00 - 8-МИ ЦИЛИНДРОВЫЙ ДВИГАТЕЛЬ
(GM00-047) - 2007-2008 CK1 ДВИГАТЕЛЬ В СБОРЕ-6.2L V8 ЧАСТЬ 1 БЛОК ЦИЛИНДРОВ & СОПРЯЖЕННЫЕ ДЕТАЛИ (L92/6.2-8)
11570662 БОЛТ, CONN ROD (PART OF 105) (MJ9X44, 13 THD, 15.5 OD, 12.9, PL)
12493712 BEARING KIT, CONN ROD (STD)
12607475 ROD, CONN (INCLS 102, 103, 106)
19178595 PISTON, (W/PIN) (INCLS 109) (0.5MM O.S.)
19178597 PISTON, (W/PIN) (INCLS 109) (STD)
89018049 RING KIT, PSTN (STD) [НАБОР ПОРШНЕВЫХ КОЛЕЦ]
89018050 RING KIT, PSTN (0.5 MM O.S.)
12569638 RETAINER, PSTN PIN (PART OF 107)
09427693 PLUG, CUP 5/8, CORROSION RESISTANT STL (INCLS 110) (1.531)
12586687 HEATER, ENG COOL (W/2-PIN AND SILVER COLORED)
11588949 PLUG, M16X1.5X14, 24 OD, SAE 1010 STL, GMW3044, W/ AL WASHER (ENG BLK COOL DRN HOLE) [ПРОБКА ЗАМКА]
89017571 BEARING KIT, CR/SHF (#1, 2, 4, 5) (STD)
12561513 KEY, CR/SHF BALR (4.8MMX37.5MM) [ШПОНКА]
12584997 CRANKSHAFT,
12556127 БОЛТ, CR/SHF BRG CAP (SIDE) (SHORT) (M8X1.25X24) [БОЛТ М8]
12560273 STUD, CR/SHF BRG CAP (HFH, M10X2X23, M8X1.25X11, 113.5 TOTAL LONG) [БОЛТ М8]
12560272 БОЛТ, CR/SHF BRG CAP (LONG) (M10X2X102.5, 24.5) [ВИНТ]
01453658 PIN, DOWEL STRAIGHT 5/8 DIA 1 3/16 LG (TRANS LOC)
12606620 PLATE, A/TRNS FLEX (AUTO TRANSMISSION)
11569956 БОЛТ, FLYWHL (M11X1.5X23.5 W/SEALER) [БОЛТ, СПЕЦИАЛЬНЫЙ M11 X 1.5-23.5]
12576652 BALANCER, CR/SHF
12557840 БОЛТ, CR/SHF BALR (M16X2.0X103) [БОЛТ / ВИНТ]
89060436 SEAL KIT, CR/SHF RR OIL (REVERSE LIP SEAL, INCL INSTRUCTION SHEET) [УПЛОТНЕНИЕ КОЛЕНВАЛА]
12583227 CAMSHAFT, ENG (INCL PIN) (INCLS 202) (VEHICLES BUILT WITH AFM USE 2ND DESIGN.FOR 1ST DES SEE 12612273)
12612273 CAMSHAFT, ENG (INCL PIN) (INCLS 202) (VEHICLES BUILT WITHOUT ACTIVE FUEL MANAGEMENT (AFM) USE 1ST DESIGN.FOR 2ND DES SEE 12583227)
19167218 BEARING, CM/SHF (POSN #3) [НАБОР ВКЛАДЫШЕЙ]
24575061 PIN, CM/SHF SPKT LOC (PART OF 200) (17MM LONG)
12589016 RETAINER, CM/SHF (USE WITH BOLT 11561455)
11561283 БОЛТ, HVY HX FLG HD, M16X1.5X63, GMW25 (8.8) STL, GMW3359 (CM/SHF RET)
12585994 ACTUATOR, CM/SHF POSN
12588151 VALVE, CM/SHF POSN ACTR SOL
12556582 SPROCKET, CR/SHF [ШЕСТЕРНЯ КОЛЕНВАЛА]
12586482 CHAIN, CM/SHF TMG [ЦЕПЬ ПРИВОДА ГРМ]
12570326 PIN, CYL HD LOC [ЗАГЛУШКА БЛОКА ЦИЛИНДРОВ]
11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (PART OF 232) [БОЛТ, М8Х1.25Х31.5]
12626407 РОЛИК НАТЯЖИТЕЛЬ KIT, TMG CHAIN (INCLS BOLT, RETAINER) (INCLS 231)
12615666 ШЛАНГИ, CR/SHF RR OIL SEAL (INCLS BOLT, SEAL, GASKET, ШЛАНГИ)
12593587 GASKET, CR/SHF RR OIL SEAL HSG
12585546 SENSOR, CR/SHF POSN (INCLS 702) (ACDelco #213-3520) [ДАТЧИК ПОЛОЖЕНИЯ КОЛЕНВАЛА]
12570125 SENSOR, KNOCK (ACDelco #213-1576)
teamcadillac.ru
11515756 БОЛТ, HFH, M8X1.25X20, 17THD, 18 O.D., 10.9, 7114M (BOLT, CR/SHF POSN SEN) [БОЛТ]
11609289 PLUG, HEX, M28X1.25X13, 10.9, GMW3044, INT DRIVER W/THD SEAL 9985 (ENG BLK COOL DRN HOLE) (8.971)
09427693 PLUG, CUP 5/8, CORROSION RESISTANT STL (ENG BLK OIL GAL) (1.531)
19167383 BEARING, CM/SHF (POSN #1, 5) [ВТУЛКА БЛОКА ЦИЛИНДРОВ]
12453167 BEARING, CM/SHF (# 2&4) [ПОДШИПНИК]
89017572 BEARING KIT, CR/SHF THR (STD) (#3)
(GM00-282) - 2007 CK1 ДВИГАТЕЛЬ В СБОРЕ-6.2L V8 ЧАСТЬ 2 ГОЛОВКА ЦИЛИНДРОВ & СОПРЯЖЕННЫЕ ДЕТАЛИ (L92/6.2-8)(2ND DES-EXC ACTIVE FUEL)
17122490 LIFTER, VLV (RLR) ("NON-ACTIVE FUEL MANAGEMENT LIFTER") (ACDelco #HL124) [ТОЛКАТЕЛЬ КЛАПАНА]
12595365 GUIDE, VLV LFTR (ACCOMMODATES 4 VLV LFTRS EACH, WITH SIDE GROOVES) [НАПРАВЛЯЮЩАЯ КЛАПАНА ДВИГАТЕЛЯ]
12551163 БОЛТ, VLV LFTR GDE (SIDE) (SHORT) (M6X1.0X19)
teamcadillac.ru
10238852 ROD, VLV PUSH [НАПРАВЛЯЮЩАЯ МАСЛООТРАЖАТЕЛЯ]
10214664 ARM, VLV RKR (ARM, VLV RKR EXH. FOR INTKE VLV RKR ARM SEE PN 12569167, QTY 8) [КОРОМЫСЛО КЛАПАНА ДВИГАТЕЛЯ]
12560961 БОЛТ, VLV RKR ARM PIV SUPT (M8X1.25X52.5)
12600936 SUPPORT, VLV RKR ARM PIV
12610046 GASKET, CYL HD [ПРОКЛАДКА ГОЛОВКИ ЦИЛИНДРОВ]
12615361 HEAD, CYL (PARTIAL)
11571134 БОЛТ, CYL HD (M11X2X100)
12558840 БОЛТ, CYL HD (SHORT) (M8X1.25X45) [БОЛТ М8Х1.25Х45]
12482062 SEAL KIT, EXH VLV STEM OIL (22.8MM) (INCLS 8 SEALS) [КОМПЛЕКТ ПРОКЛАДОК ГОЛОВКИ ЦИЛИНДРОВ (8 ШТ)]
12482063 SEAL KIT, INT VLV STEM OIL (W/ПРУЖИНА SHIM) (14.4MM) (INCLS 8 SEALS) [КОМПЛЕКТ ПРОКЛАДОК ГОЛОВКИ ЦИЛИНДРОВ (8 ШТ)]
12589774 ПРУЖИНА, VLV [ПРУЖИНА КЛАПАНА]
10166344 CAP, VLV SPR [СЕДЛО ПРУЖИНЫ КЛАПАНА ДВИГАТЕЛЯ]
10166345 KEY, VLV STEM
12582719 VALVE, EXH (STD) [КЛАПАН]
12617533 VALVE, INT
12627970 VALVE, INT (SILCHROMME 1)
12553191 PLUG, CYL HD CORE HOLE (M12X1.5X21) (HEX, SOC)
24100002 SEAL, OIL FIL TUBE (O RING) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА]
12574386 TUBE, OIL FIL [МАСЛОЗАЛИВНАЯ ГОРЛОВИНА ДВИГАТЕЛЯ]
12573337 CAP, OIL FIL (SAE 5W30, NON-VENTED, SEAL) (INCLS 450) (ACDelco #FC208)
24100002 SEAL, OIL FIL CAP (O RING) (PART OF 424) (27.94MM I.D.) (SIZE #320) (1.745) [ПРОКЛАДКА]
12612045 GASKET, VLV RKR ARM CVR (PART OF 505) [ПРОКЛАДКА КЛАПАННОЙ КРЫШКИ]
12570427 COVER, VLV RKR ARM (INCLS 504, 515, 516, 900) (INCLS:COVER, GASKET, BOLT, DEFLECTOR, FITTING)
12582224 COVER, VLV RKR ARM (INCLS 504, 515, 516) (INCLS:COVER, GASKET, BOLT, DEFLECTOR, FITTING)
12577215 БОЛТ, VLV RKR ARM CVR (INCLS 515) (PART OF 505) (M6.0X1.0) (W/GROMMET, SLEEVE)
12607406 TUBE, PCV (FRESH AIR) [ТРУБКА ВЕНТИЛЯЦИИ КАРТЕРА]
12611592 TUBE, PCV (DIRTY AIR) [ТРУБКА]
12554211 STUD, IGN COIL BRKT (HFH, M6X1X18) (3.330) (ACDelco #12554211)
89018057 WIRE, SPLG (INCLS 901) (*KIT1) (ACDelco #356F) [СВЕЧНОЙ ПРОВОД]
12608814 SENSOR, ENG COOL TEMP (ACDelco #213-4333)
19187357 SENSOR, ENG COOL TEMP (ACDelco #213-4396) (ALL MAKES)
12609877 СВЕЧА, (GAP 0.040) (ACDelco #41-985) (IRIDIUM)
12567915 FITTING, PCV (PART OF 505)
15336959 SHIELD, SPLG WIRE (PART OF 724) (ACDelco #8006)
12569167 ARM, INT VLV RKR (USE WITH QTY 08 OF 10214664) (ARM, VLV RKR INT. FOR EXHST VLV RKR ARM SEE PN 10214664, QTY=8)
89018058 WIRE KIT, SPLG (INCLS 724) (INCLS SET OF 8 LEADS) (ACDelco #748RR) [НАБОР КАБЕЛЯ СВЕЧИ]
(GM00-283) - 2007 CK1 ДВИГАТЕЛЬ В СБОРЕ-6.2L V8 ЧАСТЬ 2 ГОЛОВКА ЦИЛИНДРОВ & СОПРЯЖЕННЫЕ ДЕТАЛИ (L92/6.2-8)(1ST DES-ACTIVE FUEL "AFM")
12551163 БОЛТ, VLV LFTR GDE (M6X1.0X19)
12571595 LIFTER, VLV ("ACTIVE FUEL MANAGEMENT LIFTER") (ACDelco #HL178) [ТОЛКАТЕЛЬ КЛАПАНА]
12617533 VALVE, INT
12607406 TUBE, PCV (FRESH AIR TUBE) (FRESH AIR) [ТРУБКА ВЕНТИЛЯЦИИ КАРТЕРА]
teamcadillac.ru
(GM00-338) - 2007-2008 CK1 ДВИГАТЕЛЬ В СБОРЕ-6.2L V8 ЧАСТЬ 3 ПЕРЕДНЯЯ КРЫШКА & COOLING (L92/6.2-8)
12585673 SEAL, CR/SHF FRT OIL (PART OF 502) (0.207) (ACDelco #296-02) [ПРОКЛАДКА]
12551926 БОЛТ, W/PMP (M8X1.25X83) [БОЛТ-M8 X 1.25 X 82.6]
11516480 БОЛТ, W/PMP INL (PART OF 300) (M6X1X25-10MM SOC)
12587395 INLET, W/PMP (PART OF 300) (ACDelco #15-10595)
89018168 THERMOSTAT KIT, ENG COOL (INCL SEAL) (PART OF 300) (INCLS 900) (ACDelco #131-160) [КЛАПАН РЕГУЛИРОВКИ ТЕМПЕРАТУРЫ СИСТЕМЫ ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ]
12559271 GASKET, W/PMP (2 OBLONG & 1 ROUND MTG HOLES, AT PUMP MANIFOLD) (ACDelco #12559271)
teamcadillac.ru
12605716 PIPE, ENG COOL AIR BL (INCLS 308, 903)
12602541 SEAL, ENG COOL AIR BL PIPE (O RING) (SINGLE TYPE ONE HOLE O-RING) (PART OF 307, 313)
11514008 БОЛТ, METRIC HEX FLG HD (M6X1X30) (POR 9.8) (ENG COOL AIR BL PIPE) (1.097)
12602540 COVER, ENG COOL AIR BL PIPE HOLE (INCLS 308) (INCL SEALS)
11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (PART OF 502) [БОЛТ, М8Х1.25Х31.5]
12616491 COVER, ENG FRT (INCLS COVER, SEAL, WIRE, JUMPER, BRACKET, GASKET, BOLT, SENSOR, MAGN ET) (INCLS 140, 501, 503, 703, 704, 737, 738, 751-753)
12574294 GASKET, ENG FRT CVR (PART OF 502) [ПРОКЛАДКА]
12591720 SENSOR, CM/SHF POSN (PART OF 502) (INCLS 704) (ACDelco #213-3826) [ДАТЧИК]
11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (PART OF 502)
12585995 MAGNET, CM/SHF POSN ACTR (PART OF 502)
12594339 SEAL, CM/SHF POSN ACTR CVR (PART OF 502)
12587397 SEAL, WAT INL (PART OF 305, 300) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО БЛОКА ЦИЛИНДРОВ]
89021297 ADHESIVE/SEALANT, THREADLOCKER HI STRENGTH 10ML ERI (PART OF 300) [АДГЕЗИВ]
12600254 HOSE, ENG COOL AIR BL PIPE DPNG (PART OF 307)
12602048 PLUG, ENG COOL AIR BL (55MM, ALUMINUM)
(GM00-339) - 2007-2008 CK1 ДВИГАТЕЛЬ В СБОРЕ-6.2L V8 ЧАСТЬ 4 МАСЛОНАСОС, PAN & СОПРЯЖЕННЫЕ ДЕТАЛИ (L92/6.2-8)
12573460 PLUG, ENG BLK OIL GAL (INCLS 110) (15.68MM DIA) (INCLS O-RING SEAL (N.S.S.)
11609289 PLUG, HEX, M28X1.25X13, 10.9, GMW3044, INT DRIVER W/THD SEAL 9985 (ENG BLK OIL GAL) (8.971)
11588949 PLUG, M16X1.5X14, 24 OD, SAE 1010 STL, GMW3044, W/ AL WASHER (ENG BLK OIL GAL) [ПРОБКА ЗАМКА]
12609074 PAN, OIL (INCLS 426-428, 430, 433-435, 438, 439, 453, 727, 728, 900-902) (INCLS BAFFLE, BOLTS, GASKET, LABEL, COVER, DEADENER, FITTING, SWITCH)
11515742 ГАЙКА, PREVAILING TORQUE TENSION FLG HD (M8X1.25X17.4 OD (CR/SHF OIL DFL)
11516521 БОЛТ, HFH M6X1X20, 9.8, 7114M, DOG PT, 14.2 OD (O/PMP SUC PIPE)
12584922 SEAL, O/PMP SUC PIPE (O RING) (PART OF 407) (20.69MM I.D., 4.20MM THICKNESS) (TEFLON COATED) (1.724) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО МАСЛОЗАБОРНИКА]
12608579 SCREEN, O/PMP (W/SUC PIPE) (INCLS 406)
11519133 БОЛТ, SELF TAP, M6X1X20, 13.2 O.D. (PART OF 413)
11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (O/PMP) [БОЛТ, М8Х1.25Х31.5]
12612289 PUMP, OIL (INCLS 408, 410, 411, 414-416)
24504091 SEAL, OIL LVL IND (O RING) (PART OF 418) (BLACK) (6.07MM ID, 1.78MM DIA)
12610053 INDICATOR, OIL LVL (INCLS 417) (WITH DUAL O-RING)
11588736 БОЛТ, HFH, M10X1.5X20, 10 THD, 22.3 O.D., 10.9, GMW3359 (OIL LVL IND TUBE)
12563918 TUBE, OIL LVL IND (INCLS 421) (INCLS SEAL)
24504091 SEAL, OIL LVL IND TUBE (O RING) (PART OF 420) (BLACK) (6.07MM ID, 1.78MM DIA)
teamcadillac.ru
12611129 DEFLECTOR, CR/SHF OIL
12558760 GASKET, МАСЛЯНЫЙ ПОДДОН (PART OF 400) (CODE CNB WYA)
11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (PART OF 400)
11562588 PLUG, МАСЛЯНЫЙ ПОДДОН DRN (PART OF 400) (W/ SEAL) (EXC MAGNET) [ЗАГЛУШКА МАСЛЯНОГО ПОДДОНА]
12611384 GASKET, МАСЛЯНЫЙ ПОДДОН CVR (USE T/W 11588714 BOLT QTY 02) (PART OF 400)
12577903 COVER, МАСЛЯНЫЙ ПОДДОН (PART OF 400)
11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (PART OF 400) [БОЛТ]
89017524 ФИЛЬТР, МАСЛЯНЫЙ (ACDelco #PF48) [МАСЛЯНЫЙ ФИЛЬТР ДВИГАТЕЛЯ]
12600225 FITTING, OIL FLTR (PART OF 400)
11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (PART OF 400) [БОЛТ, М8Х1.25Х31.5]
11588714 БОЛТ, МАСЛЯНЫЙ ПОДДОН (PART OF 400) (M6 X 1.0 X 30) (8.900) [БОЛТ]
12554990 БОЛТ, МАСЛЯНЫЙ ПОДДОН (RR POSITIONS) (PART OF 400) (M6X1.0X136)
12603782 SWITCH, ENG OIL LVL IND (PART OF 400) (INCLS 728) [ВЫКЛЮЧАТЕЛЬ]
10151633 SEAL, ENG OIL LVL SEN (PART OF 400, 727)
12608835 VALVE, OIL PRESS RLF (PART OF 400)
12594870 DEADENER, МАСЛЯНЫЙ ПОДДОН (PART OF 400)
11589241 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (PART OF 400)
12346004 SEALANT, LOCTITE PIPE-W/TEFLON 50CC TUBE (МАСЛЯНЫЙ ПОДДОН) [ГЕРМЕТИК С ТЕФЛОНОМ]
12558759 RIVET, МАСЛЯНЫЙ ПОДДОН GSKT
(GM00-357) - 2007 CK1 ДВИГАТЕЛЬ В СБОРЕ-6.2L V8 ЧАСТЬ 5 MANIFOLD & FUEL СОПРЯЖЕННЫЕ ДЕТАЛИ (L92/6.2-8)(2ND DES-EXC ACTIVE FUEL)
12580678 MANIFOLD, INT
11518075 БОЛТ, HFH, THD 22, OD 17, 8.8, GMW14C-PT, HDR POINT (PART OF 555) [ВИНТ М10]
12580760 BODY, THROT (W/THROT ACTR) (ACDelco #217-2422) [ДРОССЕЛЬНАЯ ЗАСЛОНКА]
12589235 SEAL, THROT BODY (ACDelco #217-2424) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ДРОССЕЛЬНОЙ ЗАСЛОНКИ]
12580910 БОЛТ, F/INJR DRVR MDL
12575384 БОЛТ, INT MANIF
teamcadillac.ru
89060434 GASKET, INT MANIF [ПРОКЛАДКА ВЫПУСКНОГО КОЛЛЕКТОРА (2ШТ)]
12574886 SEAL, ENG BLK VALLEY CVR HIGH PRESS PORT (PART OF 555)
12598832 COVER, ENG BLK VALLEY (INCLS 506, 537, 556) (INCLS COVER, BOLTS, GASKET, SEAL)
12610141 GASKET, ENG BLK VALLEY CVR (PART OF 555) [ПРОКЛАДКА БЛОКА ЦИЛИНДРОВ]
12593801 BRACKET, F/INJN FUEL RL
12616285 MANIFOLD, EXH (INCLS 603, 604) (INCLS SHIELD, BOLTS) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ]
12616286 MANIFOLD, EXH (INCLS 603, 604) (INCLS SHIELD, BOLTS) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ]
12600530 GASKET, EXH MANIF
11518860 БОЛТ, HFH, M8X1.25X30, 20.9 THD, 18 O.D., 10.9, GMW3179 CODE G, GM6194M (EXH MANIF FLG) [БОЛТ]
12562243 SHIELD, EXH MANIF HT (PART OF 600)
12562244 SHIELD, EXH MANIF HT (PART OF 600)
24505098 БОЛТ, HFH, RND HD, 6X1X12.15, W/ANTI SEIZE, 14.2 O.D.DG PT, 10.9, 711 (PART OF 600)
12616646 SENSOR, ENG OIL PRESS (ACDelco #D1846A) [ДАТЧИК]
12578463 STOP, F/INJN FUEL RL
11515764 БОЛТ, HFH, M10X1.5X20, 18THD, 22.3 O.D., 10.9, 7114M (F/INJN FUEL RL STOP)
09359409 SENSOR, MAP (PUSH-IN) (INCLS SEAL) (INCLS 715) (ACDelco #9359409)
16194007 SEAL, MAP SEN (PART OF 714) [УПЛОТНИТЕЛЬ ДАТЧИКА ДАВЛЕНИЯ ПОТОКА ВОЗДУХА]
12574897 HARNESS, EVAP EMIS CNSTR
12606684 VALVE, EVAP EMIS CNSTR PURGE SOL (ACDelco #214-2142) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ]
12617169 TUBE, EVAP EMIS CNSTR PURGE
12594132 RETAINER, MAP SEN
89017591 BOLT KIT, THROT BODY (INCLS 507, 538, 901) (INCLS BOLT, STUD, NUT)
(GM00-358) - 2007 CK1 ДВИГАТЕЛЬ В СБОРЕ-6.2L V8 ЧАСТЬ 5 MANIFOLD & FUEL СОПРЯЖЕННЫЕ ДЕТАЛИ (L92/6.2-8)(1ST DES-ACTIVE FUEL "AFM")
12571609 MANIFOLD, VLV LFTR OIL (ДВИГАТЕЛЬS BUILD WITH AFM PROIR TO 4/01/06) (INCLS 452, 506, 556) [ВПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ]
12585328 ФИЛЬТР, VLV LFTR OIL (ДВИГАТЕЛЬS BUILD WITH AFM PROIR TO 4/01/06) (PART OF 451) [МАСЛЯНЫЙ ФИЛЬТР]
11518075 БОЛТ, HFH, THD 22, OD 17, 8.8, GMW14C-PT, HDR POINT (PART OF 451) [ВИНТ М10]
89017690 GASKET, VLV LFTR OIL UPR MANIF (ДВИГАТЕЛЬS BUILT WITH AFM PRIOR TO 4/01/06) (PART OF 451) [ПРОКЛАДКА МАСЛЯНОГО КОЛЛЕКТОРА]
teamcadillac.ru
(TC00-900) - 2007-2009 CK1 SHIELD/ДВИГАТЕЛЬ SPLASH
15203366 SHIELD, ENG [ЗАЩИТНАЯ ПАНЕЛЬ МОТОРНОГО ОТСЕКА]
11518341 БОЛТ, HEX, M10X1.5X25, 14 THD, 28 OD, 6202M, 7114M, TAP, TR-PT (ENG SHLD) [БОЛТ М10Х1.5Х25]
(TC00-902) - 2007-2008 CK1,2,3 INTAKE MANIFOLD SHIELD/COVERS (LY6/6.0K,L76/6.0Y,L92/6.2-8)
15943789 SHIELD, UPR INT MANIF SIGHT (INCLS 2) [ЗАЩИТА]
teamcadillac.ru
19167507 GROMMET, UPR INT MANIF SIGHT SHLD (PART OF 1) (3.407)
11609319 STUD, UPR INT MANIF SIGHT SHLD (3.671)
11516075 ГАЙКА, HFH SELF LK, M6X1, 7.7THK, 14.2 O.D., 9, PZOR (UPR INT MANIF CVR) [ГАЙКА ВЫПУСКНОЙ СИСТЕМЫ D=6ММ]
12610052 COVER, UPR INT MANIF (INCLS 6) (INCLS COVER, GROMMET, INSULATOR)
12559065 GROMMET, UPR INT MANIF SIGHT SHLD (PART OF 5) (12.0 DIA X 2.4 DEEP)
15858430 RETAINER, UPR INT MANIF SIGHT SHLD (INCLS 8)
11514623 БОЛТ, HEX W/CON WA, M6X1X20 (UPR INT MANIF SIGHT SHLD)
(TC00-908) - 2007-2008 CK1 ДВИГАТЕЛЬ В СБОРЕ & PARTIAL ДВИГАТЕЛЬ (L92/6.2-8)
19178610 ДВИГАТЕЛЬ, GASOLINE (GOODWRENCH NEW) (APPLIES FOR ДВИГАТЕЛЬS WITH AND WITHOUT AFM-PLEASE REVIEW SERVICE BULLETIN) [ДВИГАТЕЛЬ БЕНЗИНОВЫЙ 8-ЦИЛИНДРОВЫЙ 403 Л.С, 6162 КУБ.СМ]
(TC00-910) - 2007-2008 K1 ДВИГАТЕЛЬ & КРЕПЛЕНИЕ ТРАНСМИССИИ-V8 (L76/6.0Y,L92/6.2-8)
15854939 MOUNT, ENG [ОПОРНЫЙ УЗЕЛ ДВИГАТЕЛЯ]
11517639 БОЛТ, ENG MT SUPT (TO FRAME BRKT) (12X1.75X44, 35THD) (4.665) [БОЛТ М10]
teamcadillac.ru
11609475 БОЛТ, HFH W/CON SPR WA, M10X1.5X33, 24 THD, 22.3 OD, 10.9, GMW3359 (ENG MT) [БОЛТ М10]
15840278 MOUNT, TRANS [ОПОРНЫЙ УЗЕЛ КПП]
11517827 БОЛТ, HFH W/FL WA, M10X1.5X35, 20 THD, 25 OD, 9.8, 7114M, MACH, P-PT, 6175M A (TRANS MT) [БОЛТ М10]
11516754 ГАЙКА, HEX, W/CON SPR WA, M10X1.5, 10THK, 28 O.D., 10, 7111M (TRANS MT) [ГАЙКА М10]
(TX00-151) - 2007 CK1(06-36) TRANSMISSION CONVERTER SHIELDS (MYC,M30,M70)
12561536 COVER, TRANS (ACDelco #12561536)
teamcadillac.ru
12560226 БОЛТ, HEX W/FLAT WASH, M6.0X1.0X14.5, 13.5, 17 OD, 9.8, 7114M, MACH (TRANS CVR)
11589040 БОЛТ, TRANS T/CV [БОЛТ М10]
11515768 БОЛТ, HFH, REDUCED BODY, M10X1.5X40, 30THD, 22.3 O.D., HDR PT, 10.9, 7114M (TRANS) [БОЛТ М10Х1.5Х40]
11519797 STUD, TRANS (DOUBLE END, HFH, M8X1.25X20, M10X1.5X40, 18 OD, 69.5 TL9.8, GMW3359)
24205899 PLUG, T/CV HSG ACC HOLE (28MM W/3 TANGS) (SMALL CVR) (ACDelco #24205899)
24205900 COVER, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП]
12561303 COVER, TRANS (ACDelco #12561303)
01 - СИСТЕМА ОХЛАЖДЕНИЯ - РЕШЕТКА РАДИАТОРА-МАСЛОСИСТЕМА
(TC01-616) - 2007-2008 CK1,2,3 НАТЯЖИТЕЛЬ РЕМНЯ/ACCESSORY DRIVE (LY6/6.0K,L76/6.0Y,L92/6.2-8)
12609719 РОЛИК НАТЯЖИТЕЛЬ, DRV BELT (2 BOLT DESIGN REPLACES 3 BOLT DESIGN) [ШКИВ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ]
12580771 PULLEY, BELT IDLER (SMOOTH CODE 5609, 0771) [НАБОР ШКИФОВ]
12580196 РОЛИК НАТЯЖИТЕЛЬ, A/C CMPR BELT [НАТЯЖИТЕЛЬ ПРИВОДНОГО РЕМНЯ]
11515767 БОЛТ, HFH, M10X1.5X35, 32THD, 22.3 O.D., MACH, 10.9, 7114M (A/C CMPR BELT TENSR) (T/W 12345493) [БОЛТ]
12626222 BELT, FAN & W/PMP & GEN & P/S PUMP [ПРИВОДНОЙ РЕМЕНЬ ГЕНЕРАТОРА 234,5 СМ]
12576447 BELT, A/C CMPR (960MM, 4 RIB) (CODE WAX, UWZ, URM) [ПРИВОДНОЙ РЕМЕНЬ КОМПРЕССОРА КОНДИЦИОНЕРА 96 СМ]
11516109 БОЛТ, HFH, REDUCED BODY, M10X1.5X65, 25 THD, 22.3 O.D., HDR PT, 10.9, 7114M (DRV BELT TENSR) [БОЛТ, М10Х1.5Х65.22]
11515767 БОЛТ, HFH, M10X1.5X35, 32THD, 22.3 O.D., MACH, 10.9, 7114M (DRV BELT TENSR) (T/W 12345493) [БОЛТ]
(TC01-902) - 2007 K1(06) РЕШЕТКА РАДИАТОРА (G.M.C. Z88, DENALI Y91)
11561788 CLIP-U, 13X15X12, 1.5 PNL, 1050, 6280M (PART OF 1) [ФИКСАТОР МОЛДИНГА КАПОТА]
11518121 ГАЙКА, U, M6X1, MULTI THD, .5'-4.0' THK PNL (RAD GRL UPR BRKT)
teamcadillac.ru
10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (FRT TOW HOOK) [ПИСТОН КРЕПЛЕНИЯ ОБЛИЦОВКИ БАМПЕРА (NYLON)]
15264513 GRILLE, RAD LWR (INCLS 6) (CHROME)
11515638 ГАЙКА, U-TYPE, M4.2X1.41X10.5.5X22, .65-3.8 PNL THK, 1050, ZF (RAD GRL) [ГАЙКА М4.2]
11609465 БОЛТ, HWH, M4.2X1.41X18, 12.5 OD, 6010M, PS (RAD GRL) (8.977) [ВИНТ М6]
25891152 GRILLE, RAD UPR (CHROME) (IF GRILLE ON FASCIA IS RIVETED;DRILL OUT RIVET HOLES ON FASCIA TO 8.835MM & ATTACH GRILLE TO FASCIA W/2 U-NUTS 11515638 & 2 BOLTS 11589015)
11610055 БОЛТ, HWASH, M6X1X23 (FRT BPR UPR FASCIA)
(TC01-903) - 2007 CK1(06-36) РЕШЕТКА РАДИАТОРА (CADILLAC Z75)
25705182 БОЛТ, FRT BPR FASCIA CTR SUPT (M9.5X6.0 HI-LO, TL 47MM, 22 OD) (12.249) [ВИНТ М5]
teamcadillac.ru
25795238 GRILLE, RAD (INCLS 1-4, 8) (BLUE) [РЕШЕТКА РАДИАТОРА]
25795239 GRILLE, RAD (INCLS 1-4, 8) (RED)
25795240 GRILLE, RAD (INCLS 1-4, 8) (WHITE) [РЕШЕТКА РАДИАТОРА]
25795241 GRILLE, RAD (INCLS 1-4, 8) (ANTIQUE BROWN)
25795242 GRILLE, RAD (INCLS 1-4, 8) (BLACK)
25795243 GRILLE, RAD (INCLS 1-4, 8) (GOLD) [РЕШЕТКА РАДИАТОРА]
25795244 GRILLE, RAD (INCLS 1-4, 8) (SILVER) [РЕШЕТКА РАДИАТОРА]
25795245 GRILLE, RAD (INCLS 1-4, 8) (RED JEWEL) [РЕШЕТКА РАДИАТОРА]
25840443 GRILLE, RAD (INCLS 1-4, 8) (BLUE)
25840444 GRILLE, RAD (INCLS 1-4, 8) (GRAY) [РЕШЕТКА РАДИАТОРА]
25840445 GRILLE, RAD (INCLS 1-4, 8) (SONOMA JEWEL)
15126354 EMBLEM, RAD GRL (PART OF 7) (MEDALLION) (USE ON VEHICLES BUILT WITH 1-PIECE DESIGN) (FOR 2ND DES SEE 25795247) [ЭМБЛЕМА РЕШЕТКИ РАДИАТОРА]
25795247 EMBLEM, RAD GRL (PART OF 7) (WREATH/CREST) (USE ON VEHICLES BUILT WITH 2-PIECE DESIGN) (FOR 1ST DES SEE 15126354) [ЭМБЛЕМА РЕШЕТКИ РАДИАТОРА]
15907251 MOLDING, КАПОТ FRT (INCLS 10) [МОЛДИНГ КАПОТА]
11610051 RETAINER, КАПОТ FRT MLDG (PART OF 9)
(TC01-905) - 2007-2008 CK1(06-36) КРЕПЛЕНИЕ РАДИАТОРА & СОПРЯЖЕННЫЕ ДЕТАЛИ (CADILLAC Z75)
15780790 INSULATOR, ENG COOL FAN SHRD (UPPER) [ДЕМПФЕР РАДИАТОРА]
11516931 БОЛТ, FLAT WA & METRIC HEX HD MACHINE, M8X1.25X50 (ENG COOL FAN)
teamcadillac.ru
15780791 INSULATOR, ENG COOL FAN SHRD (LOWER) [ДЕМПФЕР РАДИАТОРА]
11516931 БОЛТ, FLAT WA & METRIC HEX HD MACHINE, M8X1.25X50 (RAD UPR MT)
89019121 MOUNT, RAD LWR (PART OF 7)
10392941 BAFFLE, RAD SUPT
19130464 STRAP, TIE 0.38" WIDTH, BUNDLE DIA 1/16"-1-3/4", 8.27" LENGTH, NYLON 6/6 FITS 0. (WRG HARN) [ХОМУТ (ЗАЖИМ) РАДИАТОРА]
15958694 RETAINER, RAD SUPT BFL (1LH/4RH) (BLACK) (7.6DIA X 22.9 MM) (X-MAS TREE) (FOR HOLE 6.30-6.55 DIA) (16.850) [ФИКСАТОР МОЛДИНГА КУЗОВА]
15208497 BAFFLE, RAD AIR (INCLS 12)
15837581 CUSHION, BODY BOLT UPR FRT (VIOLET) (1.270) [ДЕМПФЕР РАДИАТОРА]
15201791 CUSHION, BODY BOLT LWR FRT (71MM OD)
03537772 ГАЙКА, M12X1.75, 10.6THK, 28 O.D., 10, 7111M (BODY MT) (8.917)
11562547 БОЛТ, HFH, M12X1.75X135, 100 THD, 24.7 OD, GMW25 (10.9) STL, GM 7112M, MACH (BODY MT)
15208496 BAFFLE, RAD AIR (INCLS 12)
10392942 BAFFLE, RAD SUPT
11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (PART OF 23) [ШАЙБА]
11610055 БОЛТ, HWASH, M6X1X23 (RAD GRL SUPT REINF)
15904442 BRACKET, RAD GRL UPR (INCLS 21, 24) [ПОПЕРЕЧНАЯ ПАНЕЛЬ КУЗОВА]
22581725 CLIP, КАПОТ PRIM LAT REL CBL (PART OF 23) (7.0 MM DIA) (HOLDS (1) PIPE 4.76 TO 6.35) (3.145) [ФИКСАТОР ТОРМОЗНОЙ ТРУБКИ]
25861241 BAFFLE, RAD AIR UPR (INCLS 27) (INCLS LABEL) [ОБТЕКАТЕЛЬ РАДИАТОРА]
11561878 RETAINER, PUSH PIN W/SEAL, FITS 8.0-8.25 DIA HOLE IN 3-7MM THK PNL (RAD AIR UPR BFL (PUSH IN)) [ФИКСАТОР ОПОРЫ БЛОКА УПРАВЛЕНИЯ]
11562546 WASHER, FLAT, 14X42.5X3.61 MM, SAE 1050 STL RC 37-43, 7112M (BODY MT)
(TC01-907) - 2007-2009 CK1(06-36) КРЕПЛЕНИЕ РАДИАТОРА В СБОРЕ
15945502 SUPPORT, RAD (INCLS 2-10) [ПАНЕЛЬ ПЕРЕДНЕЙ ЧАСТИ КУЗОВА]
25955528 SUPPORT, RAD (INCLS 2-10)
11561916 NUT-INSERT, M8X1.25, 13.5 HOLE, 0.7-3.8 GRIP, 24 LONG, 17.4 OD, 1008, GMW (PART OF 1, 3)
25870919 SUPPORT, F/END UPR TIE BAR (INCLS 2, 4, 6) (PART OF 1) [ПОПЕРЕЧНАЯ БАЛКА КУЗОВА]
11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (PART OF 1, 9) [БОЛТ М6]
11561407 NUT-INSERT , M6X1, 10MM HOLE, 1.7-5.25 PANEL, 19 LONG, 12.9 OD, 1008, GMW3 (PART OF 1, 3, 9) (8.921)
11516932 БОЛТ, HEX HD, W/CON WA, M6X1X25, 9.8, 6138M (PART OF 1)
teamcadillac.ru
15744933 БОЛТ, HEX HD, W/CON WA, M6X1X45 (PART OF 1) (1.267)
25870915 BRACE, F/END SH MET RAD OPG (INCLS 5, 6, 10) (PART OF 1)
25870916 BRACE, F/END SH MET RAD OPG (INCLS 5, 6, 10) (PART OF 1)
25870918 BRACE, F/END SH MET CR (PART OF 1, 9)
(TC01-909) - 2007-2009 CK1 SKID PLATE/МАСЛЯНЫЙ ПОДДОН(NZZ)
15843753 PLATE, МАСЛЯНЫЙ ПОДДОН SKID
teamcadillac.ru
11518341 БОЛТ, HEX, M10X1.5X25, 14 THD, 28 OD, 6202M, 7114M, TAP, TR-PT (МАСЛЯНЫЙ ПОДДОН SKID PLT) [БОЛТ М10Х1.5Х25]
(TC01-911) - 2007 CK1(06) ВЕНТИЛЯТОР ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ (G.M.C. Z88, L92/6.2-8)
teamcadillac.ru
15780790 INSULATOR, ENG COOL FAN SHRD (PART OF 5) (UPPER) [ДЕМПФЕР РАДИАТОРА]
10309116 LABEL, FAN BLADE WRNG (PART OF 5) (BLACK NYLON)
11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (PART OF 5) [ШАЙБА]
15780788 SHROUD KIT, ENG COOLING FAN (INCLS 1, 2, 4, 6, 7, 11) (5/7 FAN BLADES) [ОБТЕКАТЕЛЬ РАДИАТОРА]
15780789 SHROUD KIT, ENG COOLING FAN (INCLS 1, 2, 4, 6, 7, 11) (7/9 FAN BLADES) [ОБТЕКАТЕЛЬ РАДИАТОРА]
15780791 INSULATOR, ENG COOL FAN SHRD (PART OF 5) (LOWER) [ДЕМПФЕР РАДИАТОРА]
15780792 SPACER, ENG COOL FAN SHRD (PART OF 5)
22728347 БОЛТ, ENG COOL FAN SHRD
22722593 CLIP, ENG COOL FAN SHRD (PART OF 5, 8, 10, 12)
(TC01-912) - 2007-2008 CK1(06-36) ВЕНТИЛЯТОР ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ (CADILLAC Z75, L92/6.2-8)
15780788 SHROUD KIT, ENG COOLING FAN (INCLS 1, 2, 4, 6, 7, 12) (5/7 FAN BLADES) [ОБТЕКАТЕЛЬ РАДИАТОРА]
15780789 SHROUD KIT, ENG COOLING FAN (INCLS 1, 2, 4, 6, 7, 12) (7/9 FAN BLADES) [ОБТЕКАТЕЛЬ РАДИАТОРА]
15780795 MOTOR KIT, ENG CLG FAN (INCLS 12) (700 WATT) (ACDelco #15-80880)
15780796 MOTOR KIT, ENG CLG FAN (INCLS 12) (700 WATT) (ACDelco #15-80881) [ЭЛ.ДВИГАТЕЛЬ ВЕНТИЛЯТОРА РАДИАТОРА, 70ВТ]
teamcadillac.ru
15780794 BLADE KIT, ENG CLG FAN (9-BLADE) (INCLS 12) (ACDelco #15-80883)
22722593 CLIP, ENG COOL FAN SHRD (PART OF 5, 8, 9, 11, 13)
15780793 BLADE KIT, ENG CLG FAN (7-BLADE) (INCLS 12) (ACDelco #15-80882) [ВЕНТИЛЯТОР РАДИАТОРА, 90ВТ]
(TC01-913) - 2007-2008 CK1,2,3 ТРУБКИ РАДИАТОРА (LY6/6.0K,L76/6.0Y,L92/6.2-8)
15833723 TANK, RAD SURGE (ACDelco #15833723) [РАСШИРИТЕЛЬНЫЙ БАЧОК СИСТЕМЫ ОХЛАЖДЕНИЯ]
15012559 CLAMP, SPR (18.4MM TO 21.6MM) NOMINAL SIZE 20MM, STAMPED "20" (RAD SURGE TK INL HOSE) (1.240)
15834774 HOSE, RAD SURGE TK INL
25976471 HOSE, RAD VENT INL
15734742 CLAMP, RAD SURGE TK ENG HOSE (13-16MM DIA RANGE)
15041309 CLIP, RAD VENT INL HOSE
15004599 CLAMP, RAD SURGE TK ENG HOSE (BLACK) (15MM OD 17.2MM) [ХОМУТ ТРУБОПРОВОДА]
19130015 HOSE, RAD OTLT [ШЛАНГ РАДИАТОРА]
11562099 CLAMP-ПРУЖИНАBAND, NOMINAL DIA 49MM, 20 WIDTH, MAT'L 6298M, ROBO FINISH (RAD OTLT HOSE RAD) [ХОМУТ ШЛАНГА СИСТЕМЫ ОХЛАЖДЕНИЯ]
15045503 CLIP, RAD SURGE TK INL HOSE (PART OF 13) (CLIP TO HOLD 37-44 DIA HOSE AND 12.8-15 DIA VENT HOSE) (1.166)
teamcadillac.ru
25976470 HOSE, RAD INL (INCLS 11, 12)
11518559 CLAMP, ПРУЖИНАBAND, 42MM NOMINAL DIA, 20 WIDTH, 6298M, 6164M (RAD INL HOSE) [ХОМУТ ШЛАНГА РАДИАТОРА]
11517136 CLAMP, HOSE SPR, 27 NOM, 25.2 MIN-28.9 MAX, 15MM WIDE, BLACK (RAD SURGE TK OTLT HOSE)
15834772 HOSE, RAD SURGE TK OTLT
15834773 HOSE, RAD SURGE TK OTLT
15012561 CLAMP, HOSE SPR, 27 NOM, 25.2 MIN-28.9 MAX, 15MM WIDE, BLACK (RAD SURGE TK OTLT HOSE) (8.948)
11609982 БОЛТ, RAD SURGE TK (6 X 1 X 22) (8.900)
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (RAD SURGE TK) [ГАЙКА М6]
15075118 CAP, RAD SURGE TK (15 PSI DUAL O-RING) (ENGLISH/FRENCH LABEL) (ACDelco #RC98) [КРЫШКА БАЧКА РАДИАТОРА]
(TC01-915) - 2007 CK1 ПОДОГРЕВАТЕЛЬ БЛОКА ДВИГАТЕЛЯ (LC9/5.3-3,LH6/5.3M,L76/6.0Y,L92/6.2-8)
15801282 CORD, ENG COOL HTR
teamcadillac.ru
11610073 БОЛТ, ENG COOL HTR CORD CLIP (M8X1.25X16, 12.45THD) (13MM SOCKET) (8.900)
(TC01-918) - 2007-2008 CK1 РАДИАТОР В СБОРЕ (LC9/5.3-3,LH6/5.3M,LMG/5.3-0,LY2/4.8C,LY5/5.3J,L92/6.2-8)
15841568 RADIATOR, (CORE SIZE 34IN X 18 1/2IN X 1 5/16IN CODE CCJ, ARS, ATN) (INCLS 2-5) (ACDelco #21647) [ЛАМПОЧКА ПРОТИВОТУМАННОЙ ФАРЫ 27 ВТ]
15841571 RADIATOR, (CORE SIZE 34IN X 18 1/2IN X 1 1/8IN, CODE APC, ASA, ATS) (INCLS 2-5) (ACDelco #21650) [РАДИАТОР]
15226661 CONNECTOR, TRANS FLUID CLR PIPE (PART OF 1) (INCLS 4) (9/16-18) (3/8 BODY QUICK CONNECT) (AT RAD) (ACDelco #15226661)
19210848 CONNECTOR, TRANS FLUID CLR PIPE (PART OF 1) (INCLS 4) (W/O BEVEL WASHER) (ACDelco #19210848)
teamcadillac.ru
24205103 RETAINER, TRANS FLUID CLR PIPE FTG (PART OF 1, 3) (EXPANDING ПРУЖИНА WIRE) (ACDelco #24205103) [СТОПОРНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ]
89019121 MOUNT, RAD LWR (PART OF 1)
02 - СТАРТЕР - ГЕНЕРАТОР - ЗАЖИГАНИЕ - ЭЛЕКТРИКА - ЛАМПЫ
(GM02-014) - 2007-2008 CK1,2,3 ВЫСОКОВОЛЬТНЫЕ ПРОВОДА (LY6/6.0K,L76/6.0Y,L92/6.2-8)
15336959 SHIELD, SPLG WIRE (ACDelco #8006)
89018057 WIRE, SPLG (*KIT1) (ACDelco #356F) [СВЕЧНОЙ ПРОВОД]
89018058 WIRE KIT, SPLG (INCLS 3) (INCLS SET OF 8 LEADS) (ACDelco #748RR) [НАБОР КАБЕЛЯ СВЕЧИ]
(GM02-126) - 2007-2008 CK1,2,3 COIL & MODULE/IGNITION (MELCO)(LY6/6.0K,L76/6.0Y,L92/6.2-8)
11516424 БОЛТ, HFH, M6X1X25, 14.2 O.D., HDR PT, 9.8, ZE (IGN COIL) [БОЛТ М6]
teamcadillac.ru
12611424 COIL, IGN (MELCO-MITSUBISHI) (W/SQUARE-SHAPED COILS AND MARKED 12570616) (ACDelco #D510C)
12580353 BRACKET, IGN COIL (ACDelco #12580353)
12579355 WIRE, IGN COIL (INCLS CONNS) (ACDelco #357A)
(GM02-127) - 2007-2008 CK1,2,3 COIL & MODULE/IGNITION (DELPHI)(LY6/6.0K,L76/6.0Y,L92/6.2-8)
teamcadillac.ru
11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (IGN COIL)
12573190 COIL, IGN (DELPHI) (W/ROUND-SHAPED COILS AND MARKED 12573190)) (ACDelco #D514A) [КАТУШКА ЗАЖИГАНИЯ]
(GM02-129) - 2007-2009 CK1,2,3 КЛЮЧ И ЦИЛИНДР ЗАМКА/ЗАЖИГАНИЕ
teamcadillac.ru
15794826 CYLINDER KIT, IGN LK (INCLS 1, 2, 3) [ЦИЛИНДР]
15926907 КЛЮЧ, ЗАЖИГАНИЯ LK (PRE-CUT & PROGRAMMED)
15926908 КЛЮЧ, ЗАЖИГАНИЯ LK (PRE-CUT & PRE-PROGRAMED FOR FLEET)
25865394 КЛЮЧ, ЗАЖИГАНИЯ (UNCODED) (MASTER)
25945699 КЛЮЧ, DR LK & IGN LK
(TC02-603) - 2007-2008 CK1 КРЕПЛЕНИЕ ГЕНЕРАТОРА (LC9/5.3-3,LH6/5.3M,LMG/5.3-0,LY2/4.8C,LY5/5.3J,L76/6.0Y,L92/6.2-8)
25869451 GENERATOR, (STAMPED 'FJ' OR 'FB' OR 'JD') (ACDelco #25869451)
25877026 GENERATOR, (ACDelco #25877026) [ГЕНЕРАТОР 160А]
12554030 BRACKET, GEN & P/S PUMP (INCLS 5) (INCLS SPACER)
11516744 BOLT-HFH, M10X1.5X110, 26 THD, 22.3 OD, 9.8, 7114M (GEN & P/S PUMP BRKT)
11516360 БОЛТ, HFH M10X1.2X90, 9.8, 7114M, 22.3 OD HDR PT (GEN)
teamcadillac.ru
12550090 SPACER, GEN & P/S PUMP BRKT (PART OF 2) [ВТУЛКА ГЕНЕРАТОРА]
(TC02-902) - 2007-2008 CK1(06-36) ПЕРЕДНИЕ ФАРЫ (CADILLAC Z75)
15874642 SUPPORT, HDLP HSG [ОПОРА ПЕРЕДНИХ ФАР]
15874643 SUPPORT, HDLP HSG [ОПОРА ПЕРЕДНИХ ФАР]
11610055 БОЛТ, HWASH, M6X1X23 (HDLP HSG PNL)
15789983 HARNESS, FRT FOG LP WRG HARN EXTN
01999367 BULB, FRT T/SIG LP (PART OF 8) (TRADE 3757AK) (8.991) (ACDelco #3757A)
10351663 BULB, FRT T/SIG LP (PART OF 8) (AMBER) (TRADE 3457NAK) (2.880) (ACDelco #10351663) [ЛАМПОЧКА СИГНАЛА ПОВОРОТА, 21 ВТ]
10346260 BULB, FRT FOG LP (PART OF 8) (TRADE 9145) (ACDelco #9145) [ЛАМПА НАКАЛИВАНИЯ]
10383562 LAMP, FRT FOG (INCLS 5-7) [ПРОТИВОТУМАННАЯ ФАРА]
10383563 LAMP, FRT FOG (INCLS 5-7) [ЛАМПА]
25779062 LAMP, FRT FOG (INCLS 5-7) [ПРОТИВОТУМАННАЯ ФАРА]
25779063 LAMP, FRT FOG (INCLS 5-7) [ПРОТИВОТУМАННАЯ ФАРА]
25897646 HEADLAMP, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 12-20) (2.725) [ПЕРЕДНЯЯ ФАРА]
25897647 HEADLAMP, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 12-20) (2.725) [ПЕРЕДНЯЯ ФАРА]
25897648 HEADLAMP, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 10-20) (2.725) [ПЕРЕДНЯЯ ФАРА]
25897649 HEADLAMP, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 10-20) (2.725) [ПЕРЕДНЯЯ ФАРА]
11561804 БОЛТ, HDLP BULB BALLAST (PART OF 9)
15782392 BALLAST, HDLP (PART OF 9)
teamcadillac.ru
15816281 ADAPTER, HDLP BULB (PART OF 9)
15862954 ADAPTER, HDLP BULB (PART OF 9) [КОЖУХ ГАЗОРАЗРЯДНОЙ ЛАМПЫ]
15825994 BULB, HDLP (PART OF 9) (ACDelco #15825994) [ЛАМПОЧКА ПЕРЕДНЕЙ ФАРЫ (12В, 55ВТ)]
25735604 BULB, HDLP (PART OF 9) (W/IGNITOR) (ACDelco #25735604) (LOW BEAM) [ЛАМПОЧКА ПЕРЕДНЕЙ ФАРЫ 55 ВТ]
15782399 ADAPTER, DAYTIME RUNNING LP BULB (PART OF 9)
10351675 BULB, DAYTIME RUNNING LP (PART OF 9) (CLEAR) (ACDelco #10351675) [ЛАМПОЧКА НАКАЛИВАНИЯ ПЕРЕДНЕЙ ФАРЫ 27 ВТ]
09421330 BULB, TRADE#194, 12V, 2CP (PART OF 9) (ACDelco #L194)
15782393 COVER, DAYTIME RUNNING LP BULB ACC (PART OF 9)
15782398 COVER, HDLP BULB ACC (PART OF 9)
11518121 ГАЙКА, U, M6X1, MULTI THD, .5'-4.0' THK PNL (HDLP HSG PNL)
11610055 БОЛТ, HWASH, M6X1X23 (HDLP HSG)
15930599 LAMP, FRT SI T/SIG (FRT КРЫЛО SIDE) [УКАЗАТЕЛЬ ПОВОРОТА]
(TC02-903) - 2007-2009 CK1,2,3 СИГНАЛ (EXC EXPORT VD1)
89046919 СИГНАЛ, GENERIC (HIGH NOTE) (INCLS 4) (MAY REQUIRE 19116451 WIRE ASM) (INCLUDES 485 HZ СИГНАЛ, BRKT) (ACDelco #D1933E) [ЗВУКОВОЙ СИГНАЛ]
11589076 БОЛТ, HEX HD, W/CON WA, M6X1X15, 7.5 THD, 17 O.D., 6202M, GMW3044 (СИГНАЛ) [БОЛТ М6]
teamcadillac.ru
89046918 СИГНАЛ, GENERIC (LOW NOTE) (INCLS 4) (MAY REQUIRE 19116451 WIRE ASM) (INCLS 405 HZ СИГНАЛ & BRKT) (ACDelco #D1932E) [ЗВУКОВОЙ СИГНАЛ]
(TC02-904) - 2007 CK1,2,3 MODULE/BODY CONTROL
15093913 BRACKET, BCM
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (BCM BRKT) (9.665) [БОЛТ М4.2Х1.41Х25]
teamcadillac.ru
15940214 MODULE, BODY CONT (W/O CALN & OPERG SYS) (LESS PROGRAMMING FILES, REQUIRES PROGRAMMING) (ACDelco #15940214)
25971917 MODULE, BODY CONT (W/O CALN & OPERG SYS) (INCLUDES PROGRAMMING FILES) (ACDelco #25971917) [БЛОК УПРАВЛЕНИЯ КУЗОВНЫМ ОБОРУДОВАНИЕМ]
11513599 ГАЙКА, U-TYPE, M4.2X1.41, 0.65-3.80 PNL THK, PZ (I/P EXTN) (ACDelco #11513599)
15801751 BRACKET, I/P CARR LOC PIN
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (I/P (TO RET)) (9.665) [БОЛТ М4.2Х1.41Х25]
15096963 MODULE, AUX BODY CONT (ACDelco #15096963) (LABELED 15096963)
15916961 MODULE, AUX BODY CONT (ACDelco #15916961) (LABELLED 15916961)
(TC02-907) - 2007-2009 CK1(06) ЗАДНИЕ ФОНАРИ (CADILLAC Z75)
15270012 SEAL, E/GATE CTR MLDG (PART OF 2)
25779075 APPLIQUE, L/GATE UPR (INCLS 1, 4-6) (PAINT TO MATCH) (W/O HIGH MT S/LP)
25779085 LAMP, HIGH MT STOP (INCLS CZ2 STAMP) [ЛАМПА]
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (PART OF 2) [ГАЙКА М6]
15857136 WIRE, HIGH MT S/LP (PART OF 2)
11561972 БОЛТ, L/GATE APLQ (PART OF 2) (6 X 1 X 21)
11609394 БОЛТ, L/GATE APLQ (M 6 X 1 X 28) (26 OD, 9.8)
11508277 ГАЙКА, HEX W/CON WA M6X1 THD, OD-19 PEOR 9 (L/GATE APLQ) [ГАЙКА М6]
03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (L/GATE CTR MLDG)
15862654 HARNESS, RR LIC PLT LP WRG
25872958 HARNESS, RR LIC PLT LP WRG (2.714) (SERV CMP OF CAMERA PKG'S)
teamcadillac.ru
01999382 BULB, (RR LIC PLT LP) (ACDelco #W5WLL) (LONGER LIFE)
25778786 LAMP, RR LIC PLT [ФОНАРЬ ПОДСВЕТКИ НОМЕРНОГО ЗНАКА]
11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (RR LIC PLT LP LENS)
11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (T/LP) [ВИНТ]
15890424 LAMP, TAIL (INCLS 18, 19, 22)
15890425 LAMP, TAIL (INCLS 18, 19, 22)
25895482 LAMP, TAIL (INCLS 18, 19, 22) [ЗАДНИЙ ФОНАРЬ]
25895483 LAMP, TAIL (INCLS 18, 19, 22) [ЗАДНИЙ ФОНАРЬ]
15821754 BULB, B/U LP (PART OF 17) (TRADE 7440) (8.991) (ACDelco #15821754) [ЛАМПОЧКА ЗАДНЕГО ФОНАРЯ 16 ВТ]
15803482 HARNESS, T/LP WRG (PART OF 17)
11569711 ГАЙКА, PUSH-IN, M4.2X1.41, 0.7-2.15 PNL THK, SAE 1050-1065, GMW3359 W/ (T/LP) [ГАЙКА М4.2]
11562160 RETAINER, T/LP (PART OF 17) [ФИКСАТОР ЗАДНЕГО ФОНАРЯ]
(TC02-908) - 2007-2009 CK1,2,3 BLOCK/ДВИГАТЕЛЬ HARNESS JUNCTION
25815385 COVER, ENG WRG HARN J/BLK
12177236 RELAY, FAN CONT (PART OF 7) (GRAY) (SPST 280 MINI) (4-WAY) (SQUARE CASE) (W/RESISTOR) (LABELED 12177236) (9.778) (ACDelco #D7065C) [РЕЛЕ]
15328865 RELAY, FAN CONT (PART OF 7) (5 TERMINAL) (BLACK) (SPDT 280 MINI.) (DAESUNG) (ACDelco #D1724A)
12092075 FUSE, MINI (30A) (GREEN) (PART OF 7) (ACDelco #12092075)
12191645 FUSE, MINI, 2 AMP, GRAY (PART OF 7)
88909753 FUSE, MINI, 10 AMP, RED (PART OF 7)
88909754 FUSE, 15A, MINI, BLUE (PART OF 7) (ACDelco #ATM15-25) [ПРЕДОХРАНИТЕЛЬ 15 А]
88909755 FUSE, 20A, MINI, YELLOW (PART OF 7) (ACDelco #ATM20-25) [ПРЕДОХРАНИТЕЛЬ 20 А]
88909756 FUSE, 25A, MINI, CLEAR (PART OF 7) (ACDelco #ATM25-25) [ПРЕДОХРАНИТЕЛЬ, 25A]
15209748 FUSE, 40AMP, LOW PROFILE J CASE, GREEN (PART OF 7) [ПРЕДОХРАНИТЕЛЬ 20А]
15822417 FUSE, 30AMP, LOW PROFILE J CASE, PINK (PART OF 7) [ПРЕДОХРАНИТЕЛЬ, 20А]
19115640 FUSE, 60AMP, LOW PROFILE J CASE, YELLOW (PART OF 7) [ПРЕДОХРАНИТЕЛЬ, 60А]
11509226 ГАЙКА, HEX W/CON WA, M8X1.25, 7.5THK, 19 O.D., 9, ZN (CHAS RR WRG HARN J/BLK LEAD)
15092625 BLOCK, ENG WRG HARN JUNC (INCLS 2-5, 14, 15) (LABELED 15092625) (FOR 2ND DES SEE 15925042)
15925042 BLOCK, ENG WRG HARN JUNC (INCLS 2-5, 14, 15) (LABELED 15925042) (FOR 1ST DES SEE 15092625)
15853967 BRACKET, ENG WRG HARN FUSE BLK
11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (ENG WRG HARN FUSE BLK BRKT) [БОЛТ М6]
19115080 RELAY, STRTR (PART OF 7) (GRAY) (SPST 280 MICRO) (4-TERMINAL) (3.670) (ACDelco #15-50688) [РЕЛЕ ПЕРЕДНЕЙ ФАРЫ, 2 А]
teamcadillac.ru
88988889 RELAY, FOG LP (PART OF 7) (9.277) (ACDelco #D1773C)
(TC02-909) - 2007-2009 CK1,2,3 BLOCK- I/P MID JUNCTION
25867232 BRACKET, DA WRG HARN J/BLK
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA WRG HARN J/BLK BRKT) [ГАЙКА М6]
teamcadillac.ru
11516780 ГАЙКА, HEX W/CON WA, M8X1.25, 10THK, 19 O.D., 10, 7111M (PARK BRK CONT MDL) (8.917) [ГАЙКА М8]
15093837 BLOCK, BODY WRG HARN JUNC (INCLS 6)
15925043 BLOCK, BODY WRG HARN JUNC (INCLS 6)
12088575 BREAKER, CIRCUIT, 25AMP, WHITE (PART OF 5) [РАЗМЫКАТЕЛЬ ЗАЩИТЫ ЦЕПИ ТЕПЛОВОЙ]
12182117 BREAKER, CIRC (PART OF 5) (30 AMP MINI NON-CYCLING)
15319848 BREAKER, CIRC (PART OF 5) (50 AMP MAXI TYPE I)
19116527 BREAKER, CIRC (PART OF 5) (25 AMP MANUAL RESET)
15200870 COVER, DA WRG HARN J/BLK
(TC02-910) - 2007-2009 CK1,2,3 BLOCK- I/P JUNCTION
15925044 BLOCK, FUSE (INCLS 3, 4)
12092075 FUSE, MINI (30A) (GREEN) (PART OF 2) (ACDelco #12092075)
12092079 FUSE, 10A, MINI, RED (PART OF 2)
12191645 FUSE, MINI, 2 AMP, GRAY (PART OF 2)
88909754 FUSE, 15A, MINI, BLUE (PART OF 2) (ACDelco #ATM15-25) [ПРЕДОХРАНИТЕЛЬ 15 А]
88909755 FUSE, 20A, MINI, YELLOW (PART OF 2) (ACDelco #ATM20-25) [ПРЕДОХРАНИТЕЛЬ 20 А]
88909756 FUSE, 25A, MINI, CLEAR (PART OF 2) (ACDelco #ATM25-25) [ПРЕДОХРАНИТЕЛЬ, 25A]
teamcadillac.ru
12182117 BREAKER, CIRC (PART OF 2) (30 AMP MINI NON-CYCLING)
15319848 BREAKER, CIRC (PART OF 2) (50 AMP MAXI TYPE I)
19116527 BREAKER, CIRC (PART OF 2) (25 AMP MANUAL RESET)
(TC02-911) - 2007 CK1,2,3 КРЕПЛЕНИЕ АККУМУЛЯТОРА/PRIMARY
15195496 SUPPORT, BAT TRAY FRT
11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (BAT TRAY SUPT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16]
teamcadillac.ru
11509853 БОЛТ, HEX W/CON WA, M8X1.25X45, 24 O.D., HDR PT, 9.8, PS (BAT HOLDN RET) [БОЛТ]
14005061 RETAINER, BAT HOLDN (PLASTIC) [ПЛАСТИНА ФИКСАЦИИ ОСНОВАНИЯ АККУМУЛЯТОРА]
11516780 ГАЙКА, HEX W/CON WA, M8X1.25, 10THK, 19 O.D., 10, 7111M (BAT TRAY) (8.917) [ГАЙКА М8]
15872637 TRAY, BAT (PRIMARY)
11508388 ГАЙКА, HEX W/CON WA, M6X1, 23.75 O.D., 5.55THK, 9, POR (BAT TRAY) (8.915)
(TC02-912) - 2007 CK1,2,3 КРЕПЛЕНИЕ АККУМУЛЯТОРА/SECONDARY
11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (BAT TRAY) [БОЛТ М6]
25826079 TRAY, BAT (SECONDARY)
teamcadillac.ru
11609540 БОЛТ, HWASH, M6X1X20, 16.15 THD, 17 OD, 8.8, GMW4205, HDR PT. (BAT TRAY) [ВИНТ]
15850348 BRACKET, ECM [ПЕТЛЯ КРЫШКИ БАГАЖНИКА]
10399558 SUPPORT, BAT TRAY
11514623 БОЛТ, HEX W/CON WA, M6X1X20 (BAT TRAY SUPT)
11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (BAT TRAY) [ШАЙБА]
(TC02-913) - 2007 CK1,2(06-36) АККУМУЛЯТОР ПРОВОДА (EXC DUAL АККУМУЛЯТОР 6A6, WIRING PROVISIONS 9L4)(1ST DES)
25792519 STRAP, ENG GND (ACDelco #25792519)
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (ENG GND STRP) [ГАЙКА М6]
11609619 БОЛТ, HEX W/ FL WA-M10X1.5X16, 20 OD, 10.9 STL, GMW3200 FINISH (ENG GND STRP) [БОЛТ]
25814777 CABLE, BAT POS (INCLS 25-27) (ACDelco #25814777)
20771932 CABLE, GEN BAT JPR (LABELED 20771932) (ACDelco #20771932)
21021808 ГАЙКА, GEN BAT (M8X1.25X6, BRASS) (2.343) [ГАЙКА М8]
15252180 CABLE, STRTR SOL (INCLS 21, 22)
teamcadillac.ru
25875320 CABLE, STRTR SOL (ACDelco #25875320)
11516885 SCREW, HFH W/FL WA, TAP, M8X1.25X20, 7THD, 17 O.D., TR PT, 6202M, PZOR (BAT POS CBL CLIP)
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BAT POS CBL) [ГАЙКА М6]
21021808 ГАЙКА, STRTR SOL CBL (M8X1.25X6, BRASS) [ГАЙКА М8]
10306471 SENSOR, BAT CUR (PART OF 15) [КАБЕЛЬНАЯ КЛЕММА]
11561111 STUD, BAT NEG CBL GND (M10 X1.5 X 20)
25897054 CABLE, BAT NEG (INCLS 13, 17-20) (ACDelco #25897054)
11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (FWD LP WRG HARN GND) [БОЛТ М8]
19116354 CLIP, BAT CBL (PART OF 15)
19116852 BOLT KIT, BAT CBL TERM (PART OF 15) (INCLS 19, 20) [КОМПЛЕКТ БОЛТОВ М8 (2ШТ.)]
15774329 COVER, BAT POS CBL TERM (BOTTOM) (PART OF 7) [ЗАЩИТНЫЙ КОЖУХ КЛЕММЫ АККУМУЛЯТОРА]
15774328 COVER, BAT POS CBL TERM (TOP) (PART OF 7) [КРЫШКА]
15861891 COVER, BAT POS CBL J/BLK
21011332 ГАЙКА, HEX STAMPED TY DF FLG 14 (BAT POS CBL RET) (8.921)
15305191 FUSE, 175 AMP MEGA (PART OF 4) ( FUSE COLOR, BLACK W/SIZE STAMPED IN WHITE ON CASE) [ПРЕДОХРАНИТЕЛЬ (175 AMP MEGA FUSE) *ЧЕРНЫЙ]
(TC02-914) - 2007-2009 CK1,2(06) ЗАДНИЕ ДАТЧИКИ ПАРКОВКИ (UD7)
25857380 MODULE, RR OBJECT ALARM (INCLS 4) (INCLUDES INTEGRAL PLASTIC BRKT--DISCARD PREVIOUS METAL BRKT 7 FASTNERS AS NEEDED)
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (RR OBJECT ALARM MDL) [ГАЙКА М6]
15108394 BRACKET, RR OBJECT ALARM MDL (PART OF 1) (USED ON VEHICLES BUILT 3/11/07 AND PRIOR)
21997869 INDICATOR, RR OBJECT ALARM (PART OF 6)
11509253 SCREW, W/LRG WA HD, M4.2X1.4X10, 11.3 O.D., BHL PT, STL, NO (PART OF 6)
15950574 HARNESS, RR OBJECT SEN WRG [ПРОВОДКА ДАТЧИКОВ ЗВУКОВОЙ СИГНАЛИЗАЦИИ СИСТЕМЫ ПАРКОВКИ]
15239247 SENSOR KIT, RR OBJECT (INCLS 11) (PRIMED) (W/O ШЛАНГИ) (7.831) [ДАТЧИК ПАРКОВКИ]
teamcadillac.ru
19115805 SENSOR KIT, RR OBJECT (INCLS 11) (MOUNTED IN THE STEP PAD) (7.831)
19115806 SENSOR KIT, RR OBJECT (INCLS 11) (PRIMER) (MOUNTED IN THE BUMPER) (7.831)
(TC02-915) - 2007 CK1,2(06) ЖГУТЫ ПРОВОДОВ/LIFT GATE
15945323 HARNESS, L/GATE WRG (INCLS 2-3) (INCLUDES BOOT BETWEEN LIFT GATE AND BODY)
15945325 HARNESS, L/GATE WRG (INCLS 2-3) (INCLUDES GROMMET)
teamcadillac.ru
(TC02-917) - 2007-2009 CK1(06-36) ЖГУТЫ ПРОВОДОВ/ПЕРЕДНИЕ ФАРЫ (CADILLAC Z75)
15871552 HARNESS, FWD LP WRG
15936051 HARNESS, FWD LP WRG (HAS ADDITIONAL CIRCUIT IN UBEC CONN)
15936087 HARNESS, FWD LP WRG (HAS ADDITIONAL CIRCUIT IN UBEC CONN)
teamcadillac.ru
15951478 HARNESS, FWD LP WRG
15930599 LAMP, FRT SI T/SIG (FRT КРЫЛО SIDE) (СМ. ГРУППУ 02.000 "ПЕРЕДНИЕ ФАРЫ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [УКАЗАТЕЛЬ ПОВОРОТА]
15255231 HARNESS, FRT SI T/SIG LP WRG (DRIVER SIDE)
15951477 HARNESS, FRT SI T/SIG LP WRG (795MM LONG)
(TC02-918) - 2007-2009 CK1,2(06-36) ЖГУТЫ ПРОВОДОВ/ROOF
15805937 HARNESS, RF WRG (A PILLER) (INCLS 4) (W/TRIANGLE SHAPED 3-WAY CONN ON COAX CABLE) (SEE 15871431 FOR 2ND DES)
15805943 HARNESS, RF WRG (A PILLER) (INCLS 4)
15805944 HARNESS, RF WRG (A PILLER) (INCLS 4)
15805953 HARNESS, RF WRG (A PILLER) (INCLS 4) (W/TRIANGLE SHAPED 3-WAY CONN ON COAX CABLE) (SEE 15871436 FOR 2ND DES)
15805960 HARNESS, RF WRG (A PILLER) (INCLS 4) (W/TRIANGLE SHAPED 3-WAY CONN ON COAX CABLE) (SEE 15871430 FOR 2ND DES)
15805974 HARNESS, RF WRG (A PILLER) (INCLS 4)
15834980 HARNESS, RF WRG (A PILLAR) (INCLS 4) (W/TRIANGLE SHAPED 3-WAY CONN ON COAX CABLE) (FOR 2ND DES SEE 25813716)
15834988 HARNESS, RF WRG (A PILLAR) (INCLS 4) (W/TRIANGLE SHAPED 3-WAY CONN ON COAX CABLE) (FOR 2ND DES SEE 25813720)
teamcadillac.ru
15834993 HARNESS, RF WRG (INCLS 4) (W/TRIANGLE SHAPED 3-WAY CONN ON COAX CABLE) (SEE 15871444 FOR 2ND DES)
15834994 HARNESS, RF WRG (INCLS 4) (A PILLAR)
15871430 HARNESS, RF WRG (A PILLAR) (INCLS 4) (W/SEMI-CIRCLE SHAPED 3-WAY CONN ON COAX CABLE) (SEE 15805960 FOR 1ST DES)
15871436 HARNESS, RF WRG (A PILLER) (INCLS 4) (W/SEMI-CIRCLE SHAPED 3-WAY CONN ON COAX CABLE) (SEE 15805953 FOR 1ST DES)
15902496 HARNESS, RF WRG (A PILLER) (INCLS 4)
15902499 HARNESS, RF WRG (A PILLAR) (INCLS 4)
15902500 HARNESS, RF WRG (A PILLAR) (INCLS 4)
15902504 HARNESS, RF WRG (INCLS 4)
15902505 HARNESS, RF WRG (INCLS 4)
15902509 HARNESS, RF WRG (INCLS 4)
25813705 HARNESS, RF WRG (INCLS 4) ("A" PILLAR)
25813706 HARNESS, RF WRG (A PILLAR) (INCLS 4)
25813710 HARNESS, RF WRG (A PILLAR) (INCLS 4) (W/SEMI-CIRCLE SHAPED 3-WAY CONN ON COAX CABLE) (SEE 15805937 FOR 1ST DES)
25813716 HARNESS, RF WRG (A PILLAR) (INCLS 4)
25813720 HARNESS, RF WRG (A PILLAR) (INCLS 4) (W/SEMI-CIRCLE SHAPED 3-WAY CONN ON COAX CABLE) (1ST DES SEE 15834988)
25813723 HARNESS, RF WRG (INCLS 4)
19116836 CABLE, M/TEL & NAVN ANT COAX (PART OF 1) (9.647) (ACDelco #19116836)
19208818 CABLE, M/TEL & VEH LOC ANT (IN ROOF WRG) (PART OF 1) (USED IN ROOF AND DOOR HARNESSES) (ACDelco #19208818)
(TC02-919) - 2007 CK107(06) ЖГУТЫ ПРОВОДОВ/КУЗОВ
25776512 HARNESS, BODY WRG (INCLS 5, 8)
25776518 HARNESS, BODY WRG (INCLS 5, 8)
25776519 HARNESS, BODY WRG (INCLS 5, 8)
25776520 HARNESS, BODY WRG (INCLS 5, 8)
25776522 HARNESS, BODY WRG (INCLS 5, 8)
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BODY WRG HARN GND) [ГАЙКА М6]
21011332 ГАЙКА, HEX STAMPED TY DF FLG 14 (BODY WRG HARN BRKT) (8.921)
15215179 COVER, WRG HARN CONN (BLACK (REPLS ALL COLORS)) [КРЫШКА КОНТАКТНОГО РАЗЪЕМА]
teamcadillac.ru
11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (BODY WRG HARN GND) [БОЛТ М8]
(TC02-920) - 2007 CK1(06-36) ЖГУТЫ ПРОВОДОВ/CHASSIS (REAL-TIME DAMPING Z55)
15894242 HARNESS, CHAS WRG (INCLS 2, 3)
15918584 HARNESS, CHAS WRG (INCLS 2, 3)
15918587 HARNESS, CHAS WRG (INCLS 2, 3)
15918588 HARNESS, CHAS WRG (INCLS 2, 3)
19115819 TUBE, RR S/ABS AIR (PART OF 1) [ТРУБКА ТОРМОЗНОЙ СИСТЕМЫ]
teamcadillac.ru
11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (CHAS WRG) [БОЛТ М8]
21011332 ГАЙКА, HEX STAMPED TY DF FLG 14 (CHAS FRT WRG HARN BRKT) (8.921)
15045897 BRACKET, CHAS FRT WRG HARN (FRT OF DASH)
12177233 RELAY, AUTO LVL CONT (5-WAY MALE, BLACK, CODE 7233) (SHROUDED) (W/RESISTOR) (SPDT 280 MINI) (FOR 4-TERM APP CUT OFF CENTER TERM LABELED 87A) (9.277) (ACDelco #15-8721)
(TC02-924) - 2007-2008 CK1(06-36) ЖГУТЫ ПРОВОДОВ/ДВИГАТЕЛЬ (L92/6.2-8)
25809107 HARNESS, ENG WRG
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (ENG WRG HARN RET) [ГАЙКА М6]
01470030 CLAMP, WORM TYPE (11/16" TO 1 5/16") (ENG WRG HARN CLIP) (ACDelco #1470030)
11589076 БОЛТ, HEX HD, W/CON WA, M6X1X15, 7.5 THD, 17 O.D., 6202M, GMW3044 (ENG WRG HARN CLIP) [БОЛТ М6]
15305188 CLIP, ENG WRG HARN ECM LEAD (1.166)
11609832 STUD-HFH, M8X1.25X16, M8X1.25X16, 18 OD, 40.1 TL, 8.8 STL, GMW3200 (ENG WRG HARN CDT)
teamcadillac.ru
11514623 БОЛТ, HEX W/CON WA, M6X1X20 (ENG WRG HARN BRKT)
11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (ENG WRG HARN CLIP) [БОЛТ М6]
21075686 RETAINER, PUSH PIN W/SEAL, FITS 8.0-8.25 DIA HOLE IN 3-7MM THK PNL (SECD OXY SEN WRG HARN)
01470030 CLAMP, WORM TYPE (11/16" TO 1 5/16") (OXY SEN WIRE) (ACDelco #1470030)
11609467 NUT HEX, M5X0.8, 4.55 THK, 5 STL, GMW3200 (ENG WRG HARN START MTR LEAD)
(TC02-926) - 2007-2009 CK1(06) ЖГУТЫ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ EXTENSION (G.M.C. Z88, DENALI Y91, EXC UE1,U2K)
teamcadillac.ru
15127940 HARNESS, I/P WRG HARN EXTN
(TC02-928) - 2007 K1(06) ЖГУТЫ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ (G.M.C. Z88, DENALI Y91)
19115530 CABLE, RDO & MOBILE TEL & NAVIGATION ANT (PART OF 8) (IN I/P WRG) (9.675) (ACDelco #19115530)
19115531 CABLE, RDO & MOBILE TEL & NAVIGATION ANT (PART OF 8) (IN I/P WRG) (ACDelco #19115531)
19149310 BLOCK, I/P WRG HARN JUNC (PART OF 8)
15846119 HARNESS, I/P WRG (INCLS 4, 5)
15949006 HARNESS, I/P WRG (INCLS 4, 5)
15949007 HARNESS, I/P WRG (INCLS 4, 5)
15949008 HARNESS, I/P WRG (INCLS 4, 5)
15949009 HARNESS, I/P WRG (INCLS 4, 5)
15949039 HARNESS, I/P WRG (INCLS 4, 5)
15949047 HARNESS, I/P WRG (INCLS 4, 5)
15949048 HARNESS, I/P WRG (INCLS 4, 5)
15949051 HARNESS, I/P WRG (INCLS 4, 5)
15949052 HARNESS, I/P WRG (INCLS 4, 5)
15949053 HARNESS, I/P WRG (INCLS 4, 5)
teamcadillac.ru
15949054 HARNESS, I/P WRG (INCLS 4, 5)
15949084 HARNESS, I/P WRG (INCLS 4, 5)
15949085 HARNESS, I/P WRG (INCLS 4, 5)
15949086 HARNESS, I/P WRG (INCLS 4, 5)
15949087 HARNESS, I/P WRG (INCLS 4, 5)
12146933 COVER, I/P WRG HARN DATA LINK CONN
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (I/P WRG HARN DATA LINK CONN) (9.665) [БОЛТ М4.2Х1.41Х25]
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (I/P WRG HARN GND) [ГАЙКА М6]
(TC02-929) - 2007-2009 CK1(06-36) ЖГУТЫ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ (CADILLAC Z75)
15095253 CABLE, RDO ANT CBL EXTN RDO END (1021 MM) (ACDelco #15095253)
15949011 HARNESS, I/P WRG (INCLS 5)
teamcadillac.ru
15949071 HARNESS, I/P WRG (INCLS 5)
19115474 CABLE, DIGITAL RDO АНТЕННА (IN I/P WRG) (PART OF 3) (ACDelco #19115474)
(TC02-931) - 2007-2009 CK1,2(06-36) ЖГУТЫ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ FUSE BLOCK (POWER ADJUSTABLE PEDAL JF4, EXC PPV,5W4,9L4)
15918012 HARNESS, FUSE BLK WRG
teamcadillac.ru
(TC02-939) - 2007-2009 CK107(06) АККУМУЛЯТОР ПРОВОДА (DUAL АККУМУЛЯТОР 6A6)
19116037 COVER, BAT NEG CBL TERM (PART OF 8) [КОЖУХ КЛЕММЫ АККУМУЛЯТОРА]
19116852 BOLT KIT, BAT CBL TERM (PART OF 6, 8, 19, 25) (INCLS 2, 3) [КОМПЛЕКТ БОЛТОВ М8 (2ШТ.)]
19116038 COVER, BAT POS CBL TERM (PART OF 6)
25825642 CABLE, AUX BAT POS (INCLS 2-5) (ACDelco #25825642) [КАБЕЛЬ]
11609619 БОЛТ, HEX W/ FL WA-M10X1.5X16, 20 OD, 10.9 STL, GMW3200 FINISH (AUX BAT NEG CBL) [БОЛТ]
25876896 CABLE, AUX BAT NEG (INCLS 1-4) (ACDelco #25876896) [КАБЕЛЬ АККУМУЛЯТОРА 12 В]
25862352 CABLE, AUX BAT POS (RH PROC) (ACDelco #25862352)
15881616 COVER, BAT POS CBL J/BLK (3 WAY MEGAFUSE)
21021808 ГАЙКА, BAT HDL (M8X1.25X6, BRASS) (2.343) [ГАЙКА М8]
15106388 FUSE, (MEGA FUSE) (BLACK) (60 AMP) (8.965)
19116352 HOLDER, WRG HARN FUSE
12177251 FUSE, 125 AMP MEGA FUSE (125 A) (FUSE COLOR, BLACK W/SIZE STAMPED IN WHITE ON CASE) [ПРЕДОХРАНИТЕЛЬ 125 А]
15305191 FUSE, 175 AMP MEGA (ПЕПЕЛЬНИЦА LP) ( FUSE COLOR, BLACK W/SIZE STAMPED IN WHITE ON CASE) [ПРЕДОХРАНИТЕЛЬ (175 AMP MEGA FUSE) *ЧЕРНЫЙ]
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BAT POS CBL J/BLK BRKT) [ГАЙКА М6]
25797040 COVER, BAT POS CBL TERM (TOP) (PART OF 19)
25875320 CABLE, STRTR SOL (INCLS 2-4, 18, 20) (ACDelco #25875320)
15774329 COVER, BAT POS CBL TERM (BOTTOM) (PART OF 19) [ЗАЩИТНЫЙ КОЖУХ КЛЕММЫ АККУМУЛЯТОРА]
25888958 COVER, BAT POS CBL TERM (BOTTOM) (PART OF 19)
teamcadillac.ru
11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (BAT NEG CBL GND) [БОЛТ М8]
25897054 CABLE, BAT NEG (INCLS 2-4, 26, 27) (ACDelco #25897054)
19116354 CLIP, BAT CBL (PART OF 25)
10306471 SENSOR, BAT CUR (PART OF 25) [КАБЕЛЬНАЯ КЛЕММА]
(TC02-940) - 2007-2009 CK1,2,3 ЖГУТЫ ПРОВОДОВ/ACCESSORY POWER SUPPLY (WIRING PROVISIONS 9L4)
15824194 HARNESS, ACSRY PWR FUSE BLK RR WRG HARN EXTN (INCLS 4, 6, 7)
15838399 HARNESS, ACSRY PWR FUSE BLK RR WRG HARN EXTN (INCLS 4, 6, 7)
15888241 BRACKET, ACSRY PWR FUSE BLK RR WRG HARN EXTN HARN (PART OF 1)
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (ACSRY PWR FUSE BLK RR WRG HARN EXTN HARN BRKT) (9.665) [БОЛТ М4.2Х1.41Х25]
12092075 FUSE, MINI (30A) (GREEN) (PART OF 1) (ACDelco #12092075)
12193604 RELAY, ACSRY (MOBILE RADIO) (PART OF 1) (GRAY) (SPST 280 MINI) (4-TERMINAL) (CODE 3604) (9.778) (ACDelco #15-8733)
(TC02-941) - 2007-2009 CK107(06) ЖГУТЫ ПРОВОДОВ/ACCESSORY POWER SUPPLY (POLICE PACKAGE PPV, MUNICIPAL SERVICE 5W4)
15824194 HARNESS, ACSRY PWR FUSE BLK RR WRG HARN EXTN (INCLS 4, 6-8)
15838399 HARNESS, ACSRY PWR FUSE BLK RR WRG HARN EXTN (INCLS 4, 6-8)
teamcadillac.ru
12182117 BREAKER ASM, CIRC (MINI 30AMP NON-CYCLING) (PART OF 1) (2.483)
15319848 BREAKER, CIRC (PART OF 1) (50 AMP MAXI TYPE I)
(TC02-954) - 2007-2009 CK1(06) АККУМУЛЯТОР ПРОВОДА (WIRING PROVISIONS 9L4)
15856795 STRAP, ENG GND (ACDelco #15856795)
15921158 STRAP, ENG GND (ACDelco #15921158)
25825642 CABLE, AUX BAT POS (INCLS 23, 25, 27) (ACDelco #25825642) [КАБЕЛЬ]
25875320 CABLE, STRTR SOL (INCLS 18-22) (ACDelco #25875320)
10306471 SENSOR, BAT CUR (PART OF 16) [КАБЕЛЬНАЯ КЛЕММА]
25897052 CABLE, BAT NEG (INCLS 13, 14, 18-20) (ACDelco #25897052)
19116852 BOLT KIT, BAT CBL TERM (INCLS 19, 20) (PART OF 9, 16) [КОМПЛЕКТ БОЛТОВ М8 (2ШТ.)]
25888958 COVER, BAT POS CBL TERM (BOTTOM) (PART OF 9)
25797040 COVER, BAT POS CBL TERM (TOP) (PART OF 9)
21021808 ГАЙКА, BAT HDL (PART OF 4) (M8X1.25X6, BRASS) (2.343) [ГАЙКА М8]
teamcadillac.ru
19116352 HOLDER, WRG HARN FUSE (PART OF 4)
(TC02-956) - 2007 CK1,2(06-36) АККУМУЛЯТОР ПРОВОДА (EXC DUAL АККУМУЛЯТОР 6A6, WIRING PROVISIONS 9L4)(2ND DES)
25814777 CABLE, BAT POS (INCLS 23, 26, 27) (ACDelco #25814777)
25897054 CABLE, BAT NEG (INCLS 13, 17, 19-21) (ACDelco #25897054)
11561048 БОЛТ, HEX W/FL WA-3/8-16X.625, .82 OD, GM275 STL, GMW3200 FINISH (ENG WRG HARN GND)
