(GM00-047) - 2009 CK1 ДВИГАТЕЛЬ В СБОРЕ-6.2L V8 ЧАСТЬ 1 БЛОК ЦИЛИНДРОВ & СОПРЯЖЕННЫЕ ДЕТАЛИ (L9H/6.2-2)
11570662 БОЛТ, CONN ROD (PART OF 105) (MJ9X44, 13 THD, 15.5 OD, 12.9, PL)
89017573 BEARING KIT, CONN ROD (STD)
12607475 ROD, CONN (INCLS 102, 103, 106) (USED WITH FLOATING PIN PISTON) (WITH PIN RETAINING CLIP)
teamcadillac.ru
19178597 PISTON, (W/PIN) (HAS LOC DIMPLE 46MM FROM CTR & CASTING #81096 INSIDE SKIRT.FOR BROAD CAST CODES SCM, SCU, SBN, &W/CRANK 12588612.LAST 4 DIG OF CRANK PN LOC ON RR FL) (INCLS 109) (STD) (FOR 2ND DES SEE 19208473)
19208473 PISTON KIT, ENG (STD, HAS LOC DIMPLE 37MM FROM CTR & CASTING #81224 INSIDE SKIRT.FOR BROADCAST CODES SDF, SDH, SDD, &W/CRANK 12588613.LAST 4 DIG OF CRANK PN LOC ON) (INCLS 109) (STD) (RR FLG, FOR 1ST DES SEE 19178597)
19168090 RING KIT, PSTN (STD)
89018050 RING KIT, PSTN (0.5 MM O.S.)
12569638 RETAINER, PSTN PIN (PART OF 107)
12573460 PLUG, ENG BLK OIL GAL (INCLS 110) (15.68MM DIA) (INCLS O-RING SEAL (N.S.S.)
12586687 HEATER, ENG COOL
11588949 PLUG, M16X1.5X14, 24 OD, SAE 1010 STL, GMW3044, W/ AL WASHER (ENG BLK COOL DRN HOLE) [ПРОБКА ЗАМКА]
89017571 BEARING KIT, CR/SHF (#1, 2, 4, 5) (STD)
12561513 KEY, CR/SHF BALR (4.8MMX37.5MM) [ШПОНКА]
12584997 CRANKSHAFT,
12556127 БОЛТ, CR/SHF BRG CAP (SIDE) (SHORT) (M8X1.25X24) [БОЛТ М8]
12560273 STUD, CR/SHF BRG CAP (HFH, M10X2X23, M8X1.25X11, 113.5 TOTAL LONG) [БОЛТ М8]
12560272 БОЛТ, CR/SHF BRG CAP (LONG) (M10X2X102.5, 24.5) [ВИНТ]
01453658 PIN, DOWEL STRAIGHT 5/8 DIA 1 3/16 LG (TRANS LOC)
12606620 PLATE, A/TRNS FLEX (AUTO TRANSMISSION)
11569956 БОЛТ, A/TRNS FLEX PLT (M11X1.5X23.5 W/SEALER) [БОЛТ, СПЕЦИАЛЬНЫЙ M11 X 1.5-23.5]
12576652 BALANCER, CR/SHF
12557840 БОЛТ, CR/SHF BALR (M16X2.0X103) [БОЛТ / ВИНТ]
89060436 SEAL KIT, CR/SHF RR OIL (REVERSE LIP SEAL, INCL INSTRUCTION SHEET) [УПЛОТНЕНИЕ КОЛЕНВАЛА]
12617373 CAMSHAFT, ENG (INCLS 202)
19167218 BEARING, CM/SHF (POSN #3) [НАБОР ВКЛАДЫШЕЙ]
24575061 PIN, CM/SHF SPKT LOC (PART OF 200) (17MM LONG)
12589016 RETAINER, CM/SHF
11561283 БОЛТ, HVY HX FLG HD, M16X1.5X63, GMW25 (8.8) STL, GMW3359 (CM/SHF RET)
12606358 ACTUATOR, CM/SHF POSN
12588151 VALVE, CM/SHF POSN ACTR SOL
12556582 SPROCKET, CR/SHF [ШЕСТЕРНЯ КОЛЕНВАЛА]
12586482 CHAIN, CM/SHF TMG [ЦЕПЬ ПРИВОДА ГРМ]
11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (PART OF 232) [БОЛТ, М8Х1.25Х31.5]
12626407 РОЛИК НАТЯЖИТЕЛЬ KIT, TMG CHAIN (INCLS BOLT, RETAINER) (INCLS 231)
12615666 ШЛАНГИ, CR/SHF RR OIL SEAL (INCLS BOLT, SEAL, GASKET, ШЛАНГИ)
12593587 GASKET, CR/SHF RR OIL SEAL HSG
12585546 SENSOR, CR/SHF POSN (INCLS 702) (ACDelco #213-3520) [ДАТЧИК ПОЛОЖЕНИЯ КОЛЕНВАЛА]
12570125 SENSOR, KNOCK (ACDelco #213-1576)
11515756 БОЛТ, HFH, M8X1.25X20, 17THD, 18 O.D., 10.9, 7114M (BOLT, CR/SHF POSN SEN) [БОЛТ]
11609289 PLUG, HEX, M28X1.25X13, 10.9, GMW3044, INT DRIVER W/THD SEAL 9985 (ENG BLK COOL DRN HOLE) (8.971)
09427693 PLUG, CUP 5/8, CORROSION RESISTANT STL (ENG BLK OIL GAL) (1.531)
19167383 BEARING, CM/SHF (POSN #1, 5) [ВТУЛКА БЛОКА ЦИЛИНДРОВ]
19167382 BEARING, CM/SHF (# 2&4) [НАБОР ВКЛАДЫШЕЙ]
89017572 BEARING KIT, CR/SHF THR (STD) (#3)
(GM00-586) - 2009 CK1 ДВИГАТЕЛЬ В СБОРЕ-6.2L V8 ЧАСТЬ 3 ПЕРЕДНЯЯ КРЫШКА & COOLING (L9H/6.2-2)
12585673 SEAL, CR/SHF FRT OIL (PART OF 502) (0.207) (ACDelco #296-02) [ПРОКЛАДКА]
12551926 БОЛТ, W/PMP (M8X1.25X83) [БОЛТ-M8 X 1.25 X 82.6]
12587395 INLET, W/PMP (PART OF 300) (ACDelco #15-10595)
89018168 THERMOSTAT KIT, ENG COOL (INCL SEAL) (PART OF 300) (INCLS 900) (ACDelco #131-160) [КЛАПАН РЕГУЛИРОВКИ ТЕМПЕРАТУРЫ СИСТЕМЫ ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ]
12610311 GASKET, W/PMP (ACDelco #251-663) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ]
12605716 PIPE, ENG COOL AIR BL (INCLS 308, 903)
12602541 SEAL, ENG COOL AIR BL PIPE (O RING) (SINGLE TYPE ONE HOLE O-RING-SEAL) (PART OF 307)
11588715 БОЛТ, HFH, M6X1X35, 18 THD, 14.2 OD, 8.8, GMW3359, 5MM M POINT (ENG COOL AIR BL PIPE) [БОЛТ]
11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (PART OF 502) [БОЛТ, М8Х1.25Х31.5]
12616491 COVER, ENG FRT (INCLS COVER, SEAL, WIRE, JUMPER, BRACKET, GASKET, BOLT, SENSOR, MAGN ET) (INCLS 140, 501, 503, 703, 704, 737, 738, 751-753, 905)
12574294 GASKET, ENG FRT CVR (PART OF 502) [ПРОКЛАДКА]
12591720 SENSOR, CM/SHF POSN (PART OF 502) (INCLS 704) (ACDelco #213-3826) [ДАТЧИК]
12593593 WIRE, CM/SHF POSN SEN (PART OF 502) (W/3-WAY INLINE CONNECTOR TO ДВИГАТЕЛЬ HARNESS) (W/3-WAY INLINE CONNECTOR TO ДВИГАТЕЛЬ HARNESS)
12613158 WIRE, CM/SHF POSN SEN (PART OF 502) (W/5-WAY INLINE CONNECTOR TO ДВИГАТЕЛЬ HARNESS)
11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (PART OF 502)
12585995 MAGNET, CM/SHF POSN ACTR (PART OF 502)
12594339 SEAL, CM/SHF POSN ACTR CVR (PART OF 502)
12587397 SEAL, WAT INL (PART OF 305, 300) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО БЛОКА ЦИЛИНДРОВ]
89021297 ADHESIVE/SEALANT, THREADLOCKER HI STRENGTH 10ML ERI (PART OF 300) [АДГЕЗИВ]
12600254 HOSE, ENG COOL AIR BL PIPE DPNG (PART OF 307)
12602048 PLUG, ENG COOL AIR BL (55MM, ALUMINUM)
teamcadillac.ru
(GM00-615) - 2009 CK1 ДВИГАТЕЛЬ В СБОРЕ-6.2L V8 ЧАСТЬ 4 МАСЛОНАСОС, PAN & СОПРЯЖЕННЫЕ ДЕТАЛИ (L9H/6.2-2)
11609289 PLUG, HEX, M28X1.25X13, 10.9, GMW3044, INT DRIVER W/THD SEAL 9985 (ENG BLK OIL GAL) (8.971)
teamcadillac.ru
11588949 PLUG, M16X1.5X14, 24 OD, SAE 1010 STL, GMW3044, W/ AL WASHER (ENG BLK OIL GAL) [ПРОБКА ЗАМКА]
12619776 PAN, OIL (INCLS BAFFLE, BOLTS, PLUG, DEADENER, GASKET, VALVE, FITTING, SEAL) (EXC SWITCH) (INCLS 426-428, 430, 433-435, 438, 439, 453, 454, 900-902)
11609746 ГАЙКА, HFH, M8X1.25, 8.9THK, 17.6 O.D., 10 STL, GMW3200, PREV TORQUE (CR/SHF OIL DFL) [ГАЙКА М8]
11517031 ГАЙКА, HFH, M8X1.25, 9.4THK, 17.4 O.D., 10, TIN ZN (O/PMP SUC PIPE)
11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (O/PMP SUC PIPE)
12584922 SEAL, O/PMP SUC PIPE (O RING) (PART OF 407) (20.69MM I.D., 4.20MM THICKNESS) (TEFLON COATED) (1.724) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО МАСЛОЗАБОРНИКА]
12608579 SCREEN, O/PMP (W/SUC PIPE) (INCLS 406)
11519133 БОЛТ, SELF TAP, M6X1X20, 13.2 O.D. (PART OF 413)
11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (O/PMP) [БОЛТ, М8Х1.25Х31.5]
12612289 PUMP, OIL (INCLS 408, 410, 411, 414-416)
24504091 SEAL, OIL LVL IND (O RING) (PART OF 418) (BLACK) (6.07MM ID, 1.78MM DIA)
12622055 INDICATOR, OIL LVL (INCLS 417) [ЩУП (ИЗМЕРИТЕЛЬ) УРОВНЯ МАСЛА]
11588736 БОЛТ, HFH, M10X1.5X20, 10 THD, 22.3 O.D., 10.9, GMW3359 (OIL LVL IND TUBE)
12609269 TUBE, OIL LVL IND (INCL SEAL) (INCLS 421) [ТРУБКА МАСЛЯНОГО ЩУПА]
24504091 SEAL, OIL LVL IND TUBE (O RING) (PART OF 420) (BLACK) (6.07MM ID, 1.78MM DIA)
12611129 DEFLECTOR, CR/SHF OIL
12558760 GASKET, МАСЛЯНЫЙ ПОДДОН (PART OF 400) (CODE CNB WYA)
11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (PART OF 400)
11562588 PLUG, МАСЛЯНЫЙ ПОДДОН DRN (PART OF 400) (INCLS 454) (W/ SEAL) (EXC MAGNET) [ЗАГЛУШКА МАСЛЯНОГО ПОДДОНА]
12611384 GASKET, МАСЛЯНЫЙ ПОДДОН CVR (USE T/W 11588714 BOLT QTY 02) (PART OF 400)
12577903 COVER, МАСЛЯНЫЙ ПОДДОН (PART OF 400)
11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (PART OF 400) [БОЛТ]
89017524 ФИЛЬТР, МАСЛЯНЫЙ (ACDelco #PF48) [МАСЛЯНЫЙ ФИЛЬТР ДВИГАТЕЛЯ]
12600225 FITTING, OIL FLTR (PART OF 400)
11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (PART OF 400) [БОЛТ, М8Х1.25Х31.5]
12554990 БОЛТ, МАСЛЯНЫЙ ПОДДОН (PART OF 400) (M6X1.0X136)
12616850 SEAL, МАСЛЯНЫЙ ПОДДОН DRN PLUG (O RING) (PART OF 400, 430)
12608835 VALVE, OIL PRESS RLF (PART OF 400)
12594870 DEADENER, МАСЛЯНЫЙ ПОДДОН (PART OF 400)
11589241 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (PART OF 400)
12346004 SEALANT, LOCTITE PIPE-W/TEFLON 50CC TUBE (МАСЛЯНЫЙ ПОДДОН) [ГЕРМЕТИК С ТЕФЛОНОМ]
12558759 RIVET, МАСЛЯНЫЙ ПОДДОН GSKT
(TC00-900) - 2007-2009 CK1 SHIELD/ДВИГАТЕЛЬ SPLASH
15203366 SHIELD, ENG [ЗАЩИТНАЯ ПАНЕЛЬ МОТОРНОГО ОТСЕКА]
11518341 БОЛТ, HEX, M10X1.5X25, 14 THD, 28 OD, 6202M, 7114M, TAP, TR-PT (ENG SHLD) [БОЛТ М10Х1.5Х25]
(TC00-902) - 2009 CK1,2,3 INTAKE MANIFOLD SHIELD/COVERS (LY6/6.0K,L76/6.0Y,L9H/6.2-2)
15943789 SHIELD, UPR INT MANIF SIGHT (INCLS 2) [ЗАЩИТА]
19167507 GROMMET, UPR INT MANIF SIGHT SHLD (PART OF 1) (3.407)
11609319 STUD, UPR INT MANIF SIGHT SHLD (3.671)
11516075 ГАЙКА, HFH SELF LK, M6X1, 7.7THK, 14.2 O.D., 9, PZOR (UPR INT MANIF CVR) [ГАЙКА ВЫПУСКНОЙ СИСТЕМЫ D=6ММ]
12610052 COVER, UPR INT MANIF (INCLS 6)
12559065 GROMMET, UPR INT MANIF SIGHT SHLD (PART OF 5) (12.0 DIA X 2.4 DEEP)
15858430 RETAINER, UPR INT MANIF SIGHT SHLD (INCLS 8)
11514623 БОЛТ, HEX W/CON WA, M6X1X20 (UPR INT MANIF SIGHT SHLD)
(TC00-908) - 2009 CK1 ДВИГАТЕЛЬ В СБОРЕ & PARTIAL ДВИГАТЕЛЬ (L9H/6.2-2)
teamcadillac.ru
19210971 ДВИГАТЕЛЬ, GASOLINE (GOODWRENCH NEW)
(TC00-910) - 2009 K1 ДВИГАТЕЛЬ & КРЕПЛЕНИЕ ТРАНСМИССИИ-V8 (L76/6.0Y,L9H/6.2-2)
15854939 MOUNT, ENG [ОПОРНЫЙ УЗЕЛ ДВИГАТЕЛЯ]
11517639 БОЛТ, ENG MT SUPT (TO FRAME BRKT) (12X1.75X44, 35THD) (4.665) [БОЛТ М10]
11609475 БОЛТ, HFH W/CON SPR WA, M10X1.5X33, 24 THD, 22.3 OD, 10.9, GMW3359 (ENG MT) [БОЛТ М10]
teamcadillac.ru
15840278 MOUNT, TRANS [ОПОРНЫЙ УЗЕЛ КПП]
11517827 БОЛТ, HFH W/FL WA, M10X1.5X35, 20 THD, 25 OD, 9.8, 7114M, MACH, P-PT, 6175M A (TRANS MT) [БОЛТ М10]
11516754 ГАЙКА, HEX, W/CON SPR WA, M10X1.5, 10THK, 28 O.D., 10, 7111M (TRANS MT) [ГАЙКА М10]
(TX00-057) - 2009 CK1 ДВИГАТЕЛЬ В СБОРЕ-6.2L V8 ЧАСТЬ 2 ГОЛОВКА ЦИЛИНДРОВ & СОПРЯЖЕННЫЕ ДЕТАЛИ (L9H/6.2-2)
17122490 LIFTER, VLV (HYD, ROLLER, NON-ACTIVE FUEL MANAGEMENT LIFTER) (ACDelco #HL124) [ТОЛКАТЕЛЬ КЛАПАНА]
12595365 GUIDE, VLV LFTR (ACCOMMODATES 4 VLV LFTRS EACH, WITH SIDE GROOVES) [НАПРАВЛЯЮЩАЯ КЛАПАНА ДВИГАТЕЛЯ]
12551163 БОЛТ, VLV LFTR GDE (M6X1.0X19)
10238852 ROD, VLV PUSH [НАПРАВЛЯЮЩАЯ МАСЛООТРАЖАТЕЛЯ]
10214664 ARM, VLV RKR (ARM, VLV RKR EXH. FOR INTKE VLV RKR ARM SEE PN 12569167, QTY 8) [КОРОМЫСЛО КЛАПАНА ДВИГАТЕЛЯ]
12560961 БОЛТ, VLV RKR ARM PIV SUPT (M8X1.25X52.5)
12600936 SUPPORT, VLV RKR ARM PIV
teamcadillac.ru
12610046 GASKET, CYL HD [ПРОКЛАДКА ГОЛОВКИ ЦИЛИНДРОВ]
12615361 HEAD, CYL
11571134 БОЛТ, CYL HD (M11X2X100)
12558840 БОЛТ, CYL HD (M8X1.25X45) [БОЛТ М8Х1.25Х45]
12482062 SEAL KIT, EXH VLV STEM OIL (22.8MM) (INCLS 8 SEALS) [КОМПЛЕКТ ПРОКЛАДОК ГОЛОВКИ ЦИЛИНДРОВ (8 ШТ)]
12482063 SEAL KIT, INT VLV STEM OIL (W/ПРУЖИНА SHIM) (14.4MM) (INCLS 8 SEALS) [КОМПЛЕКТ ПРОКЛАДОК ГОЛОВКИ ЦИЛИНДРОВ (8 ШТ)]
12589774 ПРУЖИНА, VLV [ПРУЖИНА КЛАПАНА]
10166344 CAP, VLV SPR [СЕДЛО ПРУЖИНЫ КЛАПАНА ДВИГАТЕЛЯ]
10166345 KEY, VLV STEM
12582719 VALVE, EXH (STD) [КЛАПАН]
11610259 PLUG, CYL HD CORE HOLE (M12X1.5X21.2)
24100002 SEAL, OIL FIL TUBE (O RING) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА]
12609624 TUBE, OIL FIL
12573337 CAP, OIL FIL (SAE 5W30, NON-VENTED, SEAL) (INCLS 450) (ACDelco #FC208)
12577268 CAP, OIL FIL (MOBIL 1, SAE 5W30, NON-VENTED, W/SEAL) (INCLS 450) (ACDelco #FC209)
24100002 SEAL, OIL FIL CAP (O RING) (PART OF 424) (27.94MM I.D.) (SIZE #320) (1.745) [ПРОКЛАДКА]
12612045 GASKET, VLV RKR ARM CVR (PART OF 505) [ПРОКЛАДКА КЛАПАННОЙ КРЫШКИ]
12607721 COVER, VLV RKR ARM (INCLS 504, 515, 516, 900)
12607722 COVER, VLV RKR ARM (INCLS 504, 515, 516) (INCLS COVER, GASKET, BOLT, CONNECTOR, BAFFLE, CAP)
12577215 БОЛТ, VLV RKR ARM CVR (INCLS 515) (PART OF 505) (M6.0X1.0) (W/GROMMET, SLEEVE)
12609373 TUBE, PCV (FRESH AIR)
12597774 TUBE, PCV (DIRTY AIR) (INCLS 903)
12554211 STUD, IGN COIL BRKT (HFH, M6X1X18) (3.330) (ACDelco #12554211)
19206446 WIRE, SPLG (*KIT1)
12608814 SENSOR, ENG COOL TEMP (ACDelco #213-4333)
12609877 СВЕЧА, (GAP 0.040) (ACDelco #41-985) (IRIDIUM)
12597772 FITTING, PCV (PART OF 505)
15336959 SHIELD, SPLG WIRE (ACDelco #8006)
12569167 ARM, INT VLV RKR (OFFSET INLET ROCKER ARM) (ARM, VLV RKR INT. FOR EXHST VLV RKR ARM SEE PN 10214664, QTY=8)
19206447 WIRE KIT, SPLG (INCLS 724) (INCLS SET OF 8 LEADS) (ACDelco #748UU)
(TX00-062) - 2009 CK1 ДВИГАТЕЛЬ В СБОРЕ-6.2L V8 ЧАСТЬ 5 MANIFOLD & FUEL СОПРЯЖЕННЫЕ ДЕТАЛИ (L9H/6.2-2)
12597600 MANIFOLD, INT
11518075 БОЛТ, HFH, THD 22, OD 17, 8.8, GMW14C-PT, HDR POINT (PART OF 555) [ВИНТ М10]
12601387 BODY, THROT (ACDelco #217-3151)
12589235 SEAL, THROT BODY (ACDelco #217-2424) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ДРОССЕЛЬНОЙ ЗАСЛОНКИ]
12580910 БОЛТ, F/INJR DRVR MDL
12575384 БОЛТ, INT MANIF
89060434 GASKET, INT MANIF [ПРОКЛАДКА ВЫПУСКНОГО КОЛЛЕКТОРА (2ШТ)]
12574886 SEAL, ENG BLK VALLEY CVR HIGH PRESS PORT (PART OF 555)
12598832 COVER, ENG BLK VALLEY (INCLS 506, 537, 556) (INCLS COVER, BOLTS, GASKET, SEAL)
12610141 GASKET, ENG BLK VALLEY CVR (PART OF 555) [ПРОКЛАДКА БЛОКА ЦИЛИНДРОВ]
12593801 BRACKET, F/INJN FUEL RL
12616285 MANIFOLD, EXH (INCLS 603, 604) (INCLS SHIELD, BOLTS) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ]
12616286 MANIFOLD, EXH (INCLS 603, 604) (INCLS SHIELD, BOLTS) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ]
12617944 GASKET, EXH MANIF [ПРОКЛАДКА ВЫПУСКНОГО КОЛЛЕКТОРА]
teamcadillac.ru
11518860 БОЛТ, HFH, M8X1.25X30, 20.9 THD, 18 O.D., 10.9, GMW3179 CODE G, GM6194M (EXH MANIF FLG) [БОЛТ]
12562243 SHIELD, EXH MANIF HT (PART OF 600)
12562244 SHIELD, EXH MANIF HT (PART OF 600)
11515754 БОЛТ, HVY HEX HD, M8X1.25X12, 18 O.D., 10.9, ZE (PART OF 600)
12621234 SENSOR, ENG OIL PRESS (ACDelco #213-4411)
12578463 STOP, F/INJN FUEL RL
11515764 БОЛТ, HFH, M10X1.5X20, 18THD, 22.3 O.D., 10.9, 7114M (F/INJN FUEL RL STOP)
12594942 SENSOR, MAP (INCLS 715) (ACDelco #213-3949) [ДАТЧИК ДАВЛЕНИЯ ВОЗДУХА ВО ВПУСКНОМ КОЛЛЕКТОРЕ]
12574897 HARNESS, EVAP EMIS CNSTR
12606684 VALVE, EVAP EMIS CNSTR PURGE SOL (ACDelco #214-2142) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ]
12617169 TUBE, EVAP EMIS CNSTR PURGE
89017591 BOLT KIT, THROT BODY (INCLS 507, 538, 901) (INCLS BOLT, STUD, NUT)
(TX00-151) - 2009 CK1,2(06-36) TRANSMISSION CONVERTER SHIELDS (MYC,MYD,M30)
12561536 COVER, TRANS (ACDelco #12561536)
12560226 БОЛТ, HEX W/FLAT WASH, M6.0X1.0X14.5, 13.5, 17 OD, 9.8, 7114M, MACH (TRANS CVR)
11589040 БОЛТ, TRANS T/CV [БОЛТ М10]
11515768 БОЛТ, HFH, REDUCED BODY, M10X1.5X40, 30THD, 22.3 O.D., HDR PT, 10.9, 7114M (TRANS) [БОЛТ М10Х1.5Х40]
11519797 STUD, TRANS (DOUBLE END, HFH, M8X1.25X20, M10X1.5X40, 18 OD, 69.5 TL9.8, GMW3359)
24205899 PLUG, T/CV HSG ACC HOLE (28MM W/3 TANGS) (SMALL CVR) (ACDelco #24205899)
24205900 COVER, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП]
teamcadillac.ru
12561303 COVER, TRANS (ACDelco #12561303)
(TC01-679) - 2008-2009 CK107(06) CONTROL MODULE ОХЛАЖДАЮЩАЯ СИСТЕМА-КРЕПЛЕНИЕ РАДИАТОРА (HYBRID HP2)
25880374 HOSE, GEN CONT MDL COOL TK (СМ. ГРУППУ 01.000 "CONTROL MODULE ОХЛАЖДАЮЩАЯ СИСТЕМА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS 2)
teamcadillac.ru
11517136 CLAMP, HOSE SPR, 27 NOM, 25.2 MIN-28.9 MAX, 15MM WIDE, BLACK (PART OF 1)
11516931 БОЛТ, FLAT WA & METRIC HEX HD MACHINE, M8X1.25X50 (RAD UPR MT)
15012561 CLAMP, HOSE SPR, 27 NOM, 25.2 MIN-28.9 MAX, 15MM WIDE, BLACK (PART OF 7) (8.948)
24205103 RETAINER, TRANS FLUID CLR PIPE FTG (PART OF 3, 9) (EXPANDING ПРУЖИНА WIRE) (ACDelco #24205103) [СТОПОРНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ]
(TC01-902) - 2008-2009 CK1(06) РЕШЕТКА РАДИАТОРА (G.M.C. Z88, DENALI Y91, EXC HYBRID HP2)
11561788 CLIP-U, 13X15X12, 1.5 PNL, 1050, 6280M (PART OF 1) [ФИКСАТОР МОЛДИНГА КАПОТА]
11518121 ГАЙКА, U, M6X1, MULTI THD, .5'-4.0' THK PNL (RAD GRL UPR BRKT)
10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (FRT TOW HOOK) [ПИСТОН КРЕПЛЕНИЯ ОБЛИЦОВКИ БАМПЕРА (NYLON)]
15264513 GRILLE, RAD LWR (INCLS 6) (CHROME)
11515638 ГАЙКА, U-TYPE, M4.2X1.41X10.5.5X22, .65-3.8 PNL THK, 1050, ZF (RAD GRL) [ГАЙКА М4.2]
11609465 БОЛТ, HWH, M4.2X1.41X18, 12.5 OD, 6010M, PS (RAD GRL) (8.977) [ВИНТ М6]
25891152 GRILLE, RAD UPR (CHROME) (IF GRILLE ON FASCIA IS RIVETED;DRILL OUT RIVET HOLES ON FASCIA TO 8.835MM & ATTACH GRILLE TO FASCIA W/2 U-NUTS 11515638 & 2 BOLTS 11589015)
teamcadillac.ru
11610055 БОЛТ, HWASH, M6X1X23 (FRT BPR UPR FASCIA)
(TC01-903) - 2008-2009 CK1(06-36) РЕШЕТКА РАДИАТОРА (CADILLAC Z75, EXC PLATINUM EDITION ULT)
25705182 БОЛТ, FRT BPR FASCIA CTR SUPT (M9.5X6.0 HI-LO, TL 47MM, 22 OD) (12.249) [ВИНТ М5]
25795238 GRILLE, RAD (INCLS 1-4, 8) (BLUE) [РЕШЕТКА РАДИАТОРА]
25795240 GRILLE, RAD (INCLS 1-4, 8) (WHITE) [РЕШЕТКА РАДИАТОРА]
25795242 GRILLE, RAD (INCLS 1-4, 8) (BLACK)
25795243 GRILLE, RAD (INCLS 1-4, 8) (GOLD) [РЕШЕТКА РАДИАТОРА]
teamcadillac.ru
25795244 GRILLE, RAD (INCLS 1-4, 8) (SILVER) [РЕШЕТКА РАДИАТОРА]
25795245 GRILLE, RAD (INCLS 1-4, 8) (RED JEWEL) [РЕШЕТКА РАДИАТОРА]
25840444 GRILLE, RAD (INCLS 1-4, 8) (GRAY) [РЕШЕТКА РАДИАТОРА]
25840445 GRILLE, RAD (INCLS 1-4, 8) (SONOMA JEWEL)
25841844 GRILLE, RAD (INCLS 1-4, 8)
25878072 GRILLE, RAD (INCLS 1-4, 8) (BRAHMA) [РЕШЕТКА РАДИАТОРА]
20824266 EMBLEM, RAD GRL (PART OF 7) (BUILT 01/12/09 & AFTER) (FOR 1ST DES SEE 25795247)
25795247 EMBLEM, RAD GRL (PART OF 7) (WREATH/CREST) (BUILT PRIOR TO 01/12/09) (FOR 2ND DES SEE 20824266) [ЭМБЛЕМА РЕШЕТКИ РАДИАТОРА]
15907251 MOLDING, КАПОТ FRT (INCLS 10) [МОЛДИНГ КАПОТА]
11610051 RETAINER, КАПОТ FRT MLDG (PART OF 9)
(TC01-905) - 2009 CK1(06-36) КРЕПЛЕНИЕ РАДИАТОРА & СОПРЯЖЕННЫЕ ДЕТАЛИ (CADILLAC Z75, L9H/6.2-8)
15780790 INSULATOR, ENG COOL FAN SHRD (UPPER) [ДЕМПФЕР РАДИАТОРА]
11516931 БОЛТ, FLAT WA & METRIC HEX HD MACHINE, M8X1.25X50 (ENG COOL FAN)
15780791 INSULATOR, ENG COOL FAN SHRD (LOWER) [ДЕМПФЕР РАДИАТОРА]
89019121 MOUNT, RAD LWR (PART OF 7)
10392941 BAFFLE, RAD SUPT
19130464 STRAP, TIE 0.38" WIDTH, BUNDLE DIA 1/16"-1-3/4", 8.27" LENGTH, NYLON 6/6 FITS 0. (WRG HARN) [ХОМУТ (ЗАЖИМ) РАДИАТОРА]
15958694 RETAINER, RAD SUPT BFL (1LH/4RH) (BLACK) (7.6DIA X 22.9 MM) (X-MAS TREE) (FOR HOLE 6.30-6.55 DIA) (16.850) [ФИКСАТОР МОЛДИНГА КУЗОВА]
15208497 BAFFLE, RAD AIR (INCLS 12)
15837581 CUSHION, BODY BOLT UPR FRT (VIOLET) (1.270) [ДЕМПФЕР РАДИАТОРА]
15201791 CUSHION, BODY BOLT LWR FRT (71MM OD)
03537772 ГАЙКА, M12X1.75, 10.6THK, 28 O.D., 10, 7111M (BODY MT) (8.917)
teamcadillac.ru
11562547 БОЛТ, HFH, M12X1.75X135, 100 THD, 24.7 OD, GMW25 (10.9) STL, GM 7112M, MACH (BODY MT)
15208496 BAFFLE, RAD AIR (INCLS 12)
10392942 BAFFLE, RAD SUPT
11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (PART OF 23) [ШАЙБА]
11610055 БОЛТ, HWASH, M6X1X23 (RAD GRL SUPT REINF)
15904442 BRACKET, RAD GRL UPR (INCLS 21, 24) [ПОПЕРЕЧНАЯ ПАНЕЛЬ КУЗОВА]
22581725 CLIP, КАПОТ PRIM LAT REL CBL (PART OF 23) (7.0 MM DIA) (HOLDS (1) PIPE 4.76 TO 6.35) (3.145) [ФИКСАТОР ТОРМОЗНОЙ ТРУБКИ]
25814523 BAFFLE, RAD AIR UPR (INCLS 27) [ОБТЕКАТЕЛЬ РАДИАТОРА]
25861241 BAFFLE, RAD AIR UPR (INCLS 27) (INCLS LABEL) [ОБТЕКАТЕЛЬ РАДИАТОРА]
11561878 RETAINER, PUSH PIN W/SEAL, FITS 8.0-8.25 DIA HOLE IN 3-7MM THK PNL (RAD AIR UPR BFL (PUSH IN)) [ФИКСАТОР ОПОРЫ БЛОКА УПРАВЛЕНИЯ]
11562546 WASHER, FLAT, 14X42.5X3.61 MM, SAE 1050 STL RC 37-43, 7112M (BODY MT)
(TC01-907) - 2007-2009 CK1(06-36) КРЕПЛЕНИЕ РАДИАТОРА В СБОРЕ
25955528 SUPPORT, RAD (INCLS 2-10)
25955529 SUPPORT, RAD (INCLS 2-10) [ПЕРЕДНЯЯ ПАНЕЛЬ КУЗОВА]
11561916 NUT-INSERT, M8X1.25, 13.5 HOLE, 0.7-3.8 GRIP, 24 LONG, 17.4 OD, 1008, GMW (PART OF 1, 3)
25870919 SUPPORT, F/END UPR TIE BAR (INCLS 2, 4, 6) (PART OF 1) [ПОПЕРЕЧНАЯ БАЛКА КУЗОВА]
11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (PART OF 1, 9) [БОЛТ М6]
11561407 NUT-INSERT , M6X1, 10MM HOLE, 1.7-5.25 PANEL, 19 LONG, 12.9 OD, 1008, GMW3 (PART OF 1, 3, 9) (8.921)
11516932 БОЛТ, HEX HD, W/CON WA, M6X1X25, 9.8, 6138M (PART OF 1)
teamcadillac.ru
15744933 БОЛТ, HEX HD, W/CON WA, M6X1X45 (PART OF 1) (1.267)
25870915 BRACE, F/END SH MET RAD OPG (INCLS 5, 6, 10) (PART OF 1)
25870916 BRACE, F/END SH MET RAD OPG (INCLS 5, 6, 10) (PART OF 1)
25870918 BRACE, F/END SH MET CR (PART OF 1, 9)
(TC01-909) - 2007-2009 CK1 SKID PLATE/МАСЛЯНЫЙ ПОДДОН(NZZ)
15843753 PLATE, МАСЛЯНЫЙ ПОДДОН SKID
teamcadillac.ru
11518341 БОЛТ, HEX, M10X1.5X25, 14 THD, 28 OD, 6202M, 7114M, TAP, TR-PT (МАСЛЯНЫЙ ПОДДОН SKID PLT) [БОЛТ М10Х1.5Х25]
(TC01-912) - 2009 CK1(06-36) ВЕНТИЛЯТОР ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ (CADILLAC Z75, L9H/6.2-2)
15780790 INSULATOR, ENG COOL FAN SHRD (PART OF 5) (UPPER) [ДЕМПФЕР РАДИАТОРА]
10309116 LABEL, FAN BLADE WRNG (PART OF 5) (BLACK NYLON)
11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (PART OF 5) [ШАЙБА]
15780788 SHROUD KIT, ENG COOLING FAN (INCLS 1, 2, 4, 6, 7, 12) (5/7 FAN BLADES) [ОБТЕКАТЕЛЬ РАДИАТОРА]
15780789 SHROUD KIT, ENG COOLING FAN (INCLS 1, 2, 4, 6, 7, 12) (7/9 FAN BLADES) [ОБТЕКАТЕЛЬ РАДИАТОРА]
15780791 INSULATOR, ENG COOL FAN SHRD (PART OF 5) (LOWER) [ДЕМПФЕР РАДИАТОРА]
teamcadillac.ru
15780792 SPACER, ENG COOL FAN SHRD (PART OF 5)
15780795 MOTOR KIT, ENG CLG FAN (INCLS 12) (700 WATT) (ACDelco #15-80880)
15780796 MOTOR KIT, ENG CLG FAN (INCLS 12) (700 WATT) (ACDelco #15-80881) [ЭЛ.ДВИГАТЕЛЬ ВЕНТИЛЯТОРА РАДИАТОРА, 70ВТ]
22728347 БОЛТ, ENG COOL FAN SHRD
15780794 BLADE KIT, ENG CLG FAN (9-BLADE) (INCLS 12) (ACDelco #15-80883)
22722593 CLIP, ENG COOL FAN SHRD (PART OF 5, 8, 9, 11, 13)
15780793 BLADE KIT, ENG CLG FAN (7-BLADE) (INCLS 12) (ACDelco #15-80882) [ВЕНТИЛЯТОР РАДИАТОРА, 90ВТ]
(TC01-913) - 2009 CK1,2,3 ТРУБКИ РАДИАТОРА (LY6/6.0K,L76/6.0Y,L9H/6.2-2)
15833723 TANK, RAD SURGE (ACDelco #15833723) [РАСШИРИТЕЛЬНЫЙ БАЧОК СИСТЕМЫ ОХЛАЖДЕНИЯ]
15012559 CLAMP, SPR (18.4MM TO 21.6MM) NOMINAL SIZE 20MM, STAMPED "20" (RAD SURGE TK INL HOSE) (1.240)
15834774 HOSE, RAD SURGE TK INL
25976471 HOSE, RAD VENT INL
15734742 CLAMP, RAD SURGE TK ENG HOSE (13-16MM DIA RANGE)
15041309 CLIP, RAD VENT INL HOSE
15004599 CLAMP, RAD SURGE TK ENG HOSE (BLACK) (15MM OD 17.2MM) [ХОМУТ ТРУБОПРОВОДА]
19130015 HOSE, RAD OTLT [ШЛАНГ РАДИАТОРА]
11562099 CLAMP-ПРУЖИНАBAND, NOMINAL DIA 49MM, 20 WIDTH, MAT'L 6298M, ROBO FINISH (RAD OTLT HOSE RAD) [ХОМУТ ШЛАНГА СИСТЕМЫ ОХЛАЖДЕНИЯ]
15045503 CLIP, RAD SURGE TK INL HOSE (PART OF 13) (CLIP TO HOLD 37-44 DIA HOSE AND 12.8-15 DIA VENT HOSE) (1.166)
25976470 HOSE, RAD INL (INCLS 11, 12)
11518559 CLAMP, ПРУЖИНАBAND, 42MM NOMINAL DIA, 20 WIDTH, 6298M, 6164M (RAD INL HOSE) [ХОМУТ ШЛАНГА РАДИАТОРА]
teamcadillac.ru
11517136 CLAMP, HOSE SPR, 27 NOM, 25.2 MIN-28.9 MAX, 15MM WIDE, BLACK (RAD SURGE TK OTLT HOSE)
15834772 HOSE, RAD SURGE TK OTLT
15834773 HOSE, RAD SURGE TK OTLT
15012561 CLAMP, HOSE SPR, 27 NOM, 25.2 MIN-28.9 MAX, 15MM WIDE, BLACK (RAD SURGE TK OTLT HOSE) (8.948)
11609982 БОЛТ, RAD SURGE TK (6 X 1 X 22) (8.900)
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (RAD SURGE TK) [ГАЙКА М6]
15075118 CAP, RAD SURGE TK (15 PSI DUAL O-RING) (ENGLISH/FRENCH LABEL) (ACDelco #RC98) [КРЫШКА БАЧКА РАДИАТОРА]
(TC01-915) - 2009 CK1 ПОДОГРЕВАТЕЛЬ БЛОКА ДВИГАТЕЛЯ (LC9/5.3-3,LFA/6.0-5,LH6/5.3M,L76/6.0Y,L9H/6.2-2)
teamcadillac.ru
15801282 CORD, ENG COOL HTR
11610073 БОЛТ, ENG COOL HTR CORD CLIP (M8X1.25X16, 12.45THD) (13MM SOCKET) (8.900)
(TC01-918) - 2009 CK1 РАДИАТОР В СБОРЕ (LC9/5.3-3,LH6/5.3M,LMG/5.3-0,LY2/4.8C,LY5/5.3J,L9H/6.2-2)
15841571 RADIATOR, (CORE SIZE 34IN X 18 1/2IN X 1 1/8IN, CODE APC, ASA, ATS) (INCLS 2-5) (ACDelco #21650) [РАДИАТОР]
teamcadillac.ru
25811504 RADIATOR, (CORE SIZE 34IN X 17 1/4IN X 1 1/8IN, CODE ATR, TRANS OIL CLR) (INCLS 2-5) (ACDelco #21649)
15226661 CONNECTOR, TRANS FLUID CLR PIPE (PART OF 1) (INCLS 4) (9/16-18) (3/8 BODY QUICK CONNECT) (AT RAD) (ACDelco #15226661)
19210848 CONNECTOR, TRANS FLUID CLR PIPE (PART OF 1) (INCLS 4) (W/O BEVEL WASHER) (ACDelco #19210848)
24205103 RETAINER, TRANS FLUID CLR PIPE FTG (PART OF 1, 3) (EXPANDING ПРУЖИНА WIRE) (ACDelco #24205103) [СТОПОРНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ]
89019121 MOUNT, RAD LWR (PART OF 1)
(TC01-946) - 2008-2009 CK1(06) РЕШЕТКА РАДИАТОРА (CADILLAC Z75, PLATINUM EDITION ULT)
25957701 GRILLE, RAD UPR (INCLS 4, 7) (SILVER) [РЕШЕТКА РАДИАТОРА]
11515638 ГАЙКА, U-TYPE, M4.2X1.41X10.5.5X22, .65-3.8 PNL THK, 1050, ZF (RAD UPR GRL) [ГАЙКА М4.2]
22549046 SCREW, M4.2X1.4X25, 11.1 O.D., 6010M, NZ (PART OF 1)
teamcadillac.ru
11589039 БОЛТ, HEX, W/CON WA, M6X1X30, 20 THD, 24 O.D., 9.8, GMW4205 (RAD GRL SUPT REINF) [БОЛТ М6Х1Х30]
25957702 GRILLE, RAD LWR (SILVER)
15126354 EMBLEM, RAD GRL (PART OF 1) (MEDALLION) (BUILT PRIOR TO 01/12/09) (FOR 2ND DES SEE 20824267) [ЭМБЛЕМА РЕШЕТКИ РАДИАТОРА]
20824267 EMBLEM, RAD GRL (PART OF 1) (BUILT 01/12/09 & AFTER) (FOR 1ST DES SEE 15126354)
(TS01-555) - 2009 CK1 НАТЯЖИТЕЛЬ РЕМНЯ/ACCESSORY DRIVE (LC9/5.3-3,LMG/5.3-0,LY2/4.8C,LY5/5.3J,L76/6.0Y,LH6/5.3M,L9H/6.2-2)
teamcadillac.ru
12609719 РОЛИК НАТЯЖИТЕЛЬ, DRV BELT (2 BOLT DESIGN REPLACES 3 BOLT DESIGN) [ШКИВ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ]
12580771 PULLEY, BELT IDLER (INCLS 3) (SMOOTH CODE 5609, 0771) [НАБОР ШКИФОВ]
19178068 BELT, A/C CMPR
(GM02-126) - 2009 CK1,2,3 COIL & MODULE/IGNITION (MELCO)(LY6/6.0K,L76/6.0Y,L9H/6.2-2)
11516424 БОЛТ, HFH, M6X1X25, 14.2 O.D., HDR PT, 9.8, ZE (IGN COIL) [БОЛТ М6]
12611424 COIL, IGN (MELCO-MITSUBISHI) (W/SQUARE-SHAPED COILS AND MARKED 12570616) (ACDelco #D510C)
12580353 BRACKET, IGN COIL (ACDelco #12580353)
teamcadillac.ru
12579355 WIRE, IGN COIL (INCLS:CONNECTORS) (ACDelco #357A)
(GM02-127) - 2009 CK1,2,3 COIL & MODULE/IGNITION (DELPHI)(LY6/6.0K,L76/6.0Y,L9H/6.2-2)
11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (IGN COIL)
teamcadillac.ru
(GM02-129) - 2007-2009 CK1,2,3 КЛЮЧ И ЦИЛИНДР ЗАМКА/ЗАЖИГАНИЕ
15794826 CYLINDER KIT, IGN LK (INCLS 1, 2, 3) [ЦИЛИНДР]
teamcadillac.ru
15926907 КЛЮЧ, ЗАЖИГАНИЯ LK (PRE-CUT & PROGRAMMED)
15926908 КЛЮЧ, ЗАЖИГАНИЯ LK (PRE-CUT & PRE-PROGRAMED FOR FLEET)
25865394 КЛЮЧ, ЗАЖИГАНИЯ (UNCODED) (MASTER)
25945699 КЛЮЧ, DR LK & IGN LK
(GM02-133) - 2009 CK1,2,3 ВЫСОКОВОЛЬТНЫЕ ПРОВОДА (LY6/6.0K,L76/6.0Y,L9H/6.2-2)
19206447 WIRE KIT, SPLG (INCLS 1) (INCLS SET OF 8 LEADS) (ACDelco #748UU)
(TC02-212) - 2009 CK1(06-36) ПЕРЕДНИЕ ФАРЫ (CADILLAC Z75, L.E.D. HEADLAMP T4Q)
25999509 HEADLAMP, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 7-9) (2.725)
25999510 HEADLAMP, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 7-9) (2.725)
11589039 БОЛТ, HEX, W/CON WA, M6X1X30, 20 THD, 24 O.D., 9.8, GMW4205 (HDLP HSG) [БОЛТ М6Х1Х30]
teamcadillac.ru
11610055 БОЛТ, HWASH, M6X1X23 (HDLP HSG PNL)
15874642 SUPPORT, HDLP HSG [ОПОРА ПЕРЕДНИХ ФАР]
(TC02-213) - 2009 CK107(06) ЖГУТЫ ПРОВОДОВ/CHASSIS (HYBRID HP2, MAGNERIDE Z95)
20790105 HARNESS, CHAS WRG (INCLS 2, 13)
20790106 HARNESS, CHAS WRG (INCLS 2, 13)
20793159 HARNESS, CHAS WRG (INCLS 2, 13)
19115819 TUBE, RR S/ABS AIR (PART OF 1) [ТРУБКА ТОРМОЗНОЙ СИСТЕМЫ]
12191503 RECEPTACLE, TOW VEH ELEC (W/DOOR) [ОПОРА КОНТАКТНОГО РАЗЪЕМА ТРЕЙЛЕРНОЙ СЦЕПКИ]
11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (TRLR WRG HARN GND) [БОЛТ М8]
teamcadillac.ru
11588833 PUSH IN-PLASTIC TREE, DIA 8.6, LENGTH 21.2, NYLON GMP.PA66.063, BLACK (CHAS RR WRG HARN) [ФИКСАТОР НАКЛАДКИ ПОРОГА КУЗОВА]
15045897 BRACKET, CHAS FRT WRG HARN (FRT OF DASH)
21011332 ГАЙКА, HEX STAMPED TY DF FLG 14 (CHAS FRT WRG HARN BRKT) (8.921)
11609412 ГАЙКА, CHAS RR WRG HARN J/BLK LEAD (HEX W/CON WA, M8X1.25, 7.5 THK, 19 OD, 10 STL, GMW3200) (8.917) [ГАЙКА М8]
12177233 RELAY, AUTO LVL CONT (5-WAY MALE, BLACK, CODE 7233) (PART OF 1) (SHROUDED) (W/RESISTOR) (SPDT 280 MINI) (FOR 4-TERM APP CUT OFF CENTER TERM LABELED 87A) (9.277) (ACDelco #15-8721)
(TC02-603) - 2009 CK1 КРЕПЛЕНИЕ ГЕНЕРАТОРА (LC9/5.3-3,LH6/5.3M,LMG/5.3-0,LY2/4.8C,LY5/5.3J,L76/6.0Y,L9H/6.2-2)
25869451 GENERATOR, (STAMPED 'FJ' OR 'FB' OR 'JD') (ACDelco #25869451)
25877026 GENERATOR, (ACDelco #25877026) [ГЕНЕРАТОР 160А]
12554030 BRACKET, GEN & P/S PUMP (INCLS 5) (INCLS SPACER)
teamcadillac.ru
11516744 BOLT-HFH, M10X1.5X110, 26 THD, 22.3 OD, 9.8, 7114M (GEN & P/S PUMP BRKT)
11516360 БОЛТ, HFH M10X1.2X90, 9.8, 7114M, 22.3 OD HDR PT (GEN)
12550090 SPACER, GEN & P/S PUMP BRKT (PART OF 2) [ВТУЛКА ГЕНЕРАТОРА]
(TC02-896) - 2009 CK1(06) БОКОВЫЕ ДАТЧИКИ ПАРКОВКИ (UFT)
25820974 BRACKET, SIDE OBJECT SEN (INNER)
25820975 BRACKET, SIDE OBJECT SEN (INNER)
11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (SIDE OBJECT SEN) [ВИНТ М4]
20823460 SENSOR, SIDE OBJECT (LABELED 20823460)
teamcadillac.ru
25910830 SENSOR, SIDE OBJECT
25978649 SENSOR, SIDE OBJECT (LABELED 25978649)
15941140 BRACKET, SIDE OBJECT SEN (OUTER)
15941274 BRACKET, SIDE OBJECT SEN (OUTER)
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (SIDE OBJECT SEN) [ГАЙКА М6]
11513599 ГАЙКА, U-TYPE, M4.2X1.41, 0.65-3.80 PNL THK, PZ (SIDE OBJECT SEN) (ACDelco #11513599)
21030249 RETAINER, EXPAN, 21 LG, 20. OD, 8.0 HOLE, 3.0-5.0 PNL, NYLON 6/6, BLK (SIDE OBJECT SENSING ALERT MDL) (8.950) (PUSH IN) [ПИСТОН КРЕПЛЕНИЯ КОЖУХА РАДИАТОРА(ПЛАСТИК)]
(TC02-899) - 2008-2009 CK107(06) ЖГУТЫ ПРОВОДОВ/CHASSIS GROUND STRAPS (HYBRID HP2)
25866712 STRAP, BODY GND (LABELED 25866712 OR 25829707)
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BODY GND STRP) [ГАЙКА М6]
12337820 STRAP, 15" TIE STRAP (ACSRY WRG HARN) (ACDelco #12337820)
25866711 STRAP, R/AXLE WRG HARN
teamcadillac.ru
11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (RR BRK HOSE) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16]
(TC02-902) - 2009 CK1(06-36) ПЕРЕДНИЕ ФАРЫ (CADILLAC Z75, EXC L.E.D. HEADLAMP T4Q)
15874643 SUPPORT, HDLP HSG [ОПОРА ПЕРЕДНИХ ФАР]
15789983 HARNESS, FRT FOG LP WRG HARN EXTN
01999367 BULB, FRT T/SIG LP (PART OF 8) (TRADE 3757AK) (8.991) (ACDelco #3757A)
10351663 BULB, FRT T/SIG LP (PART OF 8) (AMBER) (TRADE 3457NAK) (2.880) (ACDelco #10351663) [ЛАМПОЧКА СИГНАЛА ПОВОРОТА, 21 ВТ]
10346260 BULB, FRT FOG LP (PART OF 8) (TRADE 9145) (ACDelco #9145) [ЛАМПА НАКАЛИВАНИЯ]
10383562 LAMP, FRT FOG (INCLS 5-7) [ПРОТИВОТУМАННАЯ ФАРА]
10383563 LAMP, FRT FOG (INCLS 5-7) [ЛАМПА]
25779062 LAMP, FRT FOG (INCLS 5-7) [ПРОТИВОТУМАННАЯ ФАРА]
25779063 LAMP, FRT FOG (INCLS 5-7) [ПРОТИВОТУМАННАЯ ФАРА]
25897646 HEADLAMP, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 12-20) (2.725) [ПЕРЕДНЯЯ ФАРА]
25897647 HEADLAMP, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 12-20) (2.725) [ПЕРЕДНЯЯ ФАРА]
25897648 HEADLAMP, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 10-20) (2.725) [ПЕРЕДНЯЯ ФАРА]
25897649 HEADLAMP, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 10-20) (2.725) [ПЕРЕДНЯЯ ФАРА]
11561804 БОЛТ, HDLP BULB BALLAST (PART OF 9)
15782392 BALLAST, HDLP (PART OF 9)
15816281 ADAPTER, HDLP BULB (PART OF 9)
15862954 ADAPTER, HDLP BULB (PART OF 9) [КОЖУХ ГАЗОРАЗРЯДНОЙ ЛАМПЫ]
15825994 BULB, HDLP (PART OF 9) (ACDelco #15825994) [ЛАМПОЧКА ПЕРЕДНЕЙ ФАРЫ (12В, 55ВТ)]
25735603 BULB, HDLP (PART OF 9) (TRADE #D1S) (ACDelco #D1S) [ЛАМПОЧКА ПЕРЕДНЕЙ ФАРЫ 50 ВТ]
25735604 BULB, HDLP (PART OF 9) (W/IGNITOR) (ACDelco #25735604) (LOW BEAM) [ЛАМПОЧКА ПЕРЕДНЕЙ ФАРЫ 55 ВТ]
15782399 ADAPTER, DAYTIME RUNNING LP BULB (PART OF 9)
teamcadillac.ru
10351675 BULB, DAYTIME RUNNING LP (PART OF 9) (CLEAR) (ACDelco #10351675) [ЛАМПОЧКА НАКАЛИВАНИЯ ПЕРЕДНЕЙ ФАРЫ 27 ВТ]
09421330 BULB, TRADE#194, 12V, 2CP (PART OF 9) (ACDelco #L194)
15782393 COVER, DAYTIME RUNNING LP BULB ACC (PART OF 9)
15782398 COVER, HDLP BULB ACC (PART OF 9)
11518121 ГАЙКА, U, M6X1, MULTI THD, .5'-4.0' THK PNL (HDLP HSG PNL)
11610055 БОЛТ, HWASH, M6X1X23 (HDLP HSG)
15930599 LAMP, FRT SI T/SIG [УКАЗАТЕЛЬ ПОВОРОТА]
(TC02-903) - 2007-2009 CK1,2,3 СИГНАЛ (EXC EXPORT VD1)
89046919 СИГНАЛ, GENERIC (HIGH NOTE) (INCLS 4) (MAY REQUIRE 19116451 WIRE ASM) (INCLUDES 485 HZ СИГНАЛ, BRKT) (ACDelco #D1933E) [ЗВУКОВОЙ СИГНАЛ]
teamcadillac.ru
11589076 БОЛТ, HEX HD, W/CON WA, M6X1X15, 7.5 THD, 17 O.D., 6202M, GMW3044 (СИГНАЛ) [БОЛТ М6]
89046918 СИГНАЛ, GENERIC (LOW NOTE) (INCLS 4) (MAY REQUIRE 19116451 WIRE ASM) (INCLS 405 HZ СИГНАЛ & BRKT) (ACDelco #D1932E) [ЗВУКОВОЙ СИГНАЛ]
(TC02-904) - 2008-2009 CK1,2,3 MODULE/BODY CONTROL & SERIAL DATA GATEWAY
15093913 BRACKET, BCM
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (BCM BRKT) (9.665) [БОЛТ М4.2Х1.41Х25]
15940214 MODULE, BODY CONT (W/O CALN & OPERG SYS) (LESS PROGRAMMING FILES, REQUIRES PROGRAMMING) (ACDelco #15940214)
25971917 MODULE, BODY CONT (W/O CALN & OPERG SYS) (INCLUDES PROGRAMMING FILES) (ACDelco #25971917) [БЛОК УПРАВЛЕНИЯ КУЗОВНЫМ ОБОРУДОВАНИЕМ]
11513599 ГАЙКА, U-TYPE, M4.2X1.41, 0.65-3.80 PNL THK, PZ (I/P EXTN) (ACDelco #11513599)
15801751 BRACKET, I/P CARR LOC PIN
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (I/P (TO RET)) (9.665) [БОЛТ М4.2Х1.41Х25]
25843242 MODULE, AUX BODY CONT (ACDelco #25843242) [МОДУЛЬ]
teamcadillac.ru
25883951 MODULE, SERIAL DATA GATEWAY (W/O CALN & OPERG SYS)
(TC02-907) - 2007-2009 CK1(06) ЗАДНИЕ ФОНАРИ (CADILLAC Z75)
15270012 SEAL, E/GATE CTR MLDG (PART OF 2)
25779075 APPLIQUE, L/GATE UPR (INCLS 1, 4-6) (PAINT TO MATCH) (W/O HIGH MT S/LP)
25779085 LAMP, HIGH MT STOP (INCLS CZ2 STAMP) [ЛАМПА]
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (PART OF 2) [ГАЙКА М6]
15857136 WIRE, HIGH MT S/LP (PART OF 2)
11561972 БОЛТ, L/GATE APLQ (PART OF 2) (6 X 1 X 21)
11609394 БОЛТ, L/GATE APLQ (M 6 X 1 X 28) (26 OD, 9.8)
11508277 ГАЙКА, HEX W/CON WA M6X1 THD, OD-19 PEOR 9 (L/GATE APLQ) [ГАЙКА М6]
03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (L/GATE CTR MLDG)
25872958 HARNESS, RR LIC PLT LP WRG
01999382 BULB, (RR LIC PLT LP) (ACDelco #W5WLL) (LONGER LIFE)
25778786 LAMP, RR LIC PLT [ФОНАРЬ ПОДСВЕТКИ НОМЕРНОГО ЗНАКА]
11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (RR LIC PLT LP LENS)
11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (T/LP) [ВИНТ]
25895482 LAMP, TAIL (INCLS 18, 19, 22) [ЗАДНИЙ ФОНАРЬ]
25895483 LAMP, TAIL (INCLS 18, 19, 22) [ЗАДНИЙ ФОНАРЬ]
25895484 LAMP, TAIL (INCLS 18, 19, 22) [ЗАДНИЙ ФОНАРЬ]
25895485 LAMP, TAIL (INCLS 18, 19, 22) [ЗАДНИЙ ФОНАРЬ]
15821754 BULB, B/U LP (PART OF 17) (TRADE 7440) (8.991) (ACDelco #15821754) [ЛАМПОЧКА ЗАДНЕГО ФОНАРЯ 16 ВТ]
teamcadillac.ru
15803482 HARNESS, T/LP WRG (PART OF 17)
15803483 HARNESS, T/LP WRG (PART OF 17)
11569711 ГАЙКА, PUSH-IN, M4.2X1.41, 0.7-2.15 PNL THK, SAE 1050-1065, GMW3359 W/ (T/LP) [ГАЙКА М4.2]
11562160 RETAINER, T/LP (PART OF 17) [ФИКСАТОР ЗАДНЕГО ФОНАРЯ]
(TC02-908) - 2007-2009 CK1,2,3 BLOCK/ДВИГАТЕЛЬ HARNESS JUNCTION
25781337 COVER, ENG WRG HARN J/BLK
12177236 RELAY, FAN CONT (PART OF 7) (GRAY) (SPST 280 MINI) (4-WAY) (SQUARE CASE) (W/RESISTOR) (LABELED 12177236) (9.778) (ACDelco #D7065C) [РЕЛЕ]
15328865 RELAY, FAN CONT (PART OF 7) (5 TERMINAL) (BLACK) (SPDT 280 MINI.) (DAESUNG) (ACDelco #D1724A)
12092075 FUSE, MINI (30A) (GREEN) (PART OF 7) (ACDelco #12092075)
12191645 FUSE, MINI, 2 AMP, GRAY (PART OF 7)
88909753 FUSE, MINI, 10 AMP, RED (PART OF 7)
88909754 FUSE, 15A, MINI, BLUE (PART OF 7) (ACDelco #ATM15-25) [ПРЕДОХРАНИТЕЛЬ 15 А]
88909755 FUSE, 20A, MINI, YELLOW (PART OF 7) (ACDelco #ATM20-25) [ПРЕДОХРАНИТЕЛЬ 20 А]
88909756 FUSE, 25A, MINI, CLEAR (PART OF 7) (ACDelco #ATM25-25) [ПРЕДОХРАНИТЕЛЬ, 25A]
15209748 FUSE, 40AMP, LOW PROFILE J CASE, GREEN (PART OF 7) [ПРЕДОХРАНИТЕЛЬ 20А]
15822417 FUSE, 30AMP, LOW PROFILE J CASE, PINK (PART OF 7) [ПРЕДОХРАНИТЕЛЬ, 20А]
19115640 FUSE, 60AMP, LOW PROFILE J CASE, YELLOW (PART OF 7) [ПРЕДОХРАНИТЕЛЬ, 60А]
11509226 ГАЙКА, HEX W/CON WA, M8X1.25, 7.5THK, 19 O.D., 9, ZN (CHAS RR WRG HARN J/BLK LEAD)
teamcadillac.ru
25815387 BLOCK, ENG WRG HARN JUNC (UNDERHOOD BEC) (INCLS 2-5, 14, 15)
15853967 BRACKET, ENG WRG HARN FUSE BLK
11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (ENG WRG HARN FUSE BLK BRKT) [БОЛТ М6]
19115080 RELAY, R/WDO DEFG (PART OF 7) (GRAY) (SPST 280 MICRO) (4-TERMINAL) (3.670) (ACDelco #15-50688) [РЕЛЕ ПЕРЕДНЕЙ ФАРЫ, 2 А]
88988889 RELAY, F/PMP (PART OF 7) (9.277) (ACDelco #D1773C)
(TC02-909) - 2007-2009 CK1,2,3 BLOCK- I/P MID JUNCTION
25867232 BRACKET, DA WRG HARN J/BLK
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA WRG HARN J/BLK BRKT) [ГАЙКА М6]
11516780 ГАЙКА, HEX W/CON WA, M8X1.25, 10THK, 19 O.D., 10, 7111M (PARK BRK CONT MDL) (8.917) [ГАЙКА М8]
15780696 BLOCK, BODY WRG HARN JUNC (INCLS 6) (LABELED 15780696)
teamcadillac.ru
15939775 BLOCK, BODY WRG HARN JUNC (INCLS 6) (LABELED 15939775)
20813086 BLOCK, BODY WRG HARN JUNC (INCLS 6) (LABELED 20813086)
20813087 BLOCK, BODY WRG HARN JUNC (INCLS 6) (LABELED 20813087)
12088575 BREAKER, CIRCUIT, 25AMP, WHITE (PART OF 5) [РАЗМЫКАТЕЛЬ ЗАЩИТЫ ЦЕПИ ТЕПЛОВОЙ]
15319848 BREAKER, CIRC (PART OF 5) (50 AMP MAXI TYPE I)
19116527 BREAKER, CIRC (PART OF 5) (25 AMP MANUAL RESET)
15200870 COVER, DA WRG HARN J/BLK
(TC02-910) - 2007-2009 CK1,2,3 BLOCK- I/P JUNCTION
25815391 BLOCK, FUSE (INCLS 3, 4) [ТОКОРАСПРЕДЕЛИТЕЛЬНАЯ КОРОБКА]
12092075 FUSE, MINI (30A) (GREEN) (PART OF 2) (ACDelco #12092075)
teamcadillac.ru
12092079 FUSE, 10A, MINI, RED (PART OF 2)
12191645 FUSE, MINI, 2 AMP, GRAY (PART OF 2)
88909754 FUSE, 15A, MINI, BLUE (PART OF 2) (ACDelco #ATM15-25) [ПРЕДОХРАНИТЕЛЬ 15 А]
88909755 FUSE, 20A, MINI, YELLOW (PART OF 2) (ACDelco #ATM20-25) [ПРЕДОХРАНИТЕЛЬ 20 А]
88909756 FUSE, 25A, MINI, CLEAR (PART OF 2) (ACDelco #ATM25-25) [ПРЕДОХРАНИТЕЛЬ, 25A]
15319848 BREAKER, CIRC (PART OF 2) (50 AMP MAXI TYPE I)
19116527 BREAKER, CIRC (PART OF 2) (25 AMP MANUAL RESET)
(TC02-911) - 2008-2009 CK1,2,3 КРЕПЛЕНИЕ АККУМУЛЯТОРА/PRIMARY (EXC HYBRID HP2)
15195496 SUPPORT, BAT TRAY FRT
11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (BAT TRAY SUPT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16]
11509853 БОЛТ, HEX W/CON WA, M8X1.25X45, 24 O.D., HDR PT, 9.8, PS (BAT HOLDN RET) [БОЛТ]
14005061 RETAINER, BAT HOLDN (PLASTIC) [ПЛАСТИНА ФИКСАЦИИ ОСНОВАНИЯ АККУМУЛЯТОРА]
11516780 ГАЙКА, HEX W/CON WA, M8X1.25, 10THK, 19 O.D., 10, 7111M (BAT TRAY) (8.917) [ГАЙКА М8]
teamcadillac.ru
15872637 TRAY, BAT (PRIMARY)
11508388 ГАЙКА, HEX W/CON WA, M6X1, 23.75 O.D., 5.55THK, 9, POR (BAT TRAY) (8.915)
(TC02-912) - 2008-2009 CK1,2,3 КРЕПЛЕНИЕ АККУМУЛЯТОРА/SECONDARY (EXC HYBRID HP2)
25826079 TRAY, BAT (SECONDARY)
11609540 БОЛТ, HWASH, M6X1X20, 16.15 THD, 17 OD, 8.8, GMW4205, HDR PT. (BAT TRAY) [ВИНТ]
15850348 BRACKET, ECM [ПЕТЛЯ КРЫШКИ БАГАЖНИКА]
10399558 SUPPORT, BAT TRAY
11514623 БОЛТ, HEX W/CON WA, M6X1X20 (BAT TRAY SUPT)
11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (BAT TRAY) [ШАЙБА]
(TC02-914) - 2007-2009 CK1,2(06) ЗАДНИЕ ДАТЧИКИ ПАРКОВКИ (UD7)
25857380 MODULE, RR OBJECT ALARM (INCLS 4) (INCLUDES INTEGRAL PLASTIC BRKT--DISCARD PREVIOUS METAL BRKT 7 FASTNERS AS NEEDED)
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (RR OBJECT ALARM MDL) [ГАЙКА М6]
teamcadillac.ru
21997869 INDICATOR, RR OBJECT ALARM (PART OF 6)
11509253 SCREW, W/LRG WA HD, M4.2X1.4X10, 11.3 O.D., BHL PT, STL, NO (PART OF 6)
15950574 HARNESS, RR OBJECT SEN WRG [ПРОВОДКА ДАТЧИКОВ ЗВУКОВОЙ СИГНАЛИЗАЦИИ СИСТЕМЫ ПАРКОВКИ]
15239247 SENSOR KIT, RR OBJECT (INCLS 11) (PRIMED) (W/O ШЛАНГИ) (7.831) [ДАТЧИК ПАРКОВКИ]
19115805 SENSOR KIT, RR OBJECT (INCLS 11) (MOUNTED IN THE STEP PAD) (7.831)
19115806 SENSOR KIT, RR OBJECT (INCLS 11) (PRIMER) (MOUNTED IN THE BUMPER) (7.831)
(TC02-915) - 2008-2009 CK1(06) ЖГУТЫ ПРОВОДОВ/LIFT GATE (CADILLAC Z75)
25925953 HARNESS, L/GATE WRG (INCLS 2-3)
25925954 HARNESS, L/GATE WRG (INCLS 2-3)
(TC02-917) - 2007-2009 CK1(06-36) ЖГУТЫ ПРОВОДОВ/ПЕРЕДНИЕ ФАРЫ (CADILLAC Z75)
15936591 HARNESS, FWD LP WRG
15936600 HARNESS, FWD LP WRG
15937883 HARNESS, FWD LP WRG (LABELED 15937883)
20821446 HARNESS, FWD LP WRG (LABELED 20821446)
20830840 HARNESS, FWD LP WRG
20830846 HARNESS, FWD LP WRG
15930599 LAMP, FRT SI T/SIG (СМ. ГРУППУ 02.000 "ПЕРЕДНИЕ ФАРЫ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [УКАЗАТЕЛЬ ПОВОРОТА]
15935384 HARNESS, FRT SI T/SIG LP WRG
15938011 HARNESS, FRT SI T/SIG LP WRG (PASS SIDE)
teamcadillac.ru
11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (FWD LP WRG HARN GND) [БОЛТ М8]
(TC02-918) - 2007-2009 CK1,2(06-36) ЖГУТЫ ПРОВОДОВ/ROOF
15936801 HARNESS, RF WRG (INCLS 4) (A PILLER)
15936821 HARNESS, RF WRG (INCLS 4)
20802968 HARNESS, RF WRG (INCLS 4)
teamcadillac.ru
(TC02-919) - 2008-2009 CK107(06) ЖГУТЫ ПРОВОДОВ/КУЗОВ (EXC HYBRID HP2)
20772066 HARNESS, BODY WRG (INCLS 5, 8)
20774298 HARNESS, BODY WRG (INCLS 5, 8)
20774299 HARNESS, BODY WRG (INCLS 5, 8)
20805463 HARNESS, BODY WRG (INCLS 5, 8)
25872004 HARNESS, BODY WRG (INCLS 5, 8)
25919525 HARNESS, BODY WRG (INCLS 5, 8)
25947095 HARNESS, BODY WRG (INCLS 5, 8)
25947185 HARNESS, BODY WRG (INCLS 5, 8)
25947325 HARNESS, BODY WRG (INCLS 5, 8)
25987053 HARNESS, BODY WRG (INCLS 5, 8)
teamcadillac.ru
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BODY WRG HARN GND) [ГАЙКА М6]
21011332 ГАЙКА, HEX STAMPED TY DF FLG 14 (BODY WRG HARN BRKT) (8.921)
15215179 COVER, WRG HARN CONN (BLACK (REPLS ALL COLORS)) [КРЫШКА КОНТАКТНОГО РАЗЪЕМА]
11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (BODY WRG HARN GND) [БОЛТ М8]
(TC02-920) - 2008-2009 CK1(06-36) ЖГУТЫ ПРОВОДОВ/CHASSIS (REAL-TIME DAMPING Z55, MAGNERIDE Z95, EXC HYBRID HP2)
25977176 HARNESS, CHAS WRG (INCLS 2, 3)
25977177 HARNESS, CHAS WRG (INCLS 2, 3)
25977196 HARNESS, CHAS WRG (INCLS 2, 3)
25977221 HARNESS, CHAS WRG (INCLS 2, 3)
11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (CHAS WRG) [БОЛТ М8]
teamcadillac.ru
12177233 RELAY, AUTO LVL CONT (5-WAY MALE, BLACK, CODE 7233) (SHROUDED) (W/RESISTOR) (SPDT 280 MINI) (FOR 4-TERM APP CUT OFF CENTER TERM LABELED 87A) (9.277) (ACDelco #15-8721)
(TC02-924) - 2009 CK1(06-36) ЖГУТЫ ПРОВОДОВ/ДВИГАТЕЛЬ (L9H/6.2-2)
15940539 HARNESS, ENG WRG
25994842 HARNESS, ENG WRG
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (ENG WRG HARN RET) [ГАЙКА М6]
01470030 CLAMP, WORM TYPE (11/16" TO 1 5/16") (ENG WRG HARN CLIP) (ACDelco #1470030)
teamcadillac.ru
11589076 БОЛТ, HEX HD, W/CON WA, M6X1X15, 7.5 THD, 17 O.D., 6202M, GMW3044 (ENG WRG HARN CLIP) [БОЛТ М6]
11609832 STUD-HFH, M8X1.25X16, M8X1.25X16, 18 OD, 40.1 TL, 8.8 STL, GMW3200 (ENG WRG HARN CDT)
11514623 БОЛТ, HEX W/CON WA, M6X1X20 (ENG WRG HARN BRKT)
11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (ENG WRG HARN CLIP) [БОЛТ М6]
21075686 RETAINER, PUSH PIN W/SEAL, FITS 8.0-8.25 DIA HOLE IN 3-7MM THK PNL (SECD OXY SEN WRG HARN)
01470030 CLAMP, WORM TYPE (11/16" TO 1 5/16") (OXY SEN WIRE) (ACDelco #1470030)
11609467 NUT HEX, M5X0.8, 4.55 THK, 5 STL, GMW3200 (ENG WRG HARN START MTR LEAD)
11561111 STUD, BAT NEG CBL GND (M10 X1.5 X 20)
(TC02-926) - 2007-2009 CK1(06) ЖГУТЫ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ EXTENSION (G.M.C. Z88, DENALI Y91, EXC UE1,U2K)
teamcadillac.ru
15127940 HARNESS, I/P WRG HARN EXTN
(TC02-928) - 2008-2009 CK1(06) ЖГУТЫ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ (G.M.C. Z88, DENALI Y91)
19117122 CABLE, DIGITAL RDO АНТЕННА (9.675) (ACDelco #19117122)
19149310 BLOCK, I/P WRG HARN JUNC (PART OF 8)
20819671 HARNESS, I/P WRG (INCLS 4, 5) (W/O CONNS FOR HTD W/S NOZZLE SYS) (FOR 1ST DES SEE 25963032)
20819672 HARNESS, I/P WRG (INCLS 4, 5) (W/O CONNS FOR HTD W/S NOZZLE SYS) (FOR 1ST DES SEE 25963045)
20819673 HARNESS, I/P WRG (INCLS 4, 5) (W/O CONNS FOR HTD W/S NOZZLE SYS) (FOR 1ST DES SEE 25963046)
20819676 HARNESS, I/P WRG (INCLS 4, 5) (W/O CONNS FOR HTD W/S NOZZLE SYS) (FOR 1ST DES SEE 25963052)
teamcadillac.ru
20819680 HARNESS, I/P WRG (INCLS 4, 5) (W/O CONNS FOR HTD W/S NOZZLE SYS) (FOR 1ST DES SEE 25963061)
20819681 HARNESS, I/P WRG (INCLS 4, 5) (W/O CONNS FOR HTD W/S NOZZLE SYS) (FOR 1ST DES SEE 25963062)
20824141 HARNESS, I/P WRG (INCLS 4, 5) (W/O CONNS FOR HTD W/S NOZZLE SYS) (FOR 1ST DES SEE 25963033)
20824146 HARNESS, I/P WRG (INCLS 4, 5) (W/O CONNS FOR HTD W/S NOZZLE SYS) (FOR 1ST DES SEE 25963047)
20824150 HARNESS, I/P WRG (INCLS 4, 5) (W/O CONNS FOR HTD W/S NOZZLE SYS) (FOR 1ST DES SEE 25963053)
25963032 HARNESS, I/P WRG (INCLS 4, 5) (W/CONN FOR HTD W/S NOZZLE SYS) (FOR 2ND DES SEE 20819671)
25963033 HARNESS, I/P WRG (INCLS 4, 5) (W/CONN FOR HTD W/S NOZZLE SYS) (FOR 2ND DES SEE 20824141)
25963045 HARNESS, I/P WRG (INCLS 4, 5) (W/CONN FOR HTD W/S NOZZLE SYS) (FOR 2ND DES SEE 20819672)
25963046 HARNESS, I/P WRG (INCLS 4, 5) (W/CONN FOR HTD W/S NOZZLE SYS) (FOR 2ND DES SEE 20819673)
25963047 HARNESS, I/P WRG (INCLS 4, 5) (W/CONN FOR HTD W/S NOZZLE SYS) (FOR 2ND DES SEE 20824146)
25963052 HARNESS, I/P WRG (INCLS 4, 5) (W/CONN FOR HTD W/S NOZZLE SYS) (FOR 2ND DES SEE 20819676)
25963053 HARNESS, I/P WRG (INCLS 4, 5) (W/CONN FOR HTD W/S NOZZLE SYS) (FOR 2ND DES SEE 20824150)
25963061 HARNESS, I/P WRG (INCLS 4, 5) (W/CONN FOR HTD W/S NOZZLE SYS) (FOR 2ND DES SEE 20819680)
25963062 HARNESS, I/P WRG (INCLS 4, 5) (W/CONN FOR HTD W/S NOZZLE SYS) (FOR 2ND DES SEE 20819681)
12146933 COVER, I/P WRG HARN DATA LINK CONN
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (I/P WRG HARN DATA LINK CONN) (9.665) [БОЛТ М4.2Х1.41Х25]
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (I/P WRG HARN GND) [ГАЙКА М6]
(TC02-929) - 2007-2009 CK1(06-36) ЖГУТЫ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ (CADILLAC Z75)
15095253 CABLE, RDO ANT CBL EXTN RDO END (1021 MM) (ACDelco #15095253)
20819666 HARNESS, I/P WRG (INCLS 5) (W/O CONNS FOR HTD W/S NOZZLE SYS) (FOR 1ST DES SEE 25963001)
20819667 HARNESS, I/P WRG (INCLS 5) (W/O CONNS FOR HTD W/S NOZZLE SYS) (FOR 1ST DES SEE 25963002)
20819668 HARNESS, I/P WRG (INCLS 5) (W/O CONNS FOR HTD W/S NOZZLE SYS) (FOR 1ST DES SEE 25963003)
20819677 HARNESS, I/P WRG (INCLS 5) (W/O CONNS FOR HTD W/S NOZZLE SYS) (FOR 1ST DES SEE 25963056)
20819678 HARNESS, I/P WRG (INCLS 5) (W/O CONNS FOR HTD W/S NOZZLE SYS) (FOR 1ST DES SEE 25963057)
20819679 HARNESS, I/P WRG (INCLS 5) (W/O CONNS FOR HTD W/S NOZZLE SYS) (FOR 1ST DES SEE 25963060)
20819682 HARNESS, I/P WRG (INCLS 5) (W/O CONNS FOR HTD W/S NOZZLE SYS) (FOR 1ST DES SEE 25963063)
20824143 HARNESS, I/P WRG (INCLS 5) (W/O CONNS FOR HTD W/S NOZZLE SYS) (FOR 1ST DES SEE 25963035)
20824152 HARNESS, I/P WRG (INCLS 5) (W/O CONNS FOR HTD W/S NOZZLE SYS) (FOR 1ST DES SEE 25963055)
20824174 HARNESS, I/P WRG (INCLS 5) (W/O CONNS FOR HTD W/S NOZZLE SYS) (FOR 1ST DES SEE 25963119)
20824202 HARNESS, I/P WRG (INCLS 5) (W/O CONNS FOR HTD W/S NOZZLE SYS) (FOR 1ST DES SEE 25963157)
20824203 HARNESS, I/P WRG (INCLS 5) (W/O CONNS FOR HTD W/S NOZZLE SYS) (FOR 1ST DES SEE 25963158)
20824208 HARNESS, I/P WRG (INCLS 5) (W/O CONNS FOR HTD W/S NOZZLE SYS) (FOR 1ST DES SEE 25978283)
20833793 HARNESS, I/P WRG (INCLS 5) (W/O CONNS FOR HTD W/S NOZZLE SYS) (FOR 1ST DES SEE 25963159)
20833795 HARNESS, I/P WRG (INCLS 5) (W/O CONNS FOR HTD W/S NOZZLE SYS) (FOR 1ST DES SEE 25963161)
25963001 HARNESS, I/P WRG (INCLS 5) (W/CONN FOR HTD W/S NOZZLE SYS) (FOR 2ND DES SEE 20819666)
25963002 HARNESS, I/P WRG (INCLS 5) (W/CONN FOR HTD W/S NOZZLE SYS) (FOR 2ND DES SEE 20819667)
25963003 HARNESS, I/P WRG (INCLS 5) (W/CONN FOR HTD W/S NOZZLE SYS) (FOR 2ND DES SEE 20819668)
25963035 HARNESS, I/P WRG (INCLS 5) (W/CONN FOR HTD W/S NOZZLE SYS) (FOR 2ND DES SEE 20824143)
25963045 HARNESS, I/P WRG (INCLS 5) (W/CONN FOR HTD W/S NOZZLE SYS) (FOR 2ND DES SEE 20819672)
25963055 HARNESS, I/P WRG (INCLS 5) (W/CONN FOR HTD W/S NOZZLE SYS) (FOR 2ND DES SEE 20824152)
25963056 HARNESS, I/P WRG (INCLS 5) (W/CONN FOR HTD W/S NOZZLE SYS) (FOR 2ND DES SEE 20819677)
25963057 HARNESS, I/P WRG (INCLS 5) (W/CONN FOR HTD W/S NOZZLE SYS) (FOR 2ND DES SEE 20819678)
25963060 HARNESS, I/P WRG (INCLS 5) (W/CONN FOR HTD W/S NOZZLE SYS) (FOR 2ND DES SEE 20819679)
teamcadillac.ru
25963063 HARNESS, I/P WRG (INCLS 5) (W/CONN FOR HTD W/S NOZZLE SYS) (FOR 2ND DES SEE 20819682)
25963119 HARNESS, I/P WRG (INCLS 5) (W/CONN FOR HTD W/S NOZZLE SYS) (FOR 2ND DES SEE 20824174)
25963157 HARNESS, I/P WRG (INCLS 5) (W/CONN FOR HTD W/S NOZZLE SYS) (FOR 2ND DES SEE 20824202)
25963158 HARNESS, I/P WRG (INCLS 5) (W/CONN FOR HTD W/S NOZZLE SYS) (FOR 2ND DES SEE 20824203)
25963159 HARNESS, I/P WRG (INCLS 5) (W/CONN FOR HTD W/S NOZZLE SYS) (FOR 2ND DES SEE 20824204)
25963161 HARNESS, I/P WRG (INCLS 5) (W/CONN FOR HTD W/S NOZZLE SYS) (FOR 2ND DES SEE 20833795)
25978283 HARNESS, I/P WRG (INCLS 5) (W/CONN FOR HTD W/S NOZZLE SYS) (FOR 2ND DES SEE 20824208)
19117122 CABLE, DIGITAL RDO АНТЕННА (PART OF 3) (9.675) (ACDelco #19117122)
(TC02-931) - 2007-2009 CK1,2(06-36) ЖГУТЫ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ FUSE BLOCK (POWER ADJUSTABLE PEDAL JF4, EXC PPV,5W4,9L4)
15780696 BLOCK, BODY WRG HARN JUNC (LABELED 15780696)
15939775 BLOCK, BODY WRG HARN JUNC (LABELED 15939775)
20813086 BLOCK, BODY WRG HARN JUNC (LABELED 20813086)
teamcadillac.ru
20813087 BLOCK, BODY WRG HARN JUNC (LABELED 20813087)
15936751 HARNESS, FUSE BLK WRG
25776703 HARNESS, FUSE BLK WRG
(TC02-939) - 2007-2009 CK107(06) АККУМУЛЯТОР ПРОВОДА (DUAL АККУМУЛЯТОР 6A6)
