОРМОЗА) 15853415 PLATE, RR BRK BKG (17" ТОРМОЗА) 15853421 PLATE, RR BRK BKG (18" ТОРМОЗА) 15853425 PLATE, RR BRK BKG (18" ТОРМОЗА) not found PIN, RR PARK BRK SHOE (*KIT1) 25693149 BRACKET, PARK BRK CBL (ATTACHES TO RR SUSP) 25693150 BRACKET, PARK BRK CBL (ATTACHES TO RR SUSP) 11517996 ГАЙКА, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (PARK BRK RR CBL BRKT) (ACDelco #11517996) [ГАЙКА М10] teamcadillac.ru 25867413 LEVER, RR PARK BRK ACTR 25814678 SHOE KIT, RR PARK BRK [ТОРМОЗНАЯ КОЛДКА] not found ПРУЖИНА, RR PARK BRK SHOE RTN (*KIT1) not found ПРУЖИНА, RR PARK BRK SHOE HOLDN (*KIT1) not found ПРУЖИНА, RR PARK BRK SHOE RTN (*KIT1) 25867414 ADJUSTER, RR PARK BRK 25814679 ПРУЖИНА KIT, PARK BRK LVR RTN (INCLS 2, 7-9) [ПРУЖИНА] (6D04-098) - 2008-2009 DM69 КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS (ПОЛНОПРИВОДНЫЙ MX7) ↓ 89059523 ГАЙКА, TRFER CASE RR ВЫХОДНОЙ SHF FLG (4.520) 15580315 WASHER, TRFER CASE RR ВЫХОДНОЙ SHF THR (FLAT) (PL, STL) (7/8 I.D. X 1 39/64 O.D., 1/8 THK) (4.510) 15635532 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF FLG (O RING) (4.412) 19179018 FLANGE, TRFER CASE RR ВЫХОДНОЙ SHF 88996681 DEFLECTOR, TRFER CASE RR ВЫХОДНОЙ SHF SEAL DIRT (5.555) 19180065 БОЛТ, TRFER CASE VIB DPNR 19179016 DAMPENER, TRFER CASE VIB (AT RR OF CASE) not found БОЛТ, WRG HARN BRKT 19208066 CASE, TRFER (FRT HALF) 19208080 РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ, TRFER CASE TWO/FOUR WHL DRV CLU 88984499 PIN, TRFER CASE HALF LOC not found BRACKET, WRG HARN 88996657 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF [УПЛОТНИТЕЛЬ] 19208081 ГАЙКА, TRFER CASE TWO/FOUR WHL DRV CLU РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ 19208077 CASE, TRFER (RR HALF) 19206436 RESISTOR, (115 OHMS) 19206437 RESISTOR, (225 OHMS) 19206438 RESISTOR, (453 OHMS) 19206439 RESISTOR, (715 OHMS) 19206440 RESISTOR, (1150 OHMS) 19206441 RESISTOR, (1820 OHMS) 19206442 RESISTOR, (3160 OHMS) 19206443 RESISTOR, (7320 OHMS) 19206444 RESISTOR, (12700 OHMS) 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL FILL) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 19179015 PLUG, TRFER CASE FRT ВЫХОДНОЙ SHF HOLE (INCLS 20) [КРЫШКА КОРПУСА РАЗДАТОЧНОЙ КОРОБКИ] not found SEAL, TRFER CASE ACC HOLE PLUG (O RING) (ЧАСТЬ OF 19) 19208087 RING, TRFER CASE FRT ВЫХОДНОЙ SHF BRG RET 19179158 SENSOR, TRFER CASE FLUID TEMP [ДАТЧИК ТЕМПЕРАТУРЫ МАСЛА РАЗДАТОЧНОЙ КОРОБКИ] 19179158 SENSOR, TRFER CASE FLUID TEMP [ДАТЧИК ТЕМПЕРАТУРЫ МАСЛА РАЗДАТОЧНОЙ КОРОБКИ] 19179014 PLUG, TRFER CASE OIL DRN 88996680 БОЛТ, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN SNBR (M5X0.8X16) 88996679 SNUBBER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN 88996680 БОЛТ, TRFER CASE VENT BFL (M5X0.8X16) (4.535) 88996658 BAFFLE, TRFER CASE VENT not found БОЛТ, TRFER CASE MT BAR INSL CLA not found CЛАМПА, TRFER CASE MT BAR INSL 19180066 VENT, TRFER CASE 88996657 SEAL, TRFER CASE FRT ВЫХОДНОЙ SHF [УПЛОТНИТЕЛЬ] 88996656 SEAL, TRFER CASE INPUT SHF [УПЛОТНИТЕЛЬ] 88996681 DEFLECTOR, TRFER CASE FRT ВЫХОДНОЙ SHF SEAL DIRT teamcadillac.ru 19208069 SHAFT, TRFER CASE FRT ВЫХОДНОЙ 89048123 БОЛТ, TRFER CASE HALF (M8X1.25X30) (6D04-099) - 2008-2009 DM69 КОРПУС КП ЧАСТЬ 2 INTERNAL COMPONENTS (ПОЛНОПРИВОДНЫЙ MX7) ↓ 15580228 BEARING, TRFER CASE RR ВЫХОДНОЙ SHF RR (2 7/8 OD X 1 3/8 ID) (STMPD 13-45-130-001) 19208080 РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ, TRFER CASE TWO/FOUR WHL DRV CLU (СМ. ГРУППУ 04.000 "КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) teamcadillac.ru 19208108 SHIM, TRFER CASE FOUR WHL DRV CLU (SELECT FIT 8.60-8.50; STAMPED "52") 19208109 SHIM, TRFER CASE FOUR WHL DRV CLU (SELECT FIT 8.80-8.70; STAMPED "53") 19208110 SHIM, TRFER CASE FOUR WHL DRV CLU (SELECT FIT 9.00-8.90; STAMPED "54") 19208111 SHIM, TRFER CASE FOUR WHL DRV CLU (SELECT FIT 9.20-9.10; STAMPED "55") 19208112 SHIM, TRFER CASE FOUR WHL DRV CLU (SELECT FIT 9.40-9.30; STAMPED "56") 19208113 SHIM, TRFER CASE FOUR WHL DRV CLU (SELECT FIT 9.60-9.50; STAMPED "57") 19208114 SHIM, TRFER CASE FOUR WHL DRV CLU (SELECT FIT 9.80-9.70; STAMPED "58") 19208115 BEARING, TRFER CASE FOUR WHL DRV CLU HSG not found ШЛАНГИ, TRFER CASE TWO/FOUR WHL DRV CLU РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ not found ROLLER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT BRG 19208358 SPACER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT BRG RLR not found ПРУЖИНА, TRFER CASE TWO/FOUR WHL DRV SYN HUB 19208088 RING, TRFER CASE TWO/FOUR WHL DRV CLU RET 19208098 СЦЕПЛЕНИЕ, TRFER CASE FRT DRV AXLE VISCOUS (INCLS 12-17) not found ACTUATOR, TRFER CASE FOUR WHL DRV not found PLATE, TRFER CASE FOUR WHL DRV CLU PRESS (ЧАСТЬ OF 10) not found PLATE, TRFER CASE FOUR WHL DRV CLU BKG (FRICTION) (ЧАСТЬ OF 10) not found PLATE, TRFER CASE FOUR WHL DRV CLU BKG (SEPERATOR) (ЧАСТЬ OF 10) not found PLATE, TRFER CASE FOUR WHL DRV CLU BKG (ЧАСТЬ OF 10) not found PLATE, TRFER CASE FOUR WHL DRV CLU BKG (ПРУЖИНА) (ЧАСТЬ OF 10) not found ШЛАНГИ, TRFER CASE FOUR WHL DRV CLU (ЧАСТЬ OF 10) 19208091 SPACER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT 19208072 CHAIN, TRFER CASE TWO/FOUR WHL DRV 19208359 SPROCKET, TRFER CASE FRT ВЫХОДНОЙ SHF DRV 19208090 WASHER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT THR 19208085 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT 19208090 WASHER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT THR 19208082 PUMP, TRFER CASE OIL 19208071 SHAFT, TRFER CASE INPUT not found BEARING, TRFER CASE INPUT SHF 19208078 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF RR 19208360 SPROCKET, TRFER CASE TWO/FOUR WHL DRV DRVN 19208089 SPACER, TRFER CASE FRT ВЫХОДНОЙ SHF DRVN SPKT 88996633 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF FRT (ACDelco #88996633) [ПОДШИПНИК РАЗДАТОЧНОЙ КОРОБКИ] (6E04-020) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ 24218963 RING, T/CV FLUID SEAL RET [КОЛЬЦО] 24237531 SEAL, T/CV FLUID (ЧАСТЬ OF 217, 219) (ACDelco #24237531) [УПЛОТНЕНИЕ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 00444613 PLUG, HEX HD, 1/8-27 NPTF, STL (LINE PRESS TEST HOLE) (ACDelco #444613) 24239384 ШЛАНГИ, T/CV (MCHG) (INCLS 206) (ACDelco #24239384) 24225422 PIPE, A/TRNS VENT not found BUSHING, T/CV (ЧАСТЬ OF 203) not found RING, A/TRNS ГИДРОНАСОС VANE (ЧАСТЬ OF 217) not found GUIDE, A/TRNS ГИДРОНАСОС ROT (ЧАСТЬ OF 217) not found RING, A/TRNS ГИДРОНАСОС SLIDE FLUID SEAL (ЧАСТЬ OF 217) not found SEAL, A/TRNS O/PMP SLIDE (O RING) (ЧАСТЬ OF 217) (*KIT1) not found ПРУЖИНА, A/TRNS ГИДРОНАСОС SLIDE OTR (ЧАСТЬ OF 217) 24222668 SLIDE, A/TRNS ГИДРОНАСОС (17.948MM-17.961MM) (ACDelco #24222668) teamcadillac.ru 24224131 SLIDE, A/TRNS ГИДРОНАСОС (17.961MM-17.974MM) (ACDelco #24224131) 24224132 SLIDE, A/TRNS ГИДРОНАСОС (17.974MM-17.987MM) (ACDelco #24224132) not found SEAL, A/TRNS ГИДРОНАСОС SLIDE (ЧАСТЬ OF 217) not found SUPPORT, A/TRNS ГИДРОНАСОС SLIDE SEAL (ЧАСТЬ OF 217) (*KIT1) not found PIN, A/TRNS ГИДРОНАСОС SLIDE PIV (ЧАСТЬ OF 217) not found VANE, A/TRNS ГИДРОНАСОС (ЧАСТЬ OF 217) 24238915 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 207-211, 213-216, 230) (17.948MM-17.961MM) (ACDelco #24238915) 24238916 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 207-211, 213-216, 230) (17.961MM-17.974MM) (ACDelco #24238916) 24238917 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 207-211, 213-216, 230) (17.974MM-17.987MM) (ACDelco #24238917) not found BUSHING, TURB SHF FRT (ЧАСТЬ OF 219) 24238919 COVER KIT, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 218, 220-230, 232-237) (ACDelco #24238919) not found VALVE, CONV FEED LIM (ЧАСТЬ OF 219) not found ПРУЖИНА, PRESS RLF BALL VLV (ЧАСТЬ OF 219) not found ПРУЖИНА, CONV FEED LIM VLV (ЧАСТЬ OF 219) not found PIN, PRESS RLF BALL VLV SPR (ЧАСТЬ OF 219) not found ПРУЖИНА, PRESS RLF BALL VLV (ЧАСТЬ OF 219) 00147500 VALVE, PRESS RLF BALL (ЧАСТЬ OF 219) not found ПРУЖИНА, TCC C/VLV (ЧАСТЬ OF 219) not found VALVE, TCC CONT (ЧАСТЬ OF 219) not found BUSHING, TURB SHF RR (ЧАСТЬ OF 219) 24224692 WASHER, 1-2-3-4 & 3-5 REV CLU HSG THR (ЧАСТЬ OF 219) 24239151 RING, 1-2-3-4 & 3-5 REV CLU FLUID SEAL (ЧАСТЬ OF 217, 219) (*KIT1, KIT2) (ACDelco #24239151) 24227061 БОЛТ, A/TRNS ГИДРОНАСОС CVR (ACDelco #24227061) [БОЛТ] 90351709 PIN, A/TRNS ГИДРОНАСОС LOC (ЧАСТЬ OF 219) ("8MM HOLLOW SPLIT PIN") (1.639) [ШПИЛЬКА] not found VALVE, PRESS REG (ЧАСТЬ OF 219) not found ПРУЖИНА, PRESS REG VLV OTR (ЧАСТЬ OF 219) not found ПРУЖИНА, PRESS REG VLV INR (ЧАСТЬ OF 219) not found VALVE, ISOLATOR (ЧАСТЬ OF 219) not found SLEEVE, ISOLATOR VLV (ЧАСТЬ OF 219) 24243891 SEAL KIT, A/TRNS SERV (INCLS 205, 210, 214, 230) (FULL TRANS) (ACDelco #24243891) 24239151 RING KIT, 1-2-3-4 & 3-5 REV CLU FLUID SEAL (INCLS 230) (ACDelco #24239151) (6M04-038) - 2008 DM69 ШЛАНГ ВЕНТИЛЯЦИИ ТРАНСМИССИИ-VENT HOSE W/DRAIN(MYB)(1ST DES) ↓ not found HOSE, TRANS VENT (INCLS 2-8) 15862039 HOSE, TRANS VENT (INCLS 2-8) (VENT HOSE W/DRAIN) (FOR 2ND DES SEE 25892019) 25892019 HOSE, TRANS VENT (INCLS 2-8) not found VENT, TRFER CASE (ЧАСТЬ OF 1) 08905794 CLIP (TRANS VENT) (ЧАСТЬ OF 1) not found CONNECTOR, TRANS VENT HOSE (ЧАСТЬ OF 1) 06466355 CONNECTOR, TRANS VENT HOSE (ЧАСТЬ OF 1) (3.278) not found STRAP, TRFER CASE VENT HOSE (ЧАСТЬ OF 1) not found HOSE, TRANS VENT (ЧАСТЬ OF 1) 25526358 CЛАМПА, SPRG BAND, 14.2MM, 9/16 OD HOSE, POR (ЧАСТЬ OF 1) not found HOSE, TRANS VENT (ЧАСТЬ OF 1) (6M04-039) - 2008 DM69 ШЛАНГ ВЕНТИЛЯЦИИ ТРАНСМИССИИ-VENT HOSE W/O DRAIN(MYB)(2ND DES) ↓ 25892019 HOSE, TRANS VENT (INCLS 2-4) 25892019 HOSE, TRANS VENT (INCLS 2-4) (VENT HOSE W/O DRAIN) (FOR 1ST DES SEE 15862039) 25526358 CЛАМПА, SPRG BAND, 14.2MM, 9/16 OD HOSE, POR (ЧАСТЬ OF 1) 08905794 CLIP (ЧАСТЬ OF 1) 25892279 VENT, TRFER CASE (ЧАСТЬ OF 1) (ACDelco #25892279) [ЗАГЛУШКА ШЛАНГА ВЕНТИЛЯЦИИ КАРТЕРА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] (GM04-042) - 2008 DM69 ТОРМОЗНОЙ СУППОРТ-ПЕРЕДНИЙ (JE5) ↓ 15851351 CALIPER, FRT BRK (INCLS 2, 3, 12-14) (17") 15851351 CALIPER, FRT BRK (INCLS 2, 3, 12-14) (17") 15853359 CALIPER, FRT BRK (INCLS 2, 3, 12-14) (17") 15853359 CALIPER, FRT BRK (INCLS 2, 3, 12-14) (17") 89027179 VALVE, FRT BRK CLPR BLEDR (ЧАСТЬ OF 1) teamcadillac.ru 88935785 CAP, FRT BRK CLPR BLEDR VLV (ЧАСТЬ OF 1) [ЗАГЛУШКА ОБРАТНОГО КЛАПАНА] 15851359 PIN, FRT BRK CLPR GDE (W/O BUSHING) not found SEAL, FRT BRK CLPR GDE PIN (*KIT3) 15851354 BRACKET, FRT BRK CLPR (17") not found ПРУЖИНА, FRT DISC BRK PAD RET (*KIT2) not found PAD, FRT DISC BRK OTR (*KIT2) not found PAD, FRT DISC BRK INR (*KIT2) not found BUSHING, FRT BRK CLPR GDE PIN (ЧАСТЬ OF 11) (*KIT3) 15851358 PIN, FRT BRK CLPR GDE (INCLS 10) (W/PLASTIC SLEEVE 1.5MM FROM TIP) (W/BUSHING) not found BOOT, FRT BRK CLPR PSTN (ЧАСТЬ OF 1) (*KIT1) not found SEAL, FRT BRK CLPR PSTN (ЧАСТЬ OF 1) (*KIT1) 15926281 PISTON, FRT BRK CLPR (ЧАСТЬ OF 1) 89027183 БОЛТ, FRT BRK CLPR GDE PIN (M8X1.0) [БОЛТ М8] 25814701 SEAL KIT, FRT BRK CLPR PSTN (INCLS 12, 13) (INCLS 2 PISTON BOOTS & PISTON SEALS) 25814699 PAD KIT, FRT DISC BRK (INCLS 7-9) 25814700 SEAL KIT, FRT BRK CLPR GDE PIN (INCLS 5, 10) (INCLS 2 SEALS & 1 BUSHING) (GM04-555) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 24227130 БОЛТ, C/VLV UPR BODY (M5X0.8X36) 24225398 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M6 X 1.0 X 20) teamcadillac.ru 24238417 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (INCLS 316) (4.329) [ДАТЧИК ЧИСЛА ОБОРОТОВ ВАЛА AКПП] 24225797 BODY, C/VLV UPR [ГИДРОРАСПРЕДЕЛИТЕЛЬНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24245720 PLATE, C/VLV BODY SPCR (W/GSKT) (ACDelco #24245720) [НАБОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96020431 VALVE, C/VLV BODY BALL CHK [КЛАПАН] 24250384 BODY, C/VLV LWR (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ/;НИЖНИЙ КЛАПАН РЕГУЛЯТОР BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (MANUAL VALVE NOT INCLUDED) (MUST USE T/W 24236934/PLATE KIT - CONT SOL VLV FLTR) 24246427 SWITCH, A/TRNS MAN SHFT SHF POSN (INCLS 315) (INTERNAL MODE SWITCH) [ВКЛЮЧАТЕЛЬ] 24224821 БОЛТ, C/VLV LWR BODY (M5X0.8X45) 24224822 БОЛТ, C/VLV LWR BODY (M5X0.8X55) 24238925 PLATE KIT, CONT SOL VLV FLTR 24240845 БОЛТ, CONT SOL VLV HEAT SINK (W/ BODY & TCM) (M5X0.8X53.0) 24241890 VALVE, CONT SOL (W/ BODY & TCM) (ACDelco #24241890) (ORDER T/W 24238913 SEAL KIT) [ГИДРОРАСПРЕДЕЛИТЕЛЬНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24236233 CLIP, A/TRNS MAN SHFT SHF POSN SW WRG HARN (ЧАСТЬ OF 308) 24236233 CLIP, A/TRNS MAN SHFT SHF POSN SW WRG HARN (ЧАСТЬ OF 308) 24236233 CLIP, A/TRNS MAN SHFT SHF POSN SW WRG HARN (ЧАСТЬ OF 308) 24236504 CLIP, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN WRG HARN (ЧАСТЬ OF 303) (GM04-556) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ВЕРХНИЙ КЛАПАН РЕГУЛЯТОР BODY БЛОК ↓ 24224766 PIN, C/VLV BODY LOC (ЧАСТЬ OF 321) (DIA.=10MM L=12.7) [ВТУЛКА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24225797 BODY, C/VLV UPR (INCLS 313, 322-338) [ГИДРОРАСПРЕДЕЛИТЕЛЬНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24230200 PIN, C/VLV BODY LOC (ЧАСТЬ OF 321) (DIA.=10MM L=29.9) [ВТУЛКА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, 1-2-3-4 CLU BOOST VLV SPR (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, 1-2-3-4 CLU REG VLV BORE PLUG (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, 1/REV BAND & 4-5-6 CLU REG VLV BORE PLUG (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, 2-6 CLU REG VLV BORE PLUG (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, 3-5-REV CLU BOOST VLV SPR (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, 3-5-REV CLU REG VLV BORE PLUG (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, 4-5-6 CLU BOOST VLV SPR (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, ACTR FEED LIM VLV (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] not found ПРУЖИНА, ACTR FEED LIM VLV (ЧАСТЬ OF 321) not found VALVE, ACTR FEED LIM (ЧАСТЬ OF 321) not found ПРУЖИНА, 1-2-3-4 CLU REG VLV (ЧАСТЬ OF 321) not found ПРУЖИНА, 1/REV BAND & 4-5-6 CLU REG VLV (ЧАСТЬ OF 321) not found ПРУЖИНА, 2-6 CLU REG VLV (ЧАСТЬ OF 321) not found ПРУЖИНА, 3-5 REV CLU REG VLV (ЧАСТЬ OF 321) not found VALVE, 1/REV BAND & 4-5-6 CLU REG (ЧАСТЬ OF 321) 24242814 PLUG, 1-2-3-4 CLU REG VLV BORE (ЧАСТЬ OF 321) (9.5 THK, 11.5 DIA) 24242814 PLUG, 1/REV BAND & 4-5-6 CLU REG VLV BORE (ЧАСТЬ OF 321) (9.5 THK, 11.5 DIA) 24242814 PLUG, 2-6 CLU REG VLV BORE (ЧАСТЬ OF 321) (9.5 THK, 11.5 DIA) 24242814 PLUG, 3-5 REV CLU REG VLV BORE (ЧАСТЬ OF 321) (9.5 THK, 11.5 DIA) not found VALVE, 1-2-3-4 CLU BOOST (ЧАСТЬ OF 321) not found VALVE, 3-5-REV CLU BOOST (ЧАСТЬ OF 321) not found VALVE, 4-5-6 CLU BOOST (ЧАСТЬ OF 321) not found ПРУЖИНА, 1-2-3-4 CLU BOOST VLV (ЧАСТЬ OF 321) not found ПРУЖИНА, 3-5-REV CLU BOOST VLV (ЧАСТЬ OF 321) not found ПРУЖИНА, 4-5-6 CLU BOOST VLV (ЧАСТЬ OF 321) not found VALVE, 2-6 CLU REG (ЧАСТЬ OF 321) teamcadillac.ru not found VALVE, 2-6 CLU REG VLV GAIN (ЧАСТЬ OF 321) not found VALVE, 3-5 REV CLU REG (ЧАСТЬ OF 321) not found VALVE, 1-2-3-4 CLU REG (ЧАСТЬ OF 321) not found VALVE, DEFAULT OVERRIDE 1-2-3-4 CLU (ЧАСТЬ OF 321) (GM04-557) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) НИЖНИЙ КЛАПАН РЕГУЛЯТОР BODY БЛОК ↓ 24224755 RETAINER, CLU PSTN DAM FEED REG VLV SPR [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, CLU SEL SOL VLV BORE PLUG #2 [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, CLU SEL SOL VLV BORE PLUG #3 [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, TCC REG APPL VLV BORE PLUG [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24242814 PLUG, CLU SEL SOL VLV BORE #2 (9.5 THK, 11.5 DIA) 24242814 PLUG, CLU SEL SOL VLV BORE #3 (9.5 THK, 11.5 DIA) 24242814 PLUG, TCC REG APPL VLV BORE (9.5 THK, 11.5 DIA) not found VALVE, TCC REG APPL SHUTTLE (ЧАСТЬ OF 351) 24250384 BODY, C/VLV LWR (INCLS 338, 352, 353, 355-357) (MANUAL VALVE NOT INCLUDED) (MUST USE T/W 24236934/PLATE KIT - CONT SOL VLV FLTR) not found VALVE, CLU SEL SOL #2 (ЧАСТЬ OF 351) not found VALVE, CLU SEL SOL #3 (ЧАСТЬ OF 351) not found ПРУЖИНА, CLU SEL SOL VLV #2 (ЧАСТЬ OF 351) teamcadillac.ru not found ПРУЖИНА, CLU SEL SOL VLV #3 (ЧАСТЬ OF 351) not found ПРУЖИНА, TCC REG APPLY VLV (ЧАСТЬ OF 351) 24224770 VALVE, MAN (ACDelco #24224770) not found VALVE, TCC REG APPLY (ЧАСТЬ OF 351) not found VALVE, CLU PSTN DAM FEED REG (ЧАСТЬ OF 351) not found ПРУЖИНА, CLU PSTN DAM FEED REG VLV (ЧАСТЬ OF 351) (GM04-558) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) 1-2-3-4 & 3-5 REVERSE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 24240625 RING, 3-5 REV CLU BKG PLT RET (LT GREEN) (2.25-2.35MM) (ACDelco #24240625) 24240626 RING, 3-5 REV CLU BKG PLT RET (GRAY) (2.47-2.57MM) (ACDelco #24240626) 24240627 RING, 3-5 REV CLU BKG PLT RET (YELLOW) (2.69-2.79MM) (ACDelco #24240627) 24240628 RING, 3-5 REV CLU BKG PLT RET (ORANGE) (2.93-3.01MM) (ACDelco #24240628) 24240629 RING, 3-5 REV CLU BKG PLT RET (LT BLUE) (3.13-3.23MM) (ACDelco #24240629) 24240630 RING, 3-5 REV CLU BKG PLT RET (WHITE) (3.35-3.45MM) (ACDelco #24240630) 24240631 RING, 3-5 REV CLU BKG PLT RET (YELLOW/PURPLE) (3.57-3.67MM) (ACDelco #24240631) 24225654 PLATE, 3-5 REV CLU BKG 24225569 PLATE, 3-5/REV CLU (PKG OF 4) (FIBER) (*KIT4) (ACDelco #24225569) 24237663 PLATE, 3-5 REV CLU (PKG OF 4) (STEEL) 24225564 PLATE, 3-5 REV CLU (WAVED) 24225748 RING, 3-5-REV CLU APPLY (ACDelco #24225748) 24233533 PLATE, 1-2-3-4 CLU BKG 24243588 PLATE, 1-2-3-4 CLU (*KIT4) (ACDelco #24243588) 24232652 PLATE, 1-2-3-4 CLU (PKG OF 5) (STEEL) 24236434 PLATE, 1-2-3-4 CLU (WAVED) not found RING, 1-2-3-4 CLU PSTN DAM RET (*KIT1, KIT2) 24225522 DAM, 1-2-3-4 CLU PSTN 24225559 ПРУЖИНА, 1-2-3-4 CLU 24241073 PISTON, 1-2-3-4 CLU not found RING, 1-2-3-4 CLU PSTN HSG RTN (*KIT1, KIT2) not found SEAL, 1-2-3-4 CLU PSTN (ЧАСТЬ OF 417) 24238558 ШЛАНГИ, 1-2-3-4 CLU PSTN (INCLS 416, 418, 419) not found SEAL, 3-5/REV CLU PSTN DAM (O RING) (ЧАСТЬ OF 417) not found SEAL, 3-5-REV CLU PSTN INR (ЧАСТЬ OF 417) 24236051 ПРУЖИНА, 3-5-REV CLU 24238560 PISTON, 3-5/REV CLU (INCLS 422) (4.164) not found SEAL, 3-5-REV CLU PSTN OTR (ЧАСТЬ OF 421) (*KIT3) not found SEAL, 1-2-3-4 CLU PSTN INR (*KIT1, KIT3) teamcadillac.ru not found SEAL, 1-2-3-4 CLU PSTN HSG (*KIT1, KIT3) not found SEAL, 1-2-3-4 CLU PSTN HSG (*KIT1, KIT3) not found BUSHING, 1-2-3-4 & 3-5/REV CLU HSG RR (ЧАСТЬ OF 427) 24237184 ШЛАНГИ, 1-2-3-4 & 3-5 REV CLU (INCLS 426) (ORDER T/W 24226393) 24226393 BEARING, 1-2-3-4 & 3-5-REV CLU 24240626 RING, 1-2-3-4 CLU BKG PLT RET (GRAY) (2.47-2.57MM) (ACDelco #24240626) 24240627 RING, 1-2-3-4 CLU BKG PLT RET (YELLOW) (2.69-2.79MM) (ACDelco #24240627) 24240628 RING, 1-2-3-4 CLU BKG PLT RET (ORANGE) (2.93-3.01MM) (ACDelco #24240628) 24240629 RING, 1-2-3-4 CLU BKG PLT RET (LT BLUE) (3.13-3.23MM) (ACDelco #24240629) 24240630 RING, 1-2-3-4 CLU BKG PLT RET (WHITE) (3.35-3.45MM) (ACDelco #24240630) 24240631 RING, 1-2-3-4 CLU BKG PLT RET (YELLOW/PURPLE) (3.57-3.67MM) (ACDelco #24240631) 24240632 RING, 1-2-3-4 CLU BKG PLT RET (LT BLUE/PURPLE) (3.79-3.89MM) (ACDelco #24240632) 24238913 SEAL KIT, A/TRNS SERV (INCLS 411, 415, 423-425) (CONTROL VLV SOL ASM) (ACDelco #24238913) [КОМПЛЕКТ ПРОКЛАДОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (5ШТ)] 24238920 RING KIT, RET (INCLS 411, 415) 24238922 SEAL KIT, A/TRNS SERV (INCLS 422-425) (TRANS BUILT ON 1-31-08 & PRIOR) (FOR 2ND DES SEE 24243890) (СЦЕПЛЕНИЕES) (ACDelco #24238922) 24238922 SEAL KIT, A/TRNS SERV (INCLS 422-425) (TRANS BUILT ON 2-01-08 & AFTER) (FOR 1ST DES SEE 24238922) (СЦЕПЛЕНИЕES) (ACDelco #24238922) 24238911 PLATE KIT, CLU (INCLS 402, 408) (ORDER T/W 24225575 & 24235455) (ACDelco #24238911) (GM04-559) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) 4-5-6 ДЕТАЛИ СЦЕПЛЕНИЯ & ВАЛ ТУРБИНЫ ↓ 24225508 RING, 4-5-6 CLU BKG PLT RET (GREEN) (2.52-2.62) (ACDelco #24225508) 24225509 RING, 4-5-6 CLU BKG PLT RET (YELLOW) (3.08-3.18) (ACDelco #24225509) 24231591 RING, 4-5-6 CLU BKG PLT RET (GREY) (2.80-2.90) (ACDelco #24231591) 24231592 RING, 4-5-6 CLU BKG PLT RET (ORANGE) (3.36-3.46) (ACDelco #24231592) 24231593 RING, 4-5-6 CLU BKG PLT RET (BLUE) (3.64-3.74) (ACDelco #24231593) 24232880 RING, 4-5-6 CLU BKG PLT RET (YELLOW/PURPLE) (4.20-4.30) (ACDelco #24232880) 24225652 PLATE, 4-5-6 CLU BKG teamcadillac.ru 24225570 PLATE, 4-5-6 CLU (INT SPLINE) (PKG OF 5) (FIBER) (*KIT3) 24225575 PLATE, 4-5-6 CLU (EXT SPLINE) (PKG OF 5) (STEEL)FIBER) (ACDelco #24225575) 24225565 PLATE, 4-5-6 CLU (WAVED) not found RING, 4-5-6 CLU PSTN DAM RET (*KIT1, KIT2) 24225526 DAM, 4-5-6 CLU PSTN 24225560 ПРУЖИНА, 4-5-6 CLU 24225523 PISTON, 4-5-6 CLU not found BUSHING, ВЫХОДНОЙ CARR SHF HSG (ЧАСТЬ OF 441) 24237963 ШЛАНГИ, 4-5-6 CLU (W/ INPUT SHF) (INCLS 440) 24225511 RING, TURB SHF FLUID SEAL 08662686 SEAL, TURB SHF (O RING) (*KIT2) (ACDelco #8662686) 24238920 RING KIT, RET (INCLS 436) 24243891 SEAL KIT, A/TRNS SERV (INCLS 436, 443) (FULL TRANS) (ACDelco #24243891) 24238911 PLATE KIT, CLU (INCLS 433) (ORDER T/W 24225575 & 24235455) (ACDelco #24238911) (GM04-560) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) 2-6 ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 24247405 RING, 2-6 CLU BKG PLT RET (1.69MM +/- 0.05) (ACDelco #24247405) 24247406 RING, 2-6 CLU BKG PLT RET (2.81MM +/- 0.05) (ACDelco #24247406) 24248107 RING, 2-6 CLU BKG PLT RET (2.25MM +/- 0.05) (ACDelco #24248107) 24248108 RING, 2-6 CLU BKG PLT RET (2.53MM +/- 0.05) (ACDelco #24248108) 24248109 RING, 2-6 CLU BKG PLT RET (1.97MM +/- 0.05) (ACDelco #24248109) 24225653 PLATE, 2-6 CLU BKG 24237973 PLATE, 2-6 CLU (WAVED) not found RING, 2-6 CLU SPR RET 24225561 ПРУЖИНА, 2-6 CLU 24225524 PISTON, 2-6 CLU teamcadillac.ru not found BUSHING, ВЫХОДНОЙ CARR OTR SUN GR SHF (ЧАСТЬ OF 459) 24225447 SUPPORT, CTR (INCLS 458, 460) not found BUSHING, ВЫХОДНОЙ CARR OTR SUN GR SHF (ЧАСТЬ OF 459) 24238911 PLATE KIT, CLU (INCLS 452) (ORDER T/W 24225575 & 24235455) (ACDelco #24238911) (GM04-561) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) LOW & REVERSE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ not found SUPPORT, CTR (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ДЕТАЛИ СЦЕПЛЕНИЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found RING, LOW & REV CLU BKG PLT RET 24225519 RING, LOW & REV CLU BKG PLT RET (2.77MM +/- 0.05) (ACDelco #24225519) (TRANS BUILT ON 9/1/08 & FORWARD) (FOR 1ST DES SEE 24248368) 24231938 RING, LOW & REV CLU BKG PLT RET (2.63MM +/- 0.05) (MUST BE USED T/W 24247402) (ACDelco #24231938) (TRANS BUILT ON 9/1/08 & FORWARD) (FOR 1ST DES SEE 24248368) 24231939 RING, LOW & REV CLU BKG PLT RET (2.93MM +/- 0.05) (MUST BE USED T/W 24247402) (ACDelco #24231939) (TRANS BUILT ON 9/1/08 & FORWARD) (FOR 1ST DES SEE 24248368) teamcadillac.ru 24247407 RING, LOW & REV CLU BKG PLT RET (2.03MM +/- 0.05) (MUST BE USED T/W 24247402) (ACDelco #24247407) (TRANS BUILT ON 9/1/08 & FORWARD) (FOR 1ST DES SEE 24248368) 24247408 RING, LOW & REV CLU BKG PLT RET (3.23MM +/- 0.05) (MUST BE USED T/W 24247402) (ACDelco #24247408) (TRANS BUILT ON 9/1/08 & FORWARD) (FOR 1ST DES SEE 24248368) 24247402 PLATE, LOW & REV CLU BKG (MUST BE USED T/W 24231937/38/38, AND 24247407/08) (ACDelco #24247402) (TRANS BUILT ON 9/1/08 & FORWARD) (FOR 1ST DES SEE 24248368) 24248368 PLATE KIT, LOW & REV CLU BKG (FOR SERVICE USE (1) OF THE FOLLOWING RET. RINGS 24225515, 24225519, OR BACKING PLATE 24225656) (4.180) (ACDelco #24248368) (TRANS BUILT ON 08-31-08 & PRIOR) (FOR 2ND DES SEE 24231937/ 24231938/ 24231939/ 242474 24236664 PLATE, LOW & REV CLU (PKG OF 6) (FIBER) (*KIT2) 24232654 PLATE, LOW & REV CLU (PKG OF 6) (STEEL) (ACDelco #24232654) 24237971 PLATE, LOW & REV CLU (WAVED) (ACDelco #24237971) 24225517 RING, LOW & REV CLU SPR RET 24238921 SPRAG, LOW CLU (INCLS 468) not found SEAL, LOW CLU SPRAG (ЧАСТЬ OF 467) (*KIT1) 24225562 ПРУЖИНА, LOW & REV CLU 24225525 PISTON, LOW & REV CLU (ACDelco #24225525) 24238922 SEAL KIT, A/TRNS SERV (INCLS 468) (TRANS BUILT ON 1-31-08 & PRIOR) (FOR 2ND DES SEE 24243890) (СЦЕПЛЕНИЕES) (ACDelco #24238922) 24238922 SEAL KIT, A/TRNS SERV (INCLS 468) (TRANS BUILT ON 2-01-08 & AFTER) (FOR 1ST DES SEE 24238922) (СЦЕПЛЕНИЕES) (ACDelco #24238922) 24238911 PLATE KIT, CLU (INCLS 463) (ORDER T/W 24225575 & 24235455) (ACDelco #24238911) (GM04-562) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) СЦЕПЛЕНИЕ HUB БЛОК ↓ 24233660 HUB, 4-5-6 CLU (W/ ВЫХОДНОЙ CARR SHF & DPNR) (INCLS 476-478) teamcadillac.ru 24230475 DAMPENER, 4-5-6 CLU (ЧАСТЬ OF 475) 24233661 PLATE, 4-5-6 CLU DPNR APPLY (ЧАСТЬ OF 475) not found RING, 4-5-6 CLU DPNR RET (ЧАСТЬ OF 475) (GM04-563) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ВЫХОДНОЙ КРОНШТЕЙН БЛОК ↓ 24225777 BEARING, CTR SUPT RLR (ЧАСТЬ OF 490) 24225483 BEARING, ВЫХОДНОЙ CARR OTR SUN GR FRT THR (ЧАСТЬ OF 490) 24225290 GEAR, ВЫХОДНОЙ CARR FRT SUN (ЧАСТЬ OF 490) 24225484 BEARING, ВЫХОДНОЙ CARR OTR SUN GR RR THR (ЧАСТЬ OF 490) teamcadillac.ru 24235807 GEAR, ВЫХОДНОЙ CARR RR SUN (ЧАСТЬ OF 490) 24225603 КРОНШТЕЙН, ВЫХОДНОЙ (INCLS 485-489, 491) not found BEARING, ВЫХОДНОЙ CARR INR SUN GR THR (ЧАСТЬ OF 490) (GM04-568) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ВЫХОДНОЙ ВАЛ БЛОК ↓ 24241092 RING, ВЫХОДНОЙ CARR INTL GR RET (ACDelco #24241092) 24228887 SPACER, ВЫХОДНОЙ CARR INTL GR (3.342) not found BUSHING, ВЫХОДНОЙ CARR (ЧАСТЬ OF 499) teamcadillac.ru 24239398 SHAFT, ВЫХОДНОЙ (INCLS 498) (WHEN SERVICING SHAFT MUST ALSO REPLACE BEARING P/N 24237771) (FLAT END OF THE SHAFT) 24239401 SHAFT, ВЫХОДНОЙ (INCLS 498) (WHEN SERVICING SHAFT MUST ALSO REPLACE BEARING P/N 24237771) (GM04-569) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) БЛОК СЦЕПЛЕНИЯ & ДЕТАЛИ КОМПЛЕКТА ↓ not found СЦЕПЛЕНИЕ, 1-2-3-4 & 3-5 REV (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ 1-2-3-4 & 3-5 REVERSE ДЕТАЛИ СЦЕПЛЕНИЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 24225602 КРОНШТЕЙН, INPUT (ACDelco #24225602) 24225289 GEAR, INPUT SUN (ACDelco #24225289) 24224405 BEARING, INPUT SUN GR THR (ACDelco #24224405) 24224405 BEARING, INPUT SUN GR THR (ACDelco #24224405) 24232409 WASHER, INPUT SUN GR THR not found СЦЕПЛЕНИЕ, 4-5-6 (W/ TURB SHF) (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ 4-5-6 ДЕТАЛИ СЦЕПЛЕНИЯ & ВАЛ ТУРБИНЫ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 24238905 BEARING, TURB SHFT THR [ПОДШИПНИК] not found HUB, 4-5-6 CLU (W/ ВЫХОДНОЙ CARR SHF & DPNR) (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ СЦЕПЛЕНИЕ HUB БЛОК" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 24233732 BEARING, 4-5-6 CLU HUB THR (ACDelco #24233732) 24233732 BEARING, 4-5-6 CLU HUB THR (ACDelco #24233732) not found BUSHING, ВЫХОДНОЙ CARR INR SUN GR SHF (ЧАСТЬ OF 64) 24225597 HUB, 1-2-3-4 CLU (W/ВЫХОДНОЙ CARR INR SUN GR SHF) not found BUSHING, ВЫХОДНОЙ CARR INR SUN GR SHF (ЧАСТЬ OF 64) 24224163 BEARING, 1-2-3-4 CLU HUB THR (ACDelco #24224163) teamcadillac.ru 24225596 HUB, 2-6 & 3-5/REV CLU (W/ ВЫХОДНОЙ CARR OTR SUN GR SHF) (INCLS 60, 62) 24224164 BEARING, 2-6 & 3-5/REV CLU HUB THR (ACDelco #24224164) 24225512 RING, CTR SUPT RET 24225447 SUPPORT, CTR not found КРОНШТЕЙН, ВЫХОДНОЙ (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ВЫХОДНОЙ КРОНШТЕЙН БЛОК" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 24225486 BEARING, ВЫХОДНОЙ CARR THR not found SHAFT, ВЫХОДНОЙ (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ВЫХОДНОЙ ВАЛ БЛОК" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 24224668 BEARING, ВЫХОДНОЙ SHF THR (ACDelco #24224668) (GM04-598) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (6L50 MYB, ЗАДНИЙ КОЛЕСО DRIVE MX0) ↓ teamcadillac.ru not found ТРАНСМИССИЯ, AUTO (REMAN) not found ТРАНСМИССИЯ, AUTO (SERV) 17804020 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 8BMA, 8BAA) 17804029 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 8BTA) (GM04-599) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (6L50 MYB, ПОЛНОПРИВОДНЫЙ MX7) ↓ not found ТРАНСМИССИЯ, AUTO not found ТРАНСМИССИЯ, AUTO (REMAN) not found ТРАНСМИССИЯ, AUTO (SERV) teamcadillac.ru 17804021 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 8BBA, 8BSA) (REMAN) (GM04-617) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ЗАМОК ПАРКОВКИ(MX7) ↓ not found PLUG, PARK PAWL SHF HOLE (ЧАСТЬ OF CASE, A/TRNS - 04.103) not found SHAFT, PARK PAWL (ЧАСТЬ OF CASE, A/TRNS - 04.103) not found ПРУЖИНА, PARK PAWL (ЧАСТЬ OF CASE, A/TRNS - 04.103) not found PAWL, PARK (ЧАСТЬ OF CASE, A/TRNS - 04.103) teamcadillac.ru 24242086 ACTUATOR, PARK PAWL (ACDelco #24242086) 24227077 PIN, MAN SHFT DTNT LVR HUB (ЧАСТЬ OF 505) 24234562 LEVER, MAN SHFT DTNT (INCLS 504) (ACDelco #24234562) 24225792 PIN, MAN SHFT SHF (ACDelco #24225792) 24235861 SEAL, MAN SHFT SHF (*KIT1) (ACDelco #24235861) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24225445 SHAFT, MAN SHFT (ACDelco #24225445) 24228969 SHAFT, MAN SHFT (ACDelco #24228969) 24224348 GUIDE, PARK PAWL ACTR (INCLS 510) 24224350 SEAL, PARK PAWL ACTR GDE (O RING) (ЧАСТЬ OF 509) (*KIT1) (ACDelco #24224350) 24226102 PIN, PARK PAWL ACTR GDE 96022192 PLUG, MAN SHFT SHF HOLE 24243891 SEAL KIT, A/TRNS SERV (INCLS 507, 510) (FULL TRANS) (ACDelco #24243891) (GM04-618) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ЗАМОК ПАРКОВКИ(MX0) ↓ not found PLUG, PARK PAWL SHF HOLE (ЧАСТЬ OF CASE, A/TRANS - 04.103) not found SHAFT, PARK PAWL (ЧАСТЬ OF CASE, A/TRNS - 04.103) not found ПРУЖИНА, PARK PAWL (ЧАСТЬ OF CASE, A/TRNS - 04.103) not found PAWL, PARK (ЧАСТЬ OF CASE, A/TRNS - 04.103) teamcadillac.ru 24242086 ACTUATOR, PARK PAWL (ACDelco #24242086) 24227077 PIN, MAN SHFT DTNT LVR HUB (ЧАСТЬ OF 505) 24234562 LEVER, MAN SHFT DTNT (INCLS 504) (ACDelco #24234562) 24225792 PIN, MAN SHFT SHF (ACDelco #24225792) 24235861 SEAL, MAN SHFT SHF (*KIT1) (ACDelco #24235861) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224348 GUIDE, PARK PAWL ACTR (INCLS 510) 24224350 SEAL, PARK PAWL ACTR GDE (O RING) (ЧАСТЬ OF 509) (*KIT1) (ACDelco #24224350) 24226102 PIN, PARK PAWL ACTR GDE 24225445 SHAFT, MAN SHFT (ACDelco #24225445) 24228969 SHAFT, MAN SHFT (ACDelco #24228969) 24243891 SEAL KIT, A/TRNS SERV (INCLS 507, 510) (FULL TRANS) (ACDelco #24243891) (GM04-667) - 2008 D69 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 24240017 CONVERTER, TORQ [ГИДРОТРАНСФОРМАТОР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] teamcadillac.ru 24243293 CONVERTER, TORQ not found ШЛАНГИ, T/CV (W/ ГИДРОНАСОС) (СМ. ГРУППУ 04.000 "TORQUE CONVERTOR ШЛАНГИ AND ГИДРОНАСОС" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11515762 БОЛТ, T/CV HSG (8.900) 24205899 PLUG, T/CV HSG ACC HOLE (28MM W/3 TANGS) (SMALL CVR) (ACDelco #24205899) 24225543 SEAL, A/TRNS ГИДРОНАСОС (ACDelco #24225543) [ПРОКЛАДКА КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] not found PIN, T/CV HSG LOC (ЧАСТЬ OF 7) 24242045 CASE, A/TRNS (INCLS 6, 12, 13) (ACDelco #24242045) 24242046 CASE, A/TRNS (INCLS 6, 12, 13) (ACDelco #24242046) 24226020 PLUG, TRANS FLUID FIL TUBE not found SEAL, A/TRNS WRG CONN (*KIT1, KIT2) not found SEAL, A/TRNS WRG CONN (O RING) (*KIT1, KIT2) 24239878 SLEEVE, A/TRNS ELEC CONN PASG [МУФТА] not found PLUG, A/TRNS CASE (ЧАСТЬ OF 7) 11515762 БОЛТ, T/CV HSG (8.900) not found SEAL, A/TRNS ГИДРОНАСОС (*KIT2) not found SEAL, A/TRNS ГИДРОНАСОС (*KIT2) 24225557 SEAL, CTR SUPT FLUID PASG (*KIT2) not found VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 24237181 БОЛТ, VLV BODY (M5X0.8X73.0) 24231074 БОЛТ, MAN SHFT DTNT (M10X1X14.5) not found DETENT, MAN SHFT not found SEAL, A/TRNS FLUID FLTR (ЧАСТЬ OF 26) 24236933 FILTER KIT, A/TRNS FLUID (INCLS 25) (ACDelco #24236933) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24225800 GASKET, A/TRNS FLUID PAN (ACDelco #24225800) [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 29535617 MAGNET, A/TRNS FLUID PAN (4.105) (ACDelco #29535617) [МАГНИТ] 24242410 PAN, A/TRNS FLUID (INCLS 31) (ACDelco #24242410) 11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (A/TRNS FLUID PAN) [БОЛТ М6] 24234212 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 29) (ACDelco #24234212) [ПРОБКА] 24205900 COVER, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] 24225783 SEAL, A/TRNS CASE EXTN (ACDelco #24225783) [УПЛОТНИТЕЛЬ КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24249873 EXTENSION, A/TRNS CASE (ACDelco #24249873) 24228876 SEAL, ВЫХОДНОЙ SHF (5.556) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24214158 BEARING, ВЫХОДНОЙ SHF (DRAWN CUP) (4.131) (ACDelco #24214158) 24230287 FLANGE, PROP SHF TRANS 24231524 ГАЙКА, FRT PROP SHF FLG (M22X1.5) (FLANGE HEX) 24229687 EXTENSION, A/TRNS CASE (MCHG) 24242995 BEARING, ВЫХОДНОЙ SHF [ПОДШИПНИК КПП] 24236928 SEAL KIT, A/TRNS ELEC CONN PASG SLEV (INCLS 9, 10) 24238913 SEAL KIT, A/TRNS SERV (CONTROL VLV SOL ASM) (ACDelco #24238913) [КОМПЛЕКТ ПРОКЛАДОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (5ШТ)] (TS04-045) - 2008 DM69 ТОРМОЗНОЙ СУППОРТ-ЗАДНИЙ ↓ 25997338 PAD KIT, RR DISC BRK (INCLS 2) not found ПРУЖИНА, RR DISC BRK PAD (ЧАСТЬ OF 1) 25997457 BRACKET, RR BRK CLPR 25997463 BRACKET, RR BRK CLPR 88935808 SEAL KIT, RR BRK CLPR GDE PIN (4.670) [ЗАЩИТНЫЙ ЧЕХОЛ ПОРШНЯ ТОРМОЗНОГО СУППОРТА] 15855612 PIN, RR BRK CLPR GDE 25843039 CALIPER, RR BRK (17" ТОРМОЗА) (INCLS 8-12) [ТОРМОЗНОЙ СУППОРТ] 25843039 CALIPER, RR BRK (INCLS 8-12) [ТОРМОЗНОЙ СУППОРТ] 25843040 CALIPER, RR BRK (17" ТОРМОЗА) (INCLS 8-12) [СУППОРТ] 25843040 CALIPER, RR BRK (INCLS 8-12) [СУППОРТ] 25843041 CALIPER, RR BRK (INCLS 8-12) [СУППОРТ] 25843042 CALIPER, RR BRK (INCLS 8-12) [СУППОРТ] 89027183 БОЛТ, RR BRK CLPR GDE PIN (M8X1.0) [БОЛТ М8] 88935785 CAP, RR BRK BLEDR VLV (ЧАСТЬ OF 6) [ЗАГЛУШКА ОБРАТНОГО КЛАПАНА] 89027179 VALVE, RR BRK BLEDR (ЧАСТЬ OF 6) not found SEAL, RR BRK CLPR PSTN (ЧАСТЬ OF 6) (*KIT1) 15926281 PISTON, RR BRK CLPR (18" H.D. ТОРМОЗА) (ЧАСТЬ OF 6) 15926282 PISTON, RR BRK CLPR (17" ТОРМОЗА) (ЧАСТЬ OF 6) teamcadillac.ru not found BOOT, RR BRK CLPR PSTN (ЧАСТЬ OF 6) (*KIT1) 25814676 SEAL KIT, RR BRK CLPR PSTN (INCLS 10, 12) 25814677 SEAL KIT, RR BRK CLPR PSTN (INCLS 10, 12) [КОМПЛЕКТ ПРОКЛАДОК] (TS04-726) - 2008 DM69 ТОРМОЗНОЙ СУППОРТ-ПЕРЕДНИЙ (J55) ↓ 15851479 CALIPER, FRT BRK (INCLS 2, 3, 8, 9, 11) (18") [СУППОРТ] 15851479 CALIPER, FRT BRK (INCLS 2, 3, 8, 9, 11) (18") [СУППОРТ] 15851480 CALIPER, FRT BRK (INCLS 2, 3, 8, 9, 11) (18") [СУППОРТ ТОРМОЗА] 15851480 CALIPER, FRT BRK (INCLS 2, 3, 8, 9, 11) (18") [СУППОРТ ТОРМОЗА] not found CAP, FRT BRK CLPR BLEDR VLV (ЧАСТЬ OF 1) 15851382 VALVE, FRT BRK CLPR BLEDR (ЧАСТЬ OF 1) 25809684 БОЛТ, FRT BRK CLPR HSG (GUIDE PIN) 25809681 PIN, FRT BRK CLPR GDE (W/O BUSHING) 25809679 PIN, FRT BRK CLPR GDE (INCLS 7) (W/PLASTIC SLEEVE 2.0MM FROM TIP) (W/BUSHING) not found BUSHING, FRT BRK CLPR GDE PIN (ЧАСТЬ OF 6, 10) not found SEAL, FRT BRK CLPR PSTN (ЧАСТЬ OF 1) (*KIT1) teamcadillac.ru 15926289 PISTON, FRT BRK CLPR (ЧАСТЬ OF 1) 25814703 SEAL KIT, FRT BRK CLPR GDE PIN (INCLS 7) [ЗАСЛОНКА] not found BOOT, FRT BRK CLPR PSTN (ЧАСТЬ OF 1) (*KIT1) 25958115 PAD KIT, FRT DISC BRK (INCLS 14) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4ШТ)] 15851384 BRACKET, FRT BRK CLPR (18") 15851384 BRACKET, FRT BRK CLPR (18") 15851476 BRACKET, FRT BRK CLPR (18") 15851476 BRACKET, FRT BRK CLPR (18") not found ПРУЖИНА, FRT DISC BRK PAD RET (ЧАСТЬ OF 12) 25814704 SEAL KIT, FRT BRK CLPR PSTN (INCLS 8, 11) [КОМПЛЕКТ УПЛОТНИТЕЛЬНЫХ КОЛЕЦ ТОРМОЗНОГО СУППОРТА (2ШТ)] 05 - ТОРМОЗА - ЗАДНЯЯ ОСЬ - ПРИВОДНОЙ ВАЛ - КОЛЕСА (6D05-013) - 2008 DM69 ВАЛ ПРИВОДА-КАРДАННЫЙ ВАЛ КРЕПЛЕНИЕ (ЗАДНИЙ КОЛЕСО DRIVE MX0) ↓ teamcadillac.ru 25902501 SHAFT, PROP (W/DRIVELINE SUPT) [КАРДАННЫЙ ВАЛ] 11589166 БОЛТ, HEX W/CON WA, M10X1.5X39.8, 25.45 THD, 28 OD, 10.9, GMW3359, M-PT (PROP SHF BRG SUPT) 25708829 SHIM, PROP SHF CTR SUPT BRG (BLACK) (OVERALL HEIGHT 2MM) [ПРОКЛАДКА] 25708830 SHIM, PROP SHF CTR SUPT BRG (GREEN) (OVERALL HEIGHT 4MM) [ПРОКЛАДКА] 25708831 SHIM, PROP SHF CTR SUPT BRG (BLUE) (OVERALL HEIGHT 6MM) [ПРОКЛАДКА] 25708832 SHIM, PROP SHF CTR SUPT BRG (YELLOW) (OVERALL HEIGHT 8MM) [ШАЙБА] 25708833 SHIM, PROP SHF CTR SUPT BRG (WHITE) (OVERALL HEIGHT 10MM) [ШАЙБА] 25708834 SHIM, PROP SHF CTR SUPT BRG (PURPLE) (OVERALL HEIGHT 12MM) [ШАЙБА] 11588658 БОЛТ, FRT PROP SHF (M12X1.75X70) (HEX) (8.900) [БОЛТ] 11588689 WASHER, FRT PROP SHF (ID 12.25, OD 23.0, THK 3.38MM) [ШАЙБА] 11516073 ГАЙКА, FRT PROP SHF (M12X1.75X11.5, 10) (HEX LK PREV TORQ) (7111M ZE) (8.917) [ГАЙКА М12Х1.75Х11.5] 11516073 ГАЙКА, RR PROP SHF (M12X1.75X11.5, 10) (HEX LK PREV TORQ) (7111M ZE) (8.917) [ГАЙКА М12Х1.75Х11.5] 11588689 WASHER, RR PROP SHF (ID 12.25, OD 23.0, THK 3.38MM) [ШАЙБА] 11588658 БОЛТ, RR PROP SHF (M12X1.75X70) (HEX) (8.900) [БОЛТ] (6D05-032) - 2008 DM69 НАСОС ДЛЯ ШИН (EXC COMPACT SPARE ШИНА ZAA) ↓ not found LABEL, ШИНА MAX SPEED (ЧАСТЬ OF 2) 25889433 CONTAINER, ШИНА SEALANT SOL (INCLS 1, 9) (INCLS ШИНА SEALANT) 25889432 КОМПРЕССОР , ШИНА AIR (INCLS 4, 5) teamcadillac.ru not found NEEDLE, INFLR HOSE (ЧАСТЬ OF 3) not found NEEDLE, INFLR HOSE (ЧАСТЬ OF 3) 11561358 NUT- WING, M8X1.25X21, 72 OD, 90 LENGTH, GM510M STL CLASS 9, GMW3044 (JK STOW) 25882302 ДЕРЖАТЕЛЬ, ШИНА AIR CMPR & ШИНА SEALANT CNTNR 11588355 БОЛТ, JK STOW not found LABEL, ШИНА SEALER CAUTION (ЧАСТЬ OF 2) 25866304 PANEL, R/CMPT SPA WHL STOW CVR [КРЫШКА НИШИ БАГАЖНОГО ОТСЕКА] (6D05-033) - 2008 DM69 КОЛЕСА ↓ 09596616 КОЛЕСО, 17X8 09596618 КОЛЕСО, 17X8 09595174 ГАЙКА, WHL (M14X1.5) 09596626 CAP, HUB 15234846 ГАЙКА, ШИНА PRESS IND SEN (14 X 19) [ГАЙКА М8] 25740352 SENSOR, ШИНА PRESS IND (СМ. ГРУППУ 05.000 "ДАТЧИК ДАВЛЕНИЯ В ШИНЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (BLUE) (JAPAN/KOREA) (ACDelco #25740352) 25789964 SENSOR, ШИНА PRESS IND (СМ. ГРУППУ 05.000 "ДАТЧИК ДАВЛЕНИЯ В ШИНЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (BLUE) (EUROPE) (ACDelco #25789964) [ДАТЧИК ДАВЛЕНИЯ ШИНЫ КОЛЕСА С РАДИОПЕРЕДАЮЩИМ УСТРОЙСТВОМ] 25789964 SENSOR, ШИНА PRESS IND (СМ. ГРУППУ 05.000 "ДАТЧИК ДАВЛЕНИЯ В ШИНЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (BLUE) (EUROPE) (ACDelco #25789964) [ДАТЧИК ДАВЛЕНИЯ ШИНЫ КОЛЕСА С РАДИОПЕРЕДАЮЩИМ УСТРОЙСТВОМ] 25920615 SENSOR, ШИНА PRESS IND (СМ. ГРУППУ 05.000 "ДАТЧИК ДАВЛЕНИЯ В ШИНЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS BLACK VALVE CAP) (ACDelco #25920615) [ДАТЧИК ДАВЛЕНИЯ ШИНЫ КОЛЕСА С ПЕРЕДАЮЩИМ УСТРОЙСТВОМ] 19209740 WEIGHT, WHL BAL (CLIP-ON REPLACEMENT) (TRIM AS REQUIRED) (WHL BAL) 09597874 КОЛЕСО, 18X8.5 09597875 КОЛЕСО, 18X8.5 09596070 ГАЙКА, WHL (M14X1.5) (SS CAP) (TOTAL LENGTH 20.22MM) teamcadillac.ru 09596628 CAP, HUB (INCLS MULTI COLORED CREST EMBLEM) 09597324 WEIGHT, WHL BAL (6.00 OZ) (STICK-ON REPLACEMENT) (TRIM AS REQUIRED) (WHL BAL) (6D05-034) - 2008 DM69 ДАТЧИК ДАВЛЕНИЯ В ШИНЕ SYSTEM(UH3) ↓ 15866242 МОДУЛЬ, LOW ШИНА PRESS IND not found HARNESS, BODY WRG (СМ. ГРУППУ 13.000 "ЖГУТЫ ПРОВОДОВ/КУЗОВ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (ШИНА PRESS IND RCVR) [ПИСТОН КРЕПЛЕНИЯ ОБЛИЦОВКИ БАМПЕРА (NYLON)] 24574578 RETAINER, RR BPR FASCIA REINF (PUSH IN) (LENGTH 18.0) (3.403) [ФИКСАТОРА ВОЗДУХООЧИСТИТЕЛЯ] 25740353 RECEIVER, ШИНА PRESS IND 15858976 BRACKET, ШИНА PRESS IND RCVR (RECEIVER MNT AT WHL OPENING) 15858977 BRACKET, ШИНА PRESS IND RCVR (RECEIVER MNT AT WHL OPENING) 25863036 HARNESS, B/U ALARM WRG 25863036 HARNESS, B/U ALARM WRG not found HARNESS, FWD LP WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/FORWARD ЛАМПА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) teamcadillac.ru 25740352 SENSOR, ШИНА PRESS IND (СМ. ГРУППУ 5.000 "ДАТЧИК ДАВЛЕНИЯ В ШИНЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (BLUE) (JAPAN/KOREA) (ACDelco #25740352) 15234846 ГАЙКА, ШИНА PRESS IND SEN (14 X 19) [ГАЙКА М8] (6D05-035) - 2008 DM69 DIFFERENTIAL КРОНШТЕЙН ЧАСТЬ 1 ↓ 25868437 КРОНШТЕЙН, DIFF (3.73 RATIO) (INCLS 2-31) 25979053 КРОНШТЕЙН, DIFF (3.23 RATIO) (INCLS 2-31) 25979054 КРОНШТЕЙН, DIFF (3.23 RATIO) (INCLS 2-31) [РЕДУКТОР ДИФФЕРЕНЦИАЛА ВЕДУЩЕГО МОСТА] 25979061 КРОНШТЕЙН, DIFF (3.42 RATIO) (INCLS 2-31) 25979062 КРОНШТЕЙН, DIFF (3.42 RATIO) (INCLS 2-31) not found SHIELD, R/AXL VENT (ЧАСТЬ OF 1) not found БОЛТ, R/AXL VENT SHLD (ЧАСТЬ OF 1) 25795472 BUSHING, DIFF CARR (RRЧАСТЬ OF 1) [ПОДШИПНИК] not found GEAR, DIFF PINION (ЧАСТЬ OF 1) not found SHIM, DIFF P/GR (ЧАСТЬ OF 1) not found BEARING, DIFF DRV P/GR INR (ЧАСТЬ OF 1) 89059038 PLUG, DIFF CARR FILL (ЧАСТЬ OF 1) (M20X1.5X14) (W/SEAL) 25795473 BUSHING, DIFF CARR (ЧАСТЬ OF 1) [ПОДШИПНИК] not found БОЛТ, RR DIFF R/GR (ЧАСТЬ OF 1) not found SHIM, DIFF BRG (ЧАСТЬ OF 1) 89058602 БОЛТ, DIFF CARR BRKT (ЧАСТЬ OF 1) (M8X1.25X30, 24 THD) (FLANGE HEAD) (5.476) 25795481 SEAL, R/AXL SHF (ЧАСТЬ OF 1) [УПЛОТНЕНИЕ] not found RING, RR WHL DRV SHF (ЧАСТЬ OF 1) 25795474 SHAFT, R/AXL (ЧАСТЬ OF 1) [ОСЬ] 25887411 SPACER, DIFF CARR (ЧАСТЬ OF 1) 14081014 БОЛТ, DIFF CARR BRKT (ЧАСТЬ OF 1) (M8X1.25X30) (6 LOBE SOCKET) ( PAN HEAD) (3.275) 25795471 BRACKET, DIFF CARR (ЧАСТЬ OF 1) not found COVER, DIFF CARR (ЧАСТЬ OF 1) not found PIN, DIFF CARR LOC (ЧАСТЬ OF 1) not found BEARING, DIFF (ЧАСТЬ OF 1) not found DIFFERENTIAL, (ЧАСТЬ OF 1) (СМ. ГРУППУ 05.000 "DIFFERENTIAL КРОНШТЕЙН ЧАСТЬ 2" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found GEAR, DIFF RING (ЧАСТЬ OF 1) 89058614 ГАЙКА, DIFF DRV P/GR (ЧАСТЬ OF 1) [ВИНТ] 25861285 FLANGE, RR WHL DRV SHF (ЧАСТЬ OF 1) 25861283 SEAL, DIFF DRV P/GR (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ДИФФЕРЕНЦИАЛА] not found BEARING, DIFF DRV P/GR OTR (ЧАСТЬ OF 1) not found SPACER, DIFF DRV P/GR BRG (ЧАСТЬ OF 1) not found TAG, R/AXL IDENT (ЧАСТЬ OF 1) teamcadillac.ru 89059038 PLUG, DIFF CARR FILL (ЧАСТЬ OF 1) (M20X1.5X14) (W/SEAL) 15852707 VENT, R/AXL HSG (ЧАСТЬ OF 1) [КЛАПАН] (6D05-036) - 2008 DM69 DIFFERENTIAL КРОНШТЕЙН КРЕПЛЕНИЕ ↓ 25868437 КРОНШТЕЙН, DIFF (3.73 RATIO) (СМ. ГРУППУ 05.000 "DIFFERENTIAL КРОНШТЕЙН" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25979053 КРОНШТЕЙН, DIFF (3.23 RATIO) (СМ. ГРУППУ 05.000 "DIFFERENTIAL КРОНШТЕЙН" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25979054 КРОНШТЕЙН, DIFF (3.23 RATIO) (СМ. ГРУППУ 05.000 "DIFFERENTIAL КРОНШТЕЙН" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [РЕДУКТОР ДИФФЕРЕНЦИАЛА ВЕДУЩЕГО МОСТА] 25979061 КРОНШТЕЙН, DIFF (3.42 RATIO) (СМ. ГРУППУ 05.000 "DIFFERENTIAL КРОНШТЕЙН" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25979062 КРОНШТЕЙН, DIFF (3.42 RATIO) (СМ. ГРУППУ 05.000 "DIFFERENTIAL КРОНШТЕЙН" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11516383 ГАЙКА, HFH LK 16X2X18.9 34.2 OD 10 7111M PREV TORQ (DIFF) [ГАЙКА] teamcadillac.ru 11518933 БОЛТ, DIFF CARR RR (M16X2X110) (8.900) 10289657 ГАЙКА, RR WHL DRV UJT SHF (M24X2.0X19.6) (HEX W/WASHER, PREVAILING TORQUE) (6.056) [ГАЙКА М24] 10396860 SHAFT, RR WHL DRV (СМ. ГРУППУ 05.000 "ВАЛ ЗАДНЕЙ ОСИ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ОСЬ] 10396861 SHAFT, RR WHL DRV (СМ. ГРУППУ 05.000 "ВАЛ ЗАДНЕЙ ОСИ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ОСЬ] 11569732 БОЛТ, DIFF CARR FRT (M14X2X101.68, 48 THD) 19206434 DAMPENER KIT, DIFF CARR (INCLS 8-10) 11518636 БОЛТ, HFH, M10X1.5X90, 25.9 THD, 22.3 OD, 10.9, GMW3359, 7.5 MAT-PT (ЧАСТЬ OF 7) [БОЛТ М10] 11515765 БОЛТ, HFH, M10X1.5X25, 22.30 O.D., HDR PT, 10.9, 7112M (ЧАСТЬ OF 7) not found BRACKET, DIFF CARR DPNR (ЧАСТЬ OF 7) 25887411 SPACER, DIFF CARR (6D05-037) - 2008 DM69 ВАЛ ЗАДНЕЙ ОСИ ↓ 10396860 SHAFT, RR WHL DRV (INCLS 2-13, 15-22) [ОСЬ] 10396861 SHAFT, RR WHL DRV (INCLS 2-13, 15-22) [ОСЬ] not found CAP, R/AXL HUB (ЧАСТЬ OF 1, 11) not found JOINT, RR WHL DRV SHF TRI-POT (ЧАСТЬ OF 1) not found CAP, R/AXL HUB (ЧАСТЬ OF 1, 11) 25782418 RETAINER KIT, RR WHL DRV SHF UJT БОЛТ (ЧАСТЬ OF 1) not found CAGE, RR WHL DRV SHF INR CV JT INR) (ЧАСТЬ OF 1) not found RACE, RR WHL DRV SHF INR CV JT INR (ЧАСТЬ OF 1) not found BEARING, R/AXL SHF (ЧАСТЬ OF 1) teamcadillac.ru not found RING, RR WHL DRV SHF TRI-POT JT SPIDER RET (ЧАСТЬ OF 1, 11) not found CЛАМПА, RR WHL DRV SHF TRI-POT JT BOOT OTR (ЧАСТЬ OF 1, 11) 25782407 BOOT KIT, RR WHL DRV SHF TRI-POT JT (INCLS 2, 4, 9, 10, 12) (ЧАСТЬ OF 1) [КОЖУХ] 88957222 CЛАМПА, RR WHL DRV SHF TRI-POT JT BOOT INR (ЧАСТЬ OF 1, 11) not found SHAFT, RR WHL DRV (ЧАСТЬ OF 1) 10289657 ГАЙКА, RR WHL DRV UJT SHF (ЧАСТЬ OF 20) (M24X2.0X19.6) (HEX W/WASHER, PREVAILING TORQUE) (6.056) [ГАЙКА М24] not found JOINT, RR WHL DRV SHF CV OTR (ЧАСТЬ OF 1) not found CAGE, RR WHL DRV SHF INR CV JT OTR) (ЧАСТЬ OF 1) not found RACE, RR WHL DRV SHF INR CV JT OTR (ЧАСТЬ OF 1) not found BEARING, R/AXL SHF (ЧАСТЬ OF 1) not found CЛАМПА, RR WHL DRV SHF CV JT BOOT OTR (ЧАСТЬ OF 1, 20) 88957230 BOOT KIT, RR WHL DRV SHF CV JT (INCLS 14, 19, 21) (ЧАСТЬ OF 1) [ПЫЛЬНИК ПРИВОДНОГО ВАЛА] not found CЛАМПА, RR WHL DRV SHF CV JT BOOT OTR (ЧАСТЬ OF 1, 20) not found RING, R/AXL SHF RET (ЧАСТЬ OF 1) (6D05-038) - 2008 DM69 ВАЛ ПРИВОДА-КАРДАННЫЙ ВАЛ КРЕПЛЕНИЕ/ЗАДНИЙ (ЗАДНИЙ КОЛЕСО DRIVE MN6) ↓ 25811731 SHAFT, PROP (W/DRIVELINE SUPT) (INCLS 6) 11588658 БОЛТ, RR PROP SHF (M12X1.75X70) (HEX) (8.900) [БОЛТ] 11588689 WASHER, RR PROP SHF (ID 12.25, OD 23.0, THK 3.38MM) [ШАЙБА] 11516073 ГАЙКА, RR PROP SHF (M12X1.75X11.5, 10) (HEX LK PREV TORQ) (7111M ZE) (8.917) [ГАЙКА М12Х1.75Х11.5] 11589166 БОЛТ, HEX W/CON WA, M10X1.5X39.8, 25.45 THD, 28 OD, 10.9, GMW3359, M-PT (RR PROP SHF BRG SUPT) teamcadillac.ru 25797833 RETAINER, FRT PROP SHF (ЧАСТЬ OF 1) [СКОБА ФЛАНЦА КАРДАННОГО ВАЛА] (6D05-047) - 2008-2010 DM DIFFERENTIAL КРОНШТЕЙН ЧАСТЬ 2 (G80) ↓ 89048116 WASHER, LKG DIFF CLU DISC THR (5.511) not found DIFFERENTIAL, (RH) not found PLATE, L/SLIP DIFF CLU (SMOOTH) (*KIT1) not found GEAR, DIFF SI not found RING, RR WHL DRV SHF not found SHAFT, DIFF P/GR not found WASHER, DIFF DRV P/GR not found GEAR, DIFF DRV PINION not found SHAFT, DIFF P/GR not found DIFFERENTIAL, (LH) not found PLATE, L/SLIP DIFF CLU (FRICTION) (*KIT1) teamcadillac.ru 19132906 DISC KIT, L/SLIP DIFF CLU (INCLS 3, 11) [КОМПЛЕКТ ДИСКОВ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (8ШТ)] (6D05-048) - 2008-2010 DM DIFFERENTIAL КРОНШТЕЙН ЧАСТЬ 2 (EXC (G80)) ↓ not found DIFFERENTIAL, (RH) not found WASHER, LKG DIFF CLU DISC THR not found PLATE, L/SLIP DIFF PRELOAD SPR not found SHAFT, DIFF P/GR (ЧАСТЬ OF 1) not found GEAR, DIFF DRV PINION teamcadillac.ru not found WASHER, DIFF DRV P/GR not found GEAR, DIFF SI not found DIFFERENTIAL, (LH) (6E05-009) - 2008-2009 DM69 ВАЛ ПРИВОДА-КАРДАННЫЙ ВАЛ КРЕПЛЕНИЕ/FRONT (ПОЛНОПРИВОДНЫЙ MX7) ↓ teamcadillac.ru not found SHAFT, F/AXL PROP (INCLS 2) 15212141 SHAFT, F/AXL PROP (INCLS 2) [КАРДАННЫЙ ВАЛ] 15212141 SHAFT, F/AXL PROP (INCLS 2) [КАРДАННЫЙ ВАЛ] 10363385 RETAINER, F/AXL PROP SHF (ЧАСТЬ OF 1) (INCLS 2 M8X1.25X45 БОЛТS AND 1 БОЛТ LOCK) [СЕРЬГА КАРДАННОГО ВАЛА] (GM05-007) - 2008-2010 D ШИНА ↓ not found ШИНА, FRT not found ШИНА, RR 19111381 ШИНА, RR (ШИНА MFG # 85527) (MICHELIN, PILOT HX MXM4, 255/45R17, BW, 98V) (ACDelco #M85527) 19163349 ШИНА, FRT (ШИНА MFG # 04049) (INSTALL .25) (SINGLE 12.5KGS) (MICHELIN, PILOT HX MXM4, P235/50R18, ORBL97V) (ACDelco #M04049) teamcadillac.ru 19163349 ШИНА, RR (ШИНА MFG # 04049) (INSTALL .25) (SINGLE 12.5KGS) (MICHELIN, PILOT HX MXM4, P235/50R18, ORBL97V) (ACDelco #M04049) 19186918 ШИНА, FRT (ШИНА MFG # 12771) (MICHELIN, PILOT SPORT PS2, 235/50ZR18, 97Y) (ACDelco #M12771) 19186918 ШИНА, RR (ШИНА MFG # 12771) (MICHELIN, PILOT SPORT PS2, 235/50ZR18, 97Y) (ACDelco #M12771) 19187271 ШИНА, FRT (ШИНА MFG # 21201) (MICHELIN, PILOT MXM4, P235/55R17, 98H) (ACDelco #M21201) 19187271 ШИНА, RR (ШИНА MFG # 21201) (MICHELIN, PILOT MXM4, P235/55R17, 98H) (ACDelco #M21201) (GM05-008) - 2008 DM69 ДАТЧИК ДАВЛЕНИЯ В ШИНЕ (UJ6,UJ9) ↓ 25789964 SENSOR, ШИНА PRESS IND (INCLS 2-5) (BLUE) (EUROPE) (ACDelco #25789964) [ДАТЧИК ДАВЛЕНИЯ ШИНЫ КОЛЕСА С РАДИОПЕРЕДАЮЩИМ УСТРОЙСТВОМ] 25789964 SENSOR, ШИНА PRESS IND (INCLS 2-5) (BLUE) (EUROPE) (ACDelco #25789964) [ДАТЧИК ДАВЛЕНИЯ ШИНЫ КОЛЕСА С РАДИОПЕРЕДАЮЩИМ УСТРОЙСТВОМ] 25920615 SENSOR, ШИНА PRESS IND (INCLS 2-5) (INCLS BLACK VALVE CAP) (ACDelco #25920615) [ДАТЧИК ДАВЛЕНИЯ ШИНЫ КОЛЕСА С ПЕРЕДАЮЩИМ УСТРОЙСТВОМ] 15263240 VALVE KIT, ШИНА (ЧАСТЬ OF 1) (INCLS 3-5) (INCLS CAP, STEM, БОЛТ) (ACDelco #15263240) [ОБРАТНЫЙ КЛАПАН КОЛЕСА] not found VALVE, ШИНА (ЧАСТЬ OF 1, 2) 25731359 CAP, ШИНА PRESS IND SEN (ЧАСТЬ OF 1, 2) (CHROME) [КОЛПАЧОК НИППЕЛЯ КОЛЕСА] teamcadillac.ru 25858636 CAP, ШИНА PRESS IND SEN (ЧАСТЬ OF 1, 2) (BLACK) [КОЛПАК ГАЙКИ КОЛЕСА] not found БОЛТ, ШИНА PRESS IND SEN (ЧАСТЬ OF 1, 2) (GM05-009) - 2008 DM69 ДАТЧИК ДАВЛЕНИЯ В ШИНЕ (UH3) ↓ teamcadillac.ru 25740352 SENSOR, ШИНА PRESS IND (INCLS 2, 3, 5) (BLUE) (JAPAN/KOREA) (ACDelco #25740352) not found GROMMET, ШИНА VLV STEM (ЧАСТЬ OF 1, 6) not found VALVE, ШИНА (ЧАСТЬ OF 1, 6) 15234846 ГАЙКА, ШИНА PRESS IND SEN (ЧАСТЬ OF 6) (14 X 19) [ГАЙКА М8] not found CAP, ШИНА PRESS IND SEN (ЧАСТЬ OF 1, 6) 25731359 CAP, ШИНА PRESS IND SEN (ЧАСТЬ OF 1, 6) (CHROME) [КОЛПАЧОК НИППЕЛЯ КОЛЕСА] 19117460 VALVE KIT, ШИНА (INCLS 2-5) (INCLS CAP, CORE, GROMMET, NUT) (ACDelco #19117460) 06 - ПЕРЕДНЯЯ ПОДВЕСКА - РУЛЕВОЕ УПРАВЛЕНИЕ (6D06-046) - 2008 DM69 ПОДВЕСКА-ПЕРЕДНЯЯ (ЗАДНИЙ КОЛЕСО DRIVE MN6,MX0) ↓ 15219467 BRACKET, FRT UPR CONT ARM (INCLS 2-6, 35) (FRT UPR CONTROL ARM INCLUDED) 15219468 BRACKET, FRT UPR CONT ARM (INCLS 2-6, 35) [КРОНШТЕЙН] 19168536 BRACKET, FRT UPR CONT ARM (INCLS 2-6, 35) [КРОНШТЕЙН] 11519961 БОЛТ-HFH M12X1.75X75, 28.25 THD, 26.6 OD, 10.9, 7114M, MACH, HDR-PT (ЧАСТЬ OF 1) 11516078 ГАЙКА, FRT UPR CONT ARM (ЧАСТЬ OF 1) (M12X1.75X18) (8.917) [ГАЙКА] not found STUD, FRT UPR CONT ARM BALL (ЧАСТЬ OF 1) not found BUSHING, FRT UPR CONT ARM (ЧАСТЬ OF 1) not found ARM, FRT UPR CONT (ЧАСТЬ OF 1) not found АМОРТИЗАТОР, FRT SHK (W/SPR) (СМ. ГРУППУ 07.000 "АМОРТИЗАТОР/ПЕРЕДНЯЯ СТОЙКА & ПРУЖИНА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11516546 БОЛТ, HFL, M8X1.25X50, 37.2 THD, 18 OD, 10.9, PZO 7114M (FRT S/ABS) 15775067 KNUCKLE, STRG (INCLS 39, 40) [ПАЛЕЦ] 15775068 KNUCKLE, STRG (INCLS 39, 40) [ПАЛЕЦ] not found ГАЙКА, FRT UPR CONT ARM BALL STUD 11519879 ГАЙКА, FRT UPR CONT ARM BALL STUD (TO STRG ARM) (M12X1.75X16.75, 28 OD) (8.915) [ВИНТ В СБОРЕ] 11516382 ГАЙКА, HFH LK M14X2X15, 28 OD 10 7111M (FRT STAB SHF LINK) [ГАЙКА М10] not found CALIPER, FRT BRK (СМ. ГРУППУ 04.000 "ТОРМОЗНОЙ СУППОРТ-ПЕРЕДНИЙ DISC" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11588811 STUD, FRT WHL (ЧАСТЬ OF 16) (M14X1.5X24, 58 TOTAL LENGTH) [ШПИЛЬКА М14] 15267102 ROTOR, FRT BRK (MCHG) 15267103 ROTOR, FRT BRK (MCHG) 11515720 БОЛТ, FRT BRK ROT (M6X1X20, 12.3 OD) (FLAT 6 LOBED) (14.5 THD) (8.908) [ВИНТ] 13502216 HUB, FRT WHL (W/BRG) (INCLS 13) (W/O SENSOR) (5.806) (ACDelco #FW372) [СТУПИЦА КОЛЕСА] 25861810 SHIELD, FRT BRK 25861811 SHIELD, FRT BRK 25861812 SHIELD, FRT BRK [ЗАЩИТНЫЙ КОЖУХ ТОРМОЗНОГО ДИСКА] teamcadillac.ru 25861813 SHIELD, FRT BRK [ЗАЩИТА] 11518854 ГАЙКА, FRT LWR CONT ARM FRT (M14X2) (8.917) 11518314 БОЛТ, FRT BRK CLPR (USE T/W 89021297 ADH) (M14X2X50, 34THD) (8.900) 18022052 БОЛТ, FRT WHL BRG (M12X1.75X51, 20THD) (5.812) [БОЛТ] 15250265 ARM, FRT LWR CONT (INCLS 22-24) 15250266 ARM, FRT LWR CONT (INCLS 22-24) 25862781 ARM, FRT LWR CONT (INCLS 22-24) [РЫЧАГ] 25862782 ARM, FRT LWR CONT (INCLS 22-24) [РЫЧАГ ПОДВЕСКИ] not found BUSHING, FRT LWR CONT ARM (ЧАСТЬ OF 21) not found BUSHING, FRT LWR CONT ARM (ЧАСТЬ OF 21) not found STUD, FRT LWR CONT ARM BALL (ЧАСТЬ OF 21) 11562579 БОЛТ, FRT LWR CONT ARM RR (HFH, M16X2X110, 38 THD, 39.5 OD, 10.9 STL) (8.900) [БОЛТ] 03537773 ГАЙКА, FRT LWR CONT ARM RR (M14X2X11.92) (HEX W/CONICAL WA PREV TORQ) (5.383) 11562581 ГАЙКА, FRT LWR CONT ARM RR (8.917) [ВИНТ] 11562580 БОЛТ, FRT LWR CONT ARM FRT (HFH, M14X2X110, 48 THD, 35.0 OD, 10.9) (NON-POINTED POINT) [БОЛТ] 11518854 ГАЙКА, FRT LWR CONT ARM FRT (M14X2) (8.917) 15250258 LINK, FRT STAB SHF [СТОЙКА СТАБИЛИЗАТОРА ПОДВЕСКИ] 15250259 SHAFT, FRT STAB 25808055 SHAFT, FRT STAB [СТАБИЛИЗАТОР ПОПЕРЕЧНОЙ УСТОЙЧИВОСТИ] 11516382 ГАЙКА, HFH LK M14X2X15, 28 OD 10 7111M (FRT STAB SHF LINK (AT SHF)) [ГАЙКА М10] 15250272 INSULATOR, FRT STAB SHF 25808056 INSULATOR, FRT STAB SHF [УПЛОТНЕНИЕ] 15250260 CЛАМПА, FRT STAB SHF INSL 11518626 БОЛТ, HFH, M10X1.5X40, 28.7 THD, 22.3 OD, 10.9, GMW3359, 7.5MM MAT POINT (FRT STAB SHF INSL CLA) not found MOUNT, FRT S/ABS UPR (ЧАСТЬ OF 1) 11517996 ГАЙКА, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (FRT S/ABS) (ACDelco #11517996) [ГАЙКА М10] 11519393 БОЛТ, HEX W/CON ПРУЖИНА WA, M12X1.75X50, 35 OD, 42 THD, 10.9, 7114M (FRT S/ABS UPR BRKT) 11517996 ГАЙКА, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (ЧАСТЬ OF 4) (ACDelco #11517996) [ГАЙКА М10] 11516477 БОЛТ-HWH, M6X1X13, 13.2 OD, 6202M, 7114M, TAP, TR-PT (ЧАСТЬ OF 9) 25809676 BRACKET, WHL SPD SEN WIRE (ЧАСТЬ OF 9) 25809677 BRACKET, WHL SPD SEN WIRE (ЧАСТЬ OF 9) (6D06-047) - 2008 DM69 НАСОС РУЛЕВОГО УПРАВЛЕНИЯ LINES (ЗАДНИЙ КОЛЕСО DRIVE MN6,MX0) ↓ teamcadillac.ru 20774507 RESERVOIR, P/S FLUID 25830754 CAP, P/S FLUID RSVR (INCLS 3) not found SEAL, P/S FLUID RSVR CAP (O RING) (ЧАСТЬ OF 2) 11516222 CЛАМПА, ПРУЖИНАBAND, HOSE DIA=23, WIDTH=15, 6298M, MM (ЧАСТЬ OF 5) [ЗАЖИМ, ХОМУТ] 25821309 HOSE, P/S FLUID RSVR OTLT (INCLS 4) [ТРУБКА] 25948283 SEAL, P/S GR INL HOSE (ЧАСТЬ OF 9) (NATURAL) (PRESSURE BACKING RING) 11517937 БОЛТ, HWH, M8X1.25X22.1, 13.85 THD, 15 OD, 9.8, 7114M, MACH, 6175M ADH, MAT-PT (P/S GR INL PIPE BRKT) [БОЛТ М8Х22] not found SEAL, P/S GR INL HOSE (O RING) (ЧАСТЬ OF 9) 25909674 HOSE, P/S GR INL (INCLS 6, 8) [ТРУБКА] 25776287 BRACKET, P/S GR INL PIPE CLIP 11589332 БОЛТ, P/S GR INL HOSE BRKT (M10X1.5X20, 12.6 THD) (6.168) 25948284 SEAL, P/S GR INL HOSE (O RING) (ЧАСТЬ OF 15) 11516424 БОЛТ, HFH, M6X1X25, 14.2 O.D., HDR PT, 9.8, ZE (P/S GR INL HOSE BRKT) [БОЛТ М6] 11589332 БОЛТ, P/S GR INL HOSE BRKT (M10X1.5X20, 12.6 THD) (6.168) 25821305 HOSE, P/S GR OTLT (INCLS 12, 16) [ШЛАНГ] 11517127 CЛАМПА, ПРУЖИНА, 17MM-NOM, BLK (ЧАСТЬ OF 15) 25904079 HOSE, P/S FLUID CLR OTLT (INCLS 19, 23) 10199206 БОЛТ, P/S GR INL & OTLT PIPE RET (M6X1.0X18) (4.785) 11517127 CЛАМПА, ПРУЖИНА, 17MM-NOM, BLK (ЧАСТЬ OF 17) 25878706 CЛАМПА, P/S FLUID RSVR INL HOSE 11517397 ГАЙКА, HEX W/CON WA, 8X1.25, 28 O.D., 7.5 THK, 9, PEOR (FRT BPR ENGY ABS) 25821303 COOLER, P/S FLUID [ОХЛАДИТЕЛЬ] not found HOSE, P/S FLUID RSVR INL (ЧАСТЬ OF 17) 11516931 БОЛТ, FLAT WA & METRIC HEX HD MACHINE, M8X1.25X50 (P/S FLUID CLR BRKT) 11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (P/S FLUID RSVR) [БОЛТ] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (P/S FLUID RSVR) 25914590 PUMP, P/S (СМ. ГРУППУ 06.000 "НАСОС РУЛЕВОГО УПРАВЛЕНИЯ КРЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ПОМПА] (6D06-048) - 2008-2009 DM69 НАСОС РУЛЕВОГО УПРАВЛЕНИЯ LINES (ПОЛНОПРИВОДНЫЙ MX7) ↓ 20774507 RESERVOIR, P/S FLUID teamcadillac.ru 25830754 CAP, P/S FLUID RSVR (INCLS 3) not found SEAL, P/S FLUID RSVR CAP (O RING) (ЧАСТЬ OF 2) 11516222 CЛАМПА, ПРУЖИНАBAND, HOSE DIA=23, WIDTH=15, 6298M, MM (ЧАСТЬ OF 5) [ЗАЖИМ, ХОМУТ] 25821309 HOSE, P/S FLUID RSVR OTLT (INCLS 4) [ТРУБКА] 25948282 SEAL, P/S GR INL HOSE (ЧАСТЬ OF 9) 11517937 БОЛТ, HWH, M8X1.25X22.1, 13.85 THD, 15 OD, 9.8, 7114M, MACH, 6175M ADH, MAT-PT (P/S GR INL PIPE BRKT) [БОЛТ М8Х22] 25948283 SEAL, P/S GR INL HOSE (ЧАСТЬ OF 9) (NATURAL) (PRESSURE BACKING RING) 25821310 HOSE, P/S GR INL (INCLS 6, 8) [ТРУБКА] 10199206 БОЛТ, P/S GR INL & OTLT PIPE RET (M6X1.0X18) (4.785) 15224339 PUMP, P/S (СМ. ГРУППУ 06.000 "НАСОС РУЛЕВОГО УПРАВЛЕНИЯ КРЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25948284 SEAL, P/S GR INL HOSE (O RING) (ЧАСТЬ OF 13) 25821306 HOSE, P/S GR OTLT (INCLS 12, 14) [ТРУБКА] 11517127 CЛАМПА, ПРУЖИНА, 17MM-NOM, BLK (ЧАСТЬ OF 13) 25904079 HOSE, P/S FLUID CLR OTLT (INCLS 17, 21) 10199206 БОЛТ, P/S GR INL & OTLT PIPE RET (M6X1.0X18) (4.785) 11517127 CЛАМПА, ПРУЖИНА, 17MM-NOM, BLK (ЧАСТЬ OF 15) 25878706 CЛАМПА, P/S FLUID RSVR INL HOSE 11517397 ГАЙКА, HEX W/CON WA, 8X1.25, 28 O.D., 7.5 THK, 9, PEOR (FRT BPR ENGY ABS) 25821303 COOLER, P/S FLUID [ОХЛАДИТЕЛЬ] not found HOSE, P/S FLUID RSVR INL (ЧАСТЬ OF 15) 11516931 БОЛТ, FLAT WA & METRIC HEX HD MACHINE, M8X1.25X50 (P/S FLUID CLR BRKT) 11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (P/S FLUID RSVR) [БОЛТ] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (P/S FLUID RSVR) (6D06-049) - 2008 DM69 СИСТЕМА РУЛЕВОГО УПРАВЛЕНИЯ & ДЕТАЛИ КОМПЛЕКТА (ЗАДНИЙ КОЛЕСО DRIVE MN6,MX0) ↓ 25862315 КРОНШТЕЙН, INST (СМ. ГРУППУ 10.000 "ПРИБОРНАЯ ПАНЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS 13, 14) (LHD) not found COLUMN, STRG (W/ INT STRG SHFT) (СМ. ГРУППУ 06.000 "РУЛЕВАЯ КОЛОНКА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS 12) 11517996 ГАЙКА, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (STRG COL) [ГАЙКА М10] 15218203 SHAFT, STRG 11610011 БОЛТ, INTER STRG SHF (M8X1.25X31, 17THD) [БОЛТ] teamcadillac.ru 25924053 SHAFT, LWR INTER STRG [ВАЛ, ОСЬ] 11518143 БОЛТ, INTER STRG SHF LWR (M10X1.5X38, 14.5) (8.900) [БОЛТ М10] 11609752 БОЛТ, INTER STRG SHF LWR (M10X1.5X39, 22THD) (16OD, 16 THRU HOLE) 11516078 ГАЙКА, STRG LNKG OTR TIE ROD (TO STRG ARM) (M12X1.75X18) (8.917) [ГАЙКА] 11589278 БОЛТ, S/GR (M12X1.75X75.9, 45THD) (8.900) not found ГАЙКА, S/GR 11516078 ГАЙКА, S/GR (TO STRG ARM) (M12X1.75X18) (8.917) [ГАЙКА] not found GEAR, STRG (СМ. ГРУППУ 06.000 "РУЛЕВОЙ МЕХАНИЗМ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found SEAL, INTER STRG SHF LWR (ЧАСТЬ OF 2) 11609875 STUD-FLANGE, M10X1.5X12.5, M10X1.5X29, 18 OD, 9.8, GMW3044, HDR-PT (ЧАСТЬ OF 1) (8.981) 11516819 NUT-STAMPED M10 X 1.5 (ЧАСТЬ OF 1) (6D06-050) - 2008-2009 DM69 СИСТЕМА РУЛЕВОГО УПРАВЛЕНИЯ & ДЕТАЛИ КОМПЛЕКТА (ПОЛНОПРИВОДНЫЙ MX7) ↓ 25862315 КРОНШТЕЙН, INST (СМ. ГРУППУ 10.000 "ПРИБОРНАЯ ПАНЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS 12, 13) (LHD) not found COLUMN, STRG (W/ INT STRG SHFT) (СМ. ГРУППУ 06.000 "РУЛЕВАЯ КОЛОНКА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11517996 ГАЙКА, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (STRG COL) [ГАЙКА М10] 11610011 БОЛТ, INTER STRG SHF (M8X1.25X31, 17THD) [БОЛТ] 15218202 SHAFT, STRG [ВАЛ РУЛЕВОЙ КОЛОНКИ] 20781437 SHAFT, LWR INTER STRG [ВАЛ РУЛЕВОЙ КОЛОНКИ] 11518143 БОЛТ, INTER STRG SHF LWR (M10X1.5X38, 14.5) (8.900) [БОЛТ М10] 11609752 БОЛТ, INTER STRG SHF LWR (M10X1.5X39, 22THD) (16OD, 16 THRU HOLE) not found GEAR, STRG (СМ. ГРУППУ 06.000 "РУЛЕВОЙ МЕХАНИЗМ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) teamcadillac.ru 11516078 ГАЙКА, STRG LNKG OTR TIE ROD (TO STRG ARM) (M12X1.75X18) (8.917) [ГАЙКА] 11589135 БОЛТ, S/GR (M12X1.75X85, 60THD) (8.900) not found SEAL, INTER STRG SHF LWR 11609875 STUD-FLANGE, M10X1.5X12.5, M10X1.5X29, 18 OD, 9.8, GMW3044, HDR-PT (ЧАСТЬ OF 1) (8.981) 11516819 NUT-STAMPED M10 X 1.5 (ЧАСТЬ OF 1) (6D06-051) - 2008 DM69 РУЛЕВАЯ КОЛОНКА ЧАСТЬ 1 (ЗАДНИЙ КОЛЕСО DRIVE MN6,MX0, EXC POWER TILT & TELESCOPING N38) ↓ 20794842 COLUMN, STRG not found HARNESS, STRG COL WRG (INCLS 3) 25930338 HARNESS, STRG COL WRG (INCLS 3) teamcadillac.ru 25930339 HARNESS, STRG COL WRG (INCLS 3) not found RETAINER, STRG COL WRG HARN) (ЧАСТЬ OF 2) 25854685 SHAFT, UPR INTER STRG (INCLS 5) [ОСЬ] not found SEAL, INTER STRG SHF LWR (ЧАСТЬ OF 4) 26058124 БОЛТ, INTER STRG SHF UPR (M10X1.5X36) (HFH W/RETAINER NYLON LOCK) (UPR TO STRG COL) (6D06-052) - 2008-2009 DM69 РУЛЕВАЯ КОЛОНКА ЧАСТЬ 1 (ПОЛНОПРИВОДНЫЙ MX7, EXC POWER TILT & TELESCOPING N38) ↓ 20794842 COLUMN, STRG not found HARNESS, STRG COL WRG (INCLS 3) 25930339 HARNESS, STRG COL WRG (INCLS 3) not found RETAINER, STRG COL WRG HARN) (ЧАСТЬ OF 2) 15218199 SHAFT, UPR INTER STRG (INCLS 5) [ВАЛ РУЛЕВОЙ КОЛОНКИ] teamcadillac.ru not found SEAL, INTER STRG SHF LWR (ЧАСТЬ OF 4) 26058124 БОЛТ, INTER STRG SHF UPR (M10X1.5X36) (HFH W/RETAINER NYLON LOCK) (UPR TO STRG COL) (6D06-053) - 2008-2009 DM69 РУЛЕВАЯ КОЛОНКА ЧАСТЬ 1 (ПОЛНОПРИВОДНЫЙ MX7, POWER TILT & TELESCOPING N38) ↓ 15218196 COLUMN, STRG [РУЛЕВАЯ КОЛОНКА] not found HARNESS, STRG COL WRG (INCLS 3) 15951276 HARNESS, STRG COL WRG (INCLS 3) 25930343 HARNESS, STRG COL WRG (INCLS 3) not found RETAINER, STRG COL WRG HARN) (ЧАСТЬ OF 2) 15218199 SHAFT, UPR INTER STRG (INCLS 5) [ВАЛ РУЛЕВОЙ КОЛОНКИ] teamcadillac.ru not found SEAL, INTER STRG SHF LWR (ЧАСТЬ OF 4) 26058124 БОЛТ, INTER STRG SHF UPR (M10X1.5X36) (HFH W/RETAINER NYLON LOCK) (UPR TO STRG COL) (6D06-054) - 2008 DM69 РУЛЕВАЯ КОЛОНКА ЧАСТЬ 1 (ЗАДНИЙ КОЛЕСО DRIVE MN6,MX0, POWER TILT & TELESCOPING N38) ↓ 15218196 COLUMN, STRG [РУЛЕВАЯ КОЛОНКА] not found HARNESS, STRG COL WRG (INCLS 3) 15951276 HARNESS, STRG COL WRG (INCLS 3) 25930340 HARNESS, STRG COL WRG (INCLS 3) 25930342 HARNESS, STRG COL WRG (INCLS 3) 25930343 HARNESS, STRG COL WRG (INCLS 3) not found RETAINER, STRG COL WRG HARN) (ЧАСТЬ OF 2) 25854685 SHAFT, UPR INTER STRG (INCLS 5) [ОСЬ] not found SEAL, INTER STRG SHF LWR (ЧАСТЬ OF 4) teamcadillac.ru 26058124 БОЛТ, INTER STRG SHF UPR (M10X1.5X36) (HFH W/RETAINER NYLON LOCK) (UPR TO STRG COL) (6D06-058) - 2008 DM69 РУЛЕВОЙ МЕХАНИЗМ В СБОРЕ (ЗАДНИЙ КОЛЕСО DRIVE MN6,MX0) ↓ 25930831 GEAR, STRG (INCLS 2, 5-8, 10-15) [РЕЙКА] 25930833 GEAR, STRG (INCLS 2, 5-8, 10-15) 25980721 GEAR, STRG (INCLS 2-15) 25980722 GEAR, STRG (INCLS 2-15) 19177440 ROD KIT, STRG LNKG INR TIE (ЧАСТЬ OF 1) (INCLS 3, 5, 6, 8) [КОМПЛЕКТ ТЯГ] 19177440 ROD KIT, STRG LNKG INR TIE (ЧАСТЬ OF 1) (INCLS 3, 5, 6, 8) (6.230) [КОМПЛЕКТ ТЯГ] 11516078 ГАЙКА, STRG LNKG OTR TIE ROD (TO STRG ARM) (ЧАСТЬ OF 1, 2, 4, 9) (M12X1.75X18) (8.917) [ГАЙКА] 19177442 ROD KIT, STRG LNKG OTR TIE (INCLS 3) (ЧАСТЬ OF 1) [НАКОНЕЧНИК РУЛЕВОЙ ТЯГИ] 11570374 ГАЙКА, STRG LNKG INR TIE ROD (ЧАСТЬ OF 1, 2) (M14X1.5, 11 THK) 11516219 CЛАМПА, ПРУЖИНАBAND, HOSE DIA 17MM, WIDTH 15MM, 6298M (ЧАСТЬ OF 1, 2, 7) 19177438 BOOT KIT, S/GR (ЧАСТЬ OF 1) (INCLS 6, 8) 11516219 CЛАМПА, ПРУЖИНАBAND, HOSE DIA 17MM, WIDTH 15MM, 6298M (ЧАСТЬ OF 1, 2, 7) 19177443 ROD KIT, STRG LNKG OTR TIE (INCLS 3) (ЧАСТЬ OF 1) [НАКОНЕЧНИК РУЛЕВОЙ ТЯГИ] 11571012 CLIP, P/S GR PIPE (ЧАСТЬ OF 1, 11) (14X20X24) (CLIP - U, HARDENED STEEL, ZP) teamcadillac.ru 19177057 PIPE KIT, S/GR (ЧАСТЬ OF 1) (INCLS 10) not found БОЛТ, S/GR (ЧАСТЬ OF 1) not found BRACKET, S/GR (ЧАСТЬ OF 1) not found БОЛТ, S/GR VLV SOL (ЧАСТЬ OF 1) 25830755 SOLENOID, S/GR VLV (ЧАСТЬ OF 1) [СОЛЕНОИД] (6D06-059) - 2008-2009 DM69 РУЛЕВОЙ МЕХАНИЗМ В СБОРЕ (ПОЛНОПРИВОДНЫЙ MX7) ↓ 25930832 GEAR, STRG (INCLS 2-5, 7-10, 12-15) [РУЛЕВАЯ РЕЙКА] 25830755 SOLENOID, S/GR VLV (ЧАСТЬ OF 1) [СОЛЕНОИД] not found БОЛТ, S/GR VLV (ЧАСТЬ OF 1) teamcadillac.ru 19177441 ROD KIT, STRG LNKG INR TIE (ЧАСТЬ OF 1) (INCLS 5, 7, 8, 10) [НАКОНЕЧНИК РУЛЕВОЙ ТЯГИ] 19177441 ROD KIT, STRG LNKG INR TIE (ЧАСТЬ OF 1) (INCLS 5, 7, 8, 10) (6.230) [НАКОНЕЧНИК РУЛЕВОЙ ТЯГИ] 11516078 ГАЙКА, STRG LNKG OTR TIE ROD (TO STRG ARM) (ЧАСТЬ OF 1, 4, 6, 11) (M12X1.75X18) (8.917) [ГАЙКА] 19177444 ROD KIT, STRG LNKG OTR TIE (INCLS 5) [НАКОНЕЧНИК РУЛЕВОЙ ТЯГИ] 11570374 ГАЙКА, STRG LNKG INR TIE ROD (ЧАСТЬ OF 1, 4) (M14X1.5, 11 THK) 11516219 CЛАМПА, ПРУЖИНАBAND, HOSE DIA 17MM, WIDTH 15MM, 6298M (ЧАСТЬ OF 1, 4, 9) 19177439 BOOT KIT, S/GR (ЧАСТЬ OF 1) (INCLS 8, 10) [ХОМУТ РУЛЕВОГО КОЛЕСА] 12338017 CЛАМПА, WORM GEAR, 28.6-76.2, STAINLESS STEEL (ЧАСТЬ OF 1, 4, 9) (ACDelco #12338017) [ЗАЖИМ, ХОМУТ] 19177445 ROD KIT, STRG LNKG OTR TIE (INCLS 5) [НАКОНЕЧНИК РУЛЕВОЙ ТЯГИ] not found CLIP, PIPE S/GR (ЧАСТЬ OF 1) not found PIPE, S/GR (ЧАСТЬ OF 1) not found БОЛТ, PIPE S/GR (ЧАСТЬ OF 1) not found BRACKET, PIPE S/GR (ЧАСТЬ OF 1) (6D06-061) - 2008 DM69 РУЛЕВАЯ КОЛОНКА ЧАСТЬ 2 SWITCHES & COVERS (EXC POWER TILT & TELESCOPING N38) ↓ not found BRACKET, T/SIG SW 15917912 SWITCH, WSW & WSWA (ACDelco #D6330E) [ПЕРЕКЛЮЧАТЕЛЬ] 25941116 РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ, STRG WHL INFL RST MDL (W/ACSRY CNCT) [ЭЛЕКТРОПРОВОД ПОДУШКИ БЕЗОПАСНОСТИ] not found БОЛТ, STRG WHL INFL RST MDL РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ 25853012 SENSOR, STRG ANGLE (LABELED W/OEM PN 25853012, 25794841.) [ДАТЧИК] 25853012 SENSOR, STRG ANGLE (LABELED W/OEM PN 25853012, 25794841.) [ДАТЧИК] 25865394 КЛЮЧ, DR LK & IGN LK (UNCODED) (MASTER) 25995382 КЛЮЧ, DR LK & IGN LK (UNCODED) 25771046 МОДУЛЬ, THEFT DTRNT (ЧАСТЬ OF 19) [БЕСКОНТАКТНЫЙ ВЫКЛЮЧАТЕЛЬ ЗАМКА ЗАЖИГАНИЯ] 20869121 CYLINDER KIT, IGN LK (UNCODED) (VEHICLES W/AUTO TRANS) 25979925 CYLINDER KIT, IGN LK (UNCODED) (MAN TRANS VEHICLES) 25925643 SHROUD, STRG COL (EBONY) 25925644 SHROUD, STRG COL (COCOA) 25749780 PLUG, STRG COL LWR TR CVR HOLE 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (STRG COL SHRD) [ВИНТ М4] 25861219 SHROUD, STRG COL (COCOA) 25942723 SHROUD, STRG COL (EBONY) teamcadillac.ru not found SOLENOID, IGN LK CYL CONT (ЧАСТЬ OF 19) 15924259 SWITCH, IGN & START (ACDelco #D1416G) [ВЫКЛЮЧАТЕЛЬ ЗАМКА ЗАЖИГАНИЯ КОНТАКТНЫЙ] 92184907 SWITCH, IGN & START [ВЫКЛЮЧАТЕЛЬ ЗАМКА ЗАЖИГАНИЯ КОНТАКТНЫЙ] not found БОЛТ, IGN & START SW (ЧАСТЬ OF 19) not found COLUMN, STRG (СМ. ГРУППУ 06.000 "РУЛЕВАЯ КОЛОНКА ЧАСТЬ 1" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found CЛАМПА, IGN LK CYL CASE (ЧАСТЬ OF 19) not found БОЛТ, IGN & START SW CLA (ЧАСТЬ OF 19) 15924257 ШЛАНГИ, IGN & START SW (INCLS 7, 13, 15, 17, 18) 15924258 ШЛАНГИ, IGN & START SW (INCLS 7, 13, 15, 17, 18) (USED ON VEHICLES BUILT 1-31-08 AND PRIOR) (FOR 2ND DES SEE 25928807) 25928230 ШЛАНГИ, IGN & START SW (INCLS 7, 13, 15, 17, 18) [КОРПУС ЗАМКА ЗАЖИГАНИЯ] 25928807 ШЛАНГИ, IGN & START SW (INCLS 7, 13, 15, 17, 18) (USED ON VEHICLES BUILT 2-1-08 AND AFTER) (FOR 1ST DES SEE 15924258) 25962171 SHROUD, STRG COL UPR (EBONY) (TOP COVER) 25962172 SHROUD, STRG COL UPR (COCOA) (TOP COVER) 25917578 COVER, STRG COL HSG (EBONY) (UPR COLUMN CLOSEOUT) 25917579 COVER, STRG COL HSG (COCOA) (UPR COLUMN CLOSEOUT) 25952115 SWITCH, T/SIG & HDLP DIMR (2.895) (ACDelco #D6242E) 25952115 SWITCH, T/SIG & HDLP DIMR (2.895) (ACDelco #D6242E) 25952115 SWITCH, T/SIG & HDLP DIMR (ACDelco #D6242E) 25952115 SWITCH, T/SIG & HDLP DIMR (ACDelco #D6242E) 25993190 SWITCH, T/SIG & HDLP DIMR (2.895) (ACDelco #D6240E) 25993190 SWITCH, T/SIG & HDLP DIMR (2.895) (ACDelco #D6240E) 25993190 SWITCH, T/SIG & HDLP DIMR (ACDelco #D6240E) 25993190 SWITCH, T/SIG & HDLP DIMR (ACDelco #D6240E) 25993191 SWITCH, T/SIG & HDLP DIMR (2.895) (ACDelco #D6241E) 25993191 SWITCH, T/SIG & HDLP DIMR (2.895) (ACDelco #D6241E) 25993191 SWITCH, T/SIG & HDLP DIMR (ACDelco #D6241E) 25993191 SWITCH, T/SIG & HDLP DIMR (ACDelco #D6241E) not found БОЛТ, T/SIG SW BRKT 25823963 KNOB, STRG COL KEY REL LVR [КНОПКА] (6D06-062) - 2008 DM69 РУЛЕВАЯ КОЛОНКА-ВЫКЛЮЧАТЕЛИ-КРЫШКИ (ЗАДНИЙ ПРИВОД, РЕГУЛИРУЕМАЯ, ТЕЛЕСКОПИЧЕСКАЯ) ↓ not found BRACKET, T/SIG SW 15917912 SWITCH, WSW & WSWA (ACDelco #D6330E) [ПЕРЕКЛЮЧАТЕЛЬ] 25941116 РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ, STRG WHL INFL RST MDL (W/ACSRY CNCT) [ЭЛЕКТРОПРОВОД ПОДУШКИ БЕЗОПАСНОСТИ] not found БОЛТ, STRG WHL INFL RST MDL РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ 25853012 SENSOR, STRG ANGLE (LABELED W/OEM PN 25853012, 25794841.) [ДАТЧИК] 25853012 SENSOR, STRG ANGLE (LABELED W/OEM PN 25853012, 25794841.) [ДАТЧИК] 25865394 КЛЮЧ, DR LK & IGN LK (UNCODED) (MASTER) 25995382 КЛЮЧ, DR LK & IGN LK (UNCODED) 25771046 МОДУЛЬ, THEFT DTRNT (ЧАСТЬ OF 24) [БЕСКОНТАКТНЫЙ ВЫКЛЮЧАТЕЛЬ ЗАМКА ЗАЖИГАНИЯ] 20869121 CYLINDER KIT, IGN LK (UNCODED) (VEHICLES W/AUTO TRANS) 25979925 CYLINDER KIT, IGN LK (UNCODED) (MAN TRANS VEHICLES) 25925643 SHROUD, STRG COL (EBONY) 25925644 SHROUD, STRG COL (COCOA) 25749780 PLUG, STRG COL LWR TR CVR HOLE 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (STRG COL SHRD) [ВИНТ М4] 25925646 SHROUD, STRG COL (EBONY) 25925647 SHROUD, STRG COL (COCOA) not found SOLENOID, IGN LK CYL CONT (ЧАСТЬ OF 24) 15924259 SWITCH, IGN & START (ACDelco #D1416G) [ВЫКЛЮЧАТЕЛЬ ЗАМКА ЗАЖИГАНИЯ КОНТАКТНЫЙ] 92184907 SWITCH, IGN & START [ВЫКЛЮЧАТЕЛЬ ЗАМКА ЗАЖИГАНИЯ КОНТАКТНЫЙ] not found БОЛТ, IGN & START SW (ЧАСТЬ OF 24) not found COLUMN, STRG (СМ. ГРУППУ 06.000 "РУЛЕВАЯ КОЛОНКА ЧАСТЬ 1" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found CЛАМПА, IGN LK CYL CASE (ЧАСТЬ OF 24) not found БОЛТ, IGN & START SW CLA (ЧАСТЬ OF 24) 15923841 SWITCH, STRG COL TILT WHL & TLSCP 25962171 SHROUD, STRG COL UPR (EBONY) (TOP COVER) 25962172 SHROUD, STRG COL UPR (COCOA) (TOP COVER) 25917578 COVER, STRG COL HSG (EBONY) (UPR COLUMN CLOSEOUT) 25917579 COVER, STRG COL HSG (COCOA) (UPR COLUMN CLOSEOUT) 25952115 SWITCH, T/SIG & HDLP DIMR (2.895) (ACDelco #D6242E) 25952115 SWITCH, T/SIG & HDLP DIMR (2.895) (ACDelco #D6242E) 25952115 SWITCH, T/SIG & HDLP DIMR (ACDelco #D6242E) 25952115 SWITCH, T/SIG & HDLP DIMR (ACDelco #D6242E) teamcadillac.ru 25993190 SWITCH, T/SIG & HDLP DIMR (2.895) (ACDelco #D6240E) 25993190 SWITCH, T/SIG & HDLP DIMR (ACDelco #D6240E) 25993191 SWITCH, T/SIG & HDLP DIMR (2.895) (ACDelco #D6241E) 25993191 SWITCH, T/SIG & HDLP DIMR (ACDelco #D6241E) not found БОЛТ, T/SIG SW BRKT 15924258 ШЛАНГИ, IGN & START SW (INCLS 7, 13, 15, 17, 18) (USED ON VEHICLES BUILT 1-31-08 AND PRIOR) (FOR 2ND DES SEE 25928807) 25928230 ШЛАНГИ, IGN & START SW (INCLS 7, 13, 15, 17, 18) [КОРПУС ЗАМКА ЗАЖИГАНИЯ] 25928806 ШЛАНГИ, IGN & START SW (INCLS 7, 13, 15, 17, 18) 25928807 ШЛАНГИ, IGN & START SW (INCLS 7, 13, 15, 17, 18) (USED ON VEHICLES BUILT 2-1-08 AND AFTER) (FOR 1ST DES SEE 15924258) 25823963 KNOB, STRG COL KEY REL LVR [КНОПКА] (6D06-065) - 2008 DM69 STEERING КОЛЕСО ↓ 25902138 КОЛЕСО, STRG (INCLS 2-5, 7, 9-12) (EBONY) (W/WOODGRAIN) 25902139 КОЛЕСО, STRG (INCLS 2-5, 7, 9-12) (COCOA) (LEATHER) 25960210 КОЛЕСО, STRG (INCLS 2-5, 7, 9-12) (EBONY) [РУЛЕВОЕ КОЛЕСО] 25960211 КОЛЕСО, STRG (INCLS 2-5, 7, 9-12) (COCOA) 25919020 HARNESS, STRG WHL PAD ACSRY WRG (ЧАСТЬ OF 1) 25850372 SWITCH, RDO CONT (ЧАСТЬ OF 1) (ARGENT) (9.649) [ВЫКЛЮЧАТЕЛЬ АУДИОСИСТЕМЫ, РАСПОЛОЖЕННЫЙ НА РУЛЕВОМ КОЛЕСЕ] 25850372 SWITCH, RDO CONT (ЧАСТЬ OF 1) (ARGENT) (9.649) [ВЫКЛЮЧАТЕЛЬ АУДИОСИСТЕМЫ, РАСПОЛОЖЕННЫЙ НА РУЛЕВОМ КОЛЕСЕ] 25850372 SWITCH, RDO CONT (ЧАСТЬ OF 1) (ARGENT) (9.649) [ВЫКЛЮЧАТЕЛЬ АУДИОСИСТЕМЫ, РАСПОЛОЖЕННЫЙ НА РУЛЕВОМ КОЛЕСЕ] 25850372 SWITCH, RDO CONT (ЧАСТЬ OF 1) (ARGENT) (9.649) [ВЫКЛЮЧАТЕЛЬ АУДИОСИСТЕМЫ, РАСПОЛОЖЕННЫЙ НА РУЛЕВОМ КОЛЕСЕ] 25850372 SWITCH, RDO CONT (ЧАСТЬ OF 1) (ARGENT) [ВЫКЛЮЧАТЕЛЬ АУДИОСИСТЕМЫ, РАСПОЛОЖЕННЫЙ НА РУЛЕВОМ КОЛЕСЕ] teamcadillac.ru 25850372 SWITCH, RDO CONT (ЧАСТЬ OF 1) (ARGENT) [ВЫКЛЮЧАТЕЛЬ АУДИОСИСТЕМЫ, РАСПОЛОЖЕННЫЙ НА РУЛЕВОМ КОЛЕСЕ] 25919049 BEZEL, STRG WHL SPOKE CONT SW (ЧАСТЬ OF 1) (STAINLESS SILVER) (3 O'CLOCK TRIM PLATE) 25889493 БОЛТ, STRG WHL СИГНАЛ SW (ЧАСТЬ OF 1) (PAN HEAD, SPECIAL THREAD, 8 OD, 13 LENGTH, 1022 STL.) (6.512) 25856864 МОДУЛЬ, STRG WHL INFL RST (EBONY) (14.865) 25856865 МОДУЛЬ, STRG WHL INFL RST (COCOA) (14.865) 25889495 CONTACT, STRG WHL СИГНАЛ (ЧАСТЬ OF 1) 11610164 БОЛТ, STRG WHL (M15X1.5X28.77, 15THD) 25919022 COVER, STRG WHL LWR (ЧАСТЬ OF 1) (STAINLESS SILVER) (6 O'CLOCK TRIM PLATE) 25919045 BEZEL, STRG WHL SPOKE CONT SW (ЧАСТЬ OF 1) (STAINLESS SILVER) (9 O'CLOCK TRIM PLATE) 15851239 SWITCH, CRCONT (ЧАСТЬ OF 1) not found SHROUD, STRG WHL (ЧАСТЬ OF 1) 25889494 БОЛТ, STRG WHL СИГНАЛ SW (TAPPING SCREW) 25889494 БОЛТ, STRG WHL СИГНАЛ SW (TAPPING SCREW) (6D06-066) - 2008 DM69 РАСПОРКА ПРЕДНЕЙ ПОДВЕСКИ ↓ 25889925 BRACE, F/END SH MET CR 11516078 ГАЙКА, HFH, M12X1.75, 14THK, 25 O.D., 10, PZOR (F/END SH MET CR BR) [ГАЙКА] 14047726 WASHER, F/END SH MET CR BR (M13X35X3) (7.347) [ШАЙБА] 11589407 БОЛТ, HWH, M8X1.25X35, 23.5 THD, 24 OD, 10.9, GMW3359, M-PT. (FRT S/ABS UPR BRKT) [БОЛТ] teamcadillac.ru 11561669 STUD - DOUBLE ENDED, M3.0X1.12X12.0, GM512M STL GRADE B, GMW4205 (FRT S/ABS) (6E06-002) - 2008-2009 DM69 ПОДВЕСКА-ПЕРЕДНЯЯ (ПОЛНОПРИВОДНЫЙ MX7) ↓ 11519393 БОЛТ, HEX W/CON ПРУЖИНА WA, M12X1.75X50, 35 OD, 42 THD, 10.9, 7114M (FRT S/ABS UPR BRKT) not found PLUG, FRT S/ABS ACC HOLE 15219467 BRACKET, FRT UPR CONT ARM (INCLS 6-11, 44-46) (FRT UPR CONTROL ARM INCLUDED) 15219468 BRACKET, FRT UPR CONT ARM (INCLS 6-11, 44-46) [КРОНШТЕЙН] 19168536 BRACKET, FRT UPR CONT ARM (INCLS 6-11, 44-46) [КРОНШТЕЙН] 11517996 ГАЙКА, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (FRT S/ABS) (ACDelco #11517996) [ГАЙКА М10] not found WASHER, FRT S/ABS 15840339 WASHER, FRT S/ABS not found MOUNT, FRT SUSP STRUT (ЧАСТЬ OF 3) not found LOCATOR, FRT SUSP STRUT UPR (ЧАСТЬ OF 3) not found WASHER, FRT UPR CONT ARM (ЧАСТЬ OF 3) 11519961 БОЛТ, FRT UPR CONT ARM (БОЛТ, HEX FLNG HD (12X1.75X75) (PZOR 10.9) (ЧАСТЬ OF 3) (M12X1.75X75) (8.900) not found STUD, FRT UPR CONT ARM BALL (ЧАСТЬ OF 3) not found BUSHING, FRT UPR CONT ARM (RR) (ЧАСТЬ OF 3) not found ARM, FRT UPR CONT (ЧАСТЬ OF 3) not found АМОРТИЗАТОР, FRT SHK (W/SPR) (СМ. ГРУППУ 07.000 "АМОРТИЗАТОР/ПЕРЕДНЯЯ СТОЙКА & ПРУЖИНА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found РАМА, DRIVETRAIN & FRT SUSP 03537773 ГАЙКА, FRT LWR CONT ARM RR (M14X2X11.92) (HEX W/CONICAL WA PREV TORQ) (5.383) not found BUSHING, FRT LWR CONT ARM RR (ЧАСТЬ OF 17) 25862781 ARM, FRT LWR CONT (INCLS 16, 18, 31) [РЫЧАГ] 25862782 ARM, FRT LWR CONT (INCLS 16, 18, 31) [РЫЧАГ ПОДВЕСКИ] not found STUD, FRT LWR CONT ARM BALL (ЧАСТЬ OF 17) 15775069 KNUCKLE, STRG [ПАЛЕЦ] 15775070 KNUCKLE, STRG [ПАЛЕЦ] not found ГАЙКА, FRT UPR CONT ARM BALL STUD 11519879 ГАЙКА, FRT UPR CONT ARM BALL STUD (TO STRG ARM) (M12X1.75X16.75, 28 OD) (8.915) [ВИНТ В СБОРЕ] teamcadillac.ru 15851374 SHIELD, FRT BRK 15851378 SHIELD, FRT BRK 15851640 SHIELD, FRT BRK 15851641 SHIELD, FRT BRK not found STUD, FRT WHL (ЧАСТЬ OF 23) not found HUB, FRT WHL (W/BRG) (INCLS 22) 13502216 HUB, FRT WHL (W/BRG) (INCLS 22) (W/O SENSOR) (5.806) (ACDelco #FW372) [СТУПИЦА КОЛЕСА] 15267102 ROTOR, FRT BRK (MCHG) 15267103 ROTOR, FRT BRK (MCHG) 11515720 БОЛТ, FRT BRK ROT (M6X1X20, 12.3 OD) (FLAT 6 LOBED) (14.5 THD) (8.908) [ВИНТ] not found ГАЙКА, S/KNU 11516382 ГАЙКА, S/KNU (M14X2X15) (W/O J CLIP RETAINER) (8.917) [ГАЙКА М10] not found CALIPER, FRT BRK (СМ. ГРУППУ 04.000 "ТОРМОЗНОЙ СУППОРТ-ПЕРЕДНИЙ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found БОЛТ, FRT BRK CLPR 11518314 БОЛТ, FRT BRK CLPR (USE T/W 89021297 ADH) (M14X2X50, 34THD) (8.900) 11562580 БОЛТ, FRT WHL BRG (HFH, M14X2X110, 48 THD, 35.0 OD, 10.9) (NON-POINTED POINT) (6.174) [БОЛТ] 10282253 ГАЙКА, FRT STAB SHF LINK (M14X2.0 6H THD) (6.164) [ГАЙКА М14] 11588357 ГАЙКА, FRT STAB SHF LINK (M12X1.75, 13.5 THK) (14.875) [ВИНТ В СБОРЕ] not found BUSHING, FRT LWR CONT ARM (FRT) (ЧАСТЬ OF 17) 11519961 БОЛТ-HFH M12X1.75X75, 28.25 THD, 26.6 OD, 10.9, 7114M, MACH, HDR-PT (FRT S/ABS YOKE) 25764673 YOKE, FRT S/ABS 25764674 YOKE, FRT S/ABS 11516383 ГАЙКА, HFH LK 16X2X18.9 34.2 OD 10 7111M PREV TORQ (FRT LWR CONT ARM) [ГАЙКА] 11516078 ГАЙКА, HFH, M12X1.75, 14THK, 25 O.D., 10, PZOR (FRT S/ABS YOKE) [ГАЙКА] 25750245 RETAINER, FRT STAB SHF INSL [ФИКСАТОР ПОДВЕСКИ] 25751736 SHAFT, FRT STAB 25773618 INSULATOR, FRT STAB SHF [ЗАГЛУШКА ПЕРЕДНЕГО СТАБИЛИЗАТОРА] 25764660 CЛАМПА, FRT STAB SHF INSL [ОПОРНАЯ СКОБА СТАБИЛИЗАТОРА] 11515775 БОЛТ, HFH, M12X1.75X30, 10.9, 7114M (FRT STAB SHF INSL CLA) [БОЛТ] 15231140 LINK, FRT STAB SHF [РЫЧАГ СТАБИЛИЗАТОРА ПОДВЕСКИ] 15231140 LINK, FRT STAB SHF [РЫЧАГ СТАБИЛИЗАТОРА ПОДВЕСКИ] not found STUD, FRT UPR CONT ARM BALL (ЧАСТЬ OF 3) not found BUSHING, FRT UPR CONT ARM (FRT) (ЧАСТЬ OF 3) 03537772 ГАЙКА, M12X1.75, 10.6THK, 28 O.D., 10, 7111M (ЧАСТЬ OF 3) (8.917) (6E06-010) - 2008-2009 DM69 DRIVE AXLE КРЕПЛЕНИЕ/FRONT (ПОЛНОПРИВОДНЫЙ MX7) ↓ not found КРОНШТЕЙН, FRT DIFF (СМ. ГРУППУ 06.000 "DIFFERENTIAL КРОНШТЕЙН/FRONT AXLE" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25790586 SHIELD, F/AXL PROP SHF HT 11514139 БОЛТ, W/WA M6X1X26, 17 OD, HDR PNT, FULL THD, 9.8, POR (F/AXL PROP SHF HT SHLD) [БОЛТ] teamcadillac.ru 11519346 БОЛТ, FRT DIFF CARR (БОЛТ-HFH W/CON WA, M12X1.75X60, 34 THD) 11518121 ГАЙКА, U, M6X1, MULTI THD, .5'-4.0' THK PNL (F/AXL PROP SHF HT SHLD PROPELLER SHAFT) 11519348 БОЛТ, HFH, M10X1.5X41.35, 29.2 THD, 22.3 OD, 10.9, GMW3359 (FRT WHL DRV INTER SHF HSG) 25714853 ШЛАНГИ, FRT WHL DRV INTER SHF (INCLS 8-10) (INCLS BEARING & RETAINER) [ЧЕХОЛ ПРИВОДА] not found ШЛАНГИ, FRT WHL DRV INTER SHF (ЧАСТЬ OF 7) not found BEARING, FRT WHL DRV INTER SHF (ЧАСТЬ OF 7) 88996676 RETAINER, FRT WHL DRV INTER SHF BRG (ЧАСТЬ OF 7) (6E06-016) - 2008-2009 DM69 DIFFERENTIAL КРОНШТЕЙН/FRONT AXLE (ПОЛНОПРИВОДНЫЙ MX7) ↓ 25978167 КРОНШТЕЙН, FRT DIFF (INCLS 2-26, 102-111) [РЕДУКТОР ДИФФЕРЕНЦИАЛА ВЕДУЩЕГО МОСТА] not found COVER, FRT DIFF CARR (ЧАСТЬ OF 1) teamcadillac.ru not found ШЛАНГИ, FRT DIFF DRV P/GR INR BRG (ЧАСТЬ OF 1) 89047861 ГАЙКА, FRT DIFF DRV P/GR (ЧАСТЬ OF 1) [ГАЙКА] 19178812 FLANGE, FRT DIFF CARR (ЧАСТЬ OF 1) 19132939 SEAL, FRT DIFF DRV P/GR (ЧАСТЬ OF 1) (4.515) [ПРОКЛАДКА] not found BEARING, FRT DIFF DRV P/GR INR (ЧАСТЬ OF 1) not found BEARING, FRT DIFF DRV P/GR INR (ЧАСТЬ OF 1) not found SHIM, FRT DIFF DRV P/GR BRG (ЧАСТЬ OF 1) 89047930 БОЛТ, FRT DIFF CARR CVR (ЧАСТЬ OF 1) 19132939 SEAL, FRT DIFF DRV P/GR (ЧАСТЬ OF 1) (4.515) [ПРОКЛАДКА] not found SPACER, FRT DIFF DRV P/GR BRG (ЧАСТЬ OF 1) not found BEARING, FRT DIFF DRV P/GR INR (ЧАСТЬ OF 1) not found BEARING, FRT DIFF DRV P/GR INR (ЧАСТЬ OF 1) 89047832 SEAL, FRT WHL DRV INTER SHF HSG (ЧАСТЬ OF 1) [ПРОКЛАДКА] 89059039 PLUG, FRT DIFF CARR OIL DRN (ЧАСТЬ OF 1) (5.400) not found SHIM, FRT DIFF SI GR (ЧАСТЬ OF 1) not found BEARING, FRT DIFF DRV P/GR OTR (ЧАСТЬ OF 1) 89047859 GASKET, FRT DIFF CARR CVR (ЧАСТЬ OF 1) [УПЛОТНЕНИЕ] 15852707 VENT, F/AXL (ЧАСТЬ OF 1) (5.387) [КЛАПАН] 88996591 SEAL, F/AXL SHF (ЧАСТЬ OF 1) (5.822) 89047930 БОЛТ, FRT DIFF CARR CVR (ЧАСТЬ OF 1) 89059038 PLUG, FRT DIFF CARR OIL FIL (ЧАСТЬ OF 1) (M20X1.5X14) (W/SEAL) (5.400) 89047934 SEAL, FRT WHL DRV INTER SHF (ЧАСТЬ OF 1) [ПРОКЛАДКА] 89047933 RETAINER, FRT WHL DRV INTER SHF (ЧАСТЬ OF 1) 89047931 SHAFT, FRT WHL DRV INTER (ЧАСТЬ OF 1) 89047929 БОЛТ, FRT DIFF R/GR (ЧАСТЬ OF 1) not found SHAFT, FRT DIFF P/GR (ЧАСТЬ OF 1) not found CASE, FRT DIFF (ЧАСТЬ OF 1) not found GEAR, FRT DIFF RING (ЧАСТЬ OF 1) not found WASHER, FRT DIFF SI GR THR (ЧАСТЬ OF 1) not found GEAR, FRT DIFF SI (ЧАСТЬ OF 1) not found WASHER, FRT DIFF P/GR THR (ЧАСТЬ OF 1) not found GEAR, FRT DIFF PINION (ЧАСТЬ OF 1) not found GEAR, FRT DIFF DRV PINION (ЧАСТЬ OF 1) (6E06-017) - 2008 DM69 НАСОС РУЛЕВОГО УПРАВЛЕНИЯ КРЕПЛЕНИЕ ↓ 12602074 BRACKET, P/S PUMP teamcadillac.ru 12602074 BRACKET, P/S PUMP 11518632 БОЛТ, P/S PUMP BRKT (M10X1.5X70, 25.9 THD) (HFH, MATPOINT) [БОЛТ] 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (P/S PUMP) not found PUMP, P/S (СМ. ГРУППУ 06.000 "НАСОС РУЛЕВОГО УПРАВЛЕНИЯ ASM" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 12574521 PULLEY, P/S PUMP [ШКИВ НАСОСА ГУРА] 12574521 PULLEY, P/S PUMP [ШКИВ НАСОСА ГУРА] 11518628 БОЛТ, HVY HEX ACORN FLG HD, M10X1.5X50, GMW25M (10.9) STL, GMW3358 (P/S PUMP BRKT) 07 - КУЗОВ - ПРУЖИНЫ - АМОРТИЗАТОРЫ - БАМПЕРЫ (6D07-025) - 2008 DM69 БАМПЕР-ПЕРЕДНИЙ (ИСКЛЮЧАЯ ЗАЩИТУ ПЕШЕХОДА) ↓ 25870685 BAR, FRT BPR IMP [ЗАДВИЖКА] not found RETAINER, FRT BPR IMP BAR STUD PLT (PUSH ON) 15869580 BRACKET, HDLP [ОПОРНАЯ ПЛАНКА ПЕРЕДНЕЙ ФАРЫ] 25924112 BRACKET, HDLP 11517397 ГАЙКА, HEX W/CON WA, 8X1.25, 28 O.D., 7.5 THK, 9, PEOR (FRT BPR ENGY ABS) 15892242 АМОРТИЗАТОР, FRT BPR FASCIA ENGY UPR [ВНУТРЕННЯЯ ПАНЕЛЬ БАМПЕРА] 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (FRT FOG LP BRKT) [ВИНТ М4] 21077131 RETAINER, FRT BPR FASCIA ENGY ABS [СТОПОПОР] 20831753 REINFORCEMENT, FRT BPR FASCIA [ОПОРНАЯ ПЛАНКА ПАНЕЛИ БАМПЕРА] 20831754 REINFORCEMENT, FRT BPR FASCIA [ОПОРНАЯ ПЛАНКА ПАНЕЛИ БАМПЕРА] 11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (FRT BPR FASCIA RET) [БОЛТ М6] 11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (FRT BPR FASCIA REINF) [БОЛТ М6] 11561857 CLIP, FRT FOG LP ADJ БОЛТ RET (BLACK) (14.13 X 11 X 8.6) (7.831) 15795653 CLIP, FRT FOG LP ADJ БОЛТ RET (13X8.13X9.27) (7.831) [ФИКСАТОР ПАНЕЛИ БАМПЕРА] 25536302 ГАЙКА, FRT BPR UPR FASCIA (4.2 X 1.41) (TAPPING NUT) (3.430) [ПРИЖИМНАЯ ПЛАСТИНА ПАНЕЛИ КУЗОВА] 25896041 GRILLE, RAD LWR (СМ. ГРУППУ 01.000 "GRILLE" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [РЕШЕТКА РАДИАТОРА] 15896564 FASCIA, FRT BPR LWR [МОЛДИНГ ПАНЕЛИ ПЕРЕДНЕГО БАМПЕРА] 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (FRT BPR FASCIA OTR RET) [ВИНТ М4] 15272090 DEFLECTOR, FRT BPR FASCIA LWR [МОЛДИНГ ПЕРЕДНЕГО БАМПЕРА] 21030249 RETAINER, EXPAN, 21 LG, 20. OD, 8.0 HOLE, 3.0-5.0 PNL, NYLON 6/6, BLK (FRT BPR LWR FASCIA) (8.950) (PUSH IN) [ПИСТОН КРЕПЛЕНИЯ КОЖУХА РАДИАТОРА(ПЛАСТИК)] 15272157 BEZEL, FRT FOG LP (FOR VEHICLES BUILT W/FRONT BRAKE ОХЛАЖДЕНИЕ DUCTS) (ON VEH BUILT BEFORE 3/31/08 OR IF REPLACED BEZEL HAS OPENINGS/SLOTSMUST ALSO ORDER 25961369) 15904574 BEZEL, FRT FOG LP [НАКЛАДКА ПАНЕЛИ БАМПЕРА] 15904575 BEZEL, FRT FOG LP [ОКАНТОВКА ПРОТИВОТУМАННОЙ ФАРЫ] 25961369 BEZEL, FRT FOG LP (FOR VEHICLES BUILT W/ FRONT BRAKE ОХЛАЖДЕНИЕ DUCTS) (ON VEH BUILT BEFORE 3/31/08 OR IF REPLACED BEZEL HAS OPENINGS/SLOTS, MUST ALSO ORDER 25961370) 11562364 CLIP, RAD GRL (18X10X11.6) [ЗАЖИМ ПАНЕЛИ БАМПЕРА] 25768800 BUMPER, FRT BPR FASCIA [ЭЛЕМЕНТ НАКЛАДКИ БАМПЕРА] 21030249 RETAINER, EXPAN, 21 LG, 20. OD, 8.0 HOLE, 3.0-5.0 PNL, NYLON 6/6, BLK (FRT BPR FASCIA (PUSH IN)) (8.950) (PUSH IN) [ПИСТОН КРЕПЛЕНИЯ КОЖУХА РАДИАТОРА(ПЛАСТИК)] not found BRACKET, FRT LIC PLT 15274674 BRACKET, FRT LIC PLT 25923854 BRACKET, FRT LIC PLT 25923855 BRACKET, FRT LIC PLT [КРОНШТЕЙН ДЛЯ НОМЕРНОГО ЗНАКА] 25967481 BRACKET, FRT LIC PLT 09423101 SCREW, TAP, M6.3X1.81X16, 14.55 O.D., 7114M, PZ0R (FRT LIC PLT) 22579423 RIVET, FRT LIC PLT BRKT (5 X 25) (10.710) [ЗАКЛЕПКА D=6 ММ] 25793665 COVER, FRT BPR FASCIA FRT TOW HOOK ACC HOLE (КРАСКА TO MATCH) [КРЫШКА] 25793663 FASCIA, FRT BPR (КРАСКА TO MATCH) (MUST ALSO ORDER DUCTS 20772527 & 20772528) 25793664 FASCIA, FRT BPR (КРАСКА TO MATCH) (MUST ALSO ORDER DUCTS 20772527 & 20772528) [ПАНЕЛЬ БАМПЕРА] 21030249 RETAINER, EXPAN, 21 LG, 20. OD, 8.0 HOLE, 3.0-5.0 PNL, NYLON 6/6, BLK (FRT BPR UPR FASCIA) (8.950) (PUSH IN) [ПИСТОН КРЕПЛЕНИЯ КОЖУХА РАДИАТОРА(ПЛАСТИК)] 25896043 GRILLE, RAD (UPPER) (СМ. ГРУППУ 01.000 "GRILLE" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [РЕШЕТКА РАДИАТОРА] 10125439 RIVET, FLAT HD, 3 LEG EXPANSION, M4.8 SHAFT, 23.5 LG, 9.8 O.D., AL (FRT BPR FASCIA SUPT) [ЗАКЛЕПКА D=4.8 ММ] 15272155 SUPPORT, FRT BPR FASCIA [КРОНШТЕЙН РЕШЕТКИ РАДИАТОРА] 11609540 БОЛТ, HWASH, M6X1X20, 16.15 THD, 17 OD, 8.8, GMW4205, HDR PT. (FRT BPR CTR FIL SUPT) [ВИНТ] 25940079 EXTENSION, FRT BPR FASCIA (W/HOLE) [ПОДКРЫЛОК] 25940080 EXTENSION, FRT BPR FASCIA (W/HOLE) [БОКОВАЯ ПАНЕЛЬ БАМПЕРА] 11589291 RETAINER, PUSH-IN, FITS 6.5 HOLE IN 7-9.5 THK PNL, NYLON 6/6 (FRT BPR FASCIA EXTN) [ФИКСАТОР ПАНЕЛИ БАМПЕРА] 25887545 MOLDING, КАПОТ FRT (INCLS 35) [МОЛДИНГ КАПОТА] 11570524 RETAINER, КАПОТ CTR MLDG (ЧАСТЬ OF 34) (10.5 X 11.8 X 8.73) [КРОНШТЕЙН] 11589291 RETAINER, PUSH-IN, FITS 6.5 HOLE IN 7-9.5 THK PNL, NYLON 6/6 (F/CMPT SPH SHLD (PUSH IN)) [ФИКСАТОР ПАНЕЛИ БАМПЕРА] 15263372 DEFLECTOR, FRT AIR (INCLS 38) teamcadillac.ru 15274627 SEAL, RAD AIR LWR (ЧАСТЬ OF 37) [УПЛОТНИТЕЛЬ] 11570215 RETAINER, F/CMPT SPH SHLD (PUSH IN) (M6X1) (FITS HOLE SIZE 9.5X14, 2-3.8MM PNL THK) [ШАЙБА] 11570215 RETAINER, F/CMPT SPH SHLD (PUSH IN) (M6X1) (FITS HOLE SIZE 9.5X14, 2-3.8MM PNL THK) [ШАЙБА] 11609385 ГАЙКА, U-TYPE, M6X1, 29.5 LEN, 12.5 WID, 19.5 CEN-END, 1050, GMW3359 (F/CMPT SPH SHLD (PUSH IN)) [ГАЙКА М 6] 11609681 БОЛТ, HEX W/FL WA, M6X1X25, 14 THD, 24 OD, GM6202M STEEL, GMW3200 (E/CMPT SPH SHLD) [БОЛТ М6] (6D07-026) - 2008 DM69 БАМПЕР ЗАДНИЙ ↓ 25919549 BRACKET, RR BPR FASCIA CTR 15264308 MOLDING, RR BPR FASCIA [МОЛДИНГ БАМПЕРА] 15266706 BAR, RR BPR IMP 15269152 BAR, RR BPR IMP [БАЛКА ЗАДНЕГО БАМПЕРА] 11519116 БОЛТ, WASHER, M6.3X1.8X20, 14 THD, 17 OD, GM6010M, 7153M (RR BPR FASCIA) [БОЛТ] 20782987 HARNESS, B/U ALARM WRG 20782987 HARNESS, B/U ALARM WRG 25863036 HARNESS, B/U ALARM WRG 25863036 HARNESS, B/U ALARM WRG 25863036 HARNESS, B/U ALARM WRG 25863036 HARNESS, B/U ALARM WRG 25863036 HARNESS, B/U ALARM WRG 11610157 ГАЙКА, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (RR BPR FASCIA) (10.701) [ГАЙКА М4] 19116009 SENSOR KIT, RR OBJECT (INCLS 9) (7.831) [ДАТЧИК ПАРКОВКИ] 19116009 SENSOR KIT, RR OBJECT (INCLS 9) [ДАТЧИК ПАРКОВКИ] 15271277 ШЛАНГИ, RR OBJECT SEN (ЧАСТЬ OF 12) [ЖГУТ ПРОВОДОВ] not found RETAINER, RR OBJECT SEN (ЧАСТЬ OF 7) 25631448 RETAINER, RR BPR FASCIA SUPT (7.2 DIA, 22.0 O.D., 30.75 LG) (W/#3 SQ ROBERTSON DR) (7.831) [ФИКСАТОР ПЕРЕДНЕЙ ПАНЕЛИ БАМПЕРА] teamcadillac.ru 11562364 CLIP, RR BPR FASCIA MLDG (18X10X11.6) (1.269) [ЗАЖИМ ПАНЕЛИ БАМПЕРА] 15896230 FASCIA, RR BPR (INCLS 8) (КРАСКА TO MATCH) [ПАНЕЛЬ БАМПЕРА] 15896232 FASCIA, RR BPR (INCLS 8) (КРАСКА TO MATCH) 15264303 INSERT, RR BPR FASCIA [ВСТАВКА ПАНЕЛИ ЗАДНЕГО БАМПЕРА] 15264304 INSERT, RR BPR FASCIA [ПАНЕЛЬ ЗАДНЕГО БАМПЕРА] 15858975 INSERT, RR BPR FASCIA [ВСТАВКА БАМПЕРА] 15896233 COVER, RR BPR FASCIA TOW HOOK ACC HOLE (КРАСКА TO MATCH) [ЗАГЛУШКА ПАНЕЛИ БАМПЕРА] 11502553 ГАЙКА, STAMPED, M6.3 STUD, SELF THD, STL, PC (RR REFL) [ГАЙКА М6] 15266713 АМОРТИЗАТОР, RR BPR ENGY [АМОРТИЗАТОР] 25805313 REFLECTOR, RR BPR FASCIA [ОТРАЖАТЕЛЬ] 10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (RR BPR FASCIA (PUSH IN)) [ПИСТОН КРЕПЛЕНИЯ ОБЛИЦОВКИ БАМПЕРА (NYLON)] 25883454 REFLECTOR, RR OTR 25883455 REFLECTOR, RR OTR 25883456 REFLECTOR, RR OTR 25883457 REFLECTOR, RR OTR 25883457 REFLECTOR, RR OTR 10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (RR BPR FASCIA INS) [ПИСТОН КРЕПЛЕНИЯ ОБЛИЦОВКИ БАМПЕРА (NYLON)] 11562364 RETAINER, RR BPR FASCIA INS (18X10X11.6) (1.269) [ЗАЖИМ ПАНЕЛИ БАМПЕРА] 25704358 RETAINER, RR BPR FASCIA (15X18X23.8) 11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (RR BPR FASCIA) (9.665) [БОЛТ М4.2Х1.41Х25] 25704358 RETAINER, RR BPR FASCIA SI (15X18X23.8) 11517397 ГАЙКА, HEX W/CON WA, 8X1.25, 28 O.D., 7.5 THK, 9, PEOR (RR BPR ENGY ABS) not found RETAINER, RR BPR IMP BAR RET (PUSH ON) 25905360 BRACKET, RR BPR FASCIA [ОПОРНАЯ ПЛАНКА ПАНЕЛИ БАМПЕРА] 25905361 BRACKET, RR BPR FASCIA [ОПОРА ПАНЕЛИ БАМПЕРА] 11519116 БОЛТ, WASHER, M6.3X1.8X20, 14 THD, 17 OD, GM6010M, 7153M (RR BPR FASCIA BRKT) [БОЛТ] 15274471 LINER, RR W/H PNL [УДЛИНИТЕЛЬ] 25954779 LINER, RR W/H PNL [ПОДКРЫЛОК] 21030249 RETAINER, EXPAN, 21 LG, 20. OD, 8.0 HOLE, 3.0-5.0 PNL, NYLON 6/6, BLK (RR W/H PNL LNR) (8.950) (PUSH IN) [ПИСТОН КРЕПЛЕНИЯ КОЖУХА РАДИАТОРА(ПЛАСТИК)] 25866112 АМОРТИЗАТОР, RR BPR ENGY LWR 25631448 RETAINER, RR BPR ENGY ABS PIN (7.2 DIA, 22.0 O.D., 30.75 LG) (W/#3 SQ ROBERTSON DR) (7.831) [ФИКСАТОР ПЕРЕДНЕЙ ПАНЕЛИ БАМПЕРА] (6D07-027) - 2008 DM69 РЕГУЛИРУЕМАЯ ПОДВЕСКА-ЭЛЕКТРИЧЕСКАЯ ↓ teamcadillac.ru 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (VEH YAW SEN & LATL ACCLRM) [БОЛТ М6] 11561645 ГАЙКА, HFH, M6X1X6.45, 13.5 OD, 10 STL, GMW3200 (VEH YAW SEN & LATL ACCLRM) 15845467 SENSOR, VEH YAW (W/VEH LATL ACCLRM) (LABELED 15845467) [ДАТЧИК] not found HARNESS, BODY WRG (СМ. ГРУППУ 13.000 "ЖГУТЫ ПРОВОДОВ/КУЗОВ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6D07-028) - 2008 DM69 РАМА & КРЕПЛЕНИЕ (ЗАДНИЙ КОЛЕСО DRIVE MN6,MX0) ↓ 20811304 РАМА, DRIVETRAIN & FRT SUSP (INCLS 3) teamcadillac.ru 11518725 БОЛТ, DRIVETRAIN & FRT SUSP FRM (CRADLE TO BODY) (M14X2.0X95) (HVY HEX FLG HD W/CON SPR WA) (8.900) [БОЛТ М14Х95] not found INSULATOR, BRK PRESS MOD VLV BRKT (ЧАСТЬ OF 1) (6D07-029) - 2008 DM69 АМОРТИЗАТОР/ПЕРЕДНЯЯ СТОЙКА & ПРУЖИНА (ЗАДНИЙ КОЛЕСО DRIVE MN6,MX0) ↓ 11517996 ГАЙКА, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (ЧАСТЬ OF 9) [ГАЙКА М10] not found BRACKET, FRT SUSP UPR CONT ARM (СМ. ГРУППУ 06.000 "ПОДВЕСКА-ПЕРЕДНЯЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 15840310 INSULATOR, FRT SPR UPR teamcadillac.ru 15840310 INSULATOR, FRT SPR UPR not found RETAINER, FRT S/ABS BPR 15840318 BUMPER, FRT S/ABS UPR 15840318 BUMPER, FRT S/ABS UPR 25807541 SHIELD, FRT S/ABS DUST 15264551 ПРУЖИНА, FRT 15264551 ПРУЖИНА, FRT 25807542 ПРУЖИНА, FRT 25807542 ПРУЖИНА, FRT 25807543 ПРУЖИНА, FRT 25807543 ПРУЖИНА, FRT 15840317 INSULATOR, FRT SPR LWR 15840317 INSULATOR, FRT SPR LWR not found АМОРТИЗАТОР, FRT SHK (INCLS 1) 15840338 АМОРТИЗАТОР, FRT SHK (INCLS 1) (АМОРТИЗАТОР ASM ONLY) (ORDER T/W 11517996 NUT) [АМОРТИЗАТОР ПЕРЕДНИЙ] 19168818 АМОРТИЗАТОР KIT, FRT SHK (INCLS 1) (ACDelco #540-353) [АМОРТИЗАТОР ПЕРЕДНИЙ, А/М CADILLAC CTS 3.6 Л] 19168818 АМОРТИЗАТОР KIT, FRT SHK (INCLS 1) (ACDelco #540-353) [АМОРТИЗАТОР ПЕРЕДНИЙ, А/М CADILLAC CTS 3.6 Л] 19168819 АМОРТИЗАТОР KIT, FRT SHK (INCLS 1) (INCLS АМОРТИЗАТОР AND NUT) (ACDelco #540-497) 19177929 АМОРТИЗАТОР KIT, FRT SHK (INCLS 1) (ACDelco #560-579) [АМОРТИЗАТОР] (6D07-030) - 2008-2009 DM69 АМОРТИЗАТОР/ПЕРЕДНЯЯ СТОЙКА & ПРУЖИНА (ПОЛНОПРИВОДНЫЙ MX7) ↓ 15264551 ПРУЖИНА, FRT teamcadillac.ru 15264551 ПРУЖИНА, FRT 25807542 ПРУЖИНА, FRT 25807542 ПРУЖИНА, FRT 25807543 ПРУЖИНА, FRT 25807543 ПРУЖИНА, FRT 15840317 INSULATOR, FRT SPR LWR 15840317 INSULATOR, FRT SPR LWR 19177929 АМОРТИЗАТОР KIT, FRT SHK (INCLS 9, 10) (ACDelco #560-579) [АМОРТИЗАТОР] 19180973 АМОРТИЗАТОР KIT, FRT SHK (INCLS 9, 10) (ACDelco #540-473) 19180974 АМОРТИЗАТОР KIT, FRT SHK (INCLS 9, 10) (ACDelco #540-474) [АМОРТИЗАТОР ПЕРЕДНИЙ А/М CADILLAC CTS 3.6 Л] 25807541 SHIELD, FRT S/ABS DUST 15840319 BUMPER, FRT S/ABS UPR 15840333 RETAINER, FRT S/ABS BPR 15840311 INSULATOR, FRT SPR UPR 15840311 INSULATOR, FRT SPR UPR not found MOUNT, FRT SUSP STRUT (ЧАСТЬ OF BRACKET, FRT UPR CONT ARM - GROUP 06.000) 15840339 WASHER, FRT S/ABS (ЧАСТЬ OF 3) 11517996 ГАЙКА, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (ЧАСТЬ OF 3) [ГАЙКА М10] (6D07-031) - 2008 DM69 ПРИЦЕПНОЕ УСТРОЙСТВО (V76) ↓ teamcadillac.ru 15292874 EYE, TOW [КРЮК БУКСИРОВОЧНЫЙ] (6D07-032) - 2008 DM69 БАМПЕР-ПЕРЕДНИЙ (С ЗАЩИТОЙ ПЕШЕХОДА) ↓ 25860888 BAR, FRT BPR IMP not found RETAINER, FRT BPR IMP BAR STUD PLT (PUSH ON) 15869580 BRACKET, HDLP [ОПОРНАЯ ПЛАНКА ПЕРЕДНЕЙ ФАРЫ] 25924112 BRACKET, HDLP 11517397 ГАЙКА, HEX W/CON WA, 8X1.25, 28 O.D., 7.5 THK, 9, PEOR (FRT BPR ENGY ABS) 25860889 АМОРТИЗАТОР, FRT BPR FASCIA ENGY UPR 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (FRT FOG LP BRKT) [ВИНТ М4] 21077131 RETAINER, FRT BPR FASCIA ENGY ABS [СТОПОПОР] 20831753 REINFORCEMENT, FRT BPR FASCIA [ОПОРНАЯ ПЛАНКА ПАНЕЛИ БАМПЕРА] 20831754 REINFORCEMENT, FRT BPR FASCIA [ОПОРНАЯ ПЛАНКА ПАНЕЛИ БАМПЕРА] 11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (FRT BPR FASCIA RET) [БОЛТ М6] 11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (FRT BPR FASCIA REINF) [БОЛТ М6] 11561857 CLIP, FRT FOG LP ADJ БОЛТ RET (BLACK) (14.13 X 11 X 8.6) (7.831) 25536302 ГАЙКА, FRT BPR UPR FASCIA (4.2 X 1.41) (TAPPING NUT) (3.430) [ПРИЖИМНАЯ ПЛАСТИНА ПАНЕЛИ КУЗОВА] 25896041 GRILLE, RAD LWR (СМ. ГРУППУ 01.000 "GRILLE" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [РЕШЕТКА РАДИАТОРА] 15896564 FASCIA, FRT BPR LWR [МОЛДИНГ ПАНЕЛИ ПЕРЕДНЕГО БАМПЕРА] 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (FRT BPR FASCIA OTR RET) [ВИНТ М4] 15272090 DEFLECTOR, FRT BPR FASCIA LWR [МОЛДИНГ ПЕРЕДНЕГО БАМПЕРА] 21030249 RETAINER, EXPAN, 21 LG, 20. OD, 8.0 HOLE, 3.0-5.0 PNL, NYLON 6/6, BLK (FRT BPR LWR FASCIA) (8.950) (PUSH IN) [ПИСТОН КРЕПЛЕНИЯ КОЖУХА РАДИАТОРА(ПЛАСТИК)] 15272157 BEZEL, FRT FOG LP (FOR VEHICLES BUILT W/FRONT BRAKE ОХЛАЖДЕНИЕ DUCTS) (ON VEH BUILT BEFORE 3/31/08 OR IF REPLACED BEZEL HAS OPENINGS/SLOTSMUST ALSO ORDER 25961369) 15904574 BEZEL, FRT FOG LP [НАКЛАДКА ПАНЕЛИ БАМПЕРА] 15904575 BEZEL, FRT FOG LP [ОКАНТОВКА ПРОТИВОТУМАННОЙ ФАРЫ] 25961369 BEZEL, FRT FOG LP (FOR VEHICLES BUILT W/ FRONT BRAKE ОХЛАЖДЕНИЕ DUCTS) (ON VEH BUILT BEFORE 3/31/08 OR IF REPLACED BEZEL HAS OPENINGS/SLOTS, MUST ALSO ORDER 25961370) 11562364 CLIP, RAD GRL (18X10X11.6) [ЗАЖИМ ПАНЕЛИ БАМПЕРА] 25768800 BUMPER, FRT BPR FASCIA [ЭЛЕМЕНТ НАКЛАДКИ БАМПЕРА] 21030249 RETAINER, EXPAN, 21 LG, 20. OD, 8.0 HOLE, 3.0-5.0 PNL, NYLON 6/6, BLK (FRT BPR FASCIA (PUSH IN)) (8.950) (PUSH IN) [ПИСТОН КРЕПЛЕНИЯ КОЖУХА РАДИАТОРА(ПЛАСТИК)] 15274674 BRACKET, FRT LIC PLT 25967481 BRACKET, FRT LIC PLT 09423101 SCREW, TAP, M6.3X1.81X16, 14.55 O.D., 7114M, PZ0R (FRT LIC PLT) 22579423 RIVET, FRT LIC PLT BRKT (5 X 25) (10.710) [ЗАКЛЕПКА D=6 ММ] teamcadillac.ru 25793665 COVER, FRT BPR FASCIA FRT TOW HOOK ACC HOLE (КРАСКА TO MATCH) [КРЫШКА] 25793663 FASCIA, FRT BPR (КРАСКА TO MATCH) (MUST ALSO ORDER DUCTS 20772527 & 20772528) 25793664 FASCIA, FRT BPR (КРАСКА TO MATCH) (MUST ALSO ORDER DUCTS 20772527 & 20772528) [ПАНЕЛЬ БАМПЕРА] 21030249 RETAINER, EXPAN, 21 LG, 20. OD, 8.0 HOLE, 3.0-5.0 PNL, NYLON 6/6, BLK (FRT BPR UPR FASCIA) (8.950) (PUSH IN) [ПИСТОН КРЕПЛЕНИЯ КОЖУХА РАДИАТОРА(ПЛАСТИК)] 25896043 GRILLE, RAD (UPPER) (СМ. ГРУППУ 01.000 "GRILLE" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [РЕШЕТКА РАДИАТОРА] 10125439 RIVET, FLAT HD, 3 LEG EXPANSION, M4.8 SHAFT, 23.5 LG, 9.8 O.D., AL (FRT BPR FASCIA SUPT) [ЗАКЛЕПКА D=4.8 ММ] 15272155 SUPPORT, FRT BPR FASCIA [КРОНШТЕЙН РЕШЕТКИ РАДИАТОРА] 11609540 БОЛТ, HWASH, M6X1X20, 16.15 THD, 17 OD, 8.8, GMW4205, HDR PT. (FRT BPR CTR FIL SUPT) [ВИНТ] 25940079 EXTENSION, FRT BPR FASCIA (W/HOLE) [ПОДКРЫЛОК] 25940080 EXTENSION, FRT BPR FASCIA (W/HOLE) [БОКОВАЯ ПАНЕЛЬ БАМПЕРА] 11589291 RETAINER, PUSH-IN, FITS 6.5 HOLE IN 7-9.5 THK PNL, NYLON 6/6 (FRT BPR FASCIA EXTN) [ФИКСАТОР ПАНЕЛИ БАМПЕРА] 25887545 MOLDING, КАПОТ FRT (INCLS 35) [МОЛДИНГ КАПОТА] 11570524 RETAINER, КАПОТ CTR MLDG (ЧАСТЬ OF 34) (10.5 X 11.8 X 8.73) [КРОНШТЕЙН] 25812678 SENSOR, PEDESTRIAN IMPACT DETECTION (СМ. ГРУППУ 02.000 "PEDESTRIAN PROTECTION SYSTEM" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACTIVE КАПОТ SYSTEM DISCRIMINATION SENSOR-FRT UPR BEAM) 11609422 БОЛТ, FRT BPR IMP BAR (M5X0.5X17.4, 14.2 OD, 9.8, GW3359, M-POINT) (0.206) 11561427 SCREW - RND HD W/SHLDR M6X1X24 (FRT BPR IMP BAR) 25898287 HARNESS, I/P WRG HARN EXTN 25812678 SENSOR, PEDESTRIAN IMPACT DETECTION (ACTIVE КАПОТ SYSTEM DISCRIMINATION SENSOR-FRT UPR BEAM) 25916157 SENSOR, PEDESTRIAN IMPACT DETECTION (LABELED 25916157) 11517397 ГАЙКА, HEX W/CON WA, 8X1.25, 28 O.D., 7.5 THK, 9, PEOR (FRT BPR ENGY ABS LWR) 25860887 BAR, FRT BPR LWR IMP 25860890 АМОРТИЗАТОР, FRT BPR FASCIA ENGY LWR 11589291 RETAINER, PUSH-IN, FITS 6.5 HOLE IN 7-9.5 THK PNL, NYLON 6/6 (F/CMPT SPH SHLD (PUSH IN)) [ФИКСАТОР ПАНЕЛИ БАМПЕРА] 15263372 DEFLECTOR, FRT AIR (INCLS 46) 15274627 SEAL, RAD AIR LWR (ЧАСТЬ OF 45) [УПЛОТНИТЕЛЬ] 11570215 RETAINER, F/CMPT SPH SHLD (PUSH IN) (M6X1) (FITS HOLE SIZE 9.5X14, 2-3.8MM PNL THK) [ШАЙБА] 11570215 RETAINER, F/CMPT SPH SHLD (PUSH IN) (M6X1) (FITS HOLE SIZE 9.5X14, 2-3.8MM PNL THK) [ШАЙБА] 11609385 ГАЙКА, U-TYPE, M6X1, 29.5 LEN, 12.5 WID, 19.5 CEN-END, 1050, GMW3359 (F/CMPT SPH SHLD (PUSH IN)) [ГАЙКА М 6] 11609681 БОЛТ, HEX W/FL WA, M6X1X25, 14 THD, 24 OD, GM6202M STEEL, GMW3200 (E/CMPT SPH SHLD) [БОЛТ М6] (6E07-015) - 2008-2009 DM69 РАМА & КРЕПЛЕНИЕ (ПОЛНОПРИВОДНЫЙ MX7) ↓ 25807373 РАМА, DRIVETRAIN & FRT SUSP [РАМА] 11519737 БОЛТ, DRIVETRAIN & FRT SUSP FRM (M16X2X60, 30 THD, 35 OD, 10.9) teamcadillac.ru 11518725 БОЛТ, DRIVETRAIN & FRT SUSP FRM (CRADLE TO BODY) (M14X2.0X95) (HVY HEX FLG HD W/CON SPR WA) (8.900) [БОЛТ М14Х95] (6E07-018) - 2008 DM69 ЗАДНЯЯ ПОДВЕСКА ↓ 25939260 ARM, RR SUSP TRAILING (INCLS 2) [РЫЧАГ] not found BUSHING, RR SUSP TRAILING ARM (ЧАСТЬ OF 1) 11518725 БОЛТ, HFH, M14X2.0X95, 45 THD, 34 OD, 10.9, 7114M, CONICAL ПРУЖИНА WA (RR SUSP TRAILING ARM) [БОЛТ М14Х95] 11516382 ГАЙКА, RR SUSP TRAILING ARM (M14X2X15) (W/O J CLIP RETAINER) (8.917) [ГАЙКА М10] 11519149 БОЛТ, RR SUSP TRAILING ARM (ЗАДНИЙ) (HFH, M14X2X90, 34 THD, 30.5 OD, 10.9, 7.3) (6.172) 11516382 ГАЙКА, RR SUSP TRAILING ARM (M14X2X15) (W/O J CLIP RETAINER) (8.917) [ГАЙКА М10] 11519149 БОЛТ, RR SUSP ADJ LINK (INNER) (HFH, M14X2X90, 34 THD, 30.5 OD, 10.9, 7.3) (6.172) 25887836 MOUNT, RR SUSP SUPT (ЗАДНИЙ) 25887835 MOUNT, RR SUSP SUPT (ЗАДНИЙ) 15267614 SUPPORT, RR SUSP 15267614 SUPPORT, RR SUSP 11516076 ГАЙКА, PREVAILING TORQUE TENSION FLG HD (M8X1.25X17.4 OD (RR S/ABS) [ГАЙКА] 11516382 ГАЙКА, RR SUSP UPR CONT ARM (TO SUPPORT-FRONT) (M14X2X15) (W/O J CLIP RETAINER) (8.917) [ГАЙКА М10] 15219475 АМОРТИЗАТОР, RR SHK (W/UPR MT) (ACDelco #540-331) [АОМОРТИЗАТОР] 15219476 АМОРТИЗАТОР, RR SHK (W/UPR MT) (ACDelco #540-332) [АМОРТИЗАТОР] 25884697 АМОРТИЗАТОР, RR SHK (W/UPR MT) (ACDelco #540-487) 25884698 АМОРТИЗАТОР, RR SHK (W/UPR MT) (ACDelco #540-488) 25884699 АМОРТИЗАТОР, RR SHK (W/UPR MT) (ACDelco #540-417) [АМОРТИЗАТОР А/М CADILLAC CTS 3.6Л] teamcadillac.ru 25884700 АМОРТИЗАТОР, RR SHK (W/UPR MT) (ACDelco #540-418) 11519150 БОЛТ, RR SUSP UPR CONT ARM (INNER) (M14X2X100) 11516873 БОЛТ, HEX HD & CON SPR WA, M14X2X100 (RR S/ABS) 11516382 ГАЙКА, RR SUSP ADJ LINK (TO SUPT-ЗАДНИЙ) (M14X2X15) (W/O J CLIP RETAINER) (8.917) [ГАЙКА М10] not found BUSHING, RR SUSP ADJ LINK (ЧАСТЬ OF 19) 11519078 БОЛТ, RR SUSP ADJ LINK (OUTER) (M14X2X110) (W/CON WASHER) (5.506) 15267634 LINK, RR SUSP ADJ (INCLS 17, 20) not found BUSHING, RR SUSP ADJ LINK (ЧАСТЬ OF 19) not found BUSHING, RR SUSP UPR CONT ARM (ЧАСТЬ OF 23) 03537773 ГАЙКА, RR SUSP UPR CONT ARM (OUTER) (M14X2X11.92) (HEX W/CONICAL WA PREV TORQ) 15267619 ARM, RR SUSP UPR CONT (INCLS 21, 24) [РЫЧАГ] 15267620 ARM, RR SUSP UPR CONT (INCLS 21, 24) [РЫЧАГ] not found BUSHING, RR SUSP UPR CONT ARM (ЧАСТЬ OF 23) 11609636 WASHER, FLAT M16X32X3, SAE1050, GMW3044 (RR SUSP) 11570509 БОЛТ, RR SUSP (ЗАДНИЙ) (M14X2X160.68, 53 THD) 11515720 SCREW, FLAT 6 LOBED, M6X1X20, 14.5 THD, 9.8, T-30 TORX, HDR PT (RR BRK ROT (PUSH ON)) (8.908) [ВИНТ] 10289657 ГАЙКА, RR WHL DRV UJT SHF (M24X2.0X19.6) (HEX W/WASHER, PREVAILING TORQUE) (6.056) [ГАЙКА М24] not found ROTOR, RR BRK 15267107 ROTOR, RR BRK (17" ТОРМОЗА) [РОТОР] 15267108 ROTOR, RR BRK (18" ТОРМОЗА) [ТОРМОЗНОЙ ДИСК] 13502216 HUB, RR WHL (W/ BRG) (INCLS 31) (W/O SENSOR) (ACDelco #FW372) [СТУПИЦА КОЛЕСА] 11588811 STUD, RR WHL (ЧАСТЬ OF 30) (M14X1.5X24, 58 TOTAL LENGTH) [ШПИЛЬКА М14] not found CALIPER, RR BRK (СМ. ГРУППУ 05.000 "CALIPER/ЗАДНИЙ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found BRAKE, RR (СМ. ГРУППУ 05.000 "СТОЯНОЧНЫЙ ТОРМОЗ ASM" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found BUSHING, RR SUSP TRAILING ARM (ЧАСТЬ OF 35) 15775071 KNUCKLE, RR SUSP (INCLS 34, 36, 37) [ПОВОРОТНЫЙ КУЛАК ПОДВЕСКИ] 15775072 KNUCKLE, RR SUSP (INCLS 34, 36, 37) [ПОВОРОТНЫЙ КУЛАК ПОДВЕСКИ] not found BUSHING, RR SUSP LWR CONT ARM (ЧАСТЬ OF 35) not found BUSHING, RR SUSP SUPT (ЧАСТЬ OF 35) 11518337 БОЛТ, HFH M12X1.75X75, 26.6 OD, 30 THD, 10.9, 7114M, ADH 6194M, REDUCED BODY (RR BRK CLPR BRKT) [БОЛТ М12] 11519097 БОЛТ, HFH M12X1.75X55, 26.6 OD, 30 THD, 10.9, 7114M, ADH 6194M, RED BODY. (RR BRK CLPR BRKT) 18022052 БОЛТ, RR WHL HUB (M12X1.75X51, 20THD) (5.812) [БОЛТ] 25693149 BRACKET, PARK BRK CBL (ATTACHES TO RR SUSP) 25693150 BRACKET, PARK BRK CBL (ATTACHES TO RR SUSP) 11518842 БОЛТ, HFH M10X1.5X60, 22.3 OD, 26 THD, 10.9, 7114M, ADH 6194M, RED BODY (PARK BRK CBL BRKT) not found SHAFT KIT, RR WHL DRV (СМ. ГРУППУ 05.000 "ВАЛ ЗАДНЕЙ ОСИ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11516078 ГАЙКА, HFH, M12X1.75, 14THK, 25 O.D., 10, PZOR (RR STAB SHF LINK) [ГАЙКА] 20765234 INSULATOR, RR SPR UPR 15219458 ПРУЖИНА, RR 15793347 ПРУЖИНА, RR 25798541 ПРУЖИНА, RR 25798541 ПРУЖИНА, RR 25798541 ПРУЖИНА, RR 25798541 ПРУЖИНА, RR 15267655 LINK, RR STAB SHF [УЛОТНИТЕЛЬ] 25964514 LINK, RR STAB SHF 11609819 БОЛТ, RR SUSP LWR CONT ARM (TO KNUCKLE) (8.900) [БОЛТ М14] 11609636 WASHER, FLAT M16X32X3, SAE1050, GMW3044 (RR SUSP) 25805110 INSULATOR, RR SPR LWR 11519150 БОЛТ, RR SUSP LWR CONT ARM (INNER) (M14X2X100) 20777471 ARM, RR SUSP LWR CONT (INCLS 53) 20777472 ARM, RR SUSP LWR CONT (INCLS 53) not found BUSHING, RR SUSP LWR CONT ARM (ЧАСТЬ OF 52) 11516382 ГАЙКА, RR SUSP UPR CONT ARM (TO SUPPORT-FRONT) (M14X2X15) (W/O J CLIP RETAINER) (8.917) [ГАЙКА М10] 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (RR STAB SHF BRKT) [БОЛТ, М10Х1.5Х30] 25719675 BRACKET, RR STAB SHF [ОПОРНАЯ СКОБА ВТУЛКИ СТАБИЛИЗАТОРА] 15267653 INSULATOR, RR STAB SHF (16MM) (65 DURO) 15880709 INSULATOR, RR STAB SHF (17MM) (65 DURO) [УПЛОТНИТЕЛЬ] 15880711 INSULATOR, RR STAB SHF (18MM) (65 DURO) [УПЛОТНИТЕЛЬ] 15880711 INSULATOR, RR STAB SHF (18MM) (65 DURO) [УПЛОТНИТЕЛЬ] 25771205 INSULATOR, RR STAB SHF (23.4MM) (60 DURO) 15267654 SHAFT, RR STAB 15267654 SHAFT, RR STAB 15880706 SHAFT, RR STAB 15880708 SHAFT, RR STAB [ВАЛ, ОСЬ] 15880708 SHAFT, RR STAB [ВАЛ, ОСЬ] 11570356 БОЛТ, RR SUSP (FRONT) (M16X2X163, 53 THD) 08 - КУЗОВНЫЕ ДЕТАЛИ ПЕРДНЯЯ ЧАСТЬ - ПОДОГРЕВАТЕЛЬ - ОБСЛУЖИВАНИЕ (6D08-046) - 2008-2010 D69 КАПОТ ↓ 25887545 MOLDING, КАПОТ FRT (INCLS 3) [МОЛДИНГ КАПОТА] 25885609 КАПОТ, (INCLS 26) 11570524 RETAINER, КАПОТ CTR MLDG (ЧАСТЬ OF 1) (10.5 X 11.8 X 8.73) [КРОНШТЕЙН] 15250702 INSULATOR, КАПОТ [УПЛОТНИТЕЛЬ] 20064875 RETAINER, PUSH-IN, 20.5MMLG, 42.76MM 1.68HD DIA, PLASTIC (КАПОТ INSL) [КЛИПСА ШУМОИЗОЛЯЦИИ КАПОТА] 11589064 БОЛТ, SHLDR, M8X1.25X27, 16 THD, 19 OD, 9.8, GMW4205, 4.5X11.3 SHLDR (КАПОТ HGE PIV) [БОЛТ] 25811662 HINGE, КАПОТ (BODY SI) [ПЕТЛЯ] 25811663 HINGE, КАПОТ (BODY SI) [ПЕТЛЯ] 10369166 WEATHERSTRIP, КАПОТ RR [УПЛОТНИТЕЛЬ КАПОТА] 25900731 SEAL, AIR INL GRL PNL SI [ПРОКЛАДКА] 25900732 SEAL, AIR INL GRL PNL SI [ПРОКЛАДКА ПАНЕЛИ КРЫЛА] 25712639 HANDLE, КАПОТ PRIM LAT REL CBL [ФИКСАТОР ТРОСА ЗАМКА КАПОТА] 11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (КАПОТ PRIM LAT REL CBL HDL) [ВИНТ] 15291413 CABLE, КАПОТ PRIM LAT REL [ТРОС ЗАМКА КАПОТА] not found LABEL, ACTIVE КАПОТ HGE ACTR CAUTION (ЧАСТЬ OF 33) 11609540 БОЛТ, HWASH, M6X1X20, 16.15 THD, 17 OD, 8.8, GMW4205, HDR PT. (КАПОТ PRIM LAT) [ВИНТ] 25869078 LATCH, КАПОТ PRIM & SECD [ЗАЩЕЛКА КАПОТА] 25869079 LATCH, КАПОТ PRIM & SECD [ЗАЩЕЛКА КАПОТА] 11609540 БОЛТ, HWASH, M6X1X20, 16.15 THD, 17 OD, 8.8, GMW4205, HDR PT. (F/END SH MET DIAG BR) [ВИНТ] 15261226 BRACE, F/END SH MET DIAG [ОПОРНАЯ ПЛАНКА ЗАЩЕЛКИ КАПОТА] 15938028 ROD, КАПОТ OPEN ASST [СТЕРЖЕНЬ] 25887182 BUMPER, КАПОТ ADJ FRT [БАМПЕР] not found BRACKET, КАПОТ OPEN ASST ROD (СМ. ГРУППУ 12.000 "КУЗОВНЫЕ ДЕТАЛИ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25876570 SEAL, КАПОТ FRT [УПЛОТНИТЕЛЬ КАПОТА] 11609990 STUD, КАПОТ OPEN ASST ROD BRKT (M8X1.25X20) [ШПИЛЬКА М8] 11589407 БОЛТ, HWH, M8X1.25X35, 23.5 THD, 24 OD, 10.9, GMW3359, M-PT. (КАПОТ HGE (BODY SI)) [БОЛТ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (КАПОТ HGE (КАПОТ SI)) [ГАЙКА] 15943798 HINGE, КАПОТ (КАПОТ SI) [ПЕТЛЯ КАПОТА] 15943799 HINGE, КАПОТ (КАПОТ SI) [ПЕТЛЯ КАПОТА] 11609540 БОЛТ, HWASH, M6X1X20, 16.15 THD, 17 OD, 8.8, GMW4205, HDR PT. (ЧАСТЬ OF 2) [ВИНТ] 25921403 BUMPER, КАПОТ FRT CTR 15931787 BUMPER, КАПОТ FRT [БАМПЕР] teamcadillac.ru 11609978 STUD, КАПОТ OPEN ASST ROD (M6X1X16) (W/8MM BALL SIDE [ШПИЛЬКА] 25811792 BUMPER, КАПОТ RR 25811793 BUMPER, КАПОТ RR 11569754 БОЛТ, КАПОТ HGE 25909697 HINGE, КАПОТ (BODY SI) 25909698 HINGE, КАПОТ (BODY SI) 25912312 ACTUATOR, ACTIVE КАПОТ HGE (INCLS 13) not found HARNESS, FWD LP WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/ПЕРЕДНИЕ ФАРЫ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6D08-047) - 2008-2009 DM69 КРЫЛО & КОЛЕСНАЯ КОРОБКА ПЕРЕДНЯЯ (ПОЛНОПРИВОДНЫЙ MX7) ↓ 15929856 КРЫЛО, FRT (INCLS 2, 4, 22, 23) 15929857 КРЫЛО, FRT (INCLS 2, 4, 22, 23) 25927536 КРЫЛО, FRT (INCLS 2, 4, 22, 23) [ПЕРЕДНЕЕ КРЫЛО] 25927537 КРЫЛО, FRT (INCLS 2, 4, 22, 23) [КРЫЛО] teamcadillac.ru not found BRACKET, F/FDR RR UPR BRKT (ЧАСТЬ OF 1) 11609540 БОЛТ, HWASH, M6X1X20, 16.15 THD, 17 OD, 8.8, GMW4205, HDR PT. (F/FDR UPR) [ВИНТ] 09442974 RIVET, 3/16" X .544 STYLE 1C, .424 LG., 34 OD, AL, PL, .062-.25 GRIP (ЧАСТЬ OF 1) 25877078 SEAL, F/FDR [УПЛОТНИТЕЛЬ ПАНЕЛИ КРЫЛА] 11609540 БОЛТ, HWASH, M6X1X20, 16.15 THD, 17 OD, 8.8, GMW4205, HDR PT. (F/FDR RR UPR BRKT) [ВИНТ] 15250708 INSULATOR, F/FDR (INCLS 8) [ВСТАВКА ПЕРЕДНЕГО КРЫЛА] 20819341 INSULATOR, F/FDR (INCLS 8) 10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (ЧАСТЬ OF 7) [ПИСТОН КРЕПЛЕНИЯ ОБЛИЦОВКИ БАМПЕРА (NYLON)] not found RETAINER, F/END PNL MLDG (PUSH ON) (ЧАСТЬ OF 11) not found RETAINER, F/END PNL MLDG (PUSH ON) (ЧАСТЬ OF 11) 25851105 ORNAMENT, F/FDR (INCLS 9, 10) [ВСТАВКА ПЕРЕДНЕГО КРЫЛА] 25851106 ORNAMENT, F/FDR (INCLS 9, 10) [ВСТАВКА ПЕРЕДНЕГО КРЫЛА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (F/FDR RR CTR BRKT) [ГАЙКА М6] 10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (F/FDR INSL (PUSH IN)) [ПИСТОН КРЕПЛЕНИЯ ОБЛИЦОВКИ БАМПЕРА (NYLON)] 25940077 LINER, FRT W/H RR (WITH HOLE) [КРЫШКА] 25940078 LINER, FRT W/H RR (WITH HOLE) (INCLS RIVET & SHIELD) [УПЛОТНИТЕЛЬ] 11609540 БОЛТ, HWASH, M6X1X20, 16.15 THD, 17 OD, 8.8, GMW4205, HDR PT. (F/FDR LWR) [ВИНТ] 10185925 RETAINER, FRT W/H LNR (КРАСКА TO MATCH) (7.1 DIA, 33MM) (15.100) 11589293 RETAINER, PUSH-IN, FITS 8.5 DIA HOLE, 4.5-7 THK PNL, NYLON 6/6 GMP.PA66.0 (ENG FRT SPH SHLD (PUSH IN)) [ФИКСАТОР ВОДОСТОЧНОЙ ПАНЕЛИ ВЕТРОВОГО СТЕКЛА] 25898938 SHIELD, FRT W/H PNL SPH 11589291 RETAINER, PUSH-IN, FITS 6.5 HOLE IN 7-9.5 THK PNL, NYLON 6/6 (FRT BPR FASCIA EXTN) [ФИКСАТОР ПАНЕЛИ БАМПЕРА] 25940079 EXTENSION, FRT BPR FASCIA (W/HOLE) [ПОДКРЫЛОК] 25940080 EXTENSION, FRT BPR FASCIA (W/HOLE) [БОКОВАЯ ПАНЕЛЬ БАМПЕРА] 11609540 БОЛТ, HWASH, M6X1X20, 16.15 THD, 17 OD, 8.8, GMW4205, HDR PT. (F/FDR FRT LWR REINF) [ВИНТ] not found REINFORCEMENT, F/FDR FRT (ЧАСТЬ OF 1) not found REINFORCEMENT, F/FDR FRT UPR (ЧАСТЬ OF 1) 11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (F/FDR RR LWR BRKT) [ШАЙБА] 11609540 БОЛТ, HWASH, M6X1X20, 16.15 THD, 17 OD, 8.8, GMW4205, HDR PT. (F/FDR) [ВИНТ] (6D08-048) - 2008 DM69 SPARE КОЛЕСО STOWAGE & JACK PARTS (COMPACT SPARE ШИНА ZAA) ↓ 25866304 PANEL, R/CMPT SPA WHL STOW CVR [КРЫШКА НИШИ БАГАЖНОГО ОТСЕКА] 11562183 ГАЙКА, SPA WHL STOW (M8X1.25X90) [ФИКСАТОР ЗАПАСНОГО КОЛЕСА] 09596625 КОЛЕСО, SPARE (DISC) (COMPACT SPARE) (18X4) not found ШИНА, SPARE 13502250 РУЧКА, ДОМКРАТА WRENCH [РУЧКА ДОМКРАТА] teamcadillac.ru not found LABEL, JK WRNG 13500011 ДОМКРАТ, [ДОМКРАТ МЕХАНИЧЕСКИЙ РУЧНОЙ НЕГИДРАВЛИЧЕСКИЙ НЕСТАЦИОНАРНЫЙ] not found LABEL, JK LOCATION INFO 15854943 CONTAINER, JK STOW [КОНТЕЙНЕР] 11562182 БОЛТ, JK STOW [БОЛТ] not found DEADENER, SPA WHL PKT CTR not found LABEL, JK USAGE INFO & WRNG 15749557 LABEL, JK USAGE INFO & WRNG (ARABIC) 15854947 EXTENSION, JK HDL [УДЛИНИТЕЛЬ РУЧКИ ДОМКРАТА] 00274288 STEM, COMPACT SPARE ШИНА VLV (.453 HOLE, 1.25 LONG) (INCLS CAP) 25744730 STRAP, SPA WHL STOW (6D08-050) - 2008 DM69 SIGHT SHIELD/ДВИГАТЕЛЬНЫЙ ОТСЕК ↓ 15902235 SHIELD, F/CMPT FRT SIGHT (INCLS 7) [ЗАЩИТА] teamcadillac.ru 10382313 RETAINER, F/CMPT FRT SIGHT SHLD (025.0X35.6) (PUSH PIN) (8.090) [КРОНШТЕЙН] 15856789 SHIELD, F/CMPT SI SIGHT (ALL TERRAIN) (INCLS 4) (W/ INSULATOR) (REMOVE INSULATING MATERIAL AS NECESSARY) [ЗАЩИТА] 19167509 INSULATOR, UPR INT MANIF CVR (ЧАСТЬ OF 3) (3.405) 12591715 GROMMET, UPR INT MANIF SIGHT SHLD (ЧАСТЬ OF 6) (32MM OD @ TOP) (ROUND AT TOP/TAPERED CONICAL BOTTOM) 12591715 GROMMET, UPR INT MANIF SIGHT SHLD (ЧАСТЬ OF 6) (32MM OD @ TOP) (ROUND AT TOP/TAPERED CONICAL BOTTOM) 12591715 GROMMET, UPR INT MANIF SIGHT SHLD (ЧАСТЬ OF 6) (32MM OD @ TOP) (ROUND AT TOP/TAPERED CONICAL BOTTOM) 15856790 SHIELD, F/CMPT SI SIGHT (ALL TERRAIN) (INCLS 5) (W/ INSULATOR) (REMOVE INSULATING MATERIAL AS NECESSARY) 25876570 SEAL, КАПОТ FRT (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ КАПОТА] 15788083 PLUG, HDLP ADJR ACC HOLE (30.2 X 7.7) (ROUND) (FITS 18.5 DIA HOLE) (12.940) [ЗАГЛУШКА ПАНЕЛИ КУЗОВА] (6D08-051) - 2008-2009 DM69 SIGHT SHIELD/НИЖНЯЯ ЧАСТЬ (LLT/3.6V, ЗАДНИЙ КОЛЕСО DRIVE MN6,MX0) ↓ teamcadillac.ru 15849031 SHIELD, E/CMPT LWR NOISE [ДЕФЛЕКТОР] 11609385 ГАЙКА, U-TYPE, M6X1, 29.5 LEN, 12.5 WID, 19.5 CEN-END, 1050, GMW3359 (F/CMPT LWR NOISE SHLD BRKT) [ГАЙКА М 6] 11609681 БОЛТ, HEX W/FL WA, M6X1X25, 14 THD, 24 OD, GM6202M STEEL, GMW3200 (F/CMPT LWR NOISE SHLD) [БОЛТ М6] 11589291 RETAINER, PUSH-IN, FITS 6.5 HOLE IN 7-9.5 THK PNL, NYLON 6/6 (F/CMPT LWR NOISE SHLD) [ФИКСАТОР ПАНЕЛИ БАМПЕРА] (6D08-052) - 2008-2009 DM69 SIGHT SHIELD/НИЖНЯЯ ЧАСТЬ (LLT/3.6V, ПОЛНОПРИВОДНЫЙ MX7) ↓ 15835283 SHIELD, E/CMPT LWR NOISE teamcadillac.ru 11609681 БОЛТ, HEX W/FL WA, M6X1X25, 14 THD, 24 OD, GM6202M STEEL, GMW3200 (F/CMPT LWR NOISE SHLD) [БОЛТ М6] 11570215 ГАЙКА, F/CMPT LWR NOISE SHLD BRKT (M6X1) (FITS HOLE SIZE 9.5X14, 2-3.8MM PNL THK) (8.160) [ШАЙБА] (6D08-053) - 2008 DM69 КРЫЛО & КОЛЕСНАЯ КОРОБКА ПЕРЕДНЯЯ (ЗАДНИЙ КОЛЕСО DRIVE MN6,MX0) ↓ 15929856 КРЫЛО, FRT (INCLS 2, 4, 22, 23) 15929857 КРЫЛО, FRT (INCLS 2, 4, 22, 23) 25927536 КРЫЛО, FRT (INCLS 2, 4, 22, 23) [ПЕРЕДНЕЕ КРЫЛО] 25927537 КРЫЛО, FRT (INCLS 2, 4, 22, 23) [КРЫЛО] not found BRACKET, F/FDR RR UPR BRKT (ЧАСТЬ OF 1) 11609540 БОЛТ, HWASH, M6X1X20, 16.15 THD, 17 OD, 8.8, GMW4205, HDR PT. (F/FDR UPR) [ВИНТ] 09442974 RIVET, 3/16" X .544 STYLE 1C, .424 LG., 34 OD, AL, PL, .062-.25 GRIP (ЧАСТЬ OF 1) teamcadillac.ru 25877078 SEAL, F/FDR [УПЛОТНИТЕЛЬ ПАНЕЛИ КРЫЛА] 11609540 БОЛТ, HWASH, M6X1X20, 16.15 THD, 17 OD, 8.8, GMW4205, HDR PT. (F/FDR RR UPR BRKT) [ВИНТ] 15250708 INSULATOR, F/FDR (INCLS 8) [ВСТАВКА ПЕРЕДНЕГО КРЫЛА] 20819341 INSULATOR, F/FDR (INCLS 8) 10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (ЧАСТЬ OF 7) [ПИСТОН КРЕПЛЕНИЯ ОБЛИЦОВКИ БАМПЕРА (NYLON)] not found RETAINER, F/END PNL MLDG (PUSH ON) (ЧАСТЬ OF 11) not found RETAINER, F/END PNL MLDG (PUSH ON) (ЧАСТЬ OF 11) 25851105 ORNAMENT, F/FDR (INCLS 9, 10) [ВСТАВКА ПЕРЕДНЕГО КРЫЛА] 25851106 ORNAMENT, F/FDR (INCLS 9, 10) [ВСТАВКА ПЕРЕДНЕГО КРЫЛА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (F/FDR RR CTR BRKT) [ГАЙКА М6] 10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (F/FDR INSL (PUSH IN)) [ПИСТОН КРЕПЛЕНИЯ ОБЛИЦОВКИ БАМПЕРА (NYLON)] 25940077 LINER, FRT W/H RR (WITH HOLE) [КРЫШКА] 25940078 LINER, FRT W/H RR (WITH HOLE) (INCLS RIVET & SHIELD) [УПЛОТНИТЕЛЬ] 11609540 БОЛТ, HWASH, M6X1X20, 16.15 THD, 17 OD, 8.8, GMW4205, HDR PT. (F/FDR LWR) [ВИНТ] 11589293 RETAINER, PUSH-IN, FITS 8.5 DIA HOLE, 4.5-7 THK PNL, NYLON 6/6 GMP.PA66.0 (FRT W/H LNR) [ФИКСАТОР ВОДОСТОЧНОЙ ПАНЕЛИ ВЕТРОВОГО СТЕКЛА] 11589293 RETAINER, PUSH-IN, FITS 8.5 DIA HOLE, 4.5-7 THK PNL, NYLON 6/6 GMP.PA66.0 (ENG FRT SPH SHLD (PUSH IN)) [ФИКСАТОР ВОДОСТОЧНОЙ ПАНЕЛИ ВЕТРОВОГО СТЕКЛА] 25898970 SHIELD, FRT W/H PNL SPH 11589291 RETAINER, PUSH-IN, FITS 6.5 HOLE IN 7-9.5 THK PNL, NYLON 6/6 (FRT BPR FASCIA EXTN) [ФИКСАТОР ПАНЕЛИ БАМПЕРА] 25940079 EXTENSION, FRT BPR FASCIA (W/HOLE) [ПОДКРЫЛОК] 25940080 EXTENSION, FRT BPR FASCIA (W/HOLE) [БОКОВАЯ ПАНЕЛЬ БАМПЕРА] 11609540 БОЛТ, HWASH, M6X1X20, 16.15 THD, 17 OD, 8.8, GMW4205, HDR PT. (F/FDR FRT LWR REINF) [ВИНТ] not found REINFORCEMENT, F/FDR FRT (ЧАСТЬ OF 1) not found REINFORCEMENT, F/FDR FRT UPR (ЧАСТЬ OF 1) 11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (F/FDR RR LWR BRKT) [ШАЙБА] 11609540 БОЛТ, HWASH, M6X1X20, 16.15 THD, 17 OD, 8.8, GMW4205, HDR PT. (F/FDR) [ВИНТ] (6D08-059) - 2008-2009 DM69 ПЕРЕХОДНИКИ/ДВИГАТЕЛЬНЫЙ ОТСЕК ↓ 15250705 INSULATOR, FRT W/H PNL 25883420 INSULATOR, DA PNL FRT 11588441 ГАЙКА, STAMP SPECIAL БОЛТ RETAINER, 24.05X17.42X2.5, SAE 1050 SPR STL, GMW3359 (DA PNL INSL) (PUSH NUT) 11588441 ГАЙКА, STAMP SPECIAL БОЛТ RETAINER, 24.05X17.42X2.5, SAE 1050 SPR STL, GMW3359 (DA PNL FRT INSL (PUSH ON)) (PUSH NUT) 15250703 INSULATOR, DA PNL teamcadillac.ru 20795357 INSULATOR, DA PNL UPR (INCLS 7, 8) not found WASHER, DA PNL INSL (ЧАСТЬ OF 6) 15056810 RETAINER, DA PNL UPR INSL (ЧАСТЬ OF 6) (18.8MM) (7.831) [ФИКСАТОР БАМПЕРА] (6D08-061) - 2008 DM69 ПАСПОРТНЫЕ ТАБЛИЧКИ И ДЕКАЛИ ↓ teamcadillac.ru 25558496 LABEL, ШИНА COMPACT SPA MAX SPD WRNG (MAX 80 KM/H) 15093589 LABEL, SPA WHL WRNG 12567697 LABEL, ALL WHL DRV CAUTION 15749557 LABEL, JK USAGE INFO & WRNG (ARABIC) 22722565 LABEL, JK WRNG (BILINGUAL) (TEXT & SYMBOLS ON WHITE BACKGROUND) not found LABEL, SERV ЧАСТЬ IDENT 15070503 LABEL, MERCURY DISPOSAL INFO 19206430 LABEL KIT, VEH CAPACITY WT & ШИНА INFO (ENGLISH ONLY LABEL FOR US) (QTY 10 PER KIT) 19206431 LABEL KIT, VEH CAPACITY WT & ШИНА INFO (ENGLISH W/FRENCH-CANADIAN LABEL FOR CANADA) (QTY 10 PER KIT) 19206432 LABEL KIT, VEH CAPACITY WT & ШИНА INFO (SPANISH LABEL FOR MEXICO) (QTY 10 PER KIT) 10443718 LABEL, ODOM SERV INFO (75MM X 55MM) (FOR USE WHEN ODOMETER OR CLUSTER IS SERVICED.) 25808256 LABEL, BAT WRNG not found LABEL, ECE & VIN not found LABEL, UNLEADED FUEL ONLY 19180225 LABEL, VEH EMIS CONT INFO (VIN MUST BE SUPPLIED WITH ORDER) 15053409 LABEL, КОНДИЦИОНЕР REFRIG & BAT & FAN BLADE & RAD FIL CAP CAUTION 15905238 LABEL, КОНДИЦИОНЕР REFRIG CHRG 12451193 LABEL, CHILD SECURITY LK OPERG INSTR (6M08-012) - 2008-2009 DM69 ШЛАНГИИ ТРУБКИ НАГРЕВАТЕЛЯ (LP1/2.8T,LLT/3.6V,LY7/3.6-7) ↓ 12606860 PIPE, HTR INL & OTLT (INCLS 6-8) [ТРУБКА] 11516222 CЛАМПА, ПРУЖИНАBAND, HOSE DIA=23, WIDTH=15, 6298M, MM (ЧАСТЬ OF 3) [ЗАЖИМ, ХОМУТ] 88958007 HOSE, HTR OTLT (INCLS 2) [ШЛАНГ] 88958006 HOSE, HTR INL (INCLS 5) [ШЛАНГ] 11516225 CЛАМПА, 25MM DIA, 15MM WIDTH, 6298 MATL (ЧАСТЬ OF 4) 12588318 SEAL, HTR INL PIPE (O RING) (ЧАСТЬ OF 1) [УПЛОТНЕНИЕ ТРУБКИ ОТОПИТЕЛЯ САЛОНА] 12592627 GASKET, HTR OTLT PIPE (ЧАСТЬ OF 1) [ПРОКЛАДКА] teamcadillac.ru 11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (ЧАСТЬ OF 1) [БОЛТ] (GM08-009) - 2008-2010 D КРАСКА/TOUCH-UP ↓ not found КРАСКА, TOUCH-UP TUBE (.5 OZ) 01052907 КРАСКА, TOUCH-UP TUBE (.5 OZ) (BLACK) (WA 8555) 12345116 КРАСКА, TOUCH-UP TUBE (.5 OZ) (PRIMER, FILLER SCRATCH) (GRAY) 12345118 КРАСКА, TOUCH-UP TUBE (.5 OZ) (CLEAR TOP COAT) 12346575 КРАСКА, TOUCH-UP TUBE (.5 OZ) (DARK MING BLUE MET) (WA 722J) 12346585 КРАСКА, TOUCH-UP TUBE (.5 OZ) (WHITE DIAMOND PEARL) (WA 800J) 12346643 КРАСКА, TOUCH-UP TUBE (.5 OZ) (DARK SPIRAL GRAY MET) (WA 805K) 12346693 КРАСКА, TOUCH-UP TUBE (.5 OZ) (LT TARNISH SILVER) (WA 994L) 12346721 КРАСКА, TOUCH-UP TUBE (.5 OZ) (SUNBURST ORANGE MET II) (WA 913L) 12346909 КРАСКА, TOUCH-UP TUBE (.5 OZ) (GOLD MIST MET) (WA 316N) 12346911 КРАСКА, TOUCH-UP TUBE (.5 OZ) (ANTIQUE BRONZE MET) (WA 317N) 88860735 КРАСКА, TOUCH-UP TUBE (.5 OZ) (TRANSITIONAL BLUE MET) (WA 400P) 88860759 КРАСКА, TOUCH-UP TUBE (.5 OZ) (KEVLAVA GRAY MET) (WA 417P) 88860775 КРАСКА, TOUCH-UP TUBE (.5 OZ) (COGNAC FROST TRI COAT) (WA 472P) (CONSISTS OF 2 TUBES (BASECOAT & TOPCOAT)) 88860791 КРАСКА, TOUCH-UP TUBE (.5 OZ) (MARY KAY PEARL TRICOAT) (WA 590Q) teamcadillac.ru 88860795 КРАСКА, TOUCH-UP TUBE (.5 OZ) (DARK BRAHMA JEWEL MET) (WA 519Q) 88860813 КРАСКА, TOUCH-UP TUBE (.5 OZ) (CRYSTAL CLARET TINTCOAT) (WA 505Q) not found КРАСКА, TOUCH-UP SPRAY (5 OZ) 12345117 КРАСКА, TOUCH-UP SPRAY (5 OZ) (PRIMER, FILLER, SCRATCH) 12345119 КРАСКА, TOUCH-UP SPRAY (5 OZ) (CLEAR TOP COAT) 12345155 КРАСКА, TOUCH-UP SPRAY (5 OZ) (BLACK) (WA 8555) 12346576 КРАСКА, TOUCH-UP SPRAY (5 OZ) (DARK MING BLUE MET) (WA 722J) 12346586 КРАСКА, TOUCH-UP SPRAY (5 OZ) (WHITE DIAMOND PEARL) (WA 800J) 12346644 КРАСКА, TOUCH-UP SPRAY (5 OZ) (DARK SPIRAL GRAY MET) (WA 805K) 12346694 КРАСКА, TOUCH-UP SPRAY (5 OZ) (LT TARNISH SILVER) (WA 994L) 12346910 КРАСКА, TOUCH-UP SPRAY (5 OZ) (GOLD MIST MET) (WA 316N) 12346912 КРАСКА, TOUCH-UP SPRAY (5 OZ) (ANTIQUE BRONZE MET) (WA 317N) 88860736 КРАСКА, TOUCH-UP SPRAY (5 OZ) (TRANSITIONAL BLUE MET) (WA 400P) 88860760 КРАСКА, TOUCH-UP SPRAY (5 OZ) (KEVLAVA GRAY MET) (WA 417P) 88860776 КРАСКА, TOUCH-UP SPRAY (5 OZ) (COGNAC FROST TRI COAT) (WA 472P) (CONSISTS OF 2 CANS (BASECOAT & TOPCOAT)) 88860792 КРАСКА, TOUCH-UP SPRAY (5 OZ) (MARY KAY PEARL TRICOAT) (WA 590Q) 88860796 КРАСКА, TOUCH-UP SPRAY (5 OZ) (DARK BRAHMA JEWEL MET) (WA 519Q) 88860814 КРАСКА, TOUCH-UP SPRAY (5 OZ) (CRYSTAL CLARET TINTCOAT) (WA 505Q) 09 - ВНУТРЕННЕЕ ОБОРУДОВАНИЕ - КОНДИЦИОНЕР - АУДИОСИСТЕМА (6D09-043) - 2008-2010 D АУДИОСИСТЕМА/ДИНАМИКИ & УСИЛИТЕЛЬ(UX8) ↓ teamcadillac.ru not found БОЛТ, RDO RR S/D SPKR (ЧАСТЬ OF 17) 11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (RDO RR SPKR) not found COVER, F/FLR CNSL RR (СМ. ГРУППУ 10.000 "КОНСОЛЬ/ПОЛ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found БОЛТ, F/FLR CNSL (ЧАСТЬ OF 6) 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (RDO FRT SPKR) [ВИНТ М4] not found RIVET, RDO VOL COMP INTR NOISE MIC (ЧАСТЬ OF 10) 11515196 SCREW, RND WA HD, M4.2X1.41X16, HILO SELF- TAP, 8.2 O.D., 6010M, NO (ЧАСТЬ OF 13) not found КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КРЫША ОТДЕЛКА/INTERIOR" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found TRIM, RR S/D (СМ. ГРУППУ 14.000 "ОТДЕЛКА/RR DOOR" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS 1, 2) not found HARNESS, BODY WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/КУЗОВ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (RDO SPKR AMPF) (6D09-053) - 2008 DM69 ВХОД ВОЗДУХА - ВЕНТИЛЯТОР ↓ not found SEAL, AIR INL (ЧАСТЬ OF 3) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (AIR INL HSG) [ГАЙКА М6] 19130171 INLET, AIR (INCLS 1, 4, 9, 12, 13) not found VALVE, AIR INL (ЧАСТЬ OF 3) 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (AIR INL HSG) [БОЛТ М6] 19130001 MOTOR, BLO (W/IMPLR) (ACDelco #15-80930) [МОТОР] 19130001 MOTOR, BLO (W/IMPLR) (8.855) (ACDelco #15-80930) [МОТОР] 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (BLO & AIR INL MDL) [БОЛТ М6] 15141283 МОДУЛЬ, BLO MOT CONT (ACDelco #15-80863) [РЕЗИСТОР 15 ВТ] teamcadillac.ru not found МОДУЛЬ, BLO & AIR INL (ЧАСТЬ OF 3) 11516589 SCREW, HEX HD W/CON SPR WA, M6X1X30, 29 THD, 17 O.D., 9.8, 7114M, ZE (AIR INL) 25815468 ACTUATOR, AIR INL VLV (ACDelco #15-73818) [АКТИВАТОР] not found SEAL, AIR INL (ЧАСТЬ OF 3) not found LEVER, AIR INL VLV (ЧАСТЬ OF 3) (6D09-064) - 2008 DM69 RADIO КРЕПЛЕНИЕ & DISPLAY(UAV,U2X,U2Y) ↓ 15226445 АНТЕННА, ELEK NAVIGATION (ACDelco #15226445) not found HARNESS, I/P WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 15862570 COVER, NAVN INFO DISPLAY OPG (EBONY) 15862571 COVER, NAVN INFO DISPLAY OPG (CASHMERE) teamcadillac.ru not found ACTUATOR, RDO & VIDEO & AUDIO DISC PLYR & NAVN INFO DISPLAY (ЧАСТЬ OF 6) 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (VIDEO DISPLAY) [ВИНТ М4] 25968621 DISPLAY, RDO & VIDEO & AUDIO DISC PLYR & NAVN INFO (INCLS 4) (ACDelco #25968621) (LABELED 25968621) [ЖК- МОНИТОР С DVD-ПЛЕЙЕРОМ] 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (RDO) [ВИНТ М4] not found CLIP, I/P CTR TR PNL (ЧАСТЬ OF 9) not found CONTROL, AM/FM STEREO & CLK & CD PLYR RDO (INCLS 8) (СМ. ГРУППУ 10.000 "ПРИБОРНАЯ ПАНЕЛЬ/CENTER CONTROL" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (RDO CONT) [ВИНТ М4] not found DISC, NAVN MAP (TO ORDER DISCS, CONTACT GM NAVIGATION DISC CENTER) 20762249 RADIO, AM/FM STEREO & VIDEO DISC PLYR & NAVN&MP3&HARD DR (ACDelco #20762249) 25816522 RADIO, AM/FM STEREO & VIDEO DISC PLYR & NAVN&MP3&HARD DR (ACDelco #25816522) (LABELED 25816522) 25912236 RADIO, AM/FM STEREO & VIDEO DISC PLYR & NAVN&MP3&HARD DR (ACDelco #25912236) 25916644 RADIO, AM/FM STEREO & VIDEO DISC PLYR & NAVN&MP3&HARD DR (ACDelco #25916644) 25916645 RADIO, AM/FM STEREO & VIDEO DISC PLYR & NAVN&MP3&HARD DR (LABELED 25916645) (ACDelco #25916645) 25979736 RADIO, AM/FM STEREO & VIDEO DISC PLYR & NAVN&MP3&HARD DR (ACDelco #25979736) 11518121 ГАЙКА, U, M6X1, MULTI THD, .5'-4.0' THK PNL (I/P) not found HARNESS, NAVIGATION WRG 25833057 HARNESS, NAVIGATION WRG (6D09-065) - 2008 DM69 RADIO КРЕПЛЕНИЕ (U2S,U2R,U2T) ↓ not found HARNESS, I/P WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25833050 CABLE, RDO ANT (I/P WRG HARN) (ACDelco #25833050) 25833062 CABLE, RDO ANT (BODY WRG HARN) (ACDelco #25833062) 11515638 ГАЙКА, U-TYPE, M4.2X1.41X10.5.5X22, .65-3.8 PNL THK, 1050, ZF (I/P) [ГАЙКА М4.2] 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (RDO) [ВИНТ М4] not found CLIP, I/P CTR TR PNL (ЧАСТЬ OF 6) not found CONTROL, AM/FM STEREO & CLK & CD PLYR RDO (INCLS 5) (СМ. ГРУППУ 10.000 "ПРИБОРНАЯ ПАНЕЛЬ/CENTER CONTROL" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (RDO CONT) [ВИНТ М4] not found RADIO, AM/FM STEREO & AUDIO DISC PLYR & MP3 PLYR&HARD DR teamcadillac.ru 19117334 RADIO, AM/FM STEREO & AUDIO DISC PLYR & MP3 PLYR (ACDelco #19117334) 20763583 RADIO, AM/FM STEREO & AUDIO DISC PLYR & MP3 PLYR&HARD DR (ACDelco #20763583) 20773368 RADIO, AM/FM STEREO & AUDIO DISC PLYR & MP3 PLYR (LABELED 20773368) (ACDelco #20773368) 20773369 RADIO, AM/FM STEREO & AUDIO DISC PLYR & MP3 PLYR (LABELED 20773369) (ACDelco #20773369) 20773370 RADIO, AM/FM STEREO & AUDIO DISC PLYR & MP3 PLYR (LABELED 20773370) (ACDelco #20773370) 25909606 RADIO, AM/FM STEREO & AUDIO DISC PLYR & MP3 PLYR&HARD DR (ACDelco #25909606) (6D09-066) - 2008 DM69 КОНДИЦИОНЕР СИСТЕМА ОХЛАЖДЕНИЯ (LP1/2.8T,LLT/3.6V,LY7/3.6-7) ↓ 15261820 TUBE, КОНДИЦИОНЕР CNDSR (INCLS 2-4) (ACDelco #15-33826) [ТРУБКА] 88958095 VALVE, КОНДИЦИОНЕР REFRIG SERV (ЧАСТЬ OF 1, 12) (ACDelco #15-50154) [ПРЕДОХРАНИТЕЛЬНЫЙ КЛАПАН СИСТЕМЫ ОХЛАЖДЕНИЯ] 88957402 CAP, КОНДИЦИОНЕР CNDSR TUBE (LIQUID) (ЧАСТЬ OF 1) (9.177) (ACDelco #15-32563) [КОЛПАЧОК КЛАПАНА СИСТЕМЫ ОХЛАЖДЕНИЯ] 25740418 SEAL, КОНДИЦИОНЕР CNDSR TUBE (O RING) (ЧАСТЬ OF 1) (8MM) (ACDelco #15-31874) [УПЛОТНЕНИЕ ТРУБКИ КОНДИЦИОНЕРА] 25728831 CЛАМПА, КОНДИЦИОНЕР CNDSR & EVPR TUBE (L=35M W=31M H=32M) [ЗАЖИМ] 25728832 CЛАМПА, КОНДИЦИОНЕР CMPR & CNDSR HOSE (L=38M W=32M H=39M) [МОДУЛЬ] 25740419 SEAL, КОНДИЦИОНЕР CMPR HOSE (5/8IN) (ЧАСТЬ OF 12) (ACDelco #15-31873) [ПРОКЛАДКА ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ] teamcadillac.ru 88957401 CAP, КОНДИЦИОНЕР CMPR HOSE (SUCTION) (ЧАСТЬ OF 12) (9.177) (ACDelco #15-32562) [КРЫШКА] not found SEAL, КОНДИЦИОНЕР REFRIG SERV VLV (O RING) (ЧАСТЬ OF 12) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (КОНДИЦИОНЕР TUBE BRKT) 88958096 CLIP, КОНДИЦИОНЕР CMPR HOSE (ЧАСТЬ OF 12) 15261843 HOSE, КОНДИЦИОНЕР CMPR (INCLS 2, 7-9, 11) (SUCTION HOSE) (ACDelco #15-33820) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 11516424 БОЛТ, HFH, M6X1X25, 14.2 O.D., HDR PT, 9.8, ZE (КОНДИЦИОНЕР CMPR HOSE) [БОЛТ М6] 25740416 SEAL, КОНДИЦИОНЕР CMPR & CNDSR HOSE (1/2IN) (ЧАСТЬ OF 15) (ACDelco #15-31872) [ПРОКЛАДКА КОМПРЕССОРА КОНДИЦИОНЕРА] 25801154 HOSE, КОНДИЦИОНЕР CMPR & CNDSR (INCLS 14) (DISCHARGE HOSE) (ACDelco #15-33825) [ТРУБКА] 11516424 БОЛТ, HFH, M6X1X25, 14.2 O.D., HDR PT, 9.8, ZE (КОНДИЦИОНЕР CMPR & CNDSR HOSE) [БОЛТ М6] 25865635 КОМПРЕССОР KIT, КОНДИЦИОНЕР (СМ. ГРУППУ 09.000 "КОМПРЕССОР КОНДИЦИОНЕРА ASM" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #15-21685) [КОМПРЕССОР] 88958089 SENSOR, КОНДИЦИОНЕР CYCLING & FAN CONT КОНДИЦИОНЕР REFRIG PRESS (ЧАСТЬ OF 22) (ACDelco #15-50153) [ВЫКЛЮЧАТЕЛЬ] 25740418 SEAL, КОНДИЦИОНЕР CYCLING & FAN CONT КОНДИЦИОНЕР REFRIG PRESS SEN (O RING) (ЧАСТЬ OF 22) (8MM) (ACDelco #15-31874) [УПЛОТНЕНИЕ ТРУБКИ КОНДИЦИОНЕРА] 88958090 SEAL, КОНДИЦИОНЕР EVAP TUBE (O RING) (ЧАСТЬ OF 22) (ACDelco #15-32579) [ПРОКЛАДКА КОНДИЦИОНЕРА] 19130331 БОЛТ, КОНДИЦИОНЕР CNDSR TUBE [БОЛТ] 15932848 TUBE, КОНДИЦИОНЕР CNDSR OTLT (INCLS 18-20) (ACDelco #15-33827) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 15932849 CONDENSER, КОНДИЦИОНЕР (INCLS 24-26) (ACDelco #15-63543) [КОНДЕНСОР] 20777795 DESICCANT KIT, КОНДИЦИОНЕР REFRIG (ЧАСТЬ OF 23) (INCLS 25, 26) not found SEAL, КОНДИЦИОНЕР RCVR & DEHYDR CVR (O RING) (ЧАСТЬ OF 23, 24) not found PLUG, КОНДИЦИОНЕР RCVR & DEHYDR (ЧАСТЬ OF 23, 24) (6D09-067) - 2008 DM69 СИСТЕМА РАСПРЕДЕЛЕНИЯ ВОЗДУХА ↓ 25800284 DUCT, SI WDO DEFG OTLT 15843182 NOZZLE, W/S DEFR [СИГНАЛ] 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (W/S DEFR NOZ) [ВИНТ М4] 25800285 DUCT, SI WDO DEFG OTLT 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (BLO & AIR INL MDL) [БОЛТ М6] not found МОДУЛЬ, HTR & КОНДИЦИОНЕР EVPR (СМ. ГРУППУ 09.000 "КОНДИЦИОНЕР & НАГРЕВАТЕЛЬ ASM" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (AIR DISTR DUCT) [ВИНТ М4] teamcadillac.ru 25905215 DUCT, AIR DISTR not found SEAL, AIR DISTR DUCT (ЧАСТЬ OF 10) 25800290 DUCT, AIR DISTR (INCLS 9) (CTR) 25905216 DUCT, AIR DISTR 25862315 КРОНШТЕЙН, INST (СМ. ГРУППУ 10.000 "ПРИБОРНАЯ ПАНЕЛЬ/STRUCTURE" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (LHD) 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (HTR & КОНДИЦИОНЕР EVPR & BLO MDL) [БОЛТ М6] 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (F/FLR CNSL RR AIR DUCT) [ВИНТ М4] 15843191 DUCT, F/FLR CNSL RR AIR (СМ. ГРУППУ 10.000 "КОНСОЛЬ/ПОЛ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS 16, 22) (U SHAPED) not found SEAL, F/FLR CNSL RR AIR DUCT (ЧАСТЬ OF 15) 25801211 DUCT, F/FLR CNSL RR AIR (СМ. ГРУППУ 10.000 "КОНСОЛЬ/ПОЛ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS 19) (L SHAPED) 25726435 DUCT, FLR RR AIR OTLT not found SEAL, F/FLR CNSL RR AIR DUCT (ЧАСТЬ OF 17) 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (F/FLR CNSL RR AIR DUCT) [ВИНТ М4] 15843181 DUCT, F/FLR CNSL FRT AIR not found SEAL, F/FLR CNSL RR AIR DUCT (ЧАСТЬ OF 15) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (HTR & КОНДИЦИОНЕР EVPR & BLO MDL) [ГАЙКА М6] not found МОДУЛЬ, BLO & AIR INL (СМ. ГРУППУ 09.000 "ВХОД ВОЗДУХА - ВЕНТИЛЯТОР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (BLO & AIR INL MDL) [БОЛТ М6] (6D09-068) - 2008 DM69 АНТЕННА/АУДИОСИСТЕМА (U2K) ↓ teamcadillac.ru 10335503 АНТЕННА, M/TEL DIGITAL (76.7 MM) (SHARK FIN, TWIST ON STYLE) (ACDelco #10335503) 10335503 АНТЕННА, M/TEL DIGITAL (76.7 MM) (SHARK FIN, TWIST ON STYLE) (9.647) (ACDelco #10335503) 25847297 BASE, DIGITAL RDO & M/TEL & VEH LOC (INCLS 4) 25833051 CABLE, DIGITAL RDO АНТЕННА (I/P WRG HARN) (ACDelco #25833051) 25833063 CABLE, DIGITAL RDO АНТЕННА (BODY WRG HARN) (ACDelco #25833063) 25833063 CABLE, DIGITAL RDO АНТЕННА (BODY WRG HARN) (ACDelco #25833063) 25833063 CABLE, DIGITAL RDO АНТЕННА (BODY WRG HARN) (ACDelco #25833063) not found БОЛТ, RDO ANT BASE (ЧАСТЬ OF 2) 25879548 HARNESS, I/P WRG HARN EXTN (FOR SOLAR SENSOR) 25898287 HARNESS, I/P WRG HARN EXTN not found RADIO, AM/FM STEREO & VIDEO DISC PLYR & NAVN&MP3&HARD DR (СМ. ГРУППУ 09.000 "RADIO КРЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6D09-069) - 2008 DM69 INFOTAINMENT SYSTEM (U2X,U2Y) ↓ 25798601 TUNER, TV (ACDelco #25798601) [ТВ-ТЮНЕР] 25833067 CABLE, TV ANT AMPF COAX (ЧАСТЬ OF 4) (ACDelco #25833067) 25833066 CABLE, TV ANT AMPF COAX (ЧАСТЬ OF 4) (ACDelco #25833066) teamcadillac.ru not found HARNESS, BODY WRG (INCLS 2, 3) (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/КУЗОВ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25723894 УСИЛИТЕЛЬ, TV ANT (JAPAN) 25769453 УСИЛИТЕЛЬ, TV ANT 11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (TV ANT MDL) [БОЛТ М8] 15243078 CABLE, TV ANT 15226443 АНТЕННА, NAVIGATION & TRAFFIC DATA (VICS) not found HARNESS, W/S HDR WRG (СМ. ГРУППУ 10.000 "КРЫША ОТДЕЛКА/INTERIOR" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6D09-070) - 2008 DM69 АНТЕННА/AUDIO ↓ 15884432 МОДУЛЬ, RDO ANT (ACDelco #15884432) 15884432 МОДУЛЬ, RDO ANT (ACDelco #15884432) 11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (RDO ANT MDL) [БОЛТ М8] 25833050 CABLE, RDO ANT (I/P WRG HARN) (ЧАСТЬ OF 4) (ACDelco #25833050) teamcadillac.ru 25833062 CABLE, RDO ANT (BODY WRG HARN) (ЧАСТЬ OF 4) (ACDelco #25833062) not found HARNESS, BODY WRG (INCLS 3) (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/КУЗОВ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6D09-071) - 2008 DM69 СИСТЕМА КОМУНИКАЦИИ "ONSTAR"(UE1) ↓ 10335503 АНТЕННА, M/TEL DIGITAL (76.7 MM) (SHARK FIN, TWIST ON STYLE) (ACDelco #10335503) 10335503 АНТЕННА, M/TEL DIGITAL (76.7 MM) (SHARK FIN, TWIST ON STYLE) (9.647) (ACDelco #10335503) 25840690 BASE, M/TEL & VEH LOC ANT (INCLS 5) (REQUIRES ANT MAST 10335503) (ACDelco #25840690) 25840690 BASE, M/TEL & VEH LOC ANT (INCLS 5) (REQUIRES ANT MAST 10335503) (ACDelco #25840690) 25847297 BASE, DIGITAL RDO & M/TEL & VEH LOC (INCLS 5) 25833064 CABLE, VEH LOC ANT (ЧАСТЬ OF 7) 25833065 CABLE, M/TEL ANT (ЧАСТЬ OF 7) not found БОЛТ, RDO ANT BASE (ЧАСТЬ OF 2) 15940564 МОДУЛЬ, COMN INTERFACE (W/MOBILE TEL XCVR) (ACDelco #15940564) (LABELED W/OEM PN 15939720 OR SERVICE PN 15940564.) 25910217 МОДУЛЬ, COMN INTERFACE (W/MOBILE TEL XCVR) (ACDelco #25910217) (LABELED 25910217) 25990227 МОДУЛЬ, COMN INTERFACE (W/MOBILE TEL XCVR) (LABELED 25990227) (ACDelco #25990227) not found HARNESS, BODY WRG (INCLS 3, 4) (СМ. ГРУППУ 13.000 "ЖГУТЫ ПРОВОДОВ/КУЗОВ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (COMN INTERFACE MDL BRKT) [БОЛТ М8] teamcadillac.ru 11514517 ГАЙКА, HEX, W/CON SPR WA, M6X1, 5.7THK, 18 O.D., 9, 7111M (COMMUNICATION INTERFACE MDL) [ГАЙКА М6] not found МОДУЛЬ, HDLNG TR (СМ. ГРУППУ 14.000 "ОТДЕЛКА/КРЫША HEADLINER" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 15241529 MICROPHONE, MOBILE TEL (2-WAY CAVITY) 15938939 АНТЕННА, WIRELESS COMN INTERFACE (BLUETOOTH) (6D09-072) - 2008 DM69 АУДИОСИСТЕМА/ДИНАМИКИ & УСИЛИТЕЛЬ (10 SPEAKER AUDIO UQS) ↓ 15240415 MICROPHONE, RDO VOL COMP INTR NOISE (ЧАСТЬ OF 5) 15246939 MICROPHONE, RDO VOL COMP INTR NOISE (ЧАСТЬ OF 5) (RDO VOL COMP) 15122573 SPEAKER, RDO FRT (ACDelco #15122573) [ДИНАМИК 30ВТ] 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (RDO FRT SPKR) [ВИНТ М4] 11610157 ГАЙКА, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (RDO FRT SPKR) (10.701) [ГАЙКА М4] not found МОДУЛЬ, HDLNG TR (INCLS 1) (СМ. ГРУППУ 10.000 "КРЫША ОТДЕЛКА/INTERIOR" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found HARNESS, I/P WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (RDO FRT S/D SPKR) (9.665) [БОЛТ М4.2Х1.41Х25] teamcadillac.ru 15278539 SPEAKER, RDO FRT S/D (ACDelco #15278539) [ДИНАМИК 40ВТ] 11570654 ГАЙКА, RDO FRT S/D SPKR (4.2 X 1.41) (FITS 8.75 SQ HOLE) not found HARNESS, FRT S/D DR WRG (СМ. ГРУППУ 10.000 "АРМАТУРА ПЕРЕДНЕЙ ДВЕРИ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25725733 SPEAKER, RDO RR S/D (ACDelco #25725733) [ДИНАМИК 40ВТ] 11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (RDO RR SPKR) 15122573 SPEAKER, RDO RR (9.650) (ACDelco #15122573) [ДИНАМИК 30ВТ] 11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (RDO RR SPKR) not found HARNESS, RR S/D WRG (СМ. ГРУППУ 10.000 "АРМАТУРА ЗАДНЕЙ ДВЕРИ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found HARNESS, BODY WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/КУЗОВ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 15278538 SPEAKER, RDO RR (ACDelco #15278538) [ДИНАМИК] 11609599 STUD, SPL, M6X1X25, 13 THD, 11 OD HD W/26 WIDE CLIP, 9.8, 6280M, P-PT (RDO SPKR AMPF) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (RDO SPKR AMPF) [ГАЙКА М6] 25921142 УСИЛИТЕЛЬ, RDO SPKR (ACDelco #25921142) [УСИЛИТЕЛЬ ЗВУКОВОЙ ЧАСТОТЫ ДЛЯ АВТОМАГНИТОЛЫ] 11514517 ГАЙКА, HEX, W/CON SPR WA, M6X1, 5.7THK, 18 O.D., 9, 7111M (RDO RR SPKR) [ГАЙКА М6] 25927513 BRACKET, R/WDO PNL SUPT 25918601 BRACKET, R/WDO PNL SUPT 25918602 BRACKET, R/WDO PNL SUPT (6D09-073) - 2008 DM69 АУДИОСИСТЕМА/ДИНАМИКИ & УСИЛИТЕЛЬ (8 SPEAKER AUDIO UQA) ↓ 15240415 MICROPHONE, RDO VOL COMP INTR NOISE (ЧАСТЬ OF 5) 15246939 MICROPHONE, RDO VOL COMP INTR NOISE (ЧАСТЬ OF 5) (RDO VOL COMP) 15278540 SPEAKER, RDO FRT (ACDelco #15278540) [ДИНАМИК] 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (RDO FRT SPKR) [ВИНТ М4] not found ГАЙКА, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (RDO FRT SPKR) (10.701) not found МОДУЛЬ, HDLNG TR (INCLS 1) (СМ. ГРУППУ 10.000 "КРЫША ОТДЕЛКА/INTERIOR" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found HARNESS, I/P WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (RDO FRT S/D SPKR) (9.665) [БОЛТ М4.2Х1.41Х25] teamcadillac.ru 15839233 SPEAKER, RDO FRT S/D (ACDelco #15839233) [ДИНАМИК] 11570654 ГАЙКА, RDO FRT S/D SPKR (4.2 X 1.41) (FITS 8.75 SQ HOLE) not found HARNESS, FRT S/D DR WRG (СМ. ГРУППУ 10.000 "АРМАТУРА ПЕРЕДНЕЙ ДВЕРИ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25725733 SPEAKER, RDO RR S/D (ACDelco #25725733) [ДИНАМИК 40ВТ] 11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (RDO RR SPKR) not found HARNESS, RR S/D WRG (СМ. ГРУППУ 10.000 "АРМАТУРА ЗАДНЕЙ ДВЕРИ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 15839234 SPEAKER, RDO RR (ACDelco #15839234) [ДИНАМИК] 11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (RDO RR SPKR) not found HARNESS, BODY WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/КУЗОВ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11609599 STUD, SPL, M6X1X25, 13 THD, 11 OD HD W/26 WIDE CLIP, 9.8, 6280M, P-PT (RDO SPKR AMPF) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (RDO SPKR AMPF) [ГАЙКА М6] 25869049 УСИЛИТЕЛЬ, RDO SPKR (ACDelco #25869049) [УСИЛИТЕЛЬ] 11514517 ГАЙКА, HEX, W/CON SPR WA, M6X1, 5.7THK, 18 O.D., 9, 7111M (RDO RR SPKR) [ГАЙКА М6] 25927513 BRACKET, R/WDO PNL SUPT not found BRACKET, R/WDO PNL SUPT 25918601 BRACKET, R/WDO PNL SUPT 25918602 BRACKET, R/WDO PNL SUPT (6D09-074) - 2008 DM69 КОНДИЦИОНЕР & НАГРЕВАТЕЛЬ ASM ↓ 15939659 HARNESS, HTR & КОНДИЦИОНЕР CONT WRG 15939656 THERMISTOR, DRV MOT AIR INL TEMP [ТЕРМИСТР] 25852678 VALVE, DEFR (ACDelco #15-50804) 25852677 VALVE, VENT (ACDelco #15-50803) 25852757 CASE, AIR DISTR 15266665 CLIP, КОНДИЦИОНЕР EVPR CASE (9.215) not found SEAL, AIR DISTR (*KIT2) not found LEVER, HTR & КОНДИЦИОНЕР CONT MODE (*KIT3) 15939657 ACTUATOR, MODE VLV (ACDelco #15-73816) [ПЕРЕКЛЮЧАТЕЛЬ] 25770699 БОЛТ, MODE VLV ACTR (PHILLIPS HEAD) 25781502 БОЛТ, MODE CONT CAM ACTR (*KIT3) (9.278) 25781502 GROMMET, HTR & КОНДИЦИОНЕР CONT TEMP CAM (*KIT1) not found LEVER, HTR & КОНДИЦИОНЕР CONT MODE (*KIT3) not found LEVER, VENT VLV (*KIT3) 25852683 LEVER, HTR & КОНДИЦИОНЕР CONT TEMP not found INSULATOR, HTR & КОНДИЦИОНЕР CONT (*KIT2) not found INSULATOR, HTR & КОНДИЦИОНЕР CONT (*KIT2) 89022548 CORE, HTR (ACDelco #15-63063) [РАДИАТОР] teamcadillac.ru 25852758 BRACKET, HTR CORE TUBE 25770699 БОЛТ, HTR & КОНДИЦИОНЕР EVPR MDL (PHILLIPS HEAD) (9.280) 25770699 БОЛТ, HTR & КОНДИЦИОНЕР CONT TEMP CAM GROM (PHILLIPS HEAD) (9.280) 89023390 ACTUATOR, TEMP VLV (PASSENGER SIDE) (ACDelco #15-73024) [ПРИВОД ЗАСЛОНКИ ОТОПИТЕЛЯ САЛОНА, 10ВТ] 11518121 ГАЙКА, U, M6X1, MULTI THD, .5'-4.0' THK PNL (HTR CONT (PUSH IN)) not found INSULATOR, КОНДИЦИОНЕР EVPR TXV (*KIT2) 25865640 EVAPORATOR KIT, КОНДИЦИОНЕР (ACDelco #15-63550) [ИСПАРИТЕЛЬ] 25781505 DUCT, FLR FRT AIR OTLT 25852681 VALVE, MIXER (ЗАДНИЙ) 25852756 CASE, AIR DISTR 25740397 ASPIRATOR, I/S AIR TEMP SEN 25781504 LEVER, HTR & КОНДИЦИОНЕР CONT TEMP (BLACK) not found CAM, HTR & КОНДИЦИОНЕР CONT TEMP (*KIT1) 25740400 HOSE, КОНДИЦИОНЕР EVPR & BLO MDL DRN 25781503 LEVER, HTR & КОНДИЦИОНЕР CONT TEMP (NATURAL) 25852682 LEVER, HTR & КОНДИЦИОНЕР CONT TEMP not found ROD, HTR & КОНДИЦИОНЕР CONT TEMP (*KIT1) not found ACTUATOR, TEMP VLV (*KIT1) 25770699 БОЛТ, TEMP VLV ACTR (PHILLIPS HEAD) 25852778 CЛАМПА, КОНДИЦИОНЕР EVPR CASE not found SEAL, КОНДИЦИОНЕР EVPR TXV (O RING) (ЧАСТЬ OF 43, 45) not found БОЛТ, КОНДИЦИОНЕР EVPR TXV (ЧАСТЬ OF 43) not found SEAL, КОНДИЦИОНЕР EVPR TXV (O RING) (ЧАСТЬ OF 43) not found SEAL, КОНДИЦИОНЕР EVPR TXV (O RING) (ЧАСТЬ OF 43, 45) 19129999 VALVE KIT, КОНДИЦИОНЕР EVPR THERMAL EXPN (INCLS 39-42, 44) (ACDelco #15-50697) [НАБОР КЛАПАНОВ] not found ATTACHMENT KIT, КОНДИЦИОНЕР EVPR TXV (ЧАСТЬ OF 43) 19130000 TUBE KIT, КОНДИЦИОНЕР EVPR TXV (INCLS 39, 42, 46) (ACDelco #15-33518) not found INSULATOR, КОНДИЦИОНЕР EVPR TXV TUBE (ЧАСТЬ OF 45) not found INSULATOR, HTR & КОНДИЦИОНЕР CONT (*KIT2) not found INSULATOR, HTR & КОНДИЦИОНЕР CONT (*KIT2) not found SEAL, HTR CORE CASE (*KIT2) 25852761 VALVE, MIXER 25852674 CASE, AIR DISTR (CENTER) 25852763 VALVE, MIXER 25874761 DRAIN, КОНДИЦИОНЕР EVPR & BLO CASE (ACDelco #15-81091) 25865637 CAM KIT, HTR & КОНДИЦИОНЕР CONT (INCLS 12, 31, 35, 36) (ACDelco #15-73848) 25865639 SEAL KIT, HTR & КОНДИЦИОНЕР EVPR & BLO MDL (INCLS 7, 16, 17, 24, 47-49) (ACDelco #15-33844) 25865638 LEVER KIT, HTR & КОНДИЦИОНЕР CONT MODE (INCLS 8, 11, 13, 14) (ACDelco #15-73849) (6D09-076) - 2008 DM69 ДАТЧИК ТЕМПЕРАТУРЫ ↓ 15826773 SENSOR, AMB AIR TEMP (WITH PUSH-IN/ATTACHMENT) (ACDelco #15-51150) [СЕНСОР] not found HARNESS, I/P WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6D09-077) - 2008-2009 DM69 КОМПРЕССОР КОНДИЦИОНЕРА КРЕПЛЕНИЕ (LP1/2.8T,LLT/3.6V,LY7/3.6-7) ↓ 25865635 КОМПРЕССОР KIT, КОНДИЦИОНЕР (СМ. ГРУППУ 09.000 "КОМПРЕССОР КОНДИЦИОНЕРА ASM" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #15-21685) [КОМПРЕССОР] teamcadillac.ru 11517115 БОЛТ, HFH, M10X1.5X160, 30.5THD, 22.3 O.D., HDR PT, 9.8, 7114M (КОНДИЦИОНЕР CMPR) 11588742 БОЛТ, КОНДИЦИОНЕР CMPR (M10X1.5X50) 12602100 BRACKET, КОНДИЦИОНЕР CMPR 11518630 БОЛТ, HFH, M10X1.5X60, 26 THD, 22.3 OD, 10.9, GMW3359, MAT POINT (КОНДИЦИОНЕР CMPR BRKT) (6D09-078) - 2008 DM69 КОМПРЕССОР КОНДИЦИОНЕРА ASM ↓ 25865635 КОМПРЕССОР KIT, КОНДИЦИОНЕР (INCLS 2-11) (ACDelco #15-21685) [КОМПРЕССОР] not found BRACKET, КОНДИЦИОНЕР CMPR (ЧАСТЬ OF 1, 10) teamcadillac.ru not found БОЛТ, КОНДИЦИОНЕР CMPR BRKT (ЧАСТЬ OF 1, 10) not found РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ, КОНДИЦИОНЕР CLU (ЧАСТЬ OF 1, 10) not found RING, КОНДИЦИОНЕР CLU РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ RET (ЧАСТЬ OF 1, 10) not found BEARING, КОНДИЦИОНЕР CMPR PUL (ЧАСТЬ OF 1, 10) not found PULLEY, КОНДИЦИОНЕР CMPR (ЧАСТЬ OF 1, 10) not found RING, КОНДИЦИОНЕР CMPR PUL BRG RET (ЧАСТЬ OF 1, 10) not found WASHER, КОНДИЦИОНЕР CMPR PUL (ЧАСТЬ OF 1, 10) 25865636 СЦЕПЛЕНИЕ KIT, КОНДИЦИОНЕР (ЧАСТЬ OF 1) (INCLS 2-9, 11) (ACDelco #15-40145) [СЦЕПЛЕНИЕ] 11561365 БОЛТ, КОНДИЦИОНЕР CMPR PUL (ЧАСТЬ OF 1, 10) (6D09-079) - 2008 D69 НАВИГАЦИОННАЯ СИСТЕМА/COMPASS МОДУЛЬ ↓ teamcadillac.ru 20860277 МОДУЛЬ, ELEK COMPASS not found HARNESS, BODY WRG (СМ. ГРУППУ 13.000 "ЖГУТЫ ПРОВОДОВ/КУЗОВ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6D09-080) - 2008 DM69 ВХОД ВОЗДУХА ↓ 19130428 COVER, PASS COMPT AIR FLTR ACC HOLE (WILL ALSO REQUIRE USE OF 19130429 ON CARS BUILT PRIOR TO 5/1/07) 19130403 FILTER KIT, PASS COMPT AIR (ЧАСТЬICLE FILTER) (ACDelco #CF133) [ВОЗДУШНЫЙ ФИЛЬТР САЛОНА] not found RETAINER, PASS COMPT AIR FLTR (ЧАСТЬ OF 4) 19130429 ШЛАНГИ, PASS COMPT AIR FLTR (INCLS 3) (9.169) 25900707 PANEL, AIR INL HSG LWR (INCLS 7) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (AIR INL HSG) [ГАЙКА М6] 11518121 ГАЙКА, U, M6X1, MULTI THD, .5'-4.0' THK PNL (ЧАСТЬ OF 5) 25746570 VALVE, PLNM DRN [ОБРАТНЫЙ КЛАПАН СИСТЕМЫ ОХЛАЖДЕНИЯ] 11516589 SCREW, HEX HD W/CON SPR WA, M6X1X30, 29 THD, 17 O.D., 9.8, 7114M, ZE (AIR INL) 11515638 ГАЙКА, U-TYPE, M4.2X1.41X10.5.5X22, .65-3.8 PNL THK, 1050, ZF (ЧАСТЬ OF 13) [ГАЙКА М4.2] 11609489 БОЛТ, HEX W/ WASHER, 4.2X1.41X25, 14.5 THD17 OD, GM6010M STL, GMW4205 (AIR INL GRL) [БОЛТ М4.2] 25892885 PANEL, AIR INL GRL (СМ. ГРУППУ 10.000 "СТЕКЛООЧИСТИТЕЛЬ-ВЕТРОВОГО СТЕКЛА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 20791499 PANEL, AIR INL HSG FRT UPR (INCLS 10) 10 - ВЕТРОВОЕ СТЕКЛО - СТЕКЛООЧИСТИТЕЛЬ - ЗЕРКАЛА - ПРИБОРНАЯ ПАНЕЛЬ - КОНСОЛЬ - ДВЕРИ (6D10-064) - 2008-2010 DM69 ПРИБОРНАЯ ПАНЕЛЬ ЧАСТЬ 1 TRIM ↓ 15862334 GRILLE, SI WDO DEFG OTLT (EBONY) 15862336 GRILLE, SI WDO DEFG OTLT (COCOA) 15862527 COVER, I/P CSTR TR PLT (EBONY) 25945705 COVER, I/P CSTR TR PLT (COCOA) 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (I/P CSTR TR PLT) [ВИНТ М4] 25876731 COVER, I/P UPR TR (EBONY) (W/O NAV INFO DISPLAY) [КРЫШКА] 25876732 COVER, I/P UPR TR (COCOA) (W/O NAV INFO DISPLAY) [КРЫШКА] 15862335 GRILLE, SI WDO DEFG OTLT (EBONY) 15862337 GRILLE, SI WDO DEFG OTLT (COCOA) 25904030 PANEL, I/P UPR TR (INCLS 7-9) (EBONY) 25945703 PANEL, I/P UPR TR (INCLS 7-9) (COCOA) 11588650 CLIP, 12X14X16.6, GM4345M (ЧАСТЬ OF 6) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА] 25776637 FILLER, I/P FRT (ЧАСТЬ OF 6) (EBONY) 11509231 SCREW, RD HD C/R TAP, M4.2X1.41X13.0, GM6010M STL, GM813M NICKEL ORGANIC (ЧАСТЬ OF 6) [ВИНТ М6Х12] 15862312 PANEL, I/P LWR TR (INCLS 22, 23, 39, 53, 55, 56) (TITANIUM) 25919726 PANEL, I/P LWR TR (INCLS 22, 23, 39, 53, 55, 56) (EBONY) 25955201 PANEL, I/P LWR TR (INCLS 22, 23, 39, 53, 55, 56) (CASHMERE) 25910546 DEFLECTOR, I/P OTR AIR OTLT (EBONY) 25910547 DEFLECTOR, I/P OTR AIR OTLT (CASHMERE) 25910548 DEFLECTOR, I/P OTR AIR OTLT (TITANIUM) teamcadillac.ru 15862378 DEFLECTOR, I/P CTR AIR OTLT (EBONY) 15862379 DEFLECTOR, I/P CTR AIR OTLT (EBONY) not found CONTROL, AM/FM STEREO & CLK & CD PLYR RDO (СМ. ГРУППУ 10.000 "ПРИБОРНАЯ ПАНЕЛЬ CENTER CONTROL" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (EBONY) 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (RDO CONT) [ВИНТ М4] 25774623 RECEPTACLE, ACSRY PWR (ЧАСТЬ OF 18) (ACSRY PWR RECEPTACLE ASSEM LABELED 4623) [ГНЕЗДО ПРИКУРИВАТЕЛЯ С КОНТАКТН. ЭЛЕМЕНТ., 12 ВТ] 25793816 RETAINER, C/LTR RCPT (ЧАСТЬ OF 18) (EBONY) (INCLUDES CAP) (W/ALUMINUM RING) [СТОПОПОР] 25941152 COMPARTMENT, I/P CTR (INCLS 16, 17) (STAINLESS SILVER) [КРЫШКА ПРИБОРНОЙ ПАНЕЛИ] 11570587 БОЛТ, I/P CTR COMPT (D 30 X 1.12 X 10) (ATTACH ICS COMPT ASM TO IP LWR) 15861623 APPLIQUE, I/P TR PLT (INCLS 21) (SAPELE WOOD) (LHD PASS) [НАКЛАДКА] 25863860 APPLIQUE, I/P TR PLT (INCLS 21) (PYRAMID) (ORG FILM) (LHD PASS) 11570189 CLIP, I/P TR PLT APLQ (CLIP-PASS, FILM, LHD) (ЧАСТЬ OF 20) (10.240) 11570189 CLIP, I/P TR PLT APLQ (CLIP-PASS, WOOD, LHD) (ЧАСТЬ OF 20) (10.240) 11515638 ГАЙКА, U-TYPE, M4.2X1.41X10.5.5X22, .65-3.8 PNL THK, 1050, ZF (ЧАСТЬ OF 10) [ГАЙКА М4.2] 11517228 ГАЙКА, PANEL, M4.2X1.41, 8.5X11.9, 2.3-2.8 THICK PNL, FITS 11.2X9.2 HOLE 1050, 4250M (ЧАСТЬ OF 10) 01642528 SWITCH, I/P COMPT LP (ЧАСТЬ OF 38) 11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (ЧАСТЬ OF 38) [ВИНТ] not found DAMPENER, I/P COMPT DR (ЧАСТЬ OF 38) 11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (I/P COMPT) [ВИНТ] 25780207 SHELF, I/P COMPT (ЧАСТЬ OF 38) (REMOVABLE SHELF) 19115808 BULB, I/P COMPT LP (ЧАСТЬ OF 30, 38) (8.991) (ACDelco #19115808) 10359030 ЛАМПА, I/P COMPT (ЧАСТЬ OF 38) (INCLS 29) (11.927) 25919697 COVER, I/P COMPT DR LAT TR (LHD GLOVEBOX) (CASHMERE) 25945208 COVER, I/P COMPT DR LAT TR (LHD GLOVEBOX) (EBONY) 25945210 COVER, I/P COMPT DR LAT TR (TITANIUM) (LHD GLOVEBOX) not found DOOR, I/P COMPT (ЧАСТЬ OF 38) 20766965 CYLINDER KIT, I/P COMPT DR LK (UNCODED) 25900747 LATCH, I/P COMPT DR (ЧАСТЬ OF 38) (LHD GLOVEBOX) 20860361 BUMPER, I/P COMPT (ЧАСТЬ OF 38) 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (I/P COMPT) [ВИНТ М4] not found PIN, I/P COMPT HGE (ЧАСТЬ OF 38) 25918399 COMPARTMENT, I/P (W/ DOOR) (INCLS 24-26, 28-30, 32, 34, 35, 37) (EBONY) (LHD GLOVEBOX) 25918400 COMPARTMENT, I/P (W/ DOOR) (INCLS 24-26, 28-30, 32, 34, 35, 37) (CASHMERE) (LHD GLOVEBOX) 25972079 COMPARTMENT, I/P (W/ DOOR) (INCLS 24-26, 28-30, 32, 34, 35, 37) (TITANIUM) (LHD GLOVEBOX) 25972082 COMPARTMENT, I/P (W/ DOOR) (INCLS 24-26, 28-30, 32, 34, 35, 37) (TITANIUM) (LHD GLOVEBOX) 11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (ЧАСТЬ OF 10) [ШАЙБА] 15861621 APPLIQUE, I/P TR PLT (INCLS 52) (SAPELE WOOD) (LHD DRVR INBOARD) [НАКЛАДКА ПЕРЕДНЕЙ КОНСОЛИ САЛОНА] 25863858 APPLIQUE, I/P TR PLT (INCLS 52) (PYRAMID) (ORGINAL FILM, LEFT HAND DRIVER INBOARD) [ЭМБЛЕМА] 25861783 DEFLECTOR, I/P OTR AIR OTLT (СМ. ГРУППУ 10.000 "ПРИБОРНАЯ ПАНЕЛЬ ELECTRICAL" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (EBONY) 25861784 DEFLECTOR, I/P OTR AIR OTLT (СМ. ГРУППУ 10.000 "ПРИБОРНАЯ ПАНЕЛЬ ELECTRICAL" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (CASHMERE) 25861785 DEFLECTOR, I/P OTR AIR OTLT (СМ. ГРУППУ 10.000 "ПРИБОРНАЯ ПАНЕЛЬ ELECTRICAL" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (TITANIUM) 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (I/P DRVR KNEE BOLS) [ВИНТ М4] 25760081 ЛАМПА, CTSY (ЧАСТЬ OF 44, 47) (INCLS 71) (I/P INSULATOR) 25848855 INSULATOR, I/P (PASS SIDE HUSH PANEL) (INCLS 43, 71) (BLACK) 11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (I/P INSL) [ВИНТ] 11609370 БОЛТ-HWH, M4.2X1.41X20, HI - LOW THD, , OD 12, 6010 STL, GMW4205, TAP (I/P INSL) (9.667) 25885688 INSULATOR, I/P (DRVR SIDE HUSH PANEL) (INCLS 43, 71) (BLACK) (DRVR SI HUSH PNL) 25927771 INSULATOR, I/P (DRVR SIDE HUSH PANEL) (INCLS 43, 71) (BLACK) (DRVR SI HUSH PNL, AUTO BASE) 15862231 BOLSTER, I/P DRVR KNEE (INCLS 49, 50) (EBONY) 15862232 BOLSTER, I/P DRVR KNEE (INCLS 49, 50) (CASHMERE) 15862233 BOLSTER, I/P DRVR KNEE (KNEE BOLSTER-IP, LHD) (INCLS 49, 50) (TITANIUM) 11515638 ГАЙКА, U-TYPE, M4.2X1.41X10.5.5X22, .65-3.8 PNL THK, 1050, ZF (ЧАСТЬ OF 48) [ГАЙКА М4.2] 11588650 CLIP, 12X14X16.6, GM4345M (ЧАСТЬ OF 48) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА] 15897785 BOLSTER, I/P DRVR KNEE 11570189 CLIP, I/P TR PLT APLQ (CLIP-DRVR INBOARD FILM, LHD) (ЧАСТЬ OF 40) (10.240) 11570189 CLIP, I/P TR PLT APLQ (CLIP-DRVR INBOARD WOOD, LHD) (ЧАСТЬ OF 40) (10.240) 15250884 ШЛАНГИ, AIR INL (ЧАСТЬ OF 10) (EBONY) (ШЛАНГИ ONLY) 15862591 ШЛАНГИ, AIR INL (ЧАСТЬ OF 10) (CASHMERE) 15862592 ШЛАНГИ, AIR INL (ЧАСТЬ OF 10) (TITANIUM) 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (I/P LWR) [ВИНТ М4] 11516993 ГАЙКА, M4.2X1.41 (ЧАСТЬ OF 10) not found ШЛАНГИ, AIR INL (ЧАСТЬ OF 10) 11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (I/P LWR BRKT) [ВИНТ] 15861622 APPLIQUE, I/P TR PLT (INCLS 59) (SAPELE WOOD) (LHD DRVR OUTBOARD) [НАКЛАДКА ПЕРЕДНЕЙ КОНСОЛИ] 25863856 APPLIQUE, I/P TR PLT (ORIGINAL FILM, LEFT HAND DRIVER OUTBOARD) (INCLS 59) (PYRAMID) (ORG FILM) (LHD DRVR OUTBOARD) 11570189 CLIP, I/P TR PLT APLQ (CLIP-DRVR OUTBOARD FILM, LHD) (ЧАСТЬ OF 58) (10.240) 11570189 CLIP, I/P TR PLT APLQ (CLIP-DRVR OUTBOARD WOOD, LHD) (ЧАСТЬ OF 58) (10.240) 11509231 SCREW, RD HD C/R TAP, M4.2X1.41X13.0, GM6010M STL, GM813M NICKEL ORGANIC (I/P UPR) [ВИНТ М6Х12] 15862580 PANEL, I/P SI TR (I/P END CAP) (INCLS 62) (EBONY) 15862581 PANEL, I/P SI TR (I/P END CAP) (INCLS 62) (EBONY) 15862582 PANEL, I/P SI TR (I/P END CAP) (INCLS 62) (CASHMERE) [ПАНЕЛЬ] 15862583 PANEL, I/P SI TR (I/P END CAP) (INCLS 62) (CASHMERE) 15862584 PANEL, I/P SI TR (I/P END CAP) (INCLS 62) (TITANIUM) 15862585 PANEL, I/P SI TR (I/P END CAP) (INCLS 62) (TITANIUM) 11588650 CLIP, 12X14X16.6, GM4345M (ЧАСТЬ OF 61) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА] 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (I/P LWR) [БОЛТ М6] 11588650 CLIP, 12X14X16.6, GM4345M (ЧАСТЬ OF 65) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА] 25934790 GRILLE, W/S DEFR NOZ (INCLS 64) (СМ. ГРУППУ 10.000 "ПРИБОРНАЯ ПАНЕЛЬ ELECTRICAL" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (EBONY) 25934791 GRILLE, W/S DEFR NOZ (INCLS 64) (СМ. ГРУППУ 10.000 "ПРИБОРНАЯ ПАНЕЛЬ ELECTRICAL" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (COCOA) 25774575 SEAL, I/P TR PAD 11516140 LIGHTER, CIG (BLACK) (W/LARGE, PLASTIC KNOB END 21.0MM) [ПРИКУРИВАТЕЛЬ] 11516141 LIGHTER, CIG (BLACK) (W/SMALL, PLASTIC KNOB END 14.0MM) [ПРИКУРИВАТЕЛЬ] 25776667 RECEPTACLE, C/LTR (2 TERMINALS) [ГНЕЗДО ПРИКУРИВАТЕЛЯ С КОНТАКТН. ЭЛЕМЕНТ., 12 ВТ] 25749635 RETAINER, C/LTR RCPT (EBONY) (W/O CAP) [ВТУЛКА ГНЕЗДА ПРИКУРИВАТЕЛЯ] 25857935 ПЕПЕЛЬНИЦА, I/P (ПЕПЕЛЬНИЦА BIN) 19115807 BULB, I/P C/LP (ЧАСТЬ OF 43, 44, 47) (8.991) (ACDelco #19115807) (6D10-065) - 2008 DM69 ПРИБОРНАЯ ПАНЕЛЬ ЧАСТЬ 2 ELECTRICAL ↓ 25934790 GRILLE, W/S DEFR NOZ (INCLS 2, 3, 5) (EBONY) 25934791 GRILLE, W/S DEFR NOZ (INCLS 2, 3, 5) (COCOA) 25713063 SENSOR, HDLP AUTO CONT AMB LGT (ЧАСТЬ OF 1) (DUAL SOLAR & TWILIGHT) [ДАТЧИК ОСВЕЩЕННОСТИ ДЛЯ АВТОМАТИЧ.ВКЛЮЧ.ГАБАРИТОВ] 25879548 HARNESS, I/P WRG HARN EXTN (ЧАСТЬ OF 1) (FOR SOLAR SENSOR) not found COVER, NAVN INFO DISPLAY OPG (СМ. ГРУППУ 10.000 "ПРИБОРНАЯ ПАНЕЛЬ CENTER CONTROL" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 15862570 COVER, NAVN INFO DISPLAY OPG (СМ. ГРУППУ 10.000 "ПРИБОРНАЯ ПАНЕЛЬ CENTER CONTROL" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (EBONY) 15862571 COVER, NAVN INFO DISPLAY OPG (СМ. ГРУППУ 10.000 "ПРИБОРНАЯ ПАНЕЛЬ CENTER CONTROL" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (CASHMERE) 11588650 CLIP, 12X14X16.6, GM4345M (ЧАСТЬ OF 1) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА] not found PANEL, INST (СМ. ГРУППУ 10.000 "ПРИБОРНАЯ ПАНЕЛЬ TRIM" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25955352 ЛАМПА, I/P FLOOD [СВЕТОДИОД ПОДСВЕТКИ ВЕЩЕВОГО ЯЩИКА] 15861623 APPLIQUE, I/P TR PLT (СМ. ГРУППУ 10.000 "ПРИБОРНАЯ ПАНЕЛЬ TRIM" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (SAPELE WOOD) (LHD PASS) [НАКЛАДКА] 25863860 APPLIQUE, I/P TR PLT (СМ. ГРУППУ 10.000 "ПРИБОРНАЯ ПАНЕЛЬ TRIM" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (PYRAMID) (ORG FILM) (LHD PASS) teamcadillac.ru 15902864 BRACKET, PEDESTRIAN IMP DETECTION MDL (INCLS 10) 11610157 ГАЙКА, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (ЧАСТЬ OF 9) (10.701) [ГАЙКА М4] 11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (PEDESTRIAN IMP DETECTION MDL BRKT) [ВИНТ] 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (PEDESTRIAN IMP DETECTION MDL) [БОЛТ М6] not found LABEL, PEDESTRIAN IMP DETECTION MDL CAUTION (ЧАСТЬ OF 14) 15940808 LABEL, PEDESTRIAN IMP DETECTION MDL CAUTION (ЧАСТЬ OF 14) 25916158 МОДУЛЬ, PEDESTRIAN IMPACT DETECTION (INCLS 13) (LABELED 25916158) 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (PEDESTRIAN IMP DETECTION MDL) [ВИНТ М4] 11610157 ГАЙКА, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (PEDESTRIAN IMP DETECTION MDL BRKT) (10.701) [ГАЙКА М4] not found МОДУЛЬ, TRFER CASE SHFT CONT 24244602 МОДУЛЬ, TRFER CASE SHFT CONT [МОДУЛЬ] 15855916 ЛАМПА, CTSY 25848855 INSULATOR, I/P (PASS SIDE HUSH PANEL) (СМ. ГРУППУ 10.000 "ПРИБОРНАЯ ПАНЕЛЬ TRIM" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (BLACK) 15868878 SWITCH, I/P LP DIMR (ЧАСТЬ OF 21) (ACDelco #D1592H) 25861783 DEFLECTOR, I/P OTR AIR OTLT (INCLS 20, 23, 24) (EBONY) 25861784 DEFLECTOR, I/P OTR AIR OTLT (INCLS 20, 23, 24) (CASHMERE) 25861785 DEFLECTOR, I/P OTR AIR OTLT (INCLS 20, 23, 24) (TITANIUM) 25864154 ЛАМПА, I/P FLOOD (DRIVER SIDE O/B PIPE LIGHT) [ЛАМПА] 11588650 CLIP, 12X14X16.6, GM4345M (ЧАСТЬ OF 21) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА] 15882574 SWITCH, DRVR INFO DISPLAY (ЧАСТЬ OF 21) 11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (INST CARR) [ВИНТ] 25885688 INSULATOR, I/P (СМ. ГРУППУ 10.000 "ПРИБОРНАЯ ПАНЕЛЬ TRIM" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (BLACK) (DRVR SI HUSH PNL) 25927771 INSULATOR, I/P (СМ. ГРУППУ 10.000 "ПРИБОРНАЯ ПАНЕЛЬ TRIM" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (BLACK) (DRVR SI HUSH PNL, AUTO BASE) not found HARNESS, I/P WRG (СМ. ГРУППУ 02.000 "HARNESS/ПРИБОРНАЯ ПАНЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11516993 ГАЙКА, M4.2X1.41 (I/P) not found CLUSTER, INST 20801267 CLUSTER, INST (ACDelco #20801267) 25860695 CLUSTER, INST (LABELED 25860695) (ACDelco #25860695) 25860697 CLUSTER, INST (LABELED 25860697) (ACDelco #25860697) 25963822 CLUSTER, INST (LABELED 25963822) (LABELED 25963822) (ACDelco #25963822) 25963823 CLUSTER, INST (LABELED 25963823) (ACDelco #25963823) 25963825 CLUSTER, INST (LABELED 25963825) (ACDelco #25963825) [ЩИТОК ПРИБОРОВ] 25993284 CLUSTER, INST (LABELED 25993284) (ACDelco #25993284) [ПРИБОРНАЯ ПАНЕЛЬ] 25993285 CLUSTER, INST (LABELED 25993285) (ACDelco #25993285) 25993286 CLUSTER, INST (LABELED 25993286) (ACDelco #25993286) 15921352 МОДУЛЬ, BODY CONT (REQUIRES PROGRAMMING) (LABELED 15921352) (ACDelco #15921352) 15921352 МОДУЛЬ, BODY CONT (REQUIRES PROGRAMMING) (LABELED 15921352) (2.560) (ACDelco #15921352) 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (INST CSTR) [ВИНТ М4] 15862527 COVER, I/P CSTR TR PLT (EBONY) 25945705 COVER, I/P CSTR TR PLT (COCOA) 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (I/P CSTR TR PLT) [ВИНТ М4] 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (BCM BRKT) [БОЛТ М6] 15819564 BRACKET, BCM 11610157 ГАЙКА, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (RDO FRT SPKR) (10.701) [ГАЙКА М4] 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (RDO FRT SPKR) [ВИНТ М4] not found SPEAKER, RDO FRT 15122573 SPEAKER, RDO FRT (ACDelco #15122573) [ДИНАМИК 30ВТ] 15278540 SPEAKER, RDO FRT (ACDelco #15278540) [ДИНАМИК] not found SPEAKER, RDO FRT CTR 15122573 SPEAKER, RDO FRT CTR (9.650) (ACDelco #15122573) [ДИНАМИК 30ВТ] not found БОЛТ, I/P INFL RST MDL 11561388 БОЛТ, I/P INFL RST MDL (M6X1X20, 11 THD, 17 OD) (8.900) not found АНТЕННА, ELEK NAVIGATION 15226445 АНТЕННА, ELEK NAVIGATION (ACDelco #15226445) not found ГАЙКА, INFL RST I/P MDL 11609411 ГАЙКА, INFL RST I/P MDL (PSIR МОДУЛЬ TO I/P RETAINER) (6 X 1, 5.07THK) (HEX-CHROME FREE FINISH) (8.917) [ГАЙКА М6] 15685170 ГАЙКА, INFL RST I/P MDL (PSIR МОДУЛЬ TO I/P RETAINER) (M6X1.0, 19.0MM OD) (8.917) 15237186 МОДУЛЬ, I/P INFL RST [МОДУЛЬ] 11509231 SCREW, RD HD C/R TAP, M4.2X1.41X13.0, GM6010M STL, GM813M NICKEL ORGANIC (HTR & КОНДИЦИОНЕР CONT) [ВИНТ М6Х12] 25865683 CONTROL, HTR & КОНДИЦИОНЕР (МОДУЛЬ ONLY) (ACDelco #15-73868) [МОДУЛЬ] (6D10-066) - 2008 DM69 ПРИБОРНАЯ ПАНЕЛЬ ЧАСТЬ 3 STRUCTURE ↓ 25795381 BRACKET, INST CARR (FOD) 11517792 ГАЙКА, HEX W/FL WA, M8X1.25, 10.75 THK, 24 OD, 10, 7111M (I/P CARR BRKT) teamcadillac.ru 11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (INST CARR BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16] 11609540 БОЛТ, HWASH, M6X1X20, 16.15 THD, 17 OD, 8.8, GMW4205, HDR PT. (ЧАСТЬ OF 6) [ВИНТ] 11516594 БОЛТ-HEX, M8X1.25X30, 22THD, 24MM O.D., 9.8, 7114M (INST CARR) 25862315 КРОНШТЕЙН, INST (INCLS 4, 7, 9, 15, 16, 18, 19, 21-23) (LHD) not found BRACKET, I/P PASS KNEE BOLS (ЧАСТЬ OF 6) 11516149 ГАЙКА, U, 8X1.25, MULTI THD, .08'-4.0' THK PNL, PZ (I/P CARR) [ГАЙКА М8] 22717573 NUT - PUSH-IN MULTI THR, M6X1.0, SAE 1050-1065, ZO (ЧАСТЬ OF 6) 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (INST CARR BRKT) [БОЛТ М6] 25795382 BRACKET, I/P CARR (TO TUNNEL ATTACH, RWD) 11519388 БОЛТ, HX HD CON WA, M8X1.25X25, 20 THD, 24 OD, 8.8, GMW3359 (SILVER), M-POINT (INST CARR BRKT) [БОЛТ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (STRG COL SUPT BRKT) [ГАЙКА] 15836476 BRACKET, STRG COL SUPT 11609540 БОЛТ, HWASH, M6X1X20, 16.15 THD, 17 OD, 8.8, GMW4205, HDR PT. (ЧАСТЬ OF 6) [ВИНТ] not found BRACKET, I/P DRVR KNEE BOLS (ЧАСТЬ OF 6) 11517792 ГАЙКА, HEX W/FL WA, M8X1.25, 10.75 THK, 24 OD, 10, 7111M (I/P CARR) 22717573 NUT - PUSH-IN MULTI THR, M6X1.0, SAE 1050-1065, ZO (ЧАСТЬ OF 6) 11515638 ГАЙКА, U-TYPE, M4.2X1.41X10.5.5X22, .65-3.8 PNL THK, 1050, ZF (ЧАСТЬ OF 6) [ГАЙКА М4.2] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (I/P STRG COL OPG SUPT) [ГАЙКА] 11516819 NUT-STAMPED M10 X 1.5 (ЧАСТЬ OF 6) 11609875 STUD-FLANGE, M10X1.5X12.5, M10X1.5X29, 18 OD, 9.8, GMW3044, HDR-PT (ЧАСТЬ OF 6) (8.981) 25795380 BRACKET, I/P CARR OTR (6D10-067) - 2008-2009 DM69 КОНСОЛЬ/ПОЛ ↓ 25887053 PLATE, F/FLR CNSL TRANS SHFT OPG TR (INCLS 2, 3, 65) 25887055 PLATE, F/FLR CNSL TRANS SHFT OPG TR (INCLS 2, 3, 65) [РАМКА РЫЧАГА ПЕРЕКЛЮЧЕНИЯ ПЕРЕДАЧ] 11509231 SCREW, RD HD C/R TAP, M4.2X1.41X13.0, GM6010M STL, GM813M NICKEL ORGANIC (ЧАСТЬ OF 1) [ВИНТ М6Х12] 25905699 PLATE, F/FLR CNSL TR (SILVER) (W/CLIPS) (*KIT2) [ОКАНТОВКА ПАНЕЛИ НАПОЛЬНОЙ КОНСОЛИ] 25862930 RETAINER, F/FLR CNSL COMPT DR LAT (PUSH ON) (LWR A/RST LATCH) (ЧАСТЬ OF 13) (*KIT3) 25903344 LATCH, F/FLR COMPT DR (LWR A/RST LATCH) (ЧАСТЬ OF 13) (*KIT3) 25903345 ПРУЖИНА, F/FLR FRT CNSL COMPT DR (LWR) (ЧАСТЬ OF 13) (*KIT3) 11509231 SCREW, RD HD C/R TAP, M4.2X1.41X13.0, GM6010M STL, GM813M NICKEL ORGANIC (ЧАСТЬ OF 13) [ВИНТ М6Х12] 11509231 SCREW, RD HD C/R TAP, M4.2X1.41X13.0, GM6010M STL, GM813M NICKEL ORGANIC (ЧАСТЬ OF 13) [ВИНТ М6Х12] not found TRAY, F/FLR CNSL STOR (ЧАСТЬ OF 13) teamcadillac.ru 25862928 LATCH, F/FLR CNSL A/RST (UPR) (ЧАСТЬ OF 13) (UPR) [РУЧКА КРЫШКИ ЛОТКА НАПОЛЬНОЙ КОНСОЛИ] 10215230 BUMPER, F/FLR CNSL COMPT DR (ЧАСТЬ OF 13) (APPROX LENGTH 15.8M) (10.565) 25903337 ARMREST, F/FLR CNSL (INCLS 5-12, 14, 15, 17-19) (CASHMERE) 25903339 ARMREST, F/FLR CNSL (INCLS 5-12, 14, 15, 17-19) (EBONY) 25903342 ARMREST, F/FLR CNSL (INCLS 5-12, 14, 15, 17-19) (TITANIUM) 25903342 ARMREST, F/FLR CNSL (INCLS 5-12, 14, 15, 17-19) (TITANIUM) not found TRAY, F/FLR CNSL STOR (ЧАСТЬ OF 13) 11570189 CLIP, F/FLR CNSL A/RST (ARMREST BIN TO LOWER RET) (ЧАСТЬ OF 13) 11516421 БОЛТ, HFH, M6X1X10, 14.2 O.D., 9.8, 7114M (F/FLR CNSL A/RST HGE) 20786772 COVER, F/FLR CNSL A/RST HGE (ЧАСТЬ OF 13) (CASHMERE) 20786773 COVER, F/FLR CNSL A/RST HGE (ЧАСТЬ OF 13) (EBONY) 25923328 COVER, F/FLR CNSL A/RST HGE (ЧАСТЬ OF 13) (SILVER) 15951262 HINGE, F/FLR CNSL COMPT DR (ЧАСТЬ OF 13) (BLACK) not found ARMREST, F/FLR CNSL (ЧАСТЬ OF 13) 11570189 CLIP, F/FLR CNSL TR PLT (TR PLT TO COMPT BIN) (*KIT2) 25886155 BRACKET, IGN LK KEY XMTR ANT (XLR/XLR-V) (EASY KEY SYSTEM-R/CMPT BRACKET) (6D10-068) - 2008 DM69 АРМАТУРА ПЕРЕДНЕЙ ДВЕРИ ЧАСТЬ 1 ↓ 25820200 WEATHERSTRIP, FRT S/D (BODY SI) (TITANIUM) [УПЛОТНЕНИЕ] 25820201 WEATHERSTRIP, FRT S/D (BODY SI) (TITANIUM) [УПЛОТНЕНИЕ] 25820202 WEATHERSTRIP, FRT S/D (BODY SI) (CASHMERE) [НАЩЕЛЬНИК] 25820203 WEATHERSTRIP, FRT S/D (BODY SI) (CASHMERE) [УПЛОТНЕНИЕ] 25820204 WEATHERSTRIP, FRT S/D (BODY SI) (EBONY) [ДАТЧИК] 25820205 WEATHERSTRIP, FRT S/D (BODY SI) (EBONY) [УПЛОТНЕНИЕ] 25863993 STRIKER, FRT S/D LK 11518445 SCREW, FLAT-HD HEX ALLEN, CSINK, M8X1.25X25, 18.05 THD, 14.7 OD, 8.8, GMW3044. (FRT S/D LK STKR) [БОЛТ М8Х1.25] 12789058 COVER, FRT S/D LK STKR 20805481 WEATHERSTRIP, FRT S/D (DOOR SI) 20805482 WEATHERSTRIP, FRT S/D (DOOR SI) 10369132 WEATHERSTRIP, FRT S/D LWR AUX 10369133 WEATHERSTRIP, FRT S/D LWR AUX 15880690 DOOR, FRT SI (СМ. ГРУППУ 12.000 "КУЗОВНЫЕ ДЕТАЛИ/ BODYSIDE" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ДВЕРЬ] 15880691 DOOR, FRT SI (СМ. ГРУППУ 12.000 "КУЗОВНЫЕ ДЕТАЛИ/ BODYSIDE" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ДВЕРЬ] 25944114 APPLIQUE, FRT S/D WDO FRM RR (NON-GRAINED) (FOR 2ND DES SEE 25955037) [НАКЛАДКА ПАНЕЛИ ДВЕРИ] 25944115 APPLIQUE, FRT S/D WDO FRM RR (NON GRAINED; BUILT BEFORE 9/24/07) (FOR 3RD DES SEE 25955038) [НАКЛАДКА ПАНЕЛИ ДВЕРИ] 25955037 APPLIQUE, FRT S/D WDO FRM RR (GRAINED) (FOR 1ST DES SEE 25944114) [МОЛДИНГ КУЗОВА] 25955038 APPLIQUE, FRT S/D WDO FRM RR (GRAINED; BUILT/AFTER 9/24/07) (FOR 2ND DES SEE 25944115) [НАКЛАДКА ПАНЕЛИ ДВЕРИ] 11509231 SCREW, RD HD C/R TAP, M4.2X1.41X13.0, GM6010M STL, GM813M NICKEL ORGANIC (FRT S/D WDO BELT R/MLDG) [ВИНТ М6Х12] 25909260 MOLDING, FRT S/D WDO BELT RVL [МОЛДИНГ КРЫШИ] 25909261 MOLDING, FRT S/D WDO BELT RVL [МОЛДИНГ КУЗОВА] 25864467 LEVER KIT, FRT S/D O/S HDL (СМ. ГРУППУ 10.000 "DOOR АРМАТУРА/ SIDE FRONT" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (КРАСКА TO MATCH) (E-Z KEY PASSIVE REMOTE) (W/CONNECTOR) [РУЧКА ДВЕРИ] 25864468 LEVER KIT, FRT S/D O/S HDL (СМ. ГРУППУ 10.000 "DOOR АРМАТУРА/ SIDE FRONT" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (КРАСКА TO MATCH) (UPLEVEL) (W/CONNECTOR)) [РУЧКА ДВЕРИ] 25864469 LEVER KIT, FRT S/D O/S HDL (СМ. ГРУППУ 10.000 "DOOR АРМАТУРА/ SIDE FRONT" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (BLACK) (BASE) (W/O CONNECTOR) 25864470 LEVER KIT, FRT S/D O/S HDL (СМ. ГРУППУ 10.000 "DOOR АРМАТУРА/ SIDE FRONT" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (BLACK) (BASE) (W/O CONNECTOR) not found WEATHERSTRIP, FRT S/D FRT AUX 10369134 WEATHERSTRIP, FRT S/D FRT AUX [МОЛДИНГ] 10369135 WEATHERSTRIP, FRT S/D FRT AUX [МОЛДНИГ] 25891058 MOLDING, BODY SI WDO RVL (INCLS 14) 25891059 MOLDING, BODY SI WDO RVL (INCLS 14) not found RETAINER, C/PLR UPR FIN MLDG (ЧАСТЬ OF 13) 25796285 RETAINER, C/PLR UPR FIN MLDG (ЧАСТЬ OF 13) [ФИКСАТОР МОЛДИНГА КУЗОВА] 20828785 SEALING STRIP, FRT S/D WDO INR 25887366 SEALING STRIP, FRT S/D WDO INR 10369139 WEATHERSTRIP, FRT S/D WDO (USED ON VEHICLES BUILT PRIOR TO SEPT 14, 2007) (FOR 2ND DES SEE 20810952) 20810952 WEATHERSTRIP, FRT S/D WDO (USED ON VEHICLES BUILT ON/AFTER SEPT 14, 20078) (FOR 1ST DES SEE 10369139) 20810953 WEATHERSTRIP, FRT S/D WDO 15932610 HINGE, FRT S/D UPR (10.454) 15932611 HINGE, FRT S/D UPR (10.454) 11609222 БОЛТ, HEX HD, W/FL WA, M9X1.25X35, 24 O.D., 6202M, 7114M (FRT S/D HGE (BODY SI)) 11610041 БОЛТ, HFH W/SHLDR, M8X1.25X25, 12.55 THD, 21 OD, 10.9 (FRT S/D UPR HGE (DR SI)) [БОЛТ] 11508277 ГАЙКА, HEX W/CON WA M6X1 THD, OD-19 PEOR 9 (FRT S/D CHK LINK (DR SI)) [ГАЙКА М6] 11610041 БОЛТ, HFH W/SHLDR, M8X1.25X25, 12.55 THD, 21 OD, 10.9 (FRT S/D LWR HGE (DR SI)) [БОЛТ] 15932610 HINGE, FRT S/D LWR 15932611 HINGE, FRT S/D LWR teamcadillac.ru 11569646 БОЛТ, FRT S/D CHK LINK (BODY SI) 15269871 LINK, FRT S/D CHK [РЫЧАГ В СБОРЕ] (6D10-069) - 2008 DM69 АРМАТУРА ПЕРЕДНЕЙ ДВЕРИ ЧАСТЬ 2 ↓ 15242616 WINDOW, FRT S/D [СТЕКЛО ПЕРЕДНЕЙ ДВЕРИ] 15242617 WINDOW, FRT S/D [СТЕКЛО ДВЕРИ] 11570209 STUD, ELEK SYS PWR SPLY MDL BRKT 22709067 DEADENER, FRT S/D (200X305) (12.810) 25757810 DEADENER, FRT S/D (390X150) (W/O HOLE) (RECTANGULAR IN SHAPE) (12.980) 25785810 BRACKET, ELEK SYS PWR SPLY MDL 25785811 BRACKET, ELEK SYS PWR SPLY MDL 11589303 БОЛТ-HFH, M6X1X38, 30 THD, 14.2 OD, 8.8 STL, GMW3359, M-PT (FRT S/D LK CVR) 25688849 RETAINER, FRT S/D O/S HDL (PUSH IN) (2.343) not found ГАЙКА, FRT S/D LK CVR (ЧАСТЬ OF 22) 11517068 NUT-METRIC HEX FLABGE, M6X1, 10MM SOCKET (FRT S/D LK CVR) 11519381 БОЛТ, WASHER M6X1X15, 5.75 THD, 17 OD, 8.8, GMW3359, M-POINT, 1.65 CON SPRWA (FRT S/D WDO REG) not found БОЛТ, FRT S/D WDO (ЧАСТЬ OF 17) not found RETAINER, FRT S/D WDO (ЧАСТЬ OF 17) not found БОЛТ, FRT S/D WDO REG MOT (ЧАСТЬ OF 17) not found MOTOR, FRT S/D WDO REG (ЧАСТЬ OF 17) 19116955 GROMMET, FRT S/D DR WRG HARN (ЧАСТЬ OF 15) 25895413 HARNESS, FRT S/D DR WRG (INCLS 14) 25895414 HARNESS, FRT S/D DR WRG (INCLS 14) 25895415 HARNESS, FRT S/D DR WRG (INCLS 14) 25895416 HARNESS, FRT S/D DR WRG (INCLS 14) 25895417 HARNESS, FRT S/D DR WRG (INCLS 14) 25895418 HARNESS, FRT S/D DR WRG (INCLS 14) 25895419 HARNESS, FRT S/D DR WRG (INCLS 14) 25895420 HARNESS, FRT S/D DR WRG (INCLS 14) 15874084 CHANNEL, FRT S/D WDO RR LWR 20849250 REGULATOR, FRT S/D WDO (INCLS 10-13) (10.783) (ACDelco #20849250) 20849250 REGULATOR, FRT S/D WDO (INCLS 10-13) (ACDelco #20849250) 25949774 REGULATOR, FRT S/D WDO (INCLS 10-13) (10.783) [ЭЛЕКТРОДВИГАТЕЛЬ СТЕКЛОПОДЪЕМНИКА 80ВТ] 25949774 REGULATOR, FRT S/D WDO (INCLS 10-13) [ЭЛЕКТРОДВИГАТЕЛЬ СТЕКЛОПОДЪЕМНИКА 80ВТ] not found CABLE, FRT S/D I/S HDL (ЧАСТЬ OF 19) 19210210 LOCK, FRT S/D (INCLS 18, 20) 19210211 LOCK, FRT S/D (INCLS 18, 20) 25831219 LOCK, FRT S/D (INCLS 18, 20) teamcadillac.ru 25831220 LOCK, FRT S/D (INCLS 18, 20) not found CLIP, FRT S/D LKG ROD (ЧАСТЬ OF 19) 15269119 ROD, FRT S/D LK CYL not found COVER, FRT S/D LK (INCLS 7) 15269130 COVER, FRT S/D LK (INCLS 7) 11508277 ГАЙКА, HEX W/CON WA M6X1 THD, OD-19 PEOR 9 (FRT S/D WDO RR CHAN LWR BRKT) [ГАЙКА М6] 25652432 PLUG, FRT S/D INR PNL HOLE (35MM DIA) (FITS 25MM HOLE) (ROUND) (12.934) 11609341 SCREW, RD WA HD 6-LOBE M6X1X19 (FRT S/D LK) [ВИНТ] 15259076 PLUG, FRT S/D INR PNL HOLE (6.35MM) (ROUND) (10.571) 25676040 PLUG, FRT S/D ACC HOLE (25MM OD) (12.809) 11518446 SCREW-RD WA HD, M6X1X19, 16.38 OD, 12 THD, 10.9, 6138M. (FRT S/D LK CVR) 11509262 WASHER, FL 6.8X25.40X2.30 STL PEOR (FRT S/D LK CVR) not found CAP, FRT S/D LK CYL (*KIT1) not found SEAL, FRT S/D O/S HDL (ЧАСТЬ OF 35) not found CLIP, FRT S/D LKG ROD (ЧАСТЬ OF 33) 15800058 CYLINDER KIT, FRT S/D LK (UNCODED) (INLCS 32) (СМ. ГРУППУ 10.000 "ЦИЛИНДР ЗАМКА ДВЕРИ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ЦИЛИНДР] 20766969 CYLINDER KIT, FRT S/D LK (UNCODED) (INLCS 32) (СМ. ГРУППУ 10.000 "ЦИЛИНДР ЗАМКА ДВЕРИ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found CLIP, FRT S/D LK REL LVR LKG ROD (ЧАСТЬ OF 35) 25864471 ШЛАНГИ KIT, FRT S/D O/S HDL (INCLS 31, 34, 36, 37) (UPLEVEL) (W/2 CONNECTORS) [ОПОРА РУЧКИ ДВЕРИ] 25864472 ШЛАНГИ KIT, FRT S/D O/S HDL (INCLS 31, 34, 36, 37) (UPLEVEL) (W/2 CONNECTORS) [КРОНШТЕЙН РУЧКИ ДВЕРИ] 25864473 ШЛАНГИ KIT, FRT S/D O/S HDL (INCLS 31, 34, 36, 37) (BASE) (W/1 CONNECTOR) [ЖГУТ ПРОВОДОВ] 25864474 ШЛАНГИ KIT, FRT S/D O/S HDL (INCLS 31, 34, 36, 37) (BASE) (W/1 CONNECTOR) [ЖГУТ ПРОВОДОВ] not found RETAINER, FRT S/D LK CYL (ЧАСТЬ OF 35) not found SEAL, FRT S/D O/S HDL (ЧАСТЬ OF 35) not found LEVER, FRT S/D O/S HDL (*KIT1) 15880690 DOOR, FRT SI (СМ. ГРУППУ 12.000 "КУЗОВНЫЕ ДЕТАЛИSIDE" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ДВЕРЬ] 15880691 DOOR, FRT SI (СМ. ГРУППУ 12.000 "КУЗОВНЫЕ ДЕТАЛИSIDE" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ДВЕРЬ] 15207033 REFLECTOR, FRT S/D WRNG (16.165) [ОТРАЖАТЕЛЬ] 25864467 LEVER KIT, FRT S/D O/S HDL (INCLS 30, 38) (КРАСКА TO MATCH) (E-Z KEY PASSIVE REMOTE) (W/CONNECTOR) [РУЧКА ДВЕРИ] 25864468 LEVER KIT, FRT S/D O/S HDL (INCLS 30, 38) (КРАСКА TO MATCH) (UPLEVEL) (W/CONNECTOR)) [РУЧКА ДВЕРИ] 25864469 LEVER KIT, FRT S/D O/S HDL (INCLS 30, 38) (BLACK) (BASE) (W/O CONNECTOR) 25864470 LEVER KIT, FRT S/D O/S HDL (INCLS 30, 38) (BLACK) (BASE) (W/O CONNECTOR) (6D10-070) - 2008 DM69 АРМАТУРА ЗАДНЕЙ ДВЕРИ ЧАСТЬ 1 ↓ 12789058 COVER, RR S/D LK STKR (10.569) 11518445 SCREW, FLAT-HD HEX ALLEN, CSINK, M8X1.25X25, 18.05 THD, 14.7 OD, 8.8, GMW3044. (RR S/D LK STKR) [БОЛТ М8Х1.25] 25863993 STRIKER, RR S/D LK 25820230 WEATHERSTRIP, RR S/D (BODY SI) (TITANIUM) [УПЛОТНЕНИЕ] 25820231 WEATHERSTRIP, RR S/D (BODY SI) (TITANIUM) [УПЛОТНЕНИЕ] 25820232 WEATHERSTRIP, RR S/D (BODY SI) (CASHMERE) [УПЛОТНЕНИЕ] 25820233 WEATHERSTRIP, RR S/D (BODY SI) (CASHMERE) [УПЛОТНЕНИЕ] 25820234 WEATHERSTRIP, RR S/D (BODY SI) (EBONY) [УПЛОТНЕНИЕ] 25820235 WEATHERSTRIP, RR S/D (BODY SI) (EBONY) [ДАТЧИК] 20805483 WEATHERSTRIP, RR S/D (DOOR SI) teamcadillac.ru 25937005 WEATHERSTRIP, RR S/D (DOOR SI) 10369148 SEALING STRIP, RR S/D WDO INR [УПЛОТНЕНИЕ] 10369149 SEALING STRIP, RR S/D WDO INR [УПЛОТНЕНИЕ] 25944116 APPLIQUE, RR S/D WDO FRM RR (NON-GRAINED APPLIQUE) (FOR 2ND DES SEE 25955039) 25944117 APPLIQUE, RR S/D WDO FRM RR (NON-GRAINED APPLIQUE) (FOR 2ND DES SEE 25955040) [НАКЛАДКА ПАНЕЛИ ДВЕРИ] 25955039 APPLIQUE, RR S/D WDO FRM RR (GRAINED APPLIQUE) (FOR 1ST DES SEE 25944116) [НАКЛАДКА ПАНЕЛИ ДВЕРИ] 25955040 APPLIQUE, RR S/D WDO FRM RR (GRAINED APPLIQUE) (FOR 1ST DES SEE 25944117) [САМОКЛЕЯЩАЯСЯ ДЕКОРАТИВНАЯ ПЛЕНКА ПАНЕЛИ ДВЕРИ] 25886851 MOLDING, RR S/D WDO BELT RVL (WITHOUT NOTCH AT OUTER BELT) (IF USING TO REPLACE MOLDING ASM 25843096 (W/O NOTCH @ OTR BELT), MAY REQUIRE TO ORDER T/W 25886852 FOR CUSTOMER APPEARANCE SATISFACTION) [МОЛДИНГ СТЕКЛА ДВЕРИ] 25886852 MOLDING, RR S/D WDO BELT RVL (WITHOUT NOTCH @ OUTER BELT) (IF USING TO REPLACE MOLDING ASM 25843097 (INCLS NOTCH @ OTR BELT), MAY REQUIRE TO ORDER T/W 25886851 FOR CUSTOMER APPEARANCE SATISFACTION) 19121209 LEVER KIT, RR S/D O/S HDL (СМ. ГРУППУ "10.000" DOOR АРМАТУРА/ ЗАДНИЙ ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (КРАСКА TO MATCH) (INCLS LEVER & CAP) (W/O CHROME INSERTS) 25864469 LEVER KIT, RR S/D O/S HDL (СМ. ГРУППУ "10.000" DOOR АРМАТУРА/ ЗАДНИЙ ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (BLACK) (BASE) (W/O CONNECTOR) 25864470 LEVER KIT, RR S/D O/S HDL (СМ. ГРУППУ "10.000" DOOR АРМАТУРА/ ЗАДНИЙ ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (BLACK) (BASE) (W/O CONNECTOR) 25864475 LEVER KIT, RR S/D O/S HDL (СМ. ГРУППУ "10.000" DOOR АРМАТУРА/ ЗАДНИЙ ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (КРАСКА TO MATCH) (INCLS LEVER & CAP) (W/O CHROME INSERTS) [КОМПЛЕКТ РЫЧАГОВ] 15880692 DOOR, RR SI (СМ. ГРУППУ 12.000 "КУЗОВНЫЕ ДЕТАЛИSIDE" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ДВЕРЬ] 15880693 DOOR, RR SI (СМ. ГРУППУ 12.000 "КУЗОВНЫЕ ДЕТАЛИSIDE" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ДВЕРЬ] 25948404 WEATHERSTRIP, RR S/D LWR 25948405 WEATHERSTRIP, RR S/D LWR 11509231 SCREW, RD HD C/R TAP, M4.2X1.41X13.0, GM6010M STL, GM813M NICKEL ORGANIC (RR S/D WDO BELT R/MLDG) [ВИНТ М6Х12] 15932618 HINGE, RR S/D UPR [ПЕТЛЯ] 15932619 HINGE, RR S/D UPR [ПЕТЛЯ] 11610041 БОЛТ, HFH W/SHLDR, M8X1.25X25, 12.55 THD, 21 OD, 10.9 (RR S/D UPR HGE (DR SI)) [БОЛТ] 11561763 SCREW M8X1.25X30, GMW3359 (RR S/D UPR HGE (BODY SI)) 11508277 ГАЙКА, HEX W/CON WA M6X1 THD, OD-19 PEOR 9 (RR S/D CHK LINK DR SI) [ГАЙКА М6] 11610041 БОЛТ, HFH W/SHLDR, M8X1.25X25, 12.55 THD, 21 OD, 10.9 (RR S/D LWR HGE (DR SI)) [БОЛТ] 15932620 HINGE, RR S/D LWR [ПЕТЛЯ В СБОРЕ] 15932621 HINGE, RR S/D LWR 11569646 БОЛТ, RR S/D CHK LINK BODY SI (10.455) 15269884 LINK, RR S/D CHK [УПЛОТНЕНИЕ] (6D10-071) - 2008 DM69 АРМАТУРА ЗАДНЕЙ ДВЕРИ ЧАСТЬ 2 ↓ 15242619 WINDOW, RR S/D [ОКНО] 15242620 WINDOW, RR S/D [ОКНО] 22709067 DEADENER, RR S/D (200X305) (12.810) 25757810 DEADENER, RR S/D (390X150) (W/O HOLE) (RECTANGULAR IN SHAPE) (12.980) 25955405 REGULATOR, RR S/D WDO (INCLS 4-6, 21) (ACDelco #25955405) [РЕГУЛЯТОР В СБОРЕ] 25955406 REGULATOR, RR S/D WDO (INCLS 4-6, 21) (ACDelco #25955406) [СТЕКЛОПОДЪЕМНИК ДВЕРИ] not found БОЛТ, RR S/D WDO REG (ЧАСТЬ OF 3) not found БОЛТ, RR S/D WDO REG MOT (ЧАСТЬ OF 3) not found MOTOR, RR S/D WDO REG (ЧАСТЬ OF 3) 20826984 HARNESS, RR S/D DR WRG (INCLS 8) 25858058 HARNESS, RR S/D DR WRG (INCLS 8) 25858059 HARNESS, RR S/D DR WRG (INCLS 8) 25858062 HARNESS, RR S/D DR WRG (INCLS 8) 25858063 HARNESS, RR S/D DR WRG (INCLS 8) 25858065 HARNESS, RR S/D DR WRG (INCLS 8) 25882870 HARNESS, RR S/D DR WRG (INCLS 8) 25955077 HARNESS, RR S/D DR WRG (INCLS 8) not found GROMMET, RR S/D WRG HARN (ЧАСТЬ OF 7) 19116956 GROMMET, RR S/D WRG HARN (ЧАСТЬ OF 7) 19116957 GROMMET, RR S/D WRG HARN (ЧАСТЬ OF 7) not found CABLE, RR S/D LAT REL (ЧАСТЬ OF 27) 11519381 БОЛТ, WASHER M6X1X15, 5.75 THD, 17 OD, 8.8, GMW3359, M-POINT, 1.65 CON SPRWA (RR S/D WDO REG) not found ROD, RR S/D LKG 15864408 ROD, RR S/D LKG [ШАТУН] 15864409 ROD, RR S/D LKG [ШАТУН] not found CLIP, RR S/D LKG ROD (ЧАСТЬ OF 27) 15269127 ROD, RR S/D O/S HDL 15269128 ROD, RR S/D O/S HDL 25887975 SEAL, RR S/D I/S HDL (16.341) 15879390 KNOB, RR S/D LKG ROD (CHROME) [КНОПКА БЛОКИРОВКИ ЗАМКА ДВЕРИ] 11609341 SCREW, RD WA HD 6-LOBE M6X1X19 (RR S/D LK) [ВИНТ] 25676040 PLUG, RR S/D ACC HOLE (25MM OD) (12.809) 21110669 PLUG, RKR INR PNL HOLE (35 MM) (ROUND) (12.179) 25864483 ШЛАНГИ KIT, RR S/D O/S HDL (INCLS 20, 22, 25) (INCLS ШЛАНГИ И SEALS) [ЖГУТ ПРОВОДОВ] 25864484 ШЛАНГИ KIT, RR S/D O/S HDL (INCLS 20, 22, 25) (INCLS ШЛАНГИ И SEALS) [ЖГУТ ПРОВОДОВ] not found CLIP, RR S/D LKG ROD (ЧАСТЬ OF 19) not found BRACKET, RR S/D ACTR CBL GDE (ЧАСТЬ OF 3) not found SEAL, RR S/D O/S HDL (ЧАСТЬ OF 19) teamcadillac.ru not found CAP, RR S/D LK CYL (ЧАСТЬ OF 24) 19121209 LEVER KIT, RR S/D O/S HDL (INCLS 23) (КРАСКА TO MATCH) (INCLS LEVER & CAP) (W/O CHROME INSERTS) 25864469 LEVER KIT, RR S/D O/S HDL (INCLS 23) (BLACK) (BASE) (W/O CONNECTOR) 25864470 LEVER KIT, RR S/D O/S HDL (INCLS 23) (BLACK) (BASE) (W/O CONNECTOR) 25864475 LEVER KIT, RR S/D O/S HDL (INCLS 23) (КРАСКА TO MATCH) (INCLS LEVER & CAP) (W/O CHROME INSERTS) [КОМПЛЕКТ РЫЧАГОВ] not found SEAL, RR S/D O/S HDL (ЧАСТЬ OF 19) 15880692 DOOR, RR SI (СМ. ГРУППУ 12.000 "КУЗОВНЫЕ ДЕТАЛИSIDE" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ДВЕРЬ] 15880693 DOOR, RR SI (СМ. ГРУППУ 12.000 "КУЗОВНЫЕ ДЕТАЛИSIDE" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ДВЕРЬ] 20825339 LOCK, RR S/D (INCLS 9, 12) 20825340 LOCK, RR S/D (INCLS 9, 12) 20825341 LOCK, RR S/D (INCLS 9, 12) [ЗАМОК ДВЕРИ] 20825342 LOCK, RR S/D (INCLS 9, 12) 11519381 БОЛТ, WASHER M6X1X15, 5.75 THD, 17 OD, 8.8, GMW3359, M-POINT, 1.65 CON SPRWA (RR S/D STA WDO DIV CHAN LWR SUPT) 11609460 SCREW, RND WA, M4.2X1.41X10, 4.2 THD, 11 OD, GM6010M, GMW4205, C/R, TAP (RR S/D STA WDO) 20800143 WINDOW, RR S/D STA (W/RR S/D WDO W/STR) (HIGH GLOSS) 25896868 WINDOW, RR S/D STA (W/RR S/D WDO W/STR) [ОКНО] (6D10-072) - 2008 DM69 ВЕТРОВОЕ СТЕКЛО TRIM & АРМАТУРА ↓ 25863396 ВЕТРОВОЕ СТЕКЛО, (INCLS 4, 11, 12) 25863397 ВЕТРОВОЕ СТЕКЛО, (INCLS 4, 12) 25863398 ВЕТРОВОЕ СТЕКЛО, (INCLS 4, 12) 25863399 ВЕТРОВОЕ СТЕКЛО, (INCLS 4, 11, 12) 25863400 ВЕТРОВОЕ СТЕКЛО, (INCLS 4, 11, 12) [ВЕТРОВОЕ СТЕКЛО] 25863401 ВЕТРОВОЕ СТЕКЛО, (INCLS 4, 12) [СТЕКЛО ВЕТРОВОЕ] not found HARNESS, RF ACSRY WRG (СМ. ГРУППУ 10.000 "КРЫША ОТДЕЛКА/INTERIOR" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) teamcadillac.ru 15271286 MIRROR, I/S RR VIEW (INCLS 8) [ВНУТРЕННЕЕ ЗЕРКАЛО ЗАДНЕГО ВИДА] 15816792 MIRROR, I/S RR VIEW (INCLS 8) (W/O MIC) (16.068) not found MOLDING, W/S UPR RVL (ЧАСТЬ OF 1) not found TAPE, VIN PLT not found PLATE, VIN not found RIVET, VIN PLT not found БОЛТ, I/S RR VIEW MIR (ЧАСТЬ OF 3) 25796686 COVER, I/S RR VIEW MIR WRG HARN UPR [КРЫШКА] 25796687 COVER, I/S RR VIEW MIR WRG HARN UPR [КРЫШКА] 25831579 SENSOR, W/S O/S MSTRE (W/O BRACKET) not found BRACKET, W/S O/S MSTRE SEN (ЧАСТЬ OF 1) not found PLATE, I/S RR VIEW MIR MT (ЧАСТЬ OF 1) 12346392 ADHESIVE KIT, GLASS URETHANE (W/S) (FOR INSTALLATION OF ALL STATIONARY WINDOW GLASS) 25885183 PANEL, AIR INL GRL (СМ. ГРУППУ 10.000 "СТЕКЛООЧИСТИТЕЛЬ-ВЕТРОВОГО СТЕКЛА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ПАНЕЛЬ] 25885184 PANEL, AIR INL GRL (СМ. ГРУППУ 10.000 "СТЕКЛООЧИСТИТЕЛЬ-ВЕТРОВОГО СТЕКЛА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ПАНЕЛЬ] 25892885 PANEL, AIR INL GRL (СМ. ГРУППУ 10.000 "СТЕКЛООЧИСТИТЕЛЬ-ВЕТРОВОГО СТЕКЛА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6D10-073) - 2008 DM69 СТЕКЛООЧИСТИТЕЛЬ-ВЕТРОВОГО СТЕКЛА ↓ 25885183 PANEL, AIR INL GRL (INCLS 5, 14, 17, 28, 29) [ПАНЕЛЬ] 25885184 PANEL, AIR INL GRL (INCLS 5, 14, 17, 28, 29) [ПАНЕЛЬ] 15890056 WIPER, W/S [НАСАДКА ЩЕТКИ СТЕКЛООЧИСТИТЕЛЯ] 15890057 WIPER, W/S [НАСАДКА ЩЕТКИ СТЕКЛООЧИСТИТЕЛЯ] 15890062 BLADE, WSW [ЩЕТКА В СБОРЕ, СТЕКЛЛОЧИСТИТЕЛЯ ВЕТРОВОГО СТЕКЛА] 15890064 BLADE, WSW [ЩЕТКА В СБОРЕ, СТЕКЛЛОЧИСТИТЕЛЯ ВЕТРОВОГО СТЕКЛА] 15890058 ARM, WSW [РЫЧАГ] 15890060 ARM, WSW [РЫЧАГ] 11561261 RIVET - DOME HEAD, 4.76X13.0, AA5052-0 AL ALLOY, GM4472M TYPE O (ЧАСТЬ OF 1) not found RETAINER, AIR INL HSG (PUSH IN) 10341324 CAP, WSW ARM NUT [КРЫШКА ДЕРЖАТЕЛЯ СТЕКЛООЧИСТИТЕЛЯ] 11609634 ГАЙКА, HEX WASH, M10X1.25, 7MM THK, 20 WA OD, 9 STL, 7111M, CON SPR WA. (WSW ARM) [ШАЙБА] not found БОЛТ, WSW TRANS (ЧАСТЬ OF 19) not found BUSHING, WSW TRANS LINK INSL (ЧАСТЬ OF 19) teamcadillac.ru 11570235 STUD, WSW SYS MDL not found BUSHING, WSW TRANS LINK INSL (ЧАСТЬ OF 19) 25877338 MOTOR, WSW (INCLS 18) (ACDelco #25877338) [МОТОР] not found BRACE, AIR INL GRL PNL (ЧАСТЬ OF 1) 11589145 ГАЙКА, PUSH ON, M10, 20.0 OD, GMW3359 (AIR INL GRL PNL) [ШАЙБА 10 ММ] 25815793 NOZZLE, WSWA [ФОРСУНКА СТЕКЛООМЫВАТЕЛЯ] not found RIVET, AIR DISTR BRKT (ЧАСТЬ OF 1) not found БОЛТ, WSW MOT (ЧАСТЬ OF 13) 15890054 ТРАНСМИССИЯ, WSW (INCLS 9, 10, 12) (ACDelco #15890054) (BUILT 09/09/07 AND PRIOR, FOR 2ND DES SEE 25904616) 25904616 ТРАНСМИССИЯ, WSW (INCLS 9, 10, 12) (ACDelco #25904616) (BUILT 09/10/07 AND AFTER, FOR 1ST DES SEE 15890054) 11515638 ГАЙКА, U-TYPE, M4.2X1.41X10.5.5X22, .65-3.8 PNL THK, 1050, ZF (AIR INL HSG) [ГАЙКА М4.2] 11518094 БОЛТ-HES W/FL WA, M6X1X21, 11.75 THD, 24 OD, 9.8, 7114M, MACH, DOG-PT (WSWA SOLV CNTNR) not found CONTAINER KIT, WSWA SOLV (INCLS 35, 36, 38) 11518121 ГАЙКА, U, M6X1, MULTI THD, .5'-4.0' THK PNL (WSWA SOLV CNTNR) 15241668 HOSE, WSWA SOLV CNTNR (CONNECTS FROM WASHER BOTTLE TO WSWA SOLV ПОДОГРЕВАТЕЛЬ HOSE) [ТРУБКА В СБОРЕ] 25962130 ПОДОГРЕВАТЕЛЬ, WSWA SOLV 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (WSWA SOLV HTR) [ГАЙКА М6] 25815794 HOSE, WSWA SOLV CNTNR (CONNECTS FROM NOZZLE TO WSWA SOLV ПОДОГРЕВАТЕЛЬ HOSE) [ТРУБКА] not found BRACE, AIR INL GRL PNL (ЧАСТЬ OF 1) 10369166 WEATHERSTRIP, КАПОТ RR (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ КАПОТА] 25892885 PANEL, AIR INL GRL 11609489 БОЛТ, HEX W/ WASHER, 4.2X1.41X25, 14.5 THD17 OD, GM6010M STL, GMW4205 (AIR INL GRL) [БОЛТ М4.2] 13227300 CAP, WSWA SOLV CNTNR [КРЫШКА БАЧКА СТЕКЛООМЫВАТЕЛЯ] 25790704 WASHER, HDLP WA PUMP (W/PUMP) (10.153) [ФАРА] 25790705 PUMP, WSWA [ПОДШИПНИК] 22039457 GROMMET, WSWA PUMP (ЧАСТЬ OF 22) (18MM) [ВТУЛКА УПЛОТНИТЕЛЬНАЯ, НАСОСА ОМЫВА ВЕТРОВОГО СТЕК] 22039457 GROMMET, WSWA SOLV CNTNR (ЧАСТЬ OF 22) (18MM) (10.153) [ВТУЛКА УПЛОТНИТЕЛЬНАЯ, НАСОСА ОМЫВА ВЕТРОВОГО СТЕК] 25790708 GROMMET, WSWA SOLV CNTNR (ЧАСТЬ OF 22) [ВТУЛКА УПЛОТНИТЕЛЬНАЯ] 15254826 INDICATOR KIT, WSWA SOLV LVL (16.065) not found GROMMET, WSWA SOLV CNTNR (ЧАСТЬ OF 22) (*KIT1) 15254826 INDICATOR KIT, WSWA SOLV LVL (INCLS 38) (16.065) (6D10-074) - 2008 DM69 ПРИБОРНАЯ ПАНЕЛЬ ЧАСТЬ 4 CENTER CONTROL (U2R,U2S,U2T) ↓ 25837731 CONTROL, AM/FM STEREO & CLK & CD PLYR RDO (INCLS 2-9, 11-13, 17-20) (TITANIUM) (ACDelco #25837731) 25837734 CONTROL, AM/FM STEREO & CLK & CD PLYR RDO (INCLS 2-9, 11-13, 17-20) (TITANIUM) (ACDelco #25837734) 25837735 CONTROL, AM/FM STEREO & CLK & CD PLYR RDO (INCLS 2-9, 11-13, 17-20) (CASHMERE) (ACDelco #25837735) 25837743 CONTROL, AM/FM STEREO & CLK & CD PLYR RDO (INCLS 2-9, 11-13, 17-20) (EBONY) (ACDelco #25837743) 25837744 CONTROL, AM/FM STEREO & CLK & CD PLYR RDO (INCLS 2-9, 11-13, 17-20) (TITANIUM) (ACDelco #25837744) 25837745 CONTROL, AM/FM STEREO & CLK & CD PLYR RDO (INCLS 2-9, 11-13, 17-20) (CASHMERE) (ACDelco #25837745) 25837747 CONTROL, AM/FM STEREO & CLK & CD PLYR RDO (INCLS 2-9, 11-13, 17-20) (EBONY) (ACDelco #25837747) 25837748 CONTROL, AM/FM STEREO & CLK & CD PLYR RDO (INCLS 2-9, 11-13, 17-20) (TITANIUM) (ACDelco #25837748) 25837749 CONTROL, AM/FM STEREO & CLK & CD PLYR RDO (INCLS 2-9, 11-13, 17-20) (CASHMERE) (ACDelco #25837749) 25837751 CONTROL, AM/FM STEREO & CLK & CD PLYR RDO (INCLS 2-9, 11-13, 17-20) (EBONY) (ACDelco #25837751) 25837752 CONTROL, AM/FM STEREO & CLK & CD PLYR RDO (INCLS 2-9, 11-13, 17-20) (TITANIUM) (ACDelco #25837752) 25837760 CONTROL, AM/FM STEREO & CLK & CD PLYR RDO (INCLS 2-9, 11-13, 17-20) (TITANIUM) (ACDelco #25837760) 25886803 CONTROL, AM/FM STEREO & CLK & CD PLYR RDO (INCLS 2-9, 11-13, 17-20) (EBONY) (ACDelco #25886803) 25886804 CONTROL, AM/FM STEREO & CLK & CD PLYR RDO (INCLS 2-9, 11-13, 17-20) (TITANIUM) (ACDelco #25886804) 25960556 CONTROL, AM/FM STEREO & CLK & CD PLYR RDO (INCLS 2-9, 11-13, 17-20) (EBONY) (ACDelco #25960556) 25960559 CONTROL, AM/FM STEREO & CLK & CD PLYR RDO (INCLS 2-9, 11-13, 17-20) (EBONY) (ACDelco #25960559) 25960560 CONTROL, AM/FM STEREO & CLK & CD PLYR RDO (INCLS 2-9, 11-13, 17-20) (CASHMERE) (ACDelco #25960560) 25960563 CONTROL, AM/FM STEREO & CLK & CD PLYR RDO (INCLS 2-9, 11-13, 17-20) (EBONY) (ACDelco #25960563) 25960566 CONTROL, AM/FM STEREO & CLK & CD PLYR RDO (INCLS 2-9, 11-13, 17-20) (CASHMERE) (ACDelco #25960566) not found RETAINER, I/P ACSRY TR PLT (ЧАСТЬ OF 1) not found БОЛТ, I/P ACSRY MT PLT (ЧАСТЬ OF 1) not found PLATE, I/P ACSRY LWR TR (ЧАСТЬ OF 1) not found DISPLAY, DRVR INFO (ЧАСТЬ OF 1) not found PLATE, I/P ACSRY UPR TR (ЧАСТЬ OF 1) not found CONTROL, HTR & КОНДИЦИОНЕР (ЧАСТЬ OF 1) not found БОЛТ, I/P ACSRY MT PLT (ЧАСТЬ OF 1) 19117334 RADIO, AM/FM STEREO & AUDIO DISC PLYR & MP3 PLYR (ЧАСТЬ OF 1) (ACDelco #19117334) 20773368 RADIO, AM/FM STEREO & AUDIO DISC PLYR & MP3 PLYR (ЧАСТЬ OF 1) (LABELED 20773368) (ACDelco #20773368) teamcadillac.ru 20773369 RADIO, AM/FM STEREO & AUDIO DISC PLYR & MP3 PLYR (ЧАСТЬ OF 1) (LABELED 20773369) (ACDelco #20773369) 20773370 RADIO, AM/FM STEREO & AUDIO DISC PLYR & MP3 PLYR (ЧАСТЬ OF 1) (LABELED 20773370) (ACDelco #20773370) 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (RDO CONT) [ВИНТ М4] not found CONTROL, PASS TEMP (ЧАСТЬ OF 1) not found CONTROL, TEMP (ЧАСТЬ OF 1) not found БОЛТ, I/P ACSRY MT PLT (ЧАСТЬ OF 1) not found COVER, I/P UPR TR 25876731 COVER, I/P UPR TR (EBONY) (W/O NAV INFO DISPLAY) [КРЫШКА] 25876732 COVER, I/P UPR TR (COCOA) (W/O NAV INFO DISPLAY) [КРЫШКА] 11570587 БОЛТ, I/P CTR COMPT (D 30 X 1.12 X 10) (ATTACH ICS COMPT ASM TO IP LWR) 25941152 COMPARTMENT, I/P CTR (СМ. ГРУППУ 10.000 "ПРИБОРНАЯ ПАНЕЛЬ TRIM" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (STAINLESS SILVER) [КРЫШКА ПРИБОРНОЙ ПАНЕЛИ] not found ШЛАНГИ, AUDIO DISC PLYR (ЧАСТЬ OF 1) not found BRACKET, CD/PLYR (ЧАСТЬ OF 1) not found DISPLAY, AUDIO DISC PLYR (ЧАСТЬ OF 1) not found БОЛТ, CD PLYR BRKT (ЧАСТЬ OF 1) (6D10-075) - 2008 DM69 ЦЕНТРАЛЬНЫЙ ЗАМОК (AU5,AU8) ↓ 20762974 TRANSMITTER, R/CON DR LK (INCLS 2) (FOB #2) 20814369 TRANSMITTER, R/CON DR LK (INCLS 2) (#1 FOB) 25841889 TRANSMITTER, R/CON DR LK (INCLS 2) (#1) [УСТРОЙСТВО ДИСТАНЦИОННОГО УПРАВЛЕНИЯ ЦЕНТРАЛЬНЫМ ЗАМКОМ] 25841890 TRANSMITTER, R/CON DR LK (INCLS 2) (#2 FOB) 25841891 TRANSMITTER, R/CON DR LK (INCLS 2) (#1 FOB) 25841892 TRANSMITTER, R/CON DR LK (INCLS 2) (#2 FOB) 12538938 АККУМУЛЯТОР, R/CON DR LK XMTR (ЧАСТЬ OF 1) (LITHIUM) (TRADE CR2032) [БАТАРЕЙКА КНОПОЧНАЯ ЛИТИЕВАЯ] not found HARNESS, BODY WRG (СМ. ГРУППУ 13.000 "ЖГУТЫ ПРОВОДОВ/КУЗОВ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 20803736 RECEIVER, R/CON DR LK (RECEIVERS LABELED OEM 20803736) 25896540 RECEIVER, R/CON DR LK (RECEIVERS LABELED OEM 25896540) 25938218 RECEIVER, R/CON DR LK (6D10-076) - 2008 DM69 ЦЕНТРАЛЬНЫЙ ЗАМОК (UHA,UHB,UHC,UHD,UHF) ↓ 20784420 TRANSMITTER, R/CON DR LK & THEFT DTRNT (INCLS 2) (ASIA TRANSMITTER W/ REMOTE START #1) (10.526) 20784420 TRANSMITTER, R/CON DR LK & THEFT DTRNT (INCLS 2) (ASIA TRANSMITTER W/ REMOTE START #1) 20784421 TRANSMITTER, R/CON DR LK & THEFT DTRNT (INCLS 2) (ASIA TRANSMITTER W/ REMOTE START #2) (10.526) 20784421 TRANSMITTER, R/CON DR LK & THEFT DTRNT (INCLS 2) (ASIA TRANSMITTER W/ REMOTE START #2) 25854937 TRANSMITTER, R/CON DR LK & THEFT DTRNT (INCLS 2) (DOMESTIC FOB WITHOUT REMOTE START 1) (10.526) 25854937 TRANSMITTER, R/CON DR LK & THEFT DTRNT (INCLS 2) (DOMESTIC FOB WITHOUT REMOTE START 1) 25854938 TRANSMITTER, R/CON DR LK & THEFT DTRNT (INCLS 2) (DOMESTIC FOB WITHOUT REMOTE START 2) (10.526) 25854938 TRANSMITTER, R/CON DR LK & THEFT DTRNT (INCLS 2) (DOMESTIC FOB WITHOUT REMOTE START 2) 25854939 TRANSMITTER, R/CON DR LK & THEFT DTRNT (INCLS 2) (EURO TRANSMITTER W/REMOTE START #1) (10.526) [ПЕРЕДАЮЩЕЕ УСТРОЙСТВО ДИСТАНЦИОННОГО УПРАВЛЕНИЯ] 25854939 TRANSMITTER, R/CON DR LK & THEFT DTRNT (INCLS 2) (EURO TRANSMITTER W/REMOTE START #1) [ПЕРЕДАЮЩЕЕ УСТРОЙСТВО ДИСТАНЦИОННОГО УПРАВЛЕНИЯ] 25854941 TRANSMITTER, R/CON DR LK & THEFT DTRNT (INCLS 2) (EURO TRANS WITHOUT REMOTE START 1) (10.526) 25854941 TRANSMITTER, R/CON DR LK & THEFT DTRNT (INCLS 2) (EURO TRANS WITHOUT REMOTE START 1) 25854942 TRANSMITTER, R/CON DR LK & THEFT DTRNT (INCLS 2) (EURO TRANS WITHOUT REMOTE START 2) (10.526) 25854942 TRANSMITTER, R/CON DR LK & THEFT DTRNT (INCLS 2) (EURO TRANS WITHOUT REMOTE START 2) 25854943 TRANSMITTER, R/CON DR LK & THEFT DTRNT (INCLS 2) (ASIA TRANSMITTER W/ REMOTE START #1) (10.526) teamcadillac.ru 25854943 TRANSMITTER, R/CON DR LK & THEFT DTRNT (INCLS 2) (ASIA TRANSMITTER W/ REMOTE START #1) 25854944 TRANSMITTER, R/CON DR LK & THEFT DTRNT (INCLS 2) (ASIA TRANSMITTER W/ REMOTE START #2) (10.526) 25854944 TRANSMITTER, R/CON DR LK & THEFT DTRNT (INCLS 2) (ASIA TRANSMITTER W/ REMOTE START #2) 25868002 TRANSMITTER, R/CON DR LK & THEFT DTRNT (INCLS 2) (EURO W/O REMOTE START AND NO PERSONALIZATION) (10.526) 25868002 TRANSMITTER, R/CON DR LK & THEFT DTRNT (INCLS 2) (EURO W/O REMOTE START AND NO PERSONALIZATION) 25869080 TRANSMITTER, R/CON DR LK & THEFT DTRNT (INCLS 2) (DOMESTIC W/REMOTE START & NO PERSONALIZATION) (OPT XMTR 3 & 4) (10.526) 25869080 TRANSMITTER, R/CON DR LK & THEFT DTRNT (INCLS 2) (DOMESTIC W/REMOTE START & NO PERSONALIZATION) (OPT XMTR 3 & 4) 25869081 TRANSMITTER, R/CON DR LK & THEFT DTRNT (INCLS 2) (EURO WITH REMOTE START AND NO PERSONALIZATION) (10.526) 25869081 TRANSMITTER, R/CON DR LK & THEFT DTRNT (INCLS 2) (EURO WITH REMOTE START AND NO PERSONALIZATION) 25869082 TRANSMITTER, R/CON DR LK & THEFT DTRNT (INCLS 2) (ASIA WITH REMOTE START AND NO PERSONALIZATION) (10.526) 25869082 TRANSMITTER, R/CON DR LK & THEFT DTRNT (INCLS 2) (ASIA WITH REMOTE START AND NO PERSONALIZATION) 25943676 TRANSMITTER, R/CON DR LK & THEFT DTRNT (INCLS 2) (DOMESTIC W/REMOTE START #1) (10.526) 25943676 TRANSMITTER, R/CON DR LK & THEFT DTRNT (INCLS 2) (DOMESTIC W/REMOTE START #1) 25943677 TRANSMITTER, R/CON DR LK & THEFT DTRNT (INCLS 2) (DOMESTIC W/REMOTE START #2) (10.526) 25943677 TRANSMITTER, R/CON DR LK & THEFT DTRNT (INCLS 2) (DOMESTIC W/REMOTE START #2) 25943679 TRANSMITTER, R/CON DR LK & THEFT DTRNT (INCLS 2) (EURO W/REMOTE START #2) (10.526) [ПЕРЕДАЮЩЕЕ УСТРОЙСТВО ОХРАННОЙ СИГНАЛИЗАЦИИ] 25943679 TRANSMITTER, R/CON DR LK & THEFT DTRNT (INCLS 2) (EURO W/REMOTE START #2) [ПЕРЕДАЮЩЕЕ УСТРОЙСТВО ОХРАННОЙ СИГНАЛИЗАЦИИ] 25943691 TRANSMITTER, R/CON DR LK & THEFT DTRNT (INCLS 2) (DOMESTIC W/O REMOTE START & NO PERSONALIZATION) (10.526) 12538938 АККУМУЛЯТОР, R/CON DR LK XMTR (ЧАСТЬ OF 1) (LITHIUM) (TRADE CR2032) [БАТАРЕЙКА КНОПОЧНАЯ ЛИТИЕВАЯ] 25995382 КЛЮЧ, DR LK & IGN LK (UNCODED) not found HARNESS, B/U ALARM WRG (СМ. ГРУППУ 07.000 "БАМПЕР ЗАДНИЙ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25884445 АНТЕННА, IGN LK KEY XMTR (PASSIVE АНТЕННА W/2 PIN CONN) 11502553 ГАЙКА, STAMPED, M6.3 STUD, SELF THD, STL, PC (R/CON DR LK RCVR ANT) [ГАЙКА М6] 25730079 АНТЕННА, IGN LK KEY XMTR (BLACK) (95 X 114 X 22) (F/FLR) (ACTIVE АНТЕННА W/5 PIN CONN) not found HARNESS, F/FLR CNSL WRG (СМ. ГРУППУ 10.000 "КОНСОЛЬ/ПОЛ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25884445 АНТЕННА, IGN LK KEY XMTR (PASSIVE АНТЕННА W/2 PIN CONN) not found RECEIVER, R/CON DR LK & THEFT DTRNT 25916007 RECEIVER, R/CON DR LK & THEFT DTRNT (10.485) (FOR VEHICLES BUILT AFTER OCT 15, 2007) (LABELED 25916007) 25916007 RECEIVER, R/CON DR LK & THEFT DTRNT (FOR VEHICLES BUILT AFTER OCT 15, 2007) (LABELED 25916007) 25916008 RECEIVER, R/CON DR LK & THEFT DTRNT (10.485) (LABELED 25916008) 25916008 RECEIVER, R/CON DR LK & THEFT DTRNT (LABELED 25916008) 25952623 RECEIVER, R/CON DR LK & THEFT DTRNT (10.485) (LABELED 25952623) 25952623 RECEIVER, R/CON DR LK & THEFT DTRNT (LABELED 25952623) 25952624 RECEIVER, R/CON DR LK & THEFT DTRNT (10.485) (LABELED 25952624) 25952624 RECEIVER, R/CON DR LK & THEFT DTRNT (LABELED 25952624) not found HARNESS, BODY WRG (СМ. ГРУППУ 13.000 "ЖГУТЫ ПРОВОДОВ/КУЗОВ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25864467 LEVER KIT, FRT S/D O/S HDL (СМ. ГРУППУ 10.000 "АРМАТУРА ПЕРЕДНЕЙ ДВЕРИ ЧАСТЬ 2" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (КРАСКА TO MATCH) (E-Z KEY PASSIVE REMOTE) (W/CONNECTOR) [РУЧКА ДВЕРИ] 25864468 LEVER KIT, FRT S/D O/S HDL (СМ. ГРУППУ 10.000 "АРМАТУРА ПЕРЕДНЕЙ ДВЕРИ ЧАСТЬ 2" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (КРАСКА TO MATCH) (UPLEVEL) (W/CONNECTOR)) [РУЧКА ДВЕРИ] 25864469 LEVER KIT, FRT S/D O/S HDL (СМ. ГРУППУ 10.000 "АРМАТУРА ПЕРЕДНЕЙ ДВЕРИ ЧАСТЬ 2" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (BLACK) (BASE) (W/O CONNECTOR) 25864470 LEVER KIT, FRT S/D O/S HDL (СМ. ГРУППУ 10.000 "АРМАТУРА ПЕРЕДНЕЙ ДВЕРИ ЧАСТЬ 2" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (BLACK) (BASE) (W/O CONNECTOR) (6D10-079) - 2008 DM69 ПРИБОРНАЯ ПАНЕЛЬ ЧАСТЬ 4 CENTER CONTROL (UAV,U2X,U2Y) ↓ 25837737 CONTROL, AM/FM STEREO & CLK & CD PLYR RDO (INCLS 2-9, 14-16, 20) (EBONY) (ACDelco #25837737) 25837740 CONTROL, AM/FM STEREO & CLK & CD PLYR RDO (INCLS 2-9, 14-16, 20) (TITANIUM) (ACDelco #25837740) 25837741 CONTROL, AM/FM STEREO & CLK & CD PLYR RDO (INCLS 2-9, 14-16, 20) (CASHMERE) (ACDelco #25837741) 25837757 CONTROL, AM/FM STEREO & CLK & CD PLYR RDO (INCLS 2-9, 14-16, 20) (TITANIUM) (ACDelco #25837757) 25960569 CONTROL, AM/FM STEREO & CLK & CD PLYR RDO (INCLS 2-9, 14-16, 20) (EBONY) (ACDelco #25960569) teamcadillac.ru 25960570 CONTROL, AM/FM STEREO & CLK & CD PLYR RDO (INCLS 2-9, 14-16, 20) (CASHMERE) (ACDelco #25960570) [ПАНЕЛЬ УПРАВЛЕНИЯ АВТОМАГНИТОЛОЙ] not found RETAINER, I/P ACSRY TR PLT (ЧАСТЬ OF 1) not found БОЛТ, I/P ACSRY MT PLT (ЧАСТЬ OF 1) not found PLATE, I/P ACSRY LWR TR (ЧАСТЬ OF 1) not found DISPLAY, DRVR INFO (ЧАСТЬ OF 1) not found PLATE, I/P ACSRY UPR TR (ЧАСТЬ OF 1) not found CONTROL, HTR & КОНДИЦИОНЕР (ЧАСТЬ OF 1) not found БОЛТ, I/P ACSRY MT PLT (ЧАСТЬ OF 1) not found CONTROL, AM/FM STEREO & T/PLYR & CD PLYR RDO (ЧАСТЬ OF 1) 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (RDO CONT) [ВИНТ М4] 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (VIDEO DISPLAY) [ВИНТ М4] not found DISPLAY, RDO & VIDEO & AUDIO DISC PLYR & NAVN INFO not found ACTUATOR, RDO & VIDEO & AUDIO DISC PLYR & NAVN INFO DISPLAY not found CONTROL, PASS TEMP (ЧАСТЬ OF 1) not found CONTROL, TEMP (ЧАСТЬ OF 1) not found БОЛТ, I/P ACSRY MT PLT (ЧАСТЬ OF 1) 15862570 COVER, NAVN INFO DISPLAY OPG (EBONY) 15862571 COVER, NAVN INFO DISPLAY OPG (CASHMERE) 11570587 БОЛТ, I/P CTR COMPT (D 30 X 1.12 X 10) (ATTACH ICS COMPT ASM TO IP LWR) 25941152 COMPARTMENT, I/P CTR (СМ. ГРУППУ 10.000 "ПРИБОРНАЯ ПАНЕЛЬ TRIM" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (STAINLESS SILVER) [КРЫШКА ПРИБОРНОЙ ПАНЕЛИ] not found ШЛАНГИ, AUDIO DISC PLYR (ЧАСТЬ OF 1) (6D10-084) - 2008 DM69 ЗЕРКАЛА ЗАДНЕГО ОБЗОРА ↓ 25828071 MIRROR, O/S RR VIEW (INCLS 2, 4-6) (КРАСКА TO MATCH) 25828071 MIRROR, O/S RR VIEW (INCLS 2, 4-6) (КРАСКА TO MATCH) 25828072 MIRROR, O/S RR VIEW (INCLS 2, 4-6) (КРАСКА TO MATCH) 25828072 MIRROR, O/S RR VIEW (INCLS 2, 4-6) (КРАСКА TO MATCH) 25828073 MIRROR, O/S RR VIEW (INCLS 2, 4-6) (КРАСКА TO MATCH) 25828074 MIRROR, O/S RR VIEW (INCLS 2, 4-6) (КРАСКА TO MATCH) 25828075 MIRROR, O/S RR VIEW (INCLS 2, 4-6) (КРАСКА TO MATCH) [ЗЕРКАЛО] 25828076 MIRROR, O/S RR VIEW (INCLS 2, 4-6) (КРАСКА TO MATCH) [ЗЕРКАЛО] teamcadillac.ru 25828077 MIRROR, O/S RR VIEW (INCLS 2, 4-6) (КРАСКА TO MATCH) [ЗЕРКАЛО] 25828078 MIRROR, O/S RR VIEW (INCLS 2, 4-6) (КРАСКА TO MATCH) [ЗЕРКАЛО] 25828082 MIRROR, O/S RR VIEW (INCLS 2, 4-6) (КРАСКА TO MATCH) 25828083 MIRROR, O/S RR VIEW (INCLS 2, 4-6) (КРАСКА TO MATCH) 25828084 MIRROR, O/S RR VIEW (INCLS 2, 4-6) (КРАСКА TO MATCH) 25828085 MIRROR, O/S RR VIEW (INCLS 2, 4-6) (КРАСКА TO MATCH) not found GASKET, O/S RR VIEW MIR (ЧАСТЬ OF 1) 11508277 ГАЙКА, HEX W/CON WA M6X1 THD, OD-19 PEOR 9 (O/S RR VIEW MIR REINF) [ГАЙКА М6] 25828087 GLASS, O/S RR VIEW MIR (W/BKG PLATE) (ЧАСТЬ OF 1) 25828088 GLASS, O/S RR VIEW MIR (W/BKG PLATE) (ЧАСТЬ OF 1) 25828089 GLASS, O/S RR VIEW MIR (W/BKG PLATE) (ЧАСТЬ OF 1) 25828090 GLASS, O/S RR VIEW MIR (W/BKG PLATE) (ЧАСТЬ OF 1) 25828091 GLASS, O/S RR VIEW MIR (W/BKG PLATE) (ЧАСТЬ OF 1) [ЗЕРКАЛО] 25828092 GLASS, O/S RR VIEW MIR (W/BKG PLATE) (ЧАСТЬ OF 1) [ЗЕРКАЛО] 25828097 GLASS, O/S RR VIEW MIR (W/BKG PLATE) (ЧАСТЬ OF 1) 25828098 GLASS, O/S RR VIEW MIR (W/BKG PLATE) (ЧАСТЬ OF 1) not found БОЛТ, O/S RR VIEW MIR MOT (ЧАСТЬ OF 1) 15951931 MOTOR, O/S RR VIEW MIR (ЧАСТЬ OF 1) (3 PIN CONNECTOR) (16.068) [ЭЛЕКТРОДВИГАТЕЛЬ РЕГУЛИРОВКИ ПОЛОЖЕНИЯ ЗЕРКАЛА ЗАДНЕГО ОБЗОРА 20 ВТ] 15951932 MOTOR, O/S RR VIEW MIR (ЧАСТЬ OF 1) (USE FOR 8 CAVITY/7 PIN CONNECTOR) (16.068) [ЭЛЕКТРОДВИГАТЕЛЬ РЕГУЛИРОВКИ ПОЛОЖЕНИЯ ЗЕРКАЛА ЗАДНЕГО ОБЗОРА 20 ВТ] (6D10-086) - 2008 DM69 ЦИЛИНДР ЗАМКА SET ↓ 20869121 CYLINDER KIT, IGN LK (UNCODED) (VEHICLES W/AUTO TRANS) teamcadillac.ru 25979925 CYLINDER KIT, IGN LK (UNCODED) (MAN TRANS VEHICLES) 25995382 КЛЮЧ, DR LK & IGN LK (UNCODED) 20766969 CYLINDER KIT, FRT S/D LK (UNCODED) 15800058 CYLINDER KIT, FRT S/D LK (UNCODED) [ЦИЛИНДР] 20766965 CYLINDER KIT, I/P COMPT DR LK (UNCODED) (6D10-110) - 2008 DM69 КОНСОЛЬ/КРЫША (DELETE ЛЮК CFN, EXC THEFT DETERENT UA2,GARAGE OPENER UG1) ↓ 11562028 БОЛТ, RF CNSL (ЧАСТЬ OF 8) not found PLATE, RF CNSL BKG (ЧАСТЬ OF 8) 15246939 MICROPHONE, RDO VOL COMP INTR NOISE (ЧАСТЬ OF 8) (RDO VOL COMP) 25886563 ЛАМПА, RF CNSL CTSY & RDG (ЧАСТЬ OF 8) (INCLS 5-7) [ЛАМПА] not found PUSHBUTTON, W/S HDR CTSY & RDG LP SW (ЧАСТЬ OF 4, 8, 11) 01999382 BULB, (ЧАСТЬ OF 4, 8, 11) (ACDelco #W5WLL) (LONGER LIFE) 25886565 LENS, RF CNSL RDG LP (ЧАСТЬ OF 4, 8) 15876681 КОНСОЛЬ, RF (INCLS 1-7, 9-13) (TITANIUM) 15876683 КОНСОЛЬ, RF (INCLS 1-7, 9-13) (TITANIUM) 15876684 КОНСОЛЬ, RF (INCLS 1-7, 9-13) (CASHMERE) 15876695 КОНСОЛЬ, RF (INCLS 1-7, 9-13) (TITANIUM) 15876696 КОНСОЛЬ, RF (INCLS 1-7, 9-13) (CASHMERE) 15876697 КОНСОЛЬ, RF (INCLS 1-7, 9-13) (TITANIUM) 15876698 КОНСОЛЬ, RF (INCLS 1-7, 9-13) (CASHMERE) 15876703 КОНСОЛЬ, RF (INCLS 1-7, 9-13) (TITANIUM) 15876704 КОНСОЛЬ, RF (INCLS 1-7, 9-13) (CASHMERE) 15876705 КОНСОЛЬ, RF (INCLS 1-7, 9-13) (TITANIUM) 15876706 КОНСОЛЬ, RF (INCLS 1-7, 9-13) (CASHMERE) 25854597 КОНСОЛЬ, RF (INCLS 1-7, 9-13) (TITANIUM) 25854598 КОНСОЛЬ, RF (INCLS 1-7, 9-13) (CASHMERE) 25854600 КОНСОЛЬ, RF (INCLS 1-7, 9-13) (TITANIUM) 25854601 КОНСОЛЬ, RF (INCLS 1-7, 9-13) (CASHMERE) teamcadillac.ru 11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (ЧАСТЬ OF 8) [ЗАЖИМ КОНСОЛИ САЛОНА] 25886564 LENS, RF CNSL RDG LP (ЧАСТЬ OF 8, 11) 25886562 ЛАМПА, RF CNSL CTSY & RDG (ЧАСТЬ OF 8) (INCLS 5, 6, 10) [ЛАМПА] 15241529 MICROPHONE, MOBILE TEL (ЧАСТЬ OF 8) (2-WAY CAVITY) 25821823 ЛАМПА, RF CNSL CTSY (ЧАСТЬ OF 8) (PIN SPOT LED) (6D10-111) - 2008 DM69 КОНСОЛЬ/КРЫША (DELETE ЛЮК CFN, GARAGE OPENER UG1, EXC THEFT DETERENT UA2) ↓ 11562028 БОЛТ, RF CNSL (ЧАСТЬ OF 10) not found PLATE, RF CNSL BKG (ЧАСТЬ OF 10) 15246939 MICROPHONE, RDO VOL COMP INTR NOISE (ЧАСТЬ OF 10) (RDO VOL COMP) 25886563 ЛАМПА, RF CNSL CTSY & RDG (ЧАСТЬ OF 10) (INCLS 5-7) [ЛАМПА] not found PUSHBUTTON, W/S HDR CTSY & RDG LP SW (ЧАСТЬ OF 4, 10, 13) 01999382 BULB, (ЧАСТЬ OF 4, 10, 13) (ACDelco #W5WLL) (LONGER LIFE) 25886565 LENS, RF CNSL RDG LP (ЧАСТЬ OF 4, 10) 15145260 TRANSMITTER, GARAGE DR OPENER (ЧАСТЬ OF 10) (W/O OWNERS INFO MANUAL) 20781584 TRANSMITTER, GARAGE DR OPENER (ЧАСТЬ OF 10) 20781584 TRANSMITTER, GARAGE DR OPENER (ЧАСТЬ OF 10) 25828896 PUSHBUTTON, GARAGE DR OPENER XMTR (ЧАСТЬ OF 10) (GRAY) 25828897 PUSHBUTTON, GARAGE DR OPENER XMTR (ЧАСТЬ OF 10) (CASHMERE) 15876686 КОНСОЛЬ, RF (INCLS 1-9, 11-15) (CASHMERE) 15876687 КОНСОЛЬ, RF (INCLS 1-9, 11-15) (TITANIUM) 15876688 КОНСОЛЬ, RF (INCLS 1-9, 11-15) (CASHMERE) 15876699 КОНСОЛЬ, RF (INCLS 1-9, 11-15) (TITANIUM) 15876700 КОНСОЛЬ, RF (INCLS 1-9, 11-15) (CASHMERE) 15876701 КОНСОЛЬ, RF (INCLS 1-9, 11-15) (TITANIUM) 15876702 КОНСОЛЬ, RF (INCLS 1-9, 11-15) (CASHMERE) 25854591 КОНСОЛЬ, RF (INCLS 1-9, 11-15) (TITANIUM) 25854592 КОНСОЛЬ, RF (INCLS 1-9, 11-15) (CASHMERE) 25854594 КОНСОЛЬ, RF (INCLS 1-9, 11-15) (TITANIUM) 25854595 КОНСОЛЬ, RF (INCLS 1-9, 11-15) (CASHMERE) 25862675 КОНСОЛЬ, RF (INCLS 1-9, 11-15) (TITANIUM) 25862676 КОНСОЛЬ, RF (INCLS 1-9, 11-15) (CASHMERE) teamcadillac.ru 25862681 КОНСОЛЬ, RF (INCLS 1-9, 11-15) (TITANIUM) 25862682 КОНСОЛЬ, RF (INCLS 1-9, 11-15) (CASHMERE) 11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (ЧАСТЬ OF 10) [ЗАЖИМ КОНСОЛИ САЛОНА] 25886564 LENS, RF CNSL RDG LP (ЧАСТЬ OF 10, 13) 25886562 ЛАМПА, RF CNSL CTSY & RDG (ЧАСТЬ OF 10) (INCLS 5, 6, 12) [ЛАМПА] 15241529 MICROPHONE, MOBILE TEL (ЧАСТЬ OF 10) (2-WAY CAVITY) 25821823 ЛАМПА, RF CNSL CTSY (ЧАСТЬ OF 10) (PIN SPOT LED) (6D10-112) - 2008 DM69 КОНСОЛЬ/КРЫША (DELETE ЛЮК CFN, THEFT DETERENT UA2, EXC GARAGE OPENER UG1) ↓ 11562028 БОЛТ, RF CNSL (ЧАСТЬ OF 9) not found PLATE, RF CNSL BKG (ЧАСТЬ OF 9) 15240415 MICROPHONE, RDO VOL COMP INTR NOISE (ЧАСТЬ OF 9) 25886563 ЛАМПА, RF CNSL CTSY & RDG (ЧАСТЬ OF 9) (INCLS 5-7) [ЛАМПА] not found PUSHBUTTON, W/S HDR CTSY & RDG LP SW (ЧАСТЬ OF 4, 9, 12) 01999382 BULB, (ЧАСТЬ OF 4, 9, 12) (ACDelco #W5WLL) (LONGER LIFE) 25886565 LENS, RF CNSL RDG LP (ЧАСТЬ OF 4, 9) 15283682 SENSOR, THEFT DTRNT (ЧАСТЬ OF 9) [ДАТЧИК НАКЛОНА КУЗОВА] 15876689 КОНСОЛЬ, RF (INCLS 1-8, 10-13) (TITANIUM) (WITHOUT VNC MICROPHONE) 15876690 КОНСОЛЬ, RF (INCLS 1-8, 10-13) (CASHMERE) (W/O VNC MIC) 15876691 КОНСОЛЬ, RF (INCLS 1-8, 10-14) (TITANIUM) 15876692 КОНСОЛЬ, RF (INCLS 1-8, 10-14) (CASHMERE) (W/O VNC MIC) 15876693 КОНСОЛЬ, RF (INCLS 1-8, 10-14) (TITANIUM) (WITHOUT VNC MICROPHONE) 15876694 КОНСОЛЬ, RF (INCLS 1-8, 10-14) (CASHMERE) 25822401 КОНСОЛЬ, RF (INCLS 1-8, 10-14) (TITANIUM) (W/VNC MICROPHONE) 25822401 КОНСОЛЬ, RF (INCLS 1-8, 10-14) (TITANIUM) (W/VNC MICROPHONE) 25822402 КОНСОЛЬ, RF (INCLS 1-8, 10-14) (CASHMERE) (W/VNC MICROPHONE) 25822402 КОНСОЛЬ, RF (INCLS 1-8, 10-14) (CASHMERE) (W/VNC MICROPHONE) 25822409 КОНСОЛЬ, RF (INCLS 1-8, 10-13) (TITANIUM) (W/VNC MICROPHONE) 25822409 КОНСОЛЬ, RF (INCLS 1-8, 10-13) (TITANIUM) (W/VNC MICROPHONE) 25822410 КОНСОЛЬ, RF (INCLS 1-8, 10-13) (CASHMERE) (W/VNC MICROPHONE) 11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (ЧАСТЬ OF 9) [ЗАЖИМ КОНСОЛИ САЛОНА] 25886564 LENS, RF CNSL RDG LP (ЧАСТЬ OF 9, 12) 25886562 ЛАМПА, RF CNSL CTSY & RDG (ЧАСТЬ OF 9) (INCLS 5, 6, 11) [ЛАМПА] 15241529 MICROPHONE, MOBILE TEL (ЧАСТЬ OF 9) (2-WAY CAVITY) 25821823 ЛАМПА, RF CNSL CTSY (ЧАСТЬ OF 9) (PIN SPOT LED) (6D10-113) - 2008 DM69 КОНСОЛЬ/КРЫША (ЛЮК C3U, EXC THEFT DETERENT UA2, GARAGE OPENER UG1) ↓ 11562028 БОЛТ, RF CNSL (ЧАСТЬ OF 9) not found PLATE, RF CNSL BKG (ЧАСТЬ OF 9) 25789090 SWITCH, SUN RF СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК (ЧАСТЬ OF 9) [ПЕРЕКЛЮЧАТЕЛЬ] 25789091 SWITCH, SUN RF (ЧАСТЬ OF 9) [ПЕРЕКЛЮЧАТЕЛЬ] 25886563 ЛАМПА, RF CNSL CTSY & RDG (ЧАСТЬ OF 9) (INCLS 6-8) [ЛАМПА] not found PUSHBUTTON, W/S HDR CTSY & RDG LP SW (ЧАСТЬ OF 5, 9, 12) 01999382 BULB, (ЧАСТЬ OF 5, 9, 12) (ACDelco #W5WLL) (LONGER LIFE) 25886565 LENS, RF CNSL RDG LP (ЧАСТЬ OF 5, 9) 15876709 КОНСОЛЬ, RF (INCLS 1-8, 10-14) (TITANIUM) 15876710 КОНСОЛЬ, RF (INCLS 1-8, 10-14) (CASHMERE) 15876711 КОНСОЛЬ, RF (INCLS 1-8, 10-14) (TITANIUM) 15876712 КОНСОЛЬ, RF (INCLS 1-8, 10-14) (CASHMERE) 15876723 КОНСОЛЬ, RF (INCLS 1-8, 10-14) (TITANIUM) 15876724 КОНСОЛЬ, RF (INCLS 1-8, 10-14) (CASHMERE) 15876725 КОНСОЛЬ, RF (INCLS 1-8, 10-14) (TITANIUM) 15876726 КОНСОЛЬ, RF (INCLS 1-8, 10-14) (CASHMERE) teamcadillac.ru 15876731 КОНСОЛЬ, RF (INCLS 1-8, 10-15) (TITANIUM) 15876732 КОНСОЛЬ, RF (INCLS 1-8, 10-15) (CASHMERE) 15876733 КОНСОЛЬ, RF (INCLS 1-8, 10-15) (TITANIUM) 15876734 КОНСОЛЬ, RF (INCLS 1-8, 10-15) (CASHMERE) 25854585 КОНСОЛЬ, RF (INCLS 1-8, 10-15) (TITANIUM) 25854586 КОНСОЛЬ, RF (INCLS 1-8, 10-15) (CASHMERE) 25854588 КОНСОЛЬ, RF (INCLS 1-8, 10-15) (TITANIUM) 25854589 КОНСОЛЬ, RF (INCLS 1-8, 10-15) (CASHMERE) 11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (ЧАСТЬ OF 9) [ЗАЖИМ КОНСОЛИ САЛОНА] 25886564 LENS, RF CNSL RDG LP (ЧАСТЬ OF 9, 12) 25886562 ЛАМПА, RF CNSL CTSY & RDG (ЧАСТЬ OF 9) (INCLS 6, 7, 11) [ЛАМПА] 15246939 MICROPHONE, RDO VOL COMP INTR NOISE (ЧАСТЬ OF 9) (RDO VOL COMP) 15241529 MICROPHONE, MOBILE TEL (ЧАСТЬ OF 9) (2-WAY CAVITY) 25821823 ЛАМПА, RF CNSL CTSY (ЧАСТЬ OF 9) (PIN SPOT LED) (6D10-114) - 2008 DM69 КОНСОЛЬ/КРЫША (ЛЮК C3U, GARAGE OPENER UG1, EXC THEFT DETERENT) ↓ 11562028 БОЛТ, RF CNSL (ЧАСТЬ OF 11) not found PLATE, RF CNSL BKG (ЧАСТЬ OF 11) 25789090 SWITCH, SUN RF СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК (ЧАСТЬ OF 11) [ПЕРЕКЛЮЧАТЕЛЬ] 25789091 SWITCH, SUN RF (ЧАСТЬ OF 11) [ПЕРЕКЛЮЧАТЕЛЬ] 25886563 ЛАМПА, RF CNSL CTSY & RDG (ЧАСТЬ OF 11) (INCLS 6-8) [ЛАМПА] not found PUSHBUTTON, W/S HDR CTSY & RDG LP SW (ЧАСТЬ OF 5, 11, 14) 01999382 BULB, (ЧАСТЬ OF 5, 11, 14) (ACDelco #W5WLL) (LONGER LIFE) 25886565 LENS, RF CNSL RDG LP (ЧАСТЬ OF 5, 11) 15145260 TRANSMITTER, GARAGE DR OPENER (ЧАСТЬ OF 11) (W/O OWNERS INFO MANUAL) 20781584 TRANSMITTER, GARAGE DR OPENER (ЧАСТЬ OF 11) 20781584 TRANSMITTER, GARAGE DR OPENER (ЧАСТЬ OF 11) 25828896 PUSHBUTTON, GARAGE DR OPENER XMTR (ЧАСТЬ OF 11) (GRAY) 25828897 PUSHBUTTON, GARAGE DR OPENER XMTR (ЧАСТЬ OF 11) (CASHMERE) 15876699 КОНСОЛЬ, RF (INCLS 1-10, 12-17) (TITANIUM) 15876700 КОНСОЛЬ, RF (INCLS 1-10, 12-17) (CASHMERE) 15876701 КОНСОЛЬ, RF (INCLS 1-10, 12-17) (TITANIUM) 15876702 КОНСОЛЬ, RF (INCLS 1-10, 12-17) (CASHMERE) 15876713 КОНСОЛЬ, RF (INCLS 1-10, 12-17) (TITANIUM) 15876714 КОНСОЛЬ, RF (INCLS 1-10, 12-17) (CASHMERE) 15876715 КОНСОЛЬ, RF (INCLS 1-10, 12-17) (TITANIUM) 15876716 КОНСОЛЬ, RF (INCLS 1-10, 12-17) (CASHMERE) 15876727 КОНСОЛЬ, RF (INCLS 1-10, 12-17) (TITANIUM) 15876728 КОНСОЛЬ, RF (INCLS 1-10, 12-17) (CASHMERE) 15876729 КОНСОЛЬ, RF (INCLS 1-10, 12-17) (TITANIUM) 15876730 КОНСОЛЬ, RF (INCLS 1-10, 12-17) (CASHMERE) 25854579 КОНСОЛЬ, RF (INCLS 1-10, 12-16) (TITANIUM) 25854580 КОНСОЛЬ, RF (INCLS 1-10, 12-16) (CASHMERE) 25854582 КОНСОЛЬ, RF (INCLS 1-10, 12-16) (TITANIUM) teamcadillac.ru 25854583 КОНСОЛЬ, RF (INCLS 1-10, 12-16) (CASHMERE) 25862672 КОНСОЛЬ, RF (INCLS 1-10, 12-16) (TITANIUM) 25862673 КОНСОЛЬ, RF (INCLS 1-10, 12-16) (CASHMERE) 25862678 КОНСОЛЬ, RF (INCLS 1-10, 12-16) (TITANIUM) 25862679 КОНСОЛЬ, RF (INCLS 1-10, 12-16) (CASHMERE) 11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (ЧАСТЬ OF 11) [ЗАЖИМ КОНСОЛИ САЛОНА] 25886564 LENS, RF CNSL RDG LP (ЧАСТЬ OF 11, 14) 25886562 ЛАМПА, RF CNSL CTSY & RDG (ЧАСТЬ OF 11) (INCLS 6, 7, 13) [ЛАМПА] 15246939 MICROPHONE, RDO VOL COMP INTR NOISE (ЧАСТЬ OF 11) (RDO VOL COMP) 15241529 MICROPHONE, MOBILE TEL (ЧАСТЬ OF 11) (2-WAY CAVITY) 25821823 ЛАМПА, RF CNSL CTSY (ЧАСТЬ OF 11) (PIN SPOT LED) (6D10-115) - 2008 DM69 КОНСОЛЬ/КРЫША (ЛЮК C3U, THEFT DETERENT UA2, EXC GARAGE OPENER UG1) ↓ 11562028 БОЛТ, RF CNSL (ЧАСТЬ OF 10) not found PLATE, RF CNSL BKG (ЧАСТЬ OF 10) 25789090 SWITCH, SUN RF СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК (ЧАСТЬ OF 10) [ПЕРЕКЛЮЧАТЕЛЬ] 25789091 SWITCH, SUN RF (ЧАСТЬ OF 10) [ПЕРЕКЛЮЧАТЕЛЬ] 25886563 ЛАМПА, RF CNSL CTSY & RDG (ЧАСТЬ OF 10) (INCLS 6-8) [ЛАМПА] not found PUSHBUTTON, W/S HDR CTSY & RDG LP SW (ЧАСТЬ OF 5, 10, 13) 01999382 BULB, (ЧАСТЬ OF 5, 10, 13) (ACDelco #W5WLL) (LONGER LIFE) 25886565 LENS, RF CNSL RDG LP (ЧАСТЬ OF 5, 10) 15283682 SENSOR, THEFT DTRNT (ЧАСТЬ OF 10) [ДАТЧИК НАКЛОНА КУЗОВА] 15876717 КОНСОЛЬ, RF (INCLS 1-9, 11-15) (TITANIUM) 15876718 КОНСОЛЬ, RF (INCLS 1-9, 11-15) (CASHMERE) 15876719 КОНСОЛЬ, RF (INCLS 1-9, 11-16) (TITANIUM) (OH SNRF CNSL W/INTR, LED & W/O VNC MIC) teamcadillac.ru 15876720 КОНСОЛЬ, RF (INCLS 1-9, 11-16) (CASHMERE) (OH SNRF CNSL W/INTR, LED & W/O VNC MIC) 15876721 КОНСОЛЬ, RF (INCLS 1-9, 11-16) (TITANIUM) (OH SNRF CNSL W/INTR, LED, & VNC MIC) 15876722 КОНСОЛЬ, RF (INCLS 1-9, 11-16) (CASHMERE) (OH SNRF CNSL W/INTR, LED, & VNC MIC) 15876735 КОНСОЛЬ, RF (INCLS 1-9, 11-15) (TITANIUM) 15876736 КОНСОЛЬ, RF (INCLS 1-9, 11-15) (CASHMERE) 25822398 КОНСОЛЬ, RF (INCLS 1-9, 11-16) (TITANIUM) 25822399 КОНСОЛЬ, RF (INCLS 1-9, 11-16) (CASHMERE) 25822404 КОНСОЛЬ, RF (INCLS 1-9, 11-15) (TITANIUM) 25822405 КОНСОЛЬ, RF (INCLS 1-9, 11-15) (CASHMERE) 11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (ЧАСТЬ OF 10) [ЗАЖИМ КОНСОЛИ САЛОНА] 25886564 LENS, RF CNSL RDG LP (ЧАСТЬ OF 10, 13) 25886562 ЛАМПА, RF CNSL CTSY & RDG (ЧАСТЬ OF 10) (INCLS 6, 7, 12) [ЛАМПА] 15240415 MICROPHONE, RDO VOL COMP INTR NOISE (ЧАСТЬ OF 10) 15241529 MICROPHONE, MOBILE TEL (ЧАСТЬ OF 10) (2-WAY CAVITY) 25821823 ЛАМПА, RF CNSL CTSY (ЧАСТЬ OF 10) (PIN SPOT LED) 11 - ЗАДНЕЕ СТЕКЛО - ДЕТАЛИ СИДЕНЬЯ - РЕГУЛЯТОР (6D11-012) - 2008 DM69 ЗАДНЕЕ ОКНО ↓ 25879313 WINDOW, RR (INCLS 2, 3) (INCLS MOLDING) [СТЕКЛО] 25879314 WINDOW, RR (INCLS 2, 3) [ОКНО] not found MOLDING, R/WDO LWR RVL (ЧАСТЬ OF 1) teamcadillac.ru not found MOLDING, R/WDO UPR RVL (ЧАСТЬ OF 1) 12 - МОЛДИНГИ - КУЗОВ - ЗАДНЯЯ ЧАСТЬ - КРЫША (6D12-052) - 2008 DM69 КУЗОВНЫЕ ДЕТАЛИ ЧАСТЬ 1-ДВИГАТЕЛЬНЫЙ ОТСЕК & DASH(MN6,MX0) ↓ 25811623 RAIL, F/CMPT OTR SI UPR [РЕЙЛИНГ] 25954300 RAIL, F/CMPT OTR SI UPR [ПАНЕЛЬ КОЛЕСНОЙ АРКИ] 25878468 REINFORCEMENT, BODY H/PLR UPR 25878469 REINFORCEMENT, BODY H/PLR UPR 15923694 PANEL, BODY H/PLR INR (INCLS 31) (USED ON VEHICLES BUILT PRIOR TO NOV 5, 2007) (FOR 2ND DES SEE 25909945) 15923695 PANEL, BODY H/PLR INR (INCLS 31) (USED ON VEHICLES BUILT PRIOR TO NOV 5, 2007) (FOR 2ND DES SEE 25909946) 25909945 PANEL, BODY H/PLR INR (INCLS 31) (USED ON VEHICLES BUILT ON/AFTER NOV 5, 2007) (FOR 1ST DES SEE 15923694) 25909946 PANEL, BODY H/PLR INR (INCLS 31) 25909946 PANEL, BODY H/PLR INR (INCLS 31) (USED ON VEHICLES BUILT ON/AFTER NOV 5, 2007) (FOR 1ST DES SEE 15923695) not found PANEL, PLNM LWR not found PANEL, W/S FRM & PLNM 25785092 BARRIER, BRK PED BRKT SND 25913292 BARRIER, BRK PED BRKT SND 25696592 SUPPORT, PARK BRK FRT CBL 11518350 ГАЙКА, TRANS SUPT (ЧАСТЬ OF 9) (M10X1.5X24MM) 25710948 REINFORCEMENT, TRANS SUPT (INCLS 8) 25719541 REINFORCEMENT, TRANS SUPT (INCLS 8) 25723917 REINFORCEMENT, TRANS SUPT (INCLS 8) 25723918 REINFORCEMENT, TRANS SUPT (INCLS 8) not found RAIL, TRANS MT SUPT FRT not found RAIL, TRANS MT SUPT FRT not found REINFORCEMENT, DA PNL (AT STRG COL OPG) not found BAR, FLR PNL #1 CR not found REINFORCEMENT, FLR PNL #1 C/BAR (ЧАСТЬ OF 17) not found REINFORCEMENT, F/CMPT S/RL RR (ЧАСТЬ OF 17) not found RAIL, F/CMPT RR SI (ЧАСТЬ OF 17) 20765259 RAIL, F/CMPT SI (INCLS 14-16, 18-24) (FULL VERSION) 20818956 RAIL, F/CMPT SI (INCLS 14-16, 18-24) (FULL VERSION) not found EXTENSION, FLR PNL #1 C/BAR (ЧАСТЬ OF 17) not found REINFORCEMENT, FLR PNL #1 C/BAR OTR (ЧАСТЬ OF 17) not found ГАЙКА, ENG MT C/MBR (ЧАСТЬ OF 17) 15923685 RAIL, F/CMPT SI (ЧАСТЬ OF 17) (INCLS 22) (FRT/SHORT VERSION) [РЕЙЛИНГ] 15923686 RAIL, F/CMPT SI (ЧАСТЬ OF 17) (INCLS 22) (FRT/SHORT VERSION) [РЕЙЛИНГ] not found RAIL, F/CMPT OTR SI LWR (ЧАСТЬ OF 17, 21) not found BRACKET, FRT W/H LWR FRT PNL (ЧАСТЬ OF 17) not found EXTENSION, F/CMPT OTR S/RL (ЧАСТЬ OF 17) 15900643 BRACKET, F/END UPR TIE BAR (ЧАСТЬ OF 26) [КРОНШТЕЙН] 25851728 BAR, F/END UPR TIE (INCLS 25, 28) 25922923 REINFORCEMENT, F/END UPR TIE BAR 25922924 REINFORCEMENT, F/END UPR TIE BAR [КРОНШТЕЙН ПАНЕЛИ КУЗОВА] 15900644 BRACKET, F/END UPR TIE BAR (ЧАСТЬ OF 26) [КРОНШТЕЙН] 25932610 PANEL, FRT W/H (INCLS 33) [ПАНЕЛЬ КОЛЕСНОЙ КОРОБКИ] 25932611 PANEL, FRT W/H (INCLS 33) not found PANEL, DA UPR EXTN not found PANEL, BODY H/PLR INR (ЧАСТЬ OF 3) 11609990 STUD, КАПОТ OPEN ASST ROD BRKT (M8X1.25X20) [ШПИЛЬКА М8] not found BRACKET, КАПОТ OPEN ASST ROD (ЧАСТЬ OF 29) 10384299 REINFORCEMENT, FRT W/H PNL RR BR 11518808 БОЛТ ASM HEX HD CON SPA WS, M6X1.0X20, GMW25M (8.8) STL, GMW3179 (FRT W/H PNL RR BR) (6D12-053) - 2008 DM69 КУЗОВНЫЕ ДЕТАЛИ ЧАСТЬ 3-БОКОВЫЕ ЧАСТИ ↓ 25896501 REINFORCEMENT, RF FRT HDR PNL (INCLS 29) 25896502 REINFORCEMENT, RF FRT HDR PNL (INCLS 29) 25883742 RAIL, RF INR SI 25883743 RAIL, RF INR SI 25912193 PANEL, QTR INR UPR 25941320 PANEL, QTR INR UPR 15292408 BRACE, QTR INR PNL 15292409 BRACE, QTR INR PNL not found FILLER, QTR OTR PNL AT R/WDO LWR (ЧАСТЬ OF 18) 15264264 FILLER, QTR OTR PNL (ЧАСТЬ OF 18) 15264265 FILLER, QTR OTR PNL (ЧАСТЬ OF 18) 25937917 REINFORCEMENT, R/CMPT LID HGE (BODY SI) (ЧАСТЬ OF 18) (USE ON VEHS W/FLAT TAB & NO S-SHAPED STEP) 25937918 REINFORCEMENT, R/CMPT LID HGE (BODY SI) (ЧАСТЬ OF 18) (USE ON VEHS W/FLAT TAB & NO S-SHAPED STEP) not found FILLER, R/CMPT FLR PNL (TO QTR OTR PNL) (ЧАСТЬ OF 18) 15251245 PANEL, RR W/H OTR (BUILT PRIOR TO 12/03/07) (FOR 2ND DES SEE 25823354) 25823354 PANEL, RR W/H OTR (BUILT 12/03/07 & AFTER) (FOR 1ST DES SEE 15251245) (FOR '08 MY'S MAY NEED TO ADD ELECTRICAL HOLE) [ПАНЕЛЬ ЗАДНЕЙ ЧЕТВЕРТИ КУЗОВА] 25942286 PANEL, RR W/H OTR 15923689 REINFORCEMENT, C/PLR OTR PNL (INCLS 11, 13) [ЦЕНТРАЛЬНАЯ СТОЙКА КУЗОВА] 15923690 REINFORCEMENT, C/PLR OTR PNL (INCLS 11, 13) [ЦЕНТРАЛЬНАЯ СТОЙКА КУЗОВА] 15265467 REINFORCEMENT, RR S/D UPR HGE (BODY SI) (ЧАСТЬ OF 10) teamcadillac.ru 15265468 REINFORCEMENT, RR S/D UPR HGE (BODY SI) (ЧАСТЬ OF 10) 15261679 REINFORCEMENT, BODY SI FRM LWR RR (USED ON VEHICLES BUILT ON 11/25/07 AND PRIOR) (FOR 2ND DES SEE 25909574) 25909574 REINFORCEMENT, BODY SI FRM LWR RR (USED ON VEHICLES BUILT ON 11/26/07 AND AFTER) (FOR 1ST DES SEE 15261679) 25909575 REINFORCEMENT, BODY SI FRM LWR RR 15265547 REINFORCEMENT, RR S/D LWR HGE (BODY SI) (ЧАСТЬ OF 10) 15265548 REINFORCEMENT, RR S/D LWR HGE (BODY SI) (ЧАСТЬ OF 10) not found REINFORCEMENT, RR S/D LK STKR (ЧАСТЬ OF 18) 15887529 BRACKET, F/FDR RR CTR (ЧАСТЬ OF 18) 15887530 BRACKET, F/FDR RR CTR (ЧАСТЬ OF 18) [ОПОРНЫЙ УГОЛОК ПЕРЕДНЕГО КРЫЛА] 25724779 BRACKET, F/FDR RR CTR (ЧАСТЬ OF 18) [КРОНШТЕЙН] 25843268 BRACKET, F/FDR RR UPR (ЧАСТЬ OF 18) [КРОНШТЕЙН] 25843269 BRACKET, F/FDR RR UPR (ЧАСТЬ OF 18) [КРОНШТЕЙН] 15270553 BRACKET, F/FDR UPR (ЧАСТЬ OF 18) 25910662 РАМА, BODY SI OTR (INCLS 5-8, 14-17) [БОКОВИНА КУЗОВА] 25910663 РАМА, BODY SI OTR (INCLS 5-8, 14-17) 15923693 REINFORCEMENT, FRT S/D OPG FRM LWR [ЦЕНТРАЛЬНАЯ СТОЙКА КУЗОВА] 20856311 REINFORCEMENT, FRT S/D OPG FRM LWR 15248653 PANEL, RKR INR 25912301 PANEL, RKR INR 15923694 PANEL, BODY H/PLR INR (INCLS 22) (USED ON VEHICLES BUILT PRIOR TO NOV 5, 2007) (FOR 2ND DES SEE 25909945) 15923695 PANEL, BODY H/PLR INR (INCLS 22) (USED ON VEHICLES BUILT PRIOR TO NOV 5, 2007) (FOR 2ND DES SEE 25909946) 25909945 PANEL, BODY H/PLR INR (INCLS 22) (USED ON VEHICLES BUILT ON/AFTER NOV 5, 2007) (FOR 1ST DES SEE 15923694) 25909946 PANEL, BODY H/PLR INR (INCLS 22) 25909946 PANEL, BODY H/PLR INR (INCLS 22) (USED ON VEHICLES BUILT ON/AFTER NOV 5, 2007) (FOR 1ST DES SEE 15923695) not found PANEL, BODY H/PLR INR (ЧАСТЬ OF 21) 25878468 REINFORCEMENT, BODY H/PLR UPR 25878469 REINFORCEMENT, BODY H/PLR UPR 25861874 РАМА, W/S OTR SI [РАМА] 25861875 РАМА, W/S OTR SI [РАМА] 15265459 PANEL, C/PLR INR (INCLS 26) 15265460 PANEL, C/PLR INR (INCLS 26) not found REINFORCEMENT, C/PLR INR PNL (ЧАСТЬ OF 25) 25832650 PANEL, RR W/H INR (VEHICLES BUILT PRIOR TO 12/17/07) (FOR 2ND DES SEE 25906430) 25832651 PANEL, RR W/H INR 25906430 PANEL, RR W/H INR (VEHICLES BUILT ON OR AFTER 12/17/07) (FOR 1ST DES SEE 25832650) 25868836 RAIL, RF OTR SI [РЕЙЛИНГ] 25868837 RAIL, RF OTR SI [РЕЙЛИНГ] 11570654 ГАЙКА, S/S SUPT (ЧАСТЬ OF 1) (4.2 X 1.41) (FITS 8.75 SQ HOLE) (9.665) (6D12-054) - 2008 DM69 КУЗОВНЫЕ ДЕТАЛИ ЧАСТЬ 4-КРЫША (DELETE ЛЮК CFN) ↓ 25945452 PANEL, RF 15257370 PANEL, RF RR HDR teamcadillac.ru 15821522 PANEL, RF FRT HDR (6D12-055) - 2008 DM69 КУЗОВНЫЕ ДЕТАЛИ ЧАСТЬ 5-НИЖНЯЯ ЧАСТЬ & ЗАДНИЙ END ↓ 25883364 PANEL, R/FLR (INCLS 5) (TRIM TO FIT RR OF RIGHT RR КОЛЕСО WELL) 25917995 TRAY, BAT 25988345 PANEL, R/END (INCLS 4) [ЗАДНЯЯ КОНЦЕВАЯ ПАНЕЛЬ] not found BRACKET, R/CMPT SI CPT SUPT (ЧАСТЬ OF 3) 25650571 BRACKET, SPA WHL STOW (ЧАСТЬ OF 1) 25675853 BRACKET, F/TNK not found BAR, FLR PNL #4 not found PLATE, R/SEAT BELT ANC (BKL SI) 25859827 REINFORCEMENT KIT, R/CMPT FLR PNL RL INTER (INSTRUCTION #19120709) 25859828 REINFORCEMENT KIT, R/CMPT FLR PNL RL INTER 15217298 EXTENSION, R/FLR PNL RR (ЧАСТЬ OF 15) [КРОНШТЕЙН ПАНЕЛИ ПОРОГА КУЗОВА] 20777228 RAIL, R/CMPT FLR PNL (W/RR SUSP SUPT) (INCLS 13, 14) (ЧАСТЬ OF 15) 20777229 RAIL, R/CMPT FLR PNL (W/RR SUSP SUPT) (INCLS 13, 14) (ЧАСТЬ OF 15) not found REINFORCEMENT, R/CMPT FLR PNL RL EXTN (ЧАСТЬ OF 12, 15) 25664871 EXTENSION, R/CMPT FLR PNL RL (ЧАСТЬ OF 12, 15) (FOR RH OR LH) [РАЗШИРИТЕЛЬ] 15929324 RAIL, R/CMPT FLR PNL RR (INCLS 11-14, 16, 17) [РЕЙЛИНГ МЕТАЛЛИЧЕСКОГО КАРКАСА КУЗОВА] 15929325 RAIL, R/CMPT FLR PNL RR (INCLS 11-14, 16, 17) [РЕЙЛИНГ МЕТАЛЛИЧЕСКОГО КАРКАСА КУЗОВА] 11519001 ГАЙКА, HEX M16X2.0X37.9, OD 50, SAE1010, PLAIN.TEFLON PER GM6076M (ЧАСТЬ OF 15) (8.899) 25911674 REINFORCEMENT, RR SUSP SUPT (ЧАСТЬ OF 15) 25911675 REINFORCEMENT, RR SUSP SUPT (ЧАСТЬ OF 15) 15251409 EXTENSION, FLR PNL #5 C/BAR 15774787 BAR, FLR PNL #5 not found REINFORCEMENT, FLR PNL #4 C/BAR not found PANEL, F/FLR 25752041 REINFORCEMENT, FLR PNL #4 C/BAR 25693149 BRACKET, PARK BRK CBL (ATTACHES TO RR SUSP) 25693150 BRACKET, PARK BRK CBL (ATTACHES TO RR SUSP) not found REINFORCEMENT, FLR PNL CTR not found PANEL, FLR PNL FIL (AT TUN PNL) not found BRACKET, F/FLR CNSL RR not found BRACKET, VEH YAW SEN & LATL ACCLRM not found REINFORCEMENT, FLR PNL AT TUN PNL not found BAR, FLR PNL #2 CR not found EXTENSION, FLR PNL #2 C/BAR not found REINFORCEMENT, FLR PNL #2 C/BAR not found REINFORCEMENT, FLR PNL #2 C/BAR not found BAR, FLR PNL #2 CR not found EXTENSION, FLR PNL #2 C/BAR not found BAR, FLR PNL #3 CR not found EXTENSION, FLR PNL #3 C/BAR not found REINFORCEMENT, FLR PNL #4 C/BAR not found BAR, FLR PNL #3 CR not found EXTENSION, FLR PNL #3 BAR not found BAR, FLR PNL #4 CR teamcadillac.ru not found EXTENSION, FLR PNL #4 C/BAR not found REINFORCEMENT, FLR PNL #4 BAR UPR not found EXTENSION, FLR PNL #4 C/BAR not found PLATE, CHILD ST RST SYS BELT BRKT ANC not found PLATE, CHILD ST RST SYS BELT BRKT ANC not found SUPPORT, R/SEAT H/RST 15259372 REINFORCEMENT, R/WDO PNL 15259373 REINFORCEMENT, R/WDO PNL 25942405 PANEL, R/WDO 15264263 PANEL, R/WDO DRN (6D12-056) - 2008 DM69 КОЛЕСОHOUSE LINER/ЗАДНИЙ ↓ 15274471 LINER, RR W/H PNL [УДЛИНИТЕЛЬ] 25954779 LINER, RR W/H PNL [ПОДКРЫЛОК] teamcadillac.ru 21030249 RETAINER, EXPAN, 21 LG, 20. OD, 8.0 HOLE, 3.0-5.0 PNL, NYLON 6/6, BLK (RR W/H PNL LNR) (8.950) (PUSH IN) [ПИСТОН КРЕПЛЕНИЯ КОЖУХА РАДИАТОРА(ПЛАСТИК)] (6D12-057) - 2008 DM69 КУЗОВНЫЕ ДЕТАЛИ ЧАСТЬ 4-КРЫША (ЛЮК C3U) ↓ 25948397 PANEL, SUN RF (INCLS 3) 15257370 PANEL, RF RR HDR not found REINFORCEMENT, SUN RF OPG (ЧАСТЬ OF 1) teamcadillac.ru 15821522 PANEL, RF FRT HDR 11561765 БОЛТ - HWASH, M6X1X15, 7.5 THD, 24 OD, 8.8, GMW3359, (RF INR S/RL REINF) (6D12-058) - 2008 DM69 ВОДОСТОК КРЫШИ (C3U) ↓ 15241393 HOSE, SUN RF HSG RR DRN 25875179 HOSE, SUN RF HSG RR DRN 15241395 HOSE, SUN RF HSG FRT DRN teamcadillac.ru 15241396 HOSE, SUN RF HSG FRT DRN (6D12-059) - 2008 DM69 ЛЮК (C3U) ↓ 25951872 SEAL, SUN RF WDO (ЧАСТЬ OF 2) (RR WDO) [УПЛОТНИТЕЛЬ ЛЮКА КРЫШИ] 15936277 WINDOW, SUN RF (INCLS 1) (RR) [ОКНО В СБОРЕ] 15936283 БОЛТ, SUN RF WDO 15936278 БОЛТ, SUN RF HSG RR SUPT 15936276 WINDOW, SUN RF (INCLS 23) (FRT) 15936279 GUIDE, SUN RF S/S 25875192 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, SUN RF (INCLS 26) (CASHMERE) 25875193 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, SUN RF (INCLS 26) (TITANIUM) 11518523 БОЛТ, W/WASHER, M6X1X45, 38 THD, 17 OD, 8.8, GMW3359, MPOINT (SUN RF MDL) 15936271 БОЛТ, SUN RF MDL 15936272 BRACKET, SUN RF MDL 25790824 BRACKET, SUN RF MDL 22686577 БОЛТ, SUN RF ACTR (TO MOTOR ASM) 25983779 MOTOR, SUN RF WDO (W/CONT MDL) 22686577 БОЛТ, SUN RF S/S MOT (TO MOTOR ASM) 25983779 MOTOR, SUN RF S/S (W/ CONT MDL) 15936282 HARNESS, SUN RF SW WRG 11588260 БОЛТ/SCREW, HEX W/ CON WA, M6X1X23 (SUN RF MDL) (SEE CATALOGUE) not found ПРУЖИНА, SUN RF HSG DRN GTR 25852812 ПРУЖИНА, SUN RF HSG DRN GTR (7.412) 25790822 БОЛТ, SUN RF HSG DRN GTR 25852813 TAPE, SUN RF A/DFL 20823965 РАМА, SUN RF (LESS GLASS, MOTOR, TRIM) (WHEN REPL '08 РАМА W/20823965 РАМА, OLD СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК CAN BE USED T/W 20814549 RETAINER) 15936273 DEFLECTOR, SUN RF AIR 25852814 COVER, SUN RF PNL SI OPG CLOSEOUT (RUBBER SEAL) 15936274 SEAL, SUN RF WDO (ЧАСТЬ OF 5) (FRONT WDO) 15936285 GUTTER, SUN RF HSG DRN (INCLS 25) 25852811 SEAL, SUN RF WDO (ЧАСТЬ OF 24) (GUTTER SEAL) teamcadillac.ru not found RETAINER, SUN RF S/S FABRIC (ЧАСТЬ OF 7) (6D12-060) - 2008 DM69 ЗАДНЯЯ АРМАТУРА ↓ 25943891 GROMMET, RR LIC PLT BRKT 25943892 GROMMET, RR LIC PLT BRKT 25903862 LID, R/CMPT (USE T/W LID I/S HANDLE 12785350) 11514623 БОЛТ, HEX W/CON WA, M6X1X20 (R/CMPT LID LAT) 25885392 LATCH, R/CMPT LID [ЗАЩЕЛКА] 25863964 COVER, R/CMPT LID LAT [КОЖУХ ЗАМКА ДВЕРИ] 25946495 STRIKER, R/CMPT LID LAT 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (R/CMPT LID LAT REL CBL HDL) [ГАЙКА М6] 19168862 WEATHERSTRIP, R/CMPT LID [УПЛОТНИТЕЛЬ КРЫШКИ БАГАЖНИКА] 22702778 VALVE, QTR OTR PNL PRESS RLF [КЛАПАН] 11609540 БОЛТ, HWASH, M6X1X20, 16.15 THD, 17 OD, 8.8, GMW4205, HDR PT. (R/CMPT LID LAT STKR) [ВИНТ] 15714276 SCREW, HWH, W/FL WA, SELF TAP, M4.2X1.41X18, 12.5 O.D., 6010M, PS (L/GATE I/S ASST HDL) (8.977) 15929859 HINGE, R/CMPT LID [ПЕТЛЯ] 15929860 HINGE, R/CMPT LID [ПЕТЛЯ] 15861471 HANDLE, L/GATE I/S ASST (EBONY) (10.512) teamcadillac.ru 25896511 BUMPER, R/CMPT LID HGE 11518531 ГАЙКА, U-TYPE, M4.2X1.41, 15.9X8.4, .7-2.1 PNL, SAE 1050 STL, 7111M, 8.65 SQ HOL (L/GATE ASST STRP) (10.512) [ГАЙКА М10] 11569592 БОЛТ-HFH W/SHLDR, M8X1.25X21, 10 THD, 18.8 OD, 9.8, GMW3359, 3X10.75 SHLDR (R/CMPT LID HGE (BODY SI)) 15247598 STRUT, R/CMPT LID [АМОРТИЗАЦИОННАЯ СТОЙКА БАГАЖНОЙ ДВЕРИ] 11609540 БОЛТ, HWASH, M6X1X20, 16.15 THD, 17 OD, 8.8, GMW4205, HDR PT. (R/CMPT LID HGE (LID SI)) [ВИНТ] 15877980 BUMPER, R/CMPT LID OTR 15259076 PLUG, R/CMPT LID PNL GA HOLE (6.35MM) (ROUND) (10.571) 25805688 BUMPER, RR LIC PLT 11569985 CLIP, R/CMPT LID LWR MLDG (ЧАСТЬ OF 26) 11569711 ГАЙКА, PUSH-IN, M4.2X1.41, 0.7-2.15 PNL THK, SAE 1050-1065, GMW3359 W/ (R/CMPT LID MLDG) [ГАЙКА М4.2] 11588458 STUD, DBL END 6-LOBED W/COLLAR M6X1X28.8 GM6010M GM613M (ЧАСТЬ OF 26) 11519612 ГАЙКА, HX CON SPR WA W/SEALER M6X1.0 6H GM510M (9) STL GM7111M (R/CMPT LID LWR MLDG) 25890524 MOLDING, R/CMPT LID LWR (INCLS 22, 24, 27) (KEYLESS TOUCHPAD ENTRY R/CMPT) [МОЛДИНГ] 25890525 MOLDING, R/CMPT LID LWR (INCLS 22, 24, 27) (KEYLESS TOUCHPAD ENTRY R/CMPT) [МОЛДИНГ] 25873332 HARNESS, RR LIC PLT LP WRG (INCLS 28) (ЧАСТЬ OF 26) [ПРОВОДКА КУЗОВА] 25873333 HARNESS, RR LIC PLT LP WRG (INCLS 28) (ЧАСТЬ OF 26) 11610092 SCREW, PAN HD W/FL WA, M4.2X1.41X20, 12.5 OD, 6010M, GMW4205, T 15 TOR (R/CMPT LID LWR MLDG) 25885376 SWITCH, L/GATE REL (ЧАСТЬ OF 26) (16.263) (ACDelco #D1432G) 10390945 CAP, R/CMPT LID HGE ADJ БОЛТ (6D12-061) - 2008 DM69 МОЛДИНГИ-ABOVE BELT ↓ 25891058 MOLDING, BODY SI WDO RVL (INCLS 2) 25891059 MOLDING, BODY SI WDO RVL (INCLS 2) 25796285 RETAINER, C/PLR UPR FIN MLDG (ЧАСТЬ OF 1) [ФИКСАТОР МОЛДИНГА КУЗОВА] 25891056 MOLDING, C/PLR (INCLS 4, 5) teamcadillac.ru 25891057 MOLDING, C/PLR (INCLS 4, 5) 25796285 RETAINER, C/PLR UPR FIN MLDG (ЧАСТЬ OF 3) [ФИКСАТОР МОЛДИНГА КУЗОВА] 11569920 RETAINER, F/FDR UPR RR R/MLDG (ЧАСТЬ OF 3) [ФИКСАТОР КОЖУХА ЗЕРКАЛА ЗАДНЕГО ОБЗОРА] 25886851 MOLDING, RR S/D WDO BELT RVL (WITHOUT NOTCH AT OUTER BELT) (IF USING TO REPLACE MOLDING ASM 25843096 (W/O NOTCH @ OTR BELT), MAY REQUIRE TO ORDER T/W 25886852 FOR CUSTOMER APPEARANCE SATISFACTION) [МОЛДИНГ СТЕКЛА ДВЕРИ] 25886852 MOLDING, RR S/D WDO BELT RVL (WITHOUT NOTCH @ OUTER BELT) (IF USING TO REPLACE MOLDING ASM 25843097 (INCLS NOTCH @ OTR BELT), MAY REQUIRE TO ORDER T/W 25886851 FOR CUSTOMER APPEARANCE SATISFACTION) 25944116 APPLIQUE, RR S/D WDO FRM RR (NON-GRAINED APPLIQUE) (FOR 2ND DES SEE 25955039) 25944117 APPLIQUE, RR S/D WDO FRM RR (NON-GRAINED APPLIQUE) (FOR 2ND DES SEE 25955040) [НАКЛАДКА ПАНЕЛИ ДВЕРИ] 25955039 APPLIQUE, RR S/D WDO FRM RR (GRAINED APPLIQUE) (FOR 1ST DES SEE 25944116) [НАКЛАДКА ПАНЕЛИ ДВЕРИ] 25955040 APPLIQUE, RR S/D WDO FRM RR (GRAINED APPLIQUE) (FOR 1ST DES SEE 25944117) [САМОКЛЕЯЩАЯСЯ ДЕКОРАТИВНАЯ ПЛЕНКА ПАНЕЛИ ДВЕРИ] 25944114 APPLIQUE, FRT S/D WDO FRM RR (NON-GRAINED) (FOR 2ND DES SEE 25955037) [НАКЛАДКА ПАНЕЛИ ДВЕРИ] 25944115 APPLIQUE, FRT S/D WDO FRM RR (NON GRAINED; BUILT BEFORE 9/24/07) (FOR 3RD DES SEE 25955038) [НАКЛАДКА ПАНЕЛИ ДВЕРИ] 25955037 APPLIQUE, FRT S/D WDO FRM RR (GRAINED) (FOR 1ST DES SEE 25944114) [МОЛДИНГ КУЗОВА] 25955038 APPLIQUE, FRT S/D WDO FRM RR (GRAINED; BUILT/AFTER 9/24/07) (FOR 2ND DES SEE 25944115) [НАКЛАДКА ПАНЕЛИ ДВЕРИ] 25909260 MOLDING, FRT S/D WDO BELT RVL [МОЛДИНГ КРЫШИ] 25909261 MOLDING, FRT S/D WDO BELT RVL [МОЛДИНГ КУЗОВА] (6D12-062) - 2008 D69 МОЛДИНГИ-BELOW BELT ↓ 25851105 ORNAMENT, F/FDR (INCLS 6) [ВСТАВКА ПЕРЕДНЕГО КРЫЛА] 25851106 ORNAMENT, F/FDR (INCLS 6) [ВСТАВКА ПЕРЕДНЕГО КРЫЛА] 25648693 RETAINER, RKR PNL MLDG (ЧАСТЬ OF 4) (GRAY) [ФИКСАТОР МОЛДИНГА ДВЕРИ] 10323057 RETAINER, RKR PNL MLDG (ЧАСТЬ OF 4) (NATURAL) [ФИКСАТОР МОЛДИНГА ПОРОГА КУЗОВА] 20757448 MOLDING, RKR PNL (INCLS 2, 3, 18) (PRIMED) (КРАСКА TO MATCH) [ПАНЕЛЬ ПОРОГА КУЗОВА] 25902111 MOLDING, RKR PNL (INCLS 2, 3, 18) (PRIMED) (КРАСКА TO MATCH) [ПАНЕЛЬ ПОРОГА КУЗОВА] 15223484 EMBLEM, F/FDR (SMALL, GM MARK OF EXCELLENCE) (12.112) [ЭМБЛЕМА] not found RETAINER, F/FDR ORNAMENT (ЧАСТЬ OF 1) 15263151 EMBLEM, R/CMPT LID (WREATH) [ЭМБЛЕМА СБОРН.-КРЫШКИ БАГАЖН] 15263152 EMBLEM, R/CMPT LID (CREST) [ЭМБЛЕМА СБОРН.