25888958 COVER, BAT POS CBL TERM (BOTTOM) (PART OF 7)
19116852 BOLT KIT, BAT CBL TERM (PART OF 7, 15) (INCLS 20, 21) [КОМПЛЕКТ БОЛТОВ М8 (2ШТ.)]
25797040 COVER, BAT POS CBL TERM (TOP) (PART OF 7)
21021808 ГАЙКА, GEN BAT (PART OF 4) (M8X1.25X6, BRASS) (2.343) [ГАЙКА М8]
teamcadillac.ru
(TC02-962) - 2007-2009 CK107(06) ЖГУТЫ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ FUSE BLOCK (POLICE PACKAGE PPV, MUNICIPAL SERVICE 5W4)
teamcadillac.ru
(TC02-963) - 2007-2009 CK1,2,3 ЖГУТЫ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ FUSE BLOCK (WIRING PROVISIONS 9L4)
teamcadillac.ru
(TC02-964) - 2007-2009 K107(06) СИГНАЛ (EXPORT VD1)
89046919 СИГНАЛ, GENERIC (HIGH NOTE) (INCLS 4, 6, 7) (MAY REQUIRE 19116451 WIRE ASM) (INCLUDES 485 HZ СИГНАЛ, BRKT) (ACDelco #D1933E) [ЗВУКОВОЙ СИГНАЛ]
89046918 СИГНАЛ, GENERIC (LOW NOTE) (INCLS 4, 6, 7) (MAY REQUIRE 19116451 WIRE ASM) (INCLS 405 HZ СИГНАЛ & BRKT) (ACDelco #D1932E) [ЗВУКОВОЙ СИГНАЛ]
(TC02-975) - 2007-2009 CK1,2,3 ФОНАРИ/КРЫША (ROOF MARKER LAMP U01)
25826849 LAMP, RF CLER OTR (INCLS 3, 4, 6)
25826850 LAMP, RF CLER CTR (INCLS 3, 4, 6) (W/SCREWS, WASHERS & NUTS) (LED BULBS) (3 LAMPS)
25826848 LAMP, RF CLER OTR (INCLS 3, 4, 6)
teamcadillac.ru
(TS02-215) - 2007-2008 CK1,2,3 КРЕПЛЕНИЕ СТАРТЕРА (LY6/6.0K,L76/6.0Y,L92/6.2-8)
teamcadillac.ru
12588400 SHIELD, STRTR HT (SNAP-ON SHIELD)
89017844 STARTER, (REMAN) (PROD 12588052, 12610301) (ACDelco #323-1637) (DELCO SERIES PG260H) [СТАРТЕР В СБОРЕ]
11588456 БОЛТ, STRTR (M10X1.5X115) (ACDelco #11588456)
03 - ТОПЛИВНАЯ СИСТЕМА - ВЫХЛОПНАЯ - СИСТЕМЫ ВЫПУСКА ВОЗДУХА
(TC03-852) - 2007 CK1(06-36) ТОПЛИВНЫЙ БАК FILLER ТРУБКИ & HOSES (LY2/4.8C,LY5/5.3J,L76/6.0Y,L92/6.2-8)(2ND DES)
25852917 PIPE, F/TNK FIL (INCLS 2-5, 7-17, 20) [ТРУБКА ТОПЛИВНОЙ СИСТЕМЫ]
11610236 CLAMP, TYPE F WORM GEAR 20-1/4 HEX HD SAE 302 STL GM3044 9 (PART OF 1, 3)
15289732 HOSE, F/TNK FIL (INCLS 2) (PART OF 1) (FILL PIPE LOWER)
11610236 CLAMP, TYPE F WORM GEAR 20-1/4 HEX HD SAE 302 STL GM3044 9 (PART OF 1)
11516885 SCREW, HFH W/FL WA, TAP, M8X1.25X20, 7THD, 17 O.D., TR PT, 6202M, PZOR (F/TNK FIL & VENT HOSE BRKT)
12337820 STRAP, 15" TIE STRAP (PART OF 1) (ACDelco #12337820)
15844701 HOSE, F/TNK FIL VENT (INCLS 9) (PART OF 1)
15146021 CAP, F/TNK VENT PIPE (PART OF 1, 8)
15124941 HOSE, EVAP EMIS (PART OF 1) (FROM FILL PIPE ASM TO TANK)
15946263 HOSE, EVAP EMIS (PART OF 1) (FROM TANK TO CHASSIS FUEL LINE)
15124940 HOSE, F/TNK FIL (PART OF 1) (FILL PIPE UPPER)
15217509 STRAP, F/TNK FIL PIPE GND (PART OF 1)
25844432 ШЛАНГИ, F/TNK FIL PIPE (PART OF 1)
15714277 SCREW, W/WA AND SLR, M4.2X1.41X13, 5.4THD, 12.5 O.D., SELF TAP, ZC (PART OF 1)
10403773 RETAINER, F/TNK FIL CAP STRP (PUSH IN) (PART OF 19)
15225006 CAP, F/TNK FIL (INCLS 18) (T-TYPE TETHER) (ACDelco #15225006)
25820825 CAP, F/TNK FIL (INCLS 18) (BUTTON TYPE TETHER) (ACDelco #GT289)
teamcadillac.ru
11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (PART OF 1) [ШАЙБА]
15953840 SCREW, PAN HD TORX W/CON WA M6X1X25 AC PT 9.8 PC 12.5-OD (F/TNK FIL PIPE HSG) (3.003) [БОЛТ]
15845031 BUMPER, F/TNK FIL DR
25880365 ПРУЖИНА, F/TNK FIL DR (12.945) (PRIOR TO INSTALL SEAL VOIDS IN PLUNGER HSG W/FLEXIABLE SEALER) [ЗАЩЕЛКА ЛЮЧКА ТОПЛИВНОЙ ГОРЛОВИНЫ]
11561878 RETAINER, PUSH PIN W/SEAL, FITS 8.0-8.25 DIA HOLE IN 3-7MM THK PNL (F/TNK FIL PIPE HSG) [ФИКСАТОР ОПОРЫ БЛОКА УПРАВЛЕНИЯ]
15940678 DOOR, F/TNK FIL (INCLS 26)
15845031 BUMPER, F/TNK FIL DR (PART OF 25)
(TC03-901) - 2007-2008 CK1 СИСТЕМА ВПУСКА ВОЗДУХА (L92/6.2-8)
15908906 CLEANER, AIR (NOTE THIS CLEANER ASM INCLUDES THE COVER & LOWER ШЛАНГИ) (INCLS BOLT, ELEMENT, FASTENER, ADAPTER) (INCLS 2-4, 15, 18-20) (REMOVAL OF RESTRICTION INDICATOR AND GROMMET.DOES NOT EFFECT FIT/FORM FUNCTION) [ВОЗДУШНЫЙ ФИЛЬТР ДВИГАТЕЛЯ]
25178714 GROMMET, A/CL AIR RSTN IND (PART OF 1)
15073765 INDICATOR, A/CL AIR RSTN (PART OF 1) [ДАТЧИК ДАВЛЕНИЯ ВОЗДУШНОЙ СИСТЕМЫ]
25171042 ADAPTER, MASS AIRFLOW SEN INL (PART OF 1) [АДАПТЕР В СБОРЕ, ДАТЧИКА РАСХОДА ВОЗДУХА]
15900024 SENSOR, MASS AIRFLOW (W/INT AIR TEMP SEN) (ACDelco #213-3828)
15901934 DUCT, A/CL OTLT (STAMPED 15901934) (APPROXIMATE OVERALL PART SIZE 670.7 X 503.5 X 418) (INCLS 6, 8, 9) [ТРУБКА]
25346092 INSULATOR, A/CL HSG (PART OF 7) (3.270)
15066121 SUPPORT, A/CL [ОПОРА ВОЗДУХООЧИСТИТЕЛЯ]
teamcadillac.ru
11516424 БОЛТ, HFH, M6X1X25, 14.2 O.D., HDR PT, 9.8, ZE (A/CL ADAP SUPT) [БОЛТ М6]
11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (BAT TRAY REINF) [ШАЙБА]
25872321 BRACKET, A/CL ADAP (INCLS TWO GROMMETS) (INCLS 17) (DIESEL NOT STAMPED ON PART)
11514623 БОЛТ, HEX W/CON WA, M6X1X20 (A/CL ADAP)
25316546 FASTENER, A/CL (PART OF 1)
11516589 SCREW, HEX HD W/CON SPR WA, M6X1X30, 29 THD, 17 O.D., 9.8, 7114M, ZE (A/CL ADAP)
25346092 INSULATOR, A/CL HSG (PART OF 13) (3.270)
15908916 ELEMENT, A/CL (PART OF 1) (ACDelco #A3086C) [ВОЗДУШНЫЙ ФИЛЬТР ДВИГАТЕЛЯ]
11561933 БОЛТ, A/CL HSG CVR (PART OF 1) (M6X2.7X36) [БОЛТ]
11562129 БОЛТ, A/CL OTLT DUCT
(TC03-903) - 2007-2008 CK1 БЛОК ЭЛЕКТРОННОГО УПРАВЛЕНИЯ MODULE & ЖГУТЫ ПРОВОДОВ (LC9/5.3-3,LH6/5.3M,LMG/5.3-0,LY2/4.8C,LY5/5.3J,L76/6.0Y,L92/6.2-8)
11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (FRT A/DFL) [БОЛТ М6]
11518121 ГАЙКА, U, M6X1, MULTI THD, .5'-4.0' THK PNL (PART OF 4)
15850348 BRACKET, ECM (INCLS 3) [ПЕТЛЯ КРЫШКИ БАГАЖНИКА]
teamcadillac.ru
12597121 MODULE, ENG CONT (ACDelco #12597121)
11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (ECM BRKT) (ACDelco #11517518) [БОЛТ]
(TC03-905) - 2007 CK1(06-36) СИСТЕМА ТОПЛИВОСНАБЖЕНИЯ-FRONT (LC9/5.3-3,LMG/5.3-0,LY2/4.8C,LY5/5.3J,L76/6.0Y,L92/6.2-8)
22695614 RETAINER, FUEL FEED HOSE CONN (13 X 19 X 36MM) (ONE TUBE) [ОПОРНАЯ ПЛАНКА ТРУБКИ ТОПЛИВНОЙ СИСТЕМЫ]
15836676 HOSE, FUEL FEED & EVAP EMIS & RTN
15085402 BRACKET, FUEL FEED & EVAP EMIS & RTN HOSE
teamcadillac.ru
11514596 ГАЙКА, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (FUEL FEED & RTN FRT HOSE BRKT) (8.915) (ACDelco #11514596)
15168648 CLIP, FUEL FEED & EVAP EMIS & RTN HOSE (W/RETAINER)
15168645 CLIP, FUEL FEED & EVAP EMIS & RTN HOSE (RETAINER)
15085405 CLIP, FUEL FEED & EVAP EMIS & RTN HOSE (CLIP - 1.36" LENGTH, MAT'L NYLON BLACK)
15085404 CLIP, FUEL FEED & EVAP EMIS & RTN HOSE (AT HOSE/PIPE CONNECTION)
15126012 BRACKET, FUEL FEED & EVAP EMIS & RTN PIPE CLIP
11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (FUEL FEED & EVAP EMIS & RTN PIPE CLIP BRKT) (ACDelco #11570082) [БОЛТ М8]
15168649 CLIP, FUEL FEED & EVAP EMIS & RTN HOSE (ANTI-RATTLE)
15168646 CLIP, FUEL FEED & EVAP EMIS & RTN HOSE (2 TUBE)
11516703 БОЛТ, HEX, M4.8X1.6X13, 20 OD, 6010M MAT, 6047M FIN (FUEL FEED & RTN FRT HOSE BRKT) (8.977)
15124945 BRACKET, FUEL FEED & RTN FRT HOSE
11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (FUEL FEED & RTN FRT HOSE BRKT) [БОЛТ М6]
15709703 ГАЙКА, HEX 10X1.5THD, 21.8 OD SS (TRFER CASE) [ГАЙКА М10]
15033698 BRACKET, FUEL FEED & RTN PIPE
(TC03-907) - 2007-2008 CK107(06) СИСТЕМА ТОПЛИВОСНАБЖЕНИЯ-REAR (LY2/4.8C,LY5/5.3J,L76/6.0Y,L92/6.2-8)
88983154 HOSE, EVAP EMIS CNSTR PURGE (INCLS 2) (3.145)
12522917 CONNECTOR KIT, FUEL FEED PIPE (PART OF 1, 3) (GREEN) (INCLS INST SHT & RET) (USE WITH 3/8 TUBE, NYLON) (3.162)
teamcadillac.ru
24100438 HOSE, FUEL FEED (INCLS 2)
12522917 CONNECTOR KIT, FUEL FEED PIPE (PART OF 6) (GREEN) (INCLS INST SHT & RET) (USE WITH 3/8 TUBE, NYLON) (3.162)
88983154 HOSE, EVAP EMIS CNSTR PURGE (INCLS 5) (3.145)
(TC03-912) - 2007 CK107(06) УГОЛЬНЫЙ ФИЛЬТР & СОПРЯЖЕННЫЕ ДЕТАЛИ
15109431 CANISTER, EVAP EMIS (ACDelco #215-464) [ТОПЛИВОИСПАРИТЕЛЬНЫЙ БАК]
10200334 БОЛТ, EVAP EMIS CNSTR BRKT (M8X1.25X30) (W/FLAT WASHER) (12.243)
15113366 BRACKET, EVAP EMIS CNSTR
11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (EVAP EMIS CNSTR) (ACDelco #11570082) [БОЛТ М8]
21992746 RETAINER, FUEL FEED HOSE CONN (PART OF 11) (5/8 INCH QUICK CONNECT RETAINER CLIP)
11516885 SCREW, HFH W/FL WA, TAP, M8X1.25X20, 7THD, 17 O.D., TR PT, 6202M, PZOR (EVAP EMIS CNSTR VENT SOL VLV BRKT)
25932567 SOLENOID, EVAP EMIS CNSTR (PART OF 11) (ACDelco #214-2236) [КЛАПАН ТОПЛИВОИСПАРИТЕЛЬНОГО БАКА]
teamcadillac.ru
15844699 VALVE, EVAP EMIS CNSTR CONT (INCLS 5-7, 9) (INCLUDES EVAP CNSTR HOSE) (ACDelco #15844699)
(TC03-913) - 2007 CK1(06-36) ТОПЛИВНЫЙ БАК FILLER ТРУБКИ & HOSES (LY2/4.8C,LY5/5.3J,L76/6.0Y,L92/6.2-8)(1ST DES)
25852917 PIPE, F/TNK FIL (INCLS 2-5, 7-18, 21) [ТРУБКА ТОПЛИВНОЙ СИСТЕМЫ]
teamcadillac.ru
15090388 CLIP, F/TNK FIL PIPE (PART OF 1)
10403773 RETAINER, F/TNK FIL CAP STRP (PUSH IN) (PART OF 20)
15225006 CAP, F/TNK FIL (INCLS 19) (T-TYPE TETHER) (ACDelco #15225006)
25820825 CAP, F/TNK FIL (INCLS 19) (BUTTON TYPE TETHER) (ACDelco #GT289)
15940678 DOOR, F/TNK FIL (INCLS 27, 28)
15940680 HINGE, F/TNK FIL DR (BODY SI) (PART OF 26)
15845031 BUMPER, F/TNK FIL DR (PART OF 26)
(TC03-915) - 2007 CK107(06) HEAT SHIELDS/EXHAUST
15797116 SHIELD, EXH HT (@ DASH PNL)
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (EXH H/SHLD (AT DA PNL)) [ГАЙКА М6]
15169247 SHIELD, EXH HT
15893979 SHIELD, EXH FRT HT (AT F/FLR PNL)
11588331 ГАЙКА, HEX HD W/CON WA, M6X1, 5.7THK, 25 O.D., 9, GM6138M (EXH H/SHLD)
teamcadillac.ru
15740776 SHIELD, EXH HT (AT INTER FLR PNL)
15102076 SHIELD, EXH HT (AT R/FLR PNL)
(TC03-917) - 2007-2008 CK1(06-36) СИСТЕМА ОТРАБОТАВШИХ ГАЗОВ-V8 (L92/6.2-8)
25824121 CONVERTER, 3WAY CTLTC (W/EXH MANIF PIPE) (3.685)
25904626 CONVERTER, 3WAY CTLTC (W/EXH MANIF PIPE) (3.685) [КАТАЛИТИЧЕСКИЙ НЕЙТРАЛИЗАТОР ВЫХЛОПНЫХ ГАЗОВ]
25904627 CONVERTER, 3WAY CTLTC (W/EXH MANIF PIPE) (3.685) [КАТАЛИТИЧЕСКИЙ НЕЙТРАЛИЗАТОР ВЫХЛОПНЫХ ГАЗОВ]
15709703 ГАЙКА, HEX 10X1.5THD, 21.8 OD SS (EXH MANIF PIPE) [ГАЙКА М10]
11589264 STUD, STRAIGHT, M10X1.5X30, M10X1.5X16, 57 TL, SS (EXH MANIF PIPE) [ШПИЛЬКА М8]
15077362 SEAL, EXH MANIF PIPE [САЛЬНИК ГЛУШИТЕЛЯ]
teamcadillac.ru
15035747 SEAL, EXH MANIF PIPE [УПЛОТНИТЕЛЬНАЯ ВТУЛКА ГЛУШИТЕЛЯ]
12589321 SENSOR, HTD OXY (POSN 2) (PRE CONVERTER) (ACDelco #213-3533) [КИСЛОРОДНЫЙ ДАТЧИК]
12590847 SENSOR, HTD OXY (POSN 3) (POST CONVERTER) (ACDelco #213-3538)
15709703 ГАЙКА, HEX 10X1.5THD, 21.8 OD SS (EXH MUFF) [ГАЙКА М10]
15028620 STUD, EXH PIPE (PART OF 12) (M10X1.5X30MM) (BUTTON HEAD) [ШПИЛЬКА]
20757529 MUFFLER, EXH (W/RESO, EXH & TAIL PIPE) (INCLS 11)
15092802 INSULATOR, EXH MUFF HNGR [ДЕМПФЕР ГЛУШИТЕЛЯ]
(TC03-918) - 2007-2009 CK1(06-36) ТОПЛИВНЫЙ БАК
10325852 RETAINER, FUEL SDR (130 MM OPENING CAM LOCK RING) (3.115) (ACDelco #TR26) [ОПОРНОЕ КОЛЬЦО ТОПЛИВНОГО НАСОСА]
16238399 SENSOR, F/TNK PRESS (PART OF 4) (ACDelco #16238399) [ДАТЧИК ДАВЛЕНИЯ ПАРОВ ТОПЛИВА]
19168130 SENSOR KIT, FUEL LVL (IF MODULE RESERVOIR ASM HAS FUEL LEVEL SENSOR POSITIONED SIDE TO SIDE USE FUEL LEVEL SENSOR KIT 19207717.) (ACDelco #19168130)
19207717 SENSOR KIT, FUEL LVL (CONTAINS 2 FUEL LEVEL SENSORS, BOTH STYLES) (ACDelco #SK1265)
teamcadillac.ru
19207716 MODULE KIT, F/TNK F/PMP (INCLS 2, 5) (INCLUDES FUEL LEVEL SENSOR) (ACDelco #MU1639) [ТОПЛИВНЫЙ НАСОС]
22682111 SEAL, FUEL SDR (O RING) (PART OF 4) (135.5 MM ID X 147.5MM OD X 6MMTALL) (ACDelco #G41) [ПРОКЛАДКА]
25904451 TANK, FUEL (29.6 GAL) (ORDER T/W 25904931) [ТОПЛИВНЫЙ БАК]
15078884 SHIELD, F/TNK RR
10009923 ГАЙКА, BOLT RETAINING ПРУЖИНА, M8X1.25, 25 O.D., ZOR (F/TNK SHLD)
15168952 RETAINER, F/TNK H/SHLD
15836686 SHIELD, F/TNK HT
(TC03-919) - 2007-2009 CK1(06-36) КРЕПЛЕНИЕ ТОПЛИВНОГО БАКА
11517806 NUT-U, M10X1.5, 30.5X28.6, 15.5 C/E, 2-5 PNL, 1050, 7111M (F/TNK STRP)
teamcadillac.ru
15745096 STRAP, F/TNK (REAR)
15745095 STRAP, F/TNK (FRONT)
11519894 BOLT-HEX W/CON WA, M10X1.5X55, 42.3 THD, 20 OD, 10.9, 7114M, MACH, MAT-PT (F/TNK STRP)
(TC04-927) - 2007 CK1,2(06-36) АКСЕЛЕРАТОР (POWER ADJUSTABLE PEDAL JF4, AN3)
15000145 БОЛТ, BRK PED PIV (12X1.75X120, 25)
11514598 ГАЙКА, BRK PED PIV (HF 12X1.75) (8.915) [ГАЙКА М12]
11517182 БОЛТ, BRK PED BRKT (M10X1.5X30, 15 THD) (8.900)
11517996 ГАЙКА, P/B BOOS (M10X1.5, 11.2 THK) (8.917) [ГАЙКА М10]
teamcadillac.ru
11562023 БОЛТ, ELEK THROT ACTR (PAN HEAD, M6X1X40, 15 THD, 12 OD, 10.9 STL, GM4277, HDR PT)
15123616 ACTUATOR PKG, THROT
15824012 BRACKET KIT, ACCEL PED ("FOR USE W/2-BOLT CBL ATTACHMENT AT ADJ MOTOR;USE PN-25863992 FOR TWIST-LOCK CBL ATTACHMENT AT ADJ PFL MOTOR.")
11505213 ГАЙКА, PUSH ON, M8, 1.96THK, 16.03 O.D., STL, PC (PART OF 17)
15685170 ГАЙКА, HEX-HD, W/FL WA, M6X1, 5.5 THK, 9, 7111M, 2MM THK 19 OD WA, NYLOC (ACCEL PED LVR) (8.917)
11516424 БОЛТ, HFH, M6X1X25, 14.2 O.D., HDR PT, 9.8, ZE (ACCEL PED LVR) [БОЛТ М6]
25832864 PEDAL, ACCEL (INCLS 13) (INCLS POSITION SENSOR)
25981009 SWITCH, S/LP (ACDelco #D1539J) [КОНЦЕВОЙ ВЫКЛЮЧАТЕЛЬ ПЕДАЛИ ТОРМОЗА]
11569844 RETAINER, BRK PED PUSH ROD (WITH BOLT)
15200851 BUSHING, BRK PED PIV [НАКЛАДКА]
25968689 PEDAL, BRK (INCLS 8, 9, 25-27) (IF REPL BRK PDL W/ 2-BOLT CBL ATTCHMNT AT ADJ PDL MOTOR, REQUIRES ACCEL BRKT KIT W/ CBL, PN 25863992)
88982977 SENSOR, BRK PED POSN (INCLS 23)
88982976 PAD, BRK PED (PART OF 22)
(TX03-040) - 2007-2008 CK1,2,3 РАМКА ТОПЛИВНОГО ИНЖЕКТОРА (LC9/5.3-3,LMG/5.3-0,LY6/6.0K,L76/6.0Y,L92/6.2-8)
12621563 RAIL, M/PORT F/INJN FUEL (CRIMPED CROSSOVER TUBE RETAINER (INCLS 520, 522-528))
25532662 CAP, FUEL PRESS SERV VLV (PART OF 510, 524) (CAP FOR PRESSURE TEST SCHRADER VALVE) (3.163) (ACDelco #214-1044) [КРЫШКА]
12570619 VALVE KIT, FUEL PRESS SERV (INCLS VALVE, CAP, SEALS) (PART OF 510) (INCLS 523) (ACDelco #12570619) [КЛАПАНА]
89017590 RETAINER KIT, F/INJN FUEL RL C/OVR TUBE (PART OF 510) (INCLS 526)
12580681 INJECTOR, SEQ M/PORT FUEL (INCLS INJECTOR, RETAINER, SEALS) (INCLS 521, 532, 534) (ACDelco #217-1621) [ТОПЛИВНЫЙ ИНЖЕКТОР]
12570620 RETAINER KIT, F/INJR (INCLS 521) (W/ 8 RETAINERS) (ACDelco #12570620)
teamcadillac.ru
12587147 SEAL KIT, F/INJR (O RING) (INCLS 532, 534) (W/ 8 UPPER & 8 LOWER SEALS) (ACDelco #217-1588) [ЗАСЛОНКА]
04 - АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ
(GM04-555) - 2007-2009 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) АКПП БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ
24227130 БОЛТ, C/VLV UPR BODY (M5X0.8X36)
24225398 БОЛТ, A/TRNS INPUT & OUTPUT SPD SEN (M6 X 1.0 X 20)
24238417 SENSOR, A/TRNS INPUT & OUTPUT SPD (INCLS 316) [ДАТЧИК ЧИСЛА ОБОРОТОВ ВАЛА AКПП]
24231442 BODY, C/VLV UPR (MUST USE T/W 24236934/PLATE KIT - CONT SOL VLV FLTR)
24242053 PLATE, C/VLV BODY SPCR (W/GSKT) (MUST USE T/W 24236934/PLATE KIT - CONT SOL VLV FLTR) (ACDelco #24242053) (USED W/2007 TRANS BROADCAST CODES) (FOR 2008 TRANS BROADCAST CODES SEE 24239408)
96020431 VALVE, C/VLV BODY BALL CHK [КЛАПАН]
24250384 BODY, C/VLV LWR (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ/НИЖНИЙ КЛАПАН РЕГУЛЯТОР BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (MANUAL VALVE NOT INCLUDED) (MUST USE T/W 24236934/PLATE KIT - CONT SOL VLV FLTR)
24246427 SWITCH, A/TRNS MAN SHFT SHF POSN (INCLS 315) (INTERNAL MODE SWITCH) [ВКЛЮЧАТЕЛЬ]
24224821 БОЛТ, C/VLV LWR BODY (M5X0.8X45)
24224822 БОЛТ, C/VLV LWR BODY (M5X0.8X55)
24236934 PLATE KIT, CONT SOL VLV FLTR [ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АКПП]
teamcadillac.ru
24240845 БОЛТ, CONT SOL VLV HEAT SINK (W/ BODY & TCM) (M5X0.8X53.0)
24238968 VALVE, CONT SOL (W/ BODY & TCM) (ORDER T/W 24236927 SEAL KIT) [ГИДРОРАСПРЕДЕЛИТЕЛЬ АКПП]
24236233 CLIP, A/TRNS MAN SHFT SHF POSN SW WRG HARN (PART OF 308)
24236504 CLIP, A/TRNS INPUT & OUTPUT SPD SEN WRG HARN (PART OF 303)
(GM04-556) - 2007-2009 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) ВЕРХНИЙ КЛАПАН РЕГУЛЯТОР BODY ASSEMBLY
24224766 PIN, C/VLV BODY LOC (DIA.=10MM L=12.7) [ВТУЛКА ГИДРОРАСПРЕДЕЛИТЕЛЯ АКПП]
24231442 BODY, C/VLV UPR (INCLS 324-327, 329, 330, 334-338) (MUST USE T/W 24236934/PLATE KIT - CONT SOL VLV FLTR)
24230200 PIN, C/VLV BODY LOC (DIA.=10MM L=29.9) [ВТУЛКА ГИДРОРАСПРЕДЕЛИТЕЛЯ АКПП]
24224755 RETAINER, 1-2-3-4 CLU BOOST VLV SPR [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АКПП]
teamcadillac.ru
24242814 PLUG, 1-2-3-4 CLU REG VLV BORE (9.5 THK, 11.5 DIA)
(GM04-557) - 2007-2009 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) НИЖНИЙ КЛАПАН РЕГУЛЯТОР BODY ASSEMBLY
24224755 RETAINER, CLU PSTN DAM FEED REG VLV SPR [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АКПП]
24242814 PLUG, CLU SEL SOL VLV BORE #2 (9.5 THK, 11.5 DIA)
teamcadillac.ru
24250384 BODY, C/VLV LWR (INCLS 338, 352, 353, 355-357) (MANUAL VALVE NOT INCLUDED) (MUST USE T/W 24236934/PLATE KIT - CONT SOL VLV FLTR)
24224770 VALVE, MAN (ACDelco #24224770)
(GM04-559) - 2007-2009 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) 4-5-6 ДЕТАЛИ СЦЕПЛЕНИЯ & ВАЛ ТУРБИНЫ
24233406 RING, 4-5-6 CLU BKG PLT RET (PURPLE) (2.49MM +/- 0.05)
24233407 RING, 4-5-6 CLU BKG PLT RET (YELLOW) (1.65MM +/- 0.05)
24233408 RING, 4-5-6 CLU BKG PLT RET (NONE) (2.07MM +/- 0.05)
24240654 PLATE, 4-5-6 CLU BKG
24224158 PLATE, 4-5-6 CLU (PKG OF 7) (FIBER) (*KIT1) [ДИСК АКПП]
teamcadillac.ru
24224648 PLATE, 4-5-6 CLU (PKG OF 7) (STEEL)
24224647 PLATE, 4-5-6 CLU (WAVED)
24237851 RING KIT, RET (1234 DAM, 1234 HSG, 456 DAM) (4.224)
24232417 DAM, 4-5-6 CLU PSTN
24224714 ПРУЖИНА, 4-5-6 CLU
24232416 PISTON, 4-5-6 CLU
24237556 ШЛАНГИ, 4-5-6 CLU (W/ INPUT SHF) (INCLS 440) (ACDelco #24237556) [ЗУБЧАТЫЕ КОЛЬЦА АВТОМАТИЧЕСКОЙ ТРАНСМИССИИ]
24224655 RING, TURB SHF FLUID SEAL (ACDelco #24224655)
24219390 SEAL, TURB SHF (O RING) (ACDelco #24219390)
24236940 PLATE KIT, CLU (INCLS 433) (ACDelco #24236940)
(GM04-560) - 2007-2009 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) 2-6 ДЕТАЛИ СЦЕПЛЕНИЯ
24232994 RING, 2-6 CLU BKG PLT RET
24224171 PLATE, 2-6 CLU BKG
24240221 PLATE, 2-6 CLU (PKG OF 6) (FIBER) (*KIT1)
teamcadillac.ru
24232497 PLATE, 2-6 CLU (PKG OF 6) (STEEL)
24224659 PLATE, 2-6 CLU (WAVED)
24235463 RING, 2-6 CLU SPR RET
24224725 ПРУЖИНА, 2-6 CLU
24224169 PISTON, 2-6 CLU
24232457 SUPPORT, CTR (INCLS 458, 460)
24236940 PLATE KIT, CLU (INCLS 452) (ACDelco #24236940)
(GM04-561) - 2007-2009 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) LOW & REVERSE ДЕТАЛИ СЦЕПЛЕНИЯ
24232457 SUPPORT, CTR (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ/CLUTCH" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА)
teamcadillac.ru
24224737 RING, LOW & REV CLU BKG PLT RET (2.31MM +/- 0.05)
24245063 RING, LOW & REV CLU BKG PLT RET (1.90MM +/- 0.05)
24245064 RING, LOW & REV CLU BKG PLT RET (2.72MM +/- 0.05)
24224175 PLATE, LOW & REV CLU BKG
24237448 PLATE, LOW & REV CLU (PKG OF 6) (FIBER) (*KIT1) (ACDelco #24237448)
24232496 PLATE, LOW & REV CLU (PKG OF 6) (STEEL) (ACDelco #24232496)
24224734 PLATE, LOW & REV CLU (WAVED) (ACDelco #24224734)
24224733 RING, LOW & REV CLU SPR RET (4.189)
24237850 SPRAG, LOW CLU (TRANS BUILT ON 10-31-06 & PRIOR)
24243894 SEAL KIT, A/TRNS SERV (CLUTCHES) (ACDelco #24243894)
24224732 ПРУЖИНА, LOW & REV CLU (ACDelco #24224732)
24224172 PISTON, LOW & REV CLU (ACDelco #24224172)
24236940 PLATE KIT, CLU (INCLS 463) (ACDelco #24236940)
(GM04-562) - 2007-2009 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) CLUTCH HUB ASSEMBLY
24238004 HUB, 4-5-6 CLU (W/ OUTPUT CARR SHF & DPNR) (INCLS 476-478)
24230368 DAMPENER, 4-5-6 CLU (PART OF 475)
teamcadillac.ru
24233359 PLATE, 4-5-6 CLU DPNR APPLY (PART OF 475)
24230370 RING, 4-5-6 CLU DPNR RET (PART OF 475)
(GM04-563) - 2007-2009 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) OUTPUT CARRIER ASSEMBLY
24224853 BEARING, CTR SUPT RLR (PART OF 490)
teamcadillac.ru
24224176 BEARING, OUTPUT CARR OTR SUN GR FRT THR (PART OF 490)
24224177 GEAR, OUTPUT CARR FRT SUN (PART OF 490) (ACDelco #24224177)
24224178 BEARING, OUTPUT CARR OTR SUN GR RR THR (PART OF 490)
24235435 GEAR, OUTPUT CARR RR SUN (PART OF 490)
24224747 CARRIER, OUTPUT (INCLS 485-489, 491) (ACDelco #24224747)
(GM04-570) - 2007-2008 CK1(06-36) УСИЛИТЕЛЬ ТОРМОЗОВ (JD9)
15947019 BOOSTER, P/B (VAC) (INCLS 4, 5) (4.805) (ACDelco #178-0787)
15823208 SENSOR KIT, P/B BOOS VAC (INCLS 2) (ACDelco #15823208)
15823207 VALVE KIT, P/B BOOS VAC CHK (INCLS 2)
(GM04-640) - 2007-2009 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) 1-2-3-4 & 3-5 REVERSE ДЕТАЛИ СЦЕПЛЕНИЯ
24240197 RING, 1-2-3-4 CLU BKG PLT RET (NO COLOR) (2.42-2.52) (ACDelco #24240197)
24240199 RING, 1-2-3-4 CLU BKG PLT RET (BLUE) (2.96-3.06)
24240200 RING, 1-2-3-4 CLU BKG PLT RET (ORANGE) (3.23-3.33)
24240201 RING, 1-2-3-4 CLU BKG PLT RET (WHITE) (3.50-3.60) (ACDelco #24240201)
24224149 PLATE, 3-5 REV CLU BKG
24224148 PLATE, 3-5/REV CLU (PKG OF 5) (FIBER) (*KIT4)
24232498 PLATE, 3-5 REV CLU (PKG OF 5) (STEEL)
24239828 PLATE, 3-5 REV CLU (WAVED)
24224633 RING, 3-5-REV CLU APPLY (ACDelco #24224633)
24222632 PLATE, 1-2-3-4 CLU BKG
24224147 PLATE, 1-2-3-4 CLU (PKG OF 6) (FIBER) (*KIT4)
24238701 PLATE, 1-2-3-4 CLU
24239615 PLATE, 1-2-3-4 CLU (WAVED)
24224708 DAM, 1-2-3-4 CLU PSTN
24224707 ПРУЖИНА, 1-2-3-4 CLU
24224146 PISTON, 1-2-3-4 CLU
24224878 ПРУЖИНА, 3-5-REV CLU
24234213 PISTON, 3-5/REV CLU (INCLS 422)
teamcadillac.ru
24237185 ШЛАНГИ, 1-2-3-4 & 3-5 REV CLU (INCLS 426) (ORDER T/W 24226393)
24226393 BEARING, 1-2-3-4 & 3-5-REV CLU
24248578 SEAL KIT, A/TRNS SERV (INLCS 411, 415, 416, 419, 423-425) (FULL TRANS) (ACDelco #24248578)
24237851 RING KIT, RET (INCLS 411, 415) (1234 DAM, 1234 HSG, 456 DAM) (4.224)
24243894 SEAL KIT, A/TRNS SERV (INCLS 416, 418, 419, 422-425) (CLUTCHES) (ACDelco #24243894)
24236940 PLATE KIT, CLU (INCLS 402, 408) (ACDelco #24236940)
(TC04-602) - 2007-2009 K1,2,3 КОРПУС КП SHIELD (NZZ)
15049809 SHIELD, TRFER CASE [ЗАЩИТА]
11518341 БОЛТ, HEX, M10X1.5X25, 14 THD, 28 OD, 6202M, 7114M, TAP, TR-PT (TRFER CASE SHLD) [БОЛТ М10Х1.5Х25]
teamcadillac.ru
(TC04-654) - 2007-2009 CK1 ТОРМОЗНОЙ СУППОРТ-ПЕРЕДНИЙ
15904194 CALIPER, FRT BRK (INCLS 2, 3, 6-9) (ACDelco #172-2402) [ТОРМОЗНОЙ СУППОРТ]
15904195 CALIPER, FRT BRK (INCLS 2, 3, 6-9) (ACDelco #172-2408) [СУППОРТ ТОРМОЗА]
25846360 VALVE, FRT BRK CLPR BLEDR (DELPHI CHASSIS, M10 X 1.5) (PART OF 1) (M10X1.5) (ACDelco #25846360)
18009891 COVER, FRT BRK BLEDR SCREW (PART OF 1) (M10X1.5 THD) (4.665)
15125961 БОЛТ, FRT BRK CLPR BRKT (*KIT1, KIT3)
25951292 SEAL KIT, FRT BRK CLPR PSTN (INCLS 9) (PART OF 1) [КОМПЛЕКТ УПЛОТНИТЕЛЬНЫХ КОЛЕЦ ТОРМОЗНОГО СУППОРТА (2ШТ)]
15125962 PISTON, FRT BRK CLPR (PART OF 1)
88963550 PIN KIT, FRT BRK CLPR GDE (INCLS 4, 5, 7, 12)
15299068 BUSHING KIT, FRT BRK CLPR GDE PIN (INCLS 7) [КОМПЛЕКТ ВТУЛОК ТОРМОЗНОГО СУППОРТА]
teamcadillac.ru
25910431 PAD KIT, FRT DISC BRK (INCLS 4, 10, 12) (ACDelco #171-0974) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4 ШТ)]
25918341 PAD KIT, FRT DISC BRK (INCLS 4, 10, 12) (ACDelco #171-0975) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4 ШТ)]
(TC04-718) - 2007-2009 K1 FRAME/TRANSMISSION SUPPORTS
11589247 BOLT-HFH, M14X2X165.5, 58.2 THD, 30.5 ID, 10.9, 7114M, MACH, CONE-PT (TRANS SUPT C/MBR)
teamcadillac.ru
11516382 ГАЙКА, HFH LK M14X2X15, 28 OD 10 7111M (TRANS SUPT C/MBR) [ГАЙКА М10]
15894408 CROSSMEMBER, TRANS SUPT
(TC04-901) - 2007-2009 CK1 TRANSMISSION FILLER TUBE & INDICATOR (4L80 AUTOMATIC MYC)
15877378 INDICATOR, TRANS FLUID LVL
teamcadillac.ru
25879175 TUBE, TRANS FLUID FIL
11516780 ГАЙКА, HEX W/CON WA, M8X1.25, 10THK, 19 O.D., 10, 7111M (TRANS FLUID FIL TUBE) (8.917) [ГАЙКА М8]
15796802 SEAL, TRANS FLUID FIL TUBE [УПЛОТНИТЕЛЬ ШЛАНГА МАСЛОПРОВОДА]
15029928 БОЛТ, TRANS H/SHLD (M8X1.25X12)
25980339 SHIELD, TRANS HT
(TC04-904) - 2007-2009 CK1 УПРАВЛЕНИЕ АКПП/АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (6L80 AUTOMATIC MYC)
15831435 BRACKET, A/TRNS RANGE SEL LVR CBL
teamcadillac.ru
15116345 RETAINER, A/TRNS RANGE SEL LVR CBL [ОПОРНАЯ СКОБА ТРОСИКА АКПП]
11610265 БОЛТ, PAN HD W/FL WA, M8X1.25X21.5, 15 THD, 22 OD, 8.8, GMW3044 (A/TRNS RANGE SEL LVR CBL BRKT)
15915999 LEVER, A/TRNS RANGE SEL LVR EQLZR
11514597 ГАЙКА, HFH, 10X1.5 THD, 9.8 THK, 21.8 OD, 510M (10) ZF 7111M (A/TRNS RANGE SEL LVR EQLZR LVR) (2.383)
(TC04-906) - 2007-2008 CK1 BRAKE CALIPER MOUNTING/FRONT & KNUCKLE
15719028 БОЛТ, FRT WHL BRG (M14X1.5X70) (6.104) [БОЛТ М14]
15016308 БОЛТ, M14X2X40, 40 THD, 28 OD, 10.9, GM6174M, LOCTITE PATCH GM6194M (S/KNU) (4.665)
11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (FRT WHL SPD SEN) [БОЛТ М6]
15133409 BRACKET, FRT WHL SPD SEN
15942236 KNUCKLE, STRG (MCHG)
15942237 KNUCKLE, STRG (MCHG) [ПОВОРОТНЫЙ КУЛАК ПОДВЕСКИ]
25918337 SHIELD, FRT BRK
25918338 SHIELD, FRT BRK
15715956 CLIP, WHL SPD SEN WIRE (PART OF 11, 14) (10.00MM) (1 HOLE CLIP)
15267361 CLIP, WHL SPD SEN WIRE (PART OF 11, 14) (CLAM SHELL WITHOUT ALIGNMENT PIN)
15229013 CLIP, WHL SPD SEN WIRE (PART OF 11, 14) (SLIDE LOCK WITH ALIGNMENT PIN)
teamcadillac.ru
15229012 SENSOR, FRT WHL SPD (INCLS 8-10) (PART OF 14) (ACDelco #15229012) (FOR VEHICLES WITH RPO PPV-USE T/W THERMAL WRAP PN 19207924, BETWEEN WHEEL SPEED SENSOR HEAD AND FIRST CLIP.) [ДАТЧИК АБС (КОЛИЧЕСТВА ОБОРОТОВ КОЛЕСА)]
15960191 БОЛТ, WHL SPD SEN (PART OF 14) (M6X1X12)
11588810 STUD, FRT WHL (PART OF 14) (M14X1.5X65) [ШПИЛЬКА КРЕПЛЕНИЯ КОЛЕСА]
25918329 HUB, FRT WHL (W/WHL SPD SEN) (INCLS 8-13) (ACDelco #FW346)
25819670 ROTOR, FRT BRK (13IN) (ACDelco #177-1014) [ТОРМОЗНОЙ ДИСК]
11609271 БОЛТ, FRT BRK ROT (M8 X 1.25 X 20)
(TC04-907) - 2007-2009 CK1(06-36) ТОРМОЗНОЙ СУППОРТ-ЗАДНИЙ
teamcadillac.ru
15792635 CALIPER KIT, RR BRK (INCLS 2-8) [ТОРМОЗНОЙ СУППОРТ]
15792636 CALIPER KIT, RR BRK (INCLS 2-8) [ТОРМОЗНОЙ СУППОРТ]
25823358 БОЛТ, RR BRK CLPR GDE PIN (PART OF 1) (*KIT1, KIT3)
15265833 BRACKET, RR BRK CLPR
15792650 ATTACHMENT KIT, RR BRK CLPR (INCLS 2, 9, 10, 13) [НАПРАВЛЯЮЩАЯ ТОРМОЗНОГО СУППОРТА]
88967108 VALVE KIT, RR BRK BLEDR (INCLS 3-5) (ACDelco #88967108)
15945636 PAD KIT, RR DISC BRK (INCLS 2, 11, 13, 14) (ACDelco #171-0982)
(TC04-910) - 2007-2009 CK1(06-36) СТОЯНОЧНЫЙ ТОРМОЗ SYSTEM
15227288 MODULE, PARK BRK CONT (INCLS 3, 5, 8, 10)
20803171 MODULE, PARK BRK CONT (INCLS 3, 5, 8, 10) (EBONY) (ACDelco #20803171) [ПЕДАЛЬ ТОРМОЗА]
15045983 SWITCH, PARK BRK (PART OF 1)
09418944 SCREW, HWH, SELF TAP, #10-16X1", 3/8" O.D., M6010M, ZN (PARK BRK ACTR POSN SW)
15929213 HANDLE, PARK BRK REL (PART OF 1) (EBONY) (INCLS CBL) [РУКОЯТКА ПАРКОВОЧНОГО ТОРМОЗА]
15929215 HANDLE, PARK BRK REL (PART OF 1)
11588831 SCREW, HEX W/ CON WA, M6X1X35, 33.5 THD, 17 O.D.HDR PT, 9.8, BLK (PARK BRK REL HDL HSG)
15298817 PAD, PARK BRK LVR PED (PART OF 1)
teamcadillac.ru
15183623 CABLE, PARK BRK INTER [ТРОС СТОЯНОЧНОГО ТОРМОЗА В ПЛАСТИКОВОЙ ОБОЛОЧКЕ]
25793731 CABLE, PARK BRK RR
25864664 CABLE, PARK BRK RR
15043173 CLIP, PARK BRK RR CBL (W/O HOLE) (W/3 OPENINGS)
11517560 SCREW, FLAT WA (NRW) AND HX WA HD, M8X1.25X25 (PARK BRK RR CBL GDE)
15087067 GUIDE, PARK BRK RR CBL (RH REAR FRAME RAIL)
15049571 GUIDE, PARK BRK RR CBL (FRONT)
(TC04-912) - 2007-2009 K1(06-36-43) КОРПУС КП ADAPTER (6L80 AUTOMATIC MYC)
24241166 ADAPTER, TRFER CASE
11515767 БОЛТ, HFH, M10X1.5X35, 32THD, 22.3 O.D., MACH, 10.9, 7114M (TRFER CASE ADAP) (T/W 12345493) [БОЛТ]
24245110 GASKET, TRFER CASE ADAP [ПРОКЛАДКА КОРПУСА РАЗДАТОЧНОЙ КОРОБКИ]
teamcadillac.ru
24246762 CASE, TRFER (W/GEARS) (CODE CW)
(TC04-916) - 2007-2009 CK1,2,3 ШЛАНГ ВЕНТИЛЯЦИИ ТРАНСМИССИИ (6L80 AUTOMATIC MYC, 6L90 AUTOMATIC MYD)
15771000 VENT, A/TRNS (PART OF 4) (ACDelco #15771000) [ФИТИНГ ВЕНТИЛЯЦИИ КОРОБКИ ПЕРЕДАЧ]
19130464 STRAP, TIE 0.38" WIDTH, BUNDLE DIA 1/16"-1-3/4", 8.27" LENGTH, NYLON 6/6 FITS 0. (PART OF 4) [ХОМУТ (ЗАЖИМ) РАДИАТОРА]
01648216 CLAMP, WORM GEAR, HEX-SLOT SCREW, 1/4X5/8, .320 WIDE BAND, BLACK (TRANS VENT HOSE) (ACDelco #1648216)
teamcadillac.ru
15128974 HOSE, TRANS VENT (INCLS 1, 2)
11514596 ГАЙКА, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (TRANS VENT HOSE CLIP BRKT) (8.915) (ACDelco #11514596)
15854320 BRACKET, TRANS VENT HOSE CLIP
(TC04-917) - 2007-2009 K1,2,3 КОРПУС КП VENT TUBE
teamcadillac.ru
15771000 VENT, TRFER CASE (4.104) (ACDelco #15771000) [ФИТИНГ ВЕНТИЛЯЦИИ КОРОБКИ ПЕРЕДАЧ]
19130464 STRAP, TIE 0.38" WIDTH, BUNDLE DIA 1/16"-1-3/4", 8.27" LENGTH, NYLON 6/6 FITS 0. (TRFER CASE VENT HOSE) [ХОМУТ (ЗАЖИМ) РАДИАТОРА]
09438315 HOSE, FUEL-OIL EVAP (TRFER CASE VENT)
01648216 CLAMP, WORM GEAR, HEX-SLOT SCREW, 1/4X5/8, .320 WIDE BAND, BLACK (TRANS FLUID CLR HOSE) (ACDelco #1648216)
(TC04-918) - 2007-2009 CK1(06-36) УСИЛИТЕЛЬ ТОРМОЗОВ & ГЛАВНЫЙ ЦИЛИНДР MOUNTING (JD9)
01470030 CLAMP, WORM TYPE (11/16" TO 1 5/16") (PART OF 1) (ACDelco #1470030)
15974046 GASKET, P/B BOOS
teamcadillac.ru
11517996 ГАЙКА, BRK M/CYL (M10X1.5, 11.2 THK) (8.917) [ГАЙКА М10]
12559760 NIPPLE, P/B BOOS VAC HOSE
(TC04-921) - 2007-2008 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА АКПП (6L80 AUTOMATIC MYC)
15779543 PIPE, TRANS FLUID AUX CLR INL (INCLS 2, 5-7) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ]
15052228 CAP, TRANS FLUID CLR PIPE CONN (PART OF 1, 9) (PLASTIC RETAINER) (ACDelco #15052228) [ФИТИНГ ТРУБОПРОВОДА]
15226661 CONNECTOR, TRANS FLUID CLR PIPE (INCLS 4) (9/16-18) (3/8 BODY QUICK CONNECT) (AT RAD) (ACDelco #15226661)
19210848 CONNECTOR, TRANS FLUID CLR PIPE (INCLS 4) (W/O BEVEL WASHER) (ACDelco #19210848)
24205103 RETAINER, TRANS FLUID CLR PIPE FTG (PART OF 3) (EXPANDING ПРУЖИНА WIRE) (ACDelco #24205103) [СТОПОРНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ]
14093869 ГАЙКА, PUSH ON, M6, 2.25THK, 12.95 O.D., STL, POR (PART OF 1, 9)
15782677 CLIP, TRANS FLUID CLR PIPE (PART OF 1, 9)
15068848 SPACER, TRANS FLUID CLR PIPE (HOLDS 2-9.5MM (3/8") DIA ТРУБКИ , CLIP TOP)
25999420 PIPE, TRANS FLUID CLR (INCLS 2, 5-7, 19) (ACDelco #25999420) [ТРУБКА СИСТЕМЫ ОХЛОЖДЕНИЯ]
11519797 STUD, TRANS (DOUBLE END, HFH, M8X1.25X20, M10X1.5X40, 18 OD, 69.5 TL9.8, GMW3359)
15120618 BRACKET, TRANS FLUID CLR PIPE
15049288 RETAINER, TRANS FLUID CLR PIPE (BLACK) (37.7X39.3) (DOUBLE SNAIL CLIP)
15022958 CLIP, TRANS FLUID CLR PIPE (RETAINS 9.5MM STL TUBING) (2.343)
11516521 БОЛТ, HFH M6X1X20, 9.8, 7114M, DOG PT, 14.2 OD (TRANS FLUID CLR PIPE CLIP)
11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (TRANS FLUID AUX CLR) [ШАЙБА]
25877162 COOLER, TRANS FLUID AUX (CODE 4639, 5464, 9344, 7192) (ACDelco #25877162)
15149708 RETAINER, TRANS FLUID AUX CLR (17.0 X 5.1 X 16.3 MM) (PUSH-IN INCLS PUSH BUTTON LOCK) (17.505) [ПИСТОН КРЕПЛЕНИЯ РАДИАТОРА]
15251488 SEAL, TRANS FLUID CLR PIPE (PART OF 9) (SEALS TWO ТРУБКИ ) [УПЛОТНЕНИЕ]
teamcadillac.ru
11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (TRANS FLUID CLR PIPE) [БОЛТ, М8Х1.25Х31.5]
(TC04-922) - 2007-2009 CK1 BRAKE ELECTRICAL SYSTEM (JD9)
15229012 SENSOR, FRT WHL SPD (INCLS 2, 3, 7) (ACDelco #15229012) (FOR VEHICLES WITH RPO PPV-USE T/W THERMAL WRAP PN 19207924, BETWEEN WHEEL SPEED SENSOR HEAD AND FIRST CLIP.) [ДАТЧИК АБС (КОЛИЧЕСТВА ОБОРОТОВ КОЛЕСА)]
teamcadillac.ru
15229013 CLIP, WHL SPD SEN WIRE (PART OF 1) (SLIDE LOCK WITH ALIGNMENT PIN)
15267361 CLIP, WHL SPD SEN WIRE (PART OF 1) (CLAM SHELL WITHOUT ALIGNMENT PIN)
11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (FRT BRK HOSE) [БОЛТ М6]
15715956 CLIP, WHL SPD SEN WIRE (PART OF 1) (10.00MM) (1 HOLE CLIP)
15960191 БОЛТ, WHL SPD SEN (M6X1X12)
11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (BRK PRESS MOD VLV BRKT) (ACDelco #11570082) [БОЛТ М8]
15121067 SENSOR, RR WHL SPD (INCLS 12-14) [ДАТЧИК АБС (КОЛИЧЕСТВА ОБОРОТОВ КОЛЕСА)]
11570519 SCREW, PAN HD, M6X1X13, 10 THD 12 OD, 9.8, PHOS & OIL.W/ADH (RR WHL SPD SEN)
(TC04-923) - 2007-2009 CK1(06-36) BRAKE CONTROL MODULE (JD9)
15905736 VALVE KIT, BRK PRESS MOD (INCLS 8, 9)
15297115 INSULATOR KIT, BRK PRESS MOD VLV (INCLS 2-4)
15125563 BRACKET, BRK PRESS MOD VLV
15905737 MODULE KIT, ELEK BRK CONT (PART OF 1) (INCLS 9) (ACDelco #15905737)
teamcadillac.ru
22688153 БОЛТ, ELEK BRK CONT MDL (ECU TO HCU ATTACH) (PART OF 1, 8)
(TC04-924) - 2007-2009 CK1(06-36) ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДР (JD9)
15268651 CAP, BRK M/CYL RSVR (PART OF 4) [КРЫШКА РЕЗЕРВУАРА ГЛАВНОГО ЦИЛИНДРА]
15823206 RESERVOIR KIT, BRK M/CYL (PART OF 4) (INCLS 3)
15844166 CYLINDER, BRK MAS (INCLS 1-3, 5, 6) [ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДР]
teamcadillac.ru
15787976 SEAL, BRK M/CYL (PART OF 4) [УПЛОТНИТЕЛЬ ЦИЛИНДРА ТОРМОЗА]
22672096 SWITCH, BRK FLUID LVL IND (PART OF 4) (ACDelco #22672096)
(TC04-927) - 2007 CK1,2(06-36) ТОРМОЗНАЯ ПЕДАЛЬ (POWER ADJUSTABLE PEDAL JF4, AN3)
25825916 BRACKET, BRK & ACCEL PED (INCLS 5, 7) (ТОРМОЗНАЯ ПЕДАЛЬ) (4.634)
teamcadillac.ru
15918012 HARNESS, FUSE BLK WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА)
25968689 PEDAL, BRK (INCLS 8-9, 25-27) (IF REPL BRK PDL W/ 2-BOLT CBL ATTCHMNT AT ADJ PDL MOTOR, REQUIRES ACCEL BRKT KIT W/ CBL, PN 25863992)
88982978 БОЛТ, BRK PED POSN SEN (PART OF 24)
(TC04-928) - 2007-2009 CK1(06-36) ТОРМОЗНЫЕ МАГИСТРАЛИ-ПЕРЕДНИЕ (JD9)
11518522 ГАЙКА, HX FLARED TUBE, M12X1.0X20.5, 11 TUBE, SAE1010, GMW4707M (PART OF 5, 6)
15808174 PIPE, BRK PRESS MOD VLV (INCLS 4, 13)
15808171 PIPE, BRK PRESS MOD VLV FRT (INCLS 4, 13)
11561578 CLIP, RR BRK FRT PIPE (31.72X17.07X15.0) (HOLDS (2) 6.75 TUBES, ROUTING CLIP)
teamcadillac.ru
88936298 PIPE, BRK (STEEL) (1/4" X 16 FT ROLL) (BRK PIPE)
11562230 CLIP, FRT BRK PIPE (52.96X22.53X17) (HOLDS THREE 6.65 TUBES)
11561432 CLIP, FRT BRK PIPE (64.68X25.86X17.0) (HOLDS 4 TUBES)
11561903 CLIP, FRT BRK PIPE (12 DIA X 22/101.4X17) (HOLDS (4)6.35 TUBES, (1)5.O TUBE, (1) 17.O & (1) 33.0 HARNESSES)
11562394 CLIP, FRT BRK PIPE
11562075 ГАЙКА, FRT BRK FRT PIPE (PART OF 5, 6) (M12X1.5X17) (INV FLARE)
11519388 БОЛТ, HX HD CON WA, M8X1.25X25, 20 THD, 24 OD, 8.8, GMW3359 (SILVER), M-POINT (ELEK BRK CONT MDL BRKT) [БОЛТ]
15923783 HOSE, FRT BRK (INCLS 18, 19) (ACDelco #176-1515) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ]
11517342 БОЛТ, HEX HD, W/FL WA, M6X1X20, 9.53 THD, 17 O.D., P-PT, 9.8, 6280M (PART OF 17, 25)
21012386 WASHER, RR BRK HOSE (PART OF 17, 25) (10.3X14.5X1.61) (COPPER) (ACDelco #21012386) [ШАЙБА 10 ММ]
11516885 SCREW, HFH W/FL WA, TAP, M8X1.25X20, 7THD, 17 O.D., TR PT, 6202M, PZOR (FRT BRK HOSE BRKT)
11561421 CLIP, FRT BRK FRT PIPE (FITS INTO DIA 6 HOLE)
11561422 CLIP, FRT BRK FRT PIPE (FITS INTO DIA 8 HOLE)
15923784 HOSE, FRT BRK (INCLS 18, 19) (ACDelco #176-1516) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ]
(TC04-929) - 2007-2009 CK1(06-36) ТОРМОНЫЕ МАГИСТРАЛИ/INTERMEDIATE (JD9)
88936298 PIPE, BRK (STEEL) (1/4" X 16 FT ROLL) (BRK)
teamcadillac.ru
11518522 ГАЙКА, HX FLARED TUBE, M12X1.0X20.5, 11 TUBE, SAE1010, GMW4707M (RR BRK FRT PIPE)
11610034 CLIP, RR BRK FRT PIPE (CLIP HOLDS TWO 6.75 TUBE, FIT 8 DIA HOLE IN 3.2 THK PNL)
11610035 CLIP, RR BRK FRT PIPE (6.9 X 20.4/77.4 X 15) (HOLD DIA 4.8, (2)6.75, 32MM TUBE, FIT 7.2 HOLE 1-5 THK PNL)
11562075 ГАЙКА, RR BRK FRT PIPE (M12X1.5X17) (INV FLARE)
(TC04-932) - 2007-2009 CK1(06-36) ТОРМОНЫЕ МАГИСТРАЛИ-ЗАДНИЕ
25906096 HOSE, RR BRK (AT CALIPER) (INCLS 5, 6) (ACDelco #176-1526) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ]
11569751 ГАЙКА, HX TUBE INVERTED FLARE, M10X1X16, SAE1010, GMW4707M (RR BRK C/OVR PIPE) [ШАЙБА]
11515756 БОЛТ, HFH, M8X1.25X20, 17THD, 18 O.D., 10.9, 7114M (RR BRK C/OVR PIPE BRKT) [БОЛТ]
11561240 CLAMP, SINGLE CLOSED-LOOP, DIA 7.25MM, C-TO-C 36.5, WIDTH 20, HOLE DIA 11 (RR BRK C/OVR PIPE) (8.948)
21012386 WASHER, RR BRK HOSE (PART OF 1, 14) (10.3X14.5X1.61) (COPPER) (ACDelco #21012386) [ШАЙБА 10 ММ]
11570052 БОЛТ, RR BRK HOSE (PART OF 1, 14) (M10X1X27.5, 16.9THD)
88983905 PIPE, BRK (3/16" X 16 FT) (BULK TUBING) (NYLON COATING) [ТРУБКА ТОРМОЗНОЙ СИСТЕМЫ]
11516885 SCREW, HFH W/FL WA, TAP, M8X1.25X20, 7THD, 17 O.D., TR PT, 6202M, PZOR (RR BRK HOSE BRKT)
15104932 HOSE, RR BRK (JOUNCE) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ]
15207574 HOSE, RR BRK (JOUNCE)
15234822 STRAP, RR BRK PIPE
12471307 БОЛТ, R/AXL HSG CVR (M8X1.25X20)
teamcadillac.ru
15791254 BRACKET, RR BRK C/OVR PIPE (CONTAINS BRACKET & SCREW) [КРОНШТЕЙН СБОРН.-ЗАДНЕЙ ТОРМОЗНОЙ ТРУБКИ]
25906097 HOSE, RR BRK (AT CALIPER) (INCLS 5, 6) (ACDelco #176-1528)
(TX04-118) - 2007 CK1 СТОЯНОЧНЫЙ ТОРМОЗ ASM (JD9)
teamcadillac.ru
15265913 ANCHOR, RR PARK BRK
15265914 PLATE, RR PARK BRK ANC BKG
15817021 ADJUSTER KIT, RR PARK BRK (INCLS 5, 6, 9-11)
15817020 SHOE KIT, RR PARK BRK (INCLS 1-3) (SERVICES ONLY ONE SIDE) (ACDelco #171-0992)
15816927 LEVER KIT, RR PARK BRK ACTR (INCLS 7, 8, 13) (4.591)
(TX04-900) - 2007-2009 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) CASE & СОПРЯЖЕННЫЕ ДЕТАЛИ
teamcadillac.ru
17804387 CONVERTER, TORQ (REMAN)
24224574 БОЛТ, T/CV HSG
24205900 COVER, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП]
24224577 SEAL, A/TRNS ГИДРОНАСОС
90351710 PIN, T/CV HSG LOC (0.293)
24237785 CASE, A/TRNS (INCLS 12, 13) (ACDelco #24237785)
24239878 SLEEVE, A/TRNS ELEC CONN PASG [МУФТА]
24238076 SEAL, OUTPUT SHF
11515768 БОЛТ, HFH, REDUCED BODY, M10X1.5X40, 30THD, 22.3 O.D., HDR PT, 10.9, 7114M (A/TRNS CASE EXTN) [БОЛТ М10Х1.5Х40]
24224820 БОЛТ, VLV BODY (USED ON TRANS BUILT ON 12-31-06 & PRIOR) (FOR 2ND DES SEE 24237181)
24237181 БОЛТ, VLV BODY (M5X0.8X73.0) (USED ON TRANS BUILT ON 01-01-07 & AFTER) (FOR 1ST DES SEE 24224820)
24231074 БОЛТ, MAN SHFT DTNT (M10X1X14.5)
24222646 DETENT, MAN SHFT (W/8MM DIA. ROLLER) (ACDelco #24222646)
24236933 FILTER KIT, A/TRNS FLUID (INCLS 25) (ACDelco #24236933) [МАСЛЯНЫЙ ФИЛЬТР АКПП]
24224781 GASKET, A/TRNS FLUID PAN (ACDelco #24224781) [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА АКПП]
29535617 MAGNET, A/TRNS FLUID PAN (4.105) (ACDelco #29535617) [МАГНИТ]
24222657 PAN, A/TRNS FLUID (WITHOUT PLUG AND GASKET) (ACDelco #24222657)
11569816 БОЛТ, HFH, M6X1X19, 11.5 THD, 14.2 OD, 8.8 STL, GMW3359-BLACK, MAT POINT (A/TRNS FLUID PAN)
24224675 SEAL, A/TRNS CASE EXTN (*KIT1) (ACDelco #24224675)
24248577 SEAL KIT, A/TRNS SERV (INCLS 33, 36) (ACDelco #24248577)
24248578 SEAL KIT, A/TRNS SERV (INCLS 33, 36) (FULL TRANS) (ACDelco #24248578)
24236927 SEAL KIT, A/TRNS SERV (INCLS 9, 10, 18-20) (CNTRL SOL VLV ASM) (ACDelco #24236927) [КОМПЛЕКТ ПРОКЛАДОК АКПП (3 РЕЗ, 3 МЕТ)]
(TX04-901) - 2007-2009 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) ГИДРОТРАНСФОРМАТОР ШЛАНГИ & ГИДРОНАСОС
teamcadillac.ru
24218963 RING, T/CV FLUID SEAL RET [КОЛЬЦО]
24237531 SEAL, T/CV FLUID (ACDelco #24237531) [УПЛОТНЕНИЕ АКПП]
00444613 PLUG, HEX HD, 1/8-27 NPTF, STL (LINE PRESS TEST HOLE) (ACDelco #444613)
24236120 ШЛАНГИ, T/CV (MCHG) (INCLS 206) (ACDelco #24236120)
24231684 PIPE, A/TRNS VENT
24237658 SEAL, TRANS FLUID CLR PIPE FTG (SEALS ONE PIPE) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ]
24222668 SLIDE, A/TRNS ГИДРОНАСОС (17.948MM-17.961MM) (ACDelco #24222668)
24224131 SLIDE, A/TRNS ГИДРОНАСОС (17.961MM-17.974MM) (ACDelco #24224131)
24224132 SLIDE, A/TRNS ГИДРОНАСОС (17.974MM-17.987MM) (ACDelco #24224132)
00147500 VALVE, PRESS RLF BALL (*KIT2)
24224692 WASHER, 1-2-3-4 & 3-5 REV CLU HSG THR (*KIT2)
24238248 RING, 1-2-3-4 & 3-5 REV CLU FLUID SEAL (*KIT2)
24227061 БОЛТ, A/TRNS ГИДРОНАСОС CVR (ACDelco #24227061) [БОЛТ]
90351709 PIN, A/TRNS ГИДРОНАСОС LOC ("8MM HOLLOW SPLIT PIN") (*KIT2) (1.639) [ШПИЛЬКА]
24236935 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS 207-211, 213-217) (17.948MM-17.961MM) (4.224) (ACDelco #24236935)
24236936 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS 207-211, 213-217) (17.961MM-17.974MM) (4.224) (ACDelco #24236936)
24236937 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS 207-211, 213-217) (17.974MM-17.987MM) (4.224) (ACDelco #24236937)
24236939 COVER KIT, A/TRNS ГИДРОНАСОС (INCLS 218-230, 232-237) (ACDelco #24236939)
(TX04-902) - 2007-2009 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) ЗАМОК ПАРКОВКИ
24242085 ACTUATOR, PARK PAWL (ACDelco #24242085)
24227077 PIN, MAN SHFT DTNT LVR HUB
24234562 LEVER, MAN SHFT DTNT (ACDelco #24234562)
24225792 PIN, MAN SHFT SHF (ACDelco #24225792)
teamcadillac.ru
24235861 SEAL, MAN SHFT SHF (ACDelco #24235861) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО АКПП]
24225445 SHAFT, MAN SHFT (ACDelco #24225445)
24224348 GUIDE, PARK PAWL ACTR (INCLS 510)
24224350 SEAL, PARK PAWL ACTR GDE (O RING) (PART OF 509) (ACDelco #24224350)
24226102 PIN, PARK PAWL ACTR GDE
(TX04-903) - 2007-2009 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) ВЫХОДНОЙ ВАЛ ASSEMBLY
24241091 RING, OUTPUT CARR INTL GR RET (ACDelco #24241091)
teamcadillac.ru
24224194 GEAR, OUTPUT CARR INTL (FRT) (ACDelco #24224194)
24227962 SPACER, OUTPUT CARR INTL GR
24230545 GEAR, OUTPUT CARR INTL (RR) (ACDelco #24230545)
24238883 SHAFT, OUTPUT (INCLS 498)
(TX04-904) - 2007-2009 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) АКПП БЛОК СЦЕПЛЕНИЯ & СОПРЯЖЕННЫЕ ДЕТАЛИ
24236874 CARRIER, INPUT (ACDelco #24236874)
24224404 GEAR, INPUT SUN (ACDelco #24224404)
24224405 BEARING, INPUT SUN GR THR (ACDelco #24224405)
24232409 WASHER, INPUT SUN GR THR
24238905 BEARING, TURB SHFT THR [ПОДШИПНИК]
teamcadillac.ru
24238004 HUB, 4-5-6 CLU (W/ OUTPUT CARR SHF & DPNR) (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ/CLUTCH HUB" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА)
24233732 BEARING, 4-5-6 CLU HUB THR (ACDelco #24233732)
24240409 HUB, 1-2-3-4 CLU (W/OUTPUT CARR INR SUN GR SHF) (ACDelco #24240409)
24224163 BEARING, 1-2-3-4 CLU HUB THR (ACDelco #24224163)
24240407 HUB, 2-6 & 3-5/REV CLU (W/ OUTPUT CARR OTR SUN GR SHF) (INCLS 60, 62) (ACDelco #24240407)
24224164 BEARING, 2-6 & 3-5/REV CLU HUB THR (ACDelco #24224164)
24224724 RING, CTR SUPT RET
24224747 CARRIER, OUTPUT (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ/OUTPUT CARRIER" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #24224747)
24224188 BEARING, OUTPUT CARR THR (ACDelco #24224188)
24238883 SHAFT, OUTPUT (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ/ВЫХОДНОЙ ВАЛ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА)
24224668 BEARING, OUTPUT SHF THR (ACDelco #24224668)
(TX04-905) - 2007-2009 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) ASSEMBLY
12491876 TRANSMISSION, AUTO (GOODWRENCH REMAN) (CODE 7CJA)
teamcadillac.ru
(TX04-906) - 2007-2009 K1 КОРПУС КП (NR3) ЧАСТЬ 1 CASE COMPONENTS-AWD (BORG WARNER 4485)
teamcadillac.ru
89059522 STUD, TRFER CASE ADAP (PART OF 2)
19132934 CASE, TRFER (FRT HALF) (INCLS 1, 3, 14)
88984499 PIN, TRFER CASE HALF LOC (PART OF 2)
19132802 BUSHING, TRFER CASE RR EXTN (PART OF 11) [ВТУЛКА РАЗДАТОЧНОЙ КОРОБКИ]
89059495 SEAL, TRFER CASE RR OUTPUT SHF [УПЛОТНЕНИЕ РАЗДАТОЧНОЙ КОРОБКИ]
88984495 PLUG, TRFER CASE OIL FILL [КОЛПАК]
89059524 БОЛТ, TRFER CASE HALF (M8X1.25X43.0)
88996459 BRACKET, TRFER CASE (UPPER)
88984495 PLUG, TRFER CASE OIL FILL (DRAIN) [КОЛПАК]
19132804 CASE, TRFER (RR HALF) (INCLS 4) (USE ON T/CASE W/BROADCAST CODE CW, GC, OR GF) (FOR 2ND DES SEE 19153151)
19153151 CASE, TRFER (RR HALF) (CODE KK) (INCLS 4) (USE ON T/CASE W/BROADCAST CODE 8887 OR HJ) (FOR 1ST DES SEE 19132804)
88984501 SEAL, TRFER CASE FRT OUTPUT SHF [УПЛОТНЕНИЕ ТРАНСФОРМАТОРНОЙ КОРОБКИ]
15580319 VENT, TRFER CASE
19132801 SEAL, TRFER CASE INPUT SHF (PART OF 2) [ПРОКЛАДКА]
(TX04-907) - 2007-2009 K1 КОРПУС КП (NR3) ЧАСТЬ 2 INTERNAL COMPONENTS-AWD (BORG WARNER 4485)
88984507 BEARING, TRFER CASE INPUT SHF
19132803 SHAFT, TRFER CASE INPUT
19168732 BUSHING, TRFER CASE FRT OUTPUT SHF DRV SPKT (PART OF 4) (ACDelco #19168732)
19167564 SPROCKET, TRFER CASE FRT OUTPUT SHF DRV (INCLS 3) [ШЕСТЕРНЯ ГРМ]
19151772 CHAIN, TRFER CASE TWO/FOUR WHL DRV [ЦЕПЬ ГРМ]
88984524 GEAR, TRFER CASE PLNT CARR SUN (INPUT) (STAMPED PM/POWDERED METAL)
89059279 CARRIER, FRT/RR DRV DIFF
89059525 WASHER, TRFER CASE PLNT CARR SUN GR THR
19168733 BUSHING, TRFER CASE RR OUTPUT SHF (PART OF 11) [ВТУЛКА РАЗДАТОЧНОЙ КОРОБКИ]
19178328 SHAFT, TRFER CASE RR OUTPUT (INCLS 10, 13, 14)
88984508 RING, TRFER CASE RR OUTPUT SHF RR BRG OTR RET (80MM I.D.) (4.535) [КОЛЬЦО УПЛОТНИТЕЛЬНОЕ]
teamcadillac.ru
88984506 BEARING, TRFER CASE RR OUTPUT SHF RR (PART OF 11)
88984493 RING, TRFER CASE RR OUTPUT SHF RR BRG RET (PART OF 11) (41MM I.D.) (ACDelco #88984493)
88996564 BEARING, TRFER CASE FRT OUTPUT SHF DRV SPKT
88984540 SPROCKET, TRFER CASE TWO/FOUR WHL DRV DRVN
89059602 PLUG, TRFER CASE FRT OUTPUT SHF HOLE (PART OF 18)
19153149 SHAFT, TRFER CASE FRT OUTPUT (INCLS 17)
04 - ТОРМОЗА
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (PART OF 1, 9) [БОЛТ М6]
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
04 - ТРАНСМИССИЯ-ТОРМОЗА
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
05 - ТОРМОЗА-ЗАДНЯЯ ОСЬ-ПРИВОДНОЙ ВАЛ-КОЛЕСА
(GM05-007) - 2007-2009 CK1,2,3 ШИНА
19107949 ШИНА, FRT (ШИНА MFG # 15476380000) (24503856AMERITRAC, TR P265/70R17, BW) (ACDelco #1547638G)
19143998 ШИНА, FRT (ШИНА MFG # 053998) (INSTALL .25) (SINGLE 19.3KGS) (BRIDGESTONE, DUELER H/L ALENZA, P285/45R22, BW110H) (ACDelco #FB053984)
19145327 ШИНА, FRT (ШИНА MFG # 54018) (INSTALL .25) (SINGLE 18.8KGS) (BRIDGESTONE, DUELER A/T RH-S, P265/65R18, 112S) (ACDelco #FB054018)
19145377 ШИНА, FRT (ШИНА MFG # 53967) (INSTALL .25) (SINGLE 19.5KGS) (BRIDGESTONE, DUELER H/L ALENZA W/UNI-T, P275/55R20, BL, 111S) (ACDelco #FB053967)
19145900 ШИНА, FRT (ШИНА MFG # 047456) (BRIDGESTONE, DUELER H/L (D683), P265/65R18, BW112H) (ACDelco #FB047456)
19148471 ШИНА, FRT (ШИНА MFG # 054035) (BRIDGESTONE, DUELER A/T-RHS, P265/65R18, OWL112S) (ACDelco #FB054035)
19160281 ШИНА, FRT (ШИНА MFG # 043665) (BRIDGESTONE, DUELER H/T (D684 II), P265/65R18, 112S) (ACDelco #FB043665)
19161372 ШИНА, FRT (ШИНА MFG # 208231) (BRIDGESTONE, M773 SWP II DURAVIS, LT245/75R16, BW) (ACDelco #FB208231)
19161391 ШИНА, FRT (ШИНА MFG # 088505) (BRIDGESTONE, DUELER A/T RHS, P265/70R17, BW) (ACDelco #FB086505)
19162484 ШИНА, FRT (ШИНА MFG # 732605500) (GOODYEAR, EAGLE RS-A, P265/60R17, BW108H) (ACDelco #HN605500)
88926367 ШИНА, FRT (ШИНА MFG # 403422658) (GOODYEAR, WRANGLER HP, 265/70R17, BSL) (ACDelco #MH422658)
88926368 ШИНА, FRT (ШИНА MFG # 403422918) (GOODYEAR, WRANGLER HP, 265/70R17, OWL) (ACDelco #MH422918)
88926372 ШИНА, FRT (ШИНА MFG # 410422176) (GOODYEAR, WRANGLER AT/S, 265/70R17, OWL) (ACDelco #MI422176)
88926373 ШИНА, FRT (ШИНА MFG # 410422177) (GOODYEAR, WRANGLER AT/S, 265/70R17, BSL) (ACDelco #MI422177)
89016784 ШИНА, FRT (ШИНА MFG # 147-985) (BRIDGESTONE, DUELER H/T (D684 II), 265/70R17, BW) (ACDelco #FB147985)
89049423 ШИНА, FRT (ШИНА MFG # 773422430) (GOODYEAR, WRANGLER ST, 265/70R17, BSL) (ACDelco #HD422430)
89049424 ШИНА, FRT (ШИНА MFG # 773422431) (GOODYEAR, WRANGLER ST, 265/70R17, OWL) (ACDelco #HD422431)
teamcadillac.ru
(TC05-025) - 2007-2009 K1,2,3 ВАЛ ПРИВОДА-КАРДАННЫЙ ВАЛ MOUNTING/FRONT AXLE
teamcadillac.ru
15734903 БОЛТ, F/AXL PROP SHF (5/16-24X1.3) (HEX) [БОЛТ М12]
07846740 RETAINER, F/AXL PROP SHF (1 13/16 IN HOLE CTR) (USED W/1 1/8 IN BRG CAP, CUT-OFF CORNERS)
(TC05-602) - 2007-2009 CK1,2,3 ВАЛ ПРИВОДА-КАРДАННЫЙ ВАЛ MOUNTING/REAR AXLE (ONE PIECE PROP)
teamcadillac.ru
15734903 БОЛТ, RR PROP SHF (5/16-24X1.3) (HEX) [БОЛТ М12]
07846740 RETAINER, RR PROP SHF (1 13/16 IN HOLE CTR) (USED W/1 1/8 IN BRG CAP, CUT-OFF CORNERS)
(TC05-653) - 2007-2009 CK1(06-36) ШЛАНГ ВЕНТИЛЯЦИИ ЗАДНЕГО МОСТА
15920576 HOSE, R/AXL VENT (INCLS 2, 3)
15157936 CLIP, R/AXL VENT HOSE (PART OF 1) (1 LINE)
15743069 VENT, R/AXL (PART OF 1)
teamcadillac.ru
26063647 CONNECTOR, R/AXL VENT HOSE
(TC05-900) - 2007-2009 CK1(06-36) ЗАПАСНОЕ КОЛЕСО
09596426 WHEEL, 17X7.5 SPARE (CODE FLY) (ACDelco #9596426)
teamcadillac.ru
15128603 CAP, ШИНА PRESS IND SEN (PART OF 2) (1ST DES USED W/CLAMP IN SENSOR 15825475 FOR 2ND DES SEE 25858636 CAP) [КОЛПАЧОК КЛАПАНА ШИНЫ КОЛЕСА]
25858636 CAP, ШИНА PRESS IND SEN (PART OF 2) (BLACK) [КОЛПАК ГАЙКИ КОЛЕСА]
09595852 WHEEL KIT, AL
(TC05-901) - 2007 CK1(06-36) КОЛЕСА (CADILLAC Z75)
09595459 WHEEL, 18X8
09595460 WHEEL, 18X8
19209740 WEIGHT, WHL BAL (CLIP-ON REPLACEMENT) (TRIM AS REQUIRED) (WHL BAL)
09595174 ГАЙКА, WHL (M14X1.5)
09595473 CAP, HUB
09597286 CAP, HUB
15128603 CAP, ШИНА PRESS IND SEN (СМ. ГРУППУ 05.000 "ШИНА VALVE STEM & PRESSURE SENSOR" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (1ST DES USED W/CLAMP IN SENSOR 15825475 FOR 2ND DES SEE 25858636 CAP) [КОЛПАЧОК КЛАПАНА ШИНЫ КОЛЕСА]
25858636 CAP, ШИНА PRESS IND SEN (СМ. ГРУППУ 05.000 "ШИНА VALVE STEM & PRESSURE SENSOR" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (BLACK) (2ND DES NOT USED W/CLAMP IN SENSOR 15825475. 1ST DES SEE 15128603) [КОЛПАК ГАЙКИ КОЛЕСА]
09593595 STEM, ШИНА VLV (СМ. ГРУППУ 05.000 "ШИНА VALVE STEM & PRESSURE SENSOR" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (FITS 0.453 HOLE, INCLS CAP 9427576 1.24" LONG HIGH PRESS)
15922396 SENSOR, ШИНА PRESS IND (СМ. ГРУППУ 05.000 "ШИНА VALVE STEM & PRESSURE SENSOR" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (SNAP-IN) (INCLUDES BLACK VALVE CAP & BLACK RUBBER VALVE) (ACDelco #15922396)
09595854 WHEEL, 22X9.0
teamcadillac.ru
09597950 CAP, HUB
(TC05-904) - 2007-2009 CK1(06-36) МОСТ В СБОРЕ/ЗАДНИЙ-ПОЛНЫЙ
15945423 МОСТ, ЗАДНИЙ (3.42 RATIO) (CODE AZ0, DG7, HS4, JR6, NJ6, ZR4, ZX1) (USED ON VEHICLES W/SMALLER THAN 22" КОЛЕСА. FOR 2ND DESIGN SEE 25870037)
25839005 МОСТ, ЗАДНИЙ (3.73 RATIO) (CODE BD0, EG2, HS9, JR4, NJ4, ZR2, ZX3) (USED ON VEHICLES W/SMALLER THAN 22" КОЛЕСА. FOR 2ND DESIGN SEE 25870034)
25869905 МОСТ, ЗАДНИЙ (3.42 RATIO) (CODE HS5, NJ5)
25870034 МОСТ, ЗАДНИЙ (3.73 RATIO) (CODE BD0, EG2, HS9, JR4, NJ4, ZR2, ZX3) (USED ON VEHICLES W/22" КОЛЕСА. FOR 1ST DESIGN SEE 25839005)
25870035 МОСТ, ЗАДНИЙ (4.10 RATIO) (CODE BF0, EG6, HT1, JR7 NJ7, ZR5, ZX4)
teamcadillac.ru
25870036 МОСТ, ЗАДНИЙ (3.23 RATIO) (CODE AR9, DG2, HS2, JR2, NJ2, ZP9, ZW8)
25870037 МОСТ, ЗАДНИЙ (3.42 RATIO) (CODE AZ0, DG7, HS4, JR6, NJ6, ZR4, ZX1) (USED ON VEHICLES W/22" КОЛЕСА. FOR 1ST DESIGN SEE 15945423)
25979181 МОСТ, ЗАДНИЙ (3.73 RATIO) (CODE BC0, BD4, ZX2)
25903653 МОСТ, ЗАДНИЙ (4.10 RATIO) (CODE BH0, ZP6)
(TC05-905) - 2007-2009 CK1(06-36) МОСТ В СБОРЕ/ЗАДНИЙ 8.625 RING GEAR ЧАСТЬ 1 (EXC (AXN))
03984818 WASHER, DIFF P/GR THR (.797 I.D. 1.70 O.D.) (*KIT1)
00454947 БОЛТ, HEX .437-14X2.250 CL-2A CAD/ZC (PART OF 31)
12471307 БОЛТ, R/AXL HSG CVR (M8X1.25X20) (*KIT2)
15791254 BRACKET, RR BRK C/OVR PIPE (INCLS 9) (CONTAINS BRACKET & SCREW) (*KIT2) [КРОНШТЕЙН СБОРН.-ЗАДНЕЙ ТОРМОЗНОЙ ТРУБКИ]
12479141 PLUG, R/AXL HSG FILL (INCLS WASHER & MAGNET) (*KIT2)
15807693 GASKET, R/AXL HSG CVR (10 BOLT HOLES) (*KIT2) [ПРОКЛАДКА КРЫШКИ ДИФФЕРЕНЦИАЛА]
12479056 GEAR KIT, DIFF RING & PINION (INCLS 16, 32, 33, 43)
12479129 GEAR KIT, DIFF RING & PINION (INCLS 16, 32, 33, 43) (INCLS BOLTS, PINION, RING & SPACER) [ШЕСТЕРНЯ]
12479316 GEAR KIT, DIFF RING & PINION (INCLS 16, 32, 33, 43)
12479393 GEAR KIT, DIFF RING & PINION (INCLS 16, 32, 33, 43)
01394892 SHIM KIT, FRT DIFF DRV P/GR BRG (.020-.024" THK)
01394893 SHIM KIT, FRT DIFF DRV P/GR BRG (.025-.029" THK)
01394894 SHIM KIT, FRT DIFF DRV P/GR BRG (.030-.034" THK)
01394895 SHIM KIT, FRT DIFF DRV P/GR BRG (.035-.039" THK)
26043991 SHIM KIT, FRT DIFF DRV P/GR BRG (.040-.044" THK)
26043992 SHIM KIT, FRT DIFF DRV P/GR BRG (.045-.049" THK) [РЕГУЛИР.ПРОКЛАДКА ДИФФЕРЕНЦИАЛА (ШАЙБА)]
teamcadillac.ru
15286375 BEARING, DIFF DRV P/GR INR (ACDelco #S1371) [ПОДШИПНИК ДИФФЕРЕНЦИАЛА]
12479162 SPACER, DIFF DRV P/GR BRG (R/AXL) (PART OF 13) (.062-.068" THK) [ШАЙБА ДИФФЕРЕНЦИАЛА]
15121067 SENSOR, RR WHL SPD [ДАТЧИК АБС (КОЛИЧЕСТВА ОБОРОТОВ КОЛЕСА)]
15286384 RING, WHL SPD SEN RELUCTOR
12479031 BEARING, R/AXL SHF (5.855) (ACDelco #RW20-10) [ПОДШИПНИК СТУПИЦЫ КОЛЕСА 60ММ]
12471686 SEAL, R/AXL SHF (ACDelco #291-315) [ПРОКЛАДКА ПОЛУОСИ ЗАДНЕГО МОСТА]
15065927 БОЛТ, PARK BRK (M12X1.75X34)
15012506 БОЛТ, RR BRK CLPR (PART OF 27) (M14X2.0X37, 37THD) (27.3-OD., 10.9, GM6174M) [БОЛТ М14Х2]
15792634 ROTOR KIT, RR BRK (INCLS 25)
11588811 STUD, RR WHL (M14X1.5X24, 58 TOTAL LENGTH) [ШПИЛЬКА М14]
15286380 SHAFT, R/AXL [ПРИВОДНОЙ ВАЛ КОЛЕСА]
03833322 LOCK, R/AXL SHF (39.43 X 19.94MM)
25789474 ШЛАНГИ, R/AXL (INCLS 5, 6) [КОРПУС ВЕДУЩЕГО МОСТА]
88891763 ГАЙКА, DIFF DRV P/GR (R/AXL) (PART OF 13, 34) (M10) [ГАЙКА М10]
00517900 WASHER, DIFF DRV P/GR (PART OF 13, 34) (.890X1.625X.190)
12470387 YOKE KIT, DIFF DRV P/GR (INCLS 32, 33, 35) (30 TEETH) (INCLS YOKE, SEAL, WASHER, NUT) (FOR NON-CANADIAN ORDERS) [КРЕСТОВИНА ВАЛА ЗАДНЕГО МОСТА]
26064028 SEAL, DIFF DRV P/GR (2 PIECE PINION SEAL) (TRIPLE LIP) (PART OF 34) (RR AXLE) [САЛЬНИК ХВОСТОВИКА ЗАДНЕГО ДИФФЕРЕНЦИАЛА]
15286376 BEARING, DIFF DRV P/GR OTR (INCLS CUP AND CONE, TIMKEN, M88048-M88010, 1 5/16 IN ID X 2 11/16 IN OD X 7/8 IN THK) (5.484) (ACDelco #S1372) [ПОДШИПНИК ДИФФЕРЕНЦИАЛА]
12471330 SPACER, DIFF BRG (4.37-4.32MM THK) (5.650) [КОЛЬЦО ДИФФЕРЕНЦИАЛА]
12471362 SHIM KIT, DIFF BRG (1.016-1.118MM RANGE) (RR AXLE) [КОМПЛЕКТ РЕГУЛИР.ПРОКЛАДОК ДИФФЕРЕНЦИАЛА (2ШТ)]
12471363 SHIM KIT, DIFF BRG (1.168-1.372MM RANGE) (RR AXLE) [КОМПЛЕКТ РЕГУЛИР.ПРОКЛАДОК ДИФФЕРЕНЦИАЛА (2ШТ)]
12471364 SHIM KIT, DIFF BRG (1.422-1.626MM RANGE) (RR AXLE) [КОМПЛЕКТ РЕГУЛИР.ПРОКЛАДОК ДИФФЕРЕНЦИАЛА (2ШТ)]
12471365 SHIM KIT, DIFF BRG (1.676-1.880MM RANGE) (RR AXLE) [КОМПЛЕКТ РЕГУЛИР.ПРОКЛАДОК ДИФФЕРЕНЦИАЛА (2ШТ)]
12471366 SHIM KIT, DIFF BRG (1.930-2.134MM RANGE) (RR AXLE) [КОМПЛЕКТ РЕГУЛИР.ПРОКЛАДОК ДИФФЕРЕНЦИАЛА (2ШТ)]
12471367 SHIM KIT, DIFF BRG (2.184-2.388MM RANGE) (RR AXLE) [КОМПЛЕКТ РЕГУЛИР.ПРОКЛАДОК ДИФФЕРЕНЦИАЛА (2ШТ)]
12471368 SHIM KIT, DIFF BRG (2.438-2.540MM RANGE) (RR AXLE) [УПОРНОЕ КОЛЬЦО ДИФФЕРЕНЦИАЛА]
25824250 BEARING, DIFF (ACDelco #S1380) [ПОДШИПНИК ДИФФЕРЕНЦИАЛА]
12471540 CASE, DIFF (STAMPED 7875/LESS INT GEARS)
25872305 БОЛТ, DIFF P/GR SHF LK (*KIT1) [БОЛТ М10]
26056109 SHAFT, DIFF P/GR (124.84MM) (*KIT1) [ВАЛ ШЕСТЕРНИ ДИФФЕРЕНЦИАЛА]
14066913 БОЛТ, RR DIFF R/GR (R/AXL) (PART OF 13) (7/16-20X7/8) (HEX)
19179021 GEAR KIT, DIFF SI & PINION (INCLS 1-4, 41, 42) (RR AXLE)
15290822 COVER KIT, R/AXL HSG (INCLS 7-12) (INCLS COVER, GASKET, PLUG, BOLTS, BRACKETS) [КРЫШКА ДИФФЕРЕНЦИАЛА ЗАДНЕГО МОСТА]
(TC05-921) - 2007 CK1,2(06-36) ШИНА VALVE STEM & PRESSURE SENSOR
15825475 SENSOR, ШИНА PRESS IND (INCLS 2, 3, 5) (VEHICLES BUILT OCT 1, 2006 AND PRIOR) (USED T/W 15825474 NUT) (FOR SERVICE SEE ITEM 7)
15128601 GROMMET, ШИНА VLV STEM (PART OF 1)
15128602 VALVE, ШИНА (PART OF 1)
15234846 ГАЙКА, ШИНА PRESS IND SEN (14 X 19) (BUILT OCT 1, 2006 AND PRIOR USED W/15825475 SENSOR) [ГАЙКА М8]
15128603 CAP, ШИНА PRESS IND SEN (PART OF 1) (1ST DES USED W/CLAMP IN SENSOR 15825475 FOR 2ND DES SEE 25858636 CAP) [КОЛПАЧОК КЛАПАНА ШИНЫ КОЛЕСА]
25858636 CAP, ШИНА PRESS IND SEN (PART OF 1) (BLACK) [КОЛПАК ГАЙКИ КОЛЕСА]
15922396 SENSOR, ШИНА PRESS IND (INCLS 6, 8-10) (SNAP-IN) (INCLUDES BLACK VALVE CAP & BLACK RUBBER VALVE) (ACDelco #15922396)
15263240 VALVE KIT, ШИНА (PART OF 7) (INCLS 6, 10) (INCLS CAP, STEM, BOLT) (ACDelco #15263240) [ОБРАТНЫЙ КЛАПАН КОЛЕСА]
teamcadillac.ru
15128603 CAP, ШИНА PRESS IND SEN (PART OF 7, 8) (1ST DES USED W/CLAMP IN SENSOR 15825475 FOR 2ND DES SEE 25858636 CAP) [КОЛПАЧОК КЛАПАНА ШИНЫ КОЛЕСА]
25858636 CAP, ШИНА PRESS IND SEN (PART OF 7, 8) (BLACK) [КОЛПАК ГАЙКИ КОЛЕСА]
09593595 STEM, ШИНА VLV (INCLS 12, 13) (FITS 0.453 HOLE, INCLS CAP 9427576 1.24" LONG HIGH PRESS)
(TC05-952) - 2007-2009 CK1(06-36) МОСТ В СБОРЕ/ЗАДНИЙ 9.50 RING GEAR ЧАСТЬ 1 (AXN)