19116852 BOLT KIT, BAT CBL TERM (PART OF 6, 8, 19, 25) (INCLS 2, 3) [КОМПЛЕКТ БОЛТОВ М8 (2ШТ.)]
19116038 COVER, BAT POS CBL TERM (PART OF 6)
25825642 CABLE, AUX BAT POS (INCLS 2-5) (ACDelco #25825642) [КАБЕЛЬ]
11609619 БОЛТ, HEX W/ FL WA-M10X1.5X16, 20 OD, 10.9 STL, GMW3200 FINISH (AUX BAT NEG CBL) [БОЛТ]
25876896 CABLE, AUX BAT NEG (INCLS 1-4) (ACDelco #25876896) [КАБЕЛЬ АККУМУЛЯТОРА 12 В]
25862352 CABLE, AUX BAT POS (RH PROC) (ACDelco #25862352)
21011332 ГАЙКА, HEX STAMPED TY DF FLG 14 (BAT POS CBL RET) (8.921)
15881616 COVER, BAT POS CBL J/BLK (3 WAY MEGAFUSE)
21021808 ГАЙКА, BAT HDL (M8X1.25X6, BRASS) (2.343) [ГАЙКА М8]
15106388 FUSE, (MEGA FUSE) (BLACK) (60 AMP) (8.965)
19116352 HOLDER, WRG HARN FUSE
12177251 FUSE, 125 AMP MEGA FUSE (125 A) (FUSE COLOR, BLACK W/SIZE STAMPED IN WHITE ON CASE) [ПРЕДОХРАНИТЕЛЬ 125 А]
15305191 FUSE, 175 AMP MEGA (ПЕПЕЛЬНИЦА LP) ( FUSE COLOR, BLACK W/SIZE STAMPED IN WHITE ON CASE) [ПРЕДОХРАНИТЕЛЬ (175 AMP MEGA FUSE) *ЧЕРНЫЙ]
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BAT POS CBL J/BLK BRKT) [ГАЙКА М6]
25797040 COVER, BAT POS CBL TERM (TOP) (PART OF 19)
20774386 CABLE, STRTR SOL (INCLS 2-4, 18, 20) (LABELED 20774386) (ACDelco #20774386)
25875321 CABLE, STRTR SOL (INCLS 2-4, 18, 20) (LABELED 25875321) (ACDelco #25875321)
25888958 COVER, BAT POS CBL TERM (BOTTOM) (PART OF 19)
21021808 ГАЙКА, STRTR SOL CBL (M8X1.25X6, BRASS) [ГАЙКА М8]
11516885 SCREW, HFH W/FL WA, TAP, M8X1.25X20, 7THD, 17 O.D., TR PT, 6202M, PZOR (BAT POS CBL CLIP)
teamcadillac.ru
11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (BAT NEG CBL GND) [БОЛТ М8]
20835005 CABLE, BAT NEG (INCLS 2-4, 26, 27)
10306471 SENSOR, BAT CUR (PART OF 25) [КАБЕЛЬНАЯ КЛЕММА]
(TC02-940) - 2007-2009 CK1,2,3 ЖГУТЫ ПРОВОДОВ/ACCESSORY POWER SUPPLY (WIRING PROVISIONS 9L4)
25825519 HARNESS, ACSRY PWR FUSE BLK RR WRG HARN EXTN (INCLS 4, 6, 7)
25825520 HARNESS, ACSRY PWR FUSE BLK RR WRG HARN EXTN (INCLS 4, 6, 7)
15888241 BRACKET, ACSRY PWR FUSE BLK RR WRG HARN EXTN HARN (PART OF 1)
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (ACSRY PWR FUSE BLK RR WRG HARN EXTN HARN BRKT) (9.665) [БОЛТ М4.2Х1.41Х25]
12092075 FUSE, MINI (30A) (GREEN) (PART OF 1) (ACDelco #12092075)
teamcadillac.ru
12193604 RELAY, ACSRY (MOBILE RADIO) (PART OF 1) (GRAY) (SPST 280 MINI) (4-TERMINAL) (CODE 3604) (9.778) (ACDelco #15-8733)
(TC02-941) - 2007-2009 CK107(06) ЖГУТЫ ПРОВОДОВ/ACCESSORY POWER SUPPLY (POLICE PACKAGE PPV, MUNICIPAL SERVICE 5W4)
25825519 HARNESS, ACSRY PWR FUSE BLK RR WRG HARN EXTN (INCLS 4, 6-8)
25825520 HARNESS, ACSRY PWR FUSE BLK RR WRG HARN EXTN (INCLS 4, 6-8)
teamcadillac.ru
12182117 BREAKER ASM, CIRC (MINI 30AMP NON-CYCLING) (PART OF 1) (2.483)
15319848 BREAKER, CIRC (50 AMP MAXI TYPE I)
(TC02-954) - 2007-2009 CK1(06) АККУМУЛЯТОР ПРОВОДА (WIRING PROVISIONS 9L4)
15856795 STRAP, ENG GND (ACDelco #15856795)
15921158 STRAP, ENG GND (ACDelco #15921158)
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (ENG GND STRP) [ГАЙКА М6]
11609619 БОЛТ, HEX W/ FL WA-M10X1.5X16, 20 OD, 10.9 STL, GMW3200 FINISH (ENG GND STRP) [БОЛТ]
25825642 CABLE, AUX BAT POS (INCLS 23, 25, 27) (ACDelco #25825642) [КАБЕЛЬ]
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BAT POS CBL) [ГАЙКА М6]
20771932 CABLE, GEN BAT JPR (LABELED 20771932) (ACDelco #20771932)
25996788 CABLE, GEN BAT JPR (ACDelco #25996788)
21021808 ГАЙКА, GEN BAT (M8X1.25X6, BRASS) (2.343) [ГАЙКА М8]
20774386 CABLE, STRTR SOL (INCLS 18-22) (LABELED 20774386) (ACDelco #20774386)
25875321 CABLE, STRTR SOL (INCLS 18-22) (LABELED 25875321) (ACDelco #25875321)
10306471 SENSOR, BAT CUR (PART OF 16) [КАБЕЛЬНАЯ КЛЕММА]
25925265 CLIP, BAT CBL (PART OF 16)
25925268 CLIP, BAT CBL (PART OF 16)
25897052 CABLE, BAT NEG (INCLS 13, 14, 18-20) (ACDelco #25897052)
teamcadillac.ru
25888958 COVER, BAT POS CBL TERM (BOTTOM) (PART OF 9)
25797040 COVER, BAT POS CBL TERM (TOP) (PART OF 9)
21021808 ГАЙКА, BAT HDL (PART OF 4) (M8X1.25X6, BRASS) (2.343) [ГАЙКА М8]
15305191 FUSE, 175 AMP MEGA (PART OF 4) ( FUSE COLOR, BLACK W/SIZE STAMPED IN WHITE ON CASE) [ПРЕДОХРАНИТЕЛЬ (175 AMP MEGA FUSE) *ЧЕРНЫЙ]
19116352 HOLDER, WRG HARN FUSE (PART OF 4)
(TC02-956) - 2008-2009 CK1,2(06-36) АККУМУЛЯТОР ПРОВОДА (EXC HYBRID HP2, DUAL АККУМУЛЯТОР 6A6, WIRING PROVISIONS 9L4)
25814777 CABLE, BAT POS (INCLS 23, 26, 27) (ACDelco #25814777)
teamcadillac.ru
10306471 SENSOR, BAT CUR (PART OF 15) [КАБЕЛЬНАЯ КЛЕММА]
20835005 CABLE, BAT NEG (INCLS 13, 17, 19-21)
11561048 БОЛТ, HEX W/FL WA-3/8-16X.625, .82 OD, GM275 STL, GMW3200 FINISH (ENG WRG HARN GND)
21021808 ГАЙКА, GEN BAT (PART OF 4) (M8X1.25X6, BRASS) (2.343) [ГАЙКА М8]
15861891 COVER, BAT POS CBL J/BLK
(TC02-962) - 2007-2009 CK107(06) ЖГУТЫ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ FUSE BLOCK (POLICE PACKAGE PPV, MUNICIPAL SERVICE 5W4)
teamcadillac.ru
(TC02-963) - 2007-2009 CK1,2,3 ЖГУТЫ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ FUSE BLOCK (WIRING PROVISIONS 9L4)
teamcadillac.ru
(TC02-964) - 2007-2009 K107(06) СИГНАЛ (EXPORT VD1)
19116451 WIRE, СИГНАЛ (PART OF 1, 2) (FOR CORRECT СИГНАЛ PN USE VIN FILTER) (REMOVE CONNECTORS) (USE W/12368063-4 KITS & 89046918-9 СИГНАЛS. MAY NEED TO SPLICE/) [КАБЕЛЬ]
11610199 БОЛТ, HEX W/CON WA, M6X1X30, 21 THD, 17 OD, 8.8, GMW3359 (СИГНАЛ)
teamcadillac.ru
25866835 СИГНАЛ, 400 & 500 HZ (INCLS 1, 2) (ACDelco #D1970F) [ЗВУКОВОЙ СИГНАЛ]
(TC02-975) - 2007-2009 CK1,2,3 ФОНАРИ/КРЫША (ROOF MARKER LAMP U01)
25826850 LAMP, RF CLER CTR (INCLS 3, 4, 6) (W/SCREWS, WASHERS & NUTS) (LED BULBS) (3 LAMPS)
(TC02-982) - 2009 CK1 CONTROL MODULE MOUNTING/DRIVE MOTOR (HYBRID HP2)
11609319 STUD, FUSE BLK SHLD (3.671)
24243399 COVER, DRV MOT GEN PWR INV MDL (3 PHASE) CBL (INCLS 5)
24238760 LABEL, HIGH VOLTAGE WRNG (PART OF 4)
11900241 БОЛТ, P/S CONT MDL (M6X1.0X12) (3.602)
25940453 TRAY, ACSRY DC PWR CONT MDL
25962338 MODULE, ELEK P/S MOT CONT (INCLS 10)
25813638 LABEL, P/S FLUID VOLTAGE CAUTION (PART OF 9) (TWO-MODE HYBRID)
11516780 ГАЙКА, HEX W/CON WA, M8X1.25, 10THK, 19 O.D., 10, 7111M (ACSRY DC PWR CONT MDL BRKT) (8.917) [ГАЙКА М8]
15254539 BRACKET, ACSRY DC PWR CONT MDL TRAY
11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (ACSRY DC PWR CONT MDL TRAY) [ГАЙКА]
15897199 BRACKET, ACSRY DC PWR CONT MDL TRAY (TO КРЫЛО)
11508388 ГАЙКА, HEX W/CON WA, M6X1, 23.75 O.D., 5.55THK, 9, POR (ACSRY DC PWR CONT MDL TRAY BRKT (TO КРЫЛО)) (8.915)
11609982 БОЛТ, ACSRY DC PWR CONT MDL TRAY (6 X 1 X 22) (8.900)
15890021 RETAINER, ACSRY DC PWR CONT MDL TRAY
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (ACSRY DC PWR CONT MDL TRAY RET) [ГАЙКА М6]
12624430 MODULE, DRV MOT GEN PWR INV (W/ 2ND MPU) (СМ. ГРУППУ 02.000 "CONTROL MODULE ASM/DRIVE MOTOR" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА)
11588564 БОЛТ, HEX W/FL WA, M8X1.25X25, 15.85 THD, 17 OD, 9.8, GMW3200M, MACH, MAT-PT (GEN CONT MDL)
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (GEN CONT MDL) [ГАЙКА М6]
19208906 RETAINER, ENG WRG HARN
11513699 SCREW, PAN HD, TORX, M6X1X18, 12 O.D., HD PT, 9.8, PE (FUSE BLK CVR)
24241226 SEAL, DRV MOT PWR INV MDL CVR (PART OF 1)
25823544 SEAL, DRV MOT PWR INV MDL (O RING) (PART OF 1)
teamcadillac.ru
25993617 SENSOR, HIGH VOLTAGE CIRC IMPACT DETECTION (INCLS 35) (LABELLED 25993617 OR 15822907)
(TC02-983) - 2008-2009 CK107(06) MODULE/ACCESSORY AC & DC POWER CONTROL(KV1)
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (ШИНА INFLR STRP) [ГАЙКА М6]
03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (ACSRY AC & DC PWR CONT MDL)
89047499 БОЛТ, ACSRY AC & DC PWR CONT MDL
15800723 BRACKET, ACSRY AC & DC PWR CONT MDL
teamcadillac.ru
10361107 MODULE KIT, ACSRY AC & DC PWR CONT (REMAN)
25856063 HARNESS, ACSRY AC & DC PWR CONT MDL WRG
(TC02-986) - 2009 CK1 BLOCK/ACCESSORY WIRING JUNCTION (HYBRID HP2)
15930926 LABEL, BAT INFO (PART OF 2)
25801752 COVER, ENG WRG HARN J/BLK (INCLS 1, 3)
25859530 LABEL, FUSE BLK (PART OF 2) (8.808)
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (AUX BAT POS CBL) [ГАЙКА М6]
88909753 FUSE, MINI, 10 AMP, RED (PART OF 16)
88909754 FUSE, 15A, MINI, BLUE (PART OF 16) (ACDelco #ATM15-25) [ПРЕДОХРАНИТЕЛЬ 15 А]
88909756 FUSE, 25A, MINI, CLEAR (PART OF 16) (ACDelco #ATM25-25) [ПРЕДОХРАНИТЕЛЬ, 25A]
11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (ENG WRG HARN FUSE BLK BRKT) [БОЛТ М6]
11610199 БОЛТ, HEX W/CON WA, M6X1X30, 21 THD, 17 OD, 8.8, GMW3359 (ENG WRG HARN FUSE BLK BRKT)
11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (СМ. ГРУППУ 03.000 "БЛОК ЭЛЕКТРОННОГО УПРАВЛЕНИЯ MODULE & ЖГУТЫ ПРОВОДОВ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ШАЙБА]
12177236 RELAY, FAN CONT (PART OF 16) (GRAY) (SPST 280 MINI) (4-WAY) (SQUARE CASE) (W/RESISTOR) (LABELED 12177236) (9.778) (ACDelco #D7065C) [РЕЛЕ]
15328865 RELAY, FAN CONT (PART OF 16) (BLACK) (SPDT 280 MINI.) (DAESUNG) (ACDelco #D1724A)
teamcadillac.ru
(TC02-987) - 2008-2009 CK107(06) КРЕПЛЕНИЕ АККУМУЛЯТОРА/PRIMARY (HYBRID HP2)
teamcadillac.ru
15850348 BRACKET, ECM (СМ. ГРУППУ 03.000 "БЛОК ЭЛЕКТРОННОГО УПРАВЛЕНИЯ MODULE & ЖГУТЫ ПРОВОДОВ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ПЕТЛЯ КРЫШКИ БАГАЖНИКА]
(TC02-988) - 2008-2009 CK107(06) КРЕПЛЕНИЕ АККУМУЛЯТОРА/DRIVE MOTOR (HYBRID HP2)
25905443 COVER, BAT NEG CBL TERM (HIGH VOLTAGE TERMINAL COVER LABELED 5443)
11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (BAT NEG CBL TERM) [БОЛТ М6]
15293650 LEVER, DRV MOT BAT HIGH VOLTAGE MAN DISCONNECT (INCLS 5)
11569660 BOLT-HEX W/CON WA, M8X1.25X40, 27 THD, 28 OD, GM6202M, GMW3200, TAPPIN (DRV MOT BAT TRAY)
03537772 ГАЙКА, M12X1.75, 10.6THK, 28 O.D., 10, 7111M (R/SEAT) (8.917)
03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (DRV MOT BAT PWR CONT MDL HARN CONN)
15294099 INSULATOR, BAT (LABELED 15294099)
25961362 INSULATOR, BAT (LABELED 2591362)
15293030 DUCT, BAT CLG AIR OTLT
25925258 DUCT, BAT CLG AIR OTLT (FAN CONNECTOR)
teamcadillac.ru
25925287 DUCT, BAT CLG AIR OTLT
11589290 RETAINER, PUSH-IN, FITS 6.5 HOLE, 4.5 -7.0 THK PNL, NYLON 6/6 GMP.PA66.0 (BAT CLG AIR OTLT DUCT) [ФИКСАТОР ПАНЕЛИ ВОЗДУХОЗАБОРНИКА]
11609558 NUT-HEX W/CON WA, M8X1.25X7.5, 24 OD, 9 STL, GMW3200 SN-ZN (DRV MOT BAT TRAY)
(TC02-989) - 2008-2009 CK107(06) АККУМУЛЯТОР/DRIVE MOTOR ЧАСТЬ 1 (HYBRID HP2)
25925265 CLIP, BAT CBL (*KIT1, KIT2)
25925268 CLIP, BAT CBL (*KIT1, KIT2)
25870508 HARNESS, DRV MOT BAT SEN MDL WRG (*KIT1, KIT2)
25870509 RETAINER, BAT VENT HOSE (*KIT1, KIT2)
25926169 RETAINER, BAT VENT HOSE (*KIT1, KIT2)
25925262 TUBE, BAT VENT (*KIT1, KIT2)
25926167 CLIP, DRV MOT BAT TEMP SEN (*KIT1, KIT2)
15293030 DUCT, BAT CLG AIR OTLT (INCLS 17) (*KIT2)
25925258 DUCT, BAT CLG AIR OTLT (INCLS 17) (FAN CONNECTOR) (*KIT2)
25925287 DUCT, BAT CLG AIR OTLT (INCLS 17) (*KIT2)
teamcadillac.ru
25926177 INSULATOR, DRV MOT BAT VENT FAN (*KIT2)
25870518 FAN, GEN BAT VENT (*KIT2)
25870510 RELAY, GEN BAT VENT FAN (*KIT2)
19180442 АККУМУЛЯТОР KIT, DRV MOT (INCLS COMPLETE АККУМУЛЯТОР ASM, NEG TERM CVR & 4 SCREWS) (INCLS 1-25)
(TC02-990) - 2008-2009 CK107(06) АККУМУЛЯТОР/DRIVE MOTOR ЧАСТЬ 2 (HYBRID HP2)
25788330 LABEL, BAT DISPOSAL (*KIT2)
15906947 LABEL, HIGH VOLTAGE CONN CAUTION (*KIT2)
25870512 SENSOR, DRV MOT BAT CUR (*KIT2)
25925265 CLIP, BAT CBL (*KIT2)
25925268 CLIP, BAT CBL (*KIT2)
20805382 MODULE, DRV MOT GEN BAT CONT (*KIT2)
25870516 MODULE, DRV MOT GEN BAT CONT (*KIT2)
25870514 RESISTOR, DRV MOT BAT INV CUR LIM (*KIT2)
25870515 RELAY, DRV MOT BAT POS HIGH VOLTAGE CONTACTOR (*KIT2)
25871271 RELAY, DRV MOT PWR INV CUR LIM (*KIT2)
25926175 COVER, DRV MOT BAT (RIGHT SIDE) (*KIT2)
15906948 LABEL, BAT WRNG (LOCATED ON АККУМУЛЯТОР) (*KIT2)
25954276 LABEL, BAT WRNG (FIRST RESPONDER CAUTION LABEL) (*KIT2)
11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (BAT NEG CBL TERM) (*KIT1, KIT2) [БОЛТ М6]
25905443 COVER, BAT NEG CBL TERM (HIGH VOLTAGE TERMINAL COVER LABELED 5443) (*KIT1, KIT2)
25925282 ШЛАНГИ, DRV MOT BAT HIGH VOLTAGE MAN DISCONNECT KNOB (*KIT1, KIT2)
15293650 LEVER, DRV MOT BAT HIGH VOLTAGE MAN DISCONNECT (INCLS 43) (*KIT2)
25926173 COVER, DRV MOT BAT (FRT) (*KIT2)
teamcadillac.ru
19180442 АККУМУЛЯТОР KIT, DRV MOT (INCLS COMPLETE АККУМУЛЯТОР ASM, NEG TERM CVR & 4 SCREWS) (INCLS 74)
(TC02-992) - 2008-2009 CK107(06) АККУМУЛЯТОР ПРОВОДА-300 VOLT (HYBRID HP2)
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BAT POS & NEG CBL CLIP) [ГАЙКА М6]
teamcadillac.ru
11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (PART OF 1)
11561918 BOLT-HEX W/CON WA, M6X1X18, 10 THD, 14 OD, 8.8, GMW3359, MAT-PT, (BAT POS & NEG (300 V) CBL)
(TC02-994) - 2008-2009 CK107(06) ЖГУТЫ ПРОВОДОВ/КУЗОВ (HYBRID HP2)
teamcadillac.ru
20764828 HARNESS, BODY WRG (INCLS 3, 6) (USED ON VEH BUILT WITH 8-WAY CONN ON КОНСОЛЬ) (FOR 1ST DES SEE 25883112)
20830842 HARNESS, BODY WRG (INCLS 3, 6)
(TC02-996) - 2009 CK1 CONTROL MODULE/DRIVE MOTOR (HYBRID HP2)
24241225 COVER, DRV MOT PWR INV MDL
24241226 SEAL, DRV MOT PWR INV MDL CVR (*KIT1)
24241224 SEAL, DRV MOT GEN PWR INV MDL CBL HSG CVR (*KIT1)
24241227 SEAL, DRV MOT CONT MDL (*KIT1)
24248171 MODULE, ACSRY DC PWR CONT (WILL REQ 17 PCS OF 11570318 WHEN SERVICED T/W 12624430) (USE T/W SEAL KIT 19168315)
11900243 БОЛТ, HFH, M6X1X23, 17 THD, 14.2 O.D., 8.8, GMW3359, M-POINT, (ACSRY DC PWR CONT MDL SERV NTC)
teamcadillac.ru
11561918 BOLT-HEX W/CON WA, M6X1X18, 10 THD, 14 OD, 8.8, GMW3359, MAT-PT, (ACSRY AC & DC PWR CONT MDL TERM)
24241223 PIPE, DRV MOT GEN PWR INV MDL COOL INL
24240095 БОЛТ, DRV MOT GEN PWR INV MDL COOL INL PIPE
11900243 БОЛТ, HFH, M6X1X23, 17 THD, 14.2 O.D., 8.8, GMW3359, M-POINT, (DRV MOT GEN PWR INV MDL COOL OTL PIPE)
24241219 PIPE, DRV MOT GEN PWR INV MDL COOL OTL
24240088 SEAL, DRV MOT GEN PWR INV MDL COOL OTL PIPE (*KIT1)
24240087 БОЛТ, DRV MOT GEN PWR INV MDL CVR (M5X13X10.9)
19168315 SEAL KIT, DRV MOT GEN PWR INV MDL (INCLS 2, 3, 5, 13)
(TC02-999) - 2009 CK1 GENERATOR WIRING-3 PHASE (HYBRID HP2)
24243399 COVER, DRV MOT GEN PWR INV MDL (3 PHASE) CBL (INCLS 4)
24243398 БОЛТ, DRV MOT GEN PWR INV MDL CBL CVR (PART OF 3)
12624430 MODULE, DRV MOT GEN PWR INV (W/ 2ND MPU) (СМ. ГРУППУ 02.000 "CONTROL MODULE/DRIVE MOTOR" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА)
teamcadillac.ru
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DRV MOT GEN POWR INV MDL CBL BRKT) [ГАЙКА М6]
24246179 INSULATOR, DRV MOT PWR INV MDL CBL TERM EXT (PART OF 8)
24246180 BRACKET, DRV MOT GEN PWR INV MDL (3 PHASE) CBL (INCLS 7)
11515765 БОЛТ, HFH, M10X1.5X25, 22.30 O.D., HDR PT, 10.9, 7112M (DRV MOT GEN POWR INV MDL CBL BRKT)
11588711 БОЛТ, HFH, M6X1X16, 10 THD, 14.2 OD, 8.8 STL, GMW3359 (DRV MOT GEN PWR INV MDL (3 PHASE) CABLE)
(TS02-215) - 2009 CK1,2,3 КРЕПЛЕНИЕ СТАРТЕРА (LY6/6.0K,L76/6.0Y,L9H/6.2-2)
teamcadillac.ru
12588400 SHIELD, STRTR HT (SNAP-ON SHIELD)
19180528 STARTER, (REMAN) (ACDelco #323-1661) [СТАРТЕР]
11588456 БОЛТ, STRTR (M10X1.5X115) (ACDelco #11588456)
03 - ТОПЛИВНАЯ СИСТЕМА - ВЫХЛОПНАЯ - СИСТЕМЫ ВЫПУСКА ВОЗДУХА
(TC03-155) - 2009 CK1(06-36) FUEL CONTROL MODULE (LC9/5.3-3,LFA/6.0-5,LMG/5.3-0,LY2/4.8C,LY5/5.3J,L76/6.0Y,L9H/6.2-2)
20850907 MODULE, F/PMP FLOW CONT (ACDelco #20850907) [БЛОК УПРАВЛЕНИЯ БЕНЗОНАОСАМИ]
teamcadillac.ru
11569768 RETAINER, PUSH-IN, FIT HOLE 6.35, 20.32 LENGTH, 17.78 OD, 2.79-14.22 THK P (PART OF 4)
25943798 SHIELD, F/PMP FLOW CONT MDL (INCLS 3)
11562584 БОЛТ, F/PMP FLOW CONT MDL (3.887)
(TC03-237) - 2008-2009 CK107(06) HEAT SHIELDS/EXHAUST
15797116 SHIELD, EXH HT (@ DASH PNL)
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (EXH H/SHLD (AT DA PNL)) [ГАЙКА М6]
teamcadillac.ru
15169247 SHIELD, EXH HT
15804781 SHIELD, EXH FRT HT (AT F/FLR PNL)
11588331 ГАЙКА, HEX HD W/CON WA, M6X1, 5.7THK, 25 O.D., 9, GM6138M (EXH H/SHLD)
15291251 SHIELD, EXH HT (AT INTER FLR PNL)
15740776 SHIELD, EXH HT (AT INTER FLR PNL)
15102076 SHIELD, EXH HT (AT R/FLR PNL)
(TC03-242) - 2009 CK1 СИСТЕМА ВПУСКА ВОЗДУХА (LC9/5.3-3,LH6/5.3M,LMG/5.3-0,LY2/4.8C,LY5/5.3J,L76/6.0Y,L9H/6.2-2)
25782054 CLEANER, AIR (INCLS 13, 16-19)
teamcadillac.ru
25782055 CLEANER, AIR (INCLS 13, 16-19) [ВОЗДУШНЫЙ ФИЛЬТР ДВИГАТЕЛЯ]
11570290 БОЛТ, MASS AIRFLOW SEN
10393948 SENSOR, MASS AIRFLOW (W/INT AIR TEMP SEN) (INCLS 20) (ACDelco #213-4343)
15901934 DUCT, A/CL OTLT (INCLS 4, 6, 7) [ТРУБКА]
25346092 INSULATOR, A/CL HSG (PART OF 5) (3.270)
15066121 SUPPORT, A/CL [ОПОРА ВОЗДУХООЧИСТИТЕЛЯ]
20808321 SUPPORT, A/CL
11516424 БОЛТ, HFH, M6X1X25, 14.2 O.D., HDR PT, 9.8, ZE (A/CL ADAP SUPT) [БОЛТ М6]
11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (BAT TRAY REINF) [ШАЙБА]
25872321 BRACKET, A/CL ADAP (INCLS TWO GROMMETS) (INCLS 15) (DIESEL NOT STAMPED ON PART)
11514623 БОЛТ, HEX W/CON WA, M6X1X20 (A/CL ADAP)
25316546 FASTENER, A/CL (PART OF 1)
11516589 SCREW, HEX HD W/CON SPR WA, M6X1X30, 29 THD, 17 O.D., 9.8, 7114M, ZE (A/CL ADAP)
25346092 INSULATOR, A/CL BRKT (PART OF 11) (3.270)
15908915 ELEMENT, A/CL (PART OF 1) (ACDelco #A3085C) [ВОЗДУШНЫЙ ФИЛЬТР ДВИГАТЕЛЯ]
15908916 ELEMENT, A/CL (PART OF 1) (ACDelco #A3086C) [ВОЗДУШНЫЙ ФИЛЬТР ДВИГАТЕЛЯ]
11561933 БОЛТ, A/CL HSG CVR (PART OF 1) (M6X2.7X36) [БОЛТ]
11562129 БОЛТ, A/CL OTLT DUCT
(TC03-852) - 2009 CK1(06-36) ТОПЛИВНЫЙ БАК FILLER ТРУБКИ & HOSES (LY2/4.8C,LY5/5.3J,L76/6.0Y,L9H/6.2-2)
25852920 PIPE, F/TNK FIL (INCLS 2-5, 7-17, 20)
11610236 CLAMP, TYPE F WORM GEAR 20-1/4 HEX HD SAE 302 STL GM3044 9 (PART OF 1, 3)
15289733 HOSE, F/TNK FIL (INCLS 2) (PART OF 1) (FILL PIPE LOWER)
teamcadillac.ru
11610236 CLAMP, TYPE F WORM GEAR 20-1/4 HEX HD SAE 302 STL GM3044 9 (PART OF 1)
11516885 SCREW, HFH W/FL WA, TAP, M8X1.25X20, 7THD, 17 O.D., TR PT, 6202M, PZOR (F/TNK FIL & VENT HOSE BRKT)
12337820 STRAP, 15" TIE STRAP (PART OF 1) (ACDelco #12337820)
15844701 HOSE, F/TNK FIL VENT (INCLS 9) (PART OF 1)
15146021 CAP, F/TNK VENT PIPE (PART OF 1, 8)
10390321 HOSE, EVAP EMIS (PART OF 1)
15946264 HOSE, EVAP EMIS (PART OF 1)
15124940 HOSE, F/TNK FIL (PART OF 1) (FILL PIPE UPPER)
15217509 STRAP, F/TNK FIL PIPE GND (PART OF 1)
15714277 SCREW, W/WA AND SLR, M4.2X1.41X13, 5.4THD, 12.5 O.D., SELF TAP, ZC (PART OF 1)
25820825 CAP, F/TNK FIL (INCLS 18) (BUTTON TYPE TETHER) (ACDelco #GT289)
25827336 CAP, F/TNK FIL (INCLS 18) (YELLOW CAP FOR E85) (ACDelco #GT295) [КРЫШКА ТОПЛИВОЗАПРАВОЧНОЙ ГОРЛОВИНЫ]
11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (PART OF 1) [ШАЙБА]
15953840 SCREW, PAN HD TORX W/CON WA M6X1X25 AC PT 9.8 PC 12.5-OD (F/TNK FIL PIPE HSG) (3.003) [БОЛТ]
15845031 BUMPER, F/TNK FIL DR
25880365 ПРУЖИНА, F/TNK FIL DR (12.945) (PRIOR TO INSTALL SEAL VOIDS IN PLUNGER HSG W/FLEXIABLE SEALER) [ЗАЩЕЛКА ЛЮЧКА ТОПЛИВНОЙ ГОРЛОВИНЫ]
11561878 RETAINER, PUSH PIN W/SEAL, FITS 8.0-8.25 DIA HOLE IN 3-7MM THK PNL (F/TNK FIL PIPE HSG) [ФИКСАТОР ОПОРЫ БЛОКА УПРАВЛЕНИЯ]
15940678 DOOR, F/TNK FIL (INCLS 26)
15845031 BUMPER, F/TNK FIL DR (PART OF 25)
(TC03-903) - 2009 CK1 БЛОК ЭЛЕКТРОННОГО УПРАВЛЕНИЯ MODULE & ЖГУТЫ ПРОВОДОВ (LC9/5.3-3,LH6/5.3M,LMG/5.3-0,LY2/4.8C,LY5/5.3J,L76/6.0Y,L9H/6.2-2)
11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (FRT A/DFL) [БОЛТ М6]
11518121 ГАЙКА, U, M6X1, MULTI THD, .5'-4.0' THK PNL (PART OF 4)
15850348 BRACKET, ECM (INCLS 3) [ПЕТЛЯ КРЫШКИ БАГАЖНИКА]
12625455 MODULE, ENG CONT (W/ 2ND MPU) (W/O CALN) (ACDelco #12625455)
11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (ECM BRKT) (ACDelco #11517518) [БОЛТ]
(TC03-907) - 2009 CK107(06) СИСТЕМА ТОПЛИВОСНАБЖЕНИЯ-REAR (LY2/4.8C,LY5/5.3J,L76/6.0Y,L9H/6.2-2)
12522917 CONNECTOR KIT, FUEL FEED PIPE (PART OF 1, 3) (GREEN) (INCLS INST SHT & RET) (USE WITH 3/8 TUBE, NYLON) (3.162)
teamcadillac.ru
24100438 HOSE, FUEL FEED (INCLS 2)
25914594 HOSE, EVAP EMIS CNSTR PURGE (INCLS 5)
(TC03-917) - 2009 CK1(06-36) СИСТЕМА ОТРАБОТАВШИХ ГАЗОВ-V8 (L9H/6.2-2)
25904626 CONVERTER, 3WAY CTLTC (W/EXH MANIF PIPE) (3.685) [КАТАЛИТИЧЕСКИЙ НЕЙТРАЛИЗАТОР ВЫХЛОПНЫХ ГАЗОВ]
25904627 CONVERTER, 3WAY CTLTC (W/EXH MANIF PIPE) (3.685) [КАТАЛИТИЧЕСКИЙ НЕЙТРАЛИЗАТОР ВЫХЛОПНЫХ ГАЗОВ]
teamcadillac.ru
15709703 ГАЙКА, HEX 10X1.5THD, 21.8 OD SS (EXH MANIF PIPE) [ГАЙКА М10]
11589264 STUD, STRAIGHT, M10X1.5X30, M10X1.5X16, 57 TL, SS (EXH MANIF PIPE) [ШПИЛЬКА М8]
15077362 SEAL, EXH MANIF PIPE [САЛЬНИК ГЛУШИТЕЛЯ]
15035747 SEAL, EXH MANIF PIPE [УПЛОТНИТЕЛЬНАЯ ВТУЛКА ГЛУШИТЕЛЯ]
12583804 SENSOR, HTD OXY (POSN 2) (ACDelco #213-3866) [КИСЛОРОДНЫЙ ДАТЧИК]
15709703 ГАЙКА, HEX 10X1.5THD, 21.8 OD SS (EXH MUFF) [ГАЙКА М10]
15028620 STUD, EXH PIPE (PART OF 12) (M10X1.5X30MM) (BUTTON HEAD) [ШПИЛЬКА]
20757529 MUFFLER, EXH (W/RESO, EXH & TAIL PIPE) (INCLS 11)
15092802 INSULATOR, EXH MUFF HNGR [ДЕМПФЕР ГЛУШИТЕЛЯ]
(TC03-918) - 2007-2009 CK1(06-36) ТОПЛИВНЫЙ БАК
10325852 RING, FUEL SDR (130 MM OPENING CAM LOCK RING) (3.115) (ACDelco #TR26) [ОПОРНОЕ КОЛЬЦО ТОПЛИВНОГО НАСОСА]
13502903 SENSOR, F/TNK PRESS (PART OF 4) (ACDelco #13502903) [ДАТЧИК ДАВЛЕНИЯ ТОПЛИВНОЙ СИСТЕМЫ]
19179870 SENSOR KIT, FUEL LVL (ACDelco #SK1297)
19181001 SENSOR KIT, FUEL LVL (ACDelco #SK1305) [ДАТЧИК УРОВНЯ ТОПЛИВА]
teamcadillac.ru
19181000 MODULE KIT, F/PMP CYC CONT (W/O FUEL LVL SEN) (INCLS 2, 5) (INCLS NON-SERVICEABLE LIFETIME FILTER) (ACDelco #M10191) [ТОПЛИВНЫЙ НАСОС]
19206650 MODULE KIT, F/TNK F/PMP (W/O FUEL LVL SEN) (INCLS 2, 5) (ACDelco #M10222) [ТОПЛИВНЫЙ НАСОС]
22682111 SEAL, FUEL SDR (O RING) (PART OF 4) (135.5 MM ID X 147.5MM OD X 6MMTALL) (ACDelco #G41) [ПРОКЛАДКА]
25904452 TANK, FUEL
25920048 TANK, FUEL
15078884 SHIELD, F/TNK RR
10009923 ГАЙКА, BOLT RETAINING ПРУЖИНА, M8X1.25, 25 O.D., ZOR (F/TNK SHLD)
15168952 RETAINER, F/TNK H/SHLD
15836686 SHIELD, F/TNK HT
(TC03-919) - 2007-2009 CK1(06-36) КРЕПЛЕНИЕ ТОПЛИВНОГО БАКА
11517806 NUT-U, M10X1.5, 30.5X28.6, 15.5 C/E, 2-5 PNL, 1050, 7111M (F/TNK STRP)
15745096 STRAP, F/TNK (REAR)
15745095 STRAP, F/TNK (FRONT)
11519894 BOLT-HEX W/CON WA, M10X1.5X55, 42.3 THD, 20 OD, 10.9, 7114M, MACH, MAT-PT (F/TNK STRP)
(TC03-987) - 2008-2009 CK107(06) УГОЛЬНЫЙ ФИЛЬТР & СОПРЯЖЕННЫЕ ДЕТАЛИ (HYBRID HP2)
15286158 CANISTER, EVAP EMIS (W/O VENT VLV SOL) (WITHOUT BRACKET) (*KIT1) (ACDelco #215-638)
10200334 БОЛТ, EVAP EMIS CNSTR BRKT (M8X1.25X30) (W/FLAT WASHER) (*KIT1) (12.243)
15286150 BRACKET, AUX EVAP EMIS CNSTR (*KIT2)
11516885 SCREW, HFH W/FL WA, TAP, M8X1.25X20, 7THD, 17 O.D., TR PT, 6202M, PZOR (EVAP EMIS CNSTR VENT SOL VLV BRKT)
11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (AUX EVAP EMIS CNSTR BRKT) (*KIT2) [БОЛТ М6]
15286148 CANISTER, AUX EVAP EMIS (*KIT2)
11516075 ГАЙКА, HFH SELF LK, M6X1, 7.7THK, 14.2 O.D., 9, PZOR (AUX EVAP EMIS CNSTR BRKT) (*KIT2) [ГАЙКА ВЫПУСКНОЙ СИСТЕМЫ D=6ММ]
25932566 VALVE, AUX EVAP EMIS CNSTR PURGE SOL (*KIT2)
15896282 CLIP, EVAP EMIS CNSTR HOSE (PART OF 11) (IN LINE CLIP)
15011302 CLIP, EVAP EMIS CNSTR HOSE (PART OF 11)
11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (EVAP EMIS CNSTR) (ACDelco #11570082) [БОЛТ М8]
15113366 BRACKET, EVAP EMIS CNSTR (*KIT1)
teamcadillac.ru
15286108 CANISTER, EVAP EMIS (INCLS 1, 2, 15) (WITH BRACKET) (ACDelco #215-637)
15286109 CANISTER, AUX EVAP EMIS (INCLS 3-5, 7-10)
(TC03-990) - 2009 CK1(06-36) СИСТЕМА ТОПЛИВОСНАБЖЕНИЯ-FRONT (LC9/5.3-3,LMG/5.3-0,LY2/4.8C,LY5/5.3J,L76/6.0Y,L9H/6.2-2)
22695614 RETAINER, FUEL FEED HOSE CONN (13 X 19 X 36MM) (ONE TUBE) [ОПОРНАЯ ПЛАНКА ТРУБКИ ТОПЛИВНОЙ СИСТЕМЫ]
15946243 HOSE, FUEL FEED (INCLS 15) [ТРУБКА ТОПЛИВНОЙ СИСТЕМЫ]
15946264 HOSE, EVAP EMIS (INCLS 16)
15085402 BRACKET, FUEL FEED & EVAP EMIS & RTN HOSE
11514596 ГАЙКА, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (FUEL FEED & RTN FRT HOSE BRKT) (8.915) (ACDelco #11514596)
teamcadillac.ru
15168648 CLIP, FUEL FEED & EVAP EMIS & RTN HOSE (W/RETAINER)
15085405 CLIP, FUEL FEED & EVAP EMIS & RTN HOSE (CLIP - 1.36" LENGTH, MAT'L NYLON BLACK)
15085404 CLIP, FUEL FEED & EVAP EMIS & RTN HOSE (AT HOSE/PIPE CONNECTION)
15126012 BRACKET, FUEL FEED & EVAP EMIS & RTN PIPE CLIP
11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (FUEL FEED & EVAP EMIS & RTN PIPE CLIP BRKT) (ACDelco #11570082) [БОЛТ М8]
15168649 CLIP, FUEL FEED & EVAP EMIS & RTN HOSE (ANTI-RATTLE)
15168646 CLIP, FUEL FEED & EVAP EMIS & RTN HOSE (PART OF 3) (2 TUBE)
15778699 SEAL, FUEL PRESS SEN (O RING)
15239857 SENSOR, FUEL PRESS (PART OF HOSE ASSEMBLY 25813125 LABELED 3125) (3.682) (ACDelco #213-3837) (PART OF HOSE ASSEMBLY 25949801 LABELED 9801)
11516703 БОЛТ, HEX, M4.8X1.6X13, 20 OD, 6010M MAT, 6047M FIN (FUEL FEED & RTN FRT HOSE BRKT) (8.977)
15124945 BRACKET, FUEL FEED & RTN FRT HOSE
11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (FUEL FEED & RTN FRT HOSE BRKT) [БОЛТ М6]
11514597 ГАЙКА, HFH, 10X1.5 THD, 9.8 THK, 21.8 OD, 510M (10) ZF 7111M (TRFER CASE) (2.383)
15033698 BRACKET, FUEL FEED & RTN PIPE
(TC04-038) - 2008-2009 CK1(06) АКСЕЛЕРАТОР (POWER ADJUSTABLE PEDAL JF4, AN3)
25863989 BRACKET, BRK & ACCEL PED (INCLS 5, 7) (ТОРМОЗНАЯ ПЕДАЛЬ) (4.634)
25863990 BRACKET, BRK & ACCEL PED (INCLS 5, 7) (ТОРМОЗНАЯ ПЕДАЛЬ) (4.634)
15000145 БОЛТ, BRK PED PIV (12X1.75X120, 25)
11514598 ГАЙКА, BRK PED PIV (HF 12X1.75) (8.915) [ГАЙКА М12]
11517182 БОЛТ, BRK PED BRKT (M10X1.5X30, 15 THD) (8.900)
11517996 ГАЙКА, P/B BOOS (M10X1.5, 11.2 THK) (8.917) [ГАЙКА М10]
11562023 БОЛТ, ELEK THROT ACTR (PAN HEAD, M6X1X40, 15 THD, 12 OD, 10.9 STL, GM4277, HDR PT)
15123616 ACTUATOR PKG, THROT
25863992 BRACKET KIT, ACCEL PED ("IF REPL ACCL PDL BRKT W/2-BOLT CBL ATTACHMENT AT ADJ PDL MOTOR, REQUIRES CORRESPONDING BRK PEDAL ASM.")
11505213 ГАЙКА, PUSH ON, M8, 1.96THK, 16.03 O.D., STL, PC (PART OF 17)
15685170 ГАЙКА, HEX-HD, W/FL WA, M6X1, 5.5 THK, 9, 7111M, 2MM THK 19 OD WA, NYLOC (ACCEL PED LVR) (8.917)
11516424 БОЛТ, HFH, M6X1X25, 14.2 O.D., HDR PT, 9.8, ZE (ACCEL PED LVR) [БОЛТ М6]
25832864 PEDAL, ACCEL (INCLS 13) (INCLS POSITION SENSOR)
25981009 SWITCH, S/LP (ACDelco #D1539J) [КОНЦЕВОЙ ВЫКЛЮЧАТЕЛЬ ПЕДАЛИ ТОРМОЗА]
11569844 RETAINER, BRK PED PUSH ROD (WITH BOLT)
15200851 BUSHING, BRK PED PIV [НАКЛАДКА]
25968689 PEDAL, BRK (INCLS 8, 9, 24-28) (IF REPL BRK PDL W/ 2-BOLT CBL ATTCHMNT AT ADJ PDL MOTOR, REQUIRES ACCEL BRKT KIT W/ CBL, PN 25863992)
11516424 БОЛТ, HFH, M6X1X25, 14.2 O.D., HDR PT, 9.8, ZE (BRK PED POSN SEN) (*KIT1) [БОЛТ М6]
88982977 SENSOR, BRK PED POSN (PART OF 22) (*KIT1)
teamcadillac.ru
88982976 PAD, BRK PED (PART OF 22)
88982977 SENSOR, BRK PED POSN (INCLS 23, 24, 28)
(TX03-040) - 2009 CK1,2,3 РАМКА ТОПЛИВНОГО ИНЖЕКТОРА (LC9/5.3-3,LMG/5.3-0,LY6/6.0K,L76/6.0Y,L9H/6.2-2)
25532662 CAP, FUEL PRESS SERV VLV (PART OF 510) (CAP FOR PRESSURE TEST SCHRADER VALVE) (3.163) (ACDelco #214-1044) [КРЫШКА]
teamcadillac.ru
12609749 INJECTOR, SEQ M/PORT FUEL (INCLS RETAINER, SEALS) (INCLS 521, 532, 534) (ACDelco #217-3410)
89017372 RETAINER KIT, F/INJR (INCLS 521) (ACDelco #89017372)
19169305 SEAL KIT, M/PORT F/INJR (INCLS 532, 534) (ACDelco #217-3092)
19207932 SEAL KIT, M/PORT F/INJR (INCLS 532, 534) (ACDelco #217-3361)
(GM04-555) - 2007-2009 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) АКПП БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ
24227130 БОЛТ, C/VLV UPR BODY (M5X0.8X36)
24225398 БОЛТ, A/TRNS INPUT & OUTPUT SPD SEN (M6 X 1.0 X 20)
24238417 SENSOR, A/TRNS INPUT & OUTPUT SPD (INCLS 316) (4.329) [ДАТЧИК ЧИСЛА ОБОРОТОВ ВАЛА AКПП]
24231442 BODY, C/VLV UPR (MUST USE T/W 24236934/PLATE KIT - CONT SOL VLV FLTR)
24245720 PLATE, C/VLV BODY SPCR (W/GSKT) (ACDelco #24245720) [НАБОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АКПП]
96020431 VALVE, C/VLV BODY BALL CHK [КЛАПАН]
24250384 BODY, C/VLV LWR (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ/НИЖНИЙ КЛАПАН РЕГУЛЯТОР BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (MANUAL VALVE NOT INCLUDED) (MUST USE T/W 24236934/PLATE KIT - CONT SOL VLV FLTR)
24246427 SWITCH, A/TRNS MAN SHFT SHF POSN (INCLS 315) (INTERNAL MODE SWITCH) [ВКЛЮЧАТЕЛЬ]
24224821 БОЛТ, C/VLV LWR BODY (M5X0.8X45)
24224822 БОЛТ, C/VLV LWR BODY (M5X0.8X55)
24236934 PLATE KIT, CONT SOL VLV FLTR [ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АКПП]
24240845 БОЛТ, CONT SOL VLV HEAT SINK (W/ BODY & TCM) (M5X0.8X53.0)
24241890 VALVE, CONT SOL (W/ BODY & TCM) (ACDelco #24241890) (ORDER T/W 24236927 SEAL KIT) [ГИДРОРАСПРЕДЕЛИТЕЛЬНЫЙ БЛОК АКПП]
24236233 CLIP, A/TRNS MAN SHFT SHF POSN SW WRG HARN (PART OF 308)
teamcadillac.ru
24236504 CLIP, A/TRNS INPUT & OUTPUT SPD SEN WRG HARN (PART OF 303)
(GM04-556) - 2007-2009 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) ВЕРХНИЙ КЛАПАН РЕГУЛЯТОР BODY ASSEMBLY
24224766 PIN, C/VLV BODY LOC (DIA.=10MM L=12.7) [ВТУЛКА ГИДРОРАСПРЕДЕЛИТЕЛЯ АКПП]
24231442 BODY, C/VLV UPR (INCLS 324-327, 329, 330, 334-338) (MUST USE T/W 24236934/PLATE KIT - CONT SOL VLV FLTR)
24230200 PIN, C/VLV BODY LOC (DIA.=10MM L=29.9) [ВТУЛКА ГИДРОРАСПРЕДЕЛИТЕЛЯ АКПП]
24224755 RETAINER, 1-2-3-4 CLU BOOST VLV SPR [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АКПП]
teamcadillac.ru
24242814 PLUG, 1-2-3-4 CLU REG VLV BORE (9.5 THK, 11.5 DIA)
(GM04-557) - 2007-2009 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) НИЖНИЙ КЛАПАН РЕГУЛЯТОР BODY ASSEMBLY
24224755 RETAINER, CLU PSTN DAM FEED REG VLV SPR [УПОРНАЯ ПЛАСТИНА ГИДРОРАСПРЕДЕЛИТЕЛЯ АКПП]
24242814 PLUG, CLU SEL SOL VLV BORE #2 (9.5 THK, 11.5 DIA)
24250384 BODY, C/VLV LWR (INCLS 338, 352, 353, 355-357) (MANUAL VALVE NOT INCLUDED) (MUST USE T/W 24236934/PLATE KIT - CONT SOL VLV FLTR)
24224770 VALVE, MAN (ACDelco #24224770)
teamcadillac.ru
(GM04-559) - 2007-2009 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) 4-5-6 ДЕТАЛИ СЦЕПЛЕНИЯ & ВАЛ ТУРБИНЫ
24233406 RING, 4-5-6 CLU BKG PLT RET (PURPLE) (2.49MM +/- 0.05)
24233407 RING, 4-5-6 CLU BKG PLT RET (YELLOW) (1.65MM +/- 0.05)
24233408 RING, 4-5-6 CLU BKG PLT RET (NONE) (2.07MM +/- 0.05)
24240654 PLATE, 4-5-6 CLU BKG
24224158 PLATE, 4-5-6 CLU (PKG OF 7) (FIBER) (*KIT1) [ДИСК АКПП]
24224648 PLATE, 4-5-6 CLU (PKG OF 7) (STEEL)
24224647 PLATE, 4-5-6 CLU (WAVED)
teamcadillac.ru
24237851 RING KIT, RET (1234 DAM, 1234 HSG, 456 DAM) (4.224)
24232417 DAM, 4-5-6 CLU PSTN
24224714 ПРУЖИНА, 4-5-6 CLU
24232416 PISTON, 4-5-6 CLU
24237556 ШЛАНГИ, 4-5-6 CLU (W/ INPUT SHF) (INCLS 440) (ACDelco #24237556) [ЗУБЧАТЫЕ КОЛЬЦА АВТОМАТИЧЕСКОЙ ТРАНСМИССИИ]
24224655 RING, TURB SHF FLUID SEAL (ACDelco #24224655)
24219390 SEAL, TURB SHF (O RING) (ACDelco #24219390)
24248008 PLATE KIT, CLU (INCLS 433) (ACDelco #24248008)
(GM04-560) - 2007-2009 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) 2-6 ДЕТАЛИ СЦЕПЛЕНИЯ
24232994 RING, 2-6 CLU BKG PLT RET
24224171 PLATE, 2-6 CLU BKG
24240221 PLATE, 2-6 CLU (PKG OF 6) (FIBER) (*KIT1)
teamcadillac.ru
24232497 PLATE, 2-6 CLU (PKG OF 6) (STEEL)
24224659 PLATE, 2-6 CLU (WAVED)
24235463 RING, 2-6 CLU SPR RET
24224725 ПРУЖИНА, 2-6 CLU
24224169 PISTON, 2-6 CLU
24232457 SUPPORT, CTR (INCLS 458, 460)
24248008 PLATE KIT, CLU (INCLS 452) (ACDelco #24248008)
(GM04-561) - 2007-2009 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) LOW & REVERSE ДЕТАЛИ СЦЕПЛЕНИЯ
24232457 SUPPORT, CTR (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ/CLUTCH" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА)
24224737 RING, LOW & REV CLU BKG PLT RET (2.31MM +/- 0.05)
24245063 RING, LOW & REV CLU BKG PLT RET (1.90MM +/- 0.05)
24245064 RING, LOW & REV CLU BKG PLT RET (2.72MM +/- 0.05)
24224175 PLATE, LOW & REV CLU BKG
24240041 PLATE, LOW & REV CLU (*KIT1) (ACDelco #24240041)
24232496 PLATE, LOW & REV CLU (PKG OF 6) (STEEL) (ACDelco #24232496)
24224734 PLATE, LOW & REV CLU (WAVED) (ACDelco #24224734)
24224733 RING, LOW & REV CLU SPR RET (4.189)
24248957 SPRAG KIT, LOW CLU (TRANS BUILT 11-01-06 & AFTER)
24243898 SEAL KIT, A/TRNS SERV (CLUTCHES) (ACDelco #24243898)
24224732 ПРУЖИНА, LOW & REV CLU (ACDelco #24224732)
24224172 PISTON, LOW & REV CLU (ACDelco #24224172)
teamcadillac.ru
24248008 PLATE KIT, CLU (INCLS 463) (ACDelco #24248008)
(GM04-562) - 2007-2009 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) CLUTCH HUB ASSEMBLY
24238004 HUB, 4-5-6 CLU (W/ OUTPUT CARR SHF & DPNR) (INCLS 476-478)
teamcadillac.ru
24230368 DAMPENER, 4-5-6 CLU (PART OF 475)
24233359 PLATE, 4-5-6 CLU DPNR APPLY (PART OF 475)
24230370 RING, 4-5-6 CLU DPNR RET (PART OF 475)
(GM04-563) - 2007-2009 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) OUTPUT CARRIER ASSEMBLY
teamcadillac.ru
24224853 BEARING, CTR SUPT RLR (PART OF 490)
24224176 BEARING, OUTPUT CARR OTR SUN GR FRT THR (PART OF 490)
24224177 GEAR, OUTPUT CARR FRT SUN (PART OF 490) (ACDelco #24224177)
24224178 BEARING, OUTPUT CARR OTR SUN GR RR THR (PART OF 490)
24235435 GEAR, OUTPUT CARR RR SUN (PART OF 490)
24224747 CARRIER, OUTPUT (INCLS 485-489, 491) (ACDelco #24224747)
(GM04-640) - 2007-2009 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) 1-2-3-4 & 3-5 REVERSE ДЕТАЛИ СЦЕПЛЕНИЯ
24240197 RING, 1-2-3-4 CLU BKG PLT RET (NO COLOR) (2.42-2.52) (ACDelco #24240197)
24240198 RING, 1-2-3-4 CLU BKG PLT RET (PURPLE) (2.69-2.79) (ACDelco #24240198)
24240199 RING, 1-2-3-4 CLU BKG PLT RET (BLUE) (2.96-3.06)
24240200 RING, 1-2-3-4 CLU BKG PLT RET (ORANGE) (3.23-3.33)
24240201 RING, 1-2-3-4 CLU BKG PLT RET (WHITE) (3.50-3.60) (ACDelco #24240201)
24224149 PLATE, 3-5 REV CLU BKG
24235681 PLATE, 3-5/REV CLU (PKG OF 5) (FIBER) (*KIT4)
24232498 PLATE, 3-5 REV CLU (PKG OF 5) (STEEL)
24239828 PLATE, 3-5 REV CLU (WAVED)
24224633 RING, 3-5-REV CLU APPLY (ACDelco #24224633)
24222632 PLATE, 1-2-3-4 CLU BKG
24224147 PLATE, 1-2-3-4 CLU (PKG OF 6) (FIBER) (*KIT4)
24238701 PLATE, 1-2-3-4 CLU (STEEL)
24239615 PLATE, 1-2-3-4 CLU (WAVED)
24224708 DAM, 1-2-3-4 CLU PSTN
24224707 ПРУЖИНА, 1-2-3-4 CLU
24238700 PISTON, 1-2-3-4 CLU
24238698 ШЛАНГИ, 1-2-3-4 CLU PSTN (ACDelco #24238698)
24237308 ПРУЖИНА, 3-5-REV CLU
24238696 PISTON, 3-5/REV CLU (INCLS 422) (ACDelco #24238696)
24237185 ШЛАНГИ, 1-2-3-4 & 3-5 REV CLU (INCLS 426) (ORDER T/W 24226393)
24226393 BEARING, 1-2-3-4 & 3-5-REV CLU
teamcadillac.ru
24248578 SEAL KIT, A/TRNS SERV (INLCS 411, 415, 416, 419, 423-425) (FULL TRANS) (ACDelco #24248578)
24237851 RING KIT, RET (INCLS 411, 415) (1234 DAM, 1234 HSG, 456 DAM) (4.224)
24243898 SEAL KIT, A/TRNS SERV (INCLS 416, 418, 419, 422-425) (CLUTCHES) (ACDelco #24243898)
24248008 PLATE KIT, CLU (INCLS 402, 408) (ACDelco #24248008)
(GM04-666) - 2009 CK1(06-36) УСИЛИТЕЛЬ ТОРМОЗОВ (JD9)
25827889 BOOSTER, P/B (INCLS 2-4) [ВАКУУМНЫЙ УСИЛИТЕЛЬ ТОРМОЗОВ]
teamcadillac.ru
15823207 VALVE KIT, P/B BOOS VAC CHK (PART OF 1) (INCLS 2)
15823208 SENSOR KIT, P/B BOOS VAC (PART OF 1) (INCLS 2) (ACDelco #15823208)
(TC04-038) - 2008-2009 CK1,2(06-36) ТОРМОЗНАЯ ПЕДАЛЬ (POWER ADJUSTABLE PEDAL JF4, AN3)
teamcadillac.ru
15936751 HARNESS, FUSE BLK WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА)
25776703 HARNESS, FUSE BLK WRG (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА)
25968689 PEDAL, BRK (INCLS 8-9, 24-28) (IF REPL BRK PDL W/ 2-BOLT CBL ATTCHMNT AT ADJ PDL MOTOR, REQUIRES ACCEL BRKT KIT W/ CBL, PN 25863992)
11516424 БОЛТ, HFH, M6X1X25, 14.2 O.D., HDR PT, 9.8, ZE (BRK PED POSN SEN) [БОЛТ М6]
(TC04-162) - 2009 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА АКПП (6L80 AUTOMATIC MYC)
15779543 PIPE, TRANS FLUID AUX CLR INL (INCLS 2, 5-7) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ]
15052228 CAP, TRANS FLUID CLR PIPE CONN (PART OF 1, 9) (PLASTIC RETAINER) (ACDelco #15052228) [ФИТИНГ ТРУБОПРОВОДА]
15226661 CONNECTOR, TRANS FLUID CLR PIPE (INCLS 4) (9/16-18) (3/8 BODY QUICK CONNECT) (AT RAD) (ACDelco #15226661)
24205103 RETAINER, TRANS FLUID CLR PIPE FTG (PART OF 3, 15, 16) (EXPANDING ПРУЖИНА WIRE) (ACDelco #24205103) [СТОПОРНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ]
14093869 ГАЙКА, PUSH ON, M6, 2.25THK, 12.95 O.D., STL, POR (PART OF 1, 9)
15782677 CLIP, TRANS FLUID CLR PIPE (PART OF 1, 9)
11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (PART OF 1, 9) [БОЛТ М6]
15068848 SPACER, TRANS FLUID CLR PIPE (HOLDS 2-9.5MM (3/8") DIA ТРУБКИ , CLIP TOP)
25999420 PIPE, TRANS FLUID CLR (INCLS 2, 5-7, 19) (ACDelco #25999420) [ТРУБКА СИСТЕМЫ ОХЛОЖДЕНИЯ]
11519797 STUD, TRANS (DOUBLE END, HFH, M8X1.25X20, M10X1.5X40, 18 OD, 69.5 TL9.8, GMW3359)
15120618 BRACKET, TRANS FLUID CLR PIPE
15049288 RETAINER, TRANS FLUID CLR PIPE (BLACK) (37.7X39.3) (DOUBLE SNAIL CLIP)
teamcadillac.ru
15022958 CLIP, TRANS FLUID CLR PIPE (RETAINS 9.5MM STL TUBING) (2.343)
11516521 БОЛТ, HFH M6X1X20, 9.8, 7114M, DOG PT, 14.2 OD (TRANS FLUID CLR PIPE CLIP)
25891509 COOLER, TRANS FLUID AUX (CODE 4639, 5464, 9344, 7192) (INCLS 4, 16, 17) (TRUCKS W/2PC STEEL BRACKETS ALSO REQ 11519377 BOLT QTY 2) (ACDelco #25891509)
19210848 CONNECTOR, TRANS FLUID CLR PIPE (PART OF 15) (INCLS 4) (W/O BEVEL WASHER) (ACDelco #19210848)
11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (PART OF 15) [ШАЙБА]
11519377 БОЛТ, HEX HD W/FL WA, M6X1X28, 18.15 THD, 17 OD, 8.8 STEEL, GMW3359 (TRANS FLUID CLR)
15251488 SEAL, TRANS FLUID CLR PIPE (PART OF 9) (SEALS TWO ТРУБКИ ) [УПЛОТНЕНИЕ]
11515758 БОЛТ, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (TRANS FLUID CLR PIPE) [БОЛТ, М8Х1.25Х31.5]
(TC04-602) - 2007-2009 K1,2,3 КОРПУС КП SHIELD (NZZ)
teamcadillac.ru
15049809 SHIELD, TRFER CASE [ЗАЩИТА]
11518341 БОЛТ, HEX, M10X1.5X25, 14 THD, 28 OD, 6202M, 7114M, TAP, TR-PT (TRFER CASE SHLD) [БОЛТ М10Х1.5Х25]
(TC04-654) - 2007-2009 CK1 ТОРМОЗНОЙ СУППОРТ-ПЕРЕДНИЙ
15904194 CALIPER, FRT BRK (INCLS 2, 3, 6-9) (ACDelco #172-2402) [ТОРМОЗНОЙ СУППОРТ]
15904195 CALIPER, FRT BRK (INCLS 2, 3, 6-9) (ACDelco #172-2408) [СУППОРТ ТОРМОЗА]
25846360 VALVE, FRT BRK CLPR BLEDR (DELPHI CHASSIS, M10 X 1.5) (PART OF 1) (M10X1.5) (ACDelco #25846360)
25846359 COVER, FRT BRK BLEDR SCREW (PART OF 1) (4.665)
15125961 БОЛТ, FRT BRK CLPR BRKT (*KIT1, KIT3)
25951292 SEAL KIT, FRT BRK CLPR PSTN (INCLS 9) (PART OF 1) [КОМПЛЕКТ УПЛОТНИТЕЛЬНЫХ КОЛЕЦ ТОРМОЗНОГО СУППОРТА (2ШТ)]
teamcadillac.ru
15125962 PISTON, FRT BRK CLPR (PART OF 1)
25910434 BRACKET KIT, FRT BRK CLPR [СКОБА ТОРМОЗНОГО СУППОРТА]
25910435 BRACKET KIT, FRT BRK CLPR [СКОБА ТОРМОЗНОГО СУППОРТА]
25910433 PIN KIT, FRT BRK CLPR GDE (INCLS 4, 5, 7, 12) (DOES NOT INCLUDE SHIMS & BOLTS) [КОМПЛЕКТ ПРИЖИМНЫХ ПЛАСТИН И НАПРАВЛЯЮЩИХ ТОРМОЗНОГО СУППОРТА]
15299068 BUSHING KIT, FRT BRK CLPR GDE PIN (INCLS 7) [КОМПЛЕКТ ВТУЛОК ТОРМОЗНОГО СУППОРТА]
25910430 PAD KIT, FRT DISC BRK (INCLS 4, 10, 12)
25910432 PAD KIT, FRT DISC BRK (INCLS 4, 10, 12) [КОЛОДКИ]
25918342 PAD KIT, FRT DISC BRK (INCLS 4, 10, 12) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4 ШТ)]
(TC04-718) - 2007-2009 K1 FRAME/TRANSMISSION SUPPORTS
11589247 BOLT-HFH, M14X2X165.5, 58.2 THD, 30.5 ID, 10.9, 7114M, MACH, CONE-PT (TRANS SUPT C/MBR)
11516382 ГАЙКА, HFH LK M14X2X15, 28 OD 10 7111M (TRANS SUPT C/MBR) [ГАЙКА М10]
teamcadillac.ru
15894408 CROSSMEMBER, TRANS SUPT
(TC04-746) - 2009 CK1(06-36) TRAILER BRAKE CONTROL (JL1)
25848909 RELAY, TRLR BRAKE CONT (ACDelco #25848909)
25866061 MODULE, TRLR BRK CONT
11562584 БОЛТ, TRLR BRK CONT MDL (3.887)
15926102 SWITCH, TRLR BRAKE CONT
(TC04-901) - 2007-2009 CK1 TRANSMISSION FILLER TUBE & INDICATOR (4L80 AUTOMATIC MYC)
15877378 INDICATOR, TRANS FLUID LVL
11516780 ГАЙКА, HEX W/CON WA, M8X1.25, 10THK, 19 O.D., 10, 7111M (TRANS FLUID FIL TUBE) (8.917) [ГАЙКА М8]
15796802 SEAL, TRANS FLUID FIL TUBE [УПЛОТНИТЕЛЬ ШЛАНГА МАСЛОПРОВОДА]
teamcadillac.ru
15029928 БОЛТ, TRANS H/SHLD (M8X1.25X12)
25980339 SHIELD, TRANS HT
(TC04-904) - 2007-2009 CK1 УПРАВЛЕНИЕ АКПП/АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (6L80 AUTOMATIC MYC)
15831435 BRACKET, A/TRNS RANGE SEL LVR CBL
teamcadillac.ru
20787608 CABLE, A/TRNS RANGE SEL LVR (AT TRNS) (LOWER CABLE) (WHEN REPLACING MUST REPLACE UPPER CABLE)
25995564 CABLE, A/TRNS RANGE SEL LVR (UPPER CABLE) [ТРОС АКПП В ПЛАСТИКОВОЙ ОБОЛОЧКЕ]
15116345 RETAINER, A/TRNS RANGE SEL LVR CBL (AT TRNS) [ОПОРНАЯ СКОБА ТРОСИКА АКПП]
11610265 БОЛТ, PAN HD W/FL WA, M8X1.25X21.5, 15 THD, 22 OD, 8.8, GMW3044 (A/TRNS RANGE SEL LVR CBL BRKT)
15915999 LEVER, A/TRNS RANGE SEL LVR EQLZR
11514597 ГАЙКА, HFH, 10X1.5 THD, 9.8 THK, 21.8 OD, 510M (10) ZF 7111M (A/TRNS RANGE SEL LVR EQLZR LVR) (2.383)
15116345 RETAINER, A/TRNS RANGE SEL LVR CBL [ОПОРНАЯ СКОБА ТРОСИКА АКПП]
20787608 CABLE, A/TRNS RANGE SEL LVR (AT TRNS) (INCLS 2, 3) (LOWER CABLE) (WHEN REPLACING MUST REPLACE UPPER CABLE)
(TC04-906) - 2009 CK1(06) BRAKE CALIPER MOUNTING/FRONT & KNUCKLE (EXC POLICE PACKAGE PPV)
15719028 БОЛТ, FRT WHL BRG (M14X1.5X70) (6.104) [БОЛТ М14]
15016308 БОЛТ, M14X2X40, 40 THD, 28 OD, 10.9, GM6174M, LOCTITE PATCH GM6194M (S/KNU) (4.665)
11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (FRT WHL SPD SEN) [БОЛТ М6]
15133409 BRACKET, FRT WHL SPD SEN
15942236 KNUCKLE, STRG (MCHG)
15942237 KNUCKLE, STRG (MCHG) [ПОВОРОТНЫЙ КУЛАК ПОДВЕСКИ]
25918337 SHIELD, FRT BRK
25918338 SHIELD, FRT BRK
15715956 CLIP, WHL SPD SEN WIRE (PART OF 11, 14) (10.00MM) (1 HOLE CLIP)
teamcadillac.ru
15267361 CLIP, WHL SPD SEN WIRE (PART OF 11, 14) (CLAM SHELL WITHOUT ALIGNMENT PIN)
15229013 CLIP, WHL SPD SEN WIRE (PART OF 11, 14) (SLIDE LOCK WITH ALIGNMENT PIN)
15229012 SENSOR, FRT WHL SPD (INCLS 8-10) (PART OF 14) (ACDelco #15229012) (FOR VEHICLES WITH RPO PPV-USE T/W THERMAL WRAP PN 19207924, BETWEEN WHEEL SPEED SENSOR HEAD AND FIRST CLIP.) [ДАТЧИК АБС (КОЛИЧЕСТВА ОБОРОТОВ КОЛЕСА)]
15960191 БОЛТ, WHL SPD SEN (PART OF 14) (M6X1X12)
11588810 STUD, FRT WHL (PART OF 14) (M14X1.5X65) [ШПИЛЬКА КРЕПЛЕНИЯ КОЛЕСА]
25918329 HUB, FRT WHL (W/WHL SPD SEN) (INCLS 8-13) (ACDelco #FW346)
25819670 ROTOR, FRT BRK (13IN) (ACDelco #177-1014) [ТОРМОЗНОЙ ДИСК]
11609271 БОЛТ, FRT BRK ROT (M8 X 1.25 X 20)
(TC04-907) - 2007-2009 CK1(06-36) ТОРМОЗНОЙ СУППОРТ-ЗАДНИЙ
15792635 CALIPER KIT, RR BRK (INCLS 2-8) [ТОРМОЗНОЙ СУППОРТ]
15792636 CALIPER KIT, RR BRK (INCLS 2-8) [ТОРМОЗНОЙ СУППОРТ]
25823358 БОЛТ, RR BRK CLPR GDE PIN (PART OF 1) (*KIT1, KIT3)
teamcadillac.ru
15265833 BRACKET, RR BRK CLPR
15792650 ATTACHMENT KIT, RR BRK CLPR (INCLS 2, 9, 10, 13) [НАПРАВЛЯЮЩАЯ ТОРМОЗНОГО СУППОРТА]
88967108 VALVE KIT, RR BRK BLEDR (INCLS 3-5) (ACDelco #88967108)
15945636 PAD KIT, RR DISC BRK (INCLS 2, 11, 13, 14) (ACDelco #171-0982)
(TC04-910) - 2007-2009 CK1(06-36) СТОЯНОЧНЫЙ ТОРМОЗ SYSTEM
20803171 MODULE, PARK BRK CONT (INCLS 3, 5, 8, 10) (EBONY) (ACDelco #20803171) [ПЕДАЛЬ ТОРМОЗА]
20805734 MODULE, PARK BRK CONT (INCLS 3, 5, 8, 10) (LINEN)
15045983 SWITCH, PARK BRK (PART OF 1)
09418944 SCREW, HWH, SELF TAP, #10-16X1", 3/8" O.D., M6010M, ZN (PARK BRK ACTR POSN SW)
15929213 HANDLE, PARK BRK REL (PART OF 1) (EBONY) (INCLS CBL) [РУКОЯТКА ПАРКОВОЧНОГО ТОРМОЗА]
teamcadillac.ru
25887810 HANDLE, PARK BRK REL (PART OF 1) (LINEN)
11588831 SCREW, HEX W/ CON WA, M6X1X35, 33.5 THD, 17 O.D.HDR PT, 9.8, BLK (PARK BRK REL HDL HSG)
15298817 PAD, PARK BRK LVR PED (PART OF 1)
25952157 CABLE, PARK BRK INTER
20756278 CABLE, PARK BRK RR
25952160 CABLE, PARK BRK RR [ТРОС СТОЯНОЧНОГО ТОРМОЗА]
15043173 CLIP, PARK BRK RR CBL (W/O HOLE) (W/3 OPENINGS)
11517560 SCREW, FLAT WA (NRW) AND HX WA HD, M8X1.25X25 (PARK BRK RR CBL GDE)
15087067 GUIDE, PARK BRK RR CBL (RH REAR FRAME RAIL)
15049571 GUIDE, PARK BRK RR CBL (FRONT)
(TC04-912) - 2007-2009 K1(06-36-43) КОРПУС КП ADAPTER (6L80 AUTOMATIC MYC)
24241166 ADAPTER, TRFER CASE
11515767 БОЛТ, HFH, M10X1.5X35, 32THD, 22.3 O.D., MACH, 10.9, 7114M (TRFER CASE ADAP) (T/W 12345493) [БОЛТ]
24245110 GASKET, TRFER CASE ADAP [ПРОКЛАДКА КОРПУСА РАЗДАТОЧНОЙ КОРОБКИ]
24246762 CASE, TRFER (W/GEARS) (CODE HJ)
24247211 CASE, TRFER (W/GEARS) (CODE LT, MV, QU)
teamcadillac.ru
24250805 CASE, TRFER (W/GEARS) (CODE PX)
15709703 ГАЙКА, HEX 10X1.5THD, 21.8 OD SS (TRFER CASE) [ГАЙКА М10]
(TC04-916) - 2007-2009 CK1,2,3 ШЛАНГ ВЕНТИЛЯЦИИ ТРАНСМИССИИ (6L80 AUTOMATIC MYC, 6L90 AUTOMATIC MYD)
teamcadillac.ru
25892279 VENT, A/TRNS (PART OF 4) (4.510) (ACDelco #25892279) [ЗАГЛУШКА ШЛАНГА ВЕНТИЛЯЦИИ КАРТЕРА АКПП]
19130464 STRAP, TIE 0.38" WIDTH, BUNDLE DIA 1/16"-1-3/4", 8.27" LENGTH, NYLON 6/6 FITS 0. (PART OF 4) [ХОМУТ (ЗАЖИМ) РАДИАТОРА]
01648216 CLAMP, WORM GEAR, HEX-SLOT SCREW, 1/4X5/8, .320 WIDE BAND, BLACK (TRANS VENT HOSE) (ACDelco #1648216)
15859985 HOSE, TRANS VENT (INCLS 1, 2)
11514596 ГАЙКА, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (TRANS VENT HOSE CLIP BRKT) (8.915) (ACDelco #11514596)
15854320 BRACKET, TRANS VENT HOSE CLIP
(TC04-917) - 2007-2009 K1,2,3 КОРПУС КП VENT TUBE
25892279 VENT, TRFER CASE (ACDelco #25892279) [ЗАГЛУШКА ШЛАНГА ВЕНТИЛЯЦИИ КАРТЕРА АКПП]
19130464 STRAP, TIE 0.38" WIDTH, BUNDLE DIA 1/16"-1-3/4", 8.27" LENGTH, NYLON 6/6 FITS 0. (TRFER CASE VENT HOSE) [ХОМУТ (ЗАЖИМ) РАДИАТОРА]
09438315 HOSE, FUEL-OIL EVAP (TRFER CASE VENT)
teamcadillac.ru
01648216 CLAMP, WORM GEAR, HEX-SLOT SCREW, 1/4X5/8, .320 WIDE BAND, BLACK (TRANS FLUID CLR HOSE) (ACDelco #1648216)
(TC04-918) - 2007-2009 CK1(06-36) УСИЛИТЕЛЬ ТОРМОЗОВ & ГЛАВНЫЙ ЦИЛИНДР MOUNTING (JD9)
25891352 HOSE, P/B BOOS VAC (INCLS 2) (ACDelco #176-1551)
01470030 CLAMP, WORM TYPE (11/16" TO 1 5/16") (PART OF 1) (ACDelco #1470030)
15974046 GASKET, P/B BOOS
11517996 ГАЙКА, BRK M/CYL (M10X1.5, 11.2 THK) (8.917) [ГАЙКА М10]
12559760 NIPPLE, P/B BOOS VAC HOSE
(TC04-920) - 2009 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА АКПП (M30, AUXILIARY COOLER KNP)
15052228 CAP, TRANS FLUID CLR PIPE CONN (PART OF 1, 8, 13) (PLASTIC RETAINER) (ACDelco #15052228) [ФИТИНГ ТРУБОПРОВОДА]
19210848 CONNECTOR, TRANS FLUID CLR PIPE (INCLS 4) (W/O BEVEL WASHER) (ACDelco #19210848)
24205103 RETAINER, TRANS FLUID CLR PIPE FTG (PART OF 3, 10) (EXPANDING ПРУЖИНА WIRE) (ACDelco #24205103) [СТОПОРНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ]
14093869 ГАЙКА, PUSH ON, M6, 2.25THK, 12.95 O.D., STL, POR (PART OF 1, 8)
15782677 CLIP, TRANS FLUID CLR PIPE (PART OF 1, 8)
11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (PART OF 1, 8) [БОЛТ М6]
teamcadillac.ru
11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (TRANS FLUID AUX CLR) [ШАЙБА]
25891509 COOLER, TRANS FLUID AUX (CODE 4639, 5464, 9344, 7192) (TRUCKS W/2PC STEEL BRACKETS ALSO REQ 11519377 BOLT QTY 2) (ACDelco #25891509)
(TC04-922) - 2007-2009 CK1 BRAKE ELECTRICAL SYSTEM (JD9)
15229012 SENSOR, FRT WHL SPD (INCLS 2, 3, 7) (ACDelco #15229012) (FOR VEHICLES WITH RPO PPV-USE T/W THERMAL WRAP PN 19207924, BETWEEN WHEEL SPEED SENSOR HEAD AND FIRST CLIP.) [ДАТЧИК АБС (КОЛИЧЕСТВА ОБОРОТОВ КОЛЕСА)]
15229013 CLIP, WHL SPD SEN WIRE (PART OF 1) (SLIDE LOCK WITH ALIGNMENT PIN)
15267361 CLIP, WHL SPD SEN WIRE (PART OF 1) (CLAM SHELL WITHOUT ALIGNMENT PIN)
11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (FRT BRK HOSE) [БОЛТ М6]
15715956 CLIP, WHL SPD SEN WIRE (PART OF 1) (10.00MM) (1 HOLE CLIP)
15960191 БОЛТ, WHL SPD SEN (M6X1X12)
11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (BRK PRESS MOD VLV BRKT) (ACDelco #11570082) [БОЛТ М8]
15121067 SENSOR, RR WHL SPD (INCLS 12-14) [ДАТЧИК АБС (КОЛИЧЕСТВА ОБОРОТОВ КОЛЕСА)]
teamcadillac.ru
11570519 SCREW, PAN HD, M6X1X13, 10 THD 12 OD, 9.8, PHOS & OIL.W/ADH (RR WHL SPD SEN)
(TC04-923) - 2007-2009 CK1(06-36) BRAKE CONTROL MODULE (JD9)
25834219 VALVE KIT, BRK PRESS MOD (INCLS 8, 9) (EXC. POLICE PKG)
15297115 INSULATOR KIT, BRK PRESS MOD VLV (INCLS 2-4)
15125563 BRACKET, BRK PRESS MOD VLV
25834221 MODULE KIT, ELEK BRK CONT (PART OF 1) (INCLS 9) (EXC. POLICE PKG) (ECU SERVICE KIT)
teamcadillac.ru
22688153 БОЛТ, ELEK BRK CONT MDL (ECU TO HCU ATTACH) (PART OF 1, 8)
(TC04-924) - 2007-2009 CK1(06-36) ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДР (JD9)
15268651 CAP, BRK M/CYL RSVR (PART OF 4) [КРЫШКА РЕЗЕРВУАРА ГЛАВНОГО ЦИЛИНДРА]
15823206 RESERVOIR KIT, BRK M/CYL (PART OF 4) (INCLS 3)
25827890 CYLINDER, BRK MAS (INCLS 1-3, 5, 6)
15787976 SEAL, BRK M/CYL (PART OF 4) [УПЛОТНИТЕЛЬ ЦИЛИНДРА ТОРМОЗА]
22672096 SWITCH, BRK FLUID LVL IND (PART OF 4) (ACDelco #22672096)
teamcadillac.ru
(TC04-928) - 2007-2009 CK1(06-36) ТОРМОЗНЫЕ МАГИСТРАЛИ-ПЕРЕДНИЕ (JD9)
11518522 ГАЙКА, HX FLARED TUBE, M12X1.0X20.5, 11 TUBE, SAE1010, GMW4707M (PART OF 5, 6)
19181732 PIPE, BRK (INCLS 4, 13) (5/16" X 16 FT) (BULK PIPE)
15194368 CLIP, RR BRK FRT PIPE (9.2X33.1) (HOLDS (2)8.25OD LINES) (4.685)
88936298 PIPE, BRK (STEEL) (1/4" X 16 FT ROLL) (BRK PIPE)
11570231 CLIP, FRT BRK PIPE (HOLDS ONE 6.65 DIA TUBE, TWO 8.35 DIA TUBE)
11570234 CLIP, FRT BRK PIPE
11570232 CLIP, FRT BRK PIPE (HOLDS TWO 6.65, TWO 8.35, ONE 5.0, ONE 17, ONE 33.0 DIA TUBES)
11562075 ГАЙКА, FRT BRK FRT PIPE (PART OF 5, 6) (M12X1.5X17) (INV FLARE)
11519388 БОЛТ, HX HD CON WA, M8X1.25X25, 20 THD, 24 OD, 8.8, GMW3359 (SILVER), M-POINT (ELEK BRK CONT MDL BRKT) [БОЛТ]
15923783 HOSE, FRT BRK (INCLS 18, 19) (ACDelco #176-1515) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ]
11517342 БОЛТ, HEX HD, W/FL WA, M6X1X20, 9.53 THD, 17 O.D., P-PT, 9.8, 6280M (PART OF 17, 25)
teamcadillac.ru
21012386 WASHER, RR BRK HOSE (PART OF 17, 25) (10.3X14.5X1.61) (COPPER) (ACDelco #21012386) [ШАЙБА 10 ММ]
11516885 SCREW, HFH W/FL WA, TAP, M8X1.25X20, 7THD, 17 O.D., TR PT, 6202M, PZOR (FRT BRK HOSE BRKT)
11561421 CLIP, FRT BRK FRT PIPE (FITS INTO DIA 6 HOLE)
11561422 CLIP, FRT BRK FRT PIPE (FITS INTO DIA 8 HOLE)
15923784 HOSE, FRT BRK (INCLS 18, 19) (ACDelco #176-1516) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ]
(TC04-929) - 2007-2009 CK1(06-36) ТОРМОНЫЕ МАГИСТРАЛИ/INTERMEDIATE (JD9)
88936298 PIPE, BRK (STEEL) (1/4" X 16 FT ROLL) (BRK)
teamcadillac.ru
11518522 ГАЙКА, HX FLARED TUBE, M12X1.0X20.5, 11 TUBE, SAE1010, GMW4707M (RR BRK FRT PIPE)
11610034 CLIP, RR BRK FRT PIPE (CLIP HOLDS TWO 6.75 TUBE, FIT 8 DIA HOLE IN 3.2 THK PNL)
11610035 CLIP, RR BRK FRT PIPE (6.9 X 20.4/77.4 X 15) (HOLD DIA 4.8, (2)6.75, 32MM TUBE, FIT 7.2 HOLE 1-5 THK PNL)
11562075 ГАЙКА, RR BRK FRT PIPE (M12X1.5X17) (INV FLARE)
(TC04-932) - 2007-2009 CK1(06-36) ТОРМОНЫЕ МАГИСТРАЛИ-ЗАДНИЕ
25906096 HOSE, RR BRK (AT CALIPER) (INCLS 5, 6) (ACDelco #176-1526) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ]
11569751 ГАЙКА, HX TUBE INVERTED FLARE, M10X1X16, SAE1010, GMW4707M (RR BRK C/OVR PIPE) [ШАЙБА]
11515756 БОЛТ, HFH, M8X1.25X20, 17THD, 18 O.D., 10.9, 7114M (RR BRK C/OVR PIPE BRKT) [БОЛТ]
11561240 CLAMP, SINGLE CLOSED-LOOP, DIA 7.25MM, C-TO-C 36.5, WIDTH 20, HOLE DIA 11 (RR BRK C/OVR PIPE) (8.948)
21012386 WASHER, RR BRK HOSE (PART OF 1, 14) (10.3X14.5X1.61) (COPPER) (ACDelco #21012386) [ШАЙБА 10 ММ]
11570052 БОЛТ, RR BRK HOSE (PART OF 1, 14) (M10X1X27.5, 16.9THD)
88983905 PIPE, BRK (3/16" X 16 FT) (BULK TUBING) (NYLON COATING) [ТРУБКА ТОРМОЗНОЙ СИСТЕМЫ]
11516885 SCREW, HFH W/FL WA, TAP, M8X1.25X20, 7THD, 17 O.D., TR PT, 6202M, PZOR (RR BRK HOSE BRKT)
25906094 HOSE, RR BRK (JOUNCE) (ACDelco #176-1541)
25906095 HOSE, RR BRK (JOUNCE) (ACDelco #176-1525) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ]
15234822 STRAP, RR BRK PIPE
12471307 БОЛТ, R/AXL HSG CVR (M8X1.25X20)
15791254 BRACKET, RR BRK C/OVR PIPE (CONTAINS BRACKET & SCREW) [КРОНШТЕЙН СБОРН.-ЗАДНЕЙ ТОРМОЗНОЙ ТРУБКИ]
teamcadillac.ru
25906097 HOSE, RR BRK (AT CALIPER) (INCLS 5, 6) (ACDelco #176-1528)
(TX04-118) - 2008-2009 CK1 СТОЯНОЧНЫЙ ТОРМОЗ ASM (JD9,J92)
teamcadillac.ru
15265913 ANCHOR, RR PARK BRK
15265914 PLATE, RR PARK BRK ANC BKG
15817021 ADJUSTER KIT, RR PARK BRK (INCLS 5, 6, 9-11)
15817020 SHOE KIT, RR PARK BRK (INCLS 1-3) (SERVICES ONLY ONE SIDE) (ACDelco #171-0992)
15816927 LEVER KIT, RR PARK BRK ACTR (INCLS 7, 8, 13) (4.591)
(TX04-900) - 2007-2009 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) CASE & СОПРЯЖЕННЫЕ ДЕТАЛИ
17804387 CONVERTER, TORQ (REMAN)
24224574 БОЛТ, T/CV HSG
24205900 COVER, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП]
teamcadillac.ru
24224577 SEAL, A/TRNS ГИДРОНАСОС
90351710 PIN, T/CV HSG LOC (0.293)
24237785 CASE, A/TRNS (INCLS 12, 13) (ACDelco #24237785)
24239878 SLEEVE, A/TRNS ELEC CONN PASG [МУФТА]
24238076 SEAL, OUTPUT SHF
11515768 БОЛТ, HFH, REDUCED BODY, M10X1.5X40, 30THD, 22.3 O.D., HDR PT, 10.9, 7114M (A/TRNS CASE EXTN) [БОЛТ М10Х1.5Х40]
24237181 БОЛТ, VLV BODY (M5X0.8X73.0)
24231074 БОЛТ, MAN SHFT DTNT (M10X1X14.5)
24222646 DETENT, MAN SHFT (W/8MM DIA. ROLLER) (ACDelco #24222646)
24236933 FILTER KIT, A/TRNS FLUID (INCLS 25) (ACDelco #24236933) [МАСЛЯНЫЙ ФИЛЬТР АКПП]
24224781 GASKET, A/TRNS FLUID PAN (ACDelco #24224781) [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА АКПП]
29535617 MAGNET, A/TRNS FLUID PAN (4.105) (ACDelco #29535617) [МАГНИТ]
24222657 PAN, A/TRNS FLUID (WITHOUT PLUG AND GASKET) (ACDelco #24222657)
11569816 БОЛТ, HFH, M6X1X19, 11.5 THD, 14.2 OD, 8.8 STL, GMW3359-BLACK, MAT POINT (A/TRNS FLUID PAN)
24224675 SEAL, A/TRNS CASE EXTN (*KIT1) (ACDelco #24224675)
24233898 SEAL, PROP SHF FRT SLIP YOKE OIL (PART OF 34) (*KIT1)
24248578 SEAL KIT, A/TRNS SERV (INCLS 33, 36) (FULL TRANS) (ACDelco #24248578)
24236927 SEAL KIT, A/TRNS SERV (INCLS 9, 10, 18-20) (CNTRL SOL VLV ASM) (ACDelco #24236927) [КОМПЛЕКТ ПРОКЛАДОК АКПП (3 РЕЗ, 3 МЕТ)]
(TX04-901) - 2007-2009 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) ГИДРОТРАНСФОРМАТОР ШЛАНГИ & ГИДРОНАСОС
24218963 RING, T/CV FLUID SEAL RET [КОЛЬЦО]
24237531 SEAL, T/CV FLUID (ACDelco #24237531) [УПЛОТНЕНИЕ АКПП]
00444613 PLUG, HEX HD, 1/8-27 NPTF, STL (LINE PRESS TEST HOLE) (ACDelco #444613)
24236120 ШЛАНГИ, T/CV (MCHG) (INCLS 206) (ACDelco #24236120)
24231684 PIPE, A/TRNS VENT
24237658 SEAL, TRANS FLUID CLR PIPE FTG (SEALS ONE PIPE) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ]
24222668 SLIDE, A/TRNS ГИДРОНАСОС (17.948MM-17.961MM) (ACDelco #24222668)
24224131 SLIDE, A/TRNS ГИДРОНАСОС (17.961MM-17.974MM) (ACDelco #24224131)
24224132 SLIDE, A/TRNS ГИДРОНАСОС (17.974MM-17.987MM) (ACDelco #24224132)
teamcadillac.ru
00147500 VALVE, PRESS RLF BALL (*KIT2)
24224692 WASHER, 1-2-3-4 & 3-5 REV CLU HSG THR (*KIT2)
24238248 RING, 1-2-3-4 & 3-5 REV CLU FLUID SEAL (*KIT2) (TRANS BUILT ON 08-17-08 & PRIOR) (FOR 2ND DES SEE 24248559)
24248559 RING KIT, 1-2-3-4 & 3-5 REV CLU FLUID SEAL (1-SET 2ND DES SEALS (INCL QUAD LOBE)) (*KIT2) (ACDelco #24248559) (TRANS BUILT ON 10-23-08 & AFTER) (FOR 1ST DES SEE 24248581)
24227061 БОЛТ, A/TRNS ГИДРОНАСОС CVR (ACDelco #24227061) [БОЛТ]
90351709 PIN, A/TRNS ГИДРОНАСОС LOC ("8MM HOLLOW SPLIT PIN") (*KIT2) (1.639) [ШПИЛЬКА]
24236935 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS 207-211, 213-217) (17.948MM-17.961MM) (4.224) (ACDelco #24236935) (TRANS BUILT ON 10-22-08 & PRIOR) (FOR 2ND DES SEE 24248569)
24236936 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS 207-211, 213-217) (17.961MM-17.974MM) (4.224) (ACDelco #24236936) (TRANS BUILT ON 10-22-08 & PRIOR) (FOR 2ND DES SEE 24248570)
24236937 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS 207-211, 213-217) (17.974MM-17.987MM) (4.224) (ACDelco #24236937) (TRANS BUILT ON 10-22-08 & PRIOR) (FOR 2ND DES SEE 24248571)
24248569 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS 207-211, 213-217) (17.948MM-17.961MM) (ACDelco #24248569) (TRANS BUILT ON 10-23-08 & AFTER) (FOR 1ST DES SEE 24236935)
24248570 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS 207-211, 213-217) (17.961MM-17.974MM) (ACDelco #24248570) (TRANS BUILT ON 10-23-08 & AFTER) (FOR 1ST DES SEE 24236936)
24248571 ROTOR PKG, A/TRNS ГИДРОНАСОС (INCLS 207-211, 213-217) (17.974MM-17.987MM) (ACDelco #24248571) (TRANS BUILT ON 10-23-08 & AFTER) (FOR 1ST DES SEE 24236937)
24236939 COVER KIT, A/TRNS ГИДРОНАСОС (INCLS 218-230, 232-237) (ACDelco #24236939) (TRANS BUILT ON 10-22-08 & PRIOR) (FOR 2ND DES SEE 24248573)
24248573 COVER KIT, A/TRNS ГИДРОНАСОС (INCLS 218-230, 232-237) (ACDelco #24248573) (TRANS BUILT ON 10-23-08 & AFTER) (FOR 1ST DES SEE 24236939)
(TX04-902) - 2007-2009 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) ЗАМОК ПАРКОВКИ
teamcadillac.ru
24242085 ACTUATOR, PARK PAWL (ACDelco #24242085)
24227077 PIN, MAN SHFT DTNT LVR HUB
24234562 LEVER, MAN SHFT DTNT (ACDelco #24234562)
24225792 PIN, MAN SHFT SHF (ACDelco #24225792)
24235861 SEAL, MAN SHFT SHF (ACDelco #24235861) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО АКПП]
24225445 SHAFT, MAN SHFT (ACDelco #24225445)
24224348 GUIDE, PARK PAWL ACTR (INCLS 510)
24224350 SEAL, PARK PAWL ACTR GDE (O RING) (PART OF 509) (ACDelco #24224350)
24226102 PIN, PARK PAWL ACTR GDE
(TX04-903) - 2007-2009 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) ВЫХОДНОЙ ВАЛ ASSEMBLY
24241091 RING, OUTPUT CARR INTL GR RET (ACDelco #24241091)
24224194 GEAR, OUTPUT CARR INTL (FRT) (ACDelco #24224194)
24227962 SPACER, OUTPUT CARR INTL GR
24230545 GEAR, OUTPUT CARR INTL (RR) (ACDelco #24230545)
24238883 SHAFT, OUTPUT (INCLS 498)
(TX04-904) - 2007-2009 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) АКПП БЛОК СЦЕПЛЕНИЯ & СОПРЯЖЕННЫЕ ДЕТАЛИ
24236874 CARRIER, INPUT (ACDelco #24236874)
24224404 GEAR, INPUT SUN (ACDelco #24224404)
24224405 BEARING, INPUT SUN GR THR (ACDelco #24224405)
24232409 WASHER, INPUT SUN GR THR
24238905 BEARING, TURB SHFT THR [ПОДШИПНИК]
24238004 HUB, 4-5-6 CLU (W/ OUTPUT CARR SHF & DPNR) (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ/CLUTCH HUB" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА)
24233732 BEARING, 4-5-6 CLU HUB THR (ACDelco #24233732)
24240409 HUB, 1-2-3-4 CLU (W/OUTPUT CARR INR SUN GR SHF) (ACDelco #24240409)
24224163 BEARING, 1-2-3-4 CLU HUB THR (ACDelco #24224163)
24240407 HUB, 2-6 & 3-5/REV CLU (W/ OUTPUT CARR OTR SUN GR SHF) (INCLS 60, 62) (ACDelco #24240407)
24224164 BEARING, 2-6 & 3-5/REV CLU HUB THR (ACDelco #24224164)
24224724 RING, CTR SUPT RET
teamcadillac.ru
24224747 CARRIER, OUTPUT (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ/OUTPUT CARRIER" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #24224747)
24224188 BEARING, OUTPUT CARR THR (ACDelco #24224188)
24238883 SHAFT, OUTPUT (СМ. ГРУППУ 04.000 "АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ/ВЫХОДНОЙ ВАЛ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА)
24224668 BEARING, OUTPUT SHF THR (ACDelco #24224668)
(TX04-905) - 2007-2009 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) ASSEMBLY
teamcadillac.ru
17804063 TRANSMISSION, AUTO (GOODWRENCH REMAN) (CODE 9CKA)
(TX04-906) - 2007-2009 K1 КОРПУС КП (NR3) ЧАСТЬ 1 CASE COMPONENTS-AWD (BORG WARNER 4485)
89059522 STUD, TRFER CASE ADAP (PART OF 2)
19132934 CASE, TRFER (FRT HALF) (INCLS 1, 3, 14)
88984499 PIN, TRFER CASE HALF LOC (PART OF 2)
19132802 BUSHING, TRFER CASE RR EXTN (PART OF 11) [ВТУЛКА РАЗДАТОЧНОЙ КОРОБКИ]
89059495 SEAL, TRFER CASE RR OUTPUT SHF [УПЛОТНЕНИЕ РАЗДАТОЧНОЙ КОРОБКИ]
88984495 PLUG, TRFER CASE OIL FILL [КОЛПАК]
89059524 БОЛТ, TRFER CASE HALF (M8X1.25X43.0)
88996459 BRACKET, TRFER CASE (UPPER)
88984495 PLUG, TRFER CASE OIL FILL (DRAIN) [КОЛПАК]
19153151 CASE, TRFER (RR HALF) (CODE KK) (INCLS 4)
88984501 SEAL, TRFER CASE FRT OUTPUT SHF [УПЛОТНЕНИЕ ТРАНСФОРМАТОРНОЙ КОРОБКИ]
15580319 VENT, TRFER CASE
19132801 SEAL, TRFER CASE INPUT SHF (PART OF 2) [ПРОКЛАДКА]
(TX04-907) - 2007-2009 K1 КОРПУС КП (NR3) ЧАСТЬ 2 INTERNAL COMPONENTS-AWD (BORG WARNER 4485)
88984507 BEARING, TRFER CASE INPUT SHF
19132803 SHAFT, TRFER CASE INPUT
19168732 BUSHING, TRFER CASE FRT OUTPUT SHF DRV SPKT (PART OF 4) (ACDelco #19168732)
19167564 SPROCKET, TRFER CASE FRT OUTPUT SHF DRV (INCLS 3) [ШЕСТЕРНЯ ГРМ]
19151772 CHAIN, TRFER CASE TWO/FOUR WHL DRV [ЦЕПЬ ГРМ]
88984524 GEAR, TRFER CASE PLNT CARR SUN (INPUT) (STAMPED PM/POWDERED METAL)
89059279 CARRIER, FRT/RR DRV DIFF
89059525 WASHER, TRFER CASE PLNT CARR SUN GR THR
teamcadillac.ru
19168733 BUSHING, TRFER CASE RR OUTPUT SHF (PART OF 11) [ВТУЛКА РАЗДАТОЧНОЙ КОРОБКИ]
19178328 SHAFT, TRFER CASE RR OUTPUT (INCLS 10, 13, 14)
88984508 RING, TRFER CASE RR OUTPUT SHF RR BRG OTR RET (80MM I.D.) (4.535) [КОЛЬЦО УПЛОТНИТЕЛЬНОЕ]
88984506 BEARING, TRFER CASE RR OUTPUT SHF RR (PART OF 11)
88984493 RING, TRFER CASE RR OUTPUT SHF RR BRG RET (PART OF 11) (41MM I.D.) (ACDelco #88984493)
88996564 BEARING, TRFER CASE FRT OUTPUT SHF DRV SPKT
88984540 SPROCKET, TRFER CASE TWO/FOUR WHL DRV DRVN
89059602 PLUG, TRFER CASE FRT OUTPUT SHF HOLE (PART OF 18)
19153149 SHAFT, TRFER CASE FRT OUTPUT (INCLS 17)
04 - ТОРМОЗА
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
11516780 ГАЙКА, HEX W/CON WA, M8X1.25, 10THK, 19 O.D., 10, 7111M (PARK BRK CONT MDL) (8.917) [ГАЙКА М8]
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA WRG HARN J/BLK BRKT) [ГАЙКА М6]
25867232 BRACKET, DA WRG HARN J/BLK
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
04 - ТРАНСМИССИЯ-ТОРМОЗА
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
05 - ТОРМОЗА-ЗАДНЯЯ ОСЬ-ПРИВОДНОЙ ВАЛ-КОЛЕСА
(GM05-007) - 2007-2009 CK1,2,3 ШИНА
19143998 ШИНА, FRT (ШИНА MFG # 053998) (INSTALL .25) (SINGLE 19.3KGS) (BRIDGESTONE, DUELER H/L ALENZA, P285/45R22, BW110H) (ACDelco #FB053984)
19145327 ШИНА, FRT (ШИНА MFG # 54018) (INSTALL .25) (SINGLE 18.8KGS) (BRIDGESTONE, DUELER A/T RH-S, P265/65R18, 112S) (ACDelco #FB054018)
19145377 ШИНА, FRT (ШИНА MFG # 53967) (INSTALL .25) (SINGLE 19.5KGS) (BRIDGESTONE, DUELER H/L ALENZA W/UNI-T, P275/55R20, BL, 111S) (ACDelco #FB053967)
19145900 ШИНА, FRT (ШИНА MFG # 047456) (BRIDGESTONE, DUELER H/L (D683), P265/65R18, BW112H) (ACDelco #FB047456)
19148471 ШИНА, FRT (ШИНА MFG # 054035) (BRIDGESTONE, DUELER A/T-RHS, P265/65R18, OWL112S) (ACDelco #FB054035)
19160281 ШИНА, FRT (ШИНА MFG # 043665) (BRIDGESTONE, DUELER H/T (D684 II), P265/65R18, 112S) (ACDelco #FB043665)
19161391 ШИНА, FRT (ШИНА MFG # 088505) (BRIDGESTONE, DUELER A/T RHS, P265/70R17, BW) (ACDelco #FB086505)
19162484 ШИНА, FRT (ШИНА MFG # 732605500) (GOODYEAR, EAGLE RS-A, P265/60R17, BW108H) (ACDelco #HN605500)
19195228 ШИНА, FRT (ШИНА MFG # 1548890000) (GENERAL, AMERITRAC TR, P265/70R17, BSW113H) (ACDelco #1544889G)
19238605 ШИНА, FRT (ШИНА MFG # 090177) (FIRESTONE, DESTINATION LE, P265/65R18, BW112S) (ACDelco #FB090177)
19238606 ШИНА, FRT (ШИНА MFG # 090279) (FIRESTONE, DESTINATION LE, P265/65R18, WOL112S) (ACDelco #FB090279)
teamcadillac.ru
88926367 ШИНА, FRT (ШИНА MFG # 403422658) (GOODYEAR, WRANGLER HP, 265/70R17, BSL) (ACDelco #MH422658)
88926368 ШИНА, FRT (ШИНА MFG # 403422918) (GOODYEAR, WRANGLER HP, 265/70R17, OWL) (ACDelco #MH422918)
88926372 ШИНА, FRT (ШИНА MFG # 410422176) (GOODYEAR, WRANGLER AT/S, 265/70R17, OWL) (ACDelco #MI422176)
88926373 ШИНА, FRT (ШИНА MFG # 410422177) (GOODYEAR, WRANGLER AT/S, 265/70R17, BSL) (ACDelco #MI422177)
89049423 ШИНА, FRT (ШИНА MFG # 773422430) (GOODYEAR, WRANGLER ST, 265/70R17, BSL) (ACDelco #HD422430)
89049424 ШИНА, FRT (ШИНА MFG # 773422431) (GOODYEAR, WRANGLER ST, 265/70R17, OWL) (ACDelco #HD422431)
(TC05-025) - 2007-2009 K1,2,3 ВАЛ ПРИВОДА-КАРДАННЫЙ ВАЛ MOUNTING/FRONT AXLE
15734903 БОЛТ, F/AXL PROP SHF (5/16-24X1.3) (HEX) [БОЛТ М12]
07846740 RETAINER, F/AXL PROP SHF (1 13/16 IN HOLE CTR) (USED W/1 1/8 IN BRG CAP, CUT-OFF CORNERS)
(TC05-320) - 2008-2009 CK107(06) НАСОС ДЛЯ ШИН (HYBRID HP2)
15226250 CONTAINER, ШИНА SEALANT SOL (INCLS 9, 10)
25791334 BRACKET, ШИНА INFLR (INCLS 5)
teamcadillac.ru
22732103 КОМПРЕССОР, ШИНА AIR (INCLS 2-4) (КОМПРЕССОР ONLY)
10382058 LABEL, ШИНА MAX SPEED (PART OF 1)
10382059 LABEL, ШИНА SEALER CAUTION (PART OF 1)
(TC05-602) - 2007-2009 CK1,2,3 ВАЛ ПРИВОДА-КАРДАННЫЙ ВАЛ MOUNTING/REAR AXLE (ONE PIECE PROP)
15734903 БОЛТ, RR PROP SHF (5/16-24X1.3) (HEX) [БОЛТ М12]
teamcadillac.ru
03920486 RETAINER, RR PROP SHF (1 21/32 IN HOLE CTR) (USED W/7/8 IN BRG CAP, SQUARE CORNERS)
(TC05-653) - 2007-2009 CK1(06-36) ШЛАНГ ВЕНТИЛЯЦИИ ЗАДНЕГО МОСТА
15920576 HOSE, R/AXL VENT (INCLS 2, 3)
15157936 CLIP, R/AXL VENT HOSE (PART OF 1) (1 LINE)
15743069 VENT, R/AXL (PART OF 1)
teamcadillac.ru
26063647 CONNECTOR, R/AXL VENT HOSE
(TC05-900) - 2007-2009 CK1(06-36) ЗАПАСНОЕ КОЛЕСО
09596426 WHEEL, 17X7.5 SPARE (CODE FLY) (ACDelco #9596426)
25858636 CAP, ШИНА PRESS IND SEN (PART OF 2) (BLACK) [КОЛПАК ГАЙКИ КОЛЕСА]
teamcadillac.ru
09595852 WHEEL KIT, AL
(TC05-904) - 2007-2009 CK1(06-36) МОСТ В СБОРЕ/ЗАДНИЙ-ПОЛНЫЙ
teamcadillac.ru
25798130 МОСТ, ЗАДНИЙ (3.08 RATIO) (CODE ZX8)
25798146 МОСТ, ЗАДНИЙ (3.42 RATIO) (CODE ZY6)
25798147 МОСТ, ЗАДНИЙ (3.42 RATIO) (CODE ZY7)
25798168 МОСТ, ЗАДНИЙ (3.73 RATIO) (CODE ZZ1)
25928306 МОСТ, ЗАДНИЙ (3.42 RATIO) (CODE FC7)
(TC05-905) - 2007-2009 CK1(06-36) МОСТ В СБОРЕ/ЗАДНИЙ 8.625 RING GEAR ЧАСТЬ 1 (EXC (AXN))
03984818 WASHER, DIFF P/GR THR (.797 I.D. 1.70 O.D.) (*KIT1)
00454947 БОЛТ, HEX .437-14X2.250 CL-2A CAD/ZC (PART OF 31)
15791254 BRACKET, RR BRK C/OVR PIPE (INCLS 9) (CONTAINS BRACKET & SCREW) [КРОНШТЕЙН СБОРН.-ЗАДНЕЙ ТОРМОЗНОЙ ТРУБКИ]
12479141 PLUG, R/AXL HSG FILL (INCLS WASHER & MAGNET)
25824253 COVER, R/AXL HSG (COVER ONLY)
15860607 GASKET, R/AXL HSG CVR (10 BOLT HOLES)
19180882 GEAR KIT, DIFF RING & PINION (INCLS 16, 32, 33, 43)
19180883 GEAR KIT, DIFF RING & PINION (INCLS 16, 32, 33, 43)
19180884 GEAR KIT, DIFF RING & PINION (INCLS 16, 32, 33, 43)
19180885 GEAR KIT, DIFF RING & PINION (INCLS 16, 32, 33, 43)
19180886 GEAR KIT, DIFF RING & PINION (INCLS 16, 32, 33, 43)
01394892 SHIM KIT, FRT DIFF DRV P/GR BRG (.020-.024" THK)
01394893 SHIM KIT, FRT DIFF DRV P/GR BRG (.025-.029" THK)
01394894 SHIM KIT, FRT DIFF DRV P/GR BRG (.030-.034" THK)
01394895 SHIM KIT, FRT DIFF DRV P/GR BRG (.035-.039" THK)
26043991 SHIM KIT, FRT DIFF DRV P/GR BRG (.040-.044" THK)
26043992 SHIM KIT, FRT DIFF DRV P/GR BRG (.045-.049" THK) [РЕГУЛИР.ПРОКЛАДКА ДИФФЕРЕНЦИАЛА (ШАЙБА)]
25824251 BEARING, DIFF DRV P/GR INR (ACDelco #S1381)
12479162 SPACER, DIFF DRV P/GR BRG (R/AXL) (PART OF 13) (.062-.068" THK) [ШАЙБА ДИФФЕРЕНЦИАЛА]
15121067 SENSOR, RR WHL SPD [ДАТЧИК АБС (КОЛИЧЕСТВА ОБОРОТОВ КОЛЕСА)]
15286384 RING, WHL SPD SEN RELUCTOR
12479031 BEARING, R/AXL SHF (5.855) (ACDelco #RW20-10) [ПОДШИПНИК СТУПИЦЫ КОЛЕСА 60ММ]
12471686 SEAL, R/AXL SHF (ACDelco #291-315) [ПРОКЛАДКА ПОЛУОСИ ЗАДНЕГО МОСТА]
15065927 БОЛТ, PARK BRK (M12X1.75X34)
15012506 БОЛТ, RR BRK CLPR (PART OF 27) (M14X2.0X37, 37THD) (27.3-OD., 10.9, GM6174M) [БОЛТ М14Х2]
25832103 ROTOR, RR BRK (INCLS 25) (ACDelco #177-1041) [ТОРМОЗНОЙ ДИСК]
11588811 STUD, RR WHL (M14X1.5X24, 58 TOTAL LENGTH) [ШПИЛЬКА М14]
15286380 SHAFT, R/AXL [ПРИВОДНОЙ ВАЛ КОЛЕСА]
03833322 LOCK, R/AXL SHF (39.43 X 19.94MM)
25824242 ШЛАНГИ, R/AXL (INCLS 5, 6)
25824244 ШЛАНГИ, R/AXL (INCLS 5, 6)
88891763 ГАЙКА, DIFF DRV P/GR (R/AXL) (PART OF 13, 34) (M10) [ГАЙКА М10]
00517900 WASHER, DIFF DRV P/GR (PART OF 13, 34) (.890X1.625X.190)
19180533 YOKE KIT, DIFF DRV P/GR (INCLS 32, 33, 35)
teamcadillac.ru
26064029 SEAL, DIFF DRV P/GR (PART OF 34) (5.545) [САЛЬНИК П/ОСИ ЗДНЕГО МОСТА]
25824252 BEARING, DIFF DRV P/GR OTR (INCLS 1 CONE AAM# 40048060 (KOYO# KESTB3372LFT) AND 1 CUP AAM# 40048058 (KOYO# KESTB3372) (ACDelco #S1382) [ШАРИКОВЫЙ ПОДШИПНИК D=80 ММ]
12471330 SPACER, DIFF BRG (4.37-4.32MM THK) (5.650) [КОЛЬЦО ДИФФЕРЕНЦИАЛА]
12471362 SHIM KIT, DIFF BRG (1.016-1.118MM RANGE) (RR AXLE) [КОМПЛЕКТ РЕГУЛИР.ПРОКЛАДОК ДИФФЕРЕНЦИАЛА (2ШТ)]
12471363 SHIM KIT, DIFF BRG (1.168-1.372MM RANGE) (RR AXLE) [КОМПЛЕКТ РЕГУЛИР.ПРОКЛАДОК ДИФФЕРЕНЦИАЛА (2ШТ)]
12471364 SHIM KIT, DIFF BRG (1.422-1.626MM RANGE) (RR AXLE) [КОМПЛЕКТ РЕГУЛИР.ПРОКЛАДОК ДИФФЕРЕНЦИАЛА (2ШТ)]
12471365 SHIM KIT, DIFF BRG (1.676-1.880MM RANGE) (RR AXLE) [КОМПЛЕКТ РЕГУЛИР.ПРОКЛАДОК ДИФФЕРЕНЦИАЛА (2ШТ)]
12471366 SHIM KIT, DIFF BRG (1.930-2.134MM RANGE) (RR AXLE) [КОМПЛЕКТ РЕГУЛИР.ПРОКЛАДОК ДИФФЕРЕНЦИАЛА (2ШТ)]
12471367 SHIM KIT, DIFF BRG (2.184-2.388MM RANGE) (RR AXLE) [КОМПЛЕКТ РЕГУЛИР.ПРОКЛАДОК ДИФФЕРЕНЦИАЛА (2ШТ)]
12471368 SHIM KIT, DIFF BRG (2.438-2.540MM RANGE) (RR AXLE) [УПОРНОЕ КОЛЬЦО ДИФФЕРЕНЦИАЛА]
25824250 BEARING, DIFF (ACDelco #S1380) [ПОДШИПНИК ДИФФЕРЕНЦИАЛА]
25824246 CASE, DIFF
25872305 БОЛТ, DIFF P/GR SHF LK (*KIT1) [БОЛТ М10]
25824249 SHAFT, DIFF P/GR (124.84 MM) (*KIT1)
11610549 БОЛТ, RR DIFF R/GR (R/AXL) (PART OF 13) (7/16-20)
19180887 GEAR KIT, DIFF SI & PINION (INCLS 1-4, 41, 42)
(TC05-922) - 2008-2009 CK1,2(06-36) ШИНА VALVE STEM & PRESSURE SENSOR
15922396 SENSOR, ШИНА PRESS IND (INCLS 2-5) (SNAP-IN) (INCLUDES BLACK VALVE CAP & BLACK RUBBER VALVE) (ACDelco #15922396)
15263240 VALVE KIT, ШИНА (PART OF 1) (INCLS 2, 4, 5) (INCLS CAP, STEM, BOLT) (ACDelco #15263240) [ОБРАТНЫЙ КЛАПАН КОЛЕСА]
25858636 CAP, ШИНА PRESS IND SEN (PART OF 1, 3) (BLACK) [КОЛПАК ГАЙКИ КОЛЕСА]
09593595 STEM, ШИНА VLV (INCLS 7, 8) (FITS 0.453 HOLE, INCLS CAP 9427576 1.24" LONG HIGH PRESS)
(TC05-942) - 2008-2009 CK1(06-36) КОЛЕСА (CADILLAC Z75)
09595459 WHEEL, 18X8
09595460 WHEEL, 18X8
19209740 WEIGHT, WHL BAL (CLIP-ON REPLACEMENT) (TRIM AS REQUIRED) (WHL BAL)
09595174 ГАЙКА, WHL (M14X1.5)
09595473 CAP, HUB
09597286 CAP, HUB
09593595 STEM, ШИНА VLV (СМ. ГРУППУ 05.000 "ШИНА VALVE STEM & PRESSURE SENSOR" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS 5) (FITS 0.453 HOLE, INCLS CAP 9427576 1.24" LONG HIGH PRESS)
15922396 SENSOR, ШИНА PRESS IND (СМ. ГРУППУ 05.000 "ШИНА VALVE STEM & PRESSURE SENSOR" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS 5) (SNAP-IN) (INCLUDES BLACK VALVE CAP & BLACK RUBBER VALVE) (ACDelco #15922396)
09595854 WHEEL, 22X9.0
09597950 CAP, HUB
09598297 CAP, HUB
09597355 CAP, HUB
09598295 CAP, HUB
teamcadillac.ru
09597224 WHEEL, 22X9.0
(TC05-952) - 2007-2009 CK1(06-36) МОСТ В СБОРЕ/ЗАДНИЙ 9.50 RING GEAR ЧАСТЬ 1 (AXN)