-КРЫШКИ БАГАЖН] 15263153 PLATE, R/CMPT LID NA (CTS, RH) 25789084 PLATE, R/CMPT LID NA (CTS 4) [ЭМБЛЕМА CTS 4] 11569985 CLIP, R/CMPT LID LWR MLDG (ЧАСТЬ OF 12) 25890524 MOLDING, R/CMPT LID LWR (СМ. ГРУППУ 12.000 "ЗАДНЯЯ АРМАТУРА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS 11) (KEYLESS TOUCHPAD ENTRY R/CMPT) [МОЛДИНГ] 25890525 MOLDING, R/CMPT LID LWR (СМ. ГРУППУ 12.000 "ЗАДНЯЯ АРМАТУРА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS 11) (KEYLESS TOUCHPAD ENTRY R/CMPT) [МОЛДИНГ] 15264308 MOLDING, RR BPR FASCIA [МОЛДИНГ БАМПЕРА] 25844607 PLATE, R/CMPT LID NA (DIRECT INJECTION) [ЭМБЛЕМА DIRECT INJECTION] 25841627 PLATE, R/CMPT LID NA (3.6) [ЭМБЛЕМА 3.6] 10387855 PLATE, R/CMPT LID NA (CHROME) (CADILLAC) (FOR EXPORT ONLY) [ЭМБЛЕМА CADILLAC] 25823426 PLATE, FRT S/D SILL TR (CADILLAC NAME PLT ONLY) [ТАБЛИЧКА] 25951244 PROTECTOR, RKR PNL RR MLDG (ЧАСТЬ OF 4) [НАКЛАДКА ПОРОГА КУЗОВА] teamcadillac.ru 25951245 PROTECTOR, RKR PNL RR MLDG (ЧАСТЬ OF 4) (6D12-063) - 2008 DM69 ПЕРЕХОДНИКИ/BODY ↓ 25925125 INSULATOR, FLR PNL R/SEAT 10376174 BARRIER, RR W/H INR PNL UPR SND not found DEADENER, R/CMPT FLR PNL 25757810 DEADENER, R/CMPT FLR PNL (390X150) (W/O HOLE) (RECTANGULAR IN SHAPE) (12.980) not found SEAL, R/END PNL not found TAPE, QTR OTR PNL FIL teamcadillac.ru 11515174 SEALING STRIP, FLR PNL DRN HOLE CVR (4 1/4" X 7 1/2") (TRIM AS REQ'D) (12.941) not found DEADENER, FLR PNL RR 25757810 DEADENER, FLR PNL TUN FRT (390X150) (W/O HOLE) (RECTANGULAR IN SHAPE) 25784232 INSULATOR, EXH H/SHLD (INCLS 11) (RWD) (12.980) 25805178 INSULATOR, EXH H/SHLD (INCLS 11) 25964067 INSULATOR, EXH H/SHLD (INCLS 11) [ТЕРМОЗАЩИТНЫЙ ЭКРАН ВЫХЛОПНОЙ ТРУБЫ] 11570585 ГАЙКА, EXH H/SHLD (ЧАСТЬ OF 10) 15250712 BARRIER, F/FLR PNL F/FLR CNSL SND (RWD) 15250712 BARRIER, F/FLR PNL F/FLR CNSL SND (RWD) 15263003 BARRIER, F/FLR PNL F/FLR CNSL SND (AWD) not found DEADENER, FLR PNL FRT 25722024 BARRIER, DA PNL INTR SND (1 LH SI OF TUNNEL) (1 RH SI - PASS THRU DR) (TWO PIECE) 11515174 INSULATOR, BODY SI INR PNL (4 1/4" X 7 1/2") (TRIM AS REQ'D) not found DEADENER, DA PNL 25872977 SEALING STRIP, BODY H/PLR INR PNL (TO PLNM PNL) 25872978 SEALING STRIP, BODY H/PLR INR PNL (TO PLNM PNL) 25883757 BARRIER, DA PNL INTR SND 20064875 RETAINER, PUSH-IN, 20.5MMLG, 42.76MM 1.68HD DIA, PLASTIC (DA PNL INTR SND BARR (PUSH IN)) [КЛИПСА ШУМОИЗОЛЯЦИИ КАПОТА] 10009923 ГАЙКА, БОЛТ RETAINING ПРУЖИНА, M8X1.25, 25 O.D., ZOR (DA PNL INTR SND BARR (PUSH IN)) 25904719 BARRIER, RR W/H INR PNL SND 25904720 BARRIER, RR W/H INR PNL SND 25757810 DEADENER, FLR PNL R/SEAT (390X150) (W/O HOLE) (RECTANGULAR IN SHAPE) 25757810 DEADENER, FLR PNL RR (390X150) (W/O HOLE) (RECTANGULAR IN SHAPE) (6D12-064) - 2008 DM69 КУЗОВНЫЕ РАЗЪЕМЫ ↓ 25882871 PLUG, BODY T/LP FIL PNL HOLE 15908858 PLUG, FLR PNL DRN HOLE (ЗАДНИЙ) (38.1 MM) 15908858 PLUG, FLR PNL DRN HOLE (38.1 MM) 11518598 PLUG, 45X65X10.6, FITS 30X50 HOLE IN 1MM THK , STL, PL (FLR PNL DRN HOLE) 25883487 PLUG, BODY H/PLR HOLE 15941290 PLUG, BODY H/PLR OTR PNL HOLE not found PLUG, SUN RF HSG FRT DRN HOSE HOLE 15200031 PLUG, SUN RF HSG FRT DRN HOSE HOLE (12MM X 30MM) (16.550) teamcadillac.ru 22653093 PLUG, F/TNK FIL DR LAT REL CBL HOLE (30.2 X 9.2 MM) (FITS 19.3MM DIA HOLE) (12.942) 15908858 PLUG, DA HOLE (38.1 MM) (12.980) 21110669 PLUG, RKR INR PNL HOLE (35 MM) (ROUND) (12.179) (6D12-066) - 2008 DM69 КУЗОВНЫЕ ДЕТАЛИ ЧАСТЬ 2-БОКОВЫЕ ЧАСТИ & ДВЕРИ ↓ 25910662 РАМА, BODY SI OTR (СМ. ГРУППУ 12.000 "КУЗОВНЫЕ ДЕТАЛИ-БОКОВЫЕ ЧАСТИ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [БОКОВИНА КУЗОВА] 25910663 РАМА, BODY SI OTR (СМ. ГРУППУ 12.000 "КУЗОВНЫЕ ДЕТАЛИ-БОКОВЫЕ ЧАСТИ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 15880690 DOOR, FRT SI (INCLS 6, 7) [ДВЕРЬ] 15880691 DOOR, FRT SI (INCLS 6, 7) [ДВЕРЬ] 15880692 DOOR, RR SI (INCLS 4, 5) [ДВЕРЬ] 15880693 DOOR, RR SI (INCLS 4, 5) [ДВЕРЬ] 15880696 PANEL, RR S/D OTR (ЧАСТЬ OF 3) 15880697 PANEL, RR S/D OTR (ЧАСТЬ OF 3) 25701880 PLATE, RR S/D HGE ANC (DR SI) (ЧАСТЬ OF 3) (10.450) 15880694 PANEL, FRT S/D OTR (ЧАСТЬ OF 2) 15880695 PANEL, FRT S/D OTR (ЧАСТЬ OF 2) teamcadillac.ru 25701880 PLATE, FRT S/D HGE ANC (DR SI) (ЧАСТЬ OF 2) (6D12-071) - 2008-2009 DM69 КУЗОВНЫЕ ДЕТАЛИ ЧАСТЬ 1-ДВИГАТЕЛЬНЫЙ ОТСЕК & DASH(MX7) ↓ 25811623 RAIL, F/CMPT OTR SI UPR [РЕЙЛИНГ] 25954300 RAIL, F/CMPT OTR SI UPR [ПАНЕЛЬ КОЛЕСНОЙ АРКИ] 25878468 REINFORCEMENT, BODY H/PLR UPR 25878469 REINFORCEMENT, BODY H/PLR UPR 15923694 PANEL, BODY H/PLR INR (INCLS 31) (USED ON VEHICLES BUILT PRIOR TO NOV 5, 2007) (FOR 2ND DES SEE 25909945) 15923695 PANEL, BODY H/PLR INR (INCLS 31) (USED ON VEHICLES BUILT PRIOR TO NOV 5, 2007) (FOR 2ND DES SEE 25909946) 25909945 PANEL, BODY H/PLR INR (INCLS 31) (USED ON VEHICLES BUILT ON/AFTER NOV 5, 2007) (FOR 1ST DES SEE 15923694) 25909946 PANEL, BODY H/PLR INR (INCLS 31) 25909946 PANEL, BODY H/PLR INR (INCLS 31) (USED ON VEHICLES BUILT ON/AFTER NOV 5, 2007) (FOR 1ST DES SEE 15923695) not found PANEL, PLNM LWR not found PANEL, W/S FRM & PLNM 25913292 BARRIER, BRK PED BRKT SND 25696592 SUPPORT, PARK BRK FRT CBL 11518350 ГАЙКА, TRANS SUPT (ЧАСТЬ OF 9) (M10X1.5X24MM) not found REINFORCEMENT, TRANS SUPT (INCLS 8) 25719541 REINFORCEMENT, TRANS SUPT 25710948 REINFORCEMENT, TRANS SUPT not found REINFORCEMENT, DA PNL (AT STRG COL OPG) not found BAR, FLR PNL #1 CR not found REINFORCEMENT, FLR PNL #1 C/BAR (ЧАСТЬ OF 17) not found REINFORCEMENT, F/CMPT S/RL RR (ЧАСТЬ OF 17) not found RAIL, F/CMPT RR SI (ЧАСТЬ OF 17) 20765259 RAIL, F/CMPT SI (INCLS 14-16, 18-24, 37) (FULL VERSION) 20818956 RAIL, F/CMPT SI (INCLS 14-16, 18-24, 37) (FULL VERSION) not found EXTENSION, FLR PNL #1 C/BAR (ЧАСТЬ OF 17) not found REINFORCEMENT, FLR PNL #1 C/BAR OTR (ЧАСТЬ OF 17) not found ГАЙКА, ENG MT C/MBR (ЧАСТЬ OF 17) not found PLATE, F/CMPT S/RL (ЧАСТЬ OF 17) not found RAIL, F/CMPT OTR SI LWR (ЧАСТЬ OF 17) not found BRACKET, FRT W/H LWR FRT PNL (ЧАСТЬ OF 17) not found EXTENSION, F/CMPT OTR S/RL (ЧАСТЬ OF 17) 15900643 BRACKET, F/END UPR TIE BAR (ЧАСТЬ OF 26) [КРОНШТЕЙН] 25851728 BAR, F/END UPR TIE (INCLS 25, 28) 25922923 REINFORCEMENT, F/END UPR TIE BAR 25922924 REINFORCEMENT, F/END UPR TIE BAR [КРОНШТЕЙН ПАНЕЛИ КУЗОВА] 15900644 BRACKET, F/END UPR TIE BAR (ЧАСТЬ OF 26) [КРОНШТЕЙН] 25932610 PANEL, FRT W/H (INCLS 33) [ПАНЕЛЬ КОЛЕСНОЙ КОРОБКИ] 25932611 PANEL, FRT W/H (INCLS 33) not found PANEL, DA not found PANEL, BODY H/PLR INR (ЧАСТЬ OF 3) 11609990 STUD, КАПОТ OPEN ASST ROD BRKT (M8X1.25X20) [ШПИЛЬКА М8] not found BRACKET, КАПОТ OPEN ASST ROD (ЧАСТЬ OF 29) 15923685 RAIL, F/CMPT SI (FRT/SHORT VERSION) [РЕЙЛИНГ] teamcadillac.ru 15923686 RAIL, F/CMPT SI (FRT/SHORT VERSION) [РЕЙЛИНГ] 10384299 REINFORCEMENT, FRT W/H PNL RR BR 11518808 БОЛТ ASM HEX HD CON SPA WS, M6X1.0X20, GMW25M (8.8) STL, GMW3179 (FRT W/H PNL RR BR) not found ГАЙКА, U/B RR S/RL (ЧАСТЬ OF 17) not found INSULATOR, TRANS SUPT 25825687 INSULATOR, TRANS SUPT 11518625 БОЛТ, PAN, M10X1.5X35, 33.5THD, 20 O.D., 10.9, 6138M (TRANS BR BRKT) 25718784 EXTENSION, TRANS MT SUPT FRT RAIL (4.083) 13 - ПРОВОДКА - ПОТОЛОК (6D13-003) - 2008 DM69 ЖГУТЫ ПРОВОДОВ/КУЗОВ ↓ 25935566 HARNESS, BODY WRG (INCLS 2-8) 25935568 HARNESS, BODY WRG (INCLS 2-8) 25935570 HARNESS, BODY WRG (INCLS 2-8) 25935571 HARNESS, BODY WRG (INCLS 2-8) 25935572 HARNESS, BODY WRG (INCLS 2-8) 25935576 HARNESS, BODY WRG (INCLS 2-8) 25935577 HARNESS, BODY WRG (INCLS 2-8) 25935578 HARNESS, BODY WRG (INCLS 2-8) 25935579 HARNESS, BODY WRG (INCLS 2-8) 25935580 HARNESS, BODY WRG (INCLS 2-8) 25935581 HARNESS, BODY WRG (INCLS 2-8) 25935582 HARNESS, BODY WRG (INCLS 2-8) 25935586 HARNESS, BODY WRG (INCLS 2-8) teamcadillac.ru 25935587 HARNESS, BODY WRG (INCLS 2-8) 25833062 CABLE, RDO ANT (ЧАСТЬ OF 1) (ACDelco #25833062) 25833063 CABLE, DIGITAL RDO АНТЕННА (BODY WRG HARN) (ЧАСТЬ OF 1) (ACDelco #25833063) 25833064 CABLE, VEH LOC ANT (ЧАСТЬ OF 1) 25833065 CABLE, M/TEL ANT (ЧАСТЬ OF 1) 88988999 RESISTOR, DATA LINK (LAN TERMINATOR) (ЧАСТЬ OF 1) (BLACK) (121 OHMS) (2-WAY MALE) 25833061 CABLE, BAT POS (ЧАСТЬ OF 1) (208" LONG) (ACDelco #25833061) [КАБЕЛЬ] 25894253 HOSE, BAT VENT (ЧАСТЬ OF 1) 11609599 STUD, SPL, M6X1X25, 13 THD, 11 OD HD W/26 WIDE CLIP, 9.8, 6280M, P-PT (BODY WRG HARN CONN BRKT) not found HARNESS, I/P WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found HARNESS, RR S/D DR WRG (СМ. ГРУППУ 10.000 "АРМАТУРА ЗАДНЕЙ ДВЕРИ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 14 - ВНУТРЕННЯЯ ОТДЕЛКА - ПЕРЕДНИЕ СИДЕНЬЯ - РЕМНИ БЕЗОПАСНОСТИ (6D10-077) - 2008 DM69 ОТДЕЛКА/КРЫША HEADLINER (DELETE ЛЮК CFN) ↓ 25863690 BRACKET, ASST HDL (INCLS 2, 27) 11569968 ГАЙКА, ASST HDL BRKT (ЧАСТЬ OF 1) (M4.2X1.41X24X17.1X16.8) 25831206 PANEL, HDLNG TR (INCLS 24, 25) (VRY LT TITANIUM) (W/O ONSTAR COAX CABLE) 25831207 PANEL, HDLNG TR (INCLS 24, 25) (CASHMERE) 25831209 PANEL, HDLNG TR (INCLS 24, 25) (TITANIUM) 25831210 PANEL, HDLNG TR (INCLS 24, 25) (CASHMERE) 25831215 PANEL, HDLNG TR (INCLS 24, 25) (TITANIUM) 25831216 PANEL, HDLNG TR (INCLS 24, 25) (CASHMERE) 25831243 PANEL, HDLNG TR (INCLS 24, 25) (TITANIUM) 25831244 PANEL, HDLNG TR (INCLS 24, 25) (CASHMERE) 11562028 БОЛТ, RF CNSL (ЧАСТЬ OF 7) 15766504 TELLTALE, INFO CTR (ЧАСТЬ OF 7) (ACDelco #15766504) 11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (ЧАСТЬ OF 7) [ЗАЖИМ КОНСОЛИ САЛОНА] 25831186 КОНСОЛЬ, RF RR (INCLS 4-6, 8, 9) (TITANIUM) 25831187 КОНСОЛЬ, RF RR (INCLS 4-6, 8, 9) (CASHMERE) 25831189 КОНСОЛЬ, RF RR (INCLS 4, 6, 8, 9) (TITANIUM) 25831190 КОНСОЛЬ, RF RR (INCLS 4, 6, 8, 9) (CASHMERE) 01999382 BULB, (ЧАСТЬ OF 7) (ACDelco #W5WLL) (LONGER LIFE) 25886564 LENS, RF CNSL RDG LP (ЧАСТЬ OF 7) 25886565 LENS, RF CNSL RDG LP (ЧАСТЬ OF 7) 25825511 HANDLE, R/RL RR ASST (INCLS 11, 12) (TITANIUM) teamcadillac.ru 25825512 HANDLE, R/RL RR ASST (INCLS 11, 12) (TITANIUM) 25825513 HANDLE, R/RL RR ASST (INCLS 11, 12) (CASHMERE) 25825514 HANDLE, R/RL RR ASST (INCLS 11, 12) (CASHMERE) 11569613 БОЛТ, HFH, M6X1X25, 19 THD, 12 OD, GM6202M STL, GMW3359, TAPTITE (ЧАСТЬ OF 10) not found COVER, R/RL RR ASST HDL HOLE (ЧАСТЬ OF 10) 13502343 BULB, S/S ILLUM MIR LP (ЧАСТЬ OF 15) (8.991) (ACDelco #13502343) not found LENS, S/S ILLUM MIR LP (ЧАСТЬ OF 15) not found LENS, S/S ILLUM MIR LP (ЧАСТЬ OF 15) 25827693 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, (INCLS 13, 14, 17) (TITANIUM) 25827694 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, (INCLS 13, 14, 17) (TITANIUM) 25827695 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, (INCLS 13, 14, 17) (CASHMERE) 25827696 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, (INCLS 13, 14, 17) (CASHMERE) not found КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (CASHMERE) 15116388 LABEL, INFL RST SYS WRNG (ЧАСТЬ OF 15) (ENGLISH/SPANISH) [НАКЛЕЙКА САМОКЛЕЯЩАЯСЯ] 25815471 LABEL, INFL RST SYS WRNG (ЧАСТЬ OF 15) (ENGLISH/ARABIC) 11610271 SCREW, PAN HD, M4.2X1.41X25, 20.5 THD, 8 OD, 6010M, GMW4205, T15 TORX, AB-PT (S/S) 11610271 SCREW, PAN HD, M4.2X1.41X25, 20.5 THD, 8 OD, 6010M, GMW4205, T15 TORX, AB-PT (S/S RET) 15803473 COVER, S/S RET БОЛТ (CASHMERE) (16.070) 15866140 COVER, S/S RET БОЛТ (TITANIUM) 15877014 SUPPORT, S/S (CASHMERE) (16.070) 25858801 SUPPORT, S/S (TITANIUM) (TIP PIN RETAINER) 13502224 RETAINER, S/S (TIP PIN) (16.070) 13502225 RETAINER, S/S (TIP PIN) (16.070) 11609345 ГАЙКА, PUSH-IN, 4.2, SAE 1050 STL, GMW3179 (S/S RET (PUSH ON)) not found RETAINER, RF CNSL (ЧАСТЬ OF 3) not found HARNESS, W/S HDR WRG (ЧАСТЬ OF 3) 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (ASST HDL BRKT) [БОЛТ М6] 11610271 SCREW, PAN HD, M4.2X1.41X25, 20.5 THD, 8 OD, 6010M, GMW4205, T15 TORX, AB-PT (ЧАСТЬ OF 1) (6D10-078) - 2008 DM69 ОТДЕЛКА/КРЫША HEADLINER (ЛЮК C3U) ↓ 25863690 BRACKET, ASST HDL (INCLS 2, 28) 11569968 ГАЙКА, ASST HDL BRKT (ЧАСТЬ OF 1) (M4.2X1.41X24X17.1X16.8) 25831200 PANEL, HDLNG TR (INCLS 25, 26) (TITANIUM) (USE ЧАСТЬ W/O UNIVERSAL GARAGE DOOR OPENER) 25831203 PANEL, HDLNG TR (INCLS 25, 26) (TITANIUM) (USE ЧАСТЬ W/O UNIVERSAL GARAGE DOOR OPENER) 25831204 PANEL, HDLNG TR (INCLS 25, 26) (CASHMERE) (USE ЧАСТЬ W/O UNIVERSAL GARAGE DOOR OPENER) 25831212 PANEL, HDLNG TR (INCLS 25, 26) (TITANIUM) 25831213 PANEL, HDLNG TR (INCLS 25, 26) (CASHMERE) 25831240 PANEL, HDLNG TR (INCLS 25, 26) (TITANIUM) 25831241 PANEL, HDLNG TR (INCLS 25, 26) (CASHMERE) 11562028 БОЛТ, RF CNSL (ЧАСТЬ OF 7) 15766504 TELLTALE, INFO CTR (ЧАСТЬ OF 7) (ACDelco #15766504) 11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (ЧАСТЬ OF 7) [ЗАЖИМ КОНСОЛИ САЛОНА] 25831186 КОНСОЛЬ, RF RR (INCLS 4-6, 8, 9) (TITANIUM) 25831187 КОНСОЛЬ, RF RR (INCLS 4-6, 8, 9) (CASHMERE) 25831189 КОНСОЛЬ, RF RR (INCLS 4-6, 8, 9) (TITANIUM) 25831190 КОНСОЛЬ, RF RR (INCLS 4-6, 8, 9) (CASHMERE) 01999382 BULB, (ЧАСТЬ OF 7) (ACDelco #W5WLL) (LONGER LIFE) 25886564 LENS, RF CNSL RDG LP (ЧАСТЬ OF 7) 25886565 LENS, RF CNSL RDG LP (ЧАСТЬ OF 7) 25825511 HANDLE, R/RL RR ASST (INCLS 11, 12) (TITANIUM) 25825512 HANDLE, R/RL RR ASST (INCLS 11, 12) (TITANIUM) 25825513 HANDLE, R/RL RR ASST (INCLS 11, 12) (CASHMERE) 25825514 HANDLE, R/RL RR ASST (INCLS 11, 12) (CASHMERE) 11569613 БОЛТ, HFH, M6X1X25, 19 THD, 12 OD, GM6202M STL, GMW3359, TAPTITE (ЧАСТЬ OF 10) not found COVER, R/RL RR ASST HDL HOLE (ЧАСТЬ OF 10) 13502343 BULB, S/S ILLUM MIR LP (ЧАСТЬ OF 15) (8.991) (ACDelco #13502343) not found LENS, S/S ILLUM MIR LP (ЧАСТЬ OF 15) 25827693 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, (INCLS 13, 14, 18) (TITANIUM) 25827694 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, (INCLS 13, 14, 18) (TITANIUM) 25827695 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, (INCLS 13, 14, 18) (CASHMERE) 25827696 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, (INCLS 13, 14, 18) (CASHMERE) 15876699 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (TITANIUM) 15876700 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (CASHMERE) 15876701 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (TITANIUM) 15876702 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (CASHMERE) 15876709 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (TITANIUM) 15876710 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (CASHMERE) teamcadillac.ru 15876711 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (TITANIUM) 15876712 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (CASHMERE) 15876713 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (TITANIUM) 15876714 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (CASHMERE) 15876715 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (TITANIUM) 15876716 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (CASHMERE) 15876717 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (TITANIUM) 15876718 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (CASHMERE) 15876719 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (TITANIUM) (OH SNRF CNSL W/INTR, LED & W/O VNC MIC) 15876720 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (CASHMERE) (OH SNRF CNSL W/INTR, LED & W/O VNC MIC) 15876721 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (TITANIUM) (OH SNRF CNSL W/INTR, LED, & VNC MIC) 15876722 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (CASHMERE) (OH SNRF CNSL W/INTR, LED, & VNC MIC) 15876723 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (TITANIUM) 15876724 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (CASHMERE) 15876725 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (TITANIUM) 15876726 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (CASHMERE) 15876727 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (TITANIUM) 15876728 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (CASHMERE) 15876729 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (TITANIUM) 15876730 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (CASHMERE) 15876731 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (TITANIUM) 15876732 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (CASHMERE) 15876733 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (TITANIUM) 15876734 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (CASHMERE) 15876735 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (TITANIUM) 15876736 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (CASHMERE) 25822398 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (TITANIUM) 25822399 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (CASHMERE) 25822404 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (TITANIUM) 25822405 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (CASHMERE) 25854579 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (TITANIUM) 25854580 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (CASHMERE) 25854582 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (TITANIUM) 25854583 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (CASHMERE) 25854585 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (TITANIUM) 25854586 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (CASHMERE) 25854588 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (TITANIUM) 25854589 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (CASHMERE) 25862672 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (TITANIUM) 25862673 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (CASHMERE) 25862678 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (TITANIUM) 25862679 КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КОНСОЛЬ/КРЫША" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (CASHMERE) 25949119 MOLDING, SUN RF PNL/WDO GARN (CASHMERE) 25949120 MOLDING, SUN RF PNL/WDO GARN (TITANIUM) 15116388 LABEL, INFL RST SYS WRNG (ЧАСТЬ OF 15) (ENGLISH/SPANISH) [НАКЛЕЙКА САМОКЛЕЯЩАЯСЯ] 25815471 LABEL, INFL RST SYS WRNG (ЧАСТЬ OF 15) (ENGLISH/ARABIC) 11610271 SCREW, PAN HD, M4.2X1.41X25, 20.5 THD, 8 OD, 6010M, GMW4205, T15 TORX, AB-PT (S/S) 15803473 COVER, S/S RET БОЛТ (CASHMERE) (16.070) 15866140 COVER, S/S RET БОЛТ (TITANIUM) 11610271 SCREW, PAN HD, M4.2X1.41X25, 20.5 THD, 8 OD, 6010M, GMW4205, T15 TORX, AB-PT (S/S RET) 15877014 SUPPORT, S/S (CASHMERE) (16.070) 25858801 SUPPORT, S/S (TITANIUM) (TIP PIN RETAINER) 13502224 RETAINER, S/S (TIP PIN) (16.070) 13502225 RETAINER, S/S (TIP PIN) (16.070) 11609345 ГАЙКА, PUSH-IN, 4.2, SAE 1050 STL, GMW3179 (S/S RET (PUSH ON)) not found RETAINER, RF CNSL (ЧАСТЬ OF 3) not found HARNESS, W/S HDR WRG (ЧАСТЬ OF 3) 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (ASST HDL BRKT) [БОЛТ М6] 11610271 SCREW, PAN HD, M4.2X1.41X25, 20.5 THD, 8 OD, 6010M, GMW4205, T15 TORX, AB-PT (ЧАСТЬ OF 1) (6D14-021) - 2008 DM69 ОБЛИЦОВКА ПЕРЕДНЕЙ ВОДИТЕЛЬСКОЙ ДВЕРИ (MEMORY A45, ЛАМПА PACKAGE TSQ) ↓ 11570654 ГАЙКА, FRT S/D TR (4.2 X 1.41) (FITS 8.75 SQ HOLE) (9.665) 11519032 RETAINER, PUSH IN, 19.5X28.4X1.8, FITS HOLE 9.1, ACETAL, BLK (ЧАСТЬ OF 18) [ФИКСАТОР ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ] not found БОЛТ - HEX WASHER HEAD, M7X1.0X20.0, GM6202M STL, GMW3200 (ЧАСТЬ OF 18) 15243683 ЛАМПА, FRT S/D WRNG (ЧАСТЬ OF 18) (FRT LIGHT PIPE) [ФАРА] 11503417 ГАЙКА, M6.3 STMPD TYPE SR ZC (ЧАСТЬ OF 18) not found APPLIQUE, FRT S/D T/PNL (ЧАСТЬ OF 18) 15243588 APPLIQUE, FRT S/D T/PNL (ЧАСТЬ OF 18) (SAPELE) (USE W/NUT 11503417 QTY 7 FOR 08;QTY 4 FOR 09 AND LATER) 25856525 ЛАМПА, FRT S/D WRNG (ЧАСТЬ OF 18) (LED PIN SPOT) [ПОДСВЕТКА САЛОНА] teamcadillac.ru not found BEZEL, FRT S/D I/S HDL (ЧАСТЬ OF 18) 11609539 SCREW, RD CROWNED WA HD, M4.2X1.41X16, STL ISO 2702, GMW4205 (FRT S/D TR) [ВИНТ] 15871923 COVER, FRT S/D PULL HDL (EBONY) [КРЫШКА] 15871925 COVER, FRT S/D PULL HDL (TITANIUM) [КРЫШКА] 15871927 COVER, FRT S/D PULL HDL (CASHMERE) [КРЫШКА] 25796933 SWITCH, R/CMPT LID REL (ЧАСТЬ OF 18) (ACDelco #D1417G) [ВЫКЛ ЮЧАТЕЛЬ] 03539184 БОЛТ, FRT S/D PULL HDL (ATTACH TO NUT IN SHT MTL) (14.683) 25927093 CAP, FRT S/D PULL HDL БОЛТ (EBONY) [НАКЛАДКА ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ] 25927095 CAP, FRT S/D PULL HDL БОЛТ (TITANIUM) [КРЫШКА] 25927097 CAP, FRT S/D PULL HDL БОЛТ (CASHMERE) [НАКЛАДКА ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ] 15867905 BEZEL, R/CMPT LID REL SW (ЧАСТЬ OF 18) (EBONY) 15867906 BEZEL, R/CMPT LID REL SW (ЧАСТЬ OF 18) (GRAY) 15867907 BEZEL, R/CMPT LID REL SW (ЧАСТЬ OF 18) (CASHMERE) 11561274 БОЛТ, FRT S/D WDO SW (ЧАСТЬ OF 18) (SCREW-PAN HEAD, #6-19X1.5, 0.83 THD, 0.26 OD) (16.263) 25783499 SWITCH, DR LK & SI WDO (ЧАСТЬ OF 18) (ARGENT) [ВЫКЛЮЧАТЕЛЬ СТЕКЛОПОДЪЕМНИКА ДВЕРИ (КЛАВ)] 25783499 SWITCH, DR LK & SI WDO (ЧАСТЬ OF 18) (ARGENT) (10.485) [ВЫКЛЮЧАТЕЛЬ СТЕКЛОПОДЪЕМНИКА ДВЕРИ (КЛАВ)] 25783500 SWITCH, DR LK & SI WDO (ЧАСТЬ OF 18) (ARGENT) 25783500 SWITCH, DR LK & SI WDO (ЧАСТЬ OF 18) (ARGENT) (10.485) 19115808 BULB, FRT S/D C/LP (ЧАСТЬ OF 18, 19) (8.991) (ACDelco #19115808) 15861185 TRIM, FRT S/D (INCLS 2-8, 11, 14-17, 19-23) (EBONY) 15861187 TRIM, FRT S/D (INCLS 2-8, 11, 14-17, 19-23) (TITANIUM) 15861188 TRIM, FRT S/D (INCLS 2-8, 11, 14-17, 19-23) (CASHMERE) 15861197 TRIM, FRT S/D (INCLS 2-8, 11, 14-17, 19-23) (EBONY) [ДАТЧИК] 15861199 TRIM, FRT S/D (INCLS 2-8, 11, 14-17, 19-23) (TITANIUM) [ОБШИВКА] 15861200 TRIM, FRT S/D (INCLS 2-8, 11, 14-17, 19-23) (CASHMERE) [ДАТЧИК] 25866864 TRIM, FRT S/D (INCLS 2-8, 11, 14-17, 19-23) (EBONY) 25866865 TRIM, FRT S/D (INCLS 2-8, 11, 14-17, 19-23) (TITANIUM) 25866866 TRIM, FRT S/D (INCLS 2-8, 11, 14-17, 19-23) (CASHMERE) 25866875 TRIM, FRT S/D (INCLS 2-8, 11, 14-17, 19-23) (EBONY) [ОБШИВКА] 25866876 TRIM, FRT S/D (INCLS 2-8, 11, 14-17, 19-23) (TITANIUM) [ОБШИВКА] 25866877 TRIM, FRT S/D (INCLS 2-8, 11, 14-17, 19-23) (CASHMERE) [ОБШИВКА] 10359030 ЛАМПА, CTSY (S/D ЛАМПА) (INCLS 17) (ЧАСТЬ OF 18) 15867890 BEZEL, FRT S/D WDO SW (ЧАСТЬ OF 18) (EBONY) 15867891 BEZEL, FRT S/D WDO SW (ЧАСТЬ OF 18) (GRAY) 15867892 BEZEL, FRT S/D WDO SW (ЧАСТЬ OF 18) (CASHMERE) 15867893 BEZEL, FRT S/D WDO SW (ЧАСТЬ OF 18) (EBONY) 15867894 BEZEL, FRT S/D WDO SW (ЧАСТЬ OF 18) (GRAY) 15867895 BEZEL, FRT S/D WDO SW (ЧАСТЬ OF 18) (CASHMERE) 25898134 SWITCH, D/SEAT ADJR MEMORY (ЧАСТЬ OF 18) (ARGENT) 25857260 HARNESS, FRT S/D WRG (ЧАСТЬ OF 18) 11519031 RETAINER, PUSH IN, 19.5X26.1X1.8, ACETAL, NATURAL, FOAM SEALER (ЧАСТЬ OF 18) [ФИКСАТОР ОБШИВКИ ДВЕРИ] 20794762 DEFLECTOR, FRT S/D WAT 20310739 ГАЙКА, FRT S/D PULL HDL (3.125 MM) (RECTANGULAR NYLON) (14.690) [ВТУЛКА ФИКСАТОРА РУЧКИ САЛОНА] 20699808 RETAINER, FRT S/D G/MLDG (PUSH IN) (ЧАСТЬ OF 27) (BLACK) (12.0MM) (X-MAS TREE) (14.875) [КЛИПСА] 25846021 MOLDING, FRT S/D GARN (INCLS 26) (EBONY) [МОЛДИНГ] (6D14-065) - 2008-2010 D69 ПЕРЕДНЯЯ ОТДЕЛКА ↓ 11561653 RETAINER, W/S SI G/MLDG (PUSH IN) (ЧАСТЬ OF 5) (YELLOW) (8.5MM DIA HOLE) (BIRD'S BEAK DOUBLE) (14.630) 25672428 RETAINER, FRT S/D SILL TR PLT (PUSH IN) (ЧАСТЬ OF 3) (7 X 14MM HOLE) (RECTANGLE) [ФИКСАТОР МОЛДИНГА ДВЕРИ] 25874356 PLATE, FRT S/D SILL TR (INCLS 2, 4) (TITANIUM) (TRIM PIECE) 25874357 PLATE, FRT S/D SILL TR (INCLS 2, 4) (CASHMERE) 25938617 PLATE, FRT S/D SILL TR (INCLS 2, 4) (EBONY) 25938618 PLATE, FRT S/D SILL TR (INCLS 2, 4) (EBONY) 25938619 PLATE, FRT S/D SILL TR (INCLS 2, 4) (TITANIUM) (TRIM PIECE) teamcadillac.ru 25938624 PLATE, FRT S/D SILL TR (INCLS 2, 4) (CASHMERE) (TRIM PIECE) 25938624 PLATE, FRT S/D SILL TR (INCLS 2, 4) (CASHMERE) (TRIM PIECE) 11588650 CLIP, 12X14X16.6, GM4345M (ЧАСТЬ OF 3) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА] 20828295 MOLDING, W/S SI GARN (INCLS 1, 6) (CASHMERE) 25937983 MOLDING, W/S SI GARN (INCLS 1, 6) (TITANIUM) [ВНУТРЕННЯЯ ПАНЕЛЬ СТОЙКИ КУЗОВА] 25937984 MOLDING, W/S SI GARN (INCLS 1, 6) (TITANIUM) [ВНУТРЕННЯЯ ПАНЕЛЬ СТОЙКИ КУЗОВА] 25937987 MOLDING, W/S SI GARN (INCLS 1, 6) (CASHMERE) [ВНУТРЕННЯЯ ПАНЕЛЬ СТОЙКИ КУЗОВА] 11570729 RETAINER, W/S SI UPR G/MLDG CLIP (ЧАСТЬ OF 5) (70.4X13) (W/NYLON TETHER) (16.041) [ФИКСАТОР ВНУТРЕННЕЙ ПАНЕЛИ СТОЙКИ КУЗОВА] 25823426 PLATE, FRT S/D SILL TR (CADILLAC NAME PLT ONLY) [ТАБЛИЧКА] (6D14-066) - 2008 DM69 ОТДЕЛКА/CENTER ПАНЕЛЬ ЗАДНЕЙ СТОЙКИ КУЗОВА & QUARTER ↓ 11609651 CLIP, C/PLR UPR T/PNL (ЧАСТЬ OF 4) (M21.8X15.0X20.5) (14.731) [ШАЙБА] 11609539 SCREW, RD CROWNED WA HD, M4.2X1.41X16, STL ISO 2702, GMW4205 (ЧАСТЬ OF 4) [ВИНТ] 15871731 PLATE, INFL RST AIRBAG NA (ЧАСТЬ OF 4) (TITANIUM) [НАКЛАДКА AIRBAG] 15871733 PLATE, INFL RST AIRBAG NA (ЧАСТЬ OF 4) (CASHMERE) (USED FOR C/PLR TRIM) [НАКЛАДКА AIRBAG] 25862282 PANEL, C/PLR UPR TR (INCLS 1-3, 5) (CASHMERE) 25908298 PANEL, C/PLR UPR TR (INCLS 1-3, 5) (TITANIUM) [ВНУТРЕННЯЯ ПАНЕЛЬ СТОЙКИ КУЗОВА] 25908299 PANEL, C/PLR UPR TR (INCLS 1-3, 5) (TITANIUM) [ВНУТРЕННЯЯ ПАНЕЛЬ СТОЙКИ КУЗОВА] 25908300 PANEL, C/PLR UPR TR (INCLS 1-3, 5) (CASHMERE) 11561653 RETAINER, C/PLR UPR T/PNL (ЧАСТЬ OF 4) (YELLOW) (8.5MM DIA HOLE) (BIRD'S BEAK DOUBLE) (14.630) 25865763 PLATE, RR S/D SILL TR (INCLS 7, 8) (EBONY) [ТАБЛИЧКА] 25865764 PLATE, RR S/D SILL TR (INCLS 7, 8) (EBONY) [ПОДДОН] 25865765 PLATE, RR S/D SILL TR (INCLS 7, 8) (TITANIUM) [ПОДДОН] 25865766 PLATE, RR S/D SILL TR (INCLS 7, 8) (TITANIUM) [ПОДДОН] 25865767 PLATE, RR S/D SILL TR (INCLS 7, 8) (CASHMERE) [ПОДДОН] 25865768 PLATE, RR S/D SILL TR (INCLS 7, 8) (CASHMERE) [ПОДДОН] 25672428 RETAINER, RR S/D SILL TR PLT (PUSH IN) (ЧАСТЬ OF 6) (7 X 14MM HOLE) (RECTANGLE) (11.175) [ФИКСАТОР МОЛДИНГА ДВЕРИ] 11588650 CLIP, 12X14X16.6, GM4345M (ЧАСТЬ OF 6) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА] 11588650 CLIP, 12X14X16.6, GM4345M (ЧАСТЬ OF 11) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА] 11561653 RETAINER, C/PLR LWR RR TR PNL (PUSH IN) (ЧАСТЬ OF 11) (YELLOW) (8.5MM DIA HOLE) (BIRD'S BEAK DOUBLE) (14.630) 25867240 PANEL, C/PLR LWR TR (INCLS 9, 10) (EBONY) [ВНУТРЕННЯЯ ПАНЕЛЬ СТОЙКИ КУЗОВА] 25867241 PANEL, C/PLR LWR TR (INCLS 9, 10) (TITANIUM) 25867242 PANEL, C/PLR LWR TR (INCLS 9, 10) (TITANIUM) 25994807 PANEL, C/PLR LWR TR (INCLS 9, 10) (EBONY) 25994811 PANEL, C/PLR LWR TR (INCLS 9, 10) (CASHMERE) 25994812 PANEL, C/PLR LWR TR (INCLS 9, 10) (CASHMERE) 11588650 CLIP, 12X14X16.6, GM4345M (ЧАСТЬ OF 13) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА] 15860117 PANEL, QTR LWR RR TR (INCLS 12, 14-16) (TITANIUM) teamcadillac.ru 15860118 PANEL, QTR LWR RR TR (INCLS 12, 14-16) (TITANIUM) 15860119 PANEL, QTR LWR RR TR (INCLS 12, 14-16) (CASHMERE) 15860120 PANEL, QTR LWR RR TR (INCLS 12, 14-16) (CASHMERE) 25861618 PANEL, QTR LWR RR TR (INCLS 12, 14-16) (EBONY) [ПАНЕЛЬ] 25931758 PANEL, QTR LWR RR TR (INCLS 12, 14-16) (EBONY) (14.731) 20510029 RETAINER, R/SEAT SHLDR BELT GDE (ЧАСТЬ OF 13) (12.118) 22584100 GUIDE, R/SEAT SHLDR BELT (ЧАСТЬ OF 13) (BLACK) 20510029 RETAINER, R/SEAT SHLDR BELT GDE (ЧАСТЬ OF 13) (12.118) 15871731 PLATE, INFL RST AIRBAG NA (ЧАСТЬ OF 19) (TITANIUM) [НАКЛАДКА AIRBAG] 15871733 PLATE, INFL RST AIRBAG NA (ЧАСТЬ OF 19) (CASHMERE) (USED FOR C/PLR TRIM) [НАКЛАДКА AIRBAG] 11609539 SCREW, RD CROWNED WA HD, M4.2X1.41X16, STL ISO 2702, GMW4205 (ЧАСТЬ OF 19) [ВИНТ] 15860116 PANEL, QTR UPR TR (INCLS 17, 18, 20-23) (CASHMERE) (USED ON VEH W/ 2 PIECE QTR TRIM; FOR MATCH, DLR MAY REPL OPPOSITE SIDE: 25979333) (FOR 2ND DES SEE 25979334) 25979329 PANEL, QTR UPR TR (INCLS 17, 18, 20-23) (TITANIUM) [ВНУТРЕННЯЯ ПАНЕЛЬ СТОЙКИ КУЗОВА] 25979330 PANEL, QTR UPR TR (INCLS 17, 18, 20-23) (TITANIUM) (USED ON VEH W/ 1 PIECE QTR TRIM; FOR MATCH, DLR MAY REPL OPPOSITE SIDE: 25979329) [ПАНЕЛЬ САЛОНА] 25979333 PANEL, QTR UPR TR (INCLS 17, 18, 20-23) (CASHMERE) 25979334 PANEL, QTR UPR TR (INCLS 17, 18, 20-23) (CASHMERE) (USED ON VEH W/ 1 PIECE QTR TRIM. FOR MATCH, DLR MAY REPL OPPOSITE SIDE: 25979333) (FOR 1ST DES SEE 15860116) 11570802 RETAINER, QTR UPR T/PNL CLIP (ЧАСТЬ OF 19) (70.4X13) (TETHER RETAINER) 11609651 CLIP, QTR UPR T/PNL (ЧАСТЬ OF 19) (M21.8X15.0X20.5) (14.731) [ШАЙБА] 11588650 CLIP, 12X14X16.6, GM4345M (ЧАСТЬ OF 19) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА] 11561654 RETAINER, QTR UPR T/PNL (PUSH IN) (ЧАСТЬ OF 19) (PLAIN) (8.5MM DIA HOLE) (BIRD'S BEAK SINGLE) (12.800) [ФИКСАТОР ВНУТРЕННЕЙ ПАНЕЛИ БАГАЖНОГО ОТДЕЛЕНИЯ] (6D14-067) - 2008 DM69 INFLATABLE RESTRAINT SYSTEM/DRIVER & PASSENGER ↓ 15278534 SENSOR, F/END INFL RST DISCRM [ДАТЧИК ПОДУШКИ БЕЗОПАСНОСТИ] teamcadillac.ru 21996989 TAG, INFL RST I/P MDL CAUTION (HANGING) 15278533 SENSOR, INFL RST SI IMP [ДАТЧИК] not found БОЛТ, INFL RST DIAGN ENGY RESV MDL 11609989 БОЛТ, INFL RST DIAGN ENGY RESV MDL (SDM CAST GROUNDING ATTACHMENT) (M6X1X25, 15 THD, 17 OD) (8.900) [БОЛТ М6] 25832109 МОДУЛЬ, INFL RST SEN & DIAGN not found ГАЙКА, INFL RST DIAGN ENGY RESV MDL 11561645 ГАЙКА, INFL RST DIAGN ENGY RESV MDL (SDM CASE GROUNDING ATTACHMENT) (M6X1, 3.45THK, 13.5 OD) (8.915) 25856864 МОДУЛЬ, STRG WHL INFL RST (EBONY) 25856865 МОДУЛЬ, STRG WHL INFL RST (COCOA) not found ГАЙКА, INFL RST I/P MDL 11609411 ГАЙКА, INFL RST I/P MDL (PSIR МОДУЛЬ TO I/P RETAINER) (6 X 1, 5.07THK) (HEX-CHROME FREE FINISH) (8.917) [ГАЙКА М6] 15685170 ГАЙКА, INFL RST I/P MDL (PSIR МОДУЛЬ TO I/P RETAINER) (M6X1.0, 19.0MM OD) (8.917) 11561388 БОЛТ, I/P INFL RST MDL (M6X1X20, 11 THD, 17 OD) (8.900) 15237186 МОДУЛЬ, I/P INFL RST [МОДУЛЬ] (6D14-068) - 2008 DM69 INFLATABLE RESTRAINT SYSTEM/КРЫША SIDE ↓ 20765683 МОДУЛЬ, RF S/RL INFL RST (INCLS 5-7) 20765684 МОДУЛЬ, RF S/RL INFL RST (INCLS 5-7) (LABELED 20765684) 11609989 БОЛТ, RF S/RL INFL RST MDL (M6X1X25, 15 THD, 17 OD) (8.900) [БОЛТ М6] 25935566 HARNESS, BODY WRG (СМ. ГРУППУ 02.000 "HARNESS/BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25935568 HARNESS, BODY WRG (СМ. ГРУППУ 02.000 "HARNESS/BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25935570 HARNESS, BODY WRG (СМ. ГРУППУ 02.000 "HARNESS/BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25935571 HARNESS, BODY WRG (СМ. ГРУППУ 02.000 "HARNESS/BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) teamcadillac.ru 25935572 HARNESS, BODY WRG (СМ. ГРУППУ 02.000 "HARNESS/BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25935576 HARNESS, BODY WRG (СМ. ГРУППУ 02.000 "HARNESS/BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25935577 HARNESS, BODY WRG (СМ. ГРУППУ 02.000 "HARNESS/BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25935578 HARNESS, BODY WRG (СМ. ГРУППУ 02.000 "HARNESS/BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25935579 HARNESS, BODY WRG (СМ. ГРУППУ 02.000 "HARNESS/BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25935580 HARNESS, BODY WRG (СМ. ГРУППУ 02.000 "HARNESS/BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25935581 HARNESS, BODY WRG (СМ. ГРУППУ 02.000 "HARNESS/BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25935582 HARNESS, BODY WRG (СМ. ГРУППУ 02.000 "HARNESS/BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25935586 HARNESS, BODY WRG (СМ. ГРУППУ 02.000 "HARNESS/BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25935587 HARNESS, BODY WRG (СМ. ГРУППУ 02.000 "HARNESS/BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 15278533 SENSOR, INFL RST SI IMP [ДАТЧИК] 11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (ЧАСТЬ OF 1) [БОЛТ М8] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (ЧАСТЬ OF 1) [ГАЙКА М6] 11589181 RETAINER, PUSHIN, FITS 6.24 HOLE IN 0.8-10 THK PNL, NYLON, BLACK (ЧАСТЬ OF 1) [ФИКСАТОР ПОДКРЫЛКА] (6D14-069) - 2008 DM69 ПАССАЖИРСКОЕ СИДЕНЬЕ-ПОДУШКА (VENTED/HEATED KB6) ↓ 25780352 COVER, D/SEAT CUSH (CASHMERE) 25780353 COVER, D/SEAT CUSH (TITANIUM) 25780354 COVER, D/SEAT CUSH (EBONY) 20755532 PAD, D/SEAT CUSH 20755533 PAD, D/SEAT CUSH 25780788 ПОДОГРЕВАТЕЛЬ, D/SEAT CUSH [НАГРЕВАТЕЛЬ] not found PAD, D/SEAT BK CUSH (СМ. ГРУППУ 14.000 "ВОДИТЕЛЬСКОЕ СИДЕНЬЕ-СПИНКА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found CLIP, D/SEAT INR ADJR RR FIN (ЧАСТЬ OF 48) 25828643 БОЛТ, F/SEAT not found BRACKET, D/SEAT RECL HDL BZL 12451497 SWITCH, D/SEAT ADJR & RECL (8-WAY) [ВКЛЮЧАТЕЛЬ] 10315826 SWITCH, D/SEAT LUMBAR CONT (EBONY) [ВЫКЛЮЧАТЕЛЬ РЕГУЛИРОВКИ ПОЛОЖЕНИЯ СИДЕНЬЯ] 15210786 SWITCH, D/SEAT LUMBAR CONT (CASHMERE) 15895688 SWITCH, D/SEAT LUMBAR CONT (TITANIUM) 15947239 BEZEL, D/SEAT ADJR SW (INCLS 14) (TITANIUM) 25994746 BEZEL, D/SEAT ADJR SW (INCLS 14) (EBONY) (W/LUMBAR PREРОЛИК НАТЯЖИТЕЛЬ) 25994748 BEZEL, D/SEAT ADJR SW (INCLS 14) (CASHMERE) 15952346 COVER, D/SEAT BELT OPG TR (RETR SI) (CASHMERE) 15952348 COVER, D/SEAT BELT OPG TR (RETR SI) (EBONY) 15952348 COVER, D/SEAT BELT OPG TR (RETR SI) (EBONY) 15889530 KNOB, D/SEAT RECL LVR (EBONY) (16.682) 15889531 KNOB, D/SEAT RECL LVR (CASHMERE) (16.682) 25863075 KNOB, D/SEAT RECL LVR (TITANIUM) 15889524 KNOB, D/SEAT ADJR SW (EBONY) (16.682) teamcadillac.ru 15889525 KNOB, D/SEAT ADJR SW (CASHMERE) (16.682) 25863076 KNOB, D/SEAT ADJR SW (TITANIUM) 11588650 CLIP, 12X14X16.6, GM4345M (ЧАСТЬ OF 10) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА] 11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (D/SEAT) not found NUT-METRIC HEX FLABGE, M6X1, 10MM SOCKET (D/SEAT) 25857034 МОДУЛЬ, D/SEAT ADJR MEMORY (REQUIRES DEALER PROGRAMMING) (LABELED 25930648) [МОДУЛЬ РЕГУЛИРОВКИ СИДЕНИЯ] 25780743 HARNESS, D/SEAT CONT MDL WRG (W/O ACTIVE H/RST;HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DESIGN SEE 25939288) 25780744 HARNESS, D/SEAT CONT MDL WRG 25904926 HARNESS, D/SEAT CONT MDL WRG (W/O ACTIVE H/RST;HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DESIGN SEE 25939287) 25939287 HARNESS, D/SEAT CONT MDL WRG (W/ ACTIVE H/RST;HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DSG SEE 25904926) 25939288 HARNESS, D/SEAT CONT MDL WRG (W/ ACTIVE H/RST;HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DSG SEE 25780743) not found ГАЙКА, D/SEAT (ЧАСТЬ OF 42) 15894164 ACTUATOR, D/SEAT OTR ADJR RR VERT (ЧАСТЬ OF 42) (INCLS 21) not found МОДУЛЬ, D/SEAT ADJR MEMORY (ЧАСТЬ OF 20, 42) 15947293 COVER, D/SEAT INR ADJR TRK RR FIN (INCLS 23) (CASHMERE) 15947295 COVER, D/SEAT INR ADJR TRK RR FIN (INCLS 23) (EBONY) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ] not found CLIP, D/SEAT (ЧАСТЬ OF 22, 24) 15947285 COVER, D/SEAT OTR ADJR TRK RR FIN (INCLS 23) (CASHMERE) 15947287 COVER, D/SEAT OTR ADJR TRK RR FIN (INCLS 23) (EBONY) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ] 25781231 ЛАМПА, LUMINESCENT [ЛАМПА ЛЮМИНИСТЦЕНТНАЯ] not found TRACK, D/SEAT OTR ADJR (ЧАСТЬ OF 42) 15947301 COVER, D/SEAT OTR ADJR TRK FRT FIN (CASHMERE) 15947303 COVER, D/SEAT OTR ADJR TRK FRT FIN (EBONY) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ] 15947309 COVER, D/SEAT INR ADJR TRK FRT FIN (CASHMERE) 15947311 COVER, D/SEAT INR ADJR TRK FRT FIN (EBONY) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ] not found TRACK, D/SEAT INR ADJR (ЧАСТЬ OF 42) 15817518 SENSOR, INFL RST FRT PASS POSITION (ЧАСТЬ OF 42) [ДАТЧИК ПОДУШКИ БЕЗОПАСНОСТИ] not found BRACE, D/SEAT (ЧАСТЬ OF 42) not found ГАЙКА, D/SEAT (ЧАСТЬ OF 42) not found ACTUATOR, D/SEAT ADJR (ЧАСТЬ OF 35, 42) not found МОДУЛЬ, D/SEAT ADJR MEMORY (ЧАСТЬ OF 35, 42) 15894137 MOTOR, D/SEAT ADJR ACTR (ЧАСТЬ OF 42) (INCLS 33, 34) (W/O SEAT ADJR MEMORY MDL) 15894138 MOTOR, D/SEAT ADJR ACTR (ЧАСТЬ OF 42) (INCLS 33, 34) (W/SEAT ADJR MEMORY MDL) not found МОДУЛЬ, D/SEAT ADJR MEMORY (ЧАСТЬ OF 37, 42) 15894170 ACTUATOR, F/SEAT TILT ADJR (ЧАСТЬ OF 42) (INCLS 36) 15894173 ACTUATOR, F/SEAT TILT ADJR (ЧАСТЬ OF 42) (INCLS 36) 25780793 ВЕНТИЛЯТОР, D/SEAT CUSH VENTILATION HEAT & COOL [ВЕНТИЛЯТОР] 15947191 COVER, D/SEAT OTR ADJR FRT FIN (INCLS 40) (CASHMERE) 15947192 COVER, D/SEAT OTR ADJR FRT FIN (INCLS 40) (TITANIUM) 15947193 COVER, D/SEAT OTR ADJR FRT FIN (INCLS 40) (EBONY) not found CLIP, D/SEAT (ЧАСТЬ OF 39) not found ГАЙКА, D/SEAT (ЧАСТЬ OF 42) 25922430 РАМА, D/SEAT CUSH (INCLS 19-21, 26, 29-37, 41, 47) not found ГАЙКА, D/SEAT BELT (BKL SI) (ЧАСТЬ OF 46) 15947249 COVER, D/SEAT INR RECL FIN (INCLS 45) (CASHMERE) 15947250 COVER, D/SEAT INR RECL FIN (INCLS 45) (TITANIUM) 15947251 COVER, D/SEAT INR RECL FIN (INCLS 45) (EBONY) not found CLIP, D/SEAT (ЧАСТЬ OF 44) 19181818 BELT KIT, D/SEAT (BKL SI) (INCLS 43) (TITANIUM) 19181819 BELT KIT, D/SEAT (BKL SI) (INCLS 43) (EBONY) 19181820 BELT KIT, D/SEAT (BKL SI) (INCLS 43) (CASHMERE) 89024400 BELT KIT, D/SEAT (BKL SI) (INCLS 43) (GRAY) not found WIRE, D/SEAT CUSH PAD (ЧАСТЬ OF 42) 15947257 COVER, D/SEAT CUSH CLOSEOUT (INCLS 5) (CASHMERE) (11.573) 15947258 COVER, D/SEAT CUSH CLOSEOUT (INCLS 5) (TITANIUM) (11.573) 15947259 COVER, D/SEAT CUSH CLOSEOUT (INCLS 5) (EBONY) (11.573) (6D14-070) - 2008 DM69 ВОДИТЕЛЬСКОЕ СИДЕНЬЕ-СПИНКА (VENTED/HEATED KB6)(1ST DES) ↓ 25777056 PAD, D/SEAT BK CUSH (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939292) 25777057 PAD, D/SEAT BK CUSH (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939293) 25780652 RESTRAINT, D/SEAT HD (INCLS 3) (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939468) [ОГРАНИЧИТЕЛЬ] 25780653 RESTRAINT, D/SEAT HD (INCLS 3) (EBONY) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939469) 25939467 RESTRAINT, D/SEAT HD (INCLS 3) (CASHMERE) not found COVER, F/SEAT H/RST CUSH (ЧАСТЬ OF 2) 15947278 PANEL, D/SEAT BK CUSH FIN (INCLS 6) (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939328) 15947279 PANEL, D/SEAT BK CUSH FIN (INCLS 6) (EBONY) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939329) 25939323 PANEL, D/SEAT BK CUSH FIN (MAY ALSO NEED TO REPL PASS SIDE) (INCLS 6) (CASHMERE) 25939324 PANEL, D/SEAT BK CUSH FIN (MAY ALSO NEED TO REPL PASS SIDE) (INCLS 6) (TITANIUM) 25939325 PANEL, D/SEAT BK CUSH FIN (MAY ALSO NEED TO REPL PASS SIDE) (INCLS 6) (EBONY) 25785786 GUIDE, D/SEAT H/RST (CASHMERE) (W/BUTTON) 25785787 GUIDE, D/SEAT H/RST (TITANIUM) (W/BUTTON) 25785788 GUIDE, D/SEAT H/RST (EBONY) (W/BUTTON) 25785789 GUIDE, D/SEAT H/RST (CASHMERE) (W/O BUTTON) 25785790 GUIDE, D/SEAT H/RST (TITANIUM) (W/O BUTTON) 25785791 GUIDE, D/SEAT H/RST (EBONY) (W/O BUTTON) 25908135 GUIDE, D/SEAT H/RST (TITANIUM) (W/BUTTON) 25908165 GUIDE, D/SEAT H/RST (TITANIUM) (W/O BUTTON) 11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (ЧАСТЬ OF 4) [ЗАЖИМ КОНСОЛИ САЛОНА] 15865916 РАМА, D/SEAT BK CUSH (INCLS 11, 13, 15-20) (W/LUMBAR) (1ST DES W/O ACTIVE H/RST, HT OF BK PNL INDENTATION ABOVE MAP PKT=8") (FOR 2ND DES SEE 25807065) 15865917 РАМА, D/SEAT BK CUSH (INCLS 11, 13, 15-20) (14.896) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25807063) [КАРКАС СПИНКИ СИДЕНИЯ] 25807065 РАМА, D/SEAT BK CUSH (INCLS 11, 13, 15-20) (2ND DES W/ACTIVE H/RST, HT OF BK PNL INDENTATION ABOUVE MAP PKT=3") (FOR 1ST DES SEE 15865916) 25780794 ВЕНТИЛЯТОР, D/SEAT BACK VENTILATION HEAT & COOL (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939274) [ВЕНТИЛЯТОР] 11517068 NUT-METRIC HEX FLABGE, M6X1, 10MM SOCKET (D/SEAT) not found BRACKET, F/SEAT BK CUSH not found БОЛТ, F/SEAT LUMBAR SUPT (ЧАСТЬ OF 7) 20759565 МОДУЛЬ, D/SEAT SI INFL RST 11571066 ГАЙКА, PUSH-ON, FOR 9/32" (6.9MM) DIA STUDS, 18.4 OD, SAE 1050 STL, GMW30 (ЧАСТЬ OF 7) teamcadillac.ru 25828643 БОЛТ, F/SEAT 15894212 BAR, F/SEAT BK CUSH FRM CR (ЧАСТЬ OF 7) not found RIVET, F/SEAT BK CUSH FRM CR) (ЧАСТЬ OF 7 not found SENSOR, D/SEAT RECL POSN (ЧАСТЬ OF 7) not found MOTOR, D/SEAT RECL ACTR (ЧАСТЬ OF 7) not found BRACKET, F/SEAT ADJR (ЧАСТЬ OF 7) 15865928 LUMBAR SUB, D/SEAT (ЧАСТЬ OF 7) (W/O ACTIVE H/RST-HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) 25939289 LUMBAR SUB, D/SEAT (ЧАСТЬ OF 7) (W/ACTIVE H/RST-HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) [ПОЯСНИЧНАЯ ОПОРА СПИНКИ СИДЕНЬЯ] 25939527 LUMBAR SUB, D/SEAT (ЧАСТЬ OF 7) (W/ACTIVE H/RST-HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) not found PAD, D/SEAT CUSH (СМ. ГРУППУ 14.000 "ПАССАЖИРСКОЕ СИДЕНЬЕ-ПОДУШКА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25780792 ПОДОГРЕВАТЕЛЬ, D/SEAT BK CUSH (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939273) [НАГРЕВАТЕЛЬ] 25780302 COVER, D/SEAT BK CUSH (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PNL PKT=8IN) (FOR 2ND DES SEE 25939463) 25780303 COVER, D/SEAT BK CUSH (EBONY) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939464) 25780360 COVER, D/SEAT BK CUSH (CASHMERE) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939456) 25780361 COVER, D/SEAT BK CUSH (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939457) 25780362 COVER, D/SEAT BK CUSH (EBONY) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939458) (6D14-071) - 2008 DM69 СИДЕНЬЕ ПАССАЖИРА-BACK (VENTED/HEATED KB6) ↓ 25777061 PAD, P/SEAT BK CUSH (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939272) 25939272 PAD, P/SEAT BK CUSH (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25777061) 25780305 COVER, P/SEAT BK CUSH (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939519) 25780306 COVER, P/SEAT BK CUSH (EBONY) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939520) 25780364 COVER, P/SEAT BK CUSH (CASHMERE) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939511) 25780365 COVER, P/SEAT BK CUSH (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939512) 25780366 COVER, P/SEAT BK CUSH (EBONY) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939513) 25939511 COVER, P/SEAT BK CUSH (CASHMERE) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780364) 25939512 COVER, P/SEAT BK CUSH (TITANIUM) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780365) 25939513 COVER, P/SEAT BK CUSH (EBONY) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780366) 25939519 COVER, P/SEAT BK CUSH (TITANIUM) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780305) 25939520 COVER, P/SEAT BK CUSH (EBONY) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780306) 25939273 ПОДОГРЕВАТЕЛЬ, P/SEAT BK CUSH (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25996273) 25996273 ПОДОГРЕВАТЕЛЬ, P/SEAT BK CUSH (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939273) 15865926 LUMBAR SUB, P/SEAT (ЧАСТЬ OF 18) (W/O ACTIVE H/RST-HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) 15865927 LUMBAR SUB, P/SEAT (ЧАСТЬ OF 18) (W/O ACTIVE H/RST-HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) 25939270 LUMBAR SUB, P/SEAT (ЧАСТЬ OF 18) (W/ACTIVE H/RST-HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) 25939527 LUMBAR SUB, P/SEAT (ЧАСТЬ OF 18) (W/ACTIVE H/RST-HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) 25780794 ВЕНТИЛЯТОР, P/SEAT BACK VENTILATION HEAT & COOL (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939274) [ВЕНТИЛЯТОР] 25939274 ВЕНТИЛЯТОР, P/SEAT BACK VENTILATION HEAT & COOL (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780794) not found BRACKET, F/SEAT ADJR (ЧАСТЬ OF 18) 15894213 ACTUATOR, P/SEAT RECL (ЧАСТЬ OF 18) not found PAD, P/SEAT CUSH (СМ. ГРУППУ 14.000 "СИДЕНЬЕ ПАССАЖИРА-CUSHION" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11571066 ГАЙКА, PUSH-ON, FOR 9/32" (6.9MM) DIA STUDS, 18.4 OD, SAE 1050 STL, GMW30 (ЧАСТЬ OF 18) 25828643 БОЛТ, F/SEAT (ЧАСТЬ OF 18) 15894212 BAR, F/SEAT BK CUSH FRM CR (ЧАСТЬ OF 18) 25898670 МОДУЛЬ, P/SEAT SI INFL RST not found RIVET, F/SEAT BK CUSH FRM CR) (ЧАСТЬ OF 18 not found БОЛТ, F/SEAT LUMBAR SUPT (ЧАСТЬ OF 18) not found BRACKET, F/SEAT BK CUSH 11517068 NUT-METRIC HEX FLABGE, M6X1, 10MM SOCKET (P/SEAT) 11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (ЧАСТЬ OF 21) [ЗАЖИМ КОНСОЛИ САЛОНА] 15865921 РАМА, P/SEAT BK CUSH (INCLS 4, 6, 7, 9-11, 13, 14) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP=8IN) (FOR 2ND DES SEE 25807066) 15865924 РАМА, P/SEAT BK CUSH (INCLS 4, 6, 7, 9-11, 13, 14) (W/O ACTIVE HEAD RESTRAINT) (FOR 2ND DES SEE 25807067) 25807066 РАМА, P/SEAT BK CUSH (INCLS 4, 6, 7, 9-11, 13, 14) (14.896) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 15865921) 25807067 РАМА, P/SEAT BK CUSH (INCLS 4, 6, 7, 9-11, 13, 14) (14.896) (W/ACTIVE HEAD RESTRAINT) (FOR 1ST DES SEE 15865924) teamcadillac.ru 25780652 RESTRAINT, P/SEAT HD (INCLS 22) (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939468) [ОГРАНИЧИТЕЛЬ] 25780653 RESTRAINT, P/SEAT HD (INCLS 22) (EBONY) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939469) 25780655 RESTRAINT, P/SEAT HD (INCLS 22) (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939472) 25780656 RESTRAINT, P/SEAT HD (INCLS 22) (EBONY) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25984306) 25939467 RESTRAINT, P/SEAT HD (INCLS 22) (CASHMERE) 25939468 RESTRAINT, P/SEAT HD (INCLS 22) (TITANIUM) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780652) 25939469 RESTRAINT, P/SEAT HD (INCLS 22) (EBONY) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780653) 25939472 RESTRAINT, P/SEAT HD (INCLS 22) (TITANIUM) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780655) 25984306 RESTRAINT, P/SEAT HD (INCLS 22) (EBONY) (WHEN USED TO SERV 2008, REPL BOTH DRIVER & PASSENGER RST) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780656) 25785786 GUIDE, P/SEAT H/RST (CASHMERE) (W/BUTTON) 25785787 GUIDE, P/SEAT H/RST (TITANIUM) (W/BUTTON) 25785788 GUIDE, P/SEAT H/RST (EBONY) (W/BUTTON) 25785789 GUIDE, P/SEAT H/RST (CASHMERE) (W/O BUTTON) 25785790 GUIDE, P/SEAT H/RST (TITANIUM) (W/O BUTTON) 25785791 GUIDE, P/SEAT H/RST (EBONY) (W/O BUTTON) 25908135 GUIDE, P/SEAT H/RST (TITANIUM) (W/BUTTON) 25908165 GUIDE, P/SEAT H/RST (TITANIUM) (W/O BUTTON) 15947283 PANEL, P/SEAT BK CUSH FIN (MAY ALSO NEED TO REPL DRIVER SIDE) (INCLS 17) (EBONY) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939494) 25939487 PANEL, P/SEAT BK CUSH FIN (INCLS 17) (CASHMERE) 25939488 PANEL, P/SEAT BK CUSH FIN (INCLS 17) (TITANIUM) 25939489 PANEL, P/SEAT BK CUSH FIN (INCLS 17) (EBONY) (MAY ALSO NEED TO REPL DRIVER SIDE) 25939493 PANEL, P/SEAT BK CUSH FIN (INCLS 17) (TITANIUM) 25939494 PANEL, P/SEAT BK CUSH FIN (INCLS 17) (EBONY) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 15947283) not found COVER, F/SEAT H/RST CUSH (ЧАСТЬ OF 19) (6D14-072) - 2008 DM69 СИДЕНЬЕ ПАССАЖИРА-CUSHION (VENTED/HEATED KB6) ↓ 25780356 COVER, P/SEAT CUSH (CASHMERE) 25780357 COVER, P/SEAT CUSH (TITANIUM) 25780358 COVER, P/SEAT CUSH (EBONY) not found PAD, P/SEAT CUSH (*KIT1) not found МОДУЛЬ, INFL RST P/SEAT SUPPRESSION (*KIT1) 19181814 BELT KIT, P/SEAT (BKL SI) (INCLS 8) (TITANIUM) 19181815 BELT KIT, P/SEAT (BKL SI) (INCLS 8) (EBONY) 19181816 BELT KIT, P/SEAT (BKL SI) (INCLS 8) (CASHMERE) not found CLIP, P/SEAT RECL LWR FIN (ЧАСТЬ OF 7) 15947253 COVER, P/SEAT RECL LWR FIN (INCLS 6) (CASHMERE) 15947254 COVER, P/SEAT RECL LWR FIN (INCLS 6) (TITANIUM) 15947255 COVER, P/SEAT RECL LWR FIN (INCLS 6) (EBONY) not found ГАЙКА, P/SEAT BELT (ЧАСТЬ OF 5) not found ГАЙКА, P/SEAT (ЧАСТЬ OF 43) not found CLIP, P/SEAT ADJR FIN (ЧАСТЬ OF 11) 15947234 COVER, P/SEAT ADJR FIN (INCLS 10) (CASHMERE) 15947235 COVER, P/SEAT ADJR FIN (INCLS 10) (TITANIUM) 15947236 COVER, P/SEAT ADJR FIN (INCLS 10) (EBONY) 25780793 ВЕНТИЛЯТОР, P/SEAT CUSH VENTILATION HEAT & COOL [ВЕНТИЛЯТОР] 15894170 ACTUATOR, F/SEAT TILT ADJR (ЧАСТЬ OF 43) 15894172 ACTUATOR, F/SEAT TILT ADJR (ЧАСТЬ OF 43) 15894173 ACTUATOR, F/SEAT TILT ADJR (ЧАСТЬ OF 43) not found ГАЙКА, P/SEAT (ЧАСТЬ OF 43) 15894154 ACTUATOR, P/SEAT INR ADJR RR VERT (ЧАСТЬ OF 43) 15894137 MOTOR, P/SEAT ADJR ACTR (INCLS 17) (ЧАСТЬ OF 43) (W/O SEAT ADJR MEMORY MDL) not found ACTUATOR, P/SEAT ADJR (ЧАСТЬ OF 16, 43) not found BRACE, P/SEAT (ЧАСТЬ OF 43) not found BRACKET, P/SEAT (ЧАСТЬ OF 43) 15817518 SENSOR, INFL RST FRT PASS POSITION (ЧАСТЬ OF 43) [ДАТЧИК ПОДУШКИ БЕЗОПАСНОСТИ] not found TRACK, P/SEAT INR ADJR (ЧАСТЬ OF 43) 15947313 COVER, P/SEAT INR ADJR TRK FRT FIN (CASHMERE) 15947315 COVER, P/SEAT INR ADJR TRK FRT FIN (EBONY) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ] 15947305 COVER, P/SEAT OTR ADJR TRK FRT FIN (CASHMERE) 15947307 COVER, P/SEAT OTR ADJR TRK FRT FIN (EBONY) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ] not found TRACK, P/SEAT OTR ADJR (ЧАСТЬ OF 43) 25780747 HARNESS, P/SEAT CONT MDL WRG (W/O ACTIVE H/RST;HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DESIGN SEE 25939265) 25780748 HARNESS, P/SEAT CONT MDL WRG (W/O ACTIVE H/RST;HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DESIGN SEE 25939267) 25904923 HARNESS, P/SEAT CONT MDL WRG (W/O ACTIVE H/RST;HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DESIGN SEE 25939265) 25904924 HARNESS, P/SEAT CONT MDL WRG (W/O ACTIVE H/RST;HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DESIGN SEE 25939266) 25939264 HARNESS, P/SEAT CONT MDL WRG (W/ ACTIVE H/RST;HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DSG SEE 25904923) 25939265 HARNESS, P/SEAT CONT MDL WRG (W/ ACTIVE H/RST;HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DSG SEE 25780747) 25939266 HARNESS, P/SEAT CONT MDL WRG (W/ ACTIVE H/RST;HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DSG SEE 25904924) 25939267 HARNESS, P/SEAT CONT MDL WRG (W/ ACTIVE H/RST;HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DSG SEE 25780748) 25781231 ЛАМПА, LUMINESCENT [ЛАМПА ЛЮМИНИСТЦЕНТНАЯ] not found CLIP, P/SEAT (ЧАСТЬ OF 28, 29 15947289 COVER, P/SEAT OTR ADJR TRK RR FIN (INCLS 27) (CASHMERE) 15947291 COVER, P/SEAT OTR ADJR TRK RR FIN (INCLS 27) (EBONY) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ] 15947297 COVER, P/SEAT INR ADJR TRK RR FIN (INCLS 27) (CASHMERE) 15947299 COVER, P/SEAT INR ADJR TRK RR FIN (INCLS 27) (EBONY) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ] not found BRACKET, INFL RST P/SEAT SUPPRESSION 11517068 NUT-METRIC HEX FLABGE, M6X1, 10MM SOCKET (P/SEAT) 11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (D/SEAT) not found CLIP, P/SEAT ADJR SW (ЧАСТЬ OF 37) 15889524 KNOB, P/SEAT ADJR SW (EBONY) (16.682) 15889525 KNOB, P/SEAT ADJR SW (CASHMERE) (16.682) 25863076 KNOB, P/SEAT ADJR SW (TITANIUM) 15889530 KNOB, P/SEAT RECL (EBONY) (16.682) 15889531 KNOB, P/SEAT RECL (CASHMERE) (16.682) 25863075 KNOB, P/SEAT RECL (TITANIUM) 15952350 COVER, P/SEAT BELT OPG TR (RETR SI) (CASHMERE) 15952351 COVER, P/SEAT BELT OPG TR (RETR SI) (TITANIUM) 15952352 COVER, P/SEAT BELT OPG TR (RETR SI) (EBONY) 15947243 BEZEL, P/SEAT ADJR SW (INCLS 33) (TITANIUM) 25994756 BEZEL, P/SEAT ADJR SW (INCLS 33) (EBONY) 25994763 BEZEL, P/SEAT ADJR SW (INCLS 33) (EBONY) 12451498 SWITCH, P/SEAT ADJR & RECL (8-WAY) (P SEAT ADJ SWITCH LABELED 12451498) [ВЫКЛЮЧАТЕЛЬ ПОЛОЖЕНИЯ СИДЕНЬЯ] 10315826 SWITCH, P/SEAT LUMBAR CONT (EBONY) [ВЫКЛЮЧАТЕЛЬ РЕГУЛИРОВКИ ПОЛОЖЕНИЯ СИДЕНЬЯ] 15210786 SWITCH, P/SEAT LUMBAR CONT (CASHMERE) 15895688 SWITCH, P/SEAT LUMBAR CONT (TITANIUM) 25780741 BRACKET, P/SEAT RECL HDL BZL 25828643 БОЛТ, F/SEAT not found CLIP, P/SEAT ADJR FIN (ЧАСТЬ OF 45) 25922431 РАМА, P/SEAT CUSH (INCLS 9, 13-21, 24, 44) not found WIRE, P/SEAT CUSH PAD (ЧАСТЬ OF 43) 15947257 COVER, P/SEAT CUSH CLOSEOUT (INCLS 42) (CASHMERE) (11.573) 15947258 COVER, P/SEAT CUSH CLOSEOUT (INCLS 42) (TITANIUM) (11.573) 15947259 COVER, P/SEAT CUSH CLOSEOUT (INCLS 42) (EBONY) (11.573) not found COVER, P/SEAT BK CUSH (СМ. ГРУППУ 14.000 "СИДЕНЬЕ ПАССАЖИРА-BACK" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found МОДУЛЬ KIT, INFL RST FRT PASS PRESENCE (W/ SEN) (INCLS 2, 3) not found МОДУЛЬ KIT, INFL RST FRT PASS PRESENCE (W/ SEN) (INCLS 2, 3) not found МОДУЛЬ KIT, INFL RST FRT PASS PRESENCE (W/ SEN) (INCLS 2, 3) (6D14-073) - 2008 DM69 СИДЕНЬЕ ПАССАЖИРА-CUSHION (POWER ADJUSTER AH8, ИСКЛЮЧАЯ ВЕНТИЛЯЦИЮ И ОБОГРЕВ KB6) ↓ 25780312 COVER, P/SEAT CUSH (CASHMERE) 25780313 COVER, P/SEAT CUSH (TITANIUM) 25780314 COVER, P/SEAT CUSH (EBONY) not found PAD, P/SEAT CUSH (*KIT1) not found МОДУЛЬ, INFL RST P/SEAT SUPPRESSION (*KIT1) not found WIRE, P/SEAT CUSH PAD (ЧАСТЬ OF 12) 19181814 BELT KIT, P/SEAT (BKL SI) (INCLS 8) (TITANIUM) 19181815 BELT KIT, P/SEAT (BKL SI) (INCLS 8) (EBONY) 19181816 BELT KIT, P/SEAT (BKL SI) (INCLS 8) (CASHMERE) not found CLIP, P/SEAT RECL LWR FIN (ЧАСТЬ OF 7) 15947253 COVER, P/SEAT RECL LWR FIN (INCLS 6) (CASHMERE) 15947254 COVER, P/SEAT RECL LWR FIN (INCLS 6) (TITANIUM) 15947255 COVER, P/SEAT RECL LWR FIN (INCLS 6) (EBONY) not found ГАЙКА, P/SEAT BELT (ЧАСТЬ OF 5) not found ГАЙКА, P/SEAT (ЧАСТЬ OF 12) not found CLIP, P/SEAT ADJR FIN (ЧАСТЬ OF 11) 15947234 COVER, P/SEAT ADJR FIN (INCLS 10) (CASHMERE) 15947235 COVER, P/SEAT ADJR FIN (INCLS 10) (TITANIUM) 15947236 COVER, P/SEAT ADJR FIN (INCLS 10) (EBONY) 25922431 РАМА, P/SEAT CUSH (INCLS 4, 9, 13-21, 24) 15894170 ACTUATOR, F/SEAT TILT ADJR (ЧАСТЬ OF 12) 15894172 ACTUATOR, F/SEAT TILT ADJR (ЧАСТЬ OF 12) 15894173 ACTUATOR, F/SEAT TILT ADJR (ЧАСТЬ OF 12) not found ГАЙКА, P/SEAT (ЧАСТЬ OF 12) 15894154 ACTUATOR, P/SEAT INR ADJR RR VERT (ЧАСТЬ OF 12) 15894137 MOTOR, P/SEAT ADJR ACTR (INCLS 17) (ЧАСТЬ OF 12) (W/O SEAT ADJR MEMORY MDL) not found ACTUATOR, P/SEAT ADJR (ЧАСТЬ OF 12, 16) not found BRACE, P/SEAT (ЧАСТЬ OF 12) not found BRACKET, P/SEAT (ЧАСТЬ OF 12) 15817518 SENSOR, INFL RST FRT PASS POSITION (ЧАСТЬ OF 12) [ДАТЧИК ПОДУШКИ БЕЗОПАСНОСТИ] not found TRACK, P/SEAT INR ADJR (ЧАСТЬ OF 12) 15947313 COVER, P/SEAT INR ADJR TRK FRT FIN (CASHMERE) 15947315 COVER, P/SEAT INR ADJR TRK FRT FIN (EBONY) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ] 15947305 COVER, P/SEAT OTR ADJR TRK FRT FIN (CASHMERE) 15947307 COVER, P/SEAT OTR ADJR TRK FRT FIN (EBONY) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ] not found TRACK, P/SEAT OTR ADJR (ЧАСТЬ OF 12) 25780747 HARNESS, P/SEAT CONT MDL WRG (W/O ACTIVE H/RST;HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DESIGN SEE 25939265) 25904923 HARNESS, P/SEAT CONT MDL WRG (W/O ACTIVE H/RST;HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DESIGN SEE 25939265) 25939264 HARNESS, P/SEAT CONT MDL WRG (W/ ACTIVE H/RST;HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DSG SEE 25904923) 25939265 HARNESS, P/SEAT CONT MDL WRG (W/ ACTIVE H/RST;HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DSG SEE 25780747) 25781231 ЛАМПА, LUMINESCENT [ЛАМПА ЛЮМИНИСТЦЕНТНАЯ] not found CLIP, P/SEAT (ЧАСТЬ OF 28, 29) 15947289 COVER, P/SEAT OTR ADJR TRK RR FIN (INCLS 27) (CASHMERE) 15947291 COVER, P/SEAT OTR ADJR TRK RR FIN (INCLS 27) (EBONY) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ] 15947297 COVER, P/SEAT INR ADJR TRK RR FIN (INCLS 27) (CASHMERE) 15947299 COVER, P/SEAT INR ADJR TRK RR FIN (INCLS 27) (EBONY) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ] not found BRACKET, INFL RST P/SEAT SUPPRESSION 11517068 NUT-METRIC HEX FLABGE, M6X1, 10MM SOCKET (P/SEAT) 11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (D/SEAT) not found CLIP, P/SEAT ADJR SW (ЧАСТЬ OF 37) 15889524 KNOB, P/SEAT ADJR SW (EBONY) (16.682) 15889525 KNOB, P/SEAT ADJR SW (CASHMERE) (16.682) 25863076 KNOB, P/SEAT ADJR SW (TITANIUM) 15889530 KNOB, P/SEAT RECL (EBONY) (16.682) 15889531 KNOB, P/SEAT RECL (CASHMERE) (16.682) 25863075 KNOB, P/SEAT RECL (TITANIUM) 15952350 COVER, P/SEAT BELT OPG TR (RETR SI) (CASHMERE) teamcadillac.ru 15952351 COVER, P/SEAT BELT OPG TR (RETR SI) (TITANIUM) 15952352 COVER, P/SEAT BELT OPG TR (RETR SI) (EBONY) 15947243 BEZEL, P/SEAT ADJR SW (INCLS 33) (TITANIUM) 25994756 BEZEL, P/SEAT ADJR SW (INCLS 33) (EBONY) 25994763 BEZEL, P/SEAT ADJR SW (INCLS 33) (EBONY) 12451498 SWITCH, P/SEAT ADJR & RECL (8-WAY) (P SEAT ADJ SWITCH LABELED 12451498) [ВЫКЛЮЧАТЕЛЬ ПОЛОЖЕНИЯ СИДЕНЬЯ] 10315826 SWITCH, P/SEAT LUMBAR CONT (EBONY) [ВЫКЛЮЧАТЕЛЬ РЕГУЛИРОВКИ ПОЛОЖЕНИЯ СИДЕНЬЯ] 15210786 SWITCH, P/SEAT LUMBAR CONT (CASHMERE) 15895688 SWITCH, P/SEAT LUMBAR CONT (TITANIUM) 25780741 BRACKET, P/SEAT RECL HDL BZL 25828643 БОЛТ, F/SEAT not found CLIP, P/SEAT ADJR FIN (ЧАСТЬ OF 43) 15947257 COVER, P/SEAT CUSH CLOSEOUT (INCLS 42) (CASHMERE) (11.573) 15947258 COVER, P/SEAT CUSH CLOSEOUT (INCLS 42) (TITANIUM) (11.573) 15947259 COVER, P/SEAT CUSH CLOSEOUT (INCLS 42) (EBONY) (11.573) not found COVER, P/SEAT BK CUSH (СМ. ГРУППУ 14.000 "СИДЕНЬЕ ПАССАЖИРА-BACK" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found МОДУЛЬ KIT, INFL RST P/SEAT SUPPRESSION (INCLS 2, 3) (6D14-074) - 2008 DM69 FRONT SEAT КРЕПЛЕНИЕ ↓ 25838780 SEAT, DRVR (EBONY) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25938654) 25838781 SEAT, DRVR (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25938655) 25838782 SEAT, DRVR (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25938656) 25838785 SEAT, DRVR (EBONY) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25938664) 25838786 SEAT, DRVR (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25938665) 25838787 SEAT, DRVR (CASHMERE) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25938666) 25838790 SEAT, DRVR (EBONY) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25938686) 25838791 SEAT, DRVR (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25938687) 25903911 SEAT, DRVR (EBONY) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25938690) 25903912 SEAT, DRVR (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25938691) 25903913 SEAT, DRVR (CASHMERE) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25938692) 25903915 SEAT, DRVR (EBONY) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25938694) 25903916 SEAT, DRVR (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25938695) 25903917 SEAT, DRVR (CASHMERE) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25938696) 25938654 SEAT, DRVR (EBONY) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25838780) 25938655 SEAT, DRVR (TITANIUM) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25838781) 25938656 SEAT, DRVR (CASHMERE) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25838782) 25938664 SEAT, DRVR (EBONY) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25838785) 25938665 SEAT, DRVR (TITANIUM) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25838786) 25938666 SEAT, DRVR (CASHMERE) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25838787) 25938686 SEAT, DRVR (EBONY) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25838790) 25938687 SEAT, DRVR (TITANIUM) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25838791) 25938690 SEAT, DRVR (EBONY) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25903911) 25938691 SEAT, DRVR (TITANIUM) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25903912) 25938692 SEAT, DRVR (CASHMERE) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25903913) 25938694 SEAT, DRVR (EBONY) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25903915) 25938695 SEAT, DRVR (TITANIUM) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25903916) 25938696 SEAT, DRVR (CASHMERE) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25903917) 15947293 COVER, D/SEAT INR ADJR TRK RR FIN (INCLS 3) (CASHMERE) 15947295 COVER, D/SEAT INR ADJR TRK RR FIN (INCLS 3) (EBONY) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ] not found CLIP, D/SEAT (ЧАСТЬ OF 2, 4) 15947285 COVER, D/SEAT OTR ADJR TRK RR FIN (INCLS 2) (CASHMERE) 15947287 COVER, D/SEAT OTR ADJR TRK RR FIN (INCLS 2) (EBONY) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ] teamcadillac.ru 11609257 БОЛТ, PAN HD, TORX, M12X1.75X34, 9.8 STEEL, GMW3179 (D/SEAT ADJR) (8.907) [БОЛТ] 15947301 COVER, D/SEAT OTR ADJR TRK FRT FIN (CASHMERE) 15947303 COVER, D/SEAT OTR ADJR TRK FRT FIN (EBONY) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ] 15947309 COVER, D/SEAT INR ADJR TRK FRT FIN (CASHMERE) 15947311 COVER, D/SEAT INR ADJR TRK FRT FIN (EBONY) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ] 15947313 COVER, P/SEAT INR ADJR TRK FRT FIN (CASHMERE) 15947315 COVER, P/SEAT INR ADJR TRK FRT FIN (EBONY) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ] 15947305 COVER, P/SEAT OTR ADJR TRK FRT FIN (CASHMERE) 15947307 COVER, P/SEAT OTR ADJR TRK FRT FIN (EBONY) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ] 25838793 SEAT, PASS (EBONY) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25938751) 25838794 SEAT, PASS (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25938752) 25838795 SEAT, PASS (CASHMERE) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25938753) 25838798 SEAT, PASS (EBONY) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25938766) 25838799 SEAT, PASS (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25938767) 25838800 SEAT, PASS (CASHMERE) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25938768) 25838803 SEAT, PASS (EBONY) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25938830) 25838804 SEAT, PASS (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25938831) 25903919 SEAT, PASS (EBONY) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25938874) 25903920 SEAT, PASS (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25938875) 25903921 SEAT, PASS (CASHMERE) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25938876) 25903923 SEAT, PASS (EBONY) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25938879) 25903924 SEAT, PASS (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25938880) 25903925 SEAT, PASS (CASHMERE) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25938881) 25938751 SEAT, PASS (EBONY) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25838793) 25938752 SEAT, PASS (TITANIUM) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25838794) 25938753 SEAT, PASS (CASHMERE) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25838795) 25938766 SEAT, PASS (EBONY) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25838798) 25938767 SEAT, PASS (TITANIUM) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25838799) 25938768 SEAT, PASS (CASHMERE) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25838800) 25938830 SEAT, PASS (EBONY) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25838803) 25938831 SEAT, PASS (TITANIUM) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25838804) 25938874 SEAT, PASS (EBONY) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25903919) 25938875 SEAT, PASS (TITANIUM) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25903920) 25938876 SEAT, PASS (CASHMERE) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25903921) 25938879 SEAT, PASS (EBONY) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25903923) 25938880 SEAT, PASS (TITANIUM) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25903924) 25938881 SEAT, PASS (CASHMERE) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25903925) 15947289 COVER, P/SEAT OTR ADJR TRK RR FIN (INCLS 12) (CASHMERE) 15947291 COVER, P/SEAT OTR ADJR TRK RR FIN (INCLS 12) (EBONY) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ] not found CLIP, P/SEAT (ЧАСТЬ OF 11, 13) 15947297 COVER, P/SEAT INR ADJR TRK RR FIN (INCLS 12) (CASHMERE) 15947299 COVER, P/SEAT INR ADJR TRK RR FIN (INCLS 12) (EBONY) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ] 11609257 БОЛТ, PAN HD, TORX, M12X1.75X34, 9.8 STEEL, GMW3179 (P/SEAT ADJR) (8.907) [БОЛТ] (6D14-075) - 2008 DM69 ПАССАЖИРСКОЕ СИДЕНЬЕ-ПОДУШКА (POWER LUMBAR AL2, ИСКЛЮЧАЯ ВЕНТИЛЯЦИЮ И ОБОГРЕВ KB6) ↓ 25780308 COVER, D/SEAT CUSH (CASHMERE) [КРЫШКА] 25780309 COVER, D/SEAT CUSH (TITANIUM) 25780310 COVER, D/SEAT CUSH (EBONY) 20755532 PAD, D/SEAT CUSH 20755532 PAD, D/SEAT CUSH 15947257 COVER, D/SEAT CUSH CLOSEOUT (INCLS 5) (CASHMERE) (11.573) 15947258 COVER, D/SEAT CUSH CLOSEOUT (INCLS 5) (TITANIUM) (11.573) 15947259 COVER, D/SEAT CUSH CLOSEOUT (INCLS 5) (EBONY) (11.573) not found PAD, D/SEAT BK CUSH (СМ. ГРУППУ 14.000 "ВОДИТЕЛЬСКОЕ СИДЕНЬЕ-СПИНКА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found CLIP, D/SEAT INR ADJR RR FIN (ЧАСТЬ OF 3) 25828643 БОЛТ, F/SEAT not found BRACKET, D/SEAT RECL HDL BZL 12451497 SWITCH, D/SEAT ADJR & RECL (8-WAY) [ВКЛЮЧАТЕЛЬ] 10315826 SWITCH, D/SEAT LUMBAR CONT (EBONY) [ВЫКЛЮЧАТЕЛЬ РЕГУЛИРОВКИ ПОЛОЖЕНИЯ СИДЕНЬЯ] 15210786 SWITCH, D/SEAT LUMBAR CONT (CASHMERE) 15895688 SWITCH, D/SEAT LUMBAR CONT (TITANIUM) 15947239 BEZEL, D/SEAT ADJR SW (INCLS 14) (TITANIUM) 25994746 BEZEL, D/SEAT ADJR SW (INCLS 14) (EBONY) (W/LUMBAR PREРОЛИК НАТЯЖИТЕЛЬ) 25994748 BEZEL, D/SEAT ADJR SW (INCLS 14) (CASHMERE) 15952346 COVER, D/SEAT BELT OPG TR (RETR SI) (CASHMERE) 15952348 COVER, D/SEAT BELT OPG TR (RETR SI) (EBONY) 15952348 COVER, D/SEAT BELT OPG TR (RETR SI) (EBONY) 15889530 KNOB, D/SEAT RECL LVR (EBONY) (16.682) 15889531 KNOB, D/SEAT RECL LVR (CASHMERE) (16.682) 25863075 KNOB, D/SEAT RECL LVR (TITANIUM) 15889524 KNOB, D/SEAT ADJR SW (EBONY) (16.682) 15889525 KNOB, D/SEAT ADJR SW (CASHMERE) (16.682) 25863076 KNOB, D/SEAT ADJR SW (TITANIUM) not found CLIP, D/SEAT ADJR SW (ЧАСТЬ OF 10) 11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (D/SEAT) 11517068 NUT-METRIC HEX FLABGE, M6X1, 10MM SOCKET (D/SEAT) 25855630 МОДУЛЬ, D/SEAT ADJR MEMORY (USE W/МОДУЛЬS LABELED W/OEM PN 25855630) (REQUIRES DEALER PROGRAMMING) (LABELED 25855630) [ПРОГРАММИРУЕМЫЙ КОНТРОЛЛЕР РЕГУЛИРОВКИ ПОЛОЖЕНИЯ СИДЕНЬЯ] 25780742 HARNESS, D/SEAT CONT MDL WRG (W/O ACTIVE H/RST;HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DESIGN SEE 25939286) 25780744 HARNESS, D/SEAT CONT MDL WRG 25904925 HARNESS, D/SEAT CONT MDL WRG (W/O ACTIVE H/RST;HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DESIGN SEE 25939285) 25939285 HARNESS, D/SEAT CONT MDL WRG (W/ ACTIVE H/RST;HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DSG SEE 25904925) 25939286 HARNESS, D/SEAT CONT MDL WRG (W/ ACTIVE H/RST;HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DSG SEE 25780742) not found ГАЙКА, D/SEAT (ЧАСТЬ OF 41) 15894164 ACTUATOR, D/SEAT OTR ADJR RR VERT (INCLS 21) (ЧАСТЬ OF 41) not found МОДУЛЬ, D/SEAT ADJR MEMORY (ЧАСТЬ OF 20, 41) teamcadillac.ru 15947293 COVER, D/SEAT INR ADJR TRK RR FIN (INCLS 23) (CASHMERE) 15947295 COVER, D/SEAT INR ADJR TRK RR FIN (INCLS 23) (EBONY) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ] not found CLIP, D/SEAT (ЧАСТЬ OF 22, 24) 15947285 COVER, D/SEAT OTR ADJR TRK RR FIN (INCLS 23) (CASHMERE) 15947287 COVER, D/SEAT OTR ADJR TRK RR FIN (INCLS 23) (EBONY) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ] 25781231 ЛАМПА, LUMINESCENT [ЛАМПА ЛЮМИНИСТЦЕНТНАЯ] not found TRACK, D/SEAT OTR ADJR (ЧАСТЬ OF 41) 15947301 COVER, D/SEAT OTR ADJR TRK FRT FIN (CASHMERE) 15947303 COVER, D/SEAT OTR ADJR TRK FRT FIN (EBONY) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ] 15947309 COVER, D/SEAT INR ADJR TRK FRT FIN (CASHMERE) 15947311 COVER, D/SEAT INR ADJR TRK FRT FIN (EBONY) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ] not found TRACK, D/SEAT INR ADJR (ЧАСТЬ OF 41) 15817518 SENSOR, INFL RST FRT PASS POSITION (ЧАСТЬ OF 41) [ДАТЧИК ПОДУШКИ БЕЗОПАСНОСТИ] not found BRACE, D/SEAT (ЧАСТЬ OF 41) not found ГАЙКА, D/SEAT (ЧАСТЬ OF 41) not found ACTUATOR, D/SEAT ADJR (ЧАСТЬ OF 35, 41) not found МОДУЛЬ, D/SEAT ADJR MEMORY (ЧАСТЬ OF 35, 41) 15894137 MOTOR, D/SEAT ADJR ACTR (ЧАСТЬ OF 41) (INCLS 33, 34) (W/O SEAT ADJR MEMORY MDL) 15894138 MOTOR, D/SEAT ADJR ACTR (ЧАСТЬ OF 41) (INCLS 33, 34) (W/SEAT ADJR MEMORY MDL) not found МОДУЛЬ, D/SEAT ADJR MEMORY (ЧАСТЬ OF 37, 41) 15894170 ACTUATOR, F/SEAT TILT ADJR (ЧАСТЬ OF 41) (INCLS 36) 15894173 ACTUATOR, F/SEAT TILT ADJR (ЧАСТЬ OF 41) (INCLS 36) 15947191 COVER, D/SEAT OTR ADJR FRT FIN (INCLS 39) (CASHMERE) 15947192 COVER, D/SEAT OTR ADJR FRT FIN (INCLS 39) (TITANIUM) 15947193 COVER, D/SEAT OTR ADJR FRT FIN (INCLS 39) (EBONY) not found CLIP, D/SEAT (ЧАСТЬ OF 38) not found ГАЙКА, D/SEAT (ЧАСТЬ OF 41) 25922430 РАМА, D/SEAT CUSH (INCLS 19-21, 26, 29-37, 40, 46) not found ГАЙКА, D/SEAT BELT (BKL SI) (ЧАСТЬ OF 45) 15947249 COVER, D/SEAT INR RECL FIN (INCLS 44) (CASHMERE) 15947250 COVER, D/SEAT INR RECL FIN (INCLS 44) (TITANIUM) 15947251 COVER, D/SEAT INR RECL FIN (INCLS 44) (EBONY) not found CLIP, D/SEAT (ЧАСТЬ OF 43) 19181818 BELT KIT, D/SEAT (BKL SI) (INCLS 42) (TITANIUM) 19181819 BELT KIT, D/SEAT (BKL SI) (INCLS 42) (EBONY) 19181820 BELT KIT, D/SEAT (BKL SI) (INCLS 42) (CASHMERE) 89024400 BELT KIT, D/SEAT (BKL SI) (INCLS 42) (GRAY) not found WIRE, D/SEAT CUSH PAD (ЧАСТЬ OF 41) (6D14-076) - 2008 DM69 ВОДИТЕЛЬСКОЕ СИДЕНЬЕ-СПИНКА (POWER LUMBAR AL2, ИСКЛЮЧАЯ ВЕНТИЛЯЦИЮ И ОБОГРЕВ KB6)(1ST DES) ↓ 25777056 PAD, D/SEAT BK CUSH (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939292) 25777056 PAD, D/SEAT BK CUSH (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939292) 25780652 RESTRAINT, D/SEAT HD (INCLS 3) (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939468) [ОГРАНИЧИТЕЛЬ] teamcadillac.ru 25780653 RESTRAINT, D/SEAT HD (INCLS 3) (EBONY) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939469) 25939467 RESTRAINT, D/SEAT HD (INCLS 3) (CASHMERE) not found COVER, F/SEAT H/RST CUSH (ЧАСТЬ OF 2) 25939323 PANEL, D/SEAT BK CUSH FIN (MAY ALSO NEED TO REPL PASS SIDE) (INCLS 6) (CASHMERE) 25939324 PANEL, D/SEAT BK CUSH FIN (MAY ALSO NEED TO REPL PASS SIDE) (INCLS 6) (TITANIUM) 25939325 PANEL, D/SEAT BK CUSH FIN (MAY ALSO NEED TO REPL PASS SIDE) (INCLS 6) (EBONY) 25785786 GUIDE, D/SEAT H/RST (CASHMERE) (W/BUTTON) 25785787 GUIDE, D/SEAT H/RST (TITANIUM) (W/BUTTON) 25785788 GUIDE, D/SEAT H/RST (EBONY) (W/BUTTON) 25785789 GUIDE, D/SEAT H/RST (CASHMERE) (W/O BUTTON) 25785790 GUIDE, D/SEAT H/RST (TITANIUM) (W/O BUTTON) 25785791 GUIDE, D/SEAT H/RST (EBONY) (W/O BUTTON) 25908135 GUIDE, D/SEAT H/RST (TITANIUM) (W/BUTTON) 25908165 GUIDE, D/SEAT H/RST (TITANIUM) (W/O BUTTON) 11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (ЧАСТЬ OF 4) [ЗАЖИМ КОНСОЛИ САЛОНА] 15865916 РАМА, D/SEAT BK CUSH (INCLS 10, 12, 14-19) (W/LUMBAR) (1ST DES W/O ACTIVE H/RST, HT OF BK PNL INDENTATION ABOVE MAP PKT=8") (FOR 2ND DES SEE 25807065) 15865917 РАМА, D/SEAT BK CUSH (INCLS 10, 12, 14-19) (14.896) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25807063) [КАРКАС СПИНКИ СИДЕНИЯ] 25807065 РАМА, D/SEAT BK CUSH (INCLS 10, 12, 14-19) (2ND DES W/ACTIVE H/RST, HT OF BK PNL INDENTATION ABOUVE MAP PKT=3") (FOR 1ST DES SEE 15865916) 11517068 NUT-METRIC HEX FLABGE, M6X1, 10MM SOCKET (D/SEAT) not found BRACKET, F/SEAT BK CUSH not found БОЛТ, F/SEAT LUMBAR SUPT (ЧАСТЬ OF 7) 20759565 МОДУЛЬ, D/SEAT SI INFL RST 11571066 ГАЙКА, PUSH-ON, FOR 9/32" (6.9MM) DIA STUDS, 18.4 OD, SAE 1050 STL, GMW30 (ЧАСТЬ OF 7) 11515764 БОЛТ, HFH, M10X1.5X20, 18THD, 22.3 O.D., 10.9, 7114M (F/SEAT) 15894212 BAR, F/SEAT BK CUSH FRM CR (ЧАСТЬ OF 7) not found RIVET, F/SEAT BK CUSH FRM CR) (ЧАСТЬ OF 7 not found SENSOR, D/SEAT RECL POSN (ЧАСТЬ OF 7) not found MOTOR, D/SEAT RECL ACTR (ЧАСТЬ OF 7) not found BRACKET, F/SEAT ADJR (ЧАСТЬ OF 7) 15865928 LUMBAR SUB, D/SEAT (ЧАСТЬ OF 7) (W/O ACTIVE H/RST-HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) 25939289 LUMBAR SUB, D/SEAT (ЧАСТЬ OF 7) (W/ACTIVE H/RST-HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) [ПОЯСНИЧНАЯ ОПОРА СПИНКИ СИДЕНЬЯ] 25939527 LUMBAR SUB, D/SEAT (ЧАСТЬ OF 7) (W/ACTIVE H/RST-HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) not found PAD, D/SEAT CUSH (СМ. ГРУППУ 14.000 "ПАССАЖИРСКОЕ СИДЕНЬЕ-ПОДУШКА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25780302 COVER, D/SEAT BK CUSH (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PNL PKT=8IN) (FOR 2ND DES SEE 25939463) 25780303 COVER, D/SEAT BK CUSH (EBONY) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939464) 25780316 COVER, D/SEAT BK CUSH (CASHMERE) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939332) 25780317 COVER, D/SEAT BK CUSH (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939333) 25780318 COVER, D/SEAT BK CUSH (EBONY) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939334) 25780361 COVER, D/SEAT BK CUSH (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939457) (6D14-077) - 2008 DM69 ПАССАЖИРСКОЕ СИДЕНЬЕ-ПОДУШКА (EXC POWER LUMBAR AL2, VENTED/HEATED KB6) ↓ 25780296 COVER, D/SEAT CUSH (TITANIUM) 25780297 COVER, D/SEAT CUSH (EBONY) 20755532 PAD, D/SEAT CUSH 20755532 PAD, D/SEAT CUSH 15947258 COVER, D/SEAT CUSH CLOSEOUT (INCLS 5) (TITANIUM) (11.573) 15947259 COVER, D/SEAT CUSH CLOSEOUT (INCLS 5) (EBONY) (11.573) not found PAD, D/SEAT BK CUSH (СМ. ГРУППУ 14.000 "ВОДИТЕЛЬСКОЕ СИДЕНЬЕ-СПИНКА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found CLIP, D/SEAT INR ADJR RR FIN (ЧАСТЬ OF 3) 25828643 БОЛТ, F/SEAT not found BRACKET, D/SEAT RECL HDL BZL 12451497 SWITCH, D/SEAT ADJR & RECL (8-WAY) [ВКЛЮЧАТЕЛЬ] 15947239 BEZEL, D/SEAT ADJR SW (INCLS 13) (TITANIUM) 15947246 BEZEL, D/SEAT ADJR SW (INCLS 13) (TITANIUM) 25994760 BEZEL, D/SEAT ADJR SW (INCLS 13) (EBONY) (W/O LUMBAR PREРОЛИК НАТЯЖИТЕЛЬ) 15952346 COVER, D/SEAT BELT OPG TR (RETR SI) (CASHMERE) 15952348 COVER, D/SEAT BELT OPG TR (RETR SI) (EBONY) 15952348 COVER, D/SEAT BELT OPG TR (RETR SI) (EBONY) 15889530 KNOB, D/SEAT RECL LVR (EBONY) (16.682) 25863075 KNOB, D/SEAT RECL LVR (TITANIUM) 15889524 KNOB, D/SEAT ADJR SW (EBONY) (16.682) 25863076 KNOB, D/SEAT ADJR SW (TITANIUM) not found CLIP, D/SEAT ADJR SW (ЧАСТЬ OF 9) 11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (D/SEAT) 11517068 NUT-METRIC HEX FLABGE, M6X1, 10MM SOCKET (D/SEAT) not found ГАЙКА, D/SEAT (ЧАСТЬ OF 40) 15894163 ACTUATOR, D/SEAT OTR ADJR RR VERT (ЧАСТЬ OF 40) 25780744 HARNESS, D/SEAT CONT MDL WRG 15947295 COVER, D/SEAT INR ADJR TRK RR FIN (INCLS 21) (EBONY) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ] 15947287 COVER, D/SEAT OTR ADJR TRK RR FIN (INCLS 21) (EBONY) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ] not found CLIP, D/SEAT (ЧАСТЬ OF 19, 20) not found TRACK, D/SEAT OTR ADJR (ЧАСТЬ OF 40) 15947303 COVER, D/SEAT OTR ADJR TRK FRT FIN (EBONY) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ] 15947311 COVER, D/SEAT INR ADJR TRK FRT FIN (EBONY) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ] not found TRACK, D/SEAT INR ADJR (ЧАСТЬ OF 40) 15817518 SENSOR, INFL RST FRT PASS POSITION (ЧАСТЬ OF 40) [ДАТЧИК ПОДУШКИ БЕЗОПАСНОСТИ] not found ГАЙКА, D/SEAT (ЧАСТЬ OF 40) not found BRACE, D/SEAT (ЧАСТЬ OF 40) not found BRAKET, D/SEAT (ЧАСТЬ OF 40) not found ACTUATOR, D/SEAT ADJR (ЧАСТЬ OF 31, 40) 15894137 MOTOR, D/SEAT ADJR ACTR (INCLS 30) (ЧАСТЬ OF 40) (W/O SEAT ADJR MEMORY MDL) 15894138 MOTOR, D/SEAT ADJR ACTR (INCLS 30) (ЧАСТЬ OF 40) (W/SEAT ADJR MEMORY MDL) 15894172 ACTUATOR, F/SEAT TILT ADJR (ЧАСТЬ OF 40) 15947192 COVER, D/SEAT OTR ADJR FRT FIN (TITANIUM) 15947193 COVER, D/SEAT OTR ADJR FRT FIN (EBONY) not found CLIP, D/SEAT (ЧАСТЬ OF 33) not found ГАЙКА, D/SEAT BELT (BKL SI) (ЧАСТЬ OF 38) 15947250 COVER, D/SEAT INR RECL FIN (INCLS 37) (TITANIUM) 15947251 COVER, D/SEAT INR RECL FIN (INCLS 37) (EBONY) not found CLIP, D/SEAT (ЧАСТЬ OF 36) 19181818 BELT KIT, D/SEAT (BKL SI) (INCLS 35) (TITANIUM) 19181819 BELT KIT, D/SEAT (BKL SI) (INCLS 35) (EBONY) teamcadillac.ru 89024400 BELT KIT, D/SEAT (BKL SI) (INCLS 35) (GRAY) not found WIRE, D/SEAT CUSH PAD (ЧАСТЬ OF 40) 25922429 РАМА, D/SEAT CUSH (INCLS 16, 17, 22, 25-32, 39) (6D14-078) - 2008 DM69 ВОДИТЕЛЬСКОЕ СИДЕНЬЕ-СПИНКА (EXC POWER LUMBAR AL2, VENTED/HEATED KB6)(1ST DES) ↓ 25777056 PAD, D/SEAT BK CUSH (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939292) 25777056 PAD, D/SEAT BK CUSH (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939292) 25780652 RESTRAINT, D/SEAT HD (INCLS 3) (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939468) [ОГРАНИЧИТЕЛЬ] 25780653 RESTRAINT, D/SEAT HD (INCLS 3) (EBONY) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939469) 25780655 RESTRAINT, D/SEAT HD (INCLS 3) (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939472) 25780656 RESTRAINT, D/SEAT HD (INCLS 3) (EBONY) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25984306) 25939467 RESTRAINT, D/SEAT HD (INCLS 3) (CASHMERE) not found COVER, F/SEAT H/RST CUSH (ЧАСТЬ OF 2) 15947278 PANEL, D/SEAT BK CUSH FIN (INCLS 6) (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939328) 15947279 PANEL, D/SEAT BK CUSH FIN (INCLS 6) (EBONY) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939329) 25939323 PANEL, D/SEAT BK CUSH FIN (MAY ALSO NEED TO REPL PASS SIDE) (INCLS 6) (CASHMERE) 25939324 PANEL, D/SEAT BK CUSH FIN (MAY ALSO NEED TO REPL PASS SIDE) (INCLS 6) (TITANIUM) 25939325 PANEL, D/SEAT BK CUSH FIN (MAY ALSO NEED TO REPL PASS SIDE) (INCLS 6) (EBONY) 25785786 GUIDE, D/SEAT H/RST (CASHMERE) (W/BUTTON) 25785787 GUIDE, D/SEAT H/RST (TITANIUM) (W/BUTTON) 25785788 GUIDE, D/SEAT H/RST (EBONY) (W/BUTTON) 25785789 GUIDE, D/SEAT H/RST (CASHMERE) (W/O BUTTON) 25785790 GUIDE, D/SEAT H/RST (TITANIUM) (W/O BUTTON) 25785791 GUIDE, D/SEAT H/RST (EBONY) (W/O BUTTON) 25908135 GUIDE, D/SEAT H/RST (TITANIUM) (W/BUTTON) 25908165 GUIDE, D/SEAT H/RST (TITANIUM) (W/O BUTTON) 11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (ЧАСТЬ OF 4) [ЗАЖИМ КОНСОЛИ САЛОНА] 15865916 РАМА, D/SEAT BK CUSH (INCLS 10, 12, 14-19) (W/LUMBAR) (1ST DES W/O ACTIVE H/RST, HT OF BK PNL INDENTATION ABOVE MAP PKT=8") (FOR 2ND DES SEE 25807065) 25807065 РАМА, D/SEAT BK CUSH (INCLS 10, 12, 14-19) (2ND DES W/ACTIVE H/RST, HT OF BK PNL INDENTATION ABOUVE MAP PKT=3") (FOR 1ST DES SEE 15865916) 11517068 NUT-METRIC HEX FLABGE, M6X1, 10MM SOCKET (D/SEAT) not found BRACKET, F/SEAT BK CUSH not found БОЛТ, F/SEAT LUMBAR SUPT (ЧАСТЬ OF 7) 20759565 МОДУЛЬ, D/SEAT SI INFL RST 11571066 ГАЙКА, PUSH-ON, FOR 9/32" (6.9MM) DIA STUDS, 18.4 OD, SAE 1050 STL, GMW30 (ЧАСТЬ OF 7) 11515764 БОЛТ, HFH, M10X1.5X20, 18THD, 22.3 O.D., 10.9, 7114M (F/SEAT) 15894212 BAR, F/SEAT BK CUSH FRM CR (ЧАСТЬ OF 7) not found RIVET, F/SEAT BK CUSH FRM CR) (ЧАСТЬ OF 7) not found SENSOR, D/SEAT RECL POSN (ЧАСТЬ OF 7) 15894213 ACTUATOR, D/SEAT RECL (ЧАСТЬ OF 7) not found BRACKET, F/SEAT ADJR (ЧАСТЬ OF 7) 15865928 LUMBAR SUB, D/SEAT (ЧАСТЬ OF 7) (W/O ACTIVE H/RST-HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) 25939289 LUMBAR SUB, D/SEAT (ЧАСТЬ OF 7) (W/ACTIVE H/RST-HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) [ПОЯСНИЧНАЯ ОПОРА СПИНКИ СИДЕНЬЯ] 25939527 LUMBAR SUB, D/SEAT (ЧАСТЬ OF 7) (W/ACTIVE H/RST-HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) not found PAD, D/SEAT CUSH (СМ. ГРУППУ 14.000 "ПАССАЖИРСКОЕ СИДЕНЬЕ-ПОДУШКА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) teamcadillac.ru 25780302 COVER, D/SEAT BK CUSH (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PNL PKT=8IN) (FOR 2ND DES SEE 25939463) 25780303 COVER, D/SEAT BK CUSH (EBONY) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939464) 25780316 COVER, D/SEAT BK CUSH (CASHMERE) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939332) 25780317 COVER, D/SEAT BK CUSH (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939333) 25780318 COVER, D/SEAT BK CUSH (EBONY) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939334) 25780361 COVER, D/SEAT BK CUSH (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939457) (6D14-079) - 2008 DM69 СИДЕНЬЕ ПАССАЖИРА-BACK (POWER ADJUSTER AH8, ИСКЛЮЧАЯ ВЕНТИЛЯЦИЮ И ОБОГРЕВ KB6) ↓ 25777060 PAD, P/SEAT BK CUSH (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939271) 25939271 PAD, P/SEAT BK CUSH (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25777060) 25780305 COVER, P/SEAT BK CUSH (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939519) 25780306 COVER, P/SEAT BK CUSH (EBONY) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939520) 25780320 COVER, P/SEAT BK CUSH (CASHMERE) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939506) 25780322 COVER, P/SEAT BK CUSH (EBONY) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939508) 25780365 COVER, P/SEAT BK CUSH (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939512) 25939506 COVER, P/SEAT BK CUSH (CASHMERE) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780320) 25939507 COVER, P/SEAT BK CUSH (TITANIUM) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780321) 25939508 COVER, P/SEAT BK CUSH (EBONY) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780322) 25939512 COVER, P/SEAT BK CUSH (TITANIUM) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780365) 25939519 COVER, P/SEAT BK CUSH (TITANIUM) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780305) 25939520 COVER, P/SEAT BK CUSH (EBONY) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780306) 15865926 LUMBAR SUB, P/SEAT (ЧАСТЬ OF 16) (W/O ACTIVE H/RST-HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) 15865927 LUMBAR SUB, P/SEAT (ЧАСТЬ OF 16) (W/O ACTIVE H/RST-HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) teamcadillac.ru 25939270 LUMBAR SUB, P/SEAT (ЧАСТЬ OF 16) (W/ACTIVE H/RST-HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) 25939527 LUMBAR SUB, P/SEAT (ЧАСТЬ OF 16) (W/ACTIVE H/RST-HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) not found BRACKET, F/SEAT ADJR (ЧАСТЬ OF 16) not found ACTUATOR, P/SEAT RECL (ЧАСТЬ OF 16) 15894213 ACTUATOR, P/SEAT RECL (ЧАСТЬ OF 16) not found PAD, P/SEAT CUSH (СМ. ГРУППУ 14.000 "СИДЕНЬЕ ПАССАЖИРА-CUSHION" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11571066 ГАЙКА, PUSH-ON, FOR 9/32" (6.9MM) DIA STUDS, 18.4 OD, SAE 1050 STL, GMW30 (ЧАСТЬ OF 16) 25828643 БОЛТ, F/SEAT (ЧАСТЬ OF 16) 15894212 BAR, F/SEAT BK CUSH FRM CR (ЧАСТЬ OF 16) 25898670 МОДУЛЬ, P/SEAT SI INFL RST not found RIVET, F/SEAT BK CUSH FRM CR) (ЧАСТЬ OF 16) not found БОЛТ, F/SEAT LUMBAR SUPT (ЧАСТЬ OF 16) 11517068 NUT-METRIC HEX FLABGE, M6X1, 10MM SOCKET (P/SEAT) not found BRACKET, INFL RST P/SEAT SI MDL 11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (ЧАСТЬ OF 18) [ЗАЖИМ КОНСОЛИ САЛОНА] 15865921 РАМА, P/SEAT BK CUSH (INCLS 3-5, 7-9, 11, 12) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP=8IN) (FOR 2ND DES SEE 25807066) 15865924 РАМА, P/SEAT BK CUSH (INCLS 3-5, 7-9, 11, 12) (W/O ACTIVE HEAD RESTRAINT) (FOR 2ND DES SEE 25807067) 25807066 РАМА, P/SEAT BK CUSH (INCLS 3-5, 7-9, 11, 12) (14.896) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 15865921) 25807067 РАМА, P/SEAT BK CUSH (INCLS 3-5, 7-9, 11, 12) (14.896) (W/ACTIVE HEAD RESTRAINT) (FOR 1ST DES SEE 15865924) 25785786 GUIDE, P/SEAT H/RST (CASHMERE) (W/BUTTON) 25785787 GUIDE, P/SEAT H/RST (TITANIUM) (W/BUTTON) 25785788 GUIDE, P/SEAT H/RST (EBONY) (W/BUTTON) 25785789 GUIDE, P/SEAT H/RST (CASHMERE) (W/O BUTTON) 25785790 GUIDE, P/SEAT H/RST (TITANIUM) (W/O BUTTON) 25785791 GUIDE, P/SEAT H/RST (EBONY) (W/O BUTTON) 25908135 GUIDE, P/SEAT H/RST (TITANIUM) (W/BUTTON) 25908165 GUIDE, P/SEAT H/RST (TITANIUM) (W/O BUTTON) 15947283 PANEL, P/SEAT BK CUSH FIN (MAY ALSO NEED TO REPL DRIVER SIDE) (INCLS 15) (EBONY) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939494) 25939487 PANEL, P/SEAT BK CUSH FIN (INCLS 15) (CASHMERE) 25939488 PANEL, P/SEAT BK CUSH FIN (INCLS 15) (TITANIUM) 25939489 PANEL, P/SEAT BK CUSH FIN (INCLS 15) (EBONY) (MAY ALSO NEED TO REPL DRIVER SIDE) 25939493 PANEL, P/SEAT BK CUSH FIN (INCLS 15) (TITANIUM) 25939494 PANEL, P/SEAT BK CUSH FIN (INCLS 15) (EBONY) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 15947283) 25780652 RESTRAINT, P/SEAT HD (INCLS 20) (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939468) [ОГРАНИЧИТЕЛЬ] 25780653 RESTRAINT, P/SEAT HD (INCLS 20) (EBONY) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939469) 25780655 RESTRAINT, P/SEAT HD (INCLS 20) (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939472) 25780656 RESTRAINT, P/SEAT HD (INCLS 20) (EBONY) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25984306) 25939467 RESTRAINT, P/SEAT HD (INCLS 20) (CASHMERE) 25939468 RESTRAINT, P/SEAT HD (INCLS 20) (TITANIUM) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780652) 25939469 RESTRAINT, P/SEAT HD (INCLS 20) (EBONY) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780653) 25939472 RESTRAINT, P/SEAT HD (INCLS 20) (TITANIUM) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780655) 25984306 RESTRAINT, P/SEAT HD (INCLS 20) (EBONY) (WHEN USED TO SERV 2008, REPL BOTH DRIVER & PASSENGER RST) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780656) not found COVER, F/SEAT H/RST CUSH (ЧАСТЬ OF 19) (6D14-080) - 2008 DM69 СИДЕНЬЕ ПАССАЖИРА-CUSHION (EXC POWER ADJUSTER AH8, VENTED/HEATED KB6) ↓ 25780299 COVER, P/SEAT CUSH (TITANIUM) 25780300 COVER, P/SEAT CUSH (EBONY) not found PAD, P/SEAT CUSH (*KIT1) not found МОДУЛЬ, INFL RST P/SEAT SUPPRESSION (*KIT1) 19181814 BELT KIT, P/SEAT (BKL SI) (INCLS 7) (TITANIUM) 19181815 BELT KIT, P/SEAT (BKL SI) (INCLS 7) (EBONY) not found CLIP, P/SEAT RECL LWR FIN (ЧАСТЬ OF 6) 15947254 COVER, P/SEAT RECL LWR FIN (INCLS 5) (TITANIUM) 15947255 COVER, P/SEAT RECL LWR FIN (INCLS 5) (EBONY) not found ГАЙКА, P/SEAT BELT (ЧАСТЬ OF 4) not found ГАЙКА, P/SEAT (ЧАСТЬ OF 37) not found CLIP, P/SEAT ADJR FIN (ЧАСТЬ OF 10) 15947235 COVER, P/SEAT ADJR FIN (INCLS 9) (TITANIUM) 15947236 COVER, P/SEAT ADJR FIN (INCLS 9) (EBONY) not found BRACKET, INFL RST P/SEAT SUPPRESSION not found TRACK, P/SEAT INR ADJR (ЧАСТЬ OF 37) not found HANDLE, P/SEAT ADJR (ЧАСТЬ OF 37) 15947315 COVER, P/SEAT INR ADJR TRK FRT FIN (EBONY) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ] 15947307 COVER, P/SEAT OTR ADJR TRK FRT FIN (EBONY) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ] not found TRACK, P/SEAT OTR ADJR (ЧАСТЬ OF 37) not found BRACKET, HARNESS 25780747 HARNESS, P/SEAT CONT MDL WRG (W/O ACTIVE H/RST;HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DESIGN SEE 25939265) 25780749 HARNESS, P/SEAT CONT MDL WRG 25904923 HARNESS, P/SEAT CONT MDL WRG (W/O ACTIVE H/RST;HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DESIGN SEE 25939265) 25939264 HARNESS, P/SEAT CONT MDL WRG (W/ ACTIVE H/RST;HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DSG SEE 25904923) 25939265 HARNESS, P/SEAT CONT MDL WRG (W/ ACTIVE H/RST;HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DSG SEE 25780747) 15817518 SENSOR, INFL RST FRT PASS POSITION (ЧАСТЬ OF 37) [ДАТЧИК ПОДУШКИ БЕЗОПАСНОСТИ] not found BRACE, P/SEAT (ЧАСТЬ OF 37) not found CLIP, P/SEAT (ЧАСТЬ OF 22, 23) 15947291 COVER, P/SEAT OTR ADJR TRK RR FIN (INCLS 21) (EBONY) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ] 15947299 COVER, P/SEAT INR ADJR TRK RR FIN (INCLS 21) (EBONY) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ] 11517068 NUT-METRIC HEX FLABGE, M6X1, 10MM SOCKET (P/SEAT) 11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (D/SEAT) not found CLIP, P/SEAT ADJR SW (ЧАСТЬ OF 30) 15947265 HANDLE, P/SEAT RECL (INCLS 28) (TITANIUM) 15947266 HANDLE, P/SEAT RECL (INCLS 28) (EBONY) not found ПРУЖИНА, P/SEAT RECL HDL (ЧАСТЬ OF 27) 15952350 COVER, P/SEAT BELT OPG TR (RETR SI) (CASHMERE) 15952351 COVER, P/SEAT BELT OPG TR (RETR SI) (TITANIUM) 15952352 COVER, P/SEAT BELT OPG TR (RETR SI) (EBONY) 15947243 BEZEL, P/SEAT ADJR SW (INCLS 26) (TITANIUM) 25994756 BEZEL, P/SEAT ADJR SW (INCLS 26) (EBONY) 25994763 BEZEL, P/SEAT ADJR SW (INCLS 26) (EBONY) 25780741 BRACKET, P/SEAT RECL HDL BZL teamcadillac.ru 25807305 ROD, P/SEAT ADJR LAT 25807304 BUSHING, P/SEAT ADJR HDL 25807307 ПРУЖИНА, P/SEAT ADJR HDL 25828643 БОЛТ, F/SEAT not found CLIP, P/SEAT ADJR FIN (ЧАСТЬ OF 38) 25922431 РАМА, P/SEAT CUSH (INCLS 8, 12, 13, 16, 19, 20, 39) 15947258 COVER, P/SEAT CUSH CLOSEOUT (INCLS 36) (TITANIUM) (11.573) 15947259 COVER, P/SEAT CUSH CLOSEOUT (INCLS 36) (EBONY) (11.573) not found WIRE, P/SEAT CUSH PAD (ЧАСТЬ OF 37) not found COVER, P/SEAT BK CUSH (СМ. ГРУППУ 14.000 "СИДЕНЬЕ ПАССАЖИРА-BACK" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6D14-081) - 2008 DM69 СИДЕНЬЕ ПАССАЖИРА-BACK (EXC POWER ADJUSTER AH8, VENTED/HEATED KB6) ↓ 25777060 PAD, P/SEAT BK CUSH (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939271) 25939271 PAD, P/SEAT BK CUSH (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25777060) teamcadillac.ru 25780305 COVER, P/SEAT BK CUSH (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939519) 25780306 COVER, P/SEAT BK CUSH (EBONY) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939520) 25780320 COVER, P/SEAT BK CUSH (CASHMERE) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939506) 25780322 COVER, P/SEAT BK CUSH (EBONY) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939508) 25780365 COVER, P/SEAT BK CUSH (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939512) 25939506 COVER, P/SEAT BK CUSH (CASHMERE) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780320) 25939507 COVER, P/SEAT BK CUSH (TITANIUM) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780321) 25939508 COVER, P/SEAT BK CUSH (EBONY) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780322) 25939512 COVER, P/SEAT BK CUSH (TITANIUM) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780365) 25939519 COVER, P/SEAT BK CUSH (TITANIUM) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780305) 25939520 COVER, P/SEAT BK CUSH (EBONY) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780306) 15865926 LUMBAR SUB, P/SEAT (ЧАСТЬ OF 13) (W/O ACTIVE H/RST-HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) 15865927 LUMBAR SUB, P/SEAT (ЧАСТЬ OF 13) (W/O ACTIVE H/RST-HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) 25939270 LUMBAR SUB, P/SEAT (ЧАСТЬ OF 13) (W/ACTIVE H/RST-HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) 25939527 LUMBAR SUB, P/SEAT (ЧАСТЬ OF 13) (W/ACTIVE H/RST-HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) not found ПРУЖИНА, P/SEAT BK CUSH) (ЧАСТЬ OF 13) not found PAD, P/SEAT CUSH (СМ. ГРУППУ 14.000 "СИДЕНЬЕ ПАССАЖИРА-CUSHION" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11515764 БОЛТ, HFH, M10X1.5X20, 18THD, 22.3 O.D., 10.9, 7114M (F/SEAT) 25807304 BUSHING, P/SEAT ADJR HDL (ЧАСТЬ OF 13) not found BRACKET, F/SEAT BK CUSH not found БОЛТ, F/SEAT LUMBAR SUPT (ЧАСТЬ OF 13) 25898670 МОДУЛЬ, P/SEAT SI INFL RST 11517068 NUT-METRIC HEX FLABGE, M6X1, 10MM SOCKET (P/SEAT) 11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (ЧАСТЬ OF 16) [ЗАЖИМ КОНСОЛИ САЛОНА] 15865924 РАМА, P/SEAT BK CUSH (INCLS 3, 4, 7, 9) (W/O ACTIVE HEAD RESTRAINT) (FOR 2ND DES SEE 25807067) 25807067 РАМА, P/SEAT BK CUSH (INCLS 3, 4, 7, 9) (14.896) (W/ACTIVE HEAD RESTRAINT) (FOR 1ST DES SEE 15865924) 25780652 RESTRAINT, P/SEAT HD (INCLS 17) (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939468) [ОГРАНИЧИТЕЛЬ] 25780653 RESTRAINT, P/SEAT HD (INCLS 17) (EBONY) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939469) 25780655 RESTRAINT, P/SEAT HD (INCLS 17) (TITANIUM) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939472) 25780656 RESTRAINT, P/SEAT HD (INCLS 17) (EBONY) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25984306) 25939467 RESTRAINT, P/SEAT HD (INCLS 17) (CASHMERE) 25939468 RESTRAINT, P/SEAT HD (INCLS 17) (TITANIUM) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780652) 25939469 RESTRAINT, P/SEAT HD (INCLS 17) (EBONY) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780653) 25939472 RESTRAINT, P/SEAT HD (INCLS 17) (TITANIUM) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780655) 25984306 RESTRAINT, P/SEAT HD (INCLS 17) (EBONY) (WHEN USED TO SERV 2008, REPL BOTH DRIVER & PASSENGER RST) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780656) 25785786 GUIDE, P/SEAT H/RST (CASHMERE) (W/BUTTON) 25785787 GUIDE, P/SEAT H/RST (TITANIUM) (W/BUTTON) 25785788 GUIDE, P/SEAT H/RST (EBONY) (W/BUTTON) 25785789 GUIDE, P/SEAT H/RST (CASHMERE) (W/O BUTTON) 25785790 GUIDE, P/SEAT H/RST (TITANIUM) (W/O BUTTON) 25785791 GUIDE, P/SEAT H/RST (EBONY) (W/O BUTTON) 25908135 GUIDE, P/SEAT H/RST (TITANIUM) (W/BUTTON) 25908165 GUIDE, P/SEAT H/RST (TITANIUM) (W/O BUTTON) 15947283 PANEL, P/SEAT BK CUSH FIN (MAY ALSO NEED TO REPL DRIVER SIDE) (INCLS 12) (EBONY) (W/O ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) (FOR 2ND DES SEE 25939494) 25939487 PANEL, P/SEAT BK CUSH FIN (INCLS 12) (CASHMERE) 25939488 PANEL, P/SEAT BK CUSH FIN (INCLS 12) (TITANIUM) 25939489 PANEL, P/SEAT BK CUSH FIN (INCLS 12) (EBONY) (MAY ALSO NEED TO REPL DRIVER SIDE) 25939493 PANEL, P/SEAT BK CUSH FIN (INCLS 12) (TITANIUM) 25939494 PANEL, P/SEAT BK CUSH FIN (INCLS 12) (EBONY) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 15947283) not found COVER, F/SEAT H/RST CUSH (ЧАСТЬ OF 14) (6D14-082) - 2008 DM69 РЕМНИ БЕЗОПАСНОСТИ-ПЕРЕДНИЕ ↓ 25848025 ADJUSTER, D/SEAT SHLDR BELT GDE (ЧАСТЬ OF 13) (INCLS 3) 25848025 ADJUSTER, P/SEAT SHLDR BELT GDE (ЧАСТЬ OF 13) (INCLS 3) not found BRACKET, D/SEAT & P/SEAT SHLDR BELT GDE CONT MDL (ЧАСТЬ OF 13) 11570986 БОЛТ, D/SEAT SHLDR BELT GDE (ЧАСТЬ OF 1, 13) (M10X1.5X30) (8.977) not found БОЛТ, D/SEAT BELT RETR (ЧАСТЬ OF 6) 11561897 БОЛТ, D/SEAT BELT RETR (ЧАСТЬ OF 6) (7/16-20X25 23.5 OD) (16.714) 11561897 БОЛТ, P/SEAT BELT RETR (ЧАСТЬ OF 6) (7/16-20X25 23.5 OD) (16.714) 21077123 RETAINER, D/SEAT BELT (PUSH ON) (PIN-TYPE) (2.483) 21077123 RETAINER, P/SEAT BELT (PUSH ON) (PIN-TYPE) (2.483) not found BELT KIT, D/SEAT (RETR SI) (INCLS 4, 7) 19207182 BELT KIT, P/SEAT (RETR SI) (INCLS 4, 7) (EBONY) 19207183 BELT KIT, P/SEAT (RETR SI) (INCLS 4, 7) (TITANIUM) 19207184 BELT KIT, P/SEAT (RETR SI) (INCLS 4, 7) (CASHMERE) 19207185 BELT KIT, D/SEAT (RETR SI) (INCLS 4, 7) (EBONY) 19207186 BELT KIT, D/SEAT (RETR SI) (INCLS 4, 7) (TITANIUM) 19207187 BELT KIT, D/SEAT (RETR SI) (INCLS 4, 7) (CASHMERE) 25878122 BELT, P/SEAT (RETR SI) (W/ TENSR) (INCLS 4, 7) (EBONY) 25878123 BELT, P/SEAT (RETR SI) (W/ TENSR) (INCLS 4, 7) (TITANIUM) 25878127 BELT, D/SEAT (RETR SI) (W/ TENSR) (INCLS 4, 7) (TITANIUM) 25878128 BELT, D/SEAT (RETR SI) (W/ TENSR) (INCLS 4, 7) (CASHMERE) 25906395 BELT, P/SEAT (RETR SI) (W/ TENSR) (INCLS 4, 7) (CASHMERE) 25906420 BELT, D/SEAT (RETR SI) (W/ TENSR) (INCLS 4, 7) (EBONY) 88952534 BELT KIT, P/SEAT (RETR SI) (INCLS 4, 7) (GRAY) 89026024 BELT KIT, P/SEAT (RETR SI) (INCLS 4, 7) (CASHMERE) not found БОЛТ, D/SEAT BELT RETR (ЧАСТЬ OF 6) not found БОЛТ, P/SEAT BELT RETR (ЧАСТЬ OF 6) 15952346 COVER, D/SEAT BELT OPG TR (RETR SI) (СМ. ГРУППУ 14.000 "ПАССАЖИРСКОЕ СИДЕНЬЕ-ПОДУШКА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (CASHMERE) 15952348 COVER, D/SEAT BELT OPG TR (RETR SI) (СМ. ГРУППУ 14.000 "ПАССАЖИРСКОЕ СИДЕНЬЕ-ПОДУШКА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (EBONY) 15952348 COVER, D/SEAT BELT OPG TR (RETR SI) (СМ. ГРУППУ 14.000 "ПАССАЖИРСКОЕ СИДЕНЬЕ-ПОДУШКА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (EBONY) 15952350 COVER, P/SEAT BELT OPG TR (RETR SI) (СМ. ГРУППУ 14.000 "СИДЕНЬЕ ПАССАЖИРА-CUSHION" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (CASHMERE) 15952351 COVER, P/SEAT BELT OPG TR (RETR SI) (СМ. ГРУППУ 14.000 "СИДЕНЬЕ ПАССАЖИРА-CUSHION" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (TITANIUM) 15952352 COVER, P/SEAT BELT OPG TR (RETR SI) (СМ. ГРУППУ 14.000 "СИДЕНЬЕ ПАССАЖИРА-CUSHION" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (EBONY) 11517996 ГАЙКА, D/SEAT BELT (RETR SI) (M10X1.5, 11.2 THK) (8.917) [ГАЙКА М10] 11517996 ГАЙКА, P/SEAT BELT (RETR SI) (M10X1.5, 11.2 THK) (8.917) [ГАЙКА М10] not found ГАЙКА, D/SEAT (BKL SI) (ЧАСТЬ OF 11) not found ГАЙКА, P/SEAT (BKL SI) (ЧАСТЬ OF 11) 19181814 BELT KIT, P/SEAT (BKL SI) (INCLS 10) (TITANIUM) 19181815 BELT KIT, P/SEAT (BKL SI) (INCLS 10) (EBONY) 19181816 BELT KIT, P/SEAT (BKL SI) (INCLS 10) (CASHMERE) 19181818 BELT KIT, D/SEAT (BKL SI) (INCLS 10) (TITANIUM) 19181818 BELT KIT, D/SEAT (BKL SI) (INCLS 10) (TITANIUM) 19181819 BELT KIT, D/SEAT (BKL SI) (INCLS 10) (EBONY) 19181820 BELT KIT, D/SEAT (BKL SI) (INCLS 10) (CASHMERE) 89024400 BELT KIT, D/SEAT (BKL SI) (INCLS 10) (GRAY) 25862282 PANEL, C/PLR UPR TR (СМ. ГРУППУ 14.000 "ОТДЕЛКА/CENTER ПАНЕЛЬ ЗАДНЕЙ СТОЙКИ КУЗОВА & QUARTER" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (CASHMERE) 25908299 PANEL, C/PLR UPR TR (СМ. ГРУППУ 14.000 "ОТДЕЛКА/CENTER ПАНЕЛЬ ЗАДНЕЙ СТОЙКИ КУЗОВА & QUARTER" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (TITANIUM) [ВНУТРЕННЯЯ ПАНЕЛЬ СТОЙКИ КУЗОВА] 25916792 ADJUSTER, P/SEAT SHLDR BELT GDE (INCLS 1-3) (BLACK) teamcadillac.ru 25916794 ADJUSTER, D/SEAT SHLDR BELT GDE (INCLS 1-3) (BLACK) 12475408 STOP KIT, BELT LAT (RETR SI) (GRAY) (16.714) 19121443 STOP KIT, BELT LAT (RETR SI) (TITANIUM) 19121445 STOP KIT, BELT LAT (RETR SI) (CASHMERE) 19121446 STOP KIT, BELT LAT (RETR SI) (EBONY) 19121446 STOP KIT, BELT LAT (RETR SI) (EBONY) (6D14-083) - 2008 DM69 ЗАДНИЕ РЕМНИ БЕЗОПАСНОСТИ ↓ 25767579 BRACKET, CHILD ST TOP STRP (INCLS 10) 11609257 БОЛТ, R/SEAT BELT (RETR SI) (M12X1.75X34) (8.907) [БОЛТ] 19207194 BELT KIT, R/SEAT (RETR SI) (INCLS 11) (EBONY) 19207195 BELT KIT, R/SEAT (RETR SI) (INCLS 11) (TITANIUM) 19207196 BELT KIT, R/SEAT (RETR SI) (INCLS 11) (CASHMERE) 25843971 BELT, R/SEAT (RETR SI) (INCLS 11) (EBONY) 25843972 BELT, R/SEAT (RETR SI) (INCLS 11) (TITANIUM) 25843973 BELT, R/SEAT (RETR SI) (INCLS 11) (CASHMERE) 11588357 ГАЙКА, R/SEAT BELT (BKL SI) (M12X1.75, 13.5 THK) [ВИНТ В СБОРЕ] 19168909 BELT KIT, R/SEAT CTR (BKL SI) (EBONY) (BKL/BKL) 19168910 BELT KIT, R/SEAT CTR (BKL SI) (TITANIUM) (BKL/BKL) 19168911 BELT KIT, R/SEAT CTR (BKL SI) (CASHMERE) (BKL/BKL) 19207188 BELT KIT, R/SEAT CTR (BKL SI) (EBONY) (BKL/BKL) 19207189 BELT KIT, R/SEAT CTR (BKL SI) (TITANIUM) (BKL/BKL) 19207190 BELT KIT, R/SEAT CTR (BKL SI) (CASHMERE) (BKL/BKL) 19168912 BELT KIT, R/SEAT CTR (BKL SI) (EBONY) (SINGLE BKL) 19168913 BELT KIT, R/SEAT CTR (BKL SI) (TITANIUM) (SINGLE BKL) [РЕМЕНЬ БЕЗОПАСНОСТИ] teamcadillac.ru 19168914 BELT KIT, R/SEAT CTR (BKL SI) (CASHMERE) (SINGLE BKL) 19207191 BELT KIT, R/SEAT CTR (BKL SI) (EBONY) (SINGLE BKL) 19207192 BELT KIT, R/SEAT CTR (BKL SI) (TITANIUM) (SINGLE BKL) 19207193 BELT KIT, R/SEAT CTR (BKL SI) (CASHMERE) (SINGLE BKL) 19179233 BELT KIT, R/SEAT CTR (RETR SI) (INCLS 11) (EBONY) 19179234 BELT KIT, R/SEAT CTR (RETR SI) (INCLS 11) (CASHMERE) 19179235 BELT KIT, R/SEAT CTR (RETR SI) (INCLS 11) (TITANIUM) 25878894 BELT, R/SEAT CTR (RETR SI) (INCLS 11) (EBONY) 25878895 BELT, R/SEAT CTR (RETR SI) (INCLS 11) (CASHMERE) 25878896 BELT, R/SEAT CTR (RETR SI) (INCLS 11) (TITANIUM) 19207197 BELT KIT, R/SEAT (RETR SI) (INCLS 11) (EBONY) 19207198 BELT KIT, R/SEAT (RETR SI) (INCLS 11) (TITANIUM) 19207199 BELT KIT, R/SEAT (RETR SI) (INCLS 11) (CASHMERE) 25843975 BELT, R/SEAT (RETR SI) (INCLS 11) (EBONY) 25843976 BELT, R/SEAT (RETR SI) (INCLS 11) (TITANIUM) 25843977 BELT, R/SEAT (RETR SI) (INCLS 11) (CASHMERE) 11609257 БОЛТ, R/SEAT CTR BELT (RETR SI) (CTR RETR РАМА ATTACHMENT) (M12X1.75X34) (8.907) [БОЛТ] 15548771 БОЛТ, CHILD ST TOP STRP BRKT (ЧАСТЬ OF 1) (M10X1.5X25) (8.913) 12475408 STOP KIT, BELT LAT (RETR SI) (ЧАСТЬ OF 3, 7, 8) (GRAY) (16.714) 19121443 STOP KIT, BELT LAT (RETR SI) (ЧАСТЬ OF 3, 7, 8) (TITANIUM) 19121445 STOP KIT, BELT LAT (RETR SI) (ЧАСТЬ OF 3, 7, 8) (CASHMERE) 19121445 STOP KIT, BELT LAT (RETR SI) (ЧАСТЬ OF 3, 7, 8) (CASHMERE) 19121446 STOP KIT, BELT LAT (RETR SI) (ЧАСТЬ OF 3, 7, 8) (EBONY) 19121446 STOP KIT, BELT LAT (RETR SI) (ЧАСТЬ OF 3, 7, 8) (EBONY) (6D14-086) - 2008 DM69 ОБЛИЦОВКА ПЕРЕДНЕЙ ВОДИТЕЛЬСКОЙ ДВЕРИ (MEMORY A45, EXC ЛАМПА PACKAGE TSQ) ↓ 11570654 ГАЙКА, FRT S/D TR (4.2 X 1.41) (FITS 8.75 SQ HOLE) (9.665) 11519032 RETAINER, PUSH IN, 19.5X28.4X1.8, FITS HOLE 9.1, ACETAL, BLK (ЧАСТЬ OF 16) [ФИКСАТОР ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ] not found БОЛТ - HEX WASHER HEAD, M7X1.0X20.0, GM6202M STL, GMW3200 (ЧАСТЬ OF 16) 11503417 ГАЙКА, M6.3 STMPD TYPE SR ZC (ЧАСТЬ OF 16) not found APPLIQUE, FRT S/D T/PNL (ЧАСТЬ OF 16) 15243588 APPLIQUE, FRT S/D T/PNL (ЧАСТЬ OF 16) (SAPELE) (USE W/NUT 11503417 QTY 7 FOR 08;QTY 4 FOR 09 AND LATER) not found BEZEL, FRT S/D I/S HDL (ЧАСТЬ OF 16) 11609539 SCREW, RD CROWNED WA HD, M4.2X1.41X16, STL ISO 2702, GMW4205 (FRT S/D TR) [ВИНТ] 15871923 COVER, FRT S/D PULL HDL (EBONY) [КРЫШКА] 15871925 COVER, FRT S/D PULL HDL (TITANIUM) [КРЫШКА] 15871927 COVER, FRT S/D PULL HDL (CASHMERE) [КРЫШКА] 25796933 SWITCH, R/CMPT LID REL (ЧАСТЬ OF 16) (ACDelco #D1417G) [ВЫКЛ ЮЧАТЕЛЬ] 03539184 БОЛТ, FRT S/D PULL HDL (ATTACH TO NUT IN SHT MTL) (14.683) 25927093 CAP, FRT S/D PULL HDL БОЛТ (EBONY) [НАКЛАДКА ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ] 25927095 CAP, FRT S/D PULL HDL БОЛТ (TITANIUM) [КРЫШКА] 25927097 CAP, FRT S/D PULL HDL БОЛТ (CASHMERE) [НАКЛАДКА ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ] 15867905 BEZEL, R/CMPT LID REL SW (ЧАСТЬ OF 16) (EBONY) 15867906 BEZEL, R/CMPT LID REL SW (ЧАСТЬ OF 16) (GRAY) 15867907 BEZEL, R/CMPT LID REL SW (ЧАСТЬ OF 16) (CASHMERE) 11561274 БОЛТ, FRT S/D WDO SW (ЧАСТЬ OF 16) (SCREW-PAN HEAD, #6-19X1.5, 0.83 THD, 0.26 OD) (16.263) 25783499 SWITCH, DR LK & SI WDO (ЧАСТЬ OF 16) (ARGENT) [ВЫКЛЮЧАТЕЛЬ СТЕКЛОПОДЪЕМНИКА ДВЕРИ (КЛАВ)] 25783499 SWITCH, DR LK & SI WDO (ЧАСТЬ OF 16) (ARGENT) (10.485) [ВЫКЛЮЧАТЕЛЬ СТЕКЛОПОДЪЕМНИКА ДВЕРИ (КЛАВ)] 25783500 SWITCH, DR LK & SI WDO (ЧАСТЬ OF 16) (ARGENT) 25783500 SWITCH, DR LK & SI WDO (ЧАСТЬ OF 16) (ARGENT) (10.485) 19115808 BULB, FRT S/D C/LP (ЧАСТЬ OF 16, 17) (8.991) (ACDelco #19115808) 25777449 TRIM, FRT S/D (INCLS 2-6, 9, 12-15, 17-21) (EBONY) 25777451 TRIM, FRT S/D (INCLS 2-6, 9, 12-15, 17-21) (TITANIUM) 25777452 TRIM, FRT S/D (INCLS 2-6, 9, 12-15, 17-21) (CASHMERE) 25777457 TRIM, FRT S/D (INCLS 2-6, 9, 12-15, 17-21) (EBONY) [ОБШИВКА] 25777459 TRIM, FRT S/D (INCLS 2-6, 9, 12-15, 17-21) (TITANIUM) 25777460 TRIM, FRT S/D (INCLS 2-6, 9, 12-15, 17-21) (CASHMERE) [ОБШИВКА] 25866868 TRIM, FRT S/D (INCLS 2-6, 9, 12-15, 17-21) (EBONY) 25866869 TRIM, FRT S/D (INCLS 2-6, 9, 12-15, 17-21) (TITANIUM) 25866870 TRIM, FRT S/D (INCLS 2-6, 9, 12-15, 17-21) (CASHMERE) 25866879 TRIM, FRT S/D (INCLS 2-6, 9, 12-15, 17-21) (EBONY) [ОБШИВКА] 25866880 TRIM, FRT S/D (INCLS 2-6, 9, 12-15, 17-21) (TITANIUM) [ОБШИВКА] 25866881 TRIM, FRT S/D (INCLS 2-6, 9, 12-15, 17-21) (CASHMERE) [ОБШИВКА] 10359030 ЛАМПА, CTSY (S/D ЛАМПА) (INCLS 15) (ЧАСТЬ OF 16) 15867890 BEZEL, FRT S/D WDO SW (ЧАСТЬ OF 16) (EBONY) 15867891 BEZEL, FRT S/D WDO SW (ЧАСТЬ OF 16) (GRAY) 15867892 BEZEL, FRT S/D WDO SW (ЧАСТЬ OF 16) (CASHMERE) 15867893 BEZEL, FRT S/D WDO SW (ЧАСТЬ OF 16) (EBONY) 15867894 BEZEL, FRT S/D WDO SW (ЧАСТЬ OF 16) (GRAY) 15867895 BEZEL, FRT S/D WDO SW (ЧАСТЬ OF 16) (CASHMERE) teamcadillac.ru 25898134 SWITCH, D/SEAT ADJR MEMORY (ЧАСТЬ OF 16) (ARGENT) 25857256 HARNESS, FRT S/D WRG (ЧАСТЬ OF 16) 11519031 RETAINER, PUSH IN, 19.5X26.1X1.8, ACETAL, NATURAL, FOAM SEALER (ЧАСТЬ OF 16) [ФИКСАТОР ОБШИВКИ ДВЕРИ] 20794762 DEFLECTOR, FRT S/D WAT 20310739 ГАЙКА, FRT S/D PULL HDL (3.125 MM) (RECTANGULAR NYLON) (14.690) [ВТУЛКА ФИКСАТОРА РУЧКИ САЛОНА] 20699808 RETAINER, FRT S/D G/MLDG (PUSH IN) (ЧАСТЬ OF 25) (BLACK) (12.0MM) (X-MAS TREE) (14.875) [КЛИПСА] 25846021 MOLDING, FRT S/D GARN (INCLS 24) (EBONY) [МОЛДИНГ] (6D14-089) - 2008 DM69 ОБЛИЦОВКА ПЕРЕДНЕЙ ВОДИТЕЛЬСКОЙ ДВЕРИ (EXC MEMORY A45) ↓ 11570654 ГАЙКА, FRT S/D TR (4.2 X 1.41) (FITS 8.75 SQ HOLE) (9.665) 11519032 RETAINER, PUSH IN, 19.5X28.4X1.8, FITS HOLE 9.1, ACETAL, BLK (ЧАСТЬ OF 15) [ФИКСАТОР ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ] not found APPLIQUE, FRT S/D T/PNL (ЧАСТЬ OF 15) 15243588 APPLIQUE, FRT S/D T/PNL (ЧАСТЬ OF 15) (SAPELE) (USE W/NUT 11503417 QTY 7 FOR 08;QTY 4 FOR 09 AND LATER) 11503417 ГАЙКА, M6.3 STMPD TYPE SR ZC (ЧАСТЬ OF 15) not found BEZEL, FRT S/D I/S HDL (ЧАСТЬ OF 15) 11609539 SCREW, RD CROWNED WA HD, M4.2X1.41X16, STL ISO 2702, GMW4205 (FRT S/D TR) [ВИНТ] 15871923 COVER, FRT S/D PULL HDL (EBONY) [КРЫШКА] 15871925 COVER, FRT S/D PULL HDL (TITANIUM) [КРЫШКА] 15871927 COVER, FRT S/D PULL HDL (CASHMERE) [КРЫШКА] 25796933 SWITCH, R/CMPT LID REL (ЧАСТЬ OF 15) (ACDelco #D1417G) [ВЫКЛ ЮЧАТЕЛЬ] 03539184 БОЛТ, FRT S/D PULL HDL (ATTACH TO NUT IN SHT MTL) (14.683) 25927093 CAP, FRT S/D PULL HDL БОЛТ (EBONY) [НАКЛАДКА ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ] 25927095 CAP, FRT S/D PULL HDL БОЛТ (TITANIUM) [КРЫШКА] 25927097 CAP, FRT S/D PULL HDL БОЛТ (CASHMERE) [НАКЛАДКА ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ] 15867905 BEZEL, R/CMPT LID REL SW (ЧАСТЬ OF 15) (EBONY) 15867906 BEZEL, R/CMPT LID REL SW (ЧАСТЬ OF 15) (GRAY) 15867907 BEZEL, R/CMPT LID REL SW (ЧАСТЬ OF 15) (CASHMERE) 11561274 БОЛТ, FRT S/D WDO SW (ЧАСТЬ OF 15) (SCREW-PAN HEAD, #6-19X1.5, 0.83 THD, 0.26 OD) (16.263) 25783499 SWITCH, DR LK & SI WDO (ЧАСТЬ OF 15) (ARGENT) [ВЫКЛЮЧАТЕЛЬ СТЕКЛОПОДЪЕМНИКА ДВЕРИ (КЛАВ)] 25783499 SWITCH, DR LK & SI WDO (ЧАСТЬ OF 15) (ARGENT) (10.485) [ВЫКЛЮЧАТЕЛЬ СТЕКЛОПОДЪЕМНИКА ДВЕРИ (КЛАВ)] 25783500 SWITCH, DR LK & SI WDO (ЧАСТЬ OF 15) (ARGENT) 25783500 SWITCH, DR LK & SI WDO (ЧАСТЬ OF 15) (ARGENT) (10.485) teamcadillac.ru 19115808 BULB, FRT S/D C/LP (ЧАСТЬ OF 15, 16) (8.991) (ACDelco #19115808) 15861193 TRIM, FRT S/D (INCLS 2-5, 8, 11-14, 16-19) (EBONY) 15861194 TRIM, FRT S/D (INCLS 2-5, 8, 11-14, 16-19) (TITANIUM) 15861205 TRIM, FRT S/D (INCLS 2-5, 8, 11-14, 16-19) (EBONY) [ДАТЧИК] 15861206 TRIM, FRT S/D (INCLS 2-5, 8, 11-14, 16-19) (TITANIUM) [ОБШИВКА] 25866872 TRIM, FRT S/D (INCLS 2-5, 8, 11-14, 16-19) (EBONY) 25866873 TRIM, FRT S/D (INCLS 2-5, 8, 11-14, 16-19) (TITANIUM) 25866883 TRIM, FRT S/D (INCLS 2-5, 8, 11-14, 16-19) (EBONY) [ОБШИВКА] 25866884 TRIM, FRT S/D (INCLS 2-5, 8, 11-14, 16-19) (TITANIUM) [ОБШИВКА] 10359030 ЛАМПА, CTSY (S/D ЛАМПА) (ЧАСТЬ OF 15) (INCLS 14) 15867890 BEZEL, FRT S/D WDO SW (ЧАСТЬ OF 15) (EBONY) 15867891 BEZEL, FRT S/D WDO SW (ЧАСТЬ OF 15) (GRAY) 15867892 BEZEL, FRT S/D WDO SW (ЧАСТЬ OF 15) (CASHMERE) 15867893 BEZEL, FRT S/D WDO SW (ЧАСТЬ OF 15) (EBONY) 15867894 BEZEL, FRT S/D WDO SW (ЧАСТЬ OF 15) (GRAY) 15867895 BEZEL, FRT S/D WDO SW (ЧАСТЬ OF 15) (CASHMERE) 25857255 HARNESS, FRT S/D WRG (ЧАСТЬ OF 15) 25857256 HARNESS, FRT S/D WRG (ЧАСТЬ OF 15) 25857258 HARNESS, FRT S/D WRG (ЧАСТЬ OF 15) 11519031 RETAINER, PUSH IN, 19.5X26.1X1.8, ACETAL, NATURAL, FOAM SEALER (ЧАСТЬ OF 15) [ФИКСАТОР ОБШИВКИ ДВЕРИ] 20794762 DEFLECTOR, FRT S/D WAT 20310739 ГАЙКА, FRT S/D PULL HDL (3.125 MM) (RECTANGULAR NYLON) (14.690) [ВТУЛКА ФИКСАТОРА РУЧКИ САЛОНА] 20699808 RETAINER, FRT S/D G/MLDG (PUSH IN) (ЧАСТЬ OF 23) (BLACK) (12.0MM) (X-MAS TREE) (14.875) [КЛИПСА] 25846021 MOLDING, FRT S/D GARN (INCLS 22) (EBONY) [МОЛДИНГ] (6D14-091) - 2008 DM69 ОБЛИЦОВКА ПЕРЕДНЕЙ ПАССАЖИРСКОЙ ДВЕРИ (ЛАМПА PACKAGE TSQ) ↓ 25846022 MOLDING, FRT S/D GARN (INCLS 3) (EBONY) [МОЛДИНГ] not found ГАЙКА, FRT S/D TR 11570654 ГАЙКА, FRT S/D TR (4.2 X 1.41) (FITS 8.75 SQ HOLE) (9.665) 20699808 RETAINER, FRT S/D G/MLDG (PUSH IN) (ЧАСТЬ OF 1) (BLACK) (12.0MM) (X-MAS TREE) (14.875) [КЛИПСА] 20310739 ГАЙКА, FRT S/D PULL HDL (3.125 MM) (RECTANGULAR NYLON) (14.690) [ВТУЛКА ФИКСАТОРА РУЧКИ САЛОНА] 20794761 DEFLECTOR, FRT S/D WAT [ПРОКЛАДКА ПАНЕЛИ ДВЕРИ] 11519031 RETAINER, PUSH IN, 19.5X26.1X1.8, ACETAL, NATURAL, FOAM SEALER (ЧАСТЬ OF 19) [ФИКСАТОР ОБШИВКИ ДВЕРИ] 25857263 HARNESS, FRT S/D WRG (ЧАСТЬ OF 19) 25857265 HARNESS, FRT S/D WRG (ЧАСТЬ OF 19) 15867896 BEZEL, FRT S/D WDO SW (ЧАСТЬ OF 19) (EBONY) 15867897 BEZEL, FRT S/D WDO SW (ЧАСТЬ OF 19) (GRAY) 15867898 BEZEL, FRT S/D WDO SW (ЧАСТЬ OF 19) (CASHMERE) 10359030 ЛАМПА, CTSY (S/D ЛАМПА) (ЧАСТЬ OF 19) (INCLS 10) 19115808 BULB, FRT S/D C/LP (ЧАСТЬ OF 9, 19) (8.991) (ACDelco #19115808) 25783498 SWITCH, DR LK & SI WDO (ЧАСТЬ OF 19) (ARGENT) [ПЕРЕКЛЮЧАТЕЛЬ] 25783498 SWITCH, DR LK & SI WDO (ЧАСТЬ OF 19) (ARGENT) (10.485) [ПЕРЕКЛЮЧАТЕЛЬ] 11561274 БОЛТ, FRT S/D WDO SW (ЧАСТЬ OF 19) (SCREW-PAN HEAD, #6-19X1.5, 0.83 THD, 0.26 OD) (16.263) 25927094 CAP, FRT S/D PULL HDL БОЛТ (EBONY) [НАКЛАДКА ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ] 25927096 CAP, FRT S/D PULL HDL БОЛТ (TITANIUM) [НАКЛАДКА ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ] 25927098 CAP, FRT S/D PULL HDL БОЛТ (CASHMERE) [КОЛПАЧЕК] 03539184 БОЛТ, FRT S/D PULL HDL (ATTACH TO NUT IN SHT MTL) (14.683) 25856525 ЛАМПА, RR S/D WRNG (ЧАСТЬ OF 19) (LED PIN SPOT) (14.691) [ПОДСВЕТКА САЛОНА] 15871924 COVER, FRT S/D PULL HDL (EBONY) [КРЫШКА] 15871926 COVER, FRT S/D PULL HDL (TITANIUM) [КРЫШКА] 15871928 COVER, FRT S/D PULL HDL (CASHMERE) [КРЫШКА] 11609539 SCREW, RD CROWNED WA HD, M4.2X1.41X16, STL ISO 2702, GMW4205 (FRT S/D TR) [ВИНТ] not found BEZEL, FRT S/D I/S HDL (ЧАСТЬ OF 19) 15861209 TRIM, FRT S/D (INCLS 6-12, 15, 18, 20-23) (EBONY) 15861211 TRIM, FRT S/D (INCLS 6-12, 15, 18, 20-23) (TITANIUM) 15861212 TRIM, FRT S/D (INCLS 6-12, 15, 18, 20-23) (CASHMERE) 25777473 TRIM, FRT S/D (INCLS 6-12, 15, 18, 20-23) (EBONY) [ОБШИВКА] 25777475 TRIM, FRT S/D (INCLS 6-12, 15, 18, 20-23) (TITANIUM) [ОБШИВКА] 25777476 TRIM, FRT S/D (INCLS 6-12, 15, 18, 20-23) (CASHMERE) [ОБШИВКА] 25866886 TRIM, FRT S/D (INCLS 6-12, 15, 18, 20-23) (EBONY) 25866887 TRIM, FRT S/D (INCLS 6-12, 15, 18, 20-23) (TITANIUM) teamcadillac.ru 25866888 TRIM, FRT S/D (INCLS 6-12, 15, 18, 20-23) (CASHMERE) 25866897 TRIM, FRT S/D (INCLS 6-12, 15, 18, 20-23) (EBONY) [ОБШИВКА] 25866898 TRIM, FRT S/D (INCLS 6-12, 15, 18, 20-23) (TITANIUM) [ОБШИВКА] 25866899 TRIM, FRT S/D (INCLS 6-12, 15, 18, 20-23) (CASHMERE) [ОБШИВКА] not found APPLIQUE, FRT S/D T/PNL (ЧАСТЬ OF 19) not found APPLIQUE, FRT S/D T/PNL (ЧАСТЬ OF 19) 15243589 APPLIQUE, FRT S/D T/PNL (ЧАСТЬ OF 19) (USE W/NUT 11503417 QTY 7 FOR 08;QTY 4 FOR 09 AND LATER) [НАКЛАДКА ДВЕРИ] 11503417 ГАЙКА, M6.3 STMPD TYPE SR ZC (ЧАСТЬ OF 19) 15243683 ЛАМПА, FRT S/D WRNG (ЧАСТЬ OF 19) (FRT LIGHT PIPE) [ФАРА] 11519032 RETAINER, PUSH IN, 19.5X28.4X1.8, FITS HOLE 9.1, ACETAL, BLK (ЧАСТЬ OF 19) [ФИКСАТОР ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ] (6D14-092) - 2008 DM69 ОБЛИЦОВКА ПЕРЕДНЕЙ ПАССАЖИРСКОЙ ДВЕРИ (EXC ЛАМПА PACKAGE TSQ) ↓ 25846022 MOLDING, FRT S/D GARN (INCLS 3) (EBONY) [МОЛДИНГ] not found ГАЙКА, FRT S/D TR 11570654 ГАЙКА, FRT S/D TR (4.2 X 1.41) (FITS 8.75 SQ HOLE) (9.665) 20699808 RETAINER, FRT S/D G/MLDG (PUSH IN) (ЧАСТЬ OF 1) (BLACK) (12.0MM) (X-MAS TREE) (14.875) [КЛИПСА] 20310739 ГАЙКА, FRT S/D PULL HDL (3.125 MM) (RECTANGULAR NYLON) (14.690) [ВТУЛКА ФИКСАТОРА РУЧКИ САЛОНА] 20794761 DEFLECTOR, FRT S/D WAT [ПРОКЛАДКА ПАНЕЛИ ДВЕРИ] 11519031 RETAINER, PUSH IN, 19.5X26.1X1.8, ACETAL, NATURAL, FOAM SEALER (ЧАСТЬ OF 18) [ФИКСАТОР ОБШИВКИ ДВЕРИ] 25857261 HARNESS, FRT S/D WRG (ЧАСТЬ OF 18) 25857262 HARNESS, FRT S/D WRG (ЧАСТЬ OF 18) 25857264 HARNESS, FRT S/D WRG (ЧАСТЬ OF 18) 25857266 HARNESS, FRT S/D WRG (ЧАСТЬ OF 18) 15867896 BEZEL, FRT S/D WDO SW (ЧАСТЬ OF 18) (EBONY) 15867897 BEZEL, FRT S/D WDO SW (ЧАСТЬ OF 18) (GRAY) 15867898 BEZEL, FRT S/D WDO SW (ЧАСТЬ OF 18) (CASHMERE) 10359030 ЛАМПА, CTSY (S/D ЛАМПА) (ЧАСТЬ OF 18) (INCLS 10) 19115808 BULB, FRT S/D C/LP (ЧАСТЬ OF 9, 18) (8.991) (ACDelco #19115808) 25783498 SWITCH, DR LK & SI WDO (ЧАСТЬ OF 18) (ARGENT) [ПЕРЕКЛЮЧАТЕЛЬ] 25783498 SWITCH, DR LK & SI WDO (ЧАСТЬ OF 18) (ARGENT) (10.485) [ПЕРЕКЛЮЧАТЕЛЬ] 11561274 БОЛТ, FRT S/D WDO SW (ЧАСТЬ OF 18) (SCREW-PAN HEAD, #6-19X1.5, 0.83 THD, 0.26 OD) (16.263) 25927094 CAP, FRT S/D PULL HDL БОЛТ (EBONY) [НАКЛАДКА ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ] 25927096 CAP, FRT S/D PULL HDL БОЛТ (TITANIUM) [НАКЛАДКА ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ] 25927098 CAP, FRT S/D PULL HDL БОЛТ (CASHMERE) [КОЛПАЧЕК] 03539184 БОЛТ, FRT S/D PULL HDL (ATTACH TO NUT IN SHT MTL) (14.683) 15871924 COVER, FRT S/D PULL HDL (EBONY) [КРЫШКА] 15871926 COVER, FRT S/D PULL HDL (TITANIUM) [КРЫШКА] 15871928 COVER, FRT S/D PULL HDL (CASHMERE) [КРЫШКА] 11609539 SCREW, RD CROWNED WA HD, M4.2X1.41X16, STL ISO 2702, GMW4205 (FRT S/D TR) [ВИНТ] not found BEZEL, FRT S/D I/S HDL (ЧАСТЬ OF 18) 15861217 TRIM, FRT S/D (INCLS 6-12, 17, 19-21) (EBONY) 15861218 TRIM, FRT S/D (INCLS 6-12, 17, 19-21) (TITANIUM) 25777468 TRIM, FRT S/D (INCLS 6-12, 17, 19-21) (CASHMERE) 25777484 TRIM, FRT S/D (INCLS 6-12, 17, 19-21) (CASHMERE) 25777489 TRIM, FRT S/D (INCLS 6-12, 17, 19-21) (EBONY) 25777490 TRIM, FRT S/D (INCLS 6-12, 17, 19-21) (TITANIUM) 25866891 TRIM, FRT S/D (INCLS 6-12, 17, 19-21) (TITANIUM) (W/MEMORY MIR & ST ADJ) 25866892 TRIM, FRT S/D (INCLS 6-12, 17, 19-21) (CASHMERE) 25866894 TRIM, FRT S/D (INCLS 6-12, 17, 19-21) (EBONY) 25866902 TRIM, FRT S/D (INCLS 6-12, 17, 19-21) (TITANIUM) [ОБШИВКА] 25866903 TRIM, FRT S/D (INCLS 6-12, 17, 19-21) (CASHMERE) [ОБШИВКА] 25866905 TRIM, FRT S/D (INCLS 6-12, 17, 19-21) (EBONY) [ОБШИВКА] not found APPLIQUE, FRT S/D T/PNL (ЧАСТЬ OF 18) not found APPLIQUE, FRT S/D T/PNL (ЧАСТЬ OF 18) teamcadillac.ru 15243589 APPLIQUE, FRT S/D T/PNL (ЧАСТЬ OF 18) (USE W/NUT 11503417 QTY 7 FOR 08;QTY 4 FOR 09 AND LATER) [НАКЛАДКА ДВЕРИ] 11503417 ГАЙКА, M6.3 STMPD TYPE SR ZC (ЧАСТЬ OF 18) 11519032 RETAINER, PUSH IN, 19.5X28.4X1.8, FITS HOLE 9.1, ACETAL, BLK (ЧАСТЬ OF 18) [ФИКСАТОР ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ] (6D14-095) - 2008 DM69 ОТДЕЛКА/ЗАДНЯЯ ДВЕРЬ (ЛАМПА PACKAGE TSQ) ↓ 25846025 MOLDING, RR S/D GARN (INCLS 2) (EBONY) [МОЛДИНГ] 25846026 MOLDING, RR S/D GARN (INCLS 2) (EBONY) [МОЛДИНГ] not found RETAINER, FRT S/D G/MLDG (PUSH IN) (ЧАСТЬ OF 1) 20699808 RETAINER, FRT S/D G/MLDG (PUSH IN) (ЧАСТЬ OF 1) (BLACK) (12.0MM) (X-MAS TREE) (14.875) [КЛИПСА] not found ГАЙКА, RR S/D TR 11570654 ГАЙКА, RR S/D TR (4.2 X 1.41) (FITS 8.75 SQ HOLE) (9.665) 25874266 DEFLECTOR, RR S/D WAT [ДЕФЛЕКТОР] 25874267 DEFLECTOR, RR S/D WAT [ПРОКЛАДКА ПАНЕЛИ ДВЕРИ] 11519031 RETAINER, PUSH IN, 19.5X26.1X1.8, ACETAL, NATURAL, FOAM SEALER (ЧАСТЬ OF 16) [ФИКСАТОР ОБШИВКИ ДВЕРИ] 15867932 BEZEL, RR S/D LKG ROD P/BUT (ЧАСТЬ OF 16) (EBONY) (10.550) 15867933 BEZEL, RR S/D LKG ROD P/BUT (ЧАСТЬ OF 16) (EBONY) (10.550) 15867936 BEZEL, RR S/D LKG ROD P/BUT (ЧАСТЬ OF 16) (CASHMERE) (10.550) 15867937 BEZEL, RR S/D LKG ROD P/BUT (ЧАСТЬ OF 16) (CASHMERE) (10.550) teamcadillac.ru 15243684 ЛАМПА, RR S/D WRNG (ЧАСТЬ OF 16) (ЗАДНИЙ LIGHT PIPE) [ФАРА] not found APPLIQUE, RR S/D T/PNL (ЧАСТЬ OF 16) not found APPLIQUE, RR S/D T/PNL (ЧАСТЬ OF 16) 15243632 APPLIQUE, RR S/D T/PNL (ЧАСТЬ OF 16) (USE W/NUT 11503417 QTY 7 FOR 08;QTY 4 FOR 09 AND LATER) [НАКЛАДКА ДВЕРИ] 15243633 APPLIQUE, RR S/D T/PNL (ЧАСТЬ OF 16) (USE W/NUT 11503417 QTY 7 FOR 08;QTY 4 FOR 09 AND LATER) [НАКЛАДКА ДВЕРИ] 11503417 ГАЙКА, M6.3 STMPD TYPE SR ZC (ЧАСТЬ OF 16) 25856525 ЛАМПА, RR S/D WRNG (ЧАСТЬ OF 16) (LED PIN SPOT) (14.691) [ПОДСВЕТКА САЛОНА] not found BEZEL, RR S/D I/S HDL (ЧАСТЬ OF 16) 11609539 SCREW, RD CROWNED WA HD, M4.2X1.41X16, STL ISO 2702, GMW4205 (RR S/D TR) [ВИНТ] 15871923 COVER, RR S/D PULL HDL (EBONY) (14.691) [КРЫШКА] 15871924 COVER, RR S/D PULL HDL (EBONY) (14.691) [КРЫШКА] 15871925 COVER, RR S/D PULL HDL (TITANIUM) (14.691) [КРЫШКА] 15871926 COVER, RR S/D PULL HDL (TITANIUM) (14.691) [КРЫШКА] 15871927 COVER, RR S/D PULL HDL (CASHMERE) (14.691) [КРЫШКА] 15871928 COVER, RR S/D PULL HDL (CASHMERE) (14.691) [КРЫШКА] 03539184 БОЛТ, RR S/D PULL HDL (14.683) 25927101 CAP, RR S/D PULL HDL БОЛТ (EBONY) [НАКЛАДКА ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ] 25927102 CAP, RR S/D PULL HDL БОЛТ (EBONY) [НАКЛАДКА ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ] 25927103 CAP, RR S/D PULL HDL БОЛТ (TITANIUM) [НАКЛАДКА ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ] 25927104 CAP, RR S/D PULL HDL БОЛТ (TITANIUM) [КОЛПАЧЕК] 25927105 CAP, RR S/D PULL HDL БОЛТ (CASHMERE) [НАКЛАДКА ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ] 25927106 CAP, RR S/D PULL HDL БОЛТ (CASHMERE) [НАКЛАДКА ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ] 15861282 TRIM, RR S/D (INCLS 5-11, 17-24) (EBONY) [ОБШИВКА] 15861284 TRIM, RR S/D (INCLS 5-11, 17-24) (TITANIUM) [ОБШИВКА] 15861285 TRIM, RR S/D (INCLS 5-11, 17-24) (CASHMERE) [ВНУТРЕННЯЯ ПАНЕЛЬ ДВЕРИ] 15861294 TRIM, RR S/D (INCLS 5-11, 17-24) (EBONY) [ОБШИВКА] 15861296 TRIM, RR S/D (INCLS 5-11, 17-24) (TITANIUM) [ОБШИВКА] 15861297 TRIM, RR S/D (INCLS 5-11, 17-24) (CASHMERE) [ОБШИВКА] 25866909 TRIM, RR S/D (INCLS 5-11, 17-24) (EBONY) [ОБШИВКА] 25866910 TRIM, RR S/D (INCLS 5-11, 17-24) (TITANIUM) [ОБШИВКА] 25866911 TRIM, RR S/D (INCLS 5-11, 17-24) (CASHMERE) [ОБШИВКА] 25866917 TRIM, RR S/D (INCLS 5-11, 17-24) (EBONY) [ОБШИВКА] 25866918 TRIM, RR S/D (INCLS 5-11, 17-24) (TITANIUM) [ВНУТРЕННЯЯ ПАНЕЛЬ ДВЕРИ] 25866919 TRIM, RR S/D (INCLS 5-11, 17-24) (CASHMERE) [ОБШИВКА] 10359030 ЛАМПА, CTSY (S/D ЛАМПА) (ЧАСТЬ OF 16) (INCLS 18) 19115808 BULB, FRT S/D C/LP (ЧАСТЬ OF 16, 17) (8.991) (ACDelco #19115808) 25914973 SWITCH, RR S/D WDO (ЧАСТЬ OF 16) 15867926 BEZEL, RR S/D WDO SW (ЧАСТЬ OF 16) (EBONY) 15867927 BEZEL, RR S/D WDO SW (ЧАСТЬ OF 16) (EBONY) 15867928 BEZEL, RR S/D WDO SW (ЧАСТЬ OF 16) (GRAY) 15867929 BEZEL, RR S/D WDO SW (ЧАСТЬ OF 16) (GRAY) 15867930 BEZEL, RR S/D WDO SW (ЧАСТЬ OF 16) (CASHMERE) 15867931 BEZEL, RR S/D WDO SW (ЧАСТЬ OF 16) (CASHMERE) 25725733 SPEAKER, RDO RR S/D (ЧАСТЬ OF 16) (ACDelco #25725733) [ДИНАМИК 40ВТ] 15809005 БОЛТ, RDO RR SPKR (ЧАСТЬ OF 16) (3.682) 25821437 HARNESS, RR S/D WRG (ЧАСТЬ OF 16) 11519032 RETAINER, PUSH IN, 19.5X28.4X1.8, FITS HOLE 9.1, ACETAL, BLK (ЧАСТЬ OF 16) [ФИКСАТОР ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ] 20310739 ГАЙКА, RR S/D PULL HDL (3.125 MM) (RECTANGULAR NYLON) (14.690) [ВТУЛКА ФИКСАТОРА РУЧКИ САЛОНА] (6D14-096) - 2008 DM69 ОТДЕЛКА/ЗАДНЯЯ ДВЕРЬ (EXC ЛАМПА PACKAGE TSQ) ↓ 25846025 MOLDING, RR S/D GARN (INCLS 2) (EBONY) [МОЛДИНГ] 25846026 MOLDING, RR S/D GARN (INCLS 2) (EBONY) [МОЛДИНГ] not found RETAINER, FRT S/D G/MLDG (PUSH IN) (ЧАСТЬ OF 1) 20699808 RETAINER, FRT S/D G/MLDG (PUSH IN) (ЧАСТЬ OF 1) (BLACK) (12.0MM) (X-MAS TREE) (14.875) [КЛИПСА] not found ГАЙКА, RR S/D TR 11570654 ГАЙКА, RR S/D TR (4.2 X 1.41) (FITS 8.75 SQ HOLE) (9.665) 25874266 DEFLECTOR, RR S/D WAT [ДЕФЛЕКТОР] 25874267 DEFLECTOR, RR S/D WAT [ПРОКЛАДКА ПАНЕЛИ ДВЕРИ] 11519031 RETAINER, PUSH IN, 19.5X26.1X1.8, ACETAL, NATURAL, FOAM SEALER (ЧАСТЬ OF 14) [ФИКСАТОР ОБШИВКИ ДВЕРИ] 15867932 BEZEL, RR S/D LKG ROD P/BUT (ЧАСТЬ OF 14) (EBONY) (10.550) 15867933 BEZEL, RR S/D LKG ROD P/BUT (ЧАСТЬ OF 14) (EBONY) (10.550) 15867936 BEZEL, RR S/D LKG ROD P/BUT (ЧАСТЬ OF 14) (CASHMERE) (10.550) 15867937 BEZEL, RR S/D LKG ROD P/BUT (ЧАСТЬ OF 14) (CASHMERE) (10.550) 11503417 ГАЙКА, M6.3 STMPD TYPE SR ZC (ЧАСТЬ OF 14) not found APPLIQUE, RR S/D T/PNL (ЧАСТЬ OF 14) not found APPLIQUE, RR S/D T/PNL (ЧАСТЬ OF 14) 15243632 APPLIQUE, RR S/D T/PNL (ЧАСТЬ OF 14) (USE W/NUT 11503417 QTY 7 FOR 08;QTY 4 FOR 09 AND LATER) [НАКЛАДКА ДВЕРИ] 15243633 APPLIQUE, RR S/D T/PNL (ЧАСТЬ OF 14) (USE W/NUT 11503417 QTY 7 FOR 08;QTY 4 FOR 09 AND LATER) [НАКЛАДКА ДВЕРИ] not found BEZEL, RR S/D I/S HDL (ЧАСТЬ OF 14) 11609539 SCREW, RD CROWNED WA HD, M4.2X1.41X16, STL ISO 2702, GMW4205 (RR S/D TR) [ВИНТ] 15871923 COVER, RR S/D PULL HDL (EBONY) (14.691) [КРЫШКА] 15871924 COVER, RR S/D PULL HDL (EBONY) (14.691) [КРЫШКА] 15871925 COVER, RR S/D PULL HDL (TITANIUM) (14.691) [КРЫШКА] 15871926 COVER, RR S/D PULL HDL (TITANIUM) (14.691) [КРЫШКА] 15871927 COVER, RR S/D PULL HDL (CASHMERE) (14.691) [КРЫШКА] 15871928 COVER, RR S/D PULL HDL (CASHMERE) (14.691) [КРЫШКА] 03539184 БОЛТ, RR S/D PULL HDL (14.683) 25927101 CAP, RR S/D PULL HDL БОЛТ (EBONY) [НАКЛАДКА ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ] 25927102 CAP, RR S/D PULL HDL БОЛТ (EBONY) [НАКЛАДКА ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ] teamcadillac.ru 25927103 CAP, RR S/D PULL HDL БОЛТ (TITANIUM) [НАКЛАДКА ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ] 25927104 CAP, RR S/D PULL HDL БОЛТ (TITANIUM) [КОЛПАЧЕК] 25927105 CAP, RR S/D PULL HDL БОЛТ (CASHMERE) [НАКЛАДКА ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ] 25927106 CAP, RR S/D PULL HDL БОЛТ (CASHMERE) [НАКЛАДКА ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ] 15861290 TRIM, RR S/D (INCLS 5-9, 15-22) (EBONY) (INCLS HANDLE) [ОБШИВКА] 15861291 TRIM, RR S/D (INCLS 5-9, 15-22) (TITANIUM) (INCLS HANDLE) [ОБШИВКА] 15861302 TRIM, RR S/D (INCLS 5-9, 15-22) (EBONY) [ОБШИВКА] 15861303 TRIM, RR S/D (INCLS 5-9, 15-22) (TITANIUM) [ОБШИВКА] 25791485 TRIM, RR S/D (INCLS 5-9, 15-22) (CASHMERE) [ОБШИВКА] 25791489 TRIM, RR S/D (INCLS 5-9, 15-22) (CASHMERE) [ОБШИВКА] 25866913 TRIM, RR S/D (INCLS 5-9, 15-22) (EBONY) [ОБШИВКА] 25866914 TRIM, RR S/D (INCLS 5-9, 15-22) (TITANIUM) [ОБШИВКА] 25866915 TRIM, RR S/D (INCLS 5-9, 15-22) (CASHMERE) [ОБШИВКА] 25866921 TRIM, RR S/D (INCLS 5-9, 15-22) (EBONY) [ОБШИВКА] 25866922 TRIM, RR S/D (INCLS 5-9, 15-22) (TITANIUM) [ОБШИВКА] 25866923 TRIM, RR S/D (INCLS 5-9, 15-22) (CASHMERE) [ОБШИВКА] 10359030 ЛАМПА, CTSY (S/D ЛАМПА) (ЧАСТЬ OF 14) (INCLS 16) 19115808 BULB, FRT S/D C/LP (ЧАСТЬ OF 14, 15) (8.991) (ACDelco #19115808) 25914973 SWITCH, RR S/D WDO (ЧАСТЬ OF 14) 15867926 BEZEL, RR S/D WDO SW (ЧАСТЬ OF 14) (EBONY) 15867927 BEZEL, RR S/D WDO SW (ЧАСТЬ OF 14) (EBONY) 15867928 BEZEL, RR S/D WDO SW (ЧАСТЬ OF 14) (GRAY) 15867929 BEZEL, RR S/D WDO SW (ЧАСТЬ OF 14) (GRAY) 15867930 BEZEL, RR S/D WDO SW (ЧАСТЬ OF 14) (CASHMERE) 15867931 BEZEL, RR S/D WDO SW (ЧАСТЬ OF 14) (CASHMERE) 25725733 SPEAKER, RDO RR S/D (ЧАСТЬ OF 14) (ACDelco #25725733) [ДИНАМИК 40ВТ] 15809005 БОЛТ, RDO RR SPKR (ЧАСТЬ OF 14) (3.682) 25821436 HARNESS, RR S/D WRG (ЧАСТЬ OF 14) 11519032 RETAINER, PUSH IN, 19.5X28.4X1.8, FITS HOLE 9.1, ACETAL, BLK (ЧАСТЬ OF 14) [ФИКСАТОР ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ] 20310739 ГАЙКА, RR S/D PULL HDL (3.125 MM) (RECTANGULAR NYLON) (14.690) [ВТУЛКА ФИКСАТОРА РУЧКИ САЛОНА] (6D14-097) - 2008 DM69 ВОДИТЕЛЬСКОЕ СИДЕНЬЕ-СПИНКА (POWER LUMBAR AL2, ИСКЛЮЧАЯ ВЕНТИЛЯЦИЮ И ОБОГРЕВ KB6)(2ND DES) ↓ 25939467 RESTRAINT, D/SEAT HD (CASHMERE) 25939468 RESTRAINT, D/SEAT HD (TITANIUM) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780652) 25939469 RESTRAINT, D/SEAT HD (EBONY) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780653) 25785786 GUIDE, D/SEAT H/RST (CASHMERE) (W/BUTTON) 25785788 GUIDE, D/SEAT H/RST (EBONY) (W/BUTTON) 25785789 GUIDE, D/SEAT H/RST (CASHMERE) (W/O BUTTON) 25785791 GUIDE, D/SEAT H/RST (EBONY) (W/O BUTTON) 25908135 GUIDE, D/SEAT H/RST (TITANIUM) (W/BUTTON) 25908165 GUIDE, D/SEAT H/RST (TITANIUM) (W/O BUTTON) 25994444 RETAINER, D/SEAT H/RST GDE 25995123 BUMPER, F/SEAT BK CUSH 25939323 PANEL, D/SEAT BK CUSH FIN (MAY ALSO NEED TO REPL PASS SIDE) (INCLS 6) (CASHMERE) 25939324 PANEL, D/SEAT BK CUSH FIN (MAY ALSO NEED TO REPL PASS SIDE) (INCLS 6) (TITANIUM) 25939325 PANEL, D/SEAT BK CUSH FIN (MAY ALSO NEED TO REPL PASS SIDE) (INCLS 6) (EBONY) 11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (ЧАСТЬ OF 5) [ЗАЖИМ КОНСОЛИ САЛОНА] 11571066 ГАЙКА, PUSH-ON, FOR 9/32" (6.9MM) DIA STUDS, 18.4 OD, SAE 1050 STL, GMW30 (ЧАСТЬ OF 19) 15894212 BAR, F/SEAT BK CUSH FRM CR (ЧАСТЬ OF 19) 25828643 БОЛТ, F/SEAT (ЧАСТЬ OF 19) not found BRACKET, D/SEAT not found RIVET, D/SEAT ADJR BRKT not found PAD, D/SEAT CUSH (СМ. ГРУППУ 14.000 "ПАССАЖИРСКОЕ СИДЕНЬЕ-ПОДУШКА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 15894213 ACTUATOR, D/SEAT RECL (ЧАСТЬ OF 19) not found BRACKET, D/SEAT RECL ACTR (ЧАСТЬ OF 19) not found BRACKET, INFL RST D/SEAT SI MDL not found ГАЙКА, INFL RST D/SEAT SI MDL not found ПРУЖИНА, F/SEAT H/RST ADJ RET 25807063 РАМА, D/SEAT BK CUSH (INCLS 8-10, 14, 15, 21) (14.896) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 15865917) 15865928 LUMBAR SUB, D/SEAT (W/O ACTIVE H/RST-HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) teamcadillac.ru 25939289 LUMBAR SUB, D/SEAT (W/ACTIVE H/RST-HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) [ПОЯСНИЧНАЯ ОПОРА СПИНКИ СИДЕНЬЯ] 25939527 LUMBAR SUB, D/SEAT (W/ACTIVE H/RST-HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) not found CLIP, ACTUATOR D/SEAT RECL) (ЧАСТЬ OF 19 25941321 HARNESS, D/SEAT WRG not found MAT, F/SEAT BK CUSH VENT FAN 25939332 COVER, D/SEAT BK CUSH (CASHMERE) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780316) 25939333 COVER, D/SEAT BK CUSH (TITANIUM) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780317) 25939334 COVER, D/SEAT BK CUSH (EBONY) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780318) 25939457 COVER, D/SEAT BK CUSH (TITANIUM) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780361) 25939292 PAD, D/SEAT BK CUSH (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25777056) not found BUSHING, F/SEAT BK CUSH PIV not found БОЛТ, D/SEAT H/RST SUPT 25994442 SUPPORT, D/SEAT H/RST (6D14-098) - 2008 DM69 ВОДИТЕЛЬСКОЕ СИДЕНЬЕ-СПИНКА (VENTED/HEATED KB6)(2ND DES) ↓ 25939467 RESTRAINT, D/SEAT HD (CASHMERE) teamcadillac.ru 25939468 RESTRAINT, D/SEAT HD (TITANIUM) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780652) 25939469 RESTRAINT, D/SEAT HD (EBONY) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780653) 25785786 GUIDE, D/SEAT H/RST (CASHMERE) (W/BUTTON) 25785788 GUIDE, D/SEAT H/RST (EBONY) (W/BUTTON) 25785789 GUIDE, D/SEAT H/RST (CASHMERE) (W/O BUTTON) 25785791 GUIDE, D/SEAT H/RST (EBONY) (W/O BUTTON) 25908135 GUIDE, D/SEAT H/RST (TITANIUM) (W/BUTTON) 25908165 GUIDE, D/SEAT H/RST (TITANIUM) (W/O BUTTON) 25994444 RETAINER, D/SEAT H/RST GDE 25995123 BUMPER, F/SEAT BK CUSH 25939323 PANEL, D/SEAT BK CUSH FIN (MAY ALSO NEED TO REPL PASS SIDE) (INCLS 6) (CASHMERE) 25939324 PANEL, D/SEAT BK CUSH FIN (MAY ALSO NEED TO REPL PASS SIDE) (INCLS 6) (TITANIUM) 25939325 PANEL, D/SEAT BK CUSH FIN (MAY ALSO NEED TO REPL PASS SIDE) (INCLS 6) (EBONY) 11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (ЧАСТЬ OF 5) [ЗАЖИМ КОНСОЛИ САЛОНА] not found МОДУЛЬ, D/SEAT SI INFL RST 11571066 ГАЙКА, PUSH-ON, FOR 9/32" (6.9MM) DIA STUDS, 18.4 OD, SAE 1050 STL, GMW30 (ЧАСТЬ OF 19) 15894212 BAR, F/SEAT BK CUSH FRM CR (ЧАСТЬ OF 19) 25828643 БОЛТ, F/SEAT (ЧАСТЬ OF 19) not found BRACKET, D/SEAT not found RIVET, D/SEAT ADJR BRKT not found PAD, D/SEAT CUSH (СМ. ГРУППУ 14.000 "ПАССАЖИРСКОЕ СИДЕНЬЕ-ПОДУШКА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 15894213 ACTUATOR, D/SEAT RECL (ЧАСТЬ OF 19) not found BRACKET, D/SEAT RECL ACTR (ЧАСТЬ OF 19) not found BRACKET, INFL RST D/SEAT SI MDL not found ГАЙКА, INFL RST D/SEAT SI MDL not found ПРУЖИНА, F/SEAT H/RST ADJ RET 25807063 РАМА, D/SEAT BK CUSH (INCLS 8-10, 14, 15, 21) (14.896) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 15865917) 15865928 LUMBAR SUB, D/SEAT (W/O ACTIVE H/RST-HT OF BK PNL INDENTATION ABOVE MAP PKT=8IN) 25939289 LUMBAR SUB, D/SEAT (W/ACTIVE H/RST-HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) [ПОЯСНИЧНАЯ ОПОРА СПИНКИ СИДЕНЬЯ] not found CLIP, ACTUATOR D/SEAT RECL) (ЧАСТЬ OF 19 25941321 HARNESS, D/SEAT WRG not found MAT, F/SEAT BK CUSH VENT FAN 25939456 COVER, D/SEAT BK CUSH (CASHMERE) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780360) 25939457 COVER, D/SEAT BK CUSH (TITANIUM) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780361) 25939458 COVER, D/SEAT BK CUSH (EBONY) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780362) 25939293 PAD, D/SEAT BK CUSH (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25777057) 25939274 ВЕНТИЛЯТОР, D/SEAT BACK VENTILATION HEAT & COOL (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780794) not found BUSHING, F/SEAT BK CUSH PIV not found БОЛТ, D/SEAT H/RST SUPT 25994442 SUPPORT, D/SEAT H/RST (6D14-119) - 2008 DM69 ВОДИТЕЛЬСКОЕ СИДЕНЬЕ-СПИНКА (EXC POWER LUMBAR AL2, VENTED/HEATED KB6)(2ND DES) ↓ 25939472 RESTRAINT, D/SEAT HD (TITANIUM) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780655) 25984306 RESTRAINT, D/SEAT HD (EBONY) (WHEN USED TO SERV 2008, REPL BOTH DRIVER & PASSENGER RST) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780656) 25785787 GUIDE, D/SEAT H/RST (TITANIUM) (W/BUTTON) 25785788 GUIDE, D/SEAT H/RST (EBONY) (W/BUTTON) 25785790 GUIDE, D/SEAT H/RST (TITANIUM) (W/O BUTTON) 25785791 GUIDE, D/SEAT H/RST (EBONY) (W/O BUTTON) teamcadillac.ru 25994444 RETAINER, D/SEAT H/RST GDE 25995123 BUMPER, F/SEAT BK CUSH 25939328 PANEL, D/SEAT BK CUSH FIN (MAY ALSO NEED TO REPL PASS SIDE) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE15947278) (INCLS 6) (TITANIUM) 25939329 PANEL, D/SEAT BK CUSH FIN (MAY ALSO NEED TO REPL PASS SIDE) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 15947279) (INCLS 6) (EBONY) 11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (ЧАСТЬ OF 5) [ЗАЖИМ КОНСОЛИ САЛОНА] not found МОДУЛЬ, D/SEAT SI INFL RST 11571066 ГАЙКА, PUSH-ON, FOR 9/32" (6.9MM) DIA STUDS, 18.4 OD, SAE 1050 STL, GMW30 (ЧАСТЬ OF 22) 15894212 BAR, F/SEAT BK CUSH FRM CR (ЧАСТЬ OF 22) 25828643 БОЛТ, F/SEAT (ЧАСТЬ OF 22) not found BRACKET, D/SEAT not found RIVET, D/SEAT ADJR BRKT not found PAD, D/SEAT CUSH (СМ. ГРУППУ 14.000 "ПАССАЖИРСКОЕ СИДЕНЬЕ-ПОДУШКА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (EBONY) (14.880) 15894213 ACTUATOR, D/SEAT RECL (ЧАСТЬ OF 22) not found BRACKET, D/SEAT RECL ACTR (ЧАСТЬ OF 22) not found BRACKET, INFL RST D/SEAT SI MDL 11517068 NUT-METRIC HEX FLABGE, M6X1, 10MM SOCKET (D/SEAT) not found ПРУЖИНА, F/SEAT H/RST ADJ RET not found BUSHING, F/SEAT BK CUSH PIV not found БОЛТ, D/SEAT H/RST SUPT 25994442 SUPPORT, D/SEAT H/RST 25807065 РАМА, D/SEAT BK CUSH (INCLS 8-10, 14, 15, 23) not found CLIP, ACTUATOR D/SEAT RECL) (ЧАСТЬ OF 22 25939527 LUMBAR SUB, D/SEAT (W/ACTIVE H/RST-HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) 25939463 COVER, D/SEAT BK CUSH (TITANIUM) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780302) 25939464 COVER, D/SEAT BK CUSH (EBONY) (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25780303) 25939292 PAD, D/SEAT BK CUSH (W/ACTIVE H/RST; HT OF BK PNL INDENTATION ABOVE MAP PKT=3IN) (FOR 1ST DES SEE 25777056) (TX16-004) - 2008-2010 D РЕМНИ БЕЗОПАСНОСТИ (EXTENSION KIT) ↓ teamcadillac.ru 12533459 EXTENSION KIT, R/SEAT BELT (BLACK) (TYPE AB) (9") (REFER TO BULLETIN ON SEAT BELT EXTDRS FOR DETAILED INFO) 12533460 EXTENSION KIT, F/SEAT BELT (BLACK) (15") (TYPE AB) (REFER TO GMSPO INFORMATION BULLETIN ON SEAT BELT EXTENDERS FOR DETAILED INFORMATION) 89024730 EXTENSION KIT, R/SEAT BELT (BLACK) (9") (16.714) (REFER TO GMSPO INFORMATION BULLETIN ON SEAT BELT EXTENDERS FOR DETAILED INFORMATION.) 89024731 EXTENSION KIT, R/SEAT BELT (BLACK) (15") (16.714) (REFER TO GMSPO INFORMATION BULLETIN ON SEAT BELT EXTENDERS FOR DETAILED INFORMATION.) 15 - ЗАДНЕЕ СИДЕНЬЕ - ПОКРЫТИЕ (6D15-015) - 2008 DM69 МОЛДИНГИ БОКОВОГО ОКНА (8 SPEAKER AUDIO UQA) ↓ not found GRILLE, RDO RR SPKR (ЧАСТЬ OF 2) 25852027 TRIM, R/WDO PNL (INCLS 1, 8, 9) (EBONY) (INCLS RR SEAL) [ОБШИВКА] 25852029 TRIM, R/WDO PNL (INCLS 1, 8, 9) (CASHMERE) (INCLS RR SEAL) [ОБШИВКА] 25979035 TRIM, R/WDO PNL (INCLS 1, 8, 9) (EBONY) (INCLS RR SEAL) 25979036 TRIM, R/WDO PNL (INCLS 1, 8, 9) (CASHMERE) (INCLS RR SEAL) 15548771 БОЛТ, CHILD ST TOP STRP BRKT (ЧАСТЬ OF 4) (M10X1.5X25) (8.913) 25767579 BRACKET, CHILD ST TOP STRP (INCLS 3, 5) not found ГАЙКА, CHILD ST TOP STRP BRKT (ЧАСТЬ OF 4) not found BEZEL, R/SEAT SHLDR BELT OPG (СМ. ГРУППУ 14.000 "ЗАДНИЕ РЕМНИ БЕЗОПАСНОСТИ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) teamcadillac.ru 10185925 RETAINER, R/WDO PNL TR (КРАСКА TO MATCH) (7.1 DIA, 33MM) (15.100) 25706781 RETAINER, CHILD ST TO STRP BRKT ACC HOLE CVR (ЧАСТЬ OF 2) 25725070 COVER, CHILD ST TOP STRP BRKT ACC HOLE (ЧАСТЬ OF 2) (EBONY) 89023835 COVER, CHILD ST TOP STRP BRKT ACC HOLE (ЧАСТЬ OF 2) (CASHMERE) (6D15-016) - 2008 DM69 МОЛДИНГИ БОКОВОГО ОКНА (10 SPEAKER AUDIO UQS) ↓ not found GRILLE, RDO RR SPKR (ЧАСТЬ OF 10) not found GRILLE, RDO RR SPKR (ЧАСТЬ OF 10) 15548771 БОЛТ, CHILD ST TOP STRP BRKT (ЧАСТЬ OF 4) (M10X1.5X25) (8.913) teamcadillac.ru 25767579 BRACKET, CHILD ST TOP STRP (INCLS 3, 5) not found ГАЙКА, CHILD ST TOP STRP BRKT (ЧАСТЬ OF 4) not found BEZEL, R/SEAT SHLDR BELT OPG (СМ. ГРУППУ 14.000 "ЗАДНИЕ РЕМНИ БЕЗОПАСНОСТИ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 10185925 RETAINER, R/WDO PNL TR (КРАСКА TO MATCH) (7.1 DIA, 33MM) (15.100) 25706781 RETAINER, CHILD ST TO STRP BRKT ACC HOLE CVR 25725070 COVER, CHILD ST TOP STRP BRKT ACC HOLE (EBONY) 89023835 COVER, CHILD ST TOP STRP BRKT ACC HOLE (CASHMERE) 25852031 TRIM, R/WDO PNL (INCLS 1, 2) (EBONY) (INCLS RR SEAL) [ОБШИВКА] 25979038 TRIM, R/WDO PNL (INCLS 1, 2) (EBONY) (INCLS RR SEAL) 25979039 TRIM, R/WDO PNL (INCLS 1, 2) (CASHMERE) (INCLS RR SEAL) 25979045 TRIM, R/WDO PNL (INCLS 1, 2) (CASHMERE) (INCLS RR SEAL) [ПАНЕЛЬ БАГАЖНОГО ОТДЕЛЕНИЯ] (6D15-018) - 2008 DM69 ЗАДНЕЕ СИДЕНЬЕ (SPLIT BACK AM9, EXC CENTER HEADREST A82) ↓ 15860394 CUSHION, R/SEAT BK (INCLS 2-7, 9, 11-16, 19-27) (EBONY) 15860395 CUSHION, R/SEAT BK (INCLS 2-7, 9, 11-16, 19-27) (TITANIUM) 15860396 CUSHION, R/SEAT BK (INCLS 2-7, 9, 11-16, 19-27) (CASHMERE) 15860398 CUSHION, R/SEAT BK (INCLS 2-7, 9, 11-16, 19-27) (EBONY) 15860399 CUSHION, R/SEAT BK (INCLS 2-7, 9, 11-16, 19-27) (TITANIUM) 15860400 CUSHION, R/SEAT BK (INCLS 2-7, 9, 11-16, 19-27) (EBONY) 15860401 CUSHION, R/SEAT BK (INCLS 2-7, 9, 11-16, 19-27) (TITANIUM) 15860402 CUSHION, R/SEAT BK (INCLS 2-7, 9, 11-16, 19-27) (CASHMERE) 25777067 PAD, R/SEAT BK CUSH (ЧАСТЬ OF 1) 25777362 PAD, R/SEAT BK SI CUSH (ЧАСТЬ OF 1) 25780733 РАМА, R/SEAT BK CUSH (ЧАСТЬ OF 1) 11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (ЧАСТЬ OF 1) 25780640 BEZEL, R/SEAT SHLDR BELT OPG (ЧАСТЬ OF 1) (CASHMERE) teamcadillac.ru 25780641 BEZEL, R/SEAT SHLDR BELT OPG (ЧАСТЬ OF 1) (TITANIUM) 25780642 BEZEL, R/SEAT SHLDR BELT OPG (ЧАСТЬ OF 1) (EBONY) 25780644 BEZEL, R/SEAT SHLDR BELT OPG (ЧАСТЬ OF 1) (CASHMERE) 25780645 BEZEL, R/SEAT SHLDR BELT OPG (ЧАСТЬ OF 1) (TITANIUM) 25780646 BEZEL, R/SEAT SHLDR BELT OPG (ЧАСТЬ OF 1) (EBONY) 11517068 NUT-METRIC HEX FLABGE, M6X1, 10MM SOCKET (ЧАСТЬ OF 1) 11508388 ГАЙКА, HEX W/CON WA, M6X1, 23.75 O.D., 5.55THK, 9, POR (R/SEAT) (8.915) 88952646 БОЛТ, R/SEAT (ЧАСТЬ OF 1) (11.628) 11515552 ГАЙКА, HEX W/CON WA, M10X1.5X13.5, 31.75 OD, 9, ZF (R/SEAT BK CUSH BRKT) 25780629 RESTRAINT, R/SEAT HD (ЧАСТЬ OF 1) (CASHMERE) 25780630 RESTRAINT, R/SEAT HD (ЧАСТЬ OF 1) (TITANIUM) 25780631 RESTRAINT, R/SEAT HD (ЧАСТЬ OF 1) (EBONY) 25780633 RESTRAINT, R/SEAT HD (ЧАСТЬ OF 1) (TITANIUM) 25780634 RESTRAINT, R/SEAT HD (ЧАСТЬ OF 1) (EBONY) 15216387 GUIDE, R/SEAT H/RST (ЧАСТЬ OF 1) (MOLDED IN BLACK) 25780736 PANEL, R/SEAT BK CUSH (ЧАСТЬ OF 1) 25780735 PANEL, R/SEAT BK CUSH (ЧАСТЬ OF 1) 25891461 STRAP, R/SEAT PULL (ЧАСТЬ OF 1) (TITANIUM) 25891462 STRAP, R/SEAT PULL (ЧАСТЬ OF 1) (EBONY) 25891463 STRAP, R/SEAT PULL (ЧАСТЬ OF 1) (CASHMERE) 25780738 LOCK, R/SEAT BK CUSH (ЧАСТЬ OF 1) 15898718 COVER, R/SEAT CUSH (ЧАСТЬ OF 28) (TITANIUM) 15898719 COVER, R/SEAT CUSH (ЧАСТЬ OF 28) (EBONY) 15898724 COVER, R/SEAT CUSH (ЧАСТЬ OF 28) (CASHMERE) 15898725 COVER, R/SEAT CUSH (ЧАСТЬ OF 28) (TITANIUM) 15898726 COVER, R/SEAT CUSH (ЧАСТЬ OF 28) (EBONY) [ЧЕХОЛ СИДЕНЬЯ (КОЖА)] 25777064 PAD, R/SEAT CUSH (ЧАСТЬ OF 28) 25778000 ARMREST, R/SEAT (ЧАСТЬ OF 1) (CASHMERE) 25778001 ARMREST, R/SEAT (ЧАСТЬ OF 1) (TITANIUM) 25778002 ARMREST, R/SEAT (ЧАСТЬ OF 1) (EBONY) 25780739 LINER, R/SEAT A/RST CUP HLDR (ЧАСТЬ OF 1) 11517068 NUT-METRIC HEX FLABGE, M6X1, 10MM SOCKET (ЧАСТЬ OF 1) 15898755 COVER, R/SEAT BK SI CUSH (ЧАСТЬ OF 1) (CASHMERE) 15898756 COVER, R/SEAT BK SI CUSH (ЧАСТЬ OF 1) (TITANIUM) 15898757 COVER, R/SEAT BK SI CUSH (ЧАСТЬ OF 1) (EBONY) 15898747 COVER, R/SEAT BK CUSH (ЧАСТЬ OF 1) (CASHMERE) 15898748 COVER, R/SEAT BK CUSH (ЧАСТЬ OF 1) (TITANIUM) 15898749 COVER, R/SEAT BK CUSH (ЧАСТЬ OF 1) (EBONY) 15898743 COVER, R/SEAT BK CUSH (ЧАСТЬ OF 1) (CASHMERE) 15898744 COVER, R/SEAT BK CUSH (ЧАСТЬ OF 1) (TITANIUM) 15898745 COVER, R/SEAT BK CUSH (ЧАСТЬ OF 1) (EBONY) 15898759 COVER, R/SEAT BK SI CUSH (ЧАСТЬ OF 1) (CASHMERE) 15898760 COVER, R/SEAT BK SI CUSH (ЧАСТЬ OF 1) (TITANIUM) 15898761 COVER, R/SEAT BK SI CUSH (ЧАСТЬ OF 1) (EBONY) 25777361 PAD, R/SEAT BK SI CUSH (ЧАСТЬ OF 1) 25777066 PAD, R/SEAT BK CUSH (ЧАСТЬ OF 1) 15860381 CUSHION, R/SEAT (INCLS 17, 18) (EBONY) 15860382 CUSHION, R/SEAT (INCLS 17, 18) (TITANIUM) 15860383 CUSHION, R/SEAT (INCLS 17, 18) (EBONY) 15860384 CUSHION, R/SEAT (INCLS 17, 18) (TITANIUM) 15860385 CUSHION, R/SEAT (INCLS 17, 18) (CASHMERE) (6D15-019) - 2008 DM69 ЗАДНЕЕ СИДЕНЬЕ (EXC SPLIT BACK AM9) ↓ 15860387 CUSHION, R/SEAT BK (INCLS 2-9, 14-17) (EBONY) 15860388 CUSHION, R/SEAT BK (INCLS 2-9, 14-17) (TITANIUM) 15860391 CUSHION, R/SEAT BK (INCLS 2-9, 14-17) (EBONY) 15860392 CUSHION, R/SEAT BK (INCLS 2-9, 14-17) (TITANIUM) 15860393 CUSHION, R/SEAT BK (INCLS 2-9, 14-17) (CASHMERE) 15860398 CUSHION, R/SEAT BK (INCLS 2-9, 14-17) (EBONY) 15860399 CUSHION, R/SEAT BK (INCLS 2-9, 14-17) (TITANIUM) 15860400 CUSHION, R/SEAT BK (INCLS 2-9, 14-17) (EBONY) 15860401 CUSHION, R/SEAT BK (INCLS 2-9, 14-17) (TITANIUM) 15860402 CUSHION, R/SEAT BK (INCLS 2-9, 14-17) (CASHMERE) 25777065 PAD, R/SEAT BK CUSH (ЧАСТЬ OF 1) 11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (ЧАСТЬ OF 1) 09419967 SCREW, 1/4-14X3/4 HWH TAP TYPE AB (ЧАСТЬ OF 1) 25777996 ARMREST, R/SEAT (ЧАСТЬ OF 1) (CASHMERE) 25777997 ARMREST, R/SEAT (ЧАСТЬ OF 1) (TITANIUM) 25777998 ARMREST, R/SEAT (ЧАСТЬ OF 1) (EBONY) 25778004 ARMREST, R/SEAT (ЧАСТЬ OF 1) (TITANIUM) 25778005 ARMREST, R/SEAT (ЧАСТЬ OF 1) (EBONY) 25780739 LINER, R/SEAT A/RST CUP HLDR (ЧАСТЬ OF 1) 25780640 BEZEL, R/SEAT SHLDR BELT OPG (ЧАСТЬ OF 1) (CASHMERE) 25780641 BEZEL, R/SEAT SHLDR BELT OPG (ЧАСТЬ OF 1) (TITANIUM) 25780642 BEZEL, R/SEAT SHLDR BELT OPG (ЧАСТЬ OF 1) (EBONY) 25780644 BEZEL, R/SEAT SHLDR BELT OPG (ЧАСТЬ OF 1) (CASHMERE) 25780645 BEZEL, R/SEAT SHLDR BELT OPG (ЧАСТЬ OF 1) (TITANIUM) 25780646 BEZEL, R/SEAT SHLDR BELT OPG (ЧАСТЬ OF 1) (EBONY) 11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (ЧАСТЬ OF 1) 11517068 NUT-METRIC HEX FLABGE, M6X1, 10MM SOCKET (ЧАСТЬ OF 1) 11508388 ГАЙКА, HEX W/CON WA, M6X1, 23.75 O.D., 5.55THK, 9, POR (R/SEAT) (8.915) 25777064 PAD, R/SEAT CUSH (ЧАСТЬ OF 18) teamcadillac.ru 15898718 COVER, R/SEAT CUSH (ЧАСТЬ OF 18) (TITANIUM) 15898719 COVER, R/SEAT CUSH (ЧАСТЬ OF 18) (EBONY) 15898724 COVER, R/SEAT CUSH (ЧАСТЬ OF 18) (CASHMERE) 15898725 COVER, R/SEAT CUSH (ЧАСТЬ OF 18) (TITANIUM) 15898726 COVER, R/SEAT CUSH (ЧАСТЬ OF 18) (EBONY) [ЧЕХОЛ СИДЕНЬЯ (КОЖА)] 11515552 ГАЙКА, HEX W/CON WA, M10X1.5X13.5, 31.75 OD, 9, ZF (R/SEAT BK CUSH BRKT) 25780732 РАМА, R/SEAT BK CUSH (ЧАСТЬ OF 1) 15216387 GUIDE, R/SEAT H/RST (ЧАСТЬ OF 1) (MOLDED IN BLACK) 25780629 RESTRAINT, R/SEAT HD (ЧАСТЬ OF 1) (CASHMERE) 25780630 RESTRAINT, R/SEAT HD (ЧАСТЬ OF 1) (TITANIUM) 25780631 RESTRAINT, R/SEAT HD (ЧАСТЬ OF 1) (EBONY) 25780633 RESTRAINT, R/SEAT HD (ЧАСТЬ OF 1) (TITANIUM) 25780634 RESTRAINT, R/SEAT HD (ЧАСТЬ OF 1) (EBONY) 15898736 COVER, R/SEAT BK CUSH (ЧАСТЬ OF 1) (TITANIUM) 15898737 COVER, R/SEAT BK CUSH (ЧАСТЬ OF 1) (EBONY) 15898739 COVER, R/SEAT BK CUSH (ЧАСТЬ OF 1) (CASHMERE) 15898740 COVER, R/SEAT BK CUSH (ЧАСТЬ OF 1) (TITANIUM) 15898741 COVER, R/SEAT BK CUSH (ЧАСТЬ OF 1) (EBONY) 15860381 CUSHION, R/SEAT (INCLS 11, 12) (EBONY) 15860382 CUSHION, R/SEAT (INCLS 11, 12) (TITANIUM) 15860383 CUSHION, R/SEAT (INCLS 11, 12) (EBONY) 15860384 CUSHION, R/SEAT (INCLS 11, 12) (TITANIUM) 15860385 CUSHION, R/SEAT (INCLS 11, 12) (CASHMERE) (6D15-020) - 2008 DM69 ЗАДНЕЕ СИДЕНЬЕ (SPLIT BACK AM9, CENTER HEADREST A82) ↓ 15860398 CUSHION, R/SEAT BK (INCLS 2-7, 9, 11-16, 19-28) (EBONY) 15860399 CUSHION, R/SEAT BK (INCLS 2-7, 9, 11-16, 19-28) (TITANIUM) 15860400 CUSHION, R/SEAT BK (INCLS 2-7, 9, 11-16, 19-28) (EBONY) 15860401 CUSHION, R/SEAT BK (INCLS 2-7, 9, 11-16, 19-28) (TITANIUM) 15860402 CUSHION, R/SEAT BK (INCLS 2-7, 9, 11-16, 19-28) (CASHMERE) 25777067 PAD, R/SEAT BK CUSH (ЧАСТЬ OF 1) 25777362 PAD, R/SEAT BK SI CUSH (ЧАСТЬ OF 1) 25780733 РАМА, R/SEAT BK CUSH (ЧАСТЬ OF 1) 11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (ЧАСТЬ OF 1) 25780640 BEZEL, R/SEAT SHLDR BELT OPG (ЧАСТЬ OF 1) (CASHMERE) 25780641 BEZEL, R/SEAT SHLDR BELT OPG (ЧАСТЬ OF 1) (TITANIUM) 25780642 BEZEL, R/SEAT SHLDR BELT OPG (ЧАСТЬ OF 1) (EBONY) 25780644 BEZEL, R/SEAT SHLDR BELT OPG (ЧАСТЬ OF 1) (CASHMERE) 25780645 BEZEL, R/SEAT SHLDR BELT OPG (ЧАСТЬ OF 1) (TITANIUM) 25780646 BEZEL, R/SEAT SHLDR BELT OPG (ЧАСТЬ OF 1) (EBONY) teamcadillac.ru 11517068 NUT-METRIC HEX FLABGE, M6X1, 10MM SOCKET (ЧАСТЬ OF 1) 11508388 ГАЙКА, HEX W/CON WA, M6X1, 23.75 O.D., 5.55THK, 9, POR (R/SEAT) (8.915) 88952646 БОЛТ, R/SEAT (ЧАСТЬ OF 1) (11.628) 11515552 ГАЙКА, HEX W/CON WA, M10X1.5X13.5, 31.75 OD, 9, ZF (R/SEAT BK CUSH BRKT) 25780629 RESTRAINT, R/SEAT HD (ЧАСТЬ OF 1) (CASHMERE) 25780630 RESTRAINT, R/SEAT HD (ЧАСТЬ OF 1) (TITANIUM) 25780631 RESTRAINT, R/SEAT HD (ЧАСТЬ OF 1) (EBONY) 25780633 RESTRAINT, R/SEAT HD (ЧАСТЬ OF 1) (TITANIUM) 25780634 RESTRAINT, R/SEAT HD (ЧАСТЬ OF 1) (EBONY) 15216387 GUIDE, R/SEAT H/RST (ЧАСТЬ OF 1) (MOLDED IN BLACK) 25805473 PANEL, R/SEAT BK CUSH (ЧАСТЬ OF 1) 25780734 PANEL, R/SEAT BK CUSH (ЧАСТЬ OF 1) 25891461 STRAP, R/SEAT PULL (ЧАСТЬ OF 1) (TITANIUM) 25891462 STRAP, R/SEAT PULL (ЧАСТЬ OF 1) (EBONY) 25891463 STRAP, R/SEAT PULL (ЧАСТЬ OF 1) (CASHMERE) 25780738 LOCK, R/SEAT BK CUSH (ЧАСТЬ OF 1) 15898718 COVER, R/SEAT CUSH (ЧАСТЬ OF 29) (TITANIUM) 15898719 COVER, R/SEAT CUSH (ЧАСТЬ OF 29) (EBONY) 15898724 COVER, R/SEAT CUSH (ЧАСТЬ OF 29) (CASHMERE) 15898725 COVER, R/SEAT CUSH (ЧАСТЬ OF 29) (TITANIUM) 15898726 COVER, R/SEAT CUSH (ЧАСТЬ OF 29) (EBONY) [ЧЕХОЛ СИДЕНЬЯ (КОЖА)] 25777064 PAD, R/SEAT CUSH (ЧАСТЬ OF 29) 25778000 ARMREST, R/SEAT (ЧАСТЬ OF 1) (CASHMERE) 25778001 ARMREST, R/SEAT (ЧАСТЬ OF 1) (TITANIUM) 25778002 ARMREST, R/SEAT (ЧАСТЬ OF 1) (EBONY) 25813209 ARMREST, R/SEAT (ЧАСТЬ OF 1) (EBONY) 25813210 ARMREST, R/SEAT (ЧАСТЬ OF 1) (TITANIUM) 25780739 LINER, R/SEAT A/RST CUP HLDR (ЧАСТЬ OF 1) 11517068 NUT-METRIC HEX FLABGE, M6X1, 10MM SOCKET (ЧАСТЬ OF 1) 25780636 RESTRAINT, R/SEAT CTR HD (ЧАСТЬ OF 1) (CASHMERE) 25780637 RESTRAINT, R/SEAT CTR HD (ЧАСТЬ OF 1) (TITANIUM) 25780638 RESTRAINT, R/SEAT CTR HD (ЧАСТЬ OF 1) (EBONY) 25813212 RESTRAINT, R/SEAT CTR HD (ЧАСТЬ OF 1) (EBONY) 25813213 RESTRAINT, R/SEAT CTR HD (ЧАСТЬ OF 1) (TITANIUM) 15898755 COVER, R/SEAT BK SI CUSH (ЧАСТЬ OF 1) (CASHMERE) 15898756 COVER, R/SEAT BK SI CUSH (ЧАСТЬ OF 1) (TITANIUM) 15898757 COVER, R/SEAT BK SI CUSH (ЧАСТЬ OF 1) (EBONY) 25812894 COVER, R/SEAT BK SI CUSH (ЧАСТЬ OF 1) (EBONY) 25812895 COVER, R/SEAT BK SI CUSH (ЧАСТЬ OF 1) (TITANIUM) 15898747 COVER, R/SEAT BK CUSH (ЧАСТЬ OF 1) (CASHMERE) 15898748 COVER, R/SEAT BK CUSH (ЧАСТЬ OF 1) (TITANIUM) 15898749 COVER, R/SEAT BK CUSH (ЧАСТЬ OF 1) (EBONY) 25812890 COVER, R/SEAT BK CUSH (ЧАСТЬ OF 1) (EBONY) 25812891 COVER, R/SEAT BK CUSH (ЧАСТЬ OF 1) (TITANIUM) 15898743 COVER, R/SEAT BK CUSH (ЧАСТЬ OF 1) (CASHMERE) 15898744 COVER, R/SEAT BK CUSH (ЧАСТЬ OF 1) (TITANIUM) 15898745 COVER, R/SEAT BK CUSH (ЧАСТЬ OF 1) (EBONY) 15898751 COVER, R/SEAT BK CUSH (ЧАСТЬ OF 1) (CASHMERE) 15898752 COVER, R/SEAT BK CUSH (ЧАСТЬ OF 1) (TITANIUM) 15898753 COVER, R/SEAT BK CUSH (ЧАСТЬ OF 1) (EBONY) 25812887 COVER, R/SEAT BK CUSH (ЧАСТЬ OF 1) (EBONY) 25812888 COVER, R/SEAT BK CUSH (ЧАСТЬ OF 1) (TITANIUM) 15898759 COVER, R/SEAT BK SI CUSH (ЧАСТЬ OF 1) (CASHMERE) 15898760 COVER, R/SEAT BK SI CUSH (ЧАСТЬ OF 1) (TITANIUM) 15898761 COVER, R/SEAT BK SI CUSH (ЧАСТЬ OF 1) (EBONY) 25812896 COVER, R/SEAT BK SI CUSH (ЧАСТЬ OF 1) (EBONY) 25812897 COVER, R/SEAT BK SI CUSH (ЧАСТЬ OF 1) (TITANIUM) 25777361 PAD, R/SEAT BK SI CUSH (ЧАСТЬ OF 1) 25777068 PAD, R/SEAT BK CUSH (ЧАСТЬ OF 1) 15860381 CUSHION, R/SEAT (INCLS 17, 18) (EBONY) 15860382 CUSHION, R/SEAT (INCLS 17, 18) (TITANIUM) 15860383 CUSHION, R/SEAT (INCLS 17, 18) (EBONY) 15860384 CUSHION, R/SEAT (INCLS 17, 18) (TITANIUM) 15860385 CUSHION, R/SEAT (INCLS 17, 18) (CASHMERE) (6D15-022) - 2008 DM69 ПОКРЫТИЕ ПОЛА ↓ 25869652 ПОКРЫТИЕ, R/FLR PNL (EBONY) 25869653 ПОКРЫТИЕ, R/FLR PNL (CASHMERE) 25819986 MAT PKG, FRONT & ЗАДНИЙ ПОКРЫТИЕ (CASHMERE) (15.286) [КОМПЛЕКТ КОВРИКОВ САЛОНА (70Х45СМ-1 ШТ. 70Х50СМ-1 ШТ. 45Х40-2ШТ.)] 25883515 MAT PKG, FRONT & ЗАДНИЙ ПОКРЫТИЕ (EBONY) (15.286) 25912371 MAT PKG, FRONT & ЗАДНИЙ ПОКРЫТИЕ (EBONY) (15.286) 25912372 MAT PKG, FRONT & ЗАДНИЙ ПОКРЫТИЕ (CASHMERE) 25912372 MAT PKG, FRONT & ЗАДНИЙ ПОКРЫТИЕ (CASHMERE) 25912372 MAT PKG, FRONT & ЗАДНИЙ ПОКРЫТИЕ (CASHMERE) (15.286) 25869640 ПОКРЫТИЕ, F/FLR PNL (EBONY) 25869640 ПОКРЫТИЕ, F/FLR PNL (EBONY) teamcadillac.ru 25869641 ПОКРЫТИЕ, F/FLR PNL (CASHMERE) 25869641 ПОКРЫТИЕ, F/FLR PNL (CASHMERE) 25869649 ПОКРЫТИЕ, F/FLR PNL (EBONY) 25869650 ПОКРЫТИЕ, F/FLR PNL (CASHMERE) 25869643 ПОКРЫТИЕ, F/FLR PNL (EBONY) 25869643 ПОКРЫТИЕ, F/FLR PNL (EBONY) 25869644 ПОКРЫТИЕ, F/FLR PNL (CASHMERE) 25869644 ПОКРЫТИЕ, F/FLR PNL (CASHMERE) 25869646 ПОКРЫТИЕ, F/FLR PNL (EBONY) 25869647 ПОКРЫТИЕ, F/FLR PNL (CASHMERE) (6D15-024) - 2008 DM69 ДЕТАЛИ ЗАДНЕЙ ОБЛИЦОВКИ ↓ 20790704 TRIM, R/CMPT LID INR PNL (DIAMOND) 10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (R/CMPT LID INR PNL TR) [ПИСТОН КРЕПЛЕНИЯ ОБЛИЦОВКИ БАМПЕРА (NYLON)] 25854615 TRIM, R/CMPT (DIAMOND) [ОБШИВКА] 20064875 RETAINER, PUSH-IN, 20.5MMLG, 42.76MM 1.68HD DIA, PLASTIC (R/CMPT SI TR) [КЛИПСА ШУМОИЗОЛЯЦИИ КАПОТА] 25923845 TRIM, R/CMPT SI (INCLS 11, 23) (DIAMOND) [ВНУТРЕННЯЯ ПАНЕЛЬ БАГАЖНОГО ОТСЕКА] teamcadillac.ru 25877931 BRACKET, R/CMPT SI CPT SUPT 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (R/CMPT SI TR PNL) [ГАЙКА М6] 10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (R/CMPT TR) [ПИСТОН КРЕПЛЕНИЯ ОБЛИЦОВКИ БАМПЕРА (NYLON)] 22600404 RETAINER, R/CMPT SI TR (GRAPHITE) [ФИКСАТОР ПАНЕЛИ БАГАЖНОГО ОТСЕКА] 10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (R/CMPT SI TR) [ПИСТОН КРЕПЛЕНИЯ ОБЛИЦОВКИ БАМПЕРА (NYLON)] not found DOOR, R/CMPT STOW TRAY (ЧАСТЬ OF 5) 25948644 NET, CONVENIENCE (BLACK) [ОГРАНИЧИТЕЛЬНАЯ СЕТКА БАГАЖНОГО ОТСЕКА] 11588650 CLIP, 12X14X16.6, GM4345M (ЧАСТЬ OF 16) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА] 25764204 HOOK, CARGO TIE DN (W/STRAIGHT BRKT) [КРОНШТЕЙН КРЕПЕЖНЫЙ] 11609257 БОЛТ, PAN HD, TORX, M12X1.75X34, 9.8 STEEL, GMW3179 (CARGO TIE DN HOOK) (8.907) [БОЛТ] 25938184 PLATE, R/CMPT SILL TR (INCLS 13) (EBONY) 15861472 BEZEL, CARGO TIE DN LOOP (EBONY) 25913683 TRIM, R/CMPT FLR PNL & R/END PNL (DIAMOND) 25890309 TRIM, R/CMPT SI (DIAMOND) [ОБШИВКА ДВЕРИ БАГАЖНИКА] 25926913 BRACKET, R/CMPT SI CPT SUPT 25691080 RETAINER, CONVENIENCE NET [ПИСТОН КРЕПЛЕНИЯ ОБИВКИ] 25819438 BAG, CONVENIENCE/CARGO NET STOW [НИША БАГАЖНОГО ОТДЕЛЕНИЯ] 25816726 LABEL, FUSE BLK (ЧАСТЬ OF 5) (8.808) 25816726 LABEL, FUSE BLK (ЧАСТЬ OF 5) 18 - ЗАПЧАСТИ - ЖИДКОСТИ - ЕМКОСТИ И ОБЪЕМЫ - НОВЫЕ ДЕТАЛИ - ЭЛЕКТРИЧЕСКИЕ СОЕДИНЕНИЯ (OTOU-087) - 2008-2009 D ОБЫЧНОЕ ОБСЛУЖИВАНИЕ ЗАПАСНЫЕ ЧАСТИ (LLT/3.6V)(220 CID) ↓ teamcadillac.ru 12597464 СВЕЧИ, (DO NOT CHANGE СВЕЧИ GAP) (ACDelco #41-990) (PLATINUM PLUG) [СВЕЧА ЗАЖИГАНИЯ] 15875795 ELEMENT, КОНДИЦИОНЕРL (ACDelco #A3096C) [ВОЗДУШНЫЙ ФИЛЬТР ДВИГАТЕЛЯ] 19114105 ФИЛЬТР, МАСЛЯНЫЙ (ACDelco #PF2129F) (DURAPACK) (BULK PKG, QTY 12) 25177917 ФИЛЬТР, МАСЛЯНЫЙ (ACDelco #PF2129) [МАСЛЯНЫЙ ФИЛЬТР ДВИГАТЕЛЯ] not found LABEL, FUEL FEED PIPE WRNG not found ФИЛЬТР, A/TRNS FLUID 24225800 GASKET, A/TRNS FLUID PAN (ACDelco #24225800) [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] (OTOU-087) - 2008-2009 D ОБЫЧНОЕ ОБСЛУЖИВАНИЕ ЗАПАСНЫЕ ЧАСТИ (LY7/3.6-7)(220 CID) ↓ 12597464 СВЕЧИ, (DO NOT CHANGE СВЕЧИ GAP) (ACDelco #41-990) (PLATINUM PLUG) [СВЕЧА ЗАЖИГАНИЯ] teamcadillac.ru 15875795 ELEMENT, КОНДИЦИОНЕРL (ACDelco #A3096C) [ВОЗДУШНЫЙ ФИЛЬТР ДВИГАТЕЛЯ] 19114105 ФИЛЬТР, МАСЛЯНЫЙ (ACDelco #PF2129F) (DURAPACK) (BULK PKG, QTY 12) 25177917 ФИЛЬТР, МАСЛЯНЫЙ (ACDelco #PF2129) [МАСЛЯНЫЙ ФИЛЬТР ДВИГАТЕЛЯ] not found LABEL, FUEL FEED PIPE WRNG 24225800 GASKET, A/TRNS FLUID PAN (ACDelco #24225800) [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] (OTOU-087) - 2008-2009 D69 ОБЫЧНОЕ ОБСЛУЖИВАНИЕ ЗАПАСНЫЕ ЧАСТИ (LP1/2.8T)(173 CID) ↓ 12597464 СВЕЧИ, (DO NOT CHANGE СВЕЧИ GAP) (ACDelco #41-990) (PLATINUM PLUG) [СВЕЧА ЗАЖИГАНИЯ] teamcadillac.ru 15875795 ELEMENT, КОНДИЦИОНЕРL (ACDelco #A3096C) [ВОЗДУШНЫЙ ФИЛЬТР ДВИГАТЕЛЯ] 19114105 ФИЛЬТР, МАСЛЯНЫЙ (ACDelco #PF2129F) (DURAPACK) (BULK PKG, QTY 12) 25177917 ФИЛЬТР, МАСЛЯНЫЙ (ACDelco #PF2129) [МАСЛЯНЫЙ ФИЛЬТР ДВИГАТЕЛЯ] not found LABEL, FUEL FEED PIPE WRNG not found ФИЛЬТР, A/TRNS FLUID 24225800 GASKET, A/TRNS FLUID PAN (ACDelco #24225800) [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 21 - АКСЕССУАРЫ (6D21-002) - 2008 DM69 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК PKG ↓ 19154508 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК PKG, (BLACK) (INSTALL .10) (0.25KGS) (POLYESTER) (W/WHITE CADILLAC SCRIPT) [СОЛНЦЕЗАЩИТНАЯ ШТОРА] 19154509 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК PKG, R/WDO (BLACK) (INSTALL .10) (0.21KGS) (POLYESTER) (W/WHITE CADILLAC SCRIPT LOGO) [СОЛНЦЕЗАЩИТНАЯ ШТОРА] (6D21-003) - 2008-2010 DM69 СПОЙЛЕР ЗАДНИЙ COMPARTMENT LID ↓ 19157098 SPOILER PKG, R/END (CLARET) (INSTALL .70) (2.26KGS) (WING) (12.181) teamcadillac.ru 19157099 SPOILER PKG, R/END (BLACK) (INSTALL .70) (2.26KGS) (WING) (12.181) 19157100 SPOILER PKG, R/END (SILVER) (INSTALL .70) (2.26KGS) (WING) (12.181) 19157101 SPOILER PKG, R/END (DIAMOND) (INSTALL .70) (2.26KGS) (WING) (12.181) 19243022 SPOILER PKG, R/END (BRAHMA) (INSTALL.70) (2.26 KGS) (WING) (12.181) (6D21-014) - 2008-2010 DM69 PERFORMANCE PKG/MUFFLER PKG ↓ 19165537 MUFFLER PKG, EXH (INSTALL 1.0) (26.6KGS) (INCLS ТРУБКИ W/RESONATORS, MID-ТРУБКИ, MUFFLERS W/TIPS & CЛАМПАS) (3.701) (6D21-019) - 2008-2010 DM69 MAT PKG/ЗАДНИЙ PREMIUM (ALL WEATHER) ↓ 19159598 MAT PKG, R/FLR (EBONY) (2.40KGS) (ALL WEATHER) (TWIN) (W/O LOGO) (VERTICLE RIBS) (15.286) [КОМПЛЕКТ КОВРИКОВ САЛОНА (2ШТ)] (6D21-020) - 2008-2010 DM69 КОЛЕСО CAP PKG (CHROME) ↓ 17800014 CAP, HUB (INSTALL .10) (SINGLE 0.03KGS) (W/WREATH & CREST EMBLEM) (18") (4 PC QTY OF 9594376) (5.858) [КОЛПАК СТУПИЦЫ КОЛЕСА] teamcadillac.ru 17800015 CAP, HUB (POLISHED) (INSTALL .10) (SINGLE 0.03KGS) (18") (80 PC QTY OF 9594376) (5.858) (6D21-021) - 2008-2010 DM69 КОЛЕСО CAP PKG (COLORED) ↓ 19165750 CAP, HUB (INSTALL .10) (SINGLE .03KGS) (MULTI-COLORED CREST EMBLEM) (4 PC QTY OF 9596984) (5.858) [КОЛПАК] 19165751 CAP, HUB (INSTALL .10) (SINGLE .03KGS) (MULTI-COLORED CREST EMBLEM) (80 PC QTY OF 9596984) (5.858) (6D21-022) - 2008-2010 DM69 КОЛЕСО PKG ↓ 17802925 КОЛЕСО, PKG (18 X 8) (CHROME) (INSTALL .30) (SINGLE 11.4KGS) (FORGED AL) (INCLS 1 WHL 19132598 & TAG) (5.803) teamcadillac.ru 17802926 КОЛЕСО, PKG (18 X 8) (CHROME) (INSTALL .30) (SINGLE 11.4KGS) (FORGED AL) (4 PC QTY 19132598) (5.803) [ДИСК КОЛЕСНЫЙ] 17802927 КОЛЕСО, PKG (18 X 8) (CHROME) (INSTALL .30) (SINGLE 11.4KGS) (FORGED AL) (16 PC QTY OF 19132598) (5.803) (6D21-023) - 2008-2010 DM69 ЗАЩИТА PKG/SPLASH (MOLDED) ↓ 17802089 ЗАЩИТА PKG, SPH (MOLDED) (BLACK) (INSTALL .50) (0.39KGS) (FRT) (NO LOGO) (8.214) [БРЫЗГОВИК] 17802090 ЗАЩИТА PKG, SPH (MOLDED) (BLACK) (INSTALL .50) (0.37KGS) (RR) (W/CTS LOGO) (8.214) [БРЫЗГОВИК] (6D21-024) - 2008-2010 D69 TRAY PKG/ЗАДНИЙ COMPARTMENT ПОЛ STORAGE ↓ 19169574 TRAY PKG, R/CMPT FLR STOW COMPT (BLACK) (1.5 KGS) (W/CADILLAC CREST & WREATH LOGO) (15.222) [ПОДДОН БАГАЖНИКА] (6D21-026) - 2008-2009 DM ЛАМПА PKG/FOOTWELL LUMINESCENT (W/O HARNESS) ↓ teamcadillac.ru 19170639 ЛАМПА PKG, FOOTWELL LUMINESCENT (INSTALL .50) (0.02 KGS) (W/O HARNESS) (11.927) (6D21-027) - 2008-2009 DM ЛАМПА PKG/FOOTWELL LUMINESCENT (W/HARNESS) ↓ 19170640 ЛАМПА PKG, FOOTWELL LUMINESCENT (INSTALL .50) (0.09 KGS) (W/HARNESS) (11.927) (6D21-028) - 2008-2010 DM69 ЛАМПА PKG/CENTER HIGH MOUNT STOP & TAIL ↓ 19170354 ЛАМПА, TAIL (2.679) (SERV CMP OF LMP PKG 19211989) 19170355 ЛАМПА, TAIL (2.679) (SERV CMP OF LMP PKG 19211989) 19170356 ЛАМПА, HIGH MT STOP (2.679) (SERV CMP OF LMP PKG 19211989) 19211989 ЛАМПА KIT, TAIL (INSTALL 1.5) (03.50 KGS) (CLEAR) (2.679) teamcadillac.ru 20907590 ЛАМПА, TAIL (2.679) (SERV CMP OF LMP PKG 20907589) 20907591 ЛАМПА, TAIL (2.679) (SERV CMP OF LMP PKG 20907589) (6D21-029) - 2008-2010 DM69 PROTECTOR PKG/КАПОТ ↓ teamcadillac.ru 19172121 PROTECTOR PKG, КАПОТ (CLEAR) (INSTALL .30) (.08 KGS) (URETHANE FILM) (8.010) (AC21-013) - 2008-2009 D LOCK PKG/CAR COVER CABLE ↓ teamcadillac.ru 12344218 LOCK PKG, CAR CVR CBL (0.2 KGS) (13.347) (AC21-476) - 2008-2010 D АВАРИЙНЫЙ PKG ↓ 12497328 ROADSIDE PKG, ACSRY MISC (INCLS PONCHO, GLOVES, BANNER, FLASHLIGHT, FUSE KIT, BUNGEE CORD, ELEC TAPE, PLIERS, RAG, SCREWDRIVER, BOOSTER ПРОВОДА, AND КОМПЛЕКТ ПЕРВОЙ ПОМОЩИ KIT) (2.28KGS) (W/GM ACSRY LOGO) (AC21-548) - 2008-2010 D ROADSIDE ASSISTANCE PKG/ROLL-UP ↓ teamcadillac.ru 88960625 ROADSIDE PKG, ACSRY MISC (1.26KGS) (ROLL-UP) (8.808) 12498311 ROADSIDE PKG, ACSRY MISC (360 PC QTY OF 88960625) (8.808) (AC21-559) - 2008-2010 D ДЕРЖАТЕЛЬ PKG/СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК CD ↓ not found ДЕРЖАТЕЛЬ PKG, S/S CD STOW 12495014 ДЕРЖАТЕЛЬ PKG, S/S CD STOW (0.12 KGS) (HOLDS 12 CD) (MOUNTED TO SUN VISOR) (10.203) [ДЕРЖАТЕЛЬ КОМПАКТ-ДИСКОВ ПЛАСТИКОВЫЙ] (AC21-560) - 2008-2010 D69 LOCK PKG/КОЛЕСО ↓ 17801711 LOCK & NUT PKG, WHL (CHROME) (INSTALL .10) (0.29 KGS) (INCLS 20 NUTS, 4 LOCKS, 1 KEY) (M14X1.5) (5.813) [КОМПЛЕКТ ГАЕК М14 (4 ШТ.)] 19212925 ГАЙКА, WHL (SERV CMP OF NUT PKG'S) (5.813) (AC21-671) - 2008-2010 D КОМПЛЕКТ ПЕРВОЙ ПОМОЩИ PKG ↓ teamcadillac.ru 12498312 MEDICAL PKG, 1ST AID (360 PC QTY OF 88960626) (8.808) 88960626 MEDICAL PKG, 1ST AID (BLACK) (0.19KGS) (WHITE GM BLOCK LOGO) (VINYL) (8.808) (AC21-716) - 2008 DM69 COVER PKG/ДВИГАТЕЛЬ SHIELD ↓ teamcadillac.ru 12499960 SHIELD PKG, ДВИГАТЕЛЬ APPEARANCE (INSTALL .20) (1.6KGS) (INCLS CVR & CAP) (0.029) (AC21-783) - 2008-2009 D ORGANIZER PKG/CARGO ↓ 12498559 ЧАСТЬITION, CARGO (GRAY) (INSTALL .10) (7.52KGS) (W/GM BLK LOGO) (W/COLLAPS WALLS & DIV) (NON-SKID MAT) (41X18X10") (17.090) (AC21-784) - 2008-2010 DM69 MAT PKG/FRONT ПОЛ VINYL (NON-PRODUCTION) ↓ 17802978 MAT PKG, F/FLR (EBONY) (4.81KGS) (ALL WEATHER) (TWIN) (W/EBONY CTS LOGO) (VERTICLE RIBS) (15.286) [КОМПЛЕКТ ПЕРЕДНИХ КОВРИКОВ САЛОНА (2ШТ)] teamcadillac.ru 19159597 MAT PKG, F/FLR (EBONY) (4.50KGS) (ALL WEATHER) (TWIN) (W/EBONY CTS LOGO) (VERTICAL RIBS) (15.286) [КОМПЛЕКТ КОВРИКОВ САЛОНА (2ШТ)] (AC21-824) - 2008-2010 DM69 ACCESSORY PKG/ШИНА (18 INCH) ↓ teamcadillac.ru 19163349 ШИНА, P235/50ZR18 N AL3 TL BW (INSTALL .25) (SINGLE 12.5KGS) (MICHELIN, PILOT HX MXM4, P235/50R18, ORBL97V) (5.880) (ACDelco #M04049) (AC21-952) - 2008-2010 D АВАРИЙНЫЙ ЗНАК PKG (CU8) ↓ not found АВАРИЙНЫЙ ЗНАК PKG, (INTERNATIONAL) teamcadillac.ru 19201300 АВАРИЙНЫЙ ЗНАК PKG, (INTERNATIONAL) (1.60KGS) (2.575) [ДОРОЖНЫЙ ЗНАК - ТРЕУГОЛЬНИК] not found АВАРИЙНЫЙ ЗНАК PKG, BULK (INTERNATIONAL) 19201301 АВАРИЙНЫЙ ЗНАК PKG, BULK (INTERNATIONAL) (2.575) (GM21-023) - 2008-2010 DM69 ACCESSORY PKG/ШИНА PRESSURE INDICATOR SENSOR ↓ 19155710 SENSOR PKG, ШИНА PRESS IND (INSTALL .10) (SINGLE 0.03KGS) (CЛАМПА-IN) (16 PC QTY OF 15268606) (5.890) [ДАТЧИК ДАВЛЕНИЯ ШИНЫ КОЛЕСА] (GM21-024) - 2008-2010 DM69 ACCESSORY PKG/ШИНА PRESSURE INDICATOR SENSOR NUT ↓ teamcadillac.ru 17800699 NUT PKG, ШИНА PRESS IND SEN (INSTALL .10) (SINGLE 0.0013 KGS) (16 PC QTY OF 15234846) (5.890) [ГАЙКА М12] (GM21-032) - 2008 DM69 ПЕПЕЛЬНИЦА PKG (BIN STYLE) ↓ 15244115 ПЕПЕЛЬНИЦА PKG, (BLACK) (INSTALL .40) (.235 KGS) (BIN TYPE) (FRT & RR) (PLASTIC) (12.009) [ПЕПЕЛЬНИЦА]
  2. Это как оказалось норма для GM, поголовно у всех моделей Шевроле, Опель, Кадиллак рано или поздно проявляется такая проблема, не знаю от чего зависит и как предотвратить, но пока я гуглил, нашел очень много историй таких же как эта, а начинается она безобидно, машина перестает видеть брелок из окна всего навсего 3 этажа и это за городом где никаких помех нет, лечится заменой батарейки в брелке, этого хватает на неделю и потом опять тишина, потом ненавязчиво пропадают датчки давления колес, то один то другой, но потом появляются и вроде все ОК, а потом как-то раз через раз, через двас, брелок работает уже только у двери и датчики редко радуют вменяемыми показаниями))) не спешите выкидывать брелок и менять датчики, оно все целое и рабочее проблема в маленьком приемнике, который стоит на стекле за зеркалом заднего вида! Номер данной деталюшки для Европейцев — 13503204 Номер данной деталюшки для Амеров — 13503205 Собна заморочился я этой проблемой зимой в -30, т.к. без автозапуска тяжеловато живется загородом))) в адовые минуса гоняли на теплый паркинг отогревать аккум) Сохранить в Альбом ну и помыться Поехал я к клубному парнеру Service-GM, @REMUS, и о чудо сканер нашел ошибки по этой хреновине и после ребята нашли в мануалах что если есть такие проблемы как у меня, надо менять этот блок, не понимаю почему recall не было раз такая частая батва и явно пользователь тут не виноват! Сохранить в Альбом Сохранить в Альбом Сохранить в Альбом Брелок по мануалу должен работать на 360* расстояние не менее 40 метров! Если работает в 2-3 метрах это уже начало болезни! Дали мне номерочек, да не подумали, и купил я амер приемник, епрст, еклмн, опрст! Сохранить в Альбом 315мгц, новый не бит не крашен фак)))) благо не очень дорого))) Как всегда, уже по традиции выручили в шеви+ красная сосна/люберцы Саша @app90 нашел мне данный приемник на складе в люберах всего за 700 рублей, что дешевле разборов на авито! от круза 14 года, там тоже датчики есть)) и я полетел, офигел от размера филлиала люберцы и забрав датчик рванул домой! После установки на выключенном зажигании и открытой водительской двери, завел машину, ничего не изменилось, подумав что датчики спят, поехал сделать кружок и о чудо появилось 3 датчика из 4, а еще через час поехав в кино, проснулся и 4-ый, брелок теперь снова работает из окна и не надо бегать за ним чтобы забрать что-то из второй машины! Урааа победа! Еще заметил вот что, сверху ЕВРО приемник с жиденькой дорожкой антенной, внизу АМЕР брелок с вот этой мандулой буквально! Надо бы потестить эту пружинку в евро варианте!
  3. 00 - 6-ТИ ЦИЛИНДРОВЫЙ ДВИГАТЕЛЬ (6D00-019) - 2008 DM69 ДВИГАТЕЛЬ В СБОРЕ & ЧАСТЬIAL ДВИГАТЕЛЬ (LP1/2.8T) ↓ teamcadillac.ru not found ДВИГАТЕЛЬ, 2.8 L (173 CID) (PRODUCTION) 12617612 ДВИГАТЕЛЬ, GASOLINE (GOODWRENCH NEW) (SERVICE) [ДВИГАТЕЛЬ БЕНЗИН, 6 ЦИЛ., 2.8Л, 210Л.С.] (6D00-029) - 2008-2010 DM69 СЦЕПЛЕНИЕ (MV7) ↓ not found PIN, TRANS LOC 12597210 PIN, TRANS LOC 12575412 FLYКОЛЕСО, ENG 12575412 FLYКОЛЕСО, ENG 12575412 FLYКОЛЕСО, ENG 11588884 БОЛТ, HEX SOC HD, M10X1X24, 21 THD, 15.9 OD, 10.9, GMW3179G, HDR PT (FLYWHL) [КРЕПЕЖ] not found PLATE, CLU PRESS (ЧАСТЬ OF 12) not found PLATE, CLU DRVN (ЧАСТЬ OF 12) 11570903 БОЛТ-HFHE, M8X1.25X20, 12 THD, 16 OD, 10.9, GMW3359, 6MM MAT PT (CLU PRESS PLT) 24242161 CYLINDER, CLU ACTR (ЧАСТЬ OF 11) [ЦИЛИНДР] not found БОЛТ, CLU ACTR CYL (ЧАСТЬ OF 11) 11518202 БОЛТ, HFH, M10X1.5X30, 22.0 00, 6202M, 6280M, TAP, TR, P-PT (ЧАСТЬ OF 11) 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] teamcadillac.ru 24242917 ТРАНСМИССИЯ, MAN (INCLS 7-9) (СМ. ГРУППУ 04.000 "ТРАНСМИССИЯ БЛОК" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ТРАНСМИССИЯ] 24243879 PLATE, CLU PRESS & DRVN (W/CVR) (INCLS 4, 5) 24222918 COVER, TRANS (0.679) 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (TRANS CVR) [БОЛТ] (6D00-042) - 2008 DM69 ДВИГАТЕЛЬ В СБОРЕ-2.8L V6 ЧАСТЬ 4 МАСЛЯНЫЙ НАСОС,МАСЛЯНЫЙ ПОДДОН & ДЕТАЛИ КОМПЛЕКТА (LP1/2.8T) ↓ 22531637 PIN, МАСЛЯНЫЙ ПОДДОН LOC (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 12586959 GUIDE, TMG CHAIN (ЧАСТЬ OF 463) (2 КРЕПЛЕНИЕ HOLES) (LOWER PRIMARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ГРМ] 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (ЧАСТЬ OF 463) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12592105 PAN, OIL (INCLS 405-407, 410, 412, 413, 420, 422, 900) [МАСЛЯНЫЙ ПОДДОН ДВИГАТЕЛЯ] 12590407 PIPE, O/PMP SUC (ЧАСТЬ OF 400) 12566837 SEAL, O/PMP SUC PIPE (ЧАСТЬ OF 400) [УПЛОТНЕНИЕ] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 400) 12566872 DEFLECTOR, CR/SHF OIL (ЧАСТЬ OF 400) 11562588 PLUG, МАСЛЯНЫЙ ПОДДОН DRN (INCLS 413) (ЧАСТЬ OF 400) (W/ SEAL) (EXC MAGNET) [ЗАГЛУШКА МАСЛЯНОГО ПОДДОНА] not found SEAL, МАСЛЯНЫЙ ПОДДОН DRN PLUG (O RING) (ЧАСТЬ OF 400, 412) 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (ЧАСТЬ OF 400) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11588424 БОЛТ, HFH, M6X1X145, 18 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 400) [ШЕСТИГРАННЫЙ ВИНТ] 12611594 INDICATOR, OIL LVL (INCLS 434) 12612349 TUBE, OIL LVL IND 24504091 SEAL, OIL LVL IND (O RING) (BLACK) (6.07MM ID, 1.78MM DIA) (INDICATOR) 24504091 SEAL, OIL LVL IND (O RING) (BLACK) (6.07MM ID, 1.78MM DIA) (TUBE) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (OIL LVL IND TUBE) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) (INDICATOR) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) (TUBE) 12591607 ADAPTER, OIL FLTR (INCLS 441-443, 446-451, 456, 458, 459, 728, 729) [АДАПТЕР МАСЛЯНОГО ФИЛЬТРА] 12591604 GASKET, OIL FLTR (ЧАСТЬ OF 440) (BETWEEN OIL FILTER ADAPTER AND BLOCK) [ПРОКЛАДКА МАСЛЯНОГО ФИЛЬТРА] 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 440) 11519174 БОЛТ, HFH, W/REDUCED BODY, M8X1.25X65, THD 22, O.D. 18, 8.8, GMW3359 (ЧАСТЬ OF 440) 25014612 VALVE, OIL FLTR BYPASS (ЧАСТЬ OF 440, 450) (W/O VAPOR SEPARATOR) (OPENING PRESSURE 21 PSI NOMINAL) (ЧАСТЬ HAS A 16.10MM MAX OD & FITS A 15.84 HOLE IN BLOCK) 11519184 БОЛТ, OIL FLTR ADAP (ЧАСТЬ OF 440) (M10X1.5X45) (0.029) not found SPACER, OIL FLTR (ЧАСТЬ OF 440) 25177917 ФИЛЬТР, МАСЛЯНЫЙ (ЧАСТЬ OF 440) (ACDelco #PF2129) [МАСЛЯНЫЙ ФИЛЬТР ДВИГАТЕЛЯ] 12583470 CAP, OIL FLTR (ЧАСТЬ OF 440) (INCLS 446, 451, 456) [КРЫШКА] 12577653 SEAL, OIL FLTR CAP (O RING) (ЧАСТЬ OF 440, 450) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КРЫШКИ МАСЛЯНОГО ФИЛЬТРА] not found BODY, BYPASS (ЧАСТЬ OF 440, 450) not found VALVE, OIL FILTER DRAIN (ЧАСТЬ OF 440) not found SEAL, OIL FLTR DRN PLUG (O RING) (ЧАСТЬ OF 440) 12590152 PUMP, OIL (INCLS 151, 154, 464-466, 468, 470-472, 474, 475) (INCLS GUIDE, БОЛТS) [МАСЛЕННЫЙ НАСОС] not found COVER, O/PMP (ЧАСТЬ OF 463) not found GEAR, O/PMP (ЧАСТЬ OF 463) not found GEAR, O/PMP IDLER (ЧАСТЬ OF 463) not found БОЛТ, O/PMP CVR (ЧАСТЬ OF 463) not found PLUG, OIL PRESS RLF VLV BORE (ЧАСТЬ OF 463) not found ПРУЖИНА, OIL PRESS RLF VLV (ЧАСТЬ OF 463) not found VALVE, OIL PRESS RLF (ЧАСТЬ OF 463) not found RETAINER, OIL PRESS RLF VLV SPR (ЧАСТЬ OF 463) 11900371 БОЛТ, HEX HD, W/1.6 FLAT WA, M8X1.25X54.3, 43 THD, 16O.D., 8.8, GMW3359 (ЧАСТЬ OF 463) 12610143 NOZZLE, PSTN OIL (INCLS 491) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 490) 12621659 SENSOR, ENG OIL PRESS (INCLS 729) (ЧАСТЬ OF 440) (ACDelco #12621659) teamcadillac.ru not found SEAL, ENG OIL PRESSURE SENSOR (ЧАСТЬ OF 440, 728) 11588694 БОЛТ, HEX-HD, M8X1.25X120.8, DOG-PT, 8.8, GMW3359 (ЧАСТЬ OF 400) (6D00-042) - 2008 DM69 ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 4 МАСЛЯНЫЙ НАСОС,МАСЛЯНЫЙ ПОДДОН & ДЕТАЛИ КОМПЛЕКТА (LLT/3.6V, ЗАДНИЙ КОЛЕСО DRIVE MN6,MX0) ↓ 22531637 PIN, МАСЛЯНЫЙ ПОДДОН LOC (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 12586959 GUIDE, TMG CHAIN (ЧАСТЬ OF 463) (2 КРЕПЛЕНИЕ HOLES) (LOWER PRIMARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ГРМ] 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (ЧАСТЬ OF 463) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12592105 PAN, OIL (INCLS 405-407, 410, 412, 413, 420, 422, 900) [МАСЛЯНЫЙ ПОДДОН ДВИГАТЕЛЯ] 12592105 PAN, OIL (INCLS 405-407, 410, 412, 413, 420, 422, 900) [МАСЛЯНЫЙ ПОДДОН ДВИГАТЕЛЯ] 12590407 PIPE, O/PMP SUC (ЧАСТЬ OF 400) 12590407 PIPE, O/PMP SUC (ЧАСТЬ OF 400) 12566837 SEAL, O/PMP SUC PIPE (ЧАСТЬ OF 400) [УПЛОТНЕНИЕ] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 400) 12566872 DEFLECTOR, CR/SHF OIL (ЧАСТЬ OF 400) 11562588 PLUG, МАСЛЯНЫЙ ПОДДОН DRN (INCLS 413) (ЧАСТЬ OF 400) (W/ SEAL) (EXC MAGNET) [ЗАГЛУШКА МАСЛЯНОГО ПОДДОНА] not found SEAL, МАСЛЯНЫЙ ПОДДОН DRN PLUG (O RING) (ЧАСТЬ OF 400, 412) 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (ЧАСТЬ OF 400) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11588424 БОЛТ, HFH, M6X1X145, 18 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 400) [ШЕСТИГРАННЫЙ ВИНТ] 12611594 INDICATOR, OIL LVL (INCLS 434) 12612349 TUBE, OIL LVL IND 24504091 SEAL, OIL LVL IND (O RING) (BLACK) (6.07MM ID, 1.78MM DIA) (INDICATOR) 24504091 SEAL, OIL LVL IND (O RING) (BLACK) (6.07MM ID, 1.78MM DIA) (TUBE) teamcadillac.ru 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (OIL LVL IND TUBE) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) (INDICATOR) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) (TUBE) 12591607 ADAPTER, OIL FLTR (INCLS 441-443, 446-451, 456, 458, 459, 728, 729) [АДАПТЕР МАСЛЯНОГО ФИЛЬТРА] 12591604 GASKET, OIL FLTR (ЧАСТЬ OF 440) (BETWEEN OIL FILTER ADAPTER AND BLOCK) [ПРОКЛАДКА МАСЛЯНОГО ФИЛЬТРА] 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 440) 11519174 БОЛТ, HFH, W/REDUCED BODY, M8X1.25X65, THD 22, O.D. 18, 8.8, GMW3359 (ЧАСТЬ OF 440) 25014612 VALVE, OIL FLTR BYPASS (ЧАСТЬ OF 440, 450) (W/O VAPOR SEPARATOR) (OPENING PRESSURE 21 PSI NOMINAL) (ЧАСТЬ HAS A 16.10MM MAX OD & FITS A 15.84 HOLE IN BLOCK) 11519184 БОЛТ, OIL FLTR ADAP (ЧАСТЬ OF 440) (M10X1.5X45) (0.029) not found SPACER, OIL FLTR (ЧАСТЬ OF 440) 19114105 ФИЛЬТР, МАСЛЯНЫЙ (ЧАСТЬ OF 440) (ACDelco #PF2129F) (DURAPACK) (BULK PKG, QTY 12) 25177917 ФИЛЬТР, МАСЛЯНЫЙ (ЧАСТЬ OF 440) (ACDelco #PF2129) [МАСЛЯНЫЙ ФИЛЬТР ДВИГАТЕЛЯ] 12583470 CAP, OIL FLTR (ЧАСТЬ OF 440) (INCLS 446, 451, 456) [КРЫШКА] not found SEAL, OIL FLTR CAP (O RING) (ЧАСТЬ OF 440, 450) not found BODY, BYPASS (ЧАСТЬ OF 440, 450) not found VALVE, OIL FILTER DRAIN (ЧАСТЬ OF 440) not found SEAL, OIL FLTR DRN PLUG (O RING) (ЧАСТЬ OF 440) 12590152 PUMP, OIL (INCLS 151, 154, 464-466, 468, 470-472, 474, 475) (INCLS GUIDE, БОЛТS) [МАСЛЕННЫЙ НАСОС] not found COVER, O/PMP (ЧАСТЬ OF 463) not found GEAR, O/PMP (ЧАСТЬ OF 463) not found GEAR, O/PMP IDLER (ЧАСТЬ OF 463) not found БОЛТ, O/PMP CVR (ЧАСТЬ OF 463) not found PLUG, OIL PRESS RLF VLV BORE (ЧАСТЬ OF 463) not found ПРУЖИНА, OIL PRESS RLF VLV (ЧАСТЬ OF 463) not found VALVE, OIL PRESS RLF (ЧАСТЬ OF 463) not found RETAINER, OIL PRESS RLF VLV SPR (ЧАСТЬ OF 463) 11900371 БОЛТ, HEX HD, W/1.6 FLAT WA, M8X1.25X54.3, 43 THD, 16O.D., 8.8, GMW3359 (ЧАСТЬ OF 463) 12610143 NOZZLE, PSTN OIL (INCLS 491) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 490) 12621659 SENSOR, ENG OIL PRESS (INCLS 729) (ЧАСТЬ OF 440) (ACDelco #12621659) not found SEAL, ENG OIL PRESSURE SENSOR (ЧАСТЬ OF 440, 728) 11588694 БОЛТ, HEX-HD, M8X1.25X120.8, DOG-PT, 8.8, GMW3359 (ЧАСТЬ OF 400) (6D00-042) - 2008-2009 DM69 ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 4 МАСЛЯНЫЙ НАСОС,МАСЛЯНЫЙ ПОДДОН & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7, ЗАДНИЙ КОЛЕСО DRIVE MN6,MX0) ↓ 22531637 PIN, МАСЛЯНЫЙ ПОДДОН LOC (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 12586959 GUIDE, TMG CHAIN (ЧАСТЬ OF 463) (2 КРЕПЛЕНИЕ HOLES) (LOWER PRIMARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ГРМ] 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (ЧАСТЬ OF 463) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12592105 PAN, OIL (INCLS 405-407, 410, 412, 413, 420, 422, 900) [МАСЛЯНЫЙ ПОДДОН ДВИГАТЕЛЯ] 12590407 PIPE, O/PMP SUC (ЧАСТЬ OF 400) 12590407 PIPE, O/PMP SUC (ЧАСТЬ OF 400) teamcadillac.ru 12566837 SEAL, O/PMP SUC PIPE (ЧАСТЬ OF 400) [УПЛОТНЕНИЕ] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 400) 12566872 DEFLECTOR, CR/SHF OIL (ЧАСТЬ OF 400) 11562588 PLUG, МАСЛЯНЫЙ ПОДДОН DRN (INCLS 413) (ЧАСТЬ OF 400) (W/ SEAL) (EXC MAGNET) [ЗАГЛУШКА МАСЛЯНОГО ПОДДОНА] not found SEAL, МАСЛЯНЫЙ ПОДДОН DRN PLUG (O RING) (ЧАСТЬ OF 400, 412) 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (ЧАСТЬ OF 400) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11588424 БОЛТ, HFH, M6X1X145, 18 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 400) [ШЕСТИГРАННЫЙ ВИНТ] 12611594 INDICATOR, OIL LVL (INCLS 434) 12612349 TUBE, OIL LVL IND 24504091 SEAL, OIL LVL IND (O RING) (BLACK) (6.07MM ID, 1.78MM DIA) (INDICATOR) 24504091 SEAL, OIL LVL IND (O RING) (BLACK) (6.07MM ID, 1.78MM DIA) (TUBE) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (OIL LVL IND TUBE) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) (INDICATOR) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) (TUBE) 12591607 ADAPTER, OIL FLTR (INCLS 441-443, 446-451, 456, 458, 459, 728, 729) [АДАПТЕР МАСЛЯНОГО ФИЛЬТРА] 12591604 GASKET, OIL FLTR (ЧАСТЬ OF 440) (BETWEEN OIL FILTER ADAPTER AND BLOCK) [ПРОКЛАДКА МАСЛЯНОГО ФИЛЬТРА] 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 440) 11519174 БОЛТ, HFH, W/REDUCED BODY, M8X1.25X65, THD 22, O.D. 18, 8.8, GMW3359 (ЧАСТЬ OF 440) 25014612 VALVE, OIL FLTR BYPASS (ЧАСТЬ OF 440, 450) (W/O VAPOR SEPARATOR) (OPENING PRESSURE 21 PSI NOMINAL) (ЧАСТЬ HAS A 16.10MM MAX OD & FITS A 15.84 HOLE IN BLOCK) 11519174 БОЛТ, OIL FLTR ADAP (БОЛТ, HFH, W/REDUCED BODY, M8X1.25X65, THD 22, O.D. 18, 8.8, GMW3359) (ЧАСТЬ OF 440) (M8X1.25X65) (8.900) 11519184 БОЛТ, OIL FLTR ADAP (ЧАСТЬ OF 440) (M10X1.5X45) (0.029) 11519980 БОЛТ, OIL FLTR ADAP (БОЛТ, HFH, W/REDUCED BODY, M8X1.25X65, THD 22, O.D. 18, 8.8, GMW3359) (ЧАСТЬ OF 440) (M8X1.25X40) (8.900) not found SPACER, OIL FLTR (ЧАСТЬ OF 440) 25177917 ФИЛЬТР, МАСЛЯНЫЙ (ЧАСТЬ OF 440) (ACDelco #PF2129) [МАСЛЯНЫЙ ФИЛЬТР ДВИГАТЕЛЯ] 12583470 CAP, OIL FLTR (ЧАСТЬ OF 440) (INCLS 446, 451, 456) [КРЫШКА] 12577653 SEAL, OIL FLTR CAP (O RING) (ЧАСТЬ OF 440, 450) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КРЫШКИ МАСЛЯНОГО ФИЛЬТРА] not found CAGE, OIL FLTR BYPASS VLV (ЧАСТЬ OF 440, 450) not found VALVE, OIL FLTR BYPASS (ЧАСТЬ OF 440) not found SEAL, OIL FLTR DRN PLUG (O RING) (ЧАСТЬ OF 440) 12590152 PUMP, OIL (INCLS 151, 154, 464-466, 468, 470-472, 474, 475) (INCLS GUIDE, БОЛТS) [МАСЛЕННЫЙ НАСОС] not found COVER, O/PMP (ЧАСТЬ OF 463) not found GEAR, O/PMP (ЧАСТЬ OF 463) not found GEAR, O/PMP IDLER (ЧАСТЬ OF 463) not found БОЛТ, O/PMP CVR (ЧАСТЬ OF 463) not found PLUG, OIL PRESS RLF VLV BORE (ЧАСТЬ OF 463) not found ПРУЖИНА, OIL PRESS RLF VLV (ЧАСТЬ OF 463) not found VALVE, OIL PRESS RLF (ЧАСТЬ OF 463) not found RETAINER, OIL PRESS RLF VLV SPR (ЧАСТЬ OF 463) 11900371 БОЛТ, HEX HD, W/1.6 FLAT WA, M8X1.25X54.3, 43 THD, 16O.D., 8.8, GMW3359 (ЧАСТЬ OF 463) 12610143 NOZZLE, PSTN OIL (INCLS 491) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 490) 12621659 SENSOR, ENG OIL PRESS (INCLS 729) (ЧАСТЬ OF 440) (ACDelco #12621659) not found SEAL, ENG OIL PRESS SEN (O RING) (ЧАСТЬ OF 440, 728) 11588694 БОЛТ, HEX-HD, M8X1.25X120.8, DOG-PT, 8.8, GMW3359 (ЧАСТЬ OF 400) (6D00-043) - 2008-2009 DM69 INTAKE MANIFOLD SHIELD/COVERS (LP1/2.8T,LY7/3.6-7) ↓ not found COVER, INT MANIF (INCLS 7, 15-19) 12632150 COVER, INT MANIF (INCLS 7, 15-19) (ДВИГАТЕЛЬ COVER) 12632150 COVER, INT MANIF (INCLS 7, 15-19) (ДВИГАТЕЛЬ COVER) (3.265) not found INSULATOR, INT MANIF CVR 12624769 INSULATOR, INT MANIF CVR 20664092 RETAINER, UPR INT MANIF SIGHT SHLD (BLACK) (6.3MM DIA X 23MM) (1.276) [КЛИПСА КРЕПЛЕНИЯ МОЛДИНГА ДВЕРИ] 12606137 INSULATOR, INT MANIF 12606137 INSULATOR, INT MANIF 11588717 БОЛТ, UPR INT MANIF CVR BRKT (M6X1.0X45.0) (2.383) 11588717 БОЛТ, UPR INT MANIF CVR BRKT (M6X1.0X45.0) (2.383) 12607233 BRACKET, UPR INT MANIF SIGHT SHLD 12607233 BRACKET, UPR INT MANIF SIGHT SHLD not found INSULATOR, F/INJR SIGHT SHLD BRKT (ЧАСТЬ OF 1) 24507878 INSULATOR, F/INJR SIGHT SHLD BRKT (ЧАСТЬ OF 1) 11588723 БОЛТ, HFH, M8X1.25X25, 18 THD, 18 OD, 8.8 STL, GMW3359, M-PT (INT MANIF SIGHT SHLD) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (INT MANIF SIGHT SHLD) 11516075 ГАЙКА, HFH SELF LK, M6X1, 7.7THK, 14.2 O.D., 9, PZOR (ЧАСТЬ OF 12) [ГАЙКА ВЫПУСКНОЙ СИСТЕМЫ D=6ММ] 11588967 STUD, BALL W/HFH, M6X1X20.65, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 12) teamcadillac.ru 12616618 BRACKET, INT MANIF SIGHT SHLD (INCLS 10, 11) 12616618 BRACKET, INT MANIF SIGHT SHLD (INCLS 10, 11) 12593348 SEAL, OIL FIL TUBE (O RING) (ЧАСТЬ OF 14) (27.94MM I.D.) (SIZE #320) (1.758) [ПРОКЛАДКА] 12593348 SEAL, OIL FIL TUBE (O RING) (ЧАСТЬ OF 14) (27.94MM I.D.) (SIZE #320) (1.758) [ПРОКЛАДКА] 12615294 TUBE, OIL FIL (INCLS 13, 20, 21) [ТРУБКА МАСЛЯНОГО ФИЛЬТРА] 12615294 TUBE, OIL FIL (INCLS 13, 20, 21) [ТРУБКА МАСЛЯНОГО ФИЛЬТРА] 12591714 GROMMET, UPR INT MANIF SIGHT SHLD (ЧАСТЬ OF 1) (60MM OD @ TOP) (ROUND TOP & BOTTOM) 12591714 GROMMET, UPR INT MANIF SIGHT SHLD (ЧАСТЬ OF 1) (60MM OD @ TOP) (ROUND TOP & BOTTOM) not found INSULATOR, F/INJR SIGHT SHLD BRKT (ЧАСТЬ OF 1) 10042521 ГАЙКА, INT MANIF INSL (ЧАСТЬ OF 1) (7.831) 10042521 ГАЙКА, INT MANIF INSL (ЧАСТЬ OF 1) (7.831) 12591715 GROMMET, UPR INT MANIF SIGHT SHLD (ЧАСТЬ OF 1) (32MM OD @ TOP) (ROUND AT TOP/TAPERED CONICAL BOTTOM) 12591715 GROMMET, UPR INT MANIF SIGHT SHLD (ЧАСТЬ OF 1) (32MM OD @ TOP) (ROUND AT TOP/TAPERED CONICAL BOTTOM) not found EMBLEM, INT MANIF CVR (ЧАСТЬ OF 1) 12607405 EMBLEM, INT MANIF CVR (ЧАСТЬ OF 1) [ЭМБЛЕМА] 12593356 CAP, OIL FIL (ЧАСТЬ OF 14) (INCLS 21) (ACDelco #FC221) [КРЫШКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ] 12593356 CAP, OIL FIL (ЧАСТЬ OF 14) (INCLS 21) (ACDelco #FC221) [КРЫШКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ] 12593348 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 14, 20) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА] 12593348 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 14, 20) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА] (6D00-044) - 2008-2009 DM69 ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ (ПОЛНОПРИВОДНЫЙ MX7) ↓ 15854018 BRACKET, ENG MT 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (ENG MT BRKT) [БОЛТ, М10Х1.5Х30] teamcadillac.ru 11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (ENG MT BRKT) [БОЛТ, М8Х1.25Х31.5] 15854019 BRACKET, ENG MT 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT) [ГАЙКА М12] 25971088 MOUNT, ENG [ОПОРНЫЙ УЗЕЛ ДВИГАТЕЛЯ] 11516754 ГАЙКА, HEX, W/CON SPR WA, M10X1.5, 10THK, 28 O.D., 10, 7111M (ENG MT FRM SI) [ГАЙКА М10] 11515775 БОЛТ, HFH, M12X1.75X30, 10.9, 7114M (TRANS MT) [БОЛТ] 25892305 MOUNT, TRANS RR 11589169 БОЛТ ASM - HEX HD W/CONICAL WASHER, M10X1.50X50, GMW25 (10.9) STL, GMW33559 (TRANS RR MT BRKT) 25971085 MOUNT, ENG [ШАРНИР ДВИГАТЕЛЯ] (6D00-045) - 2008 DM69 ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ (ЗАДНИЙ КОЛЕСО DRIVE MX0,MN6) ↓ teamcadillac.ru 25905221 BRACKET, ENG MT [КРОНШТЕЙН] 25905221 BRACKET, ENG MT [КРОНШТЕЙН] 11517383 БОЛТ, HEX W/CON SPR WASH, M10X1.5X55, 28 OD, 37 THD, 10.9, 7114M (ENG MT BRKT) 11517383 БОЛТ, HEX W/CON SPR WASH, M10X1.5X55, 28 OD, 37 THD, 10.9, 7114M (ENG MT BRKT) 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT) [ГАЙКА М12] 25905220 BRACKET, ENG MT [ КРОНШТЕЙН] 25905220 BRACKET, ENG MT [ КРОНШТЕЙН] 25973848 MOUNT, ENG 11516078 ГАЙКА, HFH, M12X1.75, 14THK, 25 O.D., 10, PZOR (ENG MT FRM SI) [ГАЙКА] 15234764 MOUNT, TRANS RR (INCLS 9, 10) [КРЕПЛЕНИЕ] 25947769 MOUNT, TRANS RR (INCLS 9, 10) 25843484 INSULATOR, TRANS RR MT SPR (ЧАСТЬ OF 8) 25843484 INSULATOR, TRANS RR MT SPR (ЧАСТЬ OF 8) not found MOUNT, TRANS RR (ЧАСТЬ OF 8) 11516078 ГАЙКА, HFH, M12X1.75, 14THK, 25 O.D., 10, PZOR (ENG MT FRM SI) [ГАЙКА] 11589169 БОЛТ ASM - HEX HD W/CONICAL WASHER, M10X1.50X50, GMW25 (10.9) STL, GMW33559 (TRANS RR MT BRKT) 11571051 БОЛТ, HFH, M10X1.5X45, 26 THD, 19 OD, 10.9, GMW3359 M-PT. (TRANS MT) (6D00-046) - 2008-2010 DM69 ПЕДАЛЬ СЦЕПЛЕНИЯ-ЦИЛИНДРЫ (MV7) ↓ 24245109 CYLINDER, CLU MAS (INCLS 12) [ЦИЛИНДР] 89047699 SENSOR, CLU PED POSN (ЧАСТЬ OF 10) (INCLS 4) (4.625) [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (CLU PED BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 2, 10) 11609746 ГАЙКА, HFH, M8X1.25, 8.9THK, 17.6 O.D., 10 STL, GMW3200, PREV TORQUE (CLU PED BRKT) [ГАЙКА М8] not found BUSHING, CLU PED RTN SPR (ЧАСТЬ OF 10) not found BUSHING, CLU PED RTN SPR GDE (ЧАСТЬ OF 10) teamcadillac.ru not found ПРУЖИНА, CLU PED RTN (ЧАСТЬ OF 10) not found PAD, CLU PED (ЧАСТЬ OF 10) 25866254 PEDAL, CLU (W/BRKT) (INCLS 2, 4, 6-9, 13) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (CLU PED) [ГАЙКА М6] not found CAP, CLU M/CYL RSVR (ЧАСТЬ OF 1) 25855318 HARNESS, CLU & SHFT CONT ACTR WRG (ЧАСТЬ OF 10) (6D00-047) - 2008 DM69 ДВИГАТЕЛЬ В СБОРЕ-2.8L V6 ЧАСТЬ 1 БЛОК ЦИЛИНДРОВ И ВНУТРЕННИЕ ДЕТАЛИ (LP1/2.8T) ↓ not found BLOCK, ENG (MCHG) not found CAP, CR/SHF BRG teamcadillac.ru 12560272 БОЛТ, CR/SHF BRG CAP (BOTTOM) (LONG) (M10X2X102.5, 24.5) [ВИНТ] 11518861 БОЛТ, HFH, W/REDCD BODY, M8X1.25X90, 26 THD, 18 O.D., 10.9, GM4277M (CR/SHF BRG CAP) [БОЛТ] 11609410 БОЛТ, HFH, M8X1.25X25, 10.9, GMW3179 (CR/SHF BRG CAP) (0.056) [БОЛТ] 11589000 БОЛТ, HFH, M8X1.25X50, 24 THD, 18 OD, 10.9, GMW3359, RED BODY, W/ADH (CR/SHF BRG CAP) 12557520 PLUG, ENG BLK OIL GAL (CUP-.390IN OD, .040IN THK, STEEL) 12621350 CRANKSHAFT, 12601937 KEY, CR/SHF BALR not found BEARING, CR/SHF UPR (*KIT1) not found BEARING, CR/SHF LWR (*KIT1, KIT2) not found BEARING, CR/SHF THR (*KIT2) 11562127 PLUG, ENG BLK OIL GAL (CUP-14.22 OD, 6.6 THK, 304SS) (0.253) 11561583 PLUG, ENG BLK OIL GAL (M14X1.5X16, 22 OD) (0.253) 11561751 PLUG, CYL HD WAT JKT HOLE (M20X1.5X30.5) (1.531) 11569584 PLUG, ENG BLK CORE HOLE (CUP DIA 34.4MM) 12597210 PIN, TRANS LOC 12620955 SEAL, CR/SHF RR OIL [ПРОКЛАДКА КОЛЕНВАЛА ДВИГАТЕЛЯ] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (CR/SHF RR OIL SEAL HSG) 22531637 PIN, МАСЛЯНЫЙ ПОДДОН LOC (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 12570326 PIN, CYL HD LOC [ЗАГЛУШКА БЛОКА ЦИЛИНДРОВ] 12603197 PLATE, A/TRNS FLEX 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12608427 ROD, CONN (INCLS 201, 202) [ОСЬ] 11519680 БОЛТ, CONN ROD (ЧАСТЬ OF 200) (M9X1X53) [БОЛТ] not found BUSHING, CONN ROD (ЧАСТЬ OF 200) not found BEARING, CONN ROD (UPPER) (*KIT4) not found BEARING, CONN ROD (LOWER) (*KIT4) 12596024 PISTON, (W/PIN) (INCLS 211, 212) (STD) 12598127 PISTON, (W/PIN) (INCLS 211, 212) (0.25MM O.S.) (FOR STD SEE 12596024) not found PIN, PSTN (ЧАСТЬ OF 210) 12566186 RETAINER, PSTN PIN (ЧАСТЬ OF 210) not found RING, PSTN CMPRN UPR (*KIT3) not found RING, PSTN CMPRN LWR (*KIT3) not found RAIL, PSTN OIL RING (*KIT3) not found SPACER, PSTN OIL RING RL (*KIT3) 12603180 BALANCER, CR/SHF (DUAL BELT) [ШКИВ КОЛЕНВАЛА] 11569873 БОЛТ, CR/SHF BALR (M14X1.5X48.4) 12610143 NOZZLE, PSTN OIL 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (PSTN OIL NOZ) 12613030 SENSOR, CR/SHF POSN (INCLS 721, 722) [ДАТЧИК ПОЛОЖЕНИЯ КОЛЕНВАЛА] not found SEAL, CR/SHF POSN SEN (O RING) (ЧАСТЬ OF 720) 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 720) 12618603 SENSOR, KNOCK (W/O LEADS) (INCLS 724) (ACDelco #213-4335) [ДАТЧИК] 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 723) not found PLATE, CLU PRESS (ЧАСТЬ OF 900) 11519976 БОЛТ, HFLGE, M8X1.25X20, 15.6 THD, 18 O.D., 8.8, GMW3359 (CLU PRESS PLT) not found PLATE, CLU DRVN (ЧАСТЬ OF 900) 24243879 PLATE, CLU PRESS & DRVN (W/CVR) (INCLS 850, 852) 12575412 FLYКОЛЕСО, ENG 11588884 БОЛТ, HEX SOC HD, M10X1X24, 21 THD, 15.9 OD, 10.9, GMW3179G, HDR PT (FLYWHL) [КРЕПЕЖ] 12610603 BEARING KIT, CR/SHF (#1, 2, 4 STD) (INCLS 122, 123) [ПОДШИПНИК СКОЛЬЖЕНИЯ КОЛЕНВАЛА] 12610604 BEARING KIT, CR/SHF (#3 STD) (INCLS 123, 124) [КОМПЛЕКТ ПОДШИПНИКОВ СКОЛЬЖЕНИЯ КОЛЕНВАЛА (3ШТ)] 12596025 RING KIT, PSTN (INCLS 213-216) (STD) 12598128 RING KIT, PSTN (INCLS 213-216) (0.25MM O.S.) 12598657 BEARING KIT, CONN ROD (INCLS 203, 204) [ПОДШИПНИК СКОЛЬЖЕНИЯ ШАТУНА] (6D00-047) - 2008 DM69 ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 1 БЛОК ЦИЛИНДРОВ И ВНУТРЕННИЕ ДЕТАЛИ (LLT/3.6V) ↓ not found BLOCK, ENG (MCHG) not found CAP, CR/SHF BRG 12560272 БОЛТ, CR/SHF BRG CAP (M10X2X102.5, 24.5) [ВИНТ] 11518861 БОЛТ, HFH, W/REDCD BODY, M8X1.25X90, 26 THD, 18 O.D., 10.9, GM4277M (CR/SHF BRG CAP) [БОЛТ] 11609410 БОЛТ, HFH, M8X1.25X25, 10.9, GMW3179 (CR/SHF BRG CAP) (0.056) [БОЛТ] 11589000 БОЛТ, HFH, M8X1.25X50, 24 THD, 18 OD, 10.9, GMW3359, RED BODY, W/ADH (CR/SHF BRG CAP) 12557520 PLUG, ENG BLK OIL GAL (CUP-.390IN OD, .040IN THK, STEEL) 12621352 CRANKSHAFT, [КОЛЕНВАЛ ДВИГАТЕЛЯ] 12601937 KEY, CR/SHF BALR not found BEARING, CR/SHF UPR (*KIT1) not found BEARING, CR/SHF LWR (*KIT1, KIT2) not found BEARING, CR/SHF THR (*KIT2) 11562127 PLUG, ENG BLK OIL GAL (CUP-14.22 OD, 6.6 THK, 304SS) (0.253) 11561583 PLUG, ENG BLK OIL GAL (M14X1.5X16, 22 OD) (0.253) 11561751 PLUG, CYL HD WAT JKT HOLE (M20X1.5X30.5) (1.531) 11569584 PLUG, ENG BLK CORE HOLE (CUP DIA 34.4MM) 12597210 PIN, TRANS LOC 12597210 PIN, TRANS LOC 12597210 PIN, TRANS LOC 12620955 SEAL, CR/SHF RR OIL [ПРОКЛАДКА КОЛЕНВАЛА ДВИГАТЕЛЯ] teamcadillac.ru 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (CR/SHF RR OIL SEAL HSG) 22531637 PIN, МАСЛЯНЫЙ ПОДДОН LOC (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 12570326 PIN, CYL HD LOC [ЗАГЛУШКА БЛОКА ЦИЛИНДРОВ] 12603197 PLATE, A/TRNS FLEX 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12590584 ROD, CONN (INCLS 201, 202) 11519680 БОЛТ, CONN ROD (ЧАСТЬ OF 200) (M9X1X53) [БОЛТ] not found BUSHING, CONN ROD (ЧАСТЬ OF 200) not found BEARING, CONN ROD (UPPER) (*KIT4) not found BEARING, CONN ROD (LOWER) (*KIT4) 12616971 PISTON, (W/PIN) (INCLS 211, 212) (STD) 12616972 PISTON, (W/PIN) (INCLS 211, 212) (STD) not found PIN, PSTN (ЧАСТЬ OF 210) 12566186 RETAINER, PSTN PIN (ЧАСТЬ OF 210) not found RING, PSTN CMPRN UPR (*KIT3) not found RING, PSTN CMPRN LWR (*KIT3) not found RAIL, PSTN OIL RING (*KIT3) not found SPACER, PSTN OIL RING RL (*KIT3) 12603180 BALANCER, CR/SHF (DUAL BELT) [ШКИВ КОЛЕНВАЛА] 11569873 БОЛТ, CR/SHF BALR (M14X1.5X48.4) 12610143 NOZZLE, PSTN OIL 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (PSTN OIL NOZ) 12613030 SENSOR, CR/SHF POSN (INCLS 721, 722) [ДАТЧИК ПОЛОЖЕНИЯ КОЛЕНВАЛА] not found SEAL, CR/SHF POSN SEN (O RING) (ЧАСТЬ OF 720) 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 720) 12618603 SENSOR, KNOCK (INCLS 724) (ACDelco #213-4335) [ДАТЧИК] 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 723) not found PLATE, CLU PRESS (ЧАСТЬ OF 900) 11519976 БОЛТ, HFLGE, M8X1.25X20, 15.6 THD, 18 O.D., 8.8, GMW3359 (CLU PRESS PLT) not found PLATE, CLU DRVN (ЧАСТЬ OF 900) 24243879 PLATE, CLU PRESS & DRVN (W/CVR) (INCLS 850, 852) 12575412 FLYКОЛЕСО, ENG 11588884 БОЛТ, HEX SOC HD, M10X1X24, 21 THD, 15.9 OD, 10.9, GMW3179G, HDR PT (FLYWHL) [КРЕПЕЖ] 12610603 BEARING KIT, CR/SHF (INCLS 122, 123) [ПОДШИПНИК СКОЛЬЖЕНИЯ КОЛЕНВАЛА] 12610604 BEARING KIT, CR/SHF (INCLS 123, 124) [КОМПЛЕКТ ПОДШИПНИКОВ СКОЛЬЖЕНИЯ КОЛЕНВАЛА (3ШТ)] 12616973 RING KIT, PSTN (INCLS 213-216) 12598657 BEARING KIT, CONN ROD (INCLS 203, 204) [ПОДШИПНИК СКОЛЬЖЕНИЯ ШАТУНА] (6D00-047) - 2008-2009 DM69 ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 1 БЛОК ЦИЛИНДРОВ И ВНУТРЕННИЕ ДЕТАЛИ (LY7/3.6-7) ↓ not found BLOCK, ENG (MCHG) not found CAP, CR/SHF BRG 12560272 БОЛТ, CR/SHF BRG CAP (BOTTOM (LONG) (M10X2X102.5, 24.5) [ВИНТ] 11518861 БОЛТ, HFH, W/REDCD BODY, M8X1.25X90, 26 THD, 18 O.D., 10.9, GM4277M (CR/SHF BRG CAP) [БОЛТ] 11609410 БОЛТ, HFH, M8X1.25X25, 10.9, GMW3179 (CR/SHF BRG CAP) (0.056) [БОЛТ] 11589000 БОЛТ, HFH, M8X1.25X50, 24 THD, 18 OD, 10.9, GMW3359, RED BODY, W/ADH (CR/SHF BRG CAP) 12557520 PLUG, ENG BLK OIL GAL (CUP-.390IN OD, .040IN THK, STEEL) 12621351 CRANKSHAFT, [КОЛЕНВАЛ] 12601937 KEY, CR/SHF BALR not found BEARING, CR/SHF UPR (*KIT1) teamcadillac.ru not found BEARING, CR/SHF LWR (*KIT1, KIT2) not found BEARING, CR/SHF THR (*KIT2) 11562127 PLUG, ENG BLK OIL GAL (CUP-14.22 OD, 6.6 THK, 304SS) (0.253) 11561583 PLUG, ENG BLK OIL GAL (M14X1.5X16, 22 OD) (0.253) 11561751 PLUG, CYL HD WAT JKT HOLE (M20X1.5X30.5) (1.531) 11569584 PLUG, ENG BLK CORE HOLE (CUP DIA 34.4MM) 12597210 PIN, TRANS LOC 12620955 SEAL, CR/SHF RR OIL [ПРОКЛАДКА КОЛЕНВАЛА ДВИГАТЕЛЯ] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (CR/SHF RR OIL SEAL HSG) 22531637 PIN, МАСЛЯНЫЙ ПОДДОН LOC (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 12570326 PIN, CYL HD LOC [ЗАГЛУШКА БЛОКА ЦИЛИНДРОВ] 12603197 PLATE, A/TRNS FLEX 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12608432 ROD, CONN (INCLS 201, 202) 11519680 БОЛТ, CONN ROD (ЧАСТЬ OF 200) (M9X1X53) [БОЛТ] not found BUSHING, CONN ROD (ЧАСТЬ OF 200) not found BEARING, CONN ROD (UPPER) (*KIT4) not found BEARING, CONN ROD (LOWER) (*KIT4) 12585675 PISTON, (W/PIN) (INCLS 211, 212) (.25 O.S.) 12590866 PISTON, (W/PIN) (INCLS 211, 212) (STD) not found PIN, PSTN (ЧАСТЬ OF 210) 12566186 RETAINER, PSTN PIN (ЧАСТЬ OF 210) not found RING, PSTN CMPRN UPR (*KIT3) not found RING, PSTN CMPRN LWR (*KIT3) not found RAIL, PSTN OIL RING (*KIT3) not found SPACER, PSTN OIL RING RL (*KIT3) 12603180 BALANCER, CR/SHF (DUAL BELT) [ШКИВ КОЛЕНВАЛА] 11569873 БОЛТ, CR/SHF BALR (M14X1.5X48.4) 12610143 NOZZLE, PSTN OIL 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (PSTN OIL NOZ) 12613030 SENSOR, CR/SHF POSN (INCLS 721, 722) [ДАТЧИК ПОЛОЖЕНИЯ КОЛЕНВАЛА] not found SEAL, CR/SHF POSN SEN (O RING) (ЧАСТЬ OF 720) 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 720) 12618603 SENSOR, KNOCK (W/O LEADS) (INCLS 724) (ACDelco #213-4335) [ДАТЧИК] 11589313 БОЛТ, HFH, M8X1.25X39, 29 THD, 18 OD, 8.8 STL, GMW3359, M-PT. (ЧАСТЬ OF 723) not found PLATE, CLU PRESS (ЧАСТЬ OF 900) 11570903 БОЛТ-HFHE, M8X1.25X20, 12 THD, 16 OD, 10.9, GMW3359, 6MM MAT PT (CLU PRESS PLT) not found PLATE, CLU DRVN (ЧАСТЬ OF 900) 24243879 PLATE, CLU PRESS & DRVN (W/CVR) (INCLS 850, 852) 12575412 FLYКОЛЕСО, ENG 11588884 БОЛТ, HEX SOC HD, M10X1X24, 21 THD, 15.9 OD, 10.9, GMW3179G, HDR PT (FLYWHL) [КРЕПЕЖ] 12610603 BEARING KIT, CR/SHF (#1, 2, 4 STD) (INCLS 122, 123) [ПОДШИПНИК СКОЛЬЖЕНИЯ КОЛЕНВАЛА] 12610604 BEARING KIT, CR/SHF (#3 STD) (INCLS 123, 124) [КОМПЛЕКТ ПОДШИПНИКОВ СКОЛЬЖЕНИЯ КОЛЕНВАЛА (3ШТ)] 12608615 RING KIT, PSTN (INCLS 213-216) (STD) 12598657 BEARING KIT, CONN ROD (INCLS 203, 204) [ПОДШИПНИК СКОЛЬЖЕНИЯ ШАТУНА] (6D00-049) - 2008 DM69 ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 2 ГОЛОВКА ЦИЛИНДРОВ & ДЕТАЛИ КОМПЛЕКТА (LLT/3.6V) ↓ 12570326 PIN, CYL HD LOC [ЗАГЛУШКА БЛОКА ЦИЛИНДРОВ] 12606653 ACTUATOR, CM/SHF POSN (USE WASHER 12630941) 12603744 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) 12603745 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) 11588279 БОЛТ, HFH, M10X1.5X80, 26 THD, 22.3 O.D., 10.9, GM4277M (CM/SHF POSN) 12624804 COVER, CM/SHF (INCLS 251, 254-256, 260, 263) [КРЫШКА] 12626054 COVER, CM/SHF (INCLS 251, 254-256, 261) [КРЫШКА] 12595107 SEAL, CM/SHF CVR (ЧАСТЬ OF 250) (*KIT1) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12607401 SEAL, CM/SHF CVR (ЧАСТЬ OF 250) (*KIT1) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12607600 SEAL, SPLG SHLD (ЧАСТЬ OF 250) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО СИСТЕМЫ ЗАЖИГАНИЯ] 11518859 БОЛТ, HFH W/SHLDR, M6X1X35, 11.85 THD, 18 O.D., 8.8, GMW3359 (ЧАСТЬ OF 250) 12595122 INSULATOR, CM/SHF CVR БОЛТ (ЧАСТЬ OF 250) (*KIT1) 12593356 CAP, OIL FIL (INCLS 904) (ACDelco #FC221) [КРЫШКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ] 12593348 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 262) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА] 12615294 TUBE, OIL FIL (INCLS 259) [ТРУБКА МАСЛЯНОГО ФИЛЬТРА] not found SEAL, PCV HOSE FTG (O RING) (ЧАСТЬ OF 250, 260) 12601745 INSULATOR, CM/SHF HSG CVR [НАКЛАДКА КЛАПАННОЙ КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12603147 INSULATOR, CM/SHF HSG CVR 12590607 HEAD, CYL (MCHG) (INCLS 313, 318, 319, 328, 336, 337) (DOES NOT INCL ENG OIL MANIF CHECK VALVES. DLR MUST INSTL) [ГОЛОВКА БЛОКА ЦИЛИНДРОВ] 12617767 HEAD, CYL (MCHG) (INCLS 313, 318, 319, 328, 336, 337) (DOES NOT INCL ENG OIL MANIF CHECK VALVES. DLR MUST INSTL) [ГОЛОВКА БЛОКА ЦИЛИНДРОВ] 12620190 GASKET, CYL HD (*KIT1) 12624743 GASKET, CYL HD (*KIT1) 11588734 БОЛТ, HFH, M8X1.25X90, 21.6 THD, 18 O.D., 8.8, GMW3359 (CYL HD) [ВИНТ] 11561751 PLUG, CYL HD WAT JKT HOLE (ЧАСТЬ OF 300) (M20X1.5X30.5) (1.531) not found SLEEVE, SPLG WIRE (ЧАСТЬ OF 300) 12575354 VALVE, EXH (STD) [КЛАПАН ВЫПУСКНОЙ] 12584760 VALVE, EXH (0.075 O.S.) [КЛАПАН ВЫПУСКНОЙ] 12575351 VALVE, INT (STD) [КЛАПАН ВПУСКНОЙ] 12584763 VALVE, INT (0.075MM O.S.) (0.297) [КЛАПАН ВПУСКНОЙ] 24100294 ARM, VLV RKR [РЫЧАГ] 24100005 ADJUSTER, HYD VLV LASH (ACDelco #24100005) [ТОЛКАТЕЛЬ КЛАПАНА ДВИГАТЕЛЯ] 12565836 SEAL, VLV STEM OIL [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КЛАПАНА ДВИГАТЕЛЯ] 12575355 ПРУЖИНА, VLV [ПРУЖИНА КЛАПАНА] 12575196 RETAINER, VLV SPR [КОМПАКТ ДИСК] 12575197 KEY, VLV STEM [КЛАПАННЫЙ КЛЮЧ] not found CAP, CM/SHF BRG (ЧАСТЬ OF 300) 12574477 RING, CM/SHF SPKT OIL SEAL (ЧАСТЬ OF 330, 331) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО РАСПРЕДВАЛА ДВИГАТЕЛЯ (2 ШТ.)] 12604375 CAMSHAFT, EXH (INCLS 329) [РАСПРЕДВАЛ] 12604376 CAMSHAFT, EXH (INCLS 329) [РАСПРЕДВАЛ] 12604374 CAMSHAFT, INT (INCLS 329) [РАСПРЕДВАЛ] teamcadillac.ru 12604377 CAMSHAFT, INT (INCLS 329) [РАСПРЕДВАЛ] not found CAP, CM/SHF BRG (ЧАСТЬ OF 300) 11518856 HFH, M6X1X43.4, 14.8 THD, 11 O.D., 8.8, GMW3179 CODE G (ЧАСТЬ OF 300) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12580965 VALVE, ENG OIL MANIF CHK [КЛАПАН] 12613057 РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ, IGN (INCLS 705) (ACDelco #12613057) 11588715 БОЛТ, HFH, M6X1X35, 18 THD, 14.2 OD, 8.8, GMW3359, 5MM M POINT (ЧАСТЬ OF 704) [БОЛТ] 12566778 SENSOR, ENG COOL TEMP (3.682) (ACDelco #213-1581) [СЕНСОР ТЕМПЕРАТУРЫ] 12566778 SENSOR, ENG COOL TEMP (ACDelco #213-1581) [СЕНСОР ТЕМПЕРАТУРЫ] 12597464 СВЕЧИ, (DO NOT CHANGE СВЕЧИ GAP) (ACDelco #41-990) (PLATINUM PLUG) [СВЕЧА ЗАЖИГАНИЯ] 12600313 SEAL, F/PMP HSG (O RING) (ЧАСТЬ OF 902) (ACDelco #G43) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ДВИГАТЕЛЯ] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 902) 12626234 PUMP, FUEL (INCLS 900, 901, 903) (ACDelco #EP2129) [ТОПЛИВНЫЙ НАСОС] 12595951 GASKET, F/PMP BRKT (ЧАСТЬ OF 902) [ПРОКЛАДКА ТОПЛИВНОГО НАСОСА] 12593348 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 258) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА] 12590679 FOLLOWER, VLV LFTR (FUEL PUMP) [НАПРАВЛЯЮЩАЯ ВТУЛКА ТОПЛИВНОГО НАСОСА] not found RAIL, DIR F/INJN FUEL (СМ. ГРУППУ 03.000 "FUEL RAIL" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11519171 БОЛТ, F/INJN FUEL RL (M8X1.25X50) (3.275) [БОЛТ ВЫПУСКНОГО КОЛЛЕКТОРА] 12625782 GASKET KIT, CYL HD (INCLS 251, 256, 302) [КОМПЛЕКТ ПРОКЛАДОК ГОЛОВКИ БЛОКА ЦИЛИНДРОВ (ПАР-2ШТ, РЕЗ-2ШТ, МЕТ-1ШТ)] (6D00-050) - 2008 DM69 ДВИГАТЕЛЬ В СБОРЕ-2.8L V6 ЧАСТЬ 5 КОЛЛЕКТОР & ДЕТАЛИ КОМПЛЕКТА (LP1/2.8T) ↓ 12604933 TUBE, PCV (FRESH AIR) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (PCV TUBE) 12616910 HOSE, PCV (INCLS 285, 286, 290-292) (DIRTY AIR) 12616908 SEAL, PCV HOSE FTG (O RING) (ЧАСТЬ OF 283) (BLUE) (LARGER OF THE TWO ON THE FITTING) [УПЛОТНЕНИЕ] 12616909 SEAL, PCV HOSE FTG (O RING) (ЧАСТЬ OF 283) (BLACK) (SMALLER OF THE TWO ON THE FITTING) [УЛОТНЕНИЕ] not found BRACKET, PCV VLV HOSE (ЧАСТЬ OF 283) not found BRACKET, PCV VLV HOSE (ЧАСТЬ OF 283) not found CLIP, PCV VLV HOSE (ЧАСТЬ OF 283) 12597853 MANIFOLD, UPR INT (MACH) (INCLS 506) 12571079 MANIFOLD, LWR INT (INCLS 519) not found PLUG, INT MANIF (ЧАСТЬ OF 503) 11518906 БОЛТ, HFH, RDUCD BDY, M8X1.25X165, 22 THD, 18 O.D., 8.8, GMW3359 (INT UPR MANIF) [БОЛТ] 11519176 БОЛТ, INT MANIF (M8X1.25X80) (4.081) [БОЛТ] not found PIN, UPR INT MANIF LOC (ЧАСТЬ OF 504) not found GASKET, UPR INT MANIF (*KIT1, KIT2, KIT3) not found GASKET, LWR INT MANIF (*KIT1, KIT3) 11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (LWR INT MANIF) 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (F/INJN FUEL RL) [БОЛТ] 11588523 STUD, M6X1 (UPR INT MANIF SIGHT SHLD) 12576262 GASKET, EXH MANIF [ПРОКЛАДКА ВЫПУСКНОГО КОЛЛЕКТОРА] 12571102 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 12580706 SHIELD, EXH MANIF HT 11518860 БОЛТ, HFH, M8X1.25X30, 20.9 THD, 18 O.D., 10.9, GMW3179 CODE G, GM6194M (EXH MANIF H/SHLD) [БОЛТ] 12582663 INSULATOR, EXH MANIF UPR 12616647 SHIELD, STRTR HT 12576263 GASKET, EXH MANIF 12571101 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 11518860 БОЛТ, HFH, M8X1.25X30, 20.9 THD, 18 O.D., 10.9, GMW3179 CODE G, GM6194M (EXH MANIF H/SHLD) [БОЛТ] 12617267 SHIELD, EXH MANIF HT 12581807 INSULATOR, EXH MANIF LWR 14093869 ГАЙКА, PUSH ON, M6, 2.25THK, 12.95 O.D., STL, POR (EXH MANIF H/SHLD INSL) 12616994 BODY, THROT (W/THROT ACTR) (ACDelco #217-3103) [ЧАСТЬ КОРПУСА] 11519972 БОЛТ, THROT BODY (M6X1.0X50) 12593360 GASKET, THROT BODY (ACDelco #40-5083) [ПРОКЛАДКА ДРОССЕЛЬНОЙ ЗАСЛОНКИ] 12611801 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 752) (ACDelco #214-1685) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 12611801 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 752) (ACDelco #214-1685) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 12611801 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 752) (ACDelco #214-1685) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 12611801 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 752) (ACDelco #214-1685) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 12611801 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 752) (ACDelco #214-1685) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (EVAP EMIS CNSTR PURGE SOL VLV BRKT) 12584171 HOSE, EVAP EMIS CNSTR SOL VLV not found BRACKET, SOL VLV (ЧАСТЬ OF 744) 12629734 VALVE, INT MANIF TUNING (INCLS 756) not found SEAL, INT MANIF TUNING VLV (ЧАСТЬ OF 755) 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (INT MANIF TUNING VLV) [БОЛТ] not found RAIL, F/INJN FUEL (СМ. ГРУППУ 03.000 "FUEL INJECTION RAIL" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 12604673 BRACE, INT MANIF 11588723 БОЛТ, HFH, M8X1.25X25, 18 THD, 18 OD, 8.8 STL, GMW3359, M-PT (INT MANIF BR) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (INT MANIF BR) teamcadillac.ru 12617801 GASKET KIT, CYL HD (INCLS 521, 522) 12595277 GASKET KIT, UPR INT MANIF (INCLS 521) [ПРОКЛАДКА] 12598158 GASKET KIT, INT MANIF (INCLS 521, 522) [ПРОКЛАДКА ДВИГАТЕЛЯ] (6D00-050) - 2008-2009 DM69 ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 5 КОЛЛЕКТОР & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7) ↓ 12604933 TUBE, PCV (FRESH AIR) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (PCV TUBE) 12616910 HOSE, PCV (INCLS 285, 286, 290-292) (DIRTY AIR) 12616908 SEAL, PCV HOSE FTG (O RING) (ЧАСТЬ OF 283) (BLUE) (LARGER OF THE TWO ON THE FITTING) [УПЛОТНЕНИЕ] 12616909 SEAL, PCV HOSE FTG (O RING) (ЧАСТЬ OF 283) (BLACK) (SMALLER OF THE TWO ON THE FITTING) [УЛОТНЕНИЕ] not found BRACKET, PCV VLV HOSE (ЧАСТЬ OF 283) not found BRACKET, PCV VLV HOSE (ЧАСТЬ OF 283) not found CLIP, PCV VLV HOSE (ЧАСТЬ OF 283) 12597853 MANIFOLD, UPR INT (MACH) (INCLS 506) 12571079 MANIFOLD, LWR INT (INCLS 519) not found PLUG, INT MANIF (ЧАСТЬ OF 503) 11518906 БОЛТ, HFH, RDUCD BDY, M8X1.25X165, 22 THD, 18 O.D., 8.8, GMW3359 (INT UPR MANIF) [БОЛТ] 11519176 БОЛТ, INT MANIF (M8X1.25X80) (4.081) [БОЛТ] not found PIN, UPR INT MANIF LOC (ЧАСТЬ OF 504) not found GASKET, UPR INT MANIF (*KIT1, KIT2, KIT3) not found GASKET, LWR INT MANIF (*KIT1, KIT3) teamcadillac.ru 11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (LWR INT MANIF) 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (F/INJN FUEL RL) [БОЛТ] 11588523 STUD, M6X1 (UPR INT MANIF SIGHT SHLD) 12576262 GASKET, EXH MANIF [ПРОКЛАДКА ВЫПУСКНОГО КОЛЛЕКТОРА] 12571102 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 12580706 SHIELD, EXH MANIF HT 11518860 БОЛТ, HFH, M8X1.25X30, 20.9 THD, 18 O.D., 10.9, GMW3179 CODE G, GM6194M (EXH MANIF H/SHLD) [БОЛТ] 12582663 INSULATOR, EXH MANIF UPR 12616647 SHIELD, STRTR HT 12576263 GASKET, EXH MANIF 12571101 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 11518860 БОЛТ, HFH, M8X1.25X30, 20.9 THD, 18 O.D., 10.9, GMW3179 CODE G, GM6194M (EXH MANIF H/SHLD) [БОЛТ] 12617267 SHIELD, EXH MANIF HT 12581807 INSULATOR, EXH MANIF LWR 14093869 ГАЙКА, PUSH ON, M6, 2.25THK, 12.95 O.D., STL, POR (EXH MANIF H/SHLD INSL) 12616994 BODY, THROT (W/THROT ACTR) (ACDelco #217-3103) [ЧАСТЬ КОРПУСА] 11519972 БОЛТ, THROT BODY (M6X1.0X50) 12593360 GASKET, THROT BODY (ACDelco #40-5083) [ПРОКЛАДКА ДРОССЕЛЬНОЙ ЗАСЛОНКИ] 12611801 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 752) (ACDelco #214-1685) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 12611801 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 752) (ACDelco #214-1685) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 12611801 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 752) (ACDelco #214-1685) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 12611801 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 752) (ACDelco #214-1685) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (EVAP EMIS CNSTR PURGE SOL VLV BRKT) 12584171 HOSE, EVAP EMIS CNSTR SOL VLV not found BRACKET, SOL VLV (ЧАСТЬ OF 744) 12629734 VALVE, INT MANIF TUNING (INCLS 756) not found SEAL, INT MANIF TUNING VLV (ЧАСТЬ OF 755) 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (INT MANIF TUNING VLV) [БОЛТ] not found RAIL, F/INJN FUEL (СМ. ГРУППУ 03.000 "FUEL INJECTION RAIL" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 12604673 BRACE, INT MANIF 11588723 БОЛТ, HFH, M8X1.25X25, 18 THD, 18 OD, 8.8 STL, GMW3359, M-PT (INT MANIF BR) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (INT MANIF BR) 12625781 GASKET KIT, CYL HD (INCLS 521, 522) (INCLS UPR & LWR INT MANIF GASKETS) [КОМПЛЕКТ ПРОКЛАДОК ВПУСКНОГО КОЛЛЕКТОРА (2ШТ)] 12595277 GASKET KIT, UPR INT MANIF (INCLS 521) [ПРОКЛАДКА] 12598158 GASKET KIT, INT MANIF (INCLS 521, 522) [ПРОКЛАДКА ДВИГАТЕЛЯ] (6D00-051) - 2008 DM69 ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 5 КОЛЛЕКТОР & ДЕТАЛИ КОМПЛЕКТА (LLT/3.6V) ↓ 12604933 TUBE, PCV (FRESH AIR) 12616915 TUBE, PCV (FOUL AIR) [ТРУБКА] 12604933 TUBE, PCV (INCLS 285, 286) (FRESH AIR) 12616915 TUBE, PCV (INCLS 285, 286) (FOUL AIR) [ТРУБКА] 12616908 SEAL, PCV HOSE FTG (O RING) (ЧАСТЬ OF 283) (BLUE) (LARGER OF THE TWO ON THE FITTING) [УПЛОТНЕНИЕ] 12616909 SEAL, PCV HOSE FTG (O RING) (ЧАСТЬ OF 283) (BLACK) (SMALLER OF THE TWO ON THE FITTING) [УЛОТНЕНИЕ] 12595765 MANIFOLD, INT (INCLS 918) [ГЛУШИТЕЛЬ] 11610106 БОЛТ-HFH, M8X1.25X126.8, 21.6 THD, 18 OD, 8.8, GMW3359, M-PT (INT MANIF) 11588735 БОЛТ, HFH, M8X1.25X100, 22 THD, 18 OD, 8.8 STL, GMW3359, M-PT (INT MANIF) 12590958 GASKET, LWR INT MANIF (*KIT1, KIT2) [ПРОКЛАДКА ВПУСКНОГО КОЛЛЕКТОРА ДВИГАТЕЛЯ] 12610850 SHIELD, FUEL PIPE 12610850 SHIELD, FUEL PIPE 11588723 БОЛТ, HFH, M8X1.25X25, 18 THD, 18 OD, 8.8 STL, GMW3359, M-PT (FUEL PIPE SHLD) 12576262 GASKET, EXH MANIF [ПРОКЛАДКА ВЫПУСКНОГО КОЛЛЕКТОРА] 12571102 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 12580706 SHIELD, EXH MANIF HT 11518860 БОЛТ, HFH, M8X1.25X30, 20.9 THD, 18 O.D., 10.9, GMW3179 CODE G, GM6194M (EXH MANIF H/SHLD) [БОЛТ] 12582663 INSULATOR, EXH MANIF UPR 12616647 SHIELD, STRTR HT 12576263 GASKET, EXH MANIF 12571101 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 11518860 БОЛТ, HFH, M8X1.25X30, 20.9 THD, 18 O.D., 10.9, GMW3179 CODE G, GM6194M (EXH MANIF H/SHLD) [БОЛТ] 12617267 SHIELD, EXH MANIF HT 12581807 INSULATOR, EXH MANIF LWR 14093869 ГАЙКА, PUSH ON, M6, 2.25THK, 12.95 O.D., STL, POR (EXH MANIF H/SHLD INSL) 12616994 BODY, THROT (W/THROT ACTR) (ACDelco #217-3103) [ЧАСТЬ КОРПУСА] 11519972 БОЛТ, THROT BODY (M6X1.0X50) 12606638 GASKET, THROT BODY (ACDelco #40-5093) [ПРОКЛАДКА] 12611801 VALVE, EVAP EMIS CNSTR PURGE SOL (ACDelco #214-1685) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 12611801 VALVE, EVAP EMIS CNSTR PURGE SOL (ACDelco #214-1685) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 12584171 HOSE, EVAP EMIS CNSTR SOL VLV 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (EVAP EMIS CNSTR PURGE SOL VLV BRKT) 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (INT MANIF) 12595766 COVER, INT MANIF (PLENUM TOP COVER) [КРЫШКА] 12630022 SHIELD, ENG RR NOISE 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (INT MANIF) 12595767 BRACE, INT MANIF 12617977 SHIELD, F/INJN FUEL RL NOISE 12611315 SHIELD, F/INJN FUEL RL NOISE (LWR) teamcadillac.ru 12574525 VALVE, FUEL PRESS SERV (ЧАСТЬ OF 913) (SCHRADER VALVE LESS CAP) [КЛАПАН КОНТРОЛЯ ДАВЛЕНИЯ ТОПЛИВНОЙ СИСТЕМЫ] 25532662 CAP, FUEL PRESS SERV VLV (ЧАСТЬ OF 913) (CAP FOR PRESSURE TEST SCHRADER VALVE) (3.163) (ACDelco #214-1044) [КРЫШКА] 25532662 CAP, FUEL PRESS SERV VLV (ЧАСТЬ OF 913) (CAP FOR PRESSURE TEST SCHRADER VALVE) (3.163) (ACDelco #214-1044) [КРЫШКА] 25532662 CAP, FUEL PRESS SERV VLV (ЧАСТЬ OF 913) (CAP FOR PRESSURE TEST SCHRADER VALVE) (3.163) (ACDelco #214-1044) [КРЫШКА] 12591003 TUBE, F/INJN FUEL RL C/OVR 11589040 БОЛТ, F/INJN FUEL FEED & RTN PIPE RET (4.115) [БОЛТ М10] 12591197 PIPE, FUEL FEED INTER [ТРУБКА ТОПЛИВНОЙ СИСТЕМЫ] 12626234 PUMP, FUEL (СМ. ГРУППУ 00.000 "ГОЛОВКА ЦИЛИНДРОВ & ДЕТАЛИ КОМПЛЕКТА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #EP2129) [ТОПЛИВНЫЙ НАСОС] 12614933 PIPE, FUEL FEED (LOW PRESSURE W/DAMPER CAN & SERVICE PORT. INLET TO HIGH PRESSURE FUEL PUMP) (INCLS 907, 908) [ШЛАНГ] 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (EXH MANIF H/SHLD) [БОЛТ] 11519977 БОЛТ- HFH, M8X1.25X25, 16 THD, 18 OD, 8.8, GMW3359, MAT-PT. (INT MANIF) 11589278 БОЛТ-HFH, M12X1.75X75.9, 45 THD, 26.6 OD, 10.9, GMW3359, REDUCED BODY (INT MANIF BR) 11588723 БОЛТ, HFH, M8X1.25X25, 18 THD, 18 OD, 8.8 STL, GMW3359, M-PT (FUEL PIPE SHLD) 00104918 BALL, 1/4" DIA, CHROME STL (ЧАСТЬ OF 503) (ACDelco #104918) 11588735 БОЛТ, HFH, M8X1.25X100, 22 THD, 18 OD, 8.8 STL, GMW3359, M-PT (INT MANIF) not found GASKET, INT MANIF CVR (*KIT2) not found GASKET, INT MANIF CVR (*KIT2) not found RAIL, DIR F/INJN FUEL (СМ. ГРУППУ 03.000 "FUEL INJECTION RAIL" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11519171 БОЛТ, F/INJN FUEL RL (M8X1.25X50) (3.275) [БОЛТ ВЫПУСКНОГО КОЛЛЕКТОРА] 12625782 GASKET KIT, CYL HD (INCLS 522) [КОМПЛЕКТ ПРОКЛАДОК ГОЛОВКИ БЛОКА ЦИЛИНДРОВ (ПАР-2ШТ, РЕЗ-2ШТ, МЕТ-1ШТ)] 12615968 GASKET KIT, INT MANIF (INCLS 522, 920, 921) [КОМППЛЕКТ ПРОКЛАДОК ВЫХЛОПНОЙ СИСТЕМЫ(МЕТАЛЛ 1ШТ, РЕЗИНА 1ШТ)] (6D00-052) - 2008 DM69 ДВИГАТЕЛЬ В СБОРЕ & ЧАСТЬIAL ДВИГАТЕЛЬ (LLT/3.6V) ↓ not found ДВИГАТЕЛЬ, 3.6 L (220 CID) not found ДВИГАТЕЛЬ KIT, GASOLINE (GOODWRENCH) not found ДВИГАТЕЛЬ, GASOLINE (GOODWRENCH NEW) not found ДВИГАТЕЛЬ, GASOLINE (GOODWRENCH REMAN) 12621267 ДВИГАТЕЛЬ KIT, GASOLINE (GOODWRENCH) [ДВИГАТЕЛЬ БЕНЗИН, 6 ЦИЛ., 3.6Л, 270Л.С.] (6D00-054) - 2008 DM69 КРЕПЛЕНИЕ ДВИГАТЕЛЯ TO ТРАНСМИССИЯ (AUTOMATIC MYB) ↓ 12603197 PLATE, A/TRNS FLEX 12603197 PLATE, A/TRNS FLEX 12603197 PLATE, A/TRNS FLEX 12597210 PIN, TRANS LOC not found БОЛТ, TRANSAXLE T/CV 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] 24242043 БОЛТ, TRANS CONV CVR (M6X1X18/M6X1X14) teamcadillac.ru not found COVER, TRANS 24222918 COVER, TRANS CONV 24222918 COVER, TRANS (0.679) 24205900 COVER, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] (6D00-060) - 2008 DM69 ДВИГАТЕЛЬ В СБОРЕ & ЧАСТЬIAL ДВИГАТЕЛЬ (LY7/3.6-7) ↓ not found ДВИГАТЕЛЬ, 3.6 L (220 CID) (PRODUCTION) 12617625 ДВИГАТЕЛЬ KIT, GASOLINE (GOODWRENCH) (MUST SWAP МАСЛЯНЫЙ ПОДДОН) (SERVICE) 19206165 ДВИГАТЕЛЬ, (SERV ЧАСТЬIAL) (SERVICE) (MAY NEED TO SWAP МАСЛЯНЫЙ ПОДДОН) (REQUIRES CRANKSHAFT BALANCER WITH KEYWAY. FOR SINGLE BELT, USE 12603181. FOR DUAL BELT BALANCER USE 12603180) (6M00-072) - 2008 DM69 INTAKE MANIFOLD SHIELD/COVERS (LLT/3.6V) ↓ 12632150 COVER, INT MANIF (INCLS 2, 12-16, 19) (ДВИГАТЕЛЬ COVER) 12632150 COVER, INT MANIF (INCLS 2, 12-16, 19) (ДВИГАТЕЛЬ COVER) (3.265) not found INSULATOR, INT MANIF CVR (ЧАСТЬ OF 1) 20664092 RETAINER, UPR INT MANIF SIGHT SHLD (BLACK) (6.3MM DIA X 23MM) (1.276) [КЛИПСА КРЕПЛЕНИЯ МОЛДИНГА ДВЕРИ] 12603359 INSULATOR, INT MANIF [УПЛОТНИТЕЛЬ] 11588723 БОЛТ, HFH, M8X1.25X25, 18 THD, 18 OD, 8.8 STL, GMW3359, M-PT (INT MANIF SIGHT SHLD) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (INT MANIF SIGHT SHLD) 11516075 ГАЙКА, HFH SELF LK, M6X1, 7.7THK, 14.2 O.D., 9, PZOR (INT MANIF SIGHT SHLD BRKT) [ГАЙКА ВЫПУСКНОЙ СИСТЕМЫ D=6ММ] 11588967 STUD, BALL W/HFH, M6X1X20.65, 14.2 O.D., 8.8, GMW3359 (INT MANIF SIGHT SHLD) 12616618 BRACKET, INT MANIF SIGHT SHLD 12593348 SEAL, OIL FIL TUBE (O RING) (27.94MM I.D.) (SIZE #320) (1.758) [ПРОКЛАДКА] 12615294 TUBE, OIL FIL (INCLS 17, 18) [ТРУБКА МАСЛЯНОГО ФИЛЬТРА] teamcadillac.ru 12591714 GROMMET, UPR INT MANIF SIGHT SHLD (ЧАСТЬ OF 1) (60MM OD @ TOP) (ROUND TOP & BOTTOM) not found INSULATOR, F/INJR SIGHT SHLD BRKT (ЧАСТЬ OF 1) 10042521 ГАЙКА, INT MANIF INSL (ЧАСТЬ OF 1) (7.831) 12591715 GROMMET, UPR INT MANIF SIGHT SHLD (ЧАСТЬ OF 1) (32MM OD @ TOP) (ROUND AT TOP/TAPERED CONICAL BOTTOM) 12607405 EMBLEM, INT MANIF CVR (ЧАСТЬ OF 1) [ЭМБЛЕМА] 12593356 CAP, OIL FIL (ЧАСТЬ OF 11) (INCLS 18) (ACDelco #FC221) [КРЫШКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ] 12593348 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 11, 17) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА] 24507878 INSULATOR, F/INJR SIGHT SHLD BRKT (ЧАСТЬ OF 1) 12630022 SHIELD, ENG RR NOISE not found SHIELD, FUEL PIPE 12610850 SHIELD, FUEL PIPE 12610850 SHIELD, FUEL PIPE 11588723 БОЛТ, HFH, M8X1.25X25, 18 THD, 18 OD, 8.8 STL, GMW3359, M-PT (FUEL PIPE SHLD) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (FUEL PIPE SHLD) (6M00-073) - 2008-2009 DM69 ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 4 МАСЛЯНЫЙ НАСОС,МАСЛЯНЫЙ ПОДДОН & ДЕТАЛИ КОМПЛЕКТА (LLT/3.6V, ПОЛНОПРИВОДНЫЙ MX7) ↓ 22531637 PIN, МАСЛЯНЫЙ ПОДДОН LOC (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 12586959 GUIDE, TMG CHAIN (ЧАСТЬ OF 463) (2 КРЕПЛЕНИЕ HOLES) (LOWER PRIMARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ГРМ] 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (ЧАСТЬ OF 463) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12596502 PAN, OIL (INCLS 404-407, 410, 412, 413, 420, 422, 900) 12575500 PLATE, МАСЛЯНЫЙ ПОДДОН SKID (ЧАСТЬ OF 400) 12575373 PIPE, O/PMP SUC (ЧАСТЬ OF 400) 12566837 SEAL, O/PMP SUC PIPE (ЧАСТЬ OF 400) [УПЛОТНЕНИЕ] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 400) 12566872 DEFLECTOR, CR/SHF OIL (ЧАСТЬ OF 400) 11562588 PLUG, МАСЛЯНЫЙ ПОДДОН DRN (ЧАСТЬ OF 400) (INCLS 413) (W/ SEAL) (EXC MAGNET) [ЗАГЛУШКА МАСЛЯНОГО ПОДДОНА] 12616850 SEAL, МАСЛЯНЫЙ ПОДДОН DRN PLUG (O RING) (ЧАСТЬ OF 400, 412) 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (ЧАСТЬ OF 400) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11588424 БОЛТ, HFH, M6X1X145, 18 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 400) [ШЕСТИГРАННЫЙ ВИНТ] 12611594 INDICATOR, OIL LVL (INCLS 434) 12612349 TUBE, OIL LVL IND (INCLS 432) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 431) (BLACK) (6.07MM ID, 1.78MM DIA) (INDICATOR) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 431) (BLACK) (6.07MM ID, 1.78MM DIA) (TUBE) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (OIL LVL IND TUBE) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) (INDICATOR) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) (TUBE) 12591607 ADAPTER, OIL FLTR (INCLS 441-443, 446-450, 456, 458, 459, 728, 729) [АДАПТЕР МАСЛЯНОГО ФИЛЬТРА] 12591604 GASKET, OIL FLTR (ЧАСТЬ OF 440) (BETWEEN OIL FILTER ADAPTER AND BLOCK) [ПРОКЛАДКА МАСЛЯНОГО ФИЛЬТРА] 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 440) 11519174 БОЛТ, HFH, W/REDUCED BODY, M8X1.25X65, THD 22, O.D. 18, 8.8, GMW3359 (ЧАСТЬ OF 440) 25014612 VALVE, OIL FLTR BYPASS (ЧАСТЬ OF 440, 450) (W/O VAPOR SEPARATOR) (OPENING PRESSURE 21 PSI NOMINAL) (ЧАСТЬ HAS A 16.10MM MAX OD & FITS A 15.84 HOLE IN BLOCK) 11519184 БОЛТ, OIL FLTR ADAP (ЧАСТЬ OF 440) (M10X1.5X45) (0.029) not found SPACER, OIL FLTR (ЧАСТЬ OF 440) 25177917 ФИЛЬТР, МАСЛЯНЫЙ (ЧАСТЬ OF 440) (ACDelco #PF2129) [МАСЛЯНЫЙ ФИЛЬТР ДВИГАТЕЛЯ] 12583470 CAP, OIL FLTR (ЧАСТЬ OF 440) (INCLS 446, 451, 456) [КРЫШКА] 12577653 SEAL, OIL FLTR CAP (O RING) (ЧАСТЬ OF 450) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КРЫШКИ МАСЛЯНОГО ФИЛЬТРА] not found RETAINER, OIL FLTR BYPASS VLV SPR (ЧАСТЬ OF 440, 450) not found CAGE, OIL FLTR BYPASS VLV (ЧАСТЬ OF 440) not found SEAL, OIL FLTR DRN PLUG (O RING) (ЧАСТЬ OF 440) 12590152 PUMP, OIL (INCLS 151, 154, 464-466, 468, 470-472, 474, 475) (INCLS GUIDE, БОЛТS) [МАСЛЕННЫЙ НАСОС] not found COVER, O/PMP (ЧАСТЬ OF 463) not found GEAR, O/PMP (ЧАСТЬ OF 463) not found GEAR, O/PMP IDLER (ЧАСТЬ OF 463) not found БОЛТ, O/PMP CVR (ЧАСТЬ OF 463) not found PLUG, OIL PRESS RLF VLV BORE (ЧАСТЬ OF 463) not found ПРУЖИНА, OIL PRESS RLF VLV (ЧАСТЬ OF 463) not found VALVE, OIL PRESS RLF (ЧАСТЬ OF 463) not found RETAINER, OIL PRESS RLF VLV SPR (ЧАСТЬ OF 463) 11900371 БОЛТ, HEX HD, W/1.6 FLAT WA, M8X1.25X54.3, 43 THD, 16O.D., 8.8, GMW3359 (ЧАСТЬ OF 463) 12610143 NOZZLE, PSTN OIL (INCLS 491) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 490) 12621659 SENSOR, ENG OIL PRESS (INCLS 729) (ЧАСТЬ OF 440) (ACDelco #12621659) not found SEAL, ENG OIL PRESS SEN (O RING) (ЧАСТЬ OF 440, 728) teamcadillac.ru 11588734 БОЛТ, HFH, M8X1.25X90, 21.6 THD, 18 O.D., 8.8, GMW3359 (ЧАСТЬ OF 400) [ВИНТ] (6M00-073) - 2008-2009 DM69 ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 4 МАСЛЯНЫЙ НАСОС,МАСЛЯНЫЙ ПОДДОН & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7, ПОЛНОПРИВОДНЫЙ MX7) ↓ 22531637 PIN, МАСЛЯНЫЙ ПОДДОН LOC (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 12586959 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (LOWER PRIMARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ГРМ] 12586960 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАТЯЖИТЕЛЬ ЦЕПИ] 12586961 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАПРАВЛЯЮЩАЯ ПРИВОДНОЙ ЦЕПИ] 12597417 GUIDE, TMG CHAIN (UPPER PRIMARY) 12600461 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ПРИВОДА ГРМ] 12600462 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ПРИВОДА ГРМ] 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (ЧАСТЬ OF 463) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12596502 PAN, OIL (INCLS 404-407, 410, 412, 413, 420, 422, 900) not found PLATE, МАСЛЯНЫЙ ПОДДОН SKID (ЧАСТЬ OF 400) 12575373 PIPE, O/PMP SUC (ЧАСТЬ OF 400) 12590407 PIPE, O/PMP SUC (ЧАСТЬ OF 400) 12566837 SEAL, O/PMP SUC PIPE (ЧАСТЬ OF 400) [УПЛОТНЕНИЕ] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 400) 12566872 DEFLECTOR, CR/SHF OIL (ЧАСТЬ OF 400) 11562588 PLUG, МАСЛЯНЫЙ ПОДДОН DRN (ЧАСТЬ OF 400) (INCLS 413) (W/ SEAL) (EXC MAGNET) [ЗАГЛУШКА МАСЛЯНОГО ПОДДОНА] 12616850 SEAL, МАСЛЯНЫЙ ПОДДОН DRN PLUG (O RING) (ЧАСТЬ OF 400, 412) 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (ЧАСТЬ OF 400) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11588424 БОЛТ, HFH, M6X1X145, 18 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 400) [ШЕСТИГРАННЫЙ ВИНТ] 12611594 INDICATOR, OIL LVL (INCLS 434) 12612349 TUBE, OIL LVL IND (INCLS 432) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 431) (BLACK) (6.07MM ID, 1.78MM DIA) (INDICATOR) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 431) (BLACK) (6.07MM ID, 1.78MM DIA) (TUBE) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (OIL LVL IND TUBE) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) (INDICATOR) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) (TUBE) 12591607 ADAPTER, OIL FLTR (INCLS 441-443, 446-450, 456, 458, 459, 728, 729) [АДАПТЕР МАСЛЯНОГО ФИЛЬТРА] 12591604 GASKET, OIL FLTR (ЧАСТЬ OF 440) (BETWEEN OIL FILTER ADAPTER AND BLOCK) [ПРОКЛАДКА МАСЛЯНОГО ФИЛЬТРА] 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 440) 11519174 БОЛТ, HFH, W/REDUCED BODY, M8X1.25X65, THD 22, O.D. 18, 8.8, GMW3359 (ЧАСТЬ OF 440) 25014612 VALVE, OIL FLTR BYPASS (ЧАСТЬ OF 440, 450) (W/O VAPOR SEPARATOR) (OPENING PRESSURE 21 PSI NOMINAL) (ЧАСТЬ HAS A 16.10MM MAX OD & FITS A 15.84 HOLE IN BLOCK) 11519174 БОЛТ, OIL FLTR ADAP (БОЛТ, HFH, W/REDUCED BODY, M8X1.25X65, THD 22, O.D. 18, 8.8, GMW3359) (ЧАСТЬ OF 440) (M8X1.25X65) (8.900) 11519184 БОЛТ, OIL FLTR ADAP (ЧАСТЬ OF 440) (M10X1.5X45) (0.029) 11519980 БОЛТ, OIL FLTR ADAP (БОЛТ, HFH, W/REDUCED BODY, M8X1.25X65, THD 22, O.D. 18, 8.8, GMW3359) (ЧАСТЬ OF 440) (M8X1.25X40) (8.900) not found SPACER, OIL FLTR (ЧАСТЬ OF 440) 25177917 ФИЛЬТР, МАСЛЯНЫЙ (ЧАСТЬ OF 440) (ACDelco #PF2129) [МАСЛЯНЫЙ ФИЛЬТР ДВИГАТЕЛЯ] 12583470 CAP, OIL FLTR (ЧАСТЬ OF 440) (INCLS 446, 456) [КРЫШКА] 12577653 SEAL, OIL FLTR CAP (O RING) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КРЫШКИ МАСЛЯНОГО ФИЛЬТРА] not found RETAINER, OIL FLTR BYPASS VLV SPR (ЧАСТЬ OF 440, 450) not found CAGE, OIL FLTR BYPASS VLV (ЧАСТЬ OF 440) not found SEAL, OIL FLTR DRN PLUG (O RING) (ЧАСТЬ OF 440) 12590152 PUMP, OIL (INCLS 151, 154, 464-466, 468, 470-472, 474, 475) (INCLS GUIDE, БОЛТS) [МАСЛЕННЫЙ НАСОС] not found COVER, O/PMP (ЧАСТЬ OF 463) not found GEAR, O/PMP (ЧАСТЬ OF 463) not found GEAR, O/PMP IDLER (ЧАСТЬ OF 463) not found БОЛТ, O/PMP CVR (ЧАСТЬ OF 463) not found PLUG, OIL PRESS RLF VLV BORE (ЧАСТЬ OF 463) not found ПРУЖИНА, OIL PRESS RLF VLV (ЧАСТЬ OF 463) not found VALVE, OIL PRESS RLF (ЧАСТЬ OF 463) not found RETAINER, OIL PRESS RLF VLV SPR (ЧАСТЬ OF 463) 11900371 БОЛТ, HEX HD, W/1.6 FLAT WA, M8X1.25X54.3, 43 THD, 16O.D., 8.8, GMW3359 (ЧАСТЬ OF 463) 12610143 NOZZLE, PSTN OIL (INCLS 491) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 490) 12621659 SENSOR, ENG OIL PRESS (INCLS 729) (ЧАСТЬ OF 440) (ACDelco #12621659) teamcadillac.ru not found SEAL, ENG OIL PRESS SEN (O RING) (ЧАСТЬ OF 440, 728) 11588734 БОЛТ, HFH, M8X1.25X90, 21.6 THD, 18 O.D., 8.8, GMW3359 (ЧАСТЬ OF 400) [ВИНТ] (GM00-395) - 2008 DM69 ДВИГАТЕЛЬ В СБОРЕ-2.8L V6 ЧАСТЬ 3 ПЕРЕДНЯЯ КРЫШКА И ОХЛАЖДЕНИЕ (LP1/2.8T) ↓ 22531637 PIN, ENG FRT CVR LOC (ЧАСТЬ OF 350) (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 11519176 БОЛТ, ENG FRT CVR (ЧАСТЬ OF 350) (M8X1.25X80) (4.081) [БОЛТ] 12611883 COVER, ENG FRT (W/ W/PMP) (INCLS 132, 348, 351-354, 360-362, 725-727, 734, 900-903) [БОКОВАЯ КРЫШКА ДВИГАТЕЛЯ] 12593045 SEAL, W/PMP (ЧАСТЬ OF 350) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519171 БОЛТ, ENG FRT CVR (ЧАСТЬ OF 350) (M8X1.25X50) (3.275) [БОЛТ ВЫПУСКНОГО КОЛЛЕКТОРА] 12608750 SEAL, CR/SHF FRT OIL (ЧАСТЬ OF 350) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КОЛЕНВАЛА] 12594060 DEADENER, ENG FRT CVR (ЧАСТЬ OF 350) (BOTTOM) [ПРОКЛАДКА КРЫШКИ ДВИГАТЕЛЯ] 12618472 PUMP, WAT (W/GSKT) (ЧАСТЬ OF 350) (INCLS 900) (ACDelco #251-724) [НАСОС] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 350) 12576326 GASKET, W/PMP (ЧАСТЬ OF 350) (ACDelco #251-2048) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12574518 PULLEY, W/PMP (ADX) 11588940 БОЛТ, HEX HD, W/CON SPR WA, M6X1X14.55, 8.45 THD, 13.3O.D., 8.8.GMW3359 (W/PMP PUL) not found THERMOSTAT, ENG COOL (*KIT1) 12592527 GASKET, ENG COOL THERM HSG (*KIT1) (ACDelco #12592527) [ПРОКЛАДКА ТЕРМОСТАТА] not found ШЛАНГИ, ENG COOL THERM UPR (*KIT1) 11588719 БОЛТ, HFH, M6X1X60, 18MM THD, 14.2 O.D., 8.8, 3359GMW (ENG COOL THERM HSG) (*KIT1) 11588720 БОЛТ, HFH, M6X1X70, 18 THD, 14.2 OD, 8.8, GMW3359, MAT POINT. (ENG COOL THERM HSG) (*KIT1) 12584325 SEAL, ENG COOL THERM HSG (O RING) (*KIT1) [КОЛЬЦЕ-ОБРАЗНОЕ УПЛОТНЕНИЕ] 12582472 SEAL, ENG COOL THERM (*KIT1) (ACDelco #12582472) [УПЛОТНИТЕЛЬ] not found ШЛАНГИ, ENG COOL THERM LWR (*KIT1) 12566429 SEAL, WAT OTLT (ЧАСТЬ OF 380) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12584040 SEAL, CLNT OTLT (O RING) (ЧАСТЬ OF 380) (ACDelco #15-32584) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519974 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 380) [БОЛТ] 12573984 OUTLET, WAT (INCLS 377-379, 905) (INCLS БОЛТS, RETAINERS, SEALS & PIPE) (ACDelco #15-10429) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 12608424 SENSOR, CM/SHF POSN (ЧАСТЬ OF 350) (INCLS 726, 727) (ACDelco #12608424) [ДАТЧИК ПОЛОЖЕНИЯ РАСПРЕДВАЛА] 12593717 SEAL, CM/SHF POSN ACTR SOL VLV (O RING) (ЧАСТЬ OF 350, 725) 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 350, 725) 12615613 VALVE, CM/SHF POSN ACTR SOL 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (CM/SHF POSN ACTR SOL VLV) 12593717 SEAL, CM/SHF POSN ACTR SOL VLV (O RING) (ЧАСТЬ OF 350) not found PLUG, W/PMP (ЧАСТЬ OF 350, 360) not found DEADENER, ENG FRT CVR (ЧАСТЬ OF 350) teamcadillac.ru not found DEADENER, ENG FRT CVR (ЧАСТЬ OF 350) not found DEADENER, ENG FRT CVR (ЧАСТЬ OF 350) (FRONT) not found PIPE, ENG COOL AIR BL (ЧАСТЬ OF 380) 12620251 ШЛАНГИ, ENG COOL THERM (INCLS 365-368, 370-373) (INCLS THERMOSTAT) [ТЕРМОСТАТИЧЕСКИЙ РЕГУЛИРУЕМЫЙ КЛАПАН СИСТЕМЫ ОХЛАЖДЕНИЯ] (GM00-395) - 2008 DM69 ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 3 ПЕРЕДНЯЯ КРЫШКА И ОХЛАЖДЕНИЕ (LLT/3.6V) ↓ 22531637 PIN, ENG FRT CVR LOC (ЧАСТЬ OF 350) (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 11519176 БОЛТ, ENG FRT CVR (ЧАСТЬ OF 350) (M8X1.25X80) (4.081) [БОЛТ] 12611883 COVER, ENG FRT (W/ W/PMP) (INCLS 132, 348, 351-354, 360-362, 725-727, 734, 900-903) [БОКОВАЯ КРЫШКА ДВИГАТЕЛЯ] 12593045 SEAL, W/PMP (ЧАСТЬ OF 350) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519171 БОЛТ, ENG FRT CVR (ЧАСТЬ OF 350) (M8X1.25X50) (3.275) [БОЛТ ВЫПУСКНОГО КОЛЛЕКТОРА] 12608750 SEAL, CR/SHF FRT OIL (ЧАСТЬ OF 350) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КОЛЕНВАЛА] 12594060 DEADENER, ENG FRT CVR (ЧАСТЬ OF 350) (BOTTOM) [ПРОКЛАДКА КРЫШКИ ДВИГАТЕЛЯ] 12618472 PUMP, WAT (W/GSKT) (ЧАСТЬ OF 350) (INCLS 900) (ACDelco #251-724) [НАСОС] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 350) 12576326 GASKET, W/PMP (ЧАСТЬ OF 350) (ACDelco #251-2048) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12574518 PULLEY, W/PMP (ADX) 11519512 БОЛТ, HFH, W/CON SPR WA, M6X1X13.4, 8.77 THD, 12.3 O.D., 8.8, GMW3359 (W/PMP PUL) not found THERMOSTAT, ENG COOL (*KIT1) 12592527 GASKET, ENG COOL THERM HSG (*KIT1) (ACDelco #12592527) [ПРОКЛАДКА ТЕРМОСТАТА] not found THERMOSTAT, ENG COOL (W/WAT INL) (*KIT1) 11519973 БОЛТ-HFH, M6X1X60, 18MM THD, 14.2 OD, 8.8, 3359GMW, REDUCED BODY, MAT PT. (ENG COOL THERM HSG) (*KIT1) [БОЛТ 6Х1Х60] 11519974 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3359 (ENG COOL THERM HSG) (*KIT1) [БОЛТ] 12584325 SEAL, ENG COOL THERM HSG (O RING) (*KIT1) [КОЛЬЦЕ-ОБРАЗНОЕ УПЛОТНЕНИЕ] 12582472 SEAL, ENG COOL THERM (*KIT1) (ACDelco #12582472) [УПЛОТНИТЕЛЬ] not found ШЛАНГИ, ENG COOL THERM LWR (*KIT1) 12566429 SEAL, WAT OTLT (ЧАСТЬ OF 380) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12584040 SEAL, CLNT OTLT (O RING) (ЧАСТЬ OF 380) (ACDelco #15-32584) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519974 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 380) [БОЛТ] 12573984 OUTLET, WAT (INCLS 377-379, 905) (INCLS БОЛТS, RETAINERS, SEALS & PIPE) (ACDelco #15-10429) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 12608424 SENSOR, CM/SHF POSN (ЧАСТЬ OF 350) (INCLS 726, 727) (ACDelco #12608424) [ДАТЧИК ПОЛОЖЕНИЯ РАСПРЕДВАЛА] 12608424 SENSOR, CM/SHF POSN (ЧАСТЬ OF 350) (INCLS 726, 727) (ACDelco #12608424) [ДАТЧИК ПОЛОЖЕНИЯ РАСПРЕДВАЛА] 12608424 SENSOR, CM/SHF POSN (ЧАСТЬ OF 350) (INCLS 726, 727) (ACDelco #12608424) [ДАТЧИК ПОЛОЖЕНИЯ РАСПРЕДВАЛА] not found SEAL, CR/SHF POSN SEN (O RING) (ЧАСТЬ OF 350, 725) 11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (ЧАСТЬ OF 350, 725) [БОЛТ] 12615613 VALVE, CM/SHF POSN ACTR SOL 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (CM/SHF POSN ACTR SOL VLV) 12593717 SEAL, CM/SHF POSN ACTR SOL VLV (O RING) (ЧАСТЬ OF 350) not found PLUG, W/PMP (ЧАСТЬ OF 350, 360) not found DEADENER, ENG FRT CVR (ЧАСТЬ OF 350) (LEFT SIDE) not found DEADENER, ENG FRT CVR (ЧАСТЬ OF 350) (RIGHT SIDE) not found DEADENER, ENG FRT CVR (ЧАСТЬ OF 350) (FRONT) not found PIPE, ENG COOL AIR BL (ЧАСТЬ OF 380) teamcadillac.ru 12620251 ШЛАНГИ, ENG COOL THERM (INCLS 365-368, 370-373) (INCLS THERMOSTAT) [ТЕРМОСТАТИЧЕСКИЙ РЕГУЛИРУЕМЫЙ КЛАПАН СИСТЕМЫ ОХЛАЖДЕНИЯ] (GM00-395) - 2008-2009 DM69 ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 3 ПЕРЕДНЯЯ КРЫШКА И ОХЛАЖДЕНИЕ (LY7/3.6-7) ↓ 22531637 PIN, ENG FRT CVR LOC (ЧАСТЬ OF 350) (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 11519171 БОЛТ, ENG FRT CVR (ЧАСТЬ OF 350) (M8X1.25X50) (3.275) [БОЛТ ВЫПУСКНОГО КОЛЛЕКТОРА] 11519176 БОЛТ, ENG FRT CVR (ЧАСТЬ OF 350) (M8X1.25X80) (4.081) [БОЛТ] 12611883 COVER, ENG FRT (W/ W/PMP) (INCLS 132, 348, 351-354, 360-362, 725-727, 734, 900-903) [БОКОВАЯ КРЫШКА ДВИГАТЕЛЯ] 12593045 SEAL, W/PMP (ЧАСТЬ OF 350) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519171 БОЛТ, ENG FRT CVR (ЧАСТЬ OF 350) (M8X1.25X50) (3.275) [БОЛТ ВЫПУСКНОГО КОЛЛЕКТОРА] 12608750 SEAL, CR/SHF FRT OIL (ЧАСТЬ OF 350) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КОЛЕНВАЛА] 12594060 DEADENER, ENG FRT CVR (ЧАСТЬ OF 350) (BOTTOM) [ПРОКЛАДКА КРЫШКИ ДВИГАТЕЛЯ] 12618472 PUMP, WAT (W/GSKT) (ЧАСТЬ OF 350) (INCLS 900) (ACDelco #251-724) [НАСОС] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 350) 12576326 GASKET, W/PMP (ЧАСТЬ OF 350) (ACDelco #251-2048) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12574518 PULLEY, W/PMP (ADX) 11588940 БОЛТ, HEX HD, W/CON SPR WA, M6X1X14.55, 8.45 THD, 13.3O.D., 8.8.GMW3359 (W/PMP PUL) not found THERMOSTAT, ENG COOL (W/WAT INL) (*KIT1) 12592527 GASKET, ENG COOL THERM HSG (*KIT1) (ACDelco #12592527) [ПРОКЛАДКА ТЕРМОСТАТА] not found ШЛАНГИ, ENG COOL THERM UPR (*KIT1) 11588719 БОЛТ, HFH, M6X1X60, 18MM THD, 14.2 O.D., 8.8, 3359GMW (ENG COOL THERM HSG) (*KIT1) 11588720 БОЛТ, HFH, M6X1X70, 18 THD, 14.2 OD, 8.8, GMW3359, MAT POINT. (ENG COOL THERM HSG) (*KIT1) 12584325 SEAL, ENG COOL THERM HSG (O RING) (*KIT1) [КОЛЬЦЕ-ОБРАЗНОЕ УПЛОТНЕНИЕ] 12582472 SEAL, ENG COOL THERM (*KIT1) (ACDelco #12582472) [УПЛОТНИТЕЛЬ] not found ШЛАНГИ, ENG COOL THERM LWR (*KIT1) teamcadillac.ru 12566429 SEAL, WAT OTLT (ЧАСТЬ OF 380) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12584040 SEAL, CLNT OTLT (O RING) (ЧАСТЬ OF 380) (ACDelco #15-32584) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519974 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 380) [БОЛТ] 12573984 OUTLET, WAT (INCLS 377-379, 905) (INCLS БОЛТS, RETAINERS, SEALS & PIPE) (ACDelco #15-10429) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 12608424 SENSOR, CM/SHF POSN (ЧАСТЬ OF 350) (INCLS 726, 727) (ACDelco #12608424) [ДАТЧИК ПОЛОЖЕНИЯ РАСПРЕДВАЛА] 12593717 SEAL, CM/SHF POSN ACTR SOL VLV (O RING) (ЧАСТЬ OF 350, 725) 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 350, 725) 12615613 VALVE, CM/SHF POSN ACTR SOL 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (CM/SHF POSN ACTR SOL VLV) 12593717 SEAL, CM/SHF POSN ACTR SOL VLV (O RING) (ЧАСТЬ OF 350) not found PLUG, W/PMP (ЧАСТЬ OF 350, 360) not found DEADENER, ENG FRT CVR (ЧАСТЬ OF 350) (LEFT SIDE) not found DEADENER, ENG FRT CVR (ЧАСТЬ OF 350) (RIGHT SIDE) not found DEADENER, ENG FRT CVR (ЧАСТЬ OF 350) (FRONT) not found PIPE, ENG COOL AIR BL (ЧАСТЬ OF 380) 12620251 ШЛАНГИ, ENG COOL THERM (INCLS 365-368, 370-373) (INCLS THERMOSTAT) [ТЕРМОСТАТИЧЕСКИЙ РЕГУЛИРУЕМЫЙ КЛАПАН СИСТЕМЫ ОХЛАЖДЕНИЯ] (GM00-396) - 2008 DM69 ДВИГАТЕЛЬ В СБОРЕ-2.8L V6 ЧАСТЬ 2 ГОЛОВКА ЦИЛИНДРОВ & ДЕТАЛИ КОМПЛЕКТА (LP1/2.8T) ↓ not found BLOCK, ENG 12570326 PIN, CYL HD LOC [ЗАГЛУШКА БЛОКА ЦИЛИНДРОВ] 12606653 ACTUATOR, CM/SHF POSN (USE WASHER 12630941) 12603744 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) 12603745 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) 11588279 БОЛТ, HFH, M10X1.5X80, 26 THD, 22.3 O.D., 10.9, GM4277M (CM/SHF POSN) 12626055 COVER, CM/SHF (INCLS 251, 254-257, 260, 263) [КЛАПАННАЯ КРЫШКА ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12595106 SEAL, CM/SHF CVR (ЧАСТЬ OF 250) (*KIT1) (ACDelco #12595106) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12626054 COVER, CM/SHF (INCLS 253-257, 261, 263) [КРЫШКА] 12595107 SEAL, CM/SHF CVR (ЧАСТЬ OF 252) (*KIT1) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] not found SEAL, SPLG SHLD (ЧАСТЬ OF 250, 252) (*KIT1) 11570020 БОЛТ, CM/SHF CVR (ЧАСТЬ OF 250, 252) 12595122 INSULATOR, CM/SHF CVR БОЛТ (ЧАСТЬ OF 250, 252) not found INSERT, IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ БОЛТ THD (ЧАСТЬ OF 250, 252) 12593356 CAP, OIL FIL (INCLS 904) (ACDelco #FC221) [КРЫШКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ] 12593348 SEAL, OIL FIL TUBE (O RING) (ЧАСТЬ OF 262) (27.94MM I.D.) (SIZE #320) (1.758) [ПРОКЛАДКА] 12578316 FITTING, PCV (ЧАСТЬ OF 250) (INCLS 263) 12583384 FITTING, PCV (ЧАСТЬ OF 250) (INCLS 263) 12615294 TUBE, OIL FIL (INCLS 259) [ТРУБКА МАСЛЯНОГО ФИЛЬТРА] not found SEAL, PCV HOSE FTG (O RING) (ЧАСТЬ OF 250, 252, 260, 261) 12601744 INSULATOR, CM/SHF HSG CVR (0.413) 12601745 INSULATOR, CM/SHF HSG CVR [НАКЛАДКА КЛАПАННОЙ КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12603909 HEAD, CYL (MCHG) (INCLS 313, 318, 319, 328, 336, 337) (DOES NOT INCL ENG OIL MANIF CHECK VALVES. DLR MUST INSTL) [ГОЛОВКА БЛОКА ЦИЛИНДРОВ] 12603906 HEAD, CYL (MCHG) (INCLS 313, 318, 319, 328, 336, 337) (DOES NOT INCL ENG OIL MANIF CHECK VALVES. DLR MUST INSTL) [ГОЛОВКА БЛОКА ЦИЛИНДРОВ] not found GASKET, CYL HD (*KIT1) not found GASKET, CYL HD (*KIT1) teamcadillac.ru 11518863 БОЛТ, CYL HD [БОЛТ] 11519177 БОЛТ-HEX FLANGE HD, REDUCED BODY, M8X1.25X90, 8.8, GMW3359 (CYL HD) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11561751 PLUG, CYL HD WAT JKT HOLE (ЧАСТЬ OF 300, 301) (M20X1.5X30.5) (1.531) not found SLEEVE, SPLG WIRE (ЧАСТЬ OF 300, 301) 11562127 PLUG, CYL HD OIL GAL (ЧАСТЬ OF 300, 301) (CUP-14.22 OD, 6.6 THK, 304SS) 12575354 VALVE, EXH (STD) [КЛАПАН ВЫПУСКНОЙ] 12584760 VALVE, EXH (0.075 O.S.) [КЛАПАН ВЫПУСКНОЙ] 12575352 VALVE, INT (STD) 12584761 VALVE, INT (0.075MM O.S.) (0.297) 24100294 ARM, VLV RKR [РЫЧАГ] 24100005 ADJUSTER, HYD VLV LASH (ACDelco #24100005) [ТОЛКАТЕЛЬ КЛАПАНА ДВИГАТЕЛЯ] 12565836 SEAL, VLV STEM OIL [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КЛАПАНА ДВИГАТЕЛЯ] 12575355 ПРУЖИНА, VLV [ПРУЖИНА КЛАПАНА] 12575196 RETAINER, VLV SPR [КОМПАКТ ДИСК] 12575197 KEY, VLV STEM [КЛАПАННЫЙ КЛЮЧ] not found CAP, CM/SHF BRG (ЧАСТЬ OF 300, 301) 12574477 RING, CM/SHF SPKT OIL SEAL (ЧАСТЬ OF 330-333) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО РАСПРЕДВАЛА ДВИГАТЕЛЯ (2 ШТ.)] 12609249 CAMSHAFT, EXH (INCLS 329) [РАСПРЕДВАЛ ДВИГАТЕЛЯ] 12609250 CAMSHAFT, INT (INCLS 329) [РАСПРЕДВАЛ ДВИГАТЕЛЯ] 12604375 CAMSHAFT, EXH (INCLS 329) [РАСПРЕДВАЛ] 12609252 CAMSHAFT, INT (INCLS 329) [РАСПРЕДВАЛ ДВИГАТЕЛЯ] not found CAP, CM/SHF BRG (ЧАСТЬ OF 300, 301) 11518856 HFH, M6X1X43.4, 14.8 THD, 11 O.D., 8.8, GMW3179 CODE G (ЧАСТЬ OF 300, 301) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12618542 РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ, IGN (INCLS 705) (ACDelco #D508C) not found БОЛТ, IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ HSG (ЧАСТЬ OF 704) 12566778 SENSOR, ENG COOL TEMP (3.682) (ACDelco #213-1581) [СЕНСОР ТЕМПЕРАТУРЫ] 12597464 СВЕЧИ, (DO NOT CHANGE СВЕЧИ GAP) (ACDelco #41-990) (PLATINUM PLUG) [СВЕЧА ЗАЖИГАНИЯ] 12580965 VALVE, ENG OIL MANIF CHK [КЛАПАН] 12593348 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 258) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА] 12617801 GASKET KIT, CYL HD (INCLS 251, 253, 254, 302, 303) (GM00-396) - 2008-2009 DM69 ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 2 ГОЛОВКА ЦИЛИНДРОВ & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7) ↓ not found BLOCK, ENG 12570326 PIN, CYL HD LOC [ЗАГЛУШКА БЛОКА ЦИЛИНДРОВ] 12606653 ACTUATOR, CM/SHF POSN (USE WASHER 12630941) 12603744 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) 12603745 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) 11588279 БОЛТ, HFH, M10X1.5X80, 26 THD, 22.3 O.D., 10.9, GM4277M (CM/SHF POSN) 12626055 COVER, CM/SHF (INCLS 251, 254-257, 260, 263) [КЛАПАННАЯ КРЫШКА ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12595106 SEAL, CM/SHF CVR (ЧАСТЬ OF 250) (*KIT1) (ACDelco #12595106) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12626054 COVER, CM/SHF (INCLS 253-257, 261, 263) [КРЫШКА] 12595107 SEAL, CM/SHF CVR (ЧАСТЬ OF 252) (*KIT1) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] not found SEAL, SPLG SHLD (ЧАСТЬ OF 250, 252) 11570020 БОЛТ, CM/SHF CVR (ЧАСТЬ OF 250, 252) 12595122 INSULATOR, CM/SHF CVR БОЛТ (ЧАСТЬ OF 250, 252) not found INSERT, IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ БОЛТ THD (ЧАСТЬ OF 250, 252) 12593356 CAP, OIL FIL (INCLS 904) (ACDelco #FC221) [КРЫШКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ] 12593348 SEAL, OIL FIL TUBE (O RING) (ЧАСТЬ OF 262) (27.94MM I.D.) (SIZE #320) (1.758) [ПРОКЛАДКА] 12578316 FITTING, PCV (ЧАСТЬ OF 250) (INCLS 263) 12583384 FITTING, PCV (ЧАСТЬ OF 252) (INCLS 263) 12615294 TUBE, OIL FIL (INCLS 259) [ТРУБКА МАСЛЯНОГО ФИЛЬТРА] not found SEAL, PCV HOSE FTG (O RING) (ЧАСТЬ OF 250, 252, 260, 261) 12601744 INSULATOR, CM/SHF HSG CVR (0.413) 12601745 INSULATOR, CM/SHF HSG CVR [НАКЛАДКА КЛАПАННОЙ КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12603904 HEAD, CYL (MCHG) (INCLS 313, 318, 319, 328, 336, 337) (DOES NOT INCL ENG OIL MANIF CHECK VALVES. DLR MUST INSTL) 12603901 HEAD, CYL (MCHG) (INCLS 313, 318, 319, 328, 336, 337) (DOES NOT INCL ENG OIL MANIF CHECK VALVES. DLR MUST INSTL) not found GASKET, CYL HD (*KIT1) not found GASKET, CYL HD (*KIT1) 11518863 БОЛТ, CYL HD [БОЛТ] 11519177 БОЛТ-HEX FLANGE HD, REDUCED BODY, M8X1.25X90, 8.8, GMW3359 (CYL HD) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11561751 PLUG, CYL HD WAT JKT HOLE (ЧАСТЬ OF 300, 301) (M20X1.5X30.5) (1.531) not found SLEEVE, SPLG WIRE (ЧАСТЬ OF 300, 301) 11562127 PLUG, CYL HD OIL GAL (ЧАСТЬ OF 300, 301) (CUP-14.22 OD, 6.6 THK, 304SS) 12575354 VALVE, EXH (STD) [КЛАПАН ВЫПУСКНОЙ] 12584760 VALVE, EXH (0.075 O.S.) [КЛАПАН ВЫПУСКНОЙ] 12575351 VALVE, INT (STD) [КЛАПАН ВПУСКНОЙ] 12584763 VALVE, INT (0.075MM O.S.) (0.297) [КЛАПАН ВПУСКНОЙ] 24100294 ARM, VLV RKR [РЫЧАГ] 24100005 ADJUSTER, HYD VLV LASH (ACDelco #24100005) [ТОЛКАТЕЛЬ КЛАПАНА ДВИГАТЕЛЯ] 12565836 SEAL, VLV STEM OIL [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КЛАПАНА ДВИГАТЕЛЯ] 12575355 ПРУЖИНА, VLV [ПРУЖИНА КЛАПАНА] 12575196 RETAINER, VLV SPR [КОМПАКТ ДИСК] 12575197 KEY, VLV STEM [КЛАПАННЫЙ КЛЮЧ] not found CAP, CM/SHF BRG (ЧАСТЬ OF 300, 301) 12574477 RING, CM/SHF SPKT OIL SEAL (ЧАСТЬ OF 330-333) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО РАСПРЕДВАЛА ДВИГАТЕЛЯ (2 ШТ.)] 12566670 CAMSHAFT, EXH (INCLS 329) 12625984 CAMSHAFT, EXH (INCLS 329) 12609250 CAMSHAFT, INT (INCLS 329) [РАСПРЕДВАЛ ДВИГАТЕЛЯ] 12604375 CAMSHAFT, EXH (INCLS 329) [РАСПРЕДВАЛ] 12620457 CAMSHAFT, EXH (INCLS 329) 12609252 CAMSHAFT, INT (INCLS 329) [РАСПРЕДВАЛ ДВИГАТЕЛЯ] 12625989 CAMSHAFT, INT (INCLS 329) not found CAP, CM/SHF BRG (ЧАСТЬ OF 300, 301) 11518856 HFH, M6X1X43.4, 14.8 THD, 11 O.D., 8.8, GMW3179 CODE G (ЧАСТЬ OF 300, 301) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12618542 РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ, IGN (INCLS 705) (ACDelco #D508C) teamcadillac.ru 11588715 БОЛТ, HFH, M6X1X35, 18 THD, 14.2 OD, 8.8, GMW3359, 5MM M POINT (ЧАСТЬ OF 704) [БОЛТ] 12566778 SENSOR, ENG COOL TEMP (3.682) (ACDelco #213-1581) [СЕНСОР ТЕМПЕРАТУРЫ] 12566778 SENSOR, ENG COOL TEMP (3.682) (ACDelco #213-1581) [СЕНСОР ТЕМПЕРАТУРЫ] 12566778 SENSOR, ENG COOL TEMP (ACDelco #213-1581) [СЕНСОР ТЕМПЕРАТУРЫ] 12597464 СВЕЧИ, (DO NOT CHANGE СВЕЧИ GAP) (ACDelco #41-990) (PLATINUM PLUG) [СВЕЧА ЗАЖИГАНИЯ] 12580965 VALVE, ENG OIL MANIF CHK [КЛАПАН] 12593348 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 258) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА] 12625781 GASKET KIT, CYL HD (INCLS 251, 253, 302, 303) (INCLS UPR & LWR INT MANIF GASKETS) [КОМПЛЕКТ ПРОКЛАДОК ВПУСКНОГО КОЛЛЕКТОРА (2ШТ)] (GM00-550) - 2008 DM69 ДВИГАТЕЛЬ В СБОРЕ-2.8L V6 ЧАСТЬ 6 ЦЕПЬ И НАТЯЖИТЕЛЬ (LP1/2.8T) ↓ 12599721 SPROCKET, CR/SHF [ШЕСТЕРНЯ РАСПРЕДВАЛА] 12586959 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (LOWER PRIMARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ГРМ] 12609262 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (INCLS 153, 164) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 152) [БОЛТ М8] 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (TMG CHAIN GDE) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12616609 CHAIN, CM/SHF INTER DRV (PRIMARY) [ЦЕПЬ ПРИВОДА ГРМ] 12597417 GUIDE, TMG CHAIN (INCLS 157) (UPPER PRIMARY) 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 156) [БОЛТ М8] 11588252 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3179 CODE G (ЧАСТЬ OF 165, 166) 12589477 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 152) (PRIMARY) 12612839 SPROCKET, TMG CHAIN IDLER (INCLS 161) (0.736) [ЗВЕЗДОЧКА РАСПРЕДВАЛА] 12612838 SPROCKET, TMG CHAIN IDLER (INCLS 161) (0.736) [ШЕСТЕРНЯ РАСПРЕДВАЛА] 12616608 CHAIN, CM/SHF INTER DRV (SECONDARY) [ЦЕПЬ ПРИВОДА ГРМ] 12600461 GUIDE, TMG CHAIN (INCLS 172) (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ПРИВОДА ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 171) [БОЛТ М8] 12586960 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАТЯЖИТЕЛЬ ЦЕПИ] 11518858 БОЛТ, HFH, M8X1.25X43, 16 THD, 18 O.D., 8.8, GMW3179 (TMG CHAIN TENSR) [БОЛТ М8] 12609260 РОЛИК НАТЯЖИТЕЛЬ, TMG CHAIN (INCLS 176, 177) (SECONDARY) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 175) [БОЛТ М8] 12589478 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 175) 12600462 GUIDE, TMG CHAIN (INCLS 182) (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ПРИВОДА ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 181) [БОЛТ М8] 12586961 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАПРАВЛЯЮЩАЯ ПРИВОДНОЙ ЦЕПИ] 11518858 БОЛТ, HFH, M8X1.25X43, 16 THD, 18 O.D., 8.8, GMW3179 (TMG CHAIN TENSR) [БОЛТ М8] 12609258 РОЛИК НАТЯЖИТЕЛЬ, TMG CHAIN (INCLS 186, 187) (SECONDARY) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 185) [БОЛТ М8] 12589479 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 185) 12606653 ACTUATOR, CM/SHF POSN (EXH) (USE WASHER 12630941) 12603744 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) (5 SCREWS ON BACKPLATE) 12603745 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) (5 SCREWS ON BACKPLATE) 11588279 БОЛТ, HFH, M10X1.5X80, 26 THD, 22.3 O.D., 10.9, GM4277M (CM/SHF POSN ACTR) teamcadillac.ru 12630941 WASHER, CM/SHF THR (USED ON ACTUATORS 12603744-745, 12606653 & 12630916-918) (**FIELD FIX ONLY, DO NOT CATALOG**) [УПОРНАЯ ШАЙБА РАСПРЕДЕЛИТЕЛЬНОГО ВАЛА ДВС] (GM00-550) - 2008 DM69 ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 6 ЦЕПЬ И НАТЯЖИТЕЛЬ (LLT/3.6V) ↓ 12599721 SPROCKET, CR/SHF [ШЕСТЕРНЯ РАСПРЕДВАЛА] 12586959 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (LOWER PRIMARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ГРМ] 12609262 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (INCLS 153, 164) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 152) [БОЛТ М8] 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (TMG CHAIN GDE) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12616609 CHAIN, CM/SHF INTER DRV (PRIMARY) [ЦЕПЬ ПРИВОДА ГРМ] 12597417 GUIDE, TMG CHAIN (INCLS 157) (UPPER PRIMARY) 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 156) [БОЛТ М8] 11588252 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3179 CODE G (ЧАСТЬ OF 165, 166) 12589477 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 152) (PRIMARY) 12612839 SPROCKET, TMG CHAIN IDLER (INCLS 161) (0.736) [ЗВЕЗДОЧКА РАСПРЕДВАЛА] 12612838 SPROCKET, TMG CHAIN IDLER (INCLS 161) (0.736) [ШЕСТЕРНЯ РАСПРЕДВАЛА] 12616608 CHAIN, CM/SHF INTER DRV (SECONDARY) [ЦЕПЬ ПРИВОДА ГРМ] 12600461 GUIDE, TMG CHAIN (INCLS 172) (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ПРИВОДА ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 171) [БОЛТ М8] 12586960 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАТЯЖИТЕЛЬ ЦЕПИ] 11518858 БОЛТ, HFH, M8X1.25X43, 16 THD, 18 O.D., 8.8, GMW3179 (TMG CHAIN TENSR) [БОЛТ М8] teamcadillac.ru 12609260 РОЛИК НАТЯЖИТЕЛЬ, TMG CHAIN (INCLS 176, 177) (SECONDARY) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 175) [БОЛТ М8] 12589478 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 175) 12600462 GUIDE, TMG CHAIN (INCLS 182) (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ПРИВОДА ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 181) [БОЛТ М8] 12586961 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАПРАВЛЯЮЩАЯ ПРИВОДНОЙ ЦЕПИ] 11518858 БОЛТ, HFH, M8X1.25X43, 16 THD, 18 O.D., 8.8, GMW3179 (TMG CHAIN TENSR) [БОЛТ М8] 12609258 РОЛИК НАТЯЖИТЕЛЬ, TMG CHAIN (INCLS 186, 187) (SECONDARY) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 185) [БОЛТ М8] 12589479 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 185) 12606653 ACTUATOR, CM/SHF POSN (EXH) (USE WASHER 12630941) 12603744 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) (5 SCREWS ON BACKPLATE) 12603745 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) (5 SCREWS ON BACKPLATE) 11588279 БОЛТ, HFH, M10X1.5X80, 26 THD, 22.3 O.D., 10.9, GM4277M (CM/SHF POSN ACTR) 12630941 WASHER, CM/SHF THR (USED ON ACTUATORS 12603744-745, 12606653 & 12630916-918) [УПОРНАЯ ШАЙБА РАСПРЕДЕЛИТЕЛЬНОГО ВАЛА ДВС] (GM00-550) - 2008-2009 DM69 ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 6 ЦЕПЬ И НАТЯЖИТЕЛЬ (LY7/3.6-7) ↓ 12599721 SPROCKET, CR/SHF [ШЕСТЕРНЯ РАСПРЕДВАЛА] 12586959 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (LOWER PRIMARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ГРМ] 12609262 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (INCLS 153, 164) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 152) [БОЛТ М8] teamcadillac.ru 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (TMG CHAIN GDE) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12616609 CHAIN, CM/SHF INTER DRV (PRIMARY) [ЦЕПЬ ПРИВОДА ГРМ] 12597417 GUIDE, TMG CHAIN (INCLS 157) (UPPER PRIMARY) 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 156) [БОЛТ М8] 11588252 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3179 CODE G (ЧАСТЬ OF 165, 166) 12589477 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 152) (PRIMARY) 12612839 SPROCKET, TMG CHAIN IDLER (INCLS 161) (0.736) [ЗВЕЗДОЧКА РАСПРЕДВАЛА] 12612838 SPROCKET, TMG CHAIN IDLER (INCLS 161) (0.736) [ШЕСТЕРНЯ РАСПРЕДВАЛА] 12616608 CHAIN, CM/SHF INTER DRV (SECONDARY) [ЦЕПЬ ПРИВОДА ГРМ] 12600461 GUIDE, TMG CHAIN (INCLS 172) (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ПРИВОДА ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 171) [БОЛТ М8] 12586960 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАТЯЖИТЕЛЬ ЦЕПИ] 11518858 БОЛТ, HFH, M8X1.25X43, 16 THD, 18 O.D., 8.8, GMW3179 (TMG CHAIN TENSR) [БОЛТ М8] 12609260 РОЛИК НАТЯЖИТЕЛЬ, TMG CHAIN (INCLS 176, 177) (SECONDARY) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 175) [БОЛТ М8] 12589478 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 175) 12600462 GUIDE, TMG CHAIN (INCLS 182) (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ПРИВОДА ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 181) [БОЛТ М8] 12586961 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАПРАВЛЯЮЩАЯ ПРИВОДНОЙ ЦЕПИ] 11518858 БОЛТ, HFH, M8X1.25X43, 16 THD, 18 O.D., 8.8, GMW3179 (TMG CHAIN TENSR) [БОЛТ М8] 12609258 РОЛИК НАТЯЖИТЕЛЬ, TMG CHAIN (INCLS 186, 187) (SECONDARY) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 185) [БОЛТ М8] 12589479 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 185) 12606653 ACTUATOR, CM/SHF POSN (EXH) (USE WASHER 12630941) 12603744 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) (5 SCREWS ON BACKPLATE) 12603745 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) (5 SCREWS ON BACKPLATE) 11588279 БОЛТ, HFH, M10X1.5X80, 26 THD, 22.3 O.D., 10.9, GM4277M (CM/SHF POSN ACTR) 12630941 WASHER, CM/SHF THR (USED ON ACTUATORS 12603744-745, 12606653 & 12630916-918) (**FIELD FIX ONLY, DO NOT CATALOG**) [УПОРНАЯ ШАЙБА РАСПРЕДЕЛИТЕЛЬНОГО ВАЛА ДВС] 00 - 8-МИ ЦИЛИНДРОВЫЙ ДВИГАТЕЛЬ (6D00-019) - 2008 DM69 ДВИГАТЕЛЬ В СБОРЕ & ЧАСТЬIAL ДВИГАТЕЛЬ (LP1/2.8T) ↓ not found ДВИГАТЕЛЬ, 2.8 L (173 CID) (PRODUCTION) 12617612 ДВИГАТЕЛЬ, GASOLINE (GOODWRENCH NEW) (SERVICE) [ДВИГАТЕЛЬ БЕНЗИН, 6 ЦИЛ., 2.8Л, 210Л.