12337937 WASHER, DIFF SI GR THR (PACKAGE INCLS (5) WASHERS)
14012699 WASHER, DIFF P/GR THR (FLAT WASHER) (56MM O.D. 23.75MM I.D.)
12471410 DIFFERENTIAL, (СМ. ГРУППУ 05.000 "МОСТ В СБОРЕ/ЗАДНИЙ LOCKING DIFFERENTIAL" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS GEARS)
teamcadillac.ru
14038087 CASE, DIFF (FOR NON-CANADIAN ORDERS) (LESS INTERNAL GEARS) (FOR NON-CANADIAN ORDERS)
14012703 БОЛТ, RR DIFF R/GR (R/AXL) (M12X1.5X22) (HEX) (*KIT1)
14012700 SHAFT, DIFF P/GR (148.0MM)
14039025 SHAFT, DIFF P/GR (144.78MM)
12337979 БОЛТ, DIFF P/GR SHF LK (M10X1.5X59) (CONTAINS 10 LOCK SCREWS)
14012675 БОЛТ, DIFF BRG CAP (M12X1.75X74)
11505123 BEARING, DIFF (INCLS CUP AND CONE, TIMKEN, JLM506849-JLM506811, 55MM ID X 90MM OD X 25MM THK) (ACDelco #S1198)
14012725 SHIM, DIFF BRG (5.59 MM)
14012726 SHIM, DIFF BRG (5.64 MM)
14012727 SHIM, DIFF BRG (5.69 MM)
14012728 SHIM, DIFF BRG (5.74 MM)
14012729 SHIM, DIFF BRG (5.79 MM)
14012730 SHIM, DIFF BRG (5.84 MM)
14012731 SHIM, DIFF BRG (5.89 MM)
14012732 SHIM, DIFF BRG (5.94 MM)
14012733 SHIM, DIFF BRG (5.99 MM)
14012734 SHIM, DIFF BRG (6.05 MM)
14012735 SHIM, DIFF BRG (6.10 MM)
14012736 SHIM, DIFF BRG (6.15 MM)
14012737 SHIM, DIFF BRG (6.20 MM)
14012738 SHIM, DIFF BRG (6.25 MM)
14012739 SHIM, DIFF BRG (6.30 MM)
14012740 SHIM, DIFF BRG (6.35 MM)
14012741 SHIM, DIFF BRG (6.40 MM)
14012742 SHIM, DIFF BRG (6.45 MM)
14012743 SHIM, DIFF BRG (6.50 MM)
14012752 SHIM, DIFF BRG (6.55 MM)
12471307 БОЛТ, R/AXL HSG CVR (PART OF 15) (M8X1.25X20)
19133285 COVER KIT, R/AXL HSG (INCLS 13, 16, 41) (INCLS COVER, GASKET, PLUGS, BOLTS)
26063649 GASKET, R/AXL HSG CVR (PART OF 15) (14 BOLT HOLES) [ПРОКЛАДКА КРЫШКИ ДИФФЕРЕНЦИАЛА]
14038010 SHIM KIT, DIFF DRV P/GR BRG (R/AXL) (.5080-.5842MM)
14038011 SHIM KIT, DIFF DRV P/GR BRG (.6096-.7112MM)
14038012 SHIM KIT, DIFF DRV P/GR BRG (.7366-.8382MM)
14038013 SHIM KIT, DIFF DRV P/GR BRG (.8636-.9398MM)
00457108 BEARING, DIFF DRV P/GR INR (ACDelco #S37)
15012506 БОЛТ, RR BRK CLPR (M14X2.0X37, 37THD) (27.3-OD., 10.9, GM6174M) [БОЛТ М14Х2]
14012746 LOCK, R/AXL SHF (43.0 X 22.5MM)
15812663 SHAFT, R/AXL
12471308 PLUG, R/AXL HSG DRN (W/WASHER) (19MM LONG) [ЗАГЛУШКА]
88891763 ГАЙКА, DIFF DRV P/GR (R/AXL) (PART OF 37) (M10) (*KIT1) [ГАЙКА М10]
00517900 WASHER, DIFF DRV P/GR (PART OF 37) (.890X1.625X.190) (*KIT1)
12470384 YOKE KIT, DIFF DRV P/GR (INCLS 35, 36, 38) (TRIPLE LIP) (INCL YOKE, SEAL WA, NUT) (FOR VEHICLES W/TWO PIECE PINION SEAL)
26064029 SEAL, DIFF DRV P/GR (PART OF 37) (5.545) [САЛЬНИК П/ОСИ ЗДНЕГО МОСТА]
09417781 BEARING, DIFF DRV P/GR OTR (2.84") (5.484) (ACDelco #S604)
14012691 SPACER, DIFF DRV P/GR BRG (35.5MM I.D. X 16.3MM WIDE) (*KIT1)
00444788 PLUG, HEADLESS SQ SOCKET 1/2" (PART OF 15)
15875855 ШЛАНГИ, R/AXL (INCLS 10) (WHEN USING 15875855 ALSO ORDER QTY 1 12471308 PLUG, R/AXL DRN)
14012753 ГАЙКА, DIFF BRG ADJ (M86X1.5)
14012707 LOCK, DIFF BRG ADJ NUT (5.537)
11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (DIFF BRG ADJ NUT LK) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16]
12471607 MAGNET, R/AXL HSG CHIP COLLECTOR (4.105) (ACDelco #12471607)
88965784 GEAR KIT, DIFF RING & PINION (INCLS 6, 17, 35, 36, 40, 49)
12471409 GEAR KIT, DIFF SI & PINION (INCLS 2, 4)
(TX05-059) - 2007-2009 CK1(06-36) МОСТ В СБОРЕ/ЗАДНИЙ 8.625 RING GEAR ЧАСТЬ 2 DIFFERENTIAL/LOCKING(G80,EXC (AXN))
25902687 DIFFERENTIAL, (INCLS 2-19) [ДИФФЕРЕНЦИАЛ ВЕДУЩЕГО МОСТА В СБОРЕ]
26056109 SHAFT, DIFF P/GR (124.84MM) [ВАЛ ШЕСТЕРНИ ДИФФЕРЕНЦИАЛА]
25872305 БОЛТ, DIFF P/GR SHF LK [БОЛТ М10]
14048409 BUSHING, LKG DIFF LOCKOUT (EATON EDS-98648) [ВТУЛКА КУЛАЧКА]
12471532 WASHER, DIFF P/GR THR (.820 I.D.X1.69 O.D.) (EATON EDS-89189, .06 LIP)
15599623 GUIDE, LKG DIFF CLU DISC (PART OF 10) (WIDTH .93 INCH)
14063581 SHIM, DIFF SI GR (.010 THK) (BELL END) [ПРОКЛАДКА]
14063582 SHIM, DIFF SI GR (.015 THK) (BELL END) [ПРОКЛАДКА]
14063583 SHIM, DIFF SI GR (.020 THK) (BELL END) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ДИФФЕРЕНЦИАЛА]
14063584 SHIM, DIFF SI GR (.025 THK) (BELL END) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ДИФФЕРЕНЦИАЛА]
teamcadillac.ru
14063585 SHIM, DIFF SI GR (.030 THK) (BELL END) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ДИФФЕРЕНЦИАЛА]
14063586 SHIM, DIFF SI GR (.035 THK) (BELL END)
14063587 SHIM, DIFF SI GR (.040 THK) (BELL END) [ПРОКЛАДКА]
14063588 SHIM, DIFF SI GR (.045 THK) (BELL END)
26045829 DISC SET, LKG DIFF CLU (INCLS 8) (EATON EDS-29996)
12471530 GOVERNOR KIT, LKG DIFF (EATON EDS-29672) (INCLS BRKT)
12471393 BLOCK, LKG DIFF THR (PURPLE) (1.322" THK)
12471394 BLOCK, LKG DIFF THR (WHITE) (1.326" THK)
12471396 BLOCK, LKG DIFF THR (YELLOW) (1.334" THK)
12471397 BLOCK, LKG DIFF THR (ORANGE) (1.338" THK)
12471398 BLOCK, LKG DIFF THR (PINK) (1.342" THK)
12471399 BLOCK, LKG DIFF THR (GREEN) (1.346" THK)
12471406 CAM, LKG DIFF (EATON EDS-89096)
12471533 GUIDE, LKG DIFF CLU DISC (PART OF 18) (WIDTH .51 INCH)
09412303 RETAINER, EXT.SNAP RING M46 DIA SHF
26012909 WASHER, LKG DIFF CLU DISC THR (.022 THK)
26012910 WASHER, LKG DIFF CLU DISC THR (.027 THK)
26012911 WASHER, LKG DIFF CLU DISC THR (.032 THK)
26012912 WASHER, LKG DIFF CLU DISC THR (.036 THK)
26012913 WASHER, LKG DIFF CLU DISC THR (.040 THK)
26012914 WASHER, LKG DIFF CLU DISC THR (.044 THK)
26012915 WASHER, LKG DIFF CLU DISC THR (.048 THK)
26012916 WASHER, LKG DIFF CLU DISC THR (.052 THK)
12471404 DISC SET, LKG DIFF CLU (INCLS 15) (EATON EDS- 29534 INCLS WASHER, DISCS & GUIDE)
19178111 GEAR KIT, DIFF SI & PINION (INCLS 6, 7, 13)
(TX05-060) - 2007-2009 CK1(06-36) МОСТ В СБОРЕ/ЗАДНИЙ 9.50 RING GEAR ЧАСТЬ 2 DIFFERENTIAL/LOCKING(G80,AXN)
12471410 DIFFERENTIAL, (INCLS 2-19) (INCLS GEARS)
14039026 WASHER, DIFF P/GR THR (DOME STYLE)
00462787 GUIDE, LKG DIFF CLU DISC (PART OF 10) (WIDTH .71 INCH)
15599626 SHIM, DIFF SI GR (.010 THK)
15599627 SHIM, DIFF SI GR (.015 THK)
15599628 SHIM, DIFF SI GR (.020 THK)
15599629 SHIM, DIFF SI GR (.025 THK)
15599630 SHIM, DIFF SI GR (.030 THK)
teamcadillac.ru
15599631 SHIM, DIFF SI GR (.035 THK)
15599632 SHIM, DIFF SI GR (.040 THK)
15599633 SHIM, DIFF SI GR (.045 THK)
12471390 DISC SET, LKG DIFF CLU (INCLS 8) (EATON EDS-29565)
14048384 GOVERNOR KIT, LKG DIFF (EATON EDS-27811) (INCLS BRKT)
12471395 BLOCK, LKG DIFF THR (BROWN) (1.330" THK)
14039028 BLOCK, LKG DIFF THR (BLUE) (1.594" THK)
14039029 BLOCK, LKG DIFF THR (GRAY) (1.598" THK)
14039031 BLOCK, LKG DIFF THR (YELLOW) (1.610" THK)
14039033 BLOCK, LKG DIFF THR (BROWN) (1.622" THK)
15599672 BLOCK, LKG DIFF THR (WHITE) (1.602" THK)
15599673 BLOCK, LKG DIFF THR (PURPLE) (1.606" THK)
15599675 BLOCK, LKG DIFF THR (ORANGE) (1.614" THK)
15599676 BLOCK, LKG DIFF THR (PINK) (1.618" THK)
12471411 CAM, LKG DIFF
15599623 GUIDE, LKG DIFF CLU DISC (PART OF 18) (WIDTH .93 INCH)
00462786 SLEEVE, LKG DIFF SI GR THR
00462769 WASHER, LKG DIFF CLU DISC THR (.027 THK)
00462770 WASHER, LKG DIFF CLU DISC THR (.037 THK)
00462771 WASHER, LKG DIFF CLU DISC THR (.042 THK)
00462772 WASHER, LKG DIFF CLU DISC THR (.048 THK)
14039035 WASHER, LKG DIFF CLU DISC THR (.022 THK)
14039036 WASHER, LKG DIFF CLU DISC THR (.032 THK)
14039037 WASHER, LKG DIFF CLU DISC THR (.040 THK)
14039038 WASHER, LKG DIFF CLU DISC THR (.044 THK)
14039039 WASHER, LKG DIFF CLU DISC THR (.052 THK)
12471408 DISC SET, LKG DIFF CLU (INCLS 15) (EATON EDS- 29566)
12471409 GEAR KIT, DIFF SI & PINION (INCLS 6, 7, 13)
(TX05-061) - 2007 K107(06) ВАЛ ПРИВОДА-КАРДАННЫЙ ВАЛ (ONE PIECE)
15814472 SHAFT, PROP (INCLS 2-4) [КАРДАННЫЙ ВАЛ]
88963576 YOKE, PROP SHF SLIP (WHEN REPLACING A ВАЛ ПРИВОДА-КАРДАННЫЙ ВАЛ SLIP YOKE, A NEW ВАЛ ПРИВОДА-КАРДАННЫЙ ВАЛ JOINT KIT (5.548) MUST ALSO BE USED) (PART OF 1) [ФЛАНЕЦ КАРДАННОГО ВАЛА]
12479126 JOINT KIT, PROP SHF UNIVERSAL (PART OF 1) (INCLS 4) (FOR NON-CANADIAN ORDERS) [КРЕСТОВИНА КАРДАННОГО ВАЛА]
01456507 RING, PROP SHF UJT SPIDER BRG RET (PART OF 1, 3) (5.586)
(TX05-113) - 2007-2009 K1 ВАЛ ПРИВОДА-КАРДАННЫЙ ВАЛ/FRONT AXLE
15902926 SHAFT, F/AXL PROP (INCLS 2-6)
12479126 JOINT KIT, F/AXL PROP SHF UNIVERSAL (PART OF 1) (INCLS 3) (FOR NON-CANADIAN ORDERS) [КРЕСТОВИНА КАРДАННОГО ВАЛА]
teamcadillac.ru
01456507 RING, PROP SHF UJT SPIDER BRG RET (PART OF 1, 2) (5.586)
12471638 YOKE, TRFER CASE F/AXL PROP SHF (USES 12471527 BOOT) (PART OF 1) (HAS FORGING OF 40006884) [ВИЛКА КАРДАННОГО ВАЛА]
26064275 CLAMP, F/AXL PROP SHF SLIP YOKE BOOT (PART OF 1, 6) (165.3) (3 SLOTS) (5.586) [ХОМУТ]
12471527 BOOT KIT, F/AXL PROP SHF SLIP YOKE (PART OF 1) (INCLS 5) (INCLS CLAMPS) (5.586) [ПЫЛЬНИК ПЕРЕДНЕЙ ОСИ]
06 - ПЕРЕДНЯЯ ОСЬ-ПЕРЕДНЯЯ ПОДВЕСКА - РУЛЕВОЕ УПРАВЛЕНИЕ
(TC06-899) - 2007 CK1 РУЛЕВОЙ МЕХАНИЗМ В СБОРЕ (2ND DES)
19207492 GEAR KIT, STRG (REMAN) (INCLS 2-10, 13-17) [РУЛЕВАЯ РЕЙКА]
19167837 PIPE KIT, S/GR (PART OF 1) (INCLS 5) (LT) (HAS FEMALE THREADS ON FITTING)
19167838 PIPE KIT, S/GR (PART OF 1) (INCLS 5) (RT) (HAS FEMALE THREADS ON FITTING)
26081619 SEAL, S/GR PIPE (O RING) (PART OF 1-3) (6.00MM) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО РУЛЕВОЙ РЕЙКИ]
07828017 RING, S/GR STUB SHF SEAL RET (PART OF 1)
15776969 SEAL, S/GR STUB SHF (PART OF 1)
11562064 CLAMP, CRIMP, 66.4 DIA, 7 WIDTH, STAINLESS STEEL (PART OF 1, 9, 14)
15254057 BOOT KIT, S/GR (INCLS 8, 10) (PART OF 1) (EXC TWO MODE HYBRID)
11562066 CLAMP, ПРУЖИНАBAND, DIA MIN 19.2, MAX 22.86, SAE 1055 STL, GM7111M (PART OF 1, 9)
11516074 ГАЙКА, STRG LNKG OTR TIE ROD (PART OF 12) (HEX M14X2, 13THK) (8.917) [ГАЙКА М10]
teamcadillac.ru
15254061 ROD KIT, STRG LNKG OTR TIE (INCLS 12) (EXC TWO-MODE HYBRID) [УСТАНОВОЧНЫЙ КОМПЛЕКТ]
11562065 ГАЙКА, STRG LNKG INR TIE ROD (PART OF 1, 14) (M16X1.5, 11THK) (8.915)
19178561 ROD KIT, STRG LNKG INR TIE (INCLS 8, 13) (PART OF 1) (EXC TWO-MODE HYBRID) [НАКОНЕЧНИК РУЛЕВОЙ ТЯГИ]
26100863 SEAL, P/S GR INL HOSE (O RING) (PART OF 1) (6.824) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО РУЛЕВОГО МЕХАНИЗМА]
13271879 SEAL, P/S GR OTLT HOSE (O-RING) (PART OF 1)
(TC06-900) - 2007-2009 K1 DRIVE AXLE MOUNTING/FRONT
15201933 BRACKET, FRT DIFF CARR (СМ. ГРУППУ 07.000 "FRAME" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [СУППОРТ ДИФФЕРЕНЦИАЛА ВЕДУЩЕГО МОСТА]
11519538 БОЛТ, FRT DIFF CARR (M12X1.75X45) (8.900) [БОЛТ М12]
11562485 ГАЙКА, FRT DIFF CARR BRKT (HF M12X1.75X14) [ГАЙКА]
11610231 WASHER - FLAT, 15X32X4.45, SAE 1050-1080 STL, HRC 40-45, GMW3179 (FRT DIFF CARR BRKT) [ШАЙБА 14 ММ]
teamcadillac.ru
11561577 БОЛТ, FRT DIFF CARR BRKT (8.900)
15201932 BRACKET, FRT DIFF CARR (СМ. ГРУППУ 07.000 "FRAME" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА)
11514598 ГАЙКА, FRT DIFF CARR BRKT (HF 12X1.75) (8.915) [ГАЙКА М12]
15847253 SHIELD, FRM FRT HT
11517560 SCREW, FLAT WA (NRW) AND HX WA HD, M8X1.25X25 (FRM FRT H/SHLD)
(TC06-901) - 2007-2009 K1 VENT HOSE/FRONT AXLE
15743069 VENT, F/AXL (PART OF 2) (5.387)
15201937 HOSE, F/AXL VENT (INCLS 1, 3)
teamcadillac.ru
15157936 CLIP, F/AXL VENT HOSE (PART OF 2) (1 LINE) (5.387)
12471619 CONNECTOR, FRT DIFF CARR VENT HOSE
(TC06-904) - 2007-2009 K1 ЧАШКА ДИФФЕРЕНЦИАЛА/FRONT AXLE ЧАСТЬ 1 ASSEMBLY (ALL WHEEL DRIVE NR3)
25818422 AXLE, FRT (3.42 RATIO) (CODE ZW5, CB8)
(TC06-905) - 2007 K1 ЧАШКА ДИФФЕРЕНЦИАЛА/FRONT AXLE ЧАСТЬ 2 (ALL WHEEL DRIVE NR3)(1ST DES)
15801498 SHAFT, FRT DRV AXLE INR
15801507 SEAL, FRT DRV AXLE INR SHF [УПЛОТНЕНИЕ ДИФФЕРЕНЦИАЛА]
26066885 BEARING, FRT DRV AXLE INR SHF (USED ON ШЛАНГИ) (6.008) [ПОДШИПНИК ДИФФЕРЕНЦИАЛА]
15270855 ШЛАНГИ, FRT DRV AXLE INR SHF
15270970 GASKET, FRT WHL DRV INTER SHF HSG [ПРОКЛАДКА ДИФФЕРЕНЦИАЛА]
26036835 БОЛТ, FRT DRV AXLE INR SHF HSG (W/WA 20 OD, M10X1.5X34.9)
15876531 CARRIER, FRT DIFF (CODE ZW5, ZW6) (W/O T-CLIP ADJSTR LOCK W/O AXLE CODES HU5, HU6, HU7, HU8, XP1, XP3, XP4, XP5) (MUST ORDER 2 OF 15876532 & 15876533 FOR W/ T-CLIP ADJSTR)
00360570 PIN, FRT DIFF HALF CARR LOC (0.685)
15270969 GASKET, FRT DIFF CARR [ПРОКЛАДКА ДИФФЕРЕНЦИАЛА]
15588312 LOCK, FRT DIFF BRG ADJR NUT (W/T-CLIP STYLE ADJUSTER LOCK W/AXLE CODES HU5, HU6, HU7, HU8, XP1, XP3, XP4, XP5) (FOR 2ND DES SEE 15876533) [ФИКСАТОР ДИФФЕРЕНЦИАЛА]
12470318 ADJUSTER, FRT DIFF BRG (INCLS 13) (INCLS INSERT, SLEEVE & NUT STMPD ZA2) (USED ON VEHICLES W/T-CLIP STYLE ADJUSTER LOCK USED ON BROADCAST AXLE CODES HU5, HU6, HU7, HU8, XP1, XP3, XP4, XP5) (FOR 2ND DES SEE 15876532) [РЕГУЛИРОВОЧНОЕ КОЛЬЦО ДИФФЕРЕНЦИАЛА]
teamcadillac.ru
09420095 BEARING, FRT DIFF (INCLS CUP AND CONE, TIMKEN, LM501349-LM501314, 41.28MM ID X 73.42MM OD X 21.43MM THK) (ACDelco #S13)
14066913 БОЛТ, FRT DIFF R/GR (7/16-20X7/8) (HEX) (*KIT2)
26063838 WASHER, FRT DIFF SI GR THR (69MM OD, 40ID, .77THK) (*KIT1) [УПОРНОЕ КОЛЬЦО ДИФФЕРЕНЦИАЛА]
12479372 RING, FRT DRV AXLE INR SHF RET (DAJACO)
26056600 RING, FRT DRV AXLE INR SHF RET (AMERICAN AXLE) [КОЛЬЦО СТОПОРНОЕ]
15588350 WASHER, FRT DIFF P/GR THR (CURVE STYLE WASHER) (51.6MM O.D., 20.27MM I.D.) (*KIT1)
26056109 SHAFT, FRT DIFF P/GR (124.84MM) (*KIT1) [ВАЛ ШЕСТЕРНИ ДИФФЕРЕНЦИАЛА]
15801501 CASE, FRT DIFF (LESS INTERNAL GEARS)
09428890 PIN, ПРУЖИНА TYPE S HOLE DIA-1/4, LENGTH 1 3/4, STEEL PL (FRT DIFF P/GR SHF LK) (*KIT1)
26041515 BEARING, FRT DRV AXLE INR SHF (USED ON ADJUSTER) [ПОДШИПНИК ДИФФЕРЕНЦИАЛА 60 ММ]
09418356 BEARING, FRT DIFF DRV P/GR INR (INCLS CUP AND CONE, TIMKEN, M802048-M802011, 1 5/8 IN ID X 3 1/4 IN OD X 1 1/32 IN THK) (5.484) (ACDelco #S33)
12479162 SPACER, FRT DIFF DRV P/GR BRG (.062-.068" THK) (*KIT2) (5.453) [ШАЙБА ДИФФЕРЕНЦИАЛА]
12471621 GASKET, FRT DIFF CARR OIL FIL PLUG (BLACK) (5.506) [ЩЕТКА]
26058815 PLUG, FRT DIFF CARR OIL DRN (M12X1.5)
15588383 GASKET, FRT DIFF CARR OIL DRN PLUG (4.195)
26058813 SHAFT, FRT DRV AXLE INR (CODE JM6, MY7, TUG, UL2, US9, XS4, ZXN, ZB2, WH2, ZW6) (5.517)
09413427 BEARING, FRT DIFF DRV P/GR OTR (INCLS CUP AND CONE, TIMKEN, M88048-M88010, 1 5/16 IN ID X 2 11/16 IN OD X 7/8 IN THK) (5.447) (ACDelco #S29)
12471590 SEAL, FRT DIFF DRV P/GR [УПЛОТНЕНИЕ ДИФФЕРЕНЦИАЛА]
88967027 YOKE, FRT DIFF DRV P/GR
00517900 WASHER, FRT DIFF DRV PINION GR (.890X1.625X.190) (*KIT2) (5.595)
88891763 ГАЙКА, FRT DIFF DRV P/GR (M10) (*KIT2) (5.595) [ГАЙКА М10]
12479318 GEAR KIT, FRT DIFF SI & PINION (INCLS 16-17, 19-21, 23)
88963591 GEAR KIT, FRT DIFF RING & DRV PINION (INCLS 15, 24, 28, 39, 40)
(TC06-906) - 2007-2009 CK1 ПОДВЕСКА-ПЕРЕДНЯЯ
15096197 ARM, FRT UPR CONT (INCLS 4) (INCLS BALL JOINT)
25812726 ARM, FRT UPR CONT (INCLS 4) (BALL JOINT IS INCLUDED PER PRINTS) [РЫЧАГ ПОДВЕСКИ]
11561435 ГАЙКА, HFH LOCK, M10X1.5X20, 28 OD, 10, 7111M, ALL METAL PREV TORQ (FRT S/ABS) [ГАЙКА]
03537772 ГАЙКА, FRT UPR CONT ARM BALL STUD (M12X1.75) (8.917)
10355407 ARM, FRT LWR CONT (INCLS 14, 17, 22) (THIS PART IS FOR ALUMINUM LCA ONLY)
teamcadillac.ru
25997508 ARM, FRT LWR CONT (INCLS 14, 17, 22) (CAST ALUMINU) [РЫЧАГ ПОДВЕСКИ]
11516133 ГАЙКА, FRT LWR CONT ARM (M16X2X15) (8.917) [ГАЙКА М16]
15567836 WASHER, FRT LWR CONT ARM (16.38IDX23.87ODX3.27) (6.168) [ШАЙБА М16]
11561429 ГАЙКА, FRT S/ABS (M10X1.5) (PREV TORQUE CLIP) [ГАЙКА М10]
15733533 БОЛТ, FRT LWR CONT ARM (M16X2.0X118, 60 THD) [БОЛТ М16]
11610404 БОЛТ, HEX W/CON WA, M10X1.5X75, 66.35THD, 20 OD, 10.9, GMW3359, M-PT (FRT S/ABS)
10369554 SHAFT, FRT STAB
11609701 БОЛТ, HFH, M10X1.5X60, 49 THD, 17.08 OD, 6202M STL, GMW3179-G, TAPPING (FRT STAB SHF) [БОЛТ М10]
11570935 CLAMP, FRT STAB SHF
15124516 INSULATOR, FRT STAB SHF (USE WITH 36 MM SHAFT) [ВТУЛКА СТАБИЛИЗАТОРА ПОДВЕСКИ]
15733534 БОЛТ, FRT LWR CONT ARM (M16X2.0X140, 52 THD) [БОЛТ М16]
11516885 SCREW, HFH W/FL WA, TAP, M8X1.25X20, 7THD, 17 O.D., TR PT, 6202M, PZOR (ELEK SUSP FRT POSN SEN BRKT)
15098628 SENSOR, ELEK SUSP FRT POSN (INCLS 38, 39) [ДАТЧИК ПОЛОЖЕНИЯ ПОДВЕСКИ]
15098629 SENSOR, ELEK SUSP FRT POSN (INCLS 38, 39) [ДАТЧИК ПОЛОЖЕНИЯ ПОДВЕСКИ]
11609404 STUD, ELEK SUSP FRT POSN SEN LINK BALL (M6X1X9.5) (HEX, 8 DIA BALL STYLE)
11509419 БОЛТ, M10X1.5X25 (FRT WHL DRV SHF) [БОЛТ М10]
15868123 SHAFT, FRT WHL DRV (СМ. ГРУППУ 06.000 "DRIVE SHAFT/FRONT WHEEL" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ПРИВОД КОЛЕСА В СБОРЕ]
15522089 WASHER, FRT WHL DRV SHF (6.063) [ШАЙБА ГАЙКИ ПЕРЕДНЕЙ СТУПИЦЫ]
11609826 ГАЙКА, FRT WHL DRV SHF (M24X2X22) [ГАЙКА М14]
15815637 LINK, ELEK SUSP FRT POSN SEN (PART OF 31)
25918049 LINK, FRT STAB SHF (INCLS 10-12, 23, 25) [СТОЙКА СТАБИЛИЗАТОРА ПОДВЕСКИ]
12472859 CAM KIT, FRT UPR CONT ARM ADJ (INCLS 2, 3, 5) (INCLS 8-CAMS, 4-BOLTS & 4-NUTS) (LOCATING PIN PART OF FRAME)
15922557 STUD KIT, FRT LWR CONT ARM BALL (INCLS 9, 14) (THIS PART IS FOR CAST IRON LCA ONLY)
(TC06-907) - 2007 CK1 СИСТЕМА РУЛЕВОГО УПРАВЛЕНИЯ & СОПРЯЖЕННЫЕ ДЕТАЛИ
11517996 ГАЙКА, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (STRG COL) [ГАЙКА М10]
21011332 ГАЙКА, HEX STAMPED TY DF FLG 14 (STRG COL SEAL) (8.921)
25815601 SEAL, STRG COL (145.2MM LONG)
25862789 SHAFT, S/GR CPLG (INCLS 6-11)
15017238 ГАЙКА, S/GR CPLG (PART OF 5) (M10X1.5 6H, 21.5 OD) (W/PREVAILING TORQ FLANGE)
11515768 БОЛТ, S/GR CPLG (PART OF 5) (M10X1.5X40, 30 THD) (8.900) [БОЛТ М10Х1.5Х40]
teamcadillac.ru
11561800 CLAMP-CRIMP, 33.5 DIA, 304 STAINLESS STEEL (PART OF 5)
11561799 CLAMP, DIA 69.7, 304 STAINLESS STEEL (PART OF 5)
26005756 БОЛТ, S/GR CPLG (USED ON LWR SHAFT) (M10X1.5X31) (HFH NYLON LOCK) (6 POINT HEAD)
11516074 ГАЙКА, HEX M14X2X13 (STRG LNKG OTR TIE ROD) [ГАЙКА М10]
11609229 БОЛТ, S/GR (M16X2X172, 57THD) (W/ADHESIVE)
11569939 БОЛТ, S/GR (M12X1.75X50, 33THD)
26058124 БОЛТ, S/GR CPLG (W/ANTI ROTATION PADDLE) (FOR 2ND DES SEE 88965503) (M10X1.5X36) (HFH W/RETAINER NYLON LOCK) (UPR TO STRG COL)
88965503 БОЛТ, S/GR CPLG (WITHOUT ANTI-ROTATION PADDLE) (FOR 1ST DES SEE 26058124) (M10X1.5X35) (FOR SERVICE USE 11515759 T/W 12345382)
11514597 ГАЙКА, S/GR CPLG (M10X1.5 6H, 21.8OD) (2.383)
14074908 WASHER, STRG COL (.460 X1.12 X.180 PL) (6.509)
(TC06-908) - 2007 CK1 РУЛЕВОЙ МЕХАНИЗМ В СБОРЕ (1ST DES)
19207492 GEAR KIT, STRG (REMAN) (INCLS 2-12, 15-18) [РУЛЕВАЯ РЕЙКА]
26081619 SEAL, S/GR PIPE (O RING) (PART OF 1, 3, 4) (6.00MM) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО РУЛЕВОЙ РЕЙКИ]
15254058 PIPE KIT, S/GR (PART OF 1) (INCLS 2, 6) (LT) (HAS MALE THREADS ON FITTING) (6.809)
15254059 PIPE KIT, S/GR (PART OF 1) (INCLS 2, 6) (RT) (HAS MALE THREADS ON FITTING)
teamcadillac.ru
11562064 CLAMP, CRIMP, 66.4 DIA, 7 WIDTH, STAINLESS STEEL (PART OF 1, 11, 16)
15254057 BOOT KIT, S/GR (INCLS 10, 12) (PART OF 1) (EXC TWO MODE HYBRID)
11562066 CLAMP, ПРУЖИНАBAND, DIA MIN 19.2, MAX 22.86, SAE 1055 STL, GM7111M (PART OF 1, 11)
11516074 ГАЙКА, STRG LNKG OTR TIE ROD (PART OF 14) (HEX M14X2, 13THK) (8.917) [ГАЙКА М10]
15254061 ROD KIT, STRG LNKG OTR TIE (INCLS 13) (EXC TWO-MODE HYBRID) [УСТАНОВОЧНЫЙ КОМПЛЕКТ]
11562065 ГАЙКА, STRG LNKG INR TIE ROD (PART OF 1, 16) (M16X1.5, 11THK) (8.915)
19178561 ROD KIT, STRG LNKG INR TIE (INCLS 10, 15) (PART OF 1) (EXC TWO-MODE HYBRID) [НАКОНЕЧНИК РУЛЕВОЙ ТЯГИ]
(TC06-910) - 2007-2009 CK1,2,3 РУЛЕВОЕ КОЛЕСО (LEATHER WRAPPED NP5, EXC ACCESSORY CONTROLS UK3)
15255057 COVER, STRG WHL LWR (PART OF 1) (MECH BRUSH)
15255097 COVER, STRG WHL LWR (PART OF 1) (EBONY)
15255102 COVER, STRG WHL LWR (PART OF 1) (TRINITY)
15844710 COVER, STRG WHL LWR (PART OF 1) (SILVER)
15257875 БОЛТ, STRG WHL LWR CVR (PART OF 1) (M3.63-1.34X10MM) (SPECIAL TORX PLUS (15 IP) PAN HEAD)
teamcadillac.ru
15255031 CONTACT, STRG WHL СИГНАЛ (PART OF 1)
15255034 COVER, STRG WHL LWR (PART OF 1) (EBONY)
15255055 COVER, STRG WHL LWR (PART OF 1) (MECH BRUSH)
15844709 COVER, STRG WHL LWR (PART OF 1) (SILVER)
15819309 SWITCH, CRCONT (PART OF 1) (ACDelco #D1957E)
11609658 ГАЙКА, STRG WHL (M14X1.5, 10THK) (NON FLANGED) (6.518) [ГАЙКА М14]
11609659 ГАЙКА, STRG WHL (M14X1.5, 10THK, 27OD) (FLANGED) (8.917) [ГАЙКА]
(TC06-911) - 2007 CK1,2,3 РУЛЕВОЕ КОЛЕСО (LEATHER WRAPPED NP5, ACCESSORY CONTROLS UK3)
teamcadillac.ru
(TC06-911) - 2007-2009 CK1 РУЛЕВОЕ КОЛЕСО (WOOD TRIM N30, EXC HEATED KA9)
15854522 WHEEL, STRG (INCLS 2-5, 7-9) (EBONY) (USE ON VEH BUILT BEFORE 7/31/2006) FOR 2ND DES SEE 15917942)
15854523 WHEEL, STRG (INCLS 2-5, 7-9) (COCOA)
15917942 WHEEL, STRG (INCLS 2-5, 7-9) (EBONY) (USE ON VEH BUILT ON OR AFTER 7/31/2006) FOR 1ST DES SEE 15854522)
15917950 WHEEL, STRG (INCLS 2-5, 7-9) (EBONY)
15917951 WHEEL, STRG (INCLS 2-5, 7-9) (COCOA)
15819311 SWITCH, RDO CONT (PART OF 1) (EBONY) (9.649) [ВЫКЛЮЧАТЕЛЬ АВТОМАГНИТОЛЫ РАСПОЛОЖЕННЫЙ НА РУЛЕВОМ КОЛЕСЕ]
15824115 SWITCH, RDO CONT (PART OF 1) (COCOA) (9.649)
15824116 SWITCH, RDO CONT (PART OF 1) (EBONY) (9.649)
15824118 SWITCH, RDO CONT (PART OF 1) (COCOA) (9.649)
teamcadillac.ru
15874515 MODULE, STRG WHL INFL RST (EBONY) (LABELED 15874515) (DUAL LEVEL) (16.712)
15874516 MODULE, STRG WHL INFL RST (COCOA) (LABELED 15874516) (DUAL LEVEL) (INCLS EMBLEM) (16.712)
15874519 MODULE, STRG WHL INFL RST (EBONY) (LABELED 15874519) (DUAL LEVEL) (16.712)
15874520 MODULE, STRG WHL INFL RST (COCOA) (LABELED 15874520) (DUAL LEVEL) (16.712)
25917968 MODULE, STRG WHL INFL RST (EBONY) (LABELED 25917968) (DUAL LEVEL) (16.712) [ПОДУШКА БЕЗОПАСНОСТИ]
25917969 MODULE, STRG WHL INFL RST (COCOA) (LABELED 25917969) (DUAL LEVEL) (16.712) [МОДУЛЬ]
25917971 MODULE, STRG WHL INFL RST (EBONY) (LABELED 25917971) (DUAL LEVEL) (16.712)
25917972 MODULE, STRG WHL INFL RST (COCOA) (LABELED 25917972) (DUAL LEVEL) (16.712)
15255100 COVER, STRG WHL LWR (PART OF 1) (TRINITY)
15824105 SWITCH, CRCONT (PART OF 1)
15824106 SWITCH, CRCONT (PART OF 1)
15824109 SWITCH, CRCONT (PART OF 1) (ACDelco #D1958E)
(TC06-912) - 2007-2009 CK1 РУЛЕВОЕ КОЛЕСО (WOOD TRIM N30, HEATED KA9)
15917946 WHEEL, STRG (INCLS 2-5, 7-9) (EBONY) (W/HTR MOD) [РУЛЕВОЕ КОЛЕСО]
15917947 WHEEL, STRG (INCLS 2-5, 7-9) (COCOA)
15917954 WHEEL, STRG (INCLS 2-5, 7-9) (EBONY)
15917955 WHEEL, STRG (INCLS 2-5, 7-9) (COCOA)
teamcadillac.ru
15824110 SWITCH, CRCONT (PART OF 1) [ВЫКЛЮЧАТЕЛЬ УПРАВЛЕНИЯ КРУИЗ-КОНТРОЛЕМ РАСПОЛОЖЕННЫЙ НА РУЛЕВОМ КОЛЕСЕ]
15824111 SWITCH, CRCONT (PART OF 1)
15824112 SWITCH, CRCONT (PART OF 1) (ACDelco #D1959E)
15824113 SWITCH, CRCONT (PART OF 1) (ACDelco #D1960E)
(TC06-913) - 2007 CK1 НАСОС РУЛЕВОГО УПРАВЛЕНИЯ LINES
25858603 HOSE, P/S GR INL (INCLS 2, 4) [ШЛАНГ СИСТЕМЫ РУЛЕВОГО УПРАВЛЕНИЯ]
26001594 SEAL, P/S GR INL HOSE (O RING) (PART OF 1) (7.65MM IDX1.63MM THK) [ПРОКЛАДКА ТРУБКИ НАСОСА]
11562063 БОЛТ, HFH, M6X1X25, 18 THD, 12.8 OD, 9.8 STL, HEX CHROME FREE, SN-ZN. (PART OF 1)
26100863 SEAL, P/S GR INL HOSE (O RING) (6.824) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО РУЛЕВОГО МЕХАНИЗМА]
11516255 CLAMP, ПРУЖИНА BAND HOSE (M16X1) (PART OF 8)
15186858 COOLER, P/S FLUID (INCLS 7) [РАДИАТОР]
teamcadillac.ru
11589039 БОЛТ, HEX, W/CON WA, M6X1X30, 20 THD, 24 O.D., 9.8, GMW4205 (P/S FLUID CLR) [БОЛТ М6Х1Х30]
11516255 CLAMP, ПРУЖИНА BAND HOSE (M16X1) (PART OF 11)
15812565 HOSE, P/S GR OTLT (INCLS 10) [ШЛАНГ СИСТЕМЫ РУЛЕВОГО УПРАВЛЕНИЯ]
11589398 БОЛТ, HEX HD, W/CON WA, M6X1X30, 18.11 THD, 24 O.D., 9.8, GMW3179, BLACK (P/S FLUID CLR)
52476687 INSULATOR, P/S FLUID CLR (UPPER)
(TC06-914) - 2007-2009 K1 DRIVE SHAFT/FRONT WHEEL
15868123 SHAFT, FRT WHL DRV (INCLS 2-16) [ПРИВОД КОЛЕСА В СБОРЕ]
26056803 RING, FRT WHL DRV SHF TRI-POT JT SPIDER RET (PART OF 4, 6) (6.056)
15295245 JOINT, FRT WHL DRV SHF TRI-POT (INCLS 3) (MUST ALSO ORDER APPROPRIATE BOOT KIT) [ШРУС В СБОРЕ]
26056789 CLAMP, FRT WHL DRV SHF TRI-POT JT BOOT OTR (PART OF 6)
26062615 BOOT KIT, FRT WHL DRV SHF TRI-POT JT (INCLS 3, 5, 7) [ПЫЛЬНИК ШРУСА]
07849180 CLAMP, FRT WHL DRV SHF TRI-POT JT BOOT INR (PART OF 6) (34.60MM DIA, 10MM THK) (6.060)
teamcadillac.ru
07849180 CLAMP, FRT WHL DRV SHF CV JT BOOT INR (PART OF 10) (34.60MM DIA, 10MM THK) (6.060)
15868187 BOOT KIT, FRT WHL DRV SHF CV JT (INCLS 9, 11, 12) [ПЫЛЬНИК ШРУСА]
26007601 CLAMP, FRT WHL DRV SHF CV JT BOOT OTR (PART OF 10) (105.91MM DIA) (6.060)
07849284 RING, FRT WHL DRV SHF CV JT INR RACE RET (PART OF 10, 14)
26057639 JOINT, FRT WHL DRV SHF CV (INCLS 12, 13, 15) (MUST ALSO ORDER APPROPRIATE BOOT KIT)
(TC06-915) - 2007-2008 CK1(06-36) РУЛЕВАЯ КОЛОНКА (EXC POLICE PACKAGE PPV)
15775830 SHROUD, STRG COL (INCLS 22) (EBONY)
15775831 SHROUD, STRG COL (INCLS 22) (TITANIUM)
15775833 SHROUD, STRG COL (INCLS 22) (COCOA)
15775834 SHROUD, STRG COL (INCLS 22) (EBONY)
15871385 SHROUD, STRG COL (INCLS 22) (COCOA)
25861815 MODULE, THEFT DTRNT
26088811 CASE, IGN LK CYL (EXCEPT LK ACTUATOR & PASS SENSOR) (PART OF 26) (PASS KEY) [КОРПУС ЗАМКА ЗАЖИГАНИЯ]
26036497 БОЛТ, STRG COL LWR TR CVR (PART OF 26) (M5X.8X15) (6.760) [БОЛТ М5]
26055299 ПРУЖИНА, STRG SHF UPR BRG (PART OF 26)
15775848 CAM, T/SIG SW CANC (PART OF 26)
26049186 PLATE, T/SIG SW CANC CAM POSN (PART OF 26) (W/SHIELD) (6.521)
05694191 RING, STRG SHF LK PLT RET (PART OF 26) (6.524)
26011609 WASHER, STRG WHL INFL RST MDL COIL (14.865) [ШАЙБА D=14ММ]
00274414 RING, EXT, SNAP, FITS M19 OR.75" SHAFT, STL, PL (STRG WHL INFL RST MDL COIL RET)
15829093 COIL, STRG WHL INFL RST MDL (W/ACSRY CNCT) [КОНТАКТНЫЙ БЛОК РУЛЕВОЙ КОЛОНКИ]
15829094 COIL, STRG WHL INFL RST MDL (W/ACSRY CNCT) [КАТУШКА]
15829095 COIL, STRG WHL INFL RST MDL (W/ACSRY CNCT)
15231641 SEAT, STRG SHF UPR BRG RACE (PART OF 26)
26036497 БОЛТ, HDLP DIMR & T/SIG SW (M5X.8X15) (6.760) [БОЛТ М5]
15849313 SWITCH, T/SIG & HDLP & HDLP DIMR & WSW & WSWA (W/O RR WIPER) (2.895) (ACDelco #D6221E)
15849314 SWITCH, T/SIG & HDLP & HDLP DIMR & WSW & WSWA (INCLUDES HAZARD BUTTON) (W/RR WIPER) (2.895) (ACDelco #D6224E)
26075818 BRACKET, IGN LK CYL CASE (PART OF 26)
26036521 PIN, STRG COL PIV (PART OF 26) [НАПРАВЛЯЮЩАЯ РЕГУЛИРОВКИ РУЛЕВОЙ КОЛОНКИ]
26034561 GUIDE, STRG COL TILT (PART OF 26) (6.514)
26090202 LEVER, STRG COL TILT LK REL (PART OF 26) (INTERNAL)
26069514 LEVER, STRG COL TILT WHL REL (EXTERNAL) [РУКОЯТКА РЕГУЛИРОВКИ УГЛА НАКЛОНА РУЛЕВОЙ КОЛОНКИ]
15775835 SEAL, A/TRNS CONT LVR [НАКЛАДКА РУЛЕВОЙ КОЛОНКИ]
teamcadillac.ru
26036317 PIN, STRG COL TILT LK REL LVR PIV (PART OF 26) (M5X0.8) (T-25 TORX)
26065450 ПРУЖИНА, STRG COL TILT (PART OF 26)
11561801 STRAP, WRG HARN (HOLDS TUBE DIA 60MM)
15775845 COLUMN, STRG (INCLS 3-8, 13, 16-19, 23, 24, 32, 34) [РУЛЕВАЯ КОЛОНКА]
15930127 COLUMN, STRG (INCLS 3-8, 13, 16-19, 23, 24, 32, 34) [РУЛЕВАЯ КОЛОНКА]
15775843 HARNESS, STRG COL WRG (HAS 1/8 IN. CONNECTOR PINS)
15775844 HARNESS, STRG COL WRG (HAS 1/8 IN. CONNECTOR PINS)
25807858 HARNESS, STRG COL WRG (HAS 1/16 IN. CONNECTOR PINS) [ПРОВОДКА РУЛЕВОЙ КОЛОНКИ]
25809424 SHAFT, UPR INTER STRG [ВАЛ РУЛЕВОЙ КОЛОНКИ]
15775847 CLIP, STRG WHL POSN SEN RET
15886733 SENSOR, STRG WHL POSN (6.552) [ДАТЧИК ПОЗИЦИИ РУЛЕВОЙ КОЛОНКИ]
15775851 ADAPTER, STRG SHF LWR BRG (PART OF 26) (INCLS LOWER BEARING)
26058124 БОЛТ, S/GR CPLG (M10X1.5X36) (HFH W/RETAINER NYLON LOCK) (UPR TO STRG COL)
15775841 SOLENOID, A/TRNS SHFT LK CONT (ACDelco #15775841)
11562309 SCREW, OVAL HEAD, 10-24X0.43", GM6010M STL, PHOSPHATE&OIL, TAPPING, W/ADH (STRG COL BRKT)
15775840 CONTROL, A/TRNS (INCLS PARK LOCK CABLE) [МЕХАНИЗМ ПЕРЕКЛЮЧЕНИЯ ПЕРЕДАЧ]
26035516 БОЛТ, A/TRNS SHFT LK CONT SOL
26086318 БОЛТ, A/TRNS CONT LVR (M6X1X13)
25733005 SWITCH, IGN & START (ACDelco #D1485F) [КОНЦЕВОЙ ВЫКЛЮЧАТЕЛЬ ЗАМКА ЗАЖИГАНИЯ]
26001827 BEARING KIT, STRG SHF UPR (STRG COL INR W/RACE)
26082804 RETAINER, A/TRNS PARK LK CBL
15775837 LEVER, A/TRNS CONT (1/8" CONNECTOR PINS)
15775838 LEVER, A/TRNS CONT (1/8" CONNECTOR PINS)
25807853 LEVER, A/TRNS CONT (1/16" CONNECTOR PINS)
25807855 LEVER, A/TRNS CONT (1/16" PINS)
(TC06-916) - 2007-2008 CK1 НАСОС РУЛЕВОГО УПРАВЛЕНИЯ ASM (LC9/5.3-3,LH6/5.3M,LMG/5.3-0,LY2/4.8C,LY5/5.3J,L76/6.0Y,L92/6.2-8)
26045594 RESERVOIR KIT, P/S FLUID (INCLS 6, 9-11) (PART OF 12)
26095194 CAP, P/S FLUID RSVR (PART OF 12)
26009574 STUD, P/S FLUID RSVR (PART OF 12) (M10X1.5X16) (SHORT) (6.606)
15241681 STUD, P/S FLUID RSVR (PART OF 12) (LONG)
26025709 FITTING, P/S PUMP (PART OF 12) (*KIT2)
26020642 SEAL, P/S PUMP FTG (O RING) (PART OF 1, 12) (14.5MM I.D.) (*KIT1) (6.635) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО НАСОСА ГУРА]
26065843 VALVE, P/S PUMP FLOW CONT (PART OF 12) (VALVE ONLY) (*KIT2)
teamcadillac.ru
15909824 PUMP, P/S (INCLS 1-11, 13, 14)
15277770 SEAL, P/S PUMP SHF (PART OF 12) (I.D.22.78MM) (USED W/19MM SHAFT) [ПРОКЛАДКА НАСОСА ГУРА]
15825938 SEAL KIT, P/S PUMP (INCLS 6, 9-11) (FRT SEAL NOT INCL)
15246463 VALVE KIT, P/S PUMP FLOW CONT (INCLS 5, 7, 8)
(TC06-932) - 2007 K1 ЧАШКА ДИФФЕРЕНЦИАЛА/FRONT AXLE ЧАСТЬ 2 (ALL WHEEL DRIVE NR3)(2ND DES)
15876533 LOCK, FRT DIFF BRG ADJR NUT (W/O T-CLIP STYLE ADJUSTER W/O AXLE CODES HU5, HU6, HU7, HU8, XP1, XP3, XP4, XP5) (FOR 1ST DES SEE 15588312) [ШПОНКА]
15876532 ADJUSTER, FRT DIFF BRG (INCLS 13) (USED ON VEHICLES /LOCK RING STYLE ADJUSTER USED ON ALL AXLES EXCEPT W/BROADCAST CODES HU5, HU6, HU7, HU8, XP1, XP3, XP4, XP5) (FOR 1ST DES SEE 12470318) [РЕГУЛЯТОР В СБОРЕ, ПОДШИПНИКА ПЕРЕДНЕГО ДИФФЕРЕНЦИАЛА]
teamcadillac.ru
12471620 PLUG, FRT DIFF CARR OIL FIL (M40 X 1.5) [ШТЕКЕР]
(TX06-017) - 2007-2008 CK1 КРЕПЛЕНИЕ НАСОСА РУЛЕВОГО УПРАВЛЕНИЯ (LC9/5.3-3,LH6/5.3M,LMG/5.3-0,LY2/4.8C,LY5/5.3J,L76/6.0Y,L92/6.2-8)
12554030 BRACKET, GEN & P/S PUMP (INCLS 2) (INCLS SPACER)
12550090 SPACER, GEN & P/S PUMP BRKT (PART OF 1) [ВТУЛКА ГЕНЕРАТОРА]
11515764 БОЛТ, HFH, M10X1.5X20, 18THD, 22.3 O.D., 10.9, 7114M (P/S PUMP RR BRKT)
11514597 ГАЙКА, HFH, 10X1.5 THD, 9.8 THK, 21.8 OD, 510M (10) ZF 7111M (P/S PUMP RR BRKT) (2.383)
teamcadillac.ru
12554032 BRACKET, P/S PUMP RR
12604004 PULLEY, P/S PUMP (PHY ID 4004) [ШКИВ НАСОСА ГУРА]
11515767 БОЛТ, HFH, M10X1.5X35, 32THD, 22.3 O.D., MACH, 10.9, 7114M (P/S PUMP) (T/W 12345493) [БОЛТ]
11519214 БОЛТ, HFH M10X1.5X115, 30 MM THD, 22.3 OD, 9.8, 7114M, MAT POINT (GEN & P/S PUMP BRKT)
07 - КУЗОВ - ПРУЖИНЫ - АМОРТИЗАТОРЫ - БАМПЕРЫ
(TC07-635) - 2007-2009 CK1(06-36) ПОДВЕСКА-ЗАДНЯЯ ЧАСТЬ 1
15918524 АМОРТИЗАТОР, RR LVLG SHK (ACDelco #580-324)
15918525 АМОРТИЗАТОР, RR LVLG SHK (ACDelco #580-326) [АМОРТИЗАТОР]
11609819 BOLT-HEX W/CON WA, M14X2X85, 45 THD, 28 OD, 10.9, GMW3359 (RR S/ABS) [БОЛТ М14]
11609243 BOLT M12X1.75X65 (RR STAB SHF INSL CLA)
15257472 LINK, RR STAB SHF [СОЕДИНЕНИЕ СТАБИЛИЗАТОРА]
10383662 SHAFT, RR STAB
11518294 BOLT-HFH, M10X1.5X29.5, 17.08 OD, 6202M, 4435M, TAP, TR-PT (RR STAB SHF INSL CLA) [БОЛТ М10]
88891781 CLAMP, RR STAB SHF INSL [КРОНШТЕЙН]
03537772 ГАЙКА, M12X1.75, 10.6THK, 28 O.D., 10, 7111M (RR STAB SHF LINK) (8.917)
11516382 ГАЙКА, HFH LK M14X2X15, 28 OD 10 7111M (RR S/ABS) [ГАЙКА М10]
14071381 INSULATOR, RR STAB SHF (RUBBER) (28.6 MM STAB BAR) [ИЗОЛЯТОР]
teamcadillac.ru
19115819 TUBE, RR S/ABS AIR (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/CHASSIS" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ТРУБКА ТОРМОЗНОЙ СИСТЕМЫ]
(TC07-676) - 2007-2009 CK1,2,3 ЦИЛИНДР ЗАМКА/ЗАПАСНОЕ КОЛЕСО
15926907 КЛЮЧ, ЗАЖИГАНИЯ LK (PRE-CUT & PROGRAMMED)
teamcadillac.ru
15926908 КЛЮЧ, ЗАЖИГАНИЯ LK (PRE-CUT & PRE-PROGRAMED FOR FLEET)
25865394 КЛЮЧ, ЗАЖИГАНИЯ (UNCODED) (MASTER)
25945700 CYLINDER, SPA WHL HOIST LK (INCLS 2-8) [ЗАМОК КРЕПЛЕНИЯ ЗАПАСНОГО КОЛЕСА]
(TC07-902) - 2007 CK1(06-36) БАМПЕР ПЕРЕДНИЙ (CADILLAC Z75)
15904442 BRACKET, RAD GRL UPR (INCLS 3) [ПОПЕРЕЧНАЯ ПАНЕЛЬ КУЗОВА]
11610055 БОЛТ, HWASH, M6X1X23 (RAD GRL SUPT REINF)
11518121 ГАЙКА, U, M6X1, MULTI THD, .5'-4.0' THK PNL (PART OF 1)
25901978 BRACKET, FRT BPR FASCIA [СУППОРТ ПАНЕЛИ БАМПЕРА]
11610055 БОЛТ, HWASH, M6X1X23 (FRT BPR FASCIA)
25947497 BAR, FRT BPR IMP [БАЛКА ПЕРЕДНЕГО БАМПЕРА]
11519154 БОЛТ, FRT BPR IMP BAR (M14X2X140) [БОЛТ]
25948814 BRACKET, FRT BPR FASCIA SI (INCLS 9) [НАПРАВЛЯЮЩАЯ ПЕРЕДНЕГО БАМПЕРА]
25948815 BRACKET, FRT BPR FASCIA SI (INCLS 9) [ОПОРНАЯ ПЛАНКА ПАНЕЛИ БАМПЕРА]
11518531 ГАЙКА, U-TYPE, M4.2X1.41, 15.9X8.4, .7-2.1 PNL, SAE 1050 STL, 7111M, 8.65 SQ HOL (PART OF 8) (10.512) [ГАЙКА М10]
11610055 БОЛТ, HWASH, M6X1X23 (FRT BPR FASCIA SI BRKT)
11609685 БОЛТ, HEX W/CON SPR WA, M6X1X27, 19 THD, 24 OD, 8.8, GMW3359 BLACK, M-PT (FRT BPR LWR FASCIA)
10376177 FILLER, FRT BPR OTR FRT [ВСТАВКА ПЕРЕДНЕГО БАМПЕРА]
teamcadillac.ru
10376178 FILLER, FRT BPR OTR FRT [ВСТАВКА ПЕРЕДНЕГО БАМПЕРА]
11515638 ГАЙКА, U-TYPE, M4.2X1.41X10.5.5X22, .65-3.8 PNL THK, 1050, ZF (FRT BPR OTR FRT FIL) [ГАЙКА М4.2]
11609385 ГАЙКА, U-TYPE, M6X1, 29.5 LEN, 12.5 WID, 19.5 CEN-END, 1050, GMW3359 (FRT BPR LWR FASCIA) [ГАЙКА М 6]
11515638 ГАЙКА, U-TYPE, M4.2X1.41X10.5.5X22, .65-3.8 PNL THK, 1050, ZF (FRT OTR A/DFL) [ГАЙКА М4.2]
11609465 БОЛТ, HWH, M4.2X1.41X18, 12.5 OD, 6010M, PS (FRT OTR A/DFL) (8.977) [ВИНТ М6]
15138234 DEFLECTOR, FRT AIR [ВОЗДУШНЫЙ ДЕФЛЕКТОР]
11609465 БОЛТ, HWH, M4.2X1.41X18, 12.5 OD, 6010M, PS (FRT BPR OTR FRT FIL) (8.977) [ВИНТ М6]
15140153 ATTACHMENT KIT, FRT LIC PLT (INCLS 20) [КРОНШТЕЙН ДЛЯ НОМЕРНОГО ЗНАКА]
15851090 BRACKET, FRT LIC PLT (CHARCOAL) [КРОНШТЕЙН-ПЕРЕДНЕГО НОМЕРНОГО ЗНАКА *СВЕТЛО-ПЕПЕЛЬНЫЙ]
15941065 BRACKET, FRT LIC PLT (PAINT TO MATCH)
15993201 RETAINER, FRT LIC PLT BRKT (PART OF 19) (FOR 9.3MM DIA HOLE) (NYLON) (17.505) [КРОНШТЕЙН]
25814554 FASCIA, FRT BPR (PAINT TO MATCH) [ПАНЕЛЬ БАМПЕРА]
25705182 БОЛТ, FRT BPR FASCIA CTR SUPT (M9.5X6.0 HI-LO, TL 47MM, 22 OD) (12.249) [ВИНТ М5]
15893972 COVER, FRT TOW HOOK OPG [КРЫШЕЧКА БУКСИРОВОЧНОЙ ПРОУШИНЫ]
15893973 COVER, FRT TOW HOOK OPG [ЗАГЛУШКА ПАНЕЛИ БАМПЕРА]
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (FRT FOG LP) [ГАЙКА М6]
15882456 SUPPORT, FRT BPR FASCIA [СУППОРТ ПАНЕЛИ БАМПЕРА]
15126354 EMBLEM, RAD GRL (MEDALLION) (USE ON VEHICLES BUILT WITH 1-PIECE DESIGN) (FOR 2ND DES SEE 25795247) [ЭМБЛЕМА РЕШЕТКИ РАДИАТОРА]
25795247 EMBLEM, RAD GRL (WREATH/CREST) (USE ON VEHICLES BUILT WITH 2-PIECE DESIGN) (FOR 1ST DES SEE 15126354) [ЭМБЛЕМА РЕШЕТКИ РАДИАТОРА]
11610055 БОЛТ, HWASH, M6X1X23 (FRT BPR UPR FASCIA)
15078238 RETAINER, RAD GRL (BLACK) (25X15.5) (ALSO REPLACES SILVER) [ФИКСАТОР РЕШЕТКИ РАДИАТОРА]
10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (FRT BPR FASCIA OTR BRKT) [ПИСТОН КРЕПЛЕНИЯ ОБЛИЦОВКИ БАМПЕРА (NYLON)]
(TC07-903) - 2007 CK1(06) ЗАПАСНОЕ КОЛЕСО CARRIER
15827206 CASE, SPA WHL LK CYL (7.680) [КОРПУС ЗАМКА КРЕПЛЕНИЯ ЗАПАСНОГО КОЛЕСА]
25945700 CYLINDER, SPA WHL HOIST LK (СМ. ГРУППУ 07.000 "ЦИЛИНДР ЗАМКА/ЗАПАСНОЕ КОЛЕСО" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ЗАМОК КРЕПЛЕНИЯ ЗАПАСНОГО КОЛЕСА]
15811583 COVER, RR BPR FASCIA ACC HOLE (PAINT TO MATCH) [КРЫШКА ЗАМКА ПОДЪЕМНИКА ЗАПАСНОГО КОЛЕСА]
10372326 GUIDE, SPA WHL HOIST SHF
teamcadillac.ru
11517827 БОЛТ, HFH W/FL WA, M10X1.5X35, 20 THD, 25 OD, 9.8, 7114M, MACH, P-PT, 6175M A (SPA WHL HOIST) [БОЛТ М10]
25912263 HOIST, SPA WHL [ПОДЪЕМНИК ЗАПАСНОГО КОЛЕСА]
25912264 HOIST, SPA WHL
11518341 БОЛТ, HEX, M10X1.5X25, 14 THD, 28 OD, 6202M, 7114M, TAP, TR-PT (SPA WHL H/SHLD) [БОЛТ М10Х1.5Х25]
25783810 SHIELD, SPA WHL HT
(TC07-906) - 2007-2009 CK107(06) БАМПЕР ЗАДНИЙ (CADILLAC Z75)
25938524 BAR, RR BPR IMP (INCLS 24, 28) (INCLS TRAILER HITCH RECEIVER) [БАЛКА ЗАДНЕГО БАМПЕРА]
11518531 ГАЙКА, U-TYPE, M4.2X1.41, 15.9X8.4, .7-2.1 PNL, SAE 1050 STL, 7111M, 8.65 SQ HOL (RR BPR FASCIA) (10.512) [ГАЙКА М10]
11519537 БОЛТ, HEX HD, W/CON WA, M12X1.75X40.8, 25.6 THD, 35 O.D., 10.9, GMW3359 (RR BPR IMP BAR)
11569711 ГАЙКА, PUSH-IN, M4.2X1.41, 0.7-2.15 PNL THK, SAE 1050-1065, GMW3359 W/ (RR BPR FASCIA) [ГАЙКА М4.2]
11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (RR W/H PNL LNR) [ВИНТ М4]
11589292 PUSH PIN, FITS 8.5 DIA HOLE IN 2-4.5 THK PNL, NYLON 6/6 GMP.PA66.015 (RR W/H PNL LNR (PUSH IN)) [ФИКСАТОР ПАНЕЛИ БАМПЕРА]
11569711 ГАЙКА, PUSH-IN, M4.2X1.41, 0.7-2.15 PNL THK, SAE 1050-1065, GMW3359 W/ (RR BPR FASCIA SI SUPT) [ГАЙКА М4.2]
15912685 BRACKET, RR BPR FASCIA SUPT [НАПРАВЛЯЮЩАЯ ПАНЕЛИ БАМПЕРА]
25906986 BRACKET, RR BPR FASCIA SUPT [ОПОРНАЯ ПЛАНКА ПАНЕЛИ ПЕРЕДНЕГО БАМПЕРА]
teamcadillac.ru
11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (RR BPR FASCIA SI SUPT) [ВИНТ М4]
15950574 HARNESS, RR OBJECT SEN WRG [ПРОВОДКА ДАТЧИКОВ ЗВУКОВОЙ СИГНАЛИЗАЦИИ СИСТЕМЫ ПАРКОВКИ]
15239247 SENSOR KIT, RR OBJECT (INCLS 13) (PRIMED) (W/O ШЛАНГИ) (*KIT1) [ДАТЧИК ПАРКОВКИ]
15817523 ШЛАНГИ, RR OBJECT SEN (PRIMED) (PART OF 16) (OUTBOARD) (*KIT1) (7.831)
15817524 ШЛАНГИ, RR OBJECT SEN (PRIMED) (PART OF 16) (INBOARD) (*KIT1) (7.831) [КОРПУС ДАТЧИКА ПАРКОВКИ]
15817525 ШЛАНГИ, RR OBJECT SEN (PRIMED) (PART OF 16) (OUTBOARD) (*KIT1) (7.831)
15817526 ШЛАНГИ, RR OBJECT SEN (PRIMED) (PART OF 16) (INBOARD) (*KIT1) (7.831)
11515638 ГАЙКА, U-TYPE, M4.2X1.41X10.5.5X22, .65-3.8 PNL THK, 1050, ZF (RR W/H PNL LNR) [ГАЙКА М4.2]
11562024 RETAINER, PUSH IN, 7.5X36.5, FITS 6.35 HOLE IN 2.29-18.34 THK PNL (RR BPR FASCIA (PUSH IN)) [ФИКСАТОР ПАНЕЛИ БАМПЕРА]
15909709 FASCIA, RR BPR (INCLS 12, 19) (PAINT TO MATCH)
20771921 FASCIA, RR BPR (INCLS 12, 19) (PAINT TO MATCH) (MAY NEED TO ORDER HITCH COVER 20777999) [ПАНЕЛЬ БАМПЕРА]
11610049 ГАЙКА, RR BPR FASCIA (SPECIAL PIN-PUSH, FITS 6.6X12.5 RECTANGULAR HOLE, 14.5 LONG) [ГАЙКА М8]
20777999 COVER PKG, RR BPR FASCIA TRLR HITCH ACC HOLE (PAINT TO MATCH) [КРЫШКА ПАНЕЛИ ЗАДНЕГО БАМПЕРА]
15811583 COVER, RR BPR FASCIA ACC HOLE (PART OF 16) (PAINT TO MATCH) [КРЫШКА ЗАМКА ПОДЪЕМНИКА ЗАПАСНОГО КОЛЕСА]
11570498 БОЛТ, HWH W/FL WA, M4.2X1.41X20, 11.4 THD, 17 OD, ISO 2702 STL , GMW4205, T (RR BPR FASCIA)
15853597 PAD, RR BPR FASCIA STEP (USE T/W 15853598) [НАКЛАДКА ПАНЕЛИ БАМПЕРА]
12191503 RECEPTACLE, TOW VEH ELEC (W/DOOR) [ОПОРА КОНТАКТНОГО РАЗЪЕМА ТРЕЙЛЕРНОЙ СЦЕПКИ]
15228708 LABEL, TRLR HITCH INFO (PART OF 1)
11561075 BOLT-HEX W/CON WA, M14X2X45, 21.18 THD, 32 OD, 10.9, GMW3359, M-PT, ADHES (RR BPR IMP BAR) [БОЛТ М12]
15853598 MOLDING, RR BPR FASCIA (INCLS 27) (CHROME) (USE T/W 15853597) [МОЛДИНГ ЗАДНЕГО БАМПЕРА]
11561857 CLIP, RR BPR FASCIA MLDG (PART OF 26) (BLACK) (14.13 X 11 X 8.6)
25894906 BRACKET, RR BPR IMP BAR (PART OF 1)
11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (RR BPR LWR FASCIA) [ШАЙБА]
25779048 REFLECTOR, R/END FASCIA [НАКЛАДКА ПАНЕЛИ БАМПЕРА]
25779049 REFLECTOR, R/END FASCIA [НАКЛАДКА ПАНЕЛИ БАМПЕРА]
19116085 SENSOR KIT, RR OBJECT (INCLS 11-13) (PRIMED) (W/ШЛАНГИ) (7.831) [ДАТЧИК КОНТРОЛЯ ПАРКОВКИ]
(TC07-906) - 2007-2009 CK107(06) БАМПЕР ЗАДНИЙ (G.M.C. Z88, DENALI Y91)
(TC07-911) - 2007-2009 K1(06-36) ПРИЦЕПНОЕ УСТРОЙСТВО
15827191 HOOK, FRT TOW [БУКСИРОВОЧНЫЙ КРЮК]
11516078 ГАЙКА, HFH, M12X1.75, 14THK, 25 O.D., 10, PZOR (FRT TOW HOOK) [ГАЙКА]
11589274 BOLT HFH, M12X1.75X45.8, 31.4 THD, 26.6 OD, 10.9, GMW3359, (FRT TOW HOOK) [БОЛТ М12]
teamcadillac.ru
11589283 БОЛТ, HFH, M12X1.75X125.9, 45 THD, 26.6 OD, 10.9, GMW3359, M-PT, REDUCED BO (FRT TOW HOOK)
(TC07-914) - 2007-2009 CK1(06-36) ПОДВЕСКА-ЗАДНЯЯ ЧАСТЬ 2
11518725 БОЛТ, R/AXL TIE ROD (M14X2.0X95) (HVY HEX FLG HD W/CON SPR WA) (8.900) [БОЛТ М14Х95]
11516382 ГАЙКА, R/AXL TIE ROD (FRAME SIDE ONLY) (M14X2X15) (W/O J CLIP RETAINER) (8.917) [ГАЙКА М10]
15251980 INSULATOR, RR SPR (FRAME SIDE ONLY)
25783732 ПРУЖИНА, RR
15765071 INSULATOR, RR SPR (AXLE SIDE ONLY) [ДЕМПФЕР ПРУЖИНЫ ПОДВЕСКИ]
15039398 ROD, R/AXL TIE (INCLS 6) [ШТАНГА ПОДВЕСКИ]
11609486 ГАЙКА, R/AXL TIE ROD (AXLE SIDE ONLY) (M14X2)
11517766 БОЛТ, R/AXL LWR CONT ARM (M14X2X106) (HEX W/CON WA) (8.900)
11516382 ГАЙКА, R/AXL LWR CONT ARM (M14X2X15) (W/O J CLIP RETAINER) (8.917) [ГАЙКА М10]
11517901 БОЛТ, R/AXL UPR CONT ARM (M14X2X90) (HEX W/CON WA) (8.900)
11516382 ГАЙКА, R/AXL UPR CONT ARM (M14X2X15) (W/O J CLIP RETAINER) (8.917) [ГАЙКА М10]
15239738 ARM, R/AXL LWR CONT (INCLS 14) [РЫЧАГ ПОДВЕСКИ]
15208540 ARM, R/AXL UPR CONT (INCLS 16) [РЫЧАГ В СБОРЕ]
teamcadillac.ru
11519144 ГАЙКА, R/AXL UPR CONT ARM (NUT W/J CLIP RETAINER)
15039397 BUMPER, RR SUSP JOUNCE
(TC07-915) - 2007 CK1(06-36) LEVEL CONTROL КОМПРЕССОР/AUTOMATIC (REAL-TIME DAMPING Z55)
teamcadillac.ru
25913289 КОМПРЕССОР, AUTO LVL CONT AIR (INCLS 2-14)
15840487 TEE, RR AIR SUSP LVLG C/VLV SPLY TUBE [ФИТИНГ ШЛАНГА ПНЕВМОПОДВЕСКИ]
(TC07-916) - 2007 CK1(06-36) ЭЛЕКТРОННОЕ УПРАВЛЕНИЕ ПОДВЕСКОЙ (REAL-TIME DAMPING Z55)
15095294 MODULE, ELEK SUSP CONT (INCLS 2, 3)
teamcadillac.ru
15128648 SENSOR, ELEK SUSP RR POSN (INCLS 11-13) [ДАТЧИК ПОЛОЖЕНИЯ ПОДВЕСКИ]
15128649 SENSOR, ELEK SUSP RR POSN (INCLS 11-13) [ДАТЧИК ПОЛОЖЕНИЯ ПОДВЕСКИ]
11516885 SCREW, HFH W/FL WA, TAP, M8X1.25X20, 7THD, 17 O.D., TR PT, 6202M, PZOR (ELEK SUSP RR POSN SEN BRKT)
15815642 LINK, ELEK SUSP RR POSN SEN (PART OF 9) [ТЯГА ПОДВЕСКИ]
22189896 BRACKET, ELEK SUSP FRT POSN SEN (PART OF 9) (INCLS 11) (ELEK SUSP RR POSN) [ОПОРНАЯ ПЛАНКА ДАТЧИКА ПОЛОЖЕНИЯ ПОДВЕСКИ]
22189897 BRACKET, ELEK SUSP FRT POSN SEN (PART OF 9) (INCLS 11) (ELEK SUSP RR POSN) [ОПОРНАЯ ПЛАНКА ДАТЧИКА ПОЛОЖЕНИЯ ПОДВЕСКИ]
15098628 SENSOR, ELEK SUSP FRT POSN (INCLS 16, 17) [ДАТЧИК ПОЛОЖЕНИЯ ПОДВЕСКИ]
15098629 SENSOR, ELEK SUSP FRT POSN (INCLS 16, 17) [ДАТЧИК ПОЛОЖЕНИЯ ПОДВЕСКИ]
15815637 LINK, ELEK SUSP FRT POSN SEN (PART OF 15)
19180262 CONNECTOR, SOL-S/ABS ELEK SUSP CONT ACTR (PART OF 4) (GRAY) (2-WAY MALE) (90DEG COUPLING) (7.450) [СОЕДИНИТЕЛЬ]
(TC07-917) - 2007 CK1(06-36) ЭЛЕКТРОННОЕ УПРАВЛЕНИЕ ПОДВЕСКОЙ (EXC ACTIVE BRAKE CONTROL DELETE JL0)
teamcadillac.ru
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (VEH YAW SEN & LATL ACCLRM) [ГАЙКА М6]
25930324 SENSOR, VEH YAW (W/VEH LATL ACCLRM)
(TC07-919) - 2007-2009 K1(06-36) FRAME
15931160 FRAME, CHASSIS (INCLS 2, 4-20) [РАМА КУЗОВА]
11561577 БОЛТ, FRT DIFF CARR BRKT (PART OF 1) (8.900)
teamcadillac.ru
15854868 BRACKET, RAD SI MT (PART OF 1, 21)
15854869 BRACKET, RAD SI MT (PART OF 1, 21)
11589274 BOLT HFH, M12X1.75X45.8, 31.4 THD, 26.6 OD, 10.9, GMW3359, (PART OF 1) [БОЛТ М12]
11589283 БОЛТ, HFH, M12X1.75X125.9, 45 THD, 26.6 OD, 10.9, GMW3359, M-PT, REDUCED BO (PART OF 1)
15774517 SPACER, FRT BPR IMP BAR BRKT (PART OF 1, 21) (*KIT1) [ВТУЛКА КРОНШТЕЙНА РАМЫ КУЗОВА]
15827191 HOOK, FRT TOW (PART OF 1) [БУКСИРОВОЧНЫЙ КРЮК]
10385576 BRACKET, U/B (PART OF 1, 21)
10385577 BRACKET, U/B (PART OF 1, 21)
11516078 ГАЙКА, HFH, M12X1.75, 14THK, 25 O.D., 10, PZOR (PART OF 1) [ГАЙКА]
15201007 CROSSMEMBER, FRT (PART OF 1, 21)
15201932 BRACKET, FRT DIFF CARR (PART OF 1)
15201933 BRACKET, FRT DIFF CARR (PART OF 1) [СУППОРТ ДИФФЕРЕНЦИАЛА ВЕДУЩЕГО МОСТА]
11514598 ГАЙКА, FRT DIFF CARR BRKT (PART OF 1) (HF 12X1.75) (8.915) [ГАЙКА М12]
19150105 CROSSMEMBER, DRIVETRAIN & FRT SUSP FRM FRT (PART OF 1)
11517236 БОЛТ, DRIVETRAIN & FRT SUSP FRM RR C/MBR (PART OF 1) (8.900)
15894408 CROSSMEMBER, TRANS SUPT (PART OF 1)
11516382 ГАЙКА, HFH LK M14X2X15, 28 OD 10 7111M (PART OF 1) [ГАЙКА М10]
11517236 BOLT ASSEMBLY - METRIC HX HD AND CONICAL ПРУЖИНА WASHER, M12X1.75X135 - 18MM SOCKET (PART OF 1)
15790389 FRAME, FRT HALF (INCLS 3-4, 7, 10, 12) (SERVICE KIT W/SECTIONING INSTRUCTIONS)
15791866 BRACKET KIT, FRT BPR IMP BAR (INCLS 7, 8) (INCLS SPACER, BOLTS, NUT) [КОМПЛЕКТ КРОНШТЕЙНА-СИЛОВОГО ЭЛЕМЕНТА ПЕРЕДН Б-ПЕРА]
(TC07-949) - 2007 CK1(06-36) АМОРТИЗАТОР/ПЕРЕДНЯЯ СТОЙКА & ПРУЖИНА (REAL-TIME DAMPING Z55)
15132801 ПРУЖИНА, FRT
15139801 ПРУЖИНА, FRT
15801393 ПРУЖИНА, FRT
15801396 ПРУЖИНА, FRT
15815629 ПРУЖИНА, FRT
15815630 ПРУЖИНА, FRT
15815634 ПРУЖИНА, FRT
15815635 ПРУЖИНА, FRT [ПРУЖИНА ПОДВЕСКИ]
15829621 ПРУЖИНА, FRT
15839350 ПРУЖИНА, FRT
15839353 ПРУЖИНА, FRT
15839361 ПРУЖИНА, FRT
15905442 ПРУЖИНА, FRT
15905445 ПРУЖИНА, FRT
15911936 ПРУЖИНА, FRT
15911940 ПРУЖИНА, FRT
15911941 ПРУЖИНА, FRT
15911942 ПРУЖИНА, FRT
15911943 ПРУЖИНА, FRT
25871192 ПРУЖИНА, FRT
25871197 ПРУЖИНА, FRT
25876851 ПРУЖИНА, FRT
15815517 ГАЙКА, S/ABS CONT ACTR VLV
11561435 ГАЙКА, FRT SUSP STRUT (M10X1.5X20) (PREV TORQ) (8.917) [ГАЙКА]
15815519 ГАЙКА, FRT SUSP STRUT (M12X1.75X23.5) (FLG HEX HD) [ГАЙКА М12]
15840282 MOUNT, FRT SUSP STRUT
25940743 MOUNT, FRT SUSP STRUT [ОПОРА АМОРТИЗАТОРА]
15803177 SEAT, FRT SPR UPR
15815521 SEAT, FRT SPR UPR [СЕДЛО ОПОРЫ АМОРТИЗАТОРА]
15886466 REINFORCEMENT, FRT SUSP STRUT MT [ВТУЛКА АМОРТИЗАТОРА]
15815516 BUMPER, FRT SUSP STRUT
15840286 BUMPER, FRT SUSP STRUT (GREEN)
15846888 BUMPER, FRT SUSP STRUT (BLUE)
15886463 BUMPER, FRT SUSP STRUT
15903334 BUMPER, FRT SUSP STRUT (RED)
15840291 INSULATOR, FRT SPR UPR (UPPER ISO W/DUST BOOT) [ЗАЩИТНЫЙ КОЖУХ АМОРТИЗАТОРА]
15846889 АМОРТИЗАТОР, FRT SHK (ACDelco #540-238)
teamcadillac.ru
15903303 АМОРТИЗАТОР, FRT SHK (ACDelco #540-256) [АМОРТИЗАТОР ПЕРЕДНИЙ, А/М C TRUCK 4 Л]
15903315 АМОРТИЗАТОР, FRT SHK (ACDelco #540-305)
15903323 АМОРТИЗАТОР, FRT SHK (ACDelco #540-257)
19209555 АМОРТИЗАТОР, FRT SHK (ACDelco #580-375) [АМОРТИЗАТОР ПЕРЕДНИЙ, А/М C TRUCK 4 Л]
20765177 АМОРТИЗАТОР, FRT SHK
20810269 АМОРТИЗАТОР, FRT SHK (ACDelco #580-372)
25845441 АМОРТИЗАТОР, FRT SHK (ACDelco #580-300)
25845444 АМОРТИЗАТОР, FRT SHK (ACDelco #580-302) [АМОРТИЗАТОР ПЕРЕДНИЙ, А/М C TRUCK 4 Л]
25852146 АМОРТИЗАТОР, FRT SHK (ACDelco #540-290)
25871207 АМОРТИЗАТОР, FRT SHK (ACDelco #540-470) [АМОРТИЗАТОР ПЕРЕДНИЙ, А/М C TRUCK 4 Л]
25871215 АМОРТИЗАТОР, FRT SHK (ACDelco #540-506) [АМОРТИЗАТОР ПЕРЕДНИЙ, А/М C TRUCK 4 Л]
25871217 АМОРТИЗАТОР, FRT SHK (ACDelco #540-460) [АМОРТИЗАТОР ПЕРЕДНИЙ, А/М C TRUCK 4 Л]
25871236 АМОРТИЗАТОР, FRT SHK (ACDelco #540-424) [АМОРТИЗАТОР ПЕРЕДНИЙ, А/М C TRUCK 4 Л]
25876832 АМОРТИЗАТОР, FRT SHK (ACDelco #540-496) [АМОРТИЗАТОР ПЕРЕДНИЙ, А/М C TRUCK 4 Л]
25876834 АМОРТИЗАТОР, FRT SHK (ACDelco #540-508) [АМОРТИЗАТОР ПЕРЕДНИЙ, А/М C TRUCK 4 Л]
25876873 АМОРТИЗАТОР, FRT SHK [АМОРТИЗАТОР ПЕРЕДНИЙ, А/М C TRUCK 4 Л]
25876876 АМОРТИЗАТОР, FRT SHK (ACDelco #540-472)
25888674 АМОРТИЗАТОР, FRT SHK (ACDelco #580-311)
25888676 АМОРТИЗАТОР, FRT SHK (ACDelco #580-313)
25888677 АМОРТИЗАТОР, FRT SHK (ACDelco #580-314) [АМОРТИЗАТОР ПЕРЕДНИЙ, А/М C TRUCK 4 Л]
25888682 АМОРТИЗАТОР, FRT SHK (ACDelco #580-319)
08 - КУЗОВНЫЕ ДЕТАЛИ ПЕРДНЯЯ ЧАСТЬ - ПОДОГРЕВАТЕЛЬ - ОБСЛУЖИВАНИЕ
(GM08-009) - 2007-2009 CK1,2,3 PAINT/TOUCH-UP
01050015 PAINT, TOUCH-UP TUBE (.5 OZ) (OLYMPIC WHITE) (WA 8624)
01052907 PAINT, TOUCH-UP TUBE (.5 OZ) (BLACK) (WA 8555)
12345116 PAINT, TOUCH-UP TUBE (.5 OZ) (PRIMER, FILLER SCRATCH) (GRAY)
12345118 PAINT, TOUCH-UP TUBE (.5 OZ) (CLEAR TOP COAT)
12345538 PAINT, TOUCH-UP TUBE (.5 OZ) (VICTORY RED) (WA 9260)
12346575 PAINT, TOUCH-UP TUBE (.5 OZ) (DARK MING BLUE MET) (WA 722J)
12346585 PAINT, TOUCH-UP TUBE (.5 OZ) (WHITE DIAMOND PEARL) (WA 800J)
12346661 PAINT, TOUCH-UP TUBE (.5 OZ) (SPORT RED MET) (WA 817K)
12346701 PAINT, TOUCH-UP TUBE (.5 OZ) (FINE SILVER BIRCH MET) (WA 926L)
12346711 PAINT, TOUCH-UP TUBE (.5 OZ) (STEALTH GRAY MET) (WA 928L)
12346721 PAINT, TOUCH-UP TUBE (.5 OZ) (SUNBURST ORANGE MET II) (WA 913L)
12346779 PAINT, TOUCH-UP TUBE (.5 OZ) (BERMUDA BLUE MET) (WA 214M)
12346781 PAINT, TOUCH-UP TUBE (.5 OZ) (GRAYSTONE MET) (WA 213M)
12346909 PAINT, TOUCH-UP TUBE (.5 OZ) (GOLD MIST MET) (WA 316N)
12346911 PAINT, TOUCH-UP TUBE (.5 OZ) (ANTIQUE BRONZE MET) (WA 317N)
12346917 PAINT, TOUCH-UP TUBE (.5 OZ) (RED JEWEL T/COAT) (WA 301N)
88860753 PAINT, TOUCH-UP TUBE (.5 OZ) (SONOMA JEWEL MET) (WA 412P)
88860755 PAINT, TOUCH-UP TUBE (.5 OZ) (COCOA MET) (WA 414P)
88860795 PAINT, TOUCH-UP TUBE (.5 OZ) (DARK BRAHMA JEWEL MET) (WA 519Q)
88860811 PAINT, TOUCH-UP TUBE (.5 OZ) (INK SLATE MET) (WA 503Q)
12345117 PAINT, TOUCH-UP SPRAY (5 OZ) (PRIMER, FILLER, SCRATCH)
12345119 PAINT, TOUCH-UP SPRAY (5 OZ) (CLEAR TOP COAT)
12345155 PAINT, TOUCH-UP SPRAY (5 OZ) (BLACK) (WA 8555)
12345205 PAINT, TOUCH-UP SPRAY (5 OZ) (OLYMPIC WHITE) (WA 8624)
12345539 PAINT, TOUCH-UP SPRAY (5 OZ) (VICTORY RED) (WA 9260)
12346576 PAINT, TOUCH-UP SPRAY (5 OZ) (DARK MING BLUE MET) (WA 722J)
12346586 PAINT, TOUCH-UP SPRAY (5 OZ) (WHITE DIAMOND PEARL) (WA 800J)
12346662 PAINT, TOUCH-UP SPRAY (5 OZ) (SPORT RED MET) (WA 817K)
12346702 PAINT, TOUCH-UP SPRAY (5 OZ) (FINE SILVER BIRCH MET) (WA 926L)
12346712 PAINT, TOUCH-UP SPRAY (5 OZ) (STEALTH GRAY MET) (WA 928L)
12346722 PAINT, TOUCH-UP SPRAY (5 OZ) (SUNBURST ORANGE MET II) (WA 913L)
12346780 PAINT, TOUCH-UP SPRAY (5 OZ) (BERMUDA BLUE MET) (WA 214M)
12346782 PAINT, TOUCH-UP SPRAY (5 OZ) (GRAYSTONE MET) (WA 213M)
12346910 PAINT, TOUCH-UP SPRAY (5 OZ) (GOLD MIST MET) (WA 316N)
12346912 PAINT, TOUCH-UP SPRAY (5 OZ) (ANTIQUE BRONZE MET) (WA 317N)
12346918 PAINT, TOUCH-UP SPRAY (5 OZ) (RED JEWEL T/COAT) (WA 301N)
teamcadillac.ru
88860754 PAINT, TOUCH-UP SPRAY (5 OZ) (SONOMA JEWEL MET) (WA 412P)
88860756 PAINT, TOUCH-UP SPRAY (5 OZ) (COCOA MET) (WA 414P)
88860796 PAINT, TOUCH-UP SPRAY (5 OZ) (DARK BRAHMA JEWEL MET) (WA 519Q)
88860812 PAINT, TOUCH-UP SPRAY (5 OZ) (INK SLATE MET) (WA 503Q)
(TC08-905) - 2007-2008 CK1(06-36) КРЫЛО & КОЛЕСНАЯ КОРОБКА ПЕРЕДНЯЯ (CADILLAC Z75)
25815065 BRACE, F/END SH MET DIAG
11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (F/END SH MET DIAG BR) [БОЛТ М6]
11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (F/FDR RR UPR BR) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16]
15185449 BRACE, F/FDR RR UPR
15185450 BRACE, F/FDR RR UPR
11610010 БОЛТ, HEX W/ CON WA, M8X1.25X40, 32 THD, 28 OD, 9.8, 7114M, MACH, P-PT (F/FDR INR PNL) [ВИНТ]
15870422 BRACKET, F/FDR UPR [КРОНШТЕЙН КРЫЛА]
15951192 BRACKET, F/FDR UPR [КРОНШТЕЙН]
11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (F/FDR UPR BRKT) (ACDelco #11570082) [БОЛТ М8]
15887400 BRACKET, КАПОТ HGE LWR (PART OF 9)
15887401 BRACKET, КАПОТ HGE LWR (PART OF 9)
25819534 КРЫЛО, FRT (INCLS 8) [ПЕРЕДНЕЕ КРЫЛО]
25819535 КРЫЛО, FRT (INCLS 8) [ПЕРЕДНЕЕ КРЫЛО]
25819548 КРЫЛО, FRT (INCLS 8) [КРЫЛО]
25819549 КРЫЛО, FRT (INCLS 8)
11516149 ГАЙКА, U, 8X1.25, MULTI THD, .08'-4.0' THK PNL, PZ (F/FDR RR UPR BRKT) [ГАЙКА М8]
15860253 INSERT, F/FDR CTR RR UPR MLDG [ВСТАВКА КРЫЛА]
15860254 INSERT, F/FDR CTR RR UPR MLDG [ВСТАВКА]
11562187 NUT-U, M8X1.25, SAE 1050 STL, GMW3179-A (F/FDR RR CTR BRKT)
25948814 BRACKET, FRT BPR FASCIA SI (INCLS 14) [НАПРАВЛЯЮЩАЯ ПЕРЕДНЕГО БАМПЕРА]
25948815 BRACKET, FRT BPR FASCIA SI (INCLS 14) [ОПОРНАЯ ПЛАНКА ПАНЕЛИ БАМПЕРА]
11518531 ГАЙКА, U-TYPE, M4.2X1.41, 15.9X8.4, .7-2.1 PNL, SAE 1050 STL, 7111M, 8.65 SQ HOL (PART OF 13) (10.512) [ГАЙКА М10]
11517164 SCREW, HEX M8X1.25X20 W/CON WA (F/FDR LWR)
11589292 PUSH PIN, FITS 8.5 DIA HOLE IN 2-4.5 THK PNL, NYLON 6/6 GMP.PA66.015 (FRT W/H LNR (PUSH IN)) [ФИКСАТОР ПАНЕЛИ БАМПЕРА]
11609952 NUT-U, M4.2X1.41, 15.9X8.4, .7-2.1 PNL, SAE 1050 STL, 7111M, 8.65 SQ HOL (FRT W/H LNR)
11562172 БОЛТ, FRT W/H LNR [БОЛТ М8]
11609489 БОЛТ, HEX W/ WASHER, 4.2X1.41X25, 14.5 THD17 OD, GM6010M STL, GMW4205 (FRT BPR FASCIA OTR BRKT) [БОЛТ М4.2]
11519949 RETAINER, FRT W/H LNR (PUSH IN) (20MM DIA X 13.4MM) (PUSH PIN & GROMMET) (10.154) [КРОНШТЕЙН В СБОРЕ]
11562024 RETAINER, PUSH IN, 7.5X36.5, FITS 6.35 HOLE IN 2.29-18.34 THK PNL (FRT W/H LNR (PUSH IN)) [ФИКСАТОР ПАНЕЛИ БАМПЕРА]
teamcadillac.ru
15926174 LINER, FRT W/H [ПОДКРЫЛОК]
25826685 INSULATOR, COWL S/PNL
25877094 INSULATOR, COWL S/PNL
11516150 ГАЙКА, U, M8X1.25X32.0, 6H STYLE 11, STL, PZOR (F/FDR LWR) [ГАЙКА М8Х1.25]
15862261 BRACKET, FRT W/H PNL UPR
15926175 LINER, FRT W/H [ПОДКРЫЛОК]
11519360 ГАЙКА, U, W/PLASTISOL, M8X1.25, 35.8X25, 21 C/E, 2.5-5 PNL, 1050, 6173M (F/FDR LWR)
15893710 SHIELD, ENG LWR FRT SPH
15893711 SHIELD, ENG LWR FRT SPH
11517560 SCREW, FLAT WA (NRW) AND HX WA HD, M8X1.25X25 (ENG LWR FRT SPH SHLD)
(TC08-906) - 2007 CK107(06) ДОМКРАТ И ИНСТРУМЕНТ СКЛАДЫВАНИЯ
25887192 RETAINER, TOOL STOW
15854611 TOOL KIT, (INCLS 3-5)
15854614 РУЧКА, ДОМКРАТА WRENCH (PART OF 2) [РУКОЯТКА ДОМКРАТА]
15295860 EXTENSION, JK HDL (PART OF 2) (406MM) (NON FLEXIBLE SHAFT) [УДЛИНИТЕЛЬ РУЧКИ ДОМКРАТА]
15101404 HANDLE, JK (PART OF 2) (508.0MM LG) [УДЛИНИТЕЛЬ РУЧКИ ДОМКРАТА]
15547900 BLOCK, WHL
teamcadillac.ru
15772593 ГАЙКА, WHL BLK (6MM) [ГАЙКА М6]
10382641 BRACKET, JK STOW (BOTTOM BRKT INCLS STUDS)
15788798 ДОМКРАТ, (INCLS 12) [РЫЧАГ В СБОРЕ]
15110160 LABEL, JK WRNG (PART OF 11)
(TC08-907) - 2007 CK1,2(06) ШЛАНГИ И ТРУБКИ /ОБОГРЕВАТЕЛЬ
15050765 CLIP, HTR HOSE (PART OF 3) (73.0MM WIDE)
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (ENG WRG HARN RET) [ГАЙКА М6]
15778415 BRACKET, HTR HOSE CLIP (INCLS 1)
15834773 HOSE, RAD SURGE TK OTLT (INCLS 4, 5)
15012561 CLAMP, HOSE SPR, 27 NOM, 25.2 MIN-28.9 MAX, 15MM WIDE, BLACK (RAD SURGE TK OTLT HOSE) (8.948)
11517136 CLAMP, HOSE SPR, 27 NOM, 25.2 MIN-28.9 MAX, 15MM WIDE, BLACK (RAD SURGE TK OTLT HOSE)
11517133 CLAMP, ПРУЖИНА, 22-26MM, 24 NOM., BLK (PART OF 10) [ХОМУТ ТРУБОПРОВОДА]
15854958 HOSE, HTR INL (INCLS 9, 11)
teamcadillac.ru
(TC08-909) - 2007 CK1,2(06-36) ПОРОГ (MOLDED BLACK BVE)
11609733 БОЛТ, HEX W/CON WA, M8X1.25X30, 20 THD, 24 OD, 10.9, GMW4205, MAT POINT (ASST STEP) [БОЛТ М8]
15203597 BRACKET, ASST STEP
11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (ASST STEP) [ГАЙКА]
15291807 EXTENSION, ASST STEP FRT
15291808 EXTENSION, ASST STEP FRT
11609997 БОЛТ, ASST STEP FRT EXTN [ВИНТ]
11519742 БОЛТ, WASHER, M8X1.25X40, 33.4 THD, 39 OD, 9.8, 7114M, 2.5-3.5 THK FL WA (ASST STEP) [БОЛТ]
(TC08-910) - 2007-2009 CK1(06-36) ПОРОГ (CHROME INSERT BVU)
15914678 STEP, ASST [КОМПЛЕКТ ГАЕК КОЛЕСА (4 ШТ)]
15914679 STEP, ASST [ПАНЕЛЬ ПОРОГА КУЗОВА]
15914684 INSERT, ASST STEP (REAR) [ОКАНТОВКА ПОДНОЖКИ]
15914685 INSERT, ASST STEP (REAR) [МОЛДИНГ ПОРОГА КУЗОВА]
15914682 INSERT, ASST STEP (FRT) [ВСТАВКА ПОДНОЖКИ КУЗОВА]
15914683 INSERT, ASST STEP (FRT) [ХРОМИРОВАННАЯ ВСТАВКА]
15291811 EXTENSION, ASST STEP FRT [ПАНЕЛЬ ПОРОГА КУЗОВА РАСШИРИТЕЛЬНАЯ]
15291812 EXTENSION, ASST STEP FRT [ПАНЕЛЬ ПОРОГА КУЗОКА РАСШИРИТЕЛЬНАЯ]
teamcadillac.ru
25694574 RETAINER, ASST STEP FRT EXTN (PUSH IN) (10.695)
(TC08-911) - 2007-2008 CK1(06-36) ПОРОГ (POWER RETRACTABLE BRS)
15806407 BRACKET, ASST STEP (BRKT USED ON RR END OF ASSIST STEP)
15806409 BRACKET, ASST STEP (BRKT USED ON RR END OF ASSIST STEP)
15806412 PAD, ASST STEP [НАКЛАДКА ПОРОГА КУЗОВА]
15806401 COVER, ASST STEP FIN (INCLS 5) (INCLS INSERT) [БОКОВАЯ ПОДНОЖКА КУЗОВА]
15806402 COVER, ASST STEP FIN (INCLS 5) (INCLS INSERT) [ПОРОГ КУЗОВА]
15224062 STEP, ASST
15872198 БОЛТ, ASST STEP FIN CVR
15871287 BRACKET, ASST STEP CTR (INCLS 20) [КРОНШТЕЙН ПОРОГА КУЗОВА]
15871288 BRACKET, ASST STEP CTR (INCLS 20)
teamcadillac.ru
15932167 SHIELD, ASST STEP (FRT)
15932168 SHIELD, ASST STEP (FRT)
11570190 БОЛТ, ASST STEP SHLD [БОЛТ М]
11569755 BOLT- HEX W/CON WA, M8X1.25X20, 10 THD, 24 OD, 8.8, GMW4205, M-PT (ASST STEP) [БОЛТ М8]
25971282 MOTOR, ASST STEP (INCLS 12)
25971283 MOTOR, ASST STEP (INCLS 12) [ЭЛ.ДВИГАТЕЛЬ БОКОВОЙ ПОДНОЖКИ КУЗОВА, 60ВТ]
11570190 БОЛТ, ASST STEP BRKT [БОЛТ М]
15872197 БОЛТ, ASST STEP BRKT
15932169 SHIELD, ASST STEP (RR)
15932170 SHIELD, ASST STEP (RR)
03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (ASST STEP)
15224078 BRACKET, ASST STEP (BRKT USED ON FRT END OF ASSIST STEP CONTAINING MOTOR)
20784793 BRACKET, ASST STEP (USED IN ASM W/MOTOR) [КРОНШТЕЙН ПОРОГА КУЗОВА]
11513599 ГАЙКА, U-TYPE, M4.2X1.41, 0.65-3.80 PNL THK, PZ (ASST STEP BRKT) (ACDelco #11513599)
25852622 MODULE, ASST STEP CONT [МОДУЛЬ КОНТРОЛЯ ЗАПАСНОЙ СТУПЕНЬКИ]
11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (ASST STEP) [ВИНТ М4]