12337937 WASHER, DIFF SI GR THR (PACKAGE INCLS (5) WASHERS)
14012699 WASHER, DIFF P/GR THR (FLAT WASHER) (56MM O.D. 23.75MM I.D.)
12471410 DIFFERENTIAL, (СМ. ГРУППУ 05.000 "МОСТ В СБОРЕ/ЗАДНИЙ LOCKING DIFFERENTIAL" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS GEARS)
14038087 CASE, DIFF (FOR NON-CANADIAN ORDERS) (LESS INTERNAL GEARS) (FOR NON-CANADIAN ORDERS)
14012703 БОЛТ, RR DIFF R/GR (R/AXL) (M12X1.5X22) (HEX) (*KIT1)
14012700 SHAFT, DIFF P/GR (148.0MM)
14039025 SHAFT, DIFF P/GR (144.78MM)
12337979 БОЛТ, DIFF P/GR SHF LK (M10X1.5X59) (CONTAINS 10 LOCK SCREWS)
14012675 БОЛТ, DIFF BRG CAP (M12X1.75X74)
11505123 BEARING, DIFF (INCLS CUP AND CONE, TIMKEN, JLM506849-JLM506811, 55MM ID X 90MM OD X 25MM THK) (ACDelco #S1198)
teamcadillac.ru
14012725 SHIM, DIFF BRG (5.59 MM)
14012726 SHIM, DIFF BRG (5.64 MM)
14012727 SHIM, DIFF BRG (5.69 MM)
14012728 SHIM, DIFF BRG (5.74 MM)
14012729 SHIM, DIFF BRG (5.79 MM)
14012730 SHIM, DIFF BRG (5.84 MM)
14012731 SHIM, DIFF BRG (5.89 MM)
14012732 SHIM, DIFF BRG (5.94 MM)
14012733 SHIM, DIFF BRG (5.99 MM)
14012734 SHIM, DIFF BRG (6.05 MM)
14012735 SHIM, DIFF BRG (6.10 MM)
14012736 SHIM, DIFF BRG (6.15 MM)
14012737 SHIM, DIFF BRG (6.20 MM)
14012738 SHIM, DIFF BRG (6.25 MM)
14012739 SHIM, DIFF BRG (6.30 MM)
14012740 SHIM, DIFF BRG (6.35 MM)
14012741 SHIM, DIFF BRG (6.40 MM)
14012742 SHIM, DIFF BRG (6.45 MM)
14012743 SHIM, DIFF BRG (6.50 MM)
14012752 SHIM, DIFF BRG (6.55 MM)
12471307 БОЛТ, R/AXL HSG CVR (PART OF 15) (M8X1.25X20)
19133285 COVER KIT, R/AXL HSG (INCLS 13, 16, 41) (INCLS COVER, GASKET, PLUGS, BOLTS)
26063649 GASKET, R/AXL HSG CVR (PART OF 15) (14 BOLT HOLES) [ПРОКЛАДКА КРЫШКИ ДИФФЕРЕНЦИАЛА]
14038010 SHIM KIT, DIFF DRV P/GR BRG (R/AXL) (.5080-.5842MM)
14038011 SHIM KIT, DIFF DRV P/GR BRG (.6096-.7112MM)
14038012 SHIM KIT, DIFF DRV P/GR BRG (.7366-.8382MM)
14038013 SHIM KIT, DIFF DRV P/GR BRG (.8636-.9398MM)
00457108 BEARING, DIFF DRV P/GR INR (ACDelco #S37)
15012506 БОЛТ, RR BRK CLPR (M14X2.0X37, 37THD) (27.3-OD., 10.9, GM6174M) [БОЛТ М14Х2]
14012746 LOCK, R/AXL SHF (43.0 X 22.5MM)
15812663 SHAFT, R/AXL
25832103 ROTOR, RR BRK (ACDelco #177-1041) [ТОРМОЗНОЙ ДИСК]
12471308 PLUG, R/AXL HSG DRN (W/WASHER) (19MM LONG) [ЗАГЛУШКА]
88891763 ГАЙКА, DIFF DRV P/GR (R/AXL) (PART OF 37) (M10) (*KIT1) [ГАЙКА М10]
00517900 WASHER, DIFF DRV P/GR (PART OF 37) (.890X1.625X.190) (*KIT1)
12470384 YOKE KIT, DIFF DRV P/GR (INCLS 35, 36, 38) (TRIPLE LIP) (INCL YOKE, SEAL WA, NUT) (FOR VEHICLES W/TWO PIECE PINION SEAL)
26064029 SEAL, DIFF DRV P/GR (PART OF 37) (5.545) [САЛЬНИК П/ОСИ ЗДНЕГО МОСТА]
09417781 BEARING, DIFF DRV P/GR OTR (2.84") (5.484) (ACDelco #S604)
14012691 SPACER, DIFF DRV P/GR BRG (35.5MM I.D. X 16.3MM WIDE) (*KIT1)
00444788 PLUG, HEADLESS SQ SOCKET 1/2" (PART OF 15)
15875855 ШЛАНГИ, R/AXL (INCLS 10) (WHEN USING 15875855 ALSO ORDER QTY 1 12471308 PLUG, R/AXL DRN)
14012753 ГАЙКА, DIFF BRG ADJ (M86X1.5)
14012707 LOCK, DIFF BRG ADJ NUT (5.537)
11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (DIFF BRG ADJ NUT LK) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16]
12471607 MAGNET, R/AXL HSG CHIP COLLECTOR (4.105) (ACDelco #12471607)
88965784 GEAR KIT, DIFF RING & PINION (INCLS 6, 17, 35, 36, 40, 49)
12471409 GEAR KIT, DIFF SI & PINION (INCLS 2, 4)
(TX05-059) - 2007-2009 CK1(06-36) МОСТ В СБОРЕ/ЗАДНИЙ 8.625 RING GEAR ЧАСТЬ 2 DIFFERENTIAL/LOCKING(G80,EXC (AXN))
25902687 DIFFERENTIAL, (INCLS 2-19) [ДИФФЕРЕНЦИАЛ ВЕДУЩЕГО МОСТА В СБОРЕ]
25872305 БОЛТ, DIFF P/GR SHF LK [БОЛТ М10]
14048409 BUSHING, LKG DIFF LOCKOUT (EATON EDS-98648) [ВТУЛКА КУЛАЧКА]
12471532 WASHER, DIFF P/GR THR (.820 I.D.X1.69 O.D.) (EATON EDS-89189, .06 LIP)
15599623 GUIDE, LKG DIFF CLU DISC (PART OF 10) (WIDTH .93 INCH)
14063581 SHIM, DIFF SI GR (.010 THK) (BELL END) [ПРОКЛАДКА]
14063582 SHIM, DIFF SI GR (.015 THK) (BELL END) [ПРОКЛАДКА]
14063583 SHIM, DIFF SI GR (.020 THK) (BELL END) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ДИФФЕРЕНЦИАЛА]
14063584 SHIM, DIFF SI GR (.025 THK) (BELL END) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ДИФФЕРЕНЦИАЛА]
14063585 SHIM, DIFF SI GR (.030 THK) (BELL END) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ДИФФЕРЕНЦИАЛА]
14063586 SHIM, DIFF SI GR (.035 THK) (BELL END)
14063587 SHIM, DIFF SI GR (.040 THK) (BELL END) [ПРОКЛАДКА]
14063588 SHIM, DIFF SI GR (.045 THK) (BELL END)
26045829 DISC SET, LKG DIFF CLU (INCLS 8) (EATON EDS-29996)
12471530 GOVERNOR KIT, LKG DIFF (EATON EDS-29672) (INCLS BRKT)
12471393 BLOCK, LKG DIFF THR (PURPLE) (1.322" THK)
12471394 BLOCK, LKG DIFF THR (WHITE) (1.326" THK)
teamcadillac.ru
12471395 BLOCK, LKG DIFF THR (BROWN) (1.330" THK)
12471396 BLOCK, LKG DIFF THR (YELLOW) (1.334" THK)
12471397 BLOCK, LKG DIFF THR (ORANGE) (1.338" THK)
12471398 BLOCK, LKG DIFF THR (PINK) (1.342" THK)
12471399 BLOCK, LKG DIFF THR (GREEN) (1.346" THK)
12471406 CAM, LKG DIFF (EATON EDS-89096)
12471533 GUIDE, LKG DIFF CLU DISC (PART OF 18) (WIDTH .51 INCH)
09412303 RETAINER, EXT.SNAP RING M46 DIA SHF
26012909 WASHER, LKG DIFF CLU DISC THR (.022 THK)
26012910 WASHER, LKG DIFF CLU DISC THR (.027 THK)
26012911 WASHER, LKG DIFF CLU DISC THR (.032 THK)
26012912 WASHER, LKG DIFF CLU DISC THR (.036 THK)
26012913 WASHER, LKG DIFF CLU DISC THR (.040 THK)
26012914 WASHER, LKG DIFF CLU DISC THR (.044 THK)
26012915 WASHER, LKG DIFF CLU DISC THR (.048 THK)
26012916 WASHER, LKG DIFF CLU DISC THR (.052 THK)
12471404 DISC SET, LKG DIFF CLU (INCLS 15) (EATON EDS- 29534 INCLS WASHER, DISCS & GUIDE)
19178111 GEAR KIT, DIFF SI & PINION (INCLS 6, 7, 13)
19180956 GEAR KIT, DIFF SI & PINION (INCLS 6, 7, 13)
(TX05-060) - 2007-2009 CK1(06-36) МОСТ В СБОРЕ/ЗАДНИЙ 9.50 RING GEAR ЧАСТЬ 2 DIFFERENTIAL/LOCKING(G80,AXN)
12471410 DIFFERENTIAL, (INCLS 2-19) (INCLS GEARS)
14039026 WASHER, DIFF P/GR THR (DOME STYLE)
00462787 GUIDE, LKG DIFF CLU DISC (PART OF 10) (WIDTH .71 INCH)
15599626 SHIM, DIFF SI GR (.010 THK)
15599627 SHIM, DIFF SI GR (.015 THK)
15599628 SHIM, DIFF SI GR (.020 THK)
15599629 SHIM, DIFF SI GR (.025 THK)
15599630 SHIM, DIFF SI GR (.030 THK)
15599631 SHIM, DIFF SI GR (.035 THK)
15599632 SHIM, DIFF SI GR (.040 THK)
15599633 SHIM, DIFF SI GR (.045 THK)
teamcadillac.ru
12471390 DISC SET, LKG DIFF CLU (INCLS 8) (EATON EDS-29565)
14048384 GOVERNOR KIT, LKG DIFF (EATON EDS-27811) (INCLS BRKT)
14039028 BLOCK, LKG DIFF THR (BLUE) (1.594" THK)
14039029 BLOCK, LKG DIFF THR (GRAY) (1.598" THK)
14039031 BLOCK, LKG DIFF THR (YELLOW) (1.610" THK)
14039033 BLOCK, LKG DIFF THR (BROWN) (1.622" THK)
15599672 BLOCK, LKG DIFF THR (WHITE) (1.602" THK)
15599673 BLOCK, LKG DIFF THR (PURPLE) (1.606" THK)
15599675 BLOCK, LKG DIFF THR (ORANGE) (1.614" THK)
15599676 BLOCK, LKG DIFF THR (PINK) (1.618" THK)
12471411 CAM, LKG DIFF
15599623 GUIDE, LKG DIFF CLU DISC (PART OF 18) (WIDTH .93 INCH)
00462786 SLEEVE, LKG DIFF SI GR THR
00462769 WASHER, LKG DIFF CLU DISC THR (.027 THK)
00462770 WASHER, LKG DIFF CLU DISC THR (.037 THK)
00462771 WASHER, LKG DIFF CLU DISC THR (.042 THK)
00462772 WASHER, LKG DIFF CLU DISC THR (.048 THK)
14039035 WASHER, LKG DIFF CLU DISC THR (.022 THK)
14039036 WASHER, LKG DIFF CLU DISC THR (.032 THK)
14039037 WASHER, LKG DIFF CLU DISC THR (.040 THK)
14039038 WASHER, LKG DIFF CLU DISC THR (.044 THK)
14039039 WASHER, LKG DIFF CLU DISC THR (.052 THK)
12471408 DISC SET, LKG DIFF CLU (INCLS 15) (EATON EDS- 29566)
12471409 GEAR KIT, DIFF SI & PINION (INCLS 6, 7, 13)
(TX05-061) - 2008-2009 K107(06) ВАЛ ПРИВОДА-КАРДАННЫЙ ВАЛ (ONE PIECE) (6L80 AUTOMATIC MYC, 4L60-E AUTOMATIC M30)
teamcadillac.ru
25932512 SHAFT, PROP (INCLS 2-4)
88964470 YOKE, PROP SHF SLIP (WHEN REPLACING A ВАЛ ПРИВОДА-КАРДАННЫЙ ВАЛ SLIP YOKE, A NEW ВАЛ ПРИВОДА-КАРДАННЫЙ ВАЛ JOINT KIT (5.548) MUST ALSO BE USED) (PART OF 1) [ВИЛКА КАРДАННОГО ВАЛА]
89059111 JOINT KIT, PROP SHF UNIVERSAL (PART OF 1) (INCLS 4) [КРЕСТОВИНА КАРДАННОГО ВАЛА]
26054781 RING, PROP SHF UJT SPIDER BRG RET (FRT PROP) (PART OF 1, 3) (RETAINING RING) [СТОПОРНОЕ КОЛЬЦО КРЕСТОВИНЫ КАРДАННОГО ВАЛА]
(TX05-113) - 2007-2009 K1 ВАЛ ПРИВОДА-КАРДАННЫЙ ВАЛ/FRONT AXLE
15902926 SHAFT, F/AXL PROP (INCLS 2-6)
teamcadillac.ru
12479126 JOINT KIT, F/AXL PROP SHF UNIVERSAL (PART OF 1) (INCLS 3) (FOR NON-CANADIAN ORDERS) [КРЕСТОВИНА КАРДАННОГО ВАЛА]
01456507 RING, PROP SHF UJT SPIDER BRG RET (PART OF 1, 2) (5.586)
12471638 YOKE, TRFER CASE F/AXL PROP SHF (USES 12471527 BOOT) (PART OF 1) (HAS FORGING OF 40006884) [ВИЛКА КАРДАННОГО ВАЛА]
26064275 CLAMP, F/AXL PROP SHF SLIP YOKE BOOT (PART OF 1, 6) (165.3) (3 SLOTS) (5.586) [ХОМУТ]
12471527 BOOT KIT, F/AXL PROP SHF SLIP YOKE (PART OF 1) (INCLS 5) (INCLS CLAMPS) (5.586) [ПЫЛЬНИК ПЕРЕДНЕЙ ОСИ]
06 - ПЕРЕДНЯЯ ОСЬ-ПЕРЕДНЯЯ ПОДВЕСКА - РУЛЕВОЕ УПРАВЛЕНИЕ
(TC06-899) - 2008-2009 CK1 РУЛЕВОЙ МЕХАНИЗМ В СБОРЕ (EXC HYBRID HP2)
19207492 GEAR KIT, STRG (REMAN) (INCLS 2-10, 13-17) [РУЛЕВАЯ РЕЙКА]
19167837 PIPE KIT, S/GR (PART OF 1) (INCLS 5) (LT) (HAS FEMALE THREADS ON FITTING)
19167838 PIPE KIT, S/GR (PART OF 1) (INCLS 5) (RT) (HAS FEMALE THREADS ON FITTING)
26081619 SEAL, S/GR PIPE (O RING) (PART OF 1-3) (6.00MM) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО РУЛЕВОЙ РЕЙКИ]
teamcadillac.ru
07828017 RING, S/GR STUB SHF SEAL RET (PART OF 1)
15776969 SEAL, S/GR STUB SHF (PART OF 1)
11562064 CLAMP, CRIMP, 66.4 DIA, 7 WIDTH, STAINLESS STEEL (PART OF 1, 9, 14)
15254057 BOOT KIT, S/GR (INCLS 8, 10) (PART OF 1) (EXC TWO MODE HYBRID)
11562066 CLAMP, ПРУЖИНАBAND, DIA MIN 19.2, MAX 22.86, SAE 1055 STL, GM7111M (PART OF 1, 9)
11516074 ГАЙКА, STRG LNKG OTR TIE ROD (PART OF 12) (HEX M14X2, 13THK) (8.917) [ГАЙКА М10]
15254061 ROD KIT, STRG LNKG OTR TIE (INCLS 12) (EXC TWO-MODE HYBRID) [УСТАНОВОЧНЫЙ КОМПЛЕКТ]
11562065 ГАЙКА, STRG LNKG INR TIE ROD (PART OF 1, 14) (M16X1.5, 11THK) (8.915)
19178561 ROD KIT, STRG LNKG INR TIE (INCLS 8, 13) (PART OF 1) (EXC TWO-MODE HYBRID) [НАКОНЕЧНИК РУЛЕВОЙ ТЯГИ]
26100863 SEAL, P/S GR INL HOSE (O RING) (PART OF 1) (6.824) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО РУЛЕВОГО МЕХАНИЗМА]
13271879 SEAL, P/S GR OTLT HOSE (O-RING) (PART OF 1)
(TC06-900) - 2007-2009 K1 DRIVE AXLE MOUNTING/FRONT
15201933 BRACKET, FRT DIFF CARR (СМ. ГРУППУ 07.000 "FRAME" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [СУППОРТ ДИФФЕРЕНЦИАЛА ВЕДУЩЕГО МОСТА]
11519538 БОЛТ, FRT DIFF CARR (M12X1.75X45) (8.900) [БОЛТ М12]
teamcadillac.ru
11562485 ГАЙКА, FRT DIFF CARR BRKT (HF M12X1.75X14) [ГАЙКА]
11610231 WASHER - FLAT, 15X32X4.45, SAE 1050-1080 STL, HRC 40-45, GMW3179 (FRT DIFF CARR BRKT) [ШАЙБА 14 ММ]
11561577 БОЛТ, FRT DIFF CARR BRKT (8.900)
15201932 BRACKET, FRT DIFF CARR (СМ. ГРУППУ 07.000 "FRAME" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА)
11514598 ГАЙКА, FRT DIFF CARR BRKT (HF 12X1.75) (8.915) [ГАЙКА М12]
15847253 SHIELD, FRM FRT HT
11517560 SCREW, FLAT WA (NRW) AND HX WA HD, M8X1.25X25 (FRM FRT H/SHLD)
(TC06-901) - 2007-2009 K1 VENT HOSE/FRONT AXLE
15743069 VENT, F/AXL (PART OF 2) (5.387)
teamcadillac.ru
15201937 HOSE, F/AXL VENT (INCLS 1, 3)
15157936 CLIP, F/AXL VENT HOSE (PART OF 2) (1 LINE) (5.387)
12471619 CONNECTOR, FRT DIFF CARR VENT HOSE
(TC06-904) - 2007-2009 K1 ЧАШКА ДИФФЕРЕНЦИАЛА/FRONT AXLE ЧАСТЬ 1 ASSEMBLY (ALL WHEEL DRIVE NR3)
teamcadillac.ru
25818422 AXLE, FRT (3.42 RATIO) (CODE ZW5, CB8)
(TC06-906) - 2007-2009 CK1 ПОДВЕСКА-ПЕРЕДНЯЯ
15096197 ARM, FRT UPR CONT (INCLS 4) (INCLS BALL JOINT)
25812726 ARM, FRT UPR CONT (INCLS 4) (BALL JOINT IS INCLUDED PER PRINTS) [РЫЧАГ ПОДВЕСКИ]
11561435 ГАЙКА, HFH LOCK, M10X1.5X20, 28 OD, 10, 7111M, ALL METAL PREV TORQ (FRT S/ABS) [ГАЙКА]
03537772 ГАЙКА, FRT UPR CONT ARM BALL STUD (M12X1.75) (8.917)
11516383 ГАЙКА, FRT LWR CONT ARM BALL STUD (M16X2X18.9, 18.2 THK) (*KIT3) (8.917) [ГАЙКА]
teamcadillac.ru
10355407 ARM, FRT LWR CONT (INCLS 14, 17, 22) (THIS PART IS FOR ALUMINUM LCA ONLY)
25788115 ARM, FRT LWR CONT (INCLS 14, 17, 22)
25997508 ARM, FRT LWR CONT (INCLS 14, 17, 22) (CAST ALUMINU) [РЫЧАГ ПОДВЕСКИ]
11516133 ГАЙКА, FRT LWR CONT ARM (M16X2X15) (8.917) [ГАЙКА М16]
15567836 WASHER, FRT LWR CONT ARM (16.38IDX23.87ODX3.27) (6.168) [ШАЙБА М16]
11561429 ГАЙКА, FRT S/ABS (M10X1.5) (PREV TORQUE CLIP) [ГАЙКА М10]
15733533 БОЛТ, FRT LWR CONT ARM (M16X2.0X118, 60 THD) [БОЛТ М16]
11610404 БОЛТ, HEX W/CON WA, M10X1.5X75, 66.35THD, 20 OD, 10.9, GMW3359, M-PT (FRT S/ABS)
10369554 SHAFT, FRT STAB
15252732 SHAFT, FRT STAB
11609701 БОЛТ, HFH, M10X1.5X60, 49 THD, 17.08 OD, 6202M STL, GMW3179-G, TAPPING (FRT STAB SHF) [БОЛТ М10]
11570935 CLAMP, FRT STAB SHF (WHEN USING NEW CLAMP 11570935 USE BOLT # 11570934)
15124516 INSULATOR, FRT STAB SHF (USE WITH 36 MM SHAFT) [ВТУЛКА СТАБИЛИЗАТОРА ПОДВЕСКИ]
15733534 БОЛТ, FRT LWR CONT ARM (M16X2.0X140, 52 THD) [БОЛТ М16]
11516885 SCREW, HFH W/FL WA, TAP, M8X1.25X20, 7THD, 17 O.D., TR PT, 6202M, PZOR (ELEK SUSP FRT POSN SEN BRKT)
15098628 SENSOR, ELEK SUSP FRT POSN (INCLS 38, 39) [ДАТЧИК ПОЛОЖЕНИЯ ПОДВЕСКИ]
15098629 SENSOR, ELEK SUSP FRT POSN (INCLS 38, 39) [ДАТЧИК ПОЛОЖЕНИЯ ПОДВЕСКИ]
11609404 STUD, ELEK SUSP FRT POSN SEN LINK BALL (M6X1X9.5) (HEX, 8 DIA BALL STYLE)
11509419 БОЛТ, M10X1.5X25 (FRT WHL DRV SHF) [БОЛТ М10]
15868123 SHAFT, FRT WHL DRV (СМ. ГРУППУ 06.000 "DRIVE SHAFT/FRONT WHEEL" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ПРИВОД КОЛЕСА В СБОРЕ]
15522089 WASHER, FRT WHL DRV SHF (6.063) [ШАЙБА ГАЙКИ ПЕРЕДНЕЙ СТУПИЦЫ]
11609826 ГАЙКА, FRT WHL DRV SHF (M24X2X22) [ГАЙКА М14]
15815637 LINK, ELEK SUSP FRT POSN SEN (PART OF 31)
25918049 LINK, FRT STAB SHF (INCLS 10-12, 23, 25) [СТОЙКА СТАБИЛИЗАТОРА ПОДВЕСКИ]
12472859 CAM KIT, FRT UPR CONT ARM ADJ (INCLS 2, 3, 5) (INCLS 8-CAMS, 4-BOLTS & 4-NUTS) (LOCATING PIN PART OF FRAME)
19209396 STUD KIT, FRT LWR CONT ARM BALL (INCLS 9, 14) [ШАРОВАЯ ОПОРА]
(TC06-907) - 2008-2009 CK1 СИСТЕМА РУЛЕВОГО УПРАВЛЕНИЯ & СОПРЯЖЕННЫЕ ДЕТАЛИ (EXC HYBRID HP2)
11517996 ГАЙКА, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (STRG COL) [ГАЙКА М10]
21011332 ГАЙКА, HEX STAMPED TY DF FLG 14 (STRG COL SEAL) (8.921)
25815601 SEAL, STRG COL (145.2MM LONG)
25862789 SHAFT, S/GR CPLG (INCLS 6-11)
15017238 ГАЙКА, S/GR CPLG (PART OF 5) (M10X1.5 6H, 21.5 OD) (W/PREVAILING TORQ FLANGE)
11515768 БОЛТ, S/GR CPLG (PART OF 5) (M10X1.5X40, 30 THD) (8.900) [БОЛТ М10Х1.5Х40]
11561800 CLAMP-CRIMP, 33.5 DIA, 304 STAINLESS STEEL (PART OF 5)
11561799 CLAMP, DIA 69.7, 304 STAINLESS STEEL (PART OF 5)
26005756 БОЛТ, S/GR CPLG (USED ON LWR SHAFT) (M10X1.5X31) (HFH NYLON LOCK) (6 POINT HEAD)
11516074 ГАЙКА, HEX M14X2X13 (STRG LNKG OTR TIE ROD) [ГАЙКА М10]
11609229 БОЛТ, S/GR (M16X2X172, 57THD) (W/ADHESIVE)
11569939 БОЛТ, S/GR (M12X1.75X50, 33THD)
teamcadillac.ru
88965503 БОЛТ, S/GR CPLG (M10X1.5X35) (FOR SERVICE USE 11515759 T/W 12345382)
11514597 ГАЙКА, S/GR CPLG (M10X1.5 6H, 21.8OD) (2.383)
14074908 WASHER, STRG COL (.460 X1.12 X.180 PL) (6.509)
(TC06-910) - 2007-2009 CK1,2,3 РУЛЕВОЕ КОЛЕСО (LEATHER WRAPPED NP5, EXC ACCESSORY CONTROLS UK3)
25776311 WHEEL, STRG (INCLS 2-4, 6-8) (CASHMERE)
15255097 COVER, STRG WHL LWR (PART OF 1) (EBONY)
15255102 COVER, STRG WHL LWR (PART OF 1) (TRINITY)
15844710 COVER, STRG WHL LWR (PART OF 1) (SILVER)
25824700 COVER, STRG WHL LWR (PART OF 1) (METAL BRUSH)
teamcadillac.ru
25826421 COVER, STRG WHL LWR (PART OF 1) (SOLITARE)
15257875 БОЛТ, STRG WHL LWR CVR (PART OF 1) (M3.63-1.34X10MM) (SPECIAL TORX PLUS (15 IP) PAN HEAD)
15255031 CONTACT, STRG WHL СИГНАЛ (PART OF 1)
15255034 COVER, STRG WHL LWR (PART OF 1) (EBONY)
15844709 COVER, STRG WHL LWR (PART OF 1) (SILVER)
25824698 COVER, STRG WHL LWR (PART OF 1) (METAL BRUSH)
11609658 ГАЙКА, STRG WHL (M14X1.5, 10THK) (NON FLANGED) (6.518) [ГАЙКА М14]
11609659 ГАЙКА, HEX M14X1.5 PLAIN GRD 9 (STRG WHL) (8.917) [ГАЙКА]
(TC06-911) - 2007-2009 CK1 РУЛЕВОЕ КОЛЕСО (WOOD TRIM N30, EXC HEATED KA9)
20853271 WHEEL, STRG (INCLS 2-5, 7-9) (EBONY)
20853272 WHEEL, STRG (INCLS 2-5, 7-9) (COCOA)
25853065 WHEEL, STRG (INCLS 2-5, 7-9) (EBONY)
25853066 WHEEL, STRG (INCLS 2-5, 7-9) (COCOA)
25853073 WHEEL, STRG (INCLS 2-5, 7-9) (EBONY)
25853074 WHEEL, STRG (INCLS 2-5, 7-9) (COCOA)
25853088 WHEEL, STRG (INCLS 2-5, 7-9) (EBONY)
25853089 WHEEL, STRG (INCLS 2-5, 7-9) (COCOA)
25851952 SWITCH, RDO CONT (PART OF 1) (EBONY) (9.649)
25851953 SWITCH, RDO CONT (PART OF 1) (COCOA) (9.649)
teamcadillac.ru
25851956 SWITCH, RDO CONT (PART OF 1) (COCOA)
15874515 MODULE, STRG WHL INFL RST (EBONY) (LABELED 15874515) (DUAL LEVEL) (16.712)
15874516 MODULE, STRG WHL INFL RST (COCOA) (LABELED 15874516) (DUAL LEVEL) (INCLS EMBLEM) (16.712)
15874519 MODULE, STRG WHL INFL RST (EBONY) (LABELED 15874519) (DUAL LEVEL) (16.712)
15874520 MODULE, STRG WHL INFL RST (COCOA) (LABELED 15874520) (DUAL LEVEL) (16.712)
25917968 MODULE, STRG WHL INFL RST (EBONY) (LABELED 25917968) (DUAL LEVEL) (16.712) [ПОДУШКА БЕЗОПАСНОСТИ]
25917969 MODULE, STRG WHL INFL RST (COCOA) (LABELED 25917969) (DUAL LEVEL) (16.712) [МОДУЛЬ]
25917971 MODULE, STRG WHL INFL RST (EBONY) (LABELED 25917971) (DUAL LEVEL) (16.712)
25917972 MODULE, STRG WHL INFL RST (COCOA) (LABELED 25917972) (DUAL LEVEL) (16.712)
15255100 COVER, STRG WHL LWR (PART OF 1) (TRINITY)
25826420 COVER, STRG WHL LWR (PART OF 1) (SOLITARE)
15819309 SWITCH, CRCONT (PART OF 1) (ACDelco #D1957E)
15824105 SWITCH, CRCONT (PART OF 1)
15824106 SWITCH, CRCONT (PART OF 1)
15824109 SWITCH, CRCONT (PART OF 1) (ACDelco #D1958E)
(TC06-911) - 2008-2009 CK1,2,3 РУЛЕВОЕ КОЛЕСО (LEATHER WRAPPED NP5, ACCESSORY CONTROLS UK3, EXC HYBRID HP2)
25853085 WHEEL, STRG (INCLS 2-5, 7-9) (CASHMERE)
25851954 SWITCH, RDO CONT (PART OF 1) (CASHMERE) (9.649)
teamcadillac.ru
(TC06-912) - 2007-2009 CK1 РУЛЕВОЕ КОЛЕСО (WOOD TRIM N30, HEATED KA9)
20777676 WHEEL, STRG (INCLS 2-5, 7-9) (COCOA)
25853076 WHEEL, STRG (INCLS 2-5, 7-9) (EBONY) [РУЛЕВОЕ КОЛЕСО]
25853077 WHEEL, STRG (INCLS 2-5, 7-9) (COCOA)
25853091 WHEEL, STRG (INCLS 2-5, 7-9) (EBONY)
25853092 WHEEL, STRG (INCLS 2-5, 7-9) (COCOA)
25853096 WHEEL, STRG (INCLS 2-5, 7-9) (COCOA)
25851956 SWITCH, RDO CONT (PART OF 1) (COCOA) (9.649)
25784920 MODULE, STRG WHL INFL RST (COCOA) (DUAL LEVEL) (16.712)
15824110 SWITCH, CRCONT (PART OF 1) [ВЫКЛЮЧАТЕЛЬ УПРАВЛЕНИЯ КРУИЗ-КОНТРОЛЕМ РАСПОЛОЖЕННЫЙ НА РУЛЕВОМ КОЛЕСЕ]
15824111 SWITCH, CRCONT (PART OF 1)
15824112 SWITCH, CRCONT (PART OF 1) (ACDelco #D1959E)
15824113 SWITCH, CRCONT (PART OF 1) (ACDelco #D1960E)
teamcadillac.ru
(TC06-913) - 2008-2009 CK1 НАСОС РУЛЕВОГО УПРАВЛЕНИЯ LINES (EXC HYBRID HP2)
25858603 HOSE, P/S GR INL (INCLS 2, 4) [ШЛАНГ СИСТЕМЫ РУЛЕВОГО УПРАВЛЕНИЯ]
26001594 SEAL, P/S GR INL HOSE (O RING) (PART OF 1) (7.65MM IDX1.63MM THK) [ПРОКЛАДКА ТРУБКИ НАСОСА]
teamcadillac.ru
11562063 БОЛТ, HFH, M6X1X25, 18 THD, 12.8 OD, 9.8 STL, HEX CHROME FREE, SN-ZN. (PART OF 1)
26100863 SEAL, P/S GR INL HOSE (O RING) (6.824) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО РУЛЕВОГО МЕХАНИЗМА]
11516255 CLAMP, ПРУЖИНА BAND HOSE (M16X1) (PART OF 8)
25918689 COOLER, P/S FLUID (INCLS 7)
11589039 БОЛТ, HEX, W/CON WA, M6X1X30, 20 THD, 24 O.D., 9.8, GMW4205 (P/S FLUID CLR) [БОЛТ М6Х1Х30]
11516255 CLAMP, ПРУЖИНА BAND HOSE (M16X1) (PART OF 11)
15812565 HOSE, P/S GR OTLT (INCLS 10) [ШЛАНГ СИСТЕМЫ РУЛЕВОГО УПРАВЛЕНИЯ]
11589398 БОЛТ, HEX HD, W/CON WA, M6X1X30, 18.11 THD, 24 O.D., 9.8, GMW3179, BLACK (P/S FLUID CLR)
52476687 INSULATOR, P/S FLUID CLR (UPPER)
(TC06-914) - 2007-2009 K1 DRIVE SHAFT/FRONT WHEEL
15868123 SHAFT, FRT WHL DRV (INCLS 2-16) [ПРИВОД КОЛЕСА В СБОРЕ]
26056803 RING, FRT WHL DRV SHF TRI-POT JT SPIDER RET (PART OF 4, 6) (6.056)
15295245 JOINT, FRT WHL DRV SHF TRI-POT (INCLS 3) (MUST ALSO ORDER APPROPRIATE BOOT KIT) [ШРУС В СБОРЕ]
26056789 CLAMP, FRT WHL DRV SHF TRI-POT JT BOOT OTR (PART OF 6)
26062615 BOOT KIT, FRT WHL DRV SHF TRI-POT JT (INCLS 3, 5, 7) [ПЫЛЬНИК ШРУСА]
07849180 CLAMP, FRT WHL DRV SHF TRI-POT JT BOOT INR (PART OF 6) (34.60MM DIA, 10MM THK) (6.060)
07849180 CLAMP, FRT WHL DRV SHF CV JT BOOT INR (PART OF 10) (34.60MM DIA, 10MM THK) (6.060)
15868187 BOOT KIT, FRT WHL DRV SHF CV JT (INCLS 9, 11, 12) [ПЫЛЬНИК ШРУСА]
26007601 CLAMP, FRT WHL DRV SHF CV JT BOOT OTR (PART OF 10) (105.91MM DIA) (6.060)
07849284 RING, FRT WHL DRV SHF CV JT INR RACE RET (PART OF 10, 14)
teamcadillac.ru
26057639 JOINT, FRT WHL DRV SHF CV (INCLS 12, 13, 15) (MUST ALSO ORDER APPROPRIATE BOOT KIT)
(TC06-916) - 2009 CK1 НАСОС РУЛЕВОГО УПРАВЛЕНИЯ ASM (LC9/5.3-3,LH6/5.3M,LMG/5.3-0,LY2/4.8C,LY5/5.3J,L76/6.0Y,L9H/6.2-2)
26045594 RESERVOIR KIT, P/S FLUID (INCLS 6, 9-11) (PART OF 12)
teamcadillac.ru
26095194 CAP, P/S FLUID RSVR (PART OF 12)
26009574 STUD, P/S FLUID RSVR (PART OF 12) (M10X1.5X16) (SHORT) (6.606)
15241681 STUD, P/S FLUID RSVR (PART OF 12) (LONG)
26025709 FITTING, P/S PUMP (PART OF 12) (*KIT2)
26020642 SEAL, P/S PUMP FTG (O RING) (PART OF 1, 12) (14.5MM I.D.) (*KIT1) (6.635) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО НАСОСА ГУРА]
26065843 VALVE, P/S PUMP FLOW CONT (PART OF 12) (VALVE ONLY) (*KIT2)
15909824 PUMP, P/S (INCLS 1-11, 13, 14)
20756716 PUMP, P/S (INCLS 1-11, 13, 14) [НАСОС ГУРА]
15277770 SEAL, P/S PUMP SHF (PART OF 12) (I.D.22.78MM) (USED W/19MM SHAFT) [ПРОКЛАДКА НАСОСА ГУРА]
15825938 SEAL KIT, P/S PUMP (INCLS 6, 9-11) (FRT SEAL NOT INCL)
15246463 VALVE KIT, P/S PUMP FLOW CONT (INCLS 5, 7, 8)
(TC06-926) - 2009 CK1(06-43) СИСТЕМА РУЛЕВОГО УПРАВЛЕНИЯ & СОПРЯЖЕННЫЕ ДЕТАЛИ (HYBRID HP2)
15017238 ГАЙКА, S/GR CPLG (M10X1.5 6H, 21.5 OD) (W/PREVAILING TORQ FLANGE)
11515768 БОЛТ, S/GR CPLG (PART OF 7) (M10X1.5X40, 30 THD) (8.900) [БОЛТ М10Х1.5Х40]
25862788 SHAFT, S/GR CPLG (INCLS 6, 8-13)
15017238 ГАЙКА, S/GR CPLG (PART OF 7) (M10X1.5 6H, 21.5 OD) (W/PREVAILING TORQ FLANGE)
11561800 CLAMP-CRIMP, 33.5 DIA, 304 STAINLESS STEEL (PART OF 7)
19177403 BOOT KIT, INTER STRG SHF (PART OF 7) (INCLS 11, 13)
11561799 CLAMP, DIA 69.7, 304 STAINLESS STEEL (PART OF 7)
teamcadillac.ru
11517817 БОЛТ, HEX, M10X1.5X25, 14 THD, 28 OD, 6202M, 7114M, TAP, TR-PT (STRG LNKG SHLD)
15847584 SHIELD, STRG LNKG
25962338 MODULE, ELEK P/S MOT CONT (INCLS 21)
11900241 БОЛТ, P/S CONT MDL (M6X1.0X12) (3.602)
12624430 MODULE, DRV MOT GEN PWR INV (W/ 2ND MPU) (СМ. ГРУППУ 02.000 "CONTROL MODULE ASM/DRIVE MOTOR" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА)
(TC06-927) - 2009 CK1(06-43) РУЛЕВОЙ МЕХАНИЗМ В СБОРЕ (HYBRID HP2)
15895639 GEAR, STRG (INCLS 2, 3, 6-9) (LESS OUTER TIE ROD ENDS)
25911321 GEAR, STRG (INCLS 2, 3, 6-9) (INCLS OUTER TIE ROD ENDS)
15895647 ROD KIT, STRG LNKG INR TIE (PART OF 1) (INCLS 6, 7, 9) (TWO-MODE HYBRID)
teamcadillac.ru
11516074 ГАЙКА, STRG LNKG OTR TIE ROD (PART OF 5) (HEX M14X2, 13THK) (8.917) [ГАЙКА М10]
15895646 ROD KIT, STRG LNKG OTR TIE (INCLS 4) (TWO-MODE HYBRID)
11562407 ГАЙКА, STRG LNKG INR TIE ROD (PART OF 1, 3) (M16X1.5, 13THK)
11570615 CLAMP, HOSE ПРУЖИНАBAND, 26 NOMINAL DIA, 15 THK, STL, ROBO (PART OF 1, 3, 8)
15895648 BOOT KIT, S/GR (PART OF 1) (INCLS 7, 9) (TWO-MODE HYBRID)
26079718 CLAMP, S/GR BOOT (PART OF 1, 3, 8) (62.7 DIA, 7.5 WIDTH) (INNER)
11569910 БОЛТ, P/S ASST MOT (PART OF 11) (M8X1.25X25, 20THD)
15895645 MOTOR KIT, P/S ASST (INCLS 10, 12-18)
15895637 SEAL, P/S ASST MOT (PART OF 11)
25813638 LABEL, P/S FLUID VOLTAGE CAUTION (PART OF 11) (TWO-MODE HYBRID)
11570589 STRAP, WRG HARN (EDGE CLIP) (PART OF 11, 15) (PA66 BLACK, 200 LENGTH)
19177399 HARNESS KIT, P/S WRG (INCLS 14, 16, 17, 18) (PART OF 11)
12355066 STRAP, PLASTIC ADJ TIE (215MM LG) (PART OF 11, 15) (8.965) (ACDelco #16TS825) [ХОМУТ С ФИКСАТОРОМ]
11569906 STRAP, WRG HARN (PART OF 11, 15) (FITS 11 DIA HOLE, 140 LENGTH, POLYPROPYLENE)
11569907 STRAP, WRG HARN (TRIPLE CLIP) (PART OF 11, 15) (FITS HOLE 6.35 DIA, HOLDS TWO LINE DIA 10.6)
(TC06-929) - 2009 CK1(06-43) РУЛЕВОЕ КОЛЕСО (HYBRID HP2, LEATHER WRAPPED NP5, ACCESSORY CONTROLS UK3)
25853080 WHEEL, STRG (INCLS 2-5, 7-9) (CASHMERE)
teamcadillac.ru
(TC06-930) - 2009 CK1(06-36) РУЛЕВАЯ КОЛОНКА (CADILLAC Z75)
15775831 SHROUD, STRG COL (INCLS 24) (TITANIUM)
25797755 SHROUD, STRG COL (INCLS 24) (EBONY)
25797756 SHROUD, STRG COL (INCLS 24) (COCOA)
25861815 ATTACHMENT KIT, THEFT DTRNT SYS
26088811 CASE, IGN LK CYL (EXCEPT LK ACTUATOR & PASS SENSOR) (PART OF 40) (PASS KEY) [КОРПУС ЗАМКА ЗАЖИГАНИЯ]
26036497 БОЛТ, STRG COL LWR TR CVR (PART OF 40) (M5X.8X15) (6.760) [БОЛТ М5]
26082804 RETAINER, A/TRNS PARK LK CBL
26036496 БОЛТ, STRG COL UPR CVR (M4.55 TAP X15) (2.188)
25733005 SWITCH, IGN & START (ACDelco #D1485F) [КОНЦЕВОЙ ВЫКЛЮЧАТЕЛЬ ЗАМКА ЗАЖИГАНИЯ]
15231641 SEAT, STRG SHF UPR BRG RACE (PART OF 40)
26055299 ПРУЖИНА, STRG SHF UPR BRG (PART OF 40)
15775848 CAM, T/SIG SW CANC (PART OF 40)
26049186 PLATE, T/SIG SW CANC CAM POSN (PART OF 40) (W/SHIELD) (6.521)
05694191 RING, STRG SHF LK PLT RET (PART OF 40) (6.524)
26011609 WASHER, STRG WHL INFL RST MDL COIL (14.865) [ШАЙБА D=14ММ]
15829093 COIL, STRG WHL INFL RST MDL (W/ACSRY CNCT) [КОНТАКТНЫЙ БЛОК РУЛЕВОЙ КОЛОНКИ]
teamcadillac.ru
15829094 COIL, STRG WHL INFL RST MDL (W/ACSRY CNCT) [КАТУШКА]
25966964 COIL, STRG WHL INFL RST MDL (W/ACSRY CNCT)
00274414 RING, EXT, SNAP, FITS M19 OR.75" SHAFT, STL, PL (STRG WHL INFL RST MDL COIL RET)
15849313 SWITCH, T/SIG & HDLP & HDLP DIMR & WSW & WSWA (W/O RR WIPER) (2.895) (ACDelco #D6221E)
15849314 SWITCH, T/SIG & HDLP & HDLP DIMR & WSW & WSWA (INCLUDES HAZARD BUTTON) (W/RR WIPER) (2.895) (ACDelco #D6224E)
26036497 БОЛТ, HDLP DIMR & T/SIG SW (M5X.8X15) (6.760) [БОЛТ М5]
26001827 BEARING KIT, STRG SHF UPR (PART OF 40) (STRG COL INR W/RACE)
25797751 HARNESS, STRG COL WRG
26036521 PIN, STRG COL PIV (PART OF 40) [НАПРАВЛЯЮЩАЯ РЕГУЛИРОВКИ РУЛЕВОЙ КОЛОНКИ]
11561801 STRAP, WRG HARN (HOLDS TUBE DIA 60MM)
15775835 SEAL, A/TRNS CONT LVR [НАКЛАДКА РУЛЕВОЙ КОЛОНКИ]
25797681 SWITCH, STRG COL TILT WHL
26104379 SCREW, FLAT HEAD W/SHLDR, M5X0.8X12, 7 THD, 9.3 OD, GM6171M STL, TAP (STRG COL HSG CVR)
26078026 CABLE, STRG COL TILT WHL ACTR (PART OF 28)
25844490 MOTOR, STRG COL TILT WHL ACTR (W/ SEN) (INCLS 27, 29-31)
26064459 БОЛТ, STRG COL TILT WHL ACTR (PART OF 28) (M4.2X1.59X11.5) (W/WSHR-TORX HD)
11562309 SCREW, OVAL HEAD, 10-24X0.43", GM6010M STL, PHOSPHATE&OIL, TAPPING, W/ADH (STRG COL TILT WHL ACTR BRKT)
25809424 SHAFT, UPR INTER STRG [ВАЛ РУЛЕВОЙ КОЛОНКИ]
15775847 CLIP, STRG WHL POSN SEN RET
15886733 SENSOR, STRG WHL POSN (6.552) [ДАТЧИК ПОЗИЦИИ РУЛЕВОЙ КОЛОНКИ]
15775851 ADAPTER, STRG SHF LWR BRG (PART OF 40) (INCLS LOWER BEARING)
11515759 БОЛТ, S/GR CPLG (M6X1.25X35) (8.900)
11515768 БОЛТ, S/GR CPLG (M10X1.5X40, 30 THD) (8.900) (USED ON INTER SHAFT-MID JOINT) [БОЛТ М10Х1.5Х40]
11610555 БОЛТ, S/GR CPLG (M10X1.5X31) (11MM SOC HEADER PT)
25797752 COLUMN, STRG (INCLS 3, 4, 8-12, 19, 21, 36, 39, 41)
25797804 COLUMN, STRG (INCLS 3, 4, 8-12, 19, 21, 36, 39, 41)
25798016 COLUMN, STRG (INCLS 3, 4, 8-12, 19, 21, 36, 39, 41)
11562309 SCREW, OVAL HEAD, 10-24X0.43", GM6010M STL, PHOSPHATE&OIL, TAPPING, W/ADH (PART OF 40)
15775841 SOLENOID, A/TRNS SHFT LK CONT (ACDelco #15775841)
15775840 CONTROL, A/TRNS (INCLS PARK LOCK CABLE) [МЕХАНИЗМ ПЕРЕКЛЮЧЕНИЯ ПЕРЕДАЧ]
26035516 БОЛТ, A/TRNS SHFT LK CONT SOL
26086318 БОЛТ, A/TRNS CONT LVR (M6X1X13)
25807853 LEVER, A/TRNS CONT (1/16" CONNECTOR PINS)
25807855 LEVER, A/TRNS CONT (1/16" PINS)
25872090 LEVER, A/TRNS CONT
25872091 LEVER, A/TRNS CONT
(TC06-932) - 2008-2009 K1 ЧАШКА ДИФФЕРЕНЦИАЛА/FRONT AXLE ЧАСТЬ 2 (ALL WHEEL DRIVE NR3)
15801498 SHAFT, FRT DRV AXLE INR
15801507 SEAL, FRT DRV AXLE INR SHF [УПЛОТНЕНИЕ ДИФФЕРЕНЦИАЛА]
26066885 BEARING, FRT DRV AXLE INR SHF (USED ON ШЛАНГИ) (6.008) [ПОДШИПНИК ДИФФЕРЕНЦИАЛА]
15270855 ШЛАНГИ, FRT DRV AXLE INR SHF
15270970 GASKET, FRT WHL DRV INTER SHF HSG [ПРОКЛАДКА ДИФФЕРЕНЦИАЛА]
26036835 БОЛТ, FRT DRV AXLE INR SHF HSG (W/WA 20 OD, M10X1.5X34.9)
15876531 CARRIER, FRT DIFF
00360570 PIN, FRT DIFF HALF CARR LOC (0.685)
15270969 GASKET, FRT DIFF CARR [ПРОКЛАДКА ДИФФЕРЕНЦИАЛА]
15876533 LOCK, FRT DIFF BRG ADJR NUT [ШПОНКА]
15876532 ADJUSTER, FRT DIFF BRG (INCLS 13) [РЕГУЛЯТОР В СБОРЕ, ПОДШИПНИКА ПЕРЕДНЕГО ДИФФЕРЕНЦИАЛА]
09420095 BEARING, FRT DIFF (INCLS CUP AND CONE, TIMKEN, LM501349-LM501314, 41.28MM ID X 73.42MM OD X 21.43MM THK) (ACDelco #S13)
14066913 БОЛТ, FRT DIFF R/GR (7/16-20X7/8) (HEX) (*KIT2)
26063838 WASHER, FRT DIFF SI GR THR (69MM OD, 40ID, .77THK) (*KIT1) [УПОРНОЕ КОЛЬЦО ДИФФЕРЕНЦИАЛА]
12479372 RING, FRT DRV AXLE INR SHF RET (DAJACO)
26056600 RING, FRT DRV AXLE INR SHF RET (AMERICAN AXLE) [КОЛЬЦО СТОПОРНОЕ]
teamcadillac.ru
15588350 WASHER, FRT DIFF P/GR THR (CURVE STYLE WASHER) (51.6MM O.D., 20.27MM I.D.) (*KIT1)
25824249 SHAFT, FRT DIFF P/GR (124.84 MM) (*KIT1)
15801501 CASE, FRT DIFF (LESS INTERNAL GEARS)
09428890 PIN, ПРУЖИНА TYPE S HOLE DIA-1/4, LENGTH 1 3/4, STEEL PL (FRT DIFF P/GR SHF LK) (*KIT1)
26041515 BEARING, FRT DRV AXLE INR SHF (USED ON ADJUSTER) [ПОДШИПНИК ДИФФЕРЕНЦИАЛА 60 ММ]
09418356 BEARING, FRT DIFF DRV P/GR INR (INCLS CUP AND CONE, TIMKEN, M802048-M802011, 1 5/8 IN ID X 3 1/4 IN OD X 1 1/32 IN THK) (5.484) (ACDelco #S33)
12479162 SPACER, FRT DIFF DRV P/GR BRG (.062-.068" THK) (*KIT2) (5.453) [ШАЙБА ДИФФЕРЕНЦИАЛА]
12471621 GASKET, FRT DIFF CARR OIL FIL PLUG (BLACK) (5.506) [ЩЕТКА]
12471620 PLUG, FRT DIFF CARR OIL FIL (M40 X 1.5) [ШТЕКЕР]
15588383 GASKET, FRT DIFF CARR OIL DRN PLUG (4.195)
26058815 PLUG, FRT DIFF CARR OIL DRN (M12X1.5)
26058813 SHAFT, FRT DRV AXLE INR (CODE JM6, MY7, TUG, UL2, US9, XS4, ZXN, ZB2, WH2, ZW6) (5.517)
09413427 BEARING, FRT DIFF DRV P/GR OTR (INCLS CUP AND CONE, TIMKEN, M88048-M88010, 1 5/16 IN ID X 2 11/16 IN OD X 7/8 IN THK) (5.447) (ACDelco #S29)
12471590 SEAL, FRT DIFF DRV P/GR [УПЛОТНЕНИЕ ДИФФЕРЕНЦИАЛА]
88967027 YOKE, FRT DIFF DRV P/GR
00517900 WASHER, FRT DIFF DRV PINION GR (.890X1.625X.190) (*KIT2) (5.595)
88891763 ГАЙКА, FRT DIFF DRV P/GR (M10) (*KIT2) (5.595) [ГАЙКА М10]
12479318 GEAR KIT, FRT DIFF SI & PINION (INCLS 16-17, 19-21, 23)
88963591 GEAR KIT, FRT DIFF RING & DRV PINION (INCLS 15, 24, 28, 39, 40)
(TX06-017) - 2009 CK1 КРЕПЛЕНИЕ НАСОСА РУЛЕВОГО УПРАВЛЕНИЯ (LC9/5.3-3,LH6/5.3M,LMG/5.3-0,LY2/4.8C,LY5/5.3J,L76/6.0Y,L9H/6.2-2)
12554030 BRACKET, GEN & P/S PUMP (INCLS 2) (INCLS SPACER)
12550090 SPACER, GEN & P/S PUMP BRKT (PART OF 1) [ВТУЛКА ГЕНЕРАТОРА]
teamcadillac.ru
11515764 БОЛТ, HFH, M10X1.5X20, 18THD, 22.3 O.D., 10.9, 7114M (P/S PUMP RR BRKT)
11514597 ГАЙКА, HFH, 10X1.5 THD, 9.8 THK, 21.8 OD, 510M (10) ZF 7111M (P/S PUMP RR BRKT) (2.383)
12554032 BRACKET, P/S PUMP RR
12604004 PULLEY, P/S PUMP (PHY ID 4004) [ШКИВ НАСОСА ГУРА]
11515767 БОЛТ, HFH, M10X1.5X35, 32THD, 22.3 O.D., MACH, 10.9, 7114M (P/S PUMP) (T/W 12345493) [БОЛТ]
11519214 БОЛТ, HFH M10X1.5X115, 30 MM THD, 22.3 OD, 9.8, 7114M, MAT POINT (GEN & P/S PUMP BRKT)
07 - КУЗОВ - ПРУЖИНЫ - АМОРТИЗАТОРЫ - БАМПЕРЫ
(TC07-635) - 2007-2009 CK1(06-36) ПОДВЕСКА-ЗАДНЯЯ ЧАСТЬ 1
25871432 АМОРТИЗАТОР, RR LVLG SHK [АМОРТИЗАТОР ПОДВЕСКИ]
teamcadillac.ru
25979392 АМОРТИЗАТОР, RR LVLG SHK (ACDelco #580-358) [АМОРТИЗАТОР]
11609819 BOLT-HEX W/CON WA, M14X2X85, 45 THD, 28 OD, 10.9, GMW3359 (RR S/ABS) [БОЛТ М14]
11609243 BOLT M12X1.75X65 (RR STAB SHF INSL CLA)
15257472 LINK, RR STAB SHF [СОЕДИНЕНИЕ СТАБИЛИЗАТОРА]
10383662 SHAFT, RR STAB
11518294 BOLT-HFH, M10X1.5X29.5, 17.08 OD, 6202M, 4435M, TAP, TR-PT (RR STAB SHF INSL CLA) [БОЛТ М10]
88891781 CLAMP, RR STAB SHF INSL [КРОНШТЕЙН]
03537772 ГАЙКА, M12X1.75, 10.6THK, 28 O.D., 10, 7111M (RR STAB SHF LINK) (8.917)
11516382 ГАЙКА, HFH LK M14X2X15, 28 OD 10 7111M (RR S/ABS) [ГАЙКА М10]
14071381 INSULATOR, RR STAB SHF (RUBBER) (28.6 MM STAB BAR) [ИЗОЛЯТОР]
19115819 TUBE, RR S/ABS AIR (СМ. ГРУППУ 02.000 "ЖГУТЫ ПРОВОДОВ/CHASSIS" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ТРУБКА ТОРМОЗНОЙ СИСТЕМЫ]
(TC07-676) - 2007-2009 CK1,2,3 ЦИЛИНДР ЗАМКА/ЗАПАСНОЕ КОЛЕСО
15926907 КЛЮЧ, ЗАЖИГАНИЯ LK (PRE-CUT & PROGRAMMED)
teamcadillac.ru
15926908 КЛЮЧ, ЗАЖИГАНИЯ LK (PRE-CUT & PRE-PROGRAMED FOR FLEET)
25865394 КЛЮЧ, ЗАЖИГАНИЯ (UNCODED) (MASTER)
25945700 CYLINDER, SPA WHL HOIST LK (INCLS 2-8) [ЗАМОК КРЕПЛЕНИЯ ЗАПАСНОГО КОЛЕСА]
(TC07-902) - 2008-2009 CK1(06-36) БАМПЕР ПЕРЕДНИЙ (CADILLAC Z75, EXC PLATINUM EDITION ULT)
15904442 BRACKET, RAD GRL UPR (INCLS 3) [ПОПЕРЕЧНАЯ ПАНЕЛЬ КУЗОВА]
11610055 БОЛТ, HWASH, M6X1X23 (RAD GRL SUPT REINF)
11518121 ГАЙКА, U, M6X1, MULTI THD, .5'-4.0' THK PNL (PART OF 1)
25901978 BRACKET, FRT BPR FASCIA [СУППОРТ ПАНЕЛИ БАМПЕРА]
11610055 БОЛТ, HWASH, M6X1X23 (FRT BPR FASCIA)
25947497 BAR, FRT BPR IMP [БАЛКА ПЕРЕДНЕГО БАМПЕРА]
11519154 БОЛТ, FRT BPR IMP BAR (M14X2X140) [БОЛТ]
25948814 BRACKET, FRT BPR FASCIA SI (INCLS 9) [НАПРАВЛЯЮЩАЯ ПЕРЕДНЕГО БАМПЕРА]
25948815 BRACKET, FRT BPR FASCIA SI (INCLS 9) [ОПОРНАЯ ПЛАНКА ПАНЕЛИ БАМПЕРА]
11518531 ГАЙКА, U-TYPE, M4.2X1.41, 15.9X8.4, .7-2.1 PNL, SAE 1050 STL, 7111M, 8.65 SQ HOL (PART OF 8) (10.512) [ГАЙКА М10]
11610055 БОЛТ, HWASH, M6X1X23 (FRT BPR FASCIA SI BRKT)
teamcadillac.ru
11609685 БОЛТ, HEX W/CON SPR WA, M6X1X27, 19 THD, 24 OD, 8.8, GMW3359 BLACK, M-PT (FRT BPR LWR FASCIA)
10376177 FILLER, FRT BPR OTR FRT [ВСТАВКА ПЕРЕДНЕГО БАМПЕРА]
10376178 FILLER, FRT BPR OTR FRT [ВСТАВКА ПЕРЕДНЕГО БАМПЕРА]
11515638 ГАЙКА, U-TYPE, M4.2X1.41X10.5.5X22, .65-3.8 PNL THK, 1050, ZF (FRT BPR OTR FRT FIL) [ГАЙКА М4.2]
11609385 ГАЙКА, U-TYPE, M6X1, 29.5 LEN, 12.5 WID, 19.5 CEN-END, 1050, GMW3359 (FRT BPR LWR FASCIA) [ГАЙКА М 6]
11515638 ГАЙКА, U-TYPE, M4.2X1.41X10.5.5X22, .65-3.8 PNL THK, 1050, ZF (FRT OTR A/DFL) [ГАЙКА М4.2]
11609465 БОЛТ, HWH, M4.2X1.41X18, 12.5 OD, 6010M, PS (FRT OTR A/DFL) (8.977) [ВИНТ М6]
15138234 DEFLECTOR, FRT AIR [ВОЗДУШНЫЙ ДЕФЛЕКТОР]
11609465 БОЛТ, HWH, M4.2X1.41X18, 12.5 OD, 6010M, PS (FRT BPR OTR FRT FIL) (8.977) [ВИНТ М6]
15140153 ATTACHMENT KIT, FRT LIC PLT (INCLS 20) [КРОНШТЕЙН ДЛЯ НОМЕРНОГО ЗНАКА]
15851090 BRACKET, FRT LIC PLT (CHARCOAL) [КРОНШТЕЙН-ПЕРЕДНЕГО НОМЕРНОГО ЗНАКА *СВЕТЛО-ПЕПЕЛЬНЫЙ]
15941065 BRACKET, FRT LIC PLT (PAINT TO MATCH)
15993201 RETAINER, FRT LIC PLT BRKT (PART OF 19) (FOR 9.3MM DIA HOLE) (NYLON) (17.505) [КРОНШТЕЙН]
25814554 FASCIA, FRT BPR (PAINT TO MATCH) [ПАНЕЛЬ БАМПЕРА]
25705182 БОЛТ, FRT BPR FASCIA CTR SUPT (M9.5X6.0 HI-LO, TL 47MM, 22 OD) (12.249) [ВИНТ М5]
15893972 COVER, FRT TOW HOOK OPG [КРЫШЕЧКА БУКСИРОВОЧНОЙ ПРОУШИНЫ]
15893973 COVER, FRT TOW HOOK OPG [ЗАГЛУШКА ПАНЕЛИ БАМПЕРА]
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (FRT FOG LP) [ГАЙКА М6]
15882456 SUPPORT, FRT BPR FASCIA [СУППОРТ ПАНЕЛИ БАМПЕРА]
20824266 EMBLEM, RAD GRL (BUILT 01/12/09 & AFTER) (FOR 1ST DES SEE 25795247)
25795247 EMBLEM, RAD GRL (WREATH/CREST) (BUILT PRIOR TO 01/12/09) (FOR 2ND DES SEE 20824266) [ЭМБЛЕМА РЕШЕТКИ РАДИАТОРА]
11610055 БОЛТ, HWASH, M6X1X23 (FRT BPR UPR FASCIA)
15078238 RETAINER, RAD GRL (BLACK) (25X15.5) (ALSO REPLACES SILVER) [ФИКСАТОР РЕШЕТКИ РАДИАТОРА]
10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (FRT BPR FASCIA OTR BRKT) [ПИСТОН КРЕПЛЕНИЯ ОБЛИЦОВКИ БАМПЕРА (NYLON)]
(TC07-903) - 2008-2009 CK1(06) ЗАПАСНОЕ КОЛЕСО CARRIER (EXC HYBRID HP2)
15827206 CASE, SPA WHL LK CYL (7.680) [КОРПУС ЗАМКА КРЕПЛЕНИЯ ЗАПАСНОГО КОЛЕСА]
25945700 CYLINDER, SPA WHL HOIST LK (СМ. ГРУППУ 07.000 "ЦИЛИНДР ЗАМКА/ЗАПАСНОЕ КОЛЕСО" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ЗАМОК КРЕПЛЕНИЯ ЗАПАСНОГО КОЛЕСА]
15811583 COVER, RR BPR FASCIA ACC HOLE (PAINT TO MATCH) [КРЫШКА ЗАМКА ПОДЪЕМНИКА ЗАПАСНОГО КОЛЕСА]
10372326 GUIDE, SPA WHL HOIST SHF
teamcadillac.ru
11517827 БОЛТ, HFH W/FL WA, M10X1.5X35, 20 THD, 25 OD, 9.8, 7114M, MACH, P-PT, 6175M A (SPA WHL HOIST) [БОЛТ М10]
25912263 HOIST, SPA WHL [ПОДЪЕМНИК ЗАПАСНОГО КОЛЕСА]
25912264 HOIST, SPA WHL
11518341 БОЛТ, HEX, M10X1.5X25, 14 THD, 28 OD, 6202M, 7114M, TAP, TR-PT (SPA WHL H/SHLD) [БОЛТ М10Х1.5Х25]
25783810 SHIELD, SPA WHL HT
(TC07-906) - 2007-2009 CK107(06) БАМПЕР ЗАДНИЙ (CADILLAC Z75)
teamcadillac.ru
25938524 BAR, RR BPR IMP (INCLS 24, 28) (INCLS TRAILER HITCH RECEIVER) [БАЛКА ЗАДНЕГО БАМПЕРА]
11518531 ГАЙКА, U-TYPE, M4.2X1.41, 15.9X8.4, .7-2.1 PNL, SAE 1050 STL, 7111M, 8.65 SQ HOL (RR BPR FASCIA) (10.512) [ГАЙКА М10]
11519537 БОЛТ, HEX HD, W/CON WA, M12X1.75X40.8, 25.6 THD, 35 O.D., 10.9, GMW3359 (RR BPR IMP BAR)
11569711 ГАЙКА, PUSH-IN, M4.2X1.41, 0.7-2.15 PNL THK, SAE 1050-1065, GMW3359 W/ (RR BPR FASCIA) [ГАЙКА М4.2]
11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (RR W/H PNL LNR) [ВИНТ М4]
11589292 PUSH PIN, FITS 8.5 DIA HOLE IN 2-4.5 THK PNL, NYLON 6/6 GMP.PA66.015 (RR W/H PNL LNR (PUSH IN)) [ФИКСАТОР ПАНЕЛИ БАМПЕРА]
11569711 ГАЙКА, PUSH-IN, M4.2X1.41, 0.7-2.15 PNL THK, SAE 1050-1065, GMW3359 W/ (RR BPR FASCIA SI SUPT) [ГАЙКА М4.2]
15912685 BRACKET, RR BPR FASCIA SUPT [НАПРАВЛЯЮЩАЯ ПАНЕЛИ БАМПЕРА]
25906986 BRACKET, RR BPR FASCIA SUPT [ОПОРНАЯ ПЛАНКА ПАНЕЛИ ПЕРЕДНЕГО БАМПЕРА]
11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (RR BPR FASCIA SI SUPT) [ВИНТ М4]
15950574 HARNESS, RR OBJECT SEN WRG [ПРОВОДКА ДАТЧИКОВ ЗВУКОВОЙ СИГНАЛИЗАЦИИ СИСТЕМЫ ПАРКОВКИ]
15239247 SENSOR KIT, RR OBJECT (INCLS 13) (PRIMED) (W/O ШЛАНГИ) (*KIT1) [ДАТЧИК ПАРКОВКИ]
15817523 ШЛАНГИ, RR OBJECT SEN (PRIMED) (PART OF 16) (OUTBOARD) (*KIT1) (7.831)
15817524 ШЛАНГИ, RR OBJECT SEN (PRIMED) (PART OF 16) (INBOARD) (*KIT1) (7.831) [КОРПУС ДАТЧИКА ПАРКОВКИ]
15817525 ШЛАНГИ, RR OBJECT SEN (PRIMED) (PART OF 16) (OUTBOARD) (*KIT1) (7.831)
15817526 ШЛАНГИ, RR OBJECT SEN (PRIMED) (PART OF 16) (INBOARD) (*KIT1) (7.831)
11515638 ГАЙКА, U-TYPE, M4.2X1.41X10.5.5X22, .65-3.8 PNL THK, 1050, ZF (RR W/H PNL LNR) [ГАЙКА М4.2]
11562024 RETAINER, PUSH IN, 7.5X36.5, FITS 6.35 HOLE IN 2.29-18.34 THK PNL (RR BPR FASCIA (PUSH IN)) [ФИКСАТОР ПАНЕЛИ БАМПЕРА]
15909709 FASCIA, RR BPR (INCLS 12, 19) (PAINT TO MATCH)
20771921 FASCIA, RR BPR (INCLS 12, 19) (PAINT TO MATCH) (MAY NEED TO ORDER HITCH COVER 20777999) [ПАНЕЛЬ БАМПЕРА]
11610049 ГАЙКА, RR BPR FASCIA (SPECIAL PIN-PUSH, FITS 6.6X12.5 RECTANGULAR HOLE, 14.5 LONG) [ГАЙКА М8]
20777999 COVER PKG, RR BPR FASCIA TRLR HITCH ACC HOLE (PAINT TO MATCH) [КРЫШКА ПАНЕЛИ ЗАДНЕГО БАМПЕРА]
15811583 COVER, RR BPR FASCIA ACC HOLE (PART OF 16) (PAINT TO MATCH) [КРЫШКА ЗАМКА ПОДЪЕМНИКА ЗАПАСНОГО КОЛЕСА]
11570498 БОЛТ, HWH W/FL WA, M4.2X1.41X20, 11.4 THD, 17 OD, ISO 2702 STL , GMW4205, T (RR BPR FASCIA)
15853597 PAD, RR BPR FASCIA STEP (USE T/W 15853598) [НАКЛАДКА ПАНЕЛИ БАМПЕРА]
12191503 RECEPTACLE, TOW VEH ELEC (W/DOOR) [ОПОРА КОНТАКТНОГО РАЗЪЕМА ТРЕЙЛЕРНОЙ СЦЕПКИ]
15228708 LABEL, TRLR HITCH INFO (PART OF 1)
11561075 BOLT-HEX W/CON WA, M14X2X45, 21.18 THD, 32 OD, 10.9, GMW3359, M-PT, ADHES (RR BPR IMP BAR) [БОЛТ М12]
15853598 MOLDING, RR BPR FASCIA (INCLS 27) (CHROME) (USE T/W 15853597) [МОЛДИНГ ЗАДНЕГО БАМПЕРА]
11561857 CLIP, RR BPR FASCIA MLDG (PART OF 26) (BLACK) (14.13 X 11 X 8.6)
25894906 BRACKET, RR BPR IMP BAR (PART OF 1)
11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (RR BPR LWR FASCIA) [ШАЙБА]
25779048 REFLECTOR, R/END FASCIA [НАКЛАДКА ПАНЕЛИ БАМПЕРА]
25779049 REFLECTOR, R/END FASCIA [НАКЛАДКА ПАНЕЛИ БАМПЕРА]
19116085 SENSOR KIT, RR OBJECT (INCLS 11-13) (PRIMED) (W/ШЛАНГИ) (7.831) [ДАТЧИК КОНТРОЛЯ ПАРКОВКИ]
(TC07-906) - 2007-2009 CK107(06) БАМПЕР ЗАДНИЙ (G.M.C. Z88, DENALI Y91)
teamcadillac.ru
(TC07-911) - 2007-2009 K1(06-36) ПРИЦЕПНОЕ УСТРОЙСТВО
15827191 HOOK, FRT TOW [БУКСИРОВОЧНЫЙ КРЮК]
20859291 HOOK, FRT TOW
teamcadillac.ru
11516078 ГАЙКА, HFH, M12X1.75, 14THK, 25 O.D., 10, PZOR (FRT TOW HOOK) [ГАЙКА]
11589274 BOLT HFH, M12X1.75X45.8, 31.4 THD, 26.6 OD, 10.9, GMW3359, (FRT TOW HOOK) [БОЛТ М12]
11589283 БОЛТ, HFH, M12X1.75X125.9, 45 THD, 26.6 OD, 10.9, GMW3359, M-PT, REDUCED BO (FRT TOW HOOK)
(TC07-914) - 2007-2009 CK1(06-36) ПОДВЕСКА-ЗАДНЯЯ ЧАСТЬ 2
11518725 БОЛТ, R/AXL TIE ROD (M14X2.0X95) (HVY HEX FLG HD W/CON SPR WA) (8.900) [БОЛТ М14Х95]
11516382 ГАЙКА, R/AXL TIE ROD (FRAME SIDE ONLY) (M14X2X15) (W/O J CLIP RETAINER) (8.917) [ГАЙКА М10]
15251980 INSULATOR, RR SPR (FRAME SIDE ONLY)
teamcadillac.ru
25783731 ПРУЖИНА, RR
25783732 ПРУЖИНА, RR
15765071 INSULATOR, RR SPR (AXLE SIDE ONLY) [ДЕМПФЕР ПРУЖИНЫ ПОДВЕСКИ]
15039398 ROD, R/AXL TIE (INCLS 6) [ШТАНГА ПОДВЕСКИ]
11609486 ГАЙКА, R/AXL TIE ROD (AXLE SIDE ONLY) (M14X2)
11517766 БОЛТ, R/AXL LWR CONT ARM (M14X2X106) (HEX W/CON WA) (8.900)
11516382 ГАЙКА, R/AXL LWR CONT ARM (M14X2X15) (W/O J CLIP RETAINER) (8.917) [ГАЙКА М10]
11517901 БОЛТ, R/AXL UPR CONT ARM (M14X2X90) (HEX W/CON WA) (8.900)
11516382 ГАЙКА, R/AXL UPR CONT ARM (M14X2X15) (W/O J CLIP RETAINER) (8.917) [ГАЙКА М10]
15239738 ARM, R/AXL LWR CONT (INCLS 14) [РЫЧАГ ПОДВЕСКИ]
15208540 ARM, R/AXL UPR CONT (INCLS 16) [РЫЧАГ В СБОРЕ]
11519144 ГАЙКА, R/AXL UPR CONT ARM (NUT W/J CLIP RETAINER)
15039397 BUMPER, RR SUSP JOUNCE
(TC07-915) - 2008-2009 CK1(06-36) LEVEL CONTROL КОМПРЕССОР/AUTOMATIC (REAL-TIME DAMPING Z55, MAGNERIDE Z95)
25913289 КОМПРЕССОР, AUTO LVL CONT AIR (INCLS 2-14)
teamcadillac.ru
15840487 TEE, RR AIR SUSP LVLG C/VLV SPLY TUBE [ФИТИНГ ШЛАНГА ПНЕВМОПОДВЕСКИ]
(TC07-916) - 2009 CK1(06-36) ЭЛЕКТРОННОЕ УПРАВЛЕНИЕ ПОДВЕСКОЙ (REAL-TIME DAMPING Z55, MAGNERIDE Z95, EXC HYBRID HP2)
25971217 MODULE, ELEK SUSP CONT (INCLS 2, 3) [БЛОК УПРАВЛЕНИЯ ПОЛОЖЕНИЕМ ПОДВЕСКИ]
25971218 MODULE, ELEK SUSP CONT (INCLS 2, 3) (LABELED 25971218)
15128648 SENSOR, ELEK SUSP RR POSN (INCLS 11-13) [ДАТЧИК ПОЛОЖЕНИЯ ПОДВЕСКИ]
15128649 SENSOR, ELEK SUSP RR POSN (INCLS 11-13) [ДАТЧИК ПОЛОЖЕНИЯ ПОДВЕСКИ]
11516885 SCREW, HFH W/FL WA, TAP, M8X1.25X20, 7THD, 17 O.D., TR PT, 6202M, PZOR (ELEK SUSP RR POSN SEN BRKT)
15815642 LINK, ELEK SUSP RR POSN SEN (PART OF 9) [ТЯГА ПОДВЕСКИ]
22189896 BRACKET, ELEK SUSP FRT POSN SEN (PART OF 9) (INCLS 11) (ELEK SUSP RR POSN) [ОПОРНАЯ ПЛАНКА ДАТЧИКА ПОЛОЖЕНИЯ ПОДВЕСКИ]
22189897 BRACKET, ELEK SUSP FRT POSN SEN (PART OF 9) (INCLS 11) (ELEK SUSP RR POSN) [ОПОРНАЯ ПЛАНКА ДАТЧИКА ПОЛОЖЕНИЯ ПОДВЕСКИ]
15098628 SENSOR, ELEK SUSP FRT POSN (INCLS 16, 17) [ДАТЧИК ПОЛОЖЕНИЯ ПОДВЕСКИ]
15098629 SENSOR, ELEK SUSP FRT POSN (INCLS 16, 17) [ДАТЧИК ПОЛОЖЕНИЯ ПОДВЕСКИ]
teamcadillac.ru
15815637 LINK, ELEK SUSP FRT POSN SEN (PART OF 15)
19180262 CONNECTOR, SOL-S/ABS ELEK SUSP CONT ACTR (PART OF 4) (GRAY) (2-WAY MALE) (90DEG COUPLING) (7.450) [СОЕДИНИТЕЛЬ]
(TC07-917) - 2008-2009 CK1(06-36) ЭЛЕКТРОННОЕ УПРАВЛЕНИЕ ПОДВЕСКОЙ (EXC HYBRID HP2, ACTIVE BRAKE CONTROL DELETE JL0)
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (VEH YAW SEN & LATL ACCLRM) [ГАЙКА М6]
teamcadillac.ru
25930324 SENSOR, VEH YAW (W/VEH LATL ACCLRM)
(TC07-919) - 2007-2009 K1(06-36) FRAME
15931160 FRAME, CHASSIS (INCLS 2, 4-20) [РАМА КУЗОВА]
11561577 БОЛТ, FRT DIFF CARR BRKT (PART OF 1) (8.900)
15854868 BRACKET, RAD SI MT (PART OF 1, 21)
teamcadillac.ru
15854869 BRACKET, RAD SI MT (PART OF 1, 21)
11589274 BOLT HFH, M12X1.75X45.8, 31.4 THD, 26.6 OD, 10.9, GMW3359, (PART OF 1) [БОЛТ М12]
11589283 БОЛТ, HFH, M12X1.75X125.9, 45 THD, 26.6 OD, 10.9, GMW3359, M-PT, REDUCED BO (PART OF 1)
15774517 SPACER, FRT BPR IMP BAR BRKT (PART OF 1, 21) (*KIT1) [ВТУЛКА КРОНШТЕЙНА РАМЫ КУЗОВА]
15827191 HOOK, FRT TOW (PART OF 1) [БУКСИРОВОЧНЫЙ КРЮК]
20859291 HOOK, FRT TOW (PART OF 1)