С.] (6D00-029) - 2008-2010 DM69 СЦЕПЛЕНИЕ (MV7) ↓ not found PIN, TRANS LOC 12597210 PIN, TRANS LOC 12575412 FLYКОЛЕСО, ENG 12575412 FLYКОЛЕСО, ENG 12575412 FLYКОЛЕСО, ENG 11588884 БОЛТ, HEX SOC HD, M10X1X24, 21 THD, 15.9 OD, 10.9, GMW3179G, HDR PT (FLYWHL) [КРЕПЕЖ] not found PLATE, CLU PRESS (ЧАСТЬ OF 12) not found PLATE, CLU DRVN (ЧАСТЬ OF 12) 11570903 БОЛТ-HFHE, M8X1.25X20, 12 THD, 16 OD, 10.9, GMW3359, 6MM MAT PT (CLU PRESS PLT) 24242161 CYLINDER, CLU ACTR (ЧАСТЬ OF 11) [ЦИЛИНДР] not found БОЛТ, CLU ACTR CYL (ЧАСТЬ OF 11) 11518202 БОЛТ, HFH, M10X1.5X30, 22.0 00, 6202M, 6280M, TAP, TR, P-PT (ЧАСТЬ OF 11) 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] teamcadillac.ru 24242917 ТРАНСМИССИЯ, MAN (INCLS 7-9) (СМ. ГРУППУ 04.000 "ТРАНСМИССИЯ БЛОК" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ТРАНСМИССИЯ] 24243879 PLATE, CLU PRESS & DRVN (W/CVR) (INCLS 4, 5) 24222918 COVER, TRANS (0.679) 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (TRANS CVR) [БОЛТ] (6D00-042) - 2008 DM69 ДВИГАТЕЛЬ В СБОРЕ-2.8L V6 ЧАСТЬ 4 МАСЛЯНЫЙ НАСОС,МАСЛЯНЫЙ ПОДДОН & ДЕТАЛИ КОМПЛЕКТА (LP1/2.8T) ↓ 22531637 PIN, МАСЛЯНЫЙ ПОДДОН LOC (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 12586959 GUIDE, TMG CHAIN (ЧАСТЬ OF 463) (2 КРЕПЛЕНИЕ HOLES) (LOWER PRIMARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ГРМ] 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (ЧАСТЬ OF 463) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12592105 PAN, OIL (INCLS 405-407, 410, 412, 413, 420, 422, 900) [МАСЛЯНЫЙ ПОДДОН ДВИГАТЕЛЯ] 12590407 PIPE, O/PMP SUC (ЧАСТЬ OF 400) 12566837 SEAL, O/PMP SUC PIPE (ЧАСТЬ OF 400) [УПЛОТНЕНИЕ] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 400) 12566872 DEFLECTOR, CR/SHF OIL (ЧАСТЬ OF 400) 11562588 PLUG, МАСЛЯНЫЙ ПОДДОН DRN (INCLS 413) (ЧАСТЬ OF 400) (W/ SEAL) (EXC MAGNET) [ЗАГЛУШКА МАСЛЯНОГО ПОДДОНА] not found SEAL, МАСЛЯНЫЙ ПОДДОН DRN PLUG (O RING) (ЧАСТЬ OF 400, 412) 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (ЧАСТЬ OF 400) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11588424 БОЛТ, HFH, M6X1X145, 18 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 400) [ШЕСТИГРАННЫЙ ВИНТ] 12611594 INDICATOR, OIL LVL (INCLS 434) 12612349 TUBE, OIL LVL IND 24504091 SEAL, OIL LVL IND (O RING) (BLACK) (6.07MM ID, 1.78MM DIA) (INDICATOR) 24504091 SEAL, OIL LVL IND (O RING) (BLACK) (6.07MM ID, 1.78MM DIA) (TUBE) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (OIL LVL IND TUBE) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) (INDICATOR) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) (TUBE) 12591607 ADAPTER, OIL FLTR (INCLS 441-443, 446-451, 456, 458, 459, 728, 729) [АДАПТЕР МАСЛЯНОГО ФИЛЬТРА] teamcadillac.ru 12591604 GASKET, OIL FLTR (ЧАСТЬ OF 440) (BETWEEN OIL FILTER ADAPTER AND BLOCK) [ПРОКЛАДКА МАСЛЯНОГО ФИЛЬТРА] 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 440) 11519174 БОЛТ, HFH, W/REDUCED BODY, M8X1.25X65, THD 22, O.D. 18, 8.8, GMW3359 (ЧАСТЬ OF 440) 25014612 VALVE, OIL FLTR BYPASS (ЧАСТЬ OF 440, 450) (W/O VAPOR SEPARATOR) (OPENING PRESSURE 21 PSI NOMINAL) (ЧАСТЬ HAS A 16.10MM MAX OD & FITS A 15.84 HOLE IN BLOCK) 11519184 БОЛТ, OIL FLTR ADAP (ЧАСТЬ OF 440) (M10X1.5X45) (0.029) not found SPACER, OIL FLTR (ЧАСТЬ OF 440) 25177917 ФИЛЬТР, МАСЛЯНЫЙ (ЧАСТЬ OF 440) (ACDelco #PF2129) [МАСЛЯНЫЙ ФИЛЬТР ДВИГАТЕЛЯ] 12583470 CAP, OIL FLTR (ЧАСТЬ OF 440) (INCLS 446, 451, 456) [КРЫШКА] 12577653 SEAL, OIL FLTR CAP (O RING) (ЧАСТЬ OF 440, 450) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КРЫШКИ МАСЛЯНОГО ФИЛЬТРА] not found BODY, BYPASS (ЧАСТЬ OF 440, 450) not found VALVE, OIL FILTER DRAIN (ЧАСТЬ OF 440) not found SEAL, OIL FLTR DRN PLUG (O RING) (ЧАСТЬ OF 440) 12590152 PUMP, OIL (INCLS 151, 154, 464-466, 468, 470-472, 474, 475) (INCLS GUIDE, БОЛТS) [МАСЛЕННЫЙ НАСОС] not found COVER, O/PMP (ЧАСТЬ OF 463) not found GEAR, O/PMP (ЧАСТЬ OF 463) not found GEAR, O/PMP IDLER (ЧАСТЬ OF 463) not found БОЛТ, O/PMP CVR (ЧАСТЬ OF 463) not found PLUG, OIL PRESS RLF VLV BORE (ЧАСТЬ OF 463) not found ПРУЖИНА, OIL PRESS RLF VLV (ЧАСТЬ OF 463) not found VALVE, OIL PRESS RLF (ЧАСТЬ OF 463) not found RETAINER, OIL PRESS RLF VLV SPR (ЧАСТЬ OF 463) 11900371 БОЛТ, HEX HD, W/1.6 FLAT WA, M8X1.25X54.3, 43 THD, 16O.D., 8.8, GMW3359 (ЧАСТЬ OF 463) 12610143 NOZZLE, PSTN OIL (INCLS 491) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 490) 12621659 SENSOR, ENG OIL PRESS (INCLS 729) (ЧАСТЬ OF 440) (ACDelco #12621659) not found SEAL, ENG OIL PRESSURE SENSOR (ЧАСТЬ OF 440, 728) 11588694 БОЛТ, HEX-HD, M8X1.25X120.8, DOG-PT, 8.8, GMW3359 (ЧАСТЬ OF 400) (6D00-042) - 2008 DM69 ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 4 МАСЛЯНЫЙ НАСОС,МАСЛЯНЫЙ ПОДДОН & ДЕТАЛИ КОМПЛЕКТА (LLT/3.6V, ЗАДНИЙ КОЛЕСО DRIVE MN6,MX0) ↓ 22531637 PIN, МАСЛЯНЫЙ ПОДДОН LOC (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 12586959 GUIDE, TMG CHAIN (ЧАСТЬ OF 463) (2 КРЕПЛЕНИЕ HOLES) (LOWER PRIMARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ГРМ] 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (ЧАСТЬ OF 463) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12592105 PAN, OIL (INCLS 405-407, 410, 412, 413, 420, 422, 900) [МАСЛЯНЫЙ ПОДДОН ДВИГАТЕЛЯ] 12592105 PAN, OIL (INCLS 405-407, 410, 412, 413, 420, 422, 900) [МАСЛЯНЫЙ ПОДДОН ДВИГАТЕЛЯ] 12590407 PIPE, O/PMP SUC (ЧАСТЬ OF 400) 12590407 PIPE, O/PMP SUC (ЧАСТЬ OF 400) 12566837 SEAL, O/PMP SUC PIPE (ЧАСТЬ OF 400) [УПЛОТНЕНИЕ] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 400) 12566872 DEFLECTOR, CR/SHF OIL (ЧАСТЬ OF 400) 11562588 PLUG, МАСЛЯНЫЙ ПОДДОН DRN (INCLS 413) (ЧАСТЬ OF 400) (W/ SEAL) (EXC MAGNET) [ЗАГЛУШКА МАСЛЯНОГО ПОДДОНА] not found SEAL, МАСЛЯНЫЙ ПОДДОН DRN PLUG (O RING) (ЧАСТЬ OF 400, 412) 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (ЧАСТЬ OF 400) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11588424 БОЛТ, HFH, M6X1X145, 18 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 400) [ШЕСТИГРАННЫЙ ВИНТ] 12611594 INDICATOR, OIL LVL (INCLS 434) 12612349 TUBE, OIL LVL IND 24504091 SEAL, OIL LVL IND (O RING) (BLACK) (6.07MM ID, 1.78MM DIA) (INDICATOR) 24504091 SEAL, OIL LVL IND (O RING) (BLACK) (6.07MM ID, 1.78MM DIA) (TUBE) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (OIL LVL IND TUBE) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) (INDICATOR) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) (TUBE) 12591607 ADAPTER, OIL FLTR (INCLS 441-443, 446-451, 456, 458, 459, 728, 729) [АДАПТЕР МАСЛЯНОГО ФИЛЬТРА] 12591604 GASKET, OIL FLTR (ЧАСТЬ OF 440) (BETWEEN OIL FILTER ADAPTER AND BLOCK) [ПРОКЛАДКА МАСЛЯНОГО ФИЛЬТРА] 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 440) 11519174 БОЛТ, HFH, W/REDUCED BODY, M8X1.25X65, THD 22, O.D. 18, 8.8, GMW3359 (ЧАСТЬ OF 440) teamcadillac.ru 25014612 VALVE, OIL FLTR BYPASS (ЧАСТЬ OF 440, 450) (W/O VAPOR SEPARATOR) (OPENING PRESSURE 21 PSI NOMINAL) (ЧАСТЬ HAS A 16.10MM MAX OD & FITS A 15.84 HOLE IN BLOCK) 11519184 БОЛТ, OIL FLTR ADAP (ЧАСТЬ OF 440) (M10X1.5X45) (0.029) not found SPACER, OIL FLTR (ЧАСТЬ OF 440) 19114105 ФИЛЬТР, МАСЛЯНЫЙ (ЧАСТЬ OF 440) (ACDelco #PF2129F) (DURAPACK) (BULK PKG, QTY 12) 25177917 ФИЛЬТР, МАСЛЯНЫЙ (ЧАСТЬ OF 440) (ACDelco #PF2129) [МАСЛЯНЫЙ ФИЛЬТР ДВИГАТЕЛЯ] 12583470 CAP, OIL FLTR (ЧАСТЬ OF 440) (INCLS 446, 451, 456) [КРЫШКА] not found SEAL, OIL FLTR CAP (O RING) (ЧАСТЬ OF 440, 450) not found BODY, BYPASS (ЧАСТЬ OF 440, 450) not found VALVE, OIL FILTER DRAIN (ЧАСТЬ OF 440) not found SEAL, OIL FLTR DRN PLUG (O RING) (ЧАСТЬ OF 440) 12590152 PUMP, OIL (INCLS 151, 154, 464-466, 468, 470-472, 474, 475) (INCLS GUIDE, БОЛТS) [МАСЛЕННЫЙ НАСОС] not found COVER, O/PMP (ЧАСТЬ OF 463) not found GEAR, O/PMP (ЧАСТЬ OF 463) not found GEAR, O/PMP IDLER (ЧАСТЬ OF 463) not found БОЛТ, O/PMP CVR (ЧАСТЬ OF 463) not found PLUG, OIL PRESS RLF VLV BORE (ЧАСТЬ OF 463) not found ПРУЖИНА, OIL PRESS RLF VLV (ЧАСТЬ OF 463) not found VALVE, OIL PRESS RLF (ЧАСТЬ OF 463) not found RETAINER, OIL PRESS RLF VLV SPR (ЧАСТЬ OF 463) 11900371 БОЛТ, HEX HD, W/1.6 FLAT WA, M8X1.25X54.3, 43 THD, 16O.D., 8.8, GMW3359 (ЧАСТЬ OF 463) 12610143 NOZZLE, PSTN OIL (INCLS 491) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 490) 12621659 SENSOR, ENG OIL PRESS (INCLS 729) (ЧАСТЬ OF 440) (ACDelco #12621659) not found SEAL, ENG OIL PRESSURE SENSOR (ЧАСТЬ OF 440, 728) 11588694 БОЛТ, HEX-HD, M8X1.25X120.8, DOG-PT, 8.8, GMW3359 (ЧАСТЬ OF 400) (6D00-042) - 2008-2009 DM69 ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 4 МАСЛЯНЫЙ НАСОС,МАСЛЯНЫЙ ПОДДОН & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7, ЗАДНИЙ КОЛЕСО DRIVE MN6,MX0) ↓ 22531637 PIN, МАСЛЯНЫЙ ПОДДОН LOC (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 12586959 GUIDE, TMG CHAIN (ЧАСТЬ OF 463) (2 КРЕПЛЕНИЕ HOLES) (LOWER PRIMARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ГРМ] 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (ЧАСТЬ OF 463) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12592105 PAN, OIL (INCLS 405-407, 410, 412, 413, 420, 422, 900) [МАСЛЯНЫЙ ПОДДОН ДВИГАТЕЛЯ] 12590407 PIPE, O/PMP SUC (ЧАСТЬ OF 400) 12590407 PIPE, O/PMP SUC (ЧАСТЬ OF 400) 12566837 SEAL, O/PMP SUC PIPE (ЧАСТЬ OF 400) [УПЛОТНЕНИЕ] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 400) 12566872 DEFLECTOR, CR/SHF OIL (ЧАСТЬ OF 400) 11562588 PLUG, МАСЛЯНЫЙ ПОДДОН DRN (INCLS 413) (ЧАСТЬ OF 400) (W/ SEAL) (EXC MAGNET) [ЗАГЛУШКА МАСЛЯНОГО ПОДДОНА] not found SEAL, МАСЛЯНЫЙ ПОДДОН DRN PLUG (O RING) (ЧАСТЬ OF 400, 412) 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (ЧАСТЬ OF 400) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11588424 БОЛТ, HFH, M6X1X145, 18 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 400) [ШЕСТИГРАННЫЙ ВИНТ] 12611594 INDICATOR, OIL LVL (INCLS 434) 12612349 TUBE, OIL LVL IND 24504091 SEAL, OIL LVL IND (O RING) (BLACK) (6.07MM ID, 1.78MM DIA) (INDICATOR) 24504091 SEAL, OIL LVL IND (O RING) (BLACK) (6.07MM ID, 1.78MM DIA) (TUBE) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (OIL LVL IND TUBE) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) (INDICATOR) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) (TUBE) 12591607 ADAPTER, OIL FLTR (INCLS 441-443, 446-451, 456, 458, 459, 728, 729) [АДАПТЕР МАСЛЯНОГО ФИЛЬТРА] 12591604 GASKET, OIL FLTR (ЧАСТЬ OF 440) (BETWEEN OIL FILTER ADAPTER AND BLOCK) [ПРОКЛАДКА МАСЛЯНОГО ФИЛЬТРА] 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 440) 11519174 БОЛТ, HFH, W/REDUCED BODY, M8X1.25X65, THD 22, O.D. 18, 8.8, GMW3359 (ЧАСТЬ OF 440) 25014612 VALVE, OIL FLTR BYPASS (ЧАСТЬ OF 440, 450) (W/O VAPOR SEPARATOR) (OPENING PRESSURE 21 PSI NOMINAL) (ЧАСТЬ HAS A 16.10MM MAX OD & FITS A 15.84 HOLE IN BLOCK) 11519174 БОЛТ, OIL FLTR ADAP (БОЛТ, HFH, W/REDUCED BODY, M8X1.25X65, THD 22, O.D. 18, 8.8, GMW3359) (ЧАСТЬ OF 440) (M8X1.25X65) (8.900) 11519184 БОЛТ, OIL FLTR ADAP (ЧАСТЬ OF 440) (M10X1.5X45) (0.029) 11519980 БОЛТ, OIL FLTR ADAP (БОЛТ, HFH, W/REDUCED BODY, M8X1.25X65, THD 22, O.D. 18, 8.8, GMW3359) (ЧАСТЬ OF 440) (M8X1.25X40) (8.900) not found SPACER, OIL FLTR (ЧАСТЬ OF 440) 25177917 ФИЛЬТР, МАСЛЯНЫЙ (ЧАСТЬ OF 440) (ACDelco #PF2129) [МАСЛЯНЫЙ ФИЛЬТР ДВИГАТЕЛЯ] 12583470 CAP, OIL FLTR (ЧАСТЬ OF 440) (INCLS 446, 451, 456) [КРЫШКА] 12577653 SEAL, OIL FLTR CAP (O RING) (ЧАСТЬ OF 440, 450) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КРЫШКИ МАСЛЯНОГО ФИЛЬТРА] not found CAGE, OIL FLTR BYPASS VLV (ЧАСТЬ OF 440, 450) not found VALVE, OIL FLTR BYPASS (ЧАСТЬ OF 440) not found SEAL, OIL FLTR DRN PLUG (O RING) (ЧАСТЬ OF 440) 12590152 PUMP, OIL (INCLS 151, 154, 464-466, 468, 470-472, 474, 475) (INCLS GUIDE, БОЛТS) [МАСЛЕННЫЙ НАСОС] not found COVER, O/PMP (ЧАСТЬ OF 463) not found GEAR, O/PMP (ЧАСТЬ OF 463) not found GEAR, O/PMP IDLER (ЧАСТЬ OF 463) not found БОЛТ, O/PMP CVR (ЧАСТЬ OF 463) not found PLUG, OIL PRESS RLF VLV BORE (ЧАСТЬ OF 463) not found ПРУЖИНА, OIL PRESS RLF VLV (ЧАСТЬ OF 463) not found VALVE, OIL PRESS RLF (ЧАСТЬ OF 463) not found RETAINER, OIL PRESS RLF VLV SPR (ЧАСТЬ OF 463) teamcadillac.ru 11900371 БОЛТ, HEX HD, W/1.6 FLAT WA, M8X1.25X54.3, 43 THD, 16O.D., 8.8, GMW3359 (ЧАСТЬ OF 463) 12610143 NOZZLE, PSTN OIL (INCLS 491) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 490) 12621659 SENSOR, ENG OIL PRESS (INCLS 729) (ЧАСТЬ OF 440) (ACDelco #12621659) not found SEAL, ENG OIL PRESS SEN (O RING) (ЧАСТЬ OF 440, 728) 11588694 БОЛТ, HEX-HD, M8X1.25X120.8, DOG-PT, 8.8, GMW3359 (ЧАСТЬ OF 400) (6D00-043) - 2008-2009 DM69 INTAKE MANIFOLD SHIELD/COVERS (LP1/2.8T,LY7/3.6-7) ↓ not found COVER, INT MANIF (INCLS 7, 15-19) 12632150 COVER, INT MANIF (INCLS 7, 15-19) (ДВИГАТЕЛЬ COVER) 12632150 COVER, INT MANIF (INCLS 7, 15-19) (ДВИГАТЕЛЬ COVER) (3.265) not found INSULATOR, INT MANIF CVR 12624769 INSULATOR, INT MANIF CVR 20664092 RETAINER, UPR INT MANIF SIGHT SHLD (BLACK) (6.3MM DIA X 23MM) (1.276) [КЛИПСА КРЕПЛЕНИЯ МОЛДИНГА ДВЕРИ] 12606137 INSULATOR, INT MANIF 12606137 INSULATOR, INT MANIF 11588717 БОЛТ, UPR INT MANIF CVR BRKT (M6X1.0X45.0) (2.383) 11588717 БОЛТ, UPR INT MANIF CVR BRKT (M6X1.0X45.0) (2.383) 12607233 BRACKET, UPR INT MANIF SIGHT SHLD 12607233 BRACKET, UPR INT MANIF SIGHT SHLD not found INSULATOR, F/INJR SIGHT SHLD BRKT (ЧАСТЬ OF 1) 24507878 INSULATOR, F/INJR SIGHT SHLD BRKT (ЧАСТЬ OF 1) 11588723 БОЛТ, HFH, M8X1.25X25, 18 THD, 18 OD, 8.8 STL, GMW3359, M-PT (INT MANIF SIGHT SHLD) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (INT MANIF SIGHT SHLD) 11516075 ГАЙКА, HFH SELF LK, M6X1, 7.7THK, 14.2 O.D., 9, PZOR (ЧАСТЬ OF 12) [ГАЙКА ВЫПУСКНОЙ СИСТЕМЫ D=6ММ] 11588967 STUD, BALL W/HFH, M6X1X20.65, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 12) 12616618 BRACKET, INT MANIF SIGHT SHLD (INCLS 10, 11) 12616618 BRACKET, INT MANIF SIGHT SHLD (INCLS 10, 11) 12593348 SEAL, OIL FIL TUBE (O RING) (ЧАСТЬ OF 14) (27.94MM I.D.) (SIZE #320) (1.758) [ПРОКЛАДКА] 12593348 SEAL, OIL FIL TUBE (O RING) (ЧАСТЬ OF 14) (27.94MM I.D.) (SIZE #320) (1.758) [ПРОКЛАДКА] 12615294 TUBE, OIL FIL (INCLS 13, 20, 21) [ТРУБКА МАСЛЯНОГО ФИЛЬТРА] 12615294 TUBE, OIL FIL (INCLS 13, 20, 21) [ТРУБКА МАСЛЯНОГО ФИЛЬТРА] 12591714 GROMMET, UPR INT MANIF SIGHT SHLD (ЧАСТЬ OF 1) (60MM OD @ TOP) (ROUND TOP & BOTTOM) 12591714 GROMMET, UPR INT MANIF SIGHT SHLD (ЧАСТЬ OF 1) (60MM OD @ TOP) (ROUND TOP & BOTTOM) teamcadillac.ru not found INSULATOR, F/INJR SIGHT SHLD BRKT (ЧАСТЬ OF 1) 10042521 ГАЙКА, INT MANIF INSL (ЧАСТЬ OF 1) (7.831) 10042521 ГАЙКА, INT MANIF INSL (ЧАСТЬ OF 1) (7.831) 12591715 GROMMET, UPR INT MANIF SIGHT SHLD (ЧАСТЬ OF 1) (32MM OD @ TOP) (ROUND AT TOP/TAPERED CONICAL BOTTOM) 12591715 GROMMET, UPR INT MANIF SIGHT SHLD (ЧАСТЬ OF 1) (32MM OD @ TOP) (ROUND AT TOP/TAPERED CONICAL BOTTOM) not found EMBLEM, INT MANIF CVR (ЧАСТЬ OF 1) 12607405 EMBLEM, INT MANIF CVR (ЧАСТЬ OF 1) [ЭМБЛЕМА] 12593356 CAP, OIL FIL (ЧАСТЬ OF 14) (INCLS 21) (ACDelco #FC221) [КРЫШКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ] 12593356 CAP, OIL FIL (ЧАСТЬ OF 14) (INCLS 21) (ACDelco #FC221) [КРЫШКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ] 12593348 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 14, 20) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА] 12593348 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 14, 20) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА] (6D00-044) - 2008-2009 DM69 ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ (ПОЛНОПРИВОДНЫЙ MX7) ↓ 15854018 BRACKET, ENG MT 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (ENG MT BRKT) [БОЛТ, М10Х1.5Х30] 11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (ENG MT BRKT) [БОЛТ, М8Х1.25Х31.5] 15854019 BRACKET, ENG MT 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT) [ГАЙКА М12] 25971088 MOUNT, ENG [ОПОРНЫЙ УЗЕЛ ДВИГАТЕЛЯ] 11516754 ГАЙКА, HEX, W/CON SPR WA, M10X1.5, 10THK, 28 O.D., 10, 7111M (ENG MT FRM SI) [ГАЙКА М10] 11515775 БОЛТ, HFH, M12X1.75X30, 10.9, 7114M (TRANS MT) [БОЛТ] teamcadillac.ru 25892305 MOUNT, TRANS RR 11589169 БОЛТ ASM - HEX HD W/CONICAL WASHER, M10X1.50X50, GMW25 (10.9) STL, GMW33559 (TRANS RR MT BRKT) 25971085 MOUNT, ENG [ШАРНИР ДВИГАТЕЛЯ] (6D00-045) - 2008 DM69 ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ (ЗАДНИЙ КОЛЕСО DRIVE MX0,MN6) ↓ 25905221 BRACKET, ENG MT [КРОНШТЕЙН] 25905221 BRACKET, ENG MT [КРОНШТЕЙН] 11517383 БОЛТ, HEX W/CON SPR WASH, M10X1.5X55, 28 OD, 37 THD, 10.9, 7114M (ENG MT BRKT) 11517383 БОЛТ, HEX W/CON SPR WASH, M10X1.5X55, 28 OD, 37 THD, 10.9, 7114M (ENG MT BRKT) 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT) [ГАЙКА М12] teamcadillac.ru 25905220 BRACKET, ENG MT [ КРОНШТЕЙН] 25905220 BRACKET, ENG MT [ КРОНШТЕЙН] 25973848 MOUNT, ENG 11516078 ГАЙКА, HFH, M12X1.75, 14THK, 25 O.D., 10, PZOR (ENG MT FRM SI) [ГАЙКА] 15234764 MOUNT, TRANS RR (INCLS 9, 10) [КРЕПЛЕНИЕ] 25947769 MOUNT, TRANS RR (INCLS 9, 10) 25843484 INSULATOR, TRANS RR MT SPR (ЧАСТЬ OF 8) 25843484 INSULATOR, TRANS RR MT SPR (ЧАСТЬ OF 8) not found MOUNT, TRANS RR (ЧАСТЬ OF 8) 11516078 ГАЙКА, HFH, M12X1.75, 14THK, 25 O.D., 10, PZOR (ENG MT FRM SI) [ГАЙКА] 11589169 БОЛТ ASM - HEX HD W/CONICAL WASHER, M10X1.50X50, GMW25 (10.9) STL, GMW33559 (TRANS RR MT BRKT) 11571051 БОЛТ, HFH, M10X1.5X45, 26 THD, 19 OD, 10.9, GMW3359 M-PT. (TRANS MT) (6D00-046) - 2008-2010 DM69 ПЕДАЛЬ СЦЕПЛЕНИЯ-ЦИЛИНДРЫ (MV7) ↓ 24245109 CYLINDER, CLU MAS (INCLS 12) [ЦИЛИНДР] 89047699 SENSOR, CLU PED POSN (ЧАСТЬ OF 10) (INCLS 4) (4.625) [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (CLU PED BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 2, 10) 11609746 ГАЙКА, HFH, M8X1.25, 8.9THK, 17.6 O.D., 10 STL, GMW3200, PREV TORQUE (CLU PED BRKT) [ГАЙКА М8] not found BUSHING, CLU PED RTN SPR (ЧАСТЬ OF 10) not found BUSHING, CLU PED RTN SPR GDE (ЧАСТЬ OF 10) not found ПРУЖИНА, CLU PED RTN (ЧАСТЬ OF 10) not found PAD, CLU PED (ЧАСТЬ OF 10) 25866254 PEDAL, CLU (W/BRKT) (INCLS 2, 4, 6-9, 13) teamcadillac.ru 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (CLU PED) [ГАЙКА М6] not found CAP, CLU M/CYL RSVR (ЧАСТЬ OF 1) 25855318 HARNESS, CLU & SHFT CONT ACTR WRG (ЧАСТЬ OF 10) (6D00-047) - 2008 DM69 ДВИГАТЕЛЬ В СБОРЕ-2.8L V6 ЧАСТЬ 1 БЛОК ЦИЛИНДРОВ И ВНУТРЕННИЕ ДЕТАЛИ (LP1/2.8T) ↓ not found BLOCK, ENG (MCHG) not found CAP, CR/SHF BRG 12560272 БОЛТ, CR/SHF BRG CAP (BOTTOM) (LONG) (M10X2X102.5, 24.5) [ВИНТ] 11518861 БОЛТ, HFH, W/REDCD BODY, M8X1.25X90, 26 THD, 18 O.D., 10.9, GM4277M (CR/SHF BRG CAP) [БОЛТ] 11609410 БОЛТ, HFH, M8X1.25X25, 10.9, GMW3179 (CR/SHF BRG CAP) (0.056) [БОЛТ] 11589000 БОЛТ, HFH, M8X1.25X50, 24 THD, 18 OD, 10.9, GMW3359, RED BODY, W/ADH (CR/SHF BRG CAP) 12557520 PLUG, ENG BLK OIL GAL (CUP-.390IN OD, .040IN THK, STEEL) 12621350 CRANKSHAFT, 12601937 KEY, CR/SHF BALR not found BEARING, CR/SHF UPR (*KIT1) not found BEARING, CR/SHF LWR (*KIT1, KIT2) not found BEARING, CR/SHF THR (*KIT2) 11562127 PLUG, ENG BLK OIL GAL (CUP-14.22 OD, 6.6 THK, 304SS) (0.253) 11561583 PLUG, ENG BLK OIL GAL (M14X1.5X16, 22 OD) (0.253) 11561751 PLUG, CYL HD WAT JKT HOLE (M20X1.5X30.5) (1.531) 11569584 PLUG, ENG BLK CORE HOLE (CUP DIA 34.4MM) 12597210 PIN, TRANS LOC 12620955 SEAL, CR/SHF RR OIL [ПРОКЛАДКА КОЛЕНВАЛА ДВИГАТЕЛЯ] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (CR/SHF RR OIL SEAL HSG) 22531637 PIN, МАСЛЯНЫЙ ПОДДОН LOC (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 12570326 PIN, CYL HD LOC [ЗАГЛУШКА БЛОКА ЦИЛИНДРОВ] 12603197 PLATE, A/TRNS FLEX 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12608427 ROD, CONN (INCLS 201, 202) [ОСЬ] 11519680 БОЛТ, CONN ROD (ЧАСТЬ OF 200) (M9X1X53) [БОЛТ] not found BUSHING, CONN ROD (ЧАСТЬ OF 200) not found BEARING, CONN ROD (UPPER) (*KIT4) not found BEARING, CONN ROD (LOWER) (*KIT4) 12596024 PISTON, (W/PIN) (INCLS 211, 212) (STD) 12598127 PISTON, (W/PIN) (INCLS 211, 212) (0.25MM O.S.) (FOR STD SEE 12596024) not found PIN, PSTN (ЧАСТЬ OF 210) 12566186 RETAINER, PSTN PIN (ЧАСТЬ OF 210) not found RING, PSTN CMPRN UPR (*KIT3) not found RING, PSTN CMPRN LWR (*KIT3) not found RAIL, PSTN OIL RING (*KIT3) not found SPACER, PSTN OIL RING RL (*KIT3) 12603180 BALANCER, CR/SHF (DUAL BELT) [ШКИВ КОЛЕНВАЛА] 11569873 БОЛТ, CR/SHF BALR (M14X1.5X48.4) 12610143 NOZZLE, PSTN OIL 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (PSTN OIL NOZ) 12613030 SENSOR, CR/SHF POSN (INCLS 721, 722) [ДАТЧИК ПОЛОЖЕНИЯ КОЛЕНВАЛА] not found SEAL, CR/SHF POSN SEN (O RING) (ЧАСТЬ OF 720) 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 720) 12618603 SENSOR, KNOCK (W/O LEADS) (INCLS 724) (ACDelco #213-4335) [ДАТЧИК] 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 723) not found PLATE, CLU PRESS (ЧАСТЬ OF 900) 11519976 БОЛТ, HFLGE, M8X1.25X20, 15.6 THD, 18 O.D., 8.8, GMW3359 (CLU PRESS PLT) not found PLATE, CLU DRVN (ЧАСТЬ OF 900) 24243879 PLATE, CLU PRESS & DRVN (W/CVR) (INCLS 850, 852) 12575412 FLYКОЛЕСО, ENG 11588884 БОЛТ, HEX SOC HD, M10X1X24, 21 THD, 15.9 OD, 10.9, GMW3179G, HDR PT (FLYWHL) [КРЕПЕЖ] 12610603 BEARING KIT, CR/SHF (#1, 2, 4 STD) (INCLS 122, 123) [ПОДШИПНИК СКОЛЬЖЕНИЯ КОЛЕНВАЛА] teamcadillac.ru 12610604 BEARING KIT, CR/SHF (#3 STD) (INCLS 123, 124) [КОМПЛЕКТ ПОДШИПНИКОВ СКОЛЬЖЕНИЯ КОЛЕНВАЛА (3ШТ)] 12596025 RING KIT, PSTN (INCLS 213-216) (STD) 12598128 RING KIT, PSTN (INCLS 213-216) (0.25MM O.S.) 12598657 BEARING KIT, CONN ROD (INCLS 203, 204) [ПОДШИПНИК СКОЛЬЖЕНИЯ ШАТУНА] (6D00-047) - 2008 DM69 ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 1 БЛОК ЦИЛИНДРОВ И ВНУТРЕННИЕ ДЕТАЛИ (LLT/3.6V) ↓ not found BLOCK, ENG (MCHG) not found CAP, CR/SHF BRG 12560272 БОЛТ, CR/SHF BRG CAP (M10X2X102.5, 24.5) [ВИНТ] 11518861 БОЛТ, HFH, W/REDCD BODY, M8X1.25X90, 26 THD, 18 O.D., 10.9, GM4277M (CR/SHF BRG CAP) [БОЛТ] 11609410 БОЛТ, HFH, M8X1.25X25, 10.9, GMW3179 (CR/SHF BRG CAP) (0.056) [БОЛТ] 11589000 БОЛТ, HFH, M8X1.25X50, 24 THD, 18 OD, 10.9, GMW3359, RED BODY, W/ADH (CR/SHF BRG CAP) 12557520 PLUG, ENG BLK OIL GAL (CUP-.390IN OD, .040IN THK, STEEL) 12621352 CRANKSHAFT, [КОЛЕНВАЛ ДВИГАТЕЛЯ] 12601937 KEY, CR/SHF BALR not found BEARING, CR/SHF UPR (*KIT1) not found BEARING, CR/SHF LWR (*KIT1, KIT2) not found BEARING, CR/SHF THR (*KIT2) 11562127 PLUG, ENG BLK OIL GAL (CUP-14.22 OD, 6.6 THK, 304SS) (0.253) 11561583 PLUG, ENG BLK OIL GAL (M14X1.5X16, 22 OD) (0.253) 11561751 PLUG, CYL HD WAT JKT HOLE (M20X1.5X30.5) (1.531) 11569584 PLUG, ENG BLK CORE HOLE (CUP DIA 34.4MM) 12597210 PIN, TRANS LOC 12597210 PIN, TRANS LOC 12597210 PIN, TRANS LOC 12620955 SEAL, CR/SHF RR OIL [ПРОКЛАДКА КОЛЕНВАЛА ДВИГАТЕЛЯ] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (CR/SHF RR OIL SEAL HSG) teamcadillac.ru 22531637 PIN, МАСЛЯНЫЙ ПОДДОН LOC (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 12570326 PIN, CYL HD LOC [ЗАГЛУШКА БЛОКА ЦИЛИНДРОВ] 12603197 PLATE, A/TRNS FLEX 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12590584 ROD, CONN (INCLS 201, 202) 11519680 БОЛТ, CONN ROD (ЧАСТЬ OF 200) (M9X1X53) [БОЛТ] not found BUSHING, CONN ROD (ЧАСТЬ OF 200) not found BEARING, CONN ROD (UPPER) (*KIT4) not found BEARING, CONN ROD (LOWER) (*KIT4) 12616971 PISTON, (W/PIN) (INCLS 211, 212) (STD) 12616972 PISTON, (W/PIN) (INCLS 211, 212) (STD) not found PIN, PSTN (ЧАСТЬ OF 210) 12566186 RETAINER, PSTN PIN (ЧАСТЬ OF 210) not found RING, PSTN CMPRN UPR (*KIT3) not found RING, PSTN CMPRN LWR (*KIT3) not found RAIL, PSTN OIL RING (*KIT3) not found SPACER, PSTN OIL RING RL (*KIT3) 12603180 BALANCER, CR/SHF (DUAL BELT) [ШКИВ КОЛЕНВАЛА] 11569873 БОЛТ, CR/SHF BALR (M14X1.5X48.4) 12610143 NOZZLE, PSTN OIL 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (PSTN OIL NOZ) 12613030 SENSOR, CR/SHF POSN (INCLS 721, 722) [ДАТЧИК ПОЛОЖЕНИЯ КОЛЕНВАЛА] not found SEAL, CR/SHF POSN SEN (O RING) (ЧАСТЬ OF 720) 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 720) 12618603 SENSOR, KNOCK (INCLS 724) (ACDelco #213-4335) [ДАТЧИК] 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 723) not found PLATE, CLU PRESS (ЧАСТЬ OF 900) 11519976 БОЛТ, HFLGE, M8X1.25X20, 15.6 THD, 18 O.D., 8.8, GMW3359 (CLU PRESS PLT) not found PLATE, CLU DRVN (ЧАСТЬ OF 900) 24243879 PLATE, CLU PRESS & DRVN (W/CVR) (INCLS 850, 852) 12575412 FLYКОЛЕСО, ENG 11588884 БОЛТ, HEX SOC HD, M10X1X24, 21 THD, 15.9 OD, 10.9, GMW3179G, HDR PT (FLYWHL) [КРЕПЕЖ] 12610603 BEARING KIT, CR/SHF (INCLS 122, 123) [ПОДШИПНИК СКОЛЬЖЕНИЯ КОЛЕНВАЛА] 12610604 BEARING KIT, CR/SHF (INCLS 123, 124) [КОМПЛЕКТ ПОДШИПНИКОВ СКОЛЬЖЕНИЯ КОЛЕНВАЛА (3ШТ)] 12616973 RING KIT, PSTN (INCLS 213-216) 12598657 BEARING KIT, CONN ROD (INCLS 203, 204) [ПОДШИПНИК СКОЛЬЖЕНИЯ ШАТУНА] (6D00-047) - 2008-2009 DM69 ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 1 БЛОК ЦИЛИНДРОВ И ВНУТРЕННИЕ ДЕТАЛИ (LY7/3.6-7) ↓ not found BLOCK, ENG (MCHG) not found CAP, CR/SHF BRG 12560272 БОЛТ, CR/SHF BRG CAP (BOTTOM (LONG) (M10X2X102.5, 24.5) [ВИНТ] 11518861 БОЛТ, HFH, W/REDCD BODY, M8X1.25X90, 26 THD, 18 O.D., 10.9, GM4277M (CR/SHF BRG CAP) [БОЛТ] 11609410 БОЛТ, HFH, M8X1.25X25, 10.9, GMW3179 (CR/SHF BRG CAP) (0.056) [БОЛТ] 11589000 БОЛТ, HFH, M8X1.25X50, 24 THD, 18 OD, 10.9, GMW3359, RED BODY, W/ADH (CR/SHF BRG CAP) 12557520 PLUG, ENG BLK OIL GAL (CUP-.390IN OD, .040IN THK, STEEL) 12621351 CRANKSHAFT, [КОЛЕНВАЛ] 12601937 KEY, CR/SHF BALR not found BEARING, CR/SHF UPR (*KIT1) not found BEARING, CR/SHF LWR (*KIT1, KIT2) not found BEARING, CR/SHF THR (*KIT2) 11562127 PLUG, ENG BLK OIL GAL (CUP-14.22 OD, 6.6 THK, 304SS) (0.253) 11561583 PLUG, ENG BLK OIL GAL (M14X1.5X16, 22 OD) (0.253) 11561751 PLUG, CYL HD WAT JKT HOLE (M20X1.5X30.5) (1.531) 11569584 PLUG, ENG BLK CORE HOLE (CUP DIA 34.4MM) 12597210 PIN, TRANS LOC 12620955 SEAL, CR/SHF RR OIL [ПРОКЛАДКА КОЛЕНВАЛА ДВИГАТЕЛЯ] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (CR/SHF RR OIL SEAL HSG) 22531637 PIN, МАСЛЯНЫЙ ПОДДОН LOC (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 12570326 PIN, CYL HD LOC [ЗАГЛУШКА БЛОКА ЦИЛИНДРОВ] 12603197 PLATE, A/TRNS FLEX 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12608432 ROD, CONN (INCLS 201, 202) 11519680 БОЛТ, CONN ROD (ЧАСТЬ OF 200) (M9X1X53) [БОЛТ] not found BUSHING, CONN ROD (ЧАСТЬ OF 200) not found BEARING, CONN ROD (UPPER) (*KIT4) not found BEARING, CONN ROD (LOWER) (*KIT4) teamcadillac.ru 12585675 PISTON, (W/PIN) (INCLS 211, 212) (.25 O.S.) 12590866 PISTON, (W/PIN) (INCLS 211, 212) (STD) not found PIN, PSTN (ЧАСТЬ OF 210) 12566186 RETAINER, PSTN PIN (ЧАСТЬ OF 210) not found RING, PSTN CMPRN UPR (*KIT3) not found RING, PSTN CMPRN LWR (*KIT3) not found RAIL, PSTN OIL RING (*KIT3) not found SPACER, PSTN OIL RING RL (*KIT3) 12603180 BALANCER, CR/SHF (DUAL BELT) [ШКИВ КОЛЕНВАЛА] 11569873 БОЛТ, CR/SHF BALR (M14X1.5X48.4) 12610143 NOZZLE, PSTN OIL 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (PSTN OIL NOZ) 12613030 SENSOR, CR/SHF POSN (INCLS 721, 722) [ДАТЧИК ПОЛОЖЕНИЯ КОЛЕНВАЛА] not found SEAL, CR/SHF POSN SEN (O RING) (ЧАСТЬ OF 720) 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 720) 12618603 SENSOR, KNOCK (W/O LEADS) (INCLS 724) (ACDelco #213-4335) [ДАТЧИК] 11589313 БОЛТ, HFH, M8X1.25X39, 29 THD, 18 OD, 8.8 STL, GMW3359, M-PT. (ЧАСТЬ OF 723) not found PLATE, CLU PRESS (ЧАСТЬ OF 900) 11570903 БОЛТ-HFHE, M8X1.25X20, 12 THD, 16 OD, 10.9, GMW3359, 6MM MAT PT (CLU PRESS PLT) not found PLATE, CLU DRVN (ЧАСТЬ OF 900) 24243879 PLATE, CLU PRESS & DRVN (W/CVR) (INCLS 850, 852) 12575412 FLYКОЛЕСО, ENG 11588884 БОЛТ, HEX SOC HD, M10X1X24, 21 THD, 15.9 OD, 10.9, GMW3179G, HDR PT (FLYWHL) [КРЕПЕЖ] 12610603 BEARING KIT, CR/SHF (#1, 2, 4 STD) (INCLS 122, 123) [ПОДШИПНИК СКОЛЬЖЕНИЯ КОЛЕНВАЛА] 12610604 BEARING KIT, CR/SHF (#3 STD) (INCLS 123, 124) [КОМПЛЕКТ ПОДШИПНИКОВ СКОЛЬЖЕНИЯ КОЛЕНВАЛА (3ШТ)] 12608615 RING KIT, PSTN (INCLS 213-216) (STD) 12598657 BEARING KIT, CONN ROD (INCLS 203, 204) [ПОДШИПНИК СКОЛЬЖЕНИЯ ШАТУНА] (6D00-049) - 2008 DM69 ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 2 ГОЛОВКА ЦИЛИНДРОВ & ДЕТАЛИ КОМПЛЕКТА (LLT/3.6V) ↓ 12570326 PIN, CYL HD LOC [ЗАГЛУШКА БЛОКА ЦИЛИНДРОВ] 12606653 ACTUATOR, CM/SHF POSN (USE WASHER 12630941) 12603744 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) 12603745 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) 11588279 БОЛТ, HFH, M10X1.5X80, 26 THD, 22.3 O.D., 10.9, GM4277M (CM/SHF POSN) 12624804 COVER, CM/SHF (INCLS 251, 254-256, 260, 263) [КРЫШКА] 12626054 COVER, CM/SHF (INCLS 251, 254-256, 261) [КРЫШКА] 12595107 SEAL, CM/SHF CVR (ЧАСТЬ OF 250) (*KIT1) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12607401 SEAL, CM/SHF CVR (ЧАСТЬ OF 250) (*KIT1) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12607600 SEAL, SPLG SHLD (ЧАСТЬ OF 250) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО СИСТЕМЫ ЗАЖИГАНИЯ] 11518859 БОЛТ, HFH W/SHLDR, M6X1X35, 11.85 THD, 18 O.D., 8.8, GMW3359 (ЧАСТЬ OF 250) 12595122 INSULATOR, CM/SHF CVR БОЛТ (ЧАСТЬ OF 250) (*KIT1) 12593356 CAP, OIL FIL (INCLS 904) (ACDelco #FC221) [КРЫШКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ] 12593348 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 262) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА] 12615294 TUBE, OIL FIL (INCLS 259) [ТРУБКА МАСЛЯНОГО ФИЛЬТРА] not found SEAL, PCV HOSE FTG (O RING) (ЧАСТЬ OF 250, 260) 12601745 INSULATOR, CM/SHF HSG CVR [НАКЛАДКА КЛАПАННОЙ КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12603147 INSULATOR, CM/SHF HSG CVR 12590607 HEAD, CYL (MCHG) (INCLS 313, 318, 319, 328, 336, 337) (DOES NOT INCL ENG OIL MANIF CHECK VALVES. DLR MUST INSTL) [ГОЛОВКА БЛОКА ЦИЛИНДРОВ] 12617767 HEAD, CYL (MCHG) (INCLS 313, 318, 319, 328, 336, 337) (DOES NOT INCL ENG OIL MANIF CHECK VALVES. DLR MUST INSTL) [ГОЛОВКА БЛОКА ЦИЛИНДРОВ] 12620190 GASKET, CYL HD (*KIT1) 12624743 GASKET, CYL HD (*KIT1) 11588734 БОЛТ, HFH, M8X1.25X90, 21.6 THD, 18 O.D., 8.8, GMW3359 (CYL HD) [ВИНТ] 11561751 PLUG, CYL HD WAT JKT HOLE (ЧАСТЬ OF 300) (M20X1.5X30.5) (1.531) not found SLEEVE, SPLG WIRE (ЧАСТЬ OF 300) 12575354 VALVE, EXH (STD) [КЛАПАН ВЫПУСКНОЙ] 12584760 VALVE, EXH (0.075 O.S.) [КЛАПАН ВЫПУСКНОЙ] 12575351 VALVE, INT (STD) [КЛАПАН ВПУСКНОЙ] 12584763 VALVE, INT (0.075MM O.S.) (0.297) [КЛАПАН ВПУСКНОЙ] 24100294 ARM, VLV RKR [РЫЧАГ] 24100005 ADJUSTER, HYD VLV LASH (ACDelco #24100005) [ТОЛКАТЕЛЬ КЛАПАНА ДВИГАТЕЛЯ] 12565836 SEAL, VLV STEM OIL [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КЛАПАНА ДВИГАТЕЛЯ] 12575355 ПРУЖИНА, VLV [ПРУЖИНА КЛАПАНА] 12575196 RETAINER, VLV SPR [КОМПАКТ ДИСК] 12575197 KEY, VLV STEM [КЛАПАННЫЙ КЛЮЧ] not found CAP, CM/SHF BRG (ЧАСТЬ OF 300) 12574477 RING, CM/SHF SPKT OIL SEAL (ЧАСТЬ OF 330, 331) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО РАСПРЕДВАЛА ДВИГАТЕЛЯ (2 ШТ.)] 12604375 CAMSHAFT, EXH (INCLS 329) [РАСПРЕДВАЛ] 12604376 CAMSHAFT, EXH (INCLS 329) [РАСПРЕДВАЛ] 12604374 CAMSHAFT, INT (INCLS 329) [РАСПРЕДВАЛ] 12604377 CAMSHAFT, INT (INCLS 329) [РАСПРЕДВАЛ] not found CAP, CM/SHF BRG (ЧАСТЬ OF 300) 11518856 HFH, M6X1X43.4, 14.8 THD, 11 O.D., 8.8, GMW3179 CODE G (ЧАСТЬ OF 300) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12580965 VALVE, ENG OIL MANIF CHK [КЛАПАН] 12613057 РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ, IGN (INCLS 705) (ACDelco #12613057) 11588715 БОЛТ, HFH, M6X1X35, 18 THD, 14.2 OD, 8.8, GMW3359, 5MM M POINT (ЧАСТЬ OF 704) [БОЛТ] 12566778 SENSOR, ENG COOL TEMP (3.682) (ACDelco #213-1581) [СЕНСОР ТЕМПЕРАТУРЫ] teamcadillac.ru 12566778 SENSOR, ENG COOL TEMP (ACDelco #213-1581) [СЕНСОР ТЕМПЕРАТУРЫ] 12597464 СВЕЧИ, (DO NOT CHANGE СВЕЧИ GAP) (ACDelco #41-990) (PLATINUM PLUG) [СВЕЧА ЗАЖИГАНИЯ] 12600313 SEAL, F/PMP HSG (O RING) (ЧАСТЬ OF 902) (ACDelco #G43) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ДВИГАТЕЛЯ] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 902) 12626234 PUMP, FUEL (INCLS 900, 901, 903) (ACDelco #EP2129) [ТОПЛИВНЫЙ НАСОС] 12595951 GASKET, F/PMP BRKT (ЧАСТЬ OF 902) [ПРОКЛАДКА ТОПЛИВНОГО НАСОСА] 12593348 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 258) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА] 12590679 FOLLOWER, VLV LFTR (FUEL PUMP) [НАПРАВЛЯЮЩАЯ ВТУЛКА ТОПЛИВНОГО НАСОСА] not found RAIL, DIR F/INJN FUEL (СМ. ГРУППУ 03.000 "FUEL RAIL" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11519171 БОЛТ, F/INJN FUEL RL (M8X1.25X50) (3.275) [БОЛТ ВЫПУСКНОГО КОЛЛЕКТОРА] 12625782 GASKET KIT, CYL HD (INCLS 251, 256, 302) [КОМПЛЕКТ ПРОКЛАДОК ГОЛОВКИ БЛОКА ЦИЛИНДРОВ (ПАР-2ШТ, РЕЗ-2ШТ, МЕТ-1ШТ)] (6D00-050) - 2008 DM69 ДВИГАТЕЛЬ В СБОРЕ-2.8L V6 ЧАСТЬ 5 КОЛЛЕКТОР & ДЕТАЛИ КОМПЛЕКТА (LP1/2.8T) ↓ 12604933 TUBE, PCV (FRESH AIR) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (PCV TUBE) 12616910 HOSE, PCV (INCLS 285, 286, 290-292) (DIRTY AIR) 12616908 SEAL, PCV HOSE FTG (O RING) (ЧАСТЬ OF 283) (BLUE) (LARGER OF THE TWO ON THE FITTING) [УПЛОТНЕНИЕ] 12616909 SEAL, PCV HOSE FTG (O RING) (ЧАСТЬ OF 283) (BLACK) (SMALLER OF THE TWO ON THE FITTING) [УЛОТНЕНИЕ] not found BRACKET, PCV VLV HOSE (ЧАСТЬ OF 283) not found BRACKET, PCV VLV HOSE (ЧАСТЬ OF 283) not found CLIP, PCV VLV HOSE (ЧАСТЬ OF 283) 12597853 MANIFOLD, UPR INT (MACH) (INCLS 506) 12571079 MANIFOLD, LWR INT (INCLS 519) not found PLUG, INT MANIF (ЧАСТЬ OF 503) 11518906 БОЛТ, HFH, RDUCD BDY, M8X1.25X165, 22 THD, 18 O.D., 8.8, GMW3359 (INT UPR MANIF) [БОЛТ] 11519176 БОЛТ, INT MANIF (M8X1.25X80) (4.081) [БОЛТ] not found PIN, UPR INT MANIF LOC (ЧАСТЬ OF 504) not found GASKET, UPR INT MANIF (*KIT1, KIT2, KIT3) not found GASKET, LWR INT MANIF (*KIT1, KIT3) 11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (LWR INT MANIF) 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (F/INJN FUEL RL) [БОЛТ] 11588523 STUD, M6X1 (UPR INT MANIF SIGHT SHLD) 12576262 GASKET, EXH MANIF [ПРОКЛАДКА ВЫПУСКНОГО КОЛЛЕКТОРА] 12571102 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 12580706 SHIELD, EXH MANIF HT 11518860 БОЛТ, HFH, M8X1.25X30, 20.9 THD, 18 O.D., 10.9, GMW3179 CODE G, GM6194M (EXH MANIF H/SHLD) [БОЛТ] teamcadillac.ru 12582663 INSULATOR, EXH MANIF UPR 12616647 SHIELD, STRTR HT 12576263 GASKET, EXH MANIF 12571101 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 11518860 БОЛТ, HFH, M8X1.25X30, 20.9 THD, 18 O.D., 10.9, GMW3179 CODE G, GM6194M (EXH MANIF H/SHLD) [БОЛТ] 12617267 SHIELD, EXH MANIF HT 12581807 INSULATOR, EXH MANIF LWR 14093869 ГАЙКА, PUSH ON, M6, 2.25THK, 12.95 O.D., STL, POR (EXH MANIF H/SHLD INSL) 12616994 BODY, THROT (W/THROT ACTR) (ACDelco #217-3103) [ЧАСТЬ КОРПУСА] 11519972 БОЛТ, THROT BODY (M6X1.0X50) 12593360 GASKET, THROT BODY (ACDelco #40-5083) [ПРОКЛАДКА ДРОССЕЛЬНОЙ ЗАСЛОНКИ] 12611801 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 752) (ACDelco #214-1685) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 12611801 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 752) (ACDelco #214-1685) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 12611801 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 752) (ACDelco #214-1685) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 12611801 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 752) (ACDelco #214-1685) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 12611801 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 752) (ACDelco #214-1685) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (EVAP EMIS CNSTR PURGE SOL VLV BRKT) 12584171 HOSE, EVAP EMIS CNSTR SOL VLV not found BRACKET, SOL VLV (ЧАСТЬ OF 744) 12629734 VALVE, INT MANIF TUNING (INCLS 756) not found SEAL, INT MANIF TUNING VLV (ЧАСТЬ OF 755) 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (INT MANIF TUNING VLV) [БОЛТ] not found RAIL, F/INJN FUEL (СМ. ГРУППУ 03.000 "FUEL INJECTION RAIL" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 12604673 BRACE, INT MANIF 11588723 БОЛТ, HFH, M8X1.25X25, 18 THD, 18 OD, 8.8 STL, GMW3359, M-PT (INT MANIF BR) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (INT MANIF BR) 12617801 GASKET KIT, CYL HD (INCLS 521, 522) 12595277 GASKET KIT, UPR INT MANIF (INCLS 521) [ПРОКЛАДКА] 12598158 GASKET KIT, INT MANIF (INCLS 521, 522) [ПРОКЛАДКА ДВИГАТЕЛЯ] (6D00-050) - 2008-2009 DM69 ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 5 КОЛЛЕКТОР & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7) ↓ 12604933 TUBE, PCV (FRESH AIR) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (PCV TUBE) 12616910 HOSE, PCV (INCLS 285, 286, 290-292) (DIRTY AIR) 12616908 SEAL, PCV HOSE FTG (O RING) (ЧАСТЬ OF 283) (BLUE) (LARGER OF THE TWO ON THE FITTING) [УПЛОТНЕНИЕ] 12616909 SEAL, PCV HOSE FTG (O RING) (ЧАСТЬ OF 283) (BLACK) (SMALLER OF THE TWO ON THE FITTING) [УЛОТНЕНИЕ] not found BRACKET, PCV VLV HOSE (ЧАСТЬ OF 283) not found BRACKET, PCV VLV HOSE (ЧАСТЬ OF 283) not found CLIP, PCV VLV HOSE (ЧАСТЬ OF 283) 12597853 MANIFOLD, UPR INT (MACH) (INCLS 506) 12571079 MANIFOLD, LWR INT (INCLS 519) not found PLUG, INT MANIF (ЧАСТЬ OF 503) 11518906 БОЛТ, HFH, RDUCD BDY, M8X1.25X165, 22 THD, 18 O.D., 8.8, GMW3359 (INT UPR MANIF) [БОЛТ] 11519176 БОЛТ, INT MANIF (M8X1.25X80) (4.081) [БОЛТ] not found PIN, UPR INT MANIF LOC (ЧАСТЬ OF 504) not found GASKET, UPR INT MANIF (*KIT1, KIT2, KIT3) not found GASKET, LWR INT MANIF (*KIT1, KIT3) 11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (LWR INT MANIF) 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (F/INJN FUEL RL) [БОЛТ] 11588523 STUD, M6X1 (UPR INT MANIF SIGHT SHLD) 12576262 GASKET, EXH MANIF [ПРОКЛАДКА ВЫПУСКНОГО КОЛЛЕКТОРА] 12571102 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 12580706 SHIELD, EXH MANIF HT 11518860 БОЛТ, HFH, M8X1.25X30, 20.9 THD, 18 O.D., 10.9, GMW3179 CODE G, GM6194M (EXH MANIF H/SHLD) [БОЛТ] 12582663 INSULATOR, EXH MANIF UPR 12616647 SHIELD, STRTR HT 12576263 GASKET, EXH MANIF 12571101 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 11518860 БОЛТ, HFH, M8X1.25X30, 20.9 THD, 18 O.D., 10.9, GMW3179 CODE G, GM6194M (EXH MANIF H/SHLD) [БОЛТ] 12617267 SHIELD, EXH MANIF HT teamcadillac.ru 12581807 INSULATOR, EXH MANIF LWR 14093869 ГАЙКА, PUSH ON, M6, 2.25THK, 12.95 O.D., STL, POR (EXH MANIF H/SHLD INSL) 12616994 BODY, THROT (W/THROT ACTR) (ACDelco #217-3103) [ЧАСТЬ КОРПУСА] 11519972 БОЛТ, THROT BODY (M6X1.0X50) 12593360 GASKET, THROT BODY (ACDelco #40-5083) [ПРОКЛАДКА ДРОССЕЛЬНОЙ ЗАСЛОНКИ] 12611801 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 752) (ACDelco #214-1685) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 12611801 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 752) (ACDelco #214-1685) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 12611801 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 752) (ACDelco #214-1685) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 12611801 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 752) (ACDelco #214-1685) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (EVAP EMIS CNSTR PURGE SOL VLV BRKT) 12584171 HOSE, EVAP EMIS CNSTR SOL VLV not found BRACKET, SOL VLV (ЧАСТЬ OF 744) 12629734 VALVE, INT MANIF TUNING (INCLS 756) not found SEAL, INT MANIF TUNING VLV (ЧАСТЬ OF 755) 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (INT MANIF TUNING VLV) [БОЛТ] not found RAIL, F/INJN FUEL (СМ. ГРУППУ 03.000 "FUEL INJECTION RAIL" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 12604673 BRACE, INT MANIF 11588723 БОЛТ, HFH, M8X1.25X25, 18 THD, 18 OD, 8.8 STL, GMW3359, M-PT (INT MANIF BR) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (INT MANIF BR) 12625781 GASKET KIT, CYL HD (INCLS 521, 522) (INCLS UPR & LWR INT MANIF GASKETS) [КОМПЛЕКТ ПРОКЛАДОК ВПУСКНОГО КОЛЛЕКТОРА (2ШТ)] 12595277 GASKET KIT, UPR INT MANIF (INCLS 521) [ПРОКЛАДКА] 12598158 GASKET KIT, INT MANIF (INCLS 521, 522) [ПРОКЛАДКА ДВИГАТЕЛЯ] (6D00-051) - 2008 DM69 ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 5 КОЛЛЕКТОР & ДЕТАЛИ КОМПЛЕКТА (LLT/3.6V) ↓ 12604933 TUBE, PCV (FRESH AIR) 12616915 TUBE, PCV (FOUL AIR) [ТРУБКА] 12604933 TUBE, PCV (INCLS 285, 286) (FRESH AIR) 12616915 TUBE, PCV (INCLS 285, 286) (FOUL AIR) [ТРУБКА] 12616908 SEAL, PCV HOSE FTG (O RING) (ЧАСТЬ OF 283) (BLUE) (LARGER OF THE TWO ON THE FITTING) [УПЛОТНЕНИЕ] 12616909 SEAL, PCV HOSE FTG (O RING) (ЧАСТЬ OF 283) (BLACK) (SMALLER OF THE TWO ON THE FITTING) [УЛОТНЕНИЕ] 12595765 MANIFOLD, INT (INCLS 918) [ГЛУШИТЕЛЬ] 11610106 БОЛТ-HFH, M8X1.25X126.8, 21.6 THD, 18 OD, 8.8, GMW3359, M-PT (INT MANIF) 11588735 БОЛТ, HFH, M8X1.25X100, 22 THD, 18 OD, 8.8 STL, GMW3359, M-PT (INT MANIF) 12590958 GASKET, LWR INT MANIF (*KIT1, KIT2) [ПРОКЛАДКА ВПУСКНОГО КОЛЛЕКТОРА ДВИГАТЕЛЯ] 12610850 SHIELD, FUEL PIPE 12610850 SHIELD, FUEL PIPE 11588723 БОЛТ, HFH, M8X1.25X25, 18 THD, 18 OD, 8.8 STL, GMW3359, M-PT (FUEL PIPE SHLD) 12576262 GASKET, EXH MANIF [ПРОКЛАДКА ВЫПУСКНОГО КОЛЛЕКТОРА] 12571102 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 12580706 SHIELD, EXH MANIF HT 11518860 БОЛТ, HFH, M8X1.25X30, 20.9 THD, 18 O.D., 10.9, GMW3179 CODE G, GM6194M (EXH MANIF H/SHLD) [БОЛТ] 12582663 INSULATOR, EXH MANIF UPR 12616647 SHIELD, STRTR HT 12576263 GASKET, EXH MANIF 12571101 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 11518860 БОЛТ, HFH, M8X1.25X30, 20.9 THD, 18 O.D., 10.9, GMW3179 CODE G, GM6194M (EXH MANIF H/SHLD) [БОЛТ] 12617267 SHIELD, EXH MANIF HT 12581807 INSULATOR, EXH MANIF LWR 14093869 ГАЙКА, PUSH ON, M6, 2.25THK, 12.95 O.D., STL, POR (EXH MANIF H/SHLD INSL) 12616994 BODY, THROT (W/THROT ACTR) (ACDelco #217-3103) [ЧАСТЬ КОРПУСА] 11519972 БОЛТ, THROT BODY (M6X1.0X50) 12606638 GASKET, THROT BODY (ACDelco #40-5093) [ПРОКЛАДКА] 12611801 VALVE, EVAP EMIS CNSTR PURGE SOL (ACDelco #214-1685) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 12611801 VALVE, EVAP EMIS CNSTR PURGE SOL (ACDelco #214-1685) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 12584171 HOSE, EVAP EMIS CNSTR SOL VLV 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (EVAP EMIS CNSTR PURGE SOL VLV BRKT) 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (INT MANIF) 12595766 COVER, INT MANIF (PLENUM TOP COVER) [КРЫШКА] 12630022 SHIELD, ENG RR NOISE 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (INT MANIF) 12595767 BRACE, INT MANIF 12617977 SHIELD, F/INJN FUEL RL NOISE 12611315 SHIELD, F/INJN FUEL RL NOISE (LWR) 12574525 VALVE, FUEL PRESS SERV (ЧАСТЬ OF 913) (SCHRADER VALVE LESS CAP) [КЛАПАН КОНТРОЛЯ ДАВЛЕНИЯ ТОПЛИВНОЙ СИСТЕМЫ] 25532662 CAP, FUEL PRESS SERV VLV (ЧАСТЬ OF 913) (CAP FOR PRESSURE TEST SCHRADER VALVE) (3.163) (ACDelco #214-1044) [КРЫШКА] 25532662 CAP, FUEL PRESS SERV VLV (ЧАСТЬ OF 913) (CAP FOR PRESSURE TEST SCHRADER VALVE) (3.163) (ACDelco #214-1044) [КРЫШКА] 25532662 CAP, FUEL PRESS SERV VLV (ЧАСТЬ OF 913) (CAP FOR PRESSURE TEST SCHRADER VALVE) (3.163) (ACDelco #214-1044) [КРЫШКА] teamcadillac.ru 12591003 TUBE, F/INJN FUEL RL C/OVR 11589040 БОЛТ, F/INJN FUEL FEED & RTN PIPE RET (4.115) [БОЛТ М10] 12591197 PIPE, FUEL FEED INTER [ТРУБКА ТОПЛИВНОЙ СИСТЕМЫ] 12626234 PUMP, FUEL (СМ. ГРУППУ 00.000 "ГОЛОВКА ЦИЛИНДРОВ & ДЕТАЛИ КОМПЛЕКТА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #EP2129) [ТОПЛИВНЫЙ НАСОС] 12614933 PIPE, FUEL FEED (LOW PRESSURE W/DAMPER CAN & SERVICE PORT. INLET TO HIGH PRESSURE FUEL PUMP) (INCLS 907, 908) [ШЛАНГ] 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (EXH MANIF H/SHLD) [БОЛТ] 11519977 БОЛТ- HFH, M8X1.25X25, 16 THD, 18 OD, 8.8, GMW3359, MAT-PT. (INT MANIF) 11589278 БОЛТ-HFH, M12X1.75X75.9, 45 THD, 26.6 OD, 10.9, GMW3359, REDUCED BODY (INT MANIF BR) 11588723 БОЛТ, HFH, M8X1.25X25, 18 THD, 18 OD, 8.8 STL, GMW3359, M-PT (FUEL PIPE SHLD) 00104918 BALL, 1/4" DIA, CHROME STL (ЧАСТЬ OF 503) (ACDelco #104918) 11588735 БОЛТ, HFH, M8X1.25X100, 22 THD, 18 OD, 8.8 STL, GMW3359, M-PT (INT MANIF) not found GASKET, INT MANIF CVR (*KIT2) not found GASKET, INT MANIF CVR (*KIT2) not found RAIL, DIR F/INJN FUEL (СМ. ГРУППУ 03.000 "FUEL INJECTION RAIL" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11519171 БОЛТ, F/INJN FUEL RL (M8X1.25X50) (3.275) [БОЛТ ВЫПУСКНОГО КОЛЛЕКТОРА] 12625782 GASKET KIT, CYL HD (INCLS 522) [КОМПЛЕКТ ПРОКЛАДОК ГОЛОВКИ БЛОКА ЦИЛИНДРОВ (ПАР-2ШТ, РЕЗ-2ШТ, МЕТ-1ШТ)] 12615968 GASKET KIT, INT MANIF (INCLS 522, 920, 921) [КОМППЛЕКТ ПРОКЛАДОК ВЫХЛОПНОЙ СИСТЕМЫ(МЕТАЛЛ 1ШТ, РЕЗИНА 1ШТ)] (6D00-052) - 2008 DM69 ДВИГАТЕЛЬ В СБОРЕ & ЧАСТЬIAL ДВИГАТЕЛЬ (LLT/3.6V) ↓ not found ДВИГАТЕЛЬ, 3.6 L (220 CID) not found ДВИГАТЕЛЬ KIT, GASOLINE (GOODWRENCH) teamcadillac.ru not found ДВИГАТЕЛЬ, GASOLINE (GOODWRENCH NEW) not found ДВИГАТЕЛЬ, GASOLINE (GOODWRENCH REMAN) 12621267 ДВИГАТЕЛЬ KIT, GASOLINE (GOODWRENCH) [ДВИГАТЕЛЬ БЕНЗИН, 6 ЦИЛ., 3.6Л, 270Л.С.] (6D00-054) - 2008 DM69 КРЕПЛЕНИЕ ДВИГАТЕЛЯ TO ТРАНСМИССИЯ (AUTOMATIC MYB) ↓ 12603197 PLATE, A/TRNS FLEX 12603197 PLATE, A/TRNS FLEX 12603197 PLATE, A/TRNS FLEX 12597210 PIN, TRANS LOC not found БОЛТ, TRANSAXLE T/CV 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] 24242043 БОЛТ, TRANS CONV CVR (M6X1X18/M6X1X14) not found COVER, TRANS teamcadillac.ru 24222918 COVER, TRANS CONV 24222918 COVER, TRANS (0.679) 24205900 COVER, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] (6D00-060) - 2008 DM69 ДВИГАТЕЛЬ В СБОРЕ & ЧАСТЬIAL ДВИГАТЕЛЬ (LY7/3.6-7) ↓ not found ДВИГАТЕЛЬ, 3.6 L (220 CID) (PRODUCTION) teamcadillac.ru 12617625 ДВИГАТЕЛЬ KIT, GASOLINE (GOODWRENCH) (MUST SWAP МАСЛЯНЫЙ ПОДДОН) (SERVICE) 19206165 ДВИГАТЕЛЬ, (SERV ЧАСТЬIAL) (SERVICE) (MAY NEED TO SWAP МАСЛЯНЫЙ ПОДДОН) (REQUIRES CRANKSHAFT BALANCER WITH KEYWAY. FOR SINGLE BELT, USE 12603181. FOR DUAL BELT BALANCER USE 12603180) (6M00-072) - 2008 DM69 INTAKE MANIFOLD SHIELD/COVERS (LLT/3.6V) ↓ 12632150 COVER, INT MANIF (INCLS 2, 12-16, 19) (ДВИГАТЕЛЬ COVER) 12632150 COVER, INT MANIF (INCLS 2, 12-16, 19) (ДВИГАТЕЛЬ COVER) (3.265) not found INSULATOR, INT MANIF CVR (ЧАСТЬ OF 1) 20664092 RETAINER, UPR INT MANIF SIGHT SHLD (BLACK) (6.3MM DIA X 23MM) (1.276) [КЛИПСА КРЕПЛЕНИЯ МОЛДИНГА ДВЕРИ] 12603359 INSULATOR, INT MANIF [УПЛОТНИТЕЛЬ] 11588723 БОЛТ, HFH, M8X1.25X25, 18 THD, 18 OD, 8.8 STL, GMW3359, M-PT (INT MANIF SIGHT SHLD) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (INT MANIF SIGHT SHLD) 11516075 ГАЙКА, HFH SELF LK, M6X1, 7.7THK, 14.2 O.D., 9, PZOR (INT MANIF SIGHT SHLD BRKT) [ГАЙКА ВЫПУСКНОЙ СИСТЕМЫ D=6ММ] 11588967 STUD, BALL W/HFH, M6X1X20.65, 14.2 O.D., 8.8, GMW3359 (INT MANIF SIGHT SHLD) 12616618 BRACKET, INT MANIF SIGHT SHLD 12593348 SEAL, OIL FIL TUBE (O RING) (27.94MM I.D.) (SIZE #320) (1.758) [ПРОКЛАДКА] 12615294 TUBE, OIL FIL (INCLS 17, 18) [ТРУБКА МАСЛЯНОГО ФИЛЬТРА] 12591714 GROMMET, UPR INT MANIF SIGHT SHLD (ЧАСТЬ OF 1) (60MM OD @ TOP) (ROUND TOP & BOTTOM) not found INSULATOR, F/INJR SIGHT SHLD BRKT (ЧАСТЬ OF 1) 10042521 ГАЙКА, INT MANIF INSL (ЧАСТЬ OF 1) (7.831) 12591715 GROMMET, UPR INT MANIF SIGHT SHLD (ЧАСТЬ OF 1) (32MM OD @ TOP) (ROUND AT TOP/TAPERED CONICAL BOTTOM) 12607405 EMBLEM, INT MANIF CVR (ЧАСТЬ OF 1) [ЭМБЛЕМА] 12593356 CAP, OIL FIL (ЧАСТЬ OF 11) (INCLS 18) (ACDelco #FC221) [КРЫШКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ] 12593348 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 11, 17) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА] 24507878 INSULATOR, F/INJR SIGHT SHLD BRKT (ЧАСТЬ OF 1) 12630022 SHIELD, ENG RR NOISE not found SHIELD, FUEL PIPE 12610850 SHIELD, FUEL PIPE 12610850 SHIELD, FUEL PIPE 11588723 БОЛТ, HFH, M8X1.25X25, 18 THD, 18 OD, 8.8 STL, GMW3359, M-PT (FUEL PIPE SHLD) teamcadillac.ru 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (FUEL PIPE SHLD) (6M00-073) - 2008-2009 DM69 ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 4 МАСЛЯНЫЙ НАСОС,МАСЛЯНЫЙ ПОДДОН & ДЕТАЛИ КОМПЛЕКТА (LLT/3.6V, ПОЛНОПРИВОДНЫЙ MX7) ↓ 22531637 PIN, МАСЛЯНЫЙ ПОДДОН LOC (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 12586959 GUIDE, TMG CHAIN (ЧАСТЬ OF 463) (2 КРЕПЛЕНИЕ HOLES) (LOWER PRIMARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ГРМ] 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (ЧАСТЬ OF 463) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12596502 PAN, OIL (INCLS 404-407, 410, 412, 413, 420, 422, 900) 12575500 PLATE, МАСЛЯНЫЙ ПОДДОН SKID (ЧАСТЬ OF 400) 12575373 PIPE, O/PMP SUC (ЧАСТЬ OF 400) 12566837 SEAL, O/PMP SUC PIPE (ЧАСТЬ OF 400) [УПЛОТНЕНИЕ] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 400) 12566872 DEFLECTOR, CR/SHF OIL (ЧАСТЬ OF 400) 11562588 PLUG, МАСЛЯНЫЙ ПОДДОН DRN (ЧАСТЬ OF 400) (INCLS 413) (W/ SEAL) (EXC MAGNET) [ЗАГЛУШКА МАСЛЯНОГО ПОДДОНА] 12616850 SEAL, МАСЛЯНЫЙ ПОДДОН DRN PLUG (O RING) (ЧАСТЬ OF 400, 412) 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (ЧАСТЬ OF 400) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11588424 БОЛТ, HFH, M6X1X145, 18 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 400) [ШЕСТИГРАННЫЙ ВИНТ] 12611594 INDICATOR, OIL LVL (INCLS 434) 12612349 TUBE, OIL LVL IND (INCLS 432) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 431) (BLACK) (6.07MM ID, 1.78MM DIA) (INDICATOR) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 431) (BLACK) (6.07MM ID, 1.78MM DIA) (TUBE) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (OIL LVL IND TUBE) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) (INDICATOR) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) (TUBE) 12591607 ADAPTER, OIL FLTR (INCLS 441-443, 446-450, 456, 458, 459, 728, 729) [АДАПТЕР МАСЛЯНОГО ФИЛЬТРА] 12591604 GASKET, OIL FLTR (ЧАСТЬ OF 440) (BETWEEN OIL FILTER ADAPTER AND BLOCK) [ПРОКЛАДКА МАСЛЯНОГО ФИЛЬТРА] 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 440) 11519174 БОЛТ, HFH, W/REDUCED BODY, M8X1.25X65, THD 22, O.D. 18, 8.8, GMW3359 (ЧАСТЬ OF 440) 25014612 VALVE, OIL FLTR BYPASS (ЧАСТЬ OF 440, 450) (W/O VAPOR SEPARATOR) (OPENING PRESSURE 21 PSI NOMINAL) (ЧАСТЬ HAS A 16.10MM MAX OD & FITS A 15.84 HOLE IN BLOCK) 11519184 БОЛТ, OIL FLTR ADAP (ЧАСТЬ OF 440) (M10X1.5X45) (0.029) not found SPACER, OIL FLTR (ЧАСТЬ OF 440) 25177917 ФИЛЬТР, МАСЛЯНЫЙ (ЧАСТЬ OF 440) (ACDelco #PF2129) [МАСЛЯНЫЙ ФИЛЬТР ДВИГАТЕЛЯ] 12583470 CAP, OIL FLTR (ЧАСТЬ OF 440) (INCLS 446, 451, 456) [КРЫШКА] 12577653 SEAL, OIL FLTR CAP (O RING) (ЧАСТЬ OF 450) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КРЫШКИ МАСЛЯНОГО ФИЛЬТРА] not found RETAINER, OIL FLTR BYPASS VLV SPR (ЧАСТЬ OF 440, 450) not found CAGE, OIL FLTR BYPASS VLV (ЧАСТЬ OF 440) not found SEAL, OIL FLTR DRN PLUG (O RING) (ЧАСТЬ OF 440) 12590152 PUMP, OIL (INCLS 151, 154, 464-466, 468, 470-472, 474, 475) (INCLS GUIDE, БОЛТS) [МАСЛЕННЫЙ НАСОС] teamcadillac.ru not found COVER, O/PMP (ЧАСТЬ OF 463) not found GEAR, O/PMP (ЧАСТЬ OF 463) not found GEAR, O/PMP IDLER (ЧАСТЬ OF 463) not found БОЛТ, O/PMP CVR (ЧАСТЬ OF 463) not found PLUG, OIL PRESS RLF VLV BORE (ЧАСТЬ OF 463) not found ПРУЖИНА, OIL PRESS RLF VLV (ЧАСТЬ OF 463) not found VALVE, OIL PRESS RLF (ЧАСТЬ OF 463) not found RETAINER, OIL PRESS RLF VLV SPR (ЧАСТЬ OF 463) 11900371 БОЛТ, HEX HD, W/1.6 FLAT WA, M8X1.25X54.3, 43 THD, 16O.D., 8.8, GMW3359 (ЧАСТЬ OF 463) 12610143 NOZZLE, PSTN OIL (INCLS 491) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 490) 12621659 SENSOR, ENG OIL PRESS (INCLS 729) (ЧАСТЬ OF 440) (ACDelco #12621659) not found SEAL, ENG OIL PRESS SEN (O RING) (ЧАСТЬ OF 440, 728) 11588734 БОЛТ, HFH, M8X1.25X90, 21.6 THD, 18 O.D., 8.8, GMW3359 (ЧАСТЬ OF 400) [ВИНТ] (6M00-073) - 2008-2009 DM69 ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 4 МАСЛЯНЫЙ НАСОС,МАСЛЯНЫЙ ПОДДОН & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7, ПОЛНОПРИВОДНЫЙ MX7) ↓ 22531637 PIN, МАСЛЯНЫЙ ПОДДОН LOC (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 12586959 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (LOWER PRIMARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ГРМ] 12586960 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАТЯЖИТЕЛЬ ЦЕПИ] 12586961 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАПРАВЛЯЮЩАЯ ПРИВОДНОЙ ЦЕПИ] 12597417 GUIDE, TMG CHAIN (UPPER PRIMARY) 12600461 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ПРИВОДА ГРМ] 12600462 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ПРИВОДА ГРМ] 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (ЧАСТЬ OF 463) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12596502 PAN, OIL (INCLS 404-407, 410, 412, 413, 420, 422, 900) not found PLATE, МАСЛЯНЫЙ ПОДДОН SKID (ЧАСТЬ OF 400) 12575373 PIPE, O/PMP SUC (ЧАСТЬ OF 400) 12590407 PIPE, O/PMP SUC (ЧАСТЬ OF 400) 12566837 SEAL, O/PMP SUC PIPE (ЧАСТЬ OF 400) [УПЛОТНЕНИЕ] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 400) 12566872 DEFLECTOR, CR/SHF OIL (ЧАСТЬ OF 400) 11562588 PLUG, МАСЛЯНЫЙ ПОДДОН DRN (ЧАСТЬ OF 400) (INCLS 413) (W/ SEAL) (EXC MAGNET) [ЗАГЛУШКА МАСЛЯНОГО ПОДДОНА] 12616850 SEAL, МАСЛЯНЫЙ ПОДДОН DRN PLUG (O RING) (ЧАСТЬ OF 400, 412) 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (ЧАСТЬ OF 400) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11588424 БОЛТ, HFH, M6X1X145, 18 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 400) [ШЕСТИГРАННЫЙ ВИНТ] 12611594 INDICATOR, OIL LVL (INCLS 434) 12612349 TUBE, OIL LVL IND (INCLS 432) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 431) (BLACK) (6.07MM ID, 1.78MM DIA) (INDICATOR) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 431) (BLACK) (6.07MM ID, 1.78MM DIA) (TUBE) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (OIL LVL IND TUBE) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) (INDICATOR) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) (TUBE) 12591607 ADAPTER, OIL FLTR (INCLS 441-443, 446-450, 456, 458, 459, 728, 729) [АДАПТЕР МАСЛЯНОГО ФИЛЬТРА] 12591604 GASKET, OIL FLTR (ЧАСТЬ OF 440) (BETWEEN OIL FILTER ADAPTER AND BLOCK) [ПРОКЛАДКА МАСЛЯНОГО ФИЛЬТРА] 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 440) 11519174 БОЛТ, HFH, W/REDUCED BODY, M8X1.25X65, THD 22, O.D. 18, 8.8, GMW3359 (ЧАСТЬ OF 440) 25014612 VALVE, OIL FLTR BYPASS (ЧАСТЬ OF 440, 450) (W/O VAPOR SEPARATOR) (OPENING PRESSURE 21 PSI NOMINAL) (ЧАСТЬ HAS A 16.10MM MAX OD & FITS A 15.84 HOLE IN BLOCK) 11519174 БОЛТ, OIL FLTR ADAP (БОЛТ, HFH, W/REDUCED BODY, M8X1.25X65, THD 22, O.D. 18, 8.8, GMW3359) (ЧАСТЬ OF 440) (M8X1.25X65) (8.900) 11519184 БОЛТ, OIL FLTR ADAP (ЧАСТЬ OF 440) (M10X1.5X45) (0.029) 11519980 БОЛТ, OIL FLTR ADAP (БОЛТ, HFH, W/REDUCED BODY, M8X1.25X65, THD 22, O.D. 18, 8.8, GMW3359) (ЧАСТЬ OF 440) (M8X1.25X40) (8.900) not found SPACER, OIL FLTR (ЧАСТЬ OF 440) 25177917 ФИЛЬТР, МАСЛЯНЫЙ (ЧАСТЬ OF 440) (ACDelco #PF2129) [МАСЛЯНЫЙ ФИЛЬТР ДВИГАТЕЛЯ] 12583470 CAP, OIL FLTR (ЧАСТЬ OF 440) (INCLS 446, 456) [КРЫШКА] teamcadillac.ru 12577653 SEAL, OIL FLTR CAP (O RING) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КРЫШКИ МАСЛЯНОГО ФИЛЬТРА] not found RETAINER, OIL FLTR BYPASS VLV SPR (ЧАСТЬ OF 440, 450) not found CAGE, OIL FLTR BYPASS VLV (ЧАСТЬ OF 440) not found SEAL, OIL FLTR DRN PLUG (O RING) (ЧАСТЬ OF 440) 12590152 PUMP, OIL (INCLS 151, 154, 464-466, 468, 470-472, 474, 475) (INCLS GUIDE, БОЛТS) [МАСЛЕННЫЙ НАСОС] not found COVER, O/PMP (ЧАСТЬ OF 463) not found GEAR, O/PMP (ЧАСТЬ OF 463) not found GEAR, O/PMP IDLER (ЧАСТЬ OF 463) not found БОЛТ, O/PMP CVR (ЧАСТЬ OF 463) not found PLUG, OIL PRESS RLF VLV BORE (ЧАСТЬ OF 463) not found ПРУЖИНА, OIL PRESS RLF VLV (ЧАСТЬ OF 463) not found VALVE, OIL PRESS RLF (ЧАСТЬ OF 463) not found RETAINER, OIL PRESS RLF VLV SPR (ЧАСТЬ OF 463) 11900371 БОЛТ, HEX HD, W/1.6 FLAT WA, M8X1.25X54.3, 43 THD, 16O.D., 8.8, GMW3359 (ЧАСТЬ OF 463) 12610143 NOZZLE, PSTN OIL (INCLS 491) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 490) 12621659 SENSOR, ENG OIL PRESS (INCLS 729) (ЧАСТЬ OF 440) (ACDelco #12621659) not found SEAL, ENG OIL PRESS SEN (O RING) (ЧАСТЬ OF 440, 728) 11588734 БОЛТ, HFH, M8X1.25X90, 21.6 THD, 18 O.D., 8.8, GMW3359 (ЧАСТЬ OF 400) [ВИНТ] (GM00-395) - 2008 DM69 ДВИГАТЕЛЬ В СБОРЕ-2.8L V6 ЧАСТЬ 3 ПЕРЕДНЯЯ КРЫШКА И ОХЛАЖДЕНИЕ (LP1/2.8T) ↓ 22531637 PIN, ENG FRT CVR LOC (ЧАСТЬ OF 350) (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 11519176 БОЛТ, ENG FRT CVR (ЧАСТЬ OF 350) (M8X1.25X80) (4.081) [БОЛТ] 12611883 COVER, ENG FRT (W/ W/PMP) (INCLS 132, 348, 351-354, 360-362, 725-727, 734, 900-903) [БОКОВАЯ КРЫШКА ДВИГАТЕЛЯ] 12593045 SEAL, W/PMP (ЧАСТЬ OF 350) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519171 БОЛТ, ENG FRT CVR (ЧАСТЬ OF 350) (M8X1.25X50) (3.275) [БОЛТ ВЫПУСКНОГО КОЛЛЕКТОРА] 12608750 SEAL, CR/SHF FRT OIL (ЧАСТЬ OF 350) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КОЛЕНВАЛА] 12594060 DEADENER, ENG FRT CVR (ЧАСТЬ OF 350) (BOTTOM) [ПРОКЛАДКА КРЫШКИ ДВИГАТЕЛЯ] 12618472 PUMP, WAT (W/GSKT) (ЧАСТЬ OF 350) (INCLS 900) (ACDelco #251-724) [НАСОС] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 350) 12576326 GASKET, W/PMP (ЧАСТЬ OF 350) (ACDelco #251-2048) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12574518 PULLEY, W/PMP (ADX) 11588940 БОЛТ, HEX HD, W/CON SPR WA, M6X1X14.55, 8.45 THD, 13.3O.D., 8.8.GMW3359 (W/PMP PUL) not found THERMOSTAT, ENG COOL (*KIT1) 12592527 GASKET, ENG COOL THERM HSG (*KIT1) (ACDelco #12592527) [ПРОКЛАДКА ТЕРМОСТАТА] not found ШЛАНГИ, ENG COOL THERM UPR (*KIT1) 11588719 БОЛТ, HFH, M6X1X60, 18MM THD, 14.2 O.D., 8.8, 3359GMW (ENG COOL THERM HSG) (*KIT1) 11588720 БОЛТ, HFH, M6X1X70, 18 THD, 14.2 OD, 8.8, GMW3359, MAT POINT. (ENG COOL THERM HSG) (*KIT1) 12584325 SEAL, ENG COOL THERM HSG (O RING) (*KIT1) [КОЛЬЦЕ-ОБРАЗНОЕ УПЛОТНЕНИЕ] 12582472 SEAL, ENG COOL THERM (*KIT1) (ACDelco #12582472) [УПЛОТНИТЕЛЬ] not found ШЛАНГИ, ENG COOL THERM LWR (*KIT1) 12566429 SEAL, WAT OTLT (ЧАСТЬ OF 380) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12584040 SEAL, CLNT OTLT (O RING) (ЧАСТЬ OF 380) (ACDelco #15-32584) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519974 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 380) [БОЛТ] 12573984 OUTLET, WAT (INCLS 377-379, 905) (INCLS БОЛТS, RETAINERS, SEALS & PIPE) (ACDelco #15-10429) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 12608424 SENSOR, CM/SHF POSN (ЧАСТЬ OF 350) (INCLS 726, 727) (ACDelco #12608424) [ДАТЧИК ПОЛОЖЕНИЯ РАСПРЕДВАЛА] 12593717 SEAL, CM/SHF POSN ACTR SOL VLV (O RING) (ЧАСТЬ OF 350, 725) teamcadillac.ru 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 350, 725) 12615613 VALVE, CM/SHF POSN ACTR SOL 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (CM/SHF POSN ACTR SOL VLV) 12593717 SEAL, CM/SHF POSN ACTR SOL VLV (O RING) (ЧАСТЬ OF 350) not found PLUG, W/PMP (ЧАСТЬ OF 350, 360) not found DEADENER, ENG FRT CVR (ЧАСТЬ OF 350) not found DEADENER, ENG FRT CVR (ЧАСТЬ OF 350) not found DEADENER, ENG FRT CVR (ЧАСТЬ OF 350) (FRONT) not found PIPE, ENG COOL AIR BL (ЧАСТЬ OF 380) 12620251 ШЛАНГИ, ENG COOL THERM (INCLS 365-368, 370-373) (INCLS THERMOSTAT) [ТЕРМОСТАТИЧЕСКИЙ РЕГУЛИРУЕМЫЙ КЛАПАН СИСТЕМЫ ОХЛАЖДЕНИЯ] (GM00-395) - 2008 DM69 ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 3 ПЕРЕДНЯЯ КРЫШКА И ОХЛАЖДЕНИЕ (LLT/3.6V) ↓ 22531637 PIN, ENG FRT CVR LOC (ЧАСТЬ OF 350) (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 11519176 БОЛТ, ENG FRT CVR (ЧАСТЬ OF 350) (M8X1.25X80) (4.081) [БОЛТ] 12611883 COVER, ENG FRT (W/ W/PMP) (INCLS 132, 348, 351-354, 360-362, 725-727, 734, 900-903) [БОКОВАЯ КРЫШКА ДВИГАТЕЛЯ] 12593045 SEAL, W/PMP (ЧАСТЬ OF 350) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519171 БОЛТ, ENG FRT CVR (ЧАСТЬ OF 350) (M8X1.25X50) (3.275) [БОЛТ ВЫПУСКНОГО КОЛЛЕКТОРА] 12608750 SEAL, CR/SHF FRT OIL (ЧАСТЬ OF 350) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КОЛЕНВАЛА] 12594060 DEADENER, ENG FRT CVR (ЧАСТЬ OF 350) (BOTTOM) [ПРОКЛАДКА КРЫШКИ ДВИГАТЕЛЯ] 12618472 PUMP, WAT (W/GSKT) (ЧАСТЬ OF 350) (INCLS 900) (ACDelco #251-724) [НАСОС] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 350) 12576326 GASKET, W/PMP (ЧАСТЬ OF 350) (ACDelco #251-2048) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12574518 PULLEY, W/PMP (ADX) 11519512 БОЛТ, HFH, W/CON SPR WA, M6X1X13.4, 8.77 THD, 12.3 O.D., 8.8, GMW3359 (W/PMP PUL) not found THERMOSTAT, ENG COOL (*KIT1) 12592527 GASKET, ENG COOL THERM HSG (*KIT1) (ACDelco #12592527) [ПРОКЛАДКА ТЕРМОСТАТА] not found THERMOSTAT, ENG COOL (W/WAT INL) (*KIT1) 11519973 БОЛТ-HFH, M6X1X60, 18MM THD, 14.2 OD, 8.8, 3359GMW, REDUCED BODY, MAT PT. (ENG COOL THERM HSG) (*KIT1) [БОЛТ 6Х1Х60] 11519974 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3359 (ENG COOL THERM HSG) (*KIT1) [БОЛТ] 12584325 SEAL, ENG COOL THERM HSG (O RING) (*KIT1) [КОЛЬЦЕ-ОБРАЗНОЕ УПЛОТНЕНИЕ] 12582472 SEAL, ENG COOL THERM (*KIT1) (ACDelco #12582472) [УПЛОТНИТЕЛЬ] not found ШЛАНГИ, ENG COOL THERM LWR (*KIT1) 12566429 SEAL, WAT OTLT (ЧАСТЬ OF 380) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12584040 SEAL, CLNT OTLT (O RING) (ЧАСТЬ OF 380) (ACDelco #15-32584) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519974 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 380) [БОЛТ] 12573984 OUTLET, WAT (INCLS 377-379, 905) (INCLS БОЛТS, RETAINERS, SEALS & PIPE) (ACDelco #15-10429) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 12608424 SENSOR, CM/SHF POSN (ЧАСТЬ OF 350) (INCLS 726, 727) (ACDelco #12608424) [ДАТЧИК ПОЛОЖЕНИЯ РАСПРЕДВАЛА] 12608424 SENSOR, CM/SHF POSN (ЧАСТЬ OF 350) (INCLS 726, 727) (ACDelco #12608424) [ДАТЧИК ПОЛОЖЕНИЯ РАСПРЕДВАЛА] 12608424 SENSOR, CM/SHF POSN (ЧАСТЬ OF 350) (INCLS 726, 727) (ACDelco #12608424) [ДАТЧИК ПОЛОЖЕНИЯ РАСПРЕДВАЛА] not found SEAL, CR/SHF POSN SEN (O RING) (ЧАСТЬ OF 350, 725) teamcadillac.ru 11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (ЧАСТЬ OF 350, 725) [БОЛТ] 12615613 VALVE, CM/SHF POSN ACTR SOL 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (CM/SHF POSN ACTR SOL VLV) 12593717 SEAL, CM/SHF POSN ACTR SOL VLV (O RING) (ЧАСТЬ OF 350) not found PLUG, W/PMP (ЧАСТЬ OF 350, 360) not found DEADENER, ENG FRT CVR (ЧАСТЬ OF 350) (LEFT SIDE) not found DEADENER, ENG FRT CVR (ЧАСТЬ OF 350) (RIGHT SIDE) not found DEADENER, ENG FRT CVR (ЧАСТЬ OF 350) (FRONT) not found PIPE, ENG COOL AIR BL (ЧАСТЬ OF 380) 12620251 ШЛАНГИ, ENG COOL THERM (INCLS 365-368, 370-373) (INCLS THERMOSTAT) [ТЕРМОСТАТИЧЕСКИЙ РЕГУЛИРУЕМЫЙ КЛАПАН СИСТЕМЫ ОХЛАЖДЕНИЯ] (GM00-395) - 2008-2009 DM69 ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 3 ПЕРЕДНЯЯ КРЫШКА И ОХЛАЖДЕНИЕ (LY7/3.6-7) ↓ 22531637 PIN, ENG FRT CVR LOC (ЧАСТЬ OF 350) (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 11519171 БОЛТ, ENG FRT CVR (ЧАСТЬ OF 350) (M8X1.25X50) (3.275) [БОЛТ ВЫПУСКНОГО КОЛЛЕКТОРА] teamcadillac.ru 11519176 БОЛТ, ENG FRT CVR (ЧАСТЬ OF 350) (M8X1.25X80) (4.081) [БОЛТ] 12611883 COVER, ENG FRT (W/ W/PMP) (INCLS 132, 348, 351-354, 360-362, 725-727, 734, 900-903) [БОКОВАЯ КРЫШКА ДВИГАТЕЛЯ] 12593045 SEAL, W/PMP (ЧАСТЬ OF 350) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519171 БОЛТ, ENG FRT CVR (ЧАСТЬ OF 350) (M8X1.25X50) (3.275) [БОЛТ ВЫПУСКНОГО КОЛЛЕКТОРА] 12608750 SEAL, CR/SHF FRT OIL (ЧАСТЬ OF 350) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КОЛЕНВАЛА] 12594060 DEADENER, ENG FRT CVR (ЧАСТЬ OF 350) (BOTTOM) [ПРОКЛАДКА КРЫШКИ ДВИГАТЕЛЯ] 12618472 PUMP, WAT (W/GSKT) (ЧАСТЬ OF 350) (INCLS 900) (ACDelco #251-724) [НАСОС] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 350) 12576326 GASKET, W/PMP (ЧАСТЬ OF 350) (ACDelco #251-2048) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12574518 PULLEY, W/PMP (ADX) 11588940 БОЛТ, HEX HD, W/CON SPR WA, M6X1X14.55, 8.45 THD, 13.3O.D., 8.8.GMW3359 (W/PMP PUL) not found THERMOSTAT, ENG COOL (W/WAT INL) (*KIT1) 12592527 GASKET, ENG COOL THERM HSG (*KIT1) (ACDelco #12592527) [ПРОКЛАДКА ТЕРМОСТАТА] not found ШЛАНГИ, ENG COOL THERM UPR (*KIT1) 11588719 БОЛТ, HFH, M6X1X60, 18MM THD, 14.2 O.D., 8.8, 3359GMW (ENG COOL THERM HSG) (*KIT1) 11588720 БОЛТ, HFH, M6X1X70, 18 THD, 14.2 OD, 8.8, GMW3359, MAT POINT. (ENG COOL THERM HSG) (*KIT1) 12584325 SEAL, ENG COOL THERM HSG (O RING) (*KIT1) [КОЛЬЦЕ-ОБРАЗНОЕ УПЛОТНЕНИЕ] 12582472 SEAL, ENG COOL THERM (*KIT1) (ACDelco #12582472) [УПЛОТНИТЕЛЬ] not found ШЛАНГИ, ENG COOL THERM LWR (*KIT1) 12566429 SEAL, WAT OTLT (ЧАСТЬ OF 380) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12584040 SEAL, CLNT OTLT (O RING) (ЧАСТЬ OF 380) (ACDelco #15-32584) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519974 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 380) [БОЛТ] 12573984 OUTLET, WAT (INCLS 377-379, 905) (INCLS БОЛТS, RETAINERS, SEALS & PIPE) (ACDelco #15-10429) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 12608424 SENSOR, CM/SHF POSN (ЧАСТЬ OF 350) (INCLS 726, 727) (ACDelco #12608424) [ДАТЧИК ПОЛОЖЕНИЯ РАСПРЕДВАЛА] 12593717 SEAL, CM/SHF POSN ACTR SOL VLV (O RING) (ЧАСТЬ OF 350, 725) 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 350, 725) 12615613 VALVE, CM/SHF POSN ACTR SOL 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (CM/SHF POSN ACTR SOL VLV) 12593717 SEAL, CM/SHF POSN ACTR SOL VLV (O RING) (ЧАСТЬ OF 350) not found PLUG, W/PMP (ЧАСТЬ OF 350, 360) not found DEADENER, ENG FRT CVR (ЧАСТЬ OF 350) (LEFT SIDE) not found DEADENER, ENG FRT CVR (ЧАСТЬ OF 350) (RIGHT SIDE) not found DEADENER, ENG FRT CVR (ЧАСТЬ OF 350) (FRONT) not found PIPE, ENG COOL AIR BL (ЧАСТЬ OF 380) 12620251 ШЛАНГИ, ENG COOL THERM (INCLS 365-368, 370-373) (INCLS THERMOSTAT) [ТЕРМОСТАТИЧЕСКИЙ РЕГУЛИРУЕМЫЙ КЛАПАН СИСТЕМЫ ОХЛАЖДЕНИЯ] (GM00-396) - 2008 DM69 ДВИГАТЕЛЬ В СБОРЕ-2.8L V6 ЧАСТЬ 2 ГОЛОВКА ЦИЛИНДРОВ & ДЕТАЛИ КОМПЛЕКТА (LP1/2.8T) ↓ not found BLOCK, ENG 12570326 PIN, CYL HD LOC [ЗАГЛУШКА БЛОКА ЦИЛИНДРОВ] 12606653 ACTUATOR, CM/SHF POSN (USE WASHER 12630941) 12603744 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) 12603745 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) 11588279 БОЛТ, HFH, M10X1.5X80, 26 THD, 22.3 O.D., 10.9, GM4277M (CM/SHF POSN) 12626055 COVER, CM/SHF (INCLS 251, 254-257, 260, 263) [КЛАПАННАЯ КРЫШКА ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12595106 SEAL, CM/SHF CVR (ЧАСТЬ OF 250) (*KIT1) (ACDelco #12595106) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12626054 COVER, CM/SHF (INCLS 253-257, 261, 263) [КРЫШКА] 12595107 SEAL, CM/SHF CVR (ЧАСТЬ OF 252) (*KIT1) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] not found SEAL, SPLG SHLD (ЧАСТЬ OF 250, 252) (*KIT1) 11570020 БОЛТ, CM/SHF CVR (ЧАСТЬ OF 250, 252) 12595122 INSULATOR, CM/SHF CVR БОЛТ (ЧАСТЬ OF 250, 252) not found INSERT, IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ БОЛТ THD (ЧАСТЬ OF 250, 252) 12593356 CAP, OIL FIL (INCLS 904) (ACDelco #FC221) [КРЫШКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ] 12593348 SEAL, OIL FIL TUBE (O RING) (ЧАСТЬ OF 262) (27.94MM I.D.) (SIZE #320) (1.758) [ПРОКЛАДКА] 12578316 FITTING, PCV (ЧАСТЬ OF 250) (INCLS 263) 12583384 FITTING, PCV (ЧАСТЬ OF 250) (INCLS 263) 12615294 TUBE, OIL FIL (INCLS 259) [ТРУБКА МАСЛЯНОГО ФИЛЬТРА] not found SEAL, PCV HOSE FTG (O RING) (ЧАСТЬ OF 250, 252, 260, 261) teamcadillac.ru 12601744 INSULATOR, CM/SHF HSG CVR (0.413) 12601745 INSULATOR, CM/SHF HSG CVR [НАКЛАДКА КЛАПАННОЙ КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12603909 HEAD, CYL (MCHG) (INCLS 313, 318, 319, 328, 336, 337) (DOES NOT INCL ENG OIL MANIF CHECK VALVES. DLR MUST INSTL) [ГОЛОВКА БЛОКА ЦИЛИНДРОВ] 12603906 HEAD, CYL (MCHG) (INCLS 313, 318, 319, 328, 336, 337) (DOES NOT INCL ENG OIL MANIF CHECK VALVES. DLR MUST INSTL) [ГОЛОВКА БЛОКА ЦИЛИНДРОВ] not found GASKET, CYL HD (*KIT1) not found GASKET, CYL HD (*KIT1) 11518863 БОЛТ, CYL HD [БОЛТ] 11519177 БОЛТ-HEX FLANGE HD, REDUCED BODY, M8X1.25X90, 8.8, GMW3359 (CYL HD) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11561751 PLUG, CYL HD WAT JKT HOLE (ЧАСТЬ OF 300, 301) (M20X1.5X30.5) (1.531) not found SLEEVE, SPLG WIRE (ЧАСТЬ OF 300, 301) 11562127 PLUG, CYL HD OIL GAL (ЧАСТЬ OF 300, 301) (CUP-14.22 OD, 6.6 THK, 304SS) 12575354 VALVE, EXH (STD) [КЛАПАН ВЫПУСКНОЙ] 12584760 VALVE, EXH (0.075 O.S.) [КЛАПАН ВЫПУСКНОЙ] 12575352 VALVE, INT (STD) 12584761 VALVE, INT (0.075MM O.S.) (0.297) 24100294 ARM, VLV RKR [РЫЧАГ] 24100005 ADJUSTER, HYD VLV LASH (ACDelco #24100005) [ТОЛКАТЕЛЬ КЛАПАНА ДВИГАТЕЛЯ] 12565836 SEAL, VLV STEM OIL [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КЛАПАНА ДВИГАТЕЛЯ] 12575355 ПРУЖИНА, VLV [ПРУЖИНА КЛАПАНА] 12575196 RETAINER, VLV SPR [КОМПАКТ ДИСК] 12575197 KEY, VLV STEM [КЛАПАННЫЙ КЛЮЧ] not found CAP, CM/SHF BRG (ЧАСТЬ OF 300, 301) 12574477 RING, CM/SHF SPKT OIL SEAL (ЧАСТЬ OF 330-333) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО РАСПРЕДВАЛА ДВИГАТЕЛЯ (2 ШТ.)] 12609249 CAMSHAFT, EXH (INCLS 329) [РАСПРЕДВАЛ ДВИГАТЕЛЯ] 12609250 CAMSHAFT, INT (INCLS 329) [РАСПРЕДВАЛ ДВИГАТЕЛЯ] 12604375 CAMSHAFT, EXH (INCLS 329) [РАСПРЕДВАЛ] 12609252 CAMSHAFT, INT (INCLS 329) [РАСПРЕДВАЛ ДВИГАТЕЛЯ] not found CAP, CM/SHF BRG (ЧАСТЬ OF 300, 301) 11518856 HFH, M6X1X43.4, 14.8 THD, 11 O.D., 8.8, GMW3179 CODE G (ЧАСТЬ OF 300, 301) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12618542 РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ, IGN (INCLS 705) (ACDelco #D508C) not found БОЛТ, IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ HSG (ЧАСТЬ OF 704) 12566778 SENSOR, ENG COOL TEMP (3.682) (ACDelco #213-1581) [СЕНСОР ТЕМПЕРАТУРЫ] 12597464 СВЕЧИ, (DO NOT CHANGE СВЕЧИ GAP) (ACDelco #41-990) (PLATINUM PLUG) [СВЕЧА ЗАЖИГАНИЯ] 12580965 VALVE, ENG OIL MANIF CHK [КЛАПАН] 12593348 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 258) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА] 12617801 GASKET KIT, CYL HD (INCLS 251, 253, 254, 302, 303) (GM00-396) - 2008-2009 DM69 ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 2 ГОЛОВКА ЦИЛИНДРОВ & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7) ↓ not found BLOCK, ENG 12570326 PIN, CYL HD LOC [ЗАГЛУШКА БЛОКА ЦИЛИНДРОВ] 12606653 ACTUATOR, CM/SHF POSN (USE WASHER 12630941) 12603744 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) 12603745 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) 11588279 БОЛТ, HFH, M10X1.5X80, 26 THD, 22.3 O.D., 10.9, GM4277M (CM/SHF POSN) 12626055 COVER, CM/SHF (INCLS 251, 254-257, 260, 263) [КЛАПАННАЯ КРЫШКА ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12595106 SEAL, CM/SHF CVR (ЧАСТЬ OF 250) (*KIT1) (ACDelco #12595106) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12626054 COVER, CM/SHF (INCLS 253-257, 261, 263) [КРЫШКА] 12595107 SEAL, CM/SHF CVR (ЧАСТЬ OF 252) (*KIT1) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] not found SEAL, SPLG SHLD (ЧАСТЬ OF 250, 252) 11570020 БОЛТ, CM/SHF CVR (ЧАСТЬ OF 250, 252) 12595122 INSULATOR, CM/SHF CVR БОЛТ (ЧАСТЬ OF 250, 252) not found INSERT, IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ БОЛТ THD (ЧАСТЬ OF 250, 252) 12593356 CAP, OIL FIL (INCLS 904) (ACDelco #FC221) [КРЫШКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ] 12593348 SEAL, OIL FIL TUBE (O RING) (ЧАСТЬ OF 262) (27.94MM I.D.) (SIZE #320) (1.758) [ПРОКЛАДКА] 12578316 FITTING, PCV (ЧАСТЬ OF 250) (INCLS 263) 12583384 FITTING, PCV (ЧАСТЬ OF 252) (INCLS 263) 12615294 TUBE, OIL FIL (INCLS 259) [ТРУБКА МАСЛЯНОГО ФИЛЬТРА] not found SEAL, PCV HOSE FTG (O RING) (ЧАСТЬ OF 250, 252, 260, 261) 12601744 INSULATOR, CM/SHF HSG CVR (0.413) 12601745 INSULATOR, CM/SHF HSG CVR [НАКЛАДКА КЛАПАННОЙ КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12603904 HEAD, CYL (MCHG) (INCLS 313, 318, 319, 328, 336, 337) (DOES NOT INCL ENG OIL MANIF CHECK VALVES. DLR MUST INSTL) 12603901 HEAD, CYL (MCHG) (INCLS 313, 318, 319, 328, 336, 337) (DOES NOT INCL ENG OIL MANIF CHECK VALVES. DLR MUST INSTL) not found GASKET, CYL HD (*KIT1) not found GASKET, CYL HD (*KIT1) 11518863 БОЛТ, CYL HD [БОЛТ] 11519177 БОЛТ-HEX FLANGE HD, REDUCED BODY, M8X1.25X90, 8.8, GMW3359 (CYL HD) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11561751 PLUG, CYL HD WAT JKT HOLE (ЧАСТЬ OF 300, 301) (M20X1.5X30.5) (1.531) not found SLEEVE, SPLG WIRE (ЧАСТЬ OF 300, 301) 11562127 PLUG, CYL HD OIL GAL (ЧАСТЬ OF 300, 301) (CUP-14.22 OD, 6.6 THK, 304SS) 12575354 VALVE, EXH (STD) [КЛАПАН ВЫПУСКНОЙ] 12584760 VALVE, EXH (0.075 O.S.) [КЛАПАН ВЫПУСКНОЙ] 12575351 VALVE, INT (STD) [КЛАПАН ВПУСКНОЙ] 12584763 VALVE, INT (0.075MM O.S.) (0.297) [КЛАПАН ВПУСКНОЙ] 24100294 ARM, VLV RKR [РЫЧАГ] 24100005 ADJUSTER, HYD VLV LASH (ACDelco #24100005) [ТОЛКАТЕЛЬ КЛАПАНА ДВИГАТЕЛЯ] 12565836 SEAL, VLV STEM OIL [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КЛАПАНА ДВИГАТЕЛЯ] 12575355 ПРУЖИНА, VLV [ПРУЖИНА КЛАПАНА] 12575196 RETAINER, VLV SPR [КОМПАКТ ДИСК] 12575197 KEY, VLV STEM [КЛАПАННЫЙ КЛЮЧ] not found CAP, CM/SHF BRG (ЧАСТЬ OF 300, 301) 12574477 RING, CM/SHF SPKT OIL SEAL (ЧАСТЬ OF 330-333) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО РАСПРЕДВАЛА ДВИГАТЕЛЯ (2 ШТ.)] 12566670 CAMSHAFT, EXH (INCLS 329) 12625984 CAMSHAFT, EXH (INCLS 329) 12609250 CAMSHAFT, INT (INCLS 329) [РАСПРЕДВАЛ ДВИГАТЕЛЯ] 12604375 CAMSHAFT, EXH (INCLS 329) [РАСПРЕДВАЛ] 12620457 CAMSHAFT, EXH (INCLS 329) 12609252 CAMSHAFT, INT (INCLS 329) [РАСПРЕДВАЛ ДВИГАТЕЛЯ] 12625989 CAMSHAFT, INT (INCLS 329) not found CAP, CM/SHF BRG (ЧАСТЬ OF 300, 301) 11518856 HFH, M6X1X43.4, 14.8 THD, 11 O.D., 8.8, GMW3179 CODE G (ЧАСТЬ OF 300, 301) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12618542 РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ, IGN (INCLS 705) (ACDelco #D508C) 11588715 БОЛТ, HFH, M6X1X35, 18 THD, 14.2 OD, 8.8, GMW3359, 5MM M POINT (ЧАСТЬ OF 704) [БОЛТ] 12566778 SENSOR, ENG COOL TEMP (3.682) (ACDelco #213-1581) [СЕНСОР ТЕМПЕРАТУРЫ] 12566778 SENSOR, ENG COOL TEMP (3.682) (ACDelco #213-1581) [СЕНСОР ТЕМПЕРАТУРЫ] 12566778 SENSOR, ENG COOL TEMP (ACDelco #213-1581) [СЕНСОР ТЕМПЕРАТУРЫ] 12597464 СВЕЧИ, (DO NOT CHANGE СВЕЧИ GAP) (ACDelco #41-990) (PLATINUM PLUG) [СВЕЧА ЗАЖИГАНИЯ] 12580965 VALVE, ENG OIL MANIF CHK [КЛАПАН] 12593348 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 258) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА] 12625781 GASKET KIT, CYL HD (INCLS 251, 253, 302, 303) (INCLS UPR & LWR INT MANIF GASKETS) [КОМПЛЕКТ ПРОКЛАДОК ВПУСКНОГО КОЛЛЕКТОРА (2ШТ)] (GM00-550) - 2008 DM69 ДВИГАТЕЛЬ В СБОРЕ-2.8L V6 ЧАСТЬ 6 ЦЕПЬ И НАТЯЖИТЕЛЬ (LP1/2.8T) ↓ 12599721 SPROCKET, CR/SHF [ШЕСТЕРНЯ РАСПРЕДВАЛА] 12586959 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (LOWER PRIMARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ГРМ] 12609262 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (INCLS 153, 164) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 152) [БОЛТ М8] 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (TMG CHAIN GDE) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12616609 CHAIN, CM/SHF INTER DRV (PRIMARY) [ЦЕПЬ ПРИВОДА ГРМ] 12597417 GUIDE, TMG CHAIN (INCLS 157) (UPPER PRIMARY) 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 156) [БОЛТ М8] 11588252 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3179 CODE G (ЧАСТЬ OF 165, 166) 12589477 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 152) (PRIMARY) 12612839 SPROCKET, TMG CHAIN IDLER (INCLS 161) (0.736) [ЗВЕЗДОЧКА РАСПРЕДВАЛА] 12612838 SPROCKET, TMG CHAIN IDLER (INCLS 161) (0.736) [ШЕСТЕРНЯ РАСПРЕДВАЛА] 12616608 CHAIN, CM/SHF INTER DRV (SECONDARY) [ЦЕПЬ ПРИВОДА ГРМ] 12600461 GUIDE, TMG CHAIN (INCLS 172) (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ПРИВОДА ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 171) [БОЛТ М8] 12586960 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАТЯЖИТЕЛЬ ЦЕПИ] 11518858 БОЛТ, HFH, M8X1.25X43, 16 THD, 18 O.D., 8.8, GMW3179 (TMG CHAIN TENSR) [БОЛТ М8] 12609260 РОЛИК НАТЯЖИТЕЛЬ, TMG CHAIN (INCLS 176, 177) (SECONDARY) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 175) [БОЛТ М8] 12589478 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 175) 12600462 GUIDE, TMG CHAIN (INCLS 182) (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ПРИВОДА ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 181) [БОЛТ М8] 12586961 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАПРАВЛЯЮЩАЯ ПРИВОДНОЙ ЦЕПИ] 11518858 БОЛТ, HFH, M8X1.25X43, 16 THD, 18 O.D., 8.8, GMW3179 (TMG CHAIN TENSR) [БОЛТ М8] 12609258 РОЛИК НАТЯЖИТЕЛЬ, TMG CHAIN (INCLS 186, 187) (SECONDARY) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 185) [БОЛТ М8] 12589479 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 185) 12606653 ACTUATOR, CM/SHF POSN (EXH) (USE WASHER 12630941) 12603744 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) (5 SCREWS ON BACKPLATE) 12603745 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) (5 SCREWS ON BACKPLATE) 11588279 БОЛТ, HFH, M10X1.5X80, 26 THD, 22.3 O.D., 10.9, GM4277M (CM/SHF POSN ACTR) 12630941 WASHER, CM/SHF THR (USED ON ACTUATORS 12603744-745, 12606653 & 12630916-918) (**FIELD FIX ONLY, DO NOT CATALOG**) [УПОРНАЯ ШАЙБА РАСПРЕДЕЛИТЕЛЬНОГО ВАЛА ДВС] (GM00-550) - 2008 DM69 ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 6 ЦЕПЬ И НАТЯЖИТЕЛЬ (LLT/3.6V) ↓ 12599721 SPROCKET, CR/SHF [ШЕСТЕРНЯ РАСПРЕДВАЛА] 12586959 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (LOWER PRIMARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ГРМ] 12609262 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (INCLS 153, 164) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 152) [БОЛТ М8] 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (TMG CHAIN GDE) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12616609 CHAIN, CM/SHF INTER DRV (PRIMARY) [ЦЕПЬ ПРИВОДА ГРМ] 12597417 GUIDE, TMG CHAIN (INCLS 157) (UPPER PRIMARY) 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 156) [БОЛТ М8] 11588252 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3179 CODE G (ЧАСТЬ OF 165, 166) 12589477 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 152) (PRIMARY) 12612839 SPROCKET, TMG CHAIN IDLER (INCLS 161) (0.736) [ЗВЕЗДОЧКА РАСПРЕДВАЛА] 12612838 SPROCKET, TMG CHAIN IDLER (INCLS 161) (0.736) [ШЕСТЕРНЯ РАСПРЕДВАЛА] 12616608 CHAIN, CM/SHF INTER DRV (SECONDARY) [ЦЕПЬ ПРИВОДА ГРМ] 12600461 GUIDE, TMG CHAIN (INCLS 172) (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ПРИВОДА ГРМ] teamcadillac.ru 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 171) [БОЛТ М8] 12586960 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАТЯЖИТЕЛЬ ЦЕПИ] 11518858 БОЛТ, HFH, M8X1.25X43, 16 THD, 18 O.D., 8.8, GMW3179 (TMG CHAIN TENSR) [БОЛТ М8] 12609260 РОЛИК НАТЯЖИТЕЛЬ, TMG CHAIN (INCLS 176, 177) (SECONDARY) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 175) [БОЛТ М8] 12589478 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 175) 12600462 GUIDE, TMG CHAIN (INCLS 182) (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ПРИВОДА ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 181) [БОЛТ М8] 12586961 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАПРАВЛЯЮЩАЯ ПРИВОДНОЙ ЦЕПИ] 11518858 БОЛТ, HFH, M8X1.25X43, 16 THD, 18 O.D., 8.8, GMW3179 (TMG CHAIN TENSR) [БОЛТ М8] 12609258 РОЛИК НАТЯЖИТЕЛЬ, TMG CHAIN (INCLS 186, 187) (SECONDARY) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 185) [БОЛТ М8] 12589479 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 185) 12606653 ACTUATOR, CM/SHF POSN (EXH) (USE WASHER 12630941) 12603744 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) (5 SCREWS ON BACKPLATE) 12603745 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) (5 SCREWS ON BACKPLATE) 11588279 БОЛТ, HFH, M10X1.5X80, 26 THD, 22.3 O.D., 10.9, GM4277M (CM/SHF POSN ACTR) 12630941 WASHER, CM/SHF THR (USED ON ACTUATORS 12603744-745, 12606653 & 12630916-918) [УПОРНАЯ ШАЙБА РАСПРЕДЕЛИТЕЛЬНОГО ВАЛА ДВС] (GM00-550) - 2008-2009 DM69 ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 6 ЦЕПЬ И НАТЯЖИТЕЛЬ (LY7/3.6-7) ↓ 12599721 SPROCKET, CR/SHF [ШЕСТЕРНЯ РАСПРЕДВАЛА] 12586959 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (LOWER PRIMARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ГРМ] 12609262 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (INCLS 153, 164) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 152) [БОЛТ М8] 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (TMG CHAIN GDE) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12616609 CHAIN, CM/SHF INTER DRV (PRIMARY) [ЦЕПЬ ПРИВОДА ГРМ] 12597417 GUIDE, TMG CHAIN (INCLS 157) (UPPER PRIMARY) 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 156) [БОЛТ М8] 11588252 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3179 CODE G (ЧАСТЬ OF 165, 166) 12589477 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 152) (PRIMARY) teamcadillac.ru 12612839 SPROCKET, TMG CHAIN IDLER (INCLS 161) (0.736) [ЗВЕЗДОЧКА РАСПРЕДВАЛА] 12612838 SPROCKET, TMG CHAIN IDLER (INCLS 161) (0.736) [ШЕСТЕРНЯ РАСПРЕДВАЛА] 12616608 CHAIN, CM/SHF INTER DRV (SECONDARY) [ЦЕПЬ ПРИВОДА ГРМ] 12600461 GUIDE, TMG CHAIN (INCLS 172) (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ПРИВОДА ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 171) [БОЛТ М8] 12586960 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАТЯЖИТЕЛЬ ЦЕПИ] 11518858 БОЛТ, HFH, M8X1.25X43, 16 THD, 18 O.D., 8.8, GMW3179 (TMG CHAIN TENSR) [БОЛТ М8] 12609260 РОЛИК НАТЯЖИТЕЛЬ, TMG CHAIN (INCLS 176, 177) (SECONDARY) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 175) [БОЛТ М8] 12589478 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 175) 12600462 GUIDE, TMG CHAIN (INCLS 182) (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ПРИВОДА ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 181) [БОЛТ М8] 12586961 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАПРАВЛЯЮЩАЯ ПРИВОДНОЙ ЦЕПИ] 11518858 БОЛТ, HFH, M8X1.25X43, 16 THD, 18 O.D., 8.8, GMW3179 (TMG CHAIN TENSR) [БОЛТ М8] 12609258 РОЛИК НАТЯЖИТЕЛЬ, TMG CHAIN (INCLS 186, 187) (SECONDARY) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 185) [БОЛТ М8] 12589479 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 185) 12606653 ACTUATOR, CM/SHF POSN (EXH) (USE WASHER 12630941) 12603744 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) (5 SCREWS ON BACKPLATE) 12603745 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) (5 SCREWS ON BACKPLATE) 11588279 БОЛТ, HFH, M10X1.5X80, 26 THD, 22.3 O.D., 10.9, GM4277M (CM/SHF POSN ACTR) 12630941 WASHER, CM/SHF THR (USED ON ACTUATORS 12603744-745, 12606653 & 12630916-918) (**FIELD FIX ONLY, DO NOT CATALOG**) [УПОРНАЯ ШАЙБА РАСПРЕДЕЛИТЕЛЬНОГО ВАЛА ДВС] 01 - СИСТЕМА ОХЛАЖДЕНИЯ - РЕШЕТКА РАДИАТОРА-МАСЛОСИСТЕМА (6D01-029) - 2008 DM69 НАТЯЖИТЕЛЬ РЕМНЯ/ACCESSORY DRIVE (LP1/2.8T,LY7/3.6-7,LLT/3.6V) ↓ not found РОЛИК НАТЯЖИТЕЛЬ, КОНДИЦИОНЕР CMPR & P/S PMP BELT 12577655 РОЛИК НАТЯЖИТЕЛЬ, КОНДИЦИОНЕР CMPR & P/S PMP BELT (9.180) [НАТЯЖИТЕЛЬ РЕМНЯ] 12577655 РОЛИК НАТЯЖИТЕЛЬ, КОНДИЦИОНЕР CMPR & P/S PMP BELT [НАТЯЖИТЕЛЬ РЕМНЯ] 11518633 БОЛТ, HFH, M10X1.5X75, 26 THD, 22.3 OD, 10.9, GMW3359, MAT- POINT. (DRV BELT TENSR) [БОЛТ М10] 12606116 BELT, КОНДИЦИОНЕР CMPR & P/S PUMP [ПРИВОДНОЙ РЕМЕНЬ ГРМ] 12621991 BELT, W/PMP & GEN [РЕМЕНЬ ГЕНЕРАТОРА L=120 СМ] 12621991 BELT, W/PMP & GEN [РЕМЕНЬ ГЕНЕРАТОРА L=120 СМ] 12621991 BELT, W/PMP & GEN [РЕМЕНЬ ГЕНЕРАТОРА L=120 СМ] 12577652 РОЛИК НАТЯЖИТЕЛЬ, W/PMP & GEN BELT [НАТЯЖИТЕЛЬ РЕМНЯ] 12577652 РОЛИК НАТЯЖИТЕЛЬ, W/PMP & GEN BELT [НАТЯЖИТЕЛЬ РЕМНЯ] 12577652 РОЛИК НАТЯЖИТЕЛЬ, W/PMP & GEN BELT [НАТЯЖИТЕЛЬ РЕМНЯ] 12566893 PULLEY, BELT IDLER [ШКИВ] 12566893 PULLEY, BELT IDLER [ШКИВ] 12566893 PULLEY, BELT IDLER [ШКИВ] (6D01-034) - 2008-2009 DM69 ПОДОГРЕВАТЕЛЬ БЛОКА ДВИГАТЕЛЯ (LLT/3.6V,LY7/3.6-7, 110V ПОДОГРЕВАТЕЛЬ K05) ↓ 15257983 CORD, ENG COOL HTR (NOT LABELED 25772573) (INCLS 2) 15257983 CORD, ENG COOL HTR (NOT LABELED 25772573) (INCLS 2) 12337820 STRAP, 15" TIE STRAP (ЧАСТЬ OF 1) (ACDelco #12337820) 12587380 ПОДОГРЕВАТЕЛЬ, ENG COOL (USE W/2 PIN ПОДОГРЕВАТЕЛЬ) [НАГРЕВАТЕЛЬ] teamcadillac.ru 12587380 ПОДОГРЕВАТЕЛЬ, ENG COOL (USE W/2 PIN ПОДОГРЕВАТЕЛЬ) [НАГРЕВАТЕЛЬ] (6D01-051) - 2008 DM69 ВЕНТИЛЯТОР ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ ↓ 25708390 BLADE, FAN (1.055) (ACDelco #15-80190) [ВЕНТИЛЯТОР РАДИАТОРА 90 ВТ] 15932856 SHROUD, ENG COOL FAN [ОБТЕКАТЕЛЬ РАДИАТОРА] 11570323 БОЛТ, ENG COOL FAN SHRD (M6X1X18, 13 THD) 15932853 MOTOR, ENG COOL FAN (ACDelco #15-81107) [МОТОР В СБОРЕ] 19129896 MOTOR, ENG COOL FAN (120W) (ACDelco #15-80873) (120W DES - USE ON CARS WITH "S" STAMPED ON FAN MOT HUB) [МОТОРЧИК] 11570325 БОЛТ, ENG COOL FAN MOT 25720201 BLADE, FAN (1.055) (ACDelco #15-80191) [ВЕНТИЛЯТОР РАДИАТОРА 90 ВТ] teamcadillac.ru 11570326 ГАЙКА, FAN BLADE (6D01-056) - 2008 DM69 РЕШЕТКА РАДИАТОРА ↓ 25885609 КАПОТ, (СМ. ГРУППУ 08.000 "КАПОТ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25887545 MOLDING, КАПОТ FRT (INCLS 3) [МОЛДИНГ КАПОТА] 11570524 RETAINER, КАПОТ CTR MLDG (ЧАСТЬ OF 2) (10.5 X 11.8 X 8.73) [КРОНШТЕЙН] 10125439 RIVET, FLAT HD, 3 LEG EXPANSION, M4.8 SHAFT, 23.5 LG, 9.8 O.D., AL (FRT BPR FASCIA SUPT) [ЗАКЛЕПКА D=4.8 ММ] 15263150 EMBLEM, RAD GRL (ЧАСТЬ OF 8) (CREST) [ЭМБЛЕМА РЕШЕТКИ РАДИАТОРА] 15263149 EMBLEM, RAD GRL (ЧАСТЬ OF 8) (WREATH) [ЭМБЛЕМА] teamcadillac.ru 11562364 CLIP, RAD GRL (18X10X11.6) [ЗАЖИМ ПАНЕЛИ БАМПЕРА] 25896043 GRILLE, RAD (UPPER) (INCLS 5, 6) [РЕШЕТКА РАДИАТОРА] not found FASCIA, FRT BPR (СМ. ГРУППУ 07.000 "БАМПЕР ПЕРЕДНИЙ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (КРАСКА TO MATCH) (MUST ALSO ORDER DUCTS 20772527 & 20772528) 25896041 GRILLE, RAD LWR [РЕШЕТКА РАДИАТОРА] 25768800 BUMPER, FRT BPR FASCIA [ЭЛЕМЕНТ НАКЛАДКИ БАМПЕРА] 21030249 RETAINER, EXPAN, 21 LG, 20. OD, 8.0 HOLE, 3.0-5.0 PNL, NYLON 6/6, BLK (FRT BPR UPR FASCIA) (8.950) (PUSH IN) [ПИСТОН КРЕПЛЕНИЯ КОЖУХА РАДИАТОРА(ПЛАСТИК)] 11589293 RETAINER, PUSH-IN, FITS 8.5 DIA HOLE, 4.5-7 THK PNL, NYLON 6/6 GMP.PA66.0 (FRT BPR FASCIA (PUSH IN)) [ФИКСАТОР ВОДОСТОЧНОЙ ПАНЕЛИ ВЕТРОВОГО СТЕКЛА] (6D01-057) - 2008 DM69 ШЛАНГИ И ТРУБКИ/РАДИАТОР (LLT/3.6V) ↓ 25800336 HOSE, RAD SURGE TK INL (INCLS 2) 11570614 CЛАМПА-ПРУЖИНАBAND, 15 NOMINAL DIA, 15 THK, STL, ROBO (ЧАСТЬ OF 1) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (RAD SURGE TK) [ГАЙКА М6] 15066786 CAP, RAD SURGE TK (15 PSI, DUAL O-RING) (ENGLISH LABEL) (ACDelco #RC99) 11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (FRT BPR FASCIA CTR SUPT) [БОЛТ М6] 15267707 TANK, RAD SURGE (INCLS 20) (ACDelco #15267707) [БАЧОК] 11518516 CЛАМПА, RAD SURGE TK ENG HOSE (ЧАСТЬ OF 8) (27MM) (BLACK & YELLOW T-CLIP) [ЗАЖИМ] 25800335 HOSE, RAD SURGE TK ENG (INCLS 7) 12608674 PIPE, RAD SURGE TK OTLT (INCLS 10) 12588318 SEAL, RAD SURGE TK OTLT PIPE (O RING) (ЧАСТЬ OF 9) (8.846) [УПЛОТНЕНИЕ ТРУБКИ ОТОПИТЕЛЯ САЛОНА] 12623519 SEAL, RAD OTLT PIPE (O RING) (ЧАСТЬ OF 17) teamcadillac.ru 11516233 CЛАМПА-ПРУЖИНАBAND, TYPE A, 15 WID, 40 HOSE OD, 6150M, 7111M, MM (ЧАСТЬ OF 13) [ХОМУТ ШЛАНГА РАДИАТОРА] 25800334 HOSE, RAD OTLT (INCLS 12) [ШЛАНГ СИСТЕМЫ ОХЛАЖДЕНИЯ] 25789911 РАДИАТОР, (ACDelco #21705) [РАДИАТОР] 25957496 РАДИАТОР, (ACDelco #21752) 11516233 CЛАМПА-ПРУЖИНАBAND, TYPE A, 15 WID, 40 HOSE OD, 6150M, 7111M, MM (RAD INL HOSE) [ХОМУТ ШЛАНГА РАДИАТОРА] 25800333 HOSE, RAD INL [ШЛАНГ РАДИАТОРА] 12612858 PIPE, RAD OTLT (INCLS 11) 11519977 БОЛТ- HFH, M8X1.25X25, 16 THD, 18 OD, 8.8, GMW3359, MAT-PT. (RAD OTLT PIPE) 11518624 БОЛТ, HFH, M10X1.5X30.4, 22.5 THD, 22.3 O.D., 10.9, GMW3359 (RAD OTLT PIPE) not found HOSE, SURGE TK OVFL (ЧАСТЬ OF 6) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (RAD SURGE TK OTLT PIPE) 11570616 CЛАМПА, ПРУЖИНАBAND, 27 NOMINAL DIA, 15 THK, STL, ROBO (AUX W/PMP HOSE) 25808863 HOSE, AUX W/PMP OTLT [ТРУБКА] 11570615 CЛАМПА, HOSE ПРУЖИНАBAND, 26 NOMINAL DIA, 15 THK, STL, ROBO (AUX W/PMP HOSE) 25808860 PUMP, AUX WAT (W/O HOSE) (ACDelco #251-721) [НАСОС ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 25808862 HOSE, AUX W/PMP INL [ТРУБКА] (6D01-058) - 2008 DM69 РАДИАТОР КРЕПЛЕНИЕ & ДЕТАЛИ КОМПЛЕКТА ↓ 15932854 РАДИАТОР, (INCLS 4, 11) (ACDelco #21706) [РАДИАТОР] 15932855 РАДИАТОР, (INCLS 4, 11) (ACDelco #21751) [РАДИАТОР] 25789911 РАДИАТОР, (INCLS 4, 11) (ACDelco #21705) [РАДИАТОР] 25957496 РАДИАТОР, (INCLS 4, 11) (ACDelco #21752) 25895886 BAFFLE, RAD AIR SI (INCLS 3) [ОБТЕКАТЕЛЬ РАДИАТОРА] not found RETAINER, RAD AIR BFL (ЧАСТЬ OF 2, 7) 15932850 INSULATOR, RAD LWR (ЧАСТЬ OF 1) [ДЕМПФЕР РАДИАТОРА] teamcadillac.ru 11570324 БОЛТ, КОНДИЦИОНЕР CNDSR (M6X1X14, 9 THD) 15932849 CONDENSER, КОНДИЦИОНЕР (СМ. ГРУППУ 09.000 "КОНДИЦИОНЕР REFIGERATION SYSTEM" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #15-63543) [КОНДЕНСОР] 25895887 BAFFLE, RAD AIR SI (INCLS 3) [КОЖУХ РАДИАТОРА] 11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (RAD UPR MT BRKT) [БОЛТ М6] 15267706 BRACKET, RAD UPR (INCLS 10) not found INSULATOR, RAD UPR (ЧАСТЬ OF 9) not found PLUG, RAD DRN (ЧАСТЬ OF 1) (6D01-061) - 2008 DM69 ШЛАНГИ И ТРУБКИ/РАДИАТОР (LP1/2.8T,LY7/3.6-7) ↓ 25800336 HOSE, RAD SURGE TK INL (INCLS 2) 11571098 CЛАМПА-ПРУЖИНАBAND, 14MM NOMINAL DIA, 15MM WIDTH, STL PER GM6298M, GMW140 (ЧАСТЬ OF 1) 11514517 ГАЙКА, HEX, W/CON SPR WA, M6X1, 5.7THK, 18 O.D., 9, 7111M (RAD SURGE TK) [ГАЙКА М6] 15066786 CAP, RAD SURGE TK (15 PSI, DUAL O-RING) (ENGLISH LABEL) (ACDelco #RC99) 11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (FRT BPR FASCIA CTR SUPT) [БОЛТ М6] 15267707 TANK, RAD SURGE (INCLS 20) (ACDelco #15267707) [БАЧОК] 11570615 CЛАМПА, HOSE ПРУЖИНАBAND, 26 NOMINAL DIA, 15 THK, STL, ROBO (ЧАСТЬ OF 8) 25800335 HOSE, RAD SURGE TK ENG (INCLS 7) 12608674 PIPE, RAD SURGE TK OTLT (INCLS 10) 12588318 SEAL, RAD SURGE TK OTLT PIPE (O RING) (ЧАСТЬ OF 9) (8.846) [УПЛОТНЕНИЕ ТРУБКИ ОТОПИТЕЛЯ САЛОНА] 12623519 SEAL, RAD OTLT PIPE (O RING) (ЧАСТЬ OF 17) 12623519 SEAL, RAD OTLT PIPE (O RING) (ЧАСТЬ OF 17) 11570618 CЛАМПА-ПРУЖИНАBAND, 42 NOMINAL DIA, 20 THK, STL, ROBO (ЧАСТЬ OF 13) 25800334 HOSE, RAD OTLT (INCLS 12) [ШЛАНГ СИСТЕМЫ ОХЛАЖДЕНИЯ] 25800334 HOSE, RAD OTLT (INCLS 12) [ШЛАНГ СИСТЕМЫ ОХЛАЖДЕНИЯ] 15932854 РАДИАТОР, (ACDelco #21706) [РАДИАТОР] 15932855 РАДИАТОР, (ACDelco #21751) [РАДИАТОР] 11516233 CЛАМПА-ПРУЖИНАBAND, TYPE A, 15 WID, 40 HOSE OD, 6150M, 7111M, MM (RAD INL HOSE) [ХОМУТ ШЛАНГА РАДИАТОРА] 25800333 HOSE, RAD INL [ШЛАНГ РАДИАТОРА] 25800333 HOSE, RAD INL [ШЛАНГ РАДИАТОРА] 12612857 PIPE, RAD OTLT (INCLS 11) teamcadillac.ru 12612857 PIPE, RAD OTLT (INCLS 11) 11519977 БОЛТ- HFH, M8X1.25X25, 16 THD, 18 OD, 8.8, GMW3359, MAT-PT. (RAD OTLT PIPE) 11518624 БОЛТ, HFH, M10X1.5X30.4, 22.5 THD, 22.3 O.D., 10.9, GMW3359 (RAD OTLT PIPE) not found HOSE, SURGE TK OVFL (ЧАСТЬ OF 6) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (RAD SURGE TK OTLT PIPE) (6M01-039) - 2008 DM69 ПОДОГРЕВАТЕЛЬ БЛОКА ДВИГАТЕЛЯ (LP1/2.8T,LLT/3.6V,LY7/3.6-7, 220V ПОДОГРЕВАТЕЛЬ KA3) ↓ 25772574 CORD, ENG COOL HTR [КАБЕЛЬ ПИТАНИЯ СИСТЕМЫ ПОДОГРЕВА ДВС] 25772574 CORD, ENG COOL HTR [КАБЕЛЬ ПИТАНИЯ СИСТЕМЫ ПОДОГРЕВА ДВС] teamcadillac.ru 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ENG COOL HTR) 02 - СТАРТЕР - ГЕНЕРАТОР - ЗАЖИГАНИЕ - ЭЛЕКТРИКА - ЛАМПЫ (6D02-056) - 2008 DM69 МОДУЛЬ/AUX BODY CONTROL ↓ 25843242 МОДУЛЬ, AUX BODY CONT (ACDelco #25843242) [МОДУЛЬ] 11514517 ГАЙКА, HEX, W/CON SPR WA, M6X1, 5.7THK, 18 O.D., 9, 7111M (BCM BRKT) [ГАЙКА М6] 15884798 BRACKET, ACSRY WRG J/BLK (XBCM BRACKET) 25929033 BRACKET, ACSRY WRG J/BLK not found HARNESS, BODY WRG (СМ. ГРУППУ 13.000 "ЖГУТЫ ПРОВОДОВ/КУЗОВ ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6D02-057) - 2008 DM69 КРЕПЛЕНИЕ АККУМУЛЯТОРА И КАБЕЛИ ↓ 25833060 CABLE, BAT POS (ЧАСТЬ OF 7) (85" LONG) (INCLS 200 AMP MEGA FUSE) (ENG WRG) (ACDelco #25833060) [КАБЕЛЬ] 25833060 CABLE, BAT POS (ЧАСТЬ OF 7) (85" LONG) (INCLS 200 AMP MEGA FUSE) (ENG WRG) (ACDelco #25833060) [КАБЕЛЬ] 25833061 CABLE, BAT POS (ЧАСТЬ OF 7) (208" LONG) (ACDelco #25833061) [КАБЕЛЬ] 25930330 CABLE, BAT NEG CBL EXTN (ACDelco #25930330) [ПРОВОД АНТЕННЫ] 11562004 БОЛТ, HEX W/FL WA, M10X1.5X30, 19 THD, 20 OD, 8.8, GMW3200, MACH, M-PT (BAT CBL TERM) 11589258 БОЛТ, BAT NEG CBL GND (M8X1.25X31) [БОЛТ М8] not found HARNESS, ENG WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/ДВИГАТЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11609746 ГАЙКА, HFH, M8X1.25, 8.9THK, 17.6 O.D., 10 STL, GMW3200, PREV TORQUE (BAT POS CBL) [ГАЙКА М8] not found HARNESS, BODY WRG (INCLS 1, 15) (СМ. ГРУППУ 13.000 "ЖГУТЫ ПРОВОДОВ/КУЗОВ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 10306471 SENSOR, BAT CUR (ЧАСТЬ OF 9) [КАБЕЛЬНАЯ КЛЕММА] teamcadillac.ru 25899221 CABLE, BAT NEG (INCLS 8) (ACDelco #25899221) (LABELED 25899221) [КАБЕЛЬ] 11610073 БОЛТ -HEX W/FL WA, M8X1.25X16, 12.45 THD, 18 OD, GM6202M, GMW3200 (BAT NEG CBL) 89022169 АККУМУЛЯТОР, (CCA 770) (TOP POST) (277X174X190) (US DEALERS CONTACT ACDELCO WD FOR ORDERING & PRICING INFO) (ACDelco #48-7YR) (PROFESSIONAL - 7 YR) 14005061 RETAINER, BAT HOLDN (PLASTIC) [ПЛАСТИНА ФИКСАЦИИ ОСНОВАНИЯ АККУМУЛЯТОРА] 11509853 БОЛТ, HEX W/CON WA, M8X1.25X45, 24 O.D., HDR PT, 9.8, PS (BAT HOLDN RET) [БОЛТ] 25808256 LABEL, BAT WRNG not found COVER, BAT POS CBL TERM (ЧАСТЬ OF 7) (6D02-058) - 2008 DM69 ДАТЧИКИ ПАРКОВКИ (UD7) ↓ 15766504 TELLTALE, INFO CTR (ACDelco #15766504) teamcadillac.ru not found HARNESS, W/S HDR WRG (СМ. ГРУППУ 10.000 "КРЫША ОТДЕЛКА/INTERIOR" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found HARNESS, BODY WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/КУЗОВ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25819594 МОДУЛЬ, RR OBJECT ALARM [БЛОК УПРАВЛЕНИЯ ПРОТИВОУГОННОЙ СИСТЕМОЙ] 20782987 HARNESS, B/U ALARM WRG 20782987 HARNESS, B/U ALARM WRG 25863036 HARNESS, B/U ALARM WRG 25863036 HARNESS, B/U ALARM WRG 25863036 HARNESS, B/U ALARM WRG 25863036 HARNESS, B/U ALARM WRG 25863036 HARNESS, B/U ALARM WRG not found RETAINER, RR OBJECT SEN (ЧАСТЬ OF 8) 15271277 ШЛАНГИ, RR OBJECT SEN [ЖГУТ ПРОВОДОВ] 19116009 SENSOR KIT, RR OBJECT (INCLS 6) (7.831) [ДАТЧИК ПАРКОВКИ] 19116009 SENSOR KIT, RR OBJECT (INCLS 6) [ДАТЧИК ПАРКОВКИ] (6D02-059) - 2008 DM69 ПЕРЕДНИЕ ФАРЫ (H.I.D. ЛАМПА TT6) ↓ 15223842 HEADЛАМПА, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 3-5, 7-10, 13, 15) (INCLS HEADЛАМПА, BRKT, CAP, BULBS, BALLAST) (2.725) (USE ON VEHICLES BUILT BEFORE 9/17/07) 15223842 HEADЛАМПА, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 3-5, 7-10, 13, 15) (INCLS HEADЛАМПА, BRKT, CAP, BULBS, BALLAST) (2.725) (USE ON VEHICLES BUILT BEFORE 9/17/07) 15223842 HEADЛАМПА, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 3-5, 7-10, 13, 15) (INCLS HEADЛАМПА, BRKT, CAP, BULBS, BALLAST) (USE ON VEHICLES BUILT BEFORE 9/17/07) 25897359 HEADЛАМПА, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 3-5, 7-10, 13, 15) (GMX322 CTS) (2.725) (USE ON VEHICLES BUILT AFTER 9/17/07) teamcadillac.ru 25897359 HEADЛАМПА, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 3-5, 7-10, 13, 15) (GMX322 CTS) (2.725) (USE ON VEHICLES BUILT AFTER 9/17/07) 25897359 HEADЛАМПА, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 3-5, 7-10, 13, 15) (GMX322 CTS) (USE ON VEHICLES BUILT AFTER 9/17/07) 25897360 HEADЛАМПА, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 3-5, 7-10, 13, 15) (2.725) (USE ON VEHICLES BUILT AFTER 9/17/07) 25897360 HEADЛАМПА, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 3-5, 7-10, 13, 15) (2.725) (USE ON VEHICLES BUILT AFTER 9/17/07) 25897360 HEADЛАМПА, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 3-5, 7-10, 13, 15) (USE ON VEHICLES BUILT AFTER 9/17/07) 11518094 БОЛТ-HES W/FL WA, M6X1X21, 11.75 THD, 24 OD, 9.8, 7114M, MACH, DOG-PT (HDLP) not found SEAL, HDLP BALLAST (ЧАСТЬ OF 1) not found BALLAST, HDLP (ЧАСТЬ OF 1) 25794777 BALLAST, HDLP (ЧАСТЬ OF 1) (2.725) [БАЛАСТ] 11570322 БОЛТ, HDLP (M4.8X1.59X16) (HEX WASHER HEAD) (2.727) 15869580 BRACKET, HDLP [ОПОРНАЯ ПЛАНКА ПЕРЕДНЕЙ ФАРЫ] 25924112 BRACKET, HDLP not found BULB, DAYTIME RUNNING LP (ЧАСТЬ OF 1) 10351675 BULB, DAYTIME RUNNING LP (ЧАСТЬ OF 1) (CLEAR) (ACDelco #10351675) [ЛАМПОЧКА НАКАЛИВАНИЯ ПЕРЕДНЕЙ ФАРЫ 27 ВТ] 15782705 BULB, HDLP (ЧАСТЬ OF 1) (AMBER) (W/SOCKET) (8.991) (ACDelco #15782705) [ЛАМПА] 15782705 BULB, HDLP (ЧАСТЬ OF 1) (AMBER) (W/SOCKET) (8.991) (ACDelco #15782705) [ЛАМПА] 25911883 BULB, HDLP (ЧАСТЬ OF 1) (D1S) (ACDelco #25911883) 25794778 CAP, HDLP SOC BULB LK (ЧАСТЬ OF 1) (2.725) not found HARNESS, FWD LP WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/FORWARD ЛАМПАS" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found HARNESS, AUX MKR LP WRG 25897584 HARNESS, AUX MKR LP WRG not found HARNESS, HDLP WRG (ЧАСТЬ OF 1) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (HDLP) [ГАЙКА М6] 15896562 BRACKET, HDLP (ЧАСТЬ OF 1) (W/ FRT SI MKR & PARK & T/SIG LP) [КРОНШТЕЙН] 15896563 BRACKET, HDLP (ЧАСТЬ OF 1) (W/ FRT SI MKR & PARK & T/SIG LP) [КРОНШТЕЙН] not found ADJUSTER, FRT FOG LP (ЧАСТЬ OF 17) 25829654 ЛАМПА, FRT FOG (INCLS 16, 18) [ПРОТИВОТУМАННАЯ ФАРА] 92095787 BULB, TRADE # H11 (ЧАСТЬ OF 17) (2.727) (ACDelco #92095787) [ЛАМПОЧКА ПРОТИВОТУМАННОЙ ФАРЫ 27 ВТ] 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (FRT FOG LP BRKT) [ВИНТ М4] not found SOCKET, FRT SI T/SIG LP (ЧАСТЬ OF 22) 10351682 BULB, AUX SI FRT T/SIG LP (ЧАСТЬ OF 22) (TRADE # WY5W) (8.991) (ACDelco #WY5W) [ЛАМПА НАКАЛИВАНИЯ] 25894827 ЛАМПА, FRT SI T/SIG (INCLS 20, 21) [БОКОВОЙ УКАЗАТЕЛЬ ПОВОРОТА (ПОВТОРИТЕЛЬ)] 25894828 ЛАМПА, FRT SI T/SIG (INCLS 20, 21) [УКАЗАТЕЛЬ ПОВОРОТА] (6D02-060) - 2008 DM69 ПЕРЕДНИЕ ФАРЫ (EXC H.I.D. ЛАМПА TT6,TT7,TT8) ↓ 25897357 HEADЛАМПА, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 3-9, 11, 13, 14) (2.725) 25897357 HEADЛАМПА, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 3-9, 11, 13, 14) (2.725) 25897357 HEADЛАМПА, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 3-9, 11, 13, 14) 25897358 HEADЛАМПА, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 3-9, 11, 13, 14) (2.725) 25897358 HEADЛАМПА, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 3-9, 11, 13, 14) (2.725) 25897358 HEADЛАМПА, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 3-9, 11, 13, 14) 11518094 БОЛТ-HES W/FL WA, M6X1X21, 11.75 THD, 24 OD, 9.8, 7114M, MACH, DOG-PT (HDLP) 01999382 BULB, (ЧАСТЬ OF 1) (ACDelco #W5WLL) (LONGER LIFE) 92095787 BULB, TRADE # H11 (ЧАСТЬ OF 1) (2.727) (ACDelco #92095787) [ЛАМПОЧКА ПРОТИВОТУМАННОЙ ФАРЫ 27 ВТ] 92095788 BULB, HDLP (HIGH BEAM) (ЧАСТЬ OF 1) (ACDelco #H9) 25794778 CAP, HDLP SOC BULB LK (ЧАСТЬ OF 1) (2.725) 11570322 БОЛТ, HDLP (ЧАСТЬ OF 1) (M4.8X1.59X16) (HEX WASHER HEAD) (2.727) 25864591 COVER, HDLP BULB ACC HOLE (HIGH BEAM) (ЧАСТЬ OF 1) not found HARNESS, HDLP WRG (ЧАСТЬ OF 1) not found HARNESS, FWD LP WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/FORWARD ЛАМПАS" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 10351679 BULB, HDLP (ЧАСТЬ OF 1) (ACDelco #10351679) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (HDLP) [ГАЙКА М6] 15896562 BRACKET, HDLP (ЧАСТЬ OF 1) (W/ FRT SI MKR & PARK & T/SIG LP) [КРОНШТЕЙН] teamcadillac.ru 11570322 БОЛТ, HDLP (M4.8X1.59X16) (HEX WASHER HEAD) (2.727) 15869580 BRACKET, HDLP [ОПОРНАЯ ПЛАНКА ПЕРЕДНЕЙ ФАРЫ] 25924112 BRACKET, HDLP (6D02-061) - 2008 DM69 КОРРЕКТОР ФАР(TR7) ↓ 25895403 МОДУЛЬ, HDLP CONT not found HARNESS, FWD LP WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/FORWARD ЛАМПА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 88957147 LINK, ELEK SUSP FRT POSN SEN not found HARNESS, BODY WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/КУЗОВ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 88957144 SENSOR, ELEK SUSP FRT POSN [ДАТЧИК ПОЛОЖЕНИЯ ПОДВЕСКИ] 03532785 STUD, ELEK SUSP POSN SEN (M5X1.0X25.5) (BALL STYLE) not found LINK, ELEK SUSP RR POSN SEN (ЧАСТЬ OF 8) teamcadillac.ru 15867032 SENSOR, ELEK SUSP RR POSN (INCLS 7) [ДАТЧИК] (6D02-062) - 2008 DM69 ЗАДНИЕ ФАРЫ ↓ 19170356 ЛАМПА, HIGH MT STOP (2.679) (SERV CMP OF LMP PKG 19211989) 20818938 ЛАМПА, HIGH MT STOP [ФОНАРЬ ДОПОЛНИТЕЛЬНОГО СТОП-СИГНАЛА] not found HARNESS, BODY WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/КУЗОВ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25890524 MOLDING, R/CMPT LID LWR (INCLS 4) (KEYLESS TOUCHPAD ENTRY R/CMPT) [МОЛДИНГ] 25890525 MOLDING, R/CMPT LID LWR (INCLS 4) (KEYLESS TOUCHPAD ENTRY R/CMPT) [МОЛДИНГ] 25873332 HARNESS, RR LIC PLT LP WRG (ЧАСТЬ OF 3) [ПРОВОДКА КУЗОВА] 25873333 HARNESS, RR LIC PLT LP WRG (ЧАСТЬ OF 3) 25911619 ЛАМПА, RR LIC PLT (INCLS 6, 7) 25911620 ЛАМПА, RR LIC PLT (INCLS 6, 7) [ФОНАРЬ ПОДСВЕТКИ НОМЕРНОГО ЗНАКА] 01999382 BULB, (ЧАСТЬ OF 5) (ACDelco #W5WLL) (LONGER LIFE) not found SOCKET, RR LIC PLT LP (ЧАСТЬ OF 5) 19170354 ЛАМПА, TAIL (2.679) (SERV CMP OF LMP PKG 19211989) 19170355 ЛАМПА, TAIL (2.679) (SERV CMP OF LMP PKG 19211989) 20907590 ЛАМПА, TAIL (2.679) (SERV CMP OF LMP PKG 20907589) 20907591 ЛАМПА, TAIL (2.679) (SERV CMP OF LMP PKG 20907589) 25902143 ЛАМПА, TAIL 25902144 ЛАМПА, TAIL 25902145 ЛАМПА, TAIL 25902146 ЛАМПА, TAIL [ЗАДНИЙ ФОНАРЬ] 25933416 ЛАМПА, TAIL 25933417 ЛАМПА, TAIL 11517736 ГАЙКА, HEX, M6X1, 5.7 HIGH, 24 OD, 9, 7111M, W/2.5 THK SEALING WA (T/LP) [ГАЙКА М6] 11519612 ГАЙКА, HX CON SPR WA W/SEALER M6X1.0 6H GM510M (9) STL GM7111M (HIGH MT S/LP) 11569711 ГАЙКА, PUSH-IN, M4.2X1.41, 0.7-2.15 PNL THK, SAE 1050-1065, GMW3359 W/ (R/CMPT LID MLDG) [ГАЙКА М4.2] 09015554 ЛАМПА, RR FOG 09015556 ЛАМПА, RR FOG 15858979 BRACKET, RR FOG LP [КРОНШТЕЙН] 15858980 BRACKET, RR FOG LP [КРОНШТЕЙН] 21030249 RETAINER, EXPAN, 21 LG, 20. OD, 8.0 HOLE, 3.0-5.0 PNL, NYLON 6/6, BLK (RR FOG LP (PUSH IN)) (8.950) (PUSH IN) [ПИСТОН КРЕПЛЕНИЯ КОЖУХА РАДИАТОРА(ПЛАСТИК)] 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (RR FOG LP BRKT) [ВИНТ М4] (6D02-064) - 2008-2009 D69 ЖГУТЫ ПРОВОДОВ/ПЕРЕДНИЕ ФАРЫ ↓ 25907186 HARNESS, FWD LP WRG (INCLS 3) 25907188 HARNESS, FWD LP WRG (INCLS 3) 25961407 HARNESS, FWD LP WRG (INCLS 3) 25961409 HARNESS, FWD LP WRG (INCLS 3) not found HARNESS, AUX MKR LP WRG 25897584 HARNESS, AUX MKR LP WRG not found БОЛТ, FWD LP WRG HARN (ЧАСТЬ OF 1) teamcadillac.ru not found HARNESS, BODY WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/КУЗОВ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found BLOCK, ENG WRG HARN JUNC (СМ. ГРУППУ 02.000 "BLOCK/ДВИГАТЕЛЬ HARNESS JUNCTION" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6D02-065) - 2008-2010 D69 РЕЛЕ/ДВИГАТЕЛЬНЫЙ ОТСЕК ↓ 25892799 COVER, F/CMPT FUSE BLK HSG [КРЫШКА БЛОКА ПРЕДОХРАНИТЕЛЕЙ] not found RELAY, DAYTIME RUNNING LP (ЧАСТЬ OF 15) 12193606 RELAY, HDLP LOW BEAM (ЧАСТЬ OF 15) (BLUE) (4-TERMINAL) (SPST 280 MINI) (4.720) (ACDelco #12193606) 19116059 RELAY, DAYTIME RUNNING LP (ЧАСТЬ OF 15) (GRAY) (4 TERMINAL) (SPACE SAVER ULTRA 280 MICRO) (2.483) 19116059 RELAY, FOG LP (ЧАСТЬ OF 15) (GRAY) (4 TERMINAL) (SPACE SAVER ULTRA 280 MICRO) (2.483) 19116059 RELAY, IGN (ЧАСТЬ OF 15) (GRAY) (4 TERMINAL) (SPACE SAVER ULTRA 280 MICRO) (2.483) 19116059 RELAY, HDLP LOW BEAM (ЧАСТЬ OF 15) (GRAY) (4 TERMINAL) (SPACE SAVER ULTRA 280 MICRO) (2.483) 19116059 RELAY, СИГНАЛ (ЧАСТЬ OF 15) (GRAY) (4 TERMINAL) (SPACE SAVER ULTRA 280 MICRO) (2.483) 19116059 RELAY, CLU PED POSN (ЧАСТЬ OF 15) (GRAY) (4 TERMINAL) (SPACE SAVER ULTRA 280 MICRO) (2.483) 19116059 RELAY, WSWA PUMP (ЧАСТЬ OF 15) (GRAY) (4 TERMINAL) (SPACE SAVER ULTRA 280 MICRO) (2.483) 88953222 RELAY, IGN (ЧАСТЬ OF ДВИГАТЕЛЬ HARNESS) (ЧАСТЬ OF 15) (GRAY) (20AMP) (4 TERMINAL) (LOW-PROFILE MICRO 280) (2.485) (ACDelco #D1755A) [РЕЛЕ] 19116060 PULLER, FUSE (ЧАСТЬ OF 15) 15209748 FUSE, 40AMP, LOW PROFILE J CASE, GREEN (ЧАСТЬ OF 15) [ПРЕДОХРАНИТЕЛЬ 20А] 15822417 FUSE, 30AMP, LOW PROFILE J CASE, PINK (ЧАСТЬ OF 15) [ПРЕДОХРАНИТЕЛЬ, 20А] 19115640 FUSE, 60AMP, LOW PROFILE J CASE, YELLOW (ЧАСТЬ OF 15) [ПРЕДОХРАНИТЕЛЬ, 60А] 19116359 FUSE, 50AMP, LOW PROFILE J-CASE, RED (ЧАСТЬ OF 15) [ПРЕДОХРАНИТЕЛЬ 50А] teamcadillac.ru 19167271 FUSE, 20AMP, LOW PROFILE J CASE, BLUE (ЧАСТЬ OF 15) not found RELAY, RR FOG LP (ЧАСТЬ OF 15) not found RELAY, HDLP WA PUMP (ЧАСТЬ OF 15) 19116057 RELAY, STRTR (ЧАСТЬ OF 15) (GRAY) (35AMP) (4 TERMINAL) (HIGH CURRENT MICRO RELAY) (2.483) (ACDelco #D1786C) [РЕЛЕ 35А] 19116057 RELAY, RR FOG LP (ЧАСТЬ OF 15) (GRAY) (35AMP) (4 TERMINAL) (HIGH CURRENT MICRO RELAY) (2.483) (ACDelco #D1786C) [РЕЛЕ 35А] 19116057 RELAY, HDLP WA PUMP (ЧАСТЬ OF 15) (GRAY) (35AMP) (4 TERMINAL) (HIGH CURRENT MICRO RELAY) (2.483) (ACDelco #D1786C) [РЕЛЕ 35А] 19116041 FUSE, 2AMP, LOW PROFILE MINI, GRAY (ЧАСТЬ OF 15) [ПРЕДОХРАНИТЕЛЬ] 19116042 FUSE, 10AMP, LOW PROFILE MINI, RED (ЧАСТЬ OF 15) [ПРЕДОХРАНИТЕЛЬ, 10A] 19116043 FUSE, 15AMP, LOW PROFILE MINI, BLUE (ЧАСТЬ OF 15) [ПРЕДОХРАНИТЕЛЬ, 15A] 19116048 FUSE, 20AMP, LOW PROFILE MINI, YELLOW (ЧАСТЬ OF 15) [ПРЕДОХРАНИТЕЛЬ, 20A] 19116050 FUSE, 30AMP, LOW PROFILE MINI, GREEN (ЧАСТЬ OF 15) [ПРЕДОХРАНИТЕЛЬ, 30A] 19153648 FUSE, 7.5AMP, LOW PROFILE MINI, BROWN (ЧАСТЬ OF 15) [ПРЕДОХРАНИТЕЛЬ 7.5А] 19116081 COVER, BAT POS CBL J/BLK (ЧАСТЬ OF 15) 19116627 БОЛТ, ENG WRG HARN J/BLK (ЧАСТЬ OF 15) not found HARNESS, BODY WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/КУЗОВ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25954993 RETAINER, ACSRY WRG J/BLK [КРЫШКА БЛОКА ПРЕДОХРАНИТЕЛЕЙ] 11518121 ГАЙКА, U, M6X1, MULTI THD, .5'-4.0' THK PNL (ЧАСТЬ OF 13) 11561758 БОЛТ, MULTIUSE RLY & FUSE BRKT (7.833) [БОЛТ] 25929033 BRACKET, ACSRY WRG J/BLK (INCLS 11) not found HARNESS, FWD LP WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/FORWARD ЛАМПА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25892797 BLOCK, ENG WRG HARN JUNC (INCLS 2-8, 16-18) [ТОКОРАСПРЕДЕЛИТЕЛЬНАЯ КОРОБКА] 25892798 BLOCK, ENG WRG HARN JUNC (INCLS 2-8, 16-18) not found RELAY, PCM (ЧАСТЬ OF 15) 19116058 RELAY, PCM (ЧАСТЬ OF 15) (BLACK) (35AMP) (5 TERMINAL) (HIGH CURRENT MICRO 280) (2.483) (ACDelco #D1780C) 19116058 RELAY, WSW PULSE CONT (ЧАСТЬ OF 15) (BLACK) (35AMP) (5 TERMINAL) (HIGH CURRENT MICRO 280) (2.483) (ACDelco #D1780C) not found BREAKER, CIRC (ЧАСТЬ OF 15) 19116527 BREAKER, CIRC (ЧАСТЬ OF 15) (25 AMP MANUAL RESET) 19116821 BREAKER, CIRC (ЧАСТЬ OF 15) 19167272 BREAKER, CIRC (ЧАСТЬ OF 15) (20 AMP MANUAL RESET) not found RELAY, HDLP HIGH BEAM (ЧАСТЬ OF 15) 19116059 RELAY, HDLP HIGH BEAM (ЧАСТЬ OF 15) (GRAY) (4 TERMINAL) (SPACE SAVER ULTRA 280 MICRO) (2.483) 88953222 RELAY, HDLP HIGH BEAM (ЧАСТЬ OF 15) (GRAY) (20AMP) (4 TERMINAL) (LOW-PROFILE MICRO 280) (2.485) (ACDelco #D1755A) [РЕЛЕ] (6D02-066) - 2008 DM69 BLOCK/ЗАДНИЙ B.E.C. ↓ 25796593 BRACKET, BODY WRG HARN J/BLK (INCLS 11) 19116058 RELAY, RR FOG LP (ЧАСТЬ OF 5) (BLACK) (35AMP) (5 TERMINAL) (HIGH CURRENT MICRO 280) (2.483) (ACDelco #D1780C) 19116058 RELAY, DR LK (ЧАСТЬ OF 5) (BLACK) (35AMP) (5 TERMINAL) (HIGH CURRENT MICRO 280) (2.483) (ACDelco #D1780C) 19116059 RELAY, S/LP SW (ЧАСТЬ OF 5) (GRAY) (4 TERMINAL) (SPACE SAVER ULTRA 280 MICRO) (2.483) 19116059 RELAY, RR SI MKR LP (ЧАСТЬ OF 5) (GRAY) (4 TERMINAL) (SPACE SAVER ULTRA 280 MICRO) (2.483) 19116059 RELAY, F/PMP (ЧАСТЬ OF 5) (GRAY) (4 TERMINAL) (SPACE SAVER ULTRA 280 MICRO) (2.483) 19116059 RELAY, L/GATE LAT ACTR (ЧАСТЬ OF 5) (GRAY) (4 TERMINAL) (SPACE SAVER ULTRA 280 MICRO) (2.483) 88953222 RELAY, S/LP SW (ЧАСТЬ OF 5) (GRAY) (20AMP) (4 TERMINAL) (LOW-PROFILE MICRO 280) (2.485) (ACDelco #D1755A) [РЕЛЕ] not found HARNESS, BODY WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/КУЗОВ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 20765590 BLOCK, BODY WRG HARN JUNC (INCLS 2, 3, 6-8) (13.100) [БЛОК] 20765590 BLOCK, BODY WRG HARN JUNC (INCLS 2, 3, 6-8) [БЛОК] 20765591 BLOCK, BODY WRG HARN JUNC (INCLS 2, 3, 6-8) (13.100) 20765591 BLOCK, BODY WRG HARN JUNC (INCLS 2, 3, 6-8) 19116042 FUSE, 10AMP, LOW PROFILE MINI, RED (ЧАСТЬ OF 5) [ПРЕДОХРАНИТЕЛЬ, 10A] 19116043 FUSE, 15AMP, LOW PROFILE MINI, BLUE (ЧАСТЬ OF 5) [ПРЕДОХРАНИТЕЛЬ, 15A] 19116048 FUSE, 20AMP, LOW PROFILE MINI, YELLOW (ЧАСТЬ OF 5) [ПРЕДОХРАНИТЕЛЬ, 20A] 19116049 FUSE, 25AMP, LOW PROFILE MINI, NATURAL (ЧАСТЬ OF 5) [ПРЕДОХРАНИТЕЛЬ, 25A] 19116050 FUSE, 30AMP, LOW PROFILE MINI, GREEN (ЧАСТЬ OF 5) [ПРЕДОХРАНИТЕЛЬ, 30A] 19116527 BREAKER, CIRC (ЧАСТЬ OF 5) (25 AMP MANUAL RESET) 19116821 BREAKER, CIRC (ЧАСТЬ OF 5) 19167272 BREAKER, CIRC (ЧАСТЬ OF 5) (20 AMP MANUAL RESET) 19116060 PULLER, FUSE (ЧАСТЬ OF 5) teamcadillac.ru not found HARNESS, BODY WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/КУЗОВ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (RR BODY FUSE BLK) [ВИНТ М4] not found ГАЙКА, RR BODY FUSE BLK BRKT (ЧАСТЬ OF 1) (6D02-067) - 2008-2009 DM69 КРЕПЛЕНИЕ ГЕНЕРАТОРА (LP1/2.8T,LLT/3.6V,LY7/3.6-7) ↓ not found BRACKET, GEN & DRV BELT TENSR 12597648 BRACKET, GEN & DRV BELT TENSR (2.277) 12597648 BRACKET, GEN & DRV BELT TENSR (2.277) 12597648 BRACKET, GEN & DRV BELT TENSR 12597648 BRACKET, GEN & DRV BELT TENSR 11518628 БОЛТ, HVY HEX ACORN FLG HD, M10X1.5X50, GMW25M (10.9) STL, GMW3358 (GEN BRKT) 11518636 БОЛТ, HFH, M10X1.5X90, 25.9 THD, 22.3 OD, 10.9, GMW3359, 7.5 MAT-PT (GEN BRKT) [БОЛТ М10] 11588733 БОЛТ, HFH, M8X1.25X80.8, 21.6 THD, 18 OD, 8.8 STL, GMW3359 (GEN BRKT) 10396863 GENERATOR, (ACDelco #10396863) (DENSO UNIT) [ГЕНЕРАТОР 140А] 10396863 GENERATOR, (ACDelco #10396863) (DENSO UNIT) [ГЕНЕРАТОР 140А] teamcadillac.ru 10396863 GENERATOR, (ACDelco #10396863) (DENSO UNIT) [ГЕНЕРАТОР 140А] 11518628 БОЛТ, HVY HEX ACORN FLG HD, M10X1.5X50, GMW25M (10.9) STL, GMW3358 (GEN) 11518633 БОЛТ, HFH, M10X1.5X75, 26 THD, 22.3 OD, 10.9, GMW3359, MAT- POINT. (GEN) [БОЛТ М10] (6D02-068) - 2008 DM69 СВЕТООТРАЖАТЕЛИ (VR5) ↓ 25943610 REFLECTOR KIT, DISABLED VEH WRNG TRIANGLE (INCLS 2-5) not found BRACKET, DISABLED VEH WRNG TRIANGLE REFL (ЧАСТЬ OF 1) not found REFLECTOR, DISABLED VEH WRNG TRIANGLE (ЧАСТЬ OF 1) teamcadillac.ru 15714276 SCREW, HWH, W/FL WA, SELF TAP, M4.2X1.41X18, 12.5 O.D., 6010M, PS (ЧАСТЬ OF 1) (8.977) 11518531 ГАЙКА, U-TYPE, M4.2X1.41, 15.9X8.4, .7-2.1 PNL, SAE 1050 STL, 7111M, 8.65 SQ HOL (ЧАСТЬ OF 1) (10.512) [ГАЙКА М10] (6D02-069) - 2008 DM69 PEDESTRAIN PROTECTION SYSTEM (B3T) ↓ 15902864 BRACKET, PEDESTRIAN IMP DETECTION MDL (INCLS 16) 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (PEDESTRIAN IMP DETECTION MDL) [ВИНТ М4] not found HARNESS, I/P WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/INSTURMENT PANEL" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25912312 ACTUATOR, ACTIVE КАПОТ HGE 11569754 БОЛТ, КАПОТ HGE 25909697 HINGE, КАПОТ (BODY SI) (СМ. ГРУППУ 08.000 "КАПОТ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25909698 HINGE, КАПОТ (BODY SI) (СМ. ГРУППУ 08.000 "КАПОТ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25811792 BUMPER, КАПОТ RR 25811793 BUMPER, КАПОТ RR 25812678 SENSOR, PEDESTRIAN IMPACT DETECTION (INCLS 10) (ACTIVE КАПОТ SYSTEM DISCRIMINATION SENSOR-FRT UPR BEAM) 11609422 БОЛТ, FRT BPR IMP BAR (M5X0.5X17.4, 14.2 OD, 9.8, GW3359, M-POINT) (0.206) 15940806 LABEL, PEDESTRIAN IMP DETECTION SEN CAUTION (ЧАСТЬ OF 8) teamcadillac.ru 25916157 SENSOR, PEDESTRIAN IMPACT DETECTION (LABELED 25863871) 25916157 SENSOR, PEDESTRIAN IMPACT DETECTION (LABELED 25916157) 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (PEDESTRIAN IMP DETECTION MDL) [БОЛТ М6] 25916158 МОДУЛЬ, PEDESTRIAN IMPACT DETECTION (INCLS 14) (LABELED 25916158) not found LABEL, PEDESTRIAN IMP DETECTION MDL CAUTION (ЧАСТЬ OF 13) 15940808 LABEL, PEDESTRIAN IMP DETECTION MDL CAUTION (ЧАСТЬ OF 13) 11610157 ГАЙКА, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (PEDESTRIAN IMP DETECTION MDL BRKT) (10.701) [ГАЙКА М4] 11610157 ГАЙКА, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (ЧАСТЬ OF 1) (10.701) [ГАЙКА М4] 11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (PEDESTRIAN IMP DETECTION MDL BRKT) [ВИНТ] 25878022 PLIERS, (WIRE CUTTER) 25878021 WRENCH, (6D02-075) - 2008-2009 DM69 ЖГУТЫ ПРОВОДОВ/ДВИГАТЕЛЬ (LP1/2.8T,LY7/3.6-7) ↓ 25953724 HARNESS, ENG WRG (INCLS 4, 6, 9) 25953725 HARNESS, ENG WRG (INCLS 4, 6, 9) [ПРОВОДКА МОТОРНОГО ОТСЕКА] 25953726 HARNESS, ENG WRG (INCLS 4, 6, 9) [ПРОВОДКА КУЗОВА] 25953734 HARNESS, ENG WRG (INCLS 4, 6, 9) [ПРОВОДКА ДВИГАТЕЛЯ] 25953735 HARNESS, ENG WRG (INCLS 4, 6, 9) 11562004 БОЛТ, HEX W/FL WA, M10X1.5X30, 19 THD, 20 OD, 8.8, GMW3200, MACH, M-PT (ENG WRG HARN SUPT) 21021808 ГАЙКА, STRTR SOL CBL (M8X1.25X6, BRASS) [ГАЙКА М8] not found BOOT, WRG HARN TERM (ЧАСТЬ OF 1) teamcadillac.ru 11609789 ГАЙКА, BAT WIRE (8.915) [ГАЙКА М8] 25833060 CABLE, BAT POS (ЧАСТЬ OF 1) (85" LONG) (INCLS 200 AMP MEGA FUSE) (ENG WRG) (ACDelco #25833060) [КАБЕЛЬ] 11609746 ГАЙКА, HFH, M8X1.25, 8.9THK, 17.6 O.D., 10 STL, GMW3200, PREV TORQUE (BAT POS CBL) [ГАЙКА М8] not found BLOCK, ENG WRG HARN JUNC (СМ. ГРУППУ 02.000 "РЕЛЕ/ДВИГАТЕЛЬНЫЙ ОТСЕК" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found БОЛТ, ENG WRG HARN (ЧАСТЬ OF 1) (6D02-076) - 2008 DM69 ЖГУТЫ ПРОВОДОВ/ДВИГАТЕЛЬ (LLT/3.6V) ↓ 25953722 HARNESS, ENG WRG (INCLS 5, 6, 9) [ПРОВОДКА МОТОРНОГО ОТСЕКА] 25953723 HARNESS, ENG WRG (INCLS 5, 6, 9) 25953727 HARNESS, ENG WRG (INCLS 5, 6, 9) [ПРОВОДКА МОТОРНОГО ОТСЕКА] 25953727 HARNESS, ENG WRG (INCLS 5, 6, 9) [ПРОВОДКА МОТОРНОГО ОТСЕКА] 11562004 БОЛТ, HEX W/FL WA, M10X1.5X30, 19 THD, 20 OD, 8.8, GMW3200, MACH, M-PT (ENG WRG HARN SUPT) 21021808 ГАЙКА, STRTR SOL BAT TERM (M8X1.25X6, BRASS) (2.343) [ГАЙКА М8] 11609789 ГАЙКА, BAT WIRE (8.915) [ГАЙКА М8] not found COVER, GEN WIRE TERM (ЧАСТЬ OF 1) teamcadillac.ru 25833060 CABLE, BAT POS (ЧАСТЬ OF 1) (85" LONG) (INCLS 200 AMP MEGA FUSE) (ENG WRG) (ACDelco #25833060) [КАБЕЛЬ] 11609746 ГАЙКА, HFH, M8X1.25, 8.9THK, 17.6 O.D., 10 STL, GMW3200, PREV TORQUE (BAT POS CBL) [ГАЙКА М8] not found BLOCK, ENG WRG HARN JUNC (СМ. ГРУППУ 02.000 "РЕЛЕ/ДВИГАТЕЛЬНЫЙ ОТСЕК" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found БОЛТ, ENG WRG HARN (ЧАСТЬ OF 1) (6D02-077) - 2008-2010 D69 ЖГУТЫ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ ↓ 25901879 HARNESS, I/P WRG 25931812 HARNESS, I/P WRG 25931813 HARNESS, I/P WRG 25931814 HARNESS, I/P WRG 25931815 HARNESS, I/P WRG 25931816 HARNESS, I/P WRG 25931817 HARNESS, I/P WRG 25931818 HARNESS, I/P WRG 25931819 HARNESS, I/P WRG 25931820 HARNESS, I/P WRG teamcadillac.ru 25931821 HARNESS, I/P WRG 25931822 HARNESS, I/P WRG 25931823 HARNESS, I/P WRG 25931824 HARNESS, I/P WRG 25931825 HARNESS, I/P WRG 25931826 HARNESS, I/P WRG 25931827 HARNESS, I/P WRG 25931828 HARNESS, I/P WRG 25931829 HARNESS, I/P WRG 25931830 HARNESS, I/P WRG 25931831 HARNESS, I/P WRG 25931832 HARNESS, I/P WRG 25931833 HARNESS, I/P WRG 25931834 HARNESS, I/P WRG 25931835 HARNESS, I/P WRG 25931836 HARNESS, I/P WRG 25931837 HARNESS, I/P WRG 25931838 HARNESS, I/P WRG 25931839 HARNESS, I/P WRG 25931840 HARNESS, I/P WRG 25931841 HARNESS, I/P WRG 25931842 HARNESS, I/P WRG 25931843 HARNESS, I/P WRG 25931843 HARNESS, I/P WRG 25931844 HARNESS, I/P WRG 25931845 HARNESS, I/P WRG 25931846 HARNESS, I/P WRG 25931847 HARNESS, I/P WRG 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (I/P WRG HARN CLIP) [ВИНТ М4] not found HARNESS, BODY WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/КУЗОВ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25892797 BLOCK, ENG WRG HARN JUNC (СМ. ГРУППУ 02.000 "РЕЛЕ/ДВИГАТЕЛЬНЫЙ ОТСЕК" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ТОКОРАСПРЕДЕЛИТЕЛЬНАЯ КОРОБКА] 25892798 BLOCK, ENG WRG HARN JUNC (СМ. ГРУППУ 02.000 "РЕЛЕ/ДВИГАТЕЛЬНЫЙ ОТСЕК" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6D02-078) - 2008-2010 D69 СИГНАЛИЗАЦИЯ/ANTI THEFT (UA2) ↓ not found SENSOR, THEFT DTRNT VEH INCLINATION 25734317 SENSOR, THEFT DTRNT VEH INCLINATION [ДАТЧИК НАКЛОНА КУЗОВА] teamcadillac.ru not found HARNESS, BODY WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/КУЗОВ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found ALARM, THEFT DTRNT (INCLS 4) (*KIT1) 15213135 ALARM, THEFT DTRNT (INCLS 4) (*KIT1) [ЗВУКОВОЙ СИГНАЛ (СИРЕНА) СИГНАЛИЗАЦИИ] not found ГАЙКА, THEFT DTRNT ALARM (ЧАСТЬ OF 3) not found BRACKET, THEFT DTRNT ALARM (*KIT1) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (THEFT DTRNT ALARM) [ГАЙКА М6] not found КОНСОЛЬ, RF (СМ. ГРУППУ 10.000 "КРЫША ОТДЕЛКА/INTERIOR" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 15283682 SENSOR, THEFT DTRNT [ДАТЧИК НАКЛОНА КУЗОВА] not found HARNESS, W/S HDR WRG (СМ. ГРУППУ 10.000 "КРЫША ОТДЕЛКА/INTERIOR" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 15853151 ALARM PKG, THEFT DTRNT (INCLS 3, 5) (INCLS ALARM & BRACKET) (6D02-083) - 2008 DM69 ПЕРЕДНИЕ ФАРЫ (H.I.D. ЛАМПА TT7,TT8) ↓ 15223846 HEADЛАМПА, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 3-5, 7-9, 12, 14) (2.725) (USE ONLY ON VEHICLES BUILT BEFORE 9-17-07, FOR 2ND DESIGN SEE 25897362) 15223846 HEADЛАМПА, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 3-5, 7-9, 12, 14) (2.725) (USE ONLY ON VEHICLES BUILT BEFORE 9-17-07, FOR 2ND DESIGN SEE 25897362) 15223846 HEADЛАМПА, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 3-5, 7-9, 12, 14) (USE ONLY ON VEHICLES BUILT BEFORE 9-17-07, FOR 2ND DESIGN SEE 25897362) 15223847 HEADЛАМПА, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 3-5, 7-9, 12, 14) (2.725) (USE ONLY ON VEHICLES BUILT BEFORE 9-17-07, FOR 2ND DESIGN SEE 25897361) 15223847 HEADЛАМПА, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 3-5, 7-9, 12, 14) (2.725) (USE ONLY ON VEHICLES BUILT BEFORE 9-17-07, FOR 2ND DESIGN SEE 25897361) 15223847 HEADЛАМПА, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 3-5, 7-9, 12, 14) (USE ONLY ON VEHICLES BUILT BEFORE 9-17-07, FOR 2ND DESIGN SEE 25897361) 25805314 HEADЛАМПА, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 3-5, 7-9, 12, 14) (INCLS HEADЛАМПА, BRKT) (2.725) 25805314 HEADЛАМПА, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 3-5, 7-9, 12, 14) (INCLS HEADЛАМПА, BRKT) (2.725) 25805314 HEADЛАМПА, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 3-5, 7-9, 12, 14) (INCLS HEADЛАМПА, BRKT) 25897361 HEADЛАМПА, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 3-5, 7-9, 12, 14) (2.725) (USE ONLY ON VEHICLES BUILT AFTER 9-17-07, FOR 1ST DESIGN SEE 15223847) 25897361 HEADЛАМПА, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 3-5, 7-9, 12, 14) (2.725) (USE ONLY ON VEHICLES BUILT AFTER 9-17-07, FOR 1ST DESIGN SEE 15223847) 25897361 HEADЛАМПА, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 3-5, 7-9, 12, 14) (USE ONLY ON VEHICLES BUILT AFTER 9-17-07, FOR 1ST DESIGN SEE 15223847) 25897362 HEADЛАМПА, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 3-5, 7-9, 12, 14) (2.725) (USE ONLY ON VEHICLES BUILT AFTER 9-17-07, FOR 1ST DESIGN SEE 15223846) 25897362 HEADЛАМПА, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 3-5, 7-9, 12, 14) (2.725) (USE ONLY ON VEHICLES BUILT AFTER 9-17-07, FOR 1ST DESIGN SEE 15223846) 25897362 HEADЛАМПА, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 3-5, 7-9, 12, 14) (USE ONLY ON VEHICLES BUILT AFTER 9-17-07, FOR 1ST DESIGN SEE 15223846) 25897363 HEADЛАМПА, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 3-5, 7-9, 12, 14) (2.725) [ПЕРЕДНЯЯ ФАРА] 25897363 HEADЛАМПА, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 3-5, 7-9, 12, 14) (2.725) [ПЕРЕДНЯЯ ФАРА] 25897363 HEADЛАМПА, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 3-5, 7-9, 12, 14) [ПЕРЕДНЯЯ ФАРА] 11570832 БОЛТ, HDLP (ЧАСТЬ OF 1) (M4.8X1.59X16) (ROUND WASHER HEAD) teamcadillac.ru not found SEAL, HDLP BALLAST (ЧАСТЬ OF 1) not found BALLAST, HDLP (ЧАСТЬ OF 1) 25794777 BALLAST, HDLP (ЧАСТЬ OF 1) (2.725) [БАЛАСТ] 11570322 БОЛТ, HDLP (ЧАСТЬ OF 1) (M4.8X1.59X16) (HEX WASHER HEAD) (2.727) 15869580 BRACKET, HDLP [ОПОРНАЯ ПЛАНКА ПЕРЕДНЕЙ ФАРЫ] 25924112 BRACKET, HDLP 15782705 BULB, HDLP (ЧАСТЬ OF 1) (AMBER) (W/SOCKET) (8.991) (ACDelco #15782705) [ЛАМПА] 25735604 BULB, HDLP (ЧАСТЬ OF 1) (W/IGNITOR) (ACDelco #25735604) [ЛАМПОЧКА ПЕРЕДНЕЙ ФАРЫ 55 ВТ] 25911883 BULB, HDLP (ЧАСТЬ OF 1) (D1S) (ACDelco #25911883) 25794778 CAP, HDLP SOC BULB LK (ЧАСТЬ OF 1) (2.725) not found HARNESS, FWD LP WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/FORWARD ЛАМПАS" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found HARNESS, AUX MKR LP WRG 25897584 HARNESS, AUX MKR LP WRG not found HARNESS, HDLP WRG (ЧАСТЬ OF 1) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (HDLP) [ГАЙКА М6] 15896562 BRACKET, HDLP (ЧАСТЬ OF 1) (W/ FRT SI MKR & PARK & T/SIG LP) [КРОНШТЕЙН] 15896563 BRACKET, HDLP (ЧАСТЬ OF 1) (W/ FRT SI MKR & PARK & T/SIG LP) [КРОНШТЕЙН] not found ADJUSTER, FRT FOG LP (ЧАСТЬ OF 16) 25808666 ЛАМПА, FRT FOG (INCLS 15, 17) [ПРОТИВОТУМАННАЯ ФАРА] 92095787 BULB, TRADE # H11 (ЧАСТЬ OF 16) (2.727) (ACDelco #92095787) [ЛАМПОЧКА ПРОТИВОТУМАННОЙ ФАРЫ 27 ВТ] 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (FRT FOG LP BRKT) [ВИНТ М4] not found SOCKET, FRT SI T/SIG LP (ЧАСТЬ OF 21) 10351682 BULB, AUX SI FRT T/SIG LP (ЧАСТЬ OF 21) (TRADE # WY5W) (8.991) (ACDelco #WY5W) [ЛАМПА НАКАЛИВАНИЯ] 25894827 ЛАМПА, FRT SI T/SIG (INCLS 19, 20) [БОКОВОЙ УКАЗАТЕЛЬ ПОВОРОТА (ПОВТОРИТЕЛЬ)] 25894828 ЛАМПА, FRT SI T/SIG (INCLS 19, 20) [УКАЗАТЕЛЬ ПОВОРОТА] (6D02-092) - 2008-2009 D69 ФАРООМЫВАТЕЛЬ (CE4) ↓ 25866755 CONTAINER, WSWA SOLV (СМ. ГРУППУ 10.000 "СТЕКЛООЧИСТИТЕЛЬ-ВЕТРОВОГО СТЕКЛА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (DOES NOT INCL CAP 12767700) 25793666 COVER, HDLP WA NOZ HOLE [КОЖУХ ФОРСУНКИ ФАРООМЫВАТЕЛЯ] 25793667 COVER, HDLP WA NOZ HOLE [КОЖУХ ФОРСУНКИ ФАРООМЫВАТЕЛЯ] 15282518 NOZZLE, HDLP WA [ФОРСУНКА ФАРООМЫВАТЕЛЯ] 15282519 NOZZLE, HDLP WA [ФОРСУНКА ФАРООМЫВАТЕЛЯ] 15282519 NOZZLE, HDLP WA [ФОРСУНКА ФАРООМЫВАТЕЛЯ] 90508376 CLIP, HDLP WA HOSE not found FASCIA, FRT BPR (СМ. ГРУППУ 07.000 "БАМПЕР ПЕРЕДНИЙ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (КРАСКА TO MATCH) (MUST ALSO ORDER DUCTS 20772527 & 20772528) 25972091 HOSE, HDLP WA [ШЛАНГ ФАРООМЫВАТЕЛЯ] 11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (WSWA SOLV CNTNR) [ШАЙБА] 11589031 БОЛТ, HES W/FL WA, M6X1X21, 11.75 THD, 24 OD, 9.8, GMW4205, 5.3 DOG-PT (WSWA SOLV CNTNR) [БОЛТ М6] 13227300 CAP, WSWA SOLV CNTNR [КРЫШКА БАЧКА СТЕКЛООМЫВАТЕЛЯ] 22039457 GROMMET, WSWA PUMP (18MM) [ВТУЛКА УПЛОТНИТЕЛЬНАЯ, НАСОСА ОМЫВА ВЕТРОВОГО СТЕК] 25790704 WASHER, HDLP WA PUMP (W/PUMP) (10.153) [ФАРА] teamcadillac.ru 25790705 PUMP, WSWA [ПОДШИПНИК] 89001122 PUMP, WSWA (10.146) (ACDelco #8-6710) (ALL MAKES) [ОМЫВАЮЩИЙ НАСОС] 89001122 PUMP, WSWA (10.146) (ACDelco #8-6710) (ALL MAKES) [ОМЫВАЮЩИЙ НАСОС] not found GROMMET, WSWA SOLV CNTNR (ЧАСТЬ OF 13) 15254826 SENSOR, WSWA SOLV LVL (INCLS 12) (16.065) (6E02-032) - 2008 DM69 СИГНАЛ ↓ teamcadillac.ru 25789207 СИГНАЛ, 400 & 500 HZ (INCLS 2, 3) (ACDelco #D1946F) 25868557 СИГНАЛ, 400 & 500 HZ (INCLS 2, 3) (ACDelco #D1967F) [ЗВУКОВОЙ СИГНАЛ] not found STUD, СИГНАЛ (ЧАСТЬ OF 1) not found ГАЙКА, СИГНАЛ (ЧАСТЬ OF 1) (6M02-037) - 2008-2009 DM69 КРЕПЛЕНИЕ СТАРТЕРА (LP1/2.8T,LLT/3.6V,LY7/3.6-7) ↓ 12610857 STARTER, (ACDelco #12610857) [СТАРТЕР] teamcadillac.ru 12616647 SHIELD, STRTR HT 12616647 SHIELD, STRTR HT 12616647 SHIELD, STRTR HT 11588740 БОЛТ, HFH, M10X1.5X40, 30 THD, 22.3 OD, 10.9, GMW3359, M-PT (STRTR) (ACDelco #11588740) 03 - ТОПЛИВНАЯ СИСТЕМА - ВЫХЛОПНАЯ - СИСТЕМА ВЫПУСКА ВОЗДУХА (6D03-053) - 2008 DM69 АКСЕЛЕРАТОР ↓ 10379038 PEDAL, ACCEL (INCLS 3-5) (INCLS POSN SENSOR) 10379039 PEDAL, ACCEL (INCLS 3-5) [ПЕДАЛЬ АКСЕЛЕРАТОРА (ГАЗА)] 11514516 ГАЙКА, HFH, M6X1, 6THK, 14.2 O.D., 9, PZOR (ACCEL PED LVR) not found BRACKET, ACCEL PED (ЧАСТЬ OF 1) not found БОЛТ, ACCEL PED LVR (ЧАСТЬ OF 1) not found ГАЙКА, ACCEL PED LVR (ЧАСТЬ OF 1) 25785092 BARRIER, BRK PED BRKT SND 25913292 BARRIER, BRK PED BRKT SND teamcadillac.ru not found REINFORCEMENT, STRG COL SUPT BRKT (6D03-076) - 2008-2009 D69 ШЛАНГИ И ТРУБКИ ТОПЛИВНОГО БАКА ↓ 25954934 ШЛАНГИ, F/TNK FIL PIPE [КОЖУХ ТОПЛИВОЗАЛИВНОЙ ГОРЛОВИНЫ] 11610236 CЛАМПА, TYPE F WORM GEAR 20-1/4 HEX HD SAE 302 STL GM3044 9 (ЧАСТЬ OF 3) 15925742 HOSE, F/TNK FIL (INCLS 2) 11588928 БОЛТ, HEX, W/FL WA, M6X1X25, 14 THD, 24 O.D., DOG-PT, STL, GMW3200 (F/TNK FIL PIPE BRKT) 25711370 CЛАМПА, F/TNK FIL HOSE (30-45MM CЛАМПА RANGE) 20789050 PIPE, F/TNK FIL teamcadillac.ru 25846197 PIPE, F/TNK FIL 15714276 SCREW, HWH, W/FL WA, SELF TAP, M4.2X1.41X18, 12.5 O.D., 6010M, PS (F/TNK FIL PIPE) (8.977) 15832215 CAP, F/TNK FIL (INCLUDES TETHER) (ACDelco #GT303) [КОЛПАК] 25966969 DOOR, F/TNK FIL (INCLS 10, 11) [ЛЮЧОК ТОПЛИВНОГО БАКА] not found ПРУЖИНА, F/TNK FIL DR (ЧАСТЬ OF 9) 89047657 BUMPER, F/TNK FIL DR (ЧАСТЬ OF 9) (HINGE) [ВТУЛКА] 22653093 PLUG, F/TNK FIL DR LAT REL CBL HOLE (30.2 X 9.2 MM) (FITS 19.3MM DIA HOLE) (12.942) 25880365 ПРУЖИНА, F/TNK FIL DR (PRIOR TO INSTALL SEAL VOIDS IN PLUNGER HSG W/FLEXIABLE SEALER) [ЗАЩЕЛКА ЛЮЧКА ТОПЛИВНОЙ ГОРЛОВИНЫ] 11609731 RIVET, POP, .25" SHANK, .63 LEN, .50 OD, .06-.30 GRP RNG, 1008 STL, GMW3044 (F/TNK FIL DR) 25907014 ACTUATOR, F/TNK FIL DR LK [ЭЛЕКТРОДВИГАТЕЛЬ ЛЮЧКА ТОПЛИВОЗАЛИВНОЙ ГОРЛОВИНЫ 20ВТ] 11589175 ГАЙКА, HEX, M8X1.25, 4 THK, GM510M, GMW3359, BLACK (F/TNK FIL DR LK ACTR) (6D03-077) - 2008-2009 D69 ТОПЛИВНЫЙ БАК КРЕПЛЕНИЕ ↓ teamcadillac.ru not found TANK, FUEL (W/SDR) (СМ. ГРУППУ 03.000 "ТОПЛИВНЫЙ БАК & УГОЛЬНЫЙ ФИЛЬТР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found PIPE, BRK & FUEL FEED & EVAP EMIS (СМ. ГРУППУ 03.000 "СИСТЕМА ТОПЛИВОСНАБЖЕНИЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25679207 STRAP, F/TNK [ЗАЖИМ БЕНЗОБАКА] 11517101 БОЛТ, METRIC HEX FLANGE HD, M10X1.5X50 (F/TNK STRP) [БОЛТ М10] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (EVAP EMIS CNSTR BRKT) [ГАЙКА М6] not found CANISTER, EVAP EMIS (СМ. ГРУППУ 03.000 "ТОПЛИВНЫЙ БАК & УГОЛЬНЫЙ ФИЛЬТР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found PIPE, F/TNK FIL (СМ. ГРУППУ 03.000 "ШЛАНГИ И ТРУБКИ ТОПЛИВНОГО БАКА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6D03-078) - 2008 DM69 СИСТЕМА ТОПЛИВОСНАБЖЕНИЯ/ТРУБКИ ↓ 25973154 PIPE, EVAP EMIS CNSTR PURGE [ТРУБКА ТОПЛИВНОЙ СИСТЕМЫ] 25973154 PIPE, EVAP EMIS CNSTR PURGE (INCLS 3) [ТРУБКА ТОПЛИВНОЙ СИСТЕМЫ] 25973156 PIPE, FUEL FEED (INCLS 5) [ТРУБКА ТОПЛИВНОЙ СИСТЕМЫ] 25973156 PIPE, FUEL FEED (INCLS 5) [ТРУБКА ТОПЛИВНОЙ СИСТЕМЫ] 21992746 RETAINER, FUEL FEED HOSE CONN (ЧАСТЬ OF 1) (5/8 INCH QUICK CONNECT RETAINER CLIP) 21992748 RETAINER, FUEL FEED HOSE CONN (ЧАСТЬ OF 1) (5/16 INCH QUICK CONNECT RETAINER CLIP) 22695614 CLIP, FUEL FEED & RTN HOSE (13 X 19 X 36MM) (ONE TUBE) [ОПОРНАЯ ПЛАНКА ТРУБКИ ТОПЛИВНОЙ СИСТЕМЫ] not found LABEL, FUEL FEED PIPE WRNG (ЧАСТЬ OF 2) 15223305 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (HOLDS TWO LINES W/PRONG) 15223308 RETAINER, BRK & FUEL PIPE (ATTACHES TO BRKT) 15223308 RETAINER, BRK & FUEL PIPE (ATTACHES TO BRKT) (3.162) 25761218 BRACKET, FUEL PIPE 11514623 БОЛТ, HEX W/CON WA, M6X1X20 (FUEL FEED & EVAP EMIS & RTN PIPE CLIP BRKT) not found SLEEVE, FUEL FEED PIPE 15223306 RETAINER, BRK & FUEL PIPE (2 FUEL/VAPORS LINE & 2 BRAKE LINES) 15223306 RETAINER, BRK & FUEL PIPE (2 FUEL/VAPORS LINE & 2 BRAKE LINES) (3.162) 15223307 RETAINER, BRK & FUEL PIPE (2 FUEL/VAPOR LINES) 15223307 RETAINER, BRK & FUEL PIPE (2 FUEL/VAPOR LINES) (3.162) teamcadillac.ru 15870391 RETAINER, BRK & FUEL PIPE (HOLDS FOUR LINES) 15870391 RETAINER, BRK & FUEL PIPE (HOLDS FOUR LINES) (3.162) 11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (FUEL FLTR BRKT) [БОЛТ М8] 15223304 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (HOLDS FOUR LINES) (3.890) not found TANK, FUEL (W/SDR) (СМ. ГРУППУ 03.000 "ТОПЛИВНЫЙ БАК & УГОЛЬНЫЙ ФИЛЬТР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6D03-079) - 2008 DM69 СИСТЕМА ВПУСКА ВОЗДУХА (LLT/3.6V) ↓ 15875837 SENSOR, MASS AIRFLOW (ACDelco #213-4250) [ДАТЧИК] 15219026 SEAL, MASS AIRFLOW SEN (O RING) (3.410) [УПЛОТНЕНИЕ] teamcadillac.ru 11561933 БОЛТ, КОНДИЦИОНЕРL HSG CVR (ЧАСТЬ OF 11) (M6X2.7X36) [БОЛТ] 11588831 SCREW, HEX W/ CON WA, M6X1X35, 33.5 THD, 17 O.D.HDR PT, 9.8, BLK (КОНДИЦИОНЕРL) 25774949 SPACER, КОНДИЦИОНЕРL HSG БОЛТ (ЧАСТЬ OF 11) 25774677 INSULATOR, КОНДИЦИОНЕРL HSG (ЧАСТЬ OF 11) (GROM AT SHOCK TOWER) not found COVER, КОНДИЦИОНЕРL HSG (ЧАСТЬ OF 11) 15875795 ELEMENT, КОНДИЦИОНЕРL (ЧАСТЬ OF 11) (ACDelco #A3096C) [ВОЗДУШНЫЙ ФИЛЬТР ДВИГАТЕЛЯ] 15875806 INSULATOR, КОНДИЦИОНЕРL HSG (ЧАСТЬ OF 11) (TOP HAT GROM LOC AT FRT TIE BAR) 15875807 INSULATOR, КОНДИЦИОНЕРL HSG (ЧАСТЬ OF 11) 25774676 CLEANER, AIR (INCLS 3, 5-10) [ФИЛЬТР] not found CЛАМПА, КОНДИЦИОНЕРL OTLT DUCT (ЧАСТЬ OF 13) 15236428 DUCT, КОНДИЦИОНЕРL OTLT (INCLS 12) [ТРУБОПРОВОД В СБОРЕ] 10356575 БОЛТ, MASS AIRFLOW SEN (6D03-080) - 2008-2009 DM69 СИСТЕМА ВПУСКА ВОЗДУХА (LP1/2.8T,LY7/3.6-7) ↓ 15875837 SENSOR, MASS AIRFLOW (ACDelco #213-4250) [ДАТЧИК] 15219026 SEAL, MASS AIRFLOW SEN (O RING) (3.410) [УПЛОТНЕНИЕ] 11561933 БОЛТ, КОНДИЦИОНЕРL HSG CVR (ЧАСТЬ OF 11) (M6X2.7X36) [БОЛТ] 11588831 SCREW, HEX W/ CON WA, M6X1X35, 33.5 THD, 17 O.D.HDR PT, 9.8, BLK (КОНДИЦИОНЕРL) 25774949 SPACER, КОНДИЦИОНЕРL HSG БОЛТ (ЧАСТЬ OF 11) 25774677 INSULATOR, КОНДИЦИОНЕРL HSG (ЧАСТЬ OF 11) (GROM AT SHOCK TOWER) not found COVER, КОНДИЦИОНЕРL HSG (ЧАСТЬ OF 11) 15875795 ELEMENT, КОНДИЦИОНЕРL (ЧАСТЬ OF 11) (ACDelco #A3096C) [ВОЗДУШНЫЙ ФИЛЬТР ДВИГАТЕЛЯ] 15875806 INSULATOR, КОНДИЦИОНЕРL HSG (ЧАСТЬ OF 11) (TOP HAT GROM LOC AT FRT TIE BAR) teamcadillac.ru 15875807 INSULATOR, КОНДИЦИОНЕРL HSG (ЧАСТЬ OF 11) 25774676 CLEANER, AIR (INCLS 3, 5-10) [ФИЛЬТР] not found CЛАМПА, КОНДИЦИОНЕРL OTLT DUCT (ЧАСТЬ OF 13) 25843874 DUCT, КОНДИЦИОНЕРL OTLT (INCLS 12) 25843874 DUCT, КОНДИЦИОНЕРL OTLT (INCLS 12) 10356575 БОЛТ, MASS AIRFLOW SEN (6D03-081) - 2008 DM69 СИСТЕМА ТОПЛИВОСНАБЖЕНИЯ/ДВИГАТЕЛЬ (LLT/3.6V) ↓ 12611801 VALVE, EVAP EMIS CNSTR PURGE SOL (ACDelco #214-1685) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 12611801 VALVE, EVAP EMIS CNSTR PURGE SOL (ACDelco #214-1685) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (EVAP EMIS CNSTR PURGE SOL VLV BRKT) 12609510 TUBE, EVAP EMIS CNSTR PURGE not found PIPE, BRK & FUEL FEED & EVAP EMIS (СМ. ГРУППУ 03.000 "СИСТЕМА ТОПЛИВОСНАБЖЕНИЯ/ТРУБКИ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11518625 БОЛТ, PAN, M10X1.5X35, 33.5THD, 20 O.D., 10.9, 6138M (F/INJN FUEL RL BRKT) 12614933 PIPE, FUEL FEED (INCLS 7, 8) [ШЛАНГ] 12574525 VALVE, FUEL PRESS SERV (ЧАСТЬ OF 6) (SCHRADER VALVE LESS CAP) [КЛАПАН КОНТРОЛЯ ДАВЛЕНИЯ ТОПЛИВНОЙ СИСТЕМЫ] 25532662 CAP, FUEL PRESS SERV VLV (ЧАСТЬ OF 6) (CAP FOR PRESSURE TEST SCHRADER VALVE) (3.163) (ACDelco #214-1044) [КРЫШКА] 25532662 CAP, FUEL PRESS SERV VLV (ЧАСТЬ OF 6) (CAP FOR PRESSURE TEST SCHRADER VALVE) (3.163) (ACDelco #214-1044) [КРЫШКА] 25532662 CAP, FUEL PRESS SERV VLV (ЧАСТЬ OF 6) (CAP FOR PRESSURE TEST SCHRADER VALVE) (3.163) (ACDelco #214-1044) [КРЫШКА] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 10) 12626234 PUMP, FUEL (INCLS 9, 11, 12) (ACDelco #EP2129) [ТОПЛИВНЫЙ НАСОС] 12595951 GASKET, F/PMP BRKT (ЧАСТЬ OF 10) [ПРОКЛАДКА ТОПЛИВНОГО НАСОСА] 12600313 SEAL, F/PMP HSG (O RING) (ЧАСТЬ OF 10) (ACDelco #G43) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ДВИГАТЕЛЯ] 12630022 SHIELD, ENG RR NOISE not found SHIELD, FUEL PIPE teamcadillac.ru 12610850 SHIELD, FUEL PIPE 12610850 SHIELD, FUEL PIPE 11588723 БОЛТ, HFH, M8X1.25X25, 18 THD, 18 OD, 8.8 STL, GMW3359, M-PT (FUEL PIPE SHLD) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (FUEL PIPE SHLD) 12590679 FOLLOWER, VLV LFTR (FUEL PUMP) [НАПРАВЛЯЮЩАЯ ВТУЛКА ТОПЛИВНОГО НАСОСА] (6D03-082) - 2008 DM69 РАМКА ТОПЛИВНОГО ИНЖЕКТОРА (LLT/3.6V) ↓ 12621292 SENSOR, FUEL PRESS (ЧАСТЬ OF БЛОК 12589096 LABELED BBB) (3.682) (ACDelco #213-4420) [ДАТЧИК ДАВЛЕНИЯ ТОПЛИВА] 12621292 SENSOR, FUEL PRESS (ЧАСТЬ OF БЛОК 12589096 LABELED BBB) (ACDelco #213-4420) [ДАТЧИК ДАВЛЕНИЯ ТОПЛИВА] 11519171 БОЛТ, F/INJN FUEL RL (M8X1.25X50) (3.275) [БОЛТ ВЫПУСКНОГО КОЛЛЕКТОРА] 12622263 RAIL, F/INJN FUEL 12623366 RAIL, F/INJN FUEL 12614936 HARNESS, F/INJR WRG 12614936 HARNESS, F/INJR WRG 12621095 HARNESS, F/INJR WRG 12621095 HARNESS, F/INJR WRG not found SEAL, F/INJR NOZ HSG (ЧАСТЬ OF 8) (*KIT1) not found INSULATOR, F/INJN FUEL RL CVR (ЧАСТЬ OF 8) (*KIT1) not found RETAINER, F/INJR (BLANK) (ЧАСТЬ OF 8) (*KIT1) 12611545 INJECTOR, DIR FUEL (INCLS 5-7, 10) (ACDelco #12611545) [ИНЖЕКТОР] teamcadillac.ru not found SPACER, F/INJR SEAL (*KIT1) not found SEAL, F/INJN FUEL RL (O RING) (ЧАСТЬ OF 8) (*KIT1) not found CЛАМПА, DIR F/INJR HLDN (*KIT1) 12618798 SEAL KIT, F/INJR (O RING) (INCLS 5-7, 9-11) (W/INJECTOR АРМАТУРА) (3.300) (ACDelco #217-3096) (6D03-083) - 2008-2009 DM69 СИСТЕМА ОТРАБОТАВШИХ ГАЗОВ (LLT/3.6V,LY7/3.6-7) ↓ 15240254 BRACKET, EXH TAIL PIPE HNGR (INCLS 2) [КРОНШТЕЙН] 25902026 BRACKET, EXH TAIL PIPE HNGR (INCLS 2) [ОПОРНАЯ ПЛАНКА ВЫХЛОПНОЙ ТРУБЫ] 15284207 INSULATOR, EXH TAIL PIPE HNGR (ЧАСТЬ OF 1) [ДЕМПФЕР ГЛУШИТЕЛЯ] not found RETAINER, RR BPR IMP BAR RET (PUSH ON) 11516650 ГАЙКА, HEX W/CON WA, M8X1.25, 28 O.D., 7.5 THK, 9, GM7111M. (RR BPR ENGY ABS) [ГАЙКА М8] 25773925 INSULATOR, EXH MUFF HNGR BRKT (ЧАСТЬ OF 9) (3.706) [ПОДВЕСКА ВЫХЛОПНОЙ ТРУБЫ] 25918352 INSULATOR, EXH MUFF HNGR BRKT (ЧАСТЬ OF 9) (WHEN REPLACING MUST REPL BOTH LH&RH FRT MUFF ПЕРЕХОДНИКИ) 24501057 RETAINER, EXH H/SHLD (ЧАСТЬ OF 8) (PUSH-IN) (6.9 HOLE DIA) (19MM LG) (1.840) [ПЛАСТИКОВЫЙ ФИКСАТОР ПОДДОНА] 11570586 RETAINER, EXH H/SHLD (ЧАСТЬ OF 8) (PUSH IN 13 MM HOLE W/ 20 X 36 MM HEAD) 25964069 INSULATOR, EXH H/SHLD (AT INTER FLR PNL) (INCLS 6, 7) [ЗАЩИТНАЯ ПАНЕЛЬ ГЛУШИТЕЛЯ] 25973275 MUFFLER, EXH (W/RESO, EXH & TAIL PIPE) (INCLS 5) [ГЛУШИТЕЛЬ В СБОРЕ] 25973275 MUFFLER, EXH (W/RESO, EXH & TAIL PIPE) (INCLS 5) (3.701) [ГЛУШИТЕЛЬ В СБОРЕ] 25973275 MUFFLER, EXH (W/RESO, EXH & TAIL PIPE) (INCLS 5) (3.701) [ГЛУШИТЕЛЬ В СБОРЕ] 25973276 MUFFLER, EXH (W/RESO, EXH & TAIL PIPE) (INCLS 5) 25973276 MUFFLER, EXH (W/RESO, EXH & TAIL PIPE) (INCLS 5) (3.701) 25973276 MUFFLER, EXH (W/RESO, EXH & TAIL PIPE) (INCLS 5) (3.701) 11516076 ГАЙКА, PREVAILING TORQUE TENSION FLG HD (M8X1.25X17.4 OD (EXH MUFF) [ГАЙКА] 12597449 SENSOR, HTD OXY (POSN 2) (ACDelco #213-3851) [КИСЛОРОДНЫЙ ДАТЧИК] 12597449 SENSOR, HTD OXY (POSN 2) (ДВИГАТЕЛЬ OUT) (ACDelco #213-3851) [КИСЛОРОДНЫЙ ДАТЧИК] 12601266 SENSOR, HTD OXY (POSN 2) (ACDelco #213-4225) [ДАТЧИК] 11570585 ГАЙКА, EXH H/SHLD (ЧАСТЬ OF 13) 25784232 INSULATOR, EXH H/SHLD (INCLS 12) (RWD) (12.980) 25805178 INSULATOR, EXH H/SHLD (INCLS 12) 25964067 INSULATOR, EXH H/SHLD (INCLS 12) [ТЕРМОЗАЩИТНЫЙ ЭКРАН ВЫХЛОПНОЙ ТРУБЫ] 25857958 SEAL, CTLTC CONV (ЧАСТЬ OF 16, 19) (INLET SEAL (W/O SHIELD)) [ПРОКЛАДКА ВЫХЛОПНОЙ ТРУБЫ] 11570494 STUD, CTLTC CONV (ЧАСТЬ OF 16, 19) [ШПИЛЬКА М8] 25971634 CONVERTER, 3WAY CTLTC (INCLS 14, 15, 17, 18) [КАТАЛИТИЧЕСКИЙ НЕЙТРАЛИЗАТОР ВЫХЛОПНЫХ ГАЗОВ] teamcadillac.ru 11569946 STUD-STRAIGHT-M8X1.25X38, M8X1.25X12, W/EXT SOC, 56 OAL, 10.9, GM6164M (ЧАСТЬ OF 16, 19) [ОСЬ] 15879730 SEAL, CTLTC CONV (ЧАСТЬ OF 16, 19) (SPHERICAL OUTLET SEAL) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КАТАЛИТИЧЕСКОГО НЕЙТРАЛИЗАТОРА] 25939989 CONVERTER, 3WAY CTLTC (INCLS 14, 15, 17, 18) [КАТАЛИТИЧЕСКИЙ НЕЙТРАЛИЗАТОР ВЫХЛОПНЫХ ГАЗОВ] 12594935 SENSOR, HTD OXY (POSN 1) (IN EXH MANIFOLD/CROSSOVER) (ACDelco #213-3850) [ДАТЧИК КИСЛОРОДНЫЙ] 15709703 ГАЙКА, HEX 10X1.5THD, 21.8 OD SS (CTLTC CONV) [ГАЙКА М10] (6D03-084) - 2008 DM69 СИСТЕМА ОТРАБОТАВШИХ ГАЗОВ (LP1/2.8T) ↓ 25939989 CONVERTER, 3WAY CTLTC (INCLS 4, 5, 7, 8) [КАТАЛИТИЧЕСКИЙ НЕЙТРАЛИЗАТОР ВЫХЛОПНЫХ ГАЗОВ] teamcadillac.ru 25971634 CONVERTER, 3WAY CTLTC (INCLS 4, 5, 7, 8) [КАТАЛИТИЧЕСКИЙ НЕЙТРАЛИЗАТОР ВЫХЛОПНЫХ ГАЗОВ] 15032594 ГАЙКА, CTLTC CONV (HEX M10X1.5) (ATTACH EXH MANIFOLD PIPE) (3.613) [ГАЙКА 10Х15] 25857958 SEAL, CTLTC CONV (ЧАСТЬ OF 1, 2) (INLET SEAL (W/O SHIELD)) [ПРОКЛАДКА ВЫХЛОПНОЙ ТРУБЫ] 11589264 STUD, STRAIGHT, M10X1.5X30, M10X1.5X16, 57 TL, SS (ЧАСТЬ OF 1, 2) [ШПИЛЬКА М8] 12594935 SENSOR, HTD OXY (POSN 1) (IN EXH MANIFOLD/CROSSOVER) (ACDelco #213-3850) [ДАТЧИК КИСЛОРОДНЫЙ] 11569946 STUD-STRAIGHT-M8X1.25X38, M8X1.25X12, W/EXT SOC, 56 OAL, 10.9, GM6164M (ЧАСТЬ OF 1, 2) [ОСЬ] 15879730 SEAL, CTLTC CONV (ЧАСТЬ OF 1, 2) (SPHERICAL OUTLET SEAL) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КАТАЛИТИЧЕСКОГО НЕЙТРАЛИЗАТОРА] 12597449 SENSOR, HTD OXY (POSN 2) (ACDelco #213-3851) [КИСЛОРОДНЫЙ ДАТЧИК] 12601266 SENSOR, HTD OXY (POSN 2) (ACDelco #213-4225) [ДАТЧИК] 11516076 ГАЙКА, PREVAILING TORQUE TENSION FLG HD (M8X1.25X17.4 OD (EXH MUFF) [ГАЙКА] 25869904 MUFFLER, EXH (W/RESO, EXH & TAIL PIPE) (INCLS 12) [ГЛУШИТЕЛЬ] 25869904 MUFFLER, EXH (W/RESO, EXH & TAIL PIPE) (INCLS 12) (3.701) [ГЛУШИТЕЛЬ] 25869904 MUFFLER, EXH (W/RESO, EXH & TAIL PIPE) (INCLS 12) (3.701) [ГЛУШИТЕЛЬ] 15284207 INSULATOR, EXH TAIL PIPE HNGR (ЧАСТЬ OF 11) [ДЕМПФЕР ГЛУШИТЕЛЯ] 15284207 INSULATOR, EXH TAIL PIPE HNGR (ЧАСТЬ OF 14) [ДЕМПФЕР ГЛУШИТЕЛЯ] 15240254 BRACKET, EXH TAIL PIPE HNGR (INCLS 13) [КРОНШТЕЙН] 25902026 BRACKET, EXH TAIL PIPE HNGR (INCLS 13) [ОПОРНАЯ ПЛАНКА ВЫХЛОПНОЙ ТРУБЫ] 11517397 ГАЙКА, HEX W/CON WA, 8X1.25, 28 O.D., 7.5 THK, 9, PEOR (RR BPR ENGY ABS) (6D03-085) - 2008 DM69 ТОПЛИВНЫЙ БАК & УГОЛЬНЫЙ ФИЛЬТР ↓ 10325852 CAM, FUEL SDR (130 MM OPENING CAM LOCK RING) (3.115) (ACDelco #TR26) [ОПОРНОЕ КОЛЬЦО ТОПЛИВНОГО НАСОСА] 25904038 HARNESS, FUEL SDR WRG (INCLS 33) (3.115) 25904038 HARNESS, FUEL SDR WRG (INCLS 33) 19208373 МОДУЛЬ KIT, F/TNK F/PMP (W/O FUEL LVL SEN) (INCLS 7) (ACDelco #M10138) [ТОПЛИВНЫЙ НАСОС] 19208373 МОДУЛЬ KIT, F/TNK F/PMP (W/O FUEL LVL SEN) (INCLS 7) (3.107) (ACDelco #M10138) [ТОПЛИВНЫЙ НАСОС] 19180436 SENSOR KIT, FUEL LVL (INCLS 7) (ACDelco #SK1277) 19180437 SENDER KIT, FUEL (INCLS 6, 7) (SECONDARY) (ACDelco #19180437) [ДАТЧИК УРОВНЯ ТОПЛИВА ИЛИ ТОПЛИВНЫЙ НАСОС?] not found SENSOR, FUEL LVL (ЧАСТЬ OF 5) 22682111 SEAL, F/PMP (O RING) (ЧАСТЬ OF 3-5) (135.5 MM ID X 147.5MM OD X 6MMTALL) (3.112) (ACDelco #G41) [ПРОКЛАДКА] not found PIPE, F/TNK FIL (СМ. ГРУППУ 03.000 "ШЛАНГИ И ТРУБКИ ТОПЛИВНОГО БАКА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11610236 CЛАМПА, TYPE F WORM GEAR 20-1/4 HEX HD SAE 302 STL GM3044 9 (ЧАСТЬ OF 10) 15925742 HOSE, F/TNK FIL (INCLS 9) 25711370 CЛАМПА, F/TNK FIL HOSE (30-45MM CЛАМПА RANGE) not found PIPE, AUX F/TNK FIL EXTN (ЧАСТЬ OF 15) not found PIPE, F/TNK VENT (ЧАСТЬ OF 15) not found PIPE, F/TNK VENT VLV (ЧАСТЬ OF 15) 25904036 TANK, FUEL (INCLS 12-14, 17) [ТОПЛИВНЫЙ БАК] 15801795 SHIELD, F/TNK [ЗАЩИТНАЯ ПАНЕЛЬ ТОПЛИВНОГО БАКА] 25679213 PIN, F/TNK UPR SHLD (ЧАСТЬ OF 15) 12522916 RETAINER KIT, FUEL FEED PIPE FTG (ЧАСТЬ OF 19) (BLUE) (INCLS INST SHT & RET) (USE WITH 5/16 TUBE, NYLON) [ЗАЖИМ ФИКСИРУЮЩИЙ, ТОПЛИВНОЙ ТРУБКИ] 15801032 PIPE, EVAP EMIS CNSTR PURGE (INCLS 18) (FRONT LINE) 25679252 RETAINER, FUEL FEED & EVAP EMIS & RTN FRT PIPE (HOLDS 15.8/7.95/7.0 TUBES, HAS CHRISTMAS TREE RETAINER) (3.162) 25679252 RETAINER, FUEL FEED & EVAP EMIS & RTN FRT PIPE (HOLDS 15.8/7.95/7.0 TUBES, HAS CHRISTMAS TREE RETAINER) 15943350 PIPE, FUEL SDR FUEL FEED [ТРУБКА ТОПЛИВНОЙ СИСТЕМЫ] not found COVER, EVAP EMIS CNSTR AIR INL OPG (*KIT1) teamcadillac.ru not found SEAL, EVAP EMIS CNSTR AIR INL OPG CVR (*KIT1) not found ФИЛЬТР, EVAP EMIS CNSTR AIR INL (*KIT1) 19177356 CANISTER, EVAP EMIS (ACDelco #215-645) [ТОПЛИВОИСПАРИТЕЛЬНЫЙ БАК] 25932573 VALVE, EVAP EMIS CNSTR VENT SOL (ACDelco #214-2230) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] not found RETAINER, EVAP EMIS CNSTR 16238399 SENSOR, F/TNK PRESS (ACDelco #16238399) [ДАТЧИК ДАВЛЕНИЯ ПАРОВ ТОПЛИВА] not found PIPE, BRK & FUEL FEED & EVAP EMIS (СМ. ГРУППУ 03.000 "СИСТЕМА ТОПЛИВОСНАБЖЕНИЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 21992746 RETAINER, FUEL FEED HOSE CONN (ЧАСТЬ OF 31) (5/8 INCH QUICK CONNECT RETAINER CLIP) 21992748 RETAINER, FUEL FEED HOSE CONN (ЧАСТЬ OF 31) (5/16 INCH QUICK CONNECT RETAINER CLIP) 25904037 PIPE, FUEL FEED RR (INCLS 30, 32) not found LABEL, FUEL FEED PIPE WRNG (ЧАСТЬ OF 31) 12186353 RETAINER, WHL SPD SEN WRG HARN CONN (ЧАСТЬ OF 2) (BLACK) (7.00/6.25 DIA, SLIDING) 19177364 FILTER KIT, EVAP EMIS CNSTR (W/ SEAL) (INCLS 22-24) (ACDelco #215-656) (6D03-090) - 2008 DM69 БЛОК ЭЛЕКТРОННОГО УПРАВЛЕНИЯ И СВЯЗАННЫЕ ДЕТАЛИ ↓ not found HARNESS, ENG WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 12623325 МОДУЛЬ, ENG CONT (W/O CALN) (ACDelco #12623325) 12623327 МОДУЛЬ, ENG CONT (W/O CALN) teamcadillac.ru 15285488 BRACKET, ECM 15285490 BRACKET, ECM (6M03-088) - 2008-2009 DM69 РАМКА ТОПЛИВНОГО ИНЖЕКТОРА (LP1/2.8T,LY7/3.6-7) ↓ 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (WRG HARN BRKT) not found BRACKET, F/INJR WRG HARN (ЧАСТЬ OF 3) 12596182 HARNESS, F/INJR WRG (INCLS 2) (IF REPL 12584312 MAY NEED TO INSTALL BRACKET FROM HARNESS.) 12596182 HARNESS, F/INJR WRG (INCLS 2) (IF REPL 12584312 MAY NEED TO INSTALL BRACKET FROM HARNESS.) 25532662 CAP, FUEL PRESS SERV VLV (CAP FOR PRESSURE TEST SCHRADER VALVE) (*KIT2) (3.163) (ACDelco #214-1044) [КРЫШКА] 25532662 CAP, FUEL PRESS SERV VLV (CAP FOR PRESSURE TEST SCHRADER VALVE) (*KIT2) (3.163) (ACDelco #214-1044) [КРЫШКА] 25532662 CAP, FUEL PRESS SERV VLV (CAP FOR PRESSURE TEST SCHRADER VALVE) (*KIT2) (3.163) (ACDelco #214-1044) [КРЫШКА] 25532662 CAP, FUEL PRESS SERV VLV (CAP FOR PRESSURE TEST SCHRADER VALVE) (*KIT2) (3.163) (ACDelco #214-1044) [КРЫШКА] 25532662 CAP, FUEL PRESS SERV VLV (CAP FOR PRESSURE TEST SCHRADER VALVE) (*KIT2) (3.163) (ACDelco #214-1044) [КРЫШКА] 25532662 CAP, FUEL PRESS SERV VLV (CAP FOR PRESSURE TEST SCHRADER VALVE) (*KIT2) (3.163) (ACDelco #214-1044) [КРЫШКА] 25532662 CAP, FUEL PRESS SERV VLV (CAP FOR PRESSURE TEST SCHRADER VALVE) (*KIT2) (3.163) (ACDelco #214-1044) [КРЫШКА] teamcadillac.ru not found VALVE, FUEL PRESS SERV (ЧАСТЬ OF 6) (*KIT2) 12572886 RAIL, F/INJN FUEL (INCLS 5, 9) (ACDelco #217-1551) [МАГИСТРАЛЬ ТОПЛИВНЫХ ФОРСУНОК ДВИГАТЕЛЯ] 12572886 RAIL, F/INJN FUEL (INCLS 5, 9) (ACDelco #217-1551) [МАГИСТРАЛЬ ТОПЛИВНЫХ ФОРСУНОК ДВИГАТЕЛЯ] 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (F/INJN FUEL RL) [БОЛТ] not found SEAL, F/INJR (O RING) (UPPER) (ЧАСТЬ OF 10) (*KIT1) not found CLIP, F/INJN FUEL RL (ЧАСТЬ OF 6) (*KIT3) 12609417 INJECTOR, M/PORT FUEL (INCLS 8, 11) (ACDelco #217-3033) [ТОПЛИВНАЯ ФОРСУНКА] 12609418 INJECTOR, M/PORT FUEL (INCLS 8, 11) (ACDelco #217-3034) not found SEAL, F/INJN FUEL RL (O RING) (LOWER) (ЧАСТЬ OF 10) (*KIT1) 12597872 SEAL KIT, F/INJR (O RING) (INCLS 8, 11) (ACDelco #217-2444) 12597872 SEAL KIT, F/INJR (O RING) (INCLS 8, 11) (ACDelco #217-2444) 12584592 VALVE KIT, FUEL PRESS SERV (INCLS 4, 5) (INCLUDES CAP AND VALVE) (ACDelco #12584592) [КЛАПАН] 12584591 RETAINER KIT, F/INJR (INCLS 9) (ACDelco #12584591) [ОПОРНАЯ ПЛАСТИНА ТОПЛИВНОЙ ФОРСУНКИ] 12584591 RETAINER KIT, F/INJR (INCLS 9) (ACDelco #12584591) [ОПОРНАЯ ПЛАСТИНА ТОПЛИВНОЙ ФОРСУНКИ] 04 - 6-ТИ СКОРОСТНАЯ МКПП (6D00-054) - 2008 DM69 ТРАНСМИССИЯ TO КРЕПЛЕНИЕ ДВИГАТЕЛЯ (AUTOMATIC MYB) ↓ 12603197 PLATE, A/TRNS FLEX 12603197 PLATE, A/TRNS FLEX 12603197 PLATE, A/TRNS FLEX 12597210 PIN, TRANS LOC 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] 24242043 БОЛТ, TRANS CONV CVR (M6X1X18/M6X1X14) 24222918 COVER, TRANS CONV 24222918 COVER, TRANS (0.679) 24205900 COVER, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] teamcadillac.ru 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] (6D04-030) - 2008 DM69 ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР ↓ 18012741 SWITCH, BRK FLUID LVL IND (*KIT1) (ACDelco #18012741) 22688449 CAP, BRK M/CYL RSVR (INCLS 3) (*KIT1) [КРЫШКА БАЧКА ТОРМОЗНОЙ ЖИДКОСТИ] not found DIAPHRAGM, BRK M/CYL RSVR (ЧАСТЬ OF 2) (*KIT1) teamcadillac.ru not found PIN, BRK M/CYL RSVR (ЧАСТЬ OF 5) (*KIT1) 18046711 RESERVOIR, BRK M/CYL (INCLS 4, 6, 7) (*KIT1) (ACDelco #18046711) not found SEAL, BRK M/CYL RSVR (ЧАСТЬ OF 5) (*KIT1) not found SEAL, BRK M/CYL RSVR (ЧАСТЬ OF 5) (*KIT1) not found RETAINER, BRK M/CYL PRIM PSTN SPR (*KIT1) not found PISTON, BRK M/CYL PRIM (*KIT1) not found SEAL, BRK M/CYL SECD PSTN PRIM (*KIT1) not found RETAINER, BRK M/CYL SECD PSTN SPR (*KIT1) not found SEAL, BRK M/CYL (*KIT1) not found PISTON, BRK M/CYL SECD (*KIT1) not found ПРУЖИНА, BRK M/CYL SECD PSTN (*KIT1) not found BODY, BRK M/CYL (*KIT1) 15267509 CYLINDER, BRK MAS (INCLS 1-15) [БЛОК ЦИЛИНДРОВ] (6D04-033) - 2008 DM69 ТОРМОЗНОЙ УСИЛИТЕЛЬ ↓ 15267511 BOOSTER, P/B (INCLS 2-5) [ГИДРОУСИЛИТЕЛЬ ТОРМОЗНОЙ СИСТЕМЫ] teamcadillac.ru not found GROMMET, P/B BOOS VAC CHK VLV (ЧАСТЬ OF 1, 3) 18022219 VALVE KIT, P/B BOOS VAC CHK (ЧАСТЬ OF 1) (INCLS 2) (BLACK) (INCLS VLV & GROM) (ACDelco #179-1266) 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 1) (0.80 IN) (PUSH IN) 15849743 ROD, BRK PED PUSH (ЧАСТЬ OF 1) (6D04-047) - 2008 DM69 ТОРМОЗНАЯ ПЕДАЛЬ ↓ not found REINFORCEMENT, STRG COL SUPT BRKT 25785092 BARRIER, BRK PED BRKT SND 25913292 BARRIER, BRK PED BRKT SND not found BRACKET, BRK PED (ЧАСТЬ OF 13) not found ГАЙКА, BRK PED BRKT BR (ЧАСТЬ OF 13) 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (ЧАСТЬ OF 13) (ACDelco #11517518) [БОЛТ] teamcadillac.ru 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] not found STUD, BRK PED BRKT (ЧАСТЬ OF 13) not found BRACKET, BRK PED (ЧАСТЬ OF 13) 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 13) (0.80 IN) (PUSH IN) 15849743 ROD, BRK PED PUSH (ЧАСТЬ OF 13) 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 13) 25771615 COVER, BRK PED (ЧАСТЬ OF 13) 15254562 PEDAL, BRK (W/BRKT) (INCLS 3-5, 7-12, 14-19) 15254563 PEDAL, BRK (W/BRKT) (INCLS 3-5, 7-12, 14-19) 25814705 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 13) (INCLS 19) [ДАТЧИК] not found PIN, BRK PED PUSH ROD (ЧАСТЬ OF 13) not found PIN, BRK PED PIV (ЧАСТЬ OF 13) 15594358 BUSHING, BRK PED PIV (ЧАСТЬ OF 13) (0.831) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 13) 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 13, 14) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] (6D04-053) - 2008-2010 DM69 6-ТИ СКОРОСТНАЯ МКПП ЧАСТЬ 1 (MV7) ASM ↓ 24242917 ТРАНСМИССИЯ, MAN [ТРАНСМИССИЯ] (6D04-054) - 2008-2010 DM69 6-ТИ СКОРОСТНАЯ МКПП ЧАСТЬ 2 (MV7) CASE COMPONENTS ↓ 89058852 БОЛТ, CLU ACTR (M6X1.0X20) 89048559 БОЛТ, CLU ACTR (M8X1.25X20) (4.104) 89058759 CASE, TRANS INTER (INCLS 8, 9) 89058774 BEARING, SHFT CONT SHF (ЧАСТЬ OF 7) (4.408) 89058791 PIN, TRANS INTER CASE LOC (ЧАСТЬ OF 7) 19178542 CASE, TRANS FRT (INCLS 12-16) 89058833 SEAL, MAIN SHF (ЧАСТЬ OF 11) not found SHIELD, INPUT SHF BRG OIL (ЧАСТЬ OF 11) 89058791 PIN, TRANS INTER CASE LOC (ЧАСТЬ OF 11) 89059311 PIN, TRANS CASE LOC (ЧАСТЬ OF 11) 89059312 PLUG, TRANS CASE HOLE (ЧАСТЬ OF 11) teamcadillac.ru not found TROUGH, TRANS RR CASE OIL 89058837 SLINGER, INPUT SHF BRG OIL 89058839 TROUGH, M/TRNS OIL 89058840 TROUGH, TRANS INTER CASE OIL not found RETAINER, CNTR GR BRG 89058820 RETAINER, CNTR GR BRG (4.352) 89058760 CASE, TRANS RR (INCLS 24-26) not found BUSHING, SHFT SHF (ЧАСТЬ OF 23) 89058774 BEARING, SHFT SHF (ЧАСТЬ OF 23) 89058791 PIN, TRANS INTER CASE LOC (ЧАСТЬ OF 23) 89058853 БОЛТ, TRANS INTER CASE (M10X1.25X40) (4.104) 89058854 БОЛТ, TRANS INTER CASE (M10X1.25X80) (4.104) 89059319 GASKET, TRANS RR CASE 89058843 PLUG, CLU HSG HOLE 89059313 VENT, M/TRNS 89059314 SEAL, REV IDLER GR SHF (O RING) (ACDelco #89059314) 89048245 GASKET, TRANS OIL DRN PLUG (ACDelco #89048245) 19132842 PLUG, TRANS OIL DRN (4.510) 89059315 БОЛТ, REV IDLER GR SHF RET 19132971 PLUG, SHFT SHF DTNT 89048559 БОЛТ, TRANS INTER CASE OIL TROUGH (M8X1.25X20) (4.104) 89058855 БОЛТ, CNTR GR BRG RET (M8X1.25X25) 89058860 DETENT, SHFT SHF 89059329 DETENT, SHFT SHF (CAM) 19178544 ПРУЖИНА, SHFT SHF DTNT 89048248 PLUG, TRANS OIL FIL 89048248 PLUG, TRANS OIL FIL (4.104) 19178541 EXTENSION, TRANS (INCLS 87, 88) 89058838 SLINGER, INPUT SHF BRG OIL (ЗАДНИЙ) (ЧАСТЬ OF 86) 19180996 SEAL, SHFT CONT SHF (ЧАСТЬ OF 86) 89058835 SEAL, RR ВЫХОДНОЙ SHF 88972750 БОЛТ, TRANS EXTN (M8X1.25X40) (8.900) 19178540 FLANGE, TRANS PROP SHF 19132973 ГАЙКА, PROP SHF TRANS FLG 89058775 BEARING, REV IDLER GR 89058836 SEAL, PROP SHF TRANS FLG FLUID 89058790 SHAFT, REV IDLER GR 89058789 GEAR, REV IDLER 89059321 SWITCH, B/U LP (ACDelco #D2271C) 89059318 RETAINER, B/U LP SW 89058851 SENSOR, M/TRNS ВЫХОДНОЙ SPD (4.337) 89058851 SENSOR, M/TRNS ВЫХОДНОЙ SPD 89058852 БОЛТ, VEH SPD SEN (M6X1.0X20) (0.780) 89058852 БОЛТ, VEH SPD SEN (M6X1.0X20) (0.780) 24242161 CYLINDER, CLU ACTR [ЦИЛИНДР] 89048245 GASKET, TRANS OIL FILL PLUG (ACDelco #89048245) (6D04-055) - 2008-2010 DM69 6-ТИ СКОРОСТНАЯ МКПП ЧАСТЬ 3 (MV7) ВХОДНОЙ И ВЫХОНОЙ ВАЛ COMPONENTS ↓ 89058782 BEARING, RR ВЫХОДНОЙ MAIN SHF RR 89058801 RING, 3RD GR BLOCKING 89058812 SLINGER, MAIN SHF BRG OIL (4.345) 19178534 SHAFT, RR MAIN 19132975 WASHER, 3RD GR THR 89058805 HUB, 3RD & 4TH GR SYN 19132845 SLEEVE, 3RD & 4TH GR SYN 19178535 INSERT, 3RD & 4TH GR SYN 89058792 RING, 4TH GR BLOCKING 19132849 ПРУЖИНА, 3RD & 4TH GR SYN 89058806 HUB, 5TH & 6TH GR SYN 89058810 BALL, 3RD & 4TH GR SYN DTNT 89058776 BEARING, INPUT SHF (RADIAL BALL) 89058777 BEARING, 4TH GR 89058779 BEARING, 6TH GR 89058778 BEARING, 3RD GR 89058780 BEARING, INPUT SHF (ROLLER) (ROLLER) 89058781 BEARING, RR ВЫХОДНОЙ SHF FRT 89059345 RING KIT, 3RD & 4TH GR RET 89059346 RING KIT, 5TH & 6TH GR SYN RET 89059347 RING KIT, 6TH GR RET 89059348 RING KIT, INPUT SHF BRG RET 89058813 RING, INPUT SHF BRG RET 89058863 SPACER, 6TH GR BRG 89058861 SPACER, 3RD & 4TH GR 89058864 SPACER, RR MAIN SHF RR BRG 89048344 PIN, GR THR WA LOC (4.419) 19178537 GEAR, 3RD 19178538 GEAR, 4TH 19178536 GEAR, 6TH teamcadillac.ru 19178539 SHAFT, INPUT 89058773 GEAR, VEH SPD SEN DRV 89048423 BALL, SPEEDO DRV GR LOC 89058810 BALL, 5TH GR SYN DTNT 19178535 INSERT, 5TH & 6TH GR SYN not found ПРУЖИНА, 5TH & 6TH GR SYN 19132849 ПРУЖИНА, 5TH & 6TH GR SYN 19132845 SLEEVE, 5TH & 6TH GR SYN 89058792 RING, 6TH GR BLOCKING (4.383) 89058792 RING, 5TH GR BLOCKING (6D04-056) - 2008-2010 DM69 6-ТИ СКОРОСТНАЯ МКПП ЧАСТЬ 4 (MV7) COUNTERSHAFT COMPONENTS ↓ 89058794 RING SET, 1ST GR BLOCKING (INCLS 96-98) not found CONE, 1ST GR SYN INR (ЧАСТЬ OF 95) not found CONE, 1ST GR SYN OTR (ЧАСТЬ OF 95) not found RING, 1ST GR OTR BLOCKING (ЧАСТЬ OF 95) 89058786 GEAR, REV GR DRV 89058865 BUSHING, REV GR BRG 89058807 HUB, 1ST & 2ND GR SYN 89058803 SLEEVE, 1ST & 2ND GR SYN 89058808 INSERT, 1ST & 2ND GR SYN 89058809 INSERT, REV GR SYN 89058793 RING, REV GR BLOCKING 89058811 ПРУЖИНА, 1ST & 2ND GR SYN 89058804 SLEEVE, REV GR SYN 89058810 BALL, 1ST & 2ND GR SYN DTNT 89058783 BEARING, CNTR GR FRT 89058785 BEARING, REV GR 89058787 BEARING, 1ST GR 89058788 BEARING, 2ND GR 89058784 BEARING, CNTR GR RR 89059343 RING, CNTR GR FRT BRG RET not found RING KIT, 1ST & 2ND GR SYN HUB RET 89059344 RING KIT, 1ST & 2ND GR SYN HUB RET 89058822 RETAINER, CNTR GR FRT BRG 89048423 BALL, REV GR THR WA LOC (4.345) 89048329 ПРУЖИНА, REV GR SYN (4.384) 89058770 GEAR, 1ST 19178532 GEAR, 2ND 19178533 GEAR, CNTR 89058769 GEAR, REV 89058794 RING SET, 2ND GR BLOCKING (INCLS 905-907) not found RING, 2ND GR OTR BLOCKING (ЧАСТЬ OF 904) not found CONE, 2ND GR SYN OTR (ЧАСТЬ OF 904) not found CONE, 2ND GR SYN INR (ЧАСТЬ OF 904) teamcadillac.ru 89059343 RING, CNTR GR FRT BRG RET (6D04-057) - 2008-2010 DM69 6-ТИ СКОРОСТНАЯ МКПП ЧАСТЬ 5 (MV7) SHIFT FORKS ↓ 19180997 JOINT, M/TRNS SHFT LVR ROD UNIVERSAL 19180067 PIN, M/TRNS SHFT LVR not found RETAINER, M/TRNS SEL SHF LVR ROD GROM 89059340 BRACKET, SHFT CONT LVR 89059331 CAM, SHFT SHF DTNT 89058762 FORK, 1ST & 2ND SHFT (INCLS BUSHINGS) 89058763 FORK, 3RD & 4TH SHFT (INCLS INSERTS) 89059342 ARM, CONT SEL 89058825 PIN, CONT SEL ARM 89058764 FORK, 5TH & 6TH SHFT (INCLS INSERTS) 89059332 LEVER, SHFT 19132858 LEVER, INTL SHFT CONT 19132857 LEVER, SEL CONT 89058830 SHAFT, 1ST & 2ND SHFT 89059333 SHAFT, 3RD & 4TH SHFT 89059335 SHAFT, 5TH & 6TH SHFT 19132859 SHAFT, REV SHFT teamcadillac.ru 89058832 LEVER, SHFT SHF DTNT 89058765 FORK, REV SHFT (INCLS INSERTS) 89058829 SHAFT, SHFT CONT 89059329 DETENT, SHFT SHF (CAM) (CAM) 89048287 БОЛТ, 3RD & 4TH SHFT FORK 89048272 PIN, SEL CONT LVR (4.008) 89048289 PIN, REV SHFT FORK (4.303) 89059339 ROLLER, SHFT SHF DTNT 19178531 ПРУЖИНА, SHFT DTNT BALL 19178544 ПРУЖИНА, SHFT SHF DTNT 89058857 БОЛТ, SHFT SHF DTNT LVR (M8X1.0X21.2) 89059338 PIN, SHFT SHF INTLK (M4X11.2) 89059337 PIN, SHFT SHF INTLK (M6X13.6) 89048292 BALL, SHFT DTNT 89058858 БОЛТ, SHFT CONT LVR BRKT (M8X1.25X32) 89058824 RETAINER, SEL CONT LVR PIN 89059316 PIN, SHFT SHF (4.408) 89058842 WEIGHT, SHFT LVR C/BAL (EXTERNAL) (4.105) 89059320 BLOCK, SHFT CONT SHF 89048272 PIN, SHFT LVR (4.008) 89048272 PIN, 1ST & 2ND SHFT FORK (4.008) 89048287 БОЛТ, 5TH & 6TH SHFT FORK (6D04-063) - 2008-2009 DM69 КОРПУС КП КРЕПЛЕНИЕ (ПОЛНОПРИВОДНЫЙ MX7) ↓ 24231525 GASKET, TRFER CASE 24249544 CASE, TRFER (W/GEARS) 11589341 БОЛТ - HFH, M10X1.5X69.9, 28.35 THD, 22.3 OD, 10.9, GMW3359, M-PT. (TRFER CASE) [БОЛТ] teamcadillac.ru 19179016 DAMPENER, TRFER CASE VIB (AT RR OF CASE) (6D04-072) - 2008-2009 DM69 ТОРМОЗНЫЕ МАГИСТРАЛИ-ПЕРЕДНИЕ (ЗАДНИЙ КОЛЕСО DRIVE MN6,MX0) ↓ 15904905 PIPE, BRK PRESS MOD VLV FRT [ТРУБКА ТОРМОЗНОЙ СИСТЕМЫ] 15904915 SPACER, FRT BRK PIPE not found CYLINDER, BRK MAS (СМ. ГРУППУ 04.000 "ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 15904908 PIPE, BRK PRESS MOD VLV RR [НАСОС В СБОРЕ] not found БОЛТ, FRT BRK HOSE (ЧАСТЬ OF 8, 20) 21012386 WASHER, FRT BRK HOSE (ЧАСТЬ OF 8, 20) (10.3X14.5X1.61) (COPPER) (ACDelco #21012386) [ШАЙБА 10 ММ] 11516546 БОЛТ, HFL, M8X1.25X50, 37.2 THD, 18 OD, 10.9, PZO 7114M (FRT S/ABS) 15818105 HOSE, FRT BRK (INCLS 5, 6, 9, 10) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ] 11569742 RETAINER, FRT BRK HOSE (ЧАСТЬ OF 8, 20) (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] not found BRACKET, FRT BRK HOSE (ЧАСТЬ OF 8) 11514623 БОЛТ, HEX W/CON WA, M6X1X20 (FRT BRK HOSE) 11569751 ГАЙКА, HX TUBE INVERTED FLARE, M10X1X16, SAE1010, GMW4707M (FRT BRK PIPE) [ШАЙБА] 88983905 PIPE, BRK (3/16" X 16 FT) (BULK TUBING) (NYLON COATING) [ТРУБКА ТОРМОЗНОЙ СИСТЕМЫ] 25957289 RETAINER, FRT BRK PIPE (4 TUBE W/TREE) 15904901 RETAINER, FRT BRK PIPE (STAR SHAPED 3 TUBE W/TREE) [КРОНШТЕЙН] teamcadillac.ru 12477665 PROTECTOR, FRT BRK PIPE (FOR 1/4" PIPE) (HT SHRINK) not found VALVE, BRK PRESS MOD (W/ELEK BRK & TRACT CONT MDL) (СМ. ГРУППУ 04.000 "КЛАПАН РЕГУЛИРОВКИ ДАВЛЕНИЯ В ТОРМОЗНОЙ СИСТЕМЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11569750 ГАЙКА, HX FLARED TUBE, M12X1.0X17, 5.3 TUBE, SAE1010, GMW4707M (FRT BRK PIPE) [ФИТИНГ ТРУБКИ ТОРМОЗНОЙ СИСТЕМЫ] not found BRACKET, FRT BRK HOSE (ЧАСТЬ OF 20) 15818106 HOSE, FRT BRK (INCLS 5, 6, 9, 19) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ] (6D04-073) - 2008-2009 DM69 ТОРМОЗНЫЕ МАГИСТРАЛИ-ПЕРЕДНИЕ (ПОЛНОПРИВОДНЫЙ MX7) ↓ 15904910 PIPE, BRK PRESS MOD VLV RR [ТРУБКА] 15904915 SPACER, FRT BRK PIPE not found CYLINDER, BRK MAS (СМ. ГРУППУ 04.000 "ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 15904907 PIPE, BRK PRESS MOD VLV FRT [НАСОС В СБОРЕ] 11570052 FITTING, FRT BRK HOSE (ЧАСТЬ OF 7) (M10X1X27.5, 16.9THD) (4.671) 21012386 WASHER, FRT BRK HOSE (ЧАСТЬ OF 7) (10.3X14.5X1.61) (COPPER) (ACDelco #21012386) [ШАЙБА 10 ММ] 25928987 HOSE, FRT BRK (INCLS 5, 6) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ] 25928988 HOSE, FRT BRK (INCLS 5, 6) 11516521 БОЛТ, HFH M6X1X20, 9.8, 7114M, DOG PT, 14.2 OD (FRT BRK HOSE) 11569742 RETAINER, FRT BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 11569751 ГАЙКА, HX TUBE INVERTED FLARE, M10X1X16, SAE1010, GMW4707M (FRT BRK PIPE) [ШАЙБА] 88983905 PIPE, BRK (3/16" X 16 FT) (BULK TUBING) (NYLON COATING) [ТРУБКА ТОРМОЗНОЙ СИСТЕМЫ] 15904902 RETAINER, FRT BRK PIPE (UPSIDE DOWN 3 TUBE CLIP W/O TREE) [КРОНШТЕЙН] 15904903 RETAINER, FRT BRK PIPE (UPSIDE DOWN 3 TUBE WITH TREE) [КРОНШТЕЙН] 12477665 PROTECTOR, FRT BRK PIPE (FOR 1/4" PIPE) (HT SHRINK) 88964150 PROTECTOR, FRT BRK PIPE (FOR 3/16" PIPE) (HT SHRINK) 15904901 RETAINER, FRT BRK PIPE (STAR SHAPED 3 TUBE W/TREE) [КРОНШТЕЙН] not found VALVE, BRK PRESS MOD (W/ELEK BRK & TRACT CONT MDL) (СМ. ГРУППУ 04.000 "КЛАПАН РЕГУЛИРОВКИ ДАВЛЕНИЯ В ТОРМОЗНОЙ СИСТЕМЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11569750 ГАЙКА, HX FLARED TUBE, M12X1.0X17, 5.3 TUBE, SAE1010, GMW4707M (FRT BRK PIPE) [ФИТИНГ ТРУБКИ ТОРМОЗНОЙ СИСТЕМЫ] (6D04-074) - 2008 DM69 ТОРМОЗНЫЕ МАГИСТРАЛИ-ЗАДНИЕ ↓ 15818185 HOSE, RR BRK (INCLS 2, 3, 5, 6) [ТРУБКА] 21012386 WASHER, RR BRK HOSE (ЧАСТЬ OF 1, 12) (10.3X14.5X1.61) (COPPER) (ACDelco #21012386) [ШАЙБА 10 ММ] not found БОЛТ, RR BRK HOSE (ЧАСТЬ OF 1, 12) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (RR BRK HOSE BRKT) [ГАЙКА М6] not found BRACKET, RR BRK HOSE (ЧАСТЬ OF 1) 11569742 RETAINER, RR BRK HOSE (ЧАСТЬ OF 1) (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 11569742 RETAINER, RR BRK HOSE (ЧАСТЬ OF 1) (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 11569751 ГАЙКА, HX TUBE INVERTED FLARE, M10X1X16, SAE1010, GMW4707M (RR BRK PIPE) [ШАЙБА] 88983905 PIPE, BRK (3/16" X 16 FT) (BULK TUBING) (NYLON COATING) [ТРУБКА ТОРМОЗНОЙ СИСТЕМЫ] 15194329 CLIP, RR BRK PIPE (27X35X15) 88964150 PROTECTOR, FRT BRK PIPE (FOR 3/16" PIPE) (HT SHRINK) 15818187 HOSE, RR BRK (INCLS 2, 3) [ТРУБКА] 25607191 RETAINER, BRK PIPE (21.5X10.0MM) (HOLDS (2) 4.68-4.82 TUBES) 25607191 RETAINER, BRK PIPE (21.5X10.0MM) (HOLDS (2) 4.68-4.82 TUBES) teamcadillac.ru 15870391 RETAINER, BRK & FUEL PIPE (HOLDS FOUR LINES) 15870391 RETAINER, BRK & FUEL PIPE (HOLDS FOUR LINES) (3.162) 11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (FUEL FLTR BRKT) [БОЛТ М8] 15223307 RETAINER, BRK & FUEL PIPE (2 FUEL/VAPOR LINES) 15223307 RETAINER, BRK & FUEL PIPE (2 FUEL/VAPOR LINES) (3.162) 15223304 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (HOLDS FOUR LINES) (3.890) 15223306 RETAINER, BRK & FUEL PIPE (2 FUEL/VAPORS LINE & 2 BRAKE LINES) 15223306 RETAINER, BRK & FUEL PIPE (2 FUEL/VAPORS LINE & 2 BRAKE LINES) (3.162) 88964150 PROTECTOR, BRK PIPE (FOR 3/16" PIPE) (HT SHRINK) 15223308 RETAINER, BRK & FUEL PIPE (ATTACHES TO BRKT) 15223308 RETAINER, BRK & FUEL PIPE (ATTACHES TO BRKT) (3.162) 25761218 BRACKET, FUEL PIPE 11514623 БОЛТ, HEX W/CON WA, M6X1X20 (FUEL FEED & EVAP EMIS & RTN PIPE CLIP BRKT) 25957289 RETAINER, FRT BRK PIPE (4 TUBE W/TREE) 11569750 ГАЙКА, HX FLARED TUBE, M12X1.0X17, 5.3 TUBE, SAE1010, GMW4707M (FRT BRK PIPE) [ФИТИНГ ТРУБКИ ТОРМОЗНОЙ СИСТЕМЫ] not found VALVE, BRK PRESS MOD (W/ELEK BRK & TRACT CONT MDL) (СМ. ГРУППУ 04.000 "КЛАПАН РЕГУЛИРОВКИ ДАВЛЕНИЯ В ТОРМОЗНОЙ СИСТЕМЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6D04-076) - 2008-2009 DM69 СТОЯНОЧНЫЙ ТОРМОЗ SYSTEM ↓ 15836531 REINFORCEMENT, PARK BRK LVR BRKT (INCLS 2) 11610157 ГАЙКА, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (ЧАСТЬ OF 1) (10.701) [ГАЙКА М4] 25880964 HANDLE, PARK BRK REL 11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (PARK BRK REL HDL) [ВИНТ] 25791543 CABLE, PARK BRK REL (ЧАСТЬ OF 6) 25885037 LEVER, PARK BRK (INCLS 5, 7-9) not found PAD, PARK BRK LVR PED (ЧАСТЬ OF 6) 10369646 БОЛТ, PARK BRK IND SW (ЧАСТЬ OF 6) 22654577 SWITCH, PARK BRK IND (ЧАСТЬ OF 6) (ACDelco #22654577) [ВКЛЮЧАТЕЛЬ] 15242114 CABLE, PARK BRK INTER (INCLS 14) [КАБЕЛЬ] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (PARK BRK INTER CBL GDE) [ГАЙКА М6] 11518625 БОЛТ, PAN, M10X1.5X35, 33.5THD, 20 O.D., 10.9, 6138M (PARK BRK INTER CBL GDE) teamcadillac.ru 20774147 CABLE, PARK BRK RR 20823796 CONNECTOR, PARK BRK CBL (ЧАСТЬ OF 10) 11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (I/P LWR BRKT) [ВИНТ] 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (PARK BRK REL HDL BRKT) [ВИНТ М4] (6D04-077) - 2008-2009 DM69 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (MYB, ПОЛНОПРИВОДНЫЙ MX7, EXC EXTRA CAPACITY V03, HEAVY DUTY V08) ↓ 24237658 SEAL, TRANS FLUID CLR PIPE FTG (SEALS ONE PIPE) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ] 15251488 SEAL, TRANS FLUID CLR HOSE (ЧАСТЬ OF 4) (SEALS TWO ТРУБКИ) [УПЛОТНЕНИЕ] 11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) [БОЛТ, М8Х1.25Х31.5] 15853683 HOSE, TRANS FLUID CLR (INCLS 2, 6, 7, 10) [ТРУБКА] 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] teamcadillac.ru 10405874 CLIP, TRANS FLUID CLR HOSE (ЧАСТЬ OF 4) (LESS MNTG TAB) (HOLDS TWO 9.5 DIA TUBES) 15052228 CЛАМПА, TRANS FLUID CLR HOSE (ЧАСТЬ OF 4) (PLASTIC RETAINER) (ACDelco #15052228) [ФИТИНГ ТРУБОПРОВОДА] not found FITTING, TRANS FLUID CLR PIPE not found RETAINER, TRANS FLUID CLR PIPE FTG not found BRACKET, TRANS OIL CLR INL & OTLT PIPE (ЧАСТЬ OF 4) (6D04-078) - 2008 DM69 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (MYB, ЗАДНИЙ КОЛЕСО DRIVE MX0, EXC EXTRA CAPACITY V03, HEAVY DUTY V08) ↓ 24237658 SEAL, TRANS FLUID CLR PIPE FTG (SEALS ONE PIPE) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ] 15251488 SEAL, TRANS FLUID CLR HOSE (ЧАСТЬ OF 3) (SEALS TWO ТРУБКИ) [УПЛОТНЕНИЕ] teamcadillac.ru 15267714 HOSE, TRANS FLUID CLR (INCLS 2, 5, 6, 9) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) [БОЛТ, М8Х1.25Х31.5] 10405874 CLIP, TRANS FLUID CLR HOSE (ЧАСТЬ OF 3) (LESS MNTG TAB) (HOLDS TWO 9.5 DIA TUBES) 15052228 CЛАМПА, TRANS FLUID CLR HOSE (ЧАСТЬ OF 3) (PLASTIC RETAINER) (ACDelco #15052228) [ФИТИНГ ТРУБОПРОВОДА] not found FITTING, TRANS FLUID CLR PIPE not found RETAINER, TRANS FLUID CLR PIPE FTG not found BRACKET, TRANS OIL CLR INL & OTLT PIPE (ЧАСТЬ OF 3) 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] (6D04-079) - 2008-2009 DM69 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (MYB, ПОЛНОПРИВОДНЫЙ MX7, EXTRA CAPACITY V03, HEAVY DUTY V08) ↓ 25829909 COOLER, TRANS FLUID AUX (INCLS 13-15) (ACDelco #25829909) [ОХЛАДИТЕЛЬ] not found RETAINER, TRANS FLUID CLR PIPE FTG 25830126 CLIP, TRANS FLUID CLR PIPE not found BRACKET, TRANS OIL CLR INL & OTLT PIPE (ЧАСТЬ OF 8) 24237658 SEAL, TRANS FLUID CLR PIPE FTG (SEALS ONE PIPE) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ] 15251488 SEAL, TRANS FLUID CLR HOSE (ЧАСТЬ OF 8) (SEALS TWO ТРУБКИ) [УПЛОТНЕНИЕ] 11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) [БОЛТ, М8Х1.25Х31.5] 25829902 HOSE, TRANS FLUID CLR (INCLS 4, 6, 11) [ШЛАНГ] 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 10405874 CLIP, TRANS FLUID CLR HOSE (LESS MNTG TAB) (HOLDS TWO 9.5 DIA TUBES) 15052228 CЛАМПА, TRANS FLUID CLR HOSE (ЧАСТЬ OF 8) (PLASTIC RETAINER) (ACDelco #15052228) [ФИТИНГ ТРУБОПРОВОДА] 25829910 PIPE, TRANS FLUID AUX CLR (INCLS 17) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] teamcadillac.ru 19129762 FITTING, TRANS FLUID CLR PIPE (ЧАСТЬ OF 1) [СОЕДИНИТЕЛЬ] 24205103 RETAINER, TRANS FLUID AUX CLR (ЧАСТЬ OF 1) (EXPANDING ПРУЖИНА WIRE) (ACDelco #24205103) [СТОПОРНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ] 10405874 CLIP, TRANS FLUID CLR HOSE (ЧАСТЬ OF 1) (LESS MNTG TAB) (HOLDS TWO 9.5 DIA TUBES) 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 15052228 CAP, TRANS FLUID CLR PIPE CONN (ЧАСТЬ OF 12) (PLASTIC RETAINER) (ACDelco #15052228) [ФИТИНГ ТРУБОПРОВОДА] not found FITTING, TRANS FLUID CLR PIPE (6D04-080) - 2008 DM69 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (MYB, ЗАДНИЙ КОЛЕСО DRIVE MX0, EXTRA CAPACITY V03, HEAVY DUTY V08) ↓ 25829909 COOLER, TRANS FLUID AUX (INCLS 13-15) (ACDelco #25829909) [ОХЛАДИТЕЛЬ] not found RETAINER, TRANS FLUID CLR PIPE FTG 25830126 CLIP, TRANS FLUID CLR PIPE 11516149 ГАЙКА, U, 8X1.25, MULTI THD, .08'-4.0' THK PNL, PZ (TRANS FLUID CLR HOSE CLIP BRKT) [ГАЙКА М8] 24237658 SEAL, TRANS FLUID CLR PIPE FTG (SEALS ONE PIPE) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ] 15251488 SEAL, TRANS FLUID CLR HOSE (ЧАСТЬ OF 8) (SEALS TWO ТРУБКИ) [УПЛОТНЕНИЕ] 11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) [БОЛТ, М8Х1.25Х31.5] 25829896 HOSE, TRANS FLUID CLR (INCLS 6, 9, 11, 19) [ШЛАНГ] 10405874 CLIP, TRANS FLUID CLR HOSE (ЧАСТЬ OF 8) (LESS MNTG TAB) (HOLDS TWO 9.5 DIA TUBES) 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] not found BRACKET, TRANS OIL CLR INL & OTLT PIPE (ЧАСТЬ OF 8) 25829910 PIPE, TRANS FLUID AUX CLR (INCLS 17) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] teamcadillac.ru 19129762 FITTING, TRANS FLUID CLR PIPE (ЧАСТЬ OF 1) [СОЕДИНИТЕЛЬ] 24205103 RETAINER, TRANS FLUID AUX CLR (ЧАСТЬ OF 1) (EXPANDING ПРУЖИНА WIRE) (ACDelco #24205103) [СТОПОРНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ] not found CLIP, TRANS FLUID CLR HOSE (ЧАСТЬ OF 1) 11570324 БОЛТ, TRANS FLUID CLR (M6X1X14, 9 THD) (9.190) 15052228 CAP, TRANS FLUID CLR PIPE CONN (ЧАСТЬ OF 12) (PLASTIC RETAINER) (ACDelco #15052228) [ФИТИНГ ТРУБОПРОВОДА] not found FITTING, TRANS FLUID CLR PIPE 15052228 CЛАМПА, TRANS FLUID CLR HOSE (ЧАСТЬ OF 8) (PLASTIC RETAINER) (ACDelco #15052228) [ФИТИНГ ТРУБОПРОВОДА] (6D04-081) - 2008 DM69 BRAKES-ВЕНТИЛЯЦИЯ ↓ 25940079 EXTENSION, FRT BPR FASCIA (СМ. ГРУППУ 07.000 "БАМПЕР ПЕРЕДНИЙ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/HOLE) [ПОДКРЫЛОК] 25940080 EXTENSION, FRT BPR FASCIA (СМ. ГРУППУ 07.000 "БАМПЕР ПЕРЕДНИЙ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/HOLE) [БОКОВАЯ ПАНЕЛЬ БАМПЕРА] 15272166 DUCT, FRT BRK CLPR CLG (CONNECTS TO FRT WHL EXTN) [ТРУБКА ВОЗДУХОВОДА] 15272167 DUCT, FRT BRK CLPR CLG (CONNECTS TO FRT FASCIA) [ТРУБКА] 15272168 DUCT, FRT BRK CLPR CLG (CONNECTS TO FRT FASCIA) [ТРУБКА] 20772527 DUCT, FRT BRK CLPR CLG (CONNECTS TO FRT FASCIA) [ВОЗДУХОЗАБОРНИК ТОРМОЗНОЙ СИСТЕМЫ] 20772528 DUCT, FRT BRK CLPR CLG (CONNECTS TO FRT FASCIA) [ВОЗДУХОЗАБОРНИК ТОРМОЗНОЙ СИСТЕМЫ] 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (FRT FOG LP BRKT) [ВИНТ М4] 25536302 ГАЙКА, FRT BPR UPR FASCIA (4.2 X 1.41) (TAPPING NUT) (3.430) [ПРИЖИМНАЯ ПЛАСТИНА ПАНЕЛИ КУЗОВА] teamcadillac.ru 15272157 BEZEL, FRT FOG LP (FOR VEHICLES BUILT W/FRONT BRAKE ОХЛАЖДЕНИЕ DUCTS) (ON VEH BUILT BEFORE 3/31/08 OR IF REPLACED BEZEL HAS OPENINGS/SLOTSMUST ALSO ORDER 25961369) 15904574 BEZEL, FRT FOG LP [НАКЛАДКА ПАНЕЛИ БАМПЕРА] 15904575 BEZEL, FRT FOG LP [ОКАНТОВКА ПРОТИВОТУМАННОЙ ФАРЫ] 25961369 BEZEL, FRT FOG LP (FOR VEHICLES BUILT W/ FRONT BRAKE ОХЛАЖДЕНИЕ DUCTS) (ON VEH BUILT BEFORE 3/31/08 OR IF REPLACED BEZEL HAS OPENINGS/SLOTS, MUST ALSO ORDER 25961370) 10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (FRT BRK CLPR CLG DUCT) [ПИСТОН КРЕПЛЕНИЯ ОБЛИЦОВКИ БАМПЕРА (NYLON)] 11561857 CLIP, FRT FOG LP ADJ БОЛТ RET (BLACK) (14.13 X 11 X 8.6) (7.831) (6D04-082) - 2008-2009 DM69 УПРАВЛЕНИЕ АКПП/АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) ↓ 25887055 PLATE, F/FLR CNSL TRANS SHFT OPG TR (INCLS 2, 3, 13-15) [РАМКА РЫЧАГА ПЕРЕКЛЮЧЕНИЯ ПЕРЕДАЧ] 25801116 INDICATOR, A/TRNS CONT (ЧАСТЬ OF 1) 11509231 SCREW, RD HD C/R TAP, M4.2X1.41X13.0, GM6010M STL, GM813M NICKEL ORGANIC (ЧАСТЬ OF 1) [ВИНТ М6Х12] 25907978 CONTROL, A/TRNS (INCLS 5-8) [БЛОК УПРАВЛЕНИЯ] 25907978 CONTROL, A/TRNS (INCLS 5-8) (4.004) [БЛОК УПРАВЛЕНИЯ] 25907979 CONTROL, A/TRNS (INCLS 5-8) [БЛОК УПРАВЛЕНИЯ] 25907979 CONTROL, A/TRNS (INCLS 5-8) (4.004) [БЛОК УПРАВЛЕНИЯ] 25907980 CONTROL, A/TRNS (INCLS 5-8) [БЛОК УПРАВЛЕНИЯ] 25907980 CONTROL, A/TRNS (INCLS 5-8) (4.004) [БЛОК УПРАВЛЕНИЯ] 25907981 CONTROL, A/TRNS (INCLS 5-8) [БЛОК УПРАВЛЕНИЯ] 25907981 CONTROL, A/TRNS (INCLS 5-8) (4.004) [БЛОК УПРАВЛЕНИЯ] 25907982 CONTROL, A/TRNS (INCLS 5-8) [БЛОК УПРАВЛЕНИЯ] 25907982 CONTROL, A/TRNS (INCLS 5-8) (4.004) [БЛОК УПРАВЛЕНИЯ] 25908000 CONTROL, A/TRNS (INCLS 5-8) [БЛОК УПРАВЛЕНИЯ] 25908000 CONTROL, A/TRNS (INCLS 5-8) (4.004) [БЛОК УПРАВЛЕНИЯ] teamcadillac.ru 25824055 KNOB, A/TRNS CONT LVR (ЧАСТЬ OF 4) (INCLS 6) (COCOA) (ALL LEATHER) 25824057 KNOB, A/TRNS CONT LVR (ЧАСТЬ OF 4) (INCLS 6) (EBONY) (SIDE EBONY LEATHER MIDDLE FIGURED SAPELE) 25824059 KNOB, A/TRNS CONT LVR (ЧАСТЬ OF 4) (INCLS 6) (COCOA) (SIDE COCOA LEATHER MIDDLE FIGURED SAPELE) 25824060 KNOB, A/TRNS CONT LVR (ЧАСТЬ OF 4) (INCLS 6) (EBONY) (ALL LEATHER) 11570687 БОЛТ, A/TRNS CONT LVR KNOB (ЧАСТЬ OF 4, 5) 25824062 BOOT, A/TRNS CONT (ЧАСТЬ OF 4) (EBONY) 25824064 BOOT, A/TRNS CONT (ЧАСТЬ OF 4) (COCOA) 25824053 BASE, A/TRNS CONT (ЧАСТЬ OF 4) 25824054 BASE, A/TRNS CONT (ЧАСТЬ OF 4) 11514603 ГАЙКА, M10X1.5 15MM SOCKET (A/TRNS RANGE SEL LVR) [ШАЙБА] 11519095 NUT-ACORN HEX, M8X1.0, 15MM THK, 9, 6047M, W/DOME. (A/TRNS RANGE SEL LVR) [ГАЙКА] 15780844 LINK, A/TRNS RANGE SEL LVR 15780845 LINK, A/TRNS RANGE SEL LVR 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL ROD ADJ) [ГАЙКА М6] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL LVR CBL BRKT) [ГАЙКА М6] 11610112 CLIP, F/FLR CNSL TR PLT (TR PLT TO SI PNL) (ЧАСТЬ OF 1) (10.4 X 13 X 9) (14.683) not found БОЛТ, F/FLR CNSL CVR (ЧАСТЬ OF 1) not found COVER, F/FLR CNSL FRT (ЧАСТЬ OF 1) (6D04-083) - 2008-2010 DM69 УПРАВЛЕНИЕ АКППS/РУЧНАЯ ТРАНСМИССИЯ (MV7) ↓ 25806639 KNOB, M/TRNS CONT LVR (W/BOOT & W/SHFT PATT) (INCLS 13) 25806640 KNOB, M/TRNS CONT LVR (W/BOOT & W/SHFT PATT) (INCLS 13) 25887053 PLATE, F/FLR CNSL TRANS SHFT OPG TR (INCLS 9, 10, 12) 15794036 PLATE, M/TRNS CONT MT 15794035 CONTROL, M/TRNS (W/SHFT PATT) [БЛОК УПРАВЛЕНИЯ] 21996990 PIN, M/TRNS CONT SHF EQLZR LVR (SHIFTER END) 25708836 RETAINER, M/TRNS SHFT LVR 25753853 PIN, M/TRNS CONT SHF EQLZR LVR (TRANS END) teamcadillac.ru 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (M/TRNS CONT BRKT) [ГАЙКА М6] 11509231 SCREW, RD HD C/R TAP, M4.2X1.41X13.0, GM6010M STL, GM813M NICKEL ORGANIC (ЧАСТЬ OF 2) [ВИНТ М6Х12] not found COVER, F/FLR CNSL FRT (ЧАСТЬ OF 2) 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (M/TRNS CONT BRKT) 11570189 CLIP, F/FLR CNSL TR PLT (ЧАСТЬ OF 2) 11610112 CLIP, F/FLR CNSL TR PLT (TR PLT TO SI PNL) (ЧАСТЬ OF 2) (10.4 X 13 X 9) (14.683) not found CAP, M/TRNS SEL LVR (ЧАСТЬ OF 1) (6D04-084) - 2008-2009 DM69 ТОРМОЗНОЙ УСИЛИТЕЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (LP1/2.8T,LY7/3.6-7) ↓ teamcadillac.ru not found CYLINDER, BRK MAS (СМ. ГРУППУ 04.000 "ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] not found REINFORCEMENT, P/B BOOS (ЧАСТЬ OF PANEL, AIR INL GRL - 12.800) 10125439 RIVET, FLAT HD, 3 LEG EXPANSION, M4.8 SHAFT, 23.5 LG, 9.8 O.D., AL (AIR INL GRL PNL) [ЗАКЛЕПКА D=4.8 ММ] not found CYLINDER, CLU MAS (СМ. ГРУППУ 00.000 "ПЕДАЛЬ СЦЕПЛЕНИЯ-ЦИЛИНДРЫ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 24245109 CYLINDER, CLU MAS (СМ. ГРУППУ 00.000 "ПЕДАЛЬ СЦЕПЛЕНИЯ-ЦИЛИНДРЫ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ЦИЛИНДР] 25873484 HOSE, P/B BOOS VAC (ACDelco #176-1497) 25873484 HOSE, P/B BOOS VAC (ACDelco #176-1497) 25923501 HOSE, P/B BOOS VAC not found BOOSTER, P/B (СМ. ГРУППУ 04.000 "ТОРМОЗНОЙ УСИЛИТЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25675835 BRACKET, BRK PED BRKT 15849744 BOOT, BRK PED PUSH ROD 25697461 RETAINER, BRK PED PUSH ROD BOOT 25785092 BARRIER, BRK PED BRKT SND 25913292 BARRIER, BRK PED BRKT SND not found PEDAL, BRK (W/BRKT) (СМ. ГРУППУ 04.000 "ТОРМОЗНАЯ ПЕДАЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11514519 ГАЙКА, BRK PED BRKT (M8X1.25, 7.32 THK) (9510M, ZF) (8.915) [ГАЙКА] not found REINFORCEMENT, P/B BOOS (СМ. ГРУППУ 10.000 "СТЕКЛООЧИСТИТЕЛЬ-ВЕТРОВОГО СТЕКЛА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6D04-085) - 2008 DM69 КЛАПАН РЕГУЛИРОВКИ ДАВЛЕНИЯ В ТОРМОЗНОЙ СИСТЕМЕ ↓ 25853512 МОДУЛЬ, ELEK BRK & TRACT CONT [МОДУЛЬ] 25854972 БОЛТ, ELEK BRK CONT MDL (ECU TO HCU ATTACH) (M4X0.7X19.5, 10THD) not found БОЛТ, ELEK BRK CONT MDL BRKT (*KIT1) teamcadillac.ru not found INSULATOR, BRK PRESS MOD VLV BRKT (*KIT1) not found INSULATOR, BRK PRESS MOD VLV (*KIT1) 15298281 VALVE, BRK PRESS MOD [КЛАПАН] 15286358 INSULATOR KIT, BRK PRESS MOD VLV (INCLS 3-5) (6D04-086) - 2008 DM69 ЭЛЕКТРИЧЕСКАЯ СИСТЕМА АБС ↓ 25996837 SENSOR, FRT WHL SPD (INCLS 2, 3, 6) 15158259 CLIP, WHL SPD SEN WIRE (ЧАСТЬ OF 1, 15) (12.0MM HOLE) 15158261 CLIP, WHL SPD SEN WIRE (ЧАСТЬ OF 1) (11MM HOLE) teamcadillac.ru not found HARNESS, ENG WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/ДВИГАТЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found VALVE, BRK PRESS MOD (W/ELEK BRK & TRACT CONT MDL) (СМ. ГРУППУ 04.000 "BRAKE CONTROL МОДУЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 15715954 CLIP, WHL SPD SEN WIRE (ЧАСТЬ OF 1) (TREE FITS 6.5 HOLE) (HOLDS (1) 10.5MM GROMMET ROUTING (1) 6.35 SPD SEN CBL) 11516521 БОЛТ, HFH M6X1X20, 9.8, 7114M, DOG PT, 14.2 OD (FRT WHL SPD SEN) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (VEH YAW SEN & LATL ACCLRM) 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (VEH YAW SEN & LATL ACCLRM) [БОЛТ М6] not found HARNESS, BODY WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/КУЗОВ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 15845467 SENSOR, VEH YAW (W/VEH LATL ACCLRM) (LABELED 15845467) [ДАТЧИК] 25866179 SENSOR, RR WHL SPD (INCLS 14) 11516521 БОЛТ, HFH M6X1X20, 9.8, 7114M, DOG PT, 14.2 OD (RR WHL SPD SEN) 10317605 CLIP, WHL SPD SEN WIRE (ЧАСТЬ OF 12) (6.8MM HOLE) (9.242) [ЗАЖИМ ДАТЧИКА АБС] 15855539 SENSOR, FRT WHL SPD (INCLS 2, 16, 17) 10317605 CLIP, WHL SPD SEN WIRE (ЧАСТЬ OF 15) (6.8MM HOLE) (9.242) [ЗАЖИМ ДАТЧИКА АБС] not found BRACKET, FRT WHL SPD SEN WIRE (ЧАСТЬ OF 15) 25820819 BRACKET, FRT WHL SPD SEN WIRE (ЧАСТЬ OF 15) 11570352 ГАЙКА, HEX JAM M12X1.75X6, GM510 (5) STL, GMW14100. (WHL SPD SEN BRKT) (6D04-087) - 2008-2009 DM69 УПРАВЛЕНИЕ АКППS/КОРПУС КП (ПОЛНОПРИВОДНЫЙ MX7) ↓ 24244602 МОДУЛЬ, TRFER CASE SHFT CONT [МОДУЛЬ] not found HARNESS, I/P WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found INSULATOR, I/P (СМ. ГРУППУ 10.000 "ПРИБОРНАЯ ПАНЕЛЬ ЧАСТЬ 1" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (BLACK) 11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (I/P INSL) [ВИНТ] 11609370 БОЛТ-HWH, M4.2X1.41X20, HI - LOW THD, , OD 12, 6010 STL, GMW4205, TAP (I/P INSL) (9.667) (6D04-088) - 2008 DM69 ТОРМОЗНОЙ УСИЛИТЕЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (LLT/3.6V) ↓ 15267511 BOOSTER, P/B (СМ. ГРУППУ 04.000 "ТОРМОЗНОЙ УСИЛИТЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ГИДРОУСИЛИТЕЛЬ ТОРМОЗНОЙ СИСТЕМЫ] teamcadillac.ru 25675835 BRACKET, BRK PED BRKT 15849744 BOOT, BRK PED PUSH ROD 25697461 RETAINER, BRK PED PUSH ROD BOOT 25785092 BARRIER, BRK PED BRKT SND 25913292 BARRIER, BRK PED BRKT SND not found PEDAL, BRK (W/BRKT) (СМ. ГРУППУ 04.000 "ТОРМОЗНАЯ ПЕДАЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 15267509 CYLINDER, BRK MAS (СМ. ГРУППУ 04.000 "ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [БЛОК ЦИЛИНДРОВ] 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] 11570167 STUD, P/B BOOS PUMP BRKT (STUD-STRAIGHT, M12X1.75X32.25, M12X1.75X23, 80 OAL, 10.9, E11 TORX) 25806500 BRACKET, VAC PUMP [ВАКУУМНЫЙ НАСОС] 11516075 ГАЙКА, HFH SELF LK, M6X1, 7.7THK, 14.2 O.D., 9, PZOR (P/B BOOS PUMP) [ГАЙКА ВЫПУСКНОЙ СИСТЕМЫ D=6ММ] 11514598 ГАЙКА, HEX FLANGE, M12X1.75X12, 26 OD, 10, 7111M, (P/B BOOS PUMP) [ГАЙКА М12] 11518075 БОЛТ, HFH, THD 22, OD 17, 8.8, GMW14C-PT, HDR POINT (P/B BOOS PUMP) [ВИНТ М10] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (P/S FLUID RSVR) 11589303 БОЛТ-HFH, M6X1X38, 30 THD, 14.2 OD, 8.8 STL, GMW3359, M-PT (P/B BOOS PUMP) 15797569 PUMP, P/B BOOS AUX [НАСОС В СБОРЕ] 20774507 RESERVOIR, P/S FLUID (СМ. ГРУППУ 06.000 "НАСОС РУЛЕВОГО УПРАВЛЕНИЯ LINES" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25926187 HOSE, P/B BOOS VAC (INCLS 21) 25926187 HOSE, P/B BOOS VAC (INCLS 21) not found CЛАМПА, P/B BOOS HSG (ЧАСТЬ OF 20) not found SPACER, P/B BOOS PUMP (*KIT1) not found INSULATOR, P/B BOOS PUMP (*KIT1) 25775922 INSULATOR KIT, P/B BOOS PUMP (INCLS 22, 23) (ON PUMP) (6D04-089) - 2008 DM69 СТОЯНОЧНЫЙ ТОРМОЗ ASM ↓ 15853380 PLATE, RR BRK BKG (17" ТОРМОЗА) 15853415 PLATE, RR BRK BKG (17" ТОРМОЗА) 15853421 PLATE, RR BRK BKG (18" ТОРМОЗА) 15853425 PLATE, RR BRK BKG (18" ТОРМОЗА) not found PIN, RR PARK BRK SHOE (*KIT1) 25693149 BRACKET, PARK BRK CBL (ATTACHES TO RR SUSP) 25693150 BRACKET, PARK BRK CBL (ATTACHES TO RR SUSP) 11517996 ГАЙКА, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (PARK BRK RR CBL BRKT) (ACDelco #11517996) [ГАЙКА М10] teamcadillac.ru 25867413 LEVER, RR PARK BRK ACTR 25814678 SHOE KIT, RR PARK BRK [ТОРМОЗНАЯ КОЛДКА] not found ПРУЖИНА, RR PARK BRK SHOE RTN (*KIT1) not found ПРУЖИНА, RR PARK BRK SHOE HOLDN (*KIT1) not found ПРУЖИНА, RR PARK BRK SHOE RTN (*KIT1) 25867414 ADJUSTER, RR PARK BRK 25814679 ПРУЖИНА KIT, PARK BRK LVR RTN (INCLS 2, 7-9) [ПРУЖИНА] (6D04-098) - 2008-2009 DM69 КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS (ПОЛНОПРИВОДНЫЙ MX7) ↓ 89059523 ГАЙКА, TRFER CASE RR ВЫХОДНОЙ SHF FLG (4.520) 15580315 WASHER, TRFER CASE RR ВЫХОДНОЙ SHF THR (FLAT) (PL, STL) (7/8 I.D. X 1 39/64 O.D., 1/8 THK) (4.510) 15635532 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF FLG (O RING) (4.412) 19179018 FLANGE, TRFER CASE RR ВЫХОДНОЙ SHF 88996681 DEFLECTOR, TRFER CASE RR ВЫХОДНОЙ SHF SEAL DIRT (5.555) 19180065 БОЛТ, TRFER CASE VIB DPNR teamcadillac.ru 19179016 DAMPENER, TRFER CASE VIB (AT RR OF CASE) not found БОЛТ, WRG HARN BRKT 19208066 CASE, TRFER (FRT HALF) 19208080 РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ, TRFER CASE TWO/FOUR WHL DRV CLU 88984499 PIN, TRFER CASE HALF LOC not found BRACKET, WRG HARN 88996657 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF [УПЛОТНИТЕЛЬ] 19208081 ГАЙКА, TRFER CASE TWO/FOUR WHL DRV CLU РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ 19208077 CASE, TRFER (RR HALF) 19206436 RESISTOR, (115 OHMS) 19206437 RESISTOR, (225 OHMS) 19206438 RESISTOR, (453 OHMS) 19206439 RESISTOR, (715 OHMS) 19206440 RESISTOR, (1150 OHMS) 19206441 RESISTOR, (1820 OHMS) 19206442 RESISTOR, (3160 OHMS) 19206443 RESISTOR, (7320 OHMS) 19206444 RESISTOR, (12700 OHMS) 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL FILL) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 19179015 PLUG, TRFER CASE FRT ВЫХОДНОЙ SHF HOLE (INCLS 20) [КРЫШКА КОРПУСА РАЗДАТОЧНОЙ КОРОБКИ] not found SEAL, TRFER CASE ACC HOLE PLUG (O RING) (ЧАСТЬ OF 19) 19208087 RING, TRFER CASE FRT ВЫХОДНОЙ SHF BRG RET 19179158 SENSOR, TRFER CASE FLUID TEMP [ДАТЧИК ТЕМПЕРАТУРЫ МАСЛА РАЗДАТОЧНОЙ КОРОБКИ] 19179158 SENSOR, TRFER CASE FLUID TEMP [ДАТЧИК ТЕМПЕРАТУРЫ МАСЛА РАЗДАТОЧНОЙ КОРОБКИ] 19179014 PLUG, TRFER CASE OIL DRN 88996680 БОЛТ, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN SNBR (M5X0.8X16) 88996679 SNUBBER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN 88996680 БОЛТ, TRFER CASE VENT BFL (M5X0.8X16) (4.535) 88996658 BAFFLE, TRFER CASE VENT not found БОЛТ, TRFER CASE MT BAR INSL CLA not found CЛАМПА, TRFER CASE MT BAR INSL 19180066 VENT, TRFER CASE 88996657 SEAL, TRFER CASE FRT ВЫХОДНОЙ SHF [УПЛОТНИТЕЛЬ] 88996656 SEAL, TRFER CASE INPUT SHF [УПЛОТНИТЕЛЬ] 88996681 DEFLECTOR, TRFER CASE FRT ВЫХОДНОЙ SHF SEAL DIRT 19208069 SHAFT, TRFER CASE FRT ВЫХОДНОЙ 89048123 БОЛТ, TRFER CASE HALF (M8X1.25X30) (6D04-099) - 2008-2009 DM69 КОРПУС КП ЧАСТЬ 2 INTERNAL COMPONENTS (ПОЛНОПРИВОДНЫЙ MX7) ↓ 15580228 BEARING, TRFER CASE RR ВЫХОДНОЙ SHF RR (2 7/8 OD X 1 3/8 ID) (STMPD 13-45-130-001) 19208080 РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ, TRFER CASE TWO/FOUR WHL DRV CLU (СМ. ГРУППУ 04.000 "КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 19208108 SHIM, TRFER CASE FOUR WHL DRV CLU (SELECT FIT 8.60-8.50; STAMPED "52") 19208109 SHIM, TRFER CASE FOUR WHL DRV CLU (SELECT FIT 8.80-8.70; STAMPED "53") 19208110 SHIM, TRFER CASE FOUR WHL DRV CLU (SELECT FIT 9.00-8.90; STAMPED "54") 19208111 SHIM, TRFER CASE FOUR WHL DRV CLU (SELECT FIT 9.20-9.10; STAMPED "55") 19208112 SHIM, TRFER CASE FOUR WHL DRV CLU (SELECT FIT 9.40-9.30; STAMPED "56") 19208113 SHIM, TRFER CASE FOUR WHL DRV CLU (SELECT FIT 9.60-9.50; STAMPED "57") 19208114 SHIM, TRFER CASE FOUR WHL DRV CLU (SELECT FIT 9.80-9.70; STAMPED "58") 19208115 BEARING, TRFER CASE FOUR WHL DRV CLU HSG not found ШЛАНГИ, TRFER CASE TWO/FOUR WHL DRV CLU РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ not found ROLLER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT BRG 19208358 SPACER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT BRG RLR not found ПРУЖИНА, TRFER CASE TWO/FOUR WHL DRV SYN HUB 19208088 RING, TRFER CASE TWO/FOUR WHL DRV CLU RET 19208098 СЦЕПЛЕНИЕ, TRFER CASE FRT DRV AXLE VISCOUS (INCLS 12-17) not found ACTUATOR, TRFER CASE FOUR WHL DRV not found PLATE, TRFER CASE FOUR WHL DRV CLU PRESS (ЧАСТЬ OF 10) not found PLATE, TRFER CASE FOUR WHL DRV CLU BKG (FRICTION) (ЧАСТЬ OF 10) not found PLATE, TRFER CASE FOUR WHL DRV CLU BKG (SEPERATOR) (ЧАСТЬ OF 10) not found PLATE, TRFER CASE FOUR WHL DRV CLU BKG (ЧАСТЬ OF 10) not found PLATE, TRFER CASE FOUR WHL DRV CLU BKG (ПРУЖИНА) (ЧАСТЬ OF 10) not found ШЛАНГИ, TRFER CASE FOUR WHL DRV CLU (ЧАСТЬ OF 10) 19208091 SPACER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT 19208072 CHAIN, TRFER CASE TWO/FOUR WHL DRV 19208359 SPROCKET, TRFER CASE FRT ВЫХОДНОЙ SHF DRV 19208090 WASHER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT THR 19208085 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT 19208090 WASHER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT THR teamcadillac.ru 19208082 PUMP, TRFER CASE OIL 19208071 SHAFT, TRFER CASE INPUT not found BEARING, TRFER CASE INPUT SHF 19208078 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF RR 19208360 SPROCKET, TRFER CASE TWO/FOUR WHL DRV DRVN 19208089 SPACER, TRFER CASE FRT ВЫХОДНОЙ SHF DRVN SPKT 88996633 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF FRT (ACDelco #88996633) [ПОДШИПНИК РАЗДАТОЧНОЙ КОРОБКИ] (6E04-020) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ 24218963 RING, T/CV FLUID SEAL RET [КОЛЬЦО] 24237531 SEAL, T/CV FLUID (ЧАСТЬ OF 217, 219) (ACDelco #24237531) [УПЛОТНЕНИЕ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 00444613 PLUG, HEX HD, 1/8-27 NPTF, STL (LINE PRESS TEST HOLE) (ACDelco #444613) 24239384 ШЛАНГИ, T/CV (MCHG) (INCLS 206) (ACDelco #24239384) 24225422 PIPE, A/TRNS VENT not found BUSHING, T/CV (ЧАСТЬ OF 203) not found RING, A/TRNS ГИДРОНАСОС VANE (ЧАСТЬ OF 217) not found GUIDE, A/TRNS ГИДРОНАСОС ROT (ЧАСТЬ OF 217) not found RING, A/TRNS ГИДРОНАСОС SLIDE FLUID SEAL (ЧАСТЬ OF 217) not found SEAL, A/TRNS O/PMP SLIDE (O RING) (ЧАСТЬ OF 217) (*KIT1) not found ПРУЖИНА, A/TRNS ГИДРОНАСОС SLIDE OTR (ЧАСТЬ OF 217) 24222668 SLIDE, A/TRNS ГИДРОНАСОС (17.948MM-17.961MM) (ACDelco #24222668) 24224131 SLIDE, A/TRNS ГИДРОНАСОС (17.961MM-17.974MM) (ACDelco #24224131) 24224132 SLIDE, A/TRNS ГИДРОНАСОС (17.974MM-17.987MM) (ACDelco #24224132) not found SEAL, A/TRNS ГИДРОНАСОС SLIDE (ЧАСТЬ OF 217) not found SUPPORT, A/TRNS ГИДРОНАСОС SLIDE SEAL (ЧАСТЬ OF 217) (*KIT1) not found PIN, A/TRNS ГИДРОНАСОС SLIDE PIV (ЧАСТЬ OF 217) not found VANE, A/TRNS ГИДРОНАСОС (ЧАСТЬ OF 217) 24238915 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 207-211, 213-216, 230) (17.948MM-17.961MM) (ACDelco #24238915) 24238916 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 207-211, 213-216, 230) (17.961MM-17.974MM) (ACDelco #24238916) 24238917 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 207-211, 213-216, 230) (17.974MM-17.987MM) (ACDelco #24238917) not found BUSHING, TURB SHF FRT (ЧАСТЬ OF 219) 24238919 COVER KIT, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 218, 220-230, 232-237) (ACDelco #24238919) not found VALVE, CONV FEED LIM (ЧАСТЬ OF 219) not found ПРУЖИНА, PRESS RLF BALL VLV (ЧАСТЬ OF 219) not found ПРУЖИНА, CONV FEED LIM VLV (ЧАСТЬ OF 219) not found PIN, PRESS RLF BALL VLV SPR (ЧАСТЬ OF 219) not found ПРУЖИНА, PRESS RLF BALL VLV (ЧАСТЬ OF 219) 00147500 VALVE, PRESS RLF BALL (ЧАСТЬ OF 219) not found ПРУЖИНА, TCC C/VLV (ЧАСТЬ OF 219) not found VALVE, TCC CONT (ЧАСТЬ OF 219) not found BUSHING, TURB SHF RR (ЧАСТЬ OF 219) 24224692 WASHER, 1-2-3-4 & 3-5 REV CLU HSG THR (ЧАСТЬ OF 219) 24239151 RING, 1-2-3-4 & 3-5 REV CLU FLUID SEAL (ЧАСТЬ OF 217, 219) (*KIT1, KIT2) (ACDelco #24239151) teamcadillac.ru 24227061 БОЛТ, A/TRNS ГИДРОНАСОС CVR (ACDelco #24227061) [БОЛТ] 90351709 PIN, A/TRNS ГИДРОНАСОС LOC (ЧАСТЬ OF 219) ("8MM HOLLOW SPLIT PIN") (1.639) [ШПИЛЬКА] not found VALVE, PRESS REG (ЧАСТЬ OF 219) not found ПРУЖИНА, PRESS REG VLV OTR (ЧАСТЬ OF 219) not found ПРУЖИНА, PRESS REG VLV INR (ЧАСТЬ OF 219) not found VALVE, ISOLATOR (ЧАСТЬ OF 219) not found SLEEVE, ISOLATOR VLV (ЧАСТЬ OF 219) 24243891 SEAL KIT, A/TRNS SERV (INCLS 205, 210, 214, 230) (FULL TRANS) (ACDelco #24243891) 24239151 RING KIT, 1-2-3-4 & 3-5 REV CLU FLUID SEAL (INCLS 230) (ACDelco #24239151) (6M04-038) - 2008 DM69 ШЛАНГ ВЕНТИЛЯЦИИ ТРАНСМИССИИ-VENT HOSE W/DRAIN(MYB)(1ST DES) ↓ not found HOSE, TRANS VENT (INCLS 2-8) 15862039 HOSE, TRANS VENT (INCLS 2-8) (VENT HOSE W/DRAIN) (FOR 2ND DES SEE 25892019) 25892019 HOSE, TRANS VENT (INCLS 2-8) not found VENT, TRFER CASE (ЧАСТЬ OF 1) 08905794 CLIP (TRANS VENT) (ЧАСТЬ OF 1) not found CONNECTOR, TRANS VENT HOSE (ЧАСТЬ OF 1) 06466355 CONNECTOR, TRANS VENT HOSE (ЧАСТЬ OF 1) (3.278) teamcadillac.ru not found STRAP, TRFER CASE VENT HOSE (ЧАСТЬ OF 1) not found HOSE, TRANS VENT (ЧАСТЬ OF 1) 25526358 CЛАМПА, SPRG BAND, 14.2MM, 9/16 OD HOSE, POR (ЧАСТЬ OF 1) not found HOSE, TRANS VENT (ЧАСТЬ OF 1) (6M04-039) - 2008 DM69 ШЛАНГ ВЕНТИЛЯЦИИ ТРАНСМИССИИ-VENT HOSE W/O DRAIN(MYB)(2ND DES) ↓ 25892019 HOSE, TRANS VENT (INCLS 2-4) 25892019 HOSE, TRANS VENT (INCLS 2-4) (VENT HOSE W/O DRAIN) (FOR 1ST DES SEE 15862039) teamcadillac.ru 25526358 CЛАМПА, SPRG BAND, 14.2MM, 9/16 OD HOSE, POR (ЧАСТЬ OF 1) 08905794 CLIP (ЧАСТЬ OF 1) 25892279 VENT, TRFER CASE (ЧАСТЬ OF 1) (ACDelco #25892279) [ЗАГЛУШКА ШЛАНГА ВЕНТИЛЯЦИИ КАРТЕРА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] (GM04-042) - 2008 DM69 ТОРМОЗНОЙ СУППОРТ-ПЕРЕДНИЙ (JE5) ↓ 15851351 CALIPER, FRT BRK (INCLS 2, 3, 12-14) (17") 15851351 CALIPER, FRT BRK (INCLS 2, 3, 12-14) (17") 15853359 CALIPER, FRT BRK (INCLS 2, 3, 12-14) (17") teamcadillac.ru 15853359 CALIPER, FRT BRK (INCLS 2, 3, 12-14) (17") 89027179 VALVE, FRT BRK CLPR BLEDR (ЧАСТЬ OF 1) 88935785 CAP, FRT BRK CLPR BLEDR VLV (ЧАСТЬ OF 1) [ЗАГЛУШКА ОБРАТНОГО КЛАПАНА] 15851359 PIN, FRT BRK CLPR GDE (W/O BUSHING) not found SEAL, FRT BRK CLPR GDE PIN (*KIT3) 15851354 BRACKET, FRT BRK CLPR (17") not found ПРУЖИНА, FRT DISC BRK PAD RET (*KIT2) not found PAD, FRT DISC BRK OTR (*KIT2) not found PAD, FRT DISC BRK INR (*KIT2) not found BUSHING, FRT BRK CLPR GDE PIN (ЧАСТЬ OF 11) (*KIT3) 15851358 PIN, FRT BRK CLPR GDE (INCLS 10) (W/PLASTIC SLEEVE 1.5MM FROM TIP) (W/BUSHING) not found BOOT, FRT BRK CLPR PSTN (ЧАСТЬ OF 1) (*KIT1) not found SEAL, FRT BRK CLPR PSTN (ЧАСТЬ OF 1) (*KIT1) 15926281 PISTON, FRT BRK CLPR (ЧАСТЬ OF 1) 89027183 БОЛТ, FRT BRK CLPR GDE PIN (M8X1.0) [БОЛТ М8] 25814701 SEAL KIT, FRT BRK CLPR PSTN (INCLS 12, 13) (INCLS 2 PISTON BOOTS & PISTON SEALS) 25814699 PAD KIT, FRT DISC BRK (INCLS 7-9) 25814700 SEAL KIT, FRT BRK CLPR GDE PIN (INCLS 5, 10) (INCLS 2 SEALS & 1 BUSHING) (GM04-555) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 24227130 БОЛТ, C/VLV UPR BODY (M5X0.8X36) 24225398 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M6 X 1.0 X 20) 24238417 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (INCLS 316) (4.329) [ДАТЧИК ЧИСЛА ОБОРОТОВ ВАЛА AКПП] 24225797 BODY, C/VLV UPR [ГИДРОРАСПРЕДЕЛИТЕЛЬНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24245720 PLATE, C/VLV BODY SPCR (W/GSKT) (ACDelco #24245720) [НАБОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96020431 VALVE, C/VLV BODY BALL CHK [КЛАПАН] 24250384 BODY, C/VLV LWR (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ/;НИЖНИЙ КЛАПАН РЕГУЛЯТОР BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (MANUAL VALVE NOT INCLUDED) (MUST USE T/W 24236934/PLATE KIT - CONT SOL VLV FLTR) 24246427 SWITCH, A/TRNS MAN SHFT SHF POSN (INCLS 315) (INTERNAL MODE SWITCH) [ВКЛЮЧАТЕЛЬ] 24224821 БОЛТ, C/VLV LWR BODY (M5X0.8X45) 24224822 БОЛТ, C/VLV LWR BODY (M5X0.8X55) 24238925 PLATE KIT, CONT SOL VLV FLTR 24240845 БОЛТ, CONT SOL VLV HEAT SINK (W/ BODY & TCM) (M5X0.8X53.0) 24241890 VALVE, CONT SOL (W/ BODY & TCM) (ACDelco #24241890) (ORDER T/W 24238913 SEAL KIT) [ГИДРОРАСПРЕДЕЛИТЕЛЬНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24236233 CLIP, A/TRNS MAN SHFT SHF POSN SW WRG HARN (ЧАСТЬ OF 308) 24236233 CLIP, A/TRNS MAN SHFT SHF POSN SW WRG HARN (ЧАСТЬ OF 308) 24236233 CLIP, A/TRNS MAN SHFT SHF POSN SW WRG HARN (ЧАСТЬ OF 308) 24236504 CLIP, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN WRG HARN (ЧАСТЬ OF 303) (GM04-556) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ВЕРХНИЙ КЛАПАН РЕГУЛЯТОР BODY БЛОК ↓ 24224766 PIN, C/VLV BODY LOC (ЧАСТЬ OF 321) (DIA.=10MM L=12.7) [ВТУЛКА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24225797 BODY, C/VLV UPR (INCLS 313, 322-338) [ГИДРОРАСПРЕДЕЛИТЕЛЬНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24230200 PIN, C/VLV BODY LOC (ЧАСТЬ OF 321) (DIA.=10MM L=29.9) [ВТУЛКА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, 1-2-3-4 CLU BOOST VLV SPR (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, 1-2-3-4 CLU REG VLV BORE PLUG (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, 1/REV BAND & 4-5-6 CLU REG VLV BORE PLUG (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, 2-6 CLU REG VLV BORE PLUG (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, 3-5-REV CLU BOOST VLV SPR (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, 3-5-REV CLU REG VLV BORE PLUG (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] teamcadillac.ru 24224755 RETAINER, 4-5-6 CLU BOOST VLV SPR (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, ACTR FEED LIM VLV (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] not found ПРУЖИНА, ACTR FEED LIM VLV (ЧАСТЬ OF 321) not found VALVE, ACTR FEED LIM (ЧАСТЬ OF 321) not found ПРУЖИНА, 1-2-3-4 CLU REG VLV (ЧАСТЬ OF 321) not found ПРУЖИНА, 1/REV BAND & 4-5-6 CLU REG VLV (ЧАСТЬ OF 321) not found ПРУЖИНА, 2-6 CLU REG VLV (ЧАСТЬ OF 321) not found ПРУЖИНА, 3-5 REV CLU REG VLV (ЧАСТЬ OF 321) not found VALVE, 1/REV BAND & 4-5-6 CLU REG (ЧАСТЬ OF 321) 24242814 PLUG, 1-2-3-4 CLU REG VLV BORE (ЧАСТЬ OF 321) (9.5 THK, 11.5 DIA) 24242814 PLUG, 1/REV BAND & 4-5-6 CLU REG VLV BORE (ЧАСТЬ OF 321) (9.5 THK, 11.5 DIA) 24242814 PLUG, 2-6 CLU REG VLV BORE (ЧАСТЬ OF 321) (9.5 THK, 11.5 DIA) 24242814 PLUG, 3-5 REV CLU REG VLV BORE (ЧАСТЬ OF 321) (9.5 THK, 11.5 DIA) not found VALVE, 1-2-3-4 CLU BOOST (ЧАСТЬ OF 321) not found VALVE, 3-5-REV CLU BOOST (ЧАСТЬ OF 321) not found VALVE, 4-5-6 CLU BOOST (ЧАСТЬ OF 321) not found ПРУЖИНА, 1-2-3-4 CLU BOOST VLV (ЧАСТЬ OF 321) not found ПРУЖИНА, 3-5-REV CLU BOOST VLV (ЧАСТЬ OF 321) not found ПРУЖИНА, 4-5-6 CLU BOOST VLV (ЧАСТЬ OF 321) not found VALVE, 2-6 CLU REG (ЧАСТЬ OF 321) not found VALVE, 2-6 CLU REG VLV GAIN (ЧАСТЬ OF 321) not found VALVE, 3-5 REV CLU REG (ЧАСТЬ OF 321) not found VALVE, 1-2-3-4 CLU REG (ЧАСТЬ OF 321) not found VALVE, DEFAULT OVERRIDE 1-2-3-4 CLU (ЧАСТЬ OF 321) (GM04-557) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) НИЖНИЙ КЛАПАН РЕГУЛЯТОР BODY БЛОК ↓ 24224755 RETAINER, CLU PSTN DAM FEED REG VLV SPR [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, CLU SEL SOL VLV BORE PLUG #2 [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, CLU SEL SOL VLV BORE PLUG #3 [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, TCC REG APPL VLV BORE PLUG [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] teamcadillac.ru 24242814 PLUG, CLU SEL SOL VLV BORE #2 (9.5 THK, 11.5 DIA) 24242814 PLUG, CLU SEL SOL VLV BORE #3 (9.5 THK, 11.5 DIA) 24242814 PLUG, TCC REG APPL VLV BORE (9.5 THK, 11.5 DIA) not found VALVE, TCC REG APPL SHUTTLE (ЧАСТЬ OF 351) 24250384 BODY, C/VLV LWR (INCLS 338, 352, 353, 355-357) (MANUAL VALVE NOT INCLUDED) (MUST USE T/W 24236934/PLATE KIT - CONT SOL VLV FLTR) not found VALVE, CLU SEL SOL #2 (ЧАСТЬ OF 351) not found VALVE, CLU SEL SOL #3 (ЧАСТЬ OF 351) not found ПРУЖИНА, CLU SEL SOL VLV #2 (ЧАСТЬ OF 351) not found ПРУЖИНА, CLU SEL SOL VLV #3 (ЧАСТЬ OF 351) not found ПРУЖИНА, TCC REG APPLY VLV (ЧАСТЬ OF 351) 24224770 VALVE, MAN (ACDelco #24224770) not found VALVE, TCC REG APPLY (ЧАСТЬ OF 351) not found VALVE, CLU PSTN DAM FEED REG (ЧАСТЬ OF 351) not found ПРУЖИНА, CLU PSTN DAM FEED REG VLV (ЧАСТЬ OF 351) (GM04-558) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) 1-2-3-4 & 3-5 REVERSE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 24240625 RING, 3-5 REV CLU BKG PLT RET (LT GREEN) (2.25-2.35MM) (ACDelco #24240625) 24240626 RING, 3-5 REV CLU BKG PLT RET (GRAY) (2.47-2.57MM) (ACDelco #24240626) 24240627 RING, 3-5 REV CLU BKG PLT RET (YELLOW) (2.69-2.79MM) (ACDelco #24240627) 24240628 RING, 3-5 REV CLU BKG PLT RET (ORANGE) (2.93-3.01MM) (ACDelco #24240628) 24240629 RING, 3-5 REV CLU BKG PLT RET (LT BLUE) (3.13-3.23MM) (ACDelco #24240629) 24240630 RING, 3-5 REV CLU BKG PLT RET (WHITE) (3.35-3.45MM) (ACDelco #24240630) 24240631 RING, 3-5 REV CLU BKG PLT RET (YELLOW/PURPLE) (3.57-3.67MM) (ACDelco #24240631) 24225654 PLATE, 3-5 REV CLU BKG 24225569 PLATE, 3-5/REV CLU (PKG OF 4) (FIBER) (*KIT4) (ACDelco #24225569) 24237663 PLATE, 3-5 REV CLU (PKG OF 4) (STEEL) 24225564 PLATE, 3-5 REV CLU (WAVED) 24225748 RING, 3-5-REV CLU APPLY (ACDelco #24225748) 24233533 PLATE, 1-2-3-4 CLU BKG 24243588 PLATE, 1-2-3-4 CLU (*KIT4) (ACDelco #24243588) 24232652 PLATE, 1-2-3-4 CLU (PKG OF 5) (STEEL) 24236434 PLATE, 1-2-3-4 CLU (WAVED) not found RING, 1-2-3-4 CLU PSTN DAM RET (*KIT1, KIT2) 24225522 DAM, 1-2-3-4 CLU PSTN 24225559 ПРУЖИНА, 1-2-3-4 CLU 24241073 PISTON, 1-2-3-4 CLU not found RING, 1-2-3-4 CLU PSTN HSG RTN (*KIT1, KIT2) not found SEAL, 1-2-3-4 CLU PSTN (ЧАСТЬ OF 417) 24238558 ШЛАНГИ, 1-2-3-4 CLU PSTN (INCLS 416, 418, 419) not found SEAL, 3-5/REV CLU PSTN DAM (O RING) (ЧАСТЬ OF 417) not found SEAL, 3-5-REV CLU PSTN INR (ЧАСТЬ OF 417) 24236051 ПРУЖИНА, 3-5-REV CLU 24238560 PISTON, 3-5/REV CLU (INCLS 422) (4.164) teamcadillac.ru not found SEAL, 3-5-REV CLU PSTN OTR (ЧАСТЬ OF 421) (*KIT3) not found SEAL, 1-2-3-4 CLU PSTN INR (*KIT1, KIT3) not found SEAL, 1-2-3-4 CLU PSTN HSG (*KIT1, KIT3) not found SEAL, 1-2-3-4 CLU PSTN HSG (*KIT1, KIT3) not found BUSHING, 1-2-3-4 & 3-5/REV CLU HSG RR (ЧАСТЬ OF 427) 24237184 ШЛАНГИ, 1-2-3-4 & 3-5 REV CLU (INCLS 426) (ORDER T/W 24226393) 24226393 BEARING, 1-2-3-4 & 3-5-REV CLU 24240626 RING, 1-2-3-4 CLU BKG PLT RET (GRAY) (2.47-2.57MM) (ACDelco #24240626) 24240627 RING, 1-2-3-4 CLU BKG PLT RET (YELLOW) (2.69-2.79MM) (ACDelco #24240627) 24240628 RING, 1-2-3-4 CLU BKG PLT RET (ORANGE) (2.93-3.01MM) (ACDelco #24240628) 24240629 RING, 1-2-3-4 CLU BKG PLT RET (LT BLUE) (3.13-3.23MM) (ACDelco #24240629) 24240630 RING, 1-2-3-4 CLU BKG PLT RET (WHITE) (3.35-3.45MM) (ACDelco #24240630) 24240631 RING, 1-2-3-4 CLU BKG PLT RET (YELLOW/PURPLE) (3.57-3.67MM) (ACDelco #24240631) 24240632 RING, 1-2-3-4 CLU BKG PLT RET (LT BLUE/PURPLE) (3.79-3.89MM) (ACDelco #24240632) 24238913 SEAL KIT, A/TRNS SERV (INCLS 411, 415, 423-425) (CONTROL VLV SOL ASM) (ACDelco #24238913) [КОМПЛЕКТ ПРОКЛАДОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (5ШТ)] 24238920 RING KIT, RET (INCLS 411, 415) 24238922 SEAL KIT, A/TRNS SERV (INCLS 422-425) (TRANS BUILT ON 1-31-08 & PRIOR) (FOR 2ND DES SEE 24243890) (СЦЕПЛЕНИЕES) (ACDelco #24238922) 24238922 SEAL KIT, A/TRNS SERV (INCLS 422-425) (TRANS BUILT ON 2-01-08 & AFTER) (FOR 1ST DES SEE 24238922) (СЦЕПЛЕНИЕES) (ACDelco #24238922) 24238911 PLATE KIT, CLU (INCLS 402, 408) (ORDER T/W 24225575 & 24235455) (ACDelco #24238911) (GM04-559) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) 4-5-6 ДЕТАЛИ СЦЕПЛЕНИЯ & ВАЛ ТУРБИНЫ ↓ 24225508 RING, 4-5-6 CLU BKG PLT RET (GREEN) (2.52-2.62) (ACDelco #24225508) 24225509 RING, 4-5-6 CLU BKG PLT RET (YELLOW) (3.08-3.18) (ACDelco #24225509) 24231591 RING, 4-5-6 CLU BKG PLT RET (GREY) (2.80-2.90) (ACDelco #24231591) 24231592 RING, 4-5-6 CLU BKG PLT RET (ORANGE) (3.36-3.46) (ACDelco #24231592) 24231593 RING, 4-5-6 CLU BKG PLT RET (BLUE) (3.64-3.74) (ACDelco #24231593) 24232880 RING, 4-5-6 CLU BKG PLT RET (YELLOW/PURPLE) (4.20-4.30) (ACDelco #24232880) 24225652 PLATE, 4-5-6 CLU BKG 24225570 PLATE, 4-5-6 CLU (INT SPLINE) (PKG OF 5) (FIBER) (*KIT3) 24225575 PLATE, 4-5-6 CLU (EXT SPLINE) (PKG OF 5) (STEEL)FIBER) (ACDelco #24225575) 24225565 PLATE, 4-5-6 CLU (WAVED) not found RING, 4-5-6 CLU PSTN DAM RET (*KIT1, KIT2) 24225526 DAM, 4-5-6 CLU PSTN 24225560 ПРУЖИНА, 4-5-6 CLU 24225523 PISTON, 4-5-6 CLU not found BUSHING, ВЫХОДНОЙ CARR SHF HSG (ЧАСТЬ OF 441) 24237963 ШЛАНГИ, 4-5-6 CLU (W/ INPUT SHF) (INCLS 440) 24225511 RING, TURB SHF FLUID SEAL 08662686 SEAL, TURB SHF (O RING) (*KIT2) (ACDelco #8662686) 24238920 RING KIT, RET (INCLS 436) 24243891 SEAL KIT, A/TRNS SERV (INCLS 436, 443) (FULL TRANS) (ACDelco #24243891) 24238911 PLATE KIT, CLU (INCLS 433) (ORDER T/W 24225575 & 24235455) (ACDelco #24238911) (GM04-560) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) 2-6 ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 24247405 RING, 2-6 CLU BKG PLT RET (1.69MM +/- 0.05) (ACDelco #24247405) 24247406 RING, 2-6 CLU BKG PLT RET (2.81MM +/- 0.05) (ACDelco #24247406) 24248107 RING, 2-6 CLU BKG PLT RET (2.25MM +/- 0.05) (ACDelco #24248107) 24248108 RING, 2-6 CLU BKG PLT RET (2.53MM +/- 0.05) (ACDelco #24248108) 24248109 RING, 2-6 CLU BKG PLT RET (1.97MM +/- 0.05) (ACDelco #24248109) 24225653 PLATE, 2-6 CLU BKG 24237973 PLATE, 2-6 CLU (WAVED) not found RING, 2-6 CLU SPR RET 24225561 ПРУЖИНА, 2-6 CLU 24225524 PISTON, 2-6 CLU teamcadillac.ru not found BUSHING, ВЫХОДНОЙ CARR OTR SUN GR SHF (ЧАСТЬ OF 459) 24225447 SUPPORT, CTR (INCLS 458, 460) not found BUSHING, ВЫХОДНОЙ CARR OTR SUN GR SHF (ЧАСТЬ OF 459) 24238911 PLATE KIT, CLU (INCLS 452) (ORDER T/W 24225575 & 24235455) (ACDelco #24238911) (GM04-561) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) LOW & REVERSE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ not found SUPPORT, CTR (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ДЕТАЛИ СЦЕПЛЕНИЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found RING, LOW & REV CLU BKG PLT RET 24225519 RING, LOW & REV CLU BKG PLT RET (2.77MM +/- 0.05) (ACDelco #24225519) (TRANS BUILT ON 9/1/08 & FORWARD) (FOR 1ST DES SEE 24248368) 24231938 RING, LOW & REV CLU BKG PLT RET (2.63MM +/- 0.05) (MUST BE USED T/W 24247402) (ACDelco #24231938) (TRANS BUILT ON 9/1/08 & FORWARD) (FOR 1ST DES SEE 24248368) 24231939 RING, LOW & REV CLU BKG PLT RET (2.93MM +/- 0.05) (MUST BE USED T/W 24247402) (ACDelco #24231939) (TRANS BUILT ON 9/1/08 & FORWARD) (FOR 1ST DES SEE 24248368) 24247407 RING, LOW & REV CLU BKG PLT RET (2.03MM +/- 0.05) (MUST BE USED T/W 24247402) (ACDelco #24247407) (TRANS BUILT ON 9/1/08 & FORWARD) (FOR 1ST DES SEE 24248368) 24247408 RING, LOW & REV CLU BKG PLT RET (3.23MM +/- 0.05) (MUST BE USED T/W 24247402) (ACDelco #24247408) (TRANS BUILT ON 9/1/08 & FORWARD) (FOR 1ST DES SEE 24248368) 24247402 PLATE, LOW & REV CLU BKG (MUST BE USED T/W 24231937/38/38, AND 24247407/08) (ACDelco #24247402) (TRANS BUILT ON 9/1/08 & FORWARD) (FOR 1ST DES SEE 24248368) 24248368 PLATE KIT, LOW & REV CLU BKG (FOR SERVICE USE (1) OF THE FOLLOWING RET. RINGS 24225515, 24225519, OR BACKING PLATE 24225656) (4.180) (ACDelco #24248368) (TRANS BUILT ON 08-31-08 & PRIOR) (FOR 2ND DES SEE 24231937/ 24231938/ 24231939/ 242474 24236664 PLATE, LOW & REV CLU (PKG OF 6) (FIBER) (*KIT2) 24232654 PLATE, LOW & REV CLU (PKG OF 6) (STEEL) (ACDelco #24232654) 24237971 PLATE, LOW & REV CLU (WAVED) (ACDelco #24237971) 24225517 RING, LOW & REV CLU SPR RET 24238921 SPRAG, LOW CLU (INCLS 468) not found SEAL, LOW CLU SPRAG (ЧАСТЬ OF 467) (*KIT1) 24225562 ПРУЖИНА, LOW & REV CLU teamcadillac.ru 24225525 PISTON, LOW & REV CLU (ACDelco #24225525) 24238922 SEAL KIT, A/TRNS SERV (INCLS 468) (TRANS BUILT ON 1-31-08 & PRIOR) (FOR 2ND DES SEE 24243890) (СЦЕПЛЕНИЕES) (ACDelco #24238922) 24238922 SEAL KIT, A/TRNS SERV (INCLS 468) (TRANS BUILT ON 2-01-08 & AFTER) (FOR 1ST DES SEE 24238922) (СЦЕПЛЕНИЕES) (ACDelco #24238922) 24238911 PLATE KIT, CLU (INCLS 463) (ORDER T/W 24225575 & 24235455) (ACDelco #24238911) (GM04-562) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) СЦЕПЛЕНИЕ HUB БЛОК ↓ teamcadillac.ru 24233660 HUB, 4-5-6 CLU (W/ ВЫХОДНОЙ CARR SHF & DPNR) (INCLS 476-478) 24230475 DAMPENER, 4-5-6 CLU (ЧАСТЬ OF 475) 24233661 PLATE, 4-5-6 CLU DPNR APPLY (ЧАСТЬ OF 475) not found RING, 4-5-6 CLU DPNR RET (ЧАСТЬ OF 475) (GM04-563) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ВЫХОДНОЙ КРОНШТЕЙН БЛОК ↓ 24225777 BEARING, CTR SUPT RLR (ЧАСТЬ OF 490) teamcadillac.ru 24225483 BEARING, ВЫХОДНОЙ CARR OTR SUN GR FRT THR (ЧАСТЬ OF 490) 24225290 GEAR, ВЫХОДНОЙ CARR FRT SUN (ЧАСТЬ OF 490) 24225484 BEARING, ВЫХОДНОЙ CARR OTR SUN GR RR THR (ЧАСТЬ OF 490) 24235807 GEAR, ВЫХОДНОЙ CARR RR SUN (ЧАСТЬ OF 490) 24225603 КРОНШТЕЙН, ВЫХОДНОЙ (INCLS 485-489, 491) not found BEARING, ВЫХОДНОЙ CARR INR SUN GR THR (ЧАСТЬ OF 490) (GM04-568) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ВЫХОДНОЙ ВАЛ БЛОК ↓ 24241092 RING, ВЫХОДНОЙ CARR INTL GR RET (ACDelco #24241092) 24228887 SPACER, ВЫХОДНОЙ CARR INTL GR (3.342) teamcadillac.ru not found BUSHING, ВЫХОДНОЙ CARR (ЧАСТЬ OF 499) 24239398 SHAFT, ВЫХОДНОЙ (INCLS 498) (WHEN SERVICING SHAFT MUST ALSO REPLACE BEARING P/N 24237771) (FLAT END OF THE SHAFT) 24239401 SHAFT, ВЫХОДНОЙ (INCLS 498) (WHEN SERVICING SHAFT MUST ALSO REPLACE BEARING P/N 24237771) (GM04-569) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) БЛОК СЦЕПЛЕНИЯ & ДЕТАЛИ КОМПЛЕКТА ↓ not found СЦЕПЛЕНИЕ, 1-2-3-4 & 3-5 REV (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ 1-2-3-4 & 3-5 REVERSE ДЕТАЛИ СЦЕПЛЕНИЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 24225602 КРОНШТЕЙН, INPUT (ACDelco #24225602) 24225289 GEAR, INPUT SUN (ACDelco #24225289) 24224405 BEARING, INPUT SUN GR THR (ACDelco #24224405) 24224405 BEARING, INPUT SUN GR THR (ACDelco #24224405) 24232409 WASHER, INPUT SUN GR THR not found СЦЕПЛЕНИЕ, 4-5-6 (W/ TURB SHF) (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ 4-5-6 ДЕТАЛИ СЦЕПЛЕНИЯ & ВАЛ ТУРБИНЫ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 24238905 BEARING, TURB SHFT THR [ПОДШИПНИК] not found HUB, 4-5-6 CLU (W/ ВЫХОДНОЙ CARR SHF & DPNR) (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ СЦЕПЛЕНИЕ HUB БЛОК" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 24233732 BEARING, 4-5-6 CLU HUB THR (ACDelco #24233732) 24233732 BEARING, 4-5-6 CLU HUB THR (ACDelco #24233732) not found BUSHING, ВЫХОДНОЙ CARR INR SUN GR SHF (ЧАСТЬ OF 64) 24225597 HUB, 1-2-3-4 CLU (W/ВЫХОДНОЙ CARR INR SUN GR SHF) not found BUSHING, ВЫХОДНОЙ CARR INR SUN GR SHF (ЧАСТЬ OF 64) 24224163 BEARING, 1-2-3-4 CLU HUB THR (ACDelco #24224163) 24225596 HUB, 2-6 & 3-5/REV CLU (W/ ВЫХОДНОЙ CARR OTR SUN GR SHF) (INCLS 60, 62) 24224164 BEARING, 2-6 & 3-5/REV CLU HUB THR (ACDelco #24224164) 24225512 RING, CTR SUPT RET 24225447 SUPPORT, CTR not found КРОНШТЕЙН, ВЫХОДНОЙ (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ВЫХОДНОЙ КРОНШТЕЙН БЛОК" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 24225486 BEARING, ВЫХОДНОЙ CARR THR not found SHAFT, ВЫХОДНОЙ (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ВЫХОДНОЙ ВАЛ БЛОК" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 24224668 BEARING, ВЫХОДНОЙ SHF THR (ACDelco #24224668) (GM04-598) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (6L50 MYB, ЗАДНИЙ КОЛЕСО DRIVE MX0) ↓ not found ТРАНСМИССИЯ, AUTO (REMAN) teamcadillac.ru not found ТРАНСМИССИЯ, AUTO (SERV) 17804020 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 8BMA, 8BAA) 17804029 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 8BTA) (GM04-599) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (6L50 MYB, ПОЛНОПРИВОДНЫЙ MX7) ↓ teamcadillac.ru not found ТРАНСМИССИЯ, AUTO not found ТРАНСМИССИЯ, AUTO (REMAN) not found ТРАНСМИССИЯ, AUTO (SERV) 17804021 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 8BBA, 8BSA) (REMAN) (GM04-617) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ЗАМОК ПАРКОВКИ(MX7) ↓ not found PLUG, PARK PAWL SHF HOLE (ЧАСТЬ OF CASE, A/TRNS - 04.103) not found SHAFT, PARK PAWL (ЧАСТЬ OF CASE, A/TRNS - 04.103) not found ПРУЖИНА, PARK PAWL (ЧАСТЬ OF CASE, A/TRNS - 04.103) not found PAWL, PARK (ЧАСТЬ OF CASE, A/TRNS - 04.103) 24242086 ACTUATOR, PARK PAWL (ACDelco #24242086) 24227077 PIN, MAN SHFT DTNT LVR HUB (ЧАСТЬ OF 505) 24234562 LEVER, MAN SHFT DTNT (INCLS 504) (ACDelco #24234562) 24225792 PIN, MAN SHFT SHF (ACDelco #24225792) 24235861 SEAL, MAN SHFT SHF (*KIT1) (ACDelco #24235861) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24225445 SHAFT, MAN SHFT (ACDelco #24225445) 24228969 SHAFT, MAN SHFT (ACDelco #24228969) 24224348 GUIDE, PARK PAWL ACTR (INCLS 510) 24224350 SEAL, PARK PAWL ACTR GDE (O RING) (ЧАСТЬ OF 509) (*KIT1) (ACDelco #24224350) 24226102 PIN, PARK PAWL ACTR GDE 96022192 PLUG, MAN SHFT SHF HOLE 24243891 SEAL KIT, A/TRNS SERV (INCLS 507, 510) (FULL TRANS) (ACDelco #24243891) (GM04-618) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ЗАМОК ПАРКОВКИ(MX0) ↓ not found PLUG, PARK PAWL SHF HOLE (ЧАСТЬ OF CASE, A/TRANS - 04.103) not found SHAFT, PARK PAWL (ЧАСТЬ OF CASE, A/TRNS - 04.103) not found ПРУЖИНА, PARK PAWL (ЧАСТЬ OF CASE, A/TRNS - 04.103) teamcadillac.ru not found PAWL, PARK (ЧАСТЬ OF CASE, A/TRNS - 04.103) 24242086 ACTUATOR, PARK PAWL (ACDelco #24242086) 24227077 PIN, MAN SHFT DTNT LVR HUB (ЧАСТЬ OF 505) 24234562 LEVER, MAN SHFT DTNT (INCLS 504) (ACDelco #24234562) 24225792 PIN, MAN SHFT SHF (ACDelco #24225792) 24235861 SEAL, MAN SHFT SHF (*KIT1) (ACDelco #24235861) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224348 GUIDE, PARK PAWL ACTR (INCLS 510) 24224350 SEAL, PARK PAWL ACTR GDE (O RING) (ЧАСТЬ OF 509) (*KIT1) (ACDelco #24224350) 24226102 PIN, PARK PAWL ACTR GDE 24225445 SHAFT, MAN SHFT (ACDelco #24225445) 24228969 SHAFT, MAN SHFT (ACDelco #24228969) 24243891 SEAL KIT, A/TRNS SERV (INCLS 507, 510) (FULL TRANS) (ACDelco #24243891) (GM04-667) - 2008 D69 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 24240017 CONVERTER, TORQ [ГИДРОТРАНСФОРМАТОР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] teamcadillac.ru 24243293 CONVERTER, TORQ not found ШЛАНГИ, T/CV (W/ ГИДРОНАСОС) (СМ. ГРУППУ 04.000 "TORQUE CONVERTOR ШЛАНГИ AND ГИДРОНАСОС" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11515762 БОЛТ, T/CV HSG (8.900) 24205899 PLUG, T/CV HSG ACC HOLE (28MM W/3 TANGS) (SMALL CVR) (ACDelco #24205899) 24225543 SEAL, A/TRNS ГИДРОНАСОС (ACDelco #24225543) [ПРОКЛАДКА КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] not found PIN, T/CV HSG LOC (ЧАСТЬ OF 7) 24242045 CASE, A/TRNS (INCLS 6, 12, 13) (ACDelco #24242045) 24242046 CASE, A/TRNS (INCLS 6, 12, 13) (ACDelco #24242046) 24226020 PLUG, TRANS FLUID FIL TUBE not found SEAL, A/TRNS WRG CONN (*KIT1, KIT2) not found SEAL, A/TRNS WRG CONN (O RING) (*KIT1, KIT2) 24239878 SLEEVE, A/TRNS ELEC CONN PASG [МУФТА] not found PLUG, A/TRNS CASE (ЧАСТЬ OF 7) 11515762 БОЛТ, T/CV HSG (8.900) not found SEAL, A/TRNS ГИДРОНАСОС (*KIT2) not found SEAL, A/TRNS ГИДРОНАСОС (*KIT2) 24225557 SEAL, CTR SUPT FLUID PASG (*KIT2) not found VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 24237181 БОЛТ, VLV BODY (M5X0.8X73.0) 24231074 БОЛТ, MAN SHFT DTNT (M10X1X14.5) not found DETENT, MAN SHFT not found SEAL, A/TRNS FLUID FLTR (ЧАСТЬ OF 26) 24236933 FILTER KIT, A/TRNS FLUID (INCLS 25) (ACDelco #24236933) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24225800 GASKET, A/TRNS FLUID PAN (ACDelco #24225800) [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 29535617 MAGNET, A/TRNS FLUID PAN (4.105) (ACDelco #29535617) [МАГНИТ] 24242410 PAN, A/TRNS FLUID (INCLS 31) (ACDelco #24242410) 11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (A/TRNS FLUID PAN) [БОЛТ М6] 24234212 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 29) (ACDelco #24234212) [ПРОБКА] 24205900 COVER, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] 24225783 SEAL, A/TRNS CASE EXTN (ACDelco #24225783) [УПЛОТНИТЕЛЬ КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24249873 EXTENSION, A/TRNS CASE (ACDelco #24249873) 24228876 SEAL, ВЫХОДНОЙ SHF (5.556) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24214158 BEARING, ВЫХОДНОЙ SHF (DRAWN CUP) (4.131) (ACDelco #24214158) 24230287 FLANGE, PROP SHF TRANS 24231524 ГАЙКА, FRT PROP SHF FLG (M22X1.5) (FLANGE HEX) 24229687 EXTENSION, A/TRNS CASE (MCHG) 24242995 BEARING, ВЫХОДНОЙ SHF [ПОДШИПНИК КПП] 24236928 SEAL KIT, A/TRNS ELEC CONN PASG SLEV (INCLS 9, 10) 24238913 SEAL KIT, A/TRNS SERV (CONTROL VLV SOL ASM) (ACDelco #24238913) [КОМПЛЕКТ ПРОКЛАДОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (5ШТ)] (TS04-045) - 2008 DM69 ТОРМОЗНОЙ СУППОРТ-ЗАДНИЙ ↓ 25997338 PAD KIT, RR DISC BRK (INCLS 2) not found ПРУЖИНА, RR DISC BRK PAD (ЧАСТЬ OF 1) 25997457 BRACKET, RR BRK CLPR 25997463 BRACKET, RR BRK CLPR 88935808 SEAL KIT, RR BRK CLPR GDE PIN (4.670) [ЗАЩИТНЫЙ ЧЕХОЛ ПОРШНЯ ТОРМОЗНОГО СУППОРТА] 15855612 PIN, RR BRK CLPR GDE 25843039 CALIPER, RR BRK (17" ТОРМОЗА) (INCLS 8-12) [ТОРМОЗНОЙ СУППОРТ] 25843039 CALIPER, RR BRK (INCLS 8-12) [ТОРМОЗНОЙ СУППОРТ] 25843040 CALIPER, RR BRK (17" ТОРМОЗА) (INCLS 8-12) [СУППОРТ] 25843040 CALIPER, RR BRK (INCLS 8-12) [СУППОРТ] 25843041 CALIPER, RR BRK (INCLS 8-12) [СУППОРТ] 25843042 CALIPER, RR BRK (INCLS 8-12) [СУППОРТ] 89027183 БОЛТ, RR BRK CLPR GDE PIN (M8X1.0) [БОЛТ М8] 88935785 CAP, RR BRK BLEDR VLV (ЧАСТЬ OF 6) [ЗАГЛУШКА ОБРАТНОГО КЛАПАНА] 89027179 VALVE, RR BRK BLEDR (ЧАСТЬ OF 6) not found SEAL, RR BRK CLPR PSTN (ЧАСТЬ OF 6) (*KIT1) 15926281 PISTON, RR BRK CLPR (18" H.D. ТОРМОЗА) (ЧАСТЬ OF 6) teamcadillac.ru 15926282 PISTON, RR BRK CLPR (17" ТОРМОЗА) (ЧАСТЬ OF 6) not found BOOT, RR BRK CLPR PSTN (ЧАСТЬ OF 6) (*KIT1) 25814676 SEAL KIT, RR BRK CLPR PSTN (INCLS 10, 12) 25814677 SEAL KIT, RR BRK CLPR PSTN (INCLS 10, 12) [КОМПЛЕКТ ПРОКЛАДОК] (TS04-726) - 2008 DM69 ТОРМОЗНОЙ СУППОРТ-ПЕРЕДНИЙ (J55) ↓ 15851479 CALIPER, FRT BRK (INCLS 2, 3, 8, 9, 11) (18") [СУППОРТ] 15851479 CALIPER, FRT BRK (INCLS 2, 3, 8, 9, 11) (18") [СУППОРТ] 15851480 CALIPER, FRT BRK (INCLS 2, 3, 8, 9, 11) (18") [СУППОРТ ТОРМОЗА] 15851480 CALIPER, FRT BRK (INCLS 2, 3, 8, 9, 11) (18") [СУППОРТ ТОРМОЗА] not found CAP, FRT BRK CLPR BLEDR VLV (ЧАСТЬ OF 1) 15851382 VALVE, FRT BRK CLPR BLEDR (ЧАСТЬ OF 1) 25809684 БОЛТ, FRT BRK CLPR HSG (GUIDE PIN) 25809681 PIN, FRT BRK CLPR GDE (W/O BUSHING) 25809679 PIN, FRT BRK CLPR GDE (INCLS 7) (W/PLASTIC SLEEVE 2.0MM FROM TIP) (W/BUSHING) not found BUSHING, FRT BRK CLPR GDE PIN (ЧАСТЬ OF 6, 10) not found SEAL, FRT BRK CLPR PSTN (ЧАСТЬ OF 1) (*KIT1) 15926289 PISTON, FRT BRK CLPR (ЧАСТЬ OF 1) 25814703 SEAL KIT, FRT BRK CLPR GDE PIN (INCLS 7) [ЗАСЛОНКА] teamcadillac.ru not found BOOT, FRT BRK CLPR PSTN (ЧАСТЬ OF 1) (*KIT1) 25958115 PAD KIT, FRT DISC BRK (INCLS 14) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4ШТ)] 15851384 BRACKET, FRT BRK CLPR (18") 15851384 BRACKET, FRT BRK CLPR (18") 15851476 BRACKET, FRT BRK CLPR (18") 15851476 BRACKET, FRT BRK CLPR (18") not found ПРУЖИНА, FRT DISC BRK PAD RET (ЧАСТЬ OF 12) 25814704 SEAL KIT, FRT BRK CLPR PSTN (INCLS 8, 11) [КОМПЛЕКТ УПЛОТНИТЕЛЬНЫХ КОЛЕЦ ТОРМОЗНОГО СУППОРТА (2ШТ)] 04 - АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (6D00-054) - 2008 DM69 ТРАНСМИССИЯ TO КРЕПЛЕНИЕ ДВИГАТЕЛЯ (AUTOMATIC MYB) ↓ 12603197 PLATE, A/TRNS FLEX 12603197 PLATE, A/TRNS FLEX 12603197 PLATE, A/TRNS FLEX teamcadillac.ru 12597210 PIN, TRANS LOC 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] 24242043 БОЛТ, TRANS CONV CVR (M6X1X18/M6X1X14) 24222918 COVER, TRANS CONV 24222918 COVER, TRANS (0.679) 24205900 COVER, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] (6D04-030) - 2008 DM69 ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР ↓ 18012741 SWITCH, BRK FLUID LVL IND (*KIT1) (ACDelco #18012741) 22688449 CAP, BRK M/CYL RSVR (INCLS 3) (*KIT1) [КРЫШКА БАЧКА ТОРМОЗНОЙ ЖИДКОСТИ] not found DIAPHRAGM, BRK M/CYL RSVR (ЧАСТЬ OF 2) (*KIT1) not found PIN, BRK M/CYL RSVR (ЧАСТЬ OF 5) (*KIT1) 18046711 RESERVOIR, BRK M/CYL (INCLS 4, 6, 7) (*KIT1) (ACDelco #18046711) not found SEAL, BRK M/CYL RSVR (ЧАСТЬ OF 5) (*KIT1) not found SEAL, BRK M/CYL RSVR (ЧАСТЬ OF 5) (*KIT1) not found RETAINER, BRK M/CYL PRIM PSTN SPR (*KIT1) not found PISTON, BRK M/CYL PRIM (*KIT1) not found SEAL, BRK M/CYL SECD PSTN PRIM (*KIT1) teamcadillac.ru not found RETAINER, BRK M/CYL SECD PSTN SPR (*KIT1) not found SEAL, BRK M/CYL (*KIT1) not found PISTON, BRK M/CYL SECD (*KIT1) not found ПРУЖИНА, BRK M/CYL SECD PSTN (*KIT1) not found BODY, BRK M/CYL (*KIT1) 15267509 CYLINDER, BRK MAS (INCLS 1-15) [БЛОК ЦИЛИНДРОВ] (6D04-033) - 2008 DM69 ТОРМОЗНОЙ УСИЛИТЕЛЬ ↓ 15267511 BOOSTER, P/B (INCLS 2-5) [ГИДРОУСИЛИТЕЛЬ ТОРМОЗНОЙ СИСТЕМЫ] not found GROMMET, P/B BOOS VAC CHK VLV (ЧАСТЬ OF 1, 3) 18022219 VALVE KIT, P/B BOOS VAC CHK (ЧАСТЬ OF 1) (INCLS 2) (BLACK) (INCLS VLV & GROM) (ACDelco #179-1266) teamcadillac.ru 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 1) (0.80 IN) (PUSH IN) 15849743 ROD, BRK PED PUSH (ЧАСТЬ OF 1) (6D04-047) - 2008 DM69 ТОРМОЗНАЯ ПЕДАЛЬ ↓ not found REINFORCEMENT, STRG COL SUPT BRKT 25785092 BARRIER, BRK PED BRKT SND 25913292 BARRIER, BRK PED BRKT SND not found BRACKET, BRK PED (ЧАСТЬ OF 13) not found ГАЙКА, BRK PED BRKT BR (ЧАСТЬ OF 13) 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (ЧАСТЬ OF 13) (ACDelco #11517518) [БОЛТ] teamcadillac.ru 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] not found STUD, BRK PED BRKT (ЧАСТЬ OF 13) not found BRACKET, BRK PED (ЧАСТЬ OF 13) 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 13) (0.80 IN) (PUSH IN) 15849743 ROD, BRK PED PUSH (ЧАСТЬ OF 13) 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 13) 25771615 COVER, BRK PED (ЧАСТЬ OF 13) 15254562 PEDAL, BRK (W/BRKT) (INCLS 3-5, 7-12, 14-19) 15254563 PEDAL, BRK (W/BRKT) (INCLS 3-5, 7-12, 14-19) 25814705 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 13) (INCLS 19) [ДАТЧИК] not found PIN, BRK PED PUSH ROD (ЧАСТЬ OF 13) not found PIN, BRK PED PIV (ЧАСТЬ OF 13) 15594358 BUSHING, BRK PED PIV (ЧАСТЬ OF 13) (0.831) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 13) 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 13, 14) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] (6D04-053) - 2008-2010 DM69 6-ТИ СКОРОСТНАЯ МКПП ЧАСТЬ 1 (MV7) ASM ↓ teamcadillac.ru 24242917 ТРАНСМИССИЯ, MAN [ТРАНСМИССИЯ] (6D04-054) - 2008-2010 DM69 6-ТИ СКОРОСТНАЯ МКПП ЧАСТЬ 2 (MV7) CASE COMPONENTS ↓ teamcadillac.ru 89058852 БОЛТ, CLU ACTR (M6X1.0X20) 89048559 БОЛТ, CLU ACTR (M8X1.25X20) (4.104) 89058759 CASE, TRANS INTER (INCLS 8, 9) 89058774 BEARING, SHFT CONT SHF (ЧАСТЬ OF 7) (4.408) 89058791 PIN, TRANS INTER CASE LOC (ЧАСТЬ OF 7) 19178542 CASE, TRANS FRT (INCLS 12-16) 89058833 SEAL, MAIN SHF (ЧАСТЬ OF 11) not found SHIELD, INPUT SHF BRG OIL (ЧАСТЬ OF 11) 89058791 PIN, TRANS INTER CASE LOC (ЧАСТЬ OF 11) 89059311 PIN, TRANS CASE LOC (ЧАСТЬ OF 11) 89059312 PLUG, TRANS CASE HOLE (ЧАСТЬ OF 11) not found TROUGH, TRANS RR CASE OIL 89058837 SLINGER, INPUT SHF BRG OIL 89058839 TROUGH, M/TRNS OIL 89058840 TROUGH, TRANS INTER CASE OIL not found RETAINER, CNTR GR BRG 89058820 RETAINER, CNTR GR BRG (4.352) 89058760 CASE, TRANS RR (INCLS 24-26) not found BUSHING, SHFT SHF (ЧАСТЬ OF 23) 89058774 BEARING, SHFT SHF (ЧАСТЬ OF 23) 89058791 PIN, TRANS INTER CASE LOC (ЧАСТЬ OF 23) 89058853 БОЛТ, TRANS INTER CASE (M10X1.25X40) (4.104) 89058854 БОЛТ, TRANS INTER CASE (M10X1.25X80) (4.104) 89059319 GASKET, TRANS RR CASE 89058843 PLUG, CLU HSG HOLE 89059313 VENT, M/TRNS 89059314 SEAL, REV IDLER GR SHF (O RING) (ACDelco #89059314) 89048245 GASKET, TRANS OIL DRN PLUG (ACDelco #89048245) 19132842 PLUG, TRANS OIL DRN (4.510) 89059315 БОЛТ, REV IDLER GR SHF RET 19132971 PLUG, SHFT SHF DTNT 89048559 БОЛТ, TRANS INTER CASE OIL TROUGH (M8X1.25X20) (4.104) 89058855 БОЛТ, CNTR GR BRG RET (M8X1.25X25) 89058860 DETENT, SHFT SHF 89059329 DETENT, SHFT SHF (CAM) 19178544 ПРУЖИНА, SHFT SHF DTNT 89048248 PLUG, TRANS OIL FIL 89048248 PLUG, TRANS OIL FIL (4.104) 19178541 EXTENSION, TRANS (INCLS 87, 88) 89058838 SLINGER, INPUT SHF BRG OIL (ЗАДНИЙ) (ЧАСТЬ OF 86) 19180996 SEAL, SHFT CONT SHF (ЧАСТЬ OF 86) 89058835 SEAL, RR ВЫХОДНОЙ SHF 88972750 БОЛТ, TRANS EXTN (M8X1.25X40) (8.900) 19178540 FLANGE, TRANS PROP SHF 19132973 ГАЙКА, PROP SHF TRANS FLG 89058775 BEARING, REV IDLER GR 89058836 SEAL, PROP SHF TRANS FLG FLUID 89058790 SHAFT, REV IDLER GR 89058789 GEAR, REV IDLER 89059321 SWITCH, B/U LP (ACDelco #D2271C) 89059318 RETAINER, B/U LP SW 89058851 SENSOR, M/TRNS ВЫХОДНОЙ SPD (4.337) 89058851 SENSOR, M/TRNS ВЫХОДНОЙ SPD 89058852 БОЛТ, VEH SPD SEN (M6X1.0X20) (0.780) 89058852 БОЛТ, VEH SPD SEN (M6X1.0X20) (0.780) 24242161 CYLINDER, CLU ACTR [ЦИЛИНДР] 89048245 GASKET, TRANS OIL FILL PLUG (ACDelco #89048245) (6D04-055) - 2008-2010 DM69 6-ТИ СКОРОСТНАЯ МКПП ЧАСТЬ 3 (MV7) ВХОДНОЙ И ВЫХОНОЙ ВАЛ COMPONENTS ↓ 89058782 BEARING, RR ВЫХОДНОЙ MAIN SHF RR 89058801 RING, 3RD GR BLOCKING 89058812 SLINGER, MAIN SHF BRG OIL (4.345) 19178534 SHAFT, RR MAIN 19132975 WASHER, 3RD GR THR 89058805 HUB, 3RD & 4TH GR SYN 19132845 SLEEVE, 3RD & 4TH GR SYN 19178535 INSERT, 3RD & 4TH GR SYN 89058792 RING, 4TH GR BLOCKING 19132849 ПРУЖИНА, 3RD & 4TH GR SYN 89058806 HUB, 5TH & 6TH GR SYN 89058810 BALL, 3RD & 4TH GR SYN DTNT 89058776 BEARING, INPUT SHF (RADIAL BALL) 89058777 BEARING, 4TH GR 89058779 BEARING, 6TH GR 89058778 BEARING, 3RD GR 89058780 BEARING, INPUT SHF (ROLLER) (ROLLER) 89058781 BEARING, RR ВЫХОДНОЙ SHF FRT 89059345 RING KIT, 3RD & 4TH GR RET 89059346 RING KIT, 5TH & 6TH GR SYN RET 89059347 RING KIT, 6TH GR RET 89059348 RING KIT, INPUT SHF BRG RET 89058813 RING, INPUT SHF BRG RET 89058863 SPACER, 6TH GR BRG 89058861 SPACER, 3RD & 4TH GR 89058864 SPACER, RR MAIN SHF RR BRG teamcadillac.ru 89048344 PIN, GR THR WA LOC (4.419) 19178537 GEAR, 3RD 19178538 GEAR, 4TH 19178536 GEAR, 6TH 19178539 SHAFT, INPUT 89058773 GEAR, VEH SPD SEN DRV 89048423 BALL, SPEEDO DRV GR LOC 89058810 BALL, 5TH GR SYN DTNT 19178535 INSERT, 5TH & 6TH GR SYN not found ПРУЖИНА, 5TH & 6TH GR SYN 19132849 ПРУЖИНА, 5TH & 6TH GR SYN 19132845 SLEEVE, 5TH & 6TH GR SYN 89058792 RING, 6TH GR BLOCKING (4.383) 89058792 RING, 5TH GR BLOCKING (6D04-056) - 2008-2010 DM69 6-ТИ СКОРОСТНАЯ МКПП ЧАСТЬ 4 (MV7) COUNTERSHAFT COMPONENTS ↓ 89058794 RING SET, 1ST GR BLOCKING (INCLS 96-98) not found CONE, 1ST GR SYN INR (ЧАСТЬ OF 95) not found CONE, 1ST GR SYN OTR (ЧАСТЬ OF 95) not found RING, 1ST GR OTR BLOCKING (ЧАСТЬ OF 95) 89058786 GEAR, REV GR DRV 89058865 BUSHING, REV GR BRG 89058807 HUB, 1ST & 2ND GR SYN 89058803 SLEEVE, 1ST & 2ND GR SYN 89058808 INSERT, 1ST & 2ND GR SYN 89058809 INSERT, REV GR SYN 89058793 RING, REV GR BLOCKING 89058811 ПРУЖИНА, 1ST & 2ND GR SYN 89058804 SLEEVE, REV GR SYN 89058810 BALL, 1ST & 2ND GR SYN DTNT 89058783 BEARING, CNTR GR FRT 89058785 BEARING, REV GR 89058787 BEARING, 1ST GR 89058788 BEARING, 2ND GR 89058784 BEARING, CNTR GR RR 89059343 RING, CNTR GR FRT BRG RET not found RING KIT, 1ST & 2ND GR SYN HUB RET teamcadillac.ru 89059344 RING KIT, 1ST & 2ND GR SYN HUB RET 89058822 RETAINER, CNTR GR FRT BRG 89048423 BALL, REV GR THR WA LOC (4.345) 89048329 ПРУЖИНА, REV GR SYN (4.384) 89058770 GEAR, 1ST 19178532 GEAR, 2ND 19178533 GEAR, CNTR 89058769 GEAR, REV 89058794 RING SET, 2ND GR BLOCKING (INCLS 905-907) not found RING, 2ND GR OTR BLOCKING (ЧАСТЬ OF 904) not found CONE, 2ND GR SYN OTR (ЧАСТЬ OF 904) not found CONE, 2ND GR SYN INR (ЧАСТЬ OF 904) 89059343 RING, CNTR GR FRT BRG RET (6D04-057) - 2008-2010 DM69 6-ТИ СКОРОСТНАЯ МКПП ЧАСТЬ 5 (MV7) SHIFT FORKS ↓ 19180997 JOINT, M/TRNS SHFT LVR ROD UNIVERSAL 19180067 PIN, M/TRNS SHFT LVR not found RETAINER, M/TRNS SEL SHF LVR ROD GROM 89059340 BRACKET, SHFT CONT LVR teamcadillac.ru 89059331 CAM, SHFT SHF DTNT 89058762 FORK, 1ST & 2ND SHFT (INCLS BUSHINGS) 89058763 FORK, 3RD & 4TH SHFT (INCLS INSERTS) 89059342 ARM, CONT SEL 89058825 PIN, CONT SEL ARM 89058764 FORK, 5TH & 6TH SHFT (INCLS INSERTS) 89059332 LEVER, SHFT 19132858 LEVER, INTL SHFT CONT 19132857 LEVER, SEL CONT 89058830 SHAFT, 1ST & 2ND SHFT 89059333 SHAFT, 3RD & 4TH SHFT 89059335 SHAFT, 5TH & 6TH SHFT 19132859 SHAFT, REV SHFT 89058832 LEVER, SHFT SHF DTNT 89058765 FORK, REV SHFT (INCLS INSERTS) 89058829 SHAFT, SHFT CONT 89059329 DETENT, SHFT SHF (CAM) (CAM) 89048287 БОЛТ, 3RD & 4TH SHFT FORK 89048272 PIN, SEL CONT LVR (4.008) 89048289 PIN, REV SHFT FORK (4.303) 89059339 ROLLER, SHFT SHF DTNT 19178531 ПРУЖИНА, SHFT DTNT BALL 19178544 ПРУЖИНА, SHFT SHF DTNT 89058857 БОЛТ, SHFT SHF DTNT LVR (M8X1.0X21.2) 89059338 PIN, SHFT SHF INTLK (M4X11.2) 89059337 PIN, SHFT SHF INTLK (M6X13.6) 89048292 BALL, SHFT DTNT 89058858 БОЛТ, SHFT CONT LVR BRKT (M8X1.25X32) 89058824 RETAINER, SEL CONT LVR PIN 89059316 PIN, SHFT SHF (4.408) 89058842 WEIGHT, SHFT LVR C/BAL (EXTERNAL) (4.105) 89059320 BLOCK, SHFT CONT SHF 89048272 PIN, SHFT LVR (4.008) 89048272 PIN, 1ST & 2ND SHFT FORK (4.008) 89048287 БОЛТ, 5TH & 6TH SHFT FORK (6D04-063) - 2008-2009 DM69 КОРПУС КП КРЕПЛЕНИЕ (ПОЛНОПРИВОДНЫЙ MX7) ↓ 24231525 GASKET, TRFER CASE teamcadillac.ru 24249544 CASE, TRFER (W/GEARS) 11589341 БОЛТ - HFH, M10X1.5X69.9, 28.35 THD, 22.3 OD, 10.9, GMW3359, M-PT. (TRFER CASE) [БОЛТ] 19179016 DAMPENER, TRFER CASE VIB (AT RR OF CASE) (6D04-072) - 2008-2009 DM69 ТОРМОЗНЫЕ МАГИСТРАЛИ-ПЕРЕДНИЕ (ЗАДНИЙ КОЛЕСО DRIVE MN6,MX0) ↓ 15904905 PIPE, BRK PRESS MOD VLV FRT [ТРУБКА ТОРМОЗНОЙ СИСТЕМЫ] 15904915 SPACER, FRT BRK PIPE not found CYLINDER, BRK MAS (СМ. ГРУППУ 04.000 "ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 15904908 PIPE, BRK PRESS MOD VLV RR [НАСОС В СБОРЕ] not found БОЛТ, FRT BRK HOSE (ЧАСТЬ OF 8, 20) 21012386 WASHER, FRT BRK HOSE (ЧАСТЬ OF 8, 20) (10.3X14.5X1.61) (COPPER) (ACDelco #21012386) [ШАЙБА 10 ММ] 11516546 БОЛТ, HFL, M8X1.25X50, 37.2 THD, 18 OD, 10.9, PZO 7114M (FRT S/ABS) 15818105 HOSE, FRT BRK (INCLS 5, 6, 9, 10) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ] 11569742 RETAINER, FRT BRK HOSE (ЧАСТЬ OF 8, 20) (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] not found BRACKET, FRT BRK HOSE (ЧАСТЬ OF 8) 11514623 БОЛТ, HEX W/CON WA, M6X1X20 (FRT BRK HOSE) 11569751 ГАЙКА, HX TUBE INVERTED FLARE, M10X1X16, SAE1010, GMW4707M (FRT BRK PIPE) [ШАЙБА] 88983905 PIPE, BRK (3/16" X 16 FT) (BULK TUBING) (NYLON COATING) [ТРУБКА ТОРМОЗНОЙ СИСТЕМЫ] 25957289 RETAINER, FRT BRK PIPE (4 TUBE W/TREE) 15904901 RETAINER, FRT BRK PIPE (STAR SHAPED 3 TUBE W/TREE) [КРОНШТЕЙН] 12477665 PROTECTOR, FRT BRK PIPE (FOR 1/4" PIPE) (HT SHRINK) not found VALVE, BRK PRESS MOD (W/ELEK BRK & TRACT CONT MDL) (СМ. ГРУППУ 04.000 "КЛАПАН РЕГУЛИРОВКИ ДАВЛЕНИЯ В ТОРМОЗНОЙ СИСТЕМЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11569750 ГАЙКА, HX FLARED TUBE, M12X1.0X17, 5.3 TUBE, SAE1010, GMW4707M (FRT BRK PIPE) [ФИТИНГ ТРУБКИ ТОРМОЗНОЙ СИСТЕМЫ] not found BRACKET, FRT BRK HOSE (ЧАСТЬ OF 20) teamcadillac.ru 15818106 HOSE, FRT BRK (INCLS 5, 6, 9, 19) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ] (6D04-073) - 2008-2009 DM69 ТОРМОЗНЫЕ МАГИСТРАЛИ-ПЕРЕДНИЕ (ПОЛНОПРИВОДНЫЙ MX7) ↓ 15904910 PIPE, BRK PRESS MOD VLV RR [ТРУБКА] 15904915 SPACER, FRT BRK PIPE teamcadillac.ru not found CYLINDER, BRK MAS (СМ. ГРУППУ 04.000 "ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 15904907 PIPE, BRK PRESS MOD VLV FRT [НАСОС В СБОРЕ] 11570052 FITTING, FRT BRK HOSE (ЧАСТЬ OF 7) (M10X1X27.5, 16.9THD) (4.671) 21012386 WASHER, FRT BRK HOSE (ЧАСТЬ OF 7) (10.3X14.5X1.61) (COPPER) (ACDelco #21012386) [ШАЙБА 10 ММ] 25928987 HOSE, FRT BRK (INCLS 5, 6) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ] 25928988 HOSE, FRT BRK (INCLS 5, 6) 11516521 БОЛТ, HFH M6X1X20, 9.8, 7114M, DOG PT, 14.2 OD (FRT BRK HOSE) 11569742 RETAINER, FRT BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 11569751 ГАЙКА, HX TUBE INVERTED FLARE, M10X1X16, SAE1010, GMW4707M (FRT BRK PIPE) [ШАЙБА] 88983905 PIPE, BRK (3/16" X 16 FT) (BULK TUBING) (NYLON COATING) [ТРУБКА ТОРМОЗНОЙ СИСТЕМЫ] 15904902 RETAINER, FRT BRK PIPE (UPSIDE DOWN 3 TUBE CLIP W/O TREE) [КРОНШТЕЙН] 15904903 RETAINER, FRT BRK PIPE (UPSIDE DOWN 3 TUBE WITH TREE) [КРОНШТЕЙН] 12477665 PROTECTOR, FRT BRK PIPE (FOR 1/4" PIPE) (HT SHRINK) 88964150 PROTECTOR, FRT BRK PIPE (FOR 3/16" PIPE) (HT SHRINK) 15904901 RETAINER, FRT BRK PIPE (STAR SHAPED 3 TUBE W/TREE) [КРОНШТЕЙН] not found VALVE, BRK PRESS MOD (W/ELEK BRK & TRACT CONT MDL) (СМ. ГРУППУ 04.000 "КЛАПАН РЕГУЛИРОВКИ ДАВЛЕНИЯ В ТОРМОЗНОЙ СИСТЕМЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11569750 ГАЙКА, HX FLARED TUBE, M12X1.0X17, 5.3 TUBE, SAE1010, GMW4707M (FRT BRK PIPE) [ФИТИНГ ТРУБКИ ТОРМОЗНОЙ СИСТЕМЫ] (6D04-074) - 2008 DM69 ТОРМОЗНЫЕ МАГИСТРАЛИ-ЗАДНИЕ ↓ 15818185 HOSE, RR BRK (INCLS 2, 3, 5, 6) [ТРУБКА] 21012386 WASHER, RR BRK HOSE (ЧАСТЬ OF 1, 12) (10.3X14.5X1.61) (COPPER) (ACDelco #21012386) [ШАЙБА 10 ММ] not found БОЛТ, RR BRK HOSE (ЧАСТЬ OF 1, 12) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (RR BRK HOSE BRKT) [ГАЙКА М6] not found BRACKET, RR BRK HOSE (ЧАСТЬ OF 1) 11569742 RETAINER, RR BRK HOSE (ЧАСТЬ OF 1) (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 11569742 RETAINER, RR BRK HOSE (ЧАСТЬ OF 1) (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 11569751 ГАЙКА, HX TUBE INVERTED FLARE, M10X1X16, SAE1010, GMW4707M (RR BRK PIPE) [ШАЙБА] 88983905 PIPE, BRK (3/16" X 16 FT) (BULK TUBING) (NYLON COATING) [ТРУБКА ТОРМОЗНОЙ СИСТЕМЫ] 15194329 CLIP, RR BRK PIPE (27X35X15) 88964150 PROTECTOR, FRT BRK PIPE (FOR 3/16" PIPE) (HT SHRINK) 15818187 HOSE, RR BRK (INCLS 2, 3) [ТРУБКА] 25607191 RETAINER, BRK PIPE (21.5X10.0MM) (HOLDS (2) 4.68-4.82 TUBES) 25607191 RETAINER, BRK PIPE (21.5X10.0MM) (HOLDS (2) 4.68-4.82 TUBES) 15870391 RETAINER, BRK & FUEL PIPE (HOLDS FOUR LINES) 15870391 RETAINER, BRK & FUEL PIPE (HOLDS FOUR LINES) (3.162) 11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (FUEL FLTR BRKT) [БОЛТ М8] 15223307 RETAINER, BRK & FUEL PIPE (2 FUEL/VAPOR LINES) 15223307 RETAINER, BRK & FUEL PIPE (2 FUEL/VAPOR LINES) (3.162) 15223304 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (HOLDS FOUR LINES) (3.890) 15223306 RETAINER, BRK & FUEL PIPE (2 FUEL/VAPORS LINE & 2 BRAKE LINES) 15223306 RETAINER, BRK & FUEL PIPE (2 FUEL/VAPORS LINE & 2 BRAKE LINES) (3.162) 88964150 PROTECTOR, BRK PIPE (FOR 3/16" PIPE) (HT SHRINK) 15223308 RETAINER, BRK & FUEL PIPE (ATTACHES TO BRKT) 15223308 RETAINER, BRK & FUEL PIPE (ATTACHES TO BRKT) (3.162) 25761218 BRACKET, FUEL PIPE teamcadillac.ru 11514623 БОЛТ, HEX W/CON WA, M6X1X20 (FUEL FEED & EVAP EMIS & RTN PIPE CLIP BRKT) 25957289 RETAINER, FRT BRK PIPE (4 TUBE W/TREE) 11569750 ГАЙКА, HX FLARED TUBE, M12X1.0X17, 5.3 TUBE, SAE1010, GMW4707M (FRT BRK PIPE) [ФИТИНГ ТРУБКИ ТОРМОЗНОЙ СИСТЕМЫ] not found VALVE, BRK PRESS MOD (W/ELEK BRK & TRACT CONT MDL) (СМ. ГРУППУ 04.000 "КЛАПАН РЕГУЛИРОВКИ ДАВЛЕНИЯ В ТОРМОЗНОЙ СИСТЕМЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6D04-076) - 2008-2009 DM69 СТОЯНОЧНЫЙ ТОРМОЗ SYSTEM ↓ 15836531 REINFORCEMENT, PARK BRK LVR BRKT (INCLS 2) 11610157 ГАЙКА, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (ЧАСТЬ OF 1) (10.701) [ГАЙКА М4] 25880964 HANDLE, PARK BRK REL 11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (PARK BRK REL HDL) [ВИНТ] 25791543 CABLE, PARK BRK REL (ЧАСТЬ OF 6) 25885037 LEVER, PARK BRK (INCLS 5, 7-9) not found PAD, PARK BRK LVR PED (ЧАСТЬ OF 6) 10369646 БОЛТ, PARK BRK IND SW (ЧАСТЬ OF 6) 22654577 SWITCH, PARK BRK IND (ЧАСТЬ OF 6) (ACDelco #22654577) [ВКЛЮЧАТЕЛЬ] 15242114 CABLE, PARK BRK INTER (INCLS 14) [КАБЕЛЬ] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (PARK BRK INTER CBL GDE) [ГАЙКА М6] 11518625 БОЛТ, PAN, M10X1.5X35, 33.5THD, 20 O.D., 10.9, 6138M (PARK BRK INTER CBL GDE) teamcadillac.ru 20774147 CABLE, PARK BRK RR 20823796 CONNECTOR, PARK BRK CBL (ЧАСТЬ OF 10) 11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (I/P LWR BRKT) [ВИНТ] 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (PARK BRK REL HDL BRKT) [ВИНТ М4] (6D04-077) - 2008-2009 DM69 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (MYB, ПОЛНОПРИВОДНЫЙ MX7, EXC EXTRA CAPACITY V03, HEAVY DUTY V08) ↓ 24237658 SEAL, TRANS FLUID CLR PIPE FTG (SEALS ONE PIPE) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ] 15251488 SEAL, TRANS FLUID CLR HOSE (ЧАСТЬ OF 4) (SEALS TWO ТРУБКИ) [УПЛОТНЕНИЕ] 11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) [БОЛТ, М8Х1.25Х31.5] 15853683 HOSE, TRANS FLUID CLR (INCLS 2, 6, 7, 10) [ТРУБКА] 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] teamcadillac.ru 10405874 CLIP, TRANS FLUID CLR HOSE (ЧАСТЬ OF 4) (LESS MNTG TAB) (HOLDS TWO 9.5 DIA TUBES) 15052228 CЛАМПА, TRANS FLUID CLR HOSE (ЧАСТЬ OF 4) (PLASTIC RETAINER) (ACDelco #15052228) [ФИТИНГ ТРУБОПРОВОДА] not found FITTING, TRANS FLUID CLR PIPE not found RETAINER, TRANS FLUID CLR PIPE FTG not found BRACKET, TRANS OIL CLR INL & OTLT PIPE (ЧАСТЬ OF 4) (6D04-078) - 2008 DM69 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (MYB, ЗАДНИЙ КОЛЕСО DRIVE MX0, EXC EXTRA CAPACITY V03, HEAVY DUTY V08) ↓ 24237658 SEAL, TRANS FLUID CLR PIPE FTG (SEALS ONE PIPE) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ] 15251488 SEAL, TRANS FLUID CLR HOSE (ЧАСТЬ OF 3) (SEALS TWO ТРУБКИ) [УПЛОТНЕНИЕ] 15267714 HOSE, TRANS FLUID CLR (INCLS 2, 5, 6, 9) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) [БОЛТ, М8Х1.25Х31.5] 10405874 CLIP, TRANS FLUID CLR HOSE (ЧАСТЬ OF 3) (LESS MNTG TAB) (HOLDS TWO 9.5 DIA TUBES) 15052228 CЛАМПА, TRANS FLUID CLR HOSE (ЧАСТЬ OF 3) (PLASTIC RETAINER) (ACDelco #15052228) [ФИТИНГ ТРУБОПРОВОДА] not found FITTING, TRANS FLUID CLR PIPE not found RETAINER, TRANS FLUID CLR PIPE FTG not found BRACKET, TRANS OIL CLR INL & OTLT PIPE (ЧАСТЬ OF 3) 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] (6D04-079) - 2008-2009 DM69 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (MYB, ПОЛНОПРИВОДНЫЙ MX7, EXTRA CAPACITY V03, HEAVY DUTY V08) ↓ 25829909 COOLER, TRANS FLUID AUX (INCLS 13-15) (ACDelco #25829909) [ОХЛАДИТЕЛЬ] not found RETAINER, TRANS FLUID CLR PIPE FTG teamcadillac.ru 25830126 CLIP, TRANS FLUID CLR PIPE not found BRACKET, TRANS OIL CLR INL & OTLT PIPE (ЧАСТЬ OF 8) 24237658 SEAL, TRANS FLUID CLR PIPE FTG (SEALS ONE PIPE) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ] 15251488 SEAL, TRANS FLUID CLR HOSE (ЧАСТЬ OF 8) (SEALS TWO ТРУБКИ) [УПЛОТНЕНИЕ] 11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) [БОЛТ, М8Х1.25Х31.5] 25829902 HOSE, TRANS FLUID CLR (INCLS 4, 6, 11) [ШЛАНГ] 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 10405874 CLIP, TRANS FLUID CLR HOSE (LESS MNTG TAB) (HOLDS TWO 9.5 DIA TUBES) 15052228 CЛАМПА, TRANS FLUID CLR HOSE (ЧАСТЬ OF 8) (PLASTIC RETAINER) (ACDelco #15052228) [ФИТИНГ ТРУБОПРОВОДА] 25829910 PIPE, TRANS FLUID AUX CLR (INCLS 17) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 19129762 FITTING, TRANS FLUID CLR PIPE (ЧАСТЬ OF 1) [СОЕДИНИТЕЛЬ] 24205103 RETAINER, TRANS FLUID AUX CLR (ЧАСТЬ OF 1) (EXPANDING ПРУЖИНА WIRE) (ACDelco #24205103) [СТОПОРНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ] 10405874 CLIP, TRANS FLUID CLR HOSE (ЧАСТЬ OF 1) (LESS MNTG TAB) (HOLDS TWO 9.5 DIA TUBES) 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 15052228 CAP, TRANS FLUID CLR PIPE CONN (ЧАСТЬ OF 12) (PLASTIC RETAINER) (ACDelco #15052228) [ФИТИНГ ТРУБОПРОВОДА] not found FITTING, TRANS FLUID CLR PIPE (6D04-080) - 2008 DM69 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (MYB, ЗАДНИЙ КОЛЕСО DRIVE MX0, EXTRA CAPACITY V03, HEAVY DUTY V08) ↓ 25829909 COOLER, TRANS FLUID AUX (INCLS 13-15) (ACDelco #25829909) [ОХЛАДИТЕЛЬ] not found RETAINER, TRANS FLUID CLR PIPE FTG 25830126 CLIP, TRANS FLUID CLR PIPE 11516149 ГАЙКА, U, 8X1.25, MULTI THD, .08'-4.0' THK PNL, PZ (TRANS FLUID CLR HOSE CLIP BRKT) [ГАЙКА М8] 24237658 SEAL, TRANS FLUID CLR PIPE FTG (SEALS ONE PIPE) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ] 15251488 SEAL, TRANS FLUID CLR HOSE (ЧАСТЬ OF 8) (SEALS TWO ТРУБКИ) [УПЛОТНЕНИЕ] 11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) [БОЛТ, М8Х1.25Х31.5] 25829896 HOSE, TRANS FLUID CLR (INCLS 6, 9, 11, 19) [ШЛАНГ] 10405874 CLIP, TRANS FLUID CLR HOSE (ЧАСТЬ OF 8) (LESS MNTG TAB) (HOLDS TWO 9.5 DIA TUBES) 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] not found BRACKET, TRANS OIL CLR INL & OTLT PIPE (ЧАСТЬ OF 8) 25829910 PIPE, TRANS FLUID AUX CLR (INCLS 17) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 19129762 FITTING, TRANS FLUID CLR PIPE (ЧАСТЬ OF 1) [СОЕДИНИТЕЛЬ] 24205103 RETAINER, TRANS FLUID AUX CLR (ЧАСТЬ OF 1) (EXPANDING ПРУЖИНА WIRE) (ACDelco #24205103) [СТОПОРНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ] teamcadillac.ru not found CLIP, TRANS FLUID CLR HOSE (ЧАСТЬ OF 1) 11570324 БОЛТ, TRANS FLUID CLR (M6X1X14, 9 THD) (9.190) 15052228 CAP, TRANS FLUID CLR PIPE CONN (ЧАСТЬ OF 12) (PLASTIC RETAINER) (ACDelco #15052228) [ФИТИНГ ТРУБОПРОВОДА] not found FITTING, TRANS FLUID CLR PIPE 15052228 CЛАМПА, TRANS FLUID CLR HOSE (ЧАСТЬ OF 8) (PLASTIC RETAINER) (ACDelco #15052228) [ФИТИНГ ТРУБОПРОВОДА] (6D04-081) - 2008 DM69 BRAKES-ВЕНТИЛЯЦИЯ ↓ 25940079 EXTENSION, FRT BPR FASCIA (СМ. ГРУППУ 07.000 "БАМПЕР ПЕРЕДНИЙ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/HOLE) [ПОДКРЫЛОК] 25940080 EXTENSION, FRT BPR FASCIA (СМ. ГРУППУ 07.000 "БАМПЕР ПЕРЕДНИЙ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/HOLE) [БОКОВАЯ ПАНЕЛЬ БАМПЕРА] 15272166 DUCT, FRT BRK CLPR CLG (CONNECTS TO FRT WHL EXTN) [ТРУБКА ВОЗДУХОВОДА] 15272167 DUCT, FRT BRK CLPR CLG (CONNECTS TO FRT FASCIA) [ТРУБКА] 15272168 DUCT, FRT BRK CLPR CLG (CONNECTS TO FRT FASCIA) [ТРУБКА] 20772527 DUCT, FRT BRK CLPR CLG (CONNECTS TO FRT FASCIA) [ВОЗДУХОЗАБОРНИК ТОРМОЗНОЙ СИСТЕМЫ] 20772528 DUCT, FRT BRK CLPR CLG (CONNECTS TO FRT FASCIA) [ВОЗДУХОЗАБОРНИК ТОРМОЗНОЙ СИСТЕМЫ] 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (FRT FOG LP BRKT) [ВИНТ М4] 25536302 ГАЙКА, FRT BPR UPR FASCIA (4.2 X 1.41) (TAPPING NUT) (3.430) [ПРИЖИМНАЯ ПЛАСТИНА ПАНЕЛИ КУЗОВА] 15272157 BEZEL, FRT FOG LP (FOR VEHICLES BUILT W/FRONT BRAKE ОХЛАЖДЕНИЕ DUCTS) (ON VEH BUILT BEFORE 3/31/08 OR IF REPLACED BEZEL HAS OPENINGS/SLOTSMUST ALSO ORDER 25961369) 15904574 BEZEL, FRT FOG LP [НАКЛАДКА ПАНЕЛИ БАМПЕРА] 15904575 BEZEL, FRT FOG LP [ОКАНТОВКА ПРОТИВОТУМАННОЙ ФАРЫ] 25961369 BEZEL, FRT FOG LP (FOR VEHICLES BUILT W/ FRONT BRAKE ОХЛАЖДЕНИЕ DUCTS) (ON VEH BUILT BEFORE 3/31/08 OR IF REPLACED BEZEL HAS OPENINGS/SLOTS, MUST ALSO ORDER 25961370) 10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (FRT BRK CLPR CLG DUCT) [ПИСТОН КРЕПЛЕНИЯ ОБЛИЦОВКИ БАМПЕРА (NYLON)] teamcadillac.ru 11561857 CLIP, FRT FOG LP ADJ БОЛТ RET (BLACK) (14.13 X 11 X 8.6) (7.831) (6D04-082) - 2008-2009 DM69 УПРАВЛЕНИЕ АКПП/АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) ↓ 25887055 PLATE, F/FLR CNSL TRANS SHFT OPG TR (INCLS 2, 3, 13-15) [РАМКА РЫЧАГА ПЕРЕКЛЮЧЕНИЯ ПЕРЕДАЧ] 25801116 INDICATOR, A/TRNS CONT (ЧАСТЬ OF 1) 11509231 SCREW, RD HD C/R TAP, M4.2X1.41X13.0, GM6010M STL, GM813M NICKEL ORGANIC (ЧАСТЬ OF 1) [ВИНТ М6Х12] 25907978 CONTROL, A/TRNS (INCLS 5-8) [БЛОК УПРАВЛЕНИЯ] 25907978 CONTROL, A/TRNS (INCLS 5-8) (4.004) [БЛОК УПРАВЛЕНИЯ] 25907979 CONTROL, A/TRNS (INCLS 5-8) [БЛОК УПРАВЛЕНИЯ] 25907979 CONTROL, A/TRNS (INCLS 5-8) (4.004) [БЛОК УПРАВЛЕНИЯ] 25907980 CONTROL, A/TRNS (INCLS 5-8) [БЛОК УПРАВЛЕНИЯ] 25907980 CONTROL, A/TRNS (INCLS 5-8) (4.004) [БЛОК УПРАВЛЕНИЯ] 25907981 CONTROL, A/TRNS (INCLS 5-8) [БЛОК УПРАВЛЕНИЯ] 25907981 CONTROL, A/TRNS (INCLS 5-8) (4.004) [БЛОК УПРАВЛЕНИЯ] 25907982 CONTROL, A/TRNS (INCLS 5-8) [БЛОК УПРАВЛЕНИЯ] 25907982 CONTROL, A/TRNS (INCLS 5-8) (4.004) [БЛОК УПРАВЛЕНИЯ] 25908000 CONTROL, A/TRNS (INCLS 5-8) [БЛОК УПРАВЛЕНИЯ] 25908000 CONTROL, A/TRNS (INCLS 5-8) (4.004) [БЛОК УПРАВЛЕНИЯ] 25824055 KNOB, A/TRNS CONT LVR (ЧАСТЬ OF 4) (INCLS 6) (COCOA) (ALL LEATHER) 25824057 KNOB, A/TRNS CONT LVR (ЧАСТЬ OF 4) (INCLS 6) (EBONY) (SIDE EBONY LEATHER MIDDLE FIGURED SAPELE) 25824059 KNOB, A/TRNS CONT LVR (ЧАСТЬ OF 4) (INCLS 6) (COCOA) (SIDE COCOA LEATHER MIDDLE FIGURED SAPELE) teamcadillac.ru 25824060 KNOB, A/TRNS CONT LVR (ЧАСТЬ OF 4) (INCLS 6) (EBONY) (ALL LEATHER) 11570687 БОЛТ, A/TRNS CONT LVR KNOB (ЧАСТЬ OF 4, 5) 25824062 BOOT, A/TRNS CONT (ЧАСТЬ OF 4) (EBONY) 25824064 BOOT, A/TRNS CONT (ЧАСТЬ OF 4) (COCOA) 25824053 BASE, A/TRNS CONT (ЧАСТЬ OF 4) 25824054 BASE, A/TRNS CONT (ЧАСТЬ OF 4) 11514603 ГАЙКА, M10X1.5 15MM SOCKET (A/TRNS RANGE SEL LVR) [ШАЙБА] 11519095 NUT-ACORN HEX, M8X1.0, 15MM THK, 9, 6047M, W/DOME. (A/TRNS RANGE SEL LVR) [ГАЙКА] 15780844 LINK, A/TRNS RANGE SEL LVR 15780845 LINK, A/TRNS RANGE SEL LVR 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL ROD ADJ) [ГАЙКА М6] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL LVR CBL BRKT) [ГАЙКА М6] 11610112 CLIP, F/FLR CNSL TR PLT (TR PLT TO SI PNL) (ЧАСТЬ OF 1) (10.4 X 13 X 9) (14.683) not found БОЛТ, F/FLR CNSL CVR (ЧАСТЬ OF 1) not found COVER, F/FLR CNSL FRT (ЧАСТЬ OF 1) (6D04-083) - 2008-2010 DM69 УПРАВЛЕНИЕ АКППS/РУЧНАЯ ТРАНСМИССИЯ (MV7) ↓ 25806639 KNOB, M/TRNS CONT LVR (W/BOOT & W/SHFT PATT) (INCLS 13) 25806640 KNOB, M/TRNS CONT LVR (W/BOOT & W/SHFT PATT) (INCLS 13) 25887053 PLATE, F/FLR CNSL TRANS SHFT OPG TR (INCLS 9, 10, 12) teamcadillac.ru 15794036 PLATE, M/TRNS CONT MT 15794035 CONTROL, M/TRNS (W/SHFT PATT) [БЛОК УПРАВЛЕНИЯ] 21996990 PIN, M/TRNS CONT SHF EQLZR LVR (SHIFTER END) 25708836 RETAINER, M/TRNS SHFT LVR 25753853 PIN, M/TRNS CONT SHF EQLZR LVR (TRANS END) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (M/TRNS CONT BRKT) [ГАЙКА М6] 11509231 SCREW, RD HD C/R TAP, M4.2X1.41X13.0, GM6010M STL, GM813M NICKEL ORGANIC (ЧАСТЬ OF 2) [ВИНТ М6Х12] not found COVER, F/FLR CNSL FRT (ЧАСТЬ OF 2) 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (M/TRNS CONT BRKT) 11570189 CLIP, F/FLR CNSL TR PLT (ЧАСТЬ OF 2) 11610112 CLIP, F/FLR CNSL TR PLT (TR PLT TO SI PNL) (ЧАСТЬ OF 2) (10.4 X 13 X 9) (14.683) not found CAP, M/TRNS SEL LVR (ЧАСТЬ OF 1) (6D04-084) - 2008-2009 DM69 ТОРМОЗНОЙ УСИЛИТЕЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (LP1/2.8T,LY7/3.6-7) ↓ not found CYLINDER, BRK MAS (СМ. ГРУППУ 04.000 "ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] not found REINFORCEMENT, P/B BOOS (ЧАСТЬ OF PANEL, AIR INL GRL - 12.800) 10125439 RIVET, FLAT HD, 3 LEG EXPANSION, M4.8 SHAFT, 23.5 LG, 9.8 O.D., AL (AIR INL GRL PNL) [ЗАКЛЕПКА D=4.8 ММ] not found CYLINDER, CLU MAS (СМ. ГРУППУ 00.000 "ПЕДАЛЬ СЦЕПЛЕНИЯ-ЦИЛИНДРЫ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 24245109 CYLINDER, CLU MAS (СМ. ГРУППУ 00.000 "ПЕДАЛЬ СЦЕПЛЕНИЯ-ЦИЛИНДРЫ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ЦИЛИНДР] 25873484 HOSE, P/B BOOS VAC (ACDelco #176-1497) 25873484 HOSE, P/B BOOS VAC (ACDelco #176-1497) 25923501 HOSE, P/B BOOS VAC not found BOOSTER, P/B (СМ. ГРУППУ 04.000 "ТОРМОЗНОЙ УСИЛИТЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25675835 BRACKET, BRK PED BRKT 15849744 BOOT, BRK PED PUSH ROD 25697461 RETAINER, BRK PED PUSH ROD BOOT 25785092 BARRIER, BRK PED BRKT SND 25913292 BARRIER, BRK PED BRKT SND teamcadillac.ru not found PEDAL, BRK (W/BRKT) (СМ. ГРУППУ 04.000 "ТОРМОЗНАЯ ПЕДАЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11514519 ГАЙКА, BRK PED BRKT (M8X1.25, 7.32 THK) (9510M, ZF) (8.915) [ГАЙКА] not found REINFORCEMENT, P/B BOOS (СМ. ГРУППУ 10.000 "СТЕКЛООЧИСТИТЕЛЬ-ВЕТРОВОГО СТЕКЛА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6D04-085) - 2008 DM69 КЛАПАН РЕГУЛИРОВКИ ДАВЛЕНИЯ В ТОРМОЗНОЙ СИСТЕМЕ ↓ teamcadillac.ru 25853512 МОДУЛЬ, ELEK BRK & TRACT CONT [МОДУЛЬ] 25854972 БОЛТ, ELEK BRK CONT MDL (ECU TO HCU ATTACH) (M4X0.7X19.5, 10THD) not found БОЛТ, ELEK BRK CONT MDL BRKT (*KIT1) not found INSULATOR, BRK PRESS MOD VLV BRKT (*KIT1) not found INSULATOR, BRK PRESS MOD VLV (*KIT1) 15298281 VALVE, BRK PRESS MOD [КЛАПАН] 15286358 INSULATOR KIT, BRK PRESS MOD VLV (INCLS 3-5) (6D04-086) - 2008 DM69 ЭЛЕКТРИЧЕСКАЯ СИСТЕМА АБС ↓ 25996837 SENSOR, FRT WHL SPD (INCLS 2, 3, 6) 15158259 CLIP, WHL SPD SEN WIRE (ЧАСТЬ OF 1, 15) (12.0MM HOLE) 15158261 CLIP, WHL SPD SEN WIRE (ЧАСТЬ OF 1) (11MM HOLE) not found HARNESS, ENG WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/ДВИГАТЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found VALVE, BRK PRESS MOD (W/ELEK BRK & TRACT CONT MDL) (СМ. ГРУППУ 04.000 "BRAKE CONTROL МОДУЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 15715954 CLIP, WHL SPD SEN WIRE (ЧАСТЬ OF 1) (TREE FITS 6.5 HOLE) (HOLDS (1) 10.5MM GROMMET ROUTING (1) 6.35 SPD SEN CBL) 11516521 БОЛТ, HFH M6X1X20, 9.8, 7114M, DOG PT, 14.2 OD (FRT WHL SPD SEN) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (VEH YAW SEN & LATL ACCLRM) 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (VEH YAW SEN & LATL ACCLRM) [БОЛТ М6] not found HARNESS, BODY WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/КУЗОВ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 15845467 SENSOR, VEH YAW (W/VEH LATL ACCLRM) (LABELED 15845467) [ДАТЧИК] 25866179 SENSOR, RR WHL SPD (INCLS 14) 11516521 БОЛТ, HFH M6X1X20, 9.8, 7114M, DOG PT, 14.2 OD (RR WHL SPD SEN) teamcadillac.ru 10317605 CLIP, WHL SPD SEN WIRE (ЧАСТЬ OF 12) (6.8MM HOLE) (9.242) [ЗАЖИМ ДАТЧИКА АБС] 15855539 SENSOR, FRT WHL SPD (INCLS 2, 16, 17) 10317605 CLIP, WHL SPD SEN WIRE (ЧАСТЬ OF 15) (6.8MM HOLE) (9.242) [ЗАЖИМ ДАТЧИКА АБС] not found BRACKET, FRT WHL SPD SEN WIRE (ЧАСТЬ OF 15) 25820819 BRACKET, FRT WHL SPD SEN WIRE (ЧАСТЬ OF 15) 11570352 ГАЙКА, HEX JAM M12X1.75X6, GM510 (5) STL, GMW14100. (WHL SPD SEN BRKT) (6D04-087) - 2008-2009 DM69 УПРАВЛЕНИЕ АКППS/КОРПУС КП (ПОЛНОПРИВОДНЫЙ MX7) ↓ teamcadillac.ru 24244602 МОДУЛЬ, TRFER CASE SHFT CONT [МОДУЛЬ] not found HARNESS, I/P WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found INSULATOR, I/P (СМ. ГРУППУ 10.000 "ПРИБОРНАЯ ПАНЕЛЬ ЧАСТЬ 1" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (BLACK) 11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (I/P INSL) [ВИНТ] 11609370 БОЛТ-HWH, M4.2X1.41X20, HI - LOW THD, , OD 12, 6010 STL, GMW4205, TAP (I/P INSL) (9.667) (6D04-088) - 2008 DM69 ТОРМОЗНОЙ УСИЛИТЕЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (LLT/3.6V) ↓ 15267511 BOOSTER, P/B (СМ. ГРУППУ 04.000 "ТОРМОЗНОЙ УСИЛИТЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ГИДРОУСИЛИТЕЛЬ ТОРМОЗНОЙ СИСТЕМЫ] 25675835 BRACKET, BRK PED BRKT 15849744 BOOT, BRK PED PUSH ROD 25697461 RETAINER, BRK PED PUSH ROD BOOT 25785092 BARRIER, BRK PED BRKT SND 25913292 BARRIER, BRK PED BRKT SND not found PEDAL, BRK (W/BRKT) (СМ. ГРУППУ 04.000 "ТОРМОЗНАЯ ПЕДАЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 15267509 CYLINDER, BRK MAS (СМ. ГРУППУ 04.000 "ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [БЛОК ЦИЛИНДРОВ] 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] 11570167 STUD, P/B BOOS PUMP BRKT (STUD-STRAIGHT, M12X1.75X32.25, M12X1.75X23, 80 OAL, 10.9, E11 TORX) 25806500 BRACKET, VAC PUMP [ВАКУУМНЫЙ НАСОС] 11516075 ГАЙКА, HFH SELF LK, M6X1, 7.7THK, 14.2 O.D., 9, PZOR (P/B BOOS PUMP) [ГАЙКА ВЫПУСКНОЙ СИСТЕМЫ D=6ММ] 11514598 ГАЙКА, HEX FLANGE, M12X1.75X12, 26 OD, 10, 7111M, (P/B BOOS PUMP) [ГАЙКА М12] 11518075 БОЛТ, HFH, THD 22, OD 17, 8.8, GMW14C-PT, HDR POINT (P/B BOOS PUMP) [ВИНТ М10] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (P/S FLUID RSVR) 11589303 БОЛТ-HFH, M6X1X38, 30 THD, 14.2 OD, 8.8 STL, GMW3359, M-PT (P/B BOOS PUMP) teamcadillac.ru 15797569 PUMP, P/B BOOS AUX [НАСОС В СБОРЕ] 20774507 RESERVOIR, P/S FLUID (СМ. ГРУППУ 06.000 "НАСОС РУЛЕВОГО УПРАВЛЕНИЯ LINES" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25926187 HOSE, P/B BOOS VAC (INCLS 21) 25926187 HOSE, P/B BOOS VAC (INCLS 21) not found CЛАМПА, P/B BOOS HSG (ЧАСТЬ OF 20) not found SPACER, P/B BOOS PUMP (*KIT1) not found INSULATOR, P/B BOOS PUMP (*KIT1) 25775922 INSULATOR KIT, P/B BOOS PUMP (INCLS 22, 23) (ON PUMP) (6D04-089) - 2008 DM69 СТОЯНОЧНЫЙ ТОРМОЗ ASM ↓ 15853380 PLATE, RR BRK BKG (17" ТОРМОЗА) 15853415 PLATE, RR BRK BKG (17" ТОРМОЗА) teamcadillac.ru 15853421 PLATE, RR BRK BKG (18" ТОРМОЗА) 15853425 PLATE, RR BRK BKG (18" ТОРМОЗА) not found PIN, RR PARK BRK SHOE (*KIT1) 25693149 BRACKET, PARK BRK CBL (ATTACHES TO RR SUSP) 25693150 BRACKET, PARK BRK CBL (ATTACHES TO RR SUSP) 11517996 ГАЙКА, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (PARK BRK RR CBL BRKT) (ACDelco #11517996) [ГАЙКА М10] 25867413 LEVER, RR PARK BRK ACTR 25814678 SHOE KIT, RR PARK BRK [ТОРМОЗНАЯ КОЛДКА] not found ПРУЖИНА, RR PARK BRK SHOE RTN (*KIT1) not found ПРУЖИНА, RR PARK BRK SHOE HOLDN (*KIT1) not found ПРУЖИНА, RR PARK BRK SHOE RTN (*KIT1) 25867414 ADJUSTER, RR PARK BRK 25814679 ПРУЖИНА KIT, PARK BRK LVR RTN (INCLS 2, 7-9) [ПРУЖИНА] (6D04-098) - 2008-2009 DM69 КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS (ПОЛНОПРИВОДНЫЙ MX7) ↓ 89059523 ГАЙКА, TRFER CASE RR ВЫХОДНОЙ SHF FLG (4.520) 15580315 WASHER, TRFER CASE RR ВЫХОДНОЙ SHF THR (FLAT) (PL, STL) (7/8 I.D. X 1 39/64 O.D., 1/8 THK) (4.510) 15635532 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF FLG (O RING) (4.412) 19179018 FLANGE, TRFER CASE RR ВЫХОДНОЙ SHF 88996681 DEFLECTOR, TRFER CASE RR ВЫХОДНОЙ SHF SEAL DIRT (5.555) 19180065 БОЛТ, TRFER CASE VIB DPNR 19179016 DAMPENER, TRFER CASE VIB (AT RR OF CASE) not found БОЛТ, WRG HARN BRKT 19208066 CASE, TRFER (FRT HALF) 19208080 РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ, TRFER CASE TWO/FOUR WHL DRV CLU 88984499 PIN, TRFER CASE HALF LOC not found BRACKET, WRG HARN 88996657 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF [УПЛОТНИТЕЛЬ] 19208081 ГАЙКА, TRFER CASE TWO/FOUR WHL DRV CLU РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ 19208077 CASE, TRFER (RR HALF) 19206436 RESISTOR, (115 OHMS) 19206437 RESISTOR, (225 OHMS) 19206438 RESISTOR, (453 OHMS) 19206439 RESISTOR, (715 OHMS) 19206440 RESISTOR, (1150 OHMS) 19206441 RESISTOR, (1820 OHMS) 19206442 RESISTOR, (3160 OHMS) 19206443 RESISTOR, (7320 OHMS) 19206444 RESISTOR, (12700 OHMS) 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL FILL) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 19179015 PLUG, TRFER CASE FRT ВЫХОДНОЙ SHF HOLE (INCLS 20) [КРЫШКА КОРПУСА РАЗДАТОЧНОЙ КОРОБКИ] not found SEAL, TRFER CASE ACC HOLE PLUG (O RING) (ЧАСТЬ OF 19) teamcadillac.ru 19208087 RING, TRFER CASE FRT ВЫХОДНОЙ SHF BRG RET 19179158 SENSOR, TRFER CASE FLUID TEMP [ДАТЧИК ТЕМПЕРАТУРЫ МАСЛА РАЗДАТОЧНОЙ КОРОБКИ] 19179158 SENSOR, TRFER CASE FLUID TEMP [ДАТЧИК ТЕМПЕРАТУРЫ МАСЛА РАЗДАТОЧНОЙ КОРОБКИ] 19179014 PLUG, TRFER CASE OIL DRN 88996680 БОЛТ, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN SNBR (M5X0.8X16) 88996679 SNUBBER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN 88996680 БОЛТ, TRFER CASE VENT BFL (M5X0.8X16) (4.535) 88996658 BAFFLE, TRFER CASE VENT not found БОЛТ, TRFER CASE MT BAR INSL CLA not found CЛАМПА, TRFER CASE MT BAR INSL 19180066 VENT, TRFER CASE 88996657 SEAL, TRFER CASE FRT ВЫХОДНОЙ SHF [УПЛОТНИТЕЛЬ] 88996656 SEAL, TRFER CASE INPUT SHF [УПЛОТНИТЕЛЬ] 88996681 DEFLECTOR, TRFER CASE FRT ВЫХОДНОЙ SHF SEAL DIRT 19208069 SHAFT, TRFER CASE FRT ВЫХОДНОЙ 89048123 БОЛТ, TRFER CASE HALF (M8X1.25X30) (6D04-099) - 2008-2009 DM69 КОРПУС КП ЧАСТЬ 2 INTERNAL COMPONENTS (ПОЛНОПРИВОДНЫЙ MX7) ↓ 15580228 BEARING, TRFER CASE RR ВЫХОДНОЙ SHF RR (2 7/8 OD X 1 3/8 ID) (STMPD 13-45-130-001) 19208080 РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ, TRFER CASE TWO/FOUR WHL DRV CLU (СМ. ГРУППУ 04.000 "КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 19208108 SHIM, TRFER CASE FOUR WHL DRV CLU (SELECT FIT 8.60-8.50; STAMPED "52") 19208109 SHIM, TRFER CASE FOUR WHL DRV CLU (SELECT FIT 8.80-8.70; STAMPED "53") 19208110 SHIM, TRFER CASE FOUR WHL DRV CLU (SELECT FIT 9.00-8.90; STAMPED "54") 19208111 SHIM, TRFER CASE FOUR WHL DRV CLU (SELECT FIT 9.20-9.10; STAMPED "55") 19208112 SHIM, TRFER CASE FOUR WHL DRV CLU (SELECT FIT 9.40-9.30; STAMPED "56") 19208113 SHIM, TRFER CASE FOUR WHL DRV CLU (SELECT FIT 9.60-9.50; STAMPED "57") 19208114 SHIM, TRFER CASE FOUR WHL DRV CLU (SELECT FIT 9.80-9.70; STAMPED "58") 19208115 BEARING, TRFER CASE FOUR WHL DRV CLU HSG not found ШЛАНГИ, TRFER CASE TWO/FOUR WHL DRV CLU РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ not found ROLLER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT BRG 19208358 SPACER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT BRG RLR not found ПРУЖИНА, TRFER CASE TWO/FOUR WHL DRV SYN HUB 19208088 RING, TRFER CASE TWO/FOUR WHL DRV CLU RET 19208098 СЦЕПЛЕНИЕ, TRFER CASE FRT DRV AXLE VISCOUS (INCLS 12-17) not found ACTUATOR, TRFER CASE FOUR WHL DRV not found PLATE, TRFER CASE FOUR WHL DRV CLU PRESS (ЧАСТЬ OF 10) not found PLATE, TRFER CASE FOUR WHL DRV CLU BKG (FRICTION) (ЧАСТЬ OF 10) not found PLATE, TRFER CASE FOUR WHL DRV CLU BKG (SEPERATOR) (ЧАСТЬ OF 10) not found PLATE, TRFER CASE FOUR WHL DRV CLU BKG (ЧАСТЬ OF 10) not found PLATE, TRFER CASE FOUR WHL DRV CLU BKG (ПРУЖИНА) (ЧАСТЬ OF 10) not found ШЛАНГИ, TRFER CASE FOUR WHL DRV CLU (ЧАСТЬ OF 10) 19208091 SPACER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT 19208072 CHAIN, TRFER CASE TWO/FOUR WHL DRV 19208359 SPROCKET, TRFER CASE FRT ВЫХОДНОЙ SHF DRV 19208090 WASHER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT THR 19208085 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT 19208090 WASHER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT THR 19208082 PUMP, TRFER CASE OIL teamcadillac.ru 19208071 SHAFT, TRFER CASE INPUT not found BEARING, TRFER CASE INPUT SHF 19208078 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF RR 19208360 SPROCKET, TRFER CASE TWO/FOUR WHL DRV DRVN 19208089 SPACER, TRFER CASE FRT ВЫХОДНОЙ SHF DRVN SPKT 88996633 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF FRT (ACDelco #88996633) [ПОДШИПНИК РАЗДАТОЧНОЙ КОРОБКИ] (6E04-020) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ 24218963 RING, T/CV FLUID SEAL RET [КОЛЬЦО] 24237531 SEAL, T/CV FLUID (ЧАСТЬ OF 217, 219) (ACDelco #24237531) [УПЛОТНЕНИЕ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 00444613 PLUG, HEX HD, 1/8-27 NPTF, STL (LINE PRESS TEST HOLE) (ACDelco #444613) 24239384 ШЛАНГИ, T/CV (MCHG) (INCLS 206) (ACDelco #24239384) 24225422 PIPE, A/TRNS VENT not found BUSHING, T/CV (ЧАСТЬ OF 203) not found RING, A/TRNS ГИДРОНАСОС VANE (ЧАСТЬ OF 217) not found GUIDE, A/TRNS ГИДРОНАСОС ROT (ЧАСТЬ OF 217) teamcadillac.ru not found RING, A/TRNS ГИДРОНАСОС SLIDE FLUID SEAL (ЧАСТЬ OF 217) not found SEAL, A/TRNS O/PMP SLIDE (O RING) (ЧАСТЬ OF 217) (*KIT1) not found ПРУЖИНА, A/TRNS ГИДРОНАСОС SLIDE OTR (ЧАСТЬ OF 217) 24222668 SLIDE, A/TRNS ГИДРОНАСОС (17.948MM-17.961MM) (ACDelco #24222668) 24224131 SLIDE, A/TRNS ГИДРОНАСОС (17.961MM-17.974MM) (ACDelco #24224131) 24224132 SLIDE, A/TRNS ГИДРОНАСОС (17.974MM-17.987MM) (ACDelco #24224132) not found SEAL, A/TRNS ГИДРОНАСОС SLIDE (ЧАСТЬ OF 217) not found SUPPORT, A/TRNS ГИДРОНАСОС SLIDE SEAL (ЧАСТЬ OF 217) (*KIT1) not found PIN, A/TRNS ГИДРОНАСОС SLIDE PIV (ЧАСТЬ OF 217) not found VANE, A/TRNS ГИДРОНАСОС (ЧАСТЬ OF 217) 24238915 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 207-211, 213-216, 230) (17.948MM-17.961MM) (ACDelco #24238915) 24238916 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 207-211, 213-216, 230) (17.961MM-17.974MM) (ACDelco #24238916) 24238917 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 207-211, 213-216, 230) (17.974MM-17.987MM) (ACDelco #24238917) not found BUSHING, TURB SHF FRT (ЧАСТЬ OF 219) 24238919 COVER KIT, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 218, 220-230, 232-237) (ACDelco #24238919) not found VALVE, CONV FEED LIM (ЧАСТЬ OF 219) not found ПРУЖИНА, PRESS RLF BALL VLV (ЧАСТЬ OF 219) not found ПРУЖИНА, CONV FEED LIM VLV (ЧАСТЬ OF 219) not found PIN, PRESS RLF BALL VLV SPR (ЧАСТЬ OF 219) not found ПРУЖИНА, PRESS RLF BALL VLV (ЧАСТЬ OF 219) 00147500 VALVE, PRESS RLF BALL (ЧАСТЬ OF 219) not found ПРУЖИНА, TCC C/VLV (ЧАСТЬ OF 219) not found VALVE, TCC CONT (ЧАСТЬ OF 219) not found BUSHING, TURB SHF RR (ЧАСТЬ OF 219) 24224692 WASHER, 1-2-3-4 & 3-5 REV CLU HSG THR (ЧАСТЬ OF 219) 24239151 RING, 1-2-3-4 & 3-5 REV CLU FLUID SEAL (ЧАСТЬ OF 217, 219) (*KIT1, KIT2) (ACDelco #24239151) 24227061 БОЛТ, A/TRNS ГИДРОНАСОС CVR (ACDelco #24227061) [БОЛТ] 90351709 PIN, A/TRNS ГИДРОНАСОС LOC (ЧАСТЬ OF 219) ("8MM HOLLOW SPLIT PIN") (1.639) [ШПИЛЬКА] not found VALVE, PRESS REG (ЧАСТЬ OF 219) not found ПРУЖИНА, PRESS REG VLV OTR (ЧАСТЬ OF 219) not found ПРУЖИНА, PRESS REG VLV INR (ЧАСТЬ OF 219) not found VALVE, ISOLATOR (ЧАСТЬ OF 219) not found SLEEVE, ISOLATOR VLV (ЧАСТЬ OF 219) 24243891 SEAL KIT, A/TRNS SERV (INCLS 205, 210, 214, 230) (FULL TRANS) (ACDelco #24243891) 24239151 RING KIT, 1-2-3-4 & 3-5 REV CLU FLUID SEAL (INCLS 230) (ACDelco #24239151) (6M04-038) - 2008 DM69 ШЛАНГ ВЕНТИЛЯЦИИ ТРАНСМИССИИ-VENT HOSE W/DRAIN(MYB)(1ST DES) ↓ not found HOSE, TRANS VENT (INCLS 2-8) 15862039 HOSE, TRANS VENT (INCLS 2-8) (VENT HOSE W/DRAIN) (FOR 2ND DES SEE 25892019) teamcadillac.ru 25892019 HOSE, TRANS VENT (INCLS 2-8) not found VENT, TRFER CASE (ЧАСТЬ OF 1) 08905794 CLIP (TRANS VENT) (ЧАСТЬ OF 1) not found CONNECTOR, TRANS VENT HOSE (ЧАСТЬ OF 1) 06466355 CONNECTOR, TRANS VENT HOSE (ЧАСТЬ OF 1) (3.278) not found STRAP, TRFER CASE VENT HOSE (ЧАСТЬ OF 1) not found HOSE, TRANS VENT (ЧАСТЬ OF 1) 25526358 CЛАМПА, SPRG BAND, 14.2MM, 9/16 OD HOSE, POR (ЧАСТЬ OF 1) not found HOSE, TRANS VENT (ЧАСТЬ OF 1) (6M04-039) - 2008 DM69 ШЛАНГ ВЕНТИЛЯЦИИ ТРАНСМИССИИ-VENT HOSE W/O DRAIN(MYB)(2ND DES) ↓ 25892019 HOSE, TRANS VENT (INCLS 2-4) 25892019 HOSE, TRANS VENT (INCLS 2-4) (VENT HOSE W/O DRAIN) (FOR 1ST DES SEE 15862039) teamcadillac.ru 25526358 CЛАМПА, SPRG BAND, 14.2MM, 9/16 OD HOSE, POR (ЧАСТЬ OF 1) 08905794 CLIP (ЧАСТЬ OF 1) 25892279 VENT, TRFER CASE (ЧАСТЬ OF 1) (ACDelco #25892279) [ЗАГЛУШКА ШЛАНГА ВЕНТИЛЯЦИИ КАРТЕРА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] (GM04-042) - 2008 DM69 ТОРМОЗНОЙ СУППОРТ-ПЕРЕДНИЙ (JE5) ↓ 15851351 CALIPER, FRT BRK (INCLS 2, 3, 12-14) (17") 15851351 CALIPER, FRT BRK (INCLS 2, 3, 12-14) (17") teamcadillac.ru 15853359 CALIPER, FRT BRK (INCLS 2, 3, 12-14) (17") 15853359 CALIPER, FRT BRK (INCLS 2, 3, 12-14) (17") 89027179 VALVE, FRT BRK CLPR BLEDR (ЧАСТЬ OF 1) 88935785 CAP, FRT BRK CLPR BLEDR VLV (ЧАСТЬ OF 1) [ЗАГЛУШКА ОБРАТНОГО КЛАПАНА] 15851359 PIN, FRT BRK CLPR GDE (W/O BUSHING) not found SEAL, FRT BRK CLPR GDE PIN (*KIT3) 15851354 BRACKET, FRT BRK CLPR (17") not found ПРУЖИНА, FRT DISC BRK PAD RET (*KIT2) not found PAD, FRT DISC BRK OTR (*KIT2) not found PAD, FRT DISC BRK INR (*KIT2) not found BUSHING, FRT BRK CLPR GDE PIN (ЧАСТЬ OF 11) (*KIT3) 15851358 PIN, FRT BRK CLPR GDE (INCLS 10) (W/PLASTIC SLEEVE 1.5MM FROM TIP) (W/BUSHING) not found BOOT, FRT BRK CLPR PSTN (ЧАСТЬ OF 1) (*KIT1) not found SEAL, FRT BRK CLPR PSTN (ЧАСТЬ OF 1) (*KIT1) 15926281 PISTON, FRT BRK CLPR (ЧАСТЬ OF 1) 89027183 БОЛТ, FRT BRK CLPR GDE PIN (M8X1.0) [БОЛТ М8] 25814701 SEAL KIT, FRT BRK CLPR PSTN (INCLS 12, 13) (INCLS 2 PISTON BOOTS & PISTON SEALS) 25814699 PAD KIT, FRT DISC BRK (INCLS 7-9) 25814700 SEAL KIT, FRT BRK CLPR GDE PIN (INCLS 5, 10) (INCLS 2 SEALS & 1 BUSHING) (GM04-555) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 24227130 БОЛТ, C/VLV UPR BODY (M5X0.8X36) 24225398 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M6 X 1.0 X 20) 24238417 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (INCLS 316) (4.329) [ДАТЧИК ЧИСЛА ОБОРОТОВ ВАЛА AКПП] 24225797 BODY, C/VLV UPR [ГИДРОРАСПРЕДЕЛИТЕЛЬНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] teamcadillac.ru 24245720 PLATE, C/VLV BODY SPCR (W/GSKT) (ACDelco #24245720) [НАБОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96020431 VALVE, C/VLV BODY BALL CHK [КЛАПАН] 24250384 BODY, C/VLV LWR (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ/;НИЖНИЙ КЛАПАН РЕГУЛЯТОР BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (MANUAL VALVE NOT INCLUDED) (MUST USE T/W 24236934/PLATE KIT - CONT SOL VLV FLTR) 24246427 SWITCH, A/TRNS MAN SHFT SHF POSN (INCLS 315) (INTERNAL MODE SWITCH) [ВКЛЮЧАТЕЛЬ] 24224821 БОЛТ, C/VLV LWR BODY (M5X0.8X45) 24224822 БОЛТ, C/VLV LWR BODY (M5X0.8X55) 24238925 PLATE KIT, CONT SOL VLV FLTR 24240845 БОЛТ, CONT SOL VLV HEAT SINK (W/ BODY & TCM) (M5X0.8X53.0) 24241890 VALVE, CONT SOL (W/ BODY & TCM) (ACDelco #24241890) (ORDER T/W 24238913 SEAL KIT) [ГИДРОРАСПРЕДЕЛИТЕЛЬНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24236233 CLIP, A/TRNS MAN SHFT SHF POSN SW WRG HARN (ЧАСТЬ OF 308) 24236233 CLIP, A/TRNS MAN SHFT SHF POSN SW WRG HARN (ЧАСТЬ OF 308) 24236233 CLIP, A/TRNS MAN SHFT SHF POSN SW WRG HARN (ЧАСТЬ OF 308) 24236504 CLIP, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN WRG HARN (ЧАСТЬ OF 303) (GM04-556) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ВЕРХНИЙ КЛАПАН РЕГУЛЯТОР BODY БЛОК ↓ 24224766 PIN, C/VLV BODY LOC (ЧАСТЬ OF 321) (DIA.=10MM L=12.7) [ВТУЛКА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24225797 BODY, C/VLV UPR (INCLS 313, 322-338) [ГИДРОРАСПРЕДЕЛИТЕЛЬНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24230200 PIN, C/VLV BODY LOC (ЧАСТЬ OF 321) (DIA.