25806034 HARNESS, ASST STEP MOTOR WRG
(TC08-912) - 2007-2009 CK1,2(06) ПАСПОРТНЫЕ ТАБЛИЧКИ И ДЕКАЛИ
15107130 LABEL, L/GATE WRNG
15787311 LABEL, FUEL RECOMMENDATION
12451193 LABEL, CHILD SECURITY LK OPERG INSTR
10443718 LABEL, ODOM SERV INFO (75MM X 55MM) (FOR USE WHEN ODOMETER OR CLUSTER IS SERVICED.)
19206430 LABEL KIT, VEH CAPACITY WT & ШИНА INFO (ENGLISH ONLY LABEL FOR US) (QTY 10 PER KIT)
teamcadillac.ru
19206431 LABEL KIT, VEH CAPACITY WT & ШИНА INFO (ENGLISH W/FRENCH-CANADIAN LABEL FOR CANADA) (QTY 10 PER KIT)
19206432 LABEL KIT, VEH CAPACITY WT & ШИНА INFO (SPANISH LABEL FOR MEXICO) (QTY 10 PER KIT)
15070503 LABEL, MERCURY DISPOSAL INFO
15839682 LABEL, FUSE BLK IDENT
15772975 LABEL, FRT TORS BAR ADJ WRNG
12567697 LABEL, ALL WHL DRV CAUTION
10309116 LABEL, FAN BLADE WRNG (BLACK NYLON)
19180225 LABEL, VEH EMIS CONT INFO (VIN MUST BE SUPPLIED WITH ORDER)
15061343 LABEL, O/S RR VIEW MIR INFO (RH SIDE ONLY) (FRENCH)
15114992 LABEL, INFL RST SYS WRNG (ENGLISH/ARABIC)
10324485 LABEL, ROADSIDE SERV INFO
15053409 LABEL, A/C REFRIG & BAT & FAN BLADE & RAD FIL CAP CAUTION
15204281 LABEL, BAT WRNG (INCLUDES SYMBOLS ONLY)
(TC08-914) - 2007-2009 CK1(06-36) ПОРОГ (TUBULAR BLACK BVV)
25831407 COVER, ASST STEP FIN (*KIT1)
25831408 COVER, ASST STEP FIN (*KIT1)
25804636 PAD, ASST STEP (*KIT1)
25804637 PAD, ASST STEP (*KIT1)
25804632 STEP, ASST (EXCLS COVER, BRKT, PAD, & INSULATOR) (*KIT1)
25804633 STEP, ASST (EXCLS COVER, BRKT, PAD, & INSULATOR) (*KIT1)
11519742 БОЛТ, WASHER, M8X1.25X40, 33.4 THD, 39 OD, 9.8, 7114M, 2.5-3.5 THK FL WA (ASST STEP) (*KIT1) [БОЛТ]
teamcadillac.ru
25816111 EXTENSION, ASST STEP FRT
25816112 EXTENSION, ASST STEP FRT
15929675 COVER, ASST STEP FIN (FRT) (*KIT1)
15929677 COVER, ASST STEP FIN (FRT) (*KIT1)
11516807 RIVET, POP, 4.8 DIA, 19.9 LONG, 16 OD, 5-5.25 HOLE, 1-9 GRIP RANGE, AL, BLACK (ASST STEP) [ЗАКЛЕПКА 4.8 ММ]
25806735 BRACKET, ASST STEP (*KIT1)
25831411 BRACKET, ASST STEP (*KIT1)
25821809 BRACKET, ASST STEP RR (INCLS 13)
25821810 BRACKET, ASST STEP RR (INCLS 13)
11515638 ГАЙКА, U-TYPE, M4.2X1.41X10.5.5X22, .65-3.8 PNL THK, 1050, ZF (PART OF 12) [ГАЙКА М4.2]
25804640 INSULATOR, ASST STEP RR SUPT (*KIT1)
25804641 INSULATOR, ASST STEP RR SUPT (*KIT1)
25804642 INSULATOR, ASST STEP FRT SUPT (*KIT1)
25804643 INSULATOR, ASST STEP FRT SUPT (*KIT1)
25831388 STEP, ASST (INCLS 1-4, 6, 9, 14, 15) (INCLS COVER, BRKT, PAD, & INSULATOR)
25831389 STEP, ASST (INCLS 1-4, 6, 9, 14, 15) (INCLS COVER, BRKT, PAD, & INSULATOR)
(TC08-934) - 2007-2008 CK1(06-36) КАПОТ (CADILLAC Z75)
15945915 HOOD, (INCLS 30) [КАПОТ]
11609797 БОЛТ, AIR INL GRL PNL (10.268)
15048061 RETAINER, AIR INL GRL PNL (PART OF 9) (PUSH IN)
25820729 PANEL, AIR INL GRL (INCLS 6) (BLACK) [НАКЛАДКА ВОДОСТОЧНОЙ ПАНЕЛИ]
25820730 PANEL, AIR INL GRL (INCLS 6) (BLACK) [НАКЛАДКА ВОДОСТОЧНОЙ ПАНЕЛИ]
teamcadillac.ru
11609796 CLIP, AIR INL GRL PNL (PART OF 5) (11.0 X 12.9 X 6.1MM) (8.950)
15999788 RETAINER, AIR INL GRL PNL (U-SHAPED/CLIP)
25887976 HOSE, WSWA NOZ (PART OF 9) [ШЛАНГ СТЕКЛООМЫВАТЕЛЯ]
25872303 PANEL, AIR INL GRL (CTR) (INCLS 3, 4, 8) (BLACK)
15894378 CABLE, КАПОТ PRIM LAT REL (INCLS PULL HANDLE) [КАБЕЛЬ]
11516780 ГАЙКА, HEX W/CON WA, M8X1.25, 10THK, 19 O.D., 10, 7111M (HOOD PRIM LAT REL CBL) (8.917) [ГАЙКА М8]
25870070 ПРУЖИНА, КАПОТ OPEN ASST
25870071 ПРУЖИНА, КАПОТ OPEN ASST
11569992 БОЛТ, КАПОТ OPEN ASST SPR
15054178 БОЛТ, HFH, W/SHOULDER, M8X1.25X23, 18 O.D., 9.8, GM6280M (HOOD OPEN ASST SPR)
15887400 BRACKET, КАПОТ HGE LWR (PART OF 19)
15887401 BRACKET, КАПОТ HGE LWR (PART OF 19)
25819534 КРЫЛО, FRT (INCLS 18) (СМ. ГРУППУ 08.000 "КРЫЛО & КОЛЕСНАЯ КОРОБКА ПЕРЕДНЯЯ" FOR DETAILED ILLUSTARTED VIEW) [ПЕРЕДНЕЕ КРЫЛО]
25819535 КРЫЛО, FRT (INCLS 18) (СМ. ГРУППУ 08.000 "КРЫЛО & КОЛЕСНАЯ КОРОБКА ПЕРЕДНЯЯ" FOR DETAILED ILLUSTARTED VIEW) [ПЕРЕДНЕЕ КРЫЛО]
25819548 КРЫЛО, FRT (INCLS 18) (СМ. ГРУППУ 08.000 "КРЫЛО & КОЛЕСНАЯ КОРОБКА ПЕРЕДНЯЯ" FOR DETAILED ILLUSTARTED VIEW) [КРЫЛО]
25819549 КРЫЛО, FRT (INCLS 18) (СМ. ГРУППУ 08.000 "КРЫЛО & КОЛЕСНАЯ КОРОБКА ПЕРЕДНЯЯ" FOR DETAILED ILLUSTARTED VIEW)
10150076 CLIP, КАПОТ PRIM LAT REL CBL (18.8 MM DIA) (ROUND CLIP) (3.425)
11589039 БОЛТ, HEX, W/CON WA, M6X1X30, 20 THD, 24 O.D., 9.8, GMW4205 (HOOD PRIM LAT) [БОЛТ М6Х1Х30]
25816903 LATCH, КАПОТ PRIM (W/O SWITCH)
25816904 LATCH, КАПОТ PRIM (W/SWITCH)
25790320 BUMPER, КАПОТ ADJ FRT
15250133 BUMPER, КАПОТ SI
25876305 STRUT, HOOD
20064875 RETAINER, PUSH-IN, 20.5MMLG, 42.76MM 1.68HD DIA, PLASTIC (HOOD INSL) [КЛИПСА ШУМОИЗОЛЯЦИИ КАПОТА]
15828996 INSULATOR, HOOD
15907251 MOLDING, КАПОТ FRT (INCLS 29) [МОЛДИНГ КАПОТА]
11561788 CLIP-U, 13X15X12, 1.5 PNL, 1050, 6280M (PART OF 28) [ФИКСАТОР МОЛДИНГА КАПОТА]
15859618 BRACKET, КАПОТ STRUT (HOOD SI) (PART OF 1)
11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (HOOD HGE) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16]
15942145 HINGE, HOOD [ПЕТЛЯ КАПОТА]
15942146 HINGE, HOOD [ПЕТЛЯ КАПОТА]
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BODY STATIC GND STRP) [ГАЙКА М6]
(TC09-700) - 2007-2009 CK1,2(06) ШЛАНГИ И ТРУБКИ /ВСПОМОГАТЕЛЬНЫЙ ОБОГРЕВАТЕЛЬ
15827283 HOSE, AUX A/C EVPR & AUX HTR (INCLS 2, 4, 6, 9-13) (KENT-MORE TUBING REPAIR KIT J41425 REQ'D FOR INSTALLATION) (9.225) (ACDelco #15-33439) [КОМПЛЕКТ ТРУБОК ТОПЛИВНОЙ СИСТЕМЫ(4 ШТ)]
15102168 CLIP, AUX A/C EVPR HOSE (PART OF 1) (2X2 PLASTIC) (SLOT ON SIDE WITH DIAMETERS OF 19.05, 9.52, AND 2 AT 12.7MM)
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (AUX A/C EVPR & CMPR HOSE CLIP) [ГАЙКА М6]
15102169 CLIP, AUX A/C EVPR HOSE (PART OF 1) (SLOT IN MIDDLE WITH DIAMETERS OF 19.05, 9.52, AND 2 AT 12.7MM)
11514596 ГАЙКА, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (AUX A/C EVPR TUBE) (8.915) (ACDelco #11514596)
02724966 SEAL, A/C CMPR & CNDSR HOSE (25MM OD X 17MM ID, 3/4IN DIA) (PART OF 1) (FOR NON-CANADIAN ORDERS) (ACDelco #15-31101)
15200864 HOSE, A/C ACCUM (СМ. ГРУППУ 09.000 "A/C СИСТЕМА ОХЛАЖДЕНИЯ/FRONT" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #15-33409)
25896467 TUBE, A/C EVPR (СМ. ГРУППУ 09.000 "A/C СИСТЕМА ОХЛАЖДЕНИЯ/FRONT" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #15-33413) [ШЛАНГ]
15055343 TEE, AUX HTR INL HOSE (PART OF 1) (NATURAL) (111MM LONG) [ФИТИНГ ШЛАНГА СТЕКЛООМЫВАТЕЛЯ]
15055342 TEE, AUX HTR INL HOSE (PART OF 1) (BLACK) (113MM LONG)
teamcadillac.ru
52474373 SEAL, A/C EVPR TUBE (PART OF 1) (METAL/RUBBER) (19MM OD X 11MM ID, 1/2 IN DIA) (ACDelco #15-31055) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО СОЕДИНЕНИЯ МАГИСТРАЛЕЙ СИСТ.]
19130031 RETAINER KIT, AUX HTR INL & OTLT HOSE CONN (INCLS 13) (PART OF 1) (INCL RETAINER, SEAL, SPACER, INSTRUCTION)
09 - ВНУТРЕННЕЕ ОБОРУДОВАНИЕ - КОНДИЦИОНЕР - АУДИОСИСТЕМА
(GM09-046) - 2007-2008 CK1,2,3 КОМПРЕССОР КОНДИЦИОНЕРА ASM (LY6/6.0K,L76/6.0Y,L92/6.2-8)
89024905 КОМПРЕССОР, A/C (INCLS 2-10) (ACDelco #89024905) [КОМПРЕССОР КОНДИЦИОНЕРА 2.3 КВТ]
11561365 БОЛТ, A/C CMPR PUL (PART OF 1) (*KIT1)
12476085 CLUTCH KIT, A/C (4 SPLINED, DENSO) (INCLS 2-10) (INCL PULLEY) (LOW MOUNT) (ACDelco #15-4709)
(TC09-675) - 2007-2009 CK1,2(06) КОНДИЦИОНЕР И НАГРЕВАТЕЛЬ В СБОРЕ (MANUAL TEMPERATURE CONTROL CJ3)
89018299 CASE, HTR
11609829 БОЛТ, A/C EVPR TUBE CLIP (4.2X2.25X16) (9.786)
89018297 CORE, HTR (INCLS 2 SEALS) (ACDelco #15-62960)
89018365 ACTUATOR, TEMP VLV (ACDelco #15-72971) [АКТУАТОР]
89018304 VALVE, DEFR (PART OF 32) (ACDelco #15-50561)
52474960 LEVER, MODE VLV
89018304 VALVE, DEFR (ACDelco #15-50561)
89018307 VALVE, TEMP [КЛАПАН]
89018302 SHIELD, HTR & A/C EVPR & BLO MDL HT
89018306 VALVE, TEMP
15780382 HARNESS, A/C MDL WRG
15780376 CASE, HTR & A/C EVPR & BLO LWR
15141283 MODULE, BLO MOT CONT (ACDelco #15-80863) [РЕЗИСТОР 15 ВТ]
89018296 EVAPORATOR, A/C (ACDelco #89018296) [ОСУШИТЕЛЬ, КОНДИЦИОНЕР]
89018295 SEAL, A/C EVPR
89018365 ACTUATOR, AIR INL VLV (ACDelco #15-72971) [АКТУАТОР]
89018304 VALVE, DEFR (PART OF 26) (ACDelco #15-50561)
15780375 INLET, AIR (INCLS 25) (INCLS DOOR & SEALS)
89018612 STUD, HTR & A/C EVPR & BLO MDL (M6X1X33MM TORX/COLR)
teamcadillac.ru
89018295 SEAL, A/C EVPR (*KIT3)
15780377 CASE, HTR & A/C EVPR & BLO UPR (INCLS 7)
89018374 ACTUATOR, MODE CONT CAM (INCLS 9, 10) (ACDelco #15-73952) [СТАРТЕР В СБОРЕ]
20760618 MOTOR, BLO (INCLS 19-21) (9.215) (ACDelco #15-81644)
89018784 SEAL KIT, HTR & A/C EVPR & BLO MDL (INCLS 5, 27, 29-31, 33, 34) [УПЛОТНЕНИЕ ОТОПИТЕЛЯ]
(TC09-676) - 2007-2009 CK1,2,3(06-43-53) КОНДИЦИОНЕР И НАГРЕВАТЕЛЬ В СБОРЕ (AUTO TEMPERATURE CONTROL CJ2)
89018299 CASE, HTR
11609829 БОЛТ, A/C EVPR TUBE CLIP (PART OF 3) (4.2X2.25X16) (9.786)
89018297 CORE, HTR (INCLS 2) (INCLS 2 SEALS) (ACDelco #15-62960)
89018365 ACTUATOR, AIR INL VLV (*KIT1) (ACDelco #15-72971) [АКТУАТОР]
teamcadillac.ru
15780378 HARNESS, A/C MDL WRG
20760618 MOTOR, BLO (*KIT2) (9.215) (ACDelco #15-81644)
(TC09-700) - 2007-2009 CK1,2(06) СИСТЕМА ОХЛАЖДЕНИЯ КОНДИЦИОНЕРА/ЗАДНИЙ
15827283 HOSE, AUX A/C EVPR & AUX HTR (INCLS 2, 4, 9-13) (KENT-MORE TUBING REPAIR KIT J41425 REQ'D FOR INSTALLATION) (ACDelco #15-33439) [КОМПЛЕКТ ТРУБОК ТОПЛИВНОЙ СИСТЕМЫ(4 ШТ)]
02724966 SEAL, A/C CMPR & CNDSR HOSE (PART OF 1) (FOR NON-CANADIAN ORDERS) (ACDelco #15-31101)
teamcadillac.ru
52474373 SEAL, A/C EVPR TUBE (19MM OD X 11MM ID) (PART OF 1) (METAL/RUBBER) (19MM OD X 11MM ID, 1/2 IN DIA) (ACDelco #15-31055) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО СОЕДИНЕНИЯ МАГИСТРАЛЕЙ СИСТ.]
(TC09-900) - 2007-2009 CK107(06) AUXILIARY A/C EVAPORATOR & BLOWER & HEATER ASM (C69)
15232210 CASE, AUX A/C EVPR & BLO (OUTER)
15920869 CASE, AUX A/C EVPR & BLO (OUTER)
15232221 BUSHING, A/C EVPR CASE
15798229 ACTUATOR, MODE VLV (AUX ACTUATOR ASM, ELEC) (ACDelco #15-73435) [РЫЧАГ КОРОБКИ ПЕРЕДАЧ]
11562121 БОЛТ, AUX A/C EVPR & BLO CASE
15798229 ACTUATOR, TEMP VLV (AUX ACTUATOR ASM, ELEC) (ACDelco #15-73435) [РЫЧАГ КОРОБКИ ПЕРЕДАЧ]
15232208 EVAPORATOR, AUX A/C (ACDelco #15-63347) [ИСПАРИТЕЛЬ СИСТЕМЫ ОХЛАЖДЕНИЯ]
15232224 SEAL, AUX A/C EVPR OTLT TUBE (ACDelco #15-33418)
15892073 TUBE, HTR CORE (INLET)
15798228 VALVE, AUX A/C EVPR THERMAL EXPN (ACDelco #15-50619)
11562123 БОЛТ, A/C EVPR TXV
teamcadillac.ru
15232211 CASE, AUX A/C EVPR & BLO LWR
15650071 VALVE, AUX A/C EVPR & BLO MDL DRN (ACDelco #15650071)
15235736 SEAL, AUX HTR CASE (USED ON VEHICLES W/AUX BLOWER MOTOR THAT HAS 1 ATTACHMENT SCREW, FOR 2ND DES SEE 15921035)
15921035 SEAL, AUX HTR CASE (ACDelco #15-33736) (USED ON VEHICLES W/AUX BLOWER MOT THAT HAS 3 ATTACHMENT SCREWS, FOR 1ST DES SEE 15235736)
11562120 STUD, HTR & A/C EVPR & BLO MDL (STUD-FLANGE, M6X1X25)
11562122 CLIP, A/C EVPR CASE (11X6.35) (9.215)
15798231 SEAL, HTR INL & OTLT PIPE (O/RING)
15232223 SEAL, AUX A/C EVPR INL TUBE (1/2") (ACDelco #15-33419)
15892072 PLATE, A/C EVPR INL TUBE BRKT BKG
15232215 VALVE, TEMP (USED ON VEHICLES W/AUX BLOWER MOTOR THAT HAS 1 ATTACHMENT SCREW, FOR 2ND DES SEE 15920866)
15920866 VALVE, TEMP (ACDelco #15-50766) (USED ON VEHICLES W/AUX BLOWER MOT THAT HAS 3 ATTACHMENT SCREWS, FOR 1ST DES SEE 15232215)
15798230 CLIP, HTR CORE
15232212 CORE, AUX HTR (ACDelco #15-63346)
15232209 CASE, AUX A/C EVPR & BLO (INNER) (USED ON VEHICLES W/AUX BLOWER MOTOR WITH 1 ATTACHMENT SCREW, FOR 2ND DESIGN SEE 15920868)
15920868 CASE, AUX A/C EVPR & BLO (INNER) (USED ON VEHICLES W/AUX BLOWER MOTOR THAT HAS 3 ATTACHMENT SCREWS, FOR 1ST DES SEE 15232209)
15141283 MODULE, BLO MOT CONT (INCLS 23) (ACDelco #15-80863) [РЕЗИСТОР 15 ВТ]
25811506 HARNESS, AUX HTR & A/C WRG
15232219 MOTOR, AUX BLO (ACDelco #15-80867) (USED ON VEHICLES W/AUX BLOWER MOT THAT HAS 1 ATTACHMENT SCREW, FOR 2ND DES SEE 15920865)
15920865 MOTOR, AUX BLO (ACDelco #15-81062) (USED ON VEHICLES W/AUX BLOWER MOT THAT HAS 3 ATTACHMENT SCREWS, FOR 1ST DES SEE 15232219)
15920871 OUTLET, AUX HTR AIR
15814847 SEAL, AUX A/C EVPR & BLO MDL OTLT DUCT
15232213 VALVE, MODE (ACDelco #15-50615) (USED ON VEHICLES W/AUX BLOWER MOT THAT HAS 1 ATTACHMENT SCREW, FOR 2ND DES SEE 15920867)
15920867 VALVE, MODE (ACDelco #15-50767) (USED ON VEHICLES W/AUX BLOWER MOT THAT HAS 3 ATTACHMENT SCREWS, FOR 1ST DES SEE 15232213)
15892074 TUBE, HTR CORE (OUTLET)
(TC09-903) - 2007 CK1,2(06-36) КОМПРЕССОР КОНДИЦИОНЕРА MOUNTING
12554026 BRACKET, A/C CMPR
12580196 РОЛИК НАТЯЖИТЕЛЬ, A/C CMPR BELT [НАТЯЖИТЕЛЬ ПРИВОДНОГО РЕМНЯ]
11515767 БОЛТ, HFH, M10X1.5X35, 32THD, 22.3 O.D., MACH, 10.9, 7114M (A/C CMPR BELT TENSR) (T/W 12345493) [БОЛТ]
89024882 КОМПРЕССОР KIT, A/C (8.0 OZ. OIL SERVICE COMP KIT) (ACDelco #89024882) [КОМПРЕССОР В СБОРЕ]
89024905 КОМПРЕССОР, A/C (ACDelco #89024905) [КОМПРЕССОР КОНДИЦИОНЕРА 2.3 КВТ]
teamcadillac.ru
11516109 БОЛТ, HFH, REDUCED BODY, M10X1.5X65, 25 THD, 22.3 O.D., HDR PT, 10.9, 7114M (A/C CMPR) [БОЛТ, М10Х1.5Х65.22]
11516503 BOLT-HFH, M10X1.5X45, 33 THD, P-PT, 9.8, 7114M (A/C CMPR)
(TC09-904) - 2007 CK1,2(06) A/C СИСТЕМА ОХЛАЖДЕНИЯ/FRONT
25967385 CONDENSER, A/C (INCLS 4) (ACDelco #15-63666) [КОНДЕНСАТОР СИСТЕМЫ ОХЛАЖДЕНИЯ]
11589039 БОЛТ, HEX, W/CON WA, M6X1X30, 20 THD, 24 O.D., 9.8, GMW4205 (A/C CNDSR BRKT) [БОЛТ М6Х1Х30]
15044225 INSULATOR, A/C CNDSR (LOWER) (ACDelco #15-63283) [ИЗОЛЯТОР КОНДИНЦ]
52481715 BRACKET, A/C CNDSR UPR (INLET/OUTLET) (PART OF 1) (114.5MM LONG)
52481716 BRACKET, A/C CNDSR UPR (RETURN) (PART OF 1) (114.5MM LONG)
52474373 SEAL, A/C CMPR & CNDSR HOSE (19MM OD X 11MM ID) (PART OF 7) (METAL/RUBBER) (19MM OD X 11MM ID, 1/2 IN DIA) (ACDelco #15-31055) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО СОЕДИНЕНИЯ МАГИСТРАЛЕЙ СИСТ.]
teamcadillac.ru
12477570 NUT-HFH, M8X1.25X8, 10.9 (A/C EVPR TUBE)
25896467 TUBE, A/C EVPR (INCLS 5, 8, 16-19, 21, 22) (ACDelco #15-33413) [ШЛАНГ]
15734255 CLIP, A/C EVPR TUBE (PART OF 7)
52474373 SEAL, A/C REFRIG PRESS SEN O RING (19MM OD X 11MM ID) (PART OF 11) (METAL/RUBBER) (19MM OD X 11MM ID, 1/2 IN DIA) (ACDelco #15-31055) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО СОЕДИНЕНИЯ МАГИСТРАЛЕЙ СИСТ.]
25975794 HOSE, A/C CNDSR (INCLS 10, 27-29) (ACDelco #15-33411) [ШЛАНГ СИСТЕМЫ КОНДИЦИОНИРОВАНИЯ]
11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (A/C CNDSR HOSE) (ACDelco #11570082) [БОЛТ М8]
02724966 SEAL, A/C ACCUM FRT HOSE (PART OF 15) (FOR NON-CANADIAN ORDERS) (ACDelco #15-31101)
11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (A/C ACCUM HOSE) (ACDelco #11570082) [БОЛТ М8]
15200864 HOSE, A/C ACCUM (INCLS 13) (ACDelco #15-33409)
52458183 SEAL, A/C REFRIG SERV VLV (O RING) (9.25MM ID) (PART OF 7) (BLACK) (RUBBER) (ACDelco #15-30572) [УПЛОТНЕНИЕ РЕЗИНОВОЕ]
03041827 CORE, A/C REFRIG SERV VLV (INCLS ПРУЖИНА, W/O O-RING, 13/64-36 THD) (PART OF 7, 18) (ACDelco #15-1119)
52458184 VALVE, A/C REFRIG SERV (INCLS O-RINGS, CORE, FEMALE FITTING & SEAL, M12X1.5 THD) (PART OF 7) (INCLS 17) (ACDelco #15-5438)
52458768 CAP, A/C REFRIG CHRG VLV (HIGH SIDE CHARGE PORT, ACCUMULATOR & EVAP TUBE) (PART OF 7) (16.6MM I.S. DIA) (WITH SEAL) (ACDelco #15-33289) [КРЫШКА КЛАПАНА СИСТЕМЫ ХЛАЖДЕНИЯ]
12477570 NUT-HFH, M8X1.25X8, 10.9 (A/C CMPR & CNDSR HOSE)
03094214 O-RING, ID .426X.070 THK, MATERIAL-NEOPRENE (PART OF 7) (ACDelco #15-3614)
15784601 ORIFICE, A/C CNDSR (PART OF 7) (ACDelco #15-33410) [ФИТИНГ ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ]
02724966 SEAL, A/C ACCUM FRT TUBE (25MM OD X 17MM ID, 3/4IN DIA) (FOR NON-CANADIAN ORDERS) (9.222) (ACDelco #15-31101)
12477570 NUT-HFH, M8X1.25X8, 10.9 (A/C ACCUM RET)
03041827 CORE, A/C REFRIG SERV VLV (INCLS ПРУЖИНА, W/O O-RING, 13/64-36 THD) (PART OF 35) (ACDelco #15-1119)
52458768 CAP, A/C REFRIG CHRG VLV (HIGH SIDE CHARGE PORT, ACCUMULATOR & EVAP TUBE) (PART OF 35) (16.6MM I.S. DIA) (WITH SEAL) (ACDelco #15-33289) [КРЫШКА КЛАПАНА СИСТЕМЫ ХЛАЖДЕНИЯ]
13502758 SENSOR, A/C REFRIG PRESS (PART OF 11) (ACDelco #15-51257)
13502759 SENSOR, A/C REFRIG PRESS (PART OF 11) (ACDelco #15-51258)
03041827 CORE, A/C REFRIG SERV VLV (INCLS ПРУЖИНА, W/O O-RING, 13/64-36 THD) (PART OF 11) (INCLS 29) (ACDelco #15-1119)
52474373 SEAL, A/C REFRIG PRESS SEN O RING (PART OF 11, 28) (METAL/RUBBER) (19MM OD X 11MM ID, 1/2 IN DIA) (ACDelco #15-31055) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО СОЕДИНЕНИЯ МАГИСТРАЛЕЙ СИСТ.]
15144494 SWITCH, A/C CYCLING (ACDelco #15-50618) [ДАТЧИК ДАВЛЕНИЯ ХЛАДАГЕНТА СИСТЕМЫ ОХЛАЖДЕНИЯ]
03093509 O-RING, 7.65MM ID, 1.78 MM THK, NEOPRENE (A/C REFRIG PRESS SEN O RING) (ACDelco #3093509)
11588331 ГАЙКА, HEX HD W/CON WA, M6X1, 5.7THK, 25 O.D., 9, GM6138M (A/C ACCUM BRKT)
11514623 БОЛТ, HEX W/CON WA, M6X1X20 (A/C ACCUM BRKT)
15194317 BRACKET, A/C ACCUM
15827281 ACCUMULATOR, A/C (INCLS 25, 26) (W/SWITCH) (ACDelco #15-10640)
02724966 SEAL, A/C CMPR & CNDSR HOSE (PART OF 36) (FOR NON-CANADIAN ORDERS) (ACDelco #15-31101)
(TC09-906) - 2007-2009 CK107(06) КРЕПЛЕНИЕ КУЗОВА
15924986 RETAINER, BODY BOLT
15018263 SHIM, BODY MT (3MM THICK) [УПОРНАЯ ПЛАСТИНА РАМЫ КУЗОВА]
15018264 SHIM, BODY MT (1.5MM THICK)
15864038 CUSHION, BODY BOLT UPR (LOCATIONS: # 5) (COLOR CODE: WHITE) [ПРОКЛАДКА]
teamcadillac.ru
15201791 CUSHION, BODY BOLT LWR FRT (71MM OD)
11562587 БОЛТ, BODY (M14X2X126) [БОЛТ М14]
15201794 CUSHION, BODY BOLT UPR (LOCATIONS: # 3 & 4) (COLOR CODE: PINK) [ДЕМПФЕР РАМЫ КУЗОВА]
15201005 CUSHION, BODY BOLT UPR (LOCATION: # 2) (COLOR CODE: ORANGE)
15201797 CUSHION, BODY BOLT UPR (LOCATION: # 1) (GREEN) [КАШИОН]
03537772 ГАЙКА, M12X1.75, 10.6THK, 28 O.D., 10, 7111M (BODY MT) (8.917)
15837581 CUSHION, BODY BOLT UPR FRT (VIOLET) (1.270) [ДЕМПФЕР РАДИАТОРА]
11562547 БОЛТ, HFH, M12X1.75X135, 100 THD, 24.7 OD, GMW25 (10.9) STL, GM 7112M, MACH (BODY MT)
11562546 WASHER, FLAT, 14X42.5X3.61 MM, SAE 1050 STL RC 37-43, 7112M (BODY MT)
(TC09-910) - 2007-2009 CK1,2,3 ДАТЧИК ТЕМПЕРАТУРЫ AMBIENT(CJ2)
15936931 SENSOR, AMB AIR TEMP GA (ACDelco #213-4190) [ДАТЧИК]
(TC09-911) - 2007-2008 CK1,2(06-36) СИСТЕМА КОМУНИКАЦИИ ("ONSTAR" UE1)
15241529 MICROPHONE, MOBILE TEL (PART OF 2) (2-WAY CAVITY)
15194280 АНТЕННА, DIGITAL RDO & M/TEL & VEH LOC (INCLS 4) (ROOF MOUNTED) (9.645) (ACDelco #15194280) (WITH WHITE 3-CAVITY CONN) (SEE 25815079 FOR 2ND DES))
15796797 АНТЕННА, M/TEL & VEH LOC (INCLS 4) (ACDelco #15796797) (WITH BLUE 3-CAVITY CONN) (SEE 15837587 FOR 2ND DES)
15837587 АНТЕННА, M/TEL & VEH LOC (INCLS 4) (ACDelco #15837587) (WITH TAN 3-CAVITY CONN) (SEE 15796797 FOR 1ST DES)
25815079 АНТЕННА, DIGITAL RDO & M/TEL & VEH LOC (INCLS 4) (9.645) (ACDelco #25815079) (WITH GRAY 3-CAVITY CONN) (SEE 15194280 FOR 1ST DES))
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (COMN INTERFACE MDL BRKT) (9.665) [БОЛТ М4.2Х1.41Х25]
11517228 ГАЙКА, PANEL, M4.2X1.41, 8.5X11.9, 2.3-2.8 THICK PNL, FITS 11.2X9.2 HOLE 1050, 4250M (COMMUNICATION INTERFACE MDL BRKT)
25791895 BRACKET, COMMUNICATION INTERFACE MDL
15800441 MODULE, COMN INTERFACE (W/MOBILE TEL XCVR) (LABELED 15800441) (CASTING NUMBER 15800440) (ACDelco #15800441)
teamcadillac.ru
25911919 MODULE, COMN INTERFACE (W/MOBILE TEL XCVR) (ACDelco #25911919)
19115474 CABLE, DIGITAL RDO АНТЕННА (IN I/P WRG) (PART OF 9) (ACDelco #19115474)
19115530 CABLE, RDO & MOBILE TEL & NAVIGATION ANT (PART OF 9) (IN I/P WRG) (9.675) (ACDelco #19115530)
19208818 CABLE, M/TEL & VEH LOC ANT (IN ROOF WRG) (PART OF 9) (USED IN ROOF AND DOOR HARNESSES) (ACDelco #19208818)
19116836 CABLE, M/TEL & NAVN ANT COAX (PART OF 12) (9.647) (ACDelco #19116836)
19208818 CABLE, M/TEL & VEH LOC ANT (IN ROOF WRG) (PART OF 12) (USED IN ROOF AND DOOR HARNESSES) (ACDelco #19208818)
15779345 COVER, I/S RR VIEW MIR WRG HARN (BETWEEN I/S MIRROR & HDLR)
(TC09-912) - 2007-2008 CK1,2,3 АНТЕННА/АУДИОСИСТЕМА (U2K)
15194280 АНТЕННА, DIGITAL RDO & M/TEL & VEH LOC (INCLS 2) (ROOF MOUNTED) (ACDelco #15194280) (WITH WHITE 3-CAVITY CONN) (SEE 25815079 FOR 2ND DES))
25815079 АНТЕННА, DIGITAL RDO & M/TEL & VEH LOC (INCLS 2) (ACDelco #25815079) (WITH GRAY 3-CAVITY CONN) (SEE 15194280 FOR 1ST DES))
19208818 CABLE, M/TEL & VEH LOC ANT (IN ROOF WRG) (IN ROOF WRG) (PART OF 9) (USED IN ROOF AND DOOR HARNESSES) (ACDelco #19208818)
15201868 BRACKET, DIGITAL RDO RCVR
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (INST CARR SUPT) (9.665) [БОЛТ М4.2Х1.41Х25]
25911777 RECEIVER, DIGITAL RDO (ACDelco #25911777)
teamcadillac.ru
19115530 CABLE, RDO & MOBILE TEL & NAVIGATION ANT (PART OF 7) (IN I/P WRG) (9.675) (ACDelco #19115530)
(TC09-913) - 2007-2009 CK1,2(06) АНТЕННА
15289725 CABLE, RDO ANT (ACDelco #15289725)
15045800 COVER, RDO ANT OPG
teamcadillac.ru
11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (ELEK BRK CONT WRG HARN GND) [БОЛТ М8]
15877496 MODULE, RDO ANT (ACDelco #15877496)
11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (RDO ANT MDL GRD) [БОЛТ М8]
11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (HDLP HSG PNL) [ШАЙБА]
15095253 CABLE, RDO ANT CBL EXTN RDO END (1021 MM) (ACDelco #15095253)
(TC09-915) - 2007-2009 CK107(06) СИСТЕМА РАСПРЕДЕЛЕНИЯ ВОЗДУХА/REAR DUCTS(C69)
25915225 DUCT, AUX A/C AIR OTLT (INCLS 14)
11518162 NUT-PANEL, M4.2X1.41, 15.9X8.4, .7-1.0 PNL, 1050, 7111M, 8.65 SQ HOLE (AUX A/C AIR OTLT DUCT)
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (FLR RR AIR DISTR) (9.665) [БОЛТ М4.2Х1.41Х25]
11518162 NUT-PANEL, M4.2X1.41, 15.9X8.4, .7-1.0 PNL, 1050, 7111M, 8.65 SQ HOLE (FLR RR AIR DISTR)
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (AUX HTR & A/C EVPR & BLO MDL) (9.665) [БОЛТ М4.2Х1.41Х25]
11518162 NUT-PANEL, M4.2X1.41, 15.9X8.4, .7-1.0 PNL, 1050, 7111M, 8.65 SQ HOLE (AUX HTR & A/C EVPR & BLO MDL)
20733729 WASHER, SEALING, M5, 4 I.D., 25MM O.D., 4MM THK, RUB (RR BPR OTR FIL)
teamcadillac.ru
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (AUX HTR & A/C EVPR & BLO MDL) [ГАЙКА М6]
15864151 DISTRIBUTOR, FLR RR AIR (INCLS 11)
15152429 RETAINER, AMB AIR TEMP SEN (PUSH IN) (PART OF 10) (HOLE LINER TYPE)
12160947 SENSOR, DUCT AIR TEMP (37.54MM) (ACDelco #15-5632) [ДАТЧИК ТЕМПЕРАТУРА ВОЗДУХА]
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (AUX A/C AIR OTLT DUCT) (9.665) [БОЛТ М4.2Х1.41Х25]
15152429 RETAINER, AMB AIR TEMP SEN (PUSH IN) (PART OF 1) (HOLE LINER TYPE)
(TC09-916) - 2007-2009 CK1,2,3 СИСТЕМА РАСПРЕДЕЛЕНИЯ ВОЗДУХА/MODULE MOUNTING
11589183 ГАЙКА, PUSH IN, W/SEAL, 4.2X1.41, 6.35-6.48 SQ HL, 9.5 SQ HD, 0.787-2.765 PNL THK, NYL (AIR INL GRL PNL)
11609539 SCREW, RD CROWNED WA HD, M4.2X1.41X16, STL ISO 2702, GMW4205 (HDLP BZL) [ВИНТ]
15856112 VALVE, PLNM DRN
teamcadillac.ru
15733206 БОЛТ, HTR & BLO MDL (M6X2.70X27)
15083574 ГАЙКА, HTR & A/C EVPR & BLO MDL (M6X1.0X6)
15138625 HOSE, A/C EVPR & BLO MDL DRN
15185462 VALVE, PLNM DRN
(TC09-918) - 2007-2009 CK1,2(06-36) СИСТЕМА РАСПРЕДЕЛЕНИЯ ВОЗДУХА/FRONT DUCTS (MANUAL TEMPERATURE CONTROL CJ3)
teamcadillac.ru
11610157 ГАЙКА, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (AIR DISTR DUCT) (10.701) [ГАЙКА М4]
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (RDO FRT SPKR) (9.665) [БОЛТ М4.2Х1.41Х25]
11609370 BOLT-HWH, M4.2X1.41X20, HI - LOW THD, , OD 12, 6010 STL, GMW4205, TAP (FLR AIR OTLT DUCT) (9.667)
15274329 DUCT, FLR RR AIR OTLT
10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (PART OF 12) [ПИСТОН КРЕПЛЕНИЯ ОБЛИЦОВКИ БАМПЕРА (NYLON)]
15256414 DUCT, FLR FRT AIR OTLT (INCLS 11)
15762755 DUCT, FLR AIR OTLT (INCLS 9)
(TC09-919) - 2007-2009 CK1(06-36) СИСТЕМА РАСПРЕДЕЛЕНИЯ ВОЗДУХА/FRONT DUCTS (CADILLAC Z75, AUTO TEMPERATURE CONTROL CJ2)
15289716 DUCT, SI WDO DEFG OTLT
11610157 ГАЙКА, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (I/P COMPT) (10.701) [ГАЙКА М4]
15289717 DUCT, SI WDO DEFG OTLT
12160947 SENSOR, DUCT AIR TEMP (37.54MM) (PART OF 9, 16) (ACDelco #15-5632) [ДАТЧИК ТЕМПЕРАТУРА ВОЗДУХА]
15152429 RETAINER, AMB AIR TEMP SEN (PUSH IN) (PART OF 9, 16) (HOLE LINER TYPE)
25992392 DUCT, AIR DISTR (INCLS 2, 4, 7, 8)
15762756 DUCT, FLR AIR OTLT
teamcadillac.ru
15958694 RETAINER, FLR FRT AIR OTLT DUCT (PUSH IN) (PART OF 15) (BLACK) (7.6DIA X 22.9 MM) (X-MAS TREE) (FOR HOLE 6.30-6.55 DIA) (16.850) [ФИКСАТОР МОЛДИНГА КУЗОВА]
15256414 DUCT, FLR FRT AIR OTLT (INCLS 14)
15762756 DUCT, FLR AIR OTLT (INCLS 7, 8, 12)
(TC09-920) - 2007-2009 CK1(06-36) АУДИОСИСТЕМА/FRONT (CADILLAC Z75)
15186674 SPEAKER, RDO W/S SI G/MLDG (PART OF 1) (ACDelco #15186674) [ДИНАМИК 20ВТ]
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 1) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
15221850 GRILLE, RDO FRT SPKR (INCLS 9) (EBONY)
15221851 GRILLE, RDO FRT SPKR (INCLS 9) (COCOA)
15248601 GRILLE, RDO FRT SPKR (INCLS 9) (EBONY)
15248602 GRILLE, RDO FRT SPKR (INCLS 9) (COCOA)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 6) [ЗАЖИМ КОНСОЛИ САЛОНА]
11570654 ГАЙКА, RDO FRT S/D SPKR (4.2 X 1.41) (FITS 8.75 SQ HOLE)
15905042 SPEAKER, RDO FRT S/D (ACDelco #15905042) [ДИНАМИК 40ВТ]
25852236 SPEAKER, RDO FRT S/D (ACDelco #25852236) [ДИНАМИК АКУСТИЧЕСКИЙ]
25852237 SPEAKER, RDO FRT S/D (ACDelco #25852237)
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (RDO FRT S/D SPKR) (9.665) [БОЛТ М4.2Х1.41Х25]
20808898 УСИЛИТЕЛЬ, RDO SPKR (ACDelco #20808898) (LABELED 20808898, 25939529 OR 15937320)
25939528 УСИЛИТЕЛЬ, RDO SPKR (ACDelco #25939528) (LABELED 25939528 OR 15937318)
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (RDO F/FLR CNSL SPKR) [ГАЙКА М6]
teamcadillac.ru
15902129 SPEAKER, RDO F/FLR CNSL (ACDelco #15902129)
11610157 ГАЙКА, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (F/FLR CNSL BRKT) (10.701) [ГАЙКА М4]
(TC09-921) - 2007-2009 CK1,2(06) АУДИОСИСТЕМА/REAR
15183044 SPEAKER, RDO BODY RR COR UPR GARN MLDG (PART OF 8) (ACDelco #15183044)
15186672 SPEAKER, RDO BODY RR COR UPR GARN MLDG (PART OF 8) (ACDelco #15186672) [ДИНАМИК 20 ВТ]
11509253 SCREW, W/LRG WA HD, M4.2X1.4X10, 11.3 O.D., BHL PT, STL, NO (PART OF 8)
11609651 RETAINER, BODY RR COR G/MLDG (PART OF 8) (M21.8X15.0X20.5) (14.731) [ШАЙБА]
teamcadillac.ru
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 8) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
11609539 SCREW, RD CROWNED WA HD, M4.2X1.41X16, STL ISO 2702, GMW4205 (PART OF 8) [ВИНТ]
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (RDO RR S/D SPKR) (9.665) [БОЛТ М4.2Х1.41Х25]
11570654 ГАЙКА, RDO RR S/D SPKR (4.2 X 1.41) (FITS 8.75 SQ HOLE)
15186669 SPEAKER, RDO RR S/D (ACDelco #15186669) [ДИНАМИК ДВЕРИ, 40ВТ]
15201406 SPEAKER, RDO RR S/D (ACDelco #15201406) [ДИНАМИК 40 ВТ]
(TC09-923) - 2007-2009 CK1(06-36) КРЕПЛЕНИЕ РАДИО (CADILLAC Z75)
10396716 АНТЕННА, ELEK NAVIGATION (ACDelco #10396716)
25865834 CABLE, TV, NAV, AMP, VEH LOC & TRAF INFO INTERFACE (I/P) (ACDelco #25865834)
11610157 ГАЙКА, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (I/P) (10.701) [ГАЙКА М4]
20815326 RADIO, AM/FM STEREO & NAVN (INCLS 8, 9) (ACDelco #20815326) [РАДИОПРИЕМНИК С CD-ПРОИГРЫВАТЕЛЕМ С НАВИГАЦИЕЙ]
25798198 RADIO, AM/FM STEREO & NAVN (INCLS 8, 9) (LABELED 25798198) (ACDelco #25798198)
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (RDO) (9.665) [БОЛТ М4.2Х1.41Х25]
19116343 KNOB, RDO TUNING CONT (PART OF 6, 13)
19116474 KNOB, RDO TUNING CONT (PART OF 6, 13)
19116343 KNOB, RDO VOL CONT (PART OF 6, 13)
19116474 KNOB, RDO VOL CONT (PART OF 6, 13)
teamcadillac.ru
25878602 PLATE, I/P ACSRY CTR TR (INCLS 12) (СМ. ГРУППУ 16.000 "ПРИБОРНАЯ ПАНЕЛЬ/TRIM" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (RUBY) (W/PLATE & DEFLECTORS)
25878603 PLATE, I/P ACSRY CTR TR (INCLS 12) (СМ. ГРУППУ 16.000 "ПРИБОРНАЯ ПАНЕЛЬ/TRIM" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (CHOCOLATE BURL) (W/DEFLECTORS) [НАКЛАДКА ПАНЕЛИ]
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 11) [ЗАЖИМ КОНСОЛИ САЛОНА]
25787813 RADIO, AM/FM STEREO & CLK & AUDIO/VIDEO DISC PLYR (INCLS 8, 9) (ACDelco #25787813) [РАДИОПРИЕМНИК С CD-ПРОИГРЫВАТЕЛЕМ]
(TC09-924) - 2007-2009 CK1,2,3 ENTERTAINMENT SYSTEM (U42, EXC DNU)
15256562 BRACKET, VIDEO DISPLAY (INCLS 4)
11518121 ГАЙКА, U, M6X1, MULTI THD, .5'-4.0' THK PNL (VIDEO DISPLAY BRKT)
11570136 БОЛТ, HEX HD, W/CON SPR WA, M6X1X23, 14 THD, 17 O.D., 8.8, GMW3359 (VIDEO DISPLAY BRKT)
15958694 RETAINER, RF RR CNSL BRKT (PUSH IN) (PART OF 1) (BLACK) (7.6DIA X 22.9 MM) (X-MAS TREE) (FOR HOLE 6.30-6.55 DIA) (16.850) [ФИКСАТОР МОЛДИНГА КУЗОВА]
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 6) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
15287715 RETAINER, RF RR CNSL (INCLS 5) (DVD BCKPLT - 2ND ROW) (10.225)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 8) [ЗАЖИМ КОНСОЛИ САЛОНА]
15095547 MODULE, AUDIO SYS XCVR (ACDelco #15095547) (LABELLED W/OEM PN 15095547.)
25835387 MODULE, AUDIO SYS XCVR (ACDelco #25835387) (LABELLED W/OEM PN 25835387.)
15948136 DISPLAY, VIDEO (GRAY) (LABELED 15948136) (ACDelco #15948136) [ДИСПЛЕЙ]
20792277 DISPLAY, VIDEO (GRAY) (LABELED 20792277)
teamcadillac.ru
25888804 DISPLAY, VIDEO (CASHMERE) (ACDelco #25888804)
25888808 DISPLAY, VIDEO (CASHMERE) (ACDelco #25888808) [ЖК-МОНИТОР С DVD-ПЛЕЕРОМ]
15190411 CONTROL, VIDEO PLYR REM (ACDelco #15190411) [ИНФРАКРАСНЫЙ ПУЛЬТ УПРАВЛЕНИЯ ДЛЯ ВИДЕО]
25795364 HEADPHONE, (INCLS 16) (WIRELESS) (ONLY ONE HEADPHONE SET, NOT A SET OF TWO)
19115533 PAD, HEADPHONE EAR (PART OF 14) (PKG OF 4)
(TC09-929) - 2007-2009 CK1,2,3 ОГНЕТУШИТЕЛЬ BRACKET (MTF)
teamcadillac.ru
11609615 RIVET - DOME HD TYPE MS, 3/16X0.308 STYLE 1 MS, SAE 1006 LOW CARBON STL, ZC PER GMW3044 (ОГНЕТУШИТЕЛЬ BRKT) (*KIT1)
15880833 EXTINGUISHER PKG, FIRE (INCLS 1, 2)
16 - КУЗОВ-СТЕКЛООЧИСТИТЕЛИ-ЗЕРКАЛА-ДВЕРИ-ОТДЕЛКА САЛОНА-РЕМНИ БЕЗОПАСНОСТИ
(MW10-005) - 2007-2009 CK1,2,3 ЦИЛИНДР ЗАМКА/DOOR
15904634 CYLINDER KIT, FRT S/D LK (UNCODED) (INCLS 2-4, 6-12) [ЦИЛИНДР]
teamcadillac.ru
(TC16-065) - 2007-2009 CK1,2(06-36) РЕМНИ БЕЗОПАСНОСТИ-ПЕРЕДНИЕ
15257724 COVER, D/SEAT SHLDR BELT GDE TR (GRAY) [КОЖУХ КРОНШТЕЙНА РЕМНЯ БЕЗОПАСНОСТИ]
15257725 COVER, D/SEAT SHLDR BELT GDE TR (CASHMERE)
15257726 COVER, D/SEAT SHLDR BELT GDE TR (CASHMERE)
teamcadillac.ru
15829533 GUIDE, D/SEAT SHLDR BELT (INCLS 4) (CASHMERE)
25901985 GUIDE, D/SEAT SHLDR BELT (INCLS 4) (GRAY) [КРОНШТЕЙН РЕГУЛИРОВКИ ВЫСОТЫ РЕМНЯ БЕЗОПАСНОСТИ]
15893204 BELT, P/SEAT (RETR SI) (INCLS 2, 6, 7, 14) (CASHMERE) [РЕМЕНЬ БЕЗОПАСНОСТИ]
19181022 BELT KIT, D/SEAT (RETR SI) (W/ PRE-TENSR) (INCLS 2, 6, 7, 14) (EBONY)
19181023 BELT KIT, D/SEAT (RETR SI) (W/ PRE-TENSR) (INCLS 2, 6, 7, 14) (CASHMERE)
19181024 BELT KIT, D/SEAT (RETR SI) (W/ PRE-TENSR) (INCLS 2, 6, 7, 14) (TITANIUM)
19181025 BELT KIT, D/SEAT (RETR SI) (W/ PRE-TENSR) (INCLS 2, 6, 7, 14) (CASHMERE)
19181027 BELT KIT, D/SEAT (RETR SI) (W/ PRE-TENSR) (INCLS 2, 6, 7, 14) (EBONY)
19181036 BELT KIT, P/SEAT (RETR SI) (W/ PRE-TENSR) (INCLS 2, 6, 7, 14) (EBONY) [РЕМЕНЬ БЕЗОПАСНОСТИ]
19181037 BELT KIT, P/SEAT (RETR SI) (W/ PRE-TENSR) (INCLS 2, 6, 7, 14) (CASHMERE)
19181038 BELT KIT, P/SEAT (RETR SI) (W/ PRE-TENSR) (INCLS 2, 6, 7, 14) (TITANIUM)
19181039 BELT KIT, P/SEAT (RETR SI) (W/ PRE-TENSR) (INCLS 2, 6, 7, 14) (CASHMERE)
19181041 BELT KIT, P/SEAT (RETR SI) (W/ PRE-TENSR) (INCLS 2, 6, 7, 14) (EBONY)
25778304 BELT, D/SEAT (RETR SI) (INCLS 2, 6, 7, 14) (EBONY)
25941491 BELT, D/SEAT (RETR SI) (INCLS 2, 6, 7, 14) (CASHMERE)
25941494 BELT, P/SEAT (RETR SI) (INCLS 2, 6, 7, 14) (EBONY) [РЕМЕНЬ БЕЗОПАСНОСТИ]
15035434 ГАЙКА, D/SEAT BELT (RETR SI) (M10X1.5X10.8) (FLANGE NUT) (16.679) [ВИНТ]
19121537 BELT KIT, D/SEAT (BKL SI) (EBONY) [ЗАЩЕЛКА РЕМНЯ БЕЗОПАСНОСТИ]
19121538 BELT KIT, D/SEAT (BKL SI) (CASHMERE)
19121539 BELT KIT, D/SEAT (BKL SI) (TITANIUM)
19121540 BELT KIT, D/SEAT (BKL SI) (CASHMERE)
19121542 BELT KIT, P/SEAT (BKL SI) (CASHMERE) (W/РОЛИК НАТЯЖИТЕЛЬ)
19121543 BELT KIT, P/SEAT (BKL SI) (TITANIUM) (W/РОЛИК НАТЯЖИТЕЛЬ)
19121544 BELT KIT, P/SEAT (BKL SI) (CASHMERE) (W/РОЛИК НАТЯЖИТЕЛЬ)
12473319 БОЛТ, F/SEAT CTR BELT (M12X1.75X37) (HEX) (OUTER) (16.682)
19121443 STOP KIT, BELT LAT (RETR SI) (PART OF 8) (TITANIUM) (14.875)
19121445 STOP KIT, BELT LAT (RETR SI) (PART OF 8) (CASHMERE) (14.875)
19121446 STOP KIT, BELT LAT (RETR SI) (PART OF 8) (EBONY) (14.875)
(TC16-212) - 2007-2009 K1(06) КОНСОЛЬ/КРЫША (CADILLAC Z75, ARS,CF5, EXC UG1)
15862412 SWITCH, SUN RF (PART OF 5) [ВЫКЛЮЧАТЕЛЬ ЛЮКА КРЫШИ]
15241529 MICROPHONE, MOBILE TEL (PART OF 5) (2-WAY CAVITY)
15862407 SWITCH, R/SEAT #2 FLDG ACTR (PART OF 5) (ON КОНСОЛЬ)
15857968 КОНСОЛЬ, RF (INCLS 1-4, 6-9, 11-14) (LT CASHMERE) (W/JCI TRANSMITTER 15145260)
15936288 КОНСОЛЬ, RF (INCLS 1-4, 6-9, 11-14) (GRAY)
25807192 КОНСОЛЬ, RF (INCLS 1-4, 6-9, 11-14) (LT CASHMERE)
teamcadillac.ru
15853948 PUSHBUTTON, RDG LP SW (PART OF 5)
15911049 LENS, DM LP (PART OF 5) (1ST ROW) [КОЖУХ ФОНАРЯ ПОДСВЕТКИ САЛОНА]
09431809 BULB, 6CP TRADE #212-2 (PART OF 5) (ACDelco #L212-2)
22625546 INDICATOR, INFL RST I/P MDL (W/WORDS ON AND OFF FOR AIRBAG) (14.865)
22627868 INDICATOR, INFL RST I/P MDL (W/AIRBAG SYMBOLS FOR ON AND OFF) (14.865)
11609345 ГАЙКА, PUSH-IN, 4.2, SAE 1050 STL, GMW3179 (PART OF 5)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 5) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
(TC16-213) - 2007-2009 K1(06) КОНСОЛЬ/КРЫША (CADILLAC Z75, CF5, EXC ARS,UG1)
15862412 SWITCH, SUN RF (PART OF 4) [ВЫКЛЮЧАТЕЛЬ ЛЮКА КРЫШИ]
15241529 MICROPHONE, MOBILE TEL (PART OF 4) (2-WAY CAVITY)
15836904 КОНСОЛЬ, RF (INCLS 1-3, 5-8, 10-13) (CASHMERE) (W/JCI TRANSMITTER 15145260)
25807194 КОНСОЛЬ, RF (INCLS 1-3, 5-8, 10-13) (GRAY)
25807195 КОНСОЛЬ, RF (INCLS 1-3, 5-8, 10-13) (LT CASHMERE)
25853059 КОНСОЛЬ, RF (INCLS 1-3, 5-8, 10-13) (CASHMERE) (2ND ROW DVD FACE PLT) (PO PNL ASM)
15853948 PUSHBUTTON, RDG LP SW (PART OF 4)
15911049 LENS, DM LP (PART OF 4) (1ST ROW) [КОЖУХ ФОНАРЯ ПОДСВЕТКИ САЛОНА]
teamcadillac.ru
09431809 BULB, 6CP TRADE #212-2 (PART OF 4) (ACDelco #L212-2)
11609345 ГАЙКА, PUSH-IN, 4.2, SAE 1050 STL, GMW3179 (PART OF 4)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 4) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
(TC16-333) - 2007 CK107(06) ЗАДНЕЕ СИДЕНЬЕ #2-RH(AS3)(2ND DES)
15898111 SEAT, RR #2 (INCLS 2-44) (CASHMERE) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
15898176 SEAT, RR #2 (INCLS 2-44) (TITANIUM) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
15898182 SEAT, RR #2 (INCLS 2-44) (CASHMERE) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
15925494 SEAT, RR #2 (INCLS 2-44) (EBONY/MOROCCO)
15925507 SEAT, RR #2 (INCLS 2-44) (EBONY/TITANIUM)
20858957 SEAT, RR #2 (INCLS 2-44) (EBONY) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
25782024 SEAT, RR #2 (INCLS 2-44) (EBONY) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
25869773 SEAT, RR #2 (INCLS 2-44) (EBONY) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
25869774 SEAT, RR #2 (INCLS 2-44) (CASHMERE) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
25869847 SEAT, RR #2 (INCLS 2-44) (EBONY)
25869853 SEAT, RR #2 (INCLS 2-44) (EBONY) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
25917044 SEAT, RR #2 (INCLS 2-44) (EBONY)
25917056 SEAT, RR #2 (INCLS 2-44) (TITANIUM)
25917108 SEAT, RR #2 (INCLS 2-44) (EBONY)
25917109 SEAT, RR #2 (INCLS 2-44) (CASHMERE)
25917110 SEAT, RR #2 (INCLS 2-44) (TITANIUM)
25917118 SEAT, RR #2 (INCLS 2-44) (EBONY)
teamcadillac.ru
25917119 SEAT, RR #2 (INCLS 2-44) (CASHMERE)
25917134 SEAT, RR #2 (INCLS 2-44) (CASHMERE)
25950391 SEAT, RR #2 (INCLS 2-44) (CASHMERE)
15804529 PAD, R/SEAT #2 BK CUSH
15827635 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE)
15827636 RESTRAINT, R/SEAT HD (INCLS 3) (TITANIUM)
15827642 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
15827646 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE) [ПОДГОЛОВНИК ЗАДНЕГО СИДЕНЬЯ]
15833505 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
15863451 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
15863452 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE)
15863456 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE)
15863458 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
15863459 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE)
15865842 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
20758001 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
20758002 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE)
20758003 RESTRAINT, R/SEAT HD (INCLS 3) (TITANIUM)
25863504 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
15279347 GUIDE, R/SEAT #2 H/RST (EBONY) (W/BUTTON)
15279348 GUIDE, R/SEAT #2 H/RST (CASHMERE) (W/BUTTON)
15279349 GUIDE, R/SEAT #2 H/RST (TITANIUM) (W/BUTTON)
15279351 GUIDE, R/SEAT #2 H/RST (EBONY) (W/O BUTTON)
15279352 GUIDE, R/SEAT #2 H/RST (CASHMERE) (W/O BUTTON)
15279353 GUIDE, R/SEAT #2 H/RST (TITANIUM) (W/O BUTTON)
15279441 GUIDE, R/SEAT #2 H/RST (CASHMERE) (W/O BUTTON)
25869335 BRACKET, R/SEAT #2 BELT (RETR SI)
15827657 COVER, R/SEAT HGE FIN (O/B)
15853693 BELT, R/SEAT #2 CTR (INCLS 8) (EBONY) (USED ON VEHICLES BUILT PRIOR TO VINS 7R170871 & 7J171621) (FOR 2ND DES SEE 15898352)
15853694 BELT, R/SEAT #2 CTR (INCLS 8) (CASHMERE) (USED ON VEHICLES BUILT PRIOR TO VINS 7R170871 & 7J171621) (FOR 2ND DES SEE 15898353)
15898352 BELT, R/SEAT #2 CTR (INCLS 8) (EBONY) (USED ON VEHICLES BUILT ON OR AFTER VINS 7R170871 & 7J171621) (FOR 1ST DES SEE 15853693)
15898353 BELT, R/SEAT #2 CTR (INCLS 8) (CASHMERE) (USED ON VEHICLES BUILT ON OR AFTER VINS 7R170871 & 7J171621) (FOR 1ST DES SEE 15280838)
19152517 BELT KIT, R/SEAT #2 CTR (RETR SI) (INCLS 8) (CASHMERE) (CENTER)
19207589 BELT KIT, R/SEAT #2 CTR (RETR SI) (INCLS 8) (EBONY) (USED ON VEHICLES BUILT WITH AND AFTER VINS 7R170871 & 7J171621) (FOR 1ST DES SEE 19121597)
19207590 BELT KIT, R/SEAT #2 CTR (RETR SI) (INCLS 8) (CASHMERE) (USED ON VEHICLES BUILT WITH AND AFTER VINS 7R170871 & 7J171621) (FOR 1ST DES SEE 19151114)
19207591 BELT KIT, R/SEAT #2 CTR (RETR SI) (INCLS 8) (TITANIUM) (USED ON VEHICLES BUILT WITH AND AFTER VINS 7R170871 & 7J171621) (FOR 1ST DES SEE 19151115)
11562382 БОЛТ, HFH, M10X1.5X130, 26 THD, 22.3 OD, 10.9, 7114M, MACH, MAT-PT (R/SEAT #2 BK CUSH)
15791110 FRAME, R/SEAT #2 BK CUSH (USED ON VEHICLES WITH VIN 7R170870 & 7J141620 & PRIOR) (FOR 2ND DES SEE 15898362)
15827631 FRAME, R/SEAT #2 BK CUSH (USED ON VEHICLES WITH VIN 7R170870 & 7J141620 & PRIOR) (FOR 2ND DES SEE 15898399)
15898362 FRAME, R/SEAT #2 BK CUSH (USED ON VEHICLES WITH VIN 7R170871 & 7J141621 & AFTER) (FOR 1ST DES SEE 15791110)
15898399 FRAME, R/SEAT #2 BK CUSH (USED ON VEHICLES WITH VIN 7R170871 & 7J141621 & AFTER) (FOR 1ST DES SEE 15827631)
15279464 KNOB, R/SEAT #2 BK CUSH LAT REL (EBONY) (USED IN PLACE OF ALL COLORS) (16.716)
19121552 BELT KIT, R/SEAT #2 (BKL SI) (EBONY) (SINGLE BKL) (USED ON VEHICLES BUILT PRIOR TO VINS 7R170871 & 7J171621) (FOR 2ND DES SEE 19152522)
19121553 BELT KIT, R/SEAT #2 (BKL SI) (CASHMERE) (SINGLE BKL) (USED ON VEHICLES BUILT PRIOR TO VINS 7R170871 & 7J171621) (FOR 2ND DES SEE 19152523)
19121554 BELT KIT, R/SEAT #2 (BKL SI) (TITANIUM) (SINGLE BKL) (USED ON VEHICLES BUILT PRIOR TO VINS 7R170871 & 7J171621) (FOR 2ND DES SEE 19152524)
19121555 BELT KIT, R/SEAT #2 (BKL SI) (CASHMERE) (SINGLE BKL) (USED ON VEHICLES BUILT PRIOR TO VINS 7R170871 & 7J171621) (FOR 2ND DES SEE 19152525)
19152522 BELT KIT, R/SEAT #2 (BKL SI) (EBONY) (SINGLE BKL) (USED ON VEHICLES BUILT WITH AND AFTER VINS 7R170871 & 7J171621) (FOR 1ST DES SEE 19121552)
19152523 BELT KIT, R/SEAT #2 (BKL SI) (CASHMERE) (SINGLE BKL) (USED ON VEHICLES BUILT WITH OR AFTER VINS 7R170871 & 7J171621) (FOR 1ST DES SEE 19121553)
19152524 BELT KIT, R/SEAT #2 (BKL SI) (TITANIUM) (SINGLE BKL) (USED ON VEHICLES BUILT WITH AND AFTER VINS 7R170871 & 7J17621) (FOR 1ST DES SEE 19121554)
19152525 BELT KIT, R/SEAT #2 (BKL SI) (CASHMERE) (SINGLE BKL) (USED ON VEHICLES BUILT WITH OR AFTER VINS 7R170871 & 7J171621) (FOR 1ST DES SEE 19121555)
15832214 LEVER, R/SEAT RSR LAT REL
25913455 LATCH, R/SEAT #2 BK CUSH (CENTER) [ЗАЩЕЛКА МЕХАНИЗМА РЕГУЛИРОВКИ ПОЛОЖЕНИЯ СИДЕНЬЯ]
15804520 COVER, R/SEAT #2 BK CUSH LAT (EBONY) (INBOARD, OUTER) (16.716)
15804522 COVER, R/SEAT #2 BK CUSH LAT (TITANIUM) (INBOARD, OUTER) (16.716)
15804523 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (INBOARD, OUTER) (16.716)
15944450 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (INBOARD, OUTER)
19127809 БОЛТ, R/SEAT #2 BK CUSH LAT (M12X1.75X63.9) (16.679)
15822384 COVER, R/SEAT #2 BK CUSH HGE FIN (EBONY)
15822385 COVER, R/SEAT #2 BK CUSH HGE FIN (CASHMERE)
15822386 COVER, R/SEAT #2 BK CUSH HGE FIN (TITANIUM)
15822387 COVER, R/SEAT #2 BK CUSH HGE FIN (CASHMERE)
15804515 COVER, R/SEAT #2 BK CUSH LAT (EBONY) (INBOARD, INNER)
15804517 COVER, R/SEAT #2 BK CUSH LAT (TITANIUM) (INBOARD, INNER)
15898418 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (INBOARD, INNER) (16.716)
15898420 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (INBOARD, INNER)
15822356 HANDLE, R/SEAT LAT REL (PART OF 28) (EBONY)
15822357 HANDLE, R/SEAT LAT REL (PART OF 28) (CASHMERE)
15822358 HANDLE, R/SEAT LAT REL (PART OF 28) (TITANIUM)
15822359 HANDLE, R/SEAT LAT REL (PART OF 28) (CASHMERE)
25913454 CABLE, R/SEAT #2 BK CUSH LAT
15924954 LATCH, R/SEAT #2 LOAD FLR (INBOARD REAR)
15804397 LATCH, R/SEAT #2 LOAD FLR (OUTBOARD REAR)
15832238 CABLE, R/SEAT #2 BK CUSH LAT (INCLS 23) (EBONY) (W/PULL HANDLE) (50% MAIN CONTROL BOX)
15832239 CABLE, R/SEAT #2 BK CUSH LAT (INCLS 23) (CASHMERE) (W/PULL HANDLE) (50% MAIN CONTROL BOX)
15832240 CABLE, R/SEAT #2 BK CUSH LAT (INCLS 23) (TITANIUM) (W/PULL HANDLE) (50% MAIN CONTROL BOX)
15832241 CABLE, R/SEAT #2 BK CUSH LAT (INCLS 23) (CASHMERE) (W/PULL HANDLE) (50% MAIN CONTROL BOX)
15804473 COVER, R/SEAT #2 BK CUSH LAT (EBONY) (REAR CLOSEOUT) (16.716)
15804474 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (REAR CLOSEOUT) (16.716)
15804475 COVER, R/SEAT #2 BK CUSH LAT (TITANIUM) (REAR CLOSEOUT) (16.716)
15804476 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (REAR CLOSEOUT) (16.716)
15898402 LATCH, R/SEAT #2 LOAD FLR
15804478 COVER, R/SEAT #2 BK CUSH LAT (EBONY) (FRONT CLOSEOUT) (16.716)
15804479 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (FRONT CLOSEOUT) (16.716)
15804480 COVER, R/SEAT #2 BK CUSH LAT (TITANIUM) (FRONT CLOSEOUT) (16.716)
15804481 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (FRONT CLOSEOUT) (16.716)
15791114 FRAME, R/SEAT #2 CUSH (USED ON VEHICLES WITH VIN 7R170870 & 7J141620 AND PRIOR) ( FOR 2ND DES SEE 15926524)
15926524 FRAME, R/SEAT #2 CUSH (USED ON VEHICLES WITH VIN 7R170871 & 7J141621 AND AFTER) ( FOR 1ST DES SEE 15791114)
15898407 COVER, R/SEAT #2 BK CUSH LAT (EBONY) (OUTBOARD, OUTER)
15898408 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (OUTBOARD, OUTER)
15898409 COVER, R/SEAT #2 BK CUSH LAT (TITANIUM) (OUTBOARD, OUTER) (16.716)
15898410 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (OUTBOARD, OUTER)
25928521 LATCH, R/SEAT #2 BK CUSH
15804493 COVER, R/SEAT #2 BK CUSH LAT (EBONY) (OUTBOARD, INNER) (16.716)
15804494 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (OUTBOARD, INNER) (16.716)
15804495 COVER, R/SEAT #2 BK CUSH LAT (TITANIUM) (OUTBOARD, INNER) (16.716)
15804496 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (OUTBOARD, INNER) (16.716)
15899837 BELT, R/SEAT #2 (RETR SI) (INCLS 8) (CASHMERE) (USED ON VEHICLES BUILT ON OR AFTER VINS 7R170871 & 7J171621) (FOR 1ST DES SEE 15853691)
19121606 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (CASHMERE) (USED FOR RH & LH SIDES)
19121607 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (CASHMERE) (USED FOR RH & LH SIDES)
19151108 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (EBONY) (USED FOR RH & LH SIDES)
19207599 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (EBONY) (HAS LOWER ANCHOR PLATE W/SLOT AND HOLE) (FOR 1ST DES SEE 19151108)
19207600 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (CASHMERE) (HAS LOWER ANCHOR PLATE W/SLOT AND HOLE) (FOR 1ST DES SEE 19121607)
19207601 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (TITANIUM) (HAS LOWER ANCHOR PLATE W/SLOT AND HOLE) (FOR 1ST DES SEE 19121608)
19207602 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (CASHMERE) (HAS LOWER ANCHOR PLATE W/SLOT AND HOLE) (FOR 1ST DES SEE 19121606)
25869320 BELT, R/SEAT #2 (RETR SI) (INCLS 8) (EBONY) (USED ON VEHICLES BUILT ON OR AFTER VINS 7R170871 & 7J171621) (FOR 2ND DES SEE 15899836)
(TC16-360) - 2007-2009 CK107(06) ОТДЕЛКА/INTERIOR-BODY SIDE REAR (CADILLAC Z75)
15931763 PLATE, R/FLR RR TR (INCLS 17, 18) (EBONY) (W/ CADILLAC INSERT) [КРЫШКА ПОЛА]
15931764 PLATE, R/FLR RR TR (INCLS 17, 18) (CASHMERE) (INCLS CADILLAC INSERT)
15905682 MOLDING, BK BODY OPG GARN (INCLS 3) (CASHMERE)
15905683 MOLDING, BK BODY OPG GARN (INCLS 3) (GRAY)
11561654 RETAINER, BODY RR COR G/MLDG (PART OF 2) (PLAIN) (8.5MM DIA HOLE) (BIRD'S BEAK SINGLE) (12.800) [ФИКСАТОР ВНУТРЕННЕЙ ПАНЕЛИ БАГАЖНОГО ОТДЕЛЕНИЯ]
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 10, 19) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
11609651 CLIP, BODY L/PLR G/MLDG (PART OF 10, 19) (M21.8X15.0X20.5) (14.731) [ШАЙБА]
15873284 PLATE, RR S/D SILL TR (INCLS 8) (CASHMERE)
15873285 PLATE, RR S/D SILL TR (INCLS 8) (EBONY) (W/CADILLAC INSERT) [НАКЛАДКА ПАНЕЛИ ПОРОГА КУЗОВА]
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 7) [ЗАЖИМ КОНСОЛИ САЛОНА]
15043000 PLUG, R/CMPT SILL TR PLT HOLE (38.0 X 17.0 X 18.0MM) (OBLONG) (16.600)
25797296 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15) (CASHMERE)
25797297 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15) (EBONY) (CLOTH WRAPPED)
25797299 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15) (CASHMERE)
25797300 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15) (EBONY) (MOLDED IN PLASTIC)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 10, 19) [ЗАЖИМ КОНСОЛИ САЛОНА]
15295389 BEZEL, R/SEAT SHLDR BELT OPG (PART OF 10, 19) (CASHMERE)
15295390 BEZEL, R/SEAT SHLDR BELT OPG (PART OF 10, 19) (EBONY)
15295393 BEZEL, R/SEAT SHLDR BELT OPG (PART OF 10, 19) (CASHMERE)
15295394 BEZEL, R/SEAT SHLDR BELT OPG (PART OF 10, 19) (EBONY)
15214081 GUIDE, R/SEAT SHLDR BELT (PART OF 10, 19) (EBONY)
15220494 GUIDE, R/SEAT SHLDR BELT (PART OF 10, 19) (CASHMERE)
11609465 БОЛТ, HWH, M4.2X1.41X18, 12.5 OD, 6010M, PS (PART OF 10, 19) (8.977) [ВИНТ М6]
15278075 PLUG, BODY L/PLR GARN MLDG (PART OF 10, 19) (GRAY) [ЗАГЛУШКА ВНУТРЕННЕЙ ПАНЕЛИ СТОЙКИ КУЗОВА]
15278076 PLUG, BODY L/PLR GARN MLDG (PART OF 10, 19) (GRAY) [ЗАГЛУШКА ВНУТРЕННЕЙ ПАНЕЛИ СТОЙКИ КУЗОВА]
15278079 PLUG, BODY L/PLR GARN MLDG (PART OF 10, 19) (EBONY)
15278080 PLUG, BODY L/PLR GARN MLDG (PART OF 10, 19) (EBONY)
15278081 PLUG, BODY L/PLR GARN MLDG (PART OF 10, 19) (CASHMERE)
15278082 PLUG, BODY L/PLR GARN MLDG (PART OF 10, 19) (CASHMERE)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 1) [ЗАЖИМ КОНСОЛИ САЛОНА]
15274516 COVER, L/GATE LK STKR (PART OF 1) (EBONY)
teamcadillac.ru
15274517 COVER, L/GATE LK STKR (PART OF 1) (LT CASHMERE)
25797293 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (CASHMERE)
25797294 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (EBONY)
25797302 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (CASHMERE) [ВНУТРЕННЯЯ ПАНЕЛЬ СТОЙКИ КУЗОВА]
25797303 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (EBONY)
15113408 SWITCH, R/SEAT ADJR (PART OF 19) (ON GARNISH MOLDING)
15214084 BEZEL, BODY L/PLR G/MLDG (PART OF 19) (EBONY)
15810644 BEZEL, BODY L/PLR G/MLDG (PART OF 19) (CASHMERE)
(TC16-375) - 2007-2009 CK107(06) ОТДЕЛКА/ВНУТРЕННЯЯ-КРЫША (EXC SUNROOF CF5)
25794574 PANEL, HDLNG TR (INCLS 9, 30, 31) (GRAY) (HEADLINER SUBSTRATE)
25794575 PANEL, HDLNG TR (INCLS 9, 30, 31) (CASHMERE) (HEADLINER SUBSTRATE)
25794576 PANEL, HDLNG TR (INCLS 9, 30, 31) (CASHMERE) (HEADLINER SUBSTRATE)
25903301 ASPIRATOR, I/S AIR TEMP SEN (ACDelco #15-51256) [ДАТЧИК ТЕМПЕРАТУРЫ ВОЗДУХА]
15774330 BRACKET, R/RL RR ASST HDL
15958694 RETAINER, R/RL RR ASST HDL (PUSH IN) (BLACK) (7.6DIA X 22.9 MM) (X-MAS TREE) (FOR HOLE 6.30-6.55 DIA) (16.850) [ФИКСАТОР МОЛДИНГА КУЗОВА]
11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (R/RL RR ASST HDL BRKT) [БОЛТ М8]
15882152 HOOK, COAT (INCLS 7) (LT CASHMERE)
20760385 HOOK, COAT (INCLS 7) (GRAY) (BEZEL W/FINGERS)
20760388 HOOK, COAT (INCLS 7) (CASHMERE)
25837307 HOOK, COAT (INCLS 7) (GRAY) (W/O FINGERS) [КРЮК]
11609649 SCREW-PAN HD, M6X1X20, 15 THD 11.25 OD, 6202M STL, GMW3044, TAPTITE 200 (PART OF 6) (8.913)
15126552 RETAINER, HDLNG T/PNL (GRAY) (26.3MM & DIA 6.85) [ФИКСАТОР ВНУТРЕННЕЙ ПАНЕЛИ КРЫШИ КУЗОВА]
15220012 RETAINER, HDLNG T/PNL (CASHMERE)
15248143 RETAINER, HDLNG T/PNL (CASHMERE)
10393498 DEFLECTOR, AUX A/C AIR OTLT (PART OF 1, 34, 42) (CASHMERE)
15217394 DEFLECTOR, AUX A/C AIR OTLT (PART OF 1, 34, 42) (GRAY)
15220013 DEFLECTOR, AUX A/C AIR OTLT (PART OF 1, 34, 42) (CASHMERE)
15905213 LAMP, DM & RDG (3RD ROW (INCLS 11-13) (VERY LIGHT CASHMERE) (2ND ROW)
15940146 LAMP, DM & RDG (2ND ROW) (3RD ROW (INCLS 11-13) (OPAL GRAY)
15940147 LAMP, DM & RDG (2ND ROW) (3RD ROW (INCLS 11-13) (CASHMERE)
15940150 LAMP, DM & RDG (3RD ROW) (3RD ROW (INCLS 11-13) (GRAY) [ЛАМПА]
15940151 LAMP, DM & RDG (3RD ROW) (3RD ROW (INCLS 11-13) (CASHMERE)
15940152 LAMP, DM & RDG (3RD ROW) (3RD ROW (INCLS 11-13) (CASHMERE)
25855591 LAMP, DM & RDG (3RD ROW (INCLS 11-13) (CASHMERE)
15853948 PUSHBUTTON, RDG LP SW (PART OF 10, 18)
15853946 LENS, DM & RDG LP (3RD ROW LAMP) (PART OF 10)
19116011 BULB, C/LP (PART OF 10, 18) (ACDelco #19116011)
15075507 GRILLE, I/S AIR TEMP SEN ASPIRATOR (GRAY)
15220014 GRILLE, I/S AIR TEMP SEN ASPIRATOR (CASHMERE) [РЕШЕТКА ВОЗДУХОВОДА]
15250566 GRILLE, I/S AIR TEMP SEN ASPIRATOR (CASHMERE)
15774320 HANDLE, R/RL RR ASST (INCLS 16) (GRAY)
15774321 HANDLE, R/RL RR ASST (INCLS 16) (LT CASHMERE)
15774324 HANDLE, R/RL RR ASST (INCLS 16) (GRAY)
15774325 HANDLE, R/RL RR ASST (INCLS 16) (LT CASHMERE)
11609649 SCREW-PAN HD, M6X1X20, 15 THD 11.25 OD, 6202M STL, GMW3044, TAPTITE 200 (PART OF 15) (8.913)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 18) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
15905213 LAMP, DM & RDG (INCLS 11, 13, 17, 19) (VERY LIGHT CASHMERE) (2ND ROW)
15940146 LAMP, DM & RDG (2ND ROW) (INCLS 11, 13, 17, 19) (OPAL GRAY)
15940147 LAMP, DM & RDG (2ND ROW) (INCLS 11, 13, 17, 19) (CASHMERE)
15940150 LAMP, DM & RDG (3RD ROW) (INCLS 11, 13, 17, 19) (GRAY) [ЛАМПА]
15940151 LAMP, DM & RDG (3RD ROW) (INCLS 11, 13, 17, 19) (CASHMERE)
15940152 LAMP, DM & RDG (3RD ROW) (INCLS 11, 13, 17, 19) (CASHMERE)
25855591 LAMP, DM & RDG (INCLS 11, 13, 17, 19) (CASHMERE)
15853946 LENS, DM & RDG LP (2ND ROW LAMP) (PART OF 18)
15853950 LENS, S/S ILLUM MIR LP (PART OF 23) (GRAY)
15853951 LENS, S/S ILLUM MIR LP (PART OF 23) (CASHMERE)
15853952 LENS, S/S ILLUM MIR LP (PART OF 23) (CASHMERE) [СТЕКЛО ПОДСВЕТКИ САЛОНА]
13502343 BULB, S/S ILLUM MIR LP (PART OF 23) (8.991) (ACDelco #13502343)
25945132 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, (INCLS 21, 22, 24, 25) (GRAY)
25945133 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, (INCLS 21, 22, 24, 25) (CASHMERE) [СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК]
25945134 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, (INCLS 21, 22, 24, 25) (LT CASHMERE)
25945137 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, (INCLS 21, 22, 24, 25) (GRAY)
25945138 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, (INCLS 21, 22, 24, 25) (CASHMERE)
25945139 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, (INCLS 21, 22, 24, 25) (LT CASHMERE)
11610271 SCREW, PAN HD, M4.2X1.41X25, 20.5 THD, 8 OD, 6010M, GMW4205, T15 TORX, AB-PT (PART OF 23)
15828264 COVER, S/S SUPT BOLT (GRAY)
15828265 COVER, S/S SUPT BOLT (LT CASHMERE)
15828266 COVER, S/S SUPT BOLT (CASHMERE)
15828268 COVER, S/S SUPT BOLT (GRAY)
15828269 COVER, S/S SUPT BOLT (LT CASHMERE)
15828270 COVER, S/S SUPT BOLT (CASHMERE)
11516440 SCREW (PART OF 28)
15882855 RETAINER, S/S (INCLS 27, 29) (LT CASHMERE)
15893661 RETAINER, S/S (INCLS 27, 29) (CASHMERE)
11609314 CLIP, S/S SUPT (PART OF 28) (4.2 X 1.41) (12.8 HOLE)
15844423 HARNESS, RF ACSRY WRG (PART OF 1, 34, 42)
25793410 HARNESS, RF ACSRY WRG (PART OF 1, 34, 42)
25793411 HARNESS, RF ACSRY WRG (PART OF 1, 34, 42)
15289725 CABLE, RDO ANT (PART OF 1, 34, 42) (ACDelco #15289725)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 33) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
15833005 RETAINER, RF RR CNSL (INCLS 32) (HVAC BACKPLATE)
15943920 PANEL, HDLNG TR (INCLS 9, 30, 31) (CASHMERE) (HEADLINER SUBSTRATE)
15943930 PANEL, HDLNG TR (INCLS 9, 30, 31) (GRAY) (HEADLINER SUBSTRATE)
25794571 PANEL, HDLNG TR (INCLS 9, 30, 31) (GRAY) (HEADLINER SUBSTRATE)
25794583 PANEL, HDLNG TR (INCLS 9, 30, 31) (CASHMERE) (HEADLINER SUBSTRATE)
25794594 PANEL, HDLNG TR (INCLS 9, 30, 31) (GRAY) (HEADLINER SUBSTRATE)
25794597 PANEL, HDLNG TR (INCLS 9, 30, 31) (GRAY) (HEADLINER SUBSTRATE)
15109353 CONTROL, AUX HTR & A/C (9.273) (ACDelco #15-73427)
15836908 КОНСОЛЬ, RF (INCLS 35, 38-41) (CASHMERE) (W/JCI TRANSMITTER 15145260)
15836915 КОНСОЛЬ, RF (INCLS 35, 38-41) (GRAY) (NON-DVD CNSL) (BUILT FROM 10/31/05 TO 01/03/06)
15836916 КОНСОЛЬ, RF (INCLS 35, 38-41) (LT CASHMERE)
15889653 КОНСОЛЬ, RF (INCLS 35, 38-41) (GRAY) (W/JCI TRANSMITTER 15145260)
15907227 КОНСОЛЬ, RF (INCLS 35, 38-41) (CASHMERE) (HVAC)
15913181 КОНСОЛЬ, RF (INCLS 35, 38-41) (LT CASHMERE) (W/LEAR TRANSMITTER KIT 25807341)
25807240 КОНСОЛЬ, RF (INCLS 35, 38-41) (GRAY) (BUILT FROM 09/25/06 TO 03/20/07)
25853059 КОНСОЛЬ, RF (INCLS 35, 38-41) (CASHMERE) (2ND ROW DVD FACE PLT) (PO PNL ASM)
09431809 BULB, 6CP TRADE #212-2 (PART OF 37) (ACDelco #L212-2)
15853944 LENS, HTR & A/C CONT (PART OF 37)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 37) [ЗАЖИМ КОНСОЛИ САЛОНА]
15826886 PANEL, HDLNG TR (INCLS 9, 30, 31) (CASHMERE) (HEADLINER SUBSTRATE)
25794578 PANEL, HDLNG TR (INCLS 9, 30, 31) (GRAY) (HEADLINER SUBSTRATE)
25794579 PANEL, HDLNG TR (INCLS 9, 30, 31) (CASHMERE) (HEADLINER SUBSTRATE)
15287715 RETAINER, RF RR CNSL (INCLS 44) (DVD BCKPLT - 2ND ROW) (10.225)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 43) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 46) [ЗАЖИМ КОНСОЛИ САЛОНА]
teamcadillac.ru
25817052 КОНСОЛЬ, RF (INCLS 45, 47-49) (GRAY) (2ND ROW DVD FACE PLT)
25853058 КОНСОЛЬ, RF (INCLS 45, 47-49) (GRAY) (DVD КОНСОЛЬ)
25853059 КОНСОЛЬ, RF (INCLS 45, 47-49) (CASHMERE) (2ND ROW DVD FACE PLT) (PO PNL ASM)
25853060 КОНСОЛЬ, RF (INCLS 45, 47-49) (LT CASHMERE)
15853942 LENS, VIDEO PLYR R/CON SEN (PART OF 46) (RH DVD PUSH-PUSH)
09431809 BULB, 6CP TRADE #212-2 (PART OF 46) (ACDelco #L212-2)
15940147 LAMP, DM & RDG (2ND ROW) (CASHMERE)
(TC16-376) - 2007-2009 CK107(06) ОТДЕЛКА/ВНУТРЕННЯЯ-КРЫША (SUNROOF CF5)
15943914 PANEL, HDLNG TR (INCLS 9, 30, 31) (CASHMERE) (HEADLINER SUBSTRATE)
25794564 PANEL, HDLNG TR (INCLS 9, 30, 31) (GRAY) (HEADLINER SUBSTRATE)
25794565 PANEL, HDLNG TR (INCLS 9, 30, 31) (CASHMERE) (HEADLINER SUBSTRATE)
25794568 PANEL, HDLNG TR (INCLS 9, 30, 31) (GRAY) (HEADLINER SUBSTRATE)
10393498 DEFLECTOR, AUX A/C AIR OTLT (PART OF 1, 34) (CASHMERE)
15217394 DEFLECTOR, AUX A/C AIR OTLT (PART OF 1, 34) (GRAY)
15220013 DEFLECTOR, AUX A/C AIR OTLT (PART OF 1, 34) (CASHMERE)
15847281 LAMP, DM & RDG (LT CASHMERE) (3RD ROW)
15905213 LAMP, DM & RDG (VERY LIGHT CASHMERE) (2ND ROW)
15940146 LAMP, DM & RDG (2ND ROW) (OPAL GRAY)
15940150 LAMP, DM & RDG (3RD ROW) (GRAY) [ЛАМПА]
15940151 LAMP, DM & RDG (3RD ROW) (CASHMERE)
15940152 LAMP, DM & RDG (3RD ROW) (CASHMERE)
25855591 LAMP, DM & RDG (CASHMERE)
teamcadillac.ru
15853946 LENS, DM & RDG LP (PART OF 18)