10385576 BRACKET, U/B (PART OF 1, 21)
10385577 BRACKET, U/B (PART OF 1, 21)
11516078 ГАЙКА, HFH, M12X1.75, 14THK, 25 O.D., 10, PZOR (PART OF 1) [ГАЙКА]
15201007 CROSSMEMBER, FRT (PART OF 1, 21)
15201932 BRACKET, FRT DIFF CARR (PART OF 1)
15201933 BRACKET, FRT DIFF CARR (PART OF 1) [СУППОРТ ДИФФЕРЕНЦИАЛА ВЕДУЩЕГО МОСТА]
11514598 ГАЙКА, FRT DIFF CARR BRKT (PART OF 1) (HF 12X1.75) (8.915) [ГАЙКА М12]
19150105 CROSSMEMBER, DRIVETRAIN & FRT SUSP FRM FRT (PART OF 1)
11517236 БОЛТ, DRIVETRAIN & FRT SUSP FRM RR C/MBR (PART OF 1) (8.900)
15894408 CROSSMEMBER, TRANS SUPT (PART OF 1)
11516382 ГАЙКА, HFH LK M14X2X15, 28 OD 10 7111M (PART OF 1) [ГАЙКА М10]
11517236 BOLT ASSEMBLY - METRIC HX HD AND CONICAL ПРУЖИНА WASHER, M12X1.75X135 - 18MM SOCKET (PART OF 1)
15790389 FRAME, FRT HALF (INCLS 3-4, 7, 10, 12) (SERVICE KIT W/SECTIONING INSTRUCTIONS)
15791866 BRACKET KIT, FRT BPR IMP BAR (INCLS 7, 8) (INCLS SPACER, BOLTS, NUT) [КОМПЛЕКТ КРОНШТЕЙНА-СИЛОВОГО ЭЛЕМЕНТА ПЕРЕДН Б-ПЕРА]
(TC07-948) - 2008-2009 CK1(06) БАМПЕР ПЕРЕДНИЙ (CADILLAC Z75, PLATINUM EDITION ULT)
15904442 BRACKET, RAD GRL UPR (INCLS 3, 4) [ПОПЕРЕЧНАЯ ПАНЕЛЬ КУЗОВА]
22581725 CLIP, КАПОТ PRIM LAT REL CBL (PART OF 1) (7.0 MM DIA) (HOLDS (1) PIPE 4.76 TO 6.35) (3.145) [ФИКСАТОР ТОРМОЗНОЙ ТРУБКИ]
teamcadillac.ru
11518531 ГАЙКА, U-TYPE, M4.2X1.41, 15.9X8.4, .7-2.1 PNL, SAE 1050 STL, 7111M, 8.65 SQ HOL (PART OF 9) (10.512) [ГАЙКА М10]
25948814 BRACKET, FRT BPR FASCIA SI [НАПРАВЛЯЮЩАЯ ПЕРЕДНЕГО БАМПЕРА]
25948815 BRACKET, FRT BPR FASCIA SI [ОПОРНАЯ ПЛАНКА ПАНЕЛИ БАМПЕРА]
11589039 БОЛТ, HEX, W/CON WA, M6X1X30, 20 THD, 24 O.D., 9.8, GMW4205 (FRT BPR FASCIA SI BRKT) [БОЛТ М6Х1Х30]
11589398 БОЛТ, HEX HD, W/CON WA, M6X1X30, 18.11 THD, 24 O.D., 9.8, GMW3179, BLACK (FRT BPR LWR FASCIA)
11515638 ГАЙКА, U-TYPE, M4.2X1.41X10.5.5X22, .65-3.8 PNL THK, 1050, ZF (PART OF 15) [ГАЙКА М4.2]
15907625 FILLER, FRT BPR OTR FRT (INCLS 14, 16)
15907626 FILLER, FRT BPR OTR FRT (INCLS 14, 16)
11609385 ГАЙКА, U-TYPE, M6X1, 29.5 LEN, 12.5 WID, 19.5 CEN-END, 1050, GMW3359 (PART OF 15) [ГАЙКА М 6]
15907623 SUPPORT, FRT BPR FASCIA
25975452 FASCIA, FRT BPR (PAINT TO MATCH) [ПАНЕЛЬ БАМПЕРА]
15907627 DEFLECTOR, FRT AIR
25957702 GRILLE, RAD LWR (СМ. ГРУППУ 01.000 "РЕШЕТКА РАДИАТОРА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (SILVER)
22579423 RIVET, FRT LIC PLT BRKT (5 X 25) (10.710) [ЗАКЛЕПКА D=6 ММ]
25782363 BRACKET, FRT LIC PLT (PAINT TO MATCH)
11515637 SCREW, FLT CSK, M4.2X1.41X13, 9.2 OD, 6172M, CC, TAP-BSSD, C/R (FRT OTR A/DFL) (**VPI 1-877-846-8243)
11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (FRT OTR A/DFL) [ВИНТ М4]
22549046 SCREW, M4.2X1.4X25, 11.1 O.D., 6010M, NZ (RAD GRL CTR PNL)
11515638 ГАЙКА, U-TYPE, M4.2X1.41X10.5.5X22, .65-3.8 PNL THK, 1050, ZF (RAD UPR GRL) [ГАЙКА М4.2]
11589039 БОЛТ, HEX, W/CON WA, M6X1X30, 20 THD, 24 O.D., 9.8, GMW4205 (PART OF 30) [БОЛТ М6Х1Х30]
25957701 GRILLE, RAD UPR (INCLS 29, 31) (СМ. ГРУППУ 01.000 "РЕШЕТКА РАДИАТОРА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (SILVER) [РЕШЕТКА РАДИАТОРА]
15126354 EMBLEM, RAD GRL (PART OF 30) (MEDALLION) (BUILT PRIOR TO 01/12/09) (FOR 2ND DES SEE 20824267) [ЭМБЛЕМА РЕШЕТКИ РАДИАТОРА]
20824267 EMBLEM, RAD GRL (PART OF 30) (BUILT 01/12/09 & AFTER) (FOR 1ST DES SEE 15126354)
(TC07-949) - 2008-2009 CK1(06-36) АМОРТИЗАТОР/ПЕРЕДНЯЯ СТОЙКА & ПРУЖИНА (REAL-TIME DAMPING Z55, MAGNERIDE Z95)
15132801 ПРУЖИНА, FRT
15801396 ПРУЖИНА, FRT
15839350 ПРУЖИНА, FRT
15839353 ПРУЖИНА, FRT
15839361 ПРУЖИНА, FRT
teamcadillac.ru
15867410 ПРУЖИНА, FRT
25871192 ПРУЖИНА, FRT
25871197 ПРУЖИНА, FRT
25876851 ПРУЖИНА, FRT
25876862 ПРУЖИНА, FRT
25876864 ПРУЖИНА, FRT
25876866 ПРУЖИНА, FRT
25909346 ПРУЖИНА, FRT
25909347 ПРУЖИНА, FRT
25909348 ПРУЖИНА, FRT
25909349 ПРУЖИНА, FRT
25909350 ПРУЖИНА, FRT
25909351 ПРУЖИНА, FRT
25909352 ПРУЖИНА, FRT [ПРУЖИНА ПОДВЕСКИ]
25909354 ПРУЖИНА, FRT
25909355 ПРУЖИНА, FRT
25909356 ПРУЖИНА, FRT
25909357 ПРУЖИНА, FRT
25940744 ПРУЖИНА, FRT
25940747 ПРУЖИНА, FRT
15815517 ГАЙКА, S/ABS CONT ACTR VLV
11561435 ГАЙКА, FRT SUSP STRUT (M10X1.5X20) (PREV TORQ) (8.917) [ГАЙКА]
15815519 ГАЙКА, FRT SUSP STRUT (M12X1.75X23.5) (FLG HEX HD) [ГАЙКА М12]
15840282 MOUNT, FRT SUSP STRUT
25940743 MOUNT, FRT SUSP STRUT [ОПОРА АМОРТИЗАТОРА]
15803177 SEAT, FRT SPR UPR
15815521 SEAT, FRT SPR UPR [СЕДЛО ОПОРЫ АМОРТИЗАТОРА]
25940742 SEAT, FRT SPR UPR
15886466 REINFORCEMENT, FRT SUSP STRUT MT [ВТУЛКА АМОРТИЗАТОРА]
15815516 BUMPER, FRT SUSP STRUT
15840286 BUMPER, FRT SUSP STRUT (GREEN)
15846888 BUMPER, FRT SUSP STRUT (BLUE)
15886463 BUMPER, FRT SUSP STRUT
25869415 BUMPER, FRT SUSP STRUT
15840291 INSULATOR, FRT SPR UPR (UPPER ISO W/DUST BOOT) [ЗАЩИТНЫЙ КОЖУХ АМОРТИЗАТОРА]
15846889 АМОРТИЗАТОР, FRT SHK (ACDelco #540-238)
15903303 АМОРТИЗАТОР, FRT SHK (ACDelco #540-256) [АМОРТИЗАТОР ПЕРЕДНИЙ, А/М C TRUCK 4 Л]
15903323 АМОРТИЗАТОР, FRT SHK (ACDelco #540-257)
20765171 АМОРТИЗАТОР, FRT SHK
20765177 АМОРТИЗАТОР, FRT SHK
20765178 АМОРТИЗАТОР, FRT SHK
20765184 АМОРТИЗАТОР, FRT SHK
20765186 АМОРТИЗАТОР, FRT SHK
20765188 АМОРТИЗАТОР, FRT SHK
20765189 АМОРТИЗАТОР, FRT SHK
20765190 АМОРТИЗАТОР, FRT SHK
20765195 АМОРТИЗАТОР, FRT SHK
20765196 АМОРТИЗАТОР, FRT SHK
20765199 АМОРТИЗАТОР, FRT SHK
20765204 АМОРТИЗАТОР, FRT SHK
20810264 АМОРТИЗАТОР, FRT SHK (ACDelco #580-369) [АМОРТИЗАТОР ПЕРЕДНИЙ, А/М C TRUCK 4 Л]
20810269 АМОРТИЗАТОР, FRT SHK (ACDelco #580-372)
20810270 АМОРТИЗАТОР, FRT SHK (ACDelco #580-373) [АМОРТИЗАТОР ПЕРЕДНИЙ, А/М C TAHOE 5.3Л]
20813217 АМОРТИЗАТОР, FRT SHK
20833671 АМОРТИЗАТОР, FRT SHK
25852146 АМОРТИЗАТОР, FRT SHK (ACDelco #540-290)
25870890 АМОРТИЗАТОР, FRT SHK (ACDelco #540-459) [АМОРТИЗАТОР ПЕРЕДНИЙ, А/М C TRUCK 4 Л]
25870892 АМОРТИЗАТОР, FRT SHK (ACDelco #540-461) [АМОРТИЗАТОР ПЕРЕДНИЙ, А/М C TRUCK 4 Л]
25870894 АМОРТИЗАТОР, FRT SHK (ACDelco #540-456) [АМОРТИЗАТОР ПЕРЕДНИЙ, А/М C TRUCK 4 Л]
25871207 АМОРТИЗАТОР, FRT SHK (ACDelco #540-470) [АМОРТИЗАТОР ПЕРЕДНИЙ, А/М C TRUCK 4 Л]
25871215 АМОРТИЗАТОР, FRT SHK (ACDelco #540-506) [АМОРТИЗАТОР ПЕРЕДНИЙ, А/М C TRUCK 4 Л]
25871217 АМОРТИЗАТОР, FRT SHK (ACDelco #540-460) [АМОРТИЗАТОР ПЕРЕДНИЙ, А/М C TRUCK 4 Л]
25871236 АМОРТИЗАТОР, FRT SHK (ACDelco #540-424) [АМОРТИЗАТОР ПЕРЕДНИЙ, А/М C TRUCK 4 Л]
25871240 АМОРТИЗАТОР, FRT SHK (ACDelco #540-471) [АМОРТИЗАТОР ПЕРЕДНИЙ, А/М C TRUCK 4 Л]
25876832 АМОРТИЗАТОР, FRT SHK (ACDelco #540-496) [АМОРТИЗАТОР ПЕРЕДНИЙ, А/М C TRUCK 4 Л]
25876834 АМОРТИЗАТОР, FRT SHK (ACDelco #540-508) [АМОРТИЗАТОР ПЕРЕДНИЙ, А/М C TRUCK 4 Л]
25876873 АМОРТИЗАТОР, FRT SHK [АМОРТИЗАТОР ПЕРЕДНИЙ, А/М C TRUCK 4 Л]
25876876 АМОРТИЗАТОР, FRT SHK (ACDelco #540-472)
25888674 АМОРТИЗАТОР, FRT SHK (ACDelco #580-311)
25888676 АМОРТИЗАТОР, FRT SHK (ACDelco #580-313)
25888677 АМОРТИЗАТОР, FRT SHK (ACDelco #580-314) [АМОРТИЗАТОР ПЕРЕДНИЙ, А/М C TRUCK 4 Л]
25888681 АМОРТИЗАТОР, FRT SHK (ACDelco #580-318) [АМОРТИЗАТОР ПЕРЕДНИЙ, А/М C TRUCK 4 Л]
25888682 АМОРТИЗАТОР, FRT SHK (ACDelco #580-319)
25940740 АМОРТИЗАТОР, FRT SHK [АМОРТИЗАТОР ПЕРЕДНИЙ, А/М C TRUCK 4 Л]
25980102 АМОРТИЗАТОР, FRT SHK (ACDelco #540-579)
(TC07-953) - 2009 CK1(06) ЭЛЕКТРОННОЕ УПРАВЛЕНИЕ ПОДВЕСКОЙ (MAGNERIDE Z95, HYBRID HP2)
25867635 SHIELD, ELEK SUSP CONT MDL
25913289 КОМПРЕССОР, AUTO LVL CONT AIR (INCLS 7, 9) (СМ. ГРУППУ 07.000 "LEVEL CONTROL КОМПРЕССОР/AUTOMATIC" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА)
15128648 SENSOR, ELEK SUSP RR POSN (INCLS 10, 11, 13) [ДАТЧИК ПОЛОЖЕНИЯ ПОДВЕСКИ]
15128649 SENSOR, ELEK SUSP RR POSN (INCLS 10, 11, 13) [ДАТЧИК ПОЛОЖЕНИЯ ПОДВЕСКИ]
15815642 LINK, ELEK SUSP RR POSN SEN (PART OF 8) [ТЯГА ПОДВЕСКИ]
teamcadillac.ru
22189896 BRACKET, ELEK SUSP FRT POSN SEN (PART OF 8) (INCLS 10) (ELEK SUSP RR POSN) [ОПОРНАЯ ПЛАНКА ДАТЧИКА ПОЛОЖЕНИЯ ПОДВЕСКИ]
22189897 BRACKET, ELEK SUSP FRT POSN SEN (PART OF 8) (INCLS 10) (ELEK SUSP RR POSN) [ОПОРНАЯ ПЛАНКА ДАТЧИКА ПОЛОЖЕНИЯ ПОДВЕСКИ]
15098628 SENSOR, ELEK SUSP FRT POSN (INCLS 17, 18) [ДАТЧИК ПОЛОЖЕНИЯ ПОДВЕСКИ]
15098629 SENSOR, ELEK SUSP FRT POSN (INCLS 17, 18) [ДАТЧИК ПОЛОЖЕНИЯ ПОДВЕСКИ]
15815637 LINK, ELEK SUSP FRT POSN SEN (PART OF 16)
08 - КУЗОВНЫЕ ДЕТАЛИ ПЕРДНЯЯ ЧАСТЬ - ПОДОГРЕВАТЕЛЬ - ОБСЛУЖИВАНИЕ
(GM08-009) - 2007-2009 CK1,2,3 PAINT/TOUCH-UP
01050015 PAINT, TOUCH-UP TUBE (.5 OZ) (OLYMPIC WHITE) (WA 8624)
01052907 PAINT, TOUCH-UP TUBE (.5 OZ) (BLACK) (WA 8555)
12345116 PAINT, TOUCH-UP TUBE (.5 OZ) (PRIMER, FILLER SCRATCH) (GRAY)
12345118 PAINT, TOUCH-UP TUBE (.5 OZ) (CLEAR TOP COAT)
12345538 PAINT, TOUCH-UP TUBE (.5 OZ) (VICTORY RED) (WA 9260)
12346575 PAINT, TOUCH-UP TUBE (.5 OZ) (DARK MING BLUE MET) (WA 722J)
12346585 PAINT, TOUCH-UP TUBE (.5 OZ) (WHITE DIAMOND PEARL) (WA 800J)
12346701 PAINT, TOUCH-UP TUBE (.5 OZ) (FINE SILVER BIRCH MET) (WA 926L)
12346711 PAINT, TOUCH-UP TUBE (.5 OZ) (STEALTH GRAY MET) (WA 928L)
12346781 PAINT, TOUCH-UP TUBE (.5 OZ) (GRAYSTONE MET) (WA 213M)
12346909 PAINT, TOUCH-UP TUBE (.5 OZ) (GOLD MIST MET) (WA 316N)
12346917 PAINT, TOUCH-UP TUBE (.5 OZ) (RED JEWEL T/COAT) (WA 301N)
88860737 PAINT, TOUCH-UP TUBE (.5 OZ) (IMPERIAL BLUE MET) (WA 403P)
88860753 PAINT, TOUCH-UP TUBE (.5 OZ) (SONOMA JEWEL MET) (WA 412P)
88860795 PAINT, TOUCH-UP TUBE (.5 OZ) (DARK BRAHMA JEWEL MET) (WA 519Q)
88860799 PAINT, TOUCH-UP TUBE (.5 OZ) (INFERNO ORANGE MET) (WA 502Q)
88860803 PAINT, TOUCH-UP TUBE (.5 OZ) (CARBON FLASH MET) (WA 501Q)
12345117 PAINT, TOUCH-UP SPRAY (5 OZ) (PRIMER, FILLER, SCRATCH)
12345119 PAINT, TOUCH-UP SPRAY (5 OZ) (CLEAR TOP COAT)
12345155 PAINT, TOUCH-UP SPRAY (5 OZ) (BLACK) (WA 8555)
12345205 PAINT, TOUCH-UP SPRAY (5 OZ) (OLYMPIC WHITE) (WA 8624)
12345539 PAINT, TOUCH-UP SPRAY (5 OZ) (VICTORY RED) (WA 9260)
12346576 PAINT, TOUCH-UP SPRAY (5 OZ) (DARK MING BLUE MET) (WA 722J)
12346586 PAINT, TOUCH-UP SPRAY (5 OZ) (WHITE DIAMOND PEARL) (WA 800J)
12346702 PAINT, TOUCH-UP SPRAY (5 OZ) (FINE SILVER BIRCH MET) (WA 926L)
12346712 PAINT, TOUCH-UP SPRAY (5 OZ) (STEALTH GRAY MET) (WA 928L)
teamcadillac.ru
12346782 PAINT, TOUCH-UP SPRAY (5 OZ) (GRAYSTONE MET) (WA 213M)
12346910 PAINT, TOUCH-UP SPRAY (5 OZ) (GOLD MIST MET) (WA 316N)
12346918 PAINT, TOUCH-UP SPRAY (5 OZ) (RED JEWEL T/COAT) (WA 301N)
88860738 PAINT, TOUCH-UP SPRAY (5 OZ) (IMPERIAL BLUE MET) (WA 403P)
88860754 PAINT, TOUCH-UP SPRAY (5 OZ) (SONOMA JEWEL MET) (WA 412P)
88860796 PAINT, TOUCH-UP SPRAY (5 OZ) (DARK BRAHMA JEWEL MET) (WA 519Q)
88860800 PAINT, TOUCH-UP SPRAY (5 OZ) (INFERNO ORANGE MET) (WA 502Q)
88860804 PAINT, TOUCH-UP SPRAY (5 OZ) (CARBON FLASH MET) (WA 501Q)
(TC08-061) - 2009 CK1(06-36) ПОРОГ (POWER RETRACTABLE BRS)
15806407 BRACKET, ASST STEP (BRKT USED ON RR END OF ASSIST STEP)
15806409 BRACKET, ASST STEP (BRKT USED ON RR END OF ASSIST STEP)
11609733 БОЛТ, HEX W/CON WA, M8X1.25X30, 20 THD, 24 OD, 10.9, GMW4205, MAT POINT (ASST STEP) [БОЛТ М8]
15806412 PAD, ASST STEP [НАКЛАДКА ПОРОГА КУЗОВА]
15806401 COVER, ASST STEP FIN (INCLS 5) (INCLS INSERT) [БОКОВАЯ ПОДНОЖКА КУЗОВА]
15806402 COVER, ASST STEP FIN (INCLS 5) (INCLS INSERT) [ПОРОГ КУЗОВА]
15224062 STEP, ASST
teamcadillac.ru
15872198 БОЛТ, ASST STEP FIN CVR
15871287 BRACKET, ASST STEP CTR (INCLS 20) [КРОНШТЕЙН ПОРОГА КУЗОВА]
15871288 BRACKET, ASST STEP CTR
15932167 SHIELD, ASST STEP (FRT)
15932168 SHIELD, ASST STEP (FRT)
11570190 БОЛТ, ASST STEP SHLD [БОЛТ М]
11569755 BOLT- HEX W/CON WA, M8X1.25X20, 10 THD, 24 OD, 8.8, GMW4205, M-PT (ASST STEP) [БОЛТ М8]
25971282 MOTOR, ASST STEP (INCLS 12)
25971283 MOTOR, ASST STEP (INCLS 12) [ЭЛ.ДВИГАТЕЛЬ БОКОВОЙ ПОДНОЖКИ КУЗОВА, 60ВТ]
11570190 БОЛТ, ASST STEP BRKT [БОЛТ М]
15932169 SHIELD, ASST STEP (RR)
15932170 SHIELD, ASST STEP (RR)
03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (ASST STEP)
15224078 BRACKET, ASST STEP (BRKT USED ON FRT END OF ASSIST STEP CONTAINING MOTOR)
11513599 ГАЙКА, U-TYPE, M4.2X1.41, 0.65-3.80 PNL THK, PZ (ASST STEP BRKT) (ACDelco #11513599)
25852622 MODULE, ASST STEP CONT [МОДУЛЬ КОНТРОЛЯ ЗАПАСНОЙ СТУПЕНЬКИ]
11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (ASST STEP) [ВИНТ М4]
(TC08-906) - 2008-2009 CK107(06) ДОМКРАТ И ИНСТРУМЕНТ СКЛАДЫВАНИЯ (EXC HYBRID HP2)
15043019 RETAINER, TOOL STOW (INCLS WINGNUT)
25887192 RETAINER, TOOL STOW
15854611 TOOL KIT, (INCLS 3-5)
15854614 РУЧКА, ДОМКРАТА WRENCH (PART OF 2) [РУКОЯТКА ДОМКРАТА]
15295860 EXTENSION, JK HDL (PART OF 2) (406MM) (NON FLEXIBLE SHAFT) [УДЛИНИТЕЛЬ РУЧКИ ДОМКРАТА]
teamcadillac.ru
15101404 HANDLE, JK (PART OF 2) (508.0MM LG) [УДЛИНИТЕЛЬ РУЧКИ ДОМКРАТА]
15547900 BLOCK, WHL
15772593 ГАЙКА, WHL BLK (6MM) [ГАЙКА М6]
10382641 BRACKET, JK STOW (BOTTOM BRKT INCLS STUDS)
15788798 ДОМКРАТ, (INCLS 12) [РЫЧАГ В СБОРЕ]
15110160 LABEL, JK WRNG (PART OF 11)
(TC08-907) - 2009 CK1,2(06) ШЛАНГИ И ТРУБКИ /ОБОГРЕВАТЕЛЬ (LC9/5.3-3,LMG/5.3-0,LY2/4.8C,LY5/5.3J,LY6/6.0K,L76/6.0Y,L9H/6.2-2)
15050765 CLIP, HTR HOSE (PART OF 3) (73.0MM WIDE)
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (ENG WRG HARN RET) [ГАЙКА М6]
teamcadillac.ru
15778415 BRACKET, HTR HOSE CLIP (INCLS 1)
15834773 HOSE, RAD SURGE TK OTLT (INCLS 4, 5)
15012561 CLAMP, HOSE SPR, 27 NOM, 25.2 MIN-28.9 MAX, 15MM WIDE, BLACK (RAD SURGE TK OTLT HOSE) (8.948)
11517136 CLAMP, HOSE SPR, 27 NOM, 25.2 MIN-28.9 MAX, 15MM WIDE, BLACK (RAD SURGE TK OTLT HOSE)
11517133 CLAMP, ПРУЖИНА, 22-26MM, 24 NOM., BLK (PART OF 10) [ХОМУТ ТРУБОПРОВОДА]
15854958 HOSE, HTR INL (INCLS 9, 11)
(TC08-909) - 2008-2009 CK1,2(06-36) ПОРОГ (MOLDED BLACK BVE, EXC HYBRID HP2)
15203597 BRACKET, ASST STEP
11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (ASST STEP) [ГАЙКА]
15291807 EXTENSION, ASST STEP FRT
teamcadillac.ru
15291808 EXTENSION, ASST STEP FRT
11609997 БОЛТ, ASST STEP FRT EXTN [ВИНТ]
11519742 БОЛТ, WASHER, M8X1.25X40, 33.4 THD, 39 OD, 9.8, 7114M, 2.5-3.5 THK FL WA (ASST STEP) [БОЛТ]
(TC08-910) - 2007-2009 CK1(06-36) ПОРОГ (CHROME INSERT BVU)
15914678 STEP, ASST [КОМПЛЕКТ ГАЕК КОЛЕСА (4 ШТ)]
15914679 STEP, ASST [ПАНЕЛЬ ПОРОГА КУЗОВА]
15914684 INSERT, ASST STEP (REAR) [ОКАНТОВКА ПОДНОЖКИ]
teamcadillac.ru
15914685 INSERT, ASST STEP (REAR) [МОЛДИНГ ПОРОГА КУЗОВА]
15914682 INSERT, ASST STEP (FRT) [ВСТАВКА ПОДНОЖКИ КУЗОВА]
15914683 INSERT, ASST STEP (FRT) [ХРОМИРОВАННАЯ ВСТАВКА]
15291811 EXTENSION, ASST STEP FRT [ПАНЕЛЬ ПОРОГА КУЗОВА РАСШИРИТЕЛЬНАЯ]
15291812 EXTENSION, ASST STEP FRT [ПАНЕЛЬ ПОРОГА КУЗОКА РАСШИРИТЕЛЬНАЯ]
25694574 RETAINER, ASST STEP FRT EXTN (PUSH IN) (10.695)
(TC08-912) - 2007-2009 CK1,2(06) ПАСПОРТНЫЕ ТАБЛИЧКИ И ДЕКАЛИ
15107130 LABEL, L/GATE WRNG
25861414 LABEL, FUEL RECOMMENDATION
teamcadillac.ru
12451193 LABEL, CHILD SECURITY LK OPERG INSTR
19206430 LABEL KIT, VEH CAPACITY WT & ШИНА INFO (ENGLISH ONLY LABEL FOR US) (QTY 10 PER KIT)
19206431 LABEL KIT, VEH CAPACITY WT & ШИНА INFO (ENGLISH W/FRENCH-CANADIAN LABEL FOR CANADA) (QTY 10 PER KIT)
19206432 LABEL KIT, VEH CAPACITY WT & ШИНА INFO (SPANISH LABEL FOR MEXICO) (QTY 10 PER KIT)
15772975 LABEL, FRT TORS BAR ADJ WRNG
12567697 LABEL, ALL WHL DRV CAUTION
10309116 LABEL, FAN BLADE WRNG (BLACK NYLON)
19180225 LABEL, VEH EMIS CONT INFO (VIN MUST BE SUPPLIED WITH ORDER)
15061343 LABEL, O/S RR VIEW MIR INFO (FRENCH)
15815407 LABEL, INFL RST SYS WRNG (ENGLISH/ARABIC)
15053409 LABEL, A/C REFRIG & BAT & FAN BLADE & RAD FIL CAP CAUTION
15906948 LABEL, BAT WRNG (LOCATED ON АККУМУЛЯТОР)
25808256 LABEL, BAT WRNG
25954276 LABEL, BAT WRNG (FIRST RESPONDER CAUTION LABEL)
(TC08-914) - 2007-2009 CK1(06-36) ПОРОГ (TUBULAR BLACK BVV)
25831407 COVER, ASST STEP FIN (*KIT1)
25831408 COVER, ASST STEP FIN (*KIT1)
25804636 PAD, ASST STEP (*KIT1)
25804637 PAD, ASST STEP (*KIT1)
25804632 STEP, ASST (EXCLS COVER, BRKT, PAD, & INSULATOR) (*KIT1)
25804633 STEP, ASST (EXCLS COVER, BRKT, PAD, & INSULATOR) (*KIT1)
11519742 БОЛТ, WASHER, M8X1.25X40, 33.4 THD, 39 OD, 9.8, 7114M, 2.5-3.5 THK FL WA (ASST STEP) (*KIT1) [БОЛТ]
25816111 EXTENSION, ASST STEP FRT
25816112 EXTENSION, ASST STEP FRT
15929675 COVER, ASST STEP FIN (FRT) (*KIT1)
15929677 COVER, ASST STEP FIN (FRT) (*KIT1)
11516807 RIVET, POP, 4.8 DIA, 19.9 LONG, 16 OD, 5-5.25 HOLE, 1-9 GRIP RANGE, AL, BLACK (ASST STEP) [ЗАКЛЕПКА 4.8 ММ]
25806735 BRACKET, ASST STEP (*KIT1)
25831411 BRACKET, ASST STEP (*KIT1)
25821809 BRACKET, ASST STEP RR (INCLS 13)
25821810 BRACKET, ASST STEP RR (INCLS 13)
11515638 ГАЙКА, U-TYPE, M4.2X1.41X10.5.5X22, .65-3.8 PNL THK, 1050, ZF (PART OF 12) [ГАЙКА М4.2]
25804640 INSULATOR, ASST STEP RR SUPT (*KIT1)
25804641 INSULATOR, ASST STEP RR SUPT (*KIT1)
25804642 INSULATOR, ASST STEP FRT SUPT (*KIT1)
teamcadillac.ru
25804643 INSULATOR, ASST STEP FRT SUPT (*KIT1)
25831388 STEP, ASST (INCLS 1-4, 6, 9, 14, 15) (INCLS COVER, BRKT, PAD, & INSULATOR)
25831389 STEP, ASST (INCLS 1-4, 6, 9, 14, 15) (INCLS COVER, BRKT, PAD, & INSULATOR)
(TC08-931) - 2008-2009 CK107(06) ПОРОГ (MOLDED BLACK BVE, HYBRID HP2)
teamcadillac.ru
25640265 ГАЙКА, ASST STEP (M8X1.25) (10.463)
25847744 EXTENSION, ASST STEP FRT
25847745 EXTENSION, ASST STEP FRT
11516931 БОЛТ, FLAT WA & METRIC HEX HD MACHINE, M8X1.25X50 (ASST STEP)
(TC08-934) - 2009 CK1(06-36) КАПОТ (CADILLAC Z75)
15945915 HOOD, (INCLS 30) [КАПОТ]
11609797 БОЛТ, AIR INL GRL PNL (10.268)
15048061 RETAINER, AIR INL GRL PNL (PART OF 9) (PUSH IN)
25820729 PANEL, AIR INL GRL (INCLS 6) (BLACK) [НАКЛАДКА ВОДОСТОЧНОЙ ПАНЕЛИ]
25820730 PANEL, AIR INL GRL (INCLS 6) (BLACK) [НАКЛАДКА ВОДОСТОЧНОЙ ПАНЕЛИ]
11609796 CLIP, AIR INL GRL PNL (PART OF 5) (11.0 X 12.9 X 6.1MM) (8.950)
15999788 RETAINER, AIR INL GRL PNL (U-SHAPED/CLIP)
25887976 HOSE, WSWA NOZ (PART OF 9) [ШЛАНГ СТЕКЛООМЫВАТЕЛЯ]
25872303 PANEL, AIR INL GRL (CTR) (INCLS 3, 4, 8) (BLACK)
15894378 CABLE, КАПОТ PRIM LAT REL (INCLS PULL HANDLE) [КАБЕЛЬ]
11516780 ГАЙКА, HEX W/CON WA, M8X1.25, 10THK, 19 O.D., 10, 7111M (HOOD PRIM LAT REL CBL) (8.917) [ГАЙКА М8]
25870070 ПРУЖИНА, КАПОТ OPEN ASST
teamcadillac.ru
25870071 ПРУЖИНА, КАПОТ OPEN ASST
11569992 БОЛТ, КАПОТ OPEN ASST SPR
15054178 БОЛТ, HFH, W/SHOULDER, M8X1.25X23, 18 O.D., 9.8, GM6280M (HOOD OPEN ASST SPR)
15870422 BRACKET, F/FDR UPR [КРОНШТЕЙН КРЫЛА]
15951192 BRACKET, F/FDR UPR [КРОНШТЕЙН]
11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (F/FDR UPR BRKT) (ACDelco #11570082) [БОЛТ М8]
15887400 BRACKET, КАПОТ HGE LWR (PART OF 19)
15887401 BRACKET, КАПОТ HGE LWR (PART OF 19)
25819534 КРЫЛО, FRT (INCLS 18) (СМ. ГРУППУ 08.000 "КРЫЛО & КОЛЕСНАЯ КОРОБКА ПЕРЕДНЯЯ" FOR DETAILED ILLUSTARTED VIEW) [ПЕРЕДНЕЕ КРЫЛО]
25819535 КРЫЛО, FRT (INCLS 18) (СМ. ГРУППУ 08.000 "КРЫЛО & КОЛЕСНАЯ КОРОБКА ПЕРЕДНЯЯ" FOR DETAILED ILLUSTARTED VIEW) [ПЕРЕДНЕЕ КРЫЛО]
25819548 КРЫЛО, FRT (INCLS 18) (СМ. ГРУППУ 08.000 "КРЫЛО & КОЛЕСНАЯ КОРОБКА ПЕРЕДНЯЯ" FOR DETAILED ILLUSTARTED VIEW) [КРЫЛО]
25819549 КРЫЛО, FRT (INCLS 18) (СМ. ГРУППУ 08.000 "КРЫЛО & КОЛЕСНАЯ КОРОБКА ПЕРЕДНЯЯ" FOR DETAILED ILLUSTARTED VIEW)
10150076 CLIP, КАПОТ PRIM LAT REL CBL (18.8 MM DIA) (ROUND CLIP) (3.425)
11589039 БОЛТ, HEX, W/CON WA, M6X1X30, 20 THD, 24 O.D., 9.8, GMW4205 (HOOD PRIM LAT) [БОЛТ М6Х1Х30]
25816903 LATCH, КАПОТ PRIM (W/O SWITCH)
25816904 LATCH, КАПОТ PRIM (W/SWITCH)
25790320 BUMPER, КАПОТ ADJ FRT
15250133 BUMPER, КАПОТ SI
25876305 STRUT, HOOD
20064875 RETAINER, PUSH-IN, 20.5MMLG, 42.76MM 1.68HD DIA, PLASTIC (HOOD INSL) [КЛИПСА ШУМОИЗОЛЯЦИИ КАПОТА]
15828996 INSULATOR, HOOD
15907251 MOLDING, КАПОТ FRT (INCLS 29) [МОЛДИНГ КАПОТА]
25921258 MOLDING, КАПОТ FRT (INCLS 29) (BRIGHT CHROME) [МОЛДИНГ]
11561788 CLIP-U, 13X15X12, 1.5 PNL, 1050, 6280M (PART OF 28) [ФИКСАТОР МОЛДИНГА КАПОТА]
15859618 BRACKET, КАПОТ STRUT (HOOD SI) (PART OF 1)
11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (HOOD HGE) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16]
15942145 HINGE, HOOD [ПЕТЛЯ КАПОТА]
15942146 HINGE, HOOD [ПЕТЛЯ КАПОТА]
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BODY STATIC GND STRP) [ГАЙКА М6]
(TC08-939) - 2009 CK1(06-36) КРЫЛО & КОЛЕСНАЯ КОРОБКА ПЕРЕДНЯЯ (CADILLAC Z75)
25815065 BRACE, F/END SH MET DIAG
11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (F/END SH MET DIAG BR) [БОЛТ М6]
11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (F/FDR RR UPR BR) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16]
15185449 BRACE, F/FDR RR UPR
15185450 BRACE, F/FDR RR UPR
11610010 БОЛТ, HEX W/ CON WA, M8X1.25X40, 32 THD, 28 OD, 9.8, 7114M, MACH, P-PT (F/FDR INR PNL) [ВИНТ]
15887400 BRACKET, КАПОТ HGE LWR (PART OF 9)
15887401 BRACKET, КАПОТ HGE LWR (PART OF 9)
25819534 КРЫЛО, FRT (INCLS 8) [ПЕРЕДНЕЕ КРЫЛО]
25819535 КРЫЛО, FRT (INCLS 8) [ПЕРЕДНЕЕ КРЫЛО]
25819548 КРЫЛО, FRT (INCLS 8) [КРЫЛО]
25819549 КРЫЛО, FRT (INCLS 8)
11516149 ГАЙКА, U, 8X1.25, MULTI THD, .08'-4.0' THK PNL, PZ (F/FDR RR UPR BRKT) [ГАЙКА М8]
15860253 INSERT, F/FDR CTR RR UPR MLDG [ВСТАВКА КРЫЛА]
15860254 INSERT, F/FDR CTR RR UPR MLDG [ВСТАВКА]
11562187 NUT-U, M8X1.25, SAE 1050 STL, GMW3179-A (F/FDR RR CTR BRKT)
25948814 BRACKET, FRT BPR FASCIA SI (INCLS 14) [НАПРАВЛЯЮЩАЯ ПЕРЕДНЕГО БАМПЕРА]
25948815 BRACKET, FRT BPR FASCIA SI (INCLS 14) [ОПОРНАЯ ПЛАНКА ПАНЕЛИ БАМПЕРА]
11518531 ГАЙКА, U-TYPE, M4.2X1.41, 15.9X8.4, .7-2.1 PNL, SAE 1050 STL, 7111M, 8.65 SQ HOL (PART OF 13) (10.512) [ГАЙКА М10]
11517164 SCREW, HEX M8X1.25X20 W/CON WA (F/FDR LWR)
11589292 PUSH PIN, FITS 8.5 DIA HOLE IN 2-4.5 THK PNL, NYLON 6/6 GMP.PA66.015 (FRT W/H LNR (PUSH IN)) [ФИКСАТОР ПАНЕЛИ БАМПЕРА]
11609952 NUT-U, M4.2X1.41, 15.9X8.4, .7-2.1 PNL, SAE 1050 STL, 7111M, 8.65 SQ HOL (FRT W/H LNR)
11562172 БОЛТ, FRT W/H LNR [БОЛТ М8]
teamcadillac.ru
11570637 БОЛТ, FRT W/H LNR (12.182)
11609489 БОЛТ, HEX W/ WASHER, 4.2X1.41X25, 14.5 THD17 OD, GM6010M STL, GMW4205 (FRT BPR FASCIA OTR BRKT) [БОЛТ М4.2]
11569768 RETAINER, PUSH-IN, FIT HOLE 6.35, 20.32 LENGTH, 17.78 OD, 2.79-14.22 THK P (FRT W/H LNR (PUSH IN))
11562024 RETAINER, PUSH IN, 7.5X36.5, FITS 6.35 HOLE IN 2.29-18.34 THK PNL (FRT W/H LNR (PUSH IN)) [ФИКСАТОР ПАНЕЛИ БАМПЕРА]
15926174 LINER, FRT W/H [ПОДКРЫЛОК]
15951232 LINER, FRT W/H [ОБШИВКА]
20787759 LINER, FRT W/H
25821701 LINER, FRT W/H [ОБШИВКА]
25826685 INSULATOR, COWL S/PNL
25877094 INSULATOR, COWL S/PNL
11570321 ГАЙКА, F/FDR LWR
15862261 BRACKET, FRT W/H PNL UPR
15926175 LINER, FRT W/H [ПОДКРЫЛОК]
15951233 LINER, FRT W/H [ОБШИВКА]
11519360 ГАЙКА, U, W/PLASTISOL, M8X1.25, 35.8X25, 21 C/E, 2.5-5 PNL, 1050, 6173M (F/FDR LWR)
15893710 SHIELD, ENG LWR FRT SPH
15893711 SHIELD, ENG LWR FRT SPH
11517560 SCREW, FLAT WA (NRW) AND HX WA HD, M8X1.25X25 (ENG LWR FRT SPH SHLD)
25961847 ORNAMENT, F/FDR
25961848 ORNAMENT, F/FDR
(TC09-700) - 2007-2009 CK1,2(06) ШЛАНГИ И ТРУБКИ /ВСПОМОГАТЕЛЬНЫЙ ОБОГРЕВАТЕЛЬ
15827283 HOSE, AUX A/C EVPR & AUX HTR (INCLS 2, 4, 6, 9-13) (KENT-MORE TUBING REPAIR KIT J41425 REQ'D FOR INSTALLATION) (9.225) (ACDelco #15-33439) [КОМПЛЕКТ ТРУБОК ТОПЛИВНОЙ СИСТЕМЫ(4 ШТ)]
19130058 HOSE, AUX A/C EVPR & AUX HTR (INCLS 2, 4, 6, 9-13) (ACDelco #15-33875)
15102168 CLIP, AUX A/C EVPR HOSE (PART OF 1) (2X2 PLASTIC) (SLOT ON SIDE WITH DIAMETERS OF 19.05, 9.52, AND 2 AT 12.7MM)
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (AUX A/C EVPR & CMPR HOSE CLIP) [ГАЙКА М6]
15102169 CLIP, AUX A/C EVPR HOSE (PART OF 1) (SLOT IN MIDDLE WITH DIAMETERS OF 19.05, 9.52, AND 2 AT 12.7MM)
11514596 ГАЙКА, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (AUX A/C EVPR TUBE) (8.915) (ACDelco #11514596)
02724966 SEAL, A/C CMPR & CNDSR HOSE (25MM OD X 17MM ID, 3/4IN DIA) (PART OF 1) (FOR NON-CANADIAN ORDERS) (ACDelco #15-31101)
15200864 HOSE, A/C ACCUM (СМ. ГРУППУ 09.000 "A/C СИСТЕМА ОХЛАЖДЕНИЯ/FRONT" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #15-33409)
teamcadillac.ru
25896467 TUBE, A/C EVPR (СМ. ГРУППУ 09.000 "A/C СИСТЕМА ОХЛАЖДЕНИЯ/FRONT" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #15-33413) [ШЛАНГ]
15055343 TEE, AUX HTR INL HOSE (PART OF 1) (NATURAL) (111MM LONG) [ФИТИНГ ШЛАНГА СТЕКЛООМЫВАТЕЛЯ]
15055342 TEE, AUX HTR INL HOSE (PART OF 1) (BLACK) (113MM LONG)
52474373 SEAL, A/C EVPR TUBE (PART OF 1) (METAL/RUBBER) (19MM OD X 11MM ID, 1/2 IN DIA) (ACDelco #15-31055) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО СОЕДИНЕНИЯ МАГИСТРАЛЕЙ СИСТ.]
19130031 RETAINER KIT, AUX HTR INL & OTLT HOSE CONN (INCLS 13) (PART OF 1) (INCL RETAINER, SEAL, SPACER, INSTRUCTION)
09 - ВНУТРЕННЕЕ ОБОРУДОВАНИЕ - КОНДИЦИОНЕР - АУДИОСИСТЕМА
(GM09-046) - 2009 CK1,2,3 КОМПРЕССОР КОНДИЦИОНЕРА ASM (LY6/6.0K,L76/6.0Y,L9H/6.2-2)
89024905 КОМПРЕССОР, A/C (INCLS 2-10) (ACDelco #89024905) [КОМПРЕССОР КОНДИЦИОНЕРА 2.3 КВТ]
teamcadillac.ru
11561365 БОЛТ, A/C CMPR PUL (PART OF 1) (*KIT1)
12476085 CLUTCH KIT, A/C (4 SPLINED, DENSO) (INCLS 2-10) (INCL PULLEY) (LOW MOUNT) (ACDelco #15-4709)
(TC09-675) - 2007-2009 CK1,2(06) КОНДИЦИОНЕР И НАГРЕВАТЕЛЬ В СБОРЕ (MANUAL TEMPERATURE CONTROL CJ3)
89018299 CASE, HTR
11609829 БОЛТ, A/C EVPR TUBE CLIP (4.2X2.25X16) (9.786)
89018297 CORE, HTR (INCLS 2 SEALS) (ACDelco #15-62960)
89018365 ACTUATOR, TEMP VLV (ACDelco #15-72971) [АКТУАТОР]
89018304 VALVE, DEFR (PART OF 32) (ACDelco #15-50561)
52474960 LEVER, MODE VLV
89018304 VALVE, DEFR (ACDelco #15-50561)
89018307 VALVE, TEMP [КЛАПАН]
89018302 SHIELD, HTR & A/C EVPR & BLO MDL HT
89018306 VALVE, TEMP
20760603 HARNESS, A/C MDL WRG
15780376 CASE, HTR & A/C EVPR & BLO LWR
15141283 MODULE, BLO MOT CONT (ACDelco #15-80863) [РЕЗИСТОР 15 ВТ]
89018296 EVAPORATOR, A/C (ACDelco #89018296) [ОСУШИТЕЛЬ, КОНДИЦИОНЕР]
89018295 SEAL, A/C EVPR
89018365 ACTUATOR, AIR INL VLV (ACDelco #15-72971) [АКТУАТОР]
89018304 VALVE, DEFR (PART OF 26) (ACDelco #15-50561)
15780375 INLET, AIR (INCLS 25) (INCLS DOOR & SEALS)
89018612 STUD, HTR & A/C EVPR & BLO MDL (M6X1X33MM TORX/COLR)
89018295 SEAL, A/C EVPR (*KIT3)
teamcadillac.ru
15780377 CASE, HTR & A/C EVPR & BLO UPR (INCLS 7)
89018374 ACTUATOR, MODE CONT CAM (INCLS 9, 10) (ACDelco #15-73952) [СТАРТЕР В СБОРЕ]
20760618 MOTOR, BLO (INCLS 19-21) (9.215) (ACDelco #15-81644)
89018784 SEAL KIT, HTR & A/C EVPR & BLO MDL (INCLS 5, 27, 29-31, 33, 34) [УПЛОТНЕНИЕ ОТОПИТЕЛЯ]
(TC09-676) - 2007-2009 CK1,2,3(06-43-53) КОНДИЦИОНЕР И НАГРЕВАТЕЛЬ В СБОРЕ (AUTO TEMPERATURE CONTROL CJ2)
89018299 CASE, HTR
11609829 БОЛТ, A/C EVPR TUBE CLIP (PART OF 3) (4.2X2.25X16) (9.786)
89018297 CORE, HTR (INCLS 2) (INCLS 2 SEALS) (ACDelco #15-62960)
89018365 ACTUATOR, AIR INL VLV (*KIT1) (ACDelco #15-72971) [АКТУАТОР]
20760602 HARNESS, A/C MDL WRG
20760618 MOTOR, BLO (*KIT2) (9.215) (ACDelco #15-81644)
teamcadillac.ru
(TC09-700) - 2007-2009 CK1,2(06) СИСТЕМА ОХЛАЖДЕНИЯ КОНДИЦИОНЕРА/ЗАДНИЙ
15827283 HOSE, AUX A/C EVPR & AUX HTR (INCLS 2, 4, 9-13) (KENT-MORE TUBING REPAIR KIT J41425 REQ'D FOR INSTALLATION) (ACDelco #15-33439) [КОМПЛЕКТ ТРУБОК ТОПЛИВНОЙ СИСТЕМЫ(4 ШТ)]
19130058 HOSE, AUX A/C EVPR & AUX HTR (INCLS 2, 4, 9-13) (8.846) (ACDelco #15-33875)
teamcadillac.ru
02724966 SEAL, A/C CMPR & CNDSR HOSE (PART OF 1) (FOR NON-CANADIAN ORDERS) (ACDelco #15-31101)
52474373 SEAL, A/C EVPR TUBE (19MM OD X 11MM ID) (PART OF 1) (METAL/RUBBER) (19MM OD X 11MM ID, 1/2 IN DIA) (ACDelco #15-31055) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО СОЕДИНЕНИЯ МАГИСТРАЛЕЙ СИСТ.]
(TC09-900) - 2007-2009 CK107(06) AUXILIARY A/C EVAPORATOR & BLOWER & HEATER ASM (C69)
teamcadillac.ru
15920869 CASE, AUX A/C EVPR & BLO (OUTER)
15232221 BUSHING, A/C EVPR CASE
15887322 ACTUATOR, MODE VLV (ACDelco #15-73644)
11562121 БОЛТ, AUX A/C EVPR & BLO CASE
15887322 ACTUATOR, TEMP VLV (ACDelco #15-73644)
15232208 EVAPORATOR, AUX A/C (ACDelco #15-63347) [ИСПАРИТЕЛЬ СИСТЕМЫ ОХЛАЖДЕНИЯ]
15232224 SEAL, AUX A/C EVPR OTLT TUBE (ACDelco #15-33418)
15892073 TUBE, HTR CORE (INLET)
25994366 VALVE, AUX A/C EVPR THERMAL EXPN (ACDelco #15-51146)
11562123 БОЛТ, A/C EVPR TXV
15232211 CASE, AUX A/C EVPR & BLO LWR
15650071 VALVE, AUX A/C EVPR & BLO MDL DRN (ACDelco #15650071)
15235736 SEAL, AUX HTR CASE
15921035 SEAL, AUX HTR CASE (ACDelco #15-33736)
11562120 STUD, HTR & A/C EVPR & BLO MDL (STUD-FLANGE, M6X1X25)
11562122 CLIP, A/C EVPR CASE (11X6.35) (9.215)
15798231 SEAL, HTR INL & OTLT PIPE (O/RING)
15232223 SEAL, AUX A/C EVPR INL TUBE (1/2") (ACDelco #15-33419)
15892072 PLATE, A/C EVPR INL TUBE BRKT BKG
15232215 VALVE, TEMP
15920866 VALVE, TEMP (ACDelco #15-50766)
15798230 CLIP, HTR CORE
15232212 CORE, AUX HTR (ACDelco #15-63346)
15920868 CASE, AUX A/C EVPR & BLO
15141283 MODULE, BLO MOT CONT (INCLS 23) (ACDelco #15-80863) [РЕЗИСТОР 15 ВТ]
25811506 HARNESS, AUX HTR & A/C WRG
15232219 MOTOR, AUX BLO (ACDelco #15-80867)
15920865 MOTOR, AUX BLO (ACDelco #15-81062)
15920871 OUTLET, AUX HTR AIR
15814847 SEAL, AUX A/C EVPR & BLO MDL OTLT DUCT
15920867 VALVE, MODE (ACDelco #15-50767)
15892074 TUBE, HTR CORE (OUTLET)
(TC09-904) - 2008-2009 CK1,2(06) A/C СИСТЕМА ОХЛАЖДЕНИЯ/FRONT (EXC HYBRID HP2)
25967385 CONDENSER, A/C (INCLS 4) (ACDelco #15-63666) [КОНДЕНСАТОР СИСТЕМЫ ОХЛАЖДЕНИЯ]
11589039 БОЛТ, HEX, W/CON WA, M6X1X30, 20 THD, 24 O.D., 9.8, GMW4205 (A/C CNDSR BRKT) [БОЛТ М6Х1Х30]
15044225 INSULATOR, A/C CNDSR (LOWER) (ACDelco #15-63283) [ИЗОЛЯТОР КОНДИНЦ]
52481715 BRACKET, A/C CNDSR UPR (INLET/OUTLET) (PART OF 1) (114.5MM LONG)
52481716 BRACKET, A/C CNDSR UPR (RETURN) (PART OF 1) (114.5MM LONG)
52474373 SEAL, A/C CMPR & CNDSR HOSE (19MM OD X 11MM ID) (PART OF 7) (METAL/RUBBER) (19MM OD X 11MM ID, 1/2 IN DIA) (ACDelco #15-31055) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО СОЕДИНЕНИЯ МАГИСТРАЛЕЙ СИСТ.]
12477570 NUT-HFH, M8X1.25X8, 10.9 (A/C EVPR TUBE)
25896467 TUBE, A/C EVPR (INCLS 5, 8, 16-19, 21, 22) (ACDelco #15-33413) [ШЛАНГ]
15734255 CLIP, A/C EVPR TUBE (PART OF 7)
52474373 SEAL, A/C REFRIG PRESS SEN O RING (19MM OD X 11MM ID) (PART OF 11) (METAL/RUBBER) (19MM OD X 11MM ID, 1/2 IN DIA) (ACDelco #15-31055) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО СОЕДИНЕНИЯ МАГИСТРАЛЕЙ СИСТ.]
teamcadillac.ru
25975794 HOSE, A/C CNDSR (INCLS 10, 27-29) (ACDelco #15-33411) [ШЛАНГ СИСТЕМЫ КОНДИЦИОНИРОВАНИЯ]
11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (A/C CNDSR HOSE) (ACDelco #11570082) [БОЛТ М8]
02724966 SEAL, A/C ACCUM FRT HOSE (PART OF 15) (FOR NON-CANADIAN ORDERS) (ACDelco #15-31101)
11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (A/C ACCUM HOSE) (ACDelco #11570082) [БОЛТ М8]
15200864 HOSE, A/C ACCUM (INCLS 13) (ACDelco #15-33409)
52458183 SEAL, A/C REFRIG SERV VLV (O RING) (9.25MM ID) (PART OF 7) (BLACK) (RUBBER) (ACDelco #15-30572) [УПЛОТНЕНИЕ РЕЗИНОВОЕ]
03041827 CORE, A/C REFRIG SERV VLV (INCLS ПРУЖИНА, W/O O-RING, 13/64-36 THD) (PART OF 7, 18) (ACDelco #15-1119)
25872392 CORE, A/C REFRIG SERV VLV (PART OF 7, 18) (ACDelco #15-63665)
52458184 VALVE, A/C REFRIG SERV (INCLS O-RINGS, CORE, FEMALE FITTING & SEAL, M12X1.5 THD) (PART OF 7) (INCLS 17) (ACDelco #15-5438)
52458768 CAP, A/C REFRIG CHRG VLV (HIGH SIDE CHARGE PORT, ACCUMULATOR & EVAP TUBE) (PART OF 7) (16.6MM I.S. DIA) (WITH SEAL) (ACDelco #15-33289) [КРЫШКА КЛАПАНА СИСТЕМЫ ХЛАЖДЕНИЯ]
12477570 NUT-HFH, M8X1.25X8, 10.9 (A/C CMPR & CNDSR HOSE)
03094214 O-RING, ID .426X.070 THK, MATERIAL-NEOPRENE (PART OF 7) (ACDelco #15-3614)
15784601 ORIFICE, A/C CNDSR (PART OF 7) (ACDelco #15-33410) [ФИТИНГ ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ]
02724966 SEAL, A/C ACCUM FRT TUBE (25MM OD X 17MM ID, 3/4IN DIA) (FOR NON-CANADIAN ORDERS) (9.222) (ACDelco #15-31101)
12477570 NUT-HFH, M8X1.25X8, 10.9 (A/C ACCUM RET)
03041827 CORE, A/C REFRIG SERV VLV (INCLS ПРУЖИНА, W/O O-RING, 13/64-36 THD) (PART OF 35) (ACDelco #15-1119)
52458768 CAP, A/C REFRIG CHRG VLV (HIGH SIDE CHARGE PORT, ACCUMULATOR & EVAP TUBE) (PART OF 35) (16.6MM I.S. DIA) (WITH SEAL) (ACDelco #15-33289) [КРЫШКА КЛАПАНА СИСТЕМЫ ХЛАЖДЕНИЯ]
13502758 SENSOR, A/C REFRIG PRESS (PART OF 11) (ACDelco #15-51257)
13502759 SENSOR, A/C REFRIG PRESS (PART OF 11) (ACDelco #15-51258)
22624069 SENSOR, A/C REFRIG PRESS (PART OF 11) (LOW PRESSURE & POA ACCUMM ASM)
03041827 CORE, A/C REFRIG SERV VLV (INCLS ПРУЖИНА, W/O O-RING, 13/64-36 THD) (PART OF 11) (INCLS 29) (ACDelco #15-1119)
25872392 CORE, A/C REFRIG SERV VLV (PART OF 11) (INCLS 29) (ACDelco #15-63665)
03041827 SEAL, A/C REFRIG PRESS SEN O RING (INCLS ПРУЖИНА, W/O O-RING, 13/64-36 THD) (PART OF 11, 28) (9.177) (ACDelco #15-1119)
52474373 SEAL, A/C REFRIG PRESS SEN O RING (PART OF 11, 28) (METAL/RUBBER) (19MM OD X 11MM ID, 1/2 IN DIA) (ACDelco #15-31055) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО СОЕДИНЕНИЯ МАГИСТРАЛЕЙ СИСТ.]
15144494 SWITCH, A/C CYCLING (ACDelco #15-50618) [ДАТЧИК ДАВЛЕНИЯ ХЛАДАГЕНТА СИСТЕМЫ ОХЛАЖДЕНИЯ]
03093509 O-RING, 7.65MM ID, 1.78 MM THK, NEOPRENE (A/C REFRIG PRESS SEN O RING) (ACDelco #3093509)
11588331 ГАЙКА, HEX HD W/CON WA, M6X1, 5.7THK, 25 O.D., 9, GM6138M (A/C ACCUM BRKT)
11514623 БОЛТ, HEX W/CON WA, M6X1X20 (A/C ACCUM BRKT)
15194317 BRACKET, A/C ACCUM
15827281 ACCUMULATOR, A/C (INCLS 25, 26) (W/SWITCH) (ACDelco #15-10640)
02724966 SEAL, A/C CMPR & CNDSR HOSE (PART OF 36) (FOR NON-CANADIAN ORDERS) (ACDelco #15-31101)
(TC09-906) - 2007-2009 CK107(06) КРЕПЛЕНИЕ КУЗОВА
15924986 RETAINER, BODY BOLT
15018263 SHIM, BODY MT (3MM THICK) [УПОРНАЯ ПЛАСТИНА РАМЫ КУЗОВА]
15018264 SHIM, BODY MT (1.5MM THICK)
15864038 CUSHION, BODY BOLT UPR (LOCATIONS: # 5) (COLOR CODE: WHITE) [ПРОКЛАДКА]
15201791 CUSHION, BODY BOLT LWR FRT (71MM OD)
11562587 БОЛТ, BODY (M14X2X126) [БОЛТ М14]
teamcadillac.ru
15201794 CUSHION, BODY BOLT UPR (LOCATIONS: # 3 & 4) (COLOR CODE: PINK) [ДЕМПФЕР РАМЫ КУЗОВА]
15201005 CUSHION, BODY BOLT UPR (LOCATION: # 2) (COLOR CODE: ORANGE)
15201797 CUSHION, BODY BOLT UPR (LOCATION: # 1) (GREEN) [КАШИОН]
03537772 ГАЙКА, M12X1.75, 10.6THK, 28 O.D., 10, 7111M (BODY MT) (8.917)
15837581 CUSHION, BODY BOLT UPR FRT (VIOLET) (1.270) [ДЕМПФЕР РАДИАТОРА]
11562547 БОЛТ, HFH, M12X1.75X135, 100 THD, 24.7 OD, GMW25 (10.9) STL, GM 7112M, MACH (BODY MT)
11562546 WASHER, FLAT, 14X42.5X3.61 MM, SAE 1050 STL RC 37-43, 7112M (BODY MT)
(TC09-910) - 2007-2009 CK1,2,3 ДАТЧИК ТЕМПЕРАТУРЫ AMBIENT(CJ2)
15936931 SENSOR, AMB AIR TEMP GA (ACDelco #213-4190) [ДАТЧИК]
teamcadillac.ru
(TC09-912) - 2009 CK1,2,3 АНТЕННА/АУДИОСИСТЕМА (U2K,UBS)
25815079 АНТЕННА, DIGITAL RDO & M/TEL & VEH LOC (INCLS 2) (ACDelco #25815079)
19116836 CABLE, M/TEL & VEH LOC ANT (IN ROOF WRG) (PART OF 9) (ACDelco #19116836)
teamcadillac.ru
19117352 CABLE, DIGITAL RDO & M/TEL & VEH LOC ANT (IN ROOF WRG) (PART OF 9) (IN IP HARNESSES ONLY) (ACDelco #19117352)
19208818 CABLE, DIGITAL RDO & M/TEL & VEH LOC ANT (IN ROOF WRG) (PART OF 9) (USED IN ROOF AND DOOR HARNESSES) (ACDelco #19208818)
15201868 BRACKET, DIGITAL RDO RCVR
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (INST CARR SUPT) (9.665) [БОЛТ М4.2Х1.41Х25]
15270316 RECEIVER, DIGITAL RDO (ACDelco #15270316) (LABELED 15270316)
15945676 RECEIVER, DIGITAL RDO (ACDelco #15945676) (LABELED 15945676)
20883237 RECEIVER, DIGITAL RDO (LABELED 20883237)
20883238 RECEIVER, DIGITAL RDO (LABELED 20883238)
(TC09-913) - 2007-2009 CK1,2(06) АНТЕННА
15289725 CABLE, RDO ANT (ACDelco #15289725) (USED W/ANT MDL LABELED 15877496 OR 15877497) (FOR 2ND DES SEE25994421)
25994421 CABLE, RDO ANT (USED W/ANT LABELED 25943786 OR 25943787) (FOR 1ST DES SEE 15289725)
15045800 COVER, RDO ANT OPG
11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (ELEK BRK CONT WRG HARN GND) [БОЛТ М8]
15877496 MODULE, RDO ANT (ACDelco #15877496) (USED ON VEH WITH PART LABELED 15877496) (FOR 2ND DES SEE 25943786)
25943786 MODULE, RDO ANT (USED ON VEH WITH PART LABELED 25943786) (FOR 1ST DES SEE 15877496)
11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (RDO ANT MDL GRD) [БОЛТ М8]
11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (HDLP HSG PNL) [ШАЙБА]
15095253 CABLE, RDO ANT CBL EXTN RDO END (1021 MM) (ACDelco #15095253)
(TC09-915) - 2007-2009 CK107(06) СИСТЕМА РАСПРЕДЕЛЕНИЯ ВОЗДУХА/REAR DUCTS(C69)
teamcadillac.ru
25897954 DUCT, AUX A/C AIR OTLT (INCLS 14) (FOR VEHICLES BUILT ON 5/5/09 & AFTER)
25915225 DUCT, AUX A/C AIR OTLT (INCLS 14) (FOR VEHICLES BUILT ON 5/4/09 & PRIOR)
11518162 NUT-PANEL, M4.2X1.41, 15.9X8.4, .7-1.0 PNL, 1050, 7111M, 8.65 SQ HOLE (AUX A/C AIR OTLT DUCT)
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (FLR RR AIR DISTR) (9.665) [БОЛТ М4.2Х1.41Х25]
11518162 NUT-PANEL, M4.2X1.41, 15.9X8.4, .7-1.0 PNL, 1050, 7111M, 8.65 SQ HOLE (FLR RR AIR DISTR)
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (AUX HTR & A/C EVPR & BLO MDL) (9.665) [БОЛТ М4.2Х1.41Х25]
11518162 NUT-PANEL, M4.2X1.41, 15.9X8.4, .7-1.0 PNL, 1050, 7111M, 8.65 SQ HOLE (AUX HTR & A/C EVPR & BLO MDL)
20733729 WASHER, SEALING, M5, 4 I.D., 25MM O.D., 4MM THK, RUB (RR BPR OTR FIL)
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (AUX HTR & A/C EVPR & BLO MDL) [ГАЙКА М6]
15864151 DISTRIBUTOR, FLR RR AIR (INCLS 11)
15152429 RETAINER, AMB AIR TEMP SEN (PUSH IN) (PART OF 10) (HOLE LINER TYPE)
12160947 SENSOR, DUCT AIR TEMP (37.54MM) (ACDelco #15-5632) (FOR SENSOR W/TWIST LOCK FEATURE, W/RETAINER, 2ND DES 25885451) [ДАТЧИК ТЕМПЕРАТУРА ВОЗДУХА]
25885451 SENSOR, DUCT AIR TEMP (ACDelco #15-51259) (FOR SENSOR W/XMAS TREE FEATURE, NO RETAINER, 1ST DES 12160947)
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (AUX A/C AIR OTLT DUCT) (9.665) [БОЛТ М4.2Х1.41Х25]
15152429 RETAINER, AMB AIR TEMP SEN (PUSH IN) (PART OF 1) (HOLE LINER TYPE)
(TC09-916) - 2007-2009 CK1,2,3 СИСТЕМА РАСПРЕДЕЛЕНИЯ ВОЗДУХА/MODULE MOUNTING
11589183 ГАЙКА, PUSH IN, W/SEAL, 4.2X1.41, 6.35-6.48 SQ HL, 9.5 SQ HD, 0.787-2.765 PNL THK, NYL (AIR INL GRL PNL)
11609539 SCREW, RD CROWNED WA HD, M4.2X1.41X16, STL ISO 2702, GMW4205 (HDLP BZL) [ВИНТ]
teamcadillac.ru
15856112 VALVE, PLNM DRN
15733206 БОЛТ, HTR & BLO MDL (M6X2.70X27)
15083574 ГАЙКА, HTR & A/C EVPR & BLO MDL (M6X1.0X6)
15138625 HOSE, A/C EVPR & BLO MDL DRN
15185462 VALVE, PLNM DRN
(TC09-918) - 2007-2009 CK1,2(06-36) СИСТЕМА РАСПРЕДЕЛЕНИЯ ВОЗДУХА/FRONT DUCTS (MANUAL TEMPERATURE CONTROL CJ3)
11610157 ГАЙКА, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (AIR DISTR DUCT) (10.701) [ГАЙКА М4]
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (RDO FRT SPKR) (9.665) [БОЛТ М4.2Х1.41Х25]
11609370 BOLT-HWH, M4.2X1.41X20, HI - LOW THD, , OD 12, 6010 STL, GMW4205, TAP (FLR AIR OTLT DUCT) (9.667)
15274329 DUCT, FLR RR AIR OTLT
10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (PART OF 12) [ПИСТОН КРЕПЛЕНИЯ ОБЛИЦОВКИ БАМПЕРА (NYLON)]
15256414 DUCT, FLR FRT AIR OTLT (INCLS 11)
15762755 DUCT, FLR AIR OTLT (INCLS 9)
teamcadillac.ru
(TC09-919) - 2007-2009 CK1(06-36) СИСТЕМА РАСПРЕДЕЛЕНИЯ ВОЗДУХА/FRONT DUCTS (CADILLAC Z75, AUTO TEMPERATURE CONTROL CJ2)
15289716 DUCT, SI WDO DEFG OTLT
11610157 ГАЙКА, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (I/P COMPT) (10.701) [ГАЙКА М4]
15289717 DUCT, SI WDO DEFG OTLT
12160947 SENSOR, DUCT AIR TEMP (37.54MM) (PART OF 9, 16) (ACDelco #15-5632) (FOR SENSOR W/TWIST LOCK FEATURE, W/RETAINER, 2ND DES 25885451) [ДАТЧИК ТЕМПЕРАТУРА ВОЗДУХА]
25885451 SENSOR, DUCT AIR TEMP (PART OF 9, 16) (ACDelco #15-51259) (FOR SENSOR W/XMAS TREE FEATURE, NO RETAINER, 1ST DES 12160947)
15152429 RETAINER, AMB AIR TEMP SEN (PUSH IN) (PART OF 9, 16) (HOLE LINER TYPE)
25992392 DUCT, AIR DISTR (INCLS 2, 4, 7, 8)
15762756 DUCT, FLR AIR OTLT
15958694 RETAINER, FLR FRT AIR OTLT DUCT (PUSH IN) (PART OF 15) (BLACK) (7.6DIA X 22.9 MM) (X-MAS TREE) (FOR HOLE 6.30-6.55 DIA) (16.850) [ФИКСАТОР МОЛДИНГА КУЗОВА]
15256414 DUCT, FLR FRT AIR OTLT (INCLS 14)
15762756 DUCT, FLR AIR OTLT (INCLS 7, 8, 12)
(TC09-920) - 2007-2009 CK1(06-36) АУДИОСИСТЕМА/FRONT (CADILLAC Z75)
teamcadillac.ru
15186674 SPEAKER, RDO W/S SI G/MLDG (PART OF 1) (ACDelco #15186674) [ДИНАМИК 20ВТ]
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 1) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
15221850 GRILLE, RDO FRT SPKR (INCLS 9) (EBONY)
15221851 GRILLE, RDO FRT SPKR (INCLS 9) (COCOA)
15248601 GRILLE, RDO FRT SPKR (INCLS 9) (EBONY)
15248602 GRILLE, RDO FRT SPKR (INCLS 9) (COCOA)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 6) [ЗАЖИМ КОНСОЛИ САЛОНА]
11570654 ГАЙКА, RDO FRT S/D SPKR (4.2 X 1.41) (FITS 8.75 SQ HOLE)
(TC09-921) - 2007-2009 CK1,2(06) АУДИОСИСТЕМА/REAR
15186672 SPEAKER, RDO BODY RR COR UPR GARN MLDG (PART OF 8) (ACDelco #15186672) [ДИНАМИК 20 ВТ]
teamcadillac.ru
11509253 SCREW, W/LRG WA HD, M4.2X1.4X10, 11.3 O.D., BHL PT, STL, NO (PART OF 8)
11609651 RETAINER, BODY RR COR G/MLDG (PART OF 8) (M21.8X15.0X20.5) (14.731) [ШАЙБА]
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 8) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
11609539 SCREW, RD CROWNED WA HD, M4.2X1.41X16, STL ISO 2702, GMW4205 (PART OF 8) [ВИНТ]
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (RDO RR S/D SPKR) (9.665) [БОЛТ М4.2Х1.41Х25]
11570654 ГАЙКА, RDO RR S/D SPKR (4.2 X 1.41) (FITS 8.75 SQ HOLE)
15186669 SPEAKER, RDO RR S/D (ACDelco #15186669) [ДИНАМИК ДВЕРИ, 40ВТ]
15201406 SPEAKER, RDO RR S/D (ACDelco #15201406) [ДИНАМИК 40 ВТ]
(TC09-923) - 2007-2009 CK1(06-36) КРЕПЛЕНИЕ РАДИО (CADILLAC Z75)
15859569 АНТЕННА, ELEK NAVIGATION (ACDelco #15859569)
25865834 CABLE, TV, NAV, AMP, VEH LOC & TRAF INFO INTERFACE (I/P) (ACDelco #25865834)
19117122 CABLE, DIGITAL RDO АНТЕННА (9.675) (ACDelco #19117122)
11610157 ГАЙКА, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (I/P) (10.701) [ГАЙКА М4]
teamcadillac.ru
20801343 RADIO, AM/FM STEREO & NAVN (INCLS 8, 9) (LABELED 20801343 OR 20773518) (ACDelco #20801343)
20801344 RADIO, AM/FM STEREO & NAVN (INCLS 8, 9) (LABELED 20801344, 20773517) (ACDelco #20801344)
20807246 RADIO, AM/FM STEREO & NAVN (INCLS 8, 9) (LABELED 20807246)
20807247 RADIO, AM/FM STEREO & NAVN (INCLS 8, 9) (LABELED 20807247)
20815326 RADIO, AM/FM STEREO & NAVN (INCLS 8, 9) (ACDelco #20815326) (LABELED 20815326) [РАДИОПРИЕМНИК С CD-ПРОИГРЫВАТЕЛЕМ С НАВИГАЦИЕЙ]
20815327 RADIO, AM/FM STEREO & NAVN (INCLS 8, 9)
20815328 RADIO, AM/FM STEREO & NAVN (INCLS 8, 9)
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (RDO) (9.665) [БОЛТ М4.2Х1.41Х25]
15876615 PLATE, I/P ACSRY CTR TR (PLATINUM)
25878603 PLATE, I/P ACSRY CTR TR (CHOCOLATE BURL) (W/DEFLECTORS) [НАКЛАДКА ПАНЕЛИ]
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 11) [ЗАЖИМ КОНСОЛИ САЛОНА]
25999294 RADIO, AM/FM STEREO & CLK & AUDIO/VIDEO DISC PLYR (INCLS 8, 9) (LABELED 25999294) (ACDelco #25999294) [РАДИОПРИЕМНИК С CD-ПРОИГРЫВАТЕЛЕМ]
(TC09-924) - 2007-2009 CK1,2,3 ENTERTAINMENT SYSTEM (U42, EXC DNU)
15256562 BRACKET, VIDEO DISPLAY (INCLS 4)
11518121 ГАЙКА, U, M6X1, MULTI THD, .5'-4.0' THK PNL (VIDEO DISPLAY BRKT)
11570136 БОЛТ, HEX HD, W/CON SPR WA, M6X1X23, 14 THD, 17 O.D., 8.8, GMW3359 (VIDEO DISPLAY BRKT)
teamcadillac.ru
15958694 RETAINER, RF RR CNSL BRKT (PUSH IN) (PART OF 1) (BLACK) (7.6DIA X 22.9 MM) (X-MAS TREE) (FOR HOLE 6.30-6.55 DIA) (16.850) [ФИКСАТОР МОЛДИНГА КУЗОВА]
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 6) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
15287715 RETAINER, RF RR CNSL (INCLS 5) (DVD BCKPLT - 2ND ROW) (10.225)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 8) [ЗАЖИМ КОНСОЛИ САЛОНА]
