00 - 8-ЦИЛИНДРОВЫЙ ДВИГАТЕЛЬ
(GM00-047) 2010-2013 CK1 ДВИГАТЕЛЬ В СБОРЕ-6.2L V8 PART 1 БЛОК ЦИЛИНДРОВ И СВЯЗАННЫЕ ДЕТАЛИ (L9H/6.2-2,L94/6.2F)
19260875 BEARING, CM/SHF (POSITION 2 & 4)
89017572 BEARING KIT, CR/SHF THR (STD) (#3)
11570662 BOLT, CONN ROD (PART OF 105) (M9X44, 13 THD, 15.5 OD, 12.9, PL)
89017573 BEARING KIT, CONN ROD (STD)
12607475 ROD, CONN (USED WITH FLOATING PIN PISTON) (WITH PIN RETAINING CLIP) (INCLS 102, 103, 106)
19208471 PISTON KIT, ENG (CAST DIMPLE 5.5MM FROM EDGE OF PIST TOP; USE T/W RING KIT 19168090. FOR 1ST DES SEE 19208473) (INCLS 109) (STD)
19208472 PISTON, (W/PIN) (INCLS 109) (0.5MM O.S.)
19208473 PISTON KIT, ENG (INCLS 109) (CAST DIMPLE 14.5MM FROM EDGE OF PIST TOP; USE T/W RING KIT 89018049.FOR 2ND DES SEE 19208471)
19168090 RING KIT, PSTN (STD) (USE T/W PISTON KIT 19208471. FOR 1ST DES SEE 89018049)
89018049 RING KIT, PSTN (STD) (USE T/W PISTON KIT 19208473. FOR 2ND DES 19168090)
19178596 RING KIT, PSTN (0.5MM O.S.)
12573460 PLUG, ENG BLK OIL GAL (INCLS 110) (15.68MM DIA) (INCLS O-RING SEAL (N.S.S.)
12586687 HEATER, ENG COOL
11588949 PLUG, M16X1.5X14, 24 OD, SAE 1010 STL, GMW3044, W/ AL WASHER (ENG BLK COOL DRN HOLE)
89017571 BEARING KIT, CR/SHF (#1, 2, 4, 5) (STD)
12561513 KEY, CR/SHF BALR (4.8MMX37.5MM)
12588613 CRANKSHAFT,
12556127 BOLT, CR/SHF BRG CAP (M8X1.25X24)
12560273 STUD, CR/SHF BRG CAP (HFH, M10X2X23, M8X1.25X11, 113.5 TOTAL LONG)
12560272 BOLT, CR/SHF BRG CAP (BOTTOM) (LONG) (M10X2X102.5, 24.5)
01453658 PIN, DOWEL STRAIGHT 5/8 DIA 1 3/16 LG (TRANS LOC)
12602448 PLATE, A/TRNS FLEX (AUTO TRANSMISSION)
11569956 BOLT, A/TRNS FLEX PLT (M11X1.5X23.5 W/SEALER)
12634105 BALANCER, CR/SHF (ACDelco #12634105)
12557840 BOLT, CR/SHF BALR (M16X2.0X103)
89060436 SEAL KIT, CR/SHF RR OIL (REVERSE LIP SEAL, INCL INSTRUCTION SHEET)
12623066 CAMSHAFT, ENG (INCLS 202)
19260876 BEARING, CM/SHF
24575061 PIN, CM/SHF SPKT LOC (PART OF 200) (17MM LONG)
12589016 RETAINER, CM/SHF (USE WITH BOLT 11561455) (INCLS SEAL)
11561283 BOLT, HVY HX FLG HD, M16X1.5X63, GMW25 (8.8) STL, GMW3359 (CM/SHF RET)
12606358 ACTUATOR, CM/SHF POSN
12588151 VALVE, CM/SHF POSN ACTR SOL
12556582 SPROCKET, CR/SHF
12586482 CHAIN, CM/SHF TMG
12570326 PIN, CYL HD LOC
11515758 BOLT, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (PART OF 232)
12626407 TENSIONER KIT, TMG CHAIN (INCLS BOLT, RETAINER) (INCLS 231) (ACDelco #12626407)
teamcadillac.ru
12639250 HOUSING, CR/SHF RR OIL SEAL
12639249 GASKET, CR/SHF RR OIL SEAL HSG
12585546 SENSOR, CR/SHF POSN (INCLS 702) (ACDelco #213-3520)
12623730 SENSOR, KNOCK (MATING CONN W/LEADS USE 13580877) (ACDelco #213-1576)
11519980 BOLT, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (KNOCK SEN)
11515756 BOLT, HFH, M8X1.25X20, 17THD, 18 O.D., 10.9, 7114M (BOLT, CR/SHF POSN SEN)
11609289 PLUG, HEX, M28X1.25X13, 10.9, GMW3044, INT DRIVER W/THD SEAL 9985 (ENG BLK COOL DRN HOLE) (8.971)
09427693 PLUG, CUP 5/8, CORROSION RESISTANT STL (ENG BLK OIL GAL) (1.531)
19260874 BEARING, CM/SHF (POSITION 1 & 5)
(GM00-586) 2010-2013 CK1 ДВИГАТЕЛЬ В СБОРЕ-6.2L V8 PART 3 ПЕРЕДНЯЯ КРЫШКА И ОХЛАЖДЕНИЕ (L9H/6.2-2,L94/6.2F)
12585673 SEAL, ENG FRT CVR (0.213) (ACDelco #296-02)
19208815 PUMP KIT, WAT (INCLS 302, 303, 305, 900-902) (INCLS GASKETS) (ACDelco #251-713)
12551926 BOLT, W/PMP (M8X1.25X83)
11516480 BOLT, W/PMP INL (PART OF 300) (M6X1X25-10MM SOC) (ACDelco #15-75247)
12587395 INLET, W/PMP (PART OF 300) (ACDelco #15-10595)
89018168 THERMOSTAT KIT, ENG COOL (INCL SEAL) (PART OF 300) (INCLS 900) (ACDelco #131-160)
12630223 GASKET, W/PMP (ACDelco #251-663)
12605716 PIPE, ENG COOL AIR BL (INCLS 308, 903)
12602541 SEAL, ENG COOL AIR BL PIPE (O RING) (SINGLE TYPE ONE HOLE O-RING) (PART OF 307)
11588715 BOLT, HFH, M6X1X35, 18 THD, 14.2 OD, 8.8, GMW3359, 5MM M POINT (ENG COOL AIR BL PIPE)
11515758 BOLT, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (ENG FRT CVR)
12594939 COVER, ENG FRT (MCHG) (USE T/W FRT COVER SEAL 12585673 AND FRT COVER GASKET 12633904)
12633904 GASKET, ENG FRT CVR
12591720 SENSOR, CM/SHF POSN (INCLS 704) (ACDelco #213-3826)
12607409 WIRE, CM/SHF POSN SEN (INCLS 905)
11588712 BOLT, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (CM/SHF POSN ACTR HUB CVR)
12585995 MAGNET, CM/SHF POSN ACTR
12594339 SEAL, CM/SHF POSN ACTR CVR
12587397 SEAL, WAT INL (PART OF 305, 300) (ACDelco #12587397)
89021297 ADHESIVE/SEALANT, THREADLOCKER HI STRENGTH 10ML ERI (PART OF 300) (ACDelco #10-1006) (89021297 SERVICED T/W BOLT 11517188)
12600254 HOSE, ENG COOL AIR BL PIPE DPNG (PART OF 307)
12602048 PLUG, ENG COOL AIR BL (50MM, ALUMINUM)
(GM00-615) 2010 CK1 ДВИГАТЕЛЬ В СБОРЕ-6.2L V8 PART 4 МАСЛЯНЫЙ НАСОС, МАСЛЯНЫЙ ПОДДОН И СОПУТСТВУЮЩИЕ ЧАСТИ(L9H/6.2-2,L94/6.2F)
11609289 PLUG, HEX, M28X1.25X13, 10.9, GMW3044, INT DRIVER W/THD SEAL 9985 (ENG BLK OIL GAL) (8.971)
11588949 PLUG, M16X1.5X14, 24 OD, SAE 1010 STL, GMW3044, W/ AL WASHER (ENG BLK OIL GAL)
12640746 PAN, OIL (INCLS BAFFLE, BOLTS, PLUG, DEADENER, GASKET, VALVE, FITTING, SEAL) (EXC SWITCH) (INCLS 426-428, 430, 433-435, 438, 439, 453, 454, 900-902)
11609746 NUT, HFH, M8X1.25, 8.9THK, 17.6 O.D., 10 STL, GMW3200, PREV TORQUE (CR/SHF OIL DFL)
11588712 BOLT, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (O/PMP SUC PIPE)
12584922 SEAL, O/PMP SUC PIPE (O RING) (PART OF 407) (ORANGE) (19.63MM I.D., 4.32MM THICKNESS) (TEFLON COATED) (1.724)
12608579 SCREEN, O/PMP (W/SUC PIPE) (INCLS 406)
11519133 BOLT, SELF TAP, M6X1X20, 13.2 O.D. (PART OF 413)
11515758 BOLT, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (O/PMP)
12612289 PUMP, OIL (INCLS 408, 410, 411, 414-416)
24504031 SEAL, OIL LVL IND (O RING) (PART OF 418) (RED)
12622055 INDICATOR, OIL LVL (INCLS 417)
11588736 BOLT, HFH, M10X1.5X20, 10 THD, 22.3 O.D., 10.9, GMW3359 (OIL LVL IND TUBE)
12609269 TUBE, OIL LVL IND (INCL SEAL) (INCLS 421)
24504031 SEAL, OIL LVL IND TUBE (O RING) (PART OF 420) (RED)
12611129 DEFLECTOR, CR/SHF OIL
12612350 GASKET, OIL PAN (PART OF 400)
11588712 BOLT, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (PART OF 400)
11562588 PLUG, OIL PAN DRN (PART OF 400) (INCLS 454) (M12X1.75X25) (W/SEAL) (EXC MAGNET)
12611384 GASKET, OIL PAN CVR (USE T/W 11588714 BOLT-QTY 2) (PART OF 400)
12577903 COVER, OIL PAN (PART OF 400)
11588714 BOLT, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (PART OF 400)
89017524 FILTER, OIL (W/O TOP MOUNTED FILTER BYPASS VALVE) (ACDelco #PF48) (DURAGUARD)
12600225 FITTING, OIL FLTR (PART OF 400)
11515758 BOLT, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (PART OF 400)
12554990 BOLT, OIL PAN (PART OF 400) (M6X1.0X136)
12616850 SEAL, OIL PAN DRN PLUG (O RING) (PART OF 400, 430)
12608835 VALVE, OIL PRESS RLF (PART OF 400)
12633653 DEADENER, OIL PAN (PART OF 400)
teamcadillac.ru
11589241 BOLT, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (PART OF 400)
12346004 SEALANT, LOCTITE PIPE-W/TEFLON 50CC TUBE (OIL PAN) (ACDelco #10-2008)
12558759 RIVET, OIL PAN GSKT
11503302 INSERT, OIL PAN DRN PLUG THD
(TC00-900) 2007-2013 CK1 ЗАЩИТА ДВИГАТЕЛЯ
22781371 SHIELD, ENG
teamcadillac.ru
11518341 BOLT, HEX, M10X1.5X25, 14 THD, 28 OD, 6202M, 7114M, TAP, TR-PT (ENG SHLD)
20944322 PLATE, OIL PAN SKID
11518341 BOLT, HEX, M10X1.5X25, 14 THD, 28 OD, 6202M, 7114M, TAP, TR-PT (OIL PAN SKID PLT)
(TC00-902) 2010-2011 CK1 ЭКРАН ВПУСКНОГО КОЛЛЕКТОРА/КРЫШКИ (L20/4.8A,LMG/5.3-0,LC9/5.3-3,L94/6.2F)
12625893 SHIELD, UPR INT MANIF SIGHT (INCLS 2)
15872173 GROMMET, UPR INT MANIF SIGHT SHLD (PART OF 1) (24X22)
11609319 STUD, UPR INT MANIF SIGHT SHLD (M6X1X20.65) (3.671)
11516075 NUT, HFH SELF LK, M6X1, 7.7THK, 14.2 O.D., 9, PZOR (UPR INT MANIF CVR)
12610052 COVER, UPR INT MANIF (INCLS 6)
12559065 GROMMET, UPR INT MANIF SIGHT SHLD (PART OF 5) (12.0 DIA)
15858430 RETAINER, UPR INT MANIF SIGHT SHLD (INCLS 8)
teamcadillac.ru
11514623 BOLT, HEX W/CON WA, M6X1X20 (UPR INT MANIF SIGHT SHLD)
(TC00-908) 2010-2013 CK1 ДВИГАТЕЛЬ В СБОРЕ И ЧАСТЬ ДВИГАТЕЛЯ (L94/6.2F)
19206471 ENGINE, GASOLINE (SERVICE NEW)
(TC00-910) 2010-2011 K1 КРЕПЛЕНИЕ ДВИГАТЕЛЯ И КОРОБКИ ПЕРЕДАЧ-V8 (L20/4.8A,LMG/5.3-0,LC9/5.3-3,LZ1/6.0J,L9H/6.2-2,L94/6.2F)
teamcadillac.ru
15854939 MOUNT, ENG (RH & LH)
11517639 BOLT, ENG MT SUPT (TO FRAME BRKT) (12X1.75X44, 35THD) (4.665)
11609475 BOLT, HFH W/CON SPR WA, M10X1.5X33, 24 THD, 22.3 OD, 10.9, GMW3359 (ENG MT)
15840278 MOUNT, TRANS
11517827 BOLT, HFH W/FL WA, M10X1.5X35, 20 THD, 25 OD, 9.8, 7114M, MACH, P-PT, 6175M A (TRANS MT)
11516754 NUT, HEX, W/CON SPR WA, M10X1.5, 10THK, 28 O.D., 10, 7111M (TRANS MT)
(TX00-057) 2010-2013 CK1 ДВИГАТЕЛЬ В СБОРЕ-6.2L V8 PART 2 ГОЛОВКА ЦИЛИНДРОВ И СВЯЗАННЫЕ ДЕТАЛИ (L9H/6.2-2,L94/6.2F)
12571595 LIFTER, VLV (HYD, ROLLER, ACTIVE FUEL MANAGEMENT LIFTER) (ACDelco #12571595)
12576400 LIFTER, VLV (NON ACTIVE) (ACDelco #HL128)
12571596 GUIDE, VLV LFTR (FRT)
12571608 GUIDE, VLV LFTR (RR)
12551163 BOLT, VLV LFTR GDE (SIDE) (SHORT) (M6X1.0X19)
teamcadillac.ru
10238852 ROD, VLV PUSH
10214664 ARM, VLV RKR (ARM, VLV RKR EXH. FOR INTKE VLV RKR ARM SEE PN 12569167, QTY 8)
12560961 BOLT, VLV RKR ARM PIV SUPT (M8X1.25X52.5)
12600936 SUPPORT, VLV RKR ARM PIV
12610046 GASKET, CYL HD
12629051 HEAD, CYL (INCLS HEAD, GUIDES, SEATS) (EXC VALVES)
19258707 BOLT, CYL HD (M11X2X100)
12558840 BOLT, CYL HD (SHORT) (M8X1.25X45)
12482062 SEAL KIT, EXH VLV STEM OIL (22.8MM) (INCLS 8 SEALS)
12482063 SEAL KIT, INT VLV STEM OIL (W/SPRING SHIM) (14.4MM) (INCLS 8 SEALS)
12589774 SPRING, VLV
10166344 CAP, VLV SPR
10166345 KEY, VLV STEM
12582719 VALVE, EXH (STD)
12627970 VALVE, INT
11610259 PLUG, CYL HD CORE HOLE (M12X1.5X21.2) (HEX, SOC)
12593348 SEAL, OIL FIL TUBE (O RING) (27.94MM I.D.) (SIZE #320) (1.758)
12609624 TUBE, OIL FIL
12573337 CAP, OIL FIL (SAE 5W30, NON-VENTED, SEAL) (INCLS 450) (ACDelco #FC208)
12593348 SEAL, OIL FIL CAP (O RING) (PART OF 424) (27.94MM I.D.) (SIZE #320)
12637683 GASKET, VLV RKR ARM CVR (PART OF 505)
12642655 COVER, VLV RKR ARM (INCLS 504, 515, 516, 900)
12637684 COVER, VLV RKR ARM (INCLS 504, 515, 516) (INCLS COVER, GASKET, BOLT, CONNECTOR, BAFFLE, CAP)
12577215 BOLT, VLV RKR ARM CVR (INCLS 515) (PART OF 505) (M6.0X1.0) (W/GROMMET, SLEEVE)
12609373 TUBE, PCV (FRESH AIR)
12597774 TUBE, PCV (DIRTY AIR) (INCLS 903) (W/ PVC VALVE AT MANIFOLD)
12554211 STUD, IGN COIL BRKT (HFH, M6X1X18) (M6X1X18.5X14) (3.330) (ACDelco #12554211)
19206446 WIRE, SPLG (*KIT1) (ACDelco #357D)
12608814 SENSOR, ENG COOL TEMP (MATING CONN W/LEADS USE 88987993) (ACDelco #213-4333)
12621258 SPARK PLUG, (GAP 0.040) (DO NOT CHANGE SPARK PLUG GAP FROM .040) (ACDelco #41-110) (IRIDIUM)
12569167 ARM, INT VLV RKR (OFFSET INLET ROCKER ARM) (ARM, VLV RKR INT. FOR EXHST VLV RKR ARM SEE PN 10214664, QTY=8)
19206447 WIRE KIT, SPLG (INCLS 724) (INCLS SET OF 8 LEADS) (ACDelco #748UU)
19297035 WIRE KIT, SPLG (INCLS 724) (ACDelco #9748UU) (ALL MAKES)
(TX00-063) 2010-2013 CK1 ДВИГАТЕЛЬ В СБОРЕ-6.2L V8 PART 5 ВПУСКНОЙ КОЛЛЕКТОР И СОПУТСТВУЮЩИЕ ДЕТАЛИ ТОПЛИВНОЙ СИСТЕМЫ (L94/6.2F)
12585328 FILTER, VLV LFTR OIL (PART OF 555) (INCLS O-RING SEAL)
12597600 MANIFOLD, INT (ACDelco #12597600)
11518075 BOLT, HFH, THD 22, OD 17, 8.8, GMW14C-PT, HDR POINT (ENG BLK VALLEY CVR)
12629992 BODY, THROT (W/THROT ACTR) (SEE GROUP 03.000 "THROTTLE BODY" FOR DETAILED ILLUSTRATED VIEW) (ACDelco #217-3151)
12589235 SEAL, THROT BODY (ACDelco #217-2424)
teamcadillac.ru
12580910 BOLT, F/INJR DRVR MDL
12575384 BOLT, INT MANIF
19207929 GASKET, INT MANIF
12580901 MANIFOLD, VLV LFTR OIL (INCLS 452, 556) (INCLS CYL DEACTIVATION SOL, GASKET, FILTER, RETAINER, BOLTS, CAP)
89017690 GASKET, VLV LFTR OIL UPR MANIF (PART OF 555) (W/O THE CENTER PORTION)
12616285 MANIFOLD, EXH (INCLS 603, 604) (INCLS SHIELD, BOLTS)
12616286 MANIFOLD, EXH (INCLS 603, 604) (INCLS SHIELD, BOLTS)
12617944 GASKET, EXH MANIF (ACDelco #12617944)
11518860 BOLT, HFH, M8X1.25X30, 20.9 THD, 18 O.D., 10.9, GMW3179 CODE G, GM6194M (EXH MANIF FLG)
12562243 SHIELD, EXH MANIF HT (PART OF 600)
12562244 SHIELD, EXH MANIF HT (PART OF 600)
11519840 BOLT, HFH, M6X1X12.3, 6.3 THD, 14.2 OD, 10.9, GMW3359, MACH, MAT-PT (PART OF 600)
12621234 SENSOR, ENG OIL PRESS (ACDelco #213-4411)
12578463 STOP, F/INJN FUEL RL
11515764 BOLT, HFH, M10X1.5X20, 18THD, 22.3 O.D., 10.9, 7114M (F/INJN FUEL RL STOP)
12644228 SENSOR, MAP (INCLS 715) (ACDelco #12644228)
12574897 HARNESS, EVAP EMIS CNSTR
12597567 VALVE, EVAP EMIS CNSTR PURGE SOL (VALVE ONLY) (USE T/W 12579283 BRKT) (ACDelco #214-1680)
12617169 TUBE, EVAP EMIS CNSTR PURGE
12615934 RETAINER, MAP SEN
12593801 BRACKET, F/INJN FUEL RL
89017591 BOLT KIT, THROT BODY (INCLS BOLT, STUD, NUT) (INCLS 507, 538, 901)
(TX00-151) 2010-2013 CK1,2(06-36) КРЕПЛЕНИЕ ДВИГАТЕЛЯ К КОРОБКЕ ПЕРЕДАЧ (MYC,MYD)
24261712 COVER, TRANS (ACDelco #24261712)
12560226 BOLT, HEX W/FLAT WASH, M6.0X1.0X14.5, 13.5, 17 OD, 9.8, 7114M, MACH (TRANS CVR)
11589040 BOLT, TRANS T/CV (M10X1.5X22)
11515768 BOLT, HFH, REDUCED BODY, M10X1.5X40, 30THD, 22.3 O.D., HDR PT, 10.9, 7114M (TRANS)
11519797 STUD, TRANS (DOUBLE END, HFH, M8X1.25X20, M10X1.5X40, 18 OD, 69.5 TL9.8, GMW3359)
24205899 PLUG, T/CV HSG ACC HOLE (28MM W/3 TANGS) (SMALL CVR) (ACDelco #24205899)
teamcadillac.ru
24261713 COVER, TRANS (ACDelco #24261713)
01 - СИСТЕМА ОХЛАЖДЕНИЯ-РЕШЕТКА-МАСЛЯНАЯ СИСТЕМА
(TC01-679) 2008-2013 CK107(06) СИСТЕМА ОХЛАЖДЕНИЯ-КРЕПЛЕНИЕ РАДИАТОРА (HYBRID HP2)
11570616 CLAMP, SPRINGBAND, 27 NOMINAL DIA, 15 THK, STL, ROBO (PART OF 1)
teamcadillac.ru
11516931 BOLT, FLAT WA & METRIC HEX HD MACHINE, M8X1.25X50 (RAD UPR MT)
11570616 CLAMP, SPRINGBAND, 27 NOMINAL DIA, 15 THK, STL, ROBO (PART OF 7)
(TC01-903) 2008-2011 CK1(06-36) РЕШЕТКА РАДИАТОРА (CADILLAC Z75, EXC PLATINUM EDITION ULT)
25705182 BOLT, FRT BPR FASCIA CTR SUPT (M9.5X6.0 HI-LO, TL 47MM, 22 OD) (12.249)
teamcadillac.ru
11610055 BOLT, HWASH, M6X1X23 (FRT BPR UPR FASCIA)
25841844 GRILLE, FRT (INCLS 1-4, 8) (CARBON FLASH)
20824262 GRILLE, FRT (INCLS 1-4, 8) (LABYRINTH)
20824264 GRILLE, FRT (INCLS 1-4, 8) (BLUE)
20824260 GRILLE, FRT (INCLS 1-4, 8) (GRAY)
20824259 GRILLE, FRT (INCLS 1-4, 8) (RED)
22860569 GRILLE, FRT (INCLS 1-4, 8) (WHITE)
22860570 GRILLE, FRT (INCLS 1-4, 8) (BLACK)
22860571 GRILLE, FRT (INCLS 1-4, 8) (GOLD)
19260456 GRILLE, FRT (INCLS 1-4, 8) (SILVER)
22860587 EMBLEM, FRT GRL (PART OF 7) (WREATH/CREAST)
15907251 MOLDING, HOOD FRT (INCLS 10) (CHROME)
11561788 CLIP, 13X15X12, 1.5 PNL, 1050, 6280M (PART OF 9)
11518121 NUT, U, M6X1, MULTI THD, .5'-4.0' THK PNL (FRT GRL UPR BRKT)
(TC01-903) 2009-2013 CK1(06) РЕШЕТКА РАДИАТОРА (CADILLAC Z75, PLATINUM EDITION ULT, HEADLAMP T84)
teamcadillac.ru
(TC01-905) 2010 CK1(06-36) КРЕПЛЕНИЕ РАДИАТОРА И СВЯЗАННЫЕ ДЕТАЛИ (CADILLAC Z75, L9H/6.2-2,L94/6.2F)
15780790 INSULATOR, ENG COOL FAN SHRD (UPPER)
11516931 BOLT, FLAT WA & METRIC HEX HD MACHINE, M8X1.25X50 (ENG COOL FAN)
15780791 INSULATOR, ENG COOL FAN SHRD (LOWER)
89019121 INSULATOR, RAD LWR (PART OF 7)
10392941 BAFFLE, RAD SUPT
19130464 STRAP, TIE 0.38" WIDTH, BUNDLE DIA 1/16"-1-3/4", 8.27" LENGTH, NYLON 6/6 FITS 0. (WRG HARN)
teamcadillac.ru
10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (RAD SUPT BFL)
15208497 BAFFLE, RAD AIR (INCLS 12)
15837581 CUSHION, BODY MT UPR FRT (VIOLET) (1.270)
15201791 CUSHION, BODY MT LWR FRT (71MM OD)
03537772 NUT, M12X1.75, 10.6THK, 28 O.D., 10, 7111M (BODY MT) (8.917)
11562547 BOLT, HFH, M12X1.75X135, 100 THD, 24.7 OD, GMW25 (10.9) STL, GM 7112M, MACH (BODY MT)
15208496 BAFFLE, RAD AIR (INCLS 12)
10392942 BAFFLE, RAD SUPT
11570097 NUT, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (PART OF 23)
11610055 BOLT, HWASH, M6X1X23 (FRT GRL SUPT REINF)
15904442 BRACKET, FRT GRL UPR (INCLS 21, 24)
22581725 CLIP, HOOD PRIM LAT REL CBL (PART OF 23) (7.0 MM DIA) (HOLDS (1) PIPE 4.76 TO 6.35) (3.145)
22737375 BAFFLE, RAD AIR UPR (INCLS 27)
22737378 BAFFLE, RAD AIR UPR (INCLS 27)
11561878 RETAINER, PUSH PIN W/SEAL, FITS 8.0-8.25 DIA HOLE IN 3-7MM THK PNL (RAD AIR UPR BFL (PUSH IN))
11562546 WASHER, FLAT, 14X42.5X3.61 MM, SAE 1050 STL RC 37-43, 7112M (BODY MT)
(TC01-907) 2007-2013 CK1(06-36) РАМА КРЕПЛЕНИЯ РАДИАТОРА (ТЕЛЕВИЗОР)
20805489 SUPPORT, RAD (INCLS 2-9) (W/AMB AIR TEMP SENSOR MTD IN BRACE-F/END SH MET) (FOR 2ND DES SEE 20927280)
20927280 SUPPORT, RAD (INCLS 2-9) (W/AMB AIR TEMP SENSOR MTD IN BRACE-F/END SH MET RAD OPENING) (FOR 1ST DES SEE 20805489)
20927279 SUPPORT, RAD (INCLS 2-9)
teamcadillac.ru
25870919 SUPPORT, F/END UPR TIE BAR (INCLS 3, 6) (PART OF 1)
11561407 NUT, INSERT , M6X1, 10MM HOLE, 1.7-5.25 PANEL, 19 LONG, 12.9 OD, 1008, GMW3 (PART OF 1, 2, 8) (8.921)
11516932 BOLT, HEX HD, W/CON WA, M6X1X25, 9.8, 6138M (PART OF 1)
11609989 BOLT, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (PART OF 1, 8)
11561916 NUT, INSERT, M8X1.25, 13.5 HOLE, 0.7-3.8 GRIP, 24 LONG, 17.4 OD, 1008, GMW (PART OF 1, 2)
15744933 BOLT, HEX HD, W/CON WA, M6X1X45 (PART OF 1) (1.267)
25870916 BRACE, F/END SH MET RAD OPG (INCLS 3, 5, 9) (PART OF 1) (BUILT W/AMB AIR TEMP SENSOR MTD IN BRACE-F/END SH MET) (FOR 2ND DES SEE 20968548)
20968548 BRACE, F/END SH MET RAD OPG (INCLS 3, 5, 9) (PART OF 1) (BUILT W/AMB AIR TEMP SENSOR MTD IN BRACE-F/END SH MET RAD OPG) (FOR 1ST DES SEE 25870916)
20968547 BRACE, F/END SH MET RAD OPG (INCLS 3, 5, 9) (PART OF 1)
25870918 BRACE, F/END SH MET CR (PART OF 1, 8)
(TC01-912) 2010-2011 CK1(06-36) ВЕНТИЛЯТОР ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ (CADILLAC Z75, L94/6.2F)
15780790 INSULATOR, ENG COOL FAN SHRD (PART OF 5) (UPPER)
10309116 LABEL, FAN BLADE WRNG (PART OF 5) (BLACK NYLON)
11570097 NUT, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (PART OF 5)
15780789 SHROUD KIT, ENG COOLING FAN (INCLS 1, 2, 4, 6, 7, 12) (7/9 FAN BLADES) (USE T/W MOTOR KITS 15780795 & 15780796 AND BLADE KITS 15780793 & 15780794 IF OEM SHROUD IS STAMPED 20895139 OR 20923004)
15780788 SHROUD KIT, ENG COOLING FAN (INCLS 1, 2, 4, 6, 7, 12) (5/7 FAN BLADES) (USE T/W MOTOR KIT 89023368 (QTY 2) & BLADE KITS 89023366 & 89024933 IF OEM SHROUD IS STAMPED 20895140 OR 20923003)
15780791 INSULATOR, ENG COOL FAN SHRD (PART OF 5) (LOWER)
15780792 SPACER, ENG COOL FAN SHRD (PART OF 5)
15780795 MOTOR KIT, ENG CLG FAN (INCLS 12) (9-BLADE RIMMED FAN - 700 WATT) (ACDelco #15-80880)
20903474 MOTOR KIT, ENG CLG FAN (INCLS 12) (5-BLADE RIMLESS FAN - 700 WATT) (ACDelco #15-81696)
15780796 MOTOR KIT, ENG CLG FAN (INCLS 12) (7-BLADE RIMMED FAN - 700 WATT) (ACDelco #15-80881)
20903475 MOTOR KIT, ENG CLG FAN (INCLS 12) (5-BLADE RIMLESS FAN - 700 WATT) (ACDelco #15-81697)
22728347 BOLT, ENG COOL FAN SHRD
15780794 BLADE KIT, ENG CLG FAN (9 BLADE) (INCLS 12) (ACDelco #15-80883)
teamcadillac.ru
20897351 BLADE KIT, ENG CLG FAN (INCLS 12) (5 BLADE, RIMLESS FAN) (ACDelco #15-81694)
22722593 CLIP, ENG COOL FAN SHRD (PART OF 5, 8, 9, 11, 13)
15780793 BLADE KIT, ENG CLG FAN (7 BLADE) (INCLS 12) (ACDelco #15-80882)
20897350 BLADE KIT, ENG CLG FAN (INCLS 12) (5-BLADE RIMLESS FAN) (ACDelco #15-81693)
(TC01-913) 2010 CK1 ШЛАНГИ РАДИАТОРА (L20/4.8A,LMG/5.3-0,LC9/5.3-3,L94/6.2F)
22797286 TANK, RAD SURGE (ACDelco #22797286)
15012559 CLAMP, SPR (18.4MM TO 21.6MM) NOMINAL SIZE 20MM, STAMPED "20" (RAD SURGE TK INL HOSE) (1.240)
22827733 HOSE, RAD SURGE TK INL
22827734 HOSE, RAD VENT INL
15734742 CLAMP, RAD SURGE TK ENG HOSE (13-16MM DIA RANGE)
15041309 CLIP, RAD VENT INL HOSE
teamcadillac.ru
15004599 CLAMP, RAD SURGE TK ENG HOSE (BLACK) (15MM OD 17.2MM)
22827735 HOSE, RAD OTLT
11571140 CLAMP, SPRINGBAND, 16 DIA, 15 WIDTH, STL PER GM6298M, GMW14083 (RAD OTLT HOSE RAD)
11562099 CLAMP, SPRINGBAND, NOMINAL DIA 49MM, 20 WIDTH, MAT'L 6298M, ROBO FINISH (RAD OTLT HOSE END)
15041307 CLIP, RAD SURGE TK INL HOSE (PART OF 13) (BLACK) (FOR 37.1-44 DIA HOSE & 12.8-15 DIA HOSE;PRONG FOR 8.0 HOLE)
15159494 CLIP, RAD INL HOSE (PART OF 13) (PUSH-IN CLIP 37-44 DIA 12.8 DIA)
22827731 HOSE, RAD INL (INCLS 11, 12)
11570618 CLAMP, SPRINGBAND, 42 NOMINAL DIA, 20 THK, STL, ROBO (RAD INL HOSE)
11570616 CLAMP, SPRINGBAND, 27 NOMINAL DIA, 15 THK, STL, ROBO (RAD SURGE TK OTLT HOSE)
15834772 HOSE, RAD SURGE TK OTLT
15834773 HOSE, RAD SURGE TK OTLT
15012561 CLAMP, HOSE SPR, 27 NOM, 25.2 MIN-28.9 MAX, 15MM WIDE, BLACK (RAD SURGE TK OTLT HOSE) (8.948)
11609982 BOLT, HEX W/FL WA, M6X1X22, 14.55 THD, 24 OD, 8.8, GMW3359, M-PT. (RAD SURGE TK)
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (RAD SURGE TK)
13502353 CAP, RAD SURGE TK
(TC01-915) 2010-2011 CK1 ОБОГРЕВАТЕЛЬ БЛОКА ДВИГАТЕЛЯ (LC9/5.3-3,LZ1/6.0J,L9H/6.2-2,L94/6.2F)
20882797 CORD, ENG COOL HTR
teamcadillac.ru
11610073 BOLT, HEX W/FL WA, M8X1.25X16, 12.45 THD, 18 OD, GM6202M, GMW3200 (ENG COOL HTR CORD CLIP)
(TC01-919) 2010-2013 CK1 РАДИАТОР В СБОРЕ (LMG/5.3-0,L9H/6.2-2,L94/6.2F)
22840116 RADIATOR, (CORE SIZE 34IN X 17 1/4IN X 1 1/8IN, TRANS OIL CLR) (INCLS 2-7) (CODE CBE, JHW, EBR, AJM, SDD, APB, ARZ, AXU, AAF9, 0116) (ACDelco #21649) (ALL MAKES)
teamcadillac.ru
15226661 CONNECTOR, TRANS FLUID CLR PIPE (PART OF 1) (INCLS 4) (9/16-18) (3/8 BODY QUICK CONNECT) (AT RAD) (ACDelco #15226661)
24205103 RETAINER, TRANS FLUID CLR PIPE FTG (PART OF 1, 3) (EXPANDING SPRING WIRE) (ACDelco #24205103)
15190249 CONNECTOR, ENG OIL CLR HOSE (PART OF 1) (INCLS 6) (ALUMINUM) (ACDelco #15190249)
15724727 RETAINER, TRANS FLUID CLR PIPE CONN (PART OF 1, 5) (1/2" WIRE CLIP) (1.540)
89019121 INSULATOR, RAD LWR (PART OF 1)
(TC01-946) 2009-2013 CK1(06) РЕШЕТКА РАДИАТОРА (CADILLAC Z75, PLATINUM EDITION ULT, EXC HEADLAMP T84)
teamcadillac.ru
22860588 GRILLE, FRT UPR (INCLS 4, 7) (SILVER)
11515638 NUT, U-TYPE, M4.2X1.41X10.5.5X22, .65-3.8 PNL THK, 1050, ZF (FRT UPR GRL)
22549046 SCREW, M4.2X1.4X25, 11.1 O.D., 6010M, NZ (PART OF 1)
11589039 BOLT, HEX, W/CON WA, M6X1X30, 20 THD, 24 O.D., 9.8, GMW4205 (FRT GRL SUPT REINF)
25957702 GRILLE, FRT LWR (SILVER)
22860589 EMBLEM, FRT GRL (PART OF 1) (MEDALLION)
11589015 BOLT, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (FRT UPR GRL)
(TS01-555) 2010-2011 CK1 ШКИВЫ И РЕМНИ/ПРИВОД ВСПОМОГАТЕЛЬНЫХ АГРЕГАТОВ (L20/4.8A,LMG/5.3-0,LC9/5.3-3,L9H/6.2-2,L94/6.2F)
12609719 TENSIONER, DRV BELT (2 BOLT DESIGN REPLACES 3 BOLT DESIGN, DISCARD UNUSED BOLT) (ACDelco #12609719)
11518633 BOLT, HFH, M10X1.5X75, 26 THD, 22.3 OD, 10.9, GMW3359, MAT- POINT. (DRV BELT TENSR)
teamcadillac.ru
12580771 PULLEY, BELT IDLER (INCLS 3) (SMOOTH CODE 5609, 0771) (ACDelco #12580771)
19210691 BELT, A/C CMPR
12626222 BELT, FAN & W/PMP & GEN & P/S PUMP (2370 MM)
02 - СТАРТЕР-ГЕНЕРАТОР-СИСТЕМА ЗАЖИГАНИЯ-ЭЛЕКТРООБОРУДОВАНИЕ-ЛАМПЫ
(GM02-126) 2010-2011 CK1 КАТУШКА И МОДУЛЬ ЗАЖИГАНИЯ (MELCO)(L20/4.8A,LMG/5.3-0,LC9/5.3-3,LZ1/6.0J,L94/6.2F)
11516424 BOLT, HFH, M6X1X25, 14.2 O.D., HDR PT, 9.8, ZE (IGN COIL)
12611424 COIL, IGN (MELCO-MITSUBISHI) (W/SQUARE-SHAPED COILS AND MARKED 12570616) (MATING CONN W/LEADS USE 88987184) (ACDelco #D510C)
teamcadillac.ru
12580353 BRACKET, IGN COIL (ACDelco #12580353)
12579355 WIRE, IGN COIL (INCLS CONNS) (ACDelco #357A)
(GM02-127) 2010-2011 CK1 КАТУШКА И МОДУЛЬ ЗАЖИГАНИЯ (DELPHI)(L20/4.8A,LMG/5.3-0,LC9/5.3-3,LZ1/6.0J,L94/6.2F)
11562426 BOLT, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (IGN COIL)
12573190 COIL, IGN (DELPHI) (W/ROUND-SHAPED COILS AND MARKED 12573190)) (ACDelco #D514A)
teamcadillac.ru
(GM02-133) 2010-2011 CK СВЕЧНОЙ ПРОВОД (L20/4.8A,LMG/5.3-0,LC9/5.3-3,LZ1/6.0J,L94/6.2F)
teamcadillac.ru
19206447 WIRE KIT, SPLG (INCLS 1) (INCLS SET OF 8 LEADS) (ACDelco #748UU)
(GM02-148) 2007-2013 CK1,2,3 КЛЮЧ И ЦИЛИНДР ЗАМКА ЗАЖИГАНИЯ
15926907 KEY, IGN LK (PRE-CUT & PROGRAMMED)
15926908 KEY, IGN LK (PRE-CUT & PRE-PROGRAMED FOR FLEET)
teamcadillac.ru
20985619 KEY, IGN (UNCODED) (MASTER)
(TC02-032) 2010-2013 CK1,2(06-36) ПРОВОДА АККУМУЛЯТОРА (EXC HYBRID HP2, DUAL BATTERY 6A6, WIRING PROVISIONS 9L4)
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (ENG GND STRP)
11609619 BOLT, HEX W/ FL WA-M10X1.5X16, 20 OD, 10.9 STL, GMW3200 FINISH (ENG GND STRP)
22850357 CABLE, BAT POS (ACDelco #22850357)
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BAT POS CBL)
20943125 CABLE, GEN BAT JPR (INCLS 5) (ACDelco #20943125)
20774386 CABLE, STRTR SOL (INCLS 18-26) (ACDelco #20774386)
teamcadillac.ru
22790285 CABLE, STRTR SOL (INCLS 18-26) (ACDelco #22790285)
11516885 SCREW, HFH W/FL WA, TAP, M8X1.25X20, 7THD, 17 O.D., TR PT, 6202M, PZOR (BAT POS CBL CLIP)
21021808 NUT, STRTR SOL CBL (M8X1.25X6, BRASS)
10306471 SENSOR, BAT CUR (PART OF 16) (FOR VEH WITH 10V SUPPLY FROM BCM) (FOR 2ND DES SEE 13505369)
13505369 SENSOR, BAT CUR (PART OF 16) (FOR VEH WITH 5V SUPPLY FROM BCM) (FOR 1ST DES SEE 10306471)
11561048 BOLT, HEX W/FL WA-3/8-16X.625, .82 OD, GM275 STL, GMW3200 FINISH (ENG WRG HARN GND)
11588337 BOLT, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (FWD LP WRG HARN GND)
20967455 CABLE, BAT NEG (INCLS 13, 17-20) (ACDelco #20967455)
19116354 CLIP, BAT CBL (PART OF 16)
19116852 BOLT KIT, BAT CBL TERM (PART OF 8, 16) (INCLS 19, 20)
20929135 BLOCK, BAT POS CBL JUNC (PART OF 8)
15305191 FUSE, 175 AMP MEGA (PART OF 8) ( FUSE COLOR, BLACK W/SIZE STAMPED IN WHITE ON CASE)
19116038 COVER, BAT POS CBL TERM (PART OF 8)
25797040 COVER, BAT POS CBL TERM (PART OF 8) (TOP)
25888958 COVER, BAT POS CBL TERM (BOTTOM) (PART OF 8)
20929134 COVER, BAT POS CBL TERM (PART OF 8)
(TC02-085) 2008-2013 CK1,2(06) СИСТЕМА ДАТЧИКОВ/ОБЪЕКТ СЗАДИ (UD7)
20956795 MODULE, RR OBJECT ALARM CONT
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (PARK ASST ALARM CONT MDL)
22899760 HARNESS, RR OBJECT ALARM SEN WRG
21997869 INDICATOR, RR OBJECT ALARM (PART OF 4)
11509253 SCREW, W/LRG WA HD, M4.2X1.4X10, 11.3 O.D., BHL PT, STL, NO (PART OF 4)
teamcadillac.ru
19116085 SENSOR KIT, PARK ASST ALARM (INCLS 8) (PRIMED) (W/HOUSING) (7.831)
15239247 SENSOR KIT, PARK ASST ALARM (INCLS 8) (PRIMED) (W/O HOUSING) (MATING CONN W/LEADS USE PART 88988337) (7.831)
(TC02-212) 2009-2013 CK1(06) ФАРЫ ПЕРЕДНИЕ (CADILLAC Z75, L.E.D. HEADLAMP T4Q)
25999509 HEADLAMP, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 7-9)
25999510 HEADLAMP, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 7-9) (2.725)
11589039 BOLT, HEX, W/CON WA, M6X1X30, 20 THD, 24 O.D., 9.8, GMW4205 (HDLP HSG)
11610055 BOLT, HWASH, M6X1X23 (HDLP HSG PNL)
15874642 SUPPORT, HDLP HSG
15874643 SUPPORT, HDLP HSG
11518121 NUT, U, M6X1, MULTI THD, .5'-4.0' THK PNL (HDLP HSG PNL)
11561804 BOLT, HDLP CONT MDL (PART OF 1) (2.727)
25883862 MODULE, HDLP CONT (PART OF 1)
25883863 COVER, PARK LP ACC HOLE (PART OF 1)
10346260 BULB, FRT FOG LP (PART OF 15) (BASE BLACK/CAP ORANGE) (TRADE 9145) (L-SHAPED) (ACDelco #9145)
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (FRT FOG LP)
teamcadillac.ru
10351663 BULB, FRT T/SIG LP (INCLS 12) (PART OF 15) (AMBER) (TRADE #3457NAK) (2.880) (ACDelco #10351663)
15789983 HARNESS, FRT FOG LP WRG HARN EXTN
10383563 LAMP, FRT FOG (INCLS 10, 12, 13)
10383562 LAMP, FRT FOG (INCLS 10, 12, 13)
15930599 LAMP, FRT SI T/SIG (FRT FENDER SIDE)
(TC02-213) 2009-2013 CK107(06) ЖГУТ ПРОВОДОВ/ШАССИ (HYBRID HP2, MAGNERIDE Z95)
20893956 HARNESS, CHAS WRG (INCLS 2, 13)
20893958 HARNESS, CHAS WRG (INCLS 2, 13)
20893957 HARNESS, CHAS WRG (INCLS 2, 13)
19115819 TUBE, RR S/ABS AIR (PART OF 1)
teamcadillac.ru
12191503 RECEPTACLE, TOW VEH ELEC (W/DOOR)
11588337 BOLT, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (TRLR WRG HARN GND)
11588833 RETAINER, PUSH-IN, PLASTIC TREE, DIA 8.6, LENGTH 21.2, NYLON GMP.PA66.063, BLACK (CHAS RR WRG HARN)
15045897 BRACKET, CHAS FRT WRG HARN
21011332 NUT, HEX STAMPED TY DF FLG 14 (CHAS FRT WRG HARN BRKT) (8.921)
11609412 NUT, CHAS RR WRG HARN J/BLK LEAD (CONTAINS CONDUCTIVE FINISH FOR ELECTRICAL GROUND) (8.917)
12193601 RELAY, AUTO LVL CONT (5-WAY MALE, BLACK, CODE 7233) (PART OF 1) (BLACK) (USED W/CONNECTOR 15306045 W/O BRKTS 5-WAY MALE) (9.277) (ACDelco #15-8719)
(TC02-603) 2010-2011 CK1 КРЕПЛЕНИЕ ГЕНЕРАТОРА (L20/4.8A,LMG/5.3-0,LC9/5.3-3,L9H/6.2-2,L94/6.2F)
25877026 GENERATOR, (ACDelco #25877026)
20881337 GENERATOR, (2 WIRE GENERATOR) (ACDelco #20881337)
20989651 GENERATOR, (USE T/W 98072072 PULLEY FOR BELT LINE-UP) (4 WIRE GENERATOR) (ACDelco #20989651)
12554030 BRACKET, GEN & P/S PUMP (INCLS 5) (INCLS SPACER)
11516744 BOLT-HFH, M10X1.5X110, 26 THD, 22.3 OD, 9.8, 7114M (GEN & P/S PUMP BRKT)
teamcadillac.ru
11516360 BOLT, HFH M10X1.2X90, 9.8, 7114M, 22.3 OD HDR PT (GEN)
12550090 SPACER, GEN & P/S PUMP BRKT (PART OF 2)
(TC02-787) 2009-2010 CK107(06) ПРОВОДА АККУМУЛЯТОРА (DUAL BATTERY 6A6)
teamcadillac.ru
19116038 COVER, BAT POS CBL TERM (PART OF 5)
19116852 BOLT KIT, BAT CBL TERM (PART OF 5, 7, 18, 25) (INCLS 2, 3)
25825642 CABLE, AUX BAT POS (INCLS 1-4) (ACDelco #25825642)
11609619 BOLT, HEX W/ FL WA-M10X1.5X16, 20 OD, 10.9 STL, GMW3200 FINISH (AUX BAT NEG CBL)
25876896 CABLE, AUX BAT NEG (INCLS 2-4) (ACDelco #25876896)
25862352 CABLE, AUX BAT POS (RH PROC) (ACDelco #25862352)
21011332 NUT, HEX STAMPED TY DF FLG 14 (BAT POS CBL RET) (8.921)
15881616 COVER, BAT POS CBL J/BLK (3 WAY MEGAFUSE)
21021808 NUT, BAT HDL (M8X1.25X6, BRASS) (2.343)
15106388 FUSE, (MEGA FUSE) (BLACK) (60 AMP) (8.965)
19116352 HOLDER, WRG HARN FUSE (ACDelco #19116352)
12177251 FUSE, 125 AMP MEGA FUSE (125 A) (FUSE COLOR, BLACK W/SIZE STAMPED IN WHITE ON CASE)
15305191 FUSE, 175 AMP MEGA (ASHTRAY LP) ( FUSE COLOR, BLACK W/SIZE STAMPED IN WHITE ON CASE)
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BAT POS CBL J/BLK BRKT)
25797040 COVER, BAT POS CBL TERM (PART OF 18) (TOP)
20774386 CABLE, STRTR SOL (INCLS 2-4, 17, 19) (ACDelco #20774386)
22790285 CABLE, STRTR SOL (INCLS 2-4, 17, 19) (ACDelco #22790285)
25888958 COVER, BAT POS CBL TERM (PART OF 18)
10306471 SENSOR, BAT CUR (PART OF 25) (FOR VEH WITH 10V SUPPLY FROM BCM) (FOR 2ND DES SEE 13505369)
13505369 SENSOR, BAT CUR (PART OF 25) (FOR VEH WITH 5V SUPPLY FROM BCM) (FOR 1ST DES SEE 10306471)
11561111 STUD, BAT NEG CBL GND (M10 X1.5 X 20)
11588337 BOLT, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (BAT NEG CBL GND)
20967455 CABLE, BAT NEG (INCLS 2-4, 22, 26) (ACDelco #20967455)
19116354 CLIP, BAT CBL (PART OF 25)
(TC02-890) 2009-2013 K1 МОДУЛЬ УПРАВЛЕНИЯ КУЗОВОМ & SERIAL DATA GATEWAY (EXPORT T89)
teamcadillac.ru
15093913 BRACKET, BCM
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (BCM BRKT) (9.665)
25835966 MODULE, BODY CONT (ACDelco #25835966)
25843242 MODULE, AUX BODY CONT (ACDelco #25843242)
11609539 SCREW, RD CROWNED WA HD, M4.2X1.41X16, STL ISO 2702, GMW4205 (BCM BRKT)
20803814 BRACKET, AUX BODY CONT MDL
11513599 NUT, U-TYPE, M4.2X1.41, 0.65-3.80 PNL THK, PZ (BCM BRKT) (ACDelco #11513599)
(TC02-896) 2009-2013 CK1(06) СИСТЕМА ДАТЧИКОВ/СТОЛКНОВЕНИЕ (UFT)
25820974 BRACKET, SIDE OBJECT SEN (INNER)
25820975 BRACKET, SIDE OBJECT SEN (INNER)
11589015 BOLT, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (SIDE OBJECT SEN)
20823460 MODULE, SIDE OBJECT SENSING ALERT
15941140 BRACKET, SIDE OBJECT SEN (OUTER)
15941274 BRACKET, SIDE OBJECT SEN (OUTER)
teamcadillac.ru
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (SIDE OBJECT SEN)
11513599 NUT, U-TYPE, M4.2X1.41, 0.65-3.80 PNL THK, PZ (SIDE OBJECT SEN) (ACDelco #11513599)
21030249 RETAINER, EXPAN, 21 LG, 20. OD, 8.0 HOLE, 3.0-5.0 PNL, NYLON 6/6, BLK (SIDE OBJECT SENSING ALERT MDL) (8.950) (PUSH IN)
(TC02-899) 2008-2013 CK107(06) ЖГУТ ПРОВОДОВ/ШАССИ GROUND STRAPS (HYBRID HP2)
25866712 STRAP, BODY GND
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BODY GND STRP)
12337820 STRAP, 15" TIE STRAP (ACSRY WRG HARN) (ACDelco #12337820)
25949588 STRAP, R/AXLE WRG HARN
teamcadillac.ru
11515755 BOLT, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (RR BRK HOSE) (T/W 12345493 REPLCS 25534835)
(TC02-902) 2009-2013 CK1(06-36) ФАРЫ ПЕРЕДНИЕ (CADILLAC Z75, EXC L.E.D. HEADLAMP T4Q)
01999367 BULB, FRT T/SIG LP (PART OF 8) (TRADE 3757AK) (8.991) (ACDelco #3757A)
10351663 BULB, FRT T/SIG LP (PART OF 8) (AMBER) (TRADE #3457NAK) (2.880) (ACDelco #10351663)
10346260 BULB, FRT FOG LP (PART OF 8) (BASE BLACK/CAP ORANGE) (TRADE 9145) (L-SHAPED) (ACDelco #9145)
10383562 LAMP, FRT FOG (INCLS 5-7)
10383563 LAMP, FRT FOG (INCLS 5-7)
25779063 LAMP, FRT FOG (INCLS 5-7)
25779062 LAMP, FRT FOG (INCLS 5-7)
20806108 HEADLAMP, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 10-20) (2.725)
20806109 HEADLAMP, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 10-20) (2.725)
teamcadillac.ru
25897647 HEADLAMP, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 10-20) (2.725)
25897646 HEADLAMP, (W/PARK & FRT SI MKR & T/SIG LP) (INCLS 10-20) (2.725)
11561804 BOLT, HDLP BULB BALLAST (PART OF 9)
15782392 BALLAST, HDLP (PART OF 9)
15816281 ADAPTER, HDLP BULB (PART OF 9)
15862954 ADAPTER, HDLP BULB (PART OF 9)
25735604 BULB, HDLP (PART OF 9) (TRADE #D1S) (W/IGNITOR) (ACDelco #25735604)
13503384 BULB, HDLP (PART OF 9) (LONG LIFE) (ACDelco #13503384)
15782399 ADAPTER, DAYTIME RUNNING LP BULB (PART OF 9)
10351675 BULB, DAYTIME RUNNING LP (PART OF 9) (CLEAR) (DAYTIME RUNNING LAMP) (ACDelco #10351675)
09421330 BULB, TRADE#194, 12V, 2CP (PART OF 9) (ACDelco #L194)
15782393 COVER, DAYTIME RUNNING LP BULB ACC (PART OF 9)
15782398 COVER, HDLP BULB ACC (PART OF 9)
11610055 BOLT, HWASH, M6X1X23 (HDLP HSG)
(TC02-903) 2007-2013 CK1,2,3 КЛАКСОН (EXC EXPORT VD1)
89046919 HORN KIT, GENERIC (HIGH NOTE) (INCLS 4) (MAY REQUIRE 19116451 WIRE ASM) (INCLUDES 485 HZ HORN, BRKT) (ACDelco #D1933E)
19301083 HORN KIT, GENERIC (HIGH NOTE) (INCLS 4) (MAY REQUIRE 19116451 WIRE ASM) (INCLUDES 485 HZ HORN, BRKT)
11589076 BOLT, HEX HD, W/CON WA, M6X1X15, 7.5 THD, 17 O.D., 6202M, GMW3044 (HORN)
teamcadillac.ru
89046918 HORN, 400 HZ (INCLS 4) (MAY REQUIRE 19116451 WIRE ASM) (INCLS 405 HZ HORN & BRKT) (ACDelco #D1932E)
19301082 HORN, 400 HZ (INCLS 4) (MAY REQUIRE 19116451 WIRE ASM) (INCLS 405 HZ HORN & BRKT)
(TC02-904) 2008-2013 CK1,2,3 МОДУЛЬ УПРАВЛЕНИЯ КУЗОВОМ & SERIAL DATA GATEWAY (EXC EXPORT T89)
11513599 NUT, U-TYPE, M4.2X1.41, 0.65-3.80 PNL THK, PZ (I/P EXTN) (ACDelco #11513599)
15801751 BRACKET, I/P CARR LOC PIN
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (I/P (TO RET)) (9.665)
25883951 MODULE, SERIAL DATA GATEWAY (W/O CALN & OPERG SYS)
(TC02-907) 2007-2013 CK1(06) ФАРЫ ЗАДНИЕ (CADILLAC Z75)
15270012 SEAL, E/GATE CTR MLDG (PART OF 2)
25970660 APPLIQUE, L/GATE UPR (W/O HIGH MT S/LP #25779085, NUT #11609411, & WIRE HARNESS #15857136) (INCLS 1, 4-6) (PAINT TO MATCH)
25779085 LAMP, HIGH MT STOP (INCLS CZ2 STAMP)
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (PART OF 2)
15857136 WIRE, HIGH MT S/LP (PART OF 2)
11561972 BOLT, L/GATE APLQ (PART OF 2) (6 X 1 X 21)
11562290 BOLT, L/GATE APLQ (M6X1X28) (26 OD, 9.8)
11508277 NUT, HEX W/CON WA M6X1 THD, OD-19 PEOR 9 (L/GATE APLQ)
03530297 NUT, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (L/GATE CTR MLDG)
25872958 HARNESS, RR LIC PLT LP WRG
01999382 BULB, (RR LIC PLT LP) (ACDelco #W5WLL) (LONGER LIFE)
25778786 LAMP, RR LIC PLT
11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (RR LIC PLT LP LENS)
11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (T/LP)
22865549 LAMP, TAIL (INCLS 18, 19, 22)
teamcadillac.ru
22884388 LAMP, TAIL (INCLS 18, 19, 22)
22884387 LAMP, TAIL (INCLS 18, 19, 22)
22884389 LAMP, TAIL (INCLS 18, 19, 22)
15821754 BULB, B/U LP (PART OF 17) (TRADE 7440) (8.991) (ACDelco #15821754)
15803483 HARNESS, T/LP WRG (PART OF 17)
11610510 NUT, PUSH-IN, M4.2X1.41, 0.7-2.15 PNL THK, SAE 1050-65, GMW3359 W/BLK SEAL (T/LP)
11562160 RETAINER, T/LP (PART OF 17)
(TC02-908) 2007-2013 CK1,2,3 БЛОК ПРЕДОХРАНИТЕЛЕЙ И РЕЛЕ/МОТОРНЫЙ ОТСЕК
25941374 COVER, ENG WRG HARN J/BLK (INCLS 16) (INCLS LABEL)
15328865 RELAY, FAN CONT (PART OF 7) (BLACK) (5-TERM, SPDT 280 MINI, 35AMP) (DAESUNG) (ACDelco #D1724A)
12191645 FUSE, 2A, MINI, GRAY (PART OF 7)
88909753 FUSE, MINI, 10 AMP, RED (PART OF 7)
88909754 FUSE, 15A, MINI, BLUE (PART OF 7) (ACDelco #ATM15-25)
88909756 FUSE, MINI (25 AMP) (CLEAR) (QTY 25 (PART OF 7) (ACDelco #ATM25-25)
12092075 FUSE, 30A, MINI, GREEN (PART OF 7) (ACDelco #12092075)
88861352 FUSE, 20A, MINI, YELLOW (PART OF 7) (ACDelco #ATM20)
15209748 FUSE, 40AMP, LOW PROFILE J CASE, GREEN (PART OF 7)
15822417 FUSE, 30AMP, LOW PROFILE J CASE, PINK (PART OF 7)
19115640 FUSE, 60AMP, LOW PROFILE J CASE, YELLOW (PART OF 7)
11509226 NUT, HEX W/CON WA, M8X1.25, 7.5THK, 19 O.D., 9, ZN (CHAS RR WRG HARN J/BLK LEAD)
22798217 BLOCK, ENG WRG HARN JUNC (INCLS 2-5, 14, 15)
22817835 BRACKET, ENG WRG HARN FUSE BLK
11561674 BOLT, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (ENG WRG HARN FUSE BLK BRKT)
12193606 RELAY, R/WDO DEFG (PART OF 7) (BLUE) (4-TERMINAL) (SPST 280 MINI) (4.720) (ACDelco #12193606)
19116057 RELAY, R/WDO DEFG (PART OF 7) (GRAY) (35AMP) (4-TERMINAL) (HIGH CURRENT MICRO RELAY) (2.483) (ACDelco #D1786C)
teamcadillac.ru
12177236 RELAY, A/C CMPR (PART OF 7) (GRAY) (SPST 280 MINI) (4-WAY) (SQUARE CASE) (W/RESISTOR) (9.778) (ACDelco #D7065C)
12193601 RELAY, A/C CMPR (PART OF 7) (BLACK) (USED W/CONNECTOR 15306045 W/O BRKTS 5-WAY MALE) (ACDelco #15-8719)
19116962 RELAY, A/C CMPR (PART OF 7) (BLACK) (4-TERM, UNSHROUDED) (2.485) (ACDelco #D1777C)
25941375 LABEL, ENG WRG HARN ACSRY RLY & FUSE IDENT (PART OF 1)
(TC02-909) 2007-2013 CK1,2,3 BLOCK- I/P MID JUNCTION
25867232 BRACKET, DA WRG HARN J/BLK
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA WRG HARN J/BLK BRKT)
teamcadillac.ru
11516780 NUT, HEX W/CON WA, M8X1.25, 10THK, 19 O.D., 10, 7111M (PARK BRK CONT MDL) (8.917)
20813086 BLOCK, BODY WRG HARN JUNC (INCLS 6)
20813087 BLOCK, BODY WRG HARN JUNC (INCLS 6)
19116527 BREAKER, CIRC (PART OF 5) (25 AMP MANUAL RESET)
12088575 BREAKER, CIRCUIT, 25AMP, WHITE (PART OF 5) (NON-CYC)
15319848 BREAKER, CIRC (PART OF 5) (50 AMP MAXI TYPE I)
25953821 COVER, DA WRG HARN J/BLK (DESIGN CHANGE:SEE TTV WILL LOOK DIFF BUT WILL WORK DLR TO CALL TAC IF AN INSTALL ISSUE.)
(TC02-910) 2007-2013 CK1,2,3 BLOCK- I/P JUNCTION
20828606 BLOCK, FUSE (INCLS 3, 4)
12191645 FUSE, 2A, MINI, GRAY (PART OF 2)
88909754 FUSE, 15A, MINI, BLUE (PART OF 2) (ACDelco #ATM15-25)
teamcadillac.ru
88909756 FUSE, MINI (25 AMP) (CLEAR) (QTY 25 (PART OF 2) (ACDelco #ATM25-25)
12092075 FUSE, 30A, MINI, GREEN (PART OF 2) (ACDelco #12092075)
12092079 FUSE, 10A, MINI, RED (PART OF 2)
88861352 FUSE, 20A, MINI, YELLOW (PART OF 2) (ACDelco #ATM20)
19116527 BREAKER, CIRC (PART OF 2) (25 AMP MANUAL RESET)
15319848 BREAKER, CIRC (PART OF 2) (50 AMP MAXI TYPE I)
(TC02-911) 2008-2013 CK1,2,3 КРЕПЛЕНИЕ АККУМУЛЯТОРА /PRIMARY (EXC HYBRID HP2)
15195496 SUPPORT, BAT TRAY FRT
11515755 BOLT, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (BAT TRAY SUPT) (T/W 12345493 REPLCS 25534835)
11509853 BOLT, HEX W/CON WA, M8X1.25X45, 24 O.D., HDR PT, 9.8, PS (BAT HOLDN RET)
teamcadillac.ru
14005061 RETAINER, BAT HOLDN (PLASTIC)
11516780 NUT, HEX W/CON WA, M8X1.25, 10THK, 19 O.D., 10, 7111M (BAT TRAY) (8.917)
15872637 TRAY, BODY BAT (PRIMARY)
25601643 NUT, HEX W/CON WA, M6X1X5.6, 24 OD, 9, ZF (BAT TRAY) (8.917)
(TC02-912) 2008-2010 CK1,2,3 КРЕПЛЕНИЕ АККУМУЛЯТОРА /SECONDARY (EXC HYBRID HP2)
11609989 BOLT, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (BAT TRAY)
25826079 TRAY, BAT (SECONDARY)
teamcadillac.ru
11609540 BOLT, HWH, M6X1X20, 16.15 THD, 17 OD, 8.8, GMW4205, HDR PT. (BAT TRAY) (8.977)
15850348 BRACKET, ECM
10399558 SUPPORT, BAT TRAY
11514623 BOLT, HEX W/CON WA, M6X1X20 (BAT TRAY SUPT)
11570097 NUT, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (BAT TRAY)
(TC02-915) 2008-2013 CK1(06) ЖГУТ ПРОВОДОВ/ДВЕРЬ БАГАЖНИКА (CADILLAC Z75)
20954751 HARNESS, L/GATE WRG (INCLS 2)
20954750 HARNESS, L/GATE WRG (INCLS 2)
(TC02-917) 2007-2013 CK1(06-36) ЖГУТ ПРОВОДОВ/ПЕРЕДНИЕ ФАРЫ (CADILLAC Z75)
22808569 HARNESS, FWD LP WRG
22908046 HARNESS, FWD LP WRG
22908045 HARNESS, FWD LP WRG
15930599 LAMP, FRT SI T/SIG (FRT FENDER SIDE) (SEE GROUP 02.000 "LAMPS/FRONT" FOR DETAILED ILLUSTRATED VIEW)
15935384 HARNESS, FRT SI T/SIG LP WRG (DRIVER SIDE)
15938011 HARNESS, FRT SI T/SIG LP WRG (PASS SIDE)
teamcadillac.ru
(TC02-918) 2007-2013 CK1,2(06-36) ЖГУТ ПРОВОДОВ/КРЫША
20787658 HARNESS, RF WRG (INCLS 4)
20787664 HARNESS, RF WRG (INCLS 4)
20873284 HARNESS, RF WRG (INCLS 4)
20900131 HARNESS, RF WRG (INCLS 4)
20900134 HARNESS, RF WRG (INCLS 4)
20950729 HARNESS, RF WRG (INCLS 4)
20950743 HARNESS, RF WRG (INCLS 4)
20873280 HARNESS, RF WRG (INCLS 4) (WALNUT)
20950739 HARNESS, RF WRG (INCLS 4)
teamcadillac.ru
19208818 CABLE, DIGITAL RDO & M/TEL & VEH LOC ANT (USED IN ROOF AND DOOR HARNESSES) (ACDelco #19208818)
(TC02-919) 2008-2013 CK107(06) ЖГУТ ПРОВОДОВ/КУЗОВ (EXC HYBRID HP2)
20927066 HARNESS, BODY WRG (INCLS 5, 8)
20927062 HARNESS, BODY WRG (INCLS 5, 8)
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BODY WRG HARN GND)
21011332 NUT, HEX STAMPED TY DF FLG 14 (BODY WRG HARN BRKT) (8.921)
25952151 COVER, WRG HARN CONN (EBONY)
25952153 COVER, WRG HARN CONN (EBONY)
teamcadillac.ru
11588337 BOLT, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (BODY WRG HARN GND)
(TC02-920) 2008-2013 CK1(06-36) ЖГУТ ПРОВОДОВ/ШАССИ (REAL-TIME DAMPING Z55, MAGNERIDE Z95, EXC HYBRID HP2)
20878208 HARNESS, CHAS WRG (INCLS 2, 3)
teamcadillac.ru
20878209 HARNESS, CHAS WRG (INCLS 2, 3)
20878217 HARNESS, CHAS WRG (INCLS 2, 3)
20878221 HARNESS, CHAS WRG (INCLS 2, 3)
11588337 BOLT, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (CHAS WRG)
12193601 RELAY, AUTO LVL CONT (5-WAY MALE, BLACK, CODE 7233) (BLACK) (USED W/CONNECTOR 15306045 W/O BRKTS 5-WAY MALE) (9.277) (ACDelco #15-8719)
(TC02-924) 2010 CK1(06-36) ЖГУТ ПРОВОДОВ ДВИГАТЕЛЯ (L9H/6.2-2,L94/6.2F)
22745883 HARNESS, ENG WRG
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (ENG WRG HARN RET)
01470030 CLAMP, WORM TYPE (11/16" TO 1 5/16") (ENG WRG HARN CLIP) (ACDelco #1470030)
11589076 BOLT, HEX HD, W/CON WA, M6X1X15, 7.5 THD, 17 O.D., 6202M, GMW3044 (ENG WRG HARN CLIP)
11609832 STUD-HFH, M8X1.25X16, M8X1.25X16, 18 OD, 40.1 TL, 8.8 STL, GMW3200 (ENG WRG HARN CDT)
teamcadillac.ru
11514623 BOLT, HEX W/CON WA, M6X1X20 (ENG WRG HARN BRKT)
11561674 BOLT, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (ENG WRG HARN CLIP)
11561878 RETAINER, PUSH PIN W/SEAL, FITS 8.0-8.25 DIA HOLE IN 3-7MM THK PNL (SECD OXY SEN WRG HARN)
01470030 CLAMP, WORM TYPE (11/16" TO 1 5/16") (OXY SEN WIRE) (ACDelco #1470030)
11609467 NUT, HEX, M5X0.8, 4.55 THK, 5 STL, GMW3200 (ENG WRG HARN START MTR LEAD)
(TC02-929) 2007-2013 CK1(06-36) ЖГУТ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ (CADILLAC Z75)
22847989 CABLE, RDO ANT CBL EXTN RDO END (1021 MM) (ACDelco #22847989)
20930548 HARNESS, I/P WRG (INCLS 5)
teamcadillac.ru
20930551 HARNESS, I/P WRG (INCLS 5)
20930552 HARNESS, I/P WRG (INCLS 5)
20930553 HARNESS, I/P WRG (INCLS 5)
20930561 HARNESS, I/P WRG (INCLS 5)
20930566 HARNESS, I/P WRG (INCLS 5)
20930567 HARNESS, I/P WRG (INCLS 5)
20930568 HARNESS, I/P WRG (INCLS 5)
20930569 HARNESS, I/P WRG (INCLS 5)
20930571 HARNESS, I/P WRG (INCLS 5)
20930572 HARNESS, I/P WRG (INCLS 5)
20930640 HARNESS, I/P WRG (INCLS 5)
20930516 HARNESS, I/P WRG (INCLS 5)
20930517 HARNESS, I/P WRG (INCLS 5)
20930554 HARNESS, I/P WRG (INCLS 5)
20930555 HARNESS, I/P WRG (INCLS 5)
20930550 HARNESS, I/P WRG (INCLS 5)
20930621 HARNESS, I/P WRG (INCLS 5)
20930573 HARNESS, I/P WRG (INCLS 5)
12146933 COVER, I/P WRG HARN DATA LINK CONN
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (I/P WRG HARN DATA LINK CONN) (9.665)
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (I/P WRG HARN GND)
(TC02-930) 2007-2013 CK1,2(06-36) ЖГУТ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ FUSE BLOCK (EXC JF4,PPV,5W4,9L4)
teamcadillac.ru
20970626 HARNESS, FUSE BLK WRG
22797936 HARNESS, FUSE BLK WRG
(TC02-931) 2007-2013 CK1,2(06-36) ЖГУТ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ FUSE BLOCK (POWER ADJUSTABLE PEDAL JF4, EXC PPV,5W4,9L4)
(TC02-940) 2007-2013 CK1,2,3 ЖГУТ ПРОВОДОВ/ACCESSORY POWER SUPPLY (WIRING PROVISIONS 9L4)
25825519 HARNESS, ACSRY PWR FUSE BLK RR WRG HARN EXTN (INCLS 4, 6, 7)
20970628 HARNESS, FUSE BLK WRG
20970630 HARNESS, FUSE BLK WRG
22797941 HARNESS, FUSE BLK WRG
15888241 BRACKET, ACSRY PWR FUSE BLK RR WRG HARN EXTN HARN (PART OF 1)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (ACSRY PWR FUSE BLK RR WRG HARN EXTN HARN BRKT) (9.665)
12092075 FUSE, 30A, MINI, GREEN (PART OF 1) (ACDelco #12092075)
teamcadillac.ru
12177236 RELAY, ACSRY (PART OF 1) (GRAY) (SPST 280 MINI) (4-WAY) (SQUARE CASE) (W/RESISTOR) (9.778) (ACDelco #D7065C)
(TC02-941) 2007-2013 CK107(06) ЖГУТ ПРОВОДОВ/ACCESSORY POWER SUPPLY (POLICE PACKAGE PPV, MUNICIPAL SERVICE 5W4)
25825520 HARNESS, ACSRY PWR FUSE BLK RR WRG HARN EXTN (INCLS 4, 6-8)
teamcadillac.ru
20970631 HARNESS, FUSE BLK WRG
12182117 BREAKER, CIRC (MINI 30AMP NON-CYCLING) (PART OF 1) (2.483)
15319848 BREAKER, CIRC (PART OF 1) (50 AMP MAXI TYPE I)
(TC02-954) 2007-2010 CK1(06) ПРОВОДА АККУМУЛЯТОРА (WIRING PROVISIONS 9L4)
20776808 STRAP, ENG GND (ACDelco #20776808)
22759558 STRAP, ENG GND (ACDelco #22759558)
25825642 CABLE, AUX BAT POS (INCLS 23, 25, 27) (ACDelco #25825642)
25996788 CABLE, GEN BAT JPR (ACDelco #25996788)
21021808 NUT, GEN BAT (M8X1.25X6, BRASS) (2.343)
20774386 CABLE, STRTR SOL (INCLS 18-22) (ACDelco #20774386)
25925265 CLIP, BAT CBL (PART OF 16) (USED FOR HIGH VOLTAGE OUTPUT CABLE)
25925268 CLIP, BAT CBL (PART OF 16) (USED FOR LOW VOLTAGE WIRE HARNESS)
25897052 CABLE, BAT NEG (INCLS 13, 14, 18-20) (ACDelco #25897052)
teamcadillac.ru
19116852 BOLT KIT, BAT CBL TERM (INCLS 19, 20) (PART OF 9, 16)
25888958 COVER, BAT POS CBL TERM (BOTTOM) (PART OF 9)
21021808 NUT, BAT HDL (PART OF 4) (M8X1.25X6, BRASS) (2.343)
15305191 FUSE, 175 AMP MEGA (PART OF 4) ( FUSE COLOR, BLACK W/SIZE STAMPED IN WHITE ON CASE)
19116352 HOLDER, WRG HARN FUSE (PART OF 4) (ACDelco #19116352)
(TC02-962) 2007-2013 CK107(06) ЖГУТ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ FUSE BLOCK (POLICE PACKAGE PPV, MUNICIPAL SERVICE 5W4)
teamcadillac.ru
(TC02-963) 2007-2013 CK1,2,3 ЖГУТ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ FUSE BLOCK (WIRING PROVISIONS 9L4)
teamcadillac.ru
(TC02-964) 2007-2013 K107(06) КЛАКСОН (EXPORT VD1)
teamcadillac.ru
19116451 WIRE, HORN (PART OF 1, 2) (FOR CORRECT HORN PN USE VIN FILTER) (OR REMOVE CONNECTORS) (USE W/12368063-4 KITS & 89046918-9 HORNS. MAY NEED TO SPLICE)
11610199 BOLT, HEX W/CON WA, M6X1X30, 21 THD, 17 OD, 8.8, GMW3359 (HORN)
25866835 HORN, 400 & 500 HZ (INCLS 1, 2) (ACDelco #D1970F)
(TC02-982) 2009-2013 CK1 МОДУЛЬ УПРАВЛЕНИЯ ГИБРИДНОЙ УСТАНОВКОЙ И КРЕПЛЕНИЯ (HYBRID HP2)
25916397 SHIELD, DRV MOT GEN CONT MDL SIGHT (INCLS 2, 32-37)
12606862 GROMMET, BECM CVR (PART OF 1) (32MM OD) (3.265)
11609319 STUD, FUSE BLK SHLD (M6X1X20.65) (3.671)
24243399 COVER, DRV MOT PWR INV MDL 3 PHASE CBL (INCLS 5)
24238760 LABEL, HIGH VOLTAGE WRNG (PART OF 4)
11900241 BOLT, P/S CONT MDL (M6X1.0X12) (3.602)
25940453 TRAY, ACSRY DC PWR CONT MDL
25962338 MODULE, ELEK P/S MOT CONT (INCLS 10)
25813638 LABEL, P/S FLUID VOLTAGE CAUTION (PART OF 9) (TWO-MODE HYBRID)
teamcadillac.ru
11516780 NUT, HEX W/CON WA, M8X1.25, 10THK, 19 O.D., 10, 7111M (ACSRY DC PWR CONT MDL BRKT) (8.917)
11516075 NUT, HFH SELF LK, M6X1, 7.7THK, 14.2 O.D., 9, PZOR (ACSRY DC PWR CONT MDL TRAY BRKT (TO FENDER))
15254539 BRACKET, ACSRY DC PWR CONT MDL TRAY
11514519 NUT, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (ACSRY DC PWR CONT MDL TRAY)
15897199 BRACKET, ACSRY DC PWR CONT MDL TRAY (TO FENDER) (ATTACH MODULE TRAY TO FENDER)
11611064 WASHER, ACSRY DC PWR CONT MDL TRAY BRKT (TO FENDER) (8.929)
11518721 NUT, HEX, W/FL WA, M6X1, 5.55 THK, 28 O.D., 9, GM6138M (ACSRY DC PWR CONT MDL TRAY BRKT (TO FENDER))
11609982 BOLT, HEX W/FL WA, M6X1X22, 14.55 THD, 24 OD, 8.8, GMW3359, M-PT. (ACSRY DC PWR CONT MDL TRAY)
15890021 RETAINER, ACSRY DC PWR CONT MDL TRAY
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (ACSRY DC PWR CONT MDL TRAY RET)
24242659 STUD, GEN POSN SEN GND
12636016 MODULE, DRV MOT GEN PWR INV (SEE GROUP 02.000 "CONTROL MODULE ASM/DRIVE MOTOR" FOR DETAILED ILLUSTRATED VIEW)
11588564 BOLT, HEX W/FL WA, M8X1.25X25, 15.85 THD, 17 OD, 9.8, GMW3200M, MACH, MAT-PT (GEN CONT MDL)
25853131 STRAP, GEN CONT MDL GND
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (GEN CONT MDL)
11513699 SCREW, PAN HD, TORX, M6X1X18, 12 O.D., HD PT, 9.8, PE (FUSE BLK CVR)
24241226 SEAL, DRV MOT PWR INV MDL CVR (PART OF 1)
25916400 BLOCK, P/W WRG HARN JUNC (PART OF 1) (HIGH VOLTAGE INTERLOCK) (2.483)
20883260 LABEL, HIGH VOLTAGE WRNG (PART OF 1) (REGULAR ADHESIVE LABEL FOR HIGH VOLTAGE COMPONENTS)
25823544 SEAL, DRV MOT PWR INV MDL (O RING) (PART OF 1)
11569940 BOLT, DRV MOT GEN PWR INV MDL CVR (PART OF 1) (M6X1X45)
25993617 SENSOR, HIGH VOLTAGE CIRC IMP DETECTION (INCLS 38)
(TC02-983) 2008-2011 CK107(06) MODULE/ACCESSORY AC & DC POWER CONTROL(KV1)
25858121 RECEPTACLE, ACSRY PWR (110 VOLT) (ACSRY PWR RECEPTACLE ASSEM LABELED 25858121)
25774623 RECEPTACLE, ACSRY PWR (EBONY) (W/O COVER) (ACSRY PWR RECEPTACLE ASSEM LABELED 25774623) (12V)
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (TIRE INFLR STRP)
03530297 NUT, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (ACSRY AC & DC PWR CONT MDL)
89047499 BOLT, ACSRY AC & DC PWR CONT MDL
15800723 BRACKET, ACSRY AC & DC PWR CONT MDL
teamcadillac.ru
10361107 MODULE, ACSRY AC & DC PWR CONT (ACDelco #10361107)
(TC02-986) 2009-2013 CK1 BLOCK/ACCESSORY WIRING JUNCTION (HYBRID HP2)
25960204 LABEL, BAT INFO (PART OF 2) (*KIT1)
25801752 COVER, ENG WRG HARN J/BLK (INCLS 1, 3) (*KIT1)
25859530 LABEL, FUSE BLK (PART OF 2) (*KIT1) (8.808)
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (AUX BAT POS CBL)
88909753 FUSE, MINI, 10 AMP, RED (PART OF 16)
teamcadillac.ru
88909754 FUSE, 15A, MINI, BLUE (PART OF 16) (ACDelco #ATM15-25)
88909756 FUSE, MINI (25 AMP) (CLEAR) (QTY 25 (PART OF 16) (ACDelco #ATM25-25)
11609989 BOLT, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (ENG WRG HARN FUSE BLK BRKT)
11610199 BOLT, HEX W/CON WA, M6X1X30, 21 THD, 17 OD, 8.8, GMW3359 (ENG WRG HARN FUSE BLK BRKT)
11570097 NUT, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (SEE GROUP 03.000 "E.C.M. MODULE & WIRING HARNESS" FOR DETAILED ILLUSTRATED VIEW)
12177236 RELAY, FAN CONT (UNDERHOOD BEC) (PART OF 16) (GRAY) (SPST 280 MINI) (4-WAY) (SQUARE CASE) (W/RESISTOR) (9.778) (ACDelco #D7065C)
12193606 RELAY, FAN CONT (PART OF 16) (BLUE) (4-TERMINAL) (SPST 280 MINI) (4.720) (ACDelco #12193606)
19116057 RELAY, FAN CONT (PART OF 16) (GRAY) (35AMP) (4-TERMINAL) (HIGH CURRENT MICRO RELAY) (2.483) (ACDelco #D1786C)
15328865 RELAY, FAN CONT (PART OF 16) (BLACK) (5-TERM, SPDT 280 MINI, 35AMP) (DAESUNG) (ACDelco #D1724A)
25960205 COVER, ACSRY WRG J/BLK (INCLS 1-3)
(TC02-987) 2008-2013 CK107(06) КРЕПЛЕНИЕ АККУМУЛЯТОРА /PRIMARY (HYBRID HP2)
teamcadillac.ru
(TC02-988) 2008-2013 CK107(06) КРЕПЛЕНИЕ АККУМУЛЯТОРА ГИБРИДНОЙ УСТАНОВКИ (HYBRID HP2)
25905443 COVER, BAT NEG CBL TERM (HIGH VOLTAGE TERMINAL COVER LABELED 5443)
11561674 BOLT, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (BAT NEG CBL TERM)
15293650 LEVER, DRV MOT BAT HIGH VOLTAGE MAN DISCONNECT (INCLS 5)
11569660 BOLT-HEX W/CON WA, M8X1.25X40, 27 THD, 28 OD, GM6202M, GMW3200, TAPPIN (DRV MOT BAT TRAY)
03537772 NUT, M12X1.75, 10.6THK, 28 O.D., 10, 7111M (R/SEAT) (8.917)
03530297 NUT, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (DRV MOT BAT PWR CONT MDL HARN CONN)
25961362 INSULATOR, BAT
15293030 DUCT, BAT CLG AIR OTLT
11589290 RETAINER, PUSH-IN, FITS 6.5 HOLE, 4.5 -7.0 THK PNL, NYLON 6/6 GMP.PA66.0 (BAT CLG AIR OTLT DUCT)
teamcadillac.ru
11609558 NUT-HEX W/CON WA, M8X1.25X7.5, 24 OD, 9 STL, GMW3200 SN-ZN (DRV MOT BAT TRAY)
(TC02-989) 2008-2013 CK107(06) АККУМУЛЯТОР ГИБРИДНОЙ УСТАНОВКИ PART 1 (HYBRID HP2)
25926174 COVER, DRV MOT BAT (SEE GROUP 02.000 "BATTERY/DRIVE MOTOR PART 2" FOR DETAILED ILLUSTRATED VIEW) (REAR) (*KIT2)
20839874 HARNESS KIT, DRV MOT BAT CONT MDL (*KIT2)
25925265 CLIP, BAT CBL (USED FOR HIGH VOLTAGE OUTPUT CABLE) (*KIT2)
teamcadillac.ru
25925268 CLIP, BAT CBL (USED FOR LOW VOLTAGE WIRE HARNESS) (*KIT2)
19116354 CLIP, BAT CBL (*KIT2)
25870508 HARNESS, DRV MOT BAT SEN MDL WRG (*KIT2)
25926169 RETAINER, BAT VENT HOSE (*KIT2)
20839876 TUBE, BAT VENT (DRAIN HOSE ASM) (*KIT2) (ACDelco #20839876)
25925266 TUBE, BAT VENT (TUBE ASM, BAT. NO. 1) (*KIT2) (ACDelco #25925266)
25925260 TUBE, BAT VENT (BAT NO. 2) (*KIT2) (ACDelco #25925260)
25925262 TUBE, BAT VENT (HOSE, TUBE CONNECT) (*KIT2)
25926167 CLIP, DRV MOT BAT TEMP SEN (*KIT2)
25925287 DUCT, DRV MOT GEN BAT CLG OTLT (INCLS 17) (*KIT2) (2.335)
25926177 INSULATOR, DRV MOT BAT VENT FAN (*KIT2)
25870518 FAN, GEN BAT VENT (*KIT2)
25925258 DUCT, DRV MOT BAT CLG BLO OTLT (*KIT2) (2.335)
25870510 RELAY, GEN BAT VENT FAN (*KIT2)
19180442 BATTERY KIT, DRV MOT (INCLS COMPLETE BATTERY ASM, NEG TERM CVR & 4 SCREWS) (INCLS 1-25)
(TC02-990) 2008-2013 CK107(06) АККУМУЛЯТОР ГИБРИДНОЙ УСТАНОВКИ PART 2 (HYBRID HP2)
25926174 COVER, DRV MOT BAT (REAR) (*KIT2)
25960202 LABEL, HIGH VOLTAGE CONN CAUTION (*KIT2)
25870512 SENSOR, DRV MOT BAT CUR (*KIT2)
25926168 BRACKET, DRV MOT GEN BAT (*KIT2) (2.215)
25870516 MODULE, BAT ENGY CONT (*KIT2) (2.212)
teamcadillac.ru
25870514 RESISTOR, DRV MOT BAT INV CUR LIM (*KIT2)
25870515 RELAY, DRV MOT BAT POS HIGH VOLTAGE CONTACTOR (*KIT2)
25871271 RELAY, DRV MOT PWR INV CUR LIM (*KIT2)
25926175 COVER, DRV MOT BAT (RIGHT SIDE) (*KIT2)
15906948 LABEL, BAT WRNG (LOCATED ON BATTERY) (*KIT2)
11561674 BOLT, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (BAT NEG CBL TERM) (*KIT1, KIT2)
25905443 COVER, BAT NEG CBL TERM (HIGH VOLTAGE TERMINAL COVER LABELED 5443) (*KIT1, KIT2)
25925282 HOUSING, DRV MOT BAT HIGH VOLTAGE MAN DISCONNECT KNOB (*KIT1, KIT2)
15293650 LEVER, DRV MOT BAT HIGH VOLTAGE MAN DISCONNECT (INCLS 43) (PART OF 46) (*KIT2)
20824868 HOUSING KIT, DRV MOT BAT HIGH VOLTAGE MAN DISCONNECT KNOB (INCLS 42-44, 47, 48) (*KIT1, KIT2)
25926173 COVER, DRV MOT BAT (FRT) (*KIT2)
25870515 RELAY, DRV MOT BAT NEG HIGH VOLTAGE CONTACTOR (*KIT2)
19180442 BATTERY KIT, DRV MOT (INCLS COMPLETE BATTERY ASM, NEG TERM CVR & 4 SCREWS) (INCLS 74)
(TC02-992) 2008-2013 CK107(06) DRIVE MOTOR ПРОВОДА АККУМУЛЯТОРА-300 VOLT (HYBRID HP2)
25880095 CABLE, GEN BAT POS & NEG (INCLS 9) (*KIT1) (2.342) (ACDelco #25880095)
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BAT POS & NEG CBL CLIP)
teamcadillac.ru
25880097 CHANNEL, DRV MOT BAT POS & NEG CBL (FRONT PLASTIC AT ELBOW) (*KIT1)
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DRV MOT BAT POS & NEG CBL CHAN)
25880098 CHANNEL, DRV MOT BAT POS & NEG CBL ( (3) PIECE PLASTIC CENTER & REAR) (*KIT1)
25880096 GROMMET, DRV MOT BAT POS & NEG CBL (*KIT1)
11562426 BOLT, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (PART OF 1)
11561918 BOLT, HEX W/CON WA, M6X1X18, 10 THD, 14 OD, 8.8, GMW3359, MAT-PT, (BAT POS & NEG (300 V) CBL)
25923890 CABLE, BAT POS & NEG (300 V) (INCLS 1, 3, 5, 6, 7)
(TC02-994) 2008-2013 CK107(06) ЖГУТ ПРОВОДОВ/КУЗОВ (HYBRID HP2)
20926931 HARNESS, BODY WRG (INCLS 3, 6)
teamcadillac.ru
(TC02-996) 2009-2013 CK1 DRIVE MOTOR CONTROL MODULE (HYBRID HP2)
24241225 COVER, DRV MOT PWR INV MDL
24241226 SEAL, DRV MOT PWR INV MDL CVR (*KIT1)
24241224 SEAL, DRV MOT GEN PWR INV MDL CBL HSG CVR (*KIT1)
teamcadillac.ru
24241227 SEAL, DRV MOT CONT MDL (*KIT1)
24251562 MODULE, ACSRY DC PWR CONT (USE T/W SEAL KIT 19168315)
11561918 BOLT, HEX W/CON WA, M6X1X18, 10 THD, 14 OD, 8.8, GMW3359, MAT-PT, (ACSRY AC & DC PWR CONT MDL TERM)
24241223 PIPE, DRV MOT GEN PWR INV MDL COOL INL
11562426 BOLT, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (DRV MOT GEN PWR INV MDL COOL INL PIPE)
11900243 BOLT, HFH, M6X1X23, 17 THD, 14.2 O.D., 8.8, GMW3359, M-POINT, (DRV MOT GEN PWR INV MDL COOL OTL PIPE)
24241219 PIPE, DRV MOT GEN PWR INV MDL COOL OTL
24240088 SEAL, DRV MOT GEN PWR INV MDL COOL OTL PIPE (*KIT1)
24240087 BOLT, DRV MOT GEN PWR INV MDL CVR (M5X13X10.9)
19168315 SEAL KIT, DRV MOT GEN PWR INV MDL (INCLS 2, 3, 5, 13)
(TC02-999) 2009-2013 CK1 ПРОВОДА ГЕНЕРАТОРА-3 PHASE (HYBRID HP2)
teamcadillac.ru
24243399 COVER, DRV MOT PWR INV MDL 3 PHASE CBL (INCLS 4)
24243398 BOLT, DRV MOT GEN PWR INV MDL CBL CVR (PART OF 3)
12636016 MODULE, DRV MOT GEN PWR INV (SEE GROUP 02.000 "DRIVE MOTOR CONTROL MODULE" FOR DETAILED ILLUSTRATED VIEW)
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DRV MOT GEN POWR INV MDL CBL BRKT)
24246179 INSULATOR, DRV MOT PWR INV MDL CBL TERM EXT (PART OF 8)
24246180 BRACKET, DRV MOT PWR INV MDL 3 PHASE CBL (INCLS 7)
11516327 BOLT, HFH, M10X1.5X25, 22.30 O.D., HDR PT, 10.9, 7112M (DRV MOT GEN POWR INV MDL CBL BRKT)
11588711 BOLT, HFH, M6X1X16, 10 THD, 14.2 OD, 8.8 STL, GMW3359 (DRV MOT PWR INV MDL 3 PHASE CABLE)
(TS02-215) 2010-2011 CK1 КРЕПЛЕНИЕ СТАРТЕРА (L20/4.8A,LMG/5.3-0,LC9/5.3-3,L94/6.2F)
12588400 SHIELD, STRTR HT (SNAP-ON SHIELD)
teamcadillac.ru
19180528 STARTER, (MATING CONN W/LEADS USE 88988118) (REMANUFACTURED-NOT FOR SALE WHERE IMPORTS ARE RESTRICTED) (ACDelco #323-1661)
11610787 BOLT, STRTR (M10X1.5X120) (ACDelco #11610787)
03 - ТОПЛИВНАЯ СИСТЕМА-ВЫХЛОП-СИСТЕМА КОНТРОЛЯ ТОКСИЧНОСТИ ВЫХЛОПНЫХ ГАЗОВ
(GM03-197) 2010-2012 CK ДРОССЕЛЬНАЯ ЗАСЛОНКА (L94/6.2F,L9H/6.2-2)
12629992 BODY, THROT (W/THROT ACTR) (INCLS 2, 3) (ACDelco #217-3151)
teamcadillac.ru
19259452 SENSOR KIT, THROT POSN (PART OF 1) (INCLS 3)
12650247 CLIP, CVR THROT POSN SNSR (PART OF 1, 2)
(TC03-155) 2010 CK1(06-36) БЛОК РЕГУЛИРОВАНИЯ РАСХОДА ТОПЛИВА (LMG/5.3-0,LC9/5.3-3,LZ1/6.0J,L9H/6.2-2,L94/6.2F)
20898936 MODULE, F/PMP FLOW CONT (ACDelco #20898936)
20877116 MODULE, F/PMP FLOW CONT (ACDelco #20877116) (LABELED 20877116)
teamcadillac.ru
01605396 RETAINER, PUSH-IN, FITS .250 HOLE, .92 LG.700-OD NYLON BLACK (PART OF 4)
25943798 SHIELD, F/PMP FLOW CONT MDL (INCLS 3)
11562584 BOLT, F/PMP FLOW CONT MDL (M6X1X27) (3.887)
(TC03-242) 2010-2011 CK1 СИСТЕМА ПОДАЧИ ВОЗДУХА (L20/4.8A,LMG/5.3-0,LC9/5.3-3,L9H/6.2-2,L94/6.2F)
teamcadillac.ru
22844819 CLEANER, AIR (INCLS 13, 16-19)
11570290 BOLT, MASS AIRFLOW SEN
10393948 SENSOR, MASS AIRFLOW (W/INT AIR TEMP SEN) (INCLS 20) (ACDelco #213-4343)
15901934 DUCT, A/CL OTLT (INCLS 4, 6, 7)
25346092 INSULATOR, A/CL HSG (PART OF 5) (3.270)
20808321 SUPPORT, A/CL
20759226 SUPPORT, A/CL
11516424 BOLT, HFH, M6X1X25, 14.2 O.D., HDR PT, 9.8, ZE (A/CL ADAP SUPT)
11570097 NUT, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (BAT TRAY REINF)
22739021 BRACKET, A/CL ADAP (INCLS THREE GROMMETS) (INCLS 15)
11514623 BOLT, HEX W/CON WA, M6X1X20 (A/CL ADAP)
25316546 FASTENER, A/CL (PART OF 1)
11516589 SCREW, HEX HD W/CON SPR WA, M6X1X30, 29 THD, 17 O.D., 9.8, 7114M, ZE (A/CL ADAP)
25346092 INSULATOR, A/CL BRKT (PART OF 11) (3.270)
15908916 ELEMENT, A/CL (PART OF 1) (ACDelco #A3086C)
11561933 BOLT, A/CL HSG CVR (PART OF 1) (M6X2.7X36)
11562129 BOLT, A/CL OTLT DUCT
(TC03-413) 2010-2013 CK107(06) ТОПЛИВОИСПАРИТЕЛЬНЫЙ БАК И СВЯЗАННЫЕ ДЕТАЛИ (HYBRID HP2)
teamcadillac.ru
15109431 CANISTER, EVAP EMIS (ACDelco #215-464)
10200334 BOLT, EVAP EMIS CNSTR BRKT (M8X1.25X30) (W/FLAT WASHER) (12.243)
22696898 CONNECTOR, EVAP EMIS HOSE
20995472 VENT, EVAP EMIS CNSTR (INCLS 4, 6, 8-11) (ORDER T/W PUSH-PIN 10121502) (ACDelco #20995472) (USE T/W 19257603 PACKARD TO USCAR CONNECTOR JUMPER HARNESS)
11516885 SCREW, HFH W/FL WA, TAP, M8X1.25X20, 7THD, 17 O.D., TR PT, 6202M, PZOR (EVAP EMIS CNSTR VENT SOL VLV BRKT)
11516594 BOLT, HEX, M8X1.25X30, 22THD, 24MM O.D., 9.8, 7114M (EVAP EMIS CNSTR)
(TC03-903) 2010-2011 CK1 E.C.M. МОДУЛЬ И ЖГУТ ПРОВОДОВ (L20/4.8A,LMG/5.3-0,LC9/5.3-3,L9H/6.2-2,L94/6.2F)
11609989 BOLT, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (FRT A/DFL)
11518121 NUT, U, M6X1, MULTI THD, .5'-4.0' THK PNL (PART OF 4)
15850348 BRACKET, ECM (INCLS 3)
teamcadillac.ru
12633238 MODULE, ENG CONT (W/ 2ND MPU) & (W/O CALN) (8.10.X SOFTWARE LEVEL) (E38 NO-START) (ACDelco #12633238)
11517518 BOLT, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (ECM BRKT) (ACDelco #11517518)
(TC03-907) 2010-2013 CK107(06) СИСТЕМА ПОДАЧИ ТОПЛИВА-REAR (L94/6.2F)
25914594 HOSE, EVAP EMIS CNSTR PURGE (INCLS 2, 6)
12522917 CONNECTOR KIT, FUEL FEED PIPE (PART OF 1, 3) (GREEN) (INCLS INST SHT & RET) (USE WITH 3/8 TUBE, NYLON) (3.162)
24100438 HOSE, FUEL FEED (INCLS 2) (TO TANK)
12522917 CONNECTOR KIT, FUEL FEED PIPE (PART OF 6) (GREEN) (INCLS INST SHT & RET) (USE WITH 3/8 TUBE, NYLON) (3.162)
teamcadillac.ru
(TC03-912) 2010-2013 CK107(06) ТОПЛИВОИСПАРИТЕЛЬНЫЙ БАК И СВЯЗАННЫЕ ДЕТАЛИ (EXC HYBRID HP2)
15113366 BRACKET, EVAP EMIS CNSTR
11570082 BOLT, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (EVAP EMIS CNSTR) (ACDelco #11570082)
21992746 RETAINER, FUEL FEED HOSE CONN (PART OF 11) (5/8 INCH QUICK CONNECT RETAINER CLIP)
20995472 VENT, EVAP EMIS CNSTR (INCLS 5-7, 9) (ORDER T/W PUSH-PIN 10121502) (ACDelco #20995472) (USE T/W 19257603 PACKARD TO USCAR CONNECTOR JUMPER HARNESS)
(TC03-917) 2010 CK1(06-36) ВЫПУСКНАЯ СИСТЕМА-V8 (L9H/6.2-2,L94/6.2F)
20854457 CONVERTER, 3WAY CTLTC (W/EXH MANIF PIPE) (3.685)
20854458 CONVERTER, 3WAY CTLTC (W/EXH MANIF PIPE)
15709703 NUT, HEX 10X1.5THD, 21.8 OD SS (EXH MANIF PIPE)
11589264 STUD, STRAIGHT, M10X1.5X30, M10X1.5X16, 57 TL, SS (EXH MANIF PIPE)
15077362 SEAL, EXH MANIF PIPE
teamcadillac.ru
15035747 SEAL, EXH MANIF PIPE
12583804 SENSOR, HTD OXY (POSN 2) (MALE END) (TAKES FEMALE CONNECTOR) (ACDelco #213-3866)
12609457 SENSOR, HTD OXY (POSN 3) (MATING CONN W/LEADS USE 15306319) (ACDelco #213-4229)
15709703 NUT, HEX 10X1.5THD, 21.8 OD SS (EXH MUFF)
15028620 STUD, EXH PIPE (PART OF 12) (M10X1.5X30MM) (BUTTON HEAD)
20757529 MUFFLER, EXH (W/RESO, EXH & TAIL PIPE) (INCLS 11)
15092802 INSULATOR, EXH MUFF HNGR
(TC03-918) 2007-2013 CK1(06-36) ТОПЛИВНЫЙ БАК
10325852 CAM, FUEL SDR (130 MM OPENING CAM LOCK RING) (3.115) (ACDelco #TR26)
13502903 SENSOR, F/TNK PRESS (PART OF 4) (ACDelco #13502903) (ORDER T/W SENSOR COVER PN 20893611)
19257104 SENSOR KIT, FUEL LVL (ACDelco #SK1356)
19259393 MODULE KIT, F/TNK F/PMP (W/O FUEL LVL SEN) (INCLS 2, 5) (ACDelco #M100062)
22682111 SEAL, F/PMP (O RING) (PART OF 4) (APPROX SIZE:147.5MM X 6MM) (ACDelco #G41)
20984565 TANK, FUEL
15078884 SHIELD, F/TNK RR
10009923 NUT, BOLT RETAINING SPRING, M8X1.25, 25 O.D., ZOR (F/TNK SHLD)
15168952 RETAINER, F/TNK H/SHLD
15836686 SHIELD, F/TNK HT (SMALL SHIELD)
(TC03-919) 2007-2013 CK1(06-36) КРЕПЛЕНИЕ ТОПЛИВНОГО БАКА
11517806 NUT, U-TYPE, M10X1.5, 30.5X28.6, 15.5 C/E, 2-5 PNL, 1050, 7111M (F/TNK STRP)
teamcadillac.ru
22868153 STRAP, F/TNK (REAR)
22868152 STRAP, F/TNK (FRONT)
11519894 BOLT, HEX W/CON WA, M10X1.5X55, 42.3 THD, 20 OD, 10.9, 7114M, MACH, MAT-PT (F/TNK STRP)
(TC03-920) 2007-2013 CK1,2(06-36) УПРАВЛЕНИЕ АКСЕЛЕРАТОРОМ (EXC POWER ADJUSTABLE PEDAL JF4)
25863989 BRACKET, BRK & ACCEL PED (LWR PLNM PNL)
11517182 BOLT, BRK PED BRKT (M10X1.5X30, 15 THD) (8.900)
11517996 NUT, P/B BOOS (M10X1.5, 11.2THK) (21.5 OD) (8.917) (ACDelco #11517996)
15268739 BRACKET, ACCEL PED
teamcadillac.ru
25832864 PEDAL, ACCEL (INCLS POSITION SENSOR) (MATING CONN W/LEADS USE 13584094)
11516424 BOLT, HFH, M6X1X25, 14.2 O.D., HDR PT, 9.8, ZE (ACCEL PED LVR)
15685170 NUT, HEX HD W/FL WA, M6X1, 5.5 THK, 9, 7111M, 2MM THK 19 OD WA, NYLOC (ACCEL PED LVR) (8.917)
(TC03-990) 2010 CK1(06-36) СИСТЕМА ПОДАЧИ ТОПЛИВА-FRONT (LMG/5.3-0,LC9/5.3-3,L9H/6.2-2,L94/6.2F)
22695614 RETAINER, FUEL FEED HOSE CONN (13 X 19 X 36MM) (ONE TUBE)
15946243 HOSE, FUEL FEED (INCLS 14) (*KIT1)
15946264 HOSE, EVAP EMIS (INCLS 15) (*KIT1)
15085402 BRACKET, FUEL FEED & EVAP EMIS & RTN HOSE (*KIT1)
11514596 NUT, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (FUEL FEED & RTN FRT HOSE BRKT) (8.915) (ACDelco #11514596)
15168648 CLIP, FUEL FEED & EVAP EMIS & RTN HOSE (W/RETAINER) (*KIT1)
15085405 CLIP, FUEL FEED & EVAP EMIS & RTN HOSE (CLIP - 1.36" LENGTH, MAT'L NYLON BLACK) (*KIT1)
15085404 CLIP, FUEL FEED & EVAP EMIS & RTN HOSE (AT HOSE/PIPE CONNECTION) (*KIT1)
teamcadillac.ru
15126012 BRACKET, FUEL FEED & EVAP EMIS & RTN PIPE CLIP (*KIT1)
11570082 BOLT, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (FUEL FEED & EVAP EMIS & RTN PIPE CLIP BRKT) (ACDelco #11570082)
15168649 CLIP, FUEL FEED & EVAP EMIS & RTN HOSE (ANTI-RATTLE) (*KIT1)
15168646 CLIP, FUEL FEED & EVAP EMIS & RTN HOSE (PART OF 3) (2 TUBE) (FUEL LINE) (*KIT1)
15778699 SEAL, FUEL PRESS SEN (O RING) (*KIT1) (ACDelco #15778699)
13500745 SENSOR, FUEL PRESS (PART OF FUEL LINE) (*KIT1) (3.682) (ACDelco #13500745)
11516703 BOLT, HEX, M4.8X1.6X13, 20 OD, 6010M MAT, 6047M FIN (FUEL FEED & RTN FRT HOSE BRKT) (8.977)
15124945 BRACKET, FUEL FEED & RTN FRT HOSE
11561674 BOLT, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (FUEL FEED & RTN FRT HOSE BRKT)
11514597 NUT, HFH, 10X1.5 THD, 9.8 THK, 21.8 OD, 510M (10) ZF 7111M (TRFER CASE) (2.383)
15033698 BRACKET, FUEL FEED & RTN PIPE
20916673 HOSE, FUEL FEED & EVAP EMIS & RTN (INCLS 3-5, 7-11, 13-17)
(TC04-106) 2010-2011 CK1,2,3 УПРАВЛЕНИЕ АКСЕЛЕРАТОРОМ (POWER ADJUSTABLE PEDAL JF4, AN3)
25863989 BRACKET, BRK & ACCEL PED (INCLS 5, 7) (LWR PLNM PNL)
15000145 BOLT, BRK PED PIV (12X1.75X120, 25)
11514598 NUT, BRK PED PIV (M12X1.75X12, 26 OD) (8.915)
11562023 BOLT, ELEK THROT ACTR (PAN HEAD, M6X1X40, 15 THD, 12 OD, 10.9 STL, GM4277, HDR PT) (PART OF 12)
15123616 ACTUATOR PKG, THROT (PART OF 12)
25863992 BRACKET KIT, ACCEL PED (IF BLUE MARK ON ADJUSTABLE PEDAL MOTOR AND/OR ACCELERATOR PEDAL BRACKET MUST ORDER T/W BRAKE PEDAL ASM) (INCLS 9-11, 13)
11505213 NUT, PUSH ON, M8, 1.96THK, 16.03 O.D., STL, PC (PART OF 12)
25981009 SWITCH, S/LP (ACDelco #D1539J)
teamcadillac.ru
11569844 RETAINER, BRK PED PUSH ROD (WITH BOLT)
15200851 BUSHING, BRK PED PIV (PART OF 22)
25968689 PEDAL, BRK (INCLS 8, 21, 23-27) (IF BLUE MARK ON MOT &/OR ACCEL PED BRKT MUST ORDER T/W ACCEL PED BRKT KIT 25863992)
11516424 BOLT, HFH, M6X1X25, 14.2 O.D., HDR PT, 9.8, ZE (PART OF 22)
25799118 SENSOR KIT, BRK PED POSN (PART OF 22) (ACDelco #25799118)
88982976 PAD, BRK PED (PART OF 22)
(TX03-052) 2010 CK1,2,3 МАГИСТРАЛЬ ТОПЛИВНОЙ ФОРСУНКИ (L20/4.8A,LMG/5.3-0,LC9/5.3-3,L96/6.0G,LY6/6.0K,L9H/6.2-2,L94/6.2F)
12621663 RAIL, SEQ M/PORT F/INJN FUEL (INCLS 2, 3)
25532662 CAP, FUEL PRESS SERV VLV (PART OF 1) (CAP FOR PRESSURE TEST SCHRADER VALVE) (3.163) (ACDelco #214-1044)
89017372 RETAINER KIT, F/INJR (PART OF 6) (ACDelco #89017372)
teamcadillac.ru
12609749 INJECTOR, SEQ M/PORT FUEL (INCLS RETAINER, SEALS) (INCLS 4, 5, 7) (ACDelco #217-3410)
19209297 SEAL KIT, M/PORT F/INJR (INCLS 5, 7) (ACDelco #217-3361)
(GM04-555) 2007-2013 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) CONTROL VALVE ASSEMBLY
24227130 BOLT, C/VLV UPR BODY (M5X0.8X36)
24225398 BOLT, A/TRNS INPUT & OUTPUT SPD SEN (M6 X 1.0 X 20)
24265535 SENSOR, A/TRNS INPUT & OUTPUT SPD (INCLS 316) (KIT/NON-UNIGEAR) (4.329) (ACDelco #24265535)
24240961 BODY, C/VLV UPR (ACDelco #24240961)
24261077 PLATE, C/VLV BODY SPCR (W/GSKT) (ACDelco #24261077)
96020431 VALVE, C/VLV BODY BALL CHK (ACDelco #96020431)
24251431 BODY, C/VLV LWR (SEE GROUP 04.000 "AUTOMATIC TRANSMISSION/LOWER CONTROL VALVE BODY" FOR DETAILED ILLUSTRATED VIEW) (W/O MANUAL VALVE) (ACDelco #24251431)
24242938 SWITCH, A/TRNS MAN SHFT SHF POSN (INCLS 315) (INTERNAL MODE SWITCH) (ACDelco #24242938)
24240848 BOLT, C/VLV LWR BODY (MX50.8X45.0)
24224822 BOLT, C/VLV LWR BODY (M5X0.8X55)
teamcadillac.ru
24236934 PLATE KIT, CONT SOL VLV FLTR (ACDelco #24236934)
24240845 BOLT, CONT SOL VLV HEAT SINK (W/ BODY & TCM) (M5X0.8X53.0) (ACDelco #24240845)
24258304 VALVE, CONT SOL (W/ BODY & TCM) (MUST ALSO ORDER EITHER A BODY KIT-C/VLV, OR A SEAL KIT-A/TRNS SERV, DEPENDING ON REPAIR.) (ELECTRONIC TRANS CONTROLLER ASM W/SOLENOIDS & TCM (NOT A CONTROL VALVE BODY ASM WITH VALVE BODY, VALVES, AND SPRINGS))
24236233 CLIP, A/TRNS MAN SHFT SHF POSN SW WRG HARN (PART OF 308)
24236504 CLIP, A/TRNS INPUT & OUTPUT SPD SEN WRG HARN (PART OF 303) (SILVER) (NON-UNIGEAR)
(GM04-556) 2007-2013 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) UPPER CONTROL VALVE BODY ASSEMBLY
24224766 PIN, C/VLV BODY LOC (DIA.=10MM L=12.7) (ACDelco #24224766)
24240961 BODY, C/VLV UPR (INCLS 324-327, 329-338) (ACDelco #24240961)
24230200 PIN, C/VLV BODY LOC (DIA.=10MM L=29.9) (ACDelco #24230200)
24224755 RETAINER, 1-2-3-4 CLU BOOST VLV SPR
teamcadillac.ru
24242814 PLUG, 1-2-3-4 CLU REG VLV BORE (9.5 THK, 11.5 DIA) (ACDelco #24242814)
09427692 PLUG, CLU PSTN EXH BLOWOFF BALL VLV (PART OF 321) (.573 O.D.) (ACDelco #9427692)
(GM04-557) 2007-2013 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) LOWER CONTROL VALVE BODY ASSEMBLY
24224755 RETAINER, CLU PSTN DAM FEED REG VLV SPR
24242814 PLUG, TCC REG APPL VLV BORE (9.5 THK, 11.5 DIA) (ACDelco #24242814)
24251431 BODY, C/VLV LWR (INCLS 338, 352, 353, 355-357) (W/O MANUAL VALVE) (ACDelco #24251431)
24224770 VALVE, MAN (ACDelco #24224770)
(GM04-559) 2007-2013 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) 4-5-6 CЦЕПЛЕНИЕ В СБОРЕ И ВАЛ ТУРБИНЫ
24233406 RING, 4-5-6 CLU BKG PLT RET (PURPLE) (2.49MM +/- 0.05) (ACDelco #24233406)
24233407 RING, 4-5-6 CLU BKG PLT RET (YELLOW) (1.65MM +/- 0.05) (ACDelco #24233407)
24233408 RING, 4-5-6 CLU BKG PLT RET (NONE) (2.07MM +/- 0.05) (ACDelco #24233408)
teamcadillac.ru
24240654 PLATE, 4-5-6 CLU BKG (ACDelco #24240654)
24224158 PLATE, 4-5-6 CLU (PKG OF 7) (FIBER) (*KIT1) (ACDelco #24224158)
24258083 PLATE, 4-5-6 CLU (STEEL) (PART PKG CONTAINS 1 PART) (ACDelco #24258083)
24224647 PLATE, 4-5-6 CLU (WAVED) (ACDelco #24224647)
24237851 RING KIT, RET (1234 DAM, 1234 HSG, 456 DAM) (4.224) (ACDelco #24237851)
24232417 DAM, 4-5-6 CLU PSTN (ACDelco #24232417)
24224714 SPRING, 4-5-6 CLU (ACDelco #24224714)
24232416 PISTON, 4-5-6 CLU (ACDelco #24232416)
24237556 HOUSING, 4-5-6 CLU (W/ INPUT SHF) (INCLS 440) (ACDelco #24237556)
24224655 RING, TURB SHF FLUID SEAL (ACDelco #24224655)
24219390 SEAL, TURB SHF (O RING) (ACDelco #24219390)
24248008 PLATE KIT, CLU (INCLS 433) (ACDelco #24248008)
(GM04-560) 2007-2013 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) 2-6 CЦЕПЛЕНИЕ В СБОРЕ
24232994 RING, 2-6 CLU BKG PLT RET (ACDelco #24232994)
24224171 PLATE, 2-6 CLU BKG (ACDelco #24224171)
24240221 PLATE, 2-6 CLU (PKG OF 6) (FIBER) (*KIT1) (ACDelco #24240221)
24232497 PLATE, 2-6 CLU (STEEL)
24224659 PLATE, 2-6 CLU (WAVED) (ACDelco #24224659)
24235463 RING, 2-6 CLU SPR RET (ACDelco #24235463)
24224725 SPRING, 2-6 CLU (ACDelco #24224725)
24224169 PISTON, 2-6 CLU (ACDelco #24224169)
24257065 SUPPORT, CTR (INCLS 458, 460) (ACDelco #24257065)
teamcadillac.ru
24248008 PLATE KIT, CLU (INCLS 452) (ACDelco #24248008)
(GM04-561) 2007-2013 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) LOW & REVERSE CLUTCH ASSEMBLY
24257065 SUPPORT, CTR (SEE GROUP 04.000 "AUTOMATIC TRANSMISSION/CLUTCH" FOR DETAILED ILLUSTRATED VIEW) (ACDelco #24257065)
24224737 RING, LOW & REV CLU BKG PLT RET (2.31MM +/- 0.05) (ACDelco #24224737)
24245063 RING, LOW & REV CLU BKG PLT RET (1.90MM +/- 0.05) (ACDelco #24245063)
teamcadillac.ru
24245064 RING, LOW & REV CLU BKG PLT RET (2.72MM +/- 0.05) (ACDelco #24245064)
24224175 PLATE, LOW & REV CLU BKG (ACDelco #24224175)
24240041 PLATE, LOW & REV CLU (FIBER) (*KIT1) (ACDelco #24240041)
24232496 PLATE, LOW & REV CLU (STEEL) (ACDelco #24232496)
24224734 PLATE, LOW & REV CLU (WAVED) (ACDelco #24224734)
24224733 RING, LOW & REV CLU SPR RET (4.189) (ACDelco #24224733)
24248957 SPRAG KIT, LOW CLU (ACDelco #24248957) (TRANS BUILT 11-01-06 & AFTER)
24243898 SEAL KIT, A/TRNS SERV (CLUTCHES) (ACDelco #24243898)
24224732 SPRING, LOW & REV CLU (ACDelco #24224732)
24224172 PISTON, LOW & REV CLU (ACDelco #24224172)
24248008 PLATE KIT, CLU (INCLS 463) (ACDelco #24248008)
(GM04-562) 2007-2013 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) CLUTCH HUB ASSEMBLY
24238004 HUB, 4-5-6 CLU (W/ OUTPUT CARR SHF & DPNR) (INCLS 476-478) (ACDelco #24238004)
24230368 DAMPENER, 4-5-6 CLU (PART OF 475) (ACDelco #24230368)
24233359 PLATE, 4-5-6 CLU DPNR APPLY (PART OF 475) (ACDelco #24233359)
24230370 RING, 4-5-6 CLU DPNR RET (PART OF 475) (ACDelco #24230370)
(GM04-563) 2007-2013 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) OUTPUT CARRIER ASSEMBLY
24224853 BEARING, CTR SUPT RLR (PART OF 490) (ACDelco #24224853)
teamcadillac.ru
24224176 BEARING, OUTPUT CARR OTR SUN GR FRT THR (PART OF 490) (ACDelco #24224176)
24224177 GEAR, OUTPUT CARR FRT SUN (PART OF 490) (ACDelco #24224177)
24224178 BEARING, OUTPUT CARR OTR SUN GR RR THR (PART OF 490) (ACDelco #24224178)
24235435 GEAR, OUTPUT CARR RR SUN (PART OF 490) (ACDelco #24235435)
24224747 CARRIER, OUTPUT (INCLS 485-489, 491) (ACDelco #24224747)
(GM04-640) 2007-2013 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) 1-2-3-4 & 3-5 REVERSE CLUTCH ASSEMBLY
24240195 RING, 3-5 REV CLU BKG PLT RET (GREEN) (1.88-1.98) (ACDelco #24240195)
24240197 RING, 3-5 REV CLU BKG PLT RET (NO COLOR) (2.42-2.52) (ACDelco #24240197)
24240198 RING, 3-5 REV CLU BKG PLT RET (PURPLE) (2.69-2.79) (ACDelco #24240198)
24240199 RING, 3-5 REV CLU BKG PLT RET (BLUE) (2.96-3.06) (ACDelco #24240199)
24224149 PLATE, 3-5 REV CLU BKG (ACDelco #24224149)
24235681 PLATE, 3-5/REV CLU (PKG OF 5) (FIBER) (*KIT4) (ACDelco #24235681)
24232498 PLATE, 3-5 REV CLU (STEEL) (ACDelco #24232498)
24239828 PLATE, 3-5 REV CLU (WAVED) (ACDelco #24239828)
24224633 RING, 3-5-REV CLU APPLY (ACDelco #24224633)
24265955 PLATE, 1-2-3-4 CLU BKG (KIT) (ACDelco #26245955)
24224147 PLATE, 1-2-3-4 CLU (PKG OF 6) (FIBER) (*KIT4) (ACDelco #24224147)
24238701 PLATE, 1-2-3-4 CLU (STEEL)
24239615 PLATE, 1-2-3-4 CLU (WAVED) (ACDelco #24239615)
24224708 DAM, 1-2-3-4 CLU PSTN (ACDelco #24224708)
24224707 SPRING, 1-2-3-4 CLU (ACDelco #24224707)
24238700 PISTON, 1-2-3-4 CLU (ACDelco #24238700)
24237308 SPRING, 3-5-REV CLU (ACDelco #24237308)
24242871 PISTON, 3-5/REV CLU (INCLS 422) (ACDelco #24242871)
teamcadillac.ru
24263590 HOUSING, 1-2-3-4 & 3-5 REV CLU (PART OF 427) (W/ BUSHING & BEARING) (ACDelco #24263590) (CONTAINS REQUIRED 1-2-3-4 & 3-5-REV CLUTCH HOUSING BEARING ASM) (DOES NOT INCL CLU DAM, PSTN, SPRINGS, SEALS, PLTS, OR RETAINERS)
24259848 CLUTCH, 1-2-3-4 & 3-5 REV (INCLS 426)
24226393 BEARING, 1-2-3-4 & 3-5-REV CLU (ACDelco #24226393)
24240197 RING, 1-2-3-4 CLU BKG PLT RET (NO COLOR) (2.42-2.52) (ACDelco #24240197)
24240199 RING, 1-2-3-4 CLU BKG PLT RET (BLUE) (2.96-3.06) (ACDelco #24240199)
24240201 RING, 1-2-3-4 CLU BKG PLT RET (WHITE) (3.50-3.60) (ACDelco #24240201)
24240198 RING, 1-2-3-4 CLU BKG PLT RET (PURPLE) (2.69-2.79) (ACDelco #24240198)
24240200 RING, 1-2-3-4 CLU BKG PLT RET (ORANGE) (3.23-3.33) (ACDelco #24240200)
24260145 SEAL KIT, A/TRNS SERV (INCLS 411, 415, 416, 419, 423-425) (ACDelco #24260145)
24237851 RING KIT, RET (INCLS 411, 415) (1234 DAM, 1234 HSG, 456 DAM) (4.224) (ACDelco #24237851)
24243898 SEAL KIT, A/TRNS SERV (INCLS 416, 418, 419, 422-425) (CLUTCHES) (ACDelco #24243898)
24248008 PLATE KIT, CLU (INCLS 402, 408) (ACDelco #24248008)
(TC04-052) 2010-2013 CK1(06-36) ТОРМОЗНОЙ УСИЛИТЕЛЬ (JD9)
20877277 BOOSTER, P/B (INCLS 2, 3) (ACDelco #178-0800)
20903152 SENSOR KIT, P/B BOOS VAC (PART OF 1) (INCLS 2) (ACDelco #178-0857)
(TC04-106) 2010-2011 CK1,2 ПЕДАЛЬ ТОРМОЗА (POWER ADJUSTABLE PEDAL JF4, AN3)
teamcadillac.ru
(TC04-162) 2009-2013 CK1 МАСЛОПРОВОДЫ ОХЛАЖДЕНИЯ АВТОМАТИЧЕСКОЙ КОРОБКИ ПЕРЕДАЧ (6L80 AUTOMATIC MYC)
15779543 PIPE, TRANS FLUID AUX CLR INL (INCLS 2, 5-7) (ACDelco #15779543)
15052228 CAP, TRANS FLUID CLR PIPE CONN (PART OF 1, 9) (PLASTIC RETAINER) (ACDelco #15052228)
15226661 CONNECTOR, TRANS FLUID CLR PIPE (INCLS 4) (9/16-18) (3/8 BODY QUICK CONNECT) (AT RAD) (ACDelco #15226661)
24205103 RETAINER, TRANS FLUID CLR PIPE FTG (PART OF 3, 15, 16) (EXPANDING SPRING WIRE) (ACDelco #24205103)
11609738 NUT, PUSH ON, M6X1, 12.7 OD, 2.18 THK, SAE 1050 STL, GMW3200. (PART OF 1, 9) (8.921)
15782677 CLIP, TRANS FLUID CLR PIPE (PART OF 1, 9) (ACDelco #15782677)
11609989 BOLT, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (PART OF 1, 9)
15068848 SPACER, TRANS FLUID CLR PIPE (HOLDS 2-9.5MM (3/8") DIA PIPES, CLIP TOP, PLASTIC)
25999420 PIPE, TRANS FLUID CLR (INCLS 2, 5-7, 19) (ACDelco #25999420)
11519797 STUD, TRANS (DOUBLE END, HFH, M8X1.25X20, M10X1.5X40, 18 OD, 69.5 TL9.8, GMW3359)
15120618 BRACKET, TRANS FLUID CLR PIPE (ACDelco #15120618)
15049288 CLIP, TRANS FLUID CLR PIPE (BLACK) (37.7X39.3) (DOUBLE SNAIL CLIP) (ACDelco #15049288)
15022958 CLIP, TRANS FLUID CLR PIPE (RETAINS 9.5MM STL TUBING) (2.343)
11516521 BOLT, HFH M6X1X20, 9.8, 7114M, DOG PT, 14.2 OD (TRANS FLUID CLR PIPE CLIP)
20880895 COOLER, TRANS FLUID AUX (CODE 4639, 5464, 9344, 7192, 1509, 0895, 7162) (INCLS 4, 16, 17) (TRUCKS W/2PC STEEL BRACKETS ALSO REQ 11519377 BOLT QTY 2) (ACDelco #20880895)
19210848 CONNECTOR, TRANS FLUID CLR PIPE (PART OF 15) (INCLS 4) (W/O BEVEL WASHER) (ACDelco #19210848)
11570097 NUT, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (PART OF 15)
11519377 BOLT, HEX HD W/FL WA, M6X1X28, 18.15 THD, 17 OD, 8.8 STEEL, GMW3359 (TRANS FLUID AUX CLR)
teamcadillac.ru
15251488 SEAL, TRANS FLUID CLR PIPE (PART OF 9) (SEALS TWO PIPES) (ACDelco #15251488)
11515758 BOLT, HFH, M8X1.25X30, 28THD, 18 O.D., MACH PT, 10.9, 7114M (TRANS FLUID CLR PIPE)
(TC04-602) 2007-2010 K1,2,3 КРОНШТЕЙН РАЗДАТОЧНОЙ КОРОБКИ (NZZ)
teamcadillac.ru
20922755 SHIELD, TRFER CASE
11518341 BOLT, HEX, M10X1.5X25, 14 THD, 28 OD, 6202M, 7114M, TAP, TR-PT (TRFER CASE SHLD)
(TC04-654) 2007-2013 CK1 ТОРМОЗНОЙ СУППОРТ ПЕРЕДНИЙ
15904194 CALIPER, FRT BRK (INCLS 2, 3, 6-9) (ACDelco #172-2402)
15904195 CALIPER, FRT BRK (INCLS 2, 3, 6-9) (ACDelco #172-2408)
25846360 VALVE, FRT BRK CLPR BLEDR (DELPHI CHASSIS, M10 X 1.5) (PART OF 1) (M10X1.5) (ACDelco #25846360)
18009891 COVER, FRT BRK BLEDR SCREW (PART OF 1) (M10X1.5 THD) (4.665)
teamcadillac.ru
15125961 BOLT, FRT BRK CLPR BRKT (M12X1.25-6G) (27MM LONG, 18.8MM HEAD, 10.9 GRADE)
25951292 SEAL KIT, FRT BRK CLPR PSTN (INCLS 9) (PART OF 1)
15125962 PISTON, FRT BRK CLPR (PART OF 1) (ACDelco #15125962)
25910434 BRACKET KIT, FRT BRK CLPR
25910435 BRACKET KIT, FRT BRK CLPR
25910433 PIN KIT, FRT BRK CLPR GDE (INCLS 5, 7) (DOES NOT INCLUDE SHIMS & BOLTS)
15299068 BUSHING KIT, FRT BRK CLPR GDE PIN (INCLS 7) (ACDelco #15299068)
25910430 PAD KIT, FRT DISC BRK (INCLS 10, 12) (ACDelco #171-1014)
25910432 PAD KIT, FRT DISC BRK (INCLS 10, 12) (ACDelco #171-1007)
22742382 PAD KIT, FRT DISC BRK (INCLS 10, 12) (ACDelco #171-1074)
13587647 SPRING KIT, FRT DISC BRK PAD RET (INCLS 12) (ACDelco #13587647)
(TC04-718) 2007-2013 K1 КРОНШТЕЙН ТРАНСМИССИИ
11589247 BOLT, HFH, M14X2X165.5, 58.2 THD, 30.5 ID, 10.9, 7114M, MACH, CONE-PT (TRANS SUPT C/MBR)
11516382 NUT, HFH LK M14X2X15, 28 OD 10 7111M (TRANS SUPT C/MBR)
15894408 CROSSMEMBER, TRANS SUPT (STRAIGHT W/3 HOLES IN CTR)
(TC04-751) 2010-2013 CK1(06-36) СТОЯНОЧНЫЙ ТОРМОЗ
25972876 SWITCH, PARK BRK (PART OF 15)
09418944 SCREW, HWH, SELF TAP, #10-16X1", 3/8" O.D., M6010M, ZN (PART OF 15)
15298817 PAD, PARK BRK LVR PED (PART OF 15)
22851203 CABLE, PARK BRK RR (ACDelco #22851203)
15043173 CLIP, PARK BRK RR CBL (STEEL) (W/O HOLE) (W/3 OPENINGS)
11517560 SCREW, FLAT WA (NRW) AND HX WA HD, M8X1.25X25 (PARK BRK RR CBL GDE)
teamcadillac.ru
15782541 GUIDE, PARK BRK RR CBL (RH REAR FRAME RAIL)
15049571 GUIDE, PARK BRK RR CBL (FRONT)
22851204 CABLE, PARK BRK RR (ACDelco #22851204)
11571172 NUT, PARK BRK CBL EQLZR (PART OF 13) (M6X1.0X22.35)
25838763 CABLE, PARK BRK INTER (INCLS 5, 12, 14) (ACDelco #25838763)
20970871 MODULE, PARK BRK CONT (INCLS 1-4) (ACDelco #20970871)
(TC04-801) 2010 CK1(06-36) БЛОК УПРАВЛЕНИЯ ТОРМОЗНОЙ СИСТЕМОЙ ПРИЦЕПА (JL1)
20904439 RELAY, TRLR BRK CONT (MATES W/CONNECTOR 13580880) (ACDelco #20904439)
teamcadillac.ru
11562584 BOLT, TRLR BRK CONT RLY (M6X1X27) (3.887)
(TC04-901) 2007-2010 CK1 ЩУП УРОВНЯ МАСЛА ТРАНСМИССИИ (4L80 AUTOMATIC MYC)
15877378 INDICATOR, TRANS FLUID LVL
24260606 TUBE, TRANS FLUID FIL
11516780 NUT, HEX W/CON WA, M8X1.25, 10THK, 19 O.D., 10, 7111M (TRANS FLUID FIL TUBE) (8.917)
15796802 SEAL, TRANS FLUID FIL TUBE
teamcadillac.ru
15029928 BOLT, TRANS H/SHLD (M8X1.25X12)
25980339 SHIELD, TRANS HT
(TC04-904) 2007-2013 CK1 МЕХАНИЗМ УПРАВЛЕНИЯ ПЕРЕКЛЮЧЕНИЕМ ПЕРЕДАЧ/МЕХАНИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (6L80 AUTOMATIC MYC)
teamcadillac.ru
15831435 BRACKET, A/TRNS RANGE SEL LVR CBL
20787608 CABLE, A/TRNS RANGE SEL LVR (AT TRNS) (LOWER CABLE) (WHEN REPLACING MUST REPLACE UPPER CABLE)
25995564 CABLE, A/TRNS RANGE SEL LVR (UPPER CABLE)
15116345 RETAINER, A/TRNS RANGE SEL LVR CBL (AT TRNS)
11610265 BOLT, PAN HD W/FL WA, M8X1.25X21.5, 15 THD, 22 OD, 8.8, GMW3044 (A/TRNS RANGE SEL LVR CBL BRKT)
15915999 LEVER, A/TRNS RANGE SEL LVR EQLZR
11514597 NUT, HFH, 10X1.5 THD, 9.8 THK, 21.8 OD, 510M (10) ZF 7111M (A/TRNS RANGE SEL LVR EQLZR LVR) (2.383)
(TC04-906) 2009-2013 CK1(06) КРЕПЛЕНИЕ ТОРМОЗНОГО СУППОРТА И ПОВОРОТНЫЙ КУЛАК (EXC POLICE PACKAGE PPV)
15719028 BOLT, FRT WHL BRG (M14X1.5X70) (6.104)
15016308 BOLT, FRT BRK CLPR (M14X2X45, 37THD, 28 OD) (8.900)
11561674 BOLT, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (FRT WHL SPD SEN)
15133409 BRACKET, FRT WHL SPD SEN
15942237 KNUCKLE, STRG (MCHG)
15942236 KNUCKLE, STRG (MCHG)
25918337 SHIELD, FRT BRK (ACDelco #25918337)
25918338 SHIELD, FRT BRK (ACDelco #25918338)
15715956 CLIP, WHL SPD SEN WIRE (PART OF 11, 14) (GRAY) (10.00MM) (HOLDS (1)10.5/9.5 GROMMET) (PRONG FITS 13.25/12.75X7.5 SLOT)
15267361 CLIP, WHL SPD SEN WIRE (PART OF 11, 14) (CLAM SHELL WITHOUT ALIGNMENT PIN)
15229013 CLIP, WHL SPD SEN WIRE (PART OF 11, 14) (SLIDE LOCK WITH ALIGNMENT PIN)
22740468 SENSOR KIT, FRT WHL SPD (INCLS 8-10) (PART OF 14) (MATING CONN W/LEADS USE 19149296) (ACDelco #22740468) (FOR VEHICLES WITH RPO PPV-USE T/W THERMAL WRAP PN 19207924, BETWEEN WHEEL SPEED SENSOR HEAD AND FIRST CLIP.)