15884142 MOLDING, SUN RF PNL/WDO GARN (CASHMERE)
25874712 MOLDING, SUN RF PNL/WDO GARN (GRAY)
25874713 MOLDING, SUN RF PNL/WDO GARN (CASHMERE)
15844423 HARNESS, RF ACSRY WRG (PART OF 1, 34)
25793410 HARNESS, RF ACSRY WRG (PART OF 1, 34)
25793411 HARNESS, RF ACSRY WRG (PART OF 1, 34)
15289725 CABLE, RDO ANT (PART OF 1, 34) (ACDelco #15289725)
15287715 RETAINER, RF RR CNSL (INCLS 32) (DVD BCKPLT - 2ND ROW) (10.225)
25794560 PANEL, HDLNG TR (INCLS 9, 30, 31) (GRAY) (HEADLINER SUBSTRATE)
25794561 PANEL, HDLNG TR (INCLS 9, 30, 31) (CASHMERE) (HEADLINER SUBSTRATE)
25794562 PANEL, HDLNG TR (INCLS 9, 30, 31) (CASHMERE) (HEADLINER SUBSTRATE)
15857968 КОНСОЛЬ, RF (INCLS 36, 38-40) (LT CASHMERE) (W/JCI TRANSMITTER 15145260)
25853058 КОНСОЛЬ, RF (INCLS 36, 38-40) (GRAY) (DVD КОНСОЛЬ)
25853059 КОНСОЛЬ, RF (INCLS 36, 38-40) (CASHMERE) (2ND ROW DVD FACE PLT) (PO PNL ASM)
25853060 КОНСОЛЬ, RF (INCLS 36, 38-40) (LT CASHMERE)
15853942 LENS, VIDEO PLYR R/CON SEN (PART OF 37) (RH DVD PUSH-PUSH)
15853943 LENS, VIDEO PLYR R/CON SEN (CTR DVD FIXED LENSPART OF 37) (CTR DVD FIXED FREEDOM)
(TC16-379) - 2007-2009 CK1(06-36) ОТДЕЛКА ДВЕРИ/SIDE FRONT-DRIVER (CADILLAC Z75)
11609385 ГАЙКА, U-TYPE, M6X1, 29.5 LEN, 12.5 WID, 19.5 CEN-END, 1050, GMW3359 (FRT S/D TR PNL) [ГАЙКА М 6]
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 18) [ЗАЖИМ КОНСОЛИ САЛОНА]
15920724 DEFLECTOR, FRT S/D WAT (PART OF 18)
15844616 KNOB, FRT S/D LKG ROD (EBONY) [КНОПКА БЛОКИРАТОРА ДВЕРИ]
15844619 KNOB, FRT S/D LKG ROD (CASHMERE) [КНОПКА БЛОКИРАТОРА ДВЕРИ]
15844620 KNOB, FRT S/D LKG ROD (COCOA)
11588650 CLIP, 12X14X16.6, GM4345M (DR LK & SI WDO RLY (PUSH IN)) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
15920631 BEZEL, FRT S/D WDO SW (RUBY BURL)
25924149 BEZEL, FRT S/D WDO SW (CHOCOLATE)
15906883 SWITCH, DR LK & SI WDO (W/MIRROR SW) [ДВЕРНОЙ ДАТЧИК]
15849185 PANEL, FRT S/D UPR FRT TR (INCLS 10) (CASHMERE)
25857282 PANEL, FRT S/D UPR FRT TR (INCLS 10) (EBONY)
15198466 SWITCH, D/SEAT ADJR MEMORY (PART OF 18)
25822439 SWITCH, D/SEAT ADJR MEMORY (PART OF 18)
15920707 HANDLE, FRT S/D I/S (PART OF 18) (EBONY) (W/CHROME HDL) [РУЧКА ДВЕРИ]
15920708 HANDLE, FRT S/D I/S (PART OF 18) (CASHMERE) (W/CHROME HANDLES)
25897906 COVER, FRT S/D I/S HDL BZL FIN (EBONY) [КРЫШКА РУЧКИ САЛОНА]
25897909 COVER, FRT S/D I/S HDL BZL FIN (CASHMERE)
25897910 COVER, FRT S/D I/S HDL BZL FIN (COCOA)
11570136 БОЛТ, HEX HD, W/CON SPR WA, M6X1X23, 14 THD, 17 O.D., 8.8, GMW3359 (FRT S/D T/PNL)
15214060 COVER, FRT S/D T/PNL (EBONY)
15214061 COVER, FRT S/D T/PNL (CASHMERE)
15219905 COVER, FRT S/D T/PNL (CASHMERE)
15939207 GRILLE, RDO FRT SPKR (PART OF 18) (CASHMERE) (9.665)
15939208 GRILLE, RDO FRT SPKR (PART OF 18) (EBONY) (9.665) [РЕШЕТКА ДИНАМИКА ДВЕРИ]
25780089 PANEL, FRT S/D TR (INCLS 2-4, 12, 13, 17, 19-26) (EBONY)
25780090 PANEL, FRT S/D TR (INCLS 2-4, 12, 13, 17, 19-26) (CASHMERE)
15876516 LAMP, CTSY (INCLS 19) (PART OF 18) (FRT S/D)
09425542 BULB, LAMP #192 (PART OF 18, 20) (ACDelco #L168)
11519031 RETAINER, PUSH IN, 19.5X26.1X1.8, ACETAL, NATURAL, FOAM SEALER (PART OF 18) [ФИКСАТОР ОБШИВКИ ДВЕРИ]
11519032 RETAINER, PUSH IN, 19.5X28.4X1.8, FITS HOLE 9.1, ACETAL, BLK (PART OF 18) [ФИКСАТОР ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ]
teamcadillac.ru
25912653 DOOR, FRT SI (СМ. ГРУППУ 16.000 "АРМАТУРА ПЕРЕДНЕЙ ДВЕРИ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/O HINGES) [ПАНЕЛЬ ДВЕРИ]
(TC16-380) - 2007-2009 CK1(06-36) ОТДЕЛКА ДВЕРИ/SIDE FRONT-PASSENGER (CADILLAC Z75)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 10) [ЗАЖИМ КОНСОЛИ САЛОНА]
15228568 DOOR, FRT SI (СМ. ГРУППУ 16.000 "АРМАТУРА ПЕРЕДНЕЙ ДВЕРИ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/O HINGES)
25973617 DEFLECTOR, FRT S/D WAT (PART OF 10)
11519032 RETAINER, PUSH IN, 19.5X28.4X1.8, FITS HOLE 9.1, ACETAL, BLK (PART OF 10) [ФИКСАТОР ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ]
11519031 RETAINER, PUSH IN, 19.5X26.1X1.8, ACETAL, NATURAL, FOAM SEALER (PART OF 10) [ФИКСАТОР ОБШИВКИ ДВЕРИ]
15876517 LAMP, CTSY (PART OF 10) (INCLS 24, 25, 26) (FRT S/D) [ЛАМПА]
25780093 PANEL, FRT S/D TR (INCLS 2, 4-9, 11, 15, 23, 25, 26) (EBONY)
25780094 PANEL, FRT S/D TR (INCLS 2, 4-9, 11, 15, 23, 25, 26) (CASHMERE)
15939207 GRILLE, RDO FRT SPKR (PART OF 10) (CASHMERE) (9.665)
15939208 GRILLE, RDO FRT SPKR (PART OF 10) (EBONY) (9.665) [РЕШЕТКА ДИНАМИКА ДВЕРИ]
15214063 COVER, FRT S/D T/PNL (EBONY) [НАКЛАДКА ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ]
15214065 COVER, FRT S/D T/PNL (TITANIUM)
15219906 COVER, FRT S/D T/PNL (CASHMERE)
15873036 COVER, FRT S/D I/S HDL BZL FIN (CASHMERE)
25897912 COVER, FRT S/D I/S HDL BZL FIN (EBONY) [ЗАГЛУШКА БОЛТА ВНУТРЕННЕЙ РУЧКИ ДВЕРИ]
15920704 HANDLE, FRT S/D I/S (PART OF 10) (EBONY) (W/CHROME HDL) [ВНУТРЕННЯЯ РУЧКА ПЕРЕДНЕЙ ДВЕРИ]
15920705 HANDLE, FRT S/D I/S (PART OF 10) (CASHMERE) (W/CHROME HANDLES) [ВНУТРЕННЯЯ РУЧКА ПЕРЕДНЕЙ ДВЕРИ]
15849186 PANEL, FRT S/D UPR FRT TR (INCLS 17) (CASHMERE)
25857286 PANEL, FRT S/D UPR FRT TR (INCLS 17) (EBONY)
25870922 RETAINER, FRT S/D UPR FRT T/PNL (PART OF 16)
15906882 SWITCH, DR LK & SI WDO (W/MODULE) [ДВЕРНОЙ ДАТЧИК]
15906884 SWITCH, DR LK & SI WDO (W/MODULE)
teamcadillac.ru
25909704 BEZEL, FRT S/D WDO SW (RUBY BURL)
25909705 BEZEL, FRT S/D WDO SW (CHOCOLATE)
09425542 BULB, LAMP #192 (PART OF 9, 10) (ACDelco #L168)
(TC16-381) - 2007-2009 CK107(06) ОТДЕЛКА ДВЕРИ/SIDE REAR (CADILLAC Z75)
15984153 ГАЙКА, RR S/D I/S HDL (16.320)
15845111 DEFLECTOR, RR S/D WAT (PART OF 14) (16.150)
15920740 DEFLECTOR, RR S/D WAT (PART OF 14) (16.150)
11519032 RETAINER, PUSH IN, 19.5X28.4X1.8, FITS HOLE 9.1, ACETAL, BLK (PART OF 14) [ФИКСАТОР ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ]
15844616 KNOB, RR S/D LKG ROD (EBONY) [КНОПКА БЛОКИРАТОРА ДВЕРИ]
15844619 KNOB, RR S/D LKG ROD (CASHMERE) [КНОПКА БЛОКИРАТОРА ДВЕРИ]
15844620 KNOB, RR S/D LKG ROD (COCOA)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (RR S/D ACSRY SW MT PLT) [ЗАЖИМ КОНСОЛИ САЛОНА]
15219999 BEZEL, RR S/D WDO SW (RUBY BURL)
15220000 BEZEL, RR S/D WDO SW (CHOCOLATE BURL) [ДЕРЖАТЕЛЬ]
15220001 BEZEL, RR S/D WDO SW (RUBY BURL)
15220002 BEZEL, RR S/D WDO SW (CHOCOLATE BURL)
25898072 SWITCH, RR S/D WDO (WITHOUT BACKLIGHTING) [ВЫКЛЮЧАТЕЛЬ СТЕКЛОПОДЪЕМНИКА ДВЕРИ (КЛАВ)]
15920683 HANDLE, RR S/D I/S (PART OF 14) (EBONY)
15920684 HANDLE, RR S/D I/S (PART OF 14) (CASHMERE) (W/CHROME HANDLES)
15920704 HANDLE, RR S/D I/S (PART OF 14) (EBONY) (W/CHROME HDL) [ВНУТРЕННЯЯ РУЧКА ПЕРЕДНЕЙ ДВЕРИ]
15920705 HANDLE, RR S/D I/S (PART OF 14) (CASHMERE) (W/CHROME HANDLES) [ВНУТРЕННЯЯ РУЧКА ПЕРЕДНЕЙ ДВЕРИ]
15939073 HANDLE, RR S/D I/S (PART OF 14) (EBONY) (W/CHROME REL HDL) [РУЧКА В СБОРЕ]
teamcadillac.ru
15873036 COVER, RR S/D I/S HDL BZL FIN (CASHMERE)
25897906 COVER, RR S/D I/S HDL BZL FIN (EBONY) [КРЫШКА РУЧКИ САЛОНА]
25897909 COVER, RR S/D I/S HDL BZL FIN (CASHMERE)
25897910 COVER, RR S/D I/S HDL BZL FIN (COCOA)
25897912 COVER, RR S/D I/S HDL BZL FIN (EBONY) [ЗАГЛУШКА БОЛТА ВНУТРЕННЕЙ РУЧКИ ДВЕРИ]
25897916 COVER, RR S/D I/S HDL BZL FIN (COCOA)
11570136 БОЛТ, HEX HD, W/CON SPR WA, M6X1X23, 14 THD, 17 O.D., 8.8, GMW3359 (RR S/D T/PNL)
15214091 COVER, RR S/D T/PNL (EBONY)
15214094 COVER, RR S/D T/PNL (EBONY)
15219914 COVER, RR S/D T/PNL (CASHMERE)
15219915 COVER, RR S/D T/PNL (CASHMERE)
25780016 PANEL, RR S/D TR (INCLS 2, 3, 5, 6, 10, 15, 16, 19, 20) (EBONY)
25780017 PANEL, RR S/D TR (INCLS 2, 3, 5, 6, 10, 15, 16, 19, 20) (CASHMERE)
25780020 PANEL, RR S/D TR (INCLS 2, 3, 5, 6, 10, 15, 16, 19, 20) (EBONY)
25780021 PANEL, RR S/D TR (INCLS 2, 3, 5, 6, 10, 15, 16, 19, 20) (CASHMERE)
11519031 RETAINER, PUSH IN, 19.5X26.1X1.8, ACETAL, NATURAL, FOAM SEALER (PART OF 14) [ФИКСАТОР ОБШИВКИ ДВЕРИ]
11609385 ГАЙКА, U-TYPE, M6X1, 29.5 LEN, 12.5 WID, 19.5 CEN-END, 1050, GMW3359 (RR S/D T/PNL) [ГАЙКА М 6]
15939207 GRILLE, RDO RR SPKR (PART OF 14) (CASHMERE)
15939208 GRILLE, RDO RR SPKR (PART OF 14) (EBONY) [РЕШЕТКА ДИНАМИКА ДВЕРИ]
15952332 RETAINER, RR S/D WAT DFL (PART OF 14)
(TC16-382) - 2007 CK107(06) ОТДЕЛКА/INTERIOR-BODY SIDE-LH QUARTER DETAIL (EXC POWER LIFTGATE E61)
15838268 HOLDER, R/SEAT CUP (PART OF 5) (EBONY) [ДЕРЖАТЕЛЬ КОМПАКТ-ДИСКОВ ПЛАСТИКОВЫЙ]
15838269 HOLDER, R/SEAT CUP (PART OF 5) (CASHMERE)
15838270 HOLDER, R/SEAT CUP (PART OF 5) (TITANIUM)
15838273 HOLDER, R/SEAT CUP (PART OF 5) (CASHMERE)
15838294 LATCH, BODY SI T/PNL OPG ACC CVR (PART OF 5) (EBONY)
15838295 LATCH, BODY SI T/PNL OPG ACC CVR (PART OF 5) (CASHMERE)
15838296 LATCH, BODY SI T/PNL OPG ACC CVR (PART OF 5) (TITANIUM)
15838297 LATCH, BODY SI T/PNL OPG ACC CVR (PART OF 5) (LT CASHMERE)
15862681 MOLDING, BODY RR COR UPR GARN (INCLS 7-13) (GRAY)
15862682 MOLDING, BODY RR COR UPR GARN (INCLS 7-13) (CASHMERE)
15863067 MOLDING, BODY RR COR UPR GARN (INCLS 7-13) (GRANITE) (W/SPKR)
15863068 MOLDING, BODY RR COR UPR GARN (INCLS 7-13) (CASHMERE) (W/SPKR)
15278014 PLUG, BODY RR COR UPR GARN MLDG (PART OF 6) (GRAY) [ЗАГЛУШКА ВНУТРЕННЕЙ ПАНЕЛИ БАГАЖНОГО ОТДЕЛЕНИЯ]
15278015 PLUG, BODY RR COR UPR GARN MLDG (PART OF 6) (CASHMERE)
teamcadillac.ru
11609539 SCREW, RD CROWNED WA HD, M4.2X1.41X16, STL ISO 2702, GMW4205 (PART OF 6) [ВИНТ]
11509253 SCREW, W/LRG WA HD, M4.2X1.4X10, 11.3 O.D., BHL PT, STL, NO (PART OF 6)
15183044 SPEAKER, RDO BODY RR COR UPR GARN MLDG (PART OF 6) (ACDelco #15183044)
11561654 RETAINER, BODY RR COR G/MLDG (PART OF 6) (PLAIN) (8.5MM DIA HOLE) (BIRD'S BEAK SINGLE) (12.800) [ФИКСАТОР ВНУТРЕННЕЙ ПАНЕЛИ БАГАЖНОГО ОТДЕЛЕНИЯ]
11609651 RETAINER, BODY RR COR G/MLDG (PART OF 6) (M21.8X15.0X20.5) (14.731) [ШАЙБА]
(TC16-383) - 2007 CK107(06) ОТДЕЛКА/INTERIOR-BODY SIDE-LH QUARTER DETAIL (POWER LIFTGATE E61)
teamcadillac.ru
15838268 HOLDER, R/SEAT CUP (PART OF 3) (EBONY) [ДЕРЖАТЕЛЬ КОМПАКТ-ДИСКОВ ПЛАСТИКОВЫЙ]
15838269 HOLDER, R/SEAT CUP (PART OF 3) (CASHMERE)
15838270 HOLDER, R/SEAT CUP (PART OF 3) (TITANIUM)
15838273 HOLDER, R/SEAT CUP (PART OF 3) (CASHMERE)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 3) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
15885777 PANEL, BODY SI TR (INCLS 1, 2) (CASHMERE)
15885778 PANEL, BODY SI TR (INCLS 1, 2) (TITANIUM)
15885779 PANEL, BODY SI TR (INCLS 1, 2) (EBONY)
15885780 PANEL, BODY SI TR (INCLS 1, 2) (CASHMERE)
15901352 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (CASHMERE) (W/O SPEAKER)
15901353 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (CASHMERE)
15901354 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (GRAY)
15901355 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (CASHMERE)
15901362 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (CASHMERE) [МОЛДИНГ]
15901363 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (GRAY) [ПРОВОДКА АККУМУЛЯТОРА]
15901364 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (CASHMERE)
25815096 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (GRAY) (W/SPKR)
15278014 PLUG, BODY RR COR UPR GARN MLDG (PART OF 4) (GRAY) [ЗАГЛУШКА ВНУТРЕННЕЙ ПАНЕЛИ БАГАЖНОГО ОТДЕЛЕНИЯ]
15278015 PLUG, BODY RR COR UPR GARN MLDG (PART OF 4) (CASHMERE)
15278016 PLUG, BODY RR COR UPR GARN MLDG (PART OF 4) (CASHMERE)
15278017 PLUG, BODY RR COR UPR GARN MLDG (PART OF 4) (GRAY)
11609539 SCREW, RD CROWNED WA HD, M4.2X1.41X16, STL ISO 2702, GMW4205 (PART OF 4) [ВИНТ]
11509253 SCREW, W/LRG WA HD, M4.2X1.4X10, 11.3 O.D., BHL PT, STL, NO (PART OF 4)
15183044 SPEAKER, RDO BODY RR COR UPR GARN MLDG (PART OF 4) (ACDelco #15183044)
15186672 SPEAKER, RDO BODY RR COR UPR GARN MLDG (PART OF 4) (ACDelco #15186672) [ДИНАМИК 20 ВТ]
11561654 RETAINER, BODY RR COR G/MLDG (PART OF 4) (PLAIN) (8.5MM DIA HOLE) (BIRD'S BEAK SINGLE) (12.800) [ФИКСАТОР ВНУТРЕННЕЙ ПАНЕЛИ БАГАЖНОГО ОТДЕЛЕНИЯ]
11609651 RETAINER, BODY RR COR G/MLDG (PART OF 4) (M21.8X15.0X20.5) (14.731) [ШАЙБА]
(TC16-384) - 2007-2009 CK107(06) ОТДЕЛКА/INTERIOR-BODY SIDE-RH QUARTER DETAIL
15863072 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13) (GRANITE) (W/SPKR)
teamcadillac.ru
15863073 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13) (CASHMERE) (W/SPKR)
15183044 SPEAKER, RDO BODY RR COR UPR GARN MLDG (PART OF 1, 15) (ACDelco #15183044)
15186672 SPEAKER, RDO BODY RR COR UPR GARN MLDG (PART OF 1, 15) (ACDelco #15186672) [ДИНАМИК 20 ВТ]
11509253 SCREW, W/LRG WA HD, M4.2X1.4X10, 11.3 O.D., BHL PT, STL, NO (PART OF 1, 15)
11561654 RETAINER, BODY RR COR G/MLDG (PART OF 1, 15) (PLAIN) (8.5MM DIA HOLE) (BIRD'S BEAK SINGLE) (12.800) [ФИКСАТОР ВНУТРЕННЕЙ ПАНЕЛИ БАГАЖНОГО ОТДЕЛЕНИЯ]
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 1, 15) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
11609508 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (PART OF 1, 15)
15278014 PLUG, BODY RR COR UPR GARN MLDG (PART OF 1, 15) (GRAY) [ЗАГЛУШКА ВНУТРЕННЕЙ ПАНЕЛИ БАГАЖНОГО ОТДЕЛЕНИЯ]
15278015 PLUG, BODY RR COR UPR GARN MLDG (PART OF 1, 15) (CASHMERE)
15187371 RETAINER, C/LTR HSG (PART OF 10) (EBONY) (INCLS COVER) [ОКАНТОВКА ГНЕЗДА ПРИКУРИВАТЕЛЯ]
25749635 RETAINER, C/LTR RCPT (PART OF 10) (EBONY) (W/O CAP) (9.709) (SERV CMP OF ПЕПЕЛЬНИЦА PKG) [ВТУЛКА ГНЕЗДА ПРИКУРИВАТЕЛЯ]
15885789 PANEL, BODY SI TR (INCLS 8, 9, 11, 12) (EBONY)
15926939 PANEL, BODY SI TR (INCLS 8, 9, 11, 12) (CASHMERE)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 10) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
11609651 RETAINER, BODY RR COR G/MLDG (PART OF 1, 15) (M21.8X15.0X20.5) (14.731) [ШАЙБА]
21997869 INDICATOR, RR OBJECT ALARM (PART OF 15)
15863076 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13, 14) (CASHMERE)
15863077 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13, 14) (LT OPEL GRAY)
15863078 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13, 14) (CASHMERE)
15863081 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13, 14) (GRANITE) (W/SPKR)
15863082 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13, 14) (CASHMERE) (W/SPKR)
25815095 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13, 14) (GRANITE OPEL GRAY)
(TC16-387) - 2007 CK1,2(06-36) СИДЕНЬЕ ВОДИТЕЛЯ/BUCKET (AN3, EXC HEATED/VENTED KB6)
15865481 RESTRAINT, D/SEAT HD (INCLS 2) (EBONY)
15865482 RESTRAINT, D/SEAT HD (INCLS 2) (CASHMERE)
15865483 RESTRAINT, D/SEAT HD (INCLS 2) (TITANIUM)
teamcadillac.ru
25798348 RESTRAINT, D/SEAT HD (INCLS 2) (EBONY) (LEATHER) (W/ BUTTON) [ПОДГОЛОВНИК СИДЕНЬЯ]
25798349 RESTRAINT, D/SEAT HD (INCLS 2) (CASHMERE) (INCLS BUTTON)
25865195 RESTRAINT, D/SEAT HD (INCLS 2) (EBONY)
25865196 RESTRAINT, D/SEAT HD (INCLS 2) (CASHMERE)
25865197 RESTRAINT, D/SEAT HD (INCLS 2) (CASHMERE)
15827107 COVER, D/SEAT BK CUSH (CASHMERE)
15827115 COVER, D/SEAT BK CUSH (EBONY)
15865828 COVER, D/SEAT BK CUSH (EBONY)
15865829 COVER, D/SEAT BK CUSH (CASHMERE)
15865830 COVER, D/SEAT BK CUSH (TITANIUM)
15923997 COVER, D/SEAT BK CUSH (EBONY)
15923998 COVER, D/SEAT BK CUSH (EBONY)
25899517 COVER, D/SEAT BK CUSH (EBONY)
25899518 COVER, D/SEAT BK CUSH (CASHMERE)
15243902 PAD, D/SEAT BK CUSH
15279347 GUIDE, F/SEAT BK H/RST ADJ ROD (EBONY) (W/BUTTON)
15279348 GUIDE, F/SEAT BK H/RST ADJ ROD (CASHMERE) (W/BUTTON)
15279349 GUIDE, F/SEAT BK H/RST ADJ ROD (TITANIUM) (W/BUTTON)
15279440 GUIDE, F/SEAT BK H/RST ADJ ROD (CASHMERE) (W/BUTTON) [НАПРАВЛЯЮЩАЯ ПОДГОЛОВНИКА СИДЕНЬЯ]
15279351 GUIDE, F/SEAT BK H/RST ADJ ROD (EBONY) (W/O BUTTON)
15279352 GUIDE, F/SEAT BK H/RST ADJ ROD (CASHMERE) (W/O BUTTON)
15279353 GUIDE, F/SEAT BK H/RST ADJ ROD (TITANIUM) (W/O BUTTON)
15279441 GUIDE, F/SEAT BK H/RST ADJ ROD (CASHMERE) (W/O BUTTON)
25808717 FRAME, D/SEAT BK CUSH (INCLS 9, 15, 16, 43-45) (INCLS LUMBAR SUPPORT, RECLINER, SENSOR & MOTOR)
20763139 LUMBAR SUB, D/SEAT (PART OF 8) (POWER) (HEAT ONLY)
15827133 RING, F/SEAT BK CUSH CVR HOG
15232706 PANEL, D/SEAT BK CUSH FIN (EBONY)
15232708 PANEL, D/SEAT BK CUSH FIN (CASHMERE)
15933726 PANEL, D/SEAT BK CUSH FIN (INCLS MAP POCKET) (EBONY) (WHEN REPL TRIM WRAP PANELS, REPLACE BOTH DRVR & PASS PANELS)
15933727 PANEL, D/SEAT BK CUSH FIN (CASHMERE) (WHEN REPL.TRIM WRAP PANELS; REPLACE BOTH DR & PASS PANELS)
15933728 PANEL, D/SEAT BK CUSH FIN (TITANIUM) (WHEN REPL.TRIM WRAP PANELS; REPLACE BOTH DR & PASS PANELS)
15243904 PAD, D/SEAT CUSH
15827129 COVER, F/SEAT RSR FIN (INCLS 14) (EBONY) (RIGHT & LEFT TOE KICK)
15827130 COVER, F/SEAT RSR FIN (INCLS 14) (CASHMERE) (RIGHT & LEFT TOE KICK)
15827131 COVER, F/SEAT RSR FIN (INCLS 14) (TITANIUM) (RIGHT & LEFT TOE KICK)
15827132 COVER, F/SEAT RSR FIN (INCLS 14) (CASHMERE) (RIGHT & LEFT TOE KICK)
11515764 БОЛТ, HFH, M10X1.5X20, 18THD, 22.3 O.D., 10.9, 7114M (D/SEAT RECL)
12451497 SWITCH, D/SEAT ADJR & RECL (8-WAY) (11.558) [ВКЛЮЧАТЕЛЬ]
25802502 SWITCH, D/SEAT LUMBAR CONT (EBONY)
25802503 SWITCH, D/SEAT LUMBAR CONT (CASHMERE) (USED WITH 4-WAY POWER LUMBAR)
25802504 SWITCH, D/SEAT LUMBAR CONT (CASHMERE)
25802505 SWITCH, D/SEAT LUMBAR CONT (TITANIUM)
15232562 COVER, D/SEAT ADJR FIN (INCLS 18) (EBONY) (8 WAY POWER)
15232563 COVER, D/SEAT ADJR FIN (INCLS 18) (CASHMERE) (8 WAY POWER)
15232564 COVER, D/SEAT ADJR FIN (INCLS 18) (TITANIUM) (8 WAY POWER)
15232565 COVER, D/SEAT ADJR FIN (INCLS 18) (CASHMERE) (8 WAY POWER) (MATCHES CARPET COLOR)
10340136 KNOB, F/SEAT RECL (EBONY) (11.377)
15222984 KNOB, F/SEAT RECL (CASHMERE) (11.377)
15222985 KNOB, F/SEAT RECL (TITANIUM) (11.377)
15786548 KNOB, F/SEAT RECL (CASHMERE)
10325879 KNOB, D/SEAT ADJR SW (EBONY) (11.558)
15222980 KNOB, D/SEAT ADJR SW (CASHMERE) (11.558)
15222981 KNOB, D/SEAT ADJR SW (TITANIUM) (11.558)
15786549 KNOB, D/SEAT ADJR SW (CASHMERE)
15232584 COVER, D/SEAT OTR ADJR TRK RR FIN (EBONY) (OUTBOARD)
15232585 COVER, D/SEAT OTR ADJR TRK RR FIN (CASHMERE) (OUTBOARD)
15232586 COVER, D/SEAT OTR ADJR TRK RR FIN (TITANIUM) (OUTBOARD)
15232587 COVER, D/SEAT OTR ADJR TRK RR FIN (CASHMERE) (OUTBOARD)
15848899 COVER, D/SEAT OTR ADJR TRK RR FIN (CASHMERE) (OUTBOARD)
11609539 SCREW, RD CROWNED WA HD, M4.2X1.41X16, STL ISO 2702, GMW4205 (D/SEAT ADJR FIN CVR) [ВИНТ]
11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (D/SEAT CUSH OTR FIN PNL)
15845152 BRACKET, D/SEAT BELT (RETR SI) (O/B)
11517996 ГАЙКА, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (D/SEAT ADJR TOP PLT) (ACDelco #11517996) [ГАЙКА М10]
15243864 COVER, D/SEAT OTR ADJR TRK RR FIN (EBONY) (INBOARD)
15243865 COVER, D/SEAT OTR ADJR TRK RR FIN (CASHMERE) (INBOARD)
15243867 COVER, D/SEAT OTR ADJR TRK RR FIN (CASHMERE) (INBOARD)
15848903 COVER, D/SEAT OTR ADJR TRK RR FIN (CASHMERE) (INBOARD)
15827134 BRACKET, D/SEAT FRT (MAIN BODY HARNESS CONNECTION) (16.686)
15243850 COVER, D/SEAT INR ADJR TRK FRT FIN (EBONY)
15243851 COVER, D/SEAT INR ADJR TRK FRT FIN (CASHMERE) (WITH ADJUSTER COVER THAT MATCHES CARPET COLOR) (FOR 2ND DES SEE 15243853)
15243852 COVER, D/SEAT INR ADJR TRK FRT FIN (TITANIUM)
15243853 COVER, D/SEAT INR ADJR TRK FRT FIN (CASHMERE) (WITH ADJUSTER COVER THAT MATCHES SEAT COLOR) (FOR 1ST DES SEE 15243851)
15848901 COVER, D/SEAT INR ADJR TRK FRT FIN (CASHMERE) (WITH ADJUSTER COVER THAT MATCHES CARPET COLOR) (FOR 2ND DES SEE 15243851)
15232242 HARNESS, D/SEAT ADJR WRG (W/LMBR/MEM/HEAT)
15780680 SENSOR, INFL RST D/SEAT POSITION [ДАТЧИК ПОДУШКИ БЕЗОПАСНОСТИ]
15845153 BRACKET, D/SEAT BELT (BKL SI) (I/B)
25966538 ADJUSTER, D/SEAT
11513599 ГАЙКА, U-TYPE, M4.2X1.41, 0.65-3.80 PNL THK, PZ (F/SEAT) (ACDelco #11513599)
11516075 ГАЙКА, HFH SELF LK, M6X1, 7.7THK, 14.2 O.D., 9, PZOR (D/SEAT ADJR MEMORY SW) [ГАЙКА ВЫПУСКНОЙ СИСТЕМЫ D=6ММ]
25855630 MODULE, D/SEAT ADJR MEMORY (REQUIRES DEALER PROGRAMMING) (LABELED 25855630) (11.558) [ПРОГРАММИРУЕМЫЙ КОНТРОЛЛЕР РЕГУЛИРОВКИ ПОЛОЖЕНИЯ СИДЕНЬЯ]
11517996 ГАЙКА, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (D/SEAT BELT (BKL SI)) (ACDelco #11517996) [ГАЙКА М10]
15854391 FRAME, D/SEAT CUSH
15827136 BRACKET, D/SEAT RECL (I/B)
15243823 COVER, D/SEAT INR RECL FIN (INCLS 18) (EBONY)
15243824 COVER, D/SEAT INR RECL FIN (INCLS 18) (CASHMERE)
15243825 COVER, D/SEAT INR RECL FIN (INCLS 18) (TITANIUM)
15243826 COVER, D/SEAT INR RECL FIN (INCLS 18) (CASHMERE)
15855909 PROTECTOR, D/SEAT RECL FIN CVR (EBONY)
15855911 PROTECTOR, D/SEAT RECL FIN CVR (EBONY)
15232559 HEATER, D/SEAT CUSH [ПОДОГРЕВ СИДЕНИЯ 45 ВТ]
15827121 COVER, D/SEAT CUSH (EBONY)
15827122 COVER, D/SEAT CUSH (CASHMERE)
15865836 COVER, D/SEAT CUSH (EBONY) (VINYL INBOARD SIDE FACING)
15865837 COVER, D/SEAT CUSH (CASHMERE) (VINYL INBOARD SIDE FACING)
15865838 COVER, D/SEAT CUSH (TITANIUM) (VINYL INBOARD SIDE FACING)
15924001 COVER, D/SEAT CUSH (EBONY)
15924002 COVER, D/SEAT CUSH (EBONY) (VINYL INBOARD SIDE FACING)
25899506 COVER, D/SEAT CUSH (CASHMERE)
25911156 HEATER, D/SEAT BK CUSH (HEAT ONLY)
25815788 CAP, F/SEAT ADJR TRK END (BLACK)
(TC16-388) - 2007 CK1,2(06-36) ПАССАЖИРСКОЕ СИДЕНЬЕ/BUCKET (AN3, EXC HEATED/VENTED KB6)
15827044 SEAT, PASS (EBONY)
15827045 SEAT, PASS (CASHMERE)
15827050 SEAT, PASS (EBONY)
15827051 SEAT, PASS (CASHMERE)
15865143 SEAT, PASS (EBONY) (WITH TRIM COVERED BACK PANEL) (FOR 2ND DES SEE 15934158)
15865144 SEAT, PASS (CASHMERE) (WITH TRIM COVERED BACK PANEL) (FOR 2ND DES SEE 15934159)
15865145 SEAT, PASS (TITANIUM) (WITH TRIM COVERED BACK PANEL) (FOR 2ND DES SEE 15934160)
15923995 SEAT, PASS (EBONY/MOROCCO) (WITH TRIM COVERED BACK PANEL) (FOR 2ND DES SEE 15934161)
15923996 SEAT, PASS (EBONY/TITANIUM) (WITH TRIM COVERED BACK PANEL) (FOR 2ND DES SEE 15934162)
15934158 SEAT, PASS (EBONY) (WITH MOLDED BACK PANEL) (FOR 1ST DES SEE 15865143)
15934159 SEAT, PASS (CASHMERE) (WITH MOLDED BACK PANEL) (FOR 1ST DES SEE 15865144)
15934160 SEAT, PASS (TITANIUM) (WITH MOLDED BACK PANEL) (FOR 1ST DES SEE 15865145)
15934161 SEAT, PASS (EBONY/MOROCCO) (WITH MOLDED BACK PANEL) (FOR 1ST DES SEE 15923995)
15934162 SEAT, PASS (EBONY/TITANIUM) (WITH MOLDED BACK PANEL) (FOR 1ST DES SEE 15923996)
15865481 RESTRAINT, P/SEAT HD (INCLS 2) (EBONY)
15865482 RESTRAINT, P/SEAT HD (INCLS 2) (CASHMERE)
15865483 RESTRAINT, P/SEAT HD (INCLS 2) (TITANIUM)
25798348 RESTRAINT, P/SEAT HD (INCLS 2) (EBONY) (LEATHER) (W/ BUTTON) [ПОДГОЛОВНИК СИДЕНЬЯ]
25798349 RESTRAINT, P/SEAT HD (INCLS 2) (CASHMERE) (INCLS BUTTON)
25865195 RESTRAINT, P/SEAT HD (INCLS 2) (EBONY)
25865196 RESTRAINT, P/SEAT HD (INCLS 2) (CASHMERE)
25865197 RESTRAINT, P/SEAT HD (INCLS 2) (CASHMERE)
15827107 COVER, P/SEAT BK CUSH (CASHMERE)
15827115 COVER, P/SEAT BK CUSH (EBONY)
15827116 COVER, P/SEAT BK CUSH (CASHMERE)
15865828 COVER, P/SEAT BK CUSH (EBONY)
15865829 COVER, P/SEAT BK CUSH (CASHMERE)
15865830 COVER, P/SEAT BK CUSH (TITANIUM)
15923997 COVER, P/SEAT BK CUSH (EBONY)
15923998 COVER, P/SEAT BK CUSH (EBONY)
25899517 COVER, P/SEAT BK CUSH (EBONY)
25899518 COVER, P/SEAT BK CUSH (CASHMERE)
15243902 PAD, P/SEAT BK CUSH
25808722 FRAME, P/SEAT BK CUSH (INCLS 9, 15, 16, 42, 43) (INCLS RECLINER, MOTOR & LUMBAR SUPPORT)
20763138 LUMBAR SUB, P/SEAT (PART OF 8) (POWER) (HEAT ONLY)
20763141 LUMBAR SUB, P/SEAT (PART OF 8) (POWER) (HEAT & COOL)
15232706 PANEL, P/SEAT BK CUSH FIN (EBONY)
15232707 PANEL, P/SEAT BK CUSH FIN (CASHMERE) (INCLS MAP POCKET)
15232708 PANEL, P/SEAT BK CUSH FIN (CASHMERE)
15933726 PANEL, P/SEAT BK CUSH FIN (INCLS MAP POCKET) (EBONY) (WHEN REPL TRIM WRAP PANELS, REPLACE BOTH DRVR & PASS PANELS)
15933727 PANEL, P/SEAT BK CUSH FIN (CASHMERE) (WHEN REPL.TRIM WRAP PANELS; REPLACE BOTH DR & PASS PANELS)
15933728 PANEL, P/SEAT BK CUSH FIN (TITANIUM) (WHEN REPL.TRIM WRAP PANELS; REPLACE BOTH DR & PASS PANELS)
11515764 БОЛТ, HFH, M10X1.5X20, 18THD, 22.3 O.D., 10.9, 7114M (P/SEAT RECL)
12451498 SWITCH, P/SEAT ADJR & RECL (8-WAY) (P SEAT ADJ SWITCH LABELED 12451498) (11.558) [ВЫКЛЮЧАТЕЛЬ ПОЛОЖЕНИЯ СИДЕНЬЯ]
25802503 SWITCH, P/SEAT LUMBAR CONT (CASHMERE) (USED WITH 4-WAY POWER LUMBAR)
15232567 COVER, P/SEAT ADJR FIN (INCLS 18) (EBONY) (POWER)
15232568 COVER, P/SEAT ADJR FIN (INCLS 18) (CASHMERE) (POWER)
15232569 COVER, P/SEAT ADJR FIN (INCLS 18) (TITANIUM) (POWER)
15232570 COVER, P/SEAT ADJR FIN (INCLS 18) (CASHMERE) (POWER)
10325879 KNOB, P/SEAT ADJR SW (EBONY) (11.558)
15222980 KNOB, P/SEAT ADJR SW (CASHMERE) (11.558)
15222981 KNOB, P/SEAT ADJR SW (TITANIUM) (11.558)
15786549 KNOB, P/SEAT ADJR SW (CASHMERE)
15232592 COVER, P/SEAT OTR ADJR TRK RR FIN (INCLS 24) (CASHMERE) (OUTBOARD) (WITH ADJUSTER COVER THAT MATCHES SEAT COLOR) (FOR 1ST DES SEE 15232590)
15243872 COVER, P/SEAT OTR ADJR TRK RR FIN (INCLS 24) (CASHMERE) (INBOARD) (WITH ADJUSTER COVER THAT MATCHES SEAT COLOR) (FOR 1ST DES SEE 15243870)
15848900 COVER, P/SEAT OTR ADJR TRK RR FIN (INCLS 24) (CASHMERE) (OUTBOARD) (WITH ADJUSTER COVER THAT MATCHES CARPET COLOR) (FOR 2ND DES SEE 15232590)
11609539 SCREW, RD CROWNED WA HD, M4.2X1.41X16, STL ISO 2702, GMW4205 (P/SEAT ADJR FIN CVR) [ВИНТ]
11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (P/SEAT CUSH OTR FIN PNL)
15845154 BRACKET, P/SEAT BELT (RETR SI) (O/B)
11517996 ГАЙКА, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (P/SEAT ADJR TOP PLT) (ACDelco #11517996) [ГАЙКА М10]
15848904 COVER, P/SEAT OTR ADJR TRK RR FIN (CASHMERE) (INBOARD) (WITH ADJUSTER COVER THAT MATCHES CARPET COLOR) (FOR 2ND DES SEE 15243870)
15827135 BRACKET, P/SEAT FRT (MAIN BODY HARNESS CONNECTION)
15243858 COVER, P/SEAT INR ADJR TRK FRT FIN (EBONY)
15243859 COVER, P/SEAT INR ADJR TRK FRT FIN (CASHMERE) (WITH ADJUSTER COVER THAT MATCHES CARPET COLOR) (FOR 2ND DES SEE 15243861)
15243860 COVER, P/SEAT INR ADJR TRK FRT FIN (TITANIUM)
15243861 COVER, P/SEAT INR ADJR TRK FRT FIN (CASHMERE) (WITH ADJUSTER COVER THAT MATCHES SEAT COLOR) (FOR 1ST DES SEE 15243859)
15848902 COVER, P/SEAT INR ADJR TRK FRT FIN (CASHMERE) (WITH ADJUSTER COVER THAT MATCHES CARPET COLOR) (FOR 2ND DES SEE 15243859)
25902019 HARNESS, P/SEAT ADJR WRG
25966545 ADJUSTER, P/SEAT (POWER 6-WAY) (INCLS MOTORS)
15845155 BRACKET, P/SEAT BELT (BKL SI) (I/B)
11516075 ГАЙКА, HFH SELF LK, M6X1, 7.7THK, 14.2 O.D., 9, PZOR (INFL RST P/SEAT SUPPRESSION) [ГАЙКА ВЫПУСКНОЙ СИСТЕМЫ D=6ММ]
11517996 ГАЙКА, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (P/SEAT BELT (BKL SI)) (ACDelco #11517996) [ГАЙКА М10]
15827059 FRAME, P/SEAT CUSH
25826416 MODULE KIT, INFL RST FRT PASS PRESENCE (W/ SEN) (INCLS 12, 38) (INCLS PAD) (USED W/ LEATHER INTERIOR)
25826417 MODULE KIT, INFL RST FRT PASS PRESENCE (W/ SEN) (INCLS 12, 38) (INCLS PAD) (USED W/ CLOTH INTERIOR)
15827137 BRACKET, P/SEAT RECL (I/B)
15243828 COVER, P/SEAT INR RECL FIN (INCLS 18) (EBONY) (INBOARD)
teamcadillac.ru
15243829 COVER, P/SEAT INR RECL FIN (INCLS 18) (CASHMERE) (INBOARD)
15243830 COVER, P/SEAT INR RECL FIN (INCLS 18) (TITANIUM) (INBOARD)
15243831 COVER, P/SEAT INR RECL FIN (INCLS 18) (CASHMERE)
15855909 PROTECTOR, P/SEAT RECL FIN CVR (EBONY)
15855911 PROTECTOR, P/SEAT RECL FIN CVR (EBONY)
15232559 HEATER, P/SEAT CUSH [ПОДОГРЕВ СИДЕНИЯ 45 ВТ]
25911156 HEATER, P/SEAT BK CUSH (HEAT ONLY)
15827109 COVER, P/SEAT CUSH (EBONY)
15827118 COVER, P/SEAT CUSH (EBONY)
15827119 COVER, P/SEAT CUSH (CASHMERE)
15865832 COVER, P/SEAT CUSH (EBONY) (VINYL INBOARD SIDE FACING)
15865833 COVER, P/SEAT CUSH (CASHMERE)
15865834 COVER, P/SEAT CUSH (TITANIUM) (VINYL INBOARD SIDE FACING)
15923999 COVER, P/SEAT CUSH (EBONY) (VINYL INBOARD SIDE FACING)
15924000 COVER, P/SEAT CUSH (EBONY) (VINYL INBOARD SIDE FACING)
25899511 COVER, P/SEAT CUSH (EBONY)
25899512 COVER, P/SEAT CUSH (CASHMERE)
(TC16-390) - 2007-2009 CK107(06) ЗАДНЕЕ СИДЕНЬЕ/BUCKET-RH (BUCKET AL4)
15842716 SEAT, RR (INCLS 2-48) (EBONY)
15842717 SEAT, RR (INCLS 2-48) (CASHMERE)
15842722 SEAT, RR (INCLS 2-48) (EBONY)
15842723 SEAT, RR (INCLS 2-48) (CASHMERE)
15843784 SEAT, RR (INCLS 2-48) (EBONY)
15843785 SEAT, RR (INCLS 2-48) (CASHMERE)
15843790 SEAT, RR (INCLS 2-48) (EBONY)
15843791 SEAT, RR (INCLS 2-48) (CASHMERE)
15843914 SEAT, RR (INCLS 2-48) (EBONY)
15843915 SEAT, RR (INCLS 2-48) (CASHMERE)
15843935 SEAT, RR (INCLS 2-48) (EBONY)
15843936 SEAT, RR (INCLS 2-48) (CASHMERE)
15865176 SEAT, RR (INCLS 2-48) (EBONY)
15865177 SEAT, RR (INCLS 2-48) (CASHMERE)
15865178 SEAT, RR (INCLS 2-48) (TITANIUM)
15865195 SEAT, RR (INCLS 2-48) (EBONY)
15865196 SEAT, RR (INCLS 2-48) (CASHMERE)
15865197 SEAT, RR (INCLS 2-48) (TITANIUM)
15939079 SEAT, RR (INCLS 2-48) (EBONY/TITANIUM)
15939080 SEAT, RR (INCLS 2-48) (EBONY/MOROCCO)
15939094 SEAT, RR (INCLS 2-48) (EBONY/TITANIUM)
15939095 SEAT, RR (INCLS 2-48) (EBONY/MOROCCO)
15865722 COVER, R/SEAT BK CUSH (EBONY)
15865723 COVER, R/SEAT BK CUSH (CASHMERE)
15865724 COVER, R/SEAT BK CUSH (TITANIUM)
15939124 COVER, R/SEAT BK CUSH (EBONY/TITANIUM)
15939125 COVER, R/SEAT BK CUSH (EBONY/MOROCCO)
25899570 COVER, R/SEAT BK CUSH (EBONY)
25899571 COVER, R/SEAT BK CUSH (CASHMERE)
25928769 COVER, R/SEAT BK CUSH (EBONY)
25928770 COVER, R/SEAT BK CUSH (CASHMERE)
15291602 PAD, R/SEAT BK CUSH
15824668 RESTRAINT, R/SEAT HD (INCLS 4) (EBONY)
15824669 RESTRAINT, R/SEAT HD (INCLS 4) (CASHMERE)
15824670 RESTRAINT, R/SEAT HD (INCLS 4) (TITANIUM)
15824672 RESTRAINT, R/SEAT HD (INCLS 4) (EBONY)
15824674 RESTRAINT, R/SEAT HD (INCLS 4) (CASHMERE)
25928791 RESTRAINT, R/SEAT HD (INCLS 4) (CASHMERE)
teamcadillac.ru
15279347 GUIDE, R/SEAT H/RST (EBONY) (W/BUTTON)
15279348 GUIDE, R/SEAT H/RST (CASHMERE) (W/BUTTON)
15279349 GUIDE, R/SEAT H/RST (TITANIUM) (W/BUTTON)
15279352 GUIDE, R/SEAT H/RST (CASHMERE) (W/O BUTTON)
15279353 GUIDE, R/SEAT H/RST (TITANIUM) (W/O BUTTON)
15279440 GUIDE, R/SEAT H/RST (CASHMERE) (W/BUTTON) [НАПРАВЛЯЮЩАЯ ПОДГОЛОВНИКА СИДЕНЬЯ]
15279441 GUIDE, R/SEAT H/RST (CASHMERE) (W/O BUTTON)
15269769 FRAME, R/SEAT BK CUSH
15279689 CAP, R/SEAT ACTR FIN CVR BOLT (EBONY) [ЗАГЛУШКА ФИКСАТОРА ПОДЛОКОТНИКА]
15279690 CAP, R/SEAT ACTR FIN CVR BOLT (CASHMERE) [ЗАГЛУШКА ФИКСАТОРА ПОДЛОКОТНИКА]
15279691 CAP, R/SEAT ACTR FIN CVR BOLT (TITANIUM) [ЗАГЛУШКА ПОДЛОКОТНИКА СИДЕНЬЯ]
15279692 CAP, R/SEAT ACTR FIN CVR BOLT (CASHMERE)
11570119 ГАЙКА, R/SEAT A/RST (T/W 11570115 STUD)
15275877 ARMREST, R/SEAT (EBONY)
15275878 ARMREST, R/SEAT (CASHMERE)
15825716 ARMREST, R/SEAT (CASHMERE)
15865501 ARMREST, R/SEAT (EBONY)
15865502 ARMREST, R/SEAT (CASHMERE)
15865503 ARMREST, R/SEAT (TITANIUM)
11570115 STUD, R/SEAT A/RST (T/W 11570119 NUT)
15291604 PAD, R/SEAT CUSH
15269765 FRAME, R/SEAT CUSH
11570116 SCREW -PAN HD, M6X1X10, 10 THD, 12 OD, STL SAE J1237, S424, TAPTITE ITE (R/SEAT LAT FIN CVR) (8.913)
11562384 ГАЙКА, HFH, M4X.7 THD, 4.75 THK, 10.5 OD, GM510M (9)STL, GM4435M-CODE A (R/SEAT FLR FIL T/PNL)
15280113 COVER, R/SEAT RECL INR FIN (EBONY) (INNER)
15280114 COVER, R/SEAT RECL INR FIN (CASHMERE) (INNER)
15280115 COVER, R/SEAT RECL INR FIN (TITANIUM) (INNER)
15280116 COVER, R/SEAT RECL INR FIN (CASHMERE) (INNER)
11562378 BOLT-HFH, M10X1.5X30, 18 THD, 22.3 OD, 10.9, GMW3359, W/ADH GM6175M (R/SEAT LAT)
15279464 KNOB, R/SEAT LAT (EBONY) (USED IN PLACE OF ALL COLORS) (16.716)
15279719 COVER, R/SEAT RECL INR FIN (INCLS 41) (EBONY) (OUTER)
15279720 COVER, R/SEAT RECL INR FIN (INCLS 41) (CASHMERE) (OUTER)
15279721 COVER, R/SEAT RECL INR FIN (INCLS 41) (TITANIUM) (OUTER)
15279722 COVER, R/SEAT RECL INR FIN (INCLS 41) (CASHMERE) (OUTER)
19121593 BELT KIT, R/SEAT (BKL SI) (EBONY) [ЗАЩЕЛКА РЕМНЯ БЕЗОПАСНОСТИ]
19121594 BELT KIT, R/SEAT (BKL SI) (CASHMERE)
19121595 BELT KIT, R/SEAT (BKL SI) (CASHMERE)
19121596 BELT KIT, R/SEAT (BKL SI) (TITANIUM)
15275899 RECLINER, R/SEAT INR (USED ON VEHICLES BUILT PRIOR TO JUNE 1, 2006) (2ND DES SEE 25896462)
25896462 RECLINER, R/SEAT INR (WHEN SERVICING VEHICLES BUILT PRIOR TO 06/01/06, DEALER NEEDS TO REPLACE BOTH INNER AND OUTER IN SETS) (USED ON VEHICLES BUILT AFTER MAY 31, 2006) (1ST DES SEE 15275899)
15275888 LATCH, R/SEAT RSR (INNER & OUTER)
11562380 BUSHING, R/SEAT HGE
15275901 ПРУЖИНА, R/SEAT RECL (TUMBLE)
15275903 ПРУЖИНА, R/SEAT RECL (MANDREL)
15275905 STRUT, R/SEAT
15280123 PANEL, R/SEAT CUSH TR (EBONY) (16.716)
15280124 PANEL, R/SEAT CUSH TR (CASHMERE) (16.716)
15280125 PANEL, R/SEAT CUSH TR (TITANIUM) (16.716)
15280126 PANEL, R/SEAT CUSH TR (CASHMERE) (16.716)
15279609 COVER, R/SEAT RSR FIN (EBONY) (REAR)
15279610 COVER, R/SEAT RSR FIN (CASHMERE) (REAR)
15279611 COVER, R/SEAT RSR FIN (TITANIUM) (REAR)
15279612 COVER, R/SEAT RSR FIN (CASHMERE) (REAR)
15269772 RISER, R/SEAT
11562379 БОЛТ, R/SEAT HGE (M10X1.5X92)
15279599 COVER, R/SEAT RSR FIN (INCLS 34) (EBONY) (FRONT)
15279600 COVER, R/SEAT RSR FIN (INCLS 34) (CASHMERE) (FRONT)
15279601 COVER, R/SEAT RSR FIN (INCLS 34) (TITANIUM) (FRONT)
15279602 COVER, R/SEAT RSR FIN (INCLS 34) (CASHMERE) (FRONT)
15843764 HARNESS, R/SEAT HTR
15843765 HARNESS, R/SEAT HTR
15279406 PIN, R/SEAT H/RST ADJ ROD LAT (EBONY)
15279407 PIN, R/SEAT H/RST ADJ ROD LAT (CASHMERE)
15279408 PIN, R/SEAT H/RST ADJ ROD LAT (TITANIUM)
15279439 PIN, R/SEAT H/RST ADJ ROD LAT (CASHMERE)
15275913 CABLE, R/SEAT BK CUSH LAT
15275915 CABLE, R/SEAT LAT (INBOARD) (SYNCH)
15275914 CABLE, R/SEAT LAT (OUTBOARD) (FLOOR LATCH)
15275897 RECLINER, R/SEAT OTR (USED ON VEHICLES BUILT PRIOR TO JUNE 1, 2006) (2ND DES SEE 25896460)
25896460 RECLINER, R/SEAT OTR (WHEN SERVICING VEHICLES BUILT PRIOR TO 06/01/06, DEALER NEEDS TO REPLACE BOTH INNER AND OUTER IN SETS) (USED ON VEHICLES BUILT AFTER MAY 31, 2006) (1ST DES SEE 15275897)
15279419 HANDLE, R/SEAT RECL (INCLS 42) (EBONY)
15279420 HANDLE, R/SEAT RECL (INCLS 42) (CASHMERE)
15279429 HANDLE, R/SEAT RECL (INCLS 42) (TITANIUM)
15279430 HANDLE, R/SEAT RECL (INCLS 42) (CASHMERE)
15279699 COVER, R/SEAT RECL OTR FIN (INCLS 41) (EBONY) (OUTER)
15279700 COVER, R/SEAT RECL OTR FIN (INCLS 41) (CASHMERE) (OUTER)
15279701 COVER, R/SEAT RECL OTR FIN (INCLS 41) (TITANIUM) (OUTER)
15279702 COVER, R/SEAT RECL OTR FIN (INCLS 41) (CASHMERE) (OUTER)
15279709 COVER, R/SEAT RECL OTR FIN (EBONY) (INNER)
15279710 COVER, R/SEAT RECL OTR FIN (CASHMERE) (INNER)
15279711 COVER, R/SEAT RECL OTR FIN (TITANIUM) (INNER)
15279712 COVER, R/SEAT RECL OTR FIN (CASHMERE) (INNER)
15865730 COVER, R/SEAT CUSH (EBONY)
15865731 COVER, R/SEAT CUSH (CASHMERE)
15865732 COVER, R/SEAT CUSH (TITANIUM)
15939156 COVER, R/SEAT CUSH (EBONY/TITANIUM)
15939157 COVER, R/SEAT CUSH (EBONY/MOROCCO)
25899558 COVER, R/SEAT CUSH (EBONY)
25899559 COVER, R/SEAT CUSH (CASHMERE)
25928781 COVER, R/SEAT CUSH (EBONY)
25928782 COVER, R/SEAT CUSH (CASHMERE)
15824750 ACTUATOR, R/SEAT RECL (INCLS CABLE)
(TC16-391) - 2007 CK107(06) ЗАДНЕЕ СИДЕНЬЕ/BENCH-40% SIDE (AM8, EXC POWER FOLDING ARS)
15824545 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
15824546 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (CASHMERE)
15843772 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
15843773 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (CASHMERE)
15843802 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
15843803 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (CASHMERE)
15865211 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
15865212 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (CASHMERE)
15865213 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (TITANIUM)
15865219 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
15865220 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (CASHMERE)
15865221 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (TITANIUM)
15914187 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
15939106 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY/TITANIUM)
15939107 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY/MOROCCO)
15291651 COVER, R/SEAT BK CUSH (EBONY)
15291652 COVER, R/SEAT BK CUSH (CASHMERE)
15291663 COVER, R/SEAT BK CUSH (EBONY)
15291664 COVER, R/SEAT BK CUSH (CASHMERE)
15865510 COVER, R/SEAT BK CUSH (CASHMERE)
15865525 COVER, R/SEAT BK CUSH (EBONY)
15865526 COVER, R/SEAT BK CUSH (CASHMERE)
15865527 COVER, R/SEAT BK CUSH (TITANIUM)
15914204 COVER, R/SEAT BK CUSH (EBONY)
15939173 COVER, R/SEAT BK CUSH (EBONY/TITANIUM)
15939174 COVER, R/SEAT BK CUSH (EBONY/MOROCCO)
25863597 COVER, R/SEAT BK CUSH (EBONY)
25863599 COVER, R/SEAT BK CUSH (TITANIUM)
15291598 PAD, R/SEAT BK CUSH
15865811 RESTRAINT, R/SEAT HD (INCLS 4) (TITANIUM)
20758014 RESTRAINT, R/SEAT HD (INCLS 4) (CASHMERE)
25863652 RESTRAINT, R/SEAT HD (INCLS 4) (EBONY)
teamcadillac.ru
15279351 GUIDE, R/SEAT H/RST (EBONY) (W/O BUTTON)
15269763 FRAME, R/SEAT BK CUSH
15291600 PAD, R/SEAT CUSH
15279530 COVER, R/SEAT BK CUSH HGE FIN (EBONY) (INBOARD, INNER) (16.674)
15279531 COVER, R/SEAT BK CUSH HGE FIN (CASHMERE) (INBOARD, INNER) (16.674)
15279532 COVER, R/SEAT BK CUSH HGE FIN (TITANIUM) (INBOARD, INNER) (16.674)
15279533 COVER, R/SEAT BK CUSH HGE FIN (CASHMERE) (INBOARD, INNER) (16.674)
15279504 COVER, R/SEAT BK CUSH HGE FIN (INCLS 40) (EBONY) (INBOARD, OUTER) (16.674)
15279505 COVER, R/SEAT BK CUSH HGE FIN (INCLS 40) (CASHMERE) (INBOARD, OUTER) (16.674)
15279506 COVER, R/SEAT BK CUSH HGE FIN (INCLS 40) (TITANIUM) (INBOARD, OUTER)
15279507 COVER, R/SEAT BK CUSH HGE FIN (INCLS 40) (CASHMERE) (INBOARD, OUTER) (16.674)
19121593 BELT KIT, R/SEAT (BKL SI) (SINGLE BKL) (EBONY) [ЗАЩЕЛКА РЕМНЯ БЕЗОПАСНОСТИ]
19121594 BELT KIT, R/SEAT (BKL SI) (SINGLE BKL) (CASHMERE)
19121596 BELT KIT, R/SEAT (BKL SI) (SINGLE BKL) (TITANIUM)
25896458 LATCH, R/SEAT BK CUSH (INBOARD)
15275888 LATCH, R/SEAT RSR (OUTBOARD)
15930099 STRUT, R/SEAT
15279554 PANEL, R/SEAT CUSH TR (EBONY) (16.716)
15279555 PANEL, R/SEAT CUSH TR (CASHMERE) (16.716)
15279556 PANEL, R/SEAT CUSH TR (TITANIUM) (16.716)
15279557 PANEL, R/SEAT CUSH TR (CASHMERE) (16.716)
15279599 COVER, R/SEAT RSR FIN (INCLS 29) (EBONY) (FRONT)
15279600 COVER, R/SEAT RSR FIN (INCLS 29) (CASHMERE) (FRONT)
15279601 COVER, R/SEAT RSR FIN (INCLS 29) (TITANIUM) (FRONT)
15279602 COVER, R/SEAT RSR FIN (INCLS 29) (CASHMERE) (FRONT)
25896457 LATCH, R/SEAT BK CUSH (OUTBOARD)
15279419 HANDLE, R/SEAT RECL (INCLS 38) (EBONY)
15279420 HANDLE, R/SEAT RECL (INCLS 38) (CASHMERE)
15279429 HANDLE, R/SEAT RECL (INCLS 38) (TITANIUM)
15279430 HANDLE, R/SEAT RECL (INCLS 38) (CASHMERE)
15279484 COVER, R/SEAT BK CUSH HGE FIN (INCLS 40) (EBONY) (OUTBOARD, OUTER) (16.674)
15279485 COVER, R/SEAT BK CUSH HGE FIN (INCLS 40) (CASHMERE) (OUTBOARD, OUTER) (16.674)
15279486 COVER, R/SEAT BK CUSH HGE FIN (INCLS 40) (TITANIUM) (OUTBOARD, OUTER) (16.674)
15279487 COVER, R/SEAT BK CUSH HGE FIN (INCLS 40) (CASHMERE) (OUTBOARD, OUTER) (16.674)
15279494 COVER, R/SEAT BK CUSH HGE FIN (EBONY) (OUTBOARD, INNER) (16.674)
15279495 COVER, R/SEAT BK CUSH HGE FIN (CASHMERE) (OUTBOARD, INNER) (16.674)
15279496 COVER, R/SEAT BK CUSH HGE FIN (TITANIUM) (OUTBOARD, INNER) (16.674)
15279497 COVER, R/SEAT BK CUSH HGE FIN (CASHMERE) (OUTBOARD, INNER) (16.674)
15291658 COVER, R/SEAT CUSH (CASHMERE)
15865518 COVER, R/SEAT CUSH (CASHMERE)
15865714 COVER, R/SEAT CUSH (EBONY)
15865715 COVER, R/SEAT CUSH (CASHMERE)
15865716 COVER, R/SEAT CUSH (TITANIUM)
15914208 COVER, R/SEAT CUSH (EBONY)
15939177 COVER, R/SEAT CUSH (EBONY/TITANIUM)
15939178 COVER, R/SEAT CUSH (EBONY/MOROCCO)
25863605 COVER, R/SEAT CUSH (EBONY)
25863607 COVER, R/SEAT CUSH (TITANIUM)
25899565 COVER, R/SEAT CUSH (CASHMERE)
(TC16-392) - 2007 CK107(06) ЗАДНЕЕ СИДЕНЬЕ/BENCH-60% SIDE (AM8, EXC POWER FOLDING ARS)
15867229 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
15867230 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (CASHMERE)
15867231 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (TITANIUM)
15867237 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
15867238 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (CASHMERE)
15867239 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (TITANIUM)
15867261 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
15867262 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (CASHMERE)
15867267 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
15867268 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (CASHMERE)
15914185 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
15939104 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY/TITANIUM)
15939105 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY/MOROCCO)
15291649 COVER, R/SEAT BK CUSH (CASHMERE)
15291660 COVER, R/SEAT BK CUSH (EBONY)
15865521 COVER, R/SEAT BK CUSH (EBONY)
15865522 COVER, R/SEAT BK CUSH (CASHMERE)
15865523 COVER, R/SEAT BK CUSH (TITANIUM)
15914202 COVER, R/SEAT BK CUSH (EBONY)
15939171 COVER, R/SEAT BK CUSH (EBONY/TITANIUM)
15939172 COVER, R/SEAT BK CUSH (EBONY/MOROCCO)
25863593 COVER, R/SEAT BK CUSH (EBONY)
25863594 COVER, R/SEAT BK CUSH (CASHMERE)
25863595 COVER, R/SEAT BK CUSH (TITANIUM)
25899577 COVER, R/SEAT BK CUSH (CASHMERE)
25899580 COVER, R/SEAT BK CUSH (CASHMERE)
25928760 COVER, R/SEAT BK CUSH (EBONY)
15291597 PAD, R/SEAT BK CUSH
15914200 PAD, R/SEAT BK CUSH
11562382 БОЛТ, HFH, M10X1.5X130, 26 THD, 22.3 OD, 10.9, 7114M, MACH, MAT-PT (R/SEAT BK CUSH FRM)
15289969 BRACKET, R/SEAT CTR BELT (RETR SI)
15279450 PROTECTOR, R/SEAT SHLDR BELT (BLACK)
15824668 RESTRAINT, R/SEAT HD (INCLS 8) (EBONY)
15824669 RESTRAINT, R/SEAT HD (INCLS 8) (CASHMERE)
15824670 RESTRAINT, R/SEAT HD (INCLS 8) (TITANIUM)
15824672 RESTRAINT, R/SEAT HD (INCLS 8) (EBONY)
15824674 RESTRAINT, R/SEAT HD (INCLS 8) (CASHMERE)
15865811 RESTRAINT, R/SEAT HD (INCLS 8) (TITANIUM)
20758014 RESTRAINT, R/SEAT HD (INCLS 8) (CASHMERE)
25863652 RESTRAINT, R/SEAT HD (INCLS 8) (EBONY)
25928791 RESTRAINT, R/SEAT HD (INCLS 8) (CASHMERE)
11562383 БОЛТ, HFH, M12X1.75X30.5, 17 THD, 26.6 OD, 10.9 STL, GMW3359, W/ADH 6175M (R/SEAT LAT)
15269762 FRAME, R/SEAT BK CUSH
15279469 COVER, R/SEAT A/RST SUPT FIN (EBONY)
15279470 COVER, R/SEAT A/RST SUPT FIN (CASHMERE)
15279471 COVER, R/SEAT A/RST SUPT FIN (TITANIUM)
15279472 COVER, R/SEAT A/RST SUPT FIN (CASHMERE)
15279489 COVER, R/SEAT BK CUSH HGE FIN (EBONY) (OUTBOARD, INNER) (16.674)
15279490 COVER, R/SEAT BK CUSH HGE FIN (CASHMERE) (OUTBOARD, INNER) (16.674)
15279491 COVER, R/SEAT BK CUSH HGE FIN (TITANIUM) (OUTBOARD, INNER) (16.674)
15279492 COVER, R/SEAT BK CUSH HGE FIN (CASHMERE) (OUTBOARD, INNER) (16.674)
19121589 BELT KIT, R/SEAT (BKL SI) (EBONY) (BKL/BKL)
19121590 BELT KIT, R/SEAT (BKL SI) (CASHMERE) (BKL/BKL)
19121591 BELT KIT, R/SEAT (BKL SI) (CASHMERE) (BKL/BKL)
19121592 BELT KIT, R/SEAT (BKL SI) (TITANIUM) (BKL/BKL)
15269764 FRAME, R/SEAT CUSH
15275886 LATCH, R/SEAT RSR
25896455 LATCH, R/SEAT BK CUSH (OUTBOARD)
15279479 COVER, R/SEAT BK CUSH HGE FIN (INCLS 49) (EBONY) (OUTBOARD, OUTER) (16.674)
15279480 COVER, R/SEAT BK CUSH HGE FIN (INCLS 49) (CASHMERE) (OUTBOARD, OUTER) (16.674)
15279481 COVER, R/SEAT BK CUSH HGE FIN (INCLS 49) (TITANIUM) (OUTBOARD, OUTER) (16.674)
15279482 COVER, R/SEAT BK CUSH HGE FIN (INCLS 49) (CASHMERE) (OUTBOARD, OUTER) (16.674)
15279414 HANDLE, R/SEAT RECL (INCLS 23) (EBONY)
15279415 HANDLE, R/SEAT RECL (INCLS 23) (CASHMERE)
15279416 HANDLE, R/SEAT RECL (INCLS 23) (TITANIUM)
15279417 HANDLE, R/SEAT RECL (INCLS 23) (CASHMERE)
15275917 CABLE, R/SEAT LAT (INBOARD) (FLOOR LATCH)
15275916 CABLE, R/SEAT LAT (INBOARD) (SYNCH)
15275912 CABLE, R/SEAT BK CUSH LAT
15279604 COVER, R/SEAT RSR FIN (EBONY) (REAR)
15279605 COVER, R/SEAT RSR FIN (CASHMERE) (REAR)
15279606 COVER, R/SEAT RSR FIN (TITANIUM) (REAR)
15279607 COVER, R/SEAT RSR FIN (CASHMERE) (REAR)
15269771 RISER, R/SEAT
15824753 COVER, R/SEAT RSR FIN (INCLS 31) (EBONY) (FRONT)
15824754 COVER, R/SEAT RSR FIN (INCLS 31) (CASHMERE) (FRONT)
15824755 COVER, R/SEAT RSR FIN (INCLS 31) (TITANIUM) (FRONT)
15824756 COVER, R/SEAT RSR FIN (INCLS 31) (CASHMERE) (FRONT)
15291599 PAD, R/SEAT CUSH
11571092 БОЛТ, R/SEAT HGE (M10X1.5X114)
15279549 PANEL, R/SEAT CUSH TR (EBONY) (16.716)
15279550 PANEL, R/SEAT CUSH TR (CASHMERE) (16.716)
15279551 PANEL, R/SEAT CUSH TR (TITANIUM) (16.716)
15279552 PANEL, R/SEAT CUSH TR (CASHMERE) (16.716)
15786704 MODULE, R/SEAT HTR CONT (REQUIRES DEALER PROGRAMMING) (11.500)
25862293 MODULE, R/SEAT HTR CONT (REQUIRES DEALER PROGRAMMING) (11.500) (SERV CMP OF HEATER PKGS)
25886638 MODULE, R/SEAT HTR CONT
15275900 ПРУЖИНА, R/SEAT RECL (TUMBLE)
15275902 ПРУЖИНА, R/SEAT RECL (MANDREL)
15279589 COVER, R/SEAT HGE LWR FIN (EBONY) (PIVOT INBOARD) (16.674)
15279590 COVER, R/SEAT HGE LWR FIN (CASHMERE) (PIVOT INBOARD) (16.674)
15279591 COVER, R/SEAT HGE LWR FIN (TITANIUM) (PIVOT INBOARD) (16.674)
15279592 COVER, R/SEAT HGE LWR FIN (CASHMERE) (PIVOT INBOARD) (16.674)
15269777 BRACKET, R/SEAT
11562381 БОЛТ, R/SEAT BK CUSH LAT PIV (M12X1.75X40)
15279594 COVER, R/SEAT HGE LWR FIN (EBONY) (PIVOT INBOARD) (16.674)
15279595 COVER, R/SEAT HGE LWR FIN (CASHMERE) (PIVOT INBOARD) (16.674)
15279596 COVER, R/SEAT HGE LWR FIN (TITANIUM) (PIVOT INBOARD) (16.674)
15279597 COVER, R/SEAT HGE LWR FIN (CASHMERE) (PIVOT INBOARD) (16.674)
15291655 COVER, R/SEAT CUSH (CASHMERE)
15291666 COVER, R/SEAT CUSH (EBONY)
15865514 COVER, R/SEAT CUSH (CASHMERE)
15865529 COVER, R/SEAT CUSH (EBONY) [ЧЕХОЛ ПОДУШКИ СИДЕНЬЯ]
15865530 COVER, R/SEAT CUSH (CASHMERE)
15865531 COVER, R/SEAT CUSH (TITANIUM)
15914206 COVER, R/SEAT CUSH (EBONY)
15939175 COVER, R/SEAT CUSH (EBONY/TITANIUM)
15939176 COVER, R/SEAT CUSH (EBONY/MOROCCO)
25863601 COVER, R/SEAT CUSH (EBONY)
25863603 COVER, R/SEAT CUSH (TITANIUM)
25899568 COVER, R/SEAT CUSH (CASHMERE)
15279499 COVER, R/SEAT BK CUSH HGE FIN (INCLS 49) (EBONY) (INBOARD, OUTER) (16.674)
15279500 COVER, R/SEAT BK CUSH HGE FIN (INCLS 49) (CASHMERE) (INBOARD, OUTER) (16.674)
15279501 COVER, R/SEAT BK CUSH HGE FIN (INCLS 49) (TITANIUM) (INBOARD, OUTER) (16.674)
15279502 COVER, R/SEAT BK CUSH HGE FIN (INCLS 49) (CASHMERE) (INBOARD, OUTER) (16.674)
11562376 SCREW-PAN HD, M12X1.75X55, 42 THD, 27 OD, 10.9, S424, W/ADH GM6175M (R/SEAT LAT)
25896456 LATCH, R/SEAT BK CUSH (INBOARD)
11562377 BOLT-HFH, M10X1.5X55, 43.45 THD, 22.3 OD, 10.9, GMW3359, W/ADH GM6175M (R/SEAT LAT)
15279525 COVER, R/SEAT BK CUSH HGE FIN (EBONY) (INBOARD, INNER) (16.674)
15279526 COVER, R/SEAT BK CUSH HGE FIN (CASHMERE) (INBOARD, INNER) (16.674)
15279527 COVER, R/SEAT BK CUSH HGE FIN (TITANIUM) (INBOARD, INNER) (16.674)
15279528 COVER, R/SEAT BK CUSH HGE FIN (CASHMERE) (INBOARD, INNER) (16.674)
15275857 ARMREST, R/SEAT (EBONY)
15275858 ARMREST, R/SEAT (CASHMERE)
15865490 ARMREST, R/SEAT (CASHMERE)
15865493 ARMREST, R/SEAT (EBONY)
15865494 ARMREST, R/SEAT (CASHMERE)
15865495 ARMREST, R/SEAT (TITANIUM)
25863535 ARMREST, R/SEAT (EBONY)
25866393 ARMREST, R/SEAT (CASHMERE)
15275887 LATCH, R/SEAT RSR (INBOARD)
11562386 БОЛТ, R/SEAT A/RST (M8X1.25X24) (8.977)
teamcadillac.ru
19151104 BELT KIT, R/SEAT CTR (RETR SI) (EBONY)
19151105 BELT KIT, R/SEAT CTR (RETR SI) (CASHMERE)
19151106 BELT KIT, R/SEAT CTR (RETR SI) (TITANIUM)
19151107 BELT KIT, R/SEAT CTR (RETR SI) (CASHMERE)
(TC16-393) - 2007 CK107(06) ЗАДНЕЕ СИДЕНЬЕ/BENCH-40% SIDE (AM8, POWER FOLDING ARS)
15843841 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
15843842 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (CASHMERE)
15843847 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
15843848 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (CASHMERE)
15843859 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY) [СИДЕНЬЕ В СБОРЕ]
15843860 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (CASHMERE)
15865243 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
15865244 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (CASHMERE)
15865245 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (TITANIUM)
15939114 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
15939115 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
15279504 COVER, R/SEAT BK CUSH HGE FIN (INCLS 41) (EBONY) (INBOARD, OUTER) (16.674)
15279505 COVER, R/SEAT BK CUSH HGE FIN (INCLS 41) (CASHMERE) (INBOARD, OUTER) (16.674)
15279506 COVER, R/SEAT BK CUSH HGE FIN (INCLS 41) (TITANIUM) (INBOARD, OUTER)
15279507 COVER, R/SEAT BK CUSH HGE FIN (INCLS 41) (CASHMERE) (INBOARD, OUTER) (16.674)
15843763 HARNESS, ST RECL WRG (ELEMENT)
15942229 CABLE, R/SEAT BK CUSH LAT
15279419 HANDLE, R/SEAT RECL (INCLS 39) (EBONY)
15279420 HANDLE, R/SEAT RECL (INCLS 39) (CASHMERE)
15279429 HANDLE, R/SEAT RECL (INCLS 39) (TITANIUM)
15279430 HANDLE, R/SEAT RECL (INCLS 39) (CASHMERE)
15279484 COVER, R/SEAT BK CUSH HGE FIN (INCLS 41) (EBONY) (OUTBOARD, OUTER) (16.674)
teamcadillac.ru
15279485 COVER, R/SEAT BK CUSH HGE FIN (INCLS 41) (CASHMERE) (OUTBOARD, OUTER) (16.674)
15279486 COVER, R/SEAT BK CUSH HGE FIN (INCLS 41) (TITANIUM) (OUTBOARD, OUTER) (16.674)
15279487 COVER, R/SEAT BK CUSH HGE FIN (INCLS 41) (CASHMERE) (OUTBOARD, OUTER) (16.674)
(TC16-394) - 2007 CK107(06) ЗАДНЕЕ СИДЕНЬЕ/BENCH-60% SIDE (AM8, POWER FOLDING ARS)
15867285 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
15867286 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (CASHMERE)
15867287 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (TITANIUM)
15867301 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
15867302 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (CASHMERE)
15867307 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
15867308 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (CASHMERE)
15939112 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
15939113 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
teamcadillac.ru
15942228 CABLE, R/SEAT BK CUSH LAT
15824751 ACTUATOR, R/SEAT RECL (INCLS CABLE) [ЭЛЕКТРОДВИГАТЕЛЬ РЕГУЛИРОВКИ ПОЛОЖЕНИЯ СИДЕНЬЯ 90 ВТ]
(TC16-395) - 2007-2009 CK107(06) ЗАДНЕЕ СИДЕНЬЕ/BUCKET-LH (BUCKET AL4)
15842713 SEAT, RR (INCLS 2-49) (EBONY)
15842714 SEAT, RR (INCLS 2-49) (CASHMERE)
15842719 SEAT, RR (INCLS 2-49) (EBONY)
15842720 SEAT, RR (INCLS 2-49) (CASHMERE)
15843781 SEAT, RR (INCLS 2-49) (EBONY)
15843782 SEAT, RR (INCLS 2-49) (CASHMERE)
15843787 SEAT, RR (INCLS 2-49) (EBONY)
15843788 SEAT, RR (INCLS 2-49) (CASHMERE)
15843911 SEAT, RR (INCLS 2-49) (EBONY)
15843912 SEAT, RR (INCLS 2-49) (CASHMERE)
15843932 SEAT, RR (INCLS 2-49) (EBONY)
15843933 SEAT, RR (INCLS 2-49) (CASHMERE)
15865172 SEAT, RR (INCLS 2-49) (EBONY)
15865173 SEAT, RR (INCLS 2-49) (CASHMERE)
15865174 SEAT, RR (INCLS 2-49) (TITANIUM)
15865191 SEAT, RR (INCLS 2-49) (EBONY)
15865192 SEAT, RR (INCLS 2-49) (CASHMERE)
15865193 SEAT, RR (INCLS 2-49) (TITANIUM)
15939077 SEAT, RR (INCLS 2-49) (EBONY/TITANIUM)
15939078 SEAT, RR (INCLS 2-49) (EBONY/MOROCCO)
15939092 SEAT, RR (INCLS 2-49) (EBONY/TITANIUM)
15939093 SEAT, RR (INCLS 2-49) (EBONY/MOROCCO)
15291701 COVER, R/SEAT BK CUSH (CASHMERE)
15865718 COVER, R/SEAT BK CUSH (EBONY)
15865719 COVER, R/SEAT BK CUSH (CASHMERE)
15865720 COVER, R/SEAT BK CUSH (TITANIUM)
15939122 COVER, R/SEAT BK CUSH (EBONY/TITANIUM)
15939123 COVER, R/SEAT BK CUSH (EBONY/MOROCCO)
25899573 COVER, R/SEAT BK CUSH (EBONY)
25899574 COVER, R/SEAT BK CUSH (CASHMERE)
25928766 COVER, R/SEAT BK CUSH (EBONY)
25928767 COVER, R/SEAT BK CUSH (CASHMERE)
15291601 PAD, R/SEAT BK CUSH
teamcadillac.ru
15269768 FRAME, R/SEAT BK CUSH
15275870 ARMREST, R/SEAT (EBONY)
15275871 ARMREST, R/SEAT (CASHMERE)
15825652 ARMREST, R/SEAT (CASHMERE)
15865497 ARMREST, R/SEAT (EBONY)
15865498 ARMREST, R/SEAT (CASHMERE)
15865499 ARMREST, R/SEAT (TITANIUM)
15291603 PAD, R/SEAT CUSH
15269770 FRAME, R/SEAT CUSH
15280108 COVER, R/SEAT RECL INR FIN (EBONY) (INNER)
15280109 COVER, R/SEAT RECL INR FIN (CASHMERE) (INNER)
15280110 COVER, R/SEAT RECL INR FIN (TITANIUM) (INNER)
15280111 COVER, R/SEAT RECL INR FIN (CASHMERE) (INNER)
15279714 COVER, R/SEAT RECL INR FIN (INCLS 42) (EBONY) (OUTER)
15279715 COVER, R/SEAT RECL INR FIN (INCLS 42) (CASHMERE) (OUTER)
15279716 COVER, R/SEAT RECL INR FIN (INCLS 42) (TITANIUM) (OUTER)
15279717 COVER, R/SEAT RECL INR FIN (INCLS 42) (CASHMERE) (OUTER)
19121601 BELT KIT, R/SEAT (BKL SI) (EBONY)
19121602 BELT KIT, R/SEAT (BKL SI) (CASHMERE)
19121603 BELT KIT, R/SEAT (BKL SI) (CASHMERE)
19121604 BELT KIT, R/SEAT (BKL SI) (TITANIUM)
15275898 RECLINER, R/SEAT INR (USED ON VEHICLES BUILT PRIOR TO JUNE 1, 2006) (2ND DES SEE 25896461)
25896461 RECLINER, R/SEAT INR (WHEN SERVICING VEHICLES BUILT PRIOR TO 06/01/06, DEALER NEEDS TO REPLACE BOTH INNER AND OUTER IN SETS) (USED ON VEHICLES BUILT AFTER MAY 31, 2006) (1ST DES SEE 15275898)
15280118 PANEL, R/SEAT CUSH TR (EBONY) (16.716)
15280119 PANEL, R/SEAT CUSH TR (CASHMERE) (16.716)
15280120 PANEL, R/SEAT CUSH TR (TITANIUM) (16.716)
15280121 PANEL, R/SEAT CUSH TR (CASHMERE) (16.716)
15280128 COVER, R/SEAT RSR FIN (EBONY) (REAR)
15280129 COVER, R/SEAT RSR FIN (CASHMERE) (REAR)
15280130 COVER, R/SEAT RSR FIN (TITANIUM) (REAR)
15280131 COVER, R/SEAT RSR FIN (CASHMERE) (REAR)
15269775 RISER, R/SEAT
15279599 COVER, R/SEAT RSR FIN (INCLS 33) (EBONY) (FRONT)
15279600 COVER, R/SEAT RSR FIN (INCLS 33) (CASHMERE) (FRONT)
15279601 COVER, R/SEAT RSR FIN (INCLS 33) (TITANIUM) (FRONT)
15279602 COVER, R/SEAT RSR FIN (INCLS 33) (CASHMERE) (FRONT)
25896459 RECLINER, R/SEAT OTR (WHEN SERVICING VEHICLES BUILT PRIOR TO 06/01/06, DEALER NEEDS TO REPLACE BOTH INNER & OUTER IN SETS)
15279414 HANDLE, R/SEAT RECL (INCLS 43) (EBONY)
15279415 HANDLE, R/SEAT RECL (INCLS 43) (CASHMERE)
15279416 HANDLE, R/SEAT RECL (INCLS 43) (TITANIUM)
15279417 HANDLE, R/SEAT RECL (INCLS 43) (CASHMERE)
15279694 COVER, R/SEAT RECL OTR FIN (INCLS 42) (EBONY) (OUTER)
15279695 COVER, R/SEAT RECL OTR FIN (INCLS 42) (CASHMERE) (OUTER)
15279696 COVER, R/SEAT RECL OTR FIN (INCLS 42) (TITANIUM) (OUTER)
15279697 COVER, R/SEAT RECL OTR FIN (INCLS 42) (CASHMERE) (OUTER) [КОЖУХ МЕХАНИЗМА РЕГУЛИРОВКИ ПОЛОЖЕНИЯ СИДЕНИЯ]
15279704 COVER, R/SEAT RECL OTR FIN (EBONY) (INNER)
15279705 COVER, R/SEAT RECL OTR FIN (CASHMERE) (INNER)
15279706 COVER, R/SEAT RECL OTR FIN (TITANIUM) (INNER)
15279707 COVER, R/SEAT RECL OTR FIN (CASHMERE) (INNER)
15865726 COVER, R/SEAT CUSH (EBONY)
15865727 COVER, R/SEAT CUSH (CASHMERE)
15865728 COVER, R/SEAT CUSH (TITANIUM)
15939155 COVER, R/SEAT CUSH (EBONY/MOROCCO)
25899561 COVER, R/SEAT CUSH (EBONY)
25899562 COVER, R/SEAT CUSH (CASHMERE)
25928778 COVER, R/SEAT CUSH (EBONY)
25928779 COVER, R/SEAT CUSH (CASHMERE)
15275906 ACTUATOR, R/SEAT RECL (INCLS CABLE)
(TC16-399) - 2007-2009 CK1,2(06) ЗАДНЕЕ СИДЕНЬЕ #2-LH(AS3)
15898107 SEAT, RR #2 (INCLS 2-42) (CASHMERE) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
15898108 SEAT, RR #2 (INCLS 2-42) (TITANIUM) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
15898162 SEAT, RR #2 (INCLS 2-42) (EBONY) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
15898172 SEAT, RR #2 (INCLS 2-42) (TITANIUM) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
15898179 SEAT, RR #2 (INCLS 2-42) (CASHMERE) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
15925493 SEAT, RR #2 (INCLS 2-42) (EBONY/MOROCCO)
15925567 SEAT, RR #2 (INCLS 2-42) (EBONY/TITANIUM)
20858956 SEAT, RR #2 (INCLS 2-42) (EBONY) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
25782021 SEAT, RR #2 (INCLS 2-42) (EBONY) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
25869767 SEAT, RR #2 (INCLS 2-42) (EBONY) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
25869768 SEAT, RR #2 (INCLS 2-42) (CASHMERE) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
25917040 SEAT, RR #2 (INCLS 2-42) (EBONY)
25917050 SEAT, RR #2 (INCLS 2-42) (TITANIUM)
25917105 SEAT, RR #2 (INCLS 2-42) (CASHMERE)
25917106 SEAT, RR #2 (INCLS 2-42) (TITANIUM)
25917112 SEAT, RR #2 (INCLS 2-42) (EBONY)
25917113 SEAT, RR #2 (INCLS 2-42) (CASHMERE)
25917130 SEAT, RR #2 (INCLS 2-42) (EBONY) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
25917131 SEAT, RR #2 (INCLS 2-42) (CASHMERE)
25950380 SEAT, RR #2 (INCLS 2-42) (EBONY)