25835387 MODULE, AUDIO SYS XCVR (ACDelco #25835387) (LABELLED W/OEM PN 25835387.)
15948136 DISPLAY, VIDEO (GRAY) (LABELED 15948136) (ACDelco #15948136) [ДИСПЛЕЙ]
20792277 DISPLAY, VIDEO (GRAY) (LABELED 20792277)
25888804 DISPLAY, VIDEO (CASHMERE) (ACDelco #25888804)
25888807 DISPLAY, VIDEO (COCOA) (ACDelco #25888807)
15190411 CONTROL, VIDEO PLYR REM (ACDelco #15190411) [ИНФРАКРАСНЫЙ ПУЛЬТ УПРАВЛЕНИЯ ДЛЯ ВИДЕО]
20830571 HEADPHONE, (INCLS 16)
(TC09-929) - 2007-2009 CK1,2,3 ОГНЕТУШИТЕЛЬ BRACKET (MTF)
11609615 RIVET - DOME HD TYPE MS, 3/16X0.308 STYLE 1 MS, SAE 1006 LOW CARBON STL, ZC PER GMW3044 (ОГНЕТУШИТЕЛЬ BRKT) (*KIT1)
teamcadillac.ru
15880833 EXTINGUISHER PKG, FIRE (INCLS 1, 2)
(TC09-939) - 2008-2009 CK1(06-36) VEHICLE INFORMATION SYSTEM (CADILLAC Z75, UL2,U3R,VFJ)
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (DIGITAL RDO RCVR BRKT) (9.665) [БОЛТ М4.2Х1.41Х25]
25890523 RECEIVER, TRAFFIC INFO
(TC09-946) - 2008-2009 CK107(06) A/C СИСТЕМА ОХЛАЖДЕНИЯ/FRONT (HYBRID HP2)
25872382 ACCUMULATOR, A/C (INCLS 3, 6, 7, 12, 36, 38-40) (ACDelco #15-10730)
11514596 ГАЙКА, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (A/C ACCUM RET) (8.915) (ACDelco #11514596)
11561065 STUD, A/C ACCUM (PART OF 1) (STRAIGHT M8X1.25X13.5, M8X1.25X27) (9.190)
02724966 SEAL, A/C ACCUM FRT HOSE (25MM OD X 17MM ID, 3/4IN DIA) (PART OF 11) (FOR NON-CANADIAN ORDERS) (ACDelco #15-31101)
11514596 ГАЙКА, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (A/C ACCUM FRT HOSE) (8.915) (ACDelco #11514596)
25872390 SEAL, AUX A/C EVPR OTLT TUBE (O RING) (PART OF 1) (W/1 SEAL)
22624069 SENSOR, A/C REFRIG PRESS (PART OF 1) (LOW PRESSURE & POA ACCUMM ASM)
25872377 HOSE, A/C ACCUM (INCLS 4)
25956569 INSULATOR, A/C ACCUM (PART OF 1)
52476687 INSULATOR, A/C CNDSR (PART OF 16-18) (UPPER) (6.602)
11514596 ГАЙКА, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (A/C CNDSR HOSE) (8.915) (ACDelco #11514596)
teamcadillac.ru
25872392 CORE, A/C REFRIG SERV VLV (PART OF 24, 25) (ACDelco #15-63665)
13502758 SENSOR, A/C REFRIG PRESS (INCLS 22) (PART OF 25) (ACDelco #15-51257)
13502759 SENSOR, A/C REFRIG PRESS (INCLS 22) (PART OF 25) (ACDelco #15-51258)
15734255 CLIP, A/C EVPR TUBE (PART OF 29)
25872375 TUBE, A/C EVPR (INCLS 26, 28, 30-35)
52494593 SCREEN, A/C EVPR TXV (PART OF 29) (ACDelco #15-75210)
25872394 VALVE, A/C REFRIG SERV (PART OF 29) (ACDelco #15-50806)
25872391 CAP, A/C REFRIG CHRG VLV (PART OF 29) (ACDelco #15-33871)
15784601 ORIFICE, A/C CNDSR (PART OF 29) (ACDelco #15-33410) [ФИТИНГ ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ]
25872393 SEAL, A/C EVPR TUBE (PART OF 29) (ACDelco #15-33873)
03041827 VALVE, A/C REFRIG PRESS SEN (INCLS ПРУЖИНА, W/O O-RING, 13/64-36 THD) (PART OF 29) (9.177) (ACDelco #15-1119)
11514623 БОЛТ, HEX W/CON WA, M6X1X20 (PART OF 1, 38)
15136597 BRACKET, A/C ACCUM (PART OF 1) (INCLS 36)
15074675 INSULATOR, A/C ACCUM (PART OF 1) (ACDelco #15-10621)
02724966 SEAL, A/C ACCUM FRT TUBE (25MM OD X 17MM ID, 3/4IN DIA) (PART OF 1) (FOR NON-CANADIAN ORDERS) (9.222) (ACDelco #15-31101)
(TC09-950) - 2008-2009 CK1(06) ENTERTAINMENT SYSTEM (CADILLAC Z75, PLATINUM EDITION ULT, HEADREST PLAYER AYE)
25865996 PLAYER, VIDEO DISC (PLAYER ASM-VIDEO DISC)
25865997 PLAYER, VIDEO DISC (PLAYER ASM-VIDEO DISC)
teamcadillac.ru
25865998 PLAYER, VIDEO DISC (PLAYER ASM-VIDEO DISC)
25865999 PLAYER, VIDEO DISC (PLAYER ASM-VIDEO DISC)
25866000 PLAYER, VIDEO DISC (PLAYER ASM-VIDEO DISC)
25866001 PLAYER, VIDEO DISC (PLAYER ASM-VIDEO DISC)
25865992 MODULE, AUDIO/VIDEO INTERFACE (ACDelco #25865992)
25865993 HARNESS, CD/PLYR WRG (ACDelco #25865993)
25865991 HEADPHONE, [НАУШНИКИ ДЛЯ АУДИО/ВИДЕОСИСТЕМЫ САЛОНА А/М, БЕСПРОВОДНЫЕ ИНФРАКРАСНЫЕ]
25865990 CONTROL, VIDEO DISC PLYR REM (ACDelco #25865990)
(TC09-951) - 2009 CK1,2(06-36) СИСТЕМА КОМУНИКАЦИИ ("ONSTAR" UE1)
15241529 MICROPHONE, MOBILE TEL (PART OF 2) (2-WAY CAVITY)
15837587 АНТЕННА, M/TEL & VEH LOC (INCLS 4) (ACDelco #15837587)
25814089 АНТЕННА, DIGITAL RDO & M/TEL & VEH LOC (INCLS 4) (9.645) (ACDelco #25814089) (SERV CMP OF RECEIVER PKG 19245113)
25815079 АНТЕННА, DIGITAL RDO & M/TEL & VEH LOC (INCLS 4) (ACDelco #25815079)
teamcadillac.ru
15779345 COVER, I/S RR VIEW MIR WRG HARN (BETWEEN I/S MIRROR & HDLR)
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (COMN INTERFACE MDL BRKT) (9.665) [БОЛТ М4.2Х1.41Х25]
11610157 ГАЙКА, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (COMMUNICATION INTERFACE MDL BRKT) (10.701) [ГАЙКА М4]
25791895 BRACKET, COMMUNICATION INTERFACE MDL
20783877 MODULE, COMN INTERFACE (W/MOBILE TEL XCVR) (ACDelco #20783877)
20783878 MODULE, COMN INTERFACE (W/MOBILE TEL XCVR) (LABELED 20783878) (ACDelco #20783878)
25984445 MODULE, COMN INTERFACE (W/MOBILE TEL XCVR) (LABELED 25984445) (ACDelco #25984445)
15938939 АНТЕННА, WIRELESS COMN INTERFACE (BLUETOOTH)
19116836 CABLE, M/TEL & VEH LOC ANT (PART OF 11) (ACDelco #19116836)
19117352 CABLE, DIGITAL RDO & M/TEL & VEH LOC ANT (PART OF 14) (IN IP HARNESSES ONLY) (ACDelco #19117352)
(TX09-016) - 2009 CK1 КОМПРЕССОР КОНДИЦИОНЕРА MOUNTING (LC9/5.3-3,LH6/5.3M,LMG/5.3-0,LY2/4.8C,LY5/5.3J,L76/6.0Y,L9H/6.2-2)
teamcadillac.ru
12554026 BRACKET, A/C CMPR
11515767 БОЛТ, HFH, M10X1.5X35, 32THD, 22.3 O.D., MACH, 10.9, 7114M (A/C CMPR BRKT) (T/W 12345493) [БОЛТ]
89024905 КОМПРЕССОР, A/C (ACDelco #89024905) [КОМПРЕССОР КОНДИЦИОНЕРА 2.3 КВТ]
11516109 БОЛТ, HFH, REDUCED BODY, M10X1.5X65, 25 THD, 22.3 O.D., HDR PT, 10.9, 7114M (A/C CMPR) [БОЛТ, М10Х1.5Х65.22]
11516503 BOLT-HFH, M10X1.5X45, 33 THD, P-PT, 9.8, 7114M (A/C CMPR)
16 - КУЗОВ-СТЕКЛООЧИСТИТЕЛИ-ЗЕРКАЛА-ДВЕРИ-ОТДЕЛКА САЛОНА-РЕМНИ БЕЗОПАСНОСТИ
(MW10-005) - 2007-2009 CK1,2,3 ЦИЛИНДР ЗАМКА/DOOR
15904634 CYLINDER KIT, FRT S/D LK (UNCODED) (INCLS 2-4, 6-12) [ЦИЛИНДР]
teamcadillac.ru
(TC16-065) - 2007-2009 CK1,2(06-36) РЕМНИ БЕЗОПАСНОСТИ-ПЕРЕДНИЕ
15257724 COVER, P/SEAT SHLDR BELT GDE TR (GRAY) [КОЖУХ КРОНШТЕЙНА РЕМНЯ БЕЗОПАСНОСТИ]
15257726 COVER, D/SEAT SHLDR BELT GDE TR (CASHMERE)
25901985 GUIDE, D/SEAT SHLDR BELT (INCLS 4) (GRAY) [КРОНШТЕЙН РЕГУЛИРОВКИ ВЫСОТЫ РЕМНЯ БЕЗОПАСНОСТИ]
19207563 BELT KIT, D/SEAT (RETR SI) (W/ PRE-TENSR) (INCLS 2, 6, 7, 14) (CASHMERE)
19207564 BELT KIT, D/SEAT (RETR SI) (W/ PRE-TENSR) (INCLS 2, 6, 7, 14) (TITANIUM)
19207568 BELT KIT, D/SEAT (RETR SI) (W/ PRE-TENSR) (INCLS 2, 6, 7, 14) (EBONY) [РЕМЕНЬ БЕЗОПАСНОСТИ В СБОРЕ]
19207569 BELT KIT, D/SEAT (RETR SI) (W/ PRE-TENSR) (INCLS 2, 6, 7, 14) (CASHMERE)
19207570 BELT KIT, D/SEAT (RETR SI) (W/ PRE-TENSR) (INCLS 2, 6, 7, 14) (TITANIUM)
19207573 BELT KIT, D/SEAT (RETR SI) (W/ PRE-TENSR) (INCLS 2, 6, 7, 14) (EBONY)
19207574 BELT KIT, D/SEAT (RETR SI) (W/ PRE-TENSR) (INCLS 2, 6, 7, 14) (COCOA)
19207576 BELT KIT, P/SEAT (RETR SI) (W/ PRE-TENSR) (INCLS 2, 6, 7, 14) (CASHMERE)
teamcadillac.ru
19207577 BELT KIT, P/SEAT (RETR SI) (W/ PRE-TENSR) (INCLS 2, 6, 7, 14) (TITANIUM)
19207582 BELT KIT, P/SEAT (RETR SI) (W/ PRE-TENSR) (INCLS 2, 6, 7, 14) (EBONY) [РЕМЕНЬ БЕЗОПАСНОСТИ В СБОРЕ]
19207583 BELT KIT, P/SEAT (RETR SI) (W/ PRE-TENSR) (INCLS 2, 6, 7, 14) (CASHMERE)
19207584 BELT KIT, P/SEAT (RETR SI) (W/ PRE-TENSR) (INCLS 2, 6, 7, 14) (TITANIUM)
19207587 BELT KIT, P/SEAT (RETR SI) (W/ PRE-TENSR) (INCLS 2, 6, 7, 14) (EBONY)
19207588 BELT KIT, P/SEAT (RETR SI) (W/ PRE-TENSR) (INCLS 2, 6, 7, 14) (COCOA)
25847302 BELT, D/SEAT (RETR SI) (INCLS 2, 6, 7, 14) (COCOA)
25847303 BELT, P/SEAT (RETR SI) (INCLS 2, 6, 7, 14) (COCOA)
25941490 BELT, D/SEAT (RETR SI) (INCLS 2, 6, 7, 14) (EBONY)
25941491 BELT, D/SEAT (RETR SI) (INCLS 2, 6, 7, 14) (CASHMERE)
25941494 BELT, P/SEAT (RETR SI) (INCLS 2, 6, 7, 14) (EBONY) [РЕМЕНЬ БЕЗОПАСНОСТИ]
11518121 ГАЙКА, D/SEAT BELT (RETR SI) (M6 X 1 X 12.5) (U-SHAPE) (8.921)
15035434 ГАЙКА, D/SEAT BELT (RETR SI) (M10X1.5X10.8) (FLANGE NUT) (16.679) [ВИНТ]
19121537 BELT KIT, D/SEAT (BKL SI) (EBONY) [ЗАЩЕЛКА РЕМНЯ БЕЗОПАСНОСТИ]
19121538 BELT KIT, D/SEAT (BKL SI) (CASHMERE)
19121539 BELT KIT, D/SEAT (BKL SI) (TITANIUM)
19121542 BELT KIT, P/SEAT (BKL SI) (CASHMERE) (W/РОЛИК НАТЯЖИТЕЛЬ)
19121543 BELT KIT, P/SEAT (BKL SI) (TITANIUM) (W/РОЛИК НАТЯЖИТЕЛЬ)
19180587 BELT KIT, D/SEAT (BKL SI) (COCOA)
19180588 BELT KIT, P/SEAT (BKL SI) (COCOA)
12473319 БОЛТ, F/SEAT CTR BELT (M12X1.75X37) (HEX) (OUTER) (16.682)
19121443 STOP KIT, BELT LAT (RETR SI) (PART OF 8) (TITANIUM) (14.875)
19121445 STOP KIT, BELT LAT (RETR SI) (PART OF 8) (CASHMERE) (14.875)
19121446 STOP KIT, BELT LAT (RETR SI) (PART OF 8) (EBONY) (14.875)
19207765 STOP KIT, BELT LAT (RETR SI) (PART OF 8) (COCOA) (14.875)
(TC16-173) - 2009 CK1,2(06-36) ПАССАЖИРСКОЕ СИДЕНЬЕ/BUCKET (AN3, EXC HEATED/VENTED HNE,KB6)
20762422 SEAT, PASS (CASHMERE)
25978443 SEAT, PASS (EBONY)
25978444 SEAT, PASS (CASHMERE)
teamcadillac.ru
25978496 SEAT, PASS (COCOA)
25978519 SEAT, PASS (EBONY)
25978520 SEAT, PASS (CASHMERE)
15865482 RESTRAINT, P/SEAT HD (INCLS 3) (CASHMERE)
15865483 RESTRAINT, P/SEAT HD (INCLS 3) (TITANIUM)
15865828 COVER, P/SEAT BK CUSH (EBONY)
15865829 COVER, P/SEAT BK CUSH (CASHMERE)
15865830 COVER, P/SEAT BK CUSH (TITANIUM)
15923998 COVER, P/SEAT BK CUSH (EBONY)
25907742 COVER, P/SEAT BK CUSH (CASHMERE)
15279351 GUIDE, F/SEAT BK H/RST ADJ ROD (EBONY) (W/O BUTTON)
15279352 GUIDE, F/SEAT BK H/RST ADJ ROD (CASHMERE) (W/O BUTTON)
15279353 GUIDE, F/SEAT BK H/RST ADJ ROD (TITANIUM) (W/O BUTTON)
15279347 GUIDE, F/SEAT BK H/RST ADJ ROD (EBONY) (W/BUTTON)
15279348 GUIDE, F/SEAT BK H/RST ADJ ROD (CASHMERE) (W/BUTTON)
15279349 GUIDE, F/SEAT BK H/RST ADJ ROD (TITANIUM) (W/BUTTON)
15243902 PAD, P/SEAT BK CUSH
25911156 HEATER, P/SEAT BK CUSH (HEAT ONLY)
15865833 COVER, P/SEAT CUSH (CASHMERE)
15865834 COVER, P/SEAT CUSH (TITANIUM) (VINYL INBOARD SIDE FACING)
15924000 COVER, P/SEAT CUSH (EBONY) (VINYL INBOARD SIDE FACING)
20779855 COVER, P/SEAT CUSH (EBONY) (CARPET INBOARD SIDE FACING)
20779856 COVER, P/SEAT CUSH (CASHMERE) (CARPET INBOARD SIDE FACING)
20779857 COVER, P/SEAT CUSH (TITANIUM) (CARPET INBOARD SIDE FACING)
20779859 COVER, P/SEAT CUSH (EBONY) (CARPET INBOARD SIDE FACING)
15232559 HEATER, P/SEAT CUSH [ПОДОГРЕВ СИДЕНИЯ 45 ВТ]
20818407 MODULE KIT, INFL RST FRT PASS PRESENCE (W/ SEN) (INCLS 11)
15855909 PROTECTOR, P/SEAT RECL FIN CVR (EBONY)
15855911 PROTECTOR, P/SEAT RECL FIN CVR (EBONY)
11515764 БОЛТ, HFH, M10X1.5X20, 18THD, 22.3 O.D., 10.9, 7114M (P/SEAT RECL)
15827137 BRACKET, P/SEAT RECL (I/B)
15243828 COVER, P/SEAT INR RECL FIN (INCLS 17) (EBONY) (INBOARD)
15243829 COVER, P/SEAT INR RECL FIN (INCLS 17) (CASHMERE) (INBOARD)
15243830 COVER, P/SEAT INR RECL FIN (INCLS 17) (TITANIUM) (INBOARD)
15827059 FRAME, P/SEAT CUSH
11517996 ГАЙКА, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (P/SEAT BELT (BKL SI)) (ACDelco #11517996) [ГАЙКА М10]
15845155 BRACKET, P/SEAT BELT (BKL SI) (I/B)
25815788 CAP, F/SEAT ADJR TRK END (BLACK)
25966553 ADJUSTER, P/SEAT (POWER)
25865122 HARNESS, P/SEAT WRG
11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (P/SEAT CUSH OTR FIN PNL)
15243858 COVER, P/SEAT INR ADJR TRK FRT FIN (EBONY)
15243859 COVER, P/SEAT INR ADJR TRK FRT FIN (CASHMERE)
15243860 COVER, P/SEAT INR ADJR TRK FRT FIN (TITANIUM)
15827135 BRACKET, P/SEAT FRT (MAIN BODY HARNESS CONNECTION)
15845154 BRACKET, P/SEAT BELT (RETR SI) (O/B)
11609539 SCREW, RD CROWNED WA HD, M4.2X1.41X16, STL ISO 2702, GMW4205 (P/SEAT ADJR FIN CVR) [ВИНТ]
10325879 KNOB, P/SEAT ADJR SW (EBONY) (11.558)
15222980 KNOB, P/SEAT ADJR SW (CASHMERE) (11.558)
15222981 KNOB, P/SEAT ADJR SW (TITANIUM) (11.558)
15889097 KNOB, P/SEAT ADJR SW (COCOA) (11.558)
15889098 KNOB, F/SEAT RECL (COCOA) (11.377)
15232567 COVER, P/SEAT ADJR FIN (INCLS 17) (EBONY) (POWER)
15232568 COVER, P/SEAT ADJR FIN (INCLS 17) (CASHMERE) (POWER)
15232569 COVER, P/SEAT ADJR FIN (INCLS 17) (TITANIUM) (POWER)
25802504 SWITCH, P/SEAT LUMBAR CONT (CASHMERE) (4-WAY POWER LUMBAR) (FOR 2ND DES SEE 25926717)
25909573 SWITCH, P/SEAT LUMBAR CONT
25926717 SWITCH, P/SEAT LUMBAR CONT (CASHMERE) (11.378) (2-WAY POWER LUMBAR) (FOR 1ST DES SEE 25802504)
25926718 SWITCH, P/SEAT LUMBAR CONT (TITANIUM) (11.378) (2-WAY POWER LUMBAR) (FOR 1ST DES SEE 25802505)
25926719 SWITCH, P/SEAT LUMBAR CONT (EBONY) (2-WAY POWER LUMBAR) (FOR 1ST DES SEE 25802502)
12451498 SWITCH, P/SEAT ADJR & RECL (8-WAY) (P SEAT ADJ SWITCH LABELED 12451498) (11.558) [ВЫКЛЮЧАТЕЛЬ ПОЛОЖЕНИЯ СИДЕНЬЯ]
11513599 ГАЙКА, U-TYPE, M4.2X1.41, 0.65-3.80 PNL THK, PZ (F/SEAT) (ACDelco #11513599)
15827129 COVER, F/SEAT RSR FIN (INCLS 44) (EBONY) (RIGHT & LEFT TOE KICK)
15827130 COVER, F/SEAT RSR FIN (INCLS 44) (CASHMERE) (RIGHT & LEFT TOE KICK)
15827131 COVER, F/SEAT RSR FIN (INCLS 44) (TITANIUM) (RIGHT & LEFT TOE KICK)
15232706 PANEL, P/SEAT BK CUSH FIN (EBONY)
15232707 PANEL, P/SEAT BK CUSH FIN (CASHMERE) (INCLS MAP POCKET)
15933726 PANEL, P/SEAT BK CUSH FIN (INCLS MAP POCKET) (EBONY) (WHEN REPL TRIM WRAP PANELS, REPLACE BOTH DRVR & PASS PANELS)
15933727 PANEL, P/SEAT BK CUSH FIN (CASHMERE) (WHEN REPL.TRIM WRAP PANELS; REPLACE BOTH DR & PASS PANELS)
15933728 PANEL, P/SEAT BK CUSH FIN (TITANIUM) (WHEN REPL.TRIM WRAP PANELS; REPLACE BOTH DR & PASS PANELS)
15827133 RING, F/SEAT BK CUSH CVR HOG
(TC16-174) - 2009 CK1(06-36) ПАССАЖИРСКОЕ СИДЕНЬЕ/BUCKET (AN3, HEATED/VENTED HNE,KB6)
teamcadillac.ru
20762424 SEAT, PASS (EBONY)
25978446 SEAT, PASS (EBONY)
15865481 RESTRAINT, P/SEAT HD (INCLS 3) (EBONY)
15827097 COVER, P/SEAT BK CUSH (EBONY)
25907743 COVER, P/SEAT BK CUSH (CASHMERE)
25789846 PAD, P/SEAT BK CUSH
25865171 COVER, P/SEAT CUSH (CASHMERE) (VINYL INBOARD SIDE FACING)
25865172 COVER, P/SEAT CUSH (TITANIUM) (VINYL INBOARD SIDE FACING)
25899514 COVER, P/SEAT CUSH (EBONY)
15243828 COVER, P/SEAT INR RECL FIN (INCLS 14) (EBONY) (INBOARD)
11517996 ГАЙКА, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (P/SEAT ADJR TOP PLT) (ACDelco #11517996) [ГАЙКА М10]
15232555 MODULE, P/SEAT CUSH VENTILATION HEAT & COOL [ЭЛЕКТРОННЫЙ МОДУЛЬ УПРАВЛЕНИЯ СИСТЕМОЙ КОМФОРТА]
11516075 ГАЙКА, HFH SELF LK, M6X1, 7.7THK, 14.2 O.D., 9, PZOR (INFL RST P/SEAT SUPPRESSION) [ГАЙКА ВЫПУСКНОЙ СИСТЕМЫ D=6ММ]
11517996 ГАЙКА, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (P/SEAT ADJR FIN CVR) (ACDelco #11517996) [ГАЙКА М10]
15232567 COVER, P/SEAT ADJR FIN (INCLS 14) (EBONY) (POWER)
15232556 BLOWER, P/SEAT CUSH VENTILATION HEAT & COOL [ВЕНТИЛЯТОР ПОДОГРЕВА СИДЕНЬЯ, 1.5ВТ]
15232557 BLOWER, P/SEAT BACK VENTILATION HEAT & COOL (INCLS THERMAL ELECTRIC DEVICE, TEMP SENSOR & FILTER) [ВЕНТИЛЯТОР ПОДОГРЕВА СИДЕНЬЯ, 1.5ВТ]
25865153 PANEL, P/SEAT BK CUSH FIN (CASHMERE)
20763141 LUMBAR SUB, P/SEAT (PART OF 52) (POWER) (HEAT & COOL)
25808721 FRAME, P/SEAT BK CUSH (INCLS 15, 38, 39, 43, 51) (INCLS RECLINER, MOTOR & LUMBAR SUPPORT)
15232558 DUCT, P/SEAT BACK VENTILATION
20818408 MODULE KIT, INFL RST FRT PASS PRESENCE (W/ SEN) (INCLS 8)
(TC16-212) - 2007-2009 K1(06) КОНСОЛЬ/КРЫША (CADILLAC Z75, ARS,CF5, EXC UG1)
25786403 SWITCH, SUN RF (PART OF 5) (BLUE LAGOON BACK LIGHTING)
25786404 SWITCH, SUN RF (PART OF 5) (TRUE WHITE BACK LIGHTING)
15241529 MICROPHONE, MOBILE TEL (PART OF 5) (2-WAY CAVITY)
15862407 SWITCH, R/SEAT #2 FLDG ACTR (PART OF 5) (ON КОНСОЛЬ)
15936288 КОНСОЛЬ, RF (INCLS 1-4, 6-9, 11-14) (GRAY)
25807192 КОНСОЛЬ, RF (INCLS 1-4, 6-9, 11-14) (LT CASHMERE)
25977560 КОНСОЛЬ, RF (INCLS 1-4, 6-9, 11-14) (CASHMERE)
25977563 КОНСОЛЬ, RF (INCLS 1-4, 6-9, 11-14) (GRAY)
25977565 КОНСОЛЬ, RF (INCLS 1-4, 6-9, 11-14) (CASHMERE)
15853948 PUSHBUTTON, RDG LP SW (PART OF 5)
15911049 LENS, DM LP (PART OF 5) (1ST ROW) [КОЖУХ ФОНАРЯ ПОДСВЕТКИ САЛОНА]
09431809 BULB, 6CP TRADE #212-2 (PART OF 5) (ACDelco #L212-2)
teamcadillac.ru
22625546 INDICATOR, INFL RST I/P MDL (W/WORDS ON AND OFF FOR AIRBAG) (14.865)
22627868 INDICATOR, INFL RST I/P MDL (W/AIRBAG SYMBOLS FOR ON AND OFF) (14.865)
11609345 ГАЙКА, PUSH-IN, 4.2, SAE 1050 STL, GMW3179 (PART OF 5)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 5) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
(TC16-213) - 2007-2009 K1(06) КОНСОЛЬ/КРЫША (CADILLAC Z75, CF5, EXC ARS,UG1)
25786403 SWITCH, SUN RF (PART OF 4) (BLUE LAGOON BACK LIGHTING)
25786404 SWITCH, SUN RF (PART OF 4) (TRUE WHITE BACK LIGHTING)
15241529 MICROPHONE, MOBILE TEL (PART OF 4) (2-WAY CAVITY)
25807194 КОНСОЛЬ, RF (INCLS 1-3, 5-8, 10-13) (GRAY)
25807195 КОНСОЛЬ, RF (INCLS 1-3, 5-8, 10-13) (LT CASHMERE)
25853059 КОНСОЛЬ, RF (INCLS 1-3, 5-8, 10-13) (CASHMERE) (2ND ROW DVD FACE PLT) (PO PNL ASM)
25977563 КОНСОЛЬ, RF (INCLS 1-3, 5-8, 10-13) (GRAY)
25977565 КОНСОЛЬ, RF (INCLS 1-3, 5-8, 10-13) (CASHMERE)
15853948 PUSHBUTTON, RDG LP SW (PART OF 4)
15911049 LENS, DM LP (PART OF 4) (1ST ROW) [КОЖУХ ФОНАРЯ ПОДСВЕТКИ САЛОНА]
teamcadillac.ru
09431809 BULB, 6CP TRADE #212-2 (PART OF 4) (ACDelco #L212-2)
11609345 ГАЙКА, PUSH-IN, 4.2, SAE 1050 STL, GMW3179 (PART OF 4)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 4) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
(TC16-239) - 2009 CK107(06) ОТДЕЛКА/INTERIOR-BODY SIDE-LH QUARTER DETAIL (HYBRID HP2, CADILLAC Z75)
15838268 HOLDER, R/SEAT CUP (PART OF 5) (EBONY) [ДЕРЖАТЕЛЬ КОМПАКТ-ДИСКОВ ПЛАСТИКОВЫЙ]
15838269 HOLDER, R/SEAT CUP (PART OF 5) (CASHMERE)
15838270 HOLDER, R/SEAT CUP (PART OF 5) (TITANIUM)
15936706 HOLDER, R/SEAT CUP (PART OF 5) (LINEN)
15838294 LATCH, BODY SI T/PNL OPG ACC CVR (PART OF 5) (EBONY)
15838295 LATCH, BODY SI T/PNL OPG ACC CVR (PART OF 5) (CASHMERE)
15838296 LATCH, BODY SI T/PNL OPG ACC CVR (PART OF 5) (TITANIUM)
15936704 LATCH, BODY SI T/PNL OPG ACC CVR (PART OF 5) (LINEN)
15294093 PANEL, BODY SI TR (INCLS 1-4, 14, 15) (TITANIUM)
15885778 PANEL, BODY SI TR (INCLS 1-4, 14, 15) (TITANIUM)
15904065 PANEL, BODY SI TR (INCLS 1-4, 14, 15) (EBONY)
20765250 PANEL, BODY SI TR (INCLS 1-4, 14, 15) (LINEN)
25902628 PANEL, BODY SI TR (INCLS 1-4, 14, 15) (CASHMERE)
15862681 MOLDING, BODY RR COR UPR GARN (INCLS 7-13) (GRAY)
15863067 MOLDING, BODY RR COR UPR GARN (INCLS 7-13) (GRANITE) (W/SPKR) (BUILT PRIOR TO 5/19/08) (FOR 2ND DES SEE 25999668)
15877451 MOLDING, BODY RR COR UPR GARN (INCLS 7-13) (LINEN)
15901352 MOLDING, BODY RR COR UPR GARN (INCLS 7-13) (CASHMERE) (W/O SPEAKER)
15901354 MOLDING, BODY RR COR UPR GARN (INCLS 7-13) (GRAY)
15901363 MOLDING, BODY RR COR UPR GARN (INCLS 7-13) (GRAY) [ПРОВОДКА АККУМУЛЯТОРА]
teamcadillac.ru
25815096 MOLDING, BODY RR COR UPR GARN (INCLS 7-13) (GRAY) (W/SPKR)
25818939 MOLDING, BODY RR COR UPR GARN (INCLS 7-13) (GRAY)
25886908 MOLDING, BODY RR COR UPR GARN (INCLS 7-13) (CASHMERE) (W/SPKR)
25999668 MOLDING, BODY RR COR UPR GARN (INCLS 7-13) (GRANITE) ( (W/O SPKR) (ORDER SPKR SEPARATE)) (BUILT 5/19/08 & AFTER) (FOR 1ST DES SEE 15863067)
15278014 PLUG, BODY RR COR UPR GARN MLDG (PART OF 6) (GRAY) [ЗАГЛУШКА ВНУТРЕННЕЙ ПАНЕЛИ БАГАЖНОГО ОТДЕЛЕНИЯ]
15278015 PLUG, BODY RR COR UPR GARN MLDG (PART OF 6) (CASHMERE)
25827851 PLUG, BODY RR COR UPR GARN MLDG (PART OF 6) (LINEN)
11609539 SCREW, RD CROWNED WA HD, M4.2X1.41X16, STL ISO 2702, GMW4205 (PART OF 6) [ВИНТ]
11509253 SCREW, W/LRG WA HD, M4.2X1.4X10, 11.3 O.D., BHL PT, STL, NO (PART OF 6)
15186672 SPEAKER, RDO BODY RR COR UPR GARN MLDG (PART OF 6) (ACDelco #15186672) [ДИНАМИК 20 ВТ]
11561654 RETAINER, BODY RR COR G/MLDG (PART OF 6) (PLAIN) (8.5MM DIA HOLE) (BIRD'S BEAK SINGLE) (12.800) [ФИКСАТОР ВНУТРЕННЕЙ ПАНЕЛИ БАГАЖНОГО ОТДЕЛЕНИЯ]
11609651 RETAINER, BODY RR COR G/MLDG (PART OF 6) (M21.8X15.0X20.5) (14.731) [ШАЙБА]
25858121 RECEPTACLE, ACSRY PWR (PART OF 5) (110 VOLT) (ACSRY PWR RECEPTACLE ASSEM LABELED 8121)
(TC16-244) - 2008-2009 CK1(06) КОНСОЛЬ/ПОЛ (CADILLAC Z75, PLATINUM EDITION ULT)
11609459 SCREW, RND WA, M4.2X1.41X13, 7.2 THD, 11.35 OD, 6010M, GMW4205 (PART OF 1, 39) [ВИНТ]
15886900 MODULE, HTR & A/C & RDO CONT
10375379 ADAPTER, AUDIO/VIDEO DISC PLYR (ACDelco #10375379)
22596346 BUMPER, F/FLR RR CNSL A/RST (PART OF 39) (10.242)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 10) [ЗАЖИМ КОНСОЛИ САЛОНА]
15833953 COVER, HTR & A/C CONT OPG (INCLS 9)
10364311 RETAINER, ACSRY PWR RCPT (CHROME RING W/BLACK CAP)
25774623 RECEPTACLE, ACSRY PWR (ACSRY PWR RECEPTACLE ASSEM LABELED 4623) [ГНЕЗДО ПРИКУРИВАТЕЛЯ С КОНТАКТН. ЭЛЕМЕНТ., 12 ВТ]
15133100 LINER, F/FLR CNSL RR CUP HLDR (PART OF 14, 39)
15133093 HOLDER, F/FLR CNSL RR CUP (INCLS 13, 18, 19) (PART OF 39)
11609459 SCREW, RND WA, M4.2X1.41X13, 7.2 THD, 11.35 OD, 6010M, GMW4205 (PART OF 39) [ВИНТ]
11589106 SCREW, RND WA HD, M4.2X1.41X25, 19.2 THD, 11.3 OD, 6010M, GMW4205, C/R, TAP, (PART OF 39) (10.774) [БОЛТ]
11609459 SCREW, RND WA, M4.2X1.41X13, 7.2 THD, 11.35 OD, 6010M, GMW4205 (PART OF 14, 39) [ВИНТ]
15133101 BUSHING, F/FLR CNSL CUP HLDR DR HGE (PART OF 14, 39)
15929132 HARNESS, F/FLR CNSL WRG (PART OF 39)
25912292 HARNESS, F/FLR CNSL WRG (PART OF 39)
20808898 УСИЛИТЕЛЬ, RDO SPKR (PART OF 39) (ACDelco #20808898)
11562473 БОЛТ, F/SEAT (M12X1.75X45) [БОЛТ М12]
15035434 ГАЙКА, F/SEAT (M10X1.5X10.8) (FLANGE NUT) (16.679) [ВИНТ]
25830462 PANEL, F/FLR CNSL SI TR (INCLS 34) (PART OF 39) (COCOA)
25830464 PANEL, F/FLR CNSL SI TR (INCLS 34) (PART OF 39) (COCOA)
25830634 DUCT, AIR INL (PART OF 39)
15876585 PANEL, F/FLR CNSL SI TR FRT (INCLS 32, 33) (СМ. ГРУППУ 16.000 "ПРИБОРНАЯ ПАНЕЛЬ/TRIM" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (LINEN)
15876587 PANEL, F/FLR CNSL SI TR FRT (INCLS 32, 33) (СМ. ГРУППУ 16.000 "ПРИБОРНАЯ ПАНЕЛЬ/TRIM" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (LINEN)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 31) [ЗАЖИМ КОНСОЛИ САЛОНА]
teamcadillac.ru
11562257 RETAINER, I/P LWR TR PAD BRKT (PUSH ON) (PART OF 31) (19.5 X 30.4 X 1.8) (14.683)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 28, 39) [ЗАЖИМ КОНСОЛИ САЛОНА]
15187371 RETAINER, ACSRY PWR RCPT (PART OF 39) (EBONY) (INCLS COVER) [ОКАНТОВКА ГНЕЗДА ПРИКУРИВАТЕЛЯ]
25774623 RECEPTACLE, ACSRY PWR (PART OF 39) (ACSRY PWR RECEPTACLE ASSEM LABELED 4623) [ГНЕЗДО ПРИКУРИВАТЕЛЯ С КОНТАКТН. ЭЛЕМЕНТ., 12 ВТ]
25999727 COMPARTMENT, F/FLR (INCLS 1-4, 8, 13-25, 28-30, 34, 35, 37, 38) (COCOA)
11609460 SCREW, RND WA, M4.2X1.41X10, 4.2 THD, 11 OD, GM6010M, GMW4205, C/R, TAP (PART OF 43)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 43) [ЗАЖИМ КОНСОЛИ САЛОНА]
25991706 BEZEL, F/FLR FRT CNSL ACSRY TR (INCLS 36, 40-42, 44-46, 48, 49) (SOLITARE)
15683368 BUMPER, F/FLR CNSL COMPT DR (PART OF 43) (8.80 DIA) (CLOSED-STOP) (FRAME)
15132973 ПЕПЕЛЬНИЦА, F/FLR CNSL (PART OF 43)
11516140 LIGHTER, CIG (BLACK) (W/LARGE, PLASTIC KNOB END 21.0MM) [ПРИКУРИВАТЕЛЬ]
25774623 RECEPTACLE, ACSRY PWR (PART OF 43) (ACSRY PWR RECEPTACLE ASSEM LABELED 4623) [ГНЕЗДО ПРИКУРИВАТЕЛЯ С КОНТАКТН. ЭЛЕМЕНТ., 12 ВТ]
25776667 RECEPTACLE, ACSRY PWR (PART OF 43) (2 TERMINALS) [ГНЕЗДО ПРИКУРИВАТЕЛЯ С КОНТАКТН. ЭЛЕМЕНТ., 12 ВТ]
25749635 RETAINER, ACSRY PWR RCPT (PART OF 43) (EBONY) (W/O CAP) [ВТУЛКА ГНЕЗДА ПРИКУРИВАТЕЛЯ]
(TC16-300) - 2008-2009 CK107(06) ЗАДНЕЕ СИДЕНЬЕ/BENCH-60% SIDE (AM8, HYBRID HP2)
15291597 PAD, R/SEAT BK CUSH
15914200 PAD, R/SEAT BK CUSH
15279450 PROTECTOR, R/SEAT SHLDR BELT (BLACK)
11570116 SCREW -PAN HD, M6X1X10, 10 THD, 12 OD, STL SAE J1237, S424, TAPTITE ITE (R/SEAT LAT FIN CVR) (8.913)
11562382 БОЛТ, HFH, M10X1.5X130, 26 THD, 22.3 OD, 10.9, 7114M, MACH, MAT-PT (R/SEAT BK CUSH FRM)
15289969 BRACKET, R/SEAT CTR BELT (RETR SI)
11562383 БОЛТ, HFH, M12X1.75X30.5, 17 THD, 26.6 OD, 10.9 STL, GMW3359, W/ADH 6175M (R/SEAT LAT)
15824668 RESTRAINT, R/SEAT HD (EBONY)
15824669 RESTRAINT, R/SEAT HD (CASHMERE)
15824670 RESTRAINT, R/SEAT HD (TITANIUM)
15824672 RESTRAINT, R/SEAT HD (EBONY)
15865811 RESTRAINT, R/SEAT HD (TITANIUM) (USED ON VEHICLES BUILT 11/30/08 & PRIOR) (2ND DES SEE 20758015)
20758013 RESTRAINT, R/SEAT HD (EBONY) (USED ON VEHICLES BUILT 12/01/08 & AFTER) (1ST DES SEE 25863652)
20758014 RESTRAINT, R/SEAT HD (CASHMERE)
20758015 RESTRAINT, R/SEAT HD (TITANIUM) (USED ON VEHICLES BUILT 12/01/08 & AFTER) (1ST DES SEE 15865811)
25863652 RESTRAINT, R/SEAT HD (EBONY) (USED ON VEHICLES BUILT 11/30/08 & PRIOR) (2ND DES SEE 20758013)
25928791 RESTRAINT, R/SEAT HD (CASHMERE)
15279347 GUIDE, R/SEAT H/RST (EBONY) (W/BUTTON)
15279348 GUIDE, R/SEAT H/RST (CASHMERE) (W/BUTTON)
15279349 GUIDE, R/SEAT H/RST (TITANIUM) (W/BUTTON)
15279351 GUIDE, R/SEAT H/RST (EBONY) (W/O BUTTON)
15279352 GUIDE, R/SEAT H/RST (CASHMERE) (W/O BUTTON)
15279353 GUIDE, R/SEAT H/RST (TITANIUM) (W/O BUTTON)
11562378 BOLT-HFH, M10X1.5X30, 18 THD, 22.3 OD, 10.9, GMW3359, W/ADH GM6175M (R/SEAT LAT)
15269762 FRAME, R/SEAT BK CUSH
15924924 RETAINER, R/SEAT BK CUSH OPG FIN CVR (PUSH IN)
teamcadillac.ru
20761386 FRAME, R/SEAT CUSH
15279414 HANDLE, R/SEAT RECL (INCLS 15) (EBONY)
15279415 HANDLE, R/SEAT RECL (INCLS 15) (CASHMERE)
15279416 HANDLE, R/SEAT RECL (INCLS 15) (TITANIUM)
11562384 ГАЙКА, HFH, M4X.7 THD, 4.75 THK, 10.5 OD, GM510M (9)STL, GM4435M-CODE A (R/SEAT FLR FIL T/PNL)
11562380 BUSHING, R/SEAT HGE
11514596 ГАЙКА, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (R/SEAT) (8.915) (ACDelco #11514596)
11562376 SCREW-PAN HD, M12X1.75X55, 42 THD, 27 OD, 10.9, S424, W/ADH GM6175M (R/SEAT LAT)
15279464 KNOB, R/SEAT LAT (EBONY) (USED IN PLACE OF ALL COLORS) (16.716)
11562386 БОЛТ, R/SEAT A/RST (M8X1.25X24) (8.977)
15865490 ARMREST, R/SEAT (CASHMERE) (USED ON VEHICLES BUILT 11/30/08 & PRIOR) (2ND DES SEE 20758006)
15865493 ARMREST, R/SEAT (EBONY)
15865494 ARMREST, R/SEAT (CASHMERE)
15865495 ARMREST, R/SEAT (TITANIUM)
20758005 ARMREST, R/SEAT (EBONY) (USED ON VEHICLES BUILT 12/01/08 & AFTER) (1ST DES SEE 25863535)
20758006 ARMREST, R/SEAT (CASHMERE) (USED ON VEHICLES BUILT 12/01/08 & AFTER) (1ST DES SEE 15865490)
20758007 ARMREST, R/SEAT (TITANIUM)
25863535 ARMREST, R/SEAT (EBONY) (USED ON VEHICLES BUILT 11/30/08 & PRIOR) (2ND DES SEE 20758005)
15279469 COVER, R/SEAT A/RST SUPT FIN (EBONY)
15279470 COVER, R/SEAT A/RST SUPT FIN (CASHMERE)
15279471 COVER, R/SEAT A/RST SUPT FIN (TITANIUM)
20789635 COVER, R/SEAT A/RST SUPT FIN (COCOA)
15279406 PIN, R/SEAT H/RST ADJ ROD LAT (EBONY)
15279407 PIN, R/SEAT H/RST ADJ ROD LAT (CASHMERE)
15279408 PIN, R/SEAT H/RST ADJ ROD LAT (TITANIUM)
19151104 BELT KIT, R/SEAT CTR (RETR SI) (EBONY)
19151105 BELT KIT, R/SEAT CTR (RETR SI) (CASHMERE)
11562377 BOLT-HFH, M10X1.5X55, 43.45 THD, 22.3 OD, 10.9, GMW3359, W/ADH GM6175M (R/SEAT LAT)
25816398 PAD, R/SEAT CUSH
25816425 COVER, R/SEAT CUSH (EBONY)
25816426 COVER, R/SEAT CUSH (CASHMERE)
25816427 COVER, R/SEAT CUSH (TITANIUM)
25949167 COVER, R/SEAT CUSH (EBONY)
25949168 COVER, R/SEAT CUSH (CASHMERE)
15865521 COVER, R/SEAT BK CUSH (EBONY)
15865522 COVER, R/SEAT BK CUSH (CASHMERE)
15865523 COVER, R/SEAT BK CUSH (TITANIUM)
15914202 COVER, R/SEAT BK CUSH (EBONY)
20758107 COVER, R/SEAT BK CUSH (EBONY) (USED ON VEHICLES BUILT 12/01/08 & AFTER) (1ST DES SEE 25970987)
20758108 COVER, R/SEAT BK CUSH (CASHMERE) (USED ON VEHICLES BUILT 12/01/08 & AFTER) (1ST DES SEE 25970988)
20758109 COVER, R/SEAT BK CUSH (TITANIUM) (USED ON VEHICLES BUILT 12/01/08 & AFTER) (1ST DES SEE 25970989)
25970987 COVER, R/SEAT BK CUSH (EBONY) (USED ON VEHICLES BUILT 11/30/08 & PRIOR) (2ND DES SEE 20758107)
25970988 COVER, R/SEAT BK CUSH (CASHMERE) (USED ON VEHICLES BUILT 11/30/08 & PRIOR) (2ND DES SEE 20758108)
25970989 COVER, R/SEAT BK CUSH (TITANIUM) (USED ON VEHICLES BUILT 11/30/08 & PRIOR) (2ND DES SEE 20758109)
(TC16-315) - 2008-2009 CK107(06) КРЕПЛЕНИЕ ЗАДНЕГО СИДЕНЬЯ (60/40 BENCH AM8, HYBRID HP2)
20765253 COVER, R/SEAT RSR FIN (INCLS 2, 3, 11) (COCOA) (MAIN CVR ASM)
25906782 COVER, R/SEAT RSR FIN (INCLS 2, 3, 11) (CASHMERE) (MAIN COVER)
25947243 COVER, R/SEAT RSR FIN (INCLS 2, 3, 11) (EBONY)
25947245 COVER, R/SEAT RSR FIN (INCLS 2, 3, 11) (TITANIUM)
20820025 COVER, R/SEAT RSR INR FIN (PART OF 1) (LINEN)
25813593 COVER, R/SEAT RSR INR FIN (PART OF 1) (EBONY)
25813594 COVER, R/SEAT RSR INR FIN (PART OF 1) (CASHMERE)
25813595 COVER, R/SEAT RSR INR FIN (PART OF 1) (TITANIUM)
11509253 SCREW, W/LRG WA HD, M4.2X1.4X10, 11.3 O.D., BHL PT, STL, NO (PART OF 1)
20765252 COVER, R/SEAT FRM OTR FIN (INCLS 6, 7) (COCOA) (RH QUICK DISCONNECT CVR ASM)
25947239 COVER, R/SEAT FRM OTR FIN (INCLS 6, 7) (EBONY)
25947240 COVER, R/SEAT FRM OTR FIN (INCLS 6, 7) (CASHMERE)
teamcadillac.ru
25947241 COVER, R/SEAT FRM OTR FIN (INCLS 6, 7) (TITANIUM)
15894130 LABEL, BAT (PART OF 5)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 5) [ЗАЖИМ КОНСОЛИ САЛОНА]
03537772 ГАЙКА, M12X1.75, 10.6THK, 28 O.D., 10, 7111M (R/SEAT) (8.917)
20765251 COVER, R/SEAT FRM FRT FIN (INCLS 9) (COCOA) (FRONT CVR)
25898239 COVER, R/SEAT FRM FRT FIN (INCLS 9) (CASHMERE)
25898240 COVER, R/SEAT FRM FRT FIN (INCLS 9) (TITANIUM)
25924173 COVER, R/SEAT FRM FRT FIN (INCLS 9) (EBONY)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 1) [ЗАЖИМ КОНСОЛИ САЛОНА]
(TC16-333) - 2008-2009 CK1,2(06) ЗАДНЕЕ СИДЕНЬЕ #2-RH(AS3)
15898176 SEAT, RR #2 (INCLS 2-44) (TITANIUM) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
15898182 SEAT, RR #2 (INCLS 2-44) (CASHMERE) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
20858957 SEAT, RR #2 (INCLS 2-44) (EBONY) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
20859117 SEAT, RR #2 (INCLS 2-44) (CASHMERE)
25782024 SEAT, RR #2 (INCLS 2-44) (EBONY) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
25869773 SEAT, RR #2 (INCLS 2-44) (EBONY) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
25869774 SEAT, RR #2 (INCLS 2-44) (CASHMERE) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
25869847 SEAT, RR #2 (INCLS 2-44) (EBONY)
25869853 SEAT, RR #2 (INCLS 2-44) (EBONY) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
25917056 SEAT, RR #2 (INCLS 2-44) (TITANIUM)
25917118 SEAT, RR #2 (INCLS 2-44) (EBONY)
25917119 SEAT, RR #2 (INCLS 2-44) (CASHMERE)
25917176 SEAT, RR #2 (INCLS 2-44) (COCOA)
25943586 SEAT, RR #2 (INCLS 2-44) (COCOA)
25949073 SEAT, RR #2 (INCLS 2-44) (COCOA)
25950392 SEAT, RR #2 (INCLS 2-44) (CASHMERE)
25950446 SEAT, RR #2 (INCLS 2-44) (CASHMERE)
25971021 SEAT, RR #2 (INCLS 2-44) (EBONY)
25971022 SEAT, RR #2 (INCLS 2-44) (CASHMERE)
25971023 SEAT, RR #2 (INCLS 2-44) (TITANIUM)
25971042 SEAT, RR #2 (INCLS 2-44) (EBONY)
25971043 SEAT, RR #2 (INCLS 2-44) (CASHMERE)
25971044 SEAT, RR #2 (INCLS 2-44) (TITANIUM)
15804529 PAD, R/SEAT #2 BK CUSH
15827635 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE) (USED ON VEHICLES BUILT 11/30/08 & PRIOR) (2ND DES SEE 20757998)
15827636 RESTRAINT, R/SEAT HD (INCLS 3) (TITANIUM) (USED ON VEHICLES BUILT 11/30/08 & PRIOR) (2ND DES SEE 20757999)
15827642 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
15833505 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
15833506 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE)
15863451 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
15863452 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE)
15863458 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
15863459 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE)
15865842 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
20757997 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY) (USED ON VEHICLES BUILT 12/01/08 & AFTER) (1ST DES SEE 25863504)
20757998 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE) (USED ON VEHICLES BUILT 12/01/08 & AFTER) (1ST DES SEE 15827635)
20757999 RESTRAINT, R/SEAT HD (INCLS 3) (TITANIUM) (USED ON VEHICLES BUILT 12/01/08 & AFTER) (1ST DES SEE 15827636)
20758001 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
20758002 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE)
20758003 RESTRAINT, R/SEAT HD (INCLS 3) (TITANIUM)
25863504 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY) (USED ON VEHICLES BUILT 11/30/08 & PRIOR) (2ND DES SEE 20757997)
15279347 GUIDE, R/SEAT #2 H/RST (EBONY) (W/BUTTON)
15279348 GUIDE, R/SEAT #2 H/RST (CASHMERE) (W/BUTTON)
15279349 GUIDE, R/SEAT #2 H/RST (TITANIUM) (W/BUTTON)
15279351 GUIDE, R/SEAT #2 H/RST (EBONY) (W/O BUTTON)
15279352 GUIDE, R/SEAT #2 H/RST (CASHMERE) (W/O BUTTON)
15279353 GUIDE, R/SEAT #2 H/RST (TITANIUM) (W/O BUTTON)
25851750 GUIDE, R/SEAT #2 H/RST (COCOA) (W/BUTTON)
25851751 GUIDE, R/SEAT #2 H/RST (COCOA) (W/O BUTTON)
25943771 GUIDE, R/SEAT #2 H/RST (COCOA)
25869335 BRACKET, R/SEAT #2 BELT (RETR SI)
15827657 COVER, R/SEAT HGE FIN (O/B)
15898352 BELT, R/SEAT #2 CTR (INCLS 8) (EBONY)
19207589 BELT KIT, R/SEAT #2 CTR (RETR SI) (INCLS 8) (EBONY)
19207590 BELT KIT, R/SEAT #2 CTR (RETR SI) (INCLS 8) (CASHMERE)
19207591 BELT KIT, R/SEAT #2 CTR (RETR SI) (INCLS 8) (TITANIUM)
19207592 BELT KIT, R/SEAT #2 CTR (RETR SI) (INCLS 8) (CASHMERE)
19207593 BELT KIT, R/SEAT #2 CTR (RETR SI) (INCLS 8) (COCOA)
11562383 БОЛТ, R/SEAT #2 BELT (RETR SI) (8.900)
15898362 FRAME, R/SEAT #2 BK CUSH
15898399 FRAME, R/SEAT #2 BK CUSH
25960399 FRAME, R/SEAT #2 BK CUSH
15279464 KNOB, R/SEAT #2 BK CUSH LAT REL (EBONY) (USED IN PLACE OF ALL COLORS) (16.716)
19152522 BELT KIT, R/SEAT #2 (BKL SI) (EBONY) (SINGLE BKL)
19152523 BELT KIT, R/SEAT #2 (BKL SI) (CASHMERE) (SINGLE BKL)
19152524 BELT KIT, R/SEAT #2 (BKL SI) (TITANIUM) (SINGLE BKL)
19180590 BELT KIT, R/SEAT #2 (BKL SI) (COCOA)
15832214 LEVER, R/SEAT RSR LAT REL
25913455 LATCH, R/SEAT #2 BK CUSH (CENTER) [ЗАЩЕЛКА МЕХАНИЗМА РЕГУЛИРОВКИ ПОЛОЖЕНИЯ СИДЕНЬЯ]
25858774 COVER, R/SEAT #2 BK CUSH LAT (COCOA) (INBOARD, OUTER)
19127809 БОЛТ, R/SEAT #2 BK CUSH LAT (M12X1.75X63.9) (16.679)
25858773 COVER, R/SEAT #2 BK CUSH LAT (COCOA) (INBOARD, INNER)
15822356 HANDLE, R/SEAT LAT REL (PART OF 28) (EBONY)
15822357 HANDLE, R/SEAT LAT REL (PART OF 28) (CASHMERE)
15822358 HANDLE, R/SEAT LAT REL (PART OF 28) (TITANIUM)
15832238 CABLE, R/SEAT #2 BK CUSH LAT (INCLS 23) (EBONY) (W/PULL HANDLE) (50% MAIN CONTROL BOX)
15832239 CABLE, R/SEAT #2 BK CUSH LAT (INCLS 23) (CASHMERE) (W/PULL HANDLE) (50% MAIN CONTROL BOX)
15832240 CABLE, R/SEAT #2 BK CUSH LAT (INCLS 23) (TITANIUM) (W/PULL HANDLE) (50% MAIN CONTROL BOX)
15804473 COVER, R/SEAT #2 BK CUSH LAT (EBONY) (REAR CLOSEOUT) (16.716)
15804474 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (REAR CLOSEOUT) (16.716)
15804475 COVER, R/SEAT #2 BK CUSH LAT (TITANIUM) (REAR CLOSEOUT) (16.716)
15804476 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (REAR CLOSEOUT) (16.716)
25858769 COVER, R/SEAT #2 BK CUSH LAT (COCOA) (REAR CLOSEOUT)
15898402 LATCH, R/SEAT #2 LOAD FLR
15804478 COVER, R/SEAT #2 BK CUSH LAT (EBONY) (FRONT CLOSEOUT) (16.716)
15804479 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (FRONT CLOSEOUT) (16.716)
15804480 COVER, R/SEAT #2 BK CUSH LAT (TITANIUM) (FRONT CLOSEOUT) (16.716)
15804481 COVER, R/SEAT #2 BK CUSH LAT (CASHMERE) (FRONT CLOSEOUT) (16.716)
25858770 COVER, R/SEAT #2 BK CUSH LAT (COCOA) (FRONT CLOSEOUT)
15926524 FRAME, R/SEAT #2 CUSH
25858772 COVER, R/SEAT #2 BK CUSH LAT (COCOA) (OUTBOARD, OUTER)
25858771 COVER, R/SEAT #2 BK CUSH LAT (COCOA) (OUTBOARD, INNER)
19207599 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (EBONY)
19207600 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (CASHMERE)
19207601 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (TITANIUM)
19207603 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (COCOA)
25869320 BELT, R/SEAT #2 (RETR SI) (INCLS 8) (EBONY)
15804533 PAD, R/SEAT #2 CUSH
15865762 COVER, R/SEAT #2 CUSH (EBONY)
15865763 COVER, R/SEAT #2 CUSH (CASHMERE)
15865764 COVER, R/SEAT #2 CUSH (TITANIUM)
15865805 COVER, R/SEAT #2 CUSH (EBONY)
15865806 COVER, R/SEAT #2 CUSH (CASHMERE)
15865807 COVER, R/SEAT #2 CUSH (TITANIUM)
15925483 COVER, R/SEAT #2 CUSH (EBONY/MOROCCO)
20758151 COVER, R/SEAT #2 CUSH (EBONY)
20758152 COVER, R/SEAT #2 CUSH (CASHMERE)
20758153 COVER, R/SEAT #2 CUSH (TITANIUM) (USED ON VEHICLES BUILT 12/01/08 & AFTER) (1ST DES SEE 25971084)
20859438 COVER, R/SEAT #2 CUSH (CASHMERE)
25858737 COVER, R/SEAT #2 CUSH (LINEN/COCOA)
25928517 COVER, R/SEAT #2 CUSH (EBONY)
25937625 COVER, R/SEAT #2 CUSH (EBONY)
25937626 COVER, R/SEAT #2 CUSH (CASHMERE)
25937627 COVER, R/SEAT #2 CUSH (TITANIUM)
25971084 COVER, R/SEAT #2 CUSH (TITANIUM) (USED ON VEHICLES BUILT 11/30/08 & PRIOR) (2ND DES SEE 20758153)
15865754 COVER, R/SEAT #2 BK CUSH (EBONY)
15865755 COVER, R/SEAT #2 BK CUSH (CASHMERE)
15865756 COVER, R/SEAT #2 BK CUSH (TITANIUM)
15865797 COVER, R/SEAT #2 BK CUSH (EBONY) (INCLS CHILD COMFORT GUIDE)
15865799 COVER, R/SEAT #2 BK CUSH (TITANIUM) (INCLS CHILD COMFORT GUIDE)
teamcadillac.ru
20758135 COVER, R/SEAT #2 BK CUSH (EBONY)
20758136 COVER, R/SEAT #2 BK CUSH (CASHMERE)
20859432 COVER, R/SEAT #2 BK CUSH (CASHMERE) (INCLS CHILD COMFORT GUIDE)
25858735 COVER, R/SEAT #2 BK CUSH (LINEN/COCOA)
25928509 COVER, R/SEAT #2 BK CUSH (EBONY) (INCLS CHILD COMFORT GUIDE)
15924920 PANEL, R/SEAT BK CUSH FIL
15924917 WIRE, R/SEAT CUSH BRDR
(TC16-360) - 2007-2009 CK107(06) ОТДЕЛКА/INTERIOR-BODY SIDE REAR (CADILLAC Z75)
15877373 PLATE, R/FLR RR TR (INCLS 17, 18) (LINEN)
15931763 PLATE, R/FLR RR TR (INCLS 17, 18) (EBONY) (W/ CADILLAC INSERT) [КРЫШКА ПОЛА]
25902618 PLATE, R/FLR RR TR (INCLS 17, 18) (CASHMERE)
15905683 MOLDING, BK BODY OPG GARN (INCLS 3) (GRAY)
15905684 MOLDING, BK BODY OPG GARN (INCLS 3) (CASHMERE)
15936713 MOLDING, BK BODY OPG GARN (INCLS 3) (LINEN)
11561654 RETAINER, BODY RR COR G/MLDG (PART OF 2) (PLAIN) (8.5MM DIA HOLE) (BIRD'S BEAK SINGLE) (12.800) [ФИКСАТОР ВНУТРЕННЕЙ ПАНЕЛИ БАГАЖНОГО ОТДЕЛЕНИЯ]
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 10, 19) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
11609651 CLIP, BODY L/PLR G/MLDG (PART OF 10, 19) (M21.8X15.0X20.5) (14.731) [ШАЙБА]
15873285 PLATE, RR S/D SILL TR (INCLS 8) (EBONY) (W/CADILLAC INSERT) [НАКЛАДКА ПАНЕЛИ ПОРОГА КУЗОВА]
15877412 PLATE, RR S/D SILL TR (INCLS 8) (LINEN)
25902616 PLATE, RR S/D SILL TR (INCLS 8) (CASHMERE)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 7) [ЗАЖИМ КОНСОЛИ САЛОНА]
15043000 PLUG, R/CMPT SILL TR PLT HOLE (38.0 X 17.0 X 18.0MM) (OBLONG) (16.600)
15875101 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15) (CASHMERE) (MOLDED IN COLOR FLECKED PLASTIC UPR TR)
15875107 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15) (CASHMERE) (MOLDED IN COLOR FLECKED PLASTIC UPR TR)
15877443 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15) (LINEN)
15877445 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15) (LINEN)
15900725 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15) (EBONY/GRANITE OPAL) (DUAL TONE PART)
15900731 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15) (EBONY) (DUAL TONE PART) (GRAY UPR) [ВНУТРЕННЯЯ ПАНЕЛЬ СТОЙКИ КУЗОВА]
20844007 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15) (LINEN)
20844008 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15) (LINEN)
25797297 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15) (EBONY) (CLOTH WRAPPED)
25797300 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15) (EBONY) (MOLDED IN PLASTIC)
25902632 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15) (CASHMERE) (CLOTH WRAPPED UPR TR)
teamcadillac.ru
25902633 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15) (CASHMERE) (CLOTH WRAPPED UPR TR)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 10, 19) [ЗАЖИМ КОНСОЛИ САЛОНА]
15295390 BEZEL, R/SEAT SHLDR BELT OPG (PART OF 10, 19) (EBONY)
15295394 BEZEL, R/SEAT SHLDR BELT OPG (PART OF 10, 19) (EBONY)
25827829 BEZEL, R/SEAT SHLDR BELT OPG (PART OF 10, 19) (LINEN)
25827831 BEZEL, R/SEAT SHLDR BELT OPG (PART OF 10, 19) (LINEN)
25903597 BEZEL, R/SEAT SHLDR BELT OPG (PART OF 10, 19) (CASHMERE)
25903598 BEZEL, R/SEAT SHLDR BELT OPG (PART OF 10, 19) (CASHMERE)
15214081 GUIDE, R/SEAT SHLDR BELT (PART OF 10, 19) (EBONY)
25827828 GUIDE, R/SEAT SHLDR BELT (PART OF 10, 19) (LINEN)
11609465 БОЛТ, HWH, M4.2X1.41X18, 12.5 OD, 6010M, PS (PART OF 10, 19) (8.977) [ВИНТ М6]
15278075 PLUG, BODY L/PLR GARN MLDG (PART OF 10, 19) (GRAY) [ЗАГЛУШКА ВНУТРЕННЕЙ ПАНЕЛИ СТОЙКИ КУЗОВА]
15278076 PLUG, BODY L/PLR GARN MLDG (PART OF 10, 19) (GRAY) [ЗАГЛУШКА ВНУТРЕННЕЙ ПАНЕЛИ СТОЙКИ КУЗОВА]
15278083 PLUG, BODY L/PLR GARN MLDG (PART OF 10, 19) (CASHMERE)
15278084 PLUG, BODY L/PLR GARN MLDG (PART OF 10, 19) (CASHMERE)
25827826 PLUG, BODY L/PLR GARN MLDG (PART OF 10, 19) (LINEN)
25827830 PLUG, BODY L/PLR GARN MLDG (PART OF 10, 19) (LINEN)
15274514 COVER, L/GATE LK STKR (PART OF 1) (CASHMERE)
15274516 COVER, L/GATE LK STKR (PART OF 1) (EBONY)
15940206 COVER, L/GATE LK STKR (PART OF 1) (LINEN)
15877443 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (LINEN)
15877445 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (LINEN)
15900737 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (EBONY) (DUAL TONE PART) (GRAY UPR)
15900738 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (CASHMERE) (MOLDED IN COLOR FLECKED PLASTIC UPR TR)
15900743 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (EBONY) (DUAL TONE PART) (GRAY UPR)
15900744 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (CASHMERE) (MOLDED IN COLOR FLECKED PLASTIC UPR TR)
20844007 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (LINEN)
20844008 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (LINEN)
25797294 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (EBONY)
25797303 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (EBONY)
25902631 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (CASHMERE) (CLOTH WRAPPED UPR TR)
25902634 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (CASHMERE) (CLOTH WRAPPED UPR TR)
15113408 SWITCH, R/SEAT ADJR (PART OF 19) (ON GARNISH MOLDING)
15214082 BEZEL, BODY L/PLR G/MLDG (PART OF 19) (CASHMERE)
15214084 BEZEL, BODY L/PLR G/MLDG (PART OF 19) (EBONY)
25827827 BEZEL, BODY L/PLR G/MLDG (PART OF 19) (LINEN)
(TC16-375) - 2007-2009 CK107(06) ОТДЕЛКА/ВНУТРЕННЯЯ-КРЫША (EXC SUNROOF CF5)
20828843 PANEL, HDLNG TR (INCLS 9, 30, 31) (GRAY)
20828845 PANEL, HDLNG TR (INCLS 9, 30, 31) (CASHMERE)
20866424 PANEL, HDLNG TR (INCLS 9, 30, 31) (GRAY)
20866425 PANEL, HDLNG TR (INCLS 9, 30, 31) (CASHMERE)
25903301 ASPIRATOR, I/S AIR TEMP SEN (ACDelco #15-51256) [ДАТЧИК ТЕМПЕРАТУРЫ ВОЗДУХА]
15774330 BRACKET, R/RL RR ASST HDL
15958694 RETAINER, R/RL RR ASST HDL (PUSH IN) (BLACK) (7.6DIA X 22.9 MM) (X-MAS TREE) (FOR HOLE 6.30-6.55 DIA) (16.850) [ФИКСАТОР МОЛДИНГА КУЗОВА]
11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (R/RL RR ASST HDL BRKT) [БОЛТ М8]
20760385 HOOK, COAT (INCLS 7) (GRAY) (BEZEL W/FINGERS)
20760388 HOOK, COAT (INCLS 7) (CASHMERE)
25837307 HOOK, COAT (INCLS 7) (GRAY) (W/O FINGERS) [КРЮК]
11609649 SCREW-PAN HD, M6X1X20, 15 THD 11.25 OD, 6202M STL, GMW3044, TAPTITE 200 (PART OF 6) (8.913)
15126552 RETAINER, HDLNG T/PNL (GRAY) (26.3MM & DIA 6.85) [ФИКСАТОР ВНУТРЕННЕЙ ПАНЕЛИ КРЫШИ КУЗОВА]
15248143 RETAINER, HDLNG T/PNL (CASHMERE)
10393498 DEFLECTOR, AUX A/C AIR OTLT (PART OF 1, 34, 42) (CASHMERE)
15217394 DEFLECTOR, AUX A/C AIR OTLT (PART OF 1, 34, 42) (GRAY)
15940146 LAMP, DM & RDG (2ND ROW) (3RD ROW (INCLS 11-13) (OPAL GRAY)
15940147 LAMP, DM & RDG (2ND ROW) (3RD ROW (INCLS 11-13) (CASHMERE)
15940150 LAMP, DM & RDG (3RD ROW) (3RD ROW (INCLS 11-13) (GRAY) [ЛАМПА]
15940151 LAMP, DM & RDG (3RD ROW) (3RD ROW (INCLS 11-13) (CASHMERE)
15853948 PUSHBUTTON, RDG LP SW (PART OF 10, 18)
15853946 LENS, DM & RDG LP (3RD ROW LAMP) (PART OF 10)
19116011 BULB, C/LP (PART OF 10, 18) (ACDelco #19116011)
15075507 GRILLE, I/S AIR TEMP SEN ASPIRATOR (GRAY)
15250566 GRILLE, I/S AIR TEMP SEN ASPIRATOR (CASHMERE)
25836768 HANDLE, R/RL RR ASST (INCLS 16) (GRAY)
25836770 HANDLE, R/RL RR ASST (INCLS 16) (GRAY)
11609649 SCREW-PAN HD, M6X1X20, 15 THD 11.25 OD, 6202M STL, GMW3044, TAPTITE 200 (PART OF 15) (8.913)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 18) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
15940146 LAMP, DM & RDG (2ND ROW) (INCLS 11, 13, 17, 19) (OPAL GRAY)
15940147 LAMP, DM & RDG (2ND ROW) (INCLS 11, 13, 17, 19) (CASHMERE)
15940150 LAMP, DM & RDG (3RD ROW) (INCLS 11, 13, 17, 19) (GRAY) [ЛАМПА]
15940151 LAMP, DM & RDG (3RD ROW) (INCLS 11, 13, 17, 19) (CASHMERE)
15853946 LENS, DM & RDG LP (2ND ROW LAMP) (PART OF 18)
15853950 LENS, S/S ILLUM MIR LP (PART OF 23) (GRAY)
15853951 LENS, S/S ILLUM MIR LP (PART OF 23) (CASHMERE)
13502343 BULB, S/S ILLUM MIR LP (PART OF 23) (8.991) (ACDelco #13502343)
25945132 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, (INCLS 21, 22, 24, 25) (GRAY)
25945133 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, (INCLS 21, 22, 24, 25) (CASHMERE) [СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК]
25945137 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, (INCLS 21, 22, 24, 25) (GRAY)
25945138 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, (INCLS 21, 22, 24, 25) (CASHMERE)
11610271 SCREW, PAN HD, M4.2X1.41X25, 20.5 THD, 8 OD, 6010M, GMW4205, T15 TORX, AB-PT (PART OF 23)
15828264 COVER, S/S SUPT BOLT (GRAY)
15828266 COVER, S/S SUPT BOLT (CASHMERE)
15828268 COVER, S/S SUPT BOLT (GRAY)
15828270 COVER, S/S SUPT BOLT (CASHMERE)
11516440 SCREW (PART OF 28)
15893661 RETAINER, S/S (INCLS 27, 29) (CASHMERE)
11609314 CLIP, S/S SUPT (PART OF 28) (4.2 X 1.41) (12.8 HOLE)
15289725 CABLE, RDO ANT (PART OF 1, 34, 42) (ACDelco #15289725) (USED W/ANT MDL LABELED 15877496 OR 15877497) (FOR 2ND DES SEE25994421)
25994421 CABLE, RDO ANT (PART OF 1, 34, 42) (USED W/ANT LABELED 25943786 OR 25943787) (FOR 1ST DES SEE 15289725)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 33) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
15833005 RETAINER, RF RR CNSL (INCLS 32) (HVAC BACKPLATE)
20866448 PANEL, HDLNG TR (INCLS 9, 30, 31) (GRAY)
20866449 PANEL, HDLNG TR (INCLS 9, 30, 31) (CASHMERE)
20866466 PANEL, HDLNG TR (INCLS 9, 30, 31) (GRAY)
25877578 PANEL, HDLNG TR (INCLS 9, 30, 31) (GRAY) (BUILT PRIOR TO 02/01/09) (FOR 2ND DES SEE 25995036)
25877579 PANEL, HDLNG TR (INCLS 9, 30, 31) (CASHMERE) (BUILT PRIOR TO 02/01/09) (FOR 2ND DES SEE 25995037)
25995036 PANEL, HDLNG TR (INCLS 9, 30, 31) (GRAY) (BUILT ON OR AFTER 02/01/09) (FOR 1ST DES SEE 25877578)
25995037 PANEL, HDLNG TR (INCLS 9, 30, 31) (CASHMERE) (BUILT ON OR AFTER 02/01/09) (FOR 1ST DES SEE 25877579)
25995045 PANEL, HDLNG TR (INCLS 9, 30, 31) (GRAY)
15109353 CONTROL, AUX HTR & A/C (9.273) (ACDelco #15-73427)
15913180 КОНСОЛЬ, RF (INCLS 35, 38-41) (GRAY) (W/LEAR TRANSMITTER KIT 25807341)
15913181 КОНСОЛЬ, RF (INCLS 35, 38-41) (LT CASHMERE) (W/LEAR TRANSMITTER KIT 25807341)
25807240 КОНСОЛЬ, RF (INCLS 35, 38-41) (GRAY)
25853059 КОНСОЛЬ, RF (INCLS 35, 38-41) (CASHMERE) (2ND ROW DVD FACE PLT) (PO PNL ASM)
25977569 КОНСОЛЬ, RF (INCLS 35, 38-41) (CASHMERE)
09431809 BULB, 6CP TRADE #212-2 (PART OF 37) (ACDelco #L212-2)
15853944 LENS, RF CNSL C/LP (PART OF 37) (9.279)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 37) [ЗАЖИМ КОНСОЛИ САЛОНА]
teamcadillac.ru
20828847 PANEL, HDLNG TR (INCLS 9, 30, 31) (GRAY)
20828848 PANEL, HDLNG TR (INCLS 9, 30, 31) (CASHMERE)
20866430 PANEL, HDLNG TR (INCLS 9, 30, 31) (GRAY)
20866431 PANEL, HDLNG TR (INCLS 9, 30, 31) (CASHMERE)
15287715 RETAINER, RF RR CNSL (INCLS 44) (DVD BCKPLT - 2ND ROW) (10.225)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 43) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 46) [ЗАЖИМ КОНСОЛИ САЛОНА]
25853058 КОНСОЛЬ, RF (INCLS 45, 47-49) (GRAY) (DVD КОНСОЛЬ)
25853059 КОНСОЛЬ, RF (INCLS 45, 47-49) (CASHMERE) (2ND ROW DVD FACE PLT) (PO PNL ASM)
15853942 LENS, VIDEO PLYR R/CON SEN (PART OF 46) (RH DVD PUSH-PUSH)
09431809 BULB, 6CP TRADE #212-2 (PART OF 46) (ACDelco #L212-2)
(TC16-376) - 2007-2009 CK107(06) ОТДЕЛКА/ВНУТРЕННЯЯ-КРЫША (SUNROOF CF5)
20828840 PANEL, HDLNG TR (INCLS 9, 30, 31) (GRAY)
20828841 PANEL, HDLNG TR (INCLS 9, 30, 31) (CASHMERE)
20866418 PANEL, HDLNG TR (INCLS 9, 30, 31) (GRAY)
20866419 PANEL, HDLNG TR (INCLS 9, 30, 31) (CASHMERE)
25877572 PANEL, HDLNG TR (INCLS 9, 30, 31) (CASHMERE) (BUILT PRIOR TO 02/01/09) (FOR 2ND DES SEE 25995034)
15936651 HOOK, COAT (INCLS 7) (LINEN)
15220012 RETAINER, HDLNG T/PNL (CASHMERE)
25851525 RETAINER, HDLNG T/PNL (LINEN)
10393498 DEFLECTOR, AUX A/C AIR OTLT (PART OF 1, 34) (CASHMERE)
15217394 DEFLECTOR, AUX A/C AIR OTLT (PART OF 1, 34) (GRAY)
25851511 DEFLECTOR, AUX A/C AIR OTLT (PART OF 1, 34) (LINEN)
15940146 LAMP, DM & RDG (2ND ROW) (OPAL GRAY)
15940147 LAMP, DM & RDG (2ND ROW) (CASHMERE)
15940150 LAMP, DM & RDG (3RD ROW) (GRAY) [ЛАМПА]
15940151 LAMP, DM & RDG (3RD ROW) (CASHMERE)
25851514 LAMP, DM & RDG (LINEN)
25851516 GRILLE, I/S AIR TEMP SEN ASPIRATOR (LINEN)
25865717 HANDLE, R/RL RR ASST (INCLS 16) (LINEN)
25865719 HANDLE, R/RL RR ASST (INCLS 16) (LINEN)
15853946 LENS, DM & RDG LP (PART OF 18)
25874712 MOLDING, SUN RF PNL/WDO GARN (GRAY)
25874713 MOLDING, SUN RF PNL/WDO GARN (CASHMERE)
teamcadillac.ru
25874715 MOLDING, SUN RF PNL/WDO GARN (LINEN)
25861408 LENS, S/S ILLUM MIR LP (PART OF 23) (COCOA)
25945135 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, (INCLS 21, 22, 24, 25) (LINEN)
25945140 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, (INCLS 21, 22, 24, 25) (LINEN)
25851512 RETAINER, S/S (INCLS 27, 29) (LINEN)
15289725 CABLE, RDO ANT (PART OF 1, 34) (ACDelco #15289725) (USED W/ANT MDL LABELED 15877496 OR 15877497) (FOR 2ND DES SEE25994421)
25994421 CABLE, RDO ANT (PART OF 1, 34) (USED W/ANT LABELED 25943786 OR 25943787) (FOR 1ST DES SEE 15289725)
15287715 RETAINER, RF RR CNSL (INCLS 32) (DVD BCKPLT - 2ND ROW) (10.225)
20828836 PANEL, HDLNG TR (INCLS 9, 30, 31) (GRAY)
20828837 PANEL, HDLNG TR (INCLS 9, 30, 31) (CASHMERE)
20828838 PANEL, HDLNG TR (INCLS 9, 30, 31) (LINEN)
20866411 PANEL, HDLNG TR (INCLS 9, 30, 31) (GRAY)
20866412 PANEL, HDLNG TR (INCLS 9, 30, 31) (CASHMERE)
20866413 PANEL, HDLNG TR (INCLS 9, 30, 31) (LINEN)
25851515 КОНСОЛЬ, RF (INCLS 36, 38-40) (COCOA) (2ND ROW)
25853058 КОНСОЛЬ, RF (INCLS 36, 38-40) (GRAY) (DVD КОНСОЛЬ)
25853059 КОНСОЛЬ, RF (INCLS 36, 38-40) (CASHMERE) (2ND ROW DVD FACE PLT) (PO PNL ASM)
15853942 LENS, VIDEO PLYR R/CON SEN (PART OF 37) (RH DVD PUSH-PUSH)
(TC16-379) - 2007-2009 CK1(06-36) ОТДЕЛКА ДВЕРИ/SIDE FRONT-DRIVER (CADILLAC Z75)
11609385 ГАЙКА, U-TYPE, M6X1, 29.5 LEN, 12.5 WID, 19.5 CEN-END, 1050, GMW3359 (FRT S/D TR PNL) [ГАЙКА М 6]
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 18) [ЗАЖИМ КОНСОЛИ САЛОНА]
15920724 DEFLECTOR, FRT S/D WAT (PART OF 18)
15844616 KNOB, FRT S/D LKG ROD (EBONY) [КНОПКА БЛОКИРАТОРА ДВЕРИ]
15844620 KNOB, FRT S/D LKG ROD (COCOA)
20785356 KNOB, FRT S/D LKG ROD (CASHMERE)
11588650 CLIP, 12X14X16.6, GM4345M (DR LK & SI WDO RLY (PUSH IN)) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
25866617 BEZEL, FRT S/D WDO SW (COCOA)
25873114 BEZEL, FRT S/D WDO SW (WALNUT)
25873115 BEZEL, FRT S/D WDO SW (CASHMERE)
20877337 SWITCH, DR LK & SI WDO
25783953 SWITCH, DR LK & SI WDO (ACDelco #D1467G)
25857282 PANEL, FRT S/D UPR FRT TR (INCLS 10) (EBONY)
25857283 PANEL, FRT S/D UPR FRT TR (INCLS 10) (COCOA)
25906770 PANEL, FRT S/D UPR FRT TR (INCLS 10) (CASHMERE)
25822439 SWITCH, D/SEAT ADJR MEMORY (PART OF 18)
15920707 HANDLE, FRT S/D I/S (PART OF 18) (EBONY) (W/CHROME HDL) [РУЧКА ДВЕРИ]
15935951 HANDLE, FRT S/D I/S (PART OF 18) (EBONY) (W/CHROME REL HDL) [РУЧКА]
25815291 HANDLE, FRT S/D I/S (PART OF 18)
25906818 HANDLE, FRT S/D I/S (PART OF 18) (CASHMERE)
25897906 COVER, FRT S/D I/S HDL BZL FIN (EBONY) [КРЫШКА РУЧКИ САЛОНА]
25897910 COVER, FRT S/D I/S HDL BZL FIN (COCOA)
25906776 COVER, FRT S/D I/S HDL BZL FIN (CASHMERE)
11570136 БОЛТ, HEX HD, W/CON SPR WA, M6X1X23, 14 THD, 17 O.D., 8.8, GMW3359 (FRT S/D T/PNL)
15214060 COVER, FRT S/D T/PNL (EBONY)
15214061 COVER, FRT S/D T/PNL (CASHMERE)
25815658 COVER, FRT S/D T/PNL (LINEN)
15939207 GRILLE, RDO FRT SPKR (PART OF 18) (CASHMERE) (9.665)
15939208 GRILLE, RDO FRT SPKR (PART OF 18) (EBONY) (9.665) [РЕШЕТКА ДИНАМИКА ДВЕРИ]
25822705 PANEL, FRT S/D TR (INCLS 2-4, 12, 13, 17, 19-26) (LINEN)
25974175 PANEL, FRT S/D TR (INCLS 2-4, 12, 13, 17, 19-26) (EBONY)
25974176 PANEL, FRT S/D TR (INCLS 2-4, 12, 13, 17, 19-26) (CASHMERE)
15876516 LAMP, CTSY (INCLS 19) (PART OF 18) (FRT S/D)
09425542 BULB, LAMP #192 (PART OF 18, 20) (ACDelco #L168)
11519031 RETAINER, PUSH IN, 19.5X26.1X1.8, ACETAL, NATURAL, FOAM SEALER (PART OF 18) [ФИКСАТОР ОБШИВКИ ДВЕРИ]
11519032 RETAINER, PUSH IN, 19.5X28.4X1.8, FITS HOLE 9.1, ACETAL, BLK (PART OF 18) [ФИКСАТОР ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ]
25912653 DOOR, FRT SI (СМ. ГРУППУ 16.000 "АРМАТУРА ПЕРЕДНЕЙ ДВЕРИ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/O HINGES) [ПАНЕЛЬ ДВЕРИ]
(TC16-380) - 2007-2009 CK1(06-36) ОТДЕЛКА ДВЕРИ/SIDE FRONT-PASSENGER (CADILLAC Z75)
15228568 DOOR, FRT SI (СМ. ГРУППУ 16.000 "АРМАТУРА ПЕРЕДНЕЙ ДВЕРИ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/O HINGES)
25973617 DEFLECTOR, FRT S/D WAT (PART OF 10)
11519032 RETAINER, PUSH IN, 19.5X28.4X1.8, FITS HOLE 9.1, ACETAL, BLK (PART OF 10) [ФИКСАТОР ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ]
teamcadillac.ru
11519031 RETAINER, PUSH IN, 19.5X26.1X1.8, ACETAL, NATURAL, FOAM SEALER (PART OF 10) [ФИКСАТОР ОБШИВКИ ДВЕРИ]
25783907 PANEL, FRT S/D TR (INCLS 2, 4-9, 11, 15, 23, 25, 26) (LINEN)
25974178 PANEL, FRT S/D TR (INCLS 2, 4-9, 11, 15, 23, 25, 26) (EBONY)
25974179 PANEL, FRT S/D TR (INCLS 2, 4-9, 11, 15, 23, 25, 26) (CASHMERE)
15939207 GRILLE, RDO FRT SPKR (PART OF 10) (CASHMERE) (9.665)
15939208 GRILLE, RDO FRT SPKR (PART OF 10) (EBONY) (9.665) [РЕШЕТКА ДИНАМИКА ДВЕРИ]
15214063 COVER, FRT S/D T/PNL (EBONY) [НАКЛАДКА ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ]
15214065 COVER, FRT S/D T/PNL (TITANIUM)
25815659 COVER, FRT S/D T/PNL (LINEN)
25897912 COVER, FRT S/D I/S HDL BZL FIN (EBONY) [ЗАГЛУШКА БОЛТА ВНУТРЕННЕЙ РУЧКИ ДВЕРИ]
15920704 HANDLE, FRT S/D I/S (PART OF 10) (EBONY) (W/CHROME HDL) [ВНУТРЕННЯЯ РУЧКА ПЕРЕДНЕЙ ДВЕРИ]
25815292 HANDLE, FRT S/D I/S (PART OF 10)
25906817 HANDLE, FRT S/D I/S (PART OF 10) (CASHMERE)
15849186 PANEL, FRT S/D UPR FRT TR (INCLS 17) (CASHMERE)
25857286 PANEL, FRT S/D UPR FRT TR (INCLS 17) (EBONY)
25857287 PANEL, FRT S/D UPR FRT TR (INCLS 17) (COCOA)
25906771 PANEL, FRT S/D UPR FRT TR (INCLS 17) (CASHMERE)
25870922 RETAINER, FRT S/D UPR FRT T/PNL (PART OF 16)
20877340 SWITCH, DR LK & SI WDO
25783954 SWITCH, DR LK & SI WDO (16.203)
25866623 BEZEL, FRT S/D WDO SW (COCOA)
25873080 BEZEL, FRT S/D WDO SW (WALNUT)
25873081 BEZEL, FRT S/D WDO SW (CASHMERE)
09425542 BULB, LAMP #192 (PART OF 9, 10) (ACDelco #L168)
(TC16-381) - 2007-2009 CK107(06) ОТДЕЛКА ДВЕРИ/SIDE REAR (CADILLAC Z75)
15984153 ГАЙКА, RR S/D I/S HDL (16.320)
15845111 DEFLECTOR, RR S/D WAT (PART OF 14) (16.150)
15920740 DEFLECTOR, RR S/D WAT (PART OF 14) (16.150)
11519032 RETAINER, PUSH IN, 19.5X28.4X1.8, FITS HOLE 9.1, ACETAL, BLK (PART OF 14) [ФИКСАТОР ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ]
15844616 KNOB, RR S/D LKG ROD (EBONY) [КНОПКА БЛОКИРАТОРА ДВЕРИ]
15844620 KNOB, RR S/D LKG ROD (COCOA)
20785356 KNOB, RR S/D LKG ROD (CASHMERE)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (RR S/D ACSRY SW MT PLT) [ЗАЖИМ КОНСОЛИ САЛОНА]
25873126 BEZEL, RR S/D WDO SW (WALNUT)
25873127 BEZEL, RR S/D WDO SW (WALNUT)
25873128 BEZEL, RR S/D WDO SW (WALNUT)
25873129 BEZEL, RR S/D WDO SW (WALNUT)
25948861 BEZEL, RR S/D WDO SW (PLATINUM COCOA)
25948862 BEZEL, RR S/D WDO SW (PLATINUM COCOA)
25898072 SWITCH, RR S/D WDO (WITHOUT BACKLIGHTING) [ВЫКЛЮЧАТЕЛЬ СТЕКЛОПОДЪЕМНИКА ДВЕРИ (КЛАВ)]
15920683 HANDLE, RR S/D I/S (PART OF 14) (EBONY)
15920704 HANDLE, RR S/D I/S (PART OF 14) (EBONY) (W/CHROME HDL) [ВНУТРЕННЯЯ РУЧКА ПЕРЕДНЕЙ ДВЕРИ]
15939073 HANDLE, RR S/D I/S (PART OF 14) (EBONY) (W/CHROME REL HDL) [РУЧКА В СБОРЕ]
25815292 HANDLE, RR S/D I/S (PART OF 14)
25815293 HANDLE, RR S/D I/S (PART OF 14)
25897906 COVER, RR S/D I/S HDL BZL FIN (EBONY) [КРЫШКА РУЧКИ САЛОНА]
25897910 COVER, RR S/D I/S HDL BZL FIN (COCOA)
25897912 COVER, RR S/D I/S HDL BZL FIN (EBONY) [ЗАГЛУШКА БОЛТА ВНУТРЕННЕЙ РУЧКИ ДВЕРИ]
25897916 COVER, RR S/D I/S HDL BZL FIN (COCOA)
25906776 COVER, RR S/D I/S HDL BZL FIN (CASHMERE)
teamcadillac.ru
25906777 COVER, RR S/D I/S HDL BZL FIN (CASHMERE)
11570136 БОЛТ, HEX HD, W/CON SPR WA, M6X1X23, 14 THD, 17 O.D., 8.8, GMW3359 (RR S/D T/PNL)
15214091 COVER, RR S/D T/PNL (EBONY)
15214094 COVER, RR S/D T/PNL (EBONY)
25815660 COVER, RR S/D T/PNL (LINEN)
25815661 COVER, RR S/D T/PNL (LINEN)
15872258 PANEL, RR S/D TR (INCLS 2, 3, 5, 6, 10, 15, 16, 19, 20) (LINEN)
15872262 PANEL, RR S/D TR (INCLS 2, 3, 5, 6, 10, 15, 16, 19, 20) (LINEN)
25974182 PANEL, RR S/D TR (INCLS 2, 3, 5, 6, 10, 15, 16, 19, 20) (EBONY)
25974183 PANEL, RR S/D TR (INCLS 2, 3, 5, 6, 10, 15, 16, 19, 20) (CASHMERE)