=10MM L=29.9) [ВТУЛКА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, 1-2-3-4 CLU BOOST VLV SPR (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, 1-2-3-4 CLU REG VLV BORE PLUG (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, 1/REV BAND & 4-5-6 CLU REG VLV BORE PLUG (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, 2-6 CLU REG VLV BORE PLUG (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, 3-5-REV CLU BOOST VLV SPR (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, 3-5-REV CLU REG VLV BORE PLUG (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, 4-5-6 CLU BOOST VLV SPR (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, ACTR FEED LIM VLV (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] not found ПРУЖИНА, ACTR FEED LIM VLV (ЧАСТЬ OF 321) not found VALVE, ACTR FEED LIM (ЧАСТЬ OF 321) not found ПРУЖИНА, 1-2-3-4 CLU REG VLV (ЧАСТЬ OF 321) not found ПРУЖИНА, 1/REV BAND & 4-5-6 CLU REG VLV (ЧАСТЬ OF 321) teamcadillac.ru not found ПРУЖИНА, 2-6 CLU REG VLV (ЧАСТЬ OF 321) not found ПРУЖИНА, 3-5 REV CLU REG VLV (ЧАСТЬ OF 321) not found VALVE, 1/REV BAND & 4-5-6 CLU REG (ЧАСТЬ OF 321) 24242814 PLUG, 1-2-3-4 CLU REG VLV BORE (ЧАСТЬ OF 321) (9.5 THK, 11.5 DIA) 24242814 PLUG, 1/REV BAND & 4-5-6 CLU REG VLV BORE (ЧАСТЬ OF 321) (9.5 THK, 11.5 DIA) 24242814 PLUG, 2-6 CLU REG VLV BORE (ЧАСТЬ OF 321) (9.5 THK, 11.5 DIA) 24242814 PLUG, 3-5 REV CLU REG VLV BORE (ЧАСТЬ OF 321) (9.5 THK, 11.5 DIA) not found VALVE, 1-2-3-4 CLU BOOST (ЧАСТЬ OF 321) not found VALVE, 3-5-REV CLU BOOST (ЧАСТЬ OF 321) not found VALVE, 4-5-6 CLU BOOST (ЧАСТЬ OF 321) not found ПРУЖИНА, 1-2-3-4 CLU BOOST VLV (ЧАСТЬ OF 321) not found ПРУЖИНА, 3-5-REV CLU BOOST VLV (ЧАСТЬ OF 321) not found ПРУЖИНА, 4-5-6 CLU BOOST VLV (ЧАСТЬ OF 321) not found VALVE, 2-6 CLU REG (ЧАСТЬ OF 321) not found VALVE, 2-6 CLU REG VLV GAIN (ЧАСТЬ OF 321) not found VALVE, 3-5 REV CLU REG (ЧАСТЬ OF 321) not found VALVE, 1-2-3-4 CLU REG (ЧАСТЬ OF 321) not found VALVE, DEFAULT OVERRIDE 1-2-3-4 CLU (ЧАСТЬ OF 321) (GM04-557) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) НИЖНИЙ КЛАПАН РЕГУЛЯТОР BODY БЛОК ↓ 24224755 RETAINER, CLU PSTN DAM FEED REG VLV SPR [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, CLU SEL SOL VLV BORE PLUG #2 [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, CLU SEL SOL VLV BORE PLUG #3 [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, TCC REG APPL VLV BORE PLUG [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24242814 PLUG, CLU SEL SOL VLV BORE #2 (9.5 THK, 11.5 DIA) teamcadillac.ru 24242814 PLUG, CLU SEL SOL VLV BORE #3 (9.5 THK, 11.5 DIA) 24242814 PLUG, TCC REG APPL VLV BORE (9.5 THK, 11.5 DIA) not found VALVE, TCC REG APPL SHUTTLE (ЧАСТЬ OF 351) 24250384 BODY, C/VLV LWR (INCLS 338, 352, 353, 355-357) (MANUAL VALVE NOT INCLUDED) (MUST USE T/W 24236934/PLATE KIT - CONT SOL VLV FLTR) not found VALVE, CLU SEL SOL #2 (ЧАСТЬ OF 351) not found VALVE, CLU SEL SOL #3 (ЧАСТЬ OF 351) not found ПРУЖИНА, CLU SEL SOL VLV #2 (ЧАСТЬ OF 351) not found ПРУЖИНА, CLU SEL SOL VLV #3 (ЧАСТЬ OF 351) not found ПРУЖИНА, TCC REG APPLY VLV (ЧАСТЬ OF 351) 24224770 VALVE, MAN (ACDelco #24224770) not found VALVE, TCC REG APPLY (ЧАСТЬ OF 351) not found VALVE, CLU PSTN DAM FEED REG (ЧАСТЬ OF 351) not found ПРУЖИНА, CLU PSTN DAM FEED REG VLV (ЧАСТЬ OF 351) (GM04-558) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) 1-2-3-4 & 3-5 REVERSE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 24240625 RING, 3-5 REV CLU BKG PLT RET (LT GREEN) (2.25-2.35MM) (ACDelco #24240625) teamcadillac.ru 24240626 RING, 3-5 REV CLU BKG PLT RET (GRAY) (2.47-2.57MM) (ACDelco #24240626) 24240627 RING, 3-5 REV CLU BKG PLT RET (YELLOW) (2.69-2.79MM) (ACDelco #24240627) 24240628 RING, 3-5 REV CLU BKG PLT RET (ORANGE) (2.93-3.01MM) (ACDelco #24240628) 24240629 RING, 3-5 REV CLU BKG PLT RET (LT BLUE) (3.13-3.23MM) (ACDelco #24240629) 24240630 RING, 3-5 REV CLU BKG PLT RET (WHITE) (3.35-3.45MM) (ACDelco #24240630) 24240631 RING, 3-5 REV CLU BKG PLT RET (YELLOW/PURPLE) (3.57-3.67MM) (ACDelco #24240631) 24225654 PLATE, 3-5 REV CLU BKG 24225569 PLATE, 3-5/REV CLU (PKG OF 4) (FIBER) (*KIT4) (ACDelco #24225569) 24237663 PLATE, 3-5 REV CLU (PKG OF 4) (STEEL) 24225564 PLATE, 3-5 REV CLU (WAVED) 24225748 RING, 3-5-REV CLU APPLY (ACDelco #24225748) 24233533 PLATE, 1-2-3-4 CLU BKG 24243588 PLATE, 1-2-3-4 CLU (*KIT4) (ACDelco #24243588) 24232652 PLATE, 1-2-3-4 CLU (PKG OF 5) (STEEL) 24236434 PLATE, 1-2-3-4 CLU (WAVED) not found RING, 1-2-3-4 CLU PSTN DAM RET (*KIT1, KIT2) 24225522 DAM, 1-2-3-4 CLU PSTN 24225559 ПРУЖИНА, 1-2-3-4 CLU 24241073 PISTON, 1-2-3-4 CLU not found RING, 1-2-3-4 CLU PSTN HSG RTN (*KIT1, KIT2) not found SEAL, 1-2-3-4 CLU PSTN (ЧАСТЬ OF 417) 24238558 ШЛАНГИ, 1-2-3-4 CLU PSTN (INCLS 416, 418, 419) not found SEAL, 3-5/REV CLU PSTN DAM (O RING) (ЧАСТЬ OF 417) not found SEAL, 3-5-REV CLU PSTN INR (ЧАСТЬ OF 417) 24236051 ПРУЖИНА, 3-5-REV CLU 24238560 PISTON, 3-5/REV CLU (INCLS 422) (4.164) not found SEAL, 3-5-REV CLU PSTN OTR (ЧАСТЬ OF 421) (*KIT3) not found SEAL, 1-2-3-4 CLU PSTN INR (*KIT1, KIT3) not found SEAL, 1-2-3-4 CLU PSTN HSG (*KIT1, KIT3) not found SEAL, 1-2-3-4 CLU PSTN HSG (*KIT1, KIT3) not found BUSHING, 1-2-3-4 & 3-5/REV CLU HSG RR (ЧАСТЬ OF 427) 24237184 ШЛАНГИ, 1-2-3-4 & 3-5 REV CLU (INCLS 426) (ORDER T/W 24226393) 24226393 BEARING, 1-2-3-4 & 3-5-REV CLU 24240626 RING, 1-2-3-4 CLU BKG PLT RET (GRAY) (2.47-2.57MM) (ACDelco #24240626) 24240627 RING, 1-2-3-4 CLU BKG PLT RET (YELLOW) (2.69-2.79MM) (ACDelco #24240627) 24240628 RING, 1-2-3-4 CLU BKG PLT RET (ORANGE) (2.93-3.01MM) (ACDelco #24240628) 24240629 RING, 1-2-3-4 CLU BKG PLT RET (LT BLUE) (3.13-3.23MM) (ACDelco #24240629) 24240630 RING, 1-2-3-4 CLU BKG PLT RET (WHITE) (3.35-3.45MM) (ACDelco #24240630) 24240631 RING, 1-2-3-4 CLU BKG PLT RET (YELLOW/PURPLE) (3.57-3.67MM) (ACDelco #24240631) 24240632 RING, 1-2-3-4 CLU BKG PLT RET (LT BLUE/PURPLE) (3.79-3.89MM) (ACDelco #24240632) 24238913 SEAL KIT, A/TRNS SERV (INCLS 411, 415, 423-425) (CONTROL VLV SOL ASM) (ACDelco #24238913) [КОМПЛЕКТ ПРОКЛАДОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (5ШТ)] 24238920 RING KIT, RET (INCLS 411, 415) 24238922 SEAL KIT, A/TRNS SERV (INCLS 422-425) (TRANS BUILT ON 1-31-08 & PRIOR) (FOR 2ND DES SEE 24243890) (СЦЕПЛЕНИЕES) (ACDelco #24238922) 24238922 SEAL KIT, A/TRNS SERV (INCLS 422-425) (TRANS BUILT ON 2-01-08 & AFTER) (FOR 1ST DES SEE 24238922) (СЦЕПЛЕНИЕES) (ACDelco #24238922) 24238911 PLATE KIT, CLU (INCLS 402, 408) (ORDER T/W 24225575 & 24235455) (ACDelco #24238911) (GM04-559) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) 4-5-6 ДЕТАЛИ СЦЕПЛЕНИЯ & ВАЛ ТУРБИНЫ ↓ 24225508 RING, 4-5-6 CLU BKG PLT RET (GREEN) (2.52-2.62) (ACDelco #24225508) 24225509 RING, 4-5-6 CLU BKG PLT RET (YELLOW) (3.08-3.18) (ACDelco #24225509) 24231591 RING, 4-5-6 CLU BKG PLT RET (GREY) (2.80-2.90) (ACDelco #24231591) 24231592 RING, 4-5-6 CLU BKG PLT RET (ORANGE) (3.36-3.46) (ACDelco #24231592) 24231593 RING, 4-5-6 CLU BKG PLT RET (BLUE) (3.64-3.74) (ACDelco #24231593) 24232880 RING, 4-5-6 CLU BKG PLT RET (YELLOW/PURPLE) (4.20-4.30) (ACDelco #24232880) 24225652 PLATE, 4-5-6 CLU BKG teamcadillac.ru 24225570 PLATE, 4-5-6 CLU (INT SPLINE) (PKG OF 5) (FIBER) (*KIT3) 24225575 PLATE, 4-5-6 CLU (EXT SPLINE) (PKG OF 5) (STEEL)FIBER) (ACDelco #24225575) 24225565 PLATE, 4-5-6 CLU (WAVED) not found RING, 4-5-6 CLU PSTN DAM RET (*KIT1, KIT2) 24225526 DAM, 4-5-6 CLU PSTN 24225560 ПРУЖИНА, 4-5-6 CLU 24225523 PISTON, 4-5-6 CLU not found BUSHING, ВЫХОДНОЙ CARR SHF HSG (ЧАСТЬ OF 441) 24237963 ШЛАНГИ, 4-5-6 CLU (W/ INPUT SHF) (INCLS 440) 24225511 RING, TURB SHF FLUID SEAL 08662686 SEAL, TURB SHF (O RING) (*KIT2) (ACDelco #8662686) 24238920 RING KIT, RET (INCLS 436) 24243891 SEAL KIT, A/TRNS SERV (INCLS 436, 443) (FULL TRANS) (ACDelco #24243891) 24238911 PLATE KIT, CLU (INCLS 433) (ORDER T/W 24225575 & 24235455) (ACDelco #24238911) (GM04-560) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) 2-6 ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 24247405 RING, 2-6 CLU BKG PLT RET (1.69MM +/- 0.05) (ACDelco #24247405) 24247406 RING, 2-6 CLU BKG PLT RET (2.81MM +/- 0.05) (ACDelco #24247406) 24248107 RING, 2-6 CLU BKG PLT RET (2.25MM +/- 0.05) (ACDelco #24248107) 24248108 RING, 2-6 CLU BKG PLT RET (2.53MM +/- 0.05) (ACDelco #24248108) 24248109 RING, 2-6 CLU BKG PLT RET (1.97MM +/- 0.05) (ACDelco #24248109) 24225653 PLATE, 2-6 CLU BKG teamcadillac.ru 24237973 PLATE, 2-6 CLU (WAVED) not found RING, 2-6 CLU SPR RET 24225561 ПРУЖИНА, 2-6 CLU 24225524 PISTON, 2-6 CLU not found BUSHING, ВЫХОДНОЙ CARR OTR SUN GR SHF (ЧАСТЬ OF 459) 24225447 SUPPORT, CTR (INCLS 458, 460) not found BUSHING, ВЫХОДНОЙ CARR OTR SUN GR SHF (ЧАСТЬ OF 459) 24238911 PLATE KIT, CLU (INCLS 452) (ORDER T/W 24225575 & 24235455) (ACDelco #24238911) (GM04-561) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) LOW & REVERSE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ not found SUPPORT, CTR (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ДЕТАЛИ СЦЕПЛЕНИЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found RING, LOW & REV CLU BKG PLT RET 24225519 RING, LOW & REV CLU BKG PLT RET (2.77MM +/- 0.05) (ACDelco #24225519) (TRANS BUILT ON 9/1/08 & FORWARD) (FOR 1ST DES SEE 24248368) 24231938 RING, LOW & REV CLU BKG PLT RET (2.63MM +/- 0.05) (MUST BE USED T/W 24247402) (ACDelco #24231938) (TRANS BUILT ON 9/1/08 & FORWARD) (FOR 1ST DES SEE 24248368) 24231939 RING, LOW & REV CLU BKG PLT RET (2.93MM +/- 0.05) (MUST BE USED T/W 24247402) (ACDelco #24231939) (TRANS BUILT ON 9/1/08 & FORWARD) (FOR 1ST DES SEE 24248368) 24247407 RING, LOW & REV CLU BKG PLT RET (2.03MM +/- 0.05) (MUST BE USED T/W 24247402) (ACDelco #24247407) (TRANS BUILT ON 9/1/08 & FORWARD) (FOR 1ST DES SEE 24248368) 24247408 RING, LOW & REV CLU BKG PLT RET (3.23MM +/- 0.05) (MUST BE USED T/W 24247402) (ACDelco #24247408) (TRANS BUILT ON 9/1/08 & FORWARD) (FOR 1ST DES SEE 24248368) 24247402 PLATE, LOW & REV CLU BKG (MUST BE USED T/W 24231937/38/38, AND 24247407/08) (ACDelco #24247402) (TRANS BUILT ON 9/1/08 & FORWARD) (FOR 1ST DES SEE 24248368) 24248368 PLATE KIT, LOW & REV CLU BKG (FOR SERVICE USE (1) OF THE FOLLOWING RET. RINGS 24225515, 24225519, OR BACKING PLATE 24225656) (4.180) (ACDelco #24248368) (TRANS BUILT ON 08-31-08 & PRIOR) (FOR 2ND DES SEE 24231937/ 24231938/ 24231939/ 242474 24236664 PLATE, LOW & REV CLU (PKG OF 6) (FIBER) (*KIT2) 24232654 PLATE, LOW & REV CLU (PKG OF 6) (STEEL) (ACDelco #24232654) 24237971 PLATE, LOW & REV CLU (WAVED) (ACDelco #24237971) 24225517 RING, LOW & REV CLU SPR RET 24238921 SPRAG, LOW CLU (INCLS 468) not found SEAL, LOW CLU SPRAG (ЧАСТЬ OF 467) (*KIT1) teamcadillac.ru 24225562 ПРУЖИНА, LOW & REV CLU 24225525 PISTON, LOW & REV CLU (ACDelco #24225525) 24238922 SEAL KIT, A/TRNS SERV (INCLS 468) (TRANS BUILT ON 1-31-08 & PRIOR) (FOR 2ND DES SEE 24243890) (СЦЕПЛЕНИЕES) (ACDelco #24238922) 24238922 SEAL KIT, A/TRNS SERV (INCLS 468) (TRANS BUILT ON 2-01-08 & AFTER) (FOR 1ST DES SEE 24238922) (СЦЕПЛЕНИЕES) (ACDelco #24238922) 24238911 PLATE KIT, CLU (INCLS 463) (ORDER T/W 24225575 & 24235455) (ACDelco #24238911) (GM04-562) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) СЦЕПЛЕНИЕ HUB БЛОК ↓ teamcadillac.ru 24233660 HUB, 4-5-6 CLU (W/ ВЫХОДНОЙ CARR SHF & DPNR) (INCLS 476-478) 24230475 DAMPENER, 4-5-6 CLU (ЧАСТЬ OF 475) 24233661 PLATE, 4-5-6 CLU DPNR APPLY (ЧАСТЬ OF 475) not found RING, 4-5-6 CLU DPNR RET (ЧАСТЬ OF 475) (GM04-563) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ВЫХОДНОЙ КРОНШТЕЙН БЛОК ↓ 24225777 BEARING, CTR SUPT RLR (ЧАСТЬ OF 490) 24225483 BEARING, ВЫХОДНОЙ CARR OTR SUN GR FRT THR (ЧАСТЬ OF 490) 24225290 GEAR, ВЫХОДНОЙ CARR FRT SUN (ЧАСТЬ OF 490) teamcadillac.ru 24225484 BEARING, ВЫХОДНОЙ CARR OTR SUN GR RR THR (ЧАСТЬ OF 490) 24235807 GEAR, ВЫХОДНОЙ CARR RR SUN (ЧАСТЬ OF 490) 24225603 КРОНШТЕЙН, ВЫХОДНОЙ (INCLS 485-489, 491) not found BEARING, ВЫХОДНОЙ CARR INR SUN GR THR (ЧАСТЬ OF 490) (GM04-568) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ВЫХОДНОЙ ВАЛ БЛОК ↓ 24241092 RING, ВЫХОДНОЙ CARR INTL GR RET (ACDelco #24241092) 24228887 SPACER, ВЫХОДНОЙ CARR INTL GR (3.342) not found BUSHING, ВЫХОДНОЙ CARR (ЧАСТЬ OF 499) 24239398 SHAFT, ВЫХОДНОЙ (INCLS 498) (WHEN SERVICING SHAFT MUST ALSO REPLACE BEARING P/N 24237771) (FLAT END OF THE SHAFT) teamcadillac.ru 24239401 SHAFT, ВЫХОДНОЙ (INCLS 498) (WHEN SERVICING SHAFT MUST ALSO REPLACE BEARING P/N 24237771) (GM04-569) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) БЛОК СЦЕПЛЕНИЯ & ДЕТАЛИ КОМПЛЕКТА ↓ not found СЦЕПЛЕНИЕ, 1-2-3-4 & 3-5 REV (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ 1-2-3-4 & 3-5 REVERSE ДЕТАЛИ СЦЕПЛЕНИЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 24225602 КРОНШТЕЙН, INPUT (ACDelco #24225602) 24225289 GEAR, INPUT SUN (ACDelco #24225289) 24224405 BEARING, INPUT SUN GR THR (ACDelco #24224405) 24224405 BEARING, INPUT SUN GR THR (ACDelco #24224405) 24232409 WASHER, INPUT SUN GR THR not found СЦЕПЛЕНИЕ, 4-5-6 (W/ TURB SHF) (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ 4-5-6 ДЕТАЛИ СЦЕПЛЕНИЯ & ВАЛ ТУРБИНЫ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 24238905 BEARING, TURB SHFT THR [ПОДШИПНИК] not found HUB, 4-5-6 CLU (W/ ВЫХОДНОЙ CARR SHF & DPNR) (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ СЦЕПЛЕНИЕ HUB БЛОК" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 24233732 BEARING, 4-5-6 CLU HUB THR (ACDelco #24233732) 24233732 BEARING, 4-5-6 CLU HUB THR (ACDelco #24233732) teamcadillac.ru not found BUSHING, ВЫХОДНОЙ CARR INR SUN GR SHF (ЧАСТЬ OF 64) 24225597 HUB, 1-2-3-4 CLU (W/ВЫХОДНОЙ CARR INR SUN GR SHF) not found BUSHING, ВЫХОДНОЙ CARR INR SUN GR SHF (ЧАСТЬ OF 64) 24224163 BEARING, 1-2-3-4 CLU HUB THR (ACDelco #24224163) 24225596 HUB, 2-6 & 3-5/REV CLU (W/ ВЫХОДНОЙ CARR OTR SUN GR SHF) (INCLS 60, 62) 24224164 BEARING, 2-6 & 3-5/REV CLU HUB THR (ACDelco #24224164) 24225512 RING, CTR SUPT RET 24225447 SUPPORT, CTR not found КРОНШТЕЙН, ВЫХОДНОЙ (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ВЫХОДНОЙ КРОНШТЕЙН БЛОК" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 24225486 BEARING, ВЫХОДНОЙ CARR THR not found SHAFT, ВЫХОДНОЙ (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ВЫХОДНОЙ ВАЛ БЛОК" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 24224668 BEARING, ВЫХОДНОЙ SHF THR (ACDelco #24224668) (GM04-598) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (6L50 MYB, ЗАДНИЙ КОЛЕСО DRIVE MX0) ↓ not found ТРАНСМИССИЯ, AUTO (REMAN) not found ТРАНСМИССИЯ, AUTO (SERV) 17804020 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 8BMA, 8BAA) teamcadillac.ru 17804029 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 8BTA) (GM04-599) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (6L50 MYB, ПОЛНОПРИВОДНЫЙ MX7) ↓ not found ТРАНСМИССИЯ, AUTO not found ТРАНСМИССИЯ, AUTO (REMAN) teamcadillac.ru not found ТРАНСМИССИЯ, AUTO (SERV) 17804021 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 8BBA, 8BSA) (REMAN) (GM04-617) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ЗАМОК ПАРКОВКИ(MX7) ↓ not found PLUG, PARK PAWL SHF HOLE (ЧАСТЬ OF CASE, A/TRNS - 04.103) not found SHAFT, PARK PAWL (ЧАСТЬ OF CASE, A/TRNS - 04.103) not found ПРУЖИНА, PARK PAWL (ЧАСТЬ OF CASE, A/TRNS - 04.103) not found PAWL, PARK (ЧАСТЬ OF CASE, A/TRNS - 04.103) teamcadillac.ru 24242086 ACTUATOR, PARK PAWL (ACDelco #24242086) 24227077 PIN, MAN SHFT DTNT LVR HUB (ЧАСТЬ OF 505) 24234562 LEVER, MAN SHFT DTNT (INCLS 504) (ACDelco #24234562) 24225792 PIN, MAN SHFT SHF (ACDelco #24225792) 24235861 SEAL, MAN SHFT SHF (*KIT1) (ACDelco #24235861) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24225445 SHAFT, MAN SHFT (ACDelco #24225445) 24228969 SHAFT, MAN SHFT (ACDelco #24228969) 24224348 GUIDE, PARK PAWL ACTR (INCLS 510) 24224350 SEAL, PARK PAWL ACTR GDE (O RING) (ЧАСТЬ OF 509) (*KIT1) (ACDelco #24224350) 24226102 PIN, PARK PAWL ACTR GDE 96022192 PLUG, MAN SHFT SHF HOLE 24243891 SEAL KIT, A/TRNS SERV (INCLS 507, 510) (FULL TRANS) (ACDelco #24243891) (GM04-618) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ЗАМОК ПАРКОВКИ(MX0) ↓ not found PLUG, PARK PAWL SHF HOLE (ЧАСТЬ OF CASE, A/TRANS - 04.103) not found SHAFT, PARK PAWL (ЧАСТЬ OF CASE, A/TRNS - 04.103) not found ПРУЖИНА, PARK PAWL (ЧАСТЬ OF CASE, A/TRNS - 04.103) not found PAWL, PARK (ЧАСТЬ OF CASE, A/TRNS - 04.103) 24242086 ACTUATOR, PARK PAWL (ACDelco #24242086) 24227077 PIN, MAN SHFT DTNT LVR HUB (ЧАСТЬ OF 505) 24234562 LEVER, MAN SHFT DTNT (INCLS 504) (ACDelco #24234562) 24225792 PIN, MAN SHFT SHF (ACDelco #24225792) 24235861 SEAL, MAN SHFT SHF (*KIT1) (ACDelco #24235861) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224348 GUIDE, PARK PAWL ACTR (INCLS 510) 24224350 SEAL, PARK PAWL ACTR GDE (O RING) (ЧАСТЬ OF 509) (*KIT1) (ACDelco #24224350) 24226102 PIN, PARK PAWL ACTR GDE 24225445 SHAFT, MAN SHFT (ACDelco #24225445) teamcadillac.ru 24228969 SHAFT, MAN SHFT (ACDelco #24228969) 24243891 SEAL KIT, A/TRNS SERV (INCLS 507, 510) (FULL TRANS) (ACDelco #24243891) (GM04-667) - 2008 D69 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 24240017 CONVERTER, TORQ [ГИДРОТРАНСФОРМАТОР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24243293 CONVERTER, TORQ not found ШЛАНГИ, T/CV (W/ ГИДРОНАСОС) (СМ. ГРУППУ 04.000 "TORQUE CONVERTOR ШЛАНГИ AND ГИДРОНАСОС" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11515762 БОЛТ, T/CV HSG (8.900) 24205899 PLUG, T/CV HSG ACC HOLE (28MM W/3 TANGS) (SMALL CVR) (ACDelco #24205899) 24225543 SEAL, A/TRNS ГИДРОНАСОС (ACDelco #24225543) [ПРОКЛАДКА КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] not found PIN, T/CV HSG LOC (ЧАСТЬ OF 7) 24242045 CASE, A/TRNS (INCLS 6, 12, 13) (ACDelco #24242045) 24242046 CASE, A/TRNS (INCLS 6, 12, 13) (ACDelco #24242046) teamcadillac.ru 24226020 PLUG, TRANS FLUID FIL TUBE not found SEAL, A/TRNS WRG CONN (*KIT1, KIT2) not found SEAL, A/TRNS WRG CONN (O RING) (*KIT1, KIT2) 24239878 SLEEVE, A/TRNS ELEC CONN PASG [МУФТА] not found PLUG, A/TRNS CASE (ЧАСТЬ OF 7) 11515762 БОЛТ, T/CV HSG (8.900) not found SEAL, A/TRNS ГИДРОНАСОС (*KIT2) not found SEAL, A/TRNS ГИДРОНАСОС (*KIT2) 24225557 SEAL, CTR SUPT FLUID PASG (*KIT2) not found VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 24237181 БОЛТ, VLV BODY (M5X0.8X73.0) 24231074 БОЛТ, MAN SHFT DTNT (M10X1X14.5) not found DETENT, MAN SHFT not found SEAL, A/TRNS FLUID FLTR (ЧАСТЬ OF 26) 24236933 FILTER KIT, A/TRNS FLUID (INCLS 25) (ACDelco #24236933) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24225800 GASKET, A/TRNS FLUID PAN (ACDelco #24225800) [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 29535617 MAGNET, A/TRNS FLUID PAN (4.105) (ACDelco #29535617) [МАГНИТ] 24242410 PAN, A/TRNS FLUID (INCLS 31) (ACDelco #24242410) 11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (A/TRNS FLUID PAN) [БОЛТ М6] 24234212 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 29) (ACDelco #24234212) [ПРОБКА] 24205900 COVER, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] 24225783 SEAL, A/TRNS CASE EXTN (ACDelco #24225783) [УПЛОТНИТЕЛЬ КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24249873 EXTENSION, A/TRNS CASE (ACDelco #24249873) 24228876 SEAL, ВЫХОДНОЙ SHF (5.556) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24214158 BEARING, ВЫХОДНОЙ SHF (DRAWN CUP) (4.131) (ACDelco #24214158) 24230287 FLANGE, PROP SHF TRANS 24231524 ГАЙКА, FRT PROP SHF FLG (M22X1.5) (FLANGE HEX) 24229687 EXTENSION, A/TRNS CASE (MCHG) 24242995 BEARING, ВЫХОДНОЙ SHF [ПОДШИПНИК КПП] 24236928 SEAL KIT, A/TRNS ELEC CONN PASG SLEV (INCLS 9, 10) 24238913 SEAL KIT, A/TRNS SERV (CONTROL VLV SOL ASM) (ACDelco #24238913) [КОМПЛЕКТ ПРОКЛАДОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (5ШТ)] (TS04-045) - 2008 DM69 ТОРМОЗНОЙ СУППОРТ-ЗАДНИЙ ↓ 25997338 PAD KIT, RR DISC BRK (INCLS 2) not found ПРУЖИНА, RR DISC BRK PAD (ЧАСТЬ OF 1) 25997457 BRACKET, RR BRK CLPR 25997463 BRACKET, RR BRK CLPR 88935808 SEAL KIT, RR BRK CLPR GDE PIN (4.670) [ЗАЩИТНЫЙ ЧЕХОЛ ПОРШНЯ ТОРМОЗНОГО СУППОРТА] 15855612 PIN, RR BRK CLPR GDE 25843039 CALIPER, RR BRK (17" ТОРМОЗА) (INCLS 8-12) [ТОРМОЗНОЙ СУППОРТ] 25843039 CALIPER, RR BRK (INCLS 8-12) [ТОРМОЗНОЙ СУППОРТ] 25843040 CALIPER, RR BRK (17" ТОРМОЗА) (INCLS 8-12) [СУППОРТ] 25843040 CALIPER, RR BRK (INCLS 8-12) [СУППОРТ] 25843041 CALIPER, RR BRK (INCLS 8-12) [СУППОРТ] teamcadillac.ru 25843042 CALIPER, RR BRK (INCLS 8-12) [СУППОРТ] 89027183 БОЛТ, RR BRK CLPR GDE PIN (M8X1.0) [БОЛТ М8] 88935785 CAP, RR BRK BLEDR VLV (ЧАСТЬ OF 6) [ЗАГЛУШКА ОБРАТНОГО КЛАПАНА] 89027179 VALVE, RR BRK BLEDR (ЧАСТЬ OF 6) not found SEAL, RR BRK CLPR PSTN (ЧАСТЬ OF 6) (*KIT1) 15926281 PISTON, RR BRK CLPR (18" H.D. ТОРМОЗА) (ЧАСТЬ OF 6) 15926282 PISTON, RR BRK CLPR (17" ТОРМОЗА) (ЧАСТЬ OF 6) not found BOOT, RR BRK CLPR PSTN (ЧАСТЬ OF 6) (*KIT1) 25814676 SEAL KIT, RR BRK CLPR PSTN (INCLS 10, 12) 25814677 SEAL KIT, RR BRK CLPR PSTN (INCLS 10, 12) [КОМПЛЕКТ ПРОКЛАДОК] (TS04-726) - 2008 DM69 ТОРМОЗНОЙ СУППОРТ-ПЕРЕДНИЙ (J55) ↓ 15851479 CALIPER, FRT BRK (INCLS 2, 3, 8, 9, 11) (18") [СУППОРТ] teamcadillac.ru 15851479 CALIPER, FRT BRK (INCLS 2, 3, 8, 9, 11) (18") [СУППОРТ] 15851480 CALIPER, FRT BRK (INCLS 2, 3, 8, 9, 11) (18") [СУППОРТ ТОРМОЗА] 15851480 CALIPER, FRT BRK (INCLS 2, 3, 8, 9, 11) (18") [СУППОРТ ТОРМОЗА] not found CAP, FRT BRK CLPR BLEDR VLV (ЧАСТЬ OF 1) 15851382 VALVE, FRT BRK CLPR BLEDR (ЧАСТЬ OF 1) 25809684 БОЛТ, FRT BRK CLPR HSG (GUIDE PIN) 25809681 PIN, FRT BRK CLPR GDE (W/O BUSHING) 25809679 PIN, FRT BRK CLPR GDE (INCLS 7) (W/PLASTIC SLEEVE 2.0MM FROM TIP) (W/BUSHING) not found BUSHING, FRT BRK CLPR GDE PIN (ЧАСТЬ OF 6, 10) not found SEAL, FRT BRK CLPR PSTN (ЧАСТЬ OF 1) (*KIT1) 15926289 PISTON, FRT BRK CLPR (ЧАСТЬ OF 1) 25814703 SEAL KIT, FRT BRK CLPR GDE PIN (INCLS 7) [ЗАСЛОНКА] not found BOOT, FRT BRK CLPR PSTN (ЧАСТЬ OF 1) (*KIT1) 25958115 PAD KIT, FRT DISC BRK (INCLS 14) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4ШТ)] 15851384 BRACKET, FRT BRK CLPR (18") 15851384 BRACKET, FRT BRK CLPR (18") 15851476 BRACKET, FRT BRK CLPR (18") 15851476 BRACKET, FRT BRK CLPR (18") not found ПРУЖИНА, FRT DISC BRK PAD RET (ЧАСТЬ OF 12) 25814704 SEAL KIT, FRT BRK CLPR PSTN (INCLS 8, 11) [КОМПЛЕКТ УПЛОТНИТЕЛЬНЫХ КОЛЕЦ ТОРМОЗНОГО СУППОРТА (2ШТ)] 04 - ТОРМОЗА (6D00-054) - 2008 DM69 ТРАНСМИССИЯ TO КРЕПЛЕНИЕ ДВИГАТЕЛЯ (AUTOMATIC MYB) ↓ 12603197 PLATE, A/TRNS FLEX 12603197 PLATE, A/TRNS FLEX 12603197 PLATE, A/TRNS FLEX 12597210 PIN, TRANS LOC 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] teamcadillac.ru 24242043 БОЛТ, TRANS CONV CVR (M6X1X18/M6X1X14) 24222918 COVER, TRANS CONV 24222918 COVER, TRANS (0.679) 24205900 COVER, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] (6D04-030) - 2008 DM69 ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР ↓ 18012741 SWITCH, BRK FLUID LVL IND (*KIT1) (ACDelco #18012741) teamcadillac.ru 22688449 CAP, BRK M/CYL RSVR (INCLS 3) (*KIT1) [КРЫШКА БАЧКА ТОРМОЗНОЙ ЖИДКОСТИ] not found DIAPHRAGM, BRK M/CYL RSVR (ЧАСТЬ OF 2) (*KIT1) not found PIN, BRK M/CYL RSVR (ЧАСТЬ OF 5) (*KIT1) 18046711 RESERVOIR, BRK M/CYL (INCLS 4, 6, 7) (*KIT1) (ACDelco #18046711) not found SEAL, BRK M/CYL RSVR (ЧАСТЬ OF 5) (*KIT1) not found SEAL, BRK M/CYL RSVR (ЧАСТЬ OF 5) (*KIT1) not found RETAINER, BRK M/CYL PRIM PSTN SPR (*KIT1) not found PISTON, BRK M/CYL PRIM (*KIT1) not found SEAL, BRK M/CYL SECD PSTN PRIM (*KIT1) not found RETAINER, BRK M/CYL SECD PSTN SPR (*KIT1) not found SEAL, BRK M/CYL (*KIT1) not found PISTON, BRK M/CYL SECD (*KIT1) not found ПРУЖИНА, BRK M/CYL SECD PSTN (*KIT1) not found BODY, BRK M/CYL (*KIT1) 15267509 CYLINDER, BRK MAS (INCLS 1-15) [БЛОК ЦИЛИНДРОВ] (6D04-033) - 2008 DM69 ТОРМОЗНОЙ УСИЛИТЕЛЬ ↓ 15267511 BOOSTER, P/B (INCLS 2-5) [ГИДРОУСИЛИТЕЛЬ ТОРМОЗНОЙ СИСТЕМЫ] not found GROMMET, P/B BOOS VAC CHK VLV (ЧАСТЬ OF 1, 3) 18022219 VALVE KIT, P/B BOOS VAC CHK (ЧАСТЬ OF 1) (INCLS 2) (BLACK) (INCLS VLV & GROM) (ACDelco #179-1266) 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 1) (0.80 IN) (PUSH IN) 15849743 ROD, BRK PED PUSH (ЧАСТЬ OF 1) (6D04-047) - 2008 DM69 ТОРМОЗНАЯ ПЕДАЛЬ ↓ not found REINFORCEMENT, STRG COL SUPT BRKT 25785092 BARRIER, BRK PED BRKT SND 25913292 BARRIER, BRK PED BRKT SND not found BRACKET, BRK PED (ЧАСТЬ OF 13) not found ГАЙКА, BRK PED BRKT BR (ЧАСТЬ OF 13) 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (ЧАСТЬ OF 13) (ACDelco #11517518) [БОЛТ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] not found STUD, BRK PED BRKT (ЧАСТЬ OF 13) not found BRACKET, BRK PED (ЧАСТЬ OF 13) 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 13) (0.80 IN) (PUSH IN) 15849743 ROD, BRK PED PUSH (ЧАСТЬ OF 13) 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 13) 25771615 COVER, BRK PED (ЧАСТЬ OF 13) 15254562 PEDAL, BRK (W/BRKT) (INCLS 3-5, 7-12, 14-19) 15254563 PEDAL, BRK (W/BRKT) (INCLS 3-5, 7-12, 14-19) 25814705 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 13) (INCLS 19) [ДАТЧИК] not found PIN, BRK PED PUSH ROD (ЧАСТЬ OF 13) not found PIN, BRK PED PIV (ЧАСТЬ OF 13) 15594358 BUSHING, BRK PED PIV (ЧАСТЬ OF 13) (0.831) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 13) 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 13, 14) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] (6D04-053) - 2008-2010 DM69 6-ТИ СКОРОСТНАЯ МКПП ЧАСТЬ 1 (MV7) ASM ↓ teamcadillac.ru 24242917 ТРАНСМИССИЯ, MAN [ТРАНСМИССИЯ] (6D04-054) - 2008-2010 DM69 6-ТИ СКОРОСТНАЯ МКПП ЧАСТЬ 2 (MV7) CASE COMPONENTS ↓ 89058852 БОЛТ, CLU ACTR (M6X1.0X20) 89048559 БОЛТ, CLU ACTR (M8X1.25X20) (4.104) 89058759 CASE, TRANS INTER (INCLS 8, 9) 89058774 BEARING, SHFT CONT SHF (ЧАСТЬ OF 7) (4.408) 89058791 PIN, TRANS INTER CASE LOC (ЧАСТЬ OF 7) 19178542 CASE, TRANS FRT (INCLS 12-16) 89058833 SEAL, MAIN SHF (ЧАСТЬ OF 11) not found SHIELD, INPUT SHF BRG OIL (ЧАСТЬ OF 11) 89058791 PIN, TRANS INTER CASE LOC (ЧАСТЬ OF 11) 89059311 PIN, TRANS CASE LOC (ЧАСТЬ OF 11) 89059312 PLUG, TRANS CASE HOLE (ЧАСТЬ OF 11) not found TROUGH, TRANS RR CASE OIL 89058837 SLINGER, INPUT SHF BRG OIL 89058839 TROUGH, M/TRNS OIL 89058840 TROUGH, TRANS INTER CASE OIL not found RETAINER, CNTR GR BRG 89058820 RETAINER, CNTR GR BRG (4.352) 89058760 CASE, TRANS RR (INCLS 24-26) not found BUSHING, SHFT SHF (ЧАСТЬ OF 23) 89058774 BEARING, SHFT SHF (ЧАСТЬ OF 23) 89058791 PIN, TRANS INTER CASE LOC (ЧАСТЬ OF 23) 89058853 БОЛТ, TRANS INTER CASE (M10X1.25X40) (4.104) 89058854 БОЛТ, TRANS INTER CASE (M10X1.25X80) (4.104) 89059319 GASKET, TRANS RR CASE 89058843 PLUG, CLU HSG HOLE 89059313 VENT, M/TRNS 89059314 SEAL, REV IDLER GR SHF (O RING) (ACDelco #89059314) 89048245 GASKET, TRANS OIL DRN PLUG (ACDelco #89048245) 19132842 PLUG, TRANS OIL DRN (4.510) 89059315 БОЛТ, REV IDLER GR SHF RET 19132971 PLUG, SHFT SHF DTNT 89048559 БОЛТ, TRANS INTER CASE OIL TROUGH (M8X1.25X20) (4.104) 89058855 БОЛТ, CNTR GR BRG RET (M8X1.25X25) 89058860 DETENT, SHFT SHF 89059329 DETENT, SHFT SHF (CAM) 19178544 ПРУЖИНА, SHFT SHF DTNT 89048248 PLUG, TRANS OIL FIL 89048248 PLUG, TRANS OIL FIL (4.104) 19178541 EXTENSION, TRANS (INCLS 87, 88) 89058838 SLINGER, INPUT SHF BRG OIL (ЗАДНИЙ) (ЧАСТЬ OF 86) 19180996 SEAL, SHFT CONT SHF (ЧАСТЬ OF 86) 89058835 SEAL, RR ВЫХОДНОЙ SHF 88972750 БОЛТ, TRANS EXTN (M8X1.25X40) (8.900) 19178540 FLANGE, TRANS PROP SHF 19132973 ГАЙКА, PROP SHF TRANS FLG 89058775 BEARING, REV IDLER GR 89058836 SEAL, PROP SHF TRANS FLG FLUID 89058790 SHAFT, REV IDLER GR 89058789 GEAR, REV IDLER 89059321 SWITCH, B/U LP (ACDelco #D2271C) teamcadillac.ru 89059318 RETAINER, B/U LP SW 89058851 SENSOR, M/TRNS ВЫХОДНОЙ SPD (4.337) 89058851 SENSOR, M/TRNS ВЫХОДНОЙ SPD 89058852 БОЛТ, VEH SPD SEN (M6X1.0X20) (0.780) 89058852 БОЛТ, VEH SPD SEN (M6X1.0X20) (0.780) 24242161 CYLINDER, CLU ACTR [ЦИЛИНДР] 89048245 GASKET, TRANS OIL FILL PLUG (ACDelco #89048245) (6D04-055) - 2008-2010 DM69 6-ТИ СКОРОСТНАЯ МКПП ЧАСТЬ 3 (MV7) ВХОДНОЙ И ВЫХОНОЙ ВАЛ COMPONENTS ↓ 89058782 BEARING, RR ВЫХОДНОЙ MAIN SHF RR 89058801 RING, 3RD GR BLOCKING 89058812 SLINGER, MAIN SHF BRG OIL (4.345) 19178534 SHAFT, RR MAIN 19132975 WASHER, 3RD GR THR 89058805 HUB, 3RD & 4TH GR SYN 19132845 SLEEVE, 3RD & 4TH GR SYN 19178535 INSERT, 3RD & 4TH GR SYN 89058792 RING, 4TH GR BLOCKING 19132849 ПРУЖИНА, 3RD & 4TH GR SYN 89058806 HUB, 5TH & 6TH GR SYN 89058810 BALL, 3RD & 4TH GR SYN DTNT 89058776 BEARING, INPUT SHF (RADIAL BALL) 89058777 BEARING, 4TH GR 89058779 BEARING, 6TH GR 89058778 BEARING, 3RD GR 89058780 BEARING, INPUT SHF (ROLLER) (ROLLER) 89058781 BEARING, RR ВЫХОДНОЙ SHF FRT 89059345 RING KIT, 3RD & 4TH GR RET 89059346 RING KIT, 5TH & 6TH GR SYN RET 89059347 RING KIT, 6TH GR RET 89059348 RING KIT, INPUT SHF BRG RET 89058813 RING, INPUT SHF BRG RET 89058863 SPACER, 6TH GR BRG 89058861 SPACER, 3RD & 4TH GR 89058864 SPACER, RR MAIN SHF RR BRG 89048344 PIN, GR THR WA LOC (4.419) 19178537 GEAR, 3RD 19178538 GEAR, 4TH 19178536 GEAR, 6TH 19178539 SHAFT, INPUT 89058773 GEAR, VEH SPD SEN DRV 89048423 BALL, SPEEDO DRV GR LOC 89058810 BALL, 5TH GR SYN DTNT 19178535 INSERT, 5TH & 6TH GR SYN not found ПРУЖИНА, 5TH & 6TH GR SYN 19132849 ПРУЖИНА, 5TH & 6TH GR SYN 19132845 SLEEVE, 5TH & 6TH GR SYN 89058792 RING, 6TH GR BLOCKING (4.383) teamcadillac.ru 89058792 RING, 5TH GR BLOCKING (6D04-056) - 2008-2010 DM69 6-ТИ СКОРОСТНАЯ МКПП ЧАСТЬ 4 (MV7) COUNTERSHAFT COMPONENTS ↓ 89058794 RING SET, 1ST GR BLOCKING (INCLS 96-98) not found CONE, 1ST GR SYN INR (ЧАСТЬ OF 95) not found CONE, 1ST GR SYN OTR (ЧАСТЬ OF 95) not found RING, 1ST GR OTR BLOCKING (ЧАСТЬ OF 95) 89058786 GEAR, REV GR DRV 89058865 BUSHING, REV GR BRG 89058807 HUB, 1ST & 2ND GR SYN 89058803 SLEEVE, 1ST & 2ND GR SYN 89058808 INSERT, 1ST & 2ND GR SYN 89058809 INSERT, REV GR SYN 89058793 RING, REV GR BLOCKING 89058811 ПРУЖИНА, 1ST & 2ND GR SYN 89058804 SLEEVE, REV GR SYN 89058810 BALL, 1ST & 2ND GR SYN DTNT 89058783 BEARING, CNTR GR FRT 89058785 BEARING, REV GR 89058787 BEARING, 1ST GR teamcadillac.ru 89058788 BEARING, 2ND GR 89058784 BEARING, CNTR GR RR 89059343 RING, CNTR GR FRT BRG RET not found RING KIT, 1ST & 2ND GR SYN HUB RET 89059344 RING KIT, 1ST & 2ND GR SYN HUB RET 89058822 RETAINER, CNTR GR FRT BRG 89048423 BALL, REV GR THR WA LOC (4.345) 89048329 ПРУЖИНА, REV GR SYN (4.384) 89058770 GEAR, 1ST 19178532 GEAR, 2ND 19178533 GEAR, CNTR 89058769 GEAR, REV 89058794 RING SET, 2ND GR BLOCKING (INCLS 905-907) not found RING, 2ND GR OTR BLOCKING (ЧАСТЬ OF 904) not found CONE, 2ND GR SYN OTR (ЧАСТЬ OF 904) not found CONE, 2ND GR SYN INR (ЧАСТЬ OF 904) 89059343 RING, CNTR GR FRT BRG RET (6D04-057) - 2008-2010 DM69 6-ТИ СКОРОСТНАЯ МКПП ЧАСТЬ 5 (MV7) SHIFT FORKS ↓ 19180997 JOINT, M/TRNS SHFT LVR ROD UNIVERSAL 19180067 PIN, M/TRNS SHFT LVR not found RETAINER, M/TRNS SEL SHF LVR ROD GROM 89059340 BRACKET, SHFT CONT LVR 89059331 CAM, SHFT SHF DTNT 89058762 FORK, 1ST & 2ND SHFT (INCLS BUSHINGS) 89058763 FORK, 3RD & 4TH SHFT (INCLS INSERTS) 89059342 ARM, CONT SEL 89058825 PIN, CONT SEL ARM 89058764 FORK, 5TH & 6TH SHFT (INCLS INSERTS) 89059332 LEVER, SHFT 19132858 LEVER, INTL SHFT CONT 19132857 LEVER, SEL CONT teamcadillac.ru 89058830 SHAFT, 1ST & 2ND SHFT 89059333 SHAFT, 3RD & 4TH SHFT 89059335 SHAFT, 5TH & 6TH SHFT 19132859 SHAFT, REV SHFT 89058832 LEVER, SHFT SHF DTNT 89058765 FORK, REV SHFT (INCLS INSERTS) 89058829 SHAFT, SHFT CONT 89059329 DETENT, SHFT SHF (CAM) (CAM) 89048287 БОЛТ, 3RD & 4TH SHFT FORK 89048272 PIN, SEL CONT LVR (4.008) 89048289 PIN, REV SHFT FORK (4.303) 89059339 ROLLER, SHFT SHF DTNT 19178531 ПРУЖИНА, SHFT DTNT BALL 19178544 ПРУЖИНА, SHFT SHF DTNT 89058857 БОЛТ, SHFT SHF DTNT LVR (M8X1.0X21.2) 89059338 PIN, SHFT SHF INTLK (M4X11.2) 89059337 PIN, SHFT SHF INTLK (M6X13.6) 89048292 BALL, SHFT DTNT 89058858 БОЛТ, SHFT CONT LVR BRKT (M8X1.25X32) 89058824 RETAINER, SEL CONT LVR PIN 89059316 PIN, SHFT SHF (4.408) 89058842 WEIGHT, SHFT LVR C/BAL (EXTERNAL) (4.105) 89059320 BLOCK, SHFT CONT SHF 89048272 PIN, SHFT LVR (4.008) 89048272 PIN, 1ST & 2ND SHFT FORK (4.008) 89048287 БОЛТ, 5TH & 6TH SHFT FORK (6D04-063) - 2008-2009 DM69 КОРПУС КП КРЕПЛЕНИЕ (ПОЛНОПРИВОДНЫЙ MX7) ↓ 24231525 GASKET, TRFER CASE 24249544 CASE, TRFER (W/GEARS) 11589341 БОЛТ - HFH, M10X1.5X69.9, 28.35 THD, 22.3 OD, 10.9, GMW3359, M-PT. (TRFER CASE) [БОЛТ] teamcadillac.ru 19179016 DAMPENER, TRFER CASE VIB (AT RR OF CASE) (6D04-072) - 2008-2009 DM69 ТОРМОЗНЫЕ МАГИСТРАЛИ-ПЕРЕДНИЕ (ЗАДНИЙ КОЛЕСО DRIVE MN6,MX0) ↓ 15904905 PIPE, BRK PRESS MOD VLV FRT [ТРУБКА ТОРМОЗНОЙ СИСТЕМЫ] 15904915 SPACER, FRT BRK PIPE not found CYLINDER, BRK MAS (СМ. ГРУППУ 04.000 "ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 15904908 PIPE, BRK PRESS MOD VLV RR [НАСОС В СБОРЕ] not found БОЛТ, FRT BRK HOSE (ЧАСТЬ OF 8, 20) 21012386 WASHER, FRT BRK HOSE (ЧАСТЬ OF 8, 20) (10.3X14.5X1.61) (COPPER) (ACDelco #21012386) [ШАЙБА 10 ММ] 11516546 БОЛТ, HFL, M8X1.25X50, 37.2 THD, 18 OD, 10.9, PZO 7114M (FRT S/ABS) 15818105 HOSE, FRT BRK (INCLS 5, 6, 9, 10) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ] 11569742 RETAINER, FRT BRK HOSE (ЧАСТЬ OF 8, 20) (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] not found BRACKET, FRT BRK HOSE (ЧАСТЬ OF 8) 11514623 БОЛТ, HEX W/CON WA, M6X1X20 (FRT BRK HOSE) 11569751 ГАЙКА, HX TUBE INVERTED FLARE, M10X1X16, SAE1010, GMW4707M (FRT BRK PIPE) [ШАЙБА] 88983905 PIPE, BRK (3/16" X 16 FT) (BULK TUBING) (NYLON COATING) [ТРУБКА ТОРМОЗНОЙ СИСТЕМЫ] 25957289 RETAINER, FRT BRK PIPE (4 TUBE W/TREE) teamcadillac.ru 15904901 RETAINER, FRT BRK PIPE (STAR SHAPED 3 TUBE W/TREE) [КРОНШТЕЙН] 12477665 PROTECTOR, FRT BRK PIPE (FOR 1/4" PIPE) (HT SHRINK) not found VALVE, BRK PRESS MOD (W/ELEK BRK & TRACT CONT MDL) (СМ. ГРУППУ 04.000 "КЛАПАН РЕГУЛИРОВКИ ДАВЛЕНИЯ В ТОРМОЗНОЙ СИСТЕМЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11569750 ГАЙКА, HX FLARED TUBE, M12X1.0X17, 5.3 TUBE, SAE1010, GMW4707M (FRT BRK PIPE) [ФИТИНГ ТРУБКИ ТОРМОЗНОЙ СИСТЕМЫ] not found BRACKET, FRT BRK HOSE (ЧАСТЬ OF 20) 15818106 HOSE, FRT BRK (INCLS 5, 6, 9, 19) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ] (6D04-073) - 2008-2009 DM69 ТОРМОЗНЫЕ МАГИСТРАЛИ-ПЕРЕДНИЕ (ПОЛНОПРИВОДНЫЙ MX7) ↓ 15904910 PIPE, BRK PRESS MOD VLV RR [ТРУБКА] teamcadillac.ru 15904915 SPACER, FRT BRK PIPE not found CYLINDER, BRK MAS (СМ. ГРУППУ 04.000 "ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 15904907 PIPE, BRK PRESS MOD VLV FRT [НАСОС В СБОРЕ] 11570052 FITTING, FRT BRK HOSE (ЧАСТЬ OF 7) (M10X1X27.5, 16.9THD) (4.671) 21012386 WASHER, FRT BRK HOSE (ЧАСТЬ OF 7) (10.3X14.5X1.61) (COPPER) (ACDelco #21012386) [ШАЙБА 10 ММ] 25928987 HOSE, FRT BRK (INCLS 5, 6) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ] 25928988 HOSE, FRT BRK (INCLS 5, 6) 11516521 БОЛТ, HFH M6X1X20, 9.8, 7114M, DOG PT, 14.2 OD (FRT BRK HOSE) 11569742 RETAINER, FRT BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 11569751 ГАЙКА, HX TUBE INVERTED FLARE, M10X1X16, SAE1010, GMW4707M (FRT BRK PIPE) [ШАЙБА] 88983905 PIPE, BRK (3/16" X 16 FT) (BULK TUBING) (NYLON COATING) [ТРУБКА ТОРМОЗНОЙ СИСТЕМЫ] 15904902 RETAINER, FRT BRK PIPE (UPSIDE DOWN 3 TUBE CLIP W/O TREE) [КРОНШТЕЙН] 15904903 RETAINER, FRT BRK PIPE (UPSIDE DOWN 3 TUBE WITH TREE) [КРОНШТЕЙН] 12477665 PROTECTOR, FRT BRK PIPE (FOR 1/4" PIPE) (HT SHRINK) 88964150 PROTECTOR, FRT BRK PIPE (FOR 3/16" PIPE) (HT SHRINK) 15904901 RETAINER, FRT BRK PIPE (STAR SHAPED 3 TUBE W/TREE) [КРОНШТЕЙН] not found VALVE, BRK PRESS MOD (W/ELEK BRK & TRACT CONT MDL) (СМ. ГРУППУ 04.000 "КЛАПАН РЕГУЛИРОВКИ ДАВЛЕНИЯ В ТОРМОЗНОЙ СИСТЕМЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11569750 ГАЙКА, HX FLARED TUBE, M12X1.0X17, 5.3 TUBE, SAE1010, GMW4707M (FRT BRK PIPE) [ФИТИНГ ТРУБКИ ТОРМОЗНОЙ СИСТЕМЫ] (6D04-074) - 2008 DM69 ТОРМОЗНЫЕ МАГИСТРАЛИ-ЗАДНИЕ ↓ 15818185 HOSE, RR BRK (INCLS 2, 3, 5, 6) [ТРУБКА] 21012386 WASHER, RR BRK HOSE (ЧАСТЬ OF 1, 12) (10.3X14.5X1.61) (COPPER) (ACDelco #21012386) [ШАЙБА 10 ММ] not found БОЛТ, RR BRK HOSE (ЧАСТЬ OF 1, 12) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (RR BRK HOSE BRKT) [ГАЙКА М6] not found BRACKET, RR BRK HOSE (ЧАСТЬ OF 1) 11569742 RETAINER, RR BRK HOSE (ЧАСТЬ OF 1) (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 11569742 RETAINER, RR BRK HOSE (ЧАСТЬ OF 1) (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 11569751 ГАЙКА, HX TUBE INVERTED FLARE, M10X1X16, SAE1010, GMW4707M (RR BRK PIPE) [ШАЙБА] 88983905 PIPE, BRK (3/16" X 16 FT) (BULK TUBING) (NYLON COATING) [ТРУБКА ТОРМОЗНОЙ СИСТЕМЫ] 15194329 CLIP, RR BRK PIPE (27X35X15) 88964150 PROTECTOR, FRT BRK PIPE (FOR 3/16" PIPE) (HT SHRINK) 15818187 HOSE, RR BRK (INCLS 2, 3) [ТРУБКА] 25607191 RETAINER, BRK PIPE (21.5X10.0MM) (HOLDS (2) 4.68-4.82 TUBES) 25607191 RETAINER, BRK PIPE (21.5X10.0MM) (HOLDS (2) 4.68-4.82 TUBES) 15870391 RETAINER, BRK & FUEL PIPE (HOLDS FOUR LINES) 15870391 RETAINER, BRK & FUEL PIPE (HOLDS FOUR LINES) (3.162) 11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (FUEL FLTR BRKT) [БОЛТ М8] 15223307 RETAINER, BRK & FUEL PIPE (2 FUEL/VAPOR LINES) 15223307 RETAINER, BRK & FUEL PIPE (2 FUEL/VAPOR LINES) (3.162) 15223304 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (HOLDS FOUR LINES) (3.890) 15223306 RETAINER, BRK & FUEL PIPE (2 FUEL/VAPORS LINE & 2 BRAKE LINES) teamcadillac.ru 15223306 RETAINER, BRK & FUEL PIPE (2 FUEL/VAPORS LINE & 2 BRAKE LINES) (3.162) 88964150 PROTECTOR, BRK PIPE (FOR 3/16" PIPE) (HT SHRINK) 15223308 RETAINER, BRK & FUEL PIPE (ATTACHES TO BRKT) 15223308 RETAINER, BRK & FUEL PIPE (ATTACHES TO BRKT) (3.162) 25761218 BRACKET, FUEL PIPE 11514623 БОЛТ, HEX W/CON WA, M6X1X20 (FUEL FEED & EVAP EMIS & RTN PIPE CLIP BRKT) 25957289 RETAINER, FRT BRK PIPE (4 TUBE W/TREE) 11569750 ГАЙКА, HX FLARED TUBE, M12X1.0X17, 5.3 TUBE, SAE1010, GMW4707M (FRT BRK PIPE) [ФИТИНГ ТРУБКИ ТОРМОЗНОЙ СИСТЕМЫ] not found VALVE, BRK PRESS MOD (W/ELEK BRK & TRACT CONT MDL) (СМ. ГРУППУ 04.000 "КЛАПАН РЕГУЛИРОВКИ ДАВЛЕНИЯ В ТОРМОЗНОЙ СИСТЕМЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6D04-076) - 2008-2009 DM69 СТОЯНОЧНЫЙ ТОРМОЗ SYSTEM ↓ 15836531 REINFORCEMENT, PARK BRK LVR BRKT (INCLS 2) 11610157 ГАЙКА, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (ЧАСТЬ OF 1) (10.701) [ГАЙКА М4] 25880964 HANDLE, PARK BRK REL 11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (PARK BRK REL HDL) [ВИНТ] 25791543 CABLE, PARK BRK REL (ЧАСТЬ OF 6) 25885037 LEVER, PARK BRK (INCLS 5, 7-9) not found PAD, PARK BRK LVR PED (ЧАСТЬ OF 6) 10369646 БОЛТ, PARK BRK IND SW (ЧАСТЬ OF 6) teamcadillac.ru 22654577 SWITCH, PARK BRK IND (ЧАСТЬ OF 6) (ACDelco #22654577) [ВКЛЮЧАТЕЛЬ] 15242114 CABLE, PARK BRK INTER (INCLS 14) [КАБЕЛЬ] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (PARK BRK INTER CBL GDE) [ГАЙКА М6] 11518625 БОЛТ, PAN, M10X1.5X35, 33.5THD, 20 O.D., 10.9, 6138M (PARK BRK INTER CBL GDE) 20774147 CABLE, PARK BRK RR 20823796 CONNECTOR, PARK BRK CBL (ЧАСТЬ OF 10) 11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (I/P LWR BRKT) [ВИНТ] 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (PARK BRK REL HDL BRKT) [ВИНТ М4] (6D04-077) - 2008-2009 DM69 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (MYB, ПОЛНОПРИВОДНЫЙ MX7, EXC EXTRA CAPACITY V03, HEAVY DUTY V08) ↓ 24237658 SEAL, TRANS FLUID CLR PIPE FTG (SEALS ONE PIPE) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ] 15251488 SEAL, TRANS FLUID CLR HOSE (ЧАСТЬ OF 4) (SEALS TWO ТРУБКИ) [УПЛОТНЕНИЕ] 11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) [БОЛТ, М8Х1.25Х31.5] 15853683 HOSE, TRANS FLUID CLR (INCLS 2, 6, 7, 10) [ТРУБКА] 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 10405874 CLIP, TRANS FLUID CLR HOSE (ЧАСТЬ OF 4) (LESS MNTG TAB) (HOLDS TWO 9.5 DIA TUBES) 15052228 CЛАМПА, TRANS FLUID CLR HOSE (ЧАСТЬ OF 4) (PLASTIC RETAINER) (ACDelco #15052228) [ФИТИНГ ТРУБОПРОВОДА] not found FITTING, TRANS FLUID CLR PIPE not found RETAINER, TRANS FLUID CLR PIPE FTG not found BRACKET, TRANS OIL CLR INL & OTLT PIPE (ЧАСТЬ OF 4) (6D04-078) - 2008 DM69 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (MYB, ЗАДНИЙ КОЛЕСО DRIVE MX0, EXC EXTRA CAPACITY V03, HEAVY DUTY V08) ↓ 24237658 SEAL, TRANS FLUID CLR PIPE FTG (SEALS ONE PIPE) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ] 15251488 SEAL, TRANS FLUID CLR HOSE (ЧАСТЬ OF 3) (SEALS TWO ТРУБКИ) [УПЛОТНЕНИЕ] 15267714 HOSE, TRANS FLUID CLR (INCLS 2, 5, 6, 9) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) [БОЛТ, М8Х1.25Х31.5] 10405874 CLIP, TRANS FLUID CLR HOSE (ЧАСТЬ OF 3) (LESS MNTG TAB) (HOLDS TWO 9.5 DIA TUBES) teamcadillac.ru 15052228 CЛАМПА, TRANS FLUID CLR HOSE (ЧАСТЬ OF 3) (PLASTIC RETAINER) (ACDelco #15052228) [ФИТИНГ ТРУБОПРОВОДА] not found FITTING, TRANS FLUID CLR PIPE not found RETAINER, TRANS FLUID CLR PIPE FTG not found BRACKET, TRANS OIL CLR INL & OTLT PIPE (ЧАСТЬ OF 3) 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] (6D04-079) - 2008-2009 DM69 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (MYB, ПОЛНОПРИВОДНЫЙ MX7, EXTRA CAPACITY V03, HEAVY DUTY V08) ↓ 25829909 COOLER, TRANS FLUID AUX (INCLS 13-15) (ACDelco #25829909) [ОХЛАДИТЕЛЬ] not found RETAINER, TRANS FLUID CLR PIPE FTG 25830126 CLIP, TRANS FLUID CLR PIPE not found BRACKET, TRANS OIL CLR INL & OTLT PIPE (ЧАСТЬ OF 8) 24237658 SEAL, TRANS FLUID CLR PIPE FTG (SEALS ONE PIPE) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ] 15251488 SEAL, TRANS FLUID CLR HOSE (ЧАСТЬ OF 8) (SEALS TWO ТРУБКИ) [УПЛОТНЕНИЕ] 11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) [БОЛТ, М8Х1.25Х31.5] 25829902 HOSE, TRANS FLUID CLR (INCLS 4, 6, 11) [ШЛАНГ] teamcadillac.ru 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 10405874 CLIP, TRANS FLUID CLR HOSE (LESS MNTG TAB) (HOLDS TWO 9.5 DIA TUBES) 15052228 CЛАМПА, TRANS FLUID CLR HOSE (ЧАСТЬ OF 8) (PLASTIC RETAINER) (ACDelco #15052228) [ФИТИНГ ТРУБОПРОВОДА] 25829910 PIPE, TRANS FLUID AUX CLR (INCLS 17) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 19129762 FITTING, TRANS FLUID CLR PIPE (ЧАСТЬ OF 1) [СОЕДИНИТЕЛЬ] 24205103 RETAINER, TRANS FLUID AUX CLR (ЧАСТЬ OF 1) (EXPANDING ПРУЖИНА WIRE) (ACDelco #24205103) [СТОПОРНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ] 10405874 CLIP, TRANS FLUID CLR HOSE (ЧАСТЬ OF 1) (LESS MNTG TAB) (HOLDS TWO 9.5 DIA TUBES) 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 15052228 CAP, TRANS FLUID CLR PIPE CONN (ЧАСТЬ OF 12) (PLASTIC RETAINER) (ACDelco #15052228) [ФИТИНГ ТРУБОПРОВОДА] not found FITTING, TRANS FLUID CLR PIPE (6D04-080) - 2008 DM69 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (MYB, ЗАДНИЙ КОЛЕСО DRIVE MX0, EXTRA CAPACITY V03, HEAVY DUTY V08) ↓ 25829909 COOLER, TRANS FLUID AUX (INCLS 13-15) (ACDelco #25829909) [ОХЛАДИТЕЛЬ] not found RETAINER, TRANS FLUID CLR PIPE FTG 25830126 CLIP, TRANS FLUID CLR PIPE 11516149 ГАЙКА, U, 8X1.25, MULTI THD, .08'-4.0' THK PNL, PZ (TRANS FLUID CLR HOSE CLIP BRKT) [ГАЙКА М8] 24237658 SEAL, TRANS FLUID CLR PIPE FTG (SEALS ONE PIPE) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ] 15251488 SEAL, TRANS FLUID CLR HOSE (ЧАСТЬ OF 8) (SEALS TWO ТРУБКИ) [УПЛОТНЕНИЕ] 11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) [БОЛТ, М8Х1.25Х31.5] 25829896 HOSE, TRANS FLUID CLR (INCLS 6, 9, 11, 19) [ШЛАНГ] 10405874 CLIP, TRANS FLUID CLR HOSE (ЧАСТЬ OF 8) (LESS MNTG TAB) (HOLDS TWO 9.5 DIA TUBES) 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] not found BRACKET, TRANS OIL CLR INL & OTLT PIPE (ЧАСТЬ OF 8) 25829910 PIPE, TRANS FLUID AUX CLR (INCLS 17) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 19129762 FITTING, TRANS FLUID CLR PIPE (ЧАСТЬ OF 1) [СОЕДИНИТЕЛЬ] 24205103 RETAINER, TRANS FLUID AUX CLR (ЧАСТЬ OF 1) (EXPANDING ПРУЖИНА WIRE) (ACDelco #24205103) [СТОПОРНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ] not found CLIP, TRANS FLUID CLR HOSE (ЧАСТЬ OF 1) 11570324 БОЛТ, TRANS FLUID CLR (M6X1X14, 9 THD) (9.190) 15052228 CAP, TRANS FLUID CLR PIPE CONN (ЧАСТЬ OF 12) (PLASTIC RETAINER) (ACDelco #15052228) [ФИТИНГ ТРУБОПРОВОДА] not found FITTING, TRANS FLUID CLR PIPE 15052228 CЛАМПА, TRANS FLUID CLR HOSE (ЧАСТЬ OF 8) (PLASTIC RETAINER) (ACDelco #15052228) [ФИТИНГ ТРУБОПРОВОДА] (6D04-081) - 2008 DM69 BRAKES-ВЕНТИЛЯЦИЯ ↓ 25940079 EXTENSION, FRT BPR FASCIA (СМ. ГРУППУ 07.000 "БАМПЕР ПЕРЕДНИЙ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/HOLE) [ПОДКРЫЛОК] 25940080 EXTENSION, FRT BPR FASCIA (СМ. ГРУППУ 07.000 "БАМПЕР ПЕРЕДНИЙ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/HOLE) [БОКОВАЯ ПАНЕЛЬ БАМПЕРА] 15272166 DUCT, FRT BRK CLPR CLG (CONNECTS TO FRT WHL EXTN) [ТРУБКА ВОЗДУХОВОДА] 15272167 DUCT, FRT BRK CLPR CLG (CONNECTS TO FRT FASCIA) [ТРУБКА] 15272168 DUCT, FRT BRK CLPR CLG (CONNECTS TO FRT FASCIA) [ТРУБКА] 20772527 DUCT, FRT BRK CLPR CLG (CONNECTS TO FRT FASCIA) [ВОЗДУХОЗАБОРНИК ТОРМОЗНОЙ СИСТЕМЫ] 20772528 DUCT, FRT BRK CLPR CLG (CONNECTS TO FRT FASCIA) [ВОЗДУХОЗАБОРНИК ТОРМОЗНОЙ СИСТЕМЫ] 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (FRT FOG LP BRKT) [ВИНТ М4] 25536302 ГАЙКА, FRT BPR UPR FASCIA (4.2 X 1.41) (TAPPING NUT) (3.430) [ПРИЖИМНАЯ ПЛАСТИНА ПАНЕЛИ КУЗОВА] 15272157 BEZEL, FRT FOG LP (FOR VEHICLES BUILT W/FRONT BRAKE ОХЛАЖДЕНИЕ DUCTS) (ON VEH BUILT BEFORE 3/31/08 OR IF REPLACED BEZEL HAS OPENINGS/SLOTSMUST ALSO ORDER 25961369) 15904574 BEZEL, FRT FOG LP [НАКЛАДКА ПАНЕЛИ БАМПЕРА] 15904575 BEZEL, FRT FOG LP [ОКАНТОВКА ПРОТИВОТУМАННОЙ ФАРЫ] 25961369 BEZEL, FRT FOG LP (FOR VEHICLES BUILT W/ FRONT BRAKE ОХЛАЖДЕНИЕ DUCTS) (ON VEH BUILT BEFORE 3/31/08 OR IF REPLACED BEZEL HAS OPENINGS/SLOTS, MUST ALSO ORDER 25961370) teamcadillac.ru 10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (FRT BRK CLPR CLG DUCT) [ПИСТОН КРЕПЛЕНИЯ ОБЛИЦОВКИ БАМПЕРА (NYLON)] 11561857 CLIP, FRT FOG LP ADJ БОЛТ RET (BLACK) (14.13 X 11 X 8.6) (7.831) (6D04-082) - 2008-2009 DM69 УПРАВЛЕНИЕ АКПП/АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) ↓ teamcadillac.ru 25887055 PLATE, F/FLR CNSL TRANS SHFT OPG TR (INCLS 2, 3, 13-15) [РАМКА РЫЧАГА ПЕРЕКЛЮЧЕНИЯ ПЕРЕДАЧ] 25801116 INDICATOR, A/TRNS CONT (ЧАСТЬ OF 1) 11509231 SCREW, RD HD C/R TAP, M4.2X1.41X13.0, GM6010M STL, GM813M NICKEL ORGANIC (ЧАСТЬ OF 1) [ВИНТ М6Х12] 25907978 CONTROL, A/TRNS (INCLS 5-8) [БЛОК УПРАВЛЕНИЯ] 25907978 CONTROL, A/TRNS (INCLS 5-8) (4.004) [БЛОК УПРАВЛЕНИЯ] 25907979 CONTROL, A/TRNS (INCLS 5-8) [БЛОК УПРАВЛЕНИЯ] 25907979 CONTROL, A/TRNS (INCLS 5-8) (4.004) [БЛОК УПРАВЛЕНИЯ] 25907980 CONTROL, A/TRNS (INCLS 5-8) [БЛОК УПРАВЛЕНИЯ] 25907980 CONTROL, A/TRNS (INCLS 5-8) (4.004) [БЛОК УПРАВЛЕНИЯ] 25907981 CONTROL, A/TRNS (INCLS 5-8) [БЛОК УПРАВЛЕНИЯ] 25907981 CONTROL, A/TRNS (INCLS 5-8) (4.004) [БЛОК УПРАВЛЕНИЯ] 25907982 CONTROL, A/TRNS (INCLS 5-8) [БЛОК УПРАВЛЕНИЯ] 25907982 CONTROL, A/TRNS (INCLS 5-8) (4.004) [БЛОК УПРАВЛЕНИЯ] 25908000 CONTROL, A/TRNS (INCLS 5-8) [БЛОК УПРАВЛЕНИЯ] 25908000 CONTROL, A/TRNS (INCLS 5-8) (4.004) [БЛОК УПРАВЛЕНИЯ] 25824055 KNOB, A/TRNS CONT LVR (ЧАСТЬ OF 4) (INCLS 6) (COCOA) (ALL LEATHER) 25824057 KNOB, A/TRNS CONT LVR (ЧАСТЬ OF 4) (INCLS 6) (EBONY) (SIDE EBONY LEATHER MIDDLE FIGURED SAPELE) 25824059 KNOB, A/TRNS CONT LVR (ЧАСТЬ OF 4) (INCLS 6) (COCOA) (SIDE COCOA LEATHER MIDDLE FIGURED SAPELE) 25824060 KNOB, A/TRNS CONT LVR (ЧАСТЬ OF 4) (INCLS 6) (EBONY) (ALL LEATHER) 11570687 БОЛТ, A/TRNS CONT LVR KNOB (ЧАСТЬ OF 4, 5) 25824062 BOOT, A/TRNS CONT (ЧАСТЬ OF 4) (EBONY) 25824064 BOOT, A/TRNS CONT (ЧАСТЬ OF 4) (COCOA) 25824053 BASE, A/TRNS CONT (ЧАСТЬ OF 4) 25824054 BASE, A/TRNS CONT (ЧАСТЬ OF 4) 11514603 ГАЙКА, M10X1.5 15MM SOCKET (A/TRNS RANGE SEL LVR) [ШАЙБА] 11519095 NUT-ACORN HEX, M8X1.0, 15MM THK, 9, 6047M, W/DOME. (A/TRNS RANGE SEL LVR) [ГАЙКА] 15780844 LINK, A/TRNS RANGE SEL LVR 15780845 LINK, A/TRNS RANGE SEL LVR 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL ROD ADJ) [ГАЙКА М6] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL LVR CBL BRKT) [ГАЙКА М6] 11610112 CLIP, F/FLR CNSL TR PLT (TR PLT TO SI PNL) (ЧАСТЬ OF 1) (10.4 X 13 X 9) (14.683) not found БОЛТ, F/FLR CNSL CVR (ЧАСТЬ OF 1) not found COVER, F/FLR CNSL FRT (ЧАСТЬ OF 1) (6D04-083) - 2008-2010 DM69 УПРАВЛЕНИЕ АКППS/РУЧНАЯ ТРАНСМИССИЯ (MV7) ↓ 25806639 KNOB, M/TRNS CONT LVR (W/BOOT & W/SHFT PATT) (INCLS 13) 25806640 KNOB, M/TRNS CONT LVR (W/BOOT & W/SHFT PATT) (INCLS 13) 25887053 PLATE, F/FLR CNSL TRANS SHFT OPG TR (INCLS 9, 10, 12) 15794036 PLATE, M/TRNS CONT MT 15794035 CONTROL, M/TRNS (W/SHFT PATT) [БЛОК УПРАВЛЕНИЯ] 21996990 PIN, M/TRNS CONT SHF EQLZR LVR (SHIFTER END) 25708836 RETAINER, M/TRNS SHFT LVR 25753853 PIN, M/TRNS CONT SHF EQLZR LVR (TRANS END) teamcadillac.ru 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (M/TRNS CONT BRKT) [ГАЙКА М6] 11509231 SCREW, RD HD C/R TAP, M4.2X1.41X13.0, GM6010M STL, GM813M NICKEL ORGANIC (ЧАСТЬ OF 2) [ВИНТ М6Х12] not found COVER, F/FLR CNSL FRT (ЧАСТЬ OF 2) 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (M/TRNS CONT BRKT) 11570189 CLIP, F/FLR CNSL TR PLT (ЧАСТЬ OF 2) 11610112 CLIP, F/FLR CNSL TR PLT (TR PLT TO SI PNL) (ЧАСТЬ OF 2) (10.4 X 13 X 9) (14.683) not found CAP, M/TRNS SEL LVR (ЧАСТЬ OF 1) (6D04-084) - 2008-2009 DM69 ТОРМОЗНОЙ УСИЛИТЕЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (LP1/2.8T,LY7/3.6-7) ↓ not found CYLINDER, BRK MAS (СМ. ГРУППУ 04.000 "ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] not found REINFORCEMENT, P/B BOOS (ЧАСТЬ OF PANEL, AIR INL GRL - 12.800) 10125439 RIVET, FLAT HD, 3 LEG EXPANSION, M4.8 SHAFT, 23.5 LG, 9.8 O.D., AL (AIR INL GRL PNL) [ЗАКЛЕПКА D=4.8 ММ] not found CYLINDER, CLU MAS (СМ. ГРУППУ 00.000 "ПЕДАЛЬ СЦЕПЛЕНИЯ-ЦИЛИНДРЫ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 24245109 CYLINDER, CLU MAS (СМ. ГРУППУ 00.000 "ПЕДАЛЬ СЦЕПЛЕНИЯ-ЦИЛИНДРЫ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ЦИЛИНДР] 25873484 HOSE, P/B BOOS VAC (ACDelco #176-1497) 25873484 HOSE, P/B BOOS VAC (ACDelco #176-1497) 25923501 HOSE, P/B BOOS VAC not found BOOSTER, P/B (СМ. ГРУППУ 04.000 "ТОРМОЗНОЙ УСИЛИТЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25675835 BRACKET, BRK PED BRKT 15849744 BOOT, BRK PED PUSH ROD 25697461 RETAINER, BRK PED PUSH ROD BOOT 25785092 BARRIER, BRK PED BRKT SND 25913292 BARRIER, BRK PED BRKT SND teamcadillac.ru not found PEDAL, BRK (W/BRKT) (СМ. ГРУППУ 04.000 "ТОРМОЗНАЯ ПЕДАЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11514519 ГАЙКА, BRK PED BRKT (M8X1.25, 7.32 THK) (9510M, ZF) (8.915) [ГАЙКА] not found REINFORCEMENT, P/B BOOS (СМ. ГРУППУ 10.000 "СТЕКЛООЧИСТИТЕЛЬ-ВЕТРОВОГО СТЕКЛА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6D04-085) - 2008 DM69 КЛАПАН РЕГУЛИРОВКИ ДАВЛЕНИЯ В ТОРМОЗНОЙ СИСТЕМЕ ↓ 25853512 МОДУЛЬ, ELEK BRK & TRACT CONT [МОДУЛЬ] teamcadillac.ru 25854972 БОЛТ, ELEK BRK CONT MDL (ECU TO HCU ATTACH) (M4X0.7X19.5, 10THD) not found БОЛТ, ELEK BRK CONT MDL BRKT (*KIT1) not found INSULATOR, BRK PRESS MOD VLV BRKT (*KIT1) not found INSULATOR, BRK PRESS MOD VLV (*KIT1) 15298281 VALVE, BRK PRESS MOD [КЛАПАН] 15286358 INSULATOR KIT, BRK PRESS MOD VLV (INCLS 3-5) (6D04-086) - 2008 DM69 ЭЛЕКТРИЧЕСКАЯ СИСТЕМА АБС ↓ 25996837 SENSOR, FRT WHL SPD (INCLS 2, 3, 6) teamcadillac.ru 15158259 CLIP, WHL SPD SEN WIRE (ЧАСТЬ OF 1, 15) (12.0MM HOLE) 15158261 CLIP, WHL SPD SEN WIRE (ЧАСТЬ OF 1) (11MM HOLE) not found HARNESS, ENG WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/ДВИГАТЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found VALVE, BRK PRESS MOD (W/ELEK BRK & TRACT CONT MDL) (СМ. ГРУППУ 04.000 "BRAKE CONTROL МОДУЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 15715954 CLIP, WHL SPD SEN WIRE (ЧАСТЬ OF 1) (TREE FITS 6.5 HOLE) (HOLDS (1) 10.5MM GROMMET ROUTING (1) 6.35 SPD SEN CBL) 11516521 БОЛТ, HFH M6X1X20, 9.8, 7114M, DOG PT, 14.2 OD (FRT WHL SPD SEN) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (VEH YAW SEN & LATL ACCLRM) 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (VEH YAW SEN & LATL ACCLRM) [БОЛТ М6] not found HARNESS, BODY WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/КУЗОВ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 15845467 SENSOR, VEH YAW (W/VEH LATL ACCLRM) (LABELED 15845467) [ДАТЧИК] 25866179 SENSOR, RR WHL SPD (INCLS 14) 11516521 БОЛТ, HFH M6X1X20, 9.8, 7114M, DOG PT, 14.2 OD (RR WHL SPD SEN) 10317605 CLIP, WHL SPD SEN WIRE (ЧАСТЬ OF 12) (6.8MM HOLE) (9.242) [ЗАЖИМ ДАТЧИКА АБС] 15855539 SENSOR, FRT WHL SPD (INCLS 2, 16, 17) 10317605 CLIP, WHL SPD SEN WIRE (ЧАСТЬ OF 15) (6.8MM HOLE) (9.242) [ЗАЖИМ ДАТЧИКА АБС] not found BRACKET, FRT WHL SPD SEN WIRE (ЧАСТЬ OF 15) 25820819 BRACKET, FRT WHL SPD SEN WIRE (ЧАСТЬ OF 15) 11570352 ГАЙКА, HEX JAM M12X1.75X6, GM510 (5) STL, GMW14100. (WHL SPD SEN BRKT) (6D04-087) - 2008-2009 DM69 УПРАВЛЕНИЕ АКППS/КОРПУС КП (ПОЛНОПРИВОДНЫЙ MX7) ↓ 24244602 МОДУЛЬ, TRFER CASE SHFT CONT [МОДУЛЬ] not found HARNESS, I/P WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found INSULATOR, I/P (СМ. ГРУППУ 10.000 "ПРИБОРНАЯ ПАНЕЛЬ ЧАСТЬ 1" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (BLACK) teamcadillac.ru 11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (I/P INSL) [ВИНТ] 11609370 БОЛТ-HWH, M4.2X1.41X20, HI - LOW THD, , OD 12, 6010 STL, GMW4205, TAP (I/P INSL) (9.667) (6D04-088) - 2008 DM69 ТОРМОЗНОЙ УСИЛИТЕЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (LLT/3.6V) ↓ 15267511 BOOSTER, P/B (СМ. ГРУППУ 04.000 "ТОРМОЗНОЙ УСИЛИТЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ГИДРОУСИЛИТЕЛЬ ТОРМОЗНОЙ СИСТЕМЫ] 25675835 BRACKET, BRK PED BRKT 15849744 BOOT, BRK PED PUSH ROD 25697461 RETAINER, BRK PED PUSH ROD BOOT 25785092 BARRIER, BRK PED BRKT SND 25913292 BARRIER, BRK PED BRKT SND not found PEDAL, BRK (W/BRKT) (СМ. ГРУППУ 04.000 "ТОРМОЗНАЯ ПЕДАЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 15267509 CYLINDER, BRK MAS (СМ. ГРУППУ 04.000 "ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [БЛОК ЦИЛИНДРОВ] 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] 11570167 STUD, P/B BOOS PUMP BRKT (STUD-STRAIGHT, M12X1.75X32.25, M12X1.75X23, 80 OAL, 10.9, E11 TORX) 25806500 BRACKET, VAC PUMP [ВАКУУМНЫЙ НАСОС] 11516075 ГАЙКА, HFH SELF LK, M6X1, 7.7THK, 14.2 O.D., 9, PZOR (P/B BOOS PUMP) [ГАЙКА ВЫПУСКНОЙ СИСТЕМЫ D=6ММ] 11514598 ГАЙКА, HEX FLANGE, M12X1.75X12, 26 OD, 10, 7111M, (P/B BOOS PUMP) [ГАЙКА М12] 11518075 БОЛТ, HFH, THD 22, OD 17, 8.8, GMW14C-PT, HDR POINT (P/B BOOS PUMP) [ВИНТ М10] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (P/S FLUID RSVR) 11589303 БОЛТ-HFH, M6X1X38, 30 THD, 14.2 OD, 8.8 STL, GMW3359, M-PT (P/B BOOS PUMP) 15797569 PUMP, P/B BOOS AUX [НАСОС В СБОРЕ] 20774507 RESERVOIR, P/S FLUID (СМ. ГРУППУ 06.000 "НАСОС РУЛЕВОГО УПРАВЛЕНИЯ LINES" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 25926187 HOSE, P/B BOOS VAC (INCLS 21) 25926187 HOSE, P/B BOOS VAC (INCLS 21) teamcadillac.ru not found CЛАМПА, P/B BOOS HSG (ЧАСТЬ OF 20) not found SPACER, P/B BOOS PUMP (*KIT1) not found INSULATOR, P/B BOOS PUMP (*KIT1) 25775922 INSULATOR KIT, P/B BOOS PUMP (INCLS 22, 23) (ON PUMP) (6D04-089) - 2008 DM69 СТОЯНОЧНЫЙ ТОРМОЗ ASM ↓ teamcadillac.ru 15853380 PLATE, RR BRK BKG (17" ТОРМОЗА) 15853415 PLATE, RR BRK BKG (17" ТОРМОЗА) 15853421 PLATE, RR BRK BKG (18" ТОРМОЗА) 15853425 PLATE, RR BRK BKG (18" ТОРМОЗА) not found PIN, RR PARK BRK SHOE (*KIT1) 25693149 BRACKET, PARK BRK CBL (ATTACHES TO RR SUSP) 25693150 BRACKET, PARK BRK CBL (ATTACHES TO RR SUSP) 11517996 ГАЙКА, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (PARK BRK RR CBL BRKT) (ACDelco #11517996) [ГАЙКА М10] 25867413 LEVER, RR PARK BRK ACTR 25814678 SHOE KIT, RR PARK BRK [ТОРМОЗНАЯ КОЛДКА] not found ПРУЖИНА, RR PARK BRK SHOE RTN (*KIT1) not found ПРУЖИНА, RR PARK BRK SHOE HOLDN (*KIT1) not found ПРУЖИНА, RR PARK BRK SHOE RTN (*KIT1) 25867414 ADJUSTER, RR PARK BRK 25814679 ПРУЖИНА KIT, PARK BRK LVR RTN (INCLS 2, 7-9) [ПРУЖИНА] (6D04-098) - 2008-2009 DM69 КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS (ПОЛНОПРИВОДНЫЙ MX7) ↓ 89059523 ГАЙКА, TRFER CASE RR ВЫХОДНОЙ SHF FLG (4.520) 15580315 WASHER, TRFER CASE RR ВЫХОДНОЙ SHF THR (FLAT) (PL, STL) (7/8 I.D. X 1 39/64 O.D., 1/8 THK) (4.510) 15635532 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF FLG (O RING) (4.412) 19179018 FLANGE, TRFER CASE RR ВЫХОДНОЙ SHF 88996681 DEFLECTOR, TRFER CASE RR ВЫХОДНОЙ SHF SEAL DIRT (5.555) 19180065 БОЛТ, TRFER CASE VIB DPNR 19179016 DAMPENER, TRFER CASE VIB (AT RR OF CASE) not found БОЛТ, WRG HARN BRKT 19208066 CASE, TRFER (FRT HALF) 19208080 РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ, TRFER CASE TWO/FOUR WHL DRV CLU 88984499 PIN, TRFER CASE HALF LOC not found BRACKET, WRG HARN 88996657 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF [УПЛОТНИТЕЛЬ] 19208081 ГАЙКА, TRFER CASE TWO/FOUR WHL DRV CLU РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ 19208077 CASE, TRFER (RR HALF) 19206436 RESISTOR, (115 OHMS) 19206437 RESISTOR, (225 OHMS) 19206438 RESISTOR, (453 OHMS) 19206439 RESISTOR, (715 OHMS) 19206440 RESISTOR, (1150 OHMS) 19206441 RESISTOR, (1820 OHMS) 19206442 RESISTOR, (3160 OHMS) 19206443 RESISTOR, (7320 OHMS) 19206444 RESISTOR, (12700 OHMS) 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL FILL) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 19179015 PLUG, TRFER CASE FRT ВЫХОДНОЙ SHF HOLE (INCLS 20) [КРЫШКА КОРПУСА РАЗДАТОЧНОЙ КОРОБКИ] not found SEAL, TRFER CASE ACC HOLE PLUG (O RING) (ЧАСТЬ OF 19) teamcadillac.ru 19208087 RING, TRFER CASE FRT ВЫХОДНОЙ SHF BRG RET 19179158 SENSOR, TRFER CASE FLUID TEMP [ДАТЧИК ТЕМПЕРАТУРЫ МАСЛА РАЗДАТОЧНОЙ КОРОБКИ] 19179158 SENSOR, TRFER CASE FLUID TEMP [ДАТЧИК ТЕМПЕРАТУРЫ МАСЛА РАЗДАТОЧНОЙ КОРОБКИ] 19179014 PLUG, TRFER CASE OIL DRN 88996680 БОЛТ, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN SNBR (M5X0.8X16) 88996679 SNUBBER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN 88996680 БОЛТ, TRFER CASE VENT BFL (M5X0.8X16) (4.535) 88996658 BAFFLE, TRFER CASE VENT not found БОЛТ, TRFER CASE MT BAR INSL CLA not found CЛАМПА, TRFER CASE MT BAR INSL 19180066 VENT, TRFER CASE 88996657 SEAL, TRFER CASE FRT ВЫХОДНОЙ SHF [УПЛОТНИТЕЛЬ] 88996656 SEAL, TRFER CASE INPUT SHF [УПЛОТНИТЕЛЬ] 88996681 DEFLECTOR, TRFER CASE FRT ВЫХОДНОЙ SHF SEAL DIRT 19208069 SHAFT, TRFER CASE FRT ВЫХОДНОЙ 89048123 БОЛТ, TRFER CASE HALF (M8X1.25X30) (6D04-099) - 2008-2009 DM69 КОРПУС КП ЧАСТЬ 2 INTERNAL COMPONENTS (ПОЛНОПРИВОДНЫЙ MX7) ↓ 15580228 BEARING, TRFER CASE RR ВЫХОДНОЙ SHF RR (2 7/8 OD X 1 3/8 ID) (STMPD 13-45-130-001) 19208080 РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ, TRFER CASE TWO/FOUR WHL DRV CLU (СМ. ГРУППУ 04.000 "КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 19208108 SHIM, TRFER CASE FOUR WHL DRV CLU (SELECT FIT 8.60-8.50; STAMPED "52") 19208109 SHIM, TRFER CASE FOUR WHL DRV CLU (SELECT FIT 8.80-8.70; STAMPED "53") 19208110 SHIM, TRFER CASE FOUR WHL DRV CLU (SELECT FIT 9.00-8.90; STAMPED "54") 19208111 SHIM, TRFER CASE FOUR WHL DRV CLU (SELECT FIT 9.20-9.10; STAMPED "55") 19208112 SHIM, TRFER CASE FOUR WHL DRV CLU (SELECT FIT 9.40-9.30; STAMPED "56") 19208113 SHIM, TRFER CASE FOUR WHL DRV CLU (SELECT FIT 9.60-9.50; STAMPED "57") 19208114 SHIM, TRFER CASE FOUR WHL DRV CLU (SELECT FIT 9.80-9.70; STAMPED "58") 19208115 BEARING, TRFER CASE FOUR WHL DRV CLU HSG not found ШЛАНГИ, TRFER CASE TWO/FOUR WHL DRV CLU РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ not found ROLLER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT BRG 19208358 SPACER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT BRG RLR not found ПРУЖИНА, TRFER CASE TWO/FOUR WHL DRV SYN HUB 19208088 RING, TRFER CASE TWO/FOUR WHL DRV CLU RET 19208098 СЦЕПЛЕНИЕ, TRFER CASE FRT DRV AXLE VISCOUS (INCLS 12-17) teamcadillac.ru not found ACTUATOR, TRFER CASE FOUR WHL DRV not found PLATE, TRFER CASE FOUR WHL DRV CLU PRESS (ЧАСТЬ OF 10) not found PLATE, TRFER CASE FOUR WHL DRV CLU BKG (FRICTION) (ЧАСТЬ OF 10) not found PLATE, TRFER CASE FOUR WHL DRV CLU BKG (SEPERATOR) (ЧАСТЬ OF 10) not found PLATE, TRFER CASE FOUR WHL DRV CLU BKG (ЧАСТЬ OF 10) not found PLATE, TRFER CASE FOUR WHL DRV CLU BKG (ПРУЖИНА) (ЧАСТЬ OF 10) not found ШЛАНГИ, TRFER CASE FOUR WHL DRV CLU (ЧАСТЬ OF 10) 19208091 SPACER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT 19208072 CHAIN, TRFER CASE TWO/FOUR WHL DRV 19208359 SPROCKET, TRFER CASE FRT ВЫХОДНОЙ SHF DRV 19208090 WASHER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT THR 19208085 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT 19208090 WASHER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT THR 19208082 PUMP, TRFER CASE OIL 19208071 SHAFT, TRFER CASE INPUT not found BEARING, TRFER CASE INPUT SHF 19208078 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF RR 19208360 SPROCKET, TRFER CASE TWO/FOUR WHL DRV DRVN 19208089 SPACER, TRFER CASE FRT ВЫХОДНОЙ SHF DRVN SPKT 88996633 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF FRT (ACDelco #88996633) [ПОДШИПНИК РАЗДАТОЧНОЙ КОРОБКИ] (6E04-020) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ 24218963 RING, T/CV FLUID SEAL RET [КОЛЬЦО] 24237531 SEAL, T/CV FLUID (ЧАСТЬ OF 217, 219) (ACDelco #24237531) [УПЛОТНЕНИЕ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 00444613 PLUG, HEX HD, 1/8-27 NPTF, STL (LINE PRESS TEST HOLE) (ACDelco #444613) teamcadillac.ru 24239384 ШЛАНГИ, T/CV (MCHG) (INCLS 206) (ACDelco #24239384) 24225422 PIPE, A/TRNS VENT not found BUSHING, T/CV (ЧАСТЬ OF 203) not found RING, A/TRNS ГИДРОНАСОС VANE (ЧАСТЬ OF 217) not found GUIDE, A/TRNS ГИДРОНАСОС ROT (ЧАСТЬ OF 217) not found RING, A/TRNS ГИДРОНАСОС SLIDE FLUID SEAL (ЧАСТЬ OF 217) not found SEAL, A/TRNS O/PMP SLIDE (O RING) (ЧАСТЬ OF 217) (*KIT1) not found ПРУЖИНА, A/TRNS ГИДРОНАСОС SLIDE OTR (ЧАСТЬ OF 217) 24222668 SLIDE, A/TRNS ГИДРОНАСОС (17.948MM-17.961MM) (ACDelco #24222668) 24224131 SLIDE, A/TRNS ГИДРОНАСОС (17.961MM-17.974MM) (ACDelco #24224131) 24224132 SLIDE, A/TRNS ГИДРОНАСОС (17.974MM-17.987MM) (ACDelco #24224132) not found SEAL, A/TRNS ГИДРОНАСОС SLIDE (ЧАСТЬ OF 217) not found SUPPORT, A/TRNS ГИДРОНАСОС SLIDE SEAL (ЧАСТЬ OF 217) (*KIT1) not found PIN, A/TRNS ГИДРОНАСОС SLIDE PIV (ЧАСТЬ OF 217) not found VANE, A/TRNS ГИДРОНАСОС (ЧАСТЬ OF 217) 24238915 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 207-211, 213-216, 230) (17.948MM-17.961MM) (ACDelco #24238915) 24238916 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 207-211, 213-216, 230) (17.961MM-17.974MM) (ACDelco #24238916) 24238917 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 207-211, 213-216, 230) (17.974MM-17.987MM) (ACDelco #24238917) not found BUSHING, TURB SHF FRT (ЧАСТЬ OF 219) 24238919 COVER KIT, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 218, 220-230, 232-237) (ACDelco #24238919) not found VALVE, CONV FEED LIM (ЧАСТЬ OF 219) not found ПРУЖИНА, PRESS RLF BALL VLV (ЧАСТЬ OF 219) not found ПРУЖИНА, CONV FEED LIM VLV (ЧАСТЬ OF 219) not found PIN, PRESS RLF BALL VLV SPR (ЧАСТЬ OF 219) not found ПРУЖИНА, PRESS RLF BALL VLV (ЧАСТЬ OF 219) 00147500 VALVE, PRESS RLF BALL (ЧАСТЬ OF 219) not found ПРУЖИНА, TCC C/VLV (ЧАСТЬ OF 219) not found VALVE, TCC CONT (ЧАСТЬ OF 219) not found BUSHING, TURB SHF RR (ЧАСТЬ OF 219) 24224692 WASHER, 1-2-3-4 & 3-5 REV CLU HSG THR (ЧАСТЬ OF 219) 24239151 RING, 1-2-3-4 & 3-5 REV CLU FLUID SEAL (ЧАСТЬ OF 217, 219) (*KIT1, KIT2) (ACDelco #24239151) 24227061 БОЛТ, A/TRNS ГИДРОНАСОС CVR (ACDelco #24227061) [БОЛТ] 90351709 PIN, A/TRNS ГИДРОНАСОС LOC (ЧАСТЬ OF 219) ("8MM HOLLOW SPLIT PIN") (1.639) [ШПИЛЬКА] not found VALVE, PRESS REG (ЧАСТЬ OF 219) not found ПРУЖИНА, PRESS REG VLV OTR (ЧАСТЬ OF 219) not found ПРУЖИНА, PRESS REG VLV INR (ЧАСТЬ OF 219) not found VALVE, ISOLATOR (ЧАСТЬ OF 219) not found SLEEVE, ISOLATOR VLV (ЧАСТЬ OF 219) 24243891 SEAL KIT, A/TRNS SERV (INCLS 205, 210, 214, 230) (FULL TRANS) (ACDelco #24243891) 24239151 RING KIT, 1-2-3-4 & 3-5 REV CLU FLUID SEAL (INCLS 230) (ACDelco #24239151) (6M04-038) - 2008 DM69 ШЛАНГ ВЕНТИЛЯЦИИ ТРАНСМИССИИ-VENT HOSE W/DRAIN(MYB)(1ST DES) ↓ not found HOSE, TRANS VENT (INCLS 2-8) 15862039 HOSE, TRANS VENT (INCLS 2-8) (VENT HOSE W/DRAIN) (FOR 2ND DES SEE 25892019) 25892019 HOSE, TRANS VENT (INCLS 2-8) not found VENT, TRFER CASE (ЧАСТЬ OF 1) 08905794 CLIP (TRANS VENT) (ЧАСТЬ OF 1) not found CONNECTOR, TRANS VENT HOSE (ЧАСТЬ OF 1) 06466355 CONNECTOR, TRANS VENT HOSE (ЧАСТЬ OF 1) (3.278) teamcadillac.ru not found STRAP, TRFER CASE VENT HOSE (ЧАСТЬ OF 1) not found HOSE, TRANS VENT (ЧАСТЬ OF 1) 25526358 CЛАМПА, SPRG BAND, 14.2MM, 9/16 OD HOSE, POR (ЧАСТЬ OF 1) not found HOSE, TRANS VENT (ЧАСТЬ OF 1) (6M04-039) - 2008 DM69 ШЛАНГ ВЕНТИЛЯЦИИ ТРАНСМИССИИ-VENT HOSE W/O DRAIN(MYB)(2ND DES) ↓ teamcadillac.ru 25892019 HOSE, TRANS VENT (INCLS 2-4) 25892019 HOSE, TRANS VENT (INCLS 2-4) (VENT HOSE W/O DRAIN) (FOR 1ST DES SEE 15862039) 25526358 CЛАМПА, SPRG BAND, 14.2MM, 9/16 OD HOSE, POR (ЧАСТЬ OF 1) 08905794 CLIP (ЧАСТЬ OF 1) 25892279 VENT, TRFER CASE (ЧАСТЬ OF 1) (ACDelco #25892279) [ЗАГЛУШКА ШЛАНГА ВЕНТИЛЯЦИИ КАРТЕРА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] (GM04-042) - 2008 DM69 ТОРМОЗНОЙ СУППОРТ-ПЕРЕДНИЙ (JE5) ↓ 15851351 CALIPER, FRT BRK (INCLS 2, 3, 12-14) (17") teamcadillac.ru 15851351 CALIPER, FRT BRK (INCLS 2, 3, 12-14) (17") 15853359 CALIPER, FRT BRK (INCLS 2, 3, 12-14) (17") 15853359 CALIPER, FRT BRK (INCLS 2, 3, 12-14) (17") 89027179 VALVE, FRT BRK CLPR BLEDR (ЧАСТЬ OF 1) 88935785 CAP, FRT BRK CLPR BLEDR VLV (ЧАСТЬ OF 1) [ЗАГЛУШКА ОБРАТНОГО КЛАПАНА] 15851359 PIN, FRT BRK CLPR GDE (W/O BUSHING) not found SEAL, FRT BRK CLPR GDE PIN (*KIT3) 15851354 BRACKET, FRT BRK CLPR (17") not found ПРУЖИНА, FRT DISC BRK PAD RET (*KIT2) not found PAD, FRT DISC BRK OTR (*KIT2) not found PAD, FRT DISC BRK INR (*KIT2) not found BUSHING, FRT BRK CLPR GDE PIN (ЧАСТЬ OF 11) (*KIT3) 15851358 PIN, FRT BRK CLPR GDE (INCLS 10) (W/PLASTIC SLEEVE 1.5MM FROM TIP) (W/BUSHING) not found BOOT, FRT BRK CLPR PSTN (ЧАСТЬ OF 1) (*KIT1) not found SEAL, FRT BRK CLPR PSTN (ЧАСТЬ OF 1) (*KIT1) 15926281 PISTON, FRT BRK CLPR (ЧАСТЬ OF 1) 89027183 БОЛТ, FRT BRK CLPR GDE PIN (M8X1.0) [БОЛТ М8] 25814701 SEAL KIT, FRT BRK CLPR PSTN (INCLS 12, 13) (INCLS 2 PISTON BOOTS & PISTON SEALS) 25814699 PAD KIT, FRT DISC BRK (INCLS 7-9) 25814700 SEAL KIT, FRT BRK CLPR GDE PIN (INCLS 5, 10) (INCLS 2 SEALS & 1 BUSHING) (GM04-555) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 24227130 БОЛТ, C/VLV UPR BODY (M5X0.8X36) 24225398 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M6 X 1.0 X 20) 24238417 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (INCLS 316) (4.329) [ДАТЧИК ЧИСЛА ОБОРОТОВ ВАЛА AКПП] 24225797 BODY, C/VLV UPR [ГИДРОРАСПРЕДЕЛИТЕЛЬНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24245720 PLATE, C/VLV BODY SPCR (W/GSKT) (ACDelco #24245720) [НАБОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96020431 VALVE, C/VLV BODY BALL CHK [КЛАПАН] 24250384 BODY, C/VLV LWR (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ/;НИЖНИЙ КЛАПАН РЕГУЛЯТОР BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (MANUAL VALVE NOT INCLUDED) (MUST USE T/W 24236934/PLATE KIT - CONT SOL VLV FLTR) 24246427 SWITCH, A/TRNS MAN SHFT SHF POSN (INCLS 315) (INTERNAL MODE SWITCH) [ВКЛЮЧАТЕЛЬ] 24224821 БОЛТ, C/VLV LWR BODY (M5X0.8X45) 24224822 БОЛТ, C/VLV LWR BODY (M5X0.8X55) 24238925 PLATE KIT, CONT SOL VLV FLTR 24240845 БОЛТ, CONT SOL VLV HEAT SINK (W/ BODY & TCM) (M5X0.8X53.0) 24241890 VALVE, CONT SOL (W/ BODY & TCM) (ACDelco #24241890) (ORDER T/W 24238913 SEAL KIT) [ГИДРОРАСПРЕДЕЛИТЕЛЬНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24236233 CLIP, A/TRNS MAN SHFT SHF POSN SW WRG HARN (ЧАСТЬ OF 308) 24236233 CLIP, A/TRNS MAN SHFT SHF POSN SW WRG HARN (ЧАСТЬ OF 308) 24236233 CLIP, A/TRNS MAN SHFT SHF POSN SW WRG HARN (ЧАСТЬ OF 308) teamcadillac.ru 24236504 CLIP, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN WRG HARN (ЧАСТЬ OF 303) (GM04-556) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ВЕРХНИЙ КЛАПАН РЕГУЛЯТОР BODY БЛОК ↓ 24224766 PIN, C/VLV BODY LOC (ЧАСТЬ OF 321) (DIA.=10MM L=12.7) [ВТУЛКА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24225797 BODY, C/VLV UPR (INCLS 313, 322-338) [ГИДРОРАСПРЕДЕЛИТЕЛЬНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24230200 PIN, C/VLV BODY LOC (ЧАСТЬ OF 321) (DIA.=10MM L=29.9) [ВТУЛКА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, 1-2-3-4 CLU BOOST VLV SPR (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, 1-2-3-4 CLU REG VLV BORE PLUG (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, 1/REV BAND & 4-5-6 CLU REG VLV BORE PLUG (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, 2-6 CLU REG VLV BORE PLUG (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, 3-5-REV CLU BOOST VLV SPR (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, 3-5-REV CLU REG VLV BORE PLUG (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, 4-5-6 CLU BOOST VLV SPR (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, ACTR FEED LIM VLV (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] not found ПРУЖИНА, ACTR FEED LIM VLV (ЧАСТЬ OF 321) not found VALVE, ACTR FEED LIM (ЧАСТЬ OF 321) not found ПРУЖИНА, 1-2-3-4 CLU REG VLV (ЧАСТЬ OF 321) not found ПРУЖИНА, 1/REV BAND & 4-5-6 CLU REG VLV (ЧАСТЬ OF 321) not found ПРУЖИНА, 2-6 CLU REG VLV (ЧАСТЬ OF 321) not found ПРУЖИНА, 3-5 REV CLU REG VLV (ЧАСТЬ OF 321) not found VALVE, 1/REV BAND & 4-5-6 CLU REG (ЧАСТЬ OF 321) 24242814 PLUG, 1-2-3-4 CLU REG VLV BORE (ЧАСТЬ OF 321) (9.5 THK, 11.5 DIA) 24242814 PLUG, 1/REV BAND & 4-5-6 CLU REG VLV BORE (ЧАСТЬ OF 321) (9.5 THK, 11.5 DIA) 24242814 PLUG, 2-6 CLU REG VLV BORE (ЧАСТЬ OF 321) (9.5 THK, 11.5 DIA) 24242814 PLUG, 3-5 REV CLU REG VLV BORE (ЧАСТЬ OF 321) (9.5 THK, 11.5 DIA) not found VALVE, 1-2-3-4 CLU BOOST (ЧАСТЬ OF 321) not found VALVE, 3-5-REV CLU BOOST (ЧАСТЬ OF 321) not found VALVE, 4-5-6 CLU BOOST (ЧАСТЬ OF 321) not found ПРУЖИНА, 1-2-3-4 CLU BOOST VLV (ЧАСТЬ OF 321) not found ПРУЖИНА, 3-5-REV CLU BOOST VLV (ЧАСТЬ OF 321) not found ПРУЖИНА, 4-5-6 CLU BOOST VLV (ЧАСТЬ OF 321) not found VALVE, 2-6 CLU REG (ЧАСТЬ OF 321) not found VALVE, 2-6 CLU REG VLV GAIN (ЧАСТЬ OF 321) not found VALVE, 3-5 REV CLU REG (ЧАСТЬ OF 321) not found VALVE, 1-2-3-4 CLU REG (ЧАСТЬ OF 321) teamcadillac.ru not found VALVE, DEFAULT OVERRIDE 1-2-3-4 CLU (ЧАСТЬ OF 321) (GM04-557) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) НИЖНИЙ КЛАПАН РЕГУЛЯТОР BODY БЛОК ↓ 24224755 RETAINER, CLU PSTN DAM FEED REG VLV SPR [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, CLU SEL SOL VLV BORE PLUG #2 [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, CLU SEL SOL VLV BORE PLUG #3 [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, TCC REG APPL VLV BORE PLUG [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24242814 PLUG, CLU SEL SOL VLV BORE #2 (9.5 THK, 11.5 DIA) 24242814 PLUG, CLU SEL SOL VLV BORE #3 (9.5 THK, 11.5 DIA) 24242814 PLUG, TCC REG APPL VLV BORE (9.5 THK, 11.5 DIA) not found VALVE, TCC REG APPL SHUTTLE (ЧАСТЬ OF 351) 24250384 BODY, C/VLV LWR (INCLS 338, 352, 353, 355-357) (MANUAL VALVE NOT INCLUDED) (MUST USE T/W 24236934/PLATE KIT - CONT SOL VLV FLTR) not found VALVE, CLU SEL SOL #2 (ЧАСТЬ OF 351) not found VALVE, CLU SEL SOL #3 (ЧАСТЬ OF 351) not found ПРУЖИНА, CLU SEL SOL VLV #2 (ЧАСТЬ OF 351) not found ПРУЖИНА, CLU SEL SOL VLV #3 (ЧАСТЬ OF 351) not found ПРУЖИНА, TCC REG APPLY VLV (ЧАСТЬ OF 351) 24224770 VALVE, MAN (ACDelco #24224770) not found VALVE, TCC REG APPLY (ЧАСТЬ OF 351) not found VALVE, CLU PSTN DAM FEED REG (ЧАСТЬ OF 351) teamcadillac.ru not found ПРУЖИНА, CLU PSTN DAM FEED REG VLV (ЧАСТЬ OF 351) (GM04-558) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) 1-2-3-4 & 3-5 REVERSE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 24240625 RING, 3-5 REV CLU BKG PLT RET (LT GREEN) (2.25-2.35MM) (ACDelco #24240625) 24240626 RING, 3-5 REV CLU BKG PLT RET (GRAY) (2.47-2.57MM) (ACDelco #24240626) 24240627 RING, 3-5 REV CLU BKG PLT RET (YELLOW) (2.69-2.79MM) (ACDelco #24240627) 24240628 RING, 3-5 REV CLU BKG PLT RET (ORANGE) (2.93-3.01MM) (ACDelco #24240628) 24240629 RING, 3-5 REV CLU BKG PLT RET (LT BLUE) (3.13-3.23MM) (ACDelco #24240629) 24240630 RING, 3-5 REV CLU BKG PLT RET (WHITE) (3.35-3.45MM) (ACDelco #24240630) 24240631 RING, 3-5 REV CLU BKG PLT RET (YELLOW/PURPLE) (3.57-3.67MM) (ACDelco #24240631) 24225654 PLATE, 3-5 REV CLU BKG 24225569 PLATE, 3-5/REV CLU (PKG OF 4) (FIBER) (*KIT4) (ACDelco #24225569) 24237663 PLATE, 3-5 REV CLU (PKG OF 4) (STEEL) 24225564 PLATE, 3-5 REV CLU (WAVED) 24225748 RING, 3-5-REV CLU APPLY (ACDelco #24225748) 24233533 PLATE, 1-2-3-4 CLU BKG 24243588 PLATE, 1-2-3-4 CLU (*KIT4) (ACDelco #24243588) 24232652 PLATE, 1-2-3-4 CLU (PKG OF 5) (STEEL) 24236434 PLATE, 1-2-3-4 CLU (WAVED) not found RING, 1-2-3-4 CLU PSTN DAM RET (*KIT1, KIT2) 24225522 DAM, 1-2-3-4 CLU PSTN 24225559 ПРУЖИНА, 1-2-3-4 CLU 24241073 PISTON, 1-2-3-4 CLU not found RING, 1-2-3-4 CLU PSTN HSG RTN (*KIT1, KIT2) not found SEAL, 1-2-3-4 CLU PSTN (ЧАСТЬ OF 417) teamcadillac.ru 24238558 ШЛАНГИ, 1-2-3-4 CLU PSTN (INCLS 416, 418, 419) not found SEAL, 3-5/REV CLU PSTN DAM (O RING) (ЧАСТЬ OF 417) not found SEAL, 3-5-REV CLU PSTN INR (ЧАСТЬ OF 417) 24236051 ПРУЖИНА, 3-5-REV CLU 24238560 PISTON, 3-5/REV CLU (INCLS 422) (4.164) not found SEAL, 3-5-REV CLU PSTN OTR (ЧАСТЬ OF 421) (*KIT3) not found SEAL, 1-2-3-4 CLU PSTN INR (*KIT1, KIT3) not found SEAL, 1-2-3-4 CLU PSTN HSG (*KIT1, KIT3) not found SEAL, 1-2-3-4 CLU PSTN HSG (*KIT1, KIT3) not found BUSHING, 1-2-3-4 & 3-5/REV CLU HSG RR (ЧАСТЬ OF 427) 24237184 ШЛАНГИ, 1-2-3-4 & 3-5 REV CLU (INCLS 426) (ORDER T/W 24226393) 24226393 BEARING, 1-2-3-4 & 3-5-REV CLU 24240626 RING, 1-2-3-4 CLU BKG PLT RET (GRAY) (2.47-2.57MM) (ACDelco #24240626) 24240627 RING, 1-2-3-4 CLU BKG PLT RET (YELLOW) (2.69-2.79MM) (ACDelco #24240627) 24240628 RING, 1-2-3-4 CLU BKG PLT RET (ORANGE) (2.93-3.01MM) (ACDelco #24240628) 24240629 RING, 1-2-3-4 CLU BKG PLT RET (LT BLUE) (3.13-3.23MM) (ACDelco #24240629) 24240630 RING, 1-2-3-4 CLU BKG PLT RET (WHITE) (3.35-3.45MM) (ACDelco #24240630) 24240631 RING, 1-2-3-4 CLU BKG PLT RET (YELLOW/PURPLE) (3.57-3.67MM) (ACDelco #24240631) 24240632 RING, 1-2-3-4 CLU BKG PLT RET (LT BLUE/PURPLE) (3.79-3.89MM) (ACDelco #24240632) 24238913 SEAL KIT, A/TRNS SERV (INCLS 411, 415, 423-425) (CONTROL VLV SOL ASM) (ACDelco #24238913) [КОМПЛЕКТ ПРОКЛАДОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (5ШТ)] 24238920 RING KIT, RET (INCLS 411, 415) 24238922 SEAL KIT, A/TRNS SERV (INCLS 422-425) (TRANS BUILT ON 1-31-08 & PRIOR) (FOR 2ND DES SEE 24243890) (СЦЕПЛЕНИЕES) (ACDelco #24238922) 24238922 SEAL KIT, A/TRNS SERV (INCLS 422-425) (TRANS BUILT ON 2-01-08 & AFTER) (FOR 1ST DES SEE 24238922) (СЦЕПЛЕНИЕES) (ACDelco #24238922) 24238911 PLATE KIT, CLU (INCLS 402, 408) (ORDER T/W 24225575 & 24235455) (ACDelco #24238911) (GM04-559) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) 4-5-6 ДЕТАЛИ СЦЕПЛЕНИЯ & ВАЛ ТУРБИНЫ ↓ 24225508 RING, 4-5-6 CLU BKG PLT RET (GREEN) (2.52-2.62) (ACDelco #24225508) 24225509 RING, 4-5-6 CLU BKG PLT RET (YELLOW) (3.08-3.18) (ACDelco #24225509) 24231591 RING, 4-5-6 CLU BKG PLT RET (GREY) (2.80-2.90) (ACDelco #24231591) teamcadillac.ru 24231592 RING, 4-5-6 CLU BKG PLT RET (ORANGE) (3.36-3.46) (ACDelco #24231592) 24231593 RING, 4-5-6 CLU BKG PLT RET (BLUE) (3.64-3.74) (ACDelco #24231593) 24232880 RING, 4-5-6 CLU BKG PLT RET (YELLOW/PURPLE) (4.20-4.30) (ACDelco #24232880) 24225652 PLATE, 4-5-6 CLU BKG 24225570 PLATE, 4-5-6 CLU (INT SPLINE) (PKG OF 5) (FIBER) (*KIT3) 24225575 PLATE, 4-5-6 CLU (EXT SPLINE) (PKG OF 5) (STEEL)FIBER) (ACDelco #24225575) 24225565 PLATE, 4-5-6 CLU (WAVED) not found RING, 4-5-6 CLU PSTN DAM RET (*KIT1, KIT2) 24225526 DAM, 4-5-6 CLU PSTN 24225560 ПРУЖИНА, 4-5-6 CLU 24225523 PISTON, 4-5-6 CLU not found BUSHING, ВЫХОДНОЙ CARR SHF HSG (ЧАСТЬ OF 441) 24237963 ШЛАНГИ, 4-5-6 CLU (W/ INPUT SHF) (INCLS 440) 24225511 RING, TURB SHF FLUID SEAL 08662686 SEAL, TURB SHF (O RING) (*KIT2) (ACDelco #8662686) 24238920 RING KIT, RET (INCLS 436) 24243891 SEAL KIT, A/TRNS SERV (INCLS 436, 443) (FULL TRANS) (ACDelco #24243891) 24238911 PLATE KIT, CLU (INCLS 433) (ORDER T/W 24225575 & 24235455) (ACDelco #24238911) (GM04-560) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) 2-6 ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 24247405 RING, 2-6 CLU BKG PLT RET (1.69MM +/- 0.05) (ACDelco #24247405) 24247406 RING, 2-6 CLU BKG PLT RET (2.81MM +/- 0.05) (ACDelco #24247406) 24248107 RING, 2-6 CLU BKG PLT RET (2.25MM +/- 0.05) (ACDelco #24248107) 24248108 RING, 2-6 CLU BKG PLT RET (2.53MM +/- 0.05) (ACDelco #24248108) 24248109 RING, 2-6 CLU BKG PLT RET (1.97MM +/- 0.05) (ACDelco #24248109) 24225653 PLATE, 2-6 CLU BKG 24237973 PLATE, 2-6 CLU (WAVED) teamcadillac.ru not found RING, 2-6 CLU SPR RET 24225561 ПРУЖИНА, 2-6 CLU 24225524 PISTON, 2-6 CLU not found BUSHING, ВЫХОДНОЙ CARR OTR SUN GR SHF (ЧАСТЬ OF 459) 24225447 SUPPORT, CTR (INCLS 458, 460) not found BUSHING, ВЫХОДНОЙ CARR OTR SUN GR SHF (ЧАСТЬ OF 459) 24238911 PLATE KIT, CLU (INCLS 452) (ORDER T/W 24225575 & 24235455) (ACDelco #24238911) (GM04-561) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) LOW & REVERSE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ not found SUPPORT, CTR (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ДЕТАЛИ СЦЕПЛЕНИЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) not found RING, LOW & REV CLU BKG PLT RET 24225519 RING, LOW & REV CLU BKG PLT RET (2.77MM +/- 0.05) (ACDelco #24225519) (TRANS BUILT ON 9/1/08 & FORWARD) (FOR 1ST DES SEE 24248368) 24231938 RING, LOW & REV CLU BKG PLT RET (2.63MM +/- 0.05) (MUST BE USED T/W 24247402) (ACDelco #24231938) (TRANS BUILT ON 9/1/08 & FORWARD) (FOR 1ST DES SEE 24248368) 24231939 RING, LOW & REV CLU BKG PLT RET (2.93MM +/- 0.05) (MUST BE USED T/W 24247402) (ACDelco #24231939) (TRANS BUILT ON 9/1/08 & FORWARD) (FOR 1ST DES SEE 24248368) 24247407 RING, LOW & REV CLU BKG PLT RET (2.03MM +/- 0.05) (MUST BE USED T/W 24247402) (ACDelco #24247407) (TRANS BUILT ON 9/1/08 & FORWARD) (FOR 1ST DES SEE 24248368) teamcadillac.ru 24247408 RING, LOW & REV CLU BKG PLT RET (3.23MM +/- 0.05) (MUST BE USED T/W 24247402) (ACDelco #24247408) (TRANS BUILT ON 9/1/08 & FORWARD) (FOR 1ST DES SEE 24248368) 24247402 PLATE, LOW & REV CLU BKG (MUST BE USED T/W 24231937/38/38, AND 24247407/08) (ACDelco #24247402) (TRANS BUILT ON 9/1/08 & FORWARD) (FOR 1ST DES SEE 24248368) 24248368 PLATE KIT, LOW & REV CLU BKG (FOR SERVICE USE (1) OF THE FOLLOWING RET. RINGS 24225515, 24225519, OR BACKING PLATE 24225656) (4.180) (ACDelco #24248368) (TRANS BUILT ON 08-31-08 & PRIOR) (FOR 2ND DES SEE 24231937/ 24231938/ 24231939/ 242474 24236664 PLATE, LOW & REV CLU (PKG OF 6) (FIBER) (*KIT2) 24232654 PLATE, LOW & REV CLU (PKG OF 6) (STEEL) (ACDelco #24232654) 24237971 PLATE, LOW & REV CLU (WAVED) (ACDelco #24237971) 24225517 RING, LOW & REV CLU SPR RET 24238921 SPRAG, LOW CLU (INCLS 468) not found SEAL, LOW CLU SPRAG (ЧАСТЬ OF 467) (*KIT1) 24225562 ПРУЖИНА, LOW & REV CLU 24225525 PISTON, LOW & REV CLU (ACDelco #24225525) 24238922 SEAL KIT, A/TRNS SERV (INCLS 468) (TRANS BUILT ON 1-31-08 & PRIOR) (FOR 2ND DES SEE 24243890) (СЦЕПЛЕНИЕES) (ACDelco #24238922) 24238922 SEAL KIT, A/TRNS SERV (INCLS 468) (TRANS BUILT ON 2-01-08 & AFTER) (FOR 1ST DES SEE 24238922) (СЦЕПЛЕНИЕES) (ACDelco #24238922) 24238911 PLATE KIT, CLU (INCLS 463) (ORDER T/W 24225575 & 24235455) (ACDelco #24238911) (GM04-562) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) СЦЕПЛЕНИЕ HUB БЛОК ↓ 24233660 HUB, 4-5-6 CLU (W/ ВЫХОДНОЙ CARR SHF & DPNR) (INCLS 476-478) 24230475 DAMPENER, 4-5-6 CLU (ЧАСТЬ OF 475) 24233661 PLATE, 4-5-6 CLU DPNR APPLY (ЧАСТЬ OF 475) teamcadillac.ru not found RING, 4-5-6 CLU DPNR RET (ЧАСТЬ OF 475) (GM04-563) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ВЫХОДНОЙ КРОНШТЕЙН БЛОК ↓ teamcadillac.ru 24225777 BEARING, CTR SUPT RLR (ЧАСТЬ OF 490) 24225483 BEARING, ВЫХОДНОЙ CARR OTR SUN GR FRT THR (ЧАСТЬ OF 490) 24225290 GEAR, ВЫХОДНОЙ CARR FRT SUN (ЧАСТЬ OF 490) 24225484 BEARING, ВЫХОДНОЙ CARR OTR SUN GR RR THR (ЧАСТЬ OF 490) 24235807 GEAR, ВЫХОДНОЙ CARR RR SUN (ЧАСТЬ OF 490) 24225603 КРОНШТЕЙН, ВЫХОДНОЙ (INCLS 485-489, 491) not found BEARING, ВЫХОДНОЙ CARR INR SUN GR THR (ЧАСТЬ OF 490) (GM04-568) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ВЫХОДНОЙ ВАЛ БЛОК ↓ teamcadillac.ru 24241092 RING, ВЫХОДНОЙ CARR INTL GR RET (ACDelco #24241092) 24228887 SPACER, ВЫХОДНОЙ CARR INTL GR (3.342) not found BUSHING, ВЫХОДНОЙ CARR (ЧАСТЬ OF 499) 24239398 SHAFT, ВЫХОДНОЙ (INCLS 498) (WHEN SERVICING SHAFT MUST ALSO REPLACE BEARING P/N 24237771) (FLAT END OF THE SHAFT) 24239401 SHAFT, ВЫХОДНОЙ (INCLS 498) (WHEN SERVICING SHAFT MUST ALSO REPLACE BEARING P/N 24237771) (GM04-569) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) БЛОК СЦЕПЛЕНИЯ & ДЕТАЛИ КОМПЛЕКТА ↓ not found СЦЕПЛЕНИЕ, 1-2-3-4 & 3-5 REV (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ 1-2-3-4 & 3-5 REVERSE ДЕТАЛИ СЦЕПЛЕНИЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 24225602 КРОНШТЕЙН, INPUT (ACDelco #24225602) 24225289 GEAR, INPUT SUN (ACDelco #24225289) 24224405 BEARING, INPUT SUN GR THR (ACDelco #24224405) 24224405 BEARING, INPUT SUN GR THR (ACDelco #24224405) 24232409 WASHER, INPUT SUN GR THR not found СЦЕПЛЕНИЕ, 4-5-6 (W/ TURB SHF) (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ 4-5-6 ДЕТАЛИ СЦЕПЛЕНИЯ & ВАЛ ТУРБИНЫ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 24238905 BEARING, TURB SHFT THR [ПОДШИПНИК] not found HUB, 4-5-6 CLU (W/ ВЫХОДНОЙ CARR SHF & DPNR) (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ СЦЕПЛЕНИЕ HUB БЛОК" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 24233732 BEARING, 4-5-6 CLU HUB THR (ACDelco #24233732) teamcadillac.ru 24233732 BEARING, 4-5-6 CLU HUB THR (ACDelco #24233732) not found BUSHING, ВЫХОДНОЙ CARR INR SUN GR SHF (ЧАСТЬ OF 64) 24225597 HUB, 1-2-3-4 CLU (W/ВЫХОДНОЙ CARR INR SUN GR SHF) not found BUSHING, ВЫХОДНОЙ CARR INR SUN GR SHF (ЧАСТЬ OF 64) 24224163 BEARING, 1-2-3-4 CLU HUB THR (ACDelco #24224163) 24225596 HUB, 2-6 & 3-5/REV CLU (W/ ВЫХОДНОЙ CARR OTR SUN GR SHF) (INCLS 60, 62) 24224164 BEARING, 2-6 & 3-5/REV CLU HUB THR (ACDelco #24224164) 24225512 RING, CTR SUPT RET 24225447 SUPPORT, CTR not found КРОНШТЕЙН, ВЫХОДНОЙ (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ВЫХОДНОЙ КРОНШТЕЙН БЛОК" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 24225486 BEARING, ВЫХОДНОЙ CARR THR not found SHAFT, ВЫХОДНОЙ (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ВЫХОДНОЙ ВАЛ БЛОК" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 24224668 BEARING, ВЫХОДНОЙ SHF THR (ACDelco #24224668) (GM04-598) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (6L50 MYB, ЗАДНИЙ КОЛЕСО DRIVE MX0) ↓ not found ТРАНСМИССИЯ, AUTO (REMAN) not found ТРАНСМИССИЯ, AUTO (SERV) 17804020 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 8BMA, 8BAA) teamcadillac.ru 17804029 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 8BTA) (GM04-599) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (6L50 MYB, ПОЛНОПРИВОДНЫЙ MX7) ↓ not found ТРАНСМИССИЯ, AUTO not found ТРАНСМИССИЯ, AUTO (REMAN) teamcadillac.ru not found ТРАНСМИССИЯ, AUTO (SERV) 17804021 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 8BBA, 8BSA) (REMAN) (GM04-617) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ЗАМОК ПАРКОВКИ(MX7) ↓ not found PLUG, PARK PAWL SHF HOLE (ЧАСТЬ OF CASE, A/TRNS - 04.103) not found SHAFT, PARK PAWL (ЧАСТЬ OF CASE, A/TRNS - 04.103) not found ПРУЖИНА, PARK PAWL (ЧАСТЬ OF CASE, A/TRNS - 04.103) not found PAWL, PARK (ЧАСТЬ OF CASE, A/TRNS - 04.103) 24242086 ACTUATOR, PARK PAWL (ACDelco #24242086) 24227077 PIN, MAN SHFT DTNT LVR HUB (ЧАСТЬ OF 505) 24234562 LEVER, MAN SHFT DTNT (INCLS 504) (ACDelco #24234562) teamcadillac.ru 24225792 PIN, MAN SHFT SHF (ACDelco #24225792) 24235861 SEAL, MAN SHFT SHF (*KIT1) (ACDelco #24235861) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24225445 SHAFT, MAN SHFT (ACDelco #24225445) 24228969 SHAFT, MAN SHFT (ACDelco #24228969) 24224348 GUIDE, PARK PAWL ACTR (INCLS 510) 24224350 SEAL, PARK PAWL ACTR GDE (O RING) (ЧАСТЬ OF 509) (*KIT1) (ACDelco #24224350) 24226102 PIN, PARK PAWL ACTR GDE 96022192 PLUG, MAN SHFT SHF HOLE 24243891 SEAL KIT, A/TRNS SERV (INCLS 507, 510) (FULL TRANS) (ACDelco #24243891) (GM04-618) - 2008-2010 D АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ЗАМОК ПАРКОВКИ(MX0) ↓ not found PLUG, PARK PAWL SHF HOLE (ЧАСТЬ OF CASE, A/TRANS - 04.103) not found SHAFT, PARK PAWL (ЧАСТЬ OF CASE, A/TRNS - 04.103) not found ПРУЖИНА, PARK PAWL (ЧАСТЬ OF CASE, A/TRNS - 04.103) not found PAWL, PARK (ЧАСТЬ OF CASE, A/TRNS - 04.103) 24242086 ACTUATOR, PARK PAWL (ACDelco #24242086) teamcadillac.ru 24227077 PIN, MAN SHFT DTNT LVR HUB (ЧАСТЬ OF 505) 24234562 LEVER, MAN SHFT DTNT (INCLS 504) (ACDelco #24234562) 24225792 PIN, MAN SHFT SHF (ACDelco #24225792) 24235861 SEAL, MAN SHFT SHF (*KIT1) (ACDelco #24235861) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224348 GUIDE, PARK PAWL ACTR (INCLS 510) 24224350 SEAL, PARK PAWL ACTR GDE (O RING) (ЧАСТЬ OF 509) (*KIT1) (ACDelco #24224350) 24226102 PIN, PARK PAWL ACTR GDE 24225445 SHAFT, MAN SHFT (ACDelco #24225445) 24228969 SHAFT, MAN SHFT (ACDelco #24228969) 24243891 SEAL KIT, A/TRNS SERV (INCLS 507, 510) (FULL TRANS) (ACDelco #24243891) (GM04-667) - 2008 D69 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 24240017 CONVERTER, TORQ [ГИДРОТРАНСФОРМАТОР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24243293 CONVERTER, TORQ not found ШЛАНГИ, T/CV (W/ ГИДРОНАСОС) (СМ. ГРУППУ 04.000 "TORQUE CONVERTOR ШЛАНГИ AND ГИДРОНАСОС" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11515762 БОЛТ, T/CV HSG (8.900) 24205899 PLUG, T/CV HSG ACC HOLE (28MM W/3 TANGS) (SMALL CVR) (ACDelco #24205899) 24225543 SEAL, A/TRNS ГИДРОНАСОС (ACDelco #24225543) [ПРОКЛАДКА КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] not found PIN, T/CV HSG LOC (ЧАСТЬ OF 7) 24242045 CASE, A/TRNS (INCLS 6, 12, 13) (ACDelco #24242045) 24242046 CASE, A/TRNS (INCLS 6, 12, 13) (ACDelco #24242046) 24226020 PLUG, TRANS FLUID FIL TUBE not found SEAL, A/TRNS WRG CONN (*KIT1, KIT2) not found SEAL, A/TRNS WRG CONN (O RING) (*KIT1, KIT2) 24239878 SLEEVE, A/TRNS ELEC CONN PASG [МУФТА] not found PLUG, A/TRNS CASE (ЧАСТЬ OF 7) 11515762 БОЛТ, T/CV HSG (8.900) not found SEAL, A/TRNS ГИДРОНАСОС (*KIT2) not found SEAL, A/TRNS ГИДРОНАСОС (*KIT2) 24225557 SEAL, CTR SUPT FLUID PASG (*KIT2) not found VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 24237181 БОЛТ, VLV BODY (M5X0.8X73.0) 24231074 БОЛТ, MAN SHFT DTNT (M10X1X14.5) not found DETENT, MAN SHFT not found SEAL, A/TRNS FLUID FLTR (ЧАСТЬ OF 26) 24236933 FILTER KIT, A/TRNS FLUID (INCLS 25) (ACDelco #24236933) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24225800 GASKET, A/TRNS FLUID PAN (ACDelco #24225800) [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 29535617 MAGNET, A/TRNS FLUID PAN (4.105) (ACDelco #29535617) [МАГНИТ] 24242410 PAN, A/TRNS FLUID (INCLS 31) (ACDelco #24242410) 11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (A/TRNS FLUID PAN) [БОЛТ М6] 24234212 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 29) (ACDelco #24234212) [ПРОБКА] 24205900 COVER, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] 24225783 SEAL, A/TRNS CASE EXTN (ACDelco #24225783) [УПЛОТНИТЕЛЬ КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24249873 EXTENSION, A/TRNS CASE (ACDelco #24249873) 24228876 SEAL, ВЫХОДНОЙ SHF (5.556) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24214158 BEARING, ВЫХОДНОЙ SHF (DRAWN CUP) (4.131) (ACDelco #24214158) 24230287 FLANGE, PROP SHF TRANS 24231524 ГАЙКА, FRT PROP SHF FLG (M22X1.5) (FLANGE HEX) teamcadillac.ru 24229687 EXTENSION, A/TRNS CASE (MCHG) 24242995 BEARING, ВЫХОДНОЙ SHF [ПОДШИПНИК КПП] 24236928 SEAL KIT, A/TRNS ELEC CONN PASG SLEV (INCLS 9, 10) 24238913 SEAL KIT, A/TRNS SERV (CONTROL VLV SOL ASM) (ACDelco #24238913) [КОМПЛЕКТ ПРОКЛАДОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (5ШТ)] (TS04-045) - 2008 DM69 ТОРМОЗНОЙ СУППОРТ-ЗАДНИЙ ↓ teamcadillac.ru 25997338 PAD KIT, RR DISC BRK (INCLS 2) not found ПРУЖИНА, RR DISC BRK PAD (ЧАСТЬ OF 1) 25997457 BRACKET, RR BRK CLPR 25997463 BRACKET, RR BRK CLPR 88935808 SEAL KIT, RR BRK CLPR GDE PIN (4.670) [ЗАЩИТНЫЙ ЧЕХОЛ ПОРШНЯ ТОРМОЗНОГО СУППОРТА] 15855612 PIN, RR BRK CLPR GDE 25843039 CALIPER, RR BRK (17" ТОРМОЗА) (INCLS 8-12) [ТОРМОЗНОЙ СУППОРТ] 25843039 CALIPER, RR BRK (INCLS 8-12) [ТОРМОЗНОЙ СУППОРТ] 25843040 CALIPER, RR BRK (17" ТОРМОЗА) (INCLS 8-12) [СУППОРТ] 25843040 CALIPER, RR BRK (INCLS 8-12) [СУППОРТ] 25843041 CALIPER, RR BRK (INCLS 8-12) [СУППОРТ] 25843042 CALIPER, RR BRK (INCLS 8-12) [СУППОРТ] 89027183 БОЛТ, RR BRK CLPR GDE PIN (M8X1.0) [БОЛТ М8] 88935785 CAP, RR BRK BLEDR VLV (ЧАСТЬ OF 6) [ЗАГЛУШКА ОБРАТНОГО КЛАПАНА] 89027179 VALVE, RR BRK BLEDR (ЧАСТЬ OF 6) not found SEAL, RR BRK CLPR PSTN (ЧАСТЬ OF 6) (*KIT1) 15926281 PISTON, RR BRK CLPR (18" H.D. ТОРМОЗА) (ЧАСТЬ OF 6) 15926282 PISTON, RR BRK CLPR (17" ТОРМОЗА) (ЧАСТЬ OF 6) not found BOOT, RR BRK CLPR PSTN (ЧАСТЬ OF 6) (*KIT1) 25814676 SEAL KIT, RR BRK CLPR PSTN (INCLS 10, 12) 25814677 SEAL KIT, RR BRK CLPR PSTN (INCLS 10, 12) [КОМПЛЕКТ ПРОКЛАДОК] (TS04-726) - 2008 DM69 ТОРМОЗНОЙ СУППОРТ-ПЕРЕДНИЙ (J55) ↓ 15851479 CALIPER, FRT BRK (INCLS 2, 3, 8, 9, 11) (18") [СУППОРТ] 15851479 CALIPER, FRT BRK (INCLS 2, 3, 8, 9, 11) (18") [СУППОРТ] 15851480 CALIPER, FRT BRK (INCLS 2, 3, 8, 9, 11) (18") [СУППОРТ ТОРМОЗА] 15851480 CALIPER, FRT BRK (INCLS 2, 3, 8, 9, 11) (18") [СУППОРТ ТОРМОЗА] not found CAP, FRT BRK CLPR BLEDR VLV (ЧАСТЬ OF 1) 15851382 VALVE, FRT BRK CLPR BLEDR (ЧАСТЬ OF 1) 25809684 БОЛТ, FRT BRK CLPR HSG (GUIDE PIN) 25809681 PIN, FRT BRK CLPR GDE (W/O BUSHING) 25809679 PIN, FRT BRK CLPR GDE (INCLS 7) (W/PLASTIC SLEEVE 2.0MM FROM TIP) (W/BUSHING) not found BUSHING, FRT BRK CLPR GDE PIN (ЧАСТЬ OF 6, 10) not found SEAL, FRT BRK CLPR PSTN (ЧАСТЬ OF 1) (*KIT1) 15926289 PISTON, FRT BRK CLPR (ЧАСТЬ OF 1) 25814703 SEAL KIT, FRT BRK CLPR GDE PIN (INCLS 7) [ЗАСЛОНКА] not found BOOT, FRT BRK CLPR PSTN (ЧАСТЬ OF 1) (*KIT1) 25958115 PAD KIT, FRT DISC BRK (INCLS 14) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4ШТ)] 15851384 BRACKET, FRT BRK CLPR (18") 15851384 BRACKET, FRT BRK CLPR (18") 15851476 BRACKET, FRT BRK CLPR (18") 15851476 BRACKET, FRT BRK CLPR (18") not found ПРУЖИНА, FRT DISC BRK PAD RET (ЧАСТЬ OF 12) 25814704 SEAL KIT, FRT BRK CLPR PSTN (INCLS 8, 11) [КОМПЛЕКТ УПЛОТНИТЕЛЬНЫХ КОЛЕЦ ТОРМОЗНОГО СУППОРТА (2ШТ)]
  4. 00 - 6-ТИ ЦИЛИНДРОВЫЙ ДВИГАТЕЛЬ ↓ (6D00-040) - 2007-2009 E ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ-V8 (LH2/4.6A) ↓ 25716470 BRACKET, ENG MT 25762621 BRACKET, ENG MT 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (ENG MT BRKT) [БОЛТ, М10Х1.5Х30] 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT) [ГАЙКА М12] 25971085 MOUNT, ENG [ШАРНИР ДВИГАТЕЛЯ] 25971087 MOUNT, ENG 25971086 MOUNT, ENG [ОПОРНЫЙ УЗЕЛ ДВИГАТЕЛЯ] 25762620 BRACKET, ENG MT 25892303 MOUNT, TRANS RR teamcadillac.ru 25892306 MOUNT, TRANS RR 11589169 БОЛТ ASM - HEX HD W/CONICAL WASHER, M10X1.50X50, GMW25 (10.9) STL, GMW33559 (TRANS RR MT BRKT) 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (TRANS MT) [БОЛТ, М10Х1.5Х30] 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT FRM SI) [ГАЙКА М12] (6E00-005) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ & ЧАСТЬIAL ДВИГАТЕЛЬ (LH2/4.6A) ↓ teamcadillac.ru 19177068 ДВИГАТЕЛЬ, GASOLINE (GOODWRENCH NEW) (FOR 07 STS, SWP OIL FILT ADAPT, ENG OIL CLR FRM ORIG ENG.06 & PREV STS/SRX/XLR SWP МАСЛЯНЫЙ ПОДДОН, ENG OIL CLR IF APPL, WTR OTLT ASM, CAM ACTUATOR FRM ORIG) (ENG.05 & PREV STS/SRX/XLR SWP CAM CVRS & PVC TBE F (6E00-013) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ & ЧАСТЬIAL ДВИГАТЕЛЬ (LY7/3.6-7) ↓ 12617625 ДВИГАТЕЛЬ KIT, GASOLINE (GOODWRENCH) (MUST SWAP OIL FILL TUBE) (6E00-014) - 2004-2009 E КРЕПЛЕНИЕ ДВИГАТЕЛЯ TO ТРАНСМИССИЯ (LY7/3.6-7) ↓ teamcadillac.ru 12572042 PLATE, A/TRNS FLEX 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (TRANS CONV CVR) [БОЛТ] 24222918 COVER, TRANS CONV 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] (6E00-015) - 2004-2009 E ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ-V6 (LY7/3.6-7, M82) ↓ 25892303 MOUNT, TRANS RR 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (TRANS MT) [БОЛТ, М10Х1.5Х30] 11517383 БОЛТ, HEX W/CON SPR WASH, M10X1.5X55, 28 OD, 37 THD, 10.9, 7114M (TRANS RR MT BRKT) teamcadillac.ru 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT) [ГАЙКА М12] 25756321 BRACKET, ENG MT 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (ENG MT BRKT) [БОЛТ, М10Х1.5Х30] 25971088 MOUNT, ENG [ОПОРНЫЙ УЗЕЛ ДВИГАТЕЛЯ] 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT FRM SI) [ГАЙКА М12] 25971089 MOUNT, ENG 25756322 BRACKET, ENG MT (6E00-016) - 2004-2009 E ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ-V6 (LY7/3.6-7, MX5) ↓ 25892306 MOUNT, TRANS RR 11515775 БОЛТ, HFH, M12X1.75X30, 10.9, 7114M (TRANS MT) [БОЛТ] 11517383 БОЛТ, HEX W/CON SPR WASH, M10X1.5X55, 28 OD, 37 THD, 10.9, 7114M (TRANS RR MT BRKT) 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT) [ГАЙКА М12] teamcadillac.ru 25756321 BRACKET, ENG MT 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (ENG MT BRKT) [БОЛТ, М10Х1.5Х30] 25971088 MOUNT, ENG [ОПОРНЫЙ УЗЕЛ ДВИГАТЕЛЯ] 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT FRM SI) [ГАЙКА М12] 25971085 MOUNT, ENG [ШАРНИР ДВИГАТЕЛЯ] 25756320 BRACKET, ENG MT (6E00-017) - 2007-2009 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 3 ПЕРЕДНЯЯ КРЫШКА И ОХЛАЖДЕНИЕ (LH2/4.6A) ↓ 03525915 PIN, ENG FRT CVR LOC (DOWEL, 5.99X17.25, CHAM BOTH ENDS, 10.9) 89017798 COVER, ENG FRT (INCLS 353) 12593627 GASKET, ENG FRT CVR [ПРОКЛАДКА ПЕРЕДНЕЙ КРЫШКИ ДВИГАТЕЛЯ] 11519038 БОЛТ-HFH, M6X1X30, 24 THD, 13.2 OD, 10.9, GMW3359, W/ADHESIVE ON THREADS (ENG FRT CVR) [БОЛТ М6] 12569545 PLUG, ENG FRT CVR HOLE 12595614 PUMP, WAT (INCLS 901) (ACDelco #251-699) [НАСОС ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519038 БОЛТ-HFH, M6X1X30, 24 THD, 13.2 OD, 10.9, GMW3359, W/ADHESIVE ON THREADS (W/PMP) [БОЛТ М6] 12604614 PULLEY, W/PMP 24503961 БОЛТ, W/PMP PUL (M6X1.0 6G THD W/WA) (8MM SOCKET HD) 12559807 THERMOSTAT, ENG COOL (W/O GSKT) (ACDelco #131-128) [КЛАПАН РЕГУЛИРОВКИ ТЕМПЕРАТУРЫ СИСТЕМЫ ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ] 12563623 GASKET, ENG COOL THERM (ACDelco #12563623) [ПРОКЛАДКА] 12596643 ШЛАНГИ, ENG COOL THERM (ACDelco #15-80869) 11519038 БОЛТ-HFH, M6X1X30, 24 THD, 13.2 OD, 10.9, GMW3359, W/ADHESIVE ON THREADS (ENG COOL THERM HSG) [БОЛТ М6] 12590694 OUTLET, WAT (INCLS 387) (ACDelco #15-10649) 12590862 GASKET, WAT OTLT [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (WAT OTLT) 12566109 HOSE, RAD BYPASS 15024902 CЛАМПА, HOSE ПРУЖИНА, 42MM - NOM SIZE, BLK (RAD BYPASS HOSE) teamcadillac.ru 11519172 БОЛТ, HFH, 8X1.25X55, 18 OD, 22THD, 8.8, GMW3359, 6MM MATPOINT, REDUCED BODY (WAT OTLT) 12580250 DUCT, LWR INT MANIF (INCLS 526) 09359409 SENSOR, MAP (INCLS SEAL) (INCLS 741) (ACDelco #9359409) 16194007 SEAL, MAP SEN (ЧАСТЬ OF 740) [УПЛОТНИТЕЛЬ ДАТЧИКА ДАВЛЕНИЯ ПОТОКА ВОЗДУХА] 12587812 BRACKET, MAP SEN 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (MAP SEN) [БОЛТ] 12608378 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 745) (ACDelco #214-2125) 11519941 БОЛТ, HFH W/SHLDR, M6X1X22, 13.8 THD, 15 OD, 9.8, 6280M, MACH, DOG-PT (SOL VLV) 12563877 SEAL, W/PMP CVR (O RING) (ЧАСТЬ OF 360) [КОЛЬЦЕВОЕ УПЛОТНЕНИЕ ВОДЯННОГО НАСОСА] (6E00-022) - 2009 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 5 КОЛЛЕКТОР & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7) ↓ 12604932 TUBE, PCV (INCLS 292) (FRESH AIR) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (PCV TUBE) 12616910 HOSE, PCV (INCLS 285, 286, 290, 291, 293) (DIRTY AIR) 12616908 SEAL, PCV HOSE FTG (O RING) (ЧАСТЬ OF 283) (BLUE) (LARGER OF THE TWO ON THE FITTING) [УПЛОТНЕНИЕ] 12616909 SEAL, PCV HOSE FTG (O RING) (ЧАСТЬ OF 283) (BLACK) (SMALLER OF THE TWO ON THE FITTING) [УЛОТНЕНИЕ] 12597853 MANIFOLD, UPR INT (MACH) (INCLS 506) 12571079 MANIFOLD, LWR INT (INCLS 519) 11518906 БОЛТ, HFH, RDUCD BDY, M8X1.25X165, 22 THD, 18 O.D., 8.8, GMW3359 (INT UPR MANIF) [БОЛТ] 11519176 БОЛТ, INT MANIF (M8X1.25X80) (4.081) [БОЛТ] 12595277 GASKET KIT, UPR INT MANIF [ПРОКЛАДКА] 12598158 GASKET KIT, INT MANIF [ПРОКЛАДКА ДВИГАТЕЛЯ] 11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (LWR INT MANIF) 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (F/INJN FUEL RL) [БОЛТ] 11609319 STUD, UPR INT MANIF SIGHT SHLD (3.671) 12576262 GASKET, EXH MANIF [ПРОКЛАДКА ВЫПУСКНОГО КОЛЛЕКТОРА] teamcadillac.ru 12571102 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 12580706 SHIELD, EXH MANIF HT 24505098 БОЛТ, HFH, RND HD, 6X1X12.15, W/ANTI SEIZE, 14.2 O.D.DG PT, 10.9, 711 (EXH MANIF H/SHLD) 12582663 INSULATOR, EXH MANIF UPR 12616647 SHIELD, STRTR HT 12608475 GASKET, EXH MANIF 12571101 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 11518860 БОЛТ, HFH, M8X1.25X30, 20.9 THD, 18 O.D., 10.9, GMW3179 CODE G, GM6194M (EXH MANIF H/SHLD) [БОЛТ] 12617267 SHIELD, EXH MANIF HT 24505098 БОЛТ, HFH, RND HD, 6X1X12.15, W/ANTI SEIZE, 14.2 O.D.DG PT, 10.9, 711 (EXH MANIF H/SHLD) 12581807 INSULATOR, EXH MANIF LWR 14093869 ГАЙКА, PUSH ON, M6, 2.25THK, 12.95 O.D., STL, POR (EXH MANIF H/SHLD INSL) 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (EXH MANIF H/SHLD) [БОЛТ] 12616994 BODY, THROT (W/THROT ACTR) (ACDelco #217-3103) [ЧАСТЬ КОРПУСА] 11519972 БОЛТ, THROT BODY (M6X1.0X50) 12593360 GASKET, THROT BODY (ACDelco #40-5083) [ПРОКЛАДКА ДРОССЕЛЬНОЙ ЗАСЛОНКИ] 12611801 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 752) (ACDelco #214-1685) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (EVAP EMIS CNSTR PURGE SOL VLV BRKT) 12584171 HOSE, EVAP EMIS CNSTR SOL VLV 12629734 VALVE, INT MANIF TUNING (INCLS 756) 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (INT MANIF TUNING VLV) [БОЛТ] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (WRG HARN BRKT) 24574534 STUD, ENG WRG HARN BRKT (M6X1X20) (1.166) (6E00-023) - 2009 E INTAKE MANIFOLD SHIELD/COVERS (LY7/3.6-7) ↓ 12583604 SHIELD, UPR INT MANIF SIGHT (INCLS 2, 5, 17) [ЗАЩИТА] 12593356 CAP, OIL FIL (INCLS 4) (ЧАСТЬ OF 7) (ACDelco #FC221) [КРЫШКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ] 12593348 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 3, 7) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА] 12606862 GROMMET, UPR INT MANIF SIGHT SHLD (ЧАСТЬ OF 1) (32MM OD) 11609319 STUD, UPR INT MANIF SIGHT SHLD (3.671) 12597946 TUBE, OIL FIL (INCLS 3, 4, 8) [ТРУБКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ ГОЛОВКИ БЛОКА] 12593348 SEAL, OIL FIL TUBE (O RING) (ЧАСТЬ OF 7) (27.94MM I.D.) (SIZE #320) (1.758) [ПРОКЛАДКА] 12604673 BRACE, INT MANIF 11588723 БОЛТ, HFH, M8X1.25X25, 18 THD, 18 OD, 8.8 STL, GMW3359, M-PT (INT MANIF BR) 11518712 БОЛТ-HEX W/CON WA, M12X1.75X59, 53.6 THD, 24OD, 10.9, 7114M, MACH, 6175M, HDR (INT MANIF SIGHT SHLD) 11516075 ГАЙКА, HFH SELF LK, M6X1, 7.7THK, 14.2 O.D., 9, PZOR (ЧАСТЬ OF 14) [ГАЙКА ВЫПУСКНОЙ СИСТЕМЫ D=6ММ] 12616618 BRACKET, INT MANIF SIGHT SHLD (INCLS 13, 16) 11588967 STUD, BALL W/HFH, M6X1X20.65, 14.2 O.D., 8.8, GMW3359 (INT MANIF BR) teamcadillac.ru (6M00-029) - 2006-2009 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 1 БЛОК ЦИЛИНДРОВ & ВНУТРЕННИЕ ДЕТАЛИ (LH2/4.6A) ↓ 12573430 SEAL, LWR C/CASE (4.3MM WIDE X 5MM TALL) [ПРОКЛАДКА] 11610074 БОЛТ-HFH, M8X1.25X45, 21 THD, 16 OD, 10.9 STL, GMW3359 (LWR C/CASE) 03522376 БОЛТ, HFH, M6X1X23, 18 THD, 14.50 OD, 7T, ZP (ENG OIL MANIF) 03542310 БОЛТ, LWR C/CASE (M10X1.5X125, 30 THD) (8.900) 03542311 STUD, LWR C/CASE (M10X1.5X125-M9X1.0X13) (1.428) 03530355 PIN, LWR C/CASE LOC (M8X20) 12582395 CRANKSHAFT, (MCHG) 12585420 PIN, CR/SHF SPKT LOC 89017562 BEARING KIT, CR/SHF (INCLS 123) (STD) (POSN # 1, 2, 4, 5) [ПОДШИПНИК] 89017563 BEARING KIT, CR/SHF (INCLS 900) (STD) (POSN # 3) [ПОДШИПНИК] 12568025 SEAL, CR/SHF RR OIL [ПРОКЛАДКА] 12338076 PIN, TRANSAXLE LOC (19.5 MM X 18.5 MM) (TO CYL BLK) 03525915 PIN, ENG FRT CVR LOC (DOWEL, 5.99X17.25, CHAM BOTH ENDS, 10.9) 24503702 PLUG, ENG BLK COOL HOLE (8X1.25X12, 10.5 THD W/6MM OF 6124M ADHES, 17.6 OD, 9.8, PC) 03522422 PLUG, CM/SHF (CUP, W/LIP, 50.24X6.12X1.52, 52.58 OD, 1008, OIL) 12582606 FLYКОЛЕСО, ENG 11589116 БОЛТ, FLYWHL (8.900) 12568122 COVER, FLYWHL HSG 12570154 SPROCKET, CR/SHF 12581223 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (PRIMARY) 01647264 БОЛТ, TMG CHAIN TENSR (HFH, 8X1.25X42, 22 THD, 17.0 OD, 9.8, PC, MACH) 12564274 CHAIN, CM/SHF INTER DRV 12559388 GUIDE KIT, TMG CHAIN (PRIMARY CHAIN) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 12577433 SPROCKET, CM/SHF INTER DRV SHF 01647272 БОЛТ, CM/SHF SPKT 12577790 SHAFT, CM/SHF INTER DRV 15685550 БОЛТ, CM/SHF INTER DRV SHF RET (M6X1X20) (16.330) [ВИНТ] 12556023 GUIDE, TMG CHAIN (SECONDARY CHAIN GUIDE) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 12556030 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (SECONDARY ON LH BANK) [НАТЯЖИТЕЛЬ РЕМНЯ] 01647264 БОЛТ, TMG CHAIN TENSR (HFH, 8X1.25X42, 22 THD, 17.0 OD, 9.8, PC, MACH) 12556023 GUIDE, TMG CHAIN (SECONDARY CHAIN GUIDE) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 12581281 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (SECONDARY ON RH BANK) 01647264 БОЛТ, TMG CHAIN TENSR (HFH, 8X1.25X42, 22 THD, 17.0 OD, 9.8, PC, MACH) 12567469 ROD, CONN (INCLS 201) (USES 23MM PIN) 12552947 БОЛТ, CONN ROD (ЧАСТЬ OF 200) (MJ9X1.0-4H6HX61.9 LONG) [БОЛТ] 89017430 PISTON, (W/PIN) (INCLS 211, 212) 12584576 BALANCER, CR/SHF [ШКИВ КОЛЕНВАЛА] 11569873 БОЛТ, CR/SHF BALR (M14X1.5X48.4) 12577394 BAFFLE, МАСЛЯНЫЙ ПОДДОН (B/W CRANK CASE AND PAN) teamcadillac.ru 12580429 SENSOR, CR/SHF POSN (INCLS 721) (ACDelco #213-3515) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (CR/SHF POSN SEN) 12570125 SENSOR, KNOCK (ACDelco #213-1576) 89017760 STARTER, (REMAN) (ACDelco #323-1633) (DELCO SERIES PG260H) [СТАРТЕР] 11515793 БОЛТ, HFH (STRTR) 12603426 HARNESS, CR/SHF POS SEN & KNOCK SEN WRG (INCLS 797) 12559363 BEARING KIT, CONN ROD (STD) (INCLS 203, 204) [КОМПЛЕКТ ПОДШИПНИКОВ СКОЛЬЖЕНИЯ ШАТУНА (2ШТ)] 89017413 RING KIT, PSTN (INCLS 213-216) (6M00-043) - 2008-2009 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 5 КОЛЛЕКТОР & FUEL ДЕТАЛИ КОМПЛЕКТА (LH2/4.6A) ↓ 12604755 TUBE, PCV (INCLS 900, 901) (FRESH AIR TUBE) 12587817 TUBE, PCV (DIRTY AIR TUBE) 12590694 OUTLET, WAT (INCLS 387) (ACDelco #15-10649) 12590862 GASKET, WAT OTLT [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (WAT OTLT) 12566109 HOSE, RAD BYPASS 15024902 CЛАМПА, HOSE ПРУЖИНА, 42MM - NOM SIZE, BLK (RAD BYPASS HOSE) 11519172 БОЛТ, HFH, 8X1.25X55, 18 OD, 22THD, 8.8, GMW3359, 6MM MATPOINT, REDUCED BODY (WAT OTLT) 12588847 MANIFOLD, INT (INCLS 501, 520, 903) 12571222 FITTING, P/B BOOS VAC TUBE 12579192 COVER, INT MANIF 12579193 COVER, INT MANIF 11588967 STUD, BALL W/HFH, M6X1X20.65, 14.2 O.D., 8.8, GMW3359 (IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ) 12588809 SEAL, UPR INT MANIF (ЧАСТЬ OF 500) [УПЛОТНИТЕЛЬ ВЫПУСКНОГО КОЛЛЕКТОРА] 12580250 DUCT, LWR INT MANIF (INCLS 526) 11588352 БОЛТ, INT MANIF (W/SPCR) 12557010 STUD, F/INJN FUEL RL (HEX, M6X1.022-M6X1.016, 45MM TOTAL LENGTH) (3.275) 12571212 SHIELD, UPR INT MANIF SIGHT (INCLS 595, 596) [ЗАЩИТНЫЙ КОЖУХ ДВИГАТЕЛЯ] 12600206 BRACKET, UPR INT MANIF SIGHT SHLD (INCLS 904) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (UPR INT MANIF SIGHT SHLD) 12567370 STUD, UPR INT MANIF SIGHT SHLD (3.265) 12567371 GROMMET, UPR INT MANIF SIGHT SHLD (ЧАСТЬ OF 590) [ВТУЛКА] 12607451 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 626, 906) (3.685) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 12607338 SHIELD, EXH MANIF HT 24505098 БОЛТ, HFH, RND HD, 6X1X12.15, W/ANTI SEIZE, 14.2 O.D.DG PT, 10.9, 711 (EXH MANIF H/SHLD) 12607450 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 626, 635, 636, 906) (3.685) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 11517031 ГАЙКА, HFH, M8X1.25, 9.4THK, 17.4 O.D., 10, TIN ZN (EXH MANIF) 11519171 БОЛТ, EXH MANIF CLA (M8X1.25X50) (3.275) [БОЛТ ВЫПУСКНОГО КОЛЛЕКТОРА] 11562490 STUD, STRAIGHT, M8X1.25X20, M8X1.25X40, 69 TL, 9.8, GMW3179, EXT HEX SOCKET (EXH MANIF) [ШПИЛЬКА М8] 11609596 STUD, CTLTC CONV (ЧАСТЬ OF 600, 620) [ШПИЛЬКА] 12576372 SHIELD, EXH MANIF HT 24505098 БОЛТ, HFH, RND HD, 6X1X12.15, W/ANTI SEIZE, 14.2 O.D.DG PT, 10.9, 711 (EXH MANIF H/SHLD) 12568289 SHIELD, EXH MANIF LWR HT (ЧАСТЬ OF 620) 10229247 RIVET, EXH MANIF H/SHLD (ЧАСТЬ OF 620) (3.601) 12615495 BODY, THROT (W/THROT ACTR) (INCLS 702) (ACDelco #217-3156) 11519973 БОЛТ-HFH, M6X1X60, 18MM THD, 14.2 OD, 8.8, 3359GMW, REDUCED BODY, MAT PT. (ЧАСТЬ OF 701) [БОЛТ 6Х1Х60] 12576549 GASKET, THROT BODY (ACDelco #217-1618) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ДРОССЕЛЬНОЙ ЗАСЛОНКИ] 09359409 SENSOR, MAP (INCLS SEAL) (INCLS 741) (ACDelco #9359409) 16194007 SEAL, MAP SEN (ЧАСТЬ OF 740) [УПЛОТНИТЕЛЬ ДАТЧИКА ДАВЛЕНИЯ ПОТОКА ВОЗДУХА] teamcadillac.ru 12587812 BRACKET, MAP SEN 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (MAP SEN) [БОЛТ] 12608378 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 745) (ACDelco #214-2125) 11519941 БОЛТ, HFH W/SHLDR, M6X1X22, 13.8 THD, 15 OD, 9.8, 6280M, MACH, DOG-PT (EVAP EMIS CNSTR PURGE SOL) 12567655 GASKET, EXH MANIF [ПРОКЛАДКА] 12613200 FITTING, PCV HOSE (ЧАСТЬ OF 281) 12571223 PLUG, P/B VAC SCE HOLE (ЧАСТЬ OF 500) (16.0 MM) 19167509 INSULATOR, UPR INT MANIF CVR (ЧАСТЬ OF 591) (3.405) 12607145 SENSOR, HTD OXY (POSN 1) (IN EXH MANIFOLD/CROSSOVER) (ACDelco #213-4116) [КИСЛОРОДНЫЙ ДАТЧИК] 25709703 SEAL, CTLTC CONV (ЧАСТЬ OF 600, 620) (ROUND METAL SEAL) [ПРОКЛАДКА НАСОСА] (6M00-071) - 2007-2009 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 4 МАСЛЯНЫЙ НАСОС, PAN & ДЕТАЛИ КОМПЛЕКТА (LH2/4.6A) ↓ 12580850 MANIFOLD, ENG OIL (INCLS 107-109) (WITHOUT МАСЛЯНЫЙ ПОДДОН BAFFLE) [КОЛЛЕКТОР МАСЛЯНЫЙ] 03522376 БОЛТ, HFH, M6X1X23, 18 THD, 14.50 OD, 7T, ZP (ENG OIL MANIF) 03542310 БОЛТ, LWR C/CASE (M10X1.5X125, 30 THD) (8.900) 03542311 STUD, LWR C/CASE (M10X1.5X125-M9X1.0X13) (1.428) 12612258 PAN, OIL (INCLS 401, 412, 413, 420-422) 12568928 GASKET, МАСЛЯНЫЙ ПОДДОН (ЧАСТЬ OF 400) [ПРОКЛАДКА] 12567529 PIPE, O/PMP SUC (INCLS 406, 407) 12573569 GASKET, O/PMP SUC PIPE (ЧАСТЬ OF 405) [ПРОКЛАДКА МАСЛЯНОГО НАСОСА] 03522382 БОЛТ, O/PMP SUC PIPE (ЧАСТЬ OF 405) (HFH, M6X1.0X28) 03542258 ГАЙКА, O/PMP SUC PIPE (HFH, M9X1) (1.430) 12577394 BAFFLE, МАСЛЯНЫЙ ПОДДОН (B/W CRANK CASE AND PAN) 11562588 PLUG, МАСЛЯНЫЙ ПОДДОН DRN (ЧАСТЬ OF 400) (INCLS 413) (W/ SEAL) (EXC MAGNET) [ЗАГЛУШКА МАСЛЯНОГО ПОДДОНА] 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 400) 11519173 БОЛТ, HFH, REDUCED BODY, M8X1.25X60, 22THD, 18 OD, 8.8, GMW3359 (ЧАСТЬ OF 400) 11519178 БОЛТ HFH, M8X1.25X100, 13MM SOCKET, 8.8, GMW3359 (ЧАСТЬ OF 400) 12585398 INDICATOR, OIL LVL (INCLS 434) [ЩУП УРОВНЯ МАСЛА] 12570585 TUBE, OIL LVL IND (INCLS 432) [НАПРАВЛЯЮЩАЯ ТРУБКА ЩУПА УРОВНЯ МАСЛА] 24504091 SEAL, OIL LVL IND TUBE (O RING) (ЧАСТЬ OF 431) (BLACK) (6.07MM ID, 1.78MM DIA) 11515765 БОЛТ, HFH, M10X1.5X25, 22.30 O.D., HDR PT, 10.9, 7112M (OIL LVL IND TUBE) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) 12598047 ADAPTER, OIL FLTR (INCLS 441, 442, 445, 446, 449, 717, 718, 728, 729) 12573045 GASKET, OIL FLTR ADAP (ЧАСТЬ OF 440) [ПРОКЛАДКА МАСЛЯНОГО ФИЛЬТРА] 11519173 БОЛТ, HFH, REDUCED BODY, M8X1.25X60, 22THD, 18 OD, 8.8, GMW3359 (ЧАСТЬ OF 440) 24575062 FITTING, OIL FLTR (ЧАСТЬ OF 440) 25014612 VALVE, OIL FLTR BYPASS (ЧАСТЬ OF 440) (W/O VAPOR SEPARATOR) (OPENING PRESSURE 21 PSI NOMINAL) (ЧАСТЬ HAS A 16.10MM MAX OD & FITS A 15.84 HOLE IN BLOCK) 89017342 ФИЛЬТР, МАСЛЯНЫЙ (ЧАСТЬ OF 440) (FOR NON-CANADIAN ORDERS) (ACDelco #89017342) 11519833 PLUG ROUND HD, M16X1.5X22, 20 OD, 10 THD, 5.8, 4345M, SEALANT 9985490, MACH (OIL FLTR BYPASS HOLE) 12590890 PUMP, OIL (INCLS 464-472) [МАСЛЯНЫЙ НАСОС] 11518944 SCREW, PAN HD, M6X1X25, 20.9 THD, 11 OD, 8.8, GMW3359, 6 LOBED T-30 M-POINT (ЧАСТЬ OF 463) (8.913) 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (O/PMP) (ACDelco #11517518) [БОЛТ] 12568009 TUBE, O/PMP OTLT (INCLS 481) [ТРУБКА] 12568320 SEAT, ENG OIL MANIF CHK VLV (ЧАСТЬ OF 480) (0.724) [КОЛЬЦЕВОЕ УПЛОТНЕНИЕ] teamcadillac.ru 11518944 SCREW, PAN HD, M6X1X25, 20.9 THD, 11 OD, 8.8, GMW3359, 6 LOBED T-30 M-POINT (O/PMP OTLT TUBE) (8.913) 12573744 SHIELD, ENG OIL PRESS GA SEN HT (ЧАСТЬ OF 440) 11519964 БОЛТ, HFH, M6X1X13, 6 THD, 14.2 OD, 8.8, GMW3359, MAT POINT (ЧАСТЬ OF 440) 12567911 SENSOR, ENG OIL PRESS (ЧАСТЬ OF 440) (INCLS 729) (ACDelco #213-1547) [ДАТЧИК ДАВЛЕНИЯ МАСЛА] (6M00-073) - 2006-2009 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 4 МАСЛЯНЫЙ НАСОС,МАСЛЯНЫЙ ПОДДОН & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7) ↓ 22531637 PIN, МАСЛЯНЫЙ ПОДДОН LOC (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 12586959 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (LOWER PRIMARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ГРМ] 12586960 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАТЯЖИТЕЛЬ ЦЕПИ] 12586961 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАПРАВЛЯЮЩАЯ ПРИВОДНОЙ ЦЕПИ] 12597417 GUIDE, TMG CHAIN (UPPER PRIMARY) teamcadillac.ru 12600461 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ПРИВОДА ГРМ] 12600462 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ПРИВОДА ГРМ] 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (ЧАСТЬ OF 463) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12596502 PAN, OIL (INCLS 404-407, 410, 412, 413, 420, 422, 900) 12575373 PIPE, O/PMP SUC (ЧАСТЬ OF 400) 12566837 SEAL, O/PMP SUC PIPE (ЧАСТЬ OF 400) [УПЛОТНЕНИЕ] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 400) 12566872 DEFLECTOR, CR/SHF OIL (ЧАСТЬ OF 400) 11562588 PLUG, МАСЛЯНЫЙ ПОДДОН DRN (ЧАСТЬ OF 400) (INCLS 413) (W/ SEAL) (EXC MAGNET) [ЗАГЛУШКА МАСЛЯНОГО ПОДДОНА] 12616850 SEAL, МАСЛЯНЫЙ ПОДДОН DRN PLUG (O RING) (ЧАСТЬ OF 400, 412) 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (ЧАСТЬ OF 400) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11588424 БОЛТ, HFH, M6X1X145, 18 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 400) [ШЕСТИГРАННЫЙ ВИНТ] 12611594 INDICATOR, OIL LVL (INCLS 434) 12612349 TUBE, OIL LVL IND (INCLS 432) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 431) (BLACK) (6.07MM ID, 1.78MM DIA) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (OIL LVL IND TUBE) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) 12591607 ADAPTER, OIL FLTR (INCLS 441-443, 446-450, 456, 458, 459, 728, 729) [АДАПТЕР МАСЛЯНОГО ФИЛЬТРА] 12591604 GASKET, OIL FLTR (ЧАСТЬ OF 440) (BETWEEN OIL FILTER ADAPTER AND BLOCK) [ПРОКЛАДКА МАСЛЯНОГО ФИЛЬТРА] 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 440) 11519174 БОЛТ, HFH, W/REDUCED BODY, M8X1.25X65, THD 22, O.D. 18, 8.8, GMW3359 (ЧАСТЬ OF 440) 25014612 VALVE, OIL FLTR BYPASS (ЧАСТЬ OF 440, 450) (W/O VAPOR SEPARATOR) (OPENING PRESSURE 21 PSI NOMINAL) (ЧАСТЬ HAS A 16.10MM MAX OD & FITS A 15.84 HOLE IN BLOCK) 11519184 БОЛТ, OIL FLTR ADAP (ЧАСТЬ OF 440) (M10X1.5X45) (0.029) 25177917 ФИЛЬТР, МАСЛЯНЫЙ (ЧАСТЬ OF 440) (ACDelco #PF2129) [МАСЛЯНЫЙ ФИЛЬТР ДВИГАТЕЛЯ] 12583470 CAP, OIL FLTR (ЧАСТЬ OF 440) (INCLS 446, 456) [КРЫШКА] 12577653 SEAL, OIL FLTR CAP (O RING) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КРЫШКИ МАСЛЯНОГО ФИЛЬТРА] 12590152 PUMP, OIL (INCLS 151, 154, 464-466, 468, 470-472, 474, 475) (INCLS GUIDE, БОЛТS) [МАСЛЕННЫЙ НАСОС] 11900371 БОЛТ, HEX HD, W/1.6 FLAT WA, M8X1.25X54.3, 43 THD, 16O.D., 8.8, GMW3359 (ЧАСТЬ OF 463) 12610143 NOZZLE, PSTN OIL (INCLS 491) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 490) 12621649 SENSOR, ENG OIL PRESS (INCLS 729) (ЧАСТЬ OF 440) (ACDelco #D1800C) 11588734 БОЛТ, HFH, M8X1.25X90, 21.6 THD, 18 O.D., 8.8, GMW3359 (ЧАСТЬ OF 400) [ВИНТ] (6Y00-003) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 2 ГОЛОВКА ЦИЛИНДРОВ & ДЕТАЛИ КОМПЛЕКТА (LH2/4.6A) ↓ 03522352 PIN, CYL HD LOC (HOLLOW DOWEL, 15.675X28, CHAM BOTH ENDS, SAE 12L14, ZP) 12564273 CHAIN, SECD TMG teamcadillac.ru 12559389 SHOE KIT, TMG CHAIN TENSR (INCLS 174) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (ЧАСТЬ OF 173) (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 89017766 SHOE KIT, TMG CHAIN TENSR (INCLS 184) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (ЧАСТЬ OF 183) (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 12576969 VALVE, CM/SHF POSN ACTR SOL 12581497 ACTUATOR, CM/SHF POSN (EXH) 12581498 ACTUATOR, CM/SHF POSN (EXH) 12581499 ACTUATOR, CM/SHF POSN (INT) 12581500 ACTUATOR, CM/SHF POSN (INT) 12591268 COVER, CM/SHF (INCLS 251, 254-256, 261, 908, 909) 12591269 COVER, CM/SHF (INCLS 251, 254-256, 261, 908, 909) 12576394 GASKET, CM/SHF CVR (ЧАСТЬ OF 250) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ ЦИЛИНДРОВ] 12576395 GASKET, CM/SHF CVR (ЧАСТЬ OF 250) (BETWEEN HEAD AND CAM COVER) [ПРОКЛАДКА] 12576396 GASKET, CM/SHF CVR (ЧАСТЬ OF 250) (СВЕЧИ HOLES) [ПРОКЛАДКА] 12557829 БОЛТ, CM/SHF CVR (ЧАСТЬ OF 250) 12573742 INSULATOR, CM/SHF CVR БОЛТ (ЧАСТЬ OF 250) 12583570 CAP, OIL FIL (ROUND W/HDL) (INCLS 259) (NON VENTED) (ACDelco #FC215) 12593348 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 258) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА] 12581538 HEAD, CYL (MCHG) (INCLS 312, 313, 315, 334-337) 12581539 HEAD, CYL (MCHG) (INCLS 312, 313, 315, 334-337) 11569957 БОЛТ, CYL HD (M11X2X161, 60 THD) (*KIT1) 01647218 БОЛТ, CYL HD (QTY 3-RH, 3-LH) (M6X1.0X50, 10.9) (HFH, MACH) 11562126 PLUG, CYL HD CORE HOLE (ЧАСТЬ OF 300) (CUP, 32.03X7.88X1.27, S30400 SS PER SAE J405.) [ЗАГЛУШКА ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 01647543 PLUG, CYL HD CORE HOLE (ЧАСТЬ OF 300) (ROUND HEAD, INT HEX, W/ALUM WASH, 20X1.5X17, 12.25 THD, C1010 RQ) 11588949 PLUG, M16X1.5X14, 24 OD, SAE 1010 STL, GMW3044, W/ AL WASHER (ЧАСТЬ OF 300) [ПРОБКА ЗАМКА] 12574785 RESTRICTOR, ENG BLK OIL GAL 12607211 VALVE, EXH 12590223 VALVE, INT 12565203 ARM, VLV RKR [КОРОМЫСЛО КЛАПАНА ДВИГАТЕЛЯ] 24100005 ADJUSTER, HYD VLV LASH (ACDelco #24100005) [ТОЛКАТЕЛЬ КЛАПАНА ДВИГАТЕЛЯ] 12574354 SEAL, VLV STEM OIL [УПЛОТНЕНИЕ ШТОКА КЛАПАНА] 12565199 ПРУЖИНА, VLV 12580385 CAP, VLV SPR 01647209 KEY, VLV STEM 12565171 CAMSHAFT, EXH (MCHG) (INCLS 338) 12565172 CAMSHAFT, EXH (MCHG) (INCLS 338) [РАСПРЕДВАЛ В СБОРЕ] 12563833 CAMSHAFT, INL (MCHG) (INCLS 338) [РАСПРЕДВАЛ] 12565168 CAMSHAFT, INL (MCHG) (INCLS 338) [КОЛЕНВАЛ] 01647553 БОЛТ, CM/SHF BRG CAP (ЧАСТЬ OF 300) (HFH, M6X1.0X39.5) 12596360 ШЛАНГИ, CM/SHF POSN ACTR (INCLS 342, 344, 345, 735-737) 12596361 ШЛАНГИ, CM/SHF POSN ACTR (INCLS 342, 344, 345, 735-737) 12567656 GASKET, CM/SHF POSN ACTR HSG (ЧАСТЬ OF 340) (0.423) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12567657 GASKET, CM/SHF POSN ACTR HSG (ЧАСТЬ OF 340) (0.423) [УПЛОТНЕНИЕ ДВИГАТЕЛЯ] 11518706 STUD-HFH, M6X1X13.4, M6X1X40, 14.2 OD, 60 TL, 10.9, GM6280M (NON HEX CHROME) (ЧАСТЬ OF 340) (8.981) 11518707 STUD, HFH, M6X1X13 / M6X1X45, 14.2 O.D., 65 TL, 9.8, GM6280M (CM/SHF POSN ACTR HSG) 11562490 STUD, STRAIGHT, M8X1.25X20, M8X1.25X40, 69 TL, 9.8, GMW3179, EXT HEX SOCKET (EXH MANIF) [ШПИЛЬКА М8] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ) 15326386 SENSOR, ENG COOL TEMP (2-WAY MALE) (3.682) (ACDelco #213-928) [ДАТЧИК ТЕМПЕРАТУРЫ ДВИГАТЕЛЯ] 12571535 СВЕЧИ, (DO NOT CHANGE GAP) (ACDelco #41-987) (PLATINUM PLUG) [СВЕЧА ЗАЖИГАНИЯ] 12593995 SENSOR, CM/SHF POSN (INCLS 726) (ACDelco #213-3517) 01647346 БОЛТ, HFH, M6X1X17, 17THD, 14.2 O.D., 8.8, ZF (CM/SHF POSN SEN) 12567085 MAGNET, CM/SHF POSN ACTR (INCLS 737) (ЧАСТЬ OF 340) [МАГНИТ] 11518845 SCREW PAN HD, M6X1X16, 15 THD, 12 OD, 8.8, 6280M, TORX, T30, HDR PT, W/SEALANT (ЧАСТЬ OF 340) 12567421 PLUG, CM/SHF POSN ACTR BORE (ЧАСТЬ OF 340, 735) 12581176 HARNESS, ELEK ICM WRG (INCLS 772) 11519976 БОЛТ, HFLGE, M8X1.25X20, 15.6 THD, 18 O.D., 8.8, GMW3359 (ELEK ICM WRG HARN CLIP) 11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (ЧАСТЬ OF 770) [БОЛТ М8] 11517094 SCREW, M5X.8X15.6, 10.4 THD, 10.2 OD, 6202M, 7114M, TAPER-POINT (ЧАСТЬ OF 250) (ACDelco #11517094) 89017450 GASKET KIT, CYL HD (INCLS 302, 310) (INCL GASKET AND M11X2.0 БОЛТS) [ПРОКЛАДКА ДВИГАТЕЛЯ] 89017451 GASKET KIT, CYL HD (INCLS 302, 310) (INCL GASKET AND M11X2.0 БОЛТS) [ПРОКЛАДКА ДВИГАТЕЛЯ] (GM00-387) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 1 БЛОК ЦИЛИНДРОВ И ВНУТРЕННИЕ ДЕТАЛИ (LY7/3.6-7) ↓ 12560272 БОЛТ, CR/SHF BRG CAP (M10X2X102.5, 24.5) [ВИНТ] 11518861 БОЛТ, HFH, W/REDCD BODY, M8X1.25X90, 26 THD, 18 O.D., 10.9, GM4277M (CR/SHF BRG CAP) [БОЛТ] 11609410 БОЛТ, HFH, M8X1.25X25, 10.9, GMW3179 (CR/SHF BRG CAP) (0.056) [БОЛТ] 89021297 ADHESIVE/SEALANT, THREADLOCKER HI STRENGTH 10ML ERI (CR/SHF BRG CAP) [АДГЕЗИВ] 11589000 БОЛТ, HFH, M8X1.25X50, 24 THD, 18 OD, 10.9, GMW3359, RED BODY, W/ADH (CR/SHF BRG CAP) 12557520 PLUG, ENG BLK OIL GAL (CUP-.390IN OD, .040IN THK, STEEL) 12621351 CRANKSHAFT, [КОЛЕНВАЛ] 11561583 PLUG, ENG BLK OIL GAL (M14X1.5X16, 22 OD) (0.253) 12566587 PLUG, ENG BLK OIL GAL 11561751 PLUG, CYL HD WAT JKT HOLE (M20X1.5X30.5) (1.531) 11569584 PLUG, ENG BLK CORE HOLE (CUP DIA 34.4MM) 12597210 PIN, TRANS LOC 12620955 SEAL, CR/SHF RR OIL (INCLS 134) [ПРОКЛАДКА КОЛЕНВАЛА ДВИГАТЕЛЯ] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 133) 22531637 PIN, МАСЛЯНЫЙ ПОДДОН LOC (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 12570326 PIN, CYL HD LOC [ЗАГЛУШКА БЛОКА ЦИЛИНДРОВ] 12572042 PLATE, A/TRNS FLEX 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12608432 ROD, CONN (INCLS 201, 202) 11519680 БОЛТ, CONN ROD (ЧАСТЬ OF 200) (M9X1X53) [БОЛТ] teamcadillac.ru 12598657 BEARING KIT, CONN ROD (UPPER) [ПОДШИПНИК СКОЛЬЖЕНИЯ ШАТУНА] 12585675 PISTON, (W/PIN) (INCLS 211, 212) (.25 O.S.) 12590866 PISTON, (W/PIN) (INCLS 211, 212) (STD) 12566186 RETAINER, PSTN PIN (ЧАСТЬ OF 210) 12603180 BALANCER, CR/SHF (DUAL BELT) [ШКИВ КОЛЕНВАЛА] 11569873 БОЛТ, CR/SHF BALR (M14X1.5X48.4) 12613030 SENSOR, CR/SHF POSN (INCLS 721, 722) [ДАТЧИК ПОЛОЖЕНИЯ КОЛЕНВАЛА] 11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (ЧАСТЬ OF 720) [БОЛТ] 12605738 SENSOR, KNOCK (W/O LEADS) (INCLS 724) (ACDelco #213-4404) 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 723) 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (EXH MANIF H/SHLD) [БОЛТ] 12610603 BEARING KIT, CR/SHF (#1, 2, 4 STD) (INCLS 122, 123) [ПОДШИПНИК СКОЛЬЖЕНИЯ КОЛЕНВАЛА] 12610604 BEARING KIT, CR/SHF (#3 STD) (INCLS 123, 124) [КОМПЛЕКТ ПОДШИПНИКОВ СКОЛЬЖЕНИЯ КОЛЕНВАЛА (3ШТ)] 12608615 RING KIT, PSTN (INCLS 213-216) (STD) (GM00-395) - 2007-2009 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 3 ПЕРЕДНЯЯ КРЫШКА И ОХЛАЖДЕНИЕ (LY7/3.6-7) ↓ 22531637 PIN, ENG FRT CVR LOC (ЧАСТЬ OF 350) (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 11519176 БОЛТ, ENG FRT CVR (ЧАСТЬ OF 350) (M8X1.25X80) (4.081) [БОЛТ] 12611883 COVER, ENG FRT (W/ W/PMP) (INCLS 132, 348, 351-354, 360-362, 725-727, 734, 900-903) [БОКОВАЯ КРЫШКА ДВИГАТЕЛЯ] 12593045 SEAL, W/PMP (ЧАСТЬ OF 350) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519171 БОЛТ, ENG FRT CVR (ЧАСТЬ OF 350) (M8X1.25X50) (3.275) [БОЛТ ВЫПУСКНОГО КОЛЛЕКТОРА] 12608750 SEAL, CR/SHF FRT OIL (ЧАСТЬ OF 350) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КОЛЕНВАЛА] 12594060 DEADENER, ENG FRT CVR (ЧАСТЬ OF 350) (BOTTOM) [ПРОКЛАДКА КРЫШКИ ДВИГАТЕЛЯ] 12618472 PUMP, WAT (W/GSKT) (INCLS 900) (ЧАСТЬ OF 350) (ACDelco #251-724) [НАСОС] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 350) 12576326 GASKET, W/PMP (ЧАСТЬ OF 350) (ACDelco #251-2048) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12574518 PULLEY, W/PMP (ADX) 11519512 БОЛТ, HFH, W/CON SPR WA, M6X1X13.4, 8.77 THD, 12.3 O.D., 8.8, GMW3359 (W/PMP PUL) 12592527 GASKET, ENG COOL THERM HSG (*KIT1) (ACDelco #12592527) [ПРОКЛАДКА ТЕРМОСТАТА] teamcadillac.ru 11519973 БОЛТ-HFH, M6X1X60, 18MM THD, 14.2 OD, 8.8, 3359GMW, REDUCED BODY, MAT PT. (ENG COOL THERM HSG) (*KIT1) [БОЛТ 6Х1Х60] 11519974 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3359 (ENG COOL THERM HSG) (*KIT1) [БОЛТ] 12584325 SEAL, ENG COOL THERM HSG (O RING) (*KIT1) [КОЛЬЦЕ-ОБРАЗНОЕ УПЛОТНЕНИЕ] 12582472 SEAL, ENG COOL THERM (*KIT1) (ACDelco #12582472) [УПЛОТНИТЕЛЬ] 12566429 SEAL, WAT OTLT (ЧАСТЬ OF 380) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12584040 SEAL, CLNT OTLT (O RING) (ЧАСТЬ OF 380) (ACDelco #15-32584) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519974 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 380) [БОЛТ] 12573984 OUTLET, WAT (INCLS 377-379, 905) (INCLS БОЛТS, RETAINERS, SEALS & PIPE) (ACDelco #15-10429) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 12608424 SENSOR, CM/SHF POSN (INCLS 726, 727) (ЧАСТЬ OF 350) (ACDelco #12608424) [ДАТЧИК ПОЛОЖЕНИЯ РАСПРЕДВАЛА] 11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (ЧАСТЬ OF 350, 725) [БОЛТ] 12576969 VALVE, CM/SHF POSN ACTR SOL 12615613 VALVE, CM/SHF POSN ACTR SOL 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (CM/SHF POSN ACTR SOL VLV) 12593717 SEAL, CM/SHF POSN ACTR SOL VLV (O RING) (ЧАСТЬ OF 350) 12620259 ШЛАНГИ, ENG COOL THERM (INCLS 365-368, 370-373) (INCLS THERMOSTAT) [КОРПУС В СБОРЕ, ТЕРМОСТАТА СИСТЕМЫ ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ] (GM00-396) - 2007-2009 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 2 ГОЛОВКА ЦИЛИНДРОВ & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7) ↓ 12570326 PIN, CYL HD LOC [ЗАГЛУШКА БЛОКА ЦИЛИНДРОВ] 12606653 ACTUATOR, CM/SHF POSN (USE WASHER 12630941) 12603744 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) 12603745 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) 11588279 БОЛТ, HFH, M10X1.5X80, 26 THD, 22.3 O.D., 10.9, GM4277M (CM/SHF POSN) 12626055 COVER, CM/SHF (INCLS 251, 254-257, 260, 263) [КЛАПАННАЯ КРЫШКА ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12595106 SEAL, CM/SHF CVR (ЧАСТЬ OF 250) (*KIT1) (ACDelco #12595106) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12626054 COVER, CM/SHF (INCLS 253-257, 261) [КРЫШКА] 12595107 SEAL, CM/SHF CVR (ЧАСТЬ OF 252) (*KIT1) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12607600 SEAL, SPLG SHLD (ЧАСТЬ OF 250, 252) (*KIT1) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО СИСТЕМЫ ЗАЖИГАНИЯ] 11518859 БОЛТ, HFH W/SHLDR, M6X1X35, 11.85 THD, 18 O.D., 8.8, GMW3359 (ЧАСТЬ OF 250, 252) 12595122 INSULATOR, CM/SHF CVR БОЛТ (ЧАСТЬ OF 250, 252) 12593356 CAP, OIL FIL (INCLS 904) (ACDelco #FC221) [КРЫШКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ] 12593348 SEAL, OIL FIL TUBE (O RING) (ЧАСТЬ OF 262) (27.94MM I.D.) (SIZE #320) (1.758) [ПРОКЛАДКА] 12578316 FITTING, PCV (ЧАСТЬ OF 250) (INCLS 263) 12583384 FITTING, PCV (ЧАСТЬ OF 252) 12597946 TUBE, OIL FIL (INCLS 259) [ТРУБКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ ГОЛОВКИ БЛОКА] 12616908 SEAL, PCV HOSE FTG (O RING) (ЧАСТЬ OF 250, 260) (BLUE) (LARGER OF THE TWO ON THE FITTING) [УПЛОТНЕНИЕ] 12616909 SEAL, PCV HOSE FTG (O RING) (ЧАСТЬ OF 250, 260) (BLACK) (SMALLER OF THE TWO ON THE FITTING) [УЛОТНЕНИЕ] 12601744 INSULATOR, CM/SHF HSG CVR (0.413) 12601745 INSULATOR, CM/SHF HSG CVR [НАКЛАДКА КЛАПАННОЙ КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12603904 HEAD, CYL (MCHG) (INCLS 313, 318, 319, 328, 336, 337) (DOES NOT INCL ENG OIL MANIF CHECK VALVES. DLR MUST INSTL) 12603901 HEAD, CYL (MCHG) (INCLS 313, 318, 319, 328, 336, 337) (DOES NOT INCL ENG OIL MANIF CHECK VALVES. DLR MUST INSTL) 11518863 БОЛТ, CYL HD (M11X2X152) [БОЛТ] 11588734 БОЛТ, HFH, M8X1.25X90, 21.6 THD, 18 O.D., 8.8, GMW3359 (CYL HD) [ВИНТ] 12565988 PLUG - M20X1.5X30.5, 8.8, GMW3044, SEALANT PER GM9985490 (ЧАСТЬ OF 300, 301) 11562127 PLUG, CYL HD OIL GAL (ЧАСТЬ OF 300, 301) (CUP-14.22 OD, 6.6 THK, 304SS) 12575354 VALVE, EXH (STD) [КЛАПАН ВЫПУСКНОЙ] 12584760 VALVE, EXH (0.075 O.S.) [КЛАПАН ВЫПУСКНОЙ] 12575351 VALVE, INT (STD) [КЛАПАН ВПУСКНОЙ] 12584763 VALVE, INT (0.075MM O.S.) (0.297) [КЛАПАН ВПУСКНОЙ] 24100294 ARM, VLV RKR [РЫЧАГ] 24100005 ADJUSTER, HYD VLV LASH (ACDelco #24100005) [ТОЛКАТЕЛЬ КЛАПАНА ДВИГАТЕЛЯ] 12565836 SEAL, VLV STEM OIL [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КЛАПАНА ДВИГАТЕЛЯ] 12575355 ПРУЖИНА, VLV [ПРУЖИНА КЛАПАНА] 12575196 RETAINER, VLV SPR [КОМПАКТ ДИСК] teamcadillac.ru 12575197 KEY, VLV STEM [КЛАПАННЫЙ КЛЮЧ] 12574477 RING, CM/SHF SPKT OIL SEAL (ЧАСТЬ OF 330-333) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО РАСПРЕДВАЛА ДВИГАТЕЛЯ (2 ШТ.)] 12625987 CAMSHAFT, EXH (INCLS 329) 12632192 CAMSHAFT, EXH (INCLS 329) 12625986 CAMSHAFT, INT (INCLS 329) 12632193 CAMSHAFT, INT (INCLS 329) 12625990 CAMSHAFT, EXH (INCLS 329) 12632194 CAMSHAFT, EXH (INCLS 329) 12625989 CAMSHAFT, INT (INCLS 329) 12632195 CAMSHAFT, INT (INCLS 329) 11518856 HFH, M6X1X43.4, 14.8 THD, 11 O.D., 8.8, GMW3179 CODE G (ЧАСТЬ OF 300, 301) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12613057 РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ, IGN (INCLS 705) (ACDelco #12613057) 11588715 БОЛТ, HFH, M6X1X35, 18 THD, 14.2 OD, 8.8, GMW3359, 5MM M POINT (ЧАСТЬ OF 704) [БОЛТ] 12566778 SENSOR, ENG COOL TEMP (3.682) (ACDelco #213-1581) [СЕНСОР ТЕМПЕРАТУРЫ] 12597464 СВЕЧИ, (DO NOT CHANGE СВЕЧИ GAP) (ACDelco #41-990) (PLATINUM PLUG) [СВЕЧА ЗАЖИГАНИЯ] 12580965 VALVE, ENG OIL MANIF CHK [КЛАПАН] 12593348 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 258) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА] 12625781 GASKET KIT, CYL HD (INCLS 251, 253, 254, 302, 303) (INCLS UPR & LWR INT MANIF GASKETS) [КОМПЛЕКТ ПРОКЛАДОК ВПУСКНОГО КОЛЛЕКТОРА (2ШТ)] (GM00-550) - 2007-2009 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 6 ЦЕПЬ И НАТЯЖИТЕЛЬ (LY7/3.6-7) ↓ 12599721 SPROCKET, CR/SHF [ШЕСТЕРНЯ РАСПРЕДВАЛА] 12586959 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (LOWER PRIMARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ГРМ] 12609262 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (INCLS 153, 164) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 152) [БОЛТ М8] 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (TMG CHAIN GDE) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12616609 CHAIN, CM/SHF INTER DRV (PRIMARY) [ЦЕПЬ ПРИВОДА ГРМ] 12597417 GUIDE, TMG CHAIN (INCLS 157) (UPPER PRIMARY) 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 156) [БОЛТ М8] 11588252 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3179 CODE G (ЧАСТЬ OF 165, 166) 12589477 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 152) (PRIMARY) 12612839 SPROCKET, TMG CHAIN IDLER (INCLS 161) (0.736) [ЗВЕЗДОЧКА РАСПРЕДВАЛА] 12612838 SPROCKET, TMG CHAIN IDLER (INCLS 161) (0.736) [ШЕСТЕРНЯ РАСПРЕДВАЛА] 12616608 CHAIN, CM/SHF INTER DRV (SECONDARY) [ЦЕПЬ ПРИВОДА ГРМ] 12600461 GUIDE, TMG CHAIN (INCLS 172) (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ПРИВОДА ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 171) [БОЛТ М8] 12586960 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАТЯЖИТЕЛЬ ЦЕПИ] 11518858 БОЛТ, HFH, M8X1.25X43, 16 THD, 18 O.D., 8.8, GMW3179 (TMG CHAIN TENSR) [БОЛТ М8] 12609260 РОЛИК НАТЯЖИТЕЛЬ, TMG CHAIN (INCLS 176, 177) (SECONDARY) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 175) [БОЛТ М8] 12589478 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 175) teamcadillac.ru 12586961 GUIDE, TMG CHAIN (INCLS 182) (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАПРАВЛЯЮЩАЯ ПРИВОДНОЙ ЦЕПИ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 181) [БОЛТ М8] 12600462 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ПРИВОДА ГРМ] 11518858 БОЛТ, HFH, M8X1.25X43, 16 THD, 18 O.D., 8.8, GMW3179 (TMG CHAIN TENSR) [БОЛТ М8] 12609258 РОЛИК НАТЯЖИТЕЛЬ, TMG CHAIN (INCLS 186, 187) (SECONDARY) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 185) [БОЛТ М8] 12589479 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 185) 12606653 ACTUATOR, CM/SHF POSN (EXH) (USE WASHER 12630941) 12626160 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12632859) (4 SCREWS ON BACKPLATE) 12626161 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12632859) (4 SCREWS ON BACKPLATE) 11588279 БОЛТ, HFH, M10X1.5X80, 26 THD, 22.3 O.D., 10.9, GM4277M (CM/SHF POSN ACTR) 12630941 WASHER, CM/SHF THR (USED ON ACTUATORS 12603744-745, 12606653 & 12630916-918) (**FIELD FIX ONLY, DO NOT CATALOG**) [УПОРНАЯ ШАЙБА РАСПРЕДЕЛИТЕЛЬНОГО ВАЛА ДВС] (GM00-588) - 2009 E КРЕПЛЕНИЕ ДВИГАТЕЛЯ TO ТРАНСМИССИЯ (LH2/4.6A) ↓ 12582606 FLYКОЛЕСО, ENG teamcadillac.ru 25773136 BRACKET, ENG WRG HARN (CHANNEL) 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] 24205900 PLUG, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] 12568123 COVER, TRANS CONV 11589116 БОЛТ, FLYWHL (8.900) 12568122 COVER, FLYWHL HSG 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (TRANS CONV CVR) 00 - 8-МИ ЦИЛИНДРОВЫЙ ДВИГАТЕЛЬ ↓ (6D00-040) - 2007-2009 E ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ-V8 (LH2/4.6A) ↓ 25716470 BRACKET, ENG MT 25762621 BRACKET, ENG MT 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (ENG MT BRKT) [БОЛТ, М10Х1.5Х30] 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT) [ГАЙКА М12] 25971085 MOUNT, ENG [ШАРНИР ДВИГАТЕЛЯ] 25971087 MOUNT, ENG 25971086 MOUNT, ENG [ОПОРНЫЙ УЗЕЛ ДВИГАТЕЛЯ] 25762620 BRACKET, ENG MT 25892303 MOUNT, TRANS RR 25892306 MOUNT, TRANS RR teamcadillac.ru 11589169 БОЛТ ASM - HEX HD W/CONICAL WASHER, M10X1.50X50, GMW25 (10.9) STL, GMW33559 (TRANS RR MT BRKT) 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (TRANS MT) [БОЛТ, М10Х1.5Х30] 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT FRM SI) [ГАЙКА М12] (6E00-005) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ & ЧАСТЬIAL ДВИГАТЕЛЬ (LH2/4.6A) ↓ teamcadillac.ru 19177068 ДВИГАТЕЛЬ, GASOLINE (GOODWRENCH NEW) (FOR 07 STS, SWP OIL FILT ADAPT, ENG OIL CLR FRM ORIG ENG.06 & PREV STS/SRX/XLR SWP МАСЛЯНЫЙ ПОДДОН, ENG OIL CLR IF APPL, WTR OTLT ASM, CAM ACTUATOR FRM ORIG) (ENG.05 & PREV STS/SRX/XLR SWP CAM CVRS & PVC TBE F (6E00-013) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ & ЧАСТЬIAL ДВИГАТЕЛЬ (LY7/3.6-7) ↓ teamcadillac.ru 12617625 ДВИГАТЕЛЬ KIT, GASOLINE (GOODWRENCH) (MUST SWAP OIL FILL TUBE) (6E00-014) - 2004-2009 E КРЕПЛЕНИЕ ДВИГАТЕЛЯ TO ТРАНСМИССИЯ (LY7/3.6-7) ↓ 12572042 PLATE, A/TRNS FLEX 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) teamcadillac.ru 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (TRANS CONV CVR) [БОЛТ] 24222918 COVER, TRANS CONV 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] (6E00-015) - 2004-2009 E ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ-V6 (LY7/3.6-7, M82) ↓ 25892303 MOUNT, TRANS RR 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (TRANS MT) [БОЛТ, М10Х1.5Х30] 11517383 БОЛТ, HEX W/CON SPR WASH, M10X1.5X55, 28 OD, 37 THD, 10.9, 7114M (TRANS RR MT BRKT) 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT) [ГАЙКА М12] 25756321 BRACKET, ENG MT 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (ENG MT BRKT) [БОЛТ, М10Х1.5Х30] 25971088 MOUNT, ENG [ОПОРНЫЙ УЗЕЛ ДВИГАТЕЛЯ] teamcadillac.ru 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT FRM SI) [ГАЙКА М12] 25971089 MOUNT, ENG 25756322 BRACKET, ENG MT (6E00-016) - 2004-2009 E ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ-V6 (LY7/3.6-7, MX5) ↓ 25892306 MOUNT, TRANS RR 11515775 БОЛТ, HFH, M12X1.75X30, 10.9, 7114M (TRANS MT) [БОЛТ] 11517383 БОЛТ, HEX W/CON SPR WASH, M10X1.5X55, 28 OD, 37 THD, 10.9, 7114M (TRANS RR MT BRKT) 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT) [ГАЙКА М12] teamcadillac.ru 25756321 BRACKET, ENG MT 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (ENG MT BRKT) [БОЛТ, М10Х1.5Х30] 25971088 MOUNT, ENG [ОПОРНЫЙ УЗЕЛ ДВИГАТЕЛЯ] 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT FRM SI) [ГАЙКА М12] 25971085 MOUNT, ENG [ШАРНИР ДВИГАТЕЛЯ] 25756320 BRACKET, ENG MT (6E00-017) - 2007-2009 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 3 ПЕРЕДНЯЯ КРЫШКА И ОХЛАЖДЕНИЕ (LH2/4.6A) ↓ 03525915 PIN, ENG FRT CVR LOC (DOWEL, 5.99X17.25, CHAM BOTH ENDS, 10.9) 89017798 COVER, ENG FRT (INCLS 353) 12593627 GASKET, ENG FRT CVR [ПРОКЛАДКА ПЕРЕДНЕЙ КРЫШКИ ДВИГАТЕЛЯ] 11519038 БОЛТ-HFH, M6X1X30, 24 THD, 13.2 OD, 10.9, GMW3359, W/ADHESIVE ON THREADS (ENG FRT CVR) [БОЛТ М6] 12569545 PLUG, ENG FRT CVR HOLE 12595614 PUMP, WAT (INCLS 901) (ACDelco #251-699) [НАСОС ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519038 БОЛТ-HFH, M6X1X30, 24 THD, 13.2 OD, 10.9, GMW3359, W/ADHESIVE ON THREADS (W/PMP) [БОЛТ М6] 12604614 PULLEY, W/PMP 24503961 БОЛТ, W/PMP PUL (M6X1.0 6G THD W/WA) (8MM SOCKET HD) 12559807 THERMOSTAT, ENG COOL (W/O GSKT) (ACDelco #131-128) [КЛАПАН РЕГУЛИРОВКИ ТЕМПЕРАТУРЫ СИСТЕМЫ ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ] 12563623 GASKET, ENG COOL THERM (ACDelco #12563623) [ПРОКЛАДКА] 12596643 ШЛАНГИ, ENG COOL THERM (ACDelco #15-80869) 11519038 БОЛТ-HFH, M6X1X30, 24 THD, 13.2 OD, 10.9, GMW3359, W/ADHESIVE ON THREADS (ENG COOL THERM HSG) [БОЛТ М6] 12590694 OUTLET, WAT (INCLS 387) (ACDelco #15-10649) 12590862 GASKET, WAT OTLT [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (WAT OTLT) 12566109 HOSE, RAD BYPASS 15024902 CЛАМПА, HOSE ПРУЖИНА, 42MM - NOM SIZE, BLK (RAD BYPASS HOSE) 11519172 БОЛТ, HFH, 8X1.25X55, 18 OD, 22THD, 8.8, GMW3359, 6MM MATPOINT, REDUCED BODY (WAT OTLT) 12580250 DUCT, LWR INT MANIF (INCLS 526) teamcadillac.ru 09359409 SENSOR, MAP (INCLS SEAL) (INCLS 741) (ACDelco #9359409) 16194007 SEAL, MAP SEN (ЧАСТЬ OF 740) [УПЛОТНИТЕЛЬ ДАТЧИКА ДАВЛЕНИЯ ПОТОКА ВОЗДУХА] 12587812 BRACKET, MAP SEN 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (MAP SEN) [БОЛТ] 12608378 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 745) (ACDelco #214-2125) 11519941 БОЛТ, HFH W/SHLDR, M6X1X22, 13.8 THD, 15 OD, 9.8, 6280M, MACH, DOG-PT (SOL VLV) 12563877 SEAL, W/PMP CVR (O RING) (ЧАСТЬ OF 360) [КОЛЬЦЕВОЕ УПЛОТНЕНИЕ ВОДЯННОГО НАСОСА] (6E00-022) - 2009 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 5 КОЛЛЕКТОР & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7) ↓ 12604932 TUBE, PCV (INCLS 292) (FRESH AIR) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (PCV TUBE) teamcadillac.ru 12616910 HOSE, PCV (INCLS 285, 286, 290, 291, 293) (DIRTY AIR) 12616908 SEAL, PCV HOSE FTG (O RING) (ЧАСТЬ OF 283) (BLUE) (LARGER OF THE TWO ON THE FITTING) [УПЛОТНЕНИЕ] 12616909 SEAL, PCV HOSE FTG (O RING) (ЧАСТЬ OF 283) (BLACK) (SMALLER OF THE TWO ON THE FITTING) [УЛОТНЕНИЕ] 12597853 MANIFOLD, UPR INT (MACH) (INCLS 506) 12571079 MANIFOLD, LWR INT (INCLS 519) 11518906 БОЛТ, HFH, RDUCD BDY, M8X1.25X165, 22 THD, 18 O.D., 8.8, GMW3359 (INT UPR MANIF) [БОЛТ] 11519176 БОЛТ, INT MANIF (M8X1.25X80) (4.081) [БОЛТ] 12595277 GASKET KIT, UPR INT MANIF [ПРОКЛАДКА] 12598158 GASKET KIT, INT MANIF [ПРОКЛАДКА ДВИГАТЕЛЯ] 11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (LWR INT MANIF) 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (F/INJN FUEL RL) [БОЛТ] 11609319 STUD, UPR INT MANIF SIGHT SHLD (3.671) 12576262 GASKET, EXH MANIF [ПРОКЛАДКА ВЫПУСКНОГО КОЛЛЕКТОРА] 12571102 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 12580706 SHIELD, EXH MANIF HT 24505098 БОЛТ, HFH, RND HD, 6X1X12.15, W/ANTI SEIZE, 14.2 O.D.DG PT, 10.9, 711 (EXH MANIF H/SHLD) 12582663 INSULATOR, EXH MANIF UPR 12616647 SHIELD, STRTR HT 12608475 GASKET, EXH MANIF 12571101 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 11518860 БОЛТ, HFH, M8X1.25X30, 20.9 THD, 18 O.D., 10.9, GMW3179 CODE G, GM6194M (EXH MANIF H/SHLD) [БОЛТ] 12617267 SHIELD, EXH MANIF HT 24505098 БОЛТ, HFH, RND HD, 6X1X12.15, W/ANTI SEIZE, 14.2 O.D.DG PT, 10.9, 711 (EXH MANIF H/SHLD) 12581807 INSULATOR, EXH MANIF LWR 14093869 ГАЙКА, PUSH ON, M6, 2.25THK, 12.95 O.D., STL, POR (EXH MANIF H/SHLD INSL) 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (EXH MANIF H/SHLD) [БОЛТ] 12616994 BODY, THROT (W/THROT ACTR) (ACDelco #217-3103) [ЧАСТЬ КОРПУСА] 11519972 БОЛТ, THROT BODY (M6X1.0X50) 12593360 GASKET, THROT BODY (ACDelco #40-5083) [ПРОКЛАДКА ДРОССЕЛЬНОЙ ЗАСЛОНКИ] 12611801 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 752) (ACDelco #214-1685) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (EVAP EMIS CNSTR PURGE SOL VLV BRKT) 12584171 HOSE, EVAP EMIS CNSTR SOL VLV 12629734 VALVE, INT MANIF TUNING (INCLS 756) 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (INT MANIF TUNING VLV) [БОЛТ] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (WRG HARN BRKT) 24574534 STUD, ENG WRG HARN BRKT (M6X1X20) (1.166) (6E00-023) - 2009 E INTAKE MANIFOLD SHIELD/COVERS (LY7/3.6-7) ↓ 12583604 SHIELD, UPR INT MANIF SIGHT (INCLS 2, 5, 17) [ЗАЩИТА] teamcadillac.ru 12593356 CAP, OIL FIL (INCLS 4) (ЧАСТЬ OF 7) (ACDelco #FC221) [КРЫШКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ] 12593348 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 3, 7) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА] 12606862 GROMMET, UPR INT MANIF SIGHT SHLD (ЧАСТЬ OF 1) (32MM OD) 11609319 STUD, UPR INT MANIF SIGHT SHLD (3.671) 12597946 TUBE, OIL FIL (INCLS 3, 4, 8) [ТРУБКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ ГОЛОВКИ БЛОКА] 12593348 SEAL, OIL FIL TUBE (O RING) (ЧАСТЬ OF 7) (27.94MM I.D.) (SIZE #320) (1.758) [ПРОКЛАДКА] 12604673 BRACE, INT MANIF 11588723 БОЛТ, HFH, M8X1.25X25, 18 THD, 18 OD, 8.8 STL, GMW3359, M-PT (INT MANIF BR) 11518712 БОЛТ-HEX W/CON WA, M12X1.75X59, 53.6 THD, 24OD, 10.9, 7114M, MACH, 6175M, HDR (INT MANIF SIGHT SHLD) 11516075 ГАЙКА, HFH SELF LK, M6X1, 7.7THK, 14.2 O.D., 9, PZOR (ЧАСТЬ OF 14) [ГАЙКА ВЫПУСКНОЙ СИСТЕМЫ D=6ММ] 12616618 BRACKET, INT MANIF SIGHT SHLD (INCLS 13, 16) 11588967 STUD, BALL W/HFH, M6X1X20.65, 14.2 O.D., 8.8, GMW3359 (INT MANIF BR) (6M00-029) - 2006-2009 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 1 БЛОК ЦИЛИНДРОВ & ВНУТРЕННИЕ ДЕТАЛИ (LH2/4.6A) ↓ teamcadillac.ru 12573430 SEAL, LWR C/CASE (4.3MM WIDE X 5MM TALL) [ПРОКЛАДКА] 11610074 БОЛТ-HFH, M8X1.25X45, 21 THD, 16 OD, 10.9 STL, GMW3359 (LWR C/CASE) 03522376 БОЛТ, HFH, M6X1X23, 18 THD, 14.50 OD, 7T, ZP (ENG OIL MANIF) 03542310 БОЛТ, LWR C/CASE (M10X1.5X125, 30 THD) (8.900) 03542311 STUD, LWR C/CASE (M10X1.5X125-M9X1.0X13) (1.428) 03530355 PIN, LWR C/CASE LOC (M8X20) 12582395 CRANKSHAFT, (MCHG) 12585420 PIN, CR/SHF SPKT LOC 89017562 BEARING KIT, CR/SHF (INCLS 123) (STD) (POSN # 1, 2, 4, 5) [ПОДШИПНИК] 89017563 BEARING KIT, CR/SHF (INCLS 900) (STD) (POSN # 3) [ПОДШИПНИК] 12568025 SEAL, CR/SHF RR OIL [ПРОКЛАДКА] 12338076 PIN, TRANSAXLE LOC (19.5 MM X 18.5 MM) (TO CYL BLK) 03525915 PIN, ENG FRT CVR LOC (DOWEL, 5.99X17.25, CHAM BOTH ENDS, 10.9) 24503702 PLUG, ENG BLK COOL HOLE (8X1.25X12, 10.5 THD W/6MM OF 6124M ADHES, 17.6 OD, 9.8, PC) 03522422 PLUG, CM/SHF (CUP, W/LIP, 50.24X6.12X1.52, 52.58 OD, 1008, OIL) 12582606 FLYКОЛЕСО, ENG 11589116 БОЛТ, FLYWHL (8.900) 12568122 COVER, FLYWHL HSG 12570154 SPROCKET, CR/SHF 12581223 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (PRIMARY) 01647264 БОЛТ, TMG CHAIN TENSR (HFH, 8X1.25X42, 22 THD, 17.0 OD, 9.8, PC, MACH) 12564274 CHAIN, CM/SHF INTER DRV 12559388 GUIDE KIT, TMG CHAIN (PRIMARY CHAIN) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 12577433 SPROCKET, CM/SHF INTER DRV SHF 01647272 БОЛТ, CM/SHF SPKT 12577790 SHAFT, CM/SHF INTER DRV 15685550 БОЛТ, CM/SHF INTER DRV SHF RET (M6X1X20) (16.330) [ВИНТ] 12556023 GUIDE, TMG CHAIN (SECONDARY CHAIN GUIDE) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 12556030 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (SECONDARY ON LH BANK) [НАТЯЖИТЕЛЬ РЕМНЯ] 01647264 БОЛТ, TMG CHAIN TENSR (HFH, 8X1.25X42, 22 THD, 17.0 OD, 9.8, PC, MACH) 12556023 GUIDE, TMG CHAIN (SECONDARY CHAIN GUIDE) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 12581281 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (SECONDARY ON RH BANK) 01647264 БОЛТ, TMG CHAIN TENSR (HFH, 8X1.25X42, 22 THD, 17.0 OD, 9.8, PC, MACH) 12567469 ROD, CONN (INCLS 201) (USES 23MM PIN) 12552947 БОЛТ, CONN ROD (ЧАСТЬ OF 200) (MJ9X1.0-4H6HX61.9 LONG) [БОЛТ] 89017430 PISTON, (W/PIN) (INCLS 211, 212) 12584576 BALANCER, CR/SHF [ШКИВ КОЛЕНВАЛА] 11569873 БОЛТ, CR/SHF BALR (M14X1.5X48.4) 12577394 BAFFLE, МАСЛЯНЫЙ ПОДДОН (B/W CRANK CASE AND PAN) 12580429 SENSOR, CR/SHF POSN (INCLS 721) (ACDelco #213-3515) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (CR/SHF POSN SEN) 12570125 SENSOR, KNOCK (ACDelco #213-1576) 89017760 STARTER, (REMAN) (ACDelco #323-1633) (DELCO SERIES PG260H) [СТАРТЕР] 11515793 БОЛТ, HFH (STRTR) 12603426 HARNESS, CR/SHF POS SEN & KNOCK SEN WRG (INCLS 797) 12559363 BEARING KIT, CONN ROD (STD) (INCLS 203, 204) [КОМПЛЕКТ ПОДШИПНИКОВ СКОЛЬЖЕНИЯ ШАТУНА (2ШТ)] 89017413 RING KIT, PSTN (INCLS 213-216) (6M00-043) - 2008-2009 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 5 КОЛЛЕКТОР & FUEL ДЕТАЛИ КОМПЛЕКТА (LH2/4.6A) ↓ 12604755 TUBE, PCV (INCLS 900, 901) (FRESH AIR TUBE) 12587817 TUBE, PCV (DIRTY AIR TUBE) 12590694 OUTLET, WAT (INCLS 387) (ACDelco #15-10649) teamcadillac.ru 12590862 GASKET, WAT OTLT [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (WAT OTLT) 12566109 HOSE, RAD BYPASS 15024902 CЛАМПА, HOSE ПРУЖИНА, 42MM - NOM SIZE, BLK (RAD BYPASS HOSE) 11519172 БОЛТ, HFH, 8X1.25X55, 18 OD, 22THD, 8.8, GMW3359, 6MM MATPOINT, REDUCED BODY (WAT OTLT) 12588847 MANIFOLD, INT (INCLS 501, 520, 903) 12571222 FITTING, P/B BOOS VAC TUBE 12579192 COVER, INT MANIF 12579193 COVER, INT MANIF 11588967 STUD, BALL W/HFH, M6X1X20.65, 14.2 O.D., 8.8, GMW3359 (IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ) 12588809 SEAL, UPR INT MANIF (ЧАСТЬ OF 500) [УПЛОТНИТЕЛЬ ВЫПУСКНОГО КОЛЛЕКТОРА] 12580250 DUCT, LWR INT MANIF (INCLS 526) 11588352 БОЛТ, INT MANIF (W/SPCR) 12557010 STUD, F/INJN FUEL RL (HEX, M6X1.022-M6X1.016, 45MM TOTAL LENGTH) (3.275) 12571212 SHIELD, UPR INT MANIF SIGHT (INCLS 595, 596) [ЗАЩИТНЫЙ КОЖУХ ДВИГАТЕЛЯ] 12600206 BRACKET, UPR INT MANIF SIGHT SHLD (INCLS 904) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (UPR INT MANIF SIGHT SHLD) 12567370 STUD, UPR INT MANIF SIGHT SHLD (3.265) 12567371 GROMMET, UPR INT MANIF SIGHT SHLD (ЧАСТЬ OF 590) [ВТУЛКА] 12607451 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 626, 906) (3.685) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 12607338 SHIELD, EXH MANIF HT 24505098 БОЛТ, HFH, RND HD, 6X1X12.15, W/ANTI SEIZE, 14.2 O.D.DG PT, 10.9, 711 (EXH MANIF H/SHLD) 12607450 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 626, 635, 636, 906) (3.685) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 11517031 ГАЙКА, HFH, M8X1.25, 9.4THK, 17.4 O.D., 10, TIN ZN (EXH MANIF) 11519171 БОЛТ, EXH MANIF CLA (M8X1.25X50) (3.275) [БОЛТ ВЫПУСКНОГО КОЛЛЕКТОРА] 11562490 STUD, STRAIGHT, M8X1.25X20, M8X1.25X40, 69 TL, 9.8, GMW3179, EXT HEX SOCKET (EXH MANIF) [ШПИЛЬКА М8] 11609596 STUD, CTLTC CONV (ЧАСТЬ OF 600, 620) [ШПИЛЬКА] 12576372 SHIELD, EXH MANIF HT 24505098 БОЛТ, HFH, RND HD, 6X1X12.15, W/ANTI SEIZE, 14.2 O.D.DG PT, 10.9, 711 (EXH MANIF H/SHLD) 12568289 SHIELD, EXH MANIF LWR HT (ЧАСТЬ OF 620) 10229247 RIVET, EXH MANIF H/SHLD (ЧАСТЬ OF 620) (3.601) 12615495 BODY, THROT (W/THROT ACTR) (INCLS 702) (ACDelco #217-3156) 11519973 БОЛТ-HFH, M6X1X60, 18MM THD, 14.2 OD, 8.8, 3359GMW, REDUCED BODY, MAT PT. (ЧАСТЬ OF 701) [БОЛТ 6Х1Х60] 12576549 GASKET, THROT BODY (ACDelco #217-1618) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ДРОССЕЛЬНОЙ ЗАСЛОНКИ] 09359409 SENSOR, MAP (INCLS SEAL) (INCLS 741) (ACDelco #9359409) 16194007 SEAL, MAP SEN (ЧАСТЬ OF 740) [УПЛОТНИТЕЛЬ ДАТЧИКА ДАВЛЕНИЯ ПОТОКА ВОЗДУХА] 12587812 BRACKET, MAP SEN 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (MAP SEN) [БОЛТ] 12608378 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 745) (ACDelco #214-2125) 11519941 БОЛТ, HFH W/SHLDR, M6X1X22, 13.8 THD, 15 OD, 9.8, 6280M, MACH, DOG-PT (EVAP EMIS CNSTR PURGE SOL) 12567655 GASKET, EXH MANIF [ПРОКЛАДКА] 12613200 FITTING, PCV HOSE (ЧАСТЬ OF 281) 12571223 PLUG, P/B VAC SCE HOLE (ЧАСТЬ OF 500) (16.0 MM) 19167509 INSULATOR, UPR INT MANIF CVR (ЧАСТЬ OF 591) (3.405) 12607145 SENSOR, HTD OXY (POSN 1) (IN EXH MANIFOLD/CROSSOVER) (ACDelco #213-4116) [КИСЛОРОДНЫЙ ДАТЧИК] 25709703 SEAL, CTLTC CONV (ЧАСТЬ OF 600, 620) (ROUND METAL SEAL) [ПРОКЛАДКА НАСОСА] (6M00-071) - 2007-2009 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 4 МАСЛЯНЫЙ НАСОС, PAN & ДЕТАЛИ КОМПЛЕКТА (LH2/4.6A) ↓ 12580850 MANIFOLD, ENG OIL (INCLS 107-109) (WITHOUT МАСЛЯНЫЙ ПОДДОН BAFFLE) [КОЛЛЕКТОР МАСЛЯНЫЙ] 03522376 БОЛТ, HFH, M6X1X23, 18 THD, 14.50 OD, 7T, ZP (ENG OIL MANIF) 03542310 БОЛТ, LWR C/CASE (M10X1.5X125, 30 THD) (8.900) 03542311 STUD, LWR C/CASE (M10X1.5X125-M9X1.0X13) (1.428) 12612258 PAN, OIL (INCLS 401, 412, 413, 420-422) 12568928 GASKET, МАСЛЯНЫЙ ПОДДОН (ЧАСТЬ OF 400) [ПРОКЛАДКА] 12567529 PIPE, O/PMP SUC (INCLS 406, 407) 12573569 GASKET, O/PMP SUC PIPE (ЧАСТЬ OF 405) [ПРОКЛАДКА МАСЛЯНОГО НАСОСА] 03522382 БОЛТ, O/PMP SUC PIPE (ЧАСТЬ OF 405) (HFH, M6X1.0X28) 03542258 ГАЙКА, O/PMP SUC PIPE (HFH, M9X1) (1.430) 12577394 BAFFLE, МАСЛЯНЫЙ ПОДДОН (B/W CRANK CASE AND PAN) 11562588 PLUG, МАСЛЯНЫЙ ПОДДОН DRN (ЧАСТЬ OF 400) (INCLS 413) (W/ SEAL) (EXC MAGNET) [ЗАГЛУШКА МАСЛЯНОГО ПОДДОНА] 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 400) 11519173 БОЛТ, HFH, REDUCED BODY, M8X1.25X60, 22THD, 18 OD, 8.8, GMW3359 (ЧАСТЬ OF 400) 11519178 БОЛТ HFH, M8X1.25X100, 13MM SOCKET, 8.8, GMW3359 (ЧАСТЬ OF 400) 12585398 INDICATOR, OIL LVL (INCLS 434) [ЩУП УРОВНЯ МАСЛА] 12570585 TUBE, OIL LVL IND (INCLS 432) [НАПРАВЛЯЮЩАЯ ТРУБКА ЩУПА УРОВНЯ МАСЛА] 24504091 SEAL, OIL LVL IND TUBE (O RING) (ЧАСТЬ OF 431) (BLACK) (6.07MM ID, 1.78MM DIA) 11515765 БОЛТ, HFH, M10X1.5X25, 22.30 O.D., HDR PT, 10.9, 7112M (OIL LVL IND TUBE) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) 12598047 ADAPTER, OIL FLTR (INCLS 441, 442, 445, 446, 449, 717, 718, 728, 729) 12573045 GASKET, OIL FLTR ADAP (ЧАСТЬ OF 440) [ПРОКЛАДКА МАСЛЯНОГО ФИЛЬТРА] 11519173 БОЛТ, HFH, REDUCED BODY, M8X1.25X60, 22THD, 18 OD, 8.8, GMW3359 (ЧАСТЬ OF 440) 24575062 FITTING, OIL FLTR (ЧАСТЬ OF 440) 25014612 VALVE, OIL FLTR BYPASS (ЧАСТЬ OF 440) (W/O VAPOR SEPARATOR) (OPENING PRESSURE 21 PSI NOMINAL) (ЧАСТЬ HAS A 16.10MM MAX OD & FITS A 15.84 HOLE IN BLOCK) 89017342 ФИЛЬТР, МАСЛЯНЫЙ (ЧАСТЬ OF 440) (FOR NON-CANADIAN ORDERS) (ACDelco #89017342) 11519833 PLUG ROUND HD, M16X1.5X22, 20 OD, 10 THD, 5.8, 4345M, SEALANT 9985490, MACH (OIL FLTR BYPASS HOLE) 12590890 PUMP, OIL (INCLS 464-472) [МАСЛЯНЫЙ НАСОС] 11518944 SCREW, PAN HD, M6X1X25, 20.9 THD, 11 OD, 8.8, GMW3359, 6 LOBED T-30 M-POINT (ЧАСТЬ OF 463) (8.913) teamcadillac.ru 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (O/PMP) (ACDelco #11517518) [БОЛТ] 12568009 TUBE, O/PMP OTLT (INCLS 481) [ТРУБКА] 12568320 SEAT, ENG OIL MANIF CHK VLV (ЧАСТЬ OF 480) (0.724) [КОЛЬЦЕВОЕ УПЛОТНЕНИЕ] 11518944 SCREW, PAN HD, M6X1X25, 20.9 THD, 11 OD, 8.8, GMW3359, 6 LOBED T-30 M-POINT (O/PMP OTLT TUBE) (8.913) 12573744 SHIELD, ENG OIL PRESS GA SEN HT (ЧАСТЬ OF 440) 11519964 БОЛТ, HFH, M6X1X13, 6 THD, 14.2 OD, 8.8, GMW3359, MAT POINT (ЧАСТЬ OF 440) 12567911 SENSOR, ENG OIL PRESS (ЧАСТЬ OF 440) (INCLS 729) (ACDelco #213-1547) [ДАТЧИК ДАВЛЕНИЯ МАСЛА] (6M00-073) - 2006-2009 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 4 МАСЛЯНЫЙ НАСОС,МАСЛЯНЫЙ ПОДДОН & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7) ↓ 22531637 PIN, МАСЛЯНЫЙ ПОДДОН LOC (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 12586959 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (LOWER PRIMARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ГРМ] 12586960 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАТЯЖИТЕЛЬ ЦЕПИ] 12586961 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАПРАВЛЯЮЩАЯ ПРИВОДНОЙ ЦЕПИ] 12597417 GUIDE, TMG CHAIN (UPPER PRIMARY) 12600461 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ПРИВОДА ГРМ] 12600462 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ПРИВОДА ГРМ] 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (ЧАСТЬ OF 463) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12596502 PAN, OIL (INCLS 404-407, 410, 412, 413, 420, 422, 900) 12575373 PIPE, O/PMP SUC (ЧАСТЬ OF 400) 12566837 SEAL, O/PMP SUC PIPE (ЧАСТЬ OF 400) [УПЛОТНЕНИЕ] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 400) 12566872 DEFLECTOR, CR/SHF OIL (ЧАСТЬ OF 400) 11562588 PLUG, МАСЛЯНЫЙ ПОДДОН DRN (ЧАСТЬ OF 400) (INCLS 413) (W/ SEAL) (EXC MAGNET) [ЗАГЛУШКА МАСЛЯНОГО ПОДДОНА] 12616850 SEAL, МАСЛЯНЫЙ ПОДДОН DRN PLUG (O RING) (ЧАСТЬ OF 400, 412) 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (ЧАСТЬ OF 400) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11588424 БОЛТ, HFH, M6X1X145, 18 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 400) [ШЕСТИГРАННЫЙ ВИНТ] 12611594 INDICATOR, OIL LVL (INCLS 434) 12612349 TUBE, OIL LVL IND (INCLS 432) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 431) (BLACK) (6.07MM ID, 1.78MM DIA) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (OIL LVL IND TUBE) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) 12591607 ADAPTER, OIL FLTR (INCLS 441-443, 446-450, 456, 458, 459, 728, 729) [АДАПТЕР МАСЛЯНОГО ФИЛЬТРА] 12591604 GASKET, OIL FLTR (ЧАСТЬ OF 440) (BETWEEN OIL FILTER ADAPTER AND BLOCK) [ПРОКЛАДКА МАСЛЯНОГО ФИЛЬТРА] 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 440) 11519174 БОЛТ, HFH, W/REDUCED BODY, M8X1.25X65, THD 22, O.D. 18, 8.8, GMW3359 (ЧАСТЬ OF 440) 25014612 VALVE, OIL FLTR BYPASS (ЧАСТЬ OF 440, 450) (W/O VAPOR SEPARATOR) (OPENING PRESSURE 21 PSI NOMINAL) (ЧАСТЬ HAS A 16.10MM MAX OD & FITS A 15.84 HOLE IN BLOCK) 11519184 БОЛТ, OIL FLTR ADAP (ЧАСТЬ OF 440) (M10X1.5X45) (0.029) 25177917 ФИЛЬТР, МАСЛЯНЫЙ (ЧАСТЬ OF 440) (ACDelco #PF2129) [МАСЛЯНЫЙ ФИЛЬТР ДВИГАТЕЛЯ] 12583470 CAP, OIL FLTR (ЧАСТЬ OF 440) (INCLS 446, 456) [КРЫШКА] 12577653 SEAL, OIL FLTR CAP (O RING) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КРЫШКИ МАСЛЯНОГО ФИЛЬТРА] 12590152 PUMP, OIL (INCLS 151, 154, 464-466, 468, 470-472, 474, 475) (INCLS GUIDE, БОЛТS) [МАСЛЕННЫЙ НАСОС] teamcadillac.ru 11900371 БОЛТ, HEX HD, W/1.6 FLAT WA, M8X1.25X54.3, 43 THD, 16O.D., 8.8, GMW3359 (ЧАСТЬ OF 463) 12610143 NOZZLE, PSTN OIL (INCLS 491) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 490) 12621649 SENSOR, ENG OIL PRESS (INCLS 729) (ЧАСТЬ OF 440) (ACDelco #D1800C) 11588734 БОЛТ, HFH, M8X1.25X90, 21.6 THD, 18 O.D., 8.8, GMW3359 (ЧАСТЬ OF 400) [ВИНТ] (6Y00-003) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 2 ГОЛОВКА ЦИЛИНДРОВ & ДЕТАЛИ КОМПЛЕКТА (LH2/4.6A) ↓ 03522352 PIN, CYL HD LOC (HOLLOW DOWEL, 15.675X28, CHAM BOTH ENDS, SAE 12L14, ZP) 12564273 CHAIN, SECD TMG 12559389 SHOE KIT, TMG CHAIN TENSR (INCLS 174) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (ЧАСТЬ OF 173) (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 89017766 SHOE KIT, TMG CHAIN TENSR (INCLS 184) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (ЧАСТЬ OF 183) (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 12576969 VALVE, CM/SHF POSN ACTR SOL 12581497 ACTUATOR, CM/SHF POSN (EXH) 12581498 ACTUATOR, CM/SHF POSN (EXH) 12581499 ACTUATOR, CM/SHF POSN (INT) 12581500 ACTUATOR, CM/SHF POSN (INT) 12591268 COVER, CM/SHF (INCLS 251, 254-256, 261, 908, 909) 12591269 COVER, CM/SHF (INCLS 251, 254-256, 261, 908, 909) 12576394 GASKET, CM/SHF CVR (ЧАСТЬ OF 250) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ ЦИЛИНДРОВ] 12576395 GASKET, CM/SHF CVR (ЧАСТЬ OF 250) (BETWEEN HEAD AND CAM COVER) [ПРОКЛАДКА] 12576396 GASKET, CM/SHF CVR (ЧАСТЬ OF 250) (СВЕЧИ HOLES) [ПРОКЛАДКА] 12557829 БОЛТ, CM/SHF CVR (ЧАСТЬ OF 250) 12573742 INSULATOR, CM/SHF CVR БОЛТ (ЧАСТЬ OF 250) 12583570 CAP, OIL FIL (ROUND W/HDL) (INCLS 259) (NON VENTED) (ACDelco #FC215) 12593348 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 258) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА] 12581538 HEAD, CYL (MCHG) (INCLS 312, 313, 315, 334-337) 12581539 HEAD, CYL (MCHG) (INCLS 312, 313, 315, 334-337) 11569957 БОЛТ, CYL HD (M11X2X161, 60 THD) (*KIT1) 01647218 БОЛТ, CYL HD (QTY 3-RH, 3-LH) (M6X1.0X50, 10.9) (HFH, MACH) 11562126 PLUG, CYL HD CORE HOLE (ЧАСТЬ OF 300) (CUP, 32.03X7.88X1.27, S30400 SS PER SAE J405.) [ЗАГЛУШКА ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 01647543 PLUG, CYL HD CORE HOLE (ЧАСТЬ OF 300) (ROUND HEAD, INT HEX, W/ALUM WASH, 20X1.5X17, 12.25 THD, C1010 RQ) 11588949 PLUG, M16X1.5X14, 24 OD, SAE 1010 STL, GMW3044, W/ AL WASHER (ЧАСТЬ OF 300) [ПРОБКА ЗАМКА] 12574785 RESTRICTOR, ENG BLK OIL GAL 12607211 VALVE, EXH 12590223 VALVE, INT 12565203 ARM, VLV RKR [КОРОМЫСЛО КЛАПАНА ДВИГАТЕЛЯ] 24100005 ADJUSTER, HYD VLV LASH (ACDelco #24100005) [ТОЛКАТЕЛЬ КЛАПАНА ДВИГАТЕЛЯ] 12574354 SEAL, VLV STEM OIL [УПЛОТНЕНИЕ ШТОКА КЛАПАНА] 12565199 ПРУЖИНА, VLV 12580385 CAP, VLV SPR 01647209 KEY, VLV STEM 12565171 CAMSHAFT, EXH (MCHG) (INCLS 338) 12565172 CAMSHAFT, EXH (MCHG) (INCLS 338) [РАСПРЕДВАЛ В СБОРЕ] 12563833 CAMSHAFT, INL (MCHG) (INCLS 338) [РАСПРЕДВАЛ] 12565168 CAMSHAFT, INL (MCHG) (INCLS 338) [КОЛЕНВАЛ] 01647553 БОЛТ, CM/SHF BRG CAP (ЧАСТЬ OF 300) (HFH, M6X1.0X39.5) 12596360 ШЛАНГИ, CM/SHF POSN ACTR (INCLS 342, 344, 345, 735-737) 12596361 ШЛАНГИ, CM/SHF POSN ACTR (INCLS 342, 344, 345, 735-737) 12567656 GASKET, CM/SHF POSN ACTR HSG (ЧАСТЬ OF 340) (0.423) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] teamcadillac.ru 12567657 GASKET, CM/SHF POSN ACTR HSG (ЧАСТЬ OF 340) (0.423) [УПЛОТНЕНИЕ ДВИГАТЕЛЯ] 11518706 STUD-HFH, M6X1X13.4, M6X1X40, 14.2 OD, 60 TL, 10.9, GM6280M (NON HEX CHROME) (ЧАСТЬ OF 340) (8.981) 11518707 STUD, HFH, M6X1X13 / M6X1X45, 14.2 O.D., 65 TL, 9.8, GM6280M (CM/SHF POSN ACTR HSG) 11562490 STUD, STRAIGHT, M8X1.25X20, M8X1.25X40, 69 TL, 9.8, GMW3179, EXT HEX SOCKET (EXH MANIF) [ШПИЛЬКА М8] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ) 15326386 SENSOR, ENG COOL TEMP (2-WAY MALE) (3.682) (ACDelco #213-928) [ДАТЧИК ТЕМПЕРАТУРЫ ДВИГАТЕЛЯ] 12571535 СВЕЧИ, (DO NOT CHANGE GAP) (ACDelco #41-987) (PLATINUM PLUG) [СВЕЧА ЗАЖИГАНИЯ] 12593995 SENSOR, CM/SHF POSN (INCLS 726) (ACDelco #213-3517) 01647346 БОЛТ, HFH, M6X1X17, 17THD, 14.2 O.D., 8.8, ZF (CM/SHF POSN SEN) 12567085 MAGNET, CM/SHF POSN ACTR (INCLS 737) (ЧАСТЬ OF 340) [МАГНИТ] 11518845 SCREW PAN HD, M6X1X16, 15 THD, 12 OD, 8.8, 6280M, TORX, T30, HDR PT, W/SEALANT (ЧАСТЬ OF 340) 12567421 PLUG, CM/SHF POSN ACTR BORE (ЧАСТЬ OF 340, 735) 12581176 HARNESS, ELEK ICM WRG (INCLS 772) 11519976 БОЛТ, HFLGE, M8X1.25X20, 15.6 THD, 18 O.D., 8.8, GMW3359 (ELEK ICM WRG HARN CLIP) 11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (ЧАСТЬ OF 770) [БОЛТ М8] 11517094 SCREW, M5X.8X15.6, 10.4 THD, 10.2 OD, 6202M, 7114M, TAPER-POINT (ЧАСТЬ OF 250) (ACDelco #11517094) 89017450 GASKET KIT, CYL HD (INCLS 302, 310) (INCL GASKET AND M11X2.0 БОЛТS) [ПРОКЛАДКА ДВИГАТЕЛЯ] 89017451 GASKET KIT, CYL HD (INCLS 302, 310) (INCL GASKET AND M11X2.0 БОЛТS) [ПРОКЛАДКА ДВИГАТЕЛЯ] (GM00-387) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 1 БЛОК ЦИЛИНДРОВ И ВНУТРЕННИЕ ДЕТАЛИ (LY7/3.6-7) ↓ teamcadillac.ru 12560272 БОЛТ, CR/SHF BRG CAP (M10X2X102.5, 24.5) [ВИНТ] 11518861 БОЛТ, HFH, W/REDCD BODY, M8X1.25X90, 26 THD, 18 O.D., 10.9, GM4277M (CR/SHF BRG CAP) [БОЛТ] 11609410 БОЛТ, HFH, M8X1.25X25, 10.9, GMW3179 (CR/SHF BRG CAP) (0.056) [БОЛТ] 89021297 ADHESIVE/SEALANT, THREADLOCKER HI STRENGTH 10ML ERI (CR/SHF BRG CAP) [АДГЕЗИВ] 11589000 БОЛТ, HFH, M8X1.25X50, 24 THD, 18 OD, 10.9, GMW3359, RED BODY, W/ADH (CR/SHF BRG CAP) 12557520 PLUG, ENG BLK OIL GAL (CUP-.390IN OD, .040IN THK, STEEL) 12621351 CRANKSHAFT, [КОЛЕНВАЛ] 11561583 PLUG, ENG BLK OIL GAL (M14X1.5X16, 22 OD) (0.253) 12566587 PLUG, ENG BLK OIL GAL 11561751 PLUG, CYL HD WAT JKT HOLE (M20X1.5X30.5) (1.531) 11569584 PLUG, ENG BLK CORE HOLE (CUP DIA 34.4MM) 12597210 PIN, TRANS LOC 12620955 SEAL, CR/SHF RR OIL (INCLS 134) [ПРОКЛАДКА КОЛЕНВАЛА ДВИГАТЕЛЯ] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 133) 22531637 PIN, МАСЛЯНЫЙ ПОДДОН LOC (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 12570326 PIN, CYL HD LOC [ЗАГЛУШКА БЛОКА ЦИЛИНДРОВ] 12572042 PLATE, A/TRNS FLEX 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12608432 ROD, CONN (INCLS 201, 202) 11519680 БОЛТ, CONN ROD (ЧАСТЬ OF 200) (M9X1X53) [БОЛТ] 12598657 BEARING KIT, CONN ROD (UPPER) [ПОДШИПНИК СКОЛЬЖЕНИЯ ШАТУНА] 12585675 PISTON, (W/PIN) (INCLS 211, 212) (.25 O.S.) 12590866 PISTON, (W/PIN) (INCLS 211, 212) (STD) 12566186 RETAINER, PSTN PIN (ЧАСТЬ OF 210) 12603180 BALANCER, CR/SHF (DUAL BELT) [ШКИВ КОЛЕНВАЛА] 11569873 БОЛТ, CR/SHF BALR (M14X1.5X48.4) 12613030 SENSOR, CR/SHF POSN (INCLS 721, 722) [ДАТЧИК ПОЛОЖЕНИЯ КОЛЕНВАЛА] 11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (ЧАСТЬ OF 720) [БОЛТ] 12605738 SENSOR, KNOCK (W/O LEADS) (INCLS 724) (ACDelco #213-4404) 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 723) 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (EXH MANIF H/SHLD) [БОЛТ] 12610603 BEARING KIT, CR/SHF (#1, 2, 4 STD) (INCLS 122, 123) [ПОДШИПНИК СКОЛЬЖЕНИЯ КОЛЕНВАЛА] 12610604 BEARING KIT, CR/SHF (#3 STD) (INCLS 123, 124) [КОМПЛЕКТ ПОДШИПНИКОВ СКОЛЬЖЕНИЯ КОЛЕНВАЛА (3ШТ)] 12608615 RING KIT, PSTN (INCLS 213-216) (STD) (GM00-395) - 2007-2009 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 3 ПЕРЕДНЯЯ КРЫШКА И ОХЛАЖДЕНИЕ (LY7/3.6-7) ↓ teamcadillac.ru 22531637 PIN, ENG FRT CVR LOC (ЧАСТЬ OF 350) (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 11519176 БОЛТ, ENG FRT CVR (ЧАСТЬ OF 350) (M8X1.25X80) (4.081) [БОЛТ] 12611883 COVER, ENG FRT (W/ W/PMP) (INCLS 132, 348, 351-354, 360-362, 725-727, 734, 900-903) [БОКОВАЯ КРЫШКА ДВИГАТЕЛЯ] 12593045 SEAL, W/PMP (ЧАСТЬ OF 350) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519171 БОЛТ, ENG FRT CVR (ЧАСТЬ OF 350) (M8X1.25X50) (3.275) [БОЛТ ВЫПУСКНОГО КОЛЛЕКТОРА] 12608750 SEAL, CR/SHF FRT OIL (ЧАСТЬ OF 350) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КОЛЕНВАЛА] 12594060 DEADENER, ENG FRT CVR (ЧАСТЬ OF 350) (BOTTOM) [ПРОКЛАДКА КРЫШКИ ДВИГАТЕЛЯ] 12618472 PUMP, WAT (W/GSKT) (INCLS 900) (ЧАСТЬ OF 350) (ACDelco #251-724) [НАСОС] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 350) 12576326 GASKET, W/PMP (ЧАСТЬ OF 350) (ACDelco #251-2048) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12574518 PULLEY, W/PMP (ADX) 11519512 БОЛТ, HFH, W/CON SPR WA, M6X1X13.4, 8.77 THD, 12.3 O.D., 8.8, GMW3359 (W/PMP PUL) 12592527 GASKET, ENG COOL THERM HSG (*KIT1) (ACDelco #12592527) [ПРОКЛАДКА ТЕРМОСТАТА] 11519973 БОЛТ-HFH, M6X1X60, 18MM THD, 14.2 OD, 8.8, 3359GMW, REDUCED BODY, MAT PT. (ENG COOL THERM HSG) (*KIT1) [БОЛТ 6Х1Х60] 11519974 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3359 (ENG COOL THERM HSG) (*KIT1) [БОЛТ] 12584325 SEAL, ENG COOL THERM HSG (O RING) (*KIT1) [КОЛЬЦЕ-ОБРАЗНОЕ УПЛОТНЕНИЕ] 12582472 SEAL, ENG COOL THERM (*KIT1) (ACDelco #12582472) [УПЛОТНИТЕЛЬ] 12566429 SEAL, WAT OTLT (ЧАСТЬ OF 380) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12584040 SEAL, CLNT OTLT (O RING) (ЧАСТЬ OF 380) (ACDelco #15-32584) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519974 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 380) [БОЛТ] 12573984 OUTLET, WAT (INCLS 377-379, 905) (INCLS БОЛТS, RETAINERS, SEALS & PIPE) (ACDelco #15-10429) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 12608424 SENSOR, CM/SHF POSN (INCLS 726, 727) (ЧАСТЬ OF 350) (ACDelco #12608424) [ДАТЧИК ПОЛОЖЕНИЯ РАСПРЕДВАЛА] 11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (ЧАСТЬ OF 350, 725) [БОЛТ] 12576969 VALVE, CM/SHF POSN ACTR SOL 12615613 VALVE, CM/SHF POSN ACTR SOL 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (CM/SHF POSN ACTR SOL VLV) 12593717 SEAL, CM/SHF POSN ACTR SOL VLV (O RING) (ЧАСТЬ OF 350) 12620259 ШЛАНГИ, ENG COOL THERM (INCLS 365-368, 370-373) (INCLS THERMOSTAT) [КОРПУС В СБОРЕ, ТЕРМОСТАТА СИСТЕМЫ ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ] (GM00-396) - 2007-2009 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 2 ГОЛОВКА ЦИЛИНДРОВ & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7) ↓ 12570326 PIN, CYL HD LOC [ЗАГЛУШКА БЛОКА ЦИЛИНДРОВ] 12606653 ACTUATOR, CM/SHF POSN (USE WASHER 12630941) 12603744 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) 12603745 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) teamcadillac.ru 11588279 БОЛТ, HFH, M10X1.5X80, 26 THD, 22.3 O.D., 10.9, GM4277M (CM/SHF POSN) 12626055 COVER, CM/SHF (INCLS 251, 254-257, 260, 263) [КЛАПАННАЯ КРЫШКА ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12595106 SEAL, CM/SHF CVR (ЧАСТЬ OF 250) (*KIT1) (ACDelco #12595106) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12626054 COVER, CM/SHF (INCLS 253-257, 261) [КРЫШКА] 12595107 SEAL, CM/SHF CVR (ЧАСТЬ OF 252) (*KIT1) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12607600 SEAL, SPLG SHLD (ЧАСТЬ OF 250, 252) (*KIT1) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО СИСТЕМЫ ЗАЖИГАНИЯ] 11518859 БОЛТ, HFH W/SHLDR, M6X1X35, 11.85 THD, 18 O.D., 8.8, GMW3359 (ЧАСТЬ OF 250, 252) 12595122 INSULATOR, CM/SHF CVR БОЛТ (ЧАСТЬ OF 250, 252) 12593356 CAP, OIL FIL (INCLS 904) (ACDelco #FC221) [КРЫШКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ] 12593348 SEAL, OIL FIL TUBE (O RING) (ЧАСТЬ OF 262) (27.94MM I.D.) (SIZE #320) (1.758) [ПРОКЛАДКА] 12578316 FITTING, PCV (ЧАСТЬ OF 250) (INCLS 263) 12583384 FITTING, PCV (ЧАСТЬ OF 252) 12597946 TUBE, OIL FIL (INCLS 259) [ТРУБКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ ГОЛОВКИ БЛОКА] 12616908 SEAL, PCV HOSE FTG (O RING) (ЧАСТЬ OF 250, 260) (BLUE) (LARGER OF THE TWO ON THE FITTING) [УПЛОТНЕНИЕ] 12616909 SEAL, PCV HOSE FTG (O RING) (ЧАСТЬ OF 250, 260) (BLACK) (SMALLER OF THE TWO ON THE FITTING) [УЛОТНЕНИЕ] 12601744 INSULATOR, CM/SHF HSG CVR (0.413) 12601745 INSULATOR, CM/SHF HSG CVR [НАКЛАДКА КЛАПАННОЙ КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12603904 HEAD, CYL (MCHG) (INCLS 313, 318, 319, 328, 336, 337) (DOES NOT INCL ENG OIL MANIF CHECK VALVES. DLR MUST INSTL) 12603901 HEAD, CYL (MCHG) (INCLS 313, 318, 319, 328, 336, 337) (DOES NOT INCL ENG OIL MANIF CHECK VALVES. DLR MUST INSTL) 11518863 БОЛТ, CYL HD (M11X2X152) [БОЛТ] 11588734 БОЛТ, HFH, M8X1.25X90, 21.6 THD, 18 O.D., 8.8, GMW3359 (CYL HD) [ВИНТ] 12565988 PLUG - M20X1.5X30.5, 8.8, GMW3044, SEALANT PER GM9985490 (ЧАСТЬ OF 300, 301) 11562127 PLUG, CYL HD OIL GAL (ЧАСТЬ OF 300, 301) (CUP-14.22 OD, 6.6 THK, 304SS) 12575354 VALVE, EXH (STD) [КЛАПАН ВЫПУСКНОЙ] 12584760 VALVE, EXH (0.075 O.S.) [КЛАПАН ВЫПУСКНОЙ] 12575351 VALVE, INT (STD) [КЛАПАН ВПУСКНОЙ] 12584763 VALVE, INT (0.075MM O.S.) (0.297) [КЛАПАН ВПУСКНОЙ] 24100294 ARM, VLV RKR [РЫЧАГ] 24100005 ADJUSTER, HYD VLV LASH (ACDelco #24100005) [ТОЛКАТЕЛЬ КЛАПАНА ДВИГАТЕЛЯ] 12565836 SEAL, VLV STEM OIL [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КЛАПАНА ДВИГАТЕЛЯ] 12575355 ПРУЖИНА, VLV [ПРУЖИНА КЛАПАНА] 12575196 RETAINER, VLV SPR [КОМПАКТ ДИСК] 12575197 KEY, VLV STEM [КЛАПАННЫЙ КЛЮЧ] 12574477 RING, CM/SHF SPKT OIL SEAL (ЧАСТЬ OF 330-333) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО РАСПРЕДВАЛА ДВИГАТЕЛЯ (2 ШТ.)] 12625987 CAMSHAFT, EXH (INCLS 329) 12632192 CAMSHAFT, EXH (INCLS 329) 12625986 CAMSHAFT, INT (INCLS 329) 12632193 CAMSHAFT, INT (INCLS 329) 12625990 CAMSHAFT, EXH (INCLS 329) 12632194 CAMSHAFT, EXH (INCLS 329) 12625989 CAMSHAFT, INT (INCLS 329) 12632195 CAMSHAFT, INT (INCLS 329) 11518856 HFH, M6X1X43.4, 14.8 THD, 11 O.D., 8.8, GMW3179 CODE G (ЧАСТЬ OF 300, 301) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12613057 РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ, IGN (INCLS 705) (ACDelco #12613057) 11588715 БОЛТ, HFH, M6X1X35, 18 THD, 14.2 OD, 8.8, GMW3359, 5MM M POINT (ЧАСТЬ OF 704) [БОЛТ] 12566778 SENSOR, ENG COOL TEMP (3.682) (ACDelco #213-1581) [СЕНСОР ТЕМПЕРАТУРЫ] 12597464 СВЕЧИ, (DO NOT CHANGE СВЕЧИ GAP) (ACDelco #41-990) (PLATINUM PLUG) [СВЕЧА ЗАЖИГАНИЯ] 12580965 VALVE, ENG OIL MANIF CHK [КЛАПАН] 12593348 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 258) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА] 12625781 GASKET KIT, CYL HD (INCLS 251, 253, 254, 302, 303) (INCLS UPR & LWR INT MANIF GASKETS) [КОМПЛЕКТ ПРОКЛАДОК ВПУСКНОГО КОЛЛЕКТОРА (2ШТ)] (GM00-550) - 2007-2009 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 6 ЦЕПЬ И НАТЯЖИТЕЛЬ (LY7/3.6-7) ↓ 12599721 SPROCKET, CR/SHF [ШЕСТЕРНЯ РАСПРЕДВАЛА] 12586959 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (LOWER PRIMARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ГРМ] 12609262 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (INCLS 153, 164) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 152) [БОЛТ М8] 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (TMG CHAIN GDE) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12616609 CHAIN, CM/SHF INTER DRV (PRIMARY) [ЦЕПЬ ПРИВОДА ГРМ] 12597417 GUIDE, TMG CHAIN (INCLS 157) (UPPER PRIMARY) 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 156) [БОЛТ М8] 11588252 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3179 CODE G (ЧАСТЬ OF 165, 166) 12589477 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 152) (PRIMARY) 12612839 SPROCKET, TMG CHAIN IDLER (INCLS 161) (0.736) [ЗВЕЗДОЧКА РАСПРЕДВАЛА] 12612838 SPROCKET, TMG CHAIN IDLER (INCLS 161) (0.736) [ШЕСТЕРНЯ РАСПРЕДВАЛА] 12616608 CHAIN, CM/SHF INTER DRV (SECONDARY) [ЦЕПЬ ПРИВОДА ГРМ] 12600461 GUIDE, TMG CHAIN (INCLS 172) (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ПРИВОДА ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 171) [БОЛТ М8] teamcadillac.ru 12586960 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАТЯЖИТЕЛЬ ЦЕПИ] 11518858 БОЛТ, HFH, M8X1.25X43, 16 THD, 18 O.D., 8.8, GMW3179 (TMG CHAIN TENSR) [БОЛТ М8] 12609260 РОЛИК НАТЯЖИТЕЛЬ, TMG CHAIN (INCLS 176, 177) (SECONDARY) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 175) [БОЛТ М8] 12589478 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 175) 12586961 GUIDE, TMG CHAIN (INCLS 182) (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАПРАВЛЯЮЩАЯ ПРИВОДНОЙ ЦЕПИ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 181) [БОЛТ М8] 12600462 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ПРИВОДА ГРМ] 11518858 БОЛТ, HFH, M8X1.25X43, 16 THD, 18 O.D., 8.8, GMW3179 (TMG CHAIN TENSR) [БОЛТ М8] 12609258 РОЛИК НАТЯЖИТЕЛЬ, TMG CHAIN (INCLS 186, 187) (SECONDARY) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 185) [БОЛТ М8] 12589479 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 185) 12606653 ACTUATOR, CM/SHF POSN (EXH) (USE WASHER 12630941) 12626160 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12632859) (4 SCREWS ON BACKPLATE) 12626161 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12632859) (4 SCREWS ON BACKPLATE) 11588279 БОЛТ, HFH, M10X1.5X80, 26 THD, 22.3 O.D., 10.9, GM4277M (CM/SHF POSN ACTR) 12630941 WASHER, CM/SHF THR (USED ON ACTUATORS 12603744-745, 12606653 & 12630916-918) (**FIELD FIX ONLY, DO NOT CATALOG**) [УПОРНАЯ ШАЙБА РАСПРЕДЕЛИТЕЛЬНОГО ВАЛА ДВС] (GM00-588) - 2009 E КРЕПЛЕНИЕ ДВИГАТЕЛЯ TO ТРАНСМИССИЯ (LH2/4.6A) ↓ 12582606 FLYКОЛЕСО, ENG 25773136 BRACKET, ENG WRG HARN (CHANNEL) 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] 24205900 PLUG, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] 12568123 COVER, TRANS CONV teamcadillac.ru 11589116 БОЛТ, FLYWHL (8.900) 12568122 COVER, FLYWHL HSG 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (TRANS CONV CVR) 01 - СИСТЕМА ОХЛАЖДЕНИЯ - РЕШЕТКА РАДИАТОРА-МАСЛОСИСТЕМА ↓ (6D01-034) - 2004-2009 E ПОДОГРЕВАТЕЛЬ БЛОКА ДВИГАТЕЛЯ (LY7/3.6-7, 110V ПОДОГРЕВАТЕЛЬ K05) ↓ 15257983 CORD, ENG COOL HTR (INCLS 2) teamcadillac.ru 12337820 STRAP, 15" TIE STRAP (ЧАСТЬ OF 1) (ACDelco #12337820) 12587380 ПОДОГРЕВАТЕЛЬ, ENG COOL (USE W/2 PIN ПОДОГРЕВАТЕЛЬ) [НАГРЕВАТЕЛЬ] (6D01-044) - 2004-2009 E РАДИАТОР ASM ↓ 19130364 РАДИАТОР, (CORE SIZE 26 3/8 X 21 3/16 X 2 1/16) (INCLS 2) (ACDelco #21710) [РАДИАТОР] teamcadillac.ru 19130397 РАДИАТОР, (CORE SIZE 26 3/8 X 21 3/16 X 2 1/16) (INCLS 2) (ACDelco #21711) [РАДИАТОР] 19130399 РАДИАТОР, (CORE SIZE 26 3/8 X 21 3/16 X 2 1/16) (INCLS 2) (ACDelco #21713) (6D01-069) - 2009 E ВЕНТИЛЯТОР ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ (LY7/3.6-7) ↓ 25881833 SHROUD, ENG COOL FAN 11570323 БОЛТ, КОНДИЦИОНЕР CNDSR (M6X1X18, 13 THD) (1.277) 25881844 RESISTOR, ENG COOL FAN 25881842 MOTOR, ENG COOL FAN (ACDelco #15-81137) teamcadillac.ru 11570323 БОЛТ, ENG COOL FAN SHRD (M6X1X18, 13 THD) 11570324 БОЛТ, ENG COOL FAN SHRD (M6X1X14, 9 THD) (9.190) 11570325 БОЛТ, ENG COOL FAN MOT 25881843 BLADE, FAN (ACDelco #15-81138) (6E01-015) - 2004-2009 E НАТЯЖИТЕЛЬ РЕМНЯ/ACCESSORY DRIVE (LH2/4.6A) ↓ 12593189 BELT, W/PMP & КОНДИЦИОНЕР CMPR & P/S PUMP [РЕМЕНЬ ДВИГАТЕЛЯ] 12578062 BELT, GEN (CODE WCN) [РЕМЕНЬ] teamcadillac.ru 11518636 БОЛТ, HFH, M10X1.5X90, 25.9 THD, 22.3 OD, 10.9, GMW3359, 7.5 MAT-PT (ЧАСТЬ OF 4) [БОЛТ М10] 12568172 РОЛИК НАТЯЖИТЕЛЬ, DRV BELT (INCLS 3) (SMOOTH PULLEY) (USE T/W БОЛТ PN 11518636) [ШКИВ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11518636 БОЛТ, HFH, M10X1.5X90, 25.9 THD, 22.3 OD, 10.9, GMW3359, 7.5 MAT-PT (ЧАСТЬ OF 6) [БОЛТ М10] 12598023 РОЛИК НАТЯЖИТЕЛЬ, DRV BELT (INCLS 5) (RIBBED PULLEY) [МЕХАНИЗМ НАТЯЖЕНИЯ] 12604688 PULLEY, BELT IDLER (INCLS 7) (ACDelco #15-40051) (6E01-018) - 2007-2009 E ВЕНТИЛЯТОР ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ-ELECTRIC PUSHER(LH2/4.6A, V92) ↓ teamcadillac.ru 89022529 BLADE, FAN (INCLS 2) (ACDelco #15-80710) [КРЫЛЬЧАТКА ВЕНТИЛЯТОРА] 89022526 MOTOR, ENG COOL FAN (ELECTRIC PUSH) (ACDelco #15-80542) [ЭЛЕКТРОДВИГАТЕЛЬ ВЕНТИЛЯТОРА 90 ВТ] 89022525 MOTOR, ENG COOL FAN (ELECTRIC PUSH) (ACDelco #15-80541) [ЭЛЕКТРОДВИГАТЕЛЬ ВЕНТИЛЯТОРА 90 ВТ] 89022544 БОЛТ KIT, ENG COOL FAN MOT [КОМПЛЕКТ БОЛТОВ ОБЛИЦОВКИ РАДИАТОРА (2 ШТ)] 89022528 BLADE, FAN (INCLS 2) (ACDelco #15-80709) [КРЫЛЬЧАТКА ВЕНТИЛЯТОРА] (6E01-019) - 2007-2009 E РЕШЕТКА РАДИАТОРА (SPORT PACKAGE VD9) ↓ 19177175 MOLDING, КАПОТ FRT (INCLS 2) (КРАСКА TO MATCH) 25844085 MOLDING, КАПОТ FRT (INCLS 2) [МОЛДИНГ КАПОТА] 11561788 CLIP-U, 13X15X12, 1.5 PNL, 1050, 6280M (ЧАСТЬ OF 1) [ФИКСАТОР МОЛДИНГА КАПОТА] 15831165 SCREEN, RAD GRL (INCLS 4) (UPPER) 15795653 CLIP, RAD GRL (ЧАСТЬ OF 3, 6) (13X8.13X9.27) (7.831) [ФИКСАТОР ПАНЕЛИ БАМПЕРА] 15831166 SCREEN, RAD GRL (INCLS 4) (LOWER) 21030249 RETAINER, EXPAN, 21 LG, 20. OD, 8.0 HOLE, 3.0-5.0 PNL, NYLON 6/6, BLK (RAD GRL) (8.950) (PUSH IN) [ПИСТОН КРЕПЛЕНИЯ КОЖУХА РАДИАТОРА(ПЛАСТИК)] teamcadillac.ru 15830874 GRILLE, RAD UPR (КРАСКА TO MATCH) [РЕШЕТКА РАДИАТОРА] 25819834 EMBLEM, RAD GRL (WREATH) 25819835 EMBLEM, RAD GRL (CREST) (6E01-023) - 2004-2009 E НАТЯЖИТЕЛЬ РЕМНЯ/ACCESSORY DRIVE (LY7/3.6-7) ↓ 12577655 РОЛИК НАТЯЖИТЕЛЬ, КОНДИЦИОНЕР CMPR & P/S PMP BELT (9.180) [НАТЯЖИТЕЛЬ РЕМНЯ] teamcadillac.ru 11518633 БОЛТ, HFH, M10X1.5X75, 26 THD, 22.3 OD, 10.9, GMW3359, MAT- POINT. (DRV BELT TENSR) [БОЛТ М10] 12578000 BELT, КОНДИЦИОНЕР CMPR & P/S PUMP [НАСОС] 12621991 BELT, W/PMP & GEN [РЕМЕНЬ ГЕНЕРАТОРА L=120 СМ] 12577652 РОЛИК НАТЯЖИТЕЛЬ, W/PMP & GEN BELT [НАТЯЖИТЕЛЬ РЕМНЯ] (6E01-024) - 2004-2009 E ПОДОГРЕВАТЕЛЬ БЛОКА ДВИГАТЕЛЯ (LH2/4.6A, 110V ПОДОГРЕВАТЕЛЬ K05) ↓ 15905855 CORD KIT, ENG COOL HTR teamcadillac.ru 12587380 ПОДОГРЕВАТЕЛЬ, ENG COOL (USE W/2 PIN ПОДОГРЕВАТЕЛЬ) [НАГРЕВАТЕЛЬ] (6E01-025) - 2004-2009 E ПОДОГРЕВАТЕЛЬ БЛОКА ДВИГАТЕЛЯ (LH2/4.6A, 220V ПОДОГРЕВАТЕЛЬ KA3) ↓ 15905854 CORD KIT, ENG COOL HTR 12587379 ПОДОГРЕВАТЕЛЬ, ENG COOL (6E01-028) - 2007-2009 E РЕШЕТКА РАДИАТОРА (EXC SPORT PACKAGE VD9) ↓ teamcadillac.ru 19177175 MOLDING, КАПОТ FRT (INCLS 2) (КРАСКА TO MATCH) 25844085 MOLDING, КАПОТ FRT (INCLS 2) [МОЛДИНГ КАПОТА] 11561788 CLIP-U, 13X15X12, 1.5 PNL, 1050, 6280M (ЧАСТЬ OF 1) [ФИКСАТОР МОЛДИНГА КАПОТА] 21030249 RETAINER, EXPAN, 21 LG, 20. OD, 8.0 HOLE, 3.0-5.0 PNL, NYLON 6/6, BLK (ЧАСТЬ OF 6) (8.950) (PUSH IN) [ПИСТОН КРЕПЛЕНИЯ КОЖУХА РАДИАТОРА(ПЛАСТИК)] 15925771 GRILLE, RAD (INCLS 4, 5, 7-10) [РЕШЕТКА РАДИАТОРА] 25765149 EMBLEM, RAD GRL (ЧАСТЬ OF 6) (CHROME) ("CREST") [ЭМБЛЕМА] 25765150 EMBLEM, RAD GRL (ЧАСТЬ OF 6) ("WREATH") [ЭМБЛЕМА] 21030249 RETAINER, EXPAN, 21 LG, 20. OD, 8.0 HOLE, 3.0-5.0 PNL, NYLON 6/6, BLK (ЧАСТЬ OF 6) (8.950) (PUSH IN) [ПИСТОН КРЕПЛЕНИЯ КОЖУХА РАДИАТОРА(ПЛАСТИК)] 24574578 RETAINER, RAD GRL (ЧАСТЬ OF 6) (LENGTH 18.0) (3.403) [ФИКСАТОРА ВОЗДУХООЧИСТИТЕЛЯ] (6E01-029) - 2007-2009 E ШЛАНГИ И ТРУБКИ/РАДИАТОР (LY7/3.6-7) ↓ 88956900 HOSE, RAD SURGE TK OTLT (INCLS 2) 11517136 CЛАМПА, HOSE SPR, 27 NOM, 25.2 MIN-28.9 MAX, 15MM WIDE, BLACK (ЧАСТЬ OF 1) 11518624 БОЛТ, HFH, M10X1.5X30.4, 22.5 THD, 22.3 O.D., 10.9, GMW3359 (RAD SURGE TK ENG PIPE CLIP) 25757865 HOSE, RAD SURGE TK OVFL (ЧАСТЬ OF 6) 15075118 CAP, RAD SURGE TK (ЧАСТЬ OF 6) (15 PSI DUAL O-RING) (ENGLISH/FRENCH LABEL) (ACDelco #RC98) [КРЫШКА БАЧКА РАДИАТОРА] 15882261 TANK, RAD SURGE (INCLS 4, 5) (ACDelco #15882261) 11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (RAD SURGE TK) [БОЛТ М6] 11514517 ГАЙКА, HEX, W/CON SPR WA, M6X1, 5.7THK, 18 O.D., 9, 7111M (RAD SURGE TK) [ГАЙКА М6] 11570614 CЛАМПА-ПРУЖИНАBAND, 15 NOMINAL DIA, 15 THK, STL, ROBO (ЧАСТЬ OF 10) 19130184 HOSE, RAD SURGE TK INL (INCLS 9) teamcadillac.ru 11516233 CЛАМПА-ПРУЖИНАBAND, TYPE A, 15 WID, 40 HOSE OD, 6150M, 7111M, MM (ЧАСТЬ OF 12) [ХОМУТ ШЛАНГА РАДИАТОРА] 89023435 HOSE, RAD INL (INCLS 11) 11516233 CЛАМПА-ПРУЖИНАBAND, TYPE A, 15 WID, 40 HOSE OD, 6150M, 7111M, MM (ЧАСТЬ OF 14) [ХОМУТ ШЛАНГА РАДИАТОРА] 25800334 HOSE, RAD OTLT (INCLS 13) [ШЛАНГ СИСТЕМЫ ОХЛАЖДЕНИЯ] 12603912 PIPE, RAD OTLT (INCLS 16) (WHEN USED IN PLACE OF 12587536 USE T/W РАДИАТОР OUTLET HOSE 19129967) 12623519 SEAL, RAD OTLT PIPE (O RING) (ЧАСТЬ OF 15) 11519977 БОЛТ- HFH, M8X1.25X25, 16 THD, 18 OD, 8.8, GMW3359, MAT-PT. (RAD OTLT PIPE) 11518624 БОЛТ, HFH, M10X1.5X30.4, 22.5 THD, 22.3 O.D., 10.9, GMW3359 (RAD OTLT PIPE) (6E01-030) - 2009 E РАДИАТОР КРЕПЛЕНИЕ & ДЕТАЛИ КОМПЛЕКТА ↓ 25718629 BRACKET, RAD UPR (INCLS 3) 25729351 BRACKET, RAD UPR (INCLS 3) 11517484 БОЛТ-HEX, M6X1X20, 9 THD, 17 OD, 9.8, 6280M, MACH, P-PT (RAD UPR MT BRKT) 11519444 PUSH-PIN, 10.0 HEADX26.0, 10.0 HOLE, PNL THK 6.2-8.71, NY 6.6 (RAD AIR LWR BFL (PUSH IN)) [ФИКСАТОР ПОДКРЫЛКА] 25802220 DEFLECTOR, FRT AIR (INCLS 17) [ОБТЕКАТЕЛЬ РАДИАТОРА] teamcadillac.ru 11570323 БОЛТ, ENG COOL FAN SHRD (M6X1X18, 13 THD) 11570324 БОЛТ, ENG COOL FAN SHRD (M6X1X14, 9 THD) (9.190) 25881833 SHROUD, ENG COOL FAN (СМ. ГРУППУ 01.000 "ВЕНТИЛЯТОР ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 19130248 SEAL, RAD LH SI (INCLS 8) [КОЖУХ РАДИАТОРА] 15932850 INSULATOR, RAD LWR [ДЕМПФЕР РАДИАТОРА] 11561026 БОЛТ-HFH, M6X1X25, 22 THD, 14.2 OD, 9.8, GMW3200, MACH, HDR-PT (КОНДИЦИОНЕР CNDSR) 19130355 CONDENSER, КОНДИЦИОНЕР (ACDelco #15-63541) 25994576 BAR, FRT BPR IMP (СМ. ГРУППУ 07.000 "БАМПЕР ПЕРЕДНИЙ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [БАЛКА ПАНЕЛИ БАМПЕРА] 19130247 SEAL, RAD AIR SI (INCLS 8) 88957418 SEAL, RAD UPR 15248340 SEAL, RAD AIR LWR (ЧАСТЬ OF 5) 25881833 SHROUD, ENG COOL FAN (СМ. ГРУППУ 01.000 "ВЕНТИЛЯТОР ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6E01-038) - 2007-2009 EB ШЛАНГИ И ТРУБКИ/РАДИАТОР (LH2/4.6A) ↓ 19129998 HOSE, RAD SURGE TK INL 11516215 CЛАМПА, ПРУЖИНАBAND, HOSE DIA 17MM, WIDTH 15MM, 6298M (RAD SURGE TK INL HOSE) 11517136 CЛАМПА, HOSE SPR, 27 NOM, 25.2 MIN-28.9 MAX, 15MM WIDE, BLACK (ЧАСТЬ OF 6) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (RAD SURGE TK OTLT HOSE CLIP BRKT) 88956890 HOSE, RAD SURGE TK OTLT (INCLS 4) (8.846) 11514517 ГАЙКА, HEX, W/CON SPR WA, M6X1, 5.7THK, 18 O.D., 9, 7111M (RAD SURGE TK) [ГАЙКА М6] 15075118 CAP, RAD SURGE TK (ЧАСТЬ OF 11) (15 PSI DUAL O-RING) (ENGLISH/FRENCH LABEL) (ACDelco #RC98) [КРЫШКА БАЧКА РАДИАТОРА] 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (RAD SURGE TK) (ACDelco #11517518) [БОЛТ] 25757865 HOSE, RAD SURGE TK OVFL (ЧАСТЬ OF 11) 15882261 TANK, RAD SURGE (INCLS 8, 10) (ACDelco #15882261) 11570614 CЛАМПА-ПРУЖИНАBAND, 15 NOMINAL DIA, 15 THK, STL, ROBO (RAD SURGE TK INL HOSE) 19130238 CЛАМПА, RAD INL HOSE (ЧАСТЬ OF 14) 25974695 HOSE, RAD INL (INCLS 13, 15) 25974696 HOSE, RAD INL (INCLS 13, 15) 89023434 HOSE, RAD INL (INCLS 13, 15) [ТРУБКА] 89023438 HOSE, RAD INL (INCLS 13, 15) [ШЛАНГ] 11570869 CЛАМПА-ПРУЖИНАBAND, 41MM NOMINAL DIA, 15MM WIDTH, STEEL, GRAY ROBO. (ЧАСТЬ OF 14) 11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (RAD OTLT HOSE BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16] 15261734 BRACKET, RAD OTLT HOSE teamcadillac.ru 25752529 BRACKET, RAD OTLT HOSE 89023433 HOSE, RAD OTLT (INCLS 16) (6M01-035) - 2004-2009 E ВЕНТИЛЯТОР ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ-ДВИГАТЕЛЬ MOUNTED (LH2/4.6A, V92) ↓ 11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (ENG COOL FAN BRKT) 12597700 BRACKET, ENG COOL FAN (INCLS 7) 11516869 БОЛТ, HEX W/CON WA, M10X1.5X18, 13THD, 20 O.D., 9.8, GM6174M (FAN BLADE) (*KIT1) 12589532 STUD, AUX ENG CLG FAN BRKT 12586654 INSULATOR, ENG COOL FAN (ЧАСТЬ OF 2) 10382029 FAN, ENG COOL (INCLS 3-5) (1.050) (ACDelco #15-4972) [ЭЛЕКТРОМАГНИТНАЯ МУФТА ВЕНТИЛЯТОРА СИСТЕМЫ ОХЛАЖДЕНИЯ] (6M01-039) - 2007-2009 E ПОДОГРЕВАТЕЛЬ БЛОКА ДВИГАТЕЛЯ (LY7/3.6-7, 220V ПОДОГРЕВАТЕЛЬ KA3) ↓ 25772574 CORD, ENG COOL HTR [КАБЕЛЬ ПИТАНИЯ СИСТЕМЫ ПОДОГРЕВА ДВС] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ENG COOL HTR) teamcadillac.ru 12588204 ПОДОГРЕВАТЕЛЬ, ENG COOL 02 - СТАРТЕР - ГЕНЕРАТОР - ЗАЖИГАНИЕ - ЭЛЕКТРИКА - ЛАМПЫ ↓ (6D02-025) - 2004-2009 E КРЕПЛЕНИЕ ГЕНЕРАТОРА (LY7/3.6-7) ↓ 12597648 BRACKET, GEN & DRV BELT TENSR (2.277) 11518628 БОЛТ, HVY HEX ACORN FLG HD, M10X1.5X50, GMW25M (10.9) STL, GMW3358 (GEN BRKT) teamcadillac.ru 11518636 БОЛТ, HFH, M10X1.5X90, 25.9 THD, 22.3 OD, 10.9, GMW3359, 7.5 MAT-PT (GEN BRKT) [БОЛТ М10] 11519176 БОЛТ, GEN BRKT (M8X1.25X80) (4.081) [БОЛТ] 25751146 GENERATOR, (ACDelco #25751146) [ГЕНЕРАТОР 150 А] 11518628 БОЛТ, HVY HEX ACORN FLG HD, M10X1.5X50, GMW25M (10.9) STL, GMW3358 (GEN) 11518633 БОЛТ, HFH, M10X1.5X75, 26 THD, 22.3 OD, 10.9, GMW3359, MAT- POINT. (GEN) [БОЛТ М10] (6D02-035) - 2004-2009 E РЕЛЕ/BODY COMPARTMENT ↓ 19116855 COVER, FUSE BLK (ЧАСТЬ OF 10) 19116051 BREAKER, CIRC (ЧАСТЬ OF 10) 15319477 FUSE, 30AMP, PINK, J-CASE, FEMALE, REGULAR (ЧАСТЬ OF 10) [ПРЕДОХРАНИТЕЛЬ 30А] 15319478 FUSE, 40AMP, GREEN, J-CASE, FEMALE (ЧАСТЬ OF 10) (ACDelco #15319478) [ПРЕДОХРАНИТЕЛЬ 40А] 12092079 FUSE, 10A, MINI, RED (ЧАСТЬ OF 10) 88909754 FUSE, 15A, MINI, BLUE (ЧАСТЬ OF 10) (ACDelco #ATM15-25) [ПРЕДОХРАНИТЕЛЬ 15 А] 19116057 RELAY, IGN (ЧАСТЬ OF 10) (GRAY) (35AMP) (4 TERMINAL) (HIGH CURRENT MICRO RELAY) (2.483) (ACDelco #D1786C) [РЕЛЕ 35А] 19116059 RELAY, IGN (ЧАСТЬ OF 10) (GRAY) (4 TERMINAL) (SPACE SAVER ULTRA 280 MICRO) (2.483) 88953222 RELAY, INTR LP (ЧАСТЬ OF 10) (GRAY) (20AMP) (4 TERMINAL) (LOW-PROFILE MICRO 280) (2.485) (ACDelco #D1755A) [РЕЛЕ] 19116060 PULLER, FUSE (ЧАСТЬ OF 10) 21997408 RELAY, ACSRY TIME DELAY CUTOFF (ЧАСТЬ OF 10) (5-TERMINAL) (SPDT, 280 MINI, HI/LOW, BLACK) (1.055) (ACDelco #15-81106) teamcadillac.ru 19116855 COVER, FUSE BLK (ЧАСТЬ OF 10) 88956533 COVER, ACSRY PWR FUSE BLK HSG (ЧАСТЬ OF 10) (LOWER COVER FOR THE LH & RH ЗАДНИЙ J/BLKS) (13.100) (6E02-022) - 2004-2009 E ФАРООМЫВАТЕЛЬ (CE4) ↓ 25890367 HOSE, HDLP WA 12335720 COVER, HDLP WA NOZ teamcadillac.ru 12335721 COVER, HDLP WA NOZ 25767592 NOZZLE, HDLP WA [ФОРСУНКА ФАРООМЫВАТЕЛЯ] 25767593 NOZZLE, HDLP WA [ФОРСУНКА СТЕКЛООМЫВАТЕЛЯ] 88958121 PUMP, HDLP WA (LOCATED IN WSW TANK) (ACDelco #88958121) [НАСОС СТЕКЛООМЫВАТЕЛЯ] 88958122 SEAL, HDLP WA PUMP (6E02-023) - 2004-2009 E КРЕПЛЕНИЕ ГЕНЕРАТОРА (LH2/4.6A) ↓ 12565095 BRACKET, GEN 11515767 БОЛТ, HFH, M10X1.5X35, 32THD, 22.3 O.D., MACH, 10.9, 7114M (GEN BRKT) (T/W 12345493) [БОЛТ] 25709327 GENERATOR, (ACDelco #25709327) [ГЕНЕРАТОР 150 А] 11516360 БОЛТ, HFH M10X1.2X90, 9.8, 7114M, 22.3 OD HDR PT (GEN) (6E02-025) - 2004-2009 E ЖГУТЫ ПРОВОДОВ/ПЕРЕДНИЕ ФАРЫ ↓ 25875707 HARNESS, FWD LP WRG (INCLS 2, 3) 25891398 HARNESS, FWD LP WRG (INCLS 2, 3) [ПРОВОДКА ПЕРЕДНИХ ФАР] 25909193 HARNESS, FWD LP WRG (INCLS 2, 3) 25909194 HARNESS, FWD LP WRG (INCLS 2, 3) 25909195 HARNESS, FWD LP WRG (INCLS 2, 3) 25909196 HARNESS, FWD LP WRG (INCLS 2, 3) 25909197 HARNESS, FWD LP WRG (INCLS 2, 3) 25909198 HARNESS, FWD LP WRG (INCLS 2, 3) teamcadillac.ru 25747284 HARNESS, S/LP WRG (6E02-026) - 2004-2009 E ЖГУТЫ ПРОВОДОВ/ДВИГАТЕЛЬ (LH2/4.6A) ↓ 25953318 HARNESS, ENG WRG 11517070 БОЛТ, HVY HFH, M10X1.5X20 (ENG WRG HARN GND) 15813405 BRACKET, ENG WRG HARN (IP INLINE) 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] teamcadillac.ru 11519861 БОЛТ, HEX W/FL WA, M10X1.5X30, 19 THD, 20 OD, 9.8, 6280M, MACH, MAT-PT (ENG WRG HARN GRD) [БОЛТ М10] 25773136 BRACKET, ENG WRG HARN (CHANNEL) 11517070 БОЛТ, HVY HFH, M10X1.5X20 (ENG WRG HARN SHLD) (6E02-027) - 2004-2009 E ЖГУТЫ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ ↓ 25950012 HARNESS, I/P WRG [ПРОВОДКА МОТОРНОГО ОТСЕКА] teamcadillac.ru 25950014 HARNESS, I/P WRG 25950016 HARNESS, I/P WRG 25950017 HARNESS, I/P WRG 25950018 HARNESS, I/P WRG 25950019 HARNESS, I/P WRG 11516630 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (I/P WRG HARN) (6E02-029) - 2004-2009 E ДАТЧИКИ ПАРКОВКИ ↓ 25938651 МОДУЛЬ, RR OBJECT ALARM 10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (RR OBJECT ALARM MDL) [ПИСТОН КРЕПЛЕНИЯ ОБЛИЦОВКИ БАМПЕРА (NYLON)] 25893294 HARNESS, RR OBJECT SEN WRG 15239247 SENSOR KIT, RR OBJECT (INCLS 6-9) (PRIMED) (W/O ШЛАНГИ) [ДАТЧИК ПАРКОВКИ] 19116421 SENSOR KIT, RR OBJECT (INCLS 6-9) (INCLS SENSOR, RETAINER AND ШЛАНГИ.) (7.831) [ДАТЧИК ЗВУКОВОЙ СИГНАЛИЗАЦИИ СИСТЕМЫ КОНТРОЛЯ ПАРКОВКИ] (6E02-030) - 2004-2009 E КЛЮЧ-ЦИЛИНДР-ЗАЖИГАНИЕ ↓ teamcadillac.ru 15794826 CYLINDER KIT, IGN LK (INCLS 1-3) [ЦИЛИНДР] 25865394 КЛЮЧ, DR LK & IGN LK (UNCODED) (MASTER) (6E02-032) - 2007-2009 E СИГНАЛ (EXC (U03)) ↓ 25789208 СИГНАЛ, 400 & 500 HZ (INCLS 2, 3) (ACDelco #D1947F) [ЗВУКОВОЙ СИГНАЛ] 11517103 STUD, SPL W/KNURLED SHLDR, M6X1X27, 10 THD, 13 O.D., P-PT., 9.8, 7114M (ЧАСТЬ OF 1) [ШТИФТ] 11517102 ГАЙКА, HEX FLG, M6X1X15, 19.8 OD, 9, 7111M (ЧАСТЬ OF 1) [ГАЙКА] (6E02-035) - 2005-2009 E ПЕРЕДНИЕ ФАРЫ (EXPORT TT7,TT8) ↓ 15930599 ЛАМПА, FRT SI T/SIG (INCLS 2) [УКАЗАТЕЛЬ ПОВОРОТА] 01999382 BULB, (ЧАСТЬ OF 1) (ACDelco #W5WLL) (LONGER LIFE) 25760398 SENSOR, HDLP LVLG FRT SUSP HEIGHT (9X/-3NM (S)9X/-3NM) (INTEGRAL STUD) [ДАТЧИК НАКЛОНА ПЕРЕДНЕЙ ЧАСТИ КУЗОВА] 01999382 BULB, (ЧАСТЬ OF 10) (ACDelco #W5WLL) (LONGER LIFE) 10346260 BULB, FRT FOG LP (ЧАСТЬ OF 10) (TRADE 9145) (ACDelco #9145) [ЛАМПА НАКАЛИВАНИЯ] 15896707 ЛАМПА, FRT T/SIG & FOG (INCLS 5-9, 11) 15896708 ЛАМПА, FRT T/SIG & FOG (INCLS 5-9, 11) 11513599 ГАЙКА, U-TYPE, M4.2X1.41, 0.65-3.80 PNL THK, PZ (ЧАСТЬ OF 14) (ACDelco #11513599) 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (FRT FOG LP) [ВИНТ М4] 15831167 BRACKET, FRT FOG LP (INCLS 12, 39) [КОНСОЛЬ] 15831168 BRACKET, FRT FOG LP (INCLS 12, 39) [КРОНШТЕЙН ПРОТИВОТУМАННОЙ ФАРЫ] 15915312 BRACKET, FRT PARK & T/SIG & FOG LP (INCLS 12, 39) [ОПОРА ПРОТИВОТУМАННОЙ ФАРЫ] 15915313 BRACKET, FRT PARK & T/SIG & FOG LP (INCLS 12, 39) [КРОНШТЕЙН ПЕРЕДНЕЙ ФАРЫ] 11588795 RETAINER, HDLP (PUSH ON) (FITS 9 X 16 HOLE, 1.5 THICK PANEL) [ДЕМПФЕР КРЕПЛЕНИЯ ПЕРЕДНЕЙ ФАРЫ] 25735603 BULB, HDLP (LOW BEAM) (ЧАСТЬ OF 22) (TRADE #D1S) (ACDelco #D1S) [ЛАМПОЧКА ПЕРЕДНЕЙ ФАРЫ 50 ВТ] 92184172 BULB, HDLP (HIGH BEAM) (ЧАСТЬ OF 22) (TRADE H7) (ACDelco #92184172) 01999382 BULB, (ЧАСТЬ OF 22) (ACDelco #W5WLL) (LONGER LIFE) 15930600 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 16-21, 23-27) [ПЕРЕДНЯЯ ФАРА] 15930601 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 16-21, 23-27) [ПЕРЕДНЯЯ ФАРА] 25766663 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 16-21, 23-27) 25766664 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 16-21, 23-27) teamcadillac.ru 25763464 BULB, FRT POSN LP (PARK FUNCTION BULB) (ЧАСТЬ OF 22) (BLUE TINT) (TRADE #W5WB50X2) (ACDelco #W5WB50X2) [ЛАМПОЧКА НАКАЛИВАНИЯ ФАРЫ 55 ВТ] 25768517 SENSOR, HDLP LVLG RR SUSP HEIGHT (INCLS 29) [ДАТЧИК ПОЛОЖЕНИЯ КУЗОВА] 25722303 HARNESS, HDLP LVLG ACTR WRG (ЧАСТЬ OF 28) 25753157 BRACKET, HDLP (INCLS 33) 11517397 ГАЙКА, HEX W/CON WA, 8X1.25, 28 O.D., 7.5 THK, 9, PEOR (FRT BPR ENGY ABS) 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (ЧАСТЬ OF 31, 38) (ACDelco #11517518) [БОЛТ] 11518497 SCREW, ASM HEX HD W/FLAT WASHER, M6X1.0X25, 14 THD, 9.8 (HDLP) 11588795 RETAINER, HDLP (PUSH ON) (FITS 9 X 16 HOLE, 1.5 THICK PANEL) [ДЕМПФЕР КРЕПЛЕНИЯ ПЕРЕДНЕЙ ФАРЫ] 11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (ЧАСТЬ OF 38) [ШАЙБА] 25753158 BRACKET, HDLP (INCLS 33, 37) [КРОНШТЕЙН В СБОРЕ] 11609459 SCREW, RND WA, M4.2X1.41X13, 7.2 THD, 11.35 OD, 6010M, GMW4205 (ЧАСТЬ OF 14) [ВИНТ] (6E02-036) - 2005-2009 E ПЕРЕДНИЕ ФАРЫ (EXC EXPORT TT7,TT8) ↓ 10346260 BULB, FRT FOG LP (ЧАСТЬ OF 7) (TRADE 9145) (ACDelco #9145) [ЛАМПА НАКАЛИВАНИЯ] 15855631 BULB, T/SIG (ЧАСТЬ OF 7) (TRADE #3457NAK-LCP) (2.880) (ACDelco #15855631) 15896707 ЛАМПА, FRT T/SIG & FOG (INCLS 2-6, 8, 37) 15896708 ЛАМПА, FRT T/SIG & FOG (INCLS 2-6, 8, 37) 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (FRT FOG LP) [ВИНТ М4] 11588795 RETAINER, HDLP (PUSH ON) (FITS 9 X 16 HOLE, 1.5 THICK PANEL) [ДЕМПФЕР КРЕПЛЕНИЯ ПЕРЕДНЕЙ ФАРЫ] 25735603 BULB, HDLP (LOW BEAM) (ЧАСТЬ OF 24) (TRADE #D1S) (ACDelco #D1S) [ЛАМПОЧКА ПЕРЕДНЕЙ ФАРЫ 50 ВТ] 92184172 BULB, HDLP (HIGH BEAM) (ЧАСТЬ OF 24, 31) (TRADE H7) (ACDelco #92184172) 01999382 BULB, (ЧАСТЬ OF 24) (ACDelco #W5WLL) (LONGER LIFE) 89024736 BALLAST, HDLP (LH AND RH) (ЧАСТЬ OF 24) teamcadillac.ru 11517397 ГАЙКА, HEX W/CON WA, 8X1.25, 28 O.D., 7.5 THK, 9, PEOR (FRT BPR ENGY ABS) 25753157 BRACKET, HDLP (INCLS 22) 11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (ЧАСТЬ OF 21, 27) [БОЛТ М6] 11518497 SCREW, ASM HEX HD W/FLAT WASHER, M6X1.0X25, 14 THD, 9.8 (HDLP) 15926960 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 11-19, 29, 36) 15926961 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 11-19, 29, 36) 11518497 SCREW, ASM HEX HD W/FLAT WASHER, M6X1.0X25, 14 THD, 9.8 (HDLP) 11518121 ГАЙКА, U, M6X1, MULTI THD, .5'-4.0' THK PNL (ЧАСТЬ OF 27) 25753158 BRACKET, HDLP (INCLS 22, 26) [КРОНШТЕЙН В СБОРЕ] 25735602 BULB, HDLP (LOW BEAM) (ЧАСТЬ OF 31) (TRADE #9006XSLL) (ACDelco #9006SXLL) [ЛАМПА НАКАЛИВАНИЯ] 01999382 BULB, (ЧАСТЬ OF 31) (ACDelco #W5WLL) (LONGER LIFE) 15926966 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 11, 12, 15, 14, 28-30, 38) 15926967 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 11, 12, 15, 14, 28-30, 38) 11588795 RETAINER, HDLP (PUSH ON) (FITS 9 X 16 HOLE, 1.5 THICK PANEL) [ДЕМПФЕР КРЕПЛЕНИЯ ПЕРЕДНЕЙ ФАРЫ] 11513599 ГАЙКА, U-TYPE, M4.2X1.41, 0.65-3.80 PNL THK, PZ (FRT T/SIG LP) (ACDelco #11513599) 15831167 BRACKET, FRT FOG LP [КОНСОЛЬ] 15831168 BRACKET, FRT FOG LP [КРОНШТЕЙН ПРОТИВОТУМАННОЙ ФАРЫ] 15915312 BRACKET, FRT PARK & T/SIG & FOG LP [ОПОРА ПРОТИВОТУМАННОЙ ФАРЫ] 15915313 BRACKET, FRT PARK & T/SIG & FOG LP [КРОНШТЕЙН ПЕРЕДНЕЙ ФАРЫ] 11609459 SCREW, RND WA, M4.2X1.41X13, 7.2 THD, 11.35 OD, 6010M, GMW4205 (FRT FOG LP) [ВИНТ] 25763464 BULB, FRT POSN LP (PARK FUNCTION BULB) (ЧАСТЬ OF 24) (BLUE TINT) (TRADE #W5WB50X2) (ACDelco #W5WB50X2) [ЛАМПОЧКА НАКАЛИВАНИЯ ФАРЫ 55 ВТ] 19120947 SOCKET, FRT T/SIG LP (ЧАСТЬ OF 7) (ACDelco #LS234) 01999382 BULB, (ЧАСТЬ OF 31) (ACDelco #W5WLL) (LONGER LIFE) (6E02-038) - 2007-2009 E РЕЛЕ & МОДУЛЬS/ДВИГАТЕЛЬНЫЙ ОТСЕК ↓ 25822674 COVER, MULTIUSE RLY & FUSE (ЧАСТЬ OF 7) [КРЫШКА ТОКОРАСПРЕДЕЛИТЕЛЬНОЙ КОРОБКИ] 25909409 COVER, MULTIUSE RLY & FUSE (ЧАСТЬ OF 7) 15209748 FUSE, 40AMP, LOW PROFILE J CASE, GREEN (ЧАСТЬ OF 7) [ПРЕДОХРАНИТЕЛЬ 20А] teamcadillac.ru 15822417 FUSE, 30AMP, LOW PROFILE J CASE, PINK (ЧАСТЬ OF 7) [ПРЕДОХРАНИТЕЛЬ, 20А] 19116359 FUSE, 50AMP, LOW PROFILE J-CASE, RED (ЧАСТЬ OF 7) [ПРЕДОХРАНИТЕЛЬ 50А] 19116041 FUSE, 2AMP, LOW PROFILE MINI, GRAY (ЧАСТЬ OF 7) [ПРЕДОХРАНИТЕЛЬ] 19116042 FUSE, 10AMP, LOW PROFILE MINI, RED (ЧАСТЬ OF 7) [ПРЕДОХРАНИТЕЛЬ, 10A] 19116043 FUSE, 15AMP, LOW PROFILE MINI, BLUE (ЧАСТЬ OF 7) [ПРЕДОХРАНИТЕЛЬ, 15A] 19116048 FUSE, 20AMP, LOW PROFILE MINI, YELLOW (ЧАСТЬ OF 7) [ПРЕДОХРАНИТЕЛЬ, 20A] 19116049 FUSE, 25AMP, LOW PROFILE MINI, NATURAL (ЧАСТЬ OF 7) [ПРЕДОХРАНИТЕЛЬ, 25A] 19116050 FUSE, 30AMP, LOW PROFILE MINI, GREEN (ЧАСТЬ OF 7) [ПРЕДОХРАНИТЕЛЬ, 30A] 19116081 COVER, BAT POS CBL J/BLK (ЧАСТЬ OF 7) 11610091 ГАЙКА, HFH, 8X1.25, 17.9 OD, 7.8 THK, 13MM HEX, 10, GMW3200 (BAT POS CBL) 25909407 BLOCK, ENG WRG HARN JUNC (INCLS 1-4, 16-18) 25909408 BLOCK, ENG WRG HARN JUNC (INCLS 1-4, 16-18) 25954993 RETAINER, ACSRY WRG J/BLK [КРЫШКА БЛОКА ПРЕДОХРАНИТЕЛЕЙ] 11561758 БОЛТ, MULTIUSE RLY & FUSE BRKT (7.833) [БОЛТ] 15879156 BRACKET, ACSRY WRG J/BLK 11609599 STUD, SPL, M6X1X25, 13 THD, 11 OD HD W/26 WIDE CLIP, 9.8, 6280M, P-PT (MULTIUSE FUSE BRKT) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (MULTIUSE RLY & FUSE BRKT) [ГАЙКА М6] 12193606 RELAY, HDLP LOW BEAM (ЧАСТЬ OF 7) (BLUE) (4-TERMINAL) (SPST 280 MINI) (4.720) (ACDelco #12193606) 19116057 RELAY, FAN CONT (ЧАСТЬ OF 7) (GRAY) (35AMP) (4 TERMINAL) (HIGH CURRENT MICRO RELAY) (2.483) (ACDelco #D1786C) [РЕЛЕ 35А] 19116058 RELAY, FAN CONT (ЧАСТЬ OF 7) (BLACK) (35AMP) (5 TERMINAL) (HIGH CURRENT MICRO 280) (2.483) (ACDelco #D1780C) 19116059 RELAY, ENG CLG BLO (ЧАСТЬ OF 7) (GRAY) (4 TERMINAL) (SPACE SAVER ULTRA 280 MICRO) (2.483) 88953222 RELAY, HDLP (ЧАСТЬ OF 7) (GRAY) (20AMP) (4 TERMINAL) (LOW-PROFILE MICRO 280) (ACDelco #D1755A) [РЕЛЕ] 19116060 PULLER, FUSE (ЧАСТЬ OF 7) 19116051 BREAKER, CIRC (ЧАСТЬ OF 7) (6E02-039) - 2005-2009 E ЗАДНИЕ ФАРЫ ↓ 25773051 WEATHERSTRIP, L/GATE UPR [БОКОВОЙ МОЛДИНГ] 11509428 БОЛТ/SCREW, HEX, W/FLAT WA, M4.2X1.4X13, 12.3 O.D., BHL PT, 6010M, NO (L/GATE APLQ) (8.977) 15211328 GASKET, HIGH MT S/LP (USED W/BEZEL 12335827) [ПРОКЛАДКА] 15211327 GASKET, HIGH MT S/LP (USED WITH BEZEL 12335827) (ON TAB SEAL-T/LP HSG S/LP (ON STUD) [ПРОКЛАДКА] 19121111 BEZEL, HIGH MT S/LP [ОКАНТОВКА ФОНАРЯ ДОПОЛНИТЕЛЬНОГО СТОП-СИГНАЛА] 15930616 ЛАМПА, HIGH MT STOP [ЗАДНИЙ ФОНАРЬ] 15213960 GASKET, HIGH MT S/LP (ON STUD) 11588650 CLIP, 12X14X16.6, GM4345M (L/GATE APLQ) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА] 25759092 GASKET, HIGH MT S/LP (38 OD X 28 ID X 9.5 THICK) [ПРОКЛАДКА МОЛДИНГА ЗАДНЕЙ ОТКИДНОЙ ДВЕРИ] 01999382 BULB, (ЧАСТЬ OF 14, 24) (ACDelco #W5WLL) (LONGER LIFE) 12450108 BULB, TRADE #3157KX (ЧАСТЬ OF 14, 24) (2.679) (ACDelco #3157KX) (LONGER LIFE KRYPTON) [ЛАМПОЧКА НАКАЛИВАНИЯ ФАРЫ 15 ВТ] 25735605 BUMPER, RR LIC PLT PKT (ЧАСТЬ OF 14, 24) (2.662) 12335850 ЛАМПА, B/U & RR LIC (W/RR LIC PLT PKT) (INCLS 10-13) (КРАСКА TO MATCH) 25936964 ЛАМПА, TAIL 25936965 ЛАМПА, TAIL 25936966 ЛАМПА, TAIL [ЗАДНИЙ ФОНАРЬ] 25936967 ЛАМПА, TAIL [ЗАДНИЙ ФОНАРЬ] 25736754 RETAINER, T/LP (PUSH IN) (14 X 21MM HEAD) 11519918 RETAINER, T/LP (PUSH IN) (16MM ROUND HEAD) (2.664) [ФИКСАТОР ЗАДНЕГО ФОНАРЯ] 11517736 ГАЙКА, HEX, M6X1, 5.7 HIGH, 24 OD, 9, 7111M, W/2.5 THK SEALING WA (T/LP) [ГАЙКА М6] 11514517 ГАЙКА, HEX, W/CON SPR WA, M6X1, 5.7THK, 18 O.D., 9, 7111M (B/U & RR LIC PLT LP) [ГАЙКА М6] 11517230 БОЛТ, TORX, W/WA, W/ADH, M6X1X20, 16.2 O.D., DOG PT, 10.9, GM6138M (L/GATE UPR SI APLQ) [ВИНТ ЗАМКА ДВЕРИ М6] 89025118 GASKET, HIGH MT S/LP 15806842 HARNESS, L/GATE LK & R/WDO DEFG & R/WDO WPR WRG 15806843 HARNESS, L/GATE LK & R/WDO DEFG & R/WDO WPR WRG teamcadillac.ru 15930602 ЛАМПА, B/U & RR FOG & RR LIC PLT (INCLS 10, 12, 13, 25, 26) (2.697) 12450108 BULB, TRADE #3157KX (RR FOG LP) (ЧАСТЬ OF 24) (2.679) (ACDelco #3157KX) (LONGER LIFE KRYPTON) [ЛАМПОЧКА НАКАЛИВАНИЯ ФАРЫ 15 ВТ] (6E02-043) - 2008-2009 EB КРЕПЛЕНИЕ АККУМУЛЯТОРА И КАБЕЛИ (LH2/4.6A) ↓ 25781867 SHIELD, BAT HT 11589258 БОЛТ, BAT CBL TERM (M8X1.25X31) [БОЛТ М8] 89022169 АККУМУЛЯТОР, (CCA 770) (TOP POST) (277X174X190) (US DEALERS CONTACT ACDELCO WD FOR ORDERING & PRICING INFO) (ACDelco #48-7YR) (PROFESSIONAL - 7 YR) 11589407 БОЛТ, HWH, M8X1.25X35, 23.5 THD, 24 OD, 10.9, GMW3359, M-PT. (BAT HOLDN RET) [БОЛТ] 25867297 RETAINER, BAT HOLDN 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (BAT TRAY) [БОЛТ М6] 11516589 SCREW, HEX HD W/CON SPR WA, M6X1X30, 29 THD, 17 O.D., 9.8, 7114M, ZE (BAT TRAY) 25783791 TRAY, BAT (INCLS 9) 11518121 ГАЙКА, U, M6X1, MULTI THD, .5'-4.0' THK PNL (ЧАСТЬ OF 8) 11516589 SCREW, HEX HD W/CON SPR WA, M6X1X30, 29 THD, 17 O.D., 9.8, 7114M, ZE (AIR INL) 11518121 ГАЙКА, U, M6X1, MULTI THD, .5'-4.0' THK PNL (AIR INL HSG) 89017760 STARTER, (REMAN) (СМ. ГРУППУ 02.000 "STARTER MOTOR" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #323-1633) (DELCO SERIES PG260H) [СТАРТЕР] 11515535 ГАЙКА, BAT WIRE (2.559) 21021808 ГАЙКА, STRTR SOL CBL (M8X1.25X6, BRASS) [ГАЙКА М8] 11515535 ГАЙКА, BAT WIRE (2.559) 12146809 COVER, GEN WIRE TERM (ЧАСТЬ OF 19) (BLACK) (TERMINAL BOOT COVER) (2.343) 25709327 GENERATOR, (СМ. ГРУППУ 02.000 "КРЕПЛЕНИЕ ГЕНЕРАТОРА" FOR DETAILLED ILLUSTRATED VIEW) (ACDelco #25709327) [ГЕНЕРАТОР 150 А] 11609412 ГАЙКА, HEX W/CON WA, M8X1.25, 7.5 THK, 19 OD, 10 STL, GMW3200 (BAT POS CBL) [ГАЙКА М8] 25848936 CABLE, BAT POS (INCLS 16) (ACDelco #25848936) 11589258 БОЛТ, BAT NEG CBL GND (M8X1.25X31) [БОЛТ М8] 25848940 CABLE, BAT NEG (INCLS 22) (ACDelco #25848940) teamcadillac.ru 10306471 SENSOR, BAT CUR (ЧАСТЬ OF 21) [КАБЕЛЬНАЯ КЛЕММА] (6E02-044) - 2008-2009 EB КРЕПЛЕНИЕ АККУМУЛЯТОРА И КАБЕЛИ (LY7/3.6-7) ↓ 25781867 SHIELD, BAT HT 11610388 STUD, HFLGE, M8X1.25X20, M10X1.5X25, 22.3 OD, 9.8, GMW3200 (BAT CBL TERM) 89022169 АККУМУЛЯТОР, (CCA 770) (TOP POST) (277X174X190) (US DEALERS CONTACT ACDELCO WD FOR ORDERING & PRICING INFO) (ACDelco #48-7YR) (PROFESSIONAL - 7 YR) 11589407 БОЛТ, HWH, M8X1.25X35, 23.5 THD, 24 OD, 10.9, GMW3359, M-PT. (BAT HOLDN RET) [БОЛТ] 25867297 RETAINER, BAT HOLDN 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (BAT TRAY) [БОЛТ М6] 11516589 SCREW, HEX HD W/CON SPR WA, M6X1X30, 29 THD, 17 O.D., 9.8, 7114M, ZE (BAT TRAY) 25783791 TRAY, BAT (INCLS 9) 11518121 ГАЙКА, U, M6X1, MULTI THD, .5'-4.0' THK PNL (ЧАСТЬ OF 8) 11516589 SCREW, HEX HD W/CON SPR WA, M6X1X30, 29 THD, 17 O.D., 9.8, 7114M, ZE (AIR INL) 11518121 ГАЙКА, U, M6X1, MULTI THD, .5'-4.0' THK PNL (AIR INL HSG) 12610857 STARTER, (СМ. ГРУППУ 02.000 "STARTER MOTOR" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #12610857) [СТАРТЕР] 21021808 ГАЙКА, STRTR SOL BAT TERM (M8X1.25X6, BRASS) (2.343) [ГАЙКА М8] 11515535 ГАЙКА, BAT WIRE (2.559) 12146809 COVER, GEN WIRE TERM (ЧАСТЬ OF 18) (BLACK) (TERMINAL BOOT COVER) (2.343) 25751146 GENERATOR, (СМ. ГРУППУ 02.000 "КРЕПЛЕНИЕ ГЕНЕРАТОРА" FOR DETAILLED ILLUSTRATED VIEW) (ACDelco #25751146) [ГЕНЕРАТОР 150 А] teamcadillac.ru 11609412 ГАЙКА, HEX W/CON WA, M8X1.25, 7.5 THK, 19 OD, 10 STL, GMW3200 (BAT POS CBL) [ГАЙКА М8] 25831922 CABLE, BAT POS (INCLS 15) (ACDelco #25831922) 11589258 БОЛТ, BAT NEG CBL GND (M8X1.25X31) [БОЛТ М8] 25848942 CABLE, BAT NEG (INCLS 21) (ACDelco #25848942) 10306471 SENSOR, BAT CUR (ЧАСТЬ OF 20) [КАБЕЛЬНАЯ КЛЕММА] (6E02-045) - 2009 EB СИГНАЛИЗАЦИЯ/ANTI THEFT (UA2) ↓ 15774715 SENSOR, THEFT DTRNT [ДАТЧИК ОБЪЕМА САЛОНА] teamcadillac.ru 11609599 STUD, SPL, M6X1X25, 13 THD, 11 OD HD W/26 WIDE CLIP, 9.8, 6280M, P-PT (THEFT DTRNT ALARM) 25734317 SENSOR, THEFT DTRNT VEH INCLINATION [ДАТЧИК НАКЛОНА КУЗОВА] 10362943 BRACKET, THEFT DTRNT ALARM 11514517 ГАЙКА, HEX, W/CON SPR WA, M6X1, 5.7THK, 18 O.D., 9, 7111M (THEFT DTRNT ALARM) [ГАЙКА М6] 15213135 ALARM, THEFT DTRNT [ЗВУКОВОЙ СИГНАЛ (СИРЕНА) СИГНАЛИЗАЦИИ] (6M02-029) - 2004-2009 E ЖГУТЫ ПРОВОДОВ/ДВИГАТЕЛЬНЫЙ ОТСЕК (LY7/3.6-7) ↓ 19117730 HARNESS, ENG WRG 11562004 БОЛТ, HEX W/FL WA, M10X1.5X30, 19 THD, 20 OD, 8.8, GMW3200, MACH, M-PT (ENG WRG HARN SUPT) teamcadillac.ru 25909407 BLOCK, ENG WRG HARN JUNC 25909408 BLOCK, ENG WRG HARN JUNC 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ENG WRG HARN OXY SEN LEAD BRKT) 12589726 BRACKET, ENG WRG HARN OXY SEN LEAD (HOLD POST SENSOR CONN "POSITION 2 CONNECTOR" ЗАДНИЙ) (6M02-037) - 2007-2009 E КРЕПЛЕНИЕ СТАРТЕРА (LY7/3.6-7) ↓ teamcadillac.ru 12610857 STARTER, (ACDelco #12610857) [СТАРТЕР] 12616647 SHIELD, STRTR HT 11588740 БОЛТ, HFH, M10X1.5X40, 30 THD, 22.3 OD, 10.9, GMW3359, M-PT (STRTR) (ACDelco #11588740) (6M02-038) - 2004-2009 E ЖГУТЫ ПРОВОДОВ/ДВИГАТЕЛЬ В СБОРЕ (LY7/3.6-7) ↓ 19117730 HARNESS, ENG WRG 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ENG WRG HARN) 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (ECM) [БОЛТ] 24574534 STUD, ENG WRG HARN BRKT (M6X1X20) (1.166) teamcadillac.ru 11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (ECM BRKT) [БОЛТ] 12585357 BRACKET, ENG WRG HARN OXY SEN LEAD (HOLDS THE PRE SENSOR CONNECTOR "POSITION 1 CONN") 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (WRG HARN BRKT) (6M02-039) - 2007-2009 E СИГНАЛ (U03) ↓ 25824314 СИГНАЛ, 500 HZ (INCLS 3-6) (ACDelco #D1956F) [ЗВУКОВОЙ СИГНАЛ] 25824316 СИГНАЛ, 400 HZ (INCLS 4, 9) (WITHOUT КРЕПЛЕНИЕ БОЛТ.) (ACDelco #D1955F) 25856297 СИГНАЛ, 400 HZ (INCLS 4, 8, 9) (W/КРЕПЛЕНИЕ БОЛТ) (ACDelco #D1963F) [ЗВУКОВОЙ СИГНАЛ] teamcadillac.ru 11516700 БОЛТ, HEX, W/CON WA, M8X1.25X55, 36THD, 24 O.D., AC PT, 9.8, 7114M (ЧАСТЬ OF 7) (6Y02-018) - 2006-2009 E РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ & МОДУЛЬ/ЗАЖИГАНИЕ (LH2/4.6A) ↓ 12597745 РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ, IGN (INCLS 705) (ACDelco #D598A) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 704) 12602860 HARNESS, IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ WRG 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ) 11588967 STUD, BALL W/HFH, M6X1X20.65, 14.2 O.D., 8.8, GMW3359 (IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ) 89018106 BRACKET, IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ (ACDelco #89018106) 03 - ТОПЛИВНАЯ СИСТЕМА - ВЫХЛОПНАЯ - СИСТЕМА ВЫПУСКА ВОЗДУХА ↓ (6D03-070) - 2007-2009 E БЛОК ЭЛЕКТРОННОГО УПРАВЛЕНИЯ И СВЯЗАННЫЕ ДЕТАЛИ (LH2/4.6A) ↓ teamcadillac.ru 15839206 BRACKET, ECM (INCLS 2, 3, 6) 11562079 STUD - M6X1X30, 1010 STEEL, FINISH GMW3200 (ЧАСТЬ OF 1) 11609669 БОЛТ, HX HD FLT WA, M6X1.0X25.0, GM500M (9.8) STL, GMW3200 (ЧАСТЬ OF 1) [БОЛТ] 12625453 МОДУЛЬ, ENG CONT (W/ 2ND MPU) (ACDelco #12625453) 11514517 ГАЙКА, HEX, W/CON SPR WA, M6X1, 5.7THK, 18 O.D., 9, 7111M (ЧАСТЬ OF 1) [ГАЙКА М6] (6E03-009) - 2007-2009 EB АКСЕЛЕРАТОР (EXC JF4) ↓ 15860872 PEDAL, ACCEL (INCLS 2, 3) teamcadillac.ru 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (ACCEL PED LVR) (6E03-010) - 2007-2009 EB АКСЕЛЕРАТОР (JF4) ↓ teamcadillac.ru 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (ACCEL PED LVR) 25838051 PEDAL, ACCEL (INCLS 3, 4) [ПЕДАЛЬ АКСЕЛЕРАТОРА] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 89047780 MOTOR KIT, BRK & ACCEL PED ADJR ACTR (INCLS 9) [ЭЛЕКТРОДВИГАТЕЛЬ ПЕДАЛЬНОГО УЗЛА 19 ВТ] 89047778 CABLE, BRK PED ADJR ACTR [ЖГУТ ПРОВОДОВ] 89047779 CABLE, ACCEL CONT (6E03-012) - 2004-2009 E ТОПЛИВНЫЙ БАК & КРЕПЛЕНИЕ ↓ 25862765 CAP, F/TNK FIL LK (0.1KGS) (ACDelco #GT264) [КРЫШКА ТОПЛИВОНАЛИВНОЙ ГОРЛОВИНЫ] 15775325 DOOR, F/TNK FIL (INCLS 6) 11509374 БОЛТ, SCR HEX W/FL WA, SELF TAP, 4.2X1.41X16, 12.5 O.D. (F/TNK FIL PIPE) 25773939 ШЛАНГИ, F/TNK FIL PIPE [КОЖУХ ТОПЛИВОЗАЛИВНОЙ ГОРЛОВИНЫ] teamcadillac.ru 89047657 BUMPER, F/TNK FIL DR (ЧАСТЬ OF 3) (HINGE) [ВТУЛКА] 11609731 RIVET, F/TNK FIL DR (25" SHANK, .63 LEN, .50 OD, .06-.30 GRP RNG, 1008 STL, GMW3044) (8.967) 15868848 PIPE, F/TNK FIL (INCLS 9, 10, 15, 19, 20) [ТРУБКА ТОПЛИВОЗАЛИВНОЙ ГОРЛОВИНЫ] 01470030 CЛАМПА, WORM TYPE (11/16" TO 1 5/16") (ЧАСТЬ OF 8) (ACDelco #1470030) 09177063 CЛАМПА, F/TNK FIL HOSE (ЧАСТЬ OF 12) (25-40MM CЛАМПА RANGE) 15925741 HOSE, F/TNK FIL (INCLS 11) [ШЛАНГ ТОПЛИВНОЙ СИСТЕМЫ] 09177063 CЛАМПА, F/TNK FIL HOSE (25-40MM CЛАМПА RANGE) 11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (F/TNK FIL PIPE BRKT) [БОЛТ М8] 15638098 RETAINER, FUEL RTN PIPE FTG (ЧАСТЬ OF 8) (NATURAL) (NYLON) (5/16") (7.9MM) 11517101 БОЛТ, METRIC HEX FLANGE HD, M10X1.5X50 (F/TNK STRP) [БОЛТ М10] 25679207 STRAP, F/TNK [ЗАЖИМ БЕНЗОБАКА] 12337820 STRAP, 15" TIE STRAP (ЧАСТЬ OF 8) (ACDelco #12337820) 25880365 ПРУЖИНА, F/TNK FIL DR (PRIOR TO INSTALL SEAL VOIDS IN PLUNGER HSG W/FLEXIABLE SEALER) [ЗАЩЕЛКА ЛЮЧКА ТОПЛИВНОЙ ГОРЛОВИНЫ] (6E03-013) - 2004-2009 E СИСТЕМА ТОПЛИВОСНАБЖЕНИЯ (LH2/4.6A) ↓ 25843248 HARNESS, FUEL SDR WRG (3.115) 25932011 HARNESS, FUEL SDR WRG (3.115) 19151155 SENDER KIT, FUEL (INCLS 24) (SECONDARY МОДУЛЬ) (ACDelco #SK1307) 19177355 CANISTER, EVAP EMIS (CANISTER WITHOUT COVER OR FILTER) (INCLS 39, 43) (ACDelco #215-644) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (EVAP EMIS CNSTR BRKT) [ГАЙКА М6] 15278918 PIPE, EVAP EMIS CNSTR PURGE 15219486 PIPE, FUEL FEED RR (INCLS 35) 15219484 PIPE, FUEL RTN RR 22514722 SEAL, FUEL FEED FRT PIPE (O RING) (ЧАСТЬ OF PIPE, FEED & RTN ASM BUNDLE) (7.35MM ID X 1.66MM THK) (ACDelco #217-452) [КОЛЬЦО УПЛОТНИТЕЛЬНОЕ, ТОПЛИВНОЙ ТРУБКИ] 25763176 ФИЛЬТР, FUEL (ACDelco #GF897) [ТОПЛИВНЫЙ ФИЛЬТР] 11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (FUEL FLTR BRKT) [БОЛТ М8] 25909398 RETAINER, FUEL FLTR 25917777 PIPE, EVAP EMIS CNSTR PURGE 15145717 PIPE, FUEL FEED (INCLS 19) 25917776 PIPE, FUEL FEED (INCLS 19) 25761218 BRACKET, FUEL PIPE 25761217 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (3.162) 25765594 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (42.10MM LENGTH) (3.162) [ФИКСАТОР ТОРМОЗНЫХ ТРУБОК] teamcadillac.ru 25679213 PIN, F/TNK UPR SHLD 25679209 SHIELD, F/TNK 25894460 TANK, FUEL (INCLS 21, 26, 27, 31, 33, 34) [ТОПЛИВНЫЙ БАК] 25901272 SEAL, FUEL SDR (ЧАСТЬ OF 2, 28, 44) (ACDelco #G37) 25740096 CAM, FUEL SDR (ACDelco #TR23) 19181827 МОДУЛЬ KIT, F/TNK F/PMP (W/O FUEL LVL SEN) (INCLS 24) (ACDelco #M10201) [ТОПЛИВНЫЙ НАСОС] 25679252 RETAINER, FUEL FEED & EVAP EMIS & RTN FRT PIPE (HOLDS 15.8/7.95/7.0 TUBES, HAS CHRISTMAS TREE RETAINER) (3.162) 15951521 PIPE, FUEL SDR FUEL FEED (INCLS CONN) (PIPE ATTACHES TO SENDING UNITS INSIDE OF GAS TANK) [ТРУБКА ТОПЛИВНОЙ СИСТЕМЫ] 16238399 SENSOR, F/TNK PRESS (ACDelco #16238399) [ДАТЧИК ДАВЛЕНИЯ ПАРОВ ТОПЛИВА] 25867885 RETAINER, BRK & FUEL PIPE (CLIP - HOLDS THREE TUBES WITH PLASTIC TREE ATTACHMENT.) 25867886 RETAINER, BRK & FUEL PIPE (CLIP - HOLDS FIVE TUBES) 25751324 RETAINER, FUEL FEED & EVAP EMIS & RTN FRT PIPE (HOLDS 7.95 & 9.5 DIA FUEL LINE, HAS CHRISTMAS TREE RETAINER) (3.162) 17114722 HOSE, EVAP EMIS CNSTR AIR INL (3.130) (ACDelco #219-366) 19177365 FILTER KIT, EVAP EMIS CNSTR (W/ SEAL) (INCLS 40) 25932573 VALVE, EVAP EMIS CNSTR VENT SOL (ACDelco #214-2230) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 19151153 SENSOR KIT, FUEL LVL (INCLS 24) (ACDelco #SK1267) (6E03-016) - 2007-2009 E СИСТЕМА ОТРАБОТАВШИХ ГАЗОВ (LH2/4.6A,EXC CHROME EXHAUST NDB) ↓ 12607145 SENSOR, HTD OXY (POSN 1) (IN EXH MANIFOLD/CROSSOVER) (ACDelco #213-4116) [КИСЛОРОДНЫЙ ДАТЧИК] 15240254 BRACKET, EXH TAIL PIPE HNGR (INCLS 3) [КРОНШТЕЙН] 25902027 BRACKET, EXH TAIL PIPE HNGR (INCLS 3) 15284207 INSULATOR, EXH TAIL PIPE HNGR (ЧАСТЬ OF 2) [ДЕМПФЕР ГЛУШИТЕЛЯ] 15251184 PIPE, EXH TAIL (ЧАСТЬ OF 6) (3.701) 25711603 INSULATOR, EXH MUFF HNGR BRKT (ЧАСТЬ OF 6) teamcadillac.ru 15290902 MUFFLER, EXH (W/RESO, EXH & TAIL PIPE) (INCLS 4, 5) 11517031 ГАЙКА, HFH, M8X1.25, 9.4THK, 17.4 O.D., 10, TIN ZN (EXH MUFF) 12610969 SENSOR, HTD OXY (POSN 3) (POST CONVERTER) (ACDelco #213-4197) [КИСЛОРОДНЫЙ ДАТЧИК] 25709703 SEAL, CTLTC CONV (ЧАСТЬ OF 11) (ROUND METAL SEAL) [ПРОКЛАДКА НАСОСА] 11609596 STUD, CTLTC CONV (ЧАСТЬ OF 11) [ШПИЛЬКА] 12607450 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 9, 10) (3.685) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 12607451 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 9, 10) (3.685) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] (6E03-017) - 2004-2009 E СИСТЕМА ТОПЛИВОСНАБЖЕНИЯ (LY7/3.6-7) ↓ 25843248 HARNESS, FUEL SDR WRG (3.115) 25932011 HARNESS, FUEL SDR WRG (3.115) 19151155 SENDER KIT, FUEL (INCLS 24) (SECONDARY МОДУЛЬ) (ACDelco #SK1307) 19177355 CANISTER, EVAP EMIS (CANISTER WITHOUT COVER OR FILTER) (INCLS 46) (ACDelco #215-644) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (EVAP EMIS CNSTR BRKT) [ГАЙКА М6] 15278918 PIPE, EVAP EMIS CNSTR PURGE 15219486 PIPE, FUEL FEED RR (INCLS 35) 15219484 PIPE, FUEL RTN RR 22514722 SEAL, FUEL FEED FRT PIPE (O RING) (ЧАСТЬ OF PIPE, FEED & RTN ASM BUNDLE) (7.35MM ID X 1.66MM THK) (ЧАСТЬ OF 15) (ACDelco #217-452) [КОЛЬЦО УПЛОТНИТЕЛЬНОЕ, ТОПЛИВНОЙ ТРУБКИ] 25763176 ФИЛЬТР, FUEL (ACDelco #GF897) [ТОПЛИВНЫЙ ФИЛЬТР] 11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (FUEL FLTR BRKT) [БОЛТ М8] 25909398 RETAINER, FUEL FLTR teamcadillac.ru 25688547 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (RETAINER W/5 HOLES (2)7.95, (2)4.76, (1)9.52MM) 25749839 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (HOLDS 3 ТРУБКИ, FLAT SHAPE, SNAP-IN RETAINER) 15888146 PIPE, EVAP EMIS CNSTR PURGE (INCLS 37, 39) 15145717 PIPE, FUEL FEED (INCLS 8, 19) 25761218 BRACKET, FUEL PIPE 25761217 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (3.162) 25679252 RETAINER, FUEL FEED & EVAP EMIS & RTN FRT PIPE (HOLDS 15.8/7.95/7.0 TUBES, HAS CHRISTMAS TREE RETAINER) (3.162) 25679213 PIN, F/TNK UPR SHLD 25679209 SHIELD, F/TNK 25894460 TANK, FUEL (INCLS 21, 26, 27, 31, 33, 34) [ТОПЛИВНЫЙ БАК] 25901272 SEAL, FUEL SDR (ЧАСТЬ OF 2, 28, 47) (ACDelco #G37) 25740096 CAM, FUEL SDR (ACDelco #TR23) 19181827 МОДУЛЬ KIT, F/TNK F/PMP (W/O FUEL LVL SEN) (INCLS 24) (ACDelco #M10201) [ТОПЛИВНЫЙ НАСОС] 25679252 RETAINER, FUEL FEED & EVAP EMIS & RTN FRT PIPE (HOLDS 15.8/7.95/7.0 TUBES, HAS CHRISTMAS TREE RETAINER) (3.162) 15951521 PIPE, FUEL SDR FUEL FEED (INCLS CONN) (PIPE ATTACHES TO SENDING UNITS INSIDE OF GAS TANK) [ТРУБКА ТОПЛИВНОЙ СИСТЕМЫ] 16238399 SENSOR, F/TNK PRESS (ACDelco #16238399) [ДАТЧИК ДАВЛЕНИЯ ПАРОВ ТОПЛИВА] 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (FUEL FEED & EVAP EMIS & RTN PIPE CLIP BRKT) [БОЛТ М6] 25654373 CLIP, FUEL FEED & RTN HOSE (PLASTIC) 25726788 RETAINER, BRK & FUEL PIPE (SQUARE HEAD PUSH PIN W/5 HOLES (2)4.76. (2)8.00 (1)9.52) [ФИКСАТОР ТОРМОЗНЫХ ТРУБОК] 17114722 HOSE, EVAP EMIS CNSTR AIR INL (3.130) (ACDelco #219-366) 19177365 FILTER KIT, EVAP EMIS CNSTR (W/ SEAL) (INCLS 42, 43) 25932573 VALVE, EVAP EMIS CNSTR VENT SOL (ACDelco #214-2230) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 19151153 SENSOR KIT, FUEL LVL (INCLS 24) (ACDelco #SK1267) (6E03-019) - 2007-2009 E БЛОК ЭЛЕКТРОННОГО УПРАВЛЕНИЯ И СВЯЗАННЫЕ ДЕТАЛИ (LY7/3.6-7) ↓ 12623327 МОДУЛЬ, ENG CONT (W/O CALN) 25784072 BRACKET, ECM (INCLS 5, 6) 24239785 МОДУЛЬ, TRANS CONT (W/O CALN) teamcadillac.ru 11609462 SCREW, M4.2X1.41X13, GMW4205 (ЧАСТЬ OF 3) 11561758 БОЛТ, MULTIUSE RLY & FUSE BRKT (7.833) [БОЛТ] 15879156 BRACKET, ACSRY WRG J/BLK 11609599 STUD, SPL, M6X1X25, 13 THD, 11 OD HD W/26 WIDE CLIP, 9.8, 6280M, P-PT (MULTIUSE FUSE BRKT) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (MULTIUSE RLY & FUSE BRKT) [ГАЙКА М6] (6E03-021) - 2007-2009 E СИСТЕМА ОТРАБОТАВШИХ ГАЗОВ (LH2/4.6A, CHROME EXHAUST NDB) ↓ 12607145 SENSOR, HTD OXY (POSN 1) (IN EXH MANIFOLD/CROSSOVER) (ACDelco #213-4116) [КИСЛОРОДНЫЙ ДАТЧИК] 15240254 BRACKET, EXH TAIL PIPE HNGR (INCLS 3) [КРОНШТЕЙН] 25902027 BRACKET, EXH TAIL PIPE HNGR (INCLS 3) 15284207 INSULATOR, EXH TAIL PIPE HNGR (ЧАСТЬ OF 2) [ДЕМПФЕР ГЛУШИТЕЛЯ] 15251184 PIPE, EXH TAIL (ЧАСТЬ OF 7) (3.701) teamcadillac.ru 15828673 EXTENSION, EXH TAIL PIPE (ЧАСТЬ OF 7) 25711603 INSULATOR, EXH MUFF HNGR BRKT (ЧАСТЬ OF 7) 15832125 MUFFLER, EXH (W/RESO, EXH & TAIL PIPE) (INCLS 4-6) 11517031 ГАЙКА, HFH, M8X1.25, 9.4THK, 17.4 O.D., 10, TIN ZN (EXH MUFF) 12609159 SENSOR, HTD OXY (POSN 2) (POST CONVERTER) (ACDelco #213-4156) [ДАТЧИК КИСЛОРОДНЫЙ] 25709703 SEAL, CTLTC CONV (ЧАСТЬ OF 11) (ROUND METAL SEAL) [ПРОКЛАДКА НАСОСА] 12607450 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 10, 12) (3.685) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 12607451 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 10, 12) (3.685) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 11609596 STUD, CTLTC CONV (ЧАСТЬ OF 11) [ШПИЛЬКА] (6E03-022) - 2007-2009 E СИСТЕМА ВПУСКА ВОЗДУХА (LH2/4.6A) ↓ 25798271 ELEMENT, КОНДИЦИОНЕРL (ACDelco #A2944C) [ВОЗДУШНЫЙ ФИЛЬТР ДВИГАТЕЛЯ] 11561910 БОЛТ, КОНДИЦИОНЕРL (M6X1.0X24) (T30 TORQ) (SHLDR W/FL WA) 19151529 COVER, КОНДИЦИОНЕРL HSG LWR (INCLS 2, 3, 7) [КРЫШКА ВОЗДУХОЗАБОРНИКА] 11561910 БОЛТ, КОНДИЦИОНЕРL (M6X1.0X24) (T30 TORQ) (SHLDR W/FL WA) 19177871 INSULATOR, КОНДИЦИОНЕРL HSG (ЧАСТЬ OF 5) (MOUNT TO MID RAIL) 11609385 ГАЙКА, U-TYPE, M6X1, 29.5 LEN, 12.5 WID, 19.5 CEN-END, 1050, GMW3359 (КОНДИЦИОНЕРL) [ГАЙКА М 6] 15833712 DUCT, КОНДИЦИОНЕРL OTLT (INCLS 9) (3.417) [ШЛАНГ ВОЗДУХООЧИСТИТЕЛЯ] teamcadillac.ru 15865791 SENSOR, MASS AIRFLOW (W/INT AIR TEMP SEN) (ЧАСТЬ OF 14) (MASS AIRFLOW SENSOR LABELED 5791 LESS GASKET) (ACDelco #213-4222) [ДАТЧИК РАСХОДА ВОЗДУХА] 25805631 ADAPTER, MASS AIRFLOW SEN INL (INCLS 12, 13) [АДАПТЕР ПОТОКОВ ВОЗДУХА] 15147461 GASKET, MASS AIRFLOW SEN (ROUND) 11516424 БОЛТ, HFH, M6X1X25, 14.2 O.D., HDR PT, 9.8, ZE (MASS AIRFLOW SEN) [БОЛТ М6] 15147459 COVER, КОНДИЦИОНЕРL HSG (INCLS 11) [КРЫШКА ВОЗДУХООЧИСТИТЕЛЯ] (6E03-023) - 2007-2009 E СИСТЕМА ВПУСКА ВОЗДУХА (LY7/3.6-7) ↓ 25798271 ELEMENT, КОНДИЦИОНЕРL (ACDelco #A2944C) [ВОЗДУШНЫЙ ФИЛЬТР ДВИГАТЕЛЯ] 11588831 SCREW, HEX W/ CON WA, M6X1X35, 33.5 THD, 17 O.D.HDR PT, 9.8, BLK (КОНДИЦИОНЕРL) 19151528 COVER, КОНДИЦИОНЕРL HSG LWR (INCLS 2, 3, 7) [КРЫШКА ВОЗДУХООЧИСТИТЕЛЯ] teamcadillac.ru 11561910 БОЛТ, КОНДИЦИОНЕРL (M6X1.0X24) (T30 TORQ) (SHLDR W/FL WA) 19177871 INSULATOR, КОНДИЦИОНЕРL HSG (ЧАСТЬ OF 5) (MOUNT TO MID RAIL) 11609385 ГАЙКА, U-TYPE, M6X1, 29.5 LEN, 12.5 WID, 19.5 CEN-END, 1050, GMW3359 (КОНДИЦИОНЕРL) [ГАЙКА М 6] 25733253 CЛАМПА, RR INT AIR DUCT (ЧАСТЬ OF 10) (FLEX END) 15812947 DUCT, RR INT AIR (W/RESO) (INCLS 9, 11) 25733254 CЛАМПА, RR INT AIR DUCT (ЧАСТЬ OF 10) (ELBOW END) 10356575 БОЛТ, MASS AIRFLOW SEN (ЧАСТЬ OF 16) 15875837 SENSOR, MASS AIRFLOW (ACDelco #213-4250) [ДАТЧИК] 15147456 GASKET, MASS AIRFLOW SEN 11516424 БОЛТ, HFH, M6X1X25, 14.2 O.D., HDR PT, 9.8, ZE (КОНДИЦИОНЕРL HSG) [БОЛТ М6] 15147455 COVER, КОНДИЦИОНЕРL HSG (INCLS 12) [КРЫШКА ВОЗДУШНОГО ФИЛЬТРА] (6E03-024) - 2008-2009 E СИСТЕМА ОТРАБОТАВШИХ ГАЗОВ (LY7/3.6-7) ↓ 15240254 BRACKET, EXH TAIL PIPE HNGR (INCLS 2) [КРОНШТЕЙН] 25902027 BRACKET, EXH TAIL PIPE HNGR (INCLS 2) 15284207 INSULATOR, EXH TAIL PIPE HNGR (ЧАСТЬ OF 1) [ДЕМПФЕР ГЛУШИТЕЛЯ] 15251183 PIPE, EXH TAIL (ЧАСТЬ OF 5) 15927181 MUFFLER, EXH (W/RESO, EXH & TAIL PIPE) (INCLS 3, 4) [ГЛУШИТЕЛЬ С ВЫХЛОПНОЙ ТРУБОЙ] 15927182 MUFFLER, EXH (W/RESO, EXH & TAIL PIPE) (INCLS 3, 4) 25797844 MUFFLER, EXH (W/RESO, EXH & TAIL PIPE) (INCLS 3, 4) 11517031 ГАЙКА, HFH, M8X1.25, 9.4THK, 17.4 O.D., 10, TIN ZN (EXH MUFF) 12597449 SENSOR, HTD OXY (POSN 2) (POST CONVERTER) (ACDelco #213-3851) [КИСЛОРОДНЫЙ ДАТЧИК] 15879730 SEAL, CTLTC CONV (ЧАСТЬ OF 9) (SPHERICAL OUTLET SEAL) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КАТАЛИТИЧЕСКОГО НЕЙТРАЛИЗАТОРА] 25939989 CONVERTER, 3WAY CTLTC (INCLS 8, 10, 12, 13) [КАТАЛИТИЧЕСКИЙ НЕЙТРАЛИЗАТОР ВЫХЛОПНЫХ ГАЗОВ] 25971634 CONVERTER, 3WAY CTLTC (INCLS 8, 10, 12, 13) [КАТАЛИТИЧЕСКИЙ НЕЙТРАЛИЗАТОР ВЫХЛОПНЫХ ГАЗОВ] teamcadillac.ru 11569946 STUD-STRAIGHT-M8X1.25X38, M8X1.25X12, W/EXT SOC, 56 OAL, 10.9, GM6164M (ЧАСТЬ OF 9) [ОСЬ] 12594935 SENSOR, HTD OXY (POSN 1) (IN EXH MANIFOLD/CROSSOVER) (ACDelco #213-3850) [ДАТЧИК КИСЛОРОДНЫЙ] 11570494 STUD, CTLTC CONV (ЧАСТЬ OF 9) [ШПИЛЬКА М8] 25857958 SEAL, CTLTC CONV (INLET SEAL (W/O SHIELD)) [ПРОКЛАДКА ВЫХЛОПНОЙ ТРУБЫ] 12571101 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 12571102 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 15709703 ГАЙКА, HEX 10X1.5THD, 21.8 OD SS (CTLTC CONV) [ГАЙКА М10] (6M03-088) - 2004-2009 E РАМКА ТОПЛИВНОГО ИНЖЕКТОРА (LY7/3.6-7) ↓ 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (WRG HARN BRKT) 12596182 HARNESS, F/INJR WRG (INCLS 2) (IF REPL 12584312 MAY NEED TO INSTALL BRACKET FROM HARNESS.) 25532662 CAP, FUEL PRESS SERV VLV (CAP FOR PRESSURE TEST SCHRADER VALVE) (*KIT2) (3.163) (ACDelco #214-1044) [КРЫШКА] 12572886 RAIL, F/INJN FUEL (INCLS 5, 9) (ACDelco #217-1551) [МАГИСТРАЛЬ ТОПЛИВНЫХ ФОРСУНОК ДВИГАТЕЛЯ] 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (F/INJN FUEL RL) [БОЛТ] 12609418 INJECTOR, M/PORT FUEL (INCLS 8, 11) (ACDelco #217-3034) 12597872 SEAL KIT, F/INJR (O RING) (INCLS 8, 11) (ACDelco #217-2444) teamcadillac.ru 12584592 VALVE KIT, FUEL PRESS SERV (INCLS 4, 5) (INCLUDES CAP AND VALVE) (ACDelco #12584592) [КЛАПАН] 12584591 RETAINER KIT, F/INJR (INCLS 9) (ACDelco #12584591) [ОПОРНАЯ ПЛАСТИНА ТОПЛИВНОЙ ФОРСУНКИ] (6M03-090) - 2007-2009 E РАМКА ТОПЛИВНОГО ИНЖЕКТОРА (LH2/4.6A) ↓ 12598329 RAIL KIT, SEQ M/PORT F/INJN FUEL (ACDelco #X2598329) 12597871 INJECTOR KIT, SEQ M/PORT FUEL (INCLS 562-564) (ACDelco #217-2443) [ТОПЛИВНАЯ ФОРСУНКА] teamcadillac.ru 25532662 CAP, FUEL PRESS SERV VLV (CAP FOR PRESSURE TEST SCHRADER VALVE) (*KIT3) (3.163) (ACDelco #214-1044) [КРЫШКА] 12574525 VALVE, FUEL PRESS SERV (SCHRADER VALVE LESS CAP) (*KIT3) [КЛАПАН КОНТРОЛЯ ДАВЛЕНИЯ ТОПЛИВНОЙ СИСТЕМЫ] 12584591 RETAINER KIT, F/INJR (INCLS 562) (ACDelco #12584591) [ОПОРНАЯ ПЛАСТИНА ТОПЛИВНОЙ ФОРСУНКИ] 12597872 SEAL KIT, F/INJR (O RING) (INCLS 563, 564) (ACDelco #217-2444) 12584592 VALVE KIT, FUEL PRESS SERV (INCLS 565, 566) (INCLUDES CAP AND VALVE) (ACDelco #12584592) [КЛАПАН] 04 - АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ↓ (6D04-023) - 2004-2009 E СТОЯНОЧНЫЙ ТОРМОЗ ASM ↓ 88951984 PLATE, RR PARK BRK ANC BKG (4.591) teamcadillac.ru 88951985 PLATE, RR PARK BRK ANC BKG (4.591) 88951982 ACTUATOR KIT, RR PARK BRK (INCLS 2) (ACDelco #179-2053) [АКТУАТОР] 88951983 ACTUATOR KIT, RR PARK BRK (INCLS 2) (ACDelco #179-2054) [АКТУАТОР] 89047676 SHOE KIT, RR PARK BRK (INCLS 5) (ACDelco #171-0915) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (2 ШТ)] (6D04-031) - 2004-2009 E ТОРМОЗНОЙ СУППОРТ-ЗАДНИЙ ↓ 89047677 CALIPER KIT, RR BRK (INCLS 2, 3, 7-9) (ACDelco #172-2343) teamcadillac.ru 89047678 CALIPER KIT, RR BRK (INCLS 2, 3, 7-9) (ACDelco #172-2344) [ТОРМОЗНОЙ СУППОРТ] 88951992 CAP, RR BRK BLEDR VLV (ЧАСТЬ OF 1) 88951991 VALVE, RR BRK CLPR BLEDR (ЧАСТЬ OF 1) 89047757 PAD KIT, RR DISC BRK (INCLS 4, 12) (ACDelco #171-859) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4 ШТ)] 89047758 PAD KIT, RR DISC BRK (INCLS 4, 12) (4.667) (ACDelco #171-0906) [ТОРМОЗНЫЕ КОЛОДКИ] 88957163 BRACKET, RR BRK CLPR [СКОБА ТОРМОЗНОГО СУППОРТА] 89047759 PIN KIT, RR BRK CLPR GDE (INCLS 4-6) (INCLS 2 PINS, 2 SEALS & 2 (2.75") БОЛТS) (ACDelco #179-2044) [НАПРАВЛЯЮЩАЯ ТОРМОЗНОГО СУППОРТА (2 ШТ)] 88957162 REPAIR KIT, RR BRK CLPR HYD (INCLS 4, 6, 8, 9) (6D04-033) - 2004-2009 E ТОРМОЗНОЙ УСИЛИТЕЛЬ ↓ 88967237 BOOSTER, P/B (W/O VLV) (ACDelco #178-0695) teamcadillac.ru 05461808 GROMMET, P/B BOOS VAC CHK VLV (*KIT1) 03817880 RETAINER, BRK PED PUSH ROD (0.80 IN) (PUSH IN) 18022219 VALVE KIT, P/B BOOS VAC CHK (INCLS 2, 3) (BLACK) (INCLS VLV & GROM) (ACDelco #179-1266) (6D04-067) - 2007-2009 E КОРПУС КП КРЕПЛЕНИЕ (MYB,MX7) ↓ 24231525 GASKET, TRFER CASE 19132968 CASE, TRFER (W/GEARS) (LESS DAMPENER) teamcadillac.ru 24243367 CASE, TRFER (W/GEARS) 11589341 БОЛТ - HFH, M10X1.5X69.9, 28.35 THD, 22.3 OD, 10.9, GMW3359, M-PT. (TRFER CASE) [БОЛТ] (6E00-014) - 2004-2009 E ТРАНСМИССИЯ TO КРЕПЛЕНИЕ ДВИГАТЕЛЯ (LY7/3.6-7) ↓ teamcadillac.ru 12572042 PLATE, A/TRNS FLEX 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (TRANS CVR) [БОЛТ] 24222918 COVER, TRANS CONV 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] (6E03-019) - 2007-2009 E T.C.M. МОДУЛЬ (LY7/3.6-7) ↓ 12623327 МОДУЛЬ, ENG CONT (W/O CALN) 25784072 BRACKET, ECM (INCLS 5, 6) 24239785 МОДУЛЬ, TRANS CONT (W/O CALN) 11609462 SCREW, M4.2X1.41X13, GMW4205 (ЧАСТЬ OF 3) 11561758 БОЛТ, MULTIUSE RLY & FUSE BRKT (7.833) [БОЛТ] 15879156 BRACKET, ACSRY WRG J/BLK 11609599 STUD, SPL, M6X1X25, 13 THD, 11 OD HD W/26 WIDE CLIP, 9.8, 6280M, P-PT (MULTIUSE FUSE BRKT) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (MULTIUSE RLY & FUSE BRKT) [ГАЙКА М6] (6E04-007) - 2007-2009 EB ТОРМОЗНЫЕ ШЛАНГИ И ТРУБКИ ↓ 15933099 HOSE, FRT BRK (INCLS 15, 16) (ACDelco #176-1495) 11569742 RETAINER, FRT BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (BRK & FUEL FEED & FUEL RTN & EVAP EMIS) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА] 25761218 BRACKET, FUEL PIPE 25761217 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (3.162) 12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (FRT BRK) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА] 10388788 PIPE, BRK PRESS MOD VLV FRT (INCLS 29) 10388794 PIPE, BRK PRESS MOD VLV RR (INCLS 29) 03541444 SPACER, FRT BRK PIPE teamcadillac.ru 11516521 БОЛТ, HFH M6X1X20, 9.8, 7114M, DOG PT, 14.2 OD (FRT BRK HOSE) 15933098 HOSE, FRT BRK (INCLS 15, 16) (ACDelco #176-1487) 25743891 RETAINER, RR BRK FRT PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT) 11569737 FITTING, FRT BRK PIPE (ЧАСТЬ OF 1, 12) (7/16-24X0.36, 0.30THD) (0.56 LONG, 3/16TUBE) 25743891 RETAINER, FRT BRK PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT) 15904901 CLIP, FRT BRK PIPE (STAR SHAPED 3 TUBE W/TREE) [КРОНШТЕЙН] 25737279 CLIP, FRT BRK PIPE (THREE WAY RETAINER SINGLE CENTRAL FIR-TREE ATTACHMENT) 25749839 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (HOLDS 3 ТРУБКИ, FLAT SHAPE, SNAP-IN RETAINER) 25867884 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE 15880948 RETAINER, BRK PIPE (FOR 5 LINES W/45 DEGREE PUSHPIN) 25607191 RETAINER, BRK PIPE (21.5X10.0MM) (HOLDS (2) 4.68-4.82 TUBES) 11569742 RETAINER, RR BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 15724650 ГАЙКА, INVERTED FLARED TUBE, 9/16"-18, 1/4" TUBE, ZD (BRK PIPE) (4.686) [ГАЙКА] 25693890 RETAINER, RR BRK PIPE (HOLDS (1) 4.76 LINE) (W/TREE) [ЗАМОК, ФИКСАТОР] 11588803 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 7, 8) (1/2-20X.40, .32 THD) (INVERTED FLARED TUBE) (.62 LONG, 1/4 TUBE) [ГАЙКА М20] 15724650 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 7, 8) (9/16-18 X .40) (INVERTED FLARED TUBE) [ГАЙКА] 15933091 HOSE, RR BRK (INCLS 22, 23) (ACDelco #15933091) 15933092 HOSE, RR BRK (INCLS 22, 23) (ACDelco #15933092) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ] 88964150 PROTECTOR, RR BRK PIPE (FOR 3/16" PIPE) (HT SHRINK) (6E04-008) - 2007-2009 EB ТОРМОЗНАЯ ПЕДАЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (EXC (JF4)) ↓ 25732428 BARRIER, BRK PED BRKT SND 25697461 RETAINER, BRK PED PUSH ROD BOOT 25732452 BOOT, BRK PED PUSH ROD 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) teamcadillac.ru 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] 15932827 HOSE, P/B BOOS VAC (ACDelco #176-1496) 25818868 PEDAL, BRK (W/BRKT) (INCLS 10, 11, 14, 16-18) 25771615 COVER, BRK PED (ЧАСТЬ OF 9) 89047699 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 9) [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 9) 10434956 BUSHING, BRK PED PUSH ROD 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 9) 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 9) (0.80 IN) (PUSH IN) (6E04-012) - 2007-2009 E КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS(MYB,MX7) ↓ 88996677 CASE, TRFER (FRT HALF) (INCLS 12-14) 19133265 CASE, TRFER (RR HALF) (INCLS 5, 7) 88996679 SNUBBER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN 88996680 БОЛТ, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN SNBR (M5X0.8X16) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 2) 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL FILL) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996657 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 2) [УПЛОТНИТЕЛЬ] 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL DRN) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996680 БОЛТ, TRFER CASE VENT BFL (M5X0.8X16) (4.535) 88996658 BAFFLE, TRFER CASE VENT 89048123 БОЛТ, TRFER CASE HALF (M8X1.25X30) teamcadillac.ru 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 1) 88996656 SEAL, TRFER CASE INPUT SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 88996657 SEAL, TRFER CASE FRT ВЫХОДНОЙ SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] (6E04-013) - 2008-2009 E КОРПУС КП ЧАСТЬ 2 INTERNAL COMPONENTS(MX5) ↓ 88984517 WASHER, TRFER CASE PLNT CARR SUN GR THR (25.8X52.0X2.2) 88984524 GEAR, TRFER CASE PLNT CARR SUN (INPUT) (STAMPED PM/POWDERED METAL) 88984493 RING, TRFER CASE RR ВЫХОДНОЙ SHF RR BRG RET (41MM I.D.) (ACDelco #88984493) 88996564 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT 88996665 BEARING, TRFER CASE MAIN SHF FRT (ВЫХОДНОЙ ВАЛ FRT) teamcadillac.ru 19168733 BUSHING, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 106) [ВТУЛКА РАЗДАТОЧНОЙ КОРОБКИ] 19178237 SHAFT, TRFER CASE RR ВЫХОДНОЙ (INCLS 105) 19178238 SHAFT, TRFER CASE RR ВЫХОДНОЙ (INCLS 105) 19133264 SPROCKET, TRFER CASE FRT ВЫХОДНОЙ SHF DRV (INCLS 108) [ШЕСТЕРНЯ РАЗДАТОЧНОЙ КОРОБКИ] 19168732 BUSHING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT (ЧАСТЬ OF 107) (ACDelco #19168732) 19132837 CHAIN, TRFER CASE TWO/FOUR WHL DRV 89059578 CHAIN, TRFER CASE TWO/FOUR WHL DRV [ЦЕПЬ РАЗДАТОЧНОЙ КОРОБКИ] 88984523 GEAR, TRFER CASE PLNT CARR SUN (ВЫХОДНОЙ) 89059279 КРОНШТЕЙН, FRT/RR DRV DIFF 89059284 SHAFT, TRFER CASE FRT ВЫХОДНОЙ (INCLS 900) 88996664 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF RR 88996671 RING, TRFER CASE FRT ВЫХОДНОЙ SHF BRG RET 88996666 SPROCKET, TRFER CASE TWO/FOUR WHL DRV DRVN [ЗВЕЗДОЧКА] 88996633 BEARING, TRFER CASE RR ВЫХОДНОЙ SHF RR (ACDelco #88996633) [ПОДШИПНИК РАЗДАТОЧНОЙ КОРОБКИ] 15580230 BEARING, TRFER CASE INPUT SHF (BORG-WARNER) (4.510) 19132966 SHAFT, TRFER CASE INPUT 88996681 DEFLECTOR, TRFER CASE FRT ВЫХОДНОЙ SHF SEAL DIRT (ЧАСТЬ OF 112) (6E04-016) - 2004-2009 E КЛАПАН РЕГУЛИРОВКИ ДАВЛЕНИЯ В ТОРМОЗНОЙ СИСТЕМЕ ↓ 19153350 МОДУЛЬ KIT, ELEK BRK & TRACT CONT [МОДУЛЬ] 89060233 VALVE KIT, BRK PRESS MOD (INCLS 3, 4) (ACDelco #89060233) [ГИДРАВЛИЧЕСКИЙ БЛОК АБС] 25743362 SENSOR, BRK PRESS MOD VLV PRESS (ЧАСТЬ OF 2) (ACDelco #25743362) [ДАТЧИК] 25741456 INSULATOR, BRK PRESS MOD VLV (ЧАСТЬ OF 2) 11588304 STUD, FLANGE DOUBLE END, M8X14 UNTHD, M8X1.25X13, 17 OD, 5.8, GM4345M (BRK PRESS MOD VLV BRKT) 11514596 ГАЙКА, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (BRK PRESS MOD VLV BRKT) (8.915) (ACDelco #11514596) 11508351 SCREW, PAN HD, C/R, 5X0.8X13, 9.3 OD, FULL THD, THD RLLR, 6171M, PC (BRK PRESS MOD VLV) (8.977) (6E04-017) - 2007-2009 E ШЛАНГ ВЕНТИЛЯЦИИ ТРАНСМИССИИ (LY7/3.6-7, M82,MX5) ↓ 25764835 VENT, A/TRNS (INCLS 2, 3) (ACDelco #25764835) 15955072 CLIP, TRANS VENT HOSE (ЧАСТЬ OF 1) (.650MM DIA) (2.343) (6E04-018) - 2004-2009 E КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS(MX5) ↓ 88996677 CASE, TRFER (FRT HALF) (INCLS 12-14) 19133265 CASE, TRFER (RR HALF) (INCLS 5, 7) 88996679 SNUBBER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN 88996680 БОЛТ, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN SNBR (M5X0.8X16) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 2) 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL FILL) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996657 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 2) [УПЛОТНИТЕЛЬ] 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL DRN) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996680 БОЛТ, TRFER CASE VENT BFL (M5X0.8X16) (4.535) 88996658 BAFFLE, TRFER CASE VENT 89048123 БОЛТ, TRFER CASE HALF (M8X1.25X30) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 1) teamcadillac.ru 88996656 SEAL, TRFER CASE INPUT SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 88996657 SEAL, TRFER CASE FRT ВЫХОДНОЙ SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 19180066 VENT, TRFER CASE 89048123 БОЛТ, TRFER CASE VIB DPNR (M8X1.25X30) 19133173 DAMPENER, TRFER CASE VIB (YOKE STYLE; БОЛТS TO RR OF T-CASE) (6E04-020) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ 24218963 RING, T/CV FLUID SEAL RET [КОЛЬЦО] 24237531 SEAL, T/CV FLUID (ЧАСТЬ OF 217, 219) (ACDelco #24237531) [УПЛОТНЕНИЕ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 00444613 PLUG, HEX HD, 1/8-27 NPTF, STL (LINE PRESS TEST HOLE) (ACDelco #444613) 24239385 ШЛАНГИ, T/CV (MCHG) (INCLS 206) 24225422 PIPE, A/TRNS VENT 15251488 SEAL, TRANS FLUID CLR PIPE FTG (ЧАСТЬ OF 217, 219) (SEALS TWO ТРУБКИ) (*KIT1) [УПЛОТНЕНИЕ] 24237658 SEAL, TRANS FLUID CLR PIPE FTG (ЧАСТЬ OF 217, 219) (SEALS ONE PIPE) (*KIT1) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ] 24222668 SLIDE, A/TRNS ГИДРОНАСОС (17.948MM-17.961MM) (ACDelco #24222668) 24224131 SLIDE, A/TRNS ГИДРОНАСОС (17.961MM-17.974MM) (ACDelco #24224131) 24224132 SLIDE, A/TRNS ГИДРОНАСОС (17.974MM-17.987MM) (ACDelco #24224132) teamcadillac.ru 24238915 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 207-211, 213-216, 230) (17.948MM-17.961MM) (ACDelco #24238915) 24238916 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 207-211, 213-216, 230) (17.961MM-17.974MM) (ACDelco #24238916) 24238917 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 207-211, 213-216, 230) (17.974MM-17.987MM) (ACDelco #24238917) 24238919 COVER KIT, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 218, 220-230, 232-237) (ACDelco #24238919) 00147500 VALVE, PRESS RLF BALL (ЧАСТЬ OF 219) 24224692 WASHER, 1-2-3-4 & 3-5 REV CLU HSG THR (ЧАСТЬ OF 219) 24239151 RING KIT, 1-2-3-4 & 3-5 REV CLU FLUID SEAL (ACDelco #24239151) 24248559 RING KIT, 1-2-3-4 & 3-5 REV CLU FLUID SEAL (1-SET 2ND DES SEALS (INCL QUAD LOBE)) (ACDelco #24248559) 24227061 БОЛТ, A/TRNS ГИДРОНАСОС CVR (ACDelco #24227061) [БОЛТ] 90351709 PIN, A/TRNS ГИДРОНАСОС LOC (ЧАСТЬ OF 219) ("8MM HOLLOW SPLIT PIN") (1.639) [ШПИЛЬКА] 24243891 SEAL KIT, A/TRNS SERV (INCLS 205, 210, 214, 230) (UNITS BUILT 8-17-08 & PRIOR) (2ND DES SEE 24248567) (FULL TRANS) (ACDelco #24243891) (6E04-022) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (LY7/3.6-7, V92) ↓ 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 89022494 BRACKET, TRANS FLUID CLR 19129782 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) [ТРУБКА МАСЛООХЛАДИТЕЛЯ] 19130214 SEAL, TRANS FLUID CLR HOSE CONN (O RING) 19129781 HOSE, TRANS FLUID CLR LWR (W/BLOCK) 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] teamcadillac.ru 19130449 COOLER, TRANS FLUID (INCLS 7-10) (ACDelco #19130449) [РАДИАТОР] (6E04-024) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (LH2/4.6A, EXC V92) ↓ 19130449 COOLER, TRANS FLUID (INCLS 7-9) (ACDelco #19130449) [РАДИАТОР] 11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) [БОЛТ, М8Х1.25Х31.5] 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 15251488 SEAL, TRANS FLUID CLR PIPE FTG (ЧАСТЬ OF 5) (SEALS TWO ТРУБКИ) [УПЛОТНЕНИЕ] 15882260 PIPE, TRANS FLUID CLR INL & OTLT (INCLS 4, 6) [ТРУБКА МАСЛОПРОВОДА] teamcadillac.ru 10405874 CLIP, TRANS FLUID CLR PIPE (ЧАСТЬ OF 5) (LESS MNTG TAB) (HOLDS TWO 9.5 DIA TUBES) 11570323 БОЛТ, КОНДИЦИОНЕР CNDSR (M6X1X18, 13 THD) (1.277) 15921020 CLIP, TRANS FLUID AUX CLR PIPE (CYLINDRICAL) (1 PIPE) (6E04-025) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (LH2/4.6A, V92) ↓ 19130449 COOLER, TRANS FLUID (INCLS 7-10) (ACDelco #19130449) [РАДИАТОР] 11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) [БОЛТ, М8Х1.25Х31.5] 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] teamcadillac.ru 15882260 PIPE, TRANS FLUID CLR INL & OTLT (INCLS 4, 6) [ТРУБКА МАСЛОПРОВОДА] 10405874 CLIP, TRANS FLUID CLR PIPE (ЧАСТЬ OF 5) (LESS MNTG TAB) (HOLDS TWO 9.5 DIA TUBES) 15921020 CLIP, TRANS FLUID AUX CLR PIPE (CYLINDRICAL) (1 PIPE) (6E04-027) - 2007-2009 EB СТОЯНОЧНЫЙ ТОРМОЗ SYSTEM ↓ 10395687 LEVER, PARK BRK (INCLS 2-4, 17, 18) teamcadillac.ru 22654577 SWITCH, PARK BRK IND (ЧАСТЬ OF 1) (ACDelco #22654577) [ВКЛЮЧАТЕЛЬ] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (PARK BRK INTER CBL GDE) [ГАЙКА М6] 15797212 CABLE, PARK BRK INTER (INCLS 5, 10, 11) (ACDelco #15797212) [ТРОС СТОЯНОЧНОГО ТОРМОЗА В СБОРЕ] 11517484 БОЛТ-HEX, M6X1X20, 9 THD, 17 OD, 9.8, 6280M, MACH, P-PT (PARK BRK INTER CBL GDE) 25764260 CABLE, PARK BRK RR (28.2X28.5X811.7MM) (ACDelco #25764260) [ТРОС СТОЯНОЧНОГО ТОРМОЗА] 25880964 HANDLE, PARK BRK REL 11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (PARK BRK REL HDL HSG) [ВИНТ] 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (КАПОТ PRIM LAT REL CBL HDL BRKT) [ВИНТ М4] 15882985 RETAINER, PARK BRK REL HDL 11570654 ГАЙКА, PARK BRK REL HDL BRKT (4.2 X 1.41) (FITS 8.75 SQ HOLE) (9.665) 89047821 CABLE, PARK BRK REL (ЧАСТЬ OF 1) (ACDelco #89047821) 10369646 БОЛТ, PARK BRK IND SW (ЧАСТЬ OF 1) (6E04-030) - 2007-2009 E УПРАВЛЕНИЕ АКПП/АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX0) ↓ 15946116 PLATE, F/FLR CNSL TRANS SHFT OPG TR PLT MT (INCLS 14) (TORTOISE SHELL) 25828031 PLATE, F/FLR CNSL TRANS SHFT OPG TR PLT MT (INCLS 14) (FIGURED SAPELE) 19180495 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (EBONY ON MIDDLE & SIDES) 19180497 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (COCOA ON MIDDLE & SIDES) 19180501 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (FIG SAPELE WOOD W/EBONY) 19180506 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (FIG SAPELE WOOD W/COCOA) 89027001 COVER, A/TRNS CONT LVR HDL (ЧАСТЬ OF 2) (4.006) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL LVR CBL BRKT) [ГАЙКА М6] teamcadillac.ru 15780845 LINK, A/TRNS RANGE SEL LVR 15780847 LINK, A/TRNS RANGE SEL LVR 11519095 NUT-ACORN HEX, M8X1.0, 15MM THK, 9, 6047M, W/DOME. (A/TRNS RANGE SEL LVR) [ГАЙКА] 25789237 RETAINER, F/FLR CNSL (ЧАСТЬ OF 9) 25807057 BEZEL, F/FLR CNSL CUP HLDR (INCLS 8) (GRAY) 25807058 BEZEL, F/FLR CNSL CUP HLDR (INCLS 8) (EBONY) 25807059 BEZEL, F/FLR CNSL CUP HLDR (INCLS 8) (CASHMERE) 19167874 CONTROL, A/TRNS 19167876 CONTROL, A/TRNS 89027003 BULB, A/TRNS CONT POSN IND (BULB W/BLUE COVER) (4.020) (ACDelco #89027003) 19122183 BEZEL, A/TRNS CONT HSG (PRNDL CHROME COVER) 11570687 БОЛТ, A/TRNS CONT LVR KNOB (ЧАСТЬ OF 2) (6E04-031) - 2007-2009 E УПРАВЛЕНИЕ АКПП/АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX7) ↓ 15946116 PLATE, F/FLR CNSL TRANS SHFT OPG TR PLT MT (INCLS 2) (TORTOISE SHELL) 25828031 PLATE, F/FLR CNSL TRANS SHFT OPG TR PLT MT (INCLS 2) (FIGURED SAPELE) 11570687 БОЛТ, A/TRNS CONT LVR KNOB (ЧАСТЬ OF 14) 89027003 BULB, A/TRNS CONT POSN IND (BULB W/BLUE COVER) (4.020) (ACDelco #89027003) 19167812 CONTROL, A/TRNS [МЕХАНИЗМ ПЕРЕКЛЮЧЕНИЯ ПЕРЕДАЧ] 19167875 CONTROL, A/TRNS [ПОДДОН АКП] 25807057 BEZEL, F/FLR CNSL CUP HLDR (INCLS 7) (GRAY) 25807058 BEZEL, F/FLR CNSL CUP HLDR (INCLS 7) (EBONY) 25807059 BEZEL, F/FLR CNSL CUP HLDR (INCLS 7) (CASHMERE) 25789237 RETAINER, F/FLR CNSL (ЧАСТЬ OF 6) teamcadillac.ru 11514603 ГАЙКА, M10X1.5 15MM SOCKET (A/TRNS RANGE SEL LVR) [ШАЙБА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL ROD ADJ) [ГАЙКА М6] 15780844 LINK, A/TRNS RANGE SEL LVR 15780846 LINK, A/TRNS RANGE SEL LVR 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL LVR CBL BRKT) [ГАЙКА М6] 19122183 BEZEL, A/TRNS CONT HSG (PRNDL CHROME COVER) 89027001 COVER, A/TRNS CONT LVR HDL (ЧАСТЬ OF 14) (4.006) 19180495 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (EBONY ON MIDDLE & SIDES) 19180497 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (COCOA ON MIDDLE & SIDES) 19180501 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (FIG SAPELE WOOD W/EBONY) 19180506 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (FIG SAPELE WOOD W/COCOA) (6E04-035) - 2005-2009 E BRAKE SYSTEM/ANTILOCK ↓ 12413103 HUB, FRT WHL (W/BRG) (СМ. ГРУППУ 06.000 "ПОДВЕСКА-ПЕРЕДНЯЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/WHL SPD SEN) (ACDelco #FW149) [СТУПИЦА КОЛЕСА] teamcadillac.ru 12413105 HUB, FRT WHL (W/BRG) (СМ. ГРУППУ 06.000 "ПОДВЕСКА-ПЕРЕДНЯЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPEED SENSOR) (ACDelco #FW150) [СТУПИЦА КОЛЕСА] 89047639 HUB, RR WHL (W/WHL SPD SEN) (СМ. ГРУППУ 06.000 "ЗАДНЯЯ ПОДВЕСКА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6 STUD HUB) (ACDelco #RW20-19) [СТУПИЦА КОЛЕСА] 10307709 SENSOR, VEH YAW (W/VEH LATL ACCLRM) [ДАТЧИК] 15906579 SENSOR, VEH YAW (W/ VEH LATL & LGTDNL ACCLRM) [ДАТЧИК] 11561645 ГАЙКА, HFH, M6X1X6.45, 13.5 OD, 10 STL, GMW3200 (VEH YAW SEN & LATL ACCLRM) (6E04-036) - 2007-2009 EB ТОРМОЗНАЯ ПЕДАЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (JF4) ↓ 25732428 BARRIER, BRK PED BRKT SND 25697461 RETAINER, BRK PED PUSH ROD BOOT 25732452 BOOT, BRK PED PUSH ROD 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] 15932827 HOSE, P/B BOOS VAC (ACDelco #176-1496) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (ACCEL PED LVR) 10368488 PEDAL, BRK (INCLS 12, 13, 15, 18-22) 25771615 COVER, BRK PED (ЧАСТЬ OF 11) 89047699 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 11) (INCLS 18) [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 89047780 MOTOR KIT, BRK & ACCEL PED ADJR ACTR [ЭЛЕКТРОДВИГАТЕЛЬ ПЕДАЛЬНОГО УЗЛА 19 ВТ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 11, 13) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 11) 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 11) teamcadillac.ru 25697461 RETAINER, BRK PED PUSH ROD BOOT (ЧАСТЬ OF 11) 89047779 CABLE, ACCEL CONT 89047778 CABLE, BRK PED ADJR ACTR [ЖГУТ ПРОВОДОВ] 25741052 BRACKET, BRK PED BRKT 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-037) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (LY7/3.6-7, EXC V92) ↓ 19130570 HOSE, TRANS FLUID CLR LWR (W/BLOCK) (INCLS 7) 11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16] 89022494 BRACKET, TRANS FLUID CLR 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 25740416 SEAL, TRANS FLUID CLR PIPE (O RING) (1/2IN) (9.222) (ACDelco #15-31872) [ПРОКЛАДКА КОМПРЕССОРА КОНДИЦИОНЕРА] 19129977 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) teamcadillac.ru 15921020 CLIP, TRANS FLUID AUX CLR PIPE (CYLINDRICAL) (1 PIPE) (6M04-039) - 2009 E ШЛАНГ ВЕНТИЛЯЦИИ ТРАНСМИССИИ (LH2/4.6A, MYB) ↓ 25892279 VENT, TRFER CASE (ЧАСТЬ OF 3) (ACDelco #25892279) [ЗАГЛУШКА ШЛАНГА ВЕНТИЛЯЦИИ КАРТЕРА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 08905794 CLIP (ЧАСТЬ OF 3) teamcadillac.ru 25892019 HOSE, TRANS VENT (INCLS 1, 2, 4) 25526358 CЛАМПА, SPRG BAND, 14.2MM, 9/16 OD HOSE, POR (ЧАСТЬ OF 3) (6M04-041) - 2009 E26 ТОРМОЗНАЯ ПЕДАЛЬ (PWR ADJ PEDALS JF4) ↓ 25741052 BRACKET, BRK PED BRKT 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 25732428 BARRIER, BRK PED BRKT SND 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 89047778 CABLE, BRK PED ADJR ACTR [ЖГУТ ПРОВОДОВ] teamcadillac.ru 89047780 MOTOR KIT, BRK & ACCEL PED ADJR ACTR [ЭЛЕКТРОДВИГАТЕЛЬ ПЕДАЛЬНОГО УЗЛА 19 ВТ] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (BRK PED POSN SEN) 89047699 SENSOR KIT, BRK PED POSN [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 25697461 RETAINER, BRK PED PUSH ROD BOOT (ЧАСТЬ OF 21) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 21) 10368488 PEDAL, BRK (INCLS 5, 8-10, 13, 15-20, 22) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-042) - 2009 E26 ТОРМОЗНАЯ ПЕДАЛЬ (EXC PWR ADJ PEDALS JF4) ↓ 25741052 BRACKET, BRK PED BRKT 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 25732428 BARRIER, BRK PED BRKT SND 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] teamcadillac.ru 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 18) 89047699 SENSOR KIT, BRK PED POSN [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 15594358 BUSHING, BRK PED PIV (ЧАСТЬ OF 18) (0.831) 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 18) (0.80 IN) (PUSH IN) 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 18) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 18) 25771615 COVER, BRK PED (ЧАСТЬ OF 18) 25818868 PEDAL, BRK (W/BRKT) (INCLS 5-8, 10, 12-17, 19) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-044) - 2004-2009 E26 ТОРМОЗНОЙ УСИЛИТЕЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА ↓ 88967237 BOOSTER, P/B (СМ. ГРУППУ 04.000 "ТОРМОЗНОЙ УСИЛИТЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/O VLV) (ACDelco #178-0695) 25732452 BOOT, BRK PED PUSH ROD teamcadillac.ru 25697461 RETAINER, BRK PED PUSH ROD BOOT 10367561 CYLINDER, BRK MAS (СМ. ГРУППУ 4.000 "ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #174-1012) [ЦИЛИНДР] 11609949 ГАЙКА, BRK M/CYL (M10X1.5, 11.2 THK) (8.917) [ГАЙКА] 25873484 HOSE, P/B BOOS VAC (ACDelco #176-1497) (GM00-588) - 2009 E ТРАНСМИССИЯ TO КРЕПЛЕНИЕ ДВИГАТЕЛЯ (LH2/4.6A) ↓ 12582606 FLYКОЛЕСО, ENG 25773136 BRACKET, ENG WRG HARN (CHANNEL) 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] 24205900 PLUG, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] 12568123 COVER, TRANS CONV teamcadillac.ru 11589116 БОЛТ, FLYWHL (8.900) 12568122 COVER, FLYWHL HSG 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (TRANS CONV CVR) (GM04-064) - 2004-2009 E ТОРМОЗНОЙ СУППОРТ-ПЕРЕДНИЙ ↓ teamcadillac.ru 18047980 CALIPER, FRT BRK (INCLS 2-4, 8-10) (IF DISCONTINUED USE DURASTOP EQUIVALENT) (4.667) (ACDelco #172-1643) [ТОРМОЗНОЙ СУППОРТ] 18047981 CALIPER, FRT BRK (INCLS 2-4, 8-10) (IF DISCONTINUED USE DURASTOP EQUIVALENT) (4.667) (ACDelco #172-1644) [ТОРМОЗНОЙ СУППОРТ] 18043178 COVER, FRT BRK BLEDR SCREW (ЧАСТЬ OF 1) 18047986 VALVE KIT, FRT BRK CLPR BLEDR (ЧАСТЬ OF 1) (ACDelco #18047986) 18046750 БОЛТ, FRT BRK CLPR GDE PIN (ЧАСТЬ OF 1, 11) (*KIT2) [БОЛТ] 18047985 PISTON KIT, FRT BRK CLPR (ЧАСТЬ OF 1) 18047988 PAD KIT, FRT DISC BRK (INCLS 4, 14) (ACDelco #171-665) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4 ШТ)] 19122384 PAD KIT, FRT DISC BRK (INCLS 4, 14) (ACDelco #171-688) 18045221 SEAL, FRT BRK CLPR GDE PIN 18047987 BRACKET, FRT BRK CLPR (W/GUIDE PIN БОЛТS) [КРОНШТЕЙН] 18046698 ПРУЖИНА, FRT DISC BRK PAD RET (ЧАСТЬ OF 11) (ACDelco #179-2235) 18047989 PIN KIT, FRT BRK CLPR GDE (INCLS 5-7) (INCLS 2 (2.5") БОЛТS) 18047984 CALIPER KIT, FRT BRK (INCLS 4, 8, 9) (4.667) (ACDelco #173-0538) (GM04-312) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (5L40-E M82) ↓ teamcadillac.ru 96042897 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 6GRG) (GM04-376) - 2004-2009 E ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР ↓ 18012741 SWITCH, BRK FLUID LVL IND (ЧАСТЬ OF 15) (ACDelco #18012741) 22688449 CAP, BRK M/CYL RSVR (ЧАСТЬ OF 15) (INCLS 3) [КРЫШКА БАЧКА ТОРМОЗНОЙ ЖИДКОСТИ] 18046711 RESERVOIR, BRK M/CYL (ЧАСТЬ OF 15) (INCLS 4, 6-7) (ACDelco #18046711) 18060168 PISTON, BRK M/CYL SECD (ЧАСТЬ OF 15) 10367561 CYLINDER, BRK MAS (INCLS 1-14) (ACDelco #174-1012) [ЦИЛИНДР] teamcadillac.ru 18022002 CYLINDER KIT, BRK MAS (INCLS 8-12) (ACDelco #175-424) (GM04-485) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (5L40-E MX5) ↓ teamcadillac.ru 96042890 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 6GGG) [АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ В СБОРЕ] (GM04-555) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 24227130 БОЛТ, C/VLV UPR BODY (M5X0.8X36) 24225398 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M6 X 1.0 X 20) 24238417 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (INCLS 316) (4.329) [ДАТЧИК ЧИСЛА ОБОРОТОВ ВАЛА AКПП] 24225797 BODY, C/VLV UPR [ГИДРОРАСПРЕДЕЛИТЕЛЬНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24245720 PLATE, C/VLV BODY SPCR (W/GSKT) (ACDelco #24245720) [НАБОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96020431 VALVE, C/VLV BODY BALL CHK [КЛАПАН] teamcadillac.ru 24250384 BODY, C/VLV LWR (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ/;НИЖНИЙ КЛАПАН РЕГУЛЯТОР BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (MANUAL VALVE NOT INCLUDED) (MUST USE T/W 24236934/PLATE KIT - CONT SOL VLV FLTR) 24246427 SWITCH, A/TRNS MAN SHFT SHF POSN (INCLS 315) (INTERNAL MODE SWITCH) [ВКЛЮЧАТЕЛЬ] 24224821 БОЛТ, C/VLV LWR BODY (M5X0.8X45) 24224822 БОЛТ, C/VLV LWR BODY (M5X0.8X55) 24238925 PLATE KIT, CONT SOL VLV FLTR 24240845 БОЛТ, CONT SOL VLV HEAT SINK (W/ BODY & TCM) (M5X0.8X53.0) 24241890 VALVE, CONT SOL (W/ BODY & TCM) (ACDelco #24241890) (ORDER T/W 24238913 SEAL KIT) [ГИДРОРАСПРЕДЕЛИТЕЛЬНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24236233 CLIP, A/TRNS MAN SHFT SHF POSN SW WRG HARN (ЧАСТЬ OF 308) 24236504 CLIP, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN WRG HARN (ЧАСТЬ OF 303) (GM04-556) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ВЕРХНИЙ КЛАПАН РЕГУЛЯТОР BODY БЛОК ↓ 24224766 PIN, C/VLV BODY LOC (ЧАСТЬ OF 321) (DIA.=10MM L=12.7) [ВТУЛКА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24225797 BODY, C/VLV UPR (INCLS 313, 322-338) [ГИДРОРАСПРЕДЕЛИТЕЛЬНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24230200 PIN, C/VLV BODY LOC (ЧАСТЬ OF 321) (DIA.