25950387 SEAT, RR #2 (INCLS 2-42) (CASHMERE)
25950893 SEAT, RR #2 (INCLS 2-42) (EBONY)
15804530 PAD, R/SEAT #2 BK CUSH
15827635 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE)
15827636 RESTRAINT, R/SEAT HD (INCLS 3) (TITANIUM)
15827642 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
15827646 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE) [ПОДГОЛОВНИК ЗАДНЕГО СИДЕНЬЯ]
15833505 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
15863451 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
15863452 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE)
15863456 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE)
15863458 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
15863459 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE)
15865842 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
20758001 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
20758002 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE)
20758003 RESTRAINT, R/SEAT HD (INCLS 3) (TITANIUM)
25863504 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
15279347 GUIDE, R/SEAT #2 H/RST (EBONY) (W/BUTTON)
15279348 GUIDE, R/SEAT #2 H/RST (CASHMERE) (W/BUTTON)
15279349 GUIDE, R/SEAT #2 H/RST (TITANIUM) (W/BUTTON)
15279351 GUIDE, R/SEAT #2 H/RST (EBONY) (W/O BUTTON)
15279352 GUIDE, R/SEAT #2 H/RST (CASHMERE) (W/O BUTTON)
15279353 GUIDE, R/SEAT #2 H/RST (TITANIUM) (W/O BUTTON)
15279441 GUIDE, R/SEAT #2 H/RST (CASHMERE) (W/O BUTTON)
25869335 BRACKET, R/SEAT #2 BELT (RETR SI)
11562382 БОЛТ, HFH, M10X1.5X130, 26 THD, 22.3 OD, 10.9, 7114M, MACH, MAT-PT (R/SEAT #2 BK CUSH)
19121606 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (CASHMERE) (USED FOR RH & LH SIDES)
19121607 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (CASHMERE) (USED FOR RH & LH SIDES)
19151108 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (EBONY) (USED FOR RH & LH SIDES)
19152513 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (CASHMERE) (HAS LOWER ANCHOR PLATE W/SLOT AND HOLE) (FOR 1ST DES SEE 19121606)
19207594 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (EBONY) (HAS LOWER ANCHOR PLATE S/SLOT AND HOLE) (FOR 1ST DES SEE 19151108)
19207595 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (CASHMERE) (HAS LOWER ANCHOR PLATE W/SLOT AND HOLE) (FOR 1ST DES SEE 19121607)
teamcadillac.ru
25778330 BELT, R/SEAT #2 (RETR SI) (INCLS 8) (CASHMERE) (USED ON VEHICLES BUILT ON OR AFTER VINS 7R170871 & 7J171621) (FOR 1ST DES SEE 15853691) [РЕМЕНЬ БЕЗОПАСНОСТИ]
25869317 BELT, R/SEAT #2 (RETR SI) (INCLS 8) (EBONY) (USED ON VEHICLES BUILT 0N OR AFTER VINS 7R170871 & 7J171621) (FOR 1ST DES SEE 15853690)
15827657 COVER, R/SEAT HGE FIN (O/B)
12478382 БОЛТ, R/SEAT #2 (M10X1.50X28.0) [БОЛТ]
15279464 KNOB, R/SEAT #2 BK CUSH LAT REL (EBONY) (USED IN PLACE OF ALL COLORS) (16.716)
15898412 COVER, R/SEAT #2 BK CUSH LAT (EBONY) (OUTBOARD, OUTER) (16.716) [БОКОВАЯ КРЫШКА СИДЕНИЯ]
15898413 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (OUTBOARD, OUTER) (16.716)
15898414 COVER, R/SEAT #2 BK CUSH LAT (TITANIUM) (OUTBOARD, OUTER) (16.716)
15898415 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (OUTBOARD, OUTER) [ЧЕХОЛ СПИНКИ СИДЕНЬЯ]
19127809 БОЛТ, R/SEAT #2 BK CUSH LAT (M12X1.75X63.9) (16.679)
15804503 COVER, R/SEAT #2 BK CUSH LAT (EBONY) (OUTBOARD, INNER) (16.716)
15804504 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (OUTBOARD, INNER) (16.716)
15804505 COVER, R/SEAT #2 BK CUSH LAT (TITANIUM) (OUTBOARD, INNER) (16.716)
15804506 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (OUTBOARD, INNER) (16.716)
15822356 HANDLE, R/SEAT LAT REL (PART OF 26) (EBONY)
15822357 HANDLE, R/SEAT LAT REL (PART OF 26) (CASHMERE)
15822358 HANDLE, R/SEAT LAT REL (PART OF 26) (TITANIUM)
15822359 HANDLE, R/SEAT LAT REL (PART OF 26) (CASHMERE)
25928520 LATCH, R/SEAT #2 BK CUSH (SIDE)
15804483 COVER, R/SEAT #2 BK CUSH LAT (EBONY) (REAR CLOSEOUT) (16.716)
15804484 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (REAR CLOSEOUT) (16.716)
15804485 COVER, R/SEAT #2 BK CUSH LAT (TITANIUM) (REAR CLOSEOUT) (16.716)
15804486 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (REAR CLOSEOUT) (16.716)
15898401 LATCH, R/SEAT #2 LOAD FLR
15804488 COVER, R/SEAT #2 BK CUSH LAT (EBONY) (FRONT CLOSEOUT) (16.716)
15804489 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (FRONT CLOSEOUT) (16.716)
15804490 COVER, R/SEAT #2 BK CUSH LAT (TITANIUM) (FRONT CLOSEOUT) (16.716)
15804491 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (FRONT CLOSEOUT) (16.716)
15804397 LATCH, R/SEAT #2 LOAD FLR (OUTBOARD REAR)
15804404 CABLE, R/SEAT #2 BK CUSH LAT (LOCK OUT)
15832238 CABLE, R/SEAT #2 BK CUSH LAT (INCLS 18) (EBONY) (W/PULL HANDLE) (50% MAIN CONTROL BOX)
15832239 CABLE, R/SEAT #2 BK CUSH LAT (INCLS 18) (CASHMERE) (W/PULL HANDLE) (50% MAIN CONTROL BOX)
15832240 CABLE, R/SEAT #2 BK CUSH LAT (INCLS 18) (TITANIUM) (W/PULL HANDLE) (50% MAIN CONTROL BOX)
15832241 CABLE, R/SEAT #2 BK CUSH LAT (INCLS 18) (CASHMERE) (W/PULL HANDLE) (50% MAIN CONTROL BOX)
15791115 FRAME, R/SEAT #2 CUSH
15822389 COVER, R/SEAT #2 BK CUSH HGE FIN (EBONY) (INBOARD, OUTER)
15822390 COVER, R/SEAT #2 BK CUSH HGE FIN (CASHMERE) (INBOARD, OUTER)
15822391 COVER, R/SEAT #2 BK CUSH HGE FIN (TITANIUM)
15822392 COVER, R/SEAT #2 BK CUSH HGE FIN (CASHMERE) (INBOARD, OUTER)
15832214 LEVER, R/SEAT RSR LAT REL
15924950 COVER, R/SEAT #2 BK CUSH HGE FIN (EBONY) (PIVOT PROTECTOR)
15924951 COVER, R/SEAT #2 BK CUSH HGE FIN (CASHMERE) (PIVOT PROTECTOR)
15924952 COVER, R/SEAT #2 BK CUSH HGE FIN (TITANIUM) (PIVOT PROTECTOR)
15924953 COVER, R/SEAT #2 BK CUSH HGE FIN (CASHMERE)
15833812 RETAINER, R/SEAT CUSH FRM
15791111 FRAME, R/SEAT #2 BK CUSH (USED ON VEHICLES WITH VIN 7R170870 & 7J141620 & PRIOR) (FOR 2ND DES SEE 15898363)
15827632 FRAME, R/SEAT #2 BK CUSH (USED ON VEHICLES WITH VIN 7R170870 & 7J141620 & PRIOR) (FOR 2ND DES SEE 15898400)
15898363 FRAME, R/SEAT #2 BK CUSH (USED ON VEHICLES WITH VIN 7R170871 & 7J141621 & AFTER) (FOR 1ST DES SEE 15791111)
15898400 FRAME, R/SEAT #2 BK CUSH (USED ON VEHICLES WITH VIN 7R170871 & 7J141621 & AFTER) (FOR 1ST DES SEE 15827632)
19152519 BELT KIT, R/SEAT #2 (BKL SI) (CASHMERE) (BKL/BKL) (USED ON VEHICLES BUILT WITH AND AFTER VINS 7R170871 & 7J171621) (FOR 1ST DES SEE 19121549)
19152520 BELT KIT, R/SEAT #2 (BKL SI) (TITANIUM) (BKL/BKL) (USED ON VEHICLES BUILT WITH AND AFTER 7R170871 & 7J171621) (FOR 1ST DES 19121550)
19152521 BELT KIT, R/SEAT #2 (BKL SI) (CASHMERE) (BKL/BKL) (USED ON VEHICLES BUILT WITH AND AFTER VINS 7R170871 & 7J171621) (FOR 1ST DES SEE 19121551)
15804534 PAD, R/SEAT #2 CUSH
15865758 COVER, R/SEAT #2 CUSH (EBONY)
15865759 COVER, R/SEAT #2 CUSH (CASHMERE)
15865760 COVER, R/SEAT #2 CUSH (TITANIUM)
15865801 COVER, R/SEAT #2 CUSH (EBONY)
15865802 COVER, R/SEAT #2 CUSH (CASHMERE)
15865803 COVER, R/SEAT #2 CUSH (TITANIUM)
15925482 COVER, R/SEAT #2 CUSH (EBONY/MOROCCO)
15925510 COVER, R/SEAT #2 CUSH (EBONY/TITANIUM)
25928513 COVER, R/SEAT #2 CUSH (EBONY)
25928514 COVER, R/SEAT #2 CUSH (CASHMERE)
15865750 COVER, R/SEAT #2 BK CUSH (EBONY)
15865751 COVER, R/SEAT #2 BK CUSH (CASHMERE)
15865752 COVER, R/SEAT #2 BK CUSH (TITANIUM)
15865793 COVER, R/SEAT #2 BK CUSH (EBONY) (INCLS CHILD COMFORT GUIDE)
15865794 COVER, R/SEAT #2 BK CUSH (CASHMERE) (INCLS CHILD COMFORT GUIDE)
15865795 COVER, R/SEAT #2 BK CUSH (TITANIUM) (INCLS CHILD COMFORT GUIDE)
15925480 COVER, R/SEAT #2 BK CUSH (EBONY/MOROCCO) (INCLS CHILD COMFORT GUIDE)
15925508 COVER, R/SEAT #2 BK CUSH (EBONY/TITANIUM) (INCLS CHILD COMFORT GUIDE)
25928505 COVER, R/SEAT #2 BK CUSH (EBONY) (INCLS CHILD COMFORT GUIDE)
25928506 COVER, R/SEAT #2 BK CUSH (CASHMERE) (INCLS CHILD COMFORT GUIDE)
88936748 CAP, R/SEAT ADJR TRK END (BLACK)
15924919 PANEL, R/SEAT BK CUSH FIL
15924924 RETAINER, R/SEAT BK CUSH OPG FIN CVR (PUSH IN)
15924917 WIRE, R/SEAT CUSH BRDR
(TC16-401) - 2007 CK107(06) ЗАДНЕЕ СИДЕНЬЕ #2-RH(AS3)(1ST DES)
15898111 SEAT, RR #2 (INCLS 2-44) (CASHMERE) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
15898176 SEAT, RR #2 (INCLS 2-44) (TITANIUM) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
15898182 SEAT, RR #2 (INCLS 2-44) (CASHMERE) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
15925494 SEAT, RR #2 (INCLS 2-44) (EBONY/MOROCCO)
15925507 SEAT, RR #2 (INCLS 2-44) (EBONY/TITANIUM)
20858957 SEAT, RR #2 (INCLS 2-44) (EBONY) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
25782024 SEAT, RR #2 (INCLS 2-44) (EBONY) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
25869773 SEAT, RR #2 (INCLS 2-44) (EBONY) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
25869774 SEAT, RR #2 (INCLS 2-44) (CASHMERE) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
25869847 SEAT, RR #2 (INCLS 2-44) (EBONY)
25869853 SEAT, RR #2 (INCLS 2-44) (EBONY) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
25917044 SEAT, RR #2 (INCLS 2-44) (EBONY)
25917056 SEAT, RR #2 (INCLS 2-44) (TITANIUM)
25917108 SEAT, RR #2 (INCLS 2-44) (EBONY)
25917109 SEAT, RR #2 (INCLS 2-44) (CASHMERE)
25917110 SEAT, RR #2 (INCLS 2-44) (TITANIUM)
25917118 SEAT, RR #2 (INCLS 2-44) (EBONY)
25917119 SEAT, RR #2 (INCLS 2-44) (CASHMERE)
25917134 SEAT, RR #2 (INCLS 2-44) (CASHMERE)
25950391 SEAT, RR #2 (INCLS 2-44) (CASHMERE)
15804529 PAD, R/SEAT #2 BK CUSH
15853693 BELT, R/SEAT #2 CTR (INCLS 8) (EBONY) (USED ON VEHICLES BUILT PRIOR TO VINS 7R170871 & 7J171621) (FOR 2ND DES SEE 15898352)
15853694 BELT, R/SEAT #2 CTR (INCLS 8) (CASHMERE) (USED ON VEHICLES BUILT PRIOR TO VINS 7R170871 & 7J171621) (FOR 2ND DES SEE 15898353)
15791110 FRAME, R/SEAT #2 BK CUSH (USED ON VEHICLES WITH VIN 7R170870 & 7J141620 & PRIOR) (FOR 2ND DES SEE 15898362)
15827631 FRAME, R/SEAT #2 BK CUSH (USED ON VEHICLES WITH VIN 7R170870 & 7J141620 & PRIOR) (FOR 2ND DES SEE 15898399)
19121552 BELT KIT, R/SEAT #2 (BKL SI) (EBONY) (SINGLE BKL) (USED ON VEHICLES BUILT PRIOR TO VINS 7R170871 & 7J171621) (FOR 2ND DES SEE 19152522)
19121553 BELT KIT, R/SEAT #2 (BKL SI) (CASHMERE) (SINGLE BKL) (USED ON VEHICLES BUILT PRIOR TO VINS 7R170871 & 7J171621) (FOR 2ND DES SEE 19152523)
19121554 BELT KIT, R/SEAT #2 (BKL SI) (TITANIUM) (SINGLE BKL) (USED ON VEHICLES BUILT PRIOR TO VINS 7R170871 & 7J171621) (FOR 2ND DES SEE 19152524)
19121555 BELT KIT, R/SEAT #2 (BKL SI) (CASHMERE) (SINGLE BKL) (USED ON VEHICLES BUILT PRIOR TO VINS 7R170871 & 7J171621) (FOR 2ND DES SEE 19152525)
19152522 BELT KIT, R/SEAT #2 (BKL SI) (EBONY) (SINGLE BKL) (USED ON VEHICLES BUILT WITH AND AFTER VINS 7R170871 & 7J171621) (FOR 1ST DES SEE 19121552)
25913455 LATCH, R/SEAT #2 BK CUSH (CENTER) [ЗАЩЕЛКА МЕХАНИЗМА РЕГУЛИРОВКИ ПОЛОЖЕНИЯ СИДЕНЬЯ]
15804520 COVER, R/SEAT #2 BK CUSH LAT (EBONY) (INBOARD, OUTER) (16.716)
15804522 COVER, R/SEAT #2 BK CUSH LAT (TITANIUM) (INBOARD, OUTER) (16.716)
15804523 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (INBOARD, OUTER) (16.716)
15944450 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (INBOARD, OUTER)
15822384 COVER, R/SEAT #2 BK CUSH HGE FIN (EBONY)
15822385 COVER, R/SEAT #2 BK CUSH HGE FIN (CASHMERE)
15822386 COVER, R/SEAT #2 BK CUSH HGE FIN (TITANIUM)
15822387 COVER, R/SEAT #2 BK CUSH HGE FIN (CASHMERE)
15804515 COVER, R/SEAT #2 BK CUSH LAT (EBONY) (INBOARD, INNER)
15804517 COVER, R/SEAT #2 BK CUSH LAT (TITANIUM) (INBOARD, INNER)
15898418 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (INBOARD, INNER) (16.716)
15898420 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (INBOARD, INNER)
15822356 HANDLE, R/SEAT LAT REL (PART OF 28) (EBONY)
15822357 HANDLE, R/SEAT LAT REL (PART OF 28) (CASHMERE)
15822358 HANDLE, R/SEAT LAT REL (PART OF 28) (TITANIUM)
15822359 HANDLE, R/SEAT LAT REL (PART OF 28) (CASHMERE)
25913454 CABLE, R/SEAT #2 BK CUSH LAT
15804399 LATCH, R/SEAT #2 LOAD FLR (INBOARD REAR)
15832238 CABLE, R/SEAT #2 BK CUSH LAT (INCLS 23) (EBONY) (W/PULL HANDLE) (50% MAIN CONTROL BOX)
15832239 CABLE, R/SEAT #2 BK CUSH LAT (INCLS 23) (CASHMERE) (W/PULL HANDLE) (50% MAIN CONTROL BOX)
15832240 CABLE, R/SEAT #2 BK CUSH LAT (INCLS 23) (TITANIUM) (W/PULL HANDLE) (50% MAIN CONTROL BOX)
15832241 CABLE, R/SEAT #2 BK CUSH LAT (INCLS 23) (CASHMERE) (W/PULL HANDLE) (50% MAIN CONTROL BOX)
15804473 COVER, R/SEAT #2 BK CUSH LAT (EBONY) (REAR CLOSEOUT) (16.716)
15804474 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (REAR CLOSEOUT) (16.716)
15804475 COVER, R/SEAT #2 BK CUSH LAT (TITANIUM) (REAR CLOSEOUT) (16.716)
15804476 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (REAR CLOSEOUT) (16.716)
15898402 LATCH, R/SEAT #2 LOAD FLR
15804478 COVER, R/SEAT #2 BK CUSH LAT (EBONY) (FRONT CLOSEOUT) (16.716)
15804479 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (FRONT CLOSEOUT) (16.716)
15804480 COVER, R/SEAT #2 BK CUSH LAT (TITANIUM) (FRONT CLOSEOUT) (16.716)
15804481 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (FRONT CLOSEOUT) (16.716)
15791114 FRAME, R/SEAT #2 CUSH (USED ON VEHICLES WITH VIN 7R170870 & 7J141620 AND PRIOR) ( FOR 2ND DES SEE 15926524)
15898407 COVER, R/SEAT #2 BK CUSH LAT (EBONY) (OUTBOARD, OUTER)
15898408 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (OUTBOARD, OUTER)
15898409 COVER, R/SEAT #2 BK CUSH LAT (TITANIUM) (OUTBOARD, OUTER) (16.716)
15898410 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (OUTBOARD, OUTER)
25928521 LATCH, R/SEAT #2 BK CUSH
15804493 COVER, R/SEAT #2 BK CUSH LAT (EBONY) (OUTBOARD, INNER) (16.716)
15804494 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (OUTBOARD, INNER) (16.716)
15804495 COVER, R/SEAT #2 BK CUSH LAT (TITANIUM) (OUTBOARD, INNER) (16.716)
15804496 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (OUTBOARD, INNER) (16.716)
teamcadillac.ru
15804533 PAD, R/SEAT #2 CUSH
15865762 COVER, R/SEAT #2 CUSH (EBONY)
15865763 COVER, R/SEAT #2 CUSH (CASHMERE)
15865764 COVER, R/SEAT #2 CUSH (TITANIUM)
15865805 COVER, R/SEAT #2 CUSH (EBONY)
15865806 COVER, R/SEAT #2 CUSH (CASHMERE)
15865807 COVER, R/SEAT #2 CUSH (TITANIUM)
15925483 COVER, R/SEAT #2 CUSH (EBONY/MOROCCO)
25928487 COVER, R/SEAT #2 CUSH (EBONY/TITANIUM)
25928517 COVER, R/SEAT #2 CUSH (EBONY)
25928518 COVER, R/SEAT #2 CUSH (CASHMERE)
15865754 COVER, R/SEAT #2 BK CUSH (EBONY)
15865755 COVER, R/SEAT #2 BK CUSH (CASHMERE)
15865756 COVER, R/SEAT #2 BK CUSH (TITANIUM)
15865797 COVER, R/SEAT #2 BK CUSH (EBONY) (INCLS CHILD COMFORT GUIDE)
15865798 COVER, R/SEAT #2 BK CUSH (CASHMERE) (INCLS CHILD COMFORT GUIDE)
15865799 COVER, R/SEAT #2 BK CUSH (TITANIUM) (INCLS CHILD COMFORT GUIDE)
15925481 COVER, R/SEAT #2 BK CUSH (EBONY/MOROCCO) (INCLS CHILD COMFORT GUIDE)
15925509 COVER, R/SEAT #2 BK CUSH (EBONY/TITANIUM) (INCLS CHILD COMFORT GUIDE)
25928509 COVER, R/SEAT #2 BK CUSH (EBONY) (INCLS CHILD COMFORT GUIDE)
25928510 COVER, R/SEAT #2 BK CUSH (CASHMERE)
15924920 PANEL, R/SEAT BK CUSH FIL
(TC16-403) - 2007-2008 CK107(06) АРМАТУРА СИДЕНЬЯ/ЗАДНЕЕ СИДЕНЬЕ #2 STRIKERS(AS3,AW2)
11515775 БОЛТ, HFH, M12X1.75X30, 10.9, 7114M (R/SEAT #2 RSR LAT STKR) [БОЛТ]
15013755 STRIKER, R/SEAT #2 RSR LAT (LOWER)
15038813 STRIKER, R/SEAT #2 RSR LAT (OUTER) (INCLS UPPER & LOWER)
teamcadillac.ru
15038814 STRIKER, R/SEAT #2 RSR LAT (CENTER)
15076678 INSULATOR, R/SEAT #2 RSR LAT
(TC16-405) - 2007-2008 CK1,2(06) ЗАДНЕЕ СИДЕНЬЕ #2 (AW2)
15898134 SEAT, RR #2 (INCLS 2-39) (EBONY)
15898135 SEAT, RR #2 (INCLS 2-39) (CASHMERE)
15898136 SEAT, RR #2 (INCLS 2-39) (TITANIUM)
15898138 SEAT, RR #2 (INCLS 2-39) (EBONY)
15898139 SEAT, RR #2 (INCLS 2-39) (CASHMERE)
15898140 SEAT, RR #2 (INCLS 2-39) (TITANIUM)
15898142 SEAT, RR #2 (INCLS 2-39) (EBONY)
15898143 SEAT, RR #2 (INCLS 2-39) (CASHMERE)
15898144 SEAT, RR #2 (INCLS 2-39) (TITANIUM)
15898147 SEAT, RR #2 (INCLS 2-39) (CASHMERE)
15898148 SEAT, RR #2 (INCLS 2-39) (TITANIUM)
15898156 SEAT, RR #2 (INCLS 2-39) (EBONY)
15898157 SEAT, RR #2 (INCLS 2-39) (CASHMERE)
15898159 SEAT, RR #2 (INCLS 2-39) (EBONY)
15898160 SEAT, RR #2 (INCLS 2-39) (CASHMERE)
15898191 SEAT, RR #2 (INCLS 2-39) (CASHMERE)
15898192 SEAT, RR #2 (INCLS 2-39) (TITANIUM)
15898195 SEAT, RR #2 (INCLS 2-39) (CASHMERE)
15898196 SEAT, RR #2 (INCLS 2-39) (TITANIUM)
15898200 SEAT, RR #2 (INCLS 2-39) (TITANIUM)
teamcadillac.ru
15898203 SEAT, RR #2 (INCLS 2-39) (CASHMERE)
15898204 SEAT, RR #2 (INCLS 2-39) (TITANIUM)
15898206 SEAT, RR #2 (INCLS 2-39) (EBONY)
15898209 SEAT, RR #2 (INCLS 2-39) (EBONY)
15898212 SEAT, RR #2 (INCLS 2-39) (EBONY)
15898213 SEAT, RR #2 (INCLS 2-39) (CASHMERE)
15898215 SEAT, RR #2 (INCLS 2-39) (EBONY)
15898216 SEAT, RR #2 (INCLS 2-39) (CASHMERE)
15925570 SEAT, RR #2 (INCLS 2-39) (EBONY/MOROCCO)
15925634 SEAT, RR #2 (INCLS 2-39) (EBONY/MOROCCO)
25869802 SEAT, RR #2 (INCLS 2-39) (EBONY)
25869803 SEAT, RR #2 (INCLS 2-39) (EBONY)
25869805 SEAT, RR #2 (INCLS 2-39) (EBONY)
25869809 SEAT, RR #2 (INCLS 2-39) (EBONY/TITANIUM)
25869811 SEAT, RR #2 (INCLS 2-39) (EBONY)
25869812 SEAT, RR #2 (INCLS 2-39) (CASHMERE)
25869814 SEAT, RR #2 (INCLS 2-39) (EBONY)
25869815 SEAT, RR #2 (INCLS 2-39) (CASHMERE)
25869872 SEAT, RR #2 (INCLS 2-39) (EBONY/TITANIUM)
25869882 SEAT, RR #2 (INCLS 2-39) (CASHMERE)
25917136 SEAT, RR #2 (INCLS 2-39) (EBONY)
25917140 SEAT, RR #2 (INCLS 2-39) (EBONY)
25950452 SEAT, RR #2 (INCLS 2-39) (EBONY)
25950458 SEAT, RR #2 (INCLS 2-39) (EBONY)
25950468 SEAT, RR #2 (INCLS 2-39) (CASHMERE)
15804531 PAD, R/SEAT #2 BK CUSH
15804532 PAD, R/SEAT #2 BK CUSH
15833506 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE)
19121608 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (TITANIUM) (USED FOR RH & LH SIDES)
19207599 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (EBONY) (USED ON VEHICLES BUILT WITH & AFTER VINS 7R170871 & 7J171621) (FOR 1ST DES SEE 19121605)
19207600 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (CASHMERE) (HAS LOWER ANCHOR PALTE W/SLOT AND HOLE) (FOR 1ST DES SEE 19121607)
19207601 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (TITANIUM) (HAS LOWER ANCHOR PLATE W/SLOT AND HOLE) (FOR 1ST DES SEE 19121608)
19207602 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (CASHMERE) (HAS LOWER ANCHOR PLATE W/SLOT AND HOLE) (FOR 1ST DES SEE 19121606)
15822356 HANDLE, R/SEAT LAT REL (ЧАСТЬ 26) (EBONY)
15822357 HANDLE, R/SEAT LAT REL (ЧАСТЬ 26) (CASHMERE)
15822358 HANDLE, R/SEAT LAT REL (ЧАСТЬ 26) (TITANIUM)
15822359 HANDLE, R/SEAT LAT REL (ЧАСТЬ 26) (CASHMERE)
15804453 COVER, R/SEAT #2 BK CUSH LAT (EBONY) (REAR CLOSEOUT) (16.716)
15804454 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (REAR CLOSEOUT) (16.716)
15804455 COVER, R/SEAT #2 BK CUSH LAT (TITANIUM) (REAR CLOSEOUT) (16.716)
15804456 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (REAR CLOSEOUT) (16.716)
15804463 COVER, R/SEAT #2 BK CUSH LAT (EBONY) (REAR CLOSEOUT) (16.716)
15804464 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (REAR CLOSEOUT) (16.716)
15804465 COVER, R/SEAT #2 BK CUSH LAT (TITANIUM) (REAR CLOSEOUT) (16.716)
15804466 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (REAR CLOSEOUT) (16.716)
15804458 COVER, R/SEAT #2 BK CUSH LAT (EBONY) (FRONT CLOSEOUT) (16.716)
15804459 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (FRONT CLOSEOUT) (16.716)
15804460 COVER, R/SEAT #2 BK CUSH LAT (TITANIUM) (FRONT CLOSEOUT) (16.716)
15804461 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (FRONT CLOSEOUT) (16.716)
15804468 COVER, R/SEAT #2 BK CUSH LAT (EBONY) (FRONT CLOSEOUT) (16.716)
15804469 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (FRONT CLOSEOUT) (16.716)
15804470 COVER, R/SEAT #2 BK CUSH LAT (TITANIUM) (FRONT CLOSEOUT) (16.716)
15804471 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (FRONT CLOSEOUT) (16.716)
15791116 FRAME, R/SEAT #2 CUSH
15791117 FRAME, R/SEAT #2 CUSH
15822361 COMPARTMENT, R/SEAT CUSH (EBONY)
15822362 COMPARTMENT, R/SEAT CUSH (CASHMERE)
15822363 COMPARTMENT, R/SEAT CUSH (TITANIUM)
15822364 COMPARTMENT, R/SEAT CUSH (CASHMERE)
19121548 BELT KIT, R/SEAT #2 (BKL SI) (EBONY) (BKL/BKL) (USED ON VEHICLES BUILT PRIOR TO VINS 7R170871 & 7J171621) (FOR 2ND DES SEE 19152518)
19152518 BELT KIT, R/SEAT #2 (BKL SI) (EBONY) (BKL/BKL) (USED ON VEHICLES BUILT WITH AND AFTER VINS 7R170871 & 7J171621) (FOR 1ST DES SEE 19121548)
19152526 BELT KIT, R/SEAT #2 (BKL SI) (EBONY) (USED FOR RH & LH SIDES) (USED ON VEHICLES BUILT WITH OR AFTER VINS 7R170871 & 7J171621) (FOR 1ST DES SEE 19121552)
19152527 BELT KIT, R/SEAT #2 (BKL SI) (CASHMERE) (USED FOR RH & LH SIDES) (USED ON VEHICLES BUILT WITH OR AFTER VINS 7R170871 & 7J171621) (FOR 1ST DES SEE 19121553)
19152528 BELT KIT, R/SEAT #2 (BKL SI) (TITANIUM) (USED FOR RH & LH SIDES) (USED ON VEHICLES BUILT WITH OR AFTER VINS 7R170871 & 7J171621) (FOR 1ST DES SEE 19121554)
19152529 BELT KIT, R/SEAT #2 (BKL SI) (CASHMERE) (USED FOR RH & LH SIDES) (USED ON VEHICLES BUILT WITH OR AFTER VINS 7R170871 & 7J171621) (FOR 1ST DES SEE 19121555)
15791112 FRAME, R/SEAT #2 BK CUSH (USED ON VEHICLES WITH VIN 7R170870 & 7J141620 & PRIOR) (FOR 2ND DES SEE 15898364)
15791113 FRAME, R/SEAT #2 BK CUSH (USED ON VEHICLES WITH VIN 7R170870 & 7J141620 & PRIOR) (FOR 2ND DES SEE 15898365)
15898364 FRAME, R/SEAT #2 BK CUSH (USED ON VEHICLES WITH VIN 7R170871 & 7J141621 & AFTER) (FOR 1ST DES SEE 15791112)
15898365 FRAME, R/SEAT #2 BK CUSH (USED ON VEHICLES WITH VIN 7R170871 & 7J141621 & AFTER) (FOR 1ST DES SEE 15791113)
15827651 LINER, RR CTR ST CUP HLDR HSG CMPT (FOR CUPHOLDER)
15827650 LINER, RR CTR ST CUSH LWR FIN PNL [УПЛОТНИТЕЛЬ]
15804535 PAD, R/SEAT #2 CUSH
15804536 PAD, R/SEAT #2 CUSH
15804687 COVER, R/SEAT #2 CUSH (EBONY)
15804688 COVER, R/SEAT #2 CUSH (CASHMERE)
15804690 COVER, R/SEAT #2 CUSH (EBONY)
15804691 COVER, R/SEAT #2 CUSH (CASHMERE)
15804726 COVER, R/SEAT #2 CUSH (EBONY)
15804727 COVER, R/SEAT #2 CUSH (CASHMERE)
15804729 COVER, R/SEAT #2 CUSH (EBONY)
15804730 COVER, R/SEAT #2 CUSH (CASHMERE)
15865742 COVER, R/SEAT #2 CUSH (EBONY)
15865743 COVER, R/SEAT #2 CUSH (CASHMERE)
15865744 COVER, R/SEAT #2 CUSH (TITANIUM)
15865746 COVER, R/SEAT #2 CUSH (EBONY)
15865747 COVER, R/SEAT #2 CUSH (CASHMERE)
15865748 COVER, R/SEAT #2 CUSH (TITANIUM)
15865778 COVER, R/SEAT #2 CUSH (EBONY)
15865779 COVER, R/SEAT #2 CUSH (CASHMERE)
15865780 COVER, R/SEAT #2 CUSH (TITANIUM)
15865782 COVER, R/SEAT #2 CUSH (EBONY)
15865783 COVER, R/SEAT #2 CUSH (CASHMERE)
15865784 COVER, R/SEAT #2 CUSH (TITANIUM)
15925582 COVER, R/SEAT #2 CUSH (EBONY/MOROCCO)
15925583 COVER, R/SEAT #2 CUSH (EBONY/MOROCCO)
15925622 COVER, R/SEAT #2 CUSH (EBONY/TITANIUM)
15925623 COVER, R/SEAT #2 CUSH (EBONY/TITANIUM)
15804681 COVER, R/SEAT #2 BK CUSH (EBONY) (INCLS CHILD COMFORT GUIDE)
15804682 COVER, R/SEAT #2 BK CUSH (CASHMERE) (INCLS CHILD COMFORT GUIDE)
15804684 COVER, R/SEAT #2 BK CUSH (EBONY) (INCLS CHILD COMFORT GUIDE)
15804685 COVER, R/SEAT #2 BK CUSH (CASHMERE) (INCLS CHILD COMFORT GUIDE)
15804719 COVER, R/SEAT #2 BK CUSH (EBONY) (INCLS CHILD COMFORT GUIDE)
15804720 COVER, R/SEAT #2 BK CUSH (CASHMERE) (INCLS CHILD COMFORT GUIDE)
15804722 COVER, R/SEAT #2 BK CUSH (EBONY) (INCLS CHILD COMFORT GUIDE)
15804723 COVER, R/SEAT #2 BK CUSH (CASHMERE) (INCLS CHILD COMFORT GUIDE)
15865734 COVER, R/SEAT #2 BK CUSH (EBONY)
15865735 COVER, R/SEAT #2 BK CUSH (CASHMERE)
15865736 COVER, R/SEAT #2 BK CUSH (TITANIUM)
15865738 COVER, R/SEAT #2 BK CUSH (EBONY) (INCLS SEAT BELT COMFORT GUIDE)
15865739 COVER, R/SEAT #2 BK CUSH (CASHMERE) (INCLS SEAT BELT COMFORT GUIDE)
15865740 COVER, R/SEAT #2 BK CUSH (TITANIUM) (INCLS SEAT BELT COMFORT GUIDE)
15865766 COVER, R/SEAT #2 BK CUSH (EBONY) (INCLS CHILD COMFORT GUIDE)
15865767 COVER, R/SEAT #2 BK CUSH (CASHMERE) (INCLS CHILD COMFORT GUIDE)
15865768 COVER, R/SEAT #2 BK CUSH (TITANIUM) (INCLS CHILD COMFORT GUIDE)
15865770 COVER, R/SEAT #2 BK CUSH (EBONY) (INCLS CHILD COMFORT GUIDE)
15865771 COVER, R/SEAT #2 BK CUSH (CASHMERE) (INCLS CHILD COMFORT GUIDE)
15865772 COVER, R/SEAT #2 BK CUSH (TITANIUM) (INCLS CHILD COMFORT GUIDE)
15925580 COVER, R/SEAT #2 BK CUSH (EBONY/MOROCCO) (INCLS CHILD COMFORT GUIDE)
15925581 COVER, R/SEAT #2 BK CUSH (EBONY/MOROCCO) (INCLS CHILD COMFORT GUIDE)
15925612 COVER, R/SEAT #2 BK CUSH (EBONY/TITANIUM) (INCLS CHILD COMFORT GUIDE)
15925613 COVER, R/SEAT #2 BK CUSH (EBONY/TITANIUM) (INCLS CHILD COMFORT GUIDE)
15924921 PANEL, R/SEAT BK CUSH FIL
15924922 PANEL, R/SEAT BK CUSH FIL
15804397 LATCH, R/SEAT #2 LOAD FLR (INCLS 21) (OUTBOARD REAR)
15898401 LATCH, R/SEAT #2 LOAD FLR (INCLS 21)
15898402 LATCH, R/SEAT #2 LOAD FLR (INCLS 21)
(TC16-420) - 2007-2009 CK107(06) ЗАДНИЕ РЕМНИ БЕЗОПАСНОСТИ (AL4,AM8)
19167317 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 17) (EBONY)
19167318 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 17) (CASHMERE)
19167319 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 17) (CASHMERE)
19167320 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 17) (TITANIUM)
19167321 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 17) (EBONY)
19167322 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 17) (CASHMERE)
19167323 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 17) (CASHMERE)
19167324 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 17) (TITANIUM)
25810538 BELT, R/SEAT (RETR SI) (INCLS 2, 17) (EBONY) [РЕМЕНЬ БЕЗОПАСНОСТИ]
25810539 BELT, R/SEAT (RETR SI) (INCLS 2, 17) (CASHMERE) [РЕМЕНЬ БЕЗОПАСНОСТИ]
25810541 BELT, R/SEAT (RETR SI) (INCLS 2, 17) (EBONY) [РЕМЕНЬ, ЗАДНЕГО СИДЕНЬЯ, ПРАВЫЙ (ЧЕРНЫЙ)]
25810542 BELT, R/SEAT (RETR SI) (INCLS 2, 17) (CASHMERE) [РЕМЕНЬ БЕЗОПАСНОСТИ]
11609886 БОЛТ, R/SEAT BELT (RETR SI) (M12X1.75X40, 22 OD)
11588500 БОЛТ, R/SEAT BELT (RETR SI) (M12X1.75X62.7, 22 OD)
11610207 БОЛТ, R/SEAT BELT (RETR SI) (M12X1.75X76, 22 OD) (8.913) [БОЛТ]
teamcadillac.ru
15853706 BELT, R/SEAT CTR SHLDR (RETR SI) (INCLS 12, 17) (EBONY)
15853707 BELT, R/SEAT CTR SHLDR (RETR SI) (INCLS 12, 17) (CASHMERE)
19151104 BELT KIT, R/SEAT CTR (RETR SI) (INCLS 12, 17) (EBONY)
19151105 BELT KIT, R/SEAT CTR (RETR SI) (INCLS 12, 17) (CASHMERE)
19151106 BELT KIT, R/SEAT CTR (RETR SI) (INCLS 12, 17) (TITANIUM)
19151107 BELT KIT, R/SEAT CTR (RETR SI) (INCLS 12, 17) (CASHMERE)
25869335 BRACKET, R/SEAT CTR BELT (RETR SI)
19121443 STOP KIT, BELT LAT (RETR SI) (PART OF 1, 10) (TITANIUM) (14.875)
19121445 STOP KIT, BELT LAT (RETR SI) (PART OF 1, 10) (CASHMERE) (14.875)
19121446 STOP KIT, BELT LAT (RETR SI) (PART OF 1, 10) (EBONY) (14.875)
(TC16-432) - 2007-2009 K107(06) ЗЕРКАЛО/ВНЕШНЕЕ (HEATED,POWER FOLDING DR4)
teamcadillac.ru
15923191 GLASS, O/S RR VIEW MIR (PART OF 4) [СТЕКЛО ЗЕРКАЛА ЗАДНЕГО ОБЗОРА]
15923192 GLASS, O/S RR VIEW MIR (PART OF 4) [СТЕКЛО ЗЕРКАЛА ЗАДНЕГО ОБЗОРА]
25840168 GLASS, O/S RR VIEW MIR (PART OF 4)
25840169 GLASS, O/S RR VIEW MIR (PART OF 4)
15874997 ACTUATOR, O/S RR VIEW MIR INR (PART OF 4) (W/2 PIGTAILS ON BACK) (MEMORY) (BUILT PRIOR TO 04/24/06 WITH TM2A MEMORY ACTUATORS) (FOR 2ND DES SEE 25808705)
15874998 ACTUATOR, O/S RR VIEW MIR INR (PART OF 4) (W/2 PIGTAILS ON BACK) (MEMORY) (BUILT PRIOR TO 04/24/06 WITH TM2A MEMORY ACTUATORS) (FOR 2ND DES SEE 25808706)
25808705 ACTUATOR, O/S RR VIEW MIR INR (PART OF 4) (W/1 PIGTAIL ON BACK) (GLASS ACTUATOR W/MEMORY/MANUAL FOLDS) (BUILT 04/24/06 & AFTER WITH TM2B MEMORY ACTUATORS) (FOR 1ST DES SEE 15874997) [ЭЛЕКТРОДВИГАТЕЛЬ РЕГУЛИРОВКИ ПОЛОЖЕНИЯ ЗЕРКАЛА ЗАДНЕГО ОБЗОРА 20 ВТ]
25808706 ACTUATOR, O/S RR VIEW MIR INR (PART OF 4) (W/1 PIGTAIL ON BACK) (GLASS ACTUATOR W/MEMORY/MANUAL FOLDS) (BUILT 04/24/06 & AFTER WITH TM2B MEMORY ACTUATORS) (FOR 1ST DES SEE 15874998) [ЭЛЕКТРОДВИГАТЕЛЬ ЗЕРКАЛА ЗАДНЕГО ОБЗОРА 20 ВТ]
25780264 MIRROR, O/S RR VIEW (INCLS 1-3, 5, 8) (PAINT TO MATCH) (INCLS ШЛАНГИ) [ЗЕРКАЛО ЗАДНЕГО ОБЗОРА В СБОРЕ]
25780265 MIRROR, O/S RR VIEW (INCLS 1-3, 5, 8) (PAINT TO MATCH) (INCLS ШЛАНГИ) [ЗЕРКАЛО ЗАДНЕГО ОБЗОРА]
25840162 MIRROR, O/S RR VIEW (INCLS 1-3, 5, 8) (PAINT TO MATCH) (INCLS ШЛАНГИ) [ЗЕРКАЛО ЗАДНЕГО ОБЗОРА]
25840163 MIRROR, O/S RR VIEW (INCLS 1-3, 5, 8) (PAINT TO MATCH) (INCLS ШЛАНГИ) [ЗЕРКАЛО ЗАДНЕГО ОБЗОРА]
25862774 SEAL, O/S RR VIEW MIR (PART OF 4)
25862775 SEAL, O/S RR VIEW MIR (PART OF 4)
11508388 ГАЙКА, HEX W/CON WA, M6X1, 23.75 O.D., 5.55THK, 9, POR (O/S RR VIEW MIR) (8.915)
25816712 FILLER, FRT S/D O/S RR VIEW MIR (INSIDE VEHICLE) [НАПОЛНИТЕЛЬ-ПЕРЕДН.ЗЕРК.ЗАДН.ВИД]
25788156 ШЛАНГИ, O/S RR VIEW MIR (PART OF 4) (PAINT TO MATCH) [КРЫШКА КОРПУСА ЗЕРКАЛА ЗАДНЕГО ОБЗОРА]
25788157 ШЛАНГИ, O/S RR VIEW MIR (PART OF 4) (PAINT TO MATCH) (16.069) [КРЫШКА КОРПУСА ЗЕРКАЛА ЗАДНЕГО ОБЗОРА]
(TC16-434) - 2007-2009 CK1,2(06-36) ЗЕРКАЛО/ВНЕШНЕЕ (HEATED,POWER FOLDING,TURN SIGNAL DL3)
15874992 GLASS, O/S RR VIEW MIR (PART OF 4) (BUILT PRIOR TO 03/15/07) (FOR 2ND DES SEE 25892978) [СТЕКЛО ЗЕРКАЛА ЗАДНЕГО ВИДА]
15886196 GLASS, O/S RR VIEW MIR (PART OF 4) [СТЕКЛО ЗЕРКАЛА ЗАДНЕГО ОБЗОРА]
15886197 GLASS, O/S RR VIEW MIR (PART OF 4)
25892978 GLASS, O/S RR VIEW MIR (PART OF 4) (REMOVE ADDITIONAL ПРУЖИНА FINGER FROM LOWER OUTBOARD CORNER) (BUILT 03/15/07 & AFTER) (FOR 1ST DES SEE 15874992) [СТЕКЛО ЗЕРКАЛА ЗАДНЕГО ОБЗОРА]
25776084 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (CHROME)
25776162 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (PAINT TO MATCH) (W/CHROME LOWER) [ЗЕРКАЛО]
25779760 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (PAINT TO MATCH)
25779805 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (MOLDED IN BLACK) (GRAINED)
25779849 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (PAINT TO MATCH) [ЗЕРКАЛО ДВЕРИ В СБОРЕ]
25782166 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (CHROME) [ЗЕРКАЛО ДВЕРИ В СБОРЕ]
25782175 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (CHROME) [ЗЕРКАЛО ЗАДНЕГО ОБЗОРА В СБОРЕ]
25831064 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (CHROME)
25831065 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (CHROME) [ЗЕРКАЛО ЗАДНЕГО ОБЗОРА В СБОРЕ]
25831078 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (PAINT TO MATCH) (W/CHROME LOWER) [ЗЕРКАЛО ЗАДНЕГО ОБЗОРА]
25831194 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (MOLDED IN BLACK) (GRAINED)
25831236 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (PAINT TO MATCH)
25865452 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (BLACK) (PRIME AND PAINT REMANUFACTURED CUT AS REQUIRED TRIM AS REQD) [ЗЕРКАЛО ЗАДНЕГО ВИДА, БОКОВОЕ, ЧЕРНОЕ]
01999382 BULB, (PART OF 4, 6) (ACDelco #W5WLL) (LONGER LIFE)
15874999 LAMP, CTSY (PART OF 4) (INCLS 5) (O/S RR VIEW)
15875000 LAMP, CTSY (PART OF 4) (INCLS 5) (O/S RR VIEW)
25862772 SEAL, O/S RR VIEW MIR (PART OF 4)
25862773 SEAL, O/S RR VIEW MIR (PART OF 4)
25788154 ШЛАНГИ, O/S RR VIEW MIR (PART OF 4) (MOLDED IN BLACK) [КОЖУХ ЗЕРКАЛА ЗАДНЕГО ВИДА]
25788155 ШЛАНГИ, O/S RR VIEW MIR (PART OF 4) (MOLDED IN BLACK) [КОРПУС САЛОННОГО ЗЕРКАЛА ЗАДНЕГО ОБЗОРА]
teamcadillac.ru
25788158 ШЛАНГИ, O/S RR VIEW MIR (PART OF 4) (CHROME)
25788159 ШЛАНГИ, O/S RR VIEW MIR (PART OF 4) (CHROME)
25788160 ШЛАНГИ, O/S RR VIEW MIR (PART OF 4) (CHROME) [КРЫШКА КОРПУСА ЗЕРКАЛА ЗАДНЕГО ОБЗОРА]
25788161 ШЛАНГИ, O/S RR VIEW MIR (PART OF 4) (CHROME) [КРЫШКА ЗЕРКАЛА ЗАДНЕГО ОБЗОРА]
(TC16-447) - 2007 CK1,2(06-36) FRONT SEAT MOUNTING (AN3,A95)
15214539 COVER, D/SEAT INR ADJR RR FIN (EBONY) (INBOARD TRACKS) (REAR) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ]
15214540 COVER, D/SEAT INR ADJR RR FIN (CASHMERE) (MATCHES CARPET COLOR)
15214541 COVER, D/SEAT INR ADJR RR FIN (TITANIUM) (MATCHES CARPET COLOR)
15219928 COVER, D/SEAT INR ADJR RR FIN (CASHMERE) (MATCHES SEAT COLOR)
15895269 COVER, D/SEAT INR ADJR RR FIN (TITANIUM) (MATCHES SEAT COLOR)
15902134 COVER, D/SEAT INR ADJR RR FIN (CASHMERE)
15214527 COVER, F/SEAT ADJR FIN (EBONY) (BELT UTILITY) [КРЫШКА]
15214528 COVER, F/SEAT ADJR FIN (CASHMERE) (BELT UTILITY)
15214529 COVER, F/SEAT ADJR FIN (TITANIUM) (BELT UTILITY)
15219925 COVER, F/SEAT ADJR FIN (CASHMERE) (BELT UTILITY)
11562473 БОЛТ, F/SEAT (M12X1.75X45) [БОЛТ М12]
15214533 CAP, F/SEAT ADJR OTR FIN CVR BOLT (EBONY) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ]
15214534 CAP, F/SEAT ADJR OTR FIN CVR BOLT (CASHMERE) (MATCHES CARPET COLOR)
15214535 CAP, F/SEAT ADJR OTR FIN CVR BOLT (TITANIUM) (MATCHES CARPET COLOR)
15219926 CAP, F/SEAT ADJR OTR FIN CVR BOLT (CASHMERE) (MATCHES SEAT COLOR)
teamcadillac.ru
15895267 CAP, F/SEAT ADJR OTR FIN CVR BOLT (TITANIUM) (MATCHES SEAT COLOR)
15902140 CAP, F/SEAT ADJR OTR FIN CVR BOLT (CASHMERE)
15215179 COVER, WRG HARN CONN (BLACK (REPLS ALL COLORS)) [КРЫШКА КОНТАКТНОГО РАЗЪЕМА]
15214537 COVER, D/SEAT INR ADJR FRT FIN (CASHMERE) (MATCHES CARPET COLOR)
15214538 COVER, D/SEAT INR ADJR FRT FIN (TITANIUM) (MATCHES CARPET COLOR)
15931771 COVER, D/SEAT INR ADJR FRT FIN (EBONY)
15931772 COVER, D/SEAT INR ADJR FRT FIN (CASHMERE) (MATCHES SEAT COLOR)
15931773 COVER, D/SEAT INR ADJR FRT FIN (TITANIUM)
15931774 COVER, D/SEAT INR ADJR FRT FIN (CASHMERE) (MATCHES SEAT COLOR)
15035434 ГАЙКА, F/SEAT (M10X1.5X10.8) (FLANGE NUT) (16.679) [ВИНТ]
15214543 COVER, P/SEAT INR ADJR FRT FIN (CASHMERE) (MATCHES CARPET COLOR)
15214544 COVER, P/SEAT INR ADJR FRT FIN (TITANIUM) (MATCHES CARPET COLOR)
15931777 COVER, P/SEAT INR ADJR FRT FIN (EBONY) (INBOARD TRACKS) [КРЫШКА МЕХАНИЗМА РЕГУЛИРОВКИ ПОЛОЖЕНИЯ СИДЕНЬЯ]
15931778 COVER, P/SEAT INR ADJR FRT FIN (CASHMERE) (MATCHES SEAT COLOR)
15931779 COVER, P/SEAT INR ADJR FRT FIN (TITANIUM) (MATCHES SEAT COLOR)
15931780 COVER, P/SEAT INR ADJR FRT FIN (CASHMERE)
15214530 COVER, F/SEAT ADJR FIN (EBONY) (OUTBOARD, 40%, BELT UTILITY) [КОЖУХ МЕХАНИЗМА РЕГУЛИРОВКИ ПОЛОЖЕНИЯ СИДЕНЬЯ]
15214531 COVER, F/SEAT ADJR FIN (CASHMERE) (BELT UTILITY)
15214532 COVER, F/SEAT ADJR FIN (TITANIUM) (BELT UTILITY)
15219924 COVER, F/SEAT ADJR FIN (CASHMERE) (BELT UTILITY)
15214545 COVER, P/SEAT INR ADJR RR FIN (EBONY) (INBOARD TRACKS) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ]
15214546 COVER, P/SEAT INR ADJR RR FIN (CASHMERE) (MATCHES CARPET COLOR)
15214547 COVER, P/SEAT INR ADJR RR FIN (TITANIUM) (MATCHES CARPET COLOR)
15219930 COVER, P/SEAT INR ADJR RR FIN (CASHMERE) (MATCHES SEAT COLOR)
15895289 COVER, P/SEAT INR ADJR RR FIN (TITANIUM) (MATCHES SEAT COLOR)
15902136 COVER, P/SEAT INR ADJR RR FIN (CASHMERE)
(TC16-449) - 2007 CK1(06-36) СИДЕНЬЕ ВОДИТЕЛЯ/BUCKET (AN3, HEATED/VENTED KB6)
25798348 RESTRAINT, D/SEAT HD (INCLS 2) (EBONY) (LEATHER) (W/ BUTTON) [ПОДГОЛОВНИК СИДЕНЬЯ]
25798350 RESTRAINT, D/SEAT HD (INCLS 2) (CASHMERE) (INCLS BUTTON)
15827097 COVER, D/SEAT BK CUSH (EBONY)
25899521 COVER, D/SEAT BK CUSH (CASHMERE)
25789846 PAD, D/SEAT BK CUSH
15279347 GUIDE, F/SEAT BK H/RST ADJ ROD (EBONY) (W/BUTTON)
15279440 GUIDE, F/SEAT BK H/RST ADJ ROD (CASHMERE) (W/BUTTON) [НАПРАВЛЯЮЩАЯ ПОДГОЛОВНИКА СИДЕНЬЯ]
15279351 GUIDE, F/SEAT BK H/RST ADJ ROD (EBONY) (W/O BUTTON)
15279441 GUIDE, F/SEAT BK H/RST ADJ ROD (CASHMERE) (W/O BUTTON)
25808716 FRAME, D/SEAT BK CUSH (INCLS 9, 15, 17, 20, 21, 48) (INCLS RECLINER, MOTOR, SENSOR & LUMBAR SUPPORT) [КАРКАС СПИНКИ СИДЕНИЯ C ПОЯСНИЧНОЙ ОПОРОЙ]
20763137 LUMBAR SUB, D/SEAT (PART OF 8) (POWER) (HEAT & COOL)
15827133 RING, F/SEAT BK CUSH CVR HOG
15232700 PANEL, D/SEAT BK CUSH FIN (EBONY)
15232701 PANEL, D/SEAT BK CUSH FIN (CASHMERE)
15232558 DUCT, D/SEAT BACK VENTILATION
15232557 BLOWER, D/SEAT BACK VENTILATION HEAT & COOL (INCLS THERMAL ELECTRIC DEVICE, TEMP SENSOR & FILTER) [ВЕНТИЛЯТОР ПОДОГРЕВА СИДЕНЬЯ, 1.5ВТ]
25789849 PAD, D/SEAT CUSH
11517996 ГАЙКА, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (D/SEAT ADJR TOP PLT) (ACDelco #11517996) [ГАЙКА М10]
15827129 COVER, F/SEAT RSR FIN (INCLS 19) (EBONY) (RIGHT & LEFT TOE KICK)
15827132 COVER, F/SEAT RSR FIN (INCLS 19) (CASHMERE) (RIGHT & LEFT TOE KICK)
11515764 БОЛТ, HFH, M10X1.5X20, 18THD, 22.3 O.D., 10.9, 7114M (D/SEAT RECL)
12451497 SWITCH, D/SEAT ADJR & RECL (8-WAY) (11.558) [ВКЛЮЧАТЕЛЬ]
25802503 SWITCH, D/SEAT LUMBAR CONT (CASHMERE) (USED WITH 4-WAY POWER LUMBAR)
15232562 COVER, D/SEAT ADJR FIN (INCLS 32) (EBONY) (8 WAY POWER)
15232565 COVER, D/SEAT ADJR FIN (INCLS 32) (CASHMERE) (8 WAY POWER) (MATCHES CARPET COLOR)
10340136 KNOB, F/SEAT RECL (EBONY) (11.377)
15786548 KNOB, F/SEAT RECL (CASHMERE)
10325879 KNOB, D/SEAT ADJR SW (EBONY) (11.558)
15786549 KNOB, D/SEAT ADJR SW (CASHMERE)
15232584 COVER, D/SEAT OTR ADJR TRK RR FIN (EBONY) (OUTBOARD)
15232585 COVER, D/SEAT OTR ADJR TRK RR FIN (CASHMERE) (OUTBOARD)
15232587 COVER, D/SEAT OTR ADJR TRK RR FIN (CASHMERE) (OUTBOARD)
15848899 COVER, D/SEAT OTR ADJR TRK RR FIN (CASHMERE) (OUTBOARD)
11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (D/SEAT ADJR FIN CVR)
teamcadillac.ru
11513599 ГАЙКА, U-TYPE, M4.2X1.41, 0.65-3.80 PNL THK, PZ (F/SEAT) (ACDelco #11513599)
25966538 ADJUSTER, D/SEAT
15845152 BRACKET, D/SEAT BELT (RETR SI) (O/B)
15243864 COVER, D/SEAT OTR ADJR TRK RR FIN (EBONY) (INBOARD)
15243865 COVER, D/SEAT OTR ADJR TRK RR FIN (CASHMERE) (INBOARD)
15243867 COVER, D/SEAT OTR ADJR TRK RR FIN (CASHMERE) (INBOARD)
15848903 COVER, D/SEAT OTR ADJR TRK RR FIN (CASHMERE) (INBOARD)
15827134 BRACKET, D/SEAT FRT (MAIN BODY HARNESS CONNECTION) (16.686)
15243850 COVER, D/SEAT INR ADJR TRK FRT FIN (EBONY)
15243851 COVER, D/SEAT INR ADJR TRK FRT FIN (CASHMERE) (WITH ADJUSTER COVER THAT MATCHES CARPET COLOR) (FOR 2ND DES SEE 15243853)
15243853 COVER, D/SEAT INR ADJR TRK FRT FIN (CASHMERE) (WITH ADJUSTER COVER THAT MATCHES SEAT COLOR) (FOR 1ST DES SEE 15243851)
15232243 HARNESS, D/SEAT ADJR WRG (W/LMBR/MEM/HEAT/COOL)
15780680 SENSOR, INFL RST D/SEAT POSITION [ДАТЧИК ПОДУШКИ БЕЗОПАСНОСТИ]
15845153 BRACKET, D/SEAT BELT (BKL SI) (I/B)
11516075 ГАЙКА, HFH SELF LK, M6X1, 7.7THK, 14.2 O.D., 9, PZOR (D/SEAT ADJR MEMORY SW) [ГАЙКА ВЫПУСКНОЙ СИСТЕМЫ D=6ММ]
25862038 MODULE, D/SEAT ADJR MEMORY (REQUIRES DEALER PROGRAMMING) (11.558)
15232556 BLOWER, D/SEAT CUSH VENTILATION HEAT & COOL [ВЕНТИЛЯТОР ПОДОГРЕВА СИДЕНЬЯ, 1.5ВТ]
11517996 ГАЙКА, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (D/SEAT BELT (BKL SI)) (ACDelco #11517996) [ГАЙКА М10]
19121537 BELT KIT, D/SEAT (BKL SI) (EBONY) [ЗАЩЕЛКА РЕМНЯ БЕЗОПАСНОСТИ]
19121540 BELT KIT, D/SEAT (BKL SI) (CASHMERE)
15854391 FRAME, D/SEAT CUSH
15827136 BRACKET, D/SEAT RECL (I/B)
15243823 COVER, D/SEAT INR RECL FIN (INCLS 32) (EBONY)
15243826 COVER, D/SEAT INR RECL FIN (INCLS 32) (CASHMERE)
15855909 PROTECTOR, D/SEAT RECL FIN CVR (EBONY)
15855911 PROTECTOR, D/SEAT RECL FIN CVR (EBONY)
15924002 COVER, D/SEAT CUSH (EBONY) (VINYL INBOARD SIDE FACING)
25899508 COVER, D/SEAT CUSH (EBONY) [ЧЕХОЛ ПОДУШКИ СИДЕНЬЯ]
25899509 COVER, D/SEAT CUSH (CASHMERE)
25815788 CAP, F/SEAT ADJR TRK END (BLACK)
(TC16-450) - 2007 CK1(06-36) ПАССАЖИРСКОЕ СИДЕНЬЕ/BUCKET (AN3, HEATED/VENTED KB6)
15827056 SEAT, PASS (EBONY)
15827057 SEAT, PASS (CASHMERE)
15865143 SEAT, PASS (EBONY) (WITH TRIM COVERED BACK PANEL) (FOR 2ND DES SEE 15934158)
15923996 SEAT, PASS (EBONY/TITANIUM) (WITH TRIM COVERED BACK PANEL) (FOR 2ND DES SEE 15934162)
15934158 SEAT, PASS (EBONY) (WITH MOLDED BACK PANEL) (FOR 1ST DES SEE 15865143)
15934162 SEAT, PASS (EBONY/TITANIUM) (WITH MOLDED BACK PANEL) (FOR 1ST DES SEE 15923996)
15865481 RESTRAINT, P/SEAT HD (INCLS 2) (EBONY)
25798348 RESTRAINT, P/SEAT HD (INCLS 2) (EBONY) (LEATHER) (W/ BUTTON) [ПОДГОЛОВНИК СИДЕНЬЯ]
25798350 RESTRAINT, P/SEAT HD (INCLS 2) (CASHMERE) (INCLS BUTTON)
15827097 COVER, P/SEAT BK CUSH (EBONY)
15865828 COVER, P/SEAT BK CUSH (EBONY)
15923998 COVER, P/SEAT BK CUSH (EBONY)
25899521 COVER, P/SEAT BK CUSH (CASHMERE)
25789846 PAD, P/SEAT BK CUSH
25808721 FRAME, P/SEAT BK CUSH (INCLS 9, 15, 18, 19, 47) (INCLS RECLINER, MOTOR & LUMBAR SUPPORT)
20763141 LUMBAR SUB, P/SEAT (PART OF 8) (POWER) (HEAT & COOL)
15232700 PANEL, P/SEAT BK CUSH FIN (EBONY)
15232701 PANEL, P/SEAT BK CUSH FIN (CASHMERE)
15232557 BLOWER, P/SEAT BACK VENTILATION HEAT & COOL (INCLS THERMAL ELECTRIC DEVICE, TEMP SENSOR & FILTER) [ВЕНТИЛЯТОР ПОДОГРЕВА СИДЕНЬЯ, 1.5ВТ]
15232558 DUCT, P/SEAT BACK VENTILATION
15827129 COVER, F/SEAT RSR FIN (INCLS 17) (EBONY) (RIGHT & LEFT TOE KICK)
15827132 COVER, F/SEAT RSR FIN (INCLS 17) (CASHMERE) (RIGHT & LEFT TOE KICK)
11515764 БОЛТ, HFH, M10X1.5X20, 18THD, 22.3 O.D., 10.9, 7114M (P/SEAT RECL)
12451498 SWITCH, P/SEAT ADJR & RECL (8-WAY) (P SEAT ADJ SWITCH LABELED 12451498) (11.558) [ВЫКЛЮЧАТЕЛЬ ПОЛОЖЕНИЯ СИДЕНЬЯ]
25802503 SWITCH, P/SEAT LUMBAR CONT (CASHMERE) (USED WITH 4-WAY POWER LUMBAR)
15232567 COVER, P/SEAT ADJR FIN (INCLS 21) (EBONY) (POWER)
teamcadillac.ru
15232570 COVER, P/SEAT ADJR FIN (INCLS 21) (CASHMERE) (POWER)
10325879 KNOB, P/SEAT ADJR SW (EBONY) (11.558)
15786549 KNOB, P/SEAT ADJR SW (CASHMERE)
15232592 COVER, P/SEAT OTR ADJR TRK RR FIN (INCLS 29) (CASHMERE) (OUTBOARD) (WITH ADJUSTER COVER THAT MATCHES SEAT COLOR) (FOR 1ST DES SEE 15232590)
15243872 COVER, P/SEAT OTR ADJR TRK RR FIN (INCLS 29) (CASHMERE) (INBOARD) (WITH ADJUSTER COVER THAT MATCHES SEAT COLOR) (FOR 1ST DES SEE 15243870)
11517996 ГАЙКА, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (P/SEAT ADJR FIN CVR) (ACDelco #11517996) [ГАЙКА М10]
11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (P/SEAT CUSH OTR FIN PNL)
15845154 BRACKET, P/SEAT BELT (RETR SI) (O/B)
11517996 ГАЙКА, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (P/SEAT ADJR TOP PLT) (ACDelco #11517996) [ГАЙКА М10]
15827135 BRACKET, P/SEAT FRT (MAIN BODY HARNESS CONNECTION)
15243858 COVER, P/SEAT INR ADJR TRK FRT FIN (EBONY)
15243859 COVER, P/SEAT INR ADJR TRK FRT FIN (CASHMERE) (WITH ADJUSTER COVER THAT MATCHES CARPET COLOR) (FOR 2ND DES SEE 15243861)
15243861 COVER, P/SEAT INR ADJR TRK FRT FIN (CASHMERE) (WITH ADJUSTER COVER THAT MATCHES SEAT COLOR) (FOR 1ST DES SEE 15243859)
25902020 HARNESS, P/SEAT ADJR WRG [ЖГУТ ПРОВОДОВ]
25966545 ADJUSTER, P/SEAT (POWER 6-WAY) (INCLS MOTORS)
15232556 BLOWER, P/SEAT CUSH VENTILATION HEAT & COOL [ВЕНТИЛЯТОР ПОДОГРЕВА СИДЕНЬЯ, 1.5ВТ]
11516075 ГАЙКА, HFH SELF LK, M6X1, 7.7THK, 14.2 O.D., 9, PZOR (INFL RST P/SEAT SUPPRESSION) [ГАЙКА ВЫПУСКНОЙ СИСТЕМЫ D=6ММ]
11517996 ГАЙКА, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (P/SEAT BELT (BKL SI)) (ACDelco #11517996) [ГАЙКА М10]
15232555 MODULE, P/SEAT CUSH VENTILATION HEAT & COOL [ЭЛЕКТРОННЫЙ МОДУЛЬ УПРАВЛЕНИЯ СИСТЕМОЙ КОМФОРТА]
19121544 BELT KIT, P/SEAT (BKL SI) (CASHMERE) (W/РОЛИК НАТЯЖИТЕЛЬ)
15827059 FRAME, P/SEAT CUSH
25789848 MODULE KIT, INFL RST FRT PASS PRESENCE (W/ SEN) (INCLS 14, 40)
15827137 BRACKET, P/SEAT RECL (I/B)
15855909 PROTECTOR, P/SEAT RECL FIN CVR (EBONY)
15855911 PROTECTOR, P/SEAT RECL FIN CVR (EBONY)
15243828 COVER, P/SEAT INR RECL FIN (INCLS 21) (EBONY) (INBOARD)
15243831 COVER, P/SEAT INR RECL FIN (INCLS 21) (CASHMERE)
15865832 COVER, P/SEAT CUSH (EBONY) (VINYL INBOARD SIDE FACING)
15924000 COVER, P/SEAT CUSH (EBONY) (VINYL INBOARD SIDE FACING)
25899514 COVER, P/SEAT CUSH (EBONY)
25899515 COVER, P/SEAT CUSH (CASHMERE)
(TC16-453) - 2007 CK107(06) КРЕПЛЕНИЕ ЗАДНЕГО СИДЕНЬЯ (60/40 BENCH AM8)
15887830 COVER, R/SEAT RSR FIN (EBONY) (ON FLOOR)
15887831 COVER, R/SEAT RSR FIN (CASHMERE) (ON FLOOR)
15887832 COVER, R/SEAT RSR FIN (TITANIUM) (ON FLOOR)
teamcadillac.ru
15887833 COVER, R/SEAT RSR FIN (CASHMERE) (ON FLOOR)
03537772 ГАЙКА, M12X1.75, 10.6THK, 28 O.D., 10, 7111M (R/SEAT) (8.917)
11562546 WASHER, FLAT, 14X42.5X3.61 MM, SAE 1050 STL RC 37-43, 7112M (R/SEAT)
(TC16-455) - 2007-2009 CK107(06) КРЕПЛЕНИЕ ЗАДНЕГО СИДЕНЬЯ (BUCKET AL4)
15887842 COVER, R/SEAT RSR FIN (EBONY) (ON FLOOR) (W/CARPET)
15887843 COVER, R/SEAT RSR FIN (CASHMERE) (ON FLOOR) (W/CARPET)
15887844 COVER, R/SEAT RSR FIN (TITANIUM) (ON FLOOR) (W/CARPET)
15887845 COVER, R/SEAT RSR FIN (CASHMERE) (ON FLOOR) (W/CARPET)
15887836 COVER, R/SEAT RSR FIN (EBONY) (ON FLOOR) (W/CARPET)
15887837 COVER, R/SEAT RSR FIN (CASHMERE) (ON FLOOR) (W/CARPET)
15887838 COVER, R/SEAT RSR FIN (TITANIUM) (ON FLOOR) (W/CARPET)
15887839 COVER, R/SEAT RSR FIN (CASHMERE) (ON FLOOR) (W/CARPET)
teamcadillac.ru
(TC16-464) - 2007-2008 CK1(06) WIPER SYSTEM/ВЕТРОВОЕ СТЕКЛО (POLICE PACKAGE PPV)
20773355 ARM, WSW (INCLS 2) (BLACK) (USE ON VEH BUILT 07/23/07 & AFTER) (FOR 1ST DES SEE 20773357)
20773356 ARM, WSW (INCLS 2) (BLACK) (USE ON VEH BUILT 07/23/07 & AFTER) (FOR 1ST DES SEE 20773358)
teamcadillac.ru
20773357 ARM, WSW (INCLS 2) (BLACK) (W/NOZZLE & HOSE) (STYLIZED) (USE ON VEH BUILT 07/22/07 & PRIOR) (FOR 2ND DES SEE 20773355)
20773358 ARM, WSW (INCLS 2) (BLACK) (W/NOZZLE & HOSE) (STYLIZED) (USE ON VEH BUILT 07/22/07 & PRIOR) (FOR 2ND DES SEE 20773356)
15776792 CAP, WSW ARM FIN (PART OF 1) [КОЛПАЧОК ДЕРЖАТЕЛЯ ЩЕТКИ СТЕКЛООЧИСТИТЕЛЯ]
11609634 ГАЙКА, HEX WASH, M10X1.25, 7MM THK, 20 WA OD, 9 STL, 7111M, CON SPR WA. (WSW ARM) [ШАЙБА]
25820729 PANEL, AIR INL GRL (USED ON VEHICLES BUILT 5/6/07 AND PRIOR.) (BLACK) [НАКЛАДКА ВОДОСТОЧНОЙ ПАНЕЛИ]
25820730 PANEL, AIR INL GRL (USED ON VEHICLES BUILT 5/7/07 AND AFTER.) (BLACK) [НАКЛАДКА ВОДОСТОЧНОЙ ПАНЕЛИ]
11609796 CLIP, AIR INL GRL PNL (11.0 X 12.9 X 6.1MM) (8.950)
15780444 COVER, W/S O/S MSTRE SEN (COVERS MIR HARNESS)
25942005 SENSOR, W/S O/S MSTRE (INCLS 31) (10.163) [ДАТЧИК ДОЖДЯ ВЕТРОВОГО СТЕКЛА]
25872303 PANEL, AIR INL GRL (CTR) (INCLS 10, 15, 18) (BLACK)
25887976 HOSE, WSWA NOZ (PART OF 9) [ШЛАНГ СТЕКЛООМЫВАТЕЛЯ]
25923882 MODULE, WSW SYS [ЭЛЕКТРОДВИГАТЕЛЬ СТЕКЛООЧИСТИТЕЛЯ 90 ВТ]
11513947 БОЛТ, HEX, W/WA, M6X1X35, 24 O.D., AC PT, 9.8, POR (WSW SYS MDL)
15999788 RETAINER, AIR INL GRL PNL (U-SHAPED/CLIP)
11589183 ГАЙКА, PUSH IN, W/SEAL, 4.2X1.41, 6.35-6.48 SQ HL, 9.5 SQ HD, 0.787-2.765 PNL THK, NYL (AIR INL GRL PNL)
15200240 WEATHERSTRIP, КАПОТ RR (PART OF 9)
11609797 БОЛТ, AIR INL GRL PNL (10.268)
25877402 BLADE, WSW (22") [ЩЕТКА СТЕКЛООЧИСТИТЕЛЯ]
15048061 RETAINER, AIR INL GRL PNL (PART OF 9) (PUSH IN)
25956849 HEATER, WSWA SOLV [ОБОГРЕВАТЕЛЬ ЖИДКОСТИ СТЕКЛООЧИСТИТЕЛЯ 20ВТ]
25731418 CAP, WSWA SOLV CNTNR (W/ISO SYMBOL) (10.154)
15942522 CONTAINER KIT, WSWA SOLV (2P & 1LS GROMMETS) (INCLS 24, 25) [БАЧОК СТЕКЛООМЫВАТЕЛЯ]
11516578 БОЛТ, HEX W/FL WA, M6X1X25, 16 THD, 24 OD, 9.8, 7114M, MACH, 6MM P PT. (WSWA SOLV CNTNR)
15213911 INDICATOR KIT, WSWA SOLV LVL (LEVEL SENSOR KIT WITH GROMMET) (INCLS 24) [ДАТЧИК УРОВНЯ ЖИДКОСТИ БАЧКА СТЕКЛООМЫВАТЕЛЯ]
15248578 GROMMET, WSWA SOLV CNTNR (LEVEL SENSOR GROMMET) (PART OF 21, 23) [ВТУЛКА ДАТЧИКА УРОВНЯ БАЧКА СТЕКЛООМЫВАТЕЛЯ]
15927514 GROMMET, WSWA PUMP (PUMP GROMMET) (PART OF 21, 26, 27) [УПЛОТНЯЮЩЕЕ КОЛЬЦО]
15942524 PUMP KIT, WSWA W/ SEAL (INCLS 25) (RR PUMP KIT W/GROMMET)
15942523 PUMP KIT, WSWA W/ SEAL (INCLS 25) (FRT PUMP KIT W/GROMMET) (ACDelco #15942523) [НАСОС СТЕКЛООМЫВАТЕЛЯ]
25887957 HOSE, R/WDO WA PUMP (СМ. ГРУППУ 16.000 "WIPER SYSTEM/ ЗАДНЕЕ ОКНО" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (REAR JUMPER HOSE)
15917649 HOSE, WSWA PUMP (FRT JUMPER HOSE)
11516793 ГАЙКА, HEX, W/CON WA, M6X1X5.5, 16 O.D., 9, 7111M (WSWA SOLV HTR)
15829099 LENS, W/S O/S MSTRE SEN (PART OF 8) (INCLS THE SILICON GEL) [КОЖУХ ДАТЧИКА ДОЖДЯ]
25816571 GASKET, WSW TRANS (AT PIVOT POINT)
(TC16-577) - 2007-2009 CK1,2(06) КОНСОЛЬ/ПОЛ COVER (FLOOR КОНСОЛЬ DELETE 9N5)
11589294 RETAINER, F/FLR PNL CPT (BLACK) (M8.5 W/20.0MM HEAD) (8.133) [ФИКСАТОР ОБТЕКАТЕЛЯ РАДИАТОРА]
teamcadillac.ru
15926324 COVER, F/FLR PNL CPT HOLE (BLACK)
(TC16-920) - 2007 CK1,2(06) LUGGAGE COMPARTMENT COVER/REAR (RYJ)
15244019 SHADE, LUGG (CASHMERE) (INSTALL .10) (0.4 KGS) (VINYL)
15244020 SHADE, LUGG (TITANIUM) (INSTALL .10) (0.4 KGS) (VINYL)
15244021 SHADE, LUGG (EBONY) (INSTALL .10) (0.4 KGS) (VINYL) [ШТОРКА БАГАЖНОГО ОТСЕКА]
15244024 SHADE, LUGG (CASHMERE) (INSTALL .10) (0.4 KGS) (VINYL)
15244025 SHADE, LUGG (TITANIUM) (INSTALL .10) (0.4 KGS) (VINYL)
teamcadillac.ru
15244026 SHADE, LUGG (EBONY) (INSTALL .10) (0.4 KGS) (VINYL)
15277000 SHADE, LUGG (CASHMERE) (INSTALL .10) (0.4 KGS) (VINYL) [ШТОРКА БАГАЖНОГО ОТСЕКА 90Х120СМ]
(TC16-934) - 2007-2008 CK1(06-36) ПРИБОРНАЯ ПАНЕЛЬ & СОПРЯЖЕННЫЕ ДЕТАЛИ ЧАСТЬ 1 TRIM (CADILLAC Z75)
15893136 PANEL, I/P UPR TR (W/ W/S DEFR NOZ GRL) (INCLS 2, 56) (COCOA)
teamcadillac.ru
25903822 PANEL, I/P UPR TR (W/ W/S DEFR NOZ GRL) (INCLS 2, 56) (EBONY) [ПАНЕЛЬ В СБОРЕ]
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 1) [ЗАЖИМ КОНСОЛИ САЛОНА]
15221850 GRILLE, RDO FRT SPKR (INCLS 4) (EBONY)
15221851 GRILLE, RDO FRT SPKR (INCLS 4) (COCOA)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 3) [ЗАЖИМ КОНСОЛИ САЛОНА]
15233191 GRILLE, SI WDO DEFG OTLT (GRAY) (*KIT2)
15813116 GRILLE, SI WDO DEFG OTLT (EBONY) (*KIT2)
15813117 GRILLE, SI WDO DEFG OTLT (COCOA) (*KIT2)
15813143 GRILLE, SI WDO DEFG OTLT (EBONY) (*KIT2)
15813144 GRILLE, SI WDO DEFG OTLT (COCOA) (*KIT2)
15813113 PANEL, I/P UPR TR (EBONY) (W/O GRILLES) (*KIT2)
15813114 PANEL, I/P UPR TR (COCOA) (W/O GRILLES) (*KIT2)
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (I/P UPR TR PAD) (9.665) [БОЛТ М4.2Х1.41Х25]
11610157 ГАЙКА, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (PART OF 10) (10.701) [ГАЙКА М4]
25914313 PLATE, I/P CSTR TR (INCLS 52, 55) (EBONY)
15941681 PANEL, I/P LWR TR (INCLS 8, 53) (EBONY)
15941682 PANEL, I/P LWR TR (INCLS 8, 53) (LT CASHMERE)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 13, 50) [ЗАЖИМ КОНСОЛИ САЛОНА]
25976634 DEFLECTOR, I/P OTR AIR OTLT (PART OF 13) (EBONY)
15933153 PLATE, I/P TR (INCLS 11, 12) (RUBY) [ВОЗДУХОВОД ВЕНТИЛЯЦИИ САЛОНА]
15933154 PLATE, I/P TR (INCLS 11, 12) (CHOCOLATE) [ПОДДОН]
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 15) [ЗАЖИМ КОНСОЛИ САЛОНА]
15854787 COVER, I/P COMPT ACC HOLE (INCLS 14) (EBONY) (GLOVE BOX) [НАКЛАДКА ЦЕНТРАЛЬНОЙ КОНСОЛИ]
15854854 BUMPER, I/P COMPT DR STOP (BIN) (*KIT1) (16.110)
11609509 SCREW, LG RD WA HD, C/R, HI-LO, 4.2X1.41X13, 11.35-OD, B PT, 6010, GMW4205 (I/P COMPT DR) (*KIT1)
15683368 BUMPER, I/P COMPT (8.80 DIA) (CLOSED-STOP) (FRAME) (*KIT1) (16.650)
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (I/P COMPT DR) (9.665) [БОЛТ М4.2Х1.41Х25]
11609539 SCREW, RD CROWNED WA HD, M4.2X1.41X16, STL ISO 2702, GMW4205 (I/P COMPT DR LAT STKR) (*KIT1) [ВИНТ]
11610157 ГАЙКА, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (I/P LWR TIE BAR) (*KIT1) (10.701) [ГАЙКА М4]
11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (I/P COMPT DR HGE) (*KIT1) [ВИНТ М4]
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (I/P ACSRY CTR TR PLT) (*KIT3) [ЗАЖИМ КОНСОЛИ САЛОНА]
25976636 DEFLECTOR, I/P CTR AIR OTLT (EBONY) (*KIT3) [ВОЗДУХОВОД ВЕНТИЛЯЦИИ САЛОНА]
13502637 LATCH, I/P COMPT DR (EBONY) (W/LOCK) (PO DR & COMPMNT ASM) (*KIT1)
15296557 LATCH, I/P COMPT DR (CASHMERE) (W/LOCK) (*KIT1) (10.268)
25965476 LATCH, I/P COMPT DR (LT CASHMERE) (W/LOCK) (*KIT1)
15794823 CYLINDER, I/P COMPT DR LK [ЦИЛИНДР ЗАМКА ПЕРЧАТОЧНОГО ЯЩИКА]
25878605 PLATE, I/P ACSRY CTR TR (RUBY BURLWOOD) (W/O DEFLECTORS) (*KIT3) [ПАНЕЛЬ ЦЕНТРАЛЬНОЙ КОНСОЛИ]
25878606 PLATE, I/P ACSRY CTR TR (CHOCOLATE BURL) (W/O DEFLECTORS) (*KIT3)
15890427 DEFLECTOR, I/P CTR AIR OTLT (EBONY) (*KIT3)
10365827 INSULATOR, I/P (W/O FELT TAPE)
25790726 INSULATOR, I/P (W/FELT TAPE)
11609370 BOLT-HWH, M4.2X1.41X20, HI - LOW THD, , OD 12, 6010 STL, GMW4205, TAP (I/P INSL) (9.667)
15238666 PANEL, F/FLR CNSL SI TR FRT (INCLS 36) (EBONY) (16.081)
15238667 PANEL, F/FLR CNSL SI TR FRT (INCLS 36) (CASHMERE) (16.081)
15923060 PANEL, F/FLR CNSL SI TR FRT (INCLS 36-38, 57) (EBONY) (16.081)
15923061 PANEL, F/FLR CNSL SI TR FRT (INCLS 36-38, 57) (CASHMERE) (16.081)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 35) [ЗАЖИМ КОНСОЛИ САЛОНА]
11588920 SCREW, W/RND WA, M3.5X1.59X9.5, 6 THD, 7 O.D., GM512M, GMW3044 (PART OF 35)
15240415 MICROPHONE, RDO VOL COMP INTR NOISE (PART OF 35)
15221547 PLATE, HDLP SW TR (INCLS 40, 41) (EBONY)
11610112 CLIP, HDLP (PART OF 39) (10.4 X 13 X 9) (14.683)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 39) [ЗАЖИМ КОНСОЛИ САЛОНА]
15856685 BOLSTER, I/P DRVR KNEE (INCLS 42) (EBONY) [БУФЕР]
15856686 BOLSTER, I/P DRVR KNEE (INCLS 42) (CASHMERE)
15870179 BOLSTER, I/P DRVR KNEE (INCLS 42) (LT CASHMERE)
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (I/P DRVR KNEE BOLS) (9.665) [БОЛТ М4.2Х1.41Х25]
15832783 COVER, I/P FUSE BLK ACC HOLE (INCLS 46-49) (EBONY) (BUILT PRIOR TO 9/4/06) (FOR 2ND DES SEE 25855840)
15832786 COVER, I/P FUSE BLK ACC HOLE (INCLS 46-49) (COCOA) (BUILT PRIOR TO 9/4/06) (FOR 2ND DES SEE 25855843)
15832787 COVER, I/P FUSE BLK ACC HOLE (INCLS 46-49) (LT CASHMERE) (BUILT PRIOR TO 9/4/06) (FOR 2ND DES SEE 25855844)
15839736 COVER, I/P FUSE BLK ACC HOLE (INCLS 46-49) (EBONY) (BUILT PRIOR TO 9/4/06) (FOR 2ND DES SEE 25855846)
15839739 COVER, I/P FUSE BLK ACC HOLE (INCLS 46-49) (COCOA) (BUILT PRIOR TO 9/4/06) (FOR 2ND DES SEE 25855849)
15839740 COVER, I/P FUSE BLK ACC HOLE (INCLS 46-49) (LT CASHMERE) (BUILT PRIOR TO O9/4/06) (FOR 2ND DES SEE 25855850)
25855840 COVER, I/P FUSE BLK ACC HOLE (INCLS 46-49) (EBONY) (BUILT 9/4/06 & AFTER) (FOR 1ST DES SEE 15832783) [БОКОВАЯ КРЫШКА ЦЕНТРАЛЬНОЙ КОНСОЛИ]
25855843 COVER, I/P FUSE BLK ACC HOLE (INCLS 46-49) (COCOA) (BUILT 9/4/06 & AFTER) (FOR 1ST DES SEE 15832786)
25855844 COVER, I/P FUSE BLK ACC HOLE (INCLS 46-49) (LT CASHMERE) (BUILT 9/4/06 & AFTER) (FOR 1ST DES SEE 15832787)
25855846 COVER, I/P FUSE BLK ACC HOLE (INCLS 46-49) (EBONY) (BUILT 9/4/06 & AFTER) (FOR 1ST DES SEE 15839736)
25855849 COVER, I/P FUSE BLK ACC HOLE (INCLS 46-49) (COCOA) (BUILT 9/4/06 & AFTER) (FOR 1ST DES SEE 15839739)
25855850 COVER, I/P FUSE BLK ACC HOLE (INCLS 46-49) (LT CASHMERE) (BUILT 9/4/06 & AFTER) (FOR 1ST DES SEE 15839740)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 45) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
12092079 FUSE, 10A, MINI, RED (PART OF 45)
88909749 FUSE, 3A, MINI, VIOLET (PART OF 45) (8.965) (ACDelco #ATM3-25)
88909754 FUSE, 15A, MINI, BLUE (PART OF 45) (ACDelco #ATM15-25) [ПРЕДОХРАНИТЕЛЬ 15 А]
88909755 FUSE, 20A, MINI, YELLOW (PART OF 45) (ACDelco #ATM20-25) [ПРЕДОХРАНИТЕЛЬ 20 А]
88909756 FUSE, 25A, MINI, CLEAR (PART OF 45) (ACDelco #ATM25-25) [ПРЕДОХРАНИТЕЛЬ, 25A]
15839682 LABEL, FUSE BLK IDENT (PART OF 45)
12084791 PULLER, FUSE (PART OF 45) (MINI) (I/P COVER)
15863360 PLATE, I/P TR (INCLS 11, 51) (RUBY)
15863361 PLATE, I/P TR (INCLS 11, 51) (CHOCOLATE)
25976632 DEFLECTOR, I/P OTR AIR OTLT (PART OF 50) (EBONY)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 9) [ЗАЖИМ КОНСОЛИ САЛОНА]
11513599 ГАЙКА, U-TYPE, M4.2X1.41, 0.65-3.80 PNL THK, PZ (PART OF 10) (ACDelco #11513599)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (I/P UPR TR PLT) (*KIT2) [ЗАЖИМ КОНСОЛИ САЛОНА]
25603681 INSULATOR, I/P CSTR TR PLT (PART OF 9) (BLACK/RUBBER) (*KIT3)
11562257 RETAINER, I/P LWR TR PAD BRKT (PUSH ON) (PART OF 35) (19.5 X 30.4 X 1.8) (14.683)
25965503 DOOR, I/P COMPT (INCLS 16-19, 21-26, 29) (EBONY)
25965504 DOOR, I/P COMPT (INCLS 16-19, 21-26, 29) (CASHMERE)
15929999 PANEL, I/P UPR TR (INCLS 5, 6, 54) (EBONY) (CADILLAC)
15930000 PANEL, I/P UPR TR (INCLS 5, 6, 54) (COCOA) (W/CASHMERE TRIM)
25878602 PLATE, I/P ACSRY CTR TR (INCLS 27, 28, 31, 32, 55) (RUBY) (W/PLATE & DEFLECTORS)
25878603 PLATE, I/P ACSRY CTR TR (INCLS 27, 28, 31, 32) (CHOCOLATE BURL) (W/DEFLECTORS) [НАКЛАДКА ПАНЕЛИ]
(TC16-936) - 2007-2009 CK1(06-36) ПРИБОРНАЯ ПАНЕЛЬ & СОПРЯЖЕННЫЕ ДЕТАЛИ ЧАСТЬ 2 ELECTRICAL (CADILLAC Z75)
25812355 MODULE, I/P INFL RST (EBONY) [МОДУЛЬ УПРАВЛЕНИЯ ПРИБОРНОЙ ПАНЕЛЬЮ]
25812358 MODULE, I/P INFL RST (CASHMERE) [МОДУЛЬ]
11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (I/P INFL RST MDL) [БОЛТ М8]