25974185 PANEL, RR S/D TR (INCLS 2, 3, 5, 6, 10, 15, 16, 19, 20) (EBONY)
25974186 PANEL, RR S/D TR (INCLS 2, 3, 5, 6, 10, 15, 16, 19, 20) (CASHMERE)
11519031 RETAINER, PUSH IN, 19.5X26.1X1.8, ACETAL, NATURAL, FOAM SEALER (PART OF 14) [ФИКСАТОР ОБШИВКИ ДВЕРИ]
11609385 ГАЙКА, U-TYPE, M6X1, 29.5 LEN, 12.5 WID, 19.5 CEN-END, 1050, GMW3359 (RR S/D T/PNL) [ГАЙКА М 6]
15952332 RETAINER, RR S/D WAT DFL (PART OF 14)
(TC16-382) - 2008-2009 CK107(06) ОТДЕЛКА/INTERIOR-BODY SIDE-LH QUARTER DETAIL (EXC POWER LIFTGATE E61, EXC HP2, CHEVROLET X88)
teamcadillac.ru
15862682 MOLDING, BODY RR COR UPR GARN (INCLS 7-13) (CASHMERE)
15863068 MOLDING, BODY RR COR UPR GARN (INCLS 7-13) (CASHMERE) (W/SPKR) (BUILT PRIOR TO 5/19/08) (FOR 2ND DES SEE 25999669)
25818940 MOLDING, BODY RR COR UPR GARN (INCLS 7-13) (CASHMERE)
25999669 MOLDING, BODY RR COR UPR GARN (INCLS 7-13) (CASHMERE) ( (W/O SPKR) (ORDER SPKR SEPARATE)) (BUILT 5/19/08 & AFTER) (FOR 1ST DES SEE 15863068)
(TC16-383) - 2008-2009 CK107(06) ОТДЕЛКА/INTERIOR-BODY SIDE-LH QUARTER DETAIL (POWER LIFTGATE E61,EXC HP2, CHEVROLET X88)
15838268 HOLDER, R/SEAT CUP (PART OF 3) (EBONY) [ДЕРЖАТЕЛЬ КОМПАКТ-ДИСКОВ ПЛАСТИКОВЫЙ]
15838269 HOLDER, R/SEAT CUP (PART OF 3) (CASHMERE)
15838270 HOLDER, R/SEAT CUP (PART OF 3) (TITANIUM)
15936706 HOLDER, R/SEAT CUP (PART OF 3) (LINEN)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 3) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
15885777 PANEL, BODY SI TR (INCLS 1, 2) (CASHMERE)
15885778 PANEL, BODY SI TR (INCLS 1, 2) (TITANIUM)
15885779 PANEL, BODY SI TR (INCLS 1, 2) (EBONY)
15936654 PANEL, BODY SI TR (INCLS 1, 2) (LINEN)
15877451 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (LINEN)
15901352 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (CASHMERE) (W/O SPEAKER)
15901354 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (GRAY)
15901363 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (GRAY) [ПРОВОДКА АККУМУЛЯТОРА]
15901364 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (CASHMERE)
25815096 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (GRAY) (W/SPKR)
25886908 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (CASHMERE) (W/SPKR)
15278014 PLUG, BODY RR COR UPR GARN MLDG (PART OF 4) (GRAY) [ЗАГЛУШКА ВНУТРЕННЕЙ ПАНЕЛИ БАГАЖНОГО ОТДЕЛЕНИЯ]
15278015 PLUG, BODY RR COR UPR GARN MLDG (PART OF 4) (CASHMERE)
teamcadillac.ru
15278017 PLUG, BODY RR COR UPR GARN MLDG (PART OF 4) (GRAY)
25827851 PLUG, BODY RR COR UPR GARN MLDG (PART OF 4) (LINEN)
11609539 SCREW, RD CROWNED WA HD, M4.2X1.41X16, STL ISO 2702, GMW4205 (PART OF 4) [ВИНТ]
11509253 SCREW, W/LRG WA HD, M4.2X1.4X10, 11.3 O.D., BHL PT, STL, NO (PART OF 4)
15186672 SPEAKER, RDO BODY RR COR UPR GARN MLDG (PART OF 4) (ACDelco #15186672) [ДИНАМИК 20 ВТ]
11561654 RETAINER, BODY RR COR G/MLDG (PART OF 4) (PLAIN) (8.5MM DIA HOLE) (BIRD'S BEAK SINGLE) (12.800) [ФИКСАТОР ВНУТРЕННЕЙ ПАНЕЛИ БАГАЖНОГО ОТДЕЛЕНИЯ]
11609651 RETAINER, BODY RR COR G/MLDG (PART OF 4) (M21.8X15.0X20.5) (14.731) [ШАЙБА]
(TC16-384) - 2007-2009 CK107(06) ОТДЕЛКА/INTERIOR-BODY SIDE-RH QUARTER DETAIL
15863072 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13) (GRANITE) (W/SPKR) (BUILT PRIOR TO 5/19/08) (FOR 2ND DES SEE 25999671)
15863073 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13) (CASHMERE) (W/SPKR) (BUILT PRIOR TO 5/19/08) (FOR 2ND DES SEE 25999672)
15877453 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13) (LINEN) (W/SPEAKER)
25818936 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13) (GRAY)
25818937 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13) (CASHMERE)
25999671 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13) (GRANITE) ( (W/O SPKR) (ORDER SPKR SEPARATE)) (BUILT 5/19/08 & AFTER) (FOR 1ST DES SEE 15863072)
25999672 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13) (CASHMERE) ( (W/O SPKR) (ORDER SPKR SEPARATE)) (BUILT 5/19/08 & AFTER) (FOR 1ST DES SEE 15863073)
15186672 SPEAKER, RDO BODY RR COR UPR GARN MLDG (PART OF 1, 15) (ACDelco #15186672) [ДИНАМИК 20 ВТ]
11509253 SCREW, W/LRG WA HD, M4.2X1.4X10, 11.3 O.D., BHL PT, STL, NO (PART OF 1, 15)
11561654 RETAINER, BODY RR COR G/MLDG (PART OF 1, 15) (PLAIN) (8.5MM DIA HOLE) (BIRD'S BEAK SINGLE) (12.800) [ФИКСАТОР ВНУТРЕННЕЙ ПАНЕЛИ БАГАЖНОГО ОТДЕЛЕНИЯ]
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 1, 15) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
11609508 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (PART OF 1, 15)
15278014 PLUG, BODY RR COR UPR GARN MLDG (PART OF 1, 15) (GRAY) [ЗАГЛУШКА ВНУТРЕННЕЙ ПАНЕЛИ БАГАЖНОГО ОТДЕЛЕНИЯ]
15278015 PLUG, BODY RR COR UPR GARN MLDG (PART OF 1, 15) (CASHMERE)
25827851 PLUG, BODY RR COR UPR GARN MLDG (PART OF 1, 15) (LINEN)
15187371 RETAINER, C/LTR HSG (PART OF 10) (EBONY) (INCLS COVER) [ОКАНТОВКА ГНЕЗДА ПРИКУРИВАТЕЛЯ]
25749635 RETAINER, C/LTR RCPT (PART OF 10) (EBONY) (W/O CAP) (9.709) (SERV CMP OF ПЕПЕЛЬНИЦА PKG) [ВТУЛКА ГНЕЗДА ПРИКУРИВАТЕЛЯ]
25776667 RECEPTACLE, ACSRY PWR (PART OF 10) (2 TERMINALS) [ГНЕЗДО ПРИКУРИВАТЕЛЯ С КОНТАКТН. ЭЛЕМЕНТ., 12 ВТ]
15926940 PANEL, BODY SI TR (INCLS 8, 9, 11, 12) (EBONY)
15936655 PANEL, BODY SI TR (INCLS 8, 9, 11, 12) (LINEN)
teamcadillac.ru
25902629 PANEL, BODY SI TR (INCLS 8, 9, 11, 12) (CASHMERE)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 10) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
11609651 RETAINER, BODY RR COR G/MLDG (PART OF 1, 15) (M21.8X15.0X20.5) (14.731) [ШАЙБА]
21997869 INDICATOR, RR OBJECT ALARM (PART OF 15)
15863077 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13, 14) (LT OPEL GRAY)
15863078 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13, 14) (CASHMERE)
15863081 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13, 14) (GRANITE) (W/SPKR) (BUILT PRIOR TO 5/19/08) (FOR 2ND DES SEE 25999674)
15863082 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13, 14) (CASHMERE) (W/SPKR) (BUILT PRIOR TO 5/19/08) (FOR 2ND DES SEE 25999675)
15877453 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13, 14) (LINEN) (W/SPEAKER)
15936708 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13, 14) (LINEN) (W/O SPEAKER)
25815095 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13, 14) (GRANITE OPEL GRAY)
25818941 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13, 14) (CASHMERE)
25999674 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13, 14) (GRANITE) ( (W/O SPKR) (ORDER SPKR SEPARATE)) (BUILT 5/19/08 & AFTER) (FOR 1ST DES SEE 15863081)
25999675 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13, 14) (CASHMERE) ( (W/O SPKR) (ORDER SPKR SEPARATE)) (BUILT 5/19/08 & AFTER) (FOR 1ST DES SEE 15863082)
(TC16-387) - 2008-2009 CK1,2(06-36) СИДЕНЬЕ ВОДИТЕЛЯ/BUCKET (AN3, EXC VENTED/HEATED HNE,KB6)
25865177 SEAT, DRVR (EBONY)
25865474 SEAT, DRVR (EBONY)
25865475 SEAT, DRVR (CASHMERE)
25907678 SEAT, DRVR (CASHMERE)
15865481 RESTRAINT, D/SEAT HD (INCLS 2) (EBONY)
15865482 RESTRAINT, D/SEAT HD (INCLS 2) (CASHMERE)
15865483 RESTRAINT, D/SEAT HD (INCLS 2) (TITANIUM)
15827115 COVER, D/SEAT BK CUSH (EBONY)
15827116 COVER, D/SEAT BK CUSH (CASHMERE)
15865828 COVER, D/SEAT BK CUSH (EBONY)
teamcadillac.ru
15865829 COVER, D/SEAT BK CUSH (CASHMERE)
15865830 COVER, D/SEAT BK CUSH (TITANIUM)
15923998 COVER, D/SEAT BK CUSH (EBONY)
25899517 COVER, D/SEAT BK CUSH (EBONY)
25907742 COVER, D/SEAT BK CUSH (CASHMERE)
15243902 PAD, D/SEAT BK CUSH
25808717 FRAME, D/SEAT BK CUSH (INCLS 9, 15, 16, 43-45) (INCLS LUMBAR SUPPORT, RECLINER, SENSOR & MOTOR)
15232706 PANEL, D/SEAT BK CUSH FIN (EBONY)
15933726 PANEL, D/SEAT BK CUSH FIN (INCLS MAP POCKET) (EBONY) (WHEN REPL TRIM WRAP PANELS, REPLACE BOTH DRVR & PASS PANELS)
15933727 PANEL, D/SEAT BK CUSH FIN (CASHMERE) (WHEN REPL.TRIM WRAP PANELS; REPLACE BOTH DR & PASS PANELS)
15933728 PANEL, D/SEAT BK CUSH FIN (TITANIUM) (WHEN REPL.TRIM WRAP PANELS; REPLACE BOTH DR & PASS PANELS)
20860379 PANEL, D/SEAT BK CUSH FIN (TITANIUM)
20860380 PANEL, D/SEAT BK CUSH FIN (CASHMERE)
20860381 PANEL, D/SEAT BK CUSH FIN (EBONY)
15243904 PAD, D/SEAT CUSH
15827129 COVER, F/SEAT RSR FIN (INCLS 14) (EBONY) (RIGHT & LEFT TOE KICK)
15827130 COVER, F/SEAT RSR FIN (INCLS 14) (CASHMERE) (RIGHT & LEFT TOE KICK)
15827131 COVER, F/SEAT RSR FIN (INCLS 14) (TITANIUM) (RIGHT & LEFT TOE KICK)
11515764 БОЛТ, HFH, M10X1.5X20, 18THD, 22.3 O.D., 10.9, 7114M (D/SEAT RECL)
12451497 SWITCH, D/SEAT ADJR & RECL (8-WAY) (11.558) [ВКЛЮЧАТЕЛЬ]
25802502 SWITCH, D/SEAT LUMBAR CONT (EBONY)
25802504 SWITCH, D/SEAT LUMBAR CONT (CASHMERE)
25802505 SWITCH, D/SEAT LUMBAR CONT (TITANIUM)
15232562 COVER, D/SEAT ADJR FIN (INCLS 18) (EBONY) (8 WAY POWER)
15232563 COVER, D/SEAT ADJR FIN (INCLS 18) (CASHMERE) (8 WAY POWER)
15232564 COVER, D/SEAT ADJR FIN (INCLS 18) (TITANIUM) (8 WAY POWER)
10325879 KNOB, D/SEAT ADJR SW (EBONY) (11.558)
15222980 KNOB, D/SEAT ADJR SW (CASHMERE) (11.558)
15222981 KNOB, D/SEAT ADJR SW (TITANIUM) (11.558)
15232584 COVER, D/SEAT OTR ADJR TRK RR FIN (EBONY) (OUTBOARD)
15232585 COVER, D/SEAT OTR ADJR TRK RR FIN (CASHMERE) (OUTBOARD)
15232586 COVER, D/SEAT OTR ADJR TRK RR FIN (TITANIUM) (OUTBOARD)
11609539 SCREW, RD CROWNED WA HD, M4.2X1.41X16, STL ISO 2702, GMW4205 (D/SEAT ADJR FIN CVR) [ВИНТ]
11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (D/SEAT CUSH OTR FIN PNL)
15845152 BRACKET, D/SEAT BELT (RETR SI) (O/B)
11517996 ГАЙКА, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (D/SEAT ADJR TOP PLT) (ACDelco #11517996) [ГАЙКА М10]
15243864 COVER, D/SEAT OTR ADJR TRK RR FIN (EBONY) (INBOARD)
15243865 COVER, D/SEAT OTR ADJR TRK RR FIN (CASHMERE) (INBOARD)
15827134 BRACKET, D/SEAT FRT (MAIN BODY HARNESS CONNECTION) (16.686)
15243850 COVER, D/SEAT INR ADJR TRK FRT FIN (EBONY)
15243851 COVER, D/SEAT INR ADJR TRK FRT FIN (CASHMERE)
15243852 COVER, D/SEAT INR ADJR TRK FRT FIN (TITANIUM)
25865101 HARNESS, D/SEAT WRG
15780680 SENSOR, INFL RST D/SEAT POSITION [ДАТЧИК ПОДУШКИ БЕЗОПАСНОСТИ]
15845153 BRACKET, D/SEAT BELT (BKL SI) (I/B)
25966538 ADJUSTER, D/SEAT
25966540 ADJUSTER, D/SEAT
11516075 ГАЙКА, HFH SELF LK, M6X1, 7.7THK, 14.2 O.D., 9, PZOR (D/SEAT ADJR MEMORY SW) [ГАЙКА ВЫПУСКНОЙ СИСТЕМЫ D=6ММ]
25855629 MODULE, D/SEAT ADJR MEMORY (REQUIRES DEALER PROGRAMMING) (LABELED 25855629) [МОДУЛЬ]
25855630 MODULE, D/SEAT ADJR MEMORY (REQUIRES DEALER PROGRAMMING) (LABELED 25855630) (11.558) [ПРОГРАММИРУЕМЫЙ КОНТРОЛЛЕР РЕГУЛИРОВКИ ПОЛОЖЕНИЯ СИДЕНЬЯ]
11517996 ГАЙКА, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (D/SEAT BELT (BKL SI)) (ACDelco #11517996) [ГАЙКА М10]
15854391 FRAME, D/SEAT CUSH
15827136 BRACKET, D/SEAT RECL (I/B)
15243823 COVER, D/SEAT INR RECL FIN (INCLS 18) (EBONY)
15243824 COVER, D/SEAT INR RECL FIN (INCLS 18) (CASHMERE)
15243825 COVER, D/SEAT INR RECL FIN (INCLS 18) (TITANIUM)
15855909 PROTECTOR, D/SEAT RECL FIN CVR (EBONY)
15855911 PROTECTOR, D/SEAT RECL FIN CVR (EBONY)
15232559 HEATER, D/SEAT CUSH [ПОДОГРЕВ СИДЕНИЯ 45 ВТ]
15827121 COVER, D/SEAT CUSH (EBONY)
15827122 COVER, D/SEAT CUSH (CASHMERE)
15924001 COVER, D/SEAT CUSH (EBONY)
20779849 COVER, D/SEAT CUSH (EBONY) (CARPET INBOARD SIDE FACING)
20779850 COVER, D/SEAT CUSH (CASHMERE) (CARPET INBOARD SIDE FACING)
20779851 COVER, D/SEAT CUSH (TITANIUM) (CARPET INBOARD SIDE FACING)
20779853 COVER, D/SEAT CUSH (EBONY) (CARPET INBOARD SIDE FACING)
25899505 COVER, D/SEAT CUSH (EBONY)
25907744 COVER, D/SEAT CUSH (CASHMERE)
25911156 HEATER, D/SEAT BK CUSH (HEAT ONLY)
(TC16-390) - 2007-2009 CK107(06) ЗАДНЕЕ СИДЕНЬЕ/BUCKET-RH (BUCKET AL4)
15842716 SEAT, RR (INCLS 2-48) (EBONY)
15842722 SEAT, RR (INCLS 2-48) (EBONY)
15843784 SEAT, RR (INCLS 2-48) (EBONY)
15843785 SEAT, RR (INCLS 2-48) (CASHMERE)
15843790 SEAT, RR (INCLS 2-48) (EBONY)
15843914 SEAT, RR (INCLS 2-48) (EBONY)
15843935 SEAT, RR (INCLS 2-48) (EBONY)
15843936 SEAT, RR (INCLS 2-48) (CASHMERE)
25907988 SEAT, RR (INCLS 2-48) (CASHMERE)
25907990 SEAT, RR (INCLS 2-48) (CASHMERE)
25907993 SEAT, RR (INCLS 2-48) (CASHMERE)
25907997 SEAT, RR (INCLS 2-48) (CASHMERE)
25942794 SEAT, RR (INCLS 2-48) (COCOA)
25949035 SEAT, RR (INCLS 2-48) (COCOA)
15865722 COVER, R/SEAT BK CUSH (EBONY)
15865723 COVER, R/SEAT BK CUSH (CASHMERE)
15865724 COVER, R/SEAT BK CUSH (TITANIUM)
25858418 COVER, R/SEAT BK CUSH (COCOA)
25899570 COVER, R/SEAT BK CUSH (EBONY)
25908028 COVER, R/SEAT BK CUSH (CASHMERE)
25928769 COVER, R/SEAT BK CUSH (EBONY)
25928770 COVER, R/SEAT BK CUSH (CASHMERE)
15291602 PAD, R/SEAT BK CUSH
15824668 RESTRAINT, R/SEAT HD (INCLS 4) (EBONY)
15824669 RESTRAINT, R/SEAT HD (INCLS 4) (CASHMERE)
15824670 RESTRAINT, R/SEAT HD (INCLS 4) (TITANIUM)
15824672 RESTRAINT, R/SEAT HD (INCLS 4) (EBONY)
15824676 RESTRAINT, R/SEAT HD (INCLS 4) (EBONY)
25858321 RESTRAINT, R/SEAT HD (INCLS 4) (COCOA)
25928791 RESTRAINT, R/SEAT HD (INCLS 4) (CASHMERE)
15269769 FRAME, R/SEAT BK CUSH
15279689 CAP, R/SEAT ACTR FIN CVR BOLT (EBONY) [ЗАГЛУШКА ФИКСАТОРА ПОДЛОКОТНИКА]
15279690 CAP, R/SEAT ACTR FIN CVR BOLT (CASHMERE) [ЗАГЛУШКА ФИКСАТОРА ПОДЛОКОТНИКА]
15279691 CAP, R/SEAT ACTR FIN CVR BOLT (TITANIUM) [ЗАГЛУШКА ПОДЛОКОТНИКА СИДЕНЬЯ]
11570119 ГАЙКА, R/SEAT A/RST (T/W 11570115 STUD)
15275877 ARMREST, R/SEAT (EBONY)
15275878 ARMREST, R/SEAT (CASHMERE)
15865501 ARMREST, R/SEAT (EBONY)
15865502 ARMREST, R/SEAT (CASHMERE)
15865503 ARMREST, R/SEAT (TITANIUM)
25858416 ARMREST, R/SEAT (COCOA)
11570115 STUD, R/SEAT A/RST (T/W 11570119 NUT)
15291604 PAD, R/SEAT CUSH
15269765 FRAME, R/SEAT CUSH
15280113 COVER, R/SEAT RECL INR FIN (EBONY) (INNER)
15280114 COVER, R/SEAT RECL INR FIN (CASHMERE) (INNER)
15280115 COVER, R/SEAT RECL INR FIN (TITANIUM) (INNER)
15280116 COVER, R/SEAT RECL INR FIN (CASHMERE) (INNER)
15279719 COVER, R/SEAT RECL INR FIN (INCLS 41) (EBONY) (OUTER)
15279720 COVER, R/SEAT RECL INR FIN (INCLS 41) (CASHMERE) (OUTER)
15279721 COVER, R/SEAT RECL INR FIN (INCLS 41) (TITANIUM) (OUTER)
15279722 COVER, R/SEAT RECL INR FIN (INCLS 41) (CASHMERE) (OUTER)
19121593 BELT KIT, R/SEAT (BKL SI) (EBONY) [ЗАЩЕЛКА РЕМНЯ БЕЗОПАСНОСТИ]
19121595 BELT KIT, R/SEAT (BKL SI) (CASHMERE)
19121596 BELT KIT, R/SEAT (BKL SI) (TITANIUM)
19180585 BELT KIT, R/SEAT (BKL SI) (COCOA)
25896462 RECLINER, R/SEAT INR (WHEN SERVICING VEHICLES BUILT PRIOR TO 06/01/06, DEALER NEEDS TO REPLACE BOTH INNER & OUTER IN SETS)
15275888 LATCH, R/SEAT RSR (INNER & OUTER)
15275901 ПРУЖИНА, R/SEAT RECL (TUMBLE)
15275903 ПРУЖИНА, R/SEAT RECL (MANDREL)
15275905 STRUT, R/SEAT
15280123 PANEL, R/SEAT CUSH TR (EBONY) (16.716)
15280124 PANEL, R/SEAT CUSH TR (CASHMERE) (16.716)
15280125 PANEL, R/SEAT CUSH TR (TITANIUM) (16.716)
15279609 COVER, R/SEAT RSR FIN (EBONY) (REAR)
15279610 COVER, R/SEAT RSR FIN (CASHMERE) (REAR)
15279611 COVER, R/SEAT RSR FIN (TITANIUM) (REAR)
15279612 COVER, R/SEAT RSR FIN (CASHMERE) (REAR)
15269772 RISER, R/SEAT
11562379 БОЛТ, R/SEAT HGE (M10X1.5X92)
15279599 COVER, R/SEAT RSR FIN (INCLS 34) (EBONY) (FRONT)
15279600 COVER, R/SEAT RSR FIN (INCLS 34) (CASHMERE) (FRONT)
15279601 COVER, R/SEAT RSR FIN (INCLS 34) (TITANIUM) (FRONT)
15279602 COVER, R/SEAT RSR FIN (INCLS 34) (CASHMERE) (FRONT)
15843764 HARNESS, R/SEAT HTR
15843765 HARNESS, R/SEAT HTR
15275913 CABLE, R/SEAT BK CUSH LAT
15275915 CABLE, R/SEAT LAT (INBOARD) (SYNCH)
15275914 CABLE, R/SEAT LAT (OUTBOARD) (FLOOR LATCH)
25896460 RECLINER, R/SEAT OTR (WHEN SERVICING VEHICLES BUILT PRIOR TO 06/01/06, DEALER NEEDS TO REPLACE BOTH INNER & OUTER IN SETS)
15279419 HANDLE, R/SEAT RECL (INCLS 42) (EBONY)
15279420 HANDLE, R/SEAT RECL (INCLS 42) (CASHMERE)
15279429 HANDLE, R/SEAT RECL (INCLS 42) (TITANIUM)
15279699 COVER, R/SEAT RECL OTR FIN (INCLS 41) (EBONY) (OUTER)
15279700 COVER, R/SEAT RECL OTR FIN (INCLS 41) (CASHMERE) (OUTER)
15279701 COVER, R/SEAT RECL OTR FIN (INCLS 41) (TITANIUM) (OUTER)
15279702 COVER, R/SEAT RECL OTR FIN (INCLS 41) (CASHMERE) (OUTER)
15279709 COVER, R/SEAT RECL OTR FIN (EBONY) (INNER)
15279710 COVER, R/SEAT RECL OTR FIN (CASHMERE) (INNER)
15279711 COVER, R/SEAT RECL OTR FIN (TITANIUM) (INNER)
15279712 COVER, R/SEAT RECL OTR FIN (CASHMERE) (INNER)
15865730 COVER, R/SEAT CUSH (EBONY)
teamcadillac.ru
15865731 COVER, R/SEAT CUSH (CASHMERE)
15865732 COVER, R/SEAT CUSH (TITANIUM)
15939156 COVER, R/SEAT CUSH (EBONY/TITANIUM)
15939157 COVER, R/SEAT CUSH (EBONY/MOROCCO)
25858420 COVER, R/SEAT CUSH (COCOA)
25899558 COVER, R/SEAT CUSH (EBONY)
25908029 COVER, R/SEAT CUSH (CASHMERE)
25928781 COVER, R/SEAT CUSH (EBONY)
25928782 COVER, R/SEAT CUSH (CASHMERE)
25931449 COVER, R/SEAT CUSH (TITANIUM)
15824750 ACTUATOR, R/SEAT RECL (INCLS CABLE)
(TC16-391) - 2008-2009 CK107(06) ЗАДНЕЕ СИДЕНЬЕ/BENCH-40% SIDE (AM8, EXC POWER FOLDING ARS, HYBRID HP2)
15824545 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
15824546 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (CASHMERE)
15843772 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
15843802 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
15914187 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
25908002 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (CASHMERE)
25908010 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (CASHMERE)
25970963 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
25970964 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (CASHMERE)
25970965 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (TITANIUM)
15291651 COVER, R/SEAT BK CUSH (EBONY)
15291652 COVER, R/SEAT BK CUSH (CASHMERE)
15865510 COVER, R/SEAT BK CUSH (CASHMERE)
15865525 COVER, R/SEAT BK CUSH (EBONY)
15865526 COVER, R/SEAT BK CUSH (CASHMERE)
15865527 COVER, R/SEAT BK CUSH (TITANIUM)
15914204 COVER, R/SEAT BK CUSH (EBONY)
20758111 COVER, R/SEAT BK CUSH (EBONY) (USED ON VEHICLES BUILT 12/01/08 & AFTER) (1ST DES SEE 25970991)
20758112 COVER, R/SEAT BK CUSH (CASHMERE) (USED ON VEHICLES BUILT 12/01/08 & AFTER) (1ST DES SEE 25970992)
20758113 COVER, R/SEAT BK CUSH (TITANIUM) (USED ON VEHICLES BUILT 12/01/08 & AFTER) (1ST DES SEE 25970993)
25863599 COVER, R/SEAT BK CUSH (TITANIUM)
25908033 COVER, R/SEAT BK CUSH (CASHMERE)
25931397 COVER, R/SEAT BK CUSH (CASHMERE)
25970991 COVER, R/SEAT BK CUSH (EBONY) (USED ON VEHICLES BUILT 11/30/08 & PRIOR) (2ND DES SEE 20758111)
25970992 COVER, R/SEAT BK CUSH (CASHMERE) (USED ON VEHICLES BUILT 11/30/08 & PRIOR) (2ND DES SEE 20758112)
25970993 COVER, R/SEAT BK CUSH (EBONY) (USED ON VEHICLES BUILT 11/30/08 & PRIOR) (2ND DES SEE 20758113)
15291598 PAD, R/SEAT BK CUSH
15865811 RESTRAINT, R/SEAT HD (INCLS 4) (TITANIUM) (USED ON VEHICLES BUILT 11/30/08 & PRIOR) (2ND DES SEE 20758015)
20758013 RESTRAINT, R/SEAT HD (INCLS 4) (EBONY) (USED ON VEHICLES BUILT 12/01/08 & AFTER) (1ST DES SEE 25863652)
20758014 RESTRAINT, R/SEAT HD (INCLS 4) (CASHMERE)
20758015 RESTRAINT, R/SEAT HD (INCLS 4) (TITANIUM) (USED ON VEHICLES BUILT 12/01/08 & AFTER) (1ST DES SEE 15865811)
25863652 RESTRAINT, R/SEAT HD (INCLS 4) (EBONY) (USED ON VEHICLES BUILT 11/30/08 & PRIOR) (2ND DES SEE 20758013)
15269763 FRAME, R/SEAT BK CUSH
15291600 PAD, R/SEAT CUSH
19121593 BELT KIT, R/SEAT (BKL SI) (SINGLE BKL) (EBONY) [ЗАЩЕЛКА РЕМНЯ БЕЗОПАСНОСТИ]
19121596 BELT KIT, R/SEAT (BKL SI) (SINGLE BKL) (TITANIUM)
15275888 LATCH, R/SEAT RSR (OUTBOARD)
15930099 STRUT, R/SEAT
15279554 PANEL, R/SEAT CUSH TR (EBONY) (16.716)
15279555 PANEL, R/SEAT CUSH TR (CASHMERE) (16.716)
15279556 PANEL, R/SEAT CUSH TR (TITANIUM) (16.716)
teamcadillac.ru
15279419 HANDLE, R/SEAT RECL (INCLS 38) (EBONY)
15279420 HANDLE, R/SEAT RECL (INCLS 38) (CASHMERE)
15279429 HANDLE, R/SEAT RECL (INCLS 38) (TITANIUM)
15291658 COVER, R/SEAT CUSH (CASHMERE)
15865518 COVER, R/SEAT CUSH (CASHMERE)
15865714 COVER, R/SEAT CUSH (EBONY)
15865715 COVER, R/SEAT CUSH (CASHMERE)
15865716 COVER, R/SEAT CUSH (TITANIUM)
15914208 COVER, R/SEAT CUSH (EBONY)
20758119 COVER, R/SEAT CUSH (EBONY) (USED ON VEHICLES BUILT 12/01/08 & AFTER) (1ST DES SEE 25970999)
20758120 COVER, R/SEAT CUSH (CASHMERE) (USED ON VEHICLES BUILT 12/01/08 & AFTER) (1ST DES SEE 25971000)
20758121 COVER, R/SEAT CUSH (TITANIUM) (USED ON VEHICLES BUILT 12/01/08 & AFTER) (1ST DES SEE 25971001)
25908034 COVER, R/SEAT CUSH (CASHMERE)
25931403 COVER, R/SEAT CUSH (CASHMERE)
25970999 COVER, R/SEAT CUSH (EBONY) (USED ON VEHICLES BUILT 11/30/08 & PRIOR) (2ND DES SEE 20758119)
25971000 COVER, R/SEAT CUSH (CASHMERE) (USED ON VEHICLES BUILT 11/30/08 & PRIOR) (2ND DES SEE 20758120)
25971001 COVER, R/SEAT CUSH (TITANIUM) (USED ON VEHICLES BUILT 11/30/08 & PRIOR) (2ND DES SEE 20758121)
(TC16-392) - 2008-2009 CK107(06) ЗАДНЕЕ СИДЕНЬЕ/BENCH-60% SIDE (AM8, EXC POWER FOLDING ARS, HYBRID HP2)
15914185 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
25835077 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
25835078 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (CASHMERE)
25835080 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
25835182 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
25908001 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (CASHMERE)
25908009 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (CASHMERE)
25970971 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
25970972 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (CASHMERE)
25970973 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (TITANIUM)
15291649 COVER, R/SEAT BK CUSH (CASHMERE)
15291660 COVER, R/SEAT BK CUSH (EBONY)
15939171 COVER, R/SEAT BK CUSH (EBONY/TITANIUM)
25928760 COVER, R/SEAT BK CUSH (EBONY)
15824668 RESTRAINT, R/SEAT HD (INCLS 8) (EBONY)
15824669 RESTRAINT, R/SEAT HD (INCLS 8) (CASHMERE)
15824670 RESTRAINT, R/SEAT HD (INCLS 8) (TITANIUM)
15824672 RESTRAINT, R/SEAT HD (INCLS 8) (EBONY)
15824676 RESTRAINT, R/SEAT HD (INCLS 8) (EBONY)
15865811 RESTRAINT, R/SEAT HD (INCLS 8) (TITANIUM) (USED ON VEHICLES BUILT 11/30/08 & PRIOR) (2ND DES SEE 20758015)
20758013 RESTRAINT, R/SEAT HD (INCLS 8) (EBONY) (USED ON VEHICLES BUILT 12/01/08 & AFTER) (1ST DES SEE 25863652)
20758014 RESTRAINT, R/SEAT HD (INCLS 8) (CASHMERE)
20758015 RESTRAINT, R/SEAT HD (INCLS 8) (TITANIUM) (USED ON VEHICLES BUILT 12/01/08 & AFTER) (1ST DES SEE 15865811)
25863652 RESTRAINT, R/SEAT HD (INCLS 8) (EBONY) (USED ON VEHICLES BUILT 11/30/08 & PRIOR) (2ND DES SEE 20758013)
25928791 RESTRAINT, R/SEAT HD (INCLS 8) (CASHMERE)
teamcadillac.ru
15279489 COVER, R/SEAT BK CUSH HGE FIN (EBONY) (OUTBOARD, INNER) (16.674)
15279490 COVER, R/SEAT BK CUSH HGE FIN (CASHMERE) (OUTBOARD, INNER) (16.674)
15279491 COVER, R/SEAT BK CUSH HGE FIN (TITANIUM) (OUTBOARD, INNER) (16.674)
19121589 BELT KIT, R/SEAT (BKL SI) (EBONY) (BKL/BKL)
19121591 BELT KIT, R/SEAT (BKL SI) (CASHMERE) (BKL/BKL)
19121592 BELT KIT, R/SEAT (BKL SI) (TITANIUM) (BKL/BKL)
15269764 FRAME, R/SEAT CUSH
15275886 LATCH, R/SEAT RSR
15279479 COVER, R/SEAT BK CUSH HGE FIN (INCLS 49) (EBONY) (OUTBOARD, OUTER) (16.674)
15279480 COVER, R/SEAT BK CUSH HGE FIN (INCLS 49) (CASHMERE) (OUTBOARD, OUTER) (16.674)
15279481 COVER, R/SEAT BK CUSH HGE FIN (INCLS 49) (TITANIUM) (OUTBOARD, OUTER) (16.674)
15279414 HANDLE, R/SEAT RECL (INCLS 23) (EBONY)
15279415 HANDLE, R/SEAT RECL (INCLS 23) (CASHMERE)
15279416 HANDLE, R/SEAT RECL (INCLS 23) (TITANIUM)
15275917 CABLE, R/SEAT LAT (INBOARD) (FLOOR LATCH)
15275916 CABLE, R/SEAT LAT (INBOARD) (SYNCH)
15275912 CABLE, R/SEAT BK CUSH LAT
15279604 COVER, R/SEAT RSR FIN (EBONY) (REAR)
15279605 COVER, R/SEAT RSR FIN (CASHMERE) (REAR)
15279606 COVER, R/SEAT RSR FIN (TITANIUM) (REAR)
15279607 COVER, R/SEAT RSR FIN (CASHMERE) (REAR)
15269771 RISER, R/SEAT
15824753 COVER, R/SEAT RSR FIN (INCLS 31) (EBONY) (FRONT)
15824754 COVER, R/SEAT RSR FIN (INCLS 31) (CASHMERE) (FRONT)
15824755 COVER, R/SEAT RSR FIN (INCLS 31) (TITANIUM) (FRONT)
15824756 COVER, R/SEAT RSR FIN (INCLS 31) (CASHMERE) (FRONT)
15291599 PAD, R/SEAT CUSH
11571092 БОЛТ, R/SEAT HGE (M10X1.5X114)
15279549 PANEL, R/SEAT CUSH TR (EBONY) (16.716)
15279550 PANEL, R/SEAT CUSH TR (CASHMERE) (16.716)
15279551 PANEL, R/SEAT CUSH TR (TITANIUM) (16.716)
15786704 MODULE, R/SEAT HTR CONT (REQUIRES DEALER PROGRAMMING) (11.500)
25862293 MODULE, R/SEAT HTR CONT (REQUIRES DEALER PROGRAMMING) (11.500) (SERV CMP OF HEATER PKGS)
25886638 MODULE, R/SEAT HTR CONT
15275900 ПРУЖИНА, R/SEAT RECL (TUMBLE)
15275902 ПРУЖИНА, R/SEAT RECL (MANDREL)
15279589 COVER, R/SEAT HGE LWR FIN (EBONY) (PIVOT INBOARD) (16.674)
15279590 COVER, R/SEAT HGE LWR FIN (CASHMERE) (PIVOT INBOARD) (16.674)
15279591 COVER, R/SEAT HGE LWR FIN (TITANIUM) (PIVOT INBOARD) (16.674)
15269777 BRACKET, R/SEAT
11562381 БОЛТ, R/SEAT BK CUSH LAT PIV (M12X1.75X40)
15279594 COVER, R/SEAT HGE LWR FIN (EBONY) (PIVOT INBOARD) (16.674)
15279595 COVER, R/SEAT HGE LWR FIN (CASHMERE) (PIVOT INBOARD) (16.674)
15279596 COVER, R/SEAT HGE LWR FIN (TITANIUM) (PIVOT INBOARD) (16.674)
15291655 COVER, R/SEAT CUSH (CASHMERE)
15865514 COVER, R/SEAT CUSH (CASHMERE)
15865529 COVER, R/SEAT CUSH (EBONY) [ЧЕХОЛ ПОДУШКИ СИДЕНЬЯ]
15865530 COVER, R/SEAT CUSH (CASHMERE)
15865531 COVER, R/SEAT CUSH (TITANIUM)
15914206 COVER, R/SEAT CUSH (EBONY)
20758115 COVER, R/SEAT CUSH (EBONY) (USED ON VEHICLES BUILT 12/01/08 & AFTER) (1ST DES SEE 25970995)
20758116 COVER, R/SEAT CUSH (CASHMERE) (USED ON VEHICLES BUILT 12/01/08 & AFTER) (1ST DES SEE 25970996)
20758117 COVER, R/SEAT CUSH (TITANIUM) (USED ON VEHICLES BUILT 12/01/08 & AFTER) (1ST DES SEE 25970997)
25863603 COVER, R/SEAT CUSH (TITANIUM)
25899567 COVER, R/SEAT CUSH (EBONY)
25908032 COVER, R/SEAT CUSH (CASHMERE)
25931390 COVER, R/SEAT CUSH (EBONY)
25970995 COVER, R/SEAT CUSH (EBONY) (USED ON VEHICLES BUILT 11/30/08 & PRIOR) (2ND DES SEE 20758115)
25970996 COVER, R/SEAT CUSH (CASHMERE) (USED ON VEHICLES BUILT 11/30/08 & PRIOR) (2ND DES SEE 20758116)
25970997 COVER, R/SEAT CUSH (TITANIUM) (USED ON VEHICLES BUILT 11/30/08 & PRIOR) (2ND DES SEE 20758117)
15279499 COVER, R/SEAT BK CUSH HGE FIN (INCLS 49) (EBONY) (INBOARD, OUTER) (16.674)
15279500 COVER, R/SEAT BK CUSH HGE FIN (INCLS 49) (CASHMERE) (INBOARD, OUTER) (16.674)
15279501 COVER, R/SEAT BK CUSH HGE FIN (INCLS 49) (TITANIUM) (INBOARD, OUTER) (16.674)
15279525 COVER, R/SEAT BK CUSH HGE FIN (EBONY) (INBOARD, INNER) (16.674)
15279526 COVER, R/SEAT BK CUSH HGE FIN (CASHMERE) (INBOARD, INNER) (16.674)
15279527 COVER, R/SEAT BK CUSH HGE FIN (TITANIUM) (INBOARD, INNER) (16.674)
25908030 ARMREST, R/SEAT (CASHMERE)
15275887 LATCH, R/SEAT RSR (INBOARD)
(TC16-393) - 2008-2009 CK107(06) ЗАДНЕЕ СИДЕНЬЕ/BENCH-40% SIDE (AM8, POWER FOLDING ARS, EXC HYBRID HP2)
15843841 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
15843842 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (CASHMERE)
15843847 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
15843859 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY) [СИДЕНЬЕ В СБОРЕ]
25908006 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (CASHMERE)
25908012 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (CASHMERE)
teamcadillac.ru
15279530 COVER, R/SEAT BK CUSH HGE FIN (EBONY) (INBOARD, INNER) (16.674)
15279531 COVER, R/SEAT BK CUSH HGE FIN (CASHMERE) (INBOARD, INNER) (16.674)
15279532 COVER, R/SEAT BK CUSH HGE FIN (TITANIUM) (INBOARD, INNER) (16.674)
15279533 COVER, R/SEAT BK CUSH HGE FIN (CASHMERE) (INBOARD, INNER) (16.674)
15279504 COVER, R/SEAT BK CUSH HGE FIN (INCLS 41) (EBONY) (INBOARD, OUTER) (16.674)
15279505 COVER, R/SEAT BK CUSH HGE FIN (INCLS 41) (CASHMERE) (INBOARD, OUTER) (16.674)
15279506 COVER, R/SEAT BK CUSH HGE FIN (INCLS 41) (TITANIUM) (INBOARD, OUTER)
15279599 COVER, R/SEAT RSR FIN (INCLS 29) (EBONY) (FRONT)
15279600 COVER, R/SEAT RSR FIN (INCLS 29) (CASHMERE) (FRONT)
15279601 COVER, R/SEAT RSR FIN (INCLS 29) (TITANIUM) (FRONT)
15279602 COVER, R/SEAT RSR FIN (INCLS 29) (CASHMERE) (FRONT)
15843763 HARNESS, ST RECL WRG (ELEMENT)
15942229 CABLE, R/SEAT BK CUSH LAT
25896457 LATCH, R/SEAT BK CUSH (OUTBOARD)
15279419 HANDLE, R/SEAT RECL (INCLS 39) (EBONY)
15279420 HANDLE, R/SEAT RECL (INCLS 39) (CASHMERE)
15279429 HANDLE, R/SEAT RECL (INCLS 39) (TITANIUM)
15279484 COVER, R/SEAT BK CUSH HGE FIN (INCLS 41) (EBONY) (OUTBOARD, OUTER) (16.674)
15279485 COVER, R/SEAT BK CUSH HGE FIN (INCLS 41) (CASHMERE) (OUTBOARD, OUTER) (16.674)
15279486 COVER, R/SEAT BK CUSH HGE FIN (INCLS 41) (TITANIUM) (OUTBOARD, OUTER) (16.674)
15279494 COVER, R/SEAT BK CUSH HGE FIN (EBONY) (OUTBOARD, INNER) (16.674)
15279495 COVER, R/SEAT BK CUSH HGE FIN (CASHMERE) (OUTBOARD, INNER) (16.674)
15279496 COVER, R/SEAT BK CUSH HGE FIN (TITANIUM) (OUTBOARD, INNER) (16.674)
(TC16-394) - 2008-2009 CK107(06) ЗАДНЕЕ СИДЕНЬЕ/BENCH-60% SIDE (AM8, POWER FOLDING ARS, EXC HYBRID HP2)
25835086 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
25835087 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (CASHMERE)
25835089 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
25835185 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (EBONY)
25908005 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (CASHMERE)
25908011 SEAT, RR (ONLY AVAILABLE DURING CURRENT MODEL YEAR) (CASHMERE)
15291597 PAD, R/SEAT BK CUSH
15914200 PAD, R/SEAT BK CUSH
11562382 БОЛТ, HFH, M10X1.5X130, 26 THD, 22.3 OD, 10.9, 7114M, MACH, MAT-PT (R/SEAT BK CUSH FRM)
15289969 BRACKET, R/SEAT CTR BELT (RETR SI)
15279450 PROTECTOR, R/SEAT SHLDR BELT (BLACK)
11570116 SCREW -PAN HD, M6X1X10, 10 THD, 12 OD, STL SAE J1237, S424, TAPTITE ITE (R/SEAT LAT FIN CVR) (8.913)
11562383 БОЛТ, HFH, M12X1.75X30.5, 17 THD, 26.6 OD, 10.9 STL, GMW3359, W/ADH 6175M (R/SEAT LAT)
15279347 GUIDE, R/SEAT H/RST (EBONY) (W/BUTTON)
15279348 GUIDE, R/SEAT H/RST (CASHMERE) (W/BUTTON)
15279349 GUIDE, R/SEAT H/RST (TITANIUM) (W/BUTTON)
15279351 GUIDE, R/SEAT H/RST (EBONY) (W/O BUTTON)
15279352 GUIDE, R/SEAT H/RST (CASHMERE) (W/O BUTTON)
15279353 GUIDE, R/SEAT H/RST (TITANIUM) (W/O BUTTON)
11562378 BOLT-HFH, M10X1.5X30, 18 THD, 22.3 OD, 10.9, GMW3359, W/ADH GM6175M (R/SEAT LAT)
25896455 LATCH, R/SEAT BK CUSH (OUTBOARD)
teamcadillac.ru
15942228 CABLE, R/SEAT BK CUSH LAT
25896456 LATCH, R/SEAT BK CUSH (INBOARD)
15824751 ACTUATOR, R/SEAT RECL (INCLS CABLE) [ЭЛЕКТРОДВИГАТЕЛЬ РЕГУЛИРОВКИ ПОЛОЖЕНИЯ СИДЕНЬЯ 90 ВТ]
(TC16-395) - 2007-2009 CK107(06) ЗАДНЕЕ СИДЕНЬЕ/BUCKET-LH (BUCKET AL4)
25834162 SEAT, RR (INCLS 2-49) (EBONY)
25834165 SEAT, RR (INCLS 2-49) (EBONY)
25834412 SEAT, RR (INCLS 2-49) (EBONY)
25834413 SEAT, RR (INCLS 2-49) (CASHMERE)
25834415 SEAT, RR (INCLS 2-49) (EBONY)
25834424 SEAT, RR (INCLS 2-49) (EBONY)
25834430 SEAT, RR (INCLS 2-49) (EBONY)
25834431 SEAT, RR (INCLS 2-49) (CASHMERE)
25907987 SEAT, RR (INCLS 2-49) (CASHMERE)
25907989 SEAT, RR (INCLS 2-49) (CASHMERE)
25907992 SEAT, RR (INCLS 2-49) (CASHMERE)
25907996 SEAT, RR (INCLS 2-49) (CASHMERE)
25942792 SEAT, RR (INCLS 2-49) (COCOA)
25949033 SEAT, RR (INCLS 2-49) (COCOA)
15865718 COVER, R/SEAT BK CUSH (EBONY)
15865719 COVER, R/SEAT BK CUSH (CASHMERE)
15865720 COVER, R/SEAT BK CUSH (TITANIUM)
25858326 COVER, R/SEAT BK CUSH (COCOA)
25899573 COVER, R/SEAT BK CUSH (EBONY)
25908024 COVER, R/SEAT BK CUSH (CASHMERE)
25928766 COVER, R/SEAT BK CUSH (EBONY)
25928767 COVER, R/SEAT BK CUSH (CASHMERE)
15291601 PAD, R/SEAT BK CUSH
25851750 GUIDE, R/SEAT H/RST (COCOA) (W/BUTTON)
25851751 GUIDE, R/SEAT H/RST (COCOA) (W/O BUTTON)
15269768 FRAME, R/SEAT BK CUSH
25858335 CAP, R/SEAT ACTR FIN CVR BOLT (COCOA)
15275870 ARMREST, R/SEAT (EBONY)
15825652 ARMREST, R/SEAT (CASHMERE)
15865497 ARMREST, R/SEAT (EBONY)
teamcadillac.ru
15865498 ARMREST, R/SEAT (CASHMERE)
15865499 ARMREST, R/SEAT (TITANIUM)
25858323 ARMREST, R/SEAT (COCOA)
15291603 PAD, R/SEAT CUSH
15269770 FRAME, R/SEAT CUSH
11562384 ГАЙКА, HFH, M4X.7 THD, 4.75 THK, 10.5 OD, GM510M (9)STL, GM4435M-CODE A (R/SEAT FLR FIL T/PNL)
15280108 COVER, R/SEAT RECL INR FIN (EBONY) (INNER)
15280109 COVER, R/SEAT RECL INR FIN (CASHMERE) (INNER)
15280110 COVER, R/SEAT RECL INR FIN (TITANIUM) (INNER)
25858339 COVER, R/SEAT RECL INR FIN (COCOA) (INNER)
15279464 KNOB, R/SEAT LAT (EBONY) (USED IN PLACE OF ALL COLORS) (16.716)
15279714 COVER, R/SEAT RECL INR FIN (INCLS 42) (EBONY) (OUTER)
15279715 COVER, R/SEAT RECL INR FIN (INCLS 42) (CASHMERE) (OUTER)
15279716 COVER, R/SEAT RECL INR FIN (INCLS 42) (TITANIUM) (OUTER)
19121601 BELT KIT, R/SEAT (BKL SI) (EBONY)
19121603 BELT KIT, R/SEAT (BKL SI) (CASHMERE)
19121604 BELT KIT, R/SEAT (BKL SI) (TITANIUM)
19180586 BELT KIT, R/SEAT (BKL SI) (COCOA)
25896461 RECLINER, R/SEAT INR (WHEN SERVICING VEHICLES BUILT PRIOR TO 06/01/06, DEALER NEEDS TO REPLACE BOTH INNER & OUTER IN SETS)
11562380 BUSHING, R/SEAT HGE
15280118 PANEL, R/SEAT CUSH TR (EBONY) (16.716)
15280119 PANEL, R/SEAT CUSH TR (CASHMERE) (16.716)
15280120 PANEL, R/SEAT CUSH TR (TITANIUM) (16.716)
25858340 PANEL, R/SEAT CUSH TR (COCOA)
15280128 COVER, R/SEAT RSR FIN (EBONY) (REAR)
15280129 COVER, R/SEAT RSR FIN (CASHMERE) (REAR)
15280130 COVER, R/SEAT RSR FIN (TITANIUM) (REAR)
25858341 COVER, R/SEAT RSR FIN (COCOA) (REAR)
15269775 RISER, R/SEAT
15279599 COVER, R/SEAT RSR FIN (INCLS 33) (EBONY) (FRONT)
15279600 COVER, R/SEAT RSR FIN (INCLS 33) (CASHMERE) (FRONT)
15279601 COVER, R/SEAT RSR FIN (INCLS 33) (TITANIUM) (FRONT)
15279406 PIN, R/SEAT H/RST ADJ ROD LAT (EBONY)
15279407 PIN, R/SEAT H/RST ADJ ROD LAT (CASHMERE)
15279408 PIN, R/SEAT H/RST ADJ ROD LAT (TITANIUM)
25858342 PIN, R/SEAT H/RST ADJ ROD LAT (COCOA)
25896459 RECLINER, R/SEAT OTR (WHEN SERVICING VEHICLES BUILT PRIOR TO 06/01/06, DEALER NEEDS TO REPLACE BOTH INNER & OUTER IN SETS)
15279414 HANDLE, R/SEAT RECL (INCLS 43) (EBONY)
15279415 HANDLE, R/SEAT RECL (INCLS 43) (CASHMERE)
15279416 HANDLE, R/SEAT RECL (INCLS 43) (TITANIUM)
15279694 COVER, R/SEAT RECL OTR FIN (INCLS 42) (EBONY) (OUTER)
15279695 COVER, R/SEAT RECL OTR FIN (INCLS 42) (CASHMERE) (OUTER)
15279696 COVER, R/SEAT RECL OTR FIN (INCLS 42) (TITANIUM) (OUTER)
15279697 COVER, R/SEAT RECL OTR FIN (INCLS 42) (CASHMERE) (OUTER) [КОЖУХ МЕХАНИЗМА РЕГУЛИРОВКИ ПОЛОЖЕНИЯ СИДЕНИЯ]
25858336 COVER, R/SEAT RECL OTR FIN (INCLS 42) (COCOA) (OUTER)
15279704 COVER, R/SEAT RECL OTR FIN (EBONY) (INNER)
15279705 COVER, R/SEAT RECL OTR FIN (CASHMERE) (INNER)
15279706 COVER, R/SEAT RECL OTR FIN (TITANIUM) (INNER)
25858337 COVER, R/SEAT RECL OTR FIN (COCOA) (INNER)
15865726 COVER, R/SEAT CUSH (EBONY)
15865727 COVER, R/SEAT CUSH (CASHMERE)
15865728 COVER, R/SEAT CUSH (TITANIUM)
15939155 COVER, R/SEAT CUSH (EBONY/MOROCCO)
25858328 COVER, R/SEAT CUSH (COCOA)
25899561 COVER, R/SEAT CUSH (EBONY)
25908025 COVER, R/SEAT CUSH (CASHMERE)
25928778 COVER, R/SEAT CUSH (EBONY)
25928779 COVER, R/SEAT CUSH (CASHMERE)
15275906 ACTUATOR, R/SEAT RECL (INCLS CABLE)
(TC16-399) - 2007-2009 CK1,2(06) ЗАДНЕЕ СИДЕНЬЕ #2-LH(AS3)
15898172 SEAT, RR #2 (INCLS 2-42) (TITANIUM) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
15898179 SEAT, RR #2 (INCLS 2-42) (CASHMERE) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
20858956 SEAT, RR #2 (INCLS 2-42) (EBONY) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
20859114 SEAT, RR #2 (INCLS 2-42) (CASHMERE)
25782021 SEAT, RR #2 (INCLS 2-42) (EBONY) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
25869767 SEAT, RR #2 (INCLS 2-42) (EBONY) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
25869768 SEAT, RR #2 (INCLS 2-42) (CASHMERE) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
25917050 SEAT, RR #2 (INCLS 2-42) (TITANIUM)
25917112 SEAT, RR #2 (INCLS 2-42) (EBONY)
25917113 SEAT, RR #2 (INCLS 2-42) (CASHMERE)
25917130 SEAT, RR #2 (INCLS 2-42) (EBONY) (VIN 7R170870/7J141620 & PRIOR MUST REPLACE IN SETS)
25917174 SEAT, RR #2 (INCLS 2-42) (COCOA)
25943584 SEAT, RR #2 (INCLS 2-42) (COCOA)
25949071 SEAT, RR #2 (INCLS 2-42) (COCOA)
25950380 SEAT, RR #2 (INCLS 2-42) (EBONY)
25950388 SEAT, RR #2 (INCLS 2-42) (CASHMERE)
25950442 SEAT, RR #2 (INCLS 2-42) (CASHMERE)
25950893 SEAT, RR #2 (INCLS 2-42) (EBONY)
25971017 SEAT, RR #2 (INCLS 2-42) (EBONY)
25971018 SEAT, RR #2 (INCLS 2-42) (CASHMERE)
25971019 SEAT, RR #2 (INCLS 2-42) (TITANIUM)
25971038 SEAT, RR #2 (INCLS 2-42) (EBONY)
25971039 SEAT, RR #2 (INCLS 2-42) (CASHMERE)
25971040 SEAT, RR #2 (INCLS 2-42) (TITANIUM)
15804530 PAD, R/SEAT #2 BK CUSH
15827635 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE) (USED ON VEHICLES BUILT 11/30/08 & PRIOR) (2ND DES SEE 20757998)
15827636 RESTRAINT, R/SEAT HD (INCLS 3) (TITANIUM) (USED ON VEHICLES BUILT 11/30/08 & PRIOR) (2ND DES SEE 20757999)
15827642 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
15833505 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
15833506 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE)
15863451 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
15863452 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE)
15863458 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
15863459 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE)
15865842 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
20757997 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY) (USED ON VEHICLES BUILT 12/01/08 & AFTER) (1ST DES SEE 25863504)
20757998 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE) (USED ON VEHICLES BUILT 12/01/08 & AFTER) (1ST DES SEE 15827635)
20757999 RESTRAINT, R/SEAT HD (INCLS 3) (TITANIUM) (USED ON VEHICLES BUILT 12/01/08 & AFTER) (1ST DES SEE 15827636)
20758001 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
20758002 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE)
20758003 RESTRAINT, R/SEAT HD (INCLS 3) (TITANIUM)
25863504 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY) (USED ON VEHICLES BUILT 11/30/08 & PRIOR) (2ND DES SEE 20757997)
15279347 GUIDE, R/SEAT #2 H/RST (EBONY) (W/BUTTON)
15279348 GUIDE, R/SEAT #2 H/RST (CASHMERE) (W/BUTTON)
15279349 GUIDE, R/SEAT #2 H/RST (TITANIUM) (W/BUTTON)
15279351 GUIDE, R/SEAT #2 H/RST (EBONY) (W/O BUTTON)
15279352 GUIDE, R/SEAT #2 H/RST (CASHMERE) (W/O BUTTON)
15279353 GUIDE, R/SEAT #2 H/RST (TITANIUM) (W/O BUTTON)
25851750 GUIDE, R/SEAT #2 H/RST (COCOA) (W/BUTTON)
25851751 GUIDE, R/SEAT #2 H/RST (COCOA) (W/O BUTTON)
25943771 GUIDE, R/SEAT #2 H/RST (COCOA)
25869335 BRACKET, R/SEAT #2 BELT (RETR SI)
11562382 БОЛТ, HFH, M10X1.5X130, 26 THD, 22.3 OD, 10.9, 7114M, MACH, MAT-PT (R/SEAT #2 BK CUSH)
11562383 БОЛТ, R/SEAT #2 BELT (RETR SI) (8.900)
19207594 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (EBONY)
19207595 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (CASHMERE)
19207596 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (TITANIUM)
19207598 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (COCOA)
25869317 BELT, R/SEAT #2 (RETR SI) (INCLS 8) (EBONY)
15827657 COVER, R/SEAT HGE FIN (O/B)
12478382 БОЛТ, R/SEAT #2 (M10X1.50X28.0) [БОЛТ]
15279464 KNOB, R/SEAT #2 BK CUSH LAT REL (EBONY) (USED IN PLACE OF ALL COLORS) (16.716)
15898412 COVER, R/SEAT #2 BK CUSH LAT (EBONY) (OUTBOARD, OUTER) (16.716) [БОКОВАЯ КРЫШКА СИДЕНИЯ]
19127809 БОЛТ, R/SEAT #2 BK CUSH LAT (M12X1.75X63.9) (16.679)
15822356 HANDLE, R/SEAT LAT REL (PART OF 26) (EBONY)
15822357 HANDLE, R/SEAT LAT REL (PART OF 26) (CASHMERE)
15822358 HANDLE, R/SEAT LAT REL (PART OF 26) (TITANIUM)
25928520 LATCH, R/SEAT #2 BK CUSH (SIDE)
15898401 LATCH, R/SEAT #2 LOAD FLR
15791115 FRAME, R/SEAT #2 CUSH
15822392 COVER, R/SEAT #2 BK CUSH HGE FIN (CASHMERE) (INBOARD, OUTER)
15832214 LEVER, R/SEAT RSR LAT REL
teamcadillac.ru
15833812 RETAINER, R/SEAT CUSH FRM
15898363 FRAME, R/SEAT #2 BK CUSH
15898400 FRAME, R/SEAT #2 BK CUSH
25960398 FRAME, R/SEAT #2 BK CUSH
19152518 BELT KIT, R/SEAT #2 (BKL SI) (EBONY) (BKL/BKL)
19152519 BELT KIT, R/SEAT #2 (BKL SI) (CASHMERE) (BKL/BKL)
19152520 BELT KIT, R/SEAT #2 (BKL SI) (TITANIUM) (BKL/BKL)
19180589 BELT KIT, R/SEAT #2 (BKL SI) (COCOA)
15804534 PAD, R/SEAT #2 CUSH
15865758 COVER, R/SEAT #2 CUSH (EBONY)
15865759 COVER, R/SEAT #2 CUSH (CASHMERE)
15865760 COVER, R/SEAT #2 CUSH (TITANIUM)
15865801 COVER, R/SEAT #2 CUSH (EBONY)
15865802 COVER, R/SEAT #2 CUSH (CASHMERE)
15865803 COVER, R/SEAT #2 CUSH (TITANIUM)
15925482 COVER, R/SEAT #2 CUSH (EBONY/MOROCCO)
15925510 COVER, R/SEAT #2 CUSH (EBONY/TITANIUM)
20758147 COVER, R/SEAT #2 CUSH (EBONY)
20758148 COVER, R/SEAT #2 CUSH (CASHMERE)
20758149 COVER, R/SEAT #2 CUSH (TITANIUM) (USED ON VEHICLES BUILT 12/01/08 & AFTER) (1ST DES SEE 25971080)
20859435 COVER, R/SEAT #2 CUSH (CASHMERE)
25858728 COVER, R/SEAT #2 CUSH (LINEN/COCOA)
25928513 COVER, R/SEAT #2 CUSH (EBONY)
25937613 COVER, R/SEAT #2 CUSH (EBONY)
25937614 COVER, R/SEAT #2 CUSH (CASHMERE)
25937615 COVER, R/SEAT #2 CUSH (TITANIUM)
25971080 COVER, R/SEAT #2 CUSH (TITANIUM) (USED ON VEHICLES BUILT 11/30/08 & PRIOR) (2ND DES SEE 20758149)
15865750 COVER, R/SEAT #2 BK CUSH (EBONY)
15865751 COVER, R/SEAT #2 BK CUSH (CASHMERE)
15865752 COVER, R/SEAT #2 BK CUSH (TITANIUM)
15865793 COVER, R/SEAT #2 BK CUSH (EBONY) (INCLS CHILD COMFORT GUIDE)
20758131 COVER, R/SEAT #2 BK CUSH (EBONY)
20758132 COVER, R/SEAT #2 BK CUSH (CASHMERE)
20758133 COVER, R/SEAT #2 BK CUSH (TITANIUM) (USED ON VEHICLES BUILT 12/01/08 & AFTER) (1ST DES SEE 25971064)
20859429 COVER, R/SEAT #2 BK CUSH (CASHMERE) (INCLS CHILD COMFORT GUIDE)
25858726 COVER, R/SEAT #2 BK CUSH (LINEN/COCOA)
25928505 COVER, R/SEAT #2 BK CUSH (EBONY) (INCLS CHILD COMFORT GUIDE)
25971064 COVER, R/SEAT #2 BK CUSH (TITANIUM) (USED ON VEHICLES BUILT 11/30/08 & PRIOR) (2ND DES SEE 20758133)
88936748 CAP, R/SEAT ADJR TRK END (BLACK)
15924919 PANEL, R/SEAT BK CUSH FIL
(TC16-403) - 2009 CK107(06) АРМАТУРА СИДЕНЬЯ/ЗАДНЕЕ СИДЕНЬЕ #2 STRIKERS(AS3)
11515775 БОЛТ, HFH, M12X1.75X30, 10.9, 7114M (R/SEAT #2 RSR LAT STKR) [БОЛТ]
15013755 STRIKER, R/SEAT #2 RSR LAT (LOWER)
15038813 STRIKER, R/SEAT #2 RSR LAT (OUTER) (INCLS UPPER & LOWER)
15038814 STRIKER, R/SEAT #2 RSR LAT (CENTER)
teamcadillac.ru
(TC16-420) - 2007-2009 CK107(06) ЗАДНИЕ РЕМНИ БЕЗОПАСНОСТИ (AL4,AM8)
19167317 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 17) (EBONY)
19167319 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 17) (CASHMERE)
19167320 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 17) (TITANIUM)
19167321 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 17) (EBONY)
19167323 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 17) (CASHMERE)
19167324 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 17) (TITANIUM)
19168657 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 17) (COCOA)
19168658 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 17) (COCOA)
25810538 BELT, R/SEAT (RETR SI) (INCLS 2, 17) (EBONY) [РЕМЕНЬ БЕЗОПАСНОСТИ]
25810541 BELT, R/SEAT (RETR SI) (INCLS 2, 17) (EBONY) [РЕМЕНЬ, ЗАДНЕГО СИДЕНЬЯ, ПРАВЫЙ (ЧЕРНЫЙ)]
25847304 BELT, R/SEAT (RETR SI) (INCLS 2, 17) (COCOA)
25847305 BELT, R/SEAT (RETR SI) (INCLS 2, 17) (COCOA)
25906758 BELT, R/SEAT (RETR SI) (INCLS 2, 17) (CASHMERE)
25906759 BELT, R/SEAT (RETR SI) (INCLS 2, 17) (CASHMERE)
11609886 БОЛТ, R/SEAT BELT (RETR SI) (M12X1.75X40, 22 OD)
11610207 БОЛТ, R/SEAT BELT (RETR SI) (M12X1.75X76, 22 OD) (8.913) [БОЛТ]
11562376 SCREW-PAN HD, M12X1.75X55, 42 THD, 27 OD, 10.9, S424, W/ADH GM6175M (R/SEAT LAT)
15853706 BELT, R/SEAT CTR SHLDR (RETR SI) (INCLS 12, 17) (EBONY)
19151104 BELT KIT, R/SEAT CTR (RETR SI) (INCLS 12, 17) (EBONY)
19151105 BELT KIT, R/SEAT CTR (RETR SI) (INCLS 12, 17) (CASHMERE)
19210381 BELT, R/SEAT CTR SHLDR (RETR SI) (INCLS 12, 17) (COCOA)
teamcadillac.ru
25919004 BELT, R/SEAT CTR SHLDR (RETR SI) (INCLS 12, 17) (CASHMERE)
25869335 BRACKET, R/SEAT CTR BELT (RETR SI)
19121443 STOP KIT, BELT LAT (RETR SI) (PART OF 1, 10) (TITANIUM) (14.875)
19121445 STOP KIT, BELT LAT (RETR SI) (PART OF 1, 10) (CASHMERE) (14.875)
19121446 STOP KIT, BELT LAT (RETR SI) (PART OF 1, 10) (EBONY) (14.875)
19207765 STOP KIT, BELT LAT (RETR SI) (PART OF 1, 10) (COCOA) (14.875)
(TC16-432) - 2007-2009 K107(06) ЗЕРКАЛО/ВНЕШНЕЕ (HEATED,POWER FOLDING DR4)
15923191 GLASS, O/S RR VIEW MIR (PART OF 4) [СТЕКЛО ЗЕРКАЛА ЗАДНЕГО ОБЗОРА]
15923192 GLASS, O/S RR VIEW MIR (PART OF 4) [СТЕКЛО ЗЕРКАЛА ЗАДНЕГО ОБЗОРА]
25840168 GLASS, O/S RR VIEW MIR (PART OF 4)
25840169 GLASS, O/S RR VIEW MIR (PART OF 4)
25808705 ACTUATOR, O/S RR VIEW MIR INR (PART OF 4) (W/1 PIGTAIL ON BACK) (GLASS ACTUATOR W/MEMORY/MANUAL FOLDS) [ЭЛЕКТРОДВИГАТЕЛЬ РЕГУЛИРОВКИ ПОЛОЖЕНИЯ ЗЕРКАЛА ЗАДНЕГО ОБЗОРА 20 ВТ]
25808706 ACTUATOR, O/S RR VIEW MIR INR (PART OF 4) (W/1 PIGTAIL ON BACK) (GLASS ACTUATOR W/MEMORY/MANUAL FOLDS) [ЭЛЕКТРОДВИГАТЕЛЬ ЗЕРКАЛА ЗАДНЕГО ОБЗОРА 20 ВТ]
25840162 MIRROR, O/S RR VIEW (INCLS 1-3, 5, 8) (PAINT TO MATCH) (INCLS ШЛАНГИ) [ЗЕРКАЛО ЗАДНЕГО ОБЗОРА]
25840163 MIRROR, O/S RR VIEW (INCLS 1-3, 5, 8) (PAINT TO MATCH) (INCLS ШЛАНГИ) [ЗЕРКАЛО ЗАДНЕГО ОБЗОРА]
25892557 MIRROR, O/S RR VIEW (INCLS 1-3, 5, 8) (PAINT TO MATCH) (INCLS ШЛАНГИ) [ЗЕРКАЛО ЗАДНЕГО ОБЗОРА В СБОРЕ]
25892558 MIRROR, O/S RR VIEW (INCLS 1-3, 5, 8) (PAINT TO MATCH) (INCLS ШЛАНГИ) [ЗЕРКАЛО ЗАДНЕГО ОБЗОРА В СБОРЕ]
25862774 SEAL, O/S RR VIEW MIR (PART OF 4)
25862775 SEAL, O/S RR VIEW MIR (PART OF 4)
teamcadillac.ru
11508388 ГАЙКА, HEX W/CON WA, M6X1, 23.75 O.D., 5.55THK, 9, POR (O/S RR VIEW MIR) (8.915)
25816712 FILLER, FRT S/D O/S RR VIEW MIR (INSIDE VEHICLE) [НАПОЛНИТЕЛЬ-ПЕРЕДН.ЗЕРК.ЗАДН.ВИД]
25788156 ШЛАНГИ, O/S RR VIEW MIR (PART OF 4) (PAINT TO MATCH) [КРЫШКА КОРПУСА ЗЕРКАЛА ЗАДНЕГО ОБЗОРА]
25788157 ШЛАНГИ, O/S RR VIEW MIR (PART OF 4) (PAINT TO MATCH) (16.069) [КРЫШКА КОРПУСА ЗЕРКАЛА ЗАДНЕГО ОБЗОРА]
(TC16-434) - 2007-2009 CK1,2(06-36) ЗЕРКАЛО/ВНЕШНЕЕ (HEATED,POWER FOLDING,TURN SIGNAL DL3)
20778440 GLASS, O/S RR VIEW MIR (PART OF 4)
20778441 GLASS, O/S RR VIEW MIR (PART OF 4)
25829662 GLASS, O/S RR VIEW MIR (PART OF 4)
25829663 GLASS, O/S RR VIEW MIR (PART OF 4)
25829664 GLASS, O/S RR VIEW MIR (PART OF 4)
25808704 ACTUATOR, O/S RR VIEW MIR INR (PART OF 4) (W/1 PIGTAIL ON BACK) (W/O MEMORY) [ЭЛЕКТРОДВИГАТЕЛЬ РЕГУЛИРОВКИ ПОЛОЖЕНИЯ ЗЕРКАЛА ЗАДНЕГО ВИДА 20 ВТ]
20756787 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (PAINT TO MATCH)
20756788 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (PAINT TO MATCH)
20756873 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (PAINT TO MATCH)
20756915 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (PAINT TO MATCH)
20756937 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (PAINT TO MATCH)
20756947 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (PAINT TO MATCH)
20756968 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (BLACK) (BUILT W/SOLID ARROW T/SIG ON GLS) (FOR 1ST DES SEE 25865452)
20843108 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (BRIGHT CHROME)
25788563 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (BLACK)
25788564 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (BLACK)
25788583 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (PAINT TO MATCH)
teamcadillac.ru
25788589 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (CHROME)
25788590 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (CHROME)
25801798 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (PAINT TO MATCH)
25801799 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (PAINT TO MATCH)
25801822 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (MOLDED IN BLACK)
25801823 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (MOLDED IN BLACK)
25801846 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (PAINT TO MATCH)
25801864 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (CHROME)
25801865 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (CHROME)
25865452 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (BLACK) (PRIME AND PAINT REMANUFACTURED CUT AS REQUIRED TRIM AS REQD) (BUILT W/INDIV DOTTED ARROW T/SIG ON GLS) (FOR 2ND DES SEE 20756968) [ЗЕРКАЛО ЗАДНЕГО ВИДА, БОКОВОЕ, ЧЕРНОЕ]
01999382 BULB, (PART OF 4, 6) (ACDelco #W5WLL) (LONGER LIFE)
15874999 LAMP, CTSY (PART OF 4) (INCLS 5) (O/S RR VIEW)
15875000 LAMP, CTSY (PART OF 4) (INCLS 5) (O/S RR VIEW)
25862772 SEAL, O/S RR VIEW MIR (PART OF 4)
25862773 SEAL, O/S RR VIEW MIR (PART OF 4)
25788154 ШЛАНГИ, O/S RR VIEW MIR (PART OF 4) (MOLDED IN BLACK) [КОЖУХ ЗЕРКАЛА ЗАДНЕГО ВИДА]
25788155 ШЛАНГИ, O/S RR VIEW MIR (PART OF 4) (MOLDED IN BLACK) [КОРПУС САЛОННОГО ЗЕРКАЛА ЗАДНЕГО ОБЗОРА]
25788160 ШЛАНГИ, O/S RR VIEW MIR (PART OF 4) (CHROME) [КРЫШКА КОРПУСА ЗЕРКАЛА ЗАДНЕГО ОБЗОРА]
(TC16-447) - 2008-2009 CK1,2(06-36) FRONT SEAT MOUNTING (AN3,A95, EXC HYBRID HP2)
15214539 COVER, D/SEAT INR ADJR RR FIN (EBONY) (INBOARD TRACKS) (REAR) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ]
15219928 COVER, D/SEAT INR ADJR RR FIN (CASHMERE)
15882407 COVER, D/SEAT INR ADJR RR FIN (COCOA)
teamcadillac.ru
15895269 COVER, D/SEAT INR ADJR RR FIN (TITANIUM)
15214527 COVER, F/SEAT ADJR FIN (EBONY) (BELT UTILITY) [КРЫШКА]
15214529 COVER, F/SEAT ADJR FIN (TITANIUM) (BELT UTILITY)
15219925 COVER, F/SEAT ADJR FIN (CASHMERE) (BELT UTILITY)
15882421 COVER, F/SEAT ADJR FIN (COCOA)
11562473 БОЛТ, F/SEAT (M12X1.75X45) [БОЛТ М12]
15214533 CAP, F/SEAT ADJR OTR FIN CVR BOLT (EBONY) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ]
15219926 CAP, F/SEAT ADJR OTR FIN CVR BOLT (CASHMERE)
15882403 CAP, F/SEAT ADJR OTR FIN CVR BOLT (COCOA)
15895267 CAP, F/SEAT ADJR OTR FIN CVR BOLT (TITANIUM)
15215179 COVER, WRG HARN CONN (BLACK (REPLS ALL COLORS)) [КРЫШКА КОНТАКТНОГО РАЗЪЕМА]
15882405 COVER, D/SEAT INR ADJR FRT FIN (COCOA)
15931771 COVER, D/SEAT INR ADJR FRT FIN (EBONY)
15931772 COVER, D/SEAT INR ADJR FRT FIN (CASHMERE)
15931773 COVER, D/SEAT INR ADJR FRT FIN (TITANIUM)
15035434 ГАЙКА, F/SEAT (M10X1.5X10.8) (FLANGE NUT) (16.679) [ВИНТ]
15882409 COVER, P/SEAT INR ADJR FRT FIN (COCOA)
15931777 COVER, P/SEAT INR ADJR FRT FIN (EBONY) (INBOARD TRACKS) [КРЫШКА МЕХАНИЗМА РЕГУЛИРОВКИ ПОЛОЖЕНИЯ СИДЕНЬЯ]
15931778 COVER, P/SEAT INR ADJR FRT FIN (CASHMERE)
15931779 COVER, P/SEAT INR ADJR FRT FIN (TITANIUM)
15214530 COVER, F/SEAT ADJR FIN (EBONY) (OUTBOARD, 40%, BELT UTILITY) [КОЖУХ МЕХАНИЗМА РЕГУЛИРОВКИ ПОЛОЖЕНИЯ СИДЕНЬЯ]
15214532 COVER, F/SEAT ADJR FIN (TITANIUM) (BELT UTILITY)
15219924 COVER, F/SEAT ADJR FIN (CASHMERE) (BELT UTILITY)
15882423 COVER, F/SEAT ADJR FIN (COCOA)
15214545 COVER, P/SEAT INR ADJR RR FIN (EBONY) (INBOARD TRACKS) [КРЫШКА РЕГУЛИРОВОЧНОГО МЕХАНИЗМА СИДЕНИЯ]
15219930 COVER, P/SEAT INR ADJR RR FIN (CASHMERE)
15882411 COVER, P/SEAT INR ADJR RR FIN (COCOA)
15895289 COVER, P/SEAT INR ADJR RR FIN (TITANIUM)
(TC16-449) - 2008-2009 CK1(06-36) СИДЕНЬЕ ВОДИТЕЛЯ/BUCKET (AN3, HEATED/VENTED HNE,KB6)
25865290 SEAT, DRVR (EBONY)
25942727 SEAT, DRVR (COCOA)
25969271 SEAT, DRVR (COCOA)
25948864 RESTRAINT, D/SEAT HD (INCLS 2) (COCOA)
15827097 COVER, D/SEAT BK CUSH (EBONY)
25851673 COVER, D/SEAT BK CUSH (COCOA)
25907743 COVER, D/SEAT BK CUSH (CASHMERE)
25789846 PAD, D/SEAT BK CUSH
25808716 FRAME, D/SEAT BK CUSH (INCLS 9, 15, 17, 20, 21, 48) (INCLS RECLINER, MOTOR, SENSOR & LUMBAR SUPPORT) [КАРКАС СПИНКИ СИДЕНИЯ C ПОЯСНИЧНОЙ ОПОРОЙ]
20763137 LUMBAR SUB, D/SEAT (PART OF 8) (POWER) (HEAT & COOL)
15827133 RING, F/SEAT BK CUSH CVR HOG
15232700 PANEL, D/SEAT BK CUSH FIN (EBONY)
25865152 PANEL, D/SEAT BK CUSH FIN (EBONY)
25865153 PANEL, D/SEAT BK CUSH FIN (CASHMERE)
25865154 PANEL, D/SEAT BK CUSH FIN (TITANIUM)
25865611 PANEL, D/SEAT BK CUSH FIN (CASHMERE)
25969424 PANEL, D/SEAT BK CUSH FIN (COCOA)
15232558 DUCT, D/SEAT BACK VENTILATION
15232557 BLOWER, D/SEAT BACK VENTILATION HEAT & COOL (INCLS THERMAL ELECTRIC DEVICE, TEMP SENSOR & FILTER) [ВЕНТИЛЯТОР ПОДОГРЕВА СИДЕНЬЯ, 1.5ВТ]
25789849 PAD, D/SEAT CUSH
15827129 COVER, F/SEAT RSR FIN (INCLS 19) (EBONY) (RIGHT & LEFT TOE KICK)
25851756 COVER, F/SEAT RSR FIN (INCLS 19) (COCOA)
25909573 SWITCH, D/SEAT LUMBAR CONT
25926719 SWITCH, D/SEAT LUMBAR CONT (EBONY) (2-WAY POWER LUMBAR) (FOR 1ST DES SEE 25802502)
15232562 COVER, D/SEAT ADJR FIN (INCLS 32) (EBONY) (8 WAY POWER)
25851752 COVER, D/SEAT ADJR FIN (INCLS 32) (COCOA) (8 WAY POWER)
15889098 KNOB, F/SEAT RECL (COCOA) (11.377)
15889097 KNOB, D/SEAT ADJR SW (COCOA) (11.558)
11513599 ГАЙКА, U-TYPE, M4.2X1.41, 0.65-3.80 PNL THK, PZ (F/SEAT) (ACDelco #11513599)
25851758 COVER, D/SEAT INR ADJR TRK FRT FIN (COCOA)
15232243 HARNESS, D/SEAT ADJR WRG (W/LMBR/MEM/HEAT/COOL)
25865138 HARNESS, D/SEAT ADJR WRG
15232556 BLOWER, D/SEAT CUSH VENTILATION HEAT & COOL [ВЕНТИЛЯТОР ПОДОГРЕВА СИДЕНЬЯ, 1.5ВТ]
19121537 BELT KIT, D/SEAT (BKL SI) (EBONY) [ЗАЩЕЛКА РЕМНЯ БЕЗОПАСНОСТИ]
19180587 BELT KIT, D/SEAT (BKL SI) (COCOA)
teamcadillac.ru
15243823 COVER, D/SEAT INR RECL FIN (INCLS 32) (EBONY)
25851757 COVER, D/SEAT INR RECL FIN (INCLS 32) (COCOA)
25851675 COVER, D/SEAT CUSH (COCOA)
25865146 COVER, D/SEAT CUSH (EBONY) (VINYL INBOARD SIDE FACING)
25865147 COVER, D/SEAT CUSH (CASHMERE) (VINYL INBOARD SIDE FACING)
25865148 COVER, D/SEAT CUSH (TITANIUM) (VINYL INBOARD SIDE FACING)
25907745 COVER, D/SEAT CUSH (CASHMERE)
25815788 CAP, F/SEAT ADJR TRK END (BLACK)
(TC16-452) - 2008-2009 CK1,2(06) LOCKING SYSTEM/REMOTE (CADILLAC Z75, AP3,AP8)
15913415 TRANSMITTER, R/CON DR LK (INCLS 2) (4 BUTN) (W/REMOTE STARTER) (LIFTGLASS) (LABELED OEM 15913415)
15913416 TRANSMITTER, R/CON DR LK (INCLS 2) (4 BUTN) (W/O REMOTE STARTER) (LIFTGLASS)
15913420 TRANSMITTER, R/CON DR LK (INCLS 2) (3 BUTTON) (W/O REMOTE STARTER)
20763094 TRANSMITTER, R/CON DR LK (INCLS 2) (FOB #1)
20763095 TRANSMITTER, R/CON DR LK (INCLS 2) (FOB #2)
25842674 TRANSMITTER, R/CON DR LK (INCLS 2) (FOB #1) [УСТРОЙСТВО ДИСТАНЦИОННОГО УПРАВЛЕНИЯ ЦЕНТРАЛЬНЫМ ЗАМКОМ]
teamcadillac.ru
25842675 TRANSMITTER, R/CON DR LK (INCLS 2) (FOB #2) [УСТРОЙСТВО ДИСТАНЦИОННОГО УПРАВЛЕНИЯ ЦЕНТРАЛЬНЫМ ЗАМКОМ]
12538938 АККУМУЛЯТОР, R/CON DR LK XMTR (PART OF 1) (LITHIUM) (TRADE CR2032) (10.485) [БАТАРЕЙКА КНОПОЧНАЯ ЛИТИЕВАЯ]
15827429 АНТЕННА, R/CON DR LK RCVR
25852909 RECEIVER, R/CON DR LK (10.485) (LABELED 25852909)
25896497 RECEIVER, R/CON DR LK (RECEIVERS LABELED OEM 25896497) (10.485)
(TC16-453) - 2008-2009 CK107(06) КРЕПЛЕНИЕ ЗАДНЕГО СИДЕНЬЯ (60/40 BENCH AM8, EXC HYBRID HP2)
15887830 COVER, R/SEAT RSR FIN (EBONY) (ON FLOOR)
15887831 COVER, R/SEAT RSR FIN (CASHMERE) (ON FLOOR)
15887833 COVER, R/SEAT RSR FIN (CASHMERE) (ON FLOOR)
03537772 ГАЙКА, M12X1.75, 10.6THK, 28 O.D., 10, 7111M (R/SEAT) (8.917)
11562546 WASHER, FLAT, 14X42.5X3.61 MM, SAE 1050 STL RC 37-43, 7112M (R/SEAT)
teamcadillac.ru
(TC16-455) - 2007-2009 CK107(06) КРЕПЛЕНИЕ ЗАДНЕГО СИДЕНЬЯ (BUCKET AL4)
15887842 COVER, R/SEAT RSR FIN (EBONY) (ON FLOOR) (W/CARPET)
15887843 COVER, R/SEAT RSR FIN (CASHMERE) (ON FLOOR) (W/CARPET)
15887844 COVER, R/SEAT RSR FIN (TITANIUM) (ON FLOOR) (W/CARPET)
teamcadillac.ru
15887845 COVER, R/SEAT RSR FIN (CASHMERE) (ON FLOOR) (W/CARPET)
15887836 COVER, R/SEAT RSR FIN (EBONY) (ON FLOOR) (W/CARPET)
15887837 COVER, R/SEAT RSR FIN (CASHMERE) (ON FLOOR) (W/CARPET)
15887838 COVER, R/SEAT RSR FIN (TITANIUM) (ON FLOOR) (W/CARPET)
15887839 COVER, R/SEAT RSR FIN (CASHMERE) (ON FLOOR) (W/CARPET)
(TC16-577) - 2007-2009 CK1,2(06) КОНСОЛЬ/ПОЛ COVER (FLOOR КОНСОЛЬ DELETE 9N5)
11589294 RETAINER, F/FLR PNL CPT (BLACK) (M8.5 W/20.0MM HEAD) (8.133) [ФИКСАТОР ОБТЕКАТЕЛЯ РАДИАТОРА]
15926324 COVER, F/FLR PNL CPT HOLE (BLACK)
(TC16-910) - 2008-2009 CK107(06) ЗАДНЕЕ СИДЕНЬЕ/BENCH-40% SIDE (AM8, HYBRID HP2)
15824668 RESTRAINT, R/SEAT HD (EBONY)
15824669 RESTRAINT, R/SEAT HD (CASHMERE)
15824670 RESTRAINT, R/SEAT HD (TITANIUM)
15824672 RESTRAINT, R/SEAT HD (EBONY)
15865811 RESTRAINT, R/SEAT HD (TITANIUM) (USED ON VEHICLES BUILT 11/30/08 & PRIOR) (2ND DES SEE 20758015)
20758013 RESTRAINT, R/SEAT HD (EBONY) (USED ON VEHICLES BUILT 12/01/08 & AFTER) (1ST DES SEE 25863652)
20758014 RESTRAINT, R/SEAT HD (CASHMERE)
20758015 RESTRAINT, R/SEAT HD (TITANIUM) (USED ON VEHICLES BUILT 12/01/08 & AFTER) (1ST DES SEE 15865811)
25863652 RESTRAINT, R/SEAT HD (EBONY) (USED ON VEHICLES BUILT 11/30/08 & PRIOR) (2ND DES SEE 20758013)
25928791 RESTRAINT, R/SEAT HD (CASHMERE)
15924924 RETAINER, R/SEAT BK CUSH OPG FIN CVR (PUSH IN)
teamcadillac.ru
15279419 HANDLE, R/SEAT RECL (INCLS 29) (EBONY)
15279420 HANDLE, R/SEAT RECL (INCLS 29) (CASHMERE)
15279429 HANDLE, R/SEAT RECL (INCLS 29) (TITANIUM)
25816418 PAD, R/SEAT CUSH
25816429 COVER, R/SEAT CUSH (EBONY)
25816430 COVER, R/SEAT CUSH (CASHMERE)
25816431 COVER, R/SEAT CUSH (TITANIUM)
25949198 COVER, R/SEAT CUSH (EBONY)
25949199 COVER, R/SEAT CUSH (CASHMERE)
(TC16-936) - 2007-2009 CK1(06-36) ПРИБОРНАЯ ПАНЕЛЬ & СОПРЯЖЕННЫЕ ДЕТАЛИ ЧАСТЬ 2 ELECTRICAL (CADILLAC Z75)
25812358 MODULE, I/P INFL RST (CASHMERE) [МОДУЛЬ]
25819574 MODULE, I/P INFL RST (COCOA)
11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (I/P INFL RST MDL) [БОЛТ М8]