15960191 BOLT, WHL SPD SEN (PART OF 14) (M6X1X12)
11588810 STUD, FRT WHL (PART OF 14) (M14X1.5X29)
25918329 HUB, FRT WHL (W/WHL SPD SEN) (INCLS 8-13) (ACDelco #25918329)
teamcadillac.ru
25819670 ROTOR, FRT BRK (13IN) (ACDelco #177-1014)
11609271 BOLT, FRT BRK ROT (M8 X 1.25 X 20)
(TC04-907) 2007-2013 CK1(06-36) ТОРМОЗНОЙ СУППОРТ ЗАДНИЙ
15792635 CALIPER, RR BRK (INCLS 2-8) (INCLS CALIPER ATTACH BOLTS) (4.667) (ACDelco #15792635)
15792636 CALIPER, RR BRK (INCLS 2-8) (INCLS CALIPER ATTACH BOLTS) (4.667) (ACDelco #15792636)
25823358 BOLT, RR BRK CLPR GDE PIN (PART OF 1) (*KIT1, KIT3)
15265833 BRACKET, RR BRK CLPR
15792650 PIN KIT, RR BRK CLPR GDE (INCLS 2, 9, 10, 13) (ACDelco #15792650)
88967108 VALVE KIT, RR BRK BLEDR (INCLS 3-5) (ACDelco #88967108)
teamcadillac.ru
25949454 PAD KIT, RR DISC BRK (INCLS 2, 11, 13, 14) (ACDelco #171-0999)
(TC04-912) 2007-2013 K1(06-36-43) РАЗДАТОЧНАЯ КОРОБКА ADAPTER (6L80 AUTOMATIC MYC)
24241166 ADAPTER, TRFER CASE
11515767 BOLT, HFH, M10X1.5X35, 32THD, 22.3 O.D., MACH, 10.9, 7114M (TRFER CASE ADAP) (T/W 12345493)
24245110 GASKET, TRFER CASE ADAP
24246762 CASE, TRFER (W/GEARS)
teamcadillac.ru
15709703 NUT, HEX 10X1.5THD, 21.8 OD SS (TRFER CASE)
(TC04-916) 2007-2013 CK1,2,3 ШЛАНГ ОТВОДА ГАЗОВ ИЗ ТРАНСМИССИИ (6L80 AUTOMATIC MYC, 6L90 AUTOMATIC MYD)
25892279 VENT, A/TRNS (PART OF 2) (VENT STEM W/CAP) (4.510) (ACDelco #25892279)
15859985 HOSE, TRANS VENT (INCLS 1, 3-6)
08905794 CLIP, (PART OF 2)
11514596 NUT, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (TRANS VENT HOSE CLIP BRKT) (8.915) (ACDelco #11514596)
teamcadillac.ru
15854320 BRACKET, TRANS VENT HOSE CLIP (ACDelco #15854320) (CODE 0367, 4320)
15820585 HOSE, TRFER CASE VENT
(TC04-917) 2007-2013 K1,2,3 ТРУБКА ВЕНТИЛЯЦИИ РАЗДАТОЧНОЙ КОРОБКИ
25892279 VENT, TRFER CASE (VENT STEM W/CAP) (*KIT1) (ACDelco #25892279)
19130464 STRAP, TIE 0.38" WIDTH, BUNDLE DIA 1/16"-1-3/4", 8.27" LENGTH, NYLON 6/6 FITS 0. (TRFER CASE VENT HOSE) (*KIT1)
09438315 HOSE, FUEL-OIL EVAP (TRFER CASE VENT) (*KIT1)
25518880 CLAMP, HEX HD, WORM GEAR, .250-.625, .320 WIDE, SS (TRANS FLUID CLR HOSE) (*KIT1) (8.948) (ACDelco #25518880)
teamcadillac.ru
15820585 HOSE, TRFER CASE VENT (INCLS 1-4)
(TC04-918) 2007-2013 CK1(06-36) ТОРМОЗНОЙ УСИЛИТЕЛЬ И КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (JD9)
25891352 HOSE, P/B BOOS VAC (INCLS 2) (ACDelco #176-1551)
01470030 CLAMP, WORM TYPE (11/16" TO 1 5/16") (PART OF 1) (ACDelco #1470030)
teamcadillac.ru
15974046 GASKET, P/B BOOS (ACDelco #15974046)
11517996 NUT, BRK M/CYL (M10X1.5, 11.2THK) (21.5 OD) (8.917) (ACDelco #11517996)
12559760 NIPPLE, P/B BOOS VAC HOSE (ACDelco #12559760)
(TC04-922) 2007-2013 CK1 ЭЛЕКТРИЧЕСКАЯ СИСТЕМА ТОРМОЗОВ (JD9)
22740468 SENSOR KIT, FRT WHL SPD (INCLS 2, 3, 7) (MATING CONN W/LEADS USE 19149296) (ACDelco #22740468) (FOR VEHICLES WITH RPO PPV-USE T/W THERMAL WRAP PN 19207924, BETWEEN WHEEL SPEED SENSOR HEAD AND FIRST CLIP.)
15229013 CLIP, WHL SPD SEN WIRE (PART OF 1) (SLIDE LOCK WITH ALIGNMENT PIN)
15267361 CLIP, WHL SPD SEN WIRE (PART OF 1) (CLAM SHELL WITHOUT ALIGNMENT PIN)
11561674 BOLT, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (FRT BRK HOSE)
15715956 CLIP, WHL SPD SEN WIRE (PART OF 1) (GRAY) (10.00MM) (HOLDS (1)10.5/9.5 GROMMET) (PRONG FITS 13.25/12.75X7.5 SLOT)
15960191 BOLT, WHL SPD SEN (M6X1X12)
11570082 BOLT, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (BRK PRESS MOD VLV BRKT) (ACDelco #11570082)
20938122 SENSOR, RR WHL SPD (INCLS 12-14) (ACDelco #20938122)
teamcadillac.ru
11570519 SCREW, PAN HD, M6X1X13, 10 THD 12 OD, 9.8, PHOS & OIL.W/ADH (RR WHL SPD SEN)
(TC04-923) 2007-2013 CK1(06-36) МОДУЛЬ УПРАВЛЕНИЯ ТОРМОЗАМИ (JD9)
20896912 VALVE KIT, BRK PRESS MOD (INCLS 8, 9) (INCLS ELEK BRAKE MOD) (ACDelco #20896912)
15297115 INSULATOR KIT, BRK PRESS MOD VLV (INCLS 2-4)
teamcadillac.ru
15125563 BRACKET, BRK PRESS MOD VLV
20896914 MODULE KIT, ELEK BRK & TRACT CONT (PART OF 1) (INCLS 9) (ACDelco #20896914)
22688153 BOLT, ELEK BRK CONT MDL (ECU TO HCU ATTACH) (PART OF 1, 8)
(TC04-924) 2007-2013 CK1(06-36) ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДР (JD9)
20760280 CAP, BRK M/CYL RSVR (PART OF 4)
15823206 RESERVOIR KIT, BRK M/CYL (PART OF 4) (INCLS 3)
20845345 CYLINDER, BRK MAS (INCLS 1-3, 5, 6) (ACDelco #174-1159)
15787976 SEAL, BRK M/CYL (PART OF 4) (ACDelco #15787976)
teamcadillac.ru
22672096 SWITCH, BRK FLUID LVL IND (PART OF 4) (ACDelco #22672096)
(TC04-925) 2007-2010 CK1,2(06-36) ПЕДАЛЬ ТОРМОЗА (EXC POWER ADJUSTABLE PEDAL JF4)
15713209 BRACKET, BRK & ACCEL PED (INCLS 5, 6) (L=45 W=80 H=80) (DASH PANEL) (0.829)
25863989 BRACKET, BRK & ACCEL PED (INCLS 5, 6) (LWR PLNM PNL)
teamcadillac.ru
15906963 PEDAL, BRK (INCLS 13)
15706042 PAD, BRK PED (PART OF 12)
(TC04-928) 2007-2013 CK1(06-36) ТОРМОЗНЫЕ МАГИСТРАЛИ ПЕРЕДНИЕ (JD9)
11518522 NUT, HX FLARED TUBE, M12X1.0X20.5, 11 TUBE, SAE1010, GMW4707M (PART OF 5, 6)
19181732 PIPE, BRK (INCLS 4, 13) (5/16" X 16 FT) (BULK PIPE) (ACDelco #19181732)
15194368 CLIP, RR BRK FRT PIPE (BLACK) (9.2X33.1X15) (HOLDS (2)7.94 LINES) (NYLON) (4.685)
88936298 PIPE, BRK (STEEL) (1/4" X 16 FT ROLL) (BRK PIPE)
teamcadillac.ru
11570231 CLIP, FRT BRK PIPE (BLACK) (53.66X22.53X17.0) (HOLDS (1)6.65, & (2)8.35 DIA TUBES) (NYLON)
11570234 CLIP, FRT BRK PIPE (BLACK) (HOLDS (2)6.65, (2)8.35 DIA TUBES) (NYLON)
11570232 CLIP, FRT BRK PIPE (BLACK) (12DIA X22/101.4X17) (HOLDS (2)6.65, (2)8.35, (1)5.0 TUBES, (1)17 & (1)33.0 HARNESSES)
11570528 CLIP, FRT BRK PIPE (4.26X22X15) (HOLDS (2) 8.20 BRK LINES)
11562075 NUT, FRT BRK FRT PIPE (PART OF 5, 6) (M12X1.5X17) (INVERTED FLARE)
11519388 BOLT, HX HD CON WA, M8X1.25X25, 20 THD, 24 OD, 8.8, GMW3359 (SILVER), M-POINT (ELEK BRK CONT MDL BRKT)
15923783 HOSE, FRT BRK (INCLS 18, 19) (ACDelco #176-1515)
11569669 BOLT, FRT BRK HOSE (PART OF 17, 25) (M10X1.5X23, 13THD) (BANJO)
11516885 SCREW, HFH W/FL WA, TAP, M8X1.25X20, 7THD, 17 O.D., TR PT, 6202M, PZOR (FRT BRK HOSE BRKT)
11561421 CLIP, FRT BRK FRT PIPE (HOLDS (1)6.65 DIA TUBE, (1)15.0 DIA HARNESS, FITS 6 DIA HOLE)
11561422 CLIP, FRT BRK FRT PIPE (HOLDS (1)6.65 DIA TUBE, (1)15.0 DIA HARNESS, FITS 8 DIA HOLE)
15923784 HOSE, FRT BRK (INCLS 18, 19) (ACDelco #176-1516)
(TC04-929) 2007-2013 CK1(06-36) ТОРМОЗНЫЕ МАГИСТРАЛИ/INTERMEDIATE (JD9)
88936298 PIPE, BRK (STEEL) (1/4" X 16 FT ROLL) (BRK)
11518522 NUT, HX FLARED TUBE, M12X1.0X20.5, 11 TUBE, SAE1010, GMW4707M (RR BRK FRT PIPE)
teamcadillac.ru
11610034 CLIP, RR BRK FRT PIPE (BROWN/BLACK) (8X22X44) (HOLDS (2)6.75 TUBES) (PRONG FITS 8 DIA HOLE IN 3.2 THK PNL)
11610035 CLIP, RR BRK FRT PIPE (BROWN/BLACK) (6.9 X 20.4/77.4 X 15) (HOLDS (1)4.8, (2)6.75 TUBES, & (1)32 HARNESS) (FITS 7.2 HOLE)
11562075 NUT, RR BRK FRT PIPE (M12X1.5X17) (INVERTED FLARE)
(TC04-932) 2007-2013 CK1(06-36) ТОРМОЗНЫЕ МАГИСТРАЛИ ЗАДНИЕ
teamcadillac.ru
25906096 HOSE, RR BRK (AT CALIPER) (INCLS 5, 6) (ACDelco #176-1526)
25890942 HOSE, RR BRK (CALIPER) (INCLS 5, 6)
11569751 NUT, HX TUBE INVERTED FLARE, M10X1X16, SAE1010, GMW4707M (RR BRK C/OVR PIPE)
11515756 BOLT, HFH, M8X1.25X20, 17THD, 18 O.D., 10.9, 7114M (RR BRK C/OVR PIPE BRKT)
11561240 CLAMP, SINGLE CLOSED-LOOP, DIA 7.25MM, C-TO-C 36.5, WIDTH 20, HOLE DIA 11 (RR BRK C/OVR PIPE) (8.948)
21012386 WASHER, RR BRK HOSE (PART OF 1, 14) (10.3X14.5X1.61) (COPPER) (ACDelco #21012386)
11569590 BOLT, RR BRK HOSE (PART OF 1, 14) (M10X1X27.5, 16.9THD) (BANJO)
88983905 PIPE, BRK (3/16" X 16') (BULK TUBING) (NYLON COATING) (ACDelco #88983905)
11516885 SCREW, HFH W/FL WA, TAP, M8X1.25X20, 7THD, 17 O.D., TR PT, 6202M, PZOR (RR BRK HOSE BRKT)
25890941 HOSE, RR BRK (JOUNCE)
25906094 HOSE, RR BRK (JOUNCE) (ACDelco #176-1541)
25906095 HOSE, RR BRK (JOUNCE) (ACDelco #176-1525)
15234822 STRAP, RR BRK PIPE
12471307 BOLT, R/AXL HSG CVR (M8X1.25X22.6, 19.2THD) (13 DRIVER SIZE)
20763162 BRACKET, RR BRK C/OVR PIPE
25906097 HOSE, RR BRK (AT CALIPER) (INCLS 5, 6) (ACDelco #176-1528)
25890943 HOSE, RR BRK (CALIPER) (INCLS 5, 6)
(TX04-118) 2008-2013 CK1 СТОЯНОЧНЫЙ ТОРМОЗ В СБОРЕ (JD9,J92)
15265913 ANCHOR, RR PARK BRK
25877333 PLATE, RR PARK BRK ANC BKG (ACDelco #25877333)
teamcadillac.ru
15817021 ADJUSTER KIT, RR PARK BRK (INCLS 5, 6, 9-11)
15817020 SHOE KIT, RR PARK BRK (INCLS 1-3) (SERVICES ONLY ONE SIDE) (ACDelco #171-0992)
15816927 LEVER KIT, RR PARK BRK ACTR (INCLS 7, 8, 13) (4.591)
(TX04-900) 2007-2013 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) CASE & RELATED PARTS
17804387 CONVERTER, TORQ (REMANUFACTURED-NOT FOR SALE WHERE IMPORTS ARE RESTRICTED)
24224574 BOLT, T/CV HSG (ACDelco #24224574)
24205899 PLUG, T/CV HSG ACC HOLE (28MM W/3 TANGS) (SMALL CVR) (ACDelco #24205899)
24224577 SEAL, A/TRNS FLUID PUMP (ACDelco #24224577)
90351710 PIN, T/CV HSG LOC (0.293)
24237785 CASE, A/TRNS (INCLS 12, 13) (ACDelco #24237785)
24239878 SLEEVE, A/TRNS ELEC CONN PASG (ACDelco #24239878)
24238076 SEAL, OUTPUT SHF (ACDelco #24238076)
11515768 BOLT, HFH, REDUCED BODY, M10X1.5X40, 30THD, 22.3 O.D., HDR PT, 10.9, 7114M (A/TRNS CASE EXTN)
teamcadillac.ru
24237181 BOLT, VLV BODY (M5 X 0.8 X 73.0) (ACDelco #24237181)
24231074 BOLT, MAN SHFT DTNT (M10X1X14.5)
24222646 DETENT, MAN SHFT (W/8MM DIA. ROLLER) (ACDelco #24222646)
24236933 FILTER KIT, A/TRNS FLUID (INCLS 25) (ACDelco #24236933)
24224781 GASKET, A/TRNS FLUID PAN (ACDelco #24224781)
29535617 MAGNET, A/TRNS FLUID PAN (4.105) (ACDelco #29535617)
24222657 PAN, A/TRNS FLUID (W/ OUT PLUG AND INTERNAL FLUID LEVEL STANDPIPE) (ACDelco #24222657)
11569816 BOLT, HFH, M6X1X19, 11.5 THD, 14.2 OD, 8.8 STL, GMW3359-BLACK, MAT POINT (A/TRNS FLUID PAN)
24205900 COVER, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900)
24224675 SEAL, A/TRNS CASE EXTN (*KIT1) (ACDelco #24224675)
24260145 SEAL KIT, A/TRNS SERV (INCLS 33, 36) (ACDelco #24260145)
24236927 SEAL KIT, A/TRNS SERV (INCLS 9, 10, 18-20) (CNTRL SOL VLV ASM) (ACDelco #24236927)
(TX04-901) 2007-2013 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) TORQUE CONVERTER HOUSING & FLUID PUMP
24218963 RING, T/CV FLUID SEAL RET (ACDelco #24218963)
24237531 SEAL, T/CV FLUID (ACDelco #24237531)
00444613 PLUG, HEX HD, 1/8-27 NPTF, STL (LINE PRESS TEST HOLE) (ACDelco #444613)
24236120 HOUSING, T/CV (MCHG) (INCLS 206) (ACDelco #24236120)
24231684 PIPE, A/TRNS VENT (ACDelco #24231684)
24237658 SEAL, TRANS FLUID CLR PIPE FTG (AT TRANS) (SEALS ONE PIPE) (ACDelco #24237658)
teamcadillac.ru
24222668 SLIDE, A/TRNS FLUID PUMP (17.948MM-17.961MM) (ACDelco #24222668)
24224131 SLIDE, A/TRNS FLUID PUMP (17.961MM-17.974MM) (ACDelco #24224131)
24224132 SLIDE, A/TRNS FLUID PUMP (17.974MM-17.987MM) (ACDelco #24224132)
00147500 VALVE, PRESS RLF BALL (*KIT2) (ACDelco #00147500)
24224692 WASHER, 1-2-3-4 & 3-5 REV CLU HSG THR (*KIT2) (ACDelco #24224692)
24248559 RING KIT, 1-2-3-4 & 3-5 REV CLU FLUID SEAL (1-SET 2ND DES SEALS (INCL QUAD LOBE)) (*KIT2) (ACDelco #24248559)
24227061 BOLT, A/TRNS FLUID PUMP CVR (ACDelco #24227061)
90351709 PIN, A/TRNS FLUID PUMP LOC ("8MM HOLLOW SPLIT PIN") (*KIT2) (1.639)
24225398 BOLT, 1-2-3-4 & 3-5-REV CLU SUPT (M6 X 1.0 X 20) (4.329)
24248569 ROTOR PKG, A/TRNS FLUID PUMP (INCLS 207-211, 213-217) (17.948MM-17.961MM) (ACDelco #24248569)
24248571 ROTOR PKG, A/TRNS FLUID PUMP (INCLS 207-211, 213-217) (17.974MM-17.987MM) (ACDelco #24248571)
24248570 ROTOR PKG, A/TRNS FLUID PUMP (INCLS 207-211, 213-217) (17.961MM-17.974MM) (ACDelco #24248570)
24248573 COVER KIT, A/TRNS FLUID PUMP (INCLS 218-230, 232-237) (ACDelco #24248573)
(TX04-902) 2007-2013 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) PARK LOCK LINKAGE
24242085 ACTUATOR, PARK PAWL (ACDelco #24242085)
24227077 PIN, MAN SHFT DTNT LVR HUB (ACDelco #24227077)
24234562 LEVER, MAN SHFT DTNT (ACDelco #24234562)
24225792 PIN, MAN SHFT SHF (ACDelco #24225792)
24235861 SEAL, MAN SHFT SHF (ACDelco #24235861)
24225445 SHAFT, MAN SHFT (ACDelco #24225445)
teamcadillac.ru
24224348 GUIDE, PARK PAWL ACTR (INCLS 510)
24224350 SEAL, PARK PAWL ACTR GDE (O RING) (PART OF 509) (ACDelco #24224350)
24226102 PIN, PARK PAWL ACTR GDE (ACDelco #24226102)
(TX04-903) 2007-2013 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) OUTPUT SHAFT ASSEMBLY
24241091 RING, OUTPUT CARR INTL GR RET (ACDelco #24241091)
24224194 GEAR, OUTPUT CARR INTL (*KIT1)
24227962 SPACER, OUTPUT CARR INTL GR (ACDelco #24227962)
24230545 GEAR, OUTPUT CARR INTL (RR) (*KIT1) (ACDelco #24230545)
teamcadillac.ru
19260885 GEAR, OUTPUT INTL (W/OUTPUT SHAFT) (CODE 2CKA, 3CJA, 0CKA) (INCLS 495, 497-499) (ACDelco #19260885)
(TX04-904) 2007-2013 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) CLUTCH ASSEMBLIES & RELATED PARTS
24236874 CARRIER, INPUT (ACDelco #24236874)
24224404 GEAR, INPUT SUN (ACDelco #24224404)
24224405 BEARING, INPUT SUN GR THR (ACDelco #24224405)
24232409 WASHER, INPUT SUN GR THR (ACDelco #24232409)
24238905 BEARING, TURB SHFT THR (ACDelco #24238905)
teamcadillac.ru
24238004 HUB, 4-5-6 CLU (W/ OUTPUT CARR SHF & DPNR) (SEE GROUP 04.000 "AUTOMATIC TRANSMISSION/CLUTCH HUB" FOR DETAILED ILLUSTRATED VIEW) (ACDelco #24238004)
24233732 BEARING, 4-5-6 CLU HUB THR (ACDelco #24233732)
24224162 HUB, 1-2-3-4 CLU (W/OUTPUT CARR INR SUN GR SHF) (ACDelco #24224162)
24237209 BEARING, 1-2-3-4 CLU HUB THR (ACDelco #24237209)
24235127 HUB, 2-6 & 3-5/REV CLU (W/ OUTPUT CARR OTR SUN GR SHF) (INCLS 60, 62) (ACDelco #24235127)
24224164 BEARING, 2-6 & 3-5/REV CLU HUB THR (ACDelco #24224164)
24224724 RING, CTR SUPT RET (ACDelco #24224724)
24224747 CARRIER, OUTPUT (SEE GROUP 04.000 "AUTOMATIC TRANSMISSION/OUTPUT CARRIER" FOR DETAILED ILLUSTRATED VIEW) (ACDelco #24224747)
24251655 BEARING, OUTPUT CARR THR (ACDelco #24251655)
24224668 BEARING, OUTPUT SHF THR (ACDelco #24224668)
(TX04-905) 2007-2013 CK1 АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MYC) (6L80) ASSEMBLY
17804416 TRANSMISSION, AUTO (SERVICE) (REMANUFACTURED-NOT FOR SALE WHERE IMPORTS ARE RESTRICTED) (CODE OCKA)
(TX04-906) 2007-2013 K1 РАЗДАТОЧНАЯ КОРОБКА (NR3) PART 1 ДЕТАЛИ КОРПУСА-AWD (BORG WARNER 4485)
89059522 STUD, TRFER CASE ADAP (PART OF 2)
19132934 CASE, TRFER (FRT HALF) (INCLS 1, 3, 14)
88984499 PIN, TRFER CASE HALF LOC (PART OF 2)
19132802 BUSHING, TRFER CASE RR EXTN (PART OF 11)
89059495 SEAL, TRFER CASE RR OUTPUT SHF
teamcadillac.ru
88984495 PLUG, TRFER CASE OIL FILL
89059524 BOLT, TRFER CASE HALF (M8X1.25X43.0)
88996459 BRACKET, TRFER CASE (UPPER)
88984495 PLUG, TRFER CASE OIL FILL (DRAIN)
19153151 CASE, TRFER (RR HALF) (CODE KK) (INCLS 4)
88984501 SEAL, TRFER CASE FRT OUTPUT SHF
15580319 VENT, TRFER CASE
19132801 SEAL, TRFER CASE INPUT SHF (PART OF 2)
(TX04-907) 2007-2013 K1 РАЗДАТОЧНАЯ КОРОБКА (NR3) PART 2 ВНУТРЕННИЕ ДЕТАЛИ-AWD (BORG WARNER 4485)
88984507 BEARING, TRFER CASE INPUT SHF
19132803 SHAFT, TRFER CASE INPUT
19168732 BUSHING, TRFER CASE FRT OUTPUT SHF DRV SPKT (PART OF 4) (ACDelco #19168732)
19258136 SPROCKET, TRFER CASE FRT OUTPUT SHF DRV (INCLS 3)
19151772 CHAIN, TRFER CASE TWO/FOUR WHL DRV
88984523 GEAR, TRFER CASE PLNT CARR SUN (OUTPUT)
19210917 CARRIER, FRT/RR DRV DIFF
89059525 WASHER, TRFER CASE PLNT CARR SUN GR THR
teamcadillac.ru
88984524 GEAR, TRFER CASE PLNT CARR SUN (INPUT) (STAMPED PM/POWDERED METAL)
19168733 BUSHING, TRFER CASE RR OUTPUT SHF (PART OF 11)
19178328 SHAFT, TRFER CASE RR OUTPUT (INCLS 10, 13, 14)
88984508 RING, TRFER CASE RR OUTPUT SHF RR BRG OTR RET (80MM I.D.) (4.535)
88984506 BEARING, TRFER CASE RR OUTPUT SHF RR (PART OF 11)
88984493 RING, TRFER CASE RR OUTPUT SHF RR BRG RET (PART OF 11) (41MM I.D.) (ACDelco #88984493)
88996564 BEARING, TRFER CASE FRT OUTPUT SHF DRV SPKT
19258135 SPROCKET, TRFER CASE TWO/FOUR WHL DRV DRVN
89059602 PLUG, TRFER CASE FRT OUTPUT SHF HOLE (PART OF 18)
19153149 SHAFT, TRFER CASE FRT OUTPUT (INCLS 17)
88984518 WASHER, TRFER CASE FRT OUTPUT SHF DRVN SPKT THR
04 - РАЗДАТОЧНАЯ КОРОБКА
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
04 - ТОРМОЗА
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
11516780 NUT, HEX W/CON WA, M8X1.25, 10THK, 19 O.D., 10, 7111M (PARK BRK CONT MDL) (8.917)
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
04 - ТРАНСМИССИЯ-ТОРМОЗА
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
05 - ТОРМОЗА-ЗАДНИЙ МОСТ-КАРДАННЫЙ ВАЛ-КОЛЕСА
(GM05-007) 2007-2013 CK1,2,3 ШИНА
19145377 TIRE, FRT (TIRE MFG # 53967) (INSTALL .25) (SINGLE 19.5KGS) (BRIDGESTONE, DUELER H/L ALENZA W/UNI-T, P275/55R20, BL, 111S) (ACDelco #FB053967)
19145900 TIRE, FRT (TIRE MFG # 047456) (BRIDGESTONE, DUELER H/L (D683), P265/65R18, BW112H) (ACDelco #FB047456)
19148471 TIRE, FRT (TIRE MFG # 054035) (BRIDGESTONE, DUELER A/T-RHS, P265/65R18, OWL112S) (ACDelco #FB054035)
19143998 TIRE, RR (TIRE MFG # 053998) (INSTALL .25) (SINGLE 19.3KGS) (BRIDGESTONE, DUELER H/L ALENZA, P285/45R22, BW110H) (ACDelco #FB053984)
89049423 TIRE, SPARE (GOODYEAR, WRANGLER ST, 265/70R17, BSL) (ACDelco #HD422430)
19161391 TIRE, FRT (TIRE MFG # 088505) (BRIDGESTONE, DUELER A/T RHS, P265/70R17, BW) (ACDelco #FB086505)
88926373 TIRE, FRT (TIRE MFG # 410422177) (GOODYEAR, WRANGLER AT/S, 265/70R17, BSL) (ACDelco #MI422177)
19238605 TIRE, FRT (TIRE MFG # 090177) (FIRESTONE, DESTINATION LE, P265/65R18, BW112S) (ACDelco #FB090177)
19238606 TIRE, FRT (TIRE MFG # 090279) (FIRESTONE, DESTINATION LE, P265/65R18, WOL112S) (ACDelco #FB090279)
19191085 TIRE, FRT (TIRE MFG # 403767658) (GOODYEAR, WRANGLER HP, P265/70R17, BSL113S) (ACDelco #MH767658)
89000920 TIRE, FRT (TIRE MFG # 106087625) (GOODYEAR, EAGLE GT II, 285/50R20, VSB) (ACDelco #ZA087625)
88926367 TIRE, FRT (TIRE MFG # 403422658) (GOODYEAR, WRANGLER HP, 265/70R17, BSL) (ACDelco #MH422658)
88926368 TIRE, FRT (TIRE MFG # 403422918) (GOODYEAR, WRANGLER HP, 265/70R17, OWL) (ACDelco #MH422918)
88926372 TIRE, SPARE (GOODYEAR, WRANGLER AT/S, 265/70R17, OWL) (ACDelco #MI422176)
89049423 TIRE, FRT (TIRE MFG # 773422430) (GOODYEAR, WRANGLER ST, 265/70R17, BSL) (ACDelco #HD422430)
teamcadillac.ru
89049424 TIRE, FRT (TIRE MFG # 773422431) (GOODYEAR, WRANGLER ST, 265/70R17, OWL) (ACDelco #HD422431)
19143998 TIRE, FRT (TIRE MFG # 053998) (INSTALL .25) (SINGLE 19.3KGS) (BRIDGESTONE, DUELER H/L ALENZA, P285/45R22, BW110H) (ACDelco #FB053984)
19145327 TIRE, FRT (TIRE MFG # 54018) (INSTALL .25) (SINGLE 18.8KGS) (BRIDGESTONE, DUELER A/T RH-S, P265/65R18, 112S) (ACDelco #FB054018)
19252710 TIRE, SPARE (TIRE MFG # 15482850000) (ACDelco #1548285G) (GENERAL, AMERITRAC TR, P265/70R17BSW113H)
19145892 TIRE, FRT (TIRE MFG # 43614) (ACDelco #FB043614) (BRIDGESTONE, DUELER H/T, (D684 II)_P265/65R18, BW112S)
19254959 TIRE, FRT (TIRE MFG # 732301500) (ACDelco #HN301500) (GOODYEAR, EAGLE RS-A POLICE, P265/60R17VSB108V)
(TC05-025) 2007-2013 K1,2,3 КРЕПЛЕНИЕ КАРДАННОГО ВАЛА/ПЕРЕДНИЙ МОСТ
teamcadillac.ru
15734903 BOLT, F/AXL PROP SHF (5/16-24X1.3) (HEX)
07846740 RETAINER, F/AXL PROP SHF (1 13/16 IN HOLE CTR) (USED W/1 1/8 IN BRG CAP, CUT-OFF CORNERS)
(TC05-320) 2008-2013 CK107(06) НАДУВНОЕ УСТРОЙСТВО ДЛЯ ШИН (HYBRID HP2)
15226250 CONTAINER, TIRE SEALANT SOL (INCLS 9, 10)
25791334 BRACKET, TIRE INFLR (INCLS 5)
teamcadillac.ru
22732103 COMPRESSOR, TIRE AIR (INCLS 2-4) (COMPRESSOR ONLY)
10382058 LABEL, TIRE MAX SPEED (PART OF 1)
10382059 LABEL, TIRE SEALER CAUTION (PART OF 1)
(TC05-602) 2007-2013 CK1,2,3 КРЕПЛЕНИЕ КАРДАННОГО ВАЛА/ЗАДНИЙ МОСТ (ONE PIECE PROP)
teamcadillac.ru
15734903 BOLT, RR PROP SHF (5/16-24X1.3) (HEX)
03920486 RETAINER, RR PROP SHF (1 21/32 IN HOLE CTR) (USED W/7/8 IN BRG CAP, SQUARE CORNERS)
(TC05-653) 2007-2013 CK1(06-36) РУБКА ВЕНТИЛЯЦИИ ЗАДНЕГО МОСТА
teamcadillac.ru
15920576 HOSE, R/AXL VENT (INCLS 2, 3) (4.0 ID) (APPROX 2020.5 LENGTH)
15157936 CLIP, R/AXL VENT HOSE (PART OF 1) (BLACK) (HOLDS 8.75 DIA LINE, NYLON)
15743069 VENT, R/AXL (PART OF 1)
26063647 CONNECTOR, R/AXL VENT HOSE
(TC05-900) 2007-2013 CK1(06-36) ЗАПАСНОЕ КОЛЕСО
09596426 WHEEL, 17X7.5 SPA (CODE FLY UTY) (ACDelco #9596426)
teamcadillac.ru
25858636 CAP, TIRE PRESS IND SEN (PART OF 2) (BLACK) (ACDelco #25858636)
09595852 WHEEL, 17X7 SPA (ALUM)
(TC05-904) 2007-2013 CK1(06-36) ОСЬ ЗАДНЯЯ В СБОРЕ-COMPLETE
20937817 AXLE, RR (3.42 RATIO) (CODE AACC AAM5 AAZS)
22874932 AXLE, RR (CODE AACD AAM6 AAZT)
teamcadillac.ru
22847703 AXLE, RR (3.42 RATIO) (CODE AACG AAM8 AAX6 AA5C)
(TC05-905) 2009-2013 CK1(06-36) ОСЬ ЗАДНЯЯ В СБОРЕ 8.625 RING GEAR PART 1 (EXC (AXN))
03984818 WASHER, DIFF P/GR THR (.797 I.D. 1.70 O.D.) (*KIT1)
00454947 BOLT, HEX .437-14X2.250 CL-2A CAD/ZC (PART OF 31)
20763162 BRACKET, RR BRK C/OVR PIPE (INCLS 9)
92230583 PLUG, R/AXL HSG FILL (M20X1.5X16, 29 OD) (SQ HD W/WASHER, W/MAGNET) (NO ZINC COATING)
25824253 COVER, R/AXL HSG (COVER ONLY)
15860607 GASKET, R/AXL HSG CVR (10 BOLT HOLES)
19180884 GEAR KIT, DIFF RING & PINION (INCLS 16, 32, 33, 43)
01394892 SHIM KIT, DIFF DRV P/GR BRG (R/AXL) (.020-.024" THK)
01394893 SHIM KIT, DIFF DRV P/GR BRG (.025-.029" THK)
01394894 SHIM KIT, DIFF DRV P/GR BRG (.030-.034" THK)
01394895 SHIM KIT, DIFF DRV P/GR BRG (.035-.039" THK)
26043991 SHIM KIT, DIFF DRV P/GR BRG (.040-.044" THK)
26043992 SHIM KIT, DIFF DRV P/GR BRG (.045-.049" THK)
25824251 BEARING, DIFF DRV P/GR INR (8.5/8.625 DIA) (ACDelco #S1381)
12479162 SPACER, DIFF DRV P/GR BRG (R/AXL) (PART OF 13) (.062-.068" THK)
20938122 SENSOR, RR WHL SPD (ACDelco #20938122)
15286384 RING, WHL SPD SEN RELUCTOR
12479031 BEARING, R/AXL SHF (5.855) (ACDelco #RW20-10)
12471686 SEAL, R/AXL SHF (ACDelco #291-315)
15065927 BOLT, PARK BRK (M12X1.75X34)
15012506 BOLT, RR BRK CLPR (PART OF 27) (M14X2.0X37, 37THD) (27.3-OD., 10.9, GM6174M)
25832103 ROTOR, RR BRK (INCLS 25) (ACDelco #177-1041)
11588811 STUD, RR WHL (M14X1.5X58, 24THD) (21 OD)
22874951 SHAFT, R/AXL
03833322 LOCK, R/AXL SHF (39.43 X 19.94MM)
25824244 HOUSING, R/AXL (INCLS 5, 6)
88891763 NUT, DIFF DRV P/GR (R/AXL) (PART OF 13, 34) (M10)
00517900 WASHER, DIFF DRV P/GR (PART OF 13, 34) (.890X1.625X.190)
19180533 YOKE KIT, DIFF DRV P/GR (INCLS 32, 33, 35) (INCLS NUT, SEAL, WASHER & YOKE)
26064029 SEAL, DIFF DRV P/GR (PART OF 34) (5.545)
25824252 BEARING, DIFF DRV P/GR OTR (INCLS 1 CONE AAM# 40048060 AND 1 CUP AAM# 40048058) (8.5/8.625 DIA) (ACDelco #S1382)
12471330 SPACER, DIFF BRG (4.37-4.32MM THK) (5.650)
12471362 SHIM KIT, DIFF BRG (1.016-1.118MM RANGE) (RR AXLE)
12471363 SHIM KIT, DIFF BRG (1.168-1.372MM RANGE) (RR AXLE)
12471364 SHIM KIT, DIFF BRG (1.422-1.626MM RANGE) (RR AXLE)
12471365 SHIM KIT, DIFF BRG (1.676-1.880MM RANGE) (RR AXLE)
12471366 SHIM KIT, DIFF BRG (1.930-2.134MM RANGE) (RR AXLE)
12471367 SHIM KIT, DIFF BRG (2.184-2.388MM RANGE) (RR AXLE)
12471368 SHIM KIT, DIFF BRG (2.438-2.540MM RANGE) (RR AXLE)
25824250 BEARING, DIFF (8.5/8.625 DIA) (ACDelco #S1380)
25824246 CASE, DIFF (CASE ONLY)
25872305 BOLT, DIFF P/GR SHF LK (.3X18X30, 12.7THD) (*KIT1)
25824249 SHAFT, DIFF P/GR (124.84 MM) (*KIT1)
11610549 BOLT, RR DIFF R/GR (R/AXL) (PART OF 13) (7/16-20)
teamcadillac.ru
19180887 GEAR KIT, DIFF SI & PINION (INCLS 1-4, 41, 42)
(TC05-922) 2008-2013 CK1,2(06-36) TIRE VALVE STEM & PRESSURE SENSOR
20923680 SENSOR, TIRE PRESS IND (INCLS 2-5) (SNAP IN) (INCLS BLACK VALVE CAP) (ACDelco #20923680) (ALL NON HIGH-PERF APPS PREV SERV'D W/MET STEM NOW SERV'D W/RUB STEM)
15263240 VALVE KIT, TIRE (PART OF 1) (INCLS 2, 4, 5) (INCLS BLK CAP, STEM, BOLT) (ACDelco #15263240)
teamcadillac.ru
25858636 CAP, TIRE PRESS IND SEN (PART OF 1, 3) (BLACK) (ACDelco #25858636)
09593595 STEM, TIRE VLV (INCLS 7, 8) (FITS 0.453 HOLE, INCLS CAP 9427576 1.24" LONG HIGH PRESS)
(TC05-954) 2010-2013 CK1(06-36) ОСЬ ЗАДНЯЯ В СБОРЕ 9.50 RING GEAR PART 1 (AXN)
12471307 BOLT, R/AXL HSG CVR (PART OF 4) (M8X1.25X22.6, 19.2THD) (13 DRIVER SIZE)
92230583 PLUG, R/AXL HSG FILL (PART OF 4) (M20X1.5X16, 29 OD) (SQ HD W/WASHER, W/MAGNET) (NO ZINC COATING)
19133285 COVER KIT, R/AXL HSG (INCLS 2, 3, 5) (INCLS COVER, GSKT, BOLTS, & FILL PLUG)
26063649 GASKET, R/AXL HSG CVR (PART OF 4) (14 BOLT HOLES)
12471607 MAGNET, R/AXL HSG CHIP COLLECTOR (4.105) (ACDelco #12471607)
11570339 SCREW, FLAT CS, M6X1X20, 12.3 OD, 14.2 THD, GMW25 (8.8), GMW3044, T-30, HDR-P (RR BRK ROT) (8.908)
15012506 BOLT, RR BRK CLPR (M14X2.0X37, 37THD) (27.3-OD., 10.9, GM6174M)
12471479 PLUG, R/AXL HSG DRN (M20X1.5) (21MM LONG)
25928339 HOUSING, R/AXL (INCLS 35, 36)
14012746 LOCK, R/AXL SHF (43.0 X 22.5MM)
25832103 ROTOR, RR BRK (ACDelco #177-1041)
15812663 SHAFT, R/AXL
88891763 NUT, DIFF DRV P/GR (R/AXL) (PART OF 26) (M10) (*KIT1)
00517900 WASHER, DIFF DRV P/GR (PART OF 26) (.890X1.625X.190) (*KIT1)
26064012 YOKE, DIFF DRV P/GR (INCLS 24, 25, 27)
26064029 SEAL, DIFF DRV P/GR (PART OF 26) (5.545)
09417781 BEARING, DIFF DRV P/GR OTR (2.84") (5.484) (ACDelco #S604)
14012691 SPACER, DIFF DRV P/GR BRG (35.5MM I.D. X 16.3MM WIDE) (*KIT1)
00457108 BEARING, DIFF DRV P/GR INR (ACDelco #S37)
14038010 SHIM KIT, DIFF DRV P/GR BRG (R/AXL) (.5080-.5842MM)
14038011 SHIM KIT, DIFF DRV P/GR BRG (.6096-.7112MM)
14038012 SHIM KIT, DIFF DRV P/GR BRG (.7366-.8382MM)
14038013 SHIM KIT, DIFF DRV P/GR BRG (.8636-.9398MM)
11505123 BEARING, DIFF (INCLS CUP AND CONE, TIMKEN, JLM506849-JLM506811, 55MM ID X 90MM OD X 25MM THK) (ACDelco #S1198)
teamcadillac.ru
14012725 SHIM, DIFF BRG (5.59 MM)
14012726 SHIM, DIFF BRG (5.64 MM)
14012727 SHIM, DIFF BRG (5.69 MM)
14012728 SHIM, DIFF BRG (5.74 MM)
14012729 SHIM, DIFF BRG (5.79 MM)
14012730 SHIM, DIFF BRG (5.84 MM)
14012731 SHIM, DIFF BRG (5.89 MM)
14012732 SHIM, DIFF BRG (5.94 MM)
14012733 SHIM, DIFF BRG (5.99 MM)
14012734 SHIM, DIFF BRG (6.05 MM)
14012735 SHIM, DIFF BRG (6.10 MM)
14012736 SHIM, DIFF BRG (6.15 MM)
14012737 SHIM, DIFF BRG (6.20 MM)
14012738 SHIM, DIFF BRG (6.25 MM)
14012739 SHIM, DIFF BRG (6.30 MM)
14012740 SHIM, DIFF BRG (6.35 MM)
14012741 SHIM, DIFF BRG (6.40 MM)
14012742 SHIM, DIFF BRG (6.45 MM)
14012743 SHIM, DIFF BRG (6.50 MM)
14012752 SHIM, DIFF BRG (6.55 MM)
14012675 BOLT, DIFF BRG CAP (PART OF 18) (M12X1.75X74)
22849885 DIFFERENTIAL, (SEE GROUP 05.000 "AXLE ASM/REAR LOCKING DIFFERENTIAL" FOR DETAILED ILLUSTRATED VIEW) (W/GEARS)
14012753 NUT, DIFF BRG ADJ (M86X1.5)
14012707 LOCK, DIFF BRG ADJ NUT (5.537)
11515755 BOLT, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (DIFF BRG ADJ NUT LK) (T/W 12345493 REPLCS 25534835)
88965784 GEAR KIT, DIFF RING & PINION (INCLS 6, 24, 25, 29, 37, 39)
(TC05-955) 2010-2011 CK1(06-36) КОЛЕСА (CADILLAC Z75)
teamcadillac.ru
09595459 WHEEL, 18X8 (ALUM) (MACHINED)
19209740 WEIGHT, WHL BAL (CLIP-ON REPLACEMENT) (TRIM AS REQUIRED) (WHL BAL)
09595174 NUT, WHL (M14X1.5) (NON-DECORATIVE LARGE CONE)
09595473 CAP, HUB (PLASTIC)
25858636 CAP, TIRE PRESS IND SEN (BLACK) (ACDelco #25858636)
20923680 SENSOR, TIRE PRESS IND (SEE GROUP 05.000 "TIRE VALVE STEM & PRESSURE SENSOR" FOR DETAILED ILLUSTRATED VIEW) (INCLS 5) (SNAP IN) (INCLS BLACK VALVE CAP) (ACDelco #20923680) (ALL NON HIGH-PERF APPS PREV SERV'D W/MET STEM NOW SERV'D W/RUB STEM)
09598755 WHEEL, 22X9.0 (ALUM) (31MM O/S 139.7X6XM14 B/C) (CHROME)
88966249 WHEEL, 22X9.0 (ALUM) (INCLS 1 WHL 88966249 & TAG) (SINGLE 20.8KGS) (INSTALL .25) (ALUM) (CHROME) (5.803)
09596007 CAP, HUB (PLASTIC)
09598677 CAP, HUB (EMBLEM WREATH & CREST ARE PAINTED) (USED ON WHEEL W/OUT ALIGNMENT NOTCH)
09597224 WHEEL, 22X9.0 (ALUM) (31MM O/S 139.7X6 B/C) (CHROME)
(TX05-059) 2009-2013 CK1(06-36) ОСЬ ЗАДНЯЯ В СБОРЕ 8.625 RING GEAR PART 2 DIFFERENTIAL/LOCKING(G80,EXC (AXN))
25902687 DIFFERENTIAL, (INCLS 2-19) (W/GEARS)
25909882 BUSHING, LKG DIFF LOCKOUT (40MM)
12471532 WASHER, DIFF P/GR THR (.820 I.D.X1.69 O.D.) (EATON EDS-89189, .06 LIP)
15599623 GUIDE, LKG DIFF CLU DISC (PART OF 10) (WIDTH .93 INCH)
14063581 SHIM, DIFF SI GR (.010 THK) (BELL END)
14063582 SHIM, DIFF SI GR (.015 THK) (BELL END)
14063583 SHIM, DIFF SI GR (.020 THK) (BELL END)
14063584 SHIM, DIFF SI GR (.025 THK) (BELL END)
14063585 SHIM, DIFF SI GR (.030 THK) (BELL END)
14063586 SHIM, DIFF SI GR (.035 THK) (BELL END)
14063587 SHIM, DIFF SI GR (.040 THK) (BELL END)
14063588 SHIM, DIFF SI GR (.045 THK) (BELL END)
26045829 DISC SET, LKG DIFF CLU (INCLS 8) (EATON EDS-29996)
12471530 GOVERNOR KIT, LKG DIFF (EATON EDS-29672) (INCLS BRKT)
12471393 BLOCK, LKG DIFF THR (PURPLE) (1.322" THK)
12471394 BLOCK, LKG DIFF THR (WHITE) (1.326" THK)
12471395 BLOCK, LKG DIFF THR (BROWN) (1.330" THK)
12471396 BLOCK, LKG DIFF THR (YELLOW) (1.334" THK)
teamcadillac.ru
12471397 BLOCK, LKG DIFF THR (ORANGE) (1.338" THK)
12471398 BLOCK, LKG DIFF THR (PINK) (1.342" THK)
12471399 BLOCK, LKG DIFF THR (GREEN) (1.346" THK)
12471406 CAM, LKG DIFF (EATON EDS-89096)
12471533 GUIDE, LKG DIFF CLU DISC (PART OF 18) (WIDTH .51 INCH)
09412303 RETAINER, EXT.SNAP RING M46 DIA SHF
26012909 WASHER, LKG DIFF CLU DISC THR (.022 THK)
26012910 WASHER, LKG DIFF CLU DISC THR (.027 THK)
26012911 WASHER, LKG DIFF CLU DISC THR (.032 THK)
26012912 WASHER, LKG DIFF CLU DISC THR (.036 THK)
26012913 WASHER, LKG DIFF CLU DISC THR (.040 THK)
26012914 WASHER, LKG DIFF CLU DISC THR (.044 THK)
26012915 WASHER, LKG DIFF CLU DISC THR (.048 THK)
26012916 WASHER, LKG DIFF CLU DISC THR (.052 THK)
12471404 DISC SET, LKG DIFF CLU (INCLS 15) (EATON EDS- 29534 INCLS WASHER, DISCS & GUIDE)
19180956 GEAR KIT, DIFF SI & PINION (INCLS 6, 7, 13)
(TX05-060) 2009-2013 CK1(06-36) ОСЬ ЗАДНЯЯ В СБОРЕ 9.50 RING GEAR PART 2 DIFFERENTIAL/LOCKING(AXN,G80)
22849885 DIFFERENTIAL, (INCLS 2-19) (W/GEARS)
14039025 SHAFT, DIFF P/GR (144.78 MM)
14048409 BUSHING, LKG DIFF LOCKOUT (30MM) (EATON EDS-98648)
12337979 BOLT, DIFF P/GR SHF (LOCK) (M10X1.5X59) (CONTAINS 10 LOCK SCREWS)
14039026 WASHER, DIFF P/GR THR (DOME STYLE)
00462787 GUIDE, LKG DIFF CLU DISC (PART OF 10) (WIDTH .71 INCH)
15599626 SHIM, DIFF SI GR (.010 THK)
15599627 SHIM, DIFF SI GR (.015 THK)
15599628 SHIM, DIFF SI GR (.020 THK)
15599629 SHIM, DIFF SI GR (.025 THK)
15599630 SHIM, DIFF SI GR (.030 THK)
15599631 SHIM, DIFF SI GR (.035 THK)
15599632 SHIM, DIFF SI GR (.040 THK)
15599633 SHIM, DIFF SI GR (.045 THK)
12471390 DISC SET, LKG DIFF CLU (INCLS 8) (EATON EDS-29565)
14048384 GOVERNOR KIT, LKG DIFF (EATON EDS-27811) (INCLS BRKT)
14039028 BLOCK, LKG DIFF THR (BLUE) (1.594" THK)
14039029 BLOCK, LKG DIFF THR (GRAY) (1.598" THK)
14039031 BLOCK, LKG DIFF THR (YELLOW) (1.610" THK)
teamcadillac.ru
14039033 BLOCK, LKG DIFF THR (BROWN) (1.622" THK)
15599672 BLOCK, LKG DIFF THR (WHITE) (1.602" THK)
15599673 BLOCK, LKG DIFF THR (PURPLE) (1.606" THK)
15599675 BLOCK, LKG DIFF THR (ORANGE) (1.614" THK)
15599676 BLOCK, LKG DIFF THR (PINK) (1.618" THK)
12471411 CAM, LKG DIFF
15599623 GUIDE, LKG DIFF CLU DISC (PART OF 18) (WIDTH .93 INCH)
00462786 SLEEVE, LKG DIFF SI GR THR
00462769 WASHER, LKG DIFF CLU DISC THR (.027 THK)
00462770 WASHER, LKG DIFF CLU DISC THR (.037 THK)
00462771 WASHER, LKG DIFF CLU DISC THR (.042 THK)
00462772 WASHER, LKG DIFF CLU DISC THR (.048 THK)
14039035 WASHER, LKG DIFF CLU DISC THR (.022 THK)
14039036 WASHER, LKG DIFF CLU DISC THR (.032 THK)
14039037 WASHER, LKG DIFF CLU DISC THR (.040 THK)
14039038 WASHER, LKG DIFF CLU DISC THR (.044 THK)
14039039 WASHER, LKG DIFF CLU DISC THR (.052 THK)
12471408 DISC SET, LKG DIFF CLU (INCLS 15) (EATON EDS-29566)
12471409 GEAR KIT, DIFF SI & PINION (INCLS 6, 7, 13)
(TX05-061) 2010-2013 K107(06) КАРДАННЫЙ ВАЛ (ONE PIECE) (6L80 AUTOMATIC MYC)
22845689 SHAFT, PROP (INCLS 2-4) (CODE AACX AAK7 AALN AAMK ST5 SX4)
teamcadillac.ru
88964470 YOKE, PROP SHF SLIP (WHEN REPLACING A PROP SHAFT SLIP YOKE, A NEW PROP SHAFT JOINT KIT (5.548) MUST ALSO BE USED) (PART OF 1) (32 TOOTH, 1355 JOINT, NICKEL PLATED)
89059111 JOINT KIT, PROP SHF UNIVERSAL (PART OF 1) (INCLS 4)
(TX05-113) 2007-2010 K1 КАРДАННЫЙ ВАЛ/ПЕРЕДНИЙ МОСТ
22845693 SHAFT, F/AXL PROP (CODE PR1 RR6 5693 7354) (INCLS 2-6)
12479126 JOINT KIT, F/AXL PROP SHF UNIVERSAL (PART OF 1) (INCLS 3) (FOR NON-CANADIAN ORDERS)
01456507 RING, PROP SHF UJT SPIDER BRG RET (PART OF 1, 2) (ID 26.9MM) (5.586)
12471638 YOKE, TRFER CASE F/AXL PROP SHF (USES 12471527 BOOT) (PART OF 1) (HAS FORGING OF 40006884)
26064275 CLAMP, F/AXL PROP SHF SLIP YOKE BOOT (PART OF 1, 6) (165.3) (3 SLOTS) (5.586)
teamcadillac.ru
12471527 BOOT KIT, F/AXL PROP SHF SLIP YOKE (PART OF 1) (INCLS 5) (INCLS CLAMPS) (DOUBLE CLAMP BOOT) (5.586)
06 - ПЕРЕДНИЙ МОСТ-ПЕРЕДНЯЯ ПОДВЕСКА-РУЛЕВОЕ УПРАВЛЕНИЕ
(TC06-899) 2008-2013 CK1 РУЛЕВОЙ МЕХАНИЗМ В СБОРЕ (EXC HYBRID HP2)
19207492 GEAR KIT, STRG (INCLS 2-11, 14-18) (REMANUFACTURED-NOT FOR SALE WHERE IMPORTS ARE RESTRICTED) (ACDelco #19207492)
19167837 PIPE KIT, S/GR (PART OF 1) (INCLS 5) (LT) (HAS FEMALE THREADS ON FITTING)
19167838 PIPE KIT, S/GR (PART OF 1) (INCLS 5) (RT) (HAS FEMALE THREADS ON FITTING)
teamcadillac.ru
26081619 SEAL, S/GR PIPE (O RING) (PART OF 1-3) (6.00MM)
26048003 SEAL, S/GR STUB SHF DUST (PART OF 1) (61MM X 17.6MM) (6.242)
07828017 RING, S/GR STUB SHF SEAL RET (PART OF 1) (R&P)
15776969 SEAL, S/GR STUB SHF (PART OF 1)
11562064 CLAMP, CRIMP, 66.4 DIA, 7 WIDTH, STAINLESS STEEL (PART OF 1, 10, 15)
15254057 BOOT KIT, S/GR (INCLS 9, 11) (PART OF 1) (EXC TWO MODE HYBRID)
11562066 CLAMP, SPRINGBAND, DIA MIN 19.2, MAX 22.86, SAE 1055 STL, GM7111M (PART OF 1, 10)
11516074 NUT, STRG LNKG OTR TIE ROD (PART OF 13) (HEX M14X2X13) (8.917)
15254061 ROD KIT, STRG LNKG OTR TIE (INCLS 12) (EXC TWO-MODE HYBRID)
11562065 NUT, STRG LNKG INR TIE ROD (PART OF 1, 15) (M16X1.5, 11THK) (8.915) (EXC TWO MODE HYBRID)
19178561 ROD KIT, STRG LNKG INR TIE (INCLS 9, 14) (PART OF 1) (EXC TWO-MODE HYBRID)
26100863 SEAL, P/S GR INL HOSE (O RING) (PART OF 1) (13.83 OD 1.0 THK) (TAPERED END) (6.824)
(TC06-900) 2007-2013 K1 КРЕПЛЕНИЕ ПРИВОДНОГО ВАЛА/ПЕРЕДНЯЯ ЧАСТЬ
teamcadillac.ru
15201933 BRACKET, FRT DIFF CARR (SEE GROUP 07.000 "FRAME" FOR DETAILED ILLUSTRATED VIEW)
11519538 BOLT, FRT DIFF CARR (M12X1.75X45.8, 28THD) (18 DRIVER SIZE) (8.900)
11562485 NUT, FRT DIFF CARR BRKT (HF M12X1.75X14, 34 OD)
11610231 WASHER, FLAT, 15X32X4.45, SAE 1050-1080 STL, HRC 40-45, GMW3179 (FRT DIFF CARR BRKT)
11561577 BOLT, FRT DIFF CARR BRKT (BOLT - HFH, M12X1.75X95, 30 THD, 26.6 OD, 10.9, GMW3359, ADH 6175M) (8.900)
15201932 BRACKET, FRT DIFF CARR (SEE GROUP 07.000 "FRAME" FOR DETAILED ILLUSTRATED VIEW)
11516078 NUT, FRT DIFF CARR BRKT (M12X1.75X14THK, 25 OD) (8.917)
15847253 SHIELD, FRM FRT HT
11517560 SCREW, FLAT WA (NRW) AND HX WA HD, M8X1.25X25 (FRM FRT H/SHLD)
(TC06-901) 2010 K1 ТРУБКА ВЕНТИЛЯЦИИ ПЕРЕДНЕГО МОСТА(1ST DES)
teamcadillac.ru
20830620 HOSE, F/AXL VENT (INCLS 2, 3, 5)
15743069 VENT, F/AXL (PART OF 1) (5.387)
12471619 CONNECTOR, FRT DIFF CARR VENT HOSE
(TC06-904) 2007-2013 K1 КОРПУС ДИФФЕРЕНЦИАЛА/ПЕРЕДНИЙ МОСТ PART 1 ASSEMBLY (ALL WHEEL DRIVE NR3)
teamcadillac.ru
22761724 AXLE, FRT (3.42 RATIO) (CODE ZW5, CB8)
(TC06-906) 2007-2013 CK1 ПОДВЕСКА ПЕРЕДНЯЯ
25812726 ARM, FRT UPR CONT (INCLS 4) (INCLS BALL JOINT)
25812725 ARM, FRT UPR CONT (INCLS 4) (INCLS BALL JOINT)
15538598 NUT, FRT UPR CONT ARM (14X2X15)
15741217 CAM, FRT UPR CONT ARM ADJ
15727765 BUSHING, FRT UPR CONT ARM (PART OF 1) (ACDelco #15727765)
15654866 BOLT, FRT UPR CONT ARM (M14X2X100, 30THD, 10.9)
11561435 NUT, HFH LOCK, M10X1.5X20, 28 OD, 10, 7111M, ALL METAL PREV TORQ (FRT S/ABS)
03537772 NUT, FRT UPR CONT ARM BALL STUD (M12X1.75, 10.6 THK) (HEX W/CON WA, 28.0 OD) (8.917)
11516383 NUT, FRT LWR CONT ARM BALL STUD (M16X2X18.9, 18.2 THK) (*KIT3) (8.917)
teamcadillac.ru
20869201 ARM, FRT LWR CONT (INCLS 14, 17, 22) (USED ON VEHICLES WITH CAST IRON ARMS)
20869202 ARM, FRT LWR CONT (INCLS 14, 17, 22) (USED ON VEHICLES WITH CAST IRON ARMS)
25997509 ARM, FRT LWR CONT (INCLS 14, 17, 22) (USED ON VEHICLES WITH ALUMINUM ARMS)
25997510 ARM, FRT LWR CONT (INCLS 14, 17, 22) (USED ON VEHICLES WITH ALUMINUM ARMS)
11516133 NUT, FRT LWR CONT ARM (M16X2X15) (NUT ONLY) (8.917)
15567836 WASHER, FRT LWR CONT ARM (16.38IDX23.87ODX3.27) (6.168)
11561429 NUT, FRT S/ABS (M10X1.5) (PREV TORQUE CLIP)
15733533 BOLT, FRT LWR CONT ARM (M16X2.0X118, 60 THD)
11610404 BOLT, HEX W/CON WA, M10X1.5X75, 66.35THD, 20 OD, 10.9, GMW3359, M-PT (FRT S/ABS)
10369554 SHAFT, FRT STAB (36MM) (WHEN USING THIS TO REPLACE 32MM OR 34MM BAR USE T/W 15124516)
15252732 SHAFT, FRT STAB
11609701 BOLT, HFH, M10X1.5X60, 49 THD, 17.08 OD, 6202M STL, GMW3179-G, TAPPING (FRT STAB SHF)
11570935 CLAMP, FRT STAB SHF (WHEN USING NEW CLAMP 11570935 USE BOLT # 11570934)
15124516 INSULATOR, FRT STAB SHF (USE WITH 36 MM SHAFT)
15733534 BOLT, FRT LWR CONT ARM (M16X2.0X140, 52 THD)
11516885 SCREW, HFH W/FL WA, TAP, M8X1.25X20, 7THD, 17 O.D., TR PT, 6202M, PZOR (ELEK SUSP FRT POSN SEN BRKT)
15098628 SENSOR, ELEK SUSP FRT POSN (INCLS 38, 39)
15098629 SENSOR, ELEK SUSP FRT POSN (INCLS 38, 39)
11609404 STUD, ELEK SUSP FRT POSN SEN LINK BALL (M6X1X9.5) (HEX, 8 DIA BALL STYLE)
11509419 BOLT, M10X1.5X25 (FRT WHL DRV SHF)
20909191 SHAFT, FRT WHL DRV (SEE GROUP 06.000 "DRIVE SHAFT/FRONT WHEEL" FOR DETAILED ILLUSTRATED VIEW) (ACDelco #20909191)
15522089 WASHER, FRT WHL DRV SHF (24 DIA, 5.4 THK) (6.063)
11609826 NUT, FRT WHL DRV SHF (M24X2X22)
25379115 LINK, ELEK SUSP FRT POSN SEN (PART OF 31)
25918049 LINK, FRT STAB SHF (INCLS 10-12, 23, 25)
19209396 STUD KIT, FRT LWR CONT ARM BALL (INCLS 9, 14) (STUD SIZE 121X61) (THIS PART IS FOR CAST IRON LCA ONLY)
19256481 STUD KIT, FRT LWR CONT ARM BALL (THIS PART IS FOR ALUMINUM LCA ONLY) (INCLS 9, 14) (STUD SIZE 126X61)
(TC06-907) 2008-2013 CK1 СИСТЕМА РУЛЕВОГО УПРАВЛЕНИЯ И СВЯЗАННЫЕ ДЕТАЛИ (EXC HYBRID HP2)
11517996 NUT, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (STRG COL) (ACDelco #11517996)
21011332 NUT, HEX STAMPED TY DF FLG 14 (STRG COL SEAL) (8.921)
25815601 SEAL, STRG COL (145.2MM LONG)
25862789 SHAFT, S/GR CPLG (INCLS 6-11)
15017238 NUT, S/GR CPLG (PART OF 5) (M10X1.5 6H, 21.5 OD) (W/PREVAILING TORQ FLANGE)
11515768 BOLT, S/GR CPLG (PART OF 5) (M10X1.5X40, 30THD) (8.900)
11561800 CLAMP, CRIMP, 33.5 DIA, 304 STAINLESS STEEL (PART OF 5)
11561799 CLAMP, DIA 69.7, 304 STAINLESS STEEL (PART OF 5)
11609743 BOLT, S/GR CPLG (USED ON LWR SHAFT) (M10X1.5X31, 12.3THD) (HEX CHROME FREE) (8.900)
11516074 NUT, HEX M14X2X13 (STRG LNKG OTR TIE ROD)
11609229 BOLT, S/GR (M16X2X172, 57THD) (W/ADHESIVE)
11569939 BOLT, S/GR (M12X1.75X50, 33THD)
88965503 BOLT, S/GR CPLG (M5X2.2X20, 30THD) (20.8 OD)
11514597 NUT, S/GR CPLG (M10X1.5 6H, 21.8OD) (2.383)
14074908 WASHER, STRG COL (.460 X1.12 X.180 PL) (6.509)
(TC06-911) 2007-2012 CK1 РУЛЕВОЕ КОЛЕСО (WOOD TRIM N30, EXC HEATED KA9)
22947788 WHEEL, STRG (INCLS 2-5, 7-9) (COCOA)
22947792 WHEEL, STRG (INCLS 2-5, 7-9) (COCOA)
25853073 WHEEL, STRG (INCLS 2-5, 7-9) (EBONY)
25853074 WHEEL, STRG (INCLS 2-5, 7-9) (COCOA)
25853065 WHEEL, STRG (INCLS 2-5, 7-9) (EBONY)
25853066 WHEEL, STRG (INCLS 2-5, 7-9) (COCOA)
25851952 SWITCH, RDO CONT (PART OF 1) (EBONY)
25851956 SWITCH, RDO CONT (PART OF 1) (COCOA)
25851952 SWITCH, RDO CONT (PART OF 1) (EBONY) (9.649)
25826421 COVER, STRG WHL SPOKE LWR (PART OF 1) (SOLITARE)
15255102 COVER, STRG WHL SPOKE LWR (PART OF 1) (TRINITY)
15257875 BOLT, STRG WHL LWR CVR (PART OF 1) (M3.63-1.34X10MM) (SPECIAL TORX PLUS (15 IP) PAN HEAD)
15255031 CONTACT, STRG WHL HORN (PART OF 1)
25917968 AIRBAG, STRG WHL (EBONY) (LABELED 25917968) (DUAL LEVEL) (INCLS NON-SERVICE CABLE EMBLEM)
25917969 AIRBAG, STRG WHL (COCOA) (LABELED 25917969) (DUAL LEVEL)
15255100 COVER, STRG WHL SPOKE LWR (PART OF 1) (TRINITY)
15824109 SWITCH, CRCONT (PART OF 1) (EBONY) (ACDelco #D1958E)
15824106 SWITCH, CRCONT (PART OF 1) (COCOA) (ACDelco #15824106)
teamcadillac.ru
11609658 NUT, STRG WHL (M14X1.5-6H THD) (NON-FLANGED NYLON INSERT HEX) (6.518)
(TC06-911) 2008-2013 CK1,2,3 РУЛЕВОЕ КОЛЕСО (LEATHER WRAPPED NP5, ACCESSORY CONTROLS UK3, EXC HYBRID HP2)
25853085 WHEEL, STRG (INCLS 2-5, 7-9) (CASHMERE) (HAS THE WORD "SET" ON LH SWITCH)
25851954 SWITCH, RDO CONT (PART OF 1) (CASHMERE) (9.649)
25824700 COVER, STRG WHL SPOKE LWR (PART OF 1) (METAL BRUSH)
15255034 COVER, STRG WHL SPOKE LWR (PART OF 1) (EBONY)
25824698 COVER, STRG WHL SPOKE LWR (PART OF 1) (METAL BRUSH)
15824108 SWITCH, CRCONT (PART OF 1) (VR DK CASHME) (ACDelco #15824108)
teamcadillac.ru
(TC06-912) 2007-2012 CK1 РУЛЕВОЕ КОЛЕСО (WOOD TRIM N30, HEATED KA9)
25853076 WHEEL, STRG (INCLS 2-5, 7-9) (EBONY)
25853077 WHEEL, STRG (INCLS 2-5, 7-9) (COCOA)
25853096 WHEEL, STRG (INCLS 2-5, 7-9) (COCOA)
20777676 WHEEL, STRG (INCLS 2-5, 7-9) (COCOA)
25851956 SWITCH, RDO CONT (PART OF 1) (COCOA) (9.649)
teamcadillac.ru
25784920 AIRBAG, STRG WHL (COCOA) (DUAL LEVEL)
25826420 COVER, STRG WHL SPOKE LWR (PART OF 1) (SOLITARE)
15824110 SWITCH, CRCONT (PART OF 1) (COCOA) (ACDelco #15824110)
15824112 SWITCH, CRCONT (PART OF 1) (EBONY) (ACDelco #D1959E)
(TC06-913) 2008-2013 CK1 МАГИСТРАЛИ НАСОСА РУЛЕВОГО УПРАВЛЕНИЯ (EXC HYBRID HP2)
25858603 HOSE, P/S GR INL (INCLS 2, 3)
26001594 SEAL, P/S GR INL HOSE (O RING) (PART OF 1) (7.65MM IDX1.63MM THK)
11562063 BOLT, HFH, M6X1X25, 18 THD, 12.8 OD, 9.8 STL, HEX CHROME FREE, SN-ZN. (PART OF 1)
26100863 SEAL, P/S GR OTLT HOSE (O-RING) (13.83 OD 1.0 THK) (TAPERED END) (6.824)
11571140 CLAMP, SPRINGBAND, 16 DIA, 15 WIDTH, STL PER GM6298M, GMW14083 (PART OF 7)
teamcadillac.ru
25918689 COOLER, P/S FLUID (INCLS 6)
11589039 BOLT, HEX, W/CON WA, M6X1X30, 20 THD, 24 O.D., 9.8, GMW4205 (P/S FLUID CLR)
11571140 CLAMP, SPRINGBAND, 16 DIA, 15 WIDTH, STL PER GM6298M, GMW14083 (PART OF 10)
15812565 HOSE, P/S GR OTLT (INCLS 9)
11589398 BOLT, HEX HD, W/CON WA, M6X1X30, 18.11 THD, 24 O.D., 9.8, GMW3179, BLACK (P/S FLUID CLR)
(TC06-914) 2007-2013 K1 ПРИВОДНОЙ ВАЛ/FRONT WHEEL
20909191 SHAFT, FRT WHL DRV (INCLS 2-16) (ACDelco #20909191)
26056803 RING, FRT WHL DRV SHF TRI-POT JT SPIDER RET (PART OF 1, 4, 6) (6.056)
15295245 JOINT, FRT WHL DRV SHF TRI-POT (INCLS 3 (PART OF 1) (MUST ALSO ORDER APPROPRIATE BOOT KIT)
26056789 CLAMP, FRT WHL DRV SHF TRI-POT JT BOOT OTR (PART OF 1, 6)
19256072 BOOT KIT, FRT WHL DRV SHF TRI-POT JT (INCLS 3, 5, 7 (PART OF 1) (USED ON VEH W/TRI-POT BOOT STAMPED 26145893) (FOR 1ST DES SEE 26062615)
26062615 BOOT KIT, FRT WHL DRV SHF TRI-POT JT (INCLS 3, 5, 7 (PART OF 1) (USED ON VEH W/TRI-POT BOOT STAMPED 26062615 OR 26061462) (FOR 2ND DES SEE 19256072)
07849180 CLAMP, FRT WHL DRV SHF TRI-POT JT BOOT INR (PART OF 1, 6) (ID 36.4MM, 7MM THK) (6.060)
teamcadillac.ru
26051466 CLAMP, FRT WHL DRV SHF TRI-POT JT BOOT INR (PART OF 1, 6) (35MM ID, 10MM THK) (SAGINAW) (CRIMP STYLE)
07849180 CLAMP, FRT WHL DRV SHF CV JT BOOT INR (PART OF 1, 10) (ID 36.4MM, 7MM THK) (6.060)
26051466 CLAMP, FRT WHL DRV SHF CV JT BOOT INR (PART OF 1, 10) (35MM ID, 10MM THK) (SAGINAW) (CRIMP STYLE)
15868187 BOOT KIT, FRT WHL DRV SHF CV JT (INCLS 9, 11, 12 (PART OF 1)
26007601 CLAMP, FRT WHL DRV SHF CV JT BOOT OTR (PART OF 1, 10) (105.91MM DIA) (6.060)
07849284 RING, FRT WHL DRV SHF CV JT INR RACE RET (PART OF 1, 10, 14)
26057639 JOINT, FRT WHL DRV SHF CV (INCLS 12, 13, 15, 16 (PART OF 1) (MUST ALSO ORDER APPROPRIATE BOOT KIT)
(TC06-916) 2010-2011 CK1 НАСОС РУЛЕВОГО УПРАВЛЕНИЯ В СБОРЕ (L20/4.8A,LMG/5.3-0,LC9/5.3-3,L9H/6.2-2,L94/6.2F)
19207053 RESERVOIR KIT, P/S FLUID (INCLS 6, 9-11) (PART OF 12)
26095194 CAP, P/S FLUID RSVR (PART OF 12)
26009574 STUD, P/S FLUID RSVR (PART OF 12) (M10X1.5X16) (SHORT) (6.606)
15241681 STUD, P/S FLUID RSVR (PART OF 12) (LONG)
26025709 FITTING, P/S PUMP (PART OF 12) (*KIT2)
26020642 SEAL, P/S PUMP FTG (O RING) (PART OF 1, 12) (14.5MM I.D.) (*KIT1) (6.635)
26065843 VALVE, P/S PUMP FLOW CONT (PART OF 12) (VALVE ONLY) (*KIT2)
teamcadillac.ru
19133635 SEAL, P/S PUMP RSVR (O RING) (PART OF 1, 12) (113.3MM ID) (BLACK W/WHITE STRIPE) (*KIT1)
20756714 PUMP, P/S (INCLS 1-11, 13, 14) (ACDelco #20756714)
20756716 PUMP, P/S (INCLS 1-11, 13, 14)
15277770 SEAL, P/S PUMP SHF (PART OF 12) (22.78MM I.D.) (USED W/19MM SHAFT)
15825938 SEAL KIT, P/S PUMP (INCLS 6, 9-11) (FRT SEAL NOT INCL)
15246463 VALVE KIT, P/S PUMP FLOW CONT (INCLS 5, 7, 8)
(TC06-926) 2009-2013 CK1(06-43) СИСТЕМА РУЛЕВОГО УПРАВЛЕНИЯ И СВЯЗАННЫЕ ДЕТАЛИ (HYBRID HP2)
15017238 NUT, S/GR CPLG (M10X1.5 6H, 21.5 OD) (W/PREVAILING TORQ FLANGE)
11515768 BOLT, S/GR CPLG (PART OF 7) (M10X1.5X40, 30THD) (8.900)
25979050 SHAFT, S/GR CPLG (INCLS 6, 8-13)
15017238 NUT, S/GR CPLG (PART OF 7) (M10X1.5 6H, 21.5 OD) (W/PREVAILING TORQ FLANGE)
11561800 CLAMP, CRIMP, 33.5 DIA, 304 STAINLESS STEEL (PART OF 7, 12)
19177403 BOOT KIT, INTER STRG SHF (PART OF 7) (INCLS 11, 13)
11561799 CLAMP, DIA 69.7, 304 STAINLESS STEEL (PART OF 7, 12)
11610555 BOLT, S/GR CPLG (M10X1.5X31) (11MM SOC HEADER PT)
teamcadillac.ru
11518341 BOLT, HEX, M10X1.5X25, 14 THD, 28 OD, 6202M, 7114M, TAP, TR-PT (STRG LNKG SHLD)
15847584 SHIELD, STRG LNKG
25813638 LABEL, P/S FLUID VOLTAGE CAUTION (PART OF 22) (TWO-MODE HYBRID)
25962338 MODULE, ELEK P/S MOT CONT (INCLS 21)
11900241 BOLT, P/S CONT MDL (M6X1.0X12) (3.602)
12636016 MODULE, DRV MOT GEN PWR INV (SEE GROUP 02.000 "CONTROL MODULE ASM/DRIVE MOTOR" FOR DETAILED ILLUSTRATED VIEW)
(TC06-927) 2009-2013 CK1(06-43) РУЛЕВОЙ МЕХАНИЗМ В СБОРЕ (HYBRID HP2)
20870559 GEAR, STRG (INCLS 2, 3, 6-18) (LESS OUTER TIE ROD ENDS) (INCLS P/S ASST MOTOR AND ALL CPS)
15895647 ROD KIT, STRG LNKG INR TIE (PART OF 1) (INCLS 6, 7, 9) (TWO-MODE HYBRID)
teamcadillac.ru
11516074 NUT, STRG LNKG OTR TIE ROD (PART OF 5) (HEX M14X2X13) (8.917)
15895646 ROD KIT, STRG LNKG OTR TIE (INCLS 4) (TWO-MODE HYBRID)
11562407 NUT, STRG LNKG INR TIE ROD (PART OF 1, 3) (M16X1.5, 13THK, 6T THD)
11570615 CLAMP, HOSE SPRINGBAND, 26 NOMINAL DIA, 15 THK, STL, ROBO (PART OF 1, 3, 8)
15895648 BOOT KIT, S/GR (PART OF 1) (INCLS 7, 9) (TWO-MODE HYBRID)
22913281 CLAMP, S/GR BOOT (PART OF 1, 3, 8)
11569910 BOLT, P/S ASST MOT (PART OF 1, 11) (M8X1.25X25, 20THD)
19210914 HARNESS KIT, P/S WRG (PART OF 1) (INCLS 10, 12-18) (HAS PLASTIC COVER AT MOTOR CONNECTOR) (FOR 1ST DESIGN SEE 19210915)
19210915 MOTOR KIT, P/S ASST (PART OF 1) (INCLS 10, 12-18) (HAS TAPE AT MOTOR CONNECTOR) (FOR 2ND DESIGN SEE 19210914)
15895637 SEAL, P/S ASST MOT (PART OF 1, 11)
25813638 LABEL, P/S FLUID VOLTAGE CAUTION (PART OF 1, 11) (TWO-MODE HYBRID)
11570589 STRAP, WRG HARN (EDGE CLIP) (PART OF 1, 11) (PA66 BLACK, 200 LENGTH)
12355066 STRAP, PLASTIC ADJ TIE (215MM LG) (PART OF 1, 11) (8.965) (ACDelco #16TS825)
11569906 STRAP, WRG HARN (PART OF 1, 11) (FITS 11 DIA HOLE, 140 LENGTH, POLYPROPYLENE)
11569907 STRAP, WRG HARN (TRIPLE CLIP) (PART OF 1, 11) (FITS HOLE 6.35 DIA, HOLDS TWO LINE DIA 10.6)
(TC06-929) 2009-2013 CK1(06-43) РУЛЕВОЕ КОЛЕСО (HYBRID HP2, LEATHER WRAPPED NP5, ACCESSORY CONTROLS UK3)
25853080 WHEEL, STRG (INCLS 2-5, 7-9) (CASHMERE)
teamcadillac.ru
11570668 BOLT, STRG WHL VIB DPNR (M6X2X15, 12OD) (PAN HEAD, SELF TAPPING) (6.512)
(TC06-930) 2009-2013 CK1(06-36) РУЛЕВАЯ КОЛОНКА (CADILLAC Z75)
25797756 SHROUD, STRG COL (INCLS 27) (COCOA)
25797755 SHROUD, STRG COL (INCLS 27) (EBONY)
22738087 MODULE, THEFT DTRNT (ACDelco #22738087)
26088811 CASE, IGN LK CYL (EXCEPT LK ACTUATOR & PASS SENSOR) (PASS KEY) (PART OF 43)
26036497 BOLT, STRG COL LWR TR CVR (PART OF 43) (M5X.8X15) (TRILOBULAR THREAD TWIN HELIX) (T-25 TORX RECESS) (6.760)
26082804 RETAINER, A/TRNS PARK LK CBL
teamcadillac.ru
26036496 BOLT, STRG COL UPR CVR (M4.55 TAP X15) (2.188)
25733005 SWITCH, IGN & START (ACDelco #D1485F)
26001827 BEARING KIT, STRG SHF UPR (PART OF 43) (STRG COL INR W/RACE)
15231641 SEAT, STRG SHF UPR BRG RACE (PART OF 43)
26055299 SPRING, STRG SHF UPR BRG (PART OF 43)
15775848 CAM, T/SIG SW CANC (PART OF 43)
26094767 PLATE, STRG SHF LK (PART OF 43) (W/O SHIELD)
26090892 PLATE, STRG SHF LK (PART OF 43) (W/ SHIELD)
26049186 PLATE, T/SIG SW CANC CAM POSN (W/SHIELD) (6.521)
05694191 RING, STRG SHF LK PLT RET (PART OF 43) (6.524)
26011609 WASHER, STRG WHL AIRBAG COIL (14.865)
25966964 COIL, STRG WHL AIRBAG (W/ACSRY CNCT)
25966963 COIL, STRG WHL AIRBAG (W/ACSRY CNCT)
00274414 RING, EXT, SNAP, FITS M19 OR.75" SHAFT, STL, PL (STRG WHL AIRBAG COIL RET)
15849314 SWITCH, T/SIG & HDLP & HDLP DIMR & WSW & WSWA (INCLUDES HAZARD BUTTON) (W/RR WIPER) (ACDelco #D6224E)
26036497 BOLT, HDLP DIMR & T/SIG SW (M5X.8X15) (TRILOBULAR THREAD TWIN HELIX) (T-25 TORX RECESS) (6.760)
26036327 PIN, STRG WHL LK (PART OF 43)
26061342 PIN, STRG WHL LK (PART OF 43)
26034514 SPRING, STRG WHL LK PIN (PART OF 43) (43MM)
25797751 HARNESS, STRG COL WRG
26036521 PIN, STRG COL PIV (PART OF 43)
11561801 STRAP, WRG HARN (HOLDS TUBE DIA 60MM) (ACDelco #11561801)
15775835 SEAL, A/TRNS CONT LVR
25797681 SWITCH, STRG COL TILT WHL
26104379 SCREW, FLAT HEAD W/SHLDR, M5X0.8X12, 7 THD, 9.3 OD, GM6171M STL, TAP (STRG COL HSG CVR)
26078026 CABLE, STRG COL TILT WHL ACTR (PART OF 31)
25844490 MOTOR, STRG COL TILT WHL ACTR (W/ SEN) (INCLS 30, 32-34)
26064459 BOLT, STRG COL TILT WHL ACTR (PART OF 31) (M4.2X1.59X11.5) (W/WSHR-TORX HD)
11562309 SCREW, OVAL HEAD, 10-24X0.43", GM6010M STL, PHOSPHATE&OIL, TAPPING, W/ADH (STRG COL TILT WHL ACTR BRKT)
25809424 SHAFT, UPR INTER STRG
15775847 CLIP, STRG ANGLE SEN RET
15886733 SENSOR, STRG WHL POSN (6.552) (LABELED 15886733) (FOR 2ND DES SEE 20910871)
20910871 SENSOR, STRG WHL POSN (MATING CONN W/LEADS USE 12101874) (LABELED 20910871) (FOR 1ST DES SEE 15886733) (FOR 3RD DES SEE 25855607)
15775851 ADAPTER, STRG SHF LWR BRG (PART OF 43) (INCLS LOWER BEARING)
25798016 COLUMN, STRG (INCLS 3, 4, 8-12, 14, 21, 22, 24, 39, 42, 44)
11562309 SCREW, OVAL HEAD, 10-24X0.43", GM6010M STL, PHOSPHATE&OIL, TAPPING, W/ADH (PART OF 43)
15775841 SOLENOID, A/TRNS SHFT LK CONT (ACDelco #15775841)
22833056 CONTROL, A/TRNS
26035516 BOLT, A/TRNS SHFT LK CONT SOL
26086318 BOLT, A/TRNS CONT LVR (M6X1X13)
25807853 LEVER, A/TRNS CONT (1/16" ELECTRICAL TOW CONNECTOR PIN)
25807855 LEVER, A/TRNS CONT (1/16" ELECTRICAL TOW CONNECTOR PIN)
(TC06-932) 2008-2013 K1 КОРПУС ДИФФЕРЕНЦИАЛА/ПЕРЕДНИЙ МОСТ PART 2 (ALL WHEEL DRIVE NR3)
15801498 SHAFT, FRT DRV AXLE INR
22761722 SEAL, FRT DRV AXLE INR SHF
26066885 BEARING, FRT DRV AXLE INR SHF (USED ON HOUSING) (6.008) (ACDelco #26066885)
15270855 HOUSING, FRT DRV AXLE INR SHF
15270970 GASKET, FRT WHL DRV INTER SHF HSG
26036835 BOLT, FRT DRV AXLE INR SHF HSG (W/WA 20 OD, M10X1.5X34.9)
22761723 CARRIER, FRT DIFF (INCLS PINS AND BOLTS) (W/O T-CLIP ADJSTR LOCK) (FOR AXLE CODES HU5, HU6, HU7, HU8, XP1, XP3, XP4, XP5 ZW6 W/T-CLIP ADJSTR MUST ORDER 2 OF 15876532 & 15876533)