15884145 CLOCK, (ENGLISH NUMBERS ON CLOCK FACE.)
25949881 CLOCK, (ROMAN NUMERALS ON CLOCK FACE.) [ЧАСЫ ПРИБОРНОЙ ПАНЕЛИ]
11610157 ГАЙКА, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (I/P) (10.701) [ГАЙКА М4]
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (RDO) (9.665) [БОЛТ М4.2Х1.41Х25]
15859233 SWITCH, RR OBJECT ALARM MDL
teamcadillac.ru
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (I/P ACSRY CTR TR PLT) [ЗАЖИМ КОНСОЛИ САЛОНА]
15859232 SWITCH, DRVR INFO DISPLAY [ВЫКЛЮЧАТЕЛЬ ИНФОРМАЦИОННОГО ДИСПЛЕЯ]
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (ACSRY SW BZL) (9.665) [БОЛТ М4.2Х1.41Х25]
15916341 SWITCH, ACSRY [ВЫКЛЮЧАТЕЛЬ]
15916342 SWITCH, ACSRY (ADJ PED & HOT SHOT WPR) [ВЫКЛЮЧАТЕЛЬ ПРИБОРНОЙ ПАНЕЛИ]
15911823 CONTROL, HTR & A/C (W/ F/SEAT HTR & CUSH VENT FAN) (LABELED 15911823) (ACDelco #15911823)
15926353 CONTROL, HTR & A/C (W/ D/SEAT & P/SEAT HTR) (LABELED 15926353, 25811054) (ACDelco #15926353)
15926356 CONTROL, HTR & A/C (W/ F/SEAT HTR & CUSH VENT FAN) (LABELED 15926356, 25811057) (ACDelco #15926356) [ПАНЕЛЬ УПРАВЛЕНИЯ ОТОПИТЕЛЕМ]
25928678 CONTROL, HTR & A/C (W/ D/SEAT & P/SEAT HTR) (ACDelco #15-73924)
25928681 CONTROL, HTR & A/C (W/ F/SEAT HTR & CUSH VENT FAN) (MARKED REAR) (ACDelco #15-73925)
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (COMN INTERFACE MDL BRKT) (9.665) [БОЛТ М4.2Х1.41Х25]
11588920 SCREW, W/RND WA, M3.5X1.59X9.5, 6 THD, 7 O.D., GM512M, GMW3044 (RDO VOL COMP INTR NOISE MIC)
15800441 MODULE, COMN INTERFACE (W/MOBILE TEL XCVR) (LABELED 15800441) (CASTING NUMBER 15800440) (ACDelco #15800441)
25911919 MODULE, COMN INTERFACE (W/MOBILE TEL XCVR) (ACDelco #25911919)
11610157 ГАЙКА, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (COMMUNICATION INTERFACE MDL BRKT) (10.701) [ГАЙКА М4]
25791895 BRACKET, COMMUNICATION INTERFACE MDL
15221547 PLATE, HDLP SW TR (INCLS 23) (EBONY)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 22) [ЗАЖИМ КОНСОЛИ САЛОНА]
15096896 SWITCH, HDLP & I/P LP DIMR & DM LP (INCLS FRT AND RR FOG LAMP SW) (HAS "OFF" SYMBOL) (ACDelco #D1573H) [ВЫКЛЮЧАТЕЛЬ ИНТЕНСИВНОСТИ СВЕТА ФАР]
25858706 SWITCH, HDLP & I/P LP DIMR & DM LP (HAS "DOME OFF") (INCLS FRT FOG LAMP SWITCH) (ACDelco #D1528J)
25858708 SWITCH, HDLP & I/P LP DIMR & DM LP (HAS "DOME OFF") (ACDelco #D1530J)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 29) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
12092079 FUSE, 10A, MINI, RED (PART OF 29)
88909749 FUSE, 3A, MINI, VIOLET (PART OF 29) (8.965) (ACDelco #ATM3-25)
88909754 FUSE, 15A, MINI, BLUE (PART OF 29) (ACDelco #ATM15-25) [ПРЕДОХРАНИТЕЛЬ 15 А]
88909755 FUSE, 20A, MINI, YELLOW (PART OF 29) (ACDelco #ATM20-25) [ПРЕДОХРАНИТЕЛЬ 20 А]
88909756 FUSE, 25A, MINI, CLEAR (PART OF 29) (ACDelco #ATM25-25) [ПРЕДОХРАНИТЕЛЬ, 25A]
12084791 PULLER, FUSE (PART OF 29) (MINI) (I/P COVER)
15839736 COVER, I/P FUSE BLK ACC HOLE (INCLS 26-28, 30) (EBONY) (BUILT PRIOR TO 9/4/06) (FOR 2ND DES SEE 25855846)
15839740 COVER, I/P FUSE BLK ACC HOLE (INCLS 26-28, 30) (LT CASHMERE) (BUILT PRIOR TO O9/4/06) (FOR 2ND DES SEE 25855850)
25855846 COVER, I/P FUSE BLK ACC HOLE (INCLS 26-28, 30) (EBONY) (BUILT 9/4/06 & AFTER) (FOR 1ST DES SEE 15839736)
25855850 COVER, I/P FUSE BLK ACC HOLE (INCLS 26-28, 30) (LT CASHMERE) (BUILT 9/4/06 & AFTER) (FOR 1ST DES SEE 15839740)
15839682 LABEL, FUSE BLK IDENT (PART OF 29)
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (INST CSTR) (9.665) [БОЛТ М4.2Х1.41Х25]
25713063 SENSOR, HDLP AUTO CONT AMB LGT (DUAL SOLAR & TWILIGHT) [ДАТЧИК ОСВЕЩЕННОСТИ ДЛЯ АВТОМАТИЧ.ВКЛЮЧ.ГАБАРИТОВ]
15929241 CLUSTER, INST (ACDelco #15929241) (LABELED 15929241)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 37) [ЗАЖИМ КОНСОЛИ САЛОНА]
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (RDO FRT SPKR) (9.665) [БОЛТ М4.2Х1.41Х25]
15221850 GRILLE, RDO FRT SPKR (INCLS 35) (EBONY)
15221851 GRILLE, RDO FRT SPKR (INCLS 35) (COCOA)
10396716 АНТЕННА, ELEK NAVIGATION (ACDelco #10396716)
(TC16-938) - 2007-2009 CK1,2,3 ВЕТРОВОЕ СТЕКЛО & СОПРЯЖЕННЫЕ ДЕТАЛИ
15139492 MIRROR, I/S RR VIEW (INCLS 2) (W/ONSTAR BUTTONS)
15269044 MIRROR, I/S RR VIEW (INCLS 2) (LT SEN, COMPASS, O/S TEMP DISPLAY) [ЗЕРКАЛО]
15269045 MIRROR, I/S RR VIEW (INCLS 2) (LT SEN, COMPASS, O/S TEMP DISPLAY, ONSTAR, & GPS)
15949878 MIRROR, I/S RR VIEW (INCLS 2)
15779345 COVER, I/S RR VIEW MIR WRG HARN (BETWEEN I/S MIRROR & HDLR)
15910710 ВЕТРОВОЕ СТЕКЛО, (WHEN REPL ВЕТРОВОЕ СТЕКЛО ORDER LENS FOR RAIN SENSOR) (INCLS 3, 6, 14) (INCLS UPPER MLDG) [ВЕТРОВОЕ СТЕКЛО]
15910711 ВЕТРОВОЕ СТЕКЛО, (INCLS 3, 6, 14) (INCLS UPR MLDG)
25783546 ВЕТРОВОЕ СТЕКЛО, (INCLS 3, 6, 14) (INCLS UPR MLDG) [ВЕТРОВОЕ СТЕКЛО]
11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (W/S R/MLDG)
11589183 ГАЙКА, PUSH IN, W/SEAL, 4.2X1.41, 6.35-6.48 SQ HL, 9.5 SQ HD, 0.787-2.765 PNL THK, NYL (W/S R/MLDG)
25975085 MOLDING, W/S RVL [МОЛДИНГ ВЕТРОВОГО СТЕКЛА]
teamcadillac.ru
25975086 MOLDING, W/S RVL [МОЛДИНГ В СБОРЕ]
25954952 SUPPORT, W/S [ФИКСАТОР ВЕТРОВОГО СТЕКЛА]
(TC16-939) - 2007-2009 CK107(06) КУЗОВНЫЕ ДЕТАЛИ/ROOF
15202470 PANEL, RF
25991527 PANEL, RF
15264587 BOW, RF PNL #4 (W/O NUT)
15102503 BOW, RF PNL #3 (W/O NUT)
15288511 BOW, RF PNL #2 (W/NUT)
15163037 BOW, RF PNL #1 (W/O NUT)
15202494 BRACKET, RF CNSL
teamcadillac.ru
15202446 PANEL, RF FRT HDR (INCLS 8, 9)
10056725 ГАЙКА, PUSH-IN, M4.2X1.41, 50 CARB SPR STL, GM7111M PO ZOR (PART OF 7)
(TC16-942) - 2007-2009 CK1,2,3 КУЗОВНЫЕ ДЕТАЛИ/COWL
15847235 PANEL, DA (INCLS 2-7, 9-17)
25907240 PANEL, PLNM UPR (PART OF 1)
15713209 BRACKET, BRK & ACCEL PED (PART OF 1) (L=45 W=80 H=80) (DASH PANEL) (0.829)
15134620 PANEL, PLNM LWR (PART OF 1)
15848622 PANEL, PLNM FRT (PART OF 1)
25847533 PANEL, COWL SI (PART OF 1) (INCLS 7)
15185462 VALVE, PLNM DRN
15856112 VALVE, PLNM DRN
15862261 BRACKET, FRT W/H PNL UPR (PART OF 1)
15185451 BRACKET, BAT TRAY (PART OF 1)
15176164 PANEL, COWL SI (PART OF 1) (INCLS 7)
teamcadillac.ru
11609625 STUD, DA & COWL PNL INSL (M5 X 1.6 X 57.0) (RIVET STYLE) (4.047)
15854747 BRACKET, КАПОТ STRUT (BODY SI) (PART OF 1) (INCLS 15)
11562567 STUD, КАПОТ STRUT BALL (PART OF 1, 14)
25809428 DEFLECTOR, PLNM LWR PNL WAT (PART OF 1) (INCLS 17)
15607103 RETAINER, PLNM PNL (PART OF 1, 16) (LWR WATER DEFLECTOR) (9.264)
15895064 COVER, PLNM UPR PNL OPG
(TC16-943) - 2007-2009 CK107(06) КУЗОВНЫЕ ДЕТАЛИ/НИЖНЯЯ ЧАСТЬ
15234714 PANEL, R/FLR (INCLS 2)
15630183 PLATE, CARGO TIE DN LOOP ANC (PART OF 1) (16.715)
10382641 BRACKET, JK STOW (BOTTOM BRKT INCLS STUDS)
15847621 PANEL, RR W/H INR
15274143 INSULATOR, S/D OPG FRM (C-PLR LWR)
15274144 INSULATOR, S/D OPG FRM (C-PLR LWR)
15288880 EXTENSION, INTER FLR PNL
15288881 EXTENSION, INTER FLR PNL
15290493 EXTENSION, FLR PNL (FRT)
25815106 EXTENSION, FLR PNL (FRT)
15115647 SILL, U/B RR CR
15226696 SILL, U/B #5 CR
25826963 SILL, U/B #3 CR
25860801 REINFORCEMENT, R/FLR PNL
15234718 REINFORCEMENT, R/FLR PNL OTR
15234719 REINFORCEMENT, R/FLR PNL OTR
25946282 SILL, U/B #4 CR
15154215 REINFORCEMENT, R/FLR PNL FRT
15234716 REINFORCEMENT, R/FLR PNL FRT (INCLS EXH MUFF H/SHLD, WELD STUDY)
15234712 REINFORCEMENT, INTER FLR PNL (INCLS EXH MUFF H/SHLD, WELD STUDY)
15722519 REINFORCEMENT, INTER FLR PNL
15029772 BRACE, INTER FLR PNL
15234710 REINFORCEMENT, FLR PNL
teamcadillac.ru
15234713 REINFORCEMENT, INTER FLR PNL (CENTER)
25860799 REINFORCEMENT, FLR PNL
25946285 SILL, U/B #1 CR
15107879 BRACE, CR SILL
15828261 REINFORCEMENT, FLR PNL (D/SEAT) (OUTER)
25831426 BRACKET, BODY MT (#2)
25860798 SILL, U/B #2 CR
25831425 BRACKET, BODY MT (#2)
15822915 REINFORCEMENT, FLR PNL (D/SEAT) (INNER)
25937227 BRACE, CR SILL
15896696 SILL, U/B #1 CR
15234733 REINFORCEMENT, FLR PNL (P/SEAT) (OUTER)
15234735 REINFORCEMENT, FLR PNL (P/SEAT) (INNER)
15173440 STIFFENER, FLR PNL AT TUN
15173441 STIFFENER, FLR PNL AT TUN
25860800 PANEL, F/FLR (INCLS 37-39)
15234730 PANEL, RKR FRT INR
15827692 PANEL, RKR FRT INR
25982599 PANEL, RKR FRT INR [ПАНЕЛЬ]
15174121 BRACKET, I/P LWR (PART OF 35)
15734736 STUD, F/SEAT ANC PLT (PART OF 35)
11609625 STUD, BODY WRG HARN GND (PART OF 35) (M5 X 1.6 X 57.0) (RIVET STYLE) (4.047)
15234731 PANEL, RKR RR INR (INCLS STUDS)
15243789 PANEL, RKR RR INR
15950124 PANEL, INTER FLR
(TC16-946) - 2007-2009 CK107(06) КУЗОВНЫЕ ДЕТАЛИ SIDE FRONT
15934444 FRAME, S/D OPG (INCLS 16, 17, 29, 31)
15934445 FRAME, S/D OPG (INCLS 16, 17, 29, 31)
11609733 БОЛТ, HEX W/CON WA, M8X1.25X30, 20 THD, 24 OD, 10.9, GMW4205, MAT POINT (RR S/D HGE (DR SI)) [БОЛТ М8]
25854397 HINGE, RR S/D UPR (BODY & DR SIDE) (REPL T/W 11562286 - QTY 1) [ПЕТЛЯ ДВЕРИ]
25854398 HINGE, RR S/D UPR (BODY & DR SIDE) (REPL T/W 11562286 - QTY 1) [ПЕТЛЯ ДВЕРИ]
11609733 БОЛТ, HEX W/CON WA, M8X1.25X30, 20 THD, 24 OD, 10.9, GMW4205, MAT POINT (RR S/D HGE (BODY SI)) [БОЛТ М8]
25958200 HINGE, RR S/D LWR (BODY & DR SIDE)
25958201 HINGE, RR S/D LWR (BODY & DR SIDE) [ПЕТЛЯ ДВЕРИ]
20773442 PANEL, RR S/D OTR (PART OF 8) [ПАНЕЛЬ ДВЕРИ]
20773443 PANEL, RR S/D OTR (PART OF 8)
25961382 DOOR, RR SI (INCLS 7) [ПАНЕЛЬ ДВЕРИ]
25961383 DOOR, RR SI (INCLS 7) (W/O HINGES) [ЗАДНЯЯ ДВЕРЬ]
25958196 HINGE, FRT S/D LWR (BODY & DR SIDE)
25958197 HINGE, FRT S/D LWR (BODY & DR SIDE)
11609733 БОЛТ, HEX W/CON WA, M8X1.25X30, 20 THD, 24 OD, 10.9, GMW4205, MAT POINT (FRT S/D HGE (BODY SI)) [БОЛТ М8]
25854415 HINGE, FRT S/D UPR (BODY & DR SIDE) (REPL T/W 11562286 - QTY 1) [ПЕТЛЯ ДВЕРИ]
25854416 HINGE, FRT S/D UPR (BODY & DR SIDE) (REPL T/W 11562286 - QTY 1) [ПЕТЛЯ ДВЕРИ]
25891763 PANEL, FRT S/D OTR (PART OF 14)
25891764 PANEL, FRT S/D OTR (PART OF 14)
15228568 DOOR, FRT SI (INCLS 13) (W/O HINGES)
25912653 DOOR, FRT SI (INCLS 13) (W/O HINGES) [ПАНЕЛЬ ДВЕРИ]
15837057 INSULATOR, S/D OPG FRM (LWR FRT BODY H-PLR)
15837058 INSULATOR, S/D OPG FRM (LWR FRT BODY H-PLR)
25858298 SEAL, C/PLR LWR
25858299 SEAL, C/PLR LWR
10393085 REINFORCEMENT, FRT S/D OPG FRM
10393086 REINFORCEMENT, FRT S/D OPG FRM
10393087 RAIL, RF SI (INCLS 23)
10393088 RAIL, RF SI (INCLS 23)
15853601 PANEL, C/PLR INR UPR (INCLS 25)
15853602 PANEL, C/PLR INR UPR (INCLS 25)
teamcadillac.ru
15854158 PANEL, BODY SI INR UPR
15858829 PANEL, BODY SI INR UPR
15854232 PLATE, R/SEAT SHLDR BELT ANC
25913870 PLATE, R/SEAT SHLDR BELT ANC
25918297 PANEL, C/PLR INR LWR (INCLS 30)
25918298 PANEL, C/PLR INR LWR (INCLS 30)
15232690 PLUG, BODY SI FRM ACC HOLE (SQUARE)
(TC16-948) - 2007-2009 CK107(06) КУЗОВНЫЕ ДЕТАЛИ SIDE REAR
25822461 PANEL, BODY SI OTR
25822462 PANEL, BODY SI OTR [ПАНЕЛЬ ЗАДНЕЙ ЧАСТИ КУЗОВА]
11609731 RIVET, F/TNK FIL DR HGE (25" SHANK, .63 LEN, .50 OD, .06-.30 GRP RNG, 1008 STL, GMW3044) (8.967)
15940678 DOOR, F/TNK FIL (СМ. ГРУППУ 03.000 "FUEL FILLER PIPE" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА)
15202493 FILLER, BODY SI OTR PNL
15862274 EXTENSION, RR W/H PNL FRT
15862275 EXTENSION, RR W/H PNL FRT
15929419 PANEL, RR W/H OTR (FRT)
15929495 PANEL, RR W/H OTR (FRT)
15824937 PANEL, RR W/H OTR (RR)
15824938 PANEL, RR W/H OTR (RR)
15830951 GASKET, F/TNK FIL DR OPG FIL
15830910 PANEL, BODY SI INR LWR
15830911 PANEL, BODY SI INR LWR
15876164 SEAL, BODY SI INR LWR PNL
15876165 SEAL, BODY SI INR LWR PNL
15202476 RAIL, RF UPR SI
15202477 RAIL, RF UPR SI
10394686 REINFORCEMENT, BK BODY OPG SI FRM (СМ. ГРУППУ 16.000 "КУЗОВНЫЕ ДЕТАЛИ REAR" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА)
25893160 REINFORCEMENT, BK BODY OPG SI FRM (СМ. ГРУППУ 16.000 "КУЗОВНЫЕ ДЕТАЛИ REAR" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА)
15900620 RAIL, RF LWR SI
15900621 RAIL, RF LWR SI
teamcadillac.ru
25780811 PANEL, BODY SI INR
25780812 PANEL, BODY SI INR
15255977 PANEL, F/TNK FIL PIPE HSG
(TC16-951) - 2007-2009 CK1,2(06) КУЗОВНЫЕ ДЕТАЛИ REAR
15164154 FRAME, BK BODY OPG UPR
15847152 EXTENSION, BK BODY OPG FRM UPR
25778949 FRAME, BK BODY OPG
15164155 FRAME, BK BODY OPG SI
15043000 PLUG, R/CMPT SILL TR PLT HOLE (38.0 X 17.0 X 18.0MM) (OBLONG) (16.600)
15829742 REINFORCEMENT, BK BODY OPG FRM LWR (INCLS 7)
15164157 FRAME, BK BODY OPG LWR
25946269 BRACKET, BODY RR MT (INCLS 10) (BODY)
teamcadillac.ru
15887101 SEAL, BK BODY OPG LWR FRM FIL (TO INTER FLR PNL)
15887102 SEAL, BK BODY OPG LWR FRM FIL (TO INTER FLR PNL)
15816355 PANEL, BK BODY OPG FRM SI FIL LWR
15816359 FILLER, BK BODY OPG FRM SI
15816356 PANEL, BK BODY OPG FRM SI FIL LWR
15816358 FILLER, BK BODY OPG FRM SI
15164156 FRAME, BK BODY OPG SI
(TC16-952) - 2007-2009 CK1,2,3(06-36-43) ОТДЕЛКА/INTERIOR-BODY SIDE FRONT
15924657 MOLDING, W/S SI GARN (INCLS 2-7) (GRAY) (W/SPEAKER)
15924658 MOLDING, W/S SI GARN (INCLS 2-7) (CASHMERE) (W/SPEAKER)
20803784 MOLDING, W/S SI GARN (INCLS 2-7) (GRAY)
25797326 MOLDING, W/S SI GARN (INCLS 2-7) (CASHMERE) [МОЛДИНГ КУЗОВА]
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 1) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
11609651 CLIP, W/S SI G/MLDG (PART OF 1) (M21.8X15.0X20.5) (14.731) [ШАЙБА]
11609465 БОЛТ, HWH, M4.2X1.41X18, 12.5 OD, 6010M, PS (PART OF 1) (8.977) [ВИНТ М6]
15214075 PLUG, W/S SI G/MLDG BOLT HOLE FIN (PART OF 1) (CASHMERE) (16.575)
15220491 PLUG, W/S SI G/MLDG BOLT HOLE FIN (PART OF 1) (CASHMERE)
15220492 PLUG, W/S SI G/MLDG BOLT HOLE FIN (PART OF 1) (GRAY)
15186674 SPEAKER, RDO W/S SI G/MLDG (PART OF 1, 23) (ACDelco #15186674) [ДИНАМИК 20ВТ]
15841537 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 1) (CASHMERE)
25889853 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 1)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 9) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
15848295 PANEL, BODY H/PLR TR (INCLS 8) (CASHMERE)
15848301 PANEL, BODY H/PLR TR (INCLS 8) (CASHMERE)
15904432 PANEL, BODY H/PLR TR (INCLS 8) (EBONY) [ВНУТРЕННЯЯ ПАНЕЛЬ СТОЙКИ КУЗОВА]
15904433 PANEL, BODY H/PLR TR (INCLS 8) (TITANIUM)
15904434 PANEL, BODY H/PLR TR (INCLS 8) (CASHMERE)
15904438 PANEL, BODY H/PLR TR (INCLS 8) (EBONY)
15904439 PANEL, BODY H/PLR TR (INCLS 8) (TITANIUM)
15904440 PANEL, BODY H/PLR TR (INCLS 8) (CASHMERE)
15848374 PLATE, FRT S/D SILL TR (INCLS 11) (CASHMERE) (W/CADILLAC INSERT)
15848375 PLATE, FRT S/D SILL TR (INCLS 11) (EBONY) (W/CADILLAC INSERT)
15848378 PLATE, FRT S/D SILL TR (INCLS 11) (CASHMERE) (W/CADILLAC INSERT)
15848379 PLATE, FRT S/D SILL TR (INCLS 11) (EBONY) (W/CADILLAC INSERT)
15848382 PLATE, FRT S/D SILL TR (INCLS 11) (EBONY)
15848383 PLATE, FRT S/D SILL TR (INCLS 11) (CASHMERE)
15848386 PLATE, FRT S/D SILL TR (INCLS 11) (EBONY)
15848387 PLATE, FRT S/D SILL TR (INCLS 11) (CASHMERE)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 10) [ЗАЖИМ КОНСОЛИ САЛОНА]
25809572 MOLDING, C/PLR LWR GARN (INCLS 13) (CASHMERE)
25880275 MOLDING, C/PLR LWR GARN (INCLS 13) (CASHMERE)
25880276 MOLDING, C/PLR LWR GARN (INCLS 13) (TITANIUM)
25880277 MOLDING, C/PLR LWR GARN (INCLS 13) (EBONY)
25880278 MOLDING, C/PLR LWR GARN (INCLS 13) (CASHMERE)
25880281 MOLDING, C/PLR LWR GARN (INCLS 13) (CASHMERE)
25880282 MOLDING, C/PLR LWR GARN (INCLS 13) (TITANIUM)
25880283 MOLDING, C/PLR LWR GARN (INCLS 13) (EBONY)
15214078 COVER, D/SEAT SHLDR BELT GDE ADJR CLOSEOUT (PART OF 15) (GRAY)
15236114 COVER, D/SEAT SHLDR BELT GDE ADJR CLOSEOUT (PART OF 15) (CASHMERE)
25797317 MOLDING, C/PLR UPR GARN (INCLS 13, 14, 16-19) (GRAY)
25797318 MOLDING, C/PLR UPR GARN (INCLS 13, 14, 16-19) (CASHMERE) [ВНУТРЕННЯЯ ПАНЕЛЬ БАГАЖНОГО ОТСЕКА]
25797320 MOLDING, C/PLR UPR GARN (INCLS 13, 14, 16-19) (GRAY)
25797321 MOLDING, C/PLR UPR GARN (INCLS 13, 14, 16-19) (CASHMERE)
15278044 PLUG, C/PLR HOLE (PART OF 15) (GRANITE)
15278046 PLUG, C/PLR HOLE (PART OF 15) (LT CASHMERE)
15278047 PLUG, C/PLR HOLE (PART OF 15) (GRAY)
11609465 БОЛТ, HWH, M4.2X1.41X18, 12.5 OD, 6010M, PS (PART OF 15) (8.977) [ВИНТ М6]
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 15) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
teamcadillac.ru
11570136 БОЛТ, HEX HD, W/CON SPR WA, M6X1X23, 14 THD, 17 O.D., 8.8, GMW3359 (ASST HDL)
15845416 HANDLE, ASST (GRAY)
15845417 HANDLE, ASST (LT CASHMERE)
15845418 HANDLE, ASST (CASHMERE)
15845422 HANDLE, ASST (LT CASHMERE)
20776884 HANDLE, ASST (GRAY)
20776886 HANDLE, ASST (CASHMERE)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 23) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
15924664 MOLDING, W/S SI GARN (INCLS 6, 22, 24) (GRAY) (W/SPEAKER)
15924665 MOLDING, W/S SI GARN (INCLS 6, 22, 24) (CASHMERE)
20803780 MOLDING, W/S SI GARN (INCLS 6, 22, 24) (GRAY)
25797323 MOLDING, W/S SI GARN (INCLS 6, 22, 24) (CASHMERE)
25889859 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 23) (GRAY)
25889861 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 23)
25889862 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 23)
15220455 COVER, W/S PLR ASST HDL (PART OF 27) (GRAY) (UPPER)
15220456 COVER, W/S PLR ASST HDL (PART OF 27) (CASHMERE) (UPPER)
15220459 COVER, W/S PLR ASST HDL (PART OF 27) (GRAY) (LOWER)
15220460 COVER, W/S PLR ASST HDL (PART OF 27) (CASHMERE) (LOWER)
15255444 COVER, W/S PLR ASST HDL (PART OF 27) (CASHMERE) (LOWER)
15255445 COVER, W/S PLR ASST HDL (PART OF 27) (CASHMERE) (UPPER)
11609939 БОЛТ, HEX W/FLAT WA, M6X1X30, 21 THD, 17 OD, TAPPING (W/S PLR ASST HDL)
15916832 HANDLE, W/S PLR ASST (INCLS 25) (GRAY)
15916833 HANDLE, W/S PLR ASST (INCLS 25) (CASHMERE)
15916834 HANDLE, W/S PLR ASST (INCLS 25) (CASHMERE)
(TC16-956) - 2007 CK1,2(06) LOCKING SYSTEM/REMOTE (AP3,AP8,AU0,AU5,AU8)
12538938 АККУМУЛЯТОР, R/CON DR LK XMTR (PART OF 2) (LITHIUM) (TRADE CR2032) (10.485) [БАТАРЕЙКА КНОПОЧНАЯ ЛИТИЕВАЯ]
15913415 TRANSMITTER, R/CON DR LK (INCLS 1) (4 BUTN) (W/REMOTE STARTER) (LIFTGLASS) (LABELED OEM 15913415)
teamcadillac.ru
15913416 TRANSMITTER, R/CON DR LK (INCLS 1) (4 BUTN) (W/O REMOTE STARTER) (LIFTGLASS)
15913418 TRANSMITTER, R/CON DR LK (INCLS 1) (5 BUTN) (W/O REMOTE STARTER) (LIFTGATE & LIFTGLASS) (LABELED OEM 15913418)
15913420 TRANSMITTER, R/CON DR LK (INCLS 1) (3 BUTTON) (W/O REMOTE STARTER)
15913422 TRANSMITTER, R/CON DR LK (INCLS 1) (LABELED OEM 15913422) [УСТРОЙСТВО ДИСТАНЦИОННОГО УПРАВЛЕНИЯ ЦЕНТРАЛЬНЫМ ЗАМКОМ]
15913426 TRANSMITTER, R/CON DR LK (INCLS 1) (LABELED OEM 15913426)
15913427 TRANSMITTER, R/CON DR LK (INCLS 1) (5 BUTN) (W/REMOTE STARTER) (LIFTGATE & LIFTGLASS) (LABELED OEM 15913427) [УСТРОЙСТВО ДИСТАНЦИОННОГО УПРАВЛЕНИЯ ЦЕНТРАЛЬНЫМ ЗАМКОМ]
15827429 АНТЕННА, R/CON DR LK RCVR
20803736 RECEIVER, R/CON DR LK (RECEIVERS LABELED OEM 20803736) (10.485)
25852909 RECEIVER, R/CON DR LK (10.485) (LABELED 15857831 OR 15946938)
25896540 RECEIVER, R/CON DR LK (RECEIVERS LABELED OEM 25896540) (10.485)
(TC16-957) - 2007-2009 CK1,2(06-36) ПРИБОРНАЯ ПАНЕЛЬ & СОПРЯЖЕННЫЕ ДЕТАЛИ ЧАСТЬ 3 SUPPORTS (CADILLAC Z75)
25842111 SUPPORT, INST CARR (INCLS 3, 4, 10)
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (I/P LWR TR PAD) (9.665) [БОЛТ М4.2Х1.41Х25]
11610157 ГАЙКА, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (PART OF 1) (10.701) [ГАЙКА М4]
25640395 ГАЙКА, I/P CARR SUPT (PART OF 1) (COPPER) (9.647)
15192254 DEFLECTOR, I/P DRVR KNEE BOLS [КОЖУХ НИЖНЕЙ ЧАСТИ ЦЕНТРАЛЬНОЙ КОНСОЛИ]
11508277 ГАЙКА, HEX W/CON WA M6X1 THD, OD-19 PEOR 9 (I/P DRVR KNEE BOLS DFL) [ГАЙКА М6]
10355555 BRACE, I/P CTR SUPT
11609410 БОЛТ, HFH, M8X1.25X25, 10.9, GMW3179 (I/P CTR SUPT BR) (0.056) [БОЛТ]
11589407 БОЛТ, HWH, M8X1.25X35, 23.5 THD, 24 OD, 10.9, GMW3359, M-PT. (INST CARR SUPT) [БОЛТ]
11508277 ГАЙКА, HEX W/CON WA M6X1 THD, OD-19 PEOR 9 (I/P LWR T/PNL) [ГАЙКА М6]
teamcadillac.ru
11570136 БОЛТ, HEX HD, W/CON SPR WA, M6X1X23, 14 THD, 17 O.D., 8.8, GMW3359 (I/P UPR T/PNL)
(TC16-958) - 2007-2009 CK1,2(06) WIPER SYSTEM/ВЕТРОВОЕ СТЕКЛО (EXC POLICE PACKAGE PPV)
15916552 ARM, WSW (W/NOZZLE & HOSE) (CONVENTIONAL) (USE ON VEH BUILT 07/22/07 & PRIOR) (FOR 2ND DES SEE 25872300) [ДЕРЖАТЕЛЬ СТЕКЛООЧИСТИТЕЛЯ]
20773357 ARM, WSW (BLACK) (W/NOZZLE & HOSE) (STYLIZED) (USE ON VEH BUILT 07/22/07 & PRIOR) (FOR 2ND DES SEE 20773355)
25872299 ARM, WSW (W/NOZZLE & HOSE) (CONVENTIONAL) (USE ON VEH BUILT 07/22/07 & PRIOR) (FOR 2ND DES SEE 25875220)
25872300 ARM, WSW (W/NOZZLE & HOSE) (USE ON VEH BUILT 07/23/07 & AFTER) (FOR 1ST DES SEE 15916552)
25875220 ARM, WSW (W/NOZZLE & HOSE) (USE ON VEH BUILT 07/23/07 & AFTER) (FOR 1ST DES SEE 25872299)
15788727 CAP, WSW ARM FIN (10.147) [КОЛПАЧОК ДЕРЖАТЕЛЯ ЩЕТКИ СТЕКЛООЧИСТИТЕЛЯ]
25820729 PANEL, AIR INL GRL (BLACK) [НАКЛАДКА ВОДОСТОЧНОЙ ПАНЕЛИ]
25820730 PANEL, AIR INL GRL (BLACK) [НАКЛАДКА ВОДОСТОЧНОЙ ПАНЕЛИ]
25872303 PANEL, AIR INL GRL (CTR) (INCLS 10, 14, 18) (BLACK)
11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (AIR INL GRL PNL)
teamcadillac.ru
11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (WSWA SOLV CNTNR) [БОЛТ М6]
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (WSWA SOLV HTR) [ГАЙКА М6]
(TC16-960) - 2007-2009 CK1,2(06) СТЕКЛООЧИСТИТЕЛЬ-ЗАДНЕГО СТЕКЛА (C25)
15942522 CONTAINER KIT, WSWA SOLV (2P & 1LS GROMMETS) (INCLS 3) [БАЧОК СТЕКЛООМЫВАТЕЛЯ]
25887957 HOSE, R/WDO WA PUMP (REAR JUMPER HOSE)
15927514 GROMMET, WSWA PUMP (PUMP GROMMET) (PART OF 1, 4) [УПЛОТНЯЮЩЕЕ КОЛЬЦО]
15942524 PUMP KIT, WSWA W/ SEAL (INCLS 3) (RR PUMP KIT W/GROMMET)
25820075 RAMP, R/WDO WPR ARM PARK [УПОР ДЕРЖАТЕЛЯ ЩЕТКИ СТЕКЛООЧИСТИТЕЛЯ]
25820122 BLADE, R/WDO WPR [ЩЕТКА СТЕКЛООЧИСТИТЕЛЯ]
15798935 CAP, WSW ARM NUT (PART OF 10) [КОЛПАЧОК-ГАЙКИ ОЧИСТ.ЗАДН.СТКЛА]
11589150 ГАЙКА, HEX, W/ADH, M8X1.25X6.80, 5, GMW3359 (R/WDO WPR ARM) [ГАЙКА]
15277756 ARM, R/WDO WPR (INCLS 8) (INCLS HOSE) [ДЕРЖАТЕЛЬ ЩЕТКИ СТЕКЛООЧИСТИТЕЛЯ]
11569839 ГАЙКА, R/WDO WPR MOT
15173732 SPACER, R/WDO WPR MOT
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (R/WDO WPR ARM PARK RAMP) [ГАЙКА М6]
25923437 MOTOR, R/WDO WPR (INCLS MTG BOLTS AND GROMMETS) (ACDelco #25923437) [ЭЛЕКТРОДВИГАТЕЛЬ СТЕКЛООЧИСТИТЕЛЯ 90 ВТ]
25887953 HOSE, WSWA L/GATE EXTN RR (ACDelco #25887953)
20784419 HOSE, WSWA L/GATE EXTN SI LWR (ACDelco #20784419)
15076678 INSULATOR, WSW TRANS SUPT (16.686)
(TC16-961) - 2007-2009 CK1,2(06) WHEELHOUSE LINER/REAR
15938661 LINER, RR W/H PNL (INCLS 6) (W/NUT) [КРЫШКА]
15938662 LINER, RR W/H PNL (INCLS 6) (W/NUT) [ПОДКРЫЛОК]
11609459 SCREW, RND WA, M4.2X1.41X13, 7.2 THD, 11.35 OD, 6010M, GMW4205 (RR W/H PNL LNR) [ВИНТ]
11589292 PUSH PIN, FITS 8.5 DIA HOLE IN 2-4.5 THK PNL, NYLON 6/6 GMP.PA66.015 (RR W/H PNL LNR (PUSH IN)) [ФИКСАТОР ПАНЕЛИ БАМПЕРА]
01605396 RETAINER, PUSH-IN, FITS .250 HOLE, .92 LG.700-OD NYLON BLACK (RR W/H PNL LNR (PUSH IN))
11570498 БОЛТ, HWH W/FL WA, M4.2X1.41X20, 11.4 THD, 17 OD, ISO 2702 STL , GMW4205, T (RR W/H PNL LNR)
11513599 ГАЙКА, U-TYPE, M4.2X1.41, 0.65-3.80 PNL THK, PZ (PART OF 1) (ACDelco #11513599)
11518531 ГАЙКА, U-TYPE, M4.2X1.41, 15.9X8.4, .7-2.1 PNL, SAE 1050 STL, 7111M, 8.65 SQ HOL (RR W/H PNL) (10.512) [ГАЙКА М10]
teamcadillac.ru
(TC16-962) - 2007-2009 CK1,2,3 INSULATORS/DASH PANEL
15852989 INSULATOR, DA PNL (INTERIOR DASH)
15901816 INSULATOR, DA PNL (INTERIOR DASH)
25826685 INSULATOR, COWL S/PNL
25877094 INSULATOR, COWL S/PNL
25954935 INSULATOR, DA PNL (INCLS 4) (ДВИГАТЕЛЬ SIDE)
teamcadillac.ru
(TC16-963) - 2007 CK107(06) FLOOR COVERING & СОПРЯЖЕННЫЕ ДЕТАЛИ
15811635 CARPET, R/FLR PNL (INCLS 5, 15, 16) (EBONY)
15811636 CARPET, R/FLR PNL (INCLS 5, 15, 16) (CASHMERE)
15819120 MAT, R/FLR (BLACK)
15948213 CARPET, R/FLR PNL (INCLS 5, 15, 16) (TITANIUM)
25891808 CARPET, R/FLR PNL (INCLS 5, 15, 16) (EBONY)
25891809 CARPET, R/FLR PNL (INCLS 5, 15, 16) (CASHMERE)
25891810 CARPET, R/FLR PNL (INCLS 5, 15, 16) (CASHMERE)
11588960 БОЛТ, PAN HD, M10X1.5X38, 30 THD, 18OD, 10.8, 4205GMW, TORX, M-POINT (CARGO TIE DN HOOK)
15749157 HOOK, CARGO TIE DN (BLACK) (17.090)
15835448 INSULATOR, FLR PNL RR
25974423 INSULATOR, FLR PNL RR
15917244 DEADENER, RR W/H INR PNL
15917245 DEADENER, RR W/H INR PNL
90584197 DEADENER, FLR PNL (88X220MM) (6.758)
25921050 INSULATOR, FLR PNL FRT
teamcadillac.ru
25850428 CARPET, F/FLR PNL (EBONY) [НАПОЛЬНОЕ ПОКРЫТИЕ САЛОНА]
25850429 CARPET, F/FLR PNL (TITANIUM)
25850430 CARPET, F/FLR PNL (CASHMERE)
25850431 CARPET, F/FLR PNL (CASHMERE)
25850434 CARPET, F/FLR PNL (EBONY)
25850435 CARPET, F/FLR PNL (TITANIUM)
25850436 CARPET, F/FLR PNL (CASHMERE)
25998503 MAT, F/FLR PNL (BLACK)
19121499 MAT PKG, FRONT VINYL (CASHMERE) (TWIN) (NO LOGO) (16.800)
19121914 MAT PKG, FRONT CARPET (CASHMERE) (TWIN) (NO LOGO) (15.286) [КОВРИК]
19121915 MAT PKG, FRONT CARPET (EBONY) (TWIN) (NO LOGO) (15.286) [КОМПЛЕКТ КОВРИКОВ САЛОНА (2ШТ) 0.48 М2]
19121487 MAT PKG, REAR VINYL (NO LONGER AVAIL, REFER ALT P/NS 19166596, 19166602, 19155783, 19158991, 19157415) (CASHMERE) (TWIN) (16.800)
19121926 MAT PKG, REAR CARPET (EBONY) (TWIN) (16.800) [КОМПЛЕКТ КОВРИКОВ САЛОНА (2ШТ) 0.48 М2]
19121927 MAT PKG, REAR CARPET (CASHMERE) (TWIN) (16.800) [КОВРИК]
25781944 MAT PKG, REVERSIBLE CARGO (EBONY) (USED WHEN 3RD ROW SEAT IS REMOVED)
25781945 MAT PKG, REVERSIBLE CARGO (TITANIUM) (USED WHEN 3RD ROW SEAT IS REMOVED)
25781946 MAT PKG, REVERSIBLE CARGO (CASHMERE) (USED WHEN 3RD ROW SEAT IS REMOVED)
15948218 CARPET, R/FLR PNL (EBONY)
15948219 CARPET, R/FLR PNL (TITANIUM)
15948220 CARPET, R/FLR PNL (CASHMERE)
25998505 MAT, R/FLR (BLACK)
(TC16-965) - 2007-2009 CK1,2,3 INFLATABLE RESTRAINT SYSTEM
25812356 MODULE, I/P INFL RST (CASHMERE)
25812357 MODULE, I/P INFL RST (TITANIUM)
15874515 MODULE, STRG WHL INFL RST (EBONY) (LABELED 15874515) (DUAL LEVEL) (16.712)
15874516 MODULE, STRG WHL INFL RST (COCOA) (LABELED 15874516) (DUAL LEVEL) (INCLS EMBLEM) (16.712)
15874519 MODULE, STRG WHL INFL RST (EBONY) (LABELED 15874519) (DUAL LEVEL) (16.712)
15874520 MODULE, STRG WHL INFL RST (COCOA) (LABELED 15874520) (DUAL LEVEL) (16.712)
25917968 MODULE, STRG WHL INFL RST (EBONY) (LABELED 25917968) (DUAL LEVEL) (16.712) [ПОДУШКА БЕЗОПАСНОСТИ]
25917969 MODULE, STRG WHL INFL RST (COCOA) (LABELED 25917969) (DUAL LEVEL) (16.712) [МОДУЛЬ]
25917971 MODULE, STRG WHL INFL RST (EBONY) (LABELED 25917971) (DUAL LEVEL) (16.712)
25917972 MODULE, STRG WHL INFL RST (COCOA) (LABELED 25917972) (DUAL LEVEL) (16.712)
21996989 TAG, INFL RST I/P MDL CAUTION (HANGING)
03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (INFL RST VEH ROLLOVER SEN)
25815382 SENSOR, INFL RST VEH ROLLOVER [ДАТЧИК ПОДУШКИ БЕЗОПАСНОСТИ]
teamcadillac.ru
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (INFL RST SEN & DIAGN MDL) [ГАЙКА М6]
25823556 MODULE, INFL RST SEN & DIAGN [БЛОК УПРАВЛЕНИЯ ПОДУШКОЙ БЕЗОПАСНОСТИ]
25823557 MODULE, INFL RST SEN & DIAGN
15854647 SENSOR, F/END INFL RST DISCRM
22625546 INDICATOR, INFL RST I/P MDL (W/WORDS ON AND OFF FOR AIRBAG) (14.865)
22627868 INDICATOR, INFL RST I/P MDL (W/AIRBAG SYMBOLS FOR ON AND OFF) (14.865)
(TC16-966) - 2007-2009 CK107(06) INFLATABLE RESTRAINT SYSTEM/ROOF SIDE(ASF)
15939463 MODULE, INFL RST RF S/RL RR (INCLS 2, 3) (3RD ROW) [ПОДУШКА БЕЗОПАСНОСТИ]
15939464 MODULE, INFL RST RF S/RL RR (INCLS 2, 3) (3RD ROW) [ПОДУШКА БЕЗОПАСНОСТИ]
11609939 БОЛТ, HEX W/FLAT WA, M6X1X30, 21 THD, 17 OD, TAPPING (PART OF 1)
11609939 БОЛТ, HEX W/FLAT WA, M6X1X30, 21 THD, 17 OD, TAPPING (PART OF 6)
25903827 MODULE, RF S/RL INFL RST (INCLS 4, 5) (LABELED 25903827) [ПОДУШКА БЕЗОПАСНОСТИ]
25903828 MODULE, RF S/RL INFL RST (INCLS 4, 5) (LABELED 25903828) [ПОДУШКА БЕЗОПАСНОСТИ]
teamcadillac.ru
10381278 SENSOR, INFL RST SI IMP (MOUNTED ON RR DR BEAM) (INCLS BOLTS) (MT ON RR DOOR BEAM) [ДАТЧИК ПОДУШКИ БЕЗОПАСНОСТИ]
15093923 SENSOR, INFL RST SI IMP (MOUNTED ON FRT DR BEAM) (W/BOLTS) (MT ON FRT DOOR BEAM) [ДАТЧИК ПОДУШКИ БЕЗОПАСНОСТИ]
(TC16-971) - 2007-2009 CK1(06-36) АРМАТУРА ДВЕРИ/SIDE FRONT ЧАСТЬ 1 (CADILLAC Z75)
25844462 WEATHERSTRIP, FRT & RR S/D UPR AUX (INCLS RETAINERS) [УПЛОТНИТЕЛЬ ДВЕРИ]
25844463 WEATHERSTRIP, FRT & RR S/D UPR AUX (INCLS RETAINERS)
25892949 WEATHERSTRIP, FRT S/D [УПЛОТНИТЕЛЬ ДВЕРИ]
25892950 WEATHERSTRIP, FRT S/D [УПЛОТНИТЕЛЬ ДВЕРИ]
15201414 PLATE, FRT S/D LK STKR ANC
10387651 WASHER, FRT S/D LK STKR (10.571)
25863993 STRIKER, FRT S/D LK (10.569)
09442471 БОЛТ, TORX HD, W/FLAT CSK, M8X1.25X35, 28 THD, 15.2 O.D., 9.8, NO (FRT S/D LK STKR)
25895273 MOLDING, FRT S/D WDO RVL
25895274 MOLDING, FRT S/D WDO RVL
11588393 БОЛТ, FRT S/D O/S HDL (6 X 1 X 15, 7 THD) (8.900)
teamcadillac.ru
16633853 CLIP, FRT S/D LKG ROD (PART OF 12) (YELLOW) (PLASTIC) (10.527) [ФИКСАТОР ШТОКА ЗАМКА ПЕРЕДНЕЙ ДВЕРИ]
25960525 HANDLE, FRT S/D O/S (INCLS 11) (CHROME) (ORDER T/W CLIP-20828232) (FOR INSTLN PROCDR REF #09-08-64-023)
25960526 HANDLE, FRT S/D O/S (INCLS 11) (CHROME) [РУЧКА ДВЕРИ]
20835970 WEATHERSTRIP, FRT S/D LWR AUX (INCLS 13)
25784707 WEATHERSTRIP, FRT S/D LWR AUX (INCLS 13)
11562286 БОЛТ, FRT S/D HGE (8 X 1.25 X 24)
(TC16-973) - 2007-2009 CK1(06-36) АРМАТУРА ДВЕРИ/SIDE FRONT ЧАСТЬ 2 (CADILLAC Z75)
15140731 WINDOW, FRT S/D [СТЕКЛО]
15140732 WINDOW, FRT S/D [СТЕКЛО ПЕРЕДНЕЙ ДВЕРИ]
25865730 SEALING STRIP, FRT S/D WDO INR [УПЛОТНИТЕЛЬ ОКНА ДВЕРИ]
11589177 BOLT ASM, HEX HD, M6X1.0X18.0, GMW25 9.8 STL, GMW3359 (FRT S/D WDO FRT W/STR RET)
15792915 RETAINER, FRT S/D WDO W/STR FRT
15901807 RETAINER, FRT S/D WDO W/STR FRT
15876169 RETAINER, FRT S/D WDO W/STR RR (INCLS 6)
15876170 RETAINER, FRT S/D WDO W/STR RR (INCLS 6)
25885878 REGULATOR, FRT S/D WDO (INCLS 9-11, 18-20) (W/MOTOR) (16.260) (ACDelco #25885878)
25885879 REGULATOR, FRT S/D WDO (INCLS 9-11, 18-20) (W/MOTOR) (16.260) (ACDelco #25885879)
15844874 MOTOR, FRT S/D WDO REG (PART OF 8) (USE ON REGULATORS W/BOTTOM NUT FASTENER) (ACDelco #15844874)
11589177 BOLT ASM, HEX HD, M6X1.0X18.0, GMW25 9.8 STL, GMW3359 (FRT S/D WDO REG)
15858695 HARNESS, FRT S/D DR WRG
15905278 HARNESS, FRT S/D DR WRG
15905280 HARNESS, FRT S/D DR WRG
teamcadillac.ru
25811735 LOCK, FRT S/D (INCLS 15)
25811737 LOCK, FRT S/D (INCLS 15) (W/CABLE)
25863019 LOCK, FRT S/D (INCLS 15)
25876387 LOCK, FRT S/D (INCLS 15) (W/CABLE) (INCLS ACTUATOR)
25876388 LOCK, FRT S/D (INCLS 15) (W/O KEY CYL) (INCLS ACTUATOR) [ЗАМОК ДВЕРИ]
15920704 HANDLE, FRT S/D I/S (EBONY) (W/CHROME HDL) [ВНУТРЕННЯЯ РУЧКА ПЕРЕДНЕЙ ДВЕРИ]
15920705 HANDLE, FRT S/D I/S (CASHMERE) (W/CHROME HANDLES) [ВНУТРЕННЯЯ РУЧКА ПЕРЕДНЕЙ ДВЕРИ]
15920707 HANDLE, FRT S/D I/S (EBONY) (W/CHROME HDL) [РУЧКА ДВЕРИ]
15920708 HANDLE, FRT S/D I/S (CASHMERE) (W/CHROME HANDLES)
15940197 HANDLE, FRT S/D I/S (TITANIUM) (W/CHROME REL HANDLE) [РУЧКА]
11570136 БОЛТ, HEX HD, W/CON SPR WA, M6X1X23, 14 THD, 17 O.D., 8.8, GMW3359 (FRT S/D T/PNL)
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (FRT S/D WDO REG) [ГАЙКА М6]
15807100 PLUG, FRT S/D DRN HOLE
15039965 BUMPER, RR S/D
15175184 ROD, FRT S/D LKG [ТЯГА ЗАМКА ДВЕРИ]
15175185 ROD, FRT S/D LKG
15831543 ROD, FRT S/D O/S HDL [ТЯГА ЗАМКА ДВЕРИ]
15831544 ROD, FRT S/D O/S HDL
11517230 БОЛТ, TORX, W/WA, W/ADH, M6X1X20, 16.2 O.D., DOG PT, 10.9, GM6138M (FRT S/D LK) [ВИНТ ЗАМКА ДВЕРИ М6]
15093923 SENSOR, INFL RST SI IMP (W/BOLTS) (MT ON FRT DOOR BEAM) [ДАТЧИК ПОДУШКИ БЕЗОПАСНОСТИ]
21110669 PLUG, FRT S/D O/S HDL ACC HOLE (35 MM) (ROUND) (12.179)
25887975 GROMMET, FRT S/D LKG ROD
11609385 ГАЙКА, U-TYPE, M6X1, 29.5 LEN, 12.5 WID, 19.5 CEN-END, 1050, GMW3359 (FRT S/D TR PNL) [ГАЙКА М 6]
15827500 ROD, FRT S/D LK CYL
15827501 ROD, FRT S/D LK CYL [ТЯГА ЗАМКА ДВЕРИ]
16633853 CLIP, FRT S/D LKG ROD (PART OF 34) (YELLOW) (PLASTIC) (10.527) [ФИКСАТОР ШТОКА ЗАМКА ПЕРЕДНЕЙ ДВЕРИ]
15904634 CYLINDER KIT, FRT S/D LK (UNCODED) [ЦИЛИНДР]
25960525 HANDLE, FRT S/D O/S (INCLS 32) (CHROME) (ORDER T/W CLIP-20828232) (FOR INSTLN PROCDR REF #09-08-64-023)
25960526 HANDLE, FRT S/D O/S (INCLS 32) (CHROME) [РУЧКА ДВЕРИ]
15228568 DOOR, FRT SI (СМ. ГРУППУ 16.000 "КУЗОВНЫЕ ДЕТАЛИSIDE" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/O HINGES)
25912653 DOOR, FRT SI (СМ. ГРУППУ 16.000 "КУЗОВНЫЕ ДЕТАЛИSIDE" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/O HINGES) [ПАНЕЛЬ ДВЕРИ]
15876882 MOLDING, FRT S/D WDO GARN
15876883 MOLDING, FRT S/D WDO GARN
(TC16-975) - 2007-2009 CK107(06) АРМАТУРА ДВЕРИ/SIDE REAR ЧАСТЬ 1 (CADILLAC Z75)
15201414 PLATE, RR S/D LK STKR ANC
25863993 STRIKER, RR S/D LK (10.569)
09442471 БОЛТ, RR S/D LK STKR (8 X 1.25 X 35) (8.908)
11518445 БОЛТ, RR S/D LK STKR (8 X 1.25 X 25) (T40) (8.908) [БОЛТ М8Х1.25]
25831000 WEATHERSTRIP, RR S/D
15792912 WEATHERSTRIP, RR S/D FRT AUX [УПЛОТНИТЕЛЬ СТЕКЛА ДВЕРИ]
15792913 WEATHERSTRIP, RR S/D FRT AUX [УПЛОТНИТЕЛЬ СТЕКЛА ДВЕРИ]
25961382 DOOR, RR SI (СМ. ГРУППУ 16.000 "КУЗОВНЫЕ ДЕТАЛИ/ BODYSIDE" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ПАНЕЛЬ ДВЕРИ]
25961383 DOOR, RR SI (СМ. ГРУППУ 16.000 "КУЗОВНЫЕ ДЕТАЛИ/ BODYSIDE" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/O HINGES) [ЗАДНЯЯ ДВЕРЬ]
25895271 MOLDING, RR S/D WDO RVL
25895272 MOLDING, RR S/D WDO RVL
11517515 BOLT-HFH, M6X1X10, THD 8.5, OD 14.2, 9.8, GM6280, HDR PT. (RR S/D O/S HDL)
25960521 HANDLE, RR S/D O/S (CHROME) [РУЧКА ДВЕРИ]
25960522 HANDLE, RR S/D O/S (CHROME) [РУЧКА ДВЕРИ]
teamcadillac.ru
11562286 БОЛТ, RR S/D HGE (8 X 1.25 X 24)
25784684 WEATHERSTRIP, RR S/D LWR AUX (INCLS 18)
25784685 WEATHERSTRIP, RR S/D LWR AUX (INCLS 18)
25865733 SEALING STRIP, RR S/D WDO INR [УПЛОТНЕНИЕ]
15876895 MOLDING, RR S/D WDO GARN
15876896 MOLDING, RR S/D WDO GARN
(TC16-977) - 2007-2009 CK107(06) АРМАТУРА ДВЕРИ/SIDE REAR ЧАСТЬ 2
15140723 WINDOW, RR S/D [СТЕКЛО ДВЕРИ]
15140724 WINDOW, RR S/D [СТЕКЛО ДВЕРИ]
15140725 WINDOW, RR S/D [СТЕКЛО ЗАДНЕЙ ДВЕРИ]
15140726 WINDOW, RR S/D [СТЕКЛО ЗАДНЕЙ ДВЕРИ]
11589177 BOLT ASM, HEX HD, M6X1.0X18.0, GMW25 9.8 STL, GMW3359 (RR S/D WDO REG)
25885882 REGULATOR, RR S/D WDO (INCLS 3, 5, 6, 16, 17) (INCLS MOTOR) (ACDelco #25885882) [СТЕКЛОПОДЪЕМНИК ДВЕРИ]
25885883 REGULATOR, RR S/D WDO (INCLS 3, 5, 6, 16, 17) (INCLS MOTOR) (ACDelco #25885883) [РЕГУЛЯТОР В СБОРЕ]
11589177 BOLT ASM, HEX HD, M6X1.0X18.0, GMW25 9.8 STL, GMW3359 (PART OF 4)
15844874 MOTOR, RR S/D WDO REG (PART OF 4) (USE ON REGULATORS W/BOTTOM NUT FASTENER) (ACDelco #15844874)
15844877 MOTOR, RR S/D WDO REG (PART OF 4) (ACDelco #15844877)
15924057 HARNESS, RR S/D DR WRG (INCLS 7)
15924058 HARNESS, RR S/D DR WRG (INCLS 7)
15924059 HARNESS, RR S/D DR WRG (INCLS 7)
15924060 HARNESS, RR S/D DR WRG (INCLS 7)
25876389 LATCH, RR S/D (INCLS 9) (W/ACTUATOR) [ЗАМОК ДВЕРИ]
25876390 LATCH, RR S/D (INCLS 9) (INCLS ACTAUTOR) [ЗАМОК ДВЕРИ]
15175416 ROD, RR S/D LAT [ТЯГА ЗАМКА ДВЕРИ]
15175417 ROD, RR S/D LAT
15844616 KNOB, RR S/D LKG ROD (EBONY) [КНОПКА БЛОКИРАТОРА ДВЕРИ]
15844617 KNOB, RR S/D LKG ROD (CASHMERE)
teamcadillac.ru
15844618 KNOB, RR S/D LKG ROD (TITANIUM)
15844619 KNOB, RR S/D LKG ROD (CASHMERE) [КНОПКА БЛОКИРАТОРА ДВЕРИ]
15844620 KNOB, RR S/D LKG ROD (COCOA)
15920683 HANDLE, RR S/D I/S (EBONY)
15920684 HANDLE, RR S/D I/S (CASHMERE) (W/CHROME HANDLES)
15920704 HANDLE, RR S/D I/S (EBONY) (W/CHROME HDL) [ВНУТРЕННЯЯ РУЧКА ПЕРЕДНЕЙ ДВЕРИ]
15920705 HANDLE, RR S/D I/S (CASHMERE) (W/CHROME HANDLES) [ВНУТРЕННЯЯ РУЧКА ПЕРЕДНЕЙ ДВЕРИ]
15939073 HANDLE, RR S/D I/S (EBONY) (W/CHROME REL HDL) [РУЧКА В СБОРЕ]
15939075 HANDLE, RR S/D I/S (CASHMERE) (W/CHROME REL HANDLE)
15939076 HANDLE, RR S/D I/S (COCOA) (W/CHROME REL HANDLE)
15939084 HANDLE, RR S/D I/S (EBONY) (W/CHROME REL HANDLE)
15939086 HANDLE, RR S/D I/S (CASHMERE) (W/CHROME REL HANDLE)
15939087 HANDLE, RR S/D I/S (COCOA) (W/CHROME REL HANDLE)
11570136 БОЛТ, HEX HD, W/CON SPR WA, M6X1X23, 14 THD, 17 O.D., 8.8, GMW3359 (RR S/D T/PNL)
11609385 ГАЙКА, U-TYPE, M6X1, 29.5 LEN, 12.5 WID, 19.5 CEN-END, 1050, GMW3359 (RR S/D T/PNL) [ГАЙКА М 6]
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (RR S/D WDO REG) [ГАЙКА М6]
21110669 PLUG, RR S/D O/S HDL ACC HOLE (35 MM) (ROUND) (12.179)
25887975 GROMMET, RR S/D LKG ROD
11609341 SCREW, RD WA HD 6-LOBE M6X1X19 (RR S/D LAT) [ВИНТ]
15831547 ROD, RR S/D O/S HDL
15831548 ROD, RR S/D O/S HDL
15930553 HANDLE, RR S/D O/S (BLACK NON-TEXTURED BASE, PAINT TO MATCH, PLATINUM CHROME HDL) (T/W 15832413)
15930554 HANDLE, RR S/D O/S (BLACK NON-TEXTURED BASE, PAINT TO MATCH, PLATINUM CHROME HDL) (T/W 15832413)
(TC16-978) - 2007-2009 CK1,2(06) ОКНА/СТОРОНА КУЗОВА
10385139 WINDOW, BODY SI RR
10385140 WINDOW, BODY SI RR
25778988 WINDOW, BODY SI RR
25778989 WINDOW, BODY SI RR (INCLS АНТЕННА)
25810430 WINDOW, BODY SI RR (INCLS АНТЕННА) [СТЕКЛО БАГАЖНОЙ ДВЕРИ]
25810433 WINDOW, BODY SI RR [СТЕКЛО ЗАДНЕЕ БОКОВОЕ]
teamcadillac.ru
15877496 MODULE, RDO ANT (СМ. ГРУППУ 09.000 "АНТЕННА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #15877496)
(TC16-979) - 2007-2009 CK1,2(06-36) SUNROOF (CF5)
25798334 WINDOW, SUN RF (INCLS 2, 3)
15242782 БОЛТ, SUN RF WDO (PART OF 1)
teamcadillac.ru
15837594 SEAL, SUN RF WDO (PART OF 1)
25942826 FRAME, SUN RF (INCLS 8) (W/O MOTOR) [КАРКАС ЛЮКА КРЫШИ КУЗОВА]
11518121 ГАЙКА, U, M6X1, MULTI THD, .5'-4.0' THK PNL (SUN RF MDL)
11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (SUN RF MDL) [БОЛТ М6]
11514623 БОЛТ, HEX W/CON WA, M6X1X20 (SUN RF MDL)
15837588 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, SUN RF (CASHMERE)
15846533 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, SUN RF (LT CASHMERE)
15846534 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, SUN RF (GRAY)
15884142 MOLDING, SUN RF PNL/WDO GARN (CASHMERE)
25874712 MOLDING, SUN RF PNL/WDO GARN (GRAY)
25874713 MOLDING, SUN RF PNL/WDO GARN (CASHMERE)
15837591 BRACKET, SUN RF MDL
15934722 MOTOR, SUN RF ACTR
11514623 БОЛТ, HEX W/CON WA, M6X1X20 (SUN RF ACTR)
20823530 COVER, SUN RF PNL SI OPG CLOSEOUT (BLACK)
20823531 COVER, SUN RF PNL SI OPG CLOSEOUT (BLACK)
15837592 DEFLECTOR, SUN RF AIR
15924423 STOP, SUN RF S/S (12.810)
(TC16-980) - 2007-2009 CK1,2(06-36) ВОДОСТОК КРЫШИ (CF5)
15164170 HOSE, SUN RF HSG RR DRN
15164171 HOSE, SUN RF HSG RR DRN
25836913 HOSE, SUN RF HSG FRT DRN
teamcadillac.ru
25836914 HOSE, SUN RF HSG FRT DRN
(TC16-982) - 2007 K1(06) КОНСОЛЬ/ПОЛ (G.M.C. Z88, DENALI Y91)
15946301 LINER, F/FLR CNSL F/CMPT (PART OF 2, 4) [ВСТАВКА ЛОТКА НАПОЛЬНОЙ КОНСОЛИ]
15905985 PUSHBUTTON, F/FLR CNSL COMPT DR LAT (INCLS 1) (PART OF 4) (MAPLE)
15250347 ARMREST, F/FLR CNSL (INCLS 1-3, 7, 35) (EBONY)
15250348 ARMREST, F/FLR CNSL (INCLS 1-3, 7, 35) (CASHMERE)
15217105 PANEL, F/FLR CNSL R/CMPT DR (EBONY)
15217106 PANEL, F/FLR CNSL R/CMPT DR (CASHMERE)
11609459 SCREW, RND WA, M4.2X1.41X13, 7.2 THD, 11.35 OD, 6010M, GMW4205 (F/FLR CNSL) [ВИНТ]
15905980 COMPARTMENT, F/FLR (INCLS 19, 22, 23) (EBONY)
15905981 COMPARTMENT, F/FLR (INCLS 19, 22, 23) (CASHMERE)
25911854 COMPARTMENT, F/FLR (INCLS 19, 22, 23) (EBONY)
25911855 COMPARTMENT, F/FLR (INCLS 19, 22, 23) (CASHMERE)
25913721 COMPARTMENT, F/FLR (INCLS 19, 22, 23) (EBONY)
25913722 COMPARTMENT, F/FLR (INCLS 19, 22, 23) (CASHMERE)
15217101 PANEL, F/FLR FRT CNSL RR TR (EBONY)
15217102 PANEL, F/FLR FRT CNSL RR TR (CASHMERE)
15886277 MODULE, HTR & A/C & RDO CONT (СМ. ГРУППУ 09.000 "A/C & HEATER CONTROL" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #15886277)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 12) [ЗАЖИМ КОНСОЛИ САЛОНА]
teamcadillac.ru
15134825 BEZEL, F/FLR CNSL COMPT (INCLS 11, 13, 14, 15) (NO AUDIO JACKS)
15134826 BEZEL, F/FLR CNSL COMPT (INCLS 11, 13, 14, 15) (EBONY) (2 AUDIO JACKS)
15187371 RETAINER, ACSRY PWR RCPT (PART OF 12) (EBONY) (INCLS COVER) [ОКАНТОВКА ГНЕЗДА ПРИКУРИВАТЕЛЯ]
10375379 ADAPTER, AUDIO/VIDEO DISC PLYR (PART OF 12) (ACDelco #10375379)
15134790 LINER, F/FLR CNSL RR CUP HLDR (EBONY) (W/O FINGERS)
15134819 HOLDER, F/FLR RR CNSL CUP
15134821 HINGE, F/FLR CNSL COMPT DR (REAR CUPHOLDER DOOR HINGE)
15929131 HARNESS, F/FLR CNSL WRG (PART OF 8)
25781989 HARNESS, F/FLR CNSL WRG (PART OF 8)
15134799 RETAINER, F/FLR CNSL (INCLS 32)
11610157 ГАЙКА, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (F/FLR CNSL) (10.701) [ГАЙКА М4]
11562473 БОЛТ, F/SEAT (M12X1.75X45) [БОЛТ М12]
15035434 ГАЙКА, F/SEAT (M10X1.5X10.8) (FLANGE NUT) (16.679) [ВИНТ]
25939528 УСИЛИТЕЛЬ, RDO SPKR (ACDelco #25939528) (LABELED 25939528 OR 15937318)
15134797 RETAINER, F/FLR CNSL (INCLS 28, 29)
25749635 RETAINER, ACSRY PWR RCPT (EBONY) (W/O CAP) [ВТУЛКА ГНЕЗДА ПРИКУРИВАТЕЛЯ]
15134801 MAT, F/FLR CNSL FRT COMPT (PART OF 20) (EBONY)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 33) [ЗАЖИМ КОНСОЛИ САЛОНА]
15070572 BUMPER, F/FLR RR CNSL A/RST (PART OF 4)
25912888 BEZEL, F/FLR FRT CNSL ACSRY TR (INCLS 36, 38, 39) (MAPLE)
(TC16-984) - 2007 CK1(06) КОНСОЛЬ/ПОЛ ЧАСТЬ 1-LOWER (CADILLAC Z75)
11609459 SCREW, RND WA, M4.2X1.41X13, 7.2 THD, 11.35 OD, 6010M, GMW4205 (PART OF 1, 36) [ВИНТ]
teamcadillac.ru
15886900 MODULE, HTR & A/C & RDO CONT
10375379 ADAPTER, AUDIO/VIDEO DISC PLYR (ACDelco #10375379)
22596346 BUMPER, F/FLR RR CNSL A/RST (10.242)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (F/FLR CNSL SI T/PNL) [ЗАЖИМ КОНСОЛИ САЛОНА]
15833953 COVER, HTR & A/C CONT OPG
25774623 RECEPTACLE, ACSRY PWR (ACSRY PWR RECEPTACLE ASSEM LABELED 4623) [ГНЕЗДО ПРИКУРИВАТЕЛЯ С КОНТАКТН. ЭЛЕМЕНТ., 12 ВТ]
15133100 LINER, F/FLR CNSL RR CUP HLDR (PART OF 19)
11609459 SCREW, RND WA, M4.2X1.41X13, 7.2 THD, 11.35 OD, 6010M, GMW4205 (PART OF 36) [ВИНТ]
11589106 SCREW, RND WA HD, M4.2X1.41X25, 19.2 THD, 11.3 OD, 6010M, GMW4205, C/R, TAP, (PART OF 36) (10.774) [БОЛТ]
11609459 SCREW, RND WA, M4.2X1.41X13, 7.2 THD, 11.35 OD, 6010M, GMW4205 (PART OF 19) [ВИНТ]
15133101 BUSHING, F/FLR CNSL CUP HLDR DR HGE (PART OF 19)
15133093 HOLDER, F/FLR CNSL RR CUP (INCLS 13, 17, 18)
15929132 HARNESS, F/FLR CNSL WRG
20808898 УСИЛИТЕЛЬ, RDO SPKR (ACDelco #20808898) (LABELED 20808898, 25939529 OR 15937320)
11610157 ГАЙКА, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (PART OF 36) (10.701) [ГАЙКА М4]
15238666 PANEL, F/FLR CNSL SI TR FRT (INCLS 30, 31) (СМ. ГРУППУ 16.000 "ПРИБОРНАЯ ПАНЕЛЬ/TRIM" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА.) (EBONY) (16.081)
15238667 PANEL, F/FLR CNSL SI TR FRT (INCLS 30, 31) (СМ. ГРУППУ 16.000 "ПРИБОРНАЯ ПАНЕЛЬ/TRIM" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА.) (CASHMERE) (16.081)
15923060 PANEL, F/FLR CNSL SI TR FRT (INCLS 30, 31) (СМ. ГРУППУ 16.000 "ПРИБОРНАЯ ПАНЕЛЬ/TRIM" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА.) (EBONY) (16.081)
15923061 PANEL, F/FLR CNSL SI TR FRT (INCLS 30, 31) (СМ. ГРУППУ 16.000 "ПРИБОРНАЯ ПАНЕЛЬ/TRIM" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА.) (CASHMERE) (16.081)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 29) [ЗАЖИМ КОНСОЛИ САЛОНА]
11562257 RETAINER, I/P LWR TR PAD BRKT (PUSH ON) (PART OF 29) (19.5 X 30.4 X 1.8) (14.683)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 28, 36) [ЗАЖИМ КОНСОЛИ САЛОНА]
15187371 RETAINER, ACSRY PWR RCPT (PART OF 36) (EBONY) (INCLS COVER) [ОКАНТОВКА ГНЕЗДА ПРИКУРИВАТЕЛЯ]
25774623 RECEPTACLE, ACSRY PWR (PART OF 36) (ACSRY PWR RECEPTACLE ASSEM LABELED 4623) [ГНЕЗДО ПРИКУРИВАТЕЛЯ С КОНТАКТН. ЭЛЕМЕНТ., 12 ВТ]
25775479 COMPARTMENT, F/FLR (INCLS 1-4, 14-17, 21, 22, 24, 25, 28, 32-35) (EBONY)
25775480 COMPARTMENT, F/FLR (INCLS 1-4, 14-17, 21, 22, 24, 25, 28, 32-35) (LT CASHMERE)
25775485 COMPARTMENT, F/FLR (INCLS 1-4, 14-17, 21, 22, 24, 25, 28, 32-35) (EBONY)
25775486 COMPARTMENT, F/FLR (INCLS 1-4, 14-17, 21, 22, 24, 25, 28, 32-35) (LT CASHMERE)
11609460 SCREW, RND WA, M4.2X1.41X10, 4.2 THD, 11 OD, GM6010M, GMW4205, C/R, TAP (PART OF 39)
15909298 BEZEL, F/FLR FRT CNSL ACSRY TR (INCLS 37, 38, 40-43, 45, 46) (CHOCOLATE BURL)
20820047 BEZEL, F/FLR FRT CNSL ACSRY TR (INCLS 37, 38, 40-43, 45, 46) (CHOCOLATE) [ПАНЕЛЬ ЦЕНТРАЛЬНОЙ КОНСОЛИ]
25775309 BEZEL, F/FLR FRT CNSL ACSRY TR (INCLS 37, 38, 40-43, 45, 46) (RUBY)
15683368 BUMPER, F/FLR CNSL ПЕПЕЛЬНИЦА DR (PART OF 39) (8.80 DIA) (CLOSED-STOP) (FRAME) (16.650)
22596346 BUMPER, F/FLR RR CNSL A/RST (PART OF 39) (10.242)
15132973 ПЕПЕЛЬНИЦА, F/FLR CNSL (PART OF 39)
15132964 HOLDER, F/FLR CNSL CUP (PART OF 39)
11516140 LIGHTER, CIG (MAY NEED TO CHANGE RECEPTACLE IF LIGHTER DOESN'T WORK OR USE ПЕПЕЛЬНИЦА PKG 17800493.) (BLACK) (W/LARGE, PLASTIC KNOB END 21.0MM) [ПРИКУРИВАТЕЛЬ]
25776667 RECEPTACLE, ACSRY PWR (PART OF 39) (2 TERMINALS) [ГНЕЗДО ПРИКУРИВАТЕЛЯ С КОНТАКТН. ЭЛЕМЕНТ., 12 ВТ]
25749635 RETAINER, ACSRY PWR RCPT (PART OF 39) (EBONY) (W/O CAP) [ВТУЛКА ГНЕЗДА ПРИКУРИВАТЕЛЯ]
(TC16-985) - 2007-2009 CK1(06) КОНСОЛЬ/КРЫША (CADILLAC Z75, ARS,CF5,UG1)
teamcadillac.ru
15862412 SWITCH, SUN RF (PART OF 5) [ВЫКЛЮЧАТЕЛЬ ЛЮКА КРЫШИ]
15241529 MICROPHONE, MOBILE TEL (PART OF 5) (2-WAY CAVITY)
15211504 SWITCH, L/GATE ACTR (PART OF 5) (PART OF LIFT GATE PNL)
15299399 SWITCH, L/GATE ACTR (FULL OPEN SWITCH) (PART OF 5) (12.243)
25845571 SWITCH, L/GATE ACTR (PART OF 5) (PART OF RF КОНСОЛЬ)
15862407 SWITCH, R/SEAT #2 FLDG ACTR (PART OF 5) (ON КОНСОЛЬ)
15857968 КОНСОЛЬ, RF (INCLS 1-4, 6-8, 10-15) (LT CASHMERE) (W/JCI TRANSMITTER 15145260)
15889626 КОНСОЛЬ, RF (INCLS 1-4, 6-8, 10-15) (GRAY) (JCI UGDO W/HOUSE SYMBOL) (FOR 2ND DES SEE 15913168)
25848251 КОНСОЛЬ, RF (INCLS 1-4, 6-8, 10-15) (GRAY) (LEAR GDO) (FOR 1ST DES SEE 15889626)
25848252 КОНСОЛЬ, RF (INCLS 1-4, 6-8, 10-15) (LT CASHMERE) (W/LEAR TRANSMITTER KIT 25807341)
25853059 КОНСОЛЬ, RF (INCLS 1-4, 6-8, 10-15) (CASHMERE) (2ND ROW DVD FACE PLT) (PO PNL ASM)
15853948 PUSHBUTTON, RDG LP SW (PART OF 5)
15911049 LENS, DM LP (PART OF 5) (1ST ROW) [КОЖУХ ФОНАРЯ ПОДСВЕТКИ САЛОНА]
09431809 BULB, 6CP TRADE #212-2 (PART OF 5) (ACDelco #L212-2)
15145260 TRANSMITTER, GARAGE DR OPENER (PART OF 5) (W/O OWNERS INFO MANUAL)
11609345 ГАЙКА, PUSH-IN, 4.2, SAE 1050 STL, GMW3179 (PART OF 5)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 5) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
(TC16-986) - 2007-2009 CK1(06) КОНСОЛЬ/КРЫША (CADILLAC Z75, CF5,UG1, EXC ARS)
15862412 SWITCH, SUN RF (PART OF 4) [ВЫКЛЮЧАТЕЛЬ ЛЮКА КРЫШИ]
teamcadillac.ru
15241529 MICROPHONE, MOBILE TEL (PART OF 4) (2-WAY CAVITY)
15211504 SWITCH, L/GATE ACTR (PART OF 4) (PART OF LIFT GATE PNL)
15299399 SWITCH, L/GATE ACTR (FULL OPEN SWITCH) (PART OF 4) (12.243)
15853948 PUSHBUTTON, RDG LP SW (PART OF 4)
15911049 LENS, DM LP (PART OF 4) (1ST ROW) [КОЖУХ ФОНАРЯ ПОДСВЕТКИ САЛОНА]
09431809 BULB, 6CP TRADE #212-2 (PART OF 4) (ACDelco #L212-2)
15145260 TRANSMITTER, GARAGE DR OPENER (PART OF 4) (W/O OWNERS INFO MANUAL)
11609345 ГАЙКА, PUSH-IN, 4.2, SAE 1050 STL, GMW3179 (PART OF 4)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 4) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
(TC16-989) - 2007-2009 CK1(06) КОНСОЛЬ/КРЫША (CADILLAC Z75, ARS,UG1, EXC CF5)
15911047 BRACKET, RF RR CNSL (PART OF 6)
11516630 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (PART OF 6)
15241529 MICROPHONE, MOBILE TEL (PART OF 6) (2-WAY CAVITY)
15862407 SWITCH, R/SEAT #2 FLDG ACTR (PART OF 6) (ON КОНСОЛЬ)
15836889 КОНСОЛЬ, RF (INCLS 1-5, 7-10, 12-17) (CASHMERE) (W/JCI TRANSMITTER 15145260)
15857971 КОНСОЛЬ, RF (INCLS 1-5, 7-10, 12-17) (GRAY) (W/JCI TRANSMITTER 15145260)
15913173 КОНСОЛЬ, RF (INCLS 1-5, 7-10, 12-17) (LT CASHMERE) (W/LEAR TRANSMITTER KIT 25807341)
15853948 PUSHBUTTON, RDG LP SW (PART OF 6)
15911049 LENS, DM LP (PART OF 6) (1ST ROW) [КОЖУХ ФОНАРЯ ПОДСВЕТКИ САЛОНА]
09431809 BULB, 6CP TRADE #212-2 (PART OF 6) (ACDelco #L212-2)
15145260 TRANSMITTER, GARAGE DR OPENER (PART OF 6) (W/O OWNERS INFO MANUAL)
teamcadillac.ru
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 6) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
11609345 ГАЙКА, PUSH-IN, 4.2, SAE 1050 STL, GMW3179 (PART OF 6)
(TC16-990) - 2007-2009 K1(06) КОНСОЛЬ/КРЫША (CADILLAC Z75, ARS, EXC CF5,UG1)
teamcadillac.ru
15836889 КОНСОЛЬ, RF (INCLS 1-5, 7-10, 12-14) (CASHMERE) (W/JCI TRANSMITTER 15145260)
15836896 КОНСОЛЬ, RF (INCLS 1-5, 7-10, 12-14) (GRAY) (NON-DVD CNSL)
15889641 КОНСОЛЬ, RF (INCLS 1-5, 7-10, 12-14) (LT CASHMERE)
(TC16-992) - 2007-2009 CK1(06) КОНСОЛЬ/КРЫША (CADILLAC Z75, UG1, EXC ARS,CF5)
15911047 BRACKET, RF RR CNSL (PART OF 5)
11516630 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (PART OF 5)
15836908 КОНСОЛЬ, RF (INCLS 1-4, 6-9, 11-16) (CASHMERE) (W/JCI TRANSMITTER 15145260)
15889653 КОНСОЛЬ, RF (INCLS 1-4, 6-9, 11-16) (GRAY) (W/JCI TRANSMITTER 15145260)
15913181 КОНСОЛЬ, RF (INCLS 1-4, 6-9, 11-16) (LT CASHMERE) (W/LEAR TRANSMITTER KIT 25807341)
teamcadillac.ru
(TC16-993) - 2007-2009 K1(06) КОНСОЛЬ/КРЫША (CADILLAC Z75, EXC ARS,CF5,UG1)
15836908 КОНСОЛЬ, RF (INCLS 1-4, 6-9, 11-13) (CASHMERE) (W/JCI TRANSMITTER 15145260)
15836915 КОНСОЛЬ, RF (INCLS 1-4, 6-9, 11-13) (GRAY) (NON-DVD CNSL) (BUILT FROM 10/31/05 TO 01/03/06)
15836916 КОНСОЛЬ, RF (INCLS 1-4, 6-9, 11-13) (LT CASHMERE)
25807240 КОНСОЛЬ, RF (INCLS 1-4, 6-9, 11-13) (GRAY) (BUILT FROM 09/25/06 TO 03/20/07)
25817052 КОНСОЛЬ, RF (INCLS 1-4, 6-9, 11-13) (GRAY) (2ND ROW DVD FACE PLT)
25853059 КОНСОЛЬ, RF (INCLS 1-4, 6-9, 11-13) (CASHMERE) (2ND ROW DVD FACE PLT) (PO PNL ASM)
teamcadillac.ru
(TC16-997) - 2007-2008 CK1,2(06) CAMERA SYSTEM/REAR VIEW (UVC)
15862654 HARNESS, RR LIC PLT LP WRG
25872958 HARNESS, RR LIC PLT LP WRG (2.714) (SERV CMP OF CAMERA PKG'S)
15218778 SPACER, RR VIEW CAMERA IMAGE DISPLAY BRKT (PART OF 4)
15173619 CAMERA, RR VIEW (INCLS 3, 5, 6, 14) (INCLS SMALL HARNESS) [КАМЕРА ЗАДНЕГО ВИДА]
19211811 CAMERA, RR VIEW (INCLS 3, 5, 6, 14) (INSTALL 1.0) (00.1 KGS) (9.715) (SERV CMP OF CAMERA PKGS 19170227, 19171822)
03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (L/GATE CTR MLDG)
10371724 MODULE, RR VIEW CAMERA IMAGE DISPLAY (2.195) [МОДУЛЬ]
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (COMMUNICATION INTERFACE MDL BRKT) [ГАЙКА М6]
teamcadillac.ru
15317832 RETAINER, RR VIEW CAMERA (PART OF 4) (GREY) (SECONDARY LOCK) (3.166)
(TK16-002) - 2007 CK1(06) КОНСОЛЬ/ПОЛ-КРЫШКА (CADILLAC Z75)
teamcadillac.ru
15220797 PANEL, F/FLR CNSL COMPT DR (EBONY) (UPR) (16.585)
15220798 PANEL, F/FLR CNSL COMPT DR (CASHMERE) (UPPER) (16.585)
15133062 PANEL, F/FLR CNSL COMPT DR INR (INCLS 8) (W/LATCH)
20858325 LID, F/TOP STOW COMPT (INCLS 4, 5, 7) (EBONY) (LOWER)
20858326 LID, F/TOP STOW COMPT (INCLS 4, 5, 7) (CASHMERE) (LOWER)
11609459 SCREW, RND WA, M4.2X1.41X13, 7.2 THD, 11.35 OD, 6010M, GMW4205 (PART OF 3) [ВИНТ]
22596346 BUMPER, F/FLR RR CNSL A/RST (PART OF 3) (10.242)
25778771 BUMPER, F/FLR RR CNSL A/RST (PART OF 2)
(TX16-004) - 2007-2009 CK1,2,3 РЕМНИ БЕЗОПАСНОСТИ (EXTENSION KIT)
89024296 EXTENSION KIT, F/SEAT BELT (BLACK) (9") (14.875) (REFER TO GMSPO INFORMATION BULLETIN ON SEAT BELT EXTENDERS FOR DETAILED INFORMATION)
89024297 EXTENSION KIT, F/SEAT BELT (BLACK) (15") (14.875) (REFER TO GMSPO INFORMATION BULLETIN ON SEAT BELT EXTENDERS FOR DETAILED INFORMATION)
17 - ЗАДНИЕ КУЗОВНЫЕ ДЕТАЛИ-МОЛДИНГИ-ОТДЕЛКА ГРУЗОВОГО ОТДЕЛА
(TC17-744) - 2007-2009 CK107(06) БАГАЖНИК (G.M.C. Z88, DENALI Y91, V54)
15838222 RAIL, LUGG CARR CR (BLACK) [ВНЕШНИЙ ВЕРХНИЙ БАГАЖНИК]
25787589 COVER, LUGG CARR S/RL RR FIN (PAINT TO MATCH) (*KIT1, KIT2)
11518684 ГАЙКА, LUGG CARR SUPT (M6X1X16) (HEX CHROME FREE FINISH) [ГАЙКА М6]
15916756 PLATE, LUGG CARR S/RL BRKT ANC
11609900 SCREW, PAN WASH, M6X1X39, 31 THD, 12.25 OD, 8.8, GMW4700, TORX, MACH, 'P'POI (LUGG CARR SUPT)
25892761 RAIL, LUGG CARR SI (CHROME) (*KIT1)
25892762 RAIL, LUGG CARR SI (CHROME) (*KIT1)
25787559 COVER, LUGG CARR S/RL FRT FIN (PAINT TO MATCH) (*KIT1, KIT3)
25787560 COVER, LUGG CARR S/RL FRT FIN (PAINT TO MATCH) (*KIT1, KIT3)
teamcadillac.ru
25836350 RAIL KIT, LUGG CARR SI (INCLS 2, 6, 7) (CHROME)
25996381 RAIL KIT, LUGG CARR SI (INCLS 2, 6, 7) (CHROME)
25832914 COVER KIT, LUGG CARR S/RL ACC HOLE RR (INCLS 2) (INCLS PAINT TO MATCH COVER)
25832915 COVER KIT, LUGG CARR S/RL ACC HOLE RR (INCLS 2) (INCLS PAINT TO MATCH COVER)
25832916 COVER KIT, LUGG CARR S/RL ACC HOLE FRT (INCLS 7) (PAINT TO MATCH)
25832917 COVER KIT, LUGG CARR S/RL ACC HOLE FRT (INCLS 7) (PAINT TO MATCH)
(TC17-903) - 2007 CK107(06) NAMEPLATES (CADILLAC Z75)
15223483 EMBLEM, FRT S/D (CHROME) (GM) [ЭМБЛЕМА GM]
15162148 PLATE, FRT S/D NA (CHROME) (ESCALADE) (17.215) [ЭМБЛЕМА ЕSCALADE]
10387855 EMBLEM, L/GATE (CHROME) (CADILLAC) (FOR EXPORT ONLY) (12.182) [ЭМБЛЕМА CADILLAC]
15162148 EMBLEM, L/GATE (ESCALADE) [ЭМБЛЕМА ЕSCALADE]
15905786 EMBLEM, L/GATE (WREATH & CREST) [ЭМБЛЕМА МОЛДИНГА БАГАЖНОЙ ДВЕРИ]
(TC17-909) - 2007-2009 CK1(06) АРМАТУРА ОТКРЫВАНИЯ(ПОДЪЕМА) ДВЕРИ ЧАСТЬ 1 (CADILLAC Z75)
15262791 APPLIQUE, Q/PNL UPR (PAINT TO MATCH)
25970600 APPLIQUE, Q/PNL UPR (PAINT TO MATCH) [УГЛОВАЯ ПАНЕЛЬ ЗАДНЕЙ СТОЙКИ КУЗОВА]
11569711 ГАЙКА, PUSH-IN, M4.2X1.41, 0.7-2.15 PNL THK, SAE 1050-1065, GMW3359 W/ (Q/PNL UPR APLQ) [ГАЙКА М4.2]
11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (Q/PNL UPR APLQ) [ВИНТ]
25916023 WINDOW, L/GATE (INCLS 25, 26) [СТЕКЛО БАГАЖНОЙ ДВЕРИ]
25916024 WINDOW, L/GATE (INCLS 25, 26) [СТЕКЛО БАГАЖНОЙ ДВЕРИ]
25949077 WEATHERSTRIP, L/GATE WDO [УПЛОТНЕНИЕ ДВЕРИ]
15277943 GATE, LIFT
15038385 BUMPER, L/GATE WDO
11562471 STUD, L/GATE STRUT BALL (L/GATE SI) (8.015)
15161943 STRUT, L/GATE WDO [АМОРТИЗАЦИОННАЯ СТОЙКА СТЕКЛА ЗАДНЕЙ ОТКИДНОЙ ДВЕРИ]
15161944 STRUT, L/GATE WDO
15875510 HINGE, L/GATE
11519388 БОЛТ, HX HD CON WA, M8X1.25X25, 20 THD, 24 OD, 8.8, GMW3359 (SILVER), M-POINT (L/GATE HGE (L/GATE SI)) [БОЛТ]
11609341 SCREW, RD WA HD 6-LOBE M6X1X19 (L/GATE STRUT BRKT (L/GATE SI)) [ВИНТ]
15891962 BRACKET, L/GATE STRUT (L/GATE SI)
11518445 SCREW, FLAT-HD HEX ALLEN, CSINK, M8X1.25X25, 18.05 THD, 14.7 OD, 8.8, GMW3044. (L/GATE LK STKR) [БОЛТ М8Х1.25]
15134851 STRIKER, L/GATE LK
15827433 STRUT, L/GATE [АМОРТИЗАЦИОННАЯ СТОЙКА ЗАДНЕЙ ОТКИДНОЙ ДВЕРИ]
15854712 STRUT, L/GATE [АМОРТИЗАЦИОННАЯ СТОЙКА ЗАДНЕЙ ОТКИДНОЙ ДВЕРИ]
teamcadillac.ru
15892254 BUMPER, L/GATE
15816854 VALVE, BK BODY OPG FRM PRESS RLF
11561717 STUD, L/GATE STRUT (BODY SI) (M8X1.25X25) (STAINLESS STEEL)
11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (L/GATE HGE (BODY SI)) [ГАЙКА]
25815980 WEATHERSTRIP, L/GATE [УПЛОТНЕНИЕ ЗАДНЕЙ ОТКИДНОЙ ДВЕРИ]
11610075 RING, FOR 6MM DIA SHAFT, SS (L/GATE HGE PIN)
15834697 WEATHERSTRIP, L/GATE UPR
15931278 TAPE, L/GATE ADJ BPR PAD
15273470 HANDLE, L/GATE WDO O/S (PART OF 4)
25916031 TERMINAL, R/WDO DEFG WIRE (PART OF 4) (2.480) [КОНТАКТНЫЙ РАЗЪЕМ ПРОВОДКИ ОБОГРЕВАТЕЛЯ ЗАДНЕГО СТЕКЛА]
(TC17-911) - 2007-2009 CK1(06) АРМАТУРА ОТКРЫВАНИЯ(ПОДЪЕМА) ДВЕРИ ЧАСТЬ 2 (CADILLAC Z75)
15270012 SEAL, E/GATE CTR MLDG (PART OF 3)
11561972 БОЛТ, L/GATE APLQ (PART OF 3) (6 X 1 X 21)
25779075 APPLIQUE, L/GATE UPR (INCLS 1, 2) (PAINT TO MATCH) (W/O HIGH MT S/LP)
25779085 LAMP, HIGH MT STOP (INCLS CZ2 STAMP) [ЛАМПА]
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (HIGH MT S/LP) [ГАЙКА М6]
15857136 WIRE, HIGH MT S/LP
11508277 ГАЙКА, HEX W/CON WA M6X1 THD, OD-19 PEOR 9 (L/GATE APLQ) [ГАЙКА М6]
11569914 ГАЙКА, RR LIC PLT (SINGLE NUT) (EXCLS SEAL)
15106857 SWITCH, L/GATE REL (PART OF 11) (ACDelco #D1499F) [КОНЦЕВОЙ ВЫКЛЮЧАТЕЛЬ БАГАЖНОЙ ДВЕРИ]
teamcadillac.ru
15842442 HANDLE, L/GATE O/S (INCLS 10, 12-14) (PAINT TO MATCH)
12335645 GASKET, L/GATE WDO O/S HDL (PART OF 11) (7.800)
11508388 ГАЙКА, HEX W/CON WA, M6X1, 23.75 O.D., 5.55THK, 9, POR (L/GATE O/S HDL) (8.915)
15101589 PLUG, L/GATE INR PNL DRN HOLE (W/ПРУЖИНА CLIP)
21110669 PLUG, L/GATE WRG HARN HOLE (35 MM) (ROUND) (12.179)
15259076 PLUG, L/GATE SEN ATCH HOLE (6.35MM) (ROUND) (10.571)
11609394 БОЛТ, L/GATE APLQ (M 6 X 1 X 28) (26 OD, 9.8)
25886854 LATCH, L/GATE WDO (INCLS 22) (REFER TO BULLETIN 07-08-66-005A WHEN REPLACING LATCH W/ BRKT)
11589327 БОЛТ, L/GATE WDO LAT (PART OF 21)
11609341 SCREW, RD WA HD 6-LOBE M6X1X19 (L/GATE LK) [ВИНТ]
13501872 LATCH, L/GATE (W/AJAR SW) (12.242)
15858590 LOCK, L/GATE (LATCH ONLY) (12.242)
(TC17-916) - 2007-2008 CK1(06) АРМАТУРА ОТКРЫВАНИЯ(ПОДЪЕМА) ДВЕРИ ЧАСТЬ 3 CENTER APPLIQUE (CADILLAC Z75, EXC REAR VIEW CAMERA UVC)
teamcadillac.ru
15915680 APPLIQUE, L/GATE (INCLS 4, 7-10, 12) [НАКЛАДКА ЗАДНЕЙ ДВЕРИ]
15798062 SWITCH, L/GATE WDO REL (ACDelco #D1994E)
15905786 EMBLEM, L/GATE (PART OF 2) (WREATH & CREST) [ЭМБЛЕМА МОЛДИНГА БАГАЖНОЙ ДВЕРИ]
25778786 LAMP, RR LIC PLT [ФОНАРЬ ПОДСВЕТКИ НОМЕРНОГО ЗНАКА]
11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (RR LIC PLT LP LENS)
11562334 RETAINER, L/GATE CTR APLQ (PART OF 2)
01999382 BULB, (RR LIC PLT LP) (ACDelco #W5WLL) (LONGER LIFE)
(TC17-917) - 2007-2008 CK1(06) АРМАТУРА ОТКРЫВАНИЯ(ПОДЪЕМА) ДВЕРИ ЧАСТЬ 3 CENTER APPLIQUE (CADILLAC Z75, REAR VIEW CAMERA UVC)
15915679 APPLIQUE, L/GATE CTR (INCLS 4, 11-14, 16) (CHROME) (INCLS EMBLEM) [НАКЛАДКА КРЫШКИ БАГАЖНИКА С ЭМБЛЕМОЙ CADILLAC]
15218778 SPACER, RR VIEW CAMERA IMAGE DISPLAY BRKT (PART OF 7)
15173619 CAMERA, RR VIEW (INCLS 6, 8, 9, 18) (INCLS SMALL HARNESS) [КАМЕРА ЗАДНЕГО ВИДА]
19211811 CAMERA, RR VIEW (INCLS 6, 8, 9, 18) (INSTALL 1.0) (00.1 KGS) (9.715) (SERV CMP OF CAMERA PKGS 19170227, 19171822)
teamcadillac.ru
15127746 CLIP, L/GATE LWR MLDG (INCLS 13) (PART OF 2) (NATURAL) (SET-UP HEIGHT 5.05MM) (8.309)
15317832 RETAINER, RR VIEW CAMERA (PART OF 7) (GREY) (SECONDARY LOCK) (3.166)
(TC17-918) - 2007-2009 CK1,2(06) АРМАТУРА ОТКРЫВАНИЯ(ПОДЪЕМА) ДВЕРИ ЧАСТЬ 4 ACTUATOR SYSTEM (POWER LIFTGATE E61)
25889602 MOTOR, L/GATE CLOSE ACTR (INCLS 2) (PART OF 4) (12.243)
11562045 БОЛТ, L/GATE CLOSE ACTR MOT (PART OF 1, 4)
25778508 SENSOR, L/GATE SI UPR (ANTI-PINCH) (W/RETAINERS)
25778509 SENSOR, L/GATE SI UPR (ANTI-PINCH) (W/RETAINERS)
25889603 MODULE, L/GATE CLOSE ACTR MOT CONT (INCLS 1, 2, 5-8) [ЭЛЕКТРОДВИГАТЕЛЬ ЗАДНЕЙ ДВЕРИ В СБОРЕ 90 ВТ]
15299399 SWITCH, L/GATE ACTR (INCLS 6) (PART OF 4) (12.243)
11562045 БОЛТ, L/GATE CLOSE ACTR MOT (PART OF 4)
15810321 BRACKET, L/GATE CLOSE ACTR (PART OF 4)
15836293 ROD, L/GATE ACTR [ТЯГА ЗАМКА БАГАЖНОЙ ДВЕРИ]
25824256 MODULE, ACSRY & L/GATE CONT (UNPROGRAMMED) (12.243) [БЛОК УПРАВЛЕНИЯ ЭЛЕКТРООБОРУДОВАНИЕМ 5ОЙ ДВЕРИ]
25880968 MODULE, ACSRY & L/GATE CONT (PROGRAMMED)
11609410 БОЛТ, HFH, M8X1.25X25, 10.9, GMW3179 (L/GATE CLOSE ACTR) (0.056) [БОЛТ]
15173772 BRACKET, L/GATE ACTR ROD
11517230 БОЛТ, TORX, W/WA, W/ADH, M6X1X20, 16.2 O.D., DOG PT, 10.9, GM6138M (L/GATE ACTR ROD BRKT) [ВИНТ ЗАМКА ДВЕРИ М6]
(TC17-919) - 2007-2009 CK1(06) LIFTGATE TRIM (CADILLAC Z75)
15864304 MOLDING, L/GATE WDO UPR GARN (INCLS 2, 3) (CASHMERE)
15864305 MOLDING, L/GATE WDO UPR GARN (INCLS 2, 3) (TITANIUM)
15864306 MOLDING, L/GATE WDO UPR GARN (INCLS 2, 3) (EBONY)
teamcadillac.ru
15864307 MOLDING, L/GATE WDO UPR GARN (INCLS 2, 3) (LT CASHMERE)
11561654 RETAINER, L/GATE WDO UPR G/MLDG (PART OF 1) (PLAIN) (8.5MM DIA HOLE) (BIRD'S BEAK SINGLE) (12.800) [ФИКСАТОР ВНУТРЕННЕЙ ПАНЕЛИ БАГАЖНОГО ОТДЕЛЕНИЯ]
11609242 ГАЙКА, L/GATE TR FIN PNL (M6X1, 18X17X14.3)
11561654 CLIP, L/GATE TR FIN PNL (PART OF 9) (PLAIN) (8.5MM DIA HOLE) (BIRD'S BEAK SINGLE) (12.800) [ФИКСАТОР ВНУТРЕННЕЙ ПАНЕЛИ БАГАЖНОГО ОТДЕЛЕНИЯ]
15838601 HANDLE, L/GATE I/S PULL (PART OF 9) (EBONY)
15838603 HANDLE, L/GATE I/S PULL (PART OF 9) (CASHMERE)
15838604 HANDLE, L/GATE I/S PULL (PART OF 9) (LT CASHMERE)
15952901 HANDLE, L/GATE I/S PULL (PART OF 9) (TITANIUM)
11518329 SCR, TORX PAN HD, W/WA, M6X1X25, 18 THD, 15 OD, 9.8, 6138M, TORX (L/GATE TR FIN PNL)
20787039 PANEL, L/GATE TR FIN (INCLS 4, 6, 7, 10-13) (CASHMERE) (NO LONGER INCLS PULL STRAP)
20799809 PANEL, L/GATE TR FIN (INCLS 4, 6, 7, 10-13) (TITANIUM) (NO LONGER INCLS PULL STRAP)
20799810 PANEL, L/GATE TR FIN (INCLS 4, 6, 7, 10-13) (EBONY) (NO LONGER INCLS PULL STRAP) [ВНУТРЕННЯЯ ПАНЕЛЬ ЗАДНЕЙ ОТКИДНОЙ ДВЕРИ]
25852158 PANEL, L/GATE TR FIN (INCLS 4, 6, 7, 10-13) (LT CASHMERE) (NO LONGER INCLS PULL STRAP)
15211504 SWITCH, L/GATE ACTR (PART OF 9) (PART OF LIFT GATE PNL)
15107130 LABEL, L/GATE WRNG (PART OF 9)
15594543 CLIP, L/GATE TR FIN PNL (PART OF 9) (12.7 X 10.4) (9.665) [ФИКСАТОР ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ]
15838552 STRAP, L/GATE PULL (PART OF 9) (EBONY)
15838553 STRAP, L/GATE PULL (PART OF 9) (TITANIUM)
15838554 STRAP, L/GATE PULL (PART OF 9) (CASHMERE)
15838555 STRAP, L/GATE PULL (PART OF 9) (LT CASHMERE)
15120856 RETAINER, L/GATE WDO UPR G/MLDG (BLACK) (8.141) [ФИКСАТОР ВНУТРЕННЕЙ ПАНЕЛИ КУЗОВА]
(TC17-922) - 2007-2009 CK107(06) МОЛДИНГИ (CADILLAC Z75)
15826605 MOLDING, RF PNL JT FIN [МОЛДИНГ КРЫШИ]
teamcadillac.ru
15876401 MOLDING, RR S/D (CHROME)
15876402 MOLDING, RR S/D (CHROME)
15876405 MOLDING, FRT S/D (CHROME) [МОЛДИНГ ПЕРЕДНЕЙ ДВЕРИ]
15876406 MOLDING, FRT S/D (CHROME) [МОЛДИНГ ПЕРЕДНЕЙ ДВЕРИ]
15860253 INSERT, F/FDR CTR RR UPR MLDG [ВСТАВКА КРЫЛА]
15860254 INSERT, F/FDR CTR RR UPR MLDG [ВСТАВКА]
18 - ЗАПЧАСТИ - ЖИДКОСТИ - ЕМКОСТИ И ОБЪЕМЫ - НОВЫЕ ДЕТАЛИ - ЭЛЕКТРИЧЕСКИЕ СОЕДИНЕНИЯ
(OTOU-028) - 2007-2008 CK1 ОБЫЧНОЕ ОБСЛУЖИВАНИЕ ЗАПАСНЫЕ ЧАСТИ (L92/6.2-8)(379 CID)
12609877 СВЕЧА, (GAP 0.040) (ACDelco #41-985) (IRIDIUM)
15908916 ELEMENT, A/CL (ACDelco #A3086C) [ВОЗДУШНЫЙ ФИЛЬТР ДВИГАТЕЛЯ]
19167894 ФИЛЬТР, МАСЛЯНЫЙ (ACDelco #PF48F) (DURAPACK) (BULK PKG, QTY 12) [МАСЛЯНЫЙ ФИЛЬТР ДВИГАТЕЛЯ]
89017524 ФИЛЬТР, МАСЛЯНЫЙ (ACDelco #PF48) [МАСЛЯНЫЙ ФИЛЬТР ДВИГАТЕЛЯ]
89018058 WIRE KIT, SPLG (INCLS SET OF 8 LEADS) (ACDelco #748RR) [НАБОР КАБЕЛЯ СВЕЧИ]
24236933 FILTER KIT, A/TRNS FLUID (ACDelco #24236933) [МАСЛЯНЫЙ ФИЛЬТР АКПП]
teamcadillac.ru
24224781 GASKET, A/TRNS FLUID PAN (ACDelco #24224781) [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА АКПП]
21 - АКСЕССУАРЫ
(6K21-005) - 2007-2009 CK1,2,3 COVER PKG/FRONT SEAT HEADREST
19166485 COVER PKG, F/SEAT HEADREST (CASHMERE) (INSTALL .10) (0.45KGS) (LEATHER) (INCLS 2 CVR'S) (16.718)
19166486 COVER PKG, F/SEAT HEADREST (EBONY) (INSTALL .10) (0.45KGS) (LEATHER) (INCLS 2 CVR'S) (16.718)
teamcadillac.ru
19166487 COVER PKG, F/SEAT HEADREST (CASHMERE) (INSTALL .10) (0.45KGS) (LEATHER W/VINYL) (INCLS 2 CVR'S) (16.718)
(AC21-548) - 2007-2009 CK1,2,3 ROADSIDE ASSISTANCE PKG/ROLL-UP
12498311 ROADSIDE PKG, ACSRY MISC (360 PC QTY OF 88960625) (8.808)
88960625 ROADSIDE PKG, ACSRY MISC (INCLS BUNGEE CORDS, FLASHLIGHT, FUSE KIT, GLOVES, PLIERS, TAPE, RAG, PONCHO, SCREWDRIVER W/BITS, ШИНА GAUGE, & BAG) (1.26KGS) (ROLL-UP) (8.808)
(AC21-560) - 2007-2009 CK1,2 LOCK PKG/WHEEL
12498075 LOCK PKG, WHL (NON-DECORATIVE) (INSTALL .10) (SINGLE 0.6KGS) (W/HEX FREE COATING) (4 NUTS & KEY) (M14X1.5 W/EXT THD) (5.875) [КОМПЛЕКТ ГАЕК М14]
12498076 LOCK PKG, WHL (INSTALL .10) (SINGLE 0.5KGS) (W/HEX FREE COATING) (4 NUTS & KEY) (M14X1.5 W/EXT THD) (5.875) [КОМПЛЕКТ БОЛТОВ М14 (4ШТ)]
12498082 LOCK PKG, WHL (INSTALL .10) (SINGLE 0.6KGS) (W/HEX FREE COATING) (10 PC QTY OF 12498075) (5.875)
teamcadillac.ru
17801711 NUT PKG, SPL SECURITY WHL LK (CHROME) (INSTALL .10) (0.29 KGS) (INCLS 20 NUTS, 4 LOCKS, 1 KEY) (M14X1.5) (5.813) (PREFERRED USE ON WHLS W/EXPOSED LUGS & W/O NEED TO RETAIN A WHL CAP/COVER) [КОМПЛЕКТ ГАЕК М14 (4 ШТ.)]