=10MM L=29.9) [ВТУЛКА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, 1-2-3-4 CLU BOOST VLV SPR (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] teamcadillac.ru 24242814 PLUG, 1-2-3-4 CLU REG VLV BORE (ЧАСТЬ OF 321) (9.5 THK, 11.5 DIA) (GM04-557) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) НИЖНИЙ КЛАПАН РЕГУЛЯТОР BODY БЛОК ↓ 24224755 RETAINER, CLU PSTN DAM FEED REG VLV SPR [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] teamcadillac.ru 24242814 PLUG, CLU SEL SOL VLV BORE #2 (9.5 THK, 11.5 DIA) 24250384 BODY, C/VLV LWR (INCLS 338, 352, 353, 355-357) (MANUAL VALVE NOT INCLUDED) (MUST USE T/W 24236934/PLATE KIT - CONT SOL VLV FLTR) 24224770 VALVE, MAN (ACDelco #24224770) (GM04-558) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) 1-2-3-4 & 3-5 REVERSE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 24240625 RING, 3-5 REV CLU BKG PLT RET (ЧАСТЬ OF 427) (LT GREEN) (2.25-2.35MM) (ACDelco #24240625) 24240626 RING, 3-5 REV CLU BKG PLT RET (ЧАСТЬ OF 427) (GRAY) (2.47-2.57MM) (ACDelco #24240626) 24240627 RING, 3-5 REV CLU BKG PLT RET (ЧАСТЬ OF 427) (YELLOW) (2.69-2.79MM) (ACDelco #24240627) 24240628 RING, 3-5 REV CLU BKG PLT RET (ЧАСТЬ OF 427) (ORANGE) (2.93-3.01MM) (ACDelco #24240628) 24240629 RING, 3-5 REV CLU BKG PLT RET (ЧАСТЬ OF 427) (LT BLUE) (3.13-3.23MM) (ACDelco #24240629) 24240630 RING, 3-5 REV CLU BKG PLT RET (ЧАСТЬ OF 427) (WHITE) (3.35-3.45MM) (ACDelco #24240630) 24240631 RING, 3-5 REV CLU BKG PLT RET (ЧАСТЬ OF 427) (YELLOW/PURPLE) (3.57-3.67MM) (ACDelco #24240631) 24225654 PLATE, 3-5 REV CLU BKG 24237663 PLATE, 3-5 REV CLU (PKG OF 4) (STEEL) 24225564 PLATE, 3-5 REV CLU (WAVED) 24233533 PLATE, 1-2-3-4 CLU BKG 24243588 PLATE, 1-2-3-4 CLU (ACDelco #24243588) 24232652 PLATE, 1-2-3-4 CLU (PKG OF 5) (STEEL) 24236434 PLATE, 1-2-3-4 CLU (WAVED) 24225522 DAM, 1-2-3-4 CLU PSTN 24225559 ПРУЖИНА, 1-2-3-4 CLU 24241073 PISTON, 1-2-3-4 CLU 24238558 ШЛАНГИ, 1-2-3-4 CLU PSTN 24236051 ПРУЖИНА, 3-5-REV CLU 24238560 PISTON, 3-5/REV CLU (INCLS 422) (4.164) teamcadillac.ru 24237184 ШЛАНГИ, 1-2-3-4 & 3-5 REV CLU (INCLS 400, 426, 429) (ORDER T/W 24226393) 24226393 BEARING, 1-2-3-4 & 3-5-REV CLU 24240626 RING, 1-2-3-4 CLU BKG PLT RET (ЧАСТЬ OF 427) (GRAY) (2.47-2.57MM) (ACDelco #24240626) 24240627 RING, 1-2-3-4 CLU BKG PLT RET (ЧАСТЬ OF 427) (YELLOW) (2.69-2.79MM) (ACDelco #24240627) 24240628 RING, 1-2-3-4 CLU BKG PLT RET (ЧАСТЬ OF 427) (ORANGE) (2.93-3.01MM) (ACDelco #24240628) 24240629 RING, 1-2-3-4 CLU BKG PLT RET (ЧАСТЬ OF 427) (LT BLUE) (3.13-3.23MM) (ACDelco #24240629) 24240630 RING, 1-2-3-4 CLU BKG PLT RET (ЧАСТЬ OF 427) (WHITE) (3.35-3.45MM) (ACDelco #24240630) 24240631 RING, 1-2-3-4 CLU BKG PLT RET (ЧАСТЬ OF 427) (YELLOW/PURPLE) (3.57-3.67MM) (ACDelco #24240631) 24240632 RING, 1-2-3-4 CLU BKG PLT RET (ЧАСТЬ OF 427) (LT BLUE/PURPLE) (3.79-3.89MM) (ACDelco #24240632) 24238920 RING KIT, RET (INCLS 411, 415) 24238922 SEAL KIT, A/TRNS SERV (INCLS 416, 418, 419, 422-425) (СЦЕПЛЕНИЕES) (ACDelco #24238922) (GM04-559) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) 4-5-6 ДЕТАЛИ СЦЕПЛЕНИЯ & ВАЛ ТУРБИНЫ ↓ 24225508 RING, 4-5-6 CLU BKG PLT RET (GREEN) (2.52-2.62) (ACDelco #24225508) 24225509 RING, 4-5-6 CLU BKG PLT RET (YELLOW) (3.08-3.18) (ACDelco #24225509) 24231591 RING, 4-5-6 CLU BKG PLT RET (GREY) (2.80-2.90) (ACDelco #24231591) 24231592 RING, 4-5-6 CLU BKG PLT RET (ORANGE) (3.36-3.46) (ACDelco #24231592) 24231593 RING, 4-5-6 CLU BKG PLT RET (BLUE) (3.64-3.74) (ACDelco #24231593) teamcadillac.ru 24232879 RING, 4-5-6 CLU BKG PLT RET (WHITE) (3.74-3.84) (ACDelco #24232879) 24232880 RING, 4-5-6 CLU BKG PLT RET (YELLOW/PURPLE) (4.20-4.30) (ACDelco #24232880) 24225652 PLATE, 4-5-6 CLU BKG 24225570 PLATE, 4-5-6 CLU (INT SPLINE) (PKG OF 5) (FIBER) 24225575 PLATE, 4-5-6 CLU (EXT SPLINE) (PKG OF 5) (STEEL)FIBER) (ACDelco #24225575) 24225565 PLATE, 4-5-6 CLU (WAVED) 24225526 DAM, 4-5-6 CLU PSTN 24225560 ПРУЖИНА, 4-5-6 CLU 24225523 PISTON, 4-5-6 CLU 24237963 ШЛАНГИ, 4-5-6 CLU (W/ INPUT SHF) (INCLS 440) 08662686 SEAL, TURB SHF (O RING) (*KIT2) (ACDelco #8662686) 24238920 RING KIT, RET (INCLS 436) 24243891 SEAL KIT, A/TRNS SERV (INCLS 436, 442, 443) (UNITS BUILT 8-17-08 & PRIOR) (2ND DES SEE 24248567) (FULL TRANS) (ACDelco #24243891) (GM04-560) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) 2-6 ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 24247405 RING, 2-6 CLU BKG PLT RET (1.69MM +/- 0.05) (ACDelco #24247405) 24247406 RING, 2-6 CLU BKG PLT RET (2.81MM +/- 0.05) (ACDelco #24247406) 24248107 RING, 2-6 CLU BKG PLT RET (2.25MM +/- 0.05) (ACDelco #24248107) 24248108 RING, 2-6 CLU BKG PLT RET (2.53MM +/- 0.05) (ACDelco #24248108) 24248109 RING, 2-6 CLU BKG PLT RET (1.97MM +/- 0.05) (ACDelco #24248109) 24225653 PLATE, 2-6 CLU BKG teamcadillac.ru 24237973 PLATE, 2-6 CLU (WAVED) 24225561 ПРУЖИНА, 2-6 CLU 24225524 PISTON, 2-6 CLU 24225447 SUPPORT, CTR (INCLS 458, 460) 24238911 PLATE KIT, CLU (INCLS 452) (ORDER T/W 24225575 & 24235455) (ACDelco #24238911) (GM04-561) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) LOW & REVERSE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 24225519 RING, LOW & REV CLU BKG PLT RET (2.77MM +/- 0.05) (ACDelco #24225519) 24231938 RING, LOW & REV CLU BKG PLT RET (2.63MM +/- 0.05) (MUST BE USED T/W 24247402) (ACDelco #24231938) 24231939 RING, LOW & REV CLU BKG PLT RET (2.93MM +/- 0.05) (MUST BE USED T/W 24247402) (ACDelco #24231939) 24247407 RING, LOW & REV CLU BKG PLT RET (2.03MM +/- 0.05) (MUST BE USED T/W 24247402) (ACDelco #24247407) 24247408 RING, LOW & REV CLU BKG PLT RET (3.23MM +/- 0.05) (MUST BE USED T/W 24247402) (ACDelco #24247408) 24247402 PLATE, LOW & REV CLU BKG (MUST BE USED T/W 24231937/38/38, AND 24247407/08) (ACDelco #24247402) 24236664 PLATE, LOW & REV CLU (PKG OF 6) (FIBER) 24232654 PLATE, LOW & REV CLU (PKG OF 6) (STEEL) (ACDelco #24232654) 24237971 PLATE, LOW & REV CLU (WAVED) (ACDelco #24237971) 24225517 RING, LOW & REV CLU SPR RET 24238921 SPRAG, LOW CLU (INCLS 468) 24225562 ПРУЖИНА, LOW & REV CLU teamcadillac.ru 24225525 PISTON, LOW & REV CLU (ACDelco #24225525) 24238922 SEAL KIT, A/TRNS SERV (INCLS 468) (СЦЕПЛЕНИЕES) (ACDelco #24238922) (GM04-562) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) СЦЕПЛЕНИЕ HUB БЛОК ↓ 24233660 HUB, 4-5-6 CLU (W/ ВЫХОДНОЙ CARR SHF & DPNR) (INCLS 476-478) 24230475 DAMPENER, 4-5-6 CLU (ЧАСТЬ OF 475) 24233661 PLATE, 4-5-6 CLU DPNR APPLY (ЧАСТЬ OF 475) 24230370 RING, 4-5-6 CLU DPNR RET (ЧАСТЬ OF 475) (GM04-563) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ВЫХОДНОЙ КРОНШТЕЙН БЛОК ↓ 24225777 BEARING, CTR SUPT RLR (ЧАСТЬ OF 490) 24225483 BEARING, ВЫХОДНОЙ CARR OTR SUN GR FRT THR (ЧАСТЬ OF 490) 24225290 GEAR, ВЫХОДНОЙ CARR FRT SUN (ЧАСТЬ OF 490) 24225484 BEARING, ВЫХОДНОЙ CARR OTR SUN GR RR THR (ЧАСТЬ OF 490) teamcadillac.ru 24235807 GEAR, ВЫХОДНОЙ CARR RR SUN (ЧАСТЬ OF 490) 24225603 КРОНШТЕЙН, ВЫХОДНОЙ (INCLS 485-489, 491) (GM04-565) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ЗАМОК ПАРКОВКИ ↓ 24242086 ACTUATOR, PARK PAWL (ACDelco #24242086) 24227077 PIN, MAN SHFT DTNT LVR HUB (ЧАСТЬ OF 505) 24234562 LEVER, MAN SHFT DTNT (INCLS 504) (ACDelco #24234562) 24225792 PIN, MAN SHFT SHF (ACDelco #24225792) 24235861 SEAL, MAN SHFT SHF (*KIT1) (ACDelco #24235861) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24225445 SHAFT, MAN SHFT (ACDelco #24225445) 24228969 SHAFT, MAN SHFT (ACDelco #24228969) 24224348 GUIDE, PARK PAWL ACTR (INCLS 510) 24224350 SEAL, PARK PAWL ACTR GDE (O RING) (ЧАСТЬ OF 509) (*KIT1) (ACDelco #24224350) 24226102 PIN, PARK PAWL ACTR GDE 24243891 SEAL KIT, A/TRNS SERV (INCLS 507, 510) (UNITS BUILT 8-17-08 & PRIOR) (2ND DES SEE 24248567) (FULL TRANS) (ACDelco #24243891) teamcadillac.ru (GM04-568) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ВЫХОДНОЙ ВАЛ БЛОК ↓ 24241092 RING, ВЫХОДНОЙ CARR INTL GR RET (ACDelco #24241092) teamcadillac.ru 24225477 GEAR, ВЫХОДНОЙ CARR INTL (FRT) 24228887 SPACER, ВЫХОДНОЙ CARR INTL GR (3.342) 24230333 GEAR, ВЫХОДНОЙ CARR INTL (RR) 24239398 SHAFT, ВЫХОДНОЙ (INCLS 495, 497, 498) (WHEN SERVICING SHAFT MUST ALSO REPLACE BEARING P/N 24237771) 24239401 SHAFT, ВЫХОДНОЙ (INCLS 495, 497, 498) (WHEN SERVICING SHAFT MUST ALSO REPLACE BEARING P/N 24237771) (GM04-569) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) БЛОК СЦЕПЛЕНИЯ & ДЕТАЛИ КОМПЛЕКТА ↓ 24225602 КРОНШТЕЙН, INPUT (ACDelco #24225602) 24225289 GEAR, INPUT SUN (ACDelco #24225289) 24224405 BEARING, INPUT SUN GR THR (ACDelco #24224405) 24232409 WASHER, INPUT SUN GR THR 24238905 BEARING, TURB SHFT THR [ПОДШИПНИК] 24233732 BEARING, 4-5-6 CLU HUB THR (ACDelco #24233732) teamcadillac.ru 24225597 HUB, 1-2-3-4 CLU (W/ВЫХОДНОЙ CARR INR SUN GR SHF) 24224163 BEARING, 1-2-3-4 CLU HUB THR (ACDelco #24224163) 24225596 HUB, 2-6 & 3-5/REV CLU (W/ ВЫХОДНОЙ CARR OTR SUN GR SHF) (INCLS 60, 62) 24224164 BEARING, 2-6 & 3-5/REV CLU HUB THR (ACDelco #24224164) 24225512 RING, CTR SUPT RET 24225447 SUPPORT, CTR 24225486 BEARING, ВЫХОДНОЙ CARR THR 24224668 BEARING, ВЫХОДНОЙ SHF THR (ACDelco #24224668) (GM04-573) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042861 GASKET, A/TRNS CASE EXTN (*KIT1) 24237771 BEARING, ВЫХОДНОЙ SHF (ЧАСТЬ OF 27) 96042860 EXTENSION, A/TRNS CASE (INCLS 26, 28, 29) 24237771 BEARING, ВЫХОДНОЙ SHF (ЧАСТЬ OF 27) 96041851 SEAL, PROP SHF TRANS FLG FLUID (ЧАСТЬ OF 27) (*KIT1) [ПРОКЛАДКА ТРАНСФОРМАТОРНОГО ВАЛА] 96042984 FLANGE, ВЫХОДНОЙ SHF 96041805 NUT KIT, ВЫХОДНОЙ SHFT (INCLS 30, 32, 33) (M6X1.0X16) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) (*KIT1) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) (*KIT1) teamcadillac.ru 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96042963 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPACER PLATE & GASKET) 96042986 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96043253 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) 96042712 DETENT, MAN SHFT 96042847 HARNESS, A/TRNS WRG 96041849 SEAL, A/TRNS WRG CONN (O RING) (*KIT1) 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN (*KIT1) [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (*KIT1) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (*KIT1) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) 96042945 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/GSKT, SEAL, RET) (INCLS 25, 29, 36, 38, 46, 56, 60, 63, 64) (GM04-574) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042887 GASKET, A/TRNS CASE EXTN [ПРОКЛАДКА КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042888 EXTENSION, A/TRNS CASE (INCLS 28, 69) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) teamcadillac.ru 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96042963 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPACER PLATE & GASKET) 96042986 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) 96042712 DETENT, MAN SHFT 96042847 HARNESS, A/TRNS WRG 96041849 SEAL, A/TRNS WRG CONN (O RING) 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) 96042543 WASHER, INPUT & REACTION CARR THR 96042587 SEAL, PROP SHF TRANS FLG FLUID [ПРОКЛАДКА КРЫШКИ РАЗДАТОЧНОЙ КОРОБКИ] 08677884 BEARING, ВЫХОДНОЙ SHF THR (ЧАСТЬ OF 27) (4.180) (ACDelco #8677884) (GM04-575) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ teamcadillac.ru 96042554 CONVERTER, TORQ (REMAN) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042812 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) 96042806 СЦЕПЛЕНИЕ, DIR & REV (СМ. ГРУППУ 04.000 "DIRECT AND REVERSE СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042807 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (СМ. ГРУППУ 04.000 "FORWARD AND COAST СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042698 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) (СМ. ГРУППУ 04.000 "INPUT SUN GEAR SHAFT AND FORWARD SPRAG СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (СМ. ГРУППУ 04.000 "DIRECT СЦЕПЛЕНИЕ DRUM AND SHAFT" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042701 WASHER, INPUT & REACTION CARR INR SHF THR 96042808 ШЛАНГИ, O/D CLU (СМ. ГРУППУ 04.000 "OVERDRIVE AND INTERMEDIATE СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (СМ. ГРУППУ 04.000 "LOW СЦЕПЛЕНИЕ SPRAG" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042705 BEARING, CTR SUPT RLR (4.180) 96042809 SUPPORT, CTR (СМ. ГРУППУ 04.000 "CENTER SUPPORT" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042707 КРОНШТЕЙН, INPUT & REACTION (СМ. ГРУППУ 04.000 "PLANETARY КРОНШТЕЙН" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (4.176) 96042708 BEARING, INPUT & REACTION CARR THR 96042709 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (СМ. ГРУППУ 04.000 "ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96041847 WASHER, INPUT & REACTION CARR THR (4.265) (GM04-576) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ 96042554 CONVERTER, TORQ (REMAN) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042812 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) 96042814 СЦЕПЛЕНИЕ, DIR & REV 96042815 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) 96042698 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) (INCLS 9) 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) 96042701 WASHER, INPUT & REACTION CARR INR SHF THR 96042808 ШЛАНГИ, O/D CLU 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) 08677884 BEARING, LOW CLU RLR THR (*KIT1) (ACDelco #8677884) 96042705 BEARING, LOW CLU RLR THR (*KIT1) 96042816 SUPPORT, CTR 96042817 КРОНШТЕЙН, INPUT & REACTION 96042818 BEARING, INPUT & REACTION CARR THR teamcadillac.ru 96042813 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) 96042543 WASHER, INPUT & REACTION CARR THR 96042818 BEARING, INPUT & REACTION CARR THR (GM04-577) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ 08680684 ПРУЖИНА, LINE BOOST VLV (*KIT1) (4.262) (ACDelco #8680684) 08642581 SEAL, A/TRNS ГИДРОНАСОС CVR SCRN (*KIT1) (ACDelco #8642581) teamcadillac.ru 96015215 БОЛТ, T/CV FLUID SEAL (*KIT1) 96041855 SEAL, T/CV FLUID [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 08634106 ПРУЖИНА, PRESS RLF BALL VLV (*KIT1) (ACDelco #8634106) 00147500 VALVE, PRESS RLF BALL (*KIT1) 96042812 ШЛАНГИ KIT, T/CV (INCLS 200-215, 217-220, 223, 226-228, 231-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-577) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ 08680684 ПРУЖИНА, LINE BOOST VLV (*KIT1) (4.262) (ACDelco #8680684) teamcadillac.ru 96015215 БОЛТ, T/CV FLUID SEAL (*KIT1) 96041855 SEAL, T/CV FLUID [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 08634106 ПРУЖИНА, PRESS RLF BALL VLV (*KIT1) (ACDelco #8634106) 00147500 VALVE, PRESS RLF BALL (*KIT1) 96042812 ШЛАНГИ KIT, T/CV (INCLS 200-215, 217-220, 223, 226-228, 231-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-578) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 24209145 ФИЛЬТР, PRESS CONT SOL VLV FLUID (*KIT1, KIT2) (ACDelco #24209145) [ФИЛЬТР] 24209145 ФИЛЬТР, PRESS CONT SOL VLV FLUID (*KIT1, KIT2) (ACDelco #24209145) [ФИЛЬТР] teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 300-309, 312-334) (INCLS SPACER PLATE & GASKET) 96042986 VALVE, CONT (W/BODY & VLV) (INCLS 300-309, 312-334) 96043253 VALVE, CONT (W/BODY & VLV) (INCLS 300-309, 312-334) 96042986 GASKET KIT, A/TRNS (INCLS 303, 305, 306, 308, 309, 312, 314, 316, 330, 332) (4.265) (GM04-578) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 96020027 БОЛТ, C/VLV CHAN PLT (*KIT1) 96025325 БОЛТ, INTER CLU ACCUM (*KIT1) (4.265) teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 300-334) (INCLS SPACER PLATE & GASKET) 96042986 VALVE, CONT (W/BODY & VLV) (INCLS 300-334) (GM04-579) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 08680781 RETAINER, PRESS CONT SOL VLV (*KIT1) (ACDelco #8680781) 96042599 VALVE, TCC PWM SOL 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 340-351, 353-356) (INCLS SPACER PLATE & GASKET) 96042986 VALVE, CONT (W/BODY & VLV) (INCLS 340-351, 353-356) 96043253 VALVE, CONT (W/BODY & VLV) (INCLS 340-351, 353-356) (GM04-579) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 08680781 RETAINER, PRESS CONT SOL VLV (*KIT1) (ACDelco #8680781) 96042599 VALVE, TCC PWM SOL 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 340-348, 351, 353-354) (INCLS SPACER PLATE & GASKET) 96042986 VALVE, CONT (W/BODY & VLV) (INCLS 340-348, 351, 353-354) (GM04-580) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 08680781 RETAINER, 1-2 SHFT SOL VLV (*KIT1) (ACDelco #8680781) 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 343, 349, 350, 365-367, 370-375, 377-388) (INCLS SPACER PLATE & GASKET) 96042986 VALVE, CONT (W/BODY & VLV) (INCLS 343, 349, 350, 365-367, 370-375, 377-388) 96043253 VALVE, CONT (W/BODY & VLV) (INCLS 343, 349, 350, 365-367, 370-375, 377-388) (GM04-580) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 08680781 RETAINER, 1-2 SHFT SOL VLV (*KIT1) (ACDelco #8680781) 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 343, 351, 365-367, 370-375, 377-388) (INCLS SPACER PLATE & GASKET) 96042986 VALVE, CONT (W/BODY & VLV) (INCLS 343, 351, 365-367, 370-375, 377-388) 96042889 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/PLT, GSKT, SEAL) (INCLS 343, 351, 365-367, 370-375, 377-388) (GM04-581) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru 96042806 СЦЕПЛЕНИЕ, DIR & REV (INCLS 400-420) (GM04-581) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru 96042814 СЦЕПЛЕНИЕ, DIR & REV (INCLS 400-420) (GM04-582) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96041856 SEAL, INPUT SHF (O RING) (*KIT1) [ПРОКЛАДКА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] teamcadillac.ru 96042807 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-451) (GM04-582) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042815 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-451) (GM04-583) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042707 КРОНШТЕЙН, INPUT & REACTION (INCLS 455-462) (4.176) (GM04-583) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042817 КРОНШТЕЙН, INPUT & REACTION (INCLS 455-462) (GM04-584) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-584) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ teamcadillac.ru 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-585) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 470-477) (GM04-585) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 470-477) (GM04-586) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 480-497) (GM04-586) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 480-497) (GM04-587) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК ↓ teamcadillac.ru 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (INCLS 500-505) (GM04-587) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК ↓ teamcadillac.ru 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (INCLS 500-505) (GM04-588) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) КРЕПЛЕНИЕ ↓ teamcadillac.ru 96042809 SUPPORT, CTR (INCLS 510-535) (GM04-588) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) КРЕПЛЕНИЕ ↓ teamcadillac.ru 96042816 SUPPORT, CTR (INCLS 510-535) (GM04-589) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) PLANETARY КРОНШТЕЙН БЛОК ↓ teamcadillac.ru 96042707 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-554) (4.176) (GM04-589) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) PLANETARY КРОНШТЕЙН БЛОК ↓ teamcadillac.ru 96042817 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-554) (GM04-590) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК ↓ 96042709 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560-564) (GM04-591) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК ↓ teamcadillac.ru 96042813 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560-561, 563-564) (GM04-593) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) PARKING PAWL БЛОК ↓ 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 96042540 SWITCH, A/TRNS MAN SHFT SHF POSN [ВЫКЛЮЧАТЕЛЬ ПРИВОДА] 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 08644709 SEAL, MAN SHFT SHF (W/O PTFE LUBRICANT APPLIED TO SEAL) (ACDelco #8644709) 96041857 SHAFT, MAN SHFT teamcadillac.ru 96042711 PAWL KIT, PARK 96041852 PLUG, MAN SHFT SHF HOLE (4.279) 96041842 SPACER, MAN SHFT DTNT LVR (GM04-594) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) PARKING PAWL БЛОК ↓ 96042819 LEVER, MAN SHFT DTNT 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] teamcadillac.ru 96042540 SWITCH, A/TRNS MAN SHFT SHF POSN [ВЫКЛЮЧАТЕЛЬ ПРИВОДА] 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 08644709 SEAL, MAN SHFT SHF (W/O PTFE LUBRICANT APPLIED TO SEAL) (ACDelco #8644709) 96042544 SHAFT KIT, MAN SHFT 96042820 PAWL KIT, PARK (GM04-598) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (6L50 MYB, ЗАДНИЙ КОЛЕСО DRIVE MX0) ↓ 17804000 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) teamcadillac.ru 17804001 ТРАНСМИССИЯ, AUTO (GM04-599) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (6L50 MYB, ALL КОЛЕСО DRIVE MX7) ↓ 17804000 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) 17804001 ТРАНСМИССИЯ, AUTO (GM04-668) - 2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 24240018 CONVERTER, TORQ [ГИДРОТРАНСФОРМАТОР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 11515762 БОЛТ-HFLGE, M8X1.25X50, 18 OD, 22 THD, 10.9, PZO (T/CV HSG) 24225543 SEAL, A/TRNS ГИДРОНАСОС (ACDelco #24225543) [ПРОКЛАДКА КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24242045 CASE, A/TRNS (INCLS 6, 12, 13) (ACDelco #24242045) 24242046 CASE, A/TRNS (INCLS 6, 12, 13) (ACDelco #24242046) 24226020 PLUG, TRANS FLUID FIL TUBE 24239878 SLEEVE, A/TRNS ELEC CONN PASG [МУФТА] 24225788 БОЛТ, A/TRNS CASE EXTN (M10X1.5X34) 24225557 SEAL, CTR SUPT FLUID PASG (*KIT2) 24224822 БОЛТ, C/VLV LWR BODY (M5X0.8X55) 24231074 БОЛТ, MAN SHFT DTNT (M10X1X14.5) 24222646 DETENT, MAN SHFT (W/8MM DIA. ROLLER) (ACDelco #24222646) 24236933 FILTER KIT, A/TRNS FLUID (INCLS 25) (ACDelco #24236933) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24225800 GASKET, A/TRNS FLUID PAN (ACDelco #24225800) [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 29535617 MAGNET, A/TRNS FLUID PAN (4.105) (ACDelco #29535617) [МАГНИТ] teamcadillac.ru 24242410 PAN, A/TRNS FLUID (INCLS 31) (ACDelco #24242410) 11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (A/TRNS FLUID PAN) [БОЛТ М6] 24234212 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 29) (ACDelco #24234212) [ПРОБКА] 24205900 PLUG, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] 24225783 SEAL, A/TRNS CASE EXTN (ACDelco #24225783) [УПЛОТНИТЕЛЬ КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24237879 EXTENSION, A/TRNS CASE (INCLS 36, 37) (ACDelco #24237879) 24228876 SEAL, ВЫХОДНОЙ SHF (ЧАСТЬ OF 34) (5.556) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24214158 BEARING, ВЫХОДНОЙ SHF (DRAWN CUP) (ЧАСТЬ OF 34) (4.131) (ACDelco #24214158) 24230287 FLANGE, PROP SHF TRANS 24231524 ГАЙКА, FRT PROP SHF FLG (M22X1.5) (FLANGE HEX) 24229687 EXTENSION, A/TRNS CASE (MCHG) 24237771 BEARING, ВЫХОДНОЙ SHF 24242995 BEARING, ВЫХОДНОЙ SHF [ПОДШИПНИК КПП] 24236928 SEAL KIT, A/TRNS ELEC CONN PASG SLEV (INCLS 9, 10) 24238913 SEAL KIT, A/TRNS SERV (INCLS 9, 10, 18-20) (CONTROL VLV SOL ASM) (ACDelco #24238913) [КОМПЛЕКТ ПРОКЛАДОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (5ШТ)] 04 - ТОРМОЗА ↓ (6D04-023) - 2004-2009 E СТОЯНОЧНЫЙ ТОРМОЗ ASM ↓ 88951984 PLATE, RR PARK BRK ANC BKG (4.591) 88951985 PLATE, RR PARK BRK ANC BKG (4.591) 88951982 ACTUATOR KIT, RR PARK BRK (INCLS 2) (ACDelco #179-2053) [АКТУАТОР] 88951983 ACTUATOR KIT, RR PARK BRK (INCLS 2) (ACDelco #179-2054) [АКТУАТОР] 89047676 SHOE KIT, RR PARK BRK (INCLS 5) (ACDelco #171-0915) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (2 ШТ)] (6D04-031) - 2004-2009 E ТОРМОЗНОЙ СУППОРТ-ЗАДНИЙ ↓ 89047677 CALIPER KIT, RR BRK (INCLS 2, 3, 7-9) (ACDelco #172-2343) 89047678 CALIPER KIT, RR BRK (INCLS 2, 3, 7-9) (ACDelco #172-2344) [ТОРМОЗНОЙ СУППОРТ] 88951992 CAP, RR BRK BLEDR VLV (ЧАСТЬ OF 1) 88951991 VALVE, RR BRK CLPR BLEDR (ЧАСТЬ OF 1) 89047757 PAD KIT, RR DISC BRK (INCLS 4, 12) (ACDelco #171-859) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4 ШТ)] 89047758 PAD KIT, RR DISC BRK (INCLS 4, 12) (4.667) (ACDelco #171-0906) [ТОРМОЗНЫЕ КОЛОДКИ] 88957163 BRACKET, RR BRK CLPR [СКОБА ТОРМОЗНОГО СУППОРТА] 89047759 PIN KIT, RR BRK CLPR GDE (INCLS 4-6) (INCLS 2 PINS, 2 SEALS & 2 (2.75") БОЛТS) (ACDelco #179-2044) [НАПРАВЛЯЮЩАЯ ТОРМОЗНОГО СУППОРТА (2 ШТ)] teamcadillac.ru 88957162 REPAIR KIT, RR BRK CLPR HYD (INCLS 4, 6, 8, 9) (6D04-033) - 2004-2009 E ТОРМОЗНОЙ УСИЛИТЕЛЬ ↓ 88967237 BOOSTER, P/B (W/O VLV) (ACDelco #178-0695) 05461808 GROMMET, P/B BOOS VAC CHK VLV (*KIT1) 03817880 RETAINER, BRK PED PUSH ROD (0.80 IN) (PUSH IN) teamcadillac.ru 18022219 VALVE KIT, P/B BOOS VAC CHK (INCLS 2, 3) (BLACK) (INCLS VLV & GROM) (ACDelco #179-1266) (6D04-067) - 2007-2009 E КОРПУС КП КРЕПЛЕНИЕ (MYB,MX7) ↓ 24231525 GASKET, TRFER CASE teamcadillac.ru 19132968 CASE, TRFER (W/GEARS) (LESS DAMPENER) 24243367 CASE, TRFER (W/GEARS) 11589341 БОЛТ - HFH, M10X1.5X69.9, 28.35 THD, 22.3 OD, 10.9, GMW3359, M-PT. (TRFER CASE) [БОЛТ] (6E00-014) - 2004-2009 E ТРАНСМИССИЯ TO КРЕПЛЕНИЕ ДВИГАТЕЛЯ (LY7/3.6-7) ↓ 12572042 PLATE, A/TRNS FLEX 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] teamcadillac.ru 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (TRANS CVR) [БОЛТ] 24222918 COVER, TRANS CONV 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] (6E03-019) - 2007-2009 E T.C.M. МОДУЛЬ (LY7/3.6-7) ↓ 12623327 МОДУЛЬ, ENG CONT (W/O CALN) 25784072 BRACKET, ECM (INCLS 5, 6) teamcadillac.ru 24239785 МОДУЛЬ, TRANS CONT (W/O CALN) 11609462 SCREW, M4.2X1.41X13, GMW4205 (ЧАСТЬ OF 3) 11561758 БОЛТ, MULTIUSE RLY & FUSE BRKT (7.833) [БОЛТ] 15879156 BRACKET, ACSRY WRG J/BLK 11609599 STUD, SPL, M6X1X25, 13 THD, 11 OD HD W/26 WIDE CLIP, 9.8, 6280M, P-PT (MULTIUSE FUSE BRKT) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (MULTIUSE RLY & FUSE BRKT) [ГАЙКА М6] (6E04-007) - 2007-2009 EB ТОРМОЗНЫЕ ШЛАНГИ И ТРУБКИ ↓ 15933099 HOSE, FRT BRK (INCLS 15, 16) (ACDelco #176-1495) 11569742 RETAINER, FRT BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (BRK & FUEL FEED & FUEL RTN & EVAP EMIS) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА] 25761218 BRACKET, FUEL PIPE 25761217 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (3.162) 12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (FRT BRK) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА] teamcadillac.ru 10388788 PIPE, BRK PRESS MOD VLV FRT (INCLS 29) 10388794 PIPE, BRK PRESS MOD VLV RR (INCLS 29) 03541444 SPACER, FRT BRK PIPE 11516521 БОЛТ, HFH M6X1X20, 9.8, 7114M, DOG PT, 14.2 OD (FRT BRK HOSE) 15933098 HOSE, FRT BRK (INCLS 15, 16) (ACDelco #176-1487) 25743891 RETAINER, RR BRK FRT PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT) 11569737 FITTING, FRT BRK PIPE (ЧАСТЬ OF 1, 12) (7/16-24X0.36, 0.30THD) (0.56 LONG, 3/16TUBE) 25743891 RETAINER, FRT BRK PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT) 15904901 CLIP, FRT BRK PIPE (STAR SHAPED 3 TUBE W/TREE) [КРОНШТЕЙН] 25737279 CLIP, FRT BRK PIPE (THREE WAY RETAINER SINGLE CENTRAL FIR-TREE ATTACHMENT) 25749839 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (HOLDS 3 ТРУБКИ, FLAT SHAPE, SNAP-IN RETAINER) 25867884 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE 15880948 RETAINER, BRK PIPE (FOR 5 LINES W/45 DEGREE PUSHPIN) 25607191 RETAINER, BRK PIPE (21.5X10.0MM) (HOLDS (2) 4.68-4.82 TUBES) 11569742 RETAINER, RR BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 15724650 ГАЙКА, INVERTED FLARED TUBE, 9/16"-18, 1/4" TUBE, ZD (BRK PIPE) (4.686) [ГАЙКА] 25693890 RETAINER, RR BRK PIPE (HOLDS (1) 4.76 LINE) (W/TREE) [ЗАМОК, ФИКСАТОР] 11588803 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 7, 8) (1/2-20X.40, .32 THD) (INVERTED FLARED TUBE) (.62 LONG, 1/4 TUBE) [ГАЙКА М20] 15724650 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 7, 8) (9/16-18 X .40) (INVERTED FLARED TUBE) [ГАЙКА] 15933091 HOSE, RR BRK (INCLS 22, 23) (ACDelco #15933091) 15933092 HOSE, RR BRK (INCLS 22, 23) (ACDelco #15933092) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ] 88964150 PROTECTOR, RR BRK PIPE (FOR 3/16" PIPE) (HT SHRINK) (6E04-008) - 2007-2009 EB ТОРМОЗНАЯ ПЕДАЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (EXC (JF4)) ↓ 25732428 BARRIER, BRK PED BRKT SND 25697461 RETAINER, BRK PED PUSH ROD BOOT 25732452 BOOT, BRK PED PUSH ROD 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] 15932827 HOSE, P/B BOOS VAC (ACDelco #176-1496) 25818868 PEDAL, BRK (W/BRKT) (INCLS 10, 11, 14, 16-18) 25771615 COVER, BRK PED (ЧАСТЬ OF 9) 89047699 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 9) [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 9) teamcadillac.ru 10434956 BUSHING, BRK PED PUSH ROD 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 9) 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 9) (0.80 IN) (PUSH IN) (6E04-012) - 2007-2009 E КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS(MYB,MX7) ↓ 88996677 CASE, TRFER (FRT HALF) (INCLS 12-14) 19133265 CASE, TRFER (RR HALF) (INCLS 5, 7) 88996679 SNUBBER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN 88996680 БОЛТ, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN SNBR (M5X0.8X16) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 2) 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL FILL) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996657 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 2) [УПЛОТНИТЕЛЬ] 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL DRN) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996680 БОЛТ, TRFER CASE VENT BFL (M5X0.8X16) (4.535) 88996658 BAFFLE, TRFER CASE VENT teamcadillac.ru 89048123 БОЛТ, TRFER CASE HALF (M8X1.25X30) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 1) 88996656 SEAL, TRFER CASE INPUT SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 88996657 SEAL, TRFER CASE FRT ВЫХОДНОЙ SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] (6E04-013) - 2008-2009 E КОРПУС КП ЧАСТЬ 2 INTERNAL COMPONENTS(MX5) ↓ 88984517 WASHER, TRFER CASE PLNT CARR SUN GR THR (25.8X52.0X2.2) 88984524 GEAR, TRFER CASE PLNT CARR SUN (INPUT) (STAMPED PM/POWDERED METAL) 88984493 RING, TRFER CASE RR ВЫХОДНОЙ SHF RR BRG RET (41MM I.D.) (ACDelco #88984493) 88996564 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT 88996665 BEARING, TRFER CASE MAIN SHF FRT (ВЫХОДНОЙ ВАЛ FRT) 19168733 BUSHING, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 106) [ВТУЛКА РАЗДАТОЧНОЙ КОРОБКИ] 19178237 SHAFT, TRFER CASE RR ВЫХОДНОЙ (INCLS 105) 19178238 SHAFT, TRFER CASE RR ВЫХОДНОЙ (INCLS 105) 19133264 SPROCKET, TRFER CASE FRT ВЫХОДНОЙ SHF DRV (INCLS 108) [ШЕСТЕРНЯ РАЗДАТОЧНОЙ КОРОБКИ] 19168732 BUSHING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT (ЧАСТЬ OF 107) (ACDelco #19168732) 19132837 CHAIN, TRFER CASE TWO/FOUR WHL DRV 89059578 CHAIN, TRFER CASE TWO/FOUR WHL DRV [ЦЕПЬ РАЗДАТОЧНОЙ КОРОБКИ] 88984523 GEAR, TRFER CASE PLNT CARR SUN (ВЫХОДНОЙ) 89059279 КРОНШТЕЙН, FRT/RR DRV DIFF 89059284 SHAFT, TRFER CASE FRT ВЫХОДНОЙ (INCLS 900) 88996664 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF RR 88996671 RING, TRFER CASE FRT ВЫХОДНОЙ SHF BRG RET 88996666 SPROCKET, TRFER CASE TWO/FOUR WHL DRV DRVN [ЗВЕЗДОЧКА] 88996633 BEARING, TRFER CASE RR ВЫХОДНОЙ SHF RR (ACDelco #88996633) [ПОДШИПНИК РАЗДАТОЧНОЙ КОРОБКИ] 15580230 BEARING, TRFER CASE INPUT SHF (BORG-WARNER) (4.510) 19132966 SHAFT, TRFER CASE INPUT teamcadillac.ru 88996681 DEFLECTOR, TRFER CASE FRT ВЫХОДНОЙ SHF SEAL DIRT (ЧАСТЬ OF 112) (6E04-016) - 2004-2009 E КЛАПАН РЕГУЛИРОВКИ ДАВЛЕНИЯ В ТОРМОЗНОЙ СИСТЕМЕ ↓ 19153350 МОДУЛЬ KIT, ELEK BRK & TRACT CONT [МОДУЛЬ] teamcadillac.ru 89060233 VALVE KIT, BRK PRESS MOD (INCLS 3, 4) (ACDelco #89060233) [ГИДРАВЛИЧЕСКИЙ БЛОК АБС] 25743362 SENSOR, BRK PRESS MOD VLV PRESS (ЧАСТЬ OF 2) (ACDelco #25743362) [ДАТЧИК] 25741456 INSULATOR, BRK PRESS MOD VLV (ЧАСТЬ OF 2) 11588304 STUD, FLANGE DOUBLE END, M8X14 UNTHD, M8X1.25X13, 17 OD, 5.8, GM4345M (BRK PRESS MOD VLV BRKT) 11514596 ГАЙКА, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (BRK PRESS MOD VLV BRKT) (8.915) (ACDelco #11514596) 11508351 SCREW, PAN HD, C/R, 5X0.8X13, 9.3 OD, FULL THD, THD RLLR, 6171M, PC (BRK PRESS MOD VLV) (8.977) (6E04-017) - 2007-2009 E ШЛАНГ ВЕНТИЛЯЦИИ ТРАНСМИССИИ (LY7/3.6-7, M82,MX5) ↓ 25764835 VENT, A/TRNS (INCLS 2, 3) (ACDelco #25764835) teamcadillac.ru 15955072 CLIP, TRANS VENT HOSE (ЧАСТЬ OF 1) (.650MM DIA) (2.343) (6E04-018) - 2004-2009 E КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS(MX5) ↓ 88996677 CASE, TRFER (FRT HALF) (INCLS 12-14) 19133265 CASE, TRFER (RR HALF) (INCLS 5, 7) teamcadillac.ru 88996679 SNUBBER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN 88996680 БОЛТ, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN SNBR (M5X0.8X16) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 2) 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL FILL) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996657 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 2) [УПЛОТНИТЕЛЬ] 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL DRN) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996680 БОЛТ, TRFER CASE VENT BFL (M5X0.8X16) (4.535) 88996658 BAFFLE, TRFER CASE VENT 89048123 БОЛТ, TRFER CASE HALF (M8X1.25X30) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 1) 88996656 SEAL, TRFER CASE INPUT SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 88996657 SEAL, TRFER CASE FRT ВЫХОДНОЙ SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 19180066 VENT, TRFER CASE 89048123 БОЛТ, TRFER CASE VIB DPNR (M8X1.25X30) 19133173 DAMPENER, TRFER CASE VIB (YOKE STYLE; БОЛТS TO RR OF T-CASE) (6E04-020) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ 24218963 RING, T/CV FLUID SEAL RET [КОЛЬЦО] 24237531 SEAL, T/CV FLUID (ЧАСТЬ OF 217, 219) (ACDelco #24237531) [УПЛОТНЕНИЕ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 00444613 PLUG, HEX HD, 1/8-27 NPTF, STL (LINE PRESS TEST HOLE) (ACDelco #444613) 24239385 ШЛАНГИ, T/CV (MCHG) (INCLS 206) 24225422 PIPE, A/TRNS VENT 15251488 SEAL, TRANS FLUID CLR PIPE FTG (ЧАСТЬ OF 217, 219) (SEALS TWO ТРУБКИ) (*KIT1) [УПЛОТНЕНИЕ] 24237658 SEAL, TRANS FLUID CLR PIPE FTG (ЧАСТЬ OF 217, 219) (SEALS ONE PIPE) (*KIT1) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ] teamcadillac.ru 24222668 SLIDE, A/TRNS ГИДРОНАСОС (17.948MM-17.961MM) (ACDelco #24222668) 24224131 SLIDE, A/TRNS ГИДРОНАСОС (17.961MM-17.974MM) (ACDelco #24224131) 24224132 SLIDE, A/TRNS ГИДРОНАСОС (17.974MM-17.987MM) (ACDelco #24224132) 24238915 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 207-211, 213-216, 230) (17.948MM-17.961MM) (ACDelco #24238915) 24238916 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 207-211, 213-216, 230) (17.961MM-17.974MM) (ACDelco #24238916) 24238917 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 207-211, 213-216, 230) (17.974MM-17.987MM) (ACDelco #24238917) 24238919 COVER KIT, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 218, 220-230, 232-237) (ACDelco #24238919) 00147500 VALVE, PRESS RLF BALL (ЧАСТЬ OF 219) 24224692 WASHER, 1-2-3-4 & 3-5 REV CLU HSG THR (ЧАСТЬ OF 219) 24239151 RING KIT, 1-2-3-4 & 3-5 REV CLU FLUID SEAL (ACDelco #24239151) 24248559 RING KIT, 1-2-3-4 & 3-5 REV CLU FLUID SEAL (1-SET 2ND DES SEALS (INCL QUAD LOBE)) (ACDelco #24248559) 24227061 БОЛТ, A/TRNS ГИДРОНАСОС CVR (ACDelco #24227061) [БОЛТ] 90351709 PIN, A/TRNS ГИДРОНАСОС LOC (ЧАСТЬ OF 219) ("8MM HOLLOW SPLIT PIN") (1.639) [ШПИЛЬКА] 24243891 SEAL KIT, A/TRNS SERV (INCLS 205, 210, 214, 230) (UNITS BUILT 8-17-08 & PRIOR) (2ND DES SEE 24248567) (FULL TRANS) (ACDelco #24243891) (6E04-022) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (LY7/3.6-7, V92) ↓ 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 89022494 BRACKET, TRANS FLUID CLR 19129782 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) [ТРУБКА МАСЛООХЛАДИТЕЛЯ] 19130214 SEAL, TRANS FLUID CLR HOSE CONN (O RING) 19129781 HOSE, TRANS FLUID CLR LWR (W/BLOCK) teamcadillac.ru 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 19130449 COOLER, TRANS FLUID (INCLS 7-10) (ACDelco #19130449) [РАДИАТОР] (6E04-024) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (LH2/4.6A, EXC V92) ↓ 19130449 COOLER, TRANS FLUID (INCLS 7-9) (ACDelco #19130449) [РАДИАТОР] 11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) [БОЛТ, М8Х1.25Х31.5] 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 15251488 SEAL, TRANS FLUID CLR PIPE FTG (ЧАСТЬ OF 5) (SEALS TWO ТРУБКИ) [УПЛОТНЕНИЕ] 15882260 PIPE, TRANS FLUID CLR INL & OTLT (INCLS 4, 6) [ТРУБКА МАСЛОПРОВОДА] 10405874 CLIP, TRANS FLUID CLR PIPE (ЧАСТЬ OF 5) (LESS MNTG TAB) (HOLDS TWO 9.5 DIA TUBES) teamcadillac.ru 11570323 БОЛТ, КОНДИЦИОНЕР CNDSR (M6X1X18, 13 THD) (1.277) 15921020 CLIP, TRANS FLUID AUX CLR PIPE (CYLINDRICAL) (1 PIPE) (6E04-025) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (LH2/4.6A, V92) ↓ 19130449 COOLER, TRANS FLUID (INCLS 7-10) (ACDelco #19130449) [РАДИАТОР] 11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) [БОЛТ, М8Х1.25Х31.5] 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 15882260 PIPE, TRANS FLUID CLR INL & OTLT (INCLS 4, 6) [ТРУБКА МАСЛОПРОВОДА] 10405874 CLIP, TRANS FLUID CLR PIPE (ЧАСТЬ OF 5) (LESS MNTG TAB) (HOLDS TWO 9.5 DIA TUBES) teamcadillac.ru 15921020 CLIP, TRANS FLUID AUX CLR PIPE (CYLINDRICAL) (1 PIPE) (6E04-027) - 2007-2009 EB СТОЯНОЧНЫЙ ТОРМОЗ SYSTEM ↓ 10395687 LEVER, PARK BRK (INCLS 2-4, 17, 18) 22654577 SWITCH, PARK BRK IND (ЧАСТЬ OF 1) (ACDelco #22654577) [ВКЛЮЧАТЕЛЬ] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (PARK BRK INTER CBL GDE) [ГАЙКА М6] teamcadillac.ru 15797212 CABLE, PARK BRK INTER (INCLS 5, 10, 11) (ACDelco #15797212) [ТРОС СТОЯНОЧНОГО ТОРМОЗА В СБОРЕ] 11517484 БОЛТ-HEX, M6X1X20, 9 THD, 17 OD, 9.8, 6280M, MACH, P-PT (PARK BRK INTER CBL GDE) 25764260 CABLE, PARK BRK RR (28.2X28.5X811.7MM) (ACDelco #25764260) [ТРОС СТОЯНОЧНОГО ТОРМОЗА] 25880964 HANDLE, PARK BRK REL 11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (PARK BRK REL HDL HSG) [ВИНТ] 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (КАПОТ PRIM LAT REL CBL HDL BRKT) [ВИНТ М4] 15882985 RETAINER, PARK BRK REL HDL 11570654 ГАЙКА, PARK BRK REL HDL BRKT (4.2 X 1.41) (FITS 8.75 SQ HOLE) (9.665) 89047821 CABLE, PARK BRK REL (ЧАСТЬ OF 1) (ACDelco #89047821) 10369646 БОЛТ, PARK BRK IND SW (ЧАСТЬ OF 1) (6E04-030) - 2007-2009 E УПРАВЛЕНИЕ АКПП/АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX0) ↓ 15946116 PLATE, F/FLR CNSL TRANS SHFT OPG TR PLT MT (INCLS 14) (TORTOISE SHELL) 25828031 PLATE, F/FLR CNSL TRANS SHFT OPG TR PLT MT (INCLS 14) (FIGURED SAPELE) 19180495 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (EBONY ON MIDDLE & SIDES) 19180497 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (COCOA ON MIDDLE & SIDES) 19180501 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (FIG SAPELE WOOD W/EBONY) 19180506 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (FIG SAPELE WOOD W/COCOA) 89027001 COVER, A/TRNS CONT LVR HDL (ЧАСТЬ OF 2) (4.006) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL LVR CBL BRKT) [ГАЙКА М6] 15780845 LINK, A/TRNS RANGE SEL LVR 15780847 LINK, A/TRNS RANGE SEL LVR 11519095 NUT-ACORN HEX, M8X1.0, 15MM THK, 9, 6047M, W/DOME. (A/TRNS RANGE SEL LVR) [ГАЙКА] teamcadillac.ru 25789237 RETAINER, F/FLR CNSL (ЧАСТЬ OF 9) 25807057 BEZEL, F/FLR CNSL CUP HLDR (INCLS 8) (GRAY) 25807058 BEZEL, F/FLR CNSL CUP HLDR (INCLS 8) (EBONY) 25807059 BEZEL, F/FLR CNSL CUP HLDR (INCLS 8) (CASHMERE) 19167874 CONTROL, A/TRNS 19167876 CONTROL, A/TRNS 89027003 BULB, A/TRNS CONT POSN IND (BULB W/BLUE COVER) (4.020) (ACDelco #89027003) 19122183 BEZEL, A/TRNS CONT HSG (PRNDL CHROME COVER) 11570687 БОЛТ, A/TRNS CONT LVR KNOB (ЧАСТЬ OF 2) (6E04-031) - 2007-2009 E УПРАВЛЕНИЕ АКПП/АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX7) ↓ 15946116 PLATE, F/FLR CNSL TRANS SHFT OPG TR PLT MT (INCLS 2) (TORTOISE SHELL) 25828031 PLATE, F/FLR CNSL TRANS SHFT OPG TR PLT MT (INCLS 2) (FIGURED SAPELE) 11570687 БОЛТ, A/TRNS CONT LVR KNOB (ЧАСТЬ OF 14) 89027003 BULB, A/TRNS CONT POSN IND (BULB W/BLUE COVER) (4.020) (ACDelco #89027003) 19167812 CONTROL, A/TRNS [МЕХАНИЗМ ПЕРЕКЛЮЧЕНИЯ ПЕРЕДАЧ] 19167875 CONTROL, A/TRNS [ПОДДОН АКП] 25807057 BEZEL, F/FLR CNSL CUP HLDR (INCLS 7) (GRAY) 25807058 BEZEL, F/FLR CNSL CUP HLDR (INCLS 7) (EBONY) teamcadillac.ru 25807059 BEZEL, F/FLR CNSL CUP HLDR (INCLS 7) (CASHMERE) 25789237 RETAINER, F/FLR CNSL (ЧАСТЬ OF 6) 11514603 ГАЙКА, M10X1.5 15MM SOCKET (A/TRNS RANGE SEL LVR) [ШАЙБА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL ROD ADJ) [ГАЙКА М6] 15780844 LINK, A/TRNS RANGE SEL LVR 15780846 LINK, A/TRNS RANGE SEL LVR 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL LVR CBL BRKT) [ГАЙКА М6] 19122183 BEZEL, A/TRNS CONT HSG (PRNDL CHROME COVER) 89027001 COVER, A/TRNS CONT LVR HDL (ЧАСТЬ OF 14) (4.006) 19180495 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (EBONY ON MIDDLE & SIDES) 19180497 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (COCOA ON MIDDLE & SIDES) 19180501 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (FIG SAPELE WOOD W/EBONY) 19180506 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (FIG SAPELE WOOD W/COCOA) (6E04-035) - 2005-2009 E BRAKE SYSTEM/ANTILOCK ↓ teamcadillac.ru 12413103 HUB, FRT WHL (W/BRG) (СМ. ГРУППУ 06.000 "ПОДВЕСКА-ПЕРЕДНЯЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/WHL SPD SEN) (ACDelco #FW149) [СТУПИЦА КОЛЕСА] 12413105 HUB, FRT WHL (W/BRG) (СМ. ГРУППУ 06.000 "ПОДВЕСКА-ПЕРЕДНЯЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPEED SENSOR) (ACDelco #FW150) [СТУПИЦА КОЛЕСА] 89047639 HUB, RR WHL (W/WHL SPD SEN) (СМ. ГРУППУ 06.000 "ЗАДНЯЯ ПОДВЕСКА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6 STUD HUB) (ACDelco #RW20-19) [СТУПИЦА КОЛЕСА] 10307709 SENSOR, VEH YAW (W/VEH LATL ACCLRM) [ДАТЧИК] 15906579 SENSOR, VEH YAW (W/ VEH LATL & LGTDNL ACCLRM) [ДАТЧИК] 11561645 ГАЙКА, HFH, M6X1X6.45, 13.5 OD, 10 STL, GMW3200 (VEH YAW SEN & LATL ACCLRM) (6E04-036) - 2007-2009 EB ТОРМОЗНАЯ ПЕДАЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (JF4) ↓ 25732428 BARRIER, BRK PED BRKT SND 25697461 RETAINER, BRK PED PUSH ROD BOOT 25732452 BOOT, BRK PED PUSH ROD 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) teamcadillac.ru 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] 15932827 HOSE, P/B BOOS VAC (ACDelco #176-1496) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (ACCEL PED LVR) 10368488 PEDAL, BRK (INCLS 12, 13, 15, 18-22) 25771615 COVER, BRK PED (ЧАСТЬ OF 11) 89047699 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 11) (INCLS 18) [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 89047780 MOTOR KIT, BRK & ACCEL PED ADJR ACTR [ЭЛЕКТРОДВИГАТЕЛЬ ПЕДАЛЬНОГО УЗЛА 19 ВТ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 11, 13) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 11) 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 11) 25697461 RETAINER, BRK PED PUSH ROD BOOT (ЧАСТЬ OF 11) 89047779 CABLE, ACCEL CONT 89047778 CABLE, BRK PED ADJR ACTR [ЖГУТ ПРОВОДОВ] 25741052 BRACKET, BRK PED BRKT 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-037) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (LY7/3.6-7, EXC V92) ↓ 19130570 HOSE, TRANS FLUID CLR LWR (W/BLOCK) (INCLS 7) 11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16] 89022494 BRACKET, TRANS FLUID CLR 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 25740416 SEAL, TRANS FLUID CLR PIPE (O RING) (1/2IN) (9.222) (ACDelco #15-31872) [ПРОКЛАДКА КОМПРЕССОРА КОНДИЦИОНЕРА] 19129977 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) teamcadillac.ru 15921020 CLIP, TRANS FLUID AUX CLR PIPE (CYLINDRICAL) (1 PIPE) (6M04-039) - 2009 E ШЛАНГ ВЕНТИЛЯЦИИ ТРАНСМИССИИ (LH2/4.6A, MYB) ↓ 25892279 VENT, TRFER CASE (ЧАСТЬ OF 3) (ACDelco #25892279) [ЗАГЛУШКА ШЛАНГА ВЕНТИЛЯЦИИ КАРТЕРА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 08905794 CLIP (ЧАСТЬ OF 3) teamcadillac.ru 25892019 HOSE, TRANS VENT (INCLS 1, 2, 4) 25526358 CЛАМПА, SPRG BAND, 14.2MM, 9/16 OD HOSE, POR (ЧАСТЬ OF 3) (6M04-041) - 2009 E26 ТОРМОЗНАЯ ПЕДАЛЬ (PWR ADJ PEDALS JF4) ↓ 25741052 BRACKET, BRK PED BRKT 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 25732428 BARRIER, BRK PED BRKT SND 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 89047778 CABLE, BRK PED ADJR ACTR [ЖГУТ ПРОВОДОВ] 89047780 MOTOR KIT, BRK & ACCEL PED ADJR ACTR [ЭЛЕКТРОДВИГАТЕЛЬ ПЕДАЛЬНОГО УЗЛА 19 ВТ] teamcadillac.ru 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (BRK PED POSN SEN) 89047699 SENSOR KIT, BRK PED POSN [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 25697461 RETAINER, BRK PED PUSH ROD BOOT (ЧАСТЬ OF 21) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 21) 10368488 PEDAL, BRK (INCLS 5, 8-10, 13, 15-20, 22) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-042) - 2009 E26 ТОРМОЗНАЯ ПЕДАЛЬ (EXC PWR ADJ PEDALS JF4) ↓ 25741052 BRACKET, BRK PED BRKT 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 25732428 BARRIER, BRK PED BRKT SND 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 18) 89047699 SENSOR KIT, BRK PED POSN [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 15594358 BUSHING, BRK PED PIV (ЧАСТЬ OF 18) (0.831) 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 18) (0.80 IN) (PUSH IN) 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 18) teamcadillac.ru 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 18) 25771615 COVER, BRK PED (ЧАСТЬ OF 18) 25818868 PEDAL, BRK (W/BRKT) (INCLS 5-8, 10, 12-17, 19) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-044) - 2004-2009 E26 ТОРМОЗНОЙ УСИЛИТЕЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА ↓ teamcadillac.ru 88967237 BOOSTER, P/B (СМ. ГРУППУ 04.000 "ТОРМОЗНОЙ УСИЛИТЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/O VLV) (ACDelco #178-0695) 25732452 BOOT, BRK PED PUSH ROD 25697461 RETAINER, BRK PED PUSH ROD BOOT 10367561 CYLINDER, BRK MAS (СМ. ГРУППУ 4.000 "ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #174-1012) [ЦИЛИНДР] 11609949 ГАЙКА, BRK M/CYL (M10X1.5, 11.2 THK) (8.917) [ГАЙКА] 25873484 HOSE, P/B BOOS VAC (ACDelco #176-1497) (GM00-588) - 2009 E ТРАНСМИССИЯ TO КРЕПЛЕНИЕ ДВИГАТЕЛЯ (LH2/4.6A) ↓ 12582606 FLYКОЛЕСО, ENG 25773136 BRACKET, ENG WRG HARN (CHANNEL) 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] teamcadillac.ru 24205900 PLUG, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] 12568123 COVER, TRANS CONV 11589116 БОЛТ, FLYWHL (8.900) 12568122 COVER, FLYWHL HSG 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (TRANS CONV CVR) (GM04-064) - 2004-2009 E ТОРМОЗНОЙ СУППОРТ-ПЕРЕДНИЙ ↓ 18047980 CALIPER, FRT BRK (INCLS 2-4, 8-10) (IF DISCONTINUED USE DURASTOP EQUIVALENT) (4.667) (ACDelco #172-1643) [ТОРМОЗНОЙ СУППОРТ] 18047981 CALIPER, FRT BRK (INCLS 2-4, 8-10) (IF DISCONTINUED USE DURASTOP EQUIVALENT) (4.667) (ACDelco #172-1644) [ТОРМОЗНОЙ СУППОРТ] 18043178 COVER, FRT BRK BLEDR SCREW (ЧАСТЬ OF 1) 18047986 VALVE KIT, FRT BRK CLPR BLEDR (ЧАСТЬ OF 1) (ACDelco #18047986) 18046750 БОЛТ, FRT BRK CLPR GDE PIN (ЧАСТЬ OF 1, 11) (*KIT2) [БОЛТ] teamcadillac.ru 18047985 PISTON KIT, FRT BRK CLPR (ЧАСТЬ OF 1) 18047988 PAD KIT, FRT DISC BRK (INCLS 4, 14) (ACDelco #171-665) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4 ШТ)] 19122384 PAD KIT, FRT DISC BRK (INCLS 4, 14) (ACDelco #171-688) 18045221 SEAL, FRT BRK CLPR GDE PIN 18047987 BRACKET, FRT BRK CLPR (W/GUIDE PIN БОЛТS) [КРОНШТЕЙН] 18046698 ПРУЖИНА, FRT DISC BRK PAD RET (ЧАСТЬ OF 11) (ACDelco #179-2235) 18047989 PIN KIT, FRT BRK CLPR GDE (INCLS 5-7) (INCLS 2 (2.5") БОЛТS) 18047984 CALIPER KIT, FRT BRK (INCLS 4, 8, 9) (4.667) (ACDelco #173-0538) (GM04-312) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (5L40-E M82) ↓ 96042897 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 6GRG) (GM04-376) - 2004-2009 E ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР ↓ 18012741 SWITCH, BRK FLUID LVL IND (ЧАСТЬ OF 15) (ACDelco #18012741) teamcadillac.ru 22688449 CAP, BRK M/CYL RSVR (ЧАСТЬ OF 15) (INCLS 3) [КРЫШКА БАЧКА ТОРМОЗНОЙ ЖИДКОСТИ] 18046711 RESERVOIR, BRK M/CYL (ЧАСТЬ OF 15) (INCLS 4, 6-7) (ACDelco #18046711) 18060168 PISTON, BRK M/CYL SECD (ЧАСТЬ OF 15) 10367561 CYLINDER, BRK MAS (INCLS 1-14) (ACDelco #174-1012) [ЦИЛИНДР] 18022002 CYLINDER KIT, BRK MAS (INCLS 8-12) (ACDelco #175-424) (GM04-485) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (5L40-E MX5) ↓ teamcadillac.ru 96042890 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 6GGG) [АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ В СБОРЕ] (GM04-555) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 24227130 БОЛТ, C/VLV UPR BODY (M5X0.8X36) 24225398 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M6 X 1.0 X 20) teamcadillac.ru 24238417 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (INCLS 316) (4.329) [ДАТЧИК ЧИСЛА ОБОРОТОВ ВАЛА AКПП] 24225797 BODY, C/VLV UPR [ГИДРОРАСПРЕДЕЛИТЕЛЬНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24245720 PLATE, C/VLV BODY SPCR (W/GSKT) (ACDelco #24245720) [НАБОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96020431 VALVE, C/VLV BODY BALL CHK [КЛАПАН] 24250384 BODY, C/VLV LWR (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ/;НИЖНИЙ КЛАПАН РЕГУЛЯТОР BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (MANUAL VALVE NOT INCLUDED) (MUST USE T/W 24236934/PLATE KIT - CONT SOL VLV FLTR) 24246427 SWITCH, A/TRNS MAN SHFT SHF POSN (INCLS 315) (INTERNAL MODE SWITCH) [ВКЛЮЧАТЕЛЬ] 24224821 БОЛТ, C/VLV LWR BODY (M5X0.8X45) 24224822 БОЛТ, C/VLV LWR BODY (M5X0.8X55) 24238925 PLATE KIT, CONT SOL VLV FLTR 24240845 БОЛТ, CONT SOL VLV HEAT SINK (W/ BODY & TCM) (M5X0.8X53.0) 24241890 VALVE, CONT SOL (W/ BODY & TCM) (ACDelco #24241890) (ORDER T/W 24238913 SEAL KIT) [ГИДРОРАСПРЕДЕЛИТЕЛЬНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24236233 CLIP, A/TRNS MAN SHFT SHF POSN SW WRG HARN (ЧАСТЬ OF 308) 24236504 CLIP, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN WRG HARN (ЧАСТЬ OF 303) (GM04-556) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ВЕРХНИЙ КЛАПАН РЕГУЛЯТОР BODY БЛОК ↓ teamcadillac.ru 24224766 PIN, C/VLV BODY LOC (ЧАСТЬ OF 321) (DIA.=10MM L=12.7) [ВТУЛКА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24225797 BODY, C/VLV UPR (INCLS 313, 322-338) [ГИДРОРАСПРЕДЕЛИТЕЛЬНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24230200 PIN, C/VLV BODY LOC (ЧАСТЬ OF 321) (DIA.=10MM L=29.9) [ВТУЛКА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, 1-2-3-4 CLU BOOST VLV SPR (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24242814 PLUG, 1-2-3-4 CLU REG VLV BORE (ЧАСТЬ OF 321) (9.5 THK, 11.5 DIA) (GM04-557) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) НИЖНИЙ КЛАПАН РЕГУЛЯТОР BODY БЛОК ↓ teamcadillac.ru 24224755 RETAINER, CLU PSTN DAM FEED REG VLV SPR [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24242814 PLUG, CLU SEL SOL VLV BORE #2 (9.5 THK, 11.5 DIA) 24250384 BODY, C/VLV LWR (INCLS 338, 352, 353, 355-357) (MANUAL VALVE NOT INCLUDED) (MUST USE T/W 24236934/PLATE KIT - CONT SOL VLV FLTR) 24224770 VALVE, MAN (ACDelco #24224770) (GM04-558) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) 1-2-3-4 & 3-5 REVERSE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 24240625 RING, 3-5 REV CLU BKG PLT RET (ЧАСТЬ OF 427) (LT GREEN) (2.25-2.35MM) (ACDelco #24240625) 24240626 RING, 3-5 REV CLU BKG PLT RET (ЧАСТЬ OF 427) (GRAY) (2.47-2.57MM) (ACDelco #24240626) 24240627 RING, 3-5 REV CLU BKG PLT RET (ЧАСТЬ OF 427) (YELLOW) (2.69-2.79MM) (ACDelco #24240627) 24240628 RING, 3-5 REV CLU BKG PLT RET (ЧАСТЬ OF 427) (ORANGE) (2.93-3.01MM) (ACDelco #24240628) 24240629 RING, 3-5 REV CLU BKG PLT RET (ЧАСТЬ OF 427) (LT BLUE) (3.13-3.23MM) (ACDelco #24240629) 24240630 RING, 3-5 REV CLU BKG PLT RET (ЧАСТЬ OF 427) (WHITE) (3.35-3.45MM) (ACDelco #24240630) 24240631 RING, 3-5 REV CLU BKG PLT RET (ЧАСТЬ OF 427) (YELLOW/PURPLE) (3.57-3.67MM) (ACDelco #24240631) 24225654 PLATE, 3-5 REV CLU BKG 24237663 PLATE, 3-5 REV CLU (PKG OF 4) (STEEL) 24225564 PLATE, 3-5 REV CLU (WAVED) 24233533 PLATE, 1-2-3-4 CLU BKG 24243588 PLATE, 1-2-3-4 CLU (ACDelco #24243588) 24232652 PLATE, 1-2-3-4 CLU (PKG OF 5) (STEEL) 24236434 PLATE, 1-2-3-4 CLU (WAVED) 24225522 DAM, 1-2-3-4 CLU PSTN 24225559 ПРУЖИНА, 1-2-3-4 CLU 24241073 PISTON, 1-2-3-4 CLU 24238558 ШЛАНГИ, 1-2-3-4 CLU PSTN 24236051 ПРУЖИНА, 3-5-REV CLU 24238560 PISTON, 3-5/REV CLU (INCLS 422) (4.164) 24237184 ШЛАНГИ, 1-2-3-4 & 3-5 REV CLU (INCLS 400, 426, 429) (ORDER T/W 24226393) 24226393 BEARING, 1-2-3-4 & 3-5-REV CLU 24240626 RING, 1-2-3-4 CLU BKG PLT RET (ЧАСТЬ OF 427) (GRAY) (2.47-2.57MM) (ACDelco #24240626) 24240627 RING, 1-2-3-4 CLU BKG PLT RET (ЧАСТЬ OF 427) (YELLOW) (2.69-2.79MM) (ACDelco #24240627) 24240628 RING, 1-2-3-4 CLU BKG PLT RET (ЧАСТЬ OF 427) (ORANGE) (2.93-3.01MM) (ACDelco #24240628) teamcadillac.ru 24240629 RING, 1-2-3-4 CLU BKG PLT RET (ЧАСТЬ OF 427) (LT BLUE) (3.13-3.23MM) (ACDelco #24240629) 24240630 RING, 1-2-3-4 CLU BKG PLT RET (ЧАСТЬ OF 427) (WHITE) (3.35-3.45MM) (ACDelco #24240630) 24240631 RING, 1-2-3-4 CLU BKG PLT RET (ЧАСТЬ OF 427) (YELLOW/PURPLE) (3.57-3.67MM) (ACDelco #24240631) 24240632 RING, 1-2-3-4 CLU BKG PLT RET (ЧАСТЬ OF 427) (LT BLUE/PURPLE) (3.79-3.89MM) (ACDelco #24240632) 24238920 RING KIT, RET (INCLS 411, 415) 24238922 SEAL KIT, A/TRNS SERV (INCLS 416, 418, 419, 422-425) (СЦЕПЛЕНИЕES) (ACDelco #24238922) (GM04-559) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) 4-5-6 ДЕТАЛИ СЦЕПЛЕНИЯ & ВАЛ ТУРБИНЫ ↓ 24225508 RING, 4-5-6 CLU BKG PLT RET (GREEN) (2.52-2.62) (ACDelco #24225508) 24225509 RING, 4-5-6 CLU BKG PLT RET (YELLOW) (3.08-3.18) (ACDelco #24225509) 24231591 RING, 4-5-6 CLU BKG PLT RET (GREY) (2.80-2.90) (ACDelco #24231591) 24231592 RING, 4-5-6 CLU BKG PLT RET (ORANGE) (3.36-3.46) (ACDelco #24231592) 24231593 RING, 4-5-6 CLU BKG PLT RET (BLUE) (3.64-3.74) (ACDelco #24231593) 24232879 RING, 4-5-6 CLU BKG PLT RET (WHITE) (3.74-3.84) (ACDelco #24232879) 24232880 RING, 4-5-6 CLU BKG PLT RET (YELLOW/PURPLE) (4.20-4.30) (ACDelco #24232880) 24225652 PLATE, 4-5-6 CLU BKG 24225570 PLATE, 4-5-6 CLU (INT SPLINE) (PKG OF 5) (FIBER) 24225575 PLATE, 4-5-6 CLU (EXT SPLINE) (PKG OF 5) (STEEL)FIBER) (ACDelco #24225575) teamcadillac.ru 24225565 PLATE, 4-5-6 CLU (WAVED) 24225526 DAM, 4-5-6 CLU PSTN 24225560 ПРУЖИНА, 4-5-6 CLU 24225523 PISTON, 4-5-6 CLU 24237963 ШЛАНГИ, 4-5-6 CLU (W/ INPUT SHF) (INCLS 440) 08662686 SEAL, TURB SHF (O RING) (*KIT2) (ACDelco #8662686) 24238920 RING KIT, RET (INCLS 436) 24243891 SEAL KIT, A/TRNS SERV (INCLS 436, 442, 443) (UNITS BUILT 8-17-08 & PRIOR) (2ND DES SEE 24248567) (FULL TRANS) (ACDelco #24243891) (GM04-560) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) 2-6 ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 24247405 RING, 2-6 CLU BKG PLT RET (1.69MM +/- 0.05) (ACDelco #24247405) 24247406 RING, 2-6 CLU BKG PLT RET (2.81MM +/- 0.05) (ACDelco #24247406) 24248107 RING, 2-6 CLU BKG PLT RET (2.25MM +/- 0.05) (ACDelco #24248107) teamcadillac.ru 24248108 RING, 2-6 CLU BKG PLT RET (2.53MM +/- 0.05) (ACDelco #24248108) 24248109 RING, 2-6 CLU BKG PLT RET (1.97MM +/- 0.05) (ACDelco #24248109) 24225653 PLATE, 2-6 CLU BKG 24237973 PLATE, 2-6 CLU (WAVED) 24225561 ПРУЖИНА, 2-6 CLU 24225524 PISTON, 2-6 CLU 24225447 SUPPORT, CTR (INCLS 458, 460) 24238911 PLATE KIT, CLU (INCLS 452) (ORDER T/W 24225575 & 24235455) (ACDelco #24238911) (GM04-561) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) LOW & REVERSE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 24225519 RING, LOW & REV CLU BKG PLT RET (2.77MM +/- 0.05) (ACDelco #24225519) 24231938 RING, LOW & REV CLU BKG PLT RET (2.63MM +/- 0.05) (MUST BE USED T/W 24247402) (ACDelco #24231938) 24231939 RING, LOW & REV CLU BKG PLT RET (2.93MM +/- 0.05) (MUST BE USED T/W 24247402) (ACDelco #24231939) 24247407 RING, LOW & REV CLU BKG PLT RET (2.03MM +/- 0.05) (MUST BE USED T/W 24247402) (ACDelco #24247407) 24247408 RING, LOW & REV CLU BKG PLT RET (3.23MM +/- 0.05) (MUST BE USED T/W 24247402) (ACDelco #24247408) 24247402 PLATE, LOW & REV CLU BKG (MUST BE USED T/W 24231937/38/38, AND 24247407/08) (ACDelco #24247402) 24236664 PLATE, LOW & REV CLU (PKG OF 6) (FIBER) 24232654 PLATE, LOW & REV CLU (PKG OF 6) (STEEL) (ACDelco #24232654) 24237971 PLATE, LOW & REV CLU (WAVED) (ACDelco #24237971) 24225517 RING, LOW & REV CLU SPR RET teamcadillac.ru 24238921 SPRAG, LOW CLU (INCLS 468) 24225562 ПРУЖИНА, LOW & REV CLU 24225525 PISTON, LOW & REV CLU (ACDelco #24225525) 24238922 SEAL KIT, A/TRNS SERV (INCLS 468) (СЦЕПЛЕНИЕES) (ACDelco #24238922) (GM04-562) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) СЦЕПЛЕНИЕ HUB БЛОК ↓ teamcadillac.ru 24233660 HUB, 4-5-6 CLU (W/ ВЫХОДНОЙ CARR SHF & DPNR) (INCLS 476-478) 24230475 DAMPENER, 4-5-6 CLU (ЧАСТЬ OF 475) 24233661 PLATE, 4-5-6 CLU DPNR APPLY (ЧАСТЬ OF 475) 24230370 RING, 4-5-6 CLU DPNR RET (ЧАСТЬ OF 475) (GM04-563) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ВЫХОДНОЙ КРОНШТЕЙН БЛОК ↓ 24225777 BEARING, CTR SUPT RLR (ЧАСТЬ OF 490) teamcadillac.ru 24225483 BEARING, ВЫХОДНОЙ CARR OTR SUN GR FRT THR (ЧАСТЬ OF 490) 24225290 GEAR, ВЫХОДНОЙ CARR FRT SUN (ЧАСТЬ OF 490) 24225484 BEARING, ВЫХОДНОЙ CARR OTR SUN GR RR THR (ЧАСТЬ OF 490) 24235807 GEAR, ВЫХОДНОЙ CARR RR SUN (ЧАСТЬ OF 490) 24225603 КРОНШТЕЙН, ВЫХОДНОЙ (INCLS 485-489, 491) (GM04-565) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ЗАМОК ПАРКОВКИ ↓ 24242086 ACTUATOR, PARK PAWL (ACDelco #24242086) 24227077 PIN, MAN SHFT DTNT LVR HUB (ЧАСТЬ OF 505) 24234562 LEVER, MAN SHFT DTNT (INCLS 504) (ACDelco #24234562) 24225792 PIN, MAN SHFT SHF (ACDelco #24225792) 24235861 SEAL, MAN SHFT SHF (*KIT1) (ACDelco #24235861) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24225445 SHAFT, MAN SHFT (ACDelco #24225445) 24228969 SHAFT, MAN SHFT (ACDelco #24228969) 24224348 GUIDE, PARK PAWL ACTR (INCLS 510) 24224350 SEAL, PARK PAWL ACTR GDE (O RING) (ЧАСТЬ OF 509) (*KIT1) (ACDelco #24224350) 24226102 PIN, PARK PAWL ACTR GDE 24243891 SEAL KIT, A/TRNS SERV (INCLS 507, 510) (UNITS BUILT 8-17-08 & PRIOR) (2ND DES SEE 24248567) (FULL TRANS) (ACDelco #24243891) (GM04-568) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ВЫХОДНОЙ ВАЛ БЛОК ↓ teamcadillac.ru 24241092 RING, ВЫХОДНОЙ CARR INTL GR RET (ACDelco #24241092) 24225477 GEAR, ВЫХОДНОЙ CARR INTL (FRT) 24228887 SPACER, ВЫХОДНОЙ CARR INTL GR (3.342) 24230333 GEAR, ВЫХОДНОЙ CARR INTL (RR) 24239398 SHAFT, ВЫХОДНОЙ (INCLS 495, 497, 498) (WHEN SERVICING SHAFT MUST ALSO REPLACE BEARING P/N 24237771) 24239401 SHAFT, ВЫХОДНОЙ (INCLS 495, 497, 498) (WHEN SERVICING SHAFT MUST ALSO REPLACE BEARING P/N 24237771) (GM04-569) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) БЛОК СЦЕПЛЕНИЯ & ДЕТАЛИ КОМПЛЕКТА ↓ 24225602 КРОНШТЕЙН, INPUT (ACDelco #24225602) 24225289 GEAR, INPUT SUN (ACDelco #24225289) 24224405 BEARING, INPUT SUN GR THR (ACDelco #24224405) 24232409 WASHER, INPUT SUN GR THR 24238905 BEARING, TURB SHFT THR [ПОДШИПНИК] 24233732 BEARING, 4-5-6 CLU HUB THR (ACDelco #24233732) teamcadillac.ru 24225597 HUB, 1-2-3-4 CLU (W/ВЫХОДНОЙ CARR INR SUN GR SHF) 24224163 BEARING, 1-2-3-4 CLU HUB THR (ACDelco #24224163) 24225596 HUB, 2-6 & 3-5/REV CLU (W/ ВЫХОДНОЙ CARR OTR SUN GR SHF) (INCLS 60, 62) 24224164 BEARING, 2-6 & 3-5/REV CLU HUB THR (ACDelco #24224164) 24225512 RING, CTR SUPT RET 24225447 SUPPORT, CTR 24225486 BEARING, ВЫХОДНОЙ CARR THR 24224668 BEARING, ВЫХОДНОЙ SHF THR (ACDelco #24224668) (GM04-573) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042861 GASKET, A/TRNS CASE EXTN (*KIT1) 24237771 BEARING, ВЫХОДНОЙ SHF (ЧАСТЬ OF 27) 96042860 EXTENSION, A/TRNS CASE (INCLS 26, 28, 29) 24237771 BEARING, ВЫХОДНОЙ SHF (ЧАСТЬ OF 27) 96041851 SEAL, PROP SHF TRANS FLG FLUID (ЧАСТЬ OF 27) (*KIT1) [ПРОКЛАДКА ТРАНСФОРМАТОРНОГО ВАЛА] 96042984 FLANGE, ВЫХОДНОЙ SHF 96041805 NUT KIT, ВЫХОДНОЙ SHFT (INCLS 30, 32, 33) (M6X1.0X16) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) (*KIT1) teamcadillac.ru 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) (*KIT1) 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96042963 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPACER PLATE & GASKET) 96042986 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96043253 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) 96042712 DETENT, MAN SHFT 96042847 HARNESS, A/TRNS WRG 96041849 SEAL, A/TRNS WRG CONN (O RING) (*KIT1) 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN (*KIT1) [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (*KIT1) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (*KIT1) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) 96042945 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/GSKT, SEAL, RET) (INCLS 25, 29, 36, 38, 46, 56, 60, 63, 64) (GM04-574) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042887 GASKET, A/TRNS CASE EXTN [ПРОКЛАДКА КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042888 EXTENSION, A/TRNS CASE (INCLS 28, 69) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96042963 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPACER PLATE & GASKET) 96042986 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) 96042712 DETENT, MAN SHFT 96042847 HARNESS, A/TRNS WRG 96041849 SEAL, A/TRNS WRG CONN (O RING) teamcadillac.ru 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) 96042543 WASHER, INPUT & REACTION CARR THR 96042587 SEAL, PROP SHF TRANS FLG FLUID [ПРОКЛАДКА КРЫШКИ РАЗДАТОЧНОЙ КОРОБКИ] 08677884 BEARING, ВЫХОДНОЙ SHF THR (ЧАСТЬ OF 27) (4.180) (ACDelco #8677884) (GM04-575) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ 96042554 CONVERTER, TORQ (REMAN) teamcadillac.ru 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042812 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) 96042806 СЦЕПЛЕНИЕ, DIR & REV (СМ. ГРУППУ 04.000 "DIRECT AND REVERSE СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042807 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (СМ. ГРУППУ 04.000 "FORWARD AND COAST СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042698 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) (СМ. ГРУППУ 04.000 "INPUT SUN GEAR SHAFT AND FORWARD SPRAG СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (СМ. ГРУППУ 04.000 "DIRECT СЦЕПЛЕНИЕ DRUM AND SHAFT" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042701 WASHER, INPUT & REACTION CARR INR SHF THR 96042808 ШЛАНГИ, O/D CLU (СМ. ГРУППУ 04.000 "OVERDRIVE AND INTERMEDIATE СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (СМ. ГРУППУ 04.000 "LOW СЦЕПЛЕНИЕ SPRAG" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042705 BEARING, CTR SUPT RLR (4.180) 96042809 SUPPORT, CTR (СМ. ГРУППУ 04.000 "CENTER SUPPORT" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042707 КРОНШТЕЙН, INPUT & REACTION (СМ. ГРУППУ 04.000 "PLANETARY КРОНШТЕЙН" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (4.176) 96042708 BEARING, INPUT & REACTION CARR THR 96042709 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (СМ. ГРУППУ 04.000 "ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96041847 WASHER, INPUT & REACTION CARR THR (4.265) (GM04-576) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ 96042554 CONVERTER, TORQ (REMAN) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042812 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) teamcadillac.ru 96042814 СЦЕПЛЕНИЕ, DIR & REV 96042815 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) 96042698 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) (INCLS 9) 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) 96042701 WASHER, INPUT & REACTION CARR INR SHF THR 96042808 ШЛАНГИ, O/D CLU 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) 08677884 BEARING, LOW CLU RLR THR (*KIT1) (ACDelco #8677884) 96042705 BEARING, LOW CLU RLR THR (*KIT1) 96042816 SUPPORT, CTR 96042817 КРОНШТЕЙН, INPUT & REACTION 96042818 BEARING, INPUT & REACTION CARR THR 96042813 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) 96042543 WASHER, INPUT & REACTION CARR THR 96042818 BEARING, INPUT & REACTION CARR THR (GM04-577) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ teamcadillac.ru 08680684 ПРУЖИНА, LINE BOOST VLV (*KIT1) (4.262) (ACDelco #8680684) 08642581 SEAL, A/TRNS ГИДРОНАСОС CVR SCRN (*KIT1) (ACDelco #8642581) 96015215 БОЛТ, T/CV FLUID SEAL (*KIT1) 96041855 SEAL, T/CV FLUID [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 08634106 ПРУЖИНА, PRESS RLF BALL VLV (*KIT1) (ACDelco #8634106) 00147500 VALVE, PRESS RLF BALL (*KIT1) 96042812 ШЛАНГИ KIT, T/CV (INCLS 200-215, 217-220, 223, 226-228, 231-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-577) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ 08680684 ПРУЖИНА, LINE BOOST VLV (*KIT1) (4.262) (ACDelco #8680684) 96015215 БОЛТ, T/CV FLUID SEAL (*KIT1) 96041855 SEAL, T/CV FLUID [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] teamcadillac.ru 08634106 ПРУЖИНА, PRESS RLF BALL VLV (*KIT1) (ACDelco #8634106) 00147500 VALVE, PRESS RLF BALL (*KIT1) 96042812 ШЛАНГИ KIT, T/CV (INCLS 200-215, 217-220, 223, 226-228, 231-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-578) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 24209145 ФИЛЬТР, PRESS CONT SOL VLV FLUID (*KIT1, KIT2) (ACDelco #24209145) [ФИЛЬТР] 24209145 ФИЛЬТР, PRESS CONT SOL VLV FLUID (*KIT1, KIT2) (ACDelco #24209145) [ФИЛЬТР] teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 300-309, 312-334) (INCLS SPACER PLATE & GASKET) 96042986 VALVE, CONT (W/BODY & VLV) (INCLS 300-309, 312-334) 96043253 VALVE, CONT (W/BODY & VLV) (INCLS 300-309, 312-334) 96042986 GASKET KIT, A/TRNS (INCLS 303, 305, 306, 308, 309, 312, 314, 316, 330, 332) (4.265) (GM04-578) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 96020027 БОЛТ, C/VLV CHAN PLT (*KIT1) teamcadillac.ru 96025325 БОЛТ, INTER CLU ACCUM (*KIT1) (4.265) 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 300-334) (INCLS SPACER PLATE & GASKET) 96042986 VALVE, CONT (W/BODY & VLV) (INCLS 300-334) (GM04-579) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 08680781 RETAINER, PRESS CONT SOL VLV (*KIT1) (ACDelco #8680781) 96042599 VALVE, TCC PWM SOL 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 340-351, 353-356) (INCLS SPACER PLATE & GASKET) 96042986 VALVE, CONT (W/BODY & VLV) (INCLS 340-351, 353-356) 96043253 VALVE, CONT (W/BODY & VLV) (INCLS 340-351, 353-356) (GM04-579) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 08680781 RETAINER, PRESS CONT SOL VLV (*KIT1) (ACDelco #8680781) 96042599 VALVE, TCC PWM SOL 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 340-348, 351, 353-354) (INCLS SPACER PLATE & GASKET) 96042986 VALVE, CONT (W/BODY & VLV) (INCLS 340-348, 351, 353-354) (GM04-580) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 08680781 RETAINER, 1-2 SHFT SOL VLV (*KIT1) (ACDelco #8680781) 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 343, 349, 350, 365-367, 370-375, 377-388) (INCLS SPACER PLATE & GASKET) 96042986 VALVE, CONT (W/BODY & VLV) (INCLS 343, 349, 350, 365-367, 370-375, 377-388) 96043253 VALVE, CONT (W/BODY & VLV) (INCLS 343, 349, 350, 365-367, 370-375, 377-388) (GM04-580) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 08680781 RETAINER, 1-2 SHFT SOL VLV (*KIT1) (ACDelco #8680781) teamcadillac.ru 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 343, 351, 365-367, 370-375, 377-388) (INCLS SPACER PLATE & GASKET) 96042986 VALVE, CONT (W/BODY & VLV) (INCLS 343, 351, 365-367, 370-375, 377-388) 96042889 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/PLT, GSKT, SEAL) (INCLS 343, 351, 365-367, 370-375, 377-388) (GM04-581) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru 96042806 СЦЕПЛЕНИЕ, DIR & REV (INCLS 400-420) (GM04-581) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru 96042814 СЦЕПЛЕНИЕ, DIR & REV (INCLS 400-420) (GM04-582) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96041856 SEAL, INPUT SHF (O RING) (*KIT1) [ПРОКЛАДКА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] teamcadillac.ru 96042807 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-451) (GM04-582) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042815 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-451) (GM04-583) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042707 КРОНШТЕЙН, INPUT & REACTION (INCLS 455-462) (4.176) (GM04-583) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042817 КРОНШТЕЙН, INPUT & REACTION (INCLS 455-462) (GM04-584) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ teamcadillac.ru 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-584) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ teamcadillac.ru 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-585) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 470-477) (GM04-585) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 470-477) (GM04-586) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 480-497) (GM04-586) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 480-497) (GM04-587) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК ↓ teamcadillac.ru 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (INCLS 500-505) (GM04-587) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК ↓ teamcadillac.ru 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (INCLS 500-505) (GM04-588) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) КРЕПЛЕНИЕ ↓ teamcadillac.ru 96042809 SUPPORT, CTR (INCLS 510-535) (GM04-588) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) КРЕПЛЕНИЕ ↓ teamcadillac.ru 96042816 SUPPORT, CTR (INCLS 510-535) (GM04-589) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) PLANETARY КРОНШТЕЙН БЛОК ↓ teamcadillac.ru 96042707 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-554) (4.176) (GM04-589) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) PLANETARY КРОНШТЕЙН БЛОК ↓ teamcadillac.ru 96042817 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-554) (GM04-590) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК ↓ teamcadillac.ru 96042709 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560-564) (GM04-591) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК ↓ teamcadillac.ru 96042813 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560-561, 563-564) (GM04-593) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) PARKING PAWL БЛОК ↓ 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 96042540 SWITCH, A/TRNS MAN SHFT SHF POSN [ВЫКЛЮЧАТЕЛЬ ПРИВОДА] 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 08644709 SEAL, MAN SHFT SHF (W/O PTFE LUBRICANT APPLIED TO SEAL) (ACDelco #8644709) 96041857 SHAFT, MAN SHFT teamcadillac.ru 96042711 PAWL KIT, PARK 96041852 PLUG, MAN SHFT SHF HOLE (4.279) 96041842 SPACER, MAN SHFT DTNT LVR (GM04-594) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) PARKING PAWL БЛОК ↓ 96042819 LEVER, MAN SHFT DTNT 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 96042540 SWITCH, A/TRNS MAN SHFT SHF POSN [ВЫКЛЮЧАТЕЛЬ ПРИВОДА] 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 08644709 SEAL, MAN SHFT SHF (W/O PTFE LUBRICANT APPLIED TO SEAL) (ACDelco #8644709) 96042544 SHAFT KIT, MAN SHFT teamcadillac.ru 96042820 PAWL KIT, PARK (GM04-598) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (6L50 MYB, ЗАДНИЙ КОЛЕСО DRIVE MX0) ↓ 17804000 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) teamcadillac.ru 17804001 ТРАНСМИССИЯ, AUTO (GM04-599) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (6L50 MYB, ALL КОЛЕСО DRIVE MX7) ↓ 17804000 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) teamcadillac.ru 17804001 ТРАНСМИССИЯ, AUTO (GM04-668) - 2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 24240018 CONVERTER, TORQ [ГИДРОТРАНСФОРМАТОР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 11515762 БОЛТ-HFLGE, M8X1.25X50, 18 OD, 22 THD, 10.9, PZO (T/CV HSG) 24225543 SEAL, A/TRNS ГИДРОНАСОС (ACDelco #24225543) [ПРОКЛАДКА КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24242045 CASE, A/TRNS (INCLS 6, 12, 13) (ACDelco #24242045) 24242046 CASE, A/TRNS (INCLS 6, 12, 13) (ACDelco #24242046) 24226020 PLUG, TRANS FLUID FIL TUBE 24239878 SLEEVE, A/TRNS ELEC CONN PASG [МУФТА] 24225788 БОЛТ, A/TRNS CASE EXTN (M10X1.5X34) 24225557 SEAL, CTR SUPT FLUID PASG (*KIT2) teamcadillac.ru 24224822 БОЛТ, C/VLV LWR BODY (M5X0.8X55) 24231074 БОЛТ, MAN SHFT DTNT (M10X1X14.5) 24222646 DETENT, MAN SHFT (W/8MM DIA. ROLLER) (ACDelco #24222646) 24236933 FILTER KIT, A/TRNS FLUID (INCLS 25) (ACDelco #24236933) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24225800 GASKET, A/TRNS FLUID PAN (ACDelco #24225800) [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 29535617 MAGNET, A/TRNS FLUID PAN (4.105) (ACDelco #29535617) [МАГНИТ] 24242410 PAN, A/TRNS FLUID (INCLS 31) (ACDelco #24242410) 11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (A/TRNS FLUID PAN) [БОЛТ М6] 24234212 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 29) (ACDelco #24234212) [ПРОБКА] 24205900 PLUG, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] 24225783 SEAL, A/TRNS CASE EXTN (ACDelco #24225783) [УПЛОТНИТЕЛЬ КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24237879 EXTENSION, A/TRNS CASE (INCLS 36, 37) (ACDelco #24237879) 24228876 SEAL, ВЫХОДНОЙ SHF (ЧАСТЬ OF 34) (5.556) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24214158 BEARING, ВЫХОДНОЙ SHF (DRAWN CUP) (ЧАСТЬ OF 34) (4.131) (ACDelco #24214158) 24230287 FLANGE, PROP SHF TRANS 24231524 ГАЙКА, FRT PROP SHF FLG (M22X1.5) (FLANGE HEX) 24229687 EXTENSION, A/TRNS CASE (MCHG) 24237771 BEARING, ВЫХОДНОЙ SHF 24242995 BEARING, ВЫХОДНОЙ SHF [ПОДШИПНИК КПП] 24236928 SEAL KIT, A/TRNS ELEC CONN PASG SLEV (INCLS 9, 10) 24238913 SEAL KIT, A/TRNS SERV (INCLS 9, 10, 18-20) (CONTROL VLV SOL ASM) (ACDelco #24238913) [КОМПЛЕКТ ПРОКЛАДОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (5ШТ)] 04 - КОРПУС КП ↓ (6D04-023) - 2004-2009 E СТОЯНОЧНЫЙ ТОРМОЗ ASM ↓ 88951984 PLATE, RR PARK BRK ANC BKG (4.591) 88951985 PLATE, RR PARK BRK ANC BKG (4.591) teamcadillac.ru 88951982 ACTUATOR KIT, RR PARK BRK (INCLS 2) (ACDelco #179-2053) [АКТУАТОР] 88951983 ACTUATOR KIT, RR PARK BRK (INCLS 2) (ACDelco #179-2054) [АКТУАТОР] 89047676 SHOE KIT, RR PARK BRK (INCLS 5) (ACDelco #171-0915) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (2 ШТ)] (6D04-031) - 2004-2009 E ТОРМОЗНОЙ СУППОРТ-ЗАДНИЙ ↓ 89047677 CALIPER KIT, RR BRK (INCLS 2, 3, 7-9) (ACDelco #172-2343) 89047678 CALIPER KIT, RR BRK (INCLS 2, 3, 7-9) (ACDelco #172-2344) [ТОРМОЗНОЙ СУППОРТ] teamcadillac.ru 88951992 CAP, RR BRK BLEDR VLV (ЧАСТЬ OF 1) 88951991 VALVE, RR BRK CLPR BLEDR (ЧАСТЬ OF 1) 89047757 PAD KIT, RR DISC BRK (INCLS 4, 12) (ACDelco #171-859) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4 ШТ)] 89047758 PAD KIT, RR DISC BRK (INCLS 4, 12) (4.667) (ACDelco #171-0906) [ТОРМОЗНЫЕ КОЛОДКИ] 88957163 BRACKET, RR BRK CLPR [СКОБА ТОРМОЗНОГО СУППОРТА] 89047759 PIN KIT, RR BRK CLPR GDE (INCLS 4-6) (INCLS 2 PINS, 2 SEALS & 2 (2.75") БОЛТS) (ACDelco #179-2044) [НАПРАВЛЯЮЩАЯ ТОРМОЗНОГО СУППОРТА (2 ШТ)] 88957162 REPAIR KIT, RR BRK CLPR HYD (INCLS 4, 6, 8, 9) (6D04-033) - 2004-2009 E ТОРМОЗНОЙ УСИЛИТЕЛЬ ↓ 88967237 BOOSTER, P/B (W/O VLV) (ACDelco #178-0695) teamcadillac.ru 05461808 GROMMET, P/B BOOS VAC CHK VLV (*KIT1) 03817880 RETAINER, BRK PED PUSH ROD (0.80 IN) (PUSH IN) 18022219 VALVE KIT, P/B BOOS VAC CHK (INCLS 2, 3) (BLACK) (INCLS VLV & GROM) (ACDelco #179-1266) (6D04-067) - 2007-2009 E КОРПУС КП КРЕПЛЕНИЕ (MYB,MX7) ↓ 24231525 GASKET, TRFER CASE 19132968 CASE, TRFER (W/GEARS) (LESS DAMPENER) 24243367 CASE, TRFER (W/GEARS) 11589341 БОЛТ - HFH, M10X1.5X69.9, 28.35 THD, 22.3 OD, 10.9, GMW3359, M-PT. (TRFER CASE) [БОЛТ] (6E00-014) - 2004-2009 E ТРАНСМИССИЯ TO КРЕПЛЕНИЕ ДВИГАТЕЛЯ (LY7/3.6-7) ↓ teamcadillac.ru 12572042 PLATE, A/TRNS FLEX 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (TRANS CVR) [БОЛТ] 24222918 COVER, TRANS CONV 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] (6E03-019) - 2007-2009 E T.C.M. МОДУЛЬ (LY7/3.6-7) ↓ 12623327 МОДУЛЬ, ENG CONT (W/O CALN) 25784072 BRACKET, ECM (INCLS 5, 6) 24239785 МОДУЛЬ, TRANS CONT (W/O CALN) teamcadillac.ru 11609462 SCREW, M4.2X1.41X13, GMW4205 (ЧАСТЬ OF 3) 11561758 БОЛТ, MULTIUSE RLY & FUSE BRKT (7.833) [БОЛТ] 15879156 BRACKET, ACSRY WRG J/BLK 11609599 STUD, SPL, M6X1X25, 13 THD, 11 OD HD W/26 WIDE CLIP, 9.8, 6280M, P-PT (MULTIUSE FUSE BRKT) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (MULTIUSE RLY & FUSE BRKT) [ГАЙКА М6] (6E04-007) - 2007-2009 EB ТОРМОЗНЫЕ ШЛАНГИ И ТРУБКИ ↓ 15933099 HOSE, FRT BRK (INCLS 15, 16) (ACDelco #176-1495) 11569742 RETAINER, FRT BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (BRK & FUEL FEED & FUEL RTN & EVAP EMIS) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА] 25761218 BRACKET, FUEL PIPE 25761217 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (3.162) 12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (FRT BRK) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА] 10388788 PIPE, BRK PRESS MOD VLV FRT (INCLS 29) 10388794 PIPE, BRK PRESS MOD VLV RR (INCLS 29) 03541444 SPACER, FRT BRK PIPE 11516521 БОЛТ, HFH M6X1X20, 9.8, 7114M, DOG PT, 14.2 OD (FRT BRK HOSE) 15933098 HOSE, FRT BRK (INCLS 15, 16) (ACDelco #176-1487) 25743891 RETAINER, RR BRK FRT PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT) 11569737 FITTING, FRT BRK PIPE (ЧАСТЬ OF 1, 12) (7/16-24X0.36, 0.30THD) (0.56 LONG, 3/16TUBE) 25743891 RETAINER, FRT BRK PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT) 15904901 CLIP, FRT BRK PIPE (STAR SHAPED 3 TUBE W/TREE) [КРОНШТЕЙН] 25737279 CLIP, FRT BRK PIPE (THREE WAY RETAINER SINGLE CENTRAL FIR-TREE ATTACHMENT) 25749839 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (HOLDS 3 ТРУБКИ, FLAT SHAPE, SNAP-IN RETAINER) teamcadillac.ru 25867884 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE 15880948 RETAINER, BRK PIPE (FOR 5 LINES W/45 DEGREE PUSHPIN) 25607191 RETAINER, BRK PIPE (21.5X10.0MM) (HOLDS (2) 4.68-4.82 TUBES) 11569742 RETAINER, RR BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 15724650 ГАЙКА, INVERTED FLARED TUBE, 9/16"-18, 1/4" TUBE, ZD (BRK PIPE) (4.686) [ГАЙКА] 25693890 RETAINER, RR BRK PIPE (HOLDS (1) 4.76 LINE) (W/TREE) [ЗАМОК, ФИКСАТОР] 11588803 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 7, 8) (1/2-20X.40, .32 THD) (INVERTED FLARED TUBE) (.62 LONG, 1/4 TUBE) [ГАЙКА М20] 15724650 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 7, 8) (9/16-18 X .40) (INVERTED FLARED TUBE) [ГАЙКА] 15933091 HOSE, RR BRK (INCLS 22, 23) (ACDelco #15933091) 15933092 HOSE, RR BRK (INCLS 22, 23) (ACDelco #15933092) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ] 88964150 PROTECTOR, RR BRK PIPE (FOR 3/16" PIPE) (HT SHRINK) (6E04-008) - 2007-2009 EB ТОРМОЗНАЯ ПЕДАЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (EXC (JF4)) ↓ 25732428 BARRIER, BRK PED BRKT SND 25697461 RETAINER, BRK PED PUSH ROD BOOT 25732452 BOOT, BRK PED PUSH ROD 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] 15932827 HOSE, P/B BOOS VAC (ACDelco #176-1496) 25818868 PEDAL, BRK (W/BRKT) (INCLS 10, 11, 14, 16-18) teamcadillac.ru 25771615 COVER, BRK PED (ЧАСТЬ OF 9) 89047699 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 9) [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 9) 10434956 BUSHING, BRK PED PUSH ROD 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 9) 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 9) (0.80 IN) (PUSH IN) (6E04-012) - 2007-2009 E КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS(MYB,MX7) ↓ 88996677 CASE, TRFER (FRT HALF) (INCLS 12-14) 19133265 CASE, TRFER (RR HALF) (INCLS 5, 7) 88996679 SNUBBER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN teamcadillac.ru 88996680 БОЛТ, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN SNBR (M5X0.8X16) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 2) 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL FILL) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996657 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 2) [УПЛОТНИТЕЛЬ] 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL DRN) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996680 БОЛТ, TRFER CASE VENT BFL (M5X0.8X16) (4.535) 88996658 BAFFLE, TRFER CASE VENT 89048123 БОЛТ, TRFER CASE HALF (M8X1.25X30) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 1) 88996656 SEAL, TRFER CASE INPUT SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 88996657 SEAL, TRFER CASE FRT ВЫХОДНОЙ SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] (6E04-013) - 2008-2009 E КОРПУС КП ЧАСТЬ 2 INTERNAL COMPONENTS(MX5) ↓ 88984517 WASHER, TRFER CASE PLNT CARR SUN GR THR (25.8X52.0X2.2) 88984524 GEAR, TRFER CASE PLNT CARR SUN (INPUT) (STAMPED PM/POWDERED METAL) 88984493 RING, TRFER CASE RR ВЫХОДНОЙ SHF RR BRG RET (41MM I.D.) (ACDelco #88984493) 88996564 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT 88996665 BEARING, TRFER CASE MAIN SHF FRT (ВЫХОДНОЙ ВАЛ FRT) 19168733 BUSHING, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 106) [ВТУЛКА РАЗДАТОЧНОЙ КОРОБКИ] 19178237 SHAFT, TRFER CASE RR ВЫХОДНОЙ (INCLS 105) 19178238 SHAFT, TRFER CASE RR ВЫХОДНОЙ (INCLS 105) 19133264 SPROCKET, TRFER CASE FRT ВЫХОДНОЙ SHF DRV (INCLS 108) [ШЕСТЕРНЯ РАЗДАТОЧНОЙ КОРОБКИ] 19168732 BUSHING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT (ЧАСТЬ OF 107) (ACDelco #19168732) teamcadillac.ru 19132837 CHAIN, TRFER CASE TWO/FOUR WHL DRV 89059578 CHAIN, TRFER CASE TWO/FOUR WHL DRV [ЦЕПЬ РАЗДАТОЧНОЙ КОРОБКИ] 88984523 GEAR, TRFER CASE PLNT CARR SUN (ВЫХОДНОЙ) 89059279 КРОНШТЕЙН, FRT/RR DRV DIFF 89059284 SHAFT, TRFER CASE FRT ВЫХОДНОЙ (INCLS 900) 88996664 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF RR 88996671 RING, TRFER CASE FRT ВЫХОДНОЙ SHF BRG RET 88996666 SPROCKET, TRFER CASE TWO/FOUR WHL DRV DRVN [ЗВЕЗДОЧКА] 88996633 BEARING, TRFER CASE RR ВЫХОДНОЙ SHF RR (ACDelco #88996633) [ПОДШИПНИК РАЗДАТОЧНОЙ КОРОБКИ] 15580230 BEARING, TRFER CASE INPUT SHF (BORG-WARNER) (4.510) 19132966 SHAFT, TRFER CASE INPUT 88996681 DEFLECTOR, TRFER CASE FRT ВЫХОДНОЙ SHF SEAL DIRT (ЧАСТЬ OF 112) (6E04-016) - 2004-2009 E КЛАПАН РЕГУЛИРОВКИ ДАВЛЕНИЯ В ТОРМОЗНОЙ СИСТЕМЕ ↓ 19153350 МОДУЛЬ KIT, ELEK BRK & TRACT CONT [МОДУЛЬ] 89060233 VALVE KIT, BRK PRESS MOD (INCLS 3, 4) (ACDelco #89060233) [ГИДРАВЛИЧЕСКИЙ БЛОК АБС] 25743362 SENSOR, BRK PRESS MOD VLV PRESS (ЧАСТЬ OF 2) (ACDelco #25743362) [ДАТЧИК] 25741456 INSULATOR, BRK PRESS MOD VLV (ЧАСТЬ OF 2) 11588304 STUD, FLANGE DOUBLE END, M8X14 UNTHD, M8X1.25X13, 17 OD, 5.8, GM4345M (BRK PRESS MOD VLV BRKT) 11514596 ГАЙКА, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (BRK PRESS MOD VLV BRKT) (8.915) (ACDelco #11514596) 11508351 SCREW, PAN HD, C/R, 5X0.8X13, 9.3 OD, FULL THD, THD RLLR, 6171M, PC (BRK PRESS MOD VLV) (8.977) (6E04-017) - 2007-2009 E ШЛАНГ ВЕНТИЛЯЦИИ ТРАНСМИССИИ (LY7/3.6-7, M82,MX5) ↓ 25764835 VENT, A/TRNS (INCLS 2, 3) (ACDelco #25764835) 15955072 CLIP, TRANS VENT HOSE (ЧАСТЬ OF 1) (.650MM DIA) (2.343) (6E04-018) - 2004-2009 E КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS(MX5) ↓ 88996677 CASE, TRFER (FRT HALF) (INCLS 12-14) 19133265 CASE, TRFER (RR HALF) (INCLS 5, 7) 88996679 SNUBBER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN 88996680 БОЛТ, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN SNBR (M5X0.8X16) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 2) 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL FILL) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996657 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 2) [УПЛОТНИТЕЛЬ] 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL DRN) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996680 БОЛТ, TRFER CASE VENT BFL (M5X0.8X16) (4.535) 88996658 BAFFLE, TRFER CASE VENT 89048123 БОЛТ, TRFER CASE HALF (M8X1.25X30) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 1) 88996656 SEAL, TRFER CASE INPUT SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 88996657 SEAL, TRFER CASE FRT ВЫХОДНОЙ SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 19180066 VENT, TRFER CASE 89048123 БОЛТ, TRFER CASE VIB DPNR (M8X1.25X30) teamcadillac.ru 19133173 DAMPENER, TRFER CASE VIB (YOKE STYLE; БОЛТS TO RR OF T-CASE) (6E04-020) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ 24218963 RING, T/CV FLUID SEAL RET [КОЛЬЦО] 24237531 SEAL, T/CV FLUID (ЧАСТЬ OF 217, 219) (ACDelco #24237531) [УПЛОТНЕНИЕ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 00444613 PLUG, HEX HD, 1/8-27 NPTF, STL (LINE PRESS TEST HOLE) (ACDelco #444613) 24239385 ШЛАНГИ, T/CV (MCHG) (INCLS 206) 24225422 PIPE, A/TRNS VENT 15251488 SEAL, TRANS FLUID CLR PIPE FTG (ЧАСТЬ OF 217, 219) (SEALS TWO ТРУБКИ) (*KIT1) [УПЛОТНЕНИЕ] 24237658 SEAL, TRANS FLUID CLR PIPE FTG (ЧАСТЬ OF 217, 219) (SEALS ONE PIPE) (*KIT1) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ] 24222668 SLIDE, A/TRNS ГИДРОНАСОС (17.948MM-17.961MM) (ACDelco #24222668) 24224131 SLIDE, A/TRNS ГИДРОНАСОС (17.961MM-17.974MM) (ACDelco #24224131) 24224132 SLIDE, A/TRNS ГИДРОНАСОС (17.974MM-17.987MM) (ACDelco #24224132) 24238915 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 207-211, 213-216, 230) (17.948MM-17.961MM) (ACDelco #24238915) 24238916 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 207-211, 213-216, 230) (17.961MM-17.974MM) (ACDelco #24238916) 24238917 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 207-211, 213-216, 230) (17.974MM-17.987MM) (ACDelco #24238917) 24238919 COVER KIT, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 218, 220-230, 232-237) (ACDelco #24238919) teamcadillac.ru 00147500 VALVE, PRESS RLF BALL (ЧАСТЬ OF 219) 24224692 WASHER, 1-2-3-4 & 3-5 REV CLU HSG THR (ЧАСТЬ OF 219) 24239151 RING KIT, 1-2-3-4 & 3-5 REV CLU FLUID SEAL (ACDelco #24239151) 24248559 RING KIT, 1-2-3-4 & 3-5 REV CLU FLUID SEAL (1-SET 2ND DES SEALS (INCL QUAD LOBE)) (ACDelco #24248559) 24227061 БОЛТ, A/TRNS ГИДРОНАСОС CVR (ACDelco #24227061) [БОЛТ] 90351709 PIN, A/TRNS ГИДРОНАСОС LOC (ЧАСТЬ OF 219) ("8MM HOLLOW SPLIT PIN") (1.639) [ШПИЛЬКА] 24243891 SEAL KIT, A/TRNS SERV (INCLS 205, 210, 214, 230) (UNITS BUILT 8-17-08 & PRIOR) (2ND DES SEE 24248567) (FULL TRANS) (ACDelco #24243891) (6E04-022) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (LY7/3.6-7, V92) ↓ 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] teamcadillac.ru 89022494 BRACKET, TRANS FLUID CLR 19129782 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) [ТРУБКА МАСЛООХЛАДИТЕЛЯ] 19130214 SEAL, TRANS FLUID CLR HOSE CONN (O RING) 19129781 HOSE, TRANS FLUID CLR LWR (W/BLOCK) 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 19130449 COOLER, TRANS FLUID (INCLS 7-10) (ACDelco #19130449) [РАДИАТОР] (6E04-024) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (LH2/4.6A, EXC V92) ↓ 19130449 COOLER, TRANS FLUID (INCLS 7-9) (ACDelco #19130449) [РАДИАТОР] 11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) [БОЛТ, М8Х1.25Х31.5] 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 15251488 SEAL, TRANS FLUID CLR PIPE FTG (ЧАСТЬ OF 5) (SEALS TWO ТРУБКИ) [УПЛОТНЕНИЕ] 15882260 PIPE, TRANS FLUID CLR INL & OTLT (INCLS 4, 6) [ТРУБКА МАСЛОПРОВОДА] teamcadillac.ru 10405874 CLIP, TRANS FLUID CLR PIPE (ЧАСТЬ OF 5) (LESS MNTG TAB) (HOLDS TWO 9.5 DIA TUBES) 11570323 БОЛТ, КОНДИЦИОНЕР CNDSR (M6X1X18, 13 THD) (1.277) 15921020 CLIP, TRANS FLUID AUX CLR PIPE (CYLINDRICAL) (1 PIPE) (6E04-025) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (LH2/4.6A, V92) ↓ 19130449 COOLER, TRANS FLUID (INCLS 7-10) (ACDelco #19130449) [РАДИАТОР] teamcadillac.ru 11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) [БОЛТ, М8Х1.25Х31.5] 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 15882260 PIPE, TRANS FLUID CLR INL & OTLT (INCLS 4, 6) [ТРУБКА МАСЛОПРОВОДА] 10405874 CLIP, TRANS FLUID CLR PIPE (ЧАСТЬ OF 5) (LESS MNTG TAB) (HOLDS TWO 9.5 DIA TUBES) 15921020 CLIP, TRANS FLUID AUX CLR PIPE (CYLINDRICAL) (1 PIPE) (6E04-027) - 2007-2009 EB СТОЯНОЧНЫЙ ТОРМОЗ SYSTEM ↓ 10395687 LEVER, PARK BRK (INCLS 2-4, 17, 18) 22654577 SWITCH, PARK BRK IND (ЧАСТЬ OF 1) (ACDelco #22654577) [ВКЛЮЧАТЕЛЬ] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (PARK BRK INTER CBL GDE) [ГАЙКА М6] 15797212 CABLE, PARK BRK INTER (INCLS 5, 10, 11) (ACDelco #15797212) [ТРОС СТОЯНОЧНОГО ТОРМОЗА В СБОРЕ] 11517484 БОЛТ-HEX, M6X1X20, 9 THD, 17 OD, 9.8, 6280M, MACH, P-PT (PARK BRK INTER CBL GDE) 25764260 CABLE, PARK BRK RR (28.2X28.5X811.7MM) (ACDelco #25764260) [ТРОС СТОЯНОЧНОГО ТОРМОЗА] 25880964 HANDLE, PARK BRK REL teamcadillac.ru 11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (PARK BRK REL HDL HSG) [ВИНТ] 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (КАПОТ PRIM LAT REL CBL HDL BRKT) [ВИНТ М4] 15882985 RETAINER, PARK BRK REL HDL 11570654 ГАЙКА, PARK BRK REL HDL BRKT (4.2 X 1.41) (FITS 8.75 SQ HOLE) (9.665) 89047821 CABLE, PARK BRK REL (ЧАСТЬ OF 1) (ACDelco #89047821) 10369646 БОЛТ, PARK BRK IND SW (ЧАСТЬ OF 1) (6E04-030) - 2007-2009 E УПРАВЛЕНИЕ АКПП/АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX0) ↓ 15946116 PLATE, F/FLR CNSL TRANS SHFT OPG TR PLT MT (INCLS 14) (TORTOISE SHELL) 25828031 PLATE, F/FLR CNSL TRANS SHFT OPG TR PLT MT (INCLS 14) (FIGURED SAPELE) 19180495 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (EBONY ON MIDDLE & SIDES) 19180497 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (COCOA ON MIDDLE & SIDES) 19180501 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (FIG SAPELE WOOD W/EBONY) 19180506 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (FIG SAPELE WOOD W/COCOA) 89027001 COVER, A/TRNS CONT LVR HDL (ЧАСТЬ OF 2) (4.006) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL LVR CBL BRKT) [ГАЙКА М6] teamcadillac.ru 15780845 LINK, A/TRNS RANGE SEL LVR 15780847 LINK, A/TRNS RANGE SEL LVR 11519095 NUT-ACORN HEX, M8X1.0, 15MM THK, 9, 6047M, W/DOME. (A/TRNS RANGE SEL LVR) [ГАЙКА] 25789237 RETAINER, F/FLR CNSL (ЧАСТЬ OF 9) 25807057 BEZEL, F/FLR CNSL CUP HLDR (INCLS 8) (GRAY) 25807058 BEZEL, F/FLR CNSL CUP HLDR (INCLS 8) (EBONY) 25807059 BEZEL, F/FLR CNSL CUP HLDR (INCLS 8) (CASHMERE) 19167874 CONTROL, A/TRNS 19167876 CONTROL, A/TRNS 89027003 BULB, A/TRNS CONT POSN IND (BULB W/BLUE COVER) (4.020) (ACDelco #89027003) 19122183 BEZEL, A/TRNS CONT HSG (PRNDL CHROME COVER) 11570687 БОЛТ, A/TRNS CONT LVR KNOB (ЧАСТЬ OF 2) (6E04-031) - 2007-2009 E УПРАВЛЕНИЕ АКПП/АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX7) ↓ 15946116 PLATE, F/FLR CNSL TRANS SHFT OPG TR PLT MT (INCLS 2) (TORTOISE SHELL) 25828031 PLATE, F/FLR CNSL TRANS SHFT OPG TR PLT MT (INCLS 2) (FIGURED SAPELE) 11570687 БОЛТ, A/TRNS CONT LVR KNOB (ЧАСТЬ OF 14) 89027003 BULB, A/TRNS CONT POSN IND (BULB W/BLUE COVER) (4.020) (ACDelco #89027003) 19167812 CONTROL, A/TRNS [МЕХАНИЗМ ПЕРЕКЛЮЧЕНИЯ ПЕРЕДАЧ] 19167875 CONTROL, A/TRNS [ПОДДОН АКП] 25807057 BEZEL, F/FLR CNSL CUP HLDR (INCLS 7) (GRAY) 25807058 BEZEL, F/FLR CNSL CUP HLDR (INCLS 7) (EBONY) 25807059 BEZEL, F/FLR CNSL CUP HLDR (INCLS 7) (CASHMERE) 25789237 RETAINER, F/FLR CNSL (ЧАСТЬ OF 6) teamcadillac.ru 11514603 ГАЙКА, M10X1.5 15MM SOCKET (A/TRNS RANGE SEL LVR) [ШАЙБА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL ROD ADJ) [ГАЙКА М6] 15780844 LINK, A/TRNS RANGE SEL LVR 15780846 LINK, A/TRNS RANGE SEL LVR 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL LVR CBL BRKT) [ГАЙКА М6] 19122183 BEZEL, A/TRNS CONT HSG (PRNDL CHROME COVER) 89027001 COVER, A/TRNS CONT LVR HDL (ЧАСТЬ OF 14) (4.006) 19180495 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (EBONY ON MIDDLE & SIDES) 19180497 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (COCOA ON MIDDLE & SIDES) 19180501 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (FIG SAPELE WOOD W/EBONY) 19180506 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (FIG SAPELE WOOD W/COCOA) (6E04-035) - 2005-2009 E BRAKE SYSTEM/ANTILOCK ↓ teamcadillac.ru 12413103 HUB, FRT WHL (W/BRG) (СМ. ГРУППУ 06.000 "ПОДВЕСКА-ПЕРЕДНЯЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/WHL SPD SEN) (ACDelco #FW149) [СТУПИЦА КОЛЕСА] 12413105 HUB, FRT WHL (W/BRG) (СМ. ГРУППУ 06.000 "ПОДВЕСКА-ПЕРЕДНЯЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPEED SENSOR) (ACDelco #FW150) [СТУПИЦА КОЛЕСА] 89047639 HUB, RR WHL (W/WHL SPD SEN) (СМ. ГРУППУ 06.000 "ЗАДНЯЯ ПОДВЕСКА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6 STUD HUB) (ACDelco #RW20-19) [СТУПИЦА КОЛЕСА] 10307709 SENSOR, VEH YAW (W/VEH LATL ACCLRM) [ДАТЧИК] 15906579 SENSOR, VEH YAW (W/ VEH LATL & LGTDNL ACCLRM) [ДАТЧИК] 11561645 ГАЙКА, HFH, M6X1X6.45, 13.5 OD, 10 STL, GMW3200 (VEH YAW SEN & LATL ACCLRM) (6E04-036) - 2007-2009 EB ТОРМОЗНАЯ ПЕДАЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (JF4) ↓ 25732428 BARRIER, BRK PED BRKT SND 25697461 RETAINER, BRK PED PUSH ROD BOOT 25732452 BOOT, BRK PED PUSH ROD 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] 15932827 HOSE, P/B BOOS VAC (ACDelco #176-1496) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (ACCEL PED LVR) 10368488 PEDAL, BRK (INCLS 12, 13, 15, 18-22) 25771615 COVER, BRK PED (ЧАСТЬ OF 11) 89047699 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 11) (INCLS 18) [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 89047780 MOTOR KIT, BRK & ACCEL PED ADJR ACTR [ЭЛЕКТРОДВИГАТЕЛЬ ПЕДАЛЬНОГО УЗЛА 19 ВТ] teamcadillac.ru 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 11, 13) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 11) 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 11) 25697461 RETAINER, BRK PED PUSH ROD BOOT (ЧАСТЬ OF 11) 89047779 CABLE, ACCEL CONT 89047778 CABLE, BRK PED ADJR ACTR [ЖГУТ ПРОВОДОВ] 25741052 BRACKET, BRK PED BRKT 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-037) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (LY7/3.6-7, EXC V92) ↓ 19130570 HOSE, TRANS FLUID CLR LWR (W/BLOCK) (INCLS 7) 11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16] 89022494 BRACKET, TRANS FLUID CLR 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 25740416 SEAL, TRANS FLUID CLR PIPE (O RING) (1/2IN) (9.222) (ACDelco #15-31872) [ПРОКЛАДКА КОМПРЕССОРА КОНДИЦИОНЕРА] 19129977 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) teamcadillac.ru 15921020 CLIP, TRANS FLUID AUX CLR PIPE (CYLINDRICAL) (1 PIPE) (6M04-039) - 2009 E ШЛАНГ ВЕНТИЛЯЦИИ ТРАНСМИССИИ (LH2/4.6A, MYB) ↓ teamcadillac.ru 25892279 VENT, TRFER CASE (ЧАСТЬ OF 3) (ACDelco #25892279) [ЗАГЛУШКА ШЛАНГА ВЕНТИЛЯЦИИ КАРТЕРА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 08905794 CLIP (ЧАСТЬ OF 3) 25892019 HOSE, TRANS VENT (INCLS 1, 2, 4) 25526358 CЛАМПА, SPRG BAND, 14.2MM, 9/16 OD HOSE, POR (ЧАСТЬ OF 3) (6M04-041) - 2009 E26 ТОРМОЗНАЯ ПЕДАЛЬ (PWR ADJ PEDALS JF4) ↓ 25741052 BRACKET, BRK PED BRKT 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 25732428 BARRIER, BRK PED BRKT SND 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] teamcadillac.ru 89047778 CABLE, BRK PED ADJR ACTR [ЖГУТ ПРОВОДОВ] 89047780 MOTOR KIT, BRK & ACCEL PED ADJR ACTR [ЭЛЕКТРОДВИГАТЕЛЬ ПЕДАЛЬНОГО УЗЛА 19 ВТ] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (BRK PED POSN SEN) 89047699 SENSOR KIT, BRK PED POSN [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 25697461 RETAINER, BRK PED PUSH ROD BOOT (ЧАСТЬ OF 21) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 21) 10368488 PEDAL, BRK (INCLS 5, 8-10, 13, 15-20, 22) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-042) - 2009 E26 ТОРМОЗНАЯ ПЕДАЛЬ (EXC PWR ADJ PEDALS JF4) ↓ 25741052 BRACKET, BRK PED BRKT 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 25732428 BARRIER, BRK PED BRKT SND 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 18) 89047699 SENSOR KIT, BRK PED POSN [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] teamcadillac.ru 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 15594358 BUSHING, BRK PED PIV (ЧАСТЬ OF 18) (0.831) 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 18) (0.80 IN) (PUSH IN) 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 18) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 18) 25771615 COVER, BRK PED (ЧАСТЬ OF 18) 25818868 PEDAL, BRK (W/BRKT) (INCLS 5-8, 10, 12-17, 19) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-044) - 2004-2009 E26 ТОРМОЗНОЙ УСИЛИТЕЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА ↓ 88967237 BOOSTER, P/B (СМ. ГРУППУ 04.000 "ТОРМОЗНОЙ УСИЛИТЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/O VLV) (ACDelco #178-0695) 25732452 BOOT, BRK PED PUSH ROD 25697461 RETAINER, BRK PED PUSH ROD BOOT 10367561 CYLINDER, BRK MAS (СМ. ГРУППУ 4.000 "ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #174-1012) [ЦИЛИНДР] 11609949 ГАЙКА, BRK M/CYL (M10X1.5, 11.2 THK) (8.917) [ГАЙКА] teamcadillac.ru 25873484 HOSE, P/B BOOS VAC (ACDelco #176-1497) (GM00-588) - 2009 E ТРАНСМИССИЯ TO КРЕПЛЕНИЕ ДВИГАТЕЛЯ (LH2/4.6A) ↓ 12582606 FLYКОЛЕСО, ENG 25773136 BRACKET, ENG WRG HARN (CHANNEL) 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] 24205900 PLUG, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] 12568123 COVER, TRANS CONV 11589116 БОЛТ, FLYWHL (8.900) 12568122 COVER, FLYWHL HSG 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) teamcadillac.ru 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (TRANS CONV CVR) (GM04-064) - 2004-2009 E ТОРМОЗНОЙ СУППОРТ-ПЕРЕДНИЙ ↓ 18047980 CALIPER, FRT BRK (INCLS 2-4, 8-10) (IF DISCONTINUED USE DURASTOP EQUIVALENT) (4.667) (ACDelco #172-1643) [ТОРМОЗНОЙ СУППОРТ] 18047981 CALIPER, FRT BRK (INCLS 2-4, 8-10) (IF DISCONTINUED USE DURASTOP EQUIVALENT) (4.667) (ACDelco #172-1644) [ТОРМОЗНОЙ СУППОРТ] 18043178 COVER, FRT BRK BLEDR SCREW (ЧАСТЬ OF 1) 18047986 VALVE KIT, FRT BRK CLPR BLEDR (ЧАСТЬ OF 1) (ACDelco #18047986) 18046750 БОЛТ, FRT BRK CLPR GDE PIN (ЧАСТЬ OF 1, 11) (*KIT2) [БОЛТ] teamcadillac.ru 18047985 PISTON KIT, FRT BRK CLPR (ЧАСТЬ OF 1) 18047988 PAD KIT, FRT DISC BRK (INCLS 4, 14) (ACDelco #171-665) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4 ШТ)] 19122384 PAD KIT, FRT DISC BRK (INCLS 4, 14) (ACDelco #171-688) 18045221 SEAL, FRT BRK CLPR GDE PIN 18047987 BRACKET, FRT BRK CLPR (W/GUIDE PIN БОЛТS) [КРОНШТЕЙН] 18046698 ПРУЖИНА, FRT DISC BRK PAD RET (ЧАСТЬ OF 11) (ACDelco #179-2235) 18047989 PIN KIT, FRT BRK CLPR GDE (INCLS 5-7) (INCLS 2 (2.5") БОЛТS) 18047984 CALIPER KIT, FRT BRK (INCLS 4, 8, 9) (4.667) (ACDelco #173-0538) (GM04-312) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (5L40-E M82) ↓ teamcadillac.ru 96042897 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 6GRG) (GM04-376) - 2004-2009 E ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР ↓ 18012741 SWITCH, BRK FLUID LVL IND (ЧАСТЬ OF 15) (ACDelco #18012741) 22688449 CAP, BRK M/CYL RSVR (ЧАСТЬ OF 15) (INCLS 3) [КРЫШКА БАЧКА ТОРМОЗНОЙ ЖИДКОСТИ] 18046711 RESERVOIR, BRK M/CYL (ЧАСТЬ OF 15) (INCLS 4, 6-7) (ACDelco #18046711) teamcadillac.ru 18060168 PISTON, BRK M/CYL SECD (ЧАСТЬ OF 15) 10367561 CYLINDER, BRK MAS (INCLS 1-14) (ACDelco #174-1012) [ЦИЛИНДР] 18022002 CYLINDER KIT, BRK MAS (INCLS 8-12) (ACDelco #175-424) (GM04-485) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (5L40-E MX5) ↓ 96042890 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 6GGG) [АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ В СБОРЕ] (GM04-555) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 24227130 БОЛТ, C/VLV UPR BODY (M5X0.8X36) 24225398 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M6 X 1.0 X 20) 24238417 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (INCLS 316) (4.329) [ДАТЧИК ЧИСЛА ОБОРОТОВ ВАЛА AКПП] 24225797 BODY, C/VLV UPR [ГИДРОРАСПРЕДЕЛИТЕЛЬНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24245720 PLATE, C/VLV BODY SPCR (W/GSKT) (ACDelco #24245720) [НАБОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96020431 VALVE, C/VLV BODY BALL CHK [КЛАПАН] 24250384 BODY, C/VLV LWR (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ/;НИЖНИЙ КЛАПАН РЕГУЛЯТОР BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (MANUAL VALVE NOT INCLUDED) (MUST USE T/W 24236934/PLATE KIT - CONT SOL VLV FLTR) 24246427 SWITCH, A/TRNS MAN SHFT SHF POSN (INCLS 315) (INTERNAL MODE SWITCH) [ВКЛЮЧАТЕЛЬ] 24224821 БОЛТ, C/VLV LWR BODY (M5X0.8X45) 24224822 БОЛТ, C/VLV LWR BODY (M5X0.8X55) 24238925 PLATE KIT, CONT SOL VLV FLTR 24240845 БОЛТ, CONT SOL VLV HEAT SINK (W/ BODY & TCM) (M5X0.8X53.0) teamcadillac.ru 24241890 VALVE, CONT SOL (W/ BODY & TCM) (ACDelco #24241890) (ORDER T/W 24238913 SEAL KIT) [ГИДРОРАСПРЕДЕЛИТЕЛЬНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24236233 CLIP, A/TRNS MAN SHFT SHF POSN SW WRG HARN (ЧАСТЬ OF 308) 24236504 CLIP, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN WRG HARN (ЧАСТЬ OF 303) (GM04-556) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ВЕРХНИЙ КЛАПАН РЕГУЛЯТОР BODY БЛОК ↓ 24224766 PIN, C/VLV BODY LOC (ЧАСТЬ OF 321) (DIA.=10MM L=12.7) [ВТУЛКА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24225797 BODY, C/VLV UPR (INCLS 313, 322-338) [ГИДРОРАСПРЕДЕЛИТЕЛЬНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24230200 PIN, C/VLV BODY LOC (ЧАСТЬ OF 321) (DIA.=10MM L=29.9) [ВТУЛКА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, 1-2-3-4 CLU BOOST VLV SPR (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24242814 PLUG, 1-2-3-4 CLU REG VLV BORE (ЧАСТЬ OF 321) (9.5 THK, 11.5 DIA) teamcadillac.ru (GM04-557) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) НИЖНИЙ КЛАПАН РЕГУЛЯТОР BODY БЛОК ↓ 24224755 RETAINER, CLU PSTN DAM FEED REG VLV SPR [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] teamcadillac.ru 24242814 PLUG, CLU SEL SOL VLV BORE #2 (9.5 THK, 11.5 DIA) 24250384 BODY, C/VLV LWR (INCLS 338, 352, 353, 355-357) (MANUAL VALVE NOT INCLUDED) (MUST USE T/W 24236934/PLATE KIT - CONT SOL VLV FLTR) 24224770 VALVE, MAN (ACDelco #24224770) (GM04-558) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) 1-2-3-4 & 3-5 REVERSE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 24240625 RING, 3-5 REV CLU BKG PLT RET (ЧАСТЬ OF 427) (LT GREEN) (2.25-2.35MM) (ACDelco #24240625) 24240626 RING, 3-5 REV CLU BKG PLT RET (ЧАСТЬ OF 427) (GRAY) (2.47-2.57MM) (ACDelco #24240626) 24240627 RING, 3-5 REV CLU BKG PLT RET (ЧАСТЬ OF 427) (YELLOW) (2.69-2.79MM) (ACDelco #24240627) 24240628 RING, 3-5 REV CLU BKG PLT RET (ЧАСТЬ OF 427) (ORANGE) (2.93-3.01MM) (ACDelco #24240628) 24240629 RING, 3-5 REV CLU BKG PLT RET (ЧАСТЬ OF 427) (LT BLUE) (3.13-3.23MM) (ACDelco #24240629) teamcadillac.ru 24240630 RING, 3-5 REV CLU BKG PLT RET (ЧАСТЬ OF 427) (WHITE) (3.35-3.45MM) (ACDelco #24240630) 24240631 RING, 3-5 REV CLU BKG PLT RET (ЧАСТЬ OF 427) (YELLOW/PURPLE) (3.57-3.67MM) (ACDelco #24240631) 24225654 PLATE, 3-5 REV CLU BKG 24237663 PLATE, 3-5 REV CLU (PKG OF 4) (STEEL) 24225564 PLATE, 3-5 REV CLU (WAVED) 24233533 PLATE, 1-2-3-4 CLU BKG 24243588 PLATE, 1-2-3-4 CLU (ACDelco #24243588) 24232652 PLATE, 1-2-3-4 CLU (PKG OF 5) (STEEL) 24236434 PLATE, 1-2-3-4 CLU (WAVED) 24225522 DAM, 1-2-3-4 CLU PSTN 24225559 ПРУЖИНА, 1-2-3-4 CLU 24241073 PISTON, 1-2-3-4 CLU 24238558 ШЛАНГИ, 1-2-3-4 CLU PSTN 24236051 ПРУЖИНА, 3-5-REV CLU 24238560 PISTON, 3-5/REV CLU (INCLS 422) (4.164) 24237184 ШЛАНГИ, 1-2-3-4 & 3-5 REV CLU (INCLS 400, 426, 429) (ORDER T/W 24226393) 24226393 BEARING, 1-2-3-4 & 3-5-REV CLU 24240626 RING, 1-2-3-4 CLU BKG PLT RET (ЧАСТЬ OF 427) (GRAY) (2.47-2.57MM) (ACDelco #24240626) 24240627 RING, 1-2-3-4 CLU BKG PLT RET (ЧАСТЬ OF 427) (YELLOW) (2.69-2.79MM) (ACDelco #24240627) 24240628 RING, 1-2-3-4 CLU BKG PLT RET (ЧАСТЬ OF 427) (ORANGE) (2.93-3.01MM) (ACDelco #24240628) 24240629 RING, 1-2-3-4 CLU BKG PLT RET (ЧАСТЬ OF 427) (LT BLUE) (3.13-3.23MM) (ACDelco #24240629) 24240630 RING, 1-2-3-4 CLU BKG PLT RET (ЧАСТЬ OF 427) (WHITE) (3.35-3.45MM) (ACDelco #24240630) 24240631 RING, 1-2-3-4 CLU BKG PLT RET (ЧАСТЬ OF 427) (YELLOW/PURPLE) (3.57-3.67MM) (ACDelco #24240631) 24240632 RING, 1-2-3-4 CLU BKG PLT RET (ЧАСТЬ OF 427) (LT BLUE/PURPLE) (3.79-3.89MM) (ACDelco #24240632) 24238920 RING KIT, RET (INCLS 411, 415) 24238922 SEAL KIT, A/TRNS SERV (INCLS 416, 418, 419, 422-425) (СЦЕПЛЕНИЕES) (ACDelco #24238922) (GM04-559) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) 4-5-6 ДЕТАЛИ СЦЕПЛЕНИЯ & ВАЛ ТУРБИНЫ ↓ 24225508 RING, 4-5-6 CLU BKG PLT RET (GREEN) (2.52-2.62) (ACDelco #24225508) 24225509 RING, 4-5-6 CLU BKG PLT RET (YELLOW) (3.08-3.18) (ACDelco #24225509) 24231591 RING, 4-5-6 CLU BKG PLT RET (GREY) (2.80-2.90) (ACDelco #24231591) 24231592 RING, 4-5-6 CLU BKG PLT RET (ORANGE) (3.36-3.46) (ACDelco #24231592) 24231593 RING, 4-5-6 CLU BKG PLT RET (BLUE) (3.64-3.74) (ACDelco #24231593) teamcadillac.ru 24232879 RING, 4-5-6 CLU BKG PLT RET (WHITE) (3.74-3.84) (ACDelco #24232879) 24232880 RING, 4-5-6 CLU BKG PLT RET (YELLOW/PURPLE) (4.20-4.30) (ACDelco #24232880) 24225652 PLATE, 4-5-6 CLU BKG 24225570 PLATE, 4-5-6 CLU (INT SPLINE) (PKG OF 5) (FIBER) 24225575 PLATE, 4-5-6 CLU (EXT SPLINE) (PKG OF 5) (STEEL)FIBER) (ACDelco #24225575) 24225565 PLATE, 4-5-6 CLU (WAVED) 24225526 DAM, 4-5-6 CLU PSTN 24225560 ПРУЖИНА, 4-5-6 CLU 24225523 PISTON, 4-5-6 CLU 24237963 ШЛАНГИ, 4-5-6 CLU (W/ INPUT SHF) (INCLS 440) 08662686 SEAL, TURB SHF (O RING) (*KIT2) (ACDelco #8662686) 24238920 RING KIT, RET (INCLS 436) 24243891 SEAL KIT, A/TRNS SERV (INCLS 436, 442, 443) (UNITS BUILT 8-17-08 & PRIOR) (2ND DES SEE 24248567) (FULL TRANS) (ACDelco #24243891) (GM04-560) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) 2-6 ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 24247405 RING, 2-6 CLU BKG PLT RET (1.69MM +/- 0.05) (ACDelco #24247405) 24247406 RING, 2-6 CLU BKG PLT RET (2.81MM +/- 0.05) (ACDelco #24247406) 24248107 RING, 2-6 CLU BKG PLT RET (2.25MM +/- 0.05) (ACDelco #24248107) 24248108 RING, 2-6 CLU BKG PLT RET (2.53MM +/- 0.05) (ACDelco #24248108) 24248109 RING, 2-6 CLU BKG PLT RET (1.97MM +/- 0.05) (ACDelco #24248109) 24225653 PLATE, 2-6 CLU BKG 24237973 PLATE, 2-6 CLU (WAVED) 24225561 ПРУЖИНА, 2-6 CLU teamcadillac.ru 24225524 PISTON, 2-6 CLU 24225447 SUPPORT, CTR (INCLS 458, 460) 24238911 PLATE KIT, CLU (INCLS 452) (ORDER T/W 24225575 & 24235455) (ACDelco #24238911) (GM04-561) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) LOW & REVERSE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 24225519 RING, LOW & REV CLU BKG PLT RET (2.77MM +/- 0.05) (ACDelco #24225519) 24231938 RING, LOW & REV CLU BKG PLT RET (2.63MM +/- 0.05) (MUST BE USED T/W 24247402) (ACDelco #24231938) 24231939 RING, LOW & REV CLU BKG PLT RET (2.93MM +/- 0.05) (MUST BE USED T/W 24247402) (ACDelco #24231939) 24247407 RING, LOW & REV CLU BKG PLT RET (2.03MM +/- 0.05) (MUST BE USED T/W 24247402) (ACDelco #24247407) 24247408 RING, LOW & REV CLU BKG PLT RET (3.23MM +/- 0.05) (MUST BE USED T/W 24247402) (ACDelco #24247408) 24247402 PLATE, LOW & REV CLU BKG (MUST BE USED T/W 24231937/38/38, AND 24247407/08) (ACDelco #24247402) 24236664 PLATE, LOW & REV CLU (PKG OF 6) (FIBER) 24232654 PLATE, LOW & REV CLU (PKG OF 6) (STEEL) (ACDelco #24232654) 24237971 PLATE, LOW & REV CLU (WAVED) (ACDelco #24237971) teamcadillac.ru 24225517 RING, LOW & REV CLU SPR RET 24238921 SPRAG, LOW CLU (INCLS 468) 24225562 ПРУЖИНА, LOW & REV CLU 24225525 PISTON, LOW & REV CLU (ACDelco #24225525) 24238922 SEAL KIT, A/TRNS SERV (INCLS 468) (СЦЕПЛЕНИЕES) (ACDelco #24238922) (GM04-562) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) СЦЕПЛЕНИЕ HUB БЛОК ↓ 24233660 HUB, 4-5-6 CLU (W/ ВЫХОДНОЙ CARR SHF & DPNR) (INCLS 476-478) 24230475 DAMPENER, 4-5-6 CLU (ЧАСТЬ OF 475) teamcadillac.ru 24233661 PLATE, 4-5-6 CLU DPNR APPLY (ЧАСТЬ OF 475) 24230370 RING, 4-5-6 CLU DPNR RET (ЧАСТЬ OF 475) (GM04-563) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ВЫХОДНОЙ КРОНШТЕЙН БЛОК ↓ teamcadillac.ru 24225777 BEARING, CTR SUPT RLR (ЧАСТЬ OF 490) 24225483 BEARING, ВЫХОДНОЙ CARR OTR SUN GR FRT THR (ЧАСТЬ OF 490) 24225290 GEAR, ВЫХОДНОЙ CARR FRT SUN (ЧАСТЬ OF 490) 24225484 BEARING, ВЫХОДНОЙ CARR OTR SUN GR RR THR (ЧАСТЬ OF 490) 24235807 GEAR, ВЫХОДНОЙ CARR RR SUN (ЧАСТЬ OF 490) 24225603 КРОНШТЕЙН, ВЫХОДНОЙ (INCLS 485-489, 491) (GM04-565) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ЗАМОК ПАРКОВКИ ↓ 24242086 ACTUATOR, PARK PAWL (ACDelco #24242086) 24227077 PIN, MAN SHFT DTNT LVR HUB (ЧАСТЬ OF 505) 24234562 LEVER, MAN SHFT DTNT (INCLS 504) (ACDelco #24234562) 24225792 PIN, MAN SHFT SHF (ACDelco #24225792) 24235861 SEAL, MAN SHFT SHF (*KIT1) (ACDelco #24235861) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24225445 SHAFT, MAN SHFT (ACDelco #24225445) teamcadillac.ru 24228969 SHAFT, MAN SHFT (ACDelco #24228969) 24224348 GUIDE, PARK PAWL ACTR (INCLS 510) 24224350 SEAL, PARK PAWL ACTR GDE (O RING) (ЧАСТЬ OF 509) (*KIT1) (ACDelco #24224350) 24226102 PIN, PARK PAWL ACTR GDE 24243891 SEAL KIT, A/TRNS SERV (INCLS 507, 510) (UNITS BUILT 8-17-08 & PRIOR) (2ND DES SEE 24248567) (FULL TRANS) (ACDelco #24243891) (GM04-568) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ВЫХОДНОЙ ВАЛ БЛОК ↓ 24241092 RING, ВЫХОДНОЙ CARR INTL GR RET (ACDelco #24241092) 24225477 GEAR, ВЫХОДНОЙ CARR INTL (FRT) 24228887 SPACER, ВЫХОДНОЙ CARR INTL GR (3.342) 24230333 GEAR, ВЫХОДНОЙ CARR INTL (RR) teamcadillac.ru 24239398 SHAFT, ВЫХОДНОЙ (INCLS 495, 497, 498) (WHEN SERVICING SHAFT MUST ALSO REPLACE BEARING P/N 24237771) 24239401 SHAFT, ВЫХОДНОЙ (INCLS 495, 497, 498) (WHEN SERVICING SHAFT MUST ALSO REPLACE BEARING P/N 24237771) (GM04-569) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) БЛОК СЦЕПЛЕНИЯ & ДЕТАЛИ КОМПЛЕКТА ↓ 24225602 КРОНШТЕЙН, INPUT (ACDelco #24225602) teamcadillac.ru 24225289 GEAR, INPUT SUN (ACDelco #24225289) 24224405 BEARING, INPUT SUN GR THR (ACDelco #24224405) 24232409 WASHER, INPUT SUN GR THR 24238905 BEARING, TURB SHFT THR [ПОДШИПНИК] 24233732 BEARING, 4-5-6 CLU HUB THR (ACDelco #24233732) 24225597 HUB, 1-2-3-4 CLU (W/ВЫХОДНОЙ CARR INR SUN GR SHF) 24224163 BEARING, 1-2-3-4 CLU HUB THR (ACDelco #24224163) 24225596 HUB, 2-6 & 3-5/REV CLU (W/ ВЫХОДНОЙ CARR OTR SUN GR SHF) (INCLS 60, 62) 24224164 BEARING, 2-6 & 3-5/REV CLU HUB THR (ACDelco #24224164) 24225512 RING, CTR SUPT RET 24225447 SUPPORT, CTR 24225486 BEARING, ВЫХОДНОЙ CARR THR 24224668 BEARING, ВЫХОДНОЙ SHF THR (ACDelco #24224668) (GM04-573) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042861 GASKET, A/TRNS CASE EXTN (*KIT1) 24237771 BEARING, ВЫХОДНОЙ SHF (ЧАСТЬ OF 27) 96042860 EXTENSION, A/TRNS CASE (INCLS 26, 28, 29) 24237771 BEARING, ВЫХОДНОЙ SHF (ЧАСТЬ OF 27) 96041851 SEAL, PROP SHF TRANS FLG FLUID (ЧАСТЬ OF 27) (*KIT1) [ПРОКЛАДКА ТРАНСФОРМАТОРНОГО ВАЛА] 96042984 FLANGE, ВЫХОДНОЙ SHF 96041805 NUT KIT, ВЫХОДНОЙ SHFT (INCLS 30, 32, 33) (M6X1.0X16) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) (*KIT1) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) (*KIT1) teamcadillac.ru 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96042963 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPACER PLATE & GASKET) 96042986 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96043253 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) 96042712 DETENT, MAN SHFT 96042847 HARNESS, A/TRNS WRG 96041849 SEAL, A/TRNS WRG CONN (O RING) (*KIT1) 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN (*KIT1) [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (*KIT1) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (*KIT1) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) 96042945 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/GSKT, SEAL, RET) (INCLS 25, 29, 36, 38, 46, 56, 60, 63, 64) (GM04-574) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042887 GASKET, A/TRNS CASE EXTN [ПРОКЛАДКА КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042888 EXTENSION, A/TRNS CASE (INCLS 28, 69) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96042963 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPACER PLATE & GASKET) 96042986 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) 96042712 DETENT, MAN SHFT 96042847 HARNESS, A/TRNS WRG 96041849 SEAL, A/TRNS WRG CONN (O RING) 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) 96042543 WASHER, INPUT & REACTION CARR THR 96042587 SEAL, PROP SHF TRANS FLG FLUID [ПРОКЛАДКА КРЫШКИ РАЗДАТОЧНОЙ КОРОБКИ] 08677884 BEARING, ВЫХОДНОЙ SHF THR (ЧАСТЬ OF 27) (4.180) (ACDelco #8677884) (GM04-575) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ 96042554 CONVERTER, TORQ (REMAN) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042812 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) 96042806 СЦЕПЛЕНИЕ, DIR & REV (СМ. ГРУППУ 04.000 "DIRECT AND REVERSE СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042807 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (СМ. ГРУППУ 04.000 "FORWARD AND COAST СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042698 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) (СМ. ГРУППУ 04.000 "INPUT SUN GEAR SHAFT AND FORWARD SPRAG СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (СМ. ГРУППУ 04.000 "DIRECT СЦЕПЛЕНИЕ DRUM AND SHAFT" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042701 WASHER, INPUT & REACTION CARR INR SHF THR 96042808 ШЛАНГИ, O/D CLU (СМ. ГРУППУ 04.000 "OVERDRIVE AND INTERMEDIATE СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (СМ. ГРУППУ 04.000 "LOW СЦЕПЛЕНИЕ SPRAG" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) teamcadillac.ru 96042705 BEARING, CTR SUPT RLR (4.180) 96042809 SUPPORT, CTR (СМ. ГРУППУ 04.000 "CENTER SUPPORT" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042707 КРОНШТЕЙН, INPUT & REACTION (СМ. ГРУППУ 04.000 "PLANETARY КРОНШТЕЙН" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (4.176) 96042708 BEARING, INPUT & REACTION CARR THR 96042709 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (СМ. ГРУППУ 04.000 "ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96041847 WASHER, INPUT & REACTION CARR THR (4.265) (GM04-576) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ 96042554 CONVERTER, TORQ (REMAN) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042812 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) 96042814 СЦЕПЛЕНИЕ, DIR & REV 96042815 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) 96042698 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) (INCLS 9) 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) 96042701 WASHER, INPUT & REACTION CARR INR SHF THR 96042808 ШЛАНГИ, O/D CLU teamcadillac.ru 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) 08677884 BEARING, LOW CLU RLR THR (*KIT1) (ACDelco #8677884) 96042705 BEARING, LOW CLU RLR THR (*KIT1) 96042816 SUPPORT, CTR 96042817 КРОНШТЕЙН, INPUT & REACTION 96042818 BEARING, INPUT & REACTION CARR THR 96042813 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) 96042543 WASHER, INPUT & REACTION CARR THR 96042818 BEARING, INPUT & REACTION CARR THR (GM04-577) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ 08680684 ПРУЖИНА, LINE BOOST VLV (*KIT1) (4.262) (ACDelco #8680684) 08642581 SEAL, A/TRNS ГИДРОНАСОС CVR SCRN (*KIT1) (ACDelco #8642581) 96015215 БОЛТ, T/CV FLUID SEAL (*KIT1) teamcadillac.ru 96041855 SEAL, T/CV FLUID [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 08634106 ПРУЖИНА, PRESS RLF BALL VLV (*KIT1) (ACDelco #8634106) 00147500 VALVE, PRESS RLF BALL (*KIT1) 96042812 ШЛАНГИ KIT, T/CV (INCLS 200-215, 217-220, 223, 226-228, 231-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-577) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ teamcadillac.ru 08680684 ПРУЖИНА, LINE BOOST VLV (*KIT1) (4.262) (ACDelco #8680684) 96015215 БОЛТ, T/CV FLUID SEAL (*KIT1) 96041855 SEAL, T/CV FLUID [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 08634106 ПРУЖИНА, PRESS RLF BALL VLV (*KIT1) (ACDelco #8634106) 00147500 VALVE, PRESS RLF BALL (*KIT1) 96042812 ШЛАНГИ KIT, T/CV (INCLS 200-215, 217-220, 223, 226-228, 231-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-578) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 24209145 ФИЛЬТР, PRESS CONT SOL VLV FLUID (*KIT1, KIT2) (ACDelco #24209145) [ФИЛЬТР] 24209145 ФИЛЬТР, PRESS CONT SOL VLV FLUID (*KIT1, KIT2) (ACDelco #24209145) [ФИЛЬТР] 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 300-309, 312-334) (INCLS SPACER PLATE & GASKET) 96042986 VALVE, CONT (W/BODY & VLV) (INCLS 300-309, 312-334) 96043253 VALVE, CONT (W/BODY & VLV) (INCLS 300-309, 312-334) 96042986 GASKET KIT, A/TRNS (INCLS 303, 305, 306, 308, 309, 312, 314, 316, 330, 332) (4.265) (GM04-578) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 96020027 БОЛТ, C/VLV CHAN PLT (*KIT1) teamcadillac.ru 96025325 БОЛТ, INTER CLU ACCUM (*KIT1) (4.265) 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 300-334) (INCLS SPACER PLATE & GASKET) 96042986 VALVE, CONT (W/BODY & VLV) (INCLS 300-334) (GM04-579) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 08680781 RETAINER, PRESS CONT SOL VLV (*KIT1) (ACDelco #8680781) 96042599 VALVE, TCC PWM SOL teamcadillac.ru 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 340-351, 353-356) (INCLS SPACER PLATE & GASKET) 96042986 VALVE, CONT (W/BODY & VLV) (INCLS 340-351, 353-356) 96043253 VALVE, CONT (W/BODY & VLV) (INCLS 340-351, 353-356) (GM04-579) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 08680781 RETAINER, PRESS CONT SOL VLV (*KIT1) (ACDelco #8680781) 96042599 VALVE, TCC PWM SOL 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 340-348, 351, 353-354) (INCLS SPACER PLATE & GASKET) 96042986 VALVE, CONT (W/BODY & VLV) (INCLS 340-348, 351, 353-354) (GM04-580) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 08680781 RETAINER, 1-2 SHFT SOL VLV (*KIT1) (ACDelco #8680781) 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] teamcadillac.ru 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 343, 349, 350, 365-367, 370-375, 377-388) (INCLS SPACER PLATE & GASKET) 96042986 VALVE, CONT (W/BODY & VLV) (INCLS 343, 349, 350, 365-367, 370-375, 377-388) 96043253 VALVE, CONT (W/BODY & VLV) (INCLS 343, 349, 350, 365-367, 370-375, 377-388) (GM04-580) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 08680781 RETAINER, 1-2 SHFT SOL VLV (*KIT1) (ACDelco #8680781) 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 343, 351, 365-367, 370-375, 377-388) (INCLS SPACER PLATE & GASKET) 96042986 VALVE, CONT (W/BODY & VLV) (INCLS 343, 351, 365-367, 370-375, 377-388) 96042889 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/PLT, GSKT, SEAL) (INCLS 343, 351, 365-367, 370-375, 377-388) (GM04-581) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru 96042806 СЦЕПЛЕНИЕ, DIR & REV (INCLS 400-420) (GM04-581) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru 96042814 СЦЕПЛЕНИЕ, DIR & REV (INCLS 400-420) (GM04-582) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96041856 SEAL, INPUT SHF (O RING) (*KIT1) [ПРОКЛАДКА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] teamcadillac.ru 96042807 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-451) (GM04-582) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042815 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-451) (GM04-583) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042707 КРОНШТЕЙН, INPUT & REACTION (INCLS 455-462) (4.176) (GM04-583) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042817 КРОНШТЕЙН, INPUT & REACTION (INCLS 455-462) (GM04-584) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ teamcadillac.ru 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-584) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ teamcadillac.ru 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-585) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 470-477) (GM04-585) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 470-477) (GM04-586) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 480-497) (GM04-586) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 480-497) (GM04-587) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК ↓ teamcadillac.ru 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (INCLS 500-505) (GM04-587) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК ↓ teamcadillac.ru 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (INCLS 500-505) (GM04-588) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) КРЕПЛЕНИЕ ↓ teamcadillac.ru 96042809 SUPPORT, CTR (INCLS 510-535) (GM04-588) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) КРЕПЛЕНИЕ ↓ teamcadillac.ru 96042816 SUPPORT, CTR (INCLS 510-535) (GM04-589) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) PLANETARY КРОНШТЕЙН БЛОК ↓ teamcadillac.ru 96042707 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-554) (4.176) (GM04-589) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) PLANETARY КРОНШТЕЙН БЛОК ↓ teamcadillac.ru 96042817 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-554) (GM04-590) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК ↓ teamcadillac.ru 96042709 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560-564) (GM04-591) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК ↓ teamcadillac.ru 96042813 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560-561, 563-564) (GM04-593) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) PARKING PAWL БЛОК ↓ 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 96042540 SWITCH, A/TRNS MAN SHFT SHF POSN [ВЫКЛЮЧАТЕЛЬ ПРИВОДА] 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 08644709 SEAL, MAN SHFT SHF (W/O PTFE LUBRICANT APPLIED TO SEAL) (ACDelco #8644709) 96041857 SHAFT, MAN SHFT teamcadillac.ru 96042711 PAWL KIT, PARK 96041852 PLUG, MAN SHFT SHF HOLE (4.279) 96041842 SPACER, MAN SHFT DTNT LVR (GM04-594) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) PARKING PAWL БЛОК ↓ 96042819 LEVER, MAN SHFT DTNT 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 96042540 SWITCH, A/TRNS MAN SHFT SHF POSN [ВЫКЛЮЧАТЕЛЬ ПРИВОДА] 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 08644709 SEAL, MAN SHFT SHF (W/O PTFE LUBRICANT APPLIED TO SEAL) (ACDelco #8644709) 96042544 SHAFT KIT, MAN SHFT 96042820 PAWL KIT, PARK teamcadillac.ru (GM04-598) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (6L50 MYB, ЗАДНИЙ КОЛЕСО DRIVE MX0) ↓ teamcadillac.ru 17804000 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) 17804001 ТРАНСМИССИЯ, AUTO (GM04-599) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (6L50 MYB, ALL КОЛЕСО DRIVE MX7) ↓ teamcadillac.ru 17804000 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) 17804001 ТРАНСМИССИЯ, AUTO (GM04-668) - 2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 24240018 CONVERTER, TORQ [ГИДРОТРАНСФОРМАТОР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 11515762 БОЛТ-HFLGE, M8X1.25X50, 18 OD, 22 THD, 10.9, PZO (T/CV HSG) 24225543 SEAL, A/TRNS ГИДРОНАСОС (ACDelco #24225543) [ПРОКЛАДКА КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24242045 CASE, A/TRNS (INCLS 6, 12, 13) (ACDelco #24242045) 24242046 CASE, A/TRNS (INCLS 6, 12, 13) (ACDelco #24242046) 24226020 PLUG, TRANS FLUID FIL TUBE 24239878 SLEEVE, A/TRNS ELEC CONN PASG [МУФТА] 24225788 БОЛТ, A/TRNS CASE EXTN (M10X1.5X34) 24225557 SEAL, CTR SUPT FLUID PASG (*KIT2) 24224822 БОЛТ, C/VLV LWR BODY (M5X0.8X55) 24231074 БОЛТ, MAN SHFT DTNT (M10X1X14.5) 24222646 DETENT, MAN SHFT (W/8MM DIA. ROLLER) (ACDelco #24222646) 24236933 FILTER KIT, A/TRNS FLUID (INCLS 25) (ACDelco #24236933) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24225800 GASKET, A/TRNS FLUID PAN (ACDelco #24225800) [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 29535617 MAGNET, A/TRNS FLUID PAN (4.105) (ACDelco #29535617) [МАГНИТ] 24242410 PAN, A/TRNS FLUID (INCLS 31) (ACDelco #24242410) 11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (A/TRNS FLUID PAN) [БОЛТ М6] 24234212 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 29) (ACDelco #24234212) [ПРОБКА] 24205900 PLUG, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] 24225783 SEAL, A/TRNS CASE EXTN (ACDelco #24225783) [УПЛОТНИТЕЛЬ КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24237879 EXTENSION, A/TRNS CASE (INCLS 36, 37) (ACDelco #24237879) 24228876 SEAL, ВЫХОДНОЙ SHF (ЧАСТЬ OF 34) (5.556) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24214158 BEARING, ВЫХОДНОЙ SHF (DRAWN CUP) (ЧАСТЬ OF 34) (4.131) (ACDelco #24214158) 24230287 FLANGE, PROP SHF TRANS 24231524 ГАЙКА, FRT PROP SHF FLG (M22X1.5) (FLANGE HEX) 24229687 EXTENSION, A/TRNS CASE (MCHG) 24237771 BEARING, ВЫХОДНОЙ SHF 24242995 BEARING, ВЫХОДНОЙ SHF [ПОДШИПНИК КПП] 24236928 SEAL KIT, A/TRNS ELEC CONN PASG SLEV (INCLS 9, 10) 24238913 SEAL KIT, A/TRNS SERV (INCLS 9, 10, 18-20) (CONTROL VLV SOL ASM) (ACDelco #24238913) [КОМПЛЕКТ ПРОКЛАДОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (5ШТ)] 04 - ТРАНСМИССИЯ - ТОРМОЗ ↓ (6D04-023) - 2004-2009 E СТОЯНОЧНЫЙ ТОРМОЗ ASM ↓ 88951984 PLATE, RR PARK BRK ANC BKG (4.591) 88951985 PLATE, RR PARK BRK ANC BKG (4.591) teamcadillac.ru 88951982 ACTUATOR KIT, RR PARK BRK (INCLS 2) (ACDelco #179-2053) [АКТУАТОР] 88951983 ACTUATOR KIT, RR PARK BRK (INCLS 2) (ACDelco #179-2054) [АКТУАТОР] 89047676 SHOE KIT, RR PARK BRK (INCLS 5) (ACDelco #171-0915) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (2 ШТ)] (6D04-031) - 2004-2009 E ТОРМОЗНОЙ СУППОРТ-ЗАДНИЙ ↓ 89047677 CALIPER KIT, RR BRK (INCLS 2, 3, 7-9) (ACDelco #172-2343) 89047678 CALIPER KIT, RR BRK (INCLS 2, 3, 7-9) (ACDelco #172-2344) [ТОРМОЗНОЙ СУППОРТ] 88951992 CAP, RR BRK BLEDR VLV (ЧАСТЬ OF 1) 88951991 VALVE, RR BRK CLPR BLEDR (ЧАСТЬ OF 1) teamcadillac.ru 89047757 PAD KIT, RR DISC BRK (INCLS 4, 12) (ACDelco #171-859) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4 ШТ)] 89047758 PAD KIT, RR DISC BRK (INCLS 4, 12) (4.667) (ACDelco #171-0906) [ТОРМОЗНЫЕ КОЛОДКИ] 88957163 BRACKET, RR BRK CLPR [СКОБА ТОРМОЗНОГО СУППОРТА] 89047759 PIN KIT, RR BRK CLPR GDE (INCLS 4-6) (INCLS 2 PINS, 2 SEALS & 2 (2.75") БОЛТS) (ACDelco #179-2044) [НАПРАВЛЯЮЩАЯ ТОРМОЗНОГО СУППОРТА (2 ШТ)] 88957162 REPAIR KIT, RR BRK CLPR HYD (INCLS 4, 6, 8, 9) (6D04-033) - 2004-2009 E ТОРМОЗНОЙ УСИЛИТЕЛЬ ↓ 88967237 BOOSTER, P/B (W/O VLV) (ACDelco #178-0695) 05461808 GROMMET, P/B BOOS VAC CHK VLV (*KIT1) teamcadillac.ru 03817880 RETAINER, BRK PED PUSH ROD (0.80 IN) (PUSH IN) 18022219 VALVE KIT, P/B BOOS VAC CHK (INCLS 2, 3) (BLACK) (INCLS VLV & GROM) (ACDelco #179-1266) (6D04-067) - 2007-2009 E КОРПУС КП КРЕПЛЕНИЕ (MYB,MX7) ↓ 24231525 GASKET, TRFER CASE teamcadillac.ru 19132968 CASE, TRFER (W/GEARS) (LESS DAMPENER) 24243367 CASE, TRFER (W/GEARS) 11589341 БОЛТ - HFH, M10X1.5X69.9, 28.35 THD, 22.3 OD, 10.9, GMW3359, M-PT. (TRFER CASE) [БОЛТ] (6E00-014) - 2004-2009 E ТРАНСМИССИЯ TO КРЕПЛЕНИЕ ДВИГАТЕЛЯ (LY7/3.6-7) ↓ 12572042 PLATE, A/TRNS FLEX 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (TRANS CVR) [БОЛТ] teamcadillac.ru 24222918 COVER, TRANS CONV 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] (6E03-019) - 2007-2009 E T.C.M. МОДУЛЬ (LY7/3.6-7) ↓ 12623327 МОДУЛЬ, ENG CONT (W/O CALN) 25784072 BRACKET, ECM (INCLS 5, 6) 24239785 МОДУЛЬ, TRANS CONT (W/O CALN) teamcadillac.ru 11609462 SCREW, M4.2X1.41X13, GMW4205 (ЧАСТЬ OF 3) 11561758 БОЛТ, MULTIUSE RLY & FUSE BRKT (7.833) [БОЛТ] 15879156 BRACKET, ACSRY WRG J/BLK 11609599 STUD, SPL, M6X1X25, 13 THD, 11 OD HD W/26 WIDE CLIP, 9.8, 6280M, P-PT (MULTIUSE FUSE BRKT) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (MULTIUSE RLY & FUSE BRKT) [ГАЙКА М6] (6E04-007) - 2007-2009 EB ТОРМОЗНЫЕ ШЛАНГИ И ТРУБКИ ↓ 15933099 HOSE, FRT BRK (INCLS 15, 16) (ACDelco #176-1495) teamcadillac.ru 11569742 RETAINER, FRT BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (BRK & FUEL FEED & FUEL RTN & EVAP EMIS) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА] 25761218 BRACKET, FUEL PIPE 25761217 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (3.162) 12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (FRT BRK) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА] 10388788 PIPE, BRK PRESS MOD VLV FRT (INCLS 29) 10388794 PIPE, BRK PRESS MOD VLV RR (INCLS 29) 03541444 SPACER, FRT BRK PIPE 11516521 БОЛТ, HFH M6X1X20, 9.8, 7114M, DOG PT, 14.2 OD (FRT BRK HOSE) 15933098 HOSE, FRT BRK (INCLS 15, 16) (ACDelco #176-1487) 25743891 RETAINER, RR BRK FRT PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT) 11569737 FITTING, FRT BRK PIPE (ЧАСТЬ OF 1, 12) (7/16-24X0.36, 0.30THD) (0.56 LONG, 3/16TUBE) 25743891 RETAINER, FRT BRK PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT) 15904901 CLIP, FRT BRK PIPE (STAR SHAPED 3 TUBE W/TREE) [КРОНШТЕЙН] 25737279 CLIP, FRT BRK PIPE (THREE WAY RETAINER SINGLE CENTRAL FIR-TREE ATTACHMENT) 25749839 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (HOLDS 3 ТРУБКИ, FLAT SHAPE, SNAP-IN RETAINER) 25867884 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE 15880948 RETAINER, BRK PIPE (FOR 5 LINES W/45 DEGREE PUSHPIN) 25607191 RETAINER, BRK PIPE (21.5X10.0MM) (HOLDS (2) 4.68-4.82 TUBES) 11569742 RETAINER, RR BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 15724650 ГАЙКА, INVERTED FLARED TUBE, 9/16"-18, 1/4" TUBE, ZD (BRK PIPE) (4.686) [ГАЙКА] 25693890 RETAINER, RR BRK PIPE (HOLDS (1) 4.76 LINE) (W/TREE) [ЗАМОК, ФИКСАТОР] 11588803 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 7, 8) (1/2-20X.40, .32 THD) (INVERTED FLARED TUBE) (.62 LONG, 1/4 TUBE) [ГАЙКА М20] 15724650 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 7, 8) (9/16-18 X .40) (INVERTED FLARED TUBE) [ГАЙКА] 15933091 HOSE, RR BRK (INCLS 22, 23) (ACDelco #15933091) 15933092 HOSE, RR BRK (INCLS 22, 23) (ACDelco #15933092) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ] 88964150 PROTECTOR, RR BRK PIPE (FOR 3/16" PIPE) (HT SHRINK) (6E04-008) - 2007-2009 EB ТОРМОЗНАЯ ПЕДАЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (EXC (JF4)) ↓ teamcadillac.ru 25732428 BARRIER, BRK PED BRKT SND 25697461 RETAINER, BRK PED PUSH ROD BOOT 25732452 BOOT, BRK PED PUSH ROD 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] 15932827 HOSE, P/B BOOS VAC (ACDelco #176-1496) 25818868 PEDAL, BRK (W/BRKT) (INCLS 10, 11, 14, 16-18) 25771615 COVER, BRK PED (ЧАСТЬ OF 9) 89047699 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 9) [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 9) 10434956 BUSHING, BRK PED PUSH ROD 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 9) 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 9) (0.80 IN) (PUSH IN) (6E04-012) - 2007-2009 E КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS(MYB,MX7) ↓ 88996677 CASE, TRFER (FRT HALF) (INCLS 12-14) 19133265 CASE, TRFER (RR HALF) (INCLS 5, 7) 88996679 SNUBBER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN 88996680 БОЛТ, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN SNBR (M5X0.8X16) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 2) teamcadillac.ru 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL FILL) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996657 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 2) [УПЛОТНИТЕЛЬ] 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL DRN) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996680 БОЛТ, TRFER CASE VENT BFL (M5X0.8X16) (4.535) 88996658 BAFFLE, TRFER CASE VENT 89048123 БОЛТ, TRFER CASE HALF (M8X1.25X30) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 1) 88996656 SEAL, TRFER CASE INPUT SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 88996657 SEAL, TRFER CASE FRT ВЫХОДНОЙ SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] (6E04-013) - 2008-2009 E КОРПУС КП ЧАСТЬ 2 INTERNAL COMPONENTS(MX5) ↓ 88984517 WASHER, TRFER CASE PLNT CARR SUN GR THR (25.8X52.0X2.2) 88984524 GEAR, TRFER CASE PLNT CARR SUN (INPUT) (STAMPED PM/POWDERED METAL) 88984493 RING, TRFER CASE RR ВЫХОДНОЙ SHF RR BRG RET (41MM I.D.) (ACDelco #88984493) 88996564 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT 88996665 BEARING, TRFER CASE MAIN SHF FRT (ВЫХОДНОЙ ВАЛ FRT) 19168733 BUSHING, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 106) [ВТУЛКА РАЗДАТОЧНОЙ КОРОБКИ] 19178237 SHAFT, TRFER CASE RR ВЫХОДНОЙ (INCLS 105) 19178238 SHAFT, TRFER CASE RR ВЫХОДНОЙ (INCLS 105) 19133264 SPROCKET, TRFER CASE FRT ВЫХОДНОЙ SHF DRV (INCLS 108) [ШЕСТЕРНЯ РАЗДАТОЧНОЙ КОРОБКИ] 19168732 BUSHING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT (ЧАСТЬ OF 107) (ACDelco #19168732) 19132837 CHAIN, TRFER CASE TWO/FOUR WHL DRV 89059578 CHAIN, TRFER CASE TWO/FOUR WHL DRV [ЦЕПЬ РАЗДАТОЧНОЙ КОРОБКИ] 88984523 GEAR, TRFER CASE PLNT CARR SUN (ВЫХОДНОЙ) 89059279 КРОНШТЕЙН, FRT/RR DRV DIFF 89059284 SHAFT, TRFER CASE FRT ВЫХОДНОЙ (INCLS 900) 88996664 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF RR 88996671 RING, TRFER CASE FRT ВЫХОДНОЙ SHF BRG RET 88996666 SPROCKET, TRFER CASE TWO/FOUR WHL DRV DRVN [ЗВЕЗДОЧКА] 88996633 BEARING, TRFER CASE RR ВЫХОДНОЙ SHF RR (ACDelco #88996633) [ПОДШИПНИК РАЗДАТОЧНОЙ КОРОБКИ] 15580230 BEARING, TRFER CASE INPUT SHF (BORG-WARNER) (4.510) 19132966 SHAFT, TRFER CASE INPUT 88996681 DEFLECTOR, TRFER CASE FRT ВЫХОДНОЙ SHF SEAL DIRT (ЧАСТЬ OF 112) (6E04-016) - 2004-2009 E КЛАПАН РЕГУЛИРОВКИ ДАВЛЕНИЯ В ТОРМОЗНОЙ СИСТЕМЕ ↓ 19153350 МОДУЛЬ KIT, ELEK BRK & TRACT CONT [МОДУЛЬ] 89060233 VALVE KIT, BRK PRESS MOD (INCLS 3, 4) (ACDelco #89060233) [ГИДРАВЛИЧЕСКИЙ БЛОК АБС] 25743362 SENSOR, BRK PRESS MOD VLV PRESS (ЧАСТЬ OF 2) (ACDelco #25743362) [ДАТЧИК] 25741456 INSULATOR, BRK PRESS MOD VLV (ЧАСТЬ OF 2) 11588304 STUD, FLANGE DOUBLE END, M8X14 UNTHD, M8X1.25X13, 17 OD, 5.8, GM4345M (BRK PRESS MOD VLV BRKT) 11514596 ГАЙКА, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (BRK PRESS MOD VLV BRKT) (8.915) (ACDelco #11514596) 11508351 SCREW, PAN HD, C/R, 5X0.8X13, 9.3 OD, FULL THD, THD RLLR, 6171M, PC (BRK PRESS MOD VLV) (8.977) (6E04-017) - 2007-2009 E ШЛАНГ ВЕНТИЛЯЦИИ ТРАНСМИССИИ (LY7/3.6-7, M82,MX5) ↓ 25764835 VENT, A/TRNS (INCLS 2, 3) (ACDelco #25764835) teamcadillac.ru 15955072 CLIP, TRANS VENT HOSE (ЧАСТЬ OF 1) (.650MM DIA) (2.343) (6E04-018) - 2004-2009 E КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS(MX5) ↓ 88996677 CASE, TRFER (FRT HALF) (INCLS 12-14) 19133265 CASE, TRFER (RR HALF) (INCLS 5, 7) 88996679 SNUBBER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN 88996680 БОЛТ, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN SNBR (M5X0.8X16) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 2) 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL FILL) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996657 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 2) [УПЛОТНИТЕЛЬ] 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL DRN) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996680 БОЛТ, TRFER CASE VENT BFL (M5X0.8X16) (4.535) 88996658 BAFFLE, TRFER CASE VENT 89048123 БОЛТ, TRFER CASE HALF (M8X1.25X30) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 1) 88996656 SEAL, TRFER CASE INPUT SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 88996657 SEAL, TRFER CASE FRT ВЫХОДНОЙ SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 19180066 VENT, TRFER CASE 89048123 БОЛТ, TRFER CASE VIB DPNR (M8X1.25X30) 19133173 DAMPENER, TRFER CASE VIB (YOKE STYLE; БОЛТS TO RR OF T-CASE) (6E04-020) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ 24218963 RING, T/CV FLUID SEAL RET [КОЛЬЦО] 24237531 SEAL, T/CV FLUID (ЧАСТЬ OF 217, 219) (ACDelco #24237531) [УПЛОТНЕНИЕ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 00444613 PLUG, HEX HD, 1/8-27 NPTF, STL (LINE PRESS TEST HOLE) (ACDelco #444613) 24239385 ШЛАНГИ, T/CV (MCHG) (INCLS 206) 24225422 PIPE, A/TRNS VENT 15251488 SEAL, TRANS FLUID CLR PIPE FTG (ЧАСТЬ OF 217, 219) (SEALS TWO ТРУБКИ) (*KIT1) [УПЛОТНЕНИЕ] 24237658 SEAL, TRANS FLUID CLR PIPE FTG (ЧАСТЬ OF 217, 219) (SEALS ONE PIPE) (*KIT1) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ] 24222668 SLIDE, A/TRNS ГИДРОНАСОС (17.948MM-17.961MM) (ACDelco #24222668) 24224131 SLIDE, A/TRNS ГИДРОНАСОС (17.961MM-17.974MM) (ACDelco #24224131) 24224132 SLIDE, A/TRNS ГИДРОНАСОС (17.974MM-17.987MM) (ACDelco #24224132) 24238915 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 207-211, 213-216, 230) (17.948MM-17.961MM) (ACDelco #24238915) 24238916 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 207-211, 213-216, 230) (17.961MM-17.974MM) (ACDelco #24238916) 24238917 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 207-211, 213-216, 230) (17.974MM-17.987MM) (ACDelco #24238917) 24238919 COVER KIT, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 218, 220-230, 232-237) (ACDelco #24238919) 00147500 VALVE, PRESS RLF BALL (ЧАСТЬ OF 219) 24224692 WASHER, 1-2-3-4 & 3-5 REV CLU HSG THR (ЧАСТЬ OF 219) 24239151 RING KIT, 1-2-3-4 & 3-5 REV CLU FLUID SEAL (ACDelco #24239151) 24248559 RING KIT, 1-2-3-4 & 3-5 REV CLU FLUID SEAL (1-SET 2ND DES SEALS (INCL QUAD LOBE)) (ACDelco #24248559) 24227061 БОЛТ, A/TRNS ГИДРОНАСОС CVR (ACDelco #24227061) [БОЛТ] 90351709 PIN, A/TRNS ГИДРОНАСОС LOC (ЧАСТЬ OF 219) ("8MM HOLLOW SPLIT PIN") (1.639) [ШПИЛЬКА] teamcadillac.ru 24243891 SEAL KIT, A/TRNS SERV (INCLS 205, 210, 214, 230) (UNITS BUILT 8-17-08 & PRIOR) (2ND DES SEE 24248567) (FULL TRANS) (ACDelco #24243891) (6E04-022) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (LY7/3.6-7, V92) ↓ 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 89022494 BRACKET, TRANS FLUID CLR 19129782 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) [ТРУБКА МАСЛООХЛАДИТЕЛЯ] 19130214 SEAL, TRANS FLUID CLR HOSE CONN (O RING) 19129781 HOSE, TRANS FLUID CLR LWR (W/BLOCK) 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] teamcadillac.ru 19130449 COOLER, TRANS FLUID (INCLS 7-10) (ACDelco #19130449) [РАДИАТОР]
  5. 00 - 6-ТИ ЦИЛИНДРОВЫЙ ДВИГАТЕЛЬ ↓ (6D00-036) - 2007-2008 E КРЕПЛЕНИЕ ДВИГАТЕЛЯ TO ТРАНСМИССИЯ (LH2/4.6A) ↓ 12582606 FLYКОЛЕСО, ENG 15813405 BRACKET, ENG WRG HARN (IP INLINE) 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] 24205900 PLUG, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] 24205899 PLUG, T/CV HSG ACC HOLE (28MM W/3 TANGS) (SMALL CVR) (ACDelco #24205899) 11589116 БОЛТ, FLYWHL (8.900) 12568122 COVER, FLYWHL HSG 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (TRANS CONV CVR) (ACDelco #11517518) [БОЛТ] 12568123 COVER, TRANS CONV (6D00-040) - 2007-2009 E ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ-V8 (LH2/4.6A) ↓ teamcadillac.ru 25716470 BRACKET, ENG MT 25762621 BRACKET, ENG MT 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (ENG MT BRKT) [БОЛТ, М10Х1.5Х30] 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT) [ГАЙКА М12] 25971085 MOUNT, ENG [ШАРНИР ДВИГАТЕЛЯ] 25971087 MOUNT, ENG 25971086 MOUNT, ENG [ОПОРНЫЙ УЗЕЛ ДВИГАТЕЛЯ] 25762620 BRACKET, ENG MT 25892303 MOUNT, TRANS RR 25892306 MOUNT, TRANS RR 11589169 БОЛТ ASM - HEX HD W/CONICAL WASHER, M10X1.50X50, GMW25 (10.9) STL, GMW33559 (TRANS RR MT BRKT) 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (TRANS MT) [БОЛТ, М10Х1.5Х30] 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT FRM SI) [ГАЙКА М12] (6E00-005) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ & ЧАСТЬIAL ДВИГАТЕЛЬ (LH2/4.6A) ↓ teamcadillac.ru 19177068 ДВИГАТЕЛЬ, GASOLINE (GOODWRENCH NEW) (FOR 07 STS, SWP OIL FILT ADAPT, ENG OIL CLR FRM ORIG ENG.06 & PREV STS/SRX/XLR SWP МАСЛЯНЫЙ ПОДДОН, ENG OIL CLR IF APPL, WTR OTLT ASM, CAM ACTUATOR FRM ORIG) (ENG.05 & PREV STS/SRX/XLR SWP CAM CVRS & PVC TBE F (6E00-013) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ & ЧАСТЬIAL ДВИГАТЕЛЬ (LY7/3.6-7) ↓ 12617625 ДВИГАТЕЛЬ KIT, GASOLINE (GOODWRENCH) (MUST SWAP OIL FILL TUBE) 19206165 ДВИГАТЕЛЬ, (SERV ЧАСТЬIAL) (MAY NEED TO SWAP МАСЛЯНЫЙ ПОДДОН) (REQUIRES CRANKSHAFT BALANCER WITH KEYWAY. FOR SINGLE BELT, USE 12603181. FOR DUAL BELT BALANCER USE 12603180) (6E00-014) - 2004-2009 E КРЕПЛЕНИЕ ДВИГАТЕЛЯ TO ТРАНСМИССИЯ (LY7/3.6-7) ↓ 12572042 PLATE, A/TRNS FLEX 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (TRANS CONV CVR) [БОЛТ] teamcadillac.ru 24222918 COVER, TRANS CONV 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] (6E00-015) - 2004-2009 E ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ-V6 (LY7/3.6-7, M82) ↓ 25892303 MOUNT, TRANS RR 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (TRANS MT) [БОЛТ, М10Х1.5Х30] 11517383 БОЛТ, HEX W/CON SPR WASH, M10X1.5X55, 28 OD, 37 THD, 10.9, 7114M (TRANS RR MT BRKT) 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT) [ГАЙКА М12] 25756321 BRACKET, ENG MT 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (ENG MT BRKT) [БОЛТ, М10Х1.5Х30] teamcadillac.ru 25971088 MOUNT, ENG [ОПОРНЫЙ УЗЕЛ ДВИГАТЕЛЯ] 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT FRM SI) [ГАЙКА М12] 25971089 MOUNT, ENG 25756322 BRACKET, ENG MT (6E00-016) - 2004-2009 E ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ-V6 (LY7/3.6-7, MX5) ↓ 25892306 MOUNT, TRANS RR 11515775 БОЛТ, HFH, M12X1.75X30, 10.9, 7114M (TRANS MT) [БОЛТ] 11517383 БОЛТ, HEX W/CON SPR WASH, M10X1.5X55, 28 OD, 37 THD, 10.9, 7114M (TRANS RR MT BRKT) 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT) [ГАЙКА М12] 25756321 BRACKET, ENG MT 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (ENG MT BRKT) [БОЛТ, М10Х1.5Х30] 25971088 MOUNT, ENG [ОПОРНЫЙ УЗЕЛ ДВИГАТЕЛЯ] 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT FRM SI) [ГАЙКА М12] teamcadillac.ru 25971085 MOUNT, ENG [ШАРНИР ДВИГАТЕЛЯ] 25756320 BRACKET, ENG MT (6E00-017) - 2007-2009 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 3 ПЕРЕДНЯЯ КРЫШКА И ОХЛАЖДЕНИЕ (LH2/4.6A) ↓ 03525915 PIN, ENG FRT CVR LOC (DOWEL, 5.99X17.25, CHAM BOTH ENDS, 10.9) 89017798 COVER, ENG FRT (INCLS 353) 12593627 GASKET, ENG FRT CVR [ПРОКЛАДКА ПЕРЕДНЕЙ КРЫШКИ ДВИГАТЕЛЯ] 11519038 БОЛТ-HFH, M6X1X30, 24 THD, 13.2 OD, 10.9, GMW3359, W/ADHESIVE ON THREADS (ENG FRT CVR) [БОЛТ М6] 12569545 PLUG, ENG FRT CVR HOLE 12595614 PUMP, WAT (INCLS 901) (ACDelco #251-699) [НАСОС ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519038 БОЛТ-HFH, M6X1X30, 24 THD, 13.2 OD, 10.9, GMW3359, W/ADHESIVE ON THREADS (W/PMP) [БОЛТ М6] 12604614 PULLEY, W/PMP 24503961 БОЛТ, W/PMP PUL (M6X1.0 6G THD W/WA) (8MM SOCKET HD) 12559807 THERMOSTAT, ENG COOL (W/O GSKT) (ACDelco #131-128) [КЛАПАН РЕГУЛИРОВКИ ТЕМПЕРАТУРЫ СИСТЕМЫ ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ] 12563623 GASKET, ENG COOL THERM (ACDelco #12563623) [ПРОКЛАДКА] 12596643 ШЛАНГИ, ENG COOL THERM (ACDelco #15-80869) 11519038 БОЛТ-HFH, M6X1X30, 24 THD, 13.2 OD, 10.9, GMW3359, W/ADHESIVE ON THREADS (ENG COOL THERM HSG) [БОЛТ М6] 12590694 OUTLET, WAT (INCLS 387) (ACDelco #15-10649) 12590862 GASKET, WAT OTLT [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (WAT OTLT) 12566109 HOSE, RAD BYPASS 15024902 CЛАМПА, HOSE ПРУЖИНА, 42MM - NOM SIZE, BLK (RAD BYPASS HOSE) teamcadillac.ru 11519172 БОЛТ, HFH, 8X1.25X55, 18 OD, 22THD, 8.8, GMW3359, 6MM MATPOINT, REDUCED BODY (WAT OTLT) 12580250 DUCT, LWR INT MANIF (INCLS 526) 09359409 SENSOR, MAP (INCLS SEAL) (INCLS 741) (ACDelco #9359409) 16194007 SEAL, MAP SEN (ЧАСТЬ OF 740) [УПЛОТНИТЕЛЬ ДАТЧИКА ДАВЛЕНИЯ ПОТОКА ВОЗДУХА] 12587812 BRACKET, MAP SEN 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (MAP SEN) [БОЛТ] 12608378 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 745) (ACDelco #214-2125) 11519941 БОЛТ, HFH W/SHLDR, M6X1X22, 13.8 THD, 15 OD, 9.8, 6280M, MACH, DOG-PT (SOL VLV) 12563877 SEAL, W/PMP CVR (O RING) (ЧАСТЬ OF 360) [КОЛЬЦЕВОЕ УПЛОТНЕНИЕ ВОДЯННОГО НАСОСА] (6E00-019) - 2007-2008 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 5 КОЛЛЕКТОР & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7) ↓ 12604932 TUBE, PCV (INCLS 292) (FRESH AIR) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (PCV TUBE) 12616910 HOSE, PCV (INCLS 285, 286, 290, 291, 293) (DIRTY AIR) 12616908 SEAL, PCV HOSE FTG (O RING) (ЧАСТЬ OF 283) (BLUE) (LARGER OF THE TWO ON THE FITTING) [УПЛОТНЕНИЕ] 12616909 SEAL, PCV HOSE FTG (O RING) (ЧАСТЬ OF 283) (BLACK) (SMALLER OF THE TWO ON THE FITTING) [УЛОТНЕНИЕ] 12597853 MANIFOLD, UPR INT (MACH) (INCLS 506) 12571079 MANIFOLD, LWR INT (INCLS 519) 12567371 GROMMET, UPR INT MANIF SIGHT SHLD [ВТУЛКА] 11518906 БОЛТ, HFH, RDUCD BDY, M8X1.25X165, 22 THD, 18 O.D., 8.8, GMW3359 (INT UPR MANIF) [БОЛТ] 11519176 БОЛТ, INT MANIF (M8X1.25X80) (4.081) [БОЛТ] teamcadillac.ru 12595277 GASKET KIT, UPR INT MANIF [ПРОКЛАДКА] 12598158 GASKET KIT, INT MANIF [ПРОКЛАДКА ДВИГАТЕЛЯ] 11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (LWR INT MANIF) 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (F/INJN FUEL RL) [БОЛТ] 11609319 STUD, UPR INT MANIF SIGHT SHLD (3.671) 12576262 GASKET, EXH MANIF [ПРОКЛАДКА ВЫПУСКНОГО КОЛЛЕКТОРА] 12571102 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 12580706 SHIELD, EXH MANIF HT 24505098 БОЛТ, HFH, RND HD, 6X1X12.15, W/ANTI SEIZE, 14.2 O.D.DG PT, 10.9, 711 (EXH MANIF H/SHLD) 12582663 INSULATOR, EXH MANIF UPR 12616647 INSULATOR, EXH MANIF LWR (2.042) 12576263 GASKET, EXH MANIF 12571101 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 11518860 БОЛТ, HFH, M8X1.25X30, 20.9 THD, 18 O.D., 10.9, GMW3179 CODE G, GM6194M (EXH MANIF H/SHLD) [БОЛТ] 12617267 SHIELD, EXH MANIF HT 24505098 БОЛТ, HFH, RND HD, 6X1X12.15, W/ANTI SEIZE, 14.2 O.D.DG PT, 10.9, 711 (EXH MANIF H/SHLD) 12581807 INSULATOR, EXH MANIF LWR 14093869 ГАЙКА, PUSH ON, M6, 2.25THK, 12.95 O.D., STL, POR (EXH MANIF H/SHLD INSL) 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (EXH MANIF H/SHLD) [БОЛТ] 12604075 BODY, THROT (W/THROT ACTR) (ACDelco #217-3031) 12616994 BODY, THROT (W/THROT ACTR) (ACDelco #217-3103) [ЧАСТЬ КОРПУСА] 11519972 БОЛТ, THROT BODY (M6X1.0X50) 12593360 GASKET, THROT BODY (ACDelco #40-5083) [ПРОКЛАДКА ДРОССЕЛЬНОЙ ЗАСЛОНКИ] 12611801 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 752) (ACDelco #214-1685) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (EVAP EMIS CNSTR PURGE SOL VLV BRKT) 12584171 HOSE, EVAP EMIS CNSTR SOL VLV 12586694 VALVE, INT MANIF TUNING (INCLS 756) 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (INT MANIF TUNING VLV) [БОЛТ] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (WRG HARN BRKT) 24574534 STUD, ENG WRG HARN BRKT (M6X1X20) (1.166) (6E00-021) - 2007-2008 E INTAKE MANIFOLD SHIELD/COVERS (LY7/3.6-7) ↓ 12583604 SHIELD, UPR INT MANIF SIGHT (INCLS 2, 5, 18) [ЗАЩИТА] 12593356 CAP, OIL FIL (INCLS 4) (ЧАСТЬ OF 7) (ACDelco #FC221) [КРЫШКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ] 12593348 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 3, 7) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА] 12606862 GROMMET, UPR INT MANIF SIGHT SHLD (ЧАСТЬ OF 1) (32MM OD) 11609319 STUD, UPR INT MANIF SIGHT SHLD (3.671) 12597946 TUBE, OIL FIL (INCLS 3, 4, 8) [ТРУБКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ ГОЛОВКИ БЛОКА] 12593348 SEAL, OIL FIL TUBE (O RING) (ЧАСТЬ OF 7) (27.94MM I.D.) (SIZE #320) (1.758) [ПРОКЛАДКА] 12604673 BRACE, INT MANIF 11588723 БОЛТ, HFH, M8X1.25X25, 18 THD, 18 OD, 8.8 STL, GMW3359, M-PT (INT MANIF BR) 11518712 БОЛТ-HEX W/CON WA, M12X1.75X59, 53.6 THD, 24OD, 10.9, 7114M, MACH, 6175M, HDR (INT MANIF SIGHT SHLD) 11516075 ГАЙКА, HFH SELF LK, M6X1, 7.7THK, 14.2 O.D., 9, PZOR (ЧАСТЬ OF 14) [ГАЙКА ВЫПУСКНОЙ СИСТЕМЫ D=6ММ] 12616618 BRACKET, INT MANIF SIGHT SHLD (INCLS 13, 16) teamcadillac.ru 11588967 STUD, BALL W/HFH, M6X1X20.65, 14.2 O.D., 8.8, GMW3359 (INT MANIF BR) 12567371 GROMMET, UPR INT MANIF SIGHT SHLD [ВТУЛКА] (6M00-029) - 2006-2009 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 1 БЛОК ЦИЛИНДРОВ & ВНУТРЕННИЕ ДЕТАЛИ (LH2/4.6A) ↓ 12573430 SEAL, LWR C/CASE (4.3MM WIDE X 5MM TALL) [ПРОКЛАДКА] 11610074 БОЛТ-HFH, M8X1.25X45, 21 THD, 16 OD, 10.9 STL, GMW3359 (LWR C/CASE) 03522376 БОЛТ, HFH, M6X1X23, 18 THD, 14.50 OD, 7T, ZP (ENG OIL MANIF) 03542310 БОЛТ, LWR C/CASE (M10X1.5X125, 30 THD) (8.900) 03542311 STUD, LWR C/CASE (M10X1.5X125-M9X1.0X13) (1.428) 03530355 PIN, LWR C/CASE LOC (M8X20) 12582395 CRANKSHAFT, (MCHG) 12585420 PIN, CR/SHF SPKT LOC 89017562 BEARING KIT, CR/SHF (INCLS 123) (STD) (POSN # 1, 2, 4, 5) [ПОДШИПНИК] 89017563 BEARING KIT, CR/SHF (INCLS 900) (STD) (POSN # 3) [ПОДШИПНИК] 12568025 SEAL, CR/SHF RR OIL [ПРОКЛАДКА] 12338076 PIN, TRANSAXLE LOC (19.5 MM X 18.5 MM) (TO CYL BLK) 03525915 PIN, ENG FRT CVR LOC (DOWEL, 5.99X17.25, CHAM BOTH ENDS, 10.9) 24503702 PLUG, ENG BLK COOL HOLE (8X1.25X12, 10.5 THD W/6MM OF 6124M ADHES, 17.6 OD, 9.8, PC) 03522422 PLUG, CM/SHF (CUP, W/LIP, 50.24X6.12X1.52, 52.58 OD, 1008, OIL) 12582606 FLYКОЛЕСО, ENG 11589116 БОЛТ, FLYWHL (8.900) 12568122 COVER, FLYWHL HSG 12570154 SPROCKET, CR/SHF 12581223 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (PRIMARY) 01647264 БОЛТ, TMG CHAIN TENSR (HFH, 8X1.25X42, 22 THD, 17.0 OD, 9.8, PC, MACH) 12564274 CHAIN, CM/SHF INTER DRV 12559388 GUIDE KIT, TMG CHAIN (PRIMARY CHAIN) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 12577433 SPROCKET, CM/SHF INTER DRV SHF 01647272 БОЛТ, CM/SHF SPKT 12577790 SHAFT, CM/SHF INTER DRV 15685550 БОЛТ, CM/SHF INTER DRV SHF RET (M6X1X20) (16.330) [ВИНТ] 12556023 GUIDE, TMG CHAIN (SECONDARY CHAIN GUIDE) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 12556030 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (SECONDARY ON LH BANK) [НАТЯЖИТЕЛЬ РЕМНЯ] 01647264 БОЛТ, TMG CHAIN TENSR (HFH, 8X1.25X42, 22 THD, 17.0 OD, 9.8, PC, MACH) 12556023 GUIDE, TMG CHAIN (SECONDARY CHAIN GUIDE) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 12581281 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (SECONDARY ON RH BANK) 01647264 БОЛТ, TMG CHAIN TENSR (HFH, 8X1.25X42, 22 THD, 17.0 OD, 9.8, PC, MACH) 12567469 ROD, CONN (INCLS 201) (USES 23MM PIN) 12552947 БОЛТ, CONN ROD (ЧАСТЬ OF 200) (MJ9X1.0-4H6HX61.9 LONG) [БОЛТ] teamcadillac.ru 89017430 PISTON, (W/PIN) (INCLS 211, 212) 12584576 BALANCER, CR/SHF [ШКИВ КОЛЕНВАЛА] 11569873 БОЛТ, CR/SHF BALR (M14X1.5X48.4) 12577394 BAFFLE, МАСЛЯНЫЙ ПОДДОН (B/W CRANK CASE AND PAN) 12580429 SENSOR, CR/SHF POSN (INCLS 721) (ACDelco #213-3515) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (CR/SHF POSN SEN) 12570125 SENSOR, KNOCK (ACDelco #213-1576) 89017760 STARTER, (REMAN) (ACDelco #323-1633) (DELCO SERIES PG260H) [СТАРТЕР] 11515793 БОЛТ, HFH (STRTR) 12603426 HARNESS, CR/SHF POS SEN & KNOCK SEN WRG (INCLS 797) 12559363 BEARING KIT, CONN ROD (STD) (INCLS 203, 204) [КОМПЛЕКТ ПОДШИПНИКОВ СКОЛЬЖЕНИЯ ШАТУНА (2ШТ)] 89017413 RING KIT, PSTN (INCLS 213-216) (6M00-042) - 2007 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 5 КОЛЛЕКТОР & FUEL ДЕТАЛИ КОМПЛЕКТА (LH2/4.6A) ↓ teamcadillac.ru 12604755 TUBE, PCV (INCLS 900, 901) (FRESH AIR TUBE) 12587817 TUBE, PCV (DIRTY AIR TUBE) 12604755 TUBE, PCV (FRESH AIR TUBE) 12590694 OUTLET, WAT (INCLS 387) (ACDelco #15-10649) 12590862 GASKET, WAT OTLT [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (WAT OTLT) 12566109 HOSE, RAD BYPASS 15024902 CЛАМПА, HOSE ПРУЖИНА, 42MM - NOM SIZE, BLK (RAD BYPASS HOSE) 11519172 БОЛТ, HFH, 8X1.25X55, 18 OD, 22THD, 8.8, GMW3359, 6MM MATPOINT, REDUCED BODY (WAT OTLT) 12588847 MANIFOLD, INT (INCLS 501, 520, 903) 12571222 FITTING, P/B BOOS VAC TUBE 12579192 COVER, INT MANIF 12579193 COVER, INT MANIF 11588967 STUD, BALL W/HFH, M6X1X20.65, 14.2 O.D., 8.8, GMW3359 (IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ) 12588809 SEAL, UPR INT MANIF (ЧАСТЬ OF 500) [УПЛОТНИТЕЛЬ ВЫПУСКНОГО КОЛЛЕКТОРА] 12580250 DUCT, LWR INT MANIF (INCLS 526) 11588352 БОЛТ, INT MANIF (W/SPCR) 12557010 STUD, F/INJN FUEL RL (HEX, M6X1.022-M6X1.016, 45MM TOTAL LENGTH) (3.275) 12571212 SHIELD, UPR INT MANIF SIGHT (INCLS 595, 596) [ЗАЩИТНЫЙ КОЖУХ ДВИГАТЕЛЯ] 12600206 BRACKET, UPR INT MANIF SIGHT SHLD (INCLS 904) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (UPR INT MANIF SIGHT SHLD) 12567370 STUD, UPR INT MANIF SIGHT SHLD (3.265) 12567371 GROMMET, UPR INT MANIF SIGHT SHLD (ЧАСТЬ OF 590) [ВТУЛКА] 12607451 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 626, 906) (3.685) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 12607338 SHIELD, EXH MANIF HT 24505098 БОЛТ, HFH, RND HD, 6X1X12.15, W/ANTI SEIZE, 14.2 O.D.DG PT, 10.9, 711 (EXH MANIF H/SHLD) 12604020 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 626, 635, 636, 906) (3.685) 12607450 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 626, 635, 636, 906) (3.685) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 11517031 ГАЙКА, HFH, M8X1.25, 9.4THK, 17.4 O.D., 10, TIN ZN (EXH MANIF) 11519171 БОЛТ, EXH MANIF CLA (M8X1.25X50) (3.275) [БОЛТ ВЫПУСКНОГО КОЛЛЕКТОРА] 11562490 STUD, STRAIGHT, M8X1.25X20, M8X1.25X40, 69 TL, 9.8, GMW3179, EXT HEX SOCKET (EXH MANIF) [ШПИЛЬКА М8] 11609596 STUD, CTLTC CONV (ЧАСТЬ OF 600, 620) [ШПИЛЬКА] 12576372 SHIELD, EXH MANIF HT 24505098 БОЛТ, HFH, RND HD, 6X1X12.15, W/ANTI SEIZE, 14.2 O.D.DG PT, 10.9, 711 (EXH MANIF H/SHLD) 12568289 SHIELD, EXH MANIF LWR HT (ЧАСТЬ OF 620) 10229247 RIVET, EXH MANIF H/SHLD (ЧАСТЬ OF 620) (3.601) 12602800 BODY, THROT (W/THROT ACTR) (INCLS 702) (ACDelco #217-2892) [ДРОССЕЛЬНАЯ ЗАСЛОНКА] 11519973 БОЛТ-HFH, M6X1X60, 18MM THD, 14.2 OD, 8.8, 3359GMW, REDUCED BODY, MAT PT. (ЧАСТЬ OF 701) [БОЛТ 6Х1Х60] 12576549 GASKET, THROT BODY (ACDelco #217-1618) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ДРОССЕЛЬНОЙ ЗАСЛОНКИ] 09359409 SENSOR, MAP (INCLS SEAL) (INCLS 741) (ACDelco #9359409) 16194007 SEAL, MAP SEN (ЧАСТЬ OF 740) [УПЛОТНИТЕЛЬ ДАТЧИКА ДАВЛЕНИЯ ПОТОКА ВОЗДУХА] 12587812 BRACKET, MAP SEN 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (MAP SEN) [БОЛТ] 12608378 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 745) (ACDelco #214-2125) 11519941 БОЛТ, HFH W/SHLDR, M6X1X22, 13.8 THD, 15 OD, 9.8, 6280M, MACH, DOG-PT (EVAP EMIS CNSTR PURGE SOL) 25917777 PIPE, EVAP EMIS CNSTR PURGE (INCLS 748, 749) 12567655 GASKET, EXH MANIF [ПРОКЛАДКА] 12613200 FITTING, PCV HOSE (ЧАСТЬ OF 281) 12571223 PLUG, P/B VAC SCE HOLE (ЧАСТЬ OF 500) (16.0 MM) 19167509 INSULATOR, UPR INT MANIF CVR (ЧАСТЬ OF 591) (3.405) 12607145 SENSOR, HTD OXY (POSN 1) (IN EXH MANIFOLD/CROSSOVER) (ACDelco #213-4116) [КИСЛОРОДНЫЙ ДАТЧИК] 25709703 SEAL, CTLTC CONV (ЧАСТЬ OF 600, 620) (ROUND METAL SEAL) [ПРОКЛАДКА НАСОСА] (6M00-071) - 2007-2009 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 4 МАСЛЯНЫЙ НАСОС, PAN & ДЕТАЛИ КОМПЛЕКТА (LH2/4.6A) ↓ 12580850 MANIFOLD, ENG OIL (INCLS 107-109) (WITHOUT МАСЛЯНЫЙ ПОДДОН BAFFLE) [КОЛЛЕКТОР МАСЛЯНЫЙ] 03522376 БОЛТ, HFH, M6X1X23, 18 THD, 14.50 OD, 7T, ZP (ENG OIL MANIF) 03542310 БОЛТ, LWR C/CASE (M10X1.5X125, 30 THD) (8.900) 03542311 STUD, LWR C/CASE (M10X1.5X125-M9X1.0X13) (1.428) 12612258 PAN, OIL (INCLS 401, 412, 413, 420-422) 12568928 GASKET, МАСЛЯНЫЙ ПОДДОН (ЧАСТЬ OF 400) [ПРОКЛАДКА] 12567529 PIPE, O/PMP SUC (INCLS 406, 407) 12573569 GASKET, O/PMP SUC PIPE (ЧАСТЬ OF 405) [ПРОКЛАДКА МАСЛЯНОГО НАСОСА] 03522382 БОЛТ, O/PMP SUC PIPE (ЧАСТЬ OF 405) (HFH, M6X1.0X28) 03542258 ГАЙКА, O/PMP SUC PIPE (HFH, M9X1) (1.430) 12577394 BAFFLE, МАСЛЯНЫЙ ПОДДОН (B/W CRANK CASE AND PAN) 11562588 PLUG, МАСЛЯНЫЙ ПОДДОН DRN (ЧАСТЬ OF 400) (INCLS 413) (W/ SEAL) (EXC MAGNET) [ЗАГЛУШКА МАСЛЯНОГО ПОДДОНА] 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 400) teamcadillac.ru 11519173 БОЛТ, HFH, REDUCED BODY, M8X1.25X60, 22THD, 18 OD, 8.8, GMW3359 (ЧАСТЬ OF 400) 11519178 БОЛТ HFH, M8X1.25X100, 13MM SOCKET, 8.8, GMW3359 (ЧАСТЬ OF 400) 12585398 INDICATOR, OIL LVL (INCLS 434) [ЩУП УРОВНЯ МАСЛА] 12570585 TUBE, OIL LVL IND (INCLS 432) [НАПРАВЛЯЮЩАЯ ТРУБКА ЩУПА УРОВНЯ МАСЛА] 24504091 SEAL, OIL LVL IND TUBE (O RING) (ЧАСТЬ OF 431) (BLACK) (6.07MM ID, 1.78MM DIA) 11515765 БОЛТ, HFH, M10X1.5X25, 22.30 O.D., HDR PT, 10.9, 7112M (OIL LVL IND TUBE) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) 12598047 ADAPTER, OIL FLTR (INCLS 441, 442, 445, 446, 449, 717, 718, 728, 729) 12573045 GASKET, OIL FLTR ADAP (ЧАСТЬ OF 440) [ПРОКЛАДКА МАСЛЯНОГО ФИЛЬТРА] 11519173 БОЛТ, HFH, REDUCED BODY, M8X1.25X60, 22THD, 18 OD, 8.8, GMW3359 (ЧАСТЬ OF 440) 24575062 FITTING, OIL FLTR (ЧАСТЬ OF 440) 25014612 VALVE, OIL FLTR BYPASS (ЧАСТЬ OF 440) (W/O VAPOR SEPARATOR) (OPENING PRESSURE 21 PSI NOMINAL) (ЧАСТЬ HAS A 16.10MM MAX OD & FITS A 15.84 HOLE IN BLOCK) 89017342 ФИЛЬТР, МАСЛЯНЫЙ (ЧАСТЬ OF 440) (FOR NON-CANADIAN ORDERS) (ACDelco #89017342) 11519833 PLUG ROUND HD, M16X1.5X22, 20 OD, 10 THD, 5.8, 4345M, SEALANT 9985490, MACH (OIL FLTR BYPASS HOLE) 12590890 PUMP, OIL (INCLS 464-472) [МАСЛЯНЫЙ НАСОС] 11518944 SCREW, PAN HD, M6X1X25, 20.9 THD, 11 OD, 8.8, GMW3359, 6 LOBED T-30 M-POINT (ЧАСТЬ OF 463) (8.913) 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (O/PMP) (ACDelco #11517518) [БОЛТ] 12568009 TUBE, O/PMP OTLT (INCLS 481) [ТРУБКА] 12568320 SEAT, ENG OIL MANIF CHK VLV (ЧАСТЬ OF 480) (0.724) [КОЛЬЦЕВОЕ УПЛОТНЕНИЕ] 11518944 SCREW, PAN HD, M6X1X25, 20.9 THD, 11 OD, 8.8, GMW3359, 6 LOBED T-30 M-POINT (O/PMP OTLT TUBE) (8.913) 12573744 SHIELD, ENG OIL PRESS GA SEN HT (ЧАСТЬ OF 440) 11519964 БОЛТ, HFH, M6X1X13, 6 THD, 14.2 OD, 8.8, GMW3359, MAT POINT (ЧАСТЬ OF 440) 12567911 SENSOR, ENG OIL PRESS (ЧАСТЬ OF 440) (INCLS 729) (ACDelco #213-1547) [ДАТЧИК ДАВЛЕНИЯ МАСЛА] (6M00-073) - 2006-2009 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 4 МАСЛЯНЫЙ НАСОС,МАСЛЯНЫЙ ПОДДОН & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7) ↓ 22531637 PIN, МАСЛЯНЫЙ ПОДДОН LOC (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 12586959 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (LOWER PRIMARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ГРМ] 12586960 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАТЯЖИТЕЛЬ ЦЕПИ] 12586961 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАПРАВЛЯЮЩАЯ ПРИВОДНОЙ ЦЕПИ] 12597417 GUIDE, TMG CHAIN (UPPER PRIMARY) 12600461 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ПРИВОДА ГРМ] 12600462 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ПРИВОДА ГРМ] 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (ЧАСТЬ OF 463) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12596502 PAN, OIL (INCLS 404-407, 410, 412, 413, 420, 422, 900) 12575373 PIPE, O/PMP SUC (ЧАСТЬ OF 400) 12566837 SEAL, O/PMP SUC PIPE (ЧАСТЬ OF 400) [УПЛОТНЕНИЕ] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 400) 12566872 DEFLECTOR, CR/SHF OIL (ЧАСТЬ OF 400) 11562588 PLUG, МАСЛЯНЫЙ ПОДДОН DRN (ЧАСТЬ OF 400) (INCLS 413) (W/ SEAL) (EXC MAGNET) [ЗАГЛУШКА МАСЛЯНОГО ПОДДОНА] 12616850 SEAL, МАСЛЯНЫЙ ПОДДОН DRN PLUG (O RING) (ЧАСТЬ OF 400, 412) 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (ЧАСТЬ OF 400) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11588424 БОЛТ, HFH, M6X1X145, 18 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 400) [ШЕСТИГРАННЫЙ ВИНТ] 12595327 INDICATOR, OIL LVL (INCLS 434) 12593211 TUBE, OIL LVL IND (INCLS 432) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 431) (BLACK) (6.07MM ID, 1.78MM DIA) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (OIL LVL IND TUBE) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) 12591607 ADAPTER, OIL FLTR (INCLS 441-443, 446-450, 456, 458, 459, 728, 729) [АДАПТЕР МАСЛЯНОГО ФИЛЬТРА] 12591604 GASKET, OIL FLTR (ЧАСТЬ OF 440) (BETWEEN OIL FILTER ADAPTER AND BLOCK) [ПРОКЛАДКА МАСЛЯНОГО ФИЛЬТРА] 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 440) 11519174 БОЛТ, HFH, W/REDUCED BODY, M8X1.25X65, THD 22, O.D. 18, 8.8, GMW3359 (ЧАСТЬ OF 440) 25014612 VALVE, OIL FLTR BYPASS (ЧАСТЬ OF 440, 450) (W/O VAPOR SEPARATOR) (OPENING PRESSURE 21 PSI NOMINAL) (ЧАСТЬ HAS A 16.10MM MAX OD & FITS A 15.84 HOLE IN BLOCK) 11519184 БОЛТ, OIL FLTR ADAP (ЧАСТЬ OF 440) (M10X1.5X45) (0.029) 25177917 ФИЛЬТР, МАСЛЯНЫЙ (ЧАСТЬ OF 440) (ACDelco #PF2129) [МАСЛЯНЫЙ ФИЛЬТР ДВИГАТЕЛЯ] 12583470 CAP, OIL FLTR (ЧАСТЬ OF 440) (INCLS 446, 456) [КРЫШКА] 12577653 SEAL, OIL FLTR CAP (O RING) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КРЫШКИ МАСЛЯНОГО ФИЛЬТРА] 12590152 PUMP, OIL (INCLS 151, 154, 464-466, 468, 470-472, 474, 475) (INCLS GUIDE, БОЛТS) [МАСЛЕННЫЙ НАСОС] teamcadillac.ru 11900371 БОЛТ, HEX HD, W/1.6 FLAT WA, M8X1.25X54.3, 43 THD, 16O.D., 8.8, GMW3359 (ЧАСТЬ OF 463) 12590119 NOZZLE, PSTN OIL (INCLS 491) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 490) 12621659 SENSOR, ENG OIL PRESS (INCLS 729) (ЧАСТЬ OF 440) (ACDelco #12621659) 11588734 БОЛТ, HFH, M8X1.25X90, 21.6 THD, 18 O.D., 8.8, GMW3359 (ЧАСТЬ OF 400) [ВИНТ] (6Y00-003) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 2 ГОЛОВКА ЦИЛИНДРОВ & ДЕТАЛИ КОМПЛЕКТА (LH2/4.6A) ↓ 03522352 PIN, CYL HD LOC (HOLLOW DOWEL, 15.675X28, CHAM BOTH ENDS, SAE 12L14, ZP) 12564273 CHAIN, SECD TMG 12559389 SHOE KIT, TMG CHAIN TENSR (INCLS 174) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (ЧАСТЬ OF 173) (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 89017766 SHOE KIT, TMG CHAIN TENSR (INCLS 184) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (ЧАСТЬ OF 183) (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 12576969 VALVE, CM/SHF POSN ACTR SOL 12581497 ACTUATOR, CM/SHF POSN (EXH) 12581498 ACTUATOR, CM/SHF POSN (EXH) 12581499 ACTUATOR, CM/SHF POSN (INT) 12581500 ACTUATOR, CM/SHF POSN (INT) 12591268 COVER, CM/SHF (INCLS 251, 254-256, 261, 908, 909) 12591269 COVER, CM/SHF (INCLS 251, 254-256, 261, 908, 909) 12576394 GASKET, CM/SHF CVR (ЧАСТЬ OF 250) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ ЦИЛИНДРОВ] 12576395 GASKET, CM/SHF CVR (ЧАСТЬ OF 250) (BETWEEN HEAD AND CAM COVER) [ПРОКЛАДКА] 12576396 GASKET, CM/SHF CVR (ЧАСТЬ OF 250) (СВЕЧИ HOLES) [ПРОКЛАДКА] 12557829 БОЛТ, CM/SHF CVR (ЧАСТЬ OF 250) 12573742 INSULATOR, CM/SHF CVR БОЛТ (ЧАСТЬ OF 250) 12583570 CAP, OIL FIL (ROUND W/HDL) (INCLS 259) (NON VENTED) (ACDelco #FC215) 12593348 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 258) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА] 12581538 HEAD, CYL (MCHG) (INCLS 312, 313, 315, 334-337) 12581539 HEAD, CYL (MCHG) (INCLS 312, 313, 315, 334-337) 11569957 БОЛТ, CYL HD (M11X2X161, 60 THD) (*KIT1) 01647218 БОЛТ, CYL HD (QTY 3-RH, 3-LH) (M6X1.0X50, 10.9) (HFH, MACH) 11562126 PLUG, CYL HD CORE HOLE (ЧАСТЬ OF 300) (CUP, 32.03X7.88X1.27, S30400 SS PER SAE J405.) [ЗАГЛУШКА ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 01647543 PLUG, CYL HD CORE HOLE (ЧАСТЬ OF 300) (ROUND HEAD, INT HEX, W/ALUM WASH, 20X1.5X17, 12.25 THD, C1010 RQ) 11588949 PLUG, M16X1.5X14, 24 OD, SAE 1010 STL, GMW3044, W/ AL WASHER (ЧАСТЬ OF 300) [ПРОБКА ЗАМКА] 12574785 RESTRICTOR, ENG BLK OIL GAL 12607211 VALVE, EXH 12590223 VALVE, INT 12565203 ARM, VLV RKR [КОРОМЫСЛО КЛАПАНА ДВИГАТЕЛЯ] 24100005 ADJUSTER, HYD VLV LASH (ACDelco #24100005) [ТОЛКАТЕЛЬ КЛАПАНА ДВИГАТЕЛЯ] 12574354 SEAL, VLV STEM OIL [УПЛОТНЕНИЕ ШТОКА КЛАПАНА] 12565199 ПРУЖИНА, VLV 12580385 CAP, VLV SPR 01647209 KEY, VLV STEM 12565171 CAMSHAFT, EXH (MCHG) (INCLS 338) 12565172 CAMSHAFT, EXH (MCHG) (INCLS 338) [РАСПРЕДВАЛ В СБОРЕ] 12563833 CAMSHAFT, INL (MCHG) (INCLS 338) [РАСПРЕДВАЛ] 12565168 CAMSHAFT, INL (MCHG) (INCLS 338) [КОЛЕНВАЛ] 01647553 БОЛТ, CM/SHF BRG CAP (ЧАСТЬ OF 300) (HFH, M6X1.0X39.5) 12596360 ШЛАНГИ, CM/SHF POSN ACTR (INCLS 342, 344, 345, 735-737) 12596361 ШЛАНГИ, CM/SHF POSN ACTR (INCLS 342, 344, 345, 735-737) 12567656 GASKET, CM/SHF POSN ACTR HSG (ЧАСТЬ OF 340) (0.423) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12567657 GASKET, CM/SHF POSN ACTR HSG (ЧАСТЬ OF 340) (0.423) [УПЛОТНЕНИЕ ДВИГАТЕЛЯ] 11518706 STUD-HFH, M6X1X13.4, M6X1X40, 14.2 OD, 60 TL, 10.9, GM6280M (NON HEX CHROME) (ЧАСТЬ OF 340) (8.981) 11518707 STUD, HFH, M6X1X13 / M6X1X45, 14.2 O.D., 65 TL, 9.8, GM6280M (CM/SHF POSN ACTR HSG) 11562490 STUD, STRAIGHT, M8X1.25X20, M8X1.25X40, 69 TL, 9.8, GMW3179, EXT HEX SOCKET (EXH MANIF) [ШПИЛЬКА М8] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ) 15326386 SENSOR, ENG COOL TEMP (2-WAY MALE) (3.682) (ACDelco #213-928) [ДАТЧИК ТЕМПЕРАТУРЫ ДВИГАТЕЛЯ] 12571535 СВЕЧИ, (DO NOT CHANGE GAP) (ACDelco #41-987) (PLATINUM PLUG) [СВЕЧА ЗАЖИГАНИЯ] 12593995 SENSOR, CM/SHF POSN (INCLS 726) (ACDelco #213-3517) 01647346 БОЛТ, HFH, M6X1X17, 17THD, 14.2 O.D., 8.8, ZF (CM/SHF POSN SEN) teamcadillac.ru 12567085 MAGNET, CM/SHF POSN ACTR (INCLS 737) (ЧАСТЬ OF 340) [МАГНИТ] 11518845 SCREW PAN HD, M6X1X16, 15 THD, 12 OD, 8.8, 6280M, TORX, T30, HDR PT, W/SEALANT (ЧАСТЬ OF 340) 12567421 PLUG, CM/SHF POSN ACTR BORE (ЧАСТЬ OF 340, 735) 12581176 HARNESS, ELEK ICM WRG (INCLS 772) 11519976 БОЛТ, HFLGE, M8X1.25X20, 15.6 THD, 18 O.D., 8.8, GMW3359 (ELEK ICM WRG HARN CLIP) 11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (ЧАСТЬ OF 770) [БОЛТ М8] 11517094 SCREW, M5X.8X15.6, 10.4 THD, 10.2 OD, 6202M, 7114M, TAPER-POINT (ЧАСТЬ OF 250) (ACDelco #11517094) 89017450 GASKET KIT, CYL HD (INCLS 302, 310) (INCL GASKET AND M11X2.0 БОЛТS) [ПРОКЛАДКА ДВИГАТЕЛЯ] 89017451 GASKET KIT, CYL HD (INCLS 302, 310) (INCL GASKET AND M11X2.0 БОЛТS) [ПРОКЛАДКА ДВИГАТЕЛЯ] (GM00-387) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 1 БЛОК ЦИЛИНДРОВ И ВНУТРЕННИЕ ДЕТАЛИ (LY7/3.6-7) ↓ 12560272 БОЛТ, CR/SHF BRG CAP (M10X2X102.5, 24.5) [ВИНТ] 11518861 БОЛТ, HFH, W/REDCD BODY, M8X1.25X90, 26 THD, 18 O.D., 10.9, GM4277M (CR/SHF BRG CAP) [БОЛТ] 11609410 БОЛТ, HFH, M8X1.25X25, 10.9, GMW3179 (CR/SHF BRG CAP) (0.056) [БОЛТ] 89021297 ADHESIVE/SEALANT, THREADLOCKER HI STRENGTH 10ML ERI (CR/SHF BRG CAP) [АДГЕЗИВ] 11589000 БОЛТ, HFH, M8X1.25X50, 24 THD, 18 OD, 10.9, GMW3359, RED BODY, W/ADH (CR/SHF BRG CAP) 12557520 PLUG, ENG BLK OIL GAL (CUP-.390IN OD, .040IN THK, STEEL) 12621351 CRANKSHAFT, (****REFERENCE ONLY, DO NOT CATALOG*******) (USES BALANCER W/KEY) [КОЛЕНВАЛ] 12585420 PIN, CR/SHF SPKT LOC 11561583 PLUG, ENG BLK OIL GAL (M14X1.5X16, 22 OD) (0.253) 12566587 PLUG, ENG BLK OIL GAL 11561751 PLUG, CYL HD WAT JKT HOLE (M20X1.5X30.5) (1.531) 11569584 PLUG, ENG BLK CORE HOLE (CUP DIA 34.4MM) 12597210 PIN, TRANS LOC teamcadillac.ru 12620955 SEAL, CR/SHF RR OIL (INCLS 134) [ПРОКЛАДКА КОЛЕНВАЛА ДВИГАТЕЛЯ] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 133) 22531637 PIN, МАСЛЯНЫЙ ПОДДОН LOC (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 12570326 PIN, CYL HD LOC [ЗАГЛУШКА БЛОКА ЦИЛИНДРОВ] 12572042 PLATE, A/TRNS FLEX 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12608432 ROD, CONN (INCLS 201, 202) 11519680 БОЛТ, CONN ROD (ЧАСТЬ OF 200) (M9X1X53) [БОЛТ] 12598657 BEARING KIT, CONN ROD (UPPER) [ПОДШИПНИК СКОЛЬЖЕНИЯ ШАТУНА] 12585675 PISTON, (W/PIN) (INCLS 211, 212) (.25 O.S.) 12590866 PISTON, (W/PIN) (INCLS 211, 212) (STD) 12566186 RETAINER, PSTN PIN (ЧАСТЬ OF 210) 12597654 BALANCER, CR/SHF (DUAL BELT, W/O KEYWAY) (FOR 2ND DES SEE 12603180) 12603180 BALANCER, CR/SHF (DUAL BELT) (USES BALANCER W/KEY) (FOR 1ST DES SEE 12597654) [ШКИВ КОЛЕНВАЛА] 11569873 БОЛТ, CR/SHF BALR (M14X1.5X48.4) 12613030 SENSOR, CR/SHF POSN (INCLS 721, 722) [ДАТЧИК ПОЛОЖЕНИЯ КОЛЕНВАЛА] 11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (ЧАСТЬ OF 720) [БОЛТ] 12618603 SENSOR, KNOCK (W/O LEADS) (INCLS 724) (ACDelco #213-4335) [ДАТЧИК] 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 723) 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (EXH MANIF H/SHLD) [БОЛТ] 12610603 BEARING KIT, CR/SHF (#1, 2, 4 STD) (INCLS 122, 123) [ПОДШИПНИК СКОЛЬЖЕНИЯ КОЛЕНВАЛА] 12610604 BEARING KIT, CR/SHF (#3 STD) (INCLS 123, 124) [КОМПЛЕКТ ПОДШИПНИКОВ СКОЛЬЖЕНИЯ КОЛЕНВАЛА (3ШТ)] 12608615 RING KIT, PSTN (INCLS 213-216) (STD) (GM00-395) - 2007-2009 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 3 ПЕРЕДНЯЯ КРЫШКА И ОХЛАЖДЕНИЕ (LY7/3.6-7) ↓ 22531637 PIN, ENG FRT CVR LOC (ЧАСТЬ OF 350) (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 11519176 БОЛТ, ENG FRT CVR (ЧАСТЬ OF 350) (M8X1.25X80) (4.081) [БОЛТ] 12611883 COVER, ENG FRT (W/ W/PMP) (INCLS 132, 348, 351-354, 360-362, 725-727, 734, 900-903) [БОКОВАЯ КРЫШКА ДВИГАТЕЛЯ] 12593045 SEAL, W/PMP (ЧАСТЬ OF 350) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519171 БОЛТ, ENG FRT CVR (ЧАСТЬ OF 350) (M8X1.25X50) (3.275) [БОЛТ ВЫПУСКНОГО КОЛЛЕКТОРА] 12608750 SEAL, CR/SHF FRT OIL (ЧАСТЬ OF 350) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КОЛЕНВАЛА] 12594060 DEADENER, ENG FRT CVR (ЧАСТЬ OF 350) (BOTTOM) [ПРОКЛАДКА КРЫШКИ ДВИГАТЕЛЯ] 12618472 PUMP, WAT (W/GSKT) (INCLS 900) (ЧАСТЬ OF 350) (ACDelco #251-724) [НАСОС] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 350) 12576326 GASKET, W/PMP (ЧАСТЬ OF 350) (ACDelco #251-2048) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12574518 PULLEY, W/PMP (ADX) 11519512 БОЛТ, HFH, W/CON SPR WA, M6X1X13.4, 8.77 THD, 12.3 O.D., 8.8, GMW3359 (W/PMP PUL) teamcadillac.ru 12592527 GASKET, ENG COOL THERM HSG (*KIT1) (ACDelco #12592527) [ПРОКЛАДКА ТЕРМОСТАТА] 12620260 ШЛАНГИ, ENG COOL THERM UPR (*KIT1) 11519973 БОЛТ-HFH, M6X1X60, 18MM THD, 14.2 OD, 8.8, 3359GMW, REDUCED BODY, MAT PT. (ENG COOL THERM HSG) (*KIT1) [БОЛТ 6Х1Х60] 11519974 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3359 (ENG COOL THERM HSG) (*KIT1) [БОЛТ] 12584325 SEAL, ENG COOL THERM HSG (O RING) (*KIT1) [КОЛЬЦЕ-ОБРАЗНОЕ УПЛОТНЕНИЕ] 12582472 SEAL, ENG COOL THERM (*KIT1) (ACDelco #12582472) [УПЛОТНИТЕЛЬ] 12566429 SEAL, WAT OTLT (ЧАСТЬ OF 380) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12584040 SEAL, CLNT OTLT (O RING) (ЧАСТЬ OF 380) (ACDelco #15-32584) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519974 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 380) [БОЛТ] 12573984 OUTLET, WAT (INCLS 377-379, 905) (INCLS БОЛТS, RETAINERS, SEALS & PIPE) (ACDelco #15-10429) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 12608424 SENSOR, CM/SHF POSN (INCLS 726, 727) (ЧАСТЬ OF 350) (ACDelco #12608424) [ДАТЧИК ПОЛОЖЕНИЯ РАСПРЕДВАЛА] 11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (ЧАСТЬ OF 350, 725) [БОЛТ] 12615613 VALVE, CM/SHF POSN ACTR SOL 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (CM/SHF POSN ACTR SOL VLV) 12593717 SEAL, CM/SHF POSN ACTR SOL VLV (O RING) (ЧАСТЬ OF 350) 12620259 ШЛАНГИ, ENG COOL THERM (INCLS 365-368, 370-373) (INCLS THERMOSTAT) [КОРПУС В СБОРЕ, ТЕРМОСТАТА СИСТЕМЫ ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ] 12620262 ШЛАНГИ, ENG COOL THERM (INCLS 365-368, 370-373) (GM00-396) - 2007-2009 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 2 ГОЛОВКА ЦИЛИНДРОВ & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7) ↓ 12570326 PIN, CYL HD LOC [ЗАГЛУШКА БЛОКА ЦИЛИНДРОВ] 12606653 ACTUATOR, CM/SHF POSN (USE WASHER 12630941) 12603744 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) 12603745 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) 11588279 БОЛТ, HFH, M10X1.5X80, 26 THD, 22.3 O.D., 10.9, GM4277M (CM/SHF POSN) 12626055 COVER, CM/SHF (INCLS 251, 254-257, 260, 263) [КЛАПАННАЯ КРЫШКА ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12591200 SEAL, CM/SHF CVR (ЧАСТЬ OF 250) (*KIT1) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12626054 COVER, CM/SHF (INCLS 253-257, 261) [КРЫШКА] 12591203 SEAL, CM/SHF CVR (ЧАСТЬ OF 252) (*KIT1) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12607600 SEAL, SPLG SHLD (ЧАСТЬ OF 250, 252) (*KIT1) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО СИСТЕМЫ ЗАЖИГАНИЯ] 11518859 БОЛТ, HFH W/SHLDR, M6X1X35, 11.85 THD, 18 O.D., 8.8, GMW3359 (ЧАСТЬ OF 250, 252) 12566250 INSULATOR, CM/SHF CVR БОЛТ (ЧАСТЬ OF 250, 252) 12593356 CAP, OIL FIL (INCLS 904) (ACDelco #FC221) [КРЫШКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ] 12593348 SEAL, OIL FIL TUBE (O RING) (ЧАСТЬ OF 262) (27.94MM I.D.) (SIZE #320) (1.758) [ПРОКЛАДКА] 12578316 FITTING, PCV (ЧАСТЬ OF 250) (INCLS 263) 12583384 FITTING, PCV (ЧАСТЬ OF 252) 12597946 TUBE, OIL FIL (INCLS 259) [ТРУБКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ ГОЛОВКИ БЛОКА] 12616908 SEAL, PCV HOSE FTG (O RING) (ЧАСТЬ OF 250, 260) (BLUE) (LARGER OF THE TWO ON THE FITTING) [УПЛОТНЕНИЕ] 12616909 SEAL, PCV HOSE FTG (O RING) (ЧАСТЬ OF 250, 260) (BLACK) (SMALLER OF THE TWO ON THE FITTING) [УЛОТНЕНИЕ] 12601744 INSULATOR, CM/SHF HSG CVR (0.413) 12601745 INSULATOR, CM/SHF HSG CVR [НАКЛАДКА КЛАПАННОЙ КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12603904 HEAD, CYL (MCHG) (INCLS 313, 318, 319, 328, 336, 337) (DOES NOT INCL ENG OIL MANIF CHECK VALVES. DLR MUST INSTL) 12603901 HEAD, CYL (MCHG) (INCLS 313, 318, 319, 328, 336, 337) (DOES NOT INCL ENG OIL MANIF CHECK VALVES. DLR MUST INSTL) 11518863 БОЛТ, CYL HD (M11X2X152) [БОЛТ] 11588734 БОЛТ, HFH, M8X1.25X90, 21.6 THD, 18 O.D., 8.8, GMW3359 (CYL HD) [ВИНТ] 12565988 PLUG - M20X1.5X30.5, 8.8, GMW3044, SEALANT PER GM9985490 (ЧАСТЬ OF 300, 301) 11562127 PLUG, CYL HD OIL GAL (ЧАСТЬ OF 300, 301) (CUP-14.22 OD, 6.6 THK, 304SS) 12575354 VALVE, EXH (STD) [КЛАПАН ВЫПУСКНОЙ] 12584760 VALVE, EXH (0.075 O.S.) [КЛАПАН ВЫПУСКНОЙ] 12575351 VALVE, INT (STD) [КЛАПАН ВПУСКНОЙ] 12584763 VALVE, INT (0.075MM O.S.) (0.297) [КЛАПАН ВПУСКНОЙ] teamcadillac.ru 24100294 ARM, VLV RKR [РЫЧАГ] 24100005 ADJUSTER, HYD VLV LASH (ACDelco #24100005) [ТОЛКАТЕЛЬ КЛАПАНА ДВИГАТЕЛЯ] 12565836 SEAL, VLV STEM OIL [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КЛАПАНА ДВИГАТЕЛЯ] 12575355 ПРУЖИНА, VLV [ПРУЖИНА КЛАПАНА] 12575196 RETAINER, VLV SPR [КОМПАКТ ДИСК] 12575197 KEY, VLV STEM [КЛАПАННЫЙ КЛЮЧ] 12574477 RING, CM/SHF SPKT OIL SEAL (ЧАСТЬ OF 330-333) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО РАСПРЕДВАЛА ДВИГАТЕЛЯ (2 ШТ.)] 12632192 CAMSHAFT, EXH (INCLS 329) 12609250 CAMSHAFT, INT (INCLS 329) [РАСПРЕДВАЛ ДВИГАТЕЛЯ] 12632193 CAMSHAFT, INT (INCLS 329) 12620457 CAMSHAFT, EXH (INCLS 329) 12632194 CAMSHAFT, EXH (INCLS 329) 12609252 CAMSHAFT, INT (INCLS 329) [РАСПРЕДВАЛ ДВИГАТЕЛЯ] 12632195 CAMSHAFT, INT (INCLS 329) 11518856 HFH, M6X1X43.4, 14.8 THD, 11 O.D., 8.8, GMW3179 CODE G (ЧАСТЬ OF 300, 301) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12618542 РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ, IGN (INCLS 705) (ACDelco #D508C) 11588715 БОЛТ, HFH, M6X1X35, 18 THD, 14.2 OD, 8.8, GMW3359, 5MM M POINT (ЧАСТЬ OF 704) [БОЛТ] 12566778 SENSOR, ENG COOL TEMP (3.682) (ACDelco #213-1581) [СЕНСОР ТЕМПЕРАТУРЫ] 12597464 СВЕЧИ, (DO NOT CHANGE СВЕЧИ GAP) (ACDelco #41-990) (PLATINUM PLUG) [СВЕЧА ЗАЖИГАНИЯ] 12580965 VALVE, ENG OIL MANIF CHK [КЛАПАН] 12593348 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 258) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА] 12625785 GASKET KIT, CYL HD (INCLS 251, 253, 254, 302, 303) [КОМПЛЕКТ ПРОКЛАДОК ГОЛОВКИ БЛОКА ЦИЛИНДРОВ (РЕЗ-7, МЕТ-8, ПАР-2)] (GM00-550) - 2007-2009 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 6 ЦЕПЬ И НАТЯЖИТЕЛЬ (LY7/3.6-7) ↓ 12590921 SPROCKET, CR/SHF (STAMPED 12590921) (FOR 2ND DES SEE 12599721) [ЦЕПНАЯ ЗВЕЗДОЧКА] 12599721 SPROCKET, CR/SHF (STAMPED 12599721) (FOR 1ST DES SEE 12590921) [ШЕСТЕРНЯ РАСПРЕДВАЛА] 12586959 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (LOWER PRIMARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ГРМ] 12609262 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (INCLS 153, 164) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 152) [БОЛТ М8] 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (TMG CHAIN GDE) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12616609 CHAIN, CM/SHF INTER DRV (PRIMARY) [ЦЕПЬ ПРИВОДА ГРМ] 12597417 GUIDE, TMG CHAIN (INCLS 157) (UPPER PRIMARY) teamcadillac.ru 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 156) [БОЛТ М8] 11588252 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3179 CODE G (ЧАСТЬ OF 165, 166) 12589477 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 152) (PRIMARY) 12612839 SPROCKET, TMG CHAIN IDLER (INCLS 161) (0.736) [ЗВЕЗДОЧКА РАСПРЕДВАЛА] 12612838 SPROCKET, TMG CHAIN IDLER (INCLS 161) (0.736) [ШЕСТЕРНЯ РАСПРЕДВАЛА] 12616608 CHAIN, CM/SHF INTER DRV (SECONDARY) [ЦЕПЬ ПРИВОДА ГРМ] 12600461 GUIDE, TMG CHAIN (INCLS 172) (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ПРИВОДА ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 171) [БОЛТ М8] 12586960 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАТЯЖИТЕЛЬ ЦЕПИ] 11518858 БОЛТ, HFH, M8X1.25X43, 16 THD, 18 O.D., 8.8, GMW3179 (TMG CHAIN TENSR) [БОЛТ М8] 12609260 РОЛИК НАТЯЖИТЕЛЬ, TMG CHAIN (INCLS 176, 177) (SECONDARY) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 175) [БОЛТ М8] 12589478 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 175) 12586961 GUIDE, TMG CHAIN (INCLS 182) (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАПРАВЛЯЮЩАЯ ПРИВОДНОЙ ЦЕПИ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 181) [БОЛТ М8] 12600462 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ПРИВОДА ГРМ] 11518858 БОЛТ, HFH, M8X1.25X43, 16 THD, 18 O.D., 8.8, GMW3179 (TMG CHAIN TENSR) [БОЛТ М8] 12609258 РОЛИК НАТЯЖИТЕЛЬ, TMG CHAIN (INCLS 186, 187) (SECONDARY) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 185) [БОЛТ М8] 12589479 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 185) 12606653 ACTUATOR, CM/SHF POSN (EXH) (USE WASHER 12630941) 12603744 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) (5 SCREWS ON BACKPLATE) 12603745 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) (5 SCREWS ON BACKPLATE) 11588279 БОЛТ, HFH, M10X1.5X80, 26 THD, 22.3 O.D., 10.9, GM4277M (CM/SHF POSN ACTR) 12630941 WASHER, CM/SHF THR (USED ON ACTUATORS 12603744-745, 12606653 & 12630916-918) (**FIELD FIX ONLY, DO NOT CATALOG**) [УПОРНАЯ ШАЙБА РАСПРЕДЕЛИТЕЛЬНОГО ВАЛА ДВС] 00 - 8-МИ ЦИЛИНДРОВЫЙ ДВИГАТЕЛЬ ↓ (6D00-036) - 2007-2008 E КРЕПЛЕНИЕ ДВИГАТЕЛЯ TO ТРАНСМИССИЯ (LH2/4.6A) ↓ 12582606 FLYКОЛЕСО, ENG 15813405 BRACKET, ENG WRG HARN (IP INLINE) 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] 24205900 PLUG, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] 24205899 PLUG, T/CV HSG ACC HOLE (28MM W/3 TANGS) (SMALL CVR) (ACDelco #24205899) 11589116 БОЛТ, FLYWHL (8.900) 12568122 COVER, FLYWHL HSG 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) teamcadillac.ru 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (TRANS CONV CVR) (ACDelco #11517518) [БОЛТ] 12568123 COVER, TRANS CONV (6D00-040) - 2007-2009 E ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ-V8 (LH2/4.6A) ↓ 25716470 BRACKET, ENG MT 25762621 BRACKET, ENG MT 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (ENG MT BRKT) [БОЛТ, М10Х1.5Х30] 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT) [ГАЙКА М12] 25971085 MOUNT, ENG [ШАРНИР ДВИГАТЕЛЯ] 25971087 MOUNT, ENG 25971086 MOUNT, ENG [ОПОРНЫЙ УЗЕЛ ДВИГАТЕЛЯ] 25762620 BRACKET, ENG MT 25892303 MOUNT, TRANS RR 25892306 MOUNT, TRANS RR teamcadillac.ru 11589169 БОЛТ ASM - HEX HD W/CONICAL WASHER, M10X1.50X50, GMW25 (10.9) STL, GMW33559 (TRANS RR MT BRKT) 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (TRANS MT) [БОЛТ, М10Х1.5Х30] 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT FRM SI) [ГАЙКА М12] (6E00-005) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ & ЧАСТЬIAL ДВИГАТЕЛЬ (LH2/4.6A) ↓ 19177068 ДВИГАТЕЛЬ, GASOLINE (GOODWRENCH NEW) (FOR 07 STS, SWP OIL FILT ADAPT, ENG OIL CLR FRM ORIG ENG.06 & PREV STS/SRX/XLR SWP МАСЛЯНЫЙ ПОДДОН, ENG OIL CLR IF APPL, WTR OTLT ASM, CAM ACTUATOR FRM ORIG) (ENG.05 & PREV STS/SRX/XLR SWP CAM CVRS & PVC TBE F (6E00-013) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ & ЧАСТЬIAL ДВИГАТЕЛЬ (LY7/3.6-7) ↓ 12617625 ДВИГАТЕЛЬ KIT, GASOLINE (GOODWRENCH) (MUST SWAP OIL FILL TUBE) teamcadillac.ru 19206165 ДВИГАТЕЛЬ, (SERV ЧАСТЬIAL) (MAY NEED TO SWAP МАСЛЯНЫЙ ПОДДОН) (REQUIRES CRANKSHAFT BALANCER WITH KEYWAY. FOR SINGLE BELT, USE 12603181. FOR DUAL BELT BALANCER USE 12603180) (6E00-014) - 2004-2009 E КРЕПЛЕНИЕ ДВИГАТЕЛЯ TO ТРАНСМИССИЯ (LY7/3.6-7) ↓ 12572042 PLATE, A/TRNS FLEX 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] teamcadillac.ru 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (TRANS CONV CVR) [БОЛТ] 24222918 COVER, TRANS CONV 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] (6E00-015) - 2004-2009 E ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ-V6 (LY7/3.6-7, M82) ↓ 25892303 MOUNT, TRANS RR 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (TRANS MT) [БОЛТ, М10Х1.5Х30] 11517383 БОЛТ, HEX W/CON SPR WASH, M10X1.5X55, 28 OD, 37 THD, 10.9, 7114M (TRANS RR MT BRKT) 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT) [ГАЙКА М12] 25756321 BRACKET, ENG MT 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (ENG MT BRKT) [БОЛТ, М10Х1.5Х30] 25971088 MOUNT, ENG [ОПОРНЫЙ УЗЕЛ ДВИГАТЕЛЯ] 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT FRM SI) [ГАЙКА М12] 25971089 MOUNT, ENG 25756322 BRACKET, ENG MT (6E00-016) - 2004-2009 E ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ-V6 (LY7/3.6-7, MX5) ↓ 25892306 MOUNT, TRANS RR 11515775 БОЛТ, HFH, M12X1.75X30, 10.9, 7114M (TRANS MT) [БОЛТ] 11517383 БОЛТ, HEX W/CON SPR WASH, M10X1.5X55, 28 OD, 37 THD, 10.9, 7114M (TRANS RR MT BRKT) 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT) [ГАЙКА М12] 25756321 BRACKET, ENG MT 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (ENG MT BRKT) [БОЛТ, М10Х1.5Х30] 25971088 MOUNT, ENG [ОПОРНЫЙ УЗЕЛ ДВИГАТЕЛЯ] 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT FRM SI) [ГАЙКА М12] teamcadillac.ru 25971085 MOUNT, ENG [ШАРНИР ДВИГАТЕЛЯ] 25756320 BRACKET, ENG MT (6E00-017) - 2007-2009 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 3 ПЕРЕДНЯЯ КРЫШКА И ОХЛАЖДЕНИЕ (LH2/4.6A) ↓ 03525915 PIN, ENG FRT CVR LOC (DOWEL, 5.99X17.25, CHAM BOTH ENDS, 10.9) 89017798 COVER, ENG FRT (INCLS 353) 12593627 GASKET, ENG FRT CVR [ПРОКЛАДКА ПЕРЕДНЕЙ КРЫШКИ ДВИГАТЕЛЯ] teamcadillac.ru 11519038 БОЛТ-HFH, M6X1X30, 24 THD, 13.2 OD, 10.9, GMW3359, W/ADHESIVE ON THREADS (ENG FRT CVR) [БОЛТ М6] 12569545 PLUG, ENG FRT CVR HOLE 12595614 PUMP, WAT (INCLS 901) (ACDelco #251-699) [НАСОС ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519038 БОЛТ-HFH, M6X1X30, 24 THD, 13.2 OD, 10.9, GMW3359, W/ADHESIVE ON THREADS (W/PMP) [БОЛТ М6] 12604614 PULLEY, W/PMP 24503961 БОЛТ, W/PMP PUL (M6X1.0 6G THD W/WA) (8MM SOCKET HD) 12559807 THERMOSTAT, ENG COOL (W/O GSKT) (ACDelco #131-128) [КЛАПАН РЕГУЛИРОВКИ ТЕМПЕРАТУРЫ СИСТЕМЫ ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ] 12563623 GASKET, ENG COOL THERM (ACDelco #12563623) [ПРОКЛАДКА] 12596643 ШЛАНГИ, ENG COOL THERM (ACDelco #15-80869) 11519038 БОЛТ-HFH, M6X1X30, 24 THD, 13.2 OD, 10.9, GMW3359, W/ADHESIVE ON THREADS (ENG COOL THERM HSG) [БОЛТ М6] 12590694 OUTLET, WAT (INCLS 387) (ACDelco #15-10649) 12590862 GASKET, WAT OTLT [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (WAT OTLT) 12566109 HOSE, RAD BYPASS 15024902 CЛАМПА, HOSE ПРУЖИНА, 42MM - NOM SIZE, BLK (RAD BYPASS HOSE) 11519172 БОЛТ, HFH, 8X1.25X55, 18 OD, 22THD, 8.8, GMW3359, 6MM MATPOINT, REDUCED BODY (WAT OTLT) 12580250 DUCT, LWR INT MANIF (INCLS 526) 09359409 SENSOR, MAP (INCLS SEAL) (INCLS 741) (ACDelco #9359409) 16194007 SEAL, MAP SEN (ЧАСТЬ OF 740) [УПЛОТНИТЕЛЬ ДАТЧИКА ДАВЛЕНИЯ ПОТОКА ВОЗДУХА] 12587812 BRACKET, MAP SEN 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (MAP SEN) [БОЛТ] 12608378 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 745) (ACDelco #214-2125) 11519941 БОЛТ, HFH W/SHLDR, M6X1X22, 13.8 THD, 15 OD, 9.8, 6280M, MACH, DOG-PT (SOL VLV) 12563877 SEAL, W/PMP CVR (O RING) (ЧАСТЬ OF 360) [КОЛЬЦЕВОЕ УПЛОТНЕНИЕ ВОДЯННОГО НАСОСА] (6E00-019) - 2007-2008 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 5 КОЛЛЕКТОР & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7) ↓ 12604932 TUBE, PCV (INCLS 292) (FRESH AIR) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (PCV TUBE) 12616910 HOSE, PCV (INCLS 285, 286, 290, 291, 293) (DIRTY AIR) 12616908 SEAL, PCV HOSE FTG (O RING) (ЧАСТЬ OF 283) (BLUE) (LARGER OF THE TWO ON THE FITTING) [УПЛОТНЕНИЕ] 12616909 SEAL, PCV HOSE FTG (O RING) (ЧАСТЬ OF 283) (BLACK) (SMALLER OF THE TWO ON THE FITTING) [УЛОТНЕНИЕ] 12597853 MANIFOLD, UPR INT (MACH) (INCLS 506) 12571079 MANIFOLD, LWR INT (INCLS 519) 12567371 GROMMET, UPR INT MANIF SIGHT SHLD [ВТУЛКА] 11518906 БОЛТ, HFH, RDUCD BDY, M8X1.25X165, 22 THD, 18 O.D., 8.8, GMW3359 (INT UPR MANIF) [БОЛТ] 11519176 БОЛТ, INT MANIF (M8X1.25X80) (4.081) [БОЛТ] 12595277 GASKET KIT, UPR INT MANIF [ПРОКЛАДКА] 12598158 GASKET KIT, INT MANIF [ПРОКЛАДКА ДВИГАТЕЛЯ] 11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (LWR INT MANIF) teamcadillac.ru 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (F/INJN FUEL RL) [БОЛТ] 11609319 STUD, UPR INT MANIF SIGHT SHLD (3.671) 12576262 GASKET, EXH MANIF [ПРОКЛАДКА ВЫПУСКНОГО КОЛЛЕКТОРА] 12571102 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 12580706 SHIELD, EXH MANIF HT 24505098 БОЛТ, HFH, RND HD, 6X1X12.15, W/ANTI SEIZE, 14.2 O.D.DG PT, 10.9, 711 (EXH MANIF H/SHLD) 12582663 INSULATOR, EXH MANIF UPR 12616647 INSULATOR, EXH MANIF LWR (2.042) 12576263 GASKET, EXH MANIF 12571101 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 11518860 БОЛТ, HFH, M8X1.25X30, 20.9 THD, 18 O.D., 10.9, GMW3179 CODE G, GM6194M (EXH MANIF H/SHLD) [БОЛТ] 12617267 SHIELD, EXH MANIF HT 24505098 БОЛТ, HFH, RND HD, 6X1X12.15, W/ANTI SEIZE, 14.2 O.D.DG PT, 10.9, 711 (EXH MANIF H/SHLD) 12581807 INSULATOR, EXH MANIF LWR 14093869 ГАЙКА, PUSH ON, M6, 2.25THK, 12.95 O.D., STL, POR (EXH MANIF H/SHLD INSL) 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (EXH MANIF H/SHLD) [БОЛТ] 12604075 BODY, THROT (W/THROT ACTR) (ACDelco #217-3031) 12616994 BODY, THROT (W/THROT ACTR) (ACDelco #217-3103) [ЧАСТЬ КОРПУСА] 11519972 БОЛТ, THROT BODY (M6X1.0X50) 12593360 GASKET, THROT BODY (ACDelco #40-5083) [ПРОКЛАДКА ДРОССЕЛЬНОЙ ЗАСЛОНКИ] 12611801 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 752) (ACDelco #214-1685) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (EVAP EMIS CNSTR PURGE SOL VLV BRKT) 12584171 HOSE, EVAP EMIS CNSTR SOL VLV 12586694 VALVE, INT MANIF TUNING (INCLS 756) 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (INT MANIF TUNING VLV) [БОЛТ] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (WRG HARN BRKT) 24574534 STUD, ENG WRG HARN BRKT (M6X1X20) (1.166) (6E00-021) - 2007-2008 E INTAKE MANIFOLD SHIELD/COVERS (LY7/3.6-7) ↓ 12583604 SHIELD, UPR INT MANIF SIGHT (INCLS 2, 5, 18) [ЗАЩИТА] 12593356 CAP, OIL FIL (INCLS 4) (ЧАСТЬ OF 7) (ACDelco #FC221) [КРЫШКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ] 12593348 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 3, 7) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА] 12606862 GROMMET, UPR INT MANIF SIGHT SHLD (ЧАСТЬ OF 1) (32MM OD) 11609319 STUD, UPR INT MANIF SIGHT SHLD (3.671) 12597946 TUBE, OIL FIL (INCLS 3, 4, 8) [ТРУБКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ ГОЛОВКИ БЛОКА] 12593348 SEAL, OIL FIL TUBE (O RING) (ЧАСТЬ OF 7) (27.94MM I.D.) (SIZE #320) (1.758) [ПРОКЛАДКА] 12604673 BRACE, INT MANIF 11588723 БОЛТ, HFH, M8X1.25X25, 18 THD, 18 OD, 8.8 STL, GMW3359, M-PT (INT MANIF BR) 11518712 БОЛТ-HEX W/CON WA, M12X1.75X59, 53.6 THD, 24OD, 10.9, 7114M, MACH, 6175M, HDR (INT MANIF SIGHT SHLD) 11516075 ГАЙКА, HFH SELF LK, M6X1, 7.7THK, 14.2 O.D., 9, PZOR (ЧАСТЬ OF 14) [ГАЙКА ВЫПУСКНОЙ СИСТЕМЫ D=6ММ] 12616618 BRACKET, INT MANIF SIGHT SHLD (INCLS 13, 16) 11588967 STUD, BALL W/HFH, M6X1X20.65, 14.2 O.D., 8.8, GMW3359 (INT MANIF BR) teamcadillac.ru 12567371 GROMMET, UPR INT MANIF SIGHT SHLD [ВТУЛКА] (6M00-029) - 2006-2009 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 1 БЛОК ЦИЛИНДРОВ & ВНУТРЕННИЕ ДЕТАЛИ (LH2/4.6A) ↓ 12573430 SEAL, LWR C/CASE (4.3MM WIDE X 5MM TALL) [ПРОКЛАДКА] 11610074 БОЛТ-HFH, M8X1.25X45, 21 THD, 16 OD, 10.9 STL, GMW3359 (LWR C/CASE) 03522376 БОЛТ, HFH, M6X1X23, 18 THD, 14.50 OD, 7T, ZP (ENG OIL MANIF) 03542310 БОЛТ, LWR C/CASE (M10X1.5X125, 30 THD) (8.900) 03542311 STUD, LWR C/CASE (M10X1.5X125-M9X1.0X13) (1.428) 03530355 PIN, LWR C/CASE LOC (M8X20) 12582395 CRANKSHAFT, (MCHG) 12585420 PIN, CR/SHF SPKT LOC 89017562 BEARING KIT, CR/SHF (INCLS 123) (STD) (POSN # 1, 2, 4, 5) [ПОДШИПНИК] teamcadillac.ru 89017563 BEARING KIT, CR/SHF (INCLS 900) (STD) (POSN # 3) [ПОДШИПНИК] 12568025 SEAL, CR/SHF RR OIL [ПРОКЛАДКА] 12338076 PIN, TRANSAXLE LOC (19.5 MM X 18.5 MM) (TO CYL BLK) 03525915 PIN, ENG FRT CVR LOC (DOWEL, 5.99X17.25, CHAM BOTH ENDS, 10.9) 24503702 PLUG, ENG BLK COOL HOLE (8X1.25X12, 10.5 THD W/6MM OF 6124M ADHES, 17.6 OD, 9.8, PC) 03522422 PLUG, CM/SHF (CUP, W/LIP, 50.24X6.12X1.52, 52.58 OD, 1008, OIL) 12582606 FLYКОЛЕСО, ENG 11589116 БОЛТ, FLYWHL (8.900) 12568122 COVER, FLYWHL HSG 12570154 SPROCKET, CR/SHF 12581223 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (PRIMARY) 01647264 БОЛТ, TMG CHAIN TENSR (HFH, 8X1.25X42, 22 THD, 17.0 OD, 9.8, PC, MACH) 12564274 CHAIN, CM/SHF INTER DRV 12559388 GUIDE KIT, TMG CHAIN (PRIMARY CHAIN) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 12577433 SPROCKET, CM/SHF INTER DRV SHF 01647272 БОЛТ, CM/SHF SPKT 12577790 SHAFT, CM/SHF INTER DRV 15685550 БОЛТ, CM/SHF INTER DRV SHF RET (M6X1X20) (16.330) [ВИНТ] 12556023 GUIDE, TMG CHAIN (SECONDARY CHAIN GUIDE) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 12556030 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (SECONDARY ON LH BANK) [НАТЯЖИТЕЛЬ РЕМНЯ] 01647264 БОЛТ, TMG CHAIN TENSR (HFH, 8X1.25X42, 22 THD, 17.0 OD, 9.8, PC, MACH) 12556023 GUIDE, TMG CHAIN (SECONDARY CHAIN GUIDE) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 12581281 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (SECONDARY ON RH BANK) 01647264 БОЛТ, TMG CHAIN TENSR (HFH, 8X1.25X42, 22 THD, 17.0 OD, 9.8, PC, MACH) 12567469 ROD, CONN (INCLS 201) (USES 23MM PIN) 12552947 БОЛТ, CONN ROD (ЧАСТЬ OF 200) (MJ9X1.0-4H6HX61.9 LONG) [БОЛТ] 89017430 PISTON, (W/PIN) (INCLS 211, 212) 12584576 BALANCER, CR/SHF [ШКИВ КОЛЕНВАЛА] 11569873 БОЛТ, CR/SHF BALR (M14X1.5X48.4) 12577394 BAFFLE, МАСЛЯНЫЙ ПОДДОН (B/W CRANK CASE AND PAN) 12580429 SENSOR, CR/SHF POSN (INCLS 721) (ACDelco #213-3515) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (CR/SHF POSN SEN) 12570125 SENSOR, KNOCK (ACDelco #213-1576) 89017760 STARTER, (REMAN) (ACDelco #323-1633) (DELCO SERIES PG260H) [СТАРТЕР] 11515793 БОЛТ, HFH (STRTR) 12603426 HARNESS, CR/SHF POS SEN & KNOCK SEN WRG (INCLS 797) 12559363 BEARING KIT, CONN ROD (STD) (INCLS 203, 204) [КОМПЛЕКТ ПОДШИПНИКОВ СКОЛЬЖЕНИЯ ШАТУНА (2ШТ)] 89017413 RING KIT, PSTN (INCLS 213-216) (6M00-042) - 2007 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 5 КОЛЛЕКТОР & FUEL ДЕТАЛИ КОМПЛЕКТА (LH2/4.6A) ↓ 12604755 TUBE, PCV (INCLS 900, 901) (FRESH AIR TUBE) 12587817 TUBE, PCV (DIRTY AIR TUBE) teamcadillac.ru 12604755 TUBE, PCV (FRESH AIR TUBE) 12590694 OUTLET, WAT (INCLS 387) (ACDelco #15-10649) 12590862 GASKET, WAT OTLT [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (WAT OTLT) 12566109 HOSE, RAD BYPASS 15024902 CЛАМПА, HOSE ПРУЖИНА, 42MM - NOM SIZE, BLK (RAD BYPASS HOSE) 11519172 БОЛТ, HFH, 8X1.25X55, 18 OD, 22THD, 8.8, GMW3359, 6MM MATPOINT, REDUCED BODY (WAT OTLT) 12588847 MANIFOLD, INT (INCLS 501, 520, 903) 12571222 FITTING, P/B BOOS VAC TUBE 12579192 COVER, INT MANIF 12579193 COVER, INT MANIF 11588967 STUD, BALL W/HFH, M6X1X20.65, 14.2 O.D., 8.8, GMW3359 (IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ) 12588809 SEAL, UPR INT MANIF (ЧАСТЬ OF 500) [УПЛОТНИТЕЛЬ ВЫПУСКНОГО КОЛЛЕКТОРА] 12580250 DUCT, LWR INT MANIF (INCLS 526) 11588352 БОЛТ, INT MANIF (W/SPCR) 12557010 STUD, F/INJN FUEL RL (HEX, M6X1.022-M6X1.016, 45MM TOTAL LENGTH) (3.275) 12571212 SHIELD, UPR INT MANIF SIGHT (INCLS 595, 596) [ЗАЩИТНЫЙ КОЖУХ ДВИГАТЕЛЯ] 12600206 BRACKET, UPR INT MANIF SIGHT SHLD (INCLS 904) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (UPR INT MANIF SIGHT SHLD) 12567370 STUD, UPR INT MANIF SIGHT SHLD (3.265) 12567371 GROMMET, UPR INT MANIF SIGHT SHLD (ЧАСТЬ OF 590) [ВТУЛКА] 12607451 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 626, 906) (3.685) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 12607338 SHIELD, EXH MANIF HT 24505098 БОЛТ, HFH, RND HD, 6X1X12.15, W/ANTI SEIZE, 14.2 O.D.DG PT, 10.9, 711 (EXH MANIF H/SHLD) 12604020 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 626, 635, 636, 906) (3.685) 12607450 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 626, 635, 636, 906) (3.685) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 11517031 ГАЙКА, HFH, M8X1.25, 9.4THK, 17.4 O.D., 10, TIN ZN (EXH MANIF) 11519171 БОЛТ, EXH MANIF CLA (M8X1.25X50) (3.275) [БОЛТ ВЫПУСКНОГО КОЛЛЕКТОРА] 11562490 STUD, STRAIGHT, M8X1.25X20, M8X1.25X40, 69 TL, 9.8, GMW3179, EXT HEX SOCKET (EXH MANIF) [ШПИЛЬКА М8] 11609596 STUD, CTLTC CONV (ЧАСТЬ OF 600, 620) [ШПИЛЬКА] 12576372 SHIELD, EXH MANIF HT 24505098 БОЛТ, HFH, RND HD, 6X1X12.15, W/ANTI SEIZE, 14.2 O.D.DG PT, 10.9, 711 (EXH MANIF H/SHLD) 12568289 SHIELD, EXH MANIF LWR HT (ЧАСТЬ OF 620) 10229247 RIVET, EXH MANIF H/SHLD (ЧАСТЬ OF 620) (3.601) 12602800 BODY, THROT (W/THROT ACTR) (INCLS 702) (ACDelco #217-2892) [ДРОССЕЛЬНАЯ ЗАСЛОНКА] 11519973 БОЛТ-HFH, M6X1X60, 18MM THD, 14.2 OD, 8.8, 3359GMW, REDUCED BODY, MAT PT. (ЧАСТЬ OF 701) [БОЛТ 6Х1Х60] 12576549 GASKET, THROT BODY (ACDelco #217-1618) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ДРОССЕЛЬНОЙ ЗАСЛОНКИ] 09359409 SENSOR, MAP (INCLS SEAL) (INCLS 741) (ACDelco #9359409) 16194007 SEAL, MAP SEN (ЧАСТЬ OF 740) [УПЛОТНИТЕЛЬ ДАТЧИКА ДАВЛЕНИЯ ПОТОКА ВОЗДУХА] 12587812 BRACKET, MAP SEN 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (MAP SEN) [БОЛТ] 12608378 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 745) (ACDelco #214-2125) 11519941 БОЛТ, HFH W/SHLDR, M6X1X22, 13.8 THD, 15 OD, 9.8, 6280M, MACH, DOG-PT (EVAP EMIS CNSTR PURGE SOL) 25917777 PIPE, EVAP EMIS CNSTR PURGE (INCLS 748, 749) 12567655 GASKET, EXH MANIF [ПРОКЛАДКА] 12613200 FITTING, PCV HOSE (ЧАСТЬ OF 281) 12571223 PLUG, P/B VAC SCE HOLE (ЧАСТЬ OF 500) (16.0 MM) 19167509 INSULATOR, UPR INT MANIF CVR (ЧАСТЬ OF 591) (3.405) 12607145 SENSOR, HTD OXY (POSN 1) (IN EXH MANIFOLD/CROSSOVER) (ACDelco #213-4116) [КИСЛОРОДНЫЙ ДАТЧИК] 25709703 SEAL, CTLTC CONV (ЧАСТЬ OF 600, 620) (ROUND METAL SEAL) [ПРОКЛАДКА НАСОСА] (6M00-071) - 2007-2009 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 4 МАСЛЯНЫЙ НАСОС, PAN & ДЕТАЛИ КОМПЛЕКТА (LH2/4.6A) ↓ 12580850 MANIFOLD, ENG OIL (INCLS 107-109) (WITHOUT МАСЛЯНЫЙ ПОДДОН BAFFLE) [КОЛЛЕКТОР МАСЛЯНЫЙ] 03522376 БОЛТ, HFH, M6X1X23, 18 THD, 14.50 OD, 7T, ZP (ENG OIL MANIF) 03542310 БОЛТ, LWR C/CASE (M10X1.5X125, 30 THD) (8.900) 03542311 STUD, LWR C/CASE (M10X1.5X125-M9X1.0X13) (1.428) 12612258 PAN, OIL (INCLS 401, 412, 413, 420-422) 12568928 GASKET, МАСЛЯНЫЙ ПОДДОН (ЧАСТЬ OF 400) [ПРОКЛАДКА] 12567529 PIPE, O/PMP SUC (INCLS 406, 407) 12573569 GASKET, O/PMP SUC PIPE (ЧАСТЬ OF 405) [ПРОКЛАДКА МАСЛЯНОГО НАСОСА] 03522382 БОЛТ, O/PMP SUC PIPE (ЧАСТЬ OF 405) (HFH, M6X1.0X28) 03542258 ГАЙКА, O/PMP SUC PIPE (HFH, M9X1) (1.430) 12577394 BAFFLE, МАСЛЯНЫЙ ПОДДОН (B/W CRANK CASE AND PAN) 11562588 PLUG, МАСЛЯНЫЙ ПОДДОН DRN (ЧАСТЬ OF 400) (INCLS 413) (W/ SEAL) (EXC MAGNET) [ЗАГЛУШКА МАСЛЯНОГО ПОДДОНА] 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 400) 11519173 БОЛТ, HFH, REDUCED BODY, M8X1.25X60, 22THD, 18 OD, 8.8, GMW3359 (ЧАСТЬ OF 400) 11519178 БОЛТ HFH, M8X1.25X100, 13MM SOCKET, 8.8, GMW3359 (ЧАСТЬ OF 400) 12585398 INDICATOR, OIL LVL (INCLS 434) [ЩУП УРОВНЯ МАСЛА] 12570585 TUBE, OIL LVL IND (INCLS 432) [НАПРАВЛЯЮЩАЯ ТРУБКА ЩУПА УРОВНЯ МАСЛА] 24504091 SEAL, OIL LVL IND TUBE (O RING) (ЧАСТЬ OF 431) (BLACK) (6.07MM ID, 1.78MM DIA) 11515765 БОЛТ, HFH, M10X1.5X25, 22.30 O.D., HDR PT, 10.9, 7112M (OIL LVL IND TUBE) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) 12598047 ADAPTER, OIL FLTR (INCLS 441, 442, 445, 446, 449, 717, 718, 728, 729) 12573045 GASKET, OIL FLTR ADAP (ЧАСТЬ OF 440) [ПРОКЛАДКА МАСЛЯНОГО ФИЛЬТРА] 11519173 БОЛТ, HFH, REDUCED BODY, M8X1.25X60, 22THD, 18 OD, 8.8, GMW3359 (ЧАСТЬ OF 440) 24575062 FITTING, OIL FLTR (ЧАСТЬ OF 440) 25014612 VALVE, OIL FLTR BYPASS (ЧАСТЬ OF 440) (W/O VAPOR SEPARATOR) (OPENING PRESSURE 21 PSI NOMINAL) (ЧАСТЬ HAS A 16.10MM MAX OD & FITS A 15.84 HOLE IN BLOCK) 89017342 ФИЛЬТР, МАСЛЯНЫЙ (ЧАСТЬ OF 440) (FOR NON-CANADIAN ORDERS) (ACDelco #89017342) 11519833 PLUG ROUND HD, M16X1.5X22, 20 OD, 10 THD, 5.8, 4345M, SEALANT 9985490, MACH (OIL FLTR BYPASS HOLE) 12590890 PUMP, OIL (INCLS 464-472) [МАСЛЯНЫЙ НАСОС] 11518944 SCREW, PAN HD, M6X1X25, 20.9 THD, 11 OD, 8.8, GMW3359, 6 LOBED T-30 M-POINT (ЧАСТЬ OF 463) (8.913) 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (O/PMP) (ACDelco #11517518) [БОЛТ] 12568009 TUBE, O/PMP OTLT (INCLS 481) [ТРУБКА] teamcadillac.ru 12568320 SEAT, ENG OIL MANIF CHK VLV (ЧАСТЬ OF 480) (0.724) [КОЛЬЦЕВОЕ УПЛОТНЕНИЕ] 11518944 SCREW, PAN HD, M6X1X25, 20.9 THD, 11 OD, 8.8, GMW3359, 6 LOBED T-30 M-POINT (O/PMP OTLT TUBE) (8.913) 12573744 SHIELD, ENG OIL PRESS GA SEN HT (ЧАСТЬ OF 440) 11519964 БОЛТ, HFH, M6X1X13, 6 THD, 14.2 OD, 8.8, GMW3359, MAT POINT (ЧАСТЬ OF 440) 12567911 SENSOR, ENG OIL PRESS (ЧАСТЬ OF 440) (INCLS 729) (ACDelco #213-1547) [ДАТЧИК ДАВЛЕНИЯ МАСЛА] (6M00-073) - 2006-2009 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 4 МАСЛЯНЫЙ НАСОС,МАСЛЯНЫЙ ПОДДОН & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7) ↓ 22531637 PIN, МАСЛЯНЫЙ ПОДДОН LOC (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 12586959 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (LOWER PRIMARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ГРМ] 12586960 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАТЯЖИТЕЛЬ ЦЕПИ] 12586961 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАПРАВЛЯЮЩАЯ ПРИВОДНОЙ ЦЕПИ] 12597417 GUIDE, TMG CHAIN (UPPER PRIMARY) 12600461 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ПРИВОДА ГРМ] 12600462 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ПРИВОДА ГРМ] 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (ЧАСТЬ OF 463) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12596502 PAN, OIL (INCLS 404-407, 410, 412, 413, 420, 422, 900) 12575373 PIPE, O/PMP SUC (ЧАСТЬ OF 400) 12566837 SEAL, O/PMP SUC PIPE (ЧАСТЬ OF 400) [УПЛОТНЕНИЕ] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 400) 12566872 DEFLECTOR, CR/SHF OIL (ЧАСТЬ OF 400) 11562588 PLUG, МАСЛЯНЫЙ ПОДДОН DRN (ЧАСТЬ OF 400) (INCLS 413) (W/ SEAL) (EXC MAGNET) [ЗАГЛУШКА МАСЛЯНОГО ПОДДОНА] 12616850 SEAL, МАСЛЯНЫЙ ПОДДОН DRN PLUG (O RING) (ЧАСТЬ OF 400, 412) teamcadillac.ru 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (ЧАСТЬ OF 400) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11588424 БОЛТ, HFH, M6X1X145, 18 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 400) [ШЕСТИГРАННЫЙ ВИНТ] 12595327 INDICATOR, OIL LVL (INCLS 434) 12593211 TUBE, OIL LVL IND (INCLS 432) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 431) (BLACK) (6.07MM ID, 1.78MM DIA) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (OIL LVL IND TUBE) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) 12591607 ADAPTER, OIL FLTR (INCLS 441-443, 446-450, 456, 458, 459, 728, 729) [АДАПТЕР МАСЛЯНОГО ФИЛЬТРА] 12591604 GASKET, OIL FLTR (ЧАСТЬ OF 440) (BETWEEN OIL FILTER ADAPTER AND BLOCK) [ПРОКЛАДКА МАСЛЯНОГО ФИЛЬТРА] 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 440) 11519174 БОЛТ, HFH, W/REDUCED BODY, M8X1.25X65, THD 22, O.D. 18, 8.8, GMW3359 (ЧАСТЬ OF 440) 25014612 VALVE, OIL FLTR BYPASS (ЧАСТЬ OF 440, 450) (W/O VAPOR SEPARATOR) (OPENING PRESSURE 21 PSI NOMINAL) (ЧАСТЬ HAS A 16.10MM MAX OD & FITS A 15.84 HOLE IN BLOCK) 11519184 БОЛТ, OIL FLTR ADAP (ЧАСТЬ OF 440) (M10X1.5X45) (0.029) 25177917 ФИЛЬТР, МАСЛЯНЫЙ (ЧАСТЬ OF 440) (ACDelco #PF2129) [МАСЛЯНЫЙ ФИЛЬТР ДВИГАТЕЛЯ] 12583470 CAP, OIL FLTR (ЧАСТЬ OF 440) (INCLS 446, 456) [КРЫШКА] 12577653 SEAL, OIL FLTR CAP (O RING) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КРЫШКИ МАСЛЯНОГО ФИЛЬТРА] 12590152 PUMP, OIL (INCLS 151, 154, 464-466, 468, 470-472, 474, 475) (INCLS GUIDE, БОЛТS) [МАСЛЕННЫЙ НАСОС] 11900371 БОЛТ, HEX HD, W/1.6 FLAT WA, M8X1.25X54.3, 43 THD, 16O.D., 8.8, GMW3359 (ЧАСТЬ OF 463) 12590119 NOZZLE, PSTN OIL (INCLS 491) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 490) 12621659 SENSOR, ENG OIL PRESS (INCLS 729) (ЧАСТЬ OF 440) (ACDelco #12621659) 11588734 БОЛТ, HFH, M8X1.25X90, 21.6 THD, 18 O.D., 8.8, GMW3359 (ЧАСТЬ OF 400) [ВИНТ] (6Y00-003) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 2 ГОЛОВКА ЦИЛИНДРОВ & ДЕТАЛИ КОМПЛЕКТА (LH2/4.6A) ↓ 03522352 PIN, CYL HD LOC (HOLLOW DOWEL, 15.675X28, CHAM BOTH ENDS, SAE 12L14, ZP) 12564273 CHAIN, SECD TMG 12559389 SHOE KIT, TMG CHAIN TENSR (INCLS 174) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (ЧАСТЬ OF 173) (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 89017766 SHOE KIT, TMG CHAIN TENSR (INCLS 184) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (ЧАСТЬ OF 183) (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 12576969 VALVE, CM/SHF POSN ACTR SOL 12581497 ACTUATOR, CM/SHF POSN (EXH) 12581498 ACTUATOR, CM/SHF POSN (EXH) 12581499 ACTUATOR, CM/SHF POSN (INT) 12581500 ACTUATOR, CM/SHF POSN (INT) 12591268 COVER, CM/SHF (INCLS 251, 254-256, 261, 908, 909) 12591269 COVER, CM/SHF (INCLS 251, 254-256, 261, 908, 909) 12576394 GASKET, CM/SHF CVR (ЧАСТЬ OF 250) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ ЦИЛИНДРОВ] 12576395 GASKET, CM/SHF CVR (ЧАСТЬ OF 250) (BETWEEN HEAD AND CAM COVER) [ПРОКЛАДКА] 12576396 GASKET, CM/SHF CVR (ЧАСТЬ OF 250) (СВЕЧИ HOLES) [ПРОКЛАДКА] 12557829 БОЛТ, CM/SHF CVR (ЧАСТЬ OF 250) 12573742 INSULATOR, CM/SHF CVR БОЛТ (ЧАСТЬ OF 250) 12583570 CAP, OIL FIL (ROUND W/HDL) (INCLS 259) (NON VENTED) (ACDelco #FC215) 12593348 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 258) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА] 12581538 HEAD, CYL (MCHG) (INCLS 312, 313, 315, 334-337) 12581539 HEAD, CYL (MCHG) (INCLS 312, 313, 315, 334-337) 11569957 БОЛТ, CYL HD (M11X2X161, 60 THD) (*KIT1) 01647218 БОЛТ, CYL HD (QTY 3-RH, 3-LH) (M6X1.0X50, 10.9) (HFH, MACH) 11562126 PLUG, CYL HD CORE HOLE (ЧАСТЬ OF 300) (CUP, 32.03X7.88X1.27, S30400 SS PER SAE J405.) [ЗАГЛУШКА ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 01647543 PLUG, CYL HD CORE HOLE (ЧАСТЬ OF 300) (ROUND HEAD, INT HEX, W/ALUM WASH, 20X1.5X17, 12.25 THD, C1010 RQ) 11588949 PLUG, M16X1.5X14, 24 OD, SAE 1010 STL, GMW3044, W/ AL WASHER (ЧАСТЬ OF 300) [ПРОБКА ЗАМКА] 12574785 RESTRICTOR, ENG BLK OIL GAL 12607211 VALVE, EXH 12590223 VALVE, INT 12565203 ARM, VLV RKR [КОРОМЫСЛО КЛАПАНА ДВИГАТЕЛЯ] 24100005 ADJUSTER, HYD VLV LASH (ACDelco #24100005) [ТОЛКАТЕЛЬ КЛАПАНА ДВИГАТЕЛЯ] 12574354 SEAL, VLV STEM OIL [УПЛОТНЕНИЕ ШТОКА КЛАПАНА] 12565199 ПРУЖИНА, VLV 12580385 CAP, VLV SPR 01647209 KEY, VLV STEM 12565171 CAMSHAFT, EXH (MCHG) (INCLS 338) 12565172 CAMSHAFT, EXH (MCHG) (INCLS 338) [РАСПРЕДВАЛ В СБОРЕ] 12563833 CAMSHAFT, INL (MCHG) (INCLS 338) [РАСПРЕДВАЛ] 12565168 CAMSHAFT, INL (MCHG) (INCLS 338) [КОЛЕНВАЛ] 01647553 БОЛТ, CM/SHF BRG CAP (ЧАСТЬ OF 300) (HFH, M6X1.0X39.5) 12596360 ШЛАНГИ, CM/SHF POSN ACTR (INCLS 342, 344, 345, 735-737) 12596361 ШЛАНГИ, CM/SHF POSN ACTR (INCLS 342, 344, 345, 735-737) 12567656 GASKET, CM/SHF POSN ACTR HSG (ЧАСТЬ OF 340) (0.423) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12567657 GASKET, CM/SHF POSN ACTR HSG (ЧАСТЬ OF 340) (0.423) [УПЛОТНЕНИЕ ДВИГАТЕЛЯ] 11518706 STUD-HFH, M6X1X13.4, M6X1X40, 14.2 OD, 60 TL, 10.9, GM6280M (NON HEX CHROME) (ЧАСТЬ OF 340) (8.981) 11518707 STUD, HFH, M6X1X13 / M6X1X45, 14.2 O.D., 65 TL, 9.8, GM6280M (CM/SHF POSN ACTR HSG) 11562490 STUD, STRAIGHT, M8X1.25X20, M8X1.25X40, 69 TL, 9.8, GMW3179, EXT HEX SOCKET (EXH MANIF) [ШПИЛЬКА М8] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ) 15326386 SENSOR, ENG COOL TEMP (2-WAY MALE) (3.682) (ACDelco #213-928) [ДАТЧИК ТЕМПЕРАТУРЫ ДВИГАТЕЛЯ] 12571535 СВЕЧИ, (DO NOT CHANGE GAP) (ACDelco #41-987) (PLATINUM PLUG) [СВЕЧА ЗАЖИГАНИЯ] 12593995 SENSOR, CM/SHF POSN (INCLS 726) (ACDelco #213-3517) 01647346 БОЛТ, HFH, M6X1X17, 17THD, 14.2 O.D., 8.8, ZF (CM/SHF POSN SEN) 12567085 MAGNET, CM/SHF POSN ACTR (INCLS 737) (ЧАСТЬ OF 340) [МАГНИТ] teamcadillac.ru 11518845 SCREW PAN HD, M6X1X16, 15 THD, 12 OD, 8.8, 6280M, TORX, T30, HDR PT, W/SEALANT (ЧАСТЬ OF 340) 12567421 PLUG, CM/SHF POSN ACTR BORE (ЧАСТЬ OF 340, 735) 12581176 HARNESS, ELEK ICM WRG (INCLS 772) 11519976 БОЛТ, HFLGE, M8X1.25X20, 15.6 THD, 18 O.D., 8.8, GMW3359 (ELEK ICM WRG HARN CLIP) 11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (ЧАСТЬ OF 770) [БОЛТ М8] 11517094 SCREW, M5X.8X15.6, 10.4 THD, 10.2 OD, 6202M, 7114M, TAPER-POINT (ЧАСТЬ OF 250) (ACDelco #11517094) 89017450 GASKET KIT, CYL HD (INCLS 302, 310) (INCL GASKET AND M11X2.0 БОЛТS) [ПРОКЛАДКА ДВИГАТЕЛЯ] 89017451 GASKET KIT, CYL HD (INCLS 302, 310) (INCL GASKET AND M11X2.0 БОЛТS) [ПРОКЛАДКА ДВИГАТЕЛЯ] (GM00-387) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 1 БЛОК ЦИЛИНДРОВ И ВНУТРЕННИЕ ДЕТАЛИ (LY7/3.6-7) ↓ 12560272 БОЛТ, CR/SHF BRG CAP (M10X2X102.5, 24.5) [ВИНТ] 11518861 БОЛТ, HFH, W/REDCD BODY, M8X1.25X90, 26 THD, 18 O.D., 10.9, GM4277M (CR/SHF BRG CAP) [БОЛТ] 11609410 БОЛТ, HFH, M8X1.25X25, 10.9, GMW3179 (CR/SHF BRG CAP) (0.056) [БОЛТ] 89021297 ADHESIVE/SEALANT, THREADLOCKER HI STRENGTH 10ML ERI (CR/SHF BRG CAP) [АДГЕЗИВ] 11589000 БОЛТ, HFH, M8X1.25X50, 24 THD, 18 OD, 10.9, GMW3359, RED BODY, W/ADH (CR/SHF BRG CAP) 12557520 PLUG, ENG BLK OIL GAL (CUP-.390IN OD, .040IN THK, STEEL) 12621351 CRANKSHAFT, (****REFERENCE ONLY, DO NOT CATALOG*******) (USES BALANCER W/KEY) [КОЛЕНВАЛ] 12585420 PIN, CR/SHF SPKT LOC 11561583 PLUG, ENG BLK OIL GAL (M14X1.5X16, 22 OD) (0.253) 12566587 PLUG, ENG BLK OIL GAL 11561751 PLUG, CYL HD WAT JKT HOLE (M20X1.5X30.5) (1.531) 11569584 PLUG, ENG BLK CORE HOLE (CUP DIA 34.4MM) 12597210 PIN, TRANS LOC 12620955 SEAL, CR/SHF RR OIL (INCLS 134) [ПРОКЛАДКА КОЛЕНВАЛА ДВИГАТЕЛЯ] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 133) 22531637 PIN, МАСЛЯНЫЙ ПОДДОН LOC (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 12570326 PIN, CYL HD LOC [ЗАГЛУШКА БЛОКА ЦИЛИНДРОВ] 12572042 PLATE, A/TRNS FLEX 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12608432 ROD, CONN (INCLS 201, 202) 11519680 БОЛТ, CONN ROD (ЧАСТЬ OF 200) (M9X1X53) [БОЛТ] 12598657 BEARING KIT, CONN ROD (UPPER) [ПОДШИПНИК СКОЛЬЖЕНИЯ ШАТУНА] 12585675 PISTON, (W/PIN) (INCLS 211, 212) (.25 O.S.) 12590866 PISTON, (W/PIN) (INCLS 211, 212) (STD) 12566186 RETAINER, PSTN PIN (ЧАСТЬ OF 210) 12597654 BALANCER, CR/SHF (DUAL BELT, W/O KEYWAY) (FOR 2ND DES SEE 12603180) 12603180 BALANCER, CR/SHF (DUAL BELT) (USES BALANCER W/KEY) (FOR 1ST DES SEE 12597654) [ШКИВ КОЛЕНВАЛА] 11569873 БОЛТ, CR/SHF BALR (M14X1.5X48.4) 12613030 SENSOR, CR/SHF POSN (INCLS 721, 722) [ДАТЧИК ПОЛОЖЕНИЯ КОЛЕНВАЛА] 11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (ЧАСТЬ OF 720) [БОЛТ] 12618603 SENSOR, KNOCK (W/O LEADS) (INCLS 724) (ACDelco #213-4335) [ДАТЧИК] 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 723) 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (EXH MANIF H/SHLD) [БОЛТ] 12610603 BEARING KIT, CR/SHF (#1, 2, 4 STD) (INCLS 122, 123) [ПОДШИПНИК СКОЛЬЖЕНИЯ КОЛЕНВАЛА] 12610604 BEARING KIT, CR/SHF (#3 STD) (INCLS 123, 124) [КОМПЛЕКТ ПОДШИПНИКОВ СКОЛЬЖЕНИЯ КОЛЕНВАЛА (3ШТ)] teamcadillac.ru 12608615 RING KIT, PSTN (INCLS 213-216) (STD) (GM00-395) - 2007-2009 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 3 ПЕРЕДНЯЯ КРЫШКА И ОХЛАЖДЕНИЕ (LY7/3.6-7) ↓ 22531637 PIN, ENG FRT CVR LOC (ЧАСТЬ OF 350) (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] teamcadillac.ru 11519176 БОЛТ, ENG FRT CVR (ЧАСТЬ OF 350) (M8X1.25X80) (4.081) [БОЛТ] 12611883 COVER, ENG FRT (W/ W/PMP) (INCLS 132, 348, 351-354, 360-362, 725-727, 734, 900-903) [БОКОВАЯ КРЫШКА ДВИГАТЕЛЯ] 12593045 SEAL, W/PMP (ЧАСТЬ OF 350) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519171 БОЛТ, ENG FRT CVR (ЧАСТЬ OF 350) (M8X1.25X50) (3.275) [БОЛТ ВЫПУСКНОГО КОЛЛЕКТОРА] 12608750 SEAL, CR/SHF FRT OIL (ЧАСТЬ OF 350) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КОЛЕНВАЛА] 12594060 DEADENER, ENG FRT CVR (ЧАСТЬ OF 350) (BOTTOM) [ПРОКЛАДКА КРЫШКИ ДВИГАТЕЛЯ] 12618472 PUMP, WAT (W/GSKT) (INCLS 900) (ЧАСТЬ OF 350) (ACDelco #251-724) [НАСОС] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 350) 12576326 GASKET, W/PMP (ЧАСТЬ OF 350) (ACDelco #251-2048) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12574518 PULLEY, W/PMP (ADX) 11519512 БОЛТ, HFH, W/CON SPR WA, M6X1X13.4, 8.77 THD, 12.3 O.D., 8.8, GMW3359 (W/PMP PUL) 12592527 GASKET, ENG COOL THERM HSG (*KIT1) (ACDelco #12592527) [ПРОКЛАДКА ТЕРМОСТАТА] 12620260 ШЛАНГИ, ENG COOL THERM UPR (*KIT1) 11519973 БОЛТ-HFH, M6X1X60, 18MM THD, 14.2 OD, 8.8, 3359GMW, REDUCED BODY, MAT PT. (ENG COOL THERM HSG) (*KIT1) [БОЛТ 6Х1Х60] 11519974 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3359 (ENG COOL THERM HSG) (*KIT1) [БОЛТ] 12584325 SEAL, ENG COOL THERM HSG (O RING) (*KIT1) [КОЛЬЦЕ-ОБРАЗНОЕ УПЛОТНЕНИЕ] 12582472 SEAL, ENG COOL THERM (*KIT1) (ACDelco #12582472) [УПЛОТНИТЕЛЬ] 12566429 SEAL, WAT OTLT (ЧАСТЬ OF 380) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12584040 SEAL, CLNT OTLT (O RING) (ЧАСТЬ OF 380) (ACDelco #15-32584) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519974 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 380) [БОЛТ] 12573984 OUTLET, WAT (INCLS 377-379, 905) (INCLS БОЛТS, RETAINERS, SEALS & PIPE) (ACDelco #15-10429) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 12608424 SENSOR, CM/SHF POSN (INCLS 726, 727) (ЧАСТЬ OF 350) (ACDelco #12608424) [ДАТЧИК ПОЛОЖЕНИЯ РАСПРЕДВАЛА] 11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (ЧАСТЬ OF 350, 725) [БОЛТ] 12615613 VALVE, CM/SHF POSN ACTR SOL 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (CM/SHF POSN ACTR SOL VLV) 12593717 SEAL, CM/SHF POSN ACTR SOL VLV (O RING) (ЧАСТЬ OF 350) 12620259 ШЛАНГИ, ENG COOL THERM (INCLS 365-368, 370-373) (INCLS THERMOSTAT) [КОРПУС В СБОРЕ, ТЕРМОСТАТА СИСТЕМЫ ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ] 12620262 ШЛАНГИ, ENG COOL THERM (INCLS 365-368, 370-373) (GM00-396) - 2007-2009 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 2 ГОЛОВКА ЦИЛИНДРОВ & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7) ↓ 12570326 PIN, CYL HD LOC [ЗАГЛУШКА БЛОКА ЦИЛИНДРОВ] 12606653 ACTUATOR, CM/SHF POSN (USE WASHER 12630941) 12603744 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) 12603745 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) 11588279 БОЛТ, HFH, M10X1.5X80, 26 THD, 22.3 O.D., 10.9, GM4277M (CM/SHF POSN) 12626055 COVER, CM/SHF (INCLS 251, 254-257, 260, 263) [КЛАПАННАЯ КРЫШКА ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12591200 SEAL, CM/SHF CVR (ЧАСТЬ OF 250) (*KIT1) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12626054 COVER, CM/SHF (INCLS 253-257, 261) [КРЫШКА] 12591203 SEAL, CM/SHF CVR (ЧАСТЬ OF 252) (*KIT1) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12607600 SEAL, SPLG SHLD (ЧАСТЬ OF 250, 252) (*KIT1) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО СИСТЕМЫ ЗАЖИГАНИЯ] 11518859 БОЛТ, HFH W/SHLDR, M6X1X35, 11.85 THD, 18 O.D., 8.8, GMW3359 (ЧАСТЬ OF 250, 252) 12566250 INSULATOR, CM/SHF CVR БОЛТ (ЧАСТЬ OF 250, 252) 12593356 CAP, OIL FIL (INCLS 904) (ACDelco #FC221) [КРЫШКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ] 12593348 SEAL, OIL FIL TUBE (O RING) (ЧАСТЬ OF 262) (27.94MM I.D.) (SIZE #320) (1.758) [ПРОКЛАДКА] 12578316 FITTING, PCV (ЧАСТЬ OF 250) (INCLS 263) 12583384 FITTING, PCV (ЧАСТЬ OF 252) 12597946 TUBE, OIL FIL (INCLS 259) [ТРУБКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ ГОЛОВКИ БЛОКА] 12616908 SEAL, PCV HOSE FTG (O RING) (ЧАСТЬ OF 250, 260) (BLUE) (LARGER OF THE TWO ON THE FITTING) [УПЛОТНЕНИЕ] 12616909 SEAL, PCV HOSE FTG (O RING) (ЧАСТЬ OF 250, 260) (BLACK) (SMALLER OF THE TWO ON THE FITTING) [УЛОТНЕНИЕ] 12601744 INSULATOR, CM/SHF HSG CVR (0.413) 12601745 INSULATOR, CM/SHF HSG CVR [НАКЛАДКА КЛАПАННОЙ КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12603904 HEAD, CYL (MCHG) (INCLS 313, 318, 319, 328, 336, 337) (DOES NOT INCL ENG OIL MANIF CHECK VALVES. DLR MUST INSTL) 12603901 HEAD, CYL (MCHG) (INCLS 313, 318, 319, 328, 336, 337) (DOES NOT INCL ENG OIL MANIF CHECK VALVES. DLR MUST INSTL) 11518863 БОЛТ, CYL HD (M11X2X152) [БОЛТ] 11588734 БОЛТ, HFH, M8X1.25X90, 21.6 THD, 18 O.D., 8.8, GMW3359 (CYL HD) [ВИНТ] 12565988 PLUG - M20X1.5X30.5, 8.8, GMW3044, SEALANT PER GM9985490 (ЧАСТЬ OF 300, 301) 11562127 PLUG, CYL HD OIL GAL (ЧАСТЬ OF 300, 301) (CUP-14.22 OD, 6.6 THK, 304SS) 12575354 VALVE, EXH (STD) [КЛАПАН ВЫПУСКНОЙ] 12584760 VALVE, EXH (0.075 O.S.) [КЛАПАН ВЫПУСКНОЙ] 12575351 VALVE, INT (STD) [КЛАПАН ВПУСКНОЙ] teamcadillac.ru 12584763 VALVE, INT (0.075MM O.S.) (0.297) [КЛАПАН ВПУСКНОЙ] 24100294 ARM, VLV RKR [РЫЧАГ] 24100005 ADJUSTER, HYD VLV LASH (ACDelco #24100005) [ТОЛКАТЕЛЬ КЛАПАНА ДВИГАТЕЛЯ] 12565836 SEAL, VLV STEM OIL [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КЛАПАНА ДВИГАТЕЛЯ] 12575355 ПРУЖИНА, VLV [ПРУЖИНА КЛАПАНА] 12575196 RETAINER, VLV SPR [КОМПАКТ ДИСК] 12575197 KEY, VLV STEM [КЛАПАННЫЙ КЛЮЧ] 12574477 RING, CM/SHF SPKT OIL SEAL (ЧАСТЬ OF 330-333) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО РАСПРЕДВАЛА ДВИГАТЕЛЯ (2 ШТ.)] 12632192 CAMSHAFT, EXH (INCLS 329) 12609250 CAMSHAFT, INT (INCLS 329) [РАСПРЕДВАЛ ДВИГАТЕЛЯ] 12632193 CAMSHAFT, INT (INCLS 329) 12620457 CAMSHAFT, EXH (INCLS 329) 12632194 CAMSHAFT, EXH (INCLS 329) 12609252 CAMSHAFT, INT (INCLS 329) [РАСПРЕДВАЛ ДВИГАТЕЛЯ] 12632195 CAMSHAFT, INT (INCLS 329) 11518856 HFH, M6X1X43.4, 14.8 THD, 11 O.D., 8.8, GMW3179 CODE G (ЧАСТЬ OF 300, 301) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12618542 РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ, IGN (INCLS 705) (ACDelco #D508C) 11588715 БОЛТ, HFH, M6X1X35, 18 THD, 14.2 OD, 8.8, GMW3359, 5MM M POINT (ЧАСТЬ OF 704) [БОЛТ] 12566778 SENSOR, ENG COOL TEMP (3.682) (ACDelco #213-1581) [СЕНСОР ТЕМПЕРАТУРЫ] 12597464 СВЕЧИ, (DO NOT CHANGE СВЕЧИ GAP) (ACDelco #41-990) (PLATINUM PLUG) [СВЕЧА ЗАЖИГАНИЯ] 12580965 VALVE, ENG OIL MANIF CHK [КЛАПАН] 12593348 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 258) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА] 12625785 GASKET KIT, CYL HD (INCLS 251, 253, 254, 302, 303) [КОМПЛЕКТ ПРОКЛАДОК ГОЛОВКИ БЛОКА ЦИЛИНДРОВ (РЕЗ-7, МЕТ-8, ПАР-2)] (GM00-550) - 2007-2009 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 6 ЦЕПЬ И НАТЯЖИТЕЛЬ (LY7/3.6-7) ↓ 12590921 SPROCKET, CR/SHF (STAMPED 12590921) (FOR 2ND DES SEE 12599721) [ЦЕПНАЯ ЗВЕЗДОЧКА] 12599721 SPROCKET, CR/SHF (STAMPED 12599721) (FOR 1ST DES SEE 12590921) [ШЕСТЕРНЯ РАСПРЕДВАЛА] 12586959 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (LOWER PRIMARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ГРМ] 12609262 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (INCLS 153, 164) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 152) [БОЛТ М8] 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (TMG CHAIN GDE) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12616609 CHAIN, CM/SHF INTER DRV (PRIMARY) [ЦЕПЬ ПРИВОДА ГРМ] 12597417 GUIDE, TMG CHAIN (INCLS 157) (UPPER PRIMARY) 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 156) [БОЛТ М8] 11588252 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3179 CODE G (ЧАСТЬ OF 165, 166) 12589477 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 152) (PRIMARY) 12612839 SPROCKET, TMG CHAIN IDLER (INCLS 161) (0.736) [ЗВЕЗДОЧКА РАСПРЕДВАЛА] 12612838 SPROCKET, TMG CHAIN IDLER (INCLS 161) (0.736) [ШЕСТЕРНЯ РАСПРЕДВАЛА] 12616608 CHAIN, CM/SHF INTER DRV (SECONDARY) [ЦЕПЬ ПРИВОДА ГРМ] 12600461 GUIDE, TMG CHAIN (INCLS 172) (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ПРИВОДА ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 171) [БОЛТ М8] 12586960 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАТЯЖИТЕЛЬ ЦЕПИ] 11518858 БОЛТ, HFH, M8X1.25X43, 16 THD, 18 O.D., 8.8, GMW3179 (TMG CHAIN TENSR) [БОЛТ М8] 12609260 РОЛИК НАТЯЖИТЕЛЬ, TMG CHAIN (INCLS 176, 177) (SECONDARY) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 175) [БОЛТ М8] 12589478 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 175) 12586961 GUIDE, TMG CHAIN (INCLS 182) (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАПРАВЛЯЮЩАЯ ПРИВОДНОЙ ЦЕПИ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 181) [БОЛТ М8] 12600462 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ПРИВОДА ГРМ] 11518858 БОЛТ, HFH, M8X1.25X43, 16 THD, 18 O.D., 8.8, GMW3179 (TMG CHAIN TENSR) [БОЛТ М8] 12609258 РОЛИК НАТЯЖИТЕЛЬ, TMG CHAIN (INCLS 186, 187) (SECONDARY) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 185) [БОЛТ М8] teamcadillac.ru 12589479 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 185) 12606653 ACTUATOR, CM/SHF POSN (EXH) (USE WASHER 12630941) 12603744 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) (5 SCREWS ON BACKPLATE) 12603745 ACTUATOR, CM/SHF POSN (INT) (USE WASHER 12630941) (5 SCREWS ON BACKPLATE) 11588279 БОЛТ, HFH, M10X1.5X80, 26 THD, 22.3 O.D., 10.9, GM4277M (CM/SHF POSN ACTR) 12630941 WASHER, CM/SHF THR (USED ON ACTUATORS 12603744-745, 12606653 & 12630916-918) (**FIELD FIX ONLY, DO NOT CATALOG**) [УПОРНАЯ ШАЙБА РАСПРЕДЕЛИТЕЛЬНОГО ВАЛА ДВС] 01 - СИСТЕМА ОХЛАЖДЕНИЯ - РЕШЕТКА РАДИАТОРА-МАСЛОСИСТЕМА ↓ (6D01-034) - 2004-2009 E ПОДОГРЕВАТЕЛЬ БЛОКА ДВИГАТЕЛЯ (LY7/3.6-7, 110V ПОДОГРЕВАТЕЛЬ K05) ↓ 15257983 CORD, ENG COOL HTR (INCLS 2) teamcadillac.ru 12337820 STRAP, 15" TIE STRAP (ЧАСТЬ OF 1) (ACDelco #12337820) 12587380 ПОДОГРЕВАТЕЛЬ, ENG COOL (USE W/2 PIN ПОДОГРЕВАТЕЛЬ) [НАГРЕВАТЕЛЬ] (6D01-044) - 2004-2009 E РАДИАТОР ASM ↓ 19130177 РАДИАТОР, (CORE SIZE 26 3/8 X 21 3/16 X 2 1/16) (INCLS 2) (ACDelco #21670) 19130364 РАДИАТОР, (CORE SIZE 26 3/8 X 21 3/16 X 2 1/16) (INCLS 2) (ACDelco #21710) [РАДИАТОР] 19130397 РАДИАТОР, (CORE SIZE 26 3/8 X 21 3/16 X 2 1/16) (INCLS 2) (ACDelco #21711) [РАДИАТОР] teamcadillac.ru (6E01-015) - 2004-2009 E НАТЯЖИТЕЛЬ РЕМНЯ/ACCESSORY DRIVE (LH2/4.6A) ↓ 12593189 BELT, W/PMP & КОНДИЦИОНЕР CMPR & P/S PUMP [РЕМЕНЬ ДВИГАТЕЛЯ] 12578062 BELT, GEN (CODE WCN) [РЕМЕНЬ] 11518636 БОЛТ, HFH, M10X1.5X90, 25.9 THD, 22.3 OD, 10.9, GMW3359, 7.5 MAT-PT (ЧАСТЬ OF 4) [БОЛТ М10] 12568172 РОЛИК НАТЯЖИТЕЛЬ, DRV BELT (INCLS 3) (SMOOTH PULLEY) (USE T/W БОЛТ PN 11518636) [ШКИВ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] teamcadillac.ru 11518636 БОЛТ, HFH, M10X1.5X90, 25.9 THD, 22.3 OD, 10.9, GMW3359, 7.5 MAT-PT (ЧАСТЬ OF 6) [БОЛТ М10] 12598023 РОЛИК НАТЯЖИТЕЛЬ, DRV BELT (INCLS 5) (RIBBED PULLEY) [МЕХАНИЗМ НАТЯЖЕНИЯ] 12604688 PULLEY, BELT IDLER (INCLS 7) (ACDelco #15-40051) (6E01-018) - 2007-2009 E ВЕНТИЛЯТОР ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ-ELECTRIC PUSHER(LH2/4.6A, V92) ↓ teamcadillac.ru 89022529 BLADE, FAN (INCLS 2) (ACDelco #15-80710) [КРЫЛЬЧАТКА ВЕНТИЛЯТОРА] 89022527 SHROUD, ENG COOL FAN (INCLS 4) (ELECTRIC PUSH) [ОБТЕКАТЕЛЬ РАДИАТОРА] 89022526 MOTOR, ENG COOL FAN (ELECTRIC PUSH) (ACDelco #15-80542) [ЭЛЕКТРОДВИГАТЕЛЬ ВЕНТИЛЯТОРА 90 ВТ] 89022525 MOTOR, ENG COOL FAN (ELECTRIC PUSH) (ACDelco #15-80541) [ЭЛЕКТРОДВИГАТЕЛЬ ВЕНТИЛЯТОРА 90 ВТ] 89022544 БОЛТ KIT, ENG COOL FAN MOT [КОМПЛЕКТ БОЛТОВ ОБЛИЦОВКИ РАДИАТОРА (2 ШТ)] 89022528 BLADE, FAN (INCLS 2) (ACDelco #15-80709) [КРЫЛЬЧАТКА ВЕНТИЛЯТОРА] (6E01-019) - 2007-2009 E РЕШЕТКА РАДИАТОРА (SPORT PACKAGE VD9) ↓ 15284129 MOLDING, КАПОТ FRT (INCLS 2) (USED ON VECHICLES BUILT PRIOR TO 4/16/07) (FOR 2ND DES SEE 25844085) 19177175 MOLDING, КАПОТ FRT (INCLS 2) (КРАСКА TO MATCH) 25844085 MOLDING, КАПОТ FRT (INCLS 2) (USED ON VECHICLES BUILT ON OR AFTER 4/16/07) (FOR 1ST DES SEE 15284129) [МОЛДИНГ КАПОТА] 11561788 CLIP-U, 13X15X12, 1.5 PNL, 1050, 6280M (ЧАСТЬ OF 1) [ФИКСАТОР МОЛДИНГА КАПОТА] 15831165 SCREEN, RAD GRL (INCLS 4) (UPPER) 15795653 CLIP, RAD GRL (ЧАСТЬ OF 3, 6) (13X8.13X9.27) (7.831) [ФИКСАТОР ПАНЕЛИ БАМПЕРА] 15831166 SCREEN, RAD GRL (INCLS 4) (LOWER) 21030249 RETAINER, EXPAN, 21 LG, 20. OD, 8.0 HOLE, 3.0-5.0 PNL, NYLON 6/6, BLK (RAD GRL) (8.950) (PUSH IN) [ПИСТОН КРЕПЛЕНИЯ КОЖУХА РАДИАТОРА(ПЛАСТИК)] 15830874 GRILLE, RAD UPR (КРАСКА TO MATCH) [РЕШЕТКА РАДИАТОРА] 25819834 EMBLEM, RAD GRL (WREATH) 25819835 EMBLEM, RAD GRL (CREST) teamcadillac.ru 25735038 BUMPER, КАПОТ STOP (ATTACHED TO РАДИАТОР GRILLE) [ВТУЛКА БАМПЕРА] (6E01-022) - 2004-2008 E РАДИАТОР КРЕПЛЕНИЕ & ДЕТАЛИ КОМПЛЕКТА ↓ 25718629 BRACKET, RAD UPR (INCLS 3) 25729351 BRACKET, RAD UPR (INCLS 3) 11517484 БОЛТ-HEX, M6X1X20, 9 THD, 17 OD, 9.8, 6280M, MACH, P-PT (RAD UPR MT BRKT) 11519444 PUSH-PIN, 10.0 HEADX26.0, 10.0 HOLE, PNL THK 6.2-8.71, NY 6.6 (RAD AIR LWR BFL (PUSH IN)) [ФИКСАТОР ПОДКРЫЛКА] 25802220 DEFLECTOR, FRT AIR (INCLS 18) [ОБТЕКАТЕЛЬ РАДИАТОРА] 11570323 БОЛТ, ENG COOL FAN SHRD (M6X1X18, 13 THD) 19130179 SHROUD, ENG COOL FAN (MECHANICAL PULL) [КОЖУХ ВЕНТИЛЯТОРА РАДИАТОРА] 19130248 SEAL, RAD LH SI (INCLS 8) (USE ON CARS BUILT ON OR AFTER 02/16/07 FOR 1ST DES SEE 89023441.) [КОЖУХ РАДИАТОРА] 89023441 SEAL, RAD LH SI (INCLS 8) (USE ON CARS BUILT PRIOR TO 02/16/07 FOR 2ND DES SEE 19130248.) [ОПОРА РАДИАТОРА] 15932850 INSULATOR, RAD LWR [ДЕМПФЕР РАДИАТОРА] 11561026 БОЛТ-HFH, M6X1X25, 22 THD, 14.2 OD, 9.8, GMW3200, MACH, HDR-PT (КОНДИЦИОНЕР CNDSR) 19130354 CONDENSER, КОНДИЦИОНЕР (ACDelco #15-63540) 19130355 CONDENSER, КОНДИЦИОНЕР (ACDelco #15-63541) 25994576 BAR, FRT BPR IMP (СМ. ГРУППУ 07.000 "БАМПЕР ПЕРЕДНИЙ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [БАЛКА ПАНЕЛИ БАМПЕРА] 19130247 SEAL, RAD AIR SI (INCLS 8) (USE ON CARS BUILT ON OR AFTER 02/16/07 FOR 1ST DES SEE 89023440.) 89023440 SEAL, RAD AIR SI (INCLS 8) (USE ON CARS BUILT PRIOR TO 02/16/07 FOR 2ND DES SEE 19130247.) 