15884145 CLOCK, (ENGLISH NUMBERS ON CLOCK FACE.)
25949881 CLOCK, (ROMAN NUMERALS ON CLOCK FACE.) [ЧАСЫ ПРИБОРНОЙ ПАНЕЛИ]
11610157 ГАЙКА, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (I/P) (10.701) [ГАЙКА М4]
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (RDO) (9.665) [БОЛТ М4.2Х1.41Х25]
15859233 SWITCH, RR OBJECT ALARM MDL
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (I/P ACSRY CTR TR PLT) [ЗАЖИМ КОНСОЛИ САЛОНА]
15859232 SWITCH, DRVR INFO DISPLAY [ВЫКЛЮЧАТЕЛЬ ИНФОРМАЦИОННОГО ДИСПЛЕЯ]
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (ACSRY SW BZL) (9.665) [БОЛТ М4.2Х1.41Х25]
15902838 SWITCH, ACSRY (2 BUTTON) (TRACK CONTROL, SONIC/PARK)
20820629 SWITCH, ACSRY
20820630 SWITCH, ACSRY
25845475 SWITCH, ACSRY
25845476 SWITCH, ACSRY
20803599 CONTROL, HTR & A/C (W/ D/SEAT & P/SEAT HTR)
20803601 CONTROL, HTR & A/C (W/ F/SEAT HTR & CUSH VENT FAN)
25809867 CONTROL, HTR & A/C (W/ D/SEAT & P/SEAT HTR) (ACDelco #15-73835)
25809870 CONTROL, HTR & A/C (W/ F/SEAT HTR & CUSH VENT FAN)
25928678 CONTROL, HTR & A/C (W/ D/SEAT & P/SEAT HTR) (ACDelco #15-73924)
25928679 CONTROL, HTR & A/C (W/ D/SEAT & P/SEAT HTR)
25928681 CONTROL, HTR & A/C (W/ F/SEAT HTR & CUSH VENT FAN) (MARKED REAR) (ACDelco #15-73925)
25928682 CONTROL, HTR & A/C (W/ F/SEAT HTR & CUSH VENT FAN) (MARKED REAR)
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (COMN INTERFACE MDL BRKT) (9.665) [БОЛТ М4.2Х1.41Х25]
11588920 SCREW, W/RND WA, M3.5X1.59X9.5, 6 THD, 7 O.D., GM512M, GMW3044 (RDO VOL COMP INTR NOISE MIC)
20783877 MODULE, COMN INTERFACE (W/MOBILE TEL XCVR) (ACDelco #20783877)
20783878 MODULE, COMN INTERFACE (W/MOBILE TEL XCVR) (LABELED 20783878) (ACDelco #20783878)
25984445 MODULE, COMN INTERFACE (W/MOBILE TEL XCVR) (LABELED 25984445) (ACDelco #25984445)
11610157 ГАЙКА, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (COMMUNICATION INTERFACE MDL BRKT) (10.701) [ГАЙКА М4]
25791895 BRACKET, COMMUNICATION INTERFACE MDL
15240415 MICROPHONE, RDO VOL COMP INTR NOISE
25783504 MICROPHONE, RDO VOL COMP INTR NOISE (HEADLINER PANEL)
15221547 PLATE, HDLP SW TR (INCLS 23) (EBONY)
15907806 PLATE, HDLP SW TR (INCLS 23)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 22) [ЗАЖИМ КОНСОЛИ САЛОНА]
25858706 SWITCH, HDLP & I/P LP DIMR & DM LP (HAS "DOME OFF") (INCLS FRT FOG LAMP SWITCH) (ACDelco #D1528J)
25858707 SWITCH, HDLP & I/P LP DIMR & DM LP (HAS "DOME OFF") (INCLS FRT & RR FOG LAMP SWITCH) (ACDelco #D1529J) [КОМБИНИРОВАННЫЙ ВЫКЛЮЧАТЕЛЬ НАРУЖНОГО ОСВЕЩЕНИЯ]
25858708 SWITCH, HDLP & I/P LP DIMR & DM LP (HAS "DOME OFF") (ACDelco #D1530J)
25878424 SWITCH, TRFER CASE SEL
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 29) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
12092079 FUSE, 10A, MINI, RED (PART OF 29)
88909749 FUSE, 3A, MINI, VIOLET (PART OF 29) (8.965) (ACDelco #ATM3-25)
88909754 FUSE, 15A, MINI, BLUE (PART OF 29) (ACDelco #ATM15-25) [ПРЕДОХРАНИТЕЛЬ 15 А]
88909755 FUSE, 20A, MINI, YELLOW (PART OF 29) (ACDelco #ATM20-25) [ПРЕДОХРАНИТЕЛЬ 20 А]
88909756 FUSE, 25A, MINI, CLEAR (PART OF 29) (ACDelco #ATM25-25) [ПРЕДОХРАНИТЕЛЬ, 25A]
12084791 PULLER, FUSE (PART OF 29) (MINI) (I/P COVER)
25940497 COVER, I/P FUSE BLK ACC HOLE (INCLS 26-28, 30) (LINEN)
25940508 LABEL, FUSE BLK IDENT (PART OF 29)
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (INST CSTR) (9.665) [БОЛТ М4.2Х1.41Х25]
25713063 SENSOR, HDLP AUTO CONT AMB LGT (DUAL SOLAR & TWILIGHT) [ДАТЧИК ОСВЕЩЕННОСТИ ДЛЯ АВТОМАТИЧ.ВКЛЮЧ.ГАБАРИТОВ]
20777694 CLUSTER, INST (ACDelco #20777694) (LABELED 20777694 OR 20790474)
20777695 CLUSTER, INST (LABELED 20777695) (ACDelco #20777695) (LABELED 20777695 OR 20790475) [ЩИТОК ПРИБОРОВ]
20777696 CLUSTER, INST (LABELED 20777696) (ACDelco #20777696) (LABELED 20777696 OR 20790476)
20777697 CLUSTER, INST (LABELED 20777697) (ACDelco #20777697)
20777698 CLUSTER, INST (LABELED 20777698) (ACDelco #20777698) (LABELED 20777698 OR 20790478) [ЩИТОК ПРИБОРОВ]
20777699 CLUSTER, INST (ACDelco #20777699) (LABELED 20777699, 20790479 OR 25901071) [ЩИТОК ПРИБОРОВ]
25901068 CLUSTER, INST (LABELED 25901068) (ACDelco #25901068)
teamcadillac.ru
25901069 CLUSTER, INST (LABELED 25901069) (ACDelco #25901069)
25901070 CLUSTER, INST (LABELED 25901070) (ACDelco #25901070)
25940222 CLUSTER, INST (LABELED 25940222) (ACDelco #25940222)
25940223 CLUSTER, INST (LABELED 25940223) (ACDelco #25940223)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 37) [ЗАЖИМ КОНСОЛИ САЛОНА]
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (RDO FRT SPKR) (9.665) [БОЛТ М4.2Х1.41Х25]
15221850 GRILLE, RDO FRT SPKR (INCLS 35) (EBONY)
15221851 GRILLE, RDO FRT SPKR (INCLS 35) (COCOA)
15248601 GRILLE, RDO FRT SPKR (INCLS 35) (EBONY)
25795255 GRILLE, RDO FRT SPKR (INCLS 35) (TITANIUM)
25918994 GRILLE, RDO FRT SPKR (INCLS 35) (CASHMERE)
15859569 АНТЕННА, ELEK NAVIGATION (ACDelco #15859569)
(TC16-938) - 2007-2009 CK1,2,3 ВЕТРОВОЕ СТЕКЛО & СОПРЯЖЕННЫЕ ДЕТАЛИ
10078250 MIRROR, I/S RR VIEW (INCLS 2) (STANDARD MIRROR) (10.185)
22730183 MIRROR, I/S RR VIEW (INCLS 2) (ONSTAR BUTTON IS RED CIRCLE W/WHITE CROSS) (10.185)
15779345 COVER, I/S RR VIEW MIR WRG HARN (BETWEEN I/S MIRROR & HDLR)
15910710 ВЕТРОВОЕ СТЕКЛО, (WHEN REPL ВЕТРОВОЕ СТЕКЛО ORDER LENS FOR RAIN SENSOR) (INCLS 3, 6, 14) (INCLS UPPER MLDG) [ВЕТРОВОЕ СТЕКЛО]
15910711 ВЕТРОВОЕ СТЕКЛО, (INCLS 3, 6, 14) (INCLS UPR MLDG)
20859593 ВЕТРОВОЕ СТЕКЛО, (INCLS 3, 6, 14) (BUILT W/O RAIN SENSOR) (FOR 1ST DES SEE 25783546)
25783546 ВЕТРОВОЕ СТЕКЛО, (INCLS 3, 6, 14) (INCLS UPR MLDG) (BUILT W/RAIN SENSOR) (FOR 2ND DES SEE 20859593) [ВЕТРОВОЕ СТЕКЛО]
11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (W/S R/MLDG)
11589183 ГАЙКА, PUSH IN, W/SEAL, 4.2X1.41, 6.35-6.48 SQ HL, 9.5 SQ HD, 0.787-2.765 PNL THK, NYL (W/S R/MLDG)
25975085 MOLDING, W/S RVL [МОЛДИНГ ВЕТРОВОГО СТЕКЛА]
teamcadillac.ru
25975086 MOLDING, W/S RVL [МОЛДИНГ В СБОРЕ]
25954952 SUPPORT, W/S [ФИКСАТОР ВЕТРОВОГО СТЕКЛА]
(TC16-939) - 2007-2009 CK107(06) КУЗОВНЫЕ ДЕТАЛИ/ROOF
15202470 PANEL, RF
25991527 PANEL, RF
15264587 BOW, RF PNL #4 (W/O NUT)
teamcadillac.ru
15102503 BOW, RF PNL #3 (W/O NUT)
15288511 BOW, RF PNL #2 (W/NUT)
15163037 BOW, RF PNL #1 (W/O NUT)
15202494 BRACKET, RF CNSL
15202446 PANEL, RF FRT HDR (INCLS 8, 9)
10056725 ГАЙКА, PUSH-IN, M4.2X1.41, 50 CARB SPR STL, GM7111M PO ZOR (PART OF 7)
(TC16-942) - 2007-2009 CK1,2,3 КУЗОВНЫЕ ДЕТАЛИ/COWL
15847235 PANEL, DA (INCLS 2-7, 9-17)
25907240 PANEL, PLNM UPR (PART OF 1)
15713209 BRACKET, BRK & ACCEL PED (PART OF 1) (L=45 W=80 H=80) (DASH PANEL) (0.829)
15134620 PANEL, PLNM LWR (PART OF 1)
teamcadillac.ru
25907237 PANEL, PLNM FRT (PART OF 1)
25847533 PANEL, COWL SI (PART OF 1) (INCLS 7)
15185462 VALVE, PLNM DRN
15856112 VALVE, PLNM DRN
15862261 BRACKET, FRT W/H PNL UPR (PART OF 1)
15185451 BRACKET, BAT TRAY (PART OF 1)
15176164 PANEL, COWL SI (PART OF 1) (INCLS 7)
11609625 STUD, DA & COWL PNL INSL (M5 X 1.6 X 57.0) (RIVET STYLE) (4.047)
15854747 BRACKET, КАПОТ STRUT (BODY SI) (PART OF 1) (INCLS 15)
11562567 STUD, КАПОТ STRUT BALL (PART OF 1, 14)
25809428 DEFLECTOR, PLNM LWR PNL WAT (PART OF 1) (INCLS 17)
15607103 RETAINER, PLNM PNL (PART OF 1, 16) (LWR WATER DEFLECTOR) (9.264)
15895064 COVER, PLNM UPR PNL OPG
(TC16-943) - 2007-2009 CK107(06) КУЗОВНЫЕ ДЕТАЛИ/НИЖНЯЯ ЧАСТЬ
15234714 PANEL, R/FLR (INCLS 2)
15630183 PLATE, CARGO TIE DN LOOP ANC (PART OF 1) (16.715)
10382641 BRACKET, JK STOW (BOTTOM BRKT INCLS STUDS)
15847621 PANEL, RR W/H INR
15274143 INSULATOR, S/D OPG FRM (C-PLR LWR)
15274144 INSULATOR, S/D OPG FRM (C-PLR LWR)
15288880 EXTENSION, INTER FLR PNL
15288881 EXTENSION, INTER FLR PNL
15290493 EXTENSION, FLR PNL (FRT)
25815106 EXTENSION, FLR PNL (FRT)
15115647 SILL, U/B RR CR
15226696 SILL, U/B #5 CR
25826963 SILL, U/B #3 CR
25860801 REINFORCEMENT, R/FLR PNL
15234718 REINFORCEMENT, R/FLR PNL OTR
15234719 REINFORCEMENT, R/FLR PNL OTR
25946282 SILL, U/B #4 CR
15154215 REINFORCEMENT, R/FLR PNL FRT
15234716 REINFORCEMENT, R/FLR PNL FRT (INCLS EXH MUFF H/SHLD, WELD STUDY)
15234712 REINFORCEMENT, INTER FLR PNL (INCLS EXH MUFF H/SHLD, WELD STUDY)
15722519 REINFORCEMENT, INTER FLR PNL
15029772 BRACE, INTER FLR PNL
15234710 REINFORCEMENT, FLR PNL
15234713 REINFORCEMENT, INTER FLR PNL (CENTER)
25860799 REINFORCEMENT, FLR PNL
25946285 SILL, U/B #1 CR
15107879 BRACE, CR SILL
15828261 REINFORCEMENT, FLR PNL (D/SEAT) (OUTER)
25831426 BRACKET, BODY MT (#2)
25860798 SILL, U/B #2 CR
teamcadillac.ru
25831425 BRACKET, BODY MT (#2)
15822915 REINFORCEMENT, FLR PNL (D/SEAT) (INNER)
25937227 BRACE, CR SILL
15896696 SILL, U/B #1 CR
15234733 REINFORCEMENT, FLR PNL (P/SEAT) (OUTER)
15234735 REINFORCEMENT, FLR PNL (P/SEAT) (INNER)
15173440 STIFFENER, FLR PNL AT TUN
15173441 STIFFENER, FLR PNL AT TUN
25860800 PANEL, F/FLR (INCLS 37-39)
15234730 PANEL, RKR FRT INR
15827692 PANEL, RKR FRT INR
25982599 PANEL, RKR FRT INR [ПАНЕЛЬ]
15174121 BRACKET, I/P LWR (PART OF 35)
15734736 STUD, F/SEAT ANC PLT (PART OF 35)
11609625 STUD, BODY WRG HARN GND (PART OF 35) (M5 X 1.6 X 57.0) (RIVET STYLE) (4.047)
15234731 PANEL, RKR RR INR (INCLS STUDS)
15243789 PANEL, RKR RR INR
15950124 PANEL, INTER FLR
(TC16-946) - 2007-2009 CK107(06) КУЗОВНЫЕ ДЕТАЛИ SIDE FRONT
15934444 FRAME, S/D OPG (INCLS 16, 17, 29, 31)
15934445 FRAME, S/D OPG (INCLS 16, 17, 29, 31)
11609733 БОЛТ, HEX W/CON WA, M8X1.25X30, 20 THD, 24 OD, 10.9, GMW4205, MAT POINT (RR S/D HGE (DR SI)) [БОЛТ М8]
teamcadillac.ru
25854397 HINGE, RR S/D UPR (BODY & DR SIDE) (REPL T/W 11562286 - QTY 1) [ПЕТЛЯ ДВЕРИ]
25854398 HINGE, RR S/D UPR (BODY & DR SIDE) (REPL T/W 11562286 - QTY 1) [ПЕТЛЯ ДВЕРИ]
11609733 БОЛТ, HEX W/CON WA, M8X1.25X30, 20 THD, 24 OD, 10.9, GMW4205, MAT POINT (RR S/D HGE (BODY SI)) [БОЛТ М8]
25958200 HINGE, RR S/D LWR (BODY & DR SIDE)
25958201 HINGE, RR S/D LWR (BODY & DR SIDE) [ПЕТЛЯ ДВЕРИ]
20773442 PANEL, RR S/D OTR (PART OF 8) [ПАНЕЛЬ ДВЕРИ]
20773443 PANEL, RR S/D OTR (PART OF 8)
25961382 DOOR, RR SI (INCLS 7) [ПАНЕЛЬ ДВЕРИ]
25961383 DOOR, RR SI (INCLS 7) (W/O HINGES) [ЗАДНЯЯ ДВЕРЬ]
25958196 HINGE, FRT S/D LWR (BODY & DR SIDE)
25958197 HINGE, FRT S/D LWR (BODY & DR SIDE)
11609733 БОЛТ, HEX W/CON WA, M8X1.25X30, 20 THD, 24 OD, 10.9, GMW4205, MAT POINT (FRT S/D HGE (BODY SI)) [БОЛТ М8]
25854415 HINGE, FRT S/D UPR (BODY & DR SIDE) (REPL T/W 11562286 - QTY 1) [ПЕТЛЯ ДВЕРИ]
25854416 HINGE, FRT S/D UPR (BODY & DR SIDE) (REPL T/W 11562286 - QTY 1) [ПЕТЛЯ ДВЕРИ]
25891763 PANEL, FRT S/D OTR (PART OF 14)
25891764 PANEL, FRT S/D OTR (PART OF 14)
15228568 DOOR, FRT SI (INCLS 13) (W/O HINGES)
25912653 DOOR, FRT SI (INCLS 13) (W/O HINGES) [ПАНЕЛЬ ДВЕРИ]
15837057 INSULATOR, S/D OPG FRM (LWR FRT BODY H-PLR)
15837058 INSULATOR, S/D OPG FRM (LWR FRT BODY H-PLR)
25858298 SEAL, C/PLR LWR
25858299 SEAL, C/PLR LWR
10393085 REINFORCEMENT, FRT S/D OPG FRM
10393086 REINFORCEMENT, FRT S/D OPG FRM
10393087 RAIL, RF SI (INCLS 23)
10393088 RAIL, RF SI (INCLS 23)
15853601 PANEL, C/PLR INR UPR (INCLS 25)
15853602 PANEL, C/PLR INR UPR (INCLS 25)
15854158 PANEL, BODY SI INR UPR
15858829 PANEL, BODY SI INR UPR
15854232 PLATE, R/SEAT SHLDR BELT ANC
25913870 PLATE, R/SEAT SHLDR BELT ANC
25918297 PANEL, C/PLR INR LWR (INCLS 30)
25918298 PANEL, C/PLR INR LWR (INCLS 30)
15232690 PLUG, BODY SI FRM ACC HOLE (SQUARE)
(TC16-948) - 2007-2009 CK107(06) КУЗОВНЫЕ ДЕТАЛИ SIDE REAR
25822461 PANEL, BODY SI OTR
25822462 PANEL, BODY SI OTR [ПАНЕЛЬ ЗАДНЕЙ ЧАСТИ КУЗОВА]
11609731 RIVET, F/TNK FIL DR HGE (25" SHANK, .63 LEN, .50 OD, .06-.30 GRP RNG, 1008 STL, GMW3044) (8.967)
15940678 DOOR, F/TNK FIL (СМ. ГРУППУ 03.000 "FUEL FILLER PIPE" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА)
15202493 FILLER, BODY SI OTR PNL
15862274 EXTENSION, RR W/H PNL FRT
15862275 EXTENSION, RR W/H PNL FRT
teamcadillac.ru
15929419 PANEL, RR W/H OTR (FRT)
15929495 PANEL, RR W/H OTR (FRT)
15824937 PANEL, RR W/H OTR (RR)
15824938 PANEL, RR W/H OTR (RR)
15830951 GASKET, F/TNK FIL DR OPG FIL
15830910 PANEL, BODY SI INR LWR
15830911 PANEL, BODY SI INR LWR
15876164 SEAL, BODY SI INR LWR PNL
15876165 SEAL, BODY SI INR LWR PNL
15202476 RAIL, RF UPR SI
15202477 RAIL, RF UPR SI
25893160 REINFORCEMENT, BK BODY OPG SI FRM (СМ. ГРУППУ 16.000 "КУЗОВНЫЕ ДЕТАЛИ REAR" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА)
25893161 REINFORCEMENT, BK BODY OPG SI FRM (СМ. ГРУППУ 16.000 "КУЗОВНЫЕ ДЕТАЛИ REAR" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА)
15900620 RAIL, RF LWR SI
15900621 RAIL, RF LWR SI
25780811 PANEL, BODY SI INR
25780812 PANEL, BODY SI INR
15255977 PANEL, F/TNK FIL PIPE HSG
(TC16-951) - 2007-2009 CK1,2(06) КУЗОВНЫЕ ДЕТАЛИ REAR
15164154 FRAME, BK BODY OPG UPR
15847152 EXTENSION, BK BODY OPG FRM UPR
25778949 FRAME, BK BODY OPG
15164155 FRAME, BK BODY OPG SI
15043000 PLUG, R/CMPT SILL TR PLT HOLE (38.0 X 17.0 X 18.0MM) (OBLONG) (16.600)
15829742 REINFORCEMENT, BK BODY OPG FRM LWR (INCLS 7)
15164157 FRAME, BK BODY OPG LWR
25946269 BRACKET, BODY RR MT (INCLS 10) (BODY)
15887101 SEAL, BK BODY OPG LWR FRM FIL (TO INTER FLR PNL)
15887102 SEAL, BK BODY OPG LWR FRM FIL (TO INTER FLR PNL)
15816355 PANEL, BK BODY OPG FRM SI FIL LWR
15816359 FILLER, BK BODY OPG FRM SI
15816356 PANEL, BK BODY OPG FRM SI FIL LWR
teamcadillac.ru
15816358 FILLER, BK BODY OPG FRM SI
15164156 FRAME, BK BODY OPG SI
(TC16-952) - 2007-2009 CK1,2,3(06-36-43) ОТДЕЛКА/INTERIOR-BODY SIDE FRONT
15924657 MOLDING, W/S SI GARN (INCLS 2-7) (GRAY) (W/SPEAKER)
15924658 MOLDING, W/S SI GARN (INCLS 2-7) (CASHMERE) (W/SPEAKER)
20803783 MOLDING, W/S SI GARN (INCLS 2-7) (LINEN)
20803784 MOLDING, W/S SI GARN (INCLS 2-7) (GRAY)
20804188 MOLDING, W/S SI GARN (INCLS 2-7) (CASHMERE)
25902624 MOLDING, W/S SI GARN (INCLS 2-7) (CASHMERE)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 1) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
11609651 CLIP, W/S SI G/MLDG (PART OF 1) (M21.8X15.0X20.5) (14.731) [ШАЙБА]
11609465 БОЛТ, HWH, M4.2X1.41X18, 12.5 OD, 6010M, PS (PART OF 1) (8.977) [ВИНТ М6]
15220492 PLUG, W/S SI G/MLDG BOLT HOLE FIN (PART OF 1) (GRAY)
25827808 PLUG, W/S SI G/MLDG BOLT HOLE FIN (PART OF 1) (LINEN/COCOA)
15186674 SPEAKER, RDO W/S SI G/MLDG (PART OF 1, 23) (ACDelco #15186674) [ДИНАМИК 20ВТ]
15841537 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 1) (CASHMERE)
25889853 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 1)
25889857 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 1) (LINEN)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 9) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
15877455 PANEL, BODY H/PLR TR (INCLS 8) (LINEN)
15877457 PANEL, BODY H/PLR TR (INCLS 8) (LINEN)
15904432 PANEL, BODY H/PLR TR (INCLS 8) (EBONY) [ВНУТРЕННЯЯ ПАНЕЛЬ СТОЙКИ КУЗОВА]
15904433 PANEL, BODY H/PLR TR (INCLS 8) (TITANIUM)
15904434 PANEL, BODY H/PLR TR (INCLS 8) (CASHMERE)
15904438 PANEL, BODY H/PLR TR (INCLS 8) (EBONY)
15904439 PANEL, BODY H/PLR TR (INCLS 8) (TITANIUM)
15904440 PANEL, BODY H/PLR TR (INCLS 8) (CASHMERE)
15848375 PLATE, FRT S/D SILL TR (INCLS 11) (EBONY) (W/CADILLAC INSERT)
15848379 PLATE, FRT S/D SILL TR (INCLS 11) (EBONY) (W/CADILLAC INSERT)
15848382 PLATE, FRT S/D SILL TR (INCLS 11) (EBONY)
15848383 PLATE, FRT S/D SILL TR (INCLS 11) (CASHMERE)
15848386 PLATE, FRT S/D SILL TR (INCLS 11) (EBONY)
15848387 PLATE, FRT S/D SILL TR (INCLS 11) (CASHMERE)
15877375 PLATE, FRT S/D SILL TR (INCLS 11) (LINEN)
15877377 PLATE, FRT S/D SILL TR (INCLS 11) (LINEN)
20765248 PLATE, FRT S/D SILL TR (INCLS 11) (LINEN)
20765249 PLATE, FRT S/D SILL TR (INCLS 11) (LINEN)
25902619 PLATE, FRT S/D SILL TR (INCLS 11) (CASHMERE)
25902620 PLATE, FRT S/D SILL TR (INCLS 11) (CASHMERE)
25962379 PLATE, FRT S/D SILL TR (INCLS 11) (EBONY)
25962380 PLATE, FRT S/D SILL TR (INCLS 11) (CASHMERE)
25962382 PLATE, FRT S/D SILL TR (INCLS 11) (EBONY)
25962383 PLATE, FRT S/D SILL TR (INCLS 11) (CASHMERE)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 10) [ЗАЖИМ КОНСОЛИ САЛОНА]
25880275 MOLDING, C/PLR LWR GARN (INCLS 13) (CASHMERE)
25880276 MOLDING, C/PLR LWR GARN (INCLS 13) (TITANIUM)
25880277 MOLDING, C/PLR LWR GARN (INCLS 13) (EBONY)
25880279 MOLDING, C/PLR LWR GARN (INCLS 13) (LINEN)
25880281 MOLDING, C/PLR LWR GARN (INCLS 13) (CASHMERE)
25880282 MOLDING, C/PLR LWR GARN (INCLS 13) (TITANIUM)
25880283 MOLDING, C/PLR LWR GARN (INCLS 13) (EBONY)
25880285 MOLDING, C/PLR LWR GARN (INCLS 13) (LINEN)
15214078 COVER, D/SEAT SHLDR BELT GDE ADJR CLOSEOUT (PART OF 15) (GRAY)
15255523 COVER, D/SEAT SHLDR BELT GDE ADJR CLOSEOUT (PART OF 15) (CASHMERE)
25827825 COVER, P/SEAT SHLDR BELT GDE ADJR CLOSEOUT (PART OF 15) (LINEN)
15877439 MOLDING, C/PLR UPR GARN (INCLS 13, 14, 16-19) (LINEN)
15877441 MOLDING, C/PLR UPR GARN (INCLS 13, 14, 16-19) (LINEN)
25797317 MOLDING, C/PLR UPR GARN (INCLS 13, 14, 16-19) (GRAY)
25797320 MOLDING, C/PLR UPR GARN (INCLS 13, 14, 16-19) (GRAY)
25902639 MOLDING, C/PLR UPR GARN (INCLS 13, 14, 16-19) (CASHMERE)
25902640 MOLDING, C/PLR UPR GARN (INCLS 13, 14, 16-19) (CASHMERE)
15278044 PLUG, C/PLR HOLE (PART OF 15) (GRANITE)
15278045 PLUG, C/PLR HOLE (PART OF 15) (CASHMERE)
15278047 PLUG, C/PLR HOLE (PART OF 15) (GRAY)
teamcadillac.ru
25827824 PLUG, C/PLR HOLE (PART OF 15) (LINEN)
11609465 БОЛТ, HWH, M4.2X1.41X18, 12.5 OD, 6010M, PS (PART OF 15) (8.977) [ВИНТ М6]
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 15) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
11570136 БОЛТ, HEX HD, W/CON SPR WA, M6X1X23, 14 THD, 17 O.D., 8.8, GMW3359 (ASST HDL)
15845416 HANDLE, ASST (GRAY)
15845418 HANDLE, ASST (CASHMERE)
15936642 HANDLE, ASST (LINEN)
15936643 HANDLE, ASST (LINEN)
20776884 HANDLE, ASST (GRAY)
20776886 HANDLE, ASST (CASHMERE)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 23) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
15924664 MOLDING, W/S SI GARN (INCLS 6, 22, 24) (GRAY) (W/SPEAKER)
15924665 MOLDING, W/S SI GARN (INCLS 6, 22, 24) (CASHMERE)
20803779 MOLDING, W/S SI GARN (INCLS 6, 22, 24) (LINEN)
20803780 MOLDING, W/S SI GARN (INCLS 6, 22, 24) (GRAY)
25902623 MOLDING, W/S SI GARN (INCLS 6, 22, 24) (CASHMERE)
25889859 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 23) (GRAY)
25889861 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 23)
25889863 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 23) (LINEN)
15220455 COVER, W/S PLR ASST HDL (PART OF 27) (GRAY) (UPPER)
15220459 COVER, W/S PLR ASST HDL (PART OF 27) (GRAY) (LOWER)
15255444 COVER, W/S PLR ASST HDL (PART OF 27) (CASHMERE) (LOWER)
15255445 COVER, W/S PLR ASST HDL (PART OF 27) (CASHMERE) (UPPER)
15936574 COVER, W/S PLR ASST HDL (PART OF 27) (LINEN) (UPPER)
15936575 COVER, W/S PLR ASST HDL (PART OF 27) (LINEN) (LOWER)
11609939 БОЛТ, HEX W/FLAT WA, M6X1X30, 21 THD, 17 OD, TAPPING (W/S PLR ASST HDL)
15916832 HANDLE, W/S PLR ASST (INCLS 25) (GRAY)
15916834 HANDLE, W/S PLR ASST (INCLS 25) (CASHMERE)
15936573 HANDLE, W/S PLR ASST (INCLS 25) (LINEN)
(TC16-957) - 2007-2009 CK1,2(06-36) ПРИБОРНАЯ ПАНЕЛЬ & СОПРЯЖЕННЫЕ ДЕТАЛИ ЧАСТЬ 3 SUPPORTS (CADILLAC Z75)
25842111 SUPPORT, INST CARR (INCLS 3, 4, 10)
25842112 SUPPORT, INST CARR (INCLS 3, 4, 10)
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (I/P LWR TR PAD) (9.665) [БОЛТ М4.2Х1.41Х25]
11610157 ГАЙКА, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (PART OF 1) (10.701) [ГАЙКА М4]
teamcadillac.ru
15192254 DEFLECTOR, I/P DRVR KNEE BOLS [КОЖУХ НИЖНЕЙ ЧАСТИ ЦЕНТРАЛЬНОЙ КОНСОЛИ]
11508277 ГАЙКА, HEX W/CON WA M6X1 THD, OD-19 PEOR 9 (I/P DRVR KNEE BOLS DFL) [ГАЙКА М6]
10355555 BRACE, I/P CTR SUPT
11609410 БОЛТ, HFH, M8X1.25X25, 10.9, GMW3179 (I/P CTR SUPT BR) (0.056) [БОЛТ]
11589407 БОЛТ, HWH, M8X1.25X35, 23.5 THD, 24 OD, 10.9, GMW3359, M-PT. (INST CARR SUPT) [БОЛТ]
11508277 ГАЙКА, HEX W/CON WA M6X1 THD, OD-19 PEOR 9 (I/P LWR T/PNL) [ГАЙКА М6]
11570136 БОЛТ, HEX HD, W/CON SPR WA, M6X1X23, 14 THD, 17 O.D., 8.8, GMW3359 (I/P UPR T/PNL)
(TC16-958) - 2007-2009 CK1,2(06) WIPER SYSTEM/ВЕТРОВОЕ СТЕКЛО (EXC POLICE PACKAGE PPV)
25879116 ARM, WSW (W/NOZZLE & HOSE) [ДЕРЖАТЕЛЬ ЩЕТКИ СТЕКЛООЧИСТИТЕЛЯ]
25879117 ARM, WSW (W/NOZZLE & HOSE) [ДЕРЖАТЕЛЬ ЩЕТКИ СТЕКЛООЧИСТИТЕЛЯ]
15788727 CAP, WSW ARM FIN (10.147) [КОЛПАЧОК ДЕРЖАТЕЛЯ ЩЕТКИ СТЕКЛООЧИСТИТЕЛЯ]
11609634 ГАЙКА, HEX WASH, M10X1.25, 7MM THK, 20 WA OD, 9 STL, 7111M, CON SPR WA. (WSW ARM) [ШАЙБА]
25820729 PANEL, AIR INL GRL (BLACK) [НАКЛАДКА ВОДОСТОЧНОЙ ПАНЕЛИ]
25820730 PANEL, AIR INL GRL (BLACK) [НАКЛАДКА ВОДОСТОЧНОЙ ПАНЕЛИ]
11609796 CLIP, AIR INL GRL PNL (11.0 X 12.9 X 6.1MM) (8.950)
15780444 COVER, W/S O/S MSTRE SEN (COVERS MIR HARNESS)
25942005 SENSOR, W/S O/S MSTRE (INCLS 31) (10.163) [ДАТЧИК ДОЖДЯ ВЕТРОВОГО СТЕКЛА]
25872303 PANEL, AIR INL GRL (CTR) (INCLS 10, 14, 18) (BLACK)
25887976 HOSE, WSWA NOZ (PART OF 9) [ШЛАНГ СТЕКЛООМЫВАТЕЛЯ]
25923882 MODULE, WSW SYS [ЭЛЕКТРОДВИГАТЕЛЬ СТЕКЛООЧИСТИТЕЛЯ 90 ВТ]
11513947 БОЛТ, HEX, W/WA, M6X1X35, 24 O.D., AC PT, 9.8, POR (WSW SYS MDL)
15999788 RETAINER, AIR INL GRL PNL (U-SHAPED/CLIP)
15200240 WEATHERSTRIP, КАПОТ RR (PART OF 9)
11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (AIR INL GRL PNL)
11589183 ГАЙКА, PUSH IN, W/SEAL, 4.2X1.41, 6.35-6.48 SQ HL, 9.5 SQ HD, 0.787-2.765 PNL THK, NYL (AIR INL GRL PNL)
15214346 BLADE, WSW (22") [ЩЕТКА СТЕКЛООЧИСТИТЕЛЯ]
15048061 RETAINER, AIR INL GRL PNL (PART OF 9) (PUSH IN)
25905514 HEATER, WSWA SOLV (BUILT PRIOR TO 07/14/08) (FOR 2ND DES SEE 25956850)
25956850 HEATER, WSWA SOLV (BUILT 07/14/08 & AFTER) (FOR 1ST DES SEE 25905514)
teamcadillac.ru
25731418 CAP, WSWA SOLV CNTNR (W/ISO SYMBOL) (10.154)
15942522 CONTAINER KIT, WSWA SOLV (2P & 1LS GROMMETS) (INCLS 24, 25) [БАЧОК СТЕКЛООМЫВАТЕЛЯ]
11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (WSWA SOLV CNTNR) [БОЛТ М6]
15213911 INDICATOR KIT, WSWA SOLV LVL (LEVEL SENSOR KIT WITH GROMMET) (INCLS 24) [ДАТЧИК УРОВНЯ ЖИДКОСТИ БАЧКА СТЕКЛООМЫВАТЕЛЯ]
15248578 GROMMET, WSWA SOLV CNTNR (LEVEL SENSOR GROMMET) (PART OF 21, 23) [ВТУЛКА ДАТЧИКА УРОВНЯ БАЧКА СТЕКЛООМЫВАТЕЛЯ]
15927514 GROMMET, WSWA PUMP (PUMP GROMMET) (PART OF 21, 26, 27) [УПЛОТНЯЮЩЕЕ КОЛЬЦО]
15942523 PUMP KIT, WSWA W/ SEAL (INCLS 25) (FRT PUMP KIT W/GROMMET) (ACDelco #15942523) [НАСОС СТЕКЛООМЫВАТЕЛЯ]
15942524 PUMP KIT, WSWA W/ SEAL (INCLS 25) (RR PUMP KIT W/GROMMET)
25887957 HOSE, R/WDO WA PUMP (СМ. ГРУППУ 16.000 "WIPER SYSTEM/ ЗАДНЕЕ ОКНО" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (REAR JUMPER HOSE)
15917649 HOSE, WSWA PUMP (FRT JUMPER HOSE)
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (WSWA SOLV HTR) [ГАЙКА М6]
15829099 LENS, W/S O/S MSTRE SEN (PART OF 8) (INCLS THE SILICON GEL) [КОЖУХ ДАТЧИКА ДОЖДЯ]
(TC16-960) - 2007-2009 CK1,2(06) СТЕКЛООЧИСТИТЕЛЬ-ЗАДНЕГО СТЕКЛА (C25)
15942522 CONTAINER KIT, WSWA SOLV (2P & 1LS GROMMETS) (INCLS 3) [БАЧОК СТЕКЛООМЫВАТЕЛЯ]
25887957 HOSE, R/WDO WA PUMP (REAR JUMPER HOSE)
15927514 GROMMET, WSWA PUMP (PUMP GROMMET) (PART OF 1, 4) [УПЛОТНЯЮЩЕЕ КОЛЬЦО]
teamcadillac.ru
15942524 PUMP KIT, WSWA W/ SEAL (INCLS 3) (RR PUMP KIT W/GROMMET)
25820075 RAMP, R/WDO WPR ARM PARK [УПОР ДЕРЖАТЕЛЯ ЩЕТКИ СТЕКЛООЧИСТИТЕЛЯ]
25820122 BLADE, R/WDO WPR [ЩЕТКА СТЕКЛООЧИСТИТЕЛЯ]
15798935 CAP, WSW ARM NUT (PART OF 10) [КОЛПАЧОК-ГАЙКИ ОЧИСТ.ЗАДН.СТКЛА]
11589150 ГАЙКА, HEX, W/ADH, M8X1.25X6.80, 5, GMW3359 (R/WDO WPR ARM) [ГАЙКА]
15277756 ARM, R/WDO WPR (INCLS 8) (INCLS HOSE) [ДЕРЖАТЕЛЬ ЩЕТКИ СТЕКЛООЧИСТИТЕЛЯ]
11569839 ГАЙКА, R/WDO WPR MOT
15173732 SPACER, R/WDO WPR MOT
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (R/WDO WPR ARM PARK RAMP) [ГАЙКА М6]
25923437 MOTOR, R/WDO WPR (INCLS MTG BOLTS AND GROMMETS) (ACDelco #25923437) [ЭЛЕКТРОДВИГАТЕЛЬ СТЕКЛООЧИСТИТЕЛЯ 90 ВТ]
25887953 HOSE, WSWA L/GATE EXTN RR (ACDelco #25887953)
20784419 HOSE, WSWA L/GATE EXTN SI LWR (ACDelco #20784419)
15076678 INSULATOR, WSW TRANS SUPT (16.686)
(TC16-961) - 2007-2009 CK1,2(06) WHEELHOUSE LINER/REAR
15938661 LINER, RR W/H PNL (INCLS 6) (W/NUT) [КРЫШКА]
15938662 LINER, RR W/H PNL (INCLS 6) (W/NUT) [ПОДКРЫЛОК]
11609459 SCREW, RND WA, M4.2X1.41X13, 7.2 THD, 11.35 OD, 6010M, GMW4205 (RR W/H PNL LNR) [ВИНТ]
teamcadillac.ru
11589292 PUSH PIN, FITS 8.5 DIA HOLE IN 2-4.5 THK PNL, NYLON 6/6 GMP.PA66.015 (RR W/H PNL LNR (PUSH IN)) [ФИКСАТОР ПАНЕЛИ БАМПЕРА]
01605396 RETAINER, PUSH-IN, FITS .250 HOLE, .92 LG.700-OD NYLON BLACK (RR W/H PNL LNR (PUSH IN))
11570498 БОЛТ, HWH W/FL WA, M4.2X1.41X20, 11.4 THD, 17 OD, ISO 2702 STL , GMW4205, T (RR W/H PNL LNR)
11513599 ГАЙКА, U-TYPE, M4.2X1.41, 0.65-3.80 PNL THK, PZ (PART OF 1) (ACDelco #11513599)
11518531 ГАЙКА, U-TYPE, M4.2X1.41, 15.9X8.4, .7-2.1 PNL, SAE 1050 STL, 7111M, 8.65 SQ HOL (RR W/H PNL) (10.512) [ГАЙКА М10]
(TC16-962) - 2007-2009 CK1,2,3 INSULATORS/DASH PANEL
15901816 INSULATOR, DA PNL (INTERIOR DASH)
15901817 INSULATOR, DA PNL (INTERIOR DASH)
teamcadillac.ru
25826685 INSULATOR, COWL S/PNL
25877094 INSULATOR, COWL S/PNL
25954935 INSULATOR, DA PNL (ДВИГАТЕЛЬ SIDE)
(TC16-963) - 2008-2009 CK107(06) FLOOR COVERING & СОПРЯЖЕННЫЕ ДЕТАЛИ (EXC HYBRID HP2)
15819120 MAT, R/FLR (BLACK)
15948218 CARPET, R/FLR PNL (INCLS 5, 15, 16) (EBONY)
20787982 CARPET, R/FLR PNL (INCLS 5, 15, 16) (CASHMERE)
25891808 CARPET, R/FLR PNL (INCLS 5, 15, 16) (EBONY)
25891811 CARPET, R/FLR PNL (INCLS 5, 15, 16) (LINEN)
25891812 CARPET, R/FLR PNL (INCLS 5, 15, 16) (TITANIUM)
25902610 CARPET, R/FLR PNL (INCLS 5, 15, 16) (CASHMERE)
25998505 MAT, R/FLR (BLACK)
11588960 БОЛТ, PAN HD, M10X1.5X38, 30 THD, 18OD, 10.8, 4205GMW, TORX, M-POINT (CARGO TIE DN HOOK)
15749157 HOOK, CARGO TIE DN (BLACK) (17.090)
15835448 INSULATOR, FLR PNL RR
20813426 INSULATOR, FLR PNL RR
20813427 INSULATOR, FLR PNL RR
25974423 INSULATOR, FLR PNL RR
15917244 DEADENER, RR W/H INR PNL
15917245 DEADENER, RR W/H INR PNL
25921050 INSULATOR, FLR PNL FRT
20787981 CARPET, F/FLR PNL (CASHMERE)
25850428 CARPET, F/FLR PNL (EBONY) [НАПОЛЬНОЕ ПОКРЫТИЕ САЛОНА]
25850432 CARPET, F/FLR PNL (LINEN)
25850434 CARPET, F/FLR PNL (EBONY)
25871788 CARPET, F/FLR PNL (TITANIUM)
25871789 CARPET, F/FLR PNL (TITANIUM)
25875582 CARPET, F/FLR PNL (CASHMERE)
25875583 CARPET, F/FLR PNL (CASHMERE)
25998503 MAT, F/FLR PNL (BLACK)
19121497 MAT, F/FLR AUX (EBONY) (TWIN) (NO LOGO) (16.800) [КОВРИКИ ПЕРЕДНИЕ]
19121915 MAT PKG, FRONT CARPET (EBONY) (TWIN) (NO LOGO) (15.286) [КОМПЛЕКТ КОВРИКОВ САЛОНА (2ШТ) 0.48 М2]
19149252 MAT, F/FLR AUX (TITANIUM) (TWIN) (NO LOGO) (15.286)
19206524 MAT PKG, FRONT CARPET (CASHMERE) (TWIN) (NO LOGO) (16.800)
19207995 MAT PKG, FRONT CARPET (COCOA) (TWIN) (NO LOGO) (16.800)
19121485 MAT, R/FLR AUX (EBONY) (TWIN) (16.800)
19121486 MAT, R/FLR AUX (TITANIUM) (TWIN) (16.800)
19121926 MAT PKG, REAR CARPET (EBONY) (TWIN) (16.800) [КОМПЛЕКТ КОВРИКОВ САЛОНА (2ШТ) 0.48 М2]
19206522 MAT, R/FLR AUX (CASHMERE) (TWIN) (16.800)
19206525 MAT PKG, REAR CARPET (CASHMERE) (TWIN) (16.800)
25913072 MAT PKG, REAR CARPET (COCOA) (1 PC) (16.800)
15948218 CARPET, R/FLR PNL (EBONY)
25871796 CARPET, R/FLR PNL (TITANIUM)
teamcadillac.ru
25875643 CARPET, R/FLR PNL (CASHMERE)
(TC16-965) - 2007-2009 CK1,2,3 INFLATABLE RESTRAINT SYSTEM
25812355 MODULE, I/P INFL RST (EBONY) [МОДУЛЬ УПРАВЛЕНИЯ ПРИБОРНОЙ ПАНЕЛЬЮ]
25812356 MODULE, I/P INFL RST (CASHMERE)
25812357 MODULE, I/P INFL RST (TITANIUM)
15874515 MODULE, STRG WHL INFL RST (EBONY) (LABELED 15874515) (DUAL LEVEL) (16.712)
15874516 MODULE, STRG WHL INFL RST (COCOA) (LABELED 15874516) (DUAL LEVEL) (INCLS EMBLEM) (16.712)
15874519 MODULE, STRG WHL INFL RST (EBONY) (LABELED 15874519) (DUAL LEVEL) (16.712)
15874520 MODULE, STRG WHL INFL RST (COCOA) (LABELED 15874520) (DUAL LEVEL) (16.712)
25784920 MODULE, STRG WHL INFL RST (COCOA) (DUAL LEVEL) (16.712)
25917968 MODULE, STRG WHL INFL RST (EBONY) (LABELED 25917968) (DUAL LEVEL) (16.712) [ПОДУШКА БЕЗОПАСНОСТИ]
25917969 MODULE, STRG WHL INFL RST (COCOA) (LABELED 25917969) (DUAL LEVEL) (16.712) [МОДУЛЬ]
25917971 MODULE, STRG WHL INFL RST (EBONY) (LABELED 25917971) (DUAL LEVEL) (16.712)
25917972 MODULE, STRG WHL INFL RST (COCOA) (LABELED 25917972) (DUAL LEVEL) (16.712)
21996989 TAG, INFL RST I/P MDL CAUTION (HANGING)
03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (INFL RST VEH ROLLOVER SEN)
25958754 SENSOR, INFL RST VEH ROLLOVER
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (INFL RST SEN & DIAGN MDL) [ГАЙКА М6]
20777732 MODULE, INFL RST SEN & DIAGN (LABELED 20777732) (FOR 1ST DES SEE 25794807)
25794807 MODULE, INFL RST SEN & DIAGN (LABELED 25794807) (FOR 2ND DES SEE 20777732)
25794815 SENSOR, F/END INFL RST DISCRM [ДАТЧИК ПОДУШКИ БЕЗОПАСНОСТИ]
teamcadillac.ru
22625546 INDICATOR, INFL RST I/P MDL (W/WORDS ON AND OFF FOR AIRBAG) (14.865)
22627868 INDICATOR, INFL RST I/P MDL (W/AIRBAG SYMBOLS FOR ON AND OFF) (14.865)
(TC16-966) - 2007-2009 CK107(06) INFLATABLE RESTRAINT SYSTEM/ROOF SIDE(ASF)
15939463 MODULE, INFL RST RF S/RL RR (INCLS 2, 3) (3RD ROW) [ПОДУШКА БЕЗОПАСНОСТИ]
15939464 MODULE, INFL RST RF S/RL RR (INCLS 2, 3) (3RD ROW) [ПОДУШКА БЕЗОПАСНОСТИ]
11609939 БОЛТ, HEX W/FLAT WA, M6X1X30, 21 THD, 17 OD, TAPPING (PART OF 1)
11609939 БОЛТ, HEX W/FLAT WA, M6X1X30, 21 THD, 17 OD, TAPPING (PART OF 6)
25881971 MODULE, RF S/RL INFL RST (INCLS 4, 5) (LABELED 25881971) (W/INFLATOR CANISTER LOCATED NEAR CENTER OF CUSHION) (FOR 1ST DES SEE 25903827) [МОДУЛЬ]
25881972 MODULE, RF S/RL INFL RST (INCLS 4, 5) (LABELED 25881972) (W/INFLATOR CANISTER LOCATED NEAR CENTER OF CUSHION) (FOR 1ST DES SEE 25903828) [МОДУЛЬ]
25897886 MODULE, RF S/RL INFL RST (INCLS 4, 5)
25897887 MODULE, RF S/RL INFL RST (INCLS 4, 5) [БОКОВАЯ ПОДУШКА БЕЗОПАСНОСТИ]
25903827 MODULE, RF S/RL INFL RST (INCLS 4, 5) (LABELED 25903827) (W/INFLATOR CANISTER LOCATED AT THE REAR EDGE OF CUSHION) (FOR 2ND DES SEE 25881971) [ПОДУШКА БЕЗОПАСНОСТИ]
25903828 MODULE, RF S/RL INFL RST (INCLS 4, 5) (LABELED 25903828) (W/INFLATOR CANISTER LOCATED AT THE REAR EDGE OF CUSHION) (FOR 2NDDES SEE 25881972) [ПОДУШКА БЕЗОПАСНОСТИ]
25794812 SENSOR, INFL RST SI IMP (MT ON FRT DR BEAM)
teamcadillac.ru
25794812 SENSOR, INFL RST SI IMP (MOUNTED ON FRT DR BEAM) (MT ON FRT DR BEAM)
(TC16-971) - 2007-2009 CK1(06-36) АРМАТУРА ДВЕРИ/SIDE FRONT ЧАСТЬ 1 (CADILLAC Z75)
20789461 WEATHERSTRIP, FRT & RR S/D UPR AUX (INCLS RETAINERS)
20789462 WEATHERSTRIP, FRT & RR S/D UPR AUX (INCLS RETAINERS) [УПЛОТНИТЕЛЬ ДВЕРИ]
25892949 WEATHERSTRIP, FRT S/D [УПЛОТНИТЕЛЬ ДВЕРИ]
25892950 WEATHERSTRIP, FRT S/D [УПЛОТНИТЕЛЬ ДВЕРИ]
15201414 PLATE, FRT S/D LK STKR ANC
10387651 WASHER, FRT S/D LK STKR (10.571)
25863993 STRIKER, FRT S/D LK (10.569)
09442471 БОЛТ, TORX HD, W/FLAT CSK, M8X1.25X35, 28 THD, 15.2 O.D., 9.8, NO (FRT S/D LK STKR)
20772075 MOLDING, FRT S/D WDO RVL [МОЛДИНГ СТЕКЛА ДВЕРИ]
25895274 MOLDING, FRT S/D WDO RVL
teamcadillac.ru
11588393 БОЛТ, FRT S/D O/S HDL (6 X 1 X 15, 7 THD) (8.900)
20828232 CLIP, FRT S/D O/S HDL (PART OF 12)
25960525 HANDLE, FRT S/D O/S (INCLS 11) (CHROME) (ORDER T/W CLIP-20828232) (FOR INSTLN PROCDR REF #09-08-64-023)
25960526 HANDLE, FRT S/D O/S (INCLS 11) (CHROME) [РУЧКА ДВЕРИ]
20835970 WEATHERSTRIP, FRT S/D LWR AUX (INCLS 13)
25784707 WEATHERSTRIP, FRT S/D LWR AUX (INCLS 13)
11562286 БОЛТ, FRT S/D HGE (8 X 1.25 X 24)
(TC16-973) - 2007-2009 CK1(06-36) АРМАТУРА ДВЕРИ/SIDE FRONT ЧАСТЬ 2 (CADILLAC Z75)
15140731 WINDOW, FRT S/D [СТЕКЛО]
15140732 WINDOW, FRT S/D [СТЕКЛО ПЕРЕДНЕЙ ДВЕРИ]
25865730 SEALING STRIP, FRT S/D WDO INR [УПЛОТНИТЕЛЬ ОКНА ДВЕРИ]
11589177 BOLT ASM, HEX HD, M6X1.0X18.0, GMW25 9.8 STL, GMW3359 (FRT S/D WDO FRT W/STR RET)
15792915 RETAINER, FRT S/D WDO W/STR FRT
15901807 RETAINER, FRT S/D WDO W/STR FRT
15876169 RETAINER, FRT S/D WDO W/STR RR (INCLS 6)
15876170 RETAINER, FRT S/D WDO W/STR RR (INCLS 6)
20849961 REGULATOR, FRT S/D WDO (INCLS 9-11, 18-20) (16.260) (ACDelco #20849961) [ЭЛЕКТРОДВИГАТЕЛЬ СТЕКЛОПОДЬЕМНОГО МЕХАНИЗМА В СБОРЕ, 120 ВТ]
25885879 REGULATOR, FRT S/D WDO (INCLS 9-11, 18-20) (W/MOTOR) (16.260) (ACDelco #25885879)
25978146 REGULATOR, FRT S/D WDO (INCLS 9-11, 18-20) (16.260) (ACDelco #25978146) [ЭЛЕКТРОДВИГАТЕЛЬ СТЕКЛОПОДЪЕМНИКА ДВЕРИ 80 ВТ В СБОРЕ С МЕХАНИЗМОМ]
15844874 MOTOR, FRT S/D WDO REG (PART OF 8) (USE ON REGULATORS W/BOTTOM NUT FASTENER) (ACDelco #15844874)
11589177 BOLT ASM, HEX HD, M6X1.0X18.0, GMW25 9.8 STL, GMW3359 (FRT S/D WDO REG)
15940389 HARNESS, FRT S/D DR WRG
teamcadillac.ru
15940390 HARNESS, FRT S/D DR WRG
15940393 HARNESS, FRT S/D DR WRG
15940394 HARNESS, FRT S/D DR WRG
15940397 HARNESS, FRT S/D DR WRG
15940398 HARNESS, FRT S/D DR WRG
20783848 LOCK, FRT S/D (INCLS 15)
25876384 LOCK, FRT S/D (INCLS 15)
25876385 LOCK, FRT S/D (INCLS 15) (W/ACTUATOR & CABLE) [ЗАМОК ДВЕРИ]
25876386 LOCK, FRT S/D (INCLS 15) (W/ACTUATOR & CABLE) [ЗАМОК ДВЕРИ]
25945751 LOCK, FRT S/D (INCLS 15) (INCLS ACTUATOR)
25945752 LOCK, FRT S/D (INCLS 15) (INCLS ACTUATOR)
25945753 LOCK, FRT S/D (INCLS 15)
25945754 LOCK, FRT S/D (INCLS 15) (W/ACTUATOR & CABLE) (W/O KEY CYL) [ЗАМОК ДВЕРИ]
15920704 HANDLE, FRT S/D I/S (EBONY) (W/CHROME HDL) [ВНУТРЕННЯЯ РУЧКА ПЕРЕДНЕЙ ДВЕРИ]
15920707 HANDLE, FRT S/D I/S (EBONY) (W/CHROME HDL) [РУЧКА ДВЕРИ]
15935951 HANDLE, FRT S/D I/S (EBONY) (W/CHROME REL HDL) [РУЧКА]
15935954 HANDLE, FRT S/D I/S (EBONY) (W/CHROME REL HANDLE) [РУКОЯТКА ДВЕРИ ВНУТРЕННЯЯ]
15940197 HANDLE, FRT S/D I/S (TITANIUM) (W/CHROME REL HANDLE) [РУЧКА]
25815291 HANDLE, FRT S/D I/S
25815292 HANDLE, FRT S/D I/S
25906817 HANDLE, FRT S/D I/S (CASHMERE)
25906818 HANDLE, FRT S/D I/S (CASHMERE)
11570136 БОЛТ, HEX HD, W/CON SPR WA, M6X1X23, 14 THD, 17 O.D., 8.8, GMW3359 (FRT S/D T/PNL)
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (FRT S/D WDO REG) [ГАЙКА М6]
15807100 PLUG, FRT S/D DRN HOLE
15039965 BUMPER, RR S/D
15175184 ROD, FRT S/D LKG [ТЯГА ЗАМКА ДВЕРИ]
15175185 ROD, FRT S/D LKG
15831543 ROD, FRT S/D O/S HDL [ТЯГА ЗАМКА ДВЕРИ]
15831544 ROD, FRT S/D O/S HDL
11517230 БОЛТ, TORX, W/WA, W/ADH, M6X1X20, 16.2 O.D., DOG PT, 10.9, GM6138M (FRT S/D LK) [ВИНТ ЗАМКА ДВЕРИ М6]
21110669 PLUG, FRT S/D O/S HDL ACC HOLE (35 MM) (ROUND) (12.179)
25887975 GROMMET, FRT S/D LKG ROD
11609385 ГАЙКА, U-TYPE, M6X1, 29.5 LEN, 12.5 WID, 19.5 CEN-END, 1050, GMW3359 (FRT S/D TR PNL) [ГАЙКА М 6]
15827500 ROD, FRT S/D LK CYL
15827501 ROD, FRT S/D LK CYL [ТЯГА ЗАМКА ДВЕРИ]
15904634 CYLINDER KIT, FRT S/D LK (UNCODED) [ЦИЛИНДР]
25960525 HANDLE, FRT S/D O/S (INCLS 32) (CHROME) (ORDER T/W CLIP-20828232) (FOR INSTLN PROCDR REF #09-08-64-023)
25960526 HANDLE, FRT S/D O/S (INCLS 32) (CHROME) [РУЧКА ДВЕРИ]
15228568 DOOR, FRT SI (СМ. ГРУППУ 16.000 "КУЗОВНЫЕ ДЕТАЛИSIDE" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/O HINGES)
25912653 DOOR, FRT SI (СМ. ГРУППУ 16.000 "КУЗОВНЫЕ ДЕТАЛИSIDE" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/O HINGES) [ПАНЕЛЬ ДВЕРИ]
25784518 MOLDING, FRT S/D WDO GARN
25784519 MOLDING, FRT S/D WDO GARN
(TC16-975) - 2007-2009 CK107(06) АРМАТУРА ДВЕРИ/SIDE REAR ЧАСТЬ 1 (CADILLAC Z75)
15201414 PLATE, RR S/D LK STKR ANC
25863993 STRIKER, RR S/D LK (10.569)
25831000 WEATHERSTRIP, RR S/D
15792912 WEATHERSTRIP, RR S/D FRT AUX [УПЛОТНИТЕЛЬ СТЕКЛА ДВЕРИ]
15792913 WEATHERSTRIP, RR S/D FRT AUX [УПЛОТНИТЕЛЬ СТЕКЛА ДВЕРИ]
teamcadillac.ru
25961382 DOOR, RR SI (СМ. ГРУППУ 16.000 "КУЗОВНЫЕ ДЕТАЛИ/ BODYSIDE" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ПАНЕЛЬ ДВЕРИ]
25961383 DOOR, RR SI (СМ. ГРУППУ 16.000 "КУЗОВНЫЕ ДЕТАЛИ/ BODYSIDE" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/O HINGES) [ЗАДНЯЯ ДВЕРЬ]
25895271 MOLDING, RR S/D WDO RVL
25895272 MOLDING, RR S/D WDO RVL
11517515 BOLT-HFH, M6X1X10, THD 8.5, OD 14.2, 9.8, GM6280, HDR PT. (RR S/D O/S HDL)
25960521 HANDLE, RR S/D O/S (CHROME) [РУЧКА ДВЕРИ]
25960522 HANDLE, RR S/D O/S (CHROME) [РУЧКА ДВЕРИ]
11562286 БОЛТ, RR S/D HGE (8 X 1.25 X 24)
25784684 WEATHERSTRIP, RR S/D LWR AUX (INCLS 18)
25784685 WEATHERSTRIP, RR S/D LWR AUX (INCLS 18)
25865733 SEALING STRIP, RR S/D WDO INR [УПЛОТНЕНИЕ]
15876895 MOLDING, RR S/D WDO GARN
15876896 MOLDING, RR S/D WDO GARN
(TC16-977) - 2007-2009 CK107(06) АРМАТУРА ДВЕРИ/SIDE REAR ЧАСТЬ 2
15140723 WINDOW, RR S/D [СТЕКЛО ДВЕРИ]
15140724 WINDOW, RR S/D [СТЕКЛО ДВЕРИ]
15140725 WINDOW, RR S/D [СТЕКЛО ЗАДНЕЙ ДВЕРИ]
15140726 WINDOW, RR S/D [СТЕКЛО ЗАДНЕЙ ДВЕРИ]
11589177 BOLT ASM, HEX HD, M6X1.0X18.0, GMW25 9.8 STL, GMW3359 (RR S/D WDO REG)
25885882 REGULATOR, RR S/D WDO (INCLS 3, 5, 6, 16, 17) (INCLS MOTOR) (ACDelco #25885882) [СТЕКЛОПОДЪЕМНИК ДВЕРИ]
25885883 REGULATOR, RR S/D WDO (INCLS 3, 5, 6, 16, 17) (INCLS MOTOR) (ACDelco #25885883) [РЕГУЛЯТОР В СБОРЕ]
11589177 BOLT ASM, HEX HD, M6X1.0X18.0, GMW25 9.8 STL, GMW3359 (PART OF 4)
15844874 MOTOR, RR S/D WDO REG (PART OF 4) (USE ON REGULATORS W/BOTTOM NUT FASTENER) (ACDelco #15844874)
15844877 MOTOR, RR S/D WDO REG (PART OF 4) (ACDelco #15844877)
teamcadillac.ru
15940429 HARNESS, RR S/D DR WRG (INCLS 7)
15940430 HARNESS, RR S/D DR WRG (INCLS 7)
15940431 HARNESS, RR S/D DR WRG (INCLS 7)
15940432 HARNESS, RR S/D DR WRG (INCLS 7)
20783857 LATCH, RR S/D (INCLS 9) (INCLS ACTUATOR) [ЗАМОК ДВЕРИ]
20783858 LATCH, RR S/D (INCLS 9) (INCLS ACTUATOR) [ЗАМОК ДВЕРИ]
25945740 LATCH, RR S/D (INCLS 9) (INCLS ACTUATOR)
25945741 LATCH, RR S/D (INCLS 9) (INCLS ACTUATOR)
15175416 ROD, RR S/D LAT [ТЯГА ЗАМКА ДВЕРИ]
15175417 ROD, RR S/D LAT
15844616 KNOB, RR S/D LKG ROD (EBONY) [КНОПКА БЛОКИРАТОРА ДВЕРИ]
15844617 KNOB, RR S/D LKG ROD (CASHMERE)
15844618 KNOB, RR S/D LKG ROD (TITANIUM)
15844620 KNOB, RR S/D LKG ROD (COCOA)
20785356 KNOB, RR S/D LKG ROD (CASHMERE)
15920683 HANDLE, RR S/D I/S (EBONY)
15920704 HANDLE, RR S/D I/S (EBONY) (W/CHROME HDL) [ВНУТРЕННЯЯ РУЧКА ПЕРЕДНЕЙ ДВЕРИ]
15939073 HANDLE, RR S/D I/S (EBONY) (W/CHROME REL HDL) [РУЧКА В СБОРЕ]
15939075 HANDLE, RR S/D I/S (CASHMERE) (W/CHROME REL HANDLE)
15939076 HANDLE, RR S/D I/S (COCOA) (W/CHROME REL HANDLE)
15939084 HANDLE, RR S/D I/S (EBONY) (W/CHROME REL HANDLE)
15939086 HANDLE, RR S/D I/S (CASHMERE) (W/CHROME REL HANDLE)
15939087 HANDLE, RR S/D I/S (COCOA) (W/CHROME REL HANDLE)
25815292 HANDLE, RR S/D I/S
25815293 HANDLE, RR S/D I/S
25906817 HANDLE, RR S/D I/S (CASHMERE)
25906822 HANDLE, RR S/D I/S (CASHMERE)
11570136 БОЛТ, HEX HD, W/CON SPR WA, M6X1X23, 14 THD, 17 O.D., 8.8, GMW3359 (RR S/D T/PNL)
11609385 ГАЙКА, U-TYPE, M6X1, 29.5 LEN, 12.5 WID, 19.5 CEN-END, 1050, GMW3359 (RR S/D T/PNL) [ГАЙКА М 6]
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (RR S/D WDO REG) [ГАЙКА М6]
21110669 PLUG, RR S/D O/S HDL ACC HOLE (35 MM) (ROUND) (12.179)
25887975 GROMMET, RR S/D LKG ROD
11609341 SCREW, RD WA HD 6-LOBE M6X1X19 (RR S/D LAT) [ВИНТ]
15831547 ROD, RR S/D O/S HDL
15831548 ROD, RR S/D O/S HDL
25890293 HANDLE, RR S/D O/S (BLACK TEXTURED BASE, PLATINUM CHROME HANDLE)
25890294 HANDLE, RR S/D O/S (BLACK TEXTURED BASE, PLATINUM CHROME HANDLE)
(TC16-978) - 2007-2009 CK1,2(06) ОКНА/СТОРОНА КУЗОВА
20777487 WINDOW, BODY SI RR (BUILT W/1 BUTTON CONN) (FOR 1ST DES SEE 25778989)
20777488 WINDOW, BODY SI RR (BUILT W/1 BUTTON CONN) (FOR 1ST DES SEE 25810430)
25778988 WINDOW, BODY SI RR
25778989 WINDOW, BODY SI RR (INCLS АНТЕННА) (BUILT W/2 BUTTON CONN) (FOR 2ND DES SEE 20777487)
25810430 WINDOW, BODY SI RR (INCLS АНТЕННА) (BUILT W/2 BUTTON CONN) (FOR 2ND DES SEE 20777488) [СТЕКЛО БАГАЖНОЙ ДВЕРИ]
25810433 WINDOW, BODY SI RR [СТЕКЛО ЗАДНЕЕ БОКОВОЕ]
15877496 MODULE, RDO ANT (СМ. ГРУППУ 09.000 "АНТЕННА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #15877496) (USED ON VEH WITH PART LABELED 15877496) (FOR 2ND DES SEE 25943786)
25943786 MODULE, RDO ANT (СМ. ГРУППУ 09.000 "АНТЕННА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (USED ON VEH WITH PART LABELED 25943786) (FOR 1ST DES SEE 15877496)
(TC16-979) - 2007-2009 CK1,2(06-36) SUNROOF (CF5)
25798334 WINDOW, SUN RF (INCLS 2, 3)
15242782 БОЛТ, SUN RF WDO (PART OF 1)
teamcadillac.ru
15837594 SEAL, SUN RF WDO (PART OF 1)
25942826 FRAME, SUN RF (INCLS 8) (W/O MOTOR) [КАРКАС ЛЮКА КРЫШИ КУЗОВА]
11518121 ГАЙКА, U, M6X1, MULTI THD, .5'-4.0' THK PNL (SUN RF MDL)
11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (SUN RF MDL) [БОЛТ М6]
11514623 БОЛТ, HEX W/CON WA, M6X1X20 (SUN RF MDL)
15837588 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, SUN RF (CASHMERE)
15846534 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, SUN RF (GRAY)
15905311 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, SUN RF (LINEN)
25874712 MOLDING, SUN RF PNL/WDO GARN (GRAY)
25874713 MOLDING, SUN RF PNL/WDO GARN (CASHMERE)
25874715 MOLDING, SUN RF PNL/WDO GARN (LINEN)
15837591 BRACKET, SUN RF MDL
15934722 MOTOR, SUN RF ACTR
11514623 БОЛТ, HEX W/CON WA, M6X1X20 (SUN RF ACTR)
20823530 COVER, SUN RF PNL SI OPG CLOSEOUT (BLACK)
20823531 COVER, SUN RF PNL SI OPG CLOSEOUT (BLACK)
15837592 DEFLECTOR, SUN RF AIR
15924423 STOP, SUN RF S/S (12.810)
(TC16-980) - 2007-2009 CK1,2(06-36) ВОДОСТОК КРЫШИ (CF5)
15164170 HOSE, SUN RF HSG RR DRN
15164171 HOSE, SUN RF HSG RR DRN
teamcadillac.ru
25836913 HOSE, SUN RF HSG FRT DRN
25836914 HOSE, SUN RF HSG FRT DRN
(TC16-982) - 2008-2009 CK1(06) КОНСОЛЬ/ПОЛ (G.M.C. Z88, DENALI Y91)
15946301 LINER, F/FLR CNSL F/CMPT (PART OF 2, 4) [ВСТАВКА ЛОТКА НАПОЛЬНОЙ КОНСОЛИ]
25902018 PUSHBUTTON, F/FLR CNSL COMPT DR LAT (INCLS 1) (PART OF 4) (MAPLE)
15250347 ARMREST, F/FLR CNSL (INCLS 1-3, 7, 35) (EBONY)
15250348 ARMREST, F/FLR CNSL (INCLS 1-3, 7, 35) (CASHMERE)
15217105 PANEL, F/FLR CNSL R/CMPT DR (EBONY)
15217106 PANEL, F/FLR CNSL R/CMPT DR (CASHMERE)
11609459 SCREW, RND WA, M4.2X1.41X13, 7.2 THD, 11.35 OD, 6010M, GMW4205 (F/FLR CNSL) [ВИНТ]
20817104 COMPARTMENT, F/FLR (INCLS 19, 22, 23) (EBONY)
20817105 COMPARTMENT, F/FLR (INCLS 19, 22, 23) (CASHMERE)
20817107 COMPARTMENT, F/FLR (INCLS 19, 22, 23) (EBONY)
teamcadillac.ru
20817108 COMPARTMENT, F/FLR (INCLS 19, 22, 23) (CASHMERE)
20817110 COMPARTMENT, F/FLR (INCLS 19, 22, 23) (EBONY)
20817111 COMPARTMENT, F/FLR (INCLS 19, 22, 23) (CASHMERE)
20817808 COMPARTMENT, F/FLR (INCLS 19, 22, 23) (CASHMERE)
25979500 COMPARTMENT, F/FLR (INCLS 19, 22, 23) (EBONY)
25979501 COMPARTMENT, F/FLR (INCLS 19, 22, 23) (CASHMERE)
15217101 PANEL, F/FLR FRT CNSL RR TR (EBONY)
15217102 PANEL, F/FLR FRT CNSL RR TR (CASHMERE)
15886277 MODULE, HTR & A/C & RDO CONT (СМ. ГРУППУ 09.000 "A/C & HEATER CONTROL" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #15886277)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 12) [ЗАЖИМ КОНСОЛИ САЛОНА]
15134825 BEZEL, F/FLR CNSL COMPT (INCLS 11, 13, 14, 15) (NO AUDIO JACKS)
15134826 BEZEL, F/FLR CNSL COMPT (INCLS 11, 13, 14, 15) (EBONY) (2 AUDIO JACKS)
15187371 RETAINER, ACSRY PWR RCPT (PART OF 12) (EBONY) (INCLS COVER) [ОКАНТОВКА ГНЕЗДА ПРИКУРИВАТЕЛЯ]
10375379 ADAPTER, AUDIO/VIDEO DISC PLYR (PART OF 12) (ACDelco #10375379)
15134790 LINER, F/FLR CNSL RR CUP HLDR (EBONY) (W/O FINGERS)
15134819 HOLDER, F/FLR RR CNSL CUP
15134821 HINGE, F/FLR CNSL COMPT DR (REAR CUPHOLDER DOOR HINGE)
25781989 HARNESS, F/FLR CNSL WRG (PART OF 8)
15134799 RETAINER, F/FLR CNSL (INCLS 32)
11610157 ГАЙКА, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (F/FLR CNSL) (10.701) [ГАЙКА М4]
20808897 УСИЛИТЕЛЬ, RDO SPKR (ACDelco #20808897) (LABELED 20808897)
25939528 УСИЛИТЕЛЬ, RDO SPKR (ACDelco #25939528) (LABELED 25939528 OR 15937318)
15134797 RETAINER, F/FLR CNSL (INCLS 28, 29)
25749635 RETAINER, ACSRY PWR RCPT (EBONY) (W/O CAP) [ВТУЛКА ГНЕЗДА ПРИКУРИВАТЕЛЯ]
15134801 MAT, F/FLR CNSL FRT COMPT (PART OF 20) (EBONY)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 33) [ЗАЖИМ КОНСОЛИ САЛОНА]
15070572 BUMPER, F/FLR RR CNSL A/RST (PART OF 4)
20811675 BEZEL, F/FLR FRT CNSL ACSRY TR (INCLS 36, 38, 39) (MAPLE) (W/HEAT STAKES)
25912890 BEZEL, F/FLR FRT CNSL ACSRY TR (INCLS 36, 38, 39) (BRUSH) (W/O HEAT STAKES)
(TC16-984) - 2008-2009 CK1(06) КОНСОЛЬ/ПОЛ ЧАСТЬ 1- LOWER (CADILLAC Z75, EXC PLATINUM EDITION ULT)
11609459 SCREW, RND WA, M4.2X1.41X13, 7.2 THD, 11.35 OD, 6010M, GMW4205 (PART OF 1, 36) [ВИНТ]
15886900 MODULE, HTR & A/C & RDO CONT
10375379 ADAPTER, AUDIO/VIDEO DISC PLYR (ACDelco #10375379)
22596346 BUMPER, F/FLR RR CNSL A/RST (10.242)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (F/FLR CNSL SI T/PNL) [ЗАЖИМ КОНСОЛИ САЛОНА]
15833953 COVER, HTR & A/C CONT OPG
25774623 RECEPTACLE, ACSRY PWR (ACSRY PWR RECEPTACLE ASSEM LABELED 4623) [ГНЕЗДО ПРИКУРИВАТЕЛЯ С КОНТАКТН. ЭЛЕМЕНТ., 12 ВТ]
15133100 LINER, F/FLR CNSL RR CUP HLDR (PART OF 19)
11609459 SCREW, RND WA, M4.2X1.41X13, 7.2 THD, 11.35 OD, 6010M, GMW4205 (PART OF 36) [ВИНТ]
11589106 SCREW, RND WA HD, M4.2X1.41X25, 19.2 THD, 11.3 OD, 6010M, GMW4205, C/R, TAP, (PART OF 36) (10.774) [БОЛТ]
11609459 SCREW, RND WA, M4.2X1.41X13, 7.2 THD, 11.35 OD, 6010M, GMW4205 (PART OF 19) [ВИНТ]
15133101 BUSHING, F/FLR CNSL CUP HLDR DR HGE (PART OF 19)
15133093 HOLDER, F/FLR CNSL RR CUP (INCLS 13, 17, 18)
15929132 HARNESS, F/FLR CNSL WRG
25912292 HARNESS, F/FLR CNSL WRG
20808898 УСИЛИТЕЛЬ, RDO SPKR (ACDelco #20808898)
11610157 ГАЙКА, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (PART OF 36) (10.701) [ГАЙКА М4]
15238666 PANEL, F/FLR CNSL SI TR FRT (INCLS 30, 31) (СМ. ГРУППУ 16.000 "ПРИБОРНАЯ ПАНЕЛЬ/TRIM" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА.) (EBONY) (16.081)
15923060 PANEL, F/FLR CNSL SI TR FRT (INCLS 30, 31) (СМ. ГРУППУ 16.000 "ПРИБОРНАЯ ПАНЕЛЬ/TRIM" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА.) (EBONY) (16.081)
25901544 PANEL, F/FLR CNSL SI TR FRT (INCLS 30, 31) (СМ. ГРУППУ 16.000 "ПРИБОРНАЯ ПАНЕЛЬ/TRIM" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА.) (CASHMERE)
25979584 PANEL, F/FLR CNSL SI TR FRT (INCLS 30, 31) (СМ. ГРУППУ 16.000 "ПРИБОРНАЯ ПАНЕЛЬ/TRIM" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА.) (CASHMERE)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 29) [ЗАЖИМ КОНСОЛИ САЛОНА]
11562257 RETAINER, I/P LWR TR PAD BRKT (PUSH ON) (PART OF 29) (19.5 X 30.4 X 1.8) (14.683)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 28, 36) [ЗАЖИМ КОНСОЛИ САЛОНА]
15187371 RETAINER, ACSRY PWR RCPT (PART OF 36) (EBONY) (INCLS COVER) [ОКАНТОВКА ГНЕЗДА ПРИКУРИВАТЕЛЯ]
25774623 RECEPTACLE, ACSRY PWR (PART OF 36) (ACSRY PWR RECEPTACLE ASSEM LABELED 4623) [ГНЕЗДО ПРИКУРИВАТЕЛЯ С КОНТАКТН. ЭЛЕМЕНТ., 12 ВТ]
25775480 COMPARTMENT, F/FLR (INCLS 1-4, 14-17, 21, 22, 24, 25, 28, 32-35) (LT CASHMERE)
25979634 COMPARTMENT, F/FLR (INCLS 1-4, 14-17, 21, 22, 24, 25, 28, 32-35) (EBONY)
25979635 COMPARTMENT, F/FLR (INCLS 1-4, 14-17, 21, 22, 24, 25, 28, 32-35) (CASHMERE)
25979640 COMPARTMENT, F/FLR (INCLS 1-4, 14-17, 21, 22, 24, 25, 28, 32-35) (EBONY)
25979641 COMPARTMENT, F/FLR (INCLS 1-4, 14-17, 21, 22, 24, 25, 28, 32-35) (CASHMERE)
11609460 SCREW, RND WA, M4.2X1.41X10, 4.2 THD, 11 OD, GM6010M, GMW4205, C/R, TAP (PART OF 39)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 39) [ЗАЖИМ КОНСОЛИ САЛОНА]
15909298 BEZEL, F/FLR FRT CNSL ACSRY TR (INCLS 37, 38, 40-43, 45, 46) (CHOCOLATE BURL)
20820047 BEZEL, F/FLR FRT CNSL ACSRY TR (INCLS 37, 38, 40-43, 45, 46) (CHOCOLATE) [ПАНЕЛЬ ЦЕНТРАЛЬНОЙ КОНСОЛИ]
25775309 BEZEL, F/FLR FRT CNSL ACSRY TR (INCLS 37, 38, 40-43, 45, 46) (RUBY)
22596346 BUMPER, F/FLR RR CNSL A/RST (PART OF 39) (10.242)
15132973 ПЕПЕЛЬНИЦА, F/FLR CNSL (PART OF 39)
15132964 HOLDER, F/FLR CNSL CUP (PART OF 39)
11516140 LIGHTER, CIG (BLACK) (W/LARGE, PLASTIC KNOB END 21.0MM) [ПРИКУРИВАТЕЛЬ]
25776667 RECEPTACLE, ACSRY PWR (PART OF 39) (2 TERMINALS) [ГНЕЗДО ПРИКУРИВАТЕЛЯ С КОНТАКТН. ЭЛЕМЕНТ., 12 ВТ]
25749635 RETAINER, ACSRY PWR RCPT (PART OF 39) (EBONY) (W/O CAP) [ВТУЛКА ГНЕЗДА ПРИКУРИВАТЕЛЯ]
(TC16-985) - 2007-2009 CK1(06) КОНСОЛЬ/КРЫША (CADILLAC Z75, ARS,CF5,UG1)
25786403 SWITCH, SUN RF (PART OF 5) (BLUE LAGOON BACK LIGHTING)
25786404 SWITCH, SUN RF (PART OF 5) (TRUE WHITE BACK LIGHTING)
15241529 MICROPHONE, MOBILE TEL (PART OF 5) (2-WAY CAVITY)
15211504 SWITCH, L/GATE ACTR (PART OF 5) (PART OF LIFT GATE PNL)
15299399 SWITCH, L/GATE ACTR (FULL OPEN SWITCH) (PART OF 5) (12.243)
teamcadillac.ru
25845571 SWITCH, L/GATE ACTR (PART OF 5) (PART OF RF КОНСОЛЬ)
15862407 SWITCH, R/SEAT #2 FLDG ACTR (PART OF 5) (ON КОНСОЛЬ)
20811136 КОНСОЛЬ, RF (INCLS 1-4, 6-8, 10-15) (LINEN) (W/O SW ASM)
25848251 КОНСОЛЬ, RF (INCLS 1-4, 6-8, 10-15) (GRAY)
25848252 КОНСОЛЬ, RF (INCLS 1-4, 6-8, 10-15) (LT CASHMERE) (W/LEAR TRANSMITTER KIT 25807341)
25848253 КОНСОЛЬ, RF (INCLS 1-4, 6-8, 10-15) (LINEN) (W/SW ASM)
25851515 КОНСОЛЬ, RF (INCLS 1-4, 6-8, 10-15) (COCOA) (2ND ROW)
25853059 КОНСОЛЬ, RF (INCLS 1-4, 6-8, 10-15) (CASHMERE) (2ND ROW DVD FACE PLT) (PO PNL ASM)
25977569 КОНСОЛЬ, RF (INCLS 1-4, 6-8, 10-15) (CASHMERE)
25977590 КОНСОЛЬ, RF (INCLS 1-4, 6-8, 10-15) (CASHMERE)
15853948 PUSHBUTTON, RDG LP SW (PART OF 5)
15911049 LENS, DM LP (PART OF 5) (1ST ROW) [КОЖУХ ФОНАРЯ ПОДСВЕТКИ САЛОНА]
09431809 BULB, 6CP TRADE #212-2 (PART OF 5) (ACDelco #L212-2)
25807341 TRANSMITTER, GARAGE DR OPENER (PART OF 5) (W/OWNERS INFO MANUAL)
11609345 ГАЙКА, PUSH-IN, 4.2, SAE 1050 STL, GMW3179 (PART OF 5)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 5) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
(TC16-986) - 2007-2009 CK1(06) КОНСОЛЬ/КРЫША (CADILLAC Z75, CF5,UG1, EXC ARS)
teamcadillac.ru
25786403 SWITCH, SUN RF (PART OF 4) (BLUE LAGOON BACK LIGHTING)
25786404 SWITCH, SUN RF (PART OF 4) (TRUE WHITE BACK LIGHTING)
15241529 MICROPHONE, MOBILE TEL (PART OF 4) (2-WAY CAVITY)
15211504 SWITCH, L/GATE ACTR (PART OF 4) (PART OF LIFT GATE PNL)
15299399 SWITCH, L/GATE ACTR (FULL OPEN SWITCH) (PART OF 4) (12.243)
15853948 PUSHBUTTON, RDG LP SW (PART OF 4)
15911049 LENS, DM LP (PART OF 4) (1ST ROW) [КОЖУХ ФОНАРЯ ПОДСВЕТКИ САЛОНА]
09431809 BULB, 6CP TRADE #212-2 (PART OF 4) (ACDelco #L212-2)
25807341 TRANSMITTER, GARAGE DR OPENER (PART OF 4) (W/OWNERS INFO MANUAL)
11609345 ГАЙКА, PUSH-IN, 4.2, SAE 1050 STL, GMW3179 (PART OF 4)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 4) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
(TC16-989) - 2007-2009 CK1(06) КОНСОЛЬ/КРЫША (CADILLAC Z75, ARS,UG1, EXC CF5)
15911047 BRACKET, RF RR CNSL (PART OF 6)
11516630 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (PART OF 6)
15241529 MICROPHONE, MOBILE TEL (PART OF 6) (2-WAY CAVITY)
15862407 SWITCH, R/SEAT #2 FLDG ACTR (PART OF 6) (ON КОНСОЛЬ)
15913173 КОНСОЛЬ, RF (INCLS 1-5, 7-10, 12-17) (LT CASHMERE) (W/LEAR TRANSMITTER KIT 25807341)
15913181 КОНСОЛЬ, RF (INCLS 1-5, 7-10, 12-17) (LT CASHMERE) (W/LEAR TRANSMITTER KIT 25807341)
25977569 КОНСОЛЬ, RF (INCLS 1-5, 7-10, 12-17) (CASHMERE)
25977626 КОНСОЛЬ, RF (INCLS 1-5, 7-10, 12-17) (CASHMERE)
teamcadillac.ru
15853948 PUSHBUTTON, RDG LP SW (PART OF 6)
15911049 LENS, DM LP (PART OF 6) (1ST ROW) [КОЖУХ ФОНАРЯ ПОДСВЕТКИ САЛОНА]
09431809 BULB, 6CP TRADE #212-2 (PART OF 6) (ACDelco #L212-2)
25807341 TRANSMITTER, GARAGE DR OPENER (PART OF 6) (W/OWNERS INFO MANUAL)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 6) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
11609345 ГАЙКА, PUSH-IN, 4.2, SAE 1050 STL, GMW3179 (PART OF 6)
(TC16-990) - 2007-2009 K1(06) КОНСОЛЬ/КРЫША (CADILLAC Z75, ARS, EXC CF5,UG1)
15836896 КОНСОЛЬ, RF (INCLS 1-5, 7-10, 12-14) (GRAY) (NON-DVD CNSL)
15889641 КОНСОЛЬ, RF (INCLS 1-5, 7-10, 12-14) (LT CASHMERE)
teamcadillac.ru
25853059 КОНСОЛЬ, RF (INCLS 1-5, 7-10, 12-14) (CASHMERE) (2ND ROW DVD FACE PLT) (PO PNL ASM)
25977661 КОНСОЛЬ, RF (INCLS 1-5, 7-10, 12-14) (GRAY)
(TC16-992) - 2007-2009 CK1(06) КОНСОЛЬ/КРЫША (CADILLAC Z75, UG1, EXC ARS,CF5)
15911047 BRACKET, RF RR CNSL (PART OF 5)
11516630 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (PART OF 5)
15913180 КОНСОЛЬ, RF (INCLS 1-4, 6-9, 11-16) (GRAY) (W/LEAR TRANSMITTER KIT 25807341)
15913181 КОНСОЛЬ, RF (INCLS 1-4, 6-9, 11-16) (LT CASHMERE) (W/LEAR TRANSMITTER KIT 25807341)
25977569 КОНСОЛЬ, RF (INCLS 1-4, 6-9, 11-16) (CASHMERE)
teamcadillac.ru
(TC16-993) - 2007-2009 K1(06) КОНСОЛЬ/КРЫША (CADILLAC Z75, EXC ARS,CF5,UG1)
teamcadillac.ru
25807240 КОНСОЛЬ, RF (INCLS 1-4, 6-9, 11-13) (GRAY)
25851515 КОНСОЛЬ, RF (INCLS 1-4, 6-9, 11-13) (COCOA) (2ND ROW)
25853059 КОНСОЛЬ, RF (INCLS 1-4, 6-9, 11-13) (CASHMERE) (2ND ROW DVD FACE PLT) (PO PNL ASM)
(TK16-001) - 2008-2009 CK1(06) КОНСОЛЬ/ПОЛ-КРЫШКА (CADILLAC Z75, PLATINUM EDITION ULT)
teamcadillac.ru
20858323 PANEL, F/FLR CNSL COMPT DR (INCLS 9) (COCOA) (UPR) (16.585)
20858384 PANEL, F/FLR CNSL COMPT DR INR (INCLS 8)
20858329 LID, F/TOP STOW COMPT (INCLS 4, 5, 7) (COCOA) (LWR)
11609459 SCREW, RND WA, M4.2X1.41X13, 7.2 THD, 11.35 OD, 6010M, GMW4205 (PART OF 3) [ВИНТ]
22596346 BUMPER, F/FLR RR CNSL A/RST (PART OF 3) (10.242)
25778771 BUMPER, F/FLR RR CNSL A/RST (PART OF 2)
25830489 MAT, F/FLR CNSL STOR TRAY (PART OF 1)
(TK16-002) - 2008-2009 CK1(06) КОНСОЛЬ/ПОЛ-КРЫШКА (CADILLAC Z75, EXC PLATINUM EDITION ULT)
teamcadillac.ru
15220797 PANEL, F/FLR CNSL COMPT DR (EBONY) (UPR) (16.585)
25906815 PANEL, F/FLR CNSL COMPT DR (CASHMERE) (UPR) (16.585)
15133062 PANEL, F/FLR CNSL COMPT DR INR (INCLS 8) (W/LATCH)
20858325 LID, F/TOP STOW COMPT (INCLS 4, 5, 7) (EBONY) (LOWER)
20858327 LID, F/TOP STOW COMPT (INCLS 4, 5, 7) (CASHMERE) (LOWER)
(TK16-900) - 2008-2009 CK107(06) FLOOR COVERING & СОПРЯЖЕННЫЕ ДЕТАЛИ (HYBRID HP2)
25783700 CARPET, R/FLR PNL (INCLS 2-4) (EBONY)
25783706 CARPET, R/FLR PNL (INCLS 2-4) (EBONY)
25871798 CARPET, R/FLR PNL (INCLS 2-4) (TITANIUM)
25875645 CARPET, R/FLR PNL (INCLS 2-4) (CASHMERE)
25891889 CARPET, R/FLR PNL (INCLS 2-4) (TITANIUM)
25902611 CARPET, R/FLR PNL (INCLS 2-4) (CASHMERE)
25813593 COVER, R/SEAT RSR INR FIN (СМ. ГРУППУ 16.000 "КРЕПЛЕНИЕ ЗАДНЕГО СИДЕНЬЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (EBONY)
25813594 COVER, R/SEAT RSR INR FIN (СМ. ГРУППУ 16.000 "КРЕПЛЕНИЕ ЗАДНЕГО СИДЕНЬЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (CASHMERE)
25813595 COVER, R/SEAT RSR INR FIN (СМ. ГРУППУ 16.000 "КРЕПЛЕНИЕ ЗАДНЕГО СИДЕНЬЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (TITANIUM)
20813429 INSULATOR, FLR PNL RR
20813430 INSULATOR, FLR PNL RR
25783717 INSULATOR, FLR PNL RR
teamcadillac.ru
90584197 DEADENER, FLR PNL (88X220MM) (6.758)
15294099 INSULATOR, BAT (СМ. ГРУППУ 02.000 "КРЕПЛЕНИЕ АККУМУЛЯТОРА/DRIVE MOTOR" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (LABELED 15294099)
25961362 INSULATOR, BAT (СМ. ГРУППУ 02.000 "КРЕПЛЕНИЕ АККУМУЛЯТОРА/DRIVE MOTOR" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (LABELED 2591362)
25901778 INSULATOR, FLR PNL FRT
25873426 CARPET, F/FLR PNL (EBONY)
25873429 CARPET, F/FLR PNL (TITANIUM)
25902606 CARPET, F/FLR PNL (CASHMERE)
25783706 CARPET, R/FLR PNL (EBONY)
25871798 CARPET, R/FLR PNL (TITANIUM)
25875645 CARPET, R/FLR PNL (CASHMERE)
25783718 INSULATOR, FLR PNL RR
(TK16-904) - 2009 CK1(06) ПРИБОРНАЯ ПАНЕЛЬ & СОПРЯЖЕННЫЕ ДЕТАЛИ ЧАСТЬ 1 TRIM (CADILLAC Z75)
25903822 PANEL, I/P UPR TR (W/ W/S DEFR NOZ GRL) (INCLS 2, 57) (EBONY) [ПАНЕЛЬ В СБОРЕ]
25903825 PANEL, I/P UPR TR (W/ W/S DEFR NOZ GRL) (INCLS 2, 57) (COCOA)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 1) [ЗАЖИМ КОНСОЛИ САЛОНА]
15221850 GRILLE, RDO FRT SPKR (INCLS 4) (EBONY)
15221851 GRILLE, RDO FRT SPKR (INCLS 4) (COCOA)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 3) [ЗАЖИМ КОНСОЛИ САЛОНА]
15813116 GRILLE, SI WDO DEFG OTLT (EBONY) (*KIT2)
15813117 GRILLE, SI WDO DEFG OTLT (COCOA) (*KIT2)
15813143 GRILLE, SI WDO DEFG OTLT (EBONY) (*KIT2)
15813144 GRILLE, SI WDO DEFG OTLT (COCOA) (*KIT2)
15813113 PANEL, I/P UPR TR (EBONY) (W/O GRILLES) (*KIT2)
15813114 PANEL, I/P UPR TR (COCOA) (W/O GRILLES) (*KIT2)
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (I/P UPR TR PAD) (9.665) [БОЛТ М4.2Х1.41Х25]
11610157 ГАЙКА, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (PART OF 9) (10.701) [ГАЙКА М4]
15876609 PANEL, I/P LWR TR (INCLS 8, 53) (COCOA)
15941681 PANEL, I/P LWR TR (INCLS 8, 53) (EBONY)
25901546 PANEL, I/P LWR TR (INCLS 8, 53) (CASHMERE)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 12, 50) [ЗАЖИМ КОНСОЛИ САЛОНА]
25976634 DEFLECTOR, I/P OTR AIR OTLT (PART OF 12) (EBONY)
15933153 PLATE, I/P TR (INCLS 10, 11) (RUBY) [ВОЗДУХОВОД ВЕНТИЛЯЦИИ САЛОНА]
15933154 PLATE, I/P TR (INCLS 10, 11) (CHOCOLATE) [ПОДДОН]
25957799 PLATE, I/P TR (INCLS 10, 11) (OLIVE)
25970322 PLATE, I/P TR (INCLS 10, 11, 13) (RUBY)
25970323 PLATE, I/P TR (INCLS 10, 11, 13) (CHOCOLATE)
25971121 EMBLEM, I/P (PART OF 12)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 15) [ЗАЖИМ КОНСОЛИ САЛОНА]
15854787 COVER, I/P COMPT ACC HOLE (INCLS 14) (EBONY) (GLOVE BOX) [НАКЛАДКА ЦЕНТРАЛЬНОЙ КОНСОЛИ]
15216569 DOOR, I/P COMPT (CASHMERE) (W/O LATCH, W/O PASS AIRBAG SWITCH) (*KIT1)
25913906 DOOR, I/P COMPT (CASHMERE) (W/LATCH) (*KIT1)
15854854 BUMPER, I/P COMPT DR STOP (BIN) (*KIT1) (16.110)
11609509 SCREW, LG RD WA HD, C/R, HI-LO, 4.2X1.41X13, 11.35-OD, B PT, 6010, GMW4205 (I/P COMPT DR) (*KIT1)
15683368 BUMPER, I/P COMPT (8.80 DIA) (CLOSED-STOP) (FRAME) (*KIT1) (16.650)
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (I/P COMPT DR) (9.665) [БОЛТ М4.2Х1.41Х25]
11609539 SCREW, RD CROWNED WA HD, M4.2X1.41X16, STL ISO 2702, GMW4205 (I/P COMPT DR LAT STKR) (*KIT1) [ВИНТ]
11610157 ГАЙКА, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (I/P LWR TIE BAR) (*KIT1) (10.701) [ГАЙКА М4]
11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (I/P COMPT DR HGE) (*KIT1) [ВИНТ М4]
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (I/P ACSRY CTR TR PLT) (*KIT3) [ЗАЖИМ КОНСОЛИ САЛОНА]
25976636 DEFLECTOR, I/P CTR AIR OTLT (EBONY) (*KIT3) [ВОЗДУХОВОД ВЕНТИЛЯЦИИ САЛОНА]
13502637 LATCH, I/P COMPT DR (EBONY) (W/LOCK) (PO DR & COMPMNT ASM) (*KIT1)
25960447 LATCH, I/P COMPT DR (LINEN) (W/LOCK) (*KIT1) (10.268)
15794823 CYLINDER, I/P COMPT DR LK [ЦИЛИНДР ЗАМКА ПЕРЧАТОЧНОГО ЯЩИКА]
25878605 PLATE, I/P ACSRY CTR TR (RUBY BURLWOOD) (W/O DEFLECTORS) (*KIT3) [ПАНЕЛЬ ЦЕНТРАЛЬНОЙ КОНСОЛИ]
25878606 PLATE, I/P ACSRY CTR TR (CHOCOLATE BURL) (W/O DEFLECTORS) (*KIT3)
25976638 DEFLECTOR, I/P CTR AIR OTLT (EBONY) (*KIT3) [ВОЗДУХОВОД ВЕНТИЛЯЦИИ САЛОНА]
10365827 INSULATOR, I/P (W/O FELT TAPE)
25790726 INSULATOR, I/P (W/FELT TAPE)
11609370 BOLT-HWH, M4.2X1.41X20, HI - LOW THD, , OD 12, 6010 STL, GMW4205, TAP (I/P INSL) (9.667)
15238666 PANEL, F/FLR CNSL SI TR FRT (INCLS 36) (EBONY) (16.081)
15876585 PANEL, F/FLR CNSL SI TR FRT (INCLS 36-38, 58) (LINEN)
15876587 PANEL, F/FLR CNSL SI TR FRT (INCLS 36) (LINEN)
15923060 PANEL, F/FLR CNSL SI TR FRT (INCLS 36-38, 58) (EBONY) (16.081)
25901544 PANEL, F/FLR CNSL SI TR FRT (INCLS 36) (CASHMERE)
25979584 PANEL, F/FLR CNSL SI TR FRT (INCLS 36-38, 58) (CASHMERE)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 35) [ЗАЖИМ КОНСОЛИ САЛОНА]
11588920 SCREW, W/RND WA, M3.5X1.59X9.5, 6 THD, 7 O.D., GM512M, GMW3044 (PART OF 35)
15240415 MICROPHONE, RDO VOL COMP INTR NOISE (PART OF 35)
15221547 PLATE, HDLP SW TR (INCLS 40, 41) (EBONY)
15907806 PLATE, HDLP SW TR (INCLS 40, 41)
11610112 CLIP, HDLP (PART OF 39) (10.4 X 13 X 9) (14.683)
15844177 BOLSTER, I/P DRVR KNEE (INCLS 42) (EBONY)
15844178 BOLSTER, I/P DRVR KNEE (INCLS 42) (CASHMERE)
15856685 BOLSTER, I/P DRVR KNEE (INCLS 42) (EBONY) [БУФЕР]
15856686 BOLSTER, I/P DRVR KNEE (INCLS 42) (CASHMERE)
15876573 BOLSTER, I/P DRVR KNEE (INCLS 42) (LINEN)
25894674 BOLSTER, I/P DRVR KNEE (INCLS 42) (LINEN)
11589012 БОЛТ, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (I/P DRVR KNEE BOLS) (9.665) [БОЛТ М4.2Х1.41Х25]
25855840 COVER, I/P FUSE BLK ACC HOLE (INCLS 46) (EBONY) [БОКОВАЯ КРЫШКА ЦЕНТРАЛЬНОЙ КОНСОЛИ]
25896366 COVER, I/P FUSE BLK ACC HOLE (INCLS 46) (LINEN)
25901548 COVER, I/P FUSE BLK ACC HOLE (INCLS 46) (CASHMERE)