17801712 NUT PKG, SPL SECURITY WHL LK (CHROME) (INSTALL .10) (SINGLE 0.29KGS) (INCLS 4 PACK OF 17801711) (M14X1.5) (5.813) (FOR USE WITH 20" SPO ACCESSORY КОЛЕСА) (PREFERRED USE ON WHLS W/EXPOSED LUGS & W/O NEED TO RETAIN A WHL CAP/COVER)
17802466 LOCK PKG, WHL (DECORATIVE) (CHROME) (INSTALL .10) (SINGLE 0.5 KGS) (W/HEX FREE COATING) (INCLS 4 NUTS, 1 KEY) (M14X1.5 THD) (5.875) (PREFERED USE ON WHLS W/EXPOSED LUGS & W/O NEED TO RETAIN A WHL CAP/COVER)
17802467 LOCK PKG, WHL (INSTALL .10) (SINGLE 0.5 KGS) (10 PC QTY OF 17802466) (5.875) (PREFERED USE ON WHLS W/EXPOSED LUGS & W/O NEED TO RETAIN A WHL CAP/COVER)
(AC21-583) - 2007-2009 CK1,2,3 ADAPTER PKG/TRAILER HARNESS (7-PIN TO 4-PIN ADAP)
12496599 ADAPTER PKG, TRLR WRG HARN (0.1 KGS) (CONVERTS HVY DUTY 7 PIN RND TO LGT DUTY 4 PIN FLAT) (7.068) [АДАПТЕР]
(AC21-589) - 2007-2009 CK1,2,3 ADAPTER PKG/TRAILER HARNESS (7-PIN TO PWR ADAP)
teamcadillac.ru
12497781 ADAPTER PKG, TRLR WRG HARN (0.1 KGS) (CONVERTS HVY DUTY 7-PIN CONN TO ACSRY PWR RCPT) (7.068) [АДАПТЕР КОМЛПЕКТ]
(AC21-667) - 2007-2009 CK1,2(06) LOCK PKG/HITCH
12499511 PIN PKG, LOCKING HITCH (INSTALL .10) (0.4KGS) (REQ 2" HITCH PKG) (7.068) [ЗАМОК КРЫШКИ КРЮКА ТРЕЙЛЕРНОЙ СЦЕПКИ]
(AC21-671) - 2007-2009 CK1,2,3 АПТЕЧКА ПЕРВОЙ ПОМОЩИ
teamcadillac.ru
12498312 MEDICAL PKG, 1ST AID (360 PC QTY OF 88960626) (8.808)
88960626 MEDICAL PKG, 1ST AID (BLACK) (0.19KGS) (WHITE GM BLOCK LOGO) (VINYL) (8.808)
(AC21-672) - 2007-2009 CK1,2,3 КРЕПЛЕНИЕ БАГАЖА, ВЕЛОСИПЕД (WALL MOUNT)
teamcadillac.ru
12499175 UNIT, BICYCLE/SKI CARRIER WALL MOUNT STORAGE (6.35KGS) (INCLS BRKT, PLT & HDW) (REQ'S HITCH MTD BIKE CARR) (17.070) (REQUIRES 2" HITCH PKG)
(AC21-693) - 2007-2009 CK1,2,3 MAT PKG/REAR FLOOR CARPET(NON-PRODUCTION)
17800413 MAT PKG, REAR CARPET (MOLDED EDGE) (EBONY) (1.45KGS) (1 PC) (NO LOGO) (16.800)
(AC21-736) - 2007-2009 CK1,2(06-36) CARRIER PKG/HARD SHELL (LONG)
teamcadillac.ru
12499318 CARRIER PKG, HARD SHELL (CROSSRAILS REQUIRED) (BLACK) (INSTALL .50) (10.43 KGS) (TEXTURED) (LONG) (W/GM-THULE LOGO) (INCLS LK CYL) (89"LX21"WX15"H) (17.070)
(AC21-781) - 2007-2009 CK1,2(06-36) CARRIER PKG/HARD SHELL (SHORT)
12499319 CARRIER PKG, HARD SHELL (CROSSRAILS REQUIRED) (BLACK) (INSTALL .50) (11.339KGS) (TEXTURED) (W/GM-THULE LOGO) (56"LX36"WX15"H) (INCLS CYL & HDW) (17.070)
(AC21-803) - 2007-2009 CK1,2,3 CARRIER PKG/SKI (HITCH MOUNT)
12499173 CARRIER PKG, SKI (HITCH MT) (INCLS UPR & LWR ARMS, KEY SET & INSTR) (INSTALL .10) (11.38KGS) (CARRIES 5 PR SKIS OR 4 SNOWBOARDS & 1 PR SKIS) (17.070) (REQUIRES 2" HITCH) (REQUIRES BIKE CARRIER PKG 12499171) [КРОНШТЕЙН ОТКИДНОЙ ДВЕРИ ДЛЯ КРЕПЛЕНИЯ СНОУБОРДА]
(AC21-819) - 2007-2009 CK1,2,3 VENTVISOR PKG/SIDE WINDOW
12499491 DEFLECTOR PKG, SI WDO (SILVER) (INSTALL .30) (0.43KGS) (FRT & RR) (16.290) [КОМПЛЕКТ ДЕФЛЕКТОРОВ СТЕКЛА ДВЕРИ (4ШТ)]
teamcadillac.ru
12499492 DEFLECTOR PKG, SI WDO (WHITE) (INSTALL .30) (0.43KGS) (FRT & RR) (16.290)
12499493 DEFLECTOR PKG, SI WDO (RED) (INSTALL .30) (0.43KGS) (FRT & RR) (16.290)
(AC21-824) - 2007-2009 CK1 ACCESSORY PKG/ШИНА
19107491 ШИНА, P275/55R20-111S AL2 TL BW (18.6 KGS) (INSTALL .10) (INSTALL .25) (SINGLE 18.4KGS) (GOODYEAR, EAGLE LS2, 275/55R20) (5.880) (ACDelco #LU069165)
19143998 ШИНА, P285/45R22-110H AL2 TL BW (18.6 KGS) (INSTALL .10) (INSTALL .25) (SINGLE 19.3KGS) (BRIDGESTONE, DUELER H/L ALENZA, P285/45R22, BW110H) (5.880) (ACDelco #FB053984)
19145377 ШИНА, P275/55R20-111S AL2 TL BW (19.5 KGS) (INSTALL .10) (INSTALL .25) (SINGLE 19.5KGS) (BRIDGESTONE, DUELER H/L ALENZA W/UNI-T, P275/55R20, BL, 111S) (5.880) (ACDelco #FB053967)
19185719 ШИНА, 285/45R22-114H XL AL3 BW (SINGLE 17.2KGS) (ШИНА, GOODYEAR_FORTERA SL_285/45R22_VSB114H) (5.880) (ACDelco #KY621163)
(AC21-854) - 2007-2009 CK1,2(06) TRAY PKG/REAR COMPARTMENT FLOOR STORAGE
17803357 TRAY PKG, R/CMPT FLR STOW COMPT (EBONY) (2.3KGS) (GRD PLSTC) (W/ESCALADE SCRIPT LOGO) (INCLS LINER) (2" SIDE WALLS) (16.583) (TO BE USED WHEN THIRD ROW SEAT IS NOT IN VEHICLE) [ЯЧЕЙКА ПКГ]
(AC21-855) - 2007-2009 CK1,2,3 КРЕПЛЕНИЕ БАГАЖА, ВЕЛОСИПЕД (HITCH MOUNTED)
12499171 CARRIER PKG, BICYCLE (HITCH MT) (INSTALL .10) (18.42KGS) (CARRIES 4 BIKES) (17.070) (REQUIRES 2" TRAILER HITCH AND LICENSE PLATE REMOUNT PKG-12495709) [КРОНШТЕЙН ДЛЯ КРЕПЛЕНИЯ ВЕЛОСИПЕДА]
12499722 RAIL PKG, BICYCLE CARR (HITCH MT) (17.070) (REQUIRES 2" HITCH PKG)
12499718 PLATE PKG, BICYCLE CARR RAIL MTG (12.815) (REQUIRES 2" HITCH PKG) (SERV CMP OF CARRIER PKG 12499171, 72)
12499719 CARRIER, BICYCLE (HITCH MT CARRIER LOWER SUPPORT) (12.815)
teamcadillac.ru
12499723 STRAP, HITCH MT BICYCLE CARR (BLACK) (PLASTIC) (QTY 8 PC PKG) (16.800) (REQUIRES 2" HITCH PKG)
(AC21-857) - 2007-2009 CK1,2(06) BAG PKG/ROOF LUGGAGE (SOFT)(Z88,Z75)
teamcadillac.ru
12497826 BAG PKG, RF LUGG STOW (SOFT) (WATER RESISTANT/NOT WATERPROOF) (BLACK) (INSTALL .30) (2.29KGS) (FABRIC) (CADILLAC LOGO) (11.5X29.625X37) (12.816) (CROSSRAILS REQUIRED)
(AC21-864) - 2007-2009 CK107(06) DOOR PKG/ТОПЛИВНЫЙ БАК FILLER
teamcadillac.ru
12497944 DOOR PKG, F/TNK FIL (CHROME) (INSTALL .60) (0.74 KGS) (ZINC DIE CAST) (INCLS SCREWS, NUTS & INSTR) (16.570) [ДВЕРЬ]
(AC21-865) - 2007-2009 CK1(06-36) GRILLE PKG/RADIATOR (Z75)
17801288 GRILLE PKG, RAD (WHITE) (INSTALL 1.5) (3.78KGS) (INCLS INSTR) (1.266)
17801289 GRILLE PKG, RAD (SILVER) (INSTALL 1.5) (3.78KGS) (INCLS INSTR) (1.266)
teamcadillac.ru
17801290 GRILLE PKG, RAD (BLUE) (INSTALL 1.5) (3.78KGS) (INCLS INSTR) (1.266)
19156281 GRILLE PKG, RAD (BLACK) (INSTALL 1.5) (3.78KGS) (INCLS INSTR) (1.266)
(AC21-867) - 2007-2009 CK1,2,3 HITCH PKG/BALL MOUNT
12495776 HITCH PKG, BALL MT (INSTALL .10) (2.9 KGS) (STD) (INCLS BALL MT W/1" SHANK, 5/8 HITCH PIN & 1/8 HAIR PIN) (7.068) (3/4" RISE, 2" DROP, 5000 LB MAX LOAD, 500 LB TONGUE WT) [ШАРОВЫЙ КРЮК ТРЕЙЛЕРНОЙ СЦЕПКИ]
teamcadillac.ru
12495777 HITCH PKG, BALL MT (INSTALL .10) (3.0KGS) (STD) (INCLS BALL MT W/1" SHANK, 5/8 HITCH PIN & 1/8 HAIR PIN) (7.068) (2" RISE, 3-1/4" DROP, 5000 LB MAX LOAD, 500 LB TONGUE WT) [ШАРОВЫЙ КРЮК ТРЕЙЛЕРНОЙ СЦЕПКИ]
12495778 HITCH PKG, BALL MT (INSTALL .10) (4.0KGS) (STD) (INCLS BALL MT W/1" SHANK, 5/8 HITCH PIN & 1/8 HAIR PIN) (7.068) (4" RISE, 5-1/4" DROP, 5000 LB MAX LOAD, 500 LB TONGUE WT) [ШАРОВЫЙ КРЮК ТРЕЙЛЕРНОЙ СЦЕПКИ]
(AC21-870) - 2007-2009 CK1(06-36) HOOK PKG/TOW
19158571 HOOK PKG, FRT TOW (CHROME) (INSTALL .50) (3.15KGS) (INCLS 2 HOOKS, HDW KIT & INSTR) (7.068) [БУКСИРОВОЧНЫЙ КРЮК]
teamcadillac.ru
19158568 ATTACHMENT KIT, TOW HOOK (7.068) (SERV COMP OF CHROME TOW HOOK PKGS)
(AC21-873) - 2007-2009 CK1,2(06-36) ЗАЩИТА/SPLASH (FLAT WITH CONTOUR) (NO LOGO)(Z75)
19154428 FLAP PKG, RR MUD (BLACK) (INSTALL .30) (0.76KGS) (MOLDED) (NO LOGO) (FLAT W/CONTOUR) (11.1" WIDE) (8.214) (NOT FOR USE W/ACSRY ARTICULATING ПОРОГS)
(AC21-878) - 2007-2009 CK1(06-36) HOIST PKG (EXC (HP2))
teamcadillac.ru
19158309 HOIST PKG, SPA WHL (INSTALL .50) (SINGLE 3.1KGS) (9.709) (FOR 22" WHEEL ONLY)
(AC21-879) - 2007-2009 CK1,2(06-36) HEADPHONE/ЗАДНЕЕ СИДЕНЬЕ ENTERTAINMENT (SERVICED COMPONENT)
teamcadillac.ru
19132012 HEADPHONE, R/SEAT ENTERTAINMENT (0.36 KGS) (9.680) (HEADPHONES WILL OPERATE WITH ANY GMSPO & GM DVD SYSTEM) (HEADPHONES HAS WIRELESS & DUAL CHANNEL FEATURE (CHANNEL A & CHANNEL B))
(AC21-887) - 2007-2009 CK1,2(06-36) MAT PKG/FRONT FLOOR CARPET (PRODUCTION)
teamcadillac.ru
(AC21-916) - 2007-2009 CK1,2,3 LOCK PKG/BICYCLE & SKI CARRIER
12499724 LOCK, BICYCLE (0.91KGS) (INCLS 2 KEYS) (REQ 2" HITCH PKG) (12.815)
19242660 KEY SET, HITCH CARRIER (#010) (INCLS 2 KEYS) (17.070)
19242661 KEY SET, HITCH CARRIER (#011) (INCLS 2 KEYS) (17.070)
19242662 KEY SET, HITCH CARRIER (#012) (INCLS 2 KEYS) (17.070)
19242663 KEY SET, HITCH CARRIER (#013) (INCLS 2 KEYS) (17.070)
19242664 KEY SET, HITCH CARRIER (#014) (INCLS 2 KEYS) (17.070)
19242665 KEY SET, HITCH CARRIER (#015) (INCLS 2 KEYS) (17.070)
19242666 KEY SET, HITCH CARRIER (#016) (INCLS 2 KEYS) (17.070)
19242667 KEY SET, HITCH CARRIER (#017) (INCLS 2 KEYS) (17.070)
19242668 KEY SET, HITCH CARRIER (#018) (INCLS 2 KEYS) (17.070)
19242669 KEY SET, HITCH CARRIER (#019) (INCLS 2 KEYS) (17.070)
19242670 KEY SET, HITCH CARRIER (#020) (INCLS 2 KEYS) (17.070)
19242671 KEY SET, HITCH CARRIER (#021) (INCLS 2 KEYS) (17.070)
19242673 KEY SET, HITCH CARRIER (#023) (INCLS 2 KEYS) (17.070)
19242674 KEY SET, HITCH CARRIER (#024) (INCLS 2 KEYS) (17.070)
19242675 KEY SET, HITCH CARRIER (#025) (INCLS 2 KEYS) (17.070)
19242676 KEY SET, HITCH CARRIER (#026) (INCLS 2 KEYS) (17.070)
88963077 KEY SET, HITCH CARRIER (#01) (INCLS 2 KEYS) (12.815)
88966122 KEY SET, HITCH CARRIER (#02) (INCLS 2 KEYS) (17.070)
88966123 KEY SET, HITCH CARRIER (#03) (INCLS 2 KEYS) (17.070)
88966124 KEY SET, HITCH CARRIER (#04) (INCLS 2 KEYS) (17.070)
88966125 KEY SET, HITCH CARRIER (#05) (INCLS 2 KEYS) (17.070)
88966126 KEY SET, HITCH CARRIER (#06) (INCLS 2 KEYS) (17.070)
88966127 KEY SET, HITCH CARRIER (#07) (INCLS 2 KEYS) (17.070)
teamcadillac.ru
88966128 KEY SET, HITCH CARRIER (#08) (INCLS 2 KEYS) (17.070)
88966129 KEY SET, HITCH CARRIER (#09) (INCLS 2 KEYS) (17.070)
88966130 KEY SET, HITCH CARRIER (#00) (INCLS 2 KEYS) (17.070)
(AC21-920) - 2007-2009 CK1,2,3 PLATE PKG/LICENSE REMOUNT
12495709 PLATE PKG, LIC REMOUNT (INSTALL .30) (1.13 KGS) (INCLS HDW) (17.070) (REQUIRES 2" HITCH PKG) [ДОПОЛНИТЕЛЬНЫЙ КРОНШТЕЙН НОМЕРНОГО ЗНАКА, РАСПОЛОЖЕННЫЙ НА КРЕПЛЕНИИ ДЛЯ ВЕЛОСИПЕДА]
(AC21-952) - 2007-2009 CK1,2,3 АВАРИЙНЫЙ ЗНАК PKG (CU8)
19201300 REFLECTOR PKG, DISABLED VEH WRNG TRIANGLE (1.60KGS) (2.575) [ДОРОЖНЫЙ ЗНАК - ТРЕУГОЛЬНИК]
teamcadillac.ru
19201301 REFLECTOR PKG, DISABLED VEH WRNG TRIANGLE (BULK) (2.575)
(AC21-975) - 2007-2009 CK1,2(06-36) ENTERTAINMENT PKG/R/SEAT VIDEO & T/PLYR
17803045 HEADREST PKG, DUAL DVD R/SEAT ENTERTAINMENT (INCLS 2 HEADRESTS, 2 HEADPHONES, REM CONT, JMP HARN, QUIKSTART GDE, WIRE PUL, 6 AAA BATT, 3 PWR CORDS (PASS/DRV #9), WIRELESS FM MOD-CTRL BOX, VEH JMP HARN) (CASHMERE) (INSTALL 1.0) (05.4KGS) (LEATHER W/
17803046 HEADREST PKG, DUAL DVD R/SEAT ENTERTAINMENT (INCLS 2 HEADRESTS, 2 HEADPHONES, REM CONT, JMP HARN, QUIKSTART GDE, WIRE PUL, 6 AAA BATT, 3 PWR CORDS (PASS/DRV #9), WIRELESS FM MOD-CTRL BOX, VEH JMP HARN) (EBONY) (INSTALL 1.0) (05.4KGS) (LEATHER W/VIN
17803047 HEADREST PKG, DUAL DVD R/SEAT ENTERTAINMENT (INCLS 2 HEADRESTS, 2 HEADPHONES, REM CONT, JMP HARN, QUIKSTART GDE, WIRE PUL, 6 AAA BATT, 3 PWR CORDS (PASS/DRV #9), WIRELESS FM MOD-CTRL BOX, VEH JMP HARN) (CASHMERE) (INSTALL 1.0) (05.4KGS) (LEATHER W/
17803048 HEADREST PKG, DUAL DVD R/SEAT ENTERTAINMENT (INCLS 2 HEADRESTS, 2 HEADPHONES, REM CONT, JMP HARN, QUIKSTART GDE, WIRE PUL, 6 AAA BATT, 3 PWR CORDS (PASS/DRV #9), WIRELESS FM MOD-CTRL BOX, VEH JMP HARN) (EBONY) (INSTALL 1.0) (05.4KGS) (LEATHER W/VIN
(AC21-979) - 2007-2009 CK1,2(06-36) LINER PKG/CARGO/TRUNK (X88,Z75)
teamcadillac.ru
19155460 LINER PKG, CARGO / R/CMPT (BLACK) (INSTALL .30) (VINYL) (W/WREATH & CREST LOGO) (INCLS BAG & INSTR) (17.090)
(AC21-980) - 2007-2009 CK1(06-36) КОЛЕСО (CK945)(Z75)
12499427 CAP PKG, WHL NUT (INSTALL .10) (SINGLE 0.01KGS) (CHROME PLASTIC) (24 PC QTY OF 15045768) (5.858) [КОЛПАЧОК ГАЙКИ]
12499428 CAP PKG, WHL NUT (INSTALL .10) (SINGLE 0.01KGS) (CHROME PLASTIC) (480 PC QTY OF 15045768) (5.858) [КОМПЛЕКТ ГАЕК КОЛЕСА (24 ШТ)]
12499308 CAP, HUB (CHROME) (INSTALL .10) (SINGLE 0.04KGS) (W/CADILLAC LOGO) (80 PC QTY OF 88963142) (5.858)
12499423 CAP, HUB (CHROME) (INSTALL .10) (SINGLE 0.04KGS) (W/CADILLAC LOGO) (4 PC QTY OF 88963142) (5.858) [КОЛПАК СТУПИЦЫ КОЛЕСА]
19155564 NUT PKG, WHL (INSTALL .1) (SINGLE 0.062KGS) (STEEL W/ZINC PLATE) (24 PC QTY OF 9595175) (5.813) [ГАЙКА]
17800945 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (CAST) (AL) (INCLS 1 WHL 88967789 & TAG) (5.803)
teamcadillac.ru
17800946 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (CAST) (AL) (4 PC QTY OF 88967789) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 20X8.5]
17800947 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (CAST) (AL) (16 PC QTY OF 88967789) (5.803)
(AC21-981) - 2007-2009 CK1(06-36) КОЛЕСО (CK948)(Z75)
teamcadillac.ru
17800948 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (AL) (INCLS 1 WHL 88967790 & TAG) (5.803)
17800949 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (AL) (4 PC QTY OF 88967790) (5.803)
17800950 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (AL) (16 PC QTY OF 88967790) (5.803)
(AC21-982) - 2007-2009 CK1(06-36) КОЛЕСО (CK951)(Z75)
teamcadillac.ru
17800951 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (INCLS 1 WHL 88967791 & TAG) (5.803)
17800952 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (4 PC QTY OF 88967791) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 20Х8.5]
17800953 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (16 PC QTY OF 88967791) (5.803)
(AC21-984) - 2007-2009 CK1,2(06-36) STEP PKG/TUBULAR ASST (OVAL)
teamcadillac.ru
12499706 STEP PKG, OVAL TUBE ASSIST (CHROME) (INSTALL .50) (28.0KGS) (SS) (SMOOTH OVAL TUBE) (RAISED SLOPE RECT) (BLACK PAD) (8.225) [ПОДНОЖКА]
19211747 PAD, ASST STEP FRT (LONG) (8.228) (SERV CMP OF STEP PKGS 19202895-19202902)
88963977 PAD, SI STEP (LONG STEP PAD) (8.228) (SERV CMP FOR STEP PKGS 12499706 & 12499707)
88963978 PAD, SI STEP (SHORT STEP PAD) (8.228) (SERV CMP FOR STEP PKG 12499706)
(AC21-985) - 2007-2009 CK1(06-36) КОЛЕСО (CK366)(Z75)
17800366 КОЛЕСО, 22X9 (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (CAST ALUM) (INCLS 1 WHL 88966246 OR 19170520 & TAG) (5.803)
17800367 КОЛЕСО, 22X9 (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (AL) (4 PC QTY OF 88966246 OR 19170520) (5.803) [ДИСК]
teamcadillac.ru
17800368 КОЛЕСО, 22X9 (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (CAST ALUM) (16 PC QTY OF 88966246 OR 19170520) (5.803)
(GM21-020) - 2007-2009 CK1,2,3 HEADPHONE/ЗАДНЕЕ СИДЕНЬЕ ENTERTAINMENT (UPGRADE)
teamcadillac.ru
17802612 HEADPHONE PKG, (00.2 KGS) (INCLS WIRELESS NOISE CANC HEADPHONE, OWN MAN, 2 AAA BAT) (9.665) [БЕСПРОВОДНОЙ НАУШНИК]
(GM21-023) - 2007-2009 CK1 ACCESSORY PKG/ШИНА PRESSURE INDICATOR SENSOR
19155710 SENSOR PKG, ШИНА PRESS IND (INSTALL .10) (SINGLE 0.03KGS) (CLAMP-IN) (16 PC QTY OF 15268606) (5.890) [ДАТЧИК ДАВЛЕНИЯ ШИНЫ КОЛЕСА]
(GM21-024) - 2007-2009 CK1 ACCESSORY PKG/ШИНА PRESSURE INDICATOR SENSOR NUT
teamcadillac.ru
17800699 NUT PKG, ШИНА PRESS IND SEN (INSTALL .10) (SINGLE 0.0013 KGS) (16 PC QTY OF 15234846) (5.890) [ГАЙКА М12]
(GM21-032) - 2007-2009 CK107,109(06) ПЕПЕЛЬНИЦА PKG (BIN STYLE)
17800663 ПЕПЕЛЬНИЦА PKG, (FRT FLR CNSL) (BLACK) (INSTALL .20) (BIN STYLE) (PLASTIC) (INCLS C/LTR, HSG, RET) (12.009) [ПРИКУРИВАТЕЛЬ]
(GM21-033) - 2007-2009 CK1 APPEARANCE PKG/VALVE STEM CAP
teamcadillac.ru
19159985 CAP, PKG ШИНА VLV STEM (INSTALL .10) (SINGLE 0.0045KGS) (16 PC QTY OF 25749814) (5.875)
(GM21-035) - 2007-2009 CK1,2,3 ACCESSORY PKG/VIDEO DISPLAY REMOTE CONTROL
19132011 CONTROL, VIDEO DISPLAY REMOTE (0.09KGS) (9.680) (REMOTE WILL ONLY OPERATE WITH GMSPO DVD HEADREST SYSTEMS)
(GM21-037) - 2007-2009 CK1,2,3 ADAPTER PKG/TRAILER HARNESS (7-PIN TO PWR ADAP & 7-PIN TO 4-PIN ADAP)
19201995 ADAPTER PKG, TRLR WRG HARN (0.1 KGS) (INCLS 7-4 ADAPTER, 7-POWER OUTLET ADAPTER) (7.068)
(GM21-038) - 2007-2009 CK1,2,3 TRANSMITTER PKG/REMOTE CONTROL DOOR LOCK (W/INFO DISPLAY)
teamcadillac.ru
19157237 TRANSMITTER, R/CON DR LK & THEFT DTRNT & REM START (INCLS TRANSMITTER, RCVR, ANT, H/W, OWNER MAN) (INSTALL 1.1) (00.2 KGS) (2-WAY) (8 FT CABLE) (W/GREEN CONN) (16.345) (REQ SERV PROGRAMMING SYS AND SCAN TOOL) (REQ DLR INST)
(TC21-009) - 2007-2009 CK1,2(06) RAIL PKG/БАГАЖНИК CROSS (NON-PRODUCTION)
12499282 RAIL PKG, LUGG CARR CR (BRI AN W/CHROME ENDCAPS) (INSTALL .25) (3.99KGS) (AL) (NO LOGO) (INCLS 2 RAILS & HDW) (17.070)
19157494 STRIP, LUGG CARR CR RL RUB (17.070) (SERV CMP FOR RAIL PKG 12499282)
teamcadillac.ru
(TC21-010) - 2007-2008 CK1,2,3 PERFORMANCE PKG/AIR CLEANER
teamcadillac.ru
17800809 CLEANER PKG, AIR (INCLS AIR BOX & ALUM GMPP LOGO LID, 4 BUTTON HEAD BOLTS, 5 SIZE 64 CLMPS, 90-DEG COUPLER, CMP COUPLER, CON AIR FLT, INDUC TUBE, GMPP DECAL, CARB EO DECAL) (INSTALL 1.0) (3.8KGS) (3.402) (ALSO INCLS FOAM SEAL, PCV HOSE, 2 3/8"
88967643 ELEMENT, A/CL (CONICAL) (3.410) (MAY BE A SERV PART TO CLEANER PKG, 17800809)
(TC21-013) - 2007-2009 CK1,2(06-36) MAT PKG/FRONT FLOOR CARPET (NON-PRODUCTION) (MOLDED EDGE)(Z75)
17800408 MAT PKG, F/FLR (EBONY) (2.03KGS) (CPT) (TWIN) (W/WREATH & CREST LOGO) (16.800) [КОВРИК]
17800409 MAT PKG, F/FLR (CASHMERE) (2.03KGS) (CPT) (TWIN) (W/WREATH & CREST LOGO) (16.800) [КОМПЛЕКТ КОВРИКОВ САЛОНА (2ШТ) 0,48 М2]
(TC21-014) - 2007-2009 CK1,2(06) MAT PKG/REAR PREMIUM (ALL WEATHER)(1 PIECE)
12499640 MAT PKG, R/FLR (EBONY) (3.1KGS) (ALL WEATHER) (1 PC) (NO LOGO) (VERTICAL RIBS) (16.800) [КОВРИК САЛОНА ЗАДНИЙ]
17800414 MAT PKG, R/FLR (CASHMERE) (1.45KGS) (CPT) (1 PC) (NO LOGO) (16.800)
teamcadillac.ru
19166596 MAT PKG, R/FLR (CASHMERE) (3.1KGS) (ALL WEATHER) (1 PC) (NO LOGO) (VERTICAL RIBS) (16.800) [КОВРИК САЛОНА ДЛЯ ЗАДНИХ ПАССАЖИРОВ]
(TC21-015) - 2007-2009 CK1,2(06) MAT PKG/REAR #2 PREMIUM (ALL WEATHER)(1 PIECE)
teamcadillac.ru
12499641 MAT PKG, R/FLR (R/SEAT #2) (EBONY) (1.30KGS) (ALL WEATHER) (1 PC) (NO LOGO) (VERTICAL RIBS) (16.800) [КОВРИК БАГАЖНОГО ОТСЕКА]
17800423 MAT PKG, R/FLR (R/SEAT #2) (EBONY) (1.30KGS) (CPT) (MOLDED EDGE) (1 PC) (NO LOGO) (16.800) [КОМПЛЕКТ КОВРИКОВ]
17800424 MAT PKG, R/FLR (R/SEAT #2) (CASHMERE) (1.30KGS) (CPT) (MOLED EDGE) (1 PC) (NO LOGO) (16.800)
19166599 MAT PKG, R/FLR (R/SEAT #2) (CASHMERE) (1.30KGS) (ALL WEATHER) (1 PC) (VERTICAL RIBS) (16.800) [КОВРИК]
(TC21-016) - 2007-2009 CK107(06) MAT PKG/REAR #2 CARPET (NON-PRODUCTION)
(TC21-018) - 2007-2009 CK107(06) MAT PKG/CARGO PREMIUM (ALL WEATHER)(Z75)
17801325 MAT PKG, R/CMPT FLR (EBONY) (2.0KGS) (ALL WEATHER) (W/ESCALADE LOGO) (VINYL) (USE W/3RD ROW SEAT) (8.214) [КОВРИК БАГАЖНОГО ОТСЕКА]
teamcadillac.ru
19166801 MAT PKG, R/CMPT FLR (CASHMERE) (2.0KGS) (ALL WEATHER) (W/ESCALADE LOGO) (VERT RIBS) (USE W/3RD ROW SEAT) (16.800) [КОВРИК]
(TC21-019) - 2007-2009 CK1,2(06) MAT PKG/REVERSIBLE CARGO
(TC21-022) - 2007-2009 CK1,2,3 SECURITY PKG/INCLINATION SENSOR
17800432 SENSOR PKG, THEFT DTRNT VEH INCLINATION (INSTALL .80) (0.0421KGS) (INCLS SENSOR & HARN) (2.195) (REQUIRES PROGRAMMING THRU TCSC)
(TC21-023) - 2007-2009 CK1,2(06) SHIELD PKG/DOOR SILL (NO LOGO)
17802414 PLATE PKG, S/D SILL TR (INSTALL .50) (SS) (BRUSHED) (NO LOGO) (INCLS FRT & RR) (16.603) [ЗАЩИТА]
teamcadillac.ru
(TC21-032) - 2007-2009 CK1 КОЛЕСО (CK997)(Z75)
17800997 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (AL) (INCLS 1 WHL 88967872 & TAG) (5.803)
17800998 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (AL) (4 PC QTY OF 88967872) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 20Х8.5]
teamcadillac.ru
17800999 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (ALUMINUM) (16 PC QTY OF 88967872) (5.803) [КОЛЕСО]
(TC21-033) - 2007-2009 CK1 КОЛЕСО (CK925)(Z75)
17800925 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .25) (SINGLE 19.0KGS) (20X8.5) (CAST AL) (INCLS 1 WHL 88967768) (5.803)
teamcadillac.ru
17800926 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .25) (SINGLE 19.0KGS) (20X8.5) (CAST AL) (4 PC QTY OF 88967768) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 20Х8.5]
17800927 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .25) (SINGLE 19.0KGS) (20X8.5) (CAST AL) (16 PC QTY OF 88967768) (5.803)
(TC21-034) - 2007-2009 CK1 КОЛЕСО (CK994)(Z75)
17800994 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .25) (SINGLE 18.8KGS) (20X8.5) (CAST AL) (INCLS 1 WHL 88967871 & TAG) (5.803)
teamcadillac.ru
17800995 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .25) (SINGLE 18.8KGS) (20X8.5) (CAST AL) (4 PC QTY OF 88967871) (5.803)
17800996 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .25) (SINGLE 18.8KGS) (20X8.5) (CAST AL) (16 PC QTY OF 88967871) (5.803) [КОЛЕСО]
(TC21-043) - 2007-2009 CK1,2(06-36) MAT PKG/REAR FLOOR CARPET (PRODUCTION) (TWIN)
teamcadillac.ru
(TC21-052) - 2007-2009 CK1 ACCESSORY PKG/MUFFLER
19156353 MUFFLER PKG, EXH (SS) (INSTALL 1.0) (20.41KGS) (SEMI POLISHED) (3.701) (REQ PURCHASE OF GMPP EXH EXT PKG)
19156354 MUFFLER PKG, EXH (SS) (INSTALL 1.0) (20.41KGS) (SEMI POLISHED) (3.701) (REQ PURCHASE OF GMPP EXH EXT PKG)
teamcadillac.ru
(TC21-054) - 2007-2009 CK1,2(06) ЗАЩИТА/SPLASH (MOLDED) (FRONT)(NO LOGO)(FLAT BOTTOM)
teamcadillac.ru
19165823 ЗАЩИТА, SPH (MOLDED) (SILVER) (INSTALL .50) (0.52KGS) (FRT) (8.214) [КОМПЛЕКТ БРЫЗГОВИКОВ (2ШТ)]
19165825 ЗАЩИТА, SPH (MOLDED) (BLUE) (INSTALL .50) (0.52KGS) (FRT) (8.214)
(TC21-057) - 2007-2009 CK1,2(06) ЗАЩИТА/SPLASH (MOLDED) (FRONT)(NO LOGO)(Y91,Z75)
19165822 ЗАЩИТА, SPH (MOLDED) (BLACK) (INSTALL .50) (0.52KGS) (FRT) (NO LOGO) (W/O EDGE SEAL) (8.214) [КОМПЛЕКТ БРЫЗГОВИКОВ (2 ШТ)]
19165824 ЗАЩИТА, SPH (MOLDED) (WHITE) (INSTALL .50) (0.52KGS) (FRT) (W/O EDGE SEAL) (8.214) [КОМПЛЕКТ БРЫЗГОВИКОВ (2ШТ)]
teamcadillac.ru
19165826 ЗАЩИТА, SPH (MOLDED) (GRAY) (INSTALL .50) (0.52KGS) (FRT) (W/O EDGE SEAL) (8.214) [БРЫЗГОВИК]
(TC21-058) - 2007-2009 CK1(06) ЗАЩИТА/SPLASH (MOLDED) (REAR)(NO LOGO)(Y91,Z75)
12499475 ЗАЩИТА, SPH (MOLDED) (BLACK) (INSTALL .50) (0.62KGS) (RR) (NO LOGO) (W/O EDGE SEALS) (8.214) [КОМПЛЕКТ БРЫЗГОВИКОВ (2 ШТ)]
12499476 ЗАЩИТА, SPH (MOLDED) (SILVER) (INSTALL .50) (0.62KGS) (RR) (NO LOGO) (NOT FOR USE W/ACSRY SPARE ШИНА KIT 19172547) (8.214) [БРЫЗГОВИК]
teamcadillac.ru
12499477 ЗАЩИТА, SPH (MOLDED) (WHITE) (INSTALL .50) (0.62KGS) (RR) (NO LOGO) (W/O EDGE SEALS) (8.214) [КОМПЛЕКТ БРЫЗГОВИКОВ (2 ШТ)]
17800470 ЗАЩИТА, SPH (MOLDED) (GRAY) (INSTALL .50) (0.62KGS) (RR) (NO LOGO) (W/O EDGE SEALS) (8.214)
19156300 ЗАЩИТА, SPH (MOLDED) (BLUE) (INSTALL .50) (0.62KGS) (RR) (NO LOGO) (NOT FOR USE W/ACSRY SPARE ШИНА KIT 19172547) (8.214)
(TC21-065) - 2007-2009 CK1,2,3 MAT PKG/FRONT FLOOR VINYL (PRODUCTION)
(TC21-066) - 2007-2009 CK1(06-36) SHIELD PKG/DOOR SILL (CADILLAC SCRIPT LOGO)(Z75)
17802527 PLATE PKG, S/D SILL TR (INSTALL .30) (1.46KGS) (SS) (BRUSHED) (W/CAD SCRIPT LOGO) (INCLS RH & LH FRT & 2 R/L RR) (16.603) [КОМПЛЕКТ ДЕКОРАТИВНЫХ НАКЛАДОК ПОРОГА КУЗОВА (4 ШТ.)]
(TC21-081) - 2007-2009 CK1,2(06-36) DVD PLAYER AND DOCKING STATION PKG/PORTABLE
17802180 PLAYER PKG, PORTABLE DVD (INCLS REM CTRL, BATT, ADAP, CABLE, HEADPHONE, CASE, GUIDE, MAN, BATT PKG) (INSTALL .10) (3.6 KGS) (10.2" SCREEN) (9.680) (USE WITH DOCKING STATION PACKAGE)
17803084 STATION PKG, PORTABLE DVD PLAYER DOCKING (GRAY) (INSTALL .90) (4.7KGS) (INCLS BRKT, JUMP HARN, HARDWARE KIT, TEMPLATE & INSTR) (9.680) (T/W PLAYER PKG, PORTABLE DVD)
17803087 STATION PKG, PORTABLE DVD PLAYER DOCKING (CASHMERE) (INSTALL .90) (4.7KGS) (INCLS BRKT, JUMP HARN, HARDWARE KIT, TEMPLATE & INSTR) (9.680) (T/W PLAYER PKG, PORTABLE DVD)
17803088 STATION PKG, PORTABLE DVD PLAYER DOCKING (CASHMERE) (INSTALL .90) (4.7KGS) (INCLS BRKT, JUMP HARN, HARDWARE KIT, TEMPLATE & INSTR) (9.680) (T/W PLAYER PKG, PORTABLE DVD)
19159527 STATION, PORTABLE DVD PLAYER DOCKING (GRAY) (INSTALL .10) (1.2 KGS) (9.680) (T/W PLAYER PKG, PORTABLE DVD)
19159529 STATION, PORTABLE DVD PLAYER DOCKING (CASHMERE) (INSTALL .10) (1.2KGS) (9.680) (T/W PLAYER PKG, PORTABLE DVD)
teamcadillac.ru
19159545 PLAYER, PORTABLE DVD (SILVER) (INSTALL .10) (1.6 KGS) (10.2" SCREEN) (9.680) (USE WITH DOCKING STATION PACKAGE)
19172765 STATION PKG, PORTABLE DVD PLAYER DOCKING (GRAY) (INSTALL .90) (4.7KGS) (INCLS BRKT, JUMP HARN, HARDWARE KIT, TEMPLATE & INSTR) (9.680) (T/W PLAYER PKG, PORTABLE DVD)
(TC21-082) - 2007-2009 CK1 DEFLECTOR PKG/HOOD AIR (Z75)
teamcadillac.ru
12499276 DEFLECTOR PKG, КАПОТ AIR (SMOKE) (INSTALL .30) (0.6KGS) (ACRYLIC) (NO LOGO) (INCLS FASTENERS & INSTR) (8.010)
19165534 DEFLECTOR PKG, КАПОТ AIR (CHROME) (INSTALL .30) (0.7KGS) (ABS) (NO LOGO) (8.010)
(TC21-085) - 2007-2009 CK1,2(06) STORAGE PKG/REAR FLOOR КОНСОЛЬ
teamcadillac.ru
17801739 КОНСОЛЬ PKG, R/FLR (EBONY) (INSTALL .50) (2ND ROW) (INCLS 2 BRKT'S, BRKT CVR, TEMPLATE & INSTR) (16.650) [НАПОЛЬНАЯ КОНСОЛЬ КУЗОВА]
17801740 КОНСОЛЬ PKG, R/FLR (CASHMERE) (INSTALL .50) (2ND ROW) (INCLS 2 BRKT'S, BRKT CVR, TEMPLATE & INSTR) (16.650)
17801741 КОНСОЛЬ PKG, R/FLR (TITANIUM) (INSTALL .50) (2ND ROW) (INCLS 2 BRKT'S, BRKT CVR, TEMPLATE & INSTR) (16.650)
19158538 КОНСОЛЬ PKG, FLR (CASHMERE) (INSTALL .50) (2ND ROW) (INCLS BRKT T CVR, 2 BRKT'S, TEMP & INSTR) (16.650)
(TC21-089) - 2007-2009 CK107,109(06) LAMP PKG/TAIL(Z75)
teamcadillac.ru
19166175 LAMP KIT, TAIL (CLEAR) (INSTALL .50) (3.98KGS) (INCLS RH & LH) (2.679) [ЗАДНИЙ ФОНАРЬ]
(TC21-091) - 2007-2009 CK1(06-36) УДЛИНЕННАЯ КОМПОНОВКА-ГЛУШИТЕЛЬ (OEM ONLY)(NO LOGO)
teamcadillac.ru
19170728 EXTENSION KIT, EXH TAIL PIPE (POLISHED) (INSTALL .50) (1.06KGS) (OEM ONLY) (SS) (NO LOGO) (DUAL WALL) (ANGLE CUT) (3.705)
(TC21-092) - 2007-2009 CK1 КОЛЕСО (WITH CAP)(CK369)
17800366 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (CAST ALUM) (INCLS 1 WHL 88966246 OR 19170520 & TAG) (5.803)
17800367 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (AL) (4 PC QTY OF 88966246 OR 19170520) (5.803) [ДИСК]
17800368 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (CAST ALUM) (16 PC QTY OF 88966246 OR 19170520) (5.803)
17800372 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 20.6KGS) (22X9) (CAST AL) (INCLS 1 WHL 88966248 & TAG) (5.803)
17800373 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 20.6KGS) (22X9) (CAST AL) (4 PC QTY OF 88966248)
17800374 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 20.6KGS) (22X9) (CAST AL) (16 PC QTY OF 88966248) (5.803)
17800375 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (ALUM) (INCLS 1 WHL 88966249 & TAG) (5.803)
17800376 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (AL) (4 PC QTY OF 88966249) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 22Х9]
17800377 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (AL) (16 PC QTY OF 88966249) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК22Х9]
17800910 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 22.0KGS) (22X9) (CAST AL) (INCLS 1 WHL 88967763 & TAG) (5.803)
17800911 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 22.0KSG) (22X9) (CAST AL) (4 PC QTY OF 88967763) (5.803)
17800912 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 22.0KGS) (22X9) (CAST AL) (16 PC QTY OF 88967763) (5.803)
17800913 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .30) (21.3 KGS) (22X9) (INCLS 1 WHL 88967764 & TAG) (AL) (CAST) (5.803)
17800914 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .30) (SINGLE 21.3 KGS) (22X9) (4 PC QTY OF 88967764) (AL) (CAST) (5.803)
17800915 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .30) (SINGLE 21.3 KGS) (22X9) (16 PC QTY OF 88967764) (AL) (CAST) (5.803)
17800916 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 20.0KGS) (22X9) (CAST AL) (INCLS 1 WHL 88967765 & TAG) (5.803)
17800917 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 20.0KGS) (22X9) (CAST AL) (4 PC QTY OF 88967765) (5.803) [ДИСК]
17800918 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 20.0KGS) (22X9) (CAST AL) (16 PC QTY OF 88967765) (5.803)
17800919 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .30) (20.4 KGS) (22X9) (INCLS 1 WHL 88967766 & TAG) (AL) (CAST) (5.803)
17800920 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9) (4 PC QTY OF 88966776) (AL) (CAST) (5.803)
17800921 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9) (16 PC QTY OF 88967766) (AL) (CAST) (5.803)
17800922 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9) (CAST AL) (INCLS 1 WHL 88967767 & TAG) (5.803)
17800923 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9) (CAST AL) (4 PC QTY OF 88967767) (5.803)
17800924 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9) (CAST AL) (16 PC QTY OF 88967767) (5.803)
17800925 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 19.0KGS) (20X8.5) (CAST AL) (INCLS 1 WHL 88967768) (5.803)
17800926 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 19.0KGS) (20X8.5) (CAST AL) (4 PC QTY OF 88967768) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 20Х8.5]
17800927 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 19.0KGS) (20X8.5) (CAST AL) (16 PC QTY OF 88967768) (5.803)
17800928 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (17.3KGS) (20X8.5) (CAST AL) (1 PC QTY OF 88967769) (5.803)
17800929 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (4 PC QTY OF 88967769) (5.803)
17800930 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (16 PC QTY OF 88967769) (5.803)
17800945 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (CAST) (AL) (INCLS 1 WHL 88967789 & TAG) (5.803)
17800946 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (CAST) (AL) (4 PC QTY OF 88967789) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 20X8.5]
17800947 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (CAST) (AL) (16 PC QTY OF 88967789) (5.803)
17800948 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (AL) (INCLS 1 WHL 88967790 & TAG) (5.803)
17800949 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (AL) (4 PC QTY OF 88967790) (5.803)
17800950 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (AL) (16 PC QTY OF 88967790) (5.803)
17800951 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (INCLS 1 WHL 88967791 & TAG) (5.803)
17800952 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (4 PC QTY OF 88967791) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 20Х8.5]
17800953 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (16 PC QTY OF 88967791) (5.803)
17800991 WHEEL, PKG (22 X 9) (INSTALL .25) (17.5 KG) (20X8.5) (INCLS 1 WHL 88967870 & TAG) (5.803)
17800992 WHEEL, PKG (22 X 9) (INSTALL .25) (SINGLE 17.5 KG) (20X8.5) (4 PC QTY OF 88967870) (5.803)
17800993 WHEEL, PKG (22 X 9) (INSTALL .25) (SINGLE 17.5 KG) (20X8.5) (16 PC QTY OF 88967870) (5.803)
17800994 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 18.8KGS) (20X8.5) (CAST AL) (INCLS 1 WHL 88967871 & TAG) (5.803)
17800995 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 18.8KGS) (20X8.5) (CAST AL) (4 PC QTY OF 88967871) (5.803)
17800996 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 18.8KGS) (20X8.5) (CAST AL) (16 PC QTY OF 88967871) (5.803) [КОЛЕСО]
teamcadillac.ru
17800997 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (AL) (INCLS 1 WHL 88967872 & TAG) (5.803)
17800998 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (AL) (4 PC QTY OF 88967872) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 20Х8.5]
17800999 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (ALUMINUM) (16 PC QTY OF 88967872) (5.803) [КОЛЕСО]
19170370 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .30) (SINGLE 15.0KGS) (20X8.5) (CAST AL) (INCLS 1 WHL 19170369) (5.803) (-BPH PRIOR TO VIN 1GNFK13057R386644) (-BPH PRIOR TO VIN 3GNFK16367G288891)
19170371 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .30) (SINGLE 15.0KGS) (20X8.5) (CAST AL) (4 PC QTY OF 19170369) (5.803) (-BPH PRIOR TO VIN 1GNFK13057R386644) (-BPH PRIOR TO VIN 3GNFK16367G28 8891)
19170372 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .30) (SINGLE 15.0KGS) (20X8.5) (CAST AL) (16 PC QTY OF 19170369) (5.803) (-BPH PRIOR TO VIN 1GNFK13057R386644) (-BPH PRIOR TO VIN 3GNFK16367G28 8891)
19170798 WHEEL, PKG (22 X 9) (22 X 9) (MACH./PAINTED) (INSTALL .25) (SINGLE 17.93KGS) (CAST AL) (INCLS 1 WHL 19170797 & TAG) (5.803)
19170799 WHEEL, PKG (22 X 9) (22 X 9) (MACH./PAINTED) (INSTALL .25) (SINGLE 17.93KGS) (CAST AL) (4 PC QTY OF 19170797) (5.803) [АЛЮМИНИЕВЫЙ КОЛЁСНЫЙ ДИСК R22]
19170800 WHEEL, PKG (22 X 9) (22 X 9) (MACH./PAINTED) (INSTALL .25) (SINGLE 17.93KGS) (CAST AL) (16 PC QTY OF 19170797) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 22Х9]
(TC21-093) - 2007-2009 CK1 КОЛЕСО (WITH CAP)(CK988)
17800366 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (CAST ALUM) (INCLS 1 WHL 88966246 OR 19170520 & TAG) (5.803)
17800367 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (AL) (4 PC QTY OF 88966246 OR 19170520) (5.803) [ДИСК]
17800368 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (CAST ALUM) (16 PC QTY OF 88966246 OR 19170520) (5.803)
17800372 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 20.6KGS) (22X9) (CAST AL) (INCLS 1 WHL 88966248 & TAG) (5.803)
17800373 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 20.6KGS) (22X9) (CAST AL) (4 PC QTY OF 88966248)
17800374 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 20.6KGS) (22X9) (CAST AL) (16 PC QTY OF 88966248) (5.803)
teamcadillac.ru
17800375 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (ALUM) (INCLS 1 WHL 88966249 & TAG) (5.803)
17800376 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (AL) (4 PC QTY OF 88966249) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 22Х9]
17800377 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (AL) (16 PC QTY OF 88966249) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК22Х9]
17800910 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 22.0KGS) (22X9) (CAST AL) (INCLS 1 WHL 88967763 & TAG) (5.803)
17800911 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 22.0KSG) (22X9) (CAST AL) (4 PC QTY OF 88967763) (5.803)
17800912 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 22.0KGS) (22X9) (CAST AL) (16 PC QTY OF 88967763) (5.803)
17800913 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .30) (21.3 KGS) (22X9) (INCLS 1 WHL 88967764 & TAG) (AL) (CAST) (5.803)
17800914 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .30) (SINGLE 21.3 KGS) (22X9) (4 PC QTY OF 88967764) (AL) (CAST) (5.803)
17800915 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .30) (SINGLE 21.3 KGS) (22X9) (16 PC QTY OF 88967764) (AL) (CAST) (5.803)
17800916 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 20.0KGS) (22X9) (CAST AL) (INCLS 1 WHL 88967765 & TAG) (5.803)
17800917 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 20.0KGS) (22X9) (CAST AL) (4 PC QTY OF 88967765) (5.803) [ДИСК]
17800918 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 20.0KGS) (22X9) (CAST AL) (16 PC QTY OF 88967765) (5.803)
17800919 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .30) (20.4 KGS) (22X9) (INCLS 1 WHL 88967766 & TAG) (AL) (CAST) (5.803)
17800920 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9) (4 PC QTY OF 88966776) (AL) (CAST) (5.803)
17800921 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9) (16 PC QTY OF 88967766) (AL) (CAST) (5.803)
17800922 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9) (CAST AL) (INCLS 1 WHL 88967767 & TAG) (5.803)
17800923 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9) (CAST AL) (4 PC QTY OF 88967767) (5.803)
17800924 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9) (CAST AL) (16 PC QTY OF 88967767) (5.803)
17800925 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 19.0KGS) (20X8.5) (CAST AL) (INCLS 1 WHL 88967768) (5.803)
17800926 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 19.0KGS) (20X8.5) (CAST AL) (4 PC QTY OF 88967768) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 20Х8.5]
17800927 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 19.0KGS) (20X8.5) (CAST AL) (16 PC QTY OF 88967768) (5.803)
17800928 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (17.3KGS) (20X8.5) (CAST AL) (1 PC QTY OF 88967769) (5.803)
17800929 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (4 PC QTY OF 88967769) (5.803)
17800930 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (16 PC QTY OF 88967769) (5.803)
17800945 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (CAST) (AL) (INCLS 1 WHL 88967789 & TAG) (5.803)
17800946 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (CAST) (AL) (4 PC QTY OF 88967789) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 20X8.5]
17800947 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (CAST) (AL) (16 PC QTY OF 88967789) (5.803)
17800948 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (AL) (INCLS 1 WHL 88967790 & TAG) (5.803)
17800949 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (AL) (4 PC QTY OF 88967790) (5.803)
17800950 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (AL) (16 PC QTY OF 88967790) (5.803)
17800951 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (INCLS 1 WHL 88967791 & TAG) (5.803)
17800952 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (4 PC QTY OF 88967791) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 20Х8.5]
17800953 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (16 PC QTY OF 88967791) (5.803)
17800991 WHEEL, PKG (20 X 8.5) (INSTALL .25) (17.5 KG) (20X8.5) (INCLS 1 WHL 88967870 & TAG) (5.803)
17800992 WHEEL, PKG (20 X 8.5) (INSTALL .25) (SINGLE 17.5 KG) (20X8.5) (4 PC QTY OF 88967870) (5.803)
17800993 WHEEL, PKG (20 X 8.5) (INSTALL .25) (SINGLE 17.5 KG) (20X8.5) (16 PC QTY OF 88967870) (5.803)
17800994 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 18.8KGS) (20X8.5) (CAST AL) (INCLS 1 WHL 88967871 & TAG) (5.803)
17800995 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 18.8KGS) (20X8.5) (CAST AL) (4 PC QTY OF 88967871) (5.803)
17800996 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 18.8KGS) (20X8.5) (CAST AL) (16 PC QTY OF 88967871) (5.803) [КОЛЕСО]
17800997 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (AL) (INCLS 1 WHL 88967872 & TAG) (5.803)
17800998 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (AL) (4 PC QTY OF 88967872) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 20Х8.5]
17800999 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (ALUMINUM) (16 PC QTY OF 88967872) (5.803) [КОЛЕСО]
19170370 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .30) (SINGLE 15.0KGS) (20X8.5) (CAST AL) (INCLS 1 WHL 19170369) (5.803) (-BPH PRIOR TO VIN 1GNFK13057R386644) (-BPH PRIOR TO VIN 3GNFK16367G288891)
19170371 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .30) (SINGLE 15.0KGS) (20X8.5) (CAST AL) (4 PC QTY OF 19170369) (5.803) (-BPH PRIOR TO VIN 1GNFK13057R386644) (-BPH PRIOR TO VIN 3GNFK16367G28 8891)
19170372 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .30) (SINGLE 15.0KGS) (20X8.5) (CAST AL) (16 PC QTY OF 19170369) (5.803) (-BPH PRIOR TO VIN 1GNFK13057R386644) (-BPH PRIOR TO VIN 3GNFK16367G28 8891)
19170798 WHEEL, PKG (22 X 9) (20 X 8.5) (MACH./PAINTED) (INSTALL .25) (SINGLE 17.93KGS) (CAST AL) (INCLS 1 WHL 19170797 & TAG) (5.803)
19170799 WHEEL, PKG (22 X 9) (20 X 8.5) (MACH./PAINTED) (INSTALL .25) (SINGLE 17.93KGS) (CAST AL) (4 PC QTY OF 19170797) (5.803) [АЛЮМИНИЕВЫЙ КОЛЁСНЫЙ ДИСК R22]
19170800 WHEEL, PKG (22 X 9) (20 X 8.5) (MACH./PAINTED) (INSTALL .25) (SINGLE 17.93KGS) (CAST AL) (16 PC QTY OF 19170797) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 22Х9]
(TC21-094) - 2007-2009 CK1(06-36) КОЛЕСО (CK372)(Z75)
17800372 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 20.6KGS) (22X9) (CAST AL) (INCLS 1 WHL 88966248 & TAG) (5.803)
teamcadillac.ru
17800373 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 20.6KGS) (22X9) (CAST AL) (4 PC QTY OF 88966248) (5.803)
17800374 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 20.6KGS) (22X9) (CAST AL) (16 PC QTY OF 88966248) (5.803)
(TC21-097) - 2007-2009 CK1(06-36) КОЛЕСО (CK375)(Z75)
17800375 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (ALUM) (INCLS 1 WHL 88966249 & TAG) (5.803)
17800376 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (AL) (4 PC QTY OF 88966249) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 22Х9]
17800377 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (AL) (16 PC QTY OF 88966249) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК22Х9]
(TC21-100) - 2007-2009 CK1(06-36) КОЛЕСО (CK910)(Z75)
17800910 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 22.0KGS) (22X9) (CAST AL) (INCLS 1 WHL 88967763 & TAG) (5.803)
teamcadillac.ru
17800911 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 22.0KSG) (22X9) (CAST AL) (4 PC QTY OF 88967763) (5.803)
17800912 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 22.0KGS) (22X9) (CAST AL) (16 PC QTY OF 88967763) (5.803)
(TC21-103) - 2007-2009 CK1(06-36) КОЛЕСО (CK916)(Z75)
17800916 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 20.0KGS) (22X9) (CAST AL) (INCLS 1 WHL 88967765 & TAG) (5.803)
teamcadillac.ru
17800917 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 20.0KGS) (22X9) (CAST AL) (4 PC QTY OF 88967765) (5.803) [ДИСК]
17800918 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 20.0KGS) (22X9) (CAST AL) (16 PC QTY OF 88967765) (5.803)
(TC21-106) - 2007-2009 CK1,2(06) COVER PKG/CARGO AREA
15244021 SHADE PKG, LUGG (EBONY) (INSTALL .10) (0.4 KGS) (VINYL) (16.577) [ШТОРКА БАГАЖНОГО ОТСЕКА]
teamcadillac.ru
15277000 SHADE PKG, LUGG (CASHMERE) (INSTALL .10) (0.4 KGS) (VINYL) (16.577) [ШТОРКА БАГАЖНОГО ОТСЕКА 90Х120СМ]
(TC21-119) - 2007-2009 CK107,109(06) LAMP PKG/CENTER HIGH MOUNT STOP(Z75)
19172250 LAMP KIT, HIGH MT STOP (CLEAR) (INSTALL .50) (0.91KGS) (PLASTIC) (2.679)
(TC21-121) - 2007-2009 CK1(06-36) MAT PKG/FRONT PREMIUM (ALL WEATHER)(Z75)
teamcadillac.ru
17803323 MAT PKG, F/FLR (EBONY) (3.40KGS) (ALL WEATHER) (TWIN) (W/SILVER ESCALADE LOGO) (VERTICLE RIBS) (16.800) [КОМПЛЕКТ КОВРИКОВ САЛОНА (2 ШТ)]
19166595 MAT PKG, F/FLR (CASHMERE) (3.40KGS) (ALL WEATHER) (TWIN) (W/SILVER ESCALADE LOGO) (VERTICAL RIBS) (16.800) [КОМПЛЕКТ КОВРИКОВ САЛОНА (2 ШТ)]
(TC21-122) - 2007-2009 CK1(06-43) MAT PKG/FRONT FLOOR CARPET (NON-PRODUCTION) (Z88,Y91)
17800406 MAT PKG, F/FLR (EBONY) (2.03KGS) (CPT) (TWIN) (W/DENALI LOGO) (16.800)
teamcadillac.ru
17800407 MAT PKG, F/FLR (CASHMERE) (2.03KGS) (CPT) (TWIN) ( W/DENALI LOGO) (16.800) [КОВРИК]
(TC21-137) - 2007-2008 CK1,2(06) ACCESSORY PKG/REAR VIEW CAMERA
teamcadillac.ru
19171822 CAMERA PKG, RR VIEW (INSTALL 2.5) (INCLS CAMERA, BRKT, BEZEL, LIFTGATE HARN, TEMP, FASTENER) (9.715) (REQS GM NAV RDO)
(TC21-142) - 2007-2009 CK1 КОЛЕСО (CK798)
19170798 КОЛЕСО, 22X9 (MACH./PAINTED) (INSTALL .25) (SINGLE 17.93KGS) (CAST AL) (INCLS 1 WHL 19170797 & TAG) (5.803)
19170799 КОЛЕСО, 22X9 (MACH./PAINTED) (INSTALL .25) (SINGLE 17.93KGS) (CAST AL) (4 PC QTY OF 19170797) (5.803) [АЛЮМИНИЕВЫЙ КОЛЁСНЫЙ ДИСК R22]
teamcadillac.ru
19170800 КОЛЕСО, 22X9 (MACH./PAINTED) (INSTALL .25) (SINGLE 17.93KGS) (CAST AL) (16 PC QTY OF 19170797) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 22Х9]
(TC21-143) - 2007-2009 CK1 КОЛЕСО (CK919)
17800919 КОЛЕСО, 22X9 (CHROME) (INSTALL .30) (20.4 KGS) (22X9) (INCLS 1 WHL 88967766 & TAG) (AL) (CAST) (5.803)
17800920 КОЛЕСО, 22X9 (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9) (4 PC QTY OF 88966776) (AL) (CAST) (5.803)
17800921 КОЛЕСО, 22X9 (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9) (16 PC QTY OF 88967766) (AL) (CAST) (5.803)
(TC21-144) - 2007-2009 CK1 КОЛЕСО (CK922)
17800922 КОЛЕСО, 22X9 (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9) (CAST AL) (INCLS 1 WHL 88967767 & TAG) (5.803)
17800923 КОЛЕСО, 22X9 (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9) (CAST AL) (4 PC QTY OF 88967767) (5.803)
teamcadillac.ru
17800924 КОЛЕСО, 22X9 (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9) (CAST AL) (16 PC QTY OF 88967767) (5.803)
(TC21-145) - 2007-2009 CK1 КОЛЕСО (CK928)
17800928 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .25) (17.3KGS) (20X8.5) (CAST AL) (1 PC QTY OF 88967769) (5.803)
teamcadillac.ru
17800929 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (4 PC QTY OF 88967769) (5.803)
17800930 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (16 PC QTY OF 88967769) (5.803)
(TC21-146) - 2007-2009 CK1 КОЛЕСО (CK991)
17800991 КОЛЕСО, 20X8.5 (INSTALL .25) (17.5 KG) (20X8.5) (INCLS 1 WHL 88967870 & TAG) (5.803)
17800992 КОЛЕСО, 20X8.5 (INSTALL .25) (SINGLE 17.5 KG) (20X8.5) (4 PC QTY OF 88967870) (5.803)
17800993 КОЛЕСО, 20X8.5 (INSTALL .25) (SINGLE 17.5 KG) (20X8.5) (16 PC QTY OF 88967870) (5.803)
(TC21-147) - 2007-2009 CK1 КОЛЕСО (CK370)
teamcadillac.ru
19170370 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .30) (SINGLE 15.0KGS) (20X8.5) (CAST AL) (INCLS 1 WHL 19170369) (5.803)
19170371 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .30) (SINGLE 15.0KGS) (20X8.5) (CAST AL) (4 PC QTY OF 19170369) (5.803)
19170372 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .30) (SINGLE 15.0KGS) (20X8.5) (CAST AL) (16 PC QTY OF 19170369) (5.803)
(TC21-153) - 2007-2009 CK1,2(06) NET PKG/CONVENIENCE (FLAT STYLE)
17803346 NET PKG, CONVENIENCE (BLACK) (INSTALL .50) (2ND ROW) (FLAT STYLE) (INCLS 4-RET & 4-STUDS) (16.575) [ОГРАНИЧИТЕЛЬНАЯ СЕТКА БАГАЖНОГО ОТСЕКА]
(TC21-154) - 2007-2008 CK1,2 РАДИО/НАВИГАЦИЯ(Z75)
teamcadillac.ru
19169667 RADIO PKG, NAVIGATION (INSTALL 1.5) (5.9KGS) (INCLS RDO, ANT, DATA DISC, USERS INFO & MANUAL) (9.767)
(TN21-036) - 2007-2009 CK1,2,3 SECURITY PKG/VEHICLE SHOCK SENSOR
teamcadillac.ru
17800431 ALARM PKG, THEFT DTRNT (INSTALL .80) (0.0856KGS) (INCLS HARN & INSTR) (2.195)
  • Maxim locked this тему