88957418 SEAL, RAD UPR 15932856 SHROUD, ENG COOL FAN (СМ. ГРУППУ 01.000 "ВЕНТИЛЯТОР ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ОБТЕКАТЕЛЬ РАДИАТОРА] 15248340 SEAL, RAD AIR LWR (ЧАСТЬ OF 5) (6E01-023) - 2004-2009 E НАТЯЖИТЕЛЬ РЕМНЯ/ACCESSORY DRIVE (LY7/3.6-7) ↓ teamcadillac.ru 12577655 РОЛИК НАТЯЖИТЕЛЬ, КОНДИЦИОНЕР CMPR & P/S PMP BELT (9.180) [НАТЯЖИТЕЛЬ РЕМНЯ] 11518633 БОЛТ, HFH, M10X1.5X75, 26 THD, 22.3 OD, 10.9, GMW3359, MAT- POINT. (DRV BELT TENSR) [БОЛТ М10] 12578000 BELT, КОНДИЦИОНЕР CMPR & P/S PUMP [НАСОС] 12621991 BELT, W/PMP & GEN [РЕМЕНЬ ГЕНЕРАТОРА L=120 СМ] 12577652 РОЛИК НАТЯЖИТЕЛЬ, W/PMP & GEN BELT [НАТЯЖИТЕЛЬ РЕМНЯ] (6E01-024) - 2004-2009 E ПОДОГРЕВАТЕЛЬ БЛОКА ДВИГАТЕЛЯ (LH2/4.6A, 110V ПОДОГРЕВАТЕЛЬ K05) ↓ 15905855 CORD KIT, ENG COOL HTR teamcadillac.ru 12587380 ПОДОГРЕВАТЕЛЬ, ENG COOL (USE W/2 PIN ПОДОГРЕВАТЕЛЬ) [НАГРЕВАТЕЛЬ] (6E01-025) - 2004-2009 E ПОДОГРЕВАТЕЛЬ БЛОКА ДВИГАТЕЛЯ (LH2/4.6A, 220V ПОДОГРЕВАТЕЛЬ KA3) ↓ teamcadillac.ru 15905854 CORD KIT, ENG COOL HTR 12587379 ПОДОГРЕВАТЕЛЬ, ENG COOL (6E01-027) - 2007-2008 E ВЕНТИЛЯТОР ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ (LY7/3.6-7) ↓ 25767914 FAN, ENG COOL (7 BLADE FAN FOR 160W MOTOR) (ACDelco #15-80192) 15932856 SHROUD, ENG COOL FAN (INCLS 4) [ОБТЕКАТЕЛЬ РАДИАТОРА] teamcadillac.ru 88957423 MOTOR, ENG COOL FAN (INCLS 2, 8) (160W) (ACDelco #15-80516) [ЭЛЕКТРОДВИГАТЕЛЬ ВЕНТИЛЯТОРА 90 ВТ] 88957422 MOTOR, ENG COOL FAN (INCLS 2, 8) (160W) (ACDelco #15-80515) [ЭЛЕКТРОДВИГАТЕЛЬ ВЕНТИЛЯТОРА 90 ВТ] 25767915 FAN, ENG COOL (5 BLADES FOR 160W MOT) (ACDelco #15-80193) (6E01-028) - 2007-2009 E РЕШЕТКА РАДИАТОРА (EXC SPORT PACKAGE VD9) ↓ 15284129 MOLDING, КАПОТ FRT (INCLS 2) (USED ON VECHICLES BUILT PRIOR TO 4/16/07) (FOR 2ND DES SEE 25844085) 19177175 MOLDING, КАПОТ FRT (INCLS 2) (КРАСКА TO MATCH) 25844085 MOLDING, КАПОТ FRT (INCLS 2) (USED ON VECHICLES BUILT ON OR AFTER 4/16/07) (FOR 1ST DES SEE 15284129) [МОЛДИНГ КАПОТА] 11561788 CLIP-U, 13X15X12, 1.5 PNL, 1050, 6280M (ЧАСТЬ OF 1) [ФИКСАТОР МОЛДИНГА КАПОТА] teamcadillac.ru 25735038 BUMPER, КАПОТ STOP (ЧАСТЬ OF 6) (ATTACHED TO РАДИАТОР GRILLE) [ВТУЛКА БАМПЕРА] 21030249 RETAINER, EXPAN, 21 LG, 20. OD, 8.0 HOLE, 3.0-5.0 PNL, NYLON 6/6, BLK (ЧАСТЬ OF 6) (8.950) (PUSH IN) [ПИСТОН КРЕПЛЕНИЯ КОЖУХА РАДИАТОРА(ПЛАСТИК)] 15925771 GRILLE, RAD (INCLS 4, 5, 7-10) [РЕШЕТКА РАДИАТОРА] 25765149 EMBLEM, RAD GRL (ЧАСТЬ OF 6) (CHROME) ("CREST") [ЭМБЛЕМА] 25765150 EMBLEM, RAD GRL (ЧАСТЬ OF 6) ("WREATH") [ЭМБЛЕМА] 21030249 RETAINER, EXPAN, 21 LG, 20. OD, 8.0 HOLE, 3.0-5.0 PNL, NYLON 6/6, BLK (ЧАСТЬ OF 6) (8.950) (PUSH IN) [ПИСТОН КРЕПЛЕНИЯ КОЖУХА РАДИАТОРА(ПЛАСТИК)] 24574578 RETAINER, RAD GRL (ЧАСТЬ OF 6) (LENGTH 18.0) (3.403) [ФИКСАТОРА ВОЗДУХООЧИСТИТЕЛЯ] (6E01-029) - 2007-2009 E ШЛАНГИ И ТРУБКИ/РАДИАТОР (LY7/3.6-7) ↓ 88956900 HOSE, RAD SURGE TK OTLT (INCLS 2) 11517136 CЛАМПА, HOSE SPR, 27 NOM, 25.2 MIN-28.9 MAX, 15MM WIDE, BLACK (ЧАСТЬ OF 1) 11518624 БОЛТ, HFH, M10X1.5X30.4, 22.5 THD, 22.3 O.D., 10.9, GMW3359 (RAD SURGE TK ENG PIPE CLIP) 25757865 HOSE, RAD SURGE TK OVFL (ЧАСТЬ OF 6) 15075118 CAP, RAD SURGE TK (ЧАСТЬ OF 6) (15 PSI DUAL O-RING) (ENGLISH/FRENCH LABEL) (ACDelco #RC98) [КРЫШКА БАЧКА РАДИАТОРА] 15875447 TANK, RAD SURGE (INCLS 4, 5) (ACDelco #15875447) 15882261 TANK, RAD SURGE (INCLS 4, 5) (ACDelco #15882261) 11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (RAD SURGE TK) [БОЛТ М6] 11514517 ГАЙКА, HEX, W/CON SPR WA, M6X1, 5.7THK, 18 O.D., 9, 7111M (RAD SURGE TK) [ГАЙКА М6] 11570614 CЛАМПА-ПРУЖИНАBAND, 15 NOMINAL DIA, 15 THK, STL, ROBO (ЧАСТЬ OF 10) 19130184 HOSE, RAD SURGE TK INL (INCLS 9) 19130217 HOSE, RAD SURGE TK INL (INCLS 9) 11516233 CЛАМПА-ПРУЖИНАBAND, TYPE A, 15 WID, 40 HOSE OD, 6150M, 7111M, MM (ЧАСТЬ OF 12) [ХОМУТ ШЛАНГА РАДИАТОРА] 89023435 HOSE, RAD INL (INCLS 11) teamcadillac.ru 11516233 CЛАМПА-ПРУЖИНАBAND, TYPE A, 15 WID, 40 HOSE OD, 6150M, 7111M, MM (ЧАСТЬ OF 14) [ХОМУТ ШЛАНГА РАДИАТОРА] 25800334 HOSE, RAD OTLT (INCLS 13) [ШЛАНГ СИСТЕМЫ ОХЛАЖДЕНИЯ] 12603912 PIPE, RAD OTLT (INCLS 16) (WHEN USED IN PLACE OF 12587536 USE T/W РАДИАТОР OUTLET HOSE 19129967) 12612857 PIPE, RAD OTLT (INCLS 16) 12623519 SEAL, RAD OTLT PIPE (O RING) (ЧАСТЬ OF 15) 11519977 БОЛТ- HFH, M8X1.25X25, 16 THD, 18 OD, 8.8, GMW3359, MAT-PT. (RAD OTLT PIPE) 11518624 БОЛТ, HFH, M10X1.5X30.4, 22.5 THD, 22.3 O.D., 10.9, GMW3359 (RAD OTLT PIPE) (6E01-037) - 2007-2008 EE ШЛАНГИ И ТРУБКИ/РАДИАТОР (LH2/4.6A) ↓ 19130216 HOSE, RAD SURGE TK INL 11570614 CЛАМПА-ПРУЖИНАBAND, 15 NOMINAL DIA, 15 THK, STL, ROBO (RAD SURGE TK INL HOSE) 11514517 ГАЙКА, HEX, W/CON SPR WA, M6X1, 5.7THK, 18 O.D., 9, 7111M (RAD SURGE TK) [ГАЙКА М6] 15075118 CAP, RAD SURGE TK (ЧАСТЬ OF 10) (15 PSI DUAL O-RING) (ENGLISH/FRENCH LABEL) (ACDelco #RC98) [КРЫШКА БАЧКА РАДИАТОРА] 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (RAD SURGE TK) (ACDelco #11517518) [БОЛТ] 25757865 HOSE, RAD SURGE TK OVFL (ЧАСТЬ OF 10) 11570616 CЛАМПА, ПРУЖИНАBAND, 27 NOMINAL DIA, 15 THK, STL, ROBO (ЧАСТЬ OF 9) teamcadillac.ru 19130215 HOSE, RAD SURGE TK OTLT (INCLS 7) 15875447 TANK, RAD SURGE (INCLS 4, 6) (ACDelco #15875447) 19130238 CЛАМПА, RAD INL HOSE (ЧАСТЬ OF 12) 89023434 HOSE, RAD INL (INCLS 11, 13) [ТРУБКА] 89023438 HOSE, RAD INL (INCLS 11, 13) [ШЛАНГ] 11570869 CЛАМПА-ПРУЖИНАBAND, 41MM NOMINAL DIA, 15MM WIDTH, STEEL, GRAY ROBO. (ЧАСТЬ OF 12) 11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (RAD OTLT HOSE BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16] 15261734 BRACKET, RAD OTLT HOSE 25752529 BRACKET, RAD OTLT HOSE 89023433 HOSE, RAD OTLT (INCLS 14) (6E01-038) - 2007-2009 EB ШЛАНГИ И ТРУБКИ/РАДИАТОР (LH2/4.6A) ↓ 19129998 HOSE, RAD SURGE TK INL 11516215 CЛАМПА, ПРУЖИНАBAND, HOSE DIA 17MM, WIDTH 15MM, 6298M (RAD SURGE TK INL HOSE) teamcadillac.ru 11517136 CЛАМПА, HOSE SPR, 27 NOM, 25.2 MIN-28.9 MAX, 15MM WIDE, BLACK (ЧАСТЬ OF 6) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (RAD SURGE TK OTLT HOSE CLIP BRKT) 88956890 HOSE, RAD SURGE TK OTLT (INCLS 4) (8.846) 11514517 ГАЙКА, HEX, W/CON SPR WA, M6X1, 5.7THK, 18 O.D., 9, 7111M (RAD SURGE TK) [ГАЙКА М6] 15075118 CAP, RAD SURGE TK (ЧАСТЬ OF 11) (15 PSI DUAL O-RING) (ENGLISH/FRENCH LABEL) (ACDelco #RC98) [КРЫШКА БАЧКА РАДИАТОРА] 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (RAD SURGE TK) (ACDelco #11517518) [БОЛТ] 25757865 HOSE, RAD SURGE TK OVFL (ЧАСТЬ OF 11) 15882261 TANK, RAD SURGE (INCLS 8, 10) (ACDelco #15882261) 11570614 CЛАМПА-ПРУЖИНАBAND, 15 NOMINAL DIA, 15 THK, STL, ROBO (RAD SURGE TK INL HOSE) 19130238 CЛАМПА, RAD INL HOSE (ЧАСТЬ OF 14) 89023434 HOSE, RAD INL (INCLS 13, 15) [ТРУБКА] 89023438 HOSE, RAD INL (INCLS 13, 15) [ШЛАНГ] 11570869 CЛАМПА-ПРУЖИНАBAND, 41MM NOMINAL DIA, 15MM WIDTH, STEEL, GRAY ROBO. (ЧАСТЬ OF 14) 11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (RAD OTLT HOSE BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16] 15261734 BRACKET, RAD OTLT HOSE 25752529 BRACKET, RAD OTLT HOSE 89023433 HOSE, RAD OTLT (INCLS 16) (6M01-035) - 2004-2009 E ВЕНТИЛЯТОР ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ-ДВИГАТЕЛЬ MOUNTED (LH2/4.6A, V92) ↓ 11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (ENG COOL FAN BRKT) 12597700 BRACKET, ENG COOL FAN (INCLS 7) 11516869 БОЛТ, HEX W/CON WA, M10X1.5X18, 13THD, 20 O.D., 9.8, GM6174M (FAN BLADE) (*KIT1) 12589532 STUD, AUX ENG CLG FAN BRKT teamcadillac.ru 12586654 INSULATOR, ENG COOL FAN (ЧАСТЬ OF 2) 10382029 FAN, ENG COOL (INCLS 3-5) (1.050) (ACDelco #15-4972) [ЭЛЕКТРОМАГНИТНАЯ МУФТА ВЕНТИЛЯТОРА СИСТЕМЫ ОХЛАЖДЕНИЯ] (6M01-039) - 2007-2009 E ПОДОГРЕВАТЕЛЬ БЛОКА ДВИГАТЕЛЯ (LY7/3.6-7, 220V ПОДОГРЕВАТЕЛЬ KA3) ↓ 25772574 CORD, ENG COOL HTR [КАБЕЛЬ ПИТАНИЯ СИСТЕМЫ ПОДОГРЕВА ДВС] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ENG COOL HTR) 12588204 ПОДОГРЕВАТЕЛЬ, ENG COOL 02 - СТАРТЕР - ГЕНЕРАТОР - ЗАЖИГАНИЕ - ЭЛЕКТРИКА - ЛАМПЫ ↓ (6D02-025) - 2004-2009 E КРЕПЛЕНИЕ ГЕНЕРАТОРА (LY7/3.6-7) ↓ 12597648 BRACKET, GEN & DRV BELT TENSR (2.277) 11518628 БОЛТ, HVY HEX ACORN FLG HD, M10X1.5X50, GMW25M (10.9) STL, GMW3358 (GEN BRKT) 11518636 БОЛТ, HFH, M10X1.5X90, 25.9 THD, 22.3 OD, 10.9, GMW3359, 7.5 MAT-PT (GEN BRKT) [БОЛТ М10] 11519176 БОЛТ, GEN BRKT (M8X1.25X80) (4.081) [БОЛТ] teamcadillac.ru 25751146 GENERATOR, (ACDelco #25751146) [ГЕНЕРАТОР 150 А] 11518628 БОЛТ, HVY HEX ACORN FLG HD, M10X1.5X50, GMW25M (10.9) STL, GMW3358 (GEN) 11518633 БОЛТ, HFH, M10X1.5X75, 26 THD, 22.3 OD, 10.9, GMW3359, MAT- POINT. (GEN) [БОЛТ М10] (6D02-035) - 2004-2009 E РЕЛЕ/BODY COMPARTMENT ↓ 12088553 BREAKER, CIRC (ЧАСТЬ OF 10) (CYCLING TYPE, 8MM WIDE TERMINALS) (8.965) 15319848 BREAKER, CIRC (ЧАСТЬ OF 10) (50 AMP MAXI TYPE I) 19116051 BREAKER, CIRC (ЧАСТЬ OF 10) 15319477 FUSE, 30AMP, PINK, J-CASE, FEMALE, REGULAR (ЧАСТЬ OF 10) [ПРЕДОХРАНИТЕЛЬ 30А] 15319478 FUSE, 40AMP, GREEN, J-CASE, FEMALE (ЧАСТЬ OF 10) (ACDelco #15319478) [ПРЕДОХРАНИТЕЛЬ 40А] 12092079 FUSE, 10A, MINI, RED (ЧАСТЬ OF 10) 88909754 FUSE, 15A, MINI, BLUE (ЧАСТЬ OF 10) (ACDelco #ATM15-25) [ПРЕДОХРАНИТЕЛЬ 15 А] 19116059 RELAY, IGN (ЧАСТЬ OF 10) (GRAY) (4 TERMINAL) (SPACE SAVER ULTRA 280 MICRO) (2.483) 88953222 RELAY, INTR LP (ЧАСТЬ OF 10) (GRAY) (20AMP) (4 TERMINAL) (LOW-PROFILE MICRO 280) (2.485) (ACDelco #D1755A) [РЕЛЕ] 19116060 PULLER, FUSE (ЧАСТЬ OF 10) 21997408 RELAY, ACSRY TIME DELAY CUTOFF (ЧАСТЬ OF 10) (5-TERMINAL) (SPDT, 280 MINI, HI/LOW, BLACK) (1.055) (ACDelco #15-81106) teamcadillac.ru 89046748 BLOCK, BODY WRG HARN JUNC (ЧАСТЬ OF 10) (75-WAY FEMALE) (W/O LEADS) (BELOW LH ЗАДНИЙ SEAT) 89047327 COVER, PWR DISTR FUSE BLK (ЧАСТЬ OF 10) 89046747 BLOCK, BODY WRG HARN JUNC (ЧАСТЬ OF 10) (75-WAY FEMALE) (W/O LEADS) (BELOW RH ЗАДНИЙ SEAT) (6E02-022) - 2004-2009 E ФАРООМЫВАТЕЛЬ (CE4) ↓ 25890367 HOSE, HDLP WA 12335720 COVER, HDLP WA NOZ 12335721 COVER, HDLP WA NOZ 25767592 NOZZLE, HDLP WA [ФОРСУНКА ФАРООМЫВАТЕЛЯ] 25767593 NOZZLE, HDLP WA [ФОРСУНКА СТЕКЛООМЫВАТЕЛЯ] 88958121 PUMP, HDLP WA (LOCATED IN WSW TANK) (ACDelco #88958121) [НАСОС СТЕКЛООМЫВАТЕЛЯ] 88958122 SEAL, HDLP WA PUMP (6E02-023) - 2004-2009 E КРЕПЛЕНИЕ ГЕНЕРАТОРА (LH2/4.6A) ↓ 12565095 BRACKET, GEN 11515767 БОЛТ, HFH, M10X1.5X35, 32THD, 22.3 O.D., MACH, 10.9, 7114M (GEN BRKT) (T/W 12345493) [БОЛТ] 25709327 GENERATOR, (ACDelco #25709327) [ГЕНЕРАТОР 150 А] teamcadillac.ru 11516360 БОЛТ, HFH M10X1.2X90, 9.8, 7114M, 22.3 OD HDR PT (GEN) (6E02-025) - 2004-2009 E ЖГУТЫ ПРОВОДОВ/ПЕРЕДНИЕ ФАРЫ ↓ 15874802 HARNESS, FWD LP WRG (INCLS 2, 3) 15874812 HARNESS, FWD LP WRG (INCLS 2, 3) 15874813 HARNESS, FWD LP WRG (INCLS 2, 3) teamcadillac.ru 15874814 HARNESS, FWD LP WRG (INCLS 2, 3) 15874819 HARNESS, FWD LP WRG (INCLS 2, 3) 15874820 HARNESS, FWD LP WRG (INCLS 2, 3) 25846627 HARNESS, FWD LP WRG (INCLS 2, 3) 25846628 HARNESS, FWD LP WRG (INCLS 2, 3) 25875707 HARNESS, FWD LP WRG (INCLS 2, 3) 25875708 HARNESS, FWD LP WRG (INCLS 2, 3) 25891398 HARNESS, FWD LP WRG (INCLS 2, 3) [ПРОВОДКА ПЕРЕДНИХ ФАР] 25747284 HARNESS, S/LP WRG (6E02-026) - 2004-2009 E ЖГУТЫ ПРОВОДОВ/ДВИГАТЕЛЬ (LH2/4.6A) ↓ 25953318 HARNESS, ENG WRG 11517070 БОЛТ, HVY HFH, M10X1.5X20 (ENG WRG HARN GND) 15813405 BRACKET, ENG WRG HARN (IP INLINE) 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] 11519861 БОЛТ, HEX W/FL WA, M10X1.5X30, 19 THD, 20 OD, 9.8, 6280M, MACH, MAT-PT (ENG WRG HARN GRD) [БОЛТ М10] 25773136 BRACKET, ENG WRG HARN (CHANNEL) teamcadillac.ru 11517070 БОЛТ, HVY HFH, M10X1.5X20 (ENG WRG HARN SHLD) (6E02-027) - 2004-2009 E ЖГУТЫ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ ↓ teamcadillac.ru 25811234 HARNESS, I/P WRG 25811235 HARNESS, I/P WRG 25811236 HARNESS, I/P WRG 25811237 HARNESS, I/P WRG 25811238 HARNESS, I/P WRG 25811239 HARNESS, I/P WRG 25811240 HARNESS, I/P WRG 25811241 HARNESS, I/P WRG 25811242 HARNESS, I/P WRG 25811243 HARNESS, I/P WRG 11516630 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (I/P WRG HARN) (6E02-029) - 2004-2009 E ДАТЧИКИ ПАРКОВКИ ↓ 25819594 МОДУЛЬ, RR OBJECT ALARM [БЛОК УПРАВЛЕНИЯ ПРОТИВОУГОННОЙ СИСТЕМОЙ] 10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (RR OBJECT ALARM MDL) [ПИСТОН КРЕПЛЕНИЯ ОБЛИЦОВКИ БАМПЕРА (NYLON)] teamcadillac.ru 25893294 HARNESS, RR OBJECT SEN WRG 19116421 SENSOR KIT, RR OBJECT (INCLS 6-9) (INCLS SENSOR, RETAINER AND ШЛАНГИ.) (7.831) [ДАТЧИК ЗВУКОВОЙ СИГНАЛИЗАЦИИ СИСТЕМЫ КОНТРОЛЯ ПАРКОВКИ] (6E02-030) - 2004-2009 E КЛЮЧ-ЦИЛИНДР-ЗАЖИГАНИЕ ↓ teamcadillac.ru 19207991 CYLINDER, IGN LK (INCLS 1-3) 25865394 КЛЮЧ, DR LK & IGN LK (UNCODED) (MASTER) (6E02-031) - 2007 EB КРЕПЛЕНИЕ АККУМУЛЯТОРА И КАБЕЛИ (LH2/4.6A) ↓ 25747792 SHIELD, BAT HT (INSTALLED ON RH SIDE OF CAR) 11509853 БОЛТ, HEX W/CON WA, M8X1.25X45, 24 O.D., HDR PT, 9.8, PS (BAT HOLDN RET) [БОЛТ] 25558374 RETAINER, BAT HOLDN (CENTER SLOT) [ФИКСАТОР АККУМУЛЯТОРНОЙ БАТТАРЕИ] 88901964 АККУМУЛЯТОР, (CCA 650) (SIDE TERM) (260X178X168) (US DEALERS CONTACT ACDELCO WD FOR ORDERING & PRICING INFO) (ACDelco #101-6YR) (PROFESSIONAL - 6 YR) 15204281 LABEL, BAT WRNG (INCLUDES SYMBOLS ONLY) 11518646 БОЛТ, HEX HD, W/CON WA, M6X1X30, 24.33THD, 17 OD, 9.8, 6138M, BLK (BAT TRAY) 15796853 TRAY, BAT (INCLS 8) 15812692 TRAY, BAT (INCLS 8) 11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (ЧАСТЬ OF 7) [ШАЙБА] teamcadillac.ru 15804441 CABLE, BAT POS (INCLS 21) (ACDelco #15804441) 15889950 CABLE, BAT POS (INCLS 21) (ACDelco #15889950) 21021808 ГАЙКА, STRTR SOL BAT TERM (LARGER) (M8X1.25X6, BRASS) (2.343) [ГАЙКА М8] 11504568 ГАЙКА, HEX M5X0.8 PREV TORQ INSERT 9 ZC (SMALLER) 11562004 БОЛТ, HEX W/FL WA, M10X1.5X30, 19 THD, 20 OD, 8.8, GMW3200, MACH, M-PT (BAT CBL TERM) 11515535 ГАЙКА, BAT WIRE (2.559) 15804415 CABLE, BAT NEG (INCLS 20) (ACDelco #15804415) 15889974 CABLE, BAT NEG (INCLS 20) (ACDelco #15889974) 11589258 БОЛТ, BAT NEG CBL GND (M8X1.25X31) [БОЛТ М8] 11517031 ГАЙКА, HFH, M8X1.25, 9.4THK, 17.4 O.D., 10, TIN ZN (BAT POS CBL) 12160209 COVER, BAT NEG CBL TERM (ЧАСТЬ OF 17) (BLACK VINYL) (SURROUNDS CABLE END AT BATT SIDE TERM) 19116749 COVER, BAT NEG CBL TERM (ЧАСТЬ OF 17) 12010050 COVER, BAT POS CBL БОЛТ (ЧАСТЬ OF 10) (RED) (HAS SLOTTED HOLE) (SNAPS ON TO АККУМУЛЯТОР БОЛТ) 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (BAT TRAY) [БОЛТ М6] (6E02-032) - 2007-2009 E СИГНАЛ (EXC (U03)) ↓ 25789208 СИГНАЛ, 400 & 500 HZ (INCLS 2, 3) (ACDelco #D1947F) [ЗВУКОВОЙ СИГНАЛ] 11517103 STUD, SPL W/KNURLED SHLDR, M6X1X27, 10 THD, 13 O.D., P-PT., 9.8, 7114M (ЧАСТЬ OF 1) [ШТИФТ] 11517102 ГАЙКА, HEX FLG, M6X1X15, 19.8 OD, 9, 7111M (ЧАСТЬ OF 1) [ГАЙКА] (6E02-035) - 2005-2009 E ПЕРЕДНИЕ ФАРЫ (EXPORT TT7,TT8) ↓ 15930599 ЛАМПА, FRT SI T/SIG (INCLS 2) [УКАЗАТЕЛЬ ПОВОРОТА] 01999382 BULB, (ЧАСТЬ OF 1) (ACDelco #W5WLL) (LONGER LIFE) 25760398 SENSOR, HDLP LVLG FRT SUSP HEIGHT (9X/-3NM (S)9X/-3NM) (INTEGRAL STUD) [ДАТЧИК НАКЛОНА ПЕРЕДНЕЙ ЧАСТИ КУЗОВА] 01999382 BULB, (ЧАСТЬ OF 10) (ACDelco #W5WLL) (LONGER LIFE) 10346260 BULB, FRT FOG LP (ЧАСТЬ OF 10) (TRADE 9145) (ACDelco #9145) [ЛАМПА НАКАЛИВАНИЯ] 15896707 ЛАМПА, FRT T/SIG & FOG (INCLS 5-9, 11) 15896708 ЛАМПА, FRT T/SIG & FOG (INCLS 5-9, 11) 11513599 ГАЙКА, U-TYPE, M4.2X1.41, 0.65-3.80 PNL THK, PZ (ЧАСТЬ OF 14) (ACDelco #11513599) 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (FRT FOG LP) [ВИНТ М4] 15831167 BRACKET, FRT FOG LP (INCLS 12, 39) [КОНСОЛЬ] 15831168 BRACKET, FRT FOG LP (INCLS 12, 39) [КРОНШТЕЙН ПРОТИВОТУМАННОЙ ФАРЫ] 15915312 BRACKET, FRT PARK & T/SIG & FOG LP (INCLS 12, 39) [ОПОРА ПРОТИВОТУМАННОЙ ФАРЫ] 15915313 BRACKET, FRT PARK & T/SIG & FOG LP (INCLS 12, 39) [КРОНШТЕЙН ПЕРЕДНЕЙ ФАРЫ] 11588795 RETAINER, HDLP (PUSH ON) (FITS 9 X 16 HOLE, 1.5 THICK PANEL) [ДЕМПФЕР КРЕПЛЕНИЯ ПЕРЕДНЕЙ ФАРЫ] 25735603 BULB, HDLP (LOW BEAM) (ЧАСТЬ OF 22) (TRADE #D1S) (ACDelco #D1S) [ЛАМПОЧКА ПЕРЕДНЕЙ ФАРЫ 50 ВТ] 92184172 BULB, HDLP (HIGH BEAM) (ЧАСТЬ OF 22) (TRADE H7) (ACDelco #92184172) 01999382 BULB, (ЧАСТЬ OF 22) (ACDelco #W5WLL) (LONGER LIFE) 15926963 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 16-21, 23-27) 15930600 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 16-21, 23-27) [ПЕРЕДНЯЯ ФАРА] 25766663 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 16-21, 23-27) 25766664 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 16-21, 23-27) 25763464 BULB, FRT POSN LP (PARK FUNCTION BULB) (ЧАСТЬ OF 22) (BLUE TINT) (TRADE #W5WB50X2) (ACDelco #W5WB50X2) [ЛАМПОЧКА НАКАЛИВАНИЯ ФАРЫ 55 ВТ] 25768517 SENSOR, HDLP LVLG RR SUSP HEIGHT (INCLS 29) [ДАТЧИК ПОЛОЖЕНИЯ КУЗОВА] 25722303 HARNESS, HDLP LVLG ACTR WRG (ЧАСТЬ OF 28) teamcadillac.ru 25753157 BRACKET, HDLP (INCLS 33) 11517397 ГАЙКА, HEX W/CON WA, 8X1.25, 28 O.D., 7.5 THK, 9, PEOR (FRT BPR ENGY ABS) 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (ЧАСТЬ OF 31, 38) (ACDelco #11517518) [БОЛТ] 11518497 SCREW, ASM HEX HD W/FLAT WASHER, M6X1.0X25, 14 THD, 9.8 (HDLP) 11588795 RETAINER, HDLP (PUSH ON) (FITS 9 X 16 HOLE, 1.5 THICK PANEL) [ДЕМПФЕР КРЕПЛЕНИЯ ПЕРЕДНЕЙ ФАРЫ] 11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (ЧАСТЬ OF 38) [ШАЙБА] 25753158 BRACKET, HDLP (INCLS 33, 37) [КРОНШТЕЙН В СБОРЕ] 11609459 SCREW, RND WA, M4.2X1.41X13, 7.2 THD, 11.35 OD, 6010M, GMW4205 (ЧАСТЬ OF 14) [ВИНТ] (6E02-036) - 2005-2009 E ПЕРЕДНИЕ ФАРЫ (EXC EXPORT TT7,TT8) ↓ 10346260 BULB, FRT FOG LP (ЧАСТЬ OF 7) (TRADE 9145) (ACDelco #9145) [ЛАМПА НАКАЛИВАНИЯ] 15855631 BULB, T/SIG (ЧАСТЬ OF 7) (TRADE #3457NAK-LCP) (2.880) (ACDelco #15855631) 15862271 BULB, T/SIG (ЧАСТЬ OF 7) (TRADE #3757KA) (2.880) (ACDelco #23757NAK) [ЛАМПОЧКА СИГНАЛА ПОВОРОТА, 21 ВТ] 15896707 ЛАМПА, FRT T/SIG & FOG (INCLS 2-6, 8, 37) 15896708 ЛАМПА, FRT T/SIG & FOG (INCLS 2-6, 8, 37) 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (FRT FOG LP) [ВИНТ М4] 11588795 RETAINER, HDLP (PUSH ON) (FITS 9 X 16 HOLE, 1.5 THICK PANEL) [ДЕМПФЕР КРЕПЛЕНИЯ ПЕРЕДНЕЙ ФАРЫ] 25735603 BULB, HDLP (LOW BEAM) (ЧАСТЬ OF 24) (TRADE #D1S) (ACDelco #D1S) [ЛАМПОЧКА ПЕРЕДНЕЙ ФАРЫ 50 ВТ] 92184172 BULB, HDLP (HIGH BEAM) (ЧАСТЬ OF 24, 31) (TRADE H7) (ACDelco #92184172) 01999382 BULB, (ЧАСТЬ OF 24) (ACDelco #W5WLL) (LONGER LIFE) 89024736 BALLAST, HDLP (LH AND RH) (ЧАСТЬ OF 24) 11517397 ГАЙКА, HEX W/CON WA, 8X1.25, 28 O.D., 7.5 THK, 9, PEOR (FRT BPR ENGY ABS) 25753157 BRACKET, HDLP (INCLS 22) teamcadillac.ru 11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (ЧАСТЬ OF 21, 27) [БОЛТ М6] 11518497 SCREW, ASM HEX HD W/FLAT WASHER, M6X1.0X25, 14 THD, 9.8 (HDLP) 15260975 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 11-19, 29, 36) (USE WITH 9005 BULB, FOR 2ND DESIGN SEE 15926961) 15926960 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 11-19, 29, 36) 15926961 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 11-19, 29, 36) (USE WITH H7 BULB, FOR 1ST DESIGN SEE 15260975) 11518497 SCREW, ASM HEX HD W/FLAT WASHER, M6X1.0X25, 14 THD, 9.8 (HDLP) 11518121 ГАЙКА, U, M6X1, MULTI THD, .5'-4.0' THK PNL (ЧАСТЬ OF 27) 25753158 BRACKET, HDLP (INCLS 22, 26) [КРОНШТЕЙН В СБОРЕ] 25735602 BULB, HDLP (LOW BEAM) (ЧАСТЬ OF 31) (TRADE #9006XSLL) (ACDelco #9006SXLL) [ЛАМПА НАКАЛИВАНИЯ] 01999382 BULB, (ЧАСТЬ OF 31) (ACDelco #W5WLL) (LONGER LIFE) 15926966 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 11, 12, 15, 14, 28-30, 38) 15926967 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 11, 12, 15, 14, 28-30, 38) 11588795 RETAINER, HDLP (PUSH ON) (FITS 9 X 16 HOLE, 1.5 THICK PANEL) [ДЕМПФЕР КРЕПЛЕНИЯ ПЕРЕДНЕЙ ФАРЫ] 11513599 ГАЙКА, U-TYPE, M4.2X1.41, 0.65-3.80 PNL THK, PZ (FRT T/SIG LP) (ACDelco #11513599) 15831167 BRACKET, FRT FOG LP [КОНСОЛЬ] 15831168 BRACKET, FRT FOG LP [КРОНШТЕЙН ПРОТИВОТУМАННОЙ ФАРЫ] 15915312 BRACKET, FRT PARK & T/SIG & FOG LP [ОПОРА ПРОТИВОТУМАННОЙ ФАРЫ] 15915313 BRACKET, FRT PARK & T/SIG & FOG LP [КРОНШТЕЙН ПЕРЕДНЕЙ ФАРЫ] 11609459 SCREW, RND WA, M4.2X1.41X13, 7.2 THD, 11.35 OD, 6010M, GMW4205 (FRT FOG LP) [ВИНТ] 25763464 BULB, FRT POSN LP (PARK FUNCTION BULB) (ЧАСТЬ OF 24) (BLUE TINT) (TRADE #W5WB50X2) (ACDelco #W5WB50X2) [ЛАМПОЧКА НАКАЛИВАНИЯ ФАРЫ 55 ВТ] 19120947 SOCKET, FRT T/SIG LP (ЧАСТЬ OF 7) (ACDelco #LS234) 01999382 BULB, (ЧАСТЬ OF 31) (ACDelco #W5WLL) (LONGER LIFE) (6E02-037) - 2007 EB СИГНАЛИЗАЦИЯ/ANTI THEFT (UTA) ↓ 15774715 SENSOR, THEFT DTRNT [ДАТЧИК ОБЪЕМА САЛОНА] 90355463 SWITCH, КАПОТ AJAR IND LP (ANTI THEFT WARNING UNIT) [ДАТЧИК ОТКРЫТИЯ КАПОТА (КОНЦ. ВЫКЛЮЧАТЕЛЬ)] 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (КАПОТ AJAR IND SW BRKT) 25765686 BRACKET, КАПОТ AJAR IND LP SW 11609599 STUD, SPL, M6X1X25, 13 THD, 11 OD HD W/26 WIDE CLIP, 9.8, 6280M, P-PT (THEFT DTRNT ALARM) 25734317 SENSOR, THEFT DTRNT VEH INCLINATION [ДАТЧИК НАКЛОНА КУЗОВА] 10362943 BRACKET, THEFT DTRNT ALARM teamcadillac.ru 11514517 ГАЙКА, HEX, W/CON SPR WA, M6X1, 5.7THK, 18 O.D., 9, 7111M (THEFT DTRNT ALARM) [ГАЙКА М6] 15213135 ALARM, THEFT DTRNT [ЗВУКОВОЙ СИГНАЛ (СИРЕНА) СИГНАЛИЗАЦИИ] (6E02-038) - 2007-2009 E РЕЛЕ & МОДУЛЬS/ДВИГАТЕЛЬНЫЙ ОТСЕК ↓ 25822674 COVER, MULTIUSE RLY & FUSE (ЧАСТЬ OF 7) [КРЫШКА ТОКОРАСПРЕДЕЛИТЕЛЬНОЙ КОРОБКИ] 15209748 FUSE, 40AMP, LOW PROFILE J CASE, GREEN (ЧАСТЬ OF 7) [ПРЕДОХРАНИТЕЛЬ 20А] 15822417 FUSE, 30AMP, LOW PROFILE J CASE, PINK (ЧАСТЬ OF 7) [ПРЕДОХРАНИТЕЛЬ, 20А] 19116359 FUSE, 50AMP, LOW PROFILE J-CASE, RED (ЧАСТЬ OF 7) [ПРЕДОХРАНИТЕЛЬ 50А] 19116041 FUSE, 2AMP, LOW PROFILE MINI, GRAY (ЧАСТЬ OF 7) [ПРЕДОХРАНИТЕЛЬ] 19116042 FUSE, 10AMP, LOW PROFILE MINI, RED (ЧАСТЬ OF 7) [ПРЕДОХРАНИТЕЛЬ, 10A] 19116043 FUSE, 15AMP, LOW PROFILE MINI, BLUE (ЧАСТЬ OF 7) [ПРЕДОХРАНИТЕЛЬ, 15A] 19116048 FUSE, 20AMP, LOW PROFILE MINI, YELLOW (ЧАСТЬ OF 7) [ПРЕДОХРАНИТЕЛЬ, 20A] 19116049 FUSE, 25AMP, LOW PROFILE MINI, NATURAL (ЧАСТЬ OF 7) [ПРЕДОХРАНИТЕЛЬ, 25A] 19116050 FUSE, 30AMP, LOW PROFILE MINI, GREEN (ЧАСТЬ OF 7) [ПРЕДОХРАНИТЕЛЬ, 30A] 19116081 COVER, BAT POS CBL J/BLK (ЧАСТЬ OF 7) 11610091 ГАЙКА, HFH, 8X1.25, 17.9 OD, 7.8 THK, 13MM HEX, 10, GMW3200 (BAT POS CBL) 25787958 BLOCK, ENG WRG HARN JUNC (INCLS 1-4, 16-18) 25787959 BLOCK, ENG WRG HARN JUNC (INCLS 1-4, 16-18) [БЛОК УПРАВЛЕНИЯ] 25954993 BRACKET, MULTIUSE RLY & FUSE [КРЫШКА БЛОКА ПРЕДОХРАНИТЕЛЕЙ] 11561758 БОЛТ, MULTIUSE RLY & FUSE BRKT (7.833) [БОЛТ] 15879156 BRACKET, ACSRY WRG J/BLK 11609599 STUD, SPL, M6X1X25, 13 THD, 11 OD HD W/26 WIDE CLIP, 9.8, 6280M, P-PT (MULTIUSE FUSE BRKT) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (MULTIUSE RLY & FUSE BRKT) [ГАЙКА М6] 12193606 RELAY, HDLP LOW BEAM (ЧАСТЬ OF 7) (BLUE) (4-TERMINAL) (SPST 280 MINI) (4.720) (ACDelco #12193606) 19116057 RELAY, FAN CONT (ЧАСТЬ OF 7) (GRAY) (35AMP) (4 TERMINAL) (HIGH CURRENT MICRO RELAY) (2.483) (ACDelco #D1786C) [РЕЛЕ 35А] teamcadillac.ru 19116058 RELAY, FAN CONT (ЧАСТЬ OF 7) (BLACK) (35AMP) (5 TERMINAL) (HIGH CURRENT MICRO 280) (2.483) (ACDelco #D1780C) 19116059 RELAY, ENG CLG BLO (ЧАСТЬ OF 7) (GRAY) (4 TERMINAL) (SPACE SAVER ULTRA 280 MICRO) (2.483) 88953222 RELAY, HDLP (ЧАСТЬ OF 7) (GRAY) (20AMP) (4 TERMINAL) (LOW-PROFILE MICRO 280) (ACDelco #D1755A) [РЕЛЕ] 19116060 PULLER, FUSE (ЧАСТЬ OF 7) 19116051 BREAKER, CIRC (ЧАСТЬ OF 7) (6E02-039) - 2005-2009 E ЗАДНИЕ ФАРЫ ↓ 25773051 WEATHERSTRIP, L/GATE UPR [БОКОВОЙ МОЛДИНГ] 11509428 БОЛТ/SCREW, HEX, W/FLAT WA, M4.2X1.4X13, 12.3 O.D., BHL PT, 6010M, NO (L/GATE APLQ) (8.977) 15211328 GASKET, HIGH MT S/LP (USED W/BEZEL 12335827) [ПРОКЛАДКА] 15211327 GASKET, HIGH MT S/LP (USED WITH BEZEL 12335827) (ON TAB SEAL-T/LP HSG S/LP (ON STUD) [ПРОКЛАДКА] 19121111 BEZEL, HIGH MT S/LP [ОКАНТОВКА ФОНАРЯ ДОПОЛНИТЕЛЬНОГО СТОП-СИГНАЛА] 15930616 ЛАМПА, HIGH MT STOP [ЗАДНИЙ ФОНАРЬ] teamcadillac.ru 15213960 GASKET, HIGH MT S/LP (ON STUD) 11588650 CLIP, 12X14X16.6, GM4345M (L/GATE APLQ) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА] 25759092 GASKET, HIGH MT S/LP (38 OD X 28 ID X 9.5 THICK) [ПРОКЛАДКА МОЛДИНГА ЗАДНЕЙ ОТКИДНОЙ ДВЕРИ] 01999382 BULB, (ЧАСТЬ OF 14, 24) (ACDelco #W5WLL) (LONGER LIFE) 12450108 BULB, TRADE #3157KX (ЧАСТЬ OF 14, 24) (2.679) (ACDelco #3157KX) (LONGER LIFE KRYPTON) [ЛАМПОЧКА НАКАЛИВАНИЯ ФАРЫ 15 ВТ] 25735605 BUMPER, RR LIC PLT PKT (ЧАСТЬ OF 14, 24) (2.662) 12335850 ЛАМПА, B/U & RR LIC (W/RR LIC PLT PKT) (INCLS 10-13) (КРАСКА TO MATCH) 25936964 ЛАМПА, TAIL 25936965 ЛАМПА, TAIL 25936966 ЛАМПА, TAIL [ЗАДНИЙ ФОНАРЬ] 25936967 ЛАМПА, TAIL [ЗАДНИЙ ФОНАРЬ] 25736754 RETAINER, T/LP (PUSH IN) (14 X 21MM HEAD) 11519918 RETAINER, T/LP (PUSH IN) (16MM ROUND HEAD) (2.664) [ФИКСАТОР ЗАДНЕГО ФОНАРЯ] 11517736 ГАЙКА, HEX, M6X1, 5.7 HIGH, 24 OD, 9, 7111M, W/2.5 THK SEALING WA (T/LP) [ГАЙКА М6] 11514517 ГАЙКА, HEX, W/CON SPR WA, M6X1, 5.7THK, 18 O.D., 9, 7111M (B/U & RR LIC PLT LP) [ГАЙКА М6] 11517230 БОЛТ, TORX, W/WA, W/ADH, M6X1X20, 16.2 O.D., DOG PT, 10.9, GM6138M (L/GATE UPR SI APLQ) [ВИНТ ЗАМКА ДВЕРИ М6] 89025118 GASKET, HIGH MT S/LP 15806842 HARNESS, L/GATE LK & R/WDO DEFG & R/WDO WPR WRG 15806843 HARNESS, L/GATE LK & R/WDO DEFG & R/WDO WPR WRG 15930602 ЛАМПА, B/U & RR FOG & RR LIC PLT (INCLS 10, 12, 13, 25, 26) (2.697) 12450108 BULB, TRADE #3157KX (RR FOG LP) (ЧАСТЬ OF 24) (2.679) (ACDelco #3157KX) (LONGER LIFE KRYPTON) [ЛАМПОЧКА НАКАЛИВАНИЯ ФАРЫ 15 ВТ] (6E02-040) - 2007 EB КРЕПЛЕНИЕ АККУМУЛЯТОРА И КАБЕЛИ (LY7/3.6-7) ↓ 25747792 SHIELD, BAT HT (INSTALLED ON RH SIDE OF CAR) 11509853 БОЛТ, HEX W/CON WA, M8X1.25X45, 24 O.D., HDR PT, 9.8, PS (BAT HOLDN RET) [БОЛТ] 25558374 RETAINER, BAT HOLDN (CENTER SLOT) [ФИКСАТОР АККУМУЛЯТОРНОЙ БАТТАРЕИ] 88901964 АККУМУЛЯТОР, (CCA 650) (SIDE TERM) (260X178X168) (US DEALERS CONTACT ACDELCO WD FOR ORDERING & PRICING INFO) (ACDelco #101-6YR) (PROFESSIONAL - 6 YR) 15204281 LABEL, BAT WRNG (INCLUDES SYMBOLS ONLY) 11518646 БОЛТ, HEX HD, W/CON WA, M6X1X30, 24.33THD, 17 OD, 9.8, 6138M, BLK (BAT TRAY) 15796853 TRAY, BAT (INCLS 8) 15812692 TRAY, BAT (INCLS 8) 11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (ЧАСТЬ OF 7) [ШАЙБА] 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (BAT TRAY) [БОЛТ М6] 15804414 CABLE, BAT NEG (ACDelco #15804414) 15889973 CABLE, BAT NEG teamcadillac.ru 21021808 ГАЙКА, STRTR SOL BAT TERM (LARGER) (M8X1.25X6, BRASS) (2.343) [ГАЙКА М8] 25785031 CABLE, BAT POS (ACDelco #25785031) 25834437 CABLE, BAT POS (LABELED 25834437) (ACDelco #25834437) 11515535 ГАЙКА, BAT WIRE (2.559) 11517031 ГАЙКА, HFH, M8X1.25, 9.4THK, 17.4 O.D., 10, TIN ZN (BAT POS CBL) 11589258 БОЛТ, BAT NEG CBL GND (M8X1.25X31) [БОЛТ М8] 11517274 STUD, HFH M8X1.25X20, M10X1.5X25, 22.3 OD, 9.8, 6280M. (BAT CBL TERM) (6E02-041) - 2007-2008 EE КРЕПЛЕНИЕ АККУМУЛЯТОРА И КАБЕЛИ (LY7/3.6-7) ↓ 12160209 COVER, BAT NEG CBL TERM (ЧАСТЬ OF 6) (BLACK VINYL) (SURROUNDS CABLE END AT BATT SIDE TERM) 19115561 БОЛТ, HEX HD, 3/8-16X13/32, 1/4 THD, 1 5/32 TOTAL LG, 51/64 O.D., STL, ZP (ЧАСТЬ OF 6) (8.900) (ACDelco #19115561) [БОЛТ М12] 12010049 COVER, BAT NEG CBL БОЛТ (ЧАСТЬ OF 6) (BLACK) (SNAPS ON TO АККУМУЛЯТОР БОЛТ) 11589258 БОЛТ, BAT NEG CBL GND (M8X1.25X31) [БОЛТ М8] 10306471 SENSOR, BAT CUR (ЧАСТЬ OF 6) [КАБЕЛЬНАЯ КЛЕММА] 15804414 CABLE, BAT NEG (INCLS 1-3, 5) (ACDelco #15804414) 12160210 COVER, BAT POS CBL TERM (ЧАСТЬ OF 10) (RED) (SURROUNDS CABLE END AT BATT SIDE TERM) teamcadillac.ru 19115561 БОЛТ, HEX HD, 3/8-16X13/32, 1/4 THD, 1 5/32 TOTAL LG, 51/64 O.D., STL, ZP (ЧАСТЬ OF 10) (8.900) (ACDelco #19115561) [БОЛТ М12] 12010050 COVER, BAT POS CBL БОЛТ (ЧАСТЬ OF 10) (RED) (HAS SLOTTED HOLE) (SNAPS ON TO АККУМУЛЯТОР БОЛТ) 25834437 CABLE, BAT POS (INCLS 7-9, 13) (LABELED 25834437) (ACDelco #25834437) 21021808 ГАЙКА, STRTR SOL BAT TERM (LARGER) (M8X1.25X6, BRASS) (2.343) [ГАЙКА М8] 25751146 GENERATOR, (СМ. ГРУППУ 02.000 "КРЕПЛЕНИЕ ГЕНЕРАТОРА" FOR DETAILLED ILLUSTRATED VIEW) (ACDelco #25751146) [ГЕНЕРАТОР 150 А] 12146809 COVER, GEN WIRE TERM (ЧАСТЬ OF 10) (BLACK) (TERMINAL BOOT COVER) (2.343) 11515535 ГАЙКА, BAT WIRE (2.559) 11610091 ГАЙКА, BAT POS CBL (M8 X 1.25) (8.917) 12608653 STARTER, (СМ. ГРУППУ 02.000 "STARTER MOTOR" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (MAIN АККУМУЛЯТОР TERMINALS AT 1 & 7 O'CLOCK) (ACDelco #12608653) 11518121 ГАЙКА, U, M6X1, MULTI THD, .5'-4.0' THK PNL (AIR INL HSG) 11516589 SCREW, HEX HD W/CON SPR WA, M6X1X30, 29 THD, 17 O.D., 9.8, 7114M, ZE (AIR INL) 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (BAT TRAY) [БОЛТ М6] 15796853 TRAY, BAT (INCLS 17, 19) 25558374 RETAINER, BAT HOLDN (CENTER SLOT) [ФИКСАТОР АККУМУЛЯТОРНОЙ БАТТАРЕИ] 11610388 STUD, HFLGE, M8X1.25X20, M10X1.5X25, 22.3 OD, 9.8, GMW3200 (BAT CBL TERM) 11589407 БОЛТ, HWH, M8X1.25X35, 23.5 THD, 24 OD, 10.9, GMW3359, M-PT. (BAT HOLDN RET) [БОЛТ] 88901964 АККУМУЛЯТОР, (CCA 650) (SIDE TERM) (260X178X168) (US DEALERS CONTACT ACDELCO WD FOR ORDERING & PRICING INFO) (ACDelco #101-6YR) (PROFESSIONAL - 6 YR) 25747792 SHIELD, BAT HT (INSTALLED ON RH SIDE OF CAR) (6E02-042) - 2007-2008 EE КРЕПЛЕНИЕ АККУМУЛЯТОРА И КАБЕЛИ (LH2/4.6A) ↓ 12160209 COVER, BAT NEG CBL TERM (ЧАСТЬ OF 6) (BLACK VINYL) (SURROUNDS CABLE END AT BATT SIDE TERM) 19115561 БОЛТ, HEX HD, 3/8-16X13/32, 1/4 THD, 1 5/32 TOTAL LG, 51/64 O.D., STL, ZP (ЧАСТЬ OF 6) (8.900) (ACDelco #19115561) [БОЛТ М12] 12010049 COVER, BAT NEG CBL БОЛТ (ЧАСТЬ OF 6) (BLACK) (SNAPS ON TO АККУМУЛЯТОР БОЛТ) 11589258 БОЛТ, BAT NEG CBL GND (M8X1.25X31) [БОЛТ М8] 10306471 SENSOR, BAT CUR (ЧАСТЬ OF 6) [КАБЕЛЬНАЯ КЛЕММА] 15804415 CABLE, BAT NEG (INCLS 1-3, 5) (ACDelco #15804415) 11562004 БОЛТ, HEX W/FL WA, M10X1.5X30, 19 THD, 20 OD, 8.8, GMW3200, MACH, M-PT (BAT CBL TERM) 89017760 STARTER, (REMAN) (СМ. ГРУППУ 02.000 "STARTER MOTOR" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #323-1633) (DELCO SERIES PG260H) [СТАРТЕР] 12160210 COVER, BAT POS CBL TERM (ЧАСТЬ OF 12) (RED) (SURROUNDS CABLE END AT BATT SIDE TERM) 19115561 БОЛТ, HEX HD, 3/8-16X13/32, 1/4 THD, 1 5/32 TOTAL LG, 51/64 O.D., STL, ZP (ЧАСТЬ OF 12) (8.900) (ACDelco #19115561) [БОЛТ М12] 12010050 COVER, BAT POS CBL БОЛТ (ЧАСТЬ OF 12) (RED) (HAS SLOTTED HOLE) (SNAPS ON TO АККУМУЛЯТОР БОЛТ) 15804441 CABLE, BAT POS (INCLS 9-11, 16) (ACDelco #15804441) 21021808 ГАЙКА, STRTR SOL BAT TERM (LARGER) (M8X1.25X6, BRASS) (2.343) [ГАЙКА М8] 11504568 ГАЙКА, HEX M5X0.8 PREV TORQ INSERT 9 ZC (STRTR SOL CBL) 25709327 GENERATOR, (СМ. ГРУППУ 02.000 "КРЕПЛЕНИЕ ГЕНЕРАТОРА" FOR DETAILLED ILLUSTRATED VIEW) (ACDelco #25709327) [ГЕНЕРАТОР 150 А] 12146809 COVER, GEN WIRE TERM (ЧАСТЬ OF 12) (BLACK) (TERMINAL BOOT COVER) (2.343) teamcadillac.ru 11515535 ГАЙКА, BAT WIRE (2.559) 11610091 ГАЙКА, BAT POS CBL (M8 X 1.25) (8.917) 11518121 ГАЙКА, U, M6X1, MULTI THD, .5'-4.0' THK PNL (AIR INL HSG) 11518121 ГАЙКА, U, M6X1, MULTI THD, .5'-4.0' THK PNL (ЧАСТЬ OF 25) 11516589 SCREW, HEX HD W/CON SPR WA, M6X1X30, 29 THD, 17 O.D., 9.8, 7114M, ZE (AIR INL) 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (BAT TRAY) [БОЛТ М6] 15796853 TRAY, BAT (INCLS 20, 21) 25558374 RETAINER, BAT HOLDN (CENTER SLOT) [ФИКСАТОР АККУМУЛЯТОРНОЙ БАТТАРЕИ] 11589407 БОЛТ, HWH, M8X1.25X35, 23.5 THD, 24 OD, 10.9, GMW3359, M-PT. (BAT HOLDN RET) [БОЛТ] 88901964 АККУМУЛЯТОР, (CCA 650) (SIDE TERM) (260X178X168) (US DEALERS CONTACT ACDELCO WD FOR ORDERING & PRICING INFO) (ACDelco #101-6YR) (PROFESSIONAL - 6 YR) 25747792 SHIELD, BAT HT (INSTALLED ON RH SIDE OF CAR) (6M02-029) - 2004-2009 E ЖГУТЫ ПРОВОДОВ/ДВИГАТЕЛЬНЫЙ ОТСЕК (LY7/3.6-7) ↓ 25892553 HARNESS, ENG WRG 11562004 БОЛТ, HEX W/FL WA, M10X1.5X30, 19 THD, 20 OD, 8.8, GMW3200, MACH, M-PT (ENG WRG HARN SUPT) teamcadillac.ru 25787958 BLOCK, ENG WRG HARN JUNC 25787959 BLOCK, ENG WRG HARN JUNC [БЛОК УПРАВЛЕНИЯ] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ENG WRG HARN OXY SEN LEAD BRKT) 12589726 BRACKET, ENG WRG HARN OXY SEN LEAD (HOLD POST SENSOR CONN "POSITION 2 CONNECTOR" ЗАДНИЙ) (6M02-037) - 2007-2009 E КРЕПЛЕНИЕ СТАРТЕРА (LY7/3.6-7) ↓ teamcadillac.ru 12608653 STARTER, (MAIN АККУМУЛЯТОР TERMINALS AT 1 & 7 O'CLOCK) (ACDelco #12608653) 12616647 SHIELD, STRTR HT 11588740 БОЛТ, HFH, M10X1.5X40, 30 THD, 22.3 OD, 10.9, GMW3359, M-PT (STRTR) (ACDelco #11588740) (6M02-038) - 2004-2009 E ЖГУТЫ ПРОВОДОВ/ДВИГАТЕЛЬ В СБОРЕ (LY7/3.6-7) ↓ 25892553 HARNESS, ENG WRG 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ENG WRG HARN) 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (ECM) [БОЛТ] 24574534 STUD, ENG WRG HARN BRKT (M6X1X20) (1.166) teamcadillac.ru 11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (ECM BRKT) [БОЛТ] 12585357 BRACKET, ENG WRG HARN OXY SEN LEAD (HOLDS THE PRE SENSOR CONNECTOR "POSITION 1 CONN") 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (WRG HARN BRKT) (6M02-039) - 2007-2009 E СИГНАЛ (U03) ↓ 25824314 СИГНАЛ, 500 HZ (INCLS 3-6) (ACDelco #D1956F) [ЗВУКОВОЙ СИГНАЛ] teamcadillac.ru 25824316 СИГНАЛ, 400 HZ (INCLS 4, 9) (WITHOUT КРЕПЛЕНИЕ БОЛТ.) (ACDelco #D1955F) 25856297 СИГНАЛ, 400 HZ (INCLS 4, 8, 9) (W/КРЕПЛЕНИЕ БОЛТ) (ACDelco #D1963F) [ЗВУКОВОЙ СИГНАЛ] 11516700 БОЛТ, HEX, W/CON WA, M8X1.25X55, 36THD, 24 O.D., AC PT, 9.8, 7114M (ЧАСТЬ OF 7) (6Y02-018) - 2006-2009 E РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ & МОДУЛЬ/ЗАЖИГАНИЕ (LH2/4.6A) ↓ 12597745 РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ, IGN (INCLS 705) (ACDelco #D598A) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 704) 12602860 HARNESS, IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ WRG 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ) teamcadillac.ru 11588967 STUD, BALL W/HFH, M6X1X20.65, 14.2 O.D., 8.8, GMW3359 (IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ) 89018106 BRACKET, IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ (ACDelco #89018106) 03 - ТОПЛИВНАЯ СИСТЕМА - ВЫХЛОПНАЯ - СИСТЕМА ВЫПУСКА ВОЗДУХА ↓ (6D03-070) - 2007-2009 E БЛОК ЭЛЕКТРОННОГО УПРАВЛЕНИЯ И СВЯЗАННЫЕ ДЕТАЛИ (LH2/4.6A) ↓ teamcadillac.ru 15839206 BRACKET, ECM BRKT (INCLS 2, 3, 6) 11562079 STUD - M6X1X30, 1010 STEEL, FINISH GMW3200 (ЧАСТЬ OF 1) 11609669 БОЛТ, HX HD FLT WA, M6X1.0X25.0, GM500M (9.8) STL, GMW3200 (ЧАСТЬ OF 1) [БОЛТ] 12607096 МОДУЛЬ, ENG CONT (W/ 2ND MPU) (REQUIRES PROGRAMMING) (ACDelco #12607096) [БЛОК УПРАВЛЕНИЯ ДВИГАТЕЛЕМ] 11514517 ГАЙКА, HEX, W/CON SPR WA, M6X1, 5.7THK, 18 O.D., 9, 7111M (ЧАСТЬ OF 1) [ГАЙКА М6] (6E03-009) - 2007-2009 EB АКСЕЛЕРАТОР (EXC JF4) ↓ 15263218 PEDAL, ACCEL (INCLS 2, 3) [ПЕДАЛЬ ГАЗА] teamcadillac.ru 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (ACCEL PED LVR) (6E03-010) - 2007-2009 EB АКСЕЛЕРАТОР (JF4) ↓ 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) teamcadillac.ru 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (ACCEL PED LVR) 15861029 PEDAL, ACCEL (INCLS 3, 4) (INCLS SENSOR) 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 89047780 MOTOR KIT, BRK & ACCEL PED ADJR ACTR (INCLS 9) [ЭЛЕКТРОДВИГАТЕЛЬ ПЕДАЛЬНОГО УЗЛА 19 ВТ] 89047778 CABLE, BRK PED ADJR ACTR [ЖГУТ ПРОВОДОВ] 89047779 CABLE, ACCEL CONT (6E03-012) - 2004-2009 E ТОПЛИВНЫЙ БАК & КРЕПЛЕНИЕ ↓ 25862765 CAP, F/TNK FIL LK (0.1KGS) (ACDelco #GT264) [КРЫШКА ТОПЛИВОНАЛИВНОЙ ГОРЛОВИНЫ] 15775325 DOOR, F/TNK FIL (INCLS 6) 11509374 БОЛТ, SCR HEX W/FL WA, SELF TAP, 4.2X1.41X16, 12.5 O.D. (F/TNK FIL PIPE) 25773939 ШЛАНГИ, F/TNK FIL PIPE [КОЖУХ ТОПЛИВОЗАЛИВНОЙ ГОРЛОВИНЫ] 89047657 BUMPER, F/TNK FIL DR (ЧАСТЬ OF 3) (HINGE) [ВТУЛКА] 11609731 RIVET, F/TNK FIL DR (25" SHANK, .63 LEN, .50 OD, .06-.30 GRP RNG, 1008 STL, GMW3044) (8.967) 15868848 PIPE, F/TNK FIL (INCLS 9, 10, 15, 19, 20) [ТРУБКА ТОПЛИВОЗАЛИВНОЙ ГОРЛОВИНЫ] 01470030 CЛАМПА, WORM TYPE (11/16" TO 1 5/16") (ЧАСТЬ OF 8) (ACDelco #1470030) 09177063 CЛАМПА, F/TNK FIL HOSE (ЧАСТЬ OF 12) (25-40MM CЛАМПА RANGE) 15925741 HOSE, F/TNK FIL (INCLS 11) [ШЛАНГ ТОПЛИВНОЙ СИСТЕМЫ] 09177063 CЛАМПА, F/TNK FIL HOSE (25-40MM CЛАМПА RANGE) teamcadillac.ru 11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (F/TNK FIL PIPE BRKT) [БОЛТ М8] 15638098 RETAINER, FUEL RTN PIPE FTG (ЧАСТЬ OF 8) (NATURAL) (NYLON) (5/16") (7.9MM) 11517101 БОЛТ, METRIC HEX FLANGE HD, M10X1.5X50 (F/TNK STRP) [БОЛТ М10] 25679207 STRAP, F/TNK [ЗАЖИМ БЕНЗОБАКА] 12337820 STRAP, 15" TIE STRAP (ЧАСТЬ OF 8) (ACDelco #12337820) 25880365 ПРУЖИНА, F/TNK FIL DR (PRIOR TO INSTALL SEAL VOIDS IN PLUNGER HSG W/FLEXIABLE SEALER) [ЗАЩЕЛКА ЛЮЧКА ТОПЛИВНОЙ ГОРЛОВИНЫ] (6E03-013) - 2004-2009 E СИСТЕМА ТОПЛИВОСНАБЖЕНИЯ (LH2/4.6A) ↓ 15924706 HARNESS, FUEL SDR WRG (3.115) 88965813 SENDER KIT, FUEL (INCLS 24) (FOR AUXILARY МОДУЛЬ) (ACDelco #MU1579) 19177355 CANISTER, EVAP EMIS (CANISTER WITHOUT COVER OR FILTER) (INCLS 39, 43) (ACDelco #215-644) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (EVAP EMIS CNSTR BRKT) [ГАЙКА М6] 15278918 PIPE, EVAP EMIS CNSTR PURGE 15219486 PIPE, FUEL FEED RR (INCLS 35) 15219484 PIPE, FUEL RTN RR 22514722 SEAL, FUEL FEED FRT PIPE (O RING) (ЧАСТЬ OF PIPE, FEED & RTN ASM BUNDLE) (7.35MM ID X 1.66MM THK) (ACDelco #217-452) [КОЛЬЦО УПЛОТНИТЕЛЬНОЕ, ТОПЛИВНОЙ ТРУБКИ] 25763176 ФИЛЬТР, FUEL (ACDelco #GF897) [ТОПЛИВНЫЙ ФИЛЬТР] 11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (FUEL FLTR BRKT) [БОЛТ М8] 25701014 RETAINER, FUEL FLTR 25688547 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (RETAINER W/5 HOLES (2)7.95, (2)4.76, (1)9.52MM) 15270078 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (USES RETAINER PIN FOR ATTACHMENT) [ЗАЖИМ ТРУБКИ ТОПЛИВНОЙ СИСТЕМЫ] 25917777 PIPE, EVAP EMIS CNSTR PURGE 10360402 PIPE, FUEL FEED (INCLS 19) [ТРУБКА ТОПЛИВНОЙ СИСТЕМЫ, СТАЛЬ] 25917776 PIPE, FUEL FEED (INCLS 19) 25761218 BRACKET, FUEL PIPE 25761217 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (3.162) 25765594 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (42.10MM LENGTH) (3.162) [ФИКСАТОР ТОРМОЗНЫХ ТРУБОК] 25679213 PIN, F/TNK UPR SHLD 25679209 SHIELD, F/TNK 25894460 TANK, FUEL (INCLS 21, 26, 27, 31, 33, 34) [ТОПЛИВНЫЙ БАК] 25901272 SEAL, FUEL SDR (ЧАСТЬ OF 2, 28, 44) (ACDelco #G37) 25740096 CAM, FUEL SDR (ACDelco #TR23) 19181827 МОДУЛЬ KIT, F/TNK F/PMP (W/O FUEL LVL SEN) (INCLS 24) (ACDelco #M10201) [ТОПЛИВНЫЙ НАСОС] 25679252 RETAINER, FUEL FEED & EVAP EMIS & RTN FRT PIPE (HOLDS 15.8/7.95/7.0 TUBES, HAS CHRISTMAS TREE RETAINER) (3.162) 15951521 PIPE, FUEL SDR FUEL FEED (INCLS CONN) (PIPE ATTACHES TO SENDING UNITS INSIDE OF GAS TANK) [ТРУБКА ТОПЛИВНОЙ СИСТЕМЫ] 16238399 SENSOR, F/TNK PRESS (ACDelco #16238399) [ДАТЧИК ДАВЛЕНИЯ ПАРОВ ТОПЛИВА] 25726788 RETAINER, BRK & FUEL PIPE (SQUARE HEAD PUSH PIN W/5 HOLES (2)4.76. (2)8.00 (1)9.52) [ФИКСАТОР ТОРМОЗНЫХ ТРУБОК] 25751324 RETAINER, FUEL FEED & EVAP EMIS & RTN FRT PIPE (HOLDS 7.95 & 9.5 DIA FUEL LINE, HAS CHRISTMAS TREE RETAINER) (3.162) teamcadillac.ru 17114722 HOSE, EVAP EMIS CNSTR AIR INL (3.130) (ACDelco #219-366) 17114723 COVER, EVAP EMIS CNSTR AIR INL OPG (ЧАСТЬ OF 3) 19177365 FILTER KIT, EVAP EMIS CNSTR (W/ SEAL) (INCLS 40) 25932573 VALVE, EVAP EMIS CNSTR VENT SOL (ACDelco #214-2230) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 88967139 SENSOR KIT, FUEL LVL (PRIMARY) (INCLS 24) (ACDelco #SK1161) [ТОПЛИВНЫЙ НАСОС] (6E03-016) - 2007-2009 E СИСТЕМА ОТРАБОТАВШИХ ГАЗОВ (LH2/4.6A,EXC CHROME EXHAUST NDB) ↓ 12607145 SENSOR, HTD OXY (POSN 1) (IN EXH MANIFOLD/CROSSOVER) (ACDelco #213-4116) [КИСЛОРОДНЫЙ ДАТЧИК] 15240254 BRACKET, EXH TAIL PIPE HNGR (INCLS 3) [КРОНШТЕЙН] 25902027 BRACKET, EXH TAIL PIPE HNGR (INCLS 3) 15284207 INSULATOR, EXH TAIL PIPE HNGR (ЧАСТЬ OF 2) [ДЕМПФЕР ГЛУШИТЕЛЯ] 15251184 PIPE, EXH TAIL (ЧАСТЬ OF 6) (3.701) teamcadillac.ru 25711603 INSULATOR, EXH MUFF HNGR BRKT (ЧАСТЬ OF 6) 15290902 MUFFLER, EXH (W/RESO, EXH & TAIL PIPE) (INCLS 4, 5) 11517031 ГАЙКА, HFH, M8X1.25, 9.4THK, 17.4 O.D., 10, TIN ZN (EXH MUFF) 12610969 SENSOR, HTD OXY (POSN 3) (POST CONVERTER) (ACDelco #213-4197) [КИСЛОРОДНЫЙ ДАТЧИК] 25709703 SEAL, CTLTC CONV (ЧАСТЬ OF 11) (ROUND METAL SEAL) [ПРОКЛАДКА НАСОСА] 11609596 STUD, CTLTC CONV (ЧАСТЬ OF 11) [ШПИЛЬКА] 12604020 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 9, 10) (3.685) 12607450 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 9, 10) (3.685) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 12607451 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 9, 10) (3.685) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] (6E03-017) - 2004-2009 E СИСТЕМА ТОПЛИВОСНАБЖЕНИЯ (LY7/3.6-7) ↓ 15924706 HARNESS, FUEL SDR WRG (3.115) 88965813 SENDER KIT, FUEL (INCLS 24) (FOR AUXILARY МОДУЛЬ) (ACDelco #MU1579) 19177355 CANISTER, EVAP EMIS (CANISTER WITHOUT COVER OR FILTER) (INCLS 46) (ACDelco #215-644) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (EVAP EMIS CNSTR BRKT) [ГАЙКА М6] 15278918 PIPE, EVAP EMIS CNSTR PURGE 15219486 PIPE, FUEL FEED RR (INCLS 35) 15219484 PIPE, FUEL RTN RR 22514722 SEAL, FUEL FEED FRT PIPE (O RING) (ЧАСТЬ OF PIPE, FEED & RTN ASM BUNDLE) (7.35MM ID X 1.66MM THK) (ЧАСТЬ OF 15) (ACDelco #217-452) [КОЛЬЦО УПЛОТНИТЕЛЬНОЕ, ТОПЛИВНОЙ ТРУБКИ] 25763176 ФИЛЬТР, FUEL (ACDelco #GF897) [ТОПЛИВНЫЙ ФИЛЬТР] 11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (FUEL FLTR BRKT) [БОЛТ М8] 25701014 RETAINER, FUEL FLTR 25688547 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (RETAINER W/5 HOLES (2)7.95, (2)4.76, (1)9.52MM) 25749839 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (HOLDS 3 ТРУБКИ, FLAT SHAPE, SNAP-IN RETAINER) 15888146 PIPE, EVAP EMIS CNSTR PURGE (INCLS 37, 39) 25917777 PIPE, EVAP EMIS CNSTR PURGE (INCLS 37, 39) 15145717 PIPE, FUEL FEED (INCLS 8, 19) 25761218 BRACKET, FUEL PIPE 25679252 RETAINER, FUEL FEED & EVAP EMIS & RTN FRT PIPE (HOLDS 15.8/7.95/7.0 TUBES, HAS CHRISTMAS TREE RETAINER) (3.162) 25679213 PIN, F/TNK UPR SHLD 25679209 SHIELD, F/TNK 25894460 TANK, FUEL (INCLS 21, 26, 27, 31, 33, 34) [ТОПЛИВНЫЙ БАК] 25901272 SEAL, FUEL SDR (ЧАСТЬ OF 2, 28, 47) (ACDelco #G37) 25740096 CAM, FUEL SDR (ACDelco #TR23) 19181827 МОДУЛЬ KIT, F/TNK F/PMP (W/O FUEL LVL SEN) (INCLS 24) (ACDelco #M10201) [ТОПЛИВНЫЙ НАСОС] 25679252 RETAINER, FUEL FEED & EVAP EMIS & RTN FRT PIPE (HOLDS 15.8/7.95/7.0 TUBES, HAS CHRISTMAS TREE RETAINER) (3.162) 15951521 PIPE, FUEL SDR FUEL FEED (INCLS CONN) (PIPE ATTACHES TO SENDING UNITS INSIDE OF GAS TANK) [ТРУБКА ТОПЛИВНОЙ СИСТЕМЫ] 16238399 SENSOR, F/TNK PRESS (ACDelco #16238399) [ДАТЧИК ДАВЛЕНИЯ ПАРОВ ТОПЛИВА] 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (FUEL FEED & EVAP EMIS & RTN PIPE CLIP BRKT) [БОЛТ М6] 25654373 CLIP, FUEL FEED & RTN HOSE (PLASTIC) (ЧАСТЬ OF FUEL & BRAKELINE BUNDLE НИЖНЯЯ ЧАСТЬ; POSITION 2, 4, 5) 25726788 RETAINER, BRK & FUEL PIPE (SQUARE HEAD PUSH PIN W/5 HOLES (2)4.76. (2)8.00 (1)9.52) [ФИКСАТОР ТОРМОЗНЫХ ТРУБОК] teamcadillac.ru 17114722 HOSE, EVAP EMIS CNSTR AIR INL (3.130) (ACDelco #219-366) 17114723 COVER, EVAP EMIS CNSTR AIR INL OPG (ЧАСТЬ OF 44) 19177365 FILTER KIT, EVAP EMIS CNSTR (W/ SEAL) (INCLS 42, 43) 25932573 VALVE, EVAP EMIS CNSTR VENT SOL (ACDelco #214-2230) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 88967139 SENSOR KIT, FUEL LVL (PRIMARY) (INCLS 24) (ACDelco #SK1161) [ТОПЛИВНЫЙ НАСОС] (6E03-018) - 2004-2007 E СИСТЕМА ОТРАБОТАВШИХ ГАЗОВ (LY7/3.6-7) ↓ 15240254 BRACKET, EXH TAIL PIPE HNGR (INCLS 2) [КРОНШТЕЙН] 25902027 BRACKET, EXH TAIL PIPE HNGR (INCLS 2) 15284207 INSULATOR, EXH TAIL PIPE HNGR (ЧАСТЬ OF 1) [ДЕМПФЕР ГЛУШИТЕЛЯ] 25711603 INSULATOR, EXH MUFF HNGR BRKT (ЧАСТЬ OF 5) 15251183 PIPE, EXH TAIL (ЧАСТЬ OF 5) 15233284 MUFFLER, EXH (W/RESO, EXH & TAIL PIPE) (INCLS 3, 4) 15290901 MUFFLER, EXH (W/RESO, EXH & TAIL PIPE) (INCLS 3, 4) 15790974 MUFFLER, EXH (W/RESO, EXH & TAIL PIPE) (INCLS 3, 4) 15832122 MUFFLER, EXH (W/RESO, EXH & TAIL PIPE) (INCLS 3, 4) 15832123 MUFFLER, EXH (W/RESO, EXH & TAIL PIPE) (INCLS 3, 4) 11517031 ГАЙКА, HFH, M8X1.25, 9.4THK, 17.4 O.D., 10, TIN ZN (EXH MUFF) teamcadillac.ru 12597449 SENSOR, HTD OXY (POSN 2) (POST CONVERTER) (ACDelco #213-3851) [КИСЛОРОДНЫЙ ДАТЧИК] 25768055 SEAL, CTLTC CONV (ЧАСТЬ OF 9) (SEAL WITH COVER ATTACHED) [УПЛОТНЕНИЕ КАТАЛИТИЧЕСКОГО НЕЙТРАЛИЗАТОРА] 12622977 CONVERTER, 3WAY CTLTC (INCLS 8, 10, 12, 13) [КАТАЛИТИЧЕСКИЙ НЕЙТРАЛИЗАТОР ВЫХЛОПНЫХ ГАЗОВ] 12622978 CONVERTER, 3WAY CTLTC (INCLS 8, 10, 12, 13) [КАТАЛИТИЧЕСКИЙ НЕЙТРАЛИЗАТОР ВЫХЛОПНЫХ ГАЗОВ] 15790977 CONVERTER, 3WAY CTLTC (INCLS 8, 10, 12, 13) 11609596 STUD, CTLTC CONV (ЧАСТЬ OF 9) [ШПИЛЬКА] 12594935 SENSOR, HTD OXY (POSN 1) (IN EXH MANIFOLD/CROSSOVER) (ACDelco #213-3850) [ДАТЧИК КИСЛОРОДНЫЙ] 11589264 STUD, STRAIGHT, M10X1.5X30, M10X1.5X16, 57 TL, SS (ЧАСТЬ OF 9) [ШПИЛЬКА М8] 12571101 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 12571102 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 15709703 ГАЙКА, HEX 10X1.5THD, 21.8 OD SS (CTLTC CONV) [ГАЙКА М10] (6E03-019) - 2007-2009 E БЛОК ЭЛЕКТРОННОГО УПРАВЛЕНИЯ И СВЯЗАННЫЕ ДЕТАЛИ (LY7/3.6-7) ↓ teamcadillac.ru 12605670 МОДУЛЬ, ENG CONT (W/O CALN & OPERG SYS) (ACDelco #216-130) [БЛОК УПРАВЛЕНИЯ ДВИГАТЕЛЕМ] 25784072 BRACKET, ECM (INCLS 5, 6) 24239785 МОДУЛЬ, TRANS CONT 11609462 SCREW, M4.2X1.41X13, GMW4205 (ЧАСТЬ OF 3) 11561758 БОЛТ, MULTIUSE RLY & FUSE BRKT (7.833) [БОЛТ] 15879156 BRACKET, ACSRY WRG J/BLK 11609599 STUD, SPL, M6X1X25, 13 THD, 11 OD HD W/26 WIDE CLIP, 9.8, 6280M, P-PT (MULTIUSE FUSE BRKT) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (MULTIUSE RLY & FUSE BRKT) [ГАЙКА М6] (6E03-020) - 2007-2008 EE АКСЕЛЕРАТОР ↓ 89047780 MOTOR KIT, BRK & ACCEL PED ADJR ACTR [ЭЛЕКТРОДВИГАТЕЛЬ ПЕДАЛЬНОГО УЗЛА 19 ВТ] 19153364 CABLE, ACCEL CONT 15791726 PEDAL, ACCEL (INCLS 5, 6) 25885516 PEDAL, ACCEL (INCLS 5, 6) 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] teamcadillac.ru 19153363 CABLE, BRK PED ADJR ACTR (6E03-021) - 2007-2009 E СИСТЕМА ОТРАБОТАВШИХ ГАЗОВ (LH2/4.6A, CHROME EXHAUST NDB) ↓ 12607145 SENSOR, HTD OXY (POSN 1) (IN EXH MANIFOLD/CROSSOVER) (ACDelco #213-4116) [КИСЛОРОДНЫЙ ДАТЧИК] 15240254 BRACKET, EXH TAIL PIPE HNGR (INCLS 3) [КРОНШТЕЙН] 25902027 BRACKET, EXH TAIL PIPE HNGR (INCLS 3) 15284207 INSULATOR, EXH TAIL PIPE HNGR (ЧАСТЬ OF 2) [ДЕМПФЕР ГЛУШИТЕЛЯ] 15251184 PIPE, EXH TAIL (ЧАСТЬ OF 7) (3.701) 15828673 EXTENSION, EXH TAIL PIPE (ЧАСТЬ OF 7) 25711603 INSULATOR, EXH MUFF HNGR BRKT (ЧАСТЬ OF 7) teamcadillac.ru 15832125 MUFFLER, EXH (W/RESO, EXH & TAIL PIPE) (INCLS 4-6) 11517031 ГАЙКА, HFH, M8X1.25, 9.4THK, 17.4 O.D., 10, TIN ZN (EXH MUFF) 12609159 SENSOR, HTD OXY (POSN 2) (POST CONVERTER) (ACDelco #213-4156) [ДАТЧИК КИСЛОРОДНЫЙ] 25709703 SEAL, CTLTC CONV (ЧАСТЬ OF 11) (ROUND METAL SEAL) [ПРОКЛАДКА НАСОСА] 12607450 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 10, 12) (3.685) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 12607451 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 10, 12) (3.685) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 11609596 STUD, CTLTC CONV (ЧАСТЬ OF 11) [ШПИЛЬКА] (6E03-022) - 2007-2009 E СИСТЕМА ВПУСКА ВОЗДУХА (LH2/4.6A) ↓ 25798271 ELEMENT, КОНДИЦИОНЕРL (ACDelco #A2944C) [ВОЗДУШНЫЙ ФИЛЬТР ДВИГАТЕЛЯ] 11561910 БОЛТ, КОНДИЦИОНЕРL (M6X1.0X24) (T30 TORQ) (SHLDR W/FL WA) 19151529 COVER, КОНДИЦИОНЕРL HSG LWR (INCLS 2, 3, 7) [КРЫШКА ВОЗДУХОЗАБОРНИКА] 11561910 БОЛТ, КОНДИЦИОНЕРL (M6X1.0X24) (T30 TORQ) (SHLDR W/FL WA) teamcadillac.ru 19177871 INSULATOR, КОНДИЦИОНЕРL HSG (ЧАСТЬ OF 5) (MOUNT TO MID RAIL) 11609385 ГАЙКА, U-TYPE, M6X1, 29.5 LEN, 12.5 WID, 19.5 CEN-END, 1050, GMW3359 (КОНДИЦИОНЕРL) [ГАЙКА М 6] 15833712 DUCT, RR INT AIR (W/RESO) (INCLS 9) [ШЛАНГ ВОЗДУХООЧИСТИТЕЛЯ] 15865791 SENSOR, MASS AIRFLOW (W/INT AIR TEMP SEN) (ЧАСТЬ OF 14) (MASS AIRFLOW SENSOR LABELED 5791 LESS GASKET) (ACDelco #213-4222) [ДАТЧИК РАСХОДА ВОЗДУХА] 25805631 ADAPTER, MASS AIRFLOW SEN INL (INCLS 12, 13) [АДАПТЕР ПОТОКОВ ВОЗДУХА] 15147461 GASKET, MASS AIRFLOW SEN (ROUND) 11516424 БОЛТ, HFH, M6X1X25, 14.2 O.D., HDR PT, 9.8, ZE (MASS AIRFLOW SEN) [БОЛТ М6] 15147459 COVER, КОНДИЦИОНЕРL HSG (INCLS 11) [КРЫШКА ВОЗДУХООЧИСТИТЕЛЯ] (6E03-023) - 2007-2009 E СИСТЕМА ВПУСКА ВОЗДУХА (LY7/3.6-7) ↓ 25798271 ELEMENT, КОНДИЦИОНЕРL (ACDelco #A2944C) [ВОЗДУШНЫЙ ФИЛЬТР ДВИГАТЕЛЯ] 11588831 SCREW, HEX W/ CON WA, M6X1X35, 33.5 THD, 17 O.D.HDR PT, 9.8, BLK (КОНДИЦИОНЕРL) 19151528 COVER, КОНДИЦИОНЕРL HSG LWR (INCLS 2, 3, 7) [КРЫШКА ВОЗДУХООЧИСТИТЕЛЯ] 11561910 БОЛТ, КОНДИЦИОНЕРL (M6X1.0X24) (T30 TORQ) (SHLDR W/FL WA) 19177871 INSULATOR, КОНДИЦИОНЕРL HSG (ЧАСТЬ OF 5) (MOUNT TO MID RAIL) 11609385 ГАЙКА, U-TYPE, M6X1, 29.5 LEN, 12.5 WID, 19.5 CEN-END, 1050, GMW3359 (КОНДИЦИОНЕРL) [ГАЙКА М 6] 25733253 CЛАМПА, RR INT AIR DUCT (ЧАСТЬ OF 10) (FLEX END) 15812947 DUCT, RR INT AIR (W/RESO) (INCLS 9, 11) 25733254 CЛАМПА, RR INT AIR DUCT (ЧАСТЬ OF 10) (ELBOW END) 10356575 БОЛТ, MASS AIRFLOW SEN (ЧАСТЬ OF 16) 15875837 SENSOR, MASS AIRFLOW (ACDelco #213-4250) [ДАТЧИК] teamcadillac.ru 15147456 GASKET, MASS AIRFLOW SEN 11516424 БОЛТ, HFH, M6X1X25, 14.2 O.D., HDR PT, 9.8, ZE (КОНДИЦИОНЕРL HSG) [БОЛТ М6] 15147455 COVER, КОНДИЦИОНЕРL HSG (INCLS 12) [КРЫШКА ВОЗДУШНОГО ФИЛЬТРА] (6M03-088) - 2004-2009 E РАМКА ТОПЛИВНОГО ИНЖЕКТОРА (LY7/3.6-7) ↓ 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (WRG HARN BRKT) 12596182 HARNESS, F/INJR WRG (INCLS 2) (IF REPL 12584312 MAY NEED TO INSTALL BRACKET FROM HARNESS.) 25532662 CAP, FUEL PRESS SERV VLV (CAP FOR PRESSURE TEST SCHRADER VALVE) (*KIT2) (3.163) (ACDelco #214-1044) [КРЫШКА] 12572886 RAIL, F/INJN FUEL (INCLS 5, 9) (ACDelco #217-1551) [МАГИСТРАЛЬ ТОПЛИВНЫХ ФОРСУНОК ДВИГАТЕЛЯ] 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (F/INJN FUEL RL) [БОЛТ] teamcadillac.ru 12609418 INJECTOR, M/PORT FUEL (INCLS 8, 11) (ACDelco #217-3034) 12597872 SEAL KIT, F/INJR (O RING) (INCLS 8, 11) (ACDelco #217-2444) 12584592 VALVE KIT, FUEL PRESS SERV (INCLS 4, 5) (INCLUDES CAP AND VALVE) (ACDelco #12584592) [КЛАПАН] 12584591 RETAINER KIT, F/INJR (INCLS 9) (ACDelco #12584591) [ОПОРНАЯ ПЛАСТИНА ТОПЛИВНОЙ ФОРСУНКИ] (6M03-090) - 2007-2009 E РАМКА ТОПЛИВНОГО ИНЖЕКТОРА (LH2/4.6A) ↓ 12598329 RAIL KIT, SEQ M/PORT F/INJN FUEL (ACDelco #X2598329) 12597871 INJECTOR KIT, SEQ M/PORT FUEL (INCLS 562-564) (ACDelco #217-2443) [ТОПЛИВНАЯ ФОРСУНКА] 25532662 CAP, FUEL PRESS SERV VLV (CAP FOR PRESSURE TEST SCHRADER VALVE) (*KIT3) (3.163) (ACDelco #214-1044) [КРЫШКА] 12574525 VALVE, FUEL PRESS SERV (SCHRADER VALVE LESS CAP) (*KIT3) [КЛАПАН КОНТРОЛЯ ДАВЛЕНИЯ ТОПЛИВНОЙ СИСТЕМЫ] teamcadillac.ru 12584591 RETAINER KIT, F/INJR (INCLS 562) (ACDelco #12584591) [ОПОРНАЯ ПЛАСТИНА ТОПЛИВНОЙ ФОРСУНКИ] 12597872 SEAL KIT, F/INJR (O RING) (INCLS 563, 564) (ACDelco #217-2444) 12584592 VALVE KIT, FUEL PRESS SERV (INCLS 565, 566) (INCLUDES CAP AND VALVE) (ACDelco #12584592) [КЛАПАН] 04 - АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ↓ (6D00-036) - 2007-2008 E ТРАНСМИССИЯ TO КРЕПЛЕНИЕ ДВИГАТЕЛЯ (LH2/4.6A) ↓ 12582606 FLYКОЛЕСО, ENG 25773136 BRACKET, ENG WRG HARN (CHANNEL) 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] 24205900 PLUG, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] 24205899 PLUG, T/CV HSG ACC HOLE (28MM W/3 TANGS) (SMALL CVR) (ACDelco #24205899) 11589116 БОЛТ, FLYWHL (8.900) teamcadillac.ru 12568122 COVER, FLYWHL HSG 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (TRANS CONV CVR) (ACDelco #11517518) [БОЛТ] 12568123 COVER, TRANS CONV (6D04-023) - 2004-2009 E СТОЯНОЧНЫЙ ТОРМОЗ ASM ↓ 88951984 PLATE, RR PARK BRK ANC BKG (4.591) 88951985 PLATE, RR PARK BRK ANC BKG (4.591) 88951982 ACTUATOR KIT, RR PARK BRK (INCLS 2) (ACDelco #179-2053) [АКТУАТОР] 88951983 ACTUATOR KIT, RR PARK BRK (INCLS 2) (ACDelco #179-2054) [АКТУАТОР] 89047676 SHOE KIT, RR PARK BRK (INCLS 5) (ACDelco #171-0915) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (2 ШТ)] (6D04-031) - 2004-2009 E ТОРМОЗНОЙ СУППОРТ-ЗАДНИЙ ↓ 89047677 CALIPER KIT, RR BRK (INCLS 2, 3, 7-9) (ACDelco #172-2343) 89047678 CALIPER KIT, RR BRK (INCLS 2, 3, 7-9) (ACDelco #172-2344) [ТОРМОЗНОЙ СУППОРТ] 88951992 CAP, RR BRK BLEDR VLV (ЧАСТЬ OF 1) 88951991 VALVE, RR BRK CLPR BLEDR (ЧАСТЬ OF 1) 89047757 PAD KIT, RR DISC BRK (INCLS 4, 12) (ACDelco #171-859) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4 ШТ)] 89047758 PAD KIT, RR DISC BRK (INCLS 4, 12) (4.667) (ACDelco #171-0906) [ТОРМОЗНЫЕ КОЛОДКИ] 88957163 BRACKET, RR BRK CLPR [СКОБА ТОРМОЗНОГО СУППОРТА] 89047759 PIN KIT, RR BRK CLPR GDE (INCLS 4-6) (INCLS 2 PINS, 2 SEALS & 2 (2.75") БОЛТS) (ACDelco #179-2044) [НАПРАВЛЯЮЩАЯ ТОРМОЗНОГО СУППОРТА (2 ШТ)] teamcadillac.ru 88957162 REPAIR KIT, RR BRK CLPR HYD (INCLS 4, 6, 8, 9) (6D04-033) - 2004-2009 E ТОРМОЗНОЙ УСИЛИТЕЛЬ ↓ 88967237 BOOSTER, P/B (W/O VLV) (ACDelco #178-0695) 05461808 GROMMET, P/B BOOS VAC CHK VLV (*KIT1) teamcadillac.ru 03817880 RETAINER, BRK PED PUSH ROD (0.80 IN) (PUSH IN) 18022219 VALVE KIT, P/B BOOS VAC CHK (INCLS 2, 3) (BLACK) (INCLS VLV & GROM) (ACDelco #179-1266) (6D04-067) - 2007-2009 E КОРПУС КП КРЕПЛЕНИЕ (MYB,MX7) ↓ 24231525 GASKET, TRFER CASE teamcadillac.ru 19132968 CASE, TRFER (W/GEARS) (LESS DAMPENER) 24243367 CASE, TRFER (W/GEARS) 11589341 БОЛТ - HFH, M10X1.5X69.9, 28.35 THD, 22.3 OD, 10.9, GMW3359, M-PT. (TRFER CASE) [БОЛТ] (6E00-014) - 2004-2009 E ТРАНСМИССИЯ TO КРЕПЛЕНИЕ ДВИГАТЕЛЯ (LY7/3.6-7) ↓ 12572042 PLATE, A/TRNS FLEX 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (TRANS CVR) [БОЛТ] teamcadillac.ru 24222918 COVER, TRANS CONV 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] (6E03-019) - 2007-2009 E T.C.M. МОДУЛЬ (LY7/3.6-7) ↓ teamcadillac.ru 12605670 МОДУЛЬ, ENG CONT (W/O CALN & OPERG SYS) (ACDelco #216-130) [БЛОК УПРАВЛЕНИЯ ДВИГАТЕЛЕМ] 25784072 BRACKET, ECM (INCLS 5, 6) 24239785 МОДУЛЬ, TRANS CONT 11609462 SCREW, M4.2X1.41X13, GMW4205 (ЧАСТЬ OF 3) 11561758 БОЛТ, MULTIUSE RLY & FUSE BRKT (7.833) [БОЛТ] 15879156 BRACKET, ACSRY WRG J/BLK 11609599 STUD, SPL, M6X1X25, 13 THD, 11 OD HD W/26 WIDE CLIP, 9.8, 6280M, P-PT (MULTIUSE FUSE BRKT) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (MULTIUSE RLY & FUSE BRKT) [ГАЙКА М6] (6E04-007) - 2007-2009 EB ТОРМОЗНЫЕ ШЛАНГИ И ТРУБКИ ↓ 15933099 HOSE, FRT BRK (INCLS 15, 16) (ACDelco #176-1495) 11569742 RETAINER, FRT BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (BRK & FUEL FEED & FUEL RTN & EVAP EMIS) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА] 25761218 BRACKET, FUEL PIPE 25761217 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (3.162) 12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (FRT BRK) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА] 10388788 PIPE, BRK PRESS MOD VLV FRT (INCLS 29) 10388794 PIPE, BRK PRESS MOD VLV RR (INCLS 29) 03541444 SPACER, FRT BRK PIPE 11516521 БОЛТ, HFH M6X1X20, 9.8, 7114M, DOG PT, 14.2 OD (FRT BRK HOSE) 15933098 HOSE, FRT BRK (INCLS 15, 16) (ACDelco #176-1487) 25743891 RETAINER, RR BRK FRT PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT) 11569737 FITTING, FRT BRK PIPE (ЧАСТЬ OF 1, 12) (7/16-24X0.36, 0.30THD) (0.56 LONG, 3/16TUBE) 25743891 RETAINER, FRT BRK PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT) 25737279 CLIP, FRT BRK PIPE (THREE WAY RETAINER SINGLE CENTRAL FIR-TREE ATTACHMENT) 15270078 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (USES RETAINER PIN FOR ATTACHMENT) [ЗАЖИМ ТРУБКИ ТОПЛИВНОЙ СИСТЕМЫ] 25688547 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (RETAINER W/5 HOLES (2)7.95, (2)4.76, (1)9.52MM) 25749839 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (HOLDS 3 ТРУБКИ, FLAT SHAPE, SNAP-IN RETAINER) 25607191 RETAINER, BRK PIPE (21.5X10.0MM) (HOLDS (2) 4.68-4.82 TUBES) teamcadillac.ru 11569742 RETAINER, RR BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 15724650 ГАЙКА, INVERTED FLARED TUBE, 9/16"-18, 1/4" TUBE, ZD (BRK PIPE) (4.686) [ГАЙКА] 25693890 RETAINER, RR BRK PIPE (HOLDS (1) 4.76 LINE) (W/TREE) [ЗАМОК, ФИКСАТОР] 11588803 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 7, 8) (1/2-20X.40, .32 THD) (INVERTED FLARED TUBE) (.62 LONG, 1/4 TUBE) [ГАЙКА М20] 15724650 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 7, 8) (9/16-18 X .40) (INVERTED FLARED TUBE) [ГАЙКА] 15933091 HOSE, RR BRK (INCLS 22, 23) (ACDelco #15933091) 15933092 HOSE, RR BRK (INCLS 22, 23) (ACDelco #15933092) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ] 88964150 PROTECTOR, FRT BRK PIPE (FOR 3/16" PIPE) (HT SHRINK) (6E04-008) - 2007-2009 EB ТОРМОЗНАЯ ПЕДАЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (EXC (JF4)) ↓ 25732428 BARRIER, BRK PED BRKT SND 25697461 RETAINER, BRK PED PUSH ROD BOOT 25732452 BOOT, BRK PED PUSH ROD 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) teamcadillac.ru 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] 15932827 HOSE, P/B BOOS VAC (ACDelco #176-1496) 25765419 PEDAL, BRK (W/BRKT) (INCLS 10, 11, 14, 16-18) 25771615 COVER, BRK PED (ЧАСТЬ OF 9) 89047699 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 9) [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 9) 10434956 BUSHING, BRK PED PUSH ROD 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 9) 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 9) (0.80 IN) (PUSH IN) (6E04-012) - 2007-2009 E КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS(MYB,MX7) ↓ 88996677 CASE, TRFER (FRT HALF) (INCLS 12-14) 19133265 CASE, TRFER (RR HALF) (INCLS 5, 7) 88996679 SNUBBER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN 88996680 БОЛТ, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN SNBR (M5X0.8X16) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 2) 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL FILL) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] teamcadillac.ru 88996657 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 2) [УПЛОТНИТЕЛЬ] 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL DRN) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996680 БОЛТ, TRFER CASE VENT BFL (M5X0.8X16) (4.535) 88996658 BAFFLE, TRFER CASE VENT 89048123 БОЛТ, TRFER CASE HALF (M8X1.25X30) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 1) 88996656 SEAL, TRFER CASE INPUT SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 88996657 SEAL, TRFER CASE FRT ВЫХОДНОЙ SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] (6E04-013) - 2007-2009 E КОРПУС КП ЧАСТЬ 2 INTERNAL COMPONENTS(MYB,MX7) ↓ 88984517 WASHER, TRFER CASE PLNT CARR SUN GR THR (25.8X52.0X2.2) 88984524 GEAR, TRFER CASE PLNT CARR SUN (INPUT) (STAMPED PM/POWDERED METAL) 88984493 RING, TRFER CASE RR ВЫХОДНОЙ SHF RR BRG RET (41MM I.D.) (ACDelco #88984493) 88996564 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT teamcadillac.ru 88996665 BEARING, TRFER CASE MAIN SHF FRT (ВЫХОДНОЙ ВАЛ FRT) 19168733 BUSHING, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 106) [ВТУЛКА РАЗДАТОЧНОЙ КОРОБКИ] 19178238 SHAFT, TRFER CASE RR ВЫХОДНОЙ (INCLS 105) 19133264 SPROCKET, TRFER CASE FRT ВЫХОДНОЙ SHF DRV (INCLS 108) [ШЕСТЕРНЯ РАЗДАТОЧНОЙ КОРОБКИ] 19168732 BUSHING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT (ЧАСТЬ OF 107) (ACDelco #19168732) 19132837 CHAIN, TRFER CASE TWO/FOUR WHL DRV 88984523 GEAR, TRFER CASE PLNT CARR SUN (ВЫХОДНОЙ) 89059279 КРОНШТЕЙН, FRT/RR DRV DIFF 89059284 SHAFT, TRFER CASE FRT ВЫХОДНОЙ (INCLS 900) 88996664 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF RR 88996671 RING, TRFER CASE FRT ВЫХОДНОЙ SHF BRG RET 88996666 SPROCKET, TRFER CASE TWO/FOUR WHL DRV DRVN [ЗВЕЗДОЧКА] 88996633 BEARING, TRFER CASE RR ВЫХОДНОЙ SHF RR (ACDelco #88996633) [ПОДШИПНИК РАЗДАТОЧНОЙ КОРОБКИ] 15580230 BEARING, TRFER CASE INPUT SHF (BORG-WARNER) (4.510) 19132966 SHAFT, TRFER CASE INPUT 88996681 DEFLECTOR, TRFER CASE FRT ВЫХОДНОЙ SHF SEAL DIRT (ЧАСТЬ OF 112) (6E04-016) - 2004-2009 E КЛАПАН РЕГУЛИРОВКИ ДАВЛЕНИЯ В ТОРМОЗНОЙ СИСТЕМЕ ↓ 19153350 МОДУЛЬ KIT, ELEK BRK & TRACT CONT [МОДУЛЬ] 89060233 VALVE KIT, BRK PRESS MOD (INCLS 3, 4) (ACDelco #89060233) [ГИДРАВЛИЧЕСКИЙ БЛОК АБС] 25743362 SENSOR, BRK PRESS MOD VLV PRESS (ЧАСТЬ OF 2) (ACDelco #25743362) [ДАТЧИК] 25741456 INSULATOR, BRK PRESS MOD VLV (ЧАСТЬ OF 2) 11588304 STUD, FLANGE DOUBLE END, M8X14 UNTHD, M8X1.25X13, 17 OD, 5.8, GM4345M (BRK PRESS MOD VLV BRKT) 11514596 ГАЙКА, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (BRK PRESS MOD VLV BRKT) (8.915) (ACDelco #11514596) teamcadillac.ru 11508351 SCREW, PAN HD, C/R, 5X0.8X13, 9.3 OD, FULL THD, THD RLLR, 6171M, PC (BRK PRESS MOD VLV) (8.977) (6E04-017) - 2007-2009 E ШЛАНГ ВЕНТИЛЯЦИИ ТРАНСМИССИИ (LY7/3.6-7, M82,MX5) ↓ 25764835 VENT, A/TRNS (INCLS 2, 3) (ACDelco #25764835) teamcadillac.ru 15955072 CLIP, TRANS VENT HOSE (ЧАСТЬ OF 1) (.650MM DIA) (2.343) (6E04-018) - 2004-2009 E КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS(MX5) ↓ 88996677 CASE, TRFER (FRT HALF) (INCLS 12-14) 19133265 CASE, TRFER (RR HALF) (INCLS 5, 7) 88996679 SNUBBER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN 88996680 БОЛТ, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN SNBR (M5X0.8X16) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 2) 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL FILL) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996657 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 2) [УПЛОТНИТЕЛЬ] 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL DRN) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996680 БОЛТ, TRFER CASE VENT BFL (M5X0.8X16) (4.535) 88996658 BAFFLE, TRFER CASE VENT 89048123 БОЛТ, TRFER CASE HALF (M8X1.25X30) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 1) 88996656 SEAL, TRFER CASE INPUT SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 88996657 SEAL, TRFER CASE FRT ВЫХОДНОЙ SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 19180066 VENT, TRFER CASE 89048123 БОЛТ, TRFER CASE VIB DPNR (M8X1.25X30) 19133173 DAMPENER, TRFER CASE VIB (YOKE STYLE; БОЛТS TO RR OF T-CASE) (6E04-020) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ 24218963 RING, T/CV FLUID SEAL RET [КОЛЬЦО] 24237531 SEAL, T/CV FLUID (ЧАСТЬ OF 217, 219) (ACDelco #24237531) [УПЛОТНЕНИЕ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 00444613 PLUG, HEX HD, 1/8-27 NPTF, STL (LINE PRESS TEST HOLE) (ACDelco #444613) 24239385 ШЛАНГИ, T/CV (MCHG) (INCLS 206) 24225422 PIPE, A/TRNS VENT 15251488 SEAL, TRANS FLUID CLR PIPE FTG (ЧАСТЬ OF 217, 219) (SEALS TWO ТРУБКИ) (*KIT1) [УПЛОТНЕНИЕ] 24237658 SEAL, TRANS FLUID CLR PIPE FTG (ЧАСТЬ OF 217, 219) (SEALS ONE PIPE) (*KIT1) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ] teamcadillac.ru 24222668 SLIDE, A/TRNS ГИДРОНАСОС (17.948MM-17.961MM) (ACDelco #24222668) 24224131 SLIDE, A/TRNS ГИДРОНАСОС (17.961MM-17.974MM) (ACDelco #24224131) 24224132 SLIDE, A/TRNS ГИДРОНАСОС (17.974MM-17.987MM) (ACDelco #24224132) 24238915 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 207-211, 213-216, 230) (17.948MM-17.961MM) (ACDelco #24238915) 24238916 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 207-211, 213-216, 230) (17.961MM-17.974MM) (ACDelco #24238916) 24238917 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 207-211, 213-216, 230) (17.974MM-17.987MM) (ACDelco #24238917) 24238919 COVER KIT, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 218, 220-230, 232-237) (ACDelco #24238919) 00147500 VALVE, PRESS RLF BALL (ЧАСТЬ OF 219) 24224692 WASHER, 1-2-3-4 & 3-5 REV CLU HSG THR (ЧАСТЬ OF 219) 24239151 RING, 1-2-3-4 & 3-5 REV CLU FLUID SEAL (ЧАСТЬ OF 217, 219) (*KIT1) (ACDelco #24239151) 24227061 БОЛТ, A/TRNS ГИДРОНАСОС CVR (ACDelco #24227061) [БОЛТ] 90351709 PIN, A/TRNS ГИДРОНАСОС LOC (ЧАСТЬ OF 219) ("8MM HOLLOW SPLIT PIN") (1.639) [ШПИЛЬКА] 24243891 SEAL KIT, A/TRNS SERV (INCLS 205, 210, 214, 230) (FULL TRANS) (ACDelco #24243891) (6E04-022) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (LY7/3.6-7, V92) ↓ 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 89022494 BRACKET, TRANS FLUID CLR 19129782 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) [ТРУБКА МАСЛООХЛАДИТЕЛЯ] 19130214 SEAL, TRANS FLUID CLR HOSE CONN (O RING) 19129781 HOSE, TRANS FLUID CLR LWR (W/BLOCK) 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] teamcadillac.ru 89022522 COOLER, TRANS FLUID (INCLS 7-10) (6E04-024) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (LH2/4.6A, EXC V92) ↓ 88957425 COOLER, TRANS FLUID (INCLS 7-9) (ACDelco #88957425) [ВЕНТИЛЯТОР] 11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) [БОЛТ, М8Х1.25Х31.5] teamcadillac.ru 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 15251488 SEAL, TRANS FLUID CLR PIPE FTG (ЧАСТЬ OF 5) (SEALS TWO ТРУБКИ) [УПЛОТНЕНИЕ] 15882260 PIPE, TRANS FLUID CLR INL & OTLT (INCLS 4, 6) [ТРУБКА МАСЛОПРОВОДА] 10405874 CLIP, TRANS FLUID CLR PIPE (ЧАСТЬ OF 5) (LESS MNTG TAB) (HOLDS TWO 9.5 DIA TUBES) 11570323 БОЛТ, КОНДИЦИОНЕР CNDSR (M6X1X18, 13 THD) (1.277) 15921020 CLIP, TRANS FLUID AUX CLR PIPE (CYLINDRICAL) (1 PIPE) (6E04-025) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (LH2/4.6A, V92) ↓ 89022522 COOLER, TRANS FLUID (INCLS 7-10) 11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) [БОЛТ, М8Х1.25Х31.5] 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 15882260 PIPE, TRANS FLUID CLR INL & OTLT (INCLS 4, 6) [ТРУБКА МАСЛОПРОВОДА] 10405874 CLIP, TRANS FLUID CLR PIPE (ЧАСТЬ OF 5) (LESS MNTG TAB) (HOLDS TWO 9.5 DIA TUBES) teamcadillac.ru 15921020 CLIP, TRANS FLUID AUX CLR PIPE (CYLINDRICAL) (1 PIPE) (6E04-026) - 2007-2008 EE ТОРМОЗНЫЕ ШЛАНГИ И ТРУБКИ ↓ 15933092 HOSE, RR BRK (INCLS 4, 6) (ACDelco #15933092) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ] teamcadillac.ru 11569742 RETAINER, RR BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 25607191 RETAINER, BRK PIPE (21.5X10.0MM) (HOLDS (2) 4.68-4.82 TUBES) 11569737 FITTING, RR BRK FRT PIPE (7/16-24X0.36, 0.30THD) (0.56 LONG, 3/16TUBE) 12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (BRK & FUEL FEED & FUEL RTN & EVAP EMIS) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА] 25693890 RETAINER, RR BRK PIPE (HOLDS (1) 4.76 LINE) (W/TREE) [ЗАМОК, ФИКСАТОР] 15933091 HOSE, RR BRK (INCLS 4, 6) (ACDelco #15933091) 15270078 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (USES RETAINER PIN FOR ATTACHMENT) [ЗАЖИМ ТРУБКИ ТОПЛИВНОЙ СИСТЕМЫ] 25688547 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (RETAINER W/5 HOLES (2)7.95, (2)4.76, (1)9.52MM) 25749839 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (HOLDS 3 ТРУБКИ, FLAT SHAPE, SNAP-IN RETAINER) 15270078 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (USES RETAINER PIN FOR ATTACHMENT) [ЗАЖИМ ТРУБКИ ТОПЛИВНОЙ СИСТЕМЫ] 10367562 CYLINDER, BRK MAS (СМ. ГРУППУ 04.000 "ГЛАВНЫЙ ЦИЛИНДР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11588803 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 17, 19) (1/2-20X.40, .32 THD) (INVERTED FLARED TUBE) (.62 LONG, 1/4 TUBE) [ГАЙКА М20] 15724650 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 17, 19) (9/16-18 X .40) (INVERTED FLARED TUBE) [ГАЙКА] 15270078 RETAINER, BRK & FUEL PIPE (USES RETAINER PIN FOR ATTACHMENT) [ЗАЖИМ ТРУБКИ ТОПЛИВНОЙ СИСТЕМЫ] 25726788 RETAINER, BRK & FUEL PIPE (SQUARE HEAD PUSH PIN W/5 HOLES (2)4.76. (2)8.00 (1)9.52) [ФИКСАТОР ТОРМОЗНЫХ ТРУБОК] 15792797 PIPE, BRK PRESS MOD VLV FRT (INCLS 15, 32) 25710094 RETAINER, BRK PRESS MOD VLV FRT & RR BRK PIPE (HOLDS (2) LINES) (W/SNAP IN CLIP) 15792796 PIPE, BRK PRESS MOD VLV RR (INCLS 15, 32) 15933098 HOSE, FRT BRK (INCLS 23, 24) (ACDelco #176-1487) 11516521 БОЛТ, HFH M6X1X20, 9.8, 7114M, DOG PT, 14.2 OD (FRT BRK HOSE) 11569742 RETAINER, FRT BRK HOSE (ЧАСТЬ OF 35) (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (FRT BRK) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА] 25743891 RETAINER, FRT BRK PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT) 03541444 SPACER, FRT BRK PIPE 25737279 CLIP, FRT BRK PIPE (THREE WAY RETAINER SINGLE CENTRAL FIR-TREE ATTACHMENT) 25761217 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (3.162) 25765594 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (42.10MM LENGTH) (3.162) [ФИКСАТОР ТОРМОЗНЫХ ТРУБОК] 25761218 BRACKET, FUEL PIPE 15724650 ГАЙКА, INVERTED FLARED TUBE, 9/16"-18, 1/4" TUBE, ZD (ЧАСТЬ OF 17, 19) (4.686) [ГАЙКА] 25743891 RETAINER, RR BRK FRT PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT) 15933099 HOSE, FRT BRK (INCLS 23-25) (ACDelco #176-1495) (6E04-027) - 2007-2009 EB СТОЯНОЧНЫЙ ТОРМОЗ SYSTEM ↓ 10395687 LEVER, PARK BRK (INCLS 2-4, 17, 18) 22654577 SWITCH, PARK BRK IND (ЧАСТЬ OF 1) (ACDelco #22654577) [ВКЛЮЧАТЕЛЬ] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (PARK BRK INTER CBL GDE) [ГАЙКА М6] 15797212 CABLE, PARK BRK INTER (INCLS 5, 10, 11) (ACDelco #15797212) [ТРОС СТОЯНОЧНОГО ТОРМОЗА В СБОРЕ] 11517484 БОЛТ-HEX, M6X1X20, 9 THD, 17 OD, 9.8, 6280M, MACH, P-PT (PARK BRK INTER CBL GDE) 25764260 CABLE, PARK BRK RR (28.2X28.5X811.7MM) (ACDelco #25764260) [ТРОС СТОЯНОЧНОГО ТОРМОЗА] 25880964 HANDLE, PARK BRK REL 11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (PARK BRK REL HDL HSG) [ВИНТ] 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (КАПОТ PRIM LAT REL CBL HDL BRKT) [ВИНТ М4] 15882985 RETAINER, PARK BRK REL HDL 11570654 ГАЙКА, PARK BRK REL HDL BRKT (4.2 X 1.41) (FITS 8.75 SQ HOLE) (9.665) 89047821 CABLE, PARK BRK REL (ЧАСТЬ OF 1) (ACDelco #89047821) teamcadillac.ru 10369646 БОЛТ, PARK BRK IND SW (ЧАСТЬ OF 1) (6E04-028) - 2007-2008 EE СТОЯНОЧНЫЙ ТОРМОЗ SYSTEM ↓ 15791671 LEVER, PARK BRK (INCLS 2-5, 18) 22654577 SWITCH, PARK BRK IND (ЧАСТЬ OF 1) (ACDelco #22654577) [ВКЛЮЧАТЕЛЬ] 10369646 БОЛТ, PARK BRK IND SW (ЧАСТЬ OF 1) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (PARK BRK INTER CBL GDE) [ГАЙКА М6] 15797212 CABLE, PARK BRK INTER (INCLS 6, 11, 12) (ACDelco #15797212) [ТРОС СТОЯНОЧНОГО ТОРМОЗА В СБОРЕ] 11517484 БОЛТ-HEX, M6X1X20, 9 THD, 17 OD, 9.8, 6280M, MACH, P-PT (PARK BRK INTER CBL GDE) 25764260 CABLE, PARK BRK RR (28.2X28.5X811.7MM) (ACDelco #25764260) [ТРОС СТОЯНОЧНОГО ТОРМОЗА] 25880964 HANDLE, PARK BRK REL 11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (PARK BRK REL HDL) [ВИНТ] 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (КАПОТ PRIM LAT REL CBL HDL BRKT) [ВИНТ М4] 15922197 RETAINER, PARK BRK REL HDL (ЧАСТЬ OF 19) teamcadillac.ru 11570654 ГАЙКА, I/P BRKT (4.2 X 1.41) (FITS 8.75 SQ HOLE) (9.665) 88957248 CABLE, PARK BRK REL (ЧАСТЬ OF 1) (6E04-029) - 2007-2008 EE ТОРМОЗНАЯ ПЕДАЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА ↓ 25697462 RETAINER, BRK PED PUSH ROD BOOT 25732452 BOOT, BRK PED PUSH ROD 15795475 HOSE, P/B BOOS VAC 15929447 HOSE, P/B BOOS VAC 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] teamcadillac.ru 19153363 CABLE, BRK PED ADJR ACTR (ЧАСТЬ OF 15) 89047780 MOTOR KIT, BRK & ACCEL PED ADJR ACTR (ЧАСТЬ OF 13) [ЭЛЕКТРОДВИГАТЕЛЬ ПЕДАЛЬНОГО УЗЛА 19 ВТ] 19153364 CABLE, ACCEL CONT (ЧАСТЬ OF 13) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (ACCEL PED LVR) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 15791722 PEDAL, BRK (INCLS 9, 16, 18-23) 89047704 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 15) (INCLS 23) [ДАТЧИК] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 25771615 COVER, BRK PED (ЧАСТЬ OF 15) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 15) 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 15) 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 15) (0.80 IN) (PUSH IN) 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 15, 16) (6E04-030) - 2007-2009 E УПРАВЛЕНИЕ АКПП/АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX0) ↓ 15883328 PLATE, F/FLR CNSL TRANS SHFT OPG TR PLT MT (INCLS 14) 15883329 PLATE, F/FLR CNSL TRANS SHFT OPG TR PLT MT (INCLS 14) 19150329 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (FIG SAPELE WOOD W/EBONY) 19180495 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (EBONY ON MIDDLE & SIDES) 19180497 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (COCOA ON MIDDLE & SIDES) 19180506 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (FIG SAPELE WOOD W/COCOA) 89027001 COVER, A/TRNS CONT LVR HDL (ЧАСТЬ OF 2) (4.006) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL LVR CBL BRKT) [ГАЙКА М6] 15780845 LINK, A/TRNS RANGE SEL LVR 15780847 LINK, A/TRNS RANGE SEL LVR 11519095 NUT-ACORN HEX, M8X1.0, 15MM THK, 9, 6047M, W/DOME. (A/TRNS RANGE SEL LVR) [ГАЙКА] 25789237 RETAINER, F/FLR CNSL (ЧАСТЬ OF 9) 25807057 BEZEL, F/FLR CNSL CUP HLDR (INCLS 8) (GRAY) 25807058 BEZEL, F/FLR CNSL CUP HLDR (INCLS 8) (EBONY) 25807059 BEZEL, F/FLR CNSL CUP HLDR (INCLS 8) (CASHMERE) 19167874 CONTROL, A/TRNS teamcadillac.ru 19167876 CONTROL, A/TRNS 89027003 BULB, A/TRNS CONT POSN IND (BULB W/BLUE COVER) (4.020) (ACDelco #89027003) 19122183 BEZEL, A/TRNS CONT HSG (PRNDL CHROME COVER) 11570687 БОЛТ, A/TRNS CONT LVR KNOB (ЧАСТЬ OF 2) (6E04-031) - 2007-2009 E УПРАВЛЕНИЕ АКПП/АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX7) ↓ 15883328 PLATE, F/FLR CNSL TRANS SHFT OPG TR PLT MT (INCLS 2) 15883329 PLATE, F/FLR CNSL TRANS SHFT OPG TR PLT MT (INCLS 2) 11570687 БОЛТ, A/TRNS CONT LVR KNOB (ЧАСТЬ OF 14) 89027003 BULB, A/TRNS CONT POSN IND (BULB W/BLUE COVER) (4.020) (ACDelco #89027003) 19167812 CONTROL, A/TRNS [МЕХАНИЗМ ПЕРЕКЛЮЧЕНИЯ ПЕРЕДАЧ] 19167875 CONTROL, A/TRNS [ПОДДОН АКП] 25807057 BEZEL, F/FLR CNSL CUP HLDR (INCLS 7) (GRAY) 25807058 BEZEL, F/FLR CNSL CUP HLDR (INCLS 7) (EBONY) 25807059 BEZEL, F/FLR CNSL CUP HLDR (INCLS 7) (CASHMERE) 25789237 RETAINER, F/FLR CNSL (ЧАСТЬ OF 6) teamcadillac.ru 11514603 ГАЙКА, M10X1.5 15MM SOCKET (A/TRNS RANGE SEL LVR) [ШАЙБА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL ROD ADJ) [ГАЙКА М6] 15780844 LINK, A/TRNS RANGE SEL LVR 15780846 LINK, A/TRNS RANGE SEL LVR 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL LVR CBL BRKT) [ГАЙКА М6] 19122183 BEZEL, A/TRNS CONT HSG (PRNDL CHROME COVER) 89027001 COVER, A/TRNS CONT LVR HDL (ЧАСТЬ OF 14) (4.006) 19150329 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (FIG SAPELE WOOD W/EBONY) 19180495 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (EBONY ON MIDDLE & SIDES) 19180497 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (COCOA ON MIDDLE & SIDES) 19180506 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (FIG SAPELE WOOD W/COCOA) (6E04-035) - 2005-2009 E BRAKE SYSTEM/ANTILOCK ↓ 12413103 HUB, FRT WHL (W/BRG) (СМ. ГРУППУ 06.000 "ПОДВЕСКА-ПЕРЕДНЯЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/WHL SPD SEN) (ACDelco #FW149) [СТУПИЦА КОЛЕСА] 12413105 HUB, FRT WHL (W/BRG) (СМ. ГРУППУ 06.000 "ПОДВЕСКА-ПЕРЕДНЯЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPEED SENSOR) (ACDelco #FW150) [СТУПИЦА КОЛЕСА] teamcadillac.ru 89047639 HUB, RR WHL (W/WHL SPD SEN) (СМ. ГРУППУ 06.000 "ЗАДНЯЯ ПОДВЕСКА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6 STUD HUB) (ACDelco #RW20-19) [СТУПИЦА КОЛЕСА] 10307709 SENSOR, VEH YAW (W/VEH LATL ACCLRM) [ДАТЧИК] 15906579 SENSOR, VEH YAW (W/ VEH LATL & LGTDNL ACCLRM) [ДАТЧИК] 11561645 ГАЙКА, HFH, M6X1X6.45, 13.5 OD, 10 STL, GMW3200 (VEH YAW SEN & LATL ACCLRM) (6E04-036) - 2007-2009 EB ТОРМОЗНАЯ ПЕДАЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (JF4) ↓ 25732428 BARRIER, BRK PED BRKT SND 25697461 RETAINER, BRK PED PUSH ROD BOOT 25732452 BOOT, BRK PED PUSH ROD 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] 15932827 HOSE, P/B BOOS VAC (ACDelco #176-1496) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (ACCEL PED LVR) 10368488 PEDAL, BRK (INCLS 12, 13, 15, 18-22) 25771615 COVER, BRK PED (ЧАСТЬ OF 11) 89047699 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 11) (INCLS 18) [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 89047780 MOTOR KIT, BRK & ACCEL PED ADJR ACTR [ЭЛЕКТРОДВИГАТЕЛЬ ПЕДАЛЬНОГО УЗЛА 19 ВТ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 11, 13) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 11) 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 11) teamcadillac.ru 25697461 RETAINER, BRK PED PUSH ROD BOOT (ЧАСТЬ OF 11) 89047779 CABLE, ACCEL CONT 89047778 CABLE, BRK PED ADJR ACTR [ЖГУТ ПРОВОДОВ] 25741052 BRACKET, BRK PED BRKT 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-018) - 2004-2007 E КОРПУС КП ЧАСТЬ 2 INTERNAL COMPONENTS(MX5) ↓ 88984517 WASHER, TRFER CASE PLNT CARR SUN GR THR (25.8X52.0X2.2) 88984524 GEAR, TRFER CASE PLNT CARR SUN (INPUT) (STAMPED PM/POWDERED METAL) 88984493 RING, TRFER CASE RR ВЫХОДНОЙ SHF RR BRG RET (41MM I.D.) (ACDelco #88984493) 88996564 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT 88996665 BEARING, TRFER CASE MAIN SHF FRT (ВЫХОДНОЙ ВАЛ FRT) 19168733 BUSHING, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 106) [ВТУЛКА РАЗДАТОЧНОЙ КОРОБКИ] 19178237 SHAFT, TRFER CASE RR ВЫХОДНОЙ (INCLS 105, 901) 19133264 SPROCKET, TRFER CASE FRT ВЫХОДНОЙ SHF DRV (INCLS 108) [ШЕСТЕРНЯ РАЗДАТОЧНОЙ КОРОБКИ] 19168732 BUSHING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT (ЧАСТЬ OF 107) (ACDelco #19168732) 89059578 CHAIN, TRFER CASE TWO/FOUR WHL DRV [ЦЕПЬ РАЗДАТОЧНОЙ КОРОБКИ] 88984523 GEAR, TRFER CASE PLNT CARR SUN (ВЫХОДНОЙ) 89059279 КРОНШТЕЙН, FRT/RR DRV DIFF 89059284 SHAFT, TRFER CASE FRT ВЫХОДНОЙ (INCLS 900) 88996664 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF RR 88996671 RING, TRFER CASE FRT ВЫХОДНОЙ SHF BRG RET 88996666 SPROCKET, TRFER CASE TWO/FOUR WHL DRV DRVN [ЗВЕЗДОЧКА] 88996633 BEARING, TRFER CASE RR ВЫХОДНОЙ SHF RR (ACDelco #88996633) [ПОДШИПНИК РАЗДАТОЧНОЙ КОРОБКИ] 15580230 BEARING, TRFER CASE INPUT SHF (BORG-WARNER) (4.510) 19132966 SHAFT, TRFER CASE INPUT teamcadillac.ru 88996681 DEFLECTOR, TRFER CASE FRT ВЫХОДНОЙ SHF SEAL DIRT (ЧАСТЬ OF 112) (6M04-037) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (LY7/3.6-7, EXC V92) ↓ 19129976 HOSE, TRANS FLUID CLR LWR (W/BLOCK) (INCLS 7) 11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16] 89022494 BRACKET, TRANS FLUID CLR 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 25740416 SEAL, TRANS FLUID CLR PIPE (O RING) (1/2IN) (9.222) (ACDelco #15-31872) [ПРОКЛАДКА КОМПРЕССОРА КОНДИЦИОНЕРА] 19129977 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) teamcadillac.ru 15921020 CLIP, TRANS FLUID AUX CLR PIPE (CYLINDRICAL) (1 PIPE) (6M04-038) - 2007 E ШЛАНГ ВЕНТИЛЯЦИИ ТРАНСМИССИИ (LH2/4.6A, MYB) ↓ 15236024 HOSE, TRANS VENT (INCLS 2-8) 15797504 HOSE, TRANS VENT (INCLS 2-8) 25892279 VENT, TRFER CASE (ЧАСТЬ OF 1) (ACDelco #25892279) [ЗАГЛУШКА ШЛАНГА ВЕНТИЛЯЦИИ КАРТЕРА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 08905794 CLIP (ЧАСТЬ OF 1) 06466355 CONNECTOR, TRANS VENT HOSE (TEE, CRCONT VAC (5/16 HOSE) (ЧАСТЬ OF 1) (3.278) teamcadillac.ru 25526358 CЛАМПА, SPRG BAND, 14.2MM, 9/16 OD HOSE, POR (ЧАСТЬ OF 1) (6M04-041) - 2007-2008 EB26 ТОРМОЗНАЯ ПЕДАЛЬ (PWR ADJ PEDALS JF4) ↓ 25741052 BRACKET, BRK PED BRKT 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 25732428 BARRIER, BRK PED BRKT SND 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 89047778 CABLE, BRK PED ADJR ACTR [ЖГУТ ПРОВОДОВ] 89047780 MOTOR KIT, BRK & ACCEL PED ADJR ACTR [ЭЛЕКТРОДВИГАТЕЛЬ ПЕДАЛЬНОГО УЗЛА 19 ВТ] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (BRK PED POSN SEN) teamcadillac.ru 89047699 SENSOR KIT, BRK PED POSN [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 25697461 RETAINER, BRK PED PUSH ROD BOOT (ЧАСТЬ OF 21) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 21) 10368488 PEDAL, BRK (INCLS 5, 8-10, 13, 15-20, 22) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-042) - 2007-2008 EB26 ТОРМОЗНАЯ ПЕДАЛЬ (EXC PWR ADJ PEDALS JF4) ↓ 25741052 BRACKET, BRK PED BRKT 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 25732428 BARRIER, BRK PED BRKT SND 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 18) 89047699 SENSOR KIT, BRK PED POSN [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 15594358 BUSHING, BRK PED PIV (ЧАСТЬ OF 18) (0.831) teamcadillac.ru 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 18) (0.80 IN) (PUSH IN) 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 18) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 18) 25771615 COVER, BRK PED (ЧАСТЬ OF 18) 25765419 PEDAL, BRK (W/BRKT) (INCLS 5-8, 10, 12-17, 19) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-043) - 2007-2008 EE26 ТОРМОЗНАЯ ПЕДАЛЬ ↓ 15866634 BRACKET, BRK PED BRKT teamcadillac.ru 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED) [ГАЙКА] 89047704 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 12) [ДАТЧИК] 19153363 CABLE, BRK PED ADJR ACTR (ЧАСТЬ OF 12) 25771615 COVER, BRK PED (ЧАСТЬ OF 12) 15791722 PEDAL, BRK (INCLS 4-6, 8-11, 13-19) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 12) 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 12) 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 12) (0.80 IN) (PUSH IN) 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 12) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] (6M04-044) - 2004-2009 E26 ТОРМОЗНОЙ УСИЛИТЕЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА ↓ 88967237 BOOSTER, P/B (СМ. ГРУППУ 04.000 "ТОРМОЗНОЙ УСИЛИТЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/O VLV) (ACDelco #178-0695) 25732452 BOOT, BRK PED PUSH ROD 25697461 RETAINER, BRK PED PUSH ROD BOOT 25697462 RETAINER, BRK PED PUSH ROD BOOT teamcadillac.ru 10367561 CYLINDER, BRK MAS (СМ. ГРУППУ 4.000 "ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #174-1012) [ЦИЛИНДР] 10367562 CYLINDER, BRK MAS (СМ. ГРУППУ 4.000 "ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11609949 ГАЙКА, BRK M/CYL (M10X1.5, 11.2 THK) (8.917) [ГАЙКА] 15795475 HOSE, P/B BOOS VAC 15929447 HOSE, P/B BOOS VAC 25873484 HOSE, P/B BOOS VAC (ACDelco #176-1497) (GM04-064) - 2004-2009 E ТОРМОЗНОЙ СУППОРТ-ПЕРЕДНИЙ ↓ 18047980 CALIPER, FRT BRK (INCLS 2-4, 8-10) (IF DISCONTINUED USE DURASTOP EQUIVALENT) (4.667) (ACDelco #172-1643) [ТОРМОЗНОЙ СУППОРТ] 18047981 CALIPER, FRT BRK (INCLS 2-4, 8-10) (IF DISCONTINUED USE DURASTOP EQUIVALENT) (4.667) (ACDelco #172-1644) [ТОРМОЗНОЙ СУППОРТ] 18043178 COVER, FRT BRK BLEDR SCREW (ЧАСТЬ OF 1) 18047986 VALVE KIT, FRT BRK CLPR BLEDR (ЧАСТЬ OF 1) (ACDelco #18047986) 18046750 БОЛТ, FRT BRK CLPR GDE PIN (ЧАСТЬ OF 1, 11) (*KIT2) [БОЛТ] 18047985 PISTON KIT, FRT BRK CLPR (ЧАСТЬ OF 1) teamcadillac.ru 18047988 PAD KIT, FRT DISC BRK (INCLS 4, 14) (ACDelco #171-665) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4 ШТ)] 19122384 PAD KIT, FRT DISC BRK (INCLS 4, 14) (ACDelco #171-688) 18045221 SEAL, FRT BRK CLPR GDE PIN 18047987 BRACKET, FRT BRK CLPR (W/GUIDE PIN БОЛТS) [КРОНШТЕЙН] 18046698 ПРУЖИНА, FRT DISC BRK PAD RET (ЧАСТЬ OF 11) (ACDelco #179-2235) 18047989 PIN KIT, FRT BRK CLPR GDE (INCLS 5-7) (INCLS 2 (2.5") БОЛТS) 18047984 CALIPER KIT, FRT BRK (INCLS 4, 8, 9) (4.667) (ACDelco #173-0538) (GM04-312) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (5L40-E M82) ↓ teamcadillac.ru 96042897 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 6GRG) (GM04-376) - 2004-2009 E ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР ↓ 18012741 SWITCH, BRK FLUID LVL IND (ЧАСТЬ OF 15) (ACDelco #18012741) 22688449 CAP, BRK M/CYL RSVR (ЧАСТЬ OF 15) (INCLS 3) [КРЫШКА БАЧКА ТОРМОЗНОЙ ЖИДКОСТИ] 18046711 RESERVOIR, BRK M/CYL (ЧАСТЬ OF 15) (INCLS 4, 6-7) (ACDelco #18046711) 18060168 PISTON, BRK M/CYL SECD (ЧАСТЬ OF 15) 10367561 CYLINDER, BRK MAS (INCLS 1-14) (ACDelco #174-1012) [ЦИЛИНДР] 10367562 CYLINDER, BRK MAS (INCLS 1-14) 18022002 CYLINDER KIT, BRK MAS (INCLS 8-12) (ACDelco #175-424) (GM04-485) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (5L40-E MX5) ↓ teamcadillac.ru 96042890 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 6GGG) [АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ В СБОРЕ] (GM04-555) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 24227130 БОЛТ, C/VLV UPR BODY (M5X0.8X36) 24225398 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M6 X 1.0 X 20) 24238417 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (INCLS 316) (4.329) [ДАТЧИК ЧИСЛА ОБОРОТОВ ВАЛА AКПП] 24225797 BODY, C/VLV UPR [ГИДРОРАСПРЕДЕЛИТЕЛЬНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24237789 PLATE, C/VLV BODY SPCR (W/GSKT) (USED ON UNITS BUILT BEFORE 07/17/06) (FOR 2ND DES SEE 24240068) 24246917 PLATE, C/VLV BODY SPCR (W/GSKT) (MUST USE T/W 24238925/PLATE KIT - CONT SOL VLV FLTR) (ACDelco #24246917) (USED ON UNITS BUILT ON OR AFTER 7/17/06) (FOR 1ST DES SEE 24237789) (USED W/2007 TRANS BROADCAST CODES) (FOR 2008 TRANS BROADCAST CODES SEE 2 96020431 VALVE, C/VLV BODY BALL CHK [КЛАПАН] 24250384 BODY, C/VLV LWR (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ/;НИЖНИЙ КЛАПАН РЕГУЛЯТОР BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (MANUAL VALVE NOT INCLUDED) (MUST USE T/W 24236934/PLATE KIT - CONT SOL VLV FLTR) 24246427 SWITCH, A/TRNS MAN SHFT SHF POSN (INCLS 315) (INTERNAL MODE SWITCH) [ВКЛЮЧАТЕЛЬ] 24224821 БОЛТ, C/VLV LWR BODY (M5X0.8X45) 24224822 БОЛТ, C/VLV LWR BODY (M5X0.8X55) 24238925 PLATE KIT, CONT SOL VLV FLTR 24240845 БОЛТ, CONT SOL VLV HEAT SINK (W/ BODY & TCM) (M5X0.8X53.0) 24238968 VALVE, CONT SOL (W/ BODY & TCM) (ORDER T/W 24238913 SEAL KIT) [ГИДРОРАСПРЕДЕЛИТЕЛЬ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24236233 CLIP, A/TRNS MAN SHFT SHF POSN SW WRG HARN (ЧАСТЬ OF 308) 24236504 CLIP, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN WRG HARN (ЧАСТЬ OF 303) (GM04-556) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ВЕРХНИЙ КЛАПАН РЕГУЛЯТОР BODY БЛОК ↓ 24224766 PIN, C/VLV BODY LOC (ЧАСТЬ OF 321) (DIA.=10MM L=12.7) [ВТУЛКА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24225797 BODY, C/VLV UPR (INCLS 313, 322-338) [ГИДРОРАСПРЕДЕЛИТЕЛЬНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24230200 PIN, C/VLV BODY LOC (ЧАСТЬ OF 321) (DIA.=10MM L=29.9) [ВТУЛКА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, 1-2-3-4 CLU BOOST VLV SPR (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24242814 PLUG, 1-2-3-4 CLU REG VLV BORE (ЧАСТЬ OF 321) (9.5 THK, 11.5 DIA) teamcadillac.ru (GM04-557) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) НИЖНИЙ КЛАПАН РЕГУЛЯТОР BODY БЛОК ↓ 24224755 RETAINER, CLU PSTN DAM FEED REG VLV SPR [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24242814 PLUG, CLU SEL SOL VLV BORE #2 (9.5 THK, 11.5 DIA) 24250384 BODY, C/VLV LWR (INCLS 338, 352, 353, 355-357) (MANUAL VALVE NOT INCLUDED) (MUST USE T/W 24236934/PLATE KIT - CONT SOL VLV FLTR) teamcadillac.ru 24224770 VALVE, MAN (ACDelco #24224770) (GM04-558) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) 1-2-3-4 & 3-5 REVERSE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 24225654 PLATE, 3-5 REV CLU BKG 24225569 PLATE, 3-5/REV CLU (PKG OF 4) (FIBER) (ACDelco #24225569) 24237663 PLATE, 3-5 REV CLU (PKG OF 4) (STEEL) 24225564 PLATE, 3-5 REV CLU (WAVED) 24233533 PLATE, 1-2-3-4 CLU BKG 24243588 PLATE, 1-2-3-4 CLU (ACDelco #24243588) 24232652 PLATE, 1-2-3-4 CLU (PKG OF 5) (STEEL) 24236434 PLATE, 1-2-3-4 CLU (WAVED) 24225522 DAM, 1-2-3-4 CLU PSTN 24225559 ПРУЖИНА, 1-2-3-4 CLU 24225621 PISTON, 1-2-3-4 CLU teamcadillac.ru 24236049 ШЛАНГИ, 1-2-3-4 CLU PSTN 24236051 ПРУЖИНА, 3-5-REV CLU 24236050 PISTON, 3-5/REV CLU (INCLS 422) 24237184 ШЛАНГИ, 1-2-3-4 & 3-5 REV CLU (INCLS 400, 426, 429) (ORDER T/W 24226393) (TRANS BUILT ON 01-20-07 & AFTER) (FOR 1ST DES SEE 24241232) 24241232 СЦЕПЛЕНИЕ KIT, 1-2-3-4 & 3-5 REV (INCLS 400, 426, 429) (ACDelco #24241232) (TRANS BUILT ON 01-19-07 & PRIOR) (FOR 2ND DES SEE 24237184) 24226393 BEARING, 1-2-3-4 & 3-5-REV CLU 24243891 SEAL KIT, A/TRNS SERV (INCLS 411, 415, 416, 419, 423-425) (FULL TRANS) (ACDelco #24243891) 24238920 RING KIT, RET (INCLS 411, 415) 24238922 SEAL KIT, A/TRNS SERV (INCLS 416, 418, 419, 422-425) (СЦЕПЛЕНИЕES) (ACDelco #24238922) (GM04-559) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) 4-5-6 ДЕТАЛИ СЦЕПЛЕНИЯ & ВАЛ ТУРБИНЫ ↓ 24225508 RING, 4-5-6 CLU BKG PLT RET (GREEN) (2.52-2.62) (ACDelco #24225508) 24225509 RING, 4-5-6 CLU BKG PLT RET (YELLOW) (3.08-3.18) (ACDelco #24225509) 24231591 RING, 4-5-6 CLU BKG PLT RET (GREY) (2.80-2.90) (ACDelco #24231591) 24231592 RING, 4-5-6 CLU BKG PLT RET (ORANGE) (3.36-3.46) (ACDelco #24231592) 24231593 RING, 4-5-6 CLU BKG PLT RET (BLUE) (3.64-3.74) (ACDelco #24231593) 24232879 RING, 4-5-6 CLU BKG PLT RET (WHITE) (3.74-3.84) (ACDelco #24232879) 24232880 RING, 4-5-6 CLU BKG PLT RET (YELLOW/PURPLE) (4.20-4.30) (ACDelco #24232880) 24225652 PLATE, 4-5-6 CLU BKG 24225570 PLATE, 4-5-6 CLU (INT SPLINE) (PKG OF 5) (FIBER) 24225575 PLATE, 4-5-6 CLU (EXT SPLINE) (PKG OF 5) (STEEL)FIBER) (ACDelco #24225575) 24225565 PLATE, 4-5-6 CLU (WAVED) 24225526 DAM, 4-5-6 CLU PSTN 24225560 ПРУЖИНА, 4-5-6 CLU 24225523 PISTON, 4-5-6 CLU 24237963 ШЛАНГИ, 4-5-6 CLU (W/ INPUT SHF) (INCLS 440) 08662686 SEAL, TURB SHF (O RING) (*KIT2) (ACDelco #8662686) 24238920 RING KIT, RET (INCLS 436) teamcadillac.ru 24243891 SEAL KIT, A/TRNS SERV (INCLS 436, 442, 443) (FULL TRANS) (ACDelco #24243891) (GM04-560) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) 2-6 ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 24247405 RING, 2-6 CLU BKG PLT RET (CODE 7BNA) (1.69MM +/- 0.05) (ACDelco #24247405) (WHEN ORDERING ТРАНСМИССИЯ REFER TO TECHNICAL SERVICE BULLETIN 07-07-30-011) 24247406 RING, 2-6 CLU BKG PLT RET (CODE 7BNA) (2.81MM +/- 0.05) (ACDelco #24247406) (WHEN ORDERING ТРАНСМИССИЯ REFER TO TECHNICAL SERVICE BULLETIN 07-07-30-011) 24248107 RING, 2-6 CLU BKG PLT RET (CODE 7BNA) (2.25MM +/- 0.05) (ACDelco #24248107) (WHEN ORDERING ТРАНСМИССИЯ REFER TO TECHNICAL SERVICE BULLETIN 07-07-30-011) 24248108 RING, 2-6 CLU BKG PLT RET (CODE 7BNA) (2.53MM +/- 0.05) (ACDelco #24248108) (WHEN ORDERING ТРАНСМИССИЯ REFER TO TECHNICAL SERVICE BULLETIN 07-07-30-011) 24248109 RING, 2-6 CLU BKG PLT RET (CODE 7BNA) (1.97MM +/- 0.05) (ACDelco #24248109) (WHEN ORDERING ТРАНСМИССИЯ REFER TO TECHNICAL SERVICE BULLETIN 07-07-30-011) 24225653 PLATE, 2-6 CLU BKG 24237973 PLATE, 2-6 CLU (WAVED) 24225561 ПРУЖИНА, 2-6 CLU teamcadillac.ru 24225524 PISTON, 2-6 CLU 24225447 SUPPORT, CTR (INCLS 458, 460) 24238911 PLATE KIT, CLU (INCLS 452) (ORDER T/W 24225575 & 24235455) (ACDelco #24238911) (GM04-561) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) LOW & REVERSE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 24248368 PLATE KIT, LOW & REV CLU BKG (4.180) (ACDelco #24248368) (FOR SERVICE USE (1) OF THE FOLLOWING RET. RINGS 24225515, 24225519, OR BACKING PLATE 24225656) teamcadillac.ru 24236664 PLATE, LOW & REV CLU (PKG OF 6) (FIBER) 24232654 PLATE, LOW & REV CLU (PKG OF 6) (STEEL) (ACDelco #24232654) 24237971 PLATE, LOW & REV CLU (WAVED) (ACDelco #24237971) 24225517 RING, LOW & REV CLU SPR RET 24238921 SPRAG, LOW CLU (INCLS 468) 24225562 ПРУЖИНА, LOW & REV CLU 24225525 PISTON, LOW & REV CLU (ACDelco #24225525) 24238922 SEAL KIT, A/TRNS SERV (INCLS 468) (СЦЕПЛЕНИЕES) (ACDelco #24238922) (GM04-562) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) СЦЕПЛЕНИЕ HUB БЛОК ↓ 24233660 HUB, 4-5-6 CLU (W/ ВЫХОДНОЙ CARR SHF & DPNR) (INCLS 476-478) 24230475 DAMPENER, 4-5-6 CLU (ЧАСТЬ OF 475) 24233661 PLATE, 4-5-6 CLU DPNR APPLY (ЧАСТЬ OF 475) 24230370 RING, 4-5-6 CLU DPNR RET (ЧАСТЬ OF 475) (GM04-563) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ВЫХОДНОЙ КРОНШТЕЙН БЛОК ↓ 24225777 BEARING, CTR SUPT RLR (ЧАСТЬ OF 490) 24225483 BEARING, ВЫХОДНОЙ CARR OTR SUN GR FRT THR (ЧАСТЬ OF 490) 24225290 GEAR, ВЫХОДНОЙ CARR FRT SUN (ЧАСТЬ OF 490) 24225484 BEARING, ВЫХОДНОЙ CARR OTR SUN GR RR THR (ЧАСТЬ OF 490) 24235807 GEAR, ВЫХОДНОЙ CARR RR SUN (ЧАСТЬ OF 490) 24225603 КРОНШТЕЙН, ВЫХОДНОЙ (INCLS 485-489, 491) teamcadillac.ru (GM04-565) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ЗАМОК ПАРКОВКИ ↓ 24242086 ACTUATOR, PARK PAWL (ACDelco #24242086) 24227077 PIN, MAN SHFT DTNT LVR HUB (ЧАСТЬ OF 505) 24234562 LEVER, MAN SHFT DTNT (INCLS 504) (ACDelco #24234562) 24225792 PIN, MAN SHFT SHF (ACDelco #24225792) 24235861 SEAL, MAN SHFT SHF (*KIT1) (ACDelco #24235861) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24225445 SHAFT, MAN SHFT (ACDelco #24225445) 24228969 SHAFT, MAN SHFT (ACDelco #24228969) 24224348 GUIDE, PARK PAWL ACTR (INCLS 510) 24224350 SEAL, PARK PAWL ACTR GDE (O RING) (ЧАСТЬ OF 509) (*KIT1) (ACDelco #24224350) teamcadillac.ru 24226102 PIN, PARK PAWL ACTR GDE 24243891 SEAL KIT, A/TRNS SERV (INCLS 507, 510) (FULL TRANS) (ACDelco #24243891) (GM04-568) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ВЫХОДНОЙ ВАЛ БЛОК ↓ 24241092 RING, ВЫХОДНОЙ CARR INTL GR RET (ACDelco #24241092) teamcadillac.ru 24225477 GEAR, ВЫХОДНОЙ CARR INTL (FRT) 24228887 SPACER, ВЫХОДНОЙ CARR INTL GR (3.342) 24230333 GEAR, ВЫХОДНОЙ CARR INTL (RR) 24239398 SHAFT, ВЫХОДНОЙ (INCLS 495, 497, 498) (WHEN SERVICING SHAFT MUST ALSO REPLACE BEARING P/N 24237771) 24239401 SHAFT, ВЫХОДНОЙ (INCLS 495, 497, 498) (WHEN SERVICING SHAFT MUST ALSO REPLACE BEARING P/N 24237771) (GM04-569) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) БЛОК СЦЕПЛЕНИЯ & ДЕТАЛИ КОМПЛЕКТА ↓ 24225602 КРОНШТЕЙН, INPUT (ACDelco #24225602) 24225289 GEAR, INPUT SUN (ACDelco #24225289) 24224405 BEARING, INPUT SUN GR THR (ACDelco #24224405) 24232409 WASHER, INPUT SUN GR THR 24238905 BEARING, TURB SHFT THR [ПОДШИПНИК] 24233732 BEARING, 4-5-6 CLU HUB THR (ACDelco #24233732) 24225597 HUB, 1-2-3-4 CLU (W/ВЫХОДНОЙ CARR INR SUN GR SHF) 24224163 BEARING, 1-2-3-4 CLU HUB THR (ACDelco #24224163) 24225596 HUB, 2-6 & 3-5/REV CLU (W/ ВЫХОДНОЙ CARR OTR SUN GR SHF) (INCLS 60, 62) 24224164 BEARING, 2-6 & 3-5/REV CLU HUB THR (ACDelco #24224164) 24225512 RING, CTR SUPT RET 24225447 SUPPORT, CTR 24225486 BEARING, ВЫХОДНОЙ CARR THR teamcadillac.ru 24224668 BEARING, ВЫХОДНОЙ SHF THR (ACDelco #24224668) (GM04-573) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042861 GASKET, A/TRNS CASE EXTN (*KIT1) 24237771 BEARING, ВЫХОДНОЙ SHF (ЧАСТЬ OF 27) 96042860 EXTENSION, A/TRNS CASE (INCLS 26, 28, 29) 24237771 BEARING, ВЫХОДНОЙ SHF (ЧАСТЬ OF 27) 96041851 SEAL, PROP SHF TRANS FLG FLUID (ЧАСТЬ OF 27) (*KIT1) [ПРОКЛАДКА ТРАНСФОРМАТОРНОГО ВАЛА] 96042984 FLANGE, ВЫХОДНОЙ SHF 96041805 NUT KIT, ВЫХОДНОЙ SHFT (INCLS 30, 32, 33) (M6X1.0X16) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) (*KIT1) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) (*KIT1) 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96042963 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPACER PLATE & GASKET) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) 96042712 DETENT, MAN SHFT 96017928 CLIP, WRG HARN 96042847 HARNESS, A/TRNS WRG 96041849 SEAL, A/TRNS WRG CONN (O RING) (*KIT1) 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN (*KIT1) [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (*KIT1) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (*KIT1) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) teamcadillac.ru 96042945 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/GSKT, SEAL, RET) (INCLS 25, 29, 36, 38, 46, 56, 60, 63, 64) (GM04-574) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042887 GASKET, A/TRNS CASE EXTN [ПРОКЛАДКА КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042888 EXTENSION, A/TRNS CASE (INCLS 28, 69) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE teamcadillac.ru 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96042963 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPACER PLATE & GASKET) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) 96042712 DETENT, MAN SHFT 96017928 CLIP, WRG HARN 96042847 HARNESS, A/TRNS WRG 96041849 SEAL, A/TRNS WRG CONN (O RING) 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) 96042543 WASHER, INPUT & REACTION CARR THR 96042587 SEAL, PROP SHF TRANS FLG FLUID [ПРОКЛАДКА КРЫШКИ РАЗДАТОЧНОЙ КОРОБКИ] 08677884 BEARING, ВЫХОДНОЙ SHF THR (ЧАСТЬ OF 27) (4.180) (ACDelco #8677884) (GM04-575) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ 96042554 CONVERTER, TORQ (REMAN) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042812 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) 96042806 СЦЕПЛЕНИЕ, DIR & REV (СМ. ГРУППУ 04.000 "DIRECT AND REVERSE СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042807 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (СМ. ГРУППУ 04.000 "FORWARD AND COAST СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042698 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) (СМ. ГРУППУ 04.000 "INPUT SUN GEAR SHAFT AND FORWARD SPRAG СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (СМ. ГРУППУ 04.000 "DIRECT СЦЕПЛЕНИЕ DRUM AND SHAFT" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042701 WASHER, INPUT & REACTION CARR INR SHF THR 96042808 ШЛАНГИ, O/D CLU (СМ. ГРУППУ 04.000 "OVERDRIVE AND INTERMEDIATE СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (СМ. ГРУППУ 04.000 "LOW СЦЕПЛЕНИЕ SPRAG" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042705 BEARING, CTR SUPT RLR (4.180) 96042809 SUPPORT, CTR (СМ. ГРУППУ 04.000 "CENTER SUPPORT" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042707 КРОНШТЕЙН, INPUT & REACTION (СМ. ГРУППУ 04.000 "PLANETARY КРОНШТЕЙН" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (4.176) 96042708 BEARING, INPUT & REACTION CARR THR teamcadillac.ru 96042709 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (СМ. ГРУППУ 04.000 "ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96041847 WASHER, INPUT & REACTION CARR THR (4.265) (GM04-576) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ 96042554 CONVERTER, TORQ (REMAN) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042812 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) 96042814 СЦЕПЛЕНИЕ, DIR & REV 96042815 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) teamcadillac.ru 96042698 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) (INCLS 9) 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) 96042701 WASHER, INPUT & REACTION CARR INR SHF THR 96042808 ШЛАНГИ, O/D CLU 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) 08677884 BEARING, LOW CLU RLR THR (*KIT1) (ACDelco #8677884) 96042816 SUPPORT, CTR 96042817 КРОНШТЕЙН, INPUT & REACTION 96042818 BEARING, INPUT & REACTION CARR THR 96042813 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) 96042543 WASHER, INPUT & REACTION CARR THR 96042818 BEARING, INPUT & REACTION CARR THR (GM04-577) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ teamcadillac.ru 96015215 БОЛТ, T/CV FLUID SEAL (*KIT1) 96041855 SEAL, T/CV FLUID [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042812 ШЛАНГИ KIT, T/CV (INCLS 200-215, 217-220, 223, 226-228, 231-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-577) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ teamcadillac.ru 24212478 SLIDE, A/TRNS ГИДРОНАСОС (17.9545MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212478) 24212479 SLIDE, A/TRNS ГИДРОНАСОС (17.9675MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212479) 24212480 SLIDE, A/TRNS ГИДРОНАСОС (17.9805MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212480) 24212481 SLIDE, A/TRNS ГИДРОНАСОС (17.9935MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212481) 24212482 SLIDE, A/TRNS ГИДРОНАСОС (18.0065MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212482) 24201144 RING, A/TRNS ГИДРОНАСОС VANE (RING, PUMP VANE) (ACDelco #24201144) 08631280 VANE, A/TRNS ГИДРОНАСОС (ACDelco #8631280) 24205410 GUIDE, A/TRNS ГИДРОНАСОС ROT (13 VANE) (ACDelco #24205410) 24201144 RING, A/TRNS ГИДРОНАСОС VANE (RING, PUMP VANE) (ACDelco #24201144) 96015215 БОЛТ, T/CV FLUID SEAL (*KIT1) 96041855 SEAL, T/CV FLUID [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042812 ШЛАНГИ KIT, T/CV (INCLS 200-215, 217-220, 223, 226-228, 231-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-578) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 300-309, 312-334) (INCLS SPACER PLATE & GASKET) 96042986 GASKET KIT, A/TRNS (INCLS 303, 305, 306, 308, 309, 312, 314, 316, 330, 332) (4.265) (GM04-578) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 300-334) (INCLS SPACER PLATE & GASKET) 96042986 GASKET KIT, A/TRNS (INCLS 303, 305, 306, 308, 309, 312, 314, 316, 330, 332) (4.265) (GM04-579) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96042599 VALVE, TCC PWM SOL 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 340-351, 353-356) (INCLS SPACER PLATE & GASKET) (GM04-579) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 10471813 SEAL, TCC SOL VLV (O RING) (SMALL DIA) (OTR) (ACDelco #10471813) 10475842 SEAL, TCC SOL VLV (O RING) (14 MM I.D.) (INR) (ACDelco #10475842) 96042599 VALVE, TCC PWM SOL teamcadillac.ru 10471813 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (SMALL DIA) (OTR) (ACDelco #10471813) 10475842 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (14 MM I.D.) (INR) (ACDelco #10475842) 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 340-348, 351, 353-354) (INCLS SPACER PLATE & GASKET) (GM04-580) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 343, 349, 350, 365-367, 370-375, 377-388) (INCLS SPACER PLATE & GASKET) (GM04-580) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 10471813 SEAL, TCC SOL VLV (O RING) (SMALL DIA) (OTR) (ACDelco #10471813) 10475842 SEAL, TCC SOL VLV (O RING) (14 MM I.D.) (INR) (ACDelco #10475842) 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 343, 351, 365-367, 370-375, 377-388) (INCLS SPACER PLATE & GASKET) 96042889 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/PLT, GSKT, SEAL) (INCLS 343, 351, 365-367, 370-375, 377-388) (GM04-581) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru 96042806 СЦЕПЛЕНИЕ, DIR & REV (INCLS 400-420) (GM04-581) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru 96042814 СЦЕПЛЕНИЕ, DIR & REV (INCLS 400-420) (GM04-582) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96041856 SEAL, INPUT SHF (O RING) (*KIT1) [ПРОКЛАДКА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] teamcadillac.ru 96042807 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-451) (GM04-582) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042815 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-451) (GM04-583) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042707 КРОНШТЕЙН, INPUT & REACTION (INCLS 455-462) (4.176) (GM04-583) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042817 КРОНШТЕЙН, INPUT & REACTION (INCLS 455-462) (GM04-584) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ teamcadillac.ru 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-584) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ teamcadillac.ru 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-585) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 470-477) (GM04-585) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 470-477) (GM04-586) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 480-497) (GM04-586) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 480-497) (GM04-587) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК ↓ teamcadillac.ru 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (INCLS 500-505) (GM04-587) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК ↓ teamcadillac.ru 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (INCLS 500-505) (GM04-588) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) КРЕПЛЕНИЕ ↓ teamcadillac.ru 96042809 SUPPORT, CTR (INCLS 510-535) (GM04-588) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) КРЕПЛЕНИЕ ↓ teamcadillac.ru 96042816 SUPPORT, CTR (INCLS 510-535) (GM04-589) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) PLANETARY КРОНШТЕЙН БЛОК ↓ teamcadillac.ru 96042707 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-554) (4.176) (GM04-589) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) PLANETARY КРОНШТЕЙН БЛОК ↓ teamcadillac.ru 96042817 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-554) (GM04-590) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК ↓ teamcadillac.ru 96042709 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560-564) (GM04-591) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК ↓ teamcadillac.ru 96042813 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560-561, 563-564) (GM04-593) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) PARKING PAWL БЛОК ↓ 96042710 LEVER, MAN SHFT DTNT 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 96042540 SWITCH, A/TRNS MAN SHFT SHF POSN [ВЫКЛЮЧАТЕЛЬ ПРИВОДА] 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 08644709 SEAL, MAN SHFT SHF (W/O PTFE LUBRICANT APPLIED TO SEAL) (ACDelco #8644709) 96041857 SHAFT, MAN SHFT teamcadillac.ru 96042711 PAWL KIT, PARK 96041852 PLUG, MAN SHFT SHF HOLE (4.279) 96041842 SPACER, MAN SHFT DTNT LVR (GM04-594) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) PARKING PAWL БЛОК ↓ 96042710 LEVER, MAN SHFT DTNT 96042819 LEVER, MAN SHFT DTNT 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 96042540 SWITCH, A/TRNS MAN SHFT SHF POSN [ВЫКЛЮЧАТЕЛЬ ПРИВОДА] 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 08644709 SEAL, MAN SHFT SHF (W/O PTFE LUBRICANT APPLIED TO SEAL) (ACDelco #8644709) 96042544 SHAFT KIT, MAN SHFT teamcadillac.ru 96042711 PAWL KIT, PARK 96042820 PAWL KIT, PARK (GM04-598) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (6L50 MYB, ЗАДНИЙ КОЛЕСО DRIVE MX0) ↓ teamcadillac.ru 17804012 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 7BNA) (WHEN ORDERING ТРАНСМИССИЯ REFER TO TECHNICAL SERVICE BULLETIN 07-07-30-011) (GM04-599) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (6L50 MYB, ALL КОЛЕСО DRIVE MX7) ↓ teamcadillac.ru 17804013 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 7BPA) (WHEN ORDERING ТРАНСМИССИЯ REFER TO TECHNICAL SERVICE BULLETIN 07-07-30-011) [ТРАНСМИССИОННОЕ МАСЛО7BPA (GOODWRENCH REMAN)] (GM04-667) - 2007-2008 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 24240018 CONVERTER, TORQ [ГИДРОТРАНСФОРМАТОР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 11515762 БОЛТ-HFLGE, M8X1.25X50, 18 OD, 22 THD, 10.9, PZO (T/CV HSG) 24205899 PLUG, T/CV HSG ACC HOLE (28MM W/3 TANGS) (SMALL CVR) (ACDelco #24205899) 24225543 SEAL, A/TRNS ГИДРОНАСОС (ACDelco #24225543) [ПРОКЛАДКА КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24242045 CASE, A/TRNS (INCLS 6, 12, 41) (ACDelco #24242045) 24242046 CASE, A/TRNS (INCLS 6, 12, 41) (ACDelco #24242046) 24226020 PLUG, TRANS FLUID FIL TUBE 24239878 SLEEVE, A/TRNS ELEC CONN PASG [МУФТА] 24225788 БОЛТ, A/TRNS CASE EXTN (M10X1.5X34) 24225557 SEAL, CTR SUPT FLUID PASG (*KIT2) 24224820 БОЛТ, VLV BODY (USED ON TRANS BUILT ON 12-31-06 & PRIOR) (FOR 2ND DES SEE 24237181) 24237181 БОЛТ, VLV BODY (M5X0.8X73.0) (USED ON TRANS BUILT ON 01-01-07 & AFTER) (FOR 1ST DES SEE 24224820) 24231074 БОЛТ, MAN SHFT DTNT (M10X1X14.5) 24222646 DETENT, MAN SHFT (W/8MM DIA. ROLLER) (ACDelco #24222646) 24236933 FILTER KIT, A/TRNS FLUID (INCLS 25) (ACDelco #24236933) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24225800 GASKET, A/TRNS FLUID PAN (ACDelco #24225800) [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 29535617 MAGNET, A/TRNS FLUID PAN (4.105) (ACDelco #29535617) [МАГНИТ] 24237064 PAN, A/TRNS FLUID (INCLS 31) (TRANS BUILT ON 3-2-07 & PRIOR) (FOR 2ND DES SEE 24242410) 24242410 PAN, A/TRNS FLUID (INCLS 31) (ACDelco #24242410) (MUST SERVICE T/W 24236933 FILTER FOR TRANS BUILT ON 3-2-07 & PRIOR) 11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (A/TRNS FLUID PAN) [БОЛТ М6] 24234212 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 29) (ACDelco #24234212) [ПРОБКА] 24205900 PLUG, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] 24225783 SEAL, A/TRNS CASE EXTN (ACDelco #24225783) [УПЛОТНИТЕЛЬ КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24237879 EXTENSION, A/TRNS CASE (INCLS 36, 37) (ACDelco #24237879) 24228876 SEAL, ВЫХОДНОЙ SHF (ЧАСТЬ OF 34) (5.556) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24214158 BEARING, ВЫХОДНОЙ SHF (DRAWN CUP) (ЧАСТЬ OF 34) (4.131) (ACDelco #24214158) 24230287 FLANGE, PROP SHF TRANS 24231524 ГАЙКА, FRT PROP SHF FLG (M22X1.5) (FLANGE HEX) 24229687 EXTENSION, A/TRNS CASE (MCHG) 24237771 BEARING, ВЫХОДНОЙ SHF (ЧАСТЬ OF 7) teamcadillac.ru 24242995 BEARING, ВЫХОДНОЙ SHF (ЧАСТЬ OF 7) [ПОДШИПНИК КПП] 24236928 SEAL KIT, A/TRNS ELEC CONN PASG SLEV (INCLS 9, 10) 24238913 SEAL KIT, A/TRNS SERV (INCLS 9, 10, 18-20) (CONTROL VLV SOL ASM) (ACDelco #24238913) [КОМПЛЕКТ ПРОКЛАДОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (5ШТ)] 04 - ТОРМОЗА ↓ (6D00-036) - 2007-2008 E ТРАНСМИССИЯ TO КРЕПЛЕНИЕ ДВИГАТЕЛЯ (LH2/4.6A) ↓ 12582606 FLYКОЛЕСО, ENG 25773136 BRACKET, ENG WRG HARN (CHANNEL) 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] 24205900 PLUG, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] 24205899 PLUG, T/CV HSG ACC HOLE (28MM W/3 TANGS) (SMALL CVR) (ACDelco #24205899) 11589116 БОЛТ, FLYWHL (8.900) 12568122 COVER, FLYWHL HSG teamcadillac.ru 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (TRANS CONV CVR) (ACDelco #11517518) [БОЛТ] 12568123 COVER, TRANS CONV (6D04-023) - 2004-2009 E СТОЯНОЧНЫЙ ТОРМОЗ ASM ↓ 88951984 PLATE, RR PARK BRK ANC BKG (4.591) 88951985 PLATE, RR PARK BRK ANC BKG (4.591) 88951982 ACTUATOR KIT, RR PARK BRK (INCLS 2) (ACDelco #179-2053) [АКТУАТОР] teamcadillac.ru 88951983 ACTUATOR KIT, RR PARK BRK (INCLS 2) (ACDelco #179-2054) [АКТУАТОР] 89047676 SHOE KIT, RR PARK BRK (INCLS 5) (ACDelco #171-0915) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (2 ШТ)] (6D04-031) - 2004-2009 E ТОРМОЗНОЙ СУППОРТ-ЗАДНИЙ ↓ 89047677 CALIPER KIT, RR BRK (INCLS 2, 3, 7-9) (ACDelco #172-2343) 89047678 CALIPER KIT, RR BRK (INCLS 2, 3, 7-9) (ACDelco #172-2344) [ТОРМОЗНОЙ СУППОРТ] teamcadillac.ru 88951992 CAP, RR BRK BLEDR VLV (ЧАСТЬ OF 1) 88951991 VALVE, RR BRK CLPR BLEDR (ЧАСТЬ OF 1) 89047757 PAD KIT, RR DISC BRK (INCLS 4, 12) (ACDelco #171-859) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4 ШТ)] 89047758 PAD KIT, RR DISC BRK (INCLS 4, 12) (4.667) (ACDelco #171-0906) [ТОРМОЗНЫЕ КОЛОДКИ] 88957163 BRACKET, RR BRK CLPR [СКОБА ТОРМОЗНОГО СУППОРТА] 89047759 PIN KIT, RR BRK CLPR GDE (INCLS 4-6) (INCLS 2 PINS, 2 SEALS & 2 (2.75") БОЛТS) (ACDelco #179-2044) [НАПРАВЛЯЮЩАЯ ТОРМОЗНОГО СУППОРТА (2 ШТ)] 88957162 REPAIR KIT, RR BRK CLPR HYD (INCLS 4, 6, 8, 9) (6D04-033) - 2004-2009 E ТОРМОЗНОЙ УСИЛИТЕЛЬ ↓ 88967237 BOOSTER, P/B (W/O VLV) (ACDelco #178-0695) 05461808 GROMMET, P/B BOOS VAC CHK VLV (*KIT1) teamcadillac.ru 03817880 RETAINER, BRK PED PUSH ROD (0.80 IN) (PUSH IN) 18022219 VALVE KIT, P/B BOOS VAC CHK (INCLS 2, 3) (BLACK) (INCLS VLV & GROM) (ACDelco #179-1266) (6D04-067) - 2007-2009 E КОРПУС КП КРЕПЛЕНИЕ (MYB,MX7) ↓ teamcadillac.ru 24231525 GASKET, TRFER CASE 19132968 CASE, TRFER (W/GEARS) (LESS DAMPENER) 24243367 CASE, TRFER (W/GEARS) 11589341 БОЛТ - HFH, M10X1.5X69.9, 28.35 THD, 22.3 OD, 10.9, GMW3359, M-PT. (TRFER CASE) [БОЛТ] (6E00-014) - 2004-2009 E ТРАНСМИССИЯ TO КРЕПЛЕНИЕ ДВИГАТЕЛЯ (LY7/3.6-7) ↓ 12572042 PLATE, A/TRNS FLEX 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (TRANS CVR) [БОЛТ] 24222918 COVER, TRANS CONV teamcadillac.ru 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] (6E03-019) - 2007-2009 E T.C.M. МОДУЛЬ (LY7/3.6-7) ↓ 12605670 МОДУЛЬ, ENG CONT (W/O CALN & OPERG SYS) (ACDelco #216-130) [БЛОК УПРАВЛЕНИЯ ДВИГАТЕЛЕМ] 25784072 BRACKET, ECM (INCLS 5, 6) 24239785 МОДУЛЬ, TRANS CONT 11609462 SCREW, M4.2X1.41X13, GMW4205 (ЧАСТЬ OF 3) 11561758 БОЛТ, MULTIUSE RLY & FUSE BRKT (7.833) [БОЛТ] 15879156 BRACKET, ACSRY WRG J/BLK 11609599 STUD, SPL, M6X1X25, 13 THD, 11 OD HD W/26 WIDE CLIP, 9.8, 6280M, P-PT (MULTIUSE FUSE BRKT) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (MULTIUSE RLY & FUSE BRKT) [ГАЙКА М6] (6E04-007) - 2007-2009 EB ТОРМОЗНЫЕ ШЛАНГИ И ТРУБКИ ↓ 15933099 HOSE, FRT BRK (INCLS 15, 16) (ACDelco #176-1495) 11569742 RETAINER, FRT BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (BRK & FUEL FEED & FUEL RTN & EVAP EMIS) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА] 25761218 BRACKET, FUEL PIPE 25761217 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (3.162) 12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (FRT BRK) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА] 10388788 PIPE, BRK PRESS MOD VLV FRT (INCLS 29) teamcadillac.ru 10388794 PIPE, BRK PRESS MOD VLV RR (INCLS 29) 03541444 SPACER, FRT BRK PIPE 11516521 БОЛТ, HFH M6X1X20, 9.8, 7114M, DOG PT, 14.2 OD (FRT BRK HOSE) 15933098 HOSE, FRT BRK (INCLS 15, 16) (ACDelco #176-1487) 25743891 RETAINER, RR BRK FRT PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT) 11569737 FITTING, FRT BRK PIPE (ЧАСТЬ OF 1, 12) (7/16-24X0.36, 0.30THD) (0.56 LONG, 3/16TUBE) 25743891 RETAINER, FRT BRK PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT) 25737279 CLIP, FRT BRK PIPE (THREE WAY RETAINER SINGLE CENTRAL FIR-TREE ATTACHMENT) 15270078 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (USES RETAINER PIN FOR ATTACHMENT) [ЗАЖИМ ТРУБКИ ТОПЛИВНОЙ СИСТЕМЫ] 25688547 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (RETAINER W/5 HOLES (2)7.95, (2)4.76, (1)9.52MM) 25749839 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (HOLDS 3 ТРУБКИ, FLAT SHAPE, SNAP-IN RETAINER) 25607191 RETAINER, BRK PIPE (21.5X10.0MM) (HOLDS (2) 4.68-4.82 TUBES) 11569742 RETAINER, RR BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 15724650 ГАЙКА, INVERTED FLARED TUBE, 9/16"-18, 1/4" TUBE, ZD (BRK PIPE) (4.686) [ГАЙКА] 25693890 RETAINER, RR BRK PIPE (HOLDS (1) 4.76 LINE) (W/TREE) [ЗАМОК, ФИКСАТОР] 11588803 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 7, 8) (1/2-20X.40, .32 THD) (INVERTED FLARED TUBE) (.62 LONG, 1/4 TUBE) [ГАЙКА М20] 15724650 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 7, 8) (9/16-18 X .40) (INVERTED FLARED TUBE) [ГАЙКА] 15933091 HOSE, RR BRK (INCLS 22, 23) (ACDelco #15933091) 15933092 HOSE, RR BRK (INCLS 22, 23) (ACDelco #15933092) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ] 88964150 PROTECTOR, FRT BRK PIPE (FOR 3/16" PIPE) (HT SHRINK) (6E04-008) - 2007-2009 EB ТОРМОЗНАЯ ПЕДАЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (EXC (JF4)) ↓ 25732428 BARRIER, BRK PED BRKT SND 25697461 RETAINER, BRK PED PUSH ROD BOOT 25732452 BOOT, BRK PED PUSH ROD 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) teamcadillac.ru 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] 15932827 HOSE, P/B BOOS VAC (ACDelco #176-1496) 25765419 PEDAL, BRK (W/BRKT) (INCLS 10, 11, 14, 16-18) 25771615 COVER, BRK PED (ЧАСТЬ OF 9) 89047699 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 9) [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 9) 10434956 BUSHING, BRK PED PUSH ROD 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 9) 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 9) (0.80 IN) (PUSH IN) (6E04-012) - 2007-2009 E КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS(MYB,MX7) ↓ teamcadillac.ru 88996677 CASE, TRFER (FRT HALF) (INCLS 12-14) 19133265 CASE, TRFER (RR HALF) (INCLS 5, 7) 88996679 SNUBBER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN 88996680 БОЛТ, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN SNBR (M5X0.8X16) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 2) 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL FILL) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996657 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 2) [УПЛОТНИТЕЛЬ] 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL DRN) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996680 БОЛТ, TRFER CASE VENT BFL (M5X0.8X16) (4.535) 88996658 BAFFLE, TRFER CASE VENT 89048123 БОЛТ, TRFER CASE HALF (M8X1.25X30) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 1) 88996656 SEAL, TRFER CASE INPUT SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 88996657 SEAL, TRFER CASE FRT ВЫХОДНОЙ SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] (6E04-013) - 2007-2009 E КОРПУС КП ЧАСТЬ 2 INTERNAL COMPONENTS(MYB,MX7) ↓ 88984517 WASHER, TRFER CASE PLNT CARR SUN GR THR (25.8X52.0X2.2) 88984524 GEAR, TRFER CASE PLNT CARR SUN (INPUT) (STAMPED PM/POWDERED METAL) 88984493 RING, TRFER CASE RR ВЫХОДНОЙ SHF RR BRG RET (41MM I.D.) (ACDelco #88984493) 88996564 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT 88996665 BEARING, TRFER CASE MAIN SHF FRT (ВЫХОДНОЙ ВАЛ FRT) 19168733 BUSHING, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 106) [ВТУЛКА РАЗДАТОЧНОЙ КОРОБКИ] 19178238 SHAFT, TRFER CASE RR ВЫХОДНОЙ (INCLS 105) 19133264 SPROCKET, TRFER CASE FRT ВЫХОДНОЙ SHF DRV (INCLS 108) [ШЕСТЕРНЯ РАЗДАТОЧНОЙ КОРОБКИ] 19168732 BUSHING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT (ЧАСТЬ OF 107) (ACDelco #19168732) 19132837 CHAIN, TRFER CASE TWO/FOUR WHL DRV 88984523 GEAR, TRFER CASE PLNT CARR SUN (ВЫХОДНОЙ) 89059279 КРОНШТЕЙН, FRT/RR DRV DIFF 89059284 SHAFT, TRFER CASE FRT ВЫХОДНОЙ (INCLS 900) 88996664 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF RR 88996671 RING, TRFER CASE FRT ВЫХОДНОЙ SHF BRG RET 88996666 SPROCKET, TRFER CASE TWO/FOUR WHL DRV DRVN [ЗВЕЗДОЧКА] 88996633 BEARING, TRFER CASE RR ВЫХОДНОЙ SHF RR (ACDelco #88996633) [ПОДШИПНИК РАЗДАТОЧНОЙ КОРОБКИ] 15580230 BEARING, TRFER CASE INPUT SHF (BORG-WARNER) (4.510) 19132966 SHAFT, TRFER CASE INPUT 88996681 DEFLECTOR, TRFER CASE FRT ВЫХОДНОЙ SHF SEAL DIRT (ЧАСТЬ OF 112) (6E04-016) - 2004-2009 E КЛАПАН РЕГУЛИРОВКИ ДАВЛЕНИЯ В ТОРМОЗНОЙ СИСТЕМЕ ↓ 19153350 МОДУЛЬ KIT, ELEK BRK & TRACT CONT [МОДУЛЬ] 89060233 VALVE KIT, BRK PRESS MOD (INCLS 3, 4) (ACDelco #89060233) [ГИДРАВЛИЧЕСКИЙ БЛОК АБС] teamcadillac.ru 25743362 SENSOR, BRK PRESS MOD VLV PRESS (ЧАСТЬ OF 2) (ACDelco #25743362) [ДАТЧИК] 25741456 INSULATOR, BRK PRESS MOD VLV (ЧАСТЬ OF 2) 11588304 STUD, FLANGE DOUBLE END, M8X14 UNTHD, M8X1.25X13, 17 OD, 5.8, GM4345M (BRK PRESS MOD VLV BRKT) 11514596 ГАЙКА, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (BRK PRESS MOD VLV BRKT) (8.915) (ACDelco #11514596) 11508351 SCREW, PAN HD, C/R, 5X0.8X13, 9.3 OD, FULL THD, THD RLLR, 6171M, PC (BRK PRESS MOD VLV) (8.977) (6E04-017) - 2007-2009 E ШЛАНГ ВЕНТИЛЯЦИИ ТРАНСМИССИИ (LY7/3.6-7, M82,MX5) ↓ 25764835 VENT, A/TRNS (INCLS 2, 3) (ACDelco #25764835) teamcadillac.ru 15955072 CLIP, TRANS VENT HOSE (ЧАСТЬ OF 1) (.650MM DIA) (2.343) (6E04-018) - 2004-2009 E КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS(MX5) ↓ 88996677 CASE, TRFER (FRT HALF) (INCLS 12-14) 19133265 CASE, TRFER (RR HALF) (INCLS 5, 7) 88996679 SNUBBER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN 88996680 БОЛТ, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN SNBR (M5X0.8X16) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 2) 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL FILL) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996657 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 2) [УПЛОТНИТЕЛЬ] 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL DRN) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996680 БОЛТ, TRFER CASE VENT BFL (M5X0.8X16) (4.535) 88996658 BAFFLE, TRFER CASE VENT 89048123 БОЛТ, TRFER CASE HALF (M8X1.25X30) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 1) 88996656 SEAL, TRFER CASE INPUT SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 88996657 SEAL, TRFER CASE FRT ВЫХОДНОЙ SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] teamcadillac.ru 19180066 VENT, TRFER CASE 89048123 БОЛТ, TRFER CASE VIB DPNR (M8X1.25X30) 19133173 DAMPENER, TRFER CASE VIB (YOKE STYLE; БОЛТS TO RR OF T-CASE) (6E04-020) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ 24218963 RING, T/CV FLUID SEAL RET [КОЛЬЦО] 24237531 SEAL, T/CV FLUID (ЧАСТЬ OF 217, 219) (ACDelco #24237531) [УПЛОТНЕНИЕ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 00444613 PLUG, HEX HD, 1/8-27 NPTF, STL (LINE PRESS TEST HOLE) (ACDelco #444613) 24239385 ШЛАНГИ, T/CV (MCHG) (INCLS 206) 24225422 PIPE, A/TRNS VENT 15251488 SEAL, TRANS FLUID CLR PIPE FTG (ЧАСТЬ OF 217, 219) (SEALS TWO ТРУБКИ) (*KIT1) [УПЛОТНЕНИЕ] 24237658 SEAL, TRANS FLUID CLR PIPE FTG (ЧАСТЬ OF 217, 219) (SEALS ONE PIPE) (*KIT1) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ] 24222668 SLIDE, A/TRNS ГИДРОНАСОС (17.948MM-17.961MM) (ACDelco #24222668) 24224131 SLIDE, A/TRNS ГИДРОНАСОС (17.961MM-17.974MM) (ACDelco #24224131) 24224132 SLIDE, A/TRNS ГИДРОНАСОС (17.974MM-17.987MM) (ACDelco #24224132) 24238915 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 207-211, 213-216, 230) (17.948MM-17.961MM) (ACDelco #24238915) 24238916 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 207-211, 213-216, 230) (17.961MM-17.974MM) (ACDelco #24238916) 24238917 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 207-211, 213-216, 230) (17.974MM-17.987MM) (ACDelco #24238917) 24238919 COVER KIT, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 218, 220-230, 232-237) (ACDelco #24238919) teamcadillac.ru 00147500 VALVE, PRESS RLF BALL (ЧАСТЬ OF 219) 24224692 WASHER, 1-2-3-4 & 3-5 REV CLU HSG THR (ЧАСТЬ OF 219) 24239151 RING, 1-2-3-4 & 3-5 REV CLU FLUID SEAL (ЧАСТЬ OF 217, 219) (*KIT1) (ACDelco #24239151) 24227061 БОЛТ, A/TRNS ГИДРОНАСОС CVR (ACDelco #24227061) [БОЛТ] 90351709 PIN, A/TRNS ГИДРОНАСОС LOC (ЧАСТЬ OF 219) ("8MM HOLLOW SPLIT PIN") (1.639) [ШПИЛЬКА] 24243891 SEAL KIT, A/TRNS SERV (INCLS 205, 210, 214, 230) (FULL TRANS) (ACDelco #24243891) (6E04-022) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (LY7/3.6-7, V92) ↓ 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 89022494 BRACKET, TRANS FLUID CLR 19129782 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) [ТРУБКА МАСЛООХЛАДИТЕЛЯ] 19130214 SEAL, TRANS FLUID CLR HOSE CONN (O RING) 19129781 HOSE, TRANS FLUID CLR LWR (W/BLOCK) 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] teamcadillac.ru 89022522 COOLER, TRANS FLUID (INCLS 7-10) (6E04-024) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (LH2/4.6A, EXC V92) ↓ 88957425 COOLER, TRANS FLUID (INCLS 7-9) (ACDelco #88957425) [ВЕНТИЛЯТОР] teamcadillac.ru 11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) [БОЛТ, М8Х1.25Х31.5] 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 15251488 SEAL, TRANS FLUID CLR PIPE FTG (ЧАСТЬ OF 5) (SEALS TWO ТРУБКИ) [УПЛОТНЕНИЕ] 15882260 PIPE, TRANS FLUID CLR INL & OTLT (INCLS 4, 6) [ТРУБКА МАСЛОПРОВОДА] 10405874 CLIP, TRANS FLUID CLR PIPE (ЧАСТЬ OF 5) (LESS MNTG TAB) (HOLDS TWO 9.5 DIA TUBES) 11570323 БОЛТ, КОНДИЦИОНЕР CNDSR (M6X1X18, 13 THD) (1.277) 15921020 CLIP, TRANS FLUID AUX CLR PIPE (CYLINDRICAL) (1 PIPE) (6E04-025) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (LH2/4.6A, V92) ↓ 89022522 COOLER, TRANS FLUID (INCLS 7-10) 11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) [БОЛТ, М8Х1.25Х31.5] 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 15882260 PIPE, TRANS FLUID CLR INL & OTLT (INCLS 4, 6) [ТРУБКА МАСЛОПРОВОДА] 10405874 CLIP, TRANS FLUID CLR PIPE (ЧАСТЬ OF 5) (LESS MNTG TAB) (HOLDS TWO 9.5 DIA TUBES) teamcadillac.ru 15921020 CLIP, TRANS FLUID AUX CLR PIPE (CYLINDRICAL) (1 PIPE) (6E04-026) - 2007-2008 EE ТОРМОЗНЫЕ ШЛАНГИ И ТРУБКИ ↓ 15933092 HOSE, RR BRK (INCLS 4, 6) (ACDelco #15933092) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ] 11569742 RETAINER, RR BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 25607191 RETAINER, BRK PIPE (21.5X10.0MM) (HOLDS (2) 4.68-4.82 TUBES) 11569737 FITTING, RR BRK FRT PIPE (7/16-24X0.36, 0.30THD) (0.56 LONG, 3/16TUBE) 12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (BRK & FUEL FEED & FUEL RTN & EVAP EMIS) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА] 25693890 RETAINER, RR BRK PIPE (HOLDS (1) 4.76 LINE) (W/TREE) [ЗАМОК, ФИКСАТОР] 15933091 HOSE, RR BRK (INCLS 4, 6) (ACDelco #15933091) 15270078 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (USES RETAINER PIN FOR ATTACHMENT) [ЗАЖИМ ТРУБКИ ТОПЛИВНОЙ СИСТЕМЫ] 25688547 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (RETAINER W/5 HOLES (2)7.95, (2)4.76, (1)9.52MM) 25749839 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (HOLDS 3 ТРУБКИ, FLAT SHAPE, SNAP-IN RETAINER) 15270078 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (USES RETAINER PIN FOR ATTACHMENT) [ЗАЖИМ ТРУБКИ ТОПЛИВНОЙ СИСТЕМЫ] 10367562 CYLINDER, BRK MAS (СМ. ГРУППУ 04.000 "ГЛАВНЫЙ ЦИЛИНДР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11588803 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 17, 19) (1/2-20X.40, .32 THD) (INVERTED FLARED TUBE) (.62 LONG, 1/4 TUBE) [ГАЙКА М20] 15724650 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 17, 19) (9/16-18 X .40) (INVERTED FLARED TUBE) [ГАЙКА] 15270078 RETAINER, BRK & FUEL PIPE (USES RETAINER PIN FOR ATTACHMENT) [ЗАЖИМ ТРУБКИ ТОПЛИВНОЙ СИСТЕМЫ] 25726788 RETAINER, BRK & FUEL PIPE (SQUARE HEAD PUSH PIN W/5 HOLES (2)4.76. (2)8.00 (1)9.52) [ФИКСАТОР ТОРМОЗНЫХ ТРУБОК] 15792797 PIPE, BRK PRESS MOD VLV FRT (INCLS 15, 32) 25710094 RETAINER, BRK PRESS MOD VLV FRT & RR BRK PIPE (HOLDS (2) LINES) (W/SNAP IN CLIP) 15792796 PIPE, BRK PRESS MOD VLV RR (INCLS 15, 32) 15933098 HOSE, FRT BRK (INCLS 23, 24) (ACDelco #176-1487) 11516521 БОЛТ, HFH M6X1X20, 9.8, 7114M, DOG PT, 14.2 OD (FRT BRK HOSE) 11569742 RETAINER, FRT BRK HOSE (ЧАСТЬ OF 35) (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (FRT BRK) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА] 25743891 RETAINER, FRT BRK PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT) teamcadillac.ru 03541444 SPACER, FRT BRK PIPE 25737279 CLIP, FRT BRK PIPE (THREE WAY RETAINER SINGLE CENTRAL FIR-TREE ATTACHMENT) 25761217 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (3.162) 25765594 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (42.10MM LENGTH) (3.162) [ФИКСАТОР ТОРМОЗНЫХ ТРУБОК] 25761218 BRACKET, FUEL PIPE 15724650 ГАЙКА, INVERTED FLARED TUBE, 9/16"-18, 1/4" TUBE, ZD (ЧАСТЬ OF 17, 19) (4.686) [ГАЙКА] 25743891 RETAINER, RR BRK FRT PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT) 15933099 HOSE, FRT BRK (INCLS 23-25) (ACDelco #176-1495) (6E04-027) - 2007-2009 EB СТОЯНОЧНЫЙ ТОРМОЗ SYSTEM ↓ 10395687 LEVER, PARK BRK (INCLS 2-4, 17, 18) 22654577 SWITCH, PARK BRK IND (ЧАСТЬ OF 1) (ACDelco #22654577) [ВКЛЮЧАТЕЛЬ] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (PARK BRK INTER CBL GDE) [ГАЙКА М6] 15797212 CABLE, PARK BRK INTER (INCLS 5, 10, 11) (ACDelco #15797212) [ТРОС СТОЯНОЧНОГО ТОРМОЗА В СБОРЕ] 11517484 БОЛТ-HEX, M6X1X20, 9 THD, 17 OD, 9.8, 6280M, MACH, P-PT (PARK BRK INTER CBL GDE) 25764260 CABLE, PARK BRK RR (28.2X28.5X811.7MM) (ACDelco #25764260) [ТРОС СТОЯНОЧНОГО ТОРМОЗА] 25880964 HANDLE, PARK BRK REL 11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (PARK BRK REL HDL HSG) [ВИНТ] 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (КАПОТ PRIM LAT REL CBL HDL BRKT) [ВИНТ М4] 15882985 RETAINER, PARK BRK REL HDL 11570654 ГАЙКА, PARK BRK REL HDL BRKT (4.2 X 1.41) (FITS 8.75 SQ HOLE) (9.665) teamcadillac.ru 89047821 CABLE, PARK BRK REL (ЧАСТЬ OF 1) (ACDelco #89047821) 10369646 БОЛТ, PARK BRK IND SW (ЧАСТЬ OF 1) (6E04-028) - 2007-2008 EE СТОЯНОЧНЫЙ ТОРМОЗ SYSTEM ↓ 15791671 LEVER, PARK BRK (INCLS 2-5, 18) 22654577 SWITCH, PARK BRK IND (ЧАСТЬ OF 1) (ACDelco #22654577) [ВКЛЮЧАТЕЛЬ] 10369646 БОЛТ, PARK BRK IND SW (ЧАСТЬ OF 1) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (PARK BRK INTER CBL GDE) [ГАЙКА М6] 15797212 CABLE, PARK BRK INTER (INCLS 6, 11, 12) (ACDelco #15797212) [ТРОС СТОЯНОЧНОГО ТОРМОЗА В СБОРЕ] 11517484 БОЛТ-HEX, M6X1X20, 9 THD, 17 OD, 9.8, 6280M, MACH, P-PT (PARK BRK INTER CBL GDE) 25764260 CABLE, PARK BRK RR (28.2X28.5X811.7MM) (ACDelco #25764260) [ТРОС СТОЯНОЧНОГО ТОРМОЗА] 25880964 HANDLE, PARK BRK REL teamcadillac.ru 11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (PARK BRK REL HDL) [ВИНТ] 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (КАПОТ PRIM LAT REL CBL HDL BRKT) [ВИНТ М4] 15922197 RETAINER, PARK BRK REL HDL (ЧАСТЬ OF 19) 11570654 ГАЙКА, I/P BRKT (4.2 X 1.41) (FITS 8.75 SQ HOLE) (9.665) 88957248 CABLE, PARK BRK REL (ЧАСТЬ OF 1) (6E04-029) - 2007-2008 EE ТОРМОЗНАЯ ПЕДАЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА ↓ 25697462 RETAINER, BRK PED PUSH ROD BOOT 25732452 BOOT, BRK PED PUSH ROD 15795475 HOSE, P/B BOOS VAC 15929447 HOSE, P/B BOOS VAC 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] 19153363 CABLE, BRK PED ADJR ACTR (ЧАСТЬ OF 15) 89047780 MOTOR KIT, BRK & ACCEL PED ADJR ACTR (ЧАСТЬ OF 13) [ЭЛЕКТРОДВИГАТЕЛЬ ПЕДАЛЬНОГО УЗЛА 19 ВТ] 19153364 CABLE, ACCEL CONT (ЧАСТЬ OF 13) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (ACCEL PED LVR) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] teamcadillac.ru 15791722 PEDAL, BRK (INCLS 9, 16, 18-23) 89047704 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 15) (INCLS 23) [ДАТЧИК] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 25771615 COVER, BRK PED (ЧАСТЬ OF 15) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 15) 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 15) 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 15) (0.80 IN) (PUSH IN) 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 15, 16) (6E04-030) - 2007-2009 E УПРАВЛЕНИЕ АКПП/АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX0) ↓ 15883328 PLATE, F/FLR CNSL TRANS SHFT OPG TR PLT MT (INCLS 14) 15883329 PLATE, F/FLR CNSL TRANS SHFT OPG TR PLT MT (INCLS 14) 19150329 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (FIG SAPELE WOOD W/EBONY) 19180495 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (EBONY ON MIDDLE & SIDES) 19180497 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (COCOA ON MIDDLE & SIDES) 19180506 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (FIG SAPELE WOOD W/COCOA) 89027001 COVER, A/TRNS CONT LVR HDL (ЧАСТЬ OF 2) (4.006) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL LVR CBL BRKT) [ГАЙКА М6] 15780845 LINK, A/TRNS RANGE SEL LVR teamcadillac.ru 15780847 LINK, A/TRNS RANGE SEL LVR 11519095 NUT-ACORN HEX, M8X1.0, 15MM THK, 9, 6047M, W/DOME. (A/TRNS RANGE SEL LVR) [ГАЙКА] 25789237 RETAINER, F/FLR CNSL (ЧАСТЬ OF 9) 25807057 BEZEL, F/FLR CNSL CUP HLDR (INCLS 8) (GRAY) 25807058 BEZEL, F/FLR CNSL CUP HLDR (INCLS 8) (EBONY) 25807059 BEZEL, F/FLR CNSL CUP HLDR (INCLS 8) (CASHMERE) 19167874 CONTROL, A/TRNS 19167876 CONTROL, A/TRNS 89027003 BULB, A/TRNS CONT POSN IND (BULB W/BLUE COVER) (4.020) (ACDelco #89027003) 19122183 BEZEL, A/TRNS CONT HSG (PRNDL CHROME COVER) 11570687 БОЛТ, A/TRNS CONT LVR KNOB (ЧАСТЬ OF 2) (6E04-031) - 2007-2009 E УПРАВЛЕНИЕ АКПП/АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX7) ↓ 15883328 PLATE, F/FLR CNSL TRANS SHFT OPG TR PLT MT (INCLS 2) teamcadillac.ru 15883329 PLATE, F/FLR CNSL TRANS SHFT OPG TR PLT MT (INCLS 2) 11570687 БОЛТ, A/TRNS CONT LVR KNOB (ЧАСТЬ OF 14) 89027003 BULB, A/TRNS CONT POSN IND (BULB W/BLUE COVER) (4.020) (ACDelco #89027003) 19167812 CONTROL, A/TRNS [МЕХАНИЗМ ПЕРЕКЛЮЧЕНИЯ ПЕРЕДАЧ] 19167875 CONTROL, A/TRNS [ПОДДОН АКП] 25807057 BEZEL, F/FLR CNSL CUP HLDR (INCLS 7) (GRAY) 25807058 BEZEL, F/FLR CNSL CUP HLDR (INCLS 7) (EBONY) 25807059 BEZEL, F/FLR CNSL CUP HLDR (INCLS 7) (CASHMERE) 25789237 RETAINER, F/FLR CNSL (ЧАСТЬ OF 6) 11514603 ГАЙКА, M10X1.5 15MM SOCKET (A/TRNS RANGE SEL LVR) [ШАЙБА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL ROD ADJ) [ГАЙКА М6] 15780844 LINK, A/TRNS RANGE SEL LVR 15780846 LINK, A/TRNS RANGE SEL LVR 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL LVR CBL BRKT) [ГАЙКА М6] 19122183 BEZEL, A/TRNS CONT HSG (PRNDL CHROME COVER) 89027001 COVER, A/TRNS CONT LVR HDL (ЧАСТЬ OF 14) (4.006) 19150329 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (FIG SAPELE WOOD W/EBONY) 19180495 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (EBONY ON MIDDLE & SIDES) 19180497 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (COCOA ON MIDDLE & SIDES) 19180506 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (FIG SAPELE WOOD W/COCOA) (6E04-035) - 2005-2009 E BRAKE SYSTEM/ANTILOCK ↓ 12413103 HUB, FRT WHL (W/BRG) (СМ. ГРУППУ 06.000 "ПОДВЕСКА-ПЕРЕДНЯЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/WHL SPD SEN) (ACDelco #FW149) [СТУПИЦА КОЛЕСА] teamcadillac.ru 12413105 HUB, FRT WHL (W/BRG) (СМ. ГРУППУ 06.000 "ПОДВЕСКА-ПЕРЕДНЯЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPEED SENSOR) (ACDelco #FW150) [СТУПИЦА КОЛЕСА] 89047639 HUB, RR WHL (W/WHL SPD SEN) (СМ. ГРУППУ 06.000 "ЗАДНЯЯ ПОДВЕСКА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6 STUD HUB) (ACDelco #RW20-19) [СТУПИЦА КОЛЕСА] 10307709 SENSOR, VEH YAW (W/VEH LATL ACCLRM) [ДАТЧИК] 15906579 SENSOR, VEH YAW (W/ VEH LATL & LGTDNL ACCLRM) [ДАТЧИК] 11561645 ГАЙКА, HFH, M6X1X6.45, 13.5 OD, 10 STL, GMW3200 (VEH YAW SEN & LATL ACCLRM) (6E04-036) - 2007-2009 EB ТОРМОЗНАЯ ПЕДАЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (JF4) ↓ 25732428 BARRIER, BRK PED BRKT SND 25697461 RETAINER, BRK PED PUSH ROD BOOT 25732452 BOOT, BRK PED PUSH ROD teamcadillac.ru 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] 15932827 HOSE, P/B BOOS VAC (ACDelco #176-1496) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (ACCEL PED LVR) 10368488 PEDAL, BRK (INCLS 12, 13, 15, 18-22) 25771615 COVER, BRK PED (ЧАСТЬ OF 11) 89047699 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 11) (INCLS 18) [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 89047780 MOTOR KIT, BRK & ACCEL PED ADJR ACTR [ЭЛЕКТРОДВИГАТЕЛЬ ПЕДАЛЬНОГО УЗЛА 19 ВТ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 11, 13) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 11) 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 11) 25697461 RETAINER, BRK PED PUSH ROD BOOT (ЧАСТЬ OF 11) 89047779 CABLE, ACCEL CONT 89047778 CABLE, BRK PED ADJR ACTR [ЖГУТ ПРОВОДОВ] 25741052 BRACKET, BRK PED BRKT 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-018) - 2004-2007 E КОРПУС КП ЧАСТЬ 2 INTERNAL COMPONENTS(MX5) ↓ 88984517 WASHER, TRFER CASE PLNT CARR SUN GR THR (25.8X52.0X2.2) 88984524 GEAR, TRFER CASE PLNT CARR SUN (INPUT) (STAMPED PM/POWDERED METAL) 88984493 RING, TRFER CASE RR ВЫХОДНОЙ SHF RR BRG RET (41MM I.D.) (ACDelco #88984493) 88996564 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT 88996665 BEARING, TRFER CASE MAIN SHF FRT (ВЫХОДНОЙ ВАЛ FRT) 19168733 BUSHING, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 106) [ВТУЛКА РАЗДАТОЧНОЙ КОРОБКИ] 19178237 SHAFT, TRFER CASE RR ВЫХОДНОЙ (INCLS 105, 901) 19133264 SPROCKET, TRFER CASE FRT ВЫХОДНОЙ SHF DRV (INCLS 108) [ШЕСТЕРНЯ РАЗДАТОЧНОЙ КОРОБКИ] 19168732 BUSHING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT (ЧАСТЬ OF 107) (ACDelco #19168732) 89059578 CHAIN, TRFER CASE TWO/FOUR WHL DRV [ЦЕПЬ РАЗДАТОЧНОЙ КОРОБКИ] 88984523 GEAR, TRFER CASE PLNT CARR SUN (ВЫХОДНОЙ) 89059279 КРОНШТЕЙН, FRT/RR DRV DIFF 89059284 SHAFT, TRFER CASE FRT ВЫХОДНОЙ (INCLS 900) 88996664 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF RR teamcadillac.ru 88996671 RING, TRFER CASE FRT ВЫХОДНОЙ SHF BRG RET 88996666 SPROCKET, TRFER CASE TWO/FOUR WHL DRV DRVN [ЗВЕЗДОЧКА] 88996633 BEARING, TRFER CASE RR ВЫХОДНОЙ SHF RR (ACDelco #88996633) [ПОДШИПНИК РАЗДАТОЧНОЙ КОРОБКИ] 15580230 BEARING, TRFER CASE INPUT SHF (BORG-WARNER) (4.510) 19132966 SHAFT, TRFER CASE INPUT 88996681 DEFLECTOR, TRFER CASE FRT ВЫХОДНОЙ SHF SEAL DIRT (ЧАСТЬ OF 112) (6M04-037) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (LY7/3.6-7, EXC V92) ↓ teamcadillac.ru 19129976 HOSE, TRANS FLUID CLR LWR (W/BLOCK) (INCLS 7) 11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16] 89022494 BRACKET, TRANS FLUID CLR 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 25740416 SEAL, TRANS FLUID CLR PIPE (O RING) (1/2IN) (9.222) (ACDelco #15-31872) [ПРОКЛАДКА КОМПРЕССОРА КОНДИЦИОНЕРА] 19129977 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) 15921020 CLIP, TRANS FLUID AUX CLR PIPE (CYLINDRICAL) (1 PIPE) (6M04-038) - 2007 E ШЛАНГ ВЕНТИЛЯЦИИ ТРАНСМИССИИ (LH2/4.6A, MYB) ↓ 15236024 HOSE, TRANS VENT (INCLS 2-8) 15797504 HOSE, TRANS VENT (INCLS 2-8) 25892279 VENT, TRFER CASE (ЧАСТЬ OF 1) (ACDelco #25892279) [ЗАГЛУШКА ШЛАНГА ВЕНТИЛЯЦИИ КАРТЕРА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 08905794 CLIP (ЧАСТЬ OF 1) 06466355 CONNECTOR, TRANS VENT HOSE (TEE, CRCONT VAC (5/16 HOSE) (ЧАСТЬ OF 1) (3.278) 25526358 CЛАМПА, SPRG BAND, 14.2MM, 9/16 OD HOSE, POR (ЧАСТЬ OF 1) (6M04-041) - 2007-2008 EB26 ТОРМОЗНАЯ ПЕДАЛЬ (PWR ADJ PEDALS JF4) ↓ 25741052 BRACKET, BRK PED BRKT 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 25732428 BARRIER, BRK PED BRKT SND 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 89047778 CABLE, BRK PED ADJR ACTR [ЖГУТ ПРОВОДОВ] 89047780 MOTOR KIT, BRK & ACCEL PED ADJR ACTR [ЭЛЕКТРОДВИГАТЕЛЬ ПЕДАЛЬНОГО УЗЛА 19 ВТ] teamcadillac.ru 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (BRK PED POSN SEN) 89047699 SENSOR KIT, BRK PED POSN [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 25697461 RETAINER, BRK PED PUSH ROD BOOT (ЧАСТЬ OF 21) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 21) 10368488 PEDAL, BRK (INCLS 5, 8-10, 13, 15-20, 22) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-042) - 2007-2008 EB26 ТОРМОЗНАЯ ПЕДАЛЬ (EXC PWR ADJ PEDALS JF4) ↓ teamcadillac.ru 25741052 BRACKET, BRK PED BRKT 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 25732428 BARRIER, BRK PED BRKT SND 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 18) 89047699 SENSOR KIT, BRK PED POSN [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 15594358 BUSHING, BRK PED PIV (ЧАСТЬ OF 18) (0.831) 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 18) (0.80 IN) (PUSH IN) 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 18) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 18) 25771615 COVER, BRK PED (ЧАСТЬ OF 18) 25765419 PEDAL, BRK (W/BRKT) (INCLS 5-8, 10, 12-17, 19) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-043) - 2007-2008 EE26 ТОРМОЗНАЯ ПЕДАЛЬ ↓ 15866634 BRACKET, BRK PED BRKT 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED) [ГАЙКА] 89047704 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 12) [ДАТЧИК] 19153363 CABLE, BRK PED ADJR ACTR (ЧАСТЬ OF 12) 25771615 COVER, BRK PED (ЧАСТЬ OF 12) 15791722 PEDAL, BRK (INCLS 4-6, 8-11, 13-19) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 12) 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 12) 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 12) (0.80 IN) (PUSH IN) teamcadillac.ru 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 12) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] (6M04-044) - 2004-2009 E26 ТОРМОЗНОЙ УСИЛИТЕЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА ↓ teamcadillac.ru 88967237 BOOSTER, P/B (СМ. ГРУППУ 04.000 "ТОРМОЗНОЙ УСИЛИТЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/O VLV) (ACDelco #178-0695) 25732452 BOOT, BRK PED PUSH ROD 25697461 RETAINER, BRK PED PUSH ROD BOOT 25697462 RETAINER, BRK PED PUSH ROD BOOT 10367561 CYLINDER, BRK MAS (СМ. ГРУППУ 4.000 "ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #174-1012) [ЦИЛИНДР] 10367562 CYLINDER, BRK MAS (СМ. ГРУППУ 4.000 "ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11609949 ГАЙКА, BRK M/CYL (M10X1.5, 11.2 THK) (8.917) [ГАЙКА] 15795475 HOSE, P/B BOOS VAC 15929447 HOSE, P/B BOOS VAC 25873484 HOSE, P/B BOOS VAC (ACDelco #176-1497) (GM04-064) - 2004-2009 E ТОРМОЗНОЙ СУППОРТ-ПЕРЕДНИЙ ↓ 18047980 CALIPER, FRT BRK (INCLS 2-4, 8-10) (IF DISCONTINUED USE DURASTOP EQUIVALENT) (4.667) (ACDelco #172-1643) [ТОРМОЗНОЙ СУППОРТ] 18047981 CALIPER, FRT BRK (INCLS 2-4, 8-10) (IF DISCONTINUED USE DURASTOP EQUIVALENT) (4.667) (ACDelco #172-1644) [ТОРМОЗНОЙ СУППОРТ] 18043178 COVER, FRT BRK BLEDR SCREW (ЧАСТЬ OF 1) 18047986 VALVE KIT, FRT BRK CLPR BLEDR (ЧАСТЬ OF 1) (ACDelco #18047986) teamcadillac.ru 18046750 БОЛТ, FRT BRK CLPR GDE PIN (ЧАСТЬ OF 1, 11) (*KIT2) [БОЛТ] 18047985 PISTON KIT, FRT BRK CLPR (ЧАСТЬ OF 1) 18047988 PAD KIT, FRT DISC BRK (INCLS 4, 14) (ACDelco #171-665) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4 ШТ)] 19122384 PAD KIT, FRT DISC BRK (INCLS 4, 14) (ACDelco #171-688) 18045221 SEAL, FRT BRK CLPR GDE PIN 18047987 BRACKET, FRT BRK CLPR (W/GUIDE PIN БОЛТS) [КРОНШТЕЙН] 18046698 ПРУЖИНА, FRT DISC BRK PAD RET (ЧАСТЬ OF 11) (ACDelco #179-2235) 18047989 PIN KIT, FRT BRK CLPR GDE (INCLS 5-7) (INCLS 2 (2.5") БОЛТS) 18047984 CALIPER KIT, FRT BRK (INCLS 4, 8, 9) (4.667) (ACDelco #173-0538) (GM04-312) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (5L40-E M82) ↓ teamcadillac.ru 96042897 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 6GRG) (GM04-376) - 2004-2009 E ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР ↓ 18012741 SWITCH, BRK FLUID LVL IND (ЧАСТЬ OF 15) (ACDelco #18012741) 22688449 CAP, BRK M/CYL RSVR (ЧАСТЬ OF 15) (INCLS 3) [КРЫШКА БАЧКА ТОРМОЗНОЙ ЖИДКОСТИ] 18046711 RESERVOIR, BRK M/CYL (ЧАСТЬ OF 15) (INCLS 4, 6-7) (ACDelco #18046711) teamcadillac.ru 18060168 PISTON, BRK M/CYL SECD (ЧАСТЬ OF 15) 10367561 CYLINDER, BRK MAS (INCLS 1-14) (ACDelco #174-1012) [ЦИЛИНДР] 10367562 CYLINDER, BRK MAS (INCLS 1-14) 18022002 CYLINDER KIT, BRK MAS (INCLS 8-12) (ACDelco #175-424) (GM04-485) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (5L40-E MX5) ↓ teamcadillac.ru 96042890 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 6GGG) [АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ В СБОРЕ] (GM04-555) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 24227130 БОЛТ, C/VLV UPR BODY (M5X0.8X36) 24225398 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M6 X 1.0 X 20) 24238417 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (INCLS 316) (4.329) [ДАТЧИК ЧИСЛА ОБОРОТОВ ВАЛА AКПП] 24225797 BODY, C/VLV UPR [ГИДРОРАСПРЕДЕЛИТЕЛЬНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24237789 PLATE, C/VLV BODY SPCR (W/GSKT) (USED ON UNITS BUILT BEFORE 07/17/06) (FOR 2ND DES SEE 24240068) 24246917 PLATE, C/VLV BODY SPCR (W/GSKT) (MUST USE T/W 24238925/PLATE KIT - CONT SOL VLV FLTR) (ACDelco #24246917) (USED ON UNITS BUILT ON OR AFTER 7/17/06) (FOR 1ST DES SEE 24237789) (USED W/2007 TRANS BROADCAST CODES) (FOR 2008 TRANS BROADCAST CODES SEE 2 teamcadillac.ru 96020431 VALVE, C/VLV BODY BALL CHK [КЛАПАН] 24250384 BODY, C/VLV LWR (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ/;НИЖНИЙ КЛАПАН РЕГУЛЯТОР BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (MANUAL VALVE NOT INCLUDED) (MUST USE T/W 24236934/PLATE KIT - CONT SOL VLV FLTR) 24246427 SWITCH, A/TRNS MAN SHFT SHF POSN (INCLS 315) (INTERNAL MODE SWITCH) [ВКЛЮЧАТЕЛЬ] 24224821 БОЛТ, C/VLV LWR BODY (M5X0.8X45) 24224822 БОЛТ, C/VLV LWR BODY (M5X0.8X55) 24238925 PLATE KIT, CONT SOL VLV FLTR 24240845 БОЛТ, CONT SOL VLV HEAT SINK (W/ BODY & TCM) (M5X0.8X53.0) 24238968 VALVE, CONT SOL (W/ BODY & TCM) (ORDER T/W 24238913 SEAL KIT) [ГИДРОРАСПРЕДЕЛИТЕЛЬ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24236233 CLIP, A/TRNS MAN SHFT SHF POSN SW WRG HARN (ЧАСТЬ OF 308) 24236504 CLIP, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN WRG HARN (ЧАСТЬ OF 303) (GM04-556) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ВЕРХНИЙ КЛАПАН РЕГУЛЯТОР BODY БЛОК ↓ 24224766 PIN, C/VLV BODY LOC (ЧАСТЬ OF 321) (DIA.=10MM L=12.7) [ВТУЛКА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24225797 BODY, C/VLV UPR (INCLS 313, 322-338) [ГИДРОРАСПРЕДЕЛИТЕЛЬНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24230200 PIN, C/VLV BODY LOC (ЧАСТЬ OF 321) (DIA.=10MM L=29.9) [ВТУЛКА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24224755 RETAINER, 1-2-3-4 CLU BOOST VLV SPR (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24242814 PLUG, 1-2-3-4 CLU REG VLV BORE (ЧАСТЬ OF 321) (9.5 THK, 11.5 DIA) teamcadillac.ru (GM04-557) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) НИЖНИЙ КЛАПАН РЕГУЛЯТОР BODY БЛОК ↓ 24224755 RETAINER, CLU PSTN DAM FEED REG VLV SPR [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24242814 PLUG, CLU SEL SOL VLV BORE #2 (9.5 THK, 11.5 DIA) 24250384 BODY, C/VLV LWR (INCLS 338, 352, 353, 355-357) (MANUAL VALVE NOT INCLUDED) (MUST USE T/W 24236934/PLATE KIT - CONT SOL VLV FLTR) teamcadillac.ru 24224770 VALVE, MAN (ACDelco #24224770) (GM04-558) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) 1-2-3-4 & 3-5 REVERSE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 24225654 PLATE, 3-5 REV CLU BKG 24225569 PLATE, 3-5/REV CLU (PKG OF 4) (FIBER) (ACDelco #24225569) 24237663 PLATE, 3-5 REV CLU (PKG OF 4) (STEEL) 24225564 PLATE, 3-5 REV CLU (WAVED) 24233533 PLATE, 1-2-3-4 CLU BKG 24243588 PLATE, 1-2-3-4 CLU (ACDelco #24243588) 24232652 PLATE, 1-2-3-4 CLU (PKG OF 5) (STEEL) 24236434 PLATE, 1-2-3-4 CLU (WAVED) 24225522 DAM, 1-2-3-4 CLU PSTN 24225559 ПРУЖИНА, 1-2-3-4 CLU 24225621 PISTON, 1-2-3-4 CLU 24236049 ШЛАНГИ, 1-2-3-4 CLU PSTN 24236051 ПРУЖИНА, 3-5-REV CLU teamcadillac.ru 24236050 PISTON, 3-5/REV CLU (INCLS 422) 24237184 ШЛАНГИ, 1-2-3-4 & 3-5 REV CLU (INCLS 400, 426, 429) (ORDER T/W 24226393) (TRANS BUILT ON 01-20-07 & AFTER) (FOR 1ST DES SEE 24241232) 24241232 СЦЕПЛЕНИЕ KIT, 1-2-3-4 & 3-5 REV (INCLS 400, 426, 429) (ACDelco #24241232) (TRANS BUILT ON 01-19-07 & PRIOR) (FOR 2ND DES SEE 24237184) 24226393 BEARING, 1-2-3-4 & 3-5-REV CLU 24243891 SEAL KIT, A/TRNS SERV (INCLS 411, 415, 416, 419, 423-425) (FULL TRANS) (ACDelco #24243891) 24238920 RING KIT, RET (INCLS 411, 415) 24238922 SEAL KIT, A/TRNS SERV (INCLS 416, 418, 419, 422-425) (СЦЕПЛЕНИЕES) (ACDelco #24238922) (GM04-559) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) 4-5-6 ДЕТАЛИ СЦЕПЛЕНИЯ & ВАЛ ТУРБИНЫ ↓ 24225508 RING, 4-5-6 CLU BKG PLT RET (GREEN) (2.52-2.62) (ACDelco #24225508) 24225509 RING, 4-5-6 CLU BKG PLT RET (YELLOW) (3.08-3.18) (ACDelco #24225509) 24231591 RING, 4-5-6 CLU BKG PLT RET (GREY) (2.80-2.90) (ACDelco #24231591) 24231592 RING, 4-5-6 CLU BKG PLT RET (ORANGE) (3.36-3.46) (ACDelco #24231592) 24231593 RING, 4-5-6 CLU BKG PLT RET (BLUE) (3.64-3.74) (ACDelco #24231593) 24232879 RING, 4-5-6 CLU BKG PLT RET (WHITE) (3.74-3.84) (ACDelco #24232879) 24232880 RING, 4-5-6 CLU BKG PLT RET (YELLOW/PURPLE) (4.20-4.30) (ACDelco #24232880) 24225652 PLATE, 4-5-6 CLU BKG 24225570 PLATE, 4-5-6 CLU (INT SPLINE) (PKG OF 5) (FIBER) 24225575 PLATE, 4-5-6 CLU (EXT SPLINE) (PKG OF 5) (STEEL)FIBER) (ACDelco #24225575) 24225565 PLATE, 4-5-6 CLU (WAVED) teamcadillac.ru 24225526 DAM, 4-5-6 CLU PSTN 24225560 ПРУЖИНА, 4-5-6 CLU 24225523 PISTON, 4-5-6 CLU 24237963 ШЛАНГИ, 4-5-6 CLU (W/ INPUT SHF) (INCLS 440) 08662686 SEAL, TURB SHF (O RING) (*KIT2) (ACDelco #8662686) 24238920 RING KIT, RET (INCLS 436) 24243891 SEAL KIT, A/TRNS SERV (INCLS 436, 442, 443) (FULL TRANS) (ACDelco #24243891) (GM04-560) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) 2-6 ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 24247405 RING, 2-6 CLU BKG PLT RET (CODE 7BNA) (1.69MM +/- 0.05) (ACDelco #24247405) (WHEN ORDERING ТРАНСМИССИЯ REFER TO TECHNICAL SERVICE BULLETIN 07-07-30-011) 24247406 RING, 2-6 CLU BKG PLT RET (CODE 7BNA) (2.81MM +/- 0.05) (ACDelco #24247406) (WHEN ORDERING ТРАНСМИССИЯ REFER TO TECHNICAL SERVICE BULLETIN 07-07-30-011) teamcadillac.ru 24248107 RING, 2-6 CLU BKG PLT RET (CODE 7BNA) (2.25MM +/- 0.05) (ACDelco #24248107) (WHEN ORDERING ТРАНСМИССИЯ REFER TO TECHNICAL SERVICE BULLETIN 07-07-30-011) 24248108 RING, 2-6 CLU BKG PLT RET (CODE 7BNA) (2.53MM +/- 0.05) (ACDelco #24248108) (WHEN ORDERING ТРАНСМИССИЯ REFER TO TECHNICAL SERVICE BULLETIN 07-07-30-011) 24248109 RING, 2-6 CLU BKG PLT RET (CODE 7BNA) (1.97MM +/- 0.05) (ACDelco #24248109) (WHEN ORDERING ТРАНСМИССИЯ REFER TO TECHNICAL SERVICE BULLETIN 07-07-30-011) 24225653 PLATE, 2-6 CLU BKG 24237973 PLATE, 2-6 CLU (WAVED) 24225561 ПРУЖИНА, 2-6 CLU 24225524 PISTON, 2-6 CLU 24225447 SUPPORT, CTR (INCLS 458, 460) 24238911 PLATE KIT, CLU (INCLS 452) (ORDER T/W 24225575 & 24235455) (ACDelco #24238911) (GM04-561) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) LOW & REVERSE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 24248368 PLATE KIT, LOW & REV CLU BKG (4.180) (ACDelco #24248368) (FOR SERVICE USE (1) OF THE FOLLOWING RET. RINGS 24225515, 24225519, OR BACKING PLATE 24225656) teamcadillac.ru 24236664 PLATE, LOW & REV CLU (PKG OF 6) (FIBER) 24232654 PLATE, LOW & REV CLU (PKG OF 6) (STEEL) (ACDelco #24232654) 24237971 PLATE, LOW & REV CLU (WAVED) (ACDelco #24237971) 24225517 RING, LOW & REV CLU SPR RET 24238921 SPRAG, LOW CLU (INCLS 468) 24225562 ПРУЖИНА, LOW & REV CLU 24225525 PISTON, LOW & REV CLU (ACDelco #24225525) 24238922 SEAL KIT, A/TRNS SERV (INCLS 468) (СЦЕПЛЕНИЕES) (ACDelco #24238922) (GM04-562) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) СЦЕПЛЕНИЕ HUB БЛОК ↓ 24233660 HUB, 4-5-6 CLU (W/ ВЫХОДНОЙ CARR SHF & DPNR) (INCLS 476-478) teamcadillac.ru 24230475 DAMPENER, 4-5-6 CLU (ЧАСТЬ OF 475) 24233661 PLATE, 4-5-6 CLU DPNR APPLY (ЧАСТЬ OF 475) 24230370 RING, 4-5-6 CLU DPNR RET (ЧАСТЬ OF 475) (GM04-563) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ВЫХОДНОЙ КРОНШТЕЙН БЛОК ↓ 24225777 BEARING, CTR SUPT RLR (ЧАСТЬ OF 490) 24225483 BEARING, ВЫХОДНОЙ CARR OTR SUN GR FRT THR (ЧАСТЬ OF 490) 24225290 GEAR, ВЫХОДНОЙ CARR FRT SUN (ЧАСТЬ OF 490) 24225484 BEARING, ВЫХОДНОЙ CARR OTR SUN GR RR THR (ЧАСТЬ OF 490) 24235807 GEAR, ВЫХОДНОЙ CARR RR SUN (ЧАСТЬ OF 490) teamcadillac.ru 24225603 КРОНШТЕЙН, ВЫХОДНОЙ (INCLS 485-489, 491) (GM04-565) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ЗАМОК ПАРКОВКИ ↓ teamcadillac.ru 24242086 ACTUATOR, PARK PAWL (ACDelco #24242086) 24227077 PIN, MAN SHFT DTNT LVR HUB (ЧАСТЬ OF 505) 24234562 LEVER, MAN SHFT DTNT (INCLS 504) (ACDelco #24234562) 24225792 PIN, MAN SHFT SHF (ACDelco #24225792) 24235861 SEAL, MAN SHFT SHF (*KIT1) (ACDelco #24235861) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24225445 SHAFT, MAN SHFT (ACDelco #24225445) 24228969 SHAFT, MAN SHFT (ACDelco #24228969) 24224348 GUIDE, PARK PAWL ACTR (INCLS 510) 24224350 SEAL, PARK PAWL ACTR GDE (O RING) (ЧАСТЬ OF 509) (*KIT1) (ACDelco #24224350) 24226102 PIN, PARK PAWL ACTR GDE 24243891 SEAL KIT, A/TRNS SERV (INCLS 507, 510) (FULL TRANS) (ACDelco #24243891) (GM04-568) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ВЫХОДНОЙ ВАЛ БЛОК ↓ 24241092 RING, ВЫХОДНОЙ CARR INTL GR RET (ACDelco #24241092) 24225477 GEAR, ВЫХОДНОЙ CARR INTL (FRT) 24228887 SPACER, ВЫХОДНОЙ CARR INTL GR (3.342) 24230333 GEAR, ВЫХОДНОЙ CARR INTL (RR) teamcadillac.ru 24239398 SHAFT, ВЫХОДНОЙ (INCLS 495, 497, 498) (WHEN SERVICING SHAFT MUST ALSO REPLACE BEARING P/N 24237771) 24239401 SHAFT, ВЫХОДНОЙ (INCLS 495, 497, 498) (WHEN SERVICING SHAFT MUST ALSO REPLACE BEARING P/N 24237771) (GM04-569) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) БЛОК СЦЕПЛЕНИЯ & ДЕТАЛИ КОМПЛЕКТА ↓ 24225602 КРОНШТЕЙН, INPUT (ACDelco #24225602) 24225289 GEAR, INPUT SUN (ACDelco #24225289) 24224405 BEARING, INPUT SUN GR THR (ACDelco #24224405) 24232409 WASHER, INPUT SUN GR THR 24238905 BEARING, TURB SHFT THR [ПОДШИПНИК] 24233732 BEARING, 4-5-6 CLU HUB THR (ACDelco #24233732) 24225597 HUB, 1-2-3-4 CLU (W/ВЫХОДНОЙ CARR INR SUN GR SHF) teamcadillac.ru 24224163 BEARING, 1-2-3-4 CLU HUB THR (ACDelco #24224163) 24225596 HUB, 2-6 & 3-5/REV CLU (W/ ВЫХОДНОЙ CARR OTR SUN GR SHF) (INCLS 60, 62) 24224164 BEARING, 2-6 & 3-5/REV CLU HUB THR (ACDelco #24224164) 24225512 RING, CTR SUPT RET 24225447 SUPPORT, CTR 24225486 BEARING, ВЫХОДНОЙ CARR THR 24224668 BEARING, ВЫХОДНОЙ SHF THR (ACDelco #24224668) (GM04-573) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042861 GASKET, A/TRNS CASE EXTN (*KIT1) 24237771 BEARING, ВЫХОДНОЙ SHF (ЧАСТЬ OF 27) 96042860 EXTENSION, A/TRNS CASE (INCLS 26, 28, 29) 24237771 BEARING, ВЫХОДНОЙ SHF (ЧАСТЬ OF 27) 96041851 SEAL, PROP SHF TRANS FLG FLUID (ЧАСТЬ OF 27) (*KIT1) [ПРОКЛАДКА ТРАНСФОРМАТОРНОГО ВАЛА] 96042984 FLANGE, ВЫХОДНОЙ SHF 96041805 NUT KIT, ВЫХОДНОЙ SHFT (INCLS 30, 32, 33) (M6X1.0X16) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) (*KIT1) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) (*KIT1) 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96042963 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPACER PLATE & GASKET) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) 96042712 DETENT, MAN SHFT 96017928 CLIP, WRG HARN 96042847 HARNESS, A/TRNS WRG 96041849 SEAL, A/TRNS WRG CONN (O RING) (*KIT1) 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN (*KIT1) [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (*KIT1) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (*KIT1) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) teamcadillac.ru 96042945 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/GSKT, SEAL, RET) (INCLS 25, 29, 36, 38, 46, 56, 60, 63, 64) (GM04-574) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042887 GASKET, A/TRNS CASE EXTN [ПРОКЛАДКА КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042888 EXTENSION, A/TRNS CASE (INCLS 28, 69) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96042963 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPACER PLATE & GASKET) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) 96042712 DETENT, MAN SHFT 96017928 CLIP, WRG HARN 96042847 HARNESS, A/TRNS WRG teamcadillac.ru 96041849 SEAL, A/TRNS WRG CONN (O RING) 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) 96042543 WASHER, INPUT & REACTION CARR THR 96042587 SEAL, PROP SHF TRANS FLG FLUID [ПРОКЛАДКА КРЫШКИ РАЗДАТОЧНОЙ КОРОБКИ] 08677884 BEARING, ВЫХОДНОЙ SHF THR (ЧАСТЬ OF 27) (4.180) (ACDelco #8677884) (GM04-575) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ 96042554 CONVERTER, TORQ (REMAN) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042812 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) teamcadillac.ru 96042806 СЦЕПЛЕНИЕ, DIR & REV (СМ. ГРУППУ 04.000 "DIRECT AND REVERSE СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042807 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (СМ. ГРУППУ 04.000 "FORWARD AND COAST СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042698 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) (СМ. ГРУППУ 04.000 "INPUT SUN GEAR SHAFT AND FORWARD SPRAG СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (СМ. ГРУППУ 04.000 "DIRECT СЦЕПЛЕНИЕ DRUM AND SHAFT" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042701 WASHER, INPUT & REACTION CARR INR SHF THR 96042808 ШЛАНГИ, O/D CLU (СМ. ГРУППУ 04.000 "OVERDRIVE AND INTERMEDIATE СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (СМ. ГРУППУ 04.000 "LOW СЦЕПЛЕНИЕ SPRAG" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042705 BEARING, CTR SUPT RLR (4.180) 96042809 SUPPORT, CTR (СМ. ГРУППУ 04.000 "CENTER SUPPORT" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042707 КРОНШТЕЙН, INPUT & REACTION (СМ. ГРУППУ 04.000 "PLANETARY КРОНШТЕЙН" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (4.176) 96042708 BEARING, INPUT & REACTION CARR THR 96042709 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (СМ. ГРУППУ 04.000 "ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96041847 WASHER, INPUT & REACTION CARR THR (4.265) (GM04-576) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ 96042554 CONVERTER, TORQ (REMAN) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042812 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) 96042814 СЦЕПЛЕНИЕ, DIR & REV 96042815 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) 96042698 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) (INCLS 9) 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) 96042701 WASHER, INPUT & REACTION CARR INR SHF THR 96042808 ШЛАНГИ, O/D CLU teamcadillac.ru 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) 08677884 BEARING, LOW CLU RLR THR (*KIT1) (ACDelco #8677884) 96042816 SUPPORT, CTR 96042817 КРОНШТЕЙН, INPUT & REACTION 96042818 BEARING, INPUT & REACTION CARR THR 96042813 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) 96042543 WASHER, INPUT & REACTION CARR THR 96042818 BEARING, INPUT & REACTION CARR THR (GM04-577) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ teamcadillac.ru 96015215 БОЛТ, T/CV FLUID SEAL (*KIT1) 96041855 SEAL, T/CV FLUID [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042812 ШЛАНГИ KIT, T/CV (INCLS 200-215, 217-220, 223, 226-228, 231-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-577) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ teamcadillac.ru 24212478 SLIDE, A/TRNS ГИДРОНАСОС (17.9545MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212478) 24212479 SLIDE, A/TRNS ГИДРОНАСОС (17.9675MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212479) 24212480 SLIDE, A/TRNS ГИДРОНАСОС (17.9805MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212480) 24212481 SLIDE, A/TRNS ГИДРОНАСОС (17.9935MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212481) 24212482 SLIDE, A/TRNS ГИДРОНАСОС (18.0065MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212482) 24201144 RING, A/TRNS ГИДРОНАСОС VANE (RING, PUMP VANE) (ACDelco #24201144) 08631280 VANE, A/TRNS ГИДРОНАСОС (ACDelco #8631280) 24205410 GUIDE, A/TRNS ГИДРОНАСОС ROT (13 VANE) (ACDelco #24205410) 24201144 RING, A/TRNS ГИДРОНАСОС VANE (RING, PUMP VANE) (ACDelco #24201144) 96015215 БОЛТ, T/CV FLUID SEAL (*KIT1) 96041855 SEAL, T/CV FLUID [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042812 ШЛАНГИ KIT, T/CV (INCLS 200-215, 217-220, 223, 226-228, 231-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-578) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 300-309, 312-334) (INCLS SPACER PLATE & GASKET) 96042986 GASKET KIT, A/TRNS (INCLS 303, 305, 306, 308, 309, 312, 314, 316, 330, 332) (4.265) (GM04-578) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 300-334) (INCLS SPACER PLATE & GASKET) 96042986 GASKET KIT, A/TRNS (INCLS 303, 305, 306, 308, 309, 312, 314, 316, 330, 332) (4.265) (GM04-579) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 96042599 VALVE, TCC PWM SOL 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 340-351, 353-356) (INCLS SPACER PLATE & GASKET) (GM04-579) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 10471813 SEAL, TCC SOL VLV (O RING) (SMALL DIA) (OTR) (ACDelco #10471813) 10475842 SEAL, TCC SOL VLV (O RING) (14 MM I.D.) (INR) (ACDelco #10475842) 96042599 VALVE, TCC PWM SOL 10471813 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (SMALL DIA) (OTR) (ACDelco #10471813) 10475842 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (14 MM I.D.) (INR) (ACDelco #10475842) 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 340-348, 351, 353-354) (INCLS SPACER PLATE & GASKET) (GM04-580) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] teamcadillac.ru 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 343, 349, 350, 365-367, 370-375, 377-388) (INCLS SPACER PLATE & GASKET) (GM04-580) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 10471813 SEAL, TCC SOL VLV (O RING) (SMALL DIA) (OTR) (ACDelco #10471813) 10475842 SEAL, TCC SOL VLV (O RING) (14 MM I.D.) (INR) (ACDelco #10475842) 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] teamcadillac.ru 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 343, 351, 365-367, 370-375, 377-388) (INCLS SPACER PLATE & GASKET) 96042889 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/PLT, GSKT, SEAL) (INCLS 343, 351, 365-367, 370-375, 377-388) (GM04-581) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru 96042806 СЦЕПЛЕНИЕ, DIR & REV (INCLS 400-420) (GM04-581) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru 96042814 СЦЕПЛЕНИЕ, DIR & REV (INCLS 400-420) (GM04-582) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96041856 SEAL, INPUT SHF (O RING) (*KIT1) [ПРОКЛАДКА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] teamcadillac.ru 96042807 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-451) (GM04-582) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042815 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-451) (GM04-583) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042707 КРОНШТЕЙН, INPUT & REACTION (INCLS 455-462) (4.176) (GM04-583) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96042817 КРОНШТЕЙН, INPUT & REACTION (INCLS 455-462) (GM04-584) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ teamcadillac.ru 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-584) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-585) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 470-477) (GM04-585) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 470-477) (GM04-586) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 480-497) (GM04-586) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 480-497) (GM04-587) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК ↓ teamcadillac.ru 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (INCLS 500-505) (GM04-587) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК ↓ 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (INCLS 500-505) (GM04-588) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) КРЕПЛЕНИЕ ↓ teamcadillac.ru 96042809 SUPPORT, CTR (INCLS 510-535) (GM04-588) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) КРЕПЛЕНИЕ ↓ teamcadillac.ru 96042816 SUPPORT, CTR (INCLS 510-535) (GM04-589) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) PLANETARY КРОНШТЕЙН БЛОК ↓ teamcadillac.ru 96042707 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-554) (4.176) (GM04-589) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) PLANETARY КРОНШТЕЙН БЛОК ↓ teamcadillac.ru 96042817 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-554) (GM04-590) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК ↓ 96042709 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560-564) (GM04-591) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК ↓ teamcadillac.ru 96042813 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560-561, 563-564) (GM04-593) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) PARKING PAWL БЛОК ↓ 96042710 LEVER, MAN SHFT DTNT teamcadillac.ru 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 96042540 SWITCH, A/TRNS MAN SHFT SHF POSN [ВЫКЛЮЧАТЕЛЬ ПРИВОДА] 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 08644709 SEAL, MAN SHFT SHF (W/O PTFE LUBRICANT APPLIED TO SEAL) (ACDelco #8644709) 96041857 SHAFT, MAN SHFT 96042711 PAWL KIT, PARK 96041852 PLUG, MAN SHFT SHF HOLE (4.279) 96041842 SPACER, MAN SHFT DTNT LVR (GM04-594) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) PARKING PAWL БЛОК ↓ 96042710 LEVER, MAN SHFT DTNT 96042819 LEVER, MAN SHFT DTNT 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 96042540 SWITCH, A/TRNS MAN SHFT SHF POSN [ВЫКЛЮЧАТЕЛЬ ПРИВОДА] teamcadillac.ru 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 08644709 SEAL, MAN SHFT SHF (W/O PTFE LUBRICANT APPLIED TO SEAL) (ACDelco #8644709) 96042544 SHAFT KIT, MAN SHFT 96042711 PAWL KIT, PARK 96042820 PAWL KIT, PARK (GM04-598) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (6L50 MYB, ЗАДНИЙ КОЛЕСО DRIVE MX0) ↓ teamcadillac.ru 17804012 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 7BNA) (WHEN ORDERING ТРАНСМИССИЯ REFER TO TECHNICAL SERVICE BULLETIN 07-07-30-011) (GM04-599) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (6L50 MYB, ALL КОЛЕСО DRIVE MX7) ↓ teamcadillac.ru 17804013 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 7BPA) (WHEN ORDERING ТРАНСМИССИЯ REFER TO TECHNICAL SERVICE BULLETIN 07-07-30-011) [ТРАНСМИССИОННОЕ МАСЛО7BPA (GOODWRENCH REMAN)] (GM04-667) - 2007-2008 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 24240018 CONVERTER, TORQ [ГИДРОТРАНСФОРМАТОР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 11515762 БОЛТ-HFLGE, M8X1.25X50, 18 OD, 22 THD, 10.9, PZO (T/CV HSG) 24205899 PLUG, T/CV HSG ACC HOLE (28MM W/3 TANGS) (SMALL CVR) (ACDelco #24205899) 24225543 SEAL, A/TRNS ГИДРОНАСОС (ACDelco #24225543) [ПРОКЛАДКА КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24242045 CASE, A/TRNS (INCLS 6, 12, 41) (ACDelco #24242045) 24242046 CASE, A/TRNS (INCLS 6, 12, 41) (ACDelco #24242046) 24226020 PLUG, TRANS FLUID FIL TUBE 24239878 SLEEVE, A/TRNS ELEC CONN PASG [МУФТА] 24225788 БОЛТ, A/TRNS CASE EXTN (M10X1.5X34) 24225557 SEAL, CTR SUPT FLUID PASG (*KIT2) 24224820 БОЛТ, VLV BODY (USED ON TRANS BUILT ON 12-31-06 & PRIOR) (FOR 2ND DES SEE 24237181) 24237181 БОЛТ, VLV BODY (M5X0.8X73.0) (USED ON TRANS BUILT ON 01-01-07 & AFTER) (FOR 1ST DES SEE 24224820) 24231074 БОЛТ, MAN SHFT DTNT (M10X1X14.5) 24222646 DETENT, MAN SHFT (W/8MM DIA. ROLLER) (ACDelco #24222646) 24236933 FILTER KIT, A/TRNS FLUID (INCLS 25) (ACDelco #24236933) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24225800 GASKET, A/TRNS FLUID PAN (ACDelco #24225800) [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 29535617 MAGNET, A/TRNS FLUID PAN (4.105) (ACDelco #29535617) [МАГНИТ] 24237064 PAN, A/TRNS FLUID (INCLS 31) (TRANS BUILT ON 3-2-07 & PRIOR) (FOR 2ND DES SEE 24242410) teamcadillac.ru 24242410 PAN, A/TRNS FLUID (INCLS 31) (ACDelco #24242410) (MUST SERVICE T/W 24236933 FILTER FOR TRANS BUILT ON 3-2-07 & PRIOR) 11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (A/TRNS FLUID PAN) [БОЛТ М6] 24234212 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 29) (ACDelco #24234212) [ПРОБКА] 24205900 PLUG, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] 24225783 SEAL, A/TRNS CASE EXTN (ACDelco #24225783) [УПЛОТНИТЕЛЬ КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24237879 EXTENSION, A/TRNS CASE (INCLS 36, 37) (ACDelco #24237879) 24228876 SEAL, ВЫХОДНОЙ SHF (ЧАСТЬ OF 34) (5.556) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24214158 BEARING, ВЫХОДНОЙ SHF (DRAWN CUP) (ЧАСТЬ OF 34) (4.131) (ACDelco #24214158) 24230287 FLANGE, PROP SHF TRANS 24231524 ГАЙКА, FRT PROP SHF FLG (M22X1.5) (FLANGE HEX) 24229687 EXTENSION, A/TRNS CASE (MCHG) 24237771 BEARING, ВЫХОДНОЙ SHF (ЧАСТЬ OF 7) 24242995 BEARING, ВЫХОДНОЙ SHF (ЧАСТЬ OF 7) [ПОДШИПНИК КПП] 24236928 SEAL KIT, A/TRNS ELEC CONN PASG SLEV (INCLS 9, 10) 24238913 SEAL KIT, A/TRNS SERV (INCLS 9, 10, 18-20) (CONTROL VLV SOL ASM) (ACDelco #24238913) [КОМПЛЕКТ ПРОКЛАДОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (5ШТ)] 04 - КОРПУС КП ↓ (6D00-036) - 2007-2008 E ТРАНСМИССИЯ TO КРЕПЛЕНИЕ ДВИГАТЕЛЯ (LH2/4.6A) ↓ 12582606 FLYКОЛЕСО, ENG 25773136 BRACKET, ENG WRG HARN (CHANNEL) 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] 24205900 PLUG, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] 24205899 PLUG, T/CV HSG ACC HOLE (28MM W/3 TANGS) (SMALL CVR) (ACDelco #24205899) 11589116 БОЛТ, FLYWHL (8.900) 12568122 COVER, FLYWHL HSG 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (TRANS CONV CVR) (ACDelco #11517518) [БОЛТ] teamcadillac.ru 12568123 COVER, TRANS CONV (6D04-023) - 2004-2009 E СТОЯНОЧНЫЙ ТОРМОЗ ASM ↓ 88951984 PLATE, RR PARK BRK ANC BKG (4.591) 88951985 PLATE, RR PARK BRK ANC BKG (4.591) 88951982 ACTUATOR KIT, RR PARK BRK (INCLS 2) (ACDelco #179-2053) [АКТУАТОР] 88951983 ACTUATOR KIT, RR PARK BRK (INCLS 2) (ACDelco #179-2054) [АКТУАТОР] teamcadillac.ru 89047676 SHOE KIT, RR PARK BRK (INCLS 5) (ACDelco #171-0915) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (2 ШТ)] (6D04-031) - 2004-2009 E ТОРМОЗНОЙ СУППОРТ-ЗАДНИЙ ↓ 89047677 CALIPER KIT, RR BRK (INCLS 2, 3, 7-9) (ACDelco #172-2343) 89047678 CALIPER KIT, RR BRK (INCLS 2, 3, 7-9) (ACDelco #172-2344) [ТОРМОЗНОЙ СУППОРТ] 88951992 CAP, RR BRK BLEDR VLV (ЧАСТЬ OF 1) 88951991 VALVE, RR BRK CLPR BLEDR (ЧАСТЬ OF 1) 89047757 PAD KIT, RR DISC BRK (INCLS 4, 12) (ACDelco #171-859) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4 ШТ)] teamcadillac.ru 89047758 PAD KIT, RR DISC BRK (INCLS 4, 12) (4.667) (ACDelco #171-0906) [ТОРМОЗНЫЕ КОЛОДКИ] 88957163 BRACKET, RR BRK CLPR [СКОБА ТОРМОЗНОГО СУППОРТА] 89047759 PIN KIT, RR BRK CLPR GDE (INCLS 4-6) (INCLS 2 PINS, 2 SEALS & 2 (2.75") БОЛТS) (ACDelco #179-2044) [НАПРАВЛЯЮЩАЯ ТОРМОЗНОГО СУППОРТА (2 ШТ)] 88957162 REPAIR KIT, RR BRK CLPR HYD (INCLS 4, 6, 8, 9) (6D04-033) - 2004-2009 E ТОРМОЗНОЙ УСИЛИТЕЛЬ ↓ teamcadillac.ru 88967237 BOOSTER, P/B (W/O VLV) (ACDelco #178-0695) 05461808 GROMMET, P/B BOOS VAC CHK VLV (*KIT1) 03817880 RETAINER, BRK PED PUSH ROD (0.80 IN) (PUSH IN) 18022219 VALVE KIT, P/B BOOS VAC CHK (INCLS 2, 3) (BLACK) (INCLS VLV & GROM) (ACDelco #179-1266) (6D04-067) - 2007-2009 E КОРПУС КП КРЕПЛЕНИЕ (MYB,MX7) ↓ teamcadillac.ru 24231525 GASKET, TRFER CASE 19132968 CASE, TRFER (W/GEARS) (LESS DAMPENER) 24243367 CASE, TRFER (W/GEARS) 11589341 БОЛТ - HFH, M10X1.5X69.9, 28.35 THD, 22.3 OD, 10.9, GMW3359, M-PT. (TRFER CASE) [БОЛТ] (6E00-014) - 2004-2009 E ТРАНСМИССИЯ TO КРЕПЛЕНИЕ ДВИГАТЕЛЯ (LY7/3.6-7) ↓ teamcadillac.ru 12572042 PLATE, A/TRNS FLEX 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (TRANS CVR) [БОЛТ] 24222918 COVER, TRANS CONV 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] (6E03-019) - 2007-2009 E T.C.M. МОДУЛЬ (LY7/3.6-7) ↓ 12605670 МОДУЛЬ, ENG CONT (W/O CALN & OPERG SYS) (ACDelco #216-130) [БЛОК УПРАВЛЕНИЯ ДВИГАТЕЛЕМ] 25784072 BRACKET, ECM (INCLS 5, 6) teamcadillac.ru 24239785 МОДУЛЬ, TRANS CONT 11609462 SCREW, M4.2X1.41X13, GMW4205 (ЧАСТЬ OF 3) 11561758 БОЛТ, MULTIUSE RLY & FUSE BRKT (7.833) [БОЛТ] 15879156 BRACKET, ACSRY WRG J/BLK 11609599 STUD, SPL, M6X1X25, 13 THD, 11 OD HD W/26 WIDE CLIP, 9.8, 6280M, P-PT (MULTIUSE FUSE BRKT) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (MULTIUSE RLY & FUSE BRKT) [ГАЙКА М6] (6E04-007) - 2007-2009 EB ТОРМОЗНЫЕ ШЛАНГИ И ТРУБКИ ↓ 15933099 HOSE, FRT BRK (INCLS 15, 16) (ACDelco #176-1495) 11569742 RETAINER, FRT BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (BRK & FUEL FEED & FUEL RTN & EVAP EMIS) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА] 25761218 BRACKET, FUEL PIPE 25761217 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (3.162) 12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (FRT BRK) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА] 10388788 PIPE, BRK PRESS MOD VLV FRT (INCLS 29) 10388794 PIPE, BRK PRESS MOD VLV RR (INCLS 29) 03541444 SPACER, FRT BRK PIPE 11516521 БОЛТ, HFH M6X1X20, 9.8, 7114M, DOG PT, 14.2 OD (FRT BRK HOSE) 15933098 HOSE, FRT BRK (INCLS 15, 16) (ACDelco #176-1487) 25743891 RETAINER, RR BRK FRT PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT) 11569737 FITTING, FRT BRK PIPE (ЧАСТЬ OF 1, 12) (7/16-24X0.36, 0.30THD) (0.56 LONG, 3/16TUBE) 25743891 RETAINER, FRT BRK PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT) 25737279 CLIP, FRT BRK PIPE (THREE WAY RETAINER SINGLE CENTRAL FIR-TREE ATTACHMENT) 15270078 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (USES RETAINER PIN FOR ATTACHMENT) [ЗАЖИМ ТРУБКИ ТОПЛИВНОЙ СИСТЕМЫ] teamcadillac.ru 25688547 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (RETAINER W/5 HOLES (2)7.95, (2)4.76, (1)9.52MM) 25749839 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (HOLDS 3 ТРУБКИ, FLAT SHAPE, SNAP-IN RETAINER) 25607191 RETAINER, BRK PIPE (21.5X10.0MM) (HOLDS (2) 4.68-4.82 TUBES) 11569742 RETAINER, RR BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 15724650 ГАЙКА, INVERTED FLARED TUBE, 9/16"-18, 1/4" TUBE, ZD (BRK PIPE) (4.686) [ГАЙКА] 25693890 RETAINER, RR BRK PIPE (HOLDS (1) 4.76 LINE) (W/TREE) [ЗАМОК, ФИКСАТОР] 11588803 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 7, 8) (1/2-20X.40, .32 THD) (INVERTED FLARED TUBE) (.62 LONG, 1/4 TUBE) [ГАЙКА М20] 15724650 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 7, 8) (9/16-18 X .40) (INVERTED FLARED TUBE) [ГАЙКА] 15933091 HOSE, RR BRK (INCLS 22, 23) (ACDelco #15933091) 15933092 HOSE, RR BRK (INCLS 22, 23) (ACDelco #15933092) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ] 88964150 PROTECTOR, FRT BRK PIPE (FOR 3/16" PIPE) (HT SHRINK) (6E04-008) - 2007-2009 EB ТОРМОЗНАЯ ПЕДАЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (EXC (JF4)) ↓ 25732428 BARRIER, BRK PED BRKT SND 25697461 RETAINER, BRK PED PUSH ROD BOOT 25732452 BOOT, BRK PED PUSH ROD 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] 15932827 HOSE, P/B BOOS VAC (ACDelco #176-1496) 25765419 PEDAL, BRK (W/BRKT) (INCLS 10, 11, 14, 16-18) 25771615 COVER, BRK PED (ЧАСТЬ OF 9) 89047699 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 9) [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 9) 10434956 BUSHING, BRK PED PUSH ROD teamcadillac.ru 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 9) 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 9) (0.80 IN) (PUSH IN) (6E04-012) - 2007-2009 E КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS(MYB,MX7) ↓ 88996677 CASE, TRFER (FRT HALF) (INCLS 12-14) 19133265 CASE, TRFER (RR HALF) (INCLS 5, 7) 88996679 SNUBBER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN 88996680 БОЛТ, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN SNBR (M5X0.8X16) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 2) 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL FILL) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996657 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 2) [УПЛОТНИТЕЛЬ] 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL DRN) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996680 БОЛТ, TRFER CASE VENT BFL (M5X0.8X16) (4.535) 88996658 BAFFLE, TRFER CASE VENT 89048123 БОЛТ, TRFER CASE HALF (M8X1.25X30) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 1) 88996656 SEAL, TRFER CASE INPUT SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 88996657 SEAL, TRFER CASE FRT ВЫХОДНОЙ SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] teamcadillac.ru (6E04-013) - 2007-2009 E КОРПУС КП ЧАСТЬ 2 INTERNAL COMPONENTS(MYB,MX7) ↓ 88984517 WASHER, TRFER CASE PLNT CARR SUN GR THR (25.8X52.0X2.2) 88984524 GEAR, TRFER CASE PLNT CARR SUN (INPUT) (STAMPED PM/POWDERED METAL) 88984493 RING, TRFER CASE RR ВЫХОДНОЙ SHF RR BRG RET (41MM I.D.) (ACDelco #88984493) 88996564 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT 88996665 BEARING, TRFER CASE MAIN SHF FRT (ВЫХОДНОЙ ВАЛ FRT) teamcadillac.ru 19168733 BUSHING, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 106) [ВТУЛКА РАЗДАТОЧНОЙ КОРОБКИ] 19178238 SHAFT, TRFER CASE RR ВЫХОДНОЙ (INCLS 105) 19133264 SPROCKET, TRFER CASE FRT ВЫХОДНОЙ SHF DRV (INCLS 108) [ШЕСТЕРНЯ РАЗДАТОЧНОЙ КОРОБКИ] 19168732 BUSHING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT (ЧАСТЬ OF 107) (ACDelco #19168732) 19132837 CHAIN, TRFER CASE TWO/FOUR WHL DRV 88984523 GEAR, TRFER CASE PLNT CARR SUN (ВЫХОДНОЙ) 89059279 КРОНШТЕЙН, FRT/RR DRV DIFF 89059284 SHAFT, TRFER CASE FRT ВЫХОДНОЙ (INCLS 900) 88996664 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF RR 88996671 RING, TRFER CASE FRT ВЫХОДНОЙ SHF BRG RET 88996666 SPROCKET, TRFER CASE TWO/FOUR WHL DRV DRVN [ЗВЕЗДОЧКА] 88996633 BEARING, TRFER CASE RR ВЫХОДНОЙ SHF RR (ACDelco #88996633) [ПОДШИПНИК РАЗДАТОЧНОЙ КОРОБКИ] 15580230 BEARING, TRFER CASE INPUT SHF (BORG-WARNER) (4.510) 19132966 SHAFT, TRFER CASE INPUT 88996681 DEFLECTOR, TRFER CASE FRT ВЫХОДНОЙ SHF SEAL DIRT (ЧАСТЬ OF 112) (6E04-016) - 2004-2009 E КЛАПАН РЕГУЛИРОВКИ ДАВЛЕНИЯ В ТОРМОЗНОЙ СИСТЕМЕ ↓ 19153350 МОДУЛЬ KIT, ELEK BRK & TRACT CONT [МОДУЛЬ] 89060233 VALVE KIT, BRK PRESS MOD (INCLS 3, 4) (ACDelco #89060233) [ГИДРАВЛИЧЕСКИЙ БЛОК АБС] 25743362 SENSOR, BRK PRESS MOD VLV PRESS (ЧАСТЬ OF 2) (ACDelco #25743362) [ДАТЧИК] 25741456 INSULATOR, BRK PRESS MOD VLV (ЧАСТЬ OF 2) 11588304 STUD, FLANGE DOUBLE END, M8X14 UNTHD, M8X1.25X13, 17 OD, 5.8, GM4345M (BRK PRESS MOD VLV BRKT) teamcadillac.ru 11514596 ГАЙКА, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (BRK PRESS MOD VLV BRKT) (8.915) (ACDelco #11514596) 11508351 SCREW, PAN HD, C/R, 5X0.8X13, 9.3 OD, FULL THD, THD RLLR, 6171M, PC (BRK PRESS MOD VLV) (8.977) (6E04-017) - 2007-2009 E ШЛАНГ ВЕНТИЛЯЦИИ ТРАНСМИССИИ (LY7/3.6-7, M82,MX5) ↓ 25764835 VENT, A/TRNS (INCLS 2, 3) (ACDelco #25764835) teamcadillac.ru 15955072 CLIP, TRANS VENT HOSE (ЧАСТЬ OF 1) (.650MM DIA) (2.343) (6E04-018) - 2004-2009 E КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS(MX5) ↓ 88996677 CASE, TRFER (FRT HALF) (INCLS 12-14) 19133265 CASE, TRFER (RR HALF) (INCLS 5, 7) 88996679 SNUBBER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN 88996680 БОЛТ, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN SNBR (M5X0.8X16) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 2) 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL FILL) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996657 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 2) [УПЛОТНИТЕЛЬ] 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL DRN) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] teamcadillac.ru 88996680 БОЛТ, TRFER CASE VENT BFL (M5X0.8X16) (4.535) 88996658 BAFFLE, TRFER CASE VENT 89048123 БОЛТ, TRFER CASE HALF (M8X1.25X30) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 1) 88996656 SEAL, TRFER CASE INPUT SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 88996657 SEAL, TRFER CASE FRT ВЫХОДНОЙ SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 19180066 VENT, TRFER CASE 89048123 БОЛТ, TRFER CASE VIB DPNR (M8X1.25X30) 19133173 DAMPENER, TRFER CASE VIB (YOKE STYLE; БОЛТS TO RR OF T-CASE) (6E04-020) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ 24218963 RING, T/CV FLUID SEAL RET [КОЛЬЦО] 24237531 SEAL, T/CV FLUID (ЧАСТЬ OF 217, 219) (ACDelco #24237531) [УПЛОТНЕНИЕ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 00444613 PLUG, HEX HD, 1/8-27 NPTF, STL (LINE PRESS TEST HOLE) (ACDelco #444613) 24239385 ШЛАНГИ, T/CV (MCHG) (INCLS 206) 24225422 PIPE, A/TRNS VENT 15251488 SEAL, TRANS FLUID CLR PIPE FTG (ЧАСТЬ OF 217, 219) (SEALS TWO ТРУБКИ) (*KIT1) [УПЛОТНЕНИЕ] 24237658 SEAL, TRANS FLUID CLR PIPE FTG (ЧАСТЬ OF 217, 219) (SEALS ONE PIPE) (*KIT1) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ] 24222668 SLIDE, A/TRNS ГИДРОНАСОС (17.948MM-17.961MM) (ACDelco #24222668) 24224131 SLIDE, A/TRNS ГИДРОНАСОС (17.961MM-17.974MM) (ACDelco #24224131) 24224132 SLIDE, A/TRNS ГИДРОНАСОС (17.974MM-17.987MM) (ACDelco #24224132) teamcadillac.ru 24238915 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 207-211, 213-216, 230) (17.948MM-17.961MM) (ACDelco #24238915) 24238916 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 207-211, 213-216, 230) (17.961MM-17.974MM) (ACDelco #24238916) 24238917 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 207-211, 213-216, 230) (17.974MM-17.987MM) (ACDelco #24238917) 24238919 COVER KIT, A/TRNS ГИДРОНАСОС (INCLS CONTROL VLV SEAL KIT) (INCLS 201, 205, 218, 220-230, 232-237) (ACDelco #24238919) 00147500 VALVE, PRESS RLF BALL (ЧАСТЬ OF 219) 24224692 WASHER, 1-2-3-4 & 3-5 REV CLU HSG THR (ЧАСТЬ OF 219) 24239151 RING, 1-2-3-4 & 3-5 REV CLU FLUID SEAL (ЧАСТЬ OF 217, 219) (*KIT1) (ACDelco #24239151) 24227061 БОЛТ, A/TRNS ГИДРОНАСОС CVR (ACDelco #24227061) [БОЛТ] 90351709 PIN, A/TRNS ГИДРОНАСОС LOC (ЧАСТЬ OF 219) ("8MM HOLLOW SPLIT PIN") (1.639) [ШПИЛЬКА] 24243891 SEAL KIT, A/TRNS SERV (INCLS 205, 210, 214, 230) (FULL TRANS) (ACDelco #24243891) (6E04-022) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (LY7/3.6-7, V92) ↓ 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] teamcadillac.ru 89022494 BRACKET, TRANS FLUID CLR 19129782 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) [ТРУБКА МАСЛООХЛАДИТЕЛЯ] 19130214 SEAL, TRANS FLUID CLR HOSE CONN (O RING) 19129781 HOSE, TRANS FLUID CLR LWR (W/BLOCK) 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 89022522 COOLER, TRANS FLUID (INCLS 7-10) (6E04-024) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (LH2/4.6A, EXC V92) ↓ 88957425 COOLER, TRANS FLUID (INCLS 7-9) (ACDelco #88957425) [ВЕНТИЛЯТОР] 11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) [БОЛТ, М8Х1.25Х31.5] teamcadillac.ru 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 15251488 SEAL, TRANS FLUID CLR PIPE FTG (ЧАСТЬ OF 5) (SEALS TWO ТРУБКИ) [УПЛОТНЕНИЕ] 15882260 PIPE, TRANS FLUID CLR INL & OTLT (INCLS 4, 6) [ТРУБКА МАСЛОПРОВОДА] 10405874 CLIP, TRANS FLUID CLR PIPE (ЧАСТЬ OF 5) (LESS MNTG TAB) (HOLDS TWO 9.5 DIA TUBES) 11570323 БОЛТ, КОНДИЦИОНЕР CNDSR (M6X1X18, 13 THD) (1.277) 15921020 CLIP, TRANS FLUID AUX CLR PIPE (CYLINDRICAL) (1 PIPE) (6E04-025) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (LH2/4.6A, V92) ↓ 89022522 COOLER, TRANS FLUID (INCLS 7-10) 11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) [БОЛТ, М8Х1.25Х31.5] 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 15882260 PIPE, TRANS FLUID CLR INL & OTLT (INCLS 4, 6) [ТРУБКА МАСЛОПРОВОДА] 10405874 CLIP, TRANS FLUID CLR PIPE (ЧАСТЬ OF 5) (LESS MNTG TAB) (HOLDS TWO 9.5 DIA TUBES) teamcadillac.ru 15921020 CLIP, TRANS FLUID AUX CLR PIPE (CYLINDRICAL) (1 PIPE) (6E04-026) - 2007-2008 EE ТОРМОЗНЫЕ ШЛАНГИ И ТРУБКИ ↓ 15933092 HOSE, RR BRK (INCLS 4, 6) (ACDelco #15933092) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ] 11569742 RETAINER, RR BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 25607191 RETAINER, BRK PIPE (21.5X10.0MM) (HOLDS (2) 4.68-4.82 TUBES) 11569737 FITTING, RR BRK FRT PIPE (7/16-24X0.36, 0.30THD) (0.56 LONG, 3/16TUBE) 12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (BRK & FUEL FEED & FUEL RTN & EVAP EMIS) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА] 25693890 RETAINER, RR BRK PIPE (HOLDS (1) 4.76 LINE) (W/TREE) [ЗАМОК, ФИКСАТОР] 15933091 HOSE, RR BRK (INCLS 4, 6) (ACDelco #15933091) 15270078 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (USES RETAINER PIN FOR ATTACHMENT) [ЗАЖИМ ТРУБКИ ТОПЛИВНОЙ СИСТЕМЫ] 25688547 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (RETAINER W/5 HOLES (2)7.95, (2)4.76, (1)9.52MM) 25749839 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (HOLDS 3 ТРУБКИ, FLAT SHAPE, SNAP-IN RETAINER) 15270078 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (USES RETAINER PIN FOR ATTACHMENT) [ЗАЖИМ ТРУБКИ ТОПЛИВНОЙ СИСТЕМЫ] 10367562 CYLINDER, BRK MAS (СМ. ГРУППУ 04.000 "ГЛАВНЫЙ ЦИЛИНДР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11588803 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 17, 19) (1/2-20X.40, .32 THD) (INVERTED FLARED TUBE) (.62 LONG, 1/4 TUBE) [ГАЙКА М20] 15724650 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 17, 19) (9/16-18 X .40) (INVERTED FLARED TUBE) [ГАЙКА] 15270078 RETAINER, BRK & FUEL PIPE (USES RETAINER PIN FOR ATTACHMENT) [ЗАЖИМ ТРУБКИ ТОПЛИВНОЙ СИСТЕМЫ] 25726788 RETAINER, BRK & FUEL PIPE (SQUARE HEAD PUSH PIN W/5 HOLES (2)4.76. (2)8.00 (1)9.52) [ФИКСАТОР ТОРМОЗНЫХ ТРУБОК] 15792797 PIPE, BRK PRESS MOD VLV FRT (INCLS 15, 32) 25710094 RETAINER, BRK PRESS MOD VLV FRT & RR BRK PIPE (HOLDS (2) LINES) (W/SNAP IN CLIP) 15792796 PIPE, BRK PRESS MOD VLV RR (INCLS 15, 32) 15933098 HOSE, FRT BRK (INCLS 23, 24) (ACDelco #176-1487) 11516521 БОЛТ, HFH M6X1X20, 9.8, 7114M, DOG PT, 14.2 OD (FRT BRK HOSE) 11569742 RETAINER, FRT BRK HOSE (ЧАСТЬ OF 35) (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (FRT BRK) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА] 25743891 RETAINER, FRT BRK PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT) 03541444 SPACER, FRT BRK PIPE teamcadillac.ru 25737279 CLIP, FRT BRK PIPE (THREE WAY RETAINER SINGLE CENTRAL FIR-TREE ATTACHMENT) 25761217 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (3.162) 25765594 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (42.10MM LENGTH) (3.162) [ФИКСАТОР ТОРМОЗНЫХ ТРУБОК] 25761218 BRACKET, FUEL PIPE 15724650 ГАЙКА, INVERTED FLARED TUBE, 9/16"-18, 1/4" TUBE, ZD (ЧАСТЬ OF 17, 19) (4.686) [ГАЙКА] 25743891 RETAINER, RR BRK FRT PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT) 15933099 HOSE, FRT BRK (INCLS 23-25) (ACDelco #176-1495) (6E04-027) - 2007-2009 EB СТОЯНОЧНЫЙ ТОРМОЗ SYSTEM ↓ 10395687 LEVER, PARK BRK (INCLS 2-4, 17, 18) 22654577 SWITCH, PARK BRK IND (ЧАСТЬ OF 1) (ACDelco #22654577) [ВКЛЮЧАТЕЛЬ] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (PARK BRK INTER CBL GDE) [ГАЙКА М6] teamcadillac.ru 15797212 CABLE, PARK BRK INTER (INCLS 5, 10, 11) (ACDelco #15797212) [ТРОС СТОЯНОЧНОГО ТОРМОЗА В СБОРЕ] 11517484 БОЛТ-HEX, M6X1X20, 9 THD, 17 OD, 9.8, 6280M, MACH, P-PT (PARK BRK INTER CBL GDE) 25764260 CABLE, PARK BRK RR (28.2X28.5X811.7MM) (ACDelco #25764260) [ТРОС СТОЯНОЧНОГО ТОРМОЗА] 25880964 HANDLE, PARK BRK REL 11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (PARK BRK REL HDL HSG) [ВИНТ] 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (КАПОТ PRIM LAT REL CBL HDL BRKT) [ВИНТ М4] 15882985 RETAINER, PARK BRK REL HDL 11570654 ГАЙКА, PARK BRK REL HDL BRKT (4.2 X 1.41) (FITS 8.75 SQ HOLE) (9.665) 89047821 CABLE, PARK BRK REL (ЧАСТЬ OF 1) (ACDelco #89047821) 10369646 БОЛТ, PARK BRK IND SW (ЧАСТЬ OF 1) (6E04-028) - 2007-2008 EE СТОЯНОЧНЫЙ ТОРМОЗ SYSTEM ↓ 15791671 LEVER, PARK BRK (INCLS 2-5, 18) 22654577 SWITCH, PARK BRK IND (ЧАСТЬ OF 1) (ACDelco #22654577) [ВКЛЮЧАТЕЛЬ] 10369646 БОЛТ, PARK BRK IND SW (ЧАСТЬ OF 1) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (PARK BRK INTER CBL GDE) [ГАЙКА М6] teamcadillac.ru 15797212 CABLE, PARK BRK INTER (INCLS 6, 11, 12) (ACDelco #15797212) [ТРОС СТОЯНОЧНОГО ТОРМОЗА В СБОРЕ] 11517484 БОЛТ-HEX, M6X1X20, 9 THD, 17 OD, 9.8, 6280M, MACH, P-PT (PARK BRK INTER CBL GDE) 25764260 CABLE, PARK BRK RR (28.2X28.5X811.7MM) (ACDelco #25764260) [ТРОС СТОЯНОЧНОГО ТОРМОЗА] 25880964 HANDLE, PARK BRK REL 11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (PARK BRK REL HDL) [ВИНТ] 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (КАПОТ PRIM LAT REL CBL HDL BRKT) [ВИНТ М4] 15922197 RETAINER, PARK BRK REL HDL (ЧАСТЬ OF 19) 11570654 ГАЙКА, I/P BRKT (4.2 X 1.41) (FITS 8.75 SQ HOLE) (9.665) 88957248 CABLE, PARK BRK REL (ЧАСТЬ OF 1) (6E04-029) - 2007-2008 EE ТОРМОЗНАЯ ПЕДАЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА ↓ 25697462 RETAINER, BRK PED PUSH ROD BOOT 25732452 BOOT, BRK PED PUSH ROD 15795475 HOSE, P/B BOOS VAC teamcadillac.ru 15929447 HOSE, P/B BOOS VAC 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] 19153363 CABLE, BRK PED ADJR ACTR (ЧАСТЬ OF 15) 89047780 MOTOR KIT, BRK & ACCEL PED ADJR ACTR (ЧАСТЬ OF 13) [ЭЛЕКТРОДВИГАТЕЛЬ ПЕДАЛЬНОГО УЗЛА 19 ВТ] 19153364 CABLE, ACCEL CONT (ЧАСТЬ OF 13) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (ACCEL PED LVR) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 15791722 PEDAL, BRK (INCLS 9, 16, 18-23) 89047704 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 15) (INCLS 23) [ДАТЧИК] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 25771615 COVER, BRK PED (ЧАСТЬ OF 15) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 15) 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 15) 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 15) (0.80 IN) (PUSH IN) 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 15, 16) (6E04-030) - 2007-2009 E УПРАВЛЕНИЕ АКПП/АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX0) ↓ 15883328 PLATE, F/FLR CNSL TRANS SHFT OPG TR PLT MT (INCLS 14) 15883329 PLATE, F/FLR CNSL TRANS SHFT OPG TR PLT MT (INCLS 14) 19150329 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (FIG SAPELE WOOD W/EBONY) 19180495 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (EBONY ON MIDDLE & SIDES) 19180497 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (COCOA ON MIDDLE & SIDES) 19180506 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (FIG SAPELE WOOD W/COCOA) 89027001 COVER, A/TRNS CONT LVR HDL (ЧАСТЬ OF 2) (4.006) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL LVR CBL BRKT) [ГАЙКА М6] 15780845 LINK, A/TRNS RANGE SEL LVR 15780847 LINK, A/TRNS RANGE SEL LVR 11519095 NUT-ACORN HEX, M8X1.0, 15MM THK, 9, 6047M, W/DOME. (A/TRNS RANGE SEL LVR) [ГАЙКА] 25789237 RETAINER, F/FLR CNSL (ЧАСТЬ OF 9) teamcadillac.ru 25807057 BEZEL, F/FLR CNSL CUP HLDR (INCLS 8) (GRAY) 25807058 BEZEL, F/FLR CNSL CUP HLDR (INCLS 8) (EBONY) 25807059 BEZEL, F/FLR CNSL CUP HLDR (INCLS 8) (CASHMERE) 19167874 CONTROL, A/TRNS 19167876 CONTROL, A/TRNS 89027003 BULB, A/TRNS CONT POSN IND (BULB W/BLUE COVER) (4.020) (ACDelco #89027003) 19122183 BEZEL, A/TRNS CONT HSG (PRNDL CHROME COVER) 11570687 БОЛТ, A/TRNS CONT LVR KNOB (ЧАСТЬ OF 2) (6E04-031) - 2007-2009 E УПРАВЛЕНИЕ АКПП/АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX7) ↓ 15883328 PLATE, F/FLR CNSL TRANS SHFT OPG TR PLT MT (INCLS 2) 15883329 PLATE, F/FLR CNSL TRANS SHFT OPG TR PLT MT (INCLS 2) 11570687 БОЛТ, A/TRNS CONT LVR KNOB (ЧАСТЬ OF 14) 89027003 BULB, A/TRNS CONT POSN IND (BULB W/BLUE COVER) (4.020) (ACDelco #89027003) 19167812 CONTROL, A/TRNS [МЕХАНИЗМ ПЕРЕКЛЮЧЕНИЯ ПЕРЕДАЧ] 19167875 CONTROL, A/TRNS [ПОДДОН АКП] 25807057 BEZEL, F/FLR CNSL CUP HLDR (INCLS 7) (GRAY) 25807058 BEZEL, F/FLR CNSL CUP HLDR (INCLS 7) (EBONY) 25807059 BEZEL, F/FLR CNSL CUP HLDR (INCLS 7) (CASHMERE) 25789237 RETAINER, F/FLR CNSL (ЧАСТЬ OF 6) 11514603 ГАЙКА, M10X1.5 15MM SOCKET (A/TRNS RANGE SEL LVR) [ШАЙБА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL ROD ADJ) [ГАЙКА М6] 15780844 LINK, A/TRNS RANGE SEL LVR 15780846 LINK, A/TRNS RANGE SEL LVR 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL LVR CBL BRKT) [ГАЙКА М6] 19122183 BEZEL, A/TRNS CONT HSG (PRNDL CHROME COVER) 89027001 COVER, A/TRNS CONT LVR HDL (ЧАСТЬ OF 14) (4.006) 19150329 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (FIG SAPELE WOOD W/EBONY) 19180495 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (EBONY ON MIDDLE & SIDES) teamcadillac.ru 19180497 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (COCOA ON MIDDLE & SIDES) 19180506 HANDLE, A/TRNS CONT LVR (INCLS 3, 13) (FIG SAPELE WOOD W/COCOA) (6E04-035) - 2005-2009 E BRAKE SYSTEM/ANTILOCK ↓ teamcadillac.ru 12413103 HUB, FRT WHL (W/BRG) (СМ. ГРУППУ 06.000 "ПОДВЕСКА-ПЕРЕДНЯЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/WHL SPD SEN) (ACDelco #FW149) [СТУПИЦА КОЛЕСА] 12413105 HUB, FRT WHL (W/BRG) (СМ. ГРУППУ 06.000 "ПОДВЕСКА-ПЕРЕДНЯЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPEED SENSOR) (ACDelco #FW150) [СТУПИЦА КОЛЕСА] 89047639 HUB, RR WHL (W/WHL SPD SEN) (СМ. ГРУППУ 06.000 "ЗАДНЯЯ ПОДВЕСКА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6 STUD HUB) (ACDelco #RW20-19) [СТУПИЦА КОЛЕСА] 10307709 SENSOR, VEH YAW (W/VEH LATL ACCLRM) [ДАТЧИК] 15906579 SENSOR, VEH YAW (W/ VEH LATL & LGTDNL ACCLRM) [ДАТЧИК] 11561645 ГАЙКА, HFH, M6X1X6.45, 13.5 OD, 10 STL, GMW3200 (VEH YAW SEN & LATL ACCLRM) (6E04-036) - 2007-2009 EB ТОРМОЗНАЯ ПЕДАЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (JF4) ↓ 25732428 BARRIER, BRK PED BRKT SND 25697461 RETAINER, BRK PED PUSH ROD BOOT 25732452 BOOT, BRK PED PUSH ROD 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] 15932827 HOSE, P/B BOOS VAC (ACDelco #176-1496) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (ACCEL PED LVR) 10368488 PEDAL, BRK (INCLS 12, 13, 15, 18-22) 25771615 COVER, BRK PED (ЧАСТЬ OF 11) 89047699 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 11) (INCLS 18) [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 89047780 MOTOR KIT, BRK & ACCEL PED ADJR ACTR [ЭЛЕКТРОДВИГАТЕЛЬ ПЕДАЛЬНОГО УЗЛА 19 ВТ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 11, 13) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 11) 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 11) 25697461 RETAINER, BRK PED PUSH ROD BOOT (ЧАСТЬ OF 11) 89047779 CABLE, ACCEL CONT 89047778 CABLE, BRK PED ADJR ACTR [ЖГУТ ПРОВОДОВ] teamcadillac.ru 25741052 BRACKET, BRK PED BRKT 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-018) - 2004-2007 E КОРПУС КП ЧАСТЬ 2 INTERNAL COMPONENTS(MX5) ↓ 88984517 WASHER, TRFER CASE PLNT CARR SUN GR THR (25.8X52.0X2.2) 88984524 GEAR, TRFER CASE PLNT CARR SUN (INPUT) (STAMPED PM/POWDERED METAL) 88984493 RING, TRFER CASE RR ВЫХОДНОЙ SHF RR BRG RET (41MM I.D.) (ACDelco #88984493) 88996564 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT 88996665 BEARING, TRFER CASE MAIN SHF FRT (ВЫХОДНОЙ ВАЛ FRT) 19168733 BUSHING, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 106) [ВТУЛКА РАЗДАТОЧНОЙ КОРОБКИ] 19178237 SHAFT, TRFER CASE RR ВЫХОДНОЙ (INCLS 105, 901) 19133264 SPROCKET, TRFER CASE FRT ВЫХОДНОЙ SHF DRV (INCLS 108) [ШЕСТЕРНЯ РАЗДАТОЧНОЙ КОРОБКИ] 19168732 BUSHING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT (ЧАСТЬ OF 107) (ACDelco #19168732) 89059578 CHAIN, TRFER CASE TWO/FOUR WHL DRV [ЦЕПЬ РАЗДАТОЧНОЙ КОРОБКИ] 88984523 GEAR, TRFER CASE PLNT CARR SUN (ВЫХОДНОЙ) 89059279 КРОНШТЕЙН, FRT/RR DRV DIFF 89059284 SHAFT, TRFER CASE FRT ВЫХОДНОЙ (INCLS 900) 88996664 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF RR 88996671 RING, TRFER CASE FRT ВЫХОДНОЙ SHF BRG RET 88996666 SPROCKET, TRFER CASE TWO/FOUR WHL DRV DRVN [ЗВЕЗДОЧКА] 88996633 BEARING, TRFER CASE RR ВЫХОДНОЙ SHF RR (ACDelco #88996633) [ПОДШИПНИК РАЗДАТОЧНОЙ КОРОБКИ] 15580230 BEARING, TRFER CASE INPUT SHF (BORG-WARNER) (4.510) 19132966 SHAFT, TRFER CASE INPUT 88996681 DEFLECTOR, TRFER CASE FRT ВЫХОДНОЙ SHF SEAL DIRT (ЧАСТЬ OF 112) (6M04-037) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (LY7/3.6-7, EXC V92) ↓ 19129976 HOSE, TRANS FLUID CLR LWR (W/BLOCK) (INCLS 7) 11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16] 89022494 BRACKET, TRANS FLUID CLR 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] teamcadillac.ru 25740416 SEAL, TRANS FLUID CLR PIPE (O RING) (1/2IN) (9.222) (ACDelco #15-31872) [ПРОКЛАДКА КОМПРЕССОРА КОНДИЦИОНЕРА] 19129977 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) 15921020 CLIP, TRANS FLUID AUX CLR PIPE (CYLINDRICAL) (1 PIPE) (6M04-038) - 2007 E ШЛАНГ ВЕНТИЛЯЦИИ ТРАНСМИССИИ (LH2/4.6A, MYB) ↓ 15236024 HOSE, TRANS VENT (INCLS 2-8) 15797504 HOSE, TRANS VENT (INCLS 2-8) 25892279 VENT, TRFER CASE (ЧАСТЬ OF 1) (ACDelco #25892279) [ЗАГЛУШКА ШЛАНГА ВЕНТИЛЯЦИИ КАРТЕРА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 08905794 CLIP (ЧАСТЬ OF 1) 06466355 CONNECTOR, TRANS VENT HOSE (TEE, CRCONT VAC (5/16 HOSE) (ЧАСТЬ OF 1) (3.278) teamcadillac.ru 25526358 CЛАМПА, SPRG BAND, 14.2MM, 9/16 OD HOSE, POR (ЧАСТЬ OF 1) (6M04-041) - 2007-2008 EB26 ТОРМОЗНАЯ ПЕДАЛЬ (PWR ADJ PEDALS JF4) ↓ 25741052 BRACKET, BRK PED BRKT 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 25732428 BARRIER, BRK PED BRKT SND 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 89047778 CABLE, BRK PED ADJR ACTR [ЖГУТ ПРОВОДОВ] 89047780 MOTOR KIT, BRK & ACCEL PED ADJR ACTR [ЭЛЕКТРОДВИГАТЕЛЬ ПЕДАЛЬНОГО УЗЛА 19 ВТ] teamcadillac.ru 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (BRK PED POSN SEN) 89047699 SENSOR KIT, BRK PED POSN [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 25697461 RETAINER, BRK PED PUSH ROD BOOT (ЧАСТЬ OF 21) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 21) 10368488 PEDAL, BRK (INCLS 5, 8-10, 13, 15-20, 22) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-042) - 2007-2008 EB26 ТОРМОЗНАЯ ПЕДАЛЬ (EXC PWR ADJ PEDALS JF4) ↓ 25741052 BRACKET, BRK PED BRKT 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 25732428 BARRIER, BRK PED BRKT SND 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] teamcadillac.ru 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 18) 89047699 SENSOR KIT, BRK PED POSN [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 15594358 BUSHING, BRK PED PIV (ЧАСТЬ OF 18) (0.831) 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 18) (0.80 IN) (PUSH IN) 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 18) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 18) 25771615 COVER, BRK PED (ЧАСТЬ OF 18) 25765419 PEDAL, BRK (W/BRKT) (INCLS 5-8, 10, 12-17, 19) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-043) - 2007-2008 EE26 ТОРМОЗНАЯ ПЕДАЛЬ ↓ 15866634 BRACKET, BRK PED BRKT 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED) [ГАЙКА] 89047704 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 12) [ДАТЧИК] 19153363 CABLE, BRK PED ADJR ACTR (ЧАСТЬ OF 12) 25771615 COVER, BRK PED (ЧАСТЬ OF 12) 15791722 PEDAL, BRK (INCLS 4-6, 8-11, 13-19) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 12) 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 12) 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 12) (0.80 IN) (PUSH IN) teamcadillac.ru 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 12) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] (6M04-044) - 2004-2009 E26 ТОРМОЗНОЙ УСИЛИТЕЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА ↓ 88967237 BOOSTER, P/B (СМ. ГРУППУ 04.000 "ТОРМОЗНОЙ УСИЛИТЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/O VLV) (ACDelco #178-0695) teamcadillac.ru 25732452 BOOT, BRK PED PUSH ROD 25697461 RETAINER, BRK PED PUSH ROD BOOT 25697462 RETAINER, BRK PED PUSH ROD BOOT 10367561 CYLINDER, BRK MAS (СМ. ГРУППУ 4.000 "ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #174-1012) [ЦИЛИНДР] 10367562 CYLINDER, BRK MAS (СМ. ГРУППУ 4.000 "ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 11609949 ГАЙКА, BRK M/CYL (M10X1.5, 11.2 THK) (8.917) [ГАЙКА] 15795475 HOSE, P/B BOOS VAC 15929447 HOSE, P/B BOOS VAC 25873484 HOSE, P/B BOOS VAC (ACDelco #176-1497) (GM04-064) - 2004-2009 E ТОРМОЗНОЙ СУППОРТ-ПЕРЕДНИЙ ↓ 18047980 CALIPER, FRT BRK (INCLS 2-4, 8-10) (IF DISCONTINUED USE DURASTOP EQUIVALENT) (4.667) (ACDelco #172-1643) [ТОРМОЗНОЙ СУППОРТ] 18047981 CALIPER, FRT BRK (INCLS 2-4, 8-10) (IF DISCONTINUED USE DURASTOP EQUIVALENT) (4.667) (ACDelco #172-1644) [ТОРМОЗНОЙ СУППОРТ] 18043178 COVER, FRT BRK BLEDR SCREW (ЧАСТЬ OF 1) 18047986 VALVE KIT, FRT BRK CLPR BLEDR (ЧАСТЬ OF 1) (ACDelco #18047986) 18046750 БОЛТ, FRT BRK CLPR GDE PIN (ЧАСТЬ OF 1, 11) (*KIT2) [БОЛТ] 18047985 PISTON KIT, FRT BRK CLPR (ЧАСТЬ OF 1) 18047988 PAD KIT, FRT DISC BRK (INCLS 4, 14) (ACDelco #171-665) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4 ШТ)] 19122384 PAD KIT, FRT DISC BRK (INCLS 4, 14) (ACDelco #171-688) 18045221 SEAL, FRT BRK CLPR GDE PIN 18047987 BRACKET, FRT BRK CLPR (W/GUIDE PIN БОЛТS) [КРОНШТЕЙН] 18046698 ПРУЖИНА, FRT DISC BRK PAD RET (ЧАСТЬ OF 11) (ACDelco #179-2235) 18047989 PIN KIT, FRT BRK CLPR GDE (INCLS 5-7) (INCLS 2 (2.5") БОЛТS) teamcadillac.ru 18047984 CALIPER KIT, FRT BRK (INCLS 4, 8, 9) (4.667) (ACDelco #173-0538) (GM04-312) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (5L40-E M82) ↓ teamcadillac.ru 96042897 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 6GRG) (GM04-376) - 2004-2009 E ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР ↓ 18012741 SWITCH, BRK FLUID LVL IND (ЧАСТЬ OF 15) (ACDelco #18012741) 22688449 CAP, BRK M/CYL RSVR (ЧАСТЬ OF 15) (INCLS 3) [КРЫШКА БАЧКА ТОРМОЗНОЙ ЖИДКОСТИ] 18046711 RESERVOIR, BRK M/CYL (ЧАСТЬ OF 15) (INCLS 4, 6-7) (ACDelco #18046711) teamcadillac.ru 18060168 PISTON, BRK M/CYL SECD (ЧАСТЬ OF 15) 10367561 CYLINDER, BRK MAS (INCLS 1-14) (ACDelco #174-1012) [ЦИЛИНДР] 10367562 CYLINDER, BRK MAS (INCLS 1-14) 18022002 CYLINDER KIT, BRK MAS (INCLS 8-12) (ACDelco #175-424) (GM04-485) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (5L40-E MX5) ↓ 96042890 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 6GGG) [АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ В СБОРЕ] (GM04-555) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 24227130 БОЛТ, C/VLV UPR BODY (M5X0.8X36) 24225398 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M6 X 1.0 X 20) 24238417 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (INCLS 316) (4.329) [ДАТЧИК ЧИСЛА ОБОРОТОВ ВАЛА AКПП] 24225797 BODY, C/VLV UPR [ГИДРОРАСПРЕДЕЛИТЕЛЬНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24237789 PLATE, C/VLV BODY SPCR (W/GSKT) (USED ON UNITS BUILT BEFORE 07/17/06) (FOR 2ND DES SEE 24240068) teamcadillac.ru 24246917 PLATE, C/VLV BODY SPCR (W/GSKT) (MUST USE T/W 24238925/PLATE KIT - CONT SOL VLV FLTR) (ACDelco #24246917) (USED ON UNITS BUILT ON OR AFTER 7/17/06) (FOR 1ST DES SEE 24237789) (USED W/2007 TRANS BROADCAST CODES) (FOR 2008 TRANS BROADCAST CODES SEE 2 96020431 VALVE, C/VLV BODY BALL CHK [КЛАПАН] 24250384 BODY, C/VLV LWR (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ/;НИЖНИЙ КЛАПАН РЕГУЛЯТОР BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (MANUAL VALVE NOT INCLUDED) (MUST USE T/W 24236934/PLATE KIT - CONT SOL VLV FLTR) 24246427 SWITCH, A/TRNS MAN SHFT SHF POSN (INCLS 315) (INTERNAL MODE SWITCH) [ВКЛЮЧАТЕЛЬ] 24224821 БОЛТ, C/VLV LWR BODY (M5X0.8X45) 24224822 БОЛТ, C/VLV LWR BODY (M5X0.8X55) 24238925 PLATE KIT, CONT SOL VLV FLTR 24240845 БОЛТ, CONT SOL VLV HEAT SINK (W/ BODY & TCM) (M5X0.8X53.0) 24238968 VALVE, CONT SOL (W/ BODY & TCM) (ORDER T/W 24238913 SEAL KIT) [ГИДРОРАСПРЕДЕЛИТЕЛЬ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24236233 CLIP, A/TRNS MAN SHFT SHF POSN SW WRG HARN (ЧАСТЬ OF 308) 24236504 CLIP, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN WRG HARN (ЧАСТЬ OF 303) (GM04-556) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ВЕРХНИЙ КЛАПАН РЕГУЛЯТОР BODY БЛОК ↓ 24224766 PIN, C/VLV BODY LOC (ЧАСТЬ OF 321) (DIA.=10MM L=12.7) [ВТУЛКА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24225797 BODY, C/VLV UPR (INCLS 313, 322-338) [ГИДРОРАСПРЕДЕЛИТЕЛЬНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24230200 PIN, C/VLV BODY LOC (ЧАСТЬ OF 321) (DIA.=10MM L=29.9) [ВТУЛКА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] teamcadillac.ru 24224755 RETAINER, 1-2-3-4 CLU BOOST VLV SPR (ЧАСТЬ OF 321) [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24242814 PLUG, 1-2-3-4 CLU REG VLV BORE (ЧАСТЬ OF 321) (9.5 THK, 11.5 DIA) (GM04-557) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) НИЖНИЙ КЛАПАН РЕГУЛЯТОР BODY БЛОК ↓ teamcadillac.ru 24224755 RETAINER, CLU PSTN DAM FEED REG VLV SPR [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24242814 PLUG, CLU SEL SOL VLV BORE #2 (9.5 THK, 11.5 DIA) 24250384 BODY, C/VLV LWR (INCLS 338, 352, 353, 355-357) (MANUAL VALVE NOT INCLUDED) (MUST USE T/W 24236934/PLATE KIT - CONT SOL VLV FLTR) 24224770 VALVE, MAN (ACDelco #24224770) (GM04-558) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) 1-2-3-4 & 3-5 REVERSE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 24225654 PLATE, 3-5 REV CLU BKG 24225569 PLATE, 3-5/REV CLU (PKG OF 4) (FIBER) (ACDelco #24225569) 24237663 PLATE, 3-5 REV CLU (PKG OF 4) (STEEL) 24225564 PLATE, 3-5 REV CLU (WAVED) 24233533 PLATE, 1-2-3-4 CLU BKG 24243588 PLATE, 1-2-3-4 CLU (ACDelco #24243588) 24232652 PLATE, 1-2-3-4 CLU (PKG OF 5) (STEEL) 24236434 PLATE, 1-2-3-4 CLU (WAVED) 24225522 DAM, 1-2-3-4 CLU PSTN 24225559 ПРУЖИНА, 1-2-3-4 CLU teamcadillac.ru 24225621 PISTON, 1-2-3-4 CLU 24236049 ШЛАНГИ, 1-2-3-4 CLU PSTN 24236051 ПРУЖИНА, 3-5-REV CLU 24236050 PISTON, 3-5/REV CLU (INCLS 422) 24237184 ШЛАНГИ, 1-2-3-4 & 3-5 REV CLU (INCLS 400, 426, 429) (ORDER T/W 24226393) (TRANS BUILT ON 01-20-07 & AFTER) (FOR 1ST DES SEE 24241232) 24241232 СЦЕПЛЕНИЕ KIT, 1-2-3-4 & 3-5 REV (INCLS 400, 426, 429) (ACDelco #24241232) (TRANS BUILT ON 01-19-07 & PRIOR) (FOR 2ND DES SEE 24237184) 24226393 BEARING, 1-2-3-4 & 3-5-REV CLU 24243891 SEAL KIT, A/TRNS SERV (INCLS 411, 415, 416, 419, 423-425) (FULL TRANS) (ACDelco #24243891) 24238920 RING KIT, RET (INCLS 411, 415) 24238922 SEAL KIT, A/TRNS SERV (INCLS 416, 418, 419, 422-425) (СЦЕПЛЕНИЕES) (ACDelco #24238922) (GM04-559) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) 4-5-6 ДЕТАЛИ СЦЕПЛЕНИЯ & ВАЛ ТУРБИНЫ ↓ 24225508 RING, 4-5-6 CLU BKG PLT RET (GREEN) (2.52-2.62) (ACDelco #24225508) 24225509 RING, 4-5-6 CLU BKG PLT RET (YELLOW) (3.08-3.18) (ACDelco #24225509) 24231591 RING, 4-5-6 CLU BKG PLT RET (GREY) (2.80-2.90) (ACDelco #24231591) 24231592 RING, 4-5-6 CLU BKG PLT RET (ORANGE) (3.36-3.46) (ACDelco #24231592) 24231593 RING, 4-5-6 CLU BKG PLT RET (BLUE) (3.64-3.74) (ACDelco #24231593) 24232879 RING, 4-5-6 CLU BKG PLT RET (WHITE) (3.74-3.84) (ACDelco #24232879) 24232880 RING, 4-5-6 CLU BKG PLT RET (YELLOW/PURPLE) (4.20-4.30) (ACDelco #24232880) 24225652 PLATE, 4-5-6 CLU BKG teamcadillac.ru 24225570 PLATE, 4-5-6 CLU (INT SPLINE) (PKG OF 5) (FIBER) 24225575 PLATE, 4-5-6 CLU (EXT SPLINE) (PKG OF 5) (STEEL)FIBER) (ACDelco #24225575) 24225565 PLATE, 4-5-6 CLU (WAVED) 24225526 DAM, 4-5-6 CLU PSTN 24225560 ПРУЖИНА, 4-5-6 CLU 24225523 PISTON, 4-5-6 CLU 24237963 ШЛАНГИ, 4-5-6 CLU (W/ INPUT SHF) (INCLS 440) 08662686 SEAL, TURB SHF (O RING) (*KIT2) (ACDelco #8662686) 24238920 RING KIT, RET (INCLS 436) 24243891 SEAL KIT, A/TRNS SERV (INCLS 436, 442, 443) (FULL TRANS) (ACDelco #24243891) (GM04-560) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) 2-6 ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 24247405 RING, 2-6 CLU BKG PLT RET (CODE 7BNA) (1.69MM +/- 0.05) (ACDelco #24247405) (WHEN ORDERING ТРАНСМИССИЯ REFER TO TECHNICAL SERVICE BULLETIN 07-07-30-011) 24247406 RING, 2-6 CLU BKG PLT RET (CODE 7BNA) (2.81MM +/- 0.05) (ACDelco #24247406) (WHEN ORDERING ТРАНСМИССИЯ REFER TO TECHNICAL SERVICE BULLETIN 07-07-30-011) 24248107 RING, 2-6 CLU BKG PLT RET (CODE 7BNA) (2.25MM +/- 0.05) (ACDelco #24248107) (WHEN ORDERING ТРАНСМИССИЯ REFER TO TECHNICAL SERVICE BULLETIN 07-07-30-011) 24248108 RING, 2-6 CLU BKG PLT RET (CODE 7BNA) (2.53MM +/- 0.05) (ACDelco #24248108) (WHEN ORDERING ТРАНСМИССИЯ REFER TO TECHNICAL SERVICE BULLETIN 07-07-30-011) 24248109 RING, 2-6 CLU BKG PLT RET (CODE 7BNA) (1.97MM +/- 0.05) (ACDelco #24248109) (WHEN ORDERING ТРАНСМИССИЯ REFER TO TECHNICAL SERVICE BULLETIN 07-07-30-011) 24225653 PLATE, 2-6 CLU BKG 24237973 PLATE, 2-6 CLU (WAVED) 24225561 ПРУЖИНА, 2-6 CLU 24225524 PISTON, 2-6 CLU 24225447 SUPPORT, CTR (INCLS 458, 460) teamcadillac.ru 24238911 PLATE KIT, CLU (INCLS 452) (ORDER T/W 24225575 & 24235455) (ACDelco #24238911) (GM04-561) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) LOW & REVERSE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 24248368 PLATE KIT, LOW & REV CLU BKG (4.180) (ACDelco #24248368) (FOR SERVICE USE (1) OF THE FOLLOWING RET. RINGS 24225515, 24225519, OR BACKING PLATE 24225656) 24236664 PLATE, LOW & REV CLU (PKG OF 6) (FIBER) 24232654 PLATE, LOW & REV CLU (PKG OF 6) (STEEL) (ACDelco #24232654) 24237971 PLATE, LOW & REV CLU (WAVED) (ACDelco #24237971) 24225517 RING, LOW & REV CLU SPR RET 24238921 SPRAG, LOW CLU (INCLS 468) 24225562 ПРУЖИНА, LOW & REV CLU 24225525 PISTON, LOW & REV CLU (ACDelco #24225525) 24238922 SEAL KIT, A/TRNS SERV (INCLS 468) (СЦЕПЛЕНИЕES) (ACDelco #24238922) (GM04-562) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) СЦЕПЛЕНИЕ HUB БЛОК ↓ 24233660 HUB, 4-5-6 CLU (W/ ВЫХОДНОЙ CARR SHF & DPNR) (INCLS 476-478) 24230475 DAMPENER, 4-5-6 CLU (ЧАСТЬ OF 475) 24233661 PLATE, 4-5-6 CLU DPNR APPLY (ЧАСТЬ OF 475) teamcadillac.ru 24230370 RING, 4-5-6 CLU DPNR RET (ЧАСТЬ OF 475) (GM04-563) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ВЫХОДНОЙ КРОНШТЕЙН БЛОК ↓ 24225777 BEARING, CTR SUPT RLR (ЧАСТЬ OF 490) 24225483 BEARING, ВЫХОДНОЙ CARR OTR SUN GR FRT THR (ЧАСТЬ OF 490) teamcadillac.ru 24225290 GEAR, ВЫХОДНОЙ CARR FRT SUN (ЧАСТЬ OF 490) 24225484 BEARING, ВЫХОДНОЙ CARR OTR SUN GR RR THR (ЧАСТЬ OF 490) 24235807 GEAR, ВЫХОДНОЙ CARR RR SUN (ЧАСТЬ OF 490) 24225603 КРОНШТЕЙН, ВЫХОДНОЙ (INCLS 485-489, 491) (GM04-565) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ЗАМОК ПАРКОВКИ ↓ 24242086 ACTUATOR, PARK PAWL (ACDelco #24242086) teamcadillac.ru 24227077 PIN, MAN SHFT DTNT LVR HUB (ЧАСТЬ OF 505) 24234562 LEVER, MAN SHFT DTNT (INCLS 504) (ACDelco #24234562) 24225792 PIN, MAN SHFT SHF (ACDelco #24225792) 24235861 SEAL, MAN SHFT SHF (*KIT1) (ACDelco #24235861) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24225445 SHAFT, MAN SHFT (ACDelco #24225445) 24228969 SHAFT, MAN SHFT (ACDelco #24228969) 24224348 GUIDE, PARK PAWL ACTR (INCLS 510) 24224350 SEAL, PARK PAWL ACTR GDE (O RING) (ЧАСТЬ OF 509) (*KIT1) (ACDelco #24224350) 24226102 PIN, PARK PAWL ACTR GDE 24243891 SEAL KIT, A/TRNS SERV (INCLS 507, 510) (FULL TRANS) (ACDelco #24243891) (GM04-568) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) ВЫХОДНОЙ ВАЛ БЛОК ↓ 24241092 RING, ВЫХОДНОЙ CARR INTL GR RET (ACDelco #24241092) teamcadillac.ru 24225477 GEAR, ВЫХОДНОЙ CARR INTL (FRT) 24228887 SPACER, ВЫХОДНОЙ CARR INTL GR (3.342) 24230333 GEAR, ВЫХОДНОЙ CARR INTL (RR) 24239398 SHAFT, ВЫХОДНОЙ (INCLS 495, 497, 498) (WHEN SERVICING SHAFT MUST ALSO REPLACE BEARING P/N 24237771) 24239401 SHAFT, ВЫХОДНОЙ (INCLS 495, 497, 498) (WHEN SERVICING SHAFT MUST ALSO REPLACE BEARING P/N 24237771) (GM04-569) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) БЛОК СЦЕПЛЕНИЯ & ДЕТАЛИ КОМПЛЕКТА ↓ teamcadillac.ru 24225602 КРОНШТЕЙН, INPUT (ACDelco #24225602) 24225289 GEAR, INPUT SUN (ACDelco #24225289) 24224405 BEARING, INPUT SUN GR THR (ACDelco #24224405) 24232409 WASHER, INPUT SUN GR THR 24238905 BEARING, TURB SHFT THR [ПОДШИПНИК] 24233732 BEARING, 4-5-6 CLU HUB THR (ACDelco #24233732) 24225597 HUB, 1-2-3-4 CLU (W/ВЫХОДНОЙ CARR INR SUN GR SHF) 24224163 BEARING, 1-2-3-4 CLU HUB THR (ACDelco #24224163) 24225596 HUB, 2-6 & 3-5/REV CLU (W/ ВЫХОДНОЙ CARR OTR SUN GR SHF) (INCLS 60, 62) 24224164 BEARING, 2-6 & 3-5/REV CLU HUB THR (ACDelco #24224164) 24225512 RING, CTR SUPT RET 24225447 SUPPORT, CTR 24225486 BEARING, ВЫХОДНОЙ CARR THR 24224668 BEARING, ВЫХОДНОЙ SHF THR (ACDelco #24224668) (GM04-573) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042861 GASKET, A/TRNS CASE EXTN (*KIT1) 24237771 BEARING, ВЫХОДНОЙ SHF (ЧАСТЬ OF 27) 96042860 EXTENSION, A/TRNS CASE (INCLS 26, 28, 29) 24237771 BEARING, ВЫХОДНОЙ SHF (ЧАСТЬ OF 27) 96041851 SEAL, PROP SHF TRANS FLG FLUID (ЧАСТЬ OF 27) (*KIT1) [ПРОКЛАДКА ТРАНСФОРМАТОРНОГО ВАЛА] 96042984 FLANGE, ВЫХОДНОЙ SHF teamcadillac.ru 96041805 NUT KIT, ВЫХОДНОЙ SHFT (INCLS 30, 32, 33) (M6X1.0X16) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) (*KIT1) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) (*KIT1) 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96042963 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPACER PLATE & GASKET) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) 96042712 DETENT, MAN SHFT 96017928 CLIP, WRG HARN 96042847 HARNESS, A/TRNS WRG 96041849 SEAL, A/TRNS WRG CONN (O RING) (*KIT1) 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN (*KIT1) [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (*KIT1) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (*KIT1) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) 96042945 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/GSKT, SEAL, RET) (INCLS 25, 29, 36, 38, 46, 56, 60, 63, 64) (GM04-574) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042887 GASKET, A/TRNS CASE EXTN [ПРОКЛАДКА КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042888 EXTENSION, A/TRNS CASE (INCLS 28, 69) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96042963 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPACER PLATE & GASKET) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) 96042712 DETENT, MAN SHFT 96017928 CLIP, WRG HARN 96042847 HARNESS, A/TRNS WRG teamcadillac.ru 96041849 SEAL, A/TRNS WRG CONN (O RING) 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) 96042543 WASHER, INPUT & REACTION CARR THR 96042587 SEAL, PROP SHF TRANS FLG FLUID [ПРОКЛАДКА КРЫШКИ РАЗДАТОЧНОЙ КОРОБКИ] 08677884 BEARING, ВЫХОДНОЙ SHF THR (ЧАСТЬ OF 27) (4.180) (ACDelco #8677884) (GM04-575) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ 96042554 CONVERTER, TORQ (REMAN) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042812 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) 96042806 СЦЕПЛЕНИЕ, DIR & REV (СМ. ГРУППУ 04.000 "DIRECT AND REVERSE СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042807 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (СМ. ГРУППУ 04.000 "FORWARD AND COAST СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042698 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) (СМ. ГРУППУ 04.000 "INPUT SUN GEAR SHAFT AND FORWARD SPRAG СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (СМ. ГРУППУ 04.000 "DIRECT СЦЕПЛЕНИЕ DRUM AND SHAFT" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) teamcadillac.ru 96042701 WASHER, INPUT & REACTION CARR INR SHF THR 96042808 ШЛАНГИ, O/D CLU (СМ. ГРУППУ 04.000 "OVERDRIVE AND INTERMEDIATE СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (СМ. ГРУППУ 04.000 "LOW СЦЕПЛЕНИЕ SPRAG" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042705 BEARING, CTR SUPT RLR (4.180) 96042809 SUPPORT, CTR (СМ. ГРУППУ 04.000 "CENTER SUPPORT" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042707 КРОНШТЕЙН, INPUT & REACTION (СМ. ГРУППУ 04.000 "PLANETARY КРОНШТЕЙН" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (4.176) 96042708 BEARING, INPUT & REACTION CARR THR 96042709 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (СМ. ГРУППУ 04.000 "ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96041847 WASHER, INPUT & REACTION CARR THR (4.265) (GM04-576) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ 96042554 CONVERTER, TORQ (REMAN) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042812 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) 96042814 СЦЕПЛЕНИЕ, DIR & REV 96042815 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) 96042698 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) (INCLS 9) 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) 96042701 WASHER, INPUT & REACTION CARR INR SHF THR teamcadillac.ru 96042808 ШЛАНГИ, O/D CLU 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) 08677884 BEARING, LOW CLU RLR THR (*KIT1) (ACDelco #8677884) 96042816 SUPPORT, CTR 96042817 КРОНШТЕЙН, INPUT & REACTION 96042818 BEARING, INPUT & REACTION CARR THR 96042813 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) 96042543 WASHER, INPUT & REACTION CARR THR 96042818 BEARING, INPUT & REACTION CARR THR (GM04-577) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ teamcadillac.ru 96015215 БОЛТ, T/CV FLUID SEAL (*KIT1) 96041855 SEAL, T/CV FLUID [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042812 ШЛАНГИ KIT, T/CV (INCLS 200-215, 217-220, 223, 226-228, 231-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-577) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ teamcadillac.ru 24212478 SLIDE, A/TRNS ГИДРОНАСОС (17.9545MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212478) 24212479 SLIDE, A/TRNS ГИДРОНАСОС (17.9675MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212479) 24212480 SLIDE, A/TRNS ГИДРОНАСОС (17.9805MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212480) 24212481 SLIDE, A/TRNS ГИДРОНАСОС (17.9935MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212481) 24212482 SLIDE, A/TRNS ГИДРОНАСОС (18.0065MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212482) 24201144 RING, A/TRNS ГИДРОНАСОС VANE (RING, PUMP VANE) (ACDelco #24201144) 08631280 VANE, A/TRNS ГИДРОНАСОС (ACDelco #8631280) 24205410 GUIDE, A/TRNS ГИДРОНАСОС ROT (13 VANE) (ACDelco #24205410) 24201144 RING, A/TRNS ГИДРОНАСОС VANE (RING, PUMP VANE) (ACDelco #24201144) 96015215 БОЛТ, T/CV FLUID SEAL (*KIT1) 96041855 SEAL, T/CV FLUID [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042812 ШЛАНГИ KIT, T/CV (INCLS 200-215, 217-220, 223, 226-228, 231-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-578) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 300-309, 312-334) (INCLS SPACER PLATE & GASKET) 96042986 GASKET KIT, A/TRNS (INCLS 303, 305, 306, 308, 309, 312, 314, 316, 330, 332) (4.265) (GM04-578) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 300-334) (INCLS SPACER PLATE & GASKET) 96042986 GASKET KIT, A/TRNS (INCLS 303, 305, 306, 308, 309, 312, 314, 316, 330, 332) (4.265) (GM04-579) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96042599 VALVE, TCC PWM SOL 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 340-351, 353-356) (INCLS SPACER PLATE & GASKET) (GM04-579) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 10471813 SEAL, TCC SOL VLV (O RING) (SMALL DIA) (OTR) (ACDelco #10471813) 10475842 SEAL, TCC SOL VLV (O RING) (14 MM I.D.) (INR) (ACDelco #10475842) 96042599 VALVE, TCC PWM SOL 10471813 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (SMALL DIA) (OTR) (ACDelco #10471813) 10475842 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (14 MM I.D.) (INR) (ACDelco #10475842) 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 340-348, 351, 353-354) (INCLS SPACER PLATE & GASKET) (GM04-580) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 343, 349, 350, 365-367, 370-375, 377-388) (INCLS SPACER PLATE & GASKET) (GM04-580) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 10471813 SEAL, TCC SOL VLV (O RING) (SMALL DIA) (OTR) (ACDelco #10471813) 10475842 SEAL, TCC SOL VLV (O RING) (14 MM I.D.) (INR) (ACDelco #10475842) 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 343, 351, 365-367, 370-375, 377-388) (INCLS SPACER PLATE & GASKET) 96042889 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/PLT, GSKT, SEAL) (INCLS 343, 351, 365-367, 370-375, 377-388) (GM04-581) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru 96042806 СЦЕПЛЕНИЕ, DIR & REV (INCLS 400-420) (GM04-581) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru 96042814 СЦЕПЛЕНИЕ, DIR & REV (INCLS 400-420) (GM04-582) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96041856 SEAL, INPUT SHF (O RING) (*KIT1) [ПРОКЛАДКА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042807 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-451) (GM04-582) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042815 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-451) (GM04-583) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042707 КРОНШТЕЙН, INPUT & REACTION (INCLS 455-462) (4.176) (GM04-583) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042817 КРОНШТЕЙН, INPUT & REACTION (INCLS 455-462) (GM04-584) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-584) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-585) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 470-477) (GM04-585) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 470-477) (GM04-586) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 480-497) (GM04-586) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 480-497) (GM04-587) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК ↓ teamcadillac.ru 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (INCLS 500-505) (GM04-587) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК ↓ teamcadillac.ru 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (INCLS 500-505) (GM04-588) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) КРЕПЛЕНИЕ ↓ teamcadillac.ru 96042809 SUPPORT, CTR (INCLS 510-535) (GM04-588) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) КРЕПЛЕНИЕ ↓ teamcadillac.ru 96042816 SUPPORT, CTR (INCLS 510-535) (GM04-589) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) PLANETARY КРОНШТЕЙН БЛОК ↓ teamcadillac.ru 96042707 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-554) (4.176) (GM04-589) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) PLANETARY КРОНШТЕЙН БЛОК ↓ teamcadillac.ru 96042817 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-554) (GM04-590) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК ↓ teamcadillac.ru 96042709 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560-564) (GM04-591) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК ↓ teamcadillac.ru 96042813 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560-561, 563-564) (GM04-593) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) PARKING PAWL БЛОК ↓ 96042710 LEVER, MAN SHFT DTNT 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 96042540 SWITCH, A/TRNS MAN SHFT SHF POSN [ВЫКЛЮЧАТЕЛЬ ПРИВОДА] 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 08644709 SEAL, MAN SHFT SHF (W/O PTFE LUBRICANT APPLIED TO SEAL) (ACDelco #8644709) 96041857 SHAFT, MAN SHFT 96042711 PAWL KIT, PARK 96041852 PLUG, MAN SHFT SHF HOLE (4.279) 96041842 SPACER, MAN SHFT DTNT LVR (GM04-594) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) PARKING PAWL БЛОК ↓ 96042710 LEVER, MAN SHFT DTNT 96042819 LEVER, MAN SHFT DTNT 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 96042540 SWITCH, A/TRNS MAN SHFT SHF POSN [ВЫКЛЮЧАТЕЛЬ ПРИВОДА] 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 08644709 SEAL, MAN SHFT SHF (W/O PTFE LUBRICANT APPLIED TO SEAL) (ACDelco #8644709) 96042544 SHAFT KIT, MAN SHFT 96042711 PAWL KIT, PARK 96042820 PAWL KIT, PARK teamcadillac.ru (GM04-598) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (6L50 MYB, ЗАДНИЙ КОЛЕСО DRIVE MX0) ↓ 17804012 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 7BNA) (WHEN ORDERING ТРАНСМИССИЯ REFER TO TECHNICAL SERVICE BULLETIN 07-07-30-011) (GM04-599) - 2007-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (6L50 MYB, ALL КОЛЕСО DRIVE MX7) ↓ teamcadillac.ru 17804013 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 7BPA) (WHEN ORDERING ТРАНСМИССИЯ REFER TO TECHNICAL SERVICE BULLETIN 07-07-30-011) [ТРАНСМИССИОННОЕ МАСЛО7BPA (GOODWRENCH REMAN)] (GM04-667) - 2007-2008 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYB) (6L50) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 24240018 CONVERTER, TORQ [ГИДРОТРАНСФОРМАТОР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 11515762 БОЛТ-HFLGE, M8X1.25X50, 18 OD, 22 THD, 10.9, PZO (T/CV HSG) 24205899 PLUG, T/CV HSG ACC HOLE (28MM W/3 TANGS) (SMALL CVR) (ACDelco #24205899) 24225543 SEAL, A/TRNS ГИДРОНАСОС (ACDelco #24225543) [ПРОКЛАДКА КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24242045 CASE, A/TRNS (INCLS 6, 12, 41) (ACDelco #24242045) 24242046 CASE, A/TRNS (INCLS 6, 12, 41) (ACDelco #24242046) 24226020 PLUG, TRANS FLUID FIL TUBE 24239878 SLEEVE, A/TRNS ELEC CONN PASG [МУФТА] teamcadillac.ru 24225788 БОЛТ, A/TRNS CASE EXTN (M10X1.5X34) 24225557 SEAL, CTR SUPT FLUID PASG (*KIT2) 24224820 БОЛТ, VLV BODY (USED ON TRANS BUILT ON 12-31-06 & PRIOR) (FOR 2ND DES SEE 24237181) 24237181 БОЛТ, VLV BODY (M5X0.8X73.0) (USED ON TRANS BUILT ON 01-01-07 & AFTER) (FOR 1ST DES SEE 24224820) 24231074 БОЛТ, MAN SHFT DTNT (M10X1X14.5) 24222646 DETENT, MAN SHFT (W/8MM DIA. ROLLER) (ACDelco #24222646) 24236933 FILTER KIT, A/TRNS FLUID (INCLS 25) (ACDelco #24236933) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24225800 GASKET, A/TRNS FLUID PAN (ACDelco #24225800) [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 29535617 MAGNET, A/TRNS FLUID PAN (4.105) (ACDelco #29535617) [МАГНИТ] 24237064 PAN, A/TRNS FLUID (INCLS 31) (TRANS BUILT ON 3-2-07 & PRIOR) (FOR 2ND DES SEE 24242410) 24242410 PAN, A/TRNS FLUID (INCLS 31) (ACDelco #24242410) (MUST SERVICE T/W 24236933 FILTER FOR TRANS BUILT ON 3-2-07 & PRIOR) 11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (A/TRNS FLUID PAN) [БОЛТ М6] 24234212 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 29) (ACDelco #24234212) [ПРОБКА] 24205900 PLUG, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] 24225783 SEAL, A/TRNS CASE EXTN (ACDelco #24225783) [УПЛОТНИТЕЛЬ КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24237879 EXTENSION, A/TRNS CASE (INCLS 36, 37) (ACDelco #24237879) 24228876 SEAL, ВЫХОДНОЙ SHF (ЧАСТЬ OF 34) (5.556) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 24214158 BEARING, ВЫХОДНОЙ SHF (DRAWN CUP) (ЧАСТЬ OF 34) (4.131) (ACDelco #24214158) 24230287 FLANGE, PROP SHF TRANS 24231524 ГАЙКА, FRT PROP SHF FLG (M22X1.5) (FLANGE HEX) 24229687 EXTENSION, A/TRNS CASE (MCHG) 24237771 BEARING, ВЫХОДНОЙ SHF (ЧАСТЬ OF 7) 24242995 BEARING, ВЫХОДНОЙ SHF (ЧАСТЬ OF 7) [ПОДШИПНИК КПП] 24236928 SEAL KIT, A/TRNS ELEC CONN PASG SLEV (INCLS 9, 10) 24238913 SEAL KIT, A/TRNS SERV (INCLS 9, 10, 18-20) (CONTROL VLV SOL ASM) (ACDelco #24238913) [КОМПЛЕКТ ПРОКЛАДОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (5ШТ)] 04 - ТРАНСМИССИЯ - ТОРМОЗ ↓ (6D00-036) - 2007-2008 E ТРАНСМИССИЯ TO КРЕПЛЕНИЕ ДВИГАТЕЛЯ (LH2/4.6A) ↓ 12582606 FLYКОЛЕСО, ENG 25773136 BRACKET, ENG WRG HARN (CHANNEL) 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] 24205900 PLUG, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] 24205899 PLUG, T/CV HSG ACC HOLE (28MM W/3 TANGS) (SMALL CVR) (ACDelco #24205899) 11589116 БОЛТ, FLYWHL (8.900) 12568122 COVER, FLYWHL HSG 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (TRANS CONV CVR) (ACDelco #11517518) [БОЛТ] teamcadillac.ru 12568123 COVER, TRANS CONV (6D04-023) - 2004-2009 E СТОЯНОЧНЫЙ ТОРМОЗ ASM ↓ 88951984 PLATE, RR PARK BRK ANC BKG (4.591) 88951985 PLATE, RR PARK BRK ANC BKG (4.591) 88951982 ACTUATOR KIT, RR PARK BRK (INCLS 2) (ACDelco #179-2053) [АКТУАТОР] teamcadillac.ru 88951983 ACTUATOR KIT, RR PARK BRK (INCLS 2) (ACDelco #179-2054) [АКТУАТОР] 89047676 SHOE KIT, RR PARK BRK (INCLS 5) (ACDelco #171-0915) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (2 ШТ)] (6D04-031) - 2004-2009 E ТОРМОЗНОЙ СУППОРТ-ЗАДНИЙ ↓ 89047677 CALIPER KIT, RR BRK (INCLS 2, 3, 7-9) (ACDelco #172-2343) 89047678 CALIPER KIT, RR BRK (INCLS 2, 3, 7-9) (ACDelco #172-2344) [ТОРМОЗНОЙ СУППОРТ] 88951992 CAP, RR BRK BLEDR VLV (ЧАСТЬ OF 1) 88951991 VALVE, RR BRK CLPR BLEDR (ЧАСТЬ OF 1) teamcadillac.ru 89047757 PAD KIT, RR DISC BRK (INCLS 4, 12) (ACDelco #171-859) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4 ШТ)] 89047758 PAD KIT, RR DISC BRK (INCLS 4, 12) (4.667) (ACDelco #171-0906) [ТОРМОЗНЫЕ КОЛОДКИ] 88957163 BRACKET, RR BRK CLPR [СКОБА ТОРМОЗНОГО СУППОРТА] 89047759 PIN KIT, RR BRK CLPR GDE (INCLS 4-6) (INCLS 2 PINS, 2 SEALS & 2 (2.75") БОЛТS) (ACDelco #179-2044) [НАПРАВЛЯЮЩАЯ ТОРМОЗНОГО СУППОРТА (2 ШТ)] 88957162 REPAIR KIT, RR BRK CLPR HYD (INCLS 4, 6, 8, 9) (6D04-033) - 2004-2009 E ТОРМОЗНОЙ УСИЛИТЕЛЬ ↓ 88967237 BOOSTER, P/B (W/O VLV) (ACDelco #178-0695) 05461808 GROMMET, P/B BOOS VAC CHK VLV (*KIT1) teamcadillac.ru 03817880 RETAINER, BRK PED PUSH ROD (0.80 IN) (PUSH IN) 18022219 VALVE KIT, P/B BOOS VAC CHK (INCLS 2, 3) (BLACK) (INCLS VLV & GROM) (ACDelco #179-1266) (6D04-067) - 2007-2009 E КОРПУС КП КРЕПЛЕНИЕ (MYB,MX7) ↓ 24231525 GASKET, TRFER CASE 19132968 CASE, TRFER (W/GEARS) (LESS DAMPENER) teamcadillac.ru 24243367 CASE, TRFER (W/GEARS) 11589341 БОЛТ - HFH, M10X1.5X69.9, 28.35 THD, 22.3 OD, 10.9, GMW3359, M-PT. (TRFER CASE) [БОЛТ] (6E00-014) - 2004-2009 E ТРАНСМИССИЯ TO КРЕПЛЕНИЕ ДВИГАТЕЛЯ (LY7/3.6-7) ↓ 12572042 PLATE, A/TRNS FLEX 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) teamcadillac.ru 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (TRANS CVR) [БОЛТ] 24222918 COVER, TRANS CONV 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] (6E03-019) - 2007-2009 E T.C.M. МОДУЛЬ (LY7/3.6-7) ↓ 12605670 МОДУЛЬ, ENG CONT (W/O CALN & OPERG SYS) (ACDelco #216-130) [БЛОК УПРАВЛЕНИЯ ДВИГАТЕЛЕМ] teamcadillac.ru 25784072 BRACKET, ECM (INCLS 5, 6) 24239785 МОДУЛЬ, TRANS CONT 11609462 SCREW, M4.2X1.41X13, GMW4205 (ЧАСТЬ OF 3) 11561758 БОЛТ, MULTIUSE RLY & FUSE BRKT (7.833) [БОЛТ] 15879156 BRACKET, ACSRY WRG J/BLK 11609599 STUD, SPL, M6X1X25, 13 THD, 11 OD HD W/26 WIDE CLIP, 9.8, 6280M, P-PT (MULTIUSE FUSE BRKT) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (MULTIUSE RLY & FUSE BRKT) [ГАЙКА М6] (6E04-007) - 2007-2009 EB ТОРМОЗНЫЕ ШЛАНГИ И ТРУБКИ ↓ 15933099 HOSE, FRT BRK (INCLS 15, 16) (ACDelco #176-1495) 11569742 RETAINER, FRT BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (BRK & FUEL FEED & FUEL RTN & EVAP EMIS) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА] 25761218 BRACKET, FUEL PIPE 25761217 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (3.162) 12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (FRT BRK) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА] 10388788 PIPE, BRK PRESS MOD VLV FRT (INCLS 29) 10388794 PIPE, BRK PRESS MOD VLV RR (INCLS 29) 03541444 SPACER, FRT BRK PIPE 11516521 БОЛТ, HFH M6X1X20, 9.8, 7114M, DOG PT, 14.2 OD (FRT BRK HOSE) 15933098 HOSE, FRT BRK (INCLS 15, 16) (ACDelco #176-1487) 25743891 RETAINER, RR BRK FRT PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT) 11569737 FITTING, FRT BRK PIPE (ЧАСТЬ OF 1, 12) (7/16-24X0.36, 0.30THD) (0.56 LONG, 3/16TUBE) 25743891 RETAINER, FRT BRK PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT) 25737279 CLIP, FRT BRK PIPE (THREE WAY RETAINER SINGLE CENTRAL FIR-TREE ATTACHMENT) 15270078 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (USES RETAINER PIN FOR ATTACHMENT) [ЗАЖИМ ТРУБКИ ТОПЛИВНОЙ СИСТЕМЫ] 25688547 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (RETAINER W/5 HOLES (2)7.95, (2)4.76, (1)9.52MM) teamcadillac.ru 25749839 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (HOLDS 3 ТРУБКИ, FLAT SHAPE, SNAP-IN RETAINER) 25607191 RETAINER, BRK PIPE (21.5X10.0MM) (HOLDS (2) 4.68-4.82 TUBES) 11569742 RETAINER, RR BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 15724650 ГАЙКА, INVERTED FLARED TUBE, 9/16"-18, 1/4" TUBE, ZD (BRK PIPE) (4.686) [ГАЙКА] 25693890 RETAINER, RR BRK PIPE (HOLDS (1) 4.76 LINE) (W/TREE) [ЗАМОК, ФИКСАТОР] 11588803 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 7, 8) (1/2-20X.40, .32 THD) (INVERTED FLARED TUBE) (.62 LONG, 1/4 TUBE) [ГАЙКА М20] 15724650 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 7, 8) (9/16-18 X .40) (INVERTED FLARED TUBE) [ГАЙКА] 15933091 HOSE, RR BRK (INCLS 22, 23) (ACDelco #15933091) 15933092 HOSE, RR BRK (INCLS 22, 23) (ACDelco #15933092) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ] 88964150 PROTECTOR, FRT BRK PIPE (FOR 3/16" PIPE) (HT SHRINK) (6E04-008) - 2007-2009 EB ТОРМОЗНАЯ ПЕДАЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (EXC (JF4)) ↓ 25732428 BARRIER, BRK PED BRKT SND 25697461 RETAINER, BRK PED PUSH ROD BOOT 25732452 BOOT, BRK PED PUSH ROD 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] 15932827 HOSE, P/B BOOS VAC (ACDelco #176-1496) 25765419 PEDAL, BRK (W/BRKT) (INCLS 10, 11, 14, 16-18) teamcadillac.ru 25771615 COVER, BRK PED (ЧАСТЬ OF 9) 89047699 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 9) [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 9) 10434956 BUSHING, BRK PED PUSH ROD 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 9) 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 9) (0.80 IN) (PUSH IN) (6E04-012) - 2007-2009 E КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS(MYB,MX7) ↓ teamcadillac.ru 88996677 CASE, TRFER (FRT HALF) (INCLS 12-14) 19133265 CASE, TRFER (RR HALF) (INCLS 5, 7) 88996679 SNUBBER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN 88996680 БОЛТ, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN SNBR (M5X0.8X16) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 2) 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL FILL) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996657 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 2) [УПЛОТНИТЕЛЬ] 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL DRN) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996680 БОЛТ, TRFER CASE VENT BFL (M5X0.8X16) (4.535) 88996658 BAFFLE, TRFER CASE VENT 89048123 БОЛТ, TRFER CASE HALF (M8X1.25X30) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 1) 88996656 SEAL, TRFER CASE INPUT SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 88996657 SEAL, TRFER CASE FRT ВЫХОДНОЙ SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] (6E04-013) - 2007-2009 E КОРПУС КП ЧАСТЬ 2 INTERNAL COMPONENTS(MYB,MX7) ↓ 88984517 WASHER, TRFER CASE PLNT CARR SUN GR THR (25.8X52.0X2.2) 88984524 GEAR, TRFER CASE PLNT CARR SUN (INPUT) (STAMPED PM/POWDERED METAL) 88984493 RING, TRFER CASE RR ВЫХОДНОЙ SHF RR BRG RET (41MM I.D.) (ACDelco #88984493) 88996564 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT 88996665 BEARING, TRFER CASE MAIN SHF FRT (ВЫХОДНОЙ ВАЛ FRT) 19168733 BUSHING, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 106) [ВТУЛКА РАЗДАТОЧНОЙ КОРОБКИ] 19178238 SHAFT, TRFER CASE RR ВЫХОДНОЙ (INCLS 105) 19133264 SPROCKET, TRFER CASE FRT ВЫХОДНОЙ SHF DRV (INCLS 108) [ШЕСТЕРНЯ РАЗДАТОЧНОЙ КОРОБКИ] 19168732 BUSHING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT (ЧАСТЬ OF 107) (ACDelco #19168732) teamcadillac.ru 19132837 CHAIN, TRFER CASE TWO/FOUR WHL DRV 88984523 GEAR, TRFER CASE PLNT CARR SUN (ВЫХОДНОЙ) 89059279 КРОНШТЕЙН, FRT/RR DRV DIFF 89059284 SHAFT, TRFER CASE FRT ВЫХОДНОЙ (INCLS 900) 88996664 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF RR 88996671 RING, TRFER CASE FRT ВЫХОДНОЙ SHF BRG RET 88996666 SPROCKET, TRFER CASE TWO/FOUR WHL DRV DRVN [ЗВЕЗДОЧКА] 88996633 BEARING, TRFER CASE RR ВЫХОДНОЙ SHF RR (ACDelco #88996633) [ПОДШИПНИК РАЗДАТОЧНОЙ КОРОБКИ] 15580230 BEARING, TRFER CASE INPUT SHF (BORG-WARNER) (4.510) 19132966 SHAFT, TRFER CASE INPUT 88996681 DEFLECTOR, TRFER CASE FRT ВЫХОДНОЙ SHF SEAL DIRT (ЧАСТЬ OF 112) 123