00360570 PIN, FRT DIFF HALF CARR LOC (0.685)
15270969 GASKET, FRT DIFF CARR
15876533 LOCK, FRT DIFF BRG ADJR NUT
15876532 ADJUSTER, FRT DIFF BRG (INCLS 13)
20997053 BEARING, FRT DIFF (INCLS CUP AND CONE, TIMKEN, LM501349-LM501314, 41.28MM ID X 73.42MM OD X 21.43MM THK) (ACDelco #S13)
11610549 BOLT, FRT DIFF R/GR (7/16-20) (*KIT2)
26063838 WASHER, FRT DIFF SI GR THR (69MM OD, 40ID, .77THK) (*KIT1)
12479372 RING, FRT DRV AXLE INR SHF RET
26056600 RING, FRT DRV AXLE INR SHF RET
15588350 WASHER, FRT DIFF P/GR THR (CURVE STYLE WASHER) (51.6MM O.D., 20.27MM I.D.) (*KIT1)
25824249 SHAFT, FRT DIFF P/GR (124.84 MM) (*KIT1)
15801501 CASE, FRT DIFF (LESS INTERNAL GEARS)
09428890 PIN, SPRING TYPE S HOLE DIA-1/4, LENGTH 1 3/4, STEEL PL (FRT DIFF P/GR SHF LK) (*KIT1)
26041515 BEARING, FRT DRV AXLE INR SHF (USED ON ADJUSTER) (ACDelco #26041515)
15286375 BEARING, FRT DIFF DRV P/GR INR (INCLS CUP AND CONE) (5.484) (ACDelco #S1371)
12479162 SPACER, FRT DIFF DRV P/GR BRG (.062-.068" THK) (*KIT2) (5.453)
15842651 PIN, FRT DIFF CASE
12471621 GASKET, FRT DIFF CARR OIL FIL PLUG (WASHER-FLAT, 36.17 OD, 2.62 THICK, NITRILE POLYMER, BLACK) (5.506)
12471620 PLUG, FRT DIFF CARR OIL FIL (M40 X 1.5)
15588383 GASKET, FRT DIFF CARR OIL DRN PLUG (WASHER, FLAT 24 OD, 14 ID, 2 THK, PLASTIC) (4.195)
26058815 PLUG, FRT DIFF CARR OIL DRN (M12X1.5)
26058813 SHAFT, FRT DRV AXLE INR (5.517)
15286376 BEARING, FRT DIFF DRV P/GR OTR (INCLS CUP AND CONE, TIMKEN, M88048-M88010, 1 5/16 IN ID X 2 11/16 IN OD X 7/8 IN THK) (5.484) (ACDelco #S1372)
12471590 SEAL, FRT DIFF DRV P/GR
teamcadillac.ru
88967027 YOKE, FRT DIFF DRV P/GR
00517900 WASHER, FRT DIFF DRV PINION GR (.890X1.625X.190) (*KIT2) (5.595)
88891763 NUT, FRT DIFF DRV P/GR (M10) (*KIT2) (5.595)
12479318 GEAR KIT, FRT DIFF SI & PINION (INCLS 16-17, 19-21, 23)
19257736 GEAR KIT, FRT DIFF DRV PINION (INCLS 15, 24, 28, 39, 40)
(TC06-936) 2010 K1 ТРУБКА ВЕНТИЛЯЦИИ ПЕРЕДНЕГО МОСТА(2ND DES)
20830620 HOSE, F/AXL VENT (INCLS 2, 4, 5, 7)
teamcadillac.ru
15157936 CLIP, F/AXL VENT HOSE (PART OF 1) (BLACK) (HOLDS 8.75 DIA LINE, NYLON) (5.387)
15355569 CLIP, F/AXL VENT HOSE (PART OF 1) (RETAINING CLIP, HOLDS 8 DIAM LINE, MTL PLASTIC) (5.511)
(TC06-937) 2010 K1 ТРУБКА ВЕНТИЛЯЦИИ ПЕРЕДНЕГО МОСТА(3RD DES)
20830620 HOSE, F/AXL VENT (INCLS 2, 4, 6)
teamcadillac.ru
(TX06-017) 2010-2011 CK1 КРЕПЛЕНИЕ НАСОСА РУЛЕВОГО УПРАВЛЕНИЯ (L20/4.8A,LMG/5.3-0,LC9/5.3-3,L9H/6.2-2,L94/6.2F)
12554030 BRACKET, GEN & P/S PUMP (INCLS 2) (INCLS SPACER)
teamcadillac.ru
12550090 SPACER, GEN & P/S PUMP BRKT (PART OF 1)
11515764 BOLT, HFH, M10X1.5X20, 18THD, 22.3 O.D., 10.9, 7114M (P/S PUMP RR BRKT)
11514597 NUT, HFH, 10X1.5 THD, 9.8 THK, 21.8 OD, 510M (10) ZF 7111M (P/S PUMP RR BRKT) (2.383)
12554032 BRACKET, P/S PUMP RR
12605677 PULLEY, P/S PUMP (PHY ID 4004 & 5677)
11515767 BOLT, HFH, M10X1.5X35, 32THD, 22.3 O.D., MACH, 10.9, 7114M (P/S PUMP) (T/W 12345493)
11519214 BOLT, HFH M10X1.5X115, 30 MM THD, 22.3 OD, 9.8, 7114M, MAT POINT (GEN & P/S PUMP BRKT)
07 - РАМЫ-ПРУЖИНЫ-АМОРТИЗАТОРЫ-БАМПЕРЫ
(TC07-635) 2007-2013 CK1(06-36) ПОДВЕСКА ЗАДНЯЯ PART 1
25871432 ABSORBER, RR LVLG SHK (MATING CONN W/LEADS USE 15305901) (ACDelco #25871432)
19300070 ABSORBER, RR LVLG SHK (BLACK) (ACDelco #580-450)
11611959 BOLT, HEX W/CON WA, M14X2X85, 45 THD, 28 OD, 10.9, GMW3359 (RR S/ABS)
11609243 BOLT, M12X1.75X65 (RR STAB SHF INSL CLA)
15257472 LINK, RR STAB SHF
22809843 SHAFT, RR STAB
11518294 BOLT, HFH, M10X1.5X29.5, 17.08 OD, 6202M, 4435M, TAP, TR-PT (RR STAB SHF INSL CLA)
88891781 CLAMP, RR STAB SHF INSL
11516078 NUT, HFH, M12X1.75, 14THK, 25 O.D., 10, PZOR (RR STAB SHF LINK)
11516382 NUT, HFH LK M14X2X15, 28 OD 10 7111M (RR S/ABS)
14071381 INSULATOR, RR STAB SHF (RUBBER) (28.6MM STAB BAR)
(TC07-676) 2007-2013 CK1,2,3 ЦИЛИНДР ЗАМКА/ЗАПАСНОЕ КОЛЕСО
15926907 KEY, IGN LK (PRE-CUT & PROGRAMMED)
15926908 KEY, IGN LK (PRE-CUT & PRE-PROGRAMED FOR FLEET)
20985619 KEY, IGN (UNCODED) (MASTER)
teamcadillac.ru
25945700 CYLINDER, SPA WHL HOIST LK (INCLS 2-8)
(TC07-902) 2008-2011 CK1(06-36) БАМПЕР ПЕРЕДНИЙ (CADILLAC Z75, EXC PLATINUM EDITION ULT)
15904442 BRACKET, FRT GRL UPR (INCLS 3, 4)
11610055 BOLT, HWASH, M6X1X23 (FRT GRL SUPT REINF)
11518121 NUT, U, M6X1, MULTI THD, .5'-4.0' THK PNL (PART OF 1)
22581725 CLIP, HOOD PRIM LAT REL CBL (PART OF 1) (7.0 MM DIA) (HOLDS (1) PIPE 4.76 TO 6.35) (3.145)
22742861 BRACKET, FRT BPR FASCIA
11610055 BOLT, HWASH, M6X1X23 (FRT BPR FASCIA)
25947497 BAR, FRT BPR IMP (INCLS 13) (W/ AIR DAM BRACES)
teamcadillac.ru
11519154 BOLT, FRT BPR IMP BAR (M14X2X140)
25948814 BRACKET, FRT BPR FASCIA SI (INCLS 10)
25948815 BRACKET, FRT BPR FASCIA SI (INCLS 10)
11518531 NUT, PUSH-IN, M4.2X1.41, 15.9X8.4, .7-2.1 PNL, SAE 1050 STL, 7111M, 8.65 SQ HOL (PART OF 9) (10.512)
11589039 BOLT, HEX, W/CON WA, M6X1X30, 20 THD, 24 O.D., 9.8, GMW4205 (FRT BPR FASCIA SI BRKT)
25857237 BRACKET, FRT BPR LWR IMP BAR (PART OF 7)
25857238 BRACKET, FRT BPR LWR IMP BAR (PART OF 7)
10376177 FILLER, FRT BPR OTR FRT
10376178 FILLER, FRT BPR OTR FRT
11515638 NUT, U-TYPE, M4.2X1.41X10.5.5X22, .65-3.8 PNL THK, 1050, ZF (FRT BPR OTR FRT FIL)
11609385 NUT, U-TYPE, M6X1, 29.5 LEN, 12.5 WID, 19.5 CEN-END, 1050, GMW3359 (FRT BPR LWR FASCIA)
11515638 NUT, U-TYPE, M4.2X1.41X10.5.5X22, .65-3.8 PNL THK, 1050, ZF (FRT OTR A/DFL)
11589015 BOLT, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (FRT OTR A/DFL)
15138234 DEFLECTOR, FRT AIR
11589015 BOLT, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (FRT BPR OTR FRT FIL)
15941065 BRACKET, FRT LIC PLT (PAINT TO MATCH)
22579423 RIVET, FRT LIC PLT BRKT (5 X 25) (10.710)
25814554 FASCIA, FRT BPR (PAINT TO MATCH)
25705182 BOLT, FRT BPR FASCIA CTR SUPT (M9.5X6.0 HI-LO, TL 47MM, 22 OD) (12.249)
15893972 COVER, FRT TOW HOOK OPG
15893973 COVER, FRT TOW HOOK OPG
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (FRT FOG LP)
22920677 SUPPORT, FRT BPR FASCIA
22860587 EMBLEM, FRT GRL (WREATH/CREAST)
11589039 BOLT, HEX, W/CON WA, M6X1X30, 20 THD, 24 O.D., 9.8, GMW4205 (FRT BPR UPR FASCIA)
15078238 RETAINER, FRT GRL (BLACK) (25X15.5) (ALSO REPLACES SILVER)
01605396 RETAINER, PUSH-IN, FITS .250 HOLE, .92 LG.700-OD NYLON BLACK (FRT BPR FASCIA OTR BRKT)
15140153 ATTACHMENT KIT, FRT LIC PLT (INCLS 35)
15993201 RETAINER, FRT LIC PLT BRKT (PART OF 34) (FOR 9.3MM DIA HOLE) (NYLON) (17.505)
(TC07-902) 2009-2013 CK1(06) БАМПЕР ПЕРЕДНИЙ (CADILLAC Z75, PLATINUM EDITION ULT, HEADLAMP T84)
25782363 BRACKET, FRT LIC PLT (PAINT TO MATCH)
25975452 FASCIA, FRT BPR (PAINT TO MATCH)
teamcadillac.ru
(TC07-903) 2008-2013 CK1(06) КРЕПЛЕНИЕ ЗАПАСНОГО КОЛЕСА (EXC HYBRID HP2)
15827206 CASE, SPA WHL LK CYL (7.680)
teamcadillac.ru
25945700 CYLINDER, SPA WHL HOIST LK (SEE GROUP 07.000 "LOCK CYLINDER/SPARE WHEEL" FOR DETAILED ILLUSTRATED VIEW)
15811583 COVER, RR BPR FASCIA ACC HOLE (PAINT TO MATCH)
10372326 GUIDE, SPA WHL HOIST SHF
11517827 BOLT, HFH W/FL WA, M10X1.5X35, 20 THD, 25 OD, 9.8, 7114M, MACH, P-PT, 6175M A (SPA WHL HOIST)
25974846 HOIST, SPA WHL
25974847 HOIST, SPA WHL
11518341 BOLT, HEX, M10X1.5X25, 14 THD, 28 OD, 6202M, 7114M, TAP, TR-PT (SPA WHL H/SHLD)
25783810 SHIELD, SPA WHL HT
(TC07-906) 2007-2011 CK107(06) БАМПЕР ЗАДНИЙ (CADILLAC Z75)
25938524 BAR, RR BPR IMP (INCLS 24, 28) (INCLS TRAILER HITCH RECEIVER)
11518531 NUT, PUSH-IN, M4.2X1.41, 15.9X8.4, .7-2.1 PNL, SAE 1050 STL, 7111M, 8.65 SQ HOL (RR BPR FASCIA) (10.512)
11519537 BOLT, HEX HD, W/CON WA, M12X1.75X40.8, 25.6 THD, 35 O.D., 10.9, GMW3359 (RR BPR IMP BAR)
11610510 NUT, PUSH-IN, M4.2X1.41, 0.7-2.15 PNL THK, SAE 1050-65, GMW3359 W/BLK SEAL (RR BPR FASCIA)
11589015 BOLT, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (RR W/H LNR)
11589292 RETAINER, PUSH-IN, FITS 8.5 DIA HOLE IN 2-4.5 THK PNL, NYLON 6/6 GMP.PA66.015 (RR W/H LNR (PUSH IN))
11610510 NUT, PUSH-IN, M4.2X1.41, 0.7-2.15 PNL THK, SAE 1050-65, GMW3359 W/BLK SEAL (RR BPR FASCIA SI SUPT)
25906986 BRACKET, RR BPR FASCIA SUPT
25906987 BRACKET, RR BPR FASCIA SUPT
11589015 BOLT, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (RR BPR FASCIA SI SUPT)
22899760 HARNESS, RR OBJECT ALARM SEN WRG
19116085 SENSOR KIT, PARK ASST ALARM (INCLS 13) (PRIMED) (W/HOUSING) (7.831)
15239247 SENSOR KIT, PARK ASST ALARM (INCLS 13) (PRIMED) (W/O HOUSING) (MATING CONN W/LEADS USE PART 88988337) (7.831)
15817524 HOUSING, RR OBJECT SEN (PRIMED) (PART OF 16) (INBOARD) (7.831)
15817525 HOUSING, RR OBJECT SEN (PRIMED) (PART OF 16) (OUTBOARD) (7.831)
15817526 HOUSING, RR OBJECT SEN (PRIMED) (PART OF 16) (INBOARD)
15817523 HOUSING, RR OBJECT SEN (PRIMED) (PART OF 16) (OUTBOARD) (7.831)
15817526 HOUSING, RR OBJECT SEN (PRIMED) (PART OF 16) (INBOARD) (7.831)
11515638 NUT, U-TYPE, M4.2X1.41X10.5.5X22, .65-3.8 PNL THK, 1050, ZF (RR W/H LNR)
11562024 RETAINER, PUSH IN, 7.5X36.5, FITS 6.35 HOLE IN 2.29-18.34 THK PNL (RR BPR FASCIA (PUSH IN))
20951798 FASCIA, RR BPR (INCLS 12, 19) (PAINT TO MATCH) ( (MAY NEED TO ORDER HITCH COVER 20777999)
20951797 FASCIA, RR BPR (INCLS 12, 19) (PAINT TO MATCH)
11610049 NUT, RR BPR FASCIA (SPECIAL PIN-PUSH, FITS 6.6X12.5 RECTANGULAR HOLE, 14.5 LONG)
20777999 COVER PKG, RR BPR FASCIA TRLR HITCH ACC HOLE (PAINT TO MATCH)
teamcadillac.ru
15811583 COVER, RR BPR FASCIA ACC HOLE (PART OF 16) (PAINT TO MATCH)
11570498 BOLT, HWH W/FL WA, M4.2X1.41X20, 11.4 THD, 17 OD, ISO 2702 STL , GMW4205, T (RR BPR FASCIA)
15853597 PAD, RR BPR FASCIA STEP (USE T/W 15853598)
12191503 RECEPTACLE, TOW VEH ELEC (W/DOOR)
15228708 LABEL, TRLR HITCH INFO (PART OF 1)
11561075 BOLT, HEX W/CON WA, M14X2X45, 21.18 THD, 32 OD, 10.9, GMW3359, M-PT, ADHES (RR BPR IMP BAR)
15853598 MOLDING, RR BPR FASCIA (INCLS 27) (CHROME) (USE T/W 15853597)
11561857 CLIP, RR BPR FASCIA MLDG (PART OF 26) (BLACK) (14.13 X 11 X 8.6) (V-SHAPED 1.5-1.75 RIB CLIP)
25894906 BRACKET, RR BPR IMP BAR (PART OF 1)
11570097 NUT, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (RR BPR LWR FASCIA)
25779048 REFLECTOR, R/END FASCIA
25779049 REFLECTOR, R/END FASCIA
(TC07-911) 2007-2013 K1(06-36) БУКСИРОВОЧНЫЕ КРЮКИ
00000001 HOOK, FRT TOW (DEALER INSTALLED-SEE GROUP 21.261 HOOK OR HOOK PKG)
15827191 HOOK, FRT TOW (BLACK)
22858895 HOOK, FRT TOW
11516078 NUT, HFH, M12X1.75, 14THK, 25 O.D., 10, PZOR (FRT TOW HOOK)
11589274 BOLT, HFH, M12X1.75X45.8, 31.4 THD, 26.6 OD, 10.9, GMW3359, (FRT TOW HOOK)
11589283 BOLT, HFH, M12X1.75X125.9, 45 THD, 26.6 OD, 10.9, GMW3359, M-PT, REDUCED BO (FRT TOW HOOK)
(TC07-914) 2007-2013 CK1(06-36) ПОДВЕСКА ЗАДНЯЯ PART 2
11518725 BOLT, R/AXL TIE ROD (M14X2.0X95) (HVY HEX FLG HD W/CON SPR WA) (8.900)
11516382 NUT, R/AXL TIE ROD (FRAME SIDE ONLY) (M14X2X15, 28OD) (W/O J CLIP RETAINER) (8.917)
15251980 INSULATOR, RR SPR (FRAME SIDE ONLY)
25783732 SPRING, RR COIL (CODE MBD YWJ)
25783731 SPRING, RR COIL (CODE MBC YWH)
15713853 INSULATOR, RR SPR (AXLE SIDE ONLY)
15039398 ROD, R/AXL TIE (INCLS 6)
11609486 NUT, R/AXL TIE ROD (AXLE SIDE ONLY) (M14X2)
11517766 BOLT, R/AXL LWR CONT ARM (M14X2X106) (HEX W/CON WA) (8.900)
11516382 NUT, R/AXL LWR CONT ARM (M14X2X15, 28OD) (W/O J CLIP RETAINER) (8.917)
11517901 BOLT, R/AXL UPR CONT ARM (M14X2X90) (HEX W/CON WA) (8.900)
11516382 NUT, R/AXL UPR CONT ARM (M14X2X15, 28OD) (W/O J CLIP RETAINER) (8.917)
15239738 ARM, R/AXL LWR CONT (INCLS 14)
15208540 ARM, R/AXL UPR CONT (INCLS 16) (CASE ARM) (FOR 2ND DES SEE 20917465)
20917465 ARM, R/AXL UPR CONT (INCLS 16) (STAMPED ARM) (FOR 1ST DES SEE 15208540)
teamcadillac.ru
11562586 NUT, R/AXL UPR CONT ARM (M14X2, 9THK) (W/J CLIP RETAINER)
15039397 BUMPER, RR SUSP JOUNCE
(TC07-915) 2008-2013 CK1(06-36) КОМПРЕССОР СИСТЕМЫ УПРАВЛЕНИЯ АВТОМАТИЧЕСКОЙ ПОДВЕСКОЙ (REAL-TIME DAMPING Z55, MAGNERIDE Z95)
22941806 COMPRESSOR, AUTO LVL CONT AIR (INCLS 2-14) (CODE 1806)
20982305 FILTER, AUTO LVL CONT AIR CMPR
teamcadillac.ru
22197160 HOSE, AUTO LVL CONT AIR CMPR FLTR (CUT HOSE TO FIT)
15840487 TEE, RR AIR SUSP LVLG C/VLV SPLY TUBE
(TC07-916) 2009-2013 CK1(06-36) ЭЛЕМЕНТЫ УПРАВЛЕНИЯ ПОДВЕСКОЙ/ЭЛЕКТРОНИКА (REAL-TIME DAMPING Z55, MAGNERIDE Z95, EXC HYBRID HP2)
25971218 MODULE, ELEK SUSP CONT (INCLS 2, 3) (LABELED 25971218)
25971217 MODULE, ELEK SUSP CONT (INCLS 2, 3)
20917434 SENSOR, ELEK SUSP RR POSN (FITS ON STAMPED ARM) (INCLS 11-13)
20917435 SENSOR, ELEK SUSP RR POSN (FITS ON STAMPED ARM) (INCLS 11-13)
15128648 SENSOR, ELEK SUSP RR POSN (FITS ON CAST ARM) (INCLS 11-13) (FULL ASM)
15128649 SENSOR, ELEK SUSP RR POSN (FITS ON CAST ARM) (INCLS 11-13) (FULL ASM)
11516885 SCREW, HFH W/FL WA, TAP, M8X1.25X20, 7THD, 17 O.D., TR PT, 6202M, PZOR (ELEK SUSP RR POSN SEN BRKT)
22189722 LINK, ELEK SUSP RR POSN SEN (PART OF 9)
22189896 BRACKET, ELEK SUSP FRT POSN SEN (PART OF 9) (INCLS 11) (ELEK SUSP RR POSN) (FITS ON CAST ARM) (NO COMPARABLE PART FOR STAMPED ARM)
22189897 BRACKET, ELEK SUSP FRT POSN SEN (PART OF 9) (INCLS 11) (ELEK SUSP RR POSN) (FITS ON CAST ARM) (NO COMPARABLE PART FOR STAMPED ARM)
15098628 SENSOR, ELEK SUSP FRT POSN (INCLS 16, 17)
15098629 SENSOR, ELEK SUSP FRT POSN (INCLS 16, 17)
teamcadillac.ru
25379115 LINK, ELEK SUSP FRT POSN SEN (PART OF 15)
19180262 CONNECTOR, SOL-S/ABS ELEK SUSP CONT ACTR (PART OF 4) (GRAY) (2-WAY MALE) (90DEG COUPLING) (W/O LEADS) (7.450)
(TC07-917) 2008-2013 CK1(06-36) ЭЛЕМЕНТЫ УПРАВЛЕНИЯ ПОДВЕСКОЙ/ЭЛЕКТРОНИКА (EXC HYBRID HP2, ACTIVE BRAKE CONTROL DELETE JL0)
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (VEH YAW SEN & LATL ACCLRM)
teamcadillac.ru
25930324 SENSOR, VEH YAW (W/VEH LATL ACCLRM)
(TC07-919) 2007-2013 K1(06-36) РАМА
22887987 FRAME, CHASSIS (INCLS 3-9, 11, 13, 16, 17, 19, 20, 22, 23) (MUST TRANS/REPL TRANS XMEMBER &/OR FRT DIFF CARRIER BRKTS)
88938443 EXTENSION, S/RL (REAR) (INCLS 3)
88938444 EXTENSION, S/RL (REAR) (INCLS 3)
20916985 BRACKET, BODY MT (PART OF 1, 2) (W/REINFORCEMENT) (USED ON BOTH LH & RH)
15786948 BRACKET, RR S/ABS UPR (PART OF 1)
15786947 BRACKET, RR S/ABS UPR (PART OF 1)
15894408 CROSSMEMBER, TRANS SUPT (PART OF 1) (STRAIGHT W/3 HOLES IN CTR)
11516078 NUT, HFH, M12X1.75, 14THK, 25 O.D., 10, PZOR (PART OF 1)
11517236 BOLT, DRIVETRAIN & FRT SUSP FRM REINF (PART OF 1) (M12X1.75X135) (8.900)
19150105 CROSSMEMBER, DRIVETRAIN & FRT SUSP FRM FRT (PART OF 1)
15201007 CROSSMEMBER, FRT (PART OF 1, 24)
10385576 BRACKET, U/B (PART OF 1, 24)
10385577 BRACKET, U/B (PART OF 1, 24)
15774517 SPACER, FRT BPR IMP BAR BRKT (PART OF 1, 24) (*KIT1)
teamcadillac.ru
15854868 BRACKET, RAD SI MT (PART OF 1, 24)
15854869 BRACKET, RAD SI MT (PART OF 1, 24)
11516382 NUT, HFH LK M14X2X15, 28 OD 10 7111M (FRT BPR IMP BAR BRKT) (*KIT1)
15918817 PLATE, FRT BPR IMP BAR REINF STUD (M14X2) (*KIT1)
11516382 NUT, HFH LK M14X2X15, 28 OD 10 7111M (PART OF 1)
11589247 BOLT, HFH, M14X2X165.5, 58.2 THD, 30.5 ID, 10.9, 7114M, MACH, CONE-PT (PART OF 1)
15790389 FRAME, FRT HALF (INCLS 9, 11, 13, 16, 17) (SERVICE KIT W/SECTIONING INSTRUCTIONS)
15791866 BRACKET KIT, FRT BPR IMP BAR (INCLS 13, 18-21) (INCLS SPACER, BOLTS, NUT)
(TC07-948) 2009-2011 CK1(06) БАМПЕР ПЕРЕДНИЙ (CADILLAC Z75, PLATINUM EDITION ULT, EXC HEADLAMP T84)
10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (FRT BPR FASCIA OTR BRKT)
25948814 BRACKET, FRT BPR FASCIA SI (INCLS 8)
25948815 BRACKET, FRT BPR FASCIA SI (INCLS 8)
25947497 BAR, FRT BPR IMP (W/ AIR DAM BRACES)
11589398 BOLT, HEX HD, W/CON WA, M6X1X30, 18.11 THD, 24 O.D., 9.8, GMW3179, BLACK (FRT BPR LWR FASCIA)
11515638 NUT, U-TYPE, M4.2X1.41X10.5.5X22, .65-3.8 PNL THK, 1050, ZF (PART OF 15)
15907625 FILLER, FRT BPR OTR FRT (INCLS 14, 16)
15907626 FILLER, FRT BPR OTR FRT (INCLS 14, 16)
11609385 NUT, U-TYPE, M6X1, 29.5 LEN, 12.5 WID, 19.5 CEN-END, 1050, GMW3359 (PART OF 15)
15907623 SUPPORT, FRT BPR FASCIA
15907627 DEFLECTOR, FRT AIR
11515637 SCREW, FLT CSK, M4.2X1.41X13, 9.2 OD, 6172M, CC, TAP-BSSD, C/R (FRT OTR A/DFL) (**VPI 1-877-846-8243)
22549046 SCREW, M4.2X1.4X25, 11.1 O.D., 6010M, NZ (FRT GRL CTR PNL)
11515638 NUT, U-TYPE, M4.2X1.41X10.5.5X22, .65-3.8 PNL THK, 1050, ZF (FRT UPR GRL)
11589039 BOLT, HEX, W/CON WA, M6X1X30, 20 THD, 24 O.D., 9.8, GMW4205 (PART OF 30)
teamcadillac.ru
22860589 EMBLEM, FRT GRL (PART OF 30) (MEDALLION)
11609465 BOLT, HWH, M4.2X1.41X18, 12.5 OD, 6010M, PS (FRT BPR OTR FRT FIL) (8.977)
(TC07-949) 2008-2013 CK1(06-36) ПЕРЕДНИЙ АМОРТИЗАТОР И ПРУЖИНА (REAL-TIME DAMPING Z55, MAGNERIDE Z95)
25871194 SPRING, FRT
25871196 SPRING, FRT
25876850 SPRING, FRT
25876861 SPRING, FRT
25871192 SPRING, FRT
25876851 SPRING, FRT
25876864 SPRING, FRT
25876866 SPRING, FRT
15132801 SPRING, FRT
15867410 SPRING, FRT
25876862 SPRING, FRT
25871197 SPRING, FRT
20842467 SPRING, FRT
20842468 SPRING, FRT
20842469 SPRING, FRT
20842470 SPRING, FRT
20842471 SPRING, FRT
20842472 SPRING, FRT
20842473 SPRING, FRT
20842474 SPRING, FRT
20842475 SPRING, FRT
20842476 SPRING, FRT
20842477 SPRING, FRT
20842478 SPRING, FRT
20842479 SPRING, FRT
20842480 SPRING, FRT
20842481 SPRING, FRT
25871200 SPRING, FRT
25876854 SPRING, FRT
15815517 NUT, S/ABS CONT ACTR VLV
15815519 NUT, FRT SUSP STRUT
25940743 MOUNT, FRT SUSP STRUT
15803177 SEAT, FRT SPR UPR
25940742 SEAT, FRT SPR UPR
15886466 REINFORCEMENT, FRT SUSP STRUT MT (22.25 OD, 5.2 THK) (WASHER- M12 STEPPED TO M14)
20982216 BUMPER, FRT SUSP STRUT
20982217 BUMPER, FRT SUSP STRUT
20982218 BUMPER, FRT SUSP STRUT
15886463 BUMPER, FRT SUSP STRUT
15815516 BUMPER, FRT SUSP STRUT
25940741 BOOT, FRT S/ABS
20765171 ABSORBER, FRT SHK (ACDelco #540-460)
20810265 ABSORBER, FRT SHK (ACDelco #580-370)
20765198 ABSORBER, FRT SHK (ACDelco #540-471)
20765177 ABSORBER, FRT SHK (ACDelco #540-508)
20765200 ABSORBER, FRT SHK (ACDelco #540-257)
20765204 ABSORBER, FRT SHK (ACDelco #540-571)
20765189 ABSORBER, FRT SHK (ACDelco #540-573)
20958799 ABSORBER, FRT SHK (ACDelco #540-625)
25870890 ABSORBER, FRT SHK (ACDelco #540-459)
25870892 ABSORBER, FRT SHK (ACDelco #540-461)
25876876 ABSORBER, FRT SHK (ACDelco #540-472)
25940740 ABSORBER, FRT SHK (ACDelco #580-364)
20765184 ABSORBER, FRT SHK (ACDelco #540-585)
20810264 ABSORBER, FRT SHK (ACDelco #580-369)
20810270 ABSORBER, FRT SHK (ACDelco #580-373)
20833674 ABSORBER, FRT SHK (ACDelco #540-590)
20833672 ABSORBER, FRT SHK (ACDelco #540-595)
20833675 ABSORBER, FRT SHK (ACDelco #540-588)
20765207 ABSORBER, FRT SHK
20810269 ABSORBER, FRT SHK (ACDelco #580-372)
20765196 ABSORBER, FRT SHK (ACDelco #540-544)
20765201 ABSORBER, FRT SHK (ACDelco #540-424)
20765185 ABSORBER, FRT SHK (ACDelco #560-628)
teamcadillac.ru
25980102 ABSORBER, FRT SHK (ACDelco #540-579)
20841899 INSULATOR, FRT SPR LWR
15808594 INSULATOR, FRT SPR LWR
(TC07-953) 2009-2010 CK1(06) ЭЛЕМЕНТЫ УПРАВЛЕНИЯ ПОДВЕСКОЙ/ЭЛЕКТРОНИКА (MAGNERIDE Z95, HYBRID HP2)
25867635 SHIELD, ELEK SUSP CONT MDL
22941806 COMPRESSOR, AUTO LVL CONT AIR (INCLS 7, 9) (SEE GROUP 07.000 "LEVEL CONTROL COMPRESSOR/AUTOMATIC" FOR DETAILED ILLUSTRATED VIEW) (CODE 1806)
20917434 SENSOR, ELEK SUSP RR POSN (FITS ON STAMPED ARM) (INCLS 10, 11, 13)
20917435 SENSOR, ELEK SUSP RR POSN (FITS ON STAMPED ARM) (INCLS 10, 11, 13)
15128648 SENSOR, ELEK SUSP RR POSN (FITS ON CAST ARM) (INCLS 10, 11, 13) (FULL ASM)
15128649 SENSOR, ELEK SUSP RR POSN (FITS ON CAST ARM) (INCLS 10, 11, 13) (FULL ASM)
22189722 LINK, ELEK SUSP RR POSN SEN (PART OF 8)
22189896 BRACKET, ELEK SUSP FRT POSN SEN (PART OF 8) (INCLS 10) (ELEK SUSP RR POSN) (FITS ON CAST ARM) (NO COMPARABLE PART FOR STAMPED ARM)
22189897 BRACKET, ELEK SUSP FRT POSN SEN (PART OF 8) (INCLS 10) (ELEK SUSP RR POSN) (FITS ON CAST ARM) (NO COMPARABLE PART FOR STAMPED ARM)
15098628 SENSOR, ELEK SUSP FRT POSN (INCLS 17, 18)
15098629 SENSOR, ELEK SUSP FRT POSN (INCLS 17, 18)
teamcadillac.ru
25379115 LINK, ELEK SUSP FRT POSN SEN (PART OF 16)
(TC07-962) 2007-2013 CK107(06) ТРЕЙЛЕРНАЯ СЦЕПКА COVER (VHS)
teamcadillac.ru
20777999 COVER PKG, RR BPR FASCIA TRLR HITCH ACC HOLE (INCLS 2-4) (PAINT TO MATCH)
19172859 COVER PKG, RR BPR FASCIA TRLR HITCH ACC HOLE (INCLS 2-4) (WHITE) (INSTALL .5) (0.65KGS) (INCLS BRKT, 2 NUTS & INSTR) (7.068)
19172860 COVER PKG, RR BPR FASCIA TRLR HITCH ACC HOLE (INCLS 2-4) (BLACK) (INSTALL .5) (0.65KGS) (INCLS BRKT, 2 NUTS & INSTR) (7.068)
19213271 COVER PKG, RR BPR FASCIA TRLR HITCH ACC HOLE (INCLS 2-4) (WHITE) (7.068)
11561878 RETAINER, PUSH PIN W/SEAL, FITS 8.0-8.25 DIA HOLE IN 3-7MM THK PNL (PART OF 1)
11610049 NUT, RR BPR FASCIA (PART OF 1) (SPECIAL PIN-PUSH, FITS 6.6X12.5 RECTANGULAR HOLE, 14.5 LONG)
(TK07-006) 2009-2013 K1(06) LICENSE PLATE MOUNTING (RR MOUNTING PACKAGE VLR)
20803594 BRACKET, RR LIC PLT
03907444 NUT, PUSH IN, SQUARE, UN THD, M9.5 SQ HOLE, NYLON (RR LIC PLT)
teamcadillac.ru
09423101 SCREW, TAP, M6.3X1.81X16, 14.55 O.D., 7114M, PZ0R (RR LIC PLT)
08 - ЛИСТОВОЙ МЕТАЛЛ ПЕРЕДНЕЙ ЧАСТИ - ОБОГРЕВАТЕЛЬ - ТЕХОБСЛУЖИВАНИЕ АВТОМОБИЛЯ
(GM08-009) 2007-2013 CK1,2,3 КРАСКА/TOUCH-UP
01050015 PAINT, TOUCH-UP TUBE (.5 OZ) (SUMMIT WHITE/OLYMPIC WHITE) (WA 8624) (ACDelco #01050015)
01052907 PAINT, TOUCH-UP TUBE (.5 OZ) (BLACK) (WA 8555) (ACDelco #01052907)
12345116 PAINT, TOUCH-UP TUBE (.5 OZ) (PRIMER, FILLER SCRATCH) (GRAY)
12345118 PAINT, TOUCH-UP TUBE (.5 OZ) (CLEAR TOP COAT) (ACDelco #12345118)
12345538 PAINT, TOUCH-UP TUBE (.5 OZ) (VICTORY RED) (WA 9260) (ACDelco #12345538)
12346575 PAINT, TOUCH-UP TUBE (.5 OZ) (DARK MING BLUE MET) (WA 722J)
12346585 PAINT, TOUCH-UP TUBE (.5 OZ) (WHITE DIAMOND PEARL) (WA 800J) (MAY NEED TO REAPPLY IN THIN COATS TO GET DESIRED COLOR IN MET) (ACDelco #12346585)
12346711 PAINT, TOUCH-UP TUBE (.5 OZ) (STEALTH GRAY MET) (WA 928L) (ACDelco #12346711)
12346781 PAINT, TOUCH-UP TUBE (.5 OZ) (GRAYSTONE MET) (WA 213M)
12346909 PAINT, TOUCH-UP TUBE (.5 OZ) (GOLD MIST MET) (WA 316N)
88860795 PAINT, TOUCH-UP TUBE (.5 OZ) (DARK BRAHMA JEWEL MET) (WA 519Q)
12346917 PAINT, TOUCH-UP TUBE (.5 OZ) (RED JEWEL T/COAT) (WA 301N)
88860753 PAINT, TOUCH-UP TUBE (.5 OZ) (SONOMA JEWEL MET) (WA 412P) (ACDelco #88860753)
88860799 PAINT, TOUCH-UP TUBE (.5 OZ) (INFERNO ORANGE MET) (WA 502Q)
88860803 PAINT, TOUCH-UP TUBE (.5 OZ) (CARBON FLASH MET) (WA 501Q) (ACDelco #88860803)
88860737 PAINT, TOUCH-UP TUBE (.5 OZ) (IMPERIAL BLUE MET) (WA 403P)
12346785 PAINT, TOUCH-UP TUBE (.5 OZ) (LASER BLUE MET) (WA 218M)
88860911 PAINT, TOUCH-UP TUBE (.5 OZ) (MAGNA STEEL MET) (WA 706S)
88860913 PAINT, TOUCH-UP TUBE (.5 OZ) (DARK LABYRINTH MET) (WA 707S)
88860923 PAINT, TOUCH-UP TUBE (.5 OZ) (SANTIAGO TEAL MET) (WA 717S)
88860925 PAINT, TOUCH-UP TUBE (.5 OZ) (EVOLUTION BLUE MET) (WA 718S)
88860933 PAINT, TOUCH-UP TUBE (.5 OZ) (SHEER SILVER MET) (WA 726S)
12345117 PAINT, TOUCH-UP SPRAY (5 OZ) (PRIMER, FILLER, SCRATCH) (ACDelco #12345117)
12345119 PAINT, TOUCH-UP SPRAY (5 OZ) (CLEAR TOP COAT) (ACDelco #12345119)
12345155 PAINT, TOUCH-UP SPRAY (5 OZ) (BLACK) (WA 8555) (ACDelco #12345155)
12345205 PAINT, TOUCH-UP SPRAY (5 OZ) (SUMMIT WHITE/OLYMPIC WHITE) (WA 8624) (ACDelco #12345205)
12345539 PAINT, TOUCH-UP SPRAY (5 OZ) (VICTORY RED) (WA 9260) (ACDelco #12345539)
12346576 PAINT, TOUCH-UP SPRAY (5 OZ) (DARK MING BLUE MET) (WA 722J)
12346586 PAINT, TOUCH-UP SPRAY (5 OZ) (WHITE DIAMOND PEARL) (WA 800J) (ACDelco #12346586)
12346712 PAINT, TOUCH-UP SPRAY (5 OZ) (STEALTH GRAY MET) (WA 928L) (ACDelco #12346712)
12346782 PAINT, TOUCH-UP SPRAY (5 OZ) (GRAYSTONE MET) (WA 213M)
12346910 PAINT, TOUCH-UP SPRAY (5 OZ) (GOLD MIST MET) (WA 316N)
88860796 PAINT, TOUCH-UP SPRAY (5 OZ) (DARK BRAHMA JEWEL MET) (WA 519Q)
12346918 PAINT, TOUCH-UP SPRAY (5 OZ) (RED JEWEL T/COAT) (WA 301N)
88860754 PAINT, TOUCH-UP SPRAY (5 OZ) (SONOMA JEWEL MET) (WA 412P) (ACDelco #88860754)
88860800 PAINT, TOUCH-UP SPRAY (5 OZ) (INFERNO ORANGE MET) (WA 502Q)
88860804 PAINT, TOUCH-UP SPRAY (5 OZ) (CARBON FLASH MET) (WA 501Q) (ACDelco #88860804)
88860738 PAINT, TOUCH-UP SPRAY (5 OZ) (IMPERIAL BLUE MET) (WA 403P)
12346786 PAINT, TOUCH-UP SPRAY (5 OZ) (LASER BLUE MET) (WA 218M)
teamcadillac.ru
88860912 PAINT, TOUCH-UP SPRAY (5 OZ) (MAGNA STEEL MET) (WA 706S)
88860914 PAINT, TOUCH-UP SPRAY (5 OZ) (DARK LABYRINTH MET) (WA 707S)
88860924 PAINT, TOUCH-UP SPRAY (5 OZ) (SANTIAGO TEAL MET) (WA 717S)
88860926 PAINT, TOUCH-UP SPRAY (5 OZ) (EVOLUTION BLUE MET) (WA 718S)
88860934 PAINT, TOUCH-UP SPRAY (5 OZ) (SHEER SILVER MET) (WA 726S)
(TC08-061) 2009-2013 CK1(06-36) ПОДНОЖКА (POWER RETRACTABLE BRS)
15932167 SHIELD, ASST STEP (FRT)
teamcadillac.ru
15932168 SHIELD, ASST STEP (FRT)
22778156 BRACKET, ASST STEP (BRKT USED ON FRT END OF MOTORIZED ASSIST STEP)
22778157 BRACKET, ASST STEP (BRKT USED ON FRT END OF MOTORIZED ASSIST STEP)
11570194 PLATE, ASST STEP CTR BRKT ANC
22778159 BRACKET, ASST STEP (BRKT USED ON RR END OF MOTORIZED ASSIST STEP)
22778158 BRACKET, ASST STEP (BRKT USED ON RR END OF MOTORIZED ASSIST STEP)
11609733 BOLT, HEX W/CON WA, M8X1.25X30, 20 THD, 24 OD, 10.9, GMW4205, MAT POINT (ASST STEP)
15806412 PAD, ASST STEP
20919401 COVER, ASST STEP FIN (INCLS 5) (INCLS INSERT)
20919402 COVER, ASST STEP FIN (INCLS 5) (INCLS INSERT)
25971280 STEP, ASST
15872198 BOLT, ASST STEP FIN CVR
11610602 BOLT, ASST STEP SUPT BR
11569755 BOLT, HEX W/CON WA, M8X1.25X20, 10 THD, 24 OD, 8.8, GMW4205, M-PT (ASST STEP)
20784800 BRACKET, ASST STEP CTR (INCLS 16)
20784801 BRACKET, ASST STEP CTR (INCLS 16)
15932169 SHIELD, ASST STEP (RR)
15932170 SHIELD, ASST STEP (RR)
15231167 NUT, ASST STEP (M6 I.D M12 O.D X 1.00 X 11.68) (INSERT)
25640265 NUT, ASST STEP (M8X1.25) (10.463)
11570190 BOLT, ASST STEP SHLD (M4X0.7X10)
15872197 BOLT, ASST STEP BRKT (M6X1X17)
11519125 BOLT, HEX W/CON WA, M6X1X26, 15.16 THD, 20 OD, 9.8, 6173M, MACH, 6175 ADH, MAT (ASST STEP SUPT)
11513599 NUT, U-TYPE, M4.2X1.41, 0.65-3.80 PNL THK, PZ (ASST STEP BRKT) (ACDelco #11513599)
25852622 MODULE, ASST STEP CONT
11589015 BOLT, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (ASST STEP)
20784804 SHIELD, ASST STEP (MTR COVER)
20784805 SHIELD, ASST STEP (MTR COVER)
25971283 MOTOR, ASST STEP (MAY NEED TO ORDER SHIELD)
25971282 MOTOR, ASST STEP (MAY NEED TO ORDER SHIELD)
25799851 SUPPORT, ASST STEP (WEDGE)
(TC08-906) 2008-2013 CK107(06) МЕСТО ХРАНЕНИЯ ДОМКРАТА И ИНСТРУМЕНТОВ (EXC HYBRID HP2)
11610693 RETAINER, TOOL STOW (INCLS WINGNUT)
20782715 BAG, TOOL STOW (*KIT1)
15854614 HANDLE, JK/WHL WRENCH (NON-RATCHET TYPE) (*KIT1)
15295860 EXTENSION, JK HDL (406MM) (NON FLEXIBLE SHAFT) (*KIT1)
15101404 HANDLE, JK (508.0MM LG) (*KIT1)
teamcadillac.ru
15547900 BLOCK, WHL
15772593 NUT, WHL BLK (6MM)
22895910 BRACKET, JK STOW
15783357 BOLT, WHL BLK
15788798 JACK, (INCLS 12)
20782703 TOOL KIT, (INCLS 2-5)
(TC08-907) 2010 CK1,2(06) ШЛАНГИ И ТРУБКИ/ОБОГРЕВАТЕЛЬ (LMG/5.3-0,LC9/5.3-3,L96/6.0G,L9H/6.2-2,L94/6.2F)
15050765 CLIP, HTR HOSE (PART OF 3) (73.0MM WIDE)
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (ENG WRG HARN RET)
15778415 BRACKET, HTR HOSE CLIP (INCLS 1)
teamcadillac.ru
15834773 HOSE, RAD SURGE TK OTLT (INCLS 4, 5)
15012561 CLAMP, HOSE SPR, 27 NOM, 25.2 MIN-28.9 MAX, 15MM WIDE, BLACK (RAD SURGE TK OTLT HOSE) (8.948)
11570616 CLAMP, SPRINGBAND, 27 NOMINAL DIA, 15 THK, STL, ROBO (RAD SURGE TK OTLT HOSE)
11517133 CLAMP, SPRING, 22-26MM, 24 NOM., BLK (PART OF 10)
15895065 HOSE, HTR INL (INCLS 9, 11)
(TC08-909) 2008-2013 CK1,2(06-36) ПОДНОЖКА (MOLDED BLACK BVE, EXC HYBRID HP2)
20827146 BRACKET, ASST STEP
11609997 BOLT, ASST STEP
teamcadillac.ru
15291807 EXTENSION, ASST STEP FRT
15291808 EXTENSION, ASST STEP FRT
11609997 BOLT, ASST STEP FRT EXTN
11519742 BOLT, WASHER, M8X1.25X40, 33.4 THD, 39 OD, 9.8, 7114M, 2.5-3.5 THK FL WA (ASST STEP)
03540325 STUD, ASST STEP (9.173)
(TC08-910) 2007-2013 CK1(06-36) ПОДНОЖКА (CHROME INSERT BVU)
teamcadillac.ru
15914678 STEP, ASST
15914679 STEP, ASST
15914684 INSERT, ASST STEP (RR)
15914685 INSERT, ASST STEP (RR)
15914682 INSERT, ASST STEP (FRT)
15914683 INSERT, ASST STEP (FRT)
15291811 EXTENSION, ASST STEP FRT
15291812 EXTENSION, ASST STEP FRT
25694574 RETAINER, ASST STEP FRT EXTN (PUSH IN) (PLASTIC TREE, FIT 5.0-5.25 DIA HOLE, 12MM LGTH, 10 OD, NYLON) (10.695)
(TC08-914) 2007-2013 CK1(06-36) ПОДНОЖКА (TUBULAR BLACK BVV)
25831407 COVER, ASST STEP FIN (*KIT1)
25831408 COVER, ASST STEP FIN (*KIT1)
25804637 PAD, ASST STEP (*KIT1)
25804636 PAD, ASST STEP (*KIT1)
25831393 STEP, ASST (EXCLS COVER, BRKT, PAD, & INSULATOR) (*KIT1)
25831392 STEP, ASST (EXCLS COVER, BRKT, PAD, & INSULATOR) (*KIT1)
11519742 BOLT, WASHER, M8X1.25X40, 33.4 THD, 39 OD, 9.8, 7114M, 2.5-3.5 THK FL WA (ASST STEP) (*KIT1)
25816111 EXTENSION, ASST STEP FRT
25816112 EXTENSION, ASST STEP FRT
15929675 COVER, ASST STEP FIN (FRT) (*KIT1)
15929677 COVER, ASST STEP FIN (FRT) (*KIT1)
11516807 RIVET, POP, 4.8 DIA, 19.9 LONG, 16 OD, 5-5.25 HOLE, 1-9 GRIP RANGE, AL, BLACK (ASST STEP)
25831412 BRACKET, ASST STEP (*KIT1)
25831411 BRACKET, ASST STEP (*KIT1)
25821809 BRACKET, ASST STEP RR (INCLS 13)
25821810 BRACKET, ASST STEP RR (INCLS 13)
11515638 NUT, U-TYPE, M4.2X1.41X10.5.5X22, .65-3.8 PNL THK, 1050, ZF (PART OF 12)
25804640 INSULATOR, ASST STEP RR SUPT (*KIT1)
25804641 INSULATOR, ASST STEP RR SUPT (*KIT1)
25804642 INSULATOR, ASST STEP FRT SUPT (*KIT1)
25804643 INSULATOR, ASST STEP FRT SUPT (*KIT1)
20919368 STEP, ASST (INCLS 1-4, 6, 9, 14, 15) (W/3 BRACKETS) (FOR 1ST DES SEE 25831388)
20919369 STEP, ASST (INCLS 1-4, 6, 9, 14, 15) (W/3 BRACKETS) (FOR 1ST DES SEE 25831389)
25831388 STEP, ASST (INCLS 1-4, 6, 9, 14, 15) (INCLS COVER, BRKT, PAD, & INSULATOR) (W/4 BRACKETS) (FOR 2ND DES SEE 20919368)
teamcadillac.ru
25831389 STEP, ASST (INCLS 1-4, 6, 9, 14, 15) (INCLS COVER, BRKT, PAD, & INSULATOR) (W/4 BRACKETS) (FOR 2ND DES SEE 20919369)
(TC08-931) 2008-2013 CK107(06) ПОДНОЖКА (MOLDED BLACK BVE, HYBRID HP2)
25847744 EXTENSION, ASST STEP FRT
25847745 EXTENSION, ASST STEP FRT
teamcadillac.ru
11516931 BOLT, FLAT WA & METRIC HEX HD MACHINE, M8X1.25X50 (ASST STEP)
(TC08-934) 2009-2013 CK1(06-36) КАПОТ (CADILLAC Z75)
15945915 HOOD, (INCLS 30)
11609797 BOLT, AIR INL GRL PNL (10.268)
15048061 RETAINER, AIR INL GRL PNL (PART OF 9) (PUSH IN)
25820729 PANEL, AIR INL GRL (INCLS 6) (BLACK)
25820730 PANEL, AIR INL GRL (INCLS 6) (BLACK)
11609796 CLIP, AIR INL GRL PNL (PART OF 5) (11.0 X 12.9 X 6.1MM) (8.950)
15999788 RETAINER, AIR INL GRL PNL (17X15.25X8.6) (U-SHAPED/CLIP)
20908176 HOSE, WSWA NOZ (PART OF 9)
25872303 PANEL, AIR INL GRL (CTR) (INCLS 3, 4, 8) (BLACK)
teamcadillac.ru
20968782 CABLE, HOOD PRIM LAT REL (INCLS PULL HANDLE)
11516780 NUT, HEX W/CON WA, M8X1.25, 10THK, 19 O.D., 10, 7111M (HOOD PRIM LAT REL CBL) (8.917)
25870070 SPRING, HOOD OPEN ASST
25870071 SPRING, HOOD OPEN ASST
11569992 BOLT, HOOD OPEN ASST SPR
11589064 BOLT, HOOD OPEN ASST SPR (M8X1.25X27) (8.015)
15054178 BOLT, HFH, W/SHOULDER, M8X1.25X23, 18 O.D., 9.8, GM6280M (HOOD OPEN ASST SPR)
15870422 BRACKET, F/FDR UPR
15951192 BRACKET, F/FDR UPR
11570082 BOLT, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (F/FDR UPR BRKT) (ACDelco #11570082)
15887401 BRACKET, HOOD HGE LWR (PART OF 19)
15887400 BRACKET, HOOD HGE LWR (PART OF 19)
10150076 CLIP, HOOD PRIM LAT REL CBL (18.8 MM DIA) (ROUND CLIP) (3.425)
11589039 BOLT, HEX, W/CON WA, M6X1X30, 20 THD, 24 O.D., 9.8, GMW4205 (HOOD PRIM LAT)
25816903 LATCH, HOOD PRIM (W/O SWITCH)
20763454 LATCH, HOOD PRIM (W/SWITCH)
25790320 BUMPER, HOOD ADJ FRT
15250133 BUMPER, HOOD SI
20783833 STRUT, HOOD
20064875 RETAINER, PUSH-IN, 20.5MMLG, 42.76MM 1.68HD DIA, PLASTIC (HOOD INSL)
15828996 INSULATOR, HOOD
15907251 MOLDING, HOOD FRT (INCLS 29) (CHROME)
25981130 MOLDING, HOOD FRT (INCLS 29) (CHROME)
11561788 CLIP, 13X15X12, 1.5 PNL, 1050, 6280M (PART OF 28)
15859618 BRACKET, HOOD STRUT (HOOD SI) (PART OF 1)
11515755 BOLT, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (HOOD HGE) (T/W 12345493 REPLCS 25534835)
15942145 HINGE, HOOD
15942146 HINGE, HOOD
11589064 BOLT, HOOD HGE
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BODY STATIC GND STRP)
(TC08-939) 2009-2013 CK1(06-36) КРЫЛО И КОЛЕСНАЯ АРКА/ПЕРЕДНЯЯ ЧАСТЬ (CADILLAC Z75)
25815065 BRACE, F/END SH MET DIAG
11609989 BOLT, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (F/END SH MET DIAG BR)
11515755 BOLT, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (F/FDR RR UPR BR) (T/W 12345493 REPLCS 25534835)
15185449 BRACE, F/FDR RR UPR
15185450 BRACE, F/FDR RR UPR
11610010 BOLT, HEX W/ CON WA, M8X1.25X40, 32 THD, 28 OD, 9.8, 7114M, MACH, P-PT (F/FDR INR PNL)
teamcadillac.ru
15887401 BRACKET, HOOD HGE LWR (PART OF 9)
15887400 BRACKET, HOOD HGE LWR (PART OF 9)
25992408 FENDER, FRT (INCLS 8)
25992409 FENDER, FRT (INCLS 8)
25819534 FENDER, FRT (INCLS 8)
25819535 FENDER, FRT (INCLS 8)
22900197 FENDER, FRT (INCLS 8)
11516149 NUT, U, 8X1.25, MULTI THD, .08'-4.0' THK PNL, PZ (F/FDR RR UPR BRKT)
15860253 INSERT, F/FDR CTR RR UPR MLDG (CHROME)
15860254 INSERT, F/FDR CTR RR UPR MLDG (CHROME)
11569854 NUT, U SPECIAL, M8X1.25, SAE 1050 STL, GMW3359 (SILVER) (F/FDR RR CTR BRKT)
25948814 BRACKET, FRT BPR FASCIA SI (INCLS 14)
25948815 BRACKET, FRT BPR FASCIA SI (INCLS 14)
11518531 NUT, PUSH-IN, M4.2X1.41, 15.9X8.4, .7-2.1 PNL, SAE 1050 STL, 7111M, 8.65 SQ HOL (PART OF 13) (10.512)
11517164 SCREW, HEX M8X1.25X20 W/CON WA (F/FDR LWR)
11589292 RETAINER, PUSH-IN, FITS 8.5 DIA HOLE IN 2-4.5 THK PNL, NYLON 6/6 GMP.PA66.015 (FRT W/H LNR (PUSH IN))
11609952 NUT, U-STYLE M4.2X1.41, 15.9X8.4, .7-2.1 PNL, SAE 1050 STL, 7111M, 8.65 SQ HOL (FRT W/H LNR)
11562172 BOLT, FRT W/H LNR
11609489 BOLT, HEX W/ WASHER, 4.2X1.41X25, 14.5 THD17 OD, GM6010M STL, GMW4205 (FRT BPR FASCIA OTR BRKT)
01605396 RETAINER, PUSH-IN, FITS .250 HOLE, .92 LG.700-OD NYLON BLACK (FRT W/H LNR (PUSH IN))
11562024 RETAINER, PUSH IN, 7.5X36.5, FITS 6.35 HOLE IN 2.29-18.34 THK PNL (FRT W/H LNR (PUSH IN))
22860089 LINER, FRT W/H
22860081 LINER, FRT W/H
22860097 LINER, FRT W/H
22860095 LINER, FRT W/H
11610055 BOLT, HWASH, M6X1X23 (FRT BPR FASCIA SI BRKT)
20906466 INSULATOR, COWL S/PNL
20906467 INSULATOR, COWL S/PNL
11570321 NUT, F/FDR LWR
15862261 BRACKET, FRT W/H PNL UPR
22860090 LINER, FRT W/H
22860082 LINER, FRT W/H
11519360 NUT, U, W/PLASTISOL, M8X1.25, 35.8X25, 21 C/E, 2.5-5 PNL, 1050, 6173M (F/FDR LWR)
15893710 SHIELD, ENG LWR FRT SPH
15893711 SHIELD, ENG LWR FRT SPH
11517560 SCREW, FLAT WA (NRW) AND HX WA HD, M8X1.25X25 (ENG LWR FRT SPH SHLD)
25961847 ORNAMENT, F/FDR (CHROME)
25961848 ORNAMENT, F/FDR (CHROME)
(TC08-948) 2010 CK1,2(06) ЭТИКЕТКИ
25808256 LABEL, BAT WRNG (ARABIC)
25861414 LABEL, FUEL RECOMMENDATION
20853000 LABEL, FUEL RECOMMENDATION
12451193 LABEL, CHILD SECURITY LK OPERG INSTR
19206430 LABEL KIT, VEH CAPACITY WT & TIRE INFO (ENGLISH ONLY LABEL FOR US) (QTY 10 PER KIT)
19206431 LABEL KIT, VEH CAPACITY WT & TIRE INFO (ENGLISH W/FRENCH-CANADIAN LABEL FOR CANADA) (QTY 10 PER KIT)
19206432 LABEL KIT, VEH CAPACITY WT & TIRE INFO (SPANISH LABEL FOR MEXICO) (QTY 10 PER KIT)
92229620 LABEL, MERCURY DISPOSAL INFO
25940508 LABEL, I/P WRG HARN FUSE BLK IDENT (2.483)
12567697 LABEL, ALL WHL DRV WRNG (ENGLISH/FRENCH)
25954276 LABEL, BAT WRNG (ENGLISH/FRENCH) (FIRST RESPONDER CAUTION LABEL)
10309116 LABEL, FAN BLADE WRNG (BLACK NYLON)
teamcadillac.ru
19257194 LABEL, VEH EMIS CONT INFO (VIN MUST BE SUPPLIED WITH ORDER)
15061343 LABEL, O/S RR VIEW MIR INFO (FRENCH)
21996989 TAG, I/P AIRBAG WRNG (HANGING)
15815407 LABEL, AIRBAG SYS WRNG (ENGLISH/ARABIC)
15053409 LABEL, A/C REFRIG & BAT & FAN BLADE & RAD FIL CAP CAUTION (ARABIC)
(TC09-700) 2007-2013 CK1,2(06) ШЛАНГИ И ТРУБКИ/ОБОГРЕВАТЕЛЬ
19130058 HOSE, AUX A/C EVPR & AUX HTR (INCLS 2, 4, 6, 9-13) (ACDelco #19130058)
19257318 HOSE, AUX A/C EVPR & AUX HTR (INCLS 2, 4, 6, 9-13) (KENT-MORE TUBING REPAIR KIT J41425 REQ'D FOR INSTALLATION) (9.225) (ACDelco #15-33439)
15102168 CLIP, AUX A/C EVPR HOSE (PART OF 1) (2X2 PLASTIC) (SLOT ON SIDE WITH DIAMETERS OF 19.05, 9.52, AND 2 AT 12.7MM)
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (AUX A/C EVPR & CMPR HOSE CLIP)
15102169 CLIP, AUX A/C EVPR HOSE (PART OF 1) (SLOT IN MIDDLE WITH DIAMETERS OF 19.05, 9.52, AND 2 AT 12.7MM)
11514596 NUT, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (AUX A/C EVPR TUBE) (8.915) (ACDelco #11514596)
02724966 SEAL, A/C CMPR & CNDSR HOSE (PART OF 1) (ACDelco #15-31101)
22876355 HOSE, A/C CMPR (SEE GROUP 09.000 "A/C REFRIGERATION SYSTEM/FRONT" FOR DETAILED ILLUSTRATED VIEW) (ACDelco #15-34529)
22876353 TUBE, A/C EVPR (SEE GROUP 09.000 "A/C REFRIGERATION SYSTEM/FRONT" FOR DETAILED ILLUSTRATED VIEW) (ACDelco #15-34538)
15055343 TEE, AUX HTR INL HOSE (PART OF 1) (NATURAL) (111MM LONG)
15055342 TEE, AUX HTR INL HOSE (PART OF 1) (BLACK) (113MM LONG)
52474373 SEAL, A/C EVPR TUBE (PART OF 1) (BLACK) (SLIMLINE WASHER) (19MM OD X 11MM ID, 1/2IN DIA) (SMOOTH-SIDED) (ACDelco #15-31055)
19130031 RETAINER KIT, AUX HTR INL & OTLT HOSE CONN (INCLS 13) (PART OF 1) (INCL RETAINER, SEAL, SPACER, INSTRUCTION)
teamcadillac.ru
09 - КРЕПЛЕНИЕ КУЗОВА-КОНДИЦИОНЕР-АУДИОСИСТЕМА
(GM09-046) 2010-2011 CK1 КОМПРЕССОР КОНДИЦИОНЕРА В СБОРЕ (L20/4.8A,LMG/5.3-0,LC9/5.3-3,L94/6.2F)
25940200 COMPRESSOR KIT, A/C (INCLS 2-10) (ACDelco #15-22232)
teamcadillac.ru
11561365 BOLT, A/C CMPR PUL (PART OF 1) (*KIT1)
20906283 CLUTCH KIT, A/C (4 SPLINED, DENSO) (INCLS 2-10) (ACDelco #15-4709)
(GM09-079) 2007-2013 CK1,2,3 CABLE KIT- COMMUNICATION
teamcadillac.ru
13581174 CABLE KIT, COMN INTERFACE MDL ANT (RG56 CABLES-LONG RUN CELLULAR/COMBINED CELLULAR & GPS) (ACDelco #13581174)
(GM09-080) 2007-2013 CK1,2,3 CABLE KIT- DIGITAL RADIO & VEHICLE LOCATOR
13581173 CABLE KIT, DIGITAL RDO & VEH LOC ANT COAX (RG316 CABLES-LONG RUN XM/GPS) (ACDelco #13581173)
teamcadillac.ru
(GM09-081) 2007-2013 CK1,2,3 CABLE KIT- DIGITAL RADIO & MOBILE TELEPHONE & VEHICLE LOCATOR
13581175 CONNECTOR KIT, DIGITAL RDO & M/TEL & VEH LOC ANT COAX (CONNECTIONS PACKAGE) (ACDelco #13581175)
teamcadillac.ru
(TC09-054) 2010 CK1(06-36) КРЕПЛЕНИЕ РАДИОСИСТЕМЫ (CADILLAC Z75)
15859569 ANTENNA, ELEK NAVIGATION (ACDelco #15859569)
25865834 CABLE, TV, NAV, AMP, VEH LOC & TRAF INFO INTERFACE (I/P) (ACDelco #25865834)
teamcadillac.ru
22847989 CABLE, RDO ANT CBL EXTN RDO END (1021 MM) (ACDelco #22847989)
11610157 NUT, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (I/P) (10.701)
20902104 RADIO, AM/FM STEREO & NAVN (INCLS 8, 9) (ACDelco #20902104)
20902102 RADIO, AM/FM STEREO & NAVN (INCLS 8, 9) (ACDelco #20902102)
20902103 RADIO, AM/FM STEREO & NAVN (INCLS 8, 9) (ACDelco #20902103)
20902105 RADIO, AM/FM STEREO & NAVN (INCLS 8, 9) (ACDelco #20902105)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (RDO) (9.665)
00000002 DISC, NAVN DATA (REFERENCE PART ONLY, NOT AVAILABLE THROUGH GM CC&A) (CONTACT NAV DISC CENTER AT 1-877-628-3472 OR GMNAVDISC.COM)
11588650 CLIP, 12X14X16.6, GM4345M (I/P ACSRY CTR TR PLT)
(TC09-087) 2010-2013 CK1,2(06) СИСТЕМА ОХЛАЖДЕНИЯ КОНДИЦИОНЕРА/FRONT (EXC HYBRID HP2)
20913751 CONDENSER, A/C (INCLS 4, 32-34) (ACDelco #15-63666)
11589039 BOLT, HEX, W/CON WA, M6X1X30, 20 THD, 24 O.D., 9.8, GMW4205 (A/C CNDSR BRKT)
15044225 INSULATOR, A/C CNDSR (LOWER) (ACDelco #15-63283)
52481715 BRACKET, A/C CNDSR UPR (INLET/OUTLET) (PART OF 1) (INCLS 32) (114.5MM LONG)
52482006 BRACKET, A/C CNDSR UPR (PART OF 1) (INCLS 32) (77.0MM LONG) (9.242)
52474373 SEAL, A/C CMPR & CNDSR HOSE (19MM OD X 11MM ID) (PART OF 7, 10) (BLACK) (SLIMLINE WASHER) (19MM OD X 11MM ID, 1/2IN DIA) (SMOOTH-SIDED) (ACDelco #15-31055)
12477570 NUT, HFH, M8X1.25X8, 10.9 (A/C EVPR TUBE)
22876353 TUBE, A/C EVPR (INCLS 5, 8, 15-18, 21, 26) (ACDelco #15-34538)
15734255 CLIP, A/C EVPR TUBE (PART OF 7) (HOLD ONE 12.6 DIAM PIPE, W/ PUSHIN RETAINER)
22876350 HOSE, A/C CNDSR (INCLS 5, 16, 24, 25) (ACDelco #15-34531)
11570082 BOLT, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (A/C CNDSR HOSE) (ACDelco #11570082)
02724966 SEAL, A/C ACCUM FRT HOSE (25MM OD X 17MM ID, 3/4IN DIA) (PART OF 14) (ACDelco #15-31101)
11570082 BOLT, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (A/C ACCUM HOSE) (ACDelco #11570082)
22876355 HOSE, A/C CMPR (INCLS 12, 26) (ACDelco #15-34529)
52458183 SEAL, A/C REFRIG SERV VLV (O RING) (9.25MM ID) (PART OF 7) (BLACK) (RUBBER) (ACDelco #15-30572)
03041827 CORE, A/C REFRIG SERV VLV (INCLS SPRING, W/O O-RING, 13/64-36 THD) (PART OF 7, 10, 17, 31) (W/O FITTING) (ACDelco #15-1119)
52458184 VALVE, A/C REFRIG SERV (PART OF 7) (INCLS 16) (M12X1.5 THD) (INCLS FITTING & SEAL) (ACDelco #15-5438)
52458768 CAP, A/C REFRIG SERV VLV (HIGH SIDE CHARGE PORT, ACCUMULATOR & EVAP TUBE) (PART OF 7, 31) (M8X1.0) (WITH SEAL) (LONG THREADED, NON-TETHERED CAP) (ACDelco #15-33289)
12477570 NUT, HFH, M8X1.25X8, 10.9 (A/C CMPR & CNDSR HOSE)
11514596 NUT, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (A/C CMPR & CNDSR HOSE) (8.915) (ACDelco #11514596)
19259601 ORIFICE, A/C CNDSR (PART OF 7) (ACDelco #15-33410)
02724966 SEAL, A/C ACCUM FRT TUBE (25MM OD X 17MM ID, 3/4IN DIA) (PART OF 31) (9.222) (ACDelco #15-31101)
12477570 NUT, HFH, M8X1.25X8, 10.9 (A/C ACCUM RET)
19188397 O-RING, 7.65MM ID, 1.78 MM THK, NEOPRENE (PART OF 10, 31) (ACDelco #15-3592)
22678731 SENSOR, A/C REFRIG PRESS (PART OF 10) (HIGH PRESSURE) (ALUMINUM W/O COATING) (ACDelco #15-50147)
03094214 O-RING, ID .426X.070 THK, MATERIAL-NEOPRENE (PART OF 7, 14) (ACDelco #15-3614)
11514623 BOLT, HEX W/CON WA, M6X1X20 (A/C ACCUM BRKT)
11588331 NUT, HEX HD W/CON WA, M6X1, 5.7THK, 25 O.D., 9, GM6138M (A/C ACCUM BRKT)
15194317 BRACKET, A/C ACCUM
20828233 ACCUMULATOR, A/C (INCLS 16, 18, 22, 24) (INCLS CORE & CAP) (ACDelco #15-11067)
52476687 INSULATOR, A/C CNDSR (PART OF 1, 4, 33) (UPPER) (6.602)
teamcadillac.ru
52481716 BRACKET, A/C CNDSR UPR (RETURN) (INLET/OUTLET) (PART OF 1) (INCLS 32) (114.5MM LONG)
52482008 BRACKET, A/C CNDSR UPR (INLET/OUTLET) (PART OF 1) (INCLS 32) (77.0MM LONG) (RETURN SIDE) (9.242)
11561065 STUD, A/C CNDSR (PART OF 1) (STRAIGHT M8X1.25X13.5, M8X1.25X27)
(TC09-700) 2007-2013 CK1,2(06) СИСТЕМА ОХЛАЖДЕНИЯ КОНДИЦИОНЕРА/REAR (C69)
19130058 HOSE, AUX A/C EVPR & AUX HTR (INCLS 2, 4, 6, 9-13) (8.846) (ACDelco #19130058)
19257318 HOSE, AUX A/C EVPR & AUX HTR (INCLS 2, 4, 6, 9-13) (KENT-MORE TUBING REPAIR KIT J41425 REQ'D FOR INSTALLATION) (ACDelco #15-33439)
52474373 SEAL, A/C EVPR TUBE (19MM OD X 11MM ID) (PART OF 1) (BLACK) (SLIMLINE WASHER) (19MM OD X 11MM ID, 1/2IN DIA) (SMOOTH-SIDED) (ACDelco #15-31055)
teamcadillac.ru
(TC09-900) 2007-2013 CK107(06) ОСУШИТЕЛЬ И ОБОГРЕВАТЕЛЬ КОНДИЦИОНЕРА ДОПОЛНИТЕЛЬНЫЙ (C69)
15920869 CASE, AUX A/C EVPR & BLO (OUTER)
15232221 BUSHING, A/C EVPR CASE
15887322 ACTUATOR, MODE VLV (ACDelco #15-73644)
11562121 BOLT, AUX A/C EVPR & BLO CASE
15887322 ACTUATOR, TEMP VLV (AUX) (ACDelco #15-73644)
20859526 EVAPORATOR, AUX A/C (ACDelco #15-63347)
02724952 SEAL, AUX A/C EVPR OTLT TUBE (5/8") (CONTAINS 2 SEALS) (9.222) (ACDelco #15-30917)
15892073 TUBE, HTR CORE (AUX) (INLET) (ACDelco #15892073)
25994366 VALVE, AUX A/C EVPR THERMAL EXPN (ACDelco #15-51146)
11562123 BOLT, A/C EVPR TXV (PAN HEAD, M5X35, 8.8 STL)
15232211 CASE, AUX A/C EVPR & BLO LWR
15189481 VALVE, AUX A/C EVPR & BLO MDL DRN (ACDelco #15-5420)
15921035 SEAL, AUX HTR CASE (ACDelco #15-33736)
11562120 STUD, HTR & A/C EVPR & BLO MDL (STUD-FLANGE, M6X1X25)
11562122 CLIP, A/C EVPR CASE (11X6.35) (9.215)
15798231 SEAL, HTR INL & OTLT PIPE (O-RING)
52474373 SEAL, AUX A/C EVPR INL TUBE (BLACK) (SLIMLINE WASHER) (19MM OD X 11MM ID, 1/2IN DIA) (SMOOTH-SIDED) (9.222) (ACDelco #15-31055)
15892072 PLATE, A/C EVPR INL TUBE BRKT BKG
15920866 VALVE, TEMP (ACDelco #15-50766)
22782134 CLIP, HTR CORE
15232212 CORE, AUX HTR (ACDelco #15-63346)
15920868 CASE, AUX A/C EVPR & BLO
13501703 MODULE, BLO MOT CONT (INCLS 23) (9.169) (ACDelco #15-81638)
25811506 HARNESS, AUX HTR & A/C WRG
15920865 MOTOR, AUX BLO (ACDelco #15-81062)
15920871 SEAL, AUX HTR AIR OTLT (ACDelco #15920871)
15814847 SEAL, AUX A/C EVPR & BLO MDL OTLT DUCT (ACDelco #15814847)
15920867 VALVE, MODE (AUX) (ACDelco #15-50767)
teamcadillac.ru
15892074 TUBE, HTR CORE (AUX) (OUTLET) (ACDelco #15892074)
11609953 STUD, A/C EVPR TXV (M8X1.25X11.5, M8X1.25X24, 46 TL, STAINLESS) (3.275)
(TC09-906) 2007-2013 CK107(06) КРЕПЛЕНИЕ КУЗОВА К РАМЕ
15924986 RETAINER, BODY BOLT
15018263 SHIM, BODY MT (3MM THICK)
15018264 SHIM, BODY MT (1.5MM THICK)
15864038 CUSHION, BODY MT UPR LOCATION #5 (WHITE)
15201791 CUSHION, BODY MT LWR LOCATION #1 (71MM OD)
11562587 BOLT, BODY (M14X2X126)
15201794 CUSHION, BODY MT UPR LOCATION #3 (PINK)
15201005 CUSHION, BODY MT UPR LOCATION #2 (ORANGE)
15201797 CUSHION, BODY BOLT UPR (LOCATION: # 1) (GREEN)
03537772 NUT, M12X1.75, 10.6THK, 28 O.D., 10, 7111M (BODY MT) (8.917)
15201791 CUSHION, BODY MT LWR FRT (71MM OD)
15837581 CUSHION, BODY MT UPR FRT (VIOLET) (1.270)
11562547 BOLT, HFH, M12X1.75X135, 100 THD, 24.7 OD, GMW25 (10.9) STL, GM 7112M, MACH (BODY MT)
11562546 WASHER, FLAT, 14X42.5X3.61 MM, SAE 1050 STL RC 37-43, 7112M (BODY MT)
(TC09-912) 2009-2013 CK1,2,3 АНТЕННА/ЦИФРОВАЯ АУДИОСИСТЕМА (U2K,UBS)
25775201 ANTENNA, RDO DIGITAL (INCLS 2) (XM ONLY ANTENNA) (ACDelco #25775201)
25815079 ANTENNA, DIGITAL RDO & M/TEL & VEH LOC (INCLS 2) (ONSTAR & XM) (ROOF MOUNTED) (ACDelco #25815079)
19208818 CABLE, DIGITAL RDO & M/TEL & VEH LOC ANT (PART OF 9) (USED IN ROOF AND DOOR HARNESSES) (ACDelco #19208818)
15201868 BRACKET, DIGITAL RDO RCVR
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (I/P CARR SUPT) (9.665)
20938347 RECEIVER, DIGITAL RDO (ACDelco #20938347)
teamcadillac.ru
20938348 RECEIVER, DIGITAL RDO (ACDelco #20938348)
19209842 CABLE, DIGITAL RDO & M/TEL & VEH LOC ANT (PART OF 7)
(TC09-915) 2007-2013 CK107(06) ВОЗДУХОРАСПРЕДЕЛИТЕЛЬНАЯ СИСТЕМА/REAR DUCTS(C69)
25897954 DUCT, AUX A/C AIR OTLT (INCLS 14)
11518531 NUT, PUSH-IN, M4.2X1.41, 15.9X8.4, .7-2.1 PNL, SAE 1050 STL, 7111M, 8.65 SQ HOL (AUX A/C AIR OTLT DUCT) (10.512)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (FLR RR AIR DISTR) (9.665)
11518531 NUT, PUSH-IN, M4.2X1.41, 15.9X8.4, .7-2.1 PNL, SAE 1050 STL, 7111M, 8.65 SQ HOL (FLR RR AIR DISTR) (10.512)
teamcadillac.ru
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (AUX HTR & A/C EVPR & BLO MDL) (9.665)
11518531 NUT, PUSH-IN, M4.2X1.41, 15.9X8.4, .7-2.1 PNL, SAE 1050 STL, 7111M, 8.65 SQ HOL (AUX HTR & A/C EVPR & BLO MDL) (10.512)
20733729 WASHER, SEALING, M5, 4 I.D., 25MM O.D., 4MM THK, RUB (RR BPR OTR FIL) (ACDelco #20733729)
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (AUX HTR & A/C EVPR & BLO MDL)
15864151 DISTRIBUTOR, FLR RR AIR (INCLS 11)
15152429 RETAINER, AMB AIR TEMP SEN (PUSH IN) (PART OF 10) (HOLE LINER TYPE)
12160947 SENSOR, DUCT AIR TEMP (37.54MM) (TWIST LOCK STYLE) (ACDelco #15-5632)
25885451 SENSOR, DUCT AIR TEMP (PUSH PIN STYLE) (ACDelco #15-51259)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (AUX A/C AIR OTLT DUCT) (9.665)
15152429 RETAINER, AMB AIR TEMP SEN (PUSH IN) (PART OF 1) (HOLE LINER TYPE)
12160947 SENSOR, DUCT AIR TEMP (TWIST LOCK STYLE) (ACDelco #15-5632)
(TC09-916) 2007-2013 CK1,2,3 ВОЗДУХОРАСПРЕДЕЛИТЕЛЬНАЯ СИСТЕМА/MODULE MOUNTING
11589183 NUT, PUSH IN, W/SEAL, 4.2X1.41, 6.35-6.48 SQ HL, 9.5 SQ HD, 0.787-2.765 PNL THK, NYL (AIR INL GRL PNL)
11609539 SCREW, RD CROWNED WA HD, M4.2X1.41X16, STL ISO 2702, GMW4205 (HDLP BZL)
15856112 VALVE, PLNM DRN
15733206 BOLT, HTR & BLO MDL (M6X2.70X27)
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (HTR & A/C EVPR & BLO MDL)
teamcadillac.ru
15138625 HOSE, A/C EVPR & BLO MDL DRN
15856113 VALVE, PLNM DRN
(TC09-920) 2007-2013 CK1(06-36) АУДИОСИСТЕМА/ПЕРЕДНЯЯ ЧАСТЬ (CADILLAC Z75)
25889857 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 1) (LINEN)
25889863 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 1) (LINEN)
25889853 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 1) (GRAY)
25889859 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 1) (GRAY)
25889861 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 1) (CASHMERE)
teamcadillac.ru
25889855 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 1)
15186674 SPEAKER, RDO W/S SI G/MLDG (PART OF 1) (ACDelco #15186674)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 1)
15221850 GRILLE, RDO FRT SPKR (INCLS 9) (EBONY)
15221851 GRILLE, RDO FRT SPKR (INCLS 9) (COCOA)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (RDO FRT SPKR) (9.665)
25798963 SPEAKER, RDO FRT (3.5") (9.665) (ACDelco #25798963)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 6)
11570654 NUT, RDO FRT S/D SPKR (4.2 X 1.41) (PUSH-IN NUT) (FITS 8.75 SQ HOLE)
15905042 SPEAKER, RDO FRT S/D (ACDelco #15905042)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (RDO FRT S/D SPKR) (9.665)
20944419 AMPLIFIER, RDO SPKR (ACDelco #20944419)
20808899 AMPLIFIER, RDO SPKR (ACDelco #20808899)
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (RDO F/FLR CNSL SPKR)
25915806 SPEAKER, RDO F/FLR CNSL (ACDelco #25915806)
11610157 NUT, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (F/FLR CNSL BRKT) (10.701)
(TC09-921) 2007-2013 CK1,2(06) АУДИОСИСТЕМА/ЗАДНЯЯ ЧАСТЬ
15186672 SPEAKER, RDO BODY RR COR UPR GARN MLDG (ACDelco #15186672)
11509253 SCREW, W/LRG WA HD, M4.2X1.4X10, 11.3 O.D., BHL PT, STL, NO (PART OF 8)
11561654 RETAINER, CTR PLR UPR G/MLDG (PART OF 8) (PLAIN) (BIRD'S BEAK SINGLE) (FITS 8.5 DIA HOLE) (12.800)
11609651 RETAINER, BODY RR COR G/MLDG (PART OF 8) (METAL PUSH-IN NUT, M4.2X1.41, 21.8X15X20.5) (14.731)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 8)
11609539 SCREW, RD CROWNED WA HD, M4.2X1.41X16, STL ISO 2702, GMW4205 (PART OF 8)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (RDO RR S/D SPKR) (9.665)
11570654 NUT, RDO RR S/D SPKR (4.2 X 1.41) (PUSH-IN NUT) (FITS 8.75 SQ HOLE)
15186669 SPEAKER, RDO RR S/D (ACDelco #15186669)
teamcadillac.ru
15201406 SPEAKER, RDO RR S/D ( MATING CONN W/LEADS USE 12101825) (ACDelco #15201406)
(TC09-924) 2007-2013 CK1,2,3 ENTERTAINMENT SYSTEM (U42, EXC DNU)
15256562 BRACKET, VIDEO DISPLAY (INCLS 4)
11518121 NUT, U, M6X1, MULTI THD, .5'-4.0' THK PNL (VIDEO DISPLAY BRKT)
11570136 BOLT, HEX HD, W/CON SPR WA, M6X1X23, 14 THD, 17 O.D., 8.8, GMW3359 (VIDEO DISPLAY BRKT)
10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (PART OF 1)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 6)
25995622 RETAINER, RF RR CNSL (INCLS 5) (DVD BACKPLATE - 2ND ROW)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 8)