25940492 COVER, I/P FUSE BLK ACC HOLE (INCLS 46-49) (EBONY)
25940497 COVER, I/P FUSE BLK ACC HOLE (INCLS 46-49) (LINEN)
25940498 COVER, I/P FUSE BLK ACC HOLE (INCLS 46-49) (CASHMERE)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 45) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
12092079 FUSE, 10A, MINI, RED (PART OF 45)
88909749 FUSE, 3A, MINI, VIOLET (PART OF 45) (8.965) (ACDelco #ATM3-25)
88909754 FUSE, 15A, MINI, BLUE (PART OF 45) (ACDelco #ATM15-25) [ПРЕДОХРАНИТЕЛЬ 15 А]
88909755 FUSE, 20A, MINI, YELLOW (PART OF 45) (ACDelco #ATM20-25) [ПРЕДОХРАНИТЕЛЬ 20 А]
88909756 FUSE, 25A, MINI, CLEAR (PART OF 45) (ACDelco #ATM25-25) [ПРЕДОХРАНИТЕЛЬ, 25A]
12084791 PULLER, FUSE (PART OF 45) (MINI) (I/P COVER)
25940508 LABEL, FUSE BLK IDENT (PART OF 45)
15863360 PLATE, I/P TR (INCLS 10, 51) (RUBY)
15863361 PLATE, I/P TR (INCLS 10, 51) (CHOCOLATE)
15876619 PLATE, I/P TR (INCLS 10, 51) (BURL)
teamcadillac.ru
25976632 DEFLECTOR, I/P OTR AIR OTLT (PART OF 50) (EBONY)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 54) [ЗАЖИМ КОНСОЛИ САЛОНА]
11513599 ГАЙКА, U-TYPE, M4.2X1.41, 0.65-3.80 PNL THK, PZ (PART OF 9) (ACDelco #11513599)
25914313 PLATE, I/P CSTR TR (INCLS 52, 56) (EBONY)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (I/P UPR TR PLT) (*KIT2) [ЗАЖИМ КОНСОЛИ САЛОНА]
25603681 INSULATOR, I/P CSTR TR PLT (PART OF 54) (BLACK/RUBBER) (*KIT3)
11562257 RETAINER, I/P LWR TR PAD BRKT (PUSH ON) (PART OF 35) (19.5 X 30.4 X 1.8) (14.683)
25965502 DOOR, I/P COMPT (INCLS 16-19, 21-26, 29) (LINEN)
25965503 DOOR, I/P COMPT (INCLS 16-19, 21-26, 29) (EBONY)
25965505 DOOR, I/P COMPT (INCLS 16-19, 21-26, 29) (CASHMERE)
15876611 PANEL, I/P UPR TR (INCLS 5, 6, 55) (COCOA) (W/LINEN TRIM) (BUILT PRIOR TO 7/29/08) (FOR 2ND DES SEE 25993686)
15929999 PANEL, I/P UPR TR (INCLS 5, 6, 55) (EBONY) (CADILLAC)
15930000 PANEL, I/P UPR TR (INCLS 5, 6, 55) (COCOA) (W/CASHMERE TRIM)
25993686 PANEL, I/P UPR TR (INCLS 5, 6, 55) (COCOA) (W/LINEN TRIM) (BUILT 7/29/08 & AFTER) (FOR 1ST DES SEE 15876611)
15876615 PLATE, I/P ACSRY CTR TR (INCLS 27, 28, 31, 32, 56) (PLATINUM)
25878602 PLATE, I/P ACSRY CTR TR (INCLS 27, 28, 31, 32, 56) (RUBY) (W/PLATE & DEFLECTORS)
25878603 PLATE, I/P ACSRY CTR TR (INCLS 27, 28, 31, 32, 56) (CHOCOLATE BURL) (W/DEFLECTORS) [НАКЛАДКА ПАНЕЛИ]
25878605 PLATE, I/P ACSRY CTR TR (INCLS 27, 28, 31, 32, 56) (RUBY BURLWOOD) (W/O DEFLECTORS) [ПАНЕЛЬ ЦЕНТРАЛЬНОЙ КОНСОЛИ]
25878606 PLATE, I/P ACSRY CTR TR (INCLS 27, 28, 31, 32, 56) (CHOCOLATE BURL) (W/O DEFLECTORS)
(TK16-910) - 2009 CK1,2(06) CAMERA SYSTEM/REAR VIEW (UVC)
25872958 HARNESS, RR LIC PLT LP WRG
teamcadillac.ru
03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (L/GATE CTR MLDG)
(TK16-914) - 2009 CK1(06) WIPER SYSTEM/ВЕТРОВОЕ СТЕКЛО (POLICE PACKAGE PPV)
20773355 ARM, WSW (INCLS 2) (BLACK)
20773356 ARM, WSW (INCLS 2) (BLACK)
15776792 CAP, WSW ARM FIN (PART OF 1) [КОЛПАЧОК ДЕРЖАТЕЛЯ ЩЕТКИ СТЕКЛООЧИСТИТЕЛЯ]
25820729 PANEL, AIR INL GRL (INCLS 5) (BLACK) [НАКЛАДКА ВОДОСТОЧНОЙ ПАНЕЛИ]
25820730 PANEL, AIR INL GRL (INCLS 5) (BLACK) [НАКЛАДКА ВОДОСТОЧНОЙ ПАНЕЛИ]
11609796 CLIP, AIR INL GRL PNL (PART OF 4) (11.0 X 12.9 X 6.1MM) (8.950)
25872303 PANEL, AIR INL GRL (CTR) (INCLS 10, 15, 18) (BLACK)
11609797 БОЛТ, AIR INL GRL PNL (10.268)
11516578 БОЛТ, HEX W/FL WA, M6X1X25, 16 THD, 24 OD, 9.8, 7114M, MACH, 6MM P PT. (WSWA SOLV CNTNR)
teamcadillac.ru
11516793 ГАЙКА, HEX, W/CON WA, M6X1X5.5, 16 O.D., 9, 7111M (WSWA SOLV HTR)
20779836 SPACER, AIR INL GRL PNL
(TX16-004) - 2007-2009 CK1,2,3 РЕМНИ БЕЗОПАСНОСТИ (EXTENSION KIT)
89024296 EXTENSION KIT, F/SEAT BELT (BLACK) (9") (14.875) (REFER TO GMSPO INFORMATION BULLETIN ON SEAT BELT EXTENDERS FOR DETAILED INFORMATION)
teamcadillac.ru
89024297 EXTENSION KIT, F/SEAT BELT (BLACK) (15") (14.875) (REFER TO GMSPO INFORMATION BULLETIN ON SEAT BELT EXTENDERS FOR DETAILED INFORMATION)
17 - ЗАДНИЕ КУЗОВНЫЕ ДЕТАЛИ-МОЛДИНГИ-ОТДЕЛКА ГРУЗОВОГО ОТДЕЛА
(TC17-744) - 2007-2009 CK107(06) БАГАЖНИК (G.M.C. Z88, DENALI Y91, V54)
15838222 RAIL, LUGG CARR CR (BLACK) [ВНЕШНИЙ ВЕРХНИЙ БАГАЖНИК]
25787589 COVER, LUGG CARR S/RL RR FIN (PAINT TO MATCH) (*KIT1, KIT2)
11518684 ГАЙКА, LUGG CARR SUPT (M6X1X16) (HEX CHROME FREE FINISH) [ГАЙКА М6]
15916756 PLATE, LUGG CARR S/RL BRKT ANC
11609900 SCREW, PAN WASH, M6X1X39, 31 THD, 12.25 OD, 8.8, GMW4700, TORX, MACH, 'P'POI (LUGG CARR SUPT)
25892761 RAIL, LUGG CARR SI (CHROME) (*KIT1)
25892762 RAIL, LUGG CARR SI (CHROME) (*KIT1)
25787559 COVER, LUGG CARR S/RL FRT FIN (PAINT TO MATCH) (*KIT1, KIT3)
25787560 COVER, LUGG CARR S/RL FRT FIN (PAINT TO MATCH) (*KIT1, KIT3)
25836350 RAIL KIT, LUGG CARR SI (INCLS 2, 6, 7) (CHROME)
25996381 RAIL KIT, LUGG CARR SI (INCLS 2, 6, 7) (CHROME)
25832914 COVER KIT, LUGG CARR S/RL ACC HOLE RR (INCLS 2) (INCLS PAINT TO MATCH COVER)
25832915 COVER KIT, LUGG CARR S/RL ACC HOLE RR (INCLS 2) (INCLS PAINT TO MATCH COVER)
teamcadillac.ru
25832916 COVER KIT, LUGG CARR S/RL ACC HOLE FRT (INCLS 7) (PAINT TO MATCH)
25832917 COVER KIT, LUGG CARR S/RL ACC HOLE FRT (INCLS 7) (PAINT TO MATCH)
(TC17-909) - 2007-2009 CK1(06) АРМАТУРА ОТКРЫВАНИЯ(ПОДЪЕМА) ДВЕРИ ЧАСТЬ 1 (CADILLAC Z75)
15262791 APPLIQUE, Q/PNL UPR (PAINT TO MATCH)
25970600 APPLIQUE, Q/PNL UPR (PAINT TO MATCH) [УГЛОВАЯ ПАНЕЛЬ ЗАДНЕЙ СТОЙКИ КУЗОВА]
11569711 ГАЙКА, PUSH-IN, M4.2X1.41, 0.7-2.15 PNL THK, SAE 1050-1065, GMW3359 W/ (Q/PNL UPR APLQ) [ГАЙКА М4.2]
11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (Q/PNL UPR APLQ) [ВИНТ]
25916023 WINDOW, L/GATE (INCLS 25, 26) [СТЕКЛО БАГАЖНОЙ ДВЕРИ]
teamcadillac.ru
25916024 WINDOW, L/GATE (INCLS 25, 26) [СТЕКЛО БАГАЖНОЙ ДВЕРИ]
25949077 WEATHERSTRIP, L/GATE WDO [УПЛОТНЕНИЕ ДВЕРИ]
25867975 GATE, LIFT [ПАНЕЛЬ ЗАДНЕЙ ОТКИДНОЙ ДВЕРИ]
15038385 BUMPER, L/GATE WDO
11562471 STUD, L/GATE STRUT BALL (L/GATE SI) (8.015)
15161943 STRUT, L/GATE WDO [АМОРТИЗАЦИОННАЯ СТОЙКА СТЕКЛА ЗАДНЕЙ ОТКИДНОЙ ДВЕРИ]
15161944 STRUT, L/GATE WDO
15875510 HINGE, L/GATE
11519388 БОЛТ, HX HD CON WA, M8X1.25X25, 20 THD, 24 OD, 8.8, GMW3359 (SILVER), M-POINT (L/GATE HGE (L/GATE SI)) [БОЛТ]
11609341 SCREW, RD WA HD 6-LOBE M6X1X19 (L/GATE STRUT BRKT (L/GATE SI)) [ВИНТ]
15891962 BRACKET, L/GATE STRUT (L/GATE SI)
11518445 SCREW, FLAT-HD HEX ALLEN, CSINK, M8X1.25X25, 18.05 THD, 14.7 OD, 8.8, GMW3044. (L/GATE LK STKR) [БОЛТ М8Х1.25]
15134851 STRIKER, L/GATE LK
15827433 STRUT, L/GATE [АМОРТИЗАЦИОННАЯ СТОЙКА ЗАДНЕЙ ОТКИДНОЙ ДВЕРИ]
15854712 STRUT, L/GATE [АМОРТИЗАЦИОННАЯ СТОЙКА ЗАДНЕЙ ОТКИДНОЙ ДВЕРИ]
15892254 BUMPER, L/GATE
15816854 VALVE, BK BODY OPG FRM PRESS RLF
11561717 STUD, L/GATE STRUT (BODY SI) (M8X1.25X25) (STAINLESS STEEL)
11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (L/GATE HGE (BODY SI)) [ГАЙКА]
25815980 WEATHERSTRIP, L/GATE [УПЛОТНЕНИЕ ЗАДНЕЙ ОТКИДНОЙ ДВЕРИ]
11610075 RING, FOR 6MM DIA SHAFT, SS (L/GATE HGE PIN)
15834697 WEATHERSTRIP, L/GATE UPR
15931278 TAPE, L/GATE ADJ BPR PAD
15273470 HANDLE, L/GATE WDO O/S (PART OF 4)
25916031 TERMINAL, R/WDO DEFG WIRE (PART OF 4) (2.480) [КОНТАКТНЫЙ РАЗЪЕМ ПРОВОДКИ ОБОГРЕВАТЕЛЯ ЗАДНЕГО СТЕКЛА]
(TC17-911) - 2007-2009 CK1(06) АРМАТУРА ОТКРЫВАНИЯ(ПОДЪЕМА) ДВЕРИ ЧАСТЬ 2 (CADILLAC Z75)
15270012 SEAL, E/GATE CTR MLDG (PART OF 3)
11561972 БОЛТ, L/GATE APLQ (PART OF 3) (6 X 1 X 21)
25779075 APPLIQUE, L/GATE UPR (INCLS 1, 2) (PAINT TO MATCH) (W/O HIGH MT S/LP)
25779085 LAMP, HIGH MT STOP (INCLS CZ2 STAMP) [ЛАМПА]
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (HIGH MT S/LP) [ГАЙКА М6]
15857136 WIRE, HIGH MT S/LP
11508277 ГАЙКА, HEX W/CON WA M6X1 THD, OD-19 PEOR 9 (L/GATE APLQ) [ГАЙКА М6]
11569914 ГАЙКА, RR LIC PLT (SINGLE NUT) (EXCLS SEAL)
teamcadillac.ru
15106857 SWITCH, L/GATE REL (PART OF 11) (ACDelco #D1499F) [КОНЦЕВОЙ ВЫКЛЮЧАТЕЛЬ БАГАЖНОЙ ДВЕРИ]
15842442 HANDLE, L/GATE O/S (INCLS 10, 12-14) (PAINT TO MATCH)
12335645 GASKET, L/GATE WDO O/S HDL (PART OF 11) (7.800)
11508388 ГАЙКА, HEX W/CON WA, M6X1, 23.75 O.D., 5.55THK, 9, POR (L/GATE O/S HDL) (8.915)
15101589 PLUG, L/GATE INR PNL DRN HOLE (W/ПРУЖИНА CLIP)
21110669 PLUG, L/GATE WRG HARN HOLE (35 MM) (ROUND) (12.179)
15259076 PLUG, L/GATE SEN ATCH HOLE (6.35MM) (ROUND) (10.571)
11609394 БОЛТ, L/GATE APLQ (M 6 X 1 X 28) (26 OD, 9.8)
25886854 LATCH, L/GATE WDO (INCLS 22) (REFER TO BULLETIN 07-08-66-005A WHEN REPLACING LATCH W/ BRKT)
11589327 БОЛТ, L/GATE WDO LAT (PART OF 21)
11609341 SCREW, RD WA HD 6-LOBE M6X1X19 (L/GATE LK) [ВИНТ]
13501871 LATCH, L/GATE (PO KIT ASM W/ACTUATOR) (12.242)
13501872 LATCH, L/GATE (W/AJAR SW) (12.242)
(TC17-918) - 2007-2009 CK1,2(06) АРМАТУРА ОТКРЫВАНИЯ(ПОДЪЕМА) ДВЕРИ ЧАСТЬ 4 ACTUATOR SYSTEM (POWER LIFTGATE E61)
25882453 MOTOR, L/GATE CLOSE ACTR (INCLS 2) (PART OF 4) (12.243) (BUILT 12/8/08 & AFTER) (FOR 1ST DES SEE 25889602)
teamcadillac.ru
25889602 MOTOR, L/GATE CLOSE ACTR (INCLS 2) (PART OF 4) (12.243) (BUILT PRIOR TO 12/8/08) (FOR 2ND DES SEE 25882453)
11562045 БОЛТ, L/GATE CLOSE ACTR MOT (PART OF 1, 4)
25778508 SENSOR, L/GATE SI UPR (ANTI-PINCH) (W/RETAINERS)
25778509 SENSOR, L/GATE SI UPR (ANTI-PINCH) (W/RETAINERS)
25937660 MODULE, L/GATE CLOSE ACTR MOT CONT (INCLS 1, 2, 5-8)
15299399 SWITCH, L/GATE ACTR (INCLS 6) (PART OF 4) (12.243)
11562045 БОЛТ, L/GATE CLOSE ACTR MOT (PART OF 4)
15810321 BRACKET, L/GATE CLOSE ACTR (PART OF 4)
15836293 ROD, L/GATE ACTR [ТЯГА ЗАМКА БАГАЖНОЙ ДВЕРИ]
20821156 MODULE, ACSRY & L/GATE CONT (12.243)
11609410 БОЛТ, HFH, M8X1.25X25, 10.9, GMW3179 (L/GATE CLOSE ACTR) (0.056) [БОЛТ]
15173772 BRACKET, L/GATE ACTR ROD
11517230 БОЛТ, TORX, W/WA, W/ADH, M6X1X20, 16.2 O.D., DOG PT, 10.9, GM6138M (L/GATE ACTR ROD BRKT) [ВИНТ ЗАМКА ДВЕРИ М6]
(TC17-919) - 2007-2009 CK1(06) LIFTGATE TRIM (CADILLAC Z75)
15864304 MOLDING, L/GATE WDO UPR GARN (INCLS 2, 3) (CASHMERE)
15864305 MOLDING, L/GATE WDO UPR GARN (INCLS 2, 3) (TITANIUM)
15864306 MOLDING, L/GATE WDO UPR GARN (INCLS 2, 3) (EBONY)
15936906 MOLDING, L/GATE WDO UPR GARN (INCLS 2, 3) (LINEN)
11609242 ГАЙКА, L/GATE TR FIN PNL (M6X1, 18X17X14.3)
15838601 HANDLE, L/GATE I/S PULL (PART OF 9) (EBONY)
15838603 HANDLE, L/GATE I/S PULL (PART OF 9) (CASHMERE)
15952901 HANDLE, L/GATE I/S PULL (PART OF 9) (TITANIUM)
15952904 HANDLE, L/GATE I/S PULL (PART OF 9) (LINEN)
11518329 SCR, TORX PAN HD, W/WA, M6X1X25, 18 THD, 15 OD, 9.8, 6138M, TORX (L/GATE TR FIN PNL)
20787039 PANEL, L/GATE TR FIN (INCLS 4, 6, 7, 10-13) (CASHMERE) (NO LONGER INCLS PULL STRAP)
20799804 PANEL, L/GATE TR FIN (INCLS 4, 6, 7, 10-13) (CASHMERE)
20799809 PANEL, L/GATE TR FIN (INCLS 4, 6, 7, 10-13) (TITANIUM) (NO LONGER INCLS PULL STRAP)
20799810 PANEL, L/GATE TR FIN (INCLS 4, 6, 7, 10-13) (EBONY) (NO LONGER INCLS PULL STRAP) [ВНУТРЕННЯЯ ПАНЕЛЬ ЗАДНЕЙ ОТКИДНОЙ ДВЕРИ]
25852154 PANEL, L/GATE TR FIN (INCLS 4, 6, 7, 10-13) (LINEN) (NO LONGER INCLS PULL STRAP)
teamcadillac.ru
15211504 SWITCH, L/GATE ACTR (PART OF 9) (PART OF LIFT GATE PNL)
15107130 LABEL, L/GATE WRNG (PART OF 9)
15594543 CLIP, L/GATE TR FIN PNL (12.7 X 10.4) (9.665) [ФИКСАТОР ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ]
15838552 STRAP, L/GATE PULL (PART OF 9) (EBONY)
15838553 STRAP, L/GATE PULL (PART OF 9) (TITANIUM)
15838554 STRAP, L/GATE PULL (PART OF 9) (CASHMERE)
15120856 RETAINER, L/GATE WDO UPR G/MLDG (BLACK) (8.141) [ФИКСАТОР ВНУТРЕННЕЙ ПАНЕЛИ КУЗОВА]
(TC17-922) - 2007-2009 CK107(06) МОЛДИНГИ (CADILLAC Z75)
15826605 MOLDING, RF PNL JT FIN [МОЛДИНГ КРЫШИ]
15876401 MOLDING, RR S/D (CHROME)
15876402 MOLDING, RR S/D (CHROME)
15876405 MOLDING, FRT S/D (CHROME) [МОЛДИНГ ПЕРЕДНЕЙ ДВЕРИ]
15876406 MOLDING, FRT S/D (CHROME) [МОЛДИНГ ПЕРЕДНЕЙ ДВЕРИ]
teamcadillac.ru
15860253 INSERT, F/FDR CTR RR UPR MLDG [ВСТАВКА КРЫЛА]
15860254 INSERT, F/FDR CTR RR UPR MLDG [ВСТАВКА]
(TC17-949) - 2009 CK107(06) NAMEPLATES (CADILLAC Z75)
teamcadillac.ru
15905786 EMBLEM, L/GATE (WREATH & CREST) [ЭМБЛЕМА МОЛДИНГА БАГАЖНОЙ ДВЕРИ]
15162148 EMBLEM, L/GATE (ESCALADE) [ЭМБЛЕМА ЕSCALADE]
15102283 PLATE, E/GATE NA (CHROME) (PLATINUM) [ЭМБЛЕМА БАГАЖНОЙ ДВЕРИ]
15933399 PLATE, E/GATE NA (HYBRID & 2 MODE)
15910900 EMBLEM, L/GATE (FLEX FUEL E85 ETHANOL)
25816779 PLATE, L/GATE ENG NA (FLEX POWER E85 ETHANOL) [ЭМБЛЕМА БАГАЖНОЙ ДВЕРИ]
15162148 PLATE, FRT S/D NA (ESCALADE) (17.215) [ЭМБЛЕМА ЕSCALADE]
15223483 EMBLEM, FRT S/D (CHROME) (GM) [ЭМБЛЕМА GM]
(TC17-958) - 2009 K107(06) FLARE/BODYSIDE (CADILLAC Z75, EXPORT PACKAGE VD1)
20758458 EXTENSION, RR W/H PNL
20758459 EXTENSION, RR W/H PNL
11609417 RETAINER, RR WHL OPG FLARE (8.5 X 14 X 19) (12.944) [ДЕРЖАТЕЛЬ]
teamcadillac.ru
24501057 RETAINER, F/FDR EXTN (PUSH-IN) (6.9 HOLE DIA) (19MM LG) (1.840) [ПЛАСТИКОВЫЙ ФИКСАТОР ПОДДОНА]
20758461 EXTENSION, F/FDR
20758462 EXTENSION, F/FDR
(TC17-959) - 2009 CK107(06) DECALS (CADILLAC Z75, HYBRID HP2)
25940046 DECAL, R/WDO NA (HYBRID)
25975557 DECAL, FRT S/D LWR (GUNMETAL) (HYBRID)
teamcadillac.ru
25975558 DECAL, FRT S/D LWR (GUNMETAL) (HYBRID)
25975559 DECAL, FRT S/D LWR (SILVER) (HYBRID)
25975560 DECAL, FRT S/D LWR (SILVER) (HYBRID)
25940046 DECAL, W/S NA (HYBRID) (16.475)
(TC17-962) - 2009 CK1(06) АРМАТУРА ОТКРЫВАНИЯ(ПОДЪЕМА) ДВЕРИ ЧАСТЬ 3 CENTER APPLIQUE (CADILLAC Z75, REAR VIEW CAMERA UVC)
20792526 APPLIQUE, L/GATE CTR (INCLS 4, 6-11, 13, 14, 16, 17, 19) (CHROME) (INCLS CAMERA) (CAMERA ASM WELDED IN APPLIQUE) (FOR 2ND DES SEE 20835161)
20835161 APPLIQUE, L/GATE CTR (INCLS 4, 6-11, 13, 14, 16, 17, 19) (CHROME) (SNAP-IN GENERATION 4 CAMERA ASM) (FOR 1ST DES SEE 20792526)
15798062 SWITCH, L/GATE WDO REL (ACDelco #D1994E)
15162148 EMBLEM, L/GATE (CHROME) (PART OF 2) (ESCALADE) [ЭМБЛЕМА ЕSCALADE]
15905786 EMBLEM, L/GATE (PART OF 2) (WREATH & CREST) [ЭМБЛЕМА МОЛДИНГА БАГАЖНОЙ ДВЕРИ]
25778786 LAMP, RR LIC PLT [ФОНАРЬ ПОДСВЕТКИ НОМЕРНОГО ЗНАКА]
teamcadillac.ru
11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (RR LIC PLT LP LENS)
15127746 CLIP, L/GATE LWR MLDG (INCLS 16) (PART OF 2) (NATURAL) (SET-UP HEIGHT 5.05MM) (8.309)
18 - ЗАПЧАСТИ - ЖИДКОСТИ - ЕМКОСТИ И ОБЪЕМЫ - НОВЫЕ ДЕТАЛИ - ЭЛЕКТРИЧЕСКИЕ СОЕДИНЕНИЯ
(OTOU-028) - 2009 CK1 ОБЫЧНОЕ ОБСЛУЖИВАНИЕ ЗАПАСНЫЕ ЧАСТИ (L94/6.2 )(379 CID)-DEACTIVATION
24236933 FILTER KIT, A/TRNS FLUID (ACDelco #24236933) [МАСЛЯНЫЙ ФИЛЬТР АКПП]
teamcadillac.ru
24224781 GASKET, A/TRNS FLUID PAN (ACDelco #24224781) [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА АКПП]
(OTOU-028) - 2009 CK1 ОБЫЧНОЕ ОБСЛУЖИВАНИЕ ЗАПАСНЫЕ ЧАСТИ (L9H/6.2-2)(379 CID)
12609877 СВЕЧА, (GAP 0.040) (ACDelco #41-985) (IRIDIUM)
15908915 ELEMENT, A/CL (ACDelco #A3085C) [ВОЗДУШНЫЙ ФИЛЬТР ДВИГАТЕЛЯ]
15908916 ELEMENT, A/CL (ACDelco #A3086C) [ВОЗДУШНЫЙ ФИЛЬТР ДВИГАТЕЛЯ]
89017524 ФИЛЬТР, МАСЛЯНЫЙ (ACDelco #PF48) [МАСЛЯНЫЙ ФИЛЬТР ДВИГАТЕЛЯ]
19206447 WIRE KIT, SPLG (INCLS SET OF 8 LEADS) (ACDelco #748UU)
teamcadillac.ru
21 - АКСЕССУАРЫ
(6K21-005) - 2007-2009 CK1,2,3 COVER PKG/FRONT SEAT HEADREST
19166485 COVER PKG, F/SEAT HEADREST (CASHMERE) (INSTALL .10) (0.45KGS) (LEATHER) (INCLS 2 CVR'S) (16.718)
19166486 COVER PKG, F/SEAT HEADREST (EBONY) (INSTALL .10) (0.45KGS) (LEATHER) (INCLS 2 CVR'S) (16.718)
teamcadillac.ru
19166487 COVER PKG, F/SEAT HEADREST (CASHMERE) (INSTALL .10) (0.45KGS) (LEATHER W/VINYL) (INCLS 2 CVR'S) (16.718)
(AC21-548) - 2007-2009 CK1,2,3 ROADSIDE ASSISTANCE PKG/ROLL-UP
12498311 ROADSIDE PKG, ACSRY MISC (360 PC QTY OF 88960625) (8.808)
88960625 ROADSIDE PKG, ACSRY MISC (INCLS BUNGEE CORDS, FLASHLIGHT, FUSE KIT, GLOVES, PLIERS, TAPE, RAG, PONCHO, SCREWDRIVER W/BITS, ШИНА GAUGE, & BAG) (1.26KGS) (ROLL-UP) (8.808)
(AC21-560) - 2007-2009 CK1,2 LOCK PKG/WHEEL
12498075 LOCK PKG, WHL (NON-DECORATIVE) (INSTALL .10) (SINGLE 0.6KGS) (W/HEX FREE COATING) (4 NUTS & KEY) (M14X1.5 W/EXT THD) (5.875) [КОМПЛЕКТ ГАЕК М14]
12498076 LOCK PKG, WHL (INSTALL .10) (SINGLE 0.5KGS) (W/HEX FREE COATING) (4 NUTS & KEY) (M14X1.5 W/EXT THD) (5.875) [КОМПЛЕКТ БОЛТОВ М14 (4ШТ)]
12498082 LOCK PKG, WHL (INSTALL .10) (SINGLE 0.6KGS) (W/HEX FREE COATING) (10 PC QTY OF 12498075) (5.875)
17801711 NUT PKG, SPL SECURITY WHL LK (CHROME) (INSTALL .10) (0.29 KGS) (INCLS 20 NUTS, 4 LOCKS, 1 KEY) (M14X1.5) (5.813) (PREFERRED USE ON WHLS W/EXPOSED LUGS & W/O NEED TO RETAIN A WHL CAP/COVER) [КОМПЛЕКТ ГАЕК М14 (4 ШТ.)]
17801712 NUT PKG, SPL SECURITY WHL LK (CHROME) (INSTALL .10) (SINGLE 0.29KGS) (INCLS 4 PACK OF 17801711) (M14X1.5) (5.813) (FOR USE WITH 20" SPO ACCESSORY КОЛЕСА) (PREFERRED USE ON WHLS W/EXPOSED LUGS & W/O NEED TO RETAIN A WHL CAP/COVER)
17802466 LOCK PKG, WHL (DECORATIVE) (CHROME) (INSTALL .10) (SINGLE 0.5 KGS) (W/HEX FREE COATING) (INCLS 4 NUTS, 1 KEY) (M14X1.5 THD) (5.875) (PREFERED USE ON WHLS W/EXPOSED LUGS & W/O NEED TO RETAIN A WHL CAP/COVER)
17802467 LOCK PKG, WHL (INSTALL .10) (SINGLE 0.5 KGS) (10 PC QTY OF 17802466) (5.875) (PREFERED USE ON WHLS W/EXPOSED LUGS & W/O NEED TO RETAIN A WHL CAP/COVER)
(AC21-583) - 2007-2009 CK1,2,3 ADAPTER PKG/TRAILER HARNESS (7-PIN TO 4-PIN ADAP)
teamcadillac.ru
12496599 ADAPTER PKG, TRLR WRG HARN (0.1 KGS) (CONVERTS HVY DUTY 7 PIN RND TO LGT DUTY 4 PIN FLAT) (7.068) [АДАПТЕР]
(AC21-589) - 2007-2009 CK1,2,3 ADAPTER PKG/TRAILER HARNESS (7-PIN TO PWR ADAP)
12497781 ADAPTER PKG, TRLR WRG HARN (0.1 KGS) (CONVERTS HVY DUTY 7-PIN CONN TO ACSRY PWR RCPT) (7.068) [АДАПТЕР КОМЛПЕКТ]
(AC21-667) - 2007-2009 CK1,2(06) LOCK PKG/HITCH
12499511 PIN PKG, LOCKING HITCH (INSTALL .10) (0.4KGS) (REQ 2" HITCH PKG) (7.068) [ЗАМОК КРЫШКИ КРЮКА ТРЕЙЛЕРНОЙ СЦЕПКИ]
(AC21-671) - 2007-2009 CK1,2,3 АПТЕЧКА ПЕРВОЙ ПОМОЩИ
12498312 MEDICAL PKG, 1ST AID (360 PC QTY OF 88960626) (8.808)
teamcadillac.ru
88960626 MEDICAL PKG, 1ST AID (BLACK) (0.19KGS) (WHITE GM BLOCK LOGO) (VINYL) (8.808)
(AC21-672) - 2007-2009 CK1,2,3 КРЕПЛЕНИЕ БАГАЖА, ВЕЛОСИПЕД (WALL MOUNT)
12499175 UNIT, BICYCLE/SKI CARRIER WALL MOUNT STORAGE (6.35KGS) (INCLS BRKT, PLT & HDW) (REQ'S HITCH MTD BIKE CARR) (17.070) (REQUIRES 2" HITCH PKG)
(AC21-693) - 2007-2009 CK1,2,3 MAT PKG/REAR FLOOR CARPET(NON-PRODUCTION)
teamcadillac.ru
17800413 MAT PKG, REAR CARPET (MOLDED EDGE) (EBONY) (1.45KGS) (1 PC) (NO LOGO) (16.800)
(AC21-736) - 2007-2009 CK1,2(06-36) CARRIER PKG/HARD SHELL (LONG)
12499318 CARRIER PKG, HARD SHELL (CROSSRAILS REQUIRED) (BLACK) (INSTALL .50) (10.43 KGS) (TEXTURED) (LONG) (W/GM-THULE LOGO) (INCLS LK CYL) (89"LX21"WX15"H) (17.070)
(AC21-781) - 2007-2009 CK1,2(06-36) CARRIER PKG/HARD SHELL (SHORT)
teamcadillac.ru
12499319 CARRIER PKG, HARD SHELL (CROSSRAILS REQUIRED) (BLACK) (INSTALL .50) (11.339KGS) (TEXTURED) (W/GM-THULE LOGO) (56"LX36"WX15"H) (INCLS CYL & HDW) (17.070)
(AC21-824) - 2007-2009 CK1 ACCESSORY PKG/ШИНА
19107491 ШИНА, P275/55R20-111S AL2 TL BW (18.6 KGS) (INSTALL .10) (INSTALL .25) (SINGLE 18.4KGS) (GOODYEAR, EAGLE LS2, 275/55R20) (5.880) (ACDelco #LU069165)
19143998 ШИНА, P285/45R22-110H AL2 TL BW (18.6 KGS) (INSTALL .10) (INSTALL .25) (SINGLE 19.3KGS) (BRIDGESTONE, DUELER H/L ALENZA, P285/45R22, BW110H) (5.880) (ACDelco #FB053984)
19145377 ШИНА, P275/55R20-111S AL2 TL BW (19.5 KGS) (INSTALL .10) (INSTALL .25) (SINGLE 19.5KGS) (BRIDGESTONE, DUELER H/L ALENZA W/UNI-T, P275/55R20, BL, 111S) (5.880) (ACDelco #FB053967)
teamcadillac.ru
19185719 ШИНА, 285/45R22-114H XL AL3 BW (SINGLE 17.2KGS) (ШИНА, GOODYEAR_FORTERA SL_285/45R22_VSB114H) (5.880) (ACDelco #KY621163)
19190769 ШИНА, 20 INCH - ACCESSORY (USA&CANADA ШИНА PROGRAM) (ШИНА, BRIDGESTONE_DUELER A/T RH-S_P275/55R20_BW111T) (5.880) (ACDelco #FB107925)
(AC21-854) - 2007-2009 CK1,2(06) TRAY PKG/REAR COMPARTMENT FLOOR STORAGE
17803357 TRAY PKG, R/CMPT FLR STOW COMPT (EBONY) (2.3KGS) (GRD PLSTC) (W/ESCALADE SCRIPT LOGO) (INCLS LINER) (2" SIDE WALLS) (16.583) (TO BE USED WHEN THIRD ROW SEAT IS NOT IN VEHICLE) [ЯЧЕЙКА ПКГ]
(AC21-855) - 2007-2009 CK1,2,3 КРЕПЛЕНИЕ БАГАЖА, ВЕЛОСИПЕД (HITCH MOUNTED)
12499722 RAIL PKG, BICYCLE CARR (HITCH MT) (17.070) (REQUIRES 2" HITCH PKG)
12499718 PLATE PKG, BICYCLE CARR RAIL MTG (12.815) (REQUIRES 2" HITCH PKG) (SERV CMP OF CARRIER PKG 12499171, 72)
12499719 CARRIER, BICYCLE (HITCH MT CARRIER LOWER SUPPORT) (12.815)
12499723 STRAP, HITCH MT BICYCLE CARR (BLACK) (PLASTIC) (QTY 8 PC PKG) (16.800) (REQUIRES 2" HITCH PKG)
(AC21-857) - 2007-2009 CK1,2(06) BAG PKG/ROOF LUGGAGE (SOFT)(Z88,Z75)
12497826 BAG PKG, RF LUGG STOW (SOFT) (WATER RESISTANT/NOT WATERPROOF) (BLACK) (INSTALL .30) (2.29KGS) (FABRIC) (CADILLAC LOGO) (11.5X29.625X37) (12.816) (CROSSRAILS REQUIRED)
(AC21-864) - 2007-2009 CK107(06) DOOR PKG/ТОПЛИВНЫЙ БАК FILLER
12497944 DOOR PKG, F/TNK FIL (CHROME) (INSTALL .60) (0.74 KGS) (ZINC DIE CAST) (INCLS SCREWS, NUTS & INSTR) (16.570) [ДВЕРЬ]
(AC21-865) - 2007-2009 CK1(06-36) GRILLE PKG/RADIATOR (Z75)
teamcadillac.ru
17801288 GRILLE PKG, RAD (WHITE) (INSTALL 1.5) (3.78KGS) (INCLS INSTR) (1.266)
17801289 GRILLE PKG, RAD (SILVER) (INSTALL 1.5) (3.78KGS) (INCLS INSTR) (1.266)
17801290 GRILLE PKG, RAD (BLUE) (INSTALL 1.5) (3.78KGS) (INCLS INSTR) (1.266)
19156281 GRILLE PKG, RAD (BLACK) (INSTALL 1.5) (3.78KGS) (INCLS INSTR) (1.266)
(AC21-867) - 2007-2009 CK1,2,3 HITCH PKG/BALL MOUNT
12495776 HITCH PKG, BALL MT (INSTALL .10) (2.9 KGS) (STD) (INCLS BALL MT W/1" SHANK, 5/8 HITCH PIN & 1/8 HAIR PIN) (7.068) (3/4" RISE, 2" DROP, 5000 LB MAX LOAD, 500 LB TONGUE WT) [ШАРОВЫЙ КРЮК ТРЕЙЛЕРНОЙ СЦЕПКИ]
12495777 HITCH PKG, BALL MT (INSTALL .10) (3.0KGS) (STD) (INCLS BALL MT W/1" SHANK, 5/8 HITCH PIN & 1/8 HAIR PIN) (7.068) (2" RISE, 3-1/4" DROP, 5000 LB MAX LOAD, 500 LB TONGUE WT) [ШАРОВЫЙ КРЮК ТРЕЙЛЕРНОЙ СЦЕПКИ]
12495778 HITCH PKG, BALL MT (INSTALL .10) (4.0KGS) (STD) (INCLS BALL MT W/1" SHANK, 5/8 HITCH PIN & 1/8 HAIR PIN) (7.068) (4" RISE, 5-1/4" DROP, 5000 LB MAX LOAD, 500 LB TONGUE WT) [ШАРОВЫЙ КРЮК ТРЕЙЛЕРНОЙ СЦЕПКИ]
(AC21-870) - 2007-2009 CK1(06-36) HOOK PKG/TOW
19158571 HOOK PKG, FRT TOW (CHROME) (INSTALL .50) (3.15KGS) (INCLS 2 HOOKS, HDW KIT & INSTR) (7.068) [БУКСИРОВОЧНЫЙ КРЮК]
19158568 ATTACHMENT KIT, TOW HOOK (7.068) (SERV COMP OF CHROME TOW HOOK PKGS)
(AC21-873) - 2007-2009 CK1,2(06-36) ЗАЩИТА/SPLASH (FLAT WITH CONTOUR) (NO LOGO)(Z75)
19154428 FLAP PKG, RR MUD (BLACK) (INSTALL .30) (0.76KGS) (MOLDED) (NO LOGO) (FLAT W/CONTOUR) (11.1" WIDE) (8.214) (NOT FOR USE W/ACSRY ARTICULATING ПОРОГS)
(AC21-878) - 2007-2009 CK1(06-36) HOIST PKG (EXC (HP2))
19158309 HOIST PKG, SPA WHL (INSTALL .50) (SINGLE 3.1KGS) (9.709) (FOR 22" WHEEL ONLY)
(AC21-879) - 2007-2009 CK1,2(06-36) HEADPHONE/ЗАДНЕЕ СИДЕНЬЕ ENTERTAINMENT (SERVICED COMPONENT)
19132012 HEADPHONE, R/SEAT ENTERTAINMENT (0.36 KGS) (9.680) (HEADPHONES WILL OPERATE WITH ANY GMSPO & GM DVD SYSTEM) (HEADPHONES HAS WIRELESS & DUAL CHANNEL FEATURE (CHANNEL A & CHANNEL B))
(AC21-887) - 2007-2009 CK1,2(06-36) MAT PKG/FRONT FLOOR CARPET (PRODUCTION)
(AC21-916) - 2007-2009 CK1,2,3 LOCK PKG/BICYCLE & SKI CARRIER
12499724 LOCK, BICYCLE (0.91KGS) (INCLS 2 KEYS) (REQ 2" HITCH PKG) (12.815)
19242660 KEY SET, HITCH CARRIER (#010) (INCLS 2 KEYS) (17.070)
19242661 KEY SET, HITCH CARRIER (#011) (INCLS 2 KEYS) (17.070)
19242662 KEY SET, HITCH CARRIER (#012) (INCLS 2 KEYS) (17.070)
19242663 KEY SET, HITCH CARRIER (#013) (INCLS 2 KEYS) (17.070)
19242664 KEY SET, HITCH CARRIER (#014) (INCLS 2 KEYS) (17.070)
19242665 KEY SET, HITCH CARRIER (#015) (INCLS 2 KEYS) (17.070)
19242666 KEY SET, HITCH CARRIER (#016) (INCLS 2 KEYS) (17.070)
19242667 KEY SET, HITCH CARRIER (#017) (INCLS 2 KEYS) (17.070)
19242668 KEY SET, HITCH CARRIER (#018) (INCLS 2 KEYS) (17.070)
19242669 KEY SET, HITCH CARRIER (#019) (INCLS 2 KEYS) (17.070)
19242670 KEY SET, HITCH CARRIER (#020) (INCLS 2 KEYS) (17.070)
19242671 KEY SET, HITCH CARRIER (#021) (INCLS 2 KEYS) (17.070)
19242673 KEY SET, HITCH CARRIER (#023) (INCLS 2 KEYS) (17.070)
19242674 KEY SET, HITCH CARRIER (#024) (INCLS 2 KEYS) (17.070)
19242675 KEY SET, HITCH CARRIER (#025) (INCLS 2 KEYS) (17.070)
19242676 KEY SET, HITCH CARRIER (#026) (INCLS 2 KEYS) (17.070)
88963077 KEY SET, HITCH CARRIER (#01) (INCLS 2 KEYS) (12.815)
88966122 KEY SET, HITCH CARRIER (#02) (INCLS 2 KEYS) (17.070)
88966123 KEY SET, HITCH CARRIER (#03) (INCLS 2 KEYS) (17.070)
88966124 KEY SET, HITCH CARRIER (#04) (INCLS 2 KEYS) (17.070)
88966125 KEY SET, HITCH CARRIER (#05) (INCLS 2 KEYS) (17.070)
88966126 KEY SET, HITCH CARRIER (#06) (INCLS 2 KEYS) (17.070)
88966127 KEY SET, HITCH CARRIER (#07) (INCLS 2 KEYS) (17.070)
88966128 KEY SET, HITCH CARRIER (#08) (INCLS 2 KEYS) (17.070)
88966129 KEY SET, HITCH CARRIER (#09) (INCLS 2 KEYS) (17.070)
teamcadillac.ru
88966130 KEY SET, HITCH CARRIER (#00) (INCLS 2 KEYS) (17.070)
(AC21-920) - 2007-2009 CK1,2,3 PLATE PKG/LICENSE REMOUNT
12495709 PLATE PKG, LIC REMOUNT (INSTALL .30) (1.13 KGS) (INCLS HDW) (17.070) (REQUIRES 2" HITCH PKG) [ДОПОЛНИТЕЛЬНЫЙ КРОНШТЕЙН НОМЕРНОГО ЗНАКА, РАСПОЛОЖЕННЫЙ НА КРЕПЛЕНИИ ДЛЯ ВЕЛОСИПЕДА]
(AC21-952) - 2007-2009 CK1,2,3 АВАРИЙНЫЙ ЗНАК PKG (CU8)
teamcadillac.ru
19201300 REFLECTOR PKG, DISABLED VEH WRNG TRIANGLE (1.60KGS) (2.575) [ДОРОЖНЫЙ ЗНАК - ТРЕУГОЛЬНИК]
19201301 REFLECTOR PKG, DISABLED VEH WRNG TRIANGLE (BULK) (2.575)
(AC21-975) - 2007-2009 CK1,2(06-36) ENTERTAINMENT PKG/R/SEAT VIDEO & T/PLYR
17803046 HEADREST PKG, DUAL DVD R/SEAT ENTERTAINMENT (INCLS 2 HEADRESTS, 2 HEADPHONES, REM CONT, JMP HARN, QUIKSTART GDE, WIRE PUL, 6 AAA BATT, 3 PWR CORDS (PASS/DRV #9), WIRELESS FM MOD-CTRL BOX, VEH JMP HARN) (EBONY) (INSTALL 1.0) (05.4KGS) (LEATHER W/VIN
teamcadillac.ru
17803047 HEADREST PKG, DUAL DVD R/SEAT ENTERTAINMENT (INCLS 2 HEADRESTS, 2 HEADPHONES, REM CONT, JMP HARN, QUIKSTART GDE, WIRE PUL, 6 AAA BATT, 3 PWR CORDS (PASS/DRV #9), WIRELESS FM MOD-CTRL BOX, VEH JMP HARN) (CASHMERE) (INSTALL 1.0) (05.4KGS) (LEATHER W/
17803048 HEADREST PKG, DUAL DVD R/SEAT ENTERTAINMENT (INCLS 2 HEADRESTS, 2 HEADPHONES, REM CONT, JMP HARN, QUIKSTART GDE, WIRE PUL, 6 AAA BATT, 3 PWR CORDS (PASS/DRV #9), WIRELESS FM MOD-CTRL BOX, VEH JMP HARN) (EBONY) (INSTALL 1.0) (05.4KGS) (LEATHER W/VIN
(AC21-980) - 2007-2009 CK1(06-36) КОЛЕСО (CK945)(Z75)
12499427 CAP PKG, WHL NUT (INSTALL .10) (SINGLE 0.01KGS) (CHROME PLASTIC) (24 PC QTY OF 15045768) (5.858) [КОЛПАЧОК ГАЙКИ]
12499428 CAP PKG, WHL NUT (INSTALL .10) (SINGLE 0.01KGS) (CHROME PLASTIC) (480 PC QTY OF 15045768) (5.858) [КОМПЛЕКТ ГАЕК КОЛЕСА (24 ШТ)]
12499308 CAP, HUB (CHROME) (INSTALL .10) (SINGLE 0.04KGS) (W/CADILLAC LOGO) (80 PC QTY OF 88963142) (5.858)
12499423 CAP, HUB (CHROME) (INSTALL .10) (SINGLE 0.04KGS) (W/CADILLAC LOGO) (4 PC QTY OF 88963142) (5.858) [КОЛПАК СТУПИЦЫ КОЛЕСА]
19155564 NUT PKG, WHL (INSTALL .1) (SINGLE 0.062KGS) (STEEL W/ZINC PLATE) (24 PC QTY OF 9595175) (5.813) [ГАЙКА]
17800945 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (CAST) (AL) (INCLS 1 WHL 88967789 & TAG) (5.803)
teamcadillac.ru
17800946 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (CAST) (AL) (4 PC QTY OF 88967789) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 20X8.5]
17800947 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (CAST) (AL) (16 PC QTY OF 88967789) (5.803)
(AC21-981) - 2007-2009 CK1(06-36) КОЛЕСО (CK948)(Z75)
17800948 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (AL) (INCLS 1 WHL 88967790 & TAG) (5.803)
17800949 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (AL) (4 PC QTY OF 88967790) (5.803)
17800950 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (AL) (16 PC QTY OF 88967790) (5.803)
(AC21-982) - 2007-2009 CK1(06-36) КОЛЕСО (CK951)(Z75)
teamcadillac.ru
17800951 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (INCLS 1 WHL 88967791 & TAG) (5.803)
17800952 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (4 PC QTY OF 88967791) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 20Х8.5]
17800953 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (16 PC QTY OF 88967791) (5.803)
(AC21-984) - 2007-2009 CK1,2(06-36) STEP PKG/TUBULAR ASST (OVAL)
12499706 STEP PKG, OVAL TUBE ASSIST (CHROME) (INSTALL .50) (28.0KGS) (SS) (SMOOTH OVAL TUBE) (RAISED SLOPE RECT) (BLACK PAD) (8.225) [ПОДНОЖКА]
19211747 PAD, ASST STEP FRT (LONG) (8.228) (SERV CMP OF STEP PKGS 19202895-19202902)
88963977 PAD, SI STEP (LONG STEP PAD) (8.228) (SERV CMP FOR STEP PKGS 12499706 & 12499707)
teamcadillac.ru
88963978 PAD, SI STEP (SHORT STEP PAD) (8.228) (SERV CMP FOR STEP PKG 12499706)
(AC21-985) - 2007-2009 CK1(06-36) КОЛЕСО (CK366)(Z75)
17800366 КОЛЕСО, 22X9 (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (CAST ALUM) (INCLS 1 WHL 88966246 OR 19170520 & TAG) (5.803)
17800367 КОЛЕСО, 22X9 (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (AL) (4 PC QTY OF 88966246 OR 19170520) (5.803) [ДИСК]
teamcadillac.ru
17800368 КОЛЕСО, 22X9 (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (CAST ALUM) (16 PC QTY OF 88966246 OR 19170520) (5.803)
(GM21-020) - 2007-2009 CK1,2,3 HEADPHONE/ЗАДНЕЕ СИДЕНЬЕ ENTERTAINMENT (UPGRADE)
teamcadillac.ru
17802612 HEADPHONE PKG, (00.2 KGS) (INCLS WIRELESS NOISE CANC HEADPHONE, OWN MAN, 2 AAA BAT) (9.665) [БЕСПРОВОДНОЙ НАУШНИК]
(GM21-023) - 2007-2009 CK1 ACCESSORY PKG/ШИНА PRESSURE INDICATOR SENSOR
teamcadillac.ru
19155710 SENSOR PKG, ШИНА PRESS IND (INSTALL .10) (SINGLE 0.03KGS) (CLAMP-IN) (16 PC QTY OF 15268606) (5.890) [ДАТЧИК ДАВЛЕНИЯ ШИНЫ КОЛЕСА]
(GM21-024) - 2007-2009 CK1 ACCESSORY PKG/ШИНА PRESSURE INDICATOR SENSOR NUT
17800699 NUT PKG, ШИНА PRESS IND SEN (INSTALL .10) (SINGLE 0.0013 KGS) (16 PC QTY OF 15234846) (5.890) [ГАЙКА М12]
(GM21-032) - 2007-2009 CK107,109(06) ПЕПЕЛЬНИЦА PKG (BIN STYLE)
teamcadillac.ru
17800663 ПЕПЕЛЬНИЦА PKG, (FRT FLR CNSL) (BLACK) (INSTALL .20) (BIN STYLE) (PLASTIC) (INCLS C/LTR, HSG, RET) (12.009) [ПРИКУРИВАТЕЛЬ]
(GM21-033) - 2007-2009 CK1 APPEARANCE PKG/VALVE STEM CAP
teamcadillac.ru
19159985 CAP, PKG ШИНА VLV STEM (INSTALL .10) (SINGLE 0.0045KGS) (16 PC QTY OF 25749814) (5.875)
(GM21-035) - 2007-2009 CK1,2,3 ACCESSORY PKG/VIDEO DISPLAY REMOTE CONTROL
teamcadillac.ru
19132011 CONTROL, VIDEO DISPLAY REMOTE (0.09KGS) (9.680) (REMOTE WILL ONLY OPERATE WITH GMSPO DVD HEADREST SYSTEMS)
(GM21-037) - 2007-2009 CK1,2,3 ADAPTER PKG/TRAILER HARNESS (7-PIN TO PWR ADAP & 7-PIN TO 4-PIN ADAP)
19201995 ADAPTER PKG, TRLR WRG HARN (0.1 KGS) (INCLS 7-4 ADAPTER, 7-POWER OUTLET ADAPTER) (7.068)
(GM21-038) - 2007-2009 CK1,2,3 TRANSMITTER PKG/REMOTE CONTROL DOOR LOCK (W/INFO DISPLAY)
19157237 TRANSMITTER, R/CON DR LK & THEFT DTRNT & REM START (INCLS TRANSMITTER, RCVR, ANT, H/W, OWNER MAN) (INSTALL 1.1) (00.2 KGS) (2-WAY) (8 FT CABLE) (W/GREEN CONN) (16.345) (REQ SERV PROGRAMMING SYS AND SCAN TOOL) (REQ DLR INST)
(TC21-009) - 2007-2009 CK1,2(06) RAIL PKG/БАГАЖНИК CROSS (NON-PRODUCTION)
12499282 RAIL PKG, LUGG CARR CR (BRI AN W/CHROME ENDCAPS) (INSTALL .25) (3.99KGS) (AL) (NO LOGO) (INCLS 2 RAILS & HDW) (17.070)
teamcadillac.ru
19157494 STRIP, LUGG CARR CR RL RUB (17.070) (SERV CMP FOR RAIL PKG 12499282)
(TC21-013) - 2007-2009 CK1,2(06-36) MAT PKG/FRONT FLOOR CARPET (NON-PRODUCTION) (MOLDED EDGE)(Z75)
17800408 MAT PKG, F/FLR (EBONY) (2.03KGS) (CPT) (TWIN) (W/WREATH & CREST LOGO) (16.800) [КОВРИК]
17800409 MAT PKG, F/FLR (CASHMERE) (2.03KGS) (CPT) (TWIN) (W/WREATH & CREST LOGO) (16.800) [КОМПЛЕКТ КОВРИКОВ САЛОНА (2ШТ) 0,48 М2]
(TC21-014) - 2007-2009 CK1,2(06) MAT PKG/REAR PREMIUM (ALL WEATHER)(1 PIECE)
12499640 MAT PKG, R/FLR (EBONY) (3.1KGS) (ALL WEATHER) (1 PC) (NO LOGO) (VERTICAL RIBS) (16.800) [КОВРИК САЛОНА ЗАДНИЙ]
17800414 MAT PKG, R/FLR (CASHMERE) (1.45KGS) (CPT) (1 PC) (NO LOGO) (16.800)
19166596 MAT PKG, R/FLR (CASHMERE) (3.1KGS) (ALL WEATHER) (1 PC) (NO LOGO) (VERTICAL RIBS) (16.800) [КОВРИК САЛОНА ДЛЯ ЗАДНИХ ПАССАЖИРОВ]
(TC21-015) - 2007-2009 CK1,2(06) MAT PKG/REAR #2 PREMIUM (ALL WEATHER)(1 PIECE)
teamcadillac.ru
12499641 MAT PKG, R/FLR (R/SEAT #2) (EBONY) (1.30KGS) (ALL WEATHER) (1 PC) (NO LOGO) (VERTICAL RIBS) (16.800) [КОВРИК БАГАЖНОГО ОТСЕКА]
17800423 MAT PKG, R/FLR (R/SEAT #2) (EBONY) (1.30KGS) (CPT) (MOLDED EDGE) (1 PC) (NO LOGO) (16.800) [КОМПЛЕКТ КОВРИКОВ]
17800424 MAT PKG, R/FLR (R/SEAT #2) (CASHMERE) (1.30KGS) (CPT) (MOLED EDGE) (1 PC) (NO LOGO) (16.800)
19166599 MAT PKG, R/FLR (R/SEAT #2) (CASHMERE) (1.30KGS) (ALL WEATHER) (1 PC) (VERTICAL RIBS) (16.800) [КОВРИК]
(TC21-016) - 2007-2009 CK107(06) MAT PKG/REAR #2 CARPET (NON-PRODUCTION)
teamcadillac.ru
(TC21-018) - 2007-2009 CK107(06) MAT PKG/CARGO PREMIUM (ALL WEATHER)(Z75)
teamcadillac.ru
17801325 MAT PKG, R/CMPT FLR (EBONY) (2.0KGS) (ALL WEATHER) (W/ESCALADE LOGO) (VINYL) (USE W/3RD ROW SEAT) (8.214) [КОВРИК БАГАЖНОГО ОТСЕКА]
19166801 MAT PKG, R/CMPT FLR (CASHMERE) (2.0KGS) (ALL WEATHER) (W/ESCALADE LOGO) (VERT RIBS) (USE W/3RD ROW SEAT) (16.800) [КОВРИК]
(TC21-022) - 2007-2009 CK1,2,3 SECURITY PKG/INCLINATION SENSOR
17800432 SENSOR PKG, THEFT DTRNT VEH INCLINATION (INSTALL .80) (0.0421KGS) (INCLS SENSOR & HARN) (2.195) (REQUIRES PROGRAMMING THRU TCSC)
(TC21-023) - 2007-2009 CK1,2(06) SHIELD PKG/DOOR SILL (NO LOGO)
teamcadillac.ru
17802414 PLATE PKG, S/D SILL TR (INSTALL .50) (SS) (BRUSHED) (NO LOGO) (INCLS FRT & RR) (16.603) [ЗАЩИТА]
(TC21-032) - 2007-2009 CK1 КОЛЕСО (CK997)(Z75)
teamcadillac.ru
17800997 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (AL) (INCLS 1 WHL 88967872 & TAG) (5.803)
17800998 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (AL) (4 PC QTY OF 88967872) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 20Х8.5]
17800999 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (ALUMINUM) (16 PC QTY OF 88967872) (5.803) [КОЛЕСО]
(TC21-033) - 2007-2009 CK1 КОЛЕСО (CK925)(Z75)
17800925 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .25) (SINGLE 19.0KGS) (20X8.5) (CAST AL) (INCLS 1 WHL 88967768) (5.803)
teamcadillac.ru
17800926 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .25) (SINGLE 19.0KGS) (20X8.5) (CAST AL) (4 PC QTY OF 88967768) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 20Х8.5]
17800927 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .25) (SINGLE 19.0KGS) (20X8.5) (CAST AL) (16 PC QTY OF 88967768) (5.803)
(TC21-034) - 2007-2009 CK1 КОЛЕСО (CK994)(Z75)
17800994 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .25) (SINGLE 18.8KGS) (20X8.5) (CAST AL) (INCLS 1 WHL 88967871 & TAG) (5.803)
17800995 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .25) (SINGLE 18.8KGS) (20X8.5) (CAST AL) (4 PC QTY OF 88967871) (5.803)
teamcadillac.ru
17800996 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .25) (SINGLE 18.8KGS) (20X8.5) (CAST AL) (16 PC QTY OF 88967871) (5.803) [КОЛЕСО]
(TC21-043) - 2007-2009 CK1,2(06-36) MAT PKG/REAR FLOOR CARPET (PRODUCTION) (TWIN)
19121926 MAT PKG, REAR CARPET (EBONY) (TWIN) (16.800) [КОМПЛЕКТ КОВРИКОВ САЛОНА (2ШТ) 0.48 М2]
teamcadillac.ru
19206525 MAT PKG, REAR CARPET (CASHMERE) (TWIN) (16.800)
(TC21-052) - 2007-2009 CK1 ACCESSORY PKG/MUFFLER
19156353 MUFFLER PKG, EXH (SS) (INSTALL 1.0) (20.41KGS) (SEMI POLISHED) (3.701) (REQ PURCHASE OF GMPP EXH EXT PKG)
19156354 MUFFLER PKG, EXH (SS) (INSTALL 1.0) (20.41KGS) (SEMI POLISHED) (3.701) (REQ PURCHASE OF GMPP EXH EXT PKG)
teamcadillac.ru
(TC21-054) - 2007-2009 CK1,2(06) ЗАЩИТА/SPLASH (MOLDED) (FRONT)(NO LOGO)(FLAT BOTTOM)
19165823 ЗАЩИТА, SPH (MOLDED) (SILVER) (INSTALL .50) (0.52KGS) (FRT) (8.214) [КОМПЛЕКТ БРЫЗГОВИКОВ (2ШТ)]
19165825 ЗАЩИТА, SPH (MOLDED) (BLUE) (INSTALL .50) (0.52KGS) (FRT) (8.214)
(TC21-057) - 2007-2009 CK1,2(06) ЗАЩИТА/SPLASH (MOLDED) (FRONT)(NO LOGO)(Y91,Z75)
19165822 ЗАЩИТА, SPH (MOLDED) (BLACK) (INSTALL .50) (0.52KGS) (FRT) (NO LOGO) (W/O EDGE SEAL) (8.214) [КОМПЛЕКТ БРЫЗГОВИКОВ (2 ШТ)]
teamcadillac.ru
19165824 ЗАЩИТА, SPH (MOLDED) (WHITE) (INSTALL .50) (0.52KGS) (FRT) (W/O EDGE SEAL) (8.214) [КОМПЛЕКТ БРЫЗГОВИКОВ (2ШТ)]
19165826 ЗАЩИТА, SPH (MOLDED) (GRAY) (INSTALL .50) (0.52KGS) (FRT) (W/O EDGE SEAL) (8.214) [БРЫЗГОВИК]
(TC21-058) - 2007-2009 CK1(06) ЗАЩИТА/SPLASH (MOLDED) (REAR)(NO LOGO)(Y91,Z75)
12499475 ЗАЩИТА, SPH (MOLDED) (BLACK) (INSTALL .50) (0.62KGS) (RR) (NO LOGO) (W/O EDGE SEALS) (8.214) [КОМПЛЕКТ БРЫЗГОВИКОВ (2 ШТ)]
12499476 ЗАЩИТА, SPH (MOLDED) (SILVER) (INSTALL .50) (0.62KGS) (RR) (NO LOGO) (NOT FOR USE W/ACSRY SPARE ШИНА KIT 19172547) (8.214) [БРЫЗГОВИК]
12499477 ЗАЩИТА, SPH (MOLDED) (WHITE) (INSTALL .50) (0.62KGS) (RR) (NO LOGO) (W/O EDGE SEALS) (8.214) [КОМПЛЕКТ БРЫЗГОВИКОВ (2 ШТ)]
17800470 ЗАЩИТА, SPH (MOLDED) (GRAY) (INSTALL .50) (0.62KGS) (RR) (NO LOGO) (W/O EDGE SEALS) (8.214)
19156300 ЗАЩИТА, SPH (MOLDED) (BLUE) (INSTALL .50) (0.62KGS) (RR) (NO LOGO) (NOT FOR USE W/ACSRY SPARE ШИНА KIT 19172547) (8.214)
(TC21-066) - 2007-2009 CK1(06-36) SHIELD PKG/DOOR SILL (CADILLAC SCRIPT LOGO)(Z75)
17802527 PLATE PKG, S/D SILL TR (INSTALL .30) (1.46KGS) (SS) (BRUSHED) (W/CAD SCRIPT LOGO) (INCLS RH & LH FRT & 2 R/L RR) (16.603) [КОМПЛЕКТ ДЕКОРАТИВНЫХ НАКЛАДОК ПОРОГА КУЗОВА (4 ШТ.)]
(TC21-081) - 2007-2009 CK1,2(06-36) DVD PLAYER AND DOCKING STATION PKG/PORTABLE
17802180 PLAYER PKG, PORTABLE DVD (INCLS REM CTRL, BATT, ADAP, CABLE, HEADPHONE, CASE, GUIDE, MAN, BATT PKG) (INSTALL .10) (3.6 KGS) (10.2" SCREEN) (9.680) (USE WITH DOCKING STATION PACKAGE)
teamcadillac.ru
17803084 STATION PKG, PORTABLE DVD PLAYER DOCKING (GRAY) (INSTALL .90) (4.7KGS) (INCLS BRKT, JUMP HARN, HARDWARE KIT, TEMPLATE & INSTR) (9.680) (T/W PLAYER PKG, PORTABLE DVD)
17803087 STATION PKG, PORTABLE DVD PLAYER DOCKING (CASHMERE) (INSTALL .90) (4.7KGS) (INCLS BRKT, JUMP HARN, HARDWARE KIT, TEMPLATE & INSTR) (9.680) (T/W PLAYER PKG, PORTABLE DVD)
17803088 STATION PKG, PORTABLE DVD PLAYER DOCKING (CASHMERE) (INSTALL .90) (4.7KGS) (INCLS BRKT, JUMP HARN, HARDWARE KIT, TEMPLATE & INSTR) (9.680) (T/W PLAYER PKG, PORTABLE DVD)
19159527 STATION, PORTABLE DVD PLAYER DOCKING (GRAY) (INSTALL .10) (1.2 KGS) (9.680) (T/W PLAYER PKG, PORTABLE DVD)
19159529 STATION, PORTABLE DVD PLAYER DOCKING (CASHMERE) (INSTALL .10) (1.2KGS) (9.680) (T/W PLAYER PKG, PORTABLE DVD)
19159545 PLAYER, PORTABLE DVD (SILVER) (INSTALL .10) (1.6 KGS) (10.2" SCREEN) (9.680) (USE WITH DOCKING STATION PACKAGE)
19172765 STATION PKG, PORTABLE DVD PLAYER DOCKING (GRAY) (INSTALL .90) (4.7KGS) (INCLS BRKT, JUMP HARN, HARDWARE KIT, TEMPLATE & INSTR) (9.680) (T/W PLAYER PKG, PORTABLE DVD)
(TC21-082) - 2007-2009 CK1 DEFLECTOR PKG/HOOD AIR (Z75)
12499276 DEFLECTOR PKG, КАПОТ AIR (SMOKE) (INSTALL .30) (0.6KGS) (ACRYLIC) (NO LOGO) (INCLS FASTENERS & INSTR) (8.010)
teamcadillac.ru
19165534 DEFLECTOR PKG, КАПОТ AIR (CHROME) (INSTALL .30) (0.7KGS) (ABS) (NO LOGO) (8.010)
(TC21-085) - 2007-2009 CK1,2(06) STORAGE PKG/REAR FLOOR КОНСОЛЬ
17801739 КОНСОЛЬ PKG, R/FLR (EBONY) (INSTALL .50) (2ND ROW) (INCLS 2 BRKT'S, BRKT CVR, TEMPLATE & INSTR) (16.650) [НАПОЛЬНАЯ КОНСОЛЬ КУЗОВА]
teamcadillac.ru
17801740 КОНСОЛЬ PKG, R/FLR (CASHMERE) (INSTALL .50) (2ND ROW) (INCLS 2 BRKT'S, BRKT CVR, TEMPLATE & INSTR) (16.650)
17801741 КОНСОЛЬ PKG, R/FLR (TITANIUM) (INSTALL .50) (2ND ROW) (INCLS 2 BRKT'S, BRKT CVR, TEMPLATE & INSTR) (16.650)
(TC21-089) - 2007-2009 CK107,109(06) LAMP PKG/TAIL(Z75)
teamcadillac.ru
19166175 LAMP KIT, TAIL (CLEAR) (INSTALL .50) (3.98KGS) (INCLS RH & LH) (2.679) [ЗАДНИЙ ФОНАРЬ]
(TC21-091) - 2007-2009 CK1(06-36) УДЛИНЕННАЯ КОМПОНОВКА-ГЛУШИТЕЛЬ (OEM ONLY)(NO LOGO)
19170728 EXTENSION KIT, EXH TAIL PIPE (POLISHED) (INSTALL .50) (1.06KGS) (OEM ONLY) (SS) (NO LOGO) (DUAL WALL) (ANGLE CUT) (3.705)
teamcadillac.ru
(TC21-092) - 2007-2009 CK1 КОЛЕСО (WITH CAP)(CK369)
17800366 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (CAST ALUM) (INCLS 1 WHL 88966246 OR 19170520 & TAG) (5.803)
17800367 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (AL) (4 PC QTY OF 88966246 OR 19170520) (5.803) [ДИСК]
17800368 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (CAST ALUM) (16 PC QTY OF 88966246 OR 19170520) (5.803)
17800372 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 20.6KGS) (22X9) (CAST AL) (INCLS 1 WHL 88966248 & TAG) (5.803)
17800373 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 20.6KGS) (22X9) (CAST AL) (4 PC QTY OF 88966248)
17800374 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 20.6KGS) (22X9) (CAST AL) (16 PC QTY OF 88966248) (5.803)
17800375 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (ALUM) (INCLS 1 WHL 88966249 & TAG) (5.803)
17800376 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (AL) (4 PC QTY OF 88966249) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 22Х9]
17800377 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (AL) (16 PC QTY OF 88966249) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК22Х9]
17800910 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 22.0KGS) (22X9) (CAST AL) (INCLS 1 WHL 88967763 & TAG) (5.803)
17800911 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 22.0KSG) (22X9) (CAST AL) (4 PC QTY OF 88967763) (5.803)
17800912 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 22.0KGS) (22X9) (CAST AL) (16 PC QTY OF 88967763) (5.803)
17800913 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .30) (21.3 KGS) (22X9) (INCLS 1 WHL 88967764 & TAG) (AL) (CAST) (5.803)
17800914 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .30) (SINGLE 21.3 KGS) (22X9) (4 PC QTY OF 88967764) (AL) (CAST) (5.803)
17800915 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .30) (SINGLE 21.3 KGS) (22X9) (16 PC QTY OF 88967764) (AL) (CAST) (5.803)
17800916 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 20.0KGS) (22X9) (CAST AL) (INCLS 1 WHL 88967765 & TAG) (5.803)
17800917 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 20.0KGS) (22X9) (CAST AL) (4 PC QTY OF 88967765) (5.803) [ДИСК]
teamcadillac.ru
17800918 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 20.0KGS) (22X9) (CAST AL) (16 PC QTY OF 88967765) (5.803)
17800919 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .30) (20.4 KGS) (22X9) (INCLS 1 WHL 88967766 & TAG) (AL) (CAST) (5.803)
17800920 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9) (4 PC QTY OF 88966776) (AL) (CAST) (5.803)
17800921 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9) (16 PC QTY OF 88967766) (AL) (CAST) (5.803)
17800922 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9) (CAST AL) (INCLS 1 WHL 88967767 & TAG) (5.803)
17800923 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9) (CAST AL) (4 PC QTY OF 88967767) (5.803)
17800924 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9) (CAST AL) (16 PC QTY OF 88967767) (5.803)
17800925 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 19.0KGS) (20X8.5) (CAST AL) (INCLS 1 WHL 88967768) (5.803)
17800926 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 19.0KGS) (20X8.5) (CAST AL) (4 PC QTY OF 88967768) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 20Х8.5]
17800927 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 19.0KGS) (20X8.5) (CAST AL) (16 PC QTY OF 88967768) (5.803)
17800928 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (17.3KGS) (20X8.5) (CAST AL) (1 PC QTY OF 88967769) (5.803)
17800929 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (4 PC QTY OF 88967769) (5.803)
17800930 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (16 PC QTY OF 88967769) (5.803)
17800945 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (CAST) (AL) (INCLS 1 WHL 88967789 & TAG) (5.803)
17800946 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (CAST) (AL) (4 PC QTY OF 88967789) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 20X8.5]
17800947 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (CAST) (AL) (16 PC QTY OF 88967789) (5.803)
17800948 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (AL) (INCLS 1 WHL 88967790 & TAG) (5.803)
17800949 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (AL) (4 PC QTY OF 88967790) (5.803)
17800950 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (AL) (16 PC QTY OF 88967790) (5.803)
17800951 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (INCLS 1 WHL 88967791 & TAG) (5.803)
17800952 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (4 PC QTY OF 88967791) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 20Х8.5]
17800953 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (16 PC QTY OF 88967791) (5.803)
17800991 WHEEL, PKG (22 X 9) (INSTALL .25) (17.5 KG) (20X8.5) (INCLS 1 WHL 88967870 & TAG) (5.803)
17800992 WHEEL, PKG (22 X 9) (INSTALL .25) (SINGLE 17.5 KG) (20X8.5) (4 PC QTY OF 88967870) (5.803)
17800993 WHEEL, PKG (22 X 9) (INSTALL .25) (SINGLE 17.5 KG) (20X8.5) (16 PC QTY OF 88967870) (5.803)
17800994 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 18.8KGS) (20X8.5) (CAST AL) (INCLS 1 WHL 88967871 & TAG) (5.803)
17800995 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 18.8KGS) (20X8.5) (CAST AL) (4 PC QTY OF 88967871) (5.803)
17800996 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 18.8KGS) (20X8.5) (CAST AL) (16 PC QTY OF 88967871) (5.803) [КОЛЕСО]
17800997 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (AL) (INCLS 1 WHL 88967872 & TAG) (5.803)
17800998 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (AL) (4 PC QTY OF 88967872) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 20Х8.5]
17800999 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (ALUMINUM) (16 PC QTY OF 88967872) (5.803) [КОЛЕСО]
19170370 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .30) (SINGLE 15.0KGS) (20X8.5) (CAST AL) (INCLS 1 WHL 19170369) (5.803)
19170371 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .30) (SINGLE 15.0KGS) (20X8.5) (CAST AL) (4 PC QTY OF 19170369) (5.803)
19170372 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .30) (SINGLE 15.0KGS) (20X8.5) (CAST AL) (16 PC QTY OF 19170369) (5.803)
19170798 WHEEL, PKG (22 X 9) (22 X 9) (MACH./PAINTED) (INSTALL .25) (SINGLE 17.93KGS) (CAST AL) (INCLS 1 WHL 19170797 & TAG) (5.803)
19170799 WHEEL, PKG (22 X 9) (22 X 9) (MACH./PAINTED) (INSTALL .25) (SINGLE 17.93KGS) (CAST AL) (4 PC QTY OF 19170797) (5.803) [АЛЮМИНИЕВЫЙ КОЛЁСНЫЙ ДИСК R22]
19170800 WHEEL, PKG (22 X 9) (22 X 9) (MACH./PAINTED) (INSTALL .25) (SINGLE 17.93KGS) (CAST AL) (16 PC QTY OF 19170797) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 22Х9]
19212347 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .30) (20.8 KGS) (22X9) (AL) (CAST) (INCLS 1 WHL 19212346 & TAG) (5.803)
19212348 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .30) (SINGLE 20.8 KGS) (22X9) (AL) (CAST) (4 PC QTY OF 19212346) (5.803)
19212349 WHEEL, PKG (22 X 9) (CHROME) (INSTALL .30) (SINGLE 20.8 KGS) (22X9) (AL) (CAST) (16 PC QTY OF 19212346) (5.803)
(TC21-093) - 2007-2009 CK1 КОЛЕСО (WITH CAP)(CK988)
17800366 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (CAST ALUM) (INCLS 1 WHL 88966246 OR 19170520 & TAG) (5.803)
17800367 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (AL) (4 PC QTY OF 88966246 OR 19170520) (5.803) [ДИСК]
17800368 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (CAST ALUM) (16 PC QTY OF 88966246 OR 19170520) (5.803)
17800372 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 20.6KGS) (22X9) (CAST AL) (INCLS 1 WHL 88966248 & TAG) (5.803)
17800373 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 20.6KGS) (22X9) (CAST AL) (4 PC QTY OF 88966248)
17800374 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 20.6KGS) (22X9) (CAST AL) (16 PC QTY OF 88966248) (5.803)
17800375 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (ALUM) (INCLS 1 WHL 88966249 & TAG) (5.803)
17800376 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (AL) (4 PC QTY OF 88966249) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 22Х9]
17800377 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (AL) (16 PC QTY OF 88966249) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК22Х9]
17800910 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 22.0KGS) (22X9) (CAST AL) (INCLS 1 WHL 88967763 & TAG) (5.803)
17800911 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 22.0KSG) (22X9) (CAST AL) (4 PC QTY OF 88967763) (5.803)
17800912 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 22.0KGS) (22X9) (CAST AL) (16 PC QTY OF 88967763) (5.803)
17800913 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .30) (21.3 KGS) (22X9) (INCLS 1 WHL 88967764 & TAG) (AL) (CAST) (5.803)
17800914 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .30) (SINGLE 21.3 KGS) (22X9) (4 PC QTY OF 88967764) (AL) (CAST) (5.803)
17800915 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .30) (SINGLE 21.3 KGS) (22X9) (16 PC QTY OF 88967764) (AL) (CAST) (5.803)
17800916 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 20.0KGS) (22X9) (CAST AL) (INCLS 1 WHL 88967765 & TAG) (5.803)
17800917 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 20.0KGS) (22X9) (CAST AL) (4 PC QTY OF 88967765) (5.803) [ДИСК]
17800918 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 20.0KGS) (22X9) (CAST AL) (16 PC QTY OF 88967765) (5.803)
17800919 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .30) (20.4 KGS) (22X9) (INCLS 1 WHL 88967766 & TAG) (AL) (CAST) (5.803)
17800920 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9) (4 PC QTY OF 88966776) (AL) (CAST) (5.803)
17800921 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9) (16 PC QTY OF 88967766) (AL) (CAST) (5.803)
17800922 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9) (CAST AL) (INCLS 1 WHL 88967767 & TAG) (5.803)
17800923 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9) (CAST AL) (4 PC QTY OF 88967767) (5.803)
17800924 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9) (CAST AL) (16 PC QTY OF 88967767) (5.803)
17800925 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 19.0KGS) (20X8.5) (CAST AL) (INCLS 1 WHL 88967768) (5.803)
17800926 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 19.0KGS) (20X8.5) (CAST AL) (4 PC QTY OF 88967768) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 20Х8.5]
17800927 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 19.0KGS) (20X8.5) (CAST AL) (16 PC QTY OF 88967768) (5.803)
17800928 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (17.3KGS) (20X8.5) (CAST AL) (1 PC QTY OF 88967769) (5.803)
teamcadillac.ru
17800929 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (4 PC QTY OF 88967769) (5.803)
17800930 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (16 PC QTY OF 88967769) (5.803)
17800945 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (CAST) (AL) (INCLS 1 WHL 88967789 & TAG) (5.803)
17800946 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (CAST) (AL) (4 PC QTY OF 88967789) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 20X8.5]
17800947 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (CAST) (AL) (16 PC QTY OF 88967789) (5.803)
17800948 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (AL) (INCLS 1 WHL 88967790 & TAG) (5.803)
17800949 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (AL) (4 PC QTY OF 88967790) (5.803)
17800950 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (AL) (16 PC QTY OF 88967790) (5.803)
17800951 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (INCLS 1 WHL 88967791 & TAG) (5.803)
17800952 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (4 PC QTY OF 88967791) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 20Х8.5]
17800953 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (16 PC QTY OF 88967791) (5.803)
17800991 WHEEL, PKG (20 X 8.5) (INSTALL .25) (17.5 KG) (20X8.5) (INCLS 1 WHL 88967870 & TAG) (5.803)
17800992 WHEEL, PKG (20 X 8.5) (INSTALL .25) (SINGLE 17.5 KG) (20X8.5) (4 PC QTY OF 88967870) (5.803)
17800993 WHEEL, PKG (20 X 8.5) (INSTALL .25) (SINGLE 17.5 KG) (20X8.5) (16 PC QTY OF 88967870) (5.803)
17800994 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 18.8KGS) (20X8.5) (CAST AL) (INCLS 1 WHL 88967871 & TAG) (5.803)
17800995 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 18.8KGS) (20X8.5) (CAST AL) (4 PC QTY OF 88967871) (5.803)
17800996 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 18.8KGS) (20X8.5) (CAST AL) (16 PC QTY OF 88967871) (5.803) [КОЛЕСО]
17800997 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (AL) (INCLS 1 WHL 88967872 & TAG) (5.803)
17800998 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (AL) (4 PC QTY OF 88967872) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 20Х8.5]
17800999 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (ALUMINUM) (16 PC QTY OF 88967872) (5.803) [КОЛЕСО]
19170370 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .30) (SINGLE 15.0KGS) (20X8.5) (CAST AL) (INCLS 1 WHL 19170369) (5.803)
19170371 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .30) (SINGLE 15.0KGS) (20X8.5) (CAST AL) (4 PC QTY OF 19170369) (5.803)
19170372 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .30) (SINGLE 15.0KGS) (20X8.5) (CAST AL) (16 PC QTY OF 19170369) (5.803)
19170798 WHEEL, PKG (22 X 9) (20 X 8.5) (MACH./PAINTED) (INSTALL .25) (SINGLE 17.93KGS) (CAST AL) (INCLS 1 WHL 19170797 & TAG) (5.803)
19170799 WHEEL, PKG (22 X 9) (20 X 8.5) (MACH./PAINTED) (INSTALL .25) (SINGLE 17.93KGS) (CAST AL) (4 PC QTY OF 19170797) (5.803) [АЛЮМИНИЕВЫЙ КОЛЁСНЫЙ ДИСК R22]
19170800 WHEEL, PKG (22 X 9) (20 X 8.5) (MACH./PAINTED) (INSTALL .25) (SINGLE 17.93KGS) (CAST AL) (16 PC QTY OF 19170797) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 22Х9]
19212347 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .30) (20.8 KGS) (22X9) (AL) (CAST) (INCLS 1 WHL 19212346 & TAG) (5.803)
19212348 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .30) (SINGLE 20.8 KGS) (22X9) (AL) (CAST) (4 PC QTY OF 19212346) (5.803)
19212349 WHEEL, PKG (20 X 8.5) (CHROME) (INSTALL .30) (SINGLE 20.8 KGS) (22X9) (AL) (CAST) (16 PC QTY OF 19212346) (5.803)
(TC21-094) - 2007-2009 CK1(06-36) КОЛЕСО (CK372)(Z75)
teamcadillac.ru
17800372 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 20.6KGS) (22X9) (CAST AL) (INCLS 1 WHL 88966248 & TAG) (5.803)
17800373 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 20.6KGS) (22X9) (CAST AL) (4 PC QTY OF 88966248) (5.803)
17800374 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 20.6KGS) (22X9) (CAST AL) (16 PC QTY OF 88966248) (5.803)
(TC21-097) - 2007-2009 CK1(06-36) КОЛЕСО (CK375)(Z75)
17800375 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (ALUM) (INCLS 1 WHL 88966249 & TAG) (5.803)
17800376 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (AL) (4 PC QTY OF 88966249) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 22Х9]
teamcadillac.ru
17800377 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (AL) (16 PC QTY OF 88966249) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК22Х9]
(TC21-100) - 2007-2009 CK1(06-36) КОЛЕСО (CK910)(Z75)
17800910 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 22.0KGS) (22X9) (CAST AL) (INCLS 1 WHL 88967763 & TAG) (5.803)
teamcadillac.ru
17800911 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 22.0KSG) (22X9) (CAST AL) (4 PC QTY OF 88967763) (5.803)
17800912 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 22.0KGS) (22X9) (CAST AL) (16 PC QTY OF 88967763) (5.803)
(TC21-103) - 2007-2009 CK1(06-36) КОЛЕСО (CK916)(Z75)
17800916 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 20.0KGS) (22X9) (CAST AL) (INCLS 1 WHL 88967765 & TAG) (5.803)
17800917 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 20.0KGS) (22X9) (CAST AL) (4 PC QTY OF 88967765) (5.803) [ДИСК]
17800918 WHEEL, PKG (CHROME) (INSTALL .25) (SINGLE 20.0KGS) (22X9) (CAST AL) (16 PC QTY OF 88967765) (5.803)
(TC21-106) - 2007-2009 CK1,2(06) COVER PKG/CARGO AREA
15244021 SHADE PKG, LUGG (EBONY) (INSTALL .10) (0.4 KGS) (VINYL) (16.577) [ШТОРКА БАГАЖНОГО ОТСЕКА]
15277000 SHADE PKG, LUGG (CASHMERE) (INSTALL .10) (0.4 KGS) (VINYL) (16.577) [ШТОРКА БАГАЖНОГО ОТСЕКА 90Х120СМ]
(TC21-119) - 2007-2009 CK107,109(06) LAMP PKG/CENTER HIGH MOUNT STOP(Z75)
teamcadillac.ru
19172250 LAMP KIT, HIGH MT STOP (CLEAR) (INSTALL .50) (0.91KGS) (PLASTIC) (2.679)
(TC21-121) - 2007-2009 CK1(06-36) MAT PKG/FRONT PREMIUM (ALL WEATHER)(Z75)
teamcadillac.ru
17803323 MAT PKG, F/FLR (EBONY) (3.40KGS) (ALL WEATHER) (TWIN) (W/SILVER ESCALADE LOGO) (VERTICLE RIBS) (16.800) [КОМПЛЕКТ КОВРИКОВ САЛОНА (2 ШТ)]
19166595 MAT PKG, F/FLR (CASHMERE) (3.40KGS) (ALL WEATHER) (TWIN) (W/SILVER ESCALADE LOGO) (VERTICAL RIBS) (16.800) [КОМПЛЕКТ КОВРИКОВ САЛОНА (2 ШТ)]
(TC21-122) - 2007-2009 CK1(06-43) MAT PKG/FRONT FLOOR CARPET (NON-PRODUCTION) (Z88,Y91)
17800406 MAT PKG, F/FLR (EBONY) (2.03KGS) (CPT) (TWIN) (W/DENALI LOGO) (16.800)
teamcadillac.ru
17800407 MAT PKG, F/FLR (CASHMERE) (2.03KGS) (CPT) (TWIN) ( W/DENALI LOGO) (16.800) [КОВРИК]
(TC21-142) - 2007-2009 CK1 КОЛЕСО (CK798)
19170798 КОЛЕСО, 22X9 (MACH./PAINTED) (INSTALL .25) (SINGLE 17.93KGS) (CAST AL) (INCLS 1 WHL 19170797 & TAG) (5.803)
19170799 КОЛЕСО, 22X9 (MACH./PAINTED) (INSTALL .25) (SINGLE 17.93KGS) (CAST AL) (4 PC QTY OF 19170797) (5.803) [АЛЮМИНИЕВЫЙ КОЛЁСНЫЙ ДИСК R22]
19170800 КОЛЕСО, 22X9 (MACH./PAINTED) (INSTALL .25) (SINGLE 17.93KGS) (CAST AL) (16 PC QTY OF 19170797) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 22Х9]
(TC21-143) - 2007-2009 CK1 КОЛЕСО (CK919)
teamcadillac.ru
17800919 КОЛЕСО, 22X9 (CHROME) (INSTALL .30) (20.4 KGS) (22X9) (INCLS 1 WHL 88967766 & TAG) (AL) (CAST) (5.803)
17800920 КОЛЕСО, 22X9 (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9) (4 PC QTY OF 88966776) (AL) (CAST) (5.803)
17800921 КОЛЕСО, 22X9 (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9) (16 PC QTY OF 88967766) (AL) (CAST) (5.803)
(TC21-144) - 2007-2009 CK1 КОЛЕСО (CK922)
17800922 КОЛЕСО, 22X9 (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9) (CAST AL) (INCLS 1 WHL 88967767 & TAG) (5.803)
17800923 КОЛЕСО, 22X9 (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9) (CAST AL) (4 PC QTY OF 88967767) (5.803)
17800924 КОЛЕСО, 22X9 (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9) (CAST AL) (16 PC QTY OF 88967767) (5.803)
(TC21-145) - 2007-2009 CK1 КОЛЕСО (CK928)
teamcadillac.ru
17800928 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .25) (17.3KGS) (20X8.5) (CAST AL) (1 PC QTY OF 88967769) (5.803)
17800929 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (4 PC QTY OF 88967769) (5.803)
17800930 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (16 PC QTY OF 88967769) (5.803)
(TC21-146) - 2007-2009 CK1 КОЛЕСО (CK991)
17800991 КОЛЕСО, 20X8.5 (INSTALL .25) (17.5 KG) (20X8.5) (INCLS 1 WHL 88967870 & TAG) (5.803)
teamcadillac.ru
17800992 КОЛЕСО, 20X8.5 (INSTALL .25) (SINGLE 17.5 KG) (20X8.5) (4 PC QTY OF 88967870) (5.803)
17800993 КОЛЕСО, 20X8.5 (INSTALL .25) (SINGLE 17.5 KG) (20X8.5) (16 PC QTY OF 88967870) (5.803)
(TC21-147) - 2007-2009 CK1 КОЛЕСО (CK370)
teamcadillac.ru
19170370 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .30) (SINGLE 15.0KGS) (20X8.5) (CAST AL) (INCLS 1 WHL 19170369) (5.803)
19170371 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .30) (SINGLE 15.0KGS) (20X8.5) (CAST AL) (4 PC QTY OF 19170369) (5.803)
19170372 КОЛЕСО, 20X8.5 (CHROME) (INSTALL .30) (SINGLE 15.0KGS) (20X8.5) (CAST AL) (16 PC QTY OF 19170369) (5.803)
(TC21-152) - 2008-2009 CK107(06) ACCESSORY PKG/SPARE ШИНА(HP2)
19172547 HOIST PKG, SPA WHL (INSTALL 1.5) (SINGLE 19.9KGS) (INCLS WHL, HOIST, & EXH KIT) (NOT FOR USE/ACSRY SPH GUARDS) (5.880) (P265/70R17 ШИНА & FASCIA COVER NOT INCLUDED IN KIT)
(TC21-153) - 2007-2009 CK1,2(06) NET PKG/CONVENIENCE (FLAT STYLE)
17803346 NET PKG, CONVENIENCE (BLACK) (INSTALL .50) (2ND ROW) (FLAT STYLE) (INCLS 4-RET & 4-STUDS) (16.575) [ОГРАНИЧИТЕЛЬНАЯ СЕТКА БАГАЖНОГО ОТСЕКА]
  • Maxim locked this тему