  6. 00 - 6-ТИ ЦИЛИНДРОВЫЙ ДВИГАТЕЛЬ ↓ (6E00-003) - 2004-2006 E ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ-V8 (LH2/4.6A, M22) ↓ 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT) [ГАЙКА М12] 25762620 BRACKET, ENG MT 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (ENG MT BRKT) [БОЛТ, М10Х1.5Х30] 25892303 MOUNT, TRANS RR 11515775 БОЛТ, HFH, M12X1.75X30, 10.9, 7114M (TRANS MT) [БОЛТ] 25971086 MOUNT, ENG [ОПОРНЫЙ УЗЕЛ ДВИГАТЕЛЯ] 11517383 БОЛТ, HEX W/CON SPR WASH, M10X1.5X55, 28 OD, 37 THD, 10.9, 7114M (TRANS RR MT BRKT) 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT FRM SI) [ГАЙКА М12] 25971085 MOUNT, ENG [ШАРНИР ДВИГАТЕЛЯ] teamcadillac.ru 25971087 MOUNT, ENG 25716470 BRACKET, ENG MT 25762621 BRACKET, ENG MT (6E00-004) - 2004-2006 E ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ-V8 (LH2/4.6A, MV3) ↓ 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT) [ГАЙКА М12] 25762620 BRACKET, ENG MT 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (ENG MT BRKT) [БОЛТ, М10Х1.5Х30] 15143640 MOUNT, TRANS RR teamcadillac.ru 25892306 MOUNT, TRANS RR 11515775 БОЛТ, HFH, M12X1.75X30, 10.9, 7114M (TRANS MT) [БОЛТ] 11517383 БОЛТ, HEX W/CON SPR WASH, M10X1.5X55, 28 OD, 37 THD, 10.9, 7114M (TRANS RR MT BRKT) 25971086 MOUNT, ENG [ОПОРНЫЙ УЗЕЛ ДВИГАТЕЛЯ] 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT FRM SI) [ГАЙКА М12] 25971085 MOUNT, ENG [ШАРНИР ДВИГАТЕЛЯ] 25716470 BRACKET, ENG MT (6E00-005) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ & ЧАСТЬIAL ДВИГАТЕЛЬ (LH2/4.6A) ↓ teamcadillac.ru 19177068 ДВИГАТЕЛЬ, GASOLINE (GOODWRENCH NEW) (FOR 07 STS, SWP OIL FILT ADAPT, ENG OIL CLR FRM ORIG ENG.06 & PREV STS/SRX/XLR SWP МАСЛЯНЫЙ ПОДДОН, ENG OIL CLR IF APPL, WTR OTLT ASM, CAM ACTUATOR FRM ORIG) (ENG.05 & PREV STS/SRX/XLR SWP CAM CVRS & PVC TBE F (6E00-008) - 2004-2006 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 3 ПЕРЕДНЯЯ КРЫШКА И ОХЛАЖДЕНИЕ (LH2/4.6A) ↓ teamcadillac.ru 03525915 PIN, ENG FRT CVR LOC (DOWEL, 5.99X17.25, CHAM BOTH ENDS, 10.9) 89017798 COVER, ENG FRT (INCLS 353) 12593627 GASKET, ENG FRT CVR [ПРОКЛАДКА ПЕРЕДНЕЙ КРЫШКИ ДВИГАТЕЛЯ] 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (ENG FRT CVR) [БОЛТ] 12569545 PLUG, ENG FRT CVR HOLE 12595614 PUMP, WAT (W/SEAL) (INCLS 901) (ACDelco #251-699) [НАСОС ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (W/PMP) [БОЛТ] 12604614 PULLEY, W/PMP 24503961 БОЛТ, W/PMP PUL (M6X1.0 6G THD W/WA) (8MM SOCKET HD) 12559807 THERMOSTAT, ENG COOL (W/O GSKT) (ACDelco #131-128) [КЛАПАН РЕГУЛИРОВКИ ТЕМПЕРАТУРЫ СИСТЕМЫ ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ] 12563623 GASKET, ENG COOL THERM (ACDelco #12563623) [ПРОКЛАДКА] 12596643 ШЛАНГИ, ENG COOL THERM (ACDelco #15-80869) 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (ENG COOL THERM HSG) [БОЛТ] 12583849 OUTLET, WAT (INCLS 382, 387) (ACDelco #15-10427) 12590862 GASKET, WAT OTLT [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12568102 FITTING, ENG COOL AIR BL HOSE (ЧАСТЬ OF 380) 12566109 HOSE, RAD BYPASS 15024902 CЛАМПА, HOSE ПРУЖИНА, 42MM - NOM SIZE, BLK (RAD BYPASS HOSE) 11519172 БОЛТ, HFH, 8X1.25X55, 18 OD, 22THD, 8.8, GMW3359, 6MM MATPOINT, REDUCED BODY (WAT OTLT) 12580250 PLENUM, INT MANIF (INCLS 526) 09359409 SENSOR, MAP (INCLS SEAL) (INCLS 741) (ACDelco #9359409) 16194007 SEAL, MAP SEN (ЧАСТЬ OF 740) [УПЛОТНИТЕЛЬ ДАТЧИКА ДАВЛЕНИЯ ПОТОКА ВОЗДУХА] 12587812 BRACKET, MAP SEN 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (MAP SEN) [БОЛТ] 12608378 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 745) (ACDelco #214-2125) 11519941 БОЛТ, HFH W/SHLDR, M6X1X22, 13.8 THD, 15 OD, 9.8, 6280M, MACH, DOG-PT (SOL VLV) 11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (WAT OTLT) 12563877 SEAL, W/PMP CVR (O RING) (ЧАСТЬ OF 360) [КОЛЬЦЕВОЕ УПЛОТНЕНИЕ ВОДЯННОГО НАСОСА] (6E00-013) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ & ЧАСТЬIAL ДВИГАТЕЛЬ (LY7/3.6-7) ↓ 19206165 ДВИГАТЕЛЬ, (SERV ЧАСТЬIAL) (MAY NEED TO SWAP МАСЛЯНЫЙ ПОДДОН) (REQUIRES CRANKSHAFT BALANCER WITH KEYWAY. FOR SINGLE BELT, USE 12603181. FOR DUAL BELT BALANCER USE 12603180) (6E00-014) - 2004-2009 E КРЕПЛЕНИЕ ДВИГАТЕЛЯ TO ТРАНСМИССИЯ (LY7/3.6-7) ↓ 12572042 PLATE, A/TRNS FLEX 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] teamcadillac.ru 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (TRANS CONV CVR) [БОЛТ] 24222918 COVER, TRANS CONV 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] (6E00-015) - 2004-2009 E ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ-V6 (LY7/3.6-7, M82) ↓ 25892303 MOUNT, TRANS RR teamcadillac.ru 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (TRANS MT) [БОЛТ, М10Х1.5Х30] 11517383 БОЛТ, HEX W/CON SPR WASH, M10X1.5X55, 28 OD, 37 THD, 10.9, 7114M (TRANS RR MT BRKT) 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT) [ГАЙКА М12] 25756321 BRACKET, ENG MT 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (ENG MT BRKT) [БОЛТ, М10Х1.5Х30] 25971088 MOUNT, ENG [ОПОРНЫЙ УЗЕЛ ДВИГАТЕЛЯ] 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT FRM SI) [ГАЙКА М12] 25971089 MOUNT, ENG 25756322 BRACKET, ENG MT (6E00-016) - 2004-2009 E ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ-V6 (LY7/3.6-7, MX5) ↓ 15143640 MOUNT, TRANS RR 25892306 MOUNT, TRANS RR 11515775 БОЛТ, HFH, M12X1.75X30, 10.9, 7114M (TRANS MT) [БОЛТ] 11517383 БОЛТ, HEX W/CON SPR WASH, M10X1.5X55, 28 OD, 37 THD, 10.9, 7114M (TRANS RR MT BRKT) 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT) [ГАЙКА М12] 25756321 BRACKET, ENG MT 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (ENG MT BRKT) [БОЛТ, М10Х1.5Х30] teamcadillac.ru 25971088 MOUNT, ENG [ОПОРНЫЙ УЗЕЛ ДВИГАТЕЛЯ] 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT FRM SI) [ГАЙКА М12] 25971085 MOUNT, ENG [ШАРНИР ДВИГАТЕЛЯ] 25756320 BRACKET, ENG MT (6M00-019) - 2006 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 5 КОЛЛЕКТОР & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7) ↓ 12603990 TUBE, PCV (INCLS 292) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (PCV TUBE) 12616910 HOSE, PCV (INCLS 285, 286, 290-292) (DIRTY AIR) 12587556 MANIFOLD, UPR INT (INCLS 506) 12571079 MANIFOLD, LWR INT (INCLS 519) 12567371 GROMMET, UPR INT MANIF SIGHT SHLD [ВТУЛКА] 12606862 GROMMET, UPR INT MANIF SIGHT SHLD (32MM OD) 11518906 БОЛТ, HFH, RDUCD BDY, M8X1.25X165, 22 THD, 18 O.D., 8.8, GMW3359 (INT UPR MANIF) [БОЛТ] 11519176 БОЛТ, INT MANIF (M8X1.25X80) (4.081) [БОЛТ] 12577530 BRACE, INT MANIF 11588967 STUD, BALL W/HFH, M6X1X20.65, 14.2 O.D., 8.8, GMW3359 (INT MANIF BR) 11900286 БОЛТ, HFH, W/RDUCD BODY, M12X1.75X75.9, 30 THD, 26.6 OD, 10.9, GMW3359 (INT MANIF BR) 11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (LWR INT MANIF) 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (F/INJN FUEL RL) [БОЛТ] 12583604 SHIELD, UPR INT MANIF SIGHT [ЗАЩИТА] 11517031 ГАЙКА, HFH, M8X1.25, 9.4THK, 17.4 O.D., 10, TIN ZN (UPR INT MANIF SIGHT SHLD) 12583604 SHIELD, UPR INT MANIF SIGHT (INCLS 595, 596, 598) [ЗАЩИТА] 11588523 STUD, M6X1 (UPR INT MANIF SIGHT SHLD) 12567371 GROMMET, UPR INT MANIF SIGHT SHLD (ЧАСТЬ OF 590) [ВТУЛКА] 12606862 GROMMET, UPR INT MANIF SIGHT SHLD (ЧАСТЬ OF 590) (32MM OD) 12576262 GASKET, EXH MANIF [ПРОКЛАДКА ВЫПУСКНОГО КОЛЛЕКТОРА] 12571102 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 12580706 SHIELD, EXH MANIF HT 11518860 БОЛТ, HFH, M8X1.25X30, 20.9 THD, 18 O.D., 10.9, GMW3179 CODE G, GM6194M (EXH MANIF H/SHLD) [БОЛТ] 12582663 INSULATOR, EXH MANIF UPR 12581806 INSULATOR, EXH MANIF LWR 12576263 GASKET, EXH MANIF 12571101 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 11518860 БОЛТ, HFH, M8X1.25X30, 20.9 THD, 18 O.D., 10.9, GMW3179 CODE G, GM6194M (EXH MANIF H/SHLD) [БОЛТ] 12617267 SHIELD, EXH MANIF HT 12581807 INSULATOR, EXH MANIF LWR 14093869 ГАЙКА, PUSH ON, M6, 2.25THK, 12.95 O.D., STL, POR (EXH MANIF H/SHLD INSL) 12589056 BODY, THROT (INCLS 716) (INCLS THROTTLE POSITION SENSOR) (INCLS ACT MTR) (ACDelco #217-2253) 11519972 БОЛТ, THROT BODY (M6X1.0X50) 12581398 GASKET, THROT BODY (ACDelco #217-1610) [ПРОКЛАДКА] 12577831 CLIP, ENG WRG HARN (ЧАСТЬ OF 701) [ФИКСАТОР ПРОВОДКИ МОТОРНОГО ОТСЕКА] teamcadillac.ru 12611801 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 752) (ACDelco #214-1685) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (EVAP EMIS CNSTR PURGE SOL VLV BRKT) 12584171 HOSE, EVAP EMIS CNSTR SOL VLV 12586694 VALVE, INT MANIF TUNING (INCLS 756) 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (INT MANIF TUNING VLV) [БОЛТ] 12575467 SENSOR, MAP (INCLS 778) (ACDelco #213-1584) [ДАТЧИК] 12625785 GASKET KIT, CYL HD (INCLS 521, 522) [КОМПЛЕКТ ПРОКЛАДОК ГОЛОВКИ БЛОКА ЦИЛИНДРОВ (РЕЗ-7, МЕТ-8, ПАР-2)] (6M00-029) - 2006-2009 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 1 БЛОК ЦИЛИНДРОВ & ВНУТРЕННИЕ ДЕТАЛИ (LH2/4.6A) ↓ 12573430 SEAL, LWR C/CASE (4.3MM WIDE X 5MM TALL) [ПРОКЛАДКА] 11610074 БОЛТ-HFH, M8X1.25X45, 21 THD, 16 OD, 10.9 STL, GMW3359 (LWR C/CASE) 03522376 БОЛТ, HFH, M6X1X23, 18 THD, 14.50 OD, 7T, ZP (ENG OIL MANIF) 03542310 БОЛТ, LWR C/CASE (M10X1.5X125, 30 THD) (8.900) 03542311 STUD, LWR C/CASE (M10X1.5X125-M9X1.0X13) (1.428) 03530355 PIN, LWR C/CASE LOC (M8X20) 12582395 CRANKSHAFT, (MCHG) 12585420 PIN, CR/SHF SPKT LOC 89017562 BEARING KIT, CR/SHF (INCLS 123) (STD) (POSN # 1, 2, 4, 5) [ПОДШИПНИК] 89017563 BEARING KIT, CR/SHF (INCLS 900) (STD) (POSN # 3) [ПОДШИПНИК] 12568025 SEAL, CR/SHF RR OIL [ПРОКЛАДКА] 12338076 PIN, TRANSAXLE LOC (19.5 MM X 18.5 MM) (TO CYL BLK) 03525915 PIN, ENG FRT CVR LOC (DOWEL, 5.99X17.25, CHAM BOTH ENDS, 10.9) 24503702 PLUG, ENG BLK COOL HOLE (8X1.25X12, 10.5 THD W/6MM OF 6124M ADHES, 17.6 OD, 9.8, PC) 03522422 PLUG, CM/SHF (CUP, W/LIP, 50.24X6.12X1.52, 52.58 OD, 1008, OIL) 12582606 FLYКОЛЕСО, ENG 11589116 БОЛТ, FLYWHL (8.900) 12568122 COVER, FLYWHL HSG 12570154 SPROCKET, CR/SHF 12581223 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (PRIMARY) 01647264 БОЛТ, TMG CHAIN TENSR (HFH, 8X1.25X42, 22 THD, 17.0 OD, 9.8, PC, MACH) 12564274 CHAIN, CM/SHF INTER DRV 12559388 GUIDE KIT, TMG CHAIN (PRIMARY CHAIN) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 12577433 SPROCKET, CM/SHF INTER DRV SHF 01647272 БОЛТ, CM/SHF SPKT 12577790 SHAFT, CM/SHF INTER DRV 15685550 БОЛТ, CM/SHF INTER DRV SHF RET (M6X1X20) (16.330) [ВИНТ] 12556023 GUIDE, TMG CHAIN (SECONDARY CHAIN GUIDE) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 12556030 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (SECONDARY ON LH BANK) [НАТЯЖИТЕЛЬ РЕМНЯ] 01647264 БОЛТ, TMG CHAIN TENSR (HFH, 8X1.25X42, 22 THD, 17.0 OD, 9.8, PC, MACH) 12556023 GUIDE, TMG CHAIN (SECONDARY CHAIN GUIDE) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 12581281 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (SECONDARY ON RH BANK) 01647264 БОЛТ, TMG CHAIN TENSR (HFH, 8X1.25X42, 22 THD, 17.0 OD, 9.8, PC, MACH) 12567469 ROD, CONN (INCLS 201) (USES 23MM PIN) 12552947 БОЛТ, CONN ROD (ЧАСТЬ OF 200) (MJ9X1.0-4H6HX61.9 LONG) [БОЛТ] 89017430 PISTON, (W/PIN) (INCLS 211, 212) 12584576 BALANCER, CR/SHF [ШКИВ КОЛЕНВАЛА] 11569873 БОЛТ, CR/SHF BALR (M14X1.5X48.4) 12577394 BAFFLE, МАСЛЯНЫЙ ПОДДОН (B/W CRANK CASE AND PAN) 12567170 SENSOR, CR/SHF POSN (INCLS 721) (ACDelco #213-1511) [ДАТЧИК ПОЛОЖЕНИЯ КОЛЕНВАЛА] teamcadillac.ru 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (CR/SHF POSN SEN) 12567446 SENSOR, KNOCK (ACDelco #213-1525) [ДАТЧИК ДЕТОНАЦИИ ДВИГАТЕЛЯ] 89017760 STARTER, (REMAN) (ACDelco #323-1633) (DELCO SERIES PG260H) [СТАРТЕР] 11515793 БОЛТ, HFH (STRTR) 12597445 HARNESS, CR/SHF POS SEN & KNOCK SEN WRG (INCLS 797) 12583228 BRACKET, CR/SHF POSN SEN WRG HARN CONN (ЧАСТЬ OF 796) 12559363 BEARING KIT, CONN ROD (STD) (INCLS 203, 204) [КОМПЛЕКТ ПОДШИПНИКОВ СКОЛЬЖЕНИЯ ШАТУНА (2ШТ)] 89017413 RING KIT, PSTN (INCLS 213-216) (6M00-041) - 2006 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 5 КОЛЛЕКТОР & FUEL ДЕТАЛИ КОМПЛЕКТА (LH2/4.6A) ↓ 12587818 TUBE, PCV 12587817 TUBE, PCV (DIRTY AIR TUBE) 12583849 OUTLET, WAT (INCLS 382, 387, 908) (ACDelco #15-10427) 12590862 GASKET, WAT OTLT [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12568102 FITTING, ENG COOL AIR BL HOSE (ЧАСТЬ OF 380) 12566109 HOSE, RAD BYPASS 15024902 CЛАМПА, HOSE ПРУЖИНА, 42MM - NOM SIZE, BLK (RAD BYPASS HOSE) 11519172 БОЛТ, HFH, 8X1.25X55, 18 OD, 22THD, 8.8, GMW3359, 6MM MATPOINT, REDUCED BODY (WAT OTLT) 12588847 MANIFOLD, INT (INCLS 500, 520, 903) 12571222 FITTING, P/B BOOS VAC TUBE 11588967 STUD, BALL W/HFH, M6X1X20.65, 14.2 O.D., 8.8, GMW3359 (IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ) 12588809 SEAL, UPR INT MANIF (ЧАСТЬ OF 500) [УПЛОТНИТЕЛЬ ВЫПУСКНОГО КОЛЛЕКТОРА] 12580250 PLENUM, INT MANIF (INCLS 526) 11588352 БОЛТ, INT MANIF (W/SPCR) 12557010 STUD, F/INJN FUEL RL (HEX, M6X1.022-M6X1.016, 45MM TOTAL LENGTH) (3.275) 12571212 SHIELD, UPR INT MANIF SIGHT (INCLS 595, 596) [ЗАЩИТНЫЙ КОЖУХ ДВИГАТЕЛЯ] 12600206 BRACKET, UPR INT MANIF SIGHT SHLD (INCLS 904) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (UPR INT MANIF SIGHT SHLD) 12567370 STUD, UPR INT MANIF SIGHT SHLD (3.265) 12567371 GROMMET, UPR INT MANIF SIGHT SHLD (ЧАСТЬ OF 590) [ВТУЛКА] teamcadillac.ru 12567687 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 626, 906) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 12607338 SHIELD, EXH MANIF HT 24505098 БОЛТ, HFH, RND HD, 6X1X12.15, W/ANTI SEIZE, 14.2 O.D.DG PT, 10.9, 711 (EXH MANIF H/SHLD) 12567688 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 626, 635, 636, 906) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 11517031 ГАЙКА, HFH, M8X1.25, 9.4THK, 17.4 O.D., 10, TIN ZN (EXH MANIF) 11519171 БОЛТ, EXH MANIF CLA (M8X1.25X50) (3.275) [БОЛТ ВЫПУСКНОГО КОЛЛЕКТОРА] 11562490 STUD, STRAIGHT, M8X1.25X20, M8X1.25X40, 69 TL, 9.8, GMW3179, EXT HEX SOCKET (EXH MANIF) [ШПИЛЬКА М8] 11609596 STUD, CTLTC CONV (ЧАСТЬ OF 600, 620) [ШПИЛЬКА] 12576372 SHIELD, EXH MANIF HT 24505098 БОЛТ, HFH, RND HD, 6X1X12.15, W/ANTI SEIZE, 14.2 O.D.DG PT, 10.9, 711 (EXH MANIF H/SHLD) 12568289 SHIELD, EXH MANIF LWR HT (ЧАСТЬ OF 620) 10229247 RIVET, EXH MANIF H/SHLD (ЧАСТЬ OF 620) (3.601) 12567376 BODY, THROT (W/THROT ACTR) (INCLS 702) (ACDelco #217-2294) [ДРОССЕЛЬНАЯ ЗАСЛОНКА] 11519973 БОЛТ-HFH, M6X1X60, 18MM THD, 14.2 OD, 8.8, 3359GMW, REDUCED BODY, MAT PT. (ЧАСТЬ OF 701) [БОЛТ 6Х1Х60] 12583980 GASKET, THROT BODY (ACDelco #217-2416) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ДРОССЕЛЬНОЙ ЗАСЛОНКИ] 09359409 SENSOR, MAP (INCLS SEAL) (INCLS 741) (ACDelco #9359409) 16194007 SEAL, MAP SEN (ЧАСТЬ OF 740) [УПЛОТНИТЕЛЬ ДАТЧИКА ДАВЛЕНИЯ ПОТОКА ВОЗДУХА] 12587812 BRACKET, MAP SEN 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (MAP SEN) [БОЛТ] 12608378 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 745) (ACDelco #214-2125) 11519941 БОЛТ, HFH W/SHLDR, M6X1X22, 13.8 THD, 15 OD, 9.8, 6280M, MACH, DOG-PT (EVAP EMIS CNSTR PURGE SOL) 25917777 PIPE, EVAP EMIS CNSTR PURGE (INCLS 748, 749) 12567655 GASKET, EXH MANIF [ПРОКЛАДКА] 11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (WAT OTLT) 12571223 PLUG, P/B VAC SCE HOLE (ЧАСТЬ OF 500) (16.0 MM) 19167509 INSULATOR, UPR INT MANIF CVR (ЧАСТЬ OF 591) (3.405) 12575657 SENSOR, HTD OXY (POSN 1) (IN EXH MANIFOLD/CROSSOVER) (ACDelco #213-1572) [ДАТЧИК] 12597912 SENSOR, HTD OXY (POSN 1) (IN EXH MANIFOLD/CROSSOVER) (ACDelco #213-3863) [КИСЛОРОДНЫЙ ДАТЧИК] 25709703 SEAL, CTLTC CONV (ЧАСТЬ OF 600, 620) (ROUND METAL SEAL) [ПРОКЛАДКА НАСОСА] 12585313 PLUG, ENG COOL AIR BL (ЧАСТЬ OF 380) 12616537 COVER, INT MANIF (RR) (6M00-066) - 2005-2006 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 4 МАСЛЯНЫЙ НАСОС, PAN & ДЕТАЛИ КОМПЛЕКТА (LH2/4.6A) ↓ 12580850 MANIFOLD, ENG OIL (INCLS 107-109) (WITHOUT МАСЛЯНЫЙ ПОДДОН BAFFLE) [КОЛЛЕКТОР МАСЛЯНЫЙ] 03522376 БОЛТ, HFH, M6X1X23, 18 THD, 14.50 OD, 7T, ZP (ENG OIL MANIF) 03542310 БОЛТ, LWR C/CASE (M10X1.5X125, 30 THD) (8.900) 03542311 STUD, LWR C/CASE (M10X1.5X125-M9X1.0X13) (1.428) 12567511 PAN, OIL (INCLS 401, 412, 413, 420-422, 712, 713, 715) [КАРТЕР] 12568928 GASKET, МАСЛЯНЫЙ ПОДДОН (ЧАСТЬ OF 400) [ПРОКЛАДКА] 12567529 PIPE, O/PMP SUC (INCLS 406, 407) 12573569 GASKET, O/PMP SUC PIPE (ЧАСТЬ OF 405) [ПРОКЛАДКА МАСЛЯНОГО НАСОСА] 03522382 БОЛТ, O/PMP SUC PIPE (ЧАСТЬ OF 405) (HFH, M6X1.0X28) 03542258 ГАЙКА, O/PMP SUC PIPE (HFH, M9X1) (1.430) 12577394 BAFFLE, МАСЛЯНЫЙ ПОДДОН (B/W CRANK CASE AND PAN) 11562588 PLUG, МАСЛЯНЫЙ ПОДДОН DRN (ЧАСТЬ OF 400) (INCLS 413) (W/ SEAL) (EXC MAGNET) [ЗАГЛУШКА МАСЛЯНОГО ПОДДОНА] 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 400, 412) (18 X 2) (1.456) 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 400) 11519173 БОЛТ, HFH, REDUCED BODY, M8X1.25X60, 22THD, 18 OD, 8.8, GMW3359 (ЧАСТЬ OF 400) 11519178 БОЛТ HFH, M8X1.25X100, 13MM SOCKET, 8.8, GMW3359 (ЧАСТЬ OF 400) 12585398 INDICATOR, OIL LVL (INCLS 434) [ЩУП УРОВНЯ МАСЛА] 12570585 TUBE, OIL LVL IND (INCLS 432) [НАПРАВЛЯЮЩАЯ ТРУБКА ЩУПА УРОВНЯ МАСЛА] 24504091 SEAL, OIL LVL IND TUBE (O RING) (ЧАСТЬ OF 431) (BLACK) (6.07MM ID, 1.78MM DIA) 11515765 БОЛТ, HFH, M10X1.5X25, 22.30 O.D., HDR PT, 10.9, 7112M (OIL LVL IND TUBE) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) 12598047 ADAPTER, OIL FLTR (INCLS 441, 442, 445, 446, 449, 717, 718, 728, 729) teamcadillac.ru 12573045 GASKET, OIL FLTR ADAP (ЧАСТЬ OF 440) [ПРОКЛАДКА МАСЛЯНОГО ФИЛЬТРА] 11519173 БОЛТ, HFH, REDUCED BODY, M8X1.25X60, 22THD, 18 OD, 8.8, GMW3359 (ЧАСТЬ OF 440) 24575062 FITTING, OIL FLTR (ЧАСТЬ OF 440) 25014612 VALVE, OIL FLTR BYPASS (ЧАСТЬ OF 440) (W/O VAPOR SEPARATOR) (OPENING PRESSURE 21 PSI NOMINAL) (ЧАСТЬ HAS A 16.10MM MAX OD & FITS A 15.84 HOLE IN BLOCK) 89017342 ФИЛЬТР, МАСЛЯНЫЙ (ЧАСТЬ OF 440) (FOR NON-CANADIAN ORDERS) (ACDelco #89017342) 11519833 PLUG ROUND HD, M16X1.5X22, 20 OD, 10 THD, 5.8, 4345M, SEALANT 9985490, MACH (OIL FLTR BYPASS HOLE) 12590890 PUMP, OIL (INCLS 464-472) [МАСЛЯНЫЙ НАСОС] 11518944 SCREW, PAN HD, M6X1X25, 20.9 THD, 11 OD, 8.8, GMW3359, 6 LOBED T-30 M-POINT (ЧАСТЬ OF 463) (8.913) 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (O/PMP) (ACDelco #11517518) [БОЛТ] 12568009 TUBE, O/PMP OTLT (INCLS 481) [ТРУБКА] 12568320 SEAT, ENG OIL MANIF CHK VLV (ЧАСТЬ OF 480) (0.724) [КОЛЬЦЕВОЕ УПЛОТНЕНИЕ] 11518944 SCREW, PAN HD, M6X1X25, 20.9 THD, 11 OD, 8.8, GMW3359, 6 LOBED T-30 M-POINT (O/PMP OTLT TUBE) (8.913) 12603787 SWITCH, ENG OIL LVL IND (ЧАСТЬ OF 400) (INCLS 713) 11561026 БОЛТ, ENG OIL LVL SEN (ЧАСТЬ OF 400) (8.900) 12573744 SHIELD, ENG OIL PRESS GA SEN HT (ЧАСТЬ OF 440) 11519964 БОЛТ, HFH, M6X1X13, 6 THD, 14.2 OD, 8.8, GMW3359, MAT POINT (ЧАСТЬ OF 440) 12567911 SENSOR, ENG OIL PRESS (ЧАСТЬ OF 440) (INCLS 729) (ACDelco #213-1547) [ДАТЧИК ДАВЛЕНИЯ МАСЛА] (6M00-073) - 2006-2009 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 4 МАСЛЯНЫЙ НАСОС,МАСЛЯНЫЙ ПОДДОН & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7) ↓ 22531637 PIN, МАСЛЯНЫЙ ПОДДОН LOC (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 12586959 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (LOWER PRIMARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ГРМ] 12586960 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАТЯЖИТЕЛЬ ЦЕПИ] 12586961 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАПРАВЛЯЮЩАЯ ПРИВОДНОЙ ЦЕПИ] 12597416 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) 12597417 GUIDE, TMG CHAIN (UPPER PRIMARY) 12597418 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (ЧАСТЬ OF 463) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12596502 PAN, OIL (INCLS 404-407, 410, 412, 413, 420, 422, 900) 12575373 PIPE, O/PMP SUC (ЧАСТЬ OF 400) 12566837 SEAL, O/PMP SUC PIPE (ЧАСТЬ OF 400) [УПЛОТНЕНИЕ] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 400) teamcadillac.ru 12566872 DEFLECTOR, CR/SHF OIL (ЧАСТЬ OF 400) 11562588 PLUG, МАСЛЯНЫЙ ПОДДОН DRN (ЧАСТЬ OF 400) (INCLS 413) (W/ SEAL) (EXC MAGNET) [ЗАГЛУШКА МАСЛЯНОГО ПОДДОНА] 12616850 SEAL, МАСЛЯНЫЙ ПОДДОН DRN PLUG (O RING) (ЧАСТЬ OF 400, 412) 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (ЧАСТЬ OF 400) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11588424 БОЛТ, HFH, M6X1X145, 18 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 400) [ШЕСТИГРАННЫЙ ВИНТ] 12595327 INDICATOR, OIL LVL (INCLS 434) 12593211 TUBE, OIL LVL IND (INCLS 432) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 431) (BLACK) (6.07MM ID, 1.78MM DIA) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (OIL LVL IND TUBE) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) 12591607 ADAPTER, OIL FLTR (INCLS 441-443, 446-450, 456, 458, 459, 728, 729) [АДАПТЕР МАСЛЯНОГО ФИЛЬТРА] 12591604 GASKET, OIL FLTR (ЧАСТЬ OF 440) (BETWEEN OIL FILTER ADAPTER AND BLOCK) [ПРОКЛАДКА МАСЛЯНОГО ФИЛЬТРА] 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 440) 11519174 БОЛТ, HFH, W/REDUCED BODY, M8X1.25X65, THD 22, O.D. 18, 8.8, GMW3359 (ЧАСТЬ OF 440) 25014612 VALVE, OIL FLTR BYPASS (ЧАСТЬ OF 440, 450) (W/O VAPOR SEPARATOR) (OPENING PRESSURE 21 PSI NOMINAL) (ЧАСТЬ HAS A 16.10MM MAX OD & FITS A 15.84 HOLE IN BLOCK) 11519184 БОЛТ, OIL FLTR ADAP (ЧАСТЬ OF 440) (M10X1.5X45) (0.029) 25177917 ФИЛЬТР, МАСЛЯНЫЙ (ЧАСТЬ OF 440) (ACDelco #PF2129) [МАСЛЯНЫЙ ФИЛЬТР ДВИГАТЕЛЯ] 12583470 CAP, OIL FLTR (ЧАСТЬ OF 440) (INCLS 446, 456) [КРЫШКА] 12577653 SEAL, OIL FLTR CAP (O RING) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КРЫШКИ МАСЛЯНОГО ФИЛЬТРА] 12590152 PUMP, OIL (INCLS 151, 154, 464-466, 468, 470-472, 474, 475) (INCLS GUIDE, БОЛТS) [МАСЛЕННЫЙ НАСОС] 11900371 БОЛТ, HEX HD, W/1.6 FLAT WA, M8X1.25X54.3, 43 THD, 16O.D., 8.8, GMW3359 (ЧАСТЬ OF 463) 12590119 NOZZLE, PSTN OIL (INCLS 491) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 490) 12621659 SENSOR, ENG OIL PRESS (INCLS 729) (ЧАСТЬ OF 440) (ACDelco #12621659) 11588734 БОЛТ, HFH, M8X1.25X90, 21.6 THD, 18 O.D., 8.8, GMW3359 (ЧАСТЬ OF 400) [ВИНТ] (6Y00-003) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 2 ГОЛОВКА ЦИЛИНДРОВ & ДЕТАЛИ КОМПЛЕКТА (LH2/4.6A) ↓ 03522352 PIN, CYL HD LOC (HOLLOW DOWEL, 15.675X28, CHAM BOTH ENDS, SAE 12L14, ZP) teamcadillac.ru 12564273 CHAIN, SECD TMG 12559389 SHOE KIT, TMG CHAIN TENSR (INCLS 174) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (ЧАСТЬ OF 173) (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 89017766 SHOE KIT, TMG CHAIN TENSR (INCLS 184) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (ЧАСТЬ OF 183) (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 12576969 VALVE, CM/SHF POSN ACTR SOL 12567414 ACTUATOR, CM/SHF POSN (EXH) 12567415 ACTUATOR, CM/SHF POSN (EXH) 12567416 ACTUATOR, CM/SHF POSN (INT) [ПРИВОДНОЙ МЕХАНИЗМ] 12567417 ACTUATOR, CM/SHF POSN (INT) [ПРИВОДНОЙ МЕХАНИЗМ] 12591268 COVER, CM/SHF (INCLS 251, 254-256, 261, 908, 909) 12591269 COVER, CM/SHF (INCLS 251, 254-256, 261, 908, 909) 12576394 GASKET, CM/SHF CVR (ЧАСТЬ OF 250) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ ЦИЛИНДРОВ] 12576395 GASKET, CM/SHF CVR (ЧАСТЬ OF 250) (BETWEEN HEAD AND CAM COVER) [ПРОКЛАДКА] 12576396 GASKET, CM/SHF CVR (ЧАСТЬ OF 250) (СВЕЧИ HOLES) [ПРОКЛАДКА] 12557829 БОЛТ, CM/SHF CVR (ЧАСТЬ OF 250) 12573742 INSULATOR, CM/SHF CVR БОЛТ (ЧАСТЬ OF 250) 12577268 CAP, OIL FIL (MOBIL 1, SAE 5W30, NON-VENTED, W/SEAL, W/TURNING EARS, NOT ROUND) (INCLS 259) (ACDelco #FC209) 12593348 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 258) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА] 12578248 HEAD, CYL (MCHG) (INCLS 312, 313, 315, 334-337) 12578249 HEAD, CYL (MCHG) (INCLS 312, 313, 315, 334-337) 11562349 БОЛТ, CYL HD (, M11X2X161) (*KIT1) 01647218 БОЛТ, CYL HD (QTY 3-RH, 3-LH) (M6X1.0X50, 10.9) (HFH, MACH) 11562126 PLUG, CYL HD CORE HOLE (ЧАСТЬ OF 300) (CUP, 32.03X7.88X1.27, S30400 SS PER SAE J405.) [ЗАГЛУШКА ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 01647543 PLUG, CYL HD CORE HOLE (ЧАСТЬ OF 300) (ROUND HEAD, INT HEX, W/ALUM WASH, 20X1.5X17, 12.25 THD, C1010 RQ) 11588949 PLUG, M16X1.5X14, 24 OD, SAE 1010 STL, GMW3044, W/ AL WASHER (ЧАСТЬ OF 300) [ПРОБКА ЗАМКА] 12574785 RESTRICTOR, ENG BLK OIL GAL 12607211 VALVE, EXH 12590223 VALVE, INT 12565203 ARM, VLV RKR [КОРОМЫСЛО КЛАПАНА ДВИГАТЕЛЯ] 24100005 ADJUSTER, HYD VLV LASH (ACDelco #24100005) [ТОЛКАТЕЛЬ КЛАПАНА ДВИГАТЕЛЯ] 12574354 SEAL, VLV STEM OIL [УПЛОТНЕНИЕ ШТОКА КЛАПАНА] 12565199 ПРУЖИНА, VLV 12580385 CAP, VLV SPR 01647209 KEY, VLV STEM 12565171 CAMSHAFT, EXH (MCHG) (INCLS 338) 12565172 CAMSHAFT, EXH (MCHG) (INCLS 338) [РАСПРЕДВАЛ В СБОРЕ] 12563833 CAMSHAFT, INL (MCHG) (INCLS 338) [РАСПРЕДВАЛ] 12565168 CAMSHAFT, INL (MCHG) (INCLS 338) [КОЛЕНВАЛ] 01647553 БОЛТ, CM/SHF BRG CAP (ЧАСТЬ OF 300) (HFH, M6X1.0X39.5) 12596360 ШЛАНГИ, CM/SHF POSN ACTR (INCLS 342, 344, 345, 735-737) 12596361 ШЛАНГИ, CM/SHF POSN ACTR (INCLS 342, 344, 345, 735-737) 12567656 GASKET, CM/SHF POSN ACTR HSG (ЧАСТЬ OF 340) (0.423) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12567657 GASKET, CM/SHF POSN ACTR HSG (ЧАСТЬ OF 340) (0.423) [УПЛОТНЕНИЕ ДВИГАТЕЛЯ] 11518706 STUD-HFH, M6X1X13.4, M6X1X40, 14.2 OD, 60 TL, 10.9, GM6280M (NON HEX CHROME) (ЧАСТЬ OF 340) (8.981) 11518707 STUD, HFH, M6X1X13 / M6X1X45, 14.2 O.D., 65 TL, 9.8, GM6280M (CM/SHF POSN ACTR HSG) 11562490 STUD, STRAIGHT, M8X1.25X20, M8X1.25X40, 69 TL, 9.8, GMW3179, EXT HEX SOCKET (EXH MANIF) [ШПИЛЬКА М8] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ) 15326386 SENSOR, ENG COOL TEMP (2-WAY MALE) (3.682) (ACDelco #213-928) [ДАТЧИК ТЕМПЕРАТУРЫ ДВИГАТЕЛЯ] 12571533 СВЕЧИ, (ACDelco #41-986) (PLATINUM PLUG) [СВЕЧА ЗАЖИГАНИЯ] 12569160 SENSOR, CM/SHF POSN (INCLS 726) (ACDelco #213-1512) [ДАТЧИК ПОЛОЖЕНИЯ РАСПРЕДВАЛА] 01647346 БОЛТ, HFH, M6X1X17, 17THD, 14.2 O.D., 8.8, ZF (CM/SHF POSN SEN) 12567085 MAGNET, CM/SHF POSN ACTR (INCLS 737) (ЧАСТЬ OF 340) [МАГНИТ] 11518845 SCREW PAN HD, M6X1X16, 15 THD, 12 OD, 8.8, 6280M, TORX, T30, HDR PT, W/SEALANT (ЧАСТЬ OF 340) 12567421 PLUG, CM/SHF POSN ACTR BORE (ЧАСТЬ OF 340, 735) 12581176 HARNESS, ELEK ICM WRG (INCLS 772) 11519976 БОЛТ, HFLGE, M8X1.25X20, 15.6 THD, 18 O.D., 8.8, GMW3359 (ELEK ICM WRG HARN CLIP) 11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (ЧАСТЬ OF 770) [БОЛТ М8] 11517094 SCREW, M5X.8X15.6, 10.4 THD, 10.2 OD, 6202M, 7114M, TAPER-POINT (ЧАСТЬ OF 250) (ACDelco #11517094) 89017450 GASKET KIT, CYL HD (INCLS 302, 310) (INCL GASKET AND M11X2.0 БОЛТS) [ПРОКЛАДКА ДВИГАТЕЛЯ] 89017451 GASKET KIT, CYL HD (INCLS 302, 310) (INCL GASKET AND M11X2.0 БОЛТS) [ПРОКЛАДКА ДВИГАТЕЛЯ] (GM00-031) - 2006 E КРЕПЛЕНИЕ ДВИГАТЕЛЯ TO ТРАНСМИССИЯ (LH2/4.6A) ↓ 12582606 FLYКОЛЕСО, ENG teamcadillac.ru 25771275 BRACKET, ENG WRG HARN (USED IN GENERATOR PACKAGE) 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] 24205900 COVER, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] 11589116 БОЛТ, FLYWHL (8.900) 12568122 COVER, FLYWHL HSG 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (TRANS CONV CVR) (ACDelco #11517518) [БОЛТ] 12568123 COVER, TRANS CONV (GM00-387) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 1 БЛОК ЦИЛИНДРОВ И ВНУТРЕННИЕ ДЕТАЛИ (LY7/3.6-7) ↓ 12560272 БОЛТ, CR/SHF BRG CAP (M10X2X102.5, 24.5) [ВИНТ] 11518861 БОЛТ, HFH, W/REDCD BODY, M8X1.25X90, 26 THD, 18 O.D., 10.9, GM4277M (CR/SHF BRG CAP) [БОЛТ] 11609410 БОЛТ, HFH, M8X1.25X25, 10.9, GMW3179 (CR/SHF BRG CAP) (0.056) [БОЛТ] 89021297 ADHESIVE/SEALANT, THREADLOCKER HI STRENGTH 10ML ERI (CR/SHF BRG CAP) [АДГЕЗИВ] 11589000 БОЛТ, HFH, M8X1.25X50, 24 THD, 18 OD, 10.9, GMW3359, RED BODY, W/ADH (CR/SHF BRG CAP) 12557520 PLUG, ENG BLK OIL GAL (CUP-.390IN OD, .040IN THK, STEEL) 12621351 CRANKSHAFT, (USE T/W 12601937, 12603180) [КОЛЕНВАЛ] 12585420 PIN, CR/SHF SPKT LOC 11561583 PLUG, ENG BLK OIL GAL (M14X1.5X16, 22 OD) (0.253) 12566587 PLUG, ENG BLK OIL GAL 11561751 PLUG, CYL HD WAT JKT HOLE (M20X1.5X30.5) (1.531) 00360571 PLUG, ENG BLK CORE HOLE (CUP DIA 34.3MM) 12597210 PIN, TRANS LOC 24229149 PIN, TRANS LOC 12620955 SEAL, CR/SHF RR OIL (INCLS 134) [ПРОКЛАДКА КОЛЕНВАЛА ДВИГАТЕЛЯ] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 133) 22531637 PIN, МАСЛЯНЫЙ ПОДДОН LOC (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 12570326 PIN, CYL HD LOC [ЗАГЛУШКА БЛОКА ЦИЛИНДРОВ] teamcadillac.ru 12572042 PLATE, A/TRNS FLEX 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12608432 ROD, CONN (INCLS 201, 202) 11519680 БОЛТ, CONN ROD (ЧАСТЬ OF 200) (M9X1X53) [БОЛТ] 12598657 BEARING KIT, CONN ROD (UPPER) [ПОДШИПНИК СКОЛЬЖЕНИЯ ШАТУНА] 12585675 PISTON, (W/PIN) (INCLS 211, 212) (.25 O.S.) 12590866 PISTON, (W/PIN) (INCLS 211, 212) (STD) 12566186 RETAINER, PSTN PIN (ЧАСТЬ OF 210) 12597654 BALANCER, CR/SHF (DUAL BELT, W/O KEYWAY) 11569873 БОЛТ, CR/SHF BALR (M14X1.5X48.4) 12582652 SENSOR, CR/SHF POSN (INCLS 721, 722) (ACDelco #213-1632) [ДАТЧИК] 11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (ЧАСТЬ OF 720) [БОЛТ] 12618603 SENSOR, KNOCK (W/O LEADS) (INCLS 724) (ACDelco #213-4335) [ДАТЧИК] 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 723) 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (EXH MANIF H/SHLD) [БОЛТ] 12610603 BEARING KIT, CR/SHF (#1, 2, 4 STD) (INCLS 122, 123) [ПОДШИПНИК СКОЛЬЖЕНИЯ КОЛЕНВАЛА] 12610604 BEARING KIT, CR/SHF (#3 STD) (INCLS 123, 124) [КОМПЛЕКТ ПОДШИПНИКОВ СКОЛЬЖЕНИЯ КОЛЕНВАЛА (3ШТ)] 12608615 RING KIT, PSTN (INCLS 213-216) (STD) (GM00-389) - 2004-2006 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 3 ПЕРЕДНЯЯ КРЫШКА И ОХЛАЖДЕНИЕ (LY7/3.6-7) ↓ 22531637 PIN, ENG FRT CVR LOC (ЧАСТЬ OF 350) (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 11519176 БОЛТ, ENG FRT CVR (ЧАСТЬ OF 350) (M8X1.25X80) (4.081) [БОЛТ] 12598349 COVER, ENG FRT (W/ W/PMP) (INCLS 132, 348, 351-353, 360-362, 725-727, 734, 900-903) 12593045 SEAL, W/PMP (ЧАСТЬ OF 350) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519171 БОЛТ, ENG FRT CVR (ЧАСТЬ OF 350) (M8X1.25X50) (3.275) [БОЛТ ВЫПУСКНОГО КОЛЛЕКТОРА] 12608750 SEAL, CR/SHF FRT OIL (ЧАСТЬ OF 350) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КОЛЕНВАЛА] 12618472 PUMP, WAT (W/GSKT) (ЧАСТЬ OF 350) (INCLS 900) (ACDelco #251-724) [НАСОС] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 350) 12576326 GASKET, W/PMP (ЧАСТЬ OF 350) (ACDelco #251-2048) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12574518 PULLEY, W/PMP (ADX) 11519512 БОЛТ, HFH, W/CON SPR WA, M6X1X13.4, 8.77 THD, 12.3 O.D., 8.8, GMW3359 (W/PMP PUL) 12582472 SEAL, ENG COOL THERM (ЧАСТЬ OF 367) (ACDelco #12582472) [УПЛОТНИТЕЛЬ] 12620259 ШЛАНГИ, ENG COOL THERM (INCLS 365, 366, 369, 371, 372) (INCLS THERMOSTAT) (ACDelco #15-81651) [КОРПУС В СБОРЕ, ТЕРМОСТАТА СИСТЕМЫ ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ] 11519973 БОЛТ-HFH, M6X1X60, 18MM THD, 14.2 OD, 8.8, 3359GMW, REDUCED BODY, MAT PT. (ENG COOL THERM HSG) [БОЛТ 6Х1Х60] 11519974 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3359 (ENG COOL THERM HSG) [БОЛТ] 12584325 SEAL, ENG COOL THERM HSG (O RING) (ЧАСТЬ OF 367) [КОЛЬЦЕ-ОБРАЗНОЕ УПЛОТНЕНИЕ] teamcadillac.ru 12592527 GASKET, ENG COOL THERM HSG (ЧАСТЬ OF 367) (ACDelco #12592527) [ПРОКЛАДКА ТЕРМОСТАТА] 12566429 SEAL, WAT OTLT [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12584040 SEAL, CLNT OTLT (O RING) (ACDelco #15-32584) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519974 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3359 (WAT OTLT) [БОЛТ] 12573984 OUTLET, WAT (INCLS 905) (INCLS БОЛТS, RETAINERS, SEALS & PIPE) (ACDelco #15-10429) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 12592250 SENSOR, CM/SHF POSN (ЧАСТЬ OF 350) (INCLS 726, 727) (ACDelco #213-1565) 11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (ЧАСТЬ OF 350, 725) [БОЛТ] 12615613 VALVE, CM/SHF POSN ACTR SOL 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (CM/SHF POSN ACTR SOL VLV) 12593717 SEAL, CM/SHF POSN ACTR SOL VLV (O RING) (ЧАСТЬ OF 350) (GM00-393) - 2005-2006 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 2 ГОЛОВКА ЦИЛИНДРОВ & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7) ↓ 12570326 PIN, CYL HD LOC [ЗАГЛУШКА БЛОКА ЦИЛИНДРОВ] 12590921 SPROCKET, CR/SHF [ЦЕПНАЯ ЗВЕЗДОЧКА] 12609262 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (INCLS 153, 164) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 152) [БОЛТ М8] 12590920 CHAIN, CM/SHF INTER DRV (PRIMARY) 12597417 GUIDE, TMG CHAIN (INCLS 157) (UPPER PRIMARY) 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 156) [БОЛТ М8] 11588252 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3179 CODE G (ЧАСТЬ OF 165, 166) 12589477 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 152) (PRIMARY) 12597413 SPROCKET, CM/SHF (INCLS 161) (IDLER) 12597414 SPROCKET, CM/SHF (INCLS 161) (IDLER) 12589011 CHAIN, CM/SHF INTER DRV (92 PITCH) (SECONDARY) 12597416 GUIDE, TMG CHAIN (INCLS 172) (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 171) [БОЛТ М8] 12586960 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАТЯЖИТЕЛЬ ЦЕПИ] 11518858 БОЛТ, HFH, M8X1.25X43, 16 THD, 18 O.D., 8.8, GMW3179 (TMG CHAIN TENSR) [БОЛТ М8] 12609260 РОЛИК НАТЯЖИТЕЛЬ, TMG CHAIN (INCLS 176, 177) (SECONDARY) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 175) [БОЛТ М8] 12589478 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 175) 12597418 GUIDE, TMG CHAIN (INCLS 182) (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 181) [БОЛТ М8] 12586961 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАПРАВЛЯЮЩАЯ ПРИВОДНОЙ ЦЕПИ] 11518858 БОЛТ, HFH, M8X1.25X43, 16 THD, 18 O.D., 8.8, GMW3179 (TMG CHAIN TENSR) [БОЛТ М8] 12609258 РОЛИК НАТЯЖИТЕЛЬ, TMG CHAIN (INCLS 186, 187) (SECONDARY) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 185) [БОЛТ М8] 12589479 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 185) 12588272 ACTUATOR, CM/SHF POSN (EXHAUST) 12588273 ACTUATOR, CM/SHF POSN (INTAKE) 11588279 БОЛТ, HFH, M10X1.5X80, 26 THD, 22.3 O.D., 10.9, GM4277M (CM/SHF POSN ACTR) 12604078 COVER, CM/SHF (INCLS 251, 254-257, 260, 263) 12591200 SEAL, CM/SHF CVR (ЧАСТЬ OF 250) (*KIT1) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12591201 COVER, CM/SHF (INCLS 253-257, 261) 12591203 SEAL, CM/SHF CVR (ЧАСТЬ OF 252) (*KIT1) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 11518859 БОЛТ, HFH W/SHLDR, M6X1X35, 11.85 THD, 18 O.D., 8.8, GMW3359 (ЧАСТЬ OF 250, 252) 12566250 INSULATOR, CM/SHF CVR БОЛТ (ЧАСТЬ OF 250, 252) 12593356 CAP, OIL FIL (INCLS 904) (ACDelco #FC221) [КРЫШКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ] 12593348 SEAL, OIL FIL TUBE (O RING) (ЧАСТЬ OF 262) (27.94MM I.D.) (SIZE #320) (1.758) [ПРОКЛАДКА] 12578316 FITTING, PCV (ЧАСТЬ OF 250) (INCLS 263) 12583384 FITTING, PCV (ЧАСТЬ OF 252) 12597946 TUBE, OIL FIL (INCLS 259) [ТРУБКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ ГОЛОВКИ БЛОКА] 12580962 HEAD, CYL (MCHG) (INCLS 313, 318, 319, 328, 336, 337) (TO BE USED WITH 2 ДВИГАТЕЛЬ OIL MANIF CHECK VALVE ASSEMBLIES) [ГОЛОВКА БЛОКА ЦИЛИНДРОВ] 12603901 HEAD, CYL (MCHG) (INCLS 313, 318, 319, 328, 336, 337) (DOES NOT INCL ENG OIL MANIF CHECK VALVES. DLR MUST INSTL) 11518863 БОЛТ, CYL HD [БОЛТ] 11519177 БОЛТ-HEX FLANGE HD, REDUCED BODY, M8X1.25X90, 8.8, GMW3359 (CYL HD) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12565988 PLUG - M20X1.5X30.5, 8.8, GMW3044, SEALANT PER GM9985490 (ЧАСТЬ OF 300, 301) 11562127 PLUG, CYL HD OIL GAL (ЧАСТЬ OF 300, 301) (CUP-14.22 OD, 6.6 THK, 304SS) 12575354 VALVE, EXH (STD) [КЛАПАН ВЫПУСКНОЙ] teamcadillac.ru 12584760 VALVE, EXH (0.075 O.S.) [КЛАПАН ВЫПУСКНОЙ] 12575351 VALVE, INT (STD) [КЛАПАН ВПУСКНОЙ] 12584763 VALVE, INT (0.075MM O.S.) (0.297) [КЛАПАН ВПУСКНОЙ] 24100294 ARM, VLV RKR [РЫЧАГ] 24100005 ADJUSTER, HYD VLV LASH (ACDelco #24100005) [ТОЛКАТЕЛЬ КЛАПАНА ДВИГАТЕЛЯ] 12565836 SEAL, VLV STEM OIL [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КЛАПАНА ДВИГАТЕЛЯ] 12575355 ПРУЖИНА, VLV [ПРУЖИНА КЛАПАНА] 12575196 RETAINER, VLV SPR [КОМПАКТ ДИСК] 12575197 KEY, VLV STEM [КЛАПАННЫЙ КЛЮЧ] 12574477 RING, CM/SHF SPKT OIL SEAL (ЧАСТЬ OF 330-333) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО РАСПРЕДВАЛА ДВИГАТЕЛЯ (2 ШТ.)] 12566670 CAMSHAFT, EXH (INCLS 329) 12566669 CAMSHAFT, INT (INCLS 329) 12566672 CAMSHAFT, EXH (INCLS 329) 12566671 CAMSHAFT, INT (INCLS 329) 11518856 HFH, M6X1X43.4, 14.8 THD, 11 O.D., 8.8, GMW3179 CODE G (ЧАСТЬ OF 300, 301) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12580965 VALVE, ENG OIL MANIF CHK [КЛАПАН] 12613057 РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ, IGN (INCLS 705) (ACDelco #12613057) 12566778 SENSOR, ENG COOL TEMP (3.682) (ACDelco #213-1581) [СЕНСОР ТЕМПЕРАТУРЫ] 12597464 СВЕЧИ, (DO NOT CHANGE СВЕЧИ GAP) (ACDelco #41-990) (PLATINUM PLUG) [СВЕЧА ЗАЖИГАНИЯ] 12593348 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 258) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА] 12625785 GASKET KIT, CYL HD (INCLS 251, 253, 302, 303) [КОМПЛЕКТ ПРОКЛАДОК ГОЛОВКИ БЛОКА ЦИЛИНДРОВ (РЕЗ-7, МЕТ-8, ПАР-2)] 00 - 8-МИ ЦИЛИНДРОВЫЙ ДВИГАТЕЛЬ ↓ (6E00-003) - 2004-2006 E ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ-V8 (LH2/4.6A, M22) ↓ 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT) [ГАЙКА М12] 25762620 BRACKET, ENG MT 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (ENG MT BRKT) [БОЛТ, М10Х1.5Х30] 25892303 MOUNT, TRANS RR 11515775 БОЛТ, HFH, M12X1.75X30, 10.9, 7114M (TRANS MT) [БОЛТ] 25971086 MOUNT, ENG [ОПОРНЫЙ УЗЕЛ ДВИГАТЕЛЯ] teamcadillac.ru 11517383 БОЛТ, HEX W/CON SPR WASH, M10X1.5X55, 28 OD, 37 THD, 10.9, 7114M (TRANS RR MT BRKT) 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT FRM SI) [ГАЙКА М12] 25971085 MOUNT, ENG [ШАРНИР ДВИГАТЕЛЯ] 25971087 MOUNT, ENG 25716470 BRACKET, ENG MT 25762621 BRACKET, ENG MT (6E00-004) - 2004-2006 E ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ-V8 (LH2/4.6A, MV3) ↓ 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT) [ГАЙКА М12] 25762620 BRACKET, ENG MT 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (ENG MT BRKT) [БОЛТ, М10Х1.5Х30] 15143640 MOUNT, TRANS RR 25892306 MOUNT, TRANS RR 11515775 БОЛТ, HFH, M12X1.75X30, 10.9, 7114M (TRANS MT) [БОЛТ] 11517383 БОЛТ, HEX W/CON SPR WASH, M10X1.5X55, 28 OD, 37 THD, 10.9, 7114M (TRANS RR MT BRKT) 25971086 MOUNT, ENG [ОПОРНЫЙ УЗЕЛ ДВИГАТЕЛЯ] 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT FRM SI) [ГАЙКА М12] 25971085 MOUNT, ENG [ШАРНИР ДВИГАТЕЛЯ] 25716470 BRACKET, ENG MT (6E00-005) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ & ЧАСТЬIAL ДВИГАТЕЛЬ (LH2/4.6A) ↓ teamcadillac.ru 19177068 ДВИГАТЕЛЬ, GASOLINE (GOODWRENCH NEW) (FOR 07 STS, SWP OIL FILT ADAPT, ENG OIL CLR FRM ORIG ENG.06 & PREV STS/SRX/XLR SWP МАСЛЯНЫЙ ПОДДОН, ENG OIL CLR IF APPL, WTR OTLT ASM, CAM ACTUATOR FRM ORIG) (ENG.05 & PREV STS/SRX/XLR SWP CAM CVRS & PVC TBE F (6E00-008) - 2004-2006 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 3 ПЕРЕДНЯЯ КРЫШКА И ОХЛАЖДЕНИЕ (LH2/4.6A) ↓ 03525915 PIN, ENG FRT CVR LOC (DOWEL, 5.99X17.25, CHAM BOTH ENDS, 10.9) 89017798 COVER, ENG FRT (INCLS 353) 12593627 GASKET, ENG FRT CVR [ПРОКЛАДКА ПЕРЕДНЕЙ КРЫШКИ ДВИГАТЕЛЯ] 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (ENG FRT CVR) [БОЛТ] 12569545 PLUG, ENG FRT CVR HOLE 12595614 PUMP, WAT (W/SEAL) (INCLS 901) (ACDelco #251-699) [НАСОС ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (W/PMP) [БОЛТ] 12604614 PULLEY, W/PMP 24503961 БОЛТ, W/PMP PUL (M6X1.0 6G THD W/WA) (8MM SOCKET HD) 12559807 THERMOSTAT, ENG COOL (W/O GSKT) (ACDelco #131-128) [КЛАПАН РЕГУЛИРОВКИ ТЕМПЕРАТУРЫ СИСТЕМЫ ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ] 12563623 GASKET, ENG COOL THERM (ACDelco #12563623) [ПРОКЛАДКА] 12596643 ШЛАНГИ, ENG COOL THERM (ACDelco #15-80869) 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (ENG COOL THERM HSG) [БОЛТ] 12583849 OUTLET, WAT (INCLS 382, 387) (ACDelco #15-10427) 12590862 GASKET, WAT OTLT [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12568102 FITTING, ENG COOL AIR BL HOSE (ЧАСТЬ OF 380) 12566109 HOSE, RAD BYPASS 15024902 CЛАМПА, HOSE ПРУЖИНА, 42MM - NOM SIZE, BLK (RAD BYPASS HOSE) 11519172 БОЛТ, HFH, 8X1.25X55, 18 OD, 22THD, 8.8, GMW3359, 6MM MATPOINT, REDUCED BODY (WAT OTLT) 12580250 PLENUM, INT MANIF (INCLS 526) teamcadillac.ru 09359409 SENSOR, MAP (INCLS SEAL) (INCLS 741) (ACDelco #9359409) 16194007 SEAL, MAP SEN (ЧАСТЬ OF 740) [УПЛОТНИТЕЛЬ ДАТЧИКА ДАВЛЕНИЯ ПОТОКА ВОЗДУХА] 12587812 BRACKET, MAP SEN 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (MAP SEN) [БОЛТ] 12608378 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 745) (ACDelco #214-2125) 11519941 БОЛТ, HFH W/SHLDR, M6X1X22, 13.8 THD, 15 OD, 9.8, 6280M, MACH, DOG-PT (SOL VLV) 11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (WAT OTLT) 12563877 SEAL, W/PMP CVR (O RING) (ЧАСТЬ OF 360) [КОЛЬЦЕВОЕ УПЛОТНЕНИЕ ВОДЯННОГО НАСОСА] (6E00-013) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ & ЧАСТЬIAL ДВИГАТЕЛЬ (LY7/3.6-7) ↓ 19206165 ДВИГАТЕЛЬ, (SERV ЧАСТЬIAL) (MAY NEED TO SWAP МАСЛЯНЫЙ ПОДДОН) (REQUIRES CRANKSHAFT BALANCER WITH KEYWAY. FOR SINGLE BELT, USE 12603181. FOR DUAL BELT BALANCER USE 12603180) (6E00-014) - 2004-2009 E КРЕПЛЕНИЕ ДВИГАТЕЛЯ TO ТРАНСМИССИЯ (LY7/3.6-7) ↓ 12572042 PLATE, A/TRNS FLEX teamcadillac.ru 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (TRANS CONV CVR) [БОЛТ] 24222918 COVER, TRANS CONV 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] (6E00-015) - 2004-2009 E ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ-V6 (LY7/3.6-7, M82) ↓ 25892303 MOUNT, TRANS RR 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (TRANS MT) [БОЛТ, М10Х1.5Х30] 11517383 БОЛТ, HEX W/CON SPR WASH, M10X1.5X55, 28 OD, 37 THD, 10.9, 7114M (TRANS RR MT BRKT) 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT) [ГАЙКА М12] 25756321 BRACKET, ENG MT 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (ENG MT BRKT) [БОЛТ, М10Х1.5Х30] teamcadillac.ru 25971088 MOUNT, ENG [ОПОРНЫЙ УЗЕЛ ДВИГАТЕЛЯ] 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT FRM SI) [ГАЙКА М12] 25971089 MOUNT, ENG 25756322 BRACKET, ENG MT (6E00-016) - 2004-2009 E ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ-V6 (LY7/3.6-7, MX5) ↓ 15143640 MOUNT, TRANS RR 25892306 MOUNT, TRANS RR 11515775 БОЛТ, HFH, M12X1.75X30, 10.9, 7114M (TRANS MT) [БОЛТ] 11517383 БОЛТ, HEX W/CON SPR WASH, M10X1.5X55, 28 OD, 37 THD, 10.9, 7114M (TRANS RR MT BRKT) 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT) [ГАЙКА М12] 25756321 BRACKET, ENG MT 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (ENG MT BRKT) [БОЛТ, М10Х1.5Х30] 25971088 MOUNT, ENG [ОПОРНЫЙ УЗЕЛ ДВИГАТЕЛЯ] 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT FRM SI) [ГАЙКА М12] teamcadillac.ru 25971085 MOUNT, ENG [ШАРНИР ДВИГАТЕЛЯ] 25756320 BRACKET, ENG MT (6M00-019) - 2006 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 5 КОЛЛЕКТОР & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7) ↓ 12603990 TUBE, PCV (INCLS 292) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (PCV TUBE) 12616910 HOSE, PCV (INCLS 285, 286, 290-292) (DIRTY AIR) 12587556 MANIFOLD, UPR INT (INCLS 506) 12571079 MANIFOLD, LWR INT (INCLS 519) 12567371 GROMMET, UPR INT MANIF SIGHT SHLD [ВТУЛКА] 12606862 GROMMET, UPR INT MANIF SIGHT SHLD (32MM OD) 11518906 БОЛТ, HFH, RDUCD BDY, M8X1.25X165, 22 THD, 18 O.D., 8.8, GMW3359 (INT UPR MANIF) [БОЛТ] 11519176 БОЛТ, INT MANIF (M8X1.25X80) (4.081) [БОЛТ] 12577530 BRACE, INT MANIF 11588967 STUD, BALL W/HFH, M6X1X20.65, 14.2 O.D., 8.8, GMW3359 (INT MANIF BR) 11900286 БОЛТ, HFH, W/RDUCD BODY, M12X1.75X75.9, 30 THD, 26.6 OD, 10.9, GMW3359 (INT MANIF BR) 11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (LWR INT MANIF) 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (F/INJN FUEL RL) [БОЛТ] 12583604 SHIELD, UPR INT MANIF SIGHT [ЗАЩИТА] teamcadillac.ru 11517031 ГАЙКА, HFH, M8X1.25, 9.4THK, 17.4 O.D., 10, TIN ZN (UPR INT MANIF SIGHT SHLD) 12583604 SHIELD, UPR INT MANIF SIGHT (INCLS 595, 596, 598) [ЗАЩИТА] 11588523 STUD, M6X1 (UPR INT MANIF SIGHT SHLD) 12567371 GROMMET, UPR INT MANIF SIGHT SHLD (ЧАСТЬ OF 590) [ВТУЛКА] 12606862 GROMMET, UPR INT MANIF SIGHT SHLD (ЧАСТЬ OF 590) (32MM OD) 12576262 GASKET, EXH MANIF [ПРОКЛАДКА ВЫПУСКНОГО КОЛЛЕКТОРА] 12571102 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 12580706 SHIELD, EXH MANIF HT 11518860 БОЛТ, HFH, M8X1.25X30, 20.9 THD, 18 O.D., 10.9, GMW3179 CODE G, GM6194M (EXH MANIF H/SHLD) [БОЛТ] 12582663 INSULATOR, EXH MANIF UPR 12581806 INSULATOR, EXH MANIF LWR 12576263 GASKET, EXH MANIF 12571101 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 11518860 БОЛТ, HFH, M8X1.25X30, 20.9 THD, 18 O.D., 10.9, GMW3179 CODE G, GM6194M (EXH MANIF H/SHLD) [БОЛТ] 12617267 SHIELD, EXH MANIF HT 12581807 INSULATOR, EXH MANIF LWR 14093869 ГАЙКА, PUSH ON, M6, 2.25THK, 12.95 O.D., STL, POR (EXH MANIF H/SHLD INSL) 12589056 BODY, THROT (INCLS 716) (INCLS THROTTLE POSITION SENSOR) (INCLS ACT MTR) (ACDelco #217-2253) 11519972 БОЛТ, THROT BODY (M6X1.0X50) 12581398 GASKET, THROT BODY (ACDelco #217-1610) [ПРОКЛАДКА] 12577831 CLIP, ENG WRG HARN (ЧАСТЬ OF 701) [ФИКСАТОР ПРОВОДКИ МОТОРНОГО ОТСЕКА] 12611801 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 752) (ACDelco #214-1685) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (EVAP EMIS CNSTR PURGE SOL VLV BRKT) 12584171 HOSE, EVAP EMIS CNSTR SOL VLV 12586694 VALVE, INT MANIF TUNING (INCLS 756) 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (INT MANIF TUNING VLV) [БОЛТ] 12575467 SENSOR, MAP (INCLS 778) (ACDelco #213-1584) [ДАТЧИК] 12625785 GASKET KIT, CYL HD (INCLS 521, 522) [КОМПЛЕКТ ПРОКЛАДОК ГОЛОВКИ БЛОКА ЦИЛИНДРОВ (РЕЗ-7, МЕТ-8, ПАР-2)] (6M00-029) - 2006-2009 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 1 БЛОК ЦИЛИНДРОВ & ВНУТРЕННИЕ ДЕТАЛИ (LH2/4.6A) ↓ 12573430 SEAL, LWR C/CASE (4.3MM WIDE X 5MM TALL) [ПРОКЛАДКА] 11610074 БОЛТ-HFH, M8X1.25X45, 21 THD, 16 OD, 10.9 STL, GMW3359 (LWR C/CASE) 03522376 БОЛТ, HFH, M6X1X23, 18 THD, 14.50 OD, 7T, ZP (ENG OIL MANIF) 03542310 БОЛТ, LWR C/CASE (M10X1.5X125, 30 THD) (8.900) 03542311 STUD, LWR C/CASE (M10X1.5X125-M9X1.0X13) (1.428) 03530355 PIN, LWR C/CASE LOC (M8X20) 12582395 CRANKSHAFT, (MCHG) 12585420 PIN, CR/SHF SPKT LOC 89017562 BEARING KIT, CR/SHF (INCLS 123) (STD) (POSN # 1, 2, 4, 5) [ПОДШИПНИК] 89017563 BEARING KIT, CR/SHF (INCLS 900) (STD) (POSN # 3) [ПОДШИПНИК] 12568025 SEAL, CR/SHF RR OIL [ПРОКЛАДКА] 12338076 PIN, TRANSAXLE LOC (19.5 MM X 18.5 MM) (TO CYL BLK) 03525915 PIN, ENG FRT CVR LOC (DOWEL, 5.99X17.25, CHAM BOTH ENDS, 10.9) teamcadillac.ru 24503702 PLUG, ENG BLK COOL HOLE (8X1.25X12, 10.5 THD W/6MM OF 6124M ADHES, 17.6 OD, 9.8, PC) 03522422 PLUG, CM/SHF (CUP, W/LIP, 50.24X6.12X1.52, 52.58 OD, 1008, OIL) 12582606 FLYКОЛЕСО, ENG 11589116 БОЛТ, FLYWHL (8.900) 12568122 COVER, FLYWHL HSG 12570154 SPROCKET, CR/SHF 12581223 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (PRIMARY) 01647264 БОЛТ, TMG CHAIN TENSR (HFH, 8X1.25X42, 22 THD, 17.0 OD, 9.8, PC, MACH) 12564274 CHAIN, CM/SHF INTER DRV 12559388 GUIDE KIT, TMG CHAIN (PRIMARY CHAIN) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 12577433 SPROCKET, CM/SHF INTER DRV SHF 01647272 БОЛТ, CM/SHF SPKT 12577790 SHAFT, CM/SHF INTER DRV 15685550 БОЛТ, CM/SHF INTER DRV SHF RET (M6X1X20) (16.330) [ВИНТ] 12556023 GUIDE, TMG CHAIN (SECONDARY CHAIN GUIDE) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 12556030 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (SECONDARY ON LH BANK) [НАТЯЖИТЕЛЬ РЕМНЯ] 01647264 БОЛТ, TMG CHAIN TENSR (HFH, 8X1.25X42, 22 THD, 17.0 OD, 9.8, PC, MACH) 12556023 GUIDE, TMG CHAIN (SECONDARY CHAIN GUIDE) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 12581281 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (SECONDARY ON RH BANK) 01647264 БОЛТ, TMG CHAIN TENSR (HFH, 8X1.25X42, 22 THD, 17.0 OD, 9.8, PC, MACH) 12567469 ROD, CONN (INCLS 201) (USES 23MM PIN) 12552947 БОЛТ, CONN ROD (ЧАСТЬ OF 200) (MJ9X1.0-4H6HX61.9 LONG) [БОЛТ] 89017430 PISTON, (W/PIN) (INCLS 211, 212) 12584576 BALANCER, CR/SHF [ШКИВ КОЛЕНВАЛА] 11569873 БОЛТ, CR/SHF BALR (M14X1.5X48.4) 12577394 BAFFLE, МАСЛЯНЫЙ ПОДДОН (B/W CRANK CASE AND PAN) 12567170 SENSOR, CR/SHF POSN (INCLS 721) (ACDelco #213-1511) [ДАТЧИК ПОЛОЖЕНИЯ КОЛЕНВАЛА] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (CR/SHF POSN SEN) 12567446 SENSOR, KNOCK (ACDelco #213-1525) [ДАТЧИК ДЕТОНАЦИИ ДВИГАТЕЛЯ] 89017760 STARTER, (REMAN) (ACDelco #323-1633) (DELCO SERIES PG260H) [СТАРТЕР] 11515793 БОЛТ, HFH (STRTR) 12597445 HARNESS, CR/SHF POS SEN & KNOCK SEN WRG (INCLS 797) 12583228 BRACKET, CR/SHF POSN SEN WRG HARN CONN (ЧАСТЬ OF 796) 12559363 BEARING KIT, CONN ROD (STD) (INCLS 203, 204) [КОМПЛЕКТ ПОДШИПНИКОВ СКОЛЬЖЕНИЯ ШАТУНА (2ШТ)] 89017413 RING KIT, PSTN (INCLS 213-216) (6M00-041) - 2006 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 5 КОЛЛЕКТОР & FUEL ДЕТАЛИ КОМПЛЕКТА (LH2/4.6A) ↓ 12587818 TUBE, PCV 12587817 TUBE, PCV (DIRTY AIR TUBE) 12583849 OUTLET, WAT (INCLS 382, 387, 908) (ACDelco #15-10427) 12590862 GASKET, WAT OTLT [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12568102 FITTING, ENG COOL AIR BL HOSE (ЧАСТЬ OF 380) 12566109 HOSE, RAD BYPASS 15024902 CЛАМПА, HOSE ПРУЖИНА, 42MM - NOM SIZE, BLK (RAD BYPASS HOSE) 11519172 БОЛТ, HFH, 8X1.25X55, 18 OD, 22THD, 8.8, GMW3359, 6MM MATPOINT, REDUCED BODY (WAT OTLT) 12588847 MANIFOLD, INT (INCLS 500, 520, 903) 12571222 FITTING, P/B BOOS VAC TUBE 11588967 STUD, BALL W/HFH, M6X1X20.65, 14.2 O.D., 8.8, GMW3359 (IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ) 12588809 SEAL, UPR INT MANIF (ЧАСТЬ OF 500) [УПЛОТНИТЕЛЬ ВЫПУСКНОГО КОЛЛЕКТОРА] 12580250 PLENUM, INT MANIF (INCLS 526) 11588352 БОЛТ, INT MANIF (W/SPCR) 12557010 STUD, F/INJN FUEL RL (HEX, M6X1.022-M6X1.016, 45MM TOTAL LENGTH) (3.275) 12571212 SHIELD, UPR INT MANIF SIGHT (INCLS 595, 596) [ЗАЩИТНЫЙ КОЖУХ ДВИГАТЕЛЯ] 12600206 BRACKET, UPR INT MANIF SIGHT SHLD (INCLS 904) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (UPR INT MANIF SIGHT SHLD) 12567370 STUD, UPR INT MANIF SIGHT SHLD (3.265) 12567371 GROMMET, UPR INT MANIF SIGHT SHLD (ЧАСТЬ OF 590) [ВТУЛКА] 12567687 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 626, 906) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 12607338 SHIELD, EXH MANIF HT 24505098 БОЛТ, HFH, RND HD, 6X1X12.15, W/ANTI SEIZE, 14.2 O.D.DG PT, 10.9, 711 (EXH MANIF H/SHLD) 12567688 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 626, 635, 636, 906) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 11517031 ГАЙКА, HFH, M8X1.25, 9.4THK, 17.4 O.D., 10, TIN ZN (EXH MANIF) teamcadillac.ru 11519171 БОЛТ, EXH MANIF CLA (M8X1.25X50) (3.275) [БОЛТ ВЫПУСКНОГО КОЛЛЕКТОРА] 11562490 STUD, STRAIGHT, M8X1.25X20, M8X1.25X40, 69 TL, 9.8, GMW3179, EXT HEX SOCKET (EXH MANIF) [ШПИЛЬКА М8] 11609596 STUD, CTLTC CONV (ЧАСТЬ OF 600, 620) [ШПИЛЬКА] 12576372 SHIELD, EXH MANIF HT 24505098 БОЛТ, HFH, RND HD, 6X1X12.15, W/ANTI SEIZE, 14.2 O.D.DG PT, 10.9, 711 (EXH MANIF H/SHLD) 12568289 SHIELD, EXH MANIF LWR HT (ЧАСТЬ OF 620) 10229247 RIVET, EXH MANIF H/SHLD (ЧАСТЬ OF 620) (3.601) 12567376 BODY, THROT (W/THROT ACTR) (INCLS 702) (ACDelco #217-2294) [ДРОССЕЛЬНАЯ ЗАСЛОНКА] 11519973 БОЛТ-HFH, M6X1X60, 18MM THD, 14.2 OD, 8.8, 3359GMW, REDUCED BODY, MAT PT. (ЧАСТЬ OF 701) [БОЛТ 6Х1Х60] 12583980 GASKET, THROT BODY (ACDelco #217-2416) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ДРОССЕЛЬНОЙ ЗАСЛОНКИ] 09359409 SENSOR, MAP (INCLS SEAL) (INCLS 741) (ACDelco #9359409) 16194007 SEAL, MAP SEN (ЧАСТЬ OF 740) [УПЛОТНИТЕЛЬ ДАТЧИКА ДАВЛЕНИЯ ПОТОКА ВОЗДУХА] 12587812 BRACKET, MAP SEN 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (MAP SEN) [БОЛТ] 12608378 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 745) (ACDelco #214-2125) 11519941 БОЛТ, HFH W/SHLDR, M6X1X22, 13.8 THD, 15 OD, 9.8, 6280M, MACH, DOG-PT (EVAP EMIS CNSTR PURGE SOL) 25917777 PIPE, EVAP EMIS CNSTR PURGE (INCLS 748, 749) 12567655 GASKET, EXH MANIF [ПРОКЛАДКА] 11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (WAT OTLT) 12571223 PLUG, P/B VAC SCE HOLE (ЧАСТЬ OF 500) (16.0 MM) 19167509 INSULATOR, UPR INT MANIF CVR (ЧАСТЬ OF 591) (3.405) 12575657 SENSOR, HTD OXY (POSN 1) (IN EXH MANIFOLD/CROSSOVER) (ACDelco #213-1572) [ДАТЧИК] 12597912 SENSOR, HTD OXY (POSN 1) (IN EXH MANIFOLD/CROSSOVER) (ACDelco #213-3863) [КИСЛОРОДНЫЙ ДАТЧИК] 25709703 SEAL, CTLTC CONV (ЧАСТЬ OF 600, 620) (ROUND METAL SEAL) [ПРОКЛАДКА НАСОСА] 12585313 PLUG, ENG COOL AIR BL (ЧАСТЬ OF 380) 12616537 COVER, INT MANIF (RR) (6M00-066) - 2005-2006 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 4 МАСЛЯНЫЙ НАСОС, PAN & ДЕТАЛИ КОМПЛЕКТА (LH2/4.6A) ↓ 12580850 MANIFOLD, ENG OIL (INCLS 107-109) (WITHOUT МАСЛЯНЫЙ ПОДДОН BAFFLE) [КОЛЛЕКТОР МАСЛЯНЫЙ] 03522376 БОЛТ, HFH, M6X1X23, 18 THD, 14.50 OD, 7T, ZP (ENG OIL MANIF) 03542310 БОЛТ, LWR C/CASE (M10X1.5X125, 30 THD) (8.900) 03542311 STUD, LWR C/CASE (M10X1.5X125-M9X1.0X13) (1.428) 12567511 PAN, OIL (INCLS 401, 412, 413, 420-422, 712, 713, 715) [КАРТЕР] 12568928 GASKET, МАСЛЯНЫЙ ПОДДОН (ЧАСТЬ OF 400) [ПРОКЛАДКА] 12567529 PIPE, O/PMP SUC (INCLS 406, 407) 12573569 GASKET, O/PMP SUC PIPE (ЧАСТЬ OF 405) [ПРОКЛАДКА МАСЛЯНОГО НАСОСА] 03522382 БОЛТ, O/PMP SUC PIPE (ЧАСТЬ OF 405) (HFH, M6X1.0X28) 03542258 ГАЙКА, O/PMP SUC PIPE (HFH, M9X1) (1.430) 12577394 BAFFLE, МАСЛЯНЫЙ ПОДДОН (B/W CRANK CASE AND PAN) 11562588 PLUG, МАСЛЯНЫЙ ПОДДОН DRN (ЧАСТЬ OF 400) (INCLS 413) (W/ SEAL) (EXC MAGNET) [ЗАГЛУШКА МАСЛЯНОГО ПОДДОНА] 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 400, 412) (18 X 2) (1.456) 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 400) 11519173 БОЛТ, HFH, REDUCED BODY, M8X1.25X60, 22THD, 18 OD, 8.8, GMW3359 (ЧАСТЬ OF 400) 11519178 БОЛТ HFH, M8X1.25X100, 13MM SOCKET, 8.8, GMW3359 (ЧАСТЬ OF 400) 12585398 INDICATOR, OIL LVL (INCLS 434) [ЩУП УРОВНЯ МАСЛА] 12570585 TUBE, OIL LVL IND (INCLS 432) [НАПРАВЛЯЮЩАЯ ТРУБКА ЩУПА УРОВНЯ МАСЛА] 24504091 SEAL, OIL LVL IND TUBE (O RING) (ЧАСТЬ OF 431) (BLACK) (6.07MM ID, 1.78MM DIA) 11515765 БОЛТ, HFH, M10X1.5X25, 22.30 O.D., HDR PT, 10.9, 7112M (OIL LVL IND TUBE) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) 12598047 ADAPTER, OIL FLTR (INCLS 441, 442, 445, 446, 449, 717, 718, 728, 729) 12573045 GASKET, OIL FLTR ADAP (ЧАСТЬ OF 440) [ПРОКЛАДКА МАСЛЯНОГО ФИЛЬТРА] 11519173 БОЛТ, HFH, REDUCED BODY, M8X1.25X60, 22THD, 18 OD, 8.8, GMW3359 (ЧАСТЬ OF 440) 24575062 FITTING, OIL FLTR (ЧАСТЬ OF 440) 25014612 VALVE, OIL FLTR BYPASS (ЧАСТЬ OF 440) (W/O VAPOR SEPARATOR) (OPENING PRESSURE 21 PSI NOMINAL) (ЧАСТЬ HAS A 16.10MM MAX OD & FITS A 15.84 HOLE IN BLOCK) 89017342 ФИЛЬТР, МАСЛЯНЫЙ (ЧАСТЬ OF 440) (FOR NON-CANADIAN ORDERS) (ACDelco #89017342) 11519833 PLUG ROUND HD, M16X1.5X22, 20 OD, 10 THD, 5.8, 4345M, SEALANT 9985490, MACH (OIL FLTR BYPASS HOLE) 12590890 PUMP, OIL (INCLS 464-472) [МАСЛЯНЫЙ НАСОС] 11518944 SCREW, PAN HD, M6X1X25, 20.9 THD, 11 OD, 8.8, GMW3359, 6 LOBED T-30 M-POINT (ЧАСТЬ OF 463) (8.913) 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (O/PMP) (ACDelco #11517518) [БОЛТ] 12568009 TUBE, O/PMP OTLT (INCLS 481) [ТРУБКА] 12568320 SEAT, ENG OIL MANIF CHK VLV (ЧАСТЬ OF 480) (0.724) [КОЛЬЦЕВОЕ УПЛОТНЕНИЕ] 11518944 SCREW, PAN HD, M6X1X25, 20.9 THD, 11 OD, 8.8, GMW3359, 6 LOBED T-30 M-POINT (O/PMP OTLT TUBE) (8.913) 12603787 SWITCH, ENG OIL LVL IND (ЧАСТЬ OF 400) (INCLS 713) 11561026 БОЛТ, ENG OIL LVL SEN (ЧАСТЬ OF 400) (8.900) 12573744 SHIELD, ENG OIL PRESS GA SEN HT (ЧАСТЬ OF 440) 11519964 БОЛТ, HFH, M6X1X13, 6 THD, 14.2 OD, 8.8, GMW3359, MAT POINT (ЧАСТЬ OF 440) 12567911 SENSOR, ENG OIL PRESS (ЧАСТЬ OF 440) (INCLS 729) (ACDelco #213-1547) [ДАТЧИК ДАВЛЕНИЯ МАСЛА] teamcadillac.ru (6M00-073) - 2006-2009 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 4 МАСЛЯНЫЙ НАСОС,МАСЛЯНЫЙ ПОДДОН & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7) ↓ 22531637 PIN, МАСЛЯНЫЙ ПОДДОН LOC (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 12586959 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (LOWER PRIMARY) [НАПРАВЛЯЮЩАЯ ЦЕПИ ГРМ] 12586960 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАТЯЖИТЕЛЬ ЦЕПИ] 12586961 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАПРАВЛЯЮЩАЯ ПРИВОДНОЙ ЦЕПИ] 12597416 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) 12597417 GUIDE, TMG CHAIN (UPPER PRIMARY) 12597418 GUIDE, TMG CHAIN (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (ЧАСТЬ OF 463) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12596502 PAN, OIL (INCLS 404-407, 410, 412, 413, 420, 422, 900) 12575373 PIPE, O/PMP SUC (ЧАСТЬ OF 400) 12566837 SEAL, O/PMP SUC PIPE (ЧАСТЬ OF 400) [УПЛОТНЕНИЕ] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 400) 12566872 DEFLECTOR, CR/SHF OIL (ЧАСТЬ OF 400) 11562588 PLUG, МАСЛЯНЫЙ ПОДДОН DRN (ЧАСТЬ OF 400) (INCLS 413) (W/ SEAL) (EXC MAGNET) [ЗАГЛУШКА МАСЛЯНОГО ПОДДОНА] 12616850 SEAL, МАСЛЯНЫЙ ПОДДОН DRN PLUG (O RING) (ЧАСТЬ OF 400, 412) 11588725 БОЛТ, HFH, M8X1.25X35, 25 THD, 18 OD, 8.8 STL, GMW3359, M-PT (ЧАСТЬ OF 400) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11588424 БОЛТ, HFH, M6X1X145, 18 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 400) [ШЕСТИГРАННЫЙ ВИНТ] 12595327 INDICATOR, OIL LVL (INCLS 434) 12593211 TUBE, OIL LVL IND (INCLS 432) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 431) (BLACK) (6.07MM ID, 1.78MM DIA) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (OIL LVL IND TUBE) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) 12591607 ADAPTER, OIL FLTR (INCLS 441-443, 446-450, 456, 458, 459, 728, 729) [АДАПТЕР МАСЛЯНОГО ФИЛЬТРА] 12591604 GASKET, OIL FLTR (ЧАСТЬ OF 440) (BETWEEN OIL FILTER ADAPTER AND BLOCK) [ПРОКЛАДКА МАСЛЯНОГО ФИЛЬТРА] 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 440) 11519174 БОЛТ, HFH, W/REDUCED BODY, M8X1.25X65, THD 22, O.D. 18, 8.8, GMW3359 (ЧАСТЬ OF 440) 25014612 VALVE, OIL FLTR BYPASS (ЧАСТЬ OF 440, 450) (W/O VAPOR SEPARATOR) (OPENING PRESSURE 21 PSI NOMINAL) (ЧАСТЬ HAS A 16.10MM MAX OD & FITS A 15.84 HOLE IN BLOCK) 11519184 БОЛТ, OIL FLTR ADAP (ЧАСТЬ OF 440) (M10X1.5X45) (0.029) 25177917 ФИЛЬТР, МАСЛЯНЫЙ (ЧАСТЬ OF 440) (ACDelco #PF2129) [МАСЛЯНЫЙ ФИЛЬТР ДВИГАТЕЛЯ] 12583470 CAP, OIL FLTR (ЧАСТЬ OF 440) (INCLS 446, 456) [КРЫШКА] 12577653 SEAL, OIL FLTR CAP (O RING) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КРЫШКИ МАСЛЯНОГО ФИЛЬТРА] teamcadillac.ru 12590152 PUMP, OIL (INCLS 151, 154, 464-466, 468, 470-472, 474, 475) (INCLS GUIDE, БОЛТS) [МАСЛЕННЫЙ НАСОС] 11900371 БОЛТ, HEX HD, W/1.6 FLAT WA, M8X1.25X54.3, 43 THD, 16O.D., 8.8, GMW3359 (ЧАСТЬ OF 463) 12590119 NOZZLE, PSTN OIL (INCLS 491) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 490) 12621659 SENSOR, ENG OIL PRESS (INCLS 729) (ЧАСТЬ OF 440) (ACDelco #12621659) 11588734 БОЛТ, HFH, M8X1.25X90, 21.6 THD, 18 O.D., 8.8, GMW3359 (ЧАСТЬ OF 400) [ВИНТ] (6Y00-003) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 2 ГОЛОВКА ЦИЛИНДРОВ & ДЕТАЛИ КОМПЛЕКТА (LH2/4.6A) ↓ 03522352 PIN, CYL HD LOC (HOLLOW DOWEL, 15.675X28, CHAM BOTH ENDS, SAE 12L14, ZP) 12564273 CHAIN, SECD TMG 12559389 SHOE KIT, TMG CHAIN TENSR (INCLS 174) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (ЧАСТЬ OF 173) (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 89017766 SHOE KIT, TMG CHAIN TENSR (INCLS 184) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (ЧАСТЬ OF 183) (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 12576969 VALVE, CM/SHF POSN ACTR SOL 12567414 ACTUATOR, CM/SHF POSN (EXH) 12567415 ACTUATOR, CM/SHF POSN (EXH) 12567416 ACTUATOR, CM/SHF POSN (INT) [ПРИВОДНОЙ МЕХАНИЗМ] 12567417 ACTUATOR, CM/SHF POSN (INT) [ПРИВОДНОЙ МЕХАНИЗМ] 12591268 COVER, CM/SHF (INCLS 251, 254-256, 261, 908, 909) 12591269 COVER, CM/SHF (INCLS 251, 254-256, 261, 908, 909) 12576394 GASKET, CM/SHF CVR (ЧАСТЬ OF 250) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ ЦИЛИНДРОВ] 12576395 GASKET, CM/SHF CVR (ЧАСТЬ OF 250) (BETWEEN HEAD AND CAM COVER) [ПРОКЛАДКА] 12576396 GASKET, CM/SHF CVR (ЧАСТЬ OF 250) (СВЕЧИ HOLES) [ПРОКЛАДКА] 12557829 БОЛТ, CM/SHF CVR (ЧАСТЬ OF 250) 12573742 INSULATOR, CM/SHF CVR БОЛТ (ЧАСТЬ OF 250) 12577268 CAP, OIL FIL (MOBIL 1, SAE 5W30, NON-VENTED, W/SEAL, W/TURNING EARS, NOT ROUND) (INCLS 259) (ACDelco #FC209) 12593348 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 258) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА] 12578248 HEAD, CYL (MCHG) (INCLS 312, 313, 315, 334-337) 12578249 HEAD, CYL (MCHG) (INCLS 312, 313, 315, 334-337) 11562349 БОЛТ, CYL HD (, M11X2X161) (*KIT1) 01647218 БОЛТ, CYL HD (QTY 3-RH, 3-LH) (M6X1.0X50, 10.9) (HFH, MACH) 11562126 PLUG, CYL HD CORE HOLE (ЧАСТЬ OF 300) (CUP, 32.03X7.88X1.27, S30400 SS PER SAE J405.) [ЗАГЛУШКА ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] teamcadillac.ru 01647543 PLUG, CYL HD CORE HOLE (ЧАСТЬ OF 300) (ROUND HEAD, INT HEX, W/ALUM WASH, 20X1.5X17, 12.25 THD, C1010 RQ) 11588949 PLUG, M16X1.5X14, 24 OD, SAE 1010 STL, GMW3044, W/ AL WASHER (ЧАСТЬ OF 300) [ПРОБКА ЗАМКА] 12574785 RESTRICTOR, ENG BLK OIL GAL 12607211 VALVE, EXH 12590223 VALVE, INT 12565203 ARM, VLV RKR [КОРОМЫСЛО КЛАПАНА ДВИГАТЕЛЯ] 24100005 ADJUSTER, HYD VLV LASH (ACDelco #24100005) [ТОЛКАТЕЛЬ КЛАПАНА ДВИГАТЕЛЯ] 12574354 SEAL, VLV STEM OIL [УПЛОТНЕНИЕ ШТОКА КЛАПАНА] 12565199 ПРУЖИНА, VLV 12580385 CAP, VLV SPR 01647209 KEY, VLV STEM 12565171 CAMSHAFT, EXH (MCHG) (INCLS 338) 12565172 CAMSHAFT, EXH (MCHG) (INCLS 338) [РАСПРЕДВАЛ В СБОРЕ] 12563833 CAMSHAFT, INL (MCHG) (INCLS 338) [РАСПРЕДВАЛ] 12565168 CAMSHAFT, INL (MCHG) (INCLS 338) [КОЛЕНВАЛ] 01647553 БОЛТ, CM/SHF BRG CAP (ЧАСТЬ OF 300) (HFH, M6X1.0X39.5) 12596360 ШЛАНГИ, CM/SHF POSN ACTR (INCLS 342, 344, 345, 735-737) 12596361 ШЛАНГИ, CM/SHF POSN ACTR (INCLS 342, 344, 345, 735-737) 12567656 GASKET, CM/SHF POSN ACTR HSG (ЧАСТЬ OF 340) (0.423) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12567657 GASKET, CM/SHF POSN ACTR HSG (ЧАСТЬ OF 340) (0.423) [УПЛОТНЕНИЕ ДВИГАТЕЛЯ] 11518706 STUD-HFH, M6X1X13.4, M6X1X40, 14.2 OD, 60 TL, 10.9, GM6280M (NON HEX CHROME) (ЧАСТЬ OF 340) (8.981) 11518707 STUD, HFH, M6X1X13 / M6X1X45, 14.2 O.D., 65 TL, 9.8, GM6280M (CM/SHF POSN ACTR HSG) 11562490 STUD, STRAIGHT, M8X1.25X20, M8X1.25X40, 69 TL, 9.8, GMW3179, EXT HEX SOCKET (EXH MANIF) [ШПИЛЬКА М8] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ) 15326386 SENSOR, ENG COOL TEMP (2-WAY MALE) (3.682) (ACDelco #213-928) [ДАТЧИК ТЕМПЕРАТУРЫ ДВИГАТЕЛЯ] 12571533 СВЕЧИ, (ACDelco #41-986) (PLATINUM PLUG) [СВЕЧА ЗАЖИГАНИЯ] 12569160 SENSOR, CM/SHF POSN (INCLS 726) (ACDelco #213-1512) [ДАТЧИК ПОЛОЖЕНИЯ РАСПРЕДВАЛА] 01647346 БОЛТ, HFH, M6X1X17, 17THD, 14.2 O.D., 8.8, ZF (CM/SHF POSN SEN) 12567085 MAGNET, CM/SHF POSN ACTR (INCLS 737) (ЧАСТЬ OF 340) [МАГНИТ] 11518845 SCREW PAN HD, M6X1X16, 15 THD, 12 OD, 8.8, 6280M, TORX, T30, HDR PT, W/SEALANT (ЧАСТЬ OF 340) 12567421 PLUG, CM/SHF POSN ACTR BORE (ЧАСТЬ OF 340, 735) 12581176 HARNESS, ELEK ICM WRG (INCLS 772) 11519976 БОЛТ, HFLGE, M8X1.25X20, 15.6 THD, 18 O.D., 8.8, GMW3359 (ELEK ICM WRG HARN CLIP) 11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (ЧАСТЬ OF 770) [БОЛТ М8] 11517094 SCREW, M5X.8X15.6, 10.4 THD, 10.2 OD, 6202M, 7114M, TAPER-POINT (ЧАСТЬ OF 250) (ACDelco #11517094) 89017450 GASKET KIT, CYL HD (INCLS 302, 310) (INCL GASKET AND M11X2.0 БОЛТS) [ПРОКЛАДКА ДВИГАТЕЛЯ] 89017451 GASKET KIT, CYL HD (INCLS 302, 310) (INCL GASKET AND M11X2.0 БОЛТS) [ПРОКЛАДКА ДВИГАТЕЛЯ] (GM00-031) - 2006 E КРЕПЛЕНИЕ ДВИГАТЕЛЯ TO ТРАНСМИССИЯ (LH2/4.6A) ↓ 12582606 FLYКОЛЕСО, ENG 25771275 BRACKET, ENG WRG HARN (USED IN GENERATOR PACKAGE) 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] teamcadillac.ru 24205900 COVER, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] 11589116 БОЛТ, FLYWHL (8.900) 12568122 COVER, FLYWHL HSG 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (TRANS CONV CVR) (ACDelco #11517518) [БОЛТ] 12568123 COVER, TRANS CONV (GM00-387) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 1 БЛОК ЦИЛИНДРОВ И ВНУТРЕННИЕ ДЕТАЛИ (LY7/3.6-7) ↓ 12560272 БОЛТ, CR/SHF BRG CAP (M10X2X102.5, 24.5) [ВИНТ] 11518861 БОЛТ, HFH, W/REDCD BODY, M8X1.25X90, 26 THD, 18 O.D., 10.9, GM4277M (CR/SHF BRG CAP) [БОЛТ] 11609410 БОЛТ, HFH, M8X1.25X25, 10.9, GMW3179 (CR/SHF BRG CAP) (0.056) [БОЛТ] 89021297 ADHESIVE/SEALANT, THREADLOCKER HI STRENGTH 10ML ERI (CR/SHF BRG CAP) [АДГЕЗИВ] 11589000 БОЛТ, HFH, M8X1.25X50, 24 THD, 18 OD, 10.9, GMW3359, RED BODY, W/ADH (CR/SHF BRG CAP) 12557520 PLUG, ENG BLK OIL GAL (CUP-.390IN OD, .040IN THK, STEEL) 12621351 CRANKSHAFT, (USE T/W 12601937, 12603180) [КОЛЕНВАЛ] 12585420 PIN, CR/SHF SPKT LOC 11561583 PLUG, ENG BLK OIL GAL (M14X1.5X16, 22 OD) (0.253) 12566587 PLUG, ENG BLK OIL GAL 11561751 PLUG, CYL HD WAT JKT HOLE (M20X1.5X30.5) (1.531) 00360571 PLUG, ENG BLK CORE HOLE (CUP DIA 34.3MM) 12597210 PIN, TRANS LOC 24229149 PIN, TRANS LOC 12620955 SEAL, CR/SHF RR OIL (INCLS 134) [ПРОКЛАДКА КОЛЕНВАЛА ДВИГАТЕЛЯ] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 133) 22531637 PIN, МАСЛЯНЫЙ ПОДДОН LOC (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 12570326 PIN, CYL HD LOC [ЗАГЛУШКА БЛОКА ЦИЛИНДРОВ] 12572042 PLATE, A/TRNS FLEX 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12608432 ROD, CONN (INCLS 201, 202) 11519680 БОЛТ, CONN ROD (ЧАСТЬ OF 200) (M9X1X53) [БОЛТ] 12598657 BEARING KIT, CONN ROD (UPPER) [ПОДШИПНИК СКОЛЬЖЕНИЯ ШАТУНА] 12585675 PISTON, (W/PIN) (INCLS 211, 212) (.25 O.S.) 12590866 PISTON, (W/PIN) (INCLS 211, 212) (STD) 12566186 RETAINER, PSTN PIN (ЧАСТЬ OF 210) 12597654 BALANCER, CR/SHF (DUAL BELT, W/O KEYWAY) 11569873 БОЛТ, CR/SHF BALR (M14X1.5X48.4) 12582652 SENSOR, CR/SHF POSN (INCLS 721, 722) (ACDelco #213-1632) [ДАТЧИК] 11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (ЧАСТЬ OF 720) [БОЛТ] 12618603 SENSOR, KNOCK (W/O LEADS) (INCLS 724) (ACDelco #213-4335) [ДАТЧИК] 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 723) 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (EXH MANIF H/SHLD) [БОЛТ] 12610603 BEARING KIT, CR/SHF (#1, 2, 4 STD) (INCLS 122, 123) [ПОДШИПНИК СКОЛЬЖЕНИЯ КОЛЕНВАЛА] teamcadillac.ru 12610604 BEARING KIT, CR/SHF (#3 STD) (INCLS 123, 124) [КОМПЛЕКТ ПОДШИПНИКОВ СКОЛЬЖЕНИЯ КОЛЕНВАЛА (3ШТ)] 12608615 RING KIT, PSTN (INCLS 213-216) (STD) (GM00-389) - 2004-2006 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 3 ПЕРЕДНЯЯ КРЫШКА И ОХЛАЖДЕНИЕ (LY7/3.6-7) ↓ 22531637 PIN, ENG FRT CVR LOC (ЧАСТЬ OF 350) (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 11519176 БОЛТ, ENG FRT CVR (ЧАСТЬ OF 350) (M8X1.25X80) (4.081) [БОЛТ] 12598349 COVER, ENG FRT (W/ W/PMP) (INCLS 132, 348, 351-353, 360-362, 725-727, 734, 900-903) 12593045 SEAL, W/PMP (ЧАСТЬ OF 350) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519171 БОЛТ, ENG FRT CVR (ЧАСТЬ OF 350) (M8X1.25X50) (3.275) [БОЛТ ВЫПУСКНОГО КОЛЛЕКТОРА] 12608750 SEAL, CR/SHF FRT OIL (ЧАСТЬ OF 350) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КОЛЕНВАЛА] 12618472 PUMP, WAT (W/GSKT) (ЧАСТЬ OF 350) (INCLS 900) (ACDelco #251-724) [НАСОС] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 350) 12576326 GASKET, W/PMP (ЧАСТЬ OF 350) (ACDelco #251-2048) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12574518 PULLEY, W/PMP (ADX) 11519512 БОЛТ, HFH, W/CON SPR WA, M6X1X13.4, 8.77 THD, 12.3 O.D., 8.8, GMW3359 (W/PMP PUL) 12582472 SEAL, ENG COOL THERM (ЧАСТЬ OF 367) (ACDelco #12582472) [УПЛОТНИТЕЛЬ] 12620259 ШЛАНГИ, ENG COOL THERM (INCLS 365, 366, 369, 371, 372) (INCLS THERMOSTAT) (ACDelco #15-81651) [КОРПУС В СБОРЕ, ТЕРМОСТАТА СИСТЕМЫ ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ] teamcadillac.ru 11519973 БОЛТ-HFH, M6X1X60, 18MM THD, 14.2 OD, 8.8, 3359GMW, REDUCED BODY, MAT PT. (ENG COOL THERM HSG) [БОЛТ 6Х1Х60] 11519974 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3359 (ENG COOL THERM HSG) [БОЛТ] 12584325 SEAL, ENG COOL THERM HSG (O RING) (ЧАСТЬ OF 367) [КОЛЬЦЕ-ОБРАЗНОЕ УПЛОТНЕНИЕ] 12592527 GASKET, ENG COOL THERM HSG (ЧАСТЬ OF 367) (ACDelco #12592527) [ПРОКЛАДКА ТЕРМОСТАТА] 12566429 SEAL, WAT OTLT [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12584040 SEAL, CLNT OTLT (O RING) (ACDelco #15-32584) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519974 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3359 (WAT OTLT) [БОЛТ] 12573984 OUTLET, WAT (INCLS 905) (INCLS БОЛТS, RETAINERS, SEALS & PIPE) (ACDelco #15-10429) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 12592250 SENSOR, CM/SHF POSN (ЧАСТЬ OF 350) (INCLS 726, 727) (ACDelco #213-1565) 11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (ЧАСТЬ OF 350, 725) [БОЛТ] 12615613 VALVE, CM/SHF POSN ACTR SOL 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (CM/SHF POSN ACTR SOL VLV) 12593717 SEAL, CM/SHF POSN ACTR SOL VLV (O RING) (ЧАСТЬ OF 350) (GM00-393) - 2005-2006 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 2 ГОЛОВКА ЦИЛИНДРОВ & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7) ↓ 12570326 PIN, CYL HD LOC [ЗАГЛУШКА БЛОКА ЦИЛИНДРОВ] 12590921 SPROCKET, CR/SHF [ЦЕПНАЯ ЗВЕЗДОЧКА] 12609262 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (INCLS 153, 164) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 152) [БОЛТ М8] 12590920 CHAIN, CM/SHF INTER DRV (PRIMARY) 12597417 GUIDE, TMG CHAIN (INCLS 157) (UPPER PRIMARY) 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 156) [БОЛТ М8] 11588252 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3179 CODE G (ЧАСТЬ OF 165, 166) 12589477 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 152) (PRIMARY) 12597413 SPROCKET, CM/SHF (INCLS 161) (IDLER) 12597414 SPROCKET, CM/SHF (INCLS 161) (IDLER) 12589011 CHAIN, CM/SHF INTER DRV (92 PITCH) (SECONDARY) 12597416 GUIDE, TMG CHAIN (INCLS 172) (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 171) [БОЛТ М8] 12586960 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАТЯЖИТЕЛЬ ЦЕПИ] 11518858 БОЛТ, HFH, M8X1.25X43, 16 THD, 18 O.D., 8.8, GMW3179 (TMG CHAIN TENSR) [БОЛТ М8] 12609260 РОЛИК НАТЯЖИТЕЛЬ, TMG CHAIN (INCLS 176, 177) (SECONDARY) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 175) [БОЛТ М8] 12589478 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 175) 12597418 GUIDE, TMG CHAIN (INCLS 182) (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 181) [БОЛТ М8] 12586961 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАПРАВЛЯЮЩАЯ ПРИВОДНОЙ ЦЕПИ] 11518858 БОЛТ, HFH, M8X1.25X43, 16 THD, 18 O.D., 8.8, GMW3179 (TMG CHAIN TENSR) [БОЛТ М8] 12609258 РОЛИК НАТЯЖИТЕЛЬ, TMG CHAIN (INCLS 186, 187) (SECONDARY) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 185) [БОЛТ М8] 12589479 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 185) 12588272 ACTUATOR, CM/SHF POSN (EXHAUST) 12588273 ACTUATOR, CM/SHF POSN (INTAKE) 11588279 БОЛТ, HFH, M10X1.5X80, 26 THD, 22.3 O.D., 10.9, GM4277M (CM/SHF POSN ACTR) 12604078 COVER, CM/SHF (INCLS 251, 254-257, 260, 263) 12591200 SEAL, CM/SHF CVR (ЧАСТЬ OF 250) (*KIT1) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12591201 COVER, CM/SHF (INCLS 253-257, 261) 12591203 SEAL, CM/SHF CVR (ЧАСТЬ OF 252) (*KIT1) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 11518859 БОЛТ, HFH W/SHLDR, M6X1X35, 11.85 THD, 18 O.D., 8.8, GMW3359 (ЧАСТЬ OF 250, 252) 12566250 INSULATOR, CM/SHF CVR БОЛТ (ЧАСТЬ OF 250, 252) 12593356 CAP, OIL FIL (INCLS 904) (ACDelco #FC221) [КРЫШКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ] 12593348 SEAL, OIL FIL TUBE (O RING) (ЧАСТЬ OF 262) (27.94MM I.D.) (SIZE #320) (1.758) [ПРОКЛАДКА] 12578316 FITTING, PCV (ЧАСТЬ OF 250) (INCLS 263) 12583384 FITTING, PCV (ЧАСТЬ OF 252) 12597946 TUBE, OIL FIL (INCLS 259) [ТРУБКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ ГОЛОВКИ БЛОКА] 12580962 HEAD, CYL (MCHG) (INCLS 313, 318, 319, 328, 336, 337) (TO BE USED WITH 2 ДВИГАТЕЛЬ OIL MANIF CHECK VALVE ASSEMBLIES) [ГОЛОВКА БЛОКА ЦИЛИНДРОВ] 12603901 HEAD, CYL (MCHG) (INCLS 313, 318, 319, 328, 336, 337) (DOES NOT INCL ENG OIL MANIF CHECK VALVES. DLR MUST INSTL) 11518863 БОЛТ, CYL HD [БОЛТ] teamcadillac.ru 11519177 БОЛТ-HEX FLANGE HD, REDUCED BODY, M8X1.25X90, 8.8, GMW3359 (CYL HD) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12565988 PLUG - M20X1.5X30.5, 8.8, GMW3044, SEALANT PER GM9985490 (ЧАСТЬ OF 300, 301) 11562127 PLUG, CYL HD OIL GAL (ЧАСТЬ OF 300, 301) (CUP-14.22 OD, 6.6 THK, 304SS) 12575354 VALVE, EXH (STD) [КЛАПАН ВЫПУСКНОЙ] 12584760 VALVE, EXH (0.075 O.S.) [КЛАПАН ВЫПУСКНОЙ] 12575351 VALVE, INT (STD) [КЛАПАН ВПУСКНОЙ] 12584763 VALVE, INT (0.075MM O.S.) (0.297) [КЛАПАН ВПУСКНОЙ] 24100294 ARM, VLV RKR [РЫЧАГ] 24100005 ADJUSTER, HYD VLV LASH (ACDelco #24100005) [ТОЛКАТЕЛЬ КЛАПАНА ДВИГАТЕЛЯ] 12565836 SEAL, VLV STEM OIL [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КЛАПАНА ДВИГАТЕЛЯ] 12575355 ПРУЖИНА, VLV [ПРУЖИНА КЛАПАНА] 12575196 RETAINER, VLV SPR [КОМПАКТ ДИСК] 12575197 KEY, VLV STEM [КЛАПАННЫЙ КЛЮЧ] 12574477 RING, CM/SHF SPKT OIL SEAL (ЧАСТЬ OF 330-333) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО РАСПРЕДВАЛА ДВИГАТЕЛЯ (2 ШТ.)] 12566670 CAMSHAFT, EXH (INCLS 329) 12566669 CAMSHAFT, INT (INCLS 329) 12566672 CAMSHAFT, EXH (INCLS 329) 12566671 CAMSHAFT, INT (INCLS 329) 11518856 HFH, M6X1X43.4, 14.8 THD, 11 O.D., 8.8, GMW3179 CODE G (ЧАСТЬ OF 300, 301) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12580965 VALVE, ENG OIL MANIF CHK [КЛАПАН] 12613057 РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ, IGN (INCLS 705) (ACDelco #12613057) 12566778 SENSOR, ENG COOL TEMP (3.682) (ACDelco #213-1581) [СЕНСОР ТЕМПЕРАТУРЫ] 12597464 СВЕЧИ, (DO NOT CHANGE СВЕЧИ GAP) (ACDelco #41-990) (PLATINUM PLUG) [СВЕЧА ЗАЖИГАНИЯ] 12593348 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 258) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА] 12625785 GASKET KIT, CYL HD (INCLS 251, 253, 302, 303) [КОМПЛЕКТ ПРОКЛАДОК ГОЛОВКИ БЛОКА ЦИЛИНДРОВ (РЕЗ-7, МЕТ-8, ПАР-2)] 01 - СИСТЕМА ОХЛАЖДЕНИЯ - РЕШЕТКА РАДИАТОРА-МАСЛОСИСТЕМА ↓ (6D01-034) - 2004-2009 E ПОДОГРЕВАТЕЛЬ БЛОКА ДВИГАТЕЛЯ (LY7/3.6-7, 110V ПОДОГРЕВАТЕЛЬ K05) ↓ 15257983 CORD, ENG COOL HTR (INCLS 2) teamcadillac.ru 12337820 STRAP, 15" TIE STRAP (ЧАСТЬ OF 1) (ACDelco #12337820) 12587380 ПОДОГРЕВАТЕЛЬ, ENG COOL (USE W/2 PIN ПОДОГРЕВАТЕЛЬ) [НАГРЕВАТЕЛЬ] (6D01-044) - 2004-2009 E РАДИАТОР ASM ↓ 19129970 РАДИАТОР, (INCLS 2) (ACDelco #21660) (WITH TRANS OIL COOLER IN RAD, FOR 1ST DES SEE 88957419) 19129971 РАДИАТОР, (INCLS 2) (ACDelco #21659) [РАДИАТОР] 19129973 РАДИАТОР, (W/TRAILER PROVISIONS) (INCLS 2) (ACDelco #21662) teamcadillac.ru 88957419 РАДИАТОР, (INCLS 2) (ACDelco #21508) (6E01-015) - 2004-2009 E НАТЯЖИТЕЛЬ РЕМНЯ/ACCESSORY DRIVE (LH2/4.6A) ↓ 12593189 BELT, W/PMP & КОНДИЦИОНЕР CMPR & P/S PUMP [РЕМЕНЬ ДВИГАТЕЛЯ] teamcadillac.ru 12578062 BELT, GEN (CODE WCN) [РЕМЕНЬ] 11518636 БОЛТ, HFH, M10X1.5X90, 25.9 THD, 22.3 OD, 10.9, GMW3359, 7.5 MAT-PT (ЧАСТЬ OF 4) [БОЛТ М10] 12568172 РОЛИК НАТЯЖИТЕЛЬ, DRV BELT (INCLS 3) (SMOOTH PULLEY) (USE T/W БОЛТ PN 11518636) [ШКИВ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11518636 БОЛТ, HFH, M10X1.5X90, 25.9 THD, 22.3 OD, 10.9, GMW3359, 7.5 MAT-PT (ЧАСТЬ OF 6) [БОЛТ М10] 12598023 РОЛИК НАТЯЖИТЕЛЬ, DRV BELT (INCLS 5) (RIBBED PULLEY) [МЕХАНИЗМ НАТЯЖЕНИЯ] 12604688 PULLEY, BELT IDLER (INCLS 7) (ACDelco #15-40051) (6E01-016) - 2004-2006 E ШЛАНГИ И ТРУБКИ/РАДИАТОР (LH2/4.6A, EXC V92) ↓ 88956903 HOSE, RAD SURGE TK INL (INCLS 2) [ТРУБКА] 11570614 CЛАМПА-ПРУЖИНАBAND, 15 NOMINAL DIA, 15 THK, STL, ROBO (ЧАСТЬ OF 1) 11514517 ГАЙКА, HEX, W/CON SPR WA, M6X1, 5.7THK, 18 O.D., 9, 7111M (RAD SURGE TK) [ГАЙКА М6] 15075118 CAP, RAD SURGE TK (ЧАСТЬ OF 7) (15 PSI DUAL O-RING) (ENGLISH/FRENCH LABEL) (ACDelco #RC98) [КРЫШКА БАЧКА РАДИАТОРА] 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (RAD SURGE TK) (ACDelco #11517518) [БОЛТ] 25757865 HOSE, RAD SURGE TK OVFL (ЧАСТЬ OF 7) teamcadillac.ru 25767641 TANK, RAD SURGE (INCLS 4, 6) (INCLS LOW COOLANT SWITCH) (ACDelco #25767641) [БАЧОК В СБОРЕ] 89023438 HOSE, RAD INL (INCLS 9) [ШЛАНГ] 11516233 CЛАМПА-ПРУЖИНАBAND, TYPE A, 15 WID, 40 HOSE OD, 6150M, 7111M, MM (ЧАСТЬ OF 8) [ХОМУТ ШЛАНГА РАДИАТОРА] 25752529 BRACKET, RAD OTLT HOSE 11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (RAD OTLT HOSE BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16] 11516233 CЛАМПА-ПРУЖИНАBAND, TYPE A, 15 WID, 40 HOSE OD, 6150M, 7111M, MM (ЧАСТЬ OF 13) [ХОМУТ ШЛАНГА РАДИАТОРА] 89023433 HOSE, RAD OTLT (INCLS 12) 88956890 HOSE, RAD SURGE TK OTLT (INCLS 15) (8.846) 11518516 CЛАМПА, RAD SURGE TK ENG HOSE (ЧАСТЬ OF 14) (27MM) (BLACK & YELLOW T-CLIP) [ЗАЖИМ] 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (RAD SURGE TK OTLT HOSE CLIP BRKT) (6E01-017) - 2004-2006 E ШЛАНГИ И ТРУБКИ/РАДИАТОР (LH2/4.6A, V92) ↓ 88956903 HOSE, RAD SURGE TK INL (INCLS 2) [ТРУБКА] 11570614 CЛАМПА-ПРУЖИНАBAND, 15 NOMINAL DIA, 15 THK, STL, ROBO (ЧАСТЬ OF 1) 11514517 ГАЙКА, HEX, W/CON SPR WA, M6X1, 5.7THK, 18 O.D., 9, 7111M (RAD SURGE TK) [ГАЙКА М6] 15075118 CAP, RAD SURGE TK (ЧАСТЬ OF 7) (15 PSI DUAL O-RING) (ENGLISH/FRENCH LABEL) (ACDelco #RC98) [КРЫШКА БАЧКА РАДИАТОРА] 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (RAD SURGE TK) (ACDelco #11517518) [БОЛТ] 25757865 HOSE, RAD SURGE TK OVFL (ЧАСТЬ OF 7) 25767641 TANK, RAD SURGE (INCLS 4, 6) (INCLS LOW COOLANT SWITCH) (ACDelco #25767641) [БАЧОК В СБОРЕ] 89023434 HOSE, RAD INL (INCLS 9) [ТРУБКА] 11516233 CЛАМПА-ПРУЖИНАBAND, TYPE A, 15 WID, 40 HOSE OD, 6150M, 7111M, MM (ЧАСТЬ OF 8) [ХОМУТ ШЛАНГА РАДИАТОРА] 15261734 BRACKET, RAD OTLT HOSE 11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (RAD OTLT HOSE BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16] teamcadillac.ru 11516233 CЛАМПА-ПРУЖИНАBAND, TYPE A, 15 WID, 40 HOSE OD, 6150M, 7111M, MM (ЧАСТЬ OF 13) [ХОМУТ ШЛАНГА РАДИАТОРА] 89023436 HOSE, RAD OTLT (INCLS 12, 23) 11517136 CЛАМПА, HOSE SPR, 27 NOM, 25.2 MIN-28.9 MAX, 15MM WIDE, BLACK (ЧАСТЬ OF 20) 25746579 PUMP, AUX WAT (INCLS 16-18) (ACDelco #251-683) 88958083 HOSE, AUX W/PMP OTLT (ЧАСТЬ OF 15) (INCLS 18) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (AUX W/PMP) 88956890 HOSE, RAD SURGE TK OTLT (INCLS 14) (8.846) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (RAD SURGE TK OTLT HOSE CLIP BRKT) 11570614 CЛАМПА-ПРУЖИНАBAND, 15 NOMINAL DIA, 15 THK, STL, ROBO (ЧАСТЬ OF 13) (6E01-018) - 2004-2006 E ВЕНТИЛЯТОР ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ-ELECTRIC PUSHER(V92) ↓ 89022529 BLADE, FAN (INCLS 2) (ACDelco #15-80710) [КРЫЛЬЧАТКА ВЕНТИЛЯТОРА] 89022527 SHROUD, ENG COOL FAN (INCLS 4) (ELECTRIC PUSH) [ОБТЕКАТЕЛЬ РАДИАТОРА] 89022526 MOTOR, ENG COOL FAN (ELECTRIC PUSH) (ACDelco #15-80542) [ЭЛЕКТРОДВИГАТЕЛЬ ВЕНТИЛЯТОРА 90 ВТ] teamcadillac.ru 89022525 MOTOR, ENG COOL FAN (ELECTRIC PUSH) (ACDelco #15-80541) [ЭЛЕКТРОДВИГАТЕЛЬ ВЕНТИЛЯТОРА 90 ВТ] 89022544 БОЛТ KIT, ENG COOL FAN MOT [КОМПЛЕКТ БОЛТОВ ОБЛИЦОВКИ РАДИАТОРА (2 ШТ)] 89022528 BLADE, FAN (INCLS 2) (ACDelco #15-80709) [КРЫЛЬЧАТКА ВЕНТИЛЯТОРА] (6E01-022) - 2004-2008 E РАДИАТОР КРЕПЛЕНИЕ & ДЕТАЛИ КОМПЛЕКТА ↓ 25718629 BRACKET, RAD UPR (INCLS 3) 25729351 BRACKET, RAD UPR (INCLS 3) 11517484 БОЛТ-HEX, M6X1X20, 9 THD, 17 OD, 9.8, 6280M, MACH, P-PT (RAD UPR MT BRKT) 11519444 PUSH-PIN, 10.0 HEADX26.0, 10.0 HOLE, PNL THK 6.2-8.71, NY 6.6 (RAD AIR LWR BFL (PUSH IN)) [ФИКСАТОР ПОДКРЫЛКА] 25802220 DEFLECTOR, FRT AIR (INCLS 18) [ОБТЕКАТЕЛЬ РАДИАТОРА] 11570323 БОЛТ, ENG COOL FAN SHRD (M6X1X18, 13 THD) 19130179 SHROUD, ENG COOL FAN (MECHANICAL PULL) [КОЖУХ ВЕНТИЛЯТОРА РАДИАТОРА] 89022523 SHROUD, ENG COOL FAN (MECHANICAL PULL) [ОБТЕКАТЕЛЬ РАДИАТОРА] 89023441 SEAL, RAD LH SI (INCLS 8) [ОПОРА РАДИАТОРА] 15932850 INSULATOR, RAD LWR [ДЕМПФЕР РАДИАТОРА] 11561026 БОЛТ-HFH, M6X1X25, 22 THD, 14.2 OD, 9.8, GMW3200, MACH, HDR-PT (КОНДИЦИОНЕР CNDSR) 19130354 CONDENSER, КОНДИЦИОНЕР (ACDelco #15-63540) 19130355 CONDENSER, КОНДИЦИОНЕР (ACDelco #15-63541) 25994576 BAR, FRT BPR IMP (СМ. ГРУППУ 07.000 "БАМПЕР ПЕРЕДНИЙ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [БАЛКА ПАНЕЛИ БАМПЕРА] 89023440 SEAL, RAD AIR SI (INCLS 8) teamcadillac.ru 88957418 SEAL, RAD UPR 15932856 SHROUD, ENG COOL FAN (СМ. ГРУППУ 01.000 "ВЕНТИЛЯТОР ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ОБТЕКАТЕЛЬ РАДИАТОРА] 15248340 SEAL, RAD AIR LWR (ЧАСТЬ OF 5) (6E01-023) - 2004-2009 E НАТЯЖИТЕЛЬ РЕМНЯ/ACCESSORY DRIVE (LY7/3.6-7) ↓ 12577655 РОЛИК НАТЯЖИТЕЛЬ, КОНДИЦИОНЕР CMPR & P/S PMP BELT (9.180) [НАТЯЖИТЕЛЬ РЕМНЯ] 11518633 БОЛТ, HFH, M10X1.5X75, 26 THD, 22.3 OD, 10.9, GMW3359, MAT- POINT. (DRV BELT TENSR) [БОЛТ М10] 12578000 BELT, КОНДИЦИОНЕР CMPR & P/S PUMP [НАСОС] teamcadillac.ru 12621991 BELT, W/PMP & GEN [РЕМЕНЬ ГЕНЕРАТОРА L=120 СМ] 12577652 РОЛИК НАТЯЖИТЕЛЬ, W/PMP & GEN BELT [НАТЯЖИТЕЛЬ РЕМНЯ] (6E01-024) - 2004-2009 E ПОДОГРЕВАТЕЛЬ БЛОКА ДВИГАТЕЛЯ (LH2/4.6A, 110V ПОДОГРЕВАТЕЛЬ K05) ↓ 15905855 CORD KIT, ENG COOL HTR teamcadillac.ru 12587380 ПОДОГРЕВАТЕЛЬ, ENG COOL (USE W/2 PIN ПОДОГРЕВАТЕЛЬ) [НАГРЕВАТЕЛЬ] (6E01-025) - 2004-2009 E ПОДОГРЕВАТЕЛЬ БЛОКА ДВИГАТЕЛЯ (LH2/4.6A, 220V ПОДОГРЕВАТЕЛЬ KA3) ↓ 25772264 CORD, ENG COOL HTR 12587379 ПОДОГРЕВАТЕЛЬ, ENG COOL (6E01-026) - 2004-2006 E ШЛАНГИ И ТРУБКИ/РАДИАТОР (LY7/3.6-7) ↓ 88956900 HOSE, RAD SURGE TK OTLT (INCLS 2) 11517136 CЛАМПА, HOSE SPR, 27 NOM, 25.2 MIN-28.9 MAX, 15MM WIDE, BLACK (ЧАСТЬ OF 1) 11518624 БОЛТ, HFH, M10X1.5X30.4, 22.5 THD, 22.3 O.D., 10.9, GMW3359 (RAD SURGE TK ENG PIPE CLIP) 25757865 HOSE, RAD SURGE TK OVFL (ЧАСТЬ OF 6) teamcadillac.ru 15075118 CAP, RAD SURGE TK (ЧАСТЬ OF 6) (15 PSI DUAL O-RING) (ENGLISH/FRENCH LABEL) (ACDelco #RC98) [КРЫШКА БАЧКА РАДИАТОРА] 25767641 TANK, RAD SURGE (INCLS 4, 5) (INCLS LOW COOLANT SWITCH) (ACDelco #25767641) [БАЧОК В СБОРЕ] 11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (RAD SURGE TK) [БОЛТ М6] 11514517 ГАЙКА, HEX, W/CON SPR WA, M6X1, 5.7THK, 18 O.D., 9, 7111M (RAD SURGE TK) [ГАЙКА М6] 11570614 CЛАМПА-ПРУЖИНАBAND, 15 NOMINAL DIA, 15 THK, STL, ROBO (ЧАСТЬ OF 10) 88958088 HOSE, RAD SURGE TK INL (INCLS 9) 11516233 CЛАМПА-ПРУЖИНАBAND, TYPE A, 15 WID, 40 HOSE OD, 6150M, 7111M, MM (ЧАСТЬ OF 12) [ХОМУТ ШЛАНГА РАДИАТОРА] 89023435 HOSE, RAD INL (INCLS 11) 11516233 CЛАМПА-ПРУЖИНАBAND, TYPE A, 15 WID, 40 HOSE OD, 6150M, 7111M, MM (ЧАСТЬ OF 14) [ХОМУТ ШЛАНГА РАДИАТОРА] 19129967 HOSE, RAD OTLT (INCLS 13) (RAD OUTLET HOSE I/D 32.5MM AT ENG) (1ST DES SEE 89023445) 89023445 HOSE, RAD OTLT (INCLS 13) (RAD OUTLET HOSE I/D 37MM AT ENG) (2ND DES SEE 19129967) 12603912 PIPE, RAD OTLT (INCLS 16) (WHEN USED IN PLACE OF 12587536 USE T/W РАДИАТОР OUTLET HOSE 19129967) 12623519 SEAL, RAD OTLT PIPE (O RING) (ЧАСТЬ OF 15) 11519977 БОЛТ- HFH, M8X1.25X25, 16 THD, 18 OD, 8.8, GMW3359, MAT-PT. (RAD OTLT PIPE) 11518624 БОЛТ, HFH, M10X1.5X30.4, 22.5 THD, 22.3 O.D., 10.9, GMW3359 (RAD OTLT PIPE) 25740076 BRACKET, RAD OTLT HOSE 11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (RAD OTLT HOSE BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16] (6E01-027) - 2004-2006 E ВЕНТИЛЯТОР ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ (EXC (V92)) ↓ 25767914 FAN, ENG COOL (7 BLADE FAN FOR 160W MOTOR) (ACDelco #15-80192) teamcadillac.ru 15932856 SHROUD, ENG COOL FAN (INCLS 4) [ОБТЕКАТЕЛЬ РАДИАТОРА] 88957423 MOTOR, ENG COOL FAN (INCLS 2, 8) (160W) (ACDelco #15-80516) [ЭЛЕКТРОДВИГАТЕЛЬ ВЕНТИЛЯТОРА 90 ВТ] 88957422 MOTOR, ENG COOL FAN (INCLS 2, 8) (160W) (ACDelco #15-80515) [ЭЛЕКТРОДВИГАТЕЛЬ ВЕНТИЛЯТОРА 90 ВТ] 25767915 FAN, ENG COOL (5 BLADES FOR 160W MOT) (ACDelco #15-80193) (6E01-028) - 2006 E РЕШЕТКА РАДИАТОРА ↓ 15284129 MOLDING, КАПОТ FRT (INCLS 2) 11561788 CLIP-U, 13X15X12, 1.5 PNL, 1050, 6280M (ЧАСТЬ OF 1) [ФИКСАТОР МОЛДИНГА КАПОТА] 25735038 BUMPER, КАПОТ STOP (ЧАСТЬ OF 6) (ATTACHED TO РАДИАТОР GRILLE) [ВТУЛКА БАМПЕРА] 21030249 RETAINER, EXPAN, 21 LG, 20. OD, 8.0 HOLE, 3.0-5.0 PNL, NYLON 6/6, BLK (ЧАСТЬ OF 6) (8.950) (PUSH IN) [ПИСТОН КРЕПЛЕНИЯ КОЖУХА РАДИАТОРА(ПЛАСТИК)] 15925771 GRILLE, RAD (INCLS 4, 5, 7-10) [РЕШЕТКА РАДИАТОРА] 25765149 EMBLEM, RAD GRL (ЧАСТЬ OF 6) (CHROME) ("CREST") [ЭМБЛЕМА] 25765150 EMBLEM, RAD GRL (ЧАСТЬ OF 6) ("WREATH") [ЭМБЛЕМА] teamcadillac.ru 21030249 RETAINER, EXPAN, 21 LG, 20. OD, 8.0 HOLE, 3.0-5.0 PNL, NYLON 6/6, BLK (ЧАСТЬ OF 6) (8.950) (PUSH IN) [ПИСТОН КРЕПЛЕНИЯ КОЖУХА РАДИАТОРА(ПЛАСТИК)] 24574578 RETAINER, RAD GRL (ЧАСТЬ OF 6) (LENGTH 18.0) (3.403) [ФИКСАТОРА ВОЗДУХООЧИСТИТЕЛЯ] (6M01-035) - 2004-2009 E ВЕНТИЛЯТОР ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ-ДВИГАТЕЛЬ MOUNTED (LH2/4.6A, V92) ↓ 11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (ENG COOL FAN BRKT) 12597700 BRACKET, ENG COOL FAN (INCLS 7) 11516869 БОЛТ, HEX W/CON WA, M10X1.5X18, 13THD, 20 O.D., 9.8, GM6174M (FAN BLADE) (*KIT1) 12589532 STUD, AUX ENG CLG FAN BRKT teamcadillac.ru 12586654 INSULATOR, ENG COOL FAN (ЧАСТЬ OF 2) 10382029 FAN, ENG COOL (INCLS 3-5) (1.050) (ACDelco #15-4972) [ЭЛЕКТРОМАГНИТНАЯ МУФТА ВЕНТИЛЯТОРА СИСТЕМЫ ОХЛАЖДЕНИЯ] (6M01-036) - 2004-2006 E ВЕНТИЛЯТОР ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ-ДВИГАТЕЛЬ MOUNTED (LY7/3.6-7, V92) ↓ 11518628 БОЛТ, HVY HEX ACORN FLG HD, M10X1.5X50, GMW25M (10.9) STL, GMW3358 (AUX ENG COOL FAN BRKT) teamcadillac.ru 12586654 BUSHING, ENG CLG FAN BLADE (*KIT1) (1.055) 12589532 STUD, AUX ENG CLG FAN BRKT 11516869 БОЛТ, HEX W/CON WA, M10X1.5X18, 13THD, 20 O.D., 9.8, GM6174M (FAN BLADE CLU) 10382026 FAN, ENG COOL (INCLS 8) (INCLS СЦЕПЛЕНИЕ) (ACDelco #15-80877) 11518633 БОЛТ, HFH, M10X1.5X75, 26 THD, 22.3 OD, 10.9, GMW3359, MAT- POINT. (AUX ENG COOL FAN BRKT) [БОЛТ М10] 12593813 ADAPTER, FAN BLADE CLU (INCLS 2-4) (1.055) (6M01-037) - 2005-2006 E ПОДОГРЕВАТЕЛЬ БЛОКА ДВИГАТЕЛЯ (LY7/3.6-7, 220V ПОДОГРЕВАТЕЛЬ KA3) ↓ 25772574 CORD, ENG COOL HTR [КАБЕЛЬ ПИТАНИЯ СИСТЕМЫ ПОДОГРЕВА ДВС] 12588204 ПОДОГРЕВАТЕЛЬ, ENG COOL 02 - СТАРТЕР - ГЕНЕРАТОР - ЗАЖИГАНИЕ - ЭЛЕКТРИКА - ЛАМПЫ ↓ (6D02-025) - 2004-2009 E КРЕПЛЕНИЕ ГЕНЕРАТОРА (LY7/3.6-7) ↓ 12597648 BRACKET, GEN & DRV BELT TENSR (2.277) 11518628 БОЛТ, HVY HEX ACORN FLG HD, M10X1.5X50, GMW25M (10.9) STL, GMW3358 (GEN BRKT) 11518636 БОЛТ, HFH, M10X1.5X90, 25.9 THD, 22.3 OD, 10.9, GMW3359, 7.5 MAT-PT (GEN BRKT) [БОЛТ М10] teamcadillac.ru 11519176 БОЛТ, GEN BRKT (M8X1.25X80) (4.081) [БОЛТ] 25751146 GENERATOR, (ACDelco #25751146) [ГЕНЕРАТОР 150 А] 11518628 БОЛТ, HVY HEX ACORN FLG HD, M10X1.5X50, GMW25M (10.9) STL, GMW3358 (GEN) 11518633 БОЛТ, HFH, M10X1.5X75, 26 THD, 22.3 OD, 10.9, GMW3359, MAT- POINT. (GEN) [БОЛТ М10] (6D02-035) - 2004-2009 E РЕЛЕ/BODY COMPARTMENT ↓ 12088553 BREAKER, CIRC (ЧАСТЬ OF 10) (CYCLING TYPE, 8MM WIDE TERMINALS) (8.965) 15319848 BREAKER, CIRC (ЧАСТЬ OF 10) (50 AMP MAXI TYPE I) 15319477 FUSE, 30AMP, PINK, J-CASE, FEMALE, REGULAR (ЧАСТЬ OF 10) [ПРЕДОХРАНИТЕЛЬ 30А] 15319478 FUSE, 40AMP, GREEN, J-CASE, FEMALE (ЧАСТЬ OF 10) (ACDelco #15319478) [ПРЕДОХРАНИТЕЛЬ 40А] 12092079 FUSE, 10A, MINI, RED (ЧАСТЬ OF 10) 88909754 FUSE, 15A, MINI, BLUE (ЧАСТЬ OF 10) (ACDelco #ATM15-25) [ПРЕДОХРАНИТЕЛЬ 15 А] 88953222 RELAY, INTR LP (ЧАСТЬ OF 10) (GRAY) (20AMP) (4 TERMINAL) (LOW-PROFILE MICRO 280) (2.485) (ACDelco #D1755A) [РЕЛЕ] teamcadillac.ru 19116060 PULLER, FUSE (ЧАСТЬ OF 10) 21997408 RELAY, ACSRY TIME DELAY CUTOFF (ЧАСТЬ OF 10) (5-TERMINAL) (SPDT, 280 MINI, HI/LOW, BLACK) (1.055) (ACDelco #15-81106) 89046748 BLOCK, BODY WRG HARN JUNC (ЧАСТЬ OF 10) (75-WAY FEMALE) (W/O LEADS) (BELOW LH ЗАДНИЙ SEAT) 89047327 COVER, PWR DISTR FUSE BLK (ЧАСТЬ OF 10) 89046747 BLOCK, BODY WRG HARN JUNC (ЧАСТЬ OF 10) (75-WAY FEMALE) (W/O LEADS) (BELOW RH ЗАДНИЙ SEAT) (6E02-022) - 2004-2009 E ФАРООМЫВАТЕЛЬ (CE4) ↓ 25890367 HOSE, HDLP WA 12335720 COVER, HDLP WA NOZ 12335721 COVER, HDLP WA NOZ 25767592 NOZZLE, HDLP WA [ФОРСУНКА ФАРООМЫВАТЕЛЯ] 25767593 NOZZLE, HDLP WA [ФОРСУНКА СТЕКЛООМЫВАТЕЛЯ] teamcadillac.ru 88958121 PUMP, HDLP WA (LOCATED IN WSW TANK) (ACDelco #88958121) [НАСОС СТЕКЛООМЫВАТЕЛЯ] 88958122 SEAL, HDLP WA PUMP (6E02-023) - 2004-2009 E КРЕПЛЕНИЕ ГЕНЕРАТОРА (LH2/4.6A) ↓ teamcadillac.ru 12565095 BRACKET, GEN 11515767 БОЛТ, HFH, M10X1.5X35, 32THD, 22.3 O.D., MACH, 10.9, 7114M (GEN BRKT) (T/W 12345493) [БОЛТ] 25709327 GENERATOR, (ACDelco #25709327) [ГЕНЕРАТОР 150 А] 11516360 БОЛТ, HFH M10X1.2X90, 9.8, 7114M, 22.3 OD HDR PT (GEN) (6E02-025) - 2004-2009 E ЖГУТЫ ПРОВОДОВ/ПЕРЕДНИЕ ФАРЫ ↓ 15141492 HARNESS, FWD LP WRG (INCLS 2, 3) 15141493 HARNESS, FWD LP WRG (INCLS 2, 3) 15141494 HARNESS, FWD LP WRG (INCLS 2, 3) 15141495 HARNESS, FWD LP WRG (INCLS 2, 3) teamcadillac.ru 15141496 HARNESS, FWD LP WRG (INCLS 2, 3) 15141497 HARNESS, FWD LP WRG (INCLS 2, 3) 15141498 HARNESS, FWD LP WRG (INCLS 2, 3) 15141499 HARNESS, FWD LP WRG (INCLS 2, 3) 15141500 HARNESS, FWD LP WRG (INCLS 2, 3) [К-Т ПРОВОДОВ ПЕРЕДНИХ ФАР] 15141501 HARNESS, FWD LP WRG (INCLS 2, 3) 15141502 HARNESS, FWD LP WRG (INCLS 2, 3) 15141503 HARNESS, FWD LP WRG (INCLS 2, 3) 25747284 HARNESS, S/LP WRG (6E02-026) - 2004-2009 E ЖГУТЫ ПРОВОДОВ/ДВИГАТЕЛЬ (LH2/4.6A) ↓ teamcadillac.ru 10369372 HARNESS, ENG WRG 10369373 HARNESS, ENG WRG 10369374 HARNESS, ENG WRG 10369375 HARNESS, ENG WRG 11517070 БОЛТ, HVY HFH, M10X1.5X20 (ENG WRG HARN GND) 25771275 BRACKET, ENG WRG HARN (USED IN GENERATOR PACKAGE) 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] 11519861 БОЛТ, HEX W/FL WA, M10X1.5X30, 19 THD, 20 OD, 9.8, 6280M, MACH, MAT-PT (ENG WRG HARN GRD) [БОЛТ М10] 25773136 BRACKET, ENG WRG HARN (CHANNEL) 11517070 БОЛТ, HVY HFH, M10X1.5X20 (ENG WRG HARN SHLD) (6E02-027) - 2004-2009 E ЖГУТЫ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ ↓ 15790286 HARNESS, I/P WRG 15790287 HARNESS, I/P WRG 15790288 HARNESS, I/P WRG 15790289 HARNESS, I/P WRG 15790290 HARNESS, I/P WRG teamcadillac.ru 15790291 HARNESS, I/P WRG 11516630 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (I/P WRG HARN) (6E02-028) - 2004-2006 E РЕЛЕ & МОДУЛЬS/ДВИГАТЕЛЬНЫЙ ОТСЕК ↓ 15233126 COVER, MULTIUSE RLY & FUSE (USED ON CARS BLT W/BLOCKS 15870409, 15224195-95 & 25771220; 2ND DES 15869080) [КРЫШКА] 15869080 COVER, MULTIUSE RLY & FUSE (USED ON CARS BUILT W/BLOCKS 15869077-79; 1ST DES SEE 15233126) 21997408 RELAY, FAN CONT (ЧАСТЬ OF 14) (5-TERMINAL) (SPDT, 280 MINI, HI/LOW, BLACK) (ACDelco #15-81106) 15319477 FUSE, 30AMP, PINK, J-CASE, FEMALE, REGULAR (ЧАСТЬ OF 14) [ПРЕДОХРАНИТЕЛЬ 30А] 15319478 FUSE, 40AMP, GREEN, J-CASE, FEMALE (ЧАСТЬ OF 14) (ACDelco #15319478) [ПРЕДОХРАНИТЕЛЬ 40А] 15319479 FUSE, 50 AMP, RED, J-CASE, FEMALE, REGULAR BLOW (ЧАСТЬ OF 14) 15319480 FUSE, MAXI 60 A (ЧАСТЬ OF 14) (YELLOW) (J-CASE, FEMALE) 19116060 PULLER, FUSE (ЧАСТЬ OF 14) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (MULTIUSE RLY & FUSE BRKT) [ГАЙКА М6] 25730750 BRACKET, MULTIUSE RLY & FUSE [ОПОРА ТОКОРАСПРЕДЕЛИТЕЛЬНОЙ КОРОБКИ] 11518094 БОЛТ-HES W/FL WA, M6X1X21, 11.75 THD, 24 OD, 9.8, 7114M, MACH, DOG-PT (MULTIUSE RLY & FUSE BRKT) 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (MULTIUSE RLY & FUSE BRKT) [БОЛТ М6] 15870408 BLOCK, ENG WRG HARN JUNC (INCLS 3-6, 15-17) 15870409 BLOCK, ENG WRG HARN JUNC (INCLS 3-6, 15-17) 15870410 BLOCK, ENG WRG HARN JUNC (INCLS 3-6, 15-17) 12092075 FUSE, MINI (30A) (GREEN) (ЧАСТЬ OF 14) (ACDelco #12092075) 12092079 FUSE, 10A, MINI, RED (ЧАСТЬ OF 14) 12092080 FUSE, 7.5A, MINI, BROWN (ЧАСТЬ OF 14) [КОМПЛЕКТ ПРЕДОХРАНИТЕЛЕЙ 7.5 А (5 ШТ)] 88909754 FUSE, 15A, MINI, BLUE (ЧАСТЬ OF 14) (ACDelco #ATM15-25) [ПРЕДОХРАНИТЕЛЬ 15 А] 88909755 FUSE, 20A, MINI, YELLOW (ЧАСТЬ OF 14) (ACDelco #ATM20-25) [ПРЕДОХРАНИТЕЛЬ 20 А] 12193606 RELAY, HDLP LOW BEAM (ЧАСТЬ OF 14) (BLUE) (4-TERMINAL) (SPST 280 MINI) (4.720) (ACDelco #12193606) 88953222 RELAY, FOG LP (ЧАСТЬ OF 14) (GRAY) (20AMP) (4 TERMINAL) (LOW-PROFILE MICRO 280) (ACDelco #D1755A) [РЕЛЕ] teamcadillac.ru 88953228 RELAY, HDLP WA PUMP (ЧАСТЬ OF 14) (2.485) (ACDelco #D1756A) [РЕЛЕ] 88953222 RELAY, ECM (ЧАСТЬ OF 14) (GRAY) (20AMP) (4 TERMINAL) (LOW-PROFILE MICRO 280) (2.485) (ACDelco #D1755A) [РЕЛЕ] (6E02-029) - 2004-2009 E ДАТЧИКИ ПАРКОВКИ ↓ 15210240 МОДУЛЬ, RR OBJECT ALARM [МОДУЛЬ В СБОРЕ] 10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (RR OBJECT ALARM MDL) [ПИСТОН КРЕПЛЕНИЯ ОБЛИЦОВКИ БАМПЕРА (NYLON)] 25770821 HARNESS, RR OBJECT SEN WRG [ПРОВОДКА ДАТЧИКА ЗВУКОВОЙ СИГНАЛИЗАЦИИ КОНТРОЛЯ ПАРКОВКИ] 89047028 SENSOR KIT, RR OBJECT (INCLS 6-9) (CONSIST OF BEZEL RETAINERS, RING & SENSOR) (7.831) [ДАТЧИК ЗВУКОВОЙ СИГНАЛИЗАЦИИ КОНТРОЛЯ ПАРКОВКИ] (6E02-030) - 2004-2009 E КЛЮЧ-ЦИЛИНДР-ЗАЖИГАНИЕ ↓ teamcadillac.ru 19207991 CYLINDER, IGN LK (INCLS 1-3) 19207864 КЛЮЧ, DR LK & IGN LK [КЛЮЧ ЗАМКА ДВЕРИ] 25756100 КЛЮЧ, DR LK & IGN LK VALET (UNCODED) (6E02-031) - 2006 E КРЕПЛЕНИЕ АККУМУЛЯТОРА И КАБЕЛИ (LH2/4.6A) ↓ 25747792 SHIELD, BAT HT (INSTALLED ON RH SIDE OF CAR) 11509853 БОЛТ, HEX W/CON WA, M8X1.25X45, 24 O.D., HDR PT, 9.8, PS (BAT HOLDN RET) [БОЛТ] 25558374 RETAINER, BAT HOLDN (CENTER SLOT) [ФИКСАТОР АККУМУЛЯТОРНОЙ БАТТАРЕИ] 88901964 АККУМУЛЯТОР, (CCA 650) (SIDE TERM) (260X178X168) (US DEALERS CONTACT ACDELCO WD FOR ORDERING & PRICING INFO) (ACDelco #101-6YR) (PROFESSIONAL - 6 YR) 15204281 LABEL, BAT WRNG (INCLUDES SYMBOLS ONLY) teamcadillac.ru 11518646 БОЛТ, HEX HD, W/CON WA, M6X1X30, 24.33THD, 17 OD, 9.8, 6138M, BLK (BAT TRAY) 15812692 TRAY, BAT (INCLS 8) 11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (ЧАСТЬ OF 7) [ШАЙБА] 10369851 CABLE, BAT POS (INCLS 21) (ACDelco #10369851) 21021808 ГАЙКА, STRTR SOL BAT TERM (LARGER) (M8X1.25X6, BRASS) (2.343) [ГАЙКА М8] 11504568 ГАЙКА, HEX M5X0.8 PREV TORQ INSERT 9 ZC (SMALLER) 11562004 БОЛТ, HEX W/FL WA, M10X1.5X30, 19 THD, 20 OD, 8.8, GMW3200, MACH, M-PT (BAT CBL TERM) 11515535 ГАЙКА, BAT WIRE (2.559) 15209171 CABLE, BAT NEG (INCLS 20) (ACDelco #15209171) 11589258 БОЛТ, BAT NEG CBL GND (M8X1.25X31) [БОЛТ М8] 11517031 ГАЙКА, HFH, M8X1.25, 9.4THK, 17.4 O.D., 10, TIN ZN (BAT POS CBL) 12160209 COVER, BAT NEG CBL TERM (ЧАСТЬ OF 17) (BLACK VINYL) (SURROUNDS CABLE END AT BATT SIDE TERM) 12010050 COVER, BAT POS CBL БОЛТ (ЧАСТЬ OF 10) (RED) (HAS SLOTTED HOLE) (SNAPS ON TO АККУМУЛЯТОР БОЛТ) 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (BAT TRAY) [БОЛТ М6] (6E02-032) - 2004-2006 E СИГНАЛ ↓ 25789208 СИГНАЛ, 400 & 500 HZ (INCLS 2, 3) (ACDelco #D1947F) [ЗВУКОВОЙ СИГНАЛ] teamcadillac.ru 11517103 STUD, SPL W/KNURLED SHLDR, M6X1X27, 10 THD, 13 O.D., P-PT., 9.8, 7114M (ЧАСТЬ OF 1) [ШТИФТ] 11517102 ГАЙКА, HEX FLG, M6X1X15, 19.8 OD, 9, 7111M (ЧАСТЬ OF 1) [ГАЙКА] (6E02-035) - 2005-2009 E ПЕРЕДНИЕ ФАРЫ (EXPORT TT7,TT8) ↓ 15930599 ЛАМПА, FRT SI T/SIG (INCLS 2) [УКАЗАТЕЛЬ ПОВОРОТА] 01999382 BULB, (ЧАСТЬ OF 1) (ACDelco #W5WLL) (LONGER LIFE) 25760398 SENSOR, HDLP LVLG FRT SUSP HEIGHT (9X/-3NM (S)9X/-3NM) (INTEGRAL STUD) [ДАТЧИК НАКЛОНА ПЕРЕДНЕЙ ЧАСТИ КУЗОВА] 01999382 BULB, (ЧАСТЬ OF 10) (ACDelco #W5WLL) (LONGER LIFE) 10346260 BULB, FRT FOG LP (ЧАСТЬ OF 10) (TRADE 9145) (ACDelco #9145) [ЛАМПА НАКАЛИВАНИЯ] 15896707 ЛАМПА, FRT T/SIG & FOG (INCLS 5-9, 11) teamcadillac.ru 15896708 ЛАМПА, FRT T/SIG & FOG (INCLS 5-9, 11) 11513599 ГАЙКА, U-TYPE, M4.2X1.41, 0.65-3.80 PNL THK, PZ (ЧАСТЬ OF 14) (ACDelco #11513599) 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (FRT FOG LP) [ВИНТ М4] 15915312 BRACKET, FRT PARK & T/SIG & FOG LP (INCLS 12, 39) [ОПОРА ПРОТИВОТУМАННОЙ ФАРЫ] 15915313 BRACKET, FRT PARK & T/SIG & FOG LP (INCLS 12, 39) [КРОНШТЕЙН ПЕРЕДНЕЙ ФАРЫ] 11588795 RETAINER, HDLP (PUSH ON) (FITS 9 X 16 HOLE, 1.5 THICK PANEL) [ДЕМПФЕР КРЕПЛЕНИЯ ПЕРЕДНЕЙ ФАРЫ] 25735603 BULB, HDLP (LOW BEAM) (ЧАСТЬ OF 22) (TRADE #D1S) (ACDelco #D1S) [ЛАМПОЧКА ПЕРЕДНЕЙ ФАРЫ 50 ВТ] 92184172 BULB, HDLP (HIGH BEAM) (ЧАСТЬ OF 22) (TRADE H7) (ACDelco #92184172) 01999382 BULB, (ЧАСТЬ OF 22) (ACDelco #W5WLL) (LONGER LIFE) 15926963 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 16-21, 23-27) 15930600 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 16-21, 23-27) [ПЕРЕДНЯЯ ФАРА] 25766663 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 16-21, 23-27) 25766664 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 16-21, 23-27) 25763464 BULB, FRT POSN LP (PARK FUNCTION BULB) (ЧАСТЬ OF 22) (BLUE TINT) (TRADE #W5WB50X2) (ACDelco #W5WB50X2) [ЛАМПОЧКА НАКАЛИВАНИЯ ФАРЫ 55 ВТ] 25768517 SENSOR, HDLP LVLG RR SUSP HEIGHT (INCLS 29) [ДАТЧИК ПОЛОЖЕНИЯ КУЗОВА] 25722303 HARNESS, HDLP LVLG ACTR WRG (ЧАСТЬ OF 28) 25753157 BRACKET, HDLP (INCLS 33) 11517397 ГАЙКА, HEX W/CON WA, 8X1.25, 28 O.D., 7.5 THK, 9, PEOR (FRT BPR ENGY ABS) 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (ЧАСТЬ OF 31, 38) (ACDelco #11517518) [БОЛТ] 11518497 SCREW, ASM HEX HD W/FLAT WASHER, M6X1.0X25, 14 THD, 9.8 (HDLP) 11588795 RETAINER, HDLP (PUSH ON) (FITS 9 X 16 HOLE, 1.5 THICK PANEL) [ДЕМПФЕР КРЕПЛЕНИЯ ПЕРЕДНЕЙ ФАРЫ] 11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (ЧАСТЬ OF 38) [ШАЙБА] 25753158 BRACKET, HDLP (INCLS 33, 37) [КРОНШТЕЙН В СБОРЕ] 11609459 SCREW, RND WA, M4.2X1.41X13, 7.2 THD, 11.35 OD, 6010M, GMW4205 (ЧАСТЬ OF 14) [ВИНТ] (6E02-036) - 2005-2009 E ПЕРЕДНИЕ ФАРЫ (EXC EXPORT TT7,TT8) ↓ 10346260 BULB, FRT FOG LP (ЧАСТЬ OF 7) (TRADE 9145) (ACDelco #9145) [ЛАМПА НАКАЛИВАНИЯ] 15855631 BULB, T/SIG (ЧАСТЬ OF 7) (TRADE #3457NAK-LCP) (2.880) (ACDelco #15855631) 15862271 BULB, T/SIG (ЧАСТЬ OF 7) (TRADE #3757KA) (2.880) (ACDelco #23757NAK) [ЛАМПОЧКА СИГНАЛА ПОВОРОТА, 21 ВТ] 15896707 ЛАМПА, FRT T/SIG & FOG (INCLS 2-6, 8, 37) 15896708 ЛАМПА, FRT T/SIG & FOG (INCLS 2-6, 8, 37) 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (FRT FOG LP) [ВИНТ М4] 11588795 RETAINER, HDLP (PUSH ON) (FITS 9 X 16 HOLE, 1.5 THICK PANEL) [ДЕМПФЕР КРЕПЛЕНИЯ ПЕРЕДНЕЙ ФАРЫ] 25735603 BULB, HDLP (LOW BEAM) (ЧАСТЬ OF 24) (TRADE #D1S) (ACDelco #D1S) [ЛАМПОЧКА ПЕРЕДНЕЙ ФАРЫ 50 ВТ] 92184172 BULB, HDLP (HIGH BEAM) (ЧАСТЬ OF 24, 31) (TRADE H7) (ACDelco #92184172) 01999382 BULB, (ЧАСТЬ OF 24) (ACDelco #W5WLL) (LONGER LIFE) 89024736 BALLAST, HDLP (LH AND RH) (ЧАСТЬ OF 24) 11517397 ГАЙКА, HEX W/CON WA, 8X1.25, 28 O.D., 7.5 THK, 9, PEOR (FRT BPR ENGY ABS) 25753157 BRACKET, HDLP (INCLS 22) 11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (ЧАСТЬ OF 21, 27) [БОЛТ М6] 11518497 SCREW, ASM HEX HD W/FLAT WASHER, M6X1.0X25, 14 THD, 9.8 (HDLP) 15260975 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 11-19, 29, 36) 15926960 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 11-19, 29, 36) 11518497 SCREW, ASM HEX HD W/FLAT WASHER, M6X1.0X25, 14 THD, 9.8 (HDLP) 11518121 ГАЙКА, U, M6X1, MULTI THD, .5'-4.0' THK PNL (ЧАСТЬ OF 27) 25753158 BRACKET, HDLP (INCLS 22, 26) [КРОНШТЕЙН В СБОРЕ] teamcadillac.ru 25735602 BULB, HDLP (LOW BEAM) (ЧАСТЬ OF 31) (TRADE #9006XSLL) (ACDelco #9006SXLL) [ЛАМПА НАКАЛИВАНИЯ] 01999382 BULB, (ЧАСТЬ OF 31) (ACDelco #W5WLL) (LONGER LIFE) 15926966 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 11, 12, 15, 14, 28-30, 38) 15926967 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 11, 12, 15, 14, 28-30, 38) 11588795 RETAINER, HDLP (PUSH ON) (FITS 9 X 16 HOLE, 1.5 THICK PANEL) [ДЕМПФЕР КРЕПЛЕНИЯ ПЕРЕДНЕЙ ФАРЫ] 11513599 ГАЙКА, U-TYPE, M4.2X1.41, 0.65-3.80 PNL THK, PZ (FRT T/SIG LP) (ACDelco #11513599) 15915312 BRACKET, FRT PARK & T/SIG & FOG LP [ОПОРА ПРОТИВОТУМАННОЙ ФАРЫ] 15915313 BRACKET, FRT PARK & T/SIG & FOG LP [КРОНШТЕЙН ПЕРЕДНЕЙ ФАРЫ] 11609459 SCREW, RND WA, M4.2X1.41X13, 7.2 THD, 11.35 OD, 6010M, GMW4205 (FRT FOG LP) [ВИНТ] 25763464 BULB, FRT POSN LP (PARK FUNCTION BULB) (ЧАСТЬ OF 24) (BLUE TINT) (TRADE #W5WB50X2) (ACDelco #W5WB50X2) [ЛАМПОЧКА НАКАЛИВАНИЯ ФАРЫ 55 ВТ] 19120947 SOCKET, FRT T/SIG LP (ЧАСТЬ OF 7) (ACDelco #LS234) 01999382 BULB, (ЧАСТЬ OF 31) (ACDelco #W5WLL) (LONGER LIFE) (6E02-037) - 2005-2006 E СИГНАЛИЗАЦИЯ/ANTI THEFT (UA2) ↓ 10388029 SENSOR, THEFT DTRNT [ДАТЧИК ОБЬЕМА ДЛЯ ПРОТИВОУГОННОЙ СИГНАЛИЗАЦИИ] teamcadillac.ru 90355463 SWITCH, КАПОТ AJAR IND LP (ANTI THEFT WARNING UNIT) [ДАТЧИК ОТКРЫТИЯ КАПОТА (КОНЦ. ВЫКЛЮЧАТЕЛЬ)] 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (КАПОТ AJAR IND SW BRKT) 25765686 BRACKET, КАПОТ AJAR IND LP SW 11609599 STUD, SPL, M6X1X25, 13 THD, 11 OD HD W/26 WIDE CLIP, 9.8, 6280M, P-PT (THEFT DTRNT ALARM) 25734317 SENSOR, THEFT DTRNT VEH INCLINATION [ДАТЧИК НАКЛОНА КУЗОВА] 10362943 BRACKET, THEFT DTRNT ALARM 11514517 ГАЙКА, HEX, W/CON SPR WA, M6X1, 5.7THK, 18 O.D., 9, 7111M (THEFT DTRNT ALARM) [ГАЙКА М6] 15213135 ALARM, THEFT DTRNT [ЗВУКОВОЙ СИГНАЛ (СИРЕНА) СИГНАЛИЗАЦИИ] (6E02-039) - 2005-2009 E ЗАДНИЕ ФАРЫ ↓ 25773051 WEATHERSTRIP, L/GATE UPR [БОКОВОЙ МОЛДИНГ] 11509428 БОЛТ/SCREW, HEX, W/FLAT WA, M4.2X1.4X13, 12.3 O.D., BHL PT, 6010M, NO (L/GATE APLQ) (8.977) 15211328 GASKET, HIGH MT S/LP (USED W/BEZEL 12335827) [ПРОКЛАДКА] 15211327 GASKET, HIGH MT S/LP (USED WITH BEZEL 12335827) (ON TAB SEAL-T/LP HSG S/LP (ON STUD) [ПРОКЛАДКА] 19121111 BEZEL, HIGH MT S/LP [ОКАНТОВКА ФОНАРЯ ДОПОЛНИТЕЛЬНОГО СТОП-СИГНАЛА] 15930616 ЛАМПА, HIGH MT STOP [ЗАДНИЙ ФОНАРЬ] 15213960 GASKET, HIGH MT S/LP (USED WITH BEZEL 12335827) (ON STUD) 11588650 CLIP, 12X14X16.6, GM4345M (L/GATE APLQ) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА] 25759092 GASKET, HIGH MT S/LP (38 OD X 28 ID X 9.5 THICK) [ПРОКЛАДКА МОЛДИНГА ЗАДНЕЙ ОТКИДНОЙ ДВЕРИ] 01999382 BULB, (ЧАСТЬ OF 14, 24) (ACDelco #W5WLL) (LONGER LIFE) 12450108 BULB, TRADE #3157KX (ЧАСТЬ OF 14, 24) (2.679) (ACDelco #3157KX) (LONGER LIFE KRYPTON) [ЛАМПОЧКА НАКАЛИВАНИЯ ФАРЫ 15 ВТ] 25735605 BUMPER, RR LIC PLT PKT (ЧАСТЬ OF 14, 24) (2.662) 12335850 ЛАМПА, B/U & RR LIC (W/RR LIC PLT PKT) (INCLS 10-13) (КРАСКА TO MATCH) 25936964 ЛАМПА, TAIL 25936965 ЛАМПА, TAIL 25936966 ЛАМПА, TAIL [ЗАДНИЙ ФОНАРЬ] 25936967 ЛАМПА, TAIL [ЗАДНИЙ ФОНАРЬ] 25736754 RETAINER, T/LP (PUSH IN) (14 X 21MM HEAD) 11519918 RETAINER, T/LP (PUSH IN) (16MM ROUND HEAD) (2.664) [ФИКСАТОР ЗАДНЕГО ФОНАРЯ] 11517736 ГАЙКА, HEX, M6X1, 5.7 HIGH, 24 OD, 9, 7111M, W/2.5 THK SEALING WA (T/LP) [ГАЙКА М6] 11514517 ГАЙКА, HEX, W/CON SPR WA, M6X1, 5.7THK, 18 O.D., 9, 7111M (B/U & RR LIC PLT LP) [ГАЙКА М6] 11517230 БОЛТ, TORX, W/WA, W/ADH, M6X1X20, 16.2 O.D., DOG PT, 10.9, GM6138M (L/GATE UPR SI APLQ) [ВИНТ ЗАМКА ДВЕРИ М6] 89025118 GASKET, HIGH MT S/LP 15842691 HARNESS, L/GATE LK & R/WDO DEFG & R/WDO WPR WRG teamcadillac.ru 15842692 HARNESS, L/GATE LK & R/WDO DEFG & R/WDO WPR WRG 12335851 ЛАМПА, B/U & RR FOG & RR LIC PLT (INCLS 10, 12, 13, 25, 26) (КРАСКА TO MATCH) (2.697) [ЛАМПА] 12450108 BULB, TRADE #3157KX (RR FOG LP) (ЧАСТЬ OF 24) (2.679) (ACDelco #3157KX) (LONGER LIFE KRYPTON) [ЛАМПОЧКА НАКАЛИВАНИЯ ФАРЫ 15 ВТ] (6E02-040) - 2006 E КРЕПЛЕНИЕ АККУМУЛЯТОРА И КАБЕЛИ (LY7/3.6-7) ↓ 25747792 SHIELD, BAT HT (INSTALLED ON RH SIDE OF CAR) 11509853 БОЛТ, HEX W/CON WA, M8X1.25X45, 24 O.D., HDR PT, 9.8, PS (BAT HOLDN RET) [БОЛТ] 25558374 RETAINER, BAT HOLDN (CENTER SLOT) [ФИКСАТОР АККУМУЛЯТОРНОЙ БАТТАРЕИ] 88901964 АККУМУЛЯТОР, (CCA 650) (SIDE TERM) (260X178X168) (US DEALERS CONTACT ACDELCO WD FOR ORDERING & PRICING INFO) (ACDelco #101-6YR) (PROFESSIONAL - 6 YR) 15204281 LABEL, BAT WRNG (INCLUDES SYMBOLS ONLY) 11518646 БОЛТ, HEX HD, W/CON WA, M6X1X30, 24.33THD, 17 OD, 9.8, 6138M, BLK (BAT TRAY) teamcadillac.ru 15812692 TRAY, BAT (INCLS 8) 11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (ЧАСТЬ OF 7) [ШАЙБА] 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (BAT TRAY) [БОЛТ М6] 15889973 CABLE, BAT NEG (ACDelco #15889973) 21021808 ГАЙКА, STRTR SOL BAT TERM (LARGER) (M8X1.25X6, BRASS) (2.343) [ГАЙКА М8] 25785031 CABLE, BAT POS (ACDelco #25785031) 11515535 ГАЙКА, BAT WIRE (2.559) 11517031 ГАЙКА, HFH, M8X1.25, 9.4THK, 17.4 O.D., 10, TIN ZN (BAT POS CBL) 11589258 БОЛТ, BAT NEG CBL GND (M8X1.25X31) [БОЛТ М8] 11517274 STUD, HFH M8X1.25X20, M10X1.5X25, 22.3 OD, 9.8, 6280M. (BAT CBL TERM) (6M02-029) - 2004-2009 E ЖГУТЫ ПРОВОДОВ/ДВИГАТЕЛЬНЫЙ ОТСЕК (LY7/3.6-7) ↓ 10369376 HARNESS, ENG WRG 10369377 HARNESS, ENG WRG 11562004 БОЛТ, HEX W/FL WA, M10X1.5X30, 19 THD, 20 OD, 8.8, GMW3200, MACH, M-PT (ENG WRG HARN SUPT) teamcadillac.ru 15870408 BLOCK, ENG WRG HARN JUNC 15870409 BLOCK, ENG WRG HARN JUNC 15870410 BLOCK, ENG WRG HARN JUNC 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ENG WRG HARN OXY SEN LEAD BRKT) 12589726 BRACKET, ENG WRG HARN OXY SEN LEAD (HOLD POST SENSOR CONN "POSITION 2 CONNECTOR" ЗАДНИЙ) (6M02-036) - 2004-2006 E КРЕПЛЕНИЕ СТАРТЕРА (LY7/3.6-7) ↓ 12598756 STARTER, (MAIN АККУМУЛЯТОР TERMINALS AT 6 & 12 O'CLOCK) (ACDelco #12598756) 12608653 STARTER, (MAIN АККУМУЛЯТОР TERMINALS AT 1 & 7 O'CLOCK) (ACDelco #12608653) 11518626 БОЛТ, HFH, M10X1.5X40, 28.7 THD, 22.3 OD, 10.9, GMW3359, 7.5MM MAT POINT (STRTR) (6M02-038) - 2004-2009 E ЖГУТЫ ПРОВОДОВ/ДВИГАТЕЛЬ В СБОРЕ (LY7/3.6-7) ↓ 10369376 HARNESS, ENG WRG 10369377 HARNESS, ENG WRG 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ENG WRG HARN) 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (ECM) [БОЛТ] 24574534 STUD, ENG WRG HARN BRKT (M6X1X20) (1.166) 11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (ECM BRKT) [БОЛТ] teamcadillac.ru 12585357 BRACKET, ENG WRG HARN OXY SEN LEAD (HOLDS THE PRE SENSOR CONNECTOR "POSITION 1 CONN") 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (WRG HARN BRKT) (6Y02-018) - 2006-2009 E РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ & МОДУЛЬ/ЗАЖИГАНИЕ (LH2/4.6A) ↓ teamcadillac.ru 12594176 РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ, IGN (INCLS 705) (ACDelco #D596A) (IF MARKED 12602862 USE 12594176, FOR 1ST DES SEE 89017778) 89017778 РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ, IGN (INCLS 705) (ACDelco #D593A) (РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯS 12585765 USE QTY 2 89017778, FOR 2ND DES SEE 12594176) [КАТУШКА ЗАЖИГАНИЯ] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 704) 12602860 HARNESS, IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ WRG 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ) 11588967 STUD, BALL W/HFH, M6X1X20.65, 14.2 O.D., 8.8, GMW3359 (IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ) 89018106 BRACKET, IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ (ACDelco #89018106) 03 - ТОПЛИВНАЯ СИСТЕМА - ВЫХЛОПНАЯ - СИСТЕМА ВЫПУСКА ВОЗДУХА ↓ (6E03-009) - 2004-2006 E АКСЕЛЕРАТОР (EXC JF4) ↓ 15263218 PEDAL, ACCEL (INCLS 2, 3) [ПЕДАЛЬ ГАЗА] 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (ACCEL PED LVR) (6E03-010) - 2004-2006 E АКСЕЛЕРАТОР (JF4) ↓ 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (ACCEL PED LVR) 15861029 PEDAL, ACCEL (INCLS 3, 4) (INCLS SENSOR) teamcadillac.ru 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 89047780 MOTOR KIT, BRK & ACCEL PED ADJR ACTR (INCLS 9) [ЭЛЕКТРОДВИГАТЕЛЬ ПЕДАЛЬНОГО УЗЛА 19 ВТ] 89047778 CABLE, BRK PED ADJR ACTR [ЖГУТ ПРОВОДОВ] 89047779 CABLE, ACCEL CONT (6E03-011) - 2004-2006 E СИСТЕМА ВПУСКА ВОЗДУХА (LH2/4.6A) ↓ 25798271 ELEMENT, КОНДИЦИОНЕРL (ACDelco #A2944C) [ВОЗДУШНЫЙ ФИЛЬТР ДВИГАТЕЛЯ] 19151529 COVER, КОНДИЦИОНЕРL HSG LWR (INCLS 4) [КРЫШКА ВОЗДУХОЗАБОРНИКА] 11588831 SCREW, HEX W/ CON WA, M6X1X35, 33.5 THD, 17 O.D.HDR PT, 9.8, BLK (КОНДИЦИОНЕРL) 19177871 INSULATOR, КОНДИЦИОНЕРL HSG (MOUNT TO MID RAIL) 11561910 БОЛТ, КОНДИЦИОНЕРL (M6X1.0X24) (T30 TORQ) (SHLDR W/FL WA) 88967332 БОЛТ, КОНДИЦИОНЕРL (30.7MM) 19177871 INSULATOR, КОНДИЦИОНЕРL HSG (MOUNT TO MID RAIL) 25744215 DUCT, RR INT AIR (W/RESO) (INCLS 9) [ТРУБКА ВОЗДУХОПРОВОДА] 12567377 SENSOR, MASS AIRFLOW (INCLS 11) (ACDelco #213-1594) [ДАТЧИК РАСХОДА ВОЗДУХА] 15147461 GASKET, MASS AIRFLOW SEN (ROUND) 15813321 GASKET, MASS AIRFLOW SEN (RECTANGULAR) (GASKET IS POA TO MAF SENSOR) 25314060 БОЛТ, M6X1X30, 11 THD, 12.5 OD, 4.8, 6047M, P-PT (КОНДИЦИОНЕРL HSG CVR) teamcadillac.ru 15147459 COVER, КОНДИЦИОНЕРL HSG [КРЫШКА ВОЗДУХООЧИСТИТЕЛЯ] (6E03-011) - 2004-2006 E СИСТЕМА ВПУСКА ВОЗДУХА (LY7/3.6-7) ↓ 25798271 ELEMENT, КОНДИЦИОНЕРL (ACDelco #A2944C) [ВОЗДУШНЫЙ ФИЛЬТР ДВИГАТЕЛЯ] 19151528 COVER, КОНДИЦИОНЕРL HSG LWR (INCLS 4) [КРЫШКА ВОЗДУХООЧИСТИТЕЛЯ] teamcadillac.ru 11588831 SCREW, HEX W/ CON WA, M6X1X35, 33.5 THD, 17 O.D.HDR PT, 9.8, BLK (КОНДИЦИОНЕРL) 15744944 INSULATOR, КОНДИЦИОНЕРL HSG (ЧАСТЬ INCLUDES RUBBER INSULATOR AND METAL SPACER) 19177871 INSULATOR, КОНДИЦИОНЕРL HSG (MOUNT TO MID RAIL) 25733251 DUCT, RR INT AIR (W/RESO) (INCLS 9) 88967332 БОЛТ, MASS AIRFLOW SEN (ЧАСТЬ OF 12) (30.7MM) (3.403) 12566846 SENSOR, MASS AIRFLOW (INCLS 11) (ACDelco #213-1593) [ДАТЧИК] 15147456 GASKET, MASS AIRFLOW SEN 25314060 БОЛТ, M6X1X30, 11 THD, 12.5 OD, 4.8, 6047M, P-PT (КОНДИЦИОНЕРL HSG CVR) 15147455 COVER, КОНДИЦИОНЕРL HSG [КРЫШКА ВОЗДУШНОГО ФИЛЬТРА] (6E03-012) - 2004-2009 E ТОПЛИВНЫЙ БАК & КРЕПЛЕНИЕ ↓ 25862765 CAP, F/TNK FIL LK (0.1KGS) (ACDelco #GT264) [КРЫШКА ТОПЛИВОНАЛИВНОЙ ГОРЛОВИНЫ] 15775325 DOOR, F/TNK FIL (INCLS 6) 11509374 БОЛТ, SCR HEX W/FL WA, SELF TAP, 4.2X1.41X16, 12.5 O.D. (F/TNK FIL PIPE) 25773939 ШЛАНГИ, F/TNK FIL PIPE [КОЖУХ ТОПЛИВОЗАЛИВНОЙ ГОРЛОВИНЫ] 89047657 BUMPER, F/TNK FIL DR (ЧАСТЬ OF 3) (HINGE) [ВТУЛКА] 11609731 RIVET, F/TNK FIL DR (25" SHANK, .63 LEN, .50 OD, .06-.30 GRP RNG, 1008 STL, GMW3044) (8.967) 15868848 PIPE, F/TNK FIL (INCLS 9, 10, 15, 19, 20) [ТРУБКА ТОПЛИВОЗАЛИВНОЙ ГОРЛОВИНЫ] 01470030 CЛАМПА, WORM TYPE (11/16" TO 1 5/16") (ЧАСТЬ OF 8) (ACDelco #1470030) 09177063 CЛАМПА, F/TNK FIL HOSE (ЧАСТЬ OF 12) (25-40MM CЛАМПА RANGE) 15925741 HOSE, F/TNK FIL (INCLS 11) [ШЛАНГ ТОПЛИВНОЙ СИСТЕМЫ] 09177063 CЛАМПА, F/TNK FIL HOSE (25-40MM CЛАМПА RANGE) 11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (F/TNK FIL PIPE BRKT) [БОЛТ М8] 15638098 RETAINER, FUEL RTN PIPE FTG (ЧАСТЬ OF 8) (NATURAL) (NYLON) (5/16") (7.9MM) 11517101 БОЛТ, METRIC HEX FLANGE HD, M10X1.5X50 (F/TNK STRP) [БОЛТ М10] 25679207 STRAP, F/TNK [ЗАЖИМ БЕНЗОБАКА] teamcadillac.ru 12337820 STRAP, 15" TIE STRAP (ЧАСТЬ OF 8) (ACDelco #12337820) 25880365 ПРУЖИНА, F/TNK FIL DR (PRIOR TO INSTALL SEAL VOIDS IN PLUNGER HSG W/FLEXIABLE SEALER) [ЗАЩЕЛКА ЛЮЧКА ТОПЛИВНОЙ ГОРЛОВИНЫ] (6E03-013) - 2004-2009 E СИСТЕМА ТОПЛИВОСНАБЖЕНИЯ (LH2/4.6A) ↓ 15924706 HARNESS, FUEL SDR WRG (3.115) 88965813 SENDER KIT, FUEL (INCLS 24) (FOR AUXILARY МОДУЛЬ) (ACDelco #MU1579) 19177355 CANISTER, EVAP EMIS (CANISTER WITHOUT COVER OR FILTER) (INCLS 39, 43) (ACDelco #215-644) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (EVAP EMIS CNSTR BRKT) [ГАЙКА М6] 15278918 PIPE, EVAP EMIS CNSTR PURGE 15219486 PIPE, FUEL FEED RR (INCLS 35) 15219484 PIPE, FUEL RTN RR 22514722 SEAL, FUEL FEED FRT PIPE (O RING) (ЧАСТЬ OF PIPE, FEED & RTN ASM BUNDLE) (7.35MM ID X 1.66MM THK) (ACDelco #217-452) [КОЛЬЦО УПЛОТНИТЕЛЬНОЕ, ТОПЛИВНОЙ ТРУБКИ] 25763176 ФИЛЬТР, FUEL (ACDelco #GF897) [ТОПЛИВНЫЙ ФИЛЬТР] 11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (FUEL FLTR BRKT) [БОЛТ М8] 25701014 RETAINER, FUEL FLTR 25688547 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (RETAINER W/5 HOLES (2)7.95, (2)4.76, (1)9.52MM) 15270078 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (USES RETAINER PIN FOR ATTACHMENT) [ЗАЖИМ ТРУБКИ ТОПЛИВНОЙ СИСТЕМЫ] 25917777 PIPE, EVAP EMIS CNSTR PURGE teamcadillac.ru 10360402 PIPE, FUEL FEED (INCLS 19) [ТРУБКА ТОПЛИВНОЙ СИСТЕМЫ, СТАЛЬ] 25917776 PIPE, FUEL FEED (INCLS 19) 25761218 BRACKET, FUEL PIPE 25761217 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (3.162) 25765594 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (42.10MM LENGTH) (3.162) [ФИКСАТОР ТОРМОЗНЫХ ТРУБОК] 25679213 PIN, F/TNK UPR SHLD 25679209 SHIELD, F/TNK 25894460 TANK, FUEL (INCLS 21, 26, 27, 31, 33, 34) [ТОПЛИВНЫЙ БАК] 25901272 SEAL, FUEL SDR (ЧАСТЬ OF 2, 28, 44) (ACDelco #G37) 25740096 CAM, FUEL SDR (ACDelco #TR23) 19181827 МОДУЛЬ KIT, F/TNK F/PMP (W/O FUEL LVL SEN) (INCLS 24) (ACDelco #M10201) [ТОПЛИВНЫЙ НАСОС] 25679252 RETAINER, FUEL FEED & EVAP EMIS & RTN FRT PIPE (HOLDS 15.8/7.95/7.0 TUBES, HAS CHRISTMAS TREE RETAINER) (3.162) 15951521 PIPE, FUEL SDR FUEL FEED (INCLS CONN) (PIPE ATTACHES TO SENDING UNITS INSIDE OF GAS TANK) [ТРУБКА ТОПЛИВНОЙ СИСТЕМЫ] 16238399 SENSOR, F/TNK PRESS (ACDelco #16238399) [ДАТЧИК ДАВЛЕНИЯ ПАРОВ ТОПЛИВА] 25726788 RETAINER, BRK & FUEL PIPE (SQUARE HEAD PUSH PIN W/5 HOLES (2)4.76. (2)8.00 (1)9.52) [ФИКСАТОР ТОРМОЗНЫХ ТРУБОК] 25751324 RETAINER, FUEL FEED & EVAP EMIS & RTN FRT PIPE (HOLDS 7.95 & 9.5 DIA FUEL LINE, HAS CHRISTMAS TREE RETAINER) (3.162) 17114722 HOSE, EVAP EMIS CNSTR AIR INL (3.130) (ACDelco #219-366) 17114723 COVER, EVAP EMIS CNSTR AIR INL OPG (ЧАСТЬ OF 3) 19177365 FILTER KIT, EVAP EMIS CNSTR (W/ SEAL) (INCLS 40) 25932573 VALVE, EVAP EMIS CNSTR VENT SOL (ACDelco #214-2230) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 88967139 SENSOR KIT, FUEL LVL (PRIMARY) (INCLS 24) (ACDelco #SK1161) [ТОПЛИВНЫЙ НАСОС] (6E03-014) - 2004-2006 E РАМКА ТОПЛИВНОГО ИНЖЕКТОРА (LH2/4.6A) ↓ 12580644 RAIL, SEQ M/PORT F/INJN FUEL (INCLS 580, 581) (ACDelco #217-1556) teamcadillac.ru 25532662 CAP, FUEL PRESS SERV VLV (ЧАСТЬ OF 566) (CAP FOR PRESSURE TEST SCHRADER VALVE) (3.163) (ACDelco #214-1044) [КРЫШКА] 12580648 VALVE KIT, FUEL PRESS SERV (INCLS 565) (ACDelco #12580648) 12580645 INJECTOR KIT, SEQ M/PORT FUEL (INCLS 561-564) (INCLS 1 INJECTOR, UPR AND LWR SEAL RINGS & RET) (ACDelco #217-1553) [ИНЖЕКТОР] 12580646 RETAINER KIT, F/INJR (INCLS 562) (INCLS 8 INJECTOR RET CLIPS) (ACDelco #12580646) 12580647 SEAL KIT, F/INJR (O RING) (INCLS 563, 564) (INCLS 8 UPR INJECTOR O-RINGS & 8 LWR INJECTOR O-RINGS) (ACDelco #217-1555) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО] (6E03-015) - 2004-2006 E БЛОК ЭЛЕКТРОННОГО УПРАВЛЕНИЯ И СВЯЗАННЫЕ ДЕТАЛИ (LH2/4.6A) ↓ 12576523 МОДУЛЬ, ENG CONT (REQUIRES PROGRAMMING) (ACDelco #12576523) [БЛОК УПРАВЛЕНИЯ ДВИГАТЕЛЕМ] 25730751 BRACKET, ECM BRKT 11518646 БОЛТ, HEX HD, W/CON WA, M6X1X30, 24.33THD, 17 OD, 9.8, 6138M, BLK (ECM BRKT) teamcadillac.ru 11514517 ГАЙКА, HEX, W/CON SPR WA, M6X1, 5.7THK, 18 O.D., 9, 7111M (ECM WRG HARN BRKT) [ГАЙКА М6] (6E03-016) - 2004-2006 E СИСТЕМА ОТРАБОТАВШИХ ГАЗОВ (LH2/4.6A) ↓ 12575657 SENSOR, HTD OXY (POSN 1) (IN EXH MANIFOLD/CROSSOVER) (ACDelco #213-1572) [ДАТЧИК] 12597912 SENSOR, HTD OXY (POSN 1) (IN EXH MANIFOLD/CROSSOVER) (ACDelco #213-3863) [КИСЛОРОДНЫЙ ДАТЧИК] 15240254 BRACKET, EXH TAIL PIPE HNGR (INCLS 3) [КРОНШТЕЙН] 25902027 BRACKET, EXH TAIL PIPE HNGR (INCLS 3) 15284207 INSULATOR, EXH TAIL PIPE HNGR (ЧАСТЬ OF 2) [ДЕМПФЕР ГЛУШИТЕЛЯ] 15251184 PIPE, EXH TAIL (ЧАСТЬ OF 6) (3.701) 25711603 INSULATOR, EXH MUFF HNGR BRKT (ЧАСТЬ OF 6) 15290902 MUFFLER, EXH (W/RESO, EXH & TAIL PIPE) (INCLS 4, 5) 11517031 ГАЙКА, HFH, M8X1.25, 9.4THK, 17.4 O.D., 10, TIN ZN (EXH MUFF) 12590035 SENSOR, HTD OXY (POSN 3) (POST CONVERTER) (ACDelco #213-2823) [ДАТЧИК] teamcadillac.ru 25709703 SEAL, CTLTC CONV (ЧАСТЬ OF 11) (ROUND METAL SEAL) [ПРОКЛАДКА НАСОСА] 11609596 STUD, CTLTC CONV (ЧАСТЬ OF 11) [ШПИЛЬКА] 12567687 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 9, 10) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 12567688 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 9, 10) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] (6E03-017) - 2004-2009 E СИСТЕМА ТОПЛИВОСНАБЖЕНИЯ (LY7/3.6-7) ↓ 15924706 HARNESS, FUEL SDR WRG (3.115) 88965813 SENDER KIT, FUEL (INCLS 24) (FOR AUXILARY МОДУЛЬ) (ACDelco #MU1579) 19177355 CANISTER, EVAP EMIS (CANISTER WITHOUT COVER OR FILTER) (INCLS 46) (ACDelco #215-644) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (EVAP EMIS CNSTR BRKT) [ГАЙКА М6] 15278918 PIPE, EVAP EMIS CNSTR PURGE 15219486 PIPE, FUEL FEED RR (INCLS 35) 15219484 PIPE, FUEL RTN RR 22514722 SEAL, FUEL FEED FRT PIPE (O RING) (ЧАСТЬ OF PIPE, FEED & RTN ASM BUNDLE) (7.35MM ID X 1.66MM THK) (ЧАСТЬ OF 15) (ACDelco #217-452) [КОЛЬЦО УПЛОТНИТЕЛЬНОЕ, ТОПЛИВНОЙ ТРУБКИ] 25763176 ФИЛЬТР, FUEL (ACDelco #GF897) [ТОПЛИВНЫЙ ФИЛЬТР] 11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (FUEL FLTR BRKT) [БОЛТ М8] 25701014 RETAINER, FUEL FLTR 25688547 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (RETAINER W/5 HOLES (2)7.95, (2)4.76, (1)9.52MM) 25749839 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (HOLDS 3 ТРУБКИ, FLAT SHAPE, SNAP-IN RETAINER) 15888146 PIPE, EVAP EMIS CNSTR PURGE (INCLS 37, 39) 15145717 PIPE, FUEL FEED (INCLS 8, 19) 25761218 BRACKET, FUEL PIPE 25761217 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (3.162) 25679252 RETAINER, FUEL FEED & EVAP EMIS & RTN FRT PIPE (HOLDS 15.8/7.95/7.0 TUBES, HAS CHRISTMAS TREE RETAINER) (3.162) 25679213 PIN, F/TNK UPR SHLD 25679209 SHIELD, F/TNK 25894460 TANK, FUEL (INCLS 21, 26, 27, 31, 33, 34) [ТОПЛИВНЫЙ БАК] teamcadillac.ru 25901272 SEAL, FUEL SDR (ЧАСТЬ OF 2, 28, 47) (ACDelco #G37) 25740096 CAM, FUEL SDR (ACDelco #TR23) 19181827 МОДУЛЬ KIT, F/TNK F/PMP (W/O FUEL LVL SEN) (INCLS 24) (ACDelco #M10201) [ТОПЛИВНЫЙ НАСОС] 25679252 RETAINER, FUEL FEED & EVAP EMIS & RTN FRT PIPE (HOLDS 15.8/7.95/7.0 TUBES, HAS CHRISTMAS TREE RETAINER) (3.162) 15951521 PIPE, FUEL SDR FUEL FEED (INCLS CONN) (PIPE ATTACHES TO SENDING UNITS INSIDE OF GAS TANK) [ТРУБКА ТОПЛИВНОЙ СИСТЕМЫ] 16238399 SENSOR, F/TNK PRESS (ACDelco #16238399) [ДАТЧИК ДАВЛЕНИЯ ПАРОВ ТОПЛИВА] 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (FUEL FEED & EVAP EMIS & RTN PIPE CLIP BRKT) [БОЛТ М6] 25654373 CLIP, FUEL FEED & RTN HOSE (PLASTIC) (ЧАСТЬ OF FUEL & BRAKELINE BUNDLE НИЖНЯЯ ЧАСТЬ; POSITION 2, 4, 5) 25726788 RETAINER, BRK & FUEL PIPE (SQUARE HEAD PUSH PIN W/5 HOLES (2)4.76. (2)8.00 (1)9.52) [ФИКСАТОР ТОРМОЗНЫХ ТРУБОК] 17114722 HOSE, EVAP EMIS CNSTR AIR INL (3.130) (ACDelco #219-366) 17114723 COVER, EVAP EMIS CNSTR AIR INL OPG (ЧАСТЬ OF 44) 19177365 FILTER KIT, EVAP EMIS CNSTR (W/ SEAL) (INCLS 42, 43) 25932573 VALVE, EVAP EMIS CNSTR VENT SOL (ACDelco #214-2230) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 88967139 SENSOR KIT, FUEL LVL (PRIMARY) (INCLS 24) (ACDelco #SK1161) [ТОПЛИВНЫЙ НАСОС] (6E03-018) - 2004-2007 E СИСТЕМА ОТРАБОТАВШИХ ГАЗОВ (LY7/3.6-7) ↓ 15240254 BRACKET, EXH TAIL PIPE HNGR (INCLS 2) [КРОНШТЕЙН] 25902027 BRACKET, EXH TAIL PIPE HNGR (INCLS 2) 15284207 INSULATOR, EXH TAIL PIPE HNGR (ЧАСТЬ OF 1) [ДЕМПФЕР ГЛУШИТЕЛЯ] 25711603 INSULATOR, EXH MUFF HNGR BRKT (ЧАСТЬ OF 5) 15251183 PIPE, EXH TAIL (ЧАСТЬ OF 5) 15233284 MUFFLER, EXH (W/RESO, EXH & TAIL PIPE) (INCLS 3, 4) teamcadillac.ru 15290901 MUFFLER, EXH (W/RESO, EXH & TAIL PIPE) (INCLS 3, 4) 11517031 ГАЙКА, HFH, M8X1.25, 9.4THK, 17.4 O.D., 10, TIN ZN (EXH MUFF) 12590035 SENSOR, HTD OXY (POSN 3) (POST CONVERTER) (ACDelco #213-2823) [ДАТЧИК] 25768055 SEAL, CTLTC CONV (ЧАСТЬ OF 9) (SEAL WITH COVER ATTACHED) [УПЛОТНЕНИЕ КАТАЛИТИЧЕСКОГО НЕЙТРАЛИЗАТОРА] 12622977 CONVERTER, 3WAY CTLTC (INCLS 8, 10, 12, 13) [КАТАЛИТИЧЕСКИЙ НЕЙТРАЛИЗАТОР ВЫХЛОПНЫХ ГАЗОВ] 12622978 CONVERTER, 3WAY CTLTC (INCLS 8, 10, 12, 13) [КАТАЛИТИЧЕСКИЙ НЕЙТРАЛИЗАТОР ВЫХЛОПНЫХ ГАЗОВ] 11609596 STUD, CTLTC CONV (ЧАСТЬ OF 9) [ШПИЛЬКА] 12596327 SENSOR, HTD OXY (POSN 1) (IN EXH MANIFOLD/CROSSOVER) (ACDelco #213-3240) (W/OVAL SHAPED CONNECTOR) [КИСЛОРОДНЫЙ ДАТЧИК] 11589264 STUD, STRAIGHT, M10X1.5X30, M10X1.5X16, 57 TL, SS (ЧАСТЬ OF 9) [ШПИЛЬКА М8] 12571101 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 12571102 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 15709703 ГАЙКА, HEX 10X1.5THD, 21.8 OD SS (CTLTC CONV) [ГАЙКА М10] (6M03-085) - 2004-2006 E БЛОК ЭЛЕКТРОННОГО УПРАВЛЕНИЯ И СВЯЗАННЫЕ ДЕТАЛИ (LY7/3.6-7) ↓ teamcadillac.ru 12600071 BRACKET, ECM (INCLS 8, 10) 12592124 МОДУЛЬ, ENG CONT (REQUIRES PROGRAMMING) (ACDelco #12592124) 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (ECM) [БОЛТ] 11562004 БОЛТ, HEX W/FL WA, M10X1.5X30, 19 THD, 20 OD, 8.8, GMW3200, MACH, M-PT (ECM GND STRP) 11519861 БОЛТ, HEX W/FL WA, M10X1.5X30, 19 THD, 20 OD, 9.8, 6280M, MACH, MAT-PT (ECM GND STRP) [БОЛТ М10] 11519172 БОЛТ, HFH, 8X1.25X55, 18 OD, 22THD, 8.8, GMW3359, 6MM MATPOINT, REDUCED BODY (ЧАСТЬ OF 1) 11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (ECM BRKT) [БОЛТ] 11588523 STUD, M6X1 (ЧАСТЬ OF 1) (6M03-088) - 2004-2009 E РАМКА ТОПЛИВНОГО ИНЖЕКТОРА (LY7/3.6-7) ↓ 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (WRG HARN BRKT) teamcadillac.ru 12596182 HARNESS, F/INJR WRG (INCLS 2) (IF REPL 12584312 MAY NEED TO INSTALL BRACKET FROM HARNESS.) 25532662 CAP, FUEL PRESS SERV VLV (CAP FOR PRESSURE TEST SCHRADER VALVE) (*KIT2) (3.163) (ACDelco #214-1044) [КРЫШКА] 12572886 RAIL, F/INJN FUEL (INCLS 5, 9) (ACDelco #217-1551) [МАГИСТРАЛЬ ТОПЛИВНЫХ ФОРСУНОК ДВИГАТЕЛЯ] 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (F/INJN FUEL RL) [БОЛТ] 12571159 INJECTOR, M/PORT FUEL (INCLS 8, 11) (ACDelco #217-1552) [ИНЖЕКТОР] 12576479 SEAL KIT, M/PORT F/INJR (INCLS 8, 11) (ACDelco #217-1541) [КОМПЛЕКТ ПРОКЛАДОК ИНЖЕКТОРНОЙ ФОРСУНКИ (2 ШТ] 12584592 VALVE KIT, FUEL PRESS SERV (INCLS 4, 5) (INCLUDES CAP AND VALVE) (ACDelco #12584592) [КЛАПАН] 12584591 RETAINER KIT, F/INJR (INCLS 9) (ACDelco #12584591) [ОПОРНАЯ ПЛАСТИНА ТОПЛИВНОЙ ФОРСУНКИ] 04 - АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ↓ (6D04-023) - 2004-2009 E СТОЯНОЧНЫЙ ТОРМОЗ ASM ↓ 88951984 PLATE, RR PARK BRK ANC BKG (4.591) 88951985 PLATE, RR PARK BRK ANC BKG (4.591) 88951982 ACTUATOR KIT, RR PARK BRK (INCLS 2) (ACDelco #179-2053) [АКТУАТОР] teamcadillac.ru 88951983 ACTUATOR KIT, RR PARK BRK (INCLS 2) (ACDelco #179-2054) [АКТУАТОР] 89047676 SHOE KIT, RR PARK BRK (INCLS 5) (ACDelco #171-0915) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (2 ШТ)] (6D04-031) - 2004-2009 E ТОРМОЗНОЙ СУППОРТ-ЗАДНИЙ ↓ 89047677 CALIPER KIT, RR BRK (INCLS 2, 3, 7-9) (ACDelco #172-2343) 89047678 CALIPER KIT, RR BRK (INCLS 2, 3, 7-9) (ACDelco #172-2344) [ТОРМОЗНОЙ СУППОРТ] 88951992 CAP, RR BRK BLEDR VLV (ЧАСТЬ OF 1) 88951991 VALVE, RR BRK CLPR BLEDR (ЧАСТЬ OF 1) teamcadillac.ru 89047757 PAD KIT, RR DISC BRK (INCLS 4, 12) (ACDelco #171-859) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4 ШТ)] 89047758 PAD KIT, RR DISC BRK (INCLS 4, 12) (4.667) (ACDelco #171-0906) [ТОРМОЗНЫЕ КОЛОДКИ] 88957163 BRACKET, RR BRK CLPR [СКОБА ТОРМОЗНОГО СУППОРТА] 89047759 PIN KIT, RR BRK CLPR GDE (INCLS 4-6) (INCLS 2 PINS, 2 SEALS & 2 (2.75") БОЛТS) (ACDelco #179-2044) [НАПРАВЛЯЮЩАЯ ТОРМОЗНОГО СУППОРТА (2 ШТ)] 88957162 REPAIR KIT, RR BRK CLPR HYD (INCLS 4, 6, 8, 9) (6D04-033) - 2004-2009 E ТОРМОЗНОЙ УСИЛИТЕЛЬ ↓ teamcadillac.ru 88967237 BOOSTER, P/B (W/O VLV) (ACDelco #178-0695) 05461808 GROMMET, P/B BOOS VAC CHK VLV (*KIT1) 03817880 RETAINER, BRK PED PUSH ROD (0.80 IN) (PUSH IN) 18022219 VALVE KIT, P/B BOOS VAC CHK (INCLS 2, 3) (BLACK) (INCLS VLV & GROM) (ACDelco #179-1266) (6D04-067) - 2006-2009 E КОРПУС КП КРЕПЛЕНИЕ (MX5) ↓ teamcadillac.ru 24231525 GASKET, TRFER CASE 19132968 CASE, TRFER (W/GEARS) (LESS DAMPENER) (UNITS BUILT ON 3-22-06 & AFTER) (FOR 1ST DES SEE 24234010) 24234010 CASE, TRFER (W/GEARS) (UNITS BUILT ON 3-21-06 & PRIOR) (FOR 2ND DES SEE 24238468) 11589341 БОЛТ - HFH, M10X1.5X69.9, 28.35 THD, 22.3 OD, 10.9, GMW3359, M-PT. (TRFER CASE) [БОЛТ] (6D04-068) - 2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (LY7/3.6-7, EXC V92)(WITH INTERNAL COOLER)(2ND DES) ↓ 19129976 HOSE, TRANS FLUID CLR LWR (W/BLOCK) (INCLS 7) (WITH TRANS OIL COOLER IN РАДИАТОР. FOR 1ST DES SEE 19129781.) teamcadillac.ru 11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16] 89022494 BRACKET, TRANS FLUID CLR 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 25740416 SEAL, TRANS FLUID CLR PIPE (O RING) (1/2IN) (9.222) (ACDelco #15-31872) [ПРОКЛАДКА КОМПРЕССОРА КОНДИЦИОНЕРА] 19129977 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) (WITH TRANS OIL COOLER IN РАДИАТОР. FOR 1ST DES SEE 19129782.) (6E00-014) - 2004-2009 E ТРАНСМИССИЯ TO КРЕПЛЕНИЕ ДВИГАТЕЛЯ (LY7/3.6-7) ↓ 12572042 PLATE, A/TRNS FLEX teamcadillac.ru 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (TRANS CVR) [БОЛТ] 24222918 COVER, TRANS CONV 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] (6E04-003) - 2004-2006 E УПРАВЛЕНИЕ АКПП/АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22,M82) ↓ 19121866 KNOB PKG, A/TRNS CONT LVR (INCLS 2, 13) (CASHMERE) 88967336 KNOB PKG, A/TRNS CONT LVR (INCLS 2, 13) (EBONY/BURL WALNUT) 88967337 KNOB PKG, A/TRNS CONT LVR (INCLS 2, 13) (EBONY LEATHER) 88967339 БОЛТ, A/TRNS CONT LVR KNOB (ЧАСТЬ OF 1) 25772994 PLATE, F/FLR CNSL TRANS SHFT OPG TR (INCLS TRAC CONT SWITCH) 25772995 PLATE, F/FLR CNSL TRANS SHFT OPG TR (WALNUT BURL) (INCLS TRAC CNTRL SW) [ПОДДОН] teamcadillac.ru 88967342 BASE, A/TRNS CONT (INCLS 4, 6, 7) (4.010) 88967347 SOLENOID, A/TRNS SHFT LK CONT (ЧАСТЬ OF 5) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (A/TRNS RANGE SEL ROD ADJ) 15245220 LINK, A/TRNS RANGE SEL LVR [ШАРНИР,КУЛИСА] 11519095 NUT-ACORN HEX, M8X1.0, 15MM THK, 9, 6047M, W/DOME. (A/TRNS RANGE SEL LVR) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL LVR CBL BRKT) [ГАЙКА М6] 88967341 BULB, A/TRNS CONT POSN IND (INCLS BULB W/BLUE COVER) (4.020) (ACDelco #88967341) [ЛАМПОЧКА ФАРЫ] 88967340 COVER, A/TRNS CONT LVR HDL (ЧАСТЬ OF 1) (6E04-004) - 2004-2006 E УПРАВЛЕНИЕ АКПП/АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3,MX5) ↓ 19121866 KNOB PKG, A/TRNS CONT LVR (INCLS 2, 13) (CASHMERE) 88967336 KNOB PKG, A/TRNS CONT LVR (INCLS 2, 13) (EBONY/BURL WALNUT) 88967337 KNOB PKG, A/TRNS CONT LVR (INCLS 2, 13) (EBONY LEATHER) 88967339 БОЛТ, A/TRNS CONT LVR KNOB (ЧАСТЬ OF 1) 25772994 PLATE, F/FLR CNSL TRANS SHFT OPG TR (INCLS TRAC CONT SWITCH) 25772995 PLATE, F/FLR CNSL TRANS SHFT OPG TR (WALNUT BURL) (INCLS TRAC CNTRL SW) [ПОДДОН] 19167127 BEZEL, A/TRNS CONT HSG (W/SHIF LOCK SOLENOID COV) 88967343 BASE, A/TRNS CONT (4.010) [БЛОК] 88967347 SOLENOID, A/TRNS SHFT LK CONT teamcadillac.ru 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (A/TRNS RANGE SEL ROD ADJ) 15245219 LINK, A/TRNS RANGE SEL LVR 11519095 NUT-ACORN HEX, M8X1.0, 15MM THK, 9, 6047M, W/DOME. (A/TRNS RANGE SEL LVR) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL LVR CBL BRKT) [ГАЙКА М6] 88967341 BULB, A/TRNS CONT POSN IND (INCLS BULB W/BLUE COVER) (4.020) (ACDelco #88967341) [ЛАМПОЧКА ФАРЫ] 88967340 COVER, A/TRNS CONT LVR HDL (ЧАСТЬ OF 1) (6E04-007) - 2004-2006 E ТОРМОЗНЫЕ ШЛАНГИ И ТРУБКИ ↓ 15933099 HOSE, FRT BRK (INCLS 15, 16) (ACDelco #176-1495) 11569742 RETAINER, FRT BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (BRK & FUEL FEED & FUEL RTN & EVAP EMIS) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА] 25761218 BRACKET, FUEL PIPE 25761217 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (3.162) 12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (FRT BRK) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА] 10388788 PIPE, BRK PRESS MOD VLV FRT (INCLS 29) 10388794 PIPE, BRK PRESS MOD VLV RR (INCLS 29) 03541444 SPACER, FRT BRK PIPE 11516521 БОЛТ, HFH M6X1X20, 9.8, 7114M, DOG PT, 14.2 OD (FRT BRK HOSE) 15933098 HOSE, FRT BRK (INCLS 15, 16) (ACDelco #176-1487) 25743891 RETAINER, RR BRK FRT PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT) 15724653 FITTING, FRT BRK PIPE (ЧАСТЬ OF 1, 12) (7/16-24 X .36) (.30 THD, .56 LENGTH, .194 TUBE, STL, GM7113M) 25743891 RETAINER, FRT BRK PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT) 25737279 CLIP, FRT BRK PIPE (THREE WAY RETAINER SINGLE CENTRAL FIR-TREE ATTACHMENT) 15270078 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (USES RETAINER PIN FOR ATTACHMENT) [ЗАЖИМ ТРУБКИ ТОПЛИВНОЙ СИСТЕМЫ] 25688547 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (RETAINER W/5 HOLES (2)7.95, (2)4.76, (1)9.52MM) 25749839 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (HOLDS 3 ТРУБКИ, FLAT SHAPE, SNAP-IN RETAINER) 25607191 RETAINER, BRK PIPE (21.5X10.0MM) (HOLDS (2) 4.68-4.82 TUBES) 11569742 RETAINER, RR BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 15724650 ГАЙКА, INVERTED FLARED TUBE, 9/16"-18, 1/4" TUBE, ZD (BRK PIPE) (4.686) [ГАЙКА] 25693890 RETAINER, RR BRK PIPE (HOLDS (1) 4.76 LINE) (W/TREE) [ЗАМОК, ФИКСАТОР] 11588803 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 7, 8) (1/2-20X.40, .32 THD) (INVERTED FLARED TUBE) (.62 LONG, 1/4 TUBE) [ГАЙКА М20] teamcadillac.ru 15724650 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 7, 8) (9/16-18 X .40) (INVERTED FLARED TUBE) [ГАЙКА] 15933091 HOSE, RR BRK (INCLS 22, 23) (ACDelco #15933091) 15933092 HOSE, RR BRK (INCLS 22, 23) (ACDelco #15933092) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ] 88964150 PROTECTOR, FRT BRK PIPE (FOR 3/16" PIPE) (HT SHRINK) (6E04-008) - 2004-2006 E ТОРМОЗНАЯ ПЕДАЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (EXC (JF4)) ↓ 25732428 BARRIER, BRK PED BRKT SND 25697461 RETAINER, BRK PED PUSH ROD BOOT 25732452 BOOT, BRK PED PUSH ROD 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] 15932827 HOSE, P/B BOOS VAC (ACDelco #176-1496) 25765419 PEDAL, BRK (W/BRKT) (INCLS 10, 11, 14, 16-18) 25771615 COVER, BRK PED (ЧАСТЬ OF 9) 89047699 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 9) [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] teamcadillac.ru 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 9) 10434956 BUSHING, BRK PED PUSH ROD 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 9) 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 9) (0.80 IN) (PUSH IN) (6E04-010) - 2004-2006 E СТОЯНОЧНЫЙ ТОРМОЗ SYSTEM ↓ 10395687 LEVER, PARK BRK (INCLS 2-4, 13-15) teamcadillac.ru 15797212 CABLE, PARK BRK INTER (INCLS 5, 10, 11) (ACDelco #15797212) [ТРОС СТОЯНОЧНОГО ТОРМОЗА В СБОРЕ] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (PARK BRK INTER CBL GDE) [ГАЙКА М6] 11517484 БОЛТ-HEX, M6X1X20, 9 THD, 17 OD, 9.8, 6280M, MACH, P-PT (PARK BRK INTER CBL GDE) 25764260 CABLE, PARK BRK RR (28.2X28.5X811.7MM) (ACDelco #25764260) [ТРОС СТОЯНОЧНОГО ТОРМОЗА] 25880964 HANDLE, PARK BRK REL 89047821 CABLE, PARK BRK REL (ЧАСТЬ OF 1) (ACDelco #89047821) 22654577 SWITCH, PARK BRK IND (ЧАСТЬ OF 1) (ACDelco #22654577) [ВКЛЮЧАТЕЛЬ] 10369646 БОЛТ, PARK BRK IND SW (ЧАСТЬ OF 1) (6E04-011) - 2004-2006 E T.C.M. МОДУЛЬ ↓ 24239785 МОДУЛЬ, TRANS CONT 24240286 МОДУЛЬ, TRANS CONT 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (MULTIUSE RLY & FUSE BRKT) [БОЛТ М6] (6E04-012) - 2004-2006 E КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS(MV3) ↓ 88996677 CASE, TRFER (FRT HALF) (INCLS 12-14) 19133265 CASE, TRFER (RR HALF) (INCLS 5, 7) 88996679 SNUBBER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN 88996680 БОЛТ, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN SNBR (M5X0.8X16) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 2) 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL FILL) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996657 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 2) [УПЛОТНИТЕЛЬ] teamcadillac.ru 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL DRN) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996680 БОЛТ, TRFER CASE VENT BFL (M5X0.8X16) (4.535) 88996658 BAFFLE, TRFER CASE VENT 89048123 БОЛТ, TRFER CASE HALF (M8X1.25X30) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 1) 88996656 SEAL, TRFER CASE INPUT SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 88996657 SEAL, TRFER CASE FRT ВЫХОДНОЙ SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] (6E04-014) - 2006 E КОРПУС КП КРЕПЛЕНИЕ (MV3) ↓ 11519347 БОЛТ, TRFER CASE (M10X1.5X65) (8.900) [БОЛТ] teamcadillac.ru (6E04-016) - 2004-2009 E КЛАПАН РЕГУЛИРОВКИ ДАВЛЕНИЯ В ТОРМОЗНОЙ СИСТЕМЕ ↓ 89060339 МОДУЛЬ KIT, ELEK BRK & TRACT CONT (REQS PROGRAMMING;BRK APPLY SEN REQS CALN;REFER TO SERV INFO) (ACDelco #89060339) [БЛОК УПРАВЛЕНИЯ ТОРМОЗНОЙ СИСТЕМОЙ] 89060233 VALVE KIT, BRK PRESS MOD (INCLS 3, 4) (ACDelco #89060233) [ГИДРАВЛИЧЕСКИЙ БЛОК АБС] teamcadillac.ru 25743362 SENSOR, BRK PRESS MOD VLV PRESS (ЧАСТЬ OF 2) (ACDelco #25743362) [ДАТЧИК] 25741456 INSULATOR, BRK PRESS MOD VLV (ЧАСТЬ OF 2) 11588304 STUD, FLANGE DOUBLE END, M8X14 UNTHD, M8X1.25X13, 17 OD, 5.8, GM4345M (BRK PRESS MOD VLV BRKT) 11514596 ГАЙКА, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (BRK PRESS MOD VLV BRKT) (8.915) (ACDelco #11514596) 11508351 SCREW, PAN HD, C/R, 5X0.8X13, 9.3 OD, FULL THD, THD RLLR, 6171M, PC (BRK PRESS MOD VLV) (8.977) (6E04-017) - 2004-2006 E ШЛАНГ ВЕНТИЛЯЦИИ ТРАНСМИССИИ ↓ 25764835 VENT, A/TRNS (INCLS 2, 3) (ACDelco #25764835) teamcadillac.ru 15955072 CLIP, TRANS VENT HOSE (ЧАСТЬ OF 1) (.650MM DIA) (2.343) (6E04-018) - 2004-2009 E КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS(MX5) ↓ 88996677 CASE, TRFER (FRT HALF) (INCLS 12-14) 19133265 CASE, TRFER (RR HALF) (INCLS 5, 7) 88996679 SNUBBER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN 88996680 БОЛТ, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN SNBR (M5X0.8X16) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 2) 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL FILL) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996657 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 2) [УПЛОТНИТЕЛЬ] 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL DRN) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996680 БОЛТ, TRFER CASE VENT BFL (M5X0.8X16) (4.535) teamcadillac.ru 88996658 BAFFLE, TRFER CASE VENT 89048123 БОЛТ, TRFER CASE HALF (M8X1.25X30) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 1) 88996656 SEAL, TRFER CASE INPUT SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 88996657 SEAL, TRFER CASE FRT ВЫХОДНОЙ SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 19180066 VENT, TRFER CASE 89048123 БОЛТ, TRFER CASE VIB DPNR (M8X1.25X30) 19133173 DAMPENER, TRFER CASE VIB (YOKE STYLE; БОЛТS TO RR OF T-CASE) (TRANS BUILT ON 3-22-06 & AFTER) (FOR 1ST DES SEE 89048182) 89048182 DAMPENER, TRFER CASE VIB (YOKE STYLE-БОЛТS TO RR OF T/CASE) (TRANS BUILT ON 3-21-06 & AFTER) (FOR 2ND DES SEE 19133173) (6E04-021) - 2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (LH2/4.6A, EXC V92) ↓ 11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16] 89022494 BRACKET, TRANS FLUID CLR 19129780 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) [ТРУБКА] 19129782 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) (WITH TRANS OIL COOLER EXTERNAL TO РАДИАТОР. FOR 2ND DES SEE 19129977.) [ТРУБКА МАСЛООХЛАДИТЕЛЯ] 19130214 SEAL, TRANS FLUID CLR HOSE CONN (O RING) 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 19129779 HOSE, TRANS FLUID CLR LWR (W/BLOCK) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 19129781 HOSE, TRANS FLUID CLR LWR (W/BLOCK) (WITH TRANS OIL COOLER EXTERNAL TO РАДИАТОР. FOR 2ND DES SEE 19129976) teamcadillac.ru 88957425 COOLER, TRANS FLUID (INCLS 7-11) (ACDelco #88957425) [ВЕНТИЛЯТОР] (6E04-022) - 2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (V92) ↓ 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 89022494 BRACKET, TRANS FLUID CLR 19129780 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) [ТРУБКА] 19129782 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) [ТРУБКА МАСЛООХЛАДИТЕЛЯ] 19130214 SEAL, TRANS FLUID CLR HOSE CONN (O RING) 19129779 HOSE, TRANS FLUID CLR LWR (W/BLOCK) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 19129781 HOSE, TRANS FLUID CLR LWR (W/BLOCK) 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] teamcadillac.ru 89022522 COOLER, TRANS FLUID (INCLS 7-10) (6E04-035) - 2005-2009 E BRAKE SYSTEM/ANTILOCK ↓ teamcadillac.ru 12413103 HUB, FRT WHL (W/BRG) (СМ. ГРУППУ 06.000 "ПОДВЕСКА-ПЕРЕДНЯЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/WHL SPD SEN) (ACDelco #FW149) [СТУПИЦА КОЛЕСА] 12413105 HUB, FRT WHL (W/BRG) (СМ. ГРУППУ 06.000 "ПОДВЕСКА-ПЕРЕДНЯЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPEED SENSOR) (ACDelco #FW150) [СТУПИЦА КОЛЕСА] 89047639 HUB, RR WHL (W/WHL SPD SEN) (СМ. ГРУППУ 06.000 "ЗАДНЯЯ ПОДВЕСКА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6 STUD HUB) (ACDelco #RW20-19) [СТУПИЦА КОЛЕСА] 10307709 SENSOR, VEH YAW (W/VEH LATL ACCLRM) [ДАТЧИК] 15906579 SENSOR, VEH YAW (W/ VEH LATL & LGTDNL ACCLRM) [ДАТЧИК] 11561645 ГАЙКА, HFH, M6X1X6.45, 13.5 OD, 10 STL, GMW3200 (VEH YAW SEN & LATL ACCLRM) (6E04-036) - 2005-2006 E ТОРМОЗНАЯ ПЕДАЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (JF4) ↓ 25732428 BARRIER, BRK PED BRKT SND 25697461 RETAINER, BRK PED PUSH ROD BOOT 25732452 BOOT, BRK PED PUSH ROD 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] 15932827 HOSE, P/B BOOS VAC (ACDelco #176-1496) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (ACCEL PED LVR) 10368488 PEDAL, BRK (INCLS 12, 13, 15, 18-22) 25771615 COVER, BRK PED (ЧАСТЬ OF 11) 89047699 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 11) (INCLS 18) [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 89047780 MOTOR KIT, BRK & ACCEL PED ADJR ACTR [ЭЛЕКТРОДВИГАТЕЛЬ ПЕДАЛЬНОГО УЗЛА 19 ВТ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 11, 13) teamcadillac.ru 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 11) 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 11) 25697461 RETAINER, BRK PED PUSH ROD BOOT (ЧАСТЬ OF 11) 89047779 CABLE, ACCEL CONT 89047778 CABLE, BRK PED ADJR ACTR [ЖГУТ ПРОВОДОВ] 25741052 BRACKET, BRK PED BRKT 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-018) - 2004-2006 E КОРПУС КП ЧАСТЬ 2 INTERNAL COMPONENTS(MV3) ↓ 88984517 WASHER, TRFER CASE PLNT CARR SUN GR THR (25.8X52.0X2.2) 88984524 GEAR, TRFER CASE PLNT CARR SUN (INPUT) (STAMPED PM/POWDERED METAL) 88984493 RING, TRFER CASE RR ВЫХОДНОЙ SHF RR BRG RET (41MM I.D.) (ACDelco #88984493) 88996564 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT 88996665 BEARING, TRFER CASE MAIN SHF FRT (ВЫХОДНОЙ ВАЛ FRT) teamcadillac.ru 19168733 BUSHING, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 106) [ВТУЛКА РАЗДАТОЧНОЙ КОРОБКИ] 19178237 SHAFT, TRFER CASE RR ВЫХОДНОЙ (INCLS 105, 901) 19133264 SPROCKET, TRFER CASE FRT ВЫХОДНОЙ SHF DRV (INCLS 108) [ШЕСТЕРНЯ РАЗДАТОЧНОЙ КОРОБКИ] 19168732 BUSHING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT (ЧАСТЬ OF 107) (ACDelco #19168732) 89059578 CHAIN, TRFER CASE TWO/FOUR WHL DRV [ЦЕПЬ РАЗДАТОЧНОЙ КОРОБКИ] 88984523 GEAR, TRFER CASE PLNT CARR SUN (ВЫХОДНОЙ) 89059279 КРОНШТЕЙН, FRT/RR DRV DIFF 89059284 SHAFT, TRFER CASE FRT ВЫХОДНОЙ (INCLS 900) 88996664 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF RR 88996671 RING, TRFER CASE FRT ВЫХОДНОЙ SHF BRG RET 88996666 SPROCKET, TRFER CASE TWO/FOUR WHL DRV DRVN [ЗВЕЗДОЧКА] 88996633 BEARING, TRFER CASE RR ВЫХОДНОЙ SHF RR (ACDelco #88996633) [ПОДШИПНИК РАЗДАТОЧНОЙ КОРОБКИ] 15580230 BEARING, TRFER CASE INPUT SHF (BORG-WARNER) (4.510) 19132966 SHAFT, TRFER CASE INPUT 88996681 DEFLECTOR, TRFER CASE FRT ВЫХОДНОЙ SHF SEAL DIRT (ЧАСТЬ OF 112) (6M04-041) - 2004-2006 E26 ТОРМОЗНАЯ ПЕДАЛЬ (PWR ADJ PEDALS JF4) ↓ 25741052 BRACKET, BRK PED BRKT teamcadillac.ru 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 25732428 BARRIER, BRK PED BRKT SND 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 89047778 CABLE, BRK PED ADJR ACTR [ЖГУТ ПРОВОДОВ] 89047780 MOTOR KIT, BRK & ACCEL PED ADJR ACTR [ЭЛЕКТРОДВИГАТЕЛЬ ПЕДАЛЬНОГО УЗЛА 19 ВТ] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (BRK PED POSN SEN) 89047699 SENSOR KIT, BRK PED POSN [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 25697461 RETAINER, BRK PED PUSH ROD BOOT (ЧАСТЬ OF 21) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 21) 10368488 PEDAL, BRK (INCLS 5, 8-10, 13, 15-20, 22) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-042) - 2004-2006 E26 ТОРМОЗНАЯ ПЕДАЛЬ (EXC PWR ADJ PEDALS JF4) ↓ 25741052 BRACKET, BRK PED BRKT 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 25732428 BARRIER, BRK PED BRKT SND 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 18) 89047699 SENSOR KIT, BRK PED POSN [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 18) (0.80 IN) (PUSH IN) 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 18) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 18) 25771615 COVER, BRK PED (ЧАСТЬ OF 18) 25765419 PEDAL, BRK (W/BRKT) (INCLS 5-8, 10, 12-17, 19) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-044) - 2004-2009 E26 ТОРМОЗНОЙ УСИЛИТЕЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА ↓ 88967237 BOOSTER, P/B (СМ. ГРУППУ 04.000 "ТОРМОЗНОЙ УСИЛИТЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/O VLV) (ACDelco #178-0695) 25732452 BOOT, BRK PED PUSH ROD teamcadillac.ru 25697461 RETAINER, BRK PED PUSH ROD BOOT 10367561 CYLINDER, BRK MAS (СМ. ГРУППУ 4.000 "ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #174-1012) [ЦИЛИНДР] 11517996 ГАЙКА, BRK M/CYL (M10X1.5, 11.2 THK) (8.917) [ГАЙКА М10] 25873484 HOSE, P/B BOOS VAC (ACDelco #176-1497) (GM00-031) - 2006 E ТРАНСМИССИЯ TO КРЕПЛЕНИЕ ДВИГАТЕЛЯ (LH2/4.6A) ↓ 12582606 FLYКОЛЕСО, ENG 25771275 BRACKET, ENG WRG HARN (USED IN GENERATOR PACKAGE) 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] 24205900 COVER, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] 11589116 БОЛТ, FLYWHL (8.900) 12568122 COVER, FLYWHL HSG 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) teamcadillac.ru 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (TRANS CONV CVR) (ACDelco #11517518) [БОЛТ] 12568123 COVER, TRANS CONV (GM04-064) - 2004-2009 E ТОРМОЗНОЙ СУППОРТ-ПЕРЕДНИЙ ↓ 18047980 CALIPER, FRT BRK (INCLS 2-4, 8-10) (IF DISCONTINUED USE DURASTOP EQUIVALENT) (4.667) (ACDelco #172-1643) [ТОРМОЗНОЙ СУППОРТ] 18047981 CALIPER, FRT BRK (INCLS 2-4, 8-10) (IF DISCONTINUED USE DURASTOP EQUIVALENT) (4.667) (ACDelco #172-1644) [ТОРМОЗНОЙ СУППОРТ] 18043178 COVER, FRT BRK BLEDR SCREW (ЧАСТЬ OF 1) 18047986 VALVE KIT, FRT BRK CLPR BLEDR (ЧАСТЬ OF 1) (ACDelco #18047986) 18046750 БОЛТ, FRT BRK CLPR GDE PIN (ЧАСТЬ OF 1, 11) (*KIT2) [БОЛТ] 18047985 PISTON KIT, FRT BRK CLPR (ЧАСТЬ OF 1) 18047988 PAD KIT, FRT DISC BRK (INCLS 4, 14) (ACDelco #171-665) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4 ШТ)] 19122384 PAD KIT, FRT DISC BRK (INCLS 4, 14) (ACDelco #171-688) teamcadillac.ru 18045221 SEAL, FRT BRK CLPR GDE PIN 18047987 BRACKET, FRT BRK CLPR (W/GUIDE PIN БОЛТS) [КРОНШТЕЙН] 18046698 ПРУЖИНА, FRT DISC BRK PAD RET (ЧАСТЬ OF 11) (ACDelco #179-2235) 18047989 PIN KIT, FRT BRK CLPR GDE (INCLS 5-7) (INCLS 2 (2.5") БОЛТS) 18047984 CALIPER KIT, FRT BRK (INCLS 4, 8, 9) (4.667) (ACDelco #173-0538) (GM04-312) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (5L50-E M22,5L40-E M82) ↓ 96042884 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 6GDZ) 96042897 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 6GRG) (GM04-376) - 2004-2009 E ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР ↓ 18012741 SWITCH, BRK FLUID LVL IND (ЧАСТЬ OF 15) (ACDelco #18012741) 22688449 CAP, BRK M/CYL RSVR (ЧАСТЬ OF 15) (INCLS 3) [КРЫШКА БАЧКА ТОРМОЗНОЙ ЖИДКОСТИ] teamcadillac.ru 18046711 RESERVOIR, BRK M/CYL (ЧАСТЬ OF 15) (INCLS 4, 6-7) (ACDelco #18046711) 18060168 PISTON, BRK M/CYL SECD (ЧАСТЬ OF 15) 10367561 CYLINDER, BRK MAS (INCLS 1-14) (ACDelco #174-1012) [ЦИЛИНДР] 18022002 CYLINDER KIT, BRK MAS (INCLS 8-12) (ACDelco #175-424) (GM04-485) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (5L50-E MV3,5L40-E MX5) ↓ 96042890 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 6GGG) [АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ В СБОРЕ] teamcadillac.ru 96042893 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 6GFZ) [ТРАНСМИССИЯ В СБОРЕ] (GM04-573) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042861 GASKET, A/TRNS CASE EXTN 24237771 BEARING, ВЫХОДНОЙ SHF (ЧАСТЬ OF 27) 96042882 EXTENSION, A/TRNS CASE (INCLS 26, 28, 29) (4.003) 24237771 BEARING, ВЫХОДНОЙ SHF (ЧАСТЬ OF 27) 96041851 SEAL, PROP SHF TRANS FLG FLUID (ЧАСТЬ OF 27) [ПРОКЛАДКА ТРАНСФОРМАТОРНОГО ВАЛА] 96042984 FLANGE, ВЫХОДНОЙ SHF teamcadillac.ru 96041805 NUT KIT, ВЫХОДНОЙ SHFT (INCLS 30, 32, 33) (M6X1.0X16) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96042962 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) 96042712 DETENT, MAN SHFT 96017928 CLIP, WRG HARN 96042847 HARNESS, A/TRNS WRG 96041849 SEAL, A/TRNS WRG CONN (O RING) 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) (GM04-573) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042861 GASKET, A/TRNS CASE EXTN (*KIT1) 24237771 BEARING, ВЫХОДНОЙ SHF (ЧАСТЬ OF 27) 96042860 EXTENSION, A/TRNS CASE (INCLS 26, 28, 29) 24237771 BEARING, ВЫХОДНОЙ SHF (ЧАСТЬ OF 27) 96041851 SEAL, PROP SHF TRANS FLG FLUID (ЧАСТЬ OF 27) (*KIT1) [ПРОКЛАДКА ТРАНСФОРМАТОРНОГО ВАЛА] 96042984 FLANGE, ВЫХОДНОЙ SHF 96041805 NUT KIT, ВЫХОДНОЙ SHFT (INCLS 30, 32, 33) (M6X1.0X16) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) (*KIT1) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) (*KIT1) 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96042963 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPACER PLATE & GASKET) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) 96042712 DETENT, MAN SHFT 96017928 CLIP, WRG HARN 96042847 HARNESS, A/TRNS WRG 96041849 SEAL, A/TRNS WRG CONN (O RING) (*KIT1) 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN (*KIT1) [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] teamcadillac.ru 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (*KIT1) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (*KIT1) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) 96042945 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/GSKT, SEAL, RET) (INCLS 25, 29, 36, 38, 46, 56, 60, 63, 64) (GM04-574) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042887 GASKET, A/TRNS CASE EXTN [ПРОКЛАДКА КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042896 EXTENSION, A/TRNS CASE (INCLS 28, 69) 24237771 BEARING, ВЫХОДНОЙ SHF (ЧАСТЬ OF 27) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) teamcadillac.ru 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96042962 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) 96042712 DETENT, MAN SHFT 96017928 CLIP, WRG HARN 96042847 HARNESS, A/TRNS WRG 96041849 SEAL, A/TRNS WRG CONN (O RING) 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) 96042543 WASHER, INPUT & REACTION CARR THR 96042587 SEAL, PROP SHF TRANS FLG FLUID [ПРОКЛАДКА КРЫШКИ РАЗДАТОЧНОЙ КОРОБКИ] (GM04-574) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042887 GASKET, A/TRNS CASE EXTN [ПРОКЛАДКА КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042888 EXTENSION, A/TRNS CASE (INCLS 28, 69) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96042963 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPACER PLATE & GASKET) teamcadillac.ru 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) 96042712 DETENT, MAN SHFT 96017928 CLIP, WRG HARN 96042847 HARNESS, A/TRNS WRG 96041849 SEAL, A/TRNS WRG CONN (O RING) 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) 96042543 WASHER, INPUT & REACTION CARR THR 96042587 SEAL, PROP SHF TRANS FLG FLUID [ПРОКЛАДКА КРЫШКИ РАЗДАТОЧНОЙ КОРОБКИ] 08677884 BEARING, ВЫХОДНОЙ SHF THR (ЧАСТЬ OF 27) (4.180) (ACDelco #8677884) (GM04-575) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ teamcadillac.ru 96042553 CONVERTER, TORQ (REMAN) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042835 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) 96042806 СЦЕПЛЕНИЕ, DIR & REV 96042831 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) 96042823 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) 96042824 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) 96042701 WASHER, INPUT & REACTION CARR INR SHF THR 96042808 ШЛАНГИ, O/D CLU 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) 96042705 BEARING, CTR SUPT RLR (4.180) 96042826 SUPPORT, CTR 96042832 КРОНШТЕЙН, INPUT & REACTION 96042833 BEARING, INPUT & REACTION CARR THR 96042834 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) 96042543 WASHER, INPUT & REACTION CARR THR 96042833 BEARING, INPUT & REACTION CARR THR 96042883 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/GSKT, SEAL, RET) (GM04-575) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ 96042554 CONVERTER, TORQ (REMAN) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042812 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) 96042806 СЦЕПЛЕНИЕ, DIR & REV (СМ. ГРУППУ 04.000 "DIRECT AND REVERSE СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042807 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (СМ. ГРУППУ 04.000 "FORWARD AND COAST СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042698 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) (СМ. ГРУППУ 04.000 "INPUT SUN GEAR SHAFT AND FORWARD SPRAG СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (СМ. ГРУППУ 04.000 "DIRECT СЦЕПЛЕНИЕ DRUM AND SHAFT" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042701 WASHER, INPUT & REACTION CARR INR SHF THR 96042808 ШЛАНГИ, O/D CLU (СМ. ГРУППУ 04.000 "OVERDRIVE AND INTERMEDIATE СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (СМ. ГРУППУ 04.000 "LOW СЦЕПЛЕНИЕ SPRAG" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042705 BEARING, CTR SUPT RLR (4.180) teamcadillac.ru 96042809 SUPPORT, CTR (СМ. ГРУППУ 04.000 "CENTER SUPPORT" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042707 КРОНШТЕЙН, INPUT & REACTION (СМ. ГРУППУ 04.000 "PLANETARY КРОНШТЕЙН" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (4.176) 96042708 BEARING, INPUT & REACTION CARR THR 96042709 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (СМ. ГРУППУ 04.000 "ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96041847 WASHER, INPUT & REACTION CARR THR (4.265) (GM04-576) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ 96042553 CONVERTER, TORQ (REMAN) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042835 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) 96042814 СЦЕПЛЕНИЕ, DIR & REV 96042822 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) 96042823 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) 96042824 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) 96042701 WASHER, INPUT & REACTION CARR INR SHF THR 96042808 ШЛАНГИ, O/D CLU 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) 96042826 SUPPORT, CTR 96042827 КРОНШТЕЙН, INPUT & REACTION 96042818 BEARING, INPUT & REACTION CARR THR teamcadillac.ru 96042837 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) 96042543 WASHER, INPUT & REACTION CARR THR 96042818 BEARING, INPUT & REACTION CARR THR (GM04-576) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ 96042554 CONVERTER, TORQ (REMAN) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042812 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) 96042814 СЦЕПЛЕНИЕ, DIR & REV 96042815 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) 96042698 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) (INCLS 9) 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) 96042701 WASHER, INPUT & REACTION CARR INR SHF THR teamcadillac.ru 96042808 ШЛАНГИ, O/D CLU 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) 08677884 BEARING, LOW CLU RLR THR (*KIT1) (ACDelco #8677884) 96042816 SUPPORT, CTR 96042817 КРОНШТЕЙН, INPUT & REACTION 96042818 BEARING, INPUT & REACTION CARR THR 96042813 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) 96042543 WASHER, INPUT & REACTION CARR THR 96042818 BEARING, INPUT & REACTION CARR THR (GM04-577) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ 24209145 ФИЛЬТР, PRESS CONT SOL VLV FLUID (ACDelco #24209145) [ФИЛЬТР] teamcadillac.ru 24212478 SLIDE, A/TRNS ГИДРОНАСОС (17.9545MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212478) 24212479 SLIDE, A/TRNS ГИДРОНАСОС (17.9675MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212479) 24212480 SLIDE, A/TRNS ГИДРОНАСОС (17.9805MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212480) 24212481 SLIDE, A/TRNS ГИДРОНАСОС (17.9935MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212481) 24212482 SLIDE, A/TRNS ГИДРОНАСОС (18.0065MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212482) 24201144 RING, A/TRNS ГИДРОНАСОС VANE (RING, PUMP VANE) (ACDelco #24201144) 08631280 VANE, A/TRNS ГИДРОНАСОС (ACDelco #8631280) 24205410 GUIDE, A/TRNS ГИДРОНАСОС ROT (13 VANE) (ACDelco #24205410) 96015215 БОЛТ, A/TRNS ГИДРОНАСОС (4.115) 96041855 SEAL, T/CV FLUID [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042835 ШЛАНГИ KIT, T/CV (INCLS 200-212, 214-215, 217-220, 223, 226, 227, 231-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-577) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ 24209145 ФИЛЬТР, PRESS CONT SOL VLV FLUID (*KIT1) (ACDelco #24209145) [ФИЛЬТР] 24212478 SLIDE, A/TRNS ГИДРОНАСОС (17.9545MM) (SLIDE ID MARK = 1 DIMPLE) (*KIT1) (ACDelco #24212478) 24212479 SLIDE, A/TRNS ГИДРОНАСОС (17.9675MM) (SLIDE ID MARK = 1 DIMPLE) (*KIT1) (ACDelco #24212479) 24212480 SLIDE, A/TRNS ГИДРОНАСОС (17.9805MM) (SLIDE ID MARK = 1 DIMPLE) (*KIT1) (ACDelco #24212480) 24212481 SLIDE, A/TRNS ГИДРОНАСОС (17.9935MM) (SLIDE ID MARK = 1 DIMPLE) (*KIT1) (ACDelco #24212481) 24212482 SLIDE, A/TRNS ГИДРОНАСОС (18.0065MM) (SLIDE ID MARK = 1 DIMPLE) (*KIT1) (ACDelco #24212482) 24201144 RING, A/TRNS ГИДРОНАСОС VANE (RING, PUMP VANE) (*KIT1) (ACDelco #24201144) 08631280 VANE, A/TRNS ГИДРОНАСОС (*KIT1) (ACDelco #8631280) 24205410 GUIDE, A/TRNS ГИДРОНАСОС ROT (13 VANE) (*KIT1) (ACDelco #24205410) 96041855 SEAL, T/CV FLUID (*KIT1) [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] teamcadillac.ru 96042835 ШЛАНГИ KIT, T/CV (INCLS 200-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-577) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ teamcadillac.ru 96015215 БОЛТ, T/CV FLUID SEAL (*KIT1) 96041855 SEAL, T/CV FLUID [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042812 ШЛАНГИ KIT, T/CV (INCLS 200-215, 217-220, 223, 226-228, 231-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-577) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ 24212478 SLIDE, A/TRNS ГИДРОНАСОС (17.9545MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212478) 24212479 SLIDE, A/TRNS ГИДРОНАСОС (17.9675MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212479) 24212480 SLIDE, A/TRNS ГИДРОНАСОС (17.9805MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212480) 24212481 SLIDE, A/TRNS ГИДРОНАСОС (17.9935MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212481) 24212482 SLIDE, A/TRNS ГИДРОНАСОС (18.0065MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212482) 24201144 RING, A/TRNS ГИДРОНАСОС VANE (RING, PUMP VANE) (ACDelco #24201144) 08631280 VANE, A/TRNS ГИДРОНАСОС (ACDelco #8631280) 24205410 GUIDE, A/TRNS ГИДРОНАСОС ROT (13 VANE) (ACDelco #24205410) 24201144 RING, A/TRNS ГИДРОНАСОС VANE (RING, PUMP VANE) (ACDelco #24201144) teamcadillac.ru 96015215 БОЛТ, T/CV FLUID SEAL (*KIT1) 96041855 SEAL, T/CV FLUID [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042812 ШЛАНГИ KIT, T/CV (INCLS 200-215, 217-220, 223, 226-228, 231-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-578) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 96020027 БОЛТ, C/VLV CHAN PLT 24209145 ФИЛЬТР, PRESS CONT SOL VLV FLUID (*KIT2) (ACDelco #24209145) [ФИЛЬТР] 24209145 ФИЛЬТР, PRESS CONT SOL VLV FLUID (*KIT2) (ACDelco #24209145) [ФИЛЬТР] 96025325 БОЛТ, DIR CLU ACCUM (4.265) teamcadillac.ru 96042987 GASKET KIT, A/TRNS (INCLS 303, 305, 306, 308, 309, 312, 314, 316, 330, 332) (4.265) (GM04-578) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 96020027 БОЛТ, C/VLV CHAN PLT 24209145 ФИЛЬТР, PRESS CONT SOL VLV FLUID (*KIT2) (ACDelco #24209145) [ФИЛЬТР] 24209145 ФИЛЬТР, PRESS CONT SOL VLV FLUID (*KIT2) (ACDelco #24209145) [ФИЛЬТР] 96025325 БОЛТ, DIR CLU ACCUM (4.265) teamcadillac.ru 96042987 GASKET KIT, A/TRNS (INCLS 303, 305, 306, 308, 309, 312, 314, 316, 330, 332) (4.265) (GM04-578) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 300-309, 312-334) (INCLS SPACER PLATE & GASKET) 96042986 GASKET KIT, A/TRNS (INCLS 303, 305, 306, 308, 309, 312, 314, 316, 330, 332) (4.265) (GM04-578) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 300-334) (INCLS SPACER PLATE & GASKET) 96042986 GASKET KIT, A/TRNS (INCLS 303, 305, 306, 308, 309, 312, 314, 316, 330, 332) (4.265) (GM04-579) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 10475842 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (14 MM I.D.) (INR) (ACDelco #10475842) 10475842 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (14 MM I.D.) (INR) (ACDelco #10475842) teamcadillac.ru 96042599 VALVE, TCC PWM SOL 10475842 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (14 MM I.D.) (INR) (ACDelco #10475842) 10475842 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (14 MM I.D.) (INR) (ACDelco #10475842) 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] (GM04-579) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 10475842 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (14 MM I.D.) (INR) (ACDelco #10475842) 10475842 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (14 MM I.D.) (INR) (ACDelco #10475842) 96042599 VALVE, TCC PWM SOL 10475842 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (14 MM I.D.) (INR) (ACDelco #10475842) 10475842 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (14 MM I.D.) (INR) (ACDelco #10475842) teamcadillac.ru 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] (GM04-579) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96042599 VALVE, TCC PWM SOL 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 340-351, 353-356) (INCLS SPACER PLATE & GASKET) (GM04-579) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 10471813 SEAL, TCC SOL VLV (O RING) (SMALL DIA) (OTR) (ACDelco #10471813) 10475842 SEAL, TCC SOL VLV (O RING) (14 MM I.D.) (INR) (ACDelco #10475842) teamcadillac.ru 96042599 VALVE, TCC PWM SOL 10471813 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (SMALL DIA) (OTR) (ACDelco #10471813) 10475842 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (14 MM I.D.) (INR) (ACDelco #10475842) 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 340-348, 351, 353-354) (INCLS SPACER PLATE & GASKET) (GM04-580) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 10475842 SEAL, TCC SOL VLV (O RING) (14 MM I.D.) (INR) (ACDelco #10475842) teamcadillac.ru 10475842 SEAL, TCC SOL VLV (O RING) (14 MM I.D.) (INR) (ACDelco #10475842) 08680781 RETAINER, 2-3 SHFT SOL VLV (ACDelco #8680781) 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] (GM04-580) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 10475842 SEAL, TCC SOL VLV (O RING) (14 MM I.D.) (INR) (ACDelco #10475842) 10475842 SEAL, TCC SOL VLV (O RING) (14 MM I.D.) (INR) (ACDelco #10475842) 08680781 RETAINER, 2-3 SHFT SOL VLV (ACDelco #8680781) 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] teamcadillac.ru (GM04-580) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 343, 349, 350, 365-367, 370-375, 377-388) (INCLS SPACER PLATE & GASKET) (GM04-580) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 10471813 SEAL, TCC SOL VLV (O RING) (SMALL DIA) (OTR) (ACDelco #10471813) 10475842 SEAL, TCC SOL VLV (O RING) (14 MM I.D.) (INR) (ACDelco #10475842) 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] teamcadillac.ru 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 343, 351, 365-367, 370-375, 377-388) (INCLS SPACER PLATE & GASKET) 96042889 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/PLT, GSKT, SEAL) (INCLS 343, 351, 365-367, 370-375, 377-388) (GM04-581) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru (GM04-581) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru 96042814 СЦЕПЛЕНИЕ, DIR & REV (INCLS 400-420) (GM04-581) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru 96042806 СЦЕПЛЕНИЕ, DIR & REV (INCLS 400-420) (GM04-581) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru 96042814 СЦЕПЛЕНИЕ, DIR & REV (INCLS 400-420) (GM04-582) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96042831 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-432, 434-451) teamcadillac.ru 96042883 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/GSKT, SEAL, RET) (GM04-582) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯLY ↓ teamcadillac.ru 96042822 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-451) (GM04-582) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96041856 SEAL, INPUT SHF (O RING) (*KIT1) [ПРОКЛАДКА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] teamcadillac.ru 96042807 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-451) (GM04-582) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042815 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-451) (GM04-583) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru (GM04-583) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042827 КРОНШТЕЙН, INPUT & REACTION (INCLS 455-462) (GM04-583) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042707 КРОНШТЕЙН, INPUT & REACTION (INCLS 455-462) (4.176) (GM04-583) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042817 КРОНШТЕЙН, INPUT & REACTION (INCLS 455-462) (GM04-584) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ teamcadillac.ru 96042824 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-584) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ 96042824 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-584) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ teamcadillac.ru 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-584) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ teamcadillac.ru 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-585) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru (GM04-585) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042825 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 470-477) (GM04-585) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 470-477) (GM04-585) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 470-477) (GM04-586) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru (GM04-586) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96042825 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 480-497) (GM04-586) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 480-497) (GM04-586) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 480-497) (GM04-587) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК ↓ (GM04-587) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК ↓ 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (INCLS 500-505) (GM04-587) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК ↓ teamcadillac.ru 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (INCLS 500-505) (GM04-587) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК ↓ teamcadillac.ru 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (INCLS 500-505) (GM04-588) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) КРЕПЛЕНИЕ ↓ 96042826 SUPPORT, CTR (INCLS 510-517, 519-535) teamcadillac.ru (GM04-588) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) КРЕПЛЕНИЕ ↓ teamcadillac.ru 96042826 SUPPORT, CTR (INCLS 510-535) (GM04-588) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) КРЕПЛЕНИЕ ↓ teamcadillac.ru 96042809 SUPPORT, CTR (INCLS 510-535) (GM04-588) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) КРЕПЛЕНИЕ ↓ teamcadillac.ru 96042816 SUPPORT, CTR (INCLS 510-535) (GM04-589) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) PLANETARY КРОНШТЕЙН БЛОК ↓ teamcadillac.ru 96042832 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-552, 554) (GM04-589) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) PLANETARY КРОНШТЕЙН БЛОК ↓ teamcadillac.ru 96042827 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-554) (GM04-589) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) PLANETARY КРОНШТЕЙН БЛОК ↓ teamcadillac.ru 96042707 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-554) (4.176) (GM04-589) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) PLANETARY КРОНШТЕЙН БЛОК ↓ teamcadillac.ru 96042817 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-554) (GM04-590) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК ↓ teamcadillac.ru 96042834 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560, 561, 563, 564) (GM04-590) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК ↓ teamcadillac.ru 96042709 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560-564) (GM04-591) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК ↓ 96042837 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560-564) (GM04-591) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК ↓ teamcadillac.ru 96042813 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560-561, 563-564) (GM04-593) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) PARKING PAWL БЛОК ↓ 96042710 LEVER, MAN SHFT DTNT 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 96042540 SWITCH, A/TRNS MAN SHFT SHF POSN [ВЫКЛЮЧАТЕЛЬ ПРИВОДА] 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 08644709 SEAL, MAN SHFT SHF (W/O PTFE LUBRICANT APPLIED TO SEAL) (ACDelco #8644709) 96041857 SHAFT, MAN SHFT teamcadillac.ru 96041852 PLUG, MAN SHFT SHF HOLE (4.279) (GM04-593) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) PARKING PAWL БЛОК ↓ 96042710 LEVER, MAN SHFT DTNT 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 96042540 SWITCH, A/TRNS MAN SHFT SHF POSN [ВЫКЛЮЧАТЕЛЬ ПРИВОДА] 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] teamcadillac.ru 08644709 SEAL, MAN SHFT SHF (W/O PTFE LUBRICANT APPLIED TO SEAL) (ACDelco #8644709) 96041857 SHAFT, MAN SHFT 96042711 PAWL KIT, PARK 96041852 PLUG, MAN SHFT SHF HOLE (4.279) 96041842 SPACER, MAN SHFT DTNT LVR (GM04-594) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) PARKING PAWL БЛОК ↓ 96042710 LEVER, MAN SHFT DTNT 96042819 LEVER, MAN SHFT DTNT 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 96042540 SWITCH, A/TRNS MAN SHFT SHF POSN [ВЫКЛЮЧАТЕЛЬ ПРИВОДА] 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 08644709 SEAL, MAN SHFT SHF (W/O PTFE LUBRICANT APPLIED TO SEAL) (ACDelco #8644709) 96042544 SHAFT KIT, MAN SHFT 96042820 PAWL KIT, PARK teamcadillac.ru (GM04-594) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) PARKING PAWL БЛОК ↓ 96042710 LEVER, MAN SHFT DTNT 96042819 LEVER, MAN SHFT DTNT 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 96042540 SWITCH, A/TRNS MAN SHFT SHF POSN [ВЫКЛЮЧАТЕЛЬ ПРИВОДА] 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 08644709 SEAL, MAN SHFT SHF (W/O PTFE LUBRICANT APPLIED TO SEAL) (ACDelco #8644709) 96042544 SHAFT KIT, MAN SHFT 96042820 PAWL KIT, PARK 04 - ТОРМОЗА ↓ (6D04-023) - 2004-2009 E СТОЯНОЧНЫЙ ТОРМОЗ ASM ↓ 88951984 PLATE, RR PARK BRK ANC BKG (4.591) teamcadillac.ru 88951985 PLATE, RR PARK BRK ANC BKG (4.591) 88951982 ACTUATOR KIT, RR PARK BRK (INCLS 2) (ACDelco #179-2053) [АКТУАТОР] 88951983 ACTUATOR KIT, RR PARK BRK (INCLS 2) (ACDelco #179-2054) [АКТУАТОР] 89047676 SHOE KIT, RR PARK BRK (INCLS 5) (ACDelco #171-0915) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (2 ШТ)] (6D04-031) - 2004-2009 E ТОРМОЗНОЙ СУППОРТ-ЗАДНИЙ ↓ 89047677 CALIPER KIT, RR BRK (INCLS 2, 3, 7-9) (ACDelco #172-2343) 89047678 CALIPER KIT, RR BRK (INCLS 2, 3, 7-9) (ACDelco #172-2344) [ТОРМОЗНОЙ СУППОРТ] 88951992 CAP, RR BRK BLEDR VLV (ЧАСТЬ OF 1) 88951991 VALVE, RR BRK CLPR BLEDR (ЧАСТЬ OF 1) 89047757 PAD KIT, RR DISC BRK (INCLS 4, 12) (ACDelco #171-859) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4 ШТ)] 89047758 PAD KIT, RR DISC BRK (INCLS 4, 12) (4.667) (ACDelco #171-0906) [ТОРМОЗНЫЕ КОЛОДКИ] 88957163 BRACKET, RR BRK CLPR [СКОБА ТОРМОЗНОГО СУППОРТА] teamcadillac.ru 89047759 PIN KIT, RR BRK CLPR GDE (INCLS 4-6) (INCLS 2 PINS, 2 SEALS & 2 (2.75") БОЛТS) (ACDelco #179-2044) [НАПРАВЛЯЮЩАЯ ТОРМОЗНОГО СУППОРТА (2 ШТ)] 88957162 REPAIR KIT, RR BRK CLPR HYD (INCLS 4, 6, 8, 9) (6D04-033) - 2004-2009 E ТОРМОЗНОЙ УСИЛИТЕЛЬ ↓ 88967237 BOOSTER, P/B (W/O VLV) (ACDelco #178-0695) 05461808 GROMMET, P/B BOOS VAC CHK VLV (*KIT1) 03817880 RETAINER, BRK PED PUSH ROD (0.80 IN) (PUSH IN) teamcadillac.ru 18022219 VALVE KIT, P/B BOOS VAC CHK (INCLS 2, 3) (BLACK) (INCLS VLV & GROM) (ACDelco #179-1266) (6D04-067) - 2006-2009 E КОРПУС КП КРЕПЛЕНИЕ (MX5) ↓ 24231525 GASKET, TRFER CASE 19132968 CASE, TRFER (W/GEARS) (LESS DAMPENER) (UNITS BUILT ON 3-22-06 & AFTER) (FOR 1ST DES SEE 24234010) 24234010 CASE, TRFER (W/GEARS) (UNITS BUILT ON 3-21-06 & PRIOR) (FOR 2ND DES SEE 24238468) 11589341 БОЛТ - HFH, M10X1.5X69.9, 28.35 THD, 22.3 OD, 10.9, GMW3359, M-PT. (TRFER CASE) [БОЛТ] (6D04-068) - 2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (LY7/3.6-7, EXC V92)(WITH INTERNAL COOLER)(2ND DES) ↓ teamcadillac.ru 19129976 HOSE, TRANS FLUID CLR LWR (W/BLOCK) (INCLS 7) (WITH TRANS OIL COOLER IN РАДИАТОР. FOR 1ST DES SEE 19129781.) 11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16] 89022494 BRACKET, TRANS FLUID CLR 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 25740416 SEAL, TRANS FLUID CLR PIPE (O RING) (1/2IN) (9.222) (ACDelco #15-31872) [ПРОКЛАДКА КОМПРЕССОРА КОНДИЦИОНЕРА] 19129977 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) (WITH TRANS OIL COOLER IN РАДИАТОР. FOR 1ST DES SEE 19129782.) (6E00-014) - 2004-2009 E ТРАНСМИССИЯ TO КРЕПЛЕНИЕ ДВИГАТЕЛЯ (LY7/3.6-7) ↓ 12572042 PLATE, A/TRNS FLEX 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] teamcadillac.ru 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (TRANS CVR) [БОЛТ] 24222918 COVER, TRANS CONV 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] (6E04-003) - 2004-2006 E УПРАВЛЕНИЕ АКПП/АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22,M82) ↓ 19121866 KNOB PKG, A/TRNS CONT LVR (INCLS 2, 13) (CASHMERE) 88967336 KNOB PKG, A/TRNS CONT LVR (INCLS 2, 13) (EBONY/BURL WALNUT) 88967337 KNOB PKG, A/TRNS CONT LVR (INCLS 2, 13) (EBONY LEATHER) 88967339 БОЛТ, A/TRNS CONT LVR KNOB (ЧАСТЬ OF 1) 25772994 PLATE, F/FLR CNSL TRANS SHFT OPG TR (INCLS TRAC CONT SWITCH) 25772995 PLATE, F/FLR CNSL TRANS SHFT OPG TR (WALNUT BURL) (INCLS TRAC CNTRL SW) [ПОДДОН] 88967342 BASE, A/TRNS CONT (INCLS 4, 6, 7) (4.010) 88967347 SOLENOID, A/TRNS SHFT LK CONT (ЧАСТЬ OF 5) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (A/TRNS RANGE SEL ROD ADJ) teamcadillac.ru 15245220 LINK, A/TRNS RANGE SEL LVR [ШАРНИР,КУЛИСА] 11519095 NUT-ACORN HEX, M8X1.0, 15MM THK, 9, 6047M, W/DOME. (A/TRNS RANGE SEL LVR) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL LVR CBL BRKT) [ГАЙКА М6] 88967341 BULB, A/TRNS CONT POSN IND (INCLS BULB W/BLUE COVER) (4.020) (ACDelco #88967341) [ЛАМПОЧКА ФАРЫ] 88967340 COVER, A/TRNS CONT LVR HDL (ЧАСТЬ OF 1) (6E04-004) - 2004-2006 E УПРАВЛЕНИЕ АКПП/АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3,MX5) ↓ 19121866 KNOB PKG, A/TRNS CONT LVR (INCLS 2, 13) (CASHMERE) 88967336 KNOB PKG, A/TRNS CONT LVR (INCLS 2, 13) (EBONY/BURL WALNUT) 88967337 KNOB PKG, A/TRNS CONT LVR (INCLS 2, 13) (EBONY LEATHER) 88967339 БОЛТ, A/TRNS CONT LVR KNOB (ЧАСТЬ OF 1) teamcadillac.ru 25772994 PLATE, F/FLR CNSL TRANS SHFT OPG TR (INCLS TRAC CONT SWITCH) 25772995 PLATE, F/FLR CNSL TRANS SHFT OPG TR (WALNUT BURL) (INCLS TRAC CNTRL SW) [ПОДДОН] 19167127 BEZEL, A/TRNS CONT HSG (W/SHIF LOCK SOLENOID COV) 88967343 BASE, A/TRNS CONT (4.010) [БЛОК] 88967347 SOLENOID, A/TRNS SHFT LK CONT 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (A/TRNS RANGE SEL ROD ADJ) 15245219 LINK, A/TRNS RANGE SEL LVR 11519095 NUT-ACORN HEX, M8X1.0, 15MM THK, 9, 6047M, W/DOME. (A/TRNS RANGE SEL LVR) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL LVR CBL BRKT) [ГАЙКА М6] 88967341 BULB, A/TRNS CONT POSN IND (INCLS BULB W/BLUE COVER) (4.020) (ACDelco #88967341) [ЛАМПОЧКА ФАРЫ] 88967340 COVER, A/TRNS CONT LVR HDL (ЧАСТЬ OF 1) (6E04-007) - 2004-2006 E ТОРМОЗНЫЕ ШЛАНГИ И ТРУБКИ ↓ 15933099 HOSE, FRT BRK (INCLS 15, 16) (ACDelco #176-1495) 11569742 RETAINER, FRT BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (BRK & FUEL FEED & FUEL RTN & EVAP EMIS) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА] 25761218 BRACKET, FUEL PIPE 25761217 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (3.162) 12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (FRT BRK) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА] 10388788 PIPE, BRK PRESS MOD VLV FRT (INCLS 29) 10388794 PIPE, BRK PRESS MOD VLV RR (INCLS 29) 03541444 SPACER, FRT BRK PIPE 11516521 БОЛТ, HFH M6X1X20, 9.8, 7114M, DOG PT, 14.2 OD (FRT BRK HOSE) 15933098 HOSE, FRT BRK (INCLS 15, 16) (ACDelco #176-1487) 25743891 RETAINER, RR BRK FRT PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT) 15724653 FITTING, FRT BRK PIPE (ЧАСТЬ OF 1, 12) (7/16-24 X .36) (.30 THD, .56 LENGTH, .194 TUBE, STL, GM7113M) 25743891 RETAINER, FRT BRK PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT) 25737279 CLIP, FRT BRK PIPE (THREE WAY RETAINER SINGLE CENTRAL FIR-TREE ATTACHMENT) 15270078 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (USES RETAINER PIN FOR ATTACHMENT) [ЗАЖИМ ТРУБКИ ТОПЛИВНОЙ СИСТЕМЫ] 25688547 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (RETAINER W/5 HOLES (2)7.95, (2)4.76, (1)9.52MM) teamcadillac.ru 25749839 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (HOLDS 3 ТРУБКИ, FLAT SHAPE, SNAP-IN RETAINER) 25607191 RETAINER, BRK PIPE (21.5X10.0MM) (HOLDS (2) 4.68-4.82 TUBES) 11569742 RETAINER, RR BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 15724650 ГАЙКА, INVERTED FLARED TUBE, 9/16"-18, 1/4" TUBE, ZD (BRK PIPE) (4.686) [ГАЙКА] 25693890 RETAINER, RR BRK PIPE (HOLDS (1) 4.76 LINE) (W/TREE) [ЗАМОК, ФИКСАТОР] 11588803 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 7, 8) (1/2-20X.40, .32 THD) (INVERTED FLARED TUBE) (.62 LONG, 1/4 TUBE) [ГАЙКА М20] 15724650 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 7, 8) (9/16-18 X .40) (INVERTED FLARED TUBE) [ГАЙКА] 15933091 HOSE, RR BRK (INCLS 22, 23) (ACDelco #15933091) 15933092 HOSE, RR BRK (INCLS 22, 23) (ACDelco #15933092) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ] 88964150 PROTECTOR, FRT BRK PIPE (FOR 3/16" PIPE) (HT SHRINK) (6E04-008) - 2004-2006 E ТОРМОЗНАЯ ПЕДАЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (EXC (JF4)) ↓ 25732428 BARRIER, BRK PED BRKT SND 25697461 RETAINER, BRK PED PUSH ROD BOOT 25732452 BOOT, BRK PED PUSH ROD 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] 15932827 HOSE, P/B BOOS VAC (ACDelco #176-1496) 25765419 PEDAL, BRK (W/BRKT) (INCLS 10, 11, 14, 16-18) 25771615 COVER, BRK PED (ЧАСТЬ OF 9) 89047699 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 9) [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] teamcadillac.ru 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 9) 10434956 BUSHING, BRK PED PUSH ROD 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 9) 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 9) (0.80 IN) (PUSH IN) (6E04-010) - 2004-2006 E СТОЯНОЧНЫЙ ТОРМОЗ SYSTEM ↓ 10395687 LEVER, PARK BRK (INCLS 2-4, 13-15) teamcadillac.ru 15797212 CABLE, PARK BRK INTER (INCLS 5, 10, 11) (ACDelco #15797212) [ТРОС СТОЯНОЧНОГО ТОРМОЗА В СБОРЕ] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (PARK BRK INTER CBL GDE) [ГАЙКА М6] 11517484 БОЛТ-HEX, M6X1X20, 9 THD, 17 OD, 9.8, 6280M, MACH, P-PT (PARK BRK INTER CBL GDE) 25764260 CABLE, PARK BRK RR (28.2X28.5X811.7MM) (ACDelco #25764260) [ТРОС СТОЯНОЧНОГО ТОРМОЗА] 25880964 HANDLE, PARK BRK REL 89047821 CABLE, PARK BRK REL (ЧАСТЬ OF 1) (ACDelco #89047821) 22654577 SWITCH, PARK BRK IND (ЧАСТЬ OF 1) (ACDelco #22654577) [ВКЛЮЧАТЕЛЬ] 10369646 БОЛТ, PARK BRK IND SW (ЧАСТЬ OF 1) (6E04-011) - 2004-2006 E T.C.M. МОДУЛЬ ↓ 24239785 МОДУЛЬ, TRANS CONT 24240286 МОДУЛЬ, TRANS CONT teamcadillac.ru 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (MULTIUSE RLY & FUSE BRKT) [БОЛТ М6] (6E04-012) - 2004-2006 E КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS(MV3) ↓ 88996677 CASE, TRFER (FRT HALF) (INCLS 12-14) 19133265 CASE, TRFER (RR HALF) (INCLS 5, 7) 88996679 SNUBBER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN 88996680 БОЛТ, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN SNBR (M5X0.8X16) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 2) 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL FILL) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996657 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 2) [УПЛОТНИТЕЛЬ] 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL DRN) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996680 БОЛТ, TRFER CASE VENT BFL (M5X0.8X16) (4.535) 88996658 BAFFLE, TRFER CASE VENT teamcadillac.ru 89048123 БОЛТ, TRFER CASE HALF (M8X1.25X30) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 1) 88996656 SEAL, TRFER CASE INPUT SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 88996657 SEAL, TRFER CASE FRT ВЫХОДНОЙ SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] (6E04-014) - 2006 E КОРПУС КП КРЕПЛЕНИЕ (MV3) ↓ 11519347 БОЛТ, TRFER CASE (M10X1.5X65) (8.900) [БОЛТ] teamcadillac.ru (6E04-016) - 2004-2009 E КЛАПАН РЕГУЛИРОВКИ ДАВЛЕНИЯ В ТОРМОЗНОЙ СИСТЕМЕ ↓ 89060339 МОДУЛЬ KIT, ELEK BRK & TRACT CONT (REQS PROGRAMMING;BRK APPLY SEN REQS CALN;REFER TO SERV INFO) (ACDelco #89060339) [БЛОК УПРАВЛЕНИЯ ТОРМОЗНОЙ СИСТЕМОЙ] 89060233 VALVE KIT, BRK PRESS MOD (INCLS 3, 4) (ACDelco #89060233) [ГИДРАВЛИЧЕСКИЙ БЛОК АБС] 25743362 SENSOR, BRK PRESS MOD VLV PRESS (ЧАСТЬ OF 2) (ACDelco #25743362) [ДАТЧИК] 25741456 INSULATOR, BRK PRESS MOD VLV (ЧАСТЬ OF 2) 11588304 STUD, FLANGE DOUBLE END, M8X14 UNTHD, M8X1.25X13, 17 OD, 5.8, GM4345M (BRK PRESS MOD VLV BRKT) 11514596 ГАЙКА, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (BRK PRESS MOD VLV BRKT) (8.915) (ACDelco #11514596) teamcadillac.ru 11508351 SCREW, PAN HD, C/R, 5X0.8X13, 9.3 OD, FULL THD, THD RLLR, 6171M, PC (BRK PRESS MOD VLV) (8.977) (6E04-017) - 2004-2006 E ШЛАНГ ВЕНТИЛЯЦИИ ТРАНСМИССИИ ↓ 25764835 VENT, A/TRNS (INCLS 2, 3) (ACDelco #25764835) teamcadillac.ru 15955072 CLIP, TRANS VENT HOSE (ЧАСТЬ OF 1) (.650MM DIA) (2.343) (6E04-018) - 2004-2009 E КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS(MX5) ↓ teamcadillac.ru 88996677 CASE, TRFER (FRT HALF) (INCLS 12-14) 19133265 CASE, TRFER (RR HALF) (INCLS 5, 7) 88996679 SNUBBER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN 88996680 БОЛТ, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN SNBR (M5X0.8X16) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 2) 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL FILL) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996657 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 2) [УПЛОТНИТЕЛЬ] 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL DRN) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996680 БОЛТ, TRFER CASE VENT BFL (M5X0.8X16) (4.535) 88996658 BAFFLE, TRFER CASE VENT 89048123 БОЛТ, TRFER CASE HALF (M8X1.25X30) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 1) 88996656 SEAL, TRFER CASE INPUT SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 88996657 SEAL, TRFER CASE FRT ВЫХОДНОЙ SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 19180066 VENT, TRFER CASE 89048123 БОЛТ, TRFER CASE VIB DPNR (M8X1.25X30) 19133173 DAMPENER, TRFER CASE VIB (YOKE STYLE; БОЛТS TO RR OF T-CASE) (TRANS BUILT ON 3-22-06 & AFTER) (FOR 1ST DES SEE 89048182) 89048182 DAMPENER, TRFER CASE VIB (YOKE STYLE-БОЛТS TO RR OF T/CASE) (TRANS BUILT ON 3-21-06 & AFTER) (FOR 2ND DES SEE 19133173) (6E04-021) - 2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (LH2/4.6A, EXC V92) ↓ 11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16] 89022494 BRACKET, TRANS FLUID CLR 19129780 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) [ТРУБКА] 19129782 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) (WITH TRANS OIL COOLER EXTERNAL TO РАДИАТОР. FOR 2ND DES SEE 19129977.) [ТРУБКА МАСЛООХЛАДИТЕЛЯ] 19130214 SEAL, TRANS FLUID CLR HOSE CONN (O RING) 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] teamcadillac.ru 19129779 HOSE, TRANS FLUID CLR LWR (W/BLOCK) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 19129781 HOSE, TRANS FLUID CLR LWR (W/BLOCK) (WITH TRANS OIL COOLER EXTERNAL TO РАДИАТОР. FOR 2ND DES SEE 19129976) 88957425 COOLER, TRANS FLUID (INCLS 7-11) (ACDelco #88957425) [ВЕНТИЛЯТОР] (6E04-022) - 2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (V92) ↓ 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 89022494 BRACKET, TRANS FLUID CLR teamcadillac.ru 19129780 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) [ТРУБКА] 19129782 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) [ТРУБКА МАСЛООХЛАДИТЕЛЯ] 19130214 SEAL, TRANS FLUID CLR HOSE CONN (O RING) 19129779 HOSE, TRANS FLUID CLR LWR (W/BLOCK) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 19129781 HOSE, TRANS FLUID CLR LWR (W/BLOCK) 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 89022522 COOLER, TRANS FLUID (INCLS 7-10) (6E04-035) - 2005-2009 E BRAKE SYSTEM/ANTILOCK ↓ 12413103 HUB, FRT WHL (W/BRG) (СМ. ГРУППУ 06.000 "ПОДВЕСКА-ПЕРЕДНЯЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/WHL SPD SEN) (ACDelco #FW149) [СТУПИЦА КОЛЕСА] 12413105 HUB, FRT WHL (W/BRG) (СМ. ГРУППУ 06.000 "ПОДВЕСКА-ПЕРЕДНЯЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPEED SENSOR) (ACDelco #FW150) [СТУПИЦА КОЛЕСА] 89047639 HUB, RR WHL (W/WHL SPD SEN) (СМ. ГРУППУ 06.000 "ЗАДНЯЯ ПОДВЕСКА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6 STUD HUB) (ACDelco #RW20-19) [СТУПИЦА КОЛЕСА] 10307709 SENSOR, VEH YAW (W/VEH LATL ACCLRM) [ДАТЧИК] 15906579 SENSOR, VEH YAW (W/ VEH LATL & LGTDNL ACCLRM) [ДАТЧИК] teamcadillac.ru 11561645 ГАЙКА, HFH, M6X1X6.45, 13.5 OD, 10 STL, GMW3200 (VEH YAW SEN & LATL ACCLRM) (6E04-036) - 2005-2006 E ТОРМОЗНАЯ ПЕДАЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (JF4) ↓ 25732428 BARRIER, BRK PED BRKT SND 25697461 RETAINER, BRK PED PUSH ROD BOOT 25732452 BOOT, BRK PED PUSH ROD 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) teamcadillac.ru 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] 15932827 HOSE, P/B BOOS VAC (ACDelco #176-1496) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (ACCEL PED LVR) 10368488 PEDAL, BRK (INCLS 12, 13, 15, 18-22) 25771615 COVER, BRK PED (ЧАСТЬ OF 11) 89047699 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 11) (INCLS 18) [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 89047780 MOTOR KIT, BRK & ACCEL PED ADJR ACTR [ЭЛЕКТРОДВИГАТЕЛЬ ПЕДАЛЬНОГО УЗЛА 19 ВТ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 11, 13) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 11) 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 11) 25697461 RETAINER, BRK PED PUSH ROD BOOT (ЧАСТЬ OF 11) 89047779 CABLE, ACCEL CONT 89047778 CABLE, BRK PED ADJR ACTR [ЖГУТ ПРОВОДОВ] 25741052 BRACKET, BRK PED BRKT 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-018) - 2004-2006 E КОРПУС КП ЧАСТЬ 2 INTERNAL COMPONENTS(MV3) ↓ 88984517 WASHER, TRFER CASE PLNT CARR SUN GR THR (25.8X52.0X2.2) 88984524 GEAR, TRFER CASE PLNT CARR SUN (INPUT) (STAMPED PM/POWDERED METAL) 88984493 RING, TRFER CASE RR ВЫХОДНОЙ SHF RR BRG RET (41MM I.D.) (ACDelco #88984493) 88996564 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT 88996665 BEARING, TRFER CASE MAIN SHF FRT (ВЫХОДНОЙ ВАЛ FRT) 19168733 BUSHING, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 106) [ВТУЛКА РАЗДАТОЧНОЙ КОРОБКИ] 19178237 SHAFT, TRFER CASE RR ВЫХОДНОЙ (INCLS 105, 901) 19133264 SPROCKET, TRFER CASE FRT ВЫХОДНОЙ SHF DRV (INCLS 108) [ШЕСТЕРНЯ РАЗДАТОЧНОЙ КОРОБКИ] 19168732 BUSHING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT (ЧАСТЬ OF 107) (ACDelco #19168732) teamcadillac.ru 89059578 CHAIN, TRFER CASE TWO/FOUR WHL DRV [ЦЕПЬ РАЗДАТОЧНОЙ КОРОБКИ] 88984523 GEAR, TRFER CASE PLNT CARR SUN (ВЫХОДНОЙ) 89059279 КРОНШТЕЙН, FRT/RR DRV DIFF 89059284 SHAFT, TRFER CASE FRT ВЫХОДНОЙ (INCLS 900) 88996664 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF RR 88996671 RING, TRFER CASE FRT ВЫХОДНОЙ SHF BRG RET 88996666 SPROCKET, TRFER CASE TWO/FOUR WHL DRV DRVN [ЗВЕЗДОЧКА] 88996633 BEARING, TRFER CASE RR ВЫХОДНОЙ SHF RR (ACDelco #88996633) [ПОДШИПНИК РАЗДАТОЧНОЙ КОРОБКИ] 15580230 BEARING, TRFER CASE INPUT SHF (BORG-WARNER) (4.510) 19132966 SHAFT, TRFER CASE INPUT 88996681 DEFLECTOR, TRFER CASE FRT ВЫХОДНОЙ SHF SEAL DIRT (ЧАСТЬ OF 112) (6M04-041) - 2004-2006 E26 ТОРМОЗНАЯ ПЕДАЛЬ (PWR ADJ PEDALS JF4) ↓ 25741052 BRACKET, BRK PED BRKT 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 25732428 BARRIER, BRK PED BRKT SND 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 89047778 CABLE, BRK PED ADJR ACTR [ЖГУТ ПРОВОДОВ] 89047780 MOTOR KIT, BRK & ACCEL PED ADJR ACTR [ЭЛЕКТРОДВИГАТЕЛЬ ПЕДАЛЬНОГО УЗЛА 19 ВТ] teamcadillac.ru 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (BRK PED POSN SEN) 89047699 SENSOR KIT, BRK PED POSN [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 25697461 RETAINER, BRK PED PUSH ROD BOOT (ЧАСТЬ OF 21) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 21) 10368488 PEDAL, BRK (INCLS 5, 8-10, 13, 15-20, 22) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-042) - 2004-2006 E26 ТОРМОЗНАЯ ПЕДАЛЬ (EXC PWR ADJ PEDALS JF4) ↓ 25741052 BRACKET, BRK PED BRKT 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 25732428 BARRIER, BRK PED BRKT SND 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 18) 89047699 SENSOR KIT, BRK PED POSN [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] teamcadillac.ru 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 18) (0.80 IN) (PUSH IN) 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 18) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 18) 25771615 COVER, BRK PED (ЧАСТЬ OF 18) 25765419 PEDAL, BRK (W/BRKT) (INCLS 5-8, 10, 12-17, 19) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-044) - 2004-2009 E26 ТОРМОЗНОЙ УСИЛИТЕЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА ↓ teamcadillac.ru 88967237 BOOSTER, P/B (СМ. ГРУППУ 04.000 "ТОРМОЗНОЙ УСИЛИТЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/O VLV) (ACDelco #178-0695) 25732452 BOOT, BRK PED PUSH ROD 25697461 RETAINER, BRK PED PUSH ROD BOOT 10367561 CYLINDER, BRK MAS (СМ. ГРУППУ 4.000 "ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #174-1012) [ЦИЛИНДР] 11517996 ГАЙКА, BRK M/CYL (M10X1.5, 11.2 THK) (8.917) [ГАЙКА М10] 25873484 HOSE, P/B BOOS VAC (ACDelco #176-1497) (GM00-031) - 2006 E ТРАНСМИССИЯ TO КРЕПЛЕНИЕ ДВИГАТЕЛЯ (LH2/4.6A) ↓ 12582606 FLYКОЛЕСО, ENG 25771275 BRACKET, ENG WRG HARN (USED IN GENERATOR PACKAGE) 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] 24205900 COVER, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] teamcadillac.ru 11589116 БОЛТ, FLYWHL (8.900) 12568122 COVER, FLYWHL HSG 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (TRANS CONV CVR) (ACDelco #11517518) [БОЛТ] 12568123 COVER, TRANS CONV (GM04-064) - 2004-2009 E ТОРМОЗНОЙ СУППОРТ-ПЕРЕДНИЙ ↓ teamcadillac.ru 18047980 CALIPER, FRT BRK (INCLS 2-4, 8-10) (IF DISCONTINUED USE DURASTOP EQUIVALENT) (4.667) (ACDelco #172-1643) [ТОРМОЗНОЙ СУППОРТ] 18047981 CALIPER, FRT BRK (INCLS 2-4, 8-10) (IF DISCONTINUED USE DURASTOP EQUIVALENT) (4.667) (ACDelco #172-1644) [ТОРМОЗНОЙ СУППОРТ] 18043178 COVER, FRT BRK BLEDR SCREW (ЧАСТЬ OF 1) 18047986 VALVE KIT, FRT BRK CLPR BLEDR (ЧАСТЬ OF 1) (ACDelco #18047986) 18046750 БОЛТ, FRT BRK CLPR GDE PIN (ЧАСТЬ OF 1, 11) (*KIT2) [БОЛТ] 18047985 PISTON KIT, FRT BRK CLPR (ЧАСТЬ OF 1) 18047988 PAD KIT, FRT DISC BRK (INCLS 4, 14) (ACDelco #171-665) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4 ШТ)] 19122384 PAD KIT, FRT DISC BRK (INCLS 4, 14) (ACDelco #171-688) 18045221 SEAL, FRT BRK CLPR GDE PIN 18047987 BRACKET, FRT BRK CLPR (W/GUIDE PIN БОЛТS) [КРОНШТЕЙН] 18046698 ПРУЖИНА, FRT DISC BRK PAD RET (ЧАСТЬ OF 11) (ACDelco #179-2235) 18047989 PIN KIT, FRT BRK CLPR GDE (INCLS 5-7) (INCLS 2 (2.5") БОЛТS) 18047984 CALIPER KIT, FRT BRK (INCLS 4, 8, 9) (4.667) (ACDelco #173-0538) (GM04-312) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (5L50-E M22,5L40-E M82) ↓ teamcadillac.ru 96042884 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 6GDZ) 96042897 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 6GRG) (GM04-376) - 2004-2009 E ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР ↓ 18012741 SWITCH, BRK FLUID LVL IND (ЧАСТЬ OF 15) (ACDelco #18012741) 22688449 CAP, BRK M/CYL RSVR (ЧАСТЬ OF 15) (INCLS 3) [КРЫШКА БАЧКА ТОРМОЗНОЙ ЖИДКОСТИ] 18046711 RESERVOIR, BRK M/CYL (ЧАСТЬ OF 15) (INCLS 4, 6-7) (ACDelco #18046711) teamcadillac.ru 18060168 PISTON, BRK M/CYL SECD (ЧАСТЬ OF 15) 10367561 CYLINDER, BRK MAS (INCLS 1-14) (ACDelco #174-1012) [ЦИЛИНДР] 18022002 CYLINDER KIT, BRK MAS (INCLS 8-12) (ACDelco #175-424) (GM04-485) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (5L50-E MV3,5L40-E MX5) ↓ 96042890 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 6GGG) [АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ В СБОРЕ] 96042893 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 6GFZ) [ТРАНСМИССИЯ В СБОРЕ] (GM04-573) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042861 GASKET, A/TRNS CASE EXTN 24237771 BEARING, ВЫХОДНОЙ SHF (ЧАСТЬ OF 27) 96042882 EXTENSION, A/TRNS CASE (INCLS 26, 28, 29) (4.003) 24237771 BEARING, ВЫХОДНОЙ SHF (ЧАСТЬ OF 27) 96041851 SEAL, PROP SHF TRANS FLG FLUID (ЧАСТЬ OF 27) [ПРОКЛАДКА ТРАНСФОРМАТОРНОГО ВАЛА] 96042984 FLANGE, ВЫХОДНОЙ SHF 96041805 NUT KIT, ВЫХОДНОЙ SHFT (INCLS 30, 32, 33) (M6X1.0X16) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96042962 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) 96042712 DETENT, MAN SHFT teamcadillac.ru 96017928 CLIP, WRG HARN 96042847 HARNESS, A/TRNS WRG 96041849 SEAL, A/TRNS WRG CONN (O RING) 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) (GM04-573) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042861 GASKET, A/TRNS CASE EXTN (*KIT1) 24237771 BEARING, ВЫХОДНОЙ SHF (ЧАСТЬ OF 27) 96042860 EXTENSION, A/TRNS CASE (INCLS 26, 28, 29) 24237771 BEARING, ВЫХОДНОЙ SHF (ЧАСТЬ OF 27) 96041851 SEAL, PROP SHF TRANS FLG FLUID (ЧАСТЬ OF 27) (*KIT1) [ПРОКЛАДКА ТРАНСФОРМАТОРНОГО ВАЛА] teamcadillac.ru 96042984 FLANGE, ВЫХОДНОЙ SHF 96041805 NUT KIT, ВЫХОДНОЙ SHFT (INCLS 30, 32, 33) (M6X1.0X16) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) (*KIT1) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) (*KIT1) 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96042963 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPACER PLATE & GASKET) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) 96042712 DETENT, MAN SHFT 96017928 CLIP, WRG HARN 96042847 HARNESS, A/TRNS WRG 96041849 SEAL, A/TRNS WRG CONN (O RING) (*KIT1) 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN (*KIT1) [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (*KIT1) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (*KIT1) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) 96042945 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/GSKT, SEAL, RET) (INCLS 25, 29, 36, 38, 46, 56, 60, 63, 64) (GM04-574) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042887 GASKET, A/TRNS CASE EXTN [ПРОКЛАДКА КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042896 EXTENSION, A/TRNS CASE (INCLS 28, 69) 24237771 BEARING, ВЫХОДНОЙ SHF (ЧАСТЬ OF 27) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96042962 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) 96042712 DETENT, MAN SHFT 96017928 CLIP, WRG HARN 96042847 HARNESS, A/TRNS WRG 96041849 SEAL, A/TRNS WRG CONN (O RING) 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) 96042543 WASHER, INPUT & REACTION CARR THR teamcadillac.ru 96042587 SEAL, PROP SHF TRANS FLG FLUID [ПРОКЛАДКА КРЫШКИ РАЗДАТОЧНОЙ КОРОБКИ] (GM04-574) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042887 GASKET, A/TRNS CASE EXTN [ПРОКЛАДКА КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042888 EXTENSION, A/TRNS CASE (INCLS 28, 69) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96042963 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPACER PLATE & GASKET) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) 96042712 DETENT, MAN SHFT 96017928 CLIP, WRG HARN 96042847 HARNESS, A/TRNS WRG teamcadillac.ru 96041849 SEAL, A/TRNS WRG CONN (O RING) 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) 96042543 WASHER, INPUT & REACTION CARR THR 96042587 SEAL, PROP SHF TRANS FLG FLUID [ПРОКЛАДКА КРЫШКИ РАЗДАТОЧНОЙ КОРОБКИ] 08677884 BEARING, ВЫХОДНОЙ SHF THR (ЧАСТЬ OF 27) (4.180) (ACDelco #8677884) (GM04-575) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ 96042553 CONVERTER, TORQ (REMAN) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042835 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) 96042806 СЦЕПЛЕНИЕ, DIR & REV teamcadillac.ru 96042831 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) 96042823 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) 96042824 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) 96042701 WASHER, INPUT & REACTION CARR INR SHF THR 96042808 ШЛАНГИ, O/D CLU 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) 96042705 BEARING, CTR SUPT RLR (4.180) 96042826 SUPPORT, CTR 96042832 КРОНШТЕЙН, INPUT & REACTION 96042833 BEARING, INPUT & REACTION CARR THR 96042834 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) 96042543 WASHER, INPUT & REACTION CARR THR 96042833 BEARING, INPUT & REACTION CARR THR 96042883 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/GSKT, SEAL, RET) (GM04-575) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ 96042554 CONVERTER, TORQ (REMAN) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) teamcadillac.ru 96042812 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) 96042806 СЦЕПЛЕНИЕ, DIR & REV (СМ. ГРУППУ 04.000 "DIRECT AND REVERSE СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042807 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (СМ. ГРУППУ 04.000 "FORWARD AND COAST СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042698 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) (СМ. ГРУППУ 04.000 "INPUT SUN GEAR SHAFT AND FORWARD SPRAG СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (СМ. ГРУППУ 04.000 "DIRECT СЦЕПЛЕНИЕ DRUM AND SHAFT" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042701 WASHER, INPUT & REACTION CARR INR SHF THR 96042808 ШЛАНГИ, O/D CLU (СМ. ГРУППУ 04.000 "OVERDRIVE AND INTERMEDIATE СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (СМ. ГРУППУ 04.000 "LOW СЦЕПЛЕНИЕ SPRAG" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042705 BEARING, CTR SUPT RLR (4.180) 96042809 SUPPORT, CTR (СМ. ГРУППУ 04.000 "CENTER SUPPORT" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042707 КРОНШТЕЙН, INPUT & REACTION (СМ. ГРУППУ 04.000 "PLANETARY КРОНШТЕЙН" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (4.176) 96042708 BEARING, INPUT & REACTION CARR THR 96042709 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (СМ. ГРУППУ 04.000 "ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96041847 WASHER, INPUT & REACTION CARR THR (4.265) (GM04-576) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ 96042553 CONVERTER, TORQ (REMAN) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042835 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) teamcadillac.ru 96042814 СЦЕПЛЕНИЕ, DIR & REV 96042822 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) 96042823 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) 96042824 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) 96042701 WASHER, INPUT & REACTION CARR INR SHF THR 96042808 ШЛАНГИ, O/D CLU 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) 96042826 SUPPORT, CTR 96042827 КРОНШТЕЙН, INPUT & REACTION 96042818 BEARING, INPUT & REACTION CARR THR 96042837 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) 96042543 WASHER, INPUT & REACTION CARR THR 96042818 BEARING, INPUT & REACTION CARR THR (GM04-576) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ 96042554 CONVERTER, TORQ (REMAN) teamcadillac.ru 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042812 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) 96042814 СЦЕПЛЕНИЕ, DIR & REV 96042815 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) 96042698 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) (INCLS 9) 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) 96042701 WASHER, INPUT & REACTION CARR INR SHF THR 96042808 ШЛАНГИ, O/D CLU 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) 08677884 BEARING, LOW CLU RLR THR (*KIT1) (ACDelco #8677884) 96042816 SUPPORT, CTR 96042817 КРОНШТЕЙН, INPUT & REACTION 96042818 BEARING, INPUT & REACTION CARR THR 96042813 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) 96042543 WASHER, INPUT & REACTION CARR THR 96042818 BEARING, INPUT & REACTION CARR THR (GM04-577) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ 24209145 ФИЛЬТР, PRESS CONT SOL VLV FLUID (ACDelco #24209145) [ФИЛЬТР] 24212478 SLIDE, A/TRNS ГИДРОНАСОС (17.9545MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212478) 24212479 SLIDE, A/TRNS ГИДРОНАСОС (17.9675MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212479) 24212480 SLIDE, A/TRNS ГИДРОНАСОС (17.9805MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212480) 24212481 SLIDE, A/TRNS ГИДРОНАСОС (17.9935MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212481) 24212482 SLIDE, A/TRNS ГИДРОНАСОС (18.0065MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212482) teamcadillac.ru 24201144 RING, A/TRNS ГИДРОНАСОС VANE (RING, PUMP VANE) (ACDelco #24201144) 08631280 VANE, A/TRNS ГИДРОНАСОС (ACDelco #8631280) 24205410 GUIDE, A/TRNS ГИДРОНАСОС ROT (13 VANE) (ACDelco #24205410) 96015215 БОЛТ, A/TRNS ГИДРОНАСОС (4.115) 96041855 SEAL, T/CV FLUID [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042835 ШЛАНГИ KIT, T/CV (INCLS 200-212, 214-215, 217-220, 223, 226, 227, 231-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-577) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ 24209145 ФИЛЬТР, PRESS CONT SOL VLV FLUID (*KIT1) (ACDelco #24209145) [ФИЛЬТР] 24212478 SLIDE, A/TRNS ГИДРОНАСОС (17.9545MM) (SLIDE ID MARK = 1 DIMPLE) (*KIT1) (ACDelco #24212478) 24212479 SLIDE, A/TRNS ГИДРОНАСОС (17.9675MM) (SLIDE ID MARK = 1 DIMPLE) (*KIT1) (ACDelco #24212479) 24212480 SLIDE, A/TRNS ГИДРОНАСОС (17.9805MM) (SLIDE ID MARK = 1 DIMPLE) (*KIT1) (ACDelco #24212480) 24212481 SLIDE, A/TRNS ГИДРОНАСОС (17.9935MM) (SLIDE ID MARK = 1 DIMPLE) (*KIT1) (ACDelco #24212481) 24212482 SLIDE, A/TRNS ГИДРОНАСОС (18.0065MM) (SLIDE ID MARK = 1 DIMPLE) (*KIT1) (ACDelco #24212482) 24201144 RING, A/TRNS ГИДРОНАСОС VANE (RING, PUMP VANE) (*KIT1) (ACDelco #24201144) 08631280 VANE, A/TRNS ГИДРОНАСОС (*KIT1) (ACDelco #8631280) 24205410 GUIDE, A/TRNS ГИДРОНАСОС ROT (13 VANE) (*KIT1) (ACDelco #24205410) 96041855 SEAL, T/CV FLUID (*KIT1) [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] teamcadillac.ru 96042835 ШЛАНГИ KIT, T/CV (INCLS 200-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-577) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ 96015215 БОЛТ, T/CV FLUID SEAL (*KIT1) 96041855 SEAL, T/CV FLUID [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] teamcadillac.ru 96042812 ШЛАНГИ KIT, T/CV (INCLS 200-215, 217-220, 223, 226-228, 231-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-577) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ 24212478 SLIDE, A/TRNS ГИДРОНАСОС (17.9545MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212478) 24212479 SLIDE, A/TRNS ГИДРОНАСОС (17.9675MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212479) 24212480 SLIDE, A/TRNS ГИДРОНАСОС (17.9805MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212480) 24212481 SLIDE, A/TRNS ГИДРОНАСОС (17.9935MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212481) 24212482 SLIDE, A/TRNS ГИДРОНАСОС (18.0065MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212482) 24201144 RING, A/TRNS ГИДРОНАСОС VANE (RING, PUMP VANE) (ACDelco #24201144) 08631280 VANE, A/TRNS ГИДРОНАСОС (ACDelco #8631280) teamcadillac.ru 24205410 GUIDE, A/TRNS ГИДРОНАСОС ROT (13 VANE) (ACDelco #24205410) 24201144 RING, A/TRNS ГИДРОНАСОС VANE (RING, PUMP VANE) (ACDelco #24201144) 96015215 БОЛТ, T/CV FLUID SEAL (*KIT1) 96041855 SEAL, T/CV FLUID [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042812 ШЛАНГИ KIT, T/CV (INCLS 200-215, 217-220, 223, 226-228, 231-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-578) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 96020027 БОЛТ, C/VLV CHAN PLT 24209145 ФИЛЬТР, PRESS CONT SOL VLV FLUID (*KIT2) (ACDelco #24209145) [ФИЛЬТР] 24209145 ФИЛЬТР, PRESS CONT SOL VLV FLUID (*KIT2) (ACDelco #24209145) [ФИЛЬТР] teamcadillac.ru 96025325 БОЛТ, DIR CLU ACCUM (4.265) 96042987 GASKET KIT, A/TRNS (INCLS 303, 305, 306, 308, 309, 312, 314, 316, 330, 332) (4.265) (GM04-578) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 96020027 БОЛТ, C/VLV CHAN PLT 24209145 ФИЛЬТР, PRESS CONT SOL VLV FLUID (*KIT2) (ACDelco #24209145) [ФИЛЬТР] 24209145 ФИЛЬТР, PRESS CONT SOL VLV FLUID (*KIT2) (ACDelco #24209145) [ФИЛЬТР] teamcadillac.ru 96025325 БОЛТ, DIR CLU ACCUM (4.265) 96042987 GASKET KIT, A/TRNS (INCLS 303, 305, 306, 308, 309, 312, 314, 316, 330, 332) (4.265) (GM04-578) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 300-309, 312-334) (INCLS SPACER PLATE & GASKET) 96042986 GASKET KIT, A/TRNS (INCLS 303, 305, 306, 308, 309, 312, 314, 316, 330, 332) (4.265) (GM04-578) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 300-334) (INCLS SPACER PLATE & GASKET) 96042986 GASKET KIT, A/TRNS (INCLS 303, 305, 306, 308, 309, 312, 314, 316, 330, 332) (4.265) (GM04-579) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 10475842 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (14 MM I.D.) (INR) (ACDelco #10475842) 10475842 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (14 MM I.D.) (INR) (ACDelco #10475842) 96042599 VALVE, TCC PWM SOL 10475842 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (14 MM I.D.) (INR) (ACDelco #10475842) 10475842 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (14 MM I.D.) (INR) (ACDelco #10475842) 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] (GM04-579) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 10475842 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (14 MM I.D.) (INR) (ACDelco #10475842) 10475842 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (14 MM I.D.) (INR) (ACDelco #10475842) 96042599 VALVE, TCC PWM SOL 10475842 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (14 MM I.D.) (INR) (ACDelco #10475842) 10475842 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (14 MM I.D.) (INR) (ACDelco #10475842) 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] (GM04-579) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 96042599 VALVE, TCC PWM SOL teamcadillac.ru 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 340-351, 353-356) (INCLS SPACER PLATE & GASKET) (GM04-579) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 10471813 SEAL, TCC SOL VLV (O RING) (SMALL DIA) (OTR) (ACDelco #10471813) 10475842 SEAL, TCC SOL VLV (O RING) (14 MM I.D.) (INR) (ACDelco #10475842) 96042599 VALVE, TCC PWM SOL 10471813 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (SMALL DIA) (OTR) (ACDelco #10471813) 10475842 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (14 MM I.D.) (INR) (ACDelco #10475842) 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 340-348, 351, 353-354) (INCLS SPACER PLATE & GASKET) (GM04-580) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 10475842 SEAL, TCC SOL VLV (O RING) (14 MM I.D.) (INR) (ACDelco #10475842) 10475842 SEAL, TCC SOL VLV (O RING) (14 MM I.D.) (INR) (ACDelco #10475842) teamcadillac.ru 08680781 RETAINER, 2-3 SHFT SOL VLV (ACDelco #8680781) 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] (GM04-580) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 10475842 SEAL, TCC SOL VLV (O RING) (14 MM I.D.) (INR) (ACDelco #10475842) teamcadillac.ru 10475842 SEAL, TCC SOL VLV (O RING) (14 MM I.D.) (INR) (ACDelco #10475842) 08680781 RETAINER, 2-3 SHFT SOL VLV (ACDelco #8680781) 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] (GM04-580) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 343, 349, 350, 365-367, 370-375, 377-388) (INCLS SPACER PLATE & GASKET) (GM04-580) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 10471813 SEAL, TCC SOL VLV (O RING) (SMALL DIA) (OTR) (ACDelco #10471813) 10475842 SEAL, TCC SOL VLV (O RING) (14 MM I.D.) (INR) (ACDelco #10475842) 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 343, 351, 365-367, 370-375, 377-388) (INCLS SPACER PLATE & GASKET) 96042889 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/PLT, GSKT, SEAL) (INCLS 343, 351, 365-367, 370-375, 377-388) (GM04-581) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru (GM04-581) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru 96042814 СЦЕПЛЕНИЕ, DIR & REV (INCLS 400-420) (GM04-581) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru 96042806 СЦЕПЛЕНИЕ, DIR & REV (INCLS 400-420) (GM04-581) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru 96042814 СЦЕПЛЕНИЕ, DIR & REV (INCLS 400-420) (GM04-582) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96042831 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-432, 434-451) teamcadillac.ru 96042883 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/GSKT, SEAL, RET) (GM04-582) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯLY ↓ teamcadillac.ru 96042822 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-451) (GM04-582) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96041856 SEAL, INPUT SHF (O RING) (*KIT1) [ПРОКЛАДКА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] teamcadillac.ru 96042807 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-451) (GM04-582) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042815 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-451) (GM04-583) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru (GM04-583) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042827 КРОНШТЕЙН, INPUT & REACTION (INCLS 455-462) (GM04-583) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96042707 КРОНШТЕЙН, INPUT & REACTION (INCLS 455-462) (4.176) (GM04-583) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042817 КРОНШТЕЙН, INPUT & REACTION (INCLS 455-462) (GM04-584) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ teamcadillac.ru 96042824 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-584) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ 96042824 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-584) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ teamcadillac.ru 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-584) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ teamcadillac.ru 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-585) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ (GM04-585) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042825 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 470-477) (GM04-585) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 470-477) (GM04-585) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 470-477) (GM04-586) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru (GM04-586) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042825 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 480-497) (GM04-586) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 480-497) (GM04-586) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 480-497) (GM04-587) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК ↓ teamcadillac.ru (GM04-587) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК ↓ 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (INCLS 500-505) (GM04-587) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК ↓ teamcadillac.ru 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (INCLS 500-505) (GM04-587) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК ↓ teamcadillac.ru 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (INCLS 500-505) (GM04-588) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) КРЕПЛЕНИЕ ↓ teamcadillac.ru 96042826 SUPPORT, CTR (INCLS 510-517, 519-535) (GM04-588) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) КРЕПЛЕНИЕ ↓ teamcadillac.ru 96042826 SUPPORT, CTR (INCLS 510-535) (GM04-588) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) КРЕПЛЕНИЕ ↓ teamcadillac.ru 96042809 SUPPORT, CTR (INCLS 510-535) (GM04-588) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) КРЕПЛЕНИЕ ↓ teamcadillac.ru 96042816 SUPPORT, CTR (INCLS 510-535) (GM04-589) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) PLANETARY КРОНШТЕЙН БЛОК ↓ teamcadillac.ru 96042832 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-552, 554) (GM04-589) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) PLANETARY КРОНШТЕЙН БЛОК ↓ teamcadillac.ru 96042827 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-554) (GM04-589) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) PLANETARY КРОНШТЕЙН БЛОК ↓ teamcadillac.ru 96042707 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-554) (4.176) (GM04-589) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) PLANETARY КРОНШТЕЙН БЛОК ↓ teamcadillac.ru 96042817 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-554) (GM04-590) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК ↓ teamcadillac.ru 96042834 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560, 561, 563, 564) (GM04-590) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК ↓ teamcadillac.ru 96042709 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560-564) (GM04-591) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК ↓ teamcadillac.ru 96042837 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560-564) (GM04-591) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК ↓ teamcadillac.ru 96042813 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560-561, 563-564) (GM04-593) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) PARKING PAWL БЛОК ↓ 96042710 LEVER, MAN SHFT DTNT 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] teamcadillac.ru 96042540 SWITCH, A/TRNS MAN SHFT SHF POSN [ВЫКЛЮЧАТЕЛЬ ПРИВОДА] 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 08644709 SEAL, MAN SHFT SHF (W/O PTFE LUBRICANT APPLIED TO SEAL) (ACDelco #8644709) 96041857 SHAFT, MAN SHFT 96041852 PLUG, MAN SHFT SHF HOLE (4.279) (GM04-593) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) PARKING PAWL БЛОК ↓ 96042710 LEVER, MAN SHFT DTNT 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 96042540 SWITCH, A/TRNS MAN SHFT SHF POSN [ВЫКЛЮЧАТЕЛЬ ПРИВОДА] 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] teamcadillac.ru 08644709 SEAL, MAN SHFT SHF (W/O PTFE LUBRICANT APPLIED TO SEAL) (ACDelco #8644709) 96041857 SHAFT, MAN SHFT 96042711 PAWL KIT, PARK 96041852 PLUG, MAN SHFT SHF HOLE (4.279) 96041842 SPACER, MAN SHFT DTNT LVR (GM04-594) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) PARKING PAWL БЛОК ↓ 96042710 LEVER, MAN SHFT DTNT 96042819 LEVER, MAN SHFT DTNT 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 96042540 SWITCH, A/TRNS MAN SHFT SHF POSN [ВЫКЛЮЧАТЕЛЬ ПРИВОДА] 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 08644709 SEAL, MAN SHFT SHF (W/O PTFE LUBRICANT APPLIED TO SEAL) (ACDelco #8644709) 96042544 SHAFT KIT, MAN SHFT 96042820 PAWL KIT, PARK (GM04-594) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) PARKING PAWL БЛОК ↓ 96042710 LEVER, MAN SHFT DTNT teamcadillac.ru 96042819 LEVER, MAN SHFT DTNT 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 96042540 SWITCH, A/TRNS MAN SHFT SHF POSN [ВЫКЛЮЧАТЕЛЬ ПРИВОДА] 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 08644709 SEAL, MAN SHFT SHF (W/O PTFE LUBRICANT APPLIED TO SEAL) (ACDelco #8644709) 96042544 SHAFT KIT, MAN SHFT 96042820 PAWL KIT, PARK 04 - КОРПУС КП ↓ (6D04-023) - 2004-2009 E СТОЯНОЧНЫЙ ТОРМОЗ ASM ↓ 88951984 PLATE, RR PARK BRK ANC BKG (4.591) 88951985 PLATE, RR PARK BRK ANC BKG (4.591) teamcadillac.ru 88951982 ACTUATOR KIT, RR PARK BRK (INCLS 2) (ACDelco #179-2053) [АКТУАТОР] 88951983 ACTUATOR KIT, RR PARK BRK (INCLS 2) (ACDelco #179-2054) [АКТУАТОР] 89047676 SHOE KIT, RR PARK BRK (INCLS 5) (ACDelco #171-0915) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (2 ШТ)] (6D04-031) - 2004-2009 E ТОРМОЗНОЙ СУППОРТ-ЗАДНИЙ ↓ 89047677 CALIPER KIT, RR BRK (INCLS 2, 3, 7-9) (ACDelco #172-2343) 89047678 CALIPER KIT, RR BRK (INCLS 2, 3, 7-9) (ACDelco #172-2344) [ТОРМОЗНОЙ СУППОРТ] 88951992 CAP, RR BRK BLEDR VLV (ЧАСТЬ OF 1) 88951991 VALVE, RR BRK CLPR BLEDR (ЧАСТЬ OF 1) teamcadillac.ru 89047757 PAD KIT, RR DISC BRK (INCLS 4, 12) (ACDelco #171-859) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4 ШТ)] 89047758 PAD KIT, RR DISC BRK (INCLS 4, 12) (4.667) (ACDelco #171-0906) [ТОРМОЗНЫЕ КОЛОДКИ] 88957163 BRACKET, RR BRK CLPR [СКОБА ТОРМОЗНОГО СУППОРТА] 89047759 PIN KIT, RR BRK CLPR GDE (INCLS 4-6) (INCLS 2 PINS, 2 SEALS & 2 (2.75") БОЛТS) (ACDelco #179-2044) [НАПРАВЛЯЮЩАЯ ТОРМОЗНОГО СУППОРТА (2 ШТ)] 88957162 REPAIR KIT, RR BRK CLPR HYD (INCLS 4, 6, 8, 9) (6D04-033) - 2004-2009 E ТОРМОЗНОЙ УСИЛИТЕЛЬ ↓ 88967237 BOOSTER, P/B (W/O VLV) (ACDelco #178-0695) 05461808 GROMMET, P/B BOOS VAC CHK VLV (*KIT1) teamcadillac.ru 03817880 RETAINER, BRK PED PUSH ROD (0.80 IN) (PUSH IN) 18022219 VALVE KIT, P/B BOOS VAC CHK (INCLS 2, 3) (BLACK) (INCLS VLV & GROM) (ACDelco #179-1266) (6D04-067) - 2006-2009 E КОРПУС КП КРЕПЛЕНИЕ (MX5) ↓ 24231525 GASKET, TRFER CASE 19132968 CASE, TRFER (W/GEARS) (LESS DAMPENER) (UNITS BUILT ON 3-22-06 & AFTER) (FOR 1ST DES SEE 24234010) teamcadillac.ru 24234010 CASE, TRFER (W/GEARS) (UNITS BUILT ON 3-21-06 & PRIOR) (FOR 2ND DES SEE 24238468) 11589341 БОЛТ - HFH, M10X1.5X69.9, 28.35 THD, 22.3 OD, 10.9, GMW3359, M-PT. (TRFER CASE) [БОЛТ] (6D04-068) - 2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (LY7/3.6-7, EXC V92)(WITH INTERNAL COOLER)(2ND DES) ↓ 19129976 HOSE, TRANS FLUID CLR LWR (W/BLOCK) (INCLS 7) (WITH TRANS OIL COOLER IN РАДИАТОР. FOR 1ST DES SEE 19129781.) 11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16] 89022494 BRACKET, TRANS FLUID CLR 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 25740416 SEAL, TRANS FLUID CLR PIPE (O RING) (1/2IN) (9.222) (ACDelco #15-31872) [ПРОКЛАДКА КОМПРЕССОРА КОНДИЦИОНЕРА] 19129977 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) (WITH TRANS OIL COOLER IN РАДИАТОР. FOR 1ST DES SEE 19129782.) teamcadillac.ru (6E00-014) - 2004-2009 E ТРАНСМИССИЯ TO КРЕПЛЕНИЕ ДВИГАТЕЛЯ (LY7/3.6-7) ↓ 12572042 PLATE, A/TRNS FLEX 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) teamcadillac.ru 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (TRANS CVR) [БОЛТ] 24222918 COVER, TRANS CONV 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] (6E04-003) - 2004-2006 E УПРАВЛЕНИЕ АКПП/АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22,M82) ↓ 19121866 KNOB PKG, A/TRNS CONT LVR (INCLS 2, 13) (CASHMERE) 88967336 KNOB PKG, A/TRNS CONT LVR (INCLS 2, 13) (EBONY/BURL WALNUT) 88967337 KNOB PKG, A/TRNS CONT LVR (INCLS 2, 13) (EBONY LEATHER) 88967339 БОЛТ, A/TRNS CONT LVR KNOB (ЧАСТЬ OF 1) 25772994 PLATE, F/FLR CNSL TRANS SHFT OPG TR (INCLS TRAC CONT SWITCH) 25772995 PLATE, F/FLR CNSL TRANS SHFT OPG TR (WALNUT BURL) (INCLS TRAC CNTRL SW) [ПОДДОН] teamcadillac.ru 88967342 BASE, A/TRNS CONT (INCLS 4, 6, 7) (4.010) 88967347 SOLENOID, A/TRNS SHFT LK CONT (ЧАСТЬ OF 5) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (A/TRNS RANGE SEL ROD ADJ) 15245220 LINK, A/TRNS RANGE SEL LVR [ШАРНИР,КУЛИСА] 11519095 NUT-ACORN HEX, M8X1.0, 15MM THK, 9, 6047M, W/DOME. (A/TRNS RANGE SEL LVR) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL LVR CBL BRKT) [ГАЙКА М6] 88967341 BULB, A/TRNS CONT POSN IND (INCLS BULB W/BLUE COVER) (4.020) (ACDelco #88967341) [ЛАМПОЧКА ФАРЫ] 88967340 COVER, A/TRNS CONT LVR HDL (ЧАСТЬ OF 1) (6E04-004) - 2004-2006 E УПРАВЛЕНИЕ АКПП/АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3,MX5) ↓ 19121866 KNOB PKG, A/TRNS CONT LVR (INCLS 2, 13) (CASHMERE) 88967336 KNOB PKG, A/TRNS CONT LVR (INCLS 2, 13) (EBONY/BURL WALNUT) 88967337 KNOB PKG, A/TRNS CONT LVR (INCLS 2, 13) (EBONY LEATHER) 88967339 БОЛТ, A/TRNS CONT LVR KNOB (ЧАСТЬ OF 1) 25772994 PLATE, F/FLR CNSL TRANS SHFT OPG TR (INCLS TRAC CONT SWITCH) 25772995 PLATE, F/FLR CNSL TRANS SHFT OPG TR (WALNUT BURL) (INCLS TRAC CNTRL SW) [ПОДДОН] 19167127 BEZEL, A/TRNS CONT HSG (W/SHIF LOCK SOLENOID COV) 88967343 BASE, A/TRNS CONT (4.010) [БЛОК] 88967347 SOLENOID, A/TRNS SHFT LK CONT 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (A/TRNS RANGE SEL ROD ADJ) 15245219 LINK, A/TRNS RANGE SEL LVR 11519095 NUT-ACORN HEX, M8X1.0, 15MM THK, 9, 6047M, W/DOME. (A/TRNS RANGE SEL LVR) [ГАЙКА] teamcadillac.ru 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL LVR CBL BRKT) [ГАЙКА М6] 88967341 BULB, A/TRNS CONT POSN IND (INCLS BULB W/BLUE COVER) (4.020) (ACDelco #88967341) [ЛАМПОЧКА ФАРЫ] 88967340 COVER, A/TRNS CONT LVR HDL (ЧАСТЬ OF 1) (6E04-007) - 2004-2006 E ТОРМОЗНЫЕ ШЛАНГИ И ТРУБКИ ↓ 15933099 HOSE, FRT BRK (INCLS 15, 16) (ACDelco #176-1495) 11569742 RETAINER, FRT BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (BRK & FUEL FEED & FUEL RTN & EVAP EMIS) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА] 25761218 BRACKET, FUEL PIPE 25761217 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (3.162) 12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (FRT BRK) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА] 10388788 PIPE, BRK PRESS MOD VLV FRT (INCLS 29) 10388794 PIPE, BRK PRESS MOD VLV RR (INCLS 29) 03541444 SPACER, FRT BRK PIPE 11516521 БОЛТ, HFH M6X1X20, 9.8, 7114M, DOG PT, 14.2 OD (FRT BRK HOSE) 15933098 HOSE, FRT BRK (INCLS 15, 16) (ACDelco #176-1487) 25743891 RETAINER, RR BRK FRT PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT) 15724653 FITTING, FRT BRK PIPE (ЧАСТЬ OF 1, 12) (7/16-24 X .36) (.30 THD, .56 LENGTH, .194 TUBE, STL, GM7113M) 25743891 RETAINER, FRT BRK PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT) 25737279 CLIP, FRT BRK PIPE (THREE WAY RETAINER SINGLE CENTRAL FIR-TREE ATTACHMENT) 15270078 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (USES RETAINER PIN FOR ATTACHMENT) [ЗАЖИМ ТРУБКИ ТОПЛИВНОЙ СИСТЕМЫ] 25688547 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (RETAINER W/5 HOLES (2)7.95, (2)4.76, (1)9.52MM) 25749839 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (HOLDS 3 ТРУБКИ, FLAT SHAPE, SNAP-IN RETAINER) 25607191 RETAINER, BRK PIPE (21.5X10.0MM) (HOLDS (2) 4.68-4.82 TUBES) teamcadillac.ru 11569742 RETAINER, RR BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 15724650 ГАЙКА, INVERTED FLARED TUBE, 9/16"-18, 1/4" TUBE, ZD (BRK PIPE) (4.686) [ГАЙКА] 25693890 RETAINER, RR BRK PIPE (HOLDS (1) 4.76 LINE) (W/TREE) [ЗАМОК, ФИКСАТОР] 11588803 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 7, 8) (1/2-20X.40, .32 THD) (INVERTED FLARED TUBE) (.62 LONG, 1/4 TUBE) [ГАЙКА М20] 15724650 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 7, 8) (9/16-18 X .40) (INVERTED FLARED TUBE) [ГАЙКА] 15933091 HOSE, RR BRK (INCLS 22, 23) (ACDelco #15933091) 15933092 HOSE, RR BRK (INCLS 22, 23) (ACDelco #15933092) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ] 88964150 PROTECTOR, FRT BRK PIPE (FOR 3/16" PIPE) (HT SHRINK) (6E04-008) - 2004-2006 E ТОРМОЗНАЯ ПЕДАЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (EXC (JF4)) ↓ 25732428 BARRIER, BRK PED BRKT SND 25697461 RETAINER, BRK PED PUSH ROD BOOT 25732452 BOOT, BRK PED PUSH ROD 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] 15932827 HOSE, P/B BOOS VAC (ACDelco #176-1496) 25765419 PEDAL, BRK (W/BRKT) (INCLS 10, 11, 14, 16-18) 25771615 COVER, BRK PED (ЧАСТЬ OF 9) teamcadillac.ru 89047699 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 9) [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 9) 10434956 BUSHING, BRK PED PUSH ROD 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 9) 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 9) (0.80 IN) (PUSH IN) (6E04-010) - 2004-2006 E СТОЯНОЧНЫЙ ТОРМОЗ SYSTEM ↓ 10395687 LEVER, PARK BRK (INCLS 2-4, 13-15) 15797212 CABLE, PARK BRK INTER (INCLS 5, 10, 11) (ACDelco #15797212) [ТРОС СТОЯНОЧНОГО ТОРМОЗА В СБОРЕ] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (PARK BRK INTER CBL GDE) [ГАЙКА М6] 11517484 БОЛТ-HEX, M6X1X20, 9 THD, 17 OD, 9.8, 6280M, MACH, P-PT (PARK BRK INTER CBL GDE) 25764260 CABLE, PARK BRK RR (28.2X28.5X811.7MM) (ACDelco #25764260) [ТРОС СТОЯНОЧНОГО ТОРМОЗА] 25880964 HANDLE, PARK BRK REL 89047821 CABLE, PARK BRK REL (ЧАСТЬ OF 1) (ACDelco #89047821) teamcadillac.ru 22654577 SWITCH, PARK BRK IND (ЧАСТЬ OF 1) (ACDelco #22654577) [ВКЛЮЧАТЕЛЬ] 10369646 БОЛТ, PARK BRK IND SW (ЧАСТЬ OF 1) (6E04-011) - 2004-2006 E T.C.M. МОДУЛЬ ↓ teamcadillac.ru 24239785 МОДУЛЬ, TRANS CONT 24240286 МОДУЛЬ, TRANS CONT 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (MULTIUSE RLY & FUSE BRKT) [БОЛТ М6] (6E04-012) - 2004-2006 E КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS(MV3) ↓ 88996677 CASE, TRFER (FRT HALF) (INCLS 12-14) 19133265 CASE, TRFER (RR HALF) (INCLS 5, 7) 88996679 SNUBBER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN 88996680 БОЛТ, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN SNBR (M5X0.8X16) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 2) 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL FILL) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996657 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 2) [УПЛОТНИТЕЛЬ] 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL DRN) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996680 БОЛТ, TRFER CASE VENT BFL (M5X0.8X16) (4.535) teamcadillac.ru 88996658 BAFFLE, TRFER CASE VENT 89048123 БОЛТ, TRFER CASE HALF (M8X1.25X30) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 1) 88996656 SEAL, TRFER CASE INPUT SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 88996657 SEAL, TRFER CASE FRT ВЫХОДНОЙ SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] (6E04-014) - 2006 E КОРПУС КП КРЕПЛЕНИЕ (MV3) ↓ teamcadillac.ru 11519347 БОЛТ, TRFER CASE (M10X1.5X65) (8.900) [БОЛТ] (6E04-016) - 2004-2009 E КЛАПАН РЕГУЛИРОВКИ ДАВЛЕНИЯ В ТОРМОЗНОЙ СИСТЕМЕ ↓ 89060339 МОДУЛЬ KIT, ELEK BRK & TRACT CONT (REQS PROGRAMMING;BRK APPLY SEN REQS CALN;REFER TO SERV INFO) (ACDelco #89060339) [БЛОК УПРАВЛЕНИЯ ТОРМОЗНОЙ СИСТЕМОЙ] 89060233 VALVE KIT, BRK PRESS MOD (INCLS 3, 4) (ACDelco #89060233) [ГИДРАВЛИЧЕСКИЙ БЛОК АБС] 25743362 SENSOR, BRK PRESS MOD VLV PRESS (ЧАСТЬ OF 2) (ACDelco #25743362) [ДАТЧИК] 25741456 INSULATOR, BRK PRESS MOD VLV (ЧАСТЬ OF 2) 11588304 STUD, FLANGE DOUBLE END, M8X14 UNTHD, M8X1.25X13, 17 OD, 5.8, GM4345M (BRK PRESS MOD VLV BRKT) 11514596 ГАЙКА, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (BRK PRESS MOD VLV BRKT) (8.915) (ACDelco #11514596) teamcadillac.ru 11508351 SCREW, PAN HD, C/R, 5X0.8X13, 9.3 OD, FULL THD, THD RLLR, 6171M, PC (BRK PRESS MOD VLV) (8.977) (6E04-017) - 2004-2006 E ШЛАНГ ВЕНТИЛЯЦИИ ТРАНСМИССИИ ↓ 25764835 VENT, A/TRNS (INCLS 2, 3) (ACDelco #25764835) teamcadillac.ru 15955072 CLIP, TRANS VENT HOSE (ЧАСТЬ OF 1) (.650MM DIA) (2.343) (6E04-018) - 2004-2009 E КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS(MX5) ↓ 88996677 CASE, TRFER (FRT HALF) (INCLS 12-14) 19133265 CASE, TRFER (RR HALF) (INCLS 5, 7) 88996679 SNUBBER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN 88996680 БОЛТ, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN SNBR (M5X0.8X16) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 2) 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL FILL) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996657 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 2) [УПЛОТНИТЕЛЬ] 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL DRN) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996680 БОЛТ, TRFER CASE VENT BFL (M5X0.8X16) (4.535) teamcadillac.ru 88996658 BAFFLE, TRFER CASE VENT 89048123 БОЛТ, TRFER CASE HALF (M8X1.25X30) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 1) 88996656 SEAL, TRFER CASE INPUT SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 88996657 SEAL, TRFER CASE FRT ВЫХОДНОЙ SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 19180066 VENT, TRFER CASE 89048123 БОЛТ, TRFER CASE VIB DPNR (M8X1.25X30) 19133173 DAMPENER, TRFER CASE VIB (YOKE STYLE; БОЛТS TO RR OF T-CASE) (TRANS BUILT ON 3-22-06 & AFTER) (FOR 1ST DES SEE 89048182) 89048182 DAMPENER, TRFER CASE VIB (YOKE STYLE-БОЛТS TO RR OF T/CASE) (TRANS BUILT ON 3-21-06 & AFTER) (FOR 2ND DES SEE 19133173) (6E04-021) - 2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (LH2/4.6A, EXC V92) ↓ 11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16] 89022494 BRACKET, TRANS FLUID CLR 19129780 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) [ТРУБКА] 19129782 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) (WITH TRANS OIL COOLER EXTERNAL TO РАДИАТОР. FOR 2ND DES SEE 19129977.) [ТРУБКА МАСЛООХЛАДИТЕЛЯ] teamcadillac.ru 19130214 SEAL, TRANS FLUID CLR HOSE CONN (O RING) 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 19129779 HOSE, TRANS FLUID CLR LWR (W/BLOCK) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 19129781 HOSE, TRANS FLUID CLR LWR (W/BLOCK) (WITH TRANS OIL COOLER EXTERNAL TO РАДИАТОР. FOR 2ND DES SEE 19129976) 88957425 COOLER, TRANS FLUID (INCLS 7-11) (ACDelco #88957425) [ВЕНТИЛЯТОР] (6E04-022) - 2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (V92) ↓ 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 89022494 BRACKET, TRANS FLUID CLR 19129780 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) [ТРУБКА] 19129782 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) [ТРУБКА МАСЛООХЛАДИТЕЛЯ] 19130214 SEAL, TRANS FLUID CLR HOSE CONN (O RING) 19129779 HOSE, TRANS FLUID CLR LWR (W/BLOCK) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 19129781 HOSE, TRANS FLUID CLR LWR (W/BLOCK) 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] teamcadillac.ru 89022522 COOLER, TRANS FLUID (INCLS 7-10) (6E04-035) - 2005-2009 E BRAKE SYSTEM/ANTILOCK ↓ 12413103 HUB, FRT WHL (W/BRG) (СМ. ГРУППУ 06.000 "ПОДВЕСКА-ПЕРЕДНЯЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/WHL SPD SEN) (ACDelco #FW149) [СТУПИЦА КОЛЕСА] 12413105 HUB, FRT WHL (W/BRG) (СМ. ГРУППУ 06.000 "ПОДВЕСКА-ПЕРЕДНЯЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPEED SENSOR) (ACDelco #FW150) [СТУПИЦА КОЛЕСА] 89047639 HUB, RR WHL (W/WHL SPD SEN) (СМ. ГРУППУ 06.000 "ЗАДНЯЯ ПОДВЕСКА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6 STUD HUB) (ACDelco #RW20-19) [СТУПИЦА КОЛЕСА] teamcadillac.ru 10307709 SENSOR, VEH YAW (W/VEH LATL ACCLRM) [ДАТЧИК] 15906579 SENSOR, VEH YAW (W/ VEH LATL & LGTDNL ACCLRM) [ДАТЧИК] 11561645 ГАЙКА, HFH, M6X1X6.45, 13.5 OD, 10 STL, GMW3200 (VEH YAW SEN & LATL ACCLRM) (6E04-036) - 2005-2006 E ТОРМОЗНАЯ ПЕДАЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (JF4) ↓ 25732428 BARRIER, BRK PED BRKT SND 25697461 RETAINER, BRK PED PUSH ROD BOOT 25732452 BOOT, BRK PED PUSH ROD 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] 15932827 HOSE, P/B BOOS VAC (ACDelco #176-1496) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (ACCEL PED LVR) 10368488 PEDAL, BRK (INCLS 12, 13, 15, 18-22) 25771615 COVER, BRK PED (ЧАСТЬ OF 11) 89047699 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 11) (INCLS 18) [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 89047780 MOTOR KIT, BRK & ACCEL PED ADJR ACTR [ЭЛЕКТРОДВИГАТЕЛЬ ПЕДАЛЬНОГО УЗЛА 19 ВТ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 11, 13) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 11) 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 11) 25697461 RETAINER, BRK PED PUSH ROD BOOT (ЧАСТЬ OF 11) teamcadillac.ru 89047779 CABLE, ACCEL CONT 89047778 CABLE, BRK PED ADJR ACTR [ЖГУТ ПРОВОДОВ] 25741052 BRACKET, BRK PED BRKT 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-018) - 2004-2006 E КОРПУС КП ЧАСТЬ 2 INTERNAL COMPONENTS(MV3) ↓ 88984517 WASHER, TRFER CASE PLNT CARR SUN GR THR (25.8X52.0X2.2) 88984524 GEAR, TRFER CASE PLNT CARR SUN (INPUT) (STAMPED PM/POWDERED METAL) 88984493 RING, TRFER CASE RR ВЫХОДНОЙ SHF RR BRG RET (41MM I.D.) (ACDelco #88984493) 88996564 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT 88996665 BEARING, TRFER CASE MAIN SHF FRT (ВЫХОДНОЙ ВАЛ FRT) 19168733 BUSHING, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 106) [ВТУЛКА РАЗДАТОЧНОЙ КОРОБКИ] 19178237 SHAFT, TRFER CASE RR ВЫХОДНОЙ (INCLS 105, 901) 19133264 SPROCKET, TRFER CASE FRT ВЫХОДНОЙ SHF DRV (INCLS 108) [ШЕСТЕРНЯ РАЗДАТОЧНОЙ КОРОБКИ] 19168732 BUSHING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT (ЧАСТЬ OF 107) (ACDelco #19168732) 89059578 CHAIN, TRFER CASE TWO/FOUR WHL DRV [ЦЕПЬ РАЗДАТОЧНОЙ КОРОБКИ] 88984523 GEAR, TRFER CASE PLNT CARR SUN (ВЫХОДНОЙ) 89059279 КРОНШТЕЙН, FRT/RR DRV DIFF 89059284 SHAFT, TRFER CASE FRT ВЫХОДНОЙ (INCLS 900) 88996664 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF RR teamcadillac.ru 88996671 RING, TRFER CASE FRT ВЫХОДНОЙ SHF BRG RET 88996666 SPROCKET, TRFER CASE TWO/FOUR WHL DRV DRVN [ЗВЕЗДОЧКА] 88996633 BEARING, TRFER CASE RR ВЫХОДНОЙ SHF RR (ACDelco #88996633) [ПОДШИПНИК РАЗДАТОЧНОЙ КОРОБКИ] 15580230 BEARING, TRFER CASE INPUT SHF (BORG-WARNER) (4.510) 19132966 SHAFT, TRFER CASE INPUT 88996681 DEFLECTOR, TRFER CASE FRT ВЫХОДНОЙ SHF SEAL DIRT (ЧАСТЬ OF 112) (6M04-041) - 2004-2006 E26 ТОРМОЗНАЯ ПЕДАЛЬ (PWR ADJ PEDALS JF4) ↓ 25741052 BRACKET, BRK PED BRKT 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 25732428 BARRIER, BRK PED BRKT SND 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 89047778 CABLE, BRK PED ADJR ACTR [ЖГУТ ПРОВОДОВ] 89047780 MOTOR KIT, BRK & ACCEL PED ADJR ACTR [ЭЛЕКТРОДВИГАТЕЛЬ ПЕДАЛЬНОГО УЗЛА 19 ВТ] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (BRK PED POSN SEN) 89047699 SENSOR KIT, BRK PED POSN [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] teamcadillac.ru 25697461 RETAINER, BRK PED PUSH ROD BOOT (ЧАСТЬ OF 21) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 21) 10368488 PEDAL, BRK (INCLS 5, 8-10, 13, 15-20, 22) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-042) - 2004-2006 E26 ТОРМОЗНАЯ ПЕДАЛЬ (EXC PWR ADJ PEDALS JF4) ↓ 25741052 BRACKET, BRK PED BRKT 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 25732428 BARRIER, BRK PED BRKT SND 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] teamcadillac.ru 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 18) 89047699 SENSOR KIT, BRK PED POSN [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 18) (0.80 IN) (PUSH IN) 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 18) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 18) 25771615 COVER, BRK PED (ЧАСТЬ OF 18) 25765419 PEDAL, BRK (W/BRKT) (INCLS 5-8, 10, 12-17, 19) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-044) - 2004-2009 E26 ТОРМОЗНОЙ УСИЛИТЕЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА ↓ teamcadillac.ru 88967237 BOOSTER, P/B (СМ. ГРУППУ 04.000 "ТОРМОЗНОЙ УСИЛИТЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/O VLV) (ACDelco #178-0695) 25732452 BOOT, BRK PED PUSH ROD 25697461 RETAINER, BRK PED PUSH ROD BOOT 10367561 CYLINDER, BRK MAS (СМ. ГРУППУ 4.000 "ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #174-1012) [ЦИЛИНДР] 11517996 ГАЙКА, BRK M/CYL (M10X1.5, 11.2 THK) (8.917) [ГАЙКА М10] 25873484 HOSE, P/B BOOS VAC (ACDelco #176-1497) (GM00-031) - 2006 E ТРАНСМИССИЯ TO КРЕПЛЕНИЕ ДВИГАТЕЛЯ (LH2/4.6A) ↓ 12582606 FLYКОЛЕСО, ENG 25771275 BRACKET, ENG WRG HARN (USED IN GENERATOR PACKAGE) 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] 24205900 COVER, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] 11589116 БОЛТ, FLYWHL (8.900) 12568122 COVER, FLYWHL HSG 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (TRANS CONV CVR) (ACDelco #11517518) [БОЛТ] teamcadillac.ru 12568123 COVER, TRANS CONV (GM04-064) - 2004-2009 E ТОРМОЗНОЙ СУППОРТ-ПЕРЕДНИЙ ↓ 18047980 CALIPER, FRT BRK (INCLS 2-4, 8-10) (IF DISCONTINUED USE DURASTOP EQUIVALENT) (4.667) (ACDelco #172-1643) [ТОРМОЗНОЙ СУППОРТ] 18047981 CALIPER, FRT BRK (INCLS 2-4, 8-10) (IF DISCONTINUED USE DURASTOP EQUIVALENT) (4.667) (ACDelco #172-1644) [ТОРМОЗНОЙ СУППОРТ] 18043178 COVER, FRT BRK BLEDR SCREW (ЧАСТЬ OF 1) 18047986 VALVE KIT, FRT BRK CLPR BLEDR (ЧАСТЬ OF 1) (ACDelco #18047986) 18046750 БОЛТ, FRT BRK CLPR GDE PIN (ЧАСТЬ OF 1, 11) (*KIT2) [БОЛТ] 18047985 PISTON KIT, FRT BRK CLPR (ЧАСТЬ OF 1) 18047988 PAD KIT, FRT DISC BRK (INCLS 4, 14) (ACDelco #171-665) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4 ШТ)] 19122384 PAD KIT, FRT DISC BRK (INCLS 4, 14) (ACDelco #171-688) 18045221 SEAL, FRT BRK CLPR GDE PIN 18047987 BRACKET, FRT BRK CLPR (W/GUIDE PIN БОЛТS) [КРОНШТЕЙН] 18046698 ПРУЖИНА, FRT DISC BRK PAD RET (ЧАСТЬ OF 11) (ACDelco #179-2235) teamcadillac.ru 18047989 PIN KIT, FRT BRK CLPR GDE (INCLS 5-7) (INCLS 2 (2.5") БОЛТS) 18047984 CALIPER KIT, FRT BRK (INCLS 4, 8, 9) (4.667) (ACDelco #173-0538) (GM04-312) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (5L50-E M22,5L40-E M82) ↓ teamcadillac.ru 96042884 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 6GDZ) 96042897 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 6GRG) (GM04-376) - 2004-2009 E ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР ↓ 18012741 SWITCH, BRK FLUID LVL IND (ЧАСТЬ OF 15) (ACDelco #18012741) 22688449 CAP, BRK M/CYL RSVR (ЧАСТЬ OF 15) (INCLS 3) [КРЫШКА БАЧКА ТОРМОЗНОЙ ЖИДКОСТИ] teamcadillac.ru 18046711 RESERVOIR, BRK M/CYL (ЧАСТЬ OF 15) (INCLS 4, 6-7) (ACDelco #18046711) 18060168 PISTON, BRK M/CYL SECD (ЧАСТЬ OF 15) 10367561 CYLINDER, BRK MAS (INCLS 1-14) (ACDelco #174-1012) [ЦИЛИНДР] 18022002 CYLINDER KIT, BRK MAS (INCLS 8-12) (ACDelco #175-424) (GM04-485) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (5L50-E MV3,5L40-E MX5) ↓ 96042890 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 6GGG) [АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ В СБОРЕ] teamcadillac.ru 96042893 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 6GFZ) [ТРАНСМИССИЯ В СБОРЕ] (GM04-573) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042861 GASKET, A/TRNS CASE EXTN 24237771 BEARING, ВЫХОДНОЙ SHF (ЧАСТЬ OF 27) 96042882 EXTENSION, A/TRNS CASE (INCLS 26, 28, 29) (4.003) 24237771 BEARING, ВЫХОДНОЙ SHF (ЧАСТЬ OF 27) 96041851 SEAL, PROP SHF TRANS FLG FLUID (ЧАСТЬ OF 27) [ПРОКЛАДКА ТРАНСФОРМАТОРНОГО ВАЛА] 96042984 FLANGE, ВЫХОДНОЙ SHF 96041805 NUT KIT, ВЫХОДНОЙ SHFT (INCLS 30, 32, 33) (M6X1.0X16) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) teamcadillac.ru 96042962 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) 96042712 DETENT, MAN SHFT 96017928 CLIP, WRG HARN 96042847 HARNESS, A/TRNS WRG 96041849 SEAL, A/TRNS WRG CONN (O RING) 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) (GM04-573) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042861 GASKET, A/TRNS CASE EXTN (*KIT1) 24237771 BEARING, ВЫХОДНОЙ SHF (ЧАСТЬ OF 27) 96042860 EXTENSION, A/TRNS CASE (INCLS 26, 28, 29) 24237771 BEARING, ВЫХОДНОЙ SHF (ЧАСТЬ OF 27) 96041851 SEAL, PROP SHF TRANS FLG FLUID (ЧАСТЬ OF 27) (*KIT1) [ПРОКЛАДКА ТРАНСФОРМАТОРНОГО ВАЛА] 96042984 FLANGE, ВЫХОДНОЙ SHF 96041805 NUT KIT, ВЫХОДНОЙ SHFT (INCLS 30, 32, 33) (M6X1.0X16) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) (*KIT1) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) (*KIT1) 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96042963 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPACER PLATE & GASKET) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) 96042712 DETENT, MAN SHFT 96017928 CLIP, WRG HARN 96042847 HARNESS, A/TRNS WRG 96041849 SEAL, A/TRNS WRG CONN (O RING) (*KIT1) teamcadillac.ru 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN (*KIT1) [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (*KIT1) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (*KIT1) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) 96042945 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/GSKT, SEAL, RET) (INCLS 25, 29, 36, 38, 46, 56, 60, 63, 64) (GM04-574) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042887 GASKET, A/TRNS CASE EXTN [ПРОКЛАДКА КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042896 EXTENSION, A/TRNS CASE (INCLS 28, 69) 24237771 BEARING, ВЫХОДНОЙ SHF (ЧАСТЬ OF 27) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96042962 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) 96042712 DETENT, MAN SHFT teamcadillac.ru 96017928 CLIP, WRG HARN 96042847 HARNESS, A/TRNS WRG 96041849 SEAL, A/TRNS WRG CONN (O RING) 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) 96042543 WASHER, INPUT & REACTION CARR THR 96042587 SEAL, PROP SHF TRANS FLG FLUID [ПРОКЛАДКА КРЫШКИ РАЗДАТОЧНОЙ КОРОБКИ] (GM04-574) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042887 GASKET, A/TRNS CASE EXTN [ПРОКЛАДКА КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] teamcadillac.ru 96042888 EXTENSION, A/TRNS CASE (INCLS 28, 69) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96042963 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPACER PLATE & GASKET) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) 96042712 DETENT, MAN SHFT 96017928 CLIP, WRG HARN 96042847 HARNESS, A/TRNS WRG 96041849 SEAL, A/TRNS WRG CONN (O RING) 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) 96042543 WASHER, INPUT & REACTION CARR THR 96042587 SEAL, PROP SHF TRANS FLG FLUID [ПРОКЛАДКА КРЫШКИ РАЗДАТОЧНОЙ КОРОБКИ] 08677884 BEARING, ВЫХОДНОЙ SHF THR (ЧАСТЬ OF 27) (4.180) (ACDelco #8677884) (GM04-575) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ 96042553 CONVERTER, TORQ (REMAN) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042835 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) 96042806 СЦЕПЛЕНИЕ, DIR & REV 96042831 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) 96042823 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) 96042824 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) 96042701 WASHER, INPUT & REACTION CARR INR SHF THR teamcadillac.ru 96042808 ШЛАНГИ, O/D CLU 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) 96042705 BEARING, CTR SUPT RLR (4.180) 96042826 SUPPORT, CTR 96042832 КРОНШТЕЙН, INPUT & REACTION 96042833 BEARING, INPUT & REACTION CARR THR 96042834 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) 96042543 WASHER, INPUT & REACTION CARR THR 96042833 BEARING, INPUT & REACTION CARR THR 96042883 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/GSKT, SEAL, RET) (GM04-575) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ 96042554 CONVERTER, TORQ (REMAN) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042812 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) 96042806 СЦЕПЛЕНИЕ, DIR & REV (СМ. ГРУППУ 04.000 "DIRECT AND REVERSE СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042807 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (СМ. ГРУППУ 04.000 "FORWARD AND COAST СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042698 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) (СМ. ГРУППУ 04.000 "INPUT SUN GEAR SHAFT AND FORWARD SPRAG СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (СМ. ГРУППУ 04.000 "DIRECT СЦЕПЛЕНИЕ DRUM AND SHAFT" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042701 WASHER, INPUT & REACTION CARR INR SHF THR teamcadillac.ru 96042808 ШЛАНГИ, O/D CLU (СМ. ГРУППУ 04.000 "OVERDRIVE AND INTERMEDIATE СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (СМ. ГРУППУ 04.000 "LOW СЦЕПЛЕНИЕ SPRAG" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042705 BEARING, CTR SUPT RLR (4.180) 96042809 SUPPORT, CTR (СМ. ГРУППУ 04.000 "CENTER SUPPORT" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042707 КРОНШТЕЙН, INPUT & REACTION (СМ. ГРУППУ 04.000 "PLANETARY КРОНШТЕЙН" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (4.176) 96042708 BEARING, INPUT & REACTION CARR THR 96042709 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (СМ. ГРУППУ 04.000 "ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96041847 WASHER, INPUT & REACTION CARR THR (4.265) (GM04-576) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ 96042553 CONVERTER, TORQ (REMAN) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042835 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) 96042814 СЦЕПЛЕНИЕ, DIR & REV 96042822 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) 96042823 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) 96042824 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) 96042701 WASHER, INPUT & REACTION CARR INR SHF THR 96042808 ШЛАНГИ, O/D CLU teamcadillac.ru 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) 96042826 SUPPORT, CTR 96042827 КРОНШТЕЙН, INPUT & REACTION 96042818 BEARING, INPUT & REACTION CARR THR 96042837 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) 96042543 WASHER, INPUT & REACTION CARR THR 96042818 BEARING, INPUT & REACTION CARR THR (GM04-576) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ 96042554 CONVERTER, TORQ (REMAN) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042812 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) 96042814 СЦЕПЛЕНИЕ, DIR & REV 96042815 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) 96042698 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) (INCLS 9) 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) 96042701 WASHER, INPUT & REACTION CARR INR SHF THR 96042808 ШЛАНГИ, O/D CLU 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) 08677884 BEARING, LOW CLU RLR THR (*KIT1) (ACDelco #8677884) 96042816 SUPPORT, CTR 96042817 КРОНШТЕЙН, INPUT & REACTION 96042818 BEARING, INPUT & REACTION CARR THR 96042813 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) 96042543 WASHER, INPUT & REACTION CARR THR 96042818 BEARING, INPUT & REACTION CARR THR teamcadillac.ru (GM04-577) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ 24209145 ФИЛЬТР, PRESS CONT SOL VLV FLUID (ACDelco #24209145) [ФИЛЬТР] 24212478 SLIDE, A/TRNS ГИДРОНАСОС (17.9545MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212478) 24212479 SLIDE, A/TRNS ГИДРОНАСОС (17.9675MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212479) 24212480 SLIDE, A/TRNS ГИДРОНАСОС (17.9805MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212480) teamcadillac.ru 24212481 SLIDE, A/TRNS ГИДРОНАСОС (17.9935MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212481) 24212482 SLIDE, A/TRNS ГИДРОНАСОС (18.0065MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212482) 24201144 RING, A/TRNS ГИДРОНАСОС VANE (RING, PUMP VANE) (ACDelco #24201144) 08631280 VANE, A/TRNS ГИДРОНАСОС (ACDelco #8631280) 24205410 GUIDE, A/TRNS ГИДРОНАСОС ROT (13 VANE) (ACDelco #24205410) 96015215 БОЛТ, A/TRNS ГИДРОНАСОС (4.115) 96041855 SEAL, T/CV FLUID [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042835 ШЛАНГИ KIT, T/CV (INCLS 200-212, 214-215, 217-220, 223, 226, 227, 231-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-577) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ 24209145 ФИЛЬТР, PRESS CONT SOL VLV FLUID (*KIT1) (ACDelco #24209145) [ФИЛЬТР] 24212478 SLIDE, A/TRNS ГИДРОНАСОС (17.9545MM) (SLIDE ID MARK = 1 DIMPLE) (*KIT1) (ACDelco #24212478) teamcadillac.ru 24212479 SLIDE, A/TRNS ГИДРОНАСОС (17.9675MM) (SLIDE ID MARK = 1 DIMPLE) (*KIT1) (ACDelco #24212479) 24212480 SLIDE, A/TRNS ГИДРОНАСОС (17.9805MM) (SLIDE ID MARK = 1 DIMPLE) (*KIT1) (ACDelco #24212480) 24212481 SLIDE, A/TRNS ГИДРОНАСОС (17.9935MM) (SLIDE ID MARK = 1 DIMPLE) (*KIT1) (ACDelco #24212481) 24212482 SLIDE, A/TRNS ГИДРОНАСОС (18.0065MM) (SLIDE ID MARK = 1 DIMPLE) (*KIT1) (ACDelco #24212482) 24201144 RING, A/TRNS ГИДРОНАСОС VANE (RING, PUMP VANE) (*KIT1) (ACDelco #24201144) 08631280 VANE, A/TRNS ГИДРОНАСОС (*KIT1) (ACDelco #8631280) 24205410 GUIDE, A/TRNS ГИДРОНАСОС ROT (13 VANE) (*KIT1) (ACDelco #24205410) 96041855 SEAL, T/CV FLUID (*KIT1) [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042835 ШЛАНГИ KIT, T/CV (INCLS 200-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-577) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ teamcadillac.ru 96015215 БОЛТ, T/CV FLUID SEAL (*KIT1) 96041855 SEAL, T/CV FLUID [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042812 ШЛАНГИ KIT, T/CV (INCLS 200-215, 217-220, 223, 226-228, 231-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-577) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ teamcadillac.ru 24212478 SLIDE, A/TRNS ГИДРОНАСОС (17.9545MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212478) 24212479 SLIDE, A/TRNS ГИДРОНАСОС (17.9675MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212479) 24212480 SLIDE, A/TRNS ГИДРОНАСОС (17.9805MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212480) 24212481 SLIDE, A/TRNS ГИДРОНАСОС (17.9935MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212481) 24212482 SLIDE, A/TRNS ГИДРОНАСОС (18.0065MM) (SLIDE ID MARK = 1 DIMPLE) (ACDelco #24212482) 24201144 RING, A/TRNS ГИДРОНАСОС VANE (RING, PUMP VANE) (ACDelco #24201144) 08631280 VANE, A/TRNS ГИДРОНАСОС (ACDelco #8631280) 24205410 GUIDE, A/TRNS ГИДРОНАСОС ROT (13 VANE) (ACDelco #24205410) 24201144 RING, A/TRNS ГИДРОНАСОС VANE (RING, PUMP VANE) (ACDelco #24201144) 96015215 БОЛТ, T/CV FLUID SEAL (*KIT1) 96041855 SEAL, T/CV FLUID [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042812 ШЛАНГИ KIT, T/CV (INCLS 200-215, 217-220, 223, 226-228, 231-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-578) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 96020027 БОЛТ, C/VLV CHAN PLT 24209145 ФИЛЬТР, PRESS CONT SOL VLV FLUID (*KIT2) (ACDelco #24209145) [ФИЛЬТР] 24209145 ФИЛЬТР, PRESS CONT SOL VLV FLUID (*KIT2) (ACDelco #24209145) [ФИЛЬТР] 96025325 БОЛТ, DIR CLU ACCUM (4.265) teamcadillac.ru 96042987 GASKET KIT, A/TRNS (INCLS 303, 305, 306, 308, 309, 312, 314, 316, 330, 332) (4.265) (GM04-578) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 96020027 БОЛТ, C/VLV CHAN PLT 24209145 ФИЛЬТР, PRESS CONT SOL VLV FLUID (*KIT2) (ACDelco #24209145) [ФИЛЬТР] teamcadillac.ru 24209145 ФИЛЬТР, PRESS CONT SOL VLV FLUID (*KIT2) (ACDelco #24209145) [ФИЛЬТР] 96025325 БОЛТ, DIR CLU ACCUM (4.265) 96042987 GASKET KIT, A/TRNS (INCLS 303, 305, 306, 308, 309, 312, 314, 316, 330, 332) (4.265) (GM04-578) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 300-309, 312-334) (INCLS SPACER PLATE & GASKET) 96042986 GASKET KIT, A/TRNS (INCLS 303, 305, 306, 308, 309, 312, 314, 316, 330, 332) (4.265) (GM04-578) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 300-334) (INCLS SPACER PLATE & GASKET) 96042986 GASKET KIT, A/TRNS (INCLS 303, 305, 306, 308, 309, 312, 314, 316, 330, 332) (4.265) (GM04-579) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 10475842 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (14 MM I.D.) (INR) (ACDelco #10475842) 10475842 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (14 MM I.D.) (INR) (ACDelco #10475842) 96042599 VALVE, TCC PWM SOL 10475842 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (14 MM I.D.) (INR) (ACDelco #10475842) 10475842 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (14 MM I.D.) (INR) (ACDelco #10475842) 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] (GM04-579) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 10475842 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (14 MM I.D.) (INR) (ACDelco #10475842) 10475842 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (14 MM I.D.) (INR) (ACDelco #10475842) 96042599 VALVE, TCC PWM SOL 10475842 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (14 MM I.D.) (INR) (ACDelco #10475842) 10475842 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (14 MM I.D.) (INR) (ACDelco #10475842) 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] (GM04-579) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 96042599 VALVE, TCC PWM SOL 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 340-351, 353-356) (INCLS SPACER PLATE & GASKET) (GM04-579) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 10471813 SEAL, TCC SOL VLV (O RING) (SMALL DIA) (OTR) (ACDelco #10471813) 10475842 SEAL, TCC SOL VLV (O RING) (14 MM I.D.) (INR) (ACDelco #10475842) 96042599 VALVE, TCC PWM SOL 10471813 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (SMALL DIA) (OTR) (ACDelco #10471813) 10475842 SEAL, TCC SOL VLV (O RING) (ЧАСТЬ OF 357) (14 MM I.D.) (INR) (ACDelco #10475842) 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 340-348, 351, 353-354) (INCLS SPACER PLATE & GASKET) (GM04-580) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 10475842 SEAL, TCC SOL VLV (O RING) (14 MM I.D.) (INR) (ACDelco #10475842) 10475842 SEAL, TCC SOL VLV (O RING) (14 MM I.D.) (INR) (ACDelco #10475842) 08680781 RETAINER, 2-3 SHFT SOL VLV (ACDelco #8680781) 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] (GM04-580) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 10475842 SEAL, TCC SOL VLV (O RING) (14 MM I.D.) (INR) (ACDelco #10475842) 10475842 SEAL, TCC SOL VLV (O RING) (14 MM I.D.) (INR) (ACDelco #10475842) 08680781 RETAINER, 2-3 SHFT SOL VLV (ACDelco #8680781) 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] teamcadillac.ru (GM04-580) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 343, 349, 350, 365-367, 370-375, 377-388) (INCLS SPACER PLATE & GASKET) (GM04-580) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 10471813 SEAL, TCC SOL VLV (O RING) (SMALL DIA) (OTR) (ACDelco #10471813) 10475842 SEAL, TCC SOL VLV (O RING) (14 MM I.D.) (INR) (ACDelco #10475842) 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 343, 351, 365-367, 370-375, 377-388) (INCLS SPACER PLATE & GASKET) 96042889 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/PLT, GSKT, SEAL) (INCLS 343, 351, 365-367, 370-375, 377-388) (GM04-581) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru (GM04-581) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ 96042814 СЦЕПЛЕНИЕ, DIR & REV (INCLS 400-420) (GM04-581) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru 96042806 СЦЕПЛЕНИЕ, DIR & REV (INCLS 400-420) (GM04-581) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru 96042814 СЦЕПЛЕНИЕ, DIR & REV (INCLS 400-420) (GM04-582) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96042831 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-432, 434-451) teamcadillac.ru 96042883 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/GSKT, SEAL, RET) (GM04-582) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯLY ↓ teamcadillac.ru 96042822 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-451) (GM04-582) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96041856 SEAL, INPUT SHF (O RING) (*KIT1) [ПРОКЛАДКА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] teamcadillac.ru 96042807 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-451) (GM04-582) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96042815 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-451) (GM04-583) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru (GM04-583) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042827 КРОНШТЕЙН, INPUT & REACTION (INCLS 455-462) (GM04-583) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96042707 КРОНШТЕЙН, INPUT & REACTION (INCLS 455-462) (4.176) (GM04-583) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042817 КРОНШТЕЙН, INPUT & REACTION (INCLS 455-462) (GM04-584) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ 96042824 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-584) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ teamcadillac.ru 96042824 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-584) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-584) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ teamcadillac.ru 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-585) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ (GM04-585) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042825 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 470-477) (GM04-585) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 470-477) (GM04-585) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 470-477) (GM04-586) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru (GM04-586) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042825 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 480-497) (GM04-586) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 480-497) (GM04-586) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 480-497) (GM04-587) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК ↓ teamcadillac.ru (GM04-587) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК ↓ teamcadillac.ru 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (INCLS 500-505) (GM04-587) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК ↓ teamcadillac.ru 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (INCLS 500-505) (GM04-587) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК ↓ teamcadillac.ru 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (INCLS 500-505) (GM04-588) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) КРЕПЛЕНИЕ ↓ teamcadillac.ru 96042826 SUPPORT, CTR (INCLS 510-517, 519-535) (GM04-588) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) КРЕПЛЕНИЕ ↓ teamcadillac.ru 96042826 SUPPORT, CTR (INCLS 510-535) (GM04-588) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) КРЕПЛЕНИЕ ↓ teamcadillac.ru 96042809 SUPPORT, CTR (INCLS 510-535) (GM04-588) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) КРЕПЛЕНИЕ ↓ teamcadillac.ru 96042816 SUPPORT, CTR (INCLS 510-535) (GM04-589) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) PLANETARY КРОНШТЕЙН БЛОК ↓ teamcadillac.ru 96042832 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-552, 554) (GM04-589) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) PLANETARY КРОНШТЕЙН БЛОК ↓ teamcadillac.ru 96042827 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-554) (GM04-589) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) PLANETARY КРОНШТЕЙН БЛОК ↓ teamcadillac.ru 96042707 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-554) (4.176) (GM04-589) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) PLANETARY КРОНШТЕЙН БЛОК ↓ teamcadillac.ru 96042817 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-554) (GM04-590) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК ↓ 96042834 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560, 561, 563, 564) (GM04-590) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК ↓ teamcadillac.ru 96042709 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560-564) (GM04-591) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК ↓ teamcadillac.ru 96042837 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560-564) (GM04-591) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК ↓ teamcadillac.ru 96042813 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560-561, 563-564) (GM04-593) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) PARKING PAWL БЛОК ↓ 96042710 LEVER, MAN SHFT DTNT 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 96042540 SWITCH, A/TRNS MAN SHFT SHF POSN [ВЫКЛЮЧАТЕЛЬ ПРИВОДА] 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 08644709 SEAL, MAN SHFT SHF (W/O PTFE LUBRICANT APPLIED TO SEAL) (ACDelco #8644709) teamcadillac.ru 96041857 SHAFT, MAN SHFT 96041852 PLUG, MAN SHFT SHF HOLE (4.279) (GM04-593) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) PARKING PAWL БЛОК ↓ 96042710 LEVER, MAN SHFT DTNT 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 96042540 SWITCH, A/TRNS MAN SHFT SHF POSN [ВЫКЛЮЧАТЕЛЬ ПРИВОДА] 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 08644709 SEAL, MAN SHFT SHF (W/O PTFE LUBRICANT APPLIED TO SEAL) (ACDelco #8644709) 96041857 SHAFT, MAN SHFT 96042711 PAWL KIT, PARK 96041852 PLUG, MAN SHFT SHF HOLE (4.279) 96041842 SPACER, MAN SHFT DTNT LVR (GM04-594) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) PARKING PAWL БЛОК ↓ 96042710 LEVER, MAN SHFT DTNT 96042819 LEVER, MAN SHFT DTNT 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 96042540 SWITCH, A/TRNS MAN SHFT SHF POSN [ВЫКЛЮЧАТЕЛЬ ПРИВОДА] 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 08644709 SEAL, MAN SHFT SHF (W/O PTFE LUBRICANT APPLIED TO SEAL) (ACDelco #8644709) 96042544 SHAFT KIT, MAN SHFT teamcadillac.ru 96042820 PAWL KIT, PARK (GM04-594) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) PARKING PAWL БЛОК ↓ 96042710 LEVER, MAN SHFT DTNT 96042819 LEVER, MAN SHFT DTNT 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 96042540 SWITCH, A/TRNS MAN SHFT SHF POSN [ВЫКЛЮЧАТЕЛЬ ПРИВОДА] 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 08644709 SEAL, MAN SHFT SHF (W/O PTFE LUBRICANT APPLIED TO SEAL) (ACDelco #8644709) 96042544 SHAFT KIT, MAN SHFT teamcadillac.ru 96042820 PAWL KIT, PARK 04 - ТРАНСМИССИЯ - ТОРМОЗ ↓ (6D04-023) - 2004-2009 E СТОЯНОЧНЫЙ ТОРМОЗ ASM ↓ 88951984 PLATE, RR PARK BRK ANC BKG (4.591) 88951985 PLATE, RR PARK BRK ANC BKG (4.591) 88951982 ACTUATOR KIT, RR PARK BRK (INCLS 2) (ACDelco #179-2053) [АКТУАТОР] 88951983 ACTUATOR KIT, RR PARK BRK (INCLS 2) (ACDelco #179-2054) [АКТУАТОР] teamcadillac.ru 89047676 SHOE KIT, RR PARK BRK (INCLS 5) (ACDelco #171-0915) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (2 ШТ)] (6D04-031) - 2004-2009 E ТОРМОЗНОЙ СУППОРТ-ЗАДНИЙ ↓ 89047677 CALIPER KIT, RR BRK (INCLS 2, 3, 7-9) (ACDelco #172-2343) 89047678 CALIPER KIT, RR BRK (INCLS 2, 3, 7-9) (ACDelco #172-2344) [ТОРМОЗНОЙ СУППОРТ] 88951992 CAP, RR BRK BLEDR VLV (ЧАСТЬ OF 1) 88951991 VALVE, RR BRK CLPR BLEDR (ЧАСТЬ OF 1) 89047757 PAD KIT, RR DISC BRK (INCLS 4, 12) (ACDelco #171-859) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4 ШТ)] 89047758 PAD KIT, RR DISC BRK (INCLS 4, 12) (4.667) (ACDelco #171-0906) [ТОРМОЗНЫЕ КОЛОДКИ] 88957163 BRACKET, RR BRK CLPR [СКОБА ТОРМОЗНОГО СУППОРТА] teamcadillac.ru 89047759 PIN KIT, RR BRK CLPR GDE (INCLS 4-6) (INCLS 2 PINS, 2 SEALS & 2 (2.75") БОЛТS) (ACDelco #179-2044) [НАПРАВЛЯЮЩАЯ ТОРМОЗНОГО СУППОРТА (2 ШТ)] 88957162 REPAIR KIT, RR BRK CLPR HYD (INCLS 4, 6, 8, 9) (6D04-033) - 2004-2009 E ТОРМОЗНОЙ УСИЛИТЕЛЬ ↓ 88967237 BOOSTER, P/B (W/O VLV) (ACDelco #178-0695) 05461808 GROMMET, P/B BOOS VAC CHK VLV (*KIT1) teamcadillac.ru 03817880 RETAINER, BRK PED PUSH ROD (0.80 IN) (PUSH IN) 18022219 VALVE KIT, P/B BOOS VAC CHK (INCLS 2, 3) (BLACK) (INCLS VLV & GROM) (ACDelco #179-1266) (6D04-067) - 2006-2009 E КОРПУС КП КРЕПЛЕНИЕ (MX5) ↓ 24231525 GASKET, TRFER CASE 19132968 CASE, TRFER (W/GEARS) (LESS DAMPENER) (UNITS BUILT ON 3-22-06 & AFTER) (FOR 1ST DES SEE 24234010) 24234010 CASE, TRFER (W/GEARS) (UNITS BUILT ON 3-21-06 & PRIOR) (FOR 2ND DES SEE 24238468) teamcadillac.ru 11589341 БОЛТ - HFH, M10X1.5X69.9, 28.35 THD, 22.3 OD, 10.9, GMW3359, M-PT. (TRFER CASE) [БОЛТ] (6D04-068) - 2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (LY7/3.6-7, EXC V92)(WITH INTERNAL COOLER)(2ND DES) ↓ 19129976 HOSE, TRANS FLUID CLR LWR (W/BLOCK) (INCLS 7) (WITH TRANS OIL COOLER IN РАДИАТОР. FOR 1ST DES SEE 19129781.) 11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16] 89022494 BRACKET, TRANS FLUID CLR 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] teamcadillac.ru 25740416 SEAL, TRANS FLUID CLR PIPE (O RING) (1/2IN) (9.222) (ACDelco #15-31872) [ПРОКЛАДКА КОМПРЕССОРА КОНДИЦИОНЕРА] 19129977 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) (WITH TRANS OIL COOLER IN РАДИАТОР. FOR 1ST DES SEE 19129782.)