22821789 MODULE, AUDIO SYS XCVR (ACDelco #22821789) (LABELLED W/OEM PN 25835387.)
20844135 DISPLAY, VIDEO (INCLS 17) (CASHMERE) (ACDelco #20844135)
20792277 DISPLAY, VIDEO (INCLS 17) (GRAY) (ACDelco #20792277)
20845907 DISPLAY, VIDEO (INCLS 17) (LINEN) (ACDelco #20845907)
20929305 CONTROL, VIDEO REM (ACDelco #20929305) (LABELED 20929305)
15190411 CONTROL, VIDEO REM (ACDelco #15190411) (LABELED 15190411)
teamcadillac.ru
20830572 HEADPHONE, (INCLS 16) (REPLCMT EAR PADS AVBLE THRU UNWIRED TECH AT 888-293-3332) (ACDelco #20830572)
19115533 PAD, HEADPHONE EAR (PART OF 14) (PKG OF 4) (FOR USE W/STD NON FOLD FLAT STYLE HDPHN ONLY)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (PART OF 11) (9.665)
(TC09-929) 2007-2013 CK1,2,3 ОГНЕТУШИТЕЛЬ BRACKET (MTF)
11609615 RIVET, DOME HD TYPE MS, 3/16X0.308 STYLE 1 MS, SAE 1006 LOW CARBON STL, ZC PER GMW3044 (FIRE EXTINGUISHER BRKT) (*KIT1)
15880833 EXTINGUISHER PKG, FIRE (INCLS 1, 2)
(TC09-939) 2010 CK1(06-36) VEHICLE INFORMATION SYSTEM (CADILLAC Z75, UL2,UUM,VFJ)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (DIGITAL RDO RCVR BRKT) (9.665)
25890523 RECEIVER, TRAFFIC INFO
teamcadillac.ru
(TC09-946) 2008-2013 CK107(06) СИСТЕМА ОХЛАЖДЕНИЯ КОНДИЦИОНЕРА/FRONT (HYBRID HP2)
11514596 NUT, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (A/C ACCUM RET) (8.915) (ACDelco #11514596)
teamcadillac.ru
02724966 SEAL, A/C ACCUM FRT HOSE (25MM OD X 17MM ID, 3/4IN DIA) (PART OF 11) (ACDelco #15-31101)
11514596 NUT, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (A/C ACCUM FRT HOSE) (8.915) (ACDelco #11514596)
52474373 SEAL, A/C CMPR & CNDSR HOSE (PART OF 9) (BLACK) (SLIMLINE WASHER) (19MM OD X 11MM ID, 1/2IN DIA) (SMOOTH-SIDED) (ACDelco #15-31055)
52476687 INSULATOR, A/C CNDSR (PART OF 16-18) (UPPER) (6.602)
52482008 BRACKET, A/C CNDSR UPR (PART OF 17) (INCLS 15) (77.0MM LONG) (RETURN SIDE) (9.242)
52482006 BRACKET, A/C CNDSR UPR (PART OF 17) (INCLS 15) (77.0MM LONG) (9.242)
52474373 SEAL, A/C CMPR & CNDSR HOSE (PART OF 25) (BLACK) (SLIMLINE WASHER) (19MM OD X 11MM ID, 1/2IN DIA) (SMOOTH-SIDED) (ACDelco #15-31055)
11514596 NUT, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (A/C CNDSR HOSE) (8.915) (ACDelco #11514596)
22678731 SENSOR, A/C REFRIG PRESS (INCLS 22) (PART OF 25) (HIGH PRESSURE) (ALUMINUM W/O COATING) (ACDelco #15-50147)
52474373 SEAL, A/C EVPR TUBE (PART OF 29) (BLACK) (SLIMLINE WASHER) (19MM OD X 11MM ID, 1/2IN DIA) (SMOOTH-SIDED) (ACDelco #15-31055)
15734255 CLIP, A/C EVPR TUBE (PART OF 29) (HOLD ONE 12.6 DIAM PIPE, W/ PUSHIN RETAINER)
20911239 CAP, A/C REFRIG SERV VLV (PART OF 29) (M8X1.0) (SHORT THREADED, TETHERED CAP) (ACDelco #15-34400)
20911240 CAP, A/C REFRIG SERV VLV (PART OF 29) (M10X0.75) (LONG THREADED, TETHERED CAP) (ACDelco #15-34401)
11514623 BOLT, HEX W/CON WA, M6X1X20 (PART OF 1, 38)
02724966 SEAL, A/C ACCUM FRT TUBE (25MM OD X 17MM ID, 3/4IN DIA) (PART OF 1) (9.222) (ACDelco #15-31101)
11561065 STUD, A/C CNDSR (PART OF 17) (STRAIGHT M8X1.25X13.5, M8X1.25X27)
(TC09-950) 2008-2013 CK1(06) ENTERTAINMENT SYSTEM (CADILLAC Z75, PLATINUM EDITION ULT, HEADREST PLAYER AYE)
20807057 RESTRAINT, D/SEAT HD (COCOA)
20807059 RESTRAINT, P/SEAT HD (COCOA) (INCLS CONNCTION CABLES)
teamcadillac.ru
20795513 PLAYER PKG, VIDEO DISC (W/VIDEO DISPLAY) (ACDelco #20795513)
20896154 PLAYER PKG, VIDEO DISC (W/VIDEO DISPLAY) (ACDelco #20896154)
20896155 PLAYER PKG, VIDEO DISC (W/VIDEO DISPLAY) (ACDelco #20896155)
20807055 PLAYER PKG, VIDEO DISC (W/VIDEO DISPLAY) (ACDelco #20807055)
22840154 PLAYER PKG, VIDEO DISC (W/VIDEO DISPLAY) (ACDelco #22840154)
22840149 PLAYER PKG, VIDEO DISC (W/VIDEO DISPLAY) (ACDelco #22840149)
25865992 MODULE, AUDIO/VIDEO INTERFACE (ACDelco #25865992)
19159658 CABLE KIT, AUDIO & VIDEO MDL (0.32 KGS) (INCLS CABLES 3A & 3B USED TO CONN HD RESTS TO CTRL BOX) (0.029)
25865990 CONTROL, VIDEO REM (INCLS 8) (ACDelco #25865990)
22754231 HEADPHONE, (3-4 CHANNEL)
25865993 HARNESS, AUDIO PLYR WRG (ACDelco #25865993)
(TC09-951) 2009-2013 CK1,2(06-36) СИСТЕМА СВЯЗИ ("ONSTAR" UE1)
15241529 MICROPHONE, MOBILE TEL (PART OF 2) (2-WAY CAVITY)
25815079 ANTENNA, DIGITAL RDO & M/TEL & VEH LOC (INCLS 4) (ONSTAR & XM) (ROOF MOUNTED) (ACDelco #25815079)
20850446 ANTENNA, DIGITAL RDO & M/TEL & VEH LOC (INCLS 4) (W/3-WAY CONN W/ONLY 2 LEADS) (ACDelco #20850446)
15779345 COVER, I/S RR VIEW MIR WRG HARN (BETWEEN ISRVM & HDLNG TRIM)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (COMN INTERFACE MDL BRKT) (9.665)
11610157 NUT, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (COMMUNICATION INTERFACE MDL BRKT) (10.701)
25791895 BRACKET, COMMUNICATION INTERFACE MDL
20829983 MODULE, COMN INTERFACE (W/MOBILE TEL XCVR) (LABELED 20829983) (ACDelco #20829983)
20829984 MODULE, COMN INTERFACE (W/MOBILE TEL XCVR) (LABELED 20829984) (ACDelco #20829984)
20923563 MODULE, COMN INTERFACE (W/MOBILE TEL XCVR) (LABELED 20923563) (ACDelco #20923563)
22850735 MODULE, COMN INTERFACE (W/MOBILE TEL XCVR) (ACDelco #22850735) (LABELED 22850735)
15938939 ANTENNA, WIRELESS COMN INTERFACE (BLUETOOTH) (ACDelco #15938939)
teamcadillac.ru
19117898 CABLE, DIGITAL RDO & M/TEL & VEH LOC ANT (9.675) (ACDelco #19117898)
19208818 CABLE, DIGITAL RDO & M/TEL & VEH LOC ANT (PART OF 14) (USED IN ROOF AND DOOR HARNESSES) (ACDelco #19208818)
(TC09-956) 2008-2010 CK1,2(06) БЛОК КОНДИЦИОНЕРА И ОБОГРЕВАТЕЛЯ В СБОРЕ (AUTO TEMPERATURE CONTROL CJ2)
89018306 VALVE, TEMP
20834824 HARNESS, A/C MDL WRG
20883395 CASE, HTR & A/C EVPR & BLO LWR (NEED TO USE W/MOTOR 22741027 & DUCT 20883403)
13501703 MODULE, BLO MOT CONT (9.169) (ACDelco #15-81638)
teamcadillac.ru
20883403 DUCT, HTR & A/C EVPR & BLO MDL CLG (INCLS 20) (*KIT2) (IF SCREWS REQ'D, USE PN 11609829 (QTY 3))
22741027 MOTOR, BLO (INCLS 21, 23) (9.215) (ACDelco #15-81683) (USE T/W DUCT 20883403)
89019027 EVAPORATOR, A/C (ACDelco #15-62961)
89018295 SEAL, A/C EVPR (ACDelco #89018295)
89018365 ACTUATOR, TEMP VLV (ACDelco #15-72971)
22819113 INLET, AIR (*KIT4)
89018612 STUD, HTR & A/C EVPR & BLO MDL (M6X1X33MM TORX/COLR)
20834819 CASE, HTR & A/C EVPR & BLO UPR (INCLS 7)
89018299 CASE, HTR
11609829 BOLT, A/C EVPR TUBE CLIP (M4.2X2.25X16) (9.786)
89018297 CORE, HTR (INCLS 35, 36) (INCLS 2 SEALS) (ACDelco #15-62960)
52474960 LEVER, MODE VLV
89018304 VALVE, DEFR (ACDelco #15-50561)
89018307 VALVE, TEMP
89018302 SHIELD, HTR & A/C EVPR & BLO MDL HT
25953349 SENSOR, A/C REFRIG TEMP (ACDelco #15-51267)
89018374 ACTUATOR, MODE CONT CAM (INCLS 9, 10) (ACDelco #15-73952)
22741027 MOTOR, BLO (INCLS 19-21, 23) (ACDelco #15-81683)
89018784 SEAL KIT, HTR & A/C EVPR & BLO MDL (INCLS 5, 29, 31-33, 35, 36) (ACDelco #15-34397)
22819113 INLET, AIR (INCLS 27-29)
(TC09-957) 2010-2013 CK1,2(06) АНТЕННА
25994421 CABLE, RDO ANT (ACDelco #25994421)
11561711 BOLT, RDO ANT MDL (9.665)
25943786 MODULE, RDO ANT (ACDelco #25943786)
teamcadillac.ru
15045800 COVER, RDO ANT OPG
15256489 WIRE, RDO NOISE SUPPR GND (ACDelco #15256489)
11516885 SCREW, HFH W/FL WA, TAP, M8X1.25X20, 7THD, 17 O.D., TR PT, 6202M, PZOR (RDO NOISE SUPPR GND)
(TC09-962) 2010-2013 CK1(06-36) ВОЗДУХОРАСПРЕДЕЛИТЕЛЬНАЯ СИСТЕМА/FRONT DUCTS (CADILLAC Z75, AUTO TEMPERATURE CONTROL CJ2)
15289716 DUCT, SI WDO DEFG OTLT
teamcadillac.ru
11610157 NUT, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (I/P COMPT) (10.701)
15935349 DUCT, SI WDO DEFG OTLT
25885451 SENSOR, DUCT AIR TEMP (PART OF 8) (PUSH PIN STYLE) (ACDelco #15-51259)
25992392 DUCT, AIR DISTR (INCLS 2, 4, 7)
15152429 RETAINER, AMB AIR TEMP SEN (PUSH IN) (PART OF 12) (HOLE LINER TYPE)
12160947 SENSOR, DUCT AIR TEMP (37.54MM) (PART OF 12) (FOR SENSOR W/TWIST LOCK FEATURE, W/RETAINER, 2ND DES 25885451) (TWIST LOCK STYLE) (ACDelco #15-5632)
15762756 DUCT, FLR AIR OTLT (INCLS 10, 11, 14)
11517774 BOLT, HEX, M4.2X1.41X20, 14.25 OD, 6010M, 6138M, TAP, AB-PT (FLR AIR OTLT DUCT)
25872373 DUCT, FLR RR AIR OTLT
10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (PART OF 17)
15951532 DUCT, FLR FRT AIR OTLT (INCLS 16)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (PART OF 19) (9.665)
11518531 NUT, PUSH-IN, M4.2X1.41, 15.9X8.4, .7-2.1 PNL, SAE 1050 STL, 7111M, 8.65 SQ HOL (PART OF 18) (10.512)
(TC09-963) 2009-2013 CK1,2,3 ДАТЧИК ТЕМПЕРАТУРЫ AMBIENT(CJ2)
15826773 SENSOR, AMB AIR TEMP (WITH PUSH-IN/ATTACHMENT) (ACDelco #15-51150)
teamcadillac.ru
(TX09-016) 2010-2011 CK1 КРЕПЛЕНИЕ КОМПРЕССОРА КОНДИЦИОНЕРА (L20/4.8A,LMG/5.3-0,LC9/5.3-3,L9H/6.2-2,L94/6.2F)
12554026 BRACKET, A/C CMPR
11515767 BOLT, HFH, M10X1.5X35, 32THD, 22.3 O.D., MACH, 10.9, 7114M (A/C CMPR BRKT) (T/W 12345493)
teamcadillac.ru
11516109 BOLT, HFH, REDUCED BODY, M10X1.5X65, 25 THD, 22.3 O.D., HDR PT, 10.9, 7114M (A/C CMPR)
11516503 BOLT, HFH, M10X1.5X45, 33 THD, P-PT, 9.8, 7114M (A/C CMPR)
16 - ДЕТАЛИ КУЗОВА-СТЕКЛООЧИСТИТЕЛИ-ЗЕРКАЛА-ДВЕРИ-ОТДЕЛКА-РЕМНИ БЕЗОПАСНОСТИ
(MW10-005) 2007-2013 CK1,2,3 ЦИЛИНДР ЗАМКА/ДВЕРЬ
teamcadillac.ru
20825032 CYLINDER KIT, FRT S/D LK (UNCODED) (INCLS 2-4, 6-12)
(TC16-213) 2010-2013 K1(06) КОНСОЛЬ/КРЫША (CADILLAC Z75, CF5, EXC UG1)
25786403 SWITCH, SUN RF (PART OF 4) (EBONY) (BLUE LAGOON BACK LIGHTING)
25786404 SWITCH, SUN RF (PART OF 4) (TRUE WHITE BACK LIGHTING)
15241529 MICROPHONE, MOBILE TEL (PART OF 4) (2-WAY CAVITY)
25845571 SWITCH, L/GATE ACTR (PART OF 4) (PART OF RF CONSOLE)
25851515 CONSOLE, RF (INCLS 1-3, 5-8, 10-13) (LINEN) (2ND ROW)
25807194 CONSOLE, RF (INCLS 1-3, 5-8, 10-13) (GRAY)
25977565 CONSOLE, RF (INCLS 1-3, 5-8, 10-13) (CASHMERE)
20858773 CONSOLE, RF (INCLS 1-3, 5-8, 10-13) (LINEN)
teamcadillac.ru
15853948 PUSHBUTTON, RDG LP SW (PART OF 4) (AT CONSOLE)
15911049 LENS, DM LP (PART OF 4) (1ST ROW)
09431809 BULB, 6CP TRADE #212-2 (PART OF 4) (ACDelco #L212-2)
11516630 BOLT, RF CNSL (PART OF 4) (M4.2X1.41X20) (8.977)
25828898 DISPLAY, I/P AIRBAG ARMING STATUS (W/WORDS ON AND OFF FOR AIRBAG)
25828899 DISPLAY, I/P AIRBAG ARMING STATUS (W/AIRBAG SYMBOLS FOR ON AND OFF)
11609345 NUT, PUSH-IN, 4.2, SAE 1050 STL, GMW3179 (PART OF 4)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 4)
(TC16-245) 2009-2013 CK107(06) ОТДЕЛКА ВНУТРЕННЯЯ-BODY SIDE-LH QUARTER DETAIL (HYBRID HP2, CADILLAC Z75)
15838270 HOLDER, R/SEAT CUP (PART OF 3) (TITANIUM)
15936706 HOLDER, R/SEAT CUP (PART OF 3) (LINEN)
15838268 HOLDER, R/SEAT CUP (PART OF 3) (EBONY)
15838269 HOLDER, R/SEAT CUP (PART OF 3) (CASHMERE)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 3)
15294093 PANEL, BODY SI TR (INCLS 1, 2, 12) (TITANIUM) (INCLS HIGH VOLTAGE PWR OUTLET 25858121) (W/LATCH)
15885778 PANEL, BODY SI TR (INCLS 1, 2, 12) (TITANIUM) (W/O LATCH)
15294091 PANEL, BODY SI TR (INCLS 1, 2, 12) (CASHMERE) (INCLS HIGH VOLTAGE PWR OUTLET 25858121)
15904065 PANEL, BODY SI TR (INCLS 1, 2, 12) (EBONY)
25902628 PANEL, BODY SI TR (INCLS 1, 2, 12) (CASHMERE)
20765250 PANEL, BODY SI TR (INCLS 1, 2, 12) (LINEN)
15901363 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (GRAY)
15862682 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (CASHMERE) (W/O SPKR) (MOLDING ONLY)
15901352 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (CASHMERE) (W/O SPEAKER)
25815096 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (GRAY) (W/SPKR)
25818939 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (GRAY) (W/SPKR)
25818940 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (CASHMERE) (W/SPKR)
25886908 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (CASHMERE) (W/SPEAKER)
15862681 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (GRAY) (W/O SPKR) (MOLDING ONLY)
25827851 PLUG, BODY RR COR UPR GARN MLDG (PART OF 4) (LINEN)
15278015 PLUG, BODY RR COR UPR GARN MLDG (PART OF 4) (LT CHASHMERE)
15278014 PLUG, BODY RR COR UPR GARN MLDG (PART OF 4) (GRAY)
11609539 SCREW, RD CROWNED WA HD, M4.2X1.41X16, STL ISO 2702, GMW4205 (PART OF 4)
11509253 SCREW, W/LRG WA HD, M4.2X1.4X10, 11.3 O.D., BHL PT, STL, NO (PART OF 4)
15186672 SPEAKER, RDO BODY RR COR UPR GARN MLDG (PART OF 4) (ACDelco #15186672)
teamcadillac.ru
11561654 RETAINER, BODY RR COR G/MLDG (PART OF 4) (PLAIN) (BIRD'S BEAK SINGLE) (FITS 8.5 DIA HOLE) (12.800)
11609651 RETAINER, BODY RR COR G/MLDG (PART OF 4) (METAL PUSH-IN NUT, M4.2X1.41, 21.8X15X20.5) (14.731)
25858121 RECEPTACLE, ACSRY PWR (PART OF 3) (110 VOLT) (ACSRY PWR RECEPTACLE ASSEM LABELED 25858121)
(TC16-265) 2010-2011 CK1(06) КОНСОЛЬ/ПОЛ (CADILLAC Z75, EXC PLATINUM EDITION ULT)
11609509 SCREW, LG RD WA HD, C/R, HI-LO, 4.2X1.41X13, 11.35-OD, B PT, 6010, GMW4205 (PART OF 1)
15886900 MODULE, HTR & A/C & RDO CONT
10375379 ADAPTER, AUDIO/VIDEO DISC PLYR (ACDelco #10375379)
22596346 BUMPER, F/FLR RR CNSL A/RST (W/DURAMETER 30) (LENGTH 29MM) (10.242)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (F/FLR CNSL SI T/PNL)
15833953 COVER, HTR & A/C CONT OPG
20983936 RETAINER, ACSRY PWR RCPT (EBONY) (FOR 2010&FUTURE W/USR WHEN REPL 25793816 USE T/W CVR 20983937) (ALUMINUM RING) (W/O USB COVER)
25774623 RECEPTACLE, ACSRY PWR (EBONY) (W/O COVER) (ACSRY PWR RECEPTACLE ASSEM LABELED 25774623) (12V)
15133100 LINER, F/FLR CNSL RR CUP HLDR (PART OF 19)
11609509 SCREW, LG RD WA HD, C/R, HI-LO, 4.2X1.41X13, 11.35-OD, B PT, 6010, GMW4205 (PART OF 36)
11589106 SCREW, RND WA HD, M4.2X1.41X25, 19.2 THD, 11.3 OD, 6010M, GMW4205, C/R, TAP, (PART OF 36) (10.774)
teamcadillac.ru
11609509 SCREW, LG RD WA HD, C/R, HI-LO, 4.2X1.41X13, 11.35-OD, B PT, 6010, GMW4205 (PART OF 19)
15133101 BUSHING, F/FLR CNSL CUP HLDR DR HGE (PART OF 19)
15133093 HOLDER, F/FLR CNSL RR CUP (INCLS 13, 17, 18)
20888557 HARNESS, F/FLR CNSL WRG
22825331 HARNESS, F/FLR CNSL WRG
11562473 BOLT, F/SEAT (M12X1.75X45)
15035434 NUT, F/SEAT (M10X1.5X10.8) (FLANGE NUT) (16.679)
15220791 PANEL, F/FLR CNSL SI TR (PART OF 36) (INCLS 32) (EBONY)
15220793 PANEL, F/FLR CNSL SI TR (PART OF 36) (INCLS 32) (EBONY)
25906812 PANEL, F/FLR CNSL SI TR (PART OF 36) (INCLS 32) (CASHMERE)
25906813 PANEL, F/FLR CNSL SI TR (PART OF 36) (INCLS 32) (CASHMERE)
15238666 PANEL, F/FLR CNSL SI TR FRT (INCLS 30, 31) (SEE GROUP 16.000 "INSTRUMENT PANEL/TRIM" FOR DETAILED ILLUSTRATED VIEW.) (EBONY) (16.081)
25901544 PANEL, F/FLR CNSL SI TR FRT (INCLS 30, 31) (SEE GROUP 16.000 "INSTRUMENT PANEL/TRIM" FOR DETAILED ILLUSTRATED VIEW.) (CASHMERE)
25844279 PANEL, F/FLR CNSL SI TR FRT (INCLS 30, 31) (SEE GROUP 16.000 "INSTRUMENT PANEL/TRIM" FOR DETAILED ILLUSTRATED VIEW.) (EBONY)
25901545 PANEL, F/FLR CNSL SI TR FRT (INCLS 30, 31) (SEE GROUP 16.000 "INSTRUMENT PANEL/TRIM" FOR DETAILED ILLUSTRATED VIEW.) (CASHMERE)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 29)
11562257 RETAINER, I/P LWR TR PAD BRKT (PUSH ON) (PART OF 29) (19.5 X 30.4 X 1.8) (14.683)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 28, 36)
15187371 RETAINER, ACSRY PWR RCPT (PART OF 36) (EBONY) (INCLS COVER)
25774623 RECEPTACLE, ACSRY PWR (PART OF 36) (EBONY) (W/O COVER) (ACSRY PWR RECEPTACLE ASSEM LABELED 25774623) (12V)
20898108 COMPARTMENT, F/FLR (INCLS 14-16, 21, 22, 24, 25, 28, 32-35, 47) (EBONY)
20898109 COMPARTMENT, F/FLR (INCLS 14-16, 21, 22, 24, 25, 28, 32-35, 47) (CASHMERE)
20898112 COMPARTMENT, F/FLR (INCLS 14-16, 21, 22, 24, 25, 28, 32-35, 47) (CASHMERE)
20898117 COMPARTMENT, F/FLR (INCLS 14-16, 21, 22, 24, 25, 28, 32-35, 47) (EBONY)
20898118 COMPARTMENT, F/FLR (INCLS 14-16, 21, 22, 24, 25, 28, 32-35, 47) (CASHMERE)
20898120 COMPARTMENT, F/FLR (INCLS 14-16, 21, 22, 24, 25, 28, 32-35, 47) (EBONY)
20898121 COMPARTMENT, F/FLR (INCLS 14-16, 21, 22, 24, 25, 28, 32-35, 47) (CASHMERE)
20944039 COMPARTMENT, F/FLR (INCLS 14-16, 21, 22, 24, 25, 28, 32-35, 47) (EBONY)
11609460 SCREW, RND WA, M4.2X1.41X10, 4.2 THD, 11 OD, GM6010M, GMW4205, C/R, TAP (PART OF 39)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 39)
20907562 BEZEL, F/FLR FRT CNSL ACSRY TR (INCLS 37, 38, 40-43, 45, 46) (RUBY)
20907563 BEZEL, F/FLR FRT CNSL ACSRY TR (INCLS 37, 38, 40-43, 45, 46) (CHOCOLATE BURL)
15683368 BUMPER, F/FLR CNSL COMPT DR (PART OF 39) (16MM STEM, 8MM DIA) (CLOSED-STOP) (FRAME)
22596346 BUMPER, F/FLR CNSL CUP HLDR (PART OF 39) (W/DURAMETER 30) (LENGTH 29MM) (10.242)
15132973 ASHTRAY, F/FLR CNSL (PART OF 39)
15132964 HOLDER, F/FLR CNSL CUP (PART OF 39)
11516140 LIGHTER, CIG (BLACK) (W/LARGE PLASTIC KNOB END 21.0MM)
25776667 RECEPTACLE, ACSRY PWR (PART OF 39) (2 TERMINALS)
20983936 RETAINER, ACSRY PWR RCPT (PART OF 39) (EBONY) (FOR 2010&FUTURE W/USR WHEN REPL 25793816 USE T/W CVR 20983937) (ALUMINUM RING) (W/O USB COVER)
20944418 RECEPTACLE, USB (PART OF 36)
(TC16-271) 2010-2011 CK1(06) КОНСОЛЬ/ПОЛ (CADILLAC Z75, PLATINUM EDITION ULT)
11609509 SCREW, LG RD WA HD, C/R, HI-LO, 4.2X1.41X13, 11.35-OD, B PT, 6010, GMW4205 (PART OF 39)
15886900 MODULE, HTR & A/C & RDO CONT (ACDelco #15886900)
22596346 BUMPER, F/FLR RR CNSL A/RST (PART OF 39) (W/DURAMETER 30) (LENGTH 29MM) (10.242)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 10)
teamcadillac.ru
15833953 COVER, HTR & A/C CONT OPG (INCLS 9)
10364311 DOOR, ACSRY PWR RCPT (CHROME RING W/BLACK CAP)
15133100 LINER, F/FLR CNSL RR CUP HLDR (PART OF 14, 39)
15133093 HOLDER, F/FLR CNSL RR CUP (INCLS 13, 18, 19) (PART OF 39)
11589106 SCREW, RND WA HD, M4.2X1.41X25, 19.2 THD, 11.3 OD, 6010M, GMW4205, C/R, TAP, (PART OF 39) (10.774)
11609509 SCREW, LG RD WA HD, C/R, HI-LO, 4.2X1.41X13, 11.35-OD, B PT, 6010, GMW4205 (PART OF 14, 39)
15133101 BUSHING, F/FLR CNSL CUP HLDR DR HGE (PART OF 14, 39)
20888557 HARNESS, F/FLR CNSL WRG (PART OF 39)
20888559 HARNESS, F/FLR CNSL WRG (PART OF 39)
22825331 HARNESS, F/FLR CNSL WRG (PART OF 39)
20944419 AMPLIFIER, RDO SPKR (PART OF 39) (ACDelco #20944419)
25830462 PANEL, F/FLR CNSL SI TR (INCLS 34) (PART OF 39) (COCOA)
25830464 PANEL, F/FLR CNSL SI TR (INCLS 34) (PART OF 39) (COCOA)
25830634 DUCT, AIR INL (PART OF 39)
15876585 PANEL, F/FLR CNSL SI TR FRT (INCLS 32, 33) (SEE GROUP 16.000 "INSTRUMENT PANEL/TRIM" FOR DETAILED ILLUSTRATED VIEW) (LINEN)
15876587 PANEL, F/FLR CNSL SI TR FRT (INCLS 32, 33) (SEE GROUP 16.000 "INSTRUMENT PANEL/TRIM" FOR DETAILED ILLUSTRATED VIEW) (LINEN)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 31)
11562257 RETAINER, I/P LWR TR PAD BRKT (PUSH ON) (PART OF 31) (19.5 X 30.4 X 1.8) (14.683)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 28, 39)
15187371 RETAINER, ACSRY PWR RCPT (PART OF 39) (EBONY) (INCLS COVER)
25774623 RECEPTACLE, ACSRY PWR (PART OF 39) (EBONY) (W/O COVER) (ACSRY PWR RECEPTACLE ASSEM LABELED 25774623) (12V)
20898103 COMPARTMENT, F/FLR (INCLS 2-4, 8, 13-25, 28-30, 34, 35, 37, 38, 50) (COCOA)
22876532 COMPARTMENT, F/FLR (INCLS 2-4, 8, 13-25, 28-30, 34, 35, 37, 38, 50) (LINEN)
11609460 SCREW, RND WA, M4.2X1.41X10, 4.2 THD, 11 OD, GM6010M, GMW4205, C/R, TAP (PART OF 43)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 43)
20907565 BEZEL, F/FLR FRT CNSL ACSRY TR (INCLS 36, 40-42, 44-46, 48, 49) (SOLITARE)
15683368 BUMPER, F/FLR CNSL COMPT DR (PART OF 43) (16MM STEM, 8MM DIA) (CLOSED-STOP) (FRAME)
10446032 BUMPER, F/FLR CNSL COMPT DR (PART OF 43) (8.80 DIA) (CLOSED-STOP) (FRAME) (10.263)
15132973 ASHTRAY, F/FLR CNSL (PART OF 43)
25776667 RECEPTACLE, C/LTR (PART OF 43) (2 TERMINALS)
20983936 RETAINER, ACSRY PWR RCPT (PART OF 43) (EBONY) (FOR 2010&FUTURE W/USR WHEN REPL 25793816 USE T/W CVR 20983937) (ALUMINUM RING) (W/O USB COVER)
20944418 RECEPTACLE, USB (PART OF 39)
(TC16-315) 2008-2013 CK107(06) КРЕПЛЕНИЕ ЗАДНЕГО СИДЕНЬЯ (60/40 BENCH AM8, HYBRID HP2)
25906782 COVER, R/SEAT RSR FIN (INCLS 2, 3, 11) (CASHMERE) (MAIN COVER)
25947245 COVER, R/SEAT RSR FIN (INCLS 2, 3, 11) (TITANIUM)
20848509 COVER, R/SEAT RSR FIN (INCLS 2, 3, 11) (COCOA)
20986822 COVER, R/SEAT RSR FIN (INCLS 2, 3, 11) (EBONY)
25813593 COVER, R/SEAT RSR INR FIN (PART OF 1) (EBONY)
25813595 COVER, R/SEAT RSR INR FIN (PART OF 1) (TITANIUM)
20820025 COVER, R/SEAT RSR INR FIN (PART OF 1) (LINEN)
25813594 COVER, R/SEAT RSR INR FIN (PART OF 1) (CASHMERE)
11509253 SCREW, W/LRG WA HD, M4.2X1.4X10, 11.3 O.D., BHL PT, STL, NO (PART OF 1)
20761380 SEAT, RR (EBONY)
20761383 SEAT, RR (EBONY)
15843772 SEAT, RR (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960236)
15843847 SEAT, RR (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960254)
15914185 SEAT, RR (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20959983)
15914187 SEAT, RR (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20959985)
25835080 SEAT, RR (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960239)
25835089 SEAT, RR (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960257)
25908002 SEAT, RR (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960240)
25908006 SEAT, RR (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960258)
15843802 SEAT, RR (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960272)
15843859 SEAT, RR (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960281)
25835185 SEAT, RR (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960284)
20789565 SEAT, RR (COCOA)
20789567 SEAT, RR (COCOA)
20905015 SEAT, RR (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960038)
20905016 SEAT, RR (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960039)
20905021 SEAT, RR (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960041)
20905022 SEAT, RR (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960042)
20761372 SEAT, RR (EBONY)
20761373 SEAT, RR (CASHMERE)
20761374 SEAT, RR (TITANIUM)
20761376 SEAT, RR (EBONY)
20761377 SEAT, RR (CASHMERE)
20761378 SEAT, RR (TITANIUM)
20761381 SEAT, RR (CASHMERE)
20761384 SEAT, RR (CASHMERE)
20959983 SEAT, RR (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 15914185)
20959985 SEAT, RR (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 15914187)
20960038 SEAT, RR (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 20905015)
20960039 SEAT, RR (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 20905016)
20960041 SEAT, RR (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 20905021)
20960042 SEAT, RR (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 20905022)
20960236 SEAT, RR (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 15843772)
20960237 SEAT, RR (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25908001)
20960239 SEAT, RR (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25835080)
20960240 SEAT, RR (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25908002)
20960254 SEAT, RR (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 15843847)
20960255 SEAT, RR (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25908005)
20960257 SEAT, RR (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25835089)
20960258 SEAT, RR (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25908006)
25908001 SEAT, RR (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960237)
25908005 SEAT, RR (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960255)
20795283 SEAT, RR (EBONY)
20795284 SEAT, RR (CASHMERE)
20795286 SEAT, RR (EBONY)
20795287 SEAT, RR (CASHMERE)
20830606 SEAT, RR (EBONY)
20830607 SEAT, RR (CASHMERE)
20830609 SEAT, RR (EBONY)
20830610 SEAT, RR (CASHMERE)
20960272 SEAT, RR (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 15843802)
20960273 SEAT, RR (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25908009)
20960275 SEAT, RR (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25835182)
20960276 SEAT, RR (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25908010)
20960281 SEAT, RR (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 15843859)
20960282 SEAT, RR (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25908011)
20960284 SEAT, RR (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25835185)
20960285 SEAT, RR (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25908012)
25835182 SEAT, RR (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960275)
25908009 SEAT, RR (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960273)
25908010 SEAT, RR (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960276)
25908011 SEAT, RR (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960282)
25908012 SEAT, RR (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960285)
25947239 COVER, R/SEAT FRM OTR FIN (INCLS 6, 7) (EBONY)
teamcadillac.ru
25947241 COVER, R/SEAT FRM OTR FIN (INCLS 6, 7) (TITANIUM)
25947240 COVER, R/SEAT FRM OTR FIN (INCLS 6, 7) (CASHMERE)
20848508 COVER, R/SEAT FRM OTR FIN (INCLS 6, 7) (COCOA)
15894130 LABEL, BAT (PART OF 5)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 5)
03537772 NUT, M12X1.75, 10.6THK, 28 O.D., 10, 7111M (R/SEAT) (8.917)
25898240 COVER, R/SEAT FRM FRT FIN (INCLS 9) (TITANIUM)
25924173 COVER, R/SEAT FRM FRT FIN (INCLS 9) (EBONY)
20848507 COVER, R/SEAT FRM FRT FIN (INCLS 9) (COCOA)
25924174 COVER, R/SEAT FRM FRT FIN (INCLS 9) (CASHMERE)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 1)
(TC16-333) 2008-2013 CK1,2(06) ЗАДНЕЕ СИДЕНЬЕ #2 (3RD ROW)-RH(AS3)
22760806 SEAT, 3RD ROW (INCLS 2-46) (EBONY)
22760807 SEAT, 3RD ROW (INCLS 2-46) (CASHMERE)
22760812 SEAT, 3RD ROW (INCLS 2-46) (EBONY)
22760813 SEAT, 3RD ROW (INCLS 2-46) (CASHMERE)
22760815 SEAT, 3RD ROW (INCLS 2-46) (EBONY)
22760816 SEAT, 3RD ROW (INCLS 2-46) (CASHMERE)
22760821 SEAT, 3RD ROW (INCLS 2-46) (EBONY)
22760822 SEAT, 3RD ROW (INCLS 2-46) (CASHMERE)
22760835 SEAT, 3RD ROW (INCLS 2-46) (EBONY)
22760843 SEAT, 3RD ROW (INCLS 2-46) (EBONY)
22760849 SEAT, 3RD ROW (INCLS 2-46) (COCOA)
22760853 SEAT, 3RD ROW (INCLS 2-46) (COCOA)
22760829 SEAT, 3RD ROW (INCLS 2-46) (COCOA)
22760886 SEAT, 3RD ROW (INCLS 2-46) (EBONY)
22760887 SEAT, 3RD ROW (INCLS 2-46) (CASHMERE)
15804529 PAD, 3RD ROW SEAT BK
15863451 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
15863452 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE)
15865842 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
15833506 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE)
15833505 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
15863458 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
15863459 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE)
20904837 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
20904838 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE)
20904931 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE)
15913991 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
15827642 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
15279353 GUIDE, 3RD ROW SEAT H/RST (TITANIUM) (W/O BUTTON)
25851751 GUIDE, 3RD ROW SEAT H/RST (COCOA) (W/O BUTTON)
20912677 GUIDE, 3RD ROW SEAT H/RST (COCOA) (W/BUTTON)
20912675 GUIDE, 3RD ROW SEAT H/RST (CASHMERE) (W/BUTTON)
20912676 GUIDE, 3RD ROW SEAT H/RST (TITANIUM) (W/BUTTON)
15804525 GUIDE, 3RD ROW SEAT H/RST (EBONY)
25943771 GUIDE, 3RD ROW SEAT H/RST (COCOA)
25869335 BRACKET, R/SEAT 3RD ROW BELT (RETR SI)
11570116 SCREW, PAN HD, M6X1X10, 10 THD, 12 OD, STL SAE J1237, S424, TAPTITE ITE (R/SEAT RSR FIN CVR) (8.913)
15827662 COVER, R/SEAT HGE FIN (OUTBOARD)
15827667 COVER, R/SEAT HGE FIN (INBOARD)
19207592 BELT KIT, R/SEAT #2 CTR (RETR SI) (INCLS 8) (CASHMERE)
19207593 BELT KIT, R/SEAT #2 CTR (RETR SI) (INCLS 8) (COCOA)
19207590 BELT KIT, R/SEAT #2 CTR (RETR SI) (INCLS 8) (CASHMERE)
19207591 BELT KIT, R/SEAT #2 CTR (RETR SI) (INCLS 8) (TITANIUM)
19207589 BELT KIT, R/SEAT #2 CTR (RETR SI) (INCLS 8) (EBONY)
15898352 BELT, 3RD ROW CTR SEAT BELT (INCLS 8) (EBONY)
25906826 BELT, 3RD ROW CTR SEAT BELT (INCLS 8) (CASHMERE)
25940416 BELT, 3RD ROW CTR SEAT BELT (INCLS 8) (COCOA)
11562382 BOLT, HFH, M10X1.5X130, 26 THD, 22.3 OD, 10.9, 7114M, MACH, MAT-PT (3RD ROW SEAT BK)
11562383 BOLT, 3RD ROW SEAT BELT ANC (M12X1.75X30.5) (8.900)
15898362 FRAME, 3RD ROW SEAT BK
25960399 FRAME, 3RD ROW SEAT BK
15898399 FRAME, 3RD ROW SEAT BK
teamcadillac.ru
20963262 KNOB, 3RD ROW SEAT BK LAT REL (EBONY) (OUTER)
20963265 KNOB, 3RD ROW SEAT BK LAT REL (EBONY) (INNER) (W/NUMBER LABELS ON 3RD ROW SEAT) (FOR 1ST DES SEE 15279464)
15279464 KNOB, 3RD ROW SEAT BK LAT REL (EBONY) (16.716) (W/O NUMBER LABELS ON 3RD ROW SEAT) (FOR 2ND DES SEE 20963265)
19180590 BELT KIT, R/SEAT #2 (BKL SI) (COCOA)
19152523 BELT KIT, R/SEAT #2 (BKL SI) (CASHMERE) (SINGLE BKL)
19152524 BELT KIT, R/SEAT #2 (BKL SI) (TITANIUM) (SINGLE BKL)
19152522 BELT KIT, R/SEAT #2 (BKL SI) (EBONY) (SINGLE BKL)
15832214 LEVER, R/SEAT RSR LAT REL
25913455 LATCH, 3RD ROW SEAT BK (CENTER)
15944449 COVER, 3RD ROW SEAT BK LAT (EBONY) (INBOARD, OUTER)
15944450 COVER, 3RD ROW SEAT BK LAT (CASHMERE) (INBOARD, OUTER)
15804522 COVER, 3RD ROW SEAT BK LAT (TITANIUM) (INBOARD, OUTER) (16.716)
25858774 COVER, 3RD ROW SEAT BK LAT (COCOA) (INBOARD, OUTER)
19127809 BOLT, 3RD ROW SEAT BK LAT (M12X1.75X63.9) (16.679)
15822384 COVER, 3RD ROW SEAT BK HGE FIN (EBONY)
15822385 COVER, 3RD ROW SEAT BK HGE FIN (CASHMERE)
15822386 COVER, 3RD ROW SEAT BK HGE FIN (TITANIUM)
25858775 COVER, 3RD ROW SEAT BK HGE FIN (COCOA)
15804515 COVER, 3RD ROW SEAT BK LAT (EBONY) (INBOARD, INNER)
15804516 COVER, 3RD ROW SEAT BK LAT (CASHMERE) (INBOARD, INNER)
15804517 COVER, 3RD ROW SEAT BK LAT (TITANIUM) (INBOARD, INNER)
25858773 COVER, 3RD ROW SEAT BK LAT (COCOA) (INBOARD, INNER)
20963255 HANDLE, R/SEAT LAT REL (PART OF 28) (EBONY) (W/NUMBER LABELS ON 3RD ROW SEAT) (FOR 1ST DES SEE 15822356)
20963257 HANDLE, R/SEAT LAT REL (PART OF 28) (TITANIUM) (W/NUMBER LABELS ON 3RD ROW SEAT) (FOR 1ST DES SEE 15822358)
15822356 HANDLE, R/SEAT LAT REL (PART OF 28) (EBONY) (W/O NUMBER LABELS ON 3RD ROW SEAT) (FOR 2ND DES SEE 20963255)
15822357 HANDLE, R/SEAT LAT REL (PART OF 28) (CASHMERE) (W/O NUMBER LABELS ON 3RD ROW SEAT) (FOR 2ND DES SEE 20963256)
15822358 HANDLE, R/SEAT LAT REL (PART OF 28) (TITANIUM) (W/O NUMBER LABELS ON 3RD ROW SEAT) (FOR 2ND DES SEE 20963257)
20963256 HANDLE, R/SEAT LAT REL (PART OF 28) (CASHMERE) (W/NUMBER LABELS ON 3RD ROW SEAT) (FOR 1ST DES SEE 15822357)
22906161 HANDLE, R/SEAT LAT REL (PART OF 28)
25913454 CABLE, 3RD ROW SEAT BK LAT
15924954 LATCH, 3RD ROW SEAT LOAD FLR (INBOARD REAR)
15804397 LATCH, 3RD ROW SEAT LOAD FLR (OUTBOARD REAR)
20963267 CABLE, 3RD ROW SEAT BK LAT (INCLS 23) (EBONY) (50% MAIN CONTROL BOX)
20963268 CABLE, 3RD ROW SEAT BK LAT (INCLS 23) (CASHMERE) (50% MAIN CONTROL BOX)
20963269 CABLE, 3RD ROW SEAT BK LAT (INCLS 23) (TITANIUM) (50% MAIN CONTROL BOX)
20963270 CABLE, 3RD ROW SEAT BK LAT (INCLS 23) (COCOA) (50% MAIN CONTROL BOX)
15832238 CABLE, 3RD ROW SEAT BK LAT (INCLS 23) (EBONY) (W/PULL HANDLE) (50% MAIN CONTROL BOX)
15832239 CABLE, 3RD ROW SEAT BK LAT (INCLS 23) (CASHMERE) (W/PULL HANDLE) (50% MAIN CONTROL BOX)
15832240 CABLE, 3RD ROW SEAT BK LAT (INCLS 23) (TITANIUM) (W/PULL HANDLE) (50% MAIN CONTROL BOX)
15804473 COVER, 3RD ROW SEAT BK LAT (EBONY) (REAR CLOSEOUT)
15804474 COVER, 3RD ROW SEAT BK LAT (CASHMERE) (REAR CLOSEOUT) (16.716)
15804475 COVER, 3RD ROW SEAT BK LAT (TITANIUM) (REAR CLOSEOUT) (16.716)
22740564 COVER, 3RD ROW SEAT BK LAT (EBONY)
25858769 COVER, 3RD ROW SEAT BK LAT (COCOA) (REAR CLOSEOUT)
15898402 LATCH, 3RD ROW SEAT LOAD FLR (INCLS 45, 46) (INCLS INBOARD AND OUTBOARD)
15804478 COVER, 3RD ROW SEAT BK LAT (EBONY) (FRONT CLOSEOUT) (16.716)
15804479 COVER, 3RD ROW SEAT BK LAT (CASHMERE) (FRONT CLOSEOUT) (16.716)
15804480 COVER, 3RD ROW SEAT BK LAT (TITANIUM) (FRONT CLOSEOUT) (16.716)
25858770 COVER, 3RD ROW SEAT BK LAT (COCOA) (FRONT CLOSEOUT)
15926524 FRAME, 3RD ROW SEAT CUSH
15898407 COVER, 3RD ROW SEAT BK LAT (EBONY) (OUTBOARD, OUTER)
15898408 COVER, 3RD ROW SEAT BK LAT (CASHMERE) (OUTBOARD, OUTER)
15898409 COVER, 3RD ROW SEAT BK LAT (TITANIUM) (OUTBOARD, OUTER) (16.716)
25858772 COVER, 3RD ROW SEAT BK LAT (COCOA) (OUTBOARD, OUTER)
25928521 LATCH, 3RD ROW SEAT BK
15804493 COVER, 3RD ROW SEAT BK LAT (EBONY) (OUTBOARD, INNER) (16.716)
15804494 COVER, 3RD ROW SEAT BK LAT (CASHMERE) (OUTBOARD, INNER) (16.716)
15804495 COVER, 3RD ROW SEAT BK LAT (TITANIUM) (OUTBOARD, INNER) (16.716)
25858771 COVER, 3RD ROW SEAT BK LAT (COCOA) (OUTBOARD, INNER)
19207603 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (COCOA)
19207600 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (CASHMERE)
19207601 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (TITANIUM)
19207599 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (EBONY)
25906825 BELT, R/SEAT #2 (RETR SI) (INCLS 8) (CASHMERE)
25940415 BELT, R/SEAT #2 (RETR SI) (INCLS 8) (COCOA)
25869320 BELT, R/SEAT #2 (RETR SI) (INCLS 8) (EBONY)
15827657 COVER, R/SEAT HGE FIN (OUTBOARD)
15804404 CABLE, 3RD ROW SEAT BK LAT (LOCK OUT)
15804533 PAD, 3RD ROW SEAT CUSH
25858737 COVER, 3RD ROW SEAT CUSH (COCOA)
25937625 COVER, 3RD ROW SEAT CUSH (EBONY)
25937626 COVER, 3RD ROW SEAT CUSH (CASHMERE)
25937627 COVER, 3RD ROW SEAT CUSH (TITANIUM)
20859438 COVER, 3RD ROW SEAT CUSH (CASHMERE)
20904822 COVER, 3RD ROW SEAT CUSH (EBONY)
20904824 COVER, 3RD ROW SEAT CUSH (CASHMERE)
25928483 COVER, 3RD ROW SEAT CUSH (EBONY)
22751178 COVER, 3RD ROW SEAT CUSH (EBONY)
25928485 COVER, 3RD ROW SEAT CUSH (TITANIUM)
25928484 COVER, 3RD ROW SEAT CUSH (CASHMERE)
15865797 COVER, 3RD ROW SEAT BK (INCLS CHILD COMFORT GUIDE) (EBONY)
25858735 COVER, 3RD ROW SEAT BK (COCOA)
20859432 COVER, 3RD ROW SEAT BK (INCLS CHILD COMFORT GUIDE) (CASHMERE)
20904828 COVER, 3RD ROW SEAT BK (EBONY) (W/CHILD SEAT BELT COMFORT GUIDE)
20904830 COVER, 3RD ROW SEAT BK (CASHMERE)
20859431 COVER, 3RD ROW SEAT BK (INCLS CHILD COMFORT GUIDE) (EBONY)
15924920 PANEL, R/SEAT BK FIL
25784336 RETAINER, R/SEAT BK OPG FIN CVR (PUSH IN) (16.720)
15924917 WIRE, R/SEAT CUSH BRDR
25895133 BAR, R/SEAT HGE LINK TIE (PART OF 30)
(TC16-360) 2007-2013 CK107(06) ОТДЕЛКА ВНУТРЕННЯЯ-BODY SIDE REAR (CADILLAC Z75)
15877373 PLATE, R/FLR RR TR (INCLS 17, 18) (LINEN)
15931763 PLATE, R/FLR RR TR (INCLS 17, 18) (EBONY) (W/ CADILLAC INSERT)
25902618 PLATE, R/FLR RR TR (INCLS 17, 18) (CASHMERE)
15905683 MOLDING, BK BODY OPG GARN (INCLS 3) (GRAY)
15936713 MOLDING, BK BODY OPG GARN (INCLS 3) (LINEN)
15905684 MOLDING, BK BODY OPG GARN (INCLS 3) (CASHMERE)
11561654 RETAINER, BODY RR COR G/MLDG (PART OF 2) (PLAIN) (BIRD'S BEAK SINGLE) (FITS 8.5 DIA HOLE) (12.800)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 10, 19)
teamcadillac.ru
11609651 CLIP, BODY L/PLR G/MLDG (PART OF 10, 19) (METAL PUSH-IN NUT, M4.2X1.41, 21.8X15X20.5) (14.731)
15877412 PLATE, RR S/D SILL TR (INCLS 8) (LINEN)
25902616 PLATE, RR S/D SILL TR (INCLS 8) (CASHMERE)
15873285 PLATE, RR S/D SILL TR (INCLS 8) (EBONY) (W/CADILLAC INSERT)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 7)
15043000 PLUG, R/CMPT SILL TR PLT HOLE (38.0 X 17.0 X 18.0MM) (OBLONG) (16.600)
15877445 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15) (LINEN)
15875107 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15) (CASHMERE) (MOLDED IN COLOR FLECKED PLASTIC UPR TR)
20844007 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15) (LINEN)
20844008 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15) (LINEN)
15900726 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15) (CASHMERE) (DUAL TONE PART) (GRANITE CASHMERE UPR)
20986797 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15) (CASHMERE) (DUAL TONE PART) (CASHMERE GRANITE UPR)
20986791 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15) (EBONY) (DUAL TONE PART) (GRANITE OPAL UPR)
20986796 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15) (EBONY) (DUAL TONE PART) (GRAY UPR)
15877443 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15) (LINEN)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 10, 19)
15295390 BEZEL, R/SEAT BELT OPG (PART OF 10, 19) (EBONY)
15295394 BEZEL, R/SEAT BELT OPG (PART OF 10, 19) (EBONY)
25827829 BEZEL, R/SEAT BELT OPG (PART OF 10, 19) (LINEN)
25827831 BEZEL, R/SEAT BELT OPG (PART OF 10, 19) (LINEN)
25903597 BEZEL, R/SEAT BELT OPG (PART OF 10, 19) (CASHMERE)
25903598 BEZEL, R/SEAT BELT OPG (PART OF 10, 19) (CASHMERE)
25827828 GUIDE, R/SEAT SHLDR BELT INTER (PART OF 10, 19) (LINEN)
15214079 GUIDE, R/SEAT SHLDR BELT INTER (PART OF 10, 19) (CASHMERE)
15214081 GUIDE, R/SEAT SHLDR BELT INTER (PART OF 10, 19) (EBONY)
11609465 BOLT, HWH, M4.2X1.41X18, 12.5 OD, 6010M, PS (PART OF 10, 19) (8.977)
25827826 PLUG, BODY L/PLR GARN MLDG (PART OF 10, 19) (LINEN)
25827830 PLUG, BODY L/PLR GARN MLDG (PART OF 10, 19) (LINEN)
15278075 PLUG, BODY L/PLR GARN MLDG (PART OF 10, 19) (GRAY)
15278076 PLUG, BODY L/PLR GARN MLDG (PART OF 10, 19) (GRAY)
15278083 PLUG, BODY L/PLR GARN MLDG (PART OF 10, 19) (CASHMERE)
15278084 PLUG, BODY L/PLR GARN MLDG (PART OF 10, 19) (CASHMERE)
15940206 COVER, L/GATE LK STKR (PART OF 1) (LINEN)
15274516 COVER, L/GATE LK STKR (PART OF 1) (EBONY)
20986776 COVER, L/GATE LK STKR (PART OF 1) (CASHMERE)
15877445 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (LINEN)
15900737 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (EBONY) (FOR VEHICLES LOCATED IN CHINA) (EBONY LWR, GRAY UPR)
15900743 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (EBONY) (FOR VEHICLES LOCATED IN CHINA) (EBONY LWR, GRAY UPR)
15900738 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (CASHMERE) (FOR VEHICLES LOCATED IN CHINA) (CASHMERE LWR, CASHMERE UPR) (MOLDED IN COLOR FLECKED PLASTIC UPR TR)
15900744 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (CASHMERE) (FOR VEHICLES LOCATED IN CHINA) (CASHMERE LWR, CASHMERE UPR)
22837613 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (EBONY) (FOR VEHICLES NOT LOCATED IN CHINA) (EBONY LWR, GRAY UPR)
22837614 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (CASHMERE) (FOR VEHICLES NOT LOCATED IN CHINA) (CASHMERE LWR, CASHMERE UPR)
22837618 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (EBONY) (FOR VEHICLES NOT LOCATED IN CHINA) (EBONY LWR, GRAY UPR)
22837619 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (CASHMERE) (FOR VEHICLES NOT LOCATED IN CHINA) (CASHMERE LWR, CASHMERE UPR) (MOLDED IN COLOR FLECKED PLASTIC UPR TR)
15877443 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (LINEN)
10388598 SWITCH, R/SEAT ADJR (PART OF 19) (ON GARNISH MOLDING)
15113408 SWITCH, R/SEAT ADJR (PART OF 19) (ON GARNISH MOLDING)
25827827 BEZEL, BODY L/PLR G/MLDG (PART OF 19) (LINEN)
15214084 BEZEL, BODY L/PLR G/MLDG (PART OF 19) (EBONY)
15214082 BEZEL, BODY L/PLR G/MLDG (PART OF 19) (CASHMERE)
(TC16-383) 2009-2013 CK107(06) ОТДЕЛКА ВНУТРЕННЯЯ-BODY SIDE-LH QUARTER DETAIL (CADILLAC Z75, EXC HYBRID HP2)
15885778 PANEL, BODY SI TR (INCLS 1, 2) (TITANIUM) (W/O LATCH)
15885777 PANEL, BODY SI TR (INCLS 1, 2) (CASHMERE)
15885779 PANEL, BODY SI TR (INCLS 1, 2) (EBONY)
15936654 PANEL, BODY SI TR (INCLS 1, 2) (LINEN)
15901354 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (GRAY) (W/O SPEAKER)
15877451 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (LINEN)
15278017 PLUG, BODY RR COR UPR GARN MLDG (PART OF 4) (GRAY)
teamcadillac.ru
(TC16-384) 2007-2013 CK107(06) ОТДЕЛКА ВНУТРЕННЯЯ-BODY SIDE-RH QUARTER DETAIL
25999672 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13) (CASHMERE) ( (W/O SPKR) (ORDER SPKR SEPARATE))
20881384 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13) (LINEN)
20881385 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13) (GRAY)
teamcadillac.ru
25999671 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13) (GRANITE) ( (W/O SPKR) (ORDER SPKR SEPARATE))
20986814 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13) (GRAY)
20986818 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13) (CASHMERE)
15186672 SPEAKER, RDO BODY RR COR UPR GARN MLDG (PART OF 1, 15) (ACDelco #15186672)
11509253 SCREW, W/LRG WA HD, M4.2X1.4X10, 11.3 O.D., BHL PT, STL, NO (PART OF 1, 15)
11561654 RETAINER, BODY RR COR G/MLDG (PART OF 1, 15) (PLAIN) (BIRD'S BEAK SINGLE) (FITS 8.5 DIA HOLE) (12.800)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 1, 15)
11609508 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (PART OF 1, 15)
25827851 PLUG, BODY RR COR UPR GARN MLDG (PART OF 1, 15) (LINEN)
15278015 PLUG, BODY RR COR UPR GARN MLDG (PART OF 1, 15) (LT CHASHMERE)
15278014 PLUG, BODY RR COR UPR GARN MLDG (PART OF 1, 15) (GRAY)
15187371 RETAINER, C/LTR HSG (PART OF 10) (EBONY) (INCLS COVER)
25749635 RETAINER, C/LTR RCPT (PART OF 10) (EBONY) (W/O CAP)
25776667 RECEPTACLE, ACSRY PWR (PART OF 10) (2 TERMINALS)
15936655 PANEL, BODY SI TR (INCLS 8, 9, 11, 12) (LINEN)
20986766 PANEL, BODY SI TR (INCLS 8, 9, 11, 12) (EBONY)
20986768 PANEL, BODY SI TR (INCLS 8, 9, 11, 12) (CASHMERE)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 10)
11609651 RETAINER, BODY RR COR G/MLDG (PART OF 1, 15) (METAL PUSH-IN NUT, M4.2X1.41, 21.8X15X20.5) (14.731)
21997869 INDICATOR, RR OBJECT ALARM
(TC16-390) 2007-2013 CK107(06) ЗАДНЕЕ СИДЕНЬЕ/BUCKET-RH (BUCKET AL4)
25907997 SEAT, RR (INCLS 2-48) (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960579)
20960483 SEAT, RR (INCLS 2-48) (COCOA) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25942794)
20960560 SEAT, RR (INCLS 2-48) (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 15843790)
20960561 SEAT, RR (INCLS 2-48) (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25907993)
20960578 SEAT, RR (INCLS 2-48) (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 15843914)
20960579 SEAT, RR (INCLS 2-48) (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25907997)
15843790 SEAT, RR (INCLS 2-48) (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960560)
15843914 SEAT, RR (INCLS 2-48) (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960578)
25907993 SEAT, RR (INCLS 2-48) (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960561)
25942794 SEAT, RR (INCLS 2-48) (COCOA) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960483)
20960542 SEAT, RR (INCLS 2-48) (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 15842722)
20960543 SEAT, RR (INCLS 2-48) (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25907988)
20960551 SEAT, RR (INCLS 2-48) (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 15842716)
20960552 SEAT, RR (INCLS 2-48) (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25907990)
20960597 SEAT, RR (INCLS 2-48) (COCOA) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25949035)
15842716 SEAT, RR (INCLS 2-48) (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960551)
15842722 SEAT, RR (INCLS 2-48) (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960542)
25907988 SEAT, RR (INCLS 2-48) (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960543)
25907990 SEAT, RR (INCLS 2-48) (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960552)
25949035 SEAT, RR (INCLS 2-48) (COCOA) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960597)
25858418 COVER, R/SEAT BK (COCOA)
15865722 COVER, R/SEAT BK (EBONY)
15865723 COVER, R/SEAT BK (CASHMERE)
15865724 COVER, R/SEAT BK (TITANIUM)
25908028 COVER, R/SEAT BK (CASHMERE)
25931441 COVER, R/SEAT BK (EBONY)
25931442 COVER, R/SEAT BK (CASHMERE)
25931443 COVER, R/SEAT BK (TITANIUM)
25899570 COVER, R/SEAT BK (EBONY)
22771055 PAD, R/SEAT BK
15824670 RESTRAINT, R/SEAT HD (INCLS 4) (TITANIUM)
25858321 RESTRAINT, R/SEAT HD (INCLS 4) (COCOA)
15824669 RESTRAINT, R/SEAT HD (INCLS 4) (CASHMERE)
25928791 RESTRAINT, R/SEAT HD (INCLS 4) (CASHMERE)
15865813 RESTRAINT, R/SEAT HD (INCLS 4) (EBONY)
25928790 RESTRAINT, R/SEAT HD (INCLS 4) (EBONY)
15824676 RESTRAINT, R/SEAT HD (INCLS 4) (EBONY)
25928796 PAD, R/SEAT H/RST (INCLS 4) (CASHMERE)
20912675 GUIDE, R/SEAT H/RST (CASHMERE) (W/BUTTON)
20912677 GUIDE, R/SEAT H/RST (COCOA) (W/BUTTON)
15279347 GUIDE, R/SEAT H/RST (EBONY) (W/BUTTON)
teamcadillac.ru
20912676 GUIDE, R/SEAT H/RST (TITANIUM) (W/BUTTON)
20912679 GUIDE, R/SEAT H/RST (EBONY) (W/O BUTTON)
20912680 GUIDE, R/SEAT H/RST (CASHMERE) (W/O BUTTON)
15279353 GUIDE, R/SEAT H/RST (TITANIUM) (W/O BUTTON)
25851751 GUIDE, R/SEAT H/RST (COCOA) (W/O BUTTON)
15269769 FRAME, R/SEAT BK
15279691 CAP, R/SEAT ACTR FIN CVR BOLT (TITANIUM)
25858335 CAP, R/SEAT ACTR FIN CVR BOLT (COCOA)
15279689 CAP, R/SEAT ACTR FIN CVR BOLT (EBONY)
15279690 CAP, R/SEAT ACTR FIN CVR BOLT (CASHMERE)
11570119 NUT, R/SEAT A/RST (T/W 11570115 STUD)
22785446 ARMREST, R/SEAT (EBONY) (ON VEHICLES BUILT PRIOR TO 4/2011 DEALER MAY NEED TO REMOVE STUD OFFFRAME PRIOR TO USING ARMREST WITH BOLT)
22785447 ARMREST, R/SEAT (CASHMERE) (ON VEHICLES BUILT PRIOR TO 4/2011 DEALER MAY NEED TO REMOVE STUD OFFFRAME PRIOR TO USING ARMREST WITH BOLT)
22785448 ARMREST, R/SEAT (TITANIUM) (ON VEHICLES BUILT PRIOR TO 4/2011 DEALER MAY NEED TO REMOVE STUD OFFFRAME PRIOR TO USING ARMREST WITH BOLT)
22785453 ARMREST, R/SEAT (EBONY) (ON VEHICLES BUILT PRIOR TO 4/2011 DEALER MAY NEED TO REMOVE STUD OFFFRAME PRIOR TO USING ARMREST WITH BOLT)
22785458 ARMREST, R/SEAT (COCOA) (ON VEHICLES BUILT PRIOR TO 4/2011 DEALER MAY NEED TO REMOVE STUD OFFFRAME PRIOR TO USING ARMREST WITH BOLT)
22785454 ARMREST, R/SEAT (ON VEHICLES BUILT PRIOR TO 4/2011 DEALER MAY NEED TO REMOVE STUD OFFFRAME PRIOR TO USING ARMREST WITH BOLT) (CASHMERE)
11570115 STUD, R/SEAT A/RST (T/W 11570119 NUT)
15824761 HEATER, R/SEAT CUSH
22771040 PAD, R/SEAT CUSH
15269765 FRAME, R/SEAT CUSH
11570116 SCREW, PAN HD, M6X1X10, 10 THD, 12 OD, STL SAE J1237, S424, TAPTITE ITE (R/SEAT LAT FIN CVR) (8.913)
11562384 NUT, HFH, M4X.7 THD, 4.75 THK, 10.5 OD, GM510M (9)STL, GM4435M-CODE A (R/SEAT FLR FIL T/PNL)
15280113 COVER, R/SEAT RECL INR FIN (EBONY) (INNER)
15280114 COVER, R/SEAT RECL INR FIN (CASHMERE) (INNER)
15280115 COVER, R/SEAT RECL INR FIN (TITANIUM) (INNER)
25858451 COVER, R/SEAT RECL INR FIN (COCOA) (INNER)
11562378 BOLT, HFH, M10X1.5X30, 18 THD, 22.3 OD, 10.9, GMW3359, W/ADH GM6175M (R/SEAT LAT)
15279464 KNOB, R/SEAT LAT (EBONY) (16.716) (W/O NUMBER LABELS ON 3RD ROW SEAT) (FOR 2ND DES SEE 20963265)
20963265 KNOB, R/SEAT LAT (EBONY) (INNER) (W/NUMBER LABELS ON 3RD ROW SEAT) (FOR 1ST DES SEE 15279464)
15279719 COVER, R/SEAT RECL INR FIN ( INCLS 41) (EBONY) (OUTER)
15279720 COVER, R/SEAT RECL INR FIN (INCLS 41) (CASHMERE) (OUTER)
15279721 COVER, R/SEAT RECL INR FIN (INCLS 41) (TITANIUM) (OUTER)
25858450 COVER, R/SEAT RECL INR FIN (INCLS 41) (COCOA) (OUTER)
19121596 BELT KIT, R/SEAT (BKL SI) (TITANIUM)
19180585 BELT KIT, R/SEAT (BKL SI) (COCOA)
19121595 BELT KIT, R/SEAT (BKL SI) (CASHMERE)
19121593 BELT KIT, R/SEAT (BKL SI) (EBONY)
25896462 RECLINER, R/SEAT INR (WHEN SERVICING VEHICLES BUILT PRIOR TO 06/01/06, DEALER NEEDS TO REPLACE BOTH INNER & OUTER IN SETS)
15275888 LATCH, R/SEAT RSR (INNER & OUTER)
11562380 BUSHING, R/SEAT HGE
15275901 SPRING, R/SEAT RECL (TUMBLE)
15275903 SPRING, R/SEAT RECL (MANDREL)
15275905 STRUT, R/SEAT (USED ON BOTH LH/RH)
25858467 PANEL, R/SEAT CUSH TR (COCOA)
22772267 PANEL, R/SEAT CUSH TR (EBONY)
22772268 PANEL, R/SEAT CUSH TR (CASHMERE)
22772269 PANEL, R/SEAT CUSH TR (TITANIUM)
15279609 COVER, R/SEAT RSR FIN (EBONY) (REAR)
15279610 COVER, R/SEAT RSR FIN (CASHMERE) (REAR)
15279611 COVER, R/SEAT RSR FIN (TITANIUM) (REAR)
25858447 COVER, R/SEAT RSR FIN (COCOA) (REAR)
22741877 RISER, R/SEAT
11562379 BOLT, R/SEAT HGE (M10X1.5X92)
15279599 COVER, R/SEAT RSR FIN (INCLS 34) (EBONY) (FRONT)
15279600 COVER, R/SEAT RSR FIN (INCLS 34) (CASHMERE) (FRONT)
15279601 COVER, R/SEAT RSR FIN (INCLS 34) (TITANIUM) (FRONT)
15843764 HARNESS, R/SEAT HTR
15279408 PIN, R/SEAT H/RST ADJ ROD LAT (TITANIUM)
25858342 PIN, R/SEAT H/RST ADJ ROD LAT (COCOA)
15279406 PIN, R/SEAT H/RST ADJ ROD LAT (EBONY)
15279407 PIN, R/SEAT H/RST ADJ ROD LAT (CASHMERE)
25816415 CABLE, R/SEAT BK LAT (OUTBOARD MASTER SYNC)
25816416 CABLE, R/SEAT LAT (INBOARD) (INBOARD MASTER SYNC)
15275914 CABLE, R/SEAT LAT (OUTBOARD) (FLOOR LATCH)
25896460 RECLINER, R/SEAT OTR (WHEN SERVICING VEHICLES BUILT PRIOR TO 06/01/06, DEALER NEEDS TO REPLACE BOTH INNER & OUTER IN SETS)
15279429 HANDLE, R/SEAT RECL (INCLS 42) (TITANIUM)
15279419 HANDLE, R/SEAT RECL (INCLS 42) (EBONY)
15279420 HANDLE, R/SEAT RECL (INCLS 42) (CASHMERE)
25858446 HANDLE, R/SEAT RECL (INCLS 42) (COCOA)
15279699 COVER, R/SEAT RECL OTR FIN (INCLS 41) (EBONY) (OUTER)
15279700 COVER, R/SEAT RECL OTR FIN ( INCLS 41) (CASHMERE) (OUTER)
15279701 COVER, R/SEAT RECL OTR FIN (INCLS 41) (TITANIUM) (OUTER)
25858448 COVER, R/SEAT RECL OTR FIN (INCLS 41) (COCOA) (OUTER)
15279709 COVER, R/SEAT RECL OTR FIN (EBONY) (INNER)
15279710 COVER, R/SEAT RECL OTR FIN (CASHMERE) (INNER)
15279711 COVER, R/SEAT RECL OTR FIN (TITANIUM) (INNER)
25858449 COVER, R/SEAT RECL OTR FIN (COCOA) (INNER)
15865730 COVER, R/SEAT CUSH (EBONY)
25858420 COVER, R/SEAT CUSH (COCOA)
15865731 COVER, R/SEAT CUSH (CASHMERE)
25931447 COVER, R/SEAT CUSH (EBONY)
25931449 COVER, R/SEAT CUSH (TITANIUM)
15865732 COVER, R/SEAT CUSH (TITANIUM)
25899558 COVER, R/SEAT CUSH (EBONY)
20905470 COVER, R/SEAT CUSH (CASHMERE)
15843763 HARNESS, ST RECL WRG (ELEMENT)
15824750 ACTUATOR, R/SEAT RECL (INCLS CABLE)
(TC16-391) 2008-2013 CK107(06) ЗАДНЕЕ СИДЕНЬЕ/BENCH-40% SIDE (AM8, EXC POWER FOLDING ARS, HYBRID HP2)
15843772 SEAT, RR (INCLS 2-42) (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960236)
15914187 SEAT, RR (INCLS 2-42) (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20959985)
25908002 SEAT, RR (INCLS 2-42) (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960240)
15843802 SEAT, RR (INCLS 2-42) (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960272)
20960041 SEAT, RR (INCLS 2-42) (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 20905021)
20960042 SEAT, RR (INCLS 2-42) (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 20905022)
20960236 SEAT, RR (INCLS 2-42) (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 15843772)
20960240 SEAT, RR (INCLS 2-42) (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25908002)
20905021 SEAT, RR (INCLS 2-42) (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960041)
20905022 SEAT, RR (INCLS 2-42) (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960042)
20959985 SEAT, RR (INCLS 2-42) (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 15914187)
20960272 SEAT, RR (INCLS 2-42) (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 15843802)
20960276 SEAT, RR (INCLS 2-42) (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25908010)
25908010 SEAT, RR (INCLS 2-42) (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960276)
20895604 COVER, R/SEAT BK (EBONY)
15914204 COVER, R/SEAT BK (EBONY)
25908033 COVER, R/SEAT BK (CASHMERE)
25931396 COVER, R/SEAT BK (EBONY)
25931397 COVER, R/SEAT BK (CASHMERE)
25931398 COVER, R/SEAT BK (TITANIUM)
15865525 COVER, R/SEAT BK (EBONY)
15865526 COVER, R/SEAT BK (CASHMERE)
15865527 COVER, R/SEAT BK (TITANIUM)
20905045 COVER, R/SEAT BK (EBONY)
20905046 COVER, R/SEAT BK (CASHMERE)
15291598 PAD, R/SEAT BK
20758015 RESTRAINT, R/SEAT HD (INCLS 4) (TITANIUM)
20905030 RESTRAINT, R/SEAT HD (INCLS 4) (EBONY)
20905031 RESTRAINT, R/SEAT HD (INCLS 4) (CASHMERE)
15269763 FRAME, R/SEAT BK
15291600 PAD, R/SEAT CUSH
15279530 COVER, R/SEAT BK HGE FIN (EBONY) (INBOARD, INNER) (16.674)
15279531 COVER, R/SEAT BK HGE FIN (CASHMERE) (INBOARD, INNER) (16.674)
15279532 COVER, R/SEAT BK HGE FIN (TITANIUM) (INBOARD, INNER) (16.674)
15279504 COVER, R/SEAT BK HGE FIN (INCLS 40) (EBONY) (INBOARD, OUTER) (16.674)
15279505 COVER, R/SEAT BK HGE FIN (INCLS 40) (CASHMERE) (INBOARD, OUTER) (16.674)
19121596 BELT KIT, R/SEAT (BKL SI) (SINGLE BKL) (TITANIUM)
19121593 BELT KIT, R/SEAT (BKL SI) (SINGLE BKL) (EBONY)
25896458 LATCH, R/SEAT BK (INBOARD)
15275888 LATCH, R/SEAT RSR (O/B)
22772253 PANEL, R/SEAT CUSH TR (TITANIUM)
15279554 PANEL, R/SEAT CUSH TR (EBONY) (16.716)
15279555 PANEL, R/SEAT CUSH TR (CASHMERE) (16.716)
15279599 COVER, R/SEAT RSR FIN (INCLS 29) (EBONY) (FRONT)
15279600 COVER, R/SEAT RSR FIN (INCLS 29) (CASHMERE) (FRONT)
15279601 COVER, R/SEAT RSR FIN (INCLS 29) (TITANIUM) (FRONT)
teamcadillac.ru
25896457 LATCH, R/SEAT BK (OUTBOARD)
15279429 HANDLE, R/SEAT RECL (INCLS 38) (TITANIUM)
15279419 HANDLE, R/SEAT RECL (INCLS 38) (EBONY)
15279420 HANDLE, R/SEAT RECL (INCLS 38) (CASHMERE)
15279484 COVER, R/SEAT BK HGE FIN (INCLS 40) (EBONY) (OUTBOARD, OUTER) (16.674)
15279485 COVER, R/SEAT BK HGE FIN (INCLS 40) (CASHMERE) (OUTBOARD, OUTER) (16.674)
15279486 COVER, R/SEAT BK HGE FIN (INCLS 40) (TITANIUM) (OUTBOARD, OUTER) (16.674)
15279494 COVER, R/SEAT BK HGE FIN (EBONY) (OUTBOARD, INNER) (16.674)
15279495 COVER, R/SEAT BK HGE FIN (CASHMERE) (OUTBOARD, INNER) (16.674)
15279496 COVER, R/SEAT BK HGE FIN (TITANIUM) (OUTBOARD, INNER) (16.674)
15914208 COVER, R/SEAT CUSH (EBONY)
25908034 COVER, R/SEAT CUSH (CASHMERE)
25931402 COVER, R/SEAT CUSH (EBONY)
25931403 COVER, R/SEAT CUSH (CASHMERE)
25931404 COVER, R/SEAT CUSH (TITANIUM)
15865714 COVER, R/SEAT CUSH (EBONY)
15865715 COVER, R/SEAT CUSH (CASHMERE)
15865716 COVER, R/SEAT CUSH (TITANIUM)
20905039 COVER, R/SEAT CUSH (EBONY)
20905040 COVER, R/SEAT CUSH (CASHMERE)
20905442 COVER, R/SEAT CUSH (EBONY)
11570031 PIN, R/SEAT HGE (6 X 1 X 78)
11570032 PIN, R/SEAT HGE (6 X 1 X 98)
(TC16-392) 2008-2013 CK107(06) ЗАДНЕЕ СИДЕНЬЕ/BENCH-60% SIDE (AM8, EXC POWER FOLDING ARS, HYBRID HP2)
teamcadillac.ru
15914202 COVER, R/SEAT BK (EBONY)
25908031 COVER, R/SEAT BK (CASHMERE)
25931384 COVER, R/SEAT BK (EBONY)
25931386 COVER, R/SEAT BK (TITANIUM)
15865521 COVER, R/SEAT BK (EBONY)
15865522 COVER, R/SEAT BK (CASHMERE)
15865523 COVER, R/SEAT BK (TITANIUM)
20905042 COVER, R/SEAT BK (EBONY)
20905043 COVER, R/SEAT BK (CASHMERE)
20895601 COVER, R/SEAT BK (EBONY)
15291597 PAD, R/SEAT BK
22771058 PAD, R/SEAT BK
11562382 BOLT, HFH, M10X1.5X130, 26 THD, 22.3 OD, 10.9, 7114M, MACH, MAT-PT (R/SEAT BK FRM)
15289969 BRACKET, RR CTR SEAT BELT RETR
15279450 PROTECTOR, R/SEAT SHLDR BELT (BLACK)
15824670 RESTRAINT, R/SEAT HD (INCLS 8) (TITANIUM)
25928791 RESTRAINT, R/SEAT HD (INCLS 8) (CASHMERE)
20758015 RESTRAINT, R/SEAT HD (INCLS 8) (TITANIUM)
20905030 RESTRAINT, R/SEAT HD (INCLS 8) (EBONY)
20905031 RESTRAINT, R/SEAT HD (INCLS 8) (CASHMERE)
15865813 RESTRAINT, R/SEAT HD (INCLS 8) (EBONY)
15824669 RESTRAINT, R/SEAT HD (INCLS 8) (CASHMERE)
25928790 RESTRAINT, R/SEAT HD (INCLS 8) (EBONY)
15824676 RESTRAINT, R/SEAT HD (INCLS 8) (EBONY)
11562383 BOLT, HFH, M12X1.75X30.5, 17 THD, 26.6 OD, 10.9 STL, GMW3359, W/ADH 6175M (R/SEAT LAT)
15269762 FRAME, R/SEAT BK
15279471 COVER, R/SEAT A/RST SUPT FIN (TITANIUM)
15279469 COVER, R/SEAT A/RST SUPT FIN (EBONY)
15279470 COVER, R/SEAT A/RST SUPT FIN (CASHMERE)
15279489 COVER, R/SEAT BK HGE FIN (EBONY) (OUTBOARD, INNER) (16.674)
15279490 COVER, R/SEAT BK HGE FIN (CASHMERE) (OUTBOARD, INNER) (16.674)
15279491 COVER, R/SEAT BK HGE FIN (TITANIUM) (OUTBOARD, INNER) (16.674)
19121589 BELT KIT, R/SEAT (BKL SI) (EBONY) (BKL/BKL)
19121591 BELT KIT, R/SEAT (BKL SI) (CASHMERE) (BKL/BKL)
19121592 BELT KIT, R/SEAT (BKL SI) (TITANIUM) (BKL/BKL)
15269764 FRAME, R/SEAT CUSH
15275886 LATCH, R/SEAT RSR (O/B)
15275887 LATCH, R/SEAT RSR (I/B)
25896455 LATCH, R/SEAT BK (OUTBOARD)
15279479 COVER, R/SEAT BK HGE FIN (INCLS 49) (EBONY) (OUTBOARD, OUTER) (16.674)
15279480 COVER, R/SEAT BK HGE FIN (INCLS 49) (CASHMERE) (OUTBOARD, OUTER) (16.674)
15279481 COVER, R/SEAT BK HGE FIN (INCLS 49) (TITANIUM) (OUTBOARD, OUTER) (16.674)
15279416 HANDLE, R/SEAT RECL (INCLS 23) (TITANIUM)
15279414 HANDLE, R/SEAT RECL (INCLS 23) (EBONY)
15279415 HANDLE, R/SEAT RECL (INCLS 23) (CASHMERE)
25858332 HANDLE, R/SEAT RECL (INCLS 23) (COCOA)
15275917 CABLE, R/SEAT LAT (INBOARD) (FLOOR LATCH)
25816396 CABLE, R/SEAT LAT (INBOARD) (MASTER SYNC)
25816395 CABLE, R/SEAT BK LAT (MASTER SYNC)
15279604 COVER, R/SEAT RSR FIN (EBONY) (REAR)
15279605 COVER, R/SEAT RSR FIN (CASHMERE) (REAR)
15279606 COVER, R/SEAT RSR FIN (TITANIUM) (REAR)
22741876 RISER, R/SEAT
15824753 COVER, R/SEAT RSR FIN (INCLS 31) (EBONY) (FRONT)
15824754 COVER, R/SEAT RSR FIN (INCLS 31) (CASHMERE) (FRONT)
15824755 COVER, R/SEAT RSR FIN (INCLS 31) (TITANIUM) (FRONT)
15291599 PAD, R/SEAT CUSH
11571092 BOLT, R/SEAT HGE (M10X1.5X114)
15843765 HARNESS, R/SEAT HTR
15279551 PANEL, R/SEAT CUSH TR (TITANIUM) (16.716)
15279550 PANEL, R/SEAT CUSH TR (CASHMERE) (16.716)
22772246 PANEL, R/SEAT CUSH TR (EBONY)
20933029 MODULE, R/SEAT HTR CONT
25891512 MODULE, R/SEAT HTR CONT (REQUIRES DEALER PROGRAMMING) (11.558)
20792750 HEATER, R/SEAT CUSH
15275905 STRUT, R/SEAT (USED ON 40% SIDE)
15930099 STRUT, R/SEAT (USED ON 60% SIDE)
15275900 SPRING, R/SEAT RECL (TUMBLE)
15275902 SPRING, R/SEAT RECL (MANDREL)
15279591 COVER, R/SEAT HGE LWR FIN (TITANIUM) (PIVOT INBOARD) (16.674)
15279589 COVER, R/SEAT HGE LWR FIN (EBONY) (PIVOT INBOARD) (16.674)
15279590 COVER, R/SEAT HGE LWR FIN (CASHMERE) (PIVOT INBOARD) (16.674)
15269777 BRACKET, R/SEAT
11562381 BOLT, R/SEAT BK LAT PIV (M12X1.75X40)
15279596 COVER, R/SEAT HGE LWR FIN (TITANIUM) (PIVOT INBOARD) (16.674)
15279594 COVER, R/SEAT HGE LWR FIN (EBONY) (PIVOT INBOARD) (16.674)
15279595 COVER, R/SEAT HGE LWR FIN (CASHMERE) (PIVOT INBOARD) (16.674)
15914206 COVER, R/SEAT CUSH (EBONY)
25931390 COVER, R/SEAT CUSH (EBONY)
25931391 COVER, R/SEAT CUSH (CASHMERE)
25931392 COVER, R/SEAT CUSH (TITANIUM)
15865529 COVER, R/SEAT CUSH (EBONY)
15865530 COVER, R/SEAT CUSH (CASHMERE)
15865531 COVER, R/SEAT CUSH (TITANIUM)
25899567 COVER, R/SEAT CUSH (EBONY)
20905036 COVER, R/SEAT CUSH (EBONY)
20905037 COVER, R/SEAT CUSH (CASHMERE)
20905440 COVER, R/SEAT CUSH (CASHMERE)
15279499 COVER, R/SEAT BK HGE FIN (INCLS 49) (EBONY) (INBOARD, OUTER) (16.674)
15279500 COVER, R/SEAT BK HGE FIN (INCLS 49) (CASHMERE) (INBOARD, OUTER) (16.674)
15279501 COVER, R/SEAT LAT FIN (INCLS 49) (TITANIUM) (INBOARD, OUTER)
11562376 SCREW, PAN HD, M12X1.75X55, 42 THD, 27 OD, 10.9, S424, W/ADH GM6175M (R/SEAT LAT)
25896456 LATCH, R/SEAT BK (INBOARD)
11562377 BOLT, HFH, M10X1.5X55, 43.45 THD, 22.3 OD, 10.9, GMW3359, W/ADH GM6175M (R/SEAT LAT)
15279525 COVER, R/SEAT BK HGE FIN (EBONY) (INBOARD, INNER) (16.674)
15279526 COVER, R/SEAT BK HGE FIN (CASHMERE) (INBOARD, INNER) (16.674)
15279527 COVER, R/SEAT BK HGE FIN (TITANIUM) (INBOARD, INNER) (16.674)
15275854 ARMREST, R/SEAT (EBONY)
15913989 ARMREST, R/SEAT (TITANIUM) (W/CUP HOLDER)
20904932 ARMREST, R/SEAT (TITANIUM) (W/CUP HOLDER)
20904933 ARMREST, R/SEAT (CASHMERE) (W/CUP HOLDER)
15865495 ARMREST, R/SEAT (TITANIUM)
15865493 ARMREST, R/SEAT (EBONY)
15865494 ARMREST, R/SEAT (CASHMERE)
15275855 ARMREST, R/SEAT (CASHMERE)
11562386 BOLT, HFH, M8X1.25X24, 22.5 THD, 18 OD, GM6202M, STL, GM4435M.CODE G, TAPTITE (R/SEAT A/RST)
19151106 BELT KIT, R/SEAT CTR (RETR SI) (TITANIUM)
19151105 BELT KIT, R/SEAT CTR (RETR SI) (CASHMERE)
19151104 BELT KIT, R/SEAT CTR (RETR SI) (EBONY)
(TC16-393) 2008-2013 CK107(06) ЗАДНЕЕ СИДЕНЬЕ/BENCH-40% SIDE (AM8, POWER FOLDING ARS, EXC HYBRID HP2)
teamcadillac.ru
15279504 COVER, R/SEAT BK HGE FIN (INCLS 41) (EBONY) (INBOARD, OUTER) (16.674)
15279505 COVER, R/SEAT BK HGE FIN (INCLS 41) (CASHMERE) (INBOARD, OUTER) (16.674)
15279506 COVER, R/SEAT LAT FIN (TITANIUM) (INBOARD, OUTER) (16.720)
15843762 HARNESS, ST RECL WRG (ELEMENT)
15942228 CABLE, R/SEAT BK LAT
15942229 CABLE, R/SEAT BK LAT
15279429 HANDLE, R/SEAT RECL (INCLS 39) (TITANIUM)
25858446 HANDLE, R/SEAT RECL (INCLS 39) (COCOA)
15279419 HANDLE, R/SEAT RECL (INCLS 39) (EBONY)
15279420 HANDLE, R/SEAT RECL (INCLS 39) (CASHMERE)
15279484 COVER, R/SEAT BK HGE FIN (INCLS 41) (EBONY) (OUTBOARD, OUTER) (16.674)
15279485 COVER, R/SEAT BK HGE FIN (INCLS 41) (CASHMERE) (OUTBOARD, OUTER) (16.674)
15279486 COVER, R/SEAT BK HGE FIN (INCLS 41) (TITANIUM) (OUTBOARD, OUTER) (16.674)
(TC16-394) 2008-2013 CK107(06) ЗАДНЕЕ СИДЕНЬЕ/BENCH-60% SIDE (AM8, POWER FOLDING ARS, EXC HYBRID HP2)
15279552 PANEL, R/SEAT CUSH TR (CASHMERE) (16.716)
teamcadillac.ru
15824751 ACTUATOR, R/SEAT RECL (INCLS CABLE)
(TC16-395) 2007-2013 CK107(06) ЗАДНЕЕ СИДЕНЬЕ/BUCKET-LH (BUCKET AL4)
25834415 SEAT, RR (INCLS 2-49) (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960563)
25907996 SEAT, RR (INCLS 2-49) (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960582)
25834165 SEAT, RR (INCLS 2-49) (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960554)
20960481 SEAT, RR (INCLS 2-49) (COCOA) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25942792)
20960563 SEAT, RR (INCLS 2-49) (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25834415)
20960564 SEAT, RR (INCLS 2-49) (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25907992)
20960581 SEAT, RR (INCLS 2-49) (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25834424)
20960582 SEAT, RR (INCLS 2-49) (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25907996)
25834424 SEAT, RR (INCLS 2-49) (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960581)
25907992 SEAT, RR (INCLS 2-49) (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960564)
25942792 SEAT, RR (INCLS 2-49) (COCOA) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960481)
20960545 SEAT, RR (INCLS 2-49) (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25834162)
20960546 SEAT, RR (INCLS 2-49) (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25907987)
20960554 SEAT, RR (INCLS 2-49) (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25834165)
20960555 SEAT, RR (INCLS 2-49) (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25907989)
20960595 SEAT, RR (INCLS 2-49) (COCOA) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25949033)
25834162 SEAT, RR (INCLS 2-49) (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960545)
25907987 SEAT, RR (INCLS 2-49) (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960546)
25907989 SEAT, RR (INCLS 2-49) (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960555)
25949033 SEAT, RR (INCLS 2-49) (COCOA) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960595)
15865718 COVER, R/SEAT BK (EBONY)
25858326 COVER, R/SEAT BK (COCOA)
25908024 COVER, R/SEAT BK (CASHMERE)
25931422 COVER, R/SEAT BK (EBONY)
25931423 COVER, R/SEAT BK (CASHMERE)
25931424 COVER, R/SEAT BK (TITANIUM)
15865719 COVER, R/SEAT BK (CASHMERE)
15865720 COVER, R/SEAT BK (TITANIUM)
25899573 COVER, R/SEAT BK (EBONY)
15291601 PAD, R/SEAT BK
15269768 FRAME, R/SEAT BK
22785442 ARMREST, R/SEAT (EBONY)
22785443 ARMREST, R/SEAT (CASHMERE)
22785444 ARMREST, R/SEAT (TITANIUM)
22785451 ARMREST, R/SEAT (CASHMERE) (ON VEHICLES BUILT PRIOR TO 4/2011 DEALER MAY NEED TO REMOVE STUD OFFFRAME PRIOR TO USING ARMREST WITH BOLT)
22785456 ARMREST, R/SEAT (COCOA) (ON VEHICLES BUILT PRIOR TO 4/2011 DEALER MAY NEED TO REMOVE STUD OFFFRAME PRIOR TO USING ARMREST WITH BOLT)
22785450 ARMREST, R/SEAT (EBONY) (ON VEHICLES BUILT PRIOR TO 4/2011 DEALER MAY NEED TO REMOVE STUD OFFFRAME PRIOR TO USING ARMREST WITH BOLT)
15291603 PAD, R/SEAT CUSH
15269770 FRAME, R/SEAT CUSH
15280108 COVER, R/SEAT RECL INR FIN (EBONY) (INNER)
15280109 COVER, R/SEAT RECL INR FIN (CASHMERE) (INNER)
15280110 COVER, R/SEAT RECL INR FIN (TITANIUM) (INNER)
25858339 COVER, R/SEAT RECL INR FIN (COCOA) (INNER)
15279714 COVER, R/SEAT RECL INR FIN (INCLS 42) (EBONY) (OUTER)
15279715 COVER, R/SEAT RECL INR FIN (INCLS 42) (CASHMERE) (OUTER)
15279716 COVER, R/SEAT RECL INR FIN (INCLS 42) (TITANIUM) (OUTER)
25858338 COVER, R/SEAT RECL INR FIN (INCLS 42) (COCOA) (OUTER)
19121601 BELT KIT, R/SEAT (BKL SI) (EBONY)
19121604 BELT KIT, R/SEAT (BKL SI) (TITANIUM)
19121603 BELT KIT, R/SEAT (BKL SI) (CASHMERE)
19180586 BELT KIT, R/SEAT (BKL SI) (COCOA)
25896461 RECLINER, R/SEAT INR (WHEN SERVICING VEHICLES BUILT PRIOR TO 06/01/06, DEALER NEEDS TO REPLACE BOTH INNER & OUTER IN SETS)
15275890 LATCH, R/SEAT RSR (O/B)
15280120 PANEL, R/SEAT CUSH TR (TITANIUM) (16.716)
25858340 PANEL, R/SEAT CUSH TR (COCOA)
15280119 PANEL, R/SEAT CUSH TR (CASHMERE) (16.716)
22772263 PANEL, R/SEAT CUSH TR (EBONY)
15280128 COVER, R/SEAT RSR FIN (EBONY) (REAR)
15280129 COVER, R/SEAT RSR FIN (CASHMERE) (REAR)
15280130 COVER, R/SEAT RSR FIN (TITANIUM) (REAR)
25858341 COVER, R/SEAT RSR FIN (COCOA) (REAR)
15269775 RISER, R/SEAT
22741881 RISER, R/SEAT
15279599 COVER, R/SEAT RSR FIN (INCLS 33) (EBONY) (FRONT)
15279600 COVER, R/SEAT RSR FIN (INCLS 33) (CASHMERE) (FRONT)
15279601 COVER, R/SEAT RSR FIN (INCLS 33) (TITANIUM) (FRONT)
teamcadillac.ru
25896459 RECLINER, R/SEAT OTR (WHEN SERVICING VEHICLES BUILT PRIOR TO 06/01/06, DEALER NEEDS TO REPLACE BOTH INNER & OUTER IN SETS)
15279416 HANDLE, R/SEAT RECL (INCLS 43) (TITANIUM)
25858332 HANDLE, R/SEAT RECL (INCLS 43) (COCOA)
15279414 HANDLE, R/SEAT RECL (INCLS 43) (EBONY)
15279415 HANDLE, R/SEAT RECL (INCLS 43) (CASHMERE)
15279694 COVER, R/SEAT RECL OTR FIN (INCLS 42) (EBONY) (OUTER)
15279695 COVER, R/SEAT RECL OTR FIN (INCLS 42) (CASHMERE) (OUTER)
15279696 COVER, R/SEAT RECL OTR FIN (INCLS 42) (TITANIUM) (OUTER)
25858336 COVER, R/SEAT RECL OTR FIN (INCLS 42) (COCOA) (OUTER)
15279704 COVER, R/SEAT RECL OTR FIN (EBONY) (INNER)
15279705 COVER, R/SEAT RECL OTR FIN (CASHMERE) (INNER)
15279706 COVER, R/SEAT RECL OTR FIN (TITANIUM) (INNER)
25858337 COVER, R/SEAT RECL OTR FIN (COCOA) (INNER)
25858328 COVER, R/SEAT CUSH (COCOA)
25931428 COVER, R/SEAT CUSH (EBONY)
25931430 COVER, R/SEAT CUSH (TITANIUM)
15865726 COVER, R/SEAT CUSH (EBONY)
15865727 COVER, R/SEAT CUSH (CASHMERE)
15865728 COVER, R/SEAT CUSH (TITANIUM)
25899561 COVER, R/SEAT CUSH (EBONY)
20905446 COVER, R/SEAT CUSH (CASHMERE)
15843764 HARNESS, ST RECL WRG (ELEMENT) (16.685)
15275906 ACTUATOR, R/SEAT RECL (INCLS CABLE)
(TC16-399) 2007-2013 CK1,2(06) ЗАДНЕЕ СИДЕНЬЕ #2 (3RD ROW)-LH(AS3)
22760803 SEAT, 3RD ROW (INCLS 2-44) (EBONY)
22760804 SEAT, 3RD ROW (INCLS 2-44) (CASHMERE)
22760809 SEAT, 3RD ROW (INCLS 2-44) (EBONY)
22760810 SEAT, 3RD ROW (INCLS 2-44) (CASHMERE)
22760818 SEAT, 3RD ROW (INCLS 2-44) (EBONY)
22760819 SEAT, 3RD ROW (INCLS 2-44) (CASHMERE)
22760824 SEAT, 3RD ROW (INCLS 2-44) (EBONY)
22760825 SEAT, 3RD ROW (INCLS 2-44) (CASHMERE)
22760831 SEAT, 3RD ROW (INCLS 2-44) (EBONY)
22760839 SEAT, 3RD ROW (INCLS 2-44) (EBONY)
22760847 SEAT, 3RD ROW (INCLS 2-44) (COCOA)
22760851 SEAT, 3RD ROW (INCLS 2-44) (COCOA)
22760827 SEAT, 3RD ROW (INCLS 2-44) (COCOA)
22760883 SEAT, 3RD ROW (INCLS 2-44) (EBONY)
22760884 SEAT, 3RD ROW (INCLS 2-44) (CASHMERE)
15804530 PAD, 3RD ROW SEAT BK
19207595 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (CASHMERE)
19207596 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (TITANIUM)
19207598 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (COCOA)
19207594 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (EBONY)
25906824 BELT, R/SEAT #2 (RETR SI) (INCLS 8) (CASHMERE)
25940414 BELT, R/SEAT #2 (RETR SI) (INCLS 8) (COCOA)
25869317 BELT, R/SEAT #2 (RETR SI) (INCLS 8) (EBONY)
12478382 BOLT, 3RD ROW SEAT (M10X1.50X28.0)
15898412 COVER, 3RD ROW SEAT BK LAT (EBONY) (OUTBOARD, OUTER) (16.716)
15898413 COVER, 3RD ROW SEAT BK LAT (CASHMERE) (OUTBOARD, OUTER) (16.716)
15898414 COVER, 3RD ROW SEAT BK LAT (TITANIUM) (OUTBOARD, OUTER) (16.716)
15804503 COVER, 3RD ROW SEAT BK LAT (EBONY) (OUTBOARD, INNER) (16.716)
15804504 COVER, 3RD ROW SEAT BK LAT (CASHMERE) (OUTBOARD, INNER) (16.716)
15804505 COVER, 3RD ROW SEAT BK LAT (TITANIUM) (OUTBOARD, INNER) (16.716)
20963255 HANDLE, R/SEAT LAT REL (PART OF 26) (EBONY) (W/NUMBER LABELS ON 3RD ROW SEAT) (FOR 1ST DES SEE 15822356)
20963257 HANDLE, R/SEAT LAT REL (PART OF 26) (TITANIUM) (W/NUMBER LABELS ON 3RD ROW SEAT) (FOR 1ST DES SEE 15822358)
15822356 HANDLE, R/SEAT LAT REL (PART OF 26) (EBONY) (W/O NUMBER LABELS ON 3RD ROW SEAT) (FOR 2ND DES SEE 20963255)
15822357 HANDLE, R/SEAT LAT REL (PART OF 26) (CASHMERE) (W/O NUMBER LABELS ON 3RD ROW SEAT) (FOR 2ND DES SEE 20963256)
15822358 HANDLE, R/SEAT LAT REL (PART OF 26) (TITANIUM) (W/O NUMBER LABELS ON 3RD ROW SEAT) (FOR 2ND DES SEE 20963257)
20963256 HANDLE, R/SEAT LAT REL (PART OF 26) (CASHMERE) (W/NUMBER LABELS ON 3RD ROW SEAT) (FOR 1ST DES SEE 15822357)
22906161 HANDLE, R/SEAT LAT REL (PART OF 26)
25928520 LATCH, 3RD ROW SEAT BK (SIDE)
15804483 COVER, 3RD ROW SEAT BK LAT (EBONY) (REAR CLOSEOUT) (16.716)
15804484 COVER, 3RD ROW SEAT BK LAT (CASHMERE) (REAR CLOSEOUT) (16.716)
22772286 COVER, 3RD ROW SEAT BK LAT (EBONY)
22772287 COVER, 3RD ROW SEAT BK LAT (CASHMERE)
22772289 COVER, 3RD ROW SEAT BK LAT (COCOA)
15898401 LATCH, 3RD ROW SEAT LOAD FLR (INCLS 43, 44)
15804488 COVER, 3RD ROW SEAT BK LAT (EBONY) (FRONT CLOSEOUT) (16.716)
15804489 COVER, 3RD ROW SEAT BK LAT (CASHMERE) (FRONT CLOSEOUT) (16.716)
15804490 COVER, 3RD ROW SEAT BK LAT (TITANIUM) (FRONT CLOSEOUT) (16.716)
20963267 CABLE, 3RD ROW SEAT BK LAT (INCLS 18) (EBONY) (50% MAIN CONTROL BOX)
20963268 CABLE, 3RD ROW SEAT BK LAT (INCLS 18) (CASHMERE) (50% MAIN CONTROL BOX)
teamcadillac.ru
20963269 CABLE, 3RD ROW SEAT BK LAT (INCLS 18) (TITANIUM) (50% MAIN CONTROL BOX)
20963270 CABLE, 3RD ROW SEAT BK LAT (INCLS 18) (COCOA) (50% MAIN CONTROL BOX)
15832238 CABLE, 3RD ROW SEAT BK LAT (INCLS 18) (EBONY) (W/PULL HANDLE) (50% MAIN CONTROL BOX)
15832239 CABLE, 3RD ROW SEAT BK LAT (INCLS 18) (CASHMERE) (W/PULL HANDLE) (50% MAIN CONTROL BOX)
15832240 CABLE, 3RD ROW SEAT BK LAT (INCLS 18) (TITANIUM) (W/PULL HANDLE) (50% MAIN CONTROL BOX)
15791115 FRAME, 3RD ROW SEAT CUSH
15822389 COVER, 3RD ROW SEAT BK HGE FIN (EBONY) (INBOARD, OUTER)
15822390 COVER, 3RD ROW SEAT BK HGE FIN (CASHMERE) (INBOARD, OUTER)
15822391 COVER, 3RD ROW SEAT BK HGE FIN (TITANIUM)
12476887 BOLT, 3RD ROW SEAT BK PIV (M10X1.5) (W/BUSHING) (16.679)
15924950 COVER, 3RD ROW SEAT BK HGE FIN (EBONY) (PIVOT PROTECTOR)
15924951 COVER, 3RD ROW SEAT BK HGE FIN (CASHMERE) (PIVOT PROTECTOR)
15924952 COVER, 3RD ROW SEAT BK HGE FIN (TITANIUM) (PIVOT PROTECTOR)
15833812 RETAINER, R/SEAT CUSH FRM
25960398 FRAME, 3RD ROW SEAT BK
15898363 FRAME, 3RD ROW SEAT BK
15898400 FRAME, 3RD ROW SEAT BK
19152520 BELT KIT, R/SEAT #2 (BKL SI) (TITANIUM) (BKL/BKL)
19180589 BELT KIT, R/SEAT #2 (BKL SI) (COCOA)
19152519 BELT KIT, R/SEAT #2 (BKL SI) (CASHMERE) (BKL/BKL)
19152518 BELT KIT, R/SEAT #2 (BKL SI) (EBONY) (BKL/BKL)
15804534 PAD, 3RD ROW SEAT CUSH
25858728 COVER, 3RD ROW SEAT CUSH (COCOA)
25937613 COVER, 3RD ROW SEAT CUSH (EBONY)
25937614 COVER, 3RD ROW SEAT CUSH (CASHMERE)
25937615 COVER, 3RD ROW SEAT CUSH (TITANIUM)
20758148 COVER, 3RD ROW SEAT CUSH (CASHMERE)
20904823 COVER, 3RD ROW SEAT CUSH (EBONY)
20904825 COVER, 3RD ROW SEAT CUSH (CASHMERE)
22751182 COVER, 3RD ROW SEAT CUSH (CASHMERE)
25928470 COVER, 3RD ROW SEAT CUSH (CASHMERE)
20859434 COVER, 3RD ROW SEAT CUSH (EBONY)
25928469 COVER, 3RD ROW SEAT CUSH (EBONY)
25928471 COVER, 3RD ROW SEAT CUSH (TITANIUM)
20904829 COVER, 3RD ROW SEAT BK (EBONY) (W/CHILD SEAT BELT COMFORT GUIDE) (W/O NUMBER LABELS ON 3RD ROW SEAT) (FOR 2ND DES SEE 20963297)
20904831 COVER, 3RD ROW SEAT BK (CASHMERE) (W/CHILD SEAT BELT COMFORT GUIDE) (W/O NUMBER LABELS ON 3RD ROW SEAT) (FOR 2ND DES SEE 20963298)
20963280 COVER, 3RD ROW SEAT BK (EBONY) (W/NUMBER LABELS ON 3RD ROW SEAT) (FOR 1ST DES SEE 15865793)
20963288 COVER, 3RD ROW SEAT BK (EBONY) (W/NUMBER LABELS ON 3RD ROW SEAT) (FOR 1ST DES SEE 20859428)
20963289 COVER, 3RD ROW SEAT BK (CASHMERE) (W/NUMBER LABELS ON 3RD ROW SEAT) (FOR 1ST DES SEE 20859429)
20963297 COVER, 3RD ROW SEAT BK (EBONY) (W/NUMBER LABELS ON 3RD ROW SEAT) (FOR 1ST DES SEE 20904829)
15865793 COVER, 3RD ROW SEAT BK (EBONY) (INCLS CHILD COMFORT GUIDE) (W/O NUMBER LABELS ON 3RD ROW SEAT) (FOR 2ND DES SEE 20963280)
20859428 COVER, 3RD ROW SEAT BK (EBONY) (INCLS CHILD COMFORT GUIDE) (W/O NUMBER LABELS ON 3RD ROW SEAT) (FOR 2ND DES SEE 20963288)
20859429 COVER, 3RD ROW SEAT BK (CASHMERE) (INCLS CHILD COMFORT GUIDE) (W/O NUMBER LABELS ON 3RD ROW SEAT) (FOR 2ND DES SEE 20963289)
20963298 COVER, 3RD ROW SEAT BK (CASHMERE) (W/NUMBER LABELS ON 3RD ROW SEAT) (FOR 1ST DES SEE 20904831)
20963300 COVER, 3RD ROW SEAT BK (COCOA) (W/NUMBER LABELS ON 3RD ROW SEAT) (FOR 1ST DES SEE 25858726)
25858726 COVER, 3RD ROW SEAT BK (COCOA) (W/O NUMBER LABELS ON 3RD ROW SEAT) (FOR 2ND DES SEE 20963300)
88936748 CAP, R/SEAT ADJR TRK END (BLACK)
15924919 PANEL, R/SEAT BK FIL
25895134 BAR, R/SEAT HGE LINK TIE (PART OF 21)
(TC16-420) 2007-2013 CK107(06) РЕМНИ БЕЗОПАСНОСТИ ЗАДНИЕ (AL4,AM8)
19168657 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 17) (COCOA)
19260305 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 17) (CASHMERE)
19260307 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 17) (COCOA)
19260310 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 17) (TITANIUM)
19260309 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 17) (CASHMERE)
25810538 BELT, R/SEAT (RETR SI) (INCLS 2, 17) (EBONY)
25810541 BELT, R/SEAT (RETR SI) (INCLS 2, 17) (EBONY)
25847304 BELT, R/SEAT (RETR SI) (INCLS 2, 17) (COCOA)
25847305 BELT, R/SEAT (RETR SI) (INCLS 2, 17) (COCOA)
25906758 BELT, R/SEAT (RETR SI) (INCLS 2, 17) (CASHMERE)
25906759 BELT, R/SEAT (RETR SI) (INCLS 2, 17) (CASHMERE)
19260304 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 17) (EBONY)
19260306 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 17) (TITANIUM)
19260308 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 17) (EBONY)
11588539 BOLT, R/SEAT BELT (RETR SI) (PART OF 1) (M12X1.75X52.75 22 OD) (8.913)
11609886 BOLT, R/SEAT BELT (RETR SI) (M12X1.75X40, 22 OD)
11610207 BOLT, R/SEAT BELT (RETR SI) (M12X1.75X76, 22 OD) (8.913)
19210380 BELT, R/SEAT (BKL SI) (COCOA)
19151106 BELT KIT, R/SEAT CTR (RETR SI) (INCLS 12, 17) (TITANIUM)
19210381 BELT KIT, R/SEAT CTR (RETR SI) (INCLS 12, 17) (COCOA)
19151105 BELT KIT, R/SEAT CTR (RETR SI) (INCLS 12, 17) (CASHMERE)
19151104 BELT KIT, R/SEAT CTR (RETR SI) (INCLS 12, 17) (EBONY)
teamcadillac.ru
25919004 BELT, R/SEAT CTR SHLDR (RETR SI) (INCLS 12, 17) (CASHMERE)
25778338 BELT, R/SEAT CTR SHLDR (RETR SI) (INCLS 12, 17) (EBONY)
19207765 STOP KIT, BELT LAT (RETR SI) (PART OF 1, 10) (COCOA) (14.875)
19121445 STOP KIT, BELT LAT (RETR SI) (PART OF 1, 10) (CASHMERE) (14.875)
19121443 STOP KIT, BELT LAT (RETR SI) (PART OF 1, 10) (TITANIUM) (14.875)
19121446 STOP KIT, BELT LAT (RETR SI) (PART OF 1, 10) (EBONY) (14.875)
(TC16-434) 2007-2013 CK1,2(06-36) НАРУЖНОЕ ЗЕРКАЛО ЗАДНЕГО ВИДА (HEATED,POWER FOLDING,TURN SIGNAL DL3)
25829663 GLASS, O/S RR VIEW MIR (PART OF 4)
20778440 GLASS, O/S RR VIEW MIR (PART OF 4)
20778441 GLASS, O/S RR VIEW MIR (PART OF 4)
25829662 GLASS, O/S RR VIEW MIR (PART OF 4)
25829664 GLASS, O/S RR VIEW MIR (PART OF 4)
teamcadillac.ru
11570831 BOLT, O/S RR VIEW MIR ACTR (PART OF 4)
25808705 ACTUATOR, O/S RR VIEW MIR INR (GLASS ACTUATOR W/MEMORY/POWER FOLDING MIRROR) (PART OF 4) (W/1 PIGTAIL ON BACK)
25808706 ACTUATOR, O/S RR VIEW MIR INR (GLASS ACTUATOR W/MEMORY/POWER FOLDING MIRROR) (PART OF 4) (W/1 PIGTAIL ON BACK)
25808704 ACTUATOR, O/S RR VIEW MIR INR (PART OF 4) (W/1 PIGTAIL ON BACK) (W/O MEMORY)
20756788 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (PAINT TO MATCH TOP SKULL CAP & CHROME BOTTOM)
20756774 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (CHROME)
20756950 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (CHROME)
20756905 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (PAINT TO MATCH)
20843106 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (CHROME)
20843108 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (CHROME)
20843129 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (PAINT TO MATCH)
20843216 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (PAINT TO MATCH TOP SKULL CAP & CHROME BOTTOM)
20756915 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (PAINT TO MATCH)
25801822 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (MOLDED IN BLACK)
20756968 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (BLACK)
20756951 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (CHROME)
01999382 BULB, (PART OF 4, 6) (ACDelco #W5WLL) (LONGER LIFE)
15875000 LAMP, CTSY (PART OF 4) (INCLS 5) (O/S RR VIEW)
15874999 LAMP, CTSY (PART OF 4) (INCLS 5) (O/S RR VIEW)
25862775 SEAL, O/S RR VIEW MIR (PART OF 4)
25862772 SEAL, O/S RR VIEW MIR (PART OF 4)
25862774 SEAL, O/S RR VIEW MIR (PART OF 4)
25862773 SEAL, O/S RR VIEW MIR (PART OF 4)
25601643 NUT, HEX W/CON WA, M6X1X5.6, 24 OD, 9, ZF (O/S RR VIEW MIR) (8.917)
25816712 FILLER, FRT S/D O/S RR VIEW MIR (INSIDE VEHICLE)
25788160 HOUSING, O/S RR VIEW MIR (PART OF 4) (CHROME)
25788154 HOUSING, O/S RR VIEW MIR (PART OF 4) (MOLDED IN BLACK) (PEBBLE GRAINED FINISH))
25788155 HOUSING, O/S RR VIEW MIR (PART OF 4) (MOLDED IN BLACK) (PEBBLE GRAINED FINISH))
25788156 HOUSING, O/S RR VIEW MIR (PART OF 4) (PAINT TO MATCH)
25788161 HOUSING, O/S RR VIEW MIR (PART OF 4) (CHROME)
25788157 HOUSING, O/S RR VIEW MIR (PART OF 4) (PAINT TO MATCH) (16.069)
(TC16-447) 2008-2011 CK1,2(06-36) КРЕПЛЕНИЕ ПЕРЕДНЕГО СИДЕНЬЯ (AN3,A95, EXC HYBRID HP2)
15882407 COVER, D/SEAT INR ADJR RR FIN (COCOA)
15214539 COVER, D/SEAT INR ADJR RR FIN (EBONY) (INBOARD TRACKS) (REAR)
15219928 COVER, D/SEAT INR ADJR RR FIN (CASHMERE)
15214527 COVER, D/SEAT ADJR FIN (EBONY) (BELT UTILITY)
15214529 COVER, D/SEAT ADJR FIN (TITANIUM) (BELT UTILITY)
15219925 COVER, D/SEAT ADJR FIN (CASHMERE) (BELT UTILITY)
11562473 BOLT, F/SEAT (M12X1.75X45)
15219926 CAP, F/SEAT CUSH OTR FIN CVR BOLT (CASHMERE)
15895267 CAP, F/SEAT CUSH OTR FIN CVR BOLT (TITANIUM)
15882403 CAP, F/SEAT CUSH OTR FIN CVR BOLT (COCOA)
15214533 CAP, F/SEAT CUSH OTR FIN CVR BOLT (EBONY)
25952151 COVER, WRG HARN CONN (EBONY)
25952153 COVER, WRG HARN CONN (EBONY)
15882405 COVER, D/SEAT INR ADJR FRT FIN (COCOA)
15931771 COVER, D/SEAT INR ADJR FRT FIN (EBONY)
15931772 COVER, D/SEAT INR ADJR FRT FIN (CASHMERE)
15931773 COVER, D/SEAT INR ADJR FRT FIN (TITANIUM)
15035434 NUT, F/SEAT (M10X1.5X10.8) (FLANGE NUT) (16.679)
15931779 COVER, P/SEAT INR ADJR FRT FIN (TITANIUM)
15882409 COVER, P/SEAT INR ADJR FRT FIN (COCOA)
15931777 COVER, P/SEAT INR ADJR FRT FIN (EBONY) (INBOARD TRACKS)
teamcadillac.ru
20841315 SEAT, PASS (EBONY)
20841316 SEAT, PASS (CASHMERE)
20909009 SEAT, PASS (COCOA)
20909027 SEAT, PASS (EBONY)
20909028 SEAT, PASS (CASHMERE)
20909052 SEAT, PASS (COCOA)
20908986 SEAT, DRVR (EBONY)
20908987 SEAT, DRVR (CASHMERE)
20909011 SEAT, DRVR (COCOA)
20909050 SEAT, DRVR (COCOA)
15895269 COVER, D/SEAT INR ADJR RR FIN (TITANIUM)
15931778 COVER, P/SEAT INR ADJR FRT FIN (CASHMERE)
15214530 COVER, P/SEAT ADJR FIN (EBONY) (OUTBOARD, BELT UTILITY)
15214532 COVER, P/SEAT ADJR FIN (TITANIUM) (BELT UTILITY)
15219924 COVER, P/SEAT ADJR FIN (CASHMERE) (BELT UTILITY)
15882423 COVER, P/SEAT ADJR FIN (COCOA) (BELT UTILITY)
15895289 COVER, P/SEAT INR ADJR RR FIN (TITANIUM)
15882411 COVER, P/SEAT INR ADJR RR FIN (COCOA)
15219930 COVER, P/SEAT INR ADJR RR FIN (CASHMERE)
(TC16-452) 2008-2010 CK1,2(06) СИСТЕМА ЗАМКОВ/ДИСТАНЦИОННОЕ УПРАВЛЕНИЕ БЕЗ КЛЮЧА (CADILLAC Z75, AP3,AU0)
00000001 TRANSMITTER, R/CON DR LK (DEALER INSTALLED 2-WAY WITH DISPLAY-SEE GROUP 21.271 TRANSMITTER) (INCLS 2)
20925554 TRANSMITTER, R/CON DR LK (INCLS 2) (FOB #2)
20869058 TRANSMITTER, R/CON DR LK (INCLS 2) (FOB #1) (W/O REMOTE ENG START)
20869059 TRANSMITTER, R/CON DR LK (INCLS 2) (FOB #2) (W/O REMOTE ENG START)
22756466 TRANSMITTER, R/CON DR LK (INCLS 2) (FOB #2) (W/REMOTE STARTER)
teamcadillac.ru
22756465 TRANSMITTER, R/CON DR LK (INCLS 2) (FOB #1) (W/REMOTE STARTER)
12538938 BATTERY, R/CON DR LK XMTR (PART OF 1) (LITHIUM) (TRADE CR2032) (10.485)
25880055 ANTENNA, R/CON DR LK RCVR
20803736 RECEIVER, R/CON DR LK (10.485)
20803735 RECEIVER, R/CON DR LK (RECEIVERS LABELED OEM 20803735) (10.485)
(TC16-453) 2010 CK107(06) КРЕПЛЕНИЕ ЗАДНЕГО СИДЕНЬЯ (60/40 BENCH AM8, EXC HYBRID HP2)(1ST DES)
15887830 COVER, R/SEAT RSR FIN (EBONY) (ON FLOOR)
teamcadillac.ru
15887831 COVER, R/SEAT RSR FIN (CASHMERE) (ON FLOOR)
15887833 COVER, R/SEAT RSR FIN (CASHMERE) (ON FLOOR)
25875547 COVER, R/SEAT RSR FIN (TITANIUM)
25906783 COVER, R/SEAT RSR FIN (CASHMERE)
11562546 WASHER, FLAT, 14X42.5X3.61 MM, SAE 1050 STL RC 37-43, 7112M (R/SEAT)
(TC16-455) 2010 CK107(06) КРЕПЛЕНИЕ ЗАДНЕГО СИДЕНЬЯ (BUCKET AL4)(1ST DES)
15887843 COVER, R/SEAT RSR FIN (CASHMERE) (ON FLOOR) (W/CARPET)
25831283 COVER, R/SEAT RSR FIN (LINEN) (ON FLOOR) (W/CARPET)
25875543 COVER, R/SEAT RSR FIN (TITANIUM) (ON FLOOR) (W/CARPET)
25906779 COVER, R/SEAT RSR FIN (CASHMERE) (ON FLOOR) (W/CARPET)
15887842 COVER, R/SEAT RSR FIN (EBONY) (ON FLOOR) (W/CARPET)
teamcadillac.ru
25831282 COVER, R/SEAT RSR FIN (LINEN) (ON FLOOR) (W/CARPET)
25906778 COVER, R/SEAT RSR FIN (CASHMERE) (ON FLOOR) (W/CARPET)
15887836 COVER, R/SEAT RSR FIN (EBONY) (ON FLOOR) (W/CARPET)
25875542 COVER, R/SEAT RSR FIN (TITANIUM) (ON FLOOR) (W/CARPET)
(TC16-813) 2007-2013 CK DOOR HARDWARE-PIN KITS
19260061 PIN KIT, FRT S/D HGE (INCLS UPR/LWR PINS, BUSHINGS, WASHER, DUST CAPS, NUTS, BOLT & INST SHEET, (GREASEABLE) (INCLS 2-7)
teamcadillac.ru
19260063 PIN KIT, FRT S/D HGE (INCLS CHECK PIN, ROLLLER PIN, ROLLER, BUSHINGS, DUST CAPS, NUTS & INST SHEET (GREASEABLE) (INCLS 3, 4, 9-12)
(TC16-936) 2007-2013 CK1(06-36) ПРИБОРНАЯ ПАНЕЛЬ И СВЯЗАННЫЕ ДЕТАЛИ PART 2 ELECTRICAL (CADILLAC Z75)
25819574 AIRBAG, I/P (COCOA)
25812358 AIRBAG, I/P (CASHMERE) (DUAL LEVEL)
25812355 AIRBAG, I/P (EBONY)
11588337 BOLT, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (I/P AIRBAG)
25949881 CLOCK, DISPLAY (ROMAN NUMERALS ON CLOCK FACE.)
11610157 NUT, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (I/P) (10.701)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (RDO) (9.665)
15859233 SWITCH, RR PARK ASST ALARM CONT MDL
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (I/P ACSRY CTR TR PLT)
15859232 SWITCH, DRVR INFO DISPLAY
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (ACSRY SW BZL) (9.665)
20820629 SWITCH, ACSRY (1 BUTTON) (ADJ PED)
20820630 SWITCH, ACSRY (2 BUTTON) (ADJ PED, SONIC/PARK) (W/PWR ASSIST STEP DISABLE SWITCH)
20878803 CONTROL, HTR & A/C (W/ F/SEAT HTR & CUSH VENT FAN)
20878804 CONTROL, HTR & A/C (W/ F/SEAT HTR & CUSH VENT FAN)
25936307 CONTROL, HTR & A/C (W/ F/SEAT HTR & CUSH VENT FAN) (ACDelco #15-74029)
25936309 CONTROL, HTR & A/C (W/ F/SEAT HTR & CUSH VENT FAN) (ACDelco #15-74031)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (COMN INTERFACE MDL BRKT) (9.665)
11588920 SCREW, W/RND WA, M3.5X1.59X9.5, 6 THD, 7 O.D., GM512M, GMW3044 (RDO VOL COMP INTR NOISE MIC)
20829983 MODULE, COMN INTERFACE (W/MOBILE TEL XCVR) (LABELED 20829983) (ACDelco #20829983)
20829984 MODULE, COMN INTERFACE (W/MOBILE TEL XCVR) (LABELED 20829984) (ACDelco #20829984)
20923563 MODULE, COMN INTERFACE (W/MOBILE TEL XCVR) (LABELED 20923563) (ACDelco #20923563)
22850735 MODULE, COMN INTERFACE (W/MOBILE TEL XCVR) (ACDelco #22850735) (LABELED 22850735)
11610157 NUT, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (COMMUNICATION INTERFACE MDL BRKT) (10.701)
25791895 BRACKET, COMMUNICATION INTERFACE MDL
teamcadillac.ru
25783504 MICROPHONE, RDO VOL COMP INTR NOISE (HEADLINER PANEL)
15240415 MICROPHONE, RDO VOL COMP INTR NOISE
15221547 PLATE, HDLP SW TR (INCLS 23) (EBONY)
15907806 PLATE, HDLP SW TR (INCLS 23) (EBONY)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 22)
25858706 SWITCH, HDLP & I/P LP DIMR & DM LP (HAS "DOME OFF") (INCLS FRT FOG LAMP SWITCH) (ACDelco #D1528J)
25858707 SWITCH, HDLP & I/P LP DIMR & DM LP (HAS "DOME OFF") (INCLS FRT & RR FOG LAMP SWITCH) (ACDelco #D1529J)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 29)
88909749 FUSE, 3A, MINI, VIOLET (PART OF 29) (8.965) (ACDelco #ATM3-25)
88909754 FUSE, 15A, MINI, BLUE (PART OF 29) (ACDelco #ATM15-25)
88909756 FUSE, MINI (25 AMP) (CLEAR) (QTY 25 (PART OF 29) (ACDelco #ATM25-25)
12092079 FUSE, 10A, MINI, RED (PART OF 29)
88861352 FUSE, 20A, MINI, YELLOW (PART OF 29) (ACDelco #ATM20)
12084791 PULLER, FUSE (PART OF 29) (MINI) (I/P COVER)
25940492 COVER, I/P FUSE BLK ACC HOLE (INCLS 26-28, 30) (EBONY)
25940498 COVER, I/P FUSE BLK ACC HOLE (INCLS 26-28, 30) (CASHMERE)
22925347 COVER, I/P FUSE BLK ACC HOLE (INCLS 26-28, 30) (LINEN) (IF VEH HAS 30 AMP FUSE ORDER LABEL 25940508)
25940508 LABEL, I/P WRG HARN FUSE BLK IDENT (PART OF 29) (2.483)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (INST CSTR) (9.665)
25713063 SENSOR, HDLP AUTO CONT AMB LGT (DUAL SOLAR & TWILIGHT) (ACDelco #25713063)
20887770 CLUSTER, INST (ACDelco #20887770)
20887772 CLUSTER, INST (ACDelco #20887772)
20887771 CLUSTER, INST (ACDelco #20887771)
20887773 CLUSTER, INST (ACDelco #20887773)
25798963 SPEAKER, RDO FRT (3.5") (9.665) (ACDelco #25798963)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 37)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (RDO FRT SPKR) (9.665)
15221850 GRILLE, RDO FRT SPKR (INCLS 35) (EBONY)
15221851 GRILLE, RDO FRT SPKR (INCLS 35) (COCOA)
15248601 GRILLE, RDO FRT SPKR (INCLS 35) (EBONY)
15859569 ANTENNA, ELEK NAVIGATION (ACDelco #15859569)
25918632 ANTENNA, ELEK NAVIGATION (ACDelco #25918632)
(TC16-938) 2007-2013 CK1,2,3 ВЕТРОВОЕ СТЕКЛО И СВЯЗАННЫЕ ДЕТАЛИ
25774613 MIRROR, I/S RR VIEW (INCLS 2)
15816792 MIRROR, I/S RR VIEW (INCLS 2) (W/O MIC) (MATING CONN W/LEADS USE 15306351)
teamcadillac.ru
15271286 MIRROR, I/S RR VIEW (INCLS 2) (10.185)
20945097 MIRROR, I/S RR VIEW (INCLS 2) (10.185)
22915245 MIRROR, I/S RR VIEW (INCLS 2)
19207911 BOLT, I/S RR VIEW MIR (PART OF 1) (BLACK) (M10X24X12.7) (10.186)
15779345 COVER, I/S RR VIEW MIR WRG HARN (BETWEEN ISRVM & HDLNG TRIM)
20859593 WINDSHIELD, (INCLS 3, 6, 14)
20979218 WINDSHIELD, (INCLS 3, 6, 14) (INCLS UPR MLDG)
11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (W/S R/MLDG)
11589183 NUT, PUSH IN, W/SEAL, 4.2X1.41, 6.35-6.48 SQ HL, 9.5 SQ HD, 0.787-2.765 PNL THK, NYL (W/S R/MLDG)
20918020 MOLDING, W/S RVL
20918021 MOLDING, W/S RVL
25954952 SUPPORT, W/S
(TC16-939) 2007-2013 CK107(06) ЛИСТОВОЙ МЕТАЛЛ/КРЫША
25991527 PANEL, RF (ASM)
15202470 PANEL, RF (PO PNL ASM)
15287943 PANEL, RF
15264587 BOW, RF PNL #4 (W/O NUT)
15102503 BOW, RF PNL #3 (W/O NUT)
15288511 BOW, RF PNL #2 (W/NUT)
15163037 BOW, RF PNL #1 (W/O NUT)
teamcadillac.ru
15202494 BRACKET, RF CNSL
15202446 PANEL, RF FRT HDR (INCLS 8, 9) (W/SHIELD RAKE)
10056725 NUT, PUSH-IN, M4.2X1.41, 50 CARB SPR STL, GM7111M PO ZOR (PART OF 7)
(TC16-942) 2007-2013 CK1,2,3 ЛИСТОВОЙ МЕТАЛЛ/COWL
15847235 PANEL, DA (INCLS 2-9, 11-21)
teamcadillac.ru
20836099 PANEL, PLNM UPR (PART OF 1)
11609625 STUD, DA & COWL PNL INSL (PART OF 1, 6) (M5 X 1.6 X 57.0) (RIVET STYLE) (4.047)
15713209 BRACKET, BRK & ACCEL PED (PART OF 1) (L=45 W=80 H=80) (DASH PANEL) (0.829)
15134620 PANEL, PLNM LWR (PART OF 1)
20836094 PANEL, PLNM FRT (PART OF 1) (INCLS 3, 7, 17)
11609625 STUD, DA WRG HARN (PART OF 1, 6) (M5 X 1.6 X 57.0) (RIVET STYLE) (4.047)
22844748 PANEL, COWL SI (PART OF 1) (INCLS 9)
15856112 VALVE, PLNM DRN
15856113 VALVE, PLNM DRN
15862261 BRACKET, FRT W/H PNL UPR (PART OF 1)
11609625 STUD, CHAS WRG HARN CLIP (PART OF 1) (M5 X 1.6 X 57.0) (RIVET STYLE) (4.047)
15185451 BRACKET, BAT TRAY (PART OF 1)
22844749 PANEL, COWL SI (PART OF 1) (INCLS 9)
11609625 STUD, BAT POS CBL (PART OF 1, 6) (M5 X 1.6 X 57.0) (RIVET STYLE) (4.047)
15854747 BRACKET, HOOD STRUT (BODY SI) (PART OF 1) (INCLS 19)
11562567 STUD, HOOD STRUT BALL (PART OF 1, 18)
25809428 DEFLECTOR, PLNM LWR PNL WAT (PART OF 1) (INCLS 21)
15607103 RETAINER, PLNM S/PNL WAT DFL (PART OF 1, 20) (LWR WATER DEFLECTOR) (9.264)
15895064 COVER, PLNM UPR PNL OPG
(TC16-943) 2007-2013 CK107(06) ЛИСТОВОЙ МЕТАЛЛ/UNDERBODY
15234714 PANEL, R/FLR (INCLS 2)
15630183 PLATE, CARGO TIE DN LOOP ANC (PART OF 1) (16.715)
10382641 BRACKET, JK STOW (BOTTOM BRKT INCLS STUDS)
15847621 PANEL, RR W/H INR
15274143 INSULATOR, S/D OPG FRM (C-PLR LWR)
15274144 INSULATOR, S/D OPG FRM (C-PLR LWR)
15288880 EXTENSION, INTER FLR PNL
15288881 EXTENSION, INTER FLR PNL
25815106 EXTENSION, FLR PNL (FRONT)
25815107 EXTENSION, FLR PNL (FRONT)
15115647 SILL, U/B RR CR
15226696 SILL, U/B #5 CR
25946279 SILL, U/B #3 CR
25860801 REINFORCEMENT, R/FLR PNL
teamcadillac.ru
15234718 REINFORCEMENT, R/FLR PNL OTR
15234719 REINFORCEMENT, R/FLR PNL OTR
25946282 SILL, U/B #4 CR
15154215 REINFORCEMENT, R/FLR PNL FRT
15234716 REINFORCEMENT, R/FLR PNL FRT (INCLS EXH MUFF H/SHLD, WELD STUDY)
15234712 REINFORCEMENT, INTER FLR PNL (INCLS EXH MUFF H/SHLD, WELD STUDY)
15722519 REINFORCEMENT, INTER FLR PNL
15029772 BRACE, INTER FLR PNL
15234710 REINFORCEMENT, FLR PNL
15234713 REINFORCEMENT, INTER FLR PNL (CENTER)
25860799 REINFORCEMENT, F/FLR PNL
25946285 SILL, U/B #1 CR
25937226 BRACE, CR SILL
15828261 REINFORCEMENT, FLR PNL (D/SEAT) (OUTER)
25831426 BRACKET, BODY MT (#2) (W/O REINFORCEMENT)
20848417 SILL, U/B #2 CR
25831425 BRACKET, BODY MT (#2)
15822915 REINFORCEMENT, FLR PNL (D/SEAT) (INNER)
20914723 BRACE, CR SILL
25946286 SILL, U/B #1 CR
15234733 REINFORCEMENT, FLR PNL (P/SEAT) (OUTER)
15234735 REINFORCEMENT, FLR PNL (P/SEAT) (INNER)
15173440 STIFFENER, FLR PNL AT TUN
15173441 STIFFENER, FLR PNL AT TUN
20989092 PANEL, F/FLR (INCLS 37-39)
15827692 PANEL, RKR FRT INR
25982599 PANEL, RKR FRT INR
22812484 PANEL, RKR FRT INR
15174121 BRACKET, I/P LWR (PART OF 35)
15734736 STUD, F/SEAT ANC PLT (PART OF 35)
11609625 STUD, BODY WRG HARN GND (PART OF 35) (M5 X 1.6 X 57.0) (RIVET STYLE) (4.047)
25982606 PANEL, RKR RR INR (INCLS STUDS)
25982601 PANEL, RKR RR INR
15950124 PANEL, INTER FLR
(TC16-948) 2007-2013 CK107(06) ЛИСТОВОЙ МЕТАЛЛ/BODY SIDE REAR
25822461 PANEL, BODY SI OTR
25822462 PANEL, BODY SI OTR
11519023 RIVET, POP SHANK 0.256, LENGTH 0.643, 0.189-0.268 GRIP RANGE, 1033 STL, (F/TNK FIL DR HGE)
15940678 DOOR, F/TNK FIL (SEE GROUP 03.000 "FUEL FILLER PIPE" FOR DETAILED ILLUSTRATED VIEW)
25997545 FILLER, BODY SI OTR PNL
25997546 FILLER, BODY SI OTR PNL
15862275 EXTENSION, RR W/H PNL FRT
22813619 EXTENSION, RR W/H PNL FRT
15929419 PANEL, RR W/H OTR (FRT)
15929495 PANEL, RR W/H OTR (FRT)
15824937 PANEL, RR W/H OTR (RR)
15824938 PANEL, RR W/H OTR (RR)
15830951 GASKET, F/TNK FIL DR OPG FIL
20867363 PANEL, BODY SI INR LWR
teamcadillac.ru
20867362 PANEL, BODY SI INR LWR
15876164 SEAL, BODY SI INR LWR PNL
15876165 SEAL, BODY SI INR LWR PNL
25893145 PLATE, R/SEAT SHLDR BELT ANC
25893144 PLATE, R/SEAT SHLDR BELT ANC
15202476 RAIL, RF UPR SI
15202477 RAIL, RF UPR SI
25893161 REINFORCEMENT, BK BODY OPG SI FRM (SEE GROUP 16.000 "SHEET METAL/BODY REAR" FOR DETAILED ILLUSTRATED VIEW)
25893160 REINFORCEMENT, BK BODY OPG SI FRM (SEE GROUP 16.000 "SHEET METAL/BODY REAR" FOR DETAILED ILLUSTRATED VIEW)
25893142 RAIL, RF LWR SI
25893143 RAIL, RF LWR SI
15854158 PANEL, BODY SI INR UPR
15858829 PANEL, BODY SI INR UPR
25780812 PANEL, BODY SI INR
22823527 PANEL, BODY SI INR
15255977 PANEL, F/TNK FIL PIPE HSG
(TC16-951) 2007-2013 CK1,2(06) ЛИСТОВОЙ МЕТАЛЛ/BODY REAR
20942658 FRAME, BK BODY OPG UPR
20938346 EXTENSION, BK BODY OPG FRM UPR
25778949 FRAME, BK BODY OPG
15164155 FRAME, BK BODY OPG SI
15829742 REINFORCEMENT, BK BODY OPG FRM LWR (INCLS 7)
15164157 FRAME, BK BODY OPG LWR
25946269 BRACKET, BODY RR MT (INCLS 10) (BODY)
15887101 SEAL, BK BODY OPG LWR FRM FIL (TO INTER FLR PNL)
22894056 SEAL, BK BODY OPG LWR FRM FIL (TO INTER FLR PNL)
15816355 PANEL, BK BODY OPG FRM SI FIL LWR
teamcadillac.ru
15816359 FILLER, BK BODY OPG FRM SI
15816356 PANEL, BK BODY OPG FRM SI FIL LWR
15816358 FILLER, BK BODY OPG FRM SI
15164156 FRAME, BK BODY OPG SI
(TC16-957) 2007-2013 CK1,2(06-36) ПРИБОРНАЯ ПАНЕЛЬ И СВЯЗАННЫЕ ДЕТАЛИ PART 3 SUPPORTS (CADILLAC Z75)
25842112 SUPPORT, I/P CARR (INCLS 3, 4, 10)
20996068 SUPPORT, I/P CARR (INCLS 3, 4, 10)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (I/P LWR TR PAD) (9.665)
11610157 NUT, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (PART OF 1) (10.701)
teamcadillac.ru
15192254 DEFLECTOR, I/P DRVR KNEE BOLS
11508277 NUT, HEX W/CON WA M6X1 THD, OD-19 PEOR 9 (I/P DRVR KNEE BOLS DFL)
10355555 BRACE, I/P CTR SUPT
11609410 BOLT, HFH, M8X1.25X25, 10.9, GMW3179 (I/P CTR SUPT BR) (0.056)
11589407 BOLT, HWH, M8X1.25X35, 23.5 THD, 24 OD, 10.9, GMW3359, M-PT. (I/P CARR SUPT)
11508277 NUT, HEX W/CON WA M6X1 THD, OD-19 PEOR 9 (I/P LWR T/PNL)
11570136 BOLT, HEX HD, W/CON SPR WA, M6X1X23, 14 THD, 17 O.D., 8.8, GMW3359 (I/P UPR T/PNL)
(TC16-960) 2007-2013 CK1,2(06) СТЕКЛООЧИСТИТЕЛЬ/ЗАДНЕЕ СТЕКЛО (C25)
25887957 HOSE, R/WDO WA PUMP (REAR JUMPER HOSE)
15927514 GROMMET, WSWA PUMP (PUMP GROMMET) (*KIT1, KIT2) (ACDelco #15927514)
11609989 BOLT, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (WSWA SOLV CNTNR)
25820075 RAMP, R/WDO WPR ARM PARK (ACDelco #25820075)
25820122 BLADE, R/WDO WPR (ACDelco #25820122)
15798935 CAP, WSW ARM NUT (PART OF 10)
11589150 NUT, HEX, W/ADH, M8X1.25X6.80, 5, GMW3359 (R/WDO WPR ARM)
15277756 ARM, R/WDO WPR (INCLS 8) (INCLS HOSE)
11569839 NUT, R/WDO WPR MOT
15173732 SPACER, R/WDO WPR MOT
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (R/WDO WPR ARM PARK RAMP)
25923437 MOTOR, R/WDO WPR (INCLS MTG BOLTS AND GROMMETS) (ACDelco #25923437)
25887953 HOSE, WSWA L/GATE EXTN RR (ACDelco #25887953)
20784419 HOSE, WSWA L/GATE EXTN SI LWR (ACDelco #20784419)
15076678 INSULATOR, WSW TRANS SUPT (16.686)
20999340 CONTAINER KIT, WSWA SOLV (INCLS 1, 3) (USE T/W 20999338 WHEN REPLACING 15248577, 15213911 OR 15942522.)
teamcadillac.ru
15942524 PUMP KIT, WSWA W/SEAL (INCLS 3, 4) (RR PUMP KIT W/GROMMET) (ACDelco #15942524)
(TC16-961) 2007-2013 CK1,2(06) ОБЛИЦОВКА КОЛЕСНОЙ АРКИ/REAR
15938661 LINER, RR W/H (INCLS 6) (W/NUT)
15938662 LINER, RR W/H (INCLS 6) (W/NUT)
11562172 BOLT, RR W/H LNR (8.153)
11589292 RETAINER, PUSH-IN, FITS 8.5 DIA HOLE IN 2-4.5 THK PNL, NYLON 6/6 GMP.PA66.015 (RR W/H LNR (PUSH IN))
01605396 RETAINER, PUSH-IN, FITS .250 HOLE, .92 LG.700-OD NYLON BLACK (RR W/H LNR (PUSH IN))
11570498 BOLT, HWH W/FL WA, M4.2X1.41X20, 11.4 THD, 17 OD, ISO 2702 STL , GMW4205, T (RR W/H LNR)
teamcadillac.ru
11513599 NUT, U-TYPE, M4.2X1.41, 0.65-3.80 PNL THK, PZ (PART OF 1) (ACDelco #11513599)
11518531 NUT, PUSH-IN, M4.2X1.41, 15.9X8.4, .7-2.1 PNL, SAE 1050 STL, 7111M, 8.65 SQ HOL (RR W/H PNL) (10.512)
(TC16-962) 2007-2010 CK1,2,3 ИЗОЛЯТОР ПЕРЕДНЕЙ ПАНЕЛИ МОТОРНОГО ОТСЕКА
15901816 INSULATOR, DA PNL (INTERIOR DASH)
25899456 INSULATOR, DA PNL (INTERIOR DASH FOR EXPORT)
15951335 INSULATOR, DA PNL (INTERIOR DASH)
20906466 INSULATOR, COWL S/PNL
teamcadillac.ru
20906467 INSULATOR, COWL S/PNL
20860275 INSULATOR, DA PNL (INCLS 4) (ENGINE SIDE)
(TC16-963) 2010 CK107(06) ПОКРЫТИЕ ПОЛА И СВЯЗАННЫЕ ДЕТАЛИ (EXC HYBRID HP2)(1ST DES)
25998507 MAT, R/FLR (BLACK)
15948218 CARPET, R/FLR PNL (INCLS 5, 15, 16) (EBONY) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922627)
25871796 CARPET, R/FLR PNL (INCLS 5, 15, 16) (TITANIUM) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922628)
25891808 CARPET, R/FLR PNL (INCLS 5, 15, 16) (EBONY) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922641)
25891811 CARPET, R/FLR PNL (INCLS 5, 15, 16) (LINEN) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922642)
25891812 CARPET, R/FLR PNL (INCLS 5, 15, 16) (TITANIUM) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922643)
25902610 CARPET, R/FLR PNL (INCLS 5, 15, 16) (CASHMERE) (79" LENGTH) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922644)
20922628 CARPET, R/FLR PNL (INCLS 5, 15, 16) (TITANIUM)
teamcadillac.ru
25875643 CARPET, R/FLR PNL (INCLS 5, 15, 16) (CASHMERE) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922629)
94672829 MAT, R/FLR (BLACK)
11588960 BOLT, PAN HD, M10X1.5X38, 30 THD, 18OD, 10.8, 4205GMW, TORX, M-POINT (CARGO TIE DN HOOK)
15749157 LOOP, CARGO TIE DN (BLACK) (17.090)
20922879 INSULATOR, FLR PNL RR
20922878 INSULATOR, FLR PNL RR
15917245 DEADENER, RR W/H INR PNL
15917244 DEADENER, RR W/H INR PNL
90584197 DEADENER, FLR PNL (88X220MM) (6.758)
22756982 INSULATOR, FLR PNL FRT
25896628 CARPET, F/FLR PNL (EBONY) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922210)
25896630 CARPET, F/FLR PNL (CASHMERE) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922211)
25896632 CARPET, F/FLR PNL (LINEN) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922212)
25896633 CARPET, F/FLR PNL (TITANIUM) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922213)
25896635 CARPET, F/FLR PNL (EBONY) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922621)
25896637 CARPET, F/FLR PNL (CASHMERE) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922622)
25896638 CARPET, F/FLR PNL (TITANIUM) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922623)
94672827 MAT, F/FLR PNL (BLACK) (POLICE PKG ONLY)
19121915 MAT PKG, FRONT CARPET (EBONY) (TWIN) (NO LOGO) (15.286)
19206524 MAT PKG, FRONT CARPET (CASHMERE) (TWIN) (NO LOGO) (16.800)
19207995 MAT PKG, FRONT CARPET (COCOA) (TWIN) (NO LOGO) (16.800)
19210585 MAT PKG, FRONT VINYL (EBONY) (TWIN) (NO LOGO) (16.800)
19210587 MAT PKG, FRONT VINYL (CASHMERE) (TWIN) (NO LOGO) (16.800)
19210586 MAT PKG, FRONT VINYL (TITANIUM) (TWIN) (NO LOGO) (16.800)
19121926 MAT PKG, REAR CARPET (EBONY) (TWIN) (16.800)
19206525 MAT PKG, REAR CARPET (CASHMERE) (TWIN) (16.800)
25913072 MAT PKG, REAR CARPET (COCOA) (1 PC) (16.800)
19210588 MAT PKG, REAR VINYL (EBONY) (TWIN) (16.800)
19210590 MAT PKG, REAR VINYL (CASHMERE) (TWIN) (16.800)
19210589 MAT PKG, REAR VINYL (TITANIUM) (TWIN) (16.800)
15948218 CARPET, R/FLR PNL (EBONY) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922627)
25871796 CARPET, R/FLR PNL (TITANIUM) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922628)
25891808 CARPET, R/FLR PNL (EBONY) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922641)
25891811 CARPET, R/FLR PNL (LINEN) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922642)
25891812 CARPET, R/FLR PNL (TITANIUM) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922643)
25902610 CARPET, R/FLR PNL (CASHMERE) (79" LENGTH) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922644)
20922628 CARPET, R/FLR PNL (TITANIUM)
25875643 CARPET, R/FLR PNL (CASHMERE) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922629)
(TC16-971) 2007-2013 CK1(06-36) ФУРНИТУРА ДВЕРИ/SIDE FRONT PART 1 (CADILLAC Z75)
20789461 WEATHERSTRIP, FRT & RR S/D UPR AUX (INCLS RETAINERS)
20789462 WEATHERSTRIP, FRT & RR S/D UPR AUX (INCLS RETAINERS)
22766409 WEATHERSTRIP, FRT S/D
22766410 WEATHERSTRIP, FRT S/D
15201414 PLATE, FRT S/D LK STKR ANC
10387651 WASHER, FRT S/D LK STKR (10.571)
20951578 STRIKER, FRT S/D LK (10.569)
09442471 BOLT, TORX HD, W/FLAT CSK, M8X1.25X35, 28 THD, 15.2 O.D., 9.8, NO (FRT S/D LAT STKR)
20772075 MOLDING, FRT S/D WDO RVL (W/RUN CHANNEL)
20772074 MOLDING, FRT S/D WDO RVL (W/RUN CHANNEL)
11588393 BOLT, HEX W/ CON WA, M6X1X15, 7 THD, 17 OD, 8.8, GMW4205 (FRT S/D O/S HDL)
20828232 CLIP, FRT S/D O/S HDL (PART OF 12)
20828237 HANDLE, FRT S/D O/S (INCLS 11) (MOLDED IN BLACK) (ORDER T/W CLIP-20828232) (FOR INSTLN PROCDR REF #09-08-64-023)
20828243 HANDLE, FRT S/D O/S (INCLS 11) (PAINT TO MATCH) (ORDER T/W CLIP-20828232) (FOR INSTLN PROCDR REF #09-08-64-023)
22738721 HANDLE, FRT S/D O/S (INCLS 11) (CHROME) (ORDER T/W CLIP-20828232) (FOR INSTLN PROCDR REF #09-08-64-023)
teamcadillac.ru
20954801 HANDLE, FRT S/D O/S (INCLS 11) (PAINT TO MATCH) (USE T/W CLIP 20828232) (W/O LOCK CYL HOLE)
22738722 HANDLE, FRT S/D O/S (INCLS 11) (CHROME) (USE T/W CLIP 20828232) (FOR INSTLN PROCDR REF #09-08-64-023)
20954796 HANDLE, FRT S/D O/S (INCLS 11) (MOLDED IN BLACK) (ORDER T/W CLIP-20828232) (FOR INSTLN PROCDR REF #09-08-64-023)
20835970 WEATHERSTRIP, FRT S/D LWR AUX (INCLS 13)
20835971 WEATHERSTRIP, FRT S/D LWR AUX (INCLS 13)
25854415 HINGE, FRT S/D UPR (BODY & DR SIDE) (REPL T/W 13307322 T/W ADHESIVE 89021297)
25854416 HINGE, FRT S/D UPR (BODY & DR SIDE) (REPL T/W 13307322 T/W ADHESIVE 89021297)
11609733 BOLT, HEX W/CON WA, M8X1.25X30, 20 THD, 24 OD, 10.9, GMW4205, MAT POINT (FRT S/D HGE (BODY SI))
13307322 BOLT, FRT S/D HGE (USE T/W ADHESIVE 89021297)
20969645 HINGE, FRT S/D LWR (BODY & DR SI) (W/CHECK LINK)
20969646 HINGE, FRT S/D LWR (BODY & DR SI) (W/CHECK LINK)
12451685 SPACER, FRT S/D LAT STKR (10.571)
(TC16-973) 2007-2010 CK1(06-36) ФУРНИТУРА ДВЕРИ/SIDE FRONT PART 2 (CADILLAC Z75)
15831544 ROD, FRT S/D O/S HDL
20984751 ROD, FRT S/D O/S HDL
11609341 SCREW, RD WA HD M6X1X19, 13.55 THD, 16 OD, 10.9, GMW4205, W/ADH GM6175M, MATPT (FRT S/D LAT)
20884470 SENSOR, AIRBAG SI IMP
21110669 PLUG, FRT S/D O/S HDL ACC HOLE (35 MM DIA) (FITS HOLE 25MM) (ROUND) (12.179)
20880973 GROMMET, FRT S/D LKG ROD
15827500 ROD, FRT S/D LK CYL
15827501 ROD, FRT S/D LK CYL
teamcadillac.ru
20825032 CYLINDER KIT, FRT S/D LK (UNCODED)
20828232 CLIP, FRT S/D O/S HDL (PART OF 35)
20828237 HANDLE, FRT S/D O/S (INCLS 31, 33) (MOLDED IN BLACK) (ORDER T/W CLIP-20828232) (FOR INSTLN PROCDR REF #09-08-64-023)
20828243 HANDLE, FRT S/D O/S (INCLS 31, 33) (PAINT TO MATCH) (ORDER T/W CLIP-20828232) (FOR INSTLN PROCDR REF #09-08-64-023)
22738721 HANDLE, FRT S/D O/S (INCLS 31, 33) (CHROME) (ORDER T/W CLIP-20828232) (FOR INSTLN PROCDR REF #09-08-64-023)
20954801 HANDLE, FRT S/D O/S (INCLS 31, 33) (PAINT TO MATCH) (USE T/W CLIP 20828232) (W/O LOCK CYL HOLE)
22738722 HANDLE, FRT S/D O/S (INCLS 31, 33) (CHROME) (USE T/W CLIP 20828232) (FOR INSTLN PROCDR REF #09-08-64-023)
20954796 HANDLE, FRT S/D O/S (INCLS 31, 33) (MOLDED IN BLACK) (ORDER T/W CLIP-20828232) (FOR INSTLN PROCDR REF #09-08-64-023)
22738721 HANDLE, FRT S/D O/S (INCLS 31, 33) (CHROME) (ORDER T/W CLIP-20828232) (FOR INSTLN PROCDR REF #09-08-64-023) (16.350) (SERV CMP OF HANDLE PKGS)
22738722 HANDLE, FRT S/D O/S (INCLS 31, 33) (CHROME) (USE T/W CLIP 20828232) (FOR INSTLN PROCDR REF #09-08-64-023) (16.350) (SERV CMP OF HANDLE PKGS)
15140731 WINDOW, FRT S/D
15140732 WINDOW, FRT S/D
22832142 SEALING STRIP, FRT S/D WDO INR
11589177 BOLT, HEX HD, M6X1.0X18.0, GMW25 9.8 STL, GMW3359 (FRT S/D WDO FRT W/STR RET)
15901807 RETAINER, FRT S/D WDO W/STR FRT
15901808 RETAINER, FRT S/D WDO W/STR FRT
15876169 RETAINER, FRT S/D WDO W/STR RR (INCLS 6)
15876170 RETAINER, FRT S/D WDO W/STR RR (INCLS 6)
20971729 REGULATOR, FRT S/D WDO (INCLS 9-11, 18-20) (16.260) (ACDelco #20971729)
20971730 REGULATOR, FRT S/D WDO (INCLS 9-11, 18-20) (16.260) (ACDelco #20971730)
11589177 BOLT, HEX HD, M6X1.0X18.0, GMW25 9.8 STL, GMW3359 (FRT S/D WDO REG)
20873793 HARNESS, FRT S/D DR WRG (LABELED 20873793 OR 20918197)
20956783 HARNESS, FRT S/D DR WRG
20956786 HARNESS, FRT S/D DR WRG
20956788 HARNESS, FRT S/D DR WRG
20918198 HARNESS, FRT S/D DR WRG (LABELED 20918198)
22820553 HARNESS, FRT S/D DR WRG
22820556 HARNESS, FRT S/D DR WRG (LABELED 22820556)
22820555 HARNESS, FRT S/D DR WRG (LABELED 22820555)
20929437 LOCK, FRT S/D (INCLS 15)
22862025 LOCK, FRT S/D (INCLS 15)
22862024 LOCK, FRT S/D (INCLS 15)
15920704 HANDLE, FRT S/D I/S (EBONY) (W/CHROME HDL)
25906817 HANDLE, FRT S/D I/S (CASHMERE)
15920707 HANDLE, FRT S/D I/S (EBONY) (W/CHROME HDL) (W/ HOLE FOR MEMORY SEAT SWITCH)
22855631 HANDLE, FRT S/D I/S (CASHMERE)
22855634 HANDLE, FRT S/D I/S (CHROME HANDLE BEZEL)
22855632 HANDLE, FRT S/D I/S
11570136 BOLT, HEX HD, W/CON SPR WA, M6X1X23, 14 THD, 17 O.D., 8.8, GMW3359 (FRT S/D T/PNL)
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (FRT S/D WDO REG)
15807100 PLUG, FRT S/D DRN HOLE
15039965 BUMPER, RR S/D
15175184 ROD, FRT S/D LKG
20984750 ROD, FRT S/D LKG
20866212 DOOR, FRT SI (SEE GROUP 16.000 "SHEET METAL/BODYSIDE" FOR DETAILED ILLUSTRATED VIEW) (W/O HINGES)
20970076 DOOR, FRT SI (SEE GROUP 16.000 "SHEET METAL/BODYSIDE" FOR DETAILED ILLUSTRATED VIEW) (W/O HINGES)
11609385 NUT, U-TYPE, M6X1, 29.5 LEN, 12.5 WID, 19.5 CEN-END, 1050, GMW3359 (FRT S/D TR PNL)
15887813 CLIP, FRT S/D MLDG (PART OF 39) (16.225)
25784518 MOLDING, FRT S/D WDO GARN (INCLS 38)
25784519 MOLDING, FRT S/D WDO GARN (INCLS 38)
(TC16-975) 2007-2013 CK107(06) ФУРНИТУРА ДВЕРИ/SIDE REAR PART 1 (CADILLAC Z75)
15201414 PLATE, RR S/D LK STKR ANC
20951578 STRIKER, RR S/D LK (10.569)
11518445 BOLT, RR S/D LK STKR (8 X 1.25 X 25) (T40) (8.908)
22766416 WEATHERSTRIP, RR S/D
15792912 WEATHERSTRIP, RR S/D FRT AUX
15792913 WEATHERSTRIP, RR S/D FRT AUX
teamcadillac.ru
20772079 MOLDING, RR S/D WDO RVL
20772078 MOLDING, RR S/D WDO RVL
11516421 BOLT, HFH, M6X1X10, 14.2 O.D., 9.8, 7114M (RR S/D O/S HDL)
25960522 HANDLE, RR S/D O/S (CHROME) (PO HDL PKG)
20954815 HANDLE, RR S/D O/S (MOLDED IN BLACK)
22738725 HANDLE, RR S/D O/S (CHROME) (PO HDL PKG)
20954816 HANDLE, RR S/D O/S (MOLDED IN BLACK)
20954825 HANDLE, RR S/D O/S (PAINT TO MATCH) (USE T/W CLIP 20828232)
25890276 HANDLE, RR S/D O/S (PAINT TO MATCH)
25854398 HINGE, RR S/D UPR (BODY & DR SIDE) (REPL T/W 13307322 T/W ADHESIVE 89021297)
25854397 HINGE, RR S/D UPR (BODY & DR SIDE) (REPL T/W 13307322 T/W ADHESIVE 89021297)
11609733 BOLT, HEX W/CON WA, M8X1.25X30, 20 THD, 24 OD, 10.9, GMW4205, MAT POINT (RR S/D HGE (BODY SI))
13307322 BOLT, RR S/D HGE (USE T/W ADHESIVE 89021297)
20876300 HINGE, RR S/D LWR (BODY & DR SI)
20876301 HINGE, RR S/D LWR (BODY & DR SI)
20835978 WEATHERSTRIP, RR S/D LWR AUX (INCLS 18)
20835979 WEATHERSTRIP, RR S/D LWR AUX (INCLS 18)
25865733 SEALING STRIP, RR S/D WDO INR
20794451 MOLDING, RR S/D WDO GARN
20794452 MOLDING, RR S/D WDO GARN
12451685 SPACER, RR S/D LK STKR (10.571)
(TC16-977) 2007-2011 CK107(06) ФУРНИТУРА ДВЕРИ/SIDE REAR PART 2
15140723 WINDOW, RR S/D
15140724 WINDOW, RR S/D
15140725 WINDOW, RR S/D
15140726 WINDOW, RR S/D
11589177 BOLT, HEX HD, M6X1.0X18.0, GMW25 9.8 STL, GMW3359 (RR S/D WDO REG)
25885883 REGULATOR, RR S/D WDO (INCLS 3, 5, 6, 16, 17) (W/MOTOR) (ACDelco #25885883)
25885882 REGULATOR, RR S/D WDO (INCLS 3, 5, 6, 16, 17) (W/MOTOR) (ACDelco #25885882)
11589177 BOLT, HEX HD, M6X1.0X18.0, GMW25 9.8 STL, GMW3359 (PART OF 4)
15844876 MOTOR, RR S/D WDO REG (PART OF 4) (ACDelco #15844876)
15844877 MOTOR, RR S/D WDO REG (PART OF 4) (ACDelco #15844877)
88875596 MOTOR, RR S/D WDO REG (PART OF 4) (10.783) (ALL MAKES)
88875597 MOTOR, RR S/D WDO REG (PART OF 4) (10.783) (ALL MAKES)
20953403 HARNESS, RR S/D DR WRG (INCLS 7)
20953404 HARNESS, RR S/D DR WRG (INCLS 7)
22820455 HARNESS, RR S/D DR WRG (INCLS 7)
22896456 HARNESS, RR S/D DR WRG (INCLS 7)
22785475 LATCH, RR S/D (INCLS 9)
22785476 LATCH, RR S/D (INCLS 9)
teamcadillac.ru
22785479 LATCH, RR S/D (INCLS 9)
15175416 ROD, RR S/D LAT
15175417 ROD, RR S/D LAT
15844617 KNOB, RR S/D LKG ROD (CASHMERE)
15844618 KNOB, RR S/D LKG ROD (TITANIUM)
15844620 KNOB, RR S/D LKG ROD (COCOA)
20785356 KNOB, RR S/D LKG ROD (CASHMERE)
15844616 KNOB, RR S/D LKG ROD (EBONY)
25906817 HANDLE, RR S/D I/S (CASHMERE)
25906822 HANDLE, RR S/D I/S (CASHMERE)
25815293 HANDLE, RR S/D I/S (CHROME HANDLE BEZEL)
15920683 HANDLE, RR S/D I/S (EBONY) (W/CHROME HDL)
15920704 HANDLE, RR S/D I/S (EBONY) (W/CHROME HDL)
22855634 HANDLE, RR S/D I/S (CHROME HANDLE BEZEL)
11570136 BOLT, HEX HD, W/CON SPR WA, M6X1X23, 14 THD, 17 O.D., 8.8, GMW3359 (RR S/D T/PNL)
11609385 NUT, U-TYPE, M6X1, 29.5 LEN, 12.5 WID, 19.5 CEN-END, 1050, GMW3359 (RR S/D T/PNL)
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (RR S/D WDO REG)
21110669 PLUG, RR S/D O/S HDL ACC HOLE (35 MM DIA) (FITS HOLE 25MM) (ROUND) (12.179)
20880973 GROMMET, RR S/D LKG ROD
11609341 SCREW, RD WA HD M6X1X19, 13.55 THD, 16 OD, 10.9, GMW4205, W/ADH GM6175M, MATPT (RR S/D LAT)
15831547 ROD, RR S/D O/S HDL
15831548 ROD, RR S/D O/S HDL
25960522 HANDLE, RR S/D O/S (INCLS 28-30) (CHROME) (PO HDL PKG)
20954815 HANDLE, RR S/D O/S (INCLS 28-30) (MOLDED IN BLACK)
22738725 HANDLE, RR S/D O/S (INCLS 28-30) (CHROME) (PO HDL PKG)
20954816 HANDLE, RR S/D O/S (INCLS 28-30) (MOLDED IN BLACK)
20954825 HANDLE, RR S/D O/S (INCLS 28-30) (PAINT TO MATCH) (USE T/W CLIP 20828232)
25890276 HANDLE, RR S/D O/S (INCLS 28-30) (PAINT TO MATCH)
15832413 PIN, RR S/D PULL HDL PIV (PART OF 26) (16.353)
20828232 CLIP, RR S/D O/S HDL (PART OF 26) (16.350)
(TC16-978) 2007-2013 CK1,2(06) WINDOWS/BODY SIDE
teamcadillac.ru
25810433 WINDOW, BODY SI RR
20777487 WINDOW, BODY SI RR
20777488 WINDOW, BODY SI RR
25778988 WINDOW, BODY SI RR (INCLS ANTENNA)
25943786 MODULE, RDO ANT (SEE GROUP 09.000 "ANTENNA" FOR DETAILED ILLUSTRATED VIEW) (ACDelco #25943786)
(TC16-979) 2007-2013 CK1,2(06-36) ПОТОЛОЧНЫЙ ЛЮК (CF5)
22815953 WINDOW, SUN RF (INCLS 2, 3)
11611382 BOLT, SUN RF WDO (PART OF 1) (M5X.9X6.4)
15837594 SEAL, SUN RF WDO (PART OF 1)
25942826 FRAME, SUN RF (INCLS 8) (W/O MOTOR)
11518121 NUT, U, M6X1, MULTI THD, .5'-4.0' THK PNL (SUN RF MDL)
11561674 BOLT, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (SUN RF MDL)
11514623 BOLT, HEX W/CON WA, M6X1X20 (SUN RF MDL)
15905311 SUNSHADE, SUN RF (LINEN)
15846534 SUNSHADE, SUN RF (GRAY)
15837588 SUNSHADE, SUN RF (CASHMERE)
25874715 MOLDING, SUN RF PNL/WDO GARN (LINEN)
25874713 MOLDING, SUN RF PNL/WDO GARN (CASHMERE)
25874712 MOLDING, SUN RF PNL/WDO GARN (GRAY)
15837591 BRACKET, SUN RF MDL
teamcadillac.ru
15837589 HARNESS, SUN RF WRG
15934722 MOTOR, SUN RF ACTR (ACDelco #15934722)
20823530 COVER, SUN RF PNL SI OPG CLOSEOUT (BLACK)
20823531 COVER, SUN RF PNL SI OPG CLOSEOUT (BLACK)
15837592 DEFLECTOR, SUN RF AIR
15924423 STOP, SUN RF S/S (12.810)
15924424 BOLT, SUN RF A/DFL
(TC16-980) 2007-2013 CK1,2(06-36) ДРЕНАЖ ПОТОЛОЧНОГО ЛЮКА (CF5)
15164170 HOSE, SUN RF HSG RR DRN
15164171 HOSE, SUN RF HSG RR DRN
25836914 HOSE, SUN RF HSG FRT DRN
25836913 HOSE, SUN RF HSG FRT DRN
(TC16-986) 2010-2013 CK1(06) КОНСОЛЬ/КРЫША (CADILLAC Z75, CF5,UG1)
25786403 SWITCH, SUN RF (PART OF 4) (EBONY) (BLUE LAGOON BACK LIGHTING)
25786404 SWITCH, SUN RF (PART OF 4) (TRUE WHITE BACK LIGHTING)
15241529 MICROPHONE, MOBILE TEL (PART OF 4) (2-WAY CAVITY)
25845571 SWITCH, L/GATE ACTR (PART OF 4) (PART OF RF CONSOLE)
20811136 CONSOLE, RF (INCLS 1-3, 5-7, 9-14) (LINEN) (W/O SW ASM)
teamcadillac.ru
25977567 CONSOLE, RF (INCLS 1-3, 5-7, 9-14) (GRAY) (W/LEAR TRANSMITTER KIT 25807341)
25977569 CONSOLE, RF (INCLS 1-3, 5-7, 9-14) (CASHMERE)
15853948 PUSHBUTTON, RDG LP SW (PART OF 4) (AT CONSOLE)
15911049 LENS, DM LP (PART OF 4) (1ST ROW)
09431809 BULB, 6CP TRADE #212-2 (PART OF 4) (ACDelco #L212-2)
25828898 DISPLAY, I/P AIRBAG ARMING STATUS (W/WORDS ON AND OFF FOR AIRBAG)
25828899 DISPLAY, I/P AIRBAG ARMING STATUS (W/AIRBAG SYMBOLS FOR ON AND OFF)
22784270 TRANSMITTER, GARAGE DR OPENER (PART OF 4) (WHITE BACKLITE)
11516630 BOLT, RF CNSL (PART OF 4) (M4.2X1.41X20) (8.977)
11609345 NUT, PUSH-IN, 4.2, SAE 1050 STL, GMW3179 (PART OF 4)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 4)
(TC16-992) 2010-2013 CK1(06) КОНСОЛЬ/КРЫША (CADILLAC Z75, UG1, EXC CF5)
15911047 BRACKET, RF RR CNSL (PART OF 5)
11516630 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (PART OF 5)
15241529 MICROPHONE, MOBILE TEL (PART OF 5) (2-WAY CAVITY)
25845571 SWITCH, L/GATE ACTR (PART OF 5) (PART OF RF CONSOLE)
25977628 CONSOLE, RF (INCLS 1-4, 6-9, 11-16) (GRAY) (W/LEAR TRANSMITTER KIT 25807341)
25977630 CONSOLE, RF (INCLS 1-4, 6-9, 11-16) (CASHMERE) (W/LEAR TRANSMITTER KIT 25807341)
15853948 PUSHBUTTON, RDG LP SW (PART OF 5) (AT CONSOLE)
15911049 LENS, DM LP (PART OF 5) (1ST ROW)
09431809 BULB, 6CP TRADE #212-2 (PART OF 5) (ACDelco #L212-2)
11516630 BOLT, RF CNSL (PART OF 5) (M4.2X1.41X20) (8.977)
22784270 TRANSMITTER, GARAGE DR OPENER (PART OF 5) (WHITE BACKLITE)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 5)
teamcadillac.ru
11609345 NUT, PUSH-IN, 4.2, SAE 1050 STL, GMW3179 (PART OF 5)
(TC16-993) 2010-2013 K1(06) КОНСОЛЬ/КРЫША (CADILLAC Z75, EXC CF5,UG1)
15836915 CONSOLE, RF (INCLS 1-4, 6-9, 11-13) (GRAY) (NON-DVD CNSL)
25977622 CONSOLE, RF (INCLS 1-4, 6-9, 11-13) (CASHMERE)
teamcadillac.ru
(TK16-001) 2008-2011 CK1(06) CONSOLE/FLOOR-ARMREST DETAIL (CADILLAC Z75, PLATINUM EDITION ULT)
teamcadillac.ru
11609509 SCREW, LG RD WA HD, C/R, HI-LO, 4.2X1.41X13, 11.35-OD, B PT, 6010, GMW4205 (PART OF 3) (*KIT1)
22596346 BUMPER, F/FLR RR CNSL A/RST (PART OF 3) (W/DURAMETER 30) (LENGTH 29MM) (*KIT1) (10.242)
25778771 BUMPER, F/FLR RR CNSL A/RST (PART OF 2) (*KIT1)
25830489 MAT, F/FLR CNSL STOR TRAY (PART OF 1) (*KIT1)
20898288 LID, F/TOP STOW COMPT (INCLS 1-9) (COCOA) (COMPLETE ASSEMBLY)
22796245 LID, F/TOP STOW COMPT (INCLS 1-9) (EBONY) (COMPLETE ASM)
22796246 LID, F/TOP STOW COMPT (INCLS 1-9) (LT. CASHMERE) (COMPLETE ASSEMBLY)
(TK16-002) 2008-2011 CK1(06) CONSOLE/FLOOR-ARMREST DETAIL (CADILLAC Z75, EXC PLATINUM EDITION ULT)
20898302 PANEL, F/FLR CNSL COMPT DR INR (INCLS 8) (W/LATCH) (USE ON VEHICLES BUILT PRIOR TO 4/1/11) (*KIT1)
teamcadillac.ru
11609509 SCREW, LG RD WA HD, C/R, HI-LO, 4.2X1.41X13, 11.35-OD, B PT, 6010, GMW4205 (F/FLR COMPT) (*KIT1)
22596346 BUMPER, F/FLR RR CNSL A/RST (W/DURAMETER 30) (LENGTH 29MM) (*KIT1) (10.242)
22796245 LID, F/TOP STOW COMPT (COMPLETE ASM) (INCLS 1-3, 5-8) (EBONY) (COMPLETE ASM)
22796246 LID, F/TOP STOW COMPT (INCLS 1-3, 5-8) (LT. CASHMERE) (COMPLETE ASSEMBLY)
(TK16-012) 2010-2013 CK1,2(06-36) СИДЕНЬЕ ВОДИТЕЛЯ/BUCKET-BACK (AN3, EXC HEATED/VENTED HNE,KB6)
20772419 COVER, D/SEAT BK (EBONY)
20772421 COVER, D/SEAT BK (TITANIUM)
20987367 COVER, D/SEAT BK (CASHMERE)
20998443 RESTRAINT, D/SEAT HD (INCLS 2) (TITANIUM)
20912675 GUIDE, F/SEAT H/RST (CASHMERE) (W/BUTTON)
15279347 GUIDE, D/SEAT H/RST (EBONY) (W/BUTTON)
20912676 GUIDE, F/SEAT H/RST (TITANIUM) (W/BUTTON)
20912679 GUIDE, P/SEAT H/RST (EBONY) (W/O BUTTON)
20912680 GUIDE, D/SEAT H/RST (CASHMERE) (W/O BUTTON)
15279353 GUIDE, D/SEAT H/RST (TITANIUM) (W/O BUTTON)
20823362 BEZEL, F/SEAT BK OPG RR
20860379 PANEL, D/SEAT BK FIN (TITANIUM)
20926208 PANEL, D/SEAT BK FIN (CASHMERE) (WHEN REPL.TRIM WRAP PANELS; REPLACE BOTH DR & PASS PANELS)
20926207 PANEL, D/SEAT BK FIN (EBONY) (W/MAP POCKET) (W/O VENT HOLE)
11516075 NUT, HFH SELF LK, M6X1, 7.7THK, 14.2 O.D., 9, PZOR (F/SEAT)
20997499 AIRBAG, D/SEAT SI
20824892 GUIDE, D/SEAT SI AIRBAG
11515764 BOLT, HFH, M10X1.5X20, 18THD, 22.3 O.D., 10.9, 7114M (D/SEAT RECL)
15827131 COVER, F/SEAT RSR FIN (INCLS 18) (TITANIUM) (RIGHT & LEFT TOE KICK)
15827129 COVER, F/SEAT RSR FIN (INCLS 18) (EBONY) (RIGHT & LEFT TOE KICK)
15827130 COVER, F/SEAT RSR FIN (INCLS 18) (CASHMERE) (RIGHT & LEFT TOE KICK)
teamcadillac.ru
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 17)
25934810 BRACKET, D/SEAT RECL (I/B)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 25)
15243823 COVER, D/SEAT INR RECL FIN (INCLS 24) (EBONY) (INBOARD)
15243824 COVER, D/SEAT INR RECL FIN (INCLS 24) (CASHMERE) (INBOARD)
15243825 COVER, D/SEAT INR RECL FIN (INCLS 24) (TITANIUM) (INBOARD)
15855909 PROTECTOR, D/SEAT RECL FIN CVR (EBONY) (RECL CVR CARPET BOOT 40% LH)
15855911 PROTECTOR, D/SEAT RECL FIN CVR (EBONY) (RECL CVR CARPET BOOT 40% RH)
25911156 HEATER, D/SEAT BK (HEAT ONLY)
(TK16-013) 2010-2013 CK1,2(06-36) СИДЕНЬЕ ВОДИТЕЛЯ/BUCKET-CUSHION (AN3, EXC HEATED/VENTED HNE,KB6)
20779849 COVER, D/SEAT CUSH (EBONY) (CARPET INBOARD SIDE FACING) (REPLACES VINYL)
20779850 COVER, D/SEAT CUSH (CASHMERE) (CARPET INBOARD SIDE FACING) (REPLACES VINYL)
20779851 COVER, D/SEAT CUSH (TITANIUM) (CARPET INBOARD SIDE FACING) (REPLACES VINYL)
20792748 HEATER, D/SEAT CUSH
11513599 NUT, U-TYPE, M4.2X1.41, 0.65-3.80 PNL THK, PZ (F/SEAT) (ACDelco #11513599)
22804419 ADJUSTER, D/SEAT (POWER 6-WAY) (INCLS MOTORS) (W/MEMORY)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 11)
12451497 SWITCH, D/SEAT ADJR & RECL (8-WAY) (11.558)
teamcadillac.ru
25926717 SWITCH, D/SEAT LUMBAR CONT (CASHMERE) (4-PIN, BKWD & FORWD ONLY) (11.378)
25926718 SWITCH, D/SEAT LUMBAR CONT (LT TITANIUM) (4-PIN, BKWD & FORWD ONLY) (11.378)
25926719 SWITCH, D/SEAT LUMBAR CONT (EBONY) (4-PIN, BKWD & FORWD ONLY)
15232562 COVER, D/SEAT ADJR FIN (EBONY) (8 WAY POWER) (OUTBOARD)
15232563 COVER, D/SEAT ADJR FIN (CASHMERE) (8 WAY POWER)
15232564 COVER, D/SEAT ADJR FIN (TITANIUM) (8 WAY POWER)
15222985 KNOB, F/SEAT BK RECL (TITANIUM) (11.377)
10340136 KNOB, D/SEAT RECL LVR (EBONY) (11.377)
15222984 KNOB, F/SEAT BK RECL (CASHMERE) (11.377)
15222980 KNOB, D/SEAT ADJR SW (CASHMERE) (11.558)
10325879 KNOB, D/SEAT ADJR SW (EBONY) (11.558)
15222981 KNOB, D/SEAT ADJR SW (TITANIUM) (11.558)
11609539 SCREW, RD CROWNED WA HD, M4.2X1.41X16, STL ISO 2702, GMW4205 (F/SEAT)
15845152 BRACKET, D/SEAT BELT (RETR SI) (O/B)
15232584 COVER, D/SEAT OTR ADJR TRK RR FIN (INCLS 16) (EBONY) (OUTBOARD)
15232585 COVER, D/SEAT OTR ADJR TRK RR FIN (INCLS 16) (CASHMERE) (OUTBOARD)
15232586 COVER, D/SEAT OTR ADJR TRK RR FIN (INCLS 16) (TITANIUM) (OUTBOARD)
11517996 NUT, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (D/SEAT ADJR TOP PLT) (ACDelco #11517996)
15243864 COVER, D/SEAT OTR ADJR TRK RR FIN (EBONY) (INBOARD)
15243865 COVER, D/SEAT OTR ADJR TRK RR FIN (CASHMERE) (INBOARD)
15243866 COVER, D/SEAT OTR ADJR TRK RR FIN (TITANIUM) (INBOARD)
20763638 BRACKET, D/SEAT (DRIVER SIAB)
15243852 COVER, D/SEAT INR ADJR TRK FRT FIN (TITANIUM)
15243850 COVER, D/SEAT INR ADJR TRK FRT FIN (EBONY)
15243851 COVER, D/SEAT INR ADJR TRK FRT FIN (CASHMERE)
25815788 CAP, F/SEAT ADJR TRK END (BLACK)
20900194 COVER, AIRBAG D/SEAT POSN SEN
88981918 BOLT, D/SEAT ADJR (M6X1X13.5) (16.714)
25916854 BRACKET, D/SEAT BELT (BKL SI) (I/B) (INCLDS BKL MOUNT STUD)
19121538 BELT KIT, D/SEAT (BKL SI) (CASHMERE)
19121539 BELT KIT, D/SEAT (BKL SI) (TITANIUM)
19121537 BELT KIT, D/SEAT (BKL SI) (EBONY)
11516075 NUT, HFH SELF LK, M6X1, 7.7THK, 14.2 O.D., 9, PZOR (D/SEAT ADJR MEMORY SW)
25855630 MODULE, D/SEAT ADJR MEMORY (REQUIRES DEALER PROGRAMMING) (11.558) (LABELED 25855630, 25917599, 20870474, 15921044, 15193620, 15246159, 15804058, 15820413, 15826609, 21, 15833435, 15844068, 72, 15853219, 15895345, 48, 15896747)
15854391 FRAME, D/SEAT CUSH
(TK16-014) 2010-2011 CK1,2(06-36) СИДЕНЬЕ ВОДИТЕЛЯ/BUCKET-BACK (AN3, HEATED/VENTED HNE,KB6)
20763636 COVER, D/SEAT BK (COCOA)
20895494 COVER, D/SEAT BK (EBONY)
20895495 COVER, D/SEAT BK (CASHMERE)
20859084 RESTRAINT, D/SEAT HD (INCLS 2) (EBONY)
20859085 RESTRAINT, D/SEAT HD (INCLS 2) (CASHMERE)
20899211 RESTRAINT, D/SEAT HD (INCLS 2) (COCOA)
20998437 RESTRAINT, D/SEAT HD (NO OPENING FOR DVD PLAYER) (INCLS 2) (EBONY)
teamcadillac.ru
20912677 GUIDE, F/SEAT H/RST (COCOA) (W/BUTTON)
15279347 GUIDE, F/SEAT H/RST (EBONY) (W/BUTTON)
20912679 GUIDE, F/SEAT H/RST (EBONY) (W/O BUTTON)
20912680 GUIDE, F/SEAT H/RST (CASHMERE) (W/O BUTTON)
15279353 GUIDE, F/SEAT H/RST (TITANIUM) (W/O BUTTON)
25851751 GUIDE, F/SEAT H/RST (COCOA) (W/O BUTTON)
20763637 PAD, D/SEAT BK
22804410 FRAME, D/SEAT BK (INCLS 8, 17, 18, 21, 23, 24) (W/LUMBAR)
20987411 LUMBAR SUB, D/SEAT (PART OF 7) (4 WAY POWER METAL BASKET MEMORY W/HARNESS)
20926211 PANEL, D/SEAT BK FIN (EBONY)
20926221 PANEL, D/SEAT BK FIN (COCOA)
20926212 PANEL, D/SEAT BK FIN (CASHMERE)
20926185 PANEL, D/SEAT BK FIN (EBONY) (INCLS MAP POCKET W VENT HOLE) (WRAP IN VINYL)
20926186 PANEL, D/SEAT BK FIN (CASHMERE) (WRAP IN VINYL)
20926213 PANEL, D/SEAT BK FIN (TITANIUM)
20926215 PANEL, D/SEAT BK FIN (EBONY)
15232557 BLOWER, D/SEAT BACK VENTILATION HEAT & COOL (INCLS THERMAL ELECTRIC DEVICE, TEMP SENSOR & FILTER)
25924170 DUCT, D/SEAT BACK VENTILATION
15827131 COVER, F/SEAT RSR FIN (INCLS 20) (TITANIUM) (RIGHT & LEFT TOE KICK)
25851756 COVER, F/SEAT RSR FIN (INCLS 20) (COCOA)
15827129 COVER, F/SEAT RSR FIN (INCLS 20) (EBONY) (RIGHT & LEFT TOE KICK)
15827130 COVER, F/SEAT RSR FIN (INCLS 20) (CASHMERE) (RIGHT & LEFT TOE KICK)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 19)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 27)
15243823 COVER, D/SEAT INR RECL FIN (INCLS 26) (EBONY) (INBOARD)
15243824 COVER, D/SEAT INR RECL FIN (INCLS 26) (CASHMERE) (INBOARD)
15243825 COVER, D/SEAT INR RECL FIN (INCLS 26) (TITANIUM) (INBOARD)
25851757 COVER, D/SEAT INR RECL FIN (INCLS 26) (COCOA)
(TK16-015) 2010-2011 CK1,2(06-36) СИДЕНЬЕ ВОДИТЕЛЯ/BUCKET-CUSHION (AN3, HEATED/VENTED HNE,KB6)
25789849 PAD, D/SEAT CUSH (USED ON HEAT/COOL)
25851675 COVER, D/SEAT CUSH (COCOA)
22751125 COVER, D/SEAT CUSH (EBONY)
22751126 COVER, D/SEAT CUSH (CASHMERE)
20987428 ADJUSTER, D/SEAT (USED ON VEHICLES WITH POWER TILT STEERING COLUMN W/MEMORY) (INCLS MOTORS)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 10)
25909573 SWITCH, D/SEAT LUMBAR CONT (COCOA)
teamcadillac.ru
15232563 COVER, D/SEAT ADJR FIN (INCLS 7) (CASHMERE) (8 WAY POWER)
15232564 COVER, D/SEAT ADJR FIN (INCLS 7) (TITANIUM) (8 WAY POWER)
15882421 COVER, D/SEAT ADJR FIN (INCLS 7) (COCOA) (BELT UTILITY)
25851752 COVER, D/SEAT ADJR FIN (INCLS 7) (COCOA) (8 WAY POWER)
15232562 COVER, D/SEAT ADJR FIN (INCLS 7) (EBONY) (8 WAY POWER) (OUTBOARD)
15214529 COVER, D/SEAT ADJR FIN (INCLS 7) (TITANIUM) (BELT UTILITY)
15219925 COVER, D/SEAT ADJR FIN (INCLS 7) (CASHMERE) (BELT UTILITY)
15214527 COVER, D/SEAT ADJR FIN (INCLS 7) (EBONY) (BELT UTILITY)
15889098 KNOB, F/SEAT BK RECL (COCOA) (11.377)
10340136 KNOB, F/SEAT BK RECL (EBONY) (11.377)
15889097 KNOB, D/SEAT ADJR SW (COCOA) (11.558)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 16)
15232584 COVER, D/SEAT OTR ADJR TRK RR FIN (INCLS 15) (EBONY) (OUTBOARD)
15232585 COVER, D/SEAT OTR ADJR TRK RR FIN (INCLS 15) (CASHMERE) (OUTBOARD)
15232586 COVER, D/SEAT OTR ADJR TRK RR FIN (INCLS 15) (TITANIUM) (OUTBOARD)
25851754 COVER, D/SEAT OTR ADJR TRK RR FIN (INCLS 15) (COCOA) (OUTBOARD)
15232586 COVER, D/SEAT OTR ADJR TRK RR FIN (TITANIUM) (OUTBOARD)
25851754 COVER, D/SEAT OTR ADJR TRK RR FIN (COCOA) (OUTBOARD)
15232584 COVER, D/SEAT OTR ADJR TRK RR FIN (EBONY) (OUTBOARD)
15232585 COVER, D/SEAT OTR ADJR TRK RR FIN (CASHMERE) (OUTBOARD)
15827134 BRACKET, D/SEAT (MAIN BODY HARNESS CONNECTION)
25851758 COVER, D/SEAT INR ADJR TRK FRT FIN (COCOA)
22756568 HARNESS, D/SEAT ADJR WRG
25951880 SENSOR, AIRBAG D/SEAT POSN (MATING CONN W/LEADS USE 13577629)
19180587 BELT KIT, D/SEAT (BKL SI) (COCOA)
25862041 MODULE, D/SEAT ADJR MEMORY (REQUIRES DEALER PROGRAMMING) (ADJR & HTR CONTROL) (11.558)
20987427 BLOWER, D/SEAT CUSH VENTILATION HEAT & COOL (INCLS THERMAL ELECTRIC DEVICE, TEMP SENSOR & FILTER)
(TK16-016) 2010-2013 CK1,2(06-36) СИДЕНЬЕ ПАССАЖИРА/BUCKET-BACK (AN3, EXC HEATED/VENTED HNE,KB6)
20998443 RESTRAINT, P/SEAT HD (INCLS 2) (TITANIUM)
20912675 GUIDE, P/SEAT H/RST (CASHMERE) (W/BUTTON)
15279347 GUIDE, P/SEAT H/RST (EBONY) (W/BUTTON)
20912676 GUIDE, P/SEAT H/RST (TITANIUM) (W/BUTTON)
20912680 GUIDE, P/SEAT H/RST (CASHMERE) (W/O BUTTON)
15279353 GUIDE, P/SEAT H/RST (TITANIUM) (W/O BUTTON)
20772175 PAD, P/SEAT BK
25911156 HEATER, P/SEAT BK (HEAT ONLY)
15855911 PROTECTOR, P/SEAT RECL FIN CVR (EBONY) (RECL CVR CARPET BOOT 40% RH)
15855909 PROTECTOR, P/SEAT RECL FIN CVR (EBONY) (RECL CVR CARPET BOOT 40% LH)
11515764 BOLT, HFH, M10X1.5X20, 18THD, 22.3 O.D., 10.9, 7114M (P/SEAT RECL)
15827137 BRACKET, P/SEAT RECL (INBOARD)
15243830 COVER, P/SEAT INR RECL FIN (INCLS 12) (TITANIUM) (INBOARD)
15243828 COVER, P/SEAT INR RECL FIN (INCLS 12) (EBONY) (INBOARD)
15243829 COVER, P/SEAT INR RECL FIN (INCLS 12) (CASHMERE) (INBOARD)
teamcadillac.ru
15827131 COVER, F/SEAT RSR FIN (INCLS 16) (TITANIUM) (RIGHT & LEFT TOE KICK)
15827129 COVER, F/SEAT RSR FIN (INCLS 16) (EBONY) (RIGHT & LEFT TOE KICK)
15827130 COVER, F/SEAT RSR FIN (INCLS 16) (CASHMERE) (RIGHT & LEFT TOE KICK)
20997498 AIRBAG, P/SEAT SI
20824892 GUIDE, P/SEAT SI AIRBAG MDL
20860379 PANEL, P/SEAT BK FIN (TITANIUM)
20926208 PANEL, P/SEAT BK FIN (CASHMERE) (WHEN REPL.TRIM WRAP PANELS; REPLACE BOTH DR & PASS PANELS)
20926207 PANEL, P/SEAT BK FIN (EBONY) (W/MAP POCKET) (W/O VENT HOLE)
(TK16-017) 2010-2013 CK1,2(06-36) СИДЕНЬЕ ПАССАЖИРА/BUCKET-CUSHION (AN3, EXC HEATED/VENTED HNE,KB6)
20919641 MODULE KIT, AIRBAG FRT PASS PRESENCE (W/ SEN) (INCLS 4)
20779855 COVER, P/SEAT CUSH (EBONY) (CARPET INBOARD SIDE FACING) (REPLACES VINYL)
20779857 COVER, P/SEAT CUSH (TITANIUM) (CARPET INBOARD SIDE FACING) (REPLACES VINYL)
20779856 COVER, P/SEAT CUSH (CASHMERE) (CARPET INBOARD SIDE FACING) (REPLACES VINYL)
20792748 HEATER, P/SEAT CUSH
25864494 PAD, P/SEAT CUSH (PART OF 1)
11517996 NUT, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (P/SEAT ADJR TOP PLT) (ACDelco #11517996)
22781429 FRAME, P/SEAT CUSH
19121543 BELT KIT, P/SEAT (BKL SI) (TITANIUM)
19121541 BELT KIT, P/SEAT (BKL SI) (EBONY) (W/TENSIONER)
19121542 BELT KIT, P/SEAT (BKL SI) (CASHMERE)
25916855 BRACKET, P/SEAT BELT (BKL SI) (I/B)
20958089 COVER, AIRBAG P/SEAT POSN SEN
15243860 COVER, P/SEAT INR ADJR TRK FRT FIN (TITANIUM)
15243858 COVER, P/SEAT INR ADJR TRK FRT FIN (EBONY)
15243859 COVER, P/SEAT INR ADJR TRK FRT FIN (CASHMERE)
20779109 ADJUSTER, P/SEAT (POWER 6-WAY) (INCLS MOTORS) (W/O MEMORY)
15827135 BRACKET, P/SEAT FRT (DEALER WILL NEED TO ORDER NEW COVER 20970793) (FOR HD VEHICLES)
15243869 COVER, P/SEAT OTR ADJR TRK RR FIN (EBONY) (INBOARD)
15243870 COVER, P/SEAT OTR ADJR TRK RR FIN (CASHMERE) (INBOARD)
15243871 COVER, P/SEAT OTR ADJR TRK RR FIN (TITANIUM) (INBOARD)
15232589 COVER, P/SEAT OTR ADJR TRK RR FIN (INCLS 21) (EBONY) (OUTBOARD)
15232590 COVER, P/SEAT OTR ADJR TRK RR FIN (INCLS 21) (CASHMERE) (OUTBOARD)
15232591 COVER, P/SEAT OTR ADJR TRK RR FIN (INCLS 21) (TITANIUM) (OUTBOARD)
teamcadillac.ru
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 20)
15845154 BRACKET, P/SEAT BELT (RETR SI) (O/B)
10325879 KNOB, P/SEAT ADJR SW (EBONY) (11.558)
15222981 KNOB, P/SEAT ADJR SW (TITANIUM) (11.558)
15222980 KNOB, P/SEAT ADJR SW (CASHMERE) (11.558)
15232567 COVER, P/SEAT ADJR FIN (INCLS 24) (EBONY) (POWER)
15232568 COVER, P/SEAT ADJR FIN (INCLS 24) (CASHMERE) (POWER)
15232569 COVER, P/SEAT ADJR FIN (INCLS 24) (TITANIUM) (POWER)
25926717 SWITCH, P/SEAT LUMBAR CONT (CASHMERE) (4-PIN, BKWD & FORWD ONLY) (11.378)
25926718 SWITCH, P/SEAT LUMBAR CONT (LT TITANIUM) (4-PIN, BKWD & FORWD ONLY) (11.378)
25926719 SWITCH, P/SEAT LUMBAR CONT (EBONY) (4-PIN, BKWD & FORWD ONLY)
12451498 SWITCH, P/SEAT ADJR & RECL (8-WAY) (11.558)
(TK16-018) 2010-2011 CK1,2(06-36) СИДЕНЬЕ ПАССАЖИРА/BUCKET-BACK (AN3, HEATED/VENTED HNE,KB6)
20859084 RESTRAINT, P/SEAT HD (INCLS 2) (EBONY)
20859085 RESTRAINT, P/SEAT HD (INCLS 2) (CASHMERE)
20899211 RESTRAINT, P/SEAT HD (INCLS 2) (COCOA)
20998437 RESTRAINT, P/SEAT HD (NO OPENING FOR DVD PLAYER) (INCLS 2) (EBONY)
20771978 COVER, P/SEAT BK (COCOA)
20895480 COVER, P/SEAT BK (EBONY)
20895481 COVER, P/SEAT BK (CASHMERE)
20771979 PAD, P/SEAT BK
15243830 COVER, P/SEAT INR RECL FIN (INCLS 11) (TITANIUM) (INBOARD)
25851775 COVER, P/SEAT INR RECL FIN (INCLS 11) (COCOA) (INBOARD)
15243828 COVER, P/SEAT INR RECL FIN (INCLS 11) (EBONY) (INBOARD)
15243829 COVER, P/SEAT INR RECL FIN (INCLS 11) (CASHMERE) (INBOARD)
15827131 COVER, F/SEAT RSR FIN (INCLS 15) (TITANIUM) (RIGHT & LEFT TOE KICK)
25851756 COVER, F/SEAT RSR FIN (INCLS 15) (COCOA)
15827129 COVER, F/SEAT RSR FIN (INCLS 15) (EBONY) (RIGHT & LEFT TOE KICK)
15827130 COVER, F/SEAT RSR FIN (INCLS 15) (CASHMERE) (RIGHT & LEFT TOE KICK)
25924170 DUCT, P/SEAT BACK VENTILATION
22804414 FRAME, P/SEAT BK (INCLS 12, 14, 17, 18, 29)
15232557 BLOWER, P/SEAT BACK VENTILATION HEAT & COOL (INCLS THERMAL ELECTRIC DEVICE, TEMP SENSOR & FILTER)
teamcadillac.ru
20926211 PANEL, P/SEAT BK FIN (EBONY)
20926221 PANEL, P/SEAT BK FIN (COCOA)
20926212 PANEL, P/SEAT BK FIN (CASHMERE)
20926185 PANEL, P/SEAT BK FIN (EBONY) (INCLS MAP POCKET W VENT HOLE) (WRAP IN VINYL)
20926186 PANEL, P/SEAT BK FIN (CASHMERE) (WRAP IN VINYL)
20926213 PANEL, P/SEAT BK FIN (TITANIUM)
22856925 LUMBAR SUB, P/SEAT (PART OF 23)
(TK16-019) 2010-2011 CK1,2(06-36) СИДЕНЬЕ ПАССАЖИРА/BUCKET-CUSHION (AN3, HEATED/VENTED HNE,KB6)
20919642 MODULE KIT, AIRBAG FRT PASS PRESENCE (W/ SEN) (INCLS 3)
teamcadillac.ru
25851690 COVER, P/SEAT CUSH (COCOA)
22751128 COVER, P/SEAT CUSH (EBONY)
22751129 COVER, P/SEAT CUSH (CASHMERE)
19180588 BELT KIT, P/SEAT (BKL SI) (COCOA)
15232555 MODULE, P/SEAT CUSH VENTILATION HEAT & COOL (12 WAY MATING CONN W/OUT LEADS USE 15326110)
11516075 NUT, HFH SELF LK, M6X1, 7.7THK, 14.2 O.D., 9, PZOR (AIRBAG P/SEAT SUPPRESSION)
25954737 SENSOR, AIRBAG P/SEAT POSN
20818405 HARNESS, P/SEAT ADJR WRG (RH PWR W/HEAT/COOL)
25851776 COVER, P/SEAT INR ADJR TRK FRT FIN (COCOA)
25851777 COVER, P/SEAT OTR ADJR TRK RR FIN (COCOA) (INBOARD)
15232589 COVER, P/SEAT OTR ADJR TRK RR FIN (INCLS 22) (EBONY) (OUTBOARD)
15232590 COVER, P/SEAT OTR ADJR TRK RR FIN (INCLS 22) (CASHMERE) (OUTBOARD)
15232591 COVER, P/SEAT OTR ADJR TRK RR FIN (INCLS 22) (TITANIUM) (OUTBOARD)
25851774 COVER, P/SEAT OTR ADJR TRK RR FIN (INCLS 22) (COCOA) (OUTBOARD)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 21)
20987427 BLOWER, P/SEAT CUSH VENTILATION HEAT & COOL (INCLS THERMAL ELECTRIC DEVICE, TEMP SENSOR & FILTER)
15889097 KNOB, P/SEAT ADJR SW (COCOA) (11.558)
15232569 COVER, P/SEAT ADJR FIN (INCLS 26) (TITANIUM) (POWER)
15882423 COVER, P/SEAT ADJR FIN (INCLS 26) (COCOA) (BELT UTILITY)
25851773 COVER, P/SEAT ADJR FIN (INCLS 26) (COCOA)
15214530 COVER, P/SEAT ADJR FIN (INCLS 26) (EBONY) (OUTBOARD, BELT UTILITY)
15219924 COVER, P/SEAT ADJR FIN (INCLS 26) (CASHMERE) (BELT UTILITY)
15232567 COVER, P/SEAT ADJR FIN (INCLS 26) (EBONY) (POWER)
15232568 COVER, P/SEAT ADJR FIN (INCLS 26) (CASHMERE) (POWER)
15214532 COVER, P/SEAT ADJR FIN (INCLS 26) (TITANIUM) (BELT UTILITY)
25909573 SWITCH, P/SEAT LUMBAR CONT (COCOA)
(TK16-035) 2009-2013 CK107(06) ЗАДНЕЕ СИДЕНЬЕ/BENCH-60% SIDE (AM8, HYBRID HP2)
15291597 PAD, R/SEAT BK
15279450 PROTECTOR, R/SEAT SHLDR BELT (BLACK)
11570116 SCREW, PAN HD, M6X1X10, 10 THD, 12 OD, STL SAE J1237, S424, TAPTITE ITE (R/SEAT LAT FIN CVR) (8.913)
11562382 BOLT, HFH, M10X1.5X130, 26 THD, 22.3 OD, 10.9, 7114M, MACH, MAT-PT (R/SEAT BK FRM)
15289969 BRACKET, RR CTR SEAT BELT RETR
11562383 BOLT, HFH, M12X1.75X30.5, 17 THD, 26.6 OD, 10.9 STL, GMW3359, W/ADH 6175M (R/SEAT LAT)
15824670 RESTRAINT, R/SEAT HD (TITANIUM)
25928791 RESTRAINT, R/SEAT HD (CASHMERE)
15865813 RESTRAINT, R/SEAT HD (EBONY)
15824669 RESTRAINT, R/SEAT HD (CASHMERE)
25858321 RESTRAINT, R/SEAT HD (COCOA)
25928790 RESTRAINT, R/SEAT HD (EBONY)
15824676 RESTRAINT, R/SEAT HD (EBONY)
15279353 GUIDE, R/SEAT H/RST (TITANIUM) (W/O BUTTON)
25851751 GUIDE, R/SEAT H/RST (COCOA) (W/O BUTTON)
15279347 GUIDE, R/SEAT H/RST (EBONY) (W/BUTTON)
20912677 GUIDE, R/SEAT H/RST (COCOA) (W/BUTTON)
20912675 GUIDE, R/SEAT H/RST (CASHMERE) (W/BUTTON)
20912679 GUIDE, R/SEAT H/RST (EBONY) (W/O BUTTON)
20912680 GUIDE, R/SEAT H/RST (CASHMERE) (W/O BUTTON)
20912676 GUIDE, R/SEAT H/RST (TITANIUM) (W/BUTTON)
11562378 BOLT, HFH, M10X1.5X30, 18 THD, 22.3 OD, 10.9, GMW3359, W/ADH GM6175M (R/SEAT LAT)
15269762 FRAME, R/SEAT BK
25784336 RETAINER, R/SEAT BK OPG FIN CVR (PUSH IN) (16.720)
20761386 FRAME, R/SEAT CUSH
20789621 PANEL, R/SEAT CUSH TR (COCOA) (O/B INNER)
25816439 PANEL, R/SEAT CUSH TR (EBONY) (O/B INNER)
25816440 PANEL, R/SEAT CUSH TR (CASHMERE) (O/B INNER)
25816441 PANEL, R/SEAT CUSH TR (TITANIUM) (O/B INNER)
25816390 LATCH, R/SEAT BK (OUTBOARD)
15279416 HANDLE, R/SEAT RECL (INCLS 15) (TITANIUM)
15279414 HANDLE, R/SEAT RECL (INCLS 15) (EBONY)
15279415 HANDLE, R/SEAT RECL (INCLS 15) (CASHMERE)
25858332 HANDLE, R/SEAT RECL (INCLS 15) (COCOA)
20789620 PANEL, R/SEAT CUSH TR (COCOA) (SIDE SHIELD OUTER)
25816435 PANEL, R/SEAT CUSH TR (EBONY) (SIDE SHIELD OUTER)
25816436 PANEL, R/SEAT CUSH TR (CASHMERE) (SIDE SHIELD OUTER)
25816437 PANEL, R/SEAT CUSH TR (TITANIUM) (SIDE SHIELD OUTER)
25816392 LATCH, R/SEAT RSR (O/B FLOOR)
11562384 NUT, HFH, M4X.7 THD, 4.75 THK, 10.5 OD, GM510M (9)STL, GM4435M-CODE A (R/SEAT FLR FIL T/PNL)
20761389 PANEL, R/SEAT CUSH TR (EBONY) (LATCH COVER-TUB)
20761390 PANEL, R/SEAT CUSH TR (CASHMERE) (LATCH COVER-TUB)
20789622 PANEL, R/SEAT CUSH TR (COCOA) (LATCH COVER-TUB)
22772281 PANEL, R/SEAT CUSH TR (TITANIUM)
11571092 BOLT, R/SEAT HGE (M10X1.5X114)
11562380 BUSHING, R/SEAT HGE
25816394 SPRING, R/SEAT RECL
15275900 SPRING, R/SEAT RECL (TUMBLE)
25944144 RISER, R/SEAT
11514596 NUT, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (R/SEAT) (8.915) (ACDelco #11514596)
25949171 HARNESS, R/SEAT HTR (TO HEAT PAD)
25979119 HARNESS, R/SEAT HTR (TO HELLA MODULE)
25816396 CABLE, R/SEAT LAT (MASTER SYNC)
20825904 RETAINER, R/SEAT CUSH SI FAC (EBONY)
20825905 RETAINER, R/SEAT CUSH SI FAC (CASHMERE)
20825906 RETAINER, R/SEAT CUSH SI FAC (TITANIUM)
20825907 RETAINER, R/SEAT CUSH SI FAC (COCOA)
25816395 CABLE, R/SEAT LAT (MASTER SYNC)
20789625 PANEL, R/SEAT CUSH TR (COCOA) (HINGE COVER)
25816461 PANEL, R/SEAT CUSH TR (EBONY) (HINGE COVER)
25816462 PANEL, R/SEAT CUSH TR (CASHMERE) (HINGE COVER)
25816463 PANEL, R/SEAT CUSH TR (TITANIUM) (HINGE COVER)
15275914 CABLE, R/SEAT LAT (OUTBOARD) (FLOOR LATCH)
15275917 CABLE, R/SEAT LAT (INBOARD) (FLOOR LATCH)
25816393 LATCH, R/SEAT RSR (I/B FLOOR)
20789624 PANEL, R/SEAT CUSH TR (COCOA) (I/B INNER)
25816451 PANEL, R/SEAT CUSH TR (EBONY) (I/B INNER)
25816452 PANEL, R/SEAT CUSH TR (CASHMERE) (I/B INNER)
25816453 PANEL, R/SEAT CUSH TR (TITANIUM) (I/B INNER)
11562376 SCREW, PAN HD, M12X1.75X55, 42 THD, 27 OD, 10.9, S424, W/ADH GM6175M (R/SEAT LAT)
20761393 PANEL, R/SEAT CUSH TR (EBONY) (I/B OUTER COVER)
20761394 PANEL, R/SEAT CUSH TR (CASHMERE) (I/B OUTER COVER)
20761395 PANEL, R/SEAT CUSH TR (TITANIUM) (I/B OUTER COVER)
20789623 PANEL, R/SEAT CUSH TR (COCOA) (I/B OUTER COVER)
15279464 KNOB, R/SEAT LAT (EBONY) (16.716) (W/O NUMBER LABELS ON 3RD ROW SEAT) (FOR 2ND DES SEE 20963265)
20963265 KNOB, R/SEAT LAT (EBONY) (INNER) (W/NUMBER LABELS ON 3RD ROW SEAT) (FOR 1ST DES SEE 15279464)
19121589 BELT KIT, R/SEAT (BKL SI) (EBONY) (BKL/BKL)
19121591 BELT KIT, R/SEAT (BKL SI) (CASHMERE) (BKL/BKL)
19121592 BELT KIT, R/SEAT (BKL SI) (TITANIUM) (BKL/BKL)
25949169 PROTECTOR, R/SEAT CUSH FRM EDGE
11562386 BOLT, HFH, M8X1.25X24, 22.5 THD, 18 OD, GM6202M, STL, GM4435M.CODE G, TAPTITE (R/SEAT A/RST)
15275854 ARMREST, R/SEAT (EBONY)
15275855 ARMREST, R/SEAT (CASHMERE)
20789569 ARMREST, R/SEAT (COCOA)
15865493 ARMREST, R/SEAT (EBONY)
teamcadillac.ru
15279471 COVER, R/SEAT A/RST SUPT FIN (TITANIUM)
15279469 COVER, R/SEAT A/RST SUPT FIN (EBONY)
20789635 COVER, R/SEAT A/RST SUPT FIN (COCOA)
15279470 COVER, R/SEAT A/RST SUPT FIN (CASHMERE)
15279408 PIN, R/SEAT H/RST ADJ ROD LAT (TITANIUM)
15279406 PIN, R/SEAT H/RST ADJ ROD LAT (EBONY)
15279407 PIN, R/SEAT H/RST ADJ ROD LAT (CASHMERE)
25858342 PIN, R/SEAT H/RST ADJ ROD LAT (COCOA)
19151106 BELT KIT, R/SEAT CTR (RETR SI) (TITANIUM)
19210381 BELT KIT, R/SEAT CTR (RETR SI) (COCOA)
19151105 BELT KIT, R/SEAT CTR (RETR SI) (CASHMERE)
19151104 BELT KIT, R/SEAT CTR (RETR SI) (EBONY)
11562377 BOLT, HFH, M10X1.5X55, 43.45 THD, 22.3 OD, 10.9, GMW3359, W/ADH GM6175M (R/SEAT LAT)
25816391 LATCH, R/SEAT BK (INBOARD)
20792750 HEATER, R/SEAT CUSH
25816398 PAD, R/SEAT CUSH
25816425 COVER, R/SEAT CUSH (EBONY)
25816427 COVER, R/SEAT CUSH (TITANIUM)
20789573 COVER, R/SEAT CUSH (COCOA)
25816426 COVER, R/SEAT CUSH (CASHMERE)
22751166 COVER, R/SEAT CUSH (CASHMERE)
20895549 COVER, R/SEAT CUSH (EBONY)
20789571 COVER, R/SEAT BK (COCOA)
20895601 COVER, R/SEAT BK (EBONY)
15865521 COVER, R/SEAT BK (EBONY)
15865522 COVER, R/SEAT BK (CASHMERE)
15865523 COVER, R/SEAT BK (TITANIUM)
25908031 COVER, R/SEAT BK (CASHMERE)
(TK16-036) 2009-2013 CK107(06) ЗАДНЕЕ СИДЕНЬЕ/BENCH-40% SIDE (AM8, HYBRID HP2)
15269763 FRAME, R/SEAT BK
20789640 PANEL, R/SEAT CUSH TR (COCOA) (I/B INNER)
25816481 PANEL, R/SEAT CUSH TR (EBONY) (I/B INNER)
25816482 PANEL, R/SEAT CUSH TR (CASHMERE) (I/B INNER)
25816483 PANEL, R/SEAT CUSH TR (TITANIUM) (I/B INNER)
25816411 LATCH, R/SEAT BK (INBOARD)
20761401 PANEL, R/SEAT CUSH TR (INCLS 29) (EBONY) (I/B INNER COVER)
20761402 PANEL, R/SEAT CUSH TR (INCLS 29) (CASHMERE) (I/B INNER COVER)
20761403 PANEL, R/SEAT CUSH TR (INCLS 29) (TITANIUM) (I/B INNER COVER)
20789639 PANEL, R/SEAT CUSH TR (INCLS 29) (COCOA) (I/B INNER COVER)
19121596 BELT KIT, R/SEAT (BKL SI) (SINGLE BKL) (TITANIUM)
19121595 BELT KIT, R/SEAT (BKL SI) (CASHMERE)
19121593 BELT KIT, R/SEAT (BKL SI) (SINGLE BKL) (EBONY)
19180585 BELT KIT, R/SEAT (BKL SI) (COCOA)
11570520 BOLT, R/SEAT LAT (M12X1.75X64)
25816412 LATCH, R/SEAT BK (INBOARD FLOOR)
20761397 PANEL, R/SEAT CUSH TR (EBONY) (LATCH COVER-TUB)
20789638 PANEL, R/SEAT CUSH TR (COCOA) (LATCH COVER-TUB)
22772284 PANEL, R/SEAT CUSH TR (CASHMERE) (FLOOR LATCH 40% RR CTR)
22772401 PANEL, R/SEAT CUSH TR (TITANIUM) (FLOOR LATCH 40% RR CTR)
25944145 RISER, R/SEAT
15275903 SPRING, R/SEAT RECL (MANDREL)
25816414 SPRING, R/SEAT RECL
15843764 HARNESS, R/SEAT HTR
25949201 HARNESS, R/SEAT HTR
15275914 CABLE, R/SEAT LAT (FLOOR LATCH)
25816415 CABLE, R/SEAT LAT (OUTBOARD MASTER SYNC)
25816416 CABLE, R/SEAT LAT (INBOARD) (INBOARD MASTER SYNC)
11562379 BOLT, R/SEAT HGE (M10X1.5X92)
teamcadillac.ru
20789641 PANEL, R/SEAT CUSH TR (COCOA) (HINGE COVER)
25816485 PANEL, R/SEAT CUSH TR (EBONY) (HINGE COVER)
25816486 PANEL, R/SEAT CUSH TR (CASHMERE) (HINGE COVER)
25816487 PANEL, R/SEAT CUSH TR (TITANIUM) (HINGE COVER)
20761387 FRAME, R/SEAT CUSH (FOR 2008 & EARLY 2009 VEHICLES IT MAY BE NECESSARY TO CUT A SLIT IN THE SEAT COVER FOR THE BRACKET)
20789636 PANEL, R/SEAT CUSH TR (INCLS 29) (COCOA) (SIDE SHIELD OUTER)
25816465 PANEL, R/SEAT CUSH TR (INCLS 29) (EBONY) (SIDE SHIELD OUTER)
25816466 PANEL, R/SEAT CUSH TR (INCLS 29) (CASHMERE) (SIDE SHIELD OUTER)
25816467 PANEL, R/SEAT CUSH TR (INCLS 29) (TITANIUM) (SIDE SHIELD OUTER)
15279429 HANDLE, R/SEAT RECL (INCLS 32) (TITANIUM)
25858446 HANDLE, R/SEAT RECL (INCLS 32) (COCOA)
15279419 HANDLE, R/SEAT RECL (INCLS 32) (EBONY)
15279420 HANDLE, R/SEAT RECL (INCLS 32) (CASHMERE)
25816401 LATCH, R/SEAT BK (OUTBOARD)
20789637 PANEL, R/SEAT CUSH TR (COCOA) (O/B INNER)
25816469 PANEL, R/SEAT CUSH TR (EBONY) (O/B INNER)
25816470 PANEL, R/SEAT CUSH TR (CASHMERE) (O/B INNER)
25816471 PANEL, R/SEAT CUSH TR (TITANIUM) (O/B INNER)
15824761 HEATER, R/SEAT CUSH
25816418 PAD, R/SEAT CUSH
25816429 COVER, R/SEAT CUSH (EBONY)
25816431 COVER, R/SEAT CUSH (TITANIUM)
25949198 COVER, R/SEAT CUSH (EBONY)
20789580 COVER, R/SEAT CUSH (COCOA)
25816430 COVER, R/SEAT CUSH (CASHMERE)
25908033 COVER, R/SEAT BK (CASHMERE)
15865525 COVER, R/SEAT BK (EBONY)
15865526 COVER, R/SEAT BK (CASHMERE)
15865527 COVER, R/SEAT BK (TITANIUM)
20789578 COVER, R/SEAT BK (COCOA)
20895604 COVER, R/SEAT BK (EBONY)
15291598 PAD, R/SEAT BK
(TK16-037) 2010 CK107(06) ПОКРЫТИЕ ПОЛА И СВЯЗАННЫЕ ДЕТАЛИ (EXC HYBRID HP2)(2ND DES)
20922627 CARPET, R/FLR PNL (EBONY) (W/O PLASTIC STANCHION COVERS) (FOR 1ST DES SEE 15948218)
20922629 CARPET, R/FLR PNL (CASHMERE) (W/O PLASTIC STANCHION COVERS) (FOR 1ST DES SEE 25875643)
20922641 CARPET, R/FLR PNL (INCLS 2-4) (EBONY) (W/O PLASTIC STANCHION COVERS) (FOR 1ST DES SEE 25891808)
20922642 CARPET, R/FLR PNL (INCLS 2-4) (LINEN) (W/O PLASTIC STANCHION COVERS) (FOR 1ST DES SEE 25891811)
20922643 CARPET, R/FLR PNL (INCLS 2-4) (TITANIUM) (W/O PLASTIC STANCHION COVERS) (FOR 1ST DES SEE 25891812)
teamcadillac.ru
20922644 CARPET, R/FLR PNL (INCLS 2-4) (CASHMERE) (69" LENGTH) (W/O PLASTIC STANCHION COVERS) (FOR 1ST DES SEE 25902610)
22837756 INSULATOR, R/FLR PNL CTR
20922210 CARPET, F/FLR PNL (EBONY) (W/O PLASTIC STANCHION COVERS) (FOR 1ST DES SEE 25896628)
20922212 CARPET, F/FLR PNL (LINEN) (W/O PLASTIC STANCHION COVERS) (FOR 1ST DES SEE 25896632)
20922213 CARPET, F/FLR PNL (TITANIUM) (W/O PLASTIC STANCHION COVERS) (FOR 1ST DES SEE 25896633)
20922621 CARPET, F/FLR PNL (EBONY) (W/O PLASTIC STANCHION COVERS) (FOR 1ST DES SEE 25896635)
20922622 CARPET, F/FLR PNL (CASHMERE) (W/O PLASTIC STANCHION COVERS) (FOR 1ST DES SEE 25896637)
20922623 CARPET, F/FLR PNL (TITANIUM) (W/O PLASTIC STANCHION COVERS) (FOR 1ST DES SEE 25896638)
20922211 CARPET, F/FLR PNL (CASHMERE) (W/O PLASTIC STANCHION CVRS) (FOR 1ST DES SEE 20922211)
20922993 CARPET, R/FLR PNL CTR (LINEN)
22837738 CARPET, R/FLR PNL CTR (EBONY)
22837741 CARPET, R/FLR PNL CTR (CASHMERE)
22837739 CARPET, R/FLR PNL CTR (TITANIUM)
22837743 CARPET, R/FLR PNL CTR (EBONY)
22837745 CARPET, R/FLR PNL CTR (CASHMERE)
22837744 CARPET, R/FLR PNL CTR (TITANIUM)
(TK16-040) 2010 CK107(06) КРЕПЛЕНИЕ ЗАДНЕГО СИДЕНЬЯ (BUCKET AL4)(2ND DES)
03537772 NUT, M12X1.75, 10.6THK, 28 O.D., 10, 7111M (R/SEAT) (8.917)
(TK16-042) 2010 CK107(06) КРЕПЛЕНИЕ ЗАДНЕГО СИДЕНЬЯ (60/40 BENCH AM8, EXC HYBRID HP2)(2ND DES)
(TK16-882) 2010-2013 CK107(06) ОТДЕЛКА ВНУТРЕННЯЯ-ROOF (EXC SUNROOF CF5)
20886982 PANEL, HDLNG TR (INCLS 9, 30, 31) (GRAY)
20886983 PANEL, HDLNG TR (INCLS 9, 30, 31) (CASHMERE)
20931026 ASPIRATOR, I/S AIR TEMP SEN (ACDelco #15-51256)
15774330 BRACKET, R/RL RR ASST HDL
10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (R/RL RR ASST HDL (PUSH IN))
11588337 BOLT, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (R/RL RR ASST HDL BRKT)
20760388 HOOK, COAT (INCLS 7) (CASHMERE)
20760387 HOOK, COAT (INCLS 7) (GRAY) (BEZEL W/O FINGERS)
11609649 SCREW, PAN HD, M6X1X20, 15 THD 11.25 OD, 6202M STL, GMW3044, TAPTITE 200 (PART OF 6) (8.913)
15248143 RETAINER, HDLNG T/PNL (CASHMERE)
15126552 RETAINER, HDLNG T/PNL (GRAY) (26.3MM & DIA 6.85)
25835392 DEFLECTOR, AUX A/C AIR OTLT (PART OF 1, 37, 48) (OPEL GRAY)
25835393 DEFLECTOR, AUX A/C AIR OTLT (PART OF 1, 37, 48) (CASHMERE)
15940150 LAMP, DM & RDG (INCLS 11-13) (GRAY)
25850229 LAMP, DM & RDG (INCLS 11-13) (CASHMERE)
15853948 PUSHBUTTON, RDG LP SW (PART OF 10, 18) (AT CONSOLE)
15853945 LENS, DM & RDG LP (3RD ROW LAMP) (PART OF 10)
19116011 BULB, C/LP (PART OF 10, 18) (ACDelco #19116011)
15075507 GRILLE, I/S AIR TEMP SEN ASPIRATOR (GRAY)
15250566 GRILLE, I/S AIR TEMP SEN ASPIRATOR (CASHMERE)
25836770 HANDLE, R/RL RR ASST (INCLS 16) (GRAY)
25836768 HANDLE, R/RL RR ASST (INCLS 16) (GRAY)
25836769 HANDLE, R/RL RR ASST (INCLS 16) (CASHMERE)
25836771 HANDLE, R/RL RR ASST (INCLS 16) (CASHMERE)
11609649 SCREW, PAN HD, M6X1X20, 15 THD 11.25 OD, 6202M STL, GMW3044, TAPTITE 200 (PART OF 15) (8.913)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 18)
15940146 LAMP, DM & RDG (INCLS 11, 13, 17, 19) (OPEL GRAY)
25850223 LAMP, DM & RDG (INCLS 11, 13, 17, 19) (CASHMERE)
15853945 LENS, DM & RDG LP (2ND ROW LAMP) (PART OF 18)
15853951 LENS, S/S ILLUM MIR LP (PART OF 23) (CASHMERE)
15853950 LENS, S/S ILLUM MIR LP (PART OF 23) (GRAY)
13502343 BULB, S/S ILLUM MIR LP (PART OF 23) (8.991) (ACDelco #13502343)
22764796 SUNSHADE, (INCLS 21, 22, 24, 25) (GRAY)
22850311 SUNSHADE, (INCLS 21, 22, 24, 25) (CASHMERE)
22764800 SUNSHADE, (INCLS 21, 22, 24, 25) (GRAY)
22850307 SUNSHADE, (INCLS 21, 22, 24, 25) (CASHMERE)
11610271 SCREW, PAN HD, M4.2X1.41X25, 20.5 THD, 8 OD, 6010M, GMW4205, T15 TORX, AB-PT (PART OF 23)
15828264 COVER, S/S SUPT BOLT (GRAY)
15828266 COVER, S/S SUPT BOLT (CASHMERE)
15828268 COVER, S/S SUPT BOLT (GRAY)
15828270 COVER, S/S SUPT BOLT (CASHMERE)
11516440 SCREW (S/S SUPT)
15893661 RETAINER, S/S (CASHMERE)
15882854 RETAINER, S/S (GRAY)
11569965 CLIP, S/S SUPT (M4.2X1.41) (PUSH IN) (12.8 HOLE) (FOR .7-1.1 PANEL RNG) (10.219)
25994421 CABLE, RDO ANT (PART OF 1, 37, 48) (ACDelco #25994421)
20860277 MODULE, ELEK COMPASS (ACDelco #20860277)
10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (PART OF 33, 45)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 36)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 42)
09431809 BULB, 6CP TRADE #212-2 (PART OF 42) (ACDelco #L212-2)
15256562 BRACKET, VIDEO DISPLAY (INCLS 34)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 47)
25995624 RETAINER, RF RR CNSL (INCLS 46) (DVD BACKPLATE - 3RD ROW)
25995622 RETAINER, RF RR CNSL (INCLS 46) (DVD BACKPLATE - 2ND ROW)
20886985 PANEL, HDLNG TR (INCLS 9, 30, 31) (GRAY)
20886986 PANEL, HDLNG TR (INCLS 9, 30, 31) (CASHMERE)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 53)
09431809 BULB, 6CP TRADE #212-2 (PART OF 53) (ACDelco #L212-2)
15853942 LENS, VIDEO PLYR R/CON SEN (PART OF 53) (RH DVD PUSH-PUSH)
15853941 LENS, VIDEO PLYR R/CON SEN (PART OF 53) (LH DVD PUSH-PUSH)
teamcadillac.ru
15853943 LENS, VIDEO PLYR R/CON SEN (PART OF 53) (CTR DVD FIXED FREEDOM)
25853058 CONSOLE, RF (INCLS 49-52) (GRAY) (2ND ROW DVD)
25853059 CONSOLE, RF (INCLS 49-52) (CASHMERE) (2ND ROW DVD FACE PLT) (PO PNL ASM)
25951257 BRACKET, RF PNL (LOCATED AT FRONT ANC MIC) (W/X-MAS TREE POSTS)
15240415 MICROPHONE, RDO VOL COMP INTR NOISE
(TK16-884) 2010-2013 CK107(06) ОТДЕЛКА ВНУТРЕННЯЯ-ROOF (SUNROOF CF5)
20886975 PANEL, HDLNG TR (INCLS 9, 30, 31) (GRAY)
20886976 PANEL, HDLNG TR (INCLS 9, 30, 31) (CASHMERE)
20886979 PANEL, HDLNG TR (INCLS 9, 30, 31) (GRAY)
20886980 PANEL, HDLNG TR (INCLS 9, 30, 31) (CASHMERE)
25835392 DEFLECTOR, AUX A/C AIR OTLT (PART OF 1, 38) (OPEL GRAY)
25835393 DEFLECTOR, AUX A/C AIR OTLT (PART OF 1, 38) (CASHMERE)
15940150 LAMP, DM & RDG (3RD ROW) (INCLS 11-13) (GRAY)
25850229 LAMP, DM & RDG (3RD ROW) (INCLS 11-13) (CASHMERE)
19116011 BULB, C/LP (PART OF 10) (ACDelco #19116011)
15940146 LAMP, DM & RDG (INCLS 11, 17, 19) (OPEL GRAY)
25850223 LAMP, DM & RDG (INCLS 11, 17, 19) (CASHMERE)
15853945 LENS, DM & RDG LP (PART OF 18)
teamcadillac.ru
25994421 CABLE, RDO ANT (PART OF 1, 38) (ACDelco #25994421)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 37)
25995624 RETAINER, RF RR CNSL (INCLS 36) (DVD BACKPLATE - 3RD ROW)
25995622 RETAINER, RF RR CNSL (INCLS 36) (DVD BACKPLATE - 2ND ROW)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 41)
25853058 CONSOLE, RF (INCLS 40, 42-44) (GRAY) (2ND ROW DVD)
25853059 CONSOLE, RF (INCLS 40, 42-44) (CASHMERE) (2ND ROW DVD FACE PLT) (PO PNL ASM)
15853942 LENS, VIDEO PLYR R/CON SEN (PART OF 41) (RH DVD PUSH-PUSH)
15853941 LENS, VIDEO PLYR R/CON SEN (PART OF 41) (LH DVD PUSH-PUSH)
15853943 LENS, VIDEO PLYR R/CON SEN (PART OF 41) (CTR DVD FIXED FREEDOM)
09431809 BULB, 6CP TRADE #212-2 (PART OF 41) (ACDelco #L212-2)
(TK16-900) 2008-2013 CK107(06) ПОКРЫТИЕ ПОЛА И СВЯЗАННЫЕ ДЕТАЛИ (HYBRID HP2)
25871798 CARPET, R/FLR PNL (INCLS 2-4) (TITANIUM)
25875645 CARPET, R/FLR PNL (INCLS 2-4) (CASHMERE)
teamcadillac.ru
25891889 CARPET, R/FLR PNL (INCLS 2-4) (TITANIUM)
25902611 CARPET, R/FLR PNL (INCLS 2-4) (CASHMERE)
25783706 CARPET, R/FLR PNL (INCLS 2-4) (EBONY)
20764873 CARPET, R/FLR PNL (INCLS 2-4) (LINEN)
25891886 CARPET, R/FLR PNL (INCLS 2-4) (EBONY)
25813593 COVER, R/SEAT RSR INR FIN (SEE GROUP 16.000 "REAR SEAT MOUNTING" FOR DETAILED ILLUSTRATED VIEW) (EBONY)
25813595 COVER, R/SEAT RSR INR FIN (SEE GROUP 16.000 "REAR SEAT MOUNTING" FOR DETAILED ILLUSTRATED VIEW) (TITANIUM)
20820025 COVER, R/SEAT RSR INR FIN (SEE GROUP 16.000 "REAR SEAT MOUNTING" FOR DETAILED ILLUSTRATED VIEW) (LINEN)
25813594 COVER, R/SEAT RSR INR FIN (SEE GROUP 16.000 "REAR SEAT MOUNTING" FOR DETAILED ILLUSTRATED VIEW) (CASHMERE)
20813429 INSULATOR, FLR PNL RR
20813430 INSULATOR, FLR PNL RR
25961362 INSULATOR, BAT (SEE GROUP 02.000 "BATTERY MOUNTING/DRIVE MOTOR" FOR DETAILED ILLUSTRATED VIEW)
20757791 INSULATOR, FLR PNL FRT
20764871 CARPET, F/FLR PNL (LINEN)
25896640 CARPET, F/FLR PNL (EBONY)
25896641 CARPET, F/FLR PNL (CASHMERE)
25896643 CARPET, F/FLR PNL (TITANIUM)
17800408 MAT PKG, FRONT CARPET (MOLDED EDGE) (EBONY) (2.03KGS) (CPT) (TWIN) (W/WREATH & CREST LOGO) (16.800)
17800409 MAT PKG, FRONT CARPET (MOLDED EDGE) (CASHMERE) (2.03KGS) (CPT) (TWIN) (W/WREATH & CREST LOGO) (16.800)
25871798 CARPET, R/FLR PNL (TITANIUM)
25875645 CARPET, R/FLR PNL (CASHMERE)
25783706 CARPET, R/FLR PNL (EBONY)
25891889 CARPET, R/FLR PNL (TITANIUM)
25902611 CARPET, R/FLR PNL (CASHMERE)
20764873 CARPET, R/FLR PNL (LINEN)
25891886 CARPET, R/FLR PNL (EBONY)
(TK16-904) 2009-2013 CK1(06) ПРИБОРНАЯ ПАНЕЛЬ И СВЯЗАННЫЕ ДЕТАЛИ PART 1 TRIM (CADILLAC Z75)
20844035 PANEL, I/P UPR TR (W/ W/S DEFR NOZ GRL) (INCLS 2, 57) (EBONY) (W/O SI OUTLET GRILLES)
20844038 PANEL, I/P UPR TR (W/ W/S DEFR NOZ GRL) (INCLS 2, 57) (COCOA)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 1)
15221850 GRILLE, RDO FRT SPKR (INCLS 4) (EBONY)
15221851 GRILLE, RDO FRT SPKR (INCLS 4) (COCOA)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 3)
15813116 GRILLE, SI WDO DEFG OTLT (EBONY) (*KIT2)
15813143 GRILLE, SI WDO DEFG OTLT (EBONY) (*KIT2)
15813144 GRILLE, SI WDO DEFG OTLT (COCOA) (*KIT2)
15813117 GRILLE, SI WDO DEFG OTLT (COCOA) (*KIT2)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (I/P UPR TR PAD) (9.665)
11610157 NUT, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (PART OF 9) (10.701)
22783170 PANEL, I/P LWR TR (INCLS 8, 53) (CASHMERE)
22783169 PANEL, I/P LWR TR (INCLS 8, 53) (EBONY)
22845822 PANEL, I/P LWR TR (INCLS 8, 53) (COCOA)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 12, 50)
20935580 DEFLECTOR, I/P OTR AIR OTLT (INCLS 59) (PART OF 12) (EBONY)
20935552 PLATE, I/P TR (INCLS 10, 11, 59) (RUBY)
20935553 PLATE, I/P TR (INCLS 10, 11, 59) (CHOCOLATE)
20935569 PLATE, I/P TR (INCLS 10, 11, 13) (CHOCOLATE)
20935555 PLATE, I/P TR (INCLS 10, 11, 59) (OLIVE)
20935568 PLATE, I/P TR (INCLS 10, 11, 13) (RUBY)
20935552 PLATE, I/P TR (INCLS 10, 11) (RUBY)
20935553 PLATE, I/P TR (INCLS 10, 11) (CHOCOLATE)
25971121 EMBLEM, I/P (PART OF 12)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 15)
15854787 COVER, I/P COMPT ACC HOLE (INCLS 14) (EBONY) (GLOVE BOX)
15854854 BUMPER, I/P COMPT DR STOP (BIN) (*KIT1) (16.110)
11609509 SCREW, LG RD WA HD, C/R, HI-LO, 4.2X1.41X13, 11.35-OD, B PT, 6010, GMW4205 (I/P COMPT DR) (*KIT1)
10446032 BUMPER, I/P COMPT (8.80 DIA) (CLOSED-STOP) (FRAME) (*KIT1) (10.263)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (I/P COMPT DR) (9.665)
11609539 SCREW, RD CROWNED WA HD, M4.2X1.41X16, STL ISO 2702, GMW4205 (I/P COMPT DR LAT STKR) (*KIT1)
11610157 NUT, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (I/P LWR TIE BAR) (*KIT1) (10.701)
11589015 BOLT, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (I/P COMPT DR HGE) (*KIT1)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (I/P ACSRY CTR TR PLT) (*KIT3)
20935618 DEFLECTOR, I/P CTR AIR OTLT (EBONY) (*KIT3)
25960447 LATCH, I/P COMPT DR (LINEN) (W/LOCK) (*KIT1) (10.268)
25960443 LATCH, I/P COMPT DR (EBONY) (W/LOCK HOLE) (*KIT1) (10.268)
25960448 LATCH, I/P COMPT DR (CASHMERE) (W/LOCK) (*KIT1) (10.268)
22819134 CYLINDER KIT, I/P COMPT DR LK (UNCODED)
25878605 PLATE, I/P ACSRY CTR TR (RUBY BURLWOOD) (W/O DEFLECTORS) (*KIT3)
25878606 PLATE, I/P ACSRY CTR TR (CHOCOLATE BURL) (W/O DEFLECTORS) (*KIT3)
20935616 DEFLECTOR, I/P CTR AIR OTLT (EBONY) (*KIT3)
10365827 INSULATOR, I/P (W/O FELT TAPE)
25790726 INSULATOR, I/P (W/FELT TAPE)
11517774 BOLT, HEX, M4.2X1.41X20, 14.25 OD, 6010M, 6138M, TAP, AB-PT (I/P INSL)
15238666 PANEL, F/FLR CNSL SI TR FRT (INCLS 36) (EBONY) (16.081)
15876585 PANEL, F/FLR CNSL SI TR FRT (INCLS 36-38, 58) (LINEN)
15876587 PANEL, F/FLR CNSL SI TR FRT (INCLS 36) (LINEN)
25901544 PANEL, F/FLR CNSL SI TR FRT (INCLS 36) (CASHMERE)
25844279 PANEL, F/FLR CNSL SI TR FRT (INCLS 36-38, 58) (EBONY)
25901545 PANEL, F/FLR CNSL SI TR FRT (INCLS 36-38, 58) (CASHMERE)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 35)
11588920 SCREW, W/RND WA, M3.5X1.59X9.5, 6 THD, 7 O.D., GM512M, GMW3044 (PART OF 35)
15240415 MICROPHONE, RDO VOL COMP INTR NOISE (PART OF 35)
15221547 PLATE, HDLP SW TR (INCLS 40, 41) (EBONY)
15907806 PLATE, HDLP SW TR (INCLS 40, 41) (EBONY)
teamcadillac.ru
11610112 CLIP, HDLP (PART OF 39) (10.4 X 13 X 9) (14.683)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 39)
22773450 BOLSTER, I/P KNEE (INCLS 42) (LINEN)
22773443 BOLSTER, I/P KNEE (INCLS 42) (EBONY)
22773448 BOLSTER, I/P KNEE (INCLS 42) (CASHMERE)
22773444 BOLSTER, I/P KNEE (INCLS 42) (CASHMERE)
22773447 BOLSTER, I/P KNEE (INCLS 42) (EBONY)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (I/P DRVR KNEE BOLS) (9.665)
25901548 COVER, I/P FUSE BLK ACC HOLE (INCLS 46) (CASHMERE)
25940492 COVER, I/P FUSE BLK ACC HOLE (INCLS 46-49) (EBONY)
25940498 COVER, I/P FUSE BLK ACC HOLE (INCLS 46-49) (CASHMERE)
25855840 COVER, I/P FUSE BLK ACC HOLE (INCLS 46) (EBONY)
25896366 COVER, I/P FUSE BLK ACC HOLE (INCLS 46) (LINEN)
22925347 COVER, I/P FUSE BLK ACC HOLE (INCLS 46-49) (LINEN) (IF VEH HAS 30 AMP FUSE ORDER LABEL 25940508)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 45)
88909749 FUSE, 3A, MINI, VIOLET (PART OF 45) (8.965) (ACDelco #ATM3-25)
88909754 FUSE, 15A, MINI, BLUE (PART OF 45) (ACDelco #ATM15-25)
88909756 FUSE, MINI (25 AMP) (CLEAR) (QTY 25 (PART OF 45) (ACDelco #ATM25-25)
12092079 FUSE, 10A, MINI, RED (PART OF 45)
88861352 FUSE, 20A, MINI, YELLOW (PART OF 45) (ACDelco #ATM20)
12084791 PULLER, FUSE (PART OF 45) (MINI) (I/P COVER)
25940508 LABEL, I/P WRG HARN FUSE BLK IDENT (PART OF 45) (2.483)
15876619 PLATE, I/P TR (INCLS 10, 51, 59) (BURL)
20935548 PLATE, I/P TR (INCLS 10, 51, 59) (CHOCOLATE)
20935547 PLATE, I/P TR (INCLS 10, 51, 59) (RUBY)
20935578 DEFLECTOR, I/P OTR AIR OTLT (PART OF 50) (INCLS 59) (EBONY)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 54)
11513599 NUT, U-TYPE, M4.2X1.41, 0.65-3.80 PNL THK, PZ (PART OF 9) (ACDelco #11513599)
25914313 PLATE, I/P CSTR TR (INCLS 52, 56) (EBONY)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (I/P UPR TR PLT) (*KIT2)
25603681 INSULATOR, I/P CSTR TR PLT (PART OF 54) (*KIT3)
11562257 RETAINER, I/P LWR TR PAD BRKT (PUSH ON) (PART OF 35) (19.5 X 30.4 X 1.8) (14.683)
22792288 KNOB, I/P OTR AIR OTLT (PART OF 11, 12, 50, 51)
25965505 DOOR, I/P COMPT (INCLS 16-19, 21-26, 29) (CASHMERE)
25965502 DOOR, I/P COMPT (INCLS 16-19, 21-26, 29) (LINEN)
20925891 DOOR, I/P COMPT (INCLS 16-19, 21-26, 29) (EBONY)
22845828 PANEL, I/P UPR TR (INCLS 5, 6, 55) (COCOA)
22818929 PANEL, I/P UPR TR (INCLS 5, 6, 55) (COCOA)
22845831 PANEL, I/P UPR TR (INCLS 5, 6, 55) (EBONY)
25878605 PLATE, I/P ACSRY CTR TR (INCLS 27, 28, 31, 32, 56) (RUBY BURLWOOD) (W/O DEFLECTORS)
25878606 PLATE, I/P ACSRY CTR TR (INCLS 27, 28, 31, 32, 56) (CHOCOLATE BURL) (W/O DEFLECTORS)
20935599 PLATE, I/P ACSRY CTR TR (INCLS 27, 28, 31, 32, 56) (PLATINUM) (W/PLATE & DEFLECTORS)
20935605 PLATE, I/P ACSRY CTR TR (INCLS 27, 28, 31, 32, 56) (RUBY) (W/PLATE & DEFLECTORS)
(TK16-910) 2009-2011 CK1,2(06) КАМЕРА ЗАДНЕГО ВИДА (UVC)
25872958 HARNESS, RR LIC PLT LP WRG
teamcadillac.ru
03530297 NUT, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (L/GATE CTR MLDG)
20945097 MIRROR, I/S RR VIEW (10.185)
15779345 COVER, I/S RR VIEW MIR WRG HARN (BETWEEN ISRVM & HDLNG TRIM)
(TK16-914) 2010 CK1(06) СИСТЕМА СТЕКЛООЧИСТИТЕЛЯ ВЕТРОВОГО СТЕКЛА (POLICE PACKAGE PPV)(1ST DES)