  7. 00 - 6-ТИ ЦИЛИНДРОВЫЙ ДВИГАТЕЛЬ ↓ (6D00-018) - 2004-2005 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 5 КОЛЛЕКТОР & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7) ↓ 12603990 TUBE, PCV (INCLS 292) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (PCV TUBE) 12616910 HOSE, PCV (INCLS 285, 286, 290-292) (DIRTY AIR) 12587556 MANIFOLD, UPR INT (INCLS 506) 12571079 MANIFOLD, LWR INT (INCLS 519) 12567371 GROMMET, UPR INT MANIF SIGHT SHLD [ВТУЛКА] 12606862 GROMMET, UPR INT MANIF SIGHT SHLD (32MM OD) 11518906 БОЛТ, HFH, RDUCD BDY, M8X1.25X165, 22 THD, 18 O.D., 8.8, GMW3359 (INT UPR MANIF) [БОЛТ] 11519176 БОЛТ, INT MANIF (M8X1.25X80) (4.081) [БОЛТ] 12577530 BRACE, INT MANIF 11588967 STUD, BALL W/HFH, M6X1X20.65, 14.2 O.D., 8.8, GMW3359 (INT MANIF BR) 11900286 БОЛТ, HFH, W/RDUCD BODY, M12X1.75X75.9, 30 THD, 26.6 OD, 10.9, GMW3359 (INT MANIF BR) 12595277 GASKET KIT, UPR INT MANIF (*KIT1) [ПРОКЛАДКА] 11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (LWR INT MANIF) 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (F/INJN FUEL RL) [БОЛТ] 12584921 COVER, UPR INT MANIF 11517031 ГАЙКА, HFH, M8X1.25, 9.4THK, 17.4 O.D., 10, TIN ZN (UPR INT MANIF SIGHT SHLD) 12583604 SHIELD, UPR INT MANIF SIGHT (INCLS 595, 596) [ЗАЩИТА] 11588523 STUD, M6X1 (UPR INT MANIF SIGHT SHLD) 12567371 GROMMET, UPR INT MANIF SIGHT SHLD [ВТУЛКА] teamcadillac.ru 12606862 GROMMET, UPR INT MANIF SIGHT SHLD (32MM OD) 12576262 GASKET, EXH MANIF [ПРОКЛАДКА ВЫПУСКНОГО КОЛЛЕКТОРА] 12571102 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 12580706 SHIELD, EXH MANIF HT 11517516 БОЛТ, HFH, M6X1X13, 9.5 THD, 14.2 OD, 9.8, 6280M, MACH, HDR-PT (EXH MANIF H/SHLD) 12582663 INSULATOR, EXH MANIF UPR 12581806 INSULATOR, EXH MANIF LWR 12576263 GASKET, EXH MANIF 12571101 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 11518860 БОЛТ, HFH, M8X1.25X30, 20.9 THD, 18 O.D., 10.9, GMW3179 CODE G, GM6194M (EXH MANIF H/SHLD) [БОЛТ] 12617267 SHIELD, EXH MANIF HT 12581807 INSULATOR, EXH MANIF LWR 14093869 ГАЙКА, PUSH ON, M6, 2.25THK, 12.95 O.D., STL, POR (EXH MANIF H/SHLD INSL) 12571081 BODY, THROT (INCLS 716) (INCLS THROTTLE POSITION SENSOR) (INCLS ACT MTR) (ACDelco #12571081) (STAMPED 12571081) (FOR 2ND DES SEE 12589056) 12589056 BODY, THROT (INCLS 716) (INCLS THROTTLE POSITION SENSOR) (INCLS ACT MTR) (ACDelco #217-2253) (STAMPED 12589056) (FOR 1ST DES SEE 12571081) 11519972 БОЛТ, THROT BODY (M6X1.0X50) 12581398 GASKET, THROT BODY (ACDelco #217-1610) (USE T/W 88988585 HARNESS T/W 12589056 TBI WHEN REPLACING OLD DESIGN 12571081 TBI) [ПРОКЛАДКА] 12577831 CLIP, ENG WRG HARN (ЧАСТЬ OF 701) [ФИКСАТОР ПРОВОДКИ МОТОРНОГО ОТСЕКА] 12571136 SOLENOID, EVAP EMIS CNSTR C/VLV (INCLS 752) (ACDelco #214-1086) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (EVAP EMIS CNSTR PURGE SOL VLV BRKT) 12584171 HOSE, EVAP EMIS CNSTR SOL VLV 12586694 VALVE, INT MANIF TUNING (INCLS 756) 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (INT MANIF TUNING VLV) [БОЛТ] 12575467 SENSOR, MAP (INCLS 778) (ACDelco #213-1584) [ДАТЧИК] 12572886 RAIL, F/INJN FUEL (СМ. ГРУППУ 03.000 "FUEL INJECTION RAIL" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #217-1551) [МАГИСТРАЛЬ ТОПЛИВНЫХ ФОРСУНОК ДВИГАТЕЛЯ] 12598158 GASKET KIT, INT MANIF (INCLS 521, 522) [ПРОКЛАДКА ДВИГАТЕЛЯ] (6E00-003) - 2004-2006 E ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ-V8 (LH2/4.6A, M22) ↓ 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT) [ГАЙКА М12] 25762620 BRACKET, ENG MT 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (ENG MT BRKT) [БОЛТ, М10Х1.5Х30] 25892303 MOUNT, TRANS RR 11515775 БОЛТ, HFH, M12X1.75X30, 10.9, 7114M (TRANS MT) [БОЛТ] teamcadillac.ru 25971086 MOUNT, ENG [ОПОРНЫЙ УЗЕЛ ДВИГАТЕЛЯ] 11517383 БОЛТ, HEX W/CON SPR WASH, M10X1.5X55, 28 OD, 37 THD, 10.9, 7114M (TRANS RR MT BRKT) 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT FRM SI) [ГАЙКА М12] 25971085 MOUNT, ENG [ШАРНИР ДВИГАТЕЛЯ] 25971087 MOUNT, ENG 25716470 BRACKET, ENG MT 25762621 BRACKET, ENG MT (6E00-004) - 2004-2006 E ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ-V8 (LH2/4.6A, MV3) ↓ 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT) [ГАЙКА М12] 25762620 BRACKET, ENG MT 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (ENG MT BRKT) [БОЛТ, М10Х1.5Х30] 15143640 MOUNT, TRANS RR 25892306 MOUNT, TRANS RR 11515775 БОЛТ, HFH, M12X1.75X30, 10.9, 7114M (TRANS MT) [БОЛТ] 11517383 БОЛТ, HEX W/CON SPR WASH, M10X1.5X55, 28 OD, 37 THD, 10.9, 7114M (TRANS RR MT BRKT) 25971086 MOUNT, ENG [ОПОРНЫЙ УЗЕЛ ДВИГАТЕЛЯ] 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT FRM SI) [ГАЙКА М12] teamcadillac.ru 25971085 MOUNT, ENG [ШАРНИР ДВИГАТЕЛЯ] 25716470 BRACKET, ENG MT (6E00-005) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ & ЧАСТЬIAL ДВИГАТЕЛЬ (LH2/4.6A) ↓ teamcadillac.ru 19177068 ДВИГАТЕЛЬ, GASOLINE (GOODWRENCH NEW) (FOR 07 STS, SWP OIL FILT ADAPT, ENG OIL CLR FRM ORIG ENG.06 & PREV STS/SRX/XLR SWP МАСЛЯНЫЙ ПОДДОН, ENG OIL CLR IF APPL, WTR OTLT ASM, CAM ACTUATOR FRM ORIG) (ENG.05 & PREV STS/SRX/XLR SWP CAM CVRS & PVC TBE F (6E00-006) - 2004-2005 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 1 БЛОК ЦИЛИНДРОВ & ВНУТРЕННИЕ ДЕТАЛИ (LH2/4.6A) ↓ 12573430 SEAL, LWR C/CASE (4.3MM WIDE X 5MM TALL) [ПРОКЛАДКА] 11515793 БОЛТ, HFH (LWR C/CASE) 03522376 БОЛТ, HFH, M6X1X23, 18 THD, 14.50 OD, 7T, ZP (ENG OIL MANIF) 03542310 БОЛТ, LWR C/CASE (M10X1.5X125, 30 THD) (8.900) 03542311 STUD, LWR C/CASE (M10X1.5X125-M9X1.0X13) (1.428) 03530355 PIN, LWR C/CASE LOC (M8X20) 12565564 CRANKSHAFT, (MCHG) [КОЛЕНЧАТЫЙ ВАЛ] 12585420 PIN, CR/SHF SPKT LOC 89017562 BEARING KIT, CR/SHF (STD) (POSN # 1, 2, 4, 5) [ПОДШИПНИК] 89017563 BEARING KIT, CR/SHF (STD) (POSN # 3) [ПОДШИПНИК] 12568025 SEAL, CR/SHF RR OIL [ПРОКЛАДКА] 12338076 PIN, TRANSAXLE LOC (19.5 MM X 18.5 MM) (TO CYL BLK) 03525915 PIN, ENG FRT CVR LOC (DOWEL, 5.99X17.25, CHAM BOTH ENDS, 10.9) 24503702 PLUG, ENG BLK COOL HOLE (8X1.25X12, 10.5 THD W/6MM OF 6124M ADHES, 17.6 OD, 9.8, PC) 03522422 PLUG, CM/SHF (CUP, W/LIP, 50.24X6.12X1.52, 52.58 OD, 1008, OIL) 12580474 FLYКОЛЕСО, ENG [МАХОВИК ДВИГАТЕЛЯ] 12561075 БОЛТ, FLYWHL 12568122 COVER, FLYWHL HSG 12570154 SPROCKET, CR/SHF 12581223 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (PRIMARY) 01647264 БОЛТ, TMG CHAIN TENSR (HFH, 8X1.25X42, 22 THD, 17.0 OD, 9.8, PC, MACH) 12564274 CHAIN, CM/SHF INTER DRV 12559388 GUIDE KIT, TMG CHAIN (PRIMARY CHAIN) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 12577433 SPROCKET, CM/SHF INTER DRV SHF 01647272 БОЛТ, CM/SHF SPKT 12577790 SHAFT, CM/SHF INTER DRV 15685550 БОЛТ, CM/SHF INTER DRV SHF RET (M6X1X20) (16.330) [ВИНТ] 12556023 GUIDE, TMG CHAIN (SECONDARY CHAIN GUIDE) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 12556030 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (SECONDARY) [НАТЯЖИТЕЛЬ РЕМНЯ] 01647264 БОЛТ, TMG CHAIN TENSR (HFH, 8X1.25X42, 22 THD, 17.0 OD, 9.8, PC, MACH) 12556023 GUIDE, TMG CHAIN (SECONDARY CHAIN GUIDE) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 12556030 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (SECONDARY) [НАТЯЖИТЕЛЬ РЕМНЯ] 01647264 БОЛТ, TMG CHAIN TENSR (HFH, 8X1.25X42, 22 THD, 17.0 OD, 9.8, PC, MACH) teamcadillac.ru 12567469 ROD, CONN (INCLS 201) (USES 23MM PIN) 12552947 БОЛТ, CONN ROD (ЧАСТЬ OF 200) (MJ9X1.0-4H6HX61.9 LONG) [БОЛТ] 89017430 PISTON, (W/PIN) (INCLS 211, 212) 12584576 BALANCER, CR/SHF [ШКИВ КОЛЕНВАЛА] 11569873 БОЛТ, CR/SHF BALR (M14X1.5X48.4) 12577394 BAFFLE, МАСЛЯНЫЙ ПОДДОН (B/W CRANK CASE AND PAN) 12567170 SENSOR, CR/SHF POSN (INCLS 721) (ACDelco #213-1511) [ДАТЧИК ПОЛОЖЕНИЯ КОЛЕНВАЛА] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (CR/SHF POSN SEN) 12567446 SENSOR, KNOCK (ACDelco #213-1525) [ДАТЧИК ДЕТОНАЦИИ ДВИГАТЕЛЯ] 10465558 STARTER, (REMAN) (STAMPED 12574832; FOR 2ND DES SEE 89017760) (ACDelco #323-1463) (DELCO PMGR SERIES PG260) [СТАРТЕР В СБОРЕ] 19136223 STARTER, (REMAN) (DELCO PMGR; 1.7 KW) (ACDelco #336-1914) (ALL MAKES) 88864293 STARTER, (REMAN) (DELCO PMGR; 1.7 KW) (ALL MAKES) 89017760 STARTER, (REMAN) (STAMPED 12587429; FOR 1ST DES SEE 10465558) (ACDelco #323-1633) (DELCO SERIES PG260H) [СТАРТЕР] 11515793 БОЛТ, HFH (STRTR) 12597445 HARNESS, CR/SHF POS SEN & KNOCK SEN WRG (INCLS 797) 12583228 BRACKET, CR/SHF POSN SEN WRG HARN CONN (ЧАСТЬ OF 796) 01647172 SPACER, FLYWHL 12559363 BEARING KIT, CONN ROD (STD) (INCLS 203, 204) [КОМПЛЕКТ ПОДШИПНИКОВ СКОЛЬЖЕНИЯ ШАТУНА (2ШТ)] 89017413 RING KIT, PSTN (INCLS 213-216) (6E00-007) - 2004-2005 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 5 КОЛЛЕКТОР & FUEL ДЕТАЛИ КОМПЛЕКТА (LH2/4.6A) ↓ 12565545 TUBE, PCV (CLEAN AIR TUBE) 12577168 TUBE, PCV (INCLS 284) (DIRTY AIR TUBE) 11570614 CЛАМПА-ПРУЖИНАBAND, 15 NOMINAL DIA, 15 THK, STL, ROBO (ЧАСТЬ OF 283) 12583849 OUTLET, WAT (INCLS 382, 387, 908) (ACDelco #15-10427) 12590862 GASKET, WAT OTLT [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12568102 FITTING, ENG COOL AIR BL HOSE (ЧАСТЬ OF 380) 12566109 HOSE, RAD BYPASS 15024902 CЛАМПА, HOSE ПРУЖИНА, 42MM - NOM SIZE, BLK (RAD BYPASS HOSE) 11519172 БОЛТ, HFH, 8X1.25X55, 18 OD, 22THD, 8.8, GMW3359, 6MM MATPOINT, REDUCED BODY (WAT OTLT) 12564771 MANIFOLD, INT (INCLS 502, 520, 902, 903) (INCLS PCV TUBE) (INTAKE DOES NOT NEED PRESSURE RELIEF VALVE) 12571222 FITTING, P/B BOOS VAC TUBE (ЧАСТЬ OF 500) 12579192 COVER, INT MANIF 12579193 COVER, INT MANIF 11588967 STUD, BALL W/HFH, M6X1X20.65, 14.2 O.D., 8.8, GMW3359 (IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ) 12557497 SEAL, UPR INT MANIF (ЧАСТЬ OF 500) (FITS UNDER INTAKE MANIFOLD TO ГОЛОВКА ЦИЛИНДРОВ) [УПЛОТНИТЕЛЬ] 12580250 PLENUM, INT MANIF (INCLS 526) 11588352 БОЛТ, INT MANIF (W/SPCR) 12557010 STUD, F/INJN FUEL RL (HEX, M6X1.022-M6X1.016, 45MM TOTAL LENGTH) (3.275) 12571212 SHIELD, UPR INT MANIF SIGHT (INCLS 595, 596) [ЗАЩИТНЫЙ КОЖУХ ДВИГАТЕЛЯ] 12600206 BRACKET, UPR INT MANIF SIGHT SHLD (INCLS 904) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (UPR INT MANIF SIGHT SHLD) 12567370 STUD, UPR INT MANIF SIGHT SHLD (3.265) 12567371 GROMMET, UPR INT MANIF SIGHT SHLD (ЧАСТЬ OF 590) [ВТУЛКА] 12567687 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 626, 906) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 12607338 SHIELD, EXH MANIF HT 24505098 БОЛТ, HFH, RND HD, 6X1X12.15, W/ANTI SEIZE, 14.2 O.D.DG PT, 10.9, 711 (EXH MANIF H/SHLD) 12567688 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 626, 635, 636, 906) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 11517031 ГАЙКА, HFH, M8X1.25, 9.4THK, 17.4 O.D., 10, TIN ZN (EXH MANIF) 11519171 БОЛТ, EXH MANIF CLA (M8X1.25X50) (3.275) [БОЛТ ВЫПУСКНОГО КОЛЛЕКТОРА] 12345493 SEALANT, TRANS БОЛТ ADHESIVE (GENERAL PURPOSE) 11562490 STUD, STRAIGHT, M8X1.25X20, M8X1.25X40, 69 TL, 9.8, GMW3179, EXT HEX SOCKET (EXH MANIF) [ШПИЛЬКА М8] 11609596 STUD, CTLTC CONV (ЧАСТЬ OF 600, 620) [ШПИЛЬКА] 12576372 SHIELD, EXH MANIF HT 24505098 БОЛТ, HFH, RND HD, 6X1X12.15, W/ANTI SEIZE, 14.2 O.D.DG PT, 10.9, 711 (EXH MANIF H/SHLD) 12568289 SHIELD, EXH MANIF LWR HT (ЧАСТЬ OF 620) 10229247 RIVET, EXH MANIF H/SHLD (ЧАСТЬ OF 620) (3.601) 12567376 BODY, THROT (W/THROT ACTR) (INCLS 702) (ACDelco #217-2294) [ДРОССЕЛЬНАЯ ЗАСЛОНКА] 11519973 БОЛТ-HFH, M6X1X60, 18MM THD, 14.2 OD, 8.8, 3359GMW, REDUCED BODY, MAT PT. (ЧАСТЬ OF 701) [БОЛТ 6Х1Х60] 12571741 GASKET, THROT BODY (ACDelco #12571741) [ПРОКЛАДКА ДРОССЕЛЬНОГО КЛАПАНА] 09359409 SENSOR, MAP (INCLS SEAL) (INCLS 741) (ACDelco #9359409) 16194007 SEAL, MAP SEN (ЧАСТЬ OF 740) [УПЛОТНИТЕЛЬ ДАТЧИКА ДАВЛЕНИЯ ПОТОКА ВОЗДУХА] 12587812 BRACKET, MAP SEN 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (MAP SEN) [БОЛТ] 12581282 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 745) (ACDelco #214-1105) [КЛАПАН ТОПЛИВОИСПАРИТЕЛЬНОГО БАКА] 11519941 БОЛТ, HFH W/SHLDR, M6X1X22, 13.8 THD, 15 OD, 9.8, 6280M, MACH, DOG-PT (EVAP EMIS CNSTR PURGE SOL) 25917777 PIPE, EVAP EMIS CNSTR PURGE (INCLS 748, 749) 12567655 GASKET, EXH MANIF [ПРОКЛАДКА] 11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (WAT OTLT) 12575237 TUBE, PCV (ЧАСТЬ OF 500) (PLASTIC TUBE) (POA INTAKE MANIFOLD) 12571223 PLUG, P/B VAC SCE HOLE (ЧАСТЬ OF 500) (16.0 MM) 19167509 INSULATOR, UPR INT MANIF CVR (ЧАСТЬ OF 591) (3.405) teamcadillac.ru 12575657 SENSOR, HTD OXY (POSN 1) (IN EXH MANIFOLD/CROSSOVER) (ACDelco #213-1572) (W/RECTANGULAR SHAPED CONNECTOR) (FOR 2ND DES SEE 12596327) [ДАТЧИК] 12596327 SENSOR, HTD OXY (POSN 1) (IN EXH MANIFOLD/CROSSOVER) (ACDelco #213-3240) (W/OVAL SHAPED CONNECTOR) (FOR 1ST DES SEE 12575657) [КИСЛОРОДНЫЙ ДАТЧИК] 25709703 SEAL, CTLTC CONV (ЧАСТЬ OF 600, 620) (ROUND METAL SEAL) [ПРОКЛАДКА НАСОСА] 12585313 PLUG, ENG COOL AIR BL (ЧАСТЬ OF 380) 12616537 COVER, INT MANIF (RR) (6E00-008) - 2004-2006 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 3 ПЕРЕДНЯЯ КРЫШКА И ОХЛАЖДЕНИЕ (LH2/4.6A) ↓ 03525915 PIN, ENG FRT CVR LOC (DOWEL, 5.99X17.25, CHAM BOTH ENDS, 10.9) 89017437 COVER, ENG FRT (INCLS 353) (STMPD 12569092 & USED W/PAPER GKT; FOR 2ND DESIGN SEE 89017798.) [КРЫШКА В СБОРЕ] 89017798 COVER, ENG FRT (INCLS 353) (STMPD 12584582 & USED W/METAL GKT; FOR 1ST DESIGN SEE 89017437) 12576673 GASKET, ENG FRT CVR (PAPER GASKET) (W/ПЕРЕДНЯЯ КРЫШКА STAMPED 12569092. FOR 2ND DESIGN SEE 12584580.) 12593627 GASKET, ENG FRT CVR (W/ ПЕРЕДНЯЯ КРЫШКА STAMPED 12584582; FOR 1ST DESIGN SEE 12576673.) [ПРОКЛАДКА ПЕРЕДНЕЙ КРЫШКИ ДВИГАТЕЛЯ] 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (ENG FRT CVR) [БОЛТ] 12569545 PLUG, ENG FRT CVR HOLE 12595614 PUMP, WAT (W/SEAL) (INCLS 901) (ACDelco #251-699) [НАСОС ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (W/PMP) [БОЛТ] 12604614 PULLEY, W/PMP 24503961 БОЛТ, W/PMP PUL (M6X1.0 6G THD W/WA) (8MM SOCKET HD) 12559807 THERMOSTAT, ENG COOL (W/O GSKT) (ACDelco #131-128) [КЛАПАН РЕГУЛИРОВКИ ТЕМПЕРАТУРЫ СИСТЕМЫ ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ] 12563623 GASKET, ENG COOL THERM (ACDelco #12563623) [ПРОКЛАДКА] 12596643 ШЛАНГИ, ENG COOL THERM (ACDelco #15-80869) 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (ENG COOL THERM HSG) [БОЛТ] 12583849 OUTLET, WAT (INCLS 382, 387) (ACDelco #15-10427) 12590862 GASKET, WAT OTLT [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12568102 FITTING, ENG COOL AIR BL HOSE (ЧАСТЬ OF 380) 12566109 HOSE, RAD BYPASS 15024902 CЛАМПА, HOSE ПРУЖИНА, 42MM - NOM SIZE, BLK (RAD BYPASS HOSE) teamcadillac.ru 11519172 БОЛТ, HFH, 8X1.25X55, 18 OD, 22THD, 8.8, GMW3359, 6MM MATPOINT, REDUCED BODY (WAT OTLT) 12580250 PLENUM, INT MANIF (INCLS 526) 09359409 SENSOR, MAP (INCLS SEAL) (INCLS 741) (ACDelco #9359409) 16194007 SEAL, MAP SEN (ЧАСТЬ OF 740) [УПЛОТНИТЕЛЬ ДАТЧИКА ДАВЛЕНИЯ ПОТОКА ВОЗДУХА] 12587812 BRACKET, MAP SEN 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (MAP SEN) [БОЛТ] 12581282 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 745) (ACDelco #214-1105) [КЛАПАН ТОПЛИВОИСПАРИТЕЛЬНОГО БАКА] 11519941 БОЛТ, HFH W/SHLDR, M6X1X22, 13.8 THD, 15 OD, 9.8, 6280M, MACH, DOG-PT (SOL VLV) 11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (WAT OTLT) 12563877 SEAL, W/PMP CVR (O RING) (ЧАСТЬ OF 360) [КОЛЬЦЕВОЕ УПЛОТНЕНИЕ ВОДЯННОГО НАСОСА] (6E00-010) - 2004-2005 E КРЕПЛЕНИЕ ДВИГАТЕЛЯ TO ТРАНСМИССИЯ (LH2/4.6A) ↓ 12580474 FLYКОЛЕСО, ENG (INCLS 10) [МАХОВИК ДВИГАТЕЛЯ] 25771275 BRACKET, ENG WRG HARN (USED IN GENERATOR PACKAGE) 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] 24205900 COVER, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] teamcadillac.ru 12561075 БОЛТ, FLYWHL 12568122 COVER, FLYWHL HSG 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (TRANS CONV CVR) (ACDelco #11517518) [БОЛТ] 12568123 COVER, TRANS CONV 01647172 SPACER, FLYWHL (ЧАСТЬ OF 1) (6E00-011) - 2004-2005 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 4 МАСЛЯНЫЙ НАСОС,МАСЛЯНЫЙ ПОДДОН & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7) ↓ 22531637 PIN, МАСЛЯНЫЙ ПОДДОН LOC (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 12584299 GUIDE, TMG CHAIN (ЧАСТЬ OF 463) teamcadillac.ru 12610145 PAN, OIL (INCLS 404-406, 410-413, 420, 422, 424, 712, 713) 12575373 PIPE, O/PMP SUC (ЧАСТЬ OF 400) 12566837 SEAL, O/PMP SUC PIPE (ЧАСТЬ OF 400) [УПЛОТНЕНИЕ] 12566872 DEFLECTOR, CR/SHF OIL (ЧАСТЬ OF 400) 11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (ЧАСТЬ OF 400) [БОЛТ] 11562588 PLUG, МАСЛЯНЫЙ ПОДДОН DRN (ЧАСТЬ OF 400) (INCLS 413) (W/ SEAL) (EXC MAGNET) [ЗАГЛУШКА МАСЛЯНОГО ПОДДОНА] 11588364 БОЛТ, HFH, M8X1.25X34, 25 THD, 18 O.D., 9.8, GMW3359 (ЧАСТЬ OF 400) [БОЛТ М8] 11588424 БОЛТ, HFH, M6X1X145, 18 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 400) [ШЕСТИГРАННЫЙ ВИНТ] 11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (ЧАСТЬ OF 400) [БОЛТ] 12595327 INDICATOR, OIL LVL (INCLS 434) 12593211 TUBE, OIL LVL IND (INCLS 432) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 431) (BLACK) (6.07MM ID, 1.78MM DIA) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (OIL LVL IND TUBE) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) 12591607 ADAPTER, OIL FLTR (INCLS 441-443, 446-451, 456, 458, 459, 728, 729) [АДАПТЕР МАСЛЯНОГО ФИЛЬТРА] 12591604 GASKET, OIL FLTR (ЧАСТЬ OF 440) (BETWEEN OIL FILTER ADAPTER AND BLOCK) [ПРОКЛАДКА МАСЛЯНОГО ФИЛЬТРА] 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 440) 11519174 БОЛТ, HFH, W/REDUCED BODY, M8X1.25X65, THD 22, O.D. 18, 8.8, GMW3359 (ЧАСТЬ OF 440) 25014612 VALVE, OIL FLTR BYPASS (ЧАСТЬ OF 440, 450) (W/O VAPOR SEPARATOR) (OPENING PRESSURE 21 PSI NOMINAL) (ЧАСТЬ HAS A 16.10MM MAX OD & FITS A 15.84 HOLE IN BLOCK) 11519184 БОЛТ, OIL FLTR ADAP (ЧАСТЬ OF 440) (M10X1.5X45) (0.029) 19114105 ФИЛЬТР, МАСЛЯНЫЙ (ЧАСТЬ OF 440) (ACDelco #PF2129F) (DURAPACK) (BULK PKG, QTY 12) 25177917 ФИЛЬТР, МАСЛЯНЫЙ (ЧАСТЬ OF 440) (ACDelco #PF2129) [МАСЛЯНЫЙ ФИЛЬТР ДВИГАТЕЛЯ] 12583470 CAP, OIL FLTR (ЧАСТЬ OF 440) (INCLS 446, 451, 456) [КРЫШКА] 12577653 SEAL, OIL FLTR CAP (O RING) (ЧАСТЬ OF 440, 450) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КРЫШКИ МАСЛЯНОГО ФИЛЬТРА] 12590152 PUMP, OIL (INCLS 151, 154, 464-466, 468, 470-472, 474, 475) (INCLS GUIDE, БОЛТS) [МАСЛЕННЫЙ НАСОС] 11519172 БОЛТ, HFH, 8X1.25X55, 18 OD, 22THD, 8.8, GMW3359, 6MM MATPOINT, REDUCED BODY (ЧАСТЬ OF 463) 12590119 NOZZLE, PSTN OIL (INCLS 491) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 490) 12603780 SENSOR, ENG OIL LVL & TEMP (ЧАСТЬ OF 400) (INCLS 713) (ACDelco #213-3945) 12621659 SENSOR, ENG OIL PRESS (INCLS 729) (ЧАСТЬ OF 440) (ACDelco #12621659) (6E00-013) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ & ЧАСТЬIAL ДВИГАТЕЛЬ (LY7/3.6-7) ↓ teamcadillac.ru 19206165 ДВИГАТЕЛЬ, (SERV ЧАСТЬIAL) (MAY NEED TO SWAP МАСЛЯНЫЙ ПОДДОН) (REQUIRES CRANKSHAFT BALANCER WITH KEYWAY. FOR SINGLE BELT, USE 12603181. FOR DUAL BELT BALANCER USE 12603180) (6E00-014) - 2004-2009 E КРЕПЛЕНИЕ ДВИГАТЕЛЯ TO ТРАНСМИССИЯ (LY7/3.6-7) ↓ 12572042 PLATE, A/TRNS FLEX 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] teamcadillac.ru 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (TRANS CONV CVR) [БОЛТ] 24222918 COVER, TRANS CONV 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] (6E00-015) - 2004-2009 E ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ-V6 (LY7/3.6-7, M82) ↓ 25892303 MOUNT, TRANS RR 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (TRANS MT) [БОЛТ, М10Х1.5Х30] 11517383 БОЛТ, HEX W/CON SPR WASH, M10X1.5X55, 28 OD, 37 THD, 10.9, 7114M (TRANS RR MT BRKT) teamcadillac.ru 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT) [ГАЙКА М12] 25756321 BRACKET, ENG MT 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (ENG MT BRKT) [БОЛТ, М10Х1.5Х30] 25971088 MOUNT, ENG [ОПОРНЫЙ УЗЕЛ ДВИГАТЕЛЯ] 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT FRM SI) [ГАЙКА М12] 25971089 MOUNT, ENG 25756322 BRACKET, ENG MT (6E00-016) - 2004-2009 E ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ-V6 (LY7/3.6-7, MX5) ↓ 15143640 MOUNT, TRANS RR 25892306 MOUNT, TRANS RR 11515775 БОЛТ, HFH, M12X1.75X30, 10.9, 7114M (TRANS MT) [БОЛТ] 11517383 БОЛТ, HEX W/CON SPR WASH, M10X1.5X55, 28 OD, 37 THD, 10.9, 7114M (TRANS RR MT BRKT) 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT) [ГАЙКА М12] teamcadillac.ru 25756321 BRACKET, ENG MT 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (ENG MT BRKT) [БОЛТ, М10Х1.5Х30] 25971088 MOUNT, ENG [ОПОРНЫЙ УЗЕЛ ДВИГАТЕЛЯ] 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT FRM SI) [ГАЙКА М12] 25971085 MOUNT, ENG [ШАРНИР ДВИГАТЕЛЯ] 25756320 BRACKET, ENG MT (6M00-066) - 2005-2006 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 4 МАСЛЯНЫЙ НАСОС, PAN & ДЕТАЛИ КОМПЛЕКТА (LH2/4.6A) ↓ 12580850 MANIFOLD, ENG OIL (INCLS 107-109) (WITHOUT МАСЛЯНЫЙ ПОДДОН BAFFLE) [КОЛЛЕКТОР МАСЛЯНЫЙ] 03522376 БОЛТ, HFH, M6X1X23, 18 THD, 14.50 OD, 7T, ZP (ENG OIL MANIF) 03542310 БОЛТ, LWR C/CASE (M10X1.5X125, 30 THD) (8.900) 03542311 STUD, LWR C/CASE (M10X1.5X125-M9X1.0X13) (1.428) 12567511 PAN, OIL (INCLS 401, 412, 413, 420-422, 712, 713, 715) [КАРТЕР] 12568928 GASKET, МАСЛЯНЫЙ ПОДДОН (ЧАСТЬ OF 400) [ПРОКЛАДКА] 12567529 PIPE, O/PMP SUC (INCLS 406, 407) 12573569 GASKET, O/PMP SUC PIPE (ЧАСТЬ OF 405) [ПРОКЛАДКА МАСЛЯНОГО НАСОСА] 03522382 БОЛТ, O/PMP SUC PIPE (ЧАСТЬ OF 405) (HFH, M6X1.0X28) 03542258 ГАЙКА, O/PMP SUC PIPE (HFH, M9X1) (1.430) 12577394 BAFFLE, МАСЛЯНЫЙ ПОДДОН (B/W CRANK CASE AND PAN) 11562588 PLUG, МАСЛЯНЫЙ ПОДДОН DRN (ЧАСТЬ OF 400) (INCLS 413) (W/ SEAL) (EXC MAGNET) [ЗАГЛУШКА МАСЛЯНОГО ПОДДОНА] 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 400, 412) (18 X 2) (1.456) 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 400) 11519173 БОЛТ, HFH, REDUCED BODY, M8X1.25X60, 22THD, 18 OD, 8.8, GMW3359 (ЧАСТЬ OF 400) 11519178 БОЛТ HFH, M8X1.25X100, 13MM SOCKET, 8.8, GMW3359 (ЧАСТЬ OF 400) 12585398 INDICATOR, OIL LVL (INCLS 434) [ЩУП УРОВНЯ МАСЛА] 12570585 TUBE, OIL LVL IND (INCLS 432) [НАПРАВЛЯЮЩАЯ ТРУБКА ЩУПА УРОВНЯ МАСЛА] 24504091 SEAL, OIL LVL IND TUBE (O RING) (ЧАСТЬ OF 431) (BLACK) (6.07MM ID, 1.78MM DIA) 11515765 БОЛТ, HFH, M10X1.5X25, 22.30 O.D., HDR PT, 10.9, 7112M (OIL LVL IND TUBE) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) 12598047 ADAPTER, OIL FLTR (INCLS 441, 442, 445, 446, 449, 717, 718, 728, 729) 12573045 GASKET, OIL FLTR ADAP (ЧАСТЬ OF 440) [ПРОКЛАДКА МАСЛЯНОГО ФИЛЬТРА] teamcadillac.ru 11519173 БОЛТ, HFH, REDUCED BODY, M8X1.25X60, 22THD, 18 OD, 8.8, GMW3359 (ЧАСТЬ OF 440) 24575062 FITTING, OIL FLTR (ЧАСТЬ OF 440) 25014612 VALVE, OIL FLTR BYPASS (ЧАСТЬ OF 440) (W/O VAPOR SEPARATOR) (OPENING PRESSURE 21 PSI NOMINAL) (ЧАСТЬ HAS A 16.10MM MAX OD & FITS A 15.84 HOLE IN BLOCK) 89017342 ФИЛЬТР, МАСЛЯНЫЙ (ЧАСТЬ OF 440) (FOR NON-CANADIAN ORDERS) (ACDelco #89017342) 11519833 PLUG ROUND HD, M16X1.5X22, 20 OD, 10 THD, 5.8, 4345M, SEALANT 9985490, MACH (OIL FLTR BYPASS HOLE) 12590890 PUMP, OIL (INCLS 464-472) [МАСЛЯНЫЙ НАСОС] 11518944 SCREW, PAN HD, M6X1X25, 20.9 THD, 11 OD, 8.8, GMW3359, 6 LOBED T-30 M-POINT (ЧАСТЬ OF 463) (8.913) 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (O/PMP) (ACDelco #11517518) [БОЛТ] 12568009 TUBE, O/PMP OTLT (INCLS 481) [ТРУБКА] 12568320 SEAT, ENG OIL MANIF CHK VLV (ЧАСТЬ OF 480) (0.724) [КОЛЬЦЕВОЕ УПЛОТНЕНИЕ] 11518944 SCREW, PAN HD, M6X1X25, 20.9 THD, 11 OD, 8.8, GMW3359, 6 LOBED T-30 M-POINT (O/PMP OTLT TUBE) (8.913) 12603787 SWITCH, ENG OIL LVL IND (ЧАСТЬ OF 400) (INCLS 713) 11517519 БОЛТ, ENG OIL LVL SEN (ЧАСТЬ OF 400) (M6X1X25, 22 THD, 14.2) (8.900) 12573744 SHIELD, ENG OIL PRESS GA SEN HT (ЧАСТЬ OF 440) 11519964 БОЛТ, HFH, M6X1X13, 6 THD, 14.2 OD, 8.8, GMW3359, MAT POINT (ЧАСТЬ OF 440) 12567911 SENSOR, ENG OIL PRESS (ЧАСТЬ OF 440) (INCLS 729) (ACDelco #213-1547) [ДАТЧИК ДАВЛЕНИЯ МАСЛА] (6Y00-003) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 2 ГОЛОВКА ЦИЛИНДРОВ & ДЕТАЛИ КОМПЛЕКТА (LH2/4.6A) ↓ 03522352 PIN, CYL HD LOC (HOLLOW DOWEL, 15.675X28, CHAM BOTH ENDS, SAE 12L14, ZP) 12564273 CHAIN, SECD TMG 12559389 SHOE KIT, TMG CHAIN TENSR (INCLS 174) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (ЧАСТЬ OF 173) (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 12559390 SHOE KIT, TMG CHAIN TENSR (INCLS 184) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (ЧАСТЬ OF 183) (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 12576969 VALVE, CM/SHF POSN ACTR SOL 12567414 ACTUATOR, CM/SHF POSN (EXH) 12567415 ACTUATOR, CM/SHF POSN (EXH) 12567416 ACTUATOR, CM/SHF POSN (INT) [ПРИВОДНОЙ МЕХАНИЗМ] 12567417 ACTUATOR, CM/SHF POSN (INT) [ПРИВОДНОЙ МЕХАНИЗМ] 12589229 COVER, CM/SHF (INCLS 251, 254-256, 261, 908, 909) 12591265 COVER, CM/SHF (INCLS 251, 254-256, 261, 908, 909) teamcadillac.ru 12576394 GASKET, CM/SHF CVR (ЧАСТЬ OF 250) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ ЦИЛИНДРОВ] 12576395 GASKET, CM/SHF CVR (ЧАСТЬ OF 250) (BETWEEN HEAD AND CAM COVER) [ПРОКЛАДКА] 12576396 GASKET, CM/SHF CVR (ЧАСТЬ OF 250) (СВЕЧИ HOLES) [ПРОКЛАДКА] 12557829 БОЛТ, CM/SHF CVR (ЧАСТЬ OF 250) 12573742 INSULATOR, CM/SHF CVR БОЛТ (ЧАСТЬ OF 250) 12577268 CAP, OIL FIL (MOBIL 1, SAE 5W30, NON-VENTED, W/SEAL, W/TURNING EARS, NOT ROUND) (INCLS 259) (ACDelco #FC209) 24100002 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 258) (27.94MM I.D.) (SIZE #320) (1.745) [ПРОКЛАДКА] 12578248 HEAD, CYL (MCHG) (INCLS 312, 313, 315, 334-337) 12578249 HEAD, CYL (MCHG) (INCLS 312, 313, 315, 334-337) 11589058 БОЛТ, CYL HD (M11X2.0X161) [БОЛТ М11] 01647218 БОЛТ, CYL HD (QTY 3-RH, 3-LH) (M6X1.0X50, 10.9) (HFH, MACH) 11562126 PLUG, CYL HD CORE HOLE (ЧАСТЬ OF 300) (CUP, 32.03X7.88X1.27, S30400 SS PER SAE J405.) [ЗАГЛУШКА ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 01647543 PLUG, CYL HD CORE HOLE (ЧАСТЬ OF 300) (ROUND HEAD, INT HEX, W/ALUM WASH, 20X1.5X17, 12.25 THD, C1010 RQ) 11588949 PLUG, M16X1.5X14, 24 OD, SAE 1010 STL, GMW3044, W/ AL WASHER (ЧАСТЬ OF 300) [ПРОБКА ЗАМКА] 12574785 RESTRICTOR, ENG BLK OIL GAL 12578258 VALVE, EXH [КЛАПАН ВЫПУСКНОЙ] 12590223 VALVE, INT 12565203 ARM, VLV RKR [КОРОМЫСЛО КЛАПАНА ДВИГАТЕЛЯ] 24100005 ADJUSTER, HYD VLV LASH (ACDelco #24100005) [ТОЛКАТЕЛЬ КЛАПАНА ДВИГАТЕЛЯ] 12574354 SEAL, VLV STEM OIL [УПЛОТНЕНИЕ ШТОКА КЛАПАНА] 12565199 ПРУЖИНА, VLV 12580385 CAP, VLV SPR 01647209 KEY, VLV STEM 12565171 CAMSHAFT, EXH (MCHG) (INCLS 338) 12565172 CAMSHAFT, EXH (MCHG) (INCLS 338) [РАСПРЕДВАЛ В СБОРЕ] 12563833 CAMSHAFT, INL (MCHG) (INCLS 338) [РАСПРЕДВАЛ] 12565168 CAMSHAFT, INL (MCHG) (INCLS 338) [КОЛЕНВАЛ] 01647553 БОЛТ, CM/SHF BRG CAP (ЧАСТЬ OF 300) (HFH, M6X1.0X39.5) 12596360 ШЛАНГИ, CM/SHF POSN ACTR (INCLS 342, 344, 345, 735-737) 12596361 ШЛАНГИ, CM/SHF POSN ACTR (INCLS 342, 344, 345, 735-737) 12567656 GASKET, CM/SHF POSN ACTR HSG (ЧАСТЬ OF 340) (0.423) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12567657 GASKET, CM/SHF POSN ACTR HSG (ЧАСТЬ OF 340) (0.423) [УПЛОТНЕНИЕ ДВИГАТЕЛЯ] 11518706 STUD-HFH, M6X1X13.4, M6X1X40, 14.2 OD, 60 TL, 10.9, GM6280M (NON HEX CHROME) (ЧАСТЬ OF 340) (8.981) 11518707 STUD, HFH, M6X1X13 / M6X1X45, 14.2 O.D., 65 TL, 9.8, GM6280M (CM/SHF POSN ACTR HSG) 11562490 STUD, STRAIGHT, M8X1.25X20, M8X1.25X40, 69 TL, 9.8, GMW3179, EXT HEX SOCKET (EXH MANIF) [ШПИЛЬКА М8] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ) 15326386 SENSOR, ENG COOL TEMP (2-WAY MALE) (3.682) (ACDelco #213-928) [ДАТЧИК ТЕМПЕРАТУРЫ ДВИГАТЕЛЯ] 12571533 СВЕЧИ, (ACDelco #41-986) (PLATINUM PLUG) [СВЕЧА ЗАЖИГАНИЯ] 12569160 SENSOR, CM/SHF POSN (INCLS 726) (ACDelco #213-1512) [ДАТЧИК ПОЛОЖЕНИЯ РАСПРЕДВАЛА] 01647346 БОЛТ, HFH, M6X1X17, 17THD, 14.2 O.D., 8.8, ZF (CM/SHF POSN SEN) 12567085 MAGNET, CM/SHF POSN ACTR (INCLS 737) (ЧАСТЬ OF 340) [МАГНИТ] 11518845 SCREW PAN HD, M6X1X16, 15 THD, 12 OD, 8.8, 6280M, TORX, T30, HDR PT, W/SEALANT (ЧАСТЬ OF 340) 12567421 PLUG, CM/SHF POSN ACTR BORE (ЧАСТЬ OF 340, 735) 12581176 HARNESS, ELEK ICM WRG (INCLS 772) 11519976 БОЛТ, HFLGE, M8X1.25X20, 15.6 THD, 18 O.D., 8.8, GMW3359 (ELEK ICM WRG HARN CLIP) 11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (ЧАСТЬ OF 770) [БОЛТ М8] 11517094 SCREW, M5X.8X15.6, 10.4 THD, 10.2 OD, 6202M, 7114M, TAPER-POINT (ЧАСТЬ OF 250) (ACDelco #11517094) 89017450 GASKET KIT, CYL HD (INCLS 302, 310) (INCL GASKET AND M11X2.0 БОЛТS) [ПРОКЛАДКА ДВИГАТЕЛЯ] 89017451 GASKET KIT, CYL HD (INCLS 302, 310) (INCL GASKET AND M11X2.0 БОЛТS) [ПРОКЛАДКА ДВИГАТЕЛЯ] (GM00-387) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 1 БЛОК ЦИЛИНДРОВ И ВНУТРЕННИЕ ДЕТАЛИ (LY7/3.6-7) ↓ 12560272 БОЛТ, CR/SHF BRG CAP (M10X2X102.5, 24.5) [ВИНТ] 11518861 БОЛТ, HFH, W/REDCD BODY, M8X1.25X90, 26 THD, 18 O.D., 10.9, GM4277M (CR/SHF BRG CAP) [БОЛТ] 11609410 БОЛТ, HFH, M8X1.25X25, 10.9, GMW3179 (CR/SHF BRG CAP) (0.056) [БОЛТ] 89021297 ADHESIVE/SEALANT, THREADLOCKER HI STRENGTH 10ML ERI (CR/SHF BRG CAP) [АДГЕЗИВ] 11589000 БОЛТ, HFH, M8X1.25X50, 24 THD, 18 OD, 10.9, GMW3359, RED BODY, W/ADH (CR/SHF BRG CAP) 12557520 PLUG, ENG BLK OIL GAL (CUP-.390IN OD, .040IN THK, STEEL) 12621351 CRANKSHAFT, (USE T/W 12601937, 12603180) [КОЛЕНВАЛ] 12585420 PIN, CR/SHF SPKT LOC 11561583 PLUG, ENG BLK OIL GAL (M14X1.5X16, 22 OD) (0.253) 12566587 PLUG, ENG BLK OIL GAL 11561751 PLUG, CYL HD WAT JKT HOLE (M20X1.5X30.5) (1.531) 00360571 PLUG, ENG BLK CORE HOLE (CUP DIA 34.3MM) 12597210 PIN, TRANS LOC 24229149 PIN, TRANS LOC 12620955 SEAL, CR/SHF RR OIL (INCLS 134) [ПРОКЛАДКА КОЛЕНВАЛА ДВИГАТЕЛЯ] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 133) 22531637 PIN, МАСЛЯНЫЙ ПОДДОН LOC (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 12570326 PIN, CYL HD LOC [ЗАГЛУШКА БЛОКА ЦИЛИНДРОВ] 12572042 PLATE, A/TRNS FLEX 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12608432 ROD, CONN (INCLS 201, 202) 11519680 БОЛТ, CONN ROD (ЧАСТЬ OF 200) (M9X1X53) [БОЛТ] 12598657 BEARING KIT, CONN ROD (UPPER) [ПОДШИПНИК СКОЛЬЖЕНИЯ ШАТУНА] 12585675 PISTON, (W/PIN) (INCLS 211, 212) (.25 O.S.) 12590866 PISTON, (W/PIN) (INCLS 211, 212) (STD) 12566186 RETAINER, PSTN PIN (ЧАСТЬ OF 210) 12597654 BALANCER, CR/SHF (DUAL BELT, W/O KEYWAY) 11569873 БОЛТ, CR/SHF BALR (M14X1.5X48.4) 12582652 SENSOR, CR/SHF POSN (INCLS 721, 722) (ACDelco #213-1632) [ДАТЧИК] 11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (ЧАСТЬ OF 720) [БОЛТ] 12618603 SENSOR, KNOCK (W/O LEADS) (INCLS 724) (ACDelco #213-4335) [ДАТЧИК] 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 723) 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (EXH MANIF H/SHLD) [БОЛТ] 12610603 BEARING KIT, CR/SHF (#1, 2, 4 STD) (INCLS 122, 123) [ПОДШИПНИК СКОЛЬЖЕНИЯ КОЛЕНВАЛА] teamcadillac.ru 12610604 BEARING KIT, CR/SHF (#3 STD) (INCLS 123, 124) [КОМПЛЕКТ ПОДШИПНИКОВ СКОЛЬЖЕНИЯ КОЛЕНВАЛА (3ШТ)] 12608615 RING KIT, PSTN (INCLS 213-216) (STD) (GM00-389) - 2004-2006 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 3 ПЕРЕДНЯЯ КРЫШКА И ОХЛАЖДЕНИЕ (LY7/3.6-7) ↓ 22531637 PIN, ENG FRT CVR LOC (ЧАСТЬ OF 350) (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 11519176 БОЛТ, ENG FRT CVR (ЧАСТЬ OF 350) (M8X1.25X80) (4.081) [БОЛТ] 12598349 COVER, ENG FRT (W/ W/PMP) (INCLS 132, 348, 351-353, 360-362, 725-727, 734, 900-903) 12593045 SEAL, W/PMP (ЧАСТЬ OF 350) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519171 БОЛТ, ENG FRT CVR (ЧАСТЬ OF 350) (M8X1.25X50) (3.275) [БОЛТ ВЫПУСКНОГО КОЛЛЕКТОРА] 12608750 SEAL, CR/SHF FRT OIL (ЧАСТЬ OF 350) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КОЛЕНВАЛА] 12618472 PUMP, WAT (W/GSKT) (ЧАСТЬ OF 350) (INCLS 900) (ACDelco #251-724) [НАСОС] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 350) 12576326 GASKET, W/PMP (ЧАСТЬ OF 350) (ACDelco #251-2048) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12574518 PULLEY, W/PMP (ADX) 11519512 БОЛТ, HFH, W/CON SPR WA, M6X1X13.4, 8.77 THD, 12.3 O.D., 8.8, GMW3359 (W/PMP PUL) 12582472 SEAL, ENG COOL THERM (ЧАСТЬ OF 367) (ACDelco #12582472) [УПЛОТНИТЕЛЬ] 12620259 ШЛАНГИ, ENG COOL THERM (INCLS 365, 366, 369, 371, 372) (INCLS THERMOSTAT) (ACDelco #15-81651) [КОРПУС В СБОРЕ, ТЕРМОСТАТА СИСТЕМЫ ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ] 11519973 БОЛТ-HFH, M6X1X60, 18MM THD, 14.2 OD, 8.8, 3359GMW, REDUCED BODY, MAT PT. (ENG COOL THERM HSG) [БОЛТ 6Х1Х60] 11519974 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3359 (ENG COOL THERM HSG) [БОЛТ] 12584325 SEAL, ENG COOL THERM HSG (O RING) (ЧАСТЬ OF 367) [КОЛЬЦЕ-ОБРАЗНОЕ УПЛОТНЕНИЕ] 12592527 GASKET, ENG COOL THERM HSG (ЧАСТЬ OF 367) (ACDelco #12592527) [ПРОКЛАДКА ТЕРМОСТАТА] 12566429 SEAL, WAT OTLT [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12584040 SEAL, CLNT OTLT (O RING) (ACDelco #15-32584) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519974 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3359 (WAT OTLT) [БОЛТ] 12573984 OUTLET, WAT (INCLS 905) (INCLS БОЛТS, RETAINERS, SEALS & PIPE) (ACDelco #15-10429) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 12592250 SENSOR, CM/SHF POSN (ЧАСТЬ OF 350) (INCLS 726, 727) (ACDelco #213-1565) 11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (ЧАСТЬ OF 350, 725) [БОЛТ] 12615613 VALVE, CM/SHF POSN ACTR SOL 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (CM/SHF POSN ACTR SOL VLV) 12593717 SEAL, CM/SHF POSN ACTR SOL VLV (O RING) (ЧАСТЬ OF 350) teamcadillac.ru (GM00-393) - 2005-2006 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 2 ГОЛОВКА ЦИЛИНДРОВ & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7) ↓ 12570326 PIN, CYL HD LOC [ЗАГЛУШКА БЛОКА ЦИЛИНДРОВ] 12590921 SPROCKET, CR/SHF [ЦЕПНАЯ ЗВЕЗДОЧКА] 12609262 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (INCLS 153, 164) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 152) [БОЛТ М8] 12590920 CHAIN, CM/SHF INTER DRV (PRIMARY) 12597417 GUIDE, TMG CHAIN (INCLS 157) (UPPER PRIMARY) 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 156) [БОЛТ М8] 11588252 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3179 CODE G (ЧАСТЬ OF 165, 166) 12589477 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 152) (PRIMARY) 12597413 SPROCKET, CM/SHF (INCLS 161) (IDLER) 12597414 SPROCKET, CM/SHF (INCLS 161) (IDLER) 12589011 CHAIN, CM/SHF INTER DRV (92 PITCH) (SECONDARY) 12597416 GUIDE, TMG CHAIN (INCLS 172) (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 171) [БОЛТ М8] teamcadillac.ru 12586960 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАТЯЖИТЕЛЬ ЦЕПИ] 11518858 БОЛТ, HFH, M8X1.25X43, 16 THD, 18 O.D., 8.8, GMW3179 (TMG CHAIN TENSR) [БОЛТ М8] 12609260 РОЛИК НАТЯЖИТЕЛЬ, TMG CHAIN (INCLS 176, 177) (SECONDARY) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 175) [БОЛТ М8] 12589478 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 175) 12597418 GUIDE, TMG CHAIN (INCLS 182) (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 181) [БОЛТ М8] 12586961 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАПРАВЛЯЮЩАЯ ПРИВОДНОЙ ЦЕПИ] 11518858 БОЛТ, HFH, M8X1.25X43, 16 THD, 18 O.D., 8.8, GMW3179 (TMG CHAIN TENSR) [БОЛТ М8] 12609258 РОЛИК НАТЯЖИТЕЛЬ, TMG CHAIN (INCLS 186, 187) (SECONDARY) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 185) [БОЛТ М8] 12589479 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 185) 12588272 ACTUATOR, CM/SHF POSN (EXHAUST) 12588273 ACTUATOR, CM/SHF POSN (INTAKE) 11588279 БОЛТ, HFH, M10X1.5X80, 26 THD, 22.3 O.D., 10.9, GM4277M (CM/SHF POSN ACTR) 12604078 COVER, CM/SHF (INCLS 251, 254-257, 260, 263) 12591200 SEAL, CM/SHF CVR (ЧАСТЬ OF 250) (*KIT1) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12591201 COVER, CM/SHF (INCLS 253-257, 261) 12591203 SEAL, CM/SHF CVR (ЧАСТЬ OF 252) (*KIT1) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 11518859 БОЛТ, HFH W/SHLDR, M6X1X35, 11.85 THD, 18 O.D., 8.8, GMW3359 (ЧАСТЬ OF 250, 252) 12566250 INSULATOR, CM/SHF CVR БОЛТ (ЧАСТЬ OF 250, 252) 12583570 CAP, OIL FIL (ROUND W/HDL) (INCLS 904) (NON VENTED) (ACDelco #FC215) 24100002 SEAL, OIL FIL TUBE (O RING) (ЧАСТЬ OF 262) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА] 12578316 FITTING, PCV (ЧАСТЬ OF 250) (INCLS 263) 12583384 FITTING, PCV (ЧАСТЬ OF 252) 12597946 TUBE, OIL FIL (INCLS 259) [ТРУБКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ ГОЛОВКИ БЛОКА] 12580962 HEAD, CYL (MCHG) (INCLS 313, 318, 319, 328, 336, 337) (TO BE USED WITH 2 ДВИГАТЕЛЬ OIL MANIF CHECK VALVE ASSEMBLIES) [ГОЛОВКА БЛОКА ЦИЛИНДРОВ] 12603901 HEAD, CYL (MCHG) (INCLS 313, 318, 319, 328, 336, 337) (DOES NOT INCL ENG OIL MANIF CHECK VALVES. DLR MUST INSTL) 11518863 БОЛТ, CYL HD [БОЛТ] 11519177 БОЛТ-HEX FLANGE HD, REDUCED BODY, M8X1.25X90, 8.8, GMW3359 (CYL HD) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12565988 PLUG - M20X1.5X30.5, 8.8, GMW3044, SEALANT PER GM9985490 (ЧАСТЬ OF 300, 301) 11562127 PLUG, CYL HD OIL GAL (ЧАСТЬ OF 300, 301) (CUP-14.22 OD, 6.6 THK, 304SS) 12575354 VALVE, EXH (STD) [КЛАПАН ВЫПУСКНОЙ] 12584760 VALVE, EXH (0.075 O.S.) [КЛАПАН ВЫПУСКНОЙ] 12575351 VALVE, INT (STD) [КЛАПАН ВПУСКНОЙ] 12584763 VALVE, INT (0.075MM O.S.) (0.297) [КЛАПАН ВПУСКНОЙ] 24100294 ARM, VLV RKR [РЫЧАГ] 24100005 ADJUSTER, HYD VLV LASH (ACDelco #24100005) [ТОЛКАТЕЛЬ КЛАПАНА ДВИГАТЕЛЯ] 12565836 SEAL, VLV STEM OIL [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КЛАПАНА ДВИГАТЕЛЯ] 12575355 ПРУЖИНА, VLV [ПРУЖИНА КЛАПАНА] 12575196 RETAINER, VLV SPR [КОМПАКТ ДИСК] 12575197 KEY, VLV STEM [КЛАПАННЫЙ КЛЮЧ] 12574477 RING, CM/SHF SPKT OIL SEAL (ЧАСТЬ OF 330-333) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО РАСПРЕДВАЛА ДВИГАТЕЛЯ (2 ШТ.)] 12566670 CAMSHAFT, EXH (INCLS 329) 12566669 CAMSHAFT, INT (INCLS 329) 12566672 CAMSHAFT, EXH (INCLS 329) 12566671 CAMSHAFT, INT (INCLS 329) 11518856 HFH, M6X1X43.4, 14.8 THD, 11 O.D., 8.8, GMW3179 CODE G (ЧАСТЬ OF 300, 301) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12580965 VALVE, ENG OIL MANIF CHK [КЛАПАН] 12613057 РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ, IGN (INCLS 705) (ACDelco #12613057) 12566778 SENSOR, ENG COOL TEMP (3.682) (ACDelco #213-1581) [СЕНСОР ТЕМПЕРАТУРЫ] 12597464 СВЕЧИ, (DO NOT CHANGE СВЕЧИ GAP) (ACDelco #41-990) (PLATINUM PLUG) [СВЕЧА ЗАЖИГАНИЯ] 24100002 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 258) (27.94MM I.D.) (SIZE #320) (1.745) [ПРОКЛАДКА] 12625785 GASKET KIT, CYL HD (INCLS 251, 253, 302, 303) [КОМПЛЕКТ ПРОКЛАДОК ГОЛОВКИ БЛОКА ЦИЛИНДРОВ (РЕЗ-7, МЕТ-8, ПАР-2)] 00 - 8-МИ ЦИЛИНДРОВЫЙ ДВИГАТЕЛЬ ↓ (6D00-018) - 2004-2005 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 5 КОЛЛЕКТОР & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7) ↓ 12603990 TUBE, PCV (INCLS 292) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (PCV TUBE) 12616910 HOSE, PCV (INCLS 285, 286, 290-292) (DIRTY AIR) 12587556 MANIFOLD, UPR INT (INCLS 506) 12571079 MANIFOLD, LWR INT (INCLS 519) 12567371 GROMMET, UPR INT MANIF SIGHT SHLD [ВТУЛКА] 12606862 GROMMET, UPR INT MANIF SIGHT SHLD (32MM OD) 11518906 БОЛТ, HFH, RDUCD BDY, M8X1.25X165, 22 THD, 18 O.D., 8.8, GMW3359 (INT UPR MANIF) [БОЛТ] 11519176 БОЛТ, INT MANIF (M8X1.25X80) (4.081) [БОЛТ] 12577530 BRACE, INT MANIF 11588967 STUD, BALL W/HFH, M6X1X20.65, 14.2 O.D., 8.8, GMW3359 (INT MANIF BR) 11900286 БОЛТ, HFH, W/RDUCD BODY, M12X1.75X75.9, 30 THD, 26.6 OD, 10.9, GMW3359 (INT MANIF BR) 12595277 GASKET KIT, UPR INT MANIF (*KIT1) [ПРОКЛАДКА] 11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (LWR INT MANIF) 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (F/INJN FUEL RL) [БОЛТ] 12584921 COVER, UPR INT MANIF 11517031 ГАЙКА, HFH, M8X1.25, 9.4THK, 17.4 O.D., 10, TIN ZN (UPR INT MANIF SIGHT SHLD) 12583604 SHIELD, UPR INT MANIF SIGHT (INCLS 595, 596) [ЗАЩИТА] 11588523 STUD, M6X1 (UPR INT MANIF SIGHT SHLD) 12567371 GROMMET, UPR INT MANIF SIGHT SHLD [ВТУЛКА] 12606862 GROMMET, UPR INT MANIF SIGHT SHLD (32MM OD) 12576262 GASKET, EXH MANIF [ПРОКЛАДКА ВЫПУСКНОГО КОЛЛЕКТОРА] 12571102 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 12580706 SHIELD, EXH MANIF HT 11517516 БОЛТ, HFH, M6X1X13, 9.5 THD, 14.2 OD, 9.8, 6280M, MACH, HDR-PT (EXH MANIF H/SHLD) 12582663 INSULATOR, EXH MANIF UPR 12581806 INSULATOR, EXH MANIF LWR 12576263 GASKET, EXH MANIF 12571101 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 11518860 БОЛТ, HFH, M8X1.25X30, 20.9 THD, 18 O.D., 10.9, GMW3179 CODE G, GM6194M (EXH MANIF H/SHLD) [БОЛТ] 12617267 SHIELD, EXH MANIF HT 12581807 INSULATOR, EXH MANIF LWR 14093869 ГАЙКА, PUSH ON, M6, 2.25THK, 12.95 O.D., STL, POR (EXH MANIF H/SHLD INSL) 12571081 BODY, THROT (INCLS 716) (INCLS THROTTLE POSITION SENSOR) (INCLS ACT MTR) (ACDelco #12571081) (STAMPED 12571081) (FOR 2ND DES SEE 12589056) teamcadillac.ru 12589056 BODY, THROT (INCLS 716) (INCLS THROTTLE POSITION SENSOR) (INCLS ACT MTR) (ACDelco #217-2253) (STAMPED 12589056) (FOR 1ST DES SEE 12571081) 11519972 БОЛТ, THROT BODY (M6X1.0X50) 12581398 GASKET, THROT BODY (ACDelco #217-1610) (USE T/W 88988585 HARNESS T/W 12589056 TBI WHEN REPLACING OLD DESIGN 12571081 TBI) [ПРОКЛАДКА] 12577831 CLIP, ENG WRG HARN (ЧАСТЬ OF 701) [ФИКСАТОР ПРОВОДКИ МОТОРНОГО ОТСЕКА] 12571136 SOLENOID, EVAP EMIS CNSTR C/VLV (INCLS 752) (ACDelco #214-1086) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (EVAP EMIS CNSTR PURGE SOL VLV BRKT) 12584171 HOSE, EVAP EMIS CNSTR SOL VLV 12586694 VALVE, INT MANIF TUNING (INCLS 756) 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (INT MANIF TUNING VLV) [БОЛТ] 12575467 SENSOR, MAP (INCLS 778) (ACDelco #213-1584) [ДАТЧИК] 12572886 RAIL, F/INJN FUEL (СМ. ГРУППУ 03.000 "FUEL INJECTION RAIL" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #217-1551) [МАГИСТРАЛЬ ТОПЛИВНЫХ ФОРСУНОК ДВИГАТЕЛЯ] 12598158 GASKET KIT, INT MANIF (INCLS 521, 522) [ПРОКЛАДКА ДВИГАТЕЛЯ] (6E00-003) - 2004-2006 E ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ-V8 (LH2/4.6A, M22) ↓ 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT) [ГАЙКА М12] 25762620 BRACKET, ENG MT 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (ENG MT BRKT) [БОЛТ, М10Х1.5Х30] 25892303 MOUNT, TRANS RR 11515775 БОЛТ, HFH, M12X1.75X30, 10.9, 7114M (TRANS MT) [БОЛТ] teamcadillac.ru 25971086 MOUNT, ENG [ОПОРНЫЙ УЗЕЛ ДВИГАТЕЛЯ] 11517383 БОЛТ, HEX W/CON SPR WASH, M10X1.5X55, 28 OD, 37 THD, 10.9, 7114M (TRANS RR MT BRKT) 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT FRM SI) [ГАЙКА М12] 25971085 MOUNT, ENG [ШАРНИР ДВИГАТЕЛЯ] 25971087 MOUNT, ENG 25716470 BRACKET, ENG MT 25762621 BRACKET, ENG MT (6E00-004) - 2004-2006 E ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ-V8 (LH2/4.6A, MV3) ↓ 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT) [ГАЙКА М12] 25762620 BRACKET, ENG MT teamcadillac.ru 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (ENG MT BRKT) [БОЛТ, М10Х1.5Х30] 15143640 MOUNT, TRANS RR 25892306 MOUNT, TRANS RR 11515775 БОЛТ, HFH, M12X1.75X30, 10.9, 7114M (TRANS MT) [БОЛТ] 11517383 БОЛТ, HEX W/CON SPR WASH, M10X1.5X55, 28 OD, 37 THD, 10.9, 7114M (TRANS RR MT BRKT) 25971086 MOUNT, ENG [ОПОРНЫЙ УЗЕЛ ДВИГАТЕЛЯ] 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT FRM SI) [ГАЙКА М12] 25971085 MOUNT, ENG [ШАРНИР ДВИГАТЕЛЯ] 25716470 BRACKET, ENG MT (6E00-005) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ & ЧАСТЬIAL ДВИГАТЕЛЬ (LH2/4.6A) ↓ teamcadillac.ru 19177068 ДВИГАТЕЛЬ, GASOLINE (GOODWRENCH NEW) (FOR 07 STS, SWP OIL FILT ADAPT, ENG OIL CLR FRM ORIG ENG.06 & PREV STS/SRX/XLR SWP МАСЛЯНЫЙ ПОДДОН, ENG OIL CLR IF APPL, WTR OTLT ASM, CAM ACTUATOR FRM ORIG) (ENG.05 & PREV STS/SRX/XLR SWP CAM CVRS & PVC TBE F (6E00-006) - 2004-2005 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 1 БЛОК ЦИЛИНДРОВ & ВНУТРЕННИЕ ДЕТАЛИ (LH2/4.6A) ↓ 12573430 SEAL, LWR C/CASE (4.3MM WIDE X 5MM TALL) [ПРОКЛАДКА] 11515793 БОЛТ, HFH (LWR C/CASE) 03522376 БОЛТ, HFH, M6X1X23, 18 THD, 14.50 OD, 7T, ZP (ENG OIL MANIF) 03542310 БОЛТ, LWR C/CASE (M10X1.5X125, 30 THD) (8.900) 03542311 STUD, LWR C/CASE (M10X1.5X125-M9X1.0X13) (1.428) 03530355 PIN, LWR C/CASE LOC (M8X20) 12565564 CRANKSHAFT, (MCHG) [КОЛЕНЧАТЫЙ ВАЛ] 12585420 PIN, CR/SHF SPKT LOC 89017562 BEARING KIT, CR/SHF (STD) (POSN # 1, 2, 4, 5) [ПОДШИПНИК] 89017563 BEARING KIT, CR/SHF (STD) (POSN # 3) [ПОДШИПНИК] 12568025 SEAL, CR/SHF RR OIL [ПРОКЛАДКА] 12338076 PIN, TRANSAXLE LOC (19.5 MM X 18.5 MM) (TO CYL BLK) 03525915 PIN, ENG FRT CVR LOC (DOWEL, 5.99X17.25, CHAM BOTH ENDS, 10.9) 24503702 PLUG, ENG BLK COOL HOLE (8X1.25X12, 10.5 THD W/6MM OF 6124M ADHES, 17.6 OD, 9.8, PC) 03522422 PLUG, CM/SHF (CUP, W/LIP, 50.24X6.12X1.52, 52.58 OD, 1008, OIL) 12580474 FLYКОЛЕСО, ENG [МАХОВИК ДВИГАТЕЛЯ] 12561075 БОЛТ, FLYWHL 12568122 COVER, FLYWHL HSG 12570154 SPROCKET, CR/SHF 12581223 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (PRIMARY) 01647264 БОЛТ, TMG CHAIN TENSR (HFH, 8X1.25X42, 22 THD, 17.0 OD, 9.8, PC, MACH) 12564274 CHAIN, CM/SHF INTER DRV 12559388 GUIDE KIT, TMG CHAIN (PRIMARY CHAIN) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 12577433 SPROCKET, CM/SHF INTER DRV SHF 01647272 БОЛТ, CM/SHF SPKT 12577790 SHAFT, CM/SHF INTER DRV 15685550 БОЛТ, CM/SHF INTER DRV SHF RET (M6X1X20) (16.330) [ВИНТ] 12556023 GUIDE, TMG CHAIN (SECONDARY CHAIN GUIDE) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 12556030 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (SECONDARY) [НАТЯЖИТЕЛЬ РЕМНЯ] 01647264 БОЛТ, TMG CHAIN TENSR (HFH, 8X1.25X42, 22 THD, 17.0 OD, 9.8, PC, MACH) 12556023 GUIDE, TMG CHAIN (SECONDARY CHAIN GUIDE) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 12556030 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (SECONDARY) [НАТЯЖИТЕЛЬ РЕМНЯ] 01647264 БОЛТ, TMG CHAIN TENSR (HFH, 8X1.25X42, 22 THD, 17.0 OD, 9.8, PC, MACH) 12567469 ROD, CONN (INCLS 201) (USES 23MM PIN) 12552947 БОЛТ, CONN ROD (ЧАСТЬ OF 200) (MJ9X1.0-4H6HX61.9 LONG) [БОЛТ] 89017430 PISTON, (W/PIN) (INCLS 211, 212) teamcadillac.ru 12584576 BALANCER, CR/SHF [ШКИВ КОЛЕНВАЛА] 11569873 БОЛТ, CR/SHF BALR (M14X1.5X48.4) 12577394 BAFFLE, МАСЛЯНЫЙ ПОДДОН (B/W CRANK CASE AND PAN) 12567170 SENSOR, CR/SHF POSN (INCLS 721) (ACDelco #213-1511) [ДАТЧИК ПОЛОЖЕНИЯ КОЛЕНВАЛА] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (CR/SHF POSN SEN) 12567446 SENSOR, KNOCK (ACDelco #213-1525) [ДАТЧИК ДЕТОНАЦИИ ДВИГАТЕЛЯ] 10465558 STARTER, (REMAN) (STAMPED 12574832; FOR 2ND DES SEE 89017760) (ACDelco #323-1463) (DELCO PMGR SERIES PG260) [СТАРТЕР В СБОРЕ] 19136223 STARTER, (REMAN) (DELCO PMGR; 1.7 KW) (ACDelco #336-1914) (ALL MAKES) 88864293 STARTER, (REMAN) (DELCO PMGR; 1.7 KW) (ALL MAKES) 89017760 STARTER, (REMAN) (STAMPED 12587429; FOR 1ST DES SEE 10465558) (ACDelco #323-1633) (DELCO SERIES PG260H) [СТАРТЕР] 11515793 БОЛТ, HFH (STRTR) 12597445 HARNESS, CR/SHF POS SEN & KNOCK SEN WRG (INCLS 797) 12583228 BRACKET, CR/SHF POSN SEN WRG HARN CONN (ЧАСТЬ OF 796) 01647172 SPACER, FLYWHL 12559363 BEARING KIT, CONN ROD (STD) (INCLS 203, 204) [КОМПЛЕКТ ПОДШИПНИКОВ СКОЛЬЖЕНИЯ ШАТУНА (2ШТ)] 89017413 RING KIT, PSTN (INCLS 213-216) (6E00-007) - 2004-2005 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 5 КОЛЛЕКТОР & FUEL ДЕТАЛИ КОМПЛЕКТА (LH2/4.6A) ↓ 12565545 TUBE, PCV (CLEAN AIR TUBE) 12577168 TUBE, PCV (INCLS 284) (DIRTY AIR TUBE) 11570614 CЛАМПА-ПРУЖИНАBAND, 15 NOMINAL DIA, 15 THK, STL, ROBO (ЧАСТЬ OF 283) 12583849 OUTLET, WAT (INCLS 382, 387, 908) (ACDelco #15-10427) 12590862 GASKET, WAT OTLT [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12568102 FITTING, ENG COOL AIR BL HOSE (ЧАСТЬ OF 380) 12566109 HOSE, RAD BYPASS 15024902 CЛАМПА, HOSE ПРУЖИНА, 42MM - NOM SIZE, BLK (RAD BYPASS HOSE) 11519172 БОЛТ, HFH, 8X1.25X55, 18 OD, 22THD, 8.8, GMW3359, 6MM MATPOINT, REDUCED BODY (WAT OTLT) 12564771 MANIFOLD, INT (INCLS 502, 520, 902, 903) (INCLS PCV TUBE) (INTAKE DOES NOT NEED PRESSURE RELIEF VALVE) 12571222 FITTING, P/B BOOS VAC TUBE (ЧАСТЬ OF 500) 12579192 COVER, INT MANIF 12579193 COVER, INT MANIF 11588967 STUD, BALL W/HFH, M6X1X20.65, 14.2 O.D., 8.8, GMW3359 (IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ) 12557497 SEAL, UPR INT MANIF (ЧАСТЬ OF 500) (FITS UNDER INTAKE MANIFOLD TO ГОЛОВКА ЦИЛИНДРОВ) [УПЛОТНИТЕЛЬ] 12580250 PLENUM, INT MANIF (INCLS 526) 11588352 БОЛТ, INT MANIF (W/SPCR) 12557010 STUD, F/INJN FUEL RL (HEX, M6X1.022-M6X1.016, 45MM TOTAL LENGTH) (3.275) 12571212 SHIELD, UPR INT MANIF SIGHT (INCLS 595, 596) [ЗАЩИТНЫЙ КОЖУХ ДВИГАТЕЛЯ] 12600206 BRACKET, UPR INT MANIF SIGHT SHLD (INCLS 904) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (UPR INT MANIF SIGHT SHLD) 12567370 STUD, UPR INT MANIF SIGHT SHLD (3.265) 12567371 GROMMET, UPR INT MANIF SIGHT SHLD (ЧАСТЬ OF 590) [ВТУЛКА] 12567687 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 626, 906) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] teamcadillac.ru 12607338 SHIELD, EXH MANIF HT 24505098 БОЛТ, HFH, RND HD, 6X1X12.15, W/ANTI SEIZE, 14.2 O.D.DG PT, 10.9, 711 (EXH MANIF H/SHLD) 12567688 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 626, 635, 636, 906) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 11517031 ГАЙКА, HFH, M8X1.25, 9.4THK, 17.4 O.D., 10, TIN ZN (EXH MANIF) 11519171 БОЛТ, EXH MANIF CLA (M8X1.25X50) (3.275) [БОЛТ ВЫПУСКНОГО КОЛЛЕКТОРА] 12345493 SEALANT, TRANS БОЛТ ADHESIVE (GENERAL PURPOSE) 11562490 STUD, STRAIGHT, M8X1.25X20, M8X1.25X40, 69 TL, 9.8, GMW3179, EXT HEX SOCKET (EXH MANIF) [ШПИЛЬКА М8] 11609596 STUD, CTLTC CONV (ЧАСТЬ OF 600, 620) [ШПИЛЬКА] 12576372 SHIELD, EXH MANIF HT 24505098 БОЛТ, HFH, RND HD, 6X1X12.15, W/ANTI SEIZE, 14.2 O.D.DG PT, 10.9, 711 (EXH MANIF H/SHLD) 12568289 SHIELD, EXH MANIF LWR HT (ЧАСТЬ OF 620) 10229247 RIVET, EXH MANIF H/SHLD (ЧАСТЬ OF 620) (3.601) 12567376 BODY, THROT (W/THROT ACTR) (INCLS 702) (ACDelco #217-2294) [ДРОССЕЛЬНАЯ ЗАСЛОНКА] 11519973 БОЛТ-HFH, M6X1X60, 18MM THD, 14.2 OD, 8.8, 3359GMW, REDUCED BODY, MAT PT. (ЧАСТЬ OF 701) [БОЛТ 6Х1Х60] 12571741 GASKET, THROT BODY (ACDelco #12571741) [ПРОКЛАДКА ДРОССЕЛЬНОГО КЛАПАНА] 09359409 SENSOR, MAP (INCLS SEAL) (INCLS 741) (ACDelco #9359409) 16194007 SEAL, MAP SEN (ЧАСТЬ OF 740) [УПЛОТНИТЕЛЬ ДАТЧИКА ДАВЛЕНИЯ ПОТОКА ВОЗДУХА] 12587812 BRACKET, MAP SEN 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (MAP SEN) [БОЛТ] 12581282 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 745) (ACDelco #214-1105) [КЛАПАН ТОПЛИВОИСПАРИТЕЛЬНОГО БАКА] 11519941 БОЛТ, HFH W/SHLDR, M6X1X22, 13.8 THD, 15 OD, 9.8, 6280M, MACH, DOG-PT (EVAP EMIS CNSTR PURGE SOL) 25917777 PIPE, EVAP EMIS CNSTR PURGE (INCLS 748, 749) 12567655 GASKET, EXH MANIF [ПРОКЛАДКА] 11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (WAT OTLT) 12575237 TUBE, PCV (ЧАСТЬ OF 500) (PLASTIC TUBE) (POA INTAKE MANIFOLD) 12571223 PLUG, P/B VAC SCE HOLE (ЧАСТЬ OF 500) (16.0 MM) 19167509 INSULATOR, UPR INT MANIF CVR (ЧАСТЬ OF 591) (3.405) 12575657 SENSOR, HTD OXY (POSN 1) (IN EXH MANIFOLD/CROSSOVER) (ACDelco #213-1572) (W/RECTANGULAR SHAPED CONNECTOR) (FOR 2ND DES SEE 12596327) [ДАТЧИК] 12596327 SENSOR, HTD OXY (POSN 1) (IN EXH MANIFOLD/CROSSOVER) (ACDelco #213-3240) (W/OVAL SHAPED CONNECTOR) (FOR 1ST DES SEE 12575657) [КИСЛОРОДНЫЙ ДАТЧИК] 25709703 SEAL, CTLTC CONV (ЧАСТЬ OF 600, 620) (ROUND METAL SEAL) [ПРОКЛАДКА НАСОСА] 12585313 PLUG, ENG COOL AIR BL (ЧАСТЬ OF 380) 12616537 COVER, INT MANIF (RR) (6E00-008) - 2004-2006 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 3 ПЕРЕДНЯЯ КРЫШКА И ОХЛАЖДЕНИЕ (LH2/4.6A) ↓ 03525915 PIN, ENG FRT CVR LOC (DOWEL, 5.99X17.25, CHAM BOTH ENDS, 10.9) 89017437 COVER, ENG FRT (INCLS 353) (STMPD 12569092 & USED W/PAPER GKT; FOR 2ND DESIGN SEE 89017798.) [КРЫШКА В СБОРЕ] 89017798 COVER, ENG FRT (INCLS 353) (STMPD 12584582 & USED W/METAL GKT; FOR 1ST DESIGN SEE 89017437) 12576673 GASKET, ENG FRT CVR (PAPER GASKET) (W/ПЕРЕДНЯЯ КРЫШКА STAMPED 12569092. FOR 2ND DESIGN SEE 12584580.) 12593627 GASKET, ENG FRT CVR (W/ ПЕРЕДНЯЯ КРЫШКА STAMPED 12584582; FOR 1ST DESIGN SEE 12576673.) [ПРОКЛАДКА ПЕРЕДНЕЙ КРЫШКИ ДВИГАТЕЛЯ] 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (ENG FRT CVR) [БОЛТ] 12569545 PLUG, ENG FRT CVR HOLE 12595614 PUMP, WAT (W/SEAL) (INCLS 901) (ACDelco #251-699) [НАСОС ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (W/PMP) [БОЛТ] 12604614 PULLEY, W/PMP 24503961 БОЛТ, W/PMP PUL (M6X1.0 6G THD W/WA) (8MM SOCKET HD) 12559807 THERMOSTAT, ENG COOL (W/O GSKT) (ACDelco #131-128) [КЛАПАН РЕГУЛИРОВКИ ТЕМПЕРАТУРЫ СИСТЕМЫ ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ] 12563623 GASKET, ENG COOL THERM (ACDelco #12563623) [ПРОКЛАДКА] 12596643 ШЛАНГИ, ENG COOL THERM (ACDelco #15-80869) 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (ENG COOL THERM HSG) [БОЛТ] 12583849 OUTLET, WAT (INCLS 382, 387) (ACDelco #15-10427) 12590862 GASKET, WAT OTLT [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12568102 FITTING, ENG COOL AIR BL HOSE (ЧАСТЬ OF 380) 12566109 HOSE, RAD BYPASS 15024902 CЛАМПА, HOSE ПРУЖИНА, 42MM - NOM SIZE, BLK (RAD BYPASS HOSE) 11519172 БОЛТ, HFH, 8X1.25X55, 18 OD, 22THD, 8.8, GMW3359, 6MM MATPOINT, REDUCED BODY (WAT OTLT) 12580250 PLENUM, INT MANIF (INCLS 526) 09359409 SENSOR, MAP (INCLS SEAL) (INCLS 741) (ACDelco #9359409) 16194007 SEAL, MAP SEN (ЧАСТЬ OF 740) [УПЛОТНИТЕЛЬ ДАТЧИКА ДАВЛЕНИЯ ПОТОКА ВОЗДУХА] 12587812 BRACKET, MAP SEN 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (MAP SEN) [БОЛТ] 12581282 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 745) (ACDelco #214-1105) [КЛАПАН ТОПЛИВОИСПАРИТЕЛЬНОГО БАКА] teamcadillac.ru 11519941 БОЛТ, HFH W/SHLDR, M6X1X22, 13.8 THD, 15 OD, 9.8, 6280M, MACH, DOG-PT (SOL VLV) 11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (WAT OTLT) 12563877 SEAL, W/PMP CVR (O RING) (ЧАСТЬ OF 360) [КОЛЬЦЕВОЕ УПЛОТНЕНИЕ ВОДЯННОГО НАСОСА] (6E00-010) - 2004-2005 E КРЕПЛЕНИЕ ДВИГАТЕЛЯ TO ТРАНСМИССИЯ (LH2/4.6A) ↓ 12580474 FLYКОЛЕСО, ENG (INCLS 10) [МАХОВИК ДВИГАТЕЛЯ] 25771275 BRACKET, ENG WRG HARN (USED IN GENERATOR PACKAGE) teamcadillac.ru 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] 24205900 COVER, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] 12561075 БОЛТ, FLYWHL 12568122 COVER, FLYWHL HSG 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (TRANS CONV CVR) (ACDelco #11517518) [БОЛТ] 12568123 COVER, TRANS CONV 01647172 SPACER, FLYWHL (ЧАСТЬ OF 1) (6E00-011) - 2004-2005 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 4 МАСЛЯНЫЙ НАСОС,МАСЛЯНЫЙ ПОДДОН & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7) ↓ 22531637 PIN, МАСЛЯНЫЙ ПОДДОН LOC (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 12584299 GUIDE, TMG CHAIN (ЧАСТЬ OF 463) 12610145 PAN, OIL (INCLS 404-406, 410-413, 420, 422, 424, 712, 713) 12575373 PIPE, O/PMP SUC (ЧАСТЬ OF 400) 12566837 SEAL, O/PMP SUC PIPE (ЧАСТЬ OF 400) [УПЛОТНЕНИЕ] 12566872 DEFLECTOR, CR/SHF OIL (ЧАСТЬ OF 400) 11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (ЧАСТЬ OF 400) [БОЛТ] 11562588 PLUG, МАСЛЯНЫЙ ПОДДОН DRN (ЧАСТЬ OF 400) (INCLS 413) (W/ SEAL) (EXC MAGNET) [ЗАГЛУШКА МАСЛЯНОГО ПОДДОНА] 11588364 БОЛТ, HFH, M8X1.25X34, 25 THD, 18 O.D., 9.8, GMW3359 (ЧАСТЬ OF 400) [БОЛТ М8] 11588424 БОЛТ, HFH, M6X1X145, 18 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 400) [ШЕСТИГРАННЫЙ ВИНТ] 11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (ЧАСТЬ OF 400) [БОЛТ] 12595327 INDICATOR, OIL LVL (INCLS 434) 12593211 TUBE, OIL LVL IND (INCLS 432) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 431) (BLACK) (6.07MM ID, 1.78MM DIA) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (OIL LVL IND TUBE) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) 12591607 ADAPTER, OIL FLTR (INCLS 441-443, 446-451, 456, 458, 459, 728, 729) [АДАПТЕР МАСЛЯНОГО ФИЛЬТРА] 12591604 GASKET, OIL FLTR (ЧАСТЬ OF 440) (BETWEEN OIL FILTER ADAPTER AND BLOCK) [ПРОКЛАДКА МАСЛЯНОГО ФИЛЬТРА] 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 440) 11519174 БОЛТ, HFH, W/REDUCED BODY, M8X1.25X65, THD 22, O.D. 18, 8.8, GMW3359 (ЧАСТЬ OF 440) 25014612 VALVE, OIL FLTR BYPASS (ЧАСТЬ OF 440, 450) (W/O VAPOR SEPARATOR) (OPENING PRESSURE 21 PSI NOMINAL) (ЧАСТЬ HAS A 16.10MM MAX OD & FITS A 15.84 HOLE IN BLOCK) 11519184 БОЛТ, OIL FLTR ADAP (ЧАСТЬ OF 440) (M10X1.5X45) (0.029) 19114105 ФИЛЬТР, МАСЛЯНЫЙ (ЧАСТЬ OF 440) (ACDelco #PF2129F) (DURAPACK) (BULK PKG, QTY 12) 25177917 ФИЛЬТР, МАСЛЯНЫЙ (ЧАСТЬ OF 440) (ACDelco #PF2129) [МАСЛЯНЫЙ ФИЛЬТР ДВИГАТЕЛЯ] 12583470 CAP, OIL FLTR (ЧАСТЬ OF 440) (INCLS 446, 451, 456) [КРЫШКА] 12577653 SEAL, OIL FLTR CAP (O RING) (ЧАСТЬ OF 440, 450) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КРЫШКИ МАСЛЯНОГО ФИЛЬТРА] 12590152 PUMP, OIL (INCLS 151, 154, 464-466, 468, 470-472, 474, 475) (INCLS GUIDE, БОЛТS) [МАСЛЕННЫЙ НАСОС] teamcadillac.ru 11519172 БОЛТ, HFH, 8X1.25X55, 18 OD, 22THD, 8.8, GMW3359, 6MM MATPOINT, REDUCED BODY (ЧАСТЬ OF 463) 12590119 NOZZLE, PSTN OIL (INCLS 491) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 490) 12603780 SENSOR, ENG OIL LVL & TEMP (ЧАСТЬ OF 400) (INCLS 713) (ACDelco #213-3945) 12621659 SENSOR, ENG OIL PRESS (INCLS 729) (ЧАСТЬ OF 440) (ACDelco #12621659) (6E00-013) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ & ЧАСТЬIAL ДВИГАТЕЛЬ (LY7/3.6-7) ↓ teamcadillac.ru 19206165 ДВИГАТЕЛЬ, (SERV ЧАСТЬIAL) (MAY NEED TO SWAP МАСЛЯНЫЙ ПОДДОН) (REQUIRES CRANKSHAFT BALANCER WITH KEYWAY. FOR SINGLE BELT, USE 12603181. FOR DUAL BELT BALANCER USE 12603180) (6E00-014) - 2004-2009 E КРЕПЛЕНИЕ ДВИГАТЕЛЯ TO ТРАНСМИССИЯ (LY7/3.6-7) ↓ 12572042 PLATE, A/TRNS FLEX 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] teamcadillac.ru 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (TRANS CONV CVR) [БОЛТ] 24222918 COVER, TRANS CONV 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] (6E00-015) - 2004-2009 E ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ-V6 (LY7/3.6-7, M82) ↓ 25892303 MOUNT, TRANS RR 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (TRANS MT) [БОЛТ, М10Х1.5Х30] 11517383 БОЛТ, HEX W/CON SPR WASH, M10X1.5X55, 28 OD, 37 THD, 10.9, 7114M (TRANS RR MT BRKT) 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT) [ГАЙКА М12] 25756321 BRACKET, ENG MT 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (ENG MT BRKT) [БОЛТ, М10Х1.5Х30] 25971088 MOUNT, ENG [ОПОРНЫЙ УЗЕЛ ДВИГАТЕЛЯ] 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT FRM SI) [ГАЙКА М12] 25971089 MOUNT, ENG teamcadillac.ru 25756322 BRACKET, ENG MT (6E00-016) - 2004-2009 E ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ-V6 (LY7/3.6-7, MX5) ↓ 15143640 MOUNT, TRANS RR 25892306 MOUNT, TRANS RR 11515775 БОЛТ, HFH, M12X1.75X30, 10.9, 7114M (TRANS MT) [БОЛТ] 11517383 БОЛТ, HEX W/CON SPR WASH, M10X1.5X55, 28 OD, 37 THD, 10.9, 7114M (TRANS RR MT BRKT) 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT) [ГАЙКА М12] 25756321 BRACKET, ENG MT teamcadillac.ru 11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (ENG MT BRKT) [БОЛТ, М10Х1.5Х30] 25971088 MOUNT, ENG [ОПОРНЫЙ УЗЕЛ ДВИГАТЕЛЯ] 11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT FRM SI) [ГАЙКА М12] 25971085 MOUNT, ENG [ШАРНИР ДВИГАТЕЛЯ] 25756320 BRACKET, ENG MT (6M00-066) - 2005-2006 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 4 МАСЛЯНЫЙ НАСОС, PAN & ДЕТАЛИ КОМПЛЕКТА (LH2/4.6A) ↓ 12580850 MANIFOLD, ENG OIL (INCLS 107-109) (WITHOUT МАСЛЯНЫЙ ПОДДОН BAFFLE) [КОЛЛЕКТОР МАСЛЯНЫЙ] 03522376 БОЛТ, HFH, M6X1X23, 18 THD, 14.50 OD, 7T, ZP (ENG OIL MANIF) 03542310 БОЛТ, LWR C/CASE (M10X1.5X125, 30 THD) (8.900) 03542311 STUD, LWR C/CASE (M10X1.5X125-M9X1.0X13) (1.428) 12567511 PAN, OIL (INCLS 401, 412, 413, 420-422, 712, 713, 715) [КАРТЕР] teamcadillac.ru 12568928 GASKET, МАСЛЯНЫЙ ПОДДОН (ЧАСТЬ OF 400) [ПРОКЛАДКА] 12567529 PIPE, O/PMP SUC (INCLS 406, 407) 12573569 GASKET, O/PMP SUC PIPE (ЧАСТЬ OF 405) [ПРОКЛАДКА МАСЛЯНОГО НАСОСА] 03522382 БОЛТ, O/PMP SUC PIPE (ЧАСТЬ OF 405) (HFH, M6X1.0X28) 03542258 ГАЙКА, O/PMP SUC PIPE (HFH, M9X1) (1.430) 12577394 BAFFLE, МАСЛЯНЫЙ ПОДДОН (B/W CRANK CASE AND PAN) 11562588 PLUG, МАСЛЯНЫЙ ПОДДОН DRN (ЧАСТЬ OF 400) (INCLS 413) (W/ SEAL) (EXC MAGNET) [ЗАГЛУШКА МАСЛЯНОГО ПОДДОНА] 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 400, 412) (18 X 2) (1.456) 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 400) 11519173 БОЛТ, HFH, REDUCED BODY, M8X1.25X60, 22THD, 18 OD, 8.8, GMW3359 (ЧАСТЬ OF 400) 11519178 БОЛТ HFH, M8X1.25X100, 13MM SOCKET, 8.8, GMW3359 (ЧАСТЬ OF 400) 12585398 INDICATOR, OIL LVL (INCLS 434) [ЩУП УРОВНЯ МАСЛА] 12570585 TUBE, OIL LVL IND (INCLS 432) [НАПРАВЛЯЮЩАЯ ТРУБКА ЩУПА УРОВНЯ МАСЛА] 24504091 SEAL, OIL LVL IND TUBE (O RING) (ЧАСТЬ OF 431) (BLACK) (6.07MM ID, 1.78MM DIA) 11515765 БОЛТ, HFH, M10X1.5X25, 22.30 O.D., HDR PT, 10.9, 7112M (OIL LVL IND TUBE) 24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA) 12598047 ADAPTER, OIL FLTR (INCLS 441, 442, 445, 446, 449, 717, 718, 728, 729) 12573045 GASKET, OIL FLTR ADAP (ЧАСТЬ OF 440) [ПРОКЛАДКА МАСЛЯНОГО ФИЛЬТРА] 11519173 БОЛТ, HFH, REDUCED BODY, M8X1.25X60, 22THD, 18 OD, 8.8, GMW3359 (ЧАСТЬ OF 440) 24575062 FITTING, OIL FLTR (ЧАСТЬ OF 440) 25014612 VALVE, OIL FLTR BYPASS (ЧАСТЬ OF 440) (W/O VAPOR SEPARATOR) (OPENING PRESSURE 21 PSI NOMINAL) (ЧАСТЬ HAS A 16.10MM MAX OD & FITS A 15.84 HOLE IN BLOCK) 89017342 ФИЛЬТР, МАСЛЯНЫЙ (ЧАСТЬ OF 440) (FOR NON-CANADIAN ORDERS) (ACDelco #89017342) 11519833 PLUG ROUND HD, M16X1.5X22, 20 OD, 10 THD, 5.8, 4345M, SEALANT 9985490, MACH (OIL FLTR BYPASS HOLE) 12590890 PUMP, OIL (INCLS 464-472) [МАСЛЯНЫЙ НАСОС] 11518944 SCREW, PAN HD, M6X1X25, 20.9 THD, 11 OD, 8.8, GMW3359, 6 LOBED T-30 M-POINT (ЧАСТЬ OF 463) (8.913) 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (O/PMP) (ACDelco #11517518) [БОЛТ] 12568009 TUBE, O/PMP OTLT (INCLS 481) [ТРУБКА] 12568320 SEAT, ENG OIL MANIF CHK VLV (ЧАСТЬ OF 480) (0.724) [КОЛЬЦЕВОЕ УПЛОТНЕНИЕ] 11518944 SCREW, PAN HD, M6X1X25, 20.9 THD, 11 OD, 8.8, GMW3359, 6 LOBED T-30 M-POINT (O/PMP OTLT TUBE) (8.913) 12603787 SWITCH, ENG OIL LVL IND (ЧАСТЬ OF 400) (INCLS 713) 11517519 БОЛТ, ENG OIL LVL SEN (ЧАСТЬ OF 400) (M6X1X25, 22 THD, 14.2) (8.900) 12573744 SHIELD, ENG OIL PRESS GA SEN HT (ЧАСТЬ OF 440) 11519964 БОЛТ, HFH, M6X1X13, 6 THD, 14.2 OD, 8.8, GMW3359, MAT POINT (ЧАСТЬ OF 440) 12567911 SENSOR, ENG OIL PRESS (ЧАСТЬ OF 440) (INCLS 729) (ACDelco #213-1547) [ДАТЧИК ДАВЛЕНИЯ МАСЛА] (6Y00-003) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 2 ГОЛОВКА ЦИЛИНДРОВ & ДЕТАЛИ КОМПЛЕКТА (LH2/4.6A) ↓ 03522352 PIN, CYL HD LOC (HOLLOW DOWEL, 15.675X28, CHAM BOTH ENDS, SAE 12L14, ZP) 12564273 CHAIN, SECD TMG 12559389 SHOE KIT, TMG CHAIN TENSR (INCLS 174) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (ЧАСТЬ OF 173) (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 12559390 SHOE KIT, TMG CHAIN TENSR (INCLS 184) 12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (ЧАСТЬ OF 183) (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH) 12576969 VALVE, CM/SHF POSN ACTR SOL 12567414 ACTUATOR, CM/SHF POSN (EXH) 12567415 ACTUATOR, CM/SHF POSN (EXH) 12567416 ACTUATOR, CM/SHF POSN (INT) [ПРИВОДНОЙ МЕХАНИЗМ] 12567417 ACTUATOR, CM/SHF POSN (INT) [ПРИВОДНОЙ МЕХАНИЗМ] 12589229 COVER, CM/SHF (INCLS 251, 254-256, 261, 908, 909) 12591265 COVER, CM/SHF (INCLS 251, 254-256, 261, 908, 909) 12576394 GASKET, CM/SHF CVR (ЧАСТЬ OF 250) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ ЦИЛИНДРОВ] 12576395 GASKET, CM/SHF CVR (ЧАСТЬ OF 250) (BETWEEN HEAD AND CAM COVER) [ПРОКЛАДКА] 12576396 GASKET, CM/SHF CVR (ЧАСТЬ OF 250) (СВЕЧИ HOLES) [ПРОКЛАДКА] 12557829 БОЛТ, CM/SHF CVR (ЧАСТЬ OF 250) 12573742 INSULATOR, CM/SHF CVR БОЛТ (ЧАСТЬ OF 250) 12577268 CAP, OIL FIL (MOBIL 1, SAE 5W30, NON-VENTED, W/SEAL, W/TURNING EARS, NOT ROUND) (INCLS 259) (ACDelco #FC209) 24100002 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 258) (27.94MM I.D.) (SIZE #320) (1.745) [ПРОКЛАДКА] 12578248 HEAD, CYL (MCHG) (INCLS 312, 313, 315, 334-337) 12578249 HEAD, CYL (MCHG) (INCLS 312, 313, 315, 334-337) 11589058 БОЛТ, CYL HD (M11X2.0X161) [БОЛТ М11] 01647218 БОЛТ, CYL HD (QTY 3-RH, 3-LH) (M6X1.0X50, 10.9) (HFH, MACH) 11562126 PLUG, CYL HD CORE HOLE (ЧАСТЬ OF 300) (CUP, 32.03X7.88X1.27, S30400 SS PER SAE J405.) [ЗАГЛУШКА ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 01647543 PLUG, CYL HD CORE HOLE (ЧАСТЬ OF 300) (ROUND HEAD, INT HEX, W/ALUM WASH, 20X1.5X17, 12.25 THD, C1010 RQ) 11588949 PLUG, M16X1.5X14, 24 OD, SAE 1010 STL, GMW3044, W/ AL WASHER (ЧАСТЬ OF 300) [ПРОБКА ЗАМКА] 12574785 RESTRICTOR, ENG BLK OIL GAL 12578258 VALVE, EXH [КЛАПАН ВЫПУСКНОЙ] 12590223 VALVE, INT 12565203 ARM, VLV RKR [КОРОМЫСЛО КЛАПАНА ДВИГАТЕЛЯ] 24100005 ADJUSTER, HYD VLV LASH (ACDelco #24100005) [ТОЛКАТЕЛЬ КЛАПАНА ДВИГАТЕЛЯ] 12574354 SEAL, VLV STEM OIL [УПЛОТНЕНИЕ ШТОКА КЛАПАНА] 12565199 ПРУЖИНА, VLV 12580385 CAP, VLV SPR teamcadillac.ru 01647209 KEY, VLV STEM 12565171 CAMSHAFT, EXH (MCHG) (INCLS 338) 12565172 CAMSHAFT, EXH (MCHG) (INCLS 338) [РАСПРЕДВАЛ В СБОРЕ] 12563833 CAMSHAFT, INL (MCHG) (INCLS 338) [РАСПРЕДВАЛ] 12565168 CAMSHAFT, INL (MCHG) (INCLS 338) [КОЛЕНВАЛ] 01647553 БОЛТ, CM/SHF BRG CAP (ЧАСТЬ OF 300) (HFH, M6X1.0X39.5) 12596360 ШЛАНГИ, CM/SHF POSN ACTR (INCLS 342, 344, 345, 735-737) 12596361 ШЛАНГИ, CM/SHF POSN ACTR (INCLS 342, 344, 345, 735-737) 12567656 GASKET, CM/SHF POSN ACTR HSG (ЧАСТЬ OF 340) (0.423) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12567657 GASKET, CM/SHF POSN ACTR HSG (ЧАСТЬ OF 340) (0.423) [УПЛОТНЕНИЕ ДВИГАТЕЛЯ] 11518706 STUD-HFH, M6X1X13.4, M6X1X40, 14.2 OD, 60 TL, 10.9, GM6280M (NON HEX CHROME) (ЧАСТЬ OF 340) (8.981) 11518707 STUD, HFH, M6X1X13 / M6X1X45, 14.2 O.D., 65 TL, 9.8, GM6280M (CM/SHF POSN ACTR HSG) 11562490 STUD, STRAIGHT, M8X1.25X20, M8X1.25X40, 69 TL, 9.8, GMW3179, EXT HEX SOCKET (EXH MANIF) [ШПИЛЬКА М8] 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ) 15326386 SENSOR, ENG COOL TEMP (2-WAY MALE) (3.682) (ACDelco #213-928) [ДАТЧИК ТЕМПЕРАТУРЫ ДВИГАТЕЛЯ] 12571533 СВЕЧИ, (ACDelco #41-986) (PLATINUM PLUG) [СВЕЧА ЗАЖИГАНИЯ] 12569160 SENSOR, CM/SHF POSN (INCLS 726) (ACDelco #213-1512) [ДАТЧИК ПОЛОЖЕНИЯ РАСПРЕДВАЛА] 01647346 БОЛТ, HFH, M6X1X17, 17THD, 14.2 O.D., 8.8, ZF (CM/SHF POSN SEN) 12567085 MAGNET, CM/SHF POSN ACTR (INCLS 737) (ЧАСТЬ OF 340) [МАГНИТ] 11518845 SCREW PAN HD, M6X1X16, 15 THD, 12 OD, 8.8, 6280M, TORX, T30, HDR PT, W/SEALANT (ЧАСТЬ OF 340) 12567421 PLUG, CM/SHF POSN ACTR BORE (ЧАСТЬ OF 340, 735) 12581176 HARNESS, ELEK ICM WRG (INCLS 772) 11519976 БОЛТ, HFLGE, M8X1.25X20, 15.6 THD, 18 O.D., 8.8, GMW3359 (ELEK ICM WRG HARN CLIP) 11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (ЧАСТЬ OF 770) [БОЛТ М8] 11517094 SCREW, M5X.8X15.6, 10.4 THD, 10.2 OD, 6202M, 7114M, TAPER-POINT (ЧАСТЬ OF 250) (ACDelco #11517094) 89017450 GASKET KIT, CYL HD (INCLS 302, 310) (INCL GASKET AND M11X2.0 БОЛТS) [ПРОКЛАДКА ДВИГАТЕЛЯ] 89017451 GASKET KIT, CYL HD (INCLS 302, 310) (INCL GASKET AND M11X2.0 БОЛТS) [ПРОКЛАДКА ДВИГАТЕЛЯ] (GM00-387) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 1 БЛОК ЦИЛИНДРОВ И ВНУТРЕННИЕ ДЕТАЛИ (LY7/3.6-7) ↓ 12560272 БОЛТ, CR/SHF BRG CAP (M10X2X102.5, 24.5) [ВИНТ] 11518861 БОЛТ, HFH, W/REDCD BODY, M8X1.25X90, 26 THD, 18 O.D., 10.9, GM4277M (CR/SHF BRG CAP) [БОЛТ] 11609410 БОЛТ, HFH, M8X1.25X25, 10.9, GMW3179 (CR/SHF BRG CAP) (0.056) [БОЛТ] 89021297 ADHESIVE/SEALANT, THREADLOCKER HI STRENGTH 10ML ERI (CR/SHF BRG CAP) [АДГЕЗИВ] 11589000 БОЛТ, HFH, M8X1.25X50, 24 THD, 18 OD, 10.9, GMW3359, RED BODY, W/ADH (CR/SHF BRG CAP) 12557520 PLUG, ENG BLK OIL GAL (CUP-.390IN OD, .040IN THK, STEEL) 12621351 CRANKSHAFT, (USE T/W 12601937, 12603180) [КОЛЕНВАЛ] 12585420 PIN, CR/SHF SPKT LOC 11561583 PLUG, ENG BLK OIL GAL (M14X1.5X16, 22 OD) (0.253) 12566587 PLUG, ENG BLK OIL GAL 11561751 PLUG, CYL HD WAT JKT HOLE (M20X1.5X30.5) (1.531) 00360571 PLUG, ENG BLK CORE HOLE (CUP DIA 34.3MM) 12597210 PIN, TRANS LOC 24229149 PIN, TRANS LOC 12620955 SEAL, CR/SHF RR OIL (INCLS 134) [ПРОКЛАДКА КОЛЕНВАЛА ДВИГАТЕЛЯ] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 133) 22531637 PIN, МАСЛЯНЫЙ ПОДДОН LOC (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 12570326 PIN, CYL HD LOC [ЗАГЛУШКА БЛОКА ЦИЛИНДРОВ] 12572042 PLATE, A/TRNS FLEX 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12608432 ROD, CONN (INCLS 201, 202) 11519680 БОЛТ, CONN ROD (ЧАСТЬ OF 200) (M9X1X53) [БОЛТ] teamcadillac.ru 12598657 BEARING KIT, CONN ROD (UPPER) [ПОДШИПНИК СКОЛЬЖЕНИЯ ШАТУНА] 12585675 PISTON, (W/PIN) (INCLS 211, 212) (.25 O.S.) 12590866 PISTON, (W/PIN) (INCLS 211, 212) (STD) 12566186 RETAINER, PSTN PIN (ЧАСТЬ OF 210) 12597654 BALANCER, CR/SHF (DUAL BELT, W/O KEYWAY) 11569873 БОЛТ, CR/SHF BALR (M14X1.5X48.4) 12582652 SENSOR, CR/SHF POSN (INCLS 721, 722) (ACDelco #213-1632) [ДАТЧИК] 11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (ЧАСТЬ OF 720) [БОЛТ] 12618603 SENSOR, KNOCK (W/O LEADS) (INCLS 724) (ACDelco #213-4335) [ДАТЧИК] 11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 723) 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (EXH MANIF H/SHLD) [БОЛТ] 12610603 BEARING KIT, CR/SHF (#1, 2, 4 STD) (INCLS 122, 123) [ПОДШИПНИК СКОЛЬЖЕНИЯ КОЛЕНВАЛА] 12610604 BEARING KIT, CR/SHF (#3 STD) (INCLS 123, 124) [КОМПЛЕКТ ПОДШИПНИКОВ СКОЛЬЖЕНИЯ КОЛЕНВАЛА (3ШТ)] 12608615 RING KIT, PSTN (INCLS 213-216) (STD) (GM00-389) - 2004-2006 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 3 ПЕРЕДНЯЯ КРЫШКА И ОХЛАЖДЕНИЕ (LY7/3.6-7) ↓ 22531637 PIN, ENG FRT CVR LOC (ЧАСТЬ OF 350) (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ] 11519176 БОЛТ, ENG FRT CVR (ЧАСТЬ OF 350) (M8X1.25X80) (4.081) [БОЛТ] 12598349 COVER, ENG FRT (W/ W/PMP) (INCLS 132, 348, 351-353, 360-362, 725-727, 734, 900-903) 12593045 SEAL, W/PMP (ЧАСТЬ OF 350) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519171 БОЛТ, ENG FRT CVR (ЧАСТЬ OF 350) (M8X1.25X50) (3.275) [БОЛТ ВЫПУСКНОГО КОЛЛЕКТОРА] 12608750 SEAL, CR/SHF FRT OIL (ЧАСТЬ OF 350) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КОЛЕНВАЛА] 12618472 PUMP, WAT (W/GSKT) (ЧАСТЬ OF 350) (INCLS 900) (ACDelco #251-724) [НАСОС] 11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 350) 12576326 GASKET, W/PMP (ЧАСТЬ OF 350) (ACDelco #251-2048) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12574518 PULLEY, W/PMP (ADX) 11519512 БОЛТ, HFH, W/CON SPR WA, M6X1X13.4, 8.77 THD, 12.3 O.D., 8.8, GMW3359 (W/PMP PUL) 12582472 SEAL, ENG COOL THERM (ЧАСТЬ OF 367) (ACDelco #12582472) [УПЛОТНИТЕЛЬ] 12620259 ШЛАНГИ, ENG COOL THERM (INCLS 365, 366, 369, 371, 372) (INCLS THERMOSTAT) (ACDelco #15-81651) [КОРПУС В СБОРЕ, ТЕРМОСТАТА СИСТЕМЫ ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ] 11519973 БОЛТ-HFH, M6X1X60, 18MM THD, 14.2 OD, 8.8, 3359GMW, REDUCED BODY, MAT PT. (ENG COOL THERM HSG) [БОЛТ 6Х1Х60] 11519974 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3359 (ENG COOL THERM HSG) [БОЛТ] 12584325 SEAL, ENG COOL THERM HSG (O RING) (ЧАСТЬ OF 367) [КОЛЬЦЕ-ОБРАЗНОЕ УПЛОТНЕНИЕ] teamcadillac.ru 12592527 GASKET, ENG COOL THERM HSG (ЧАСТЬ OF 367) (ACDelco #12592527) [ПРОКЛАДКА ТЕРМОСТАТА] 12566429 SEAL, WAT OTLT [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 12584040 SEAL, CLNT OTLT (O RING) (ACDelco #15-32584) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ] 11519974 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3359 (WAT OTLT) [БОЛТ] 12573984 OUTLET, WAT (INCLS 905) (INCLS БОЛТS, RETAINERS, SEALS & PIPE) (ACDelco #15-10429) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 12592250 SENSOR, CM/SHF POSN (ЧАСТЬ OF 350) (INCLS 726, 727) (ACDelco #213-1565) 11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (ЧАСТЬ OF 350, 725) [БОЛТ] 12615613 VALVE, CM/SHF POSN ACTR SOL 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (CM/SHF POSN ACTR SOL VLV) 12593717 SEAL, CM/SHF POSN ACTR SOL VLV (O RING) (ЧАСТЬ OF 350) (GM00-393) - 2005-2006 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 2 ГОЛОВКА ЦИЛИНДРОВ & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7) ↓ 12570326 PIN, CYL HD LOC [ЗАГЛУШКА БЛОКА ЦИЛИНДРОВ] 12590921 SPROCKET, CR/SHF [ЦЕПНАЯ ЗВЕЗДОЧКА] 12609262 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (INCLS 153, 164) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 152) [БОЛТ М8] 12590920 CHAIN, CM/SHF INTER DRV (PRIMARY) 12597417 GUIDE, TMG CHAIN (INCLS 157) (UPPER PRIMARY) 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 156) [БОЛТ М8] 11588252 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3179 CODE G (ЧАСТЬ OF 165, 166) teamcadillac.ru 12589477 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 152) (PRIMARY) 12597413 SPROCKET, CM/SHF (INCLS 161) (IDLER) 12597414 SPROCKET, CM/SHF (INCLS 161) (IDLER) 12589011 CHAIN, CM/SHF INTER DRV (92 PITCH) (SECONDARY) 12597416 GUIDE, TMG CHAIN (INCLS 172) (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 171) [БОЛТ М8] 12586960 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАТЯЖИТЕЛЬ ЦЕПИ] 11518858 БОЛТ, HFH, M8X1.25X43, 16 THD, 18 O.D., 8.8, GMW3179 (TMG CHAIN TENSR) [БОЛТ М8] 12609260 РОЛИК НАТЯЖИТЕЛЬ, TMG CHAIN (INCLS 176, 177) (SECONDARY) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 175) [БОЛТ М8] 12589478 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 175) 12597418 GUIDE, TMG CHAIN (INCLS 182) (2 КРЕПЛЕНИЕ HOLES) (SECONDARY) 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 181) [БОЛТ М8] 12586961 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАПРАВЛЯЮЩАЯ ПРИВОДНОЙ ЦЕПИ] 11518858 БОЛТ, HFH, M8X1.25X43, 16 THD, 18 O.D., 8.8, GMW3179 (TMG CHAIN TENSR) [БОЛТ М8] 12609258 РОЛИК НАТЯЖИТЕЛЬ, TMG CHAIN (INCLS 186, 187) (SECONDARY) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] 11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 185) [БОЛТ М8] 12589479 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 185) 12588272 ACTUATOR, CM/SHF POSN (EXHAUST) 12588273 ACTUATOR, CM/SHF POSN (INTAKE) 11588279 БОЛТ, HFH, M10X1.5X80, 26 THD, 22.3 O.D., 10.9, GM4277M (CM/SHF POSN ACTR) 12604078 COVER, CM/SHF (INCLS 251, 254-257, 260, 263) 12591200 SEAL, CM/SHF CVR (ЧАСТЬ OF 250) (*KIT1) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 12591201 COVER, CM/SHF (INCLS 253-257, 261) 12591203 SEAL, CM/SHF CVR (ЧАСТЬ OF 252) (*KIT1) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ] 11518859 БОЛТ, HFH W/SHLDR, M6X1X35, 11.85 THD, 18 O.D., 8.8, GMW3359 (ЧАСТЬ OF 250, 252) 12566250 INSULATOR, CM/SHF CVR БОЛТ (ЧАСТЬ OF 250, 252) 12583570 CAP, OIL FIL (ROUND W/HDL) (INCLS 904) (NON VENTED) (ACDelco #FC215) 24100002 SEAL, OIL FIL TUBE (O RING) (ЧАСТЬ OF 262) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА] 12578316 FITTING, PCV (ЧАСТЬ OF 250) (INCLS 263) 12583384 FITTING, PCV (ЧАСТЬ OF 252) 12597946 TUBE, OIL FIL (INCLS 259) [ТРУБКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ ГОЛОВКИ БЛОКА] 12580962 HEAD, CYL (MCHG) (INCLS 313, 318, 319, 328, 336, 337) (TO BE USED WITH 2 ДВИГАТЕЛЬ OIL MANIF CHECK VALVE ASSEMBLIES) [ГОЛОВКА БЛОКА ЦИЛИНДРОВ] 12603901 HEAD, CYL (MCHG) (INCLS 313, 318, 319, 328, 336, 337) (DOES NOT INCL ENG OIL MANIF CHECK VALVES. DLR MUST INSTL) 11518863 БОЛТ, CYL HD [БОЛТ] 11519177 БОЛТ-HEX FLANGE HD, REDUCED BODY, M8X1.25X90, 8.8, GMW3359 (CYL HD) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12565988 PLUG - M20X1.5X30.5, 8.8, GMW3044, SEALANT PER GM9985490 (ЧАСТЬ OF 300, 301) 11562127 PLUG, CYL HD OIL GAL (ЧАСТЬ OF 300, 301) (CUP-14.22 OD, 6.6 THK, 304SS) 12575354 VALVE, EXH (STD) [КЛАПАН ВЫПУСКНОЙ] 12584760 VALVE, EXH (0.075 O.S.) [КЛАПАН ВЫПУСКНОЙ] 12575351 VALVE, INT (STD) [КЛАПАН ВПУСКНОЙ] 12584763 VALVE, INT (0.075MM O.S.) (0.297) [КЛАПАН ВПУСКНОЙ] 24100294 ARM, VLV RKR [РЫЧАГ] 24100005 ADJUSTER, HYD VLV LASH (ACDelco #24100005) [ТОЛКАТЕЛЬ КЛАПАНА ДВИГАТЕЛЯ] 12565836 SEAL, VLV STEM OIL [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КЛАПАНА ДВИГАТЕЛЯ] 12575355 ПРУЖИНА, VLV [ПРУЖИНА КЛАПАНА] 12575196 RETAINER, VLV SPR [КОМПАКТ ДИСК] 12575197 KEY, VLV STEM [КЛАПАННЫЙ КЛЮЧ] 12574477 RING, CM/SHF SPKT OIL SEAL (ЧАСТЬ OF 330-333) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО РАСПРЕДВАЛА ДВИГАТЕЛЯ (2 ШТ.)] 12566670 CAMSHAFT, EXH (INCLS 329) 12566669 CAMSHAFT, INT (INCLS 329) 12566672 CAMSHAFT, EXH (INCLS 329) 12566671 CAMSHAFT, INT (INCLS 329) 11518856 HFH, M6X1X43.4, 14.8 THD, 11 O.D., 8.8, GMW3179 CODE G (ЧАСТЬ OF 300, 301) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 12580965 VALVE, ENG OIL MANIF CHK [КЛАПАН] 12613057 РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ, IGN (INCLS 705) (ACDelco #12613057) 12566778 SENSOR, ENG COOL TEMP (3.682) (ACDelco #213-1581) [СЕНСОР ТЕМПЕРАТУРЫ] 12597464 СВЕЧИ, (DO NOT CHANGE СВЕЧИ GAP) (ACDelco #41-990) (PLATINUM PLUG) [СВЕЧА ЗАЖИГАНИЯ] 24100002 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 258) (27.94MM I.D.) (SIZE #320) (1.745) [ПРОКЛАДКА] 12625785 GASKET KIT, CYL HD (INCLS 251, 253, 302, 303) [КОМПЛЕКТ ПРОКЛАДОК ГОЛОВКИ БЛОКА ЦИЛИНДРОВ (РЕЗ-7, МЕТ-8, ПАР-2)] 01 - СИСТЕМА ОХЛАЖДЕНИЯ - РЕШЕТКА РАДИАТОРА-МАСЛОСИСТЕМА ↓ (6D01-034) - 2004-2009 E ПОДОГРЕВАТЕЛЬ БЛОКА ДВИГАТЕЛЯ (LY7/3.6-7, 110V ПОДОГРЕВАТЕЛЬ K05) ↓ teamcadillac.ru 15257983 CORD, ENG COOL HTR (INCLS 2) 12337820 STRAP, 15" TIE STRAP (ЧАСТЬ OF 1) (ACDelco #12337820) 12587380 ПОДОГРЕВАТЕЛЬ, ENG COOL (USE W/2 PIN ПОДОГРЕВАТЕЛЬ) [НАГРЕВАТЕЛЬ] (6D01-044) - 2004-2009 E РАДИАТОР ASM ↓ 19129971 РАДИАТОР, (INCLS 2) (ACDelco #21659) [РАДИАТОР] 19129973 РАДИАТОР, (W/TRAILER PROVISIONS) (INCLS 2) (ACDelco #21662) 88957419 РАДИАТОР, (INCLS 2) (ACDelco #21508) (6E01-014) - 2004-2005 E РЕШЕТКА РАДИАТОРА ↓ 15284129 MOLDING, КАПОТ FRT (INCLS 2) 11519026 CLIP-U, 13X15X12, 1.5 PNL, 1050, 6280M (ЧАСТЬ OF 1) [ФИКСАТОР МОЛДИНГА КАПОТА] 25735038 BUMPER, КАПОТ STOP (ЧАСТЬ OF 6) (ATTACHED TO РАДИАТОР GRILLE) [ВТУЛКА БАМПЕРА] 21030249 RETAINER, EXPAN, 21 LG, 20. OD, 8.0 HOLE, 3.0-5.0 PNL, NYLON 6/6, BLK (ЧАСТЬ OF 6) (8.950) (PUSH IN) [ПИСТОН КРЕПЛЕНИЯ КОЖУХА РАДИАТОРА(ПЛАСТИК)] teamcadillac.ru 25763160 GRILLE, RAD (INCLS 4, 5, 7-9) [РЕШЕТКА РАДИАТОРА] 25765149 EMBLEM, RAD GRL (ЧАСТЬ OF 6) (CHROME) ("CREST") [ЭМБЛЕМА] 25765150 EMBLEM, RAD GRL (ЧАСТЬ OF 6) ("WREATH") [ЭМБЛЕМА] 21030249 RETAINER, EXPAN, 21 LG, 20. OD, 8.0 HOLE, 3.0-5.0 PNL, NYLON 6/6, BLK (ЧАСТЬ OF 6) (8.950) (PUSH IN) [ПИСТОН КРЕПЛЕНИЯ КОЖУХА РАДИАТОРА(ПЛАСТИК)] (6E01-015) - 2004-2009 E НАТЯЖИТЕЛЬ РЕМНЯ/ACCESSORY DRIVE (LH2/4.6A) ↓ 12593189 BELT, W/PMP & КОНДИЦИОНЕР CMPR & P/S PUMP [РЕМЕНЬ ДВИГАТЕЛЯ] 12578062 BELT, GEN (CODE WCN) [РЕМЕНЬ] 11518636 БОЛТ, HFH, M10X1.5X90, 25.9 THD, 22.3 OD, 10.9, GMW3359, 7.5 MAT-PT (ЧАСТЬ OF 4) [БОЛТ М10] 12568172 РОЛИК НАТЯЖИТЕЛЬ, DRV BELT (INCLS 3) (SMOOTH PULLEY) (USE T/W БОЛТ PN 11518636) [ШКИВ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ] teamcadillac.ru 11518636 БОЛТ, HFH, M10X1.5X90, 25.9 THD, 22.3 OD, 10.9, GMW3359, 7.5 MAT-PT (ЧАСТЬ OF 6) [БОЛТ М10] 12598023 РОЛИК НАТЯЖИТЕЛЬ, DRV BELT (INCLS 5) (RIBBED PULLEY) [МЕХАНИЗМ НАТЯЖЕНИЯ] 12604688 PULLEY, BELT IDLER (INCLS 7) (ACDelco #15-40051) (6E01-016) - 2004-2006 E ШЛАНГИ И ТРУБКИ/РАДИАТОР (LH2/4.6A, EXC V92) ↓ 88956903 HOSE, RAD SURGE TK INL (INCLS 2) [ТРУБКА] 11570614 CЛАМПА-ПРУЖИНАBAND, 15 NOMINAL DIA, 15 THK, STL, ROBO (ЧАСТЬ OF 1) 11514517 ГАЙКА, HEX, W/CON SPR WA, M6X1, 5.7THK, 18 O.D., 9, 7111M (RAD SURGE TK) [ГАЙКА М6] 15075118 CAP, RAD SURGE TK (ЧАСТЬ OF 7) (15 PSI DUAL O-RING) (ENGLISH/FRENCH LABEL) (ACDelco #RC98) [КРЫШКА БАЧКА РАДИАТОРА] 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (RAD SURGE TK) (ACDelco #11517518) [БОЛТ] 25757865 HOSE, RAD SURGE TK OVFL (ЧАСТЬ OF 7) 25767641 TANK, RAD SURGE (INCLS 4, 6) (INCLS LOW COOLANT SWITCH) (ACDelco #25767641) [БАЧОК В СБОРЕ] 89023438 HOSE, RAD INL (INCLS 9) [ШЛАНГ] 11516233 CЛАМПА-ПРУЖИНАBAND, TYPE A, 15 WID, 40 HOSE OD, 6150M, 7111M, MM (ЧАСТЬ OF 8) [ХОМУТ ШЛАНГА РАДИАТОРА] 25752529 BRACKET, RAD OTLT HOSE 11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (RAD OTLT HOSE BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16] 11516233 CЛАМПА-ПРУЖИНАBAND, TYPE A, 15 WID, 40 HOSE OD, 6150M, 7111M, MM (ЧАСТЬ OF 13) [ХОМУТ ШЛАНГА РАДИАТОРА] 89023433 HOSE, RAD OTLT (INCLS 12) teamcadillac.ru 88956890 HOSE, RAD SURGE TK OTLT (INCLS 15) (8.846) 11518516 CЛАМПА, RAD SURGE TK ENG HOSE (ЧАСТЬ OF 14) (27MM) (BLACK & YELLOW T-CLIP) [ЗАЖИМ] 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (RAD SURGE TK OTLT HOSE CLIP BRKT) (6E01-017) - 2004-2006 E ШЛАНГИ И ТРУБКИ/РАДИАТОР (LH2/4.6A, V92) ↓ 88956903 HOSE, RAD SURGE TK INL (INCLS 2) [ТРУБКА] 11570614 CЛАМПА-ПРУЖИНАBAND, 15 NOMINAL DIA, 15 THK, STL, ROBO (ЧАСТЬ OF 1) 11514517 ГАЙКА, HEX, W/CON SPR WA, M6X1, 5.7THK, 18 O.D., 9, 7111M (RAD SURGE TK) [ГАЙКА М6] 15075118 CAP, RAD SURGE TK (ЧАСТЬ OF 7) (15 PSI DUAL O-RING) (ENGLISH/FRENCH LABEL) (ACDelco #RC98) [КРЫШКА БАЧКА РАДИАТОРА] teamcadillac.ru 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (RAD SURGE TK) (ACDelco #11517518) [БОЛТ] 25757865 HOSE, RAD SURGE TK OVFL (ЧАСТЬ OF 7) 25767641 TANK, RAD SURGE (INCLS 4, 6) (INCLS LOW COOLANT SWITCH) (ACDelco #25767641) [БАЧОК В СБОРЕ] 89023434 HOSE, RAD INL (INCLS 9) [ТРУБКА] 11516233 CЛАМПА-ПРУЖИНАBAND, TYPE A, 15 WID, 40 HOSE OD, 6150M, 7111M, MM (ЧАСТЬ OF 8) [ХОМУТ ШЛАНГА РАДИАТОРА] 15261734 BRACKET, RAD OTLT HOSE 11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (RAD OTLT HOSE BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16] 11516233 CЛАМПА-ПРУЖИНАBAND, TYPE A, 15 WID, 40 HOSE OD, 6150M, 7111M, MM (ЧАСТЬ OF 13) [ХОМУТ ШЛАНГА РАДИАТОРА] 89023436 HOSE, RAD OTLT (INCLS 12, 23) 11517136 CЛАМПА, HOSE SPR, 27 NOM, 25.2 MIN-28.9 MAX, 15MM WIDE, BLACK (ЧАСТЬ OF 20) 25746579 PUMP, AUX WAT (INCLS 16-18) (ACDelco #251-683) 88958083 HOSE, AUX W/PMP OTLT (ЧАСТЬ OF 15) (INCLS 18) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (AUX W/PMP) 88956890 HOSE, RAD SURGE TK OTLT (INCLS 14) (8.846) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (RAD SURGE TK OTLT HOSE CLIP BRKT) 11570614 CЛАМПА-ПРУЖИНАBAND, 15 NOMINAL DIA, 15 THK, STL, ROBO (ЧАСТЬ OF 13) (6E01-018) - 2004-2006 E ВЕНТИЛЯТОР ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ-ELECTRIC PUSHER(V92) ↓ 89022529 BLADE, FAN (INCLS 2) (ACDelco #15-80710) [КРЫЛЬЧАТКА ВЕНТИЛЯТОРА] 89022527 SHROUD, ENG COOL FAN (INCLS 4) (ELECTRIC PUSH) [ОБТЕКАТЕЛЬ РАДИАТОРА] 89022526 MOTOR, ENG COOL FAN (ELECTRIC PUSH) (ACDelco #15-80542) [ЭЛЕКТРОДВИГАТЕЛЬ ВЕНТИЛЯТОРА 90 ВТ] 89022525 MOTOR, ENG COOL FAN (ELECTRIC PUSH) (ACDelco #15-80541) [ЭЛЕКТРОДВИГАТЕЛЬ ВЕНТИЛЯТОРА 90 ВТ] 89022544 БОЛТ KIT, ENG COOL FAN MOT [КОМПЛЕКТ БОЛТОВ ОБЛИЦОВКИ РАДИАТОРА (2 ШТ)] 89022528 BLADE, FAN (INCLS 2) (ACDelco #15-80709) [КРЫЛЬЧАТКА ВЕНТИЛЯТОРА] (6E01-022) - 2004-2008 E РАДИАТОР КРЕПЛЕНИЕ & ДЕТАЛИ КОМПЛЕКТА ↓ 25718629 BRACKET, RAD UPR (INCLS 3) 25729351 BRACKET, RAD UPR (INCLS 3) 11517484 БОЛТ-HEX, M6X1X20, 9 THD, 17 OD, 9.8, 6280M, MACH, P-PT (RAD UPR MT BRKT) 11519444 PUSH-PIN, 10.0 HEADX26.0, 10.0 HOLE, PNL THK 6.2-8.71, NY 6.6 (RAD AIR LWR BFL (PUSH IN)) [ФИКСАТОР ПОДКРЫЛКА] 25802220 DEFLECTOR, FRT AIR (INCLS 18) [ОБТЕКАТЕЛЬ РАДИАТОРА] teamcadillac.ru 11570323 БОЛТ, ENG COOL FAN SHRD (M6X1X18, 13 THD) 19130179 SHROUD, ENG COOL FAN (MECHANICAL PULL) [КОЖУХ ВЕНТИЛЯТОРА РАДИАТОРА] 89022523 SHROUD, ENG COOL FAN (MECHANICAL PULL) [ОБТЕКАТЕЛЬ РАДИАТОРА] 89023441 SEAL, RAD LH SI (INCLS 8) [ОПОРА РАДИАТОРА] 15932850 INSULATOR, RAD LWR [ДЕМПФЕР РАДИАТОРА] 11561026 БОЛТ-HFH, M6X1X25, 22 THD, 14.2 OD, 9.8, GMW3200, MACH, HDR-PT (КОНДИЦИОНЕР CNDSR) 19130354 CONDENSER, КОНДИЦИОНЕР (ACDelco #15-63540) 19130355 CONDENSER, КОНДИЦИОНЕР (ACDelco #15-63541) 25994576 BAR, FRT BPR IMP (СМ. ГРУППУ 07.000 "БАМПЕР ПЕРЕДНИЙ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [БАЛКА ПАНЕЛИ БАМПЕРА] 89023440 SEAL, RAD AIR SI (INCLS 8) 88957418 SEAL, RAD UPR 15932856 SHROUD, ENG COOL FAN (СМ. ГРУППУ 01.000 "ВЕНТИЛЯТОР ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ОБТЕКАТЕЛЬ РАДИАТОРА] 15248340 SEAL, RAD AIR LWR (ЧАСТЬ OF 5) (6E01-023) - 2004-2009 E НАТЯЖИТЕЛЬ РЕМНЯ/ACCESSORY DRIVE (LY7/3.6-7) ↓ 12577655 РОЛИК НАТЯЖИТЕЛЬ, КОНДИЦИОНЕР CMPR & P/S PMP BELT (9.180) [НАТЯЖИТЕЛЬ РЕМНЯ] 11518633 БОЛТ, HFH, M10X1.5X75, 26 THD, 22.3 OD, 10.9, GMW3359, MAT- POINT. (DRV BELT TENSR) [БОЛТ М10] 12578000 BELT, КОНДИЦИОНЕР CMPR & P/S PUMP [НАСОС] teamcadillac.ru 12621991 BELT, W/PMP & GEN [РЕМЕНЬ ГЕНЕРАТОРА L=120 СМ] 12577652 РОЛИК НАТЯЖИТЕЛЬ, W/PMP & GEN BELT [НАТЯЖИТЕЛЬ РЕМНЯ] (6E01-024) - 2004-2009 E ПОДОГРЕВАТЕЛЬ БЛОКА ДВИГАТЕЛЯ (LH2/4.6A, 110V ПОДОГРЕВАТЕЛЬ K05) ↓ 15269262 CORD, ENG COOL HTR (TEMRO DIV) 12587380 ПОДОГРЕВАТЕЛЬ, ENG COOL (USE W/2 PIN ПОДОГРЕВАТЕЛЬ) [НАГРЕВАТЕЛЬ] (6E01-025) - 2004-2009 E ПОДОГРЕВАТЕЛЬ БЛОКА ДВИГАТЕЛЯ (LH2/4.6A, 220V ПОДОГРЕВАТЕЛЬ KA3) ↓ 25772264 CORD, ENG COOL HTR 12587379 ПОДОГРЕВАТЕЛЬ, ENG COOL (6E01-026) - 2004-2006 E ШЛАНГИ И ТРУБКИ/РАДИАТОР (LY7/3.6-7) ↓ 88956900 HOSE, RAD SURGE TK OTLT (INCLS 2) 11517136 CЛАМПА, HOSE SPR, 27 NOM, 25.2 MIN-28.9 MAX, 15MM WIDE, BLACK (ЧАСТЬ OF 1) 11518624 БОЛТ, HFH, M10X1.5X30.4, 22.5 THD, 22.3 O.D., 10.9, GMW3359 (RAD SURGE TK ENG PIPE CLIP) 25757865 HOSE, RAD SURGE TK OVFL (ЧАСТЬ OF 6) 15075118 CAP, RAD SURGE TK (ЧАСТЬ OF 6) (15 PSI DUAL O-RING) (ENGLISH/FRENCH LABEL) (ACDelco #RC98) [КРЫШКА БАЧКА РАДИАТОРА] 25767641 TANK, RAD SURGE (INCLS 4, 5) (INCLS LOW COOLANT SWITCH) (ACDelco #25767641) [БАЧОК В СБОРЕ] 11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (RAD SURGE TK) [БОЛТ М6] 11514517 ГАЙКА, HEX, W/CON SPR WA, M6X1, 5.7THK, 18 O.D., 9, 7111M (RAD SURGE TK) [ГАЙКА М6] 11570614 CЛАМПА-ПРУЖИНАBAND, 15 NOMINAL DIA, 15 THK, STL, ROBO (ЧАСТЬ OF 10) 88958088 HOSE, RAD SURGE TK INL (INCLS 9) 11516233 CЛАМПА-ПРУЖИНАBAND, TYPE A, 15 WID, 40 HOSE OD, 6150M, 7111M, MM (ЧАСТЬ OF 12) [ХОМУТ ШЛАНГА РАДИАТОРА] 89023435 HOSE, RAD INL (INCLS 11) teamcadillac.ru 11516233 CЛАМПА-ПРУЖИНАBAND, TYPE A, 15 WID, 40 HOSE OD, 6150M, 7111M, MM (ЧАСТЬ OF 14) [ХОМУТ ШЛАНГА РАДИАТОРА] 89023445 HOSE, RAD OTLT (INCLS 13) 12603912 PIPE, RAD OTLT (INCLS 16) (WHEN USED IN PLACE OF 12587536 USE T/W РАДИАТОР OUTLET HOSE 19129967) 12623519 SEAL, RAD OTLT PIPE (O RING) (ЧАСТЬ OF 15) 11519977 БОЛТ- HFH, M8X1.25X25, 16 THD, 18 OD, 8.8, GMW3359, MAT-PT. (RAD OTLT PIPE) 11518624 БОЛТ, HFH, M10X1.5X30.4, 22.5 THD, 22.3 O.D., 10.9, GMW3359 (RAD OTLT PIPE) 25740076 BRACKET, RAD OTLT HOSE 11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (RAD OTLT HOSE BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16] (6E01-027) - 2004-2006 E ВЕНТИЛЯТОР ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ (EXC (V92)) ↓ 25767914 FAN, ENG COOL (7 BLADE FAN FOR 160W MOTOR) (ACDelco #15-80192) teamcadillac.ru 15932856 SHROUD, ENG COOL FAN (INCLS 4) [ОБТЕКАТЕЛЬ РАДИАТОРА] 88957423 MOTOR, ENG COOL FAN (INCLS 2, 8) (160W) (ACDelco #15-80516) [ЭЛЕКТРОДВИГАТЕЛЬ ВЕНТИЛЯТОРА 90 ВТ] 88957422 MOTOR, ENG COOL FAN (INCLS 2, 8) (160W) (ACDelco #15-80515) [ЭЛЕКТРОДВИГАТЕЛЬ ВЕНТИЛЯТОРА 90 ВТ] 25767915 FAN, ENG COOL (5 BLADES FOR 160W MOT) (ACDelco #15-80193) (6M01-035) - 2004-2009 E ВЕНТИЛЯТОР ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ-ДВИГАТЕЛЬ MOUNTED (LH2/4.6A, V92) ↓ 11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (ENG COOL FAN BRKT) 12597700 BRACKET, ENG COOL FAN (INCLS 7) 11516869 БОЛТ, HEX W/CON WA, M10X1.5X18, 13THD, 20 O.D., 9.8, GM6174M (FAN BLADE) (*KIT1) 12589532 STUD, AUX ENG CLG FAN BRKT 12586654 INSULATOR, ENG COOL FAN (ЧАСТЬ OF 2) 10382029 FAN, ENG COOL (INCLS 3-5) (1.050) (ACDelco #15-4972) [ЭЛЕКТРОМАГНИТНАЯ МУФТА ВЕНТИЛЯТОРА СИСТЕМЫ ОХЛАЖДЕНИЯ] (6M01-036) - 2004-2006 E ВЕНТИЛЯТОР ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ-ДВИГАТЕЛЬ MOUNTED (LY7/3.6-7, V92) ↓ teamcadillac.ru 11518628 БОЛТ, HVY HEX ACORN FLG HD, M10X1.5X50, GMW25M (10.9) STL, GMW3358 (AUX ENG COOL FAN BRKT) 12586654 BUSHING, ENG CLG FAN BLADE (*KIT1) (1.055) 12589532 STUD, AUX ENG CLG FAN BRKT 11516869 БОЛТ, HEX W/CON WA, M10X1.5X18, 13THD, 20 O.D., 9.8, GM6174M (FAN BLADE CLU) 10382026 FAN, ENG COOL (INCLS 8) (INCLS СЦЕПЛЕНИЕ) (ACDelco #15-80877) 11518633 БОЛТ, HFH, M10X1.5X75, 26 THD, 22.3 OD, 10.9, GMW3359, MAT- POINT. (AUX ENG COOL FAN BRKT) [БОЛТ М10] 12593813 ADAPTER, FAN BLADE CLU (INCLS 2-4) (1.055) (6M01-037) - 2005-2006 E ПОДОГРЕВАТЕЛЬ БЛОКА ДВИГАТЕЛЯ (LY7/3.6-7, 220V ПОДОГРЕВАТЕЛЬ KA3) ↓ 25772574 CORD, ENG COOL HTR [КАБЕЛЬ ПИТАНИЯ СИСТЕМЫ ПОДОГРЕВА ДВС] teamcadillac.ru 12588204 ПОДОГРЕВАТЕЛЬ, ENG COOL 02 - СТАРТЕР - ГЕНЕРАТОР - ЗАЖИГАНИЕ - ЭЛЕКТРИКА - ЛАМПЫ ↓ (6D02-025) - 2004-2009 E КРЕПЛЕНИЕ ГЕНЕРАТОРА (LY7/3.6-7) ↓ 12597648 BRACKET, GEN & DRV BELT TENSR (2.277) teamcadillac.ru 11518628 БОЛТ, HVY HEX ACORN FLG HD, M10X1.5X50, GMW25M (10.9) STL, GMW3358 (GEN BRKT) 11518636 БОЛТ, HFH, M10X1.5X90, 25.9 THD, 22.3 OD, 10.9, GMW3359, 7.5 MAT-PT (GEN BRKT) [БОЛТ М10] 11519176 БОЛТ, GEN BRKT (M8X1.25X80) (4.081) [БОЛТ] 25751146 GENERATOR, (ACDelco #25751146) [ГЕНЕРАТОР 150 А] 11518628 БОЛТ, HVY HEX ACORN FLG HD, M10X1.5X50, GMW25M (10.9) STL, GMW3358 (GEN) 11518633 БОЛТ, HFH, M10X1.5X75, 26 THD, 22.3 OD, 10.9, GMW3359, MAT- POINT. (GEN) [БОЛТ М10] (6D02-035) - 2004-2009 E РЕЛЕ/BODY COMPARTMENT ↓ 88956531 COVER, BODY & I/P WRG HARN J/BLK (UPPER COVER FOR THE RIGHT ЗАДНИЙ) 12077863 BREAKER, CIRCUIT, 30 AMP, GREEN (ЧАСТЬ OF 10) 15319477 FUSE, 30AMP, PINK, J-CASE, FEMALE, REGULAR (ЧАСТЬ OF 10) [ПРЕДОХРАНИТЕЛЬ 30А] 15319478 FUSE, 40AMP, GREEN, J-CASE, FEMALE (ЧАСТЬ OF 10) (ACDelco #15319478) [ПРЕДОХРАНИТЕЛЬ 40А] 12092079 FUSE, 10A, MINI, RED (ЧАСТЬ OF 10) 88909754 FUSE, 15A, MINI, BLUE (ЧАСТЬ OF 10) (ACDelco #ATM15-25) [ПРЕДОХРАНИТЕЛЬ 15 А] 88953222 RELAY, INTR LP (ЧАСТЬ OF 10) (GRAY) (20AMP) (4 TERMINAL) (LOW-PROFILE MICRO 280) (2.485) (ACDelco #D1755A) [РЕЛЕ] 19116060 PULLER, FUSE (ЧАСТЬ OF 10) 21997408 RELAY, ACSRY TIME DELAY CUTOFF (ЧАСТЬ OF 10) (5-TERMINAL) (SPDT, 280 MINI, HI/LOW, BLACK) (1.055) (ACDelco #15-81106) 88956532 COVER, BODY & I/P WRG HARN J/BLK (UPPER COVER FOR THE LEFT ЗАДНИЙ) 89046748 BLOCK, BODY WRG HARN JUNC (ЧАСТЬ OF 10) (75-WAY FEMALE) (W/O LEADS) (BELOW LH ЗАДНИЙ SEAT) teamcadillac.ru 89047326 COVER, PWR DISTR FUSE BLK (ЧАСТЬ OF 10) 89047327 COVER, PWR DISTR FUSE BLK (ЧАСТЬ OF 10) 89046747 BLOCK, BODY WRG HARN JUNC (ЧАСТЬ OF 10) (75-WAY FEMALE) (W/O LEADS) (BELOW RH ЗАДНИЙ SEAT) (6E02-022) - 2004-2009 E ФАРООМЫВАТЕЛЬ (CE4) ↓ teamcadillac.ru 25890367 HOSE, HDLP WA 12335720 COVER, HDLP WA NOZ 12335721 COVER, HDLP WA NOZ 25767592 NOZZLE, HDLP WA [ФОРСУНКА ФАРООМЫВАТЕЛЯ] 25767593 NOZZLE, HDLP WA [ФОРСУНКА СТЕКЛООМЫВАТЕЛЯ] 88958121 PUMP, HDLP WA (LOCATED IN WSW TANK) (ACDelco #88958121) [НАСОС СТЕКЛООМЫВАТЕЛЯ] 88958122 SEAL, HDLP WA PUMP (6E02-023) - 2004-2009 E КРЕПЛЕНИЕ ГЕНЕРАТОРА (LH2/4.6A) ↓ teamcadillac.ru 12565095 BRACKET, GEN 11515767 БОЛТ, HFH, M10X1.5X35, 32THD, 22.3 O.D., MACH, 10.9, 7114M (GEN BRKT) (T/W 12345493) [БОЛТ] 25756440 GENERATOR, (ACDelco #25756440) [ГЕНЕРАТОР В СБОРЕ] 11516360 БОЛТ, HFH M10X1.2X90, 9.8, 7114M, 22.3 OD HDR PT (GEN) (6E02-024) - 2004-2005 E КРЕПЛЕНИЕ АККУМУЛЯТОРА И КАБЕЛИ (LH2/4.6A) ↓ 25747792 SHIELD, BAT HT (INSTALLED ON RH SIDE OF CAR) 11509853 БОЛТ, HEX W/CON WA, M8X1.25X45, 24 O.D., HDR PT, 9.8, PS (BAT HOLDN RET) [БОЛТ] 25558374 RETAINER, BAT HOLDN (CENTER SLOT) [ФИКСАТОР АККУМУЛЯТОРНОЙ БАТТАРЕИ] teamcadillac.ru 88901964 АККУМУЛЯТОР, (CCA 650) (SIDE TERM) (260X178X168) (US DEALERS CONTACT ACDELCO WD FOR ORDERING & PRICING INFO) (ACDelco #101-6YR) (PROFESSIONAL - 6 YR) 15204281 LABEL, BAT WRNG (INCLUDES SYMBOLS ONLY) 11518646 БОЛТ, HEX HD, W/CON WA, M6X1X30, 24.33THD, 17 OD, 9.8, 6138M, BLK (BAT TRAY) 15812692 TRAY, BAT (INCLS 8) 11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (ЧАСТЬ OF 7) [ШАЙБА] 10369851 CABLE, BAT POS (INCLS 21) (ACDelco #10369851) 21021808 ГАЙКА, STRTR SOL BAT TERM (LARGER) (M8X1.25X6, BRASS) (2.343) [ГАЙКА М8] 11504568 ГАЙКА, HEX M5X0.8 PREV TORQ INSERT 9 ZC (STRTR SOL CBL) 11517070 БОЛТ, HVY HFH, M10X1.5X20 (BAT CBL TERM) 11515535 ГАЙКА, BAT WIRE (2.559) 15209171 CABLE, BAT NEG (INCLS 20) (ACDelco #15209171) 15695050 БОЛТ, BAT NEG CBL GND (SHOCK TOWER GRND) (M8 X 1.25 X 25) (HEX БОЛТ W/WASHER) (4.686) [БОЛТ КРЕПЛЕНИЯ ГЛУШИТЕЛЯ, М8Х1.25Х25] 11517031 ГАЙКА, HFH, M8X1.25, 9.4THK, 17.4 O.D., 10, TIN ZN (BAT POS CBL) 12160209 COVER, BAT NEG CBL TERM (ЧАСТЬ OF 17) (BLACK VINYL) (SURROUNDS CABLE END AT BATT SIDE TERM) 12010050 COVER, BAT POS CBL БОЛТ (ЧАСТЬ OF 10) (RED) (HAS SLOTTED HOLE) (SNAPS ON TO АККУМУЛЯТОР БОЛТ) 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (BAT TRAY) [БОЛТ М6] (6E02-025) - 2004-2009 E ЖГУТЫ ПРОВОДОВ/ПЕРЕДНИЕ ФАРЫ ↓ 15141492 HARNESS, FWD LP WRG (INCLS 2, 3) 15141494 HARNESS, FWD LP WRG (INCLS 2, 3) 15141495 HARNESS, FWD LP WRG (INCLS 2, 3) 15141496 HARNESS, FWD LP WRG (INCLS 2, 3) 15141497 HARNESS, FWD LP WRG (INCLS 2, 3) 15141499 HARNESS, FWD LP WRG (INCLS 2, 3) 15141500 HARNESS, FWD LP WRG (INCLS 2, 3) [К-Т ПРОВОДОВ ПЕРЕДНИХ ФАР] 15141501 HARNESS, FWD LP WRG (INCLS 2, 3) 15141502 HARNESS, FWD LP WRG (INCLS 2, 3) 15141503 HARNESS, FWD LP WRG (INCLS 2, 3) teamcadillac.ru 25747284 HARNESS, S/LP WRG (6E02-026) - 2004-2009 E ЖГУТЫ ПРОВОДОВ/ДВИГАТЕЛЬ (LH2/4.6A) ↓ teamcadillac.ru 15241455 HARNESS, ENG WRG 19115853 HARNESS, ENG WRG 19115855 HARNESS, ENG WRG 19115856 HARNESS, ENG WRG 11517070 БОЛТ, HVY HFH, M10X1.5X20 (ENG WRG HARN GND) 25771275 BRACKET, ENG WRG HARN (USED IN GENERATOR PACKAGE) 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] 11519861 БОЛТ, HEX W/FL WA, M10X1.5X30, 19 THD, 20 OD, 9.8, 6280M, MACH, MAT-PT (ENG WRG HARN GRD) [БОЛТ М10] 25773136 BRACKET, ENG WRG HARN (CHANNEL) 11517070 БОЛТ, HVY HFH, M10X1.5X20 (ENG WRG HARN SHLD) (6E02-027) - 2004-2009 E ЖГУТЫ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ ↓ 15209203 HARNESS, I/P WRG 19115879 HARNESS, I/P WRG 19115880 HARNESS, I/P WRG 19115881 HARNESS, I/P WRG 19115882 HARNESS, I/P WRG 19115883 HARNESS, I/P WRG 19115884 HARNESS, I/P WRG teamcadillac.ru 11516630 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (I/P WRG HARN) (6E02-028) - 2004-2006 E РЕЛЕ & МОДУЛЬS/ДВИГАТЕЛЬНЫЙ ОТСЕК ↓ 15233126 COVER, MULTIUSE RLY & FUSE (USED ON CARS BLT W/BLOCKS 15870409, 15224195-95 & 25771220; 2ND DES 15869080) [КРЫШКА] 15869080 COVER, MULTIUSE RLY & FUSE (USED ON CARS BUILT W/BLOCKS 15869077-79; 1ST DES SEE 15233126) 21997408 RELAY, FAN CONT (ЧАСТЬ OF 14) (5-TERMINAL) (SPDT, 280 MINI, HI/LOW, BLACK) (ACDelco #15-81106) 15319477 FUSE, 30AMP, PINK, J-CASE, FEMALE, REGULAR (ЧАСТЬ OF 14) [ПРЕДОХРАНИТЕЛЬ 30А] 15319478 FUSE, 40AMP, GREEN, J-CASE, FEMALE (ЧАСТЬ OF 14) (ACDelco #15319478) [ПРЕДОХРАНИТЕЛЬ 40А] 15319479 FUSE, 50 AMP, RED, J-CASE, FEMALE, REGULAR BLOW (ЧАСТЬ OF 14) 15319480 FUSE, MAXI 60 A (ЧАСТЬ OF 14) (YELLOW) (J-CASE, FEMALE) 19116060 PULLER, FUSE (ЧАСТЬ OF 14) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (MULTIUSE RLY & FUSE BRKT) [ГАЙКА М6] 25730750 BRACKET, MULTIUSE RLY & FUSE [ОПОРА ТОКОРАСПРЕДЕЛИТЕЛЬНОЙ КОРОБКИ] 11518094 БОЛТ-HES W/FL WA, M6X1X21, 11.75 THD, 24 OD, 9.8, 7114M, MACH, DOG-PT (MULTIUSE RLY & FUSE BRKT) 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (MULTIUSE RLY & FUSE BRKT) [БОЛТ М6] 15870408 BLOCK, ENG WRG HARN JUNC (INCLS 3-6, 15-17) 15870409 BLOCK, ENG WRG HARN JUNC (INCLS 3-6, 15-17) 15870410 BLOCK, ENG WRG HARN JUNC (INCLS 3-6, 15-17) 12092075 FUSE, MINI (30A) (GREEN) (ЧАСТЬ OF 14) (ACDelco #12092075) 12092079 FUSE, 10A, MINI, RED (ЧАСТЬ OF 14) 12092080 FUSE, 7.5A, MINI, BROWN (ЧАСТЬ OF 14) [КОМПЛЕКТ ПРЕДОХРАНИТЕЛЕЙ 7.5 А (5 ШТ)] 88909754 FUSE, 15A, MINI, BLUE (ЧАСТЬ OF 14) (ACDelco #ATM15-25) [ПРЕДОХРАНИТЕЛЬ 15 А] 88909755 FUSE, 20A, MINI, YELLOW (ЧАСТЬ OF 14) (ACDelco #ATM20-25) [ПРЕДОХРАНИТЕЛЬ 20 А] 12193606 RELAY, HDLP LOW BEAM (ЧАСТЬ OF 14) (BLUE) (4-TERMINAL) (SPST 280 MINI) (4.720) (ACDelco #12193606) 88953222 RELAY, FOG LP (ЧАСТЬ OF 14) (GRAY) (20AMP) (4 TERMINAL) (LOW-PROFILE MICRO 280) (ACDelco #D1755A) [РЕЛЕ] 88953228 RELAY, HDLP WA PUMP (ЧАСТЬ OF 14) (2.485) (ACDelco #D1756A) [РЕЛЕ] teamcadillac.ru 88953222 RELAY, ECM (ЧАСТЬ OF 14) (GRAY) (20AMP) (4 TERMINAL) (LOW-PROFILE MICRO 280) (2.485) (ACDelco #D1755A) [РЕЛЕ] (6E02-029) - 2004-2009 E ДАТЧИКИ ПАРКОВКИ ↓ 15210240 МОДУЛЬ, RR OBJECT ALARM [МОДУЛЬ В СБОРЕ] 10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (RR OBJECT ALARM MDL) [ПИСТОН КРЕПЛЕНИЯ ОБЛИЦОВКИ БАМПЕРА (NYLON)] 25770821 HARNESS, RR OBJECT SEN WRG [ПРОВОДКА ДАТЧИКА ЗВУКОВОЙ СИГНАЛИЗАЦИИ КОНТРОЛЯ ПАРКОВКИ] 89047028 SENSOR KIT, RR OBJECT (INCLS 6-9) (CONSIST OF BEZEL RETAINERS, RING & SENSOR) (7.831) [ДАТЧИК ЗВУКОВОЙ СИГНАЛИЗАЦИИ КОНТРОЛЯ ПАРКОВКИ] teamcadillac.ru (6E02-030) - 2004-2009 E КЛЮЧ-ЦИЛИНДР-ЗАЖИГАНИЕ ↓ 25756071 TUMBLER, IGN LK CYL (ЧАСТЬ OF 4) (#5) (W/O WINGED BEZEL) (LARGE HEADED KEYS) (BRANDED) [ТУМБЛЕР] 25756072 TUMBLER, IGN LK CYL (ЧАСТЬ OF 4) (#4) (W/O WINGED BEZEL) (LARGE HEADED KEYS) (BRANDED) [ТУМБЛЕР] 25756073 TUMBLER, IGN LK CYL (ЧАСТЬ OF 4) (#3) (W/O WINGED BEZEL) (LARGE HEADED KEYS) (BRANDED) [КОМПЛЕКТ ЛИЧИНОК ЦИЛИНДРА ЗАМКА ЗАЖИГАНИЯ (4 ШТ)] 25756074 TUMBLER, IGN LK CYL (ЧАСТЬ OF 4) (#2) (W/O WINGED BEZEL) (LARGE HEADED KEYS) (BRANDED) [К-Т НАБОРНЫХ ПЛАСТИН ЦИЛИНДРА ЗАМКА ДВЕРИ (4 ШТ.)] 25756075 TUMBLER, IGN LK CYL (ЧАСТЬ OF 4) (#1) (W/O WINGED BEZEL) (LARGE HEADED KEYS) (BRANDED) [КОМПЛЕКТ НАБОРНЫХ ПЛАСТИН ЦИЛИНДРА ЗАМКА ЗАЖИГАНИЯ (4 ШТ)] 25756090 ПРУЖИНА, IGN LK CYL TUMB (ЧАСТЬ OF 4) (W/O WINGED BZL) (LRG HEADED KEYS) (BRANDED) (10.553) 19120038 CYLINDER, IGN LK (INCLS 1-3) (W/O WINGED BEZEL) (LARGE HEADED KEYS) (BRANDED) 19207864 КЛЮЧ, DR LK & IGN LK [КЛЮЧ ЗАМКА ДВЕРИ] 25756100 КЛЮЧ, DR LK & IGN LK VALET (UNCODED) (6E02-032) - 2004-2006 E СИГНАЛ ↓ 25789208 СИГНАЛ, 400 & 500 HZ (INCLS 2, 3) (ACDelco #D1947F) [ЗВУКОВОЙ СИГНАЛ] teamcadillac.ru 11517103 STUD, SPL W/KNURLED SHLDR, M6X1X27, 10 THD, 13 O.D., P-PT., 9.8, 7114M (ЧАСТЬ OF 1) [ШТИФТ] 11517102 ГАЙКА, HEX FLG, M6X1X15, 19.8 OD, 9, 7111M (ЧАСТЬ OF 1) [ГАЙКА] (6E02-034) - 2004-2005 E КРЕПЛЕНИЕ АККУМУЛЯТОРА И КАБЕЛИ (LY7/3.6-7) ↓ 25747792 SHIELD, BAT HT (INSTALLED ON RH SIDE OF CAR) 11509853 БОЛТ, HEX W/CON WA, M8X1.25X45, 24 O.D., HDR PT, 9.8, PS (BAT HOLDN RET) [БОЛТ] 25558374 RETAINER, BAT HOLDN (CENTER SLOT) [ФИКСАТОР АККУМУЛЯТОРНОЙ БАТТАРЕИ] 88901964 АККУМУЛЯТОР, (CCA 650) (SIDE TERM) (260X178X168) (US DEALERS CONTACT ACDELCO WD FOR ORDERING & PRICING INFO) (ACDelco #101-6YR) (PROFESSIONAL - 6 YR) 15204281 LABEL, BAT WRNG (INCLUDES SYMBOLS ONLY) teamcadillac.ru 11518646 БОЛТ, HEX HD, W/CON WA, M6X1X30, 24.33THD, 17 OD, 9.8, 6138M, BLK (BAT TRAY) 15812692 TRAY, BAT (INCLS 8) 11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (ЧАСТЬ OF 7) [ШАЙБА] 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (BAT TRAY) [БОЛТ М6] 15889973 CABLE, BAT NEG (ACDelco #15889973) 21021808 ГАЙКА, STRTR SOL BAT TERM (LARGER) (M8X1.25X6, BRASS) (2.343) [ГАЙКА М8] 25785031 CABLE, BAT POS (ACDelco #25785031) 11515535 ГАЙКА, BAT WIRE (2.559) 11517031 ГАЙКА, HFH, M8X1.25, 9.4THK, 17.4 O.D., 10, TIN ZN (BAT POS CBL) 15695050 БОЛТ, BAT NEG CBL GND (TO BODY) (M8 X 1.25 X 25) (HEX БОЛТ W/WASHER) (4.686) [БОЛТ КРЕПЛЕНИЯ ГЛУШИТЕЛЯ, М8Х1.25Х25] 11517274 STUD, HFH M8X1.25X20, M10X1.5X25, 22.3 OD, 9.8, 6280M. (BAT CBL TERM) (6E02-035) - 2005-2009 E ПЕРЕДНИЕ ФАРЫ (EXPORT TT7,TT8) ↓ 15930599 ЛАМПА, FRT SI T/SIG (INCLS 2) [УКАЗАТЕЛЬ ПОВОРОТА] 01999382 BULB, (ЧАСТЬ OF 1) (ACDelco #W5WLL) (LONGER LIFE) 25760398 SENSOR, HDLP LVLG FRT SUSP HEIGHT (9X/-3NM (S)9X/-3NM) (INTEGRAL STUD) [ДАТЧИК НАКЛОНА ПЕРЕДНЕЙ ЧАСТИ КУЗОВА] 01999382 BULB, (ЧАСТЬ OF 10) (ACDelco #W5WLL) (LONGER LIFE) 10346260 BULB, FRT FOG LP (ЧАСТЬ OF 10) (TRADE 9145) (ACDelco #9145) [ЛАМПА НАКАЛИВАНИЯ] 15896707 ЛАМПА, FRT T/SIG & FOG (INCLS 5-9, 11) 15896708 ЛАМПА, FRT T/SIG & FOG (INCLS 5-9, 11) 11513599 ГАЙКА, U-TYPE, M4.2X1.41, 0.65-3.80 PNL THK, PZ (ЧАСТЬ OF 14) (ACDelco #11513599) 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (FRT FOG LP) [ВИНТ М4] 15915312 BRACKET, FRT PARK & T/SIG & FOG LP (INCLS 12, 39) [ОПОРА ПРОТИВОТУМАННОЙ ФАРЫ] 15915313 BRACKET, FRT PARK & T/SIG & FOG LP (INCLS 12, 39) [КРОНШТЕЙН ПЕРЕДНЕЙ ФАРЫ] 11588795 RETAINER, HDLP (PUSH ON) (FITS 9 X 16 HOLE, 1.5 THICK PANEL) [ДЕМПФЕР КРЕПЛЕНИЯ ПЕРЕДНЕЙ ФАРЫ] 25735603 BULB, HDLP (LOW BEAM) (ЧАСТЬ OF 22) (TRADE #D1S) (ACDelco #D1S) [ЛАМПОЧКА ПЕРЕДНЕЙ ФАРЫ 50 ВТ] 25735601 BULB, HDLP (HIGH BEAM) (ЧАСТЬ OF 22) (TRADE #9005XSLL) (ACDelco #9005SX) [ЛАМПА ФАРЫ] 01999382 BULB, (ЧАСТЬ OF 22) (ACDelco #W5WLL) (LONGER LIFE) 15926963 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 16-21, 23-27) teamcadillac.ru 15930600 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 16-21, 23-27) [ПЕРЕДНЯЯ ФАРА] 25766663 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 16-21, 23-27) 25766664 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 16-21, 23-27) 25768517 SENSOR, HDLP LVLG RR SUSP HEIGHT (INCLS 29) [ДАТЧИК ПОЛОЖЕНИЯ КУЗОВА] 25722303 HARNESS, HDLP LVLG ACTR WRG (ЧАСТЬ OF 28) 25753157 BRACKET, HDLP (INCLS 33) 11517397 ГАЙКА, HEX W/CON WA, 8X1.25, 28 O.D., 7.5 THK, 9, PEOR (FRT BPR ENGY ABS) 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (ЧАСТЬ OF 31, 38) (ACDelco #11517518) [БОЛТ] 11518497 SCREW, ASM HEX HD W/FLAT WASHER, M6X1.0X25, 14 THD, 9.8 (HDLP) 11588795 RETAINER, HDLP (PUSH ON) (FITS 9 X 16 HOLE, 1.5 THICK PANEL) [ДЕМПФЕР КРЕПЛЕНИЯ ПЕРЕДНЕЙ ФАРЫ] 11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (ЧАСТЬ OF 38) [ШАЙБА] 25753158 BRACKET, HDLP (INCLS 33, 37) [КРОНШТЕЙН В СБОРЕ] 11609459 SCREW, RND WA, M4.2X1.41X13, 7.2 THD, 11.35 OD, 6010M, GMW4205 (ЧАСТЬ OF 14) [ВИНТ] (6E02-036) - 2005-2009 E ПЕРЕДНИЕ ФАРЫ (EXC EXPORT TT7,TT8) ↓ 10346260 BULB, FRT FOG LP (ЧАСТЬ OF 7) (TRADE 9145) (ACDelco #9145) [ЛАМПА НАКАЛИВАНИЯ] 15855631 BULB, T/SIG (ЧАСТЬ OF 7) (TRADE #3457NAK-LCP) (2.880) (ACDelco #15855631) 15862271 BULB, T/SIG (ЧАСТЬ OF 7) (TRADE #3757KA) (2.880) (ACDelco #23757NAK) [ЛАМПОЧКА СИГНАЛА ПОВОРОТА, 21 ВТ] 15896707 ЛАМПА, FRT T/SIG & FOG (INCLS 2-6, 8, 37) 15896708 ЛАМПА, FRT T/SIG & FOG (INCLS 2-6, 8, 37) 11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (FRT FOG LP) [ВИНТ М4] 11588795 RETAINER, HDLP (PUSH ON) (FITS 9 X 16 HOLE, 1.5 THICK PANEL) [ДЕМПФЕР КРЕПЛЕНИЯ ПЕРЕДНЕЙ ФАРЫ] 25735603 BULB, HDLP (LOW BEAM) (ЧАСТЬ OF 24) (TRADE #D1S) (ACDelco #D1S) [ЛАМПОЧКА ПЕРЕДНЕЙ ФАРЫ 50 ВТ] 09441732 BULB, HDLP (HIGH BEAM) (ЧАСТЬ OF 24, 31) (W/TRADE #9005) (ACDelco #9005) 01999382 BULB, (ЧАСТЬ OF 24) (ACDelco #W5WLL) (LONGER LIFE) 12335548 BALLAST, HDLP (ЧАСТЬ OF 24) (1ST DESIGN HAS A 12 PIN CONNECTOR. FOR 2ND DESIGN SEE 89024736) [БАЛЛАСТ] 89024736 BALLAST, HDLP (LH AND RH) (ЧАСТЬ OF 24) (2ND DESIGN HAS A 4 PIN CONNECTOR. FOR 1ST DESIGN SEE 12335548) 11517397 ГАЙКА, HEX W/CON WA, 8X1.25, 28 O.D., 7.5 THK, 9, PEOR (FRT BPR ENGY ABS) 25753157 BRACKET, HDLP (INCLS 22) 11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (ЧАСТЬ OF 21, 27) [БОЛТ М6] 11518497 SCREW, ASM HEX HD W/FLAT WASHER, M6X1.0X25, 14 THD, 9.8 (HDLP) 15260975 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 11-19, 29, 36) teamcadillac.ru 15926960 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 11-19, 29, 36) 11518497 SCREW, ASM HEX HD W/FLAT WASHER, M6X1.0X25, 14 THD, 9.8 (HDLP) 11518121 ГАЙКА, U, M6X1, MULTI THD, .5'-4.0' THK PNL (ЧАСТЬ OF 27) 25753158 BRACKET, HDLP (INCLS 22, 26) [КРОНШТЕЙН В СБОРЕ] 25735602 BULB, HDLP (LOW BEAM) (ЧАСТЬ OF 31) (TRADE #9006XSLL) (ACDelco #9006SXLL) [ЛАМПА НАКАЛИВАНИЯ] 01999382 BULB, (ЧАСТЬ OF 31) (ACDelco #W5WLL) (LONGER LIFE) 15926966 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 11, 12, 15, 14, 28-30, 38) 15926967 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 11, 12, 15, 14, 28-30, 38) 11588795 RETAINER, HDLP (PUSH ON) (FITS 9 X 16 HOLE, 1.5 THICK PANEL) [ДЕМПФЕР КРЕПЛЕНИЯ ПЕРЕДНЕЙ ФАРЫ] 11513599 ГАЙКА, U-TYPE, M4.2X1.41, 0.65-3.80 PNL THK, PZ (FRT T/SIG LP) (ACDelco #11513599) 15915312 BRACKET, FRT PARK & T/SIG & FOG LP [ОПОРА ПРОТИВОТУМАННОЙ ФАРЫ] 15915313 BRACKET, FRT PARK & T/SIG & FOG LP [КРОНШТЕЙН ПЕРЕДНЕЙ ФАРЫ] 11609459 SCREW, RND WA, M4.2X1.41X13, 7.2 THD, 11.35 OD, 6010M, GMW4205 (FRT FOG LP) [ВИНТ] 25763464 BULB, FRT POSN LP (PARK FUNCTION BULB) (ЧАСТЬ OF 24) (BLUE TINT) (TRADE #W5WB50X2) (ACDelco #W5WB50X2) [ЛАМПОЧКА НАКАЛИВАНИЯ ФАРЫ 55 ВТ] 19120947 SOCKET, FRT T/SIG LP (ЧАСТЬ OF 7) (ACDelco #LS234) 01999382 BULB, (ЧАСТЬ OF 31) (ACDelco #W5WLL) (LONGER LIFE) (6E02-037) - 2005-2006 E СИГНАЛИЗАЦИЯ/ANTI THEFT (UA2) ↓ 10388029 SENSOR, THEFT DTRNT [ДАТЧИК ОБЬЕМА ДЛЯ ПРОТИВОУГОННОЙ СИГНАЛИЗАЦИИ] 90355463 SWITCH, КАПОТ AJAR IND LP (ANTI THEFT WARNING UNIT) [ДАТЧИК ОТКРЫТИЯ КАПОТА (КОНЦ. ВЫКЛЮЧАТЕЛЬ)] 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (КАПОТ AJAR IND SW BRKT) 25765686 BRACKET, КАПОТ AJAR IND LP SW 11609599 STUD, SPL, M6X1X25, 13 THD, 11 OD HD W/26 WIDE CLIP, 9.8, 6280M, P-PT (THEFT DTRNT ALARM) 25734317 SENSOR, THEFT DTRNT VEH INCLINATION [ДАТЧИК НАКЛОНА КУЗОВА] teamcadillac.ru 10362943 BRACKET, THEFT DTRNT ALARM 11514517 ГАЙКА, HEX, W/CON SPR WA, M6X1, 5.7THK, 18 O.D., 9, 7111M (THEFT DTRNT ALARM) [ГАЙКА М6] 15213135 ALARM, THEFT DTRNT [ЗВУКОВОЙ СИГНАЛ (СИРЕНА) СИГНАЛИЗАЦИИ] (6E02-039) - 2005-2009 E ЗАДНИЕ ФАРЫ ↓ 25773051 WEATHERSTRIP, L/GATE UPR [БОКОВОЙ МОЛДИНГ] 11509428 БОЛТ/SCREW, HEX, W/FLAT WA, M4.2X1.4X13, 12.3 O.D., BHL PT, 6010M, NO (L/GATE APLQ) (8.977) 15211328 GASKET, HIGH MT S/LP (USED W/BEZEL 12335827) [ПРОКЛАДКА] 15211327 GASKET, HIGH MT S/LP (USED WITH BEZEL 12335827) (ON TAB SEAL-T/LP HSG S/LP (ON STUD) [ПРОКЛАДКА] 19121111 BEZEL, HIGH MT S/LP (MUST ALSO ORDER GASKETS 15211328, 15211327, 25759092.) [ОКАНТОВКА ФОНАРЯ ДОПОЛНИТЕЛЬНОГО СТОП-СИГНАЛА] 15930616 ЛАМПА, HIGH MT STOP [ЗАДНИЙ ФОНАРЬ] 15213960 GASKET, HIGH MT S/LP (USED WITH BEZEL 12335827) (ON STUD) 11588650 CLIP, 12X14X16.6, GM4345M (L/GATE APLQ) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА] 25759092 GASKET, HIGH MT S/LP (38 OD X 28 ID X 9.5 THICK) [ПРОКЛАДКА МОЛДИНГА ЗАДНЕЙ ОТКИДНОЙ ДВЕРИ] 01999382 BULB, (ЧАСТЬ OF 14, 24) (ACDelco #W5WLL) (LONGER LIFE) 12450108 BULB, TRADE #3157KX (ЧАСТЬ OF 14, 24) (2.679) (ACDelco #3157KX) (LONGER LIFE KRYPTON) [ЛАМПОЧКА НАКАЛИВАНИЯ ФАРЫ 15 ВТ] 25735605 BUMPER, RR LIC PLT PKT (ЧАСТЬ OF 14, 24) (2.662) 12335850 ЛАМПА, B/U & RR LIC (W/RR LIC PLT PKT) (INCLS 10-13) (КРАСКА TO MATCH) 25936964 ЛАМПА, TAIL 25936965 ЛАМПА, TAIL 25936966 ЛАМПА, TAIL [ЗАДНИЙ ФОНАРЬ] 25936967 ЛАМПА, TAIL [ЗАДНИЙ ФОНАРЬ] 25736754 RETAINER, T/LP (PUSH IN) (14 X 21MM HEAD) 11519918 RETAINER, T/LP (PUSH IN) (16MM ROUND HEAD) (2.664) [ФИКСАТОР ЗАДНЕГО ФОНАРЯ] 11517736 ГАЙКА, HEX, M6X1, 5.7 HIGH, 24 OD, 9, 7111M, W/2.5 THK SEALING WA (T/LP) [ГАЙКА М6] 11514517 ГАЙКА, HEX, W/CON SPR WA, M6X1, 5.7THK, 18 O.D., 9, 7111M (B/U & RR LIC PLT LP) [ГАЙКА М6] 11517230 БОЛТ, TORX, W/WA, W/ADH, M6X1X20, 16.2 O.D., DOG PT, 10.9, GM6138M (L/GATE UPR SI APLQ) [ВИНТ ЗАМКА ДВЕРИ М6] teamcadillac.ru 89025118 GASKET, HIGH MT S/LP 15211652 HARNESS, L/GATE LK & R/WDO DEFG & R/WDO WPR WRG 15211653 HARNESS, L/GATE LK & R/WDO DEFG & R/WDO WPR WRG 12335851 ЛАМПА, B/U & RR FOG & RR LIC PLT (INCLS 10, 12, 13, 25, 26) (КРАСКА TO MATCH) (2.697) [ЛАМПА] 12450108 BULB, TRADE #3157KX (RR FOG LP) (ЧАСТЬ OF 24) (2.679) (ACDelco #3157KX) (LONGER LIFE KRYPTON) [ЛАМПОЧКА НАКАЛИВАНИЯ ФАРЫ 15 ВТ] (6M02-029) - 2004-2009 E ЖГУТЫ ПРОВОДОВ/ДВИГАТЕЛЬНЫЙ ОТСЕК (LY7/3.6-7) ↓ 19115857 HARNESS, ENG WRG 19115858 HARNESS, ENG WRG teamcadillac.ru 11562004 БОЛТ, HEX W/FL WA, M10X1.5X30, 19 THD, 20 OD, 8.8, GMW3200, MACH, M-PT (ENG WRG HARN SUPT) 15870408 BLOCK, ENG WRG HARN JUNC 15870409 BLOCK, ENG WRG HARN JUNC 15870410 BLOCK, ENG WRG HARN JUNC 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ENG WRG HARN OXY SEN LEAD BRKT) 12589726 BRACKET, ENG WRG HARN OXY SEN LEAD (HOLD POST SENSOR CONN "POSITION 2 CONNECTOR" ЗАДНИЙ) (6M02-036) - 2004-2006 E КРЕПЛЕНИЕ СТАРТЕРА (LY7/3.6-7) ↓ teamcadillac.ru 12597349 STARTER, (REMAN) (ACDelco #323-1629) [СТАРТЕР] 11518627 БОЛТ, HFH, M10X1.5X45, 15MM SOCKET, 10.9, GMW3359 (STRTR) (ACDelco #11518627) (6M02-038) - 2004-2009 E ЖГУТЫ ПРОВОДОВ/ДВИГАТЕЛЬ В СБОРЕ (LY7/3.6-7) ↓ 12597469 HARNESS PKG, ENG WRG (WITH OIL LEVEL SENSOR) (USE T/W 15306420 CONN T/W (2) 12575657 SENSOR) (WHEN REPLACING OLD HARNESS, CUSTOMER MAY NEED TO REPLACE ALL PARTS LISTED) 12599240 HARNESS PKG, ENG WRG (WITHOUT OIL LEVEL SENSOR) (USE T/W 15306420 CONN T/W (2) 12575657 SENSOR) (WHEN REPLACING OLD HARNESS, CUSTOMER MAY NEED TO REPLACE ALL PARTS LISTED) 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ENG WRG HARN) 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (ECM) [БОЛТ] teamcadillac.ru 24574534 STUD, ENG WRG HARN BRKT (M6X1X20) (1.166) 11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (ECM BRKT) [БОЛТ] 12585357 BRACKET, ENG WRG HARN OXY SEN LEAD (HOLDS THE PRE SENSOR CONNECTOR "POSITION 1 CONN") 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (WRG HARN BRKT) (6Y02-017) - 2004-2005 E РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ & МОДУЛЬ/ЗАЖИГАНИЕ (LH2/4.6A) ↓ teamcadillac.ru 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ) 11588967 STUD, BALL W/HFH, M6X1X20.65, 14.2 O.D., 8.8, GMW3359 (IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ) 89017778 РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ, IGN (INCLS 704-707) (ACDelco #D593A) [КАТУШКА ЗАЖИГАНИЯ] 03 - ТОПЛИВНАЯ СИСТЕМА - ВЫХЛОПНАЯ - СИСТЕМА ВЫПУСКА ВОЗДУХА ↓ (6E03-009) - 2004-2006 E АКСЕЛЕРАТОР (EXC JF4) ↓ 15263218 PEDAL, ACCEL (INCLS 2, 3) [ПЕДАЛЬ ГАЗА] teamcadillac.ru 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (ACCEL PED LVR) (6E03-010) - 2004-2006 E АКСЕЛЕРАТОР (JF4) ↓ 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (ACCEL PED LVR) 15263220 PEDAL, ACCEL (INCLS 3, 4) (INCLS SENSOR) [ПЕДАЛЬ АКСЕЛЕРАТОРА В СБОРЕ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 89047780 MOTOR KIT, BRK & ACCEL PED ADJR ACTR (INCLS 9) [ЭЛЕКТРОДВИГАТЕЛЬ ПЕДАЛЬНОГО УЗЛА 19 ВТ] teamcadillac.ru 89047778 CABLE, BRK PED ADJR ACTR [ЖГУТ ПРОВОДОВ] 89047779 CABLE, ACCEL CONT (6E03-011) - 2004-2006 E СИСТЕМА ВПУСКА ВОЗДУХА (LH2/4.6A) ↓ 25798271 ELEMENT, КОНДИЦИОНЕРL (ACDelco #A2944C) [ВОЗДУШНЫЙ ФИЛЬТР ДВИГАТЕЛЯ] 19151529 COVER, КОНДИЦИОНЕРL HSG LWR (INCLS 4) [КРЫШКА ВОЗДУХОЗАБОРНИКА] teamcadillac.ru 11588831 SCREW, HEX W/ CON WA, M6X1X35, 33.5 THD, 17 O.D.HDR PT, 9.8, BLK (КОНДИЦИОНЕРL) 19177871 INSULATOR, КОНДИЦИОНЕРL HSG (MOUNT TO MID RAIL) 12561695 БОЛТ, КОНДИЦИОНЕРL (M6X1X13MM) 88967332 БОЛТ, КОНДИЦИОНЕРL (30.7MM) 19177871 INSULATOR, КОНДИЦИОНЕРL HSG (MOUNT TO MID RAIL) 25744215 DUCT, RR INT AIR (W/RESO) (INCLS 9) [ТРУБКА ВОЗДУХОПРОВОДА] 12567377 SENSOR, MASS AIRFLOW (INCLS 11) (ACDelco #213-1594) [ДАТЧИК РАСХОДА ВОЗДУХА] 15147461 GASKET, MASS AIRFLOW SEN (ROUND) 15813321 GASKET, MASS AIRFLOW SEN (RECTANGULAR) (GASKET IS POA TO MAF SENSOR) 25314060 БОЛТ, M6X1X30, 11 THD, 12.5 OD, 4.8, 6047M, P-PT (КОНДИЦИОНЕРL HSG CVR) 15147459 COVER, КОНДИЦИОНЕРL HSG [КРЫШКА ВОЗДУХООЧИСТИТЕЛЯ] (6E03-011) - 2004-2006 E СИСТЕМА ВПУСКА ВОЗДУХА (LY7/3.6-7) ↓ 25798271 ELEMENT, КОНДИЦИОНЕРL (ACDelco #A2944C) [ВОЗДУШНЫЙ ФИЛЬТР ДВИГАТЕЛЯ] 19151528 COVER, КОНДИЦИОНЕРL HSG LWR (INCLS 4) [КРЫШКА ВОЗДУХООЧИСТИТЕЛЯ] 11588831 SCREW, HEX W/ CON WA, M6X1X35, 33.5 THD, 17 O.D.HDR PT, 9.8, BLK (КОНДИЦИОНЕРL) 15744944 INSULATOR, КОНДИЦИОНЕРL HSG (ЧАСТЬ INCLUDES RUBBER INSULATOR AND METAL SPACER) 12561695 БОЛТ, КОНДИЦИОНЕРL (M6X1X13MM) 19177871 INSULATOR, КОНДИЦИОНЕРL HSG (MOUNT TO MID RAIL) teamcadillac.ru 25733251 DUCT, RR INT AIR (W/RESO) (INCLS 9) 12566846 SENSOR, MASS AIRFLOW (INCLS 11) (ACDelco #213-1593) [ДАТЧИК] 15147456 GASKET, MASS AIRFLOW SEN 25314060 БОЛТ, M6X1X30, 11 THD, 12.5 OD, 4.8, 6047M, P-PT (КОНДИЦИОНЕРL HSG CVR) 15147455 COVER, КОНДИЦИОНЕРL HSG [КРЫШКА ВОЗДУШНОГО ФИЛЬТРА] (6E03-012) - 2004-2009 E ТОПЛИВНЫЙ БАК & КРЕПЛЕНИЕ ↓ 25862765 CAP, F/TNK FIL LK (0.1KGS) (ACDelco #GT264) [КРЫШКА ТОПЛИВОНАЛИВНОЙ ГОРЛОВИНЫ] 15775325 DOOR, F/TNK FIL (INCLS 6) teamcadillac.ru 11509374 БОЛТ, SCR HEX W/FL WA, SELF TAP, 4.2X1.41X16, 12.5 O.D. (F/TNK FIL PIPE) 25773939 ШЛАНГИ, F/TNK FIL PIPE [КОЖУХ ТОПЛИВОЗАЛИВНОЙ ГОРЛОВИНЫ] 89047657 BUMPER, F/TNK FIL DR (ЧАСТЬ OF 3) (HINGE) [ВТУЛКА] 11609731 RIVET, F/TNK FIL DR (25" SHANK, .63 LEN, .50 OD, .06-.30 GRP RNG, 1008 STL, GMW3044) (8.967) 15868848 PIPE, F/TNK FIL (INCLS 9, 10, 15, 19, 20) [ТРУБКА ТОПЛИВОЗАЛИВНОЙ ГОРЛОВИНЫ] 01470030 CЛАМПА, WORM TYPE (11/16" TO 1 5/16") (ЧАСТЬ OF 8) (ACDelco #1470030) 09177063 CЛАМПА, F/TNK FIL HOSE (ЧАСТЬ OF 12) (25-40MM CЛАМПА RANGE) 15925741 HOSE, F/TNK FIL (INCLS 11) [ШЛАНГ ТОПЛИВНОЙ СИСТЕМЫ] 09177063 CЛАМПА, F/TNK FIL HOSE (25-40MM CЛАМПА RANGE) 11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (F/TNK FIL PIPE BRKT) [БОЛТ М8] 15638098 RETAINER, FUEL RTN PIPE FTG (ЧАСТЬ OF 8) (NATURAL) (NYLON) (5/16") (7.9MM) 11517101 БОЛТ, METRIC HEX FLANGE HD, M10X1.5X50 (F/TNK STRP) [БОЛТ М10] 25679207 STRAP, F/TNK [ЗАЖИМ БЕНЗОБАКА] 12337820 STRAP, 15" TIE STRAP (ЧАСТЬ OF 8) (ACDelco #12337820) 25880365 ПРУЖИНА, F/TNK FIL DR (PRIOR TO INSTALL SEAL VOIDS IN PLUNGER HSG W/FLEXIABLE SEALER) [ЗАЩЕЛКА ЛЮЧКА ТОПЛИВНОЙ ГОРЛОВИНЫ] (6E03-013) - 2004-2009 E СИСТЕМА ТОПЛИВОСНАБЖЕНИЯ (LH2/4.6A) ↓ 15924706 HARNESS, FUEL SDR WRG (3.115) 88965813 SENDER KIT, FUEL (INCLS 24) (FOR AUXILARY МОДУЛЬ) (ACDelco #MU1579) 19177355 CANISTER, EVAP EMIS (CANISTER WITHOUT COVER OR FILTER) (INCLS 39, 43) (ACDelco #215-644) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (EVAP EMIS CNSTR BRKT) [ГАЙКА М6] 15278918 PIPE, EVAP EMIS CNSTR PURGE 15219486 PIPE, FUEL FEED RR (INCLS 35) 15219484 PIPE, FUEL RTN RR 22514722 SEAL, FUEL FEED FRT PIPE (O RING) (ЧАСТЬ OF PIPE, FEED & RTN ASM BUNDLE) (7.35MM ID X 1.66MM THK) (ACDelco #217-452) [КОЛЬЦО УПЛОТНИТЕЛЬНОЕ, ТОПЛИВНОЙ ТРУБКИ] 25763176 ФИЛЬТР, FUEL (ACDelco #GF897) [ТОПЛИВНЫЙ ФИЛЬТР] 11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (FUEL FLTR BRKT) [БОЛТ М8] 25701014 RETAINER, FUEL FLTR 25688547 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (RETAINER W/5 HOLES (2)7.95, (2)4.76, (1)9.52MM) 15270078 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (USES RETAINER PIN FOR ATTACHMENT) [ЗАЖИМ ТРУБКИ ТОПЛИВНОЙ СИСТЕМЫ] 25917777 PIPE, EVAP EMIS CNSTR PURGE 10360402 PIPE, FUEL FEED (INCLS 19) [ТРУБКА ТОПЛИВНОЙ СИСТЕМЫ, СТАЛЬ] 25917776 PIPE, FUEL FEED (INCLS 19) 25761218 BRACKET, FUEL PIPE 25761217 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (3.162) 25765594 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (42.10MM LENGTH) (3.162) [ФИКСАТОР ТОРМОЗНЫХ ТРУБОК] 25679213 PIN, F/TNK UPR SHLD 25679209 SHIELD, F/TNK 25894460 TANK, FUEL (INCLS 21, 26, 27, 31, 33, 34) [ТОПЛИВНЫЙ БАК] 25901272 SEAL, FUEL SDR (ЧАСТЬ OF 2, 28, 44) (ACDelco #G37) 25740096 CAM, FUEL SDR (ACDelco #TR23) 19181827 МОДУЛЬ KIT, F/TNK F/PMP (W/O FUEL LVL SEN) (INCLS 24) (ACDelco #M10201) [ТОПЛИВНЫЙ НАСОС] 25679252 RETAINER, FUEL FEED & EVAP EMIS & RTN FRT PIPE (HOLDS 15.8/7.95/7.0 TUBES, HAS CHRISTMAS TREE RETAINER) (3.162) 15951521 PIPE, FUEL SDR FUEL FEED (INCLS CONN) (PIPE ATTACHES TO SENDING UNITS INSIDE OF GAS TANK) [ТРУБКА ТОПЛИВНОЙ СИСТЕМЫ] 16238399 SENSOR, F/TNK PRESS (ACDelco #16238399) [ДАТЧИК ДАВЛЕНИЯ ПАРОВ ТОПЛИВА] 25726788 RETAINER, BRK & FUEL PIPE (SQUARE HEAD PUSH PIN W/5 HOLES (2)4.76. (2)8.00 (1)9.52) [ФИКСАТОР ТОРМОЗНЫХ ТРУБОК] 25751324 RETAINER, FUEL FEED & EVAP EMIS & RTN FRT PIPE (HOLDS 7.95 & 9.5 DIA FUEL LINE, HAS CHRISTMAS TREE RETAINER) (3.162) 17114722 HOSE, EVAP EMIS CNSTR AIR INL (3.130) (ACDelco #219-366) teamcadillac.ru 17114723 COVER, EVAP EMIS CNSTR AIR INL OPG (ЧАСТЬ OF 3) 19177365 FILTER KIT, EVAP EMIS CNSTR (W/ SEAL) (INCLS 40) 25932573 VALVE, EVAP EMIS CNSTR VENT SOL (ACDelco #214-2230) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 88967139 SENSOR KIT, FUEL LVL (PRIMARY) (INCLS 24) (ACDelco #SK1161) [ТОПЛИВНЫЙ НАСОС] (6E03-014) - 2004-2006 E РАМКА ТОПЛИВНОГО ИНЖЕКТОРА (LH2/4.6A) ↓ teamcadillac.ru 12580644 RAIL, SEQ M/PORT F/INJN FUEL (INCLS 580, 581) (ACDelco #217-1556) 25532662 CAP, FUEL PRESS SERV VLV (ЧАСТЬ OF 566) (CAP FOR PRESSURE TEST SCHRADER VALVE) (3.163) (ACDelco #214-1044) [КРЫШКА] 12580648 VALVE KIT, FUEL PRESS SERV (INCLS 565) (ACDelco #12580648) 12580645 INJECTOR KIT, SEQ M/PORT FUEL (INCLS 561-564) (INCLS 1 INJECTOR, UPR AND LWR SEAL RINGS & RET) (ACDelco #217-1553) [ИНЖЕКТОР] 12580646 RETAINER KIT, F/INJR (INCLS 562) (INCLS 8 INJECTOR RET CLIPS) (ACDelco #12580646) 12580647 SEAL KIT, F/INJR (O RING) (INCLS 563, 564) (INCLS 8 UPR INJECTOR O-RINGS & 8 LWR INJECTOR O-RINGS) (ACDelco #217-1555) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО] (6E03-015) - 2004-2006 E БЛОК ЭЛЕКТРОННОГО УПРАВЛЕНИЯ И СВЯЗАННЫЕ ДЕТАЛИ (LH2/4.6A) ↓ teamcadillac.ru 12576523 МОДУЛЬ, ENG CONT (REQUIRES PROGRAMMING) (ACDelco #12576523) [БЛОК УПРАВЛЕНИЯ ДВИГАТЕЛЕМ] 25730751 BRACKET, ECM BRKT 11518646 БОЛТ, HEX HD, W/CON WA, M6X1X30, 24.33THD, 17 OD, 9.8, 6138M, BLK (ECM BRKT) 11514517 ГАЙКА, HEX, W/CON SPR WA, M6X1, 5.7THK, 18 O.D., 9, 7111M (ECM WRG HARN BRKT) [ГАЙКА М6] (6E03-016) - 2004-2006 E СИСТЕМА ОТРАБОТАВШИХ ГАЗОВ (LH2/4.6A) ↓ 12575657 SENSOR, HTD OXY (POSN 1) (IN EXH MANIFOLD/CROSSOVER) (ACDelco #213-1572) (W/RECTANGULAR SHAPED CONNECTOR) (FOR 2ND DES SEE 12596327) [ДАТЧИК] 12596327 SENSOR, HTD OXY (POSN 1) (IN EXH MANIFOLD/CROSSOVER) (ACDelco #213-3240) (W/OVAL SHAPED CONNECTOR) (FOR 1ST DES SEE 12575657) [КИСЛОРОДНЫЙ ДАТЧИК] 15240254 BRACKET, EXH TAIL PIPE HNGR (INCLS 3) [КРОНШТЕЙН] 25902027 BRACKET, EXH TAIL PIPE HNGR (INCLS 3) 25711603 INSULATOR, EXH MUFF HNGR BRKT (ЧАСТЬ OF 2) 15251184 PIPE, EXH TAIL (ЧАСТЬ OF 6) (3.701) 25711603 INSULATOR, EXH MUFF HNGR BRKT (ЧАСТЬ OF 6) 15290902 MUFFLER, EXH (W/RESO, EXH & TAIL PIPE) (INCLS 4, 5) 11517031 ГАЙКА, HFH, M8X1.25, 9.4THK, 17.4 O.D., 10, TIN ZN (EXH MUFF) 12590035 SENSOR, HTD OXY (POSN 3) (POST CONVERTER) (ACDelco #213-2823) [ДАТЧИК] 25709703 SEAL, CTLTC CONV (ЧАСТЬ OF 11) (ROUND METAL SEAL) [ПРОКЛАДКА НАСОСА] 11609596 STUD, CTLTC CONV (ЧАСТЬ OF 11) [ШПИЛЬКА] 12567687 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 9, 10) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 12567688 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 9, 10) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] teamcadillac.ru (6E03-017) - 2004-2009 E СИСТЕМА ТОПЛИВОСНАБЖЕНИЯ (LY7/3.6-7) ↓ 15924706 HARNESS, FUEL SDR WRG (3.115) 88965813 SENDER KIT, FUEL (INCLS 24) (FOR AUXILARY МОДУЛЬ) (ACDelco #MU1579) 19177355 CANISTER, EVAP EMIS (CANISTER WITHOUT COVER OR FILTER) (INCLS 46) (ACDelco #215-644) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (EVAP EMIS CNSTR BRKT) [ГАЙКА М6] 15278918 PIPE, EVAP EMIS CNSTR PURGE 15219486 PIPE, FUEL FEED RR (INCLS 35) 15219484 PIPE, FUEL RTN RR 22514722 SEAL, FUEL FEED FRT PIPE (O RING) (ЧАСТЬ OF PIPE, FEED & RTN ASM BUNDLE) (7.35MM ID X 1.66MM THK) (ЧАСТЬ OF 15) (ACDelco #217-452) [КОЛЬЦО УПЛОТНИТЕЛЬНОЕ, ТОПЛИВНОЙ ТРУБКИ] 25763176 ФИЛЬТР, FUEL (ACDelco #GF897) [ТОПЛИВНЫЙ ФИЛЬТР] 11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (FUEL FLTR BRKT) [БОЛТ М8] 25701014 RETAINER, FUEL FLTR 25688547 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (RETAINER W/5 HOLES (2)7.95, (2)4.76, (1)9.52MM) 25749839 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (HOLDS 3 ТРУБКИ, FLAT SHAPE, SNAP-IN RETAINER) 15888146 PIPE, EVAP EMIS CNSTR PURGE (INCLS 37, 39) 15145717 PIPE, FUEL FEED (INCLS 8, 19) 25761218 BRACKET, FUEL PIPE 25761217 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (3.162) 25679252 RETAINER, FUEL FEED & EVAP EMIS & RTN FRT PIPE (HOLDS 15.8/7.95/7.0 TUBES, HAS CHRISTMAS TREE RETAINER) (3.162) 25679213 PIN, F/TNK UPR SHLD 25679209 SHIELD, F/TNK 25894460 TANK, FUEL (INCLS 21, 26, 27, 31, 33, 34) [ТОПЛИВНЫЙ БАК] 25901272 SEAL, FUEL SDR (ЧАСТЬ OF 2, 28, 47) (ACDelco #G37) 25740096 CAM, FUEL SDR (ACDelco #TR23) 19181827 МОДУЛЬ KIT, F/TNK F/PMP (W/O FUEL LVL SEN) (INCLS 24) (ACDelco #M10201) [ТОПЛИВНЫЙ НАСОС] 25679252 RETAINER, FUEL FEED & EVAP EMIS & RTN FRT PIPE (HOLDS 15.8/7.95/7.0 TUBES, HAS CHRISTMAS TREE RETAINER) (3.162) 15951521 PIPE, FUEL SDR FUEL FEED (INCLS CONN) (PIPE ATTACHES TO SENDING UNITS INSIDE OF GAS TANK) [ТРУБКА ТОПЛИВНОЙ СИСТЕМЫ] 16238399 SENSOR, F/TNK PRESS (ACDelco #16238399) [ДАТЧИК ДАВЛЕНИЯ ПАРОВ ТОПЛИВА] 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (FUEL FEED & EVAP EMIS & RTN PIPE CLIP BRKT) [БОЛТ М6] 25654373 CLIP, FUEL FEED & RTN HOSE (PLASTIC) (ЧАСТЬ OF FUEL & BRAKELINE BUNDLE НИЖНЯЯ ЧАСТЬ; POSITION 2, 4, 5) teamcadillac.ru 25726788 RETAINER, BRK & FUEL PIPE (SQUARE HEAD PUSH PIN W/5 HOLES (2)4.76. (2)8.00 (1)9.52) [ФИКСАТОР ТОРМОЗНЫХ ТРУБОК] 17114722 HOSE, EVAP EMIS CNSTR AIR INL (3.130) (ACDelco #219-366) 17114723 COVER, EVAP EMIS CNSTR AIR INL OPG (ЧАСТЬ OF 44) 19177365 FILTER KIT, EVAP EMIS CNSTR (W/ SEAL) (INCLS 42, 43) 25932573 VALVE, EVAP EMIS CNSTR VENT SOL (ACDelco #214-2230) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ] 88967139 SENSOR KIT, FUEL LVL (PRIMARY) (INCLS 24) (ACDelco #SK1161) [ТОПЛИВНЫЙ НАСОС] (6E03-018) - 2004-2007 E СИСТЕМА ОТРАБОТАВШИХ ГАЗОВ (LY7/3.6-7) ↓ 15240254 BRACKET, EXH TAIL PIPE HNGR (INCLS 2) [КРОНШТЕЙН] 25902027 BRACKET, EXH TAIL PIPE HNGR (INCLS 2) 15284207 INSULATOR, EXH TAIL PIPE HNGR (ЧАСТЬ OF 1) [ДЕМПФЕР ГЛУШИТЕЛЯ] 25711603 INSULATOR, EXH MUFF HNGR BRKT (ЧАСТЬ OF 5) 15251183 PIPE, EXH TAIL (ЧАСТЬ OF 5) 15233284 MUFFLER, EXH (W/RESO, EXH & TAIL PIPE) (INCLS 3, 4) 15290901 MUFFLER, EXH (W/RESO, EXH & TAIL PIPE) (INCLS 3, 4) 11517031 ГАЙКА, HFH, M8X1.25, 9.4THK, 17.4 O.D., 10, TIN ZN (EXH MUFF) teamcadillac.ru 12590035 SENSOR, HTD OXY (POSN 3) (POST CONVERTER) (ACDelco #213-2823) [ДАТЧИК] 25768055 SEAL, CTLTC CONV (ЧАСТЬ OF 9) (SEAL WITH COVER ATTACHED) [УПЛОТНЕНИЕ КАТАЛИТИЧЕСКОГО НЕЙТРАЛИЗАТОРА] 12622977 CONVERTER, 3WAY CTLTC (INCLS 8, 10, 12, 13) [КАТАЛИТИЧЕСКИЙ НЕЙТРАЛИЗАТОР ВЫХЛОПНЫХ ГАЗОВ] 12622978 CONVERTER, 3WAY CTLTC (INCLS 8, 10, 12, 13) [КАТАЛИТИЧЕСКИЙ НЕЙТРАЛИЗАТОР ВЫХЛОПНЫХ ГАЗОВ] 11609596 STUD, CTLTC CONV (ЧАСТЬ OF 9) [ШПИЛЬКА] 12575657 SENSOR, HTD OXY (POSN 1) (IN EXH MANIFOLD/CROSSOVER) (ACDelco #213-1572) (W/RECTANGULAR SHAPED CONNECTOR) (FOR 2ND DES SEE 12596327) [ДАТЧИК] 12596327 SENSOR, HTD OXY (POSN 1) (IN EXH MANIFOLD/CROSSOVER) (ACDelco #213-3240) (W/OVAL SHAPED CONNECTOR) (FOR 1ST DES SEE 12575657) [КИСЛОРОДНЫЙ ДАТЧИК] 11589264 STUD, STRAIGHT, M10X1.5X30, M10X1.5X16, 57 TL, SS (ЧАСТЬ OF 9) [ШПИЛЬКА М8] 12571101 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 12571102 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ] 15709703 ГАЙКА, HEX 10X1.5THD, 21.8 OD SS (CTLTC CONV) [ГАЙКА М10] (6M03-085) - 2004-2006 E БЛОК ЭЛЕКТРОННОГО УПРАВЛЕНИЯ И СВЯЗАННЫЕ ДЕТАЛИ (LY7/3.6-7) ↓ 12600071 BRACKET, ECM (INCLS 8, 10) 12592124 МОДУЛЬ, ENG CONT (REQUIRES PROGRAMMING) (ACDelco #12592124) 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (ECM) [БОЛТ] 11562004 БОЛТ, HEX W/FL WA, M10X1.5X30, 19 THD, 20 OD, 8.8, GMW3200, MACH, M-PT (ECM GND STRP) 11519861 БОЛТ, HEX W/FL WA, M10X1.5X30, 19 THD, 20 OD, 9.8, 6280M, MACH, MAT-PT (ECM GND STRP) [БОЛТ М10] 11519172 БОЛТ, HFH, 8X1.25X55, 18 OD, 22THD, 8.8, GMW3359, 6MM MATPOINT, REDUCED BODY (ЧАСТЬ OF 1) teamcadillac.ru 11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (ECM BRKT) [БОЛТ] 11588523 STUD, M6X1 (ЧАСТЬ OF 1) (6M03-088) - 2004-2009 E РАМКА ТОПЛИВНОГО ИНЖЕКТОРА (LY7/3.6-7) ↓ 11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (WRG HARN BRKT) 12596182 HARNESS, F/INJR WRG (INCLS 2) (IF REPL 12584312 MAY NEED TO INSTALL BRACKET FROM HARNESS.) 25532662 CAP, FUEL PRESS SERV VLV (CAP FOR PRESSURE TEST SCHRADER VALVE) (*KIT2) (3.163) (ACDelco #214-1044) [КРЫШКА] 12572886 RAIL, F/INJN FUEL (INCLS 5, 9) (ACDelco #217-1551) [МАГИСТРАЛЬ ТОПЛИВНЫХ ФОРСУНОК ДВИГАТЕЛЯ] 11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (F/INJN FUEL RL) [БОЛТ] 12571159 INJECTOR, M/PORT FUEL (INCLS 8, 11) (ACDelco #217-1552) [ИНЖЕКТОР] 12576479 SEAL KIT, M/PORT F/INJR (INCLS 8, 11) (ACDelco #217-1541) [КОМПЛЕКТ ПРОКЛАДОК ИНЖЕКТОРНОЙ ФОРСУНКИ (2 ШТ] 12584592 VALVE KIT, FUEL PRESS SERV (INCLS 4, 5) (INCLUDES CAP AND VALVE) (ACDelco #12584592) [КЛАПАН] 12584591 RETAINER KIT, F/INJR (INCLS 9) (ACDelco #12584591) [ОПОРНАЯ ПЛАСТИНА ТОПЛИВНОЙ ФОРСУНКИ] 04 - АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ↓ (6D04-023) - 2004-2009 E СТОЯНОЧНЫЙ ТОРМОЗ ASM ↓ 88951984 PLATE, RR PARK BRK ANC BKG (4.591) 88951985 PLATE, RR PARK BRK ANC BKG (4.591) 88951982 ACTUATOR KIT, RR PARK BRK (INCLS 2) (ACDelco #179-2053) [АКТУАТОР] 88951983 ACTUATOR KIT, RR PARK BRK (INCLS 2) (ACDelco #179-2054) [АКТУАТОР] teamcadillac.ru 89047676 SHOE KIT, RR PARK BRK (INCLS 5) (ACDelco #171-0915) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (2 ШТ)] (6D04-031) - 2004-2009 E ТОРМОЗНОЙ СУППОРТ-ЗАДНИЙ ↓ 89047677 CALIPER KIT, RR BRK (INCLS 2, 3, 7-9) (ACDelco #172-2343) 89047678 CALIPER KIT, RR BRK (INCLS 2, 3, 7-9) (ACDelco #172-2344) [ТОРМОЗНОЙ СУППОРТ] 88951992 CAP, RR BRK BLEDR VLV (ЧАСТЬ OF 1) 88951991 VALVE, RR BRK CLPR BLEDR (ЧАСТЬ OF 1) 89047757 PAD KIT, RR DISC BRK (INCLS 4, 12) (ACDelco #171-859) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4 ШТ)] 89047758 PAD KIT, RR DISC BRK (INCLS 4, 12) (4.667) (ACDelco #171-0906) [ТОРМОЗНЫЕ КОЛОДКИ] 88957163 BRACKET, RR BRK CLPR [СКОБА ТОРМОЗНОГО СУППОРТА] 89047759 PIN KIT, RR BRK CLPR GDE (INCLS 4-6) (INCLS 2 PINS, 2 SEALS & 2 (2.75") БОЛТS) (ACDelco #179-2044) [НАПРАВЛЯЮЩАЯ ТОРМОЗНОГО СУППОРТА (2 ШТ)] 88957162 REPAIR KIT, RR BRK CLPR HYD (INCLS 4, 6, 8, 9) (6D04-033) - 2004-2009 E ТОРМОЗНОЙ УСИЛИТЕЛЬ ↓ 88967237 BOOSTER, P/B (W/O VLV) (ACDelco #178-0695) 05461808 GROMMET, P/B BOOS VAC CHK VLV (*KIT1) 03817880 RETAINER, BRK PED PUSH ROD (0.80 IN) (PUSH IN) 18022219 VALVE KIT, P/B BOOS VAC CHK (INCLS 2, 3) (BLACK) (INCLS VLV & GROM) (ACDelco #179-1266) (6E00-010) - 2004-2005 E ТРАНСМИССИЯ TO КРЕПЛЕНИЕ ДВИГАТЕЛЯ (LH2/4.6A) ↓ 12580474 FLYКОЛЕСО, ENG (INCLS 10) [МАХОВИК ДВИГАТЕЛЯ] 25771275 BRACKET, ENG WRG HARN (USED IN GENERATOR PACKAGE) 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] 24205900 COVER, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] 12561075 БОЛТ, FLYWHL 12568122 COVER, FLYWHL HSG 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (TRANS CONV CVR) (ACDelco #11517518) [БОЛТ] 12568123 COVER, TRANS CONV teamcadillac.ru 01647172 SPACER, FLYWHL (ЧАСТЬ OF 1) (6E00-014) - 2004-2009 E ТРАНСМИССИЯ TO КРЕПЛЕНИЕ ДВИГАТЕЛЯ (LY7/3.6-7) ↓ 12572042 PLATE, A/TRNS FLEX 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (TRANS CVR) [БОЛТ] 24222918 COVER, TRANS CONV teamcadillac.ru 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] (6E04-003) - 2004-2006 E УПРАВЛЕНИЕ АКПП/АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22,M82) ↓ 88967336 KNOB PKG, A/TRNS CONT LVR (INCLS 2, 13) (EBONY/BURL WALNUT) 88967337 KNOB PKG, A/TRNS CONT LVR (INCLS 2, 13) (EBONY LEATHER) 88967339 БОЛТ, A/TRNS CONT LVR KNOB (ЧАСТЬ OF 1) 25772994 PLATE, F/FLR CNSL TRANS SHFT OPG TR (INCLS TRAC CONT SWITCH) 25772995 PLATE, F/FLR CNSL TRANS SHFT OPG TR (WALNUT BURL) (INCLS TRAC CNTRL SW) [ПОДДОН] 88967342 BASE, A/TRNS CONT (INCLS 4, 6, 7) (4.010) 88967347 SOLENOID, A/TRNS SHFT LK CONT (ЧАСТЬ OF 5) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (A/TRNS RANGE SEL ROD ADJ) 15245220 LINK, A/TRNS RANGE SEL LVR (W/ADJUSTER SLEEVE) (FOR 1ST DES SEE 25756336) [ШАРНИР,КУЛИСА] 25756336 LINK, A/TRNS RANGE SEL LVR (NON-ADJUSTABLE) (FOR 2ND DES SEE 15245220) [ШАРНИР, КУЛИСА] 11519095 NUT-ACORN HEX, M8X1.0, 15MM THK, 9, 6047M, W/DOME. (A/TRNS RANGE SEL LVR) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL LVR CBL BRKT) [ГАЙКА М6] 88967341 BULB, A/TRNS CONT POSN IND (INCLS BULB W/BLUE COVER) (4.020) (ACDelco #88967341) [ЛАМПОЧКА ФАРЫ] teamcadillac.ru 88967340 COVER, A/TRNS CONT LVR HDL (ЧАСТЬ OF 1) (6E04-004) - 2004-2006 E УПРАВЛЕНИЕ АКПП/АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3,MX5) ↓ 88967336 KNOB PKG, A/TRNS CONT LVR (INCLS 2, 13) (EBONY/BURL WALNUT) 88967337 KNOB PKG, A/TRNS CONT LVR (INCLS 2, 13) (EBONY LEATHER) 88967339 БОЛТ, A/TRNS CONT LVR KNOB (ЧАСТЬ OF 1) 25772994 PLATE, F/FLR CNSL TRANS SHFT OPG TR (INCLS TRAC CONT SWITCH) 25772995 PLATE, F/FLR CNSL TRANS SHFT OPG TR (WALNUT BURL) (INCLS TRAC CNTRL SW) [ПОДДОН] 19167127 BEZEL, A/TRNS CONT HSG (W/SHIF LOCK SOLENOID COV) 88967343 BASE, A/TRNS CONT (4.010) [БЛОК] 88967347 SOLENOID, A/TRNS SHFT LK CONT 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (A/TRNS RANGE SEL ROD ADJ) 15245219 LINK, A/TRNS RANGE SEL LVR (W/ADJUSTER SLEEVE) (FOR 1ST DES SEE 25756335) teamcadillac.ru 25756335 LINK, A/TRNS RANGE SEL LVR (NON-ADJUSTABLE) (FOR 2ND DES SEE 15245219) [РЫЧАГ В СБОРЕ] 11519095 NUT-ACORN HEX, M8X1.0, 15MM THK, 9, 6047M, W/DOME. (A/TRNS RANGE SEL LVR) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL LVR CBL BRKT) [ГАЙКА М6] 88967341 BULB, A/TRNS CONT POSN IND (INCLS BULB W/BLUE COVER) (4.020) (ACDelco #88967341) [ЛАМПОЧКА ФАРЫ] 88967340 COVER, A/TRNS CONT LVR HDL (ЧАСТЬ OF 1) (6E04-005) - 2004-2005 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (EXC V92)(WITH THERMAL BYPASS VALVE)(1ST DES) ↓ 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 89022494 BRACKET, TRANS FLUID CLR 11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16] 11515792 БОЛТ, HFH, M8X1.25X40, 22THD, 18 O.D., MAC-PT, 10.9, 7112M (TRANS FLUID CLR PIPE CONN) 24221232 VALVE, TRANS FLUID CLR THERMAL BYPASS (INCLS 5) [КЛАПАН ЖИДКОСТИ ТРАНСМИССИОННОЙ] 19130214 SEAL, TRANS FLUID CLR HOSE CONN (O RING) 19129779 HOSE, TRANS FLUID CLR LWR (W/BLOCK) (BUILT W/OR AFTER VIN 1GYEE63A750180934 USE T/W 19129780 , 11515757 & REMOVE THERM BYPASS VLV.) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 19129781 HOSE, TRANS FLUID CLR LWR (W/BLOCK) 89022495 HOSE, TRANS FLUID CLR LWR 88957425 COOLER, TRANS FLUID (INCLS 9-13) (ACDelco #88957425) [ВЕНТИЛЯТОР] teamcadillac.ru 19129780 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) (USE ON CARS BUILT W/OR AFTER VIN 1GYEE63A750180934) (FOR CARS BUILT PRIOR TO VIN REPL T/W 19129779 , 11515757 & REMOVE THERM BYPASS VLV.) [ТРУБКА] 19129782 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) (USE ON CARS BUILT W/OR AFTER VIN 1GYEE637150180965) (FOR CARS BUILT PRIOR TO VIN REPL T/W 19129781 , 11515757 & REMOVE THERM BYPASS VLV.) [ТРУБКА МАСЛООХЛАДИТЕЛЯ] 89022496 HOSE, TRANS FLUID CLR UPR (6E04-006) - 2004-2005 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (V92)(WITH THERMAL BYPASS VALVE)(1ST DES) ↓ 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 89022494 BRACKET, TRANS FLUID CLR 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 11515792 БОЛТ, HFH, M8X1.25X40, 22THD, 18 O.D., MAC-PT, 10.9, 7112M (TRANS FLUID CLR PIPE CONN) 24221232 VALVE, TRANS FLUID CLR THERMAL BYPASS (INCLS 5) [КЛАПАН ЖИДКОСТИ ТРАНСМИССИОННОЙ] 19130214 SEAL, TRANS FLUID CLR HOSE CONN (O RING) teamcadillac.ru 19129779 HOSE, TRANS FLUID CLR LWR (INCLS BLOCK) (W/BLOCK) (BUILT W/OR AFTER VIN 1GYEE63A750180934 USE T/W 19129780 , 11515757 & REMOVE THERM BYPASS VLV.) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 19129781 HOSE, TRANS FLUID CLR LWR (INCLS BLOCK) (W/BLOCK) 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR) (ACDelco #11570082) [БОЛТ М8] 89022522 COOLER, TRANS FLUID (INCLS 9-11) 19129780 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) (USE ON CARS BUILT W/OR AFTER VIN 1GYEE63A750180934) (FOR CARS BUILT PRIOR TO VIN REPL T/W 19129779 , 11515757 & REMOVE THERM BYPASS VLV.) [ТРУБКА] 19129782 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) (USE ON CARS BUILT W/OR AFTER VIN 1GYEE637150180965) (FOR CARS BUILT PRIOR TO VIN REPL T/W 19129781 , 11515757 & REMOVE THERM BYPASS VLV.) [ТРУБКА МАСЛООХЛАДИТЕЛЯ] (6E04-007) - 2004-2006 E ТОРМОЗНЫЕ ШЛАНГИ И ТРУБКИ ↓ 15933099 HOSE, FRT BRK (INCLS 15, 16) (ACDelco #176-1495) 11569742 RETAINER, FRT BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (BRK & FUEL FEED & FUEL RTN & EVAP EMIS) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА] teamcadillac.ru 25761218 BRACKET, FUEL PIPE 25761217 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (3.162) 12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (FRT BRK) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА] 10388788 PIPE, BRK PRESS MOD VLV FRT (INCLS 29) 10388794 PIPE, BRK PRESS MOD VLV RR (INCLS 29) 25763163 PIPE, BRK PRESS MOD VLV RR (9/16" FITTING AT EACH END. FOR 2ND DESIGN SEE 10388794.) (INCLS 29) 03541444 SPACER, FRT BRK PIPE 11516521 БОЛТ, HFH M6X1X20, 9.8, 7114M, DOG PT, 14.2 OD (FRT BRK HOSE) 15933098 HOSE, FRT BRK (INCLS 15, 16) (ACDelco #176-1487) 25743891 RETAINER, RR BRK FRT PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT) 15724653 FITTING, FRT BRK PIPE (ЧАСТЬ OF 1, 12) (7/16-24 X .36) (.30 THD, .56 LENGTH, .194 TUBE, STL, GM7113M) 25743891 RETAINER, FRT BRK PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT) 25737279 CLIP, FRT BRK PIPE (THREE WAY RETAINER SINGLE CENTRAL FIR-TREE ATTACHMENT) 15270078 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (USES RETAINER PIN FOR ATTACHMENT) [ЗАЖИМ ТРУБКИ ТОПЛИВНОЙ СИСТЕМЫ] 25688547 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (RETAINER W/5 HOLES (2)7.95, (2)4.76, (1)9.52MM) 25749839 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (HOLDS 3 ТРУБКИ, FLAT SHAPE, SNAP-IN RETAINER) 25607191 RETAINER, BRK PIPE (21.5X10.0MM) (HOLDS (2) 4.68-4.82 TUBES) 11569742 RETAINER, RR BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 15724650 ГАЙКА, INVERTED FLARED TUBE, 9/16"-18, 1/4" TUBE, ZD (BRK PIPE) (4.686) [ГАЙКА] 25693890 RETAINER, RR BRK PIPE (HOLDS (1) 4.76 LINE) (W/TREE) [ЗАМОК, ФИКСАТОР] 11588803 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 7, 8) (1/2-20X.40, .32 THD) (INVERTED FLARED TUBE) (.62 LONG, 1/4 TUBE) [ГАЙКА М20] 15724650 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 7, 8) (9/16-18 X .40) (INVERTED FLARED TUBE) [ГАЙКА] 15933091 HOSE, RR BRK (INCLS 22, 23) (ACDelco #15933091) 15933092 HOSE, RR BRK (INCLS 22, 23) (ACDelco #15933092) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ] 88964150 PROTECTOR, FRT BRK PIPE (FOR 3/16" PIPE) (HT SHRINK) (6E04-008) - 2004-2006 E ТОРМОЗНАЯ ПЕДАЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (EXC (JF4)) ↓ 25732428 BARRIER, BRK PED BRKT SND 25697461 RETAINER, BRK PED PUSH ROD BOOT 25732452 BOOT, BRK PED PUSH ROD 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] teamcadillac.ru 15932827 HOSE, P/B BOOS VAC (ACDelco #176-1496) 25765419 PEDAL, BRK (W/BRKT) (INCLS 10, 11, 14, 16-18) 25771615 COVER, BRK PED (ЧАСТЬ OF 9) 89047699 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 9) [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 9) 10434956 BUSHING, BRK PED PUSH ROD 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 9) 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 9) (0.80 IN) (PUSH IN) (6E04-010) - 2004-2006 E СТОЯНОЧНЫЙ ТОРМОЗ SYSTEM ↓ teamcadillac.ru 10395687 LEVER, PARK BRK (INCLS 2-4, 13-15) 15797212 CABLE, PARK BRK INTER (INCLS 5, 10, 11) (ACDelco #15797212) [ТРОС СТОЯНОЧНОГО ТОРМОЗА В СБОРЕ] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (PARK BRK INTER CBL GDE) [ГАЙКА М6] 11517484 БОЛТ-HEX, M6X1X20, 9 THD, 17 OD, 9.8, 6280M, MACH, P-PT (PARK BRK INTER CBL GDE) 25764260 CABLE, PARK BRK RR (28.2X28.5X811.7MM) (ACDelco #25764260) [ТРОС СТОЯНОЧНОГО ТОРМОЗА] 25880964 HANDLE, PARK BRK REL 89047821 CABLE, PARK BRK REL (ЧАСТЬ OF 1) (ACDelco #89047821) 22654577 SWITCH, PARK BRK IND (ЧАСТЬ OF 1) (ACDelco #22654577) [ВКЛЮЧАТЕЛЬ] (6E04-011) - 2004-2006 E T.C.M. МОДУЛЬ ↓ 24240284 МОДУЛЬ, TRANS CONT [МОДУЛЬ] teamcadillac.ru 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (MULTIUSE RLY & FUSE BRKT) [БОЛТ М6] (6E04-012) - 2004-2006 E КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS(MV3) ↓ 88996677 CASE, TRFER (FRT HALF) (INCLS 12-14) teamcadillac.ru 19133265 CASE, TRFER (RR HALF) (INCLS 5, 7) 88996679 SNUBBER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN 88996680 БОЛТ, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN SNBR (M5X0.8X16) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 2) 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL FILL) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996657 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 2) [УПЛОТНИТЕЛЬ] 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL DRN) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996680 БОЛТ, TRFER CASE VENT BFL (M5X0.8X16) (4.535) 88996658 BAFFLE, TRFER CASE VENT 89048123 БОЛТ, TRFER CASE HALF (M8X1.25X30) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 1) 88996656 SEAL, TRFER CASE INPUT SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 88996657 SEAL, TRFER CASE FRT ВЫХОДНОЙ SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] (6E04-014) - 2004-2005 E КОРПУС КП КРЕПЛЕНИЕ (MV3,MX5) ↓ teamcadillac.ru 11519347 БОЛТ, TRFER CASE (M10X1.5X65) (8.900) [БОЛТ] (6E04-016) - 2004-2009 E КЛАПАН РЕГУЛИРОВКИ ДАВЛЕНИЯ В ТОРМОЗНОЙ СИСТЕМЕ ↓ 89060339 МОДУЛЬ KIT, ELEK BRK & TRACT CONT (REQS PROGRAMMING;BRK APPLY SEN REQS CALN;REFER TO SERV INFO) (ACDelco #89060339) [БЛОК УПРАВЛЕНИЯ ТОРМОЗНОЙ СИСТЕМОЙ] 89060233 VALVE KIT, BRK PRESS MOD (INCLS 3, 4) (ACDelco #89060233) [ГИДРАВЛИЧЕСКИЙ БЛОК АБС] teamcadillac.ru 25743362 SENSOR, BRK PRESS MOD VLV PRESS (ЧАСТЬ OF 2) (ACDelco #25743362) [ДАТЧИК] 25741456 INSULATOR, BRK PRESS MOD VLV (ЧАСТЬ OF 2) 11588304 STUD, FLANGE DOUBLE END, M8X14 UNTHD, M8X1.25X13, 17 OD, 5.8, GM4345M (BRK PRESS MOD VLV BRKT) 11514596 ГАЙКА, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (BRK PRESS MOD VLV BRKT) (8.915) (ACDelco #11514596) 11508351 SCREW, PAN HD, C/R, 5X0.8X13, 9.3 OD, FULL THD, THD RLLR, 6171M, PC (BRK PRESS MOD VLV) (8.977) (6E04-017) - 2004-2006 E ШЛАНГ ВЕНТИЛЯЦИИ ТРАНСМИССИИ ↓ 25764835 VENT, A/TRNS (INCLS 2, 3) (ACDelco #25764835) 25765121 VENT, A/TRNS (INCLS 2, 3) (ACDelco #25765121) teamcadillac.ru 15955072 CLIP, TRANS VENT HOSE (ЧАСТЬ OF 1) (.650MM DIA) (2.343) (6E04-018) - 2004-2009 E КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS(MX5) ↓ 88996677 CASE, TRFER (FRT HALF) (INCLS 12-14) 19133265 CASE, TRFER (RR HALF) (INCLS 5, 7) 88996679 SNUBBER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN 88996680 БОЛТ, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN SNBR (M5X0.8X16) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 2) 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL FILL) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996657 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 2) [УПЛОТНИТЕЛЬ] 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL DRN) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996680 БОЛТ, TRFER CASE VENT BFL (M5X0.8X16) (4.535) 88996658 BAFFLE, TRFER CASE VENT 89048123 БОЛТ, TRFER CASE HALF (M8X1.25X30) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 1) 88996656 SEAL, TRFER CASE INPUT SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 88996657 SEAL, TRFER CASE FRT ВЫХОДНОЙ SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] teamcadillac.ru 19180066 VENT, TRFER CASE 89048123 БОЛТ, TRFER CASE VIB DPNR (M8X1.25X30) 89048182 DAMPENER, TRFER CASE VIB (6E04-021) - 2005 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (EXC V92)(WITHOUT THERMAL BYPASS VALVE)(2ND DES) ↓ 11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16] 89022494 BRACKET, TRANS FLUID CLR 19129780 HOSE, TRANS FLUID CLR UPR (USE ON CARS BUILT W/OR AFTER VIN 1GYEE63A750180934. USE ON CARS BUILT PRIOR TO VIN 1GYEE63A750180934 REPL T/W 19129779 & REMOVE THERM BYPASS VLV.) (W/O BLOCK) [ТРУБКА] 19129782 HOSE, TRANS FLUID CLR UPR (USE ON CARS BUILT W/OR AFTER VIN 1GYEE637150180965. USE ON CARS BUILT PRIOR TO VIN 1GYEE637150180965 REPL T/W 19129781 & REMOVE THERM BYPASS VLV.) (W/O BLOCK) [ТРУБКА МАСЛООХЛАДИТЕЛЯ] 19130214 SEAL, TRANS FLUID CLR HOSE CONN (O RING) 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 19129779 HOSE, TRANS FLUID CLR LWR (USE ON CARS BUILT W/OR AFTER VIN 1GYEE63A750180934. USE ON CARS BUILT PRIOR TO VIN 1GYEE63A750180934 REPL T/W 19129780 & REMOVE THERM BYPASS VLV.) (W/BLOCK) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 19129781 HOSE, TRANS FLUID CLR LWR (USE ON CARS BUILT W/OR AFTER VIN 1GYEE637150180965. USE ON CARS BUILT PRIOR TO VIN 1GYEE637150180965 REPL T/W 19129782 & REMOVE THERM BYPASS VLV.) (W/BLOCK) teamcadillac.ru 88957425 COOLER, TRANS FLUID (INCLS 7-11) (ACDelco #88957425) [ВЕНТИЛЯТОР] (6E04-022) - 2005 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (V92)(WITHOUT THERMAL BYPASS VALVE)(2ND DES) ↓ 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 89022494 BRACKET, TRANS FLUID CLR 19129780 HOSE, TRANS FLUID CLR UPR (USE ON CARS BUILT W/OR AFTER VIN 1GYEE63A750180934. USE ON CARS BUILT PRIOR TO VIN 1GYEE63A750180934 REPL T/W 19129779 & REMOVE THERM BYPASS VLV.) (W/O BLOCK) [ТРУБКА] 19129782 HOSE, TRANS FLUID CLR UPR (USE ON CARS BUILT W/OR AFTER VIN 1GYEE637150180965. USE ON CARS BUILT PRIOR TO VIN 1GYEE637150180965 REPL T/W 19129781 & REMOVE THERM BYPASS VLV.) (W/O BLOCK) [ТРУБКА МАСЛООХЛАДИТЕЛЯ] 19130214 SEAL, TRANS FLUID CLR HOSE CONN (O RING) 19129779 HOSE, TRANS FLUID CLR LWR (USE ON CARS BUILT W/OR AFTER VIN 1GYEE63A750180934. USE ON CARS BUILT PRIOR TO VIN 1GYEE63A750180934 REPL T/W 19129780 & REMOVE THERM BYPASS VLV.) (W/BLOCK) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 19129781 HOSE, TRANS FLUID CLR LWR (USE ON CARS BUILT W/OR AFTER VIN 1GYEE637150180965. USE ON CARS BUILT PRIOR TO VIN 1GYEE637150180965 REPL T/W 19129782 & REMOVE THERM BYPASS VLV.) (W/BLOCK) 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] teamcadillac.ru 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR) (ACDelco #11570082) [БОЛТ М8] 89022522 COOLER, TRANS FLUID (INCLS 7-9) (6E04-035) - 2005-2009 E BRAKE SYSTEM/ANTILOCK ↓ teamcadillac.ru 12413103 HUB, FRT WHL (W/BRG) (СМ. ГРУППУ 06.000 "ПОДВЕСКА-ПЕРЕДНЯЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/WHL SPD SEN) (ACDelco #FW149) [СТУПИЦА КОЛЕСА] 12413105 HUB, FRT WHL (W/BRG) (СМ. ГРУППУ 06.000 "ПОДВЕСКА-ПЕРЕДНЯЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPEED SENSOR) (ACDelco #FW150) [СТУПИЦА КОЛЕСА] 89047639 HUB, RR WHL (W/WHL SPD SEN) (СМ. ГРУППУ 06.000 "ЗАДНЯЯ ПОДВЕСКА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6 STUD HUB) (ACDelco #RW20-19) [СТУПИЦА КОЛЕСА] 10307709 SENSOR, VEH YAW (W/VEH LATL ACCLRM) [ДАТЧИК] 15906579 SENSOR, VEH YAW (W/ VEH LATL & LGTDNL ACCLRM) [ДАТЧИК] 11561645 ГАЙКА, HFH, M6X1X6.45, 13.5 OD, 10 STL, GMW3200 (VEH YAW SEN & LATL ACCLRM) (6E04-036) - 2005-2006 E ТОРМОЗНАЯ ПЕДАЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (JF4) ↓ 25732428 BARRIER, BRK PED BRKT SND 25697461 RETAINER, BRK PED PUSH ROD BOOT 25732452 BOOT, BRK PED PUSH ROD 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] 15932827 HOSE, P/B BOOS VAC (ACDelco #176-1496) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (ACCEL PED LVR) 10368488 PEDAL, BRK (INCLS 12, 13, 15, 18-22) 25771615 COVER, BRK PED (ЧАСТЬ OF 11) 89047699 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 11) (INCLS 18) [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] teamcadillac.ru 89047780 MOTOR KIT, BRK & ACCEL PED ADJR ACTR [ЭЛЕКТРОДВИГАТЕЛЬ ПЕДАЛЬНОГО УЗЛА 19 ВТ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 11, 13) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 11) 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 11) 25697461 RETAINER, BRK PED PUSH ROD BOOT (ЧАСТЬ OF 11) 89047779 CABLE, ACCEL CONT 89047778 CABLE, BRK PED ADJR ACTR [ЖГУТ ПРОВОДОВ] 25741052 BRACKET, BRK PED BRKT 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-018) - 2004-2006 E КОРПУС КП ЧАСТЬ 2 INTERNAL COMPONENTS(MV3) ↓ 88984517 WASHER, TRFER CASE PLNT CARR SUN GR THR (25.8X52.0X2.2) 88984524 GEAR, TRFER CASE PLNT CARR SUN (INPUT) (STAMPED PM/POWDERED METAL) 88984493 RING, TRFER CASE RR ВЫХОДНОЙ SHF RR BRG RET (41MM I.D.) (ACDelco #88984493) 88996564 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT 88996665 BEARING, TRFER CASE MAIN SHF FRT (ВЫХОДНОЙ ВАЛ FRT) 19168733 BUSHING, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 106) [ВТУЛКА РАЗДАТОЧНОЙ КОРОБКИ] 19178237 SHAFT, TRFER CASE RR ВЫХОДНОЙ (INCLS 105, 901) 19133264 SPROCKET, TRFER CASE FRT ВЫХОДНОЙ SHF DRV (INCLS 108) [ШЕСТЕРНЯ РАЗДАТОЧНОЙ КОРОБКИ] 19168732 BUSHING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT (ЧАСТЬ OF 107) (ACDelco #19168732) 89059578 CHAIN, TRFER CASE TWO/FOUR WHL DRV [ЦЕПЬ РАЗДАТОЧНОЙ КОРОБКИ] 88984523 GEAR, TRFER CASE PLNT CARR SUN (ВЫХОДНОЙ) 89059279 КРОНШТЕЙН, TRFER CASE PLNT 89059284 SHAFT, TRFER CASE FRT ВЫХОДНОЙ (INCLS 900) 88996664 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF RR 88996671 RING, TRFER CASE FRT ВЫХОДНОЙ SHF BRG RET 88996666 SPROCKET, TRFER CASE TWO/FOUR WHL DRV DRVN [ЗВЕЗДОЧКА] 88996633 BEARING, TRFER CASE RR ВЫХОДНОЙ SHF RR (ACDelco #88996633) [ПОДШИПНИК РАЗДАТОЧНОЙ КОРОБКИ] 15580230 BEARING, TRFER CASE INPUT SHF (BORG-WARNER) (4.510) 19132966 SHAFT, TRFER CASE INPUT teamcadillac.ru 88996681 DEFLECTOR, TRFER CASE FRT ВЫХОДНОЙ SHF SEAL DIRT (ЧАСТЬ OF 112) (6M04-041) - 2004-2006 E26 ТОРМОЗНАЯ ПЕДАЛЬ (PWR ADJ PEDALS JF4) ↓ 25741052 BRACKET, BRK PED BRKT 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 25732428 BARRIER, BRK PED BRKT SND 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 89047778 CABLE, BRK PED ADJR ACTR [ЖГУТ ПРОВОДОВ] 89047780 MOTOR KIT, BRK & ACCEL PED ADJR ACTR [ЭЛЕКТРОДВИГАТЕЛЬ ПЕДАЛЬНОГО УЗЛА 19 ВТ] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (BRK PED POSN SEN) 89047699 SENSOR KIT, BRK PED POSN [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 25697461 RETAINER, BRK PED PUSH ROD BOOT (ЧАСТЬ OF 21) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 21) 10368488 PEDAL, BRK (INCLS 5, 8-10, 13, 15-20, 22) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-042) - 2004-2006 E26 ТОРМОЗНАЯ ПЕДАЛЬ (EXC PWR ADJ PEDALS JF4) ↓ 25741052 BRACKET, BRK PED BRKT 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 25732428 BARRIER, BRK PED BRKT SND 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 18) 89047699 SENSOR KIT, BRK PED POSN [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] teamcadillac.ru 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 18) (0.80 IN) (PUSH IN) 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 18) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 18) 25771615 COVER, BRK PED (ЧАСТЬ OF 18) 25765419 PEDAL, BRK (W/BRKT) (INCLS 5-8, 10, 12-17, 19) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-044) - 2004-2009 E26 ТОРМОЗНОЙ УСИЛИТЕЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА ↓ 88967237 BOOSTER, P/B (СМ. ГРУППУ 04.000 "ТОРМОЗНОЙ УСИЛИТЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/O VLV) (ACDelco #178-0695) 25732452 BOOT, BRK PED PUSH ROD 25697461 RETAINER, BRK PED PUSH ROD BOOT 10367561 CYLINDER, BRK MAS (СМ. ГРУППУ 4.000 "ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #174-1012) [ЦИЛИНДР] 11609949 ГАЙКА, BRK M/CYL (M10X1.5, 11.2 THK) (8.917) [ГАЙКА] 25873484 HOSE, P/B BOOS VAC (ACDelco #176-1497) (GM04-064) - 2004-2009 E ТОРМОЗНОЙ СУППОРТ-ПЕРЕДНИЙ ↓ 18047980 CALIPER, FRT BRK (INCLS 2-4, 8-10) (IF DISCONTINUED USE DURASTOP EQUIVALENT) (4.667) (ACDelco #172-1643) [ТОРМОЗНОЙ СУППОРТ] 18047981 CALIPER, FRT BRK (INCLS 2-4, 8-10) (IF DISCONTINUED USE DURASTOP EQUIVALENT) (4.667) (ACDelco #172-1644) [ТОРМОЗНОЙ СУППОРТ] 18043178 COVER, FRT BRK BLEDR SCREW (ЧАСТЬ OF 1) 18047986 VALVE KIT, FRT BRK CLPR BLEDR (ЧАСТЬ OF 1) (ACDelco #18047986) 18046750 БОЛТ, FRT BRK CLPR GDE PIN (ЧАСТЬ OF 1, 11) (*KIT2) [БОЛТ] 18047985 PISTON KIT, FRT BRK CLPR (ЧАСТЬ OF 1) 18047988 PAD KIT, FRT DISC BRK (INCLS 4, 14) (ACDelco #171-665) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4 ШТ)] 19122384 PAD KIT, FRT DISC BRK (INCLS 4, 14) (ACDelco #171-688) 18045221 SEAL, FRT BRK CLPR GDE PIN 18047987 BRACKET, FRT BRK CLPR (W/GUIDE PIN БОЛТS) [КРОНШТЕЙН] 18046698 ПРУЖИНА, FRT DISC BRK PAD RET (ЧАСТЬ OF 11) (ACDelco #179-2235) 18047989 PIN KIT, FRT BRK CLPR GDE (INCLS 5-7) (INCLS 2 (2.5") БОЛТS) 18047984 CALIPER KIT, FRT BRK (INCLS 4, 8, 9) (4.667) (ACDelco #173-0538) (GM04-312) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (5L50-E M22,5L40-E M82) ↓ teamcadillac.ru 96042884 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 5GDZ) 96042897 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 5GRG) (GM04-376) - 2004-2009 E ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР ↓ 18012741 SWITCH, BRK FLUID LVL IND (ЧАСТЬ OF 15) (ACDelco #18012741) 22688449 CAP, BRK M/CYL RSVR (ЧАСТЬ OF 15) (INCLS 3) [КРЫШКА БАЧКА ТОРМОЗНОЙ ЖИДКОСТИ] 18046711 RESERVOIR, BRK M/CYL (ЧАСТЬ OF 15) (INCLS 4, 6-7) (ACDelco #18046711) teamcadillac.ru 18060168 PISTON, BRK M/CYL SECD (ЧАСТЬ OF 15) 10367561 CYLINDER, BRK MAS (INCLS 1-14) (ACDelco #174-1012) [ЦИЛИНДР] 18022002 CYLINDER KIT, BRK MAS (INCLS 8-12) (ACDelco #175-424) (GM04-485) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (5L50-E MV3,5L40-E MX5) ↓ 96042890 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 5GGG) [АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ В СБОРЕ] teamcadillac.ru 96042893 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 5GFZ) [ТРАНСМИССИЯ В СБОРЕ] (GM04-573) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042497 GASKET, A/TRNS CASE EXTN [ПРОКЛАДКА ТРАНСФОРМАТОРНОЙ КОРОБКИ] 96042882 EXTENSION, A/TRNS CASE (INCLS 26, 28, 29) (4.003) 96041851 SEAL, PROP SHF TRANS FLG FLUID (ЧАСТЬ OF 27) [ПРОКЛАДКА ТРАНСФОРМАТОРНОГО ВАЛА] 96042585 FLANGE, ВЫХОДНОЙ SHF [ФЛАНЕЦ] 96041805 NUT KIT, ВЫХОДНОЙ SHFT (INCLS 30, 32, 33) (M6X1.0X16) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) teamcadillac.ru 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96042962 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) 96042712 DETENT, MAN SHFT 96017928 CLIP, WRG HARN 96042847 HARNESS, A/TRNS WRG 96041849 SEAL, A/TRNS WRG CONN (O RING) 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) (GM04-573) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042497 GASKET, A/TRNS CASE EXTN (*KIT1) [ПРОКЛАДКА ТРАНСФОРМАТОРНОЙ КОРОБКИ] 96042496 EXTENSION, A/TRNS CASE (INCLS 26, 28, 29) 96041851 SEAL, PROP SHF TRANS FLG FLUID (ЧАСТЬ OF 27) (*KIT1) [ПРОКЛАДКА ТРАНСФОРМАТОРНОГО ВАЛА] 96042585 FLANGE, ВЫХОДНОЙ SHF [ФЛАНЕЦ] 96041805 NUT KIT, ВЫХОДНОЙ SHFT (INCLS 30, 32, 33) (M6X1.0X16) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) (*KIT1) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) (*KIT1) 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) teamcadillac.ru 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96042963 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPACER PLATE & GASKET) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) 96042712 DETENT, MAN SHFT 96017928 CLIP, WRG HARN 96042847 HARNESS, A/TRNS WRG 96041849 SEAL, A/TRNS WRG CONN (O RING) (*KIT1) 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN (*KIT1) [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (*KIT1) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (*KIT1) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) 96042945 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/GSKT, SEAL, RET) (INCLS 25, 29, 36, 38, 46, 56, 60, 63, 64) (GM04-574) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042887 GASKET, A/TRNS CASE EXTN [ПРОКЛАДКА КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042563 EXTENSION, A/TRNS CASE (INCLS 28, 69) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96042962 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) 96042712 DETENT, MAN SHFT 96017928 CLIP, WRG HARN 96042847 HARNESS, A/TRNS WRG 96041849 SEAL, A/TRNS WRG CONN (O RING) 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (1.453) teamcadillac.ru 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) 96042543 WASHER, INPUT & REACTION CARR THR 96042587 SEAL, PROP SHF TRANS FLG FLUID [ПРОКЛАДКА КРЫШКИ РАЗДАТОЧНОЙ КОРОБКИ] (GM04-574) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042887 GASKET, A/TRNS CASE EXTN [ПРОКЛАДКА КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042888 EXTENSION, A/TRNS CASE (INCLS 28, 69) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPACER PLATE & GASKET) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) 96042712 DETENT, MAN SHFT 96017928 CLIP, WRG HARN 96042847 HARNESS, A/TRNS WRG 96041849 SEAL, A/TRNS WRG CONN (O RING) 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) 96042543 WASHER, INPUT & REACTION CARR THR 96042587 SEAL, PROP SHF TRANS FLG FLUID [ПРОКЛАДКА КРЫШКИ РАЗДАТОЧНОЙ КОРОБКИ] 08677884 BEARING, ВЫХОДНОЙ SHF THR (ЧАСТЬ OF 27) (4.180) (ACDelco #8677884) (GM04-575) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ 96042553 CONVERTER, TORQ (REMAN) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042835 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) 96042806 СЦЕПЛЕНИЕ, DIR & REV 96042831 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) 96042823 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) 96042824 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) teamcadillac.ru 96042701 WASHER, INPUT & REACTION CARR INR SHF THR 96042808 ШЛАНГИ, O/D CLU 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) 96042705 BEARING, CTR SUPT RLR (4.180) 96042826 SUPPORT, CTR 96042832 КРОНШТЕЙН, INPUT & REACTION 96042833 BEARING, INPUT & REACTION CARR THR 96042834 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) 96042543 WASHER, INPUT & REACTION CARR THR 96042833 BEARING, INPUT & REACTION CARR THR 96042883 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/GSKT, SEAL, RET) (GM04-575) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ 96042554 CONVERTER, TORQ (REMAN) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042812 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) 96042806 СЦЕПЛЕНИЕ, DIR & REV (СМ. ГРУППУ 04.000 "DIRECT AND REVERSE СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042807 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (СМ. ГРУППУ 04.000 "FORWARD AND COAST СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042698 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) (СМ. ГРУППУ 04.000 "INPUT SUN GEAR SHAFT AND FORWARD SPRAG СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (СМ. ГРУППУ 04.000 "DIRECT СЦЕПЛЕНИЕ DRUM AND SHAFT" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042701 WASHER, INPUT & REACTION CARR INR SHF THR 96042808 ШЛАНГИ, O/D CLU (СМ. ГРУППУ 04.000 "OVERDRIVE AND INTERMEDIATE СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (СМ. ГРУППУ 04.000 "LOW СЦЕПЛЕНИЕ SPRAG" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042705 BEARING, CTR SUPT RLR (4.180) teamcadillac.ru 96042809 SUPPORT, CTR (СМ. ГРУППУ 04.000 "CENTER SUPPORT" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042707 КРОНШТЕЙН, INPUT & REACTION (СМ. ГРУППУ 04.000 "PLANETARY КРОНШТЕЙН" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (4.176) 96042708 BEARING, INPUT & REACTION CARR THR 96042709 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (СМ. ГРУППУ 04.000 "ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96041847 WASHER, INPUT & REACTION CARR THR (4.265) (GM04-576) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ 96042553 CONVERTER, TORQ (REMAN) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042835 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) 96042814 СЦЕПЛЕНИЕ, DIR & REV 96042822 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) 96042823 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) teamcadillac.ru 96042824 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) 96042701 WASHER, INPUT & REACTION CARR INR SHF THR 96042808 ШЛАНГИ, O/D CLU 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) 96042826 SUPPORT, CTR 96042827 КРОНШТЕЙН, INPUT & REACTION 96042818 BEARING, INPUT & REACTION CARR THR 96042837 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) 96042543 WASHER, INPUT & REACTION CARR THR 96042818 BEARING, INPUT & REACTION CARR THR (GM04-576) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ 96042554 CONVERTER, TORQ (REMAN) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042812 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) teamcadillac.ru 96042814 СЦЕПЛЕНИЕ, DIR & REV 96042815 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) 96042698 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) (INCLS 9) 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) 96042701 WASHER, INPUT & REACTION CARR INR SHF THR 96042808 ШЛАНГИ, O/D CLU 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) 96042705 BEARING, CTR SUPT RLR (*KIT1) (4.180) 96042816 SUPPORT, CTR 96042817 КРОНШТЕЙН, INPUT & REACTION 96042818 BEARING, INPUT & REACTION CARR THR 96042813 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) 96042543 WASHER, INPUT & REACTION CARR THR 96042818 BEARING, INPUT & REACTION CARR THR (GM04-577) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ teamcadillac.ru 96041855 SEAL, T/CV FLUID [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042835 ШЛАНГИ KIT, T/CV (INCLS 200-212, 214-215, 217-220, 223, 226, 227, 231-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-577) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ 96041855 SEAL, T/CV FLUID (*KIT1) [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] teamcadillac.ru 96042835 ШЛАНГИ KIT, T/CV (INCLS 200-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-577) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ teamcadillac.ru 96041855 SEAL, T/CV FLUID [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042812 ШЛАНГИ KIT, T/CV (INCLS 200-215, 217-220, 223, 226-228, 231-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-577) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ teamcadillac.ru 96041855 SEAL, T/CV FLUID [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042812 ШЛАНГИ KIT, T/CV (INCLS 200-215, 217-220, 223, 226-228, 231-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-578) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 96042987 GASKET KIT, A/TRNS (INCLS 303, 305, 306, 308, 309, 312, 314, 316, 330, 332) (4.265) (GM04-578) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96042987 GASKET KIT, A/TRNS (INCLS 303, 305, 306, 308, 309, 312, 314, 316, 330, 332) (4.265) (GM04-578) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 300-309, 312-334) (INCLS SPACER PLATE & GASKET) (GM04-578) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 300-334) (INCLS SPACER PLATE & GASKET) (GM04-579) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96042599 VALVE, TCC PWM SOL 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] (GM04-579) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96042599 VALVE, TCC PWM SOL 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] (GM04-579) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96042599 VALVE, TCC PWM SOL 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 340-351, 353-356) (INCLS SPACER PLATE & GASKET) (GM04-579) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96042599 VALVE, TCC PWM SOL 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 340-348, 351, 353-354) (INCLS SPACER PLATE & GASKET) (GM04-580) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] teamcadillac.ru (GM04-580) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] teamcadillac.ru 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] (GM04-580) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 343, 349, 350, 365-367, 370-375, 377-388) (INCLS SPACER PLATE & GASKET) (GM04-580) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 343, 351, 365-367, 370-375, 377-388) (INCLS SPACER PLATE & GASKET) 96042889 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/PLT, GSKT, SEAL) (INCLS 343, 351, 365-367, 370-375, 377-388) (GM04-581) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru (GM04-581) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru 96042814 СЦЕПЛЕНИЕ, DIR & REV (INCLS 400-420) (GM04-581) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru 96042806 СЦЕПЛЕНИЕ, DIR & REV (INCLS 400-420) (GM04-581) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru 96042814 СЦЕПЛЕНИЕ, DIR & REV (INCLS 400-420) (GM04-582) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042831 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-432, 434-451) 96042883 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/GSKT, SEAL, RET) (GM04-582) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯLY ↓ teamcadillac.ru 96042822 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-451) (GM04-582) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96041856 SEAL, INPUT SHF (O RING) (*KIT1) [ПРОКЛАДКА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] teamcadillac.ru 96042807 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-451) (GM04-582) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042815 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-451) (GM04-583) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru (GM04-583) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042827 КРОНШТЕЙН, INPUT & REACTION (INCLS 455-462) (GM04-583) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96042707 КРОНШТЕЙН, INPUT & REACTION (INCLS 455-462) (4.176) (GM04-583) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042817 КРОНШТЕЙН, INPUT & REACTION (INCLS 455-462) (GM04-584) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ teamcadillac.ru 96042824 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-584) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ teamcadillac.ru 96042824 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-584) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ teamcadillac.ru 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-584) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ teamcadillac.ru 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-585) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru (GM04-585) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96042825 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 470-477) (GM04-585) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 470-477) (GM04-585) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 470-477) (GM04-586) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru (GM04-586) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042825 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 480-497) (GM04-586) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 480-497) (GM04-586) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 480-497) (GM04-587) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК ↓ teamcadillac.ru (GM04-587) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК ↓ 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (INCLS 500-505) (GM04-587) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК ↓ teamcadillac.ru 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (INCLS 500-505) (GM04-587) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК ↓ teamcadillac.ru 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (INCLS 500-505) (GM04-588) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) КРЕПЛЕНИЕ ↓ 96042826 SUPPORT, CTR (INCLS 510-517, 519-535) teamcadillac.ru (GM04-588) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) КРЕПЛЕНИЕ ↓ teamcadillac.ru 96042826 SUPPORT, CTR (INCLS 510-535) (GM04-588) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) КРЕПЛЕНИЕ ↓ teamcadillac.ru 96042809 SUPPORT, CTR (INCLS 510-535) (GM04-588) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) КРЕПЛЕНИЕ ↓ teamcadillac.ru 96042816 SUPPORT, CTR (INCLS 510-535) (GM04-589) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) PLANETARY КРОНШТЕЙН БЛОК ↓ 96042832 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-552, 554) teamcadillac.ru (GM04-589) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) PLANETARY КРОНШТЕЙН БЛОК ↓ teamcadillac.ru 96042827 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-554) (GM04-589) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) PLANETARY КРОНШТЕЙН БЛОК ↓ teamcadillac.ru 96042707 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-554) (4.176) (GM04-589) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) PLANETARY КРОНШТЕЙН БЛОК ↓ 96042817 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-554) (GM04-590) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК ↓ teamcadillac.ru 96042834 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560, 561, 563, 564) (GM04-590) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК ↓ teamcadillac.ru 96042709 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560-564) (GM04-591) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК ↓ teamcadillac.ru 96042837 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560-564) (GM04-591) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК ↓ teamcadillac.ru 96042813 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560-561, 563-564) (GM04-593) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) PARKING PAWL БЛОК ↓ 96042710 LEVER, MAN SHFT DTNT 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 96042540 SWITCH, A/TRNS MAN SHFT SHF POSN [ВЫКЛЮЧАТЕЛЬ ПРИВОДА] 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 08644709 SEAL, MAN SHFT SHF (W/O PTFE LUBRICANT APPLIED TO SEAL) (ACDelco #8644709) 96041857 SHAFT, MAN SHFT teamcadillac.ru 96041852 PLUG, MAN SHFT SHF HOLE (4.279) (GM04-593) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) PARKING PAWL БЛОК ↓ 96042710 LEVER, MAN SHFT DTNT 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 96042540 SWITCH, A/TRNS MAN SHFT SHF POSN [ВЫКЛЮЧАТЕЛЬ ПРИВОДА] 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 08644709 SEAL, MAN SHFT SHF (W/O PTFE LUBRICANT APPLIED TO SEAL) (ACDelco #8644709) 96041857 SHAFT, MAN SHFT teamcadillac.ru 96042711 PAWL KIT, PARK 96041852 PLUG, MAN SHFT SHF HOLE (4.279) 96041842 SPACER, MAN SHFT DTNT LVR (GM04-594) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) PARKING PAWL БЛОК ↓ 96042819 LEVER, MAN SHFT DTNT 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 96042540 SWITCH, A/TRNS MAN SHFT SHF POSN [ВЫКЛЮЧАТЕЛЬ ПРИВОДА] 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 08644709 SEAL, MAN SHFT SHF (W/O PTFE LUBRICANT APPLIED TO SEAL) (ACDelco #8644709) 96042544 SHAFT KIT, MAN SHFT 96042711 PAWL KIT, PARK 96042820 PAWL KIT, PARK teamcadillac.ru (GM04-594) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) PARKING PAWL БЛОК ↓ 96042710 LEVER, MAN SHFT DTNT 96042819 LEVER, MAN SHFT DTNT 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 96042540 SWITCH, A/TRNS MAN SHFT SHF POSN [ВЫКЛЮЧАТЕЛЬ ПРИВОДА] 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 08644709 SEAL, MAN SHFT SHF (W/O PTFE LUBRICANT APPLIED TO SEAL) (ACDelco #8644709) 96042544 SHAFT KIT, MAN SHFT teamcadillac.ru 96042711 PAWL KIT, PARK 96042820 PAWL KIT, PARK 04 - ТОРМОЗА ↓ (6D04-023) - 2004-2009 E СТОЯНОЧНЫЙ ТОРМОЗ ASM ↓ 88951984 PLATE, RR PARK BRK ANC BKG (4.591) 88951985 PLATE, RR PARK BRK ANC BKG (4.591) 88951982 ACTUATOR KIT, RR PARK BRK (INCLS 2) (ACDelco #179-2053) [АКТУАТОР] 88951983 ACTUATOR KIT, RR PARK BRK (INCLS 2) (ACDelco #179-2054) [АКТУАТОР] 89047676 SHOE KIT, RR PARK BRK (INCLS 5) (ACDelco #171-0915) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (2 ШТ)] teamcadillac.ru (6D04-031) - 2004-2009 E ТОРМОЗНОЙ СУППОРТ-ЗАДНИЙ ↓ 89047677 CALIPER KIT, RR BRK (INCLS 2, 3, 7-9) (ACDelco #172-2343) 89047678 CALIPER KIT, RR BRK (INCLS 2, 3, 7-9) (ACDelco #172-2344) [ТОРМОЗНОЙ СУППОРТ] 88951992 CAP, RR BRK BLEDR VLV (ЧАСТЬ OF 1) 88951991 VALVE, RR BRK CLPR BLEDR (ЧАСТЬ OF 1) teamcadillac.ru 89047757 PAD KIT, RR DISC BRK (INCLS 4, 12) (ACDelco #171-859) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4 ШТ)] 89047758 PAD KIT, RR DISC BRK (INCLS 4, 12) (4.667) (ACDelco #171-0906) [ТОРМОЗНЫЕ КОЛОДКИ] 88957163 BRACKET, RR BRK CLPR [СКОБА ТОРМОЗНОГО СУППОРТА] 89047759 PIN KIT, RR BRK CLPR GDE (INCLS 4-6) (INCLS 2 PINS, 2 SEALS & 2 (2.75") БОЛТS) (ACDelco #179-2044) [НАПРАВЛЯЮЩАЯ ТОРМОЗНОГО СУППОРТА (2 ШТ)] 88957162 REPAIR KIT, RR BRK CLPR HYD (INCLS 4, 6, 8, 9) (6D04-033) - 2004-2009 E ТОРМОЗНОЙ УСИЛИТЕЛЬ ↓ teamcadillac.ru 88967237 BOOSTER, P/B (W/O VLV) (ACDelco #178-0695) 05461808 GROMMET, P/B BOOS VAC CHK VLV (*KIT1) 03817880 RETAINER, BRK PED PUSH ROD (0.80 IN) (PUSH IN) 18022219 VALVE KIT, P/B BOOS VAC CHK (INCLS 2, 3) (BLACK) (INCLS VLV & GROM) (ACDelco #179-1266) (6E00-010) - 2004-2005 E ТРАНСМИССИЯ TO КРЕПЛЕНИЕ ДВИГАТЕЛЯ (LH2/4.6A) ↓ 12580474 FLYКОЛЕСО, ENG (INCLS 10) [МАХОВИК ДВИГАТЕЛЯ] 25771275 BRACKET, ENG WRG HARN (USED IN GENERATOR PACKAGE) 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] teamcadillac.ru 24205900 COVER, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] 12561075 БОЛТ, FLYWHL 12568122 COVER, FLYWHL HSG 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (TRANS CONV CVR) (ACDelco #11517518) [БОЛТ] 12568123 COVER, TRANS CONV 01647172 SPACER, FLYWHL (ЧАСТЬ OF 1) (6E00-014) - 2004-2009 E ТРАНСМИССИЯ TO КРЕПЛЕНИЕ ДВИГАТЕЛЯ (LY7/3.6-7) ↓ 12572042 PLATE, A/TRNS FLEX 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] teamcadillac.ru 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (TRANS CVR) [БОЛТ] 24222918 COVER, TRANS CONV 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] (6E04-003) - 2004-2006 E УПРАВЛЕНИЕ АКПП/АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22,M82) ↓ 88967336 KNOB PKG, A/TRNS CONT LVR (INCLS 2, 13) (EBONY/BURL WALNUT) 88967337 KNOB PKG, A/TRNS CONT LVR (INCLS 2, 13) (EBONY LEATHER) 88967339 БОЛТ, A/TRNS CONT LVR KNOB (ЧАСТЬ OF 1) 25772994 PLATE, F/FLR CNSL TRANS SHFT OPG TR (INCLS TRAC CONT SWITCH) 25772995 PLATE, F/FLR CNSL TRANS SHFT OPG TR (WALNUT BURL) (INCLS TRAC CNTRL SW) [ПОДДОН] 88967342 BASE, A/TRNS CONT (INCLS 4, 6, 7) (4.010) 88967347 SOLENOID, A/TRNS SHFT LK CONT (ЧАСТЬ OF 5) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (A/TRNS RANGE SEL ROD ADJ) 15245220 LINK, A/TRNS RANGE SEL LVR (W/ADJUSTER SLEEVE) (FOR 1ST DES SEE 25756336) [ШАРНИР,КУЛИСА] teamcadillac.ru 25756336 LINK, A/TRNS RANGE SEL LVR (NON-ADJUSTABLE) (FOR 2ND DES SEE 15245220) [ШАРНИР, КУЛИСА] 11519095 NUT-ACORN HEX, M8X1.0, 15MM THK, 9, 6047M, W/DOME. (A/TRNS RANGE SEL LVR) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL LVR CBL BRKT) [ГАЙКА М6] 88967341 BULB, A/TRNS CONT POSN IND (INCLS BULB W/BLUE COVER) (4.020) (ACDelco #88967341) [ЛАМПОЧКА ФАРЫ] 88967340 COVER, A/TRNS CONT LVR HDL (ЧАСТЬ OF 1) (6E04-004) - 2004-2006 E УПРАВЛЕНИЕ АКПП/АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3,MX5) ↓ 88967336 KNOB PKG, A/TRNS CONT LVR (INCLS 2, 13) (EBONY/BURL WALNUT) 88967337 KNOB PKG, A/TRNS CONT LVR (INCLS 2, 13) (EBONY LEATHER) 88967339 БОЛТ, A/TRNS CONT LVR KNOB (ЧАСТЬ OF 1) 25772994 PLATE, F/FLR CNSL TRANS SHFT OPG TR (INCLS TRAC CONT SWITCH) 25772995 PLATE, F/FLR CNSL TRANS SHFT OPG TR (WALNUT BURL) (INCLS TRAC CNTRL SW) [ПОДДОН] 19167127 BEZEL, A/TRNS CONT HSG (W/SHIF LOCK SOLENOID COV) 88967343 BASE, A/TRNS CONT (4.010) [БЛОК] 88967347 SOLENOID, A/TRNS SHFT LK CONT 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (A/TRNS RANGE SEL ROD ADJ) 15245219 LINK, A/TRNS RANGE SEL LVR (W/ADJUSTER SLEEVE) (FOR 1ST DES SEE 25756335) teamcadillac.ru 25756335 LINK, A/TRNS RANGE SEL LVR (NON-ADJUSTABLE) (FOR 2ND DES SEE 15245219) [РЫЧАГ В СБОРЕ] 11519095 NUT-ACORN HEX, M8X1.0, 15MM THK, 9, 6047M, W/DOME. (A/TRNS RANGE SEL LVR) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL LVR CBL BRKT) [ГАЙКА М6] 88967341 BULB, A/TRNS CONT POSN IND (INCLS BULB W/BLUE COVER) (4.020) (ACDelco #88967341) [ЛАМПОЧКА ФАРЫ] 88967340 COVER, A/TRNS CONT LVR HDL (ЧАСТЬ OF 1) (6E04-005) - 2004-2005 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (EXC V92)(WITH THERMAL BYPASS VALVE)(1ST DES) ↓ 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 89022494 BRACKET, TRANS FLUID CLR 11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16] 11515792 БОЛТ, HFH, M8X1.25X40, 22THD, 18 O.D., MAC-PT, 10.9, 7112M (TRANS FLUID CLR PIPE CONN) 24221232 VALVE, TRANS FLUID CLR THERMAL BYPASS (INCLS 5) [КЛАПАН ЖИДКОСТИ ТРАНСМИССИОННОЙ] 19130214 SEAL, TRANS FLUID CLR HOSE CONN (O RING) 19129779 HOSE, TRANS FLUID CLR LWR (W/BLOCK) (BUILT W/OR AFTER VIN 1GYEE63A750180934 USE T/W 19129780 , 11515757 & REMOVE THERM BYPASS VLV.) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 19129781 HOSE, TRANS FLUID CLR LWR (W/BLOCK) 89022495 HOSE, TRANS FLUID CLR LWR 88957425 COOLER, TRANS FLUID (INCLS 9-13) (ACDelco #88957425) [ВЕНТИЛЯТОР] 19129780 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) (USE ON CARS BUILT W/OR AFTER VIN 1GYEE63A750180934) (FOR CARS BUILT PRIOR TO VIN REPL T/W 19129779 , 11515757 & REMOVE THERM BYPASS VLV.) [ТРУБКА] teamcadillac.ru 19129782 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) (USE ON CARS BUILT W/OR AFTER VIN 1GYEE637150180965) (FOR CARS BUILT PRIOR TO VIN REPL T/W 19129781 , 11515757 & REMOVE THERM BYPASS VLV.) [ТРУБКА МАСЛООХЛАДИТЕЛЯ] 89022496 HOSE, TRANS FLUID CLR UPR (6E04-006) - 2004-2005 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (V92)(WITH THERMAL BYPASS VALVE)(1ST DES) ↓ 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 89022494 BRACKET, TRANS FLUID CLR 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 11515792 БОЛТ, HFH, M8X1.25X40, 22THD, 18 O.D., MAC-PT, 10.9, 7112M (TRANS FLUID CLR PIPE CONN) 24221232 VALVE, TRANS FLUID CLR THERMAL BYPASS (INCLS 5) [КЛАПАН ЖИДКОСТИ ТРАНСМИССИОННОЙ] 19130214 SEAL, TRANS FLUID CLR HOSE CONN (O RING) 19129779 HOSE, TRANS FLUID CLR LWR (INCLS BLOCK) (W/BLOCK) (BUILT W/OR AFTER VIN 1GYEE63A750180934 USE T/W 19129780 , 11515757 & REMOVE THERM BYPASS VLV.) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 19129781 HOSE, TRANS FLUID CLR LWR (INCLS BLOCK) (W/BLOCK) teamcadillac.ru 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR) (ACDelco #11570082) [БОЛТ М8] 89022522 COOLER, TRANS FLUID (INCLS 9-11) 19129780 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) (USE ON CARS BUILT W/OR AFTER VIN 1GYEE63A750180934) (FOR CARS BUILT PRIOR TO VIN REPL T/W 19129779 , 11515757 & REMOVE THERM BYPASS VLV.) [ТРУБКА] 19129782 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) (USE ON CARS BUILT W/OR AFTER VIN 1GYEE637150180965) (FOR CARS BUILT PRIOR TO VIN REPL T/W 19129781 , 11515757 & REMOVE THERM BYPASS VLV.) [ТРУБКА МАСЛООХЛАДИТЕЛЯ] (6E04-007) - 2004-2006 E ТОРМОЗНЫЕ ШЛАНГИ И ТРУБКИ ↓ 15933099 HOSE, FRT BRK (INCLS 15, 16) (ACDelco #176-1495) 11569742 RETAINER, FRT BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (BRK & FUEL FEED & FUEL RTN & EVAP EMIS) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА] 25761218 BRACKET, FUEL PIPE 25761217 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (3.162) 12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (FRT BRK) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА] 10388788 PIPE, BRK PRESS MOD VLV FRT (INCLS 29) 10388794 PIPE, BRK PRESS MOD VLV RR (INCLS 29) 25763163 PIPE, BRK PRESS MOD VLV RR (9/16" FITTING AT EACH END. FOR 2ND DESIGN SEE 10388794.) (INCLS 29) 03541444 SPACER, FRT BRK PIPE 11516521 БОЛТ, HFH M6X1X20, 9.8, 7114M, DOG PT, 14.2 OD (FRT BRK HOSE) 15933098 HOSE, FRT BRK (INCLS 15, 16) (ACDelco #176-1487) 25743891 RETAINER, RR BRK FRT PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT) 15724653 FITTING, FRT BRK PIPE (ЧАСТЬ OF 1, 12) (7/16-24 X .36) (.30 THD, .56 LENGTH, .194 TUBE, STL, GM7113M) 25743891 RETAINER, FRT BRK PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT) 25737279 CLIP, FRT BRK PIPE (THREE WAY RETAINER SINGLE CENTRAL FIR-TREE ATTACHMENT) 15270078 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (USES RETAINER PIN FOR ATTACHMENT) [ЗАЖИМ ТРУБКИ ТОПЛИВНОЙ СИСТЕМЫ] teamcadillac.ru 25688547 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (RETAINER W/5 HOLES (2)7.95, (2)4.76, (1)9.52MM) 25749839 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (HOLDS 3 ТРУБКИ, FLAT SHAPE, SNAP-IN RETAINER) 25607191 RETAINER, BRK PIPE (21.5X10.0MM) (HOLDS (2) 4.68-4.82 TUBES) 11569742 RETAINER, RR BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 15724650 ГАЙКА, INVERTED FLARED TUBE, 9/16"-18, 1/4" TUBE, ZD (BRK PIPE) (4.686) [ГАЙКА] 25693890 RETAINER, RR BRK PIPE (HOLDS (1) 4.76 LINE) (W/TREE) [ЗАМОК, ФИКСАТОР] 11588803 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 7, 8) (1/2-20X.40, .32 THD) (INVERTED FLARED TUBE) (.62 LONG, 1/4 TUBE) [ГАЙКА М20] 15724650 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 7, 8) (9/16-18 X .40) (INVERTED FLARED TUBE) [ГАЙКА] 15933091 HOSE, RR BRK (INCLS 22, 23) (ACDelco #15933091) 15933092 HOSE, RR BRK (INCLS 22, 23) (ACDelco #15933092) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ] 88964150 PROTECTOR, FRT BRK PIPE (FOR 3/16" PIPE) (HT SHRINK) (6E04-008) - 2004-2006 E ТОРМОЗНАЯ ПЕДАЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (EXC (JF4)) ↓ 25732428 BARRIER, BRK PED BRKT SND 25697461 RETAINER, BRK PED PUSH ROD BOOT 25732452 BOOT, BRK PED PUSH ROD 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] 15932827 HOSE, P/B BOOS VAC (ACDelco #176-1496) 25765419 PEDAL, BRK (W/BRKT) (INCLS 10, 11, 14, 16-18) 25771615 COVER, BRK PED (ЧАСТЬ OF 9) 89047699 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 9) [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 9) teamcadillac.ru 10434956 BUSHING, BRK PED PUSH ROD 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 9) 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 9) (0.80 IN) (PUSH IN) (6E04-010) - 2004-2006 E СТОЯНОЧНЫЙ ТОРМОЗ SYSTEM ↓ 10395687 LEVER, PARK BRK (INCLS 2-4, 13-15) 15797212 CABLE, PARK BRK INTER (INCLS 5, 10, 11) (ACDelco #15797212) [ТРОС СТОЯНОЧНОГО ТОРМОЗА В СБОРЕ] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (PARK BRK INTER CBL GDE) [ГАЙКА М6] teamcadillac.ru 11517484 БОЛТ-HEX, M6X1X20, 9 THD, 17 OD, 9.8, 6280M, MACH, P-PT (PARK BRK INTER CBL GDE) 25764260 CABLE, PARK BRK RR (28.2X28.5X811.7MM) (ACDelco #25764260) [ТРОС СТОЯНОЧНОГО ТОРМОЗА] 25880964 HANDLE, PARK BRK REL 89047821 CABLE, PARK BRK REL (ЧАСТЬ OF 1) (ACDelco #89047821) 22654577 SWITCH, PARK BRK IND (ЧАСТЬ OF 1) (ACDelco #22654577) [ВКЛЮЧАТЕЛЬ] (6E04-011) - 2004-2006 E T.C.M. МОДУЛЬ ↓ 24240284 МОДУЛЬ, TRANS CONT [МОДУЛЬ] teamcadillac.ru 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (MULTIUSE RLY & FUSE BRKT) [БОЛТ М6] (6E04-012) - 2004-2006 E КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS(MV3) ↓ 88996677 CASE, TRFER (FRT HALF) (INCLS 12-14) teamcadillac.ru 19133265 CASE, TRFER (RR HALF) (INCLS 5, 7) 88996679 SNUBBER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN 88996680 БОЛТ, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN SNBR (M5X0.8X16) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 2) 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL FILL) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996657 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 2) [УПЛОТНИТЕЛЬ] 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL DRN) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996680 БОЛТ, TRFER CASE VENT BFL (M5X0.8X16) (4.535) 88996658 BAFFLE, TRFER CASE VENT 89048123 БОЛТ, TRFER CASE HALF (M8X1.25X30) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 1) 88996656 SEAL, TRFER CASE INPUT SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 88996657 SEAL, TRFER CASE FRT ВЫХОДНОЙ SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] (6E04-014) - 2004-2005 E КОРПУС КП КРЕПЛЕНИЕ (MV3,MX5) ↓ 11519347 БОЛТ, TRFER CASE (M10X1.5X65) (8.900) [БОЛТ] (6E04-016) - 2004-2009 E КЛАПАН РЕГУЛИРОВКИ ДАВЛЕНИЯ В ТОРМОЗНОЙ СИСТЕМЕ ↓ 89060339 МОДУЛЬ KIT, ELEK BRK & TRACT CONT (REQS PROGRAMMING;BRK APPLY SEN REQS CALN;REFER TO SERV INFO) (ACDelco #89060339) [БЛОК УПРАВЛЕНИЯ ТОРМОЗНОЙ СИСТЕМОЙ] 89060233 VALVE KIT, BRK PRESS MOD (INCLS 3, 4) (ACDelco #89060233) [ГИДРАВЛИЧЕСКИЙ БЛОК АБС] 25743362 SENSOR, BRK PRESS MOD VLV PRESS (ЧАСТЬ OF 2) (ACDelco #25743362) [ДАТЧИК] 25741456 INSULATOR, BRK PRESS MOD VLV (ЧАСТЬ OF 2) 11588304 STUD, FLANGE DOUBLE END, M8X14 UNTHD, M8X1.25X13, 17 OD, 5.8, GM4345M (BRK PRESS MOD VLV BRKT) 11514596 ГАЙКА, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (BRK PRESS MOD VLV BRKT) (8.915) (ACDelco #11514596) 11508351 SCREW, PAN HD, C/R, 5X0.8X13, 9.3 OD, FULL THD, THD RLLR, 6171M, PC (BRK PRESS MOD VLV) (8.977) (6E04-017) - 2004-2006 E ШЛАНГ ВЕНТИЛЯЦИИ ТРАНСМИССИИ ↓ 25764835 VENT, A/TRNS (INCLS 2, 3) (ACDelco #25764835) teamcadillac.ru 25765121 VENT, A/TRNS (INCLS 2, 3) (ACDelco #25765121) 15955072 CLIP, TRANS VENT HOSE (ЧАСТЬ OF 1) (.650MM DIA) (2.343) (6E04-018) - 2004-2009 E КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS(MX5) ↓ 88996677 CASE, TRFER (FRT HALF) (INCLS 12-14) 19133265 CASE, TRFER (RR HALF) (INCLS 5, 7) 88996679 SNUBBER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN 88996680 БОЛТ, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN SNBR (M5X0.8X16) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 2) 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL FILL) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996657 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 2) [УПЛОТНИТЕЛЬ] 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL DRN) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996680 БОЛТ, TRFER CASE VENT BFL (M5X0.8X16) (4.535) teamcadillac.ru 88996658 BAFFLE, TRFER CASE VENT 89048123 БОЛТ, TRFER CASE HALF (M8X1.25X30) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 1) 88996656 SEAL, TRFER CASE INPUT SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 88996657 SEAL, TRFER CASE FRT ВЫХОДНОЙ SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 19180066 VENT, TRFER CASE 89048123 БОЛТ, TRFER CASE VIB DPNR (M8X1.25X30) 89048182 DAMPENER, TRFER CASE VIB (6E04-021) - 2005 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (EXC V92)(WITHOUT THERMAL BYPASS VALVE)(2ND DES) ↓ 11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16] 89022494 BRACKET, TRANS FLUID CLR 19129780 HOSE, TRANS FLUID CLR UPR (USE ON CARS BUILT W/OR AFTER VIN 1GYEE63A750180934. USE ON CARS BUILT PRIOR TO VIN 1GYEE63A750180934 REPL T/W 19129779 & REMOVE THERM BYPASS VLV.) (W/O BLOCK) [ТРУБКА] 19129782 HOSE, TRANS FLUID CLR UPR (USE ON CARS BUILT W/OR AFTER VIN 1GYEE637150180965. USE ON CARS BUILT PRIOR TO VIN 1GYEE637150180965 REPL T/W 19129781 & REMOVE THERM BYPASS VLV.) (W/O BLOCK) [ТРУБКА МАСЛООХЛАДИТЕЛЯ] 19130214 SEAL, TRANS FLUID CLR HOSE CONN (O RING) 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 19129779 HOSE, TRANS FLUID CLR LWR (USE ON CARS BUILT W/OR AFTER VIN 1GYEE63A750180934. USE ON CARS BUILT PRIOR TO VIN 1GYEE63A750180934 REPL T/W 19129780 & REMOVE THERM BYPASS VLV.) (W/BLOCK) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 19129781 HOSE, TRANS FLUID CLR LWR (USE ON CARS BUILT W/OR AFTER VIN 1GYEE637150180965. USE ON CARS BUILT PRIOR TO VIN 1GYEE637150180965 REPL T/W 19129782 & REMOVE THERM BYPASS VLV.) (W/BLOCK) 88957425 COOLER, TRANS FLUID (INCLS 7-11) (ACDelco #88957425) [ВЕНТИЛЯТОР] (6E04-022) - 2005 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (V92)(WITHOUT THERMAL BYPASS VALVE)(2ND DES) ↓ 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 89022494 BRACKET, TRANS FLUID CLR 19129780 HOSE, TRANS FLUID CLR UPR (USE ON CARS BUILT W/OR AFTER VIN 1GYEE63A750180934. USE ON CARS BUILT PRIOR TO VIN 1GYEE63A750180934 REPL T/W 19129779 & REMOVE THERM BYPASS VLV.) (W/O BLOCK) [ТРУБКА] 19129782 HOSE, TRANS FLUID CLR UPR (USE ON CARS BUILT W/OR AFTER VIN 1GYEE637150180965. USE ON CARS BUILT PRIOR TO VIN 1GYEE637150180965 REPL T/W 19129781 & REMOVE THERM BYPASS VLV.) (W/O BLOCK) [ТРУБКА МАСЛООХЛАДИТЕЛЯ] 19130214 SEAL, TRANS FLUID CLR HOSE CONN (O RING) 19129779 HOSE, TRANS FLUID CLR LWR (USE ON CARS BUILT W/OR AFTER VIN 1GYEE63A750180934. USE ON CARS BUILT PRIOR TO VIN 1GYEE63A750180934 REPL T/W 19129780 & REMOVE THERM BYPASS VLV.) (W/BLOCK) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] teamcadillac.ru 19129781 HOSE, TRANS FLUID CLR LWR (USE ON CARS BUILT W/OR AFTER VIN 1GYEE637150180965. USE ON CARS BUILT PRIOR TO VIN 1GYEE637150180965 REPL T/W 19129782 & REMOVE THERM BYPASS VLV.) (W/BLOCK) 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR) (ACDelco #11570082) [БОЛТ М8] 89022522 COOLER, TRANS FLUID (INCLS 7-9) (6E04-035) - 2005-2009 E BRAKE SYSTEM/ANTILOCK ↓ 12413103 HUB, FRT WHL (W/BRG) (СМ. ГРУППУ 06.000 "ПОДВЕСКА-ПЕРЕДНЯЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/WHL SPD SEN) (ACDelco #FW149) [СТУПИЦА КОЛЕСА] 12413105 HUB, FRT WHL (W/BRG) (СМ. ГРУППУ 06.000 "ПОДВЕСКА-ПЕРЕДНЯЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPEED SENSOR) (ACDelco #FW150) [СТУПИЦА КОЛЕСА] 89047639 HUB, RR WHL (W/WHL SPD SEN) (СМ. ГРУППУ 06.000 "ЗАДНЯЯ ПОДВЕСКА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6 STUD HUB) (ACDelco #RW20-19) [СТУПИЦА КОЛЕСА] teamcadillac.ru 10307709 SENSOR, VEH YAW (W/VEH LATL ACCLRM) [ДАТЧИК] 15906579 SENSOR, VEH YAW (W/ VEH LATL & LGTDNL ACCLRM) [ДАТЧИК] 11561645 ГАЙКА, HFH, M6X1X6.45, 13.5 OD, 10 STL, GMW3200 (VEH YAW SEN & LATL ACCLRM) (6E04-036) - 2005-2006 E ТОРМОЗНАЯ ПЕДАЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (JF4) ↓ 25732428 BARRIER, BRK PED BRKT SND 25697461 RETAINER, BRK PED PUSH ROD BOOT 25732452 BOOT, BRK PED PUSH ROD 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] 15932827 HOSE, P/B BOOS VAC (ACDelco #176-1496) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (ACCEL PED LVR) teamcadillac.ru 10368488 PEDAL, BRK (INCLS 12, 13, 15, 18-22) 25771615 COVER, BRK PED (ЧАСТЬ OF 11) 89047699 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 11) (INCLS 18) [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 89047780 MOTOR KIT, BRK & ACCEL PED ADJR ACTR [ЭЛЕКТРОДВИГАТЕЛЬ ПЕДАЛЬНОГО УЗЛА 19 ВТ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 11, 13) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 11) 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 11) 25697461 RETAINER, BRK PED PUSH ROD BOOT (ЧАСТЬ OF 11) 89047779 CABLE, ACCEL CONT 89047778 CABLE, BRK PED ADJR ACTR [ЖГУТ ПРОВОДОВ] 25741052 BRACKET, BRK PED BRKT 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-018) - 2004-2006 E КОРПУС КП ЧАСТЬ 2 INTERNAL COMPONENTS(MV3) ↓ 88984517 WASHER, TRFER CASE PLNT CARR SUN GR THR (25.8X52.0X2.2) 88984524 GEAR, TRFER CASE PLNT CARR SUN (INPUT) (STAMPED PM/POWDERED METAL) 88984493 RING, TRFER CASE RR ВЫХОДНОЙ SHF RR BRG RET (41MM I.D.) (ACDelco #88984493) 88996564 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT 88996665 BEARING, TRFER CASE MAIN SHF FRT (ВЫХОДНОЙ ВАЛ FRT) 19168733 BUSHING, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 106) [ВТУЛКА РАЗДАТОЧНОЙ КОРОБКИ] 19178237 SHAFT, TRFER CASE RR ВЫХОДНОЙ (INCLS 105, 901) 19133264 SPROCKET, TRFER CASE FRT ВЫХОДНОЙ SHF DRV (INCLS 108) [ШЕСТЕРНЯ РАЗДАТОЧНОЙ КОРОБКИ] 19168732 BUSHING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT (ЧАСТЬ OF 107) (ACDelco #19168732) 89059578 CHAIN, TRFER CASE TWO/FOUR WHL DRV [ЦЕПЬ РАЗДАТОЧНОЙ КОРОБКИ] 88984523 GEAR, TRFER CASE PLNT CARR SUN (ВЫХОДНОЙ) teamcadillac.ru 89059279 КРОНШТЕЙН, TRFER CASE PLNT 89059284 SHAFT, TRFER CASE FRT ВЫХОДНОЙ (INCLS 900) 88996664 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF RR 88996671 RING, TRFER CASE FRT ВЫХОДНОЙ SHF BRG RET 88996666 SPROCKET, TRFER CASE TWO/FOUR WHL DRV DRVN [ЗВЕЗДОЧКА] 88996633 BEARING, TRFER CASE RR ВЫХОДНОЙ SHF RR (ACDelco #88996633) [ПОДШИПНИК РАЗДАТОЧНОЙ КОРОБКИ] 15580230 BEARING, TRFER CASE INPUT SHF (BORG-WARNER) (4.510) 19132966 SHAFT, TRFER CASE INPUT 88996681 DEFLECTOR, TRFER CASE FRT ВЫХОДНОЙ SHF SEAL DIRT (ЧАСТЬ OF 112) (6M04-041) - 2004-2006 E26 ТОРМОЗНАЯ ПЕДАЛЬ (PWR ADJ PEDALS JF4) ↓ 25741052 BRACKET, BRK PED BRKT 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 25732428 BARRIER, BRK PED BRKT SND 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] teamcadillac.ru 89047778 CABLE, BRK PED ADJR ACTR [ЖГУТ ПРОВОДОВ] 89047780 MOTOR KIT, BRK & ACCEL PED ADJR ACTR [ЭЛЕКТРОДВИГАТЕЛЬ ПЕДАЛЬНОГО УЗЛА 19 ВТ] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (BRK PED POSN SEN) 89047699 SENSOR KIT, BRK PED POSN [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 25697461 RETAINER, BRK PED PUSH ROD BOOT (ЧАСТЬ OF 21) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 21) 10368488 PEDAL, BRK (INCLS 5, 8-10, 13, 15-20, 22) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-042) - 2004-2006 E26 ТОРМОЗНАЯ ПЕДАЛЬ (EXC PWR ADJ PEDALS JF4) ↓ teamcadillac.ru 25741052 BRACKET, BRK PED BRKT 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 25732428 BARRIER, BRK PED BRKT SND 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 18) 89047699 SENSOR KIT, BRK PED POSN [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 18) (0.80 IN) (PUSH IN) 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 18) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 18) 25771615 COVER, BRK PED (ЧАСТЬ OF 18) 25765419 PEDAL, BRK (W/BRKT) (INCLS 5-8, 10, 12-17, 19) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-044) - 2004-2009 E26 ТОРМОЗНОЙ УСИЛИТЕЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА ↓ 88967237 BOOSTER, P/B (СМ. ГРУППУ 04.000 "ТОРМОЗНОЙ УСИЛИТЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/O VLV) (ACDelco #178-0695) 25732452 BOOT, BRK PED PUSH ROD 25697461 RETAINER, BRK PED PUSH ROD BOOT 10367561 CYLINDER, BRK MAS (СМ. ГРУППУ 4.000 "ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #174-1012) [ЦИЛИНДР] 11609949 ГАЙКА, BRK M/CYL (M10X1.5, 11.2 THK) (8.917) [ГАЙКА] 25873484 HOSE, P/B BOOS VAC (ACDelco #176-1497) (GM04-064) - 2004-2009 E ТОРМОЗНОЙ СУППОРТ-ПЕРЕДНИЙ ↓ 18047980 CALIPER, FRT BRK (INCLS 2-4, 8-10) (IF DISCONTINUED USE DURASTOP EQUIVALENT) (4.667) (ACDelco #172-1643) [ТОРМОЗНОЙ СУППОРТ] 18047981 CALIPER, FRT BRK (INCLS 2-4, 8-10) (IF DISCONTINUED USE DURASTOP EQUIVALENT) (4.667) (ACDelco #172-1644) [ТОРМОЗНОЙ СУППОРТ] 18043178 COVER, FRT BRK BLEDR SCREW (ЧАСТЬ OF 1) 18047986 VALVE KIT, FRT BRK CLPR BLEDR (ЧАСТЬ OF 1) (ACDelco #18047986) 18046750 БОЛТ, FRT BRK CLPR GDE PIN (ЧАСТЬ OF 1, 11) (*KIT2) [БОЛТ] 18047985 PISTON KIT, FRT BRK CLPR (ЧАСТЬ OF 1) 18047988 PAD KIT, FRT DISC BRK (INCLS 4, 14) (ACDelco #171-665) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4 ШТ)] 19122384 PAD KIT, FRT DISC BRK (INCLS 4, 14) (ACDelco #171-688) teamcadillac.ru 18045221 SEAL, FRT BRK CLPR GDE PIN 18047987 BRACKET, FRT BRK CLPR (W/GUIDE PIN БОЛТS) [КРОНШТЕЙН] 18046698 ПРУЖИНА, FRT DISC BRK PAD RET (ЧАСТЬ OF 11) (ACDelco #179-2235) 18047989 PIN KIT, FRT BRK CLPR GDE (INCLS 5-7) (INCLS 2 (2.5") БОЛТS) 18047984 CALIPER KIT, FRT BRK (INCLS 4, 8, 9) (4.667) (ACDelco #173-0538) (GM04-312) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (5L50-E M22,5L40-E M82) ↓ 96042884 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 5GDZ) teamcadillac.ru 96042897 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 5GRG) (GM04-376) - 2004-2009 E ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР ↓ 18012741 SWITCH, BRK FLUID LVL IND (ЧАСТЬ OF 15) (ACDelco #18012741) 22688449 CAP, BRK M/CYL RSVR (ЧАСТЬ OF 15) (INCLS 3) [КРЫШКА БАЧКА ТОРМОЗНОЙ ЖИДКОСТИ] 18046711 RESERVOIR, BRK M/CYL (ЧАСТЬ OF 15) (INCLS 4, 6-7) (ACDelco #18046711) teamcadillac.ru 18060168 PISTON, BRK M/CYL SECD (ЧАСТЬ OF 15) 10367561 CYLINDER, BRK MAS (INCLS 1-14) (ACDelco #174-1012) [ЦИЛИНДР] 18022002 CYLINDER KIT, BRK MAS (INCLS 8-12) (ACDelco #175-424) (GM04-485) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (5L50-E MV3,5L40-E MX5) ↓ teamcadillac.ru 96042890 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 5GGG) [АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ В СБОРЕ] 96042893 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 5GFZ) [ТРАНСМИССИЯ В СБОРЕ] (GM04-573) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042497 GASKET, A/TRNS CASE EXTN [ПРОКЛАДКА ТРАНСФОРМАТОРНОЙ КОРОБКИ] 96042882 EXTENSION, A/TRNS CASE (INCLS 26, 28, 29) (4.003) 96041851 SEAL, PROP SHF TRANS FLG FLUID (ЧАСТЬ OF 27) [ПРОКЛАДКА ТРАНСФОРМАТОРНОГО ВАЛА] 96042585 FLANGE, ВЫХОДНОЙ SHF [ФЛАНЕЦ] 96041805 NUT KIT, ВЫХОДНОЙ SHFT (INCLS 30, 32, 33) (M6X1.0X16) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96042962 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) teamcadillac.ru 96042712 DETENT, MAN SHFT 96017928 CLIP, WRG HARN 96042847 HARNESS, A/TRNS WRG 96041849 SEAL, A/TRNS WRG CONN (O RING) 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) (GM04-573) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042497 GASKET, A/TRNS CASE EXTN (*KIT1) [ПРОКЛАДКА ТРАНСФОРМАТОРНОЙ КОРОБКИ] 96042496 EXTENSION, A/TRNS CASE (INCLS 26, 28, 29) 96041851 SEAL, PROP SHF TRANS FLG FLUID (ЧАСТЬ OF 27) (*KIT1) [ПРОКЛАДКА ТРАНСФОРМАТОРНОГО ВАЛА] 96042585 FLANGE, ВЫХОДНОЙ SHF [ФЛАНЕЦ] 96041805 NUT KIT, ВЫХОДНОЙ SHFT (INCLS 30, 32, 33) (M6X1.0X16) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) (*KIT1) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) (*KIT1) 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96042963 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPACER PLATE & GASKET) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) teamcadillac.ru 96042712 DETENT, MAN SHFT 96017928 CLIP, WRG HARN 96042847 HARNESS, A/TRNS WRG 96041849 SEAL, A/TRNS WRG CONN (O RING) (*KIT1) 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN (*KIT1) [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (*KIT1) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (*KIT1) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) 96042945 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/GSKT, SEAL, RET) (INCLS 25, 29, 36, 38, 46, 56, 60, 63, 64) (GM04-574) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042887 GASKET, A/TRNS CASE EXTN [ПРОКЛАДКА КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042563 EXTENSION, A/TRNS CASE (INCLS 28, 69) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) teamcadillac.ru 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96042962 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) 96042712 DETENT, MAN SHFT 96017928 CLIP, WRG HARN 96042847 HARNESS, A/TRNS WRG 96041849 SEAL, A/TRNS WRG CONN (O RING) 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) 96042543 WASHER, INPUT & REACTION CARR THR 96042587 SEAL, PROP SHF TRANS FLG FLUID [ПРОКЛАДКА КРЫШКИ РАЗДАТОЧНОЙ КОРОБКИ] (GM04-574) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042887 GASKET, A/TRNS CASE EXTN [ПРОКЛАДКА КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042888 EXTENSION, A/TRNS CASE (INCLS 28, 69) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96042963 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPACER PLATE & GASKET) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) 96042712 DETENT, MAN SHFT 96017928 CLIP, WRG HARN 96042847 HARNESS, A/TRNS WRG 96041849 SEAL, A/TRNS WRG CONN (O RING) 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (1.456) teamcadillac.ru 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) 96042543 WASHER, INPUT & REACTION CARR THR 96042587 SEAL, PROP SHF TRANS FLG FLUID [ПРОКЛАДКА КРЫШКИ РАЗДАТОЧНОЙ КОРОБКИ] 08677884 BEARING, ВЫХОДНОЙ SHF THR (ЧАСТЬ OF 27) (4.180) (ACDelco #8677884) (GM04-575) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ 96042553 CONVERTER, TORQ (REMAN) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042835 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) 96042806 СЦЕПЛЕНИЕ, DIR & REV 96042831 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) 96042823 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) 96042824 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) 96042701 WASHER, INPUT & REACTION CARR INR SHF THR 96042808 ШЛАНГИ, O/D CLU 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) 96042705 BEARING, CTR SUPT RLR (4.180) 96042826 SUPPORT, CTR 96042832 КРОНШТЕЙН, INPUT & REACTION 96042833 BEARING, INPUT & REACTION CARR THR 96042834 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) 96042543 WASHER, INPUT & REACTION CARR THR 96042833 BEARING, INPUT & REACTION CARR THR 96042883 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/GSKT, SEAL, RET) (GM04-575) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ 96042554 CONVERTER, TORQ (REMAN) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042812 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) 96042806 СЦЕПЛЕНИЕ, DIR & REV (СМ. ГРУППУ 04.000 "DIRECT AND REVERSE СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042807 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (СМ. ГРУППУ 04.000 "FORWARD AND COAST СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042698 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) (СМ. ГРУППУ 04.000 "INPUT SUN GEAR SHAFT AND FORWARD SPRAG СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (СМ. ГРУППУ 04.000 "DIRECT СЦЕПЛЕНИЕ DRUM AND SHAFT" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042701 WASHER, INPUT & REACTION CARR INR SHF THR 96042808 ШЛАНГИ, O/D CLU (СМ. ГРУППУ 04.000 "OVERDRIVE AND INTERMEDIATE СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (СМ. ГРУППУ 04.000 "LOW СЦЕПЛЕНИЕ SPRAG" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042705 BEARING, CTR SUPT RLR (4.180) 96042809 SUPPORT, CTR (СМ. ГРУППУ 04.000 "CENTER SUPPORT" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042707 КРОНШТЕЙН, INPUT & REACTION (СМ. ГРУППУ 04.000 "PLANETARY КРОНШТЕЙН" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (4.176) 96042708 BEARING, INPUT & REACTION CARR THR 96042709 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (СМ. ГРУППУ 04.000 "ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96041847 WASHER, INPUT & REACTION CARR THR (4.265) teamcadillac.ru (GM04-576) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ 96042553 CONVERTER, TORQ (REMAN) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042835 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) 96042814 СЦЕПЛЕНИЕ, DIR & REV 96042822 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) 96042823 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) 96042824 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) 96042701 WASHER, INPUT & REACTION CARR INR SHF THR 96042808 ШЛАНГИ, O/D CLU 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) teamcadillac.ru 96042826 SUPPORT, CTR 96042827 КРОНШТЕЙН, INPUT & REACTION 96042818 BEARING, INPUT & REACTION CARR THR 96042837 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) 96042543 WASHER, INPUT & REACTION CARR THR 96042818 BEARING, INPUT & REACTION CARR THR (GM04-576) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ 96042554 CONVERTER, TORQ (REMAN) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042812 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) 96042814 СЦЕПЛЕНИЕ, DIR & REV 96042815 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) 96042698 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) (INCLS 9) 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) 96042701 WASHER, INPUT & REACTION CARR INR SHF THR 96042808 ШЛАНГИ, O/D CLU 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) 96042705 BEARING, CTR SUPT RLR (*KIT1) (4.180) 96042816 SUPPORT, CTR 96042817 КРОНШТЕЙН, INPUT & REACTION teamcadillac.ru 96042818 BEARING, INPUT & REACTION CARR THR 96042813 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) 96042543 WASHER, INPUT & REACTION CARR THR 96042818 BEARING, INPUT & REACTION CARR THR (GM04-577) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ 96041855 SEAL, T/CV FLUID [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] teamcadillac.ru 96042835 ШЛАНГИ KIT, T/CV (INCLS 200-212, 214-215, 217-220, 223, 226, 227, 231-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-577) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ teamcadillac.ru 96041855 SEAL, T/CV FLUID (*KIT1) [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042835 ШЛАНГИ KIT, T/CV (INCLS 200-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-577) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ teamcadillac.ru 96041855 SEAL, T/CV FLUID [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042812 ШЛАНГИ KIT, T/CV (INCLS 200-215, 217-220, 223, 226-228, 231-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-577) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ teamcadillac.ru 96041855 SEAL, T/CV FLUID [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042812 ШЛАНГИ KIT, T/CV (INCLS 200-215, 217-220, 223, 226-228, 231-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-578) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96042987 GASKET KIT, A/TRNS (INCLS 303, 305, 306, 308, 309, 312, 314, 316, 330, 332) (4.265) (GM04-578) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96042987 GASKET KIT, A/TRNS (INCLS 303, 305, 306, 308, 309, 312, 314, 316, 330, 332) (4.265) (GM04-578) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 300-309, 312-334) (INCLS SPACER PLATE & GASKET) (GM04-578) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 300-334) (INCLS SPACER PLATE & GASKET) (GM04-579) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 96042599 VALVE, TCC PWM SOL 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] (GM04-579) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96042599 VALVE, TCC PWM SOL 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] (GM04-579) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96042599 VALVE, TCC PWM SOL 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 340-351, 353-356) (INCLS SPACER PLATE & GASKET) (GM04-579) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 96042599 VALVE, TCC PWM SOL 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 340-348, 351, 353-354) (INCLS SPACER PLATE & GASKET) (GM04-580) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] (GM04-580) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] (GM04-580) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] teamcadillac.ru 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 343, 349, 350, 365-367, 370-375, 377-388) (INCLS SPACER PLATE & GASKET) (GM04-580) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 343, 351, 365-367, 370-375, 377-388) (INCLS SPACER PLATE & GASKET) 96042889 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/PLT, GSKT, SEAL) (INCLS 343, 351, 365-367, 370-375, 377-388) (GM04-581) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru (GM04-581) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru 96042814 СЦЕПЛЕНИЕ, DIR & REV (INCLS 400-420) (GM04-581) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru 96042806 СЦЕПЛЕНИЕ, DIR & REV (INCLS 400-420) (GM04-581) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru 96042814 СЦЕПЛЕНИЕ, DIR & REV (INCLS 400-420) (GM04-582) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96042831 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-432, 434-451) teamcadillac.ru 96042883 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/GSKT, SEAL, RET) (GM04-582) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯLY ↓ teamcadillac.ru 96042822 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-451) (GM04-582) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96041856 SEAL, INPUT SHF (O RING) (*KIT1) [ПРОКЛАДКА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042807 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-451) (GM04-582) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042815 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-451) (GM04-583) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru (GM04-583) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042827 КРОНШТЕЙН, INPUT & REACTION (INCLS 455-462) (GM04-583) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96042707 КРОНШТЕЙН, INPUT & REACTION (INCLS 455-462) (4.176) (GM04-583) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042817 КРОНШТЕЙН, INPUT & REACTION (INCLS 455-462) (GM04-584) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ 96042824 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-584) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ teamcadillac.ru 96042824 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-584) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ teamcadillac.ru 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-584) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-585) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru (GM04-585) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96042825 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 470-477) (GM04-585) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 470-477) (GM04-585) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 470-477) (GM04-586) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru (GM04-586) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042825 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 480-497) (GM04-586) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 480-497) (GM04-586) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 480-497) (GM04-587) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК ↓ teamcadillac.ru (GM04-587) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК ↓ teamcadillac.ru 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (INCLS 500-505) (GM04-587) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК ↓ 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (INCLS 500-505) (GM04-587) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК ↓ teamcadillac.ru 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (INCLS 500-505) (GM04-588) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) КРЕПЛЕНИЕ ↓ 96042826 SUPPORT, CTR (INCLS 510-517, 519-535) teamcadillac.ru (GM04-588) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) КРЕПЛЕНИЕ ↓ teamcadillac.ru 96042826 SUPPORT, CTR (INCLS 510-535) (GM04-588) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) КРЕПЛЕНИЕ ↓ teamcadillac.ru 96042809 SUPPORT, CTR (INCLS 510-535) (GM04-588) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) КРЕПЛЕНИЕ ↓ teamcadillac.ru 96042816 SUPPORT, CTR (INCLS 510-535) (GM04-589) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) PLANETARY КРОНШТЕЙН БЛОК ↓ teamcadillac.ru 96042832 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-552, 554) (GM04-589) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) PLANETARY КРОНШТЕЙН БЛОК ↓ teamcadillac.ru 96042827 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-554) (GM04-589) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) PLANETARY КРОНШТЕЙН БЛОК ↓ teamcadillac.ru 96042707 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-554) (4.176) (GM04-589) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) PLANETARY КРОНШТЕЙН БЛОК ↓ teamcadillac.ru 96042817 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-554) (GM04-590) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК ↓ teamcadillac.ru 96042834 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560, 561, 563, 564) (GM04-590) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК ↓ teamcadillac.ru 96042709 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560-564) (GM04-591) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК ↓ teamcadillac.ru 96042837 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560-564) (GM04-591) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК ↓ teamcadillac.ru 96042813 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560-561, 563-564) (GM04-593) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) PARKING PAWL БЛОК ↓ 96042710 LEVER, MAN SHFT DTNT 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 96042540 SWITCH, A/TRNS MAN SHFT SHF POSN [ВЫКЛЮЧАТЕЛЬ ПРИВОДА] 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 08644709 SEAL, MAN SHFT SHF (W/O PTFE LUBRICANT APPLIED TO SEAL) (ACDelco #8644709) 96041857 SHAFT, MAN SHFT 96041852 PLUG, MAN SHFT SHF HOLE (4.279) (GM04-593) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) PARKING PAWL БЛОК ↓ 96042710 LEVER, MAN SHFT DTNT 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 96042540 SWITCH, A/TRNS MAN SHFT SHF POSN [ВЫКЛЮЧАТЕЛЬ ПРИВОДА] 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 08644709 SEAL, MAN SHFT SHF (W/O PTFE LUBRICANT APPLIED TO SEAL) (ACDelco #8644709) 96041857 SHAFT, MAN SHFT teamcadillac.ru 96042711 PAWL KIT, PARK 96041852 PLUG, MAN SHFT SHF HOLE (4.279) 96041842 SPACER, MAN SHFT DTNT LVR (GM04-594) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) PARKING PAWL БЛОК ↓ 96042819 LEVER, MAN SHFT DTNT 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 96042540 SWITCH, A/TRNS MAN SHFT SHF POSN [ВЫКЛЮЧАТЕЛЬ ПРИВОДА] 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 08644709 SEAL, MAN SHFT SHF (W/O PTFE LUBRICANT APPLIED TO SEAL) (ACDelco #8644709) 96042544 SHAFT KIT, MAN SHFT teamcadillac.ru 96042711 PAWL KIT, PARK 96042820 PAWL KIT, PARK (GM04-594) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) PARKING PAWL БЛОК ↓ 96042710 LEVER, MAN SHFT DTNT 96042819 LEVER, MAN SHFT DTNT 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 96042540 SWITCH, A/TRNS MAN SHFT SHF POSN [ВЫКЛЮЧАТЕЛЬ ПРИВОДА] teamcadillac.ru 96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ] 08644709 SEAL, MAN SHFT SHF (W/O PTFE LUBRICANT APPLIED TO SEAL) (ACDelco #8644709) 96042544 SHAFT KIT, MAN SHFT 96042711 PAWL KIT, PARK 96042820 PAWL KIT, PARK 04 - КОРПУС КП ↓ (6D04-023) - 2004-2009 E СТОЯНОЧНЫЙ ТОРМОЗ ASM ↓ 88951984 PLATE, RR PARK BRK ANC BKG (4.591) 88951985 PLATE, RR PARK BRK ANC BKG (4.591) teamcadillac.ru 88951982 ACTUATOR KIT, RR PARK BRK (INCLS 2) (ACDelco #179-2053) [АКТУАТОР] 88951983 ACTUATOR KIT, RR PARK BRK (INCLS 2) (ACDelco #179-2054) [АКТУАТОР] 89047676 SHOE KIT, RR PARK BRK (INCLS 5) (ACDelco #171-0915) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (2 ШТ)] (6D04-031) - 2004-2009 E ТОРМОЗНОЙ СУППОРТ-ЗАДНИЙ ↓ 89047677 CALIPER KIT, RR BRK (INCLS 2, 3, 7-9) (ACDelco #172-2343) 89047678 CALIPER KIT, RR BRK (INCLS 2, 3, 7-9) (ACDelco #172-2344) [ТОРМОЗНОЙ СУППОРТ] 88951992 CAP, RR BRK BLEDR VLV (ЧАСТЬ OF 1) 88951991 VALVE, RR BRK CLPR BLEDR (ЧАСТЬ OF 1) teamcadillac.ru 89047757 PAD KIT, RR DISC BRK (INCLS 4, 12) (ACDelco #171-859) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4 ШТ)] 89047758 PAD KIT, RR DISC BRK (INCLS 4, 12) (4.667) (ACDelco #171-0906) [ТОРМОЗНЫЕ КОЛОДКИ] 88957163 BRACKET, RR BRK CLPR [СКОБА ТОРМОЗНОГО СУППОРТА] 89047759 PIN KIT, RR BRK CLPR GDE (INCLS 4-6) (INCLS 2 PINS, 2 SEALS & 2 (2.75") БОЛТS) (ACDelco #179-2044) [НАПРАВЛЯЮЩАЯ ТОРМОЗНОГО СУППОРТА (2 ШТ)] 88957162 REPAIR KIT, RR BRK CLPR HYD (INCLS 4, 6, 8, 9) (6D04-033) - 2004-2009 E ТОРМОЗНОЙ УСИЛИТЕЛЬ ↓ 88967237 BOOSTER, P/B (W/O VLV) (ACDelco #178-0695) 05461808 GROMMET, P/B BOOS VAC CHK VLV (*KIT1) teamcadillac.ru 03817880 RETAINER, BRK PED PUSH ROD (0.80 IN) (PUSH IN) 18022219 VALVE KIT, P/B BOOS VAC CHK (INCLS 2, 3) (BLACK) (INCLS VLV & GROM) (ACDelco #179-1266) (6E00-010) - 2004-2005 E ТРАНСМИССИЯ TO КРЕПЛЕНИЕ ДВИГАТЕЛЯ (LH2/4.6A) ↓ 12580474 FLYКОЛЕСО, ENG (INCLS 10) [МАХОВИК ДВИГАТЕЛЯ] 25771275 BRACKET, ENG WRG HARN (USED IN GENERATOR PACKAGE) 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] teamcadillac.ru 24205900 COVER, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП] 12561075 БОЛТ, FLYWHL 12568122 COVER, FLYWHL HSG 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) 11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (TRANS CONV CVR) (ACDelco #11517518) [БОЛТ] 12568123 COVER, TRANS CONV 01647172 SPACER, FLYWHL (ЧАСТЬ OF 1) (6E00-014) - 2004-2009 E ТРАНСМИССИЯ TO КРЕПЛЕНИЕ ДВИГАТЕЛЯ (LY7/3.6-7) ↓ 12572042 PLATE, A/TRNS FLEX 11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15) teamcadillac.ru 11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП] 11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (TRANS CVR) [БОЛТ] 24222918 COVER, TRANS CONV 11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50] (6E04-003) - 2004-2006 E УПРАВЛЕНИЕ АКПП/АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22,M82) ↓ 88967336 KNOB PKG, A/TRNS CONT LVR (INCLS 2, 13) (EBONY/BURL WALNUT) 88967337 KNOB PKG, A/TRNS CONT LVR (INCLS 2, 13) (EBONY LEATHER) 88967339 БОЛТ, A/TRNS CONT LVR KNOB (ЧАСТЬ OF 1) 25772994 PLATE, F/FLR CNSL TRANS SHFT OPG TR (INCLS TRAC CONT SWITCH) teamcadillac.ru 25772995 PLATE, F/FLR CNSL TRANS SHFT OPG TR (WALNUT BURL) (INCLS TRAC CNTRL SW) [ПОДДОН] 88967342 BASE, A/TRNS CONT (INCLS 4, 6, 7) (4.010) 88967347 SOLENOID, A/TRNS SHFT LK CONT (ЧАСТЬ OF 5) 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (A/TRNS RANGE SEL ROD ADJ) 15245220 LINK, A/TRNS RANGE SEL LVR (W/ADJUSTER SLEEVE) (FOR 1ST DES SEE 25756336) [ШАРНИР,КУЛИСА] 25756336 LINK, A/TRNS RANGE SEL LVR (NON-ADJUSTABLE) (FOR 2ND DES SEE 15245220) [ШАРНИР, КУЛИСА] 11519095 NUT-ACORN HEX, M8X1.0, 15MM THK, 9, 6047M, W/DOME. (A/TRNS RANGE SEL LVR) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL LVR CBL BRKT) [ГАЙКА М6] 88967341 BULB, A/TRNS CONT POSN IND (INCLS BULB W/BLUE COVER) (4.020) (ACDelco #88967341) [ЛАМПОЧКА ФАРЫ] 88967340 COVER, A/TRNS CONT LVR HDL (ЧАСТЬ OF 1) (6E04-004) - 2004-2006 E УПРАВЛЕНИЕ АКПП/АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3,MX5) ↓ 88967336 KNOB PKG, A/TRNS CONT LVR (INCLS 2, 13) (EBONY/BURL WALNUT) 88967337 KNOB PKG, A/TRNS CONT LVR (INCLS 2, 13) (EBONY LEATHER) teamcadillac.ru 88967339 БОЛТ, A/TRNS CONT LVR KNOB (ЧАСТЬ OF 1) 25772994 PLATE, F/FLR CNSL TRANS SHFT OPG TR (INCLS TRAC CONT SWITCH) 25772995 PLATE, F/FLR CNSL TRANS SHFT OPG TR (WALNUT BURL) (INCLS TRAC CNTRL SW) [ПОДДОН] 19167127 BEZEL, A/TRNS CONT HSG (W/SHIF LOCK SOLENOID COV) 88967343 BASE, A/TRNS CONT (4.010) [БЛОК] 88967347 SOLENOID, A/TRNS SHFT LK CONT 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (A/TRNS RANGE SEL ROD ADJ) 15245219 LINK, A/TRNS RANGE SEL LVR (W/ADJUSTER SLEEVE) (FOR 1ST DES SEE 25756335) 25756335 LINK, A/TRNS RANGE SEL LVR (NON-ADJUSTABLE) (FOR 2ND DES SEE 15245219) [РЫЧАГ В СБОРЕ] 11519095 NUT-ACORN HEX, M8X1.0, 15MM THK, 9, 6047M, W/DOME. (A/TRNS RANGE SEL LVR) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL LVR CBL BRKT) [ГАЙКА М6] 88967341 BULB, A/TRNS CONT POSN IND (INCLS BULB W/BLUE COVER) (4.020) (ACDelco #88967341) [ЛАМПОЧКА ФАРЫ] 88967340 COVER, A/TRNS CONT LVR HDL (ЧАСТЬ OF 1) (6E04-005) - 2004-2005 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (EXC V92)(WITH THERMAL BYPASS VALVE)(1ST DES) ↓ 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 89022494 BRACKET, TRANS FLUID CLR 11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16] 11515792 БОЛТ, HFH, M8X1.25X40, 22THD, 18 O.D., MAC-PT, 10.9, 7112M (TRANS FLUID CLR PIPE CONN) 24221232 VALVE, TRANS FLUID CLR THERMAL BYPASS (INCLS 5) [КЛАПАН ЖИДКОСТИ ТРАНСМИССИОННОЙ] 19130214 SEAL, TRANS FLUID CLR HOSE CONN (O RING) 19129779 HOSE, TRANS FLUID CLR LWR (W/BLOCK) (BUILT W/OR AFTER VIN 1GYEE63A750180934 USE T/W 19129780 , 11515757 & REMOVE THERM BYPASS VLV.) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 19129781 HOSE, TRANS FLUID CLR LWR (W/BLOCK) teamcadillac.ru 89022495 HOSE, TRANS FLUID CLR LWR 88957425 COOLER, TRANS FLUID (INCLS 9-13) (ACDelco #88957425) [ВЕНТИЛЯТОР] 19129780 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) (USE ON CARS BUILT W/OR AFTER VIN 1GYEE63A750180934) (FOR CARS BUILT PRIOR TO VIN REPL T/W 19129779 , 11515757 & REMOVE THERM BYPASS VLV.) [ТРУБКА] 19129782 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) (USE ON CARS BUILT W/OR AFTER VIN 1GYEE637150180965) (FOR CARS BUILT PRIOR TO VIN REPL T/W 19129781 , 11515757 & REMOVE THERM BYPASS VLV.) [ТРУБКА МАСЛООХЛАДИТЕЛЯ] 89022496 HOSE, TRANS FLUID CLR UPR (6E04-006) - 2004-2005 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (V92)(WITH THERMAL BYPASS VALVE)(1ST DES) ↓ teamcadillac.ru 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 89022494 BRACKET, TRANS FLUID CLR 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 11515792 БОЛТ, HFH, M8X1.25X40, 22THD, 18 O.D., MAC-PT, 10.9, 7112M (TRANS FLUID CLR PIPE CONN) 24221232 VALVE, TRANS FLUID CLR THERMAL BYPASS (INCLS 5) [КЛАПАН ЖИДКОСТИ ТРАНСМИССИОННОЙ] 19130214 SEAL, TRANS FLUID CLR HOSE CONN (O RING) 19129779 HOSE, TRANS FLUID CLR LWR (INCLS BLOCK) (W/BLOCK) (BUILT W/OR AFTER VIN 1GYEE63A750180934 USE T/W 19129780 , 11515757 & REMOVE THERM BYPASS VLV.) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 19129781 HOSE, TRANS FLUID CLR LWR (INCLS BLOCK) (W/BLOCK) 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR) (ACDelco #11570082) [БОЛТ М8] 89022522 COOLER, TRANS FLUID (INCLS 9-11) 19129780 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) (USE ON CARS BUILT W/OR AFTER VIN 1GYEE63A750180934) (FOR CARS BUILT PRIOR TO VIN REPL T/W 19129779 , 11515757 & REMOVE THERM BYPASS VLV.) [ТРУБКА] 19129782 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) (USE ON CARS BUILT W/OR AFTER VIN 1GYEE637150180965) (FOR CARS BUILT PRIOR TO VIN REPL T/W 19129781 , 11515757 & REMOVE THERM BYPASS VLV.) [ТРУБКА МАСЛООХЛАДИТЕЛЯ] (6E04-007) - 2004-2006 E ТОРМОЗНЫЕ ШЛАНГИ И ТРУБКИ ↓ 15933099 HOSE, FRT BRK (INCLS 15, 16) (ACDelco #176-1495) 11569742 RETAINER, FRT BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (BRK & FUEL FEED & FUEL RTN & EVAP EMIS) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА] 25761218 BRACKET, FUEL PIPE 25761217 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (3.162) 12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (FRT BRK) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА] 10388788 PIPE, BRK PRESS MOD VLV FRT (INCLS 29) 10388794 PIPE, BRK PRESS MOD VLV RR (INCLS 29) 25763163 PIPE, BRK PRESS MOD VLV RR (9/16" FITTING AT EACH END. FOR 2ND DESIGN SEE 10388794.) (INCLS 29) 03541444 SPACER, FRT BRK PIPE 11516521 БОЛТ, HFH M6X1X20, 9.8, 7114M, DOG PT, 14.2 OD (FRT BRK HOSE) 15933098 HOSE, FRT BRK (INCLS 15, 16) (ACDelco #176-1487) 25743891 RETAINER, RR BRK FRT PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT) 15724653 FITTING, FRT BRK PIPE (ЧАСТЬ OF 1, 12) (7/16-24 X .36) (.30 THD, .56 LENGTH, .194 TUBE, STL, GM7113M) 25743891 RETAINER, FRT BRK PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT) 25737279 CLIP, FRT BRK PIPE (THREE WAY RETAINER SINGLE CENTRAL FIR-TREE ATTACHMENT) 15270078 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (USES RETAINER PIN FOR ATTACHMENT) [ЗАЖИМ ТРУБКИ ТОПЛИВНОЙ СИСТЕМЫ] 25688547 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (RETAINER W/5 HOLES (2)7.95, (2)4.76, (1)9.52MM) 25749839 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (HOLDS 3 ТРУБКИ, FLAT SHAPE, SNAP-IN RETAINER) 25607191 RETAINER, BRK PIPE (21.5X10.0MM) (HOLDS (2) 4.68-4.82 TUBES) 11569742 RETAINER, RR BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ] 15724650 ГАЙКА, INVERTED FLARED TUBE, 9/16"-18, 1/4" TUBE, ZD (BRK PIPE) (4.686) [ГАЙКА] 25693890 RETAINER, RR BRK PIPE (HOLDS (1) 4.76 LINE) (W/TREE) [ЗАМОК, ФИКСАТОР] 11588803 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 7, 8) (1/2-20X.40, .32 THD) (INVERTED FLARED TUBE) (.62 LONG, 1/4 TUBE) [ГАЙКА М20] 15724650 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 7, 8) (9/16-18 X .40) (INVERTED FLARED TUBE) [ГАЙКА] 15933091 HOSE, RR BRK (INCLS 22, 23) (ACDelco #15933091) 15933092 HOSE, RR BRK (INCLS 22, 23) (ACDelco #15933092) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ] 88964150 PROTECTOR, FRT BRK PIPE (FOR 3/16" PIPE) (HT SHRINK) (6E04-008) - 2004-2006 E ТОРМОЗНАЯ ПЕДАЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (EXC (JF4)) ↓ 25732428 BARRIER, BRK PED BRKT SND 25697461 RETAINER, BRK PED PUSH ROD BOOT 25732452 BOOT, BRK PED PUSH ROD 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] 15932827 HOSE, P/B BOOS VAC (ACDelco #176-1496) 25765419 PEDAL, BRK (W/BRKT) (INCLS 10, 11, 14, 16-18) teamcadillac.ru 25771615 COVER, BRK PED (ЧАСТЬ OF 9) 89047699 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 9) [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 9) 10434956 BUSHING, BRK PED PUSH ROD 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 9) 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 9) (0.80 IN) (PUSH IN) (6E04-010) - 2004-2006 E СТОЯНОЧНЫЙ ТОРМОЗ SYSTEM ↓ 10395687 LEVER, PARK BRK (INCLS 2-4, 13-15) teamcadillac.ru 15797212 CABLE, PARK BRK INTER (INCLS 5, 10, 11) (ACDelco #15797212) [ТРОС СТОЯНОЧНОГО ТОРМОЗА В СБОРЕ] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (PARK BRK INTER CBL GDE) [ГАЙКА М6] 11517484 БОЛТ-HEX, M6X1X20, 9 THD, 17 OD, 9.8, 6280M, MACH, P-PT (PARK BRK INTER CBL GDE) 25764260 CABLE, PARK BRK RR (28.2X28.5X811.7MM) (ACDelco #25764260) [ТРОС СТОЯНОЧНОГО ТОРМОЗА] 25880964 HANDLE, PARK BRK REL 89047821 CABLE, PARK BRK REL (ЧАСТЬ OF 1) (ACDelco #89047821) 22654577 SWITCH, PARK BRK IND (ЧАСТЬ OF 1) (ACDelco #22654577) [ВКЛЮЧАТЕЛЬ] (6E04-011) - 2004-2006 E T.C.M. МОДУЛЬ ↓ 24240284 МОДУЛЬ, TRANS CONT [МОДУЛЬ] teamcadillac.ru 11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (MULTIUSE RLY & FUSE BRKT) [БОЛТ М6] (6E04-012) - 2004-2006 E КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS(MV3) ↓ 88996677 CASE, TRFER (FRT HALF) (INCLS 12-14) 19133265 CASE, TRFER (RR HALF) (INCLS 5, 7) 88996679 SNUBBER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN 88996680 БОЛТ, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN SNBR (M5X0.8X16) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 2) 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL FILL) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996657 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 2) [УПЛОТНИТЕЛЬ] 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL DRN) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] teamcadillac.ru 88996680 БОЛТ, TRFER CASE VENT BFL (M5X0.8X16) (4.535) 88996658 BAFFLE, TRFER CASE VENT 89048123 БОЛТ, TRFER CASE HALF (M8X1.25X30) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 1) 88996656 SEAL, TRFER CASE INPUT SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 88996657 SEAL, TRFER CASE FRT ВЫХОДНОЙ SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] (6E04-014) - 2004-2005 E КОРПУС КП КРЕПЛЕНИЕ (MV3,MX5) ↓ 11519347 БОЛТ, TRFER CASE (M10X1.5X65) (8.900) [БОЛТ] teamcadillac.ru (6E04-016) - 2004-2009 E КЛАПАН РЕГУЛИРОВКИ ДАВЛЕНИЯ В ТОРМОЗНОЙ СИСТЕМЕ ↓ 89060339 МОДУЛЬ KIT, ELEK BRK & TRACT CONT (REQS PROGRAMMING;BRK APPLY SEN REQS CALN;REFER TO SERV INFO) (ACDelco #89060339) [БЛОК УПРАВЛЕНИЯ ТОРМОЗНОЙ СИСТЕМОЙ] teamcadillac.ru 89060233 VALVE KIT, BRK PRESS MOD (INCLS 3, 4) (ACDelco #89060233) [ГИДРАВЛИЧЕСКИЙ БЛОК АБС] 25743362 SENSOR, BRK PRESS MOD VLV PRESS (ЧАСТЬ OF 2) (ACDelco #25743362) [ДАТЧИК] 25741456 INSULATOR, BRK PRESS MOD VLV (ЧАСТЬ OF 2) 11588304 STUD, FLANGE DOUBLE END, M8X14 UNTHD, M8X1.25X13, 17 OD, 5.8, GM4345M (BRK PRESS MOD VLV BRKT) 11514596 ГАЙКА, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (BRK PRESS MOD VLV BRKT) (8.915) (ACDelco #11514596) 11508351 SCREW, PAN HD, C/R, 5X0.8X13, 9.3 OD, FULL THD, THD RLLR, 6171M, PC (BRK PRESS MOD VLV) (8.977) (6E04-017) - 2004-2006 E ШЛАНГ ВЕНТИЛЯЦИИ ТРАНСМИССИИ ↓ 25764835 VENT, A/TRNS (INCLS 2, 3) (ACDelco #25764835) 25765121 VENT, A/TRNS (INCLS 2, 3) (ACDelco #25765121) 15955072 CLIP, TRANS VENT HOSE (ЧАСТЬ OF 1) (.650MM DIA) (2.343) (6E04-018) - 2004-2009 E КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS(MX5) ↓ 88996677 CASE, TRFER (FRT HALF) (INCLS 12-14) 19133265 CASE, TRFER (RR HALF) (INCLS 5, 7) 88996679 SNUBBER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN 88996680 БОЛТ, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN SNBR (M5X0.8X16) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 2) 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL FILL) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996657 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 2) [УПЛОТНИТЕЛЬ] teamcadillac.ru 25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL DRN) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА] 88996680 БОЛТ, TRFER CASE VENT BFL (M5X0.8X16) (4.535) 88996658 BAFFLE, TRFER CASE VENT 89048123 БОЛТ, TRFER CASE HALF (M8X1.25X30) 88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 1) 88996656 SEAL, TRFER CASE INPUT SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 88996657 SEAL, TRFER CASE FRT ВЫХОДНОЙ SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ] 19180066 VENT, TRFER CASE 89048123 БОЛТ, TRFER CASE VIB DPNR (M8X1.25X30) 89048182 DAMPENER, TRFER CASE VIB (6E04-021) - 2005 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (EXC V92)(WITHOUT THERMAL BYPASS VALVE)(2ND DES) ↓ 11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16] 89022494 BRACKET, TRANS FLUID CLR 19129780 HOSE, TRANS FLUID CLR UPR (USE ON CARS BUILT W/OR AFTER VIN 1GYEE63A750180934. USE ON CARS BUILT PRIOR TO VIN 1GYEE63A750180934 REPL T/W 19129779 & REMOVE THERM BYPASS VLV.) (W/O BLOCK) [ТРУБКА] 19129782 HOSE, TRANS FLUID CLR UPR (USE ON CARS BUILT W/OR AFTER VIN 1GYEE637150180965. USE ON CARS BUILT PRIOR TO VIN 1GYEE637150180965 REPL T/W 19129781 & REMOVE THERM BYPASS VLV.) (W/O BLOCK) [ТРУБКА МАСЛООХЛАДИТЕЛЯ] 19130214 SEAL, TRANS FLUID CLR HOSE CONN (O RING) 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 19129779 HOSE, TRANS FLUID CLR LWR (USE ON CARS BUILT W/OR AFTER VIN 1GYEE63A750180934. USE ON CARS BUILT PRIOR TO VIN 1GYEE63A750180934 REPL T/W 19129780 & REMOVE THERM BYPASS VLV.) (W/BLOCK) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 19129781 HOSE, TRANS FLUID CLR LWR (USE ON CARS BUILT W/OR AFTER VIN 1GYEE637150180965. USE ON CARS BUILT PRIOR TO VIN 1GYEE637150180965 REPL T/W 19129782 & REMOVE THERM BYPASS VLV.) (W/BLOCK) teamcadillac.ru 88957425 COOLER, TRANS FLUID (INCLS 7-11) (ACDelco #88957425) [ВЕНТИЛЯТОР] (6E04-022) - 2005 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (V92)(WITHOUT THERMAL BYPASS VALVE)(2ND DES) ↓ 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 89022494 BRACKET, TRANS FLUID CLR teamcadillac.ru 19129780 HOSE, TRANS FLUID CLR UPR (USE ON CARS BUILT W/OR AFTER VIN 1GYEE63A750180934. USE ON CARS BUILT PRIOR TO VIN 1GYEE63A750180934 REPL T/W 19129779 & REMOVE THERM BYPASS VLV.) (W/O BLOCK) [ТРУБКА] 19129782 HOSE, TRANS FLUID CLR UPR (USE ON CARS BUILT W/OR AFTER VIN 1GYEE637150180965. USE ON CARS BUILT PRIOR TO VIN 1GYEE637150180965 REPL T/W 19129781 & REMOVE THERM BYPASS VLV.) (W/O BLOCK) [ТРУБКА МАСЛООХЛАДИТЕЛЯ] 19130214 SEAL, TRANS FLUID CLR HOSE CONN (O RING) 19129779 HOSE, TRANS FLUID CLR LWR (USE ON CARS BUILT W/OR AFTER VIN 1GYEE63A750180934. USE ON CARS BUILT PRIOR TO VIN 1GYEE63A750180934 REPL T/W 19129780 & REMOVE THERM BYPASS VLV.) (W/BLOCK) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ] 19129781 HOSE, TRANS FLUID CLR LWR (USE ON CARS BUILT W/OR AFTER VIN 1GYEE637150180965. USE ON CARS BUILT PRIOR TO VIN 1GYEE637150180965 REPL T/W 19129782 & REMOVE THERM BYPASS VLV.) (W/BLOCK) 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8] 11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR) (ACDelco #11570082) [БОЛТ М8] 89022522 COOLER, TRANS FLUID (INCLS 7-9) (6E04-035) - 2005-2009 E BRAKE SYSTEM/ANTILOCK ↓ 12413103 HUB, FRT WHL (W/BRG) (СМ. ГРУППУ 06.000 "ПОДВЕСКА-ПЕРЕДНЯЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/WHL SPD SEN) (ACDelco #FW149) [СТУПИЦА КОЛЕСА] 12413105 HUB, FRT WHL (W/BRG) (СМ. ГРУППУ 06.000 "ПОДВЕСКА-ПЕРЕДНЯЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPEED SENSOR) (ACDelco #FW150) [СТУПИЦА КОЛЕСА] 89047639 HUB, RR WHL (W/WHL SPD SEN) (СМ. ГРУППУ 06.000 "ЗАДНЯЯ ПОДВЕСКА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6 STUD HUB) (ACDelco #RW20-19) [СТУПИЦА КОЛЕСА] 10307709 SENSOR, VEH YAW (W/VEH LATL ACCLRM) [ДАТЧИК] 15906579 SENSOR, VEH YAW (W/ VEH LATL & LGTDNL ACCLRM) [ДАТЧИК] teamcadillac.ru 11561645 ГАЙКА, HFH, M6X1X6.45, 13.5 OD, 10 STL, GMW3200 (VEH YAW SEN & LATL ACCLRM) (6E04-036) - 2005-2006 E ТОРМОЗНАЯ ПЕДАЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (JF4) ↓ 25732428 BARRIER, BRK PED BRKT SND 25697461 RETAINER, BRK PED PUSH ROD BOOT 25732452 BOOT, BRK PED PUSH ROD 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА] 15932827 HOSE, P/B BOOS VAC (ACDelco #176-1496) teamcadillac.ru 03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (ACCEL PED LVR) 10368488 PEDAL, BRK (INCLS 12, 13, 15, 18-22) 25771615 COVER, BRK PED (ЧАСТЬ OF 11) 89047699 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 11) (INCLS 18) [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 89047780 MOTOR KIT, BRK & ACCEL PED ADJR ACTR [ЭЛЕКТРОДВИГАТЕЛЬ ПЕДАЛЬНОГО УЗЛА 19 ВТ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 11, 13) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 11) 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 11) 25697461 RETAINER, BRK PED PUSH ROD BOOT (ЧАСТЬ OF 11) 89047779 CABLE, ACCEL CONT 89047778 CABLE, BRK PED ADJR ACTR [ЖГУТ ПРОВОДОВ] 25741052 BRACKET, BRK PED BRKT 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-018) - 2004-2006 E КОРПУС КП ЧАСТЬ 2 INTERNAL COMPONENTS(MV3) ↓ 88984517 WASHER, TRFER CASE PLNT CARR SUN GR THR (25.8X52.0X2.2) 88984524 GEAR, TRFER CASE PLNT CARR SUN (INPUT) (STAMPED PM/POWDERED METAL) 88984493 RING, TRFER CASE RR ВЫХОДНОЙ SHF RR BRG RET (41MM I.D.) (ACDelco #88984493) 88996564 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT 88996665 BEARING, TRFER CASE MAIN SHF FRT (ВЫХОДНОЙ ВАЛ FRT) 19168733 BUSHING, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 106) [ВТУЛКА РАЗДАТОЧНОЙ КОРОБКИ] 19178237 SHAFT, TRFER CASE RR ВЫХОДНОЙ (INCLS 105, 901) 19133264 SPROCKET, TRFER CASE FRT ВЫХОДНОЙ SHF DRV (INCLS 108) [ШЕСТЕРНЯ РАЗДАТОЧНОЙ КОРОБКИ] 19168732 BUSHING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT (ЧАСТЬ OF 107) (ACDelco #19168732) 89059578 CHAIN, TRFER CASE TWO/FOUR WHL DRV [ЦЕПЬ РАЗДАТОЧНОЙ КОРОБКИ] 88984523 GEAR, TRFER CASE PLNT CARR SUN (ВЫХОДНОЙ) 89059279 КРОНШТЕЙН, TRFER CASE PLNT 89059284 SHAFT, TRFER CASE FRT ВЫХОДНОЙ (INCLS 900) 88996664 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF RR 88996671 RING, TRFER CASE FRT ВЫХОДНОЙ SHF BRG RET 88996666 SPROCKET, TRFER CASE TWO/FOUR WHL DRV DRVN [ЗВЕЗДОЧКА] 88996633 BEARING, TRFER CASE RR ВЫХОДНОЙ SHF RR (ACDelco #88996633) [ПОДШИПНИК РАЗДАТОЧНОЙ КОРОБКИ] teamcadillac.ru 15580230 BEARING, TRFER CASE INPUT SHF (BORG-WARNER) (4.510) 19132966 SHAFT, TRFER CASE INPUT 88996681 DEFLECTOR, TRFER CASE FRT ВЫХОДНОЙ SHF SEAL DIRT (ЧАСТЬ OF 112) (6M04-041) - 2004-2006 E26 ТОРМОЗНАЯ ПЕДАЛЬ (PWR ADJ PEDALS JF4) ↓ 25741052 BRACKET, BRK PED BRKT 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 25732428 BARRIER, BRK PED BRKT SND 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 89047778 CABLE, BRK PED ADJR ACTR [ЖГУТ ПРОВОДОВ] 89047780 MOTOR KIT, BRK & ACCEL PED ADJR ACTR [ЭЛЕКТРОДВИГАТЕЛЬ ПЕДАЛЬНОГО УЗЛА 19 ВТ] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (BRK PED POSN SEN) 89047699 SENSOR KIT, BRK PED POSN [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 25697461 RETAINER, BRK PED PUSH ROD BOOT (ЧАСТЬ OF 21) teamcadillac.ru 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 21) 10368488 PEDAL, BRK (INCLS 5, 8-10, 13, 15-20, 22) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-042) - 2004-2006 E26 ТОРМОЗНАЯ ПЕДАЛЬ (EXC PWR ADJ PEDALS JF4) ↓ teamcadillac.ru 25741052 BRACKET, BRK PED BRKT 25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET) 25732428 BARRIER, BRK PED BRKT SND 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6] 11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 18) 89047699 SENSOR KIT, BRK PED POSN [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ] 11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА] 03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 18) (0.80 IN) (PUSH IN) 00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 18) 10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 18) 25771615 COVER, BRK PED (ЧАСТЬ OF 18) 25765419 PEDAL, BRK (W/BRKT) (INCLS 5-8, 10, 12-17, 19) 11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6] (6M04-044) - 2004-2009 E26 ТОРМОЗНОЙ УСИЛИТЕЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА ↓ 88967237 BOOSTER, P/B (СМ. ГРУППУ 04.000 "ТОРМОЗНОЙ УСИЛИТЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/O VLV) (ACDelco #178-0695) 25732452 BOOT, BRK PED PUSH ROD teamcadillac.ru 25697461 RETAINER, BRK PED PUSH ROD BOOT 10367561 CYLINDER, BRK MAS (СМ. ГРУППУ 4.000 "ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #174-1012) [ЦИЛИНДР] 11609949 ГАЙКА, BRK M/CYL (M10X1.5, 11.2 THK) (8.917) [ГАЙКА] 25873484 HOSE, P/B BOOS VAC (ACDelco #176-1497) (GM04-064) - 2004-2009 E ТОРМОЗНОЙ СУППОРТ-ПЕРЕДНИЙ ↓ 18047980 CALIPER, FRT BRK (INCLS 2-4, 8-10) (IF DISCONTINUED USE DURASTOP EQUIVALENT) (4.667) (ACDelco #172-1643) [ТОРМОЗНОЙ СУППОРТ] 18047981 CALIPER, FRT BRK (INCLS 2-4, 8-10) (IF DISCONTINUED USE DURASTOP EQUIVALENT) (4.667) (ACDelco #172-1644) [ТОРМОЗНОЙ СУППОРТ] 18043178 COVER, FRT BRK BLEDR SCREW (ЧАСТЬ OF 1) 18047986 VALVE KIT, FRT BRK CLPR BLEDR (ЧАСТЬ OF 1) (ACDelco #18047986) 18046750 БОЛТ, FRT BRK CLPR GDE PIN (ЧАСТЬ OF 1, 11) (*KIT2) [БОЛТ] teamcadillac.ru 18047985 PISTON KIT, FRT BRK CLPR (ЧАСТЬ OF 1) 18047988 PAD KIT, FRT DISC BRK (INCLS 4, 14) (ACDelco #171-665) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4 ШТ)] 19122384 PAD KIT, FRT DISC BRK (INCLS 4, 14) (ACDelco #171-688) 18045221 SEAL, FRT BRK CLPR GDE PIN 18047987 BRACKET, FRT BRK CLPR (W/GUIDE PIN БОЛТS) [КРОНШТЕЙН] 18046698 ПРУЖИНА, FRT DISC BRK PAD RET (ЧАСТЬ OF 11) (ACDelco #179-2235) 18047989 PIN KIT, FRT BRK CLPR GDE (INCLS 5-7) (INCLS 2 (2.5") БОЛТS) 18047984 CALIPER KIT, FRT BRK (INCLS 4, 8, 9) (4.667) (ACDelco #173-0538) (GM04-312) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (5L50-E M22,5L40-E M82) ↓ 96042884 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 5GDZ) 96042897 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 5GRG) (GM04-376) - 2004-2009 E ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР ↓ 18012741 SWITCH, BRK FLUID LVL IND (ЧАСТЬ OF 15) (ACDelco #18012741) 22688449 CAP, BRK M/CYL RSVR (ЧАСТЬ OF 15) (INCLS 3) [КРЫШКА БАЧКА ТОРМОЗНОЙ ЖИДКОСТИ] teamcadillac.ru 18046711 RESERVOIR, BRK M/CYL (ЧАСТЬ OF 15) (INCLS 4, 6-7) (ACDelco #18046711) 18060168 PISTON, BRK M/CYL SECD (ЧАСТЬ OF 15) 10367561 CYLINDER, BRK MAS (INCLS 1-14) (ACDelco #174-1012) [ЦИЛИНДР] 18022002 CYLINDER KIT, BRK MAS (INCLS 8-12) (ACDelco #175-424) (GM04-485) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (5L50-E MV3,5L40-E MX5) ↓ teamcadillac.ru 96042890 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 5GGG) [АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ В СБОРЕ] 96042893 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 5GFZ) [ТРАНСМИССИЯ В СБОРЕ] (GM04-573) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042497 GASKET, A/TRNS CASE EXTN [ПРОКЛАДКА ТРАНСФОРМАТОРНОЙ КОРОБКИ] 96042882 EXTENSION, A/TRNS CASE (INCLS 26, 28, 29) (4.003) 96041851 SEAL, PROP SHF TRANS FLG FLUID (ЧАСТЬ OF 27) [ПРОКЛАДКА ТРАНСФОРМАТОРНОГО ВАЛА] 96042585 FLANGE, ВЫХОДНОЙ SHF [ФЛАНЕЦ] 96041805 NUT KIT, ВЫХОДНОЙ SHFT (INCLS 30, 32, 33) (M6X1.0X16) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE teamcadillac.ru 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96042962 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) 96042712 DETENT, MAN SHFT 96017928 CLIP, WRG HARN 96042847 HARNESS, A/TRNS WRG 96041849 SEAL, A/TRNS WRG CONN (O RING) 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) (GM04-573) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042497 GASKET, A/TRNS CASE EXTN (*KIT1) [ПРОКЛАДКА ТРАНСФОРМАТОРНОЙ КОРОБКИ] 96042496 EXTENSION, A/TRNS CASE (INCLS 26, 28, 29) 96041851 SEAL, PROP SHF TRANS FLG FLUID (ЧАСТЬ OF 27) (*KIT1) [ПРОКЛАДКА ТРАНСФОРМАТОРНОГО ВАЛА] 96042585 FLANGE, ВЫХОДНОЙ SHF [ФЛАНЕЦ] 96041805 NUT KIT, ВЫХОДНОЙ SHFT (INCLS 30, 32, 33) (M6X1.0X16) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) (*KIT1) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) (*KIT1) 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96042963 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPACER PLATE & GASKET) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) 96042712 DETENT, MAN SHFT 96017928 CLIP, WRG HARN 96042847 HARNESS, A/TRNS WRG teamcadillac.ru 96041849 SEAL, A/TRNS WRG CONN (O RING) (*KIT1) 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN (*KIT1) [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (*KIT1) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (*KIT1) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) 96042945 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/GSKT, SEAL, RET) (INCLS 25, 29, 36, 38, 46, 56, 60, 63, 64) (GM04-574) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042887 GASKET, A/TRNS CASE EXTN [ПРОКЛАДКА КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042563 EXTENSION, A/TRNS CASE (INCLS 28, 69) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96042962 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) 96042712 DETENT, MAN SHFT 96017928 CLIP, WRG HARN 96042847 HARNESS, A/TRNS WRG 96041849 SEAL, A/TRNS WRG CONN (O RING) teamcadillac.ru 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) 96042543 WASHER, INPUT & REACTION CARR THR 96042587 SEAL, PROP SHF TRANS FLG FLUID [ПРОКЛАДКА КРЫШКИ РАЗДАТОЧНОЙ КОРОБКИ] (GM04-574) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) CASE & ДЕТАЛИ КОМПЛЕКТА ↓ 96042887 GASKET, A/TRNS CASE EXTN [ПРОКЛАДКА КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042888 EXTENSION, A/TRNS CASE (INCLS 28, 69) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) 96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) 96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329) 96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0) 96042963 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPACER PLATE & GASKET) 96021290 БОЛТ, VLV BODY (M8X1X50) 96021012 БОЛТ, VLV BODY (M6X1X67.4) 96042712 DETENT, MAN SHFT 96017928 CLIP, WRG HARN 96042847 HARNESS, A/TRNS WRG 96041849 SEAL, A/TRNS WRG CONN (O RING) 96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042862 GASKET, A/TRNS FLUID PAN [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА] 08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701) 96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64) teamcadillac.ru 90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (1.453) 90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (1.456) 96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16) 96042543 WASHER, INPUT & REACTION CARR THR 96042587 SEAL, PROP SHF TRANS FLG FLUID [ПРОКЛАДКА КРЫШКИ РАЗДАТОЧНОЙ КОРОБКИ] 08677884 BEARING, ВЫХОДНОЙ SHF THR (ЧАСТЬ OF 27) (4.180) (ACDelco #8677884) (GM04-575) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ 96042553 CONVERTER, TORQ (REMAN) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042835 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) teamcadillac.ru 96042806 СЦЕПЛЕНИЕ, DIR & REV 96042831 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) 96042823 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) 96042824 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) 96042701 WASHER, INPUT & REACTION CARR INR SHF THR 96042808 ШЛАНГИ, O/D CLU 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) 96042705 BEARING, CTR SUPT RLR (4.180) 96042826 SUPPORT, CTR 96042832 КРОНШТЕЙН, INPUT & REACTION 96042833 BEARING, INPUT & REACTION CARR THR 96042834 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) 96042543 WASHER, INPUT & REACTION CARR THR 96042833 BEARING, INPUT & REACTION CARR THR 96042883 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/GSKT, SEAL, RET) (GM04-575) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ 96042554 CONVERTER, TORQ (REMAN) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042812 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) teamcadillac.ru 96042806 СЦЕПЛЕНИЕ, DIR & REV (СМ. ГРУППУ 04.000 "DIRECT AND REVERSE СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042807 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (СМ. ГРУППУ 04.000 "FORWARD AND COAST СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042698 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) (СМ. ГРУППУ 04.000 "INPUT SUN GEAR SHAFT AND FORWARD SPRAG СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (СМ. ГРУППУ 04.000 "DIRECT СЦЕПЛЕНИЕ DRUM AND SHAFT" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042701 WASHER, INPUT & REACTION CARR INR SHF THR 96042808 ШЛАНГИ, O/D CLU (СМ. ГРУППУ 04.000 "OVERDRIVE AND INTERMEDIATE СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (СМ. ГРУППУ 04.000 "LOW СЦЕПЛЕНИЕ SPRAG" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042705 BEARING, CTR SUPT RLR (4.180) 96042809 SUPPORT, CTR (СМ. ГРУППУ 04.000 "CENTER SUPPORT" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96042707 КРОНШТЕЙН, INPUT & REACTION (СМ. ГРУППУ 04.000 "PLANETARY КРОНШТЕЙН" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (4.176) 96042708 BEARING, INPUT & REACTION CARR THR 96042709 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (СМ. ГРУППУ 04.000 "ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) 96041847 WASHER, INPUT & REACTION CARR THR (4.265) (GM04-576) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ 96042553 CONVERTER, TORQ (REMAN) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) teamcadillac.ru 96042835 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) 96042814 СЦЕПЛЕНИЕ, DIR & REV 96042822 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) 96042823 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) 96042824 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) 96042701 WASHER, INPUT & REACTION CARR INR SHF THR 96042808 ШЛАНГИ, O/D CLU 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) 96042826 SUPPORT, CTR 96042827 КРОНШТЕЙН, INPUT & REACTION 96042818 BEARING, INPUT & REACTION CARR THR 96042837 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) 96042543 WASHER, INPUT & REACTION CARR THR 96042818 BEARING, INPUT & REACTION CARR THR (GM04-576) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА ↓ 96042554 CONVERTER, TORQ (REMAN) 96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33) 96042812 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС) 96042814 СЦЕПЛЕНИЕ, DIR & REV 96042815 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) 96042698 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) (INCLS 9) teamcadillac.ru 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) 96042701 WASHER, INPUT & REACTION CARR INR SHF THR 96042808 ШЛАНГИ, O/D CLU 96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) 96042705 BEARING, CTR SUPT RLR (*KIT1) (4.180) 96042816 SUPPORT, CTR 96042817 КРОНШТЕЙН, INPUT & REACTION 96042818 BEARING, INPUT & REACTION CARR THR 96042813 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) 96042543 WASHER, INPUT & REACTION CARR THR 96042818 BEARING, INPUT & REACTION CARR THR (GM04-577) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ 96041855 SEAL, T/CV FLUID [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] teamcadillac.ru 96042835 ШЛАНГИ KIT, T/CV (INCLS 200-212, 214-215, 217-220, 223, 226, 227, 231-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-577) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ teamcadillac.ru 96041855 SEAL, T/CV FLUID (*KIT1) [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042835 ШЛАНГИ KIT, T/CV (INCLS 200-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-577) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ teamcadillac.ru 96041855 SEAL, T/CV FLUID [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042812 ШЛАНГИ KIT, T/CV (INCLS 200-215, 217-220, 223, 226-228, 231-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-577) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС ↓ teamcadillac.ru 96041855 SEAL, T/CV FLUID [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] 96042812 ШЛАНГИ KIT, T/CV (INCLS 200-215, 217-220, 223, 226-228, 231-242) (W/МАСЛЯНЫЙ НАСОС) (GM04-578) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96042987 GASKET KIT, A/TRNS (INCLS 303, 305, 306, 308, 309, 312, 314, 316, 330, 332) (4.265) (GM04-578) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96042987 GASKET KIT, A/TRNS (INCLS 303, 305, 306, 308, 309, 312, 314, 316, 330, 332) (4.265) (GM04-578) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 300-309, 312-334) (INCLS SPACER PLATE & GASKET) (GM04-578) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 300-334) (INCLS SPACER PLATE & GASKET) (GM04-579) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96042599 VALVE, TCC PWM SOL 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] (GM04-579) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 96042599 VALVE, TCC PWM SOL 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] (GM04-579) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 96042599 VALVE, TCC PWM SOL teamcadillac.ru 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 340-351, 353-356) (INCLS SPACER PLATE & GASKET) (GM04-579) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 96042599 VALVE, TCC PWM SOL teamcadillac.ru 10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС] 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 340-348, 351, 353-354) (INCLS SPACER PLATE & GASKET) (GM04-580) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] (GM04-580) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] teamcadillac.ru (GM04-580) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ teamcadillac.ru 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 343, 349, 350, 365-367, 370-375, 377-388) (INCLS SPACER PLATE & GASKET) (GM04-580) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ ↓ 96041866 VALVE, 1-2 SHFT SOL [КЛАПАН] 96041866 VALVE, 4-5 SHFT SOL [КЛАПАН] 96042963 VALVE, CONT (W/BODY & VLV) (INCLS 343, 351, 365-367, 370-375, 377-388) (INCLS SPACER PLATE & GASKET) 96042889 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/PLT, GSKT, SEAL) (INCLS 343, 351, 365-367, 370-375, 377-388) (GM04-581) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru (GM04-581) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru 96042814 СЦЕПЛЕНИЕ, DIR & REV (INCLS 400-420) (GM04-581) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru 96042806 СЦЕПЛЕНИЕ, DIR & REV (INCLS 400-420) (GM04-581) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК ↓ teamcadillac.ru 96042814 СЦЕПЛЕНИЕ, DIR & REV (INCLS 400-420) (GM04-582) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96042831 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-432, 434-451) teamcadillac.ru 96042883 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/GSKT, SEAL, RET) (GM04-582) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯLY ↓ teamcadillac.ru 96042822 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-451) (GM04-582) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96041856 SEAL, INPUT SHF (O RING) (*KIT1) [ПРОКЛАДКА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ] teamcadillac.ru 96042807 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-451) (GM04-582) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042815 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-451) (GM04-583) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru (GM04-583) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ 96042827 КРОНШТЕЙН, INPUT & REACTION (INCLS 455-462) (GM04-583) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042707 КРОНШТЕЙН, INPUT & REACTION (INCLS 455-462) (4.176) (GM04-583) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042817 КРОНШТЕЙН, INPUT & REACTION (INCLS 455-462) (GM04-584) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ 96042824 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-584) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ teamcadillac.ru 96042824 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-584) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-584) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ ↓ teamcadillac.ru 96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465) (GM04-585) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru (GM04-585) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042825 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 470-477) (GM04-585) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 470-477) (GM04-585) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ ↓ teamcadillac.ru 96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 470-477) (GM04-586) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ ↓ tea