20959488 ARM, WSW (INCLS 2) (BLACK)
20959487 ARM, WSW (INCLS 2) (BLACK)
15776792 CAP, WSW ARM FIN (PART OF 1) (WINDSHIELD-CAP WIPER ARM NUT)
11609634 NUT, HEX WASH, M10X1.25, 7MM THK, 20 WA OD, 9 STL, 7111M, CON SPR WA. (WSW ARM)
25820729 PANEL, AIR INL GRL (INCLS 5) (BLACK)
25820730 PANEL, AIR INL GRL (INCLS 5) (BLACK)
11609796 CLIP, AIR INL GRL PNL (PART OF 4) (11.0 X 12.9 X 6.1MM) (8.950)
teamcadillac.ru
15780444 COVER, W/S O/S MSTRE SEN (COVERS MIR HARNESS)
25872303 PANEL, AIR INL GRL (CTR) (INCLS 10, 15, 18) (BLACK)
20908176 HOSE, WSWA NOZ (PART OF 9)
25923882 MODULE, WSW SYS
11513947 BOLT, HEX, W/WA, M6X1X35, 24 O.D., AC PT, 9.8, POR (WSW SYS MDL)
15999788 RETAINER, AIR INL GRL PNL (17X15.25X8.6) (U-SHAPED/CLIP)
11589183 NUT, PUSH IN, W/SEAL, 4.2X1.41, 6.35-6.48 SQ HL, 9.5 SQ HD, 0.787-2.765 PNL THK, NYL (AIR INL GRL PNL)
15200240 WEATHERSTRIP, HOOD RR (PART OF 9)
11609797 BOLT, AIR INL GRL PNL (10.268)
25877402 BLADE, WSW (22") (ONE PIECE FLAT BLADE) (W/SIDE LOCK RELEASE CONNECT ON CENTER)
15048061 RETAINER, AIR INL GRL PNL (PART OF 9) (PUSH IN)
25731418 CAP, WSWA SOLV CNTNR (10.154)
20999340 CONTAINER KIT, WSWA SOLV (INCLS 24, 25) (USE T/W 20999338 WHEN REPLACING 15248577, 15213911 OR 15942522.)
11516578 BOLT, HEX W/FL WA, M6X1X25, 16 THD, 24 OD, 9.8, 7114M, MACH, 6MM P PT. (WSWA SOLV CNTNR)
20999338 INDICATOR KIT, WSWA SOLV LVL (INCLS 24) (LEVEL SENSOR KIT W/GROMMET) (KIT HAS 16MM DIAM LVL SENSOR) (ACDelco #20999338) (USE T/W 20999340 WHEN REPLACING 15248577, 15213911 OR 15942522.)
15248578 GROMMET, WSWA SOLV CNTNR (PART OF 21, 23)
15927514 GROMMET, WSWA PUMP (PUMP GROMMET) (PART OF 21, 26, 27) (ACDelco #15927514)
15942524 PUMP KIT, WSWA W/SEAL (INCLS 25) (RR PUMP KIT W/GROMMET) (ACDelco #15942524)
15942523 PUMP KIT, WSWA W/SEAL (INCLS 25) (FRT PUMP KIT W/GROMMET) (ACDelco #15942523)
25887957 HOSE, R/WDO WA PUMP (SEE GROUP 16.000 "WIPER SYSTEM/ REAR WINDOW" FOR DETAILED ILLUSTRATED VIEW) (REAR JUMPER HOSE)
25887977 HOSE, WSWA PUMP (FRT JUMPER HOSE)
11516793 NUT, HEX, W/CON WA, M6X1X5.5, 16 O.D., 9, 7111M (WSWA SOLV HTR)
20779836 SPACER, AIR INL GRL PNL
(TK16-915) 2010-2013 CK1,2,3 СИСТЕМА ПОДУШЕК БЕЗОПАСНОСТИ
25812356 AIRBAG, I/P (CASHMERE)
25812357 AIRBAG, I/P (TITANIUM)
25819574 AIRBAG, I/P (COCOA)
teamcadillac.ru
25812358 AIRBAG, I/P (CASHMERE) (DUAL LEVEL)
25812355 AIRBAG, I/P (EBONY)
11588337 BOLT, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (I/P AIRBAG)
25784920 AIRBAG, STRG WHL (COCOA) (DUAL LEVEL)
25917968 AIRBAG, STRG WHL (EBONY) (LABELED 25917968) (DUAL LEVEL) (INCLS NON-SERVICE CABLE EMBLEM)
25917969 AIRBAG, STRG WHL (COCOA) (LABELED 25917969) (DUAL LEVEL)
21996989 TAG, I/P AIRBAG WRNG (HANGING)
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (AIRBAG SEN & DIAGN MDL CVR)
25898069 COVER, AIRBAG SEN & DIAGN
03530297 NUT, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (AIRBAG SEN & DIAGN MDL CVR)
13576628 MODULE, AIRBAG SEN & DIAGN
13502744 SENSOR, AIRBAG F/END DISCRM (MT ON FRT RAD SUPT)
(TK16-926) 2010-2013 CK1,2(06-36) РЕМНИ БЕЗОПАСНОСТИ/ПЕРЕДНИЕ
15257724 COVER, P/SEAT SHLDR BELT GDE ADJR OPG (GRAY)
25831268 COVER, D/SEAT SHLDR BELT GDE ADJR OPG (LINEN)
15257726 COVER, D/SEAT SHLDR BELT GDE ADJR OPG (CASHMERE)
15257724 COVER, D/SEAT SHLDR BELT GDE ADJR OPG (GRAY)
25901990 ADJUSTER, D/SEAT SHLDR BELT GDE (INCLS 4) (LINEN)
25901985 ADJUSTER, D/SEAT SHLDR BELT GDE (INCLS 4) (GRAY)
25901987 ADJUSTER, P/SEAT SHLDR BELT GDE (INCLS 4) (CASHMERE)
25901985 ADJUSTER, P/SEAT SHLDR BELT GDE (INCLS 4) (GRAY)
25901987 ADJUSTER, D/SEAT SHLDR BELT GDE (INCLS 4) (CASHMERE)
11609471 BOLT, D/SEAT BELT (RETR SI) (PART OF 8) (M12X1.75X28) (14.875)
19256120 BELT KIT, D/SEAT (RETR SI) (W/PRE-TENSR) (INCLS 2, 6, 7, 14) (CASHMERE) (BEZEL W/O LOCATOR BOSS) (FOR 1ST DES SEE 19210196)
19256121 BELT KIT, D/SEAT (RETR SI) (W/PRE-TENSR) (INCLS 2, 6, 7, 14) (TITANIUM) (BEZEL W/O LOCATOR BOSS) (FOR 1ST DES SEE 19210197)
19256138 BELT, P/SEAT (RETR SI) (INCLS 2, 6, 7, 14) (CASHMERE) (BEZEL W/O LOCATOR BOSS) (FOR 1ST DES SEE 19210204)
19256139 BELT, P/SEAT (RETR SI) (INCLS 2, 6, 7, 14) (TITANIUM) (BEZEL W/O LOCATOR BOSS) (FOR 1ST DES SEE 19210203)
19256126 BELT KIT, D/SEAT (RETR SI) (W/PRE-TENSR) (INCLS 2, 6, 7, 14) (EBONY)
19256144 BELT KIT, P/SEAT (RETR SI) (W/PRE-TENSR) (INCLS 2, 6, 7, 14) (EBONY)
teamcadillac.ru
19256127 BELT KIT, D/SEAT (RETR SI) (W/PRE-TENSR) (INCLS 2, 6, 7, 14) (CASHMERE)
19256128 BELT KIT, D/SEAT (RETR SI) (W/PRE-TENSR) (INCLS 2, 6, 7, 14) (TITANIUM)
19256146 BELT KIT, P/SEAT (RETR SI) (W/PRE-TENSR) (INCLS 2, 6, 7, 14) (TITANIUM)
19256130 BELT KIT, D/SEAT (RETR SI) (W/PRE-TENSR) (INCLS 2, 6, 7, 14) (COCOA)
19256148 BELT KIT, P/SEAT (RETR SI) (W/PRE-TENSR) (INCLS 2, 6, 7, 14) (COCOA)
19256145 BELT KIT, P/SEAT (RETR SI) (W/PRE-TENSR) (INCLS 2, 6, 7, 14) (CASHMERE)
19210196 BELT KIT, D/SEAT (RETR SI) (W/PRE-TENSR) (INCLS 2, 6, 7, 14) (CASHMERE) (BEZEL W/LOCATOR BOSS) (FOR 2ND DES SEE 19256120)
19210197 BELT KIT, D/SEAT (RETR SI) (W/PRE-TENSR) (INCLS 2, 6, 7, 14) (TITANIUM) (BEZEL W/LOCATOR BOSS) (FOR 2ND DES SEE 19256121)
19210202 BELT, P/SEAT (RETR SI) (INCLS 2, 6, 7, 14) (CASHMERE) (BEZEL W/LOCATOR BOSS) (FOR 2ND DES SEE 19256138)
19210203 BELT, P/SEAT (RETR SI) (INCLS 2, 6, 7, 14) (TITANIUM) (BEZEL W/LOCATOR BOSS) (FOR 2ND DES SEE 19256139)
20899406 RETRACTOR, F/SEAT BELT (RETR SI) (EBONY)
20899407 RETRACTOR, F/SEAT BELT (RETR SI) (CASHMERE)
20899448 RETRACTOR, F/SEAT BELT (RETR SI) (CASHMERE)
20899447 BELT, P/SEAT (RETR SI) (W/ TENSR) (INCLS 2, 6, 7, 14) (EBONY)
22856522 RETRACTOR, F/SEAT BELT (RETR SI) (EBONY) (W/PRETENSIONER)
22856557 RETRACTOR, F/SEAT BELT (RETR SI) (COCOA) (W/PRETENSIONER)
22856524 RETRACTOR, F/SEAT BELT (RETR SI) (COCOA) (W/PRETENSIONER)
15035434 NUT, D/SEAT BELT (RETR SI) (M10X1.5X10.8) (FLANGE NUT) (16.679)
11517996 NUT, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (D/SEAT BELT (BKL SI)) (ACDelco #11517996)
12473319 BOLT, F/CTR SEAT BELT BKL (M12X1.75X37) (HEX) (OUTER) (16.682)
19207765 STOP KIT, BELT LAT (RETR SI) (PART OF 8) (COCOA) (14.875)
19121445 STOP KIT, BELT LAT (RETR SI) (PART OF 8) (CASHMERE) (14.875)
19121443 STOP KIT, BELT LAT (RETR SI) (PART OF 8) (TITANIUM) (14.875)
19121446 STOP KIT, BELT LAT (RETR SI) (PART OF 8) (EBONY) (14.875)
(TK16-928) 2010-2013 CK107(06) ЛИСТОВОЙ МЕТАЛЛ/BODY SIDE FRONT
15934445 FRAME, S/D OPG (INCLS 16, 17, 29, 31)
15934444 FRAME, S/D OPG (INCLS 16, 17, 29, 31)
11609733 BOLT, HEX W/CON WA, M8X1.25X30, 20 THD, 24 OD, 10.9, GMW4205, MAT POINT (RR S/D HGE (DR SI))
15288880 EXTENSION, INTER FLR PNL
15288881 EXTENSION, INTER FLR PNL
20840663 PANEL, RR S/D OTR (PART OF 8)
20840664 PANEL, RR S/D OTR (PART OF 8)
20758530 DOOR, RR SI (INCLS 7)
20969014 DOOR, RR SI (INCLS 7)
20969645 HINGE, FRT S/D LWR (BODY & DR SI) (W/CHECK LINK)
20969646 HINGE, FRT S/D LWR (BODY & DR SI) (W/CHECK LINK)
11609733 BOLT, HEX W/CON WA, M8X1.25X30, 20 THD, 24 OD, 10.9, GMW4205, MAT POINT (FRT S/D HGE (BODY SI))
25854415 HINGE, FRT S/D UPR (BODY & DR SIDE) (REPL T/W 13307322 T/W ADHESIVE 89021297)
25854416 HINGE, FRT S/D UPR (BODY & DR SIDE) (REPL T/W 13307322 T/W ADHESIVE 89021297)
25891764 PANEL, FRT S/D OTR (PART OF 14)
25891763 PANEL, FRT S/D OTR (PART OF 14)
20866212 DOOR, FRT SI (INCLS 13) (W/O HINGES)
20970076 DOOR, FRT SI (INCLS 13) (W/O HINGES)
15837058 INSULATOR, S/D OPG FRM (LWR FRT BODY H-PLR)
15837057 INSULATOR, S/D OPG FRM (LWR FRT BODY H-PLR)
teamcadillac.ru
25815106 EXTENSION, FLR PNL (FRONT)
25815107 EXTENSION, FLR PNL (FRONT)
25858298 SEAL, CTR PLR LWR
25858299 SEAL, CTR PLR LWR
10393085 REINFORCEMENT, FRT S/D OPG FRM
10393086 REINFORCEMENT, FRT S/D OPG FRM
10393087 RAIL, RF SI (INCLS 23)
10393088 RAIL, RF SI (INCLS 23)
20899350 PANEL, CTR PLR INR UPR (INCLS 25)
22802201 PANEL, CTR PLR INR UPR (INCLS 25)
15854158 PANEL, BODY SI INR UPR
15858829 PANEL, BODY SI INR UPR
25893145 PLATE, R/SEAT SHLDR BELT ANC
25893144 PLATE, R/SEAT SHLDR BELT ANC
20957778 PANEL, CTR PLR INR LWR (INCLS 30)
20957779 PANEL, CTR PLR INR LWR (INCLS 30)
15232690 PLUG, BODY SI FRM ACC HOLE (SQUARE)
(TK16-930) 2010-2013 CK1,2,3(06-36-43) ОТДЕЛКА ВНУТРЕННЯЯ-BODY SIDE FRONT
20962796 MOLDING, W/S SI GARN (INCLS 2-7) (CASHMERE) (W/SPEAKER)
20986759 MOLDING, W/S SI GARN (INCLS 2-7) (GRAY)
20986760 MOLDING, W/S SI GARN (INCLS 2-7) (CASHMERE)
20962795 MOLDING, W/S SI GARN (INCLS 2-7) (GRAY) (W/SPEAKER)
20986758 MOLDING, W/S SI GARN (INCLS 2-7) (LINEN)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 1)
11609651 CLIP, W/S SI G/MLDG (PART OF 1) (METAL PUSH-IN NUT, M4.2X1.41, 21.8X15X20.5) (14.731)
11609465 BOLT, HWH, M4.2X1.41X18, 12.5 OD, 6010M, PS (PART OF 1) (8.977)
25827808 PLUG, W/S SI G/MLDG BOLT HOLE FIN (PART OF 1) (LINEN/COCOA) (LH)
15220492 PLUG, W/S SI G/MLDG BOLT HOLE FIN (PART OF 1) (GRAY)
15214074 PLUG, W/S SI G/MLDG BOLT HOLE FIN (PART OF 1) (GRAY) (RH & LH)
15214075 PLUG, W/S SI G/MLDG BOLT HOLE FIN (PART OF 1) (CASHMERE) (16.575)
15186674 SPEAKER, RDO W/S SI G/MLDG (PART OF 1, 23) (ACDelco #15186674)
25889857 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 1) (LINEN)
25889853 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 1) (GRAY)
25889855 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 1)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 9)
15877455 PANEL, BODY H/PLR TR (INCLS 8) (LINEN)
15877457 PANEL, BODY H/PLR TR (INCLS 8) (LINEN)
15904433 PANEL, BODY H/PLR TR (INCLS 8) (TITANIUM)
15904439 PANEL, BODY H/PLR TR (INCLS 8) (TITANIUM)
15904434 PANEL, BODY H/PLR TR (INCLS 8) (CASHMERE)
15904440 PANEL, BODY H/PLR TR (INCLS 8) (CASHMERE)
15904432 PANEL, BODY H/PLR TR (INCLS 8) (EBONY)
15904438 PANEL, BODY H/PLR TR (INCLS 8) (EBONY)
25902619 PLATE, FRT S/D SILL TR (INCLS 11) (CASHMERE)
25902620 PLATE, FRT S/D SILL TR (INCLS 11) (CASHMERE)
25962379 PLATE, FRT S/D SILL TR (INCLS 11) (EBONY)
25962380 PLATE, FRT S/D SILL TR (INCLS 11) (CASHMERE)
25962382 PLATE, FRT S/D SILL TR (INCLS 11) (EBONY)
25962383 PLATE, FRT S/D SILL TR (INCLS 11) (CASHMERE)
20765248 PLATE, FRT S/D SILL TR (INCLS 11) (LINEN)
20765249 PLATE, FRT S/D SILL TR (INCLS 11) (LINEN)
15877375 PLATE, FRT S/D SILL TR (INCLS 11) (LINEN)
15877377 PLATE, FRT S/D SILL TR (INCLS 11) (LINEN)
15848375 PLATE, FRT S/D SILL TR (INCLS 11) (EBONY) (W/CADILLAC INSERT)
15848379 PLATE, FRT S/D SILL TR (INCLS 11) (EBONY) (W/CADILLAC INSERT)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 10)
20902384 MOLDING, CTR PLR LWR GARN (INCLS 13) (TITANIUM)
20902386 MOLDING, CTR PLR LWR GARN (INCLS 13) (LINEN)
20902389 MOLDING, CTR PLR LWR GARN (INCLS 13) (TITANIUM)
20902391 MOLDING, CTR PLR LWR GARN (INCLS 13) (LINEN)
20986854 MOLDING, CTR PLR LWR GARN (INCLS 13) (EBONY)
20986849 MOLDING, CTR PLR LWR GARN (INCLS 13) (EBONY)
20986847 MOLDING, CTR PLR LWR GARN (INCLS 13) (CASHMERE)
20986852 MOLDING, CTR PLR LWR GARN (INCLS 13) (CASHMERE)
11561654 RETAINER, CTR PLR UPR G/MLDG (PART OF 12, 15) (PLAIN) (BIRD'S BEAK SINGLE) (FITS 8.5 DIA HOLE) (12.800)
11609651 RETAINER, CTR PLR UPR G/MLDG (PART OF 12, 15) (METAL PUSH-IN NUT, M4.2X1.41, 21.8X15X20.5) (14.731)
11561654 RETAINER, CTR PLR G/MLDG (PART OF 12, 15) (PLAIN) (BIRD'S BEAK SINGLE) (FITS 8.5 DIA HOLE) (12.800)
teamcadillac.ru
15214078 COVER, D/SEAT SHLDR BELT GDE ADJR CLOSEOUT (PART OF 15) (GRAY)
25827825 COVER, P/SEAT SHLDR BELT GDE ADJR CLOSEOUT (PART OF 15) (LINEN)
15877439 MOLDING, CTR PLR UPR GARN (INCLS 13, 14, 16-19) (LINEN)
15877441 MOLDING, CTR PLR UPR GARN (INCLS 13, 14, 16-19) (LINEN)
20986782 MOLDING, CTR PLR UPR GARN (INCLS 13, 14, 16-19) (GRAY)
20986783 MOLDING, CTR PLR UPR GARN (INCLS 13, 14, 16-19) (CASHMERE)
20986787 MOLDING, CTR PLR UPR GARN (INCLS 13, 14, 16-19) (CASHMERE)
20986786 MOLDING, CTR PLR UPR GARN (INCLS 13, 14, 16-19) (GRAY)
15278044 PLUG, CTR PLR HOLE (PART OF 15) (GRANITE)
25827824 PLUG, CTR PLR HOLE (PART OF 15) (LINEN)
15278045 PLUG, CTR PLR HOLE (PART OF 15) (CASHMERE)
15278047 PLUG, CTR PLR HOLE (PART OF 15) (GRAY)
11609465 BOLT, HWH, M4.2X1.41X18, 12.5 OD, 6010M, PS (PART OF 15) (8.977)
11561654 RETAINER, CTR PLR UPR G/MLDG (PART OF 15) (PLAIN) (BIRD'S BEAK SINGLE) (FITS 8.5 DIA HOLE) (12.800)
11609651 RETAINER, CTR PLR UPR G/MLDG (PART OF 15) (METAL PUSH-IN NUT, M4.2X1.41, 21.8X15X20.5) (14.731)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 15)
11570136 BOLT, HEX HD, W/CON SPR WA, M6X1X23, 14 THD, 17 O.D., 8.8, GMW3359 (ASST HDL)
15936642 HANDLE, ASST (LINEN)
20776887 HANDLE, ASST (LINEN)
20986861 HANDLE, ASST (GRAY)
20986857 HANDLE, ASST (GRAY)
20986858 HANDLE, ASST (CASHMERE)
20986862 HANDLE, ASST (CASHMERE)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 23)
20986755 MOLDING, W/S SI GARN (INCLS 6, 22, 24) (GRAY)
20962773 MOLDING, W/S SI GARN (INCLS 6, 22, 24) (CASHMERE)
20986754 MOLDING, W/S SI GARN (INCLS 6, 22, 24) (LINEN)
20962772 MOLDING, W/S SI GARN (INCLS 6, 22, 24) (GRAY) (W/SPEAKER)
20986756 MOLDING, W/S SI GARN (INCLS 6, 22, 24) (CASHMERE)
25889863 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 23) (LINEN)
25889859 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 23) (GRAY)
25889861 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 23) (CASHMERE)
15936574 COVER, W/S PLR ASST HDL (PART OF 27) (LINEN) (UPPER)
15936575 COVER, W/S PLR ASST HDL (PART OF 27) (LINEN) (LOWER)
15255444 COVER, W/S PLR ASST HDL (PART OF 27) (CASHMERE) (LOWER)
15255445 COVER, W/S PLR ASST HDL (PART OF 27) (CASHMERE) (UPPER)
15220455 COVER, W/S PLR ASST HDL (PART OF 27) (GRAY) (UPPER)
15220459 COVER, W/S PLR ASST HDL (PART OF 27) (GRAY) (LOWER)
11609939 BOLT, HEX W/FLAT WA, M6X1X30, 21 THD, 17 OD, TAPPING (W/S PLR ASST HDL)
15936573 HANDLE, W/S PLR ASST (INCLS 25) (LINEN)
20986868 HANDLE, W/S PLR ASST (INCLS 25) (CASHMERE)
20986867 HANDLE, W/S PLR ASST (INCLS 25) (GRAY)
(TK16-934) 2010-2013 CK1(06-36) ОТДЕЛКА ДВЕРИ/SIDE FRONT-DRIVER (CADILLAC Z75)
25889237 DEFLECTOR, FRT S/D WAT (PART OF 23)
15844616 KNOB, FRT S/D LKG ROD (EBONY)
15844620 KNOB, FRT S/D LKG ROD (COCOA)
20785356 KNOB, FRT S/D LKG ROD (CASHMERE)
10410811 CLIP, FRT S/D C/LP (PART OF 9) (10.777)
20835555 SWITCH, FRT S/D WDO CONT (PART OF 9) (ACDelco #D1412H)
20877684 PLATE, FRT S/D ACSRY SW MT (INCLS 6-8) (WALNUT)
22769988 PLATE, FRT S/D ACSRY SW MT (INCLS 6-8) (BLACK)
20877686 PLATE, FRT S/D ACSRY SW MT (INCLS 6-8) (COCOA)
20980438 PLATE, FRT S/D ACSRY SW MT (INCLS 6-8) (MOCHA)
25857283 PANEL, FRT S/D UPR FRT TR (INCLS 11) (COCOA)
25906770 PANEL, FRT S/D UPR FRT TR (INCLS 11) (CASHMERE)
25857282 PANEL, FRT S/D UPR FRT TR (INCLS 11) (EBONY)
25870922 RETAINER, FRT S/D UPR FRT T/PNL (PART OF 10)
13500192 SEAL, FRT S/D (PART OF 23) (LOC PIN SEAL) (INCLS RIGHT & LEFT)
15905947 BOLT, FRT S/D T/PNL
25822439 SWITCH, D/SEAT ADJR MEMORY
15920707 HANDLE, FRT S/D I/S (PART OF 23) (EBONY) (W/CHROME HDL) (W/ HOLE FOR MEMORY SEAT SWITCH)
22855631 HANDLE, FRT S/D I/S (PART OF 23) (CASHMERE)
22855632 HANDLE, FRT S/D I/S (PART OF 23)
25906776 COVER, FRT S/D I/S HDL BZL FIN (CASHMERE)
25897910 COVER, FRT S/D I/S HDL BZL FIN (COCOA)
25897906 COVER, FRT S/D I/S HDL BZL FIN (EBONY)
11570136 BOLT, HEX HD, W/CON SPR WA, M6X1X23, 14 THD, 17 O.D., 8.8, GMW3359 (FRT S/D T/PNL)
20934187 COVER, FRT S/D T/PNL (EBONY)
20934190 COVER, FRT S/D T/PNL (LINEN)
22874310 COVER, FRT S/D T/PNL (CASHMERE)
15876516 LAMP, CTSY (INCLS 20, 22, 25) (FRT S/D)
09425542 BULB, LAMP #168 (PART OF 21) (ACDelco #L168)
22818536 PANEL, FRT S/D TR (INCLS 1, 2, 4, 5, 12, 15, 19, 24, 26-30, 33, 37) (EBONY)
22818547 PANEL, FRT S/D TR (INCLS 1, 2, 4, 5, 12, 15, 19, 24, 26-30, 33, 37) (LINEN)
teamcadillac.ru
22818537 PANEL, FRT S/D TR (INCLS 1, 2, 4, 5, 12, 15, 19, 24, 26-30, 33, 37) (CASHMERE)
11519031 RETAINER, PUSH IN, 19.5X26.1X1.8, ACETAL, NATURAL, FOAM SEALER (PART OF 23)
11569994 BOLT, FRT S/D I/S HDL (PART OF 23) (M4.2X1.41X16) (16.115)
11519032 RETAINER, PUSH IN, 19.5X28.4X1.8, FITS HOLE 9.1, ACETAL, BLK (PART OF 23)
20928037 ABSORBER, FRT S/D OTR PNL ENGY (INCLS 32)
01605396 RETAINER, PUSH-IN, FITS .250 HOLE, .92 LG.700-OD NYLON BLACK (PART OF 31)
15952332 RETAINER, FRT S/D WAT DFL (PART OF 23) (15MM) (16.165)
11570280 NUT, FRT S/D TR PNL
11609385 NUT, U-TYPE, M6X1, 29.5 LEN, 12.5 WID, 19.5 CEN-END, 1050, GMW3359 (FRT S/D I/S HDL)
(TK16-942) 2010-2013 CK1(06-36) ОТДЕЛКА ДВЕРИ/SIDE FRONT-PASSENGER (CADILLAC Z75)
25889238 DEFLECTOR, FRT S/D WAT (PART OF 14)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 14)
11570281 NUT, FRT S/D TR PNL
15952332 RETAINER, FRT S/D WAT DFL (PART OF 14) (15MM) (16.165)
01605396 RETAINER, PUSH-IN, FITS .250 HOLE, .92 LG.700-OD NYLON BLACK (PART OF 8)
20928038 ABSORBER, FRT S/D OTR PNL ENGY (INCLS 7)
11569994 BOLT, FRT S/D I/S HDL (PART OF 14) (M4.2X1.41X16) (16.115)
11519031 RETAINER, PUSH IN, 19.5X26.1X1.8, ACETAL, NATURAL, FOAM SEALER (PART OF 14)
20954923 PANEL, FRT S/D TR (INCLS 1, 2, 6, 9-11, 13, 17, 21, 22, 29-34) (CASHMERE)
22818533 PANEL, FRT S/D TR (INCLS 1, 2, 6, 9-11, 13, 17, 21, 22, 29-34) (EBONY)
teamcadillac.ru
22818545 PANEL, FRT S/D TR (INCLS 1, 2, 6, 9-11, 13, 17, 21, 22, 29-34) (LINEN)
09425542 BULB, LAMP #168 (PART OF 16) (ACDelco #L168)
15876517 LAMP, CTSY (INCLS 12, 15) (FRT S/D)
15939208 GRILLE, RDO FRT SPKR (PART OF 14) (EBONY) (W/O CHROME RING) (9.665)
22795287 GRILLE, RDO FRT SPKR (PART OF 14) (EBONY)
22795288 GRILLE, RDO FRT SPKR (PART OF 14) (CASHMERE)
22795289 GRILLE, RDO FRT SPKR (PART OF 14) (LINEN)
25906777 COVER, FRT S/D I/S HDL BZL FIN (CASHMERE)
25897912 COVER, FRT S/D I/S HDL BZL FIN (EBONY)
25897916 COVER, FRT S/D I/S HDL BZL FIN (COCOA)
15920704 HANDLE, FRT S/D I/S (PART OF 14) (EBONY) (W/CHROME HDL)
25906817 HANDLE, FRT S/D I/S (PART OF 14) (CASHMERE)
22855634 HANDLE, FRT S/D I/S (PART OF 14) (CHROME HANDLE BEZEL)
15905945 FILLER, FRT S/D T/PNL (PART OF 14)
25857287 PANEL, FRT S/D UPR FRT TR (INCLS 24) (COCOA)
25906771 PANEL, FRT S/D UPR FRT TR (INCLS 24) (CASHMERE)
25857286 PANEL, FRT S/D UPR FRT TR (INCLS 24) (EBONY)
25870922 RETAINER, FRT S/D UPR FRT T/PNL (PART OF 25)
11562492 BOLT, FRT S/D A/RST SW MT PLT (*KIT1)
20835556 SWITCH, DR LK & SI WDO (*KIT1)
22769989 PLATE, FRT S/D ACSRY SW MT (BLACK) (*KIT1)
20922544 PLATE, FRT S/D ACSRY SW MT (MOCHA) (*KIT1)
20922543 PLATE, FRT S/D ACSRY SW MT (WALNUT) (*KIT1)
20922545 PLATE, FRT S/D ACSRY SW MT (COCOA) (*KIT1)
22968531 PLATE, FRT S/D A/RST SW MT (CRIMSON WALNUT) (*KIT1)
22968532 PLATE, FRT S/D A/RST SW MT (MOCHA WALNUT) (*KIT1)
22968533 PLATE, FRT S/D A/RST SW MT (NEW PLATINUM COCOA) (*KIT1)
10410811 CLIP, FRT S/D C/LP (*KIT1) (10.777)
11519032 RETAINER, PUSH IN, 19.5X28.4X1.8, FITS HOLE 9.1, ACETAL, BLK (PART OF 14)
15844617 KNOB, FRT S/D LKG ROD (CASHMERE)
22769989 PLATE, FRT S/D ACSRY SW MT (INCLS 25-28) (BLACK)
20922544 PLATE, FRT S/D ACSRY SW MT (INCLS 25-28) (MOCHA)
20922543 PLATE, FRT S/D ACSRY SW MT (INCLS 25-28) (WALNUT)
20922545 PLATE, FRT S/D ACSRY SW MT (INCLS 25-28) (COCOA)
(TK16-945) 2009-2013 CK107(06) ОТДЕЛКА СИДЕНЬЯ/ЗАДНЕЕ СИДЕНЬЕ #2 STRIKERS(AS3)
11515775 BOLT, HFH, M12X1.75X30, 10.9, 7114M (3RD ROW SEAT RSR LAT STKR)
15013755 STRIKER, 3RD ROW SEAT LAT CTR (LOWER)
15038813 STRIKER, 3RD ROW SEAT LAT CTR (OUTER) (INCLS UPPER & LOWER)
teamcadillac.ru
15038814 STRIKER, 3RD ROW SEAT LAT CTR (CENTER)
(TK16-949) 2010 CK1(06) СИСТЕМА СТЕКЛООЧИСТИТЕЛЯ ВЕТРОВОГО СТЕКЛА (POLICE PACKAGE PPV)(2ND DES)
teamcadillac.ru
25820729 PANEL, AIR INL GRL (INCLS 6) (BLACK)
25820730 PANEL, AIR INL GRL (INCLS 6) (BLACK)
25872303 PANEL, AIR INL GRL (CTR) (INCLS 8, 24, 27) (BLACK)
20908176 HOSE, WSWA NOZ (PART OF 7)
15248577 INDICATOR, WSWA SOLV LVL (W/23MM DIAMETER LEVEL INDICATOR) (*KIT2)
15248578 GROMMET, WSWA SOLV CNTNR (*KIT1, KIT2)
15927514 GROMMET, WSWA PUMP (PUMP GROMMET) (*KIT1, KIT3) (ACDelco #15927514)
10150076 CLIP, WSWA NOZ HOSE (CLIP TO RET THE COWL HOSE IN THE FENDER) (18.8 MM DIA) (ROUND CLIP) (3.425)
15200240 WEATHERSTRIP, HOOD RR (PART OF 7)
15048061 RETAINER, AIR INL GRL PNL (PART OF 7) (PUSH IN)
20999340 CONTAINER KIT, WSWA SOLV (INCLS 13, 16, 17) (USE T/W 20999338 WHEN REPLACING 15248577, 15213911 OR 15942522.)
20999338 INDICATOR KIT, WSWA SOLV LVL (INCLS 15, 16) (LEVEL SENSOR KIT W/GROMMET) (KIT HAS 16MM DIAM LVL SENSOR) (ACDelco #20999338) (USE T/W 20999340 WHEN REPLACING 15248577, 15213911 OR 15942522.)
15942524 PUMP KIT, WSWA W/SEAL (INCLS 17-19) (RR PUMP KIT W/GROMMET) (ACDelco #15942524)
15942523 PUMP KIT, WSWA W/SEAL (INCLS 17-19) (FRT PUMP KIT W/GROMMET) (ACDelco #15942523)
(TK16-950) 2010-2013 CK1,2(06) СИСТЕМА СТЕКЛООЧИСТИТЕЛЯ ВЕТРОВОГО СТЕКЛА (EXC POLICE PACKAGE PPV)
25879116 ARM, WSW (W/NOZZLE & HOSE)
25879117 ARM, WSW (W/NOZZLE & HOSE)
15788727 CAP, WSW ARM FIN (10.147)
teamcadillac.ru
25872303 PANEL, AIR INL GRL (CTR) (INCLS 7, 23, 27) (BLACK)
20908176 HOSE, WSWA NOZ (PART OF 6)
11609989 BOLT, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (WSWA SOLV CNTNR)
15200240 WEATHERSTRIP, HOOD RR (PART OF 6)
11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (AIR INL GRL PNL)
12368668 WIPER, W/S (PART OF 26) (REFILL) (USED TO SERVICE 15214346 BLADE ASM)
22793882 BLADE, WSW (INCLS 25) (CONVENTIONAL BLADE)
15048061 RETAINER, AIR INL GRL PNL (PART OF 6) (PUSH IN)
20999340 CONTAINER KIT, WSWA SOLV (INCLS 12, 15, 16) (USE T/W 20999338 WHEN REPLACING 15248577, 15213911 OR 15942522.)
20999338 INDICATOR KIT, WSWA SOLV LVL (INCLS 14, 15) (LEVEL SENSOR KIT W/GROMMET) (KIT HAS 16MM DIAM LVL SENSOR) (ACDelco #20999338) (USE T/W 20999340 WHEN REPLACING 15248577, 15213911 OR 15942522.)
15942524 PUMP KIT, WSWA W/SEAL (INCLS 16-18) (RR PUMP KIT W/GROMMET) (ACDelco #15942524)
15942523 PUMP KIT, WSWA W/SEAL (INCLS 16-18) (FRT PUMP KIT W/GROMMET) (ACDelco #15942523)
(TK16-952) 2009-2013 CK107(06) ОТДЕЛКА ДВЕРИ/SIDE REAR (CADILLAC Z75)
11571164 NUT, RR S/D I/S HDL (16.545)
22778726 DEFLECTOR, RR S/D WAT (PART OF 14)
22778727 DEFLECTOR, RR S/D WAT (PART OF 14)
15844620 KNOB, RR S/D LKG ROD (COCOA)
20785356 KNOB, RR S/D LKG ROD (CASHMERE)
15844616 KNOB, RR S/D LKG ROD (EBONY)
15905947 BOLT, RR S/D T/PNL (PART OF 14)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (RR S/D ACSRY SW MT PLT)
25948861 BEZEL, RR S/D WDO SW (PLATINUM COCOA)
25948862 BEZEL, RR S/D WDO SW (PLATINUM COCOA)
25873126 BEZEL, RR S/D WDO SW (CRIMSON WALNUT)
25873127 BEZEL, RR S/D WDO SW (MOCHA WALNUT)
25873128 BEZEL, RR S/D WDO SW (CRIMSON WALNUT)
25873129 BEZEL, RR S/D WDO SW (MOCHA WALNUT)
22895547 SWITCH, RR S/D WDO
25906817 HANDLE, RR S/D I/S (PART OF 14) (CASHMERE)
25906822 HANDLE, RR S/D I/S (PART OF 14) (CASHMERE)
25815293 HANDLE, RR S/D I/S (PART OF 14) (CHROME HANDLE BEZEL)
15920683 HANDLE, RR S/D I/S (PART OF 14) (EBONY) (W/CHROME HDL)
15920704 HANDLE, RR S/D I/S (PART OF 14) (EBONY) (W/CHROME HDL)
22855634 HANDLE, RR S/D I/S (PART OF 14) (CHROME HANDLE BEZEL)
25906776 COVER, RR S/D I/S HDL BZL FIN (CASHMERE)
25906777 COVER, RR S/D I/S HDL BZL FIN (CASHMERE)
25897910 COVER, RR S/D I/S HDL BZL FIN (COCOA)
25897906 COVER, RR S/D I/S HDL BZL FIN (EBONY)
25897916 COVER, RR S/D I/S HDL BZL FIN (COCOA)
25897912 COVER, RR S/D I/S HDL BZL FIN (EBONY)
11570136 BOLT, HEX HD, W/CON SPR WA, M6X1X23, 14 THD, 17 O.D., 8.8, GMW3359 (RR S/D T/PNL)
15214092 COVER, RR S/D T/PNL (CASHMERE)
teamcadillac.ru
15214095 COVER, RR S/D T/PNL (CASHMERE)
15214091 COVER, RR S/D T/PNL (EBONY)
15214094 COVER, RR S/D T/PNL (EBONY)
25815660 COVER, RR S/D T/PNL (LINEN)
25815661 COVER, RR S/D T/PNL (LINEN)
20809068 PANEL, RR S/D TR (INCLS 2, 3, 5, 6, 10, 15, 16, 19) (LINEN)
20809072 PANEL, RR S/D TR (INCLS 2, 3, 5, 6, 10, 15, 16, 19) (LINEN)
20919794 PANEL, RR S/D TR (INCLS 2, 3, 5, 6, 10, 15, 16, 19) (CASHMERE)
20919796 PANEL, RR S/D TR (INCLS 2, 3, 5, 6, 10, 15, 16, 19) (EBONY)
20919793 PANEL, RR S/D TR (INCLS 2, 3, 5, 6, 10, 15, 16, 19) (EBONY)
20919797 PANEL, RR S/D TR (INCLS 2, 3, 5, 6, 10, 15, 16, 19) (CASHMERE)
11609385 NUT, U-TYPE, M6X1, 29.5 LEN, 12.5 WID, 19.5 CEN-END, 1050, GMW3359 (RR S/D T/PNL)
15952332 RETAINER, RR S/D WAT DFL (PART OF 14) (15MM)
(TK16-961) 2010-2013 CK107(06) СИСТЕМА ПОДУШЕК БЕЗОПАСНОСТИ/ROOF SIDE (SEAT THIRD ROW DELETE ATD)
25897886 AIRBAG, RF S/RL (INCLS 3, 5, 6) (1ST & 2ND ROW)
25897887 AIRBAG, RF S/RL (INCLS 3, 5, 6) (1ST & 2ND ROW)
teamcadillac.ru
11609939 BOLT, R/RL AIRBAG (M6X1X30, 21 THD, 17 OD) (8.977)
11562053 BOLT, R/RL AIRBAG (PART OF 1) (M6X1X23 18THD 19OD)
11609939 BOLT, R/RL AIRBAG (PART OF 1) (M6X1X30, 21 THD, 17 OD) (8.977)
20884470 SENSOR, AIRBAG SI IMP
(TK16-962) 2010-2013 CK107(06) СИСТЕМА ПОДУШЕК БЕЗОПАСНОСТИ/ROOF SIDE (REAR SEAT #2 AS3)
20955122 AIRBAG, RF S/RL (INCLS 2-4, 6) (1ST, 2ND, & 3RD ROW)
20955123 AIRBAG, RF S/RL (INCLS 2-4, 6) (1ST, 2ND, & 3RD ROW)
teamcadillac.ru
(TK16-994) 2007-2013 CK107(06) ЗАГЛУШКИ/КУЗОВ
15908858 PLUG, FLR PNL DRN HOLE (38.1 MM) (12.980)
25820734 PLUG, INTER FLR PNL ACC HOLE RR
teamcadillac.ru
15865167 INSULATOR, BODY SI INR PNL HOLE CVR (ACOUSTICAL FIBER/C-PILLAR)
15917242 INSULATOR, BODY SI INR PNL HOLE CVR
15043000 PLUG, R/CMPT SILL TR PLT HOLE (38.0 X 17.0 X 18.0MM) (OBLONG) (16.600)
15908858 PLUG, BODY SI INR LWR PNL HOLE (38.1 MM) (12.980)
10124752 PLUG, BODY SI INR LWR PNL HOLE (BLACK) (RUBBER) (FITS 30 X 18 MM OVAL HOLE) (12.966)
21110669 PLUG, RKR INR PNL HOLE (35 MM DIA) (FITS HOLE 25MM) (ROUND) (12.179)
20895614 PLUG, RKR INR PNL HOLE (48 X 8 X 35) (12.243)
15742557 PLUG, INTER FLR PNL ACC HOLE FRT (71.0 X 96.0 MM) (WELD ACCESS)
15895064 COVER, PLNM UPR PNL OPG
(TX16-004) 2007-2013 CK1,2,3 РЕМНИ БЕЗОПАСНОСТИ (EXTENSION KIT)
89024296 EXTENSION KIT, F/SEAT BELT (BLACK) (9") (14.875) (REFER TO GMSPO INFORMATION BULLETIN ON SEAT BELT EXTENDERS FOR DETAILED INFORMATION)
teamcadillac.ru
89024297 EXTENSION KIT, R/SEAT BELT (BLACK) (15") (14.875) (REFER TO GMSPO INFORMATION BULLETIN ON SEAT BELT EXTENDERS FOR DETAILED INFORMATION)
89024296 EXTENSION KIT, R/SEAT BELT (BLACK) (9") (14.875) (REFER TO GMSPO INFORMATION BULLETIN ON SEAT BELT EXTENDERS FOR DETAILED INFORMATION)
89024297 EXTENSION KIT, F/SEAT BELT (BLACK) (15") (14.875) (REFER TO GMSPO INFORMATION BULLETIN ON SEAT BELT EXTENDERS FOR DETAILED INFORMATION)
17 - ЗАДНЯЯ ЧАСТЬ КУЗОВА-МОЛДИНГИ И ОТДЕЛКА-ГРУЗОВОЙ ОТСЕК
(TC17-744) 2007-2013 CK107(06) БАГАЖНИК (CADILLAC Z75, V54)
15838222 RAIL, LUGG CARR CR (BLACK)
11518684 NUT, LUGG CARR SUPT (M6X1X16) (HEX CHROME FREE FINISH)
15916756 PLATE, LUGG CARR S/RL BRKT ANC
11609900 SCREW, PAN WASH, M6X1X39, 31 THD, 12.25 OD, 8.8, GMW4700, TORX, MACH, 'P'POI (LUGG CARR SUPT)
25892761 RAIL, LUGG CARR SI (CHROMED SS)
25996376 RAIL, LUGG CARR SI (CHROMED SS)
11570521 RETAINER, LUGG CARR S/RL FIN CVR (PUSH IN) (*KIT2, KIT3)
25832915 COVER KIT, LUGG CARR S/RL ACC HOLE RR (INCLS 2, 8) (INCLS PAINT TO MATCH CVR 25787589)
25832914 COVER KIT, LUGG CARR S/RL ACC HOLE RR (INCLS 2, 8) (INCLS PAINT TO MATCH CVR 25787590)
25832916 COVER KIT, LUGG CARR S/RL ACC HOLE FRT (INCLS 7, 8) (PAINT TO MATCH)
25832917 COVER KIT, LUGG CARR S/RL ACC HOLE FRT (INCLS 7, 8) (PAINT TO MATCH)
(TC17-909) 2007-2013 CK1(06) ФУРНИТУРА ЗАДНЕЙ ОТКИДНОЙ ДВЕРИ PART 1 (CADILLAC Z75)
25970601 APPLIQUE, Q/PNL UPR (PAINT TO MATCH)
11610510 NUT, PUSH-IN, M4.2X1.41, 0.7-2.15 PNL THK, SAE 1050-65, GMW3359 W/BLK SEAL (Q/PNL UPR APLQ)
11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (Q/PNL UPR APLQ)
25916023 WINDOW, L/GATE (INCLS 25, 26)
25916024 WINDOW, L/GATE (INCLS 25, 26)
25949077 WEATHERSTRIP, L/GATE WDO
25867975 GATE, LIFT
15038385 BUMPER, L/GATE WDO
11562471 STUD, L/GATE STRUT BALL (L/GATE SI) (8.015)
15161943 STRUT, L/GATE WDO
15161944 STRUT, L/GATE WDO
15875510 HINGE, L/GATE
11519388 BOLT, HX HD CON WA, M8X1.25X25, 20 THD, 24 OD, 8.8, GMW3359 (SILVER), M-POINT (L/GATE HGE (L/GATE SI))
11609341 SCREW, RD WA HD M6X1X19, 13.55 THD, 16 OD, 10.9, GMW4205, W/ADH GM6175M, MATPT (L/GATE STRUT BRKT (L/GATE SI))
15891962 BRACKET, L/GATE STRUT (L/GATE SI)
11518445 SCREW, FLAT-HD HEX ALLEN, CSINK, M8X1.25X25, 18.05 THD, 14.7 OD, 8.8, GMW3044. (L/GATE LK STKR)
teamcadillac.ru
15134851 STRIKER, L/GATE LK
15827433 STRUT, L/GATE
22743451 STRUT, L/GATE
15892254 BUMPER, L/GATE
25970600 APPLIQUE, Q/PNL UPR (PAINT TO MATCH)
15816854 VALVE, BK BODY OPG FRM PRESS RLF
11561717 STUD, L/GATE STRUT (BODY SI) (M8X1.25X25) (STAINLESS STEEL)
11514519 NUT, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (L/GATE HGE (BODY SI))
22775503 WEATHERSTRIP, L/GATE
11610075 RING, FOR 6MM DIA SHAFT, SS (L/GATE HGE PIN)
22845014 WEATHERSTRIP, L/GATE UPR
22782015 TAPE, L/GATE ADJ BPR PAD
15273470 HANDLE, L/GATE WDO O/S (PART OF 4)
25916031 TERMINAL, R/WDO DEFG WIRE (PART OF 4) (2.480)
(TC17-911) 2007-2013 CK1(06) ФУРНИТУРА ЗАДНЕЙ ОТКИДНОЙ ДВЕРИ PART 2 (CADILLAC Z75)
15270012 SEAL, E/GATE CTR MLDG (PART OF 3)
11561972 BOLT, L/GATE APLQ (PART OF 3) (6 X 1 X 21)
25970660 APPLIQUE, L/GATE UPR (W/O HIGH MT S/LP #25779085, NUT #11609411, & WIRE HARNESS #15857136) (INCLS 1, 2) (PAINT TO MATCH)
25779085 LAMP, HIGH MT STOP (INCLS CZ2 STAMP)
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (HIGH MT S/LP)
15857136 WIRE, HIGH MT S/LP
11508277 NUT, HEX W/CON WA M6X1 THD, OD-19 PEOR 9 (L/GATE APLQ)
11569914 NUT, RR LIC PLT (SINGLE NUT) (EXCLS SEAL)
15106857 SWITCH, L/GATE REL (PART OF 11) (ACDelco #D1499F)
25838218 HANDLE, L/GATE O/S (INCLS 10, 12-14) (PAINT TO MATCH)
12335645 GASKET, L/GATE WDO O/S HDL (PART OF 11) (7.800)
25601643 NUT, HEX W/CON WA, M6X1X5.6, 24 OD, 9, ZF (L/GATE O/S HDL) (8.917)
15101589 PLUG, L/GATE INR PNL DRN HOLE (FITS HOLE SIZE 22 MM) (W/SPRING CLIP)
21110669 PLUG, L/GATE WRG HARN HOLE (35 MM DIA) (FITS HOLE 25MM) (ROUND) (12.179)
15259076 PLUG, L/GATE SEN ATCH HOLE (6.35MM) (ROUND) (10.571)
11562290 BOLT, L/GATE APLQ (M6X1X28) (26 OD, 9.8)
25886854 LATCH, L/GATE WDO (INCLS 22) (REFER TO BULLETIN 07-08-66-005A WHEN REPLACING LATCH W/ BRKT)
11589327 BOLT, L/GATE WDO LAT (PART OF 21) (M6X1X18)
11609341 SCREW, RD WA HD M6X1X19, 13.55 THD, 16 OD, 10.9, GMW4205, W/ADH GM6175M, MATPT (L/GATE LK)
13501871 LOCK, L/GATE (PO KIT ASM W/ACTUATOR) (12.242)
13581405 LOCK, L/GATE (12.242)
teamcadillac.ru
(TC17-918) 2007-2013 CK1,2(06) ФУРНИТУРА ЗАДНЕЙ ОТКИДНОЙ ДВЕРИ PART 4 ACTUATOR SYSTEM (POWER LIFTGATE E61)
25882453 MOTOR, L/GATE CLOSE ACTR (INCLS 2) (PART OF 4) (HIGH FREQUENCY) (12.243)
11562045 BOLT, L/GATE CLOSE ACTR MOT (PART OF 1, 4)
25778508 SENSOR, L/GATE SI (ANTI-PINCH) (W/RETAINERS)
22840998 SENSOR, L/GATE SI (ANTI-PINCH) (W/RETAINERS)
20821239 MODULE, L/GATE CLOSE ACTR MOT CONT (INCLS 1, 2, 5-8)
15299399 SWITCH, L/GATE ACTR (INCLS 6) (PART OF 4) (12.243) (ACDelco #15299399)
11562045 BOLT, L/GATE CLOSE ACTR MOT (PART OF 4)
teamcadillac.ru
15810321 BRACKET, L/GATE CLOSE ACTR (PART OF 4)
15836293 ROD, L/GATE ACTR
20821156 MODULE, ACSRY & L/GATE CONT (REQUIRES SOFTWARE PROGRAM AND CALIBRATION) (12.243)
11609410 BOLT, HFH, M8X1.25X25, 10.9, GMW3179 (L/GATE CLOSE ACTR) (0.056)
15173772 BRACKET, L/GATE ACTR ROD
11609341 SCREW, RD WA HD M6X1X19, 13.55 THD, 16 OD, 10.9, GMW4205, W/ADH GM6175M, MATPT (L/GATE ACTR ROD BRKT)
(TC17-958) 2009-2013 K107(06) FLARE/BODYSIDE (CADILLAC Z75, EXPORT PACKAGE VD1)
20758458 EXTENSION, RR W/H PNL (*KIT1)
teamcadillac.ru
20758459 EXTENSION, RR W/H PNL (*KIT1)
24501057 RETAINER, F/FDR EXTN (PUSH-IN) (6.9 HOLE DIA) (19MM LG) (*KIT1) (1.840)
20758461 EXTENSION, F/FDR (*KIT1)
20758462 EXTENSION, F/FDR (*KIT1)
20758463 PARTS, MISC BODY (VENDOR INSTALLED) (INCLS 1-4)
(TC17-959) 2009-2010 CK107(06) ДЕКАЛИ (CADILLAC Z75, HYBRID HP2)
25940046 DECAL, R/WDO NA (GUNMETAL) (HYBRID)
25975557 DECAL, FRT S/D LWR (GUNMETAL) (HYBRID)
25975558 DECAL, FRT S/D LWR (GUNMETAL) (HYBRID)
25975559 DECAL, FRT S/D LWR (SILVER) (HYBRID)
25975560 DECAL, FRT S/D LWR (SILVER) (HYBRID)
25940046 DECAL, W/S NA (GUNMETAL) (HYBRID) (16.475)
(TC17-962) 2009-2011 CK1(06) ФУРНИТУРА ЗАДНЕЙ ОТКИДНОЙ ДВЕРИ PART 3 CENTER APPLIQUE (CADILLAC Z75, REAR VIEW CAMERA UVC)
22777526 APPLIQUE, L/GATE CTR (INCLS 4, 6-11, 13, 14, 16, 17, 19) (CHROME) (INCLS CAMERA)
15798062 SWITCH, L/GATE WDO REL (ACDelco #D1994E)
20823396 EMBLEM, L/GATE (PART OF 2) (WREATH/CREST)
25778786 LAMP, RR LIC PLT
teamcadillac.ru
11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (RR LIC PLT LP LENS)
11562334 RETAINER, L/GATE CTR APLQ (INCLS 16) (PART OF 2)
13500812 BULB, RR LIC PLT LP (TRADE #W5WLL) (ACDelco #13500812)
(TC17-965) 2010-2013 CK107(06) NAMEPLATES (CADILLAC Z75)
20823396 EMBLEM, L/GATE (WREATH/CREST)
20903638 PLATE, L/GATE ENG NA (HYBRID 2-MODE)
15162148 EMBLEM, L/GATE (ESCALADE)
15102283 PLATE, E/GATE VEH NA (CHROME) (PLATINUM)
20900865 PLATE, E/GATE VEH NA (HYBRID - LRG) (8.147)
20903652 EMBLEM, L/GATE (GREEN) (FLEX FUEL E85 ETHANOL) (LARGE CURVED) (12.182)
20903627 PLATE, E/GATE VEH NA (GREEN) (FLEX POWER E85 ETHANOL)
25940049 PLATE, BODY SI NA ("H") (17.507)
teamcadillac.ru
15162148 PLATE, FRT S/D VEH NA (ESCALADE) (17.215)
(TC17-983) 2010-2013 CK1(06) ОТДЕЛКА ДВЕРИ БАГАЖНИКА (CADILLAC Z75)
15936906 MOLDING, L/GATE WDO UPR GARN (INCLS 2, 3) (LINEN)
20986936 MOLDING, L/GATE WDO UPR GARN (INCLS 2, 3) (CASHMERE)
teamcadillac.ru
20986937 MOLDING, L/GATE WDO UPR GARN (INCLS 2, 3) (TITANIUM)
20986938 MOLDING, L/GATE WDO UPR GARN (INCLS 2, 3) (EBONY)
11561654 RETAINER, L/GATE WDO UPR G/MLDG (PART OF 1) (PLAIN) (BIRD'S BEAK SINGLE) (FITS 8.5 DIA HOLE) (12.800)
11609242 NUT, L/GATE TR FIN PNL (M6X1, 18X17X14.3)
11561654 CLIP, L/GATE TR FIN PNL (PART OF 9) (PLAIN) (BIRD'S BEAK SINGLE) (FITS 8.5 DIA HOLE) (12.800)
15952904 HANDLE, L/GATE I/S PULL (PART OF 9) (LINEN)
15952901 HANDLE, L/GATE I/S PULL (PART OF 9) (TITANIUM)
15952900 HANDLE, L/GATE I/S PULL (PART OF 9) (EBONY)
15952902 HANDLE, L/GATE I/S PULL (PART OF 9) (CASHMERE)
11518329 SCREW, TORX PAN HD, W/WA, M6X1X25, 18 THD, 15 OD, 9.8, 6138M, TORX (L/GATE TR FIN PNL)
20986839 PANEL, L/GATE TR FIN (INCLS 4, 6, 7, 10) (TITANIUM) (NO LONGER INCLS PULL STRAP)
20986837 PANEL, L/GATE TR FIN (INCLS 4, 6, 7, 10) (LINEN) (NO LONGER INCLS PULL STRAP)
20986838 PANEL, L/GATE TR FIN (INCLS 4, 6, 7, 10) (CASHMERE) (NO LONGER INCLS PULL STRAP)
20986840 PANEL, L/GATE TR FIN (INCLS 4, 6, 7, 10) (EBONY) (NO LONGER INCLS PULL STRAP)
15211504 SWITCH, L/GATE ACTR (PART OF 9) (PART OF LIFT GATE PNL)
15120856 RETAINER, L/GATE WDO UPR G/MLDG (BLACK) (8.141)
20986931 PLUG, L/GATE TR FIN PNL HOLE (CASHMERE)
20986934 PLUG, L/GATE TR FIN PNL HOLE (LINEN)
20986933 PLUG, L/GATE TR FIN PNL HOLE (EBONY)
20986932 PLUG, L/GATE TR FIN PNL HOLE (TITANIUM)
(TC17-985) 2009-2013 CK1(06) МОЛДИНГИ (CADILLAC Z75)
20772075 MOLDING, FRT S/D WDO RVL (INCLS 2, 3) (W/RUN CHANNEL)
20772074 MOLDING, FRT S/D WDO RVL (INCLS 2, 3) (W/RUN CHANNEL)
25895275 CLIP, FRT S/D MLDG (PART OF 1, 4)
15286992 CLIP, FRT S/D MLDG (PART OF 1, 4) (12X10.7X7.4, 0.71-1.50 THK PNL, SAE 1050 STL, GMW3200) (10.352)
20772079 MOLDING, RR S/D WDO RVL (INCLS 2, 3)
20772078 MOLDING, RR S/D WDO RVL (INCLS 2, 3)
22743309 MOLDING, RF PNL JT FIN (20MM SHORTER THAN OE PART)
teamcadillac.ru
11609457 SCREW, ROUNDWA, M4.2X1.41X20, 14.1 THD, 11.35 OD, 6010M, GMW4205, TAP, (Q/PNL UPR APLQ)
15876401 MOLDING, RR S/D (CHROME)
15876402 MOLDING, RR S/D (CHROME)
15876405 MOLDING, FRT S/D (CHROME)
15876406 MOLDING, FRT S/D (CHROME)
15860253 INSERT, F/FDR CTR RR UPR MLDG (CHROME)
15860254 INSERT, F/FDR CTR RR UPR MLDG (CHROME)
25963661 PLATE, F/FDR FRT NA (PART OF 13)
25961847 ORNAMENT, F/FDR (INCLS 12) (CHROME)
25961848 ORNAMENT, F/FDR (INCLS 12) (CHROME)
21 - ДОПОЛНИТЕЛЬНОЕ ОБОРУДОВАНИЕ-АКСЕССУАРЫ
(1L21-014) 2007-2011 CK1,2,3 DVD ПЛЕЕР/ПОДГОЛОВНИК
19156228 PLAYER, VIDEO (W/VIDEO DISPLAY) (DVD PLAYER AND DVD DISPLAY) (ELECTRONICS ARE PRE-PROGRAMMED WITH CADILLAC LOGO SPLASH SCREEN) (HEADREST NOT INCL) (ELECTRONICS ONLY) (INSTALL .10) (0.69 KGS) (9.680)
19213544 RESTRAINT PKG, R/SEAT ENTERTAINMENT HD (W/O VIDEO DISPLAY) (CASHMERE) (INSTALL .20) (1.5 KGS) (LEATHER) (9.680) (FOR VEH BUILT W/H/RST W/ADDITIONAL SEWN SEAM APPROX 50MM FWD OF SEAM B/W POSTS) (FOR 2ND DES SEE 19244279)
22840199 PLAYER, VIDEO (W/VIDEO DISPLAY) (DVD PLAYER AND DVD DISPLAY, ELECTRONICS ARE PRE-PROGRAMMED WITH CADILLAC LOGO SPLASH SCREEN, HEADREST IS NOT INCLUDED, ELECTRONICS ONLY) (9.680)
(AC21-057) 2007-2013 CK1,2,3 CARRIER PKG/SKI (HITCH MOUNTED)(THULE)
19257870 CARRIER, SKI (HITCH MT) (FOR VEH'S W/REC HITCH) (7.068)
(AC21-064) 2007-2013 CK1,2,3 DVD PLAYER-SERVICE PARTS
teamcadillac.ru
19156570 HEADREST, DRVR SI (W/O VIDEO DISPLAY) (EBONY) (LEATHER W/VINYL SIDES) (9.680) (FOR VEH BUILT W/H/RST W/ADDITIONAL SEWN SEAM APPROX 50MM FWD OF SEAM B/W POSTS) (FOR 2ND DES SEE 19244281)
19213547 HEADREST, PASS SI (W/O VIDEO DISPLAY) (EBONY) (INSTALL .20) (1.5 KGS) (LEATHER) (9.680) (FOR VEH BUILT W/H/RST W/ADDITIONAL SEWN SEAM APPROX 50MM FWD OF SEAMB/W POSTS) (FOR 2ND DES SEE 19244282)
19244304 MODULE, AUDIO/VIDEO INTERFACE (0.13 KGS) (DUAL DVD CONTROL METAL BOX) (9.680)
19245159 RETAINER, ACSRY WRG HARN (9.680)
19159658 CABLE KIT, AUDIO & VIDEO MDL (0.32 KGS) (INCLS CABLES 3A & 3B USED TO CONN HD RESTS TO CTRL BOX) (0.029)
19132011 CONTROL, VIDEO REM (INCLS 9) (0.09KGS) (W/ROW OF FUNC BUTN LBL AUTO MEM, SEARCH/SKIP, ERASE/ADD, R-S) (9.680) (REMOTE WILL ONLY OPERATE WITH GMSPO DVD HEADREST SYSTEMS)
22797471 CONTROL, VIDEO REM (INCLS 9) (W/O ROW OF FUNC BUTN LBL AUTO MEM, SEARCH/SKIP, ERASE/ADD, R-S) (9.680) (ACDelco #22797471) (REMOTE WILL ONLY OPERATE WITH GMSPO DVD HEADREST SYSTEMS)
19165593 HARNESS, AUDIO PLYR WRG (INCLS DVD JUMPER HARN & POWER CORD #9) (9.680)
(AC21-548) 2007-2013 CK1,2,3 ROADSIDE ASSISTANCE PKG/ROLL-UP
88960625 ROADSIDE PKG, ACSRY MISC (INCLS BUNGEE CORDS, FLASHLIGHT, FUSE KIT, GLOVES, PLIERS, TAPE, RAG, PONCHO, SCREWDRIVER W/BITS, TIRE GAUGE, & BAG) (1.26KGS) (ROLL-UP) (8.808)
(AC21-560) 2007-2013 CK1,2 LOCK PKG/WHEEL
17801711 NUT PKG, SPL SECURITY WHL LK (CHROME) (INSTALL .10) (0.29 KGS) (INCLS 20 NUTS, 4 LOCKING NUTS, 1 KEY) (M14X1.5) (5.813) (PREFERRED USE ON WHLS W/EXPOSED LUGS & W/O NEED TO RETAIN A WHL CAP/COVER) (FOR USE W/20" & 22" SPO ACSRY WHL)
17801712 NUT PKG, SPL SECURITY WHL LK (CHROME) (INSTALL .10) (SINGLE 0.29KGS) (INCLS 4 PACK OF 17801711) (M14X1.5) (5.813) (FOR USE WITH 20" SPO ACCESSORY WHEELS) (PREFERRED USE ON WHLS W/EXPOSED LUGS & W/O NEED TO RETAIN A WHL CAP/COVER)
12498075 LOCK PKG, SPL SECURITY WHL (NON-DECORATIVE) (INSTALL .10) (SINGLE 0.6KGS) (W/HEX FREE COATING) (4 NUTS & KEY) (M14X1.5 W/EXT THD) (5.875)
teamcadillac.ru
12498082 LOCK PKG, SPL SECURITY WHL (INSTALL .10) (SINGLE 0.6KGS) (W/HEX FREE COATING) (10 PC QTY OF 12498075) (M14X1.5 W/EXT THD) (5.875)
17802466 LOCK PKG, SPL SECURITY WHL (DECORATIVE) (CHROME) (INSTALL .10) (SINGLE 0.5 KGS) (W/HEX FREE COATING) (INCLS 4 LOCKING NUTS, 1 KEY) (M14X1.5 THD) (5.875) (PREFERED USE ON WHLS W/EXPOSED LUGS & W/O NEED TO RETAIN A WHL CAP/COVER)
12498076 LOCK PKG, SPL SECURITY WHL (NON-DECORATIVE) (INSTALL .10) (SINGLE 0.5KGS) (W/HEX FREE COATING) (4 NUTS & KEY) (M14X1.5 W/O EXT THD) (5.875)
(AC21-583) 2007-2013 CK1,2,3 ADAPTER PKG/TRAILER HARNESS (7-PIN TO 4-PIN ADAP)
12496599 ADAPTER PKG, TRLR WRG HARN RCPT (0.1 KGS) (CONVERTS HVY DUTY 7 PIN RND TO LGT DUTY 4 PIN FLAT) (7.068)
(AC21-589) 2007-2013 CK1,2,3 ADAPTER PKG/TRAILER HARNESS (7-PIN TO PWR ADAP)
12497781 ADAPTER PKG, TRLR WRG HARN RCPT (0.1 KGS) (7 TO 12V AUX ADAPTER) (7.068)
(AC21-667) 2007-2011 CK1,2,3 LOCK PKG/HITCH
12499511 PIN PKG, TRLR HITCH DRAW BAR (INSTALL .10) (0.4KGS) (REQ 2" HITCH PKG) (7.068)
88966128 KEY, TRLR HITCH THEFT DTRNT LK (#08) (INCLS 2 KEYS) (17.070) (**VPI 1-877-846-8243)
88966129 KEY, TRLR HITCH THEFT DTRNT LK (#09) (INCLS 2 KEYS) (17.070)
88963077 KEY, TRLR HITCH THEFT DTRNT LK (#01) (INCLS 2 KEYS) (12.815)
88966122 KEY, TRLR HITCH THEFT DTRNT LK (#02) (INCLS 2 KEYS) (17.070)
88966123 KEY, TRLR HITCH THEFT DTRNT LK (#03) (INCLS 2 KEYS) (17.070)
88966124 KEY, TRLR HITCH THEFT DTRNT LK (#04) (INCLS 2 KEYS) (17.070)
88966125 KEY, TRLR HITCH THEFT DTRNT LK (#05) (INCLS 2 KEYS) (17.070)
88966126 KEY, TRLR HITCH THEFT DTRNT LK (#06) (INCLS 2 KEYS) (17.070)
teamcadillac.ru
88966127 KEY, TRLR HITCH THEFT DTRNT LK (#07) (INCLS 2 KEYS) (17.070)
88966130 KEY, TRLR HITCH THEFT DTRNT LK (#00) (INCLS 2 KEYS) (17.070)
17800049 NUT PKG, TRLR HITCH DRAW BAR PIN (7.068) (SERV CMP OF PIN PKG 12499511)
(AC21-671) 2007-2013 CK1,2,3 FIRST AID PKG
12498312 MEDICAL PKG, 1ST AID (360 PC QTY OF 88960626) (8.808)
teamcadillac.ru
88960626 MEDICAL PKG, 1ST AID (BLACK) (0.19KGS) (WHITE GM BLOCK LOGO) (VINYL) (8.808)
(AC21-672) 2007-2013 CK1,2,3 CARRIER PKG/BICYCLE (WALL MOUNT)
teamcadillac.ru
12499175 HANGER PKG, BICYCLE CARR (WALL MOUNT) (6.35KGS) (INCLS BRKT, PLT & HDW) (REQ'S HITCH MTD BIKE CARR) (17.070)
(AC21-693) 2007-2013 CK1,2,3 MAT PKG/REAR FLOOR CARPET(MOLDED EDGE)
teamcadillac.ru
17800413 MAT PKG, REAR CARPET (MOLDED EDGE) (EBONY) (1.45KGS) (1 PC) (NO LOGO) (16.800)
17800414 MAT PKG, REAR CARPET (MOLDED EDGE) (CASHMERE) (1.45KGS) (1 PC) (NO LOGO) (16.800)
(AC21-736) 2007-2013 CK1,2(06-36) CARRIER PKG/HARD SHELL (LONG)
teamcadillac.ru
12499318 CONTAINER PKG, LUGG CARR STOW (CROSSRAILS REQUIRED) (HOLDS 5 PR OF SKIS) (BLACK) (INSTALL .50) (10.43 KGS) (TEXTURED) (LONG) (W/GM-THULE LOGO) (INCLS LK CYL) (89"LX21"WX15"H) (17.070)
12462636 LOCK PKG, LUGG CARR (0.050 KGS) (W/KEYS) (12.815) (SERV CMP OF CONTAINER PKGS 12499318-19)
(AC21-781) 2007-2013 CK1,2(06-36) CARRIER PKG/HARD SHELL (SHORT)
19243882 CONTAINER PKG, LUGG CARR STOW (CROSSRAILS REQUIRED) (BLACK) (INSTALL .50) (11.34 KGS) (TEXTURED) (GM/THULE LOGO) (56"L X 36"W X 15"H) (12.815)
(AC21-803) 2007-2013 CK1,2,3 CARRIER PKG/SKI (HITCH MOUNT)(SOFTRIDE)
88963077 KEY, SKI CARR LK (#01) (INCLS 2 KEYS) (12.815)
(AC21-824) 2007-2013 CK1 ACCESSORY PKG/TIRE
19107491 TIRE, P275/55R20-111S AL2 TL BW (18.6 KGS) (INSTALL .10) (INSTALL .25) (SINGLE 18.4KGS) (GOODYEAR, EAGLE LS2, 275/55R20) (5.880) (ACDelco #LU069165)
19143998 TIRE, P285/45R22-110H AL2 TL BW (18.6 KGS) (INSTALL .10) (INSTALL .25) (SINGLE 19.3KGS) (BRIDGESTONE, DUELER H/L ALENZA, P285/45R22, BW110H) (5.880) (ACDelco #FB053984)
19145377 TIRE, P275/55R20-111S AL2 TL BW (19.5 KGS) (INSTALL .10) (INSTALL .25) (SINGLE 19.5KGS) (BRIDGESTONE, DUELER H/L ALENZA W/UNI-T, P275/55R20, BL, 111S) (5.880) (ACDelco #FB053967)
teamcadillac.ru
19185719 TIRE, 285/45R22-114H XL AL3 BW (INSTALL .10) (SINGLE 17.2KGS) (TIRE, GOODYEAR_FORTERA SL_285/45R22_VSB114H) (5.880) (ACDelco #KY621163)
19190768 TIRE, P285/45R22-110H AT BW (USA&CANADA TIRE PROGRAM) (INSTALL .10) (20.6 KGS) (TIRE, BRIDGESTONE_DUELER A/T RH-S_P285/45R22_BW110H) (5.880) (ACDelco #FB107942)
89049423 TIRE, P265/70R17-113S OOR TL BW (TIRE MFG # 773422430) (17.5 KGS) (INSTALL .10) (GOODYEAR, WRANGLER ST, 265/70R17, BSL) (5.880) (ACDelco #HD422430)
19190769 TIRE, P275/55R20-111T AT BW (USA&CANADA TIRE PROGRAM) (INSTALL .25) (BRIDGESTONE, DUELER A/T RH-S, P275/55R20, BW111T) (5.880) (ACDelco #FB107925)
(AC21-855) 2007-2013 CK1,2,3 CARRIER PKG/BICYCLE (HITCH MOUNTED)
12499171 CARRIER, BICYCLE (HITCH MT) (INSTALL .10) (18.42KGS) (CARRIES 4 BIKES) (17.070) (REQUIRES 2" TRAILER HITCH AND LICENSE PLATE REMOUNT PKG-12495709)
12499718 PLATE, BICYCLE CARR RAIL MTG (12.815) (REQUIRES 2" HITCH PKG) (SERV CMP OF CARRIER PKG 12499171, 72)
12499722 RAIL PKG, BICYCLE CARR (HITCH MT) (17.070) (REQUIRES 2" HITCH PKG) (SERV CMP OF CARRIER PKG 12499171)
12499723 STRAP, BICYCLE CARR (BLACK) (PLASTIC) (QTY 8 PC PKG) (16.800) (REQUIRES 2" HITCH PKG)
12499724 LOCK, BICYCLE (0.91KGS) (INCLS 2 KEYS) (REQ 2" HITCH PKG) (12.815)
19242660 KEY SET, HITCH CARRIER (#010) (INCLS 2 KEYS) (17.070)
19242661 KEY SET, HITCH CARRIER (#011) (INCLS 2 KEYS) (17.070)
19242662 KEY SET, HITCH CARRIER (#012) (INCLS 2 KEYS) (17.070)
19242663 KEY SET, HITCH CARRIER (#013) (INCLS 2 KEYS) (17.070)
19242664 KEY SET, HITCH CARRIER (#014) (INCLS 2 KEYS) (17.070)
19242665 KEY SET, HITCH CARRIER (#015) (INCLS 2 KEYS) (17.070)
19242666 KEY SET, HITCH CARRIER (#016) (INCLS 2 KEYS) (17.070)
19242667 KEY SET, HITCH CARRIER (#017) (INCLS 2 KEYS) (17.070)
19242668 KEY SET, HITCH CARRIER (#018) (INCLS 2 KEYS) (17.070)
19242669 KEY SET, HITCH CARRIER (#019) (INCLS 2 KEYS) (17.070)
19242670 KEY SET, HITCH CARRIER (#020) (INCLS 2 KEYS) (17.070)
19242671 KEY SET, HITCH CARRIER (#021) (INCLS 2 KEYS) (17.070)
19242672 KEY SET, HITCH CARRIER (#022) (INCLS 2 KEYS) (17.070)
19242673 KEY SET, HITCH CARRIER (#023) (INCLS 2 KEYS) (17.070)
19242674 KEY SET, HITCH CARRIER (#024) (INCLS 2 KEYS) (17.070)
19242675 KEY SET, HITCH CARRIER (#025) (INCLS 2 KEYS) (17.070)
19242676 KEY SET, HITCH CARRIER (#026) (INCLS 2 KEYS) (17.070)
19242677 KEY SET, HITCH CARRIER (#027) (INCLS 2 KEYS) (17.070)
19242678 KEY SET, HITCH CARRIER (#028) (INCLS 2 KEYS) (17.070)
19242679 KEY SET, HITCH CARRIER (#029) (INCLS 2 KEYS) (17.070)
19242680 KEY SET, HITCH CARRIER (#030) (INCLS 2 KEYS) (17.070)
19242681 KEY SET, HITCH CARRIER (#031) (INCLS 2 KEYS) (17.070)
19242682 KEY SET, HITCH CARRIER (#032) (INCLS 2 KEYS) (17.070)
19242683 KEY SET, HITCH CARRIER (#033) (INCLS 2 KEYS) (17.070)
19242684 KEY SET, HITCH CARRIER (#034) (INCLS 2 KEYS) (17.070)
19242685 KEY SET, HITCH CARRIER (#035) (INCLS 2 KEYS) (17.070)
19242686 KEY SET, HITCH CARRIER (#036) (INCLS 2 KEYS) (17.070)
19242687 KEY SET, HITCH CARRIER (#037) (INCLS 2 KEYS) (17.070)
19242688 KEY SET, HITCH CARRIER (#038) (INCLS 2 KEYS) (17.070)
19242689 KEY SET, HITCH CARRIER (#039) (INCLS 2 KEYS) (17.070)
19242690 KEY SET, HITCH CARRIER (#040) (INCLS 2 KEYS) (17.070)
19242691 KEY SET, HITCH CARRIER (#041) (INCLS 2 KEYS) (17.070)
19242692 KEY SET, HITCH CARRIER (#042) (INCLS 2 KEYS) (17.070)
19242693 KEY SET, HITCH CARRIER (#043) (INCLS 2 KEYS) (17.070)
19242694 KEY SET, HITCH CARRIER (#044) (INCLS 2 KEYS) (17.070)
19242695 KEY SET, HITCH CARRIER (#045) (INCLS 2 KEYS) (17.070)
19242696 KEY SET, HITCH CARRIER (#046) (INCLS 2 KEYS) (17.070)
19242697 KEY SET, HITCH CARRIER (#047) (INCLS 2 KEYS) (17.070)
19242698 KEY SET, HITCH CARRIER (#048) (INCLS 2 KEYS) (17.070)
19242699 KEY SET, HITCH CARRIER (#049) (INCLS 2 KEYS) (17.070)
19242700 KEY SET, HITCH CARRIER (#050) (INCLS 2 KEYS) (17.070)
19242701 KEY SET, HITCH CARRIER (#051) (INCLS 2 KEYS) (17.070)
19242702 KEY SET, HITCH CARRIER (#052) (INCLS 2 KEYS) (17.070)
19242703 KEY SET, HITCH CARRIER (#053) (INCLS 2 KEYS) (17.070)
teamcadillac.ru
19242704 KEY SET, HITCH CARRIER (#054) (INCLS 2 KEYS) (17.070)
19242705 KEY SET, HITCH CARRIER (#055) (INCLS 2 KEYS) (17.070)
19242706 KEY SET, HITCH CARRIER (#056) (INCLS 2 KEYS) (17.070)
19242707 KEY SET, HITCH CARRIER (#057) (INCLS 2 KEYS) (17.070)
19242708 KEY SET, HITCH CARRIER (#058) (INCLS 2 KEYS) (17.070)
19242709 KEY SET, HITCH CARRIER (#059) (INCLS 2 KEYS) (17.070)
19242710 KEY SET, HITCH CARRIER (#060) (INCLS 2 KEYS) (17.070)
19242711 KEY SET, HITCH CARRIER (#061) (INCLS 2 KEYS) (17.070)
19242712 KEY SET, HITCH CARRIER (#062) (INCLS 2 KEYS) (17.070)
19242713 KEY SET, HITCH CARRIER (#063) (INCLS 2 KEYS) (17.070)
19242714 KEY SET, HITCH CARRIER (#064) (INCLS 2 KEYS) (17.070)
19242715 KEY SET, HITCH CARRIER (#065) (INCLS 2 KEYS) (17.070)
19242716 KEY SET, HITCH CARRIER (#066) (INCLS 2 KEYS) (17.070)
19242717 KEY SET, HITCH CARRIER (#067) (INCLS 2 KEYS) (17.070)
19242718 KEY SET, HITCH CARRIER (#068) (INCLS 2 KEYS) (17.070)
19242719 KEY SET, HITCH CARRIER (#069) (INCLS 2 KEYS) (17.070)
19242720 KEY SET, HITCH CARRIER (#070) (INCLS 2 KEYS) (17.070)
19242721 KEY SET, HITCH CARRIER (#071) (INCLS 2 KEYS) (17.070)
19242722 KEY SET, HITCH CARRIER (#072) (INCLS 2 KEYS) (17.070)
19242723 KEY SET, HITCH CARRIER (#073) (INCLS 2 KEYS) (17.070)
19242724 KEY SET, HITCH CARRIER (#074) (INCLS 2 KEYS) (17.070)
19242725 KEY SET, HITCH CARRIER (#075) (INCLS 2 KEYS) (17.070)
19242726 KEY SET, HITCH CARRIER (#076) (INCLS 2 KEYS) (17.070)
19242727 KEY SET, HITCH CARRIER (#077) (INCLS 2 KEYS) (17.070)
19242728 KEY SET, HITCH CARRIER (#078) (INCLS 2 KEYS) (17.070)
19242729 KEY SET, HITCH CARRIER (#079) (INCLS 2 KEYS) (17.070)
19242730 KEY SET, HITCH CARRIER (#080) (INCLS 2 KEYS) (17.070)
19242731 KEY SET, HITCH CARRIER (#081) (INCLS 2 KEYS) (17.070)
19242732 KEY SET, HITCH CARRIER (#082) (INCLS 2 KEYS) (17.070)
19242733 KEY SET, HITCH CARRIER (#083) (INCLS 2 KEYS) (17.070)
19242734 KEY SET, HITCH CARRIER (#084) (INCLS 2 KEYS) (17.070)
19242735 KEY SET, HITCH CARRIER (#085) (INCLS 2 KEYS) (17.070)
19242736 KEY SET, HITCH CARRIER (#086) (INCLS 2 KEYS) (17.070)
19242737 KEY SET, HITCH CARRIER (#087) (INCLS 2 KEYS) (17.070)
19242738 KEY SET, HITCH CARRIER (#088) (INCLS 2 KEYS) (17.070)
19242739 KEY SET, HITCH CARRIER (#089) (INCLS 2 KEYS) (17.070)
19242740 KEY SET, HITCH CARRIER (#090) (INCLS 2 KEYS) (17.070)
19242741 KEY SET, HITCH CARRIER (#091) (INCLS 2 KEYS) (17.070)
19242742 KEY SET, HITCH CARRIER (#092) (INCLS 2 KEYS) (17.070)
19242743 KEY SET, HITCH CARRIER (#093) (INCLS 2 KEYS) (17.070)
19242744 KEY SET, HITCH CARRIER (#094) (INCLS 2 KEYS) (17.070)
19242745 KEY SET, HITCH CARRIER (#095) (INCLS 2 KEYS) (17.070)
19242746 KEY SET, HITCH CARRIER (#096) (INCLS 2 KEYS) (17.070)
19242747 KEY SET, HITCH CARRIER (#097) (INCLS 2 KEYS) (17.070)
19242748 KEY SET, HITCH CARRIER (#098) (INCLS 2 KEYS) (17.070)
19242749 KEY SET, HITCH CARRIER (#099) (INCLS 2 KEYS) (17.070)
12499719 CARRIER, BICYCLE (HITCH MT CARRIER LOWER SUPPORT) (12.815) (SERV CMP OF CARRIER PKG 12499171)
88963912 STRAP, BICYCLE CARR (BLACK) (WEBBING) (16.800) (SERV CMP OF CARRIER PKGS)
88963077 KEY, BICYCLE CARR THEFT DTRNT LK (#01) (INCLS 2 KEYS) (12.815)
88966122 KEY, BICYCLE CARR THEFT DTRNT LK (#02) (INCLS 2 KEYS) (17.070)
88966123 KEY, BICYCLE CARR THEFT DTRNT LK (#03) (INCLS 2 KEYS) (17.070)
88966124 KEY, BICYCLE CARR THEFT DTRNT LK (#04) (INCLS 2 KEYS) (17.070)
88966125 KEY, BICYCLE CARR THEFT DTRNT LK (#05) (INCLS 2 KEYS) (17.070)
88966126 KEY, BICYCLE CARR THEFT DTRNT LK (#06) (INCLS 2 KEYS) (17.070)
88966127 KEY, BICYCLE CARR THEFT DTRNT LK (#07) (INCLS 2 KEYS) (17.070)
88966128 KEY, BICYCLE CARR THEFT DTRNT LK (#08) (INCLS 2 KEYS) (17.070) (**VPI 1-877-846-8243)
88966129 KEY, BICYCLE CARR THEFT DTRNT LK (#09) (INCLS 2 KEYS) (17.070)
88966130 KEY, BICYCLE CARR THEFT DTRNT LK (#00) (INCLS 2 KEYS) (17.070)
(AC21-857) 2007-2013 CK1,2(06) BAG PKG/ROOF LUGGAGE (SOFT)(Z88,Z75)
teamcadillac.ru
12497826 BAG PKG, LUGG CARR STOW (RF MT) (WATER RESISTANT/NOT WATERPROOF) (BLACK) (INSTALL .30) (2.29KGS) (FABRIC) (CADILLAC LOGO) (11.5X29.625X37) (12.816)
(AC21-864) 2007-2013 CK1,2(06-36) DOOR PKG/FUEL TANK FILLER
teamcadillac.ru
12497944 DOOR PKG, F/TNK FIL (CHROME) (INSTALL .60) (0.74 KGS) (ZINC DIE CAST) (INCLS SCREWS, NUTS & INSTR) (16.570)
(AC21-865) 2007-2013 CK1(06-36) GRILLE PKG/RADIATOR (Z75)
17801288 GRILLE PKG, FRT (WHITE) (INSTALL 1.5) (3.78KGS) (CHROME MESH W/BODY COLOR SURROUND) (1.266)
19156281 GRILLE PKG, FRT (BLACK) (INSTALL 1.5) (3.78KGS) (CHROME MESH W/BODY COLOR SURROUND) (1.266)
(AC21-866) 2007-2013 CK1,2,3 BALL PKG/TRAILER HITCH
12495788 BALL PKG, TRLR HITCH (CHROME) (INSTALL .10) (1.5KGS) (2 5/16" BALL;1"X2-7/8" SHANK;FLG THK 3/4" TO 1 7/8") (6000LB) (7.068)
19245478 BALL PKG, TRLR HITCH (CHROME) (INSTALL .10) (1.053 KGS) (1-7/8"BALL;1X3" SHANK;FLG THK 1/2 TO 1-3/4") (3500LB GROSS) (7.068) (USE W/BPR & HITCH FLG THK FROM 1/2" TO 1-3/4")
(AC21-867) 2007-2013 CK1,2,3 HITCH PKG/BALL MOUNT
12495777 BAR, TRLR HITCH DRAW (INSTALL .10) (3.0KGS) (STD) (INCLS BALL MT W/1" SHANK, 5/8 HITCH PIN & 1/8 HAIR PIN) (7.068) (2" RISE, 3-1/4" DROP, 5000 LB MAX LOAD, 500 LB TONGUE WT)
12495778 BAR, TRLR HITCH DRAW (INSTALL .10) (4.0KGS) (STD) (INCLS BALL MT W/1" SHANK, 5/8 HITCH PIN & 1/8 HAIR PIN) (7.068) (4" RISE, 5-1/4" DROP, 5000 LB MAX LOAD, 500 LB TONGUE WT)
19245486 BAR, TRLR HITCH DRAW (INSTALL .10) (2.9 KGS) (STD) (INCLS BALL MT W/1" SHANK, 5/8 HITCH PIN & 1/8 HAIR PIN) (7.068) (3/4" RISE, 2" DROP, 5000 LB MAX LOAD, 500 LB TONGUE WT)
(AC21-870) 2007-2010 CK1(06-36) HOOK PKG/TOW
teamcadillac.ru
19243784 HOOK PKG, FRT TOW (INSTALL .50) (CHROME) (7.068)
19158568 ATTACHMENT KIT, TOW HOOK (7.068) (SERV COMP OF CHROME TOW HOOK PKGS)
(AC21-873) 2007-2013 CK1 GUARD PKG/SPLASH (FLAT WITH CONTOUR) (NO LOGO)(Z75)
19154428 GUARD PKG, RR MUD (BLACK) (INSTALL .30) (0.76KGS) (NO LOGO) (FLAT W/CONTOUR) (446 MM LONG) (8.214)
teamcadillac.ru
19213392 FLAP PKG, MUD (FITS FRT OR RR) (BLACK) (INSTALL .30) (0.64 KGS) (FLAT W/CONTOUR) (NO LOGO) (500 MM LONG) (8.214)
(AC21-878) 2007-2013 CK1(06-36) HOIST PKG (EXC (HP2))
19158309 HOIST PKG, SPA WHL (INSTALL .50) (SINGLE 3.1KGS) (HOIST ONLY) (9.709) (FOR 22" WHEEL ONLY)
25974847 HOIST, SPA WHL (7.629) (SERV CMP OF HOIST PKG 19158309)
(AC21-879) 2007-2010 CK1,2,3 HEADPHONE/REAR SEAT ENTERTAINMENT (SERVICED COMPONENT)
teamcadillac.ru
19132012 HEADPHONE PKG, (0.36 KGS) (9.680)
(AC21-887) 2007-2013 CK1,2(06-36) MAT PKG/FRONT FLOOR CARPET (PRODUCTION)
19121915 MAT PKG, FRONT CARPET (EBONY) (TWIN) (NO LOGO) (15.286)
19206524 MAT PKG, FRONT CARPET (CASHMERE) (TWIN) (NO LOGO) (16.800)
(AC21-916) 2007-2013 CK1,2,3 LOCK PKG/BICYCLE & SKI CARRIER
teamcadillac.ru
(AC21-920) 2007-2013 CK1,2,3 PLATE PKG/LICENSE REMOUNT
12495709 BRACKET KIT, RR LIC PLT (INSTALL .30) (1.13 KGS) (INCLS HDW) (REQUIRES 2" HITCH PKG)
(AC21-952) 2007-2013 CK1,2,3 REFLECTIVE TRIANGLE PKG (CU8)
22745654 REFLECTOR PKG, DISABLED VEH WRNG TRIANGLE (1.4KGS) (2.575)
22745655 REFLECTOR PKG, DISABLED VEH WRNG TRIANGLE (BULK) (360 PC QTY OF 22745654) (2.575)
(AC21-980) 2007-2013 CK1(06-36) WHEEL PKG (CK945)(Z75)
12499427 CAP PKG, WHL NUT/BOLT (INSTALL .10) (SINGLE 0.01KGS) (CHROME PLASTIC) (24 PC QTY OF 15045768) (5.858)
12499428 CAP PKG, WHL NUT/BOLT (INSTALL .10) (SINGLE 0.01KGS) (CHROME PLASTIC) (480 PC QTY OF 15045768) (5.858)
teamcadillac.ru
12499308 CAP PKG, HUB (CHROME) (INSTALL .10) (SINGLE 0.04KGS) (W/CADILLAC LOGO) (80 PC QTY OF 88963142) (5.858)
12499423 CAP PKG, HUB (CHROME) (INSTALL .10) (SINGLE 0.04KGS) (W/CADILLAC LOGO) (4 PC QTY OF 88963142) (5.858)
19155564 NUT PKG, WHL (INSTALL .1) (SINGLE 0.062KGS) (STEEL W/ZINC PLATE) (24 PC QTY OF 9595175) (5.813)
17800945 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (CAST) (AL) (INCLS 1 WHL 88967789 & TAG) (5.803)
17800946 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (CAST) (AL) (4 PC QTY OF 88967789) (5.803)
17800947 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (CAST) (AL) (16 PC QTY OF 88967789) (5.803)
(AC21-981) 2007-2013 CK1(06-36) WHEEL PKG (CK948)(Z75)
17800948 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (AL, 6-SINGLE SPOKE) (INCLS 1 WHL 88967790 & TAG) (5.803)
teamcadillac.ru
17800949 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (AL, 6-SINGLE SPOKE) (4 PC QTY OF 88967790) (5.803)
17800950 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (AL, 6-SINGLE SPOKE) (16 PC QTY OF 88967790) (5.803)
(AC21-982) 2007-2013 CK1(06-36) WHEEL PKG (CK951)(Z75)
teamcadillac.ru
17800951 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (INCLS 1 WHL 88967791 & TAG) (5.803)
17800952 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (4 PC QTY OF 88967791) (5.803)
17800953 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (16 PC QTY OF 88967791) (5.803)
(AC21-984) 2007-2013 CK1,2,3 STEP PKG/TUBULAR ASST (OVAL)
20921112 STEP PKG, ASST (CHROME) (INSTALL .50) (17.98 KGS) (6" OVAL) (AL) (SMOOTH TUBE) (RAISED RECT) (BLACK PAD) (8.225)
teamcadillac.ru
11609836 NUT, ASST STEP RIVET (M8X1.25X17) (3.023) (SERV CMP OF STEP PKGS 12499706, 07, 17801889, 90, 19202895-902)
19211749 BRACKET, ASST STEP (8.228) (SERV CMP OF STEP PKGS 19202895-19202896)
19211750 COVER, ASST STEP BRKT (8.228)
19212311 CAP PKG, ASST STEP FIN (INCLS FRT & RR CAPS) (USE ON STEP TUBE W/NOTCH AT END) (8.304) (SERV CMP OF STEP PKGS)
20919901 PAD, ASST STEP FRT (LONG) (8.228) (SERV CMP OF STEP PKGS 19202895-19202902)
(AC21-985) 2007-2013 CK1(06-36) WHEEL PKG (CK366)(Z75)
17800366 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (AL, 6-MULTI SPOKE) (W/1 WHL 88966246 OR 19170520 & TAG) (5.803)
17800367 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (AL, 6-MULTI SPOKE) (4 PC QTY OF 88966246 OR 19170520) (5.803)
teamcadillac.ru
17800368 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (AL, 6-MULTI SPOKE) (16 PC QTY OF 88966246 OR 19170520) (5.803)
(GM21-020) 2007-2012 CK1,2,3 HEADPHONE/REAR SEAT ENTERTAINMENT (UPGRADE)
17802612 HEADPHONE PKG, (00.2 KGS) (INCLS WIRELESS NOISE CANC HEADPHONE, OWN MAN, 2 AAA BAT) (9.665)
(GM21-024) 2007-2011 CK1 ACCESSORY PKG/TIRE PRESSURE INDICATOR SENSOR NUT
17800699 NUT PKG, TIRE PRESS IND SEN (INSTALL .10) (SINGLE 0.0013 KGS) (16 PC QTY OF 15234846) (5.890)
(GM21-037) 2007-2013 CK1,2,3 ADAPTER PKG/TRAILER HARNESS (7-PIN TO PWR ADAP & 7-PIN TO 4-PIN ADAP)
19201995 ADAPTER PKG, TRLR WRG HARN RCPT (0.1 KGS) (INCLS 7-4 ADAPTER, 7-POWER OUTLET ADAPTER) (7.068)
(GM21-038) 2007-2010 CK1,2,3 TRANSMITTER PKG/REMOTE CONTROL DOOR LOCK (W/INFO DISPLAY)
19157237 TRANSMITTER PKG, R/CON DR LK & THEFT DTRNT & REM START (INCLS TRANSMITTER, RCVR, ANT, H/W, OWNER MAN) (INSTALL 1.1) (0.2 KGS) (2-WAY) (8 FT CABLE) (W/GREEN CONN) (16.345)
19131628 RECEIVER, KEYLESS ENTRY (16.345) (SERV CMP OF 17802071, 19156555, 19157233, 19157237, 19171129)
20763454 LATCH, HOOD PRIM (W/SWITCH) (8.080) (SERV CMP OF XMTR PKGS)
19131603 TRANSMITTER, KEYLESS ENTRY (W/LGATE/LGLASS/TRUNK BUTTON) (10.485)
teamcadillac.ru
19131612 TRANSMITTER, KEYLESS ENTRY (W/O RR CLOSURE BUTTONS) (SERV CMP OF 2-WAY XMTR PKGS) (10.485)
19131613 TRANSMITTER, KEYLESS ENTRY (2-WAY) (W/INFO DISPLAY) (W/TWO RR CLOSURE BUTTONS) (16.345)
19172336 ANTENNA, R/CON DR LK RCVR (ANT LABELED 19131608) (16.345)
(GM21-042) 2007-2013 CK1,2,3 ACCESSORY PKG/FIRE EXTINGUISHER
teamcadillac.ru
19211598 EXTINGUISHER PKG, FIRE (INTERNATIONAL) (INSTALL .30) (2.25 KGS) (2.5LB ABC) (9.990)
(GM21-044) 2010-2013 CK1,2,3 ACCESSORY PKG/TIRE PRESSURE INDICATOR SENSOR
19118652 SENSOR PKG, TIRE PRESS IND (INSTALL .10) (SINGLE 0.03 KGS) (16 PC QTY OF 20923680) (SNAP-IN) (5.890)
(GM21-045) 2010-2013 CK1,2,3 HEADPHONE/REAR SEAT ENTERTAINMENT (FOLD FLAT)
teamcadillac.ru
19245199 HEADPHONE PKG, (FOLD FLAT)
(TC21-009) 2007-2011 CK1(06-36) RAIL PKG/LUGGAGE CARRIER CROSS (Z75)
teamcadillac.ru
12499282 RAIL PKG, LUGG CARR CR (BRI AN W/CHROME ENDCAPS) (INSTALL .25) (3.99KGS) (AL) (NO LOGO) (INCLS 2 RAILS & HDW) (17.070)
19157488 ATTACHMENT KIT, LUGG CARR CR RL (INCLS 4 BOLTS, 4 SUPT CVRS, 4 NUTS, 4 LOOPS, WRENCH & INSTR) (17.070)
19157494 STRIP, LUGG CARR CR RL RUB (17.070)
(TC21-013) 2007-2013 CK1 MAT PKG/FRONT FLOOR CARPET (NON-PRODUCTION) (MOLDED EDGE)(Z75)
17800408 MAT PKG, FRONT CARPET (MOLDED EDGE) (EBONY) (2.03KGS) (CPT) (TWIN) (W/WREATH & CREST LOGO) (16.800)
teamcadillac.ru
17800409 MAT PKG, FRONT CARPET (MOLDED EDGE) (CASHMERE) (2.03KGS) (CPT) (TWIN) (W/WREATH & CREST LOGO) (16.800)
(TC21-014) 2007-2013 CK1,2(06) MAT PKG/REAR PREMIUM (ALL WEATHER)(1 PIECE)
12499640 MAT PKG, REAR PREMIUM (ALL WEATHER) (EBONY) (3.1KGS) (1 PC) (NO LOGO) (VERTICAL RIBS) (16.800)
teamcadillac.ru
19166596 MAT PKG, REAR PREMIUM (ALL WEATHER) (CASHMERE) (3.1KGS) (1 PC) (NO LOGO) (VERTICAL RIBS) (16.800)
(TC21-015) 2007-2013 CK1,2(06) MAT PKG/REAR #2 PREMIUM (ALL WEATHER)(1 PIECE)
teamcadillac.ru
12499641 MAT PKG, REAR #2 PREMIUM (ALL WEATHER) (EBONY) (1.30KGS) (1 PC) (NO LOGO) (VERTICAL RIBS) (16.800)
19166599 MAT PKG, REAR #2 PREMIUM (ALL WEATHER) (CASHMERE) (1.30KGS) (1 PC) (VERTICAL RIBS) (16.800)
19166600 MAT PKG, REAR #2 PREMIUM (ALL WEATHER) (GRAY) (1.30KGS) (1 PC) (NO LOGO) (VERTICAL RIBS) (16.800)
(TC21-016) 2007-2013 CK107(06) MAT PKG/REAR #2 CARPET (MOLDED EDGE)
teamcadillac.ru
17800423 MAT PKG, REAR #2 CARPET (MOLDED EDGE) (EBONY) (1.30KGS) (1 PC) (NO LOGO) (16.800)
17800424 MAT PKG, REAR #2 CARPET (MOLDED EDGE) (CASHMERE) (1.30KGS) (1 PC) (NO LOGO) (16.800)
(TC21-018) 2007-2013 CK107(06) MAT PKG/CARGO PREMIUM (ALL WEATHER)(Z75)
17801325 MAT PKG, CARGO PREMIUM (ALL WEATHER) (EBONY) (2.0KGS) (W/ESCALADE LOGO) (USE W/3RD ROW SEAT) (8.214)
19166801 MAT PKG, CARGO PREMIUM (ALL WEATHER) (CASHMERE) (2.0KGS) (W/ESCALADE LOGO) (USE W/3RD ROW SEAT) (16.800)
(TC21-022) 2007-2013 CK1,2,3 SECURITY PKG/INCLINATION SENSOR
17800431 ALARM PKG, THEFT DTRNT (INSTALL .80) (0.0856KGS) (VEH SECURITY SHOCK) (INCLS HARN & INSTR) (2.195)
17800432 ALARM PKG, THEFT DTRNT (INSTALL .80) (0.0421KGS) (INCLS SENSOR & HARN) (2.195) (REQUIRES PROGRAMMING THRU TCSC) (REQUIRES UK3 OR ACSRY DIC SWITCH PKG.)
(TC21-023) 2007-2013 CK1,2,3 SHIELD PKG/DOOR SILL (NO LOGO)
17802414 PLATE PKG, S/D SILL TR (INSTALL .50) (SS) (BRUSHED) (NO LOGO) (INCLS FRT & RR) (16.603)
(TC21-032) 2007-2013 CK1 WHEEL PKG (CK997)(Z75)
17800997 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (AL) (INCLS 1 WHL 88967872 & TAG) (5.803)
teamcadillac.ru
17800998 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (AL) (4 PC QTY OF 88967872) (5.803)
17800999 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (ALUMINUM) (16 PC QTY OF 88967872) (5.803)
(TC21-033) 2007-2011 CK1 WHEEL PKG (CK925)(Z75)
teamcadillac.ru
17800925 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 19.0KGS) (20X8.5, CAST AL) (5 SINGLE SPOKE BORDERED) (INCLS 1 WHL 88967768) (5.803)
17800926 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 19.0KGS) (20X8.5, CAST AL) (5 SINGLE SPOKE BORDERED) (4 PC QTY OF 88967768) (5.803)
17800927 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 19.0KGS) (20X8.5, CAST AL) (5 SINGLE SPOKE BORDER) (16 PC QTY OF 88967768) (5.803)
(TC21-034) 2007-2011 CK1 WHEEL PKG (CK994)(Z75)
teamcadillac.ru
17800994 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 18.8KGS) (20X8.5, AL) (6 SPOKE MULTI-FEATURE) (INCLS 1 WHL 88967871 & TAG) (5.803)
17800995 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 18.8KGS) (20X8.5, AL) (6 SPOKE MULTI-FEATURED) (4 PC QTY OF 88967871) (5.803)
17800996 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 18.8KGS) (20X8.5, AL) (6 SPOKE MULTI-FEATURED) (16 PC QTY OF 88967871) (5.803)
(TC21-043) 2007-2013 CK1,2(06-36) MAT PKG/REAR FLOOR CARPET (PRODUCTION) (TWIN)
19121926 MAT PKG, REAR CARPET (EBONY) (TWIN) (16.800)
teamcadillac.ru
19206525 MAT PKG, REAR CARPET (CASHMERE) (TWIN) (16.800)
(TC21-052) 2009-2010 CK1(06-36) ACCESSORY PKG/MUFFLER
19156353 MUFFLER PKG, EXH (SS) (INSTALL 1.0) (20.41KGS) (SEMI POLISHED) (3.701)
teamcadillac.ru
19156354 MUFFLER PKG, EXH (SS) (INSTALL 1.0) (20.41KGS) (SEMI POLISHED) (3.701)
(TC21-054) 2007-2013 CK1,2(06) GUARD PKG/SPLASH (MOLDED) (FRONT)(NO LOGO)(FLAT BOTTOM)
teamcadillac.ru
19212577 GUARD PKG, F/FDR MUD (SILVER) (INSTALL .50) (.52 KGS) (MOLDED) (8.214)
19212579 GUARD PKG, F/FDR MUD (LABYRINTH) (INSTALL .50) (.52 KGS) (MOLDED) (8.214)
(TC21-057) 2007-2013 CK1,2(06-36) GUARD PKG/SPLASH (MOLDED) (FRONT)(NO LOGO)
19212797 GUARD PKG, F/FDR MUD (NOT FOR USE W/ACSRY ARTICULATING RUN BD, FDR FLARES, OR GND EFFECTS) (BLACK) (INSTALL .50) (0.52 KGS) (MOLDED) (W/EDGE SEAL) (SMOOTH FINISH)) (8.214)
19212799 GUARD PKG, F/FDR MUD (NOT FOR USE W/ACSRY ARTICULATING RUN BD) (WHITE) (INSTALL .50) (0.52 KGS) (MOLDED) (W/EDGE SEAL) (8.214)
teamcadillac.ru
19212801 GUARD PKG, F/FDR MUD (GRAY) (INSTALL .50) (0.52 KGS) (MOLDED) (W/EDGE SEAL) (CAN BE USED W/OR W/O RUNNING BOARD) (8.214)
(TC21-058) 2007-2013 CK1(06) GUARD PKG/SPLASH (MOLDED) (REAR)(NO LOGO)(Y91,Z75)
19212154 GUARD PKG, RR MUD (SILVER) (INSTALL .50) (0.6 KGS) (MOLDED) (NOT FOR USE W/ACSRY SPARE TIRE KIT 19172547) (8.214)
19212155 GUARD PKG, RR MUD (LABYRINTH) (INSTALL .50) (0.6 KGS) (MOLDED) (NOT FOR USE W/ACSRY SPARE TIRE KIT 19172547) (8.214)
19212817 GUARD PKG, RR MUD (GRAY) (INSTALL .50) (0.62 KGS) (MOLDED) (W/EDGE SEAL) (8.214)
19212807 GUARD PKG, RR MUD (NOT FOR USE W/ACSRY SPARE TIRE KIT 19172547) (BLACK) (INSTALL .50) (0.62 KGS) (MOLDED) (W/EDGE SEAL) (8.214)
19212809 GUARD PKG, RR MUD (WHITE) (INSTALL .50) (0.62 KGS) (MOLDED) (W/EDGE SEAL) (8.214)
(TC21-066) 2007-2013 CK1(06-36) SHIELD PKG/DOOR SILL (CADILLAC SCRIPT LOGO)(Z75)
teamcadillac.ru
17802527 PLATE PKG, S/D SILL TR (INSTALL .30) (1.46KGS) (SS) (BRUSHED) (W/CAD SCRIPT LOGO) (INCLS RH & LH FRT & 2 R/L RR) (16.603)
(TC21-082) 2007-2013 CK1 DEFLECTOR PKG/HOOD AIR (Z75)
teamcadillac.ru
19172570 DEFLECTOR PKG, HOOD AIR (SMOKE) (INSTALL .3) (0.6KGS) (ACRYLIC) (NO LOGO) (INCLS FASTENERS & INSTR) (8.010)
19172571 DEFLECTOR PKG, HOOD AIR (CHROME) (INSTALL .3) (0.7KGS) (ABS) (NO LOGO) (INCLS FASTENERS & INSTR) (8.010)
(TC21-089) 2007-2013 CK107,109(06) LAMP PKG/TAIL(Z75)
22884391 LAMP KIT, TAIL (CLEAR) (INSTALL .35) (3.98 KGS) (STOP LMP) (INCLS RH/LH) (2.679)
(TC21-091) 2007-2013 CK1 EXTENSION PKG/EXHAUST TAIL PIPE (OEM ONLY)(NO LOGO)(Z75)
22799816 EXTENSION KIT, EXH TAIL PIPE (INSTALL .50) (1.06 KGS) (DUAL WALL) (ANGLE CUT) (SS) (NO LOGO) (FOR USE W/GRND FX) (3.705)
19132693 CLAMP, EXH PIPE (SERV CMP OF EXT PKGS) (3.5" TORCA STYLE) (3.708)
(TC21-094) 2007-2013 CK1(06-36) WHEEL PKG (CK372)(Z75)
17800372 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 20.6KGS) (22X9) (CAST AL) (INCLS 1 WHL 88966248 & TAG) (5.803)
17800373 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 20.6KGS) (22X9) (CAST AL) (4 PC QTY OF 88966248) (5.803)
17800374 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 20.6KGS) (22X9) (CAST AL) (16 PC QTY OF 88966248) (5.803)
(TC21-097) 2007-2013 CK1(06-36) WHEEL PKG (CK375)(Z75)
teamcadillac.ru
17800376 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (AL) (4 PC QTY OF 88966249) (5.803)
17800377 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (AL) (16 PC QTY OF 88966249) (5.803)
88966249 WHEEL PKG, (ALUM) (INCLS 1 WHL 88966249 & TAG) (SINGLE 20.8KGS) (INSTALL .25) (CHROME) (ALUM) (CHROME) (5.803)
(TC21-100) 2007-2013 CK1(06-36) WHEEL PKG (CK910)(Z75)
teamcadillac.ru
17800910 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 22.0KGS) (22X9) (AL, DESIGN 1) (INCLS 1 WHL 88967763 & TAG) (5.803)
17800911 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 22.0KSG) (22X9) (AL, DESIGN 1) (4 PC QTY OF 88967763) (5.803)
17800912 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 22.0KGS) (22X9) (AL, DESIGN 1) (16 PC QTY OF 88967763) (5.803)
(TC21-103) 2007-2013 CK1(06-36) WHEEL PKG (CK916)(Z75)
17800916 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 20.0KGS) (22X9) (CAST AL) (INCLS 1 WHL 88967765 & TAG) (5.803)
17800917 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 20.0KGS) (22X9) (CAST AL) (4 PC QTY OF 88967765) (5.803)
17800918 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 20.0KGS) (22X9) (CAST AL) (16 PC QTY OF 88967765) (5.803)
(TC21-119) 2007-2013 CK107,109(06) LAMP PKG/CENTER HIGH MOUNT STOP(Z75)
teamcadillac.ru
19172250 LAMP KIT, HIGH MT STOP (CLEAR) (INSTALL .50) (0.91KGS) (PLASTIC) (2.679)
(TC21-121) 2007-2013 CK1 MAT PKG/FRONT PREMIUM (ALL WEATHER)(Z75)
teamcadillac.ru
17803323 MAT PKG, FRONT PREMIUM (ALL WEATHER) (EBONY) (3.40KGS) (TWIN) (W/SILVER ESCALADE LOGO) (VERTICLE RIBS) (16.800)
19166595 MAT PKG, FRONT PREMIUM (ALL WEATHER) (CASHMERE) (3.40KGS) (TWIN) (W/SILVER ESCALADE LOGO) (VERTICAL RIBS) (16.800)
(TC21-137) 2009-2011 CK1,2,3 ACCESSORY PKG/REAR VIEW CAMERA
teamcadillac.ru
25872958 HARNESS, RR LIC PLT LP WRG (2.714) (SERV CMP OF CAMERA PKGS)
(TC21-142) 2007-2013 CK1 WHEEL PKG (CK798)
19170798 WHEEL PKG, (5.803)
19170799 WHEEL PKG, (5.803)
19170800 WHEEL PKG, (MACH./PAINTED) (INSTALL .25) (SINGLE 17.93KGS) (22X9) (CAST AL) (16 PC QTY OF 19170797) (5.803)
(TC21-143) 2007-2013 CK1 WHEEL PKG (CK919)
teamcadillac.ru
17800919 WHEEL PKG, (CHROME) (INSTALL .30) (20.4 KGS) (22X9) (INCLS 1 WHL 88967766 & TAG) (AL) (CAST) (5.803)
17800920 WHEEL PKG, (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9) (4 PC QTY OF 88967766) (AL) (CAST) (5.803)
17800921 WHEEL PKG, (5.803)
(TC21-144) 2007-2011 CK1 WHEEL PKG (CK922)
17800922 WHEEL PKG, (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9, CAST AL) (6 TAPERED SPOKE DES) (INCLS 1 WHL 88967767 & TAG) (5.803)
teamcadillac.ru
17800923 WHEEL PKG, (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9, CAST AL) (6 TAPERED SPOKE DES) (4 PC QTY OF 88967767) (5.803)
17800924 WHEEL PKG, (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9, CAST AL) (6 TAPERED SPOKE DES) (16 PC QTY OF 88967767) (5.803)
(TC21-145) 2007-2011 CK1 WHEEL PKG (CK928)
17800928 WHEEL PKG, (CHROME) (INSTALL .25) (17.3KGS) (20X8.5, CAST AL) (8 SQUARE SPOKE DES) (1 PC QTY OF 88967769) (5.803)
17800929 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5, CAST AL) (8 SQUARE SPOKE DES) (4 PC QTY OF 88967769) (5.803)
teamcadillac.ru
17800930 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5, CAST AL) (8 SQUARE SPOKE DES) (16 PC QTY OF 88967769) (5.803)
(TC21-146) 2007-2013 CK1 WHEEL PKG (CK991)
17800991 WHEEL PKG,
teamcadillac.ru
17800992 WHEEL PKG,
17800993 WHEEL PKG,
(TC21-147) 2007-2013 CK1 WHEEL PKG (CK370)
teamcadillac.ru
19170370 WHEEL PKG, (CHROME) (INSTALL .30) (SINGLE 15.0KGS) (20X8.5) (AL, 6 TAPERED SPOKE) (INCLS 1 WHL 19170369 & TAG) (5.803)
19170371 WHEEL PKG, (CHROME) (INSTALL .30) (SINGLE 15.0KGS) (20X8.5) (AL, 6 TAPERED SPOKE) (4 PC QTY OF 19170369) (5.803)
19170372 WHEEL PKG, (CHROME) (INSTALL .30) (SINGLE 15.0KGS) (20X8.5) (AL, 6 TAPERED SPOKE) (16 PC QTY OF 19170369) (5.803)
(TC21-152) 2008-2010 CK107(06) ACCESSORY PKG/SPARE TIRE(HP2)
19172547 HOIST PKG, SPA WHL (INSTALL 1.5) (SINGLE 19.9KGS) (INCLS WHL, HOIST, & EXH KIT) (NOT FOR USE/ACSRY SPH GUARDS) (5.880) (P265/70R17 TIRE & FASCIA COVER NOT INCLUDED IN KIT)
25851500 RESONATOR KIT, EXH (W/TAIL PIPE) (400MM MUFFLER) (3.702) (SERV CMP OF SPA WHL PKG 19172547)
09595852 WHEEL, 17X7 SPA (ALUM) (5.803) (SERV CMP OF HOIST PKG)
10372326 GUIDE, SPA WHL HOIST SHF (7.629) (SERV CMP OF SPA WHL PKGS)
15101404 HANDLE, JK (508.0MM LG) (8.820) (SERV CMP OF SPA WHL PKG)
15295860 EXTENSION, JK HDL (406MM) (NON FLEXIBLE SHAFT) (8.820) (SERV CMP OF SPA WHL PKG)
15547900 BLOCK, WHL (8.820) (SERV CMP OF SPA WHL PKG)
15772593 NUT, WHL BLK (6MM) (8.820) (SERV CMP OF SPA WHL PKG)
15783357 BOLT, WHL BLK (8.820) (SERV CMP OF SPA WHL PKG)
15827206 CASE, SPA WHL LK CYL (7.680) (SERV CMP OF SPA WHL PKG)
15854614 HANDLE, JK/WHL WRENCH (NON-RATCHET TYPE) (8.821) (SERV CMP OF SPA WHL PKG)
25783810 SHIELD, SPA WHL HT (7.629) (SERV CMP OF SPA WHL PKG)
teamcadillac.ru
25851508 CLAMP, EXH PIPE (3.708) (SERV CMP OF SPA WHL PKG 19172547)
25974846 HOIST, SPA WHL (7.629) (SERV CMP OF HOIST PKG)
20782703 TOOL KIT, (8.821) (SERV CMP OF SPA WHL PKG)
15788798 JACK, (8.820) (SERV CMP OF HOIST PKG)
11610693 RETAINER, TOOL STOW (INCLS WINGNUT) (8.821) (SERV CMP OF HOIST PKG)
22895910 BRACKET, JK STOW (8.820) (SERV CMP OF SPA WHL PKG)
(TC21-153) 2007-2013 CK1,2(06) NET PKG/CONVENIENCE (FLAT STYLE)
17803346 NET PKG, CONVENIENCE (BLACK) (INSTALL .50) (2ND ROW) (FLAT STYLE) (INCLS 4-RET & 4-STUDS) (16.575)
(TC21-161) 2007-2013 CK107,109(06) TRAY PKG/REAR COMPARTMENT FLOOR STORAGE (Z75)
teamcadillac.ru
17803357 TRAY PKG, R/CMPT FLR STOW COMPT (EBONY) (2.3KGS) (GRD PLSTC) (W/ESCALADE SCRIPT LOGO) (INCLS LINER) (2" SIDE WALLS) (16.583) (TO BE USED WHEN THIRD ROW SEAT IS NOT IN VEHICLE)
(TN21-036) 2007-2011 CK1,2,3 SECURITY PKG/VEHICLE SHOCK SENSOR
teamcadillac.ru
(TC08-939) 2009-2013 CK1(06-36) КРЫЛО И КОЛЕСНАЯ АРКА/ПЕРЕДНЯЯ ЧАСТЬ (CADILLAC Z75)
25815065 BRACE, F/END SH MET DIAG
11609989 BOLT, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (F/END SH MET DIAG BR)
11515755 BOLT, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (F/FDR RR UPR BR) (T/W 12345493 REPLCS 25534835)
15185449 BRACE, F/FDR RR UPR
15185450 BRACE, F/FDR RR UPR
11610010 BOLT, HEX W/ CON WA, M8X1.25X40, 32 THD, 28 OD, 9.8, 7114M, MACH, P-PT (F/FDR INR PNL)
15870422 BRACKET, F/FDR UPR
teamcadillac.ru
15951192 BRACKET, F/FDR UPR
11570082 BOLT, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (F/FDR UPR BRKT) (ACDelco #11570082)
15887401 BRACKET, HOOD HGE LWR (PART OF 9)
15887400 BRACKET, HOOD HGE LWR (PART OF 9)
25992408 FENDER, FRT (INCLS 8)
25992409 FENDER, FRT (INCLS 8)
25819534 FENDER, FRT (INCLS 8)
25819535 FENDER, FRT (INCLS 8)
22900197 FENDER, FRT (INCLS 8)
11516149 NUT, U, 8X1.25, MULTI THD, .08'-4.0' THK PNL, PZ (F/FDR RR UPR BRKT)
11569854 NUT, U SPECIAL, M8X1.25, SAE 1050 STL, GMW3359 (SILVER) (F/FDR RR CTR BRKT)
25948814 BRACKET, FRT BPR FASCIA SI (INCLS 14)
25948815 BRACKET, FRT BPR FASCIA SI (INCLS 14)
11518531 NUT, PUSH-IN, M4.2X1.41, 15.9X8.4, .7-2.1 PNL, SAE 1050 STL, 7111M, 8.65 SQ HOL (PART OF 13) (10.512)
11517164 SCREW, HEX M8X1.25X20 W/CON WA (F/FDR LWR)
11589292 RETAINER, PUSH-IN, FITS 8.5 DIA HOLE IN 2-4.5 THK PNL, NYLON 6/6 GMP.PA66.015 (FRT W/H LNR (PUSH IN))
11609952 NUT, U-STYLE M4.2X1.41, 15.9X8.4, .7-2.1 PNL, SAE 1050 STL, 7111M, 8.65 SQ HOL (FRT W/H LNR)
11562172 BOLT, FRT W/H LNR
10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (FRT BPR FASCIA OTR BRKT)
11609489 BOLT, HEX W/ WASHER, 4.2X1.41X25, 14.5 THD17 OD, GM6010M STL, GMW4205 (FRT BPR FASCIA OTR BRKT)
01605396 RETAINER, PUSH-IN, FITS .250 HOLE, .92 LG.700-OD NYLON BLACK (FRT W/H LNR (PUSH IN))
11562024 RETAINER, PUSH IN, 7.5X36.5, FITS 6.35 HOLE IN 2.29-18.34 THK PNL (FRT W/H LNR (PUSH IN))
22860089 LINER, FRT W/H
22860081 LINER, FRT W/H
22860097 LINER, FRT W/H
22860095 LINER, FRT W/H
11610055 BOLT, HWASH, M6X1X23 (FRT BPR FASCIA SI BRKT)
20906466 INSULATOR, COWL S/PNL
20906467 INSULATOR, COWL S/PNL
11570321 NUT, F/FDR LWR
15862261 BRACKET, FRT W/H PNL UPR
22860090 LINER, FRT W/H
22860082 LINER, FRT W/H
11519360 NUT, U, W/PLASTISOL, M8X1.25, 35.8X25, 21 C/E, 2.5-5 PNL, 1050, 6173M (F/FDR LWR)
15893710 SHIELD, ENG LWR FRT SPH
15893711 SHIELD, ENG LWR FRT SPH
11517560 SCREW, FLAT WA (NRW) AND HX WA HD, M8X1.25X25 (ENG LWR FRT SPH SHLD)
25961847 ORNAMENT, F/FDR (CHROME)
25961848 ORNAMENT, F/FDR (CHROME)
(TC08-948) 2010 CK1,2(06) ЭТИКЕТКИ
25808256 LABEL, BAT WRNG (ARABIC)
25861414 LABEL, FUEL RECOMMENDATION
20853000 LABEL, FUEL RECOMMENDATION
12451193 LABEL, CHILD SECURITY LK OPERG INSTR
19206430 LABEL KIT, VEH CAPACITY WT & TIRE INFO (ENGLISH ONLY LABEL FOR US) (QTY 10 PER KIT)
19206431 LABEL KIT, VEH CAPACITY WT & TIRE INFO (ENGLISH W/FRENCH-CANADIAN LABEL FOR CANADA) (QTY 10 PER KIT)
19206432 LABEL KIT, VEH CAPACITY WT & TIRE INFO (SPANISH LABEL FOR MEXICO) (QTY 10 PER KIT)
92229620 LABEL, MERCURY DISPOSAL INFO
25940508 LABEL, I/P WRG HARN FUSE BLK IDENT (2.483)
12567697 LABEL, ALL WHL DRV WRNG (ENGLISH/FRENCH)
25954276 LABEL, BAT WRNG (ENGLISH/FRENCH) (FIRST RESPONDER CAUTION LABEL)
10309116 LABEL, FAN BLADE WRNG (BLACK NYLON)
teamcadillac.ru
19257194 LABEL, VEH EMIS CONT INFO (VIN MUST BE SUPPLIED WITH ORDER)
15061343 LABEL, O/S RR VIEW MIR INFO (FRENCH)
21996989 TAG, I/P AIRBAG WRNG (HANGING)
15815407 LABEL, AIRBAG SYS WRNG (ENGLISH/ARABIC)
15053409 LABEL, A/C REFRIG & BAT & FAN BLADE & RAD FIL CAP CAUTION (ARABIC)
(TC09-700) 2007-2013 CK1,2(06) ШЛАНГИ И ТРУБКИ/ОБОГРЕВАТЕЛЬ
19130058 HOSE, AUX A/C EVPR & AUX HTR (INCLS 2, 4, 6, 9-13) (ACDelco #19130058)
19257318 HOSE, AUX A/C EVPR & AUX HTR (INCLS 2, 4, 6, 9-13) (KENT-MORE TUBING REPAIR KIT J41425 REQ'D FOR INSTALLATION) (9.225) (ACDelco #15-33439)
15102168 CLIP, AUX A/C EVPR HOSE (PART OF 1) (2X2 PLASTIC) (SLOT ON SIDE WITH DIAMETERS OF 19.05, 9.52, AND 2 AT 12.7MM)
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (AUX A/C EVPR & CMPR HOSE CLIP)
15102169 CLIP, AUX A/C EVPR HOSE (PART OF 1) (SLOT IN MIDDLE WITH DIAMETERS OF 19.05, 9.52, AND 2 AT 12.7MM)
11514596 NUT, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (AUX A/C EVPR TUBE) (8.915) (ACDelco #11514596)
02724966 SEAL, A/C CMPR & CNDSR HOSE (PART OF 1) (ACDelco #15-31101)
22876355 HOSE, A/C CMPR (SEE GROUP 09.000 "A/C REFRIGERATION SYSTEM/FRONT" FOR DETAILED ILLUSTRATED VIEW) (ACDelco #15-34529)
22876353 TUBE, A/C EVPR (SEE GROUP 09.000 "A/C REFRIGERATION SYSTEM/FRONT" FOR DETAILED ILLUSTRATED VIEW) (ACDelco #15-34538)
15055343 TEE, AUX HTR INL HOSE (PART OF 1) (NATURAL) (111MM LONG)
15055342 TEE, AUX HTR INL HOSE (PART OF 1) (BLACK) (113MM LONG)
52474373 SEAL, A/C EVPR TUBE (PART OF 1) (BLACK) (SLIMLINE WASHER) (19MM OD X 11MM ID, 1/2IN DIA) (SMOOTH-SIDED) (ACDelco #15-31055)
19130031 RETAINER KIT, AUX HTR INL & OTLT HOSE CONN (INCLS 13) (PART OF 1) (INCL RETAINER, SEAL, SPACER, INSTRUCTION)
teamcadillac.ru
09 - КРЕПЛЕНИЕ КУЗОВА-КОНДИЦИОНЕР-АУДИОСИСТЕМА
(GM09-046) 2010-2011 CK1 КОМПРЕССОР КОНДИЦИОНЕРА В СБОРЕ (L20/4.8A,LMG/5.3-0,LC9/5.3-3,L94/6.2F)
25940200 COMPRESSOR KIT, A/C (INCLS 2-10) (ACDelco #15-22232)
teamcadillac.ru
11561365 BOLT, A/C CMPR PUL (PART OF 1) (*KIT1)
20906283 CLUTCH KIT, A/C (4 SPLINED, DENSO) (INCLS 2-10) (ACDelco #15-4709)
(GM09-079) 2007-2013 CK1,2,3 CABLE KIT- COMMUNICATION
teamcadillac.ru
13581174 CABLE KIT, COMN INTERFACE MDL ANT (RG56 CABLES-LONG RUN CELLULAR/COMBINED CELLULAR & GPS) (ACDelco #13581174)
(GM09-080) 2007-2013 CK1,2,3 CABLE KIT- DIGITAL RADIO & VEHICLE LOCATOR
13581173 CABLE KIT, DIGITAL RDO & VEH LOC ANT COAX (RG316 CABLES-LONG RUN XM/GPS) (ACDelco #13581173)
teamcadillac.ru
(GM09-081) 2007-2013 CK1,2,3 CABLE KIT- DIGITAL RADIO & MOBILE TELEPHONE & VEHICLE LOCATOR
13581175 CONNECTOR KIT, DIGITAL RDO & M/TEL & VEH LOC ANT COAX (CONNECTIONS PACKAGE) (ACDelco #13581175)
teamcadillac.ru
(TC09-054) 2010 CK1(06-36) КРЕПЛЕНИЕ РАДИОСИСТЕМЫ (CADILLAC Z75)
15859569 ANTENNA, ELEK NAVIGATION (ACDelco #15859569)
25865834 CABLE, TV, NAV, AMP, VEH LOC & TRAF INFO INTERFACE (I/P) (ACDelco #25865834)
teamcadillac.ru
22847989 CABLE, RDO ANT CBL EXTN RDO END (1021 MM) (ACDelco #22847989)
11610157 NUT, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (I/P) (10.701)
20902104 RADIO, AM/FM STEREO & NAVN (INCLS 8, 9) (ACDelco #20902104)
20902102 RADIO, AM/FM STEREO & NAVN (INCLS 8, 9) (ACDelco #20902102)
20902103 RADIO, AM/FM STEREO & NAVN (INCLS 8, 9) (ACDelco #20902103)
20902105 RADIO, AM/FM STEREO & NAVN (INCLS 8, 9) (ACDelco #20902105)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (RDO) (9.665)
00000002 DISC, NAVN DATA (REFERENCE PART ONLY, NOT AVAILABLE THROUGH GM CC&A) (CONTACT NAV DISC CENTER AT 1-877-628-3472 OR GMNAVDISC.COM)
11588650 CLIP, 12X14X16.6, GM4345M (I/P ACSRY CTR TR PLT)
(TC09-087) 2010-2013 CK1,2(06) СИСТЕМА ОХЛАЖДЕНИЯ КОНДИЦИОНЕРА/FRONT (EXC HYBRID HP2)
20913751 CONDENSER, A/C (INCLS 4, 32-34) (ACDelco #15-63666)
11589039 BOLT, HEX, W/CON WA, M6X1X30, 20 THD, 24 O.D., 9.8, GMW4205 (A/C CNDSR BRKT)
15044225 INSULATOR, A/C CNDSR (LOWER) (ACDelco #15-63283)
52481715 BRACKET, A/C CNDSR UPR (INLET/OUTLET) (PART OF 1) (INCLS 32) (114.5MM LONG)
52482006 BRACKET, A/C CNDSR UPR (PART OF 1) (INCLS 32) (77.0MM LONG) (9.242)
52474373 SEAL, A/C CMPR & CNDSR HOSE (19MM OD X 11MM ID) (PART OF 7, 10) (BLACK) (SLIMLINE WASHER) (19MM OD X 11MM ID, 1/2IN DIA) (SMOOTH-SIDED) (ACDelco #15-31055)
12477570 NUT, HFH, M8X1.25X8, 10.9 (A/C EVPR TUBE)
22876353 TUBE, A/C EVPR (INCLS 5, 8, 15-18, 21, 26) (ACDelco #15-34538)
15734255 CLIP, A/C EVPR TUBE (PART OF 7) (HOLD ONE 12.6 DIAM PIPE, W/ PUSHIN RETAINER)
22876350 HOSE, A/C CNDSR (INCLS 5, 16, 24, 25) (ACDelco #15-34531)
11570082 BOLT, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (A/C CNDSR HOSE) (ACDelco #11570082)
02724966 SEAL, A/C ACCUM FRT HOSE (25MM OD X 17MM ID, 3/4IN DIA) (PART OF 14) (ACDelco #15-31101)
11570082 BOLT, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (A/C ACCUM HOSE) (ACDelco #11570082)
22876355 HOSE, A/C CMPR (INCLS 12, 26) (ACDelco #15-34529)
52458183 SEAL, A/C REFRIG SERV VLV (O RING) (9.25MM ID) (PART OF 7) (BLACK) (RUBBER) (ACDelco #15-30572)
03041827 CORE, A/C REFRIG SERV VLV (INCLS SPRING, W/O O-RING, 13/64-36 THD) (PART OF 7, 10, 17, 31) (W/O FITTING) (ACDelco #15-1119)
52458184 VALVE, A/C REFRIG SERV (PART OF 7) (INCLS 16) (M12X1.5 THD) (INCLS FITTING & SEAL) (ACDelco #15-5438)
52458768 CAP, A/C REFRIG SERV VLV (HIGH SIDE CHARGE PORT, ACCUMULATOR & EVAP TUBE) (PART OF 7, 31) (M8X1.0) (WITH SEAL) (LONG THREADED, NON-TETHERED CAP) (ACDelco #15-33289)
12477570 NUT, HFH, M8X1.25X8, 10.9 (A/C CMPR & CNDSR HOSE)
11514596 NUT, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (A/C CMPR & CNDSR HOSE) (8.915) (ACDelco #11514596)
19259601 ORIFICE, A/C CNDSR (PART OF 7) (ACDelco #15-33410)
02724966 SEAL, A/C ACCUM FRT TUBE (25MM OD X 17MM ID, 3/4IN DIA) (PART OF 31) (9.222) (ACDelco #15-31101)
12477570 NUT, HFH, M8X1.25X8, 10.9 (A/C ACCUM RET)
19188397 O-RING, 7.65MM ID, 1.78 MM THK, NEOPRENE (PART OF 10, 31) (ACDelco #15-3592)
22678731 SENSOR, A/C REFRIG PRESS (PART OF 10) (HIGH PRESSURE) (ALUMINUM W/O COATING) (ACDelco #15-50147)
03094214 O-RING, ID .426X.070 THK, MATERIAL-NEOPRENE (PART OF 7, 14) (ACDelco #15-3614)
11514623 BOLT, HEX W/CON WA, M6X1X20 (A/C ACCUM BRKT)
11588331 NUT, HEX HD W/CON WA, M6X1, 5.7THK, 25 O.D., 9, GM6138M (A/C ACCUM BRKT)
15194317 BRACKET, A/C ACCUM
20828233 ACCUMULATOR, A/C (INCLS 16, 18, 22, 24) (INCLS CORE & CAP) (ACDelco #15-11067)
52476687 INSULATOR, A/C CNDSR (PART OF 1, 4, 33) (UPPER) (6.602)
teamcadillac.ru
52481716 BRACKET, A/C CNDSR UPR (RETURN) (INLET/OUTLET) (PART OF 1) (INCLS 32) (114.5MM LONG)
52482008 BRACKET, A/C CNDSR UPR (INLET/OUTLET) (PART OF 1) (INCLS 32) (77.0MM LONG) (RETURN SIDE) (9.242)
11561065 STUD, A/C CNDSR (PART OF 1) (STRAIGHT M8X1.25X13.5, M8X1.25X27)
(TC09-700) 2007-2013 CK1,2(06) СИСТЕМА ОХЛАЖДЕНИЯ КОНДИЦИОНЕРА/REAR (C69)
19130058 HOSE, AUX A/C EVPR & AUX HTR (INCLS 2, 4, 6, 9-13) (8.846) (ACDelco #19130058)
19257318 HOSE, AUX A/C EVPR & AUX HTR (INCLS 2, 4, 6, 9-13) (KENT-MORE TUBING REPAIR KIT J41425 REQ'D FOR INSTALLATION) (ACDelco #15-33439)
52474373 SEAL, A/C EVPR TUBE (19MM OD X 11MM ID) (PART OF 1) (BLACK) (SLIMLINE WASHER) (19MM OD X 11MM ID, 1/2IN DIA) (SMOOTH-SIDED) (ACDelco #15-31055)
teamcadillac.ru
(TC09-900) 2007-2013 CK107(06) ОСУШИТЕЛЬ И ОБОГРЕВАТЕЛЬ КОНДИЦИОНЕРА ДОПОЛНИТЕЛЬНЫЙ (C69)
15920869 CASE, AUX A/C EVPR & BLO (OUTER)
15232221 BUSHING, A/C EVPR CASE
15887322 ACTUATOR, MODE VLV (ACDelco #15-73644)
11562121 BOLT, AUX A/C EVPR & BLO CASE
15887322 ACTUATOR, TEMP VLV (AUX) (ACDelco #15-73644)
20859526 EVAPORATOR, AUX A/C (ACDelco #15-63347)
02724952 SEAL, AUX A/C EVPR OTLT TUBE (5/8") (CONTAINS 2 SEALS) (9.222) (ACDelco #15-30917)
15892073 TUBE, HTR CORE (AUX) (INLET) (ACDelco #15892073)
25994366 VALVE, AUX A/C EVPR THERMAL EXPN (ACDelco #15-51146)
11562123 BOLT, A/C EVPR TXV (PAN HEAD, M5X35, 8.8 STL)
15232211 CASE, AUX A/C EVPR & BLO LWR
15189481 VALVE, AUX A/C EVPR & BLO MDL DRN (ACDelco #15-5420)
15921035 SEAL, AUX HTR CASE (ACDelco #15-33736)
11562120 STUD, HTR & A/C EVPR & BLO MDL (STUD-FLANGE, M6X1X25)
11562122 CLIP, A/C EVPR CASE (11X6.35) (9.215)
15798231 SEAL, HTR INL & OTLT PIPE (O-RING)
52474373 SEAL, AUX A/C EVPR INL TUBE (BLACK) (SLIMLINE WASHER) (19MM OD X 11MM ID, 1/2IN DIA) (SMOOTH-SIDED) (9.222) (ACDelco #15-31055)
15892072 PLATE, A/C EVPR INL TUBE BRKT BKG
15920866 VALVE, TEMP (ACDelco #15-50766)
22782134 CLIP, HTR CORE
15232212 CORE, AUX HTR (ACDelco #15-63346)
15920868 CASE, AUX A/C EVPR & BLO
13501703 MODULE, BLO MOT CONT (INCLS 23) (9.169) (ACDelco #15-81638)
25811506 HARNESS, AUX HTR & A/C WRG
15920865 MOTOR, AUX BLO (ACDelco #15-81062)
15920871 SEAL, AUX HTR AIR OTLT (ACDelco #15920871)
15814847 SEAL, AUX A/C EVPR & BLO MDL OTLT DUCT (ACDelco #15814847)
15920867 VALVE, MODE (AUX) (ACDelco #15-50767)
teamcadillac.ru
15892074 TUBE, HTR CORE (AUX) (OUTLET) (ACDelco #15892074)
11609953 STUD, A/C EVPR TXV (M8X1.25X11.5, M8X1.25X24, 46 TL, STAINLESS) (3.275)
(TC09-906) 2007-2013 CK107(06) КРЕПЛЕНИЕ КУЗОВА К РАМЕ
15924986 RETAINER, BODY BOLT
15018263 SHIM, BODY MT (3MM THICK)
15018264 SHIM, BODY MT (1.5MM THICK)
15864038 CUSHION, BODY MT UPR LOCATION #5 (WHITE)
15201791 CUSHION, BODY MT LWR LOCATION #1 (71MM OD)
11562587 BOLT, BODY (M14X2X126)
15201794 CUSHION, BODY MT UPR LOCATION #3 (PINK)
15201005 CUSHION, BODY MT UPR LOCATION #2 (ORANGE)
15201797 CUSHION, BODY BOLT UPR (LOCATION: # 1) (GREEN)
03537772 NUT, M12X1.75, 10.6THK, 28 O.D., 10, 7111M (BODY MT) (8.917)
15201791 CUSHION, BODY MT LWR FRT (71MM OD)
15837581 CUSHION, BODY MT UPR FRT (VIOLET) (1.270)
11562547 BOLT, HFH, M12X1.75X135, 100 THD, 24.7 OD, GMW25 (10.9) STL, GM 7112M, MACH (BODY MT)
11562546 WASHER, FLAT, 14X42.5X3.61 MM, SAE 1050 STL RC 37-43, 7112M (BODY MT)
(TC09-912) 2009-2013 CK1,2,3 АНТЕННА/ЦИФРОВАЯ АУДИОСИСТЕМА (U2K,UBS)
25775201 ANTENNA, RDO DIGITAL (INCLS 2) (XM ONLY ANTENNA) (ACDelco #25775201)
25815079 ANTENNA, DIGITAL RDO & M/TEL & VEH LOC (INCLS 2) (ONSTAR & XM) (ROOF MOUNTED) (ACDelco #25815079)
19208818 CABLE, DIGITAL RDO & M/TEL & VEH LOC ANT (PART OF 9) (USED IN ROOF AND DOOR HARNESSES) (ACDelco #19208818)
15201868 BRACKET, DIGITAL RDO RCVR
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (I/P CARR SUPT) (9.665)
20938347 RECEIVER, DIGITAL RDO (ACDelco #20938347)
teamcadillac.ru
20938348 RECEIVER, DIGITAL RDO (ACDelco #20938348)
19209842 CABLE, DIGITAL RDO & M/TEL & VEH LOC ANT (PART OF 7)
(TC09-915) 2007-2013 CK107(06) ВОЗДУХОРАСПРЕДЕЛИТЕЛЬНАЯ СИСТЕМА/REAR DUCTS(C69)
25897954 DUCT, AUX A/C AIR OTLT (INCLS 14)
11518531 NUT, PUSH-IN, M4.2X1.41, 15.9X8.4, .7-2.1 PNL, SAE 1050 STL, 7111M, 8.65 SQ HOL (AUX A/C AIR OTLT DUCT) (10.512)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (FLR RR AIR DISTR) (9.665)
11518531 NUT, PUSH-IN, M4.2X1.41, 15.9X8.4, .7-2.1 PNL, SAE 1050 STL, 7111M, 8.65 SQ HOL (FLR RR AIR DISTR) (10.512)
teamcadillac.ru
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (AUX HTR & A/C EVPR & BLO MDL) (9.665)
11518531 NUT, PUSH-IN, M4.2X1.41, 15.9X8.4, .7-2.1 PNL, SAE 1050 STL, 7111M, 8.65 SQ HOL (AUX HTR & A/C EVPR & BLO MDL) (10.512)
20733729 WASHER, SEALING, M5, 4 I.D., 25MM O.D., 4MM THK, RUB (RR BPR OTR FIL) (ACDelco #20733729)
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (AUX HTR & A/C EVPR & BLO MDL)
15864151 DISTRIBUTOR, FLR RR AIR (INCLS 11)
15152429 RETAINER, AMB AIR TEMP SEN (PUSH IN) (PART OF 10) (HOLE LINER TYPE)
12160947 SENSOR, DUCT AIR TEMP (37.54MM) (TWIST LOCK STYLE) (ACDelco #15-5632)
25885451 SENSOR, DUCT AIR TEMP (PUSH PIN STYLE) (ACDelco #15-51259)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (AUX A/C AIR OTLT DUCT) (9.665)
15152429 RETAINER, AMB AIR TEMP SEN (PUSH IN) (PART OF 1) (HOLE LINER TYPE)
12160947 SENSOR, DUCT AIR TEMP (TWIST LOCK STYLE) (ACDelco #15-5632)
(TC09-916) 2007-2013 CK1,2,3 ВОЗДУХОРАСПРЕДЕЛИТЕЛЬНАЯ СИСТЕМА/MODULE MOUNTING
11589183 NUT, PUSH IN, W/SEAL, 4.2X1.41, 6.35-6.48 SQ HL, 9.5 SQ HD, 0.787-2.765 PNL THK, NYL (AIR INL GRL PNL)
11609539 SCREW, RD CROWNED WA HD, M4.2X1.41X16, STL ISO 2702, GMW4205 (HDLP BZL)
15999788 RETAINER, AIR INL GRL PNL (17X15.25X8.6) (U-SHAPED/CLIP)
15856112 VALVE, PLNM DRN
15733206 BOLT, HTR & BLO MDL (M6X2.70X27)
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (HTR & A/C EVPR & BLO MDL)
teamcadillac.ru
15138625 HOSE, A/C EVPR & BLO MDL DRN
15856113 VALVE, PLNM DRN
(TC09-920) 2007-2013 CK1(06-36) АУДИОСИСТЕМА/ПЕРЕДНЯЯ ЧАСТЬ (CADILLAC Z75)
25889857 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 1) (LINEN)
25889863 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 1) (LINEN)
25889853 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 1) (GRAY)
25889859 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 1) (GRAY)
25889861 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 1) (CASHMERE)
teamcadillac.ru
25889855 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 1)
15186674 SPEAKER, RDO W/S SI G/MLDG (PART OF 1) (ACDelco #15186674)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 1)
15221850 GRILLE, RDO FRT SPKR (INCLS 9) (EBONY)
15221851 GRILLE, RDO FRT SPKR (INCLS 9) (COCOA)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (RDO FRT SPKR) (9.665)
25798963 SPEAKER, RDO FRT (3.5") (9.665) (ACDelco #25798963)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 6)
11570654 NUT, RDO FRT S/D SPKR (4.2 X 1.41) (PUSH-IN NUT) (FITS 8.75 SQ HOLE)
15905042 SPEAKER, RDO FRT S/D (ACDelco #15905042)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (RDO FRT S/D SPKR) (9.665)
20944419 AMPLIFIER, RDO SPKR (ACDelco #20944419)
20808899 AMPLIFIER, RDO SPKR (ACDelco #20808899)
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (RDO F/FLR CNSL SPKR)
25915806 SPEAKER, RDO F/FLR CNSL (ACDelco #25915806)
11610157 NUT, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (F/FLR CNSL BRKT) (10.701)
(TC09-921) 2007-2013 CK1,2(06) АУДИОСИСТЕМА/ЗАДНЯЯ ЧАСТЬ
15186672 SPEAKER, RDO BODY RR COR UPR GARN MLDG (ACDelco #15186672)
11509253 SCREW, W/LRG WA HD, M4.2X1.4X10, 11.3 O.D., BHL PT, STL, NO (PART OF 8)
11561654 RETAINER, CTR PLR UPR G/MLDG (PART OF 8) (PLAIN) (BIRD'S BEAK SINGLE) (FITS 8.5 DIA HOLE) (12.800)
11609651 RETAINER, BODY RR COR G/MLDG (PART OF 8) (METAL PUSH-IN NUT, M4.2X1.41, 21.8X15X20.5) (14.731)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 8)
11609539 SCREW, RD CROWNED WA HD, M4.2X1.41X16, STL ISO 2702, GMW4205 (PART OF 8)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (RDO RR S/D SPKR) (9.665)
11570654 NUT, RDO RR S/D SPKR (4.2 X 1.41) (PUSH-IN NUT) (FITS 8.75 SQ HOLE)
15186669 SPEAKER, RDO RR S/D (ACDelco #15186669)
teamcadillac.ru
15201406 SPEAKER, RDO RR S/D ( MATING CONN W/LEADS USE 12101825) (ACDelco #15201406)
(TC09-924) 2007-2013 CK1,2,3 ENTERTAINMENT SYSTEM (U42, EXC DNU)
15256562 BRACKET, VIDEO DISPLAY (INCLS 4)
11518121 NUT, U, M6X1, MULTI THD, .5'-4.0' THK PNL (VIDEO DISPLAY BRKT)
11570136 BOLT, HEX HD, W/CON SPR WA, M6X1X23, 14 THD, 17 O.D., 8.8, GMW3359 (VIDEO DISPLAY BRKT)
10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (PART OF 1)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 6)
25995622 RETAINER, RF RR CNSL (INCLS 5) (DVD BACKPLATE - 2ND ROW)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 8)
22821789 MODULE, AUDIO SYS XCVR (ACDelco #22821789) (LABELLED W/OEM PN 25835387.)
20844135 DISPLAY, VIDEO (INCLS 17) (CASHMERE) (ACDelco #20844135)
20792277 DISPLAY, VIDEO (INCLS 17) (GRAY) (ACDelco #20792277)
20845907 DISPLAY, VIDEO (INCLS 17) (LINEN) (ACDelco #20845907)
20929305 CONTROL, VIDEO REM (ACDelco #20929305) (LABELED 20929305)
15190411 CONTROL, VIDEO REM (ACDelco #15190411) (LABELED 15190411)
teamcadillac.ru
20830572 HEADPHONE, (INCLS 16) (REPLCMT EAR PADS AVBLE THRU UNWIRED TECH AT 888-293-3332) (ACDelco #20830572)
19115533 PAD, HEADPHONE EAR (PART OF 14) (PKG OF 4) (FOR USE W/STD NON FOLD FLAT STYLE HDPHN ONLY)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (PART OF 11) (9.665)
(TC09-929) 2007-2013 CK1,2,3 ОГНЕТУШИТЕЛЬ BRACKET (MTF)
11609615 RIVET, DOME HD TYPE MS, 3/16X0.308 STYLE 1 MS, SAE 1006 LOW CARBON STL, ZC PER GMW3044 (FIRE EXTINGUISHER BRKT) (*KIT1)
15880833 EXTINGUISHER PKG, FIRE (INCLS 1, 2)
(TC09-939) 2010 CK1(06-36) VEHICLE INFORMATION SYSTEM (CADILLAC Z75, UL2,UUM,VFJ)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (DIGITAL RDO RCVR BRKT) (9.665)
25890523 RECEIVER, TRAFFIC INFO
teamcadillac.ru
(TC09-946) 2008-2013 CK107(06) СИСТЕМА ОХЛАЖДЕНИЯ КОНДИЦИОНЕРА/FRONT (HYBRID HP2)
11514596 NUT, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (A/C ACCUM RET) (8.915) (ACDelco #11514596)
teamcadillac.ru
02724966 SEAL, A/C ACCUM FRT HOSE (25MM OD X 17MM ID, 3/4IN DIA) (PART OF 11) (ACDelco #15-31101)
11514596 NUT, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (A/C ACCUM FRT HOSE) (8.915) (ACDelco #11514596)
52474373 SEAL, A/C CMPR & CNDSR HOSE (PART OF 9) (BLACK) (SLIMLINE WASHER) (19MM OD X 11MM ID, 1/2IN DIA) (SMOOTH-SIDED) (ACDelco #15-31055)
52476687 INSULATOR, A/C CNDSR (PART OF 16-18) (UPPER) (6.602)
52482008 BRACKET, A/C CNDSR UPR (PART OF 17) (INCLS 15) (77.0MM LONG) (RETURN SIDE) (9.242)
52482006 BRACKET, A/C CNDSR UPR (PART OF 17) (INCLS 15) (77.0MM LONG) (9.242)
52474373 SEAL, A/C CMPR & CNDSR HOSE (PART OF 25) (BLACK) (SLIMLINE WASHER) (19MM OD X 11MM ID, 1/2IN DIA) (SMOOTH-SIDED) (ACDelco #15-31055)
11514596 NUT, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (A/C CNDSR HOSE) (8.915) (ACDelco #11514596)
22678731 SENSOR, A/C REFRIG PRESS (INCLS 22) (PART OF 25) (HIGH PRESSURE) (ALUMINUM W/O COATING) (ACDelco #15-50147)
52474373 SEAL, A/C EVPR TUBE (PART OF 29) (BLACK) (SLIMLINE WASHER) (19MM OD X 11MM ID, 1/2IN DIA) (SMOOTH-SIDED) (ACDelco #15-31055)
15734255 CLIP, A/C EVPR TUBE (PART OF 29) (HOLD ONE 12.6 DIAM PIPE, W/ PUSHIN RETAINER)
20911239 CAP, A/C REFRIG SERV VLV (PART OF 29) (M8X1.0) (SHORT THREADED, TETHERED CAP) (ACDelco #15-34400)
20911240 CAP, A/C REFRIG SERV VLV (PART OF 29) (M10X0.75) (LONG THREADED, TETHERED CAP) (ACDelco #15-34401)
11514623 BOLT, HEX W/CON WA, M6X1X20 (PART OF 1, 38)
02724966 SEAL, A/C ACCUM FRT TUBE (25MM OD X 17MM ID, 3/4IN DIA) (PART OF 1) (9.222) (ACDelco #15-31101)
11561065 STUD, A/C CNDSR (PART OF 17) (STRAIGHT M8X1.25X13.5, M8X1.25X27)
(TC09-950) 2008-2013 CK1(06) ENTERTAINMENT SYSTEM (CADILLAC Z75, PLATINUM EDITION ULT, HEADREST PLAYER AYE)
20807057 RESTRAINT, D/SEAT HD (COCOA)
20807059 RESTRAINT, P/SEAT HD (COCOA) (INCLS CONNCTION CABLES)
teamcadillac.ru
20795513 PLAYER PKG, VIDEO DISC (W/VIDEO DISPLAY) (ACDelco #20795513)
20896154 PLAYER PKG, VIDEO DISC (W/VIDEO DISPLAY) (ACDelco #20896154)
20896155 PLAYER PKG, VIDEO DISC (W/VIDEO DISPLAY) (ACDelco #20896155)
20807055 PLAYER PKG, VIDEO DISC (W/VIDEO DISPLAY) (ACDelco #20807055)
22840154 PLAYER PKG, VIDEO DISC (W/VIDEO DISPLAY) (ACDelco #22840154)
22840149 PLAYER PKG, VIDEO DISC (W/VIDEO DISPLAY) (ACDelco #22840149)
25865992 MODULE, AUDIO/VIDEO INTERFACE (ACDelco #25865992)
25865990 CONTROL, VIDEO REM (INCLS 8) (ACDelco #25865990)
22754231 HEADPHONE, (3-4 CHANNEL)
25865993 HARNESS, AUDIO PLYR WRG (ACDelco #25865993)
(TC09-951) 2009-2013 CK1,2(06-36) СИСТЕМА СВЯЗИ ("ONSTAR" UE1)
15241529 MICROPHONE, MOBILE TEL (PART OF 2) (2-WAY CAVITY)
25815079 ANTENNA, DIGITAL RDO & M/TEL & VEH LOC (INCLS 4) (ONSTAR & XM) (ROOF MOUNTED) (ACDelco #25815079)
20850446 ANTENNA, DIGITAL RDO & M/TEL & VEH LOC (INCLS 4) (W/3-WAY CONN W/ONLY 2 LEADS) (ACDelco #20850446)
15779345 COVER, I/S RR VIEW MIR WRG HARN (BETWEEN ISRVM & HDLNG TRIM)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (COMN INTERFACE MDL BRKT) (9.665)
11610157 NUT, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (COMMUNICATION INTERFACE MDL BRKT) (10.701)
25791895 BRACKET, COMMUNICATION INTERFACE MDL
20829983 MODULE, COMN INTERFACE (W/MOBILE TEL XCVR) (LABELED 20829983) (ACDelco #20829983)
20829984 MODULE, COMN INTERFACE (W/MOBILE TEL XCVR) (LABELED 20829984) (ACDelco #20829984)
20923563 MODULE, COMN INTERFACE (W/MOBILE TEL XCVR) (LABELED 20923563) (ACDelco #20923563)
22850735 MODULE, COMN INTERFACE (W/MOBILE TEL XCVR) (ACDelco #22850735) (LABELED 22850735)
15938939 ANTENNA, WIRELESS COMN INTERFACE (BLUETOOTH) (ACDelco #15938939)
teamcadillac.ru
19117898 CABLE, DIGITAL RDO & M/TEL & VEH LOC ANT (9.675) (ACDelco #19117898)
19208818 CABLE, DIGITAL RDO & M/TEL & VEH LOC ANT (PART OF 14) (USED IN ROOF AND DOOR HARNESSES) (ACDelco #19208818)
(TC09-956) 2008-2010 CK1,2(06) БЛОК КОНДИЦИОНЕРА И ОБОГРЕВАТЕЛЯ В СБОРЕ (AUTO TEMPERATURE CONTROL CJ2)
89018306 VALVE, TEMP
20834824 HARNESS, A/C MDL WRG
20883395 CASE, HTR & A/C EVPR & BLO LWR (NEED TO USE W/MOTOR 22741027 & DUCT 20883403)
13501703 MODULE, BLO MOT CONT (9.169) (ACDelco #15-81638)
teamcadillac.ru
20883403 DUCT, HTR & A/C EVPR & BLO MDL CLG (INCLS 20) (*KIT2) (IF SCREWS REQ'D, USE PN 11609829 (QTY 3))
22741027 MOTOR, BLO (INCLS 21, 23) (9.215) (ACDelco #15-81683) (USE T/W DUCT 20883403)
89019027 EVAPORATOR, A/C (ACDelco #15-62961)
89018295 SEAL, A/C EVPR (ACDelco #89018295)
89018365 ACTUATOR, TEMP VLV (ACDelco #15-72971)
22819113 INLET, AIR (*KIT4)
89018612 STUD, HTR & A/C EVPR & BLO MDL (M6X1X33MM TORX/COLR)
20834819 CASE, HTR & A/C EVPR & BLO UPR (INCLS 7)
89018299 CASE, HTR
11609829 BOLT, A/C EVPR TUBE CLIP (M4.2X2.25X16) (9.786)
89018297 CORE, HTR (INCLS 35, 36) (INCLS 2 SEALS) (ACDelco #15-62960)
52474960 LEVER, MODE VLV
89018304 VALVE, DEFR (ACDelco #15-50561)
89018307 VALVE, TEMP
89018302 SHIELD, HTR & A/C EVPR & BLO MDL HT
25953349 SENSOR, A/C REFRIG TEMP (ACDelco #15-51267)
89018374 ACTUATOR, MODE CONT CAM (INCLS 9, 10) (ACDelco #15-73952)
22741027 MOTOR, BLO (INCLS 19-21, 23) (ACDelco #15-81683)
89018784 SEAL KIT, HTR & A/C EVPR & BLO MDL (INCLS 5, 29, 31-33, 35, 36) (ACDelco #15-34397)
22819113 INLET, AIR (INCLS 27-29)
(TC09-957) 2010-2013 CK1,2(06) АНТЕННА
25994421 CABLE, RDO ANT (ACDelco #25994421)
11561711 BOLT, RDO ANT MDL (9.665)
25943786 MODULE, RDO ANT (ACDelco #25943786)
teamcadillac.ru
15045800 COVER, RDO ANT OPG
15256489 WIRE, RDO NOISE SUPPR GND (ACDelco #15256489)
11516885 SCREW, HFH W/FL WA, TAP, M8X1.25X20, 7THD, 17 O.D., TR PT, 6202M, PZOR (RDO NOISE SUPPR GND)
(TC09-962) 2010-2013 CK1(06-36) ВОЗДУХОРАСПРЕДЕЛИТЕЛЬНАЯ СИСТЕМА/FRONT DUCTS (CADILLAC Z75, AUTO TEMPERATURE CONTROL CJ2)
15289716 DUCT, SI WDO DEFG OTLT
teamcadillac.ru
11610157 NUT, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (I/P COMPT) (10.701)
15935349 DUCT, SI WDO DEFG OTLT
25885451 SENSOR, DUCT AIR TEMP (PART OF 8) (PUSH PIN STYLE) (ACDelco #15-51259)
25992392 DUCT, AIR DISTR (INCLS 2, 4, 7)
15152429 RETAINER, AMB AIR TEMP SEN (PUSH IN) (PART OF 12) (HOLE LINER TYPE)
12160947 SENSOR, DUCT AIR TEMP (37.54MM) (PART OF 12) (FOR SENSOR W/TWIST LOCK FEATURE, W/RETAINER, 2ND DES 25885451) (TWIST LOCK STYLE) (ACDelco #15-5632)
15762756 DUCT, FLR AIR OTLT (INCLS 10, 11, 14)
11517774 BOLT, HEX, M4.2X1.41X20, 14.25 OD, 6010M, 6138M, TAP, AB-PT (FLR AIR OTLT DUCT)
25872373 DUCT, FLR RR AIR OTLT
10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (PART OF 17)
15951532 DUCT, FLR FRT AIR OTLT (INCLS 16)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (PART OF 19) (9.665)
11518531 NUT, PUSH-IN, M4.2X1.41, 15.9X8.4, .7-2.1 PNL, SAE 1050 STL, 7111M, 8.65 SQ HOL (PART OF 18) (10.512)
(TC09-963) 2009-2013 CK1,2,3 ДАТЧИК ТЕМПЕРАТУРЫ AMBIENT(CJ2)
15826773 SENSOR, AMB AIR TEMP (WITH PUSH-IN/ATTACHMENT) (ACDelco #15-51150)
teamcadillac.ru
(TX09-016) 2010-2011 CK1 КРЕПЛЕНИЕ КОМПРЕССОРА КОНДИЦИОНЕРА (L20/4.8A,LMG/5.3-0,LC9/5.3-3,L9H/6.2-2,L94/6.2F)
12554026 BRACKET, A/C CMPR
11515767 BOLT, HFH, M10X1.5X35, 32THD, 22.3 O.D., MACH, 10.9, 7114M (A/C CMPR BRKT) (T/W 12345493)
teamcadillac.ru
11516109 BOLT, HFH, REDUCED BODY, M10X1.5X65, 25 THD, 22.3 O.D., HDR PT, 10.9, 7114M (A/C CMPR)
11516503 BOLT, HFH, M10X1.5X45, 33 THD, P-PT, 9.8, 7114M (A/C CMPR)
16 - ДЕТАЛИ КУЗОВА-СТЕКЛООЧИСТИТЕЛИ-ЗЕРКАЛА-ДВЕРИ-ОТДЕЛКА-РЕМНИ БЕЗОПАСНОСТИ
(MW10-005) 2007-2013 CK1,2,3 ЦИЛИНДР ЗАМКА/ДВЕРЬ
teamcadillac.ru
20985619 KEY, IGN (UNCODED) (MASTER)
20825032 CYLINDER KIT, FRT S/D LK (UNCODED) (INCLS 2-4, 6-12)
(TC16-213) 2010-2013 K1(06) КОНСОЛЬ/КРЫША (CADILLAC Z75, CF5, EXC UG1)
25786403 SWITCH, SUN RF (PART OF 4) (EBONY) (BLUE LAGOON BACK LIGHTING)
25786404 SWITCH, SUN RF (PART OF 4) (TRUE WHITE BACK LIGHTING)
15241529 MICROPHONE, MOBILE TEL (PART OF 4) (2-WAY CAVITY)
25845571 SWITCH, L/GATE ACTR (PART OF 4) (PART OF RF CONSOLE)
25851515 CONSOLE, RF (INCLS 1-3, 5-8, 10-13) (LINEN) (2ND ROW)
25807194 CONSOLE, RF (INCLS 1-3, 5-8, 10-13) (GRAY)
25977565 CONSOLE, RF (INCLS 1-3, 5-8, 10-13) (CASHMERE)
20858773 CONSOLE, RF (INCLS 1-3, 5-8, 10-13) (LINEN)
teamcadillac.ru
15853948 PUSHBUTTON, RDG LP SW (PART OF 4) (AT CONSOLE)
15911049 LENS, DM LP (PART OF 4) (1ST ROW)
09431809 BULB, 6CP TRADE #212-2 (PART OF 4) (ACDelco #L212-2)
11516630 BOLT, RF CNSL (PART OF 4) (M4.2X1.41X20) (8.977)
25828898 DISPLAY, I/P AIRBAG ARMING STATUS (W/WORDS ON AND OFF FOR AIRBAG)
25828899 DISPLAY, I/P AIRBAG ARMING STATUS (W/AIRBAG SYMBOLS FOR ON AND OFF)
11609345 NUT, PUSH-IN, 4.2, SAE 1050 STL, GMW3179 (PART OF 4)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 4)
(TC16-245) 2009-2013 CK107(06) ОТДЕЛКА ВНУТРЕННЯЯ-BODY SIDE-LH QUARTER DETAIL (HYBRID HP2, CADILLAC Z75)
15838270 HOLDER, R/SEAT CUP (PART OF 3) (TITANIUM)
15936706 HOLDER, R/SEAT CUP (PART OF 3) (LINEN)
15838268 HOLDER, R/SEAT CUP (PART OF 3) (EBONY)
15838269 HOLDER, R/SEAT CUP (PART OF 3) (CASHMERE)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 3)
15294093 PANEL, BODY SI TR (INCLS 1, 2, 12) (TITANIUM) (INCLS HIGH VOLTAGE PWR OUTLET 25858121) (W/LATCH)
15885778 PANEL, BODY SI TR (INCLS 1, 2, 12) (TITANIUM) (W/O LATCH)
15294091 PANEL, BODY SI TR (INCLS 1, 2, 12) (CASHMERE) (INCLS HIGH VOLTAGE PWR OUTLET 25858121)
15904065 PANEL, BODY SI TR (INCLS 1, 2, 12) (EBONY)
25902628 PANEL, BODY SI TR (INCLS 1, 2, 12) (CASHMERE)
20765250 PANEL, BODY SI TR (INCLS 1, 2, 12) (LINEN)
15901363 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (GRAY)
15862682 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (CASHMERE) (W/O SPKR) (MOLDING ONLY)
15901352 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (CASHMERE) (W/O SPEAKER)
25815096 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (GRAY) (W/SPKR)
25818939 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (GRAY) (W/SPKR)
25818940 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (CASHMERE) (W/SPKR)
25886908 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (CASHMERE) (W/SPEAKER)
15862681 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (GRAY) (W/O SPKR) (MOLDING ONLY)
25827851 PLUG, BODY RR COR UPR GARN MLDG (PART OF 4) (LINEN)
15278015 PLUG, BODY RR COR UPR GARN MLDG (PART OF 4) (LT CHASHMERE)
15278014 PLUG, BODY RR COR UPR GARN MLDG (PART OF 4) (GRAY)
11609539 SCREW, RD CROWNED WA HD, M4.2X1.41X16, STL ISO 2702, GMW4205 (PART OF 4)
11509253 SCREW, W/LRG WA HD, M4.2X1.4X10, 11.3 O.D., BHL PT, STL, NO (PART OF 4)
15186672 SPEAKER, RDO BODY RR COR UPR GARN MLDG (PART OF 4) (ACDelco #15186672)
teamcadillac.ru
11561654 RETAINER, BODY RR COR G/MLDG (PART OF 4) (PLAIN) (BIRD'S BEAK SINGLE) (FITS 8.5 DIA HOLE) (12.800)
11609651 RETAINER, BODY RR COR G/MLDG (PART OF 4) (METAL PUSH-IN NUT, M4.2X1.41, 21.8X15X20.5) (14.731)
25858121 RECEPTACLE, ACSRY PWR (PART OF 3) (110 VOLT) (ACSRY PWR RECEPTACLE ASSEM LABELED 25858121)
(TC16-265) 2010-2011 CK1(06) КОНСОЛЬ/ПОЛ (CADILLAC Z75, EXC PLATINUM EDITION ULT)
11609509 SCREW, LG RD WA HD, C/R, HI-LO, 4.2X1.41X13, 11.35-OD, B PT, 6010, GMW4205 (PART OF 1)
15886900 MODULE, HTR & A/C & RDO CONT
10375379 ADAPTER, AUDIO/VIDEO DISC PLYR (ACDelco #10375379)
22596346 BUMPER, F/FLR RR CNSL A/RST (W/DURAMETER 30) (LENGTH 29MM) (10.242)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (F/FLR CNSL SI T/PNL)
15833953 COVER, HTR & A/C CONT OPG
20983936 RETAINER, ACSRY PWR RCPT (EBONY) (FOR 2010&FUTURE W/USR WHEN REPL 25793816 USE T/W CVR 20983937) (ALUMINUM RING) (W/O USB COVER)
25774623 RECEPTACLE, ACSRY PWR (EBONY) (W/O COVER) (ACSRY PWR RECEPTACLE ASSEM LABELED 25774623) (12V)
15133100 LINER, F/FLR CNSL RR CUP HLDR (PART OF 19)
11609509 SCREW, LG RD WA HD, C/R, HI-LO, 4.2X1.41X13, 11.35-OD, B PT, 6010, GMW4205 (PART OF 36)
11589106 SCREW, RND WA HD, M4.2X1.41X25, 19.2 THD, 11.3 OD, 6010M, GMW4205, C/R, TAP, (PART OF 36) (10.774)
teamcadillac.ru
11609509 SCREW, LG RD WA HD, C/R, HI-LO, 4.2X1.41X13, 11.35-OD, B PT, 6010, GMW4205 (PART OF 19)
15133101 BUSHING, F/FLR CNSL CUP HLDR DR HGE (PART OF 19)
15133093 HOLDER, F/FLR CNSL RR CUP (INCLS 13, 17, 18)
20888557 HARNESS, F/FLR CNSL WRG
22825331 HARNESS, F/FLR CNSL WRG
11562473 BOLT, F/SEAT (M12X1.75X45)
15035434 NUT, F/SEAT (M10X1.5X10.8) (FLANGE NUT) (16.679)
15220791 PANEL, F/FLR CNSL SI TR (PART OF 36) (INCLS 32) (EBONY)
15220793 PANEL, F/FLR CNSL SI TR (PART OF 36) (INCLS 32) (EBONY)
25906812 PANEL, F/FLR CNSL SI TR (PART OF 36) (INCLS 32) (CASHMERE)
25906813 PANEL, F/FLR CNSL SI TR (PART OF 36) (INCLS 32) (CASHMERE)
15238666 PANEL, F/FLR CNSL SI TR FRT (INCLS 30, 31) (SEE GROUP 16.000 "INSTRUMENT PANEL/TRIM" FOR DETAILED ILLUSTRATED VIEW.) (EBONY) (16.081)
25901544 PANEL, F/FLR CNSL SI TR FRT (INCLS 30, 31) (SEE GROUP 16.000 "INSTRUMENT PANEL/TRIM" FOR DETAILED ILLUSTRATED VIEW.) (CASHMERE)
25844279 PANEL, F/FLR CNSL SI TR FRT (INCLS 30, 31) (SEE GROUP 16.000 "INSTRUMENT PANEL/TRIM" FOR DETAILED ILLUSTRATED VIEW.) (EBONY)
25901545 PANEL, F/FLR CNSL SI TR FRT (INCLS 30, 31) (SEE GROUP 16.000 "INSTRUMENT PANEL/TRIM" FOR DETAILED ILLUSTRATED VIEW.) (CASHMERE)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 29)
11562257 RETAINER, I/P LWR TR PAD BRKT (PUSH ON) (PART OF 29) (19.5 X 30.4 X 1.8) (14.683)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 28, 36)
15187371 RETAINER, ACSRY PWR RCPT (PART OF 36) (EBONY) (INCLS COVER)
25774623 RECEPTACLE, ACSRY PWR (PART OF 36) (EBONY) (W/O COVER) (ACSRY PWR RECEPTACLE ASSEM LABELED 25774623) (12V)
20898108 COMPARTMENT, F/FLR (INCLS 14-16, 21, 22, 24, 25, 28, 32-35, 47) (EBONY)
20898109 COMPARTMENT, F/FLR (INCLS 14-16, 21, 22, 24, 25, 28, 32-35, 47) (CASHMERE)
20898112 COMPARTMENT, F/FLR (INCLS 14-16, 21, 22, 24, 25, 28, 32-35, 47) (CASHMERE)
20898117 COMPARTMENT, F/FLR (INCLS 14-16, 21, 22, 24, 25, 28, 32-35, 47) (EBONY)
20898118 COMPARTMENT, F/FLR (INCLS 14-16, 21, 22, 24, 25, 28, 32-35, 47) (CASHMERE)
20898120 COMPARTMENT, F/FLR (INCLS 14-16, 21, 22, 24, 25, 28, 32-35, 47) (EBONY)
20898121 COMPARTMENT, F/FLR (INCLS 14-16, 21, 22, 24, 25, 28, 32-35, 47) (CASHMERE)
20944039 COMPARTMENT, F/FLR (INCLS 14-16, 21, 22, 24, 25, 28, 32-35, 47) (EBONY)
11609460 SCREW, RND WA, M4.2X1.41X10, 4.2 THD, 11 OD, GM6010M, GMW4205, C/R, TAP (PART OF 39)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 39)
20907562 BEZEL, F/FLR FRT CNSL ACSRY TR (INCLS 37, 38, 40-43, 45, 46) (RUBY)
20907563 BEZEL, F/FLR FRT CNSL ACSRY TR (INCLS 37, 38, 40-43, 45, 46) (CHOCOLATE BURL)
15683368 BUMPER, F/FLR CNSL COMPT DR (PART OF 39) (16MM STEM, 8MM DIA) (CLOSED-STOP) (FRAME)
22596346 BUMPER, F/FLR CNSL CUP HLDR (PART OF 39) (W/DURAMETER 30) (LENGTH 29MM) (10.242)
15132973 ASHTRAY, F/FLR CNSL (PART OF 39)
15132964 HOLDER, F/FLR CNSL CUP (PART OF 39)
11516140 LIGHTER, CIG (BLACK) (W/LARGE PLASTIC KNOB END 21.0MM)
25776667 RECEPTACLE, ACSRY PWR (PART OF 39) (2 TERMINALS)
20983936 RETAINER, ACSRY PWR RCPT (PART OF 39) (EBONY) (FOR 2010&FUTURE W/USR WHEN REPL 25793816 USE T/W CVR 20983937) (ALUMINUM RING) (W/O USB COVER)
20944418 RECEPTACLE, USB (PART OF 36)
(TC16-271) 2010-2011 CK1(06) КОНСОЛЬ/ПОЛ (CADILLAC Z75, PLATINUM EDITION ULT)
11609509 SCREW, LG RD WA HD, C/R, HI-LO, 4.2X1.41X13, 11.35-OD, B PT, 6010, GMW4205 (PART OF 39)
15886900 MODULE, HTR & A/C & RDO CONT (ACDelco #15886900)
22596346 BUMPER, F/FLR RR CNSL A/RST (PART OF 39) (W/DURAMETER 30) (LENGTH 29MM) (10.242)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 10)
teamcadillac.ru
15833953 COVER, HTR & A/C CONT OPG (INCLS 9)
10364311 DOOR, ACSRY PWR RCPT (CHROME RING W/BLACK CAP)
15133100 LINER, F/FLR CNSL RR CUP HLDR (PART OF 14, 39)
15133093 HOLDER, F/FLR CNSL RR CUP (INCLS 13, 18, 19) (PART OF 39)
11589106 SCREW, RND WA HD, M4.2X1.41X25, 19.2 THD, 11.3 OD, 6010M, GMW4205, C/R, TAP, (PART OF 39) (10.774)
11609509 SCREW, LG RD WA HD, C/R, HI-LO, 4.2X1.41X13, 11.35-OD, B PT, 6010, GMW4205 (PART OF 14, 39)
15133101 BUSHING, F/FLR CNSL CUP HLDR DR HGE (PART OF 14, 39)
20888557 HARNESS, F/FLR CNSL WRG (PART OF 39)
20888559 HARNESS, F/FLR CNSL WRG (PART OF 39)
22825331 HARNESS, F/FLR CNSL WRG (PART OF 39)
20944419 AMPLIFIER, RDO SPKR (PART OF 39) (ACDelco #20944419)
25830462 PANEL, F/FLR CNSL SI TR (INCLS 34) (PART OF 39) (COCOA)
25830464 PANEL, F/FLR CNSL SI TR (INCLS 34) (PART OF 39) (COCOA)
25830634 DUCT, AIR INL (PART OF 39)
15876585 PANEL, F/FLR CNSL SI TR FRT (INCLS 32, 33) (SEE GROUP 16.000 "INSTRUMENT PANEL/TRIM" FOR DETAILED ILLUSTRATED VIEW) (LINEN)
15876587 PANEL, F/FLR CNSL SI TR FRT (INCLS 32, 33) (SEE GROUP 16.000 "INSTRUMENT PANEL/TRIM" FOR DETAILED ILLUSTRATED VIEW) (LINEN)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 31)
11562257 RETAINER, I/P LWR TR PAD BRKT (PUSH ON) (PART OF 31) (19.5 X 30.4 X 1.8) (14.683)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 28, 39)
15187371 RETAINER, ACSRY PWR RCPT (PART OF 39) (EBONY) (INCLS COVER)
25774623 RECEPTACLE, ACSRY PWR (PART OF 39) (EBONY) (W/O COVER) (ACSRY PWR RECEPTACLE ASSEM LABELED 25774623) (12V)
20898103 COMPARTMENT, F/FLR (INCLS 2-4, 8, 13-25, 28-30, 34, 35, 37, 38, 50) (COCOA)
22876532 COMPARTMENT, F/FLR (INCLS 2-4, 8, 13-25, 28-30, 34, 35, 37, 38, 50) (LINEN)
11609460 SCREW, RND WA, M4.2X1.41X10, 4.2 THD, 11 OD, GM6010M, GMW4205, C/R, TAP (PART OF 43)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 43)
20907565 BEZEL, F/FLR FRT CNSL ACSRY TR (INCLS 36, 40-42, 44-46, 48, 49) (SOLITARE)
15683368 BUMPER, F/FLR CNSL COMPT DR (PART OF 43) (16MM STEM, 8MM DIA) (CLOSED-STOP) (FRAME)
10446032 BUMPER, F/FLR CNSL COMPT DR (PART OF 43) (8.80 DIA) (CLOSED-STOP) (FRAME) (10.263)
15132973 ASHTRAY, F/FLR CNSL (PART OF 43)
25776667 RECEPTACLE, C/LTR (PART OF 43) (2 TERMINALS)
20983936 RETAINER, ACSRY PWR RCPT (PART OF 43) (EBONY) (FOR 2010&FUTURE W/USR WHEN REPL 25793816 USE T/W CVR 20983937) (ALUMINUM RING) (W/O USB COVER)
20944418 RECEPTACLE, USB (PART OF 39)
(TC16-315) 2008-2013 CK107(06) КРЕПЛЕНИЕ ЗАДНЕГО СИДЕНЬЯ (60/40 BENCH AM8, HYBRID HP2)
25906782 COVER, R/SEAT RSR FIN (INCLS 2, 3, 11) (CASHMERE) (MAIN COVER)
25947245 COVER, R/SEAT RSR FIN (INCLS 2, 3, 11) (TITANIUM)
20848509 COVER, R/SEAT RSR FIN (INCLS 2, 3, 11) (COCOA)
20986822 COVER, R/SEAT RSR FIN (INCLS 2, 3, 11) (EBONY)
25813593 COVER, R/SEAT RSR INR FIN (PART OF 1) (EBONY)
25813595 COVER, R/SEAT RSR INR FIN (PART OF 1) (TITANIUM)
20820025 COVER, R/SEAT RSR INR FIN (PART OF 1) (LINEN)
25813594 COVER, R/SEAT RSR INR FIN (PART OF 1) (CASHMERE)
11509253 SCREW, W/LRG WA HD, M4.2X1.4X10, 11.3 O.D., BHL PT, STL, NO (PART OF 1)
20761380 SEAT, RR (EBONY)
20761383 SEAT, RR (EBONY)
15843772 SEAT, RR (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960236)
15843847 SEAT, RR (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960254)
15914185 SEAT, RR (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20959983)
15914187 SEAT, RR (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20959985)
25835080 SEAT, RR (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960239)
25835089 SEAT, RR (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960257)
25908002 SEAT, RR (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960240)
25908006 SEAT, RR (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960258)
15843802 SEAT, RR (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960272)
15843859 SEAT, RR (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960281)
25835185 SEAT, RR (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960284)
20789565 SEAT, RR (COCOA)
20789567 SEAT, RR (COCOA)
20905015 SEAT, RR (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960038)
20905016 SEAT, RR (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960039)
20905021 SEAT, RR (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960041)
20905022 SEAT, RR (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960042)
20761372 SEAT, RR (EBONY)
20761373 SEAT, RR (CASHMERE)
20761374 SEAT, RR (TITANIUM)
20761376 SEAT, RR (EBONY)
20761377 SEAT, RR (CASHMERE)
20761378 SEAT, RR (TITANIUM)
20761381 SEAT, RR (CASHMERE)
20761384 SEAT, RR (CASHMERE)
20959983 SEAT, RR (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 15914185)
20959985 SEAT, RR (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 15914187)
20960038 SEAT, RR (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 20905015)
20960039 SEAT, RR (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 20905016)
20960041 SEAT, RR (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 20905021)
20960042 SEAT, RR (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 20905022)
20960236 SEAT, RR (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 15843772)
20960237 SEAT, RR (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25908001)
20960239 SEAT, RR (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25835080)
20960240 SEAT, RR (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25908002)
20960254 SEAT, RR (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 15843847)
20960255 SEAT, RR (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25908005)
20960257 SEAT, RR (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25835089)
20960258 SEAT, RR (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25908006)
25908001 SEAT, RR (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960237)
25908005 SEAT, RR (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960255)
20795283 SEAT, RR (EBONY)
20795284 SEAT, RR (CASHMERE)
20795286 SEAT, RR (EBONY)
20795287 SEAT, RR (CASHMERE)
20830606 SEAT, RR (EBONY)
20830607 SEAT, RR (CASHMERE)
20830609 SEAT, RR (EBONY)
20830610 SEAT, RR (CASHMERE)
20960272 SEAT, RR (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 15843802)
20960273 SEAT, RR (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25908009)
20960275 SEAT, RR (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25835182)
20960276 SEAT, RR (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25908010)
20960281 SEAT, RR (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 15843859)
20960282 SEAT, RR (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25908011)
20960284 SEAT, RR (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25835185)
20960285 SEAT, RR (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25908012)
25835182 SEAT, RR (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960275)
25908009 SEAT, RR (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960273)
25908010 SEAT, RR (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960276)
25908011 SEAT, RR (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960282)
25908012 SEAT, RR (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960285)
25947239 COVER, R/SEAT FRM OTR FIN (INCLS 6, 7) (EBONY)
teamcadillac.ru
25947241 COVER, R/SEAT FRM OTR FIN (INCLS 6, 7) (TITANIUM)
25947240 COVER, R/SEAT FRM OTR FIN (INCLS 6, 7) (CASHMERE)
20848508 COVER, R/SEAT FRM OTR FIN (INCLS 6, 7) (COCOA)
15894130 LABEL, BAT (PART OF 5)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 5)
03537772 NUT, M12X1.75, 10.6THK, 28 O.D., 10, 7111M (R/SEAT) (8.917)
25898240 COVER, R/SEAT FRM FRT FIN (INCLS 9) (TITANIUM)
25924173 COVER, R/SEAT FRM FRT FIN (INCLS 9) (EBONY)
20848507 COVER, R/SEAT FRM FRT FIN (INCLS 9) (COCOA)
25924174 COVER, R/SEAT FRM FRT FIN (INCLS 9) (CASHMERE)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 1)
(TC16-333) 2008-2013 CK1,2(06) ЗАДНЕЕ СИДЕНЬЕ #2 (3RD ROW)-RH(AS3)
22760806 SEAT, 3RD ROW (INCLS 2-46) (EBONY)
22760807 SEAT, 3RD ROW (INCLS 2-46) (CASHMERE)
22760812 SEAT, 3RD ROW (INCLS 2-46) (EBONY)
22760813 SEAT, 3RD ROW (INCLS 2-46) (CASHMERE)
22760815 SEAT, 3RD ROW (INCLS 2-46) (EBONY)
22760816 SEAT, 3RD ROW (INCLS 2-46) (CASHMERE)
22760821 SEAT, 3RD ROW (INCLS 2-46) (EBONY)
22760822 SEAT, 3RD ROW (INCLS 2-46) (CASHMERE)
22760835 SEAT, 3RD ROW (INCLS 2-46) (EBONY)
22760843 SEAT, 3RD ROW (INCLS 2-46) (EBONY)
22760849 SEAT, 3RD ROW (INCLS 2-46) (COCOA)
22760853 SEAT, 3RD ROW (INCLS 2-46) (COCOA)
22760829 SEAT, 3RD ROW (INCLS 2-46) (COCOA)
22760886 SEAT, 3RD ROW (INCLS 2-46) (EBONY)
22760887 SEAT, 3RD ROW (INCLS 2-46) (CASHMERE)
15804529 PAD, 3RD ROW SEAT BK
15863451 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
15863452 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE)
15865842 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
15833506 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE)
15833505 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
15863458 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
15863459 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE)
20904837 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
20904838 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE)
20904931 RESTRAINT, R/SEAT HD (INCLS 3) (CASHMERE)
15913991 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
15827642 RESTRAINT, R/SEAT HD (INCLS 3) (EBONY)
15279353 GUIDE, 3RD ROW SEAT H/RST (TITANIUM) (W/O BUTTON)
25851751 GUIDE, 3RD ROW SEAT H/RST (COCOA) (W/O BUTTON)
20912677 GUIDE, 3RD ROW SEAT H/RST (COCOA) (W/BUTTON)
20912675 GUIDE, 3RD ROW SEAT H/RST (CASHMERE) (W/BUTTON)
20912676 GUIDE, 3RD ROW SEAT H/RST (TITANIUM) (W/BUTTON)
15804525 GUIDE, 3RD ROW SEAT H/RST (EBONY)
25943771 GUIDE, 3RD ROW SEAT H/RST (COCOA)
25869335 BRACKET, R/SEAT 3RD ROW BELT (RETR SI)
11570116 SCREW, PAN HD, M6X1X10, 10 THD, 12 OD, STL SAE J1237, S424, TAPTITE ITE (R/SEAT RSR FIN CVR) (8.913)
15827662 COVER, R/SEAT HGE FIN (OUTBOARD)
15827667 COVER, R/SEAT HGE FIN (INBOARD)
19207592 BELT KIT, R/SEAT #2 CTR (RETR SI) (INCLS 8) (CASHMERE)
19207593 BELT KIT, R/SEAT #2 CTR (RETR SI) (INCLS 8) (COCOA)
19207590 BELT KIT, R/SEAT #2 CTR (RETR SI) (INCLS 8) (CASHMERE)
19207591 BELT KIT, R/SEAT #2 CTR (RETR SI) (INCLS 8) (TITANIUM)
19207589 BELT KIT, R/SEAT #2 CTR (RETR SI) (INCLS 8) (EBONY)
15898352 BELT, 3RD ROW CTR SEAT BELT (INCLS 8) (EBONY)
25906826 BELT, 3RD ROW CTR SEAT BELT (INCLS 8) (CASHMERE)
25940416 BELT, 3RD ROW CTR SEAT BELT (INCLS 8) (COCOA)
11562382 BOLT, HFH, M10X1.5X130, 26 THD, 22.3 OD, 10.9, 7114M, MACH, MAT-PT (3RD ROW SEAT BK)
11562383 BOLT, 3RD ROW SEAT BELT ANC (M12X1.75X30.5) (8.900)
15898362 FRAME, 3RD ROW SEAT BK
25960399 FRAME, 3RD ROW SEAT BK
15898399 FRAME, 3RD ROW SEAT BK
teamcadillac.ru
20963262 KNOB, 3RD ROW SEAT BK LAT REL (EBONY) (OUTER)
20963265 KNOB, 3RD ROW SEAT BK LAT REL (EBONY) (INNER) (W/NUMBER LABELS ON 3RD ROW SEAT) (FOR 1ST DES SEE 15279464)
15279464 KNOB, 3RD ROW SEAT BK LAT REL (EBONY) (16.716) (W/O NUMBER LABELS ON 3RD ROW SEAT) (FOR 2ND DES SEE 20963265)
19180590 BELT KIT, R/SEAT #2 (BKL SI) (COCOA)
19152523 BELT KIT, R/SEAT #2 (BKL SI) (CASHMERE) (SINGLE BKL)
19152524 BELT KIT, R/SEAT #2 (BKL SI) (TITANIUM) (SINGLE BKL)
19152522 BELT KIT, R/SEAT #2 (BKL SI) (EBONY) (SINGLE BKL)
15832214 LEVER, R/SEAT RSR LAT REL
25913455 LATCH, 3RD ROW SEAT BK (CENTER)
15944449 COVER, 3RD ROW SEAT BK LAT (EBONY) (INBOARD, OUTER)
15944450 COVER, 3RD ROW SEAT BK LAT (CASHMERE) (INBOARD, OUTER)
15804522 COVER, 3RD ROW SEAT BK LAT (TITANIUM) (INBOARD, OUTER) (16.716)
25858774 COVER, 3RD ROW SEAT BK LAT (COCOA) (INBOARD, OUTER)
19127809 BOLT, 3RD ROW SEAT BK LAT (M12X1.75X63.9) (16.679)
15822384 COVER, 3RD ROW SEAT BK HGE FIN (EBONY)
15822385 COVER, 3RD ROW SEAT BK HGE FIN (CASHMERE)
15822386 COVER, 3RD ROW SEAT BK HGE FIN (TITANIUM)
25858775 COVER, 3RD ROW SEAT BK HGE FIN (COCOA)
15804515 COVER, 3RD ROW SEAT BK LAT (EBONY) (INBOARD, INNER)
15804516 COVER, 3RD ROW SEAT BK LAT (CASHMERE) (INBOARD, INNER)
15804517 COVER, 3RD ROW SEAT BK LAT (TITANIUM) (INBOARD, INNER)
25858773 COVER, 3RD ROW SEAT BK LAT (COCOA) (INBOARD, INNER)
20963255 HANDLE, R/SEAT LAT REL (PART OF 28) (EBONY) (W/NUMBER LABELS ON 3RD ROW SEAT) (FOR 1ST DES SEE 15822356)
20963257 HANDLE, R/SEAT LAT REL (PART OF 28) (TITANIUM) (W/NUMBER LABELS ON 3RD ROW SEAT) (FOR 1ST DES SEE 15822358)
15822356 HANDLE, R/SEAT LAT REL (PART OF 28) (EBONY) (W/O NUMBER LABELS ON 3RD ROW SEAT) (FOR 2ND DES SEE 20963255)
15822357 HANDLE, R/SEAT LAT REL (PART OF 28) (CASHMERE) (W/O NUMBER LABELS ON 3RD ROW SEAT) (FOR 2ND DES SEE 20963256)
15822358 HANDLE, R/SEAT LAT REL (PART OF 28) (TITANIUM) (W/O NUMBER LABELS ON 3RD ROW SEAT) (FOR 2ND DES SEE 20963257)
20963256 HANDLE, R/SEAT LAT REL (PART OF 28) (CASHMERE) (W/NUMBER LABELS ON 3RD ROW SEAT) (FOR 1ST DES SEE 15822357)
22906161 HANDLE, R/SEAT LAT REL (PART OF 28)
25913454 CABLE, 3RD ROW SEAT BK LAT
15924954 LATCH, 3RD ROW SEAT LOAD FLR (INBOARD REAR)
15804397 LATCH, 3RD ROW SEAT LOAD FLR (OUTBOARD REAR)
20963267 CABLE, 3RD ROW SEAT BK LAT (INCLS 23) (EBONY) (50% MAIN CONTROL BOX)
20963268 CABLE, 3RD ROW SEAT BK LAT (INCLS 23) (CASHMERE) (50% MAIN CONTROL BOX)
20963269 CABLE, 3RD ROW SEAT BK LAT (INCLS 23) (TITANIUM) (50% MAIN CONTROL BOX)
20963270 CABLE, 3RD ROW SEAT BK LAT (INCLS 23) (COCOA) (50% MAIN CONTROL BOX)
15832238 CABLE, 3RD ROW SEAT BK LAT (INCLS 23) (EBONY) (W/PULL HANDLE) (50% MAIN CONTROL BOX)
15832239 CABLE, 3RD ROW SEAT BK LAT (INCLS 23) (CASHMERE) (W/PULL HANDLE) (50% MAIN CONTROL BOX)
15832240 CABLE, 3RD ROW SEAT BK LAT (INCLS 23) (TITANIUM) (W/PULL HANDLE) (50% MAIN CONTROL BOX)
15804473 COVER, 3RD ROW SEAT BK LAT (EBONY) (REAR CLOSEOUT)
15804474 COVER, 3RD ROW SEAT BK LAT (CASHMERE) (REAR CLOSEOUT) (16.716)
15804475 COVER, 3RD ROW SEAT BK LAT (TITANIUM) (REAR CLOSEOUT) (16.716)
22740564 COVER, 3RD ROW SEAT BK LAT (EBONY)
25858769 COVER, 3RD ROW SEAT BK LAT (COCOA) (REAR CLOSEOUT)
15898402 LATCH, 3RD ROW SEAT LOAD FLR (INCLS 45, 46) (INCLS INBOARD AND OUTBOARD)
15804478 COVER, 3RD ROW SEAT BK LAT (EBONY) (FRONT CLOSEOUT) (16.716)
15804479 COVER, 3RD ROW SEAT BK LAT (CASHMERE) (FRONT CLOSEOUT) (16.716)
15804480 COVER, 3RD ROW SEAT BK LAT (TITANIUM) (FRONT CLOSEOUT) (16.716)
25858770 COVER, 3RD ROW SEAT BK LAT (COCOA) (FRONT CLOSEOUT)
15926524 FRAME, 3RD ROW SEAT CUSH
15898407 COVER, 3RD ROW SEAT BK LAT (EBONY) (OUTBOARD, OUTER)
15898408 COVER, 3RD ROW SEAT BK LAT (CASHMERE) (OUTBOARD, OUTER)
15898409 COVER, 3RD ROW SEAT BK LAT (TITANIUM) (OUTBOARD, OUTER) (16.716)
25858772 COVER, 3RD ROW SEAT BK LAT (COCOA) (OUTBOARD, OUTER)
25928521 LATCH, 3RD ROW SEAT BK
15804493 COVER, 3RD ROW SEAT BK LAT (EBONY) (OUTBOARD, INNER) (16.716)
15804494 COVER, 3RD ROW SEAT BK LAT (CASHMERE) (OUTBOARD, INNER) (16.716)
15804495 COVER, 3RD ROW SEAT BK LAT (TITANIUM) (OUTBOARD, INNER) (16.716)
25858771 COVER, 3RD ROW SEAT BK LAT (COCOA) (OUTBOARD, INNER)
19207603 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (COCOA)
19207600 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (CASHMERE)
19207601 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (TITANIUM)
19207599 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (EBONY)
25906825 BELT, R/SEAT #2 (RETR SI) (INCLS 8) (CASHMERE)
25940415 BELT, R/SEAT #2 (RETR SI) (INCLS 8) (COCOA)
25869320 BELT, R/SEAT #2 (RETR SI) (INCLS 8) (EBONY)
15827657 COVER, R/SEAT HGE FIN (OUTBOARD)
15804404 CABLE, 3RD ROW SEAT BK LAT (LOCK OUT)
15804533 PAD, 3RD ROW SEAT CUSH
25858737 COVER, 3RD ROW SEAT CUSH (COCOA)
25937625 COVER, 3RD ROW SEAT CUSH (EBONY)
25937626 COVER, 3RD ROW SEAT CUSH (CASHMERE)
25937627 COVER, 3RD ROW SEAT CUSH (TITANIUM)
20859438 COVER, 3RD ROW SEAT CUSH (CASHMERE)
20904822 COVER, 3RD ROW SEAT CUSH (EBONY)
20904824 COVER, 3RD ROW SEAT CUSH (CASHMERE)
25928483 COVER, 3RD ROW SEAT CUSH (EBONY)
22751178 COVER, 3RD ROW SEAT CUSH (EBONY)
25928485 COVER, 3RD ROW SEAT CUSH (TITANIUM)
25928484 COVER, 3RD ROW SEAT CUSH (CASHMERE)
15865797 COVER, 3RD ROW SEAT BK (INCLS CHILD COMFORT GUIDE) (EBONY)
25858735 COVER, 3RD ROW SEAT BK (COCOA)
20859432 COVER, 3RD ROW SEAT BK (INCLS CHILD COMFORT GUIDE) (CASHMERE)
20904828 COVER, 3RD ROW SEAT BK (EBONY) (W/CHILD SEAT BELT COMFORT GUIDE)
20904830 COVER, 3RD ROW SEAT BK (CASHMERE)
20859431 COVER, 3RD ROW SEAT BK (INCLS CHILD COMFORT GUIDE) (EBONY)
15924920 PANEL, R/SEAT BK FIL
25784336 RETAINER, R/SEAT BK OPG FIN CVR (PUSH IN) (16.720)
15924917 WIRE, R/SEAT CUSH BRDR
25895133 BAR, R/SEAT HGE LINK TIE (PART OF 30)
(TC16-360) 2007-2013 CK107(06) ОТДЕЛКА ВНУТРЕННЯЯ-BODY SIDE REAR (CADILLAC Z75)
15877373 PLATE, R/FLR RR TR (INCLS 17, 18) (LINEN)
15931763 PLATE, R/FLR RR TR (INCLS 17, 18) (EBONY) (W/ CADILLAC INSERT)
25902618 PLATE, R/FLR RR TR (INCLS 17, 18) (CASHMERE)
15905683 MOLDING, BK BODY OPG GARN (INCLS 3) (GRAY)
15936713 MOLDING, BK BODY OPG GARN (INCLS 3) (LINEN)
15905684 MOLDING, BK BODY OPG GARN (INCLS 3) (CASHMERE)
11561654 RETAINER, BODY RR COR G/MLDG (PART OF 2) (PLAIN) (BIRD'S BEAK SINGLE) (FITS 8.5 DIA HOLE) (12.800)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 10, 19)
teamcadillac.ru
11609651 CLIP, BODY L/PLR G/MLDG (PART OF 10, 19) (METAL PUSH-IN NUT, M4.2X1.41, 21.8X15X20.5) (14.731)
15877412 PLATE, RR S/D SILL TR (INCLS 8) (LINEN)
25902616 PLATE, RR S/D SILL TR (INCLS 8) (CASHMERE)
15873285 PLATE, RR S/D SILL TR (INCLS 8) (EBONY) (W/CADILLAC INSERT)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 7)
15043000 PLUG, R/CMPT SILL TR PLT HOLE (38.0 X 17.0 X 18.0MM) (OBLONG) (16.600)
15877445 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15) (LINEN)
15875107 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15) (CASHMERE) (MOLDED IN COLOR FLECKED PLASTIC UPR TR)
20844007 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15) (LINEN)
20844008 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15) (LINEN)
15900726 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15) (CASHMERE) (DUAL TONE PART) (GRANITE CASHMERE UPR)
20986797 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15) (CASHMERE) (DUAL TONE PART) (CASHMERE GRANITE UPR)
20986791 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15) (EBONY) (DUAL TONE PART) (GRANITE OPAL UPR)
20986796 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15) (EBONY) (DUAL TONE PART) (GRAY UPR)
15877443 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15) (LINEN)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 10, 19)
15295390 BEZEL, R/SEAT BELT OPG (PART OF 10, 19) (EBONY)
15295394 BEZEL, R/SEAT BELT OPG (PART OF 10, 19) (EBONY)
25827829 BEZEL, R/SEAT BELT OPG (PART OF 10, 19) (LINEN)
25827831 BEZEL, R/SEAT BELT OPG (PART OF 10, 19) (LINEN)
25903597 BEZEL, R/SEAT BELT OPG (PART OF 10, 19) (CASHMERE)
25903598 BEZEL, R/SEAT BELT OPG (PART OF 10, 19) (CASHMERE)
25827828 GUIDE, R/SEAT SHLDR BELT INTER (PART OF 10, 19) (LINEN)
15214079 GUIDE, R/SEAT SHLDR BELT INTER (PART OF 10, 19) (CASHMERE)
15214081 GUIDE, R/SEAT SHLDR BELT INTER (PART OF 10, 19) (EBONY)
11609465 BOLT, HWH, M4.2X1.41X18, 12.5 OD, 6010M, PS (PART OF 10, 19) (8.977)
25827826 PLUG, BODY L/PLR GARN MLDG (PART OF 10, 19) (LINEN)
25827830 PLUG, BODY L/PLR GARN MLDG (PART OF 10, 19) (LINEN)
15278075 PLUG, BODY L/PLR GARN MLDG (PART OF 10, 19) (GRAY)
15278076 PLUG, BODY L/PLR GARN MLDG (PART OF 10, 19) (GRAY)
15278083 PLUG, BODY L/PLR GARN MLDG (PART OF 10, 19) (CASHMERE)
15278084 PLUG, BODY L/PLR GARN MLDG (PART OF 10, 19) (CASHMERE)
15940206 COVER, L/GATE LK STKR (PART OF 1) (LINEN)
15274516 COVER, L/GATE LK STKR (PART OF 1) (EBONY)
20986776 COVER, L/GATE LK STKR (PART OF 1) (CASHMERE)
15877445 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (LINEN)
15900737 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (EBONY) (FOR VEHICLES LOCATED IN CHINA) (EBONY LWR, GRAY UPR)
15900743 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (EBONY) (FOR VEHICLES LOCATED IN CHINA) (EBONY LWR, GRAY UPR)
15900738 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (CASHMERE) (FOR VEHICLES LOCATED IN CHINA) (CASHMERE LWR, CASHMERE UPR) (MOLDED IN COLOR FLECKED PLASTIC UPR TR)
15900744 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (CASHMERE) (FOR VEHICLES LOCATED IN CHINA) (CASHMERE LWR, CASHMERE UPR)
22837613 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (EBONY) (FOR VEHICLES NOT LOCATED IN CHINA) (EBONY LWR, GRAY UPR)
22837614 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (CASHMERE) (FOR VEHICLES NOT LOCATED IN CHINA) (CASHMERE LWR, CASHMERE UPR)
22837618 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (EBONY) (FOR VEHICLES NOT LOCATED IN CHINA) (EBONY LWR, GRAY UPR)
22837619 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (CASHMERE) (FOR VEHICLES NOT LOCATED IN CHINA) (CASHMERE LWR, CASHMERE UPR) (MOLDED IN COLOR FLECKED PLASTIC UPR TR)
15877443 MOLDING, BODY L/PLR GARN (INCLS 5, 6, 11-15, 20, 21) (LINEN)
10388598 SWITCH, R/SEAT ADJR (PART OF 19) (ON GARNISH MOLDING)
15113408 SWITCH, R/SEAT ADJR (PART OF 19) (ON GARNISH MOLDING)
25827827 BEZEL, BODY L/PLR G/MLDG (PART OF 19) (LINEN)
15214084 BEZEL, BODY L/PLR G/MLDG (PART OF 19) (EBONY)
15214082 BEZEL, BODY L/PLR G/MLDG (PART OF 19) (CASHMERE)
(TC16-383) 2009-2013 CK107(06) ОТДЕЛКА ВНУТРЕННЯЯ-BODY SIDE-LH QUARTER DETAIL (CADILLAC Z75, EXC HYBRID HP2)
15885778 PANEL, BODY SI TR (INCLS 1, 2) (TITANIUM) (W/O LATCH)
15885777 PANEL, BODY SI TR (INCLS 1, 2) (CASHMERE)
15885779 PANEL, BODY SI TR (INCLS 1, 2) (EBONY)
15936654 PANEL, BODY SI TR (INCLS 1, 2) (LINEN)
15901354 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (GRAY) (W/O SPEAKER)
15877451 MOLDING, BODY RR COR UPR GARN (INCLS 5-11) (LINEN)
15278017 PLUG, BODY RR COR UPR GARN MLDG (PART OF 4) (GRAY)
teamcadillac.ru
(TC16-384) 2007-2013 CK107(06) ОТДЕЛКА ВНУТРЕННЯЯ-BODY SIDE-RH QUARTER DETAIL
25999672 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13) (CASHMERE) ( (W/O SPKR) (ORDER SPKR SEPARATE))
20881384 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13) (LINEN)
20881385 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13) (GRAY)
teamcadillac.ru
25999671 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13) (GRANITE) ( (W/O SPKR) (ORDER SPKR SEPARATE))
20986814 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13) (GRAY)
20986818 MOLDING, BODY RR COR UPR GARN (INCLS 2-7, 13) (CASHMERE)
15186672 SPEAKER, RDO BODY RR COR UPR GARN MLDG (PART OF 1, 15) (ACDelco #15186672)
11509253 SCREW, W/LRG WA HD, M4.2X1.4X10, 11.3 O.D., BHL PT, STL, NO (PART OF 1, 15)
11561654 RETAINER, BODY RR COR G/MLDG (PART OF 1, 15) (PLAIN) (BIRD'S BEAK SINGLE) (FITS 8.5 DIA HOLE) (12.800)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 1, 15)
11609508 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (PART OF 1, 15)
25827851 PLUG, BODY RR COR UPR GARN MLDG (PART OF 1, 15) (LINEN)
15278015 PLUG, BODY RR COR UPR GARN MLDG (PART OF 1, 15) (LT CHASHMERE)
15278014 PLUG, BODY RR COR UPR GARN MLDG (PART OF 1, 15) (GRAY)
15187371 RETAINER, C/LTR HSG (PART OF 10) (EBONY) (INCLS COVER)
25749635 RETAINER, C/LTR RCPT (PART OF 10) (EBONY) (W/O CAP)
25776667 RECEPTACLE, ACSRY PWR (PART OF 10) (2 TERMINALS)
15936655 PANEL, BODY SI TR (INCLS 8, 9, 11, 12) (LINEN)
20986766 PANEL, BODY SI TR (INCLS 8, 9, 11, 12) (EBONY)
20986768 PANEL, BODY SI TR (INCLS 8, 9, 11, 12) (CASHMERE)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 10)
11609651 RETAINER, BODY RR COR G/MLDG (PART OF 1, 15) (METAL PUSH-IN NUT, M4.2X1.41, 21.8X15X20.5) (14.731)
21997869 INDICATOR, RR OBJECT ALARM
(TC16-390) 2007-2013 CK107(06) ЗАДНЕЕ СИДЕНЬЕ/BUCKET-RH (BUCKET AL4)
25907997 SEAT, RR (INCLS 2-48) (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960579)
20960483 SEAT, RR (INCLS 2-48) (COCOA) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25942794)
20960560 SEAT, RR (INCLS 2-48) (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 15843790)
20960561 SEAT, RR (INCLS 2-48) (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25907993)
20960578 SEAT, RR (INCLS 2-48) (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 15843914)
20960579 SEAT, RR (INCLS 2-48) (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25907997)
15843790 SEAT, RR (INCLS 2-48) (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960560)
15843914 SEAT, RR (INCLS 2-48) (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960578)
25907993 SEAT, RR (INCLS 2-48) (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960561)
25942794 SEAT, RR (INCLS 2-48) (COCOA) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960483)
20960542 SEAT, RR (INCLS 2-48) (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 15842722)
20960543 SEAT, RR (INCLS 2-48) (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25907988)
20960551 SEAT, RR (INCLS 2-48) (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 15842716)
20960552 SEAT, RR (INCLS 2-48) (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25907990)
20960597 SEAT, RR (INCLS 2-48) (COCOA) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25949035)
15842716 SEAT, RR (INCLS 2-48) (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960551)
15842722 SEAT, RR (INCLS 2-48) (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960542)
25907988 SEAT, RR (INCLS 2-48) (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960543)
25907990 SEAT, RR (INCLS 2-48) (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960552)
25949035 SEAT, RR (INCLS 2-48) (COCOA) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960597)
25858418 COVER, R/SEAT BK (COCOA)
15865722 COVER, R/SEAT BK (EBONY)
15865723 COVER, R/SEAT BK (CASHMERE)
15865724 COVER, R/SEAT BK (TITANIUM)
25908028 COVER, R/SEAT BK (CASHMERE)
25931441 COVER, R/SEAT BK (EBONY)
25931442 COVER, R/SEAT BK (CASHMERE)
25931443 COVER, R/SEAT BK (TITANIUM)
25899570 COVER, R/SEAT BK (EBONY)
22771055 PAD, R/SEAT BK
15824670 RESTRAINT, R/SEAT HD (INCLS 4) (TITANIUM)
25858321 RESTRAINT, R/SEAT HD (INCLS 4) (COCOA)
15824669 RESTRAINT, R/SEAT HD (INCLS 4) (CASHMERE)
25928791 RESTRAINT, R/SEAT HD (INCLS 4) (CASHMERE)
15865813 RESTRAINT, R/SEAT HD (INCLS 4) (EBONY)
25928790 RESTRAINT, R/SEAT HD (INCLS 4) (EBONY)
15824676 RESTRAINT, R/SEAT HD (INCLS 4) (EBONY)
25928796 PAD, R/SEAT H/RST (INCLS 4) (CASHMERE)
20912675 GUIDE, R/SEAT H/RST (CASHMERE) (W/BUTTON)
20912677 GUIDE, R/SEAT H/RST (COCOA) (W/BUTTON)
15279347 GUIDE, R/SEAT H/RST (EBONY) (W/BUTTON)
teamcadillac.ru
20912676 GUIDE, R/SEAT H/RST (TITANIUM) (W/BUTTON)
20912679 GUIDE, R/SEAT H/RST (EBONY) (W/O BUTTON)
20912680 GUIDE, R/SEAT H/RST (CASHMERE) (W/O BUTTON)
15279353 GUIDE, R/SEAT H/RST (TITANIUM) (W/O BUTTON)
25851751 GUIDE, R/SEAT H/RST (COCOA) (W/O BUTTON)
15269769 FRAME, R/SEAT BK
15279691 CAP, R/SEAT ACTR FIN CVR BOLT (TITANIUM)
25858335 CAP, R/SEAT ACTR FIN CVR BOLT (COCOA)
15279689 CAP, R/SEAT ACTR FIN CVR BOLT (EBONY)
15279690 CAP, R/SEAT ACTR FIN CVR BOLT (CASHMERE)
11570119 NUT, R/SEAT A/RST (T/W 11570115 STUD)
22785446 ARMREST, R/SEAT (EBONY) (ON VEHICLES BUILT PRIOR TO 4/2011 DEALER MAY NEED TO REMOVE STUD OFFFRAME PRIOR TO USING ARMREST WITH BOLT)
22785447 ARMREST, R/SEAT (CASHMERE) (ON VEHICLES BUILT PRIOR TO 4/2011 DEALER MAY NEED TO REMOVE STUD OFFFRAME PRIOR TO USING ARMREST WITH BOLT)
22785448 ARMREST, R/SEAT (TITANIUM) (ON VEHICLES BUILT PRIOR TO 4/2011 DEALER MAY NEED TO REMOVE STUD OFFFRAME PRIOR TO USING ARMREST WITH BOLT)
22785453 ARMREST, R/SEAT (EBONY) (ON VEHICLES BUILT PRIOR TO 4/2011 DEALER MAY NEED TO REMOVE STUD OFFFRAME PRIOR TO USING ARMREST WITH BOLT)
22785458 ARMREST, R/SEAT (COCOA) (ON VEHICLES BUILT PRIOR TO 4/2011 DEALER MAY NEED TO REMOVE STUD OFFFRAME PRIOR TO USING ARMREST WITH BOLT)
22785454 ARMREST, R/SEAT (ON VEHICLES BUILT PRIOR TO 4/2011 DEALER MAY NEED TO REMOVE STUD OFFFRAME PRIOR TO USING ARMREST WITH BOLT) (CASHMERE)
11570115 STUD, R/SEAT A/RST (T/W 11570119 NUT)
15824761 HEATER, R/SEAT CUSH
22771040 PAD, R/SEAT CUSH
15269765 FRAME, R/SEAT CUSH
11570116 SCREW, PAN HD, M6X1X10, 10 THD, 12 OD, STL SAE J1237, S424, TAPTITE ITE (R/SEAT LAT FIN CVR) (8.913)
11562384 NUT, HFH, M4X.7 THD, 4.75 THK, 10.5 OD, GM510M (9)STL, GM4435M-CODE A (R/SEAT FLR FIL T/PNL)
15280113 COVER, R/SEAT RECL INR FIN (EBONY) (INNER)
15280114 COVER, R/SEAT RECL INR FIN (CASHMERE) (INNER)
15280115 COVER, R/SEAT RECL INR FIN (TITANIUM) (INNER)
25858451 COVER, R/SEAT RECL INR FIN (COCOA) (INNER)
11562378 BOLT, HFH, M10X1.5X30, 18 THD, 22.3 OD, 10.9, GMW3359, W/ADH GM6175M (R/SEAT LAT)
15279464 KNOB, R/SEAT LAT (EBONY) (16.716) (W/O NUMBER LABELS ON 3RD ROW SEAT) (FOR 2ND DES SEE 20963265)
20963265 KNOB, R/SEAT LAT (EBONY) (INNER) (W/NUMBER LABELS ON 3RD ROW SEAT) (FOR 1ST DES SEE 15279464)
15279719 COVER, R/SEAT RECL INR FIN ( INCLS 41) (EBONY) (OUTER)
15279720 COVER, R/SEAT RECL INR FIN (INCLS 41) (CASHMERE) (OUTER)
15279721 COVER, R/SEAT RECL INR FIN (INCLS 41) (TITANIUM) (OUTER)
25858450 COVER, R/SEAT RECL INR FIN (INCLS 41) (COCOA) (OUTER)
19121596 BELT KIT, R/SEAT (BKL SI) (TITANIUM)
19180585 BELT KIT, R/SEAT (BKL SI) (COCOA)
19121595 BELT KIT, R/SEAT (BKL SI) (CASHMERE)
19121593 BELT KIT, R/SEAT (BKL SI) (EBONY)
25896462 RECLINER, R/SEAT INR (WHEN SERVICING VEHICLES BUILT PRIOR TO 06/01/06, DEALER NEEDS TO REPLACE BOTH INNER & OUTER IN SETS)
15275888 LATCH, R/SEAT RSR (INNER & OUTER)
11562380 BUSHING, R/SEAT HGE
15275901 SPRING, R/SEAT RECL (TUMBLE)
15275903 SPRING, R/SEAT RECL (MANDREL)
15275905 STRUT, R/SEAT (USED ON BOTH LH/RH)
25858467 PANEL, R/SEAT CUSH TR (COCOA)
22772267 PANEL, R/SEAT CUSH TR (EBONY)
22772268 PANEL, R/SEAT CUSH TR (CASHMERE)
22772269 PANEL, R/SEAT CUSH TR (TITANIUM)
15279609 COVER, R/SEAT RSR FIN (EBONY) (REAR)
15279610 COVER, R/SEAT RSR FIN (CASHMERE) (REAR)
15279611 COVER, R/SEAT RSR FIN (TITANIUM) (REAR)
25858447 COVER, R/SEAT RSR FIN (COCOA) (REAR)
22741877 RISER, R/SEAT
11562379 BOLT, R/SEAT HGE (M10X1.5X92)
15279599 COVER, R/SEAT RSR FIN (INCLS 34) (EBONY) (FRONT)
15279600 COVER, R/SEAT RSR FIN (INCLS 34) (CASHMERE) (FRONT)
15279601 COVER, R/SEAT RSR FIN (INCLS 34) (TITANIUM) (FRONT)
15843764 HARNESS, R/SEAT HTR
15279408 PIN, R/SEAT H/RST ADJ ROD LAT (TITANIUM)
25858342 PIN, R/SEAT H/RST ADJ ROD LAT (COCOA)
15279406 PIN, R/SEAT H/RST ADJ ROD LAT (EBONY)
15279407 PIN, R/SEAT H/RST ADJ ROD LAT (CASHMERE)
25816415 CABLE, R/SEAT BK LAT (OUTBOARD MASTER SYNC)
25816416 CABLE, R/SEAT LAT (INBOARD) (INBOARD MASTER SYNC)
15275914 CABLE, R/SEAT LAT (OUTBOARD) (FLOOR LATCH)
25896460 RECLINER, R/SEAT OTR (WHEN SERVICING VEHICLES BUILT PRIOR TO 06/01/06, DEALER NEEDS TO REPLACE BOTH INNER & OUTER IN SETS)
15279429 HANDLE, R/SEAT RECL (INCLS 42) (TITANIUM)
15279419 HANDLE, R/SEAT RECL (INCLS 42) (EBONY)
15279420 HANDLE, R/SEAT RECL (INCLS 42) (CASHMERE)
25858446 HANDLE, R/SEAT RECL (INCLS 42) (COCOA)
15279699 COVER, R/SEAT RECL OTR FIN (INCLS 41) (EBONY) (OUTER)
15279700 COVER, R/SEAT RECL OTR FIN ( INCLS 41) (CASHMERE) (OUTER)
15279701 COVER, R/SEAT RECL OTR FIN (INCLS 41) (TITANIUM) (OUTER)
25858448 COVER, R/SEAT RECL OTR FIN (INCLS 41) (COCOA) (OUTER)
15279709 COVER, R/SEAT RECL OTR FIN (EBONY) (INNER)
15279710 COVER, R/SEAT RECL OTR FIN (CASHMERE) (INNER)
15279711 COVER, R/SEAT RECL OTR FIN (TITANIUM) (INNER)
25858449 COVER, R/SEAT RECL OTR FIN (COCOA) (INNER)
15865730 COVER, R/SEAT CUSH (EBONY)
25858420 COVER, R/SEAT CUSH (COCOA)
15865731 COVER, R/SEAT CUSH (CASHMERE)
25931447 COVER, R/SEAT CUSH (EBONY)
25931449 COVER, R/SEAT CUSH (TITANIUM)
15865732 COVER, R/SEAT CUSH (TITANIUM)
25899558 COVER, R/SEAT CUSH (EBONY)
20905470 COVER, R/SEAT CUSH (CASHMERE)
15843763 HARNESS, ST RECL WRG (ELEMENT)
15824750 ACTUATOR, R/SEAT RECL (INCLS CABLE)
(TC16-391) 2008-2013 CK107(06) ЗАДНЕЕ СИДЕНЬЕ/BENCH-40% SIDE (AM8, EXC POWER FOLDING ARS, HYBRID HP2)
15843772 SEAT, RR (INCLS 2-42) (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960236)
15914187 SEAT, RR (INCLS 2-42) (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20959985)
25908002 SEAT, RR (INCLS 2-42) (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960240)
15843802 SEAT, RR (INCLS 2-42) (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960272)
20960041 SEAT, RR (INCLS 2-42) (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 20905021)
20960042 SEAT, RR (INCLS 2-42) (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 20905022)
20960236 SEAT, RR (INCLS 2-42) (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 15843772)
20960240 SEAT, RR (INCLS 2-42) (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25908002)
20905021 SEAT, RR (INCLS 2-42) (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960041)
20905022 SEAT, RR (INCLS 2-42) (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960042)
20959985 SEAT, RR (INCLS 2-42) (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 15914187)
20960272 SEAT, RR (INCLS 2-42) (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 15843802)
20960276 SEAT, RR (INCLS 2-42) (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25908010)
25908010 SEAT, RR (INCLS 2-42) (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960276)
20895604 COVER, R/SEAT BK (EBONY)
15914204 COVER, R/SEAT BK (EBONY)
25908033 COVER, R/SEAT BK (CASHMERE)
25931396 COVER, R/SEAT BK (EBONY)
25931397 COVER, R/SEAT BK (CASHMERE)
25931398 COVER, R/SEAT BK (TITANIUM)
15865525 COVER, R/SEAT BK (EBONY)
15865526 COVER, R/SEAT BK (CASHMERE)
15865527 COVER, R/SEAT BK (TITANIUM)
20905045 COVER, R/SEAT BK (EBONY)
20905046 COVER, R/SEAT BK (CASHMERE)
15291598 PAD, R/SEAT BK
20758015 RESTRAINT, R/SEAT HD (INCLS 4) (TITANIUM)
20905030 RESTRAINT, R/SEAT HD (INCLS 4) (EBONY)
20905031 RESTRAINT, R/SEAT HD (INCLS 4) (CASHMERE)
15269763 FRAME, R/SEAT BK
15291600 PAD, R/SEAT CUSH
15279530 COVER, R/SEAT BK HGE FIN (EBONY) (INBOARD, INNER) (16.674)
15279531 COVER, R/SEAT BK HGE FIN (CASHMERE) (INBOARD, INNER) (16.674)
15279532 COVER, R/SEAT BK HGE FIN (TITANIUM) (INBOARD, INNER) (16.674)
15279504 COVER, R/SEAT BK HGE FIN (INCLS 40) (EBONY) (INBOARD, OUTER) (16.674)
15279505 COVER, R/SEAT BK HGE FIN (INCLS 40) (CASHMERE) (INBOARD, OUTER) (16.674)
19121596 BELT KIT, R/SEAT (BKL SI) (SINGLE BKL) (TITANIUM)
19121593 BELT KIT, R/SEAT (BKL SI) (SINGLE BKL) (EBONY)
25896458 LATCH, R/SEAT BK (INBOARD)
15275888 LATCH, R/SEAT RSR (O/B)
22772253 PANEL, R/SEAT CUSH TR (TITANIUM)
15279554 PANEL, R/SEAT CUSH TR (EBONY) (16.716)
15279555 PANEL, R/SEAT CUSH TR (CASHMERE) (16.716)
15279599 COVER, R/SEAT RSR FIN (INCLS 29) (EBONY) (FRONT)
15279600 COVER, R/SEAT RSR FIN (INCLS 29) (CASHMERE) (FRONT)
15279601 COVER, R/SEAT RSR FIN (INCLS 29) (TITANIUM) (FRONT)
teamcadillac.ru
25896457 LATCH, R/SEAT BK (OUTBOARD)
15279429 HANDLE, R/SEAT RECL (INCLS 38) (TITANIUM)
15279419 HANDLE, R/SEAT RECL (INCLS 38) (EBONY)
15279420 HANDLE, R/SEAT RECL (INCLS 38) (CASHMERE)
15279484 COVER, R/SEAT BK HGE FIN (INCLS 40) (EBONY) (OUTBOARD, OUTER) (16.674)
15279485 COVER, R/SEAT BK HGE FIN (INCLS 40) (CASHMERE) (OUTBOARD, OUTER) (16.674)
15279486 COVER, R/SEAT BK HGE FIN (INCLS 40) (TITANIUM) (OUTBOARD, OUTER) (16.674)
15279494 COVER, R/SEAT BK HGE FIN (EBONY) (OUTBOARD, INNER) (16.674)
15279495 COVER, R/SEAT BK HGE FIN (CASHMERE) (OUTBOARD, INNER) (16.674)
15279496 COVER, R/SEAT BK HGE FIN (TITANIUM) (OUTBOARD, INNER) (16.674)
15914208 COVER, R/SEAT CUSH (EBONY)
25908034 COVER, R/SEAT CUSH (CASHMERE)
25931402 COVER, R/SEAT CUSH (EBONY)
25931403 COVER, R/SEAT CUSH (CASHMERE)
25931404 COVER, R/SEAT CUSH (TITANIUM)
15865714 COVER, R/SEAT CUSH (EBONY)
15865715 COVER, R/SEAT CUSH (CASHMERE)
15865716 COVER, R/SEAT CUSH (TITANIUM)
20905039 COVER, R/SEAT CUSH (EBONY)
20905040 COVER, R/SEAT CUSH (CASHMERE)
20905442 COVER, R/SEAT CUSH (EBONY)
11570031 PIN, R/SEAT HGE (6 X 1 X 78)
11570032 PIN, R/SEAT HGE (6 X 1 X 98)
(TC16-392) 2008-2013 CK107(06) ЗАДНЕЕ СИДЕНЬЕ/BENCH-60% SIDE (AM8, EXC POWER FOLDING ARS, HYBRID HP2)
teamcadillac.ru
15914202 COVER, R/SEAT BK (EBONY)
25908031 COVER, R/SEAT BK (CASHMERE)
25931384 COVER, R/SEAT BK (EBONY)
25931386 COVER, R/SEAT BK (TITANIUM)
15865521 COVER, R/SEAT BK (EBONY)
15865522 COVER, R/SEAT BK (CASHMERE)
15865523 COVER, R/SEAT BK (TITANIUM)
20905042 COVER, R/SEAT BK (EBONY)
20905043 COVER, R/SEAT BK (CASHMERE)
20895601 COVER, R/SEAT BK (EBONY)
15291597 PAD, R/SEAT BK
22771058 PAD, R/SEAT BK
11562382 BOLT, HFH, M10X1.5X130, 26 THD, 22.3 OD, 10.9, 7114M, MACH, MAT-PT (R/SEAT BK FRM)
15289969 BRACKET, RR CTR SEAT BELT RETR
15279450 PROTECTOR, R/SEAT SHLDR BELT (BLACK)
15824670 RESTRAINT, R/SEAT HD (INCLS 8) (TITANIUM)
25928791 RESTRAINT, R/SEAT HD (INCLS 8) (CASHMERE)
20758015 RESTRAINT, R/SEAT HD (INCLS 8) (TITANIUM)
20905030 RESTRAINT, R/SEAT HD (INCLS 8) (EBONY)
20905031 RESTRAINT, R/SEAT HD (INCLS 8) (CASHMERE)
15865813 RESTRAINT, R/SEAT HD (INCLS 8) (EBONY)
15824669 RESTRAINT, R/SEAT HD (INCLS 8) (CASHMERE)
25928790 RESTRAINT, R/SEAT HD (INCLS 8) (EBONY)
15824676 RESTRAINT, R/SEAT HD (INCLS 8) (EBONY)
11562383 BOLT, HFH, M12X1.75X30.5, 17 THD, 26.6 OD, 10.9 STL, GMW3359, W/ADH 6175M (R/SEAT LAT)
15269762 FRAME, R/SEAT BK
15279471 COVER, R/SEAT A/RST SUPT FIN (TITANIUM)
15279469 COVER, R/SEAT A/RST SUPT FIN (EBONY)
15279470 COVER, R/SEAT A/RST SUPT FIN (CASHMERE)
15279489 COVER, R/SEAT BK HGE FIN (EBONY) (OUTBOARD, INNER) (16.674)
15279490 COVER, R/SEAT BK HGE FIN (CASHMERE) (OUTBOARD, INNER) (16.674)
15279491 COVER, R/SEAT BK HGE FIN (TITANIUM) (OUTBOARD, INNER) (16.674)
19121589 BELT KIT, R/SEAT (BKL SI) (EBONY) (BKL/BKL)
19121591 BELT KIT, R/SEAT (BKL SI) (CASHMERE) (BKL/BKL)
19121592 BELT KIT, R/SEAT (BKL SI) (TITANIUM) (BKL/BKL)
15269764 FRAME, R/SEAT CUSH
15275886 LATCH, R/SEAT RSR (O/B)
15275887 LATCH, R/SEAT RSR (I/B)
25896455 LATCH, R/SEAT BK (OUTBOARD)
15279479 COVER, R/SEAT BK HGE FIN (INCLS 49) (EBONY) (OUTBOARD, OUTER) (16.674)
15279480 COVER, R/SEAT BK HGE FIN (INCLS 49) (CASHMERE) (OUTBOARD, OUTER) (16.674)
15279481 COVER, R/SEAT BK HGE FIN (INCLS 49) (TITANIUM) (OUTBOARD, OUTER) (16.674)
15279416 HANDLE, R/SEAT RECL (INCLS 23) (TITANIUM)
15279414 HANDLE, R/SEAT RECL (INCLS 23) (EBONY)
15279415 HANDLE, R/SEAT RECL (INCLS 23) (CASHMERE)
25858332 HANDLE, R/SEAT RECL (INCLS 23) (COCOA)
15275917 CABLE, R/SEAT LAT (INBOARD) (FLOOR LATCH)
25816396 CABLE, R/SEAT LAT (INBOARD) (MASTER SYNC)
25816395 CABLE, R/SEAT BK LAT (MASTER SYNC)
15279604 COVER, R/SEAT RSR FIN (EBONY) (REAR)
15279605 COVER, R/SEAT RSR FIN (CASHMERE) (REAR)
15279606 COVER, R/SEAT RSR FIN (TITANIUM) (REAR)
22741876 RISER, R/SEAT
15824753 COVER, R/SEAT RSR FIN (INCLS 31) (EBONY) (FRONT)
15824754 COVER, R/SEAT RSR FIN (INCLS 31) (CASHMERE) (FRONT)
15824755 COVER, R/SEAT RSR FIN (INCLS 31) (TITANIUM) (FRONT)
15291599 PAD, R/SEAT CUSH
11571092 BOLT, R/SEAT HGE (M10X1.5X114)
15843765 HARNESS, R/SEAT HTR
15279551 PANEL, R/SEAT CUSH TR (TITANIUM) (16.716)
15279550 PANEL, R/SEAT CUSH TR (CASHMERE) (16.716)
22772246 PANEL, R/SEAT CUSH TR (EBONY)
20933029 MODULE, R/SEAT HTR CONT
25891512 MODULE, R/SEAT HTR CONT (REQUIRES DEALER PROGRAMMING) (11.558)
20792750 HEATER, R/SEAT CUSH
15275905 STRUT, R/SEAT (USED ON 40% SIDE)
15930099 STRUT, R/SEAT (USED ON 60% SIDE)
15275900 SPRING, R/SEAT RECL (TUMBLE)
15275902 SPRING, R/SEAT RECL (MANDREL)
15279591 COVER, R/SEAT HGE LWR FIN (TITANIUM) (PIVOT INBOARD) (16.674)
15279589 COVER, R/SEAT HGE LWR FIN (EBONY) (PIVOT INBOARD) (16.674)
15279590 COVER, R/SEAT HGE LWR FIN (CASHMERE) (PIVOT INBOARD) (16.674)
15269777 BRACKET, R/SEAT
11562381 BOLT, R/SEAT BK LAT PIV (M12X1.75X40)
15279596 COVER, R/SEAT HGE LWR FIN (TITANIUM) (PIVOT INBOARD) (16.674)
15279594 COVER, R/SEAT HGE LWR FIN (EBONY) (PIVOT INBOARD) (16.674)
15279595 COVER, R/SEAT HGE LWR FIN (CASHMERE) (PIVOT INBOARD) (16.674)
15914206 COVER, R/SEAT CUSH (EBONY)
25931390 COVER, R/SEAT CUSH (EBONY)
25931391 COVER, R/SEAT CUSH (CASHMERE)
25931392 COVER, R/SEAT CUSH (TITANIUM)
15865529 COVER, R/SEAT CUSH (EBONY)
15865530 COVER, R/SEAT CUSH (CASHMERE)
15865531 COVER, R/SEAT CUSH (TITANIUM)
25899567 COVER, R/SEAT CUSH (EBONY)
20905036 COVER, R/SEAT CUSH (EBONY)
20905037 COVER, R/SEAT CUSH (CASHMERE)
20905440 COVER, R/SEAT CUSH (CASHMERE)
15279499 COVER, R/SEAT BK HGE FIN (INCLS 49) (EBONY) (INBOARD, OUTER) (16.674)
15279500 COVER, R/SEAT BK HGE FIN (INCLS 49) (CASHMERE) (INBOARD, OUTER) (16.674)
15279501 COVER, R/SEAT LAT FIN (INCLS 49) (TITANIUM) (INBOARD, OUTER)
11562376 SCREW, PAN HD, M12X1.75X55, 42 THD, 27 OD, 10.9, S424, W/ADH GM6175M (R/SEAT LAT)
25896456 LATCH, R/SEAT BK (INBOARD)
11562377 BOLT, HFH, M10X1.5X55, 43.45 THD, 22.3 OD, 10.9, GMW3359, W/ADH GM6175M (R/SEAT LAT)
15279525 COVER, R/SEAT BK HGE FIN (EBONY) (INBOARD, INNER) (16.674)
15279526 COVER, R/SEAT BK HGE FIN (CASHMERE) (INBOARD, INNER) (16.674)
15279527 COVER, R/SEAT BK HGE FIN (TITANIUM) (INBOARD, INNER) (16.674)
15275854 ARMREST, R/SEAT (EBONY)
15913989 ARMREST, R/SEAT (TITANIUM) (W/CUP HOLDER)
20904932 ARMREST, R/SEAT (TITANIUM) (W/CUP HOLDER)
20904933 ARMREST, R/SEAT (CASHMERE) (W/CUP HOLDER)
15865495 ARMREST, R/SEAT (TITANIUM)
15865493 ARMREST, R/SEAT (EBONY)
15865494 ARMREST, R/SEAT (CASHMERE)
15275855 ARMREST, R/SEAT (CASHMERE)
11562386 BOLT, HFH, M8X1.25X24, 22.5 THD, 18 OD, GM6202M, STL, GM4435M.CODE G, TAPTITE (R/SEAT A/RST)
19151106 BELT KIT, R/SEAT CTR (RETR SI) (TITANIUM)
19151105 BELT KIT, R/SEAT CTR (RETR SI) (CASHMERE)
19151104 BELT KIT, R/SEAT CTR (RETR SI) (EBONY)
(TC16-393) 2008-2013 CK107(06) ЗАДНЕЕ СИДЕНЬЕ/BENCH-40% SIDE (AM8, POWER FOLDING ARS, EXC HYBRID HP2)
teamcadillac.ru
15279504 COVER, R/SEAT BK HGE FIN (INCLS 41) (EBONY) (INBOARD, OUTER) (16.674)
15279505 COVER, R/SEAT BK HGE FIN (INCLS 41) (CASHMERE) (INBOARD, OUTER) (16.674)
15279506 COVER, R/SEAT LAT FIN (TITANIUM) (INBOARD, OUTER) (16.720)
15843762 HARNESS, ST RECL WRG (ELEMENT)
15942228 CABLE, R/SEAT BK LAT
15942229 CABLE, R/SEAT BK LAT
15279429 HANDLE, R/SEAT RECL (INCLS 39) (TITANIUM)
25858446 HANDLE, R/SEAT RECL (INCLS 39) (COCOA)
15279419 HANDLE, R/SEAT RECL (INCLS 39) (EBONY)
15279420 HANDLE, R/SEAT RECL (INCLS 39) (CASHMERE)
15279484 COVER, R/SEAT BK HGE FIN (INCLS 41) (EBONY) (OUTBOARD, OUTER) (16.674)
15279485 COVER, R/SEAT BK HGE FIN (INCLS 41) (CASHMERE) (OUTBOARD, OUTER) (16.674)
15279486 COVER, R/SEAT BK HGE FIN (INCLS 41) (TITANIUM) (OUTBOARD, OUTER) (16.674)
(TC16-394) 2008-2013 CK107(06) ЗАДНЕЕ СИДЕНЬЕ/BENCH-60% SIDE (AM8, POWER FOLDING ARS, EXC HYBRID HP2)
15279552 PANEL, R/SEAT CUSH TR (CASHMERE) (16.716)
teamcadillac.ru
15824751 ACTUATOR, R/SEAT RECL (INCLS CABLE)
(TC16-395) 2007-2013 CK107(06) ЗАДНЕЕ СИДЕНЬЕ/BUCKET-LH (BUCKET AL4)
25834415 SEAT, RR (INCLS 2-49) (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960563)
25907996 SEAT, RR (INCLS 2-49) (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960582)
25834165 SEAT, RR (INCLS 2-49) (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960554)
20960481 SEAT, RR (INCLS 2-49) (COCOA) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25942792)
20960563 SEAT, RR (INCLS 2-49) (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25834415)
20960564 SEAT, RR (INCLS 2-49) (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25907992)
20960581 SEAT, RR (INCLS 2-49) (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25834424)
20960582 SEAT, RR (INCLS 2-49) (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25907996)
25834424 SEAT, RR (INCLS 2-49) (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960581)
25907992 SEAT, RR (INCLS 2-49) (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960564)
25942792 SEAT, RR (INCLS 2-49) (COCOA) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960481)
20960545 SEAT, RR (INCLS 2-49) (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25834162)
20960546 SEAT, RR (INCLS 2-49) (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25907987)
20960554 SEAT, RR (INCLS 2-49) (EBONY) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25834165)
20960555 SEAT, RR (INCLS 2-49) (CASHMERE) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25907989)
20960595 SEAT, RR (INCLS 2-49) (COCOA) (W/O PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 1ST DES SEE 25949033)
25834162 SEAT, RR (INCLS 2-49) (EBONY) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960545)
25907987 SEAT, RR (INCLS 2-49) (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960546)
25907989 SEAT, RR (INCLS 2-49) (CASHMERE) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960555)
25949033 SEAT, RR (INCLS 2-49) (COCOA) (W/PLASTIC STANCHION COVER IN FLOOR CARPET) (FOR 2ND DES SEE 20960595)
15865718 COVER, R/SEAT BK (EBONY)
25858326 COVER, R/SEAT BK (COCOA)
25908024 COVER, R/SEAT BK (CASHMERE)
25931422 COVER, R/SEAT BK (EBONY)
25931423 COVER, R/SEAT BK (CASHMERE)
25931424 COVER, R/SEAT BK (TITANIUM)
15865719 COVER, R/SEAT BK (CASHMERE)
15865720 COVER, R/SEAT BK (TITANIUM)
25899573 COVER, R/SEAT BK (EBONY)
15291601 PAD, R/SEAT BK
15269768 FRAME, R/SEAT BK
22785442 ARMREST, R/SEAT (EBONY)
22785443 ARMREST, R/SEAT (CASHMERE)
22785444 ARMREST, R/SEAT (TITANIUM)
22785451 ARMREST, R/SEAT (CASHMERE) (ON VEHICLES BUILT PRIOR TO 4/2011 DEALER MAY NEED TO REMOVE STUD OFFFRAME PRIOR TO USING ARMREST WITH BOLT)
22785456 ARMREST, R/SEAT (COCOA) (ON VEHICLES BUILT PRIOR TO 4/2011 DEALER MAY NEED TO REMOVE STUD OFFFRAME PRIOR TO USING ARMREST WITH BOLT)
22785450 ARMREST, R/SEAT (EBONY) (ON VEHICLES BUILT PRIOR TO 4/2011 DEALER MAY NEED TO REMOVE STUD OFFFRAME PRIOR TO USING ARMREST WITH BOLT)
15291603 PAD, R/SEAT CUSH
15269770 FRAME, R/SEAT CUSH
15280108 COVER, R/SEAT RECL INR FIN (EBONY) (INNER)
15280109 COVER, R/SEAT RECL INR FIN (CASHMERE) (INNER)
15280110 COVER, R/SEAT RECL INR FIN (TITANIUM) (INNER)
25858339 COVER, R/SEAT RECL INR FIN (COCOA) (INNER)
15279714 COVER, R/SEAT RECL INR FIN (INCLS 42) (EBONY) (OUTER)
15279715 COVER, R/SEAT RECL INR FIN (INCLS 42) (CASHMERE) (OUTER)
15279716 COVER, R/SEAT RECL INR FIN (INCLS 42) (TITANIUM) (OUTER)
25858338 COVER, R/SEAT RECL INR FIN (INCLS 42) (COCOA) (OUTER)
19121601 BELT KIT, R/SEAT (BKL SI) (EBONY)
19121604 BELT KIT, R/SEAT (BKL SI) (TITANIUM)
19121603 BELT KIT, R/SEAT (BKL SI) (CASHMERE)
19180586 BELT KIT, R/SEAT (BKL SI) (COCOA)
25896461 RECLINER, R/SEAT INR (WHEN SERVICING VEHICLES BUILT PRIOR TO 06/01/06, DEALER NEEDS TO REPLACE BOTH INNER & OUTER IN SETS)
15275890 LATCH, R/SEAT RSR (O/B)
15280120 PANEL, R/SEAT CUSH TR (TITANIUM) (16.716)
25858340 PANEL, R/SEAT CUSH TR (COCOA)
15280119 PANEL, R/SEAT CUSH TR (CASHMERE) (16.716)
22772263 PANEL, R/SEAT CUSH TR (EBONY)
15280128 COVER, R/SEAT RSR FIN (EBONY) (REAR)
15280129 COVER, R/SEAT RSR FIN (CASHMERE) (REAR)
15280130 COVER, R/SEAT RSR FIN (TITANIUM) (REAR)
25858341 COVER, R/SEAT RSR FIN (COCOA) (REAR)
15269775 RISER, R/SEAT
22741881 RISER, R/SEAT
15279599 COVER, R/SEAT RSR FIN (INCLS 33) (EBONY) (FRONT)
15279600 COVER, R/SEAT RSR FIN (INCLS 33) (CASHMERE) (FRONT)
15279601 COVER, R/SEAT RSR FIN (INCLS 33) (TITANIUM) (FRONT)
teamcadillac.ru
25896459 RECLINER, R/SEAT OTR (WHEN SERVICING VEHICLES BUILT PRIOR TO 06/01/06, DEALER NEEDS TO REPLACE BOTH INNER & OUTER IN SETS)
15279416 HANDLE, R/SEAT RECL (INCLS 43) (TITANIUM)
25858332 HANDLE, R/SEAT RECL (INCLS 43) (COCOA)
15279414 HANDLE, R/SEAT RECL (INCLS 43) (EBONY)
15279415 HANDLE, R/SEAT RECL (INCLS 43) (CASHMERE)
15279694 COVER, R/SEAT RECL OTR FIN (INCLS 42) (EBONY) (OUTER)
15279695 COVER, R/SEAT RECL OTR FIN (INCLS 42) (CASHMERE) (OUTER)
15279696 COVER, R/SEAT RECL OTR FIN (INCLS 42) (TITANIUM) (OUTER)
25858336 COVER, R/SEAT RECL OTR FIN (INCLS 42) (COCOA) (OUTER)
15279704 COVER, R/SEAT RECL OTR FIN (EBONY) (INNER)
15279705 COVER, R/SEAT RECL OTR FIN (CASHMERE) (INNER)
15279706 COVER, R/SEAT RECL OTR FIN (TITANIUM) (INNER)
25858337 COVER, R/SEAT RECL OTR FIN (COCOA) (INNER)
25858328 COVER, R/SEAT CUSH (COCOA)
25931428 COVER, R/SEAT CUSH (EBONY)
25931430 COVER, R/SEAT CUSH (TITANIUM)
15865726 COVER, R/SEAT CUSH (EBONY)
15865727 COVER, R/SEAT CUSH (CASHMERE)
15865728 COVER, R/SEAT CUSH (TITANIUM)
25899561 COVER, R/SEAT CUSH (EBONY)
20905446 COVER, R/SEAT CUSH (CASHMERE)
15843764 HARNESS, ST RECL WRG (ELEMENT) (16.685)
15275906 ACTUATOR, R/SEAT RECL (INCLS CABLE)
(TC16-399) 2007-2013 CK1,2(06) ЗАДНЕЕ СИДЕНЬЕ #2 (3RD ROW)-LH(AS3)
22760803 SEAT, 3RD ROW (INCLS 2-44) (EBONY)
22760804 SEAT, 3RD ROW (INCLS 2-44) (CASHMERE)
22760809 SEAT, 3RD ROW (INCLS 2-44) (EBONY)
22760810 SEAT, 3RD ROW (INCLS 2-44) (CASHMERE)
22760818 SEAT, 3RD ROW (INCLS 2-44) (EBONY)
22760819 SEAT, 3RD ROW (INCLS 2-44) (CASHMERE)
22760824 SEAT, 3RD ROW (INCLS 2-44) (EBONY)
22760825 SEAT, 3RD ROW (INCLS 2-44) (CASHMERE)
22760831 SEAT, 3RD ROW (INCLS 2-44) (EBONY)
22760839 SEAT, 3RD ROW (INCLS 2-44) (EBONY)
22760847 SEAT, 3RD ROW (INCLS 2-44) (COCOA)
22760851 SEAT, 3RD ROW (INCLS 2-44) (COCOA)
22760827 SEAT, 3RD ROW (INCLS 2-44) (COCOA)
22760883 SEAT, 3RD ROW (INCLS 2-44) (EBONY)
22760884 SEAT, 3RD ROW (INCLS 2-44) (CASHMERE)
15804530 PAD, 3RD ROW SEAT BK
19207595 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (CASHMERE)
19207596 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (TITANIUM)
19207598 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (COCOA)
19207594 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 8) (EBONY)
25906824 BELT, R/SEAT #2 (RETR SI) (INCLS 8) (CASHMERE)
25940414 BELT, R/SEAT #2 (RETR SI) (INCLS 8) (COCOA)
25869317 BELT, R/SEAT #2 (RETR SI) (INCLS 8) (EBONY)
12478382 BOLT, 3RD ROW SEAT (M10X1.50X28.0)
15898412 COVER, 3RD ROW SEAT BK LAT (EBONY) (OUTBOARD, OUTER) (16.716)
15898413 COVER, 3RD ROW SEAT BK LAT (CASHMERE) (OUTBOARD, OUTER) (16.716)
15898414 COVER, 3RD ROW SEAT BK LAT (TITANIUM) (OUTBOARD, OUTER) (16.716)
15804503 COVER, 3RD ROW SEAT BK LAT (EBONY) (OUTBOARD, INNER) (16.716)
15804504 COVER, 3RD ROW SEAT BK LAT (CASHMERE) (OUTBOARD, INNER) (16.716)
15804505 COVER, 3RD ROW SEAT BK LAT (TITANIUM) (OUTBOARD, INNER) (16.716)
20963255 HANDLE, R/SEAT LAT REL (PART OF 26) (EBONY) (W/NUMBER LABELS ON 3RD ROW SEAT) (FOR 1ST DES SEE 15822356)
20963257 HANDLE, R/SEAT LAT REL (PART OF 26) (TITANIUM) (W/NUMBER LABELS ON 3RD ROW SEAT) (FOR 1ST DES SEE 15822358)
15822356 HANDLE, R/SEAT LAT REL (PART OF 26) (EBONY) (W/O NUMBER LABELS ON 3RD ROW SEAT) (FOR 2ND DES SEE 20963255)
15822357 HANDLE, R/SEAT LAT REL (PART OF 26) (CASHMERE) (W/O NUMBER LABELS ON 3RD ROW SEAT) (FOR 2ND DES SEE 20963256)
15822358 HANDLE, R/SEAT LAT REL (PART OF 26) (TITANIUM) (W/O NUMBER LABELS ON 3RD ROW SEAT) (FOR 2ND DES SEE 20963257)
20963256 HANDLE, R/SEAT LAT REL (PART OF 26) (CASHMERE) (W/NUMBER LABELS ON 3RD ROW SEAT) (FOR 1ST DES SEE 15822357)
22906161 HANDLE, R/SEAT LAT REL (PART OF 26)
25928520 LATCH, 3RD ROW SEAT BK (SIDE)
15804483 COVER, 3RD ROW SEAT BK LAT (EBONY) (REAR CLOSEOUT) (16.716)
15804484 COVER, 3RD ROW SEAT BK LAT (CASHMERE) (REAR CLOSEOUT) (16.716)
22772286 COVER, 3RD ROW SEAT BK LAT (EBONY)
22772287 COVER, 3RD ROW SEAT BK LAT (CASHMERE)
22772289 COVER, 3RD ROW SEAT BK LAT (COCOA)
15898401 LATCH, 3RD ROW SEAT LOAD FLR (INCLS 43, 44)
15804488 COVER, 3RD ROW SEAT BK LAT (EBONY) (FRONT CLOSEOUT) (16.716)
15804489 COVER, 3RD ROW SEAT BK LAT (CASHMERE) (FRONT CLOSEOUT) (16.716)
15804490 COVER, 3RD ROW SEAT BK LAT (TITANIUM) (FRONT CLOSEOUT) (16.716)
20963267 CABLE, 3RD ROW SEAT BK LAT (INCLS 18) (EBONY) (50% MAIN CONTROL BOX)
20963268 CABLE, 3RD ROW SEAT BK LAT (INCLS 18) (CASHMERE) (50% MAIN CONTROL BOX)
teamcadillac.ru
20963269 CABLE, 3RD ROW SEAT BK LAT (INCLS 18) (TITANIUM) (50% MAIN CONTROL BOX)
20963270 CABLE, 3RD ROW SEAT BK LAT (INCLS 18) (COCOA) (50% MAIN CONTROL BOX)
15832238 CABLE, 3RD ROW SEAT BK LAT (INCLS 18) (EBONY) (W/PULL HANDLE) (50% MAIN CONTROL BOX)
15832239 CABLE, 3RD ROW SEAT BK LAT (INCLS 18) (CASHMERE) (W/PULL HANDLE) (50% MAIN CONTROL BOX)
15832240 CABLE, 3RD ROW SEAT BK LAT (INCLS 18) (TITANIUM) (W/PULL HANDLE) (50% MAIN CONTROL BOX)
15791115 FRAME, 3RD ROW SEAT CUSH
15822389 COVER, 3RD ROW SEAT BK HGE FIN (EBONY) (INBOARD, OUTER)
15822390 COVER, 3RD ROW SEAT BK HGE FIN (CASHMERE) (INBOARD, OUTER)
15822391 COVER, 3RD ROW SEAT BK HGE FIN (TITANIUM)
12476887 BOLT, 3RD ROW SEAT BK PIV (M10X1.5) (W/BUSHING) (16.679)
15924950 COVER, 3RD ROW SEAT BK HGE FIN (EBONY) (PIVOT PROTECTOR)
15924951 COVER, 3RD ROW SEAT BK HGE FIN (CASHMERE) (PIVOT PROTECTOR)
15924952 COVER, 3RD ROW SEAT BK HGE FIN (TITANIUM) (PIVOT PROTECTOR)
15833812 RETAINER, R/SEAT CUSH FRM
25960398 FRAME, 3RD ROW SEAT BK
15898363 FRAME, 3RD ROW SEAT BK
15898400 FRAME, 3RD ROW SEAT BK
19152520 BELT KIT, R/SEAT #2 (BKL SI) (TITANIUM) (BKL/BKL)
19180589 BELT KIT, R/SEAT #2 (BKL SI) (COCOA)
19152519 BELT KIT, R/SEAT #2 (BKL SI) (CASHMERE) (BKL/BKL)
19152518 BELT KIT, R/SEAT #2 (BKL SI) (EBONY) (BKL/BKL)
15804534 PAD, 3RD ROW SEAT CUSH
25858728 COVER, 3RD ROW SEAT CUSH (COCOA)
25937613 COVER, 3RD ROW SEAT CUSH (EBONY)
25937614 COVER, 3RD ROW SEAT CUSH (CASHMERE)
25937615 COVER, 3RD ROW SEAT CUSH (TITANIUM)
20758148 COVER, 3RD ROW SEAT CUSH (CASHMERE)
20904823 COVER, 3RD ROW SEAT CUSH (EBONY)
20904825 COVER, 3RD ROW SEAT CUSH (CASHMERE)
22751182 COVER, 3RD ROW SEAT CUSH (CASHMERE)
25928470 COVER, 3RD ROW SEAT CUSH (CASHMERE)
20859434 COVER, 3RD ROW SEAT CUSH (EBONY)
25928469 COVER, 3RD ROW SEAT CUSH (EBONY)
25928471 COVER, 3RD ROW SEAT CUSH (TITANIUM)
20904829 COVER, 3RD ROW SEAT BK (EBONY) (W/CHILD SEAT BELT COMFORT GUIDE) (W/O NUMBER LABELS ON 3RD ROW SEAT) (FOR 2ND DES SEE 20963297)
20904831 COVER, 3RD ROW SEAT BK (CASHMERE) (W/CHILD SEAT BELT COMFORT GUIDE) (W/O NUMBER LABELS ON 3RD ROW SEAT) (FOR 2ND DES SEE 20963298)
20963280 COVER, 3RD ROW SEAT BK (EBONY) (W/NUMBER LABELS ON 3RD ROW SEAT) (FOR 1ST DES SEE 15865793)
20963288 COVER, 3RD ROW SEAT BK (EBONY) (W/NUMBER LABELS ON 3RD ROW SEAT) (FOR 1ST DES SEE 20859428)
20963289 COVER, 3RD ROW SEAT BK (CASHMERE) (W/NUMBER LABELS ON 3RD ROW SEAT) (FOR 1ST DES SEE 20859429)
20963297 COVER, 3RD ROW SEAT BK (EBONY) (W/NUMBER LABELS ON 3RD ROW SEAT) (FOR 1ST DES SEE 20904829)
15865793 COVER, 3RD ROW SEAT BK (EBONY) (INCLS CHILD COMFORT GUIDE) (W/O NUMBER LABELS ON 3RD ROW SEAT) (FOR 2ND DES SEE 20963280)
20859428 COVER, 3RD ROW SEAT BK (EBONY) (INCLS CHILD COMFORT GUIDE) (W/O NUMBER LABELS ON 3RD ROW SEAT) (FOR 2ND DES SEE 20963288)
20859429 COVER, 3RD ROW SEAT BK (CASHMERE) (INCLS CHILD COMFORT GUIDE) (W/O NUMBER LABELS ON 3RD ROW SEAT) (FOR 2ND DES SEE 20963289)
20963298 COVER, 3RD ROW SEAT BK (CASHMERE) (W/NUMBER LABELS ON 3RD ROW SEAT) (FOR 1ST DES SEE 20904831)
20963300 COVER, 3RD ROW SEAT BK (COCOA) (W/NUMBER LABELS ON 3RD ROW SEAT) (FOR 1ST DES SEE 25858726)
25858726 COVER, 3RD ROW SEAT BK (COCOA) (W/O NUMBER LABELS ON 3RD ROW SEAT) (FOR 2ND DES SEE 20963300)
88936748 CAP, R/SEAT ADJR TRK END (BLACK)
15924919 PANEL, R/SEAT BK FIL
25895134 BAR, R/SEAT HGE LINK TIE (PART OF 21)
(TC16-420) 2007-2013 CK107(06) РЕМНИ БЕЗОПАСНОСТИ ЗАДНИЕ (AL4,AM8)
19168657 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 17) (COCOA)
19260305 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 17) (CASHMERE)
19260307 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 17) (COCOA)
19260310 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 17) (TITANIUM)
19260309 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 17) (CASHMERE)
25810538 BELT, R/SEAT (RETR SI) (INCLS 2, 17) (EBONY)
25810541 BELT, R/SEAT (RETR SI) (INCLS 2, 17) (EBONY)
25847304 BELT, R/SEAT (RETR SI) (INCLS 2, 17) (COCOA)
25847305 BELT, R/SEAT (RETR SI) (INCLS 2, 17) (COCOA)
25906758 BELT, R/SEAT (RETR SI) (INCLS 2, 17) (CASHMERE)
25906759 BELT, R/SEAT (RETR SI) (INCLS 2, 17) (CASHMERE)
19260304 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 17) (EBONY)
19260306 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 17) (TITANIUM)
19260308 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 17) (EBONY)
11588539 BOLT, R/SEAT BELT (RETR SI) (PART OF 1) (M12X1.75X52.75 22 OD) (8.913)
11609886 BOLT, R/SEAT BELT (RETR SI) (M12X1.75X40, 22 OD)
11610207 BOLT, R/SEAT BELT (RETR SI) (M12X1.75X76, 22 OD) (8.913)
19210380 BELT, R/SEAT (BKL SI) (COCOA)
19151106 BELT KIT, R/SEAT CTR (RETR SI) (INCLS 12, 17) (TITANIUM)
19210381 BELT KIT, R/SEAT CTR (RETR SI) (INCLS 12, 17) (COCOA)
19151105 BELT KIT, R/SEAT CTR (RETR SI) (INCLS 12, 17) (CASHMERE)
19151104 BELT KIT, R/SEAT CTR (RETR SI) (INCLS 12, 17) (EBONY)
teamcadillac.ru
25919004 BELT, R/SEAT CTR SHLDR (RETR SI) (INCLS 12, 17) (CASHMERE)
25778338 BELT, R/SEAT CTR SHLDR (RETR SI) (INCLS 12, 17) (EBONY)
19207765 STOP KIT, BELT LAT (RETR SI) (PART OF 1, 10) (COCOA) (14.875)
19121445 STOP KIT, BELT LAT (RETR SI) (PART OF 1, 10) (CASHMERE) (14.875)
19121443 STOP KIT, BELT LAT (RETR SI) (PART OF 1, 10) (TITANIUM) (14.875)
19121446 STOP KIT, BELT LAT (RETR SI) (PART OF 1, 10) (EBONY) (14.875)
(TC16-434) 2007-2013 CK1,2(06-36) НАРУЖНОЕ ЗЕРКАЛО ЗАДНЕГО ВИДА (HEATED,POWER FOLDING,TURN SIGNAL DL3)
25829663 GLASS, O/S RR VIEW MIR (PART OF 4)
20778440 GLASS, O/S RR VIEW MIR (PART OF 4)
20778441 GLASS, O/S RR VIEW MIR (PART OF 4)
25829662 GLASS, O/S RR VIEW MIR (PART OF 4)
25829664 GLASS, O/S RR VIEW MIR (PART OF 4)
teamcadillac.ru
11570831 BOLT, O/S RR VIEW MIR ACTR (PART OF 4)
25808705 ACTUATOR, O/S RR VIEW MIR INR (GLASS ACTUATOR W/MEMORY/POWER FOLDING MIRROR) (PART OF 4) (W/1 PIGTAIL ON BACK)
25808706 ACTUATOR, O/S RR VIEW MIR INR (GLASS ACTUATOR W/MEMORY/POWER FOLDING MIRROR) (PART OF 4) (W/1 PIGTAIL ON BACK)
25808704 ACTUATOR, O/S RR VIEW MIR INR (PART OF 4) (W/1 PIGTAIL ON BACK) (W/O MEMORY)
20756788 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (PAINT TO MATCH TOP SKULL CAP & CHROME BOTTOM)
20756774 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (CHROME)
20756950 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (CHROME)
20756905 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (PAINT TO MATCH)
20843106 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (CHROME)
20843108 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (CHROME)
20843129 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (PAINT TO MATCH)
20843216 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (PAINT TO MATCH TOP SKULL CAP & CHROME BOTTOM)
20756915 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (PAINT TO MATCH)
25801822 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (MOLDED IN BLACK)
20756968 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (BLACK)
20756951 MIRROR, O/S RR VIEW (INCLS 1-3, 5-7, 10) (CHROME)
01999382 BULB, (PART OF 4, 6) (ACDelco #W5WLL) (LONGER LIFE)
15875000 LAMP, CTSY (PART OF 4) (INCLS 5) (O/S RR VIEW)
15874999 LAMP, CTSY (PART OF 4) (INCLS 5) (O/S RR VIEW)
25862775 SEAL, O/S RR VIEW MIR (PART OF 4)
25862772 SEAL, O/S RR VIEW MIR (PART OF 4)
25862774 SEAL, O/S RR VIEW MIR (PART OF 4)
25862773 SEAL, O/S RR VIEW MIR (PART OF 4)
25601643 NUT, HEX W/CON WA, M6X1X5.6, 24 OD, 9, ZF (O/S RR VIEW MIR) (8.917)
25816712 FILLER, FRT S/D O/S RR VIEW MIR (INSIDE VEHICLE)
25788160 HOUSING, O/S RR VIEW MIR (PART OF 4) (CHROME)
25788154 HOUSING, O/S RR VIEW MIR (PART OF 4) (MOLDED IN BLACK) (PEBBLE GRAINED FINISH))
25788155 HOUSING, O/S RR VIEW MIR (PART OF 4) (MOLDED IN BLACK) (PEBBLE GRAINED FINISH))
25788156 HOUSING, O/S RR VIEW MIR (PART OF 4) (PAINT TO MATCH)
25788161 HOUSING, O/S RR VIEW MIR (PART OF 4) (CHROME)
25788157 HOUSING, O/S RR VIEW MIR (PART OF 4) (PAINT TO MATCH) (16.069)
(TC16-447) 2008-2011 CK1,2(06-36) КРЕПЛЕНИЕ ПЕРЕДНЕГО СИДЕНЬЯ (AN3,A95, EXC HYBRID HP2)
15882407 COVER, D/SEAT INR ADJR RR FIN (COCOA)
15214539 COVER, D/SEAT INR ADJR RR FIN (EBONY) (INBOARD TRACKS) (REAR)
15219928 COVER, D/SEAT INR ADJR RR FIN (CASHMERE)
15214527 COVER, D/SEAT ADJR FIN (EBONY) (BELT UTILITY)
15214529 COVER, D/SEAT ADJR FIN (TITANIUM) (BELT UTILITY)
15219925 COVER, D/SEAT ADJR FIN (CASHMERE) (BELT UTILITY)
11562473 BOLT, F/SEAT (M12X1.75X45)
15219926 CAP, F/SEAT CUSH OTR FIN CVR BOLT (CASHMERE)
15895267 CAP, F/SEAT CUSH OTR FIN CVR BOLT (TITANIUM)
15882403 CAP, F/SEAT CUSH OTR FIN CVR BOLT (COCOA)
15214533 CAP, F/SEAT CUSH OTR FIN CVR BOLT (EBONY)
25952151 COVER, WRG HARN CONN (EBONY)
25952153 COVER, WRG HARN CONN (EBONY)
15882405 COVER, D/SEAT INR ADJR FRT FIN (COCOA)
15931771 COVER, D/SEAT INR ADJR FRT FIN (EBONY)
15931772 COVER, D/SEAT INR ADJR FRT FIN (CASHMERE)
15931773 COVER, D/SEAT INR ADJR FRT FIN (TITANIUM)
15035434 NUT, F/SEAT (M10X1.5X10.8) (FLANGE NUT) (16.679)
15931779 COVER, P/SEAT INR ADJR FRT FIN (TITANIUM)
15882409 COVER, P/SEAT INR ADJR FRT FIN (COCOA)
15931777 COVER, P/SEAT INR ADJR FRT FIN (EBONY) (INBOARD TRACKS)
teamcadillac.ru
20841315 SEAT, PASS (EBONY)
20841316 SEAT, PASS (CASHMERE)
20909009 SEAT, PASS (COCOA)
20909027 SEAT, PASS (EBONY)
20909028 SEAT, PASS (CASHMERE)
20909052 SEAT, PASS (COCOA)
20908986 SEAT, DRVR (EBONY)
20908987 SEAT, DRVR (CASHMERE)
20909011 SEAT, DRVR (COCOA)
20909050 SEAT, DRVR (COCOA)
15895269 COVER, D/SEAT INR ADJR RR FIN (TITANIUM)
15931778 COVER, P/SEAT INR ADJR FRT FIN (CASHMERE)
15214530 COVER, P/SEAT ADJR FIN (EBONY) (OUTBOARD, BELT UTILITY)
15214532 COVER, P/SEAT ADJR FIN (TITANIUM) (BELT UTILITY)
15219924 COVER, P/SEAT ADJR FIN (CASHMERE) (BELT UTILITY)
15882423 COVER, P/SEAT ADJR FIN (COCOA) (BELT UTILITY)
15895289 COVER, P/SEAT INR ADJR RR FIN (TITANIUM)
15882411 COVER, P/SEAT INR ADJR RR FIN (COCOA)
15219930 COVER, P/SEAT INR ADJR RR FIN (CASHMERE)
(TC16-452) 2008-2010 CK1,2(06) СИСТЕМА ЗАМКОВ/ДИСТАНЦИОННОЕ УПРАВЛЕНИЕ БЕЗ КЛЮЧА (CADILLAC Z75, AP3,AU0)
00000001 TRANSMITTER, R/CON DR LK (DEALER INSTALLED 2-WAY WITH DISPLAY-SEE GROUP 21.271 TRANSMITTER) (INCLS 2)
20925554 TRANSMITTER, R/CON DR LK (INCLS 2) (FOB #2)
20869058 TRANSMITTER, R/CON DR LK (INCLS 2) (FOB #1) (W/O REMOTE ENG START)
20869059 TRANSMITTER, R/CON DR LK (INCLS 2) (FOB #2) (W/O REMOTE ENG START)
22756466 TRANSMITTER, R/CON DR LK (INCLS 2) (FOB #2) (W/REMOTE STARTER)
teamcadillac.ru
22756465 TRANSMITTER, R/CON DR LK (INCLS 2) (FOB #1) (W/REMOTE STARTER)
12538938 BATTERY, R/CON DR LK XMTR (PART OF 1) (LITHIUM) (TRADE CR2032) (10.485)
25880055 ANTENNA, R/CON DR LK RCVR
20803736 RECEIVER, R/CON DR LK (10.485)
20803735 RECEIVER, R/CON DR LK (RECEIVERS LABELED OEM 20803735) (10.485)
(TC16-453) 2010 CK107(06) КРЕПЛЕНИЕ ЗАДНЕГО СИДЕНЬЯ (60/40 BENCH AM8, EXC HYBRID HP2)(1ST DES)
15887830 COVER, R/SEAT RSR FIN (EBONY) (ON FLOOR)
teamcadillac.ru
15887831 COVER, R/SEAT RSR FIN (CASHMERE) (ON FLOOR)
15887833 COVER, R/SEAT RSR FIN (CASHMERE) (ON FLOOR)
25875547 COVER, R/SEAT RSR FIN (TITANIUM)
25906783 COVER, R/SEAT RSR FIN (CASHMERE)
11562546 WASHER, FLAT, 14X42.5X3.61 MM, SAE 1050 STL RC 37-43, 7112M (R/SEAT)
(TC16-455) 2010 CK107(06) КРЕПЛЕНИЕ ЗАДНЕГО СИДЕНЬЯ (BUCKET AL4)(1ST DES)
15887843 COVER, R/SEAT RSR FIN (CASHMERE) (ON FLOOR) (W/CARPET)
25831283 COVER, R/SEAT RSR FIN (LINEN) (ON FLOOR) (W/CARPET)
25875543 COVER, R/SEAT RSR FIN (TITANIUM) (ON FLOOR) (W/CARPET)
25906779 COVER, R/SEAT RSR FIN (CASHMERE) (ON FLOOR) (W/CARPET)
15887842 COVER, R/SEAT RSR FIN (EBONY) (ON FLOOR) (W/CARPET)
teamcadillac.ru
25831282 COVER, R/SEAT RSR FIN (LINEN) (ON FLOOR) (W/CARPET)
25906778 COVER, R/SEAT RSR FIN (CASHMERE) (ON FLOOR) (W/CARPET)
15887836 COVER, R/SEAT RSR FIN (EBONY) (ON FLOOR) (W/CARPET)
25875542 COVER, R/SEAT RSR FIN (TITANIUM) (ON FLOOR) (W/CARPET)
(TC16-813) 2007-2013 CK DOOR HARDWARE-PIN KITS
19260061 PIN KIT, FRT S/D HGE (INCLS UPR/LWR PINS, BUSHINGS, WASHER, DUST CAPS, NUTS, BOLT & INST SHEET, (GREASEABLE) (INCLS 2-7)
teamcadillac.ru
19260063 PIN KIT, FRT S/D HGE (INCLS CHECK PIN, ROLLLER PIN, ROLLER, BUSHINGS, DUST CAPS, NUTS & INST SHEET (GREASEABLE) (INCLS 3, 4, 9-12)
(TC16-936) 2007-2013 CK1(06-36) ПРИБОРНАЯ ПАНЕЛЬ И СВЯЗАННЫЕ ДЕТАЛИ PART 2 ELECTRICAL (CADILLAC Z75)
25819574 AIRBAG, I/P (COCOA)
25812358 AIRBAG, I/P (CASHMERE) (DUAL LEVEL)
25812355 AIRBAG, I/P (EBONY)
11588337 BOLT, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (I/P AIRBAG)
25949881 CLOCK, DISPLAY (ROMAN NUMERALS ON CLOCK FACE.)
11610157 NUT, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (I/P) (10.701)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (RDO) (9.665)
15859233 SWITCH, RR PARK ASST ALARM CONT MDL
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (I/P ACSRY CTR TR PLT)
15859232 SWITCH, DRVR INFO DISPLAY
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (ACSRY SW BZL) (9.665)
20820629 SWITCH, ACSRY (1 BUTTON) (ADJ PED)
20820630 SWITCH, ACSRY (2 BUTTON) (ADJ PED, SONIC/PARK) (W/PWR ASSIST STEP DISABLE SWITCH)
20878803 CONTROL, HTR & A/C (W/ F/SEAT HTR & CUSH VENT FAN)
20878804 CONTROL, HTR & A/C (W/ F/SEAT HTR & CUSH VENT FAN)
25936307 CONTROL, HTR & A/C (W/ F/SEAT HTR & CUSH VENT FAN) (ACDelco #15-74029)
25936309 CONTROL, HTR & A/C (W/ F/SEAT HTR & CUSH VENT FAN) (ACDelco #15-74031)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (COMN INTERFACE MDL BRKT) (9.665)
11588920 SCREW, W/RND WA, M3.5X1.59X9.5, 6 THD, 7 O.D., GM512M, GMW3044 (RDO VOL COMP INTR NOISE MIC)
20829983 MODULE, COMN INTERFACE (W/MOBILE TEL XCVR) (LABELED 20829983) (ACDelco #20829983)
20829984 MODULE, COMN INTERFACE (W/MOBILE TEL XCVR) (LABELED 20829984) (ACDelco #20829984)
20923563 MODULE, COMN INTERFACE (W/MOBILE TEL XCVR) (LABELED 20923563) (ACDelco #20923563)
22850735 MODULE, COMN INTERFACE (W/MOBILE TEL XCVR) (ACDelco #22850735) (LABELED 22850735)
11610157 NUT, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (COMMUNICATION INTERFACE MDL BRKT) (10.701)
25791895 BRACKET, COMMUNICATION INTERFACE MDL
teamcadillac.ru
25783504 MICROPHONE, RDO VOL COMP INTR NOISE (HEADLINER PANEL)
15240415 MICROPHONE, RDO VOL COMP INTR NOISE
15221547 PLATE, HDLP SW TR (INCLS 23) (EBONY)
15907806 PLATE, HDLP SW TR (INCLS 23) (EBONY)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 22)
25858706 SWITCH, HDLP & I/P LP DIMR & DM LP (HAS "DOME OFF") (INCLS FRT FOG LAMP SWITCH) (ACDelco #D1528J)
25858707 SWITCH, HDLP & I/P LP DIMR & DM LP (HAS "DOME OFF") (INCLS FRT & RR FOG LAMP SWITCH) (ACDelco #D1529J)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 29)
88909749 FUSE, 3A, MINI, VIOLET (PART OF 29) (8.965) (ACDelco #ATM3-25)
88909754 FUSE, 15A, MINI, BLUE (PART OF 29) (ACDelco #ATM15-25)
88909756 FUSE, MINI (25 AMP) (CLEAR) (QTY 25 (PART OF 29) (ACDelco #ATM25-25)
12092079 FUSE, 10A, MINI, RED (PART OF 29)
88861352 FUSE, 20A, MINI, YELLOW (PART OF 29) (ACDelco #ATM20)
12084791 PULLER, FUSE (PART OF 29) (MINI) (I/P COVER)
25940492 COVER, I/P FUSE BLK ACC HOLE (INCLS 26-28, 30) (EBONY)
25940498 COVER, I/P FUSE BLK ACC HOLE (INCLS 26-28, 30) (CASHMERE)
22925347 COVER, I/P FUSE BLK ACC HOLE (INCLS 26-28, 30) (LINEN) (IF VEH HAS 30 AMP FUSE ORDER LABEL 25940508)
25940508 LABEL, I/P WRG HARN FUSE BLK IDENT (PART OF 29) (2.483)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (INST CSTR) (9.665)
25713063 SENSOR, HDLP AUTO CONT AMB LGT (DUAL SOLAR & TWILIGHT) (ACDelco #25713063)
20887770 CLUSTER, INST (ACDelco #20887770)
20887772 CLUSTER, INST (ACDelco #20887772)
20887771 CLUSTER, INST (ACDelco #20887771)
20887773 CLUSTER, INST (ACDelco #20887773)
25798963 SPEAKER, RDO FRT (3.5") (9.665) (ACDelco #25798963)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 37)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (RDO FRT SPKR) (9.665)
15221850 GRILLE, RDO FRT SPKR (INCLS 35) (EBONY)
15221851 GRILLE, RDO FRT SPKR (INCLS 35) (COCOA)
15248601 GRILLE, RDO FRT SPKR (INCLS 35) (EBONY)
15859569 ANTENNA, ELEK NAVIGATION (ACDelco #15859569)
25918632 ANTENNA, ELEK NAVIGATION (ACDelco #25918632)
(TC16-938) 2007-2013 CK1,2,3 ВЕТРОВОЕ СТЕКЛО И СВЯЗАННЫЕ ДЕТАЛИ
25774613 MIRROR, I/S RR VIEW (INCLS 2)
15816792 MIRROR, I/S RR VIEW (INCLS 2) (W/O MIC) (MATING CONN W/LEADS USE 15306351)
teamcadillac.ru
15271286 MIRROR, I/S RR VIEW (INCLS 2) (10.185)
20945097 MIRROR, I/S RR VIEW (INCLS 2) (10.185)
22915245 MIRROR, I/S RR VIEW (INCLS 2)
19207911 BOLT, I/S RR VIEW MIR (PART OF 1) (BLACK) (M10X24X12.7) (10.186)
15779345 COVER, I/S RR VIEW MIR WRG HARN (BETWEEN ISRVM & HDLNG TRIM)
20859593 WINDSHIELD, (INCLS 3, 6, 14)
20979218 WINDSHIELD, (INCLS 3, 6, 14) (INCLS UPR MLDG)
11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (W/S R/MLDG)
11589183 NUT, PUSH IN, W/SEAL, 4.2X1.41, 6.35-6.48 SQ HL, 9.5 SQ HD, 0.787-2.765 PNL THK, NYL (W/S R/MLDG)
20918020 MOLDING, W/S RVL
20918021 MOLDING, W/S RVL
25954952 SUPPORT, W/S
(TC16-939) 2007-2013 CK107(06) ЛИСТОВОЙ МЕТАЛЛ/КРЫША
25991527 PANEL, RF (ASM)
15202470 PANEL, RF (PO PNL ASM)
15287943 PANEL, RF
15264587 BOW, RF PNL #4 (W/O NUT)
15102503 BOW, RF PNL #3 (W/O NUT)
15288511 BOW, RF PNL #2 (W/NUT)
15163037 BOW, RF PNL #1 (W/O NUT)
teamcadillac.ru
15202494 BRACKET, RF CNSL
15202446 PANEL, RF FRT HDR (INCLS 8, 9) (W/SHIELD RAKE)
10056725 NUT, PUSH-IN, M4.2X1.41, 50 CARB SPR STL, GM7111M PO ZOR (PART OF 7)
(TC16-942) 2007-2013 CK1,2,3 ЛИСТОВОЙ МЕТАЛЛ/COWL
15847235 PANEL, DA (INCLS 2-9, 11-21)
teamcadillac.ru
20836099 PANEL, PLNM UPR (PART OF 1)
11609625 STUD, DA & COWL PNL INSL (PART OF 1, 6) (M5 X 1.6 X 57.0) (RIVET STYLE) (4.047)
15713209 BRACKET, BRK & ACCEL PED (PART OF 1) (L=45 W=80 H=80) (DASH PANEL) (0.829)
15134620 PANEL, PLNM LWR (PART OF 1)
20836094 PANEL, PLNM FRT (PART OF 1) (INCLS 3, 7, 17)
11609625 STUD, DA WRG HARN (PART OF 1, 6) (M5 X 1.6 X 57.0) (RIVET STYLE) (4.047)
22844748 PANEL, COWL SI (PART OF 1) (INCLS 9)
15856112 VALVE, PLNM DRN
15856113 VALVE, PLNM DRN
15862261 BRACKET, FRT W/H PNL UPR (PART OF 1)
11609625 STUD, CHAS WRG HARN CLIP (PART OF 1) (M5 X 1.6 X 57.0) (RIVET STYLE) (4.047)
15185451 BRACKET, BAT TRAY (PART OF 1)
22844749 PANEL, COWL SI (PART OF 1) (INCLS 9)
11609625 STUD, BAT POS CBL (PART OF 1, 6) (M5 X 1.6 X 57.0) (RIVET STYLE) (4.047)
15854747 BRACKET, HOOD STRUT (BODY SI) (PART OF 1) (INCLS 19)
11562567 STUD, HOOD STRUT BALL (PART OF 1, 18)
25809428 DEFLECTOR, PLNM LWR PNL WAT (PART OF 1) (INCLS 21)
15607103 RETAINER, PLNM S/PNL WAT DFL (PART OF 1, 20) (LWR WATER DEFLECTOR) (9.264)
15895064 COVER, PLNM UPR PNL OPG
(TC16-943) 2007-2013 CK107(06) ЛИСТОВОЙ МЕТАЛЛ/UNDERBODY
15234714 PANEL, R/FLR (INCLS 2)
15630183 PLATE, CARGO TIE DN LOOP ANC (PART OF 1) (16.715)
10382641 BRACKET, JK STOW (BOTTOM BRKT INCLS STUDS)
15847621 PANEL, RR W/H INR
15274143 INSULATOR, S/D OPG FRM (C-PLR LWR)
15274144 INSULATOR, S/D OPG FRM (C-PLR LWR)
15288880 EXTENSION, INTER FLR PNL
15288881 EXTENSION, INTER FLR PNL
25815106 EXTENSION, FLR PNL (FRONT)
25815107 EXTENSION, FLR PNL (FRONT)
15115647 SILL, U/B RR CR
15226696 SILL, U/B #5 CR
25946279 SILL, U/B #3 CR
25860801 REINFORCEMENT, R/FLR PNL
teamcadillac.ru
15234718 REINFORCEMENT, R/FLR PNL OTR
15234719 REINFORCEMENT, R/FLR PNL OTR
25946282 SILL, U/B #4 CR
15154215 REINFORCEMENT, R/FLR PNL FRT
15234716 REINFORCEMENT, R/FLR PNL FRT (INCLS EXH MUFF H/SHLD, WELD STUDY)
15234712 REINFORCEMENT, INTER FLR PNL (INCLS EXH MUFF H/SHLD, WELD STUDY)
15722519 REINFORCEMENT, INTER FLR PNL
15029772 BRACE, INTER FLR PNL
15234710 REINFORCEMENT, FLR PNL
15234713 REINFORCEMENT, INTER FLR PNL (CENTER)
25860799 REINFORCEMENT, F/FLR PNL
25946285 SILL, U/B #1 CR
25937226 BRACE, CR SILL
15828261 REINFORCEMENT, FLR PNL (D/SEAT) (OUTER)
25831426 BRACKET, BODY MT (#2) (W/O REINFORCEMENT)
20848417 SILL, U/B #2 CR
25831425 BRACKET, BODY MT (#2)
15822915 REINFORCEMENT, FLR PNL (D/SEAT) (INNER)
20914723 BRACE, CR SILL
25946286 SILL, U/B #1 CR
15234733 REINFORCEMENT, FLR PNL (P/SEAT) (OUTER)
15234735 REINFORCEMENT, FLR PNL (P/SEAT) (INNER)
15173440 STIFFENER, FLR PNL AT TUN
15173441 STIFFENER, FLR PNL AT TUN
20989092 PANEL, F/FLR (INCLS 37-39)
15827692 PANEL, RKR FRT INR
25982599 PANEL, RKR FRT INR
22812484 PANEL, RKR FRT INR
15174121 BRACKET, I/P LWR (PART OF 35)
15734736 STUD, F/SEAT ANC PLT (PART OF 35)
11609625 STUD, BODY WRG HARN GND (PART OF 35) (M5 X 1.6 X 57.0) (RIVET STYLE) (4.047)
25982606 PANEL, RKR RR INR (INCLS STUDS)
25982601 PANEL, RKR RR INR
15950124 PANEL, INTER FLR
(TC16-948) 2007-2013 CK107(06) ЛИСТОВОЙ МЕТАЛЛ/BODY SIDE REAR
25822461 PANEL, BODY SI OTR
25822462 PANEL, BODY SI OTR
11519023 RIVET, POP SHANK 0.256, LENGTH 0.643, 0.189-0.268 GRIP RANGE, 1033 STL, (F/TNK FIL DR HGE)
15940678 DOOR, F/TNK FIL (SEE GROUP 03.000 "FUEL FILLER PIPE" FOR DETAILED ILLUSTRATED VIEW)
25997545 FILLER, BODY SI OTR PNL
25997546 FILLER, BODY SI OTR PNL
15862275 EXTENSION, RR W/H PNL FRT
22813619 EXTENSION, RR W/H PNL FRT
15929419 PANEL, RR W/H OTR (FRT)
15929495 PANEL, RR W/H OTR (FRT)
15824937 PANEL, RR W/H OTR (RR)
15824938 PANEL, RR W/H OTR (RR)
15830951 GASKET, F/TNK FIL DR OPG FIL
20867363 PANEL, BODY SI INR LWR
teamcadillac.ru
20867362 PANEL, BODY SI INR LWR
15876164 SEAL, BODY SI INR LWR PNL
15876165 SEAL, BODY SI INR LWR PNL
25893145 PLATE, R/SEAT SHLDR BELT ANC
25893144 PLATE, R/SEAT SHLDR BELT ANC
15202476 RAIL, RF UPR SI
15202477 RAIL, RF UPR SI
25893161 REINFORCEMENT, BK BODY OPG SI FRM (SEE GROUP 16.000 "SHEET METAL/BODY REAR" FOR DETAILED ILLUSTRATED VIEW)
25893160 REINFORCEMENT, BK BODY OPG SI FRM (SEE GROUP 16.000 "SHEET METAL/BODY REAR" FOR DETAILED ILLUSTRATED VIEW)
25893142 RAIL, RF LWR SI
25893143 RAIL, RF LWR SI
15854158 PANEL, BODY SI INR UPR
15858829 PANEL, BODY SI INR UPR
25780812 PANEL, BODY SI INR
22823527 PANEL, BODY SI INR
15255977 PANEL, F/TNK FIL PIPE HSG
(TC16-951) 2007-2013 CK1,2(06) ЛИСТОВОЙ МЕТАЛЛ/BODY REAR
20942658 FRAME, BK BODY OPG UPR
20938346 EXTENSION, BK BODY OPG FRM UPR
25778949 FRAME, BK BODY OPG
15164155 FRAME, BK BODY OPG SI
15829742 REINFORCEMENT, BK BODY OPG FRM LWR (INCLS 7)
15164157 FRAME, BK BODY OPG LWR
25946269 BRACKET, BODY RR MT (INCLS 10) (BODY)
15887101 SEAL, BK BODY OPG LWR FRM FIL (TO INTER FLR PNL)
22894056 SEAL, BK BODY OPG LWR FRM FIL (TO INTER FLR PNL)
15816355 PANEL, BK BODY OPG FRM SI FIL LWR
teamcadillac.ru
15816359 FILLER, BK BODY OPG FRM SI
15816356 PANEL, BK BODY OPG FRM SI FIL LWR
15816358 FILLER, BK BODY OPG FRM SI
15164156 FRAME, BK BODY OPG SI
(TC16-957) 2007-2013 CK1,2(06-36) ПРИБОРНАЯ ПАНЕЛЬ И СВЯЗАННЫЕ ДЕТАЛИ PART 3 SUPPORTS (CADILLAC Z75)
25842112 SUPPORT, I/P CARR (INCLS 3, 4, 10)
20996068 SUPPORT, I/P CARR (INCLS 3, 4, 10)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (I/P LWR TR PAD) (9.665)
11610157 NUT, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (PART OF 1) (10.701)
teamcadillac.ru
15192254 DEFLECTOR, I/P DRVR KNEE BOLS
11508277 NUT, HEX W/CON WA M6X1 THD, OD-19 PEOR 9 (I/P DRVR KNEE BOLS DFL)
10355555 BRACE, I/P CTR SUPT
11609410 BOLT, HFH, M8X1.25X25, 10.9, GMW3179 (I/P CTR SUPT BR) (0.056)
11589407 BOLT, HWH, M8X1.25X35, 23.5 THD, 24 OD, 10.9, GMW3359, M-PT. (I/P CARR SUPT)
11508277 NUT, HEX W/CON WA M6X1 THD, OD-19 PEOR 9 (I/P LWR T/PNL)
11570136 BOLT, HEX HD, W/CON SPR WA, M6X1X23, 14 THD, 17 O.D., 8.8, GMW3359 (I/P UPR T/PNL)
(TC16-960) 2007-2013 CK1,2(06) СТЕКЛООЧИСТИТЕЛЬ/ЗАДНЕЕ СТЕКЛО (C25)
25887957 HOSE, R/WDO WA PUMP (REAR JUMPER HOSE)
15927514 GROMMET, WSWA PUMP (PUMP GROMMET) (*KIT1, KIT2) (ACDelco #15927514)
11609989 BOLT, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (WSWA SOLV CNTNR)
25820075 RAMP, R/WDO WPR ARM PARK (ACDelco #25820075)
25820122 BLADE, R/WDO WPR (ACDelco #25820122)
15798935 CAP, WSW ARM NUT (PART OF 10)
11589150 NUT, HEX, W/ADH, M8X1.25X6.80, 5, GMW3359 (R/WDO WPR ARM)
15277756 ARM, R/WDO WPR (INCLS 8) (INCLS HOSE)
11569839 NUT, R/WDO WPR MOT
15173732 SPACER, R/WDO WPR MOT
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (R/WDO WPR ARM PARK RAMP)
25923437 MOTOR, R/WDO WPR (INCLS MTG BOLTS AND GROMMETS) (ACDelco #25923437)
25887953 HOSE, WSWA L/GATE EXTN RR (ACDelco #25887953)
20784419 HOSE, WSWA L/GATE EXTN SI LWR (ACDelco #20784419)
15076678 INSULATOR, WSW TRANS SUPT (16.686)
20999340 CONTAINER KIT, WSWA SOLV (INCLS 1, 3) (USE T/W 20999338 WHEN REPLACING 15248577, 15213911 OR 15942522.)
teamcadillac.ru
15942524 PUMP KIT, WSWA W/SEAL (INCLS 3, 4) (RR PUMP KIT W/GROMMET) (ACDelco #15942524)
(TC16-961) 2007-2013 CK1,2(06) ОБЛИЦОВКА КОЛЕСНОЙ АРКИ/REAR
15938661 LINER, RR W/H (INCLS 6) (W/NUT)
15938662 LINER, RR W/H (INCLS 6) (W/NUT)
11562172 BOLT, RR W/H LNR (8.153)
11589292 RETAINER, PUSH-IN, FITS 8.5 DIA HOLE IN 2-4.5 THK PNL, NYLON 6/6 GMP.PA66.015 (RR W/H LNR (PUSH IN))
01605396 RETAINER, PUSH-IN, FITS .250 HOLE, .92 LG.700-OD NYLON BLACK (RR W/H LNR (PUSH IN))
11570498 BOLT, HWH W/FL WA, M4.2X1.41X20, 11.4 THD, 17 OD, ISO 2702 STL , GMW4205, T (RR W/H LNR)
teamcadillac.ru
11513599 NUT, U-TYPE, M4.2X1.41, 0.65-3.80 PNL THK, PZ (PART OF 1) (ACDelco #11513599)
11518531 NUT, PUSH-IN, M4.2X1.41, 15.9X8.4, .7-2.1 PNL, SAE 1050 STL, 7111M, 8.65 SQ HOL (RR W/H PNL) (10.512)
(TC16-962) 2007-2010 CK1,2,3 ИЗОЛЯТОР ПЕРЕДНЕЙ ПАНЕЛИ МОТОРНОГО ОТСЕКА
15901816 INSULATOR, DA PNL (INTERIOR DASH)
25899456 INSULATOR, DA PNL (INTERIOR DASH FOR EXPORT)
15951335 INSULATOR, DA PNL (INTERIOR DASH)
20906466 INSULATOR, COWL S/PNL
teamcadillac.ru
20906467 INSULATOR, COWL S/PNL
20860275 INSULATOR, DA PNL (INCLS 4) (ENGINE SIDE)
(TC16-963) 2010 CK107(06) ПОКРЫТИЕ ПОЛА И СВЯЗАННЫЕ ДЕТАЛИ (EXC HYBRID HP2)(1ST DES)
25998507 MAT, R/FLR (BLACK)
15948218 CARPET, R/FLR PNL (INCLS 5, 15, 16) (EBONY) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922627)
25871796 CARPET, R/FLR PNL (INCLS 5, 15, 16) (TITANIUM) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922628)
25891808 CARPET, R/FLR PNL (INCLS 5, 15, 16) (EBONY) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922641)
25891811 CARPET, R/FLR PNL (INCLS 5, 15, 16) (LINEN) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922642)
25891812 CARPET, R/FLR PNL (INCLS 5, 15, 16) (TITANIUM) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922643)
25902610 CARPET, R/FLR PNL (INCLS 5, 15, 16) (CASHMERE) (79" LENGTH) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922644)
20922628 CARPET, R/FLR PNL (INCLS 5, 15, 16) (TITANIUM)
teamcadillac.ru
25875643 CARPET, R/FLR PNL (INCLS 5, 15, 16) (CASHMERE) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922629)
94672829 MAT, R/FLR (BLACK)
11588960 BOLT, PAN HD, M10X1.5X38, 30 THD, 18OD, 10.8, 4205GMW, TORX, M-POINT (CARGO TIE DN HOOK)
15749157 LOOP, CARGO TIE DN (BLACK) (17.090)
20922879 INSULATOR, FLR PNL RR
20922878 INSULATOR, FLR PNL RR
15917245 DEADENER, RR W/H INR PNL
15917244 DEADENER, RR W/H INR PNL
90584197 DEADENER, FLR PNL (88X220MM) (6.758)
22756982 INSULATOR, FLR PNL FRT
25896628 CARPET, F/FLR PNL (EBONY) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922210)
25896630 CARPET, F/FLR PNL (CASHMERE) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922211)
25896632 CARPET, F/FLR PNL (LINEN) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922212)
25896633 CARPET, F/FLR PNL (TITANIUM) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922213)
25896635 CARPET, F/FLR PNL (EBONY) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922621)
25896637 CARPET, F/FLR PNL (CASHMERE) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922622)
25896638 CARPET, F/FLR PNL (TITANIUM) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922623)
94672827 MAT, F/FLR PNL (BLACK) (POLICE PKG ONLY)
19121915 MAT PKG, FRONT CARPET (EBONY) (TWIN) (NO LOGO) (15.286)
19206524 MAT PKG, FRONT CARPET (CASHMERE) (TWIN) (NO LOGO) (16.800)
19207995 MAT PKG, FRONT CARPET (COCOA) (TWIN) (NO LOGO) (16.800)
19210585 MAT PKG, FRONT VINYL (EBONY) (TWIN) (NO LOGO) (16.800)
19210587 MAT PKG, FRONT VINYL (CASHMERE) (TWIN) (NO LOGO) (16.800)
19210586 MAT PKG, FRONT VINYL (TITANIUM) (TWIN) (NO LOGO) (16.800)
19121926 MAT PKG, REAR CARPET (EBONY) (TWIN) (16.800)
19206525 MAT PKG, REAR CARPET (CASHMERE) (TWIN) (16.800)
25913072 MAT PKG, REAR CARPET (COCOA) (1 PC) (16.800)
19210588 MAT PKG, REAR VINYL (EBONY) (TWIN) (16.800)
19210590 MAT PKG, REAR VINYL (CASHMERE) (TWIN) (16.800)
19210589 MAT PKG, REAR VINYL (TITANIUM) (TWIN) (16.800)
15948218 CARPET, R/FLR PNL (EBONY) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922627)
25871796 CARPET, R/FLR PNL (TITANIUM) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922628)
25891808 CARPET, R/FLR PNL (EBONY) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922641)
25891811 CARPET, R/FLR PNL (LINEN) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922642)
25891812 CARPET, R/FLR PNL (TITANIUM) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922643)
25902610 CARPET, R/FLR PNL (CASHMERE) (79" LENGTH) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922644)
20922628 CARPET, R/FLR PNL (TITANIUM)
25875643 CARPET, R/FLR PNL (CASHMERE) (W/PLASTIC STANCHION COVERS) (FOR 2ND DES SEE 20922629)
(TC16-971) 2007-2013 CK1(06-36) ФУРНИТУРА ДВЕРИ/SIDE FRONT PART 1 (CADILLAC Z75)
20789461 WEATHERSTRIP, FRT & RR S/D UPR AUX (INCLS RETAINERS)
20789462 WEATHERSTRIP, FRT & RR S/D UPR AUX (INCLS RETAINERS)
22766409 WEATHERSTRIP, FRT S/D
22766410 WEATHERSTRIP, FRT S/D
15201414 PLATE, FRT S/D LK STKR ANC
10387651 WASHER, FRT S/D LK STKR (10.571)
20951578 STRIKER, FRT S/D LK (10.569)
09442471 BOLT, TORX HD, W/FLAT CSK, M8X1.25X35, 28 THD, 15.2 O.D., 9.8, NO (FRT S/D LAT STKR)
20772075 MOLDING, FRT S/D WDO RVL (W/RUN CHANNEL)
20772074 MOLDING, FRT S/D WDO RVL (W/RUN CHANNEL)
11588393 BOLT, HEX W/ CON WA, M6X1X15, 7 THD, 17 OD, 8.8, GMW4205 (FRT S/D O/S HDL)
20828232 CLIP, FRT S/D O/S HDL (PART OF 12)
20828237 HANDLE, FRT S/D O/S (INCLS 11) (MOLDED IN BLACK) (ORDER T/W CLIP-20828232) (FOR INSTLN PROCDR REF #09-08-64-023)
20828243 HANDLE, FRT S/D O/S (INCLS 11) (PAINT TO MATCH) (ORDER T/W CLIP-20828232) (FOR INSTLN PROCDR REF #09-08-64-023)
22738721 HANDLE, FRT S/D O/S (INCLS 11) (CHROME) (ORDER T/W CLIP-20828232) (FOR INSTLN PROCDR REF #09-08-64-023)
teamcadillac.ru
20954801 HANDLE, FRT S/D O/S (INCLS 11) (PAINT TO MATCH) (USE T/W CLIP 20828232) (W/O LOCK CYL HOLE)
22738722 HANDLE, FRT S/D O/S (INCLS 11) (CHROME) (USE T/W CLIP 20828232) (FOR INSTLN PROCDR REF #09-08-64-023)
20954796 HANDLE, FRT S/D O/S (INCLS 11) (MOLDED IN BLACK) (ORDER T/W CLIP-20828232) (FOR INSTLN PROCDR REF #09-08-64-023)
20835970 WEATHERSTRIP, FRT S/D LWR AUX (INCLS 13)
20835971 WEATHERSTRIP, FRT S/D LWR AUX (INCLS 13)
25854415 HINGE, FRT S/D UPR (BODY & DR SIDE) (REPL T/W 13307322 T/W ADHESIVE 89021297)
25854416 HINGE, FRT S/D UPR (BODY & DR SIDE) (REPL T/W 13307322 T/W ADHESIVE 89021297)
11609733 BOLT, HEX W/CON WA, M8X1.25X30, 20 THD, 24 OD, 10.9, GMW4205, MAT POINT (FRT S/D HGE (BODY SI))
13307322 BOLT, FRT S/D HGE (USE T/W ADHESIVE 89021297)
20969645 HINGE, FRT S/D LWR (BODY & DR SI) (W/CHECK LINK)
20969646 HINGE, FRT S/D LWR (BODY & DR SI) (W/CHECK LINK)
12451685 SPACER, FRT S/D LAT STKR (10.571)
(TC16-973) 2007-2010 CK1(06-36) ФУРНИТУРА ДВЕРИ/SIDE FRONT PART 2 (CADILLAC Z75)
15831544 ROD, FRT S/D O/S HDL
20984751 ROD, FRT S/D O/S HDL
11609341 SCREW, RD WA HD M6X1X19, 13.55 THD, 16 OD, 10.9, GMW4205, W/ADH GM6175M, MATPT (FRT S/D LAT)
20884470 SENSOR, AIRBAG SI IMP
21110669 PLUG, FRT S/D O/S HDL ACC HOLE (35 MM DIA) (FITS HOLE 25MM) (ROUND) (12.179)
20880973 GROMMET, FRT S/D LKG ROD
15827500 ROD, FRT S/D LK CYL
15827501 ROD, FRT S/D LK CYL
teamcadillac.ru
20825032 CYLINDER KIT, FRT S/D LK (UNCODED)
20828232 CLIP, FRT S/D O/S HDL (PART OF 35)
20828237 HANDLE, FRT S/D O/S (INCLS 31, 33) (MOLDED IN BLACK) (ORDER T/W CLIP-20828232) (FOR INSTLN PROCDR REF #09-08-64-023)
20828243 HANDLE, FRT S/D O/S (INCLS 31, 33) (PAINT TO MATCH) (ORDER T/W CLIP-20828232) (FOR INSTLN PROCDR REF #09-08-64-023)
22738721 HANDLE, FRT S/D O/S (INCLS 31, 33) (CHROME) (ORDER T/W CLIP-20828232) (FOR INSTLN PROCDR REF #09-08-64-023)
20954801 HANDLE, FRT S/D O/S (INCLS 31, 33) (PAINT TO MATCH) (USE T/W CLIP 20828232) (W/O LOCK CYL HOLE)
22738722 HANDLE, FRT S/D O/S (INCLS 31, 33) (CHROME) (USE T/W CLIP 20828232) (FOR INSTLN PROCDR REF #09-08-64-023)
20954796 HANDLE, FRT S/D O/S (INCLS 31, 33) (MOLDED IN BLACK) (ORDER T/W CLIP-20828232) (FOR INSTLN PROCDR REF #09-08-64-023)
22738721 HANDLE, FRT S/D O/S (INCLS 31, 33) (CHROME) (ORDER T/W CLIP-20828232) (FOR INSTLN PROCDR REF #09-08-64-023) (16.350) (SERV CMP OF HANDLE PKGS)
22738722 HANDLE, FRT S/D O/S (INCLS 31, 33) (CHROME) (USE T/W CLIP 20828232) (FOR INSTLN PROCDR REF #09-08-64-023) (16.350) (SERV CMP OF HANDLE PKGS)
15140731 WINDOW, FRT S/D
15140732 WINDOW, FRT S/D
22832142 SEALING STRIP, FRT S/D WDO INR
11589177 BOLT, HEX HD, M6X1.0X18.0, GMW25 9.8 STL, GMW3359 (FRT S/D WDO FRT W/STR RET)
15901807 RETAINER, FRT S/D WDO W/STR FRT
15901808 RETAINER, FRT S/D WDO W/STR FRT
15876169 RETAINER, FRT S/D WDO W/STR RR (INCLS 6)
15876170 RETAINER, FRT S/D WDO W/STR RR (INCLS 6)
20971729 REGULATOR, FRT S/D WDO (INCLS 9-11, 18-20) (16.260) (ACDelco #20971729)
20971730 REGULATOR, FRT S/D WDO (INCLS 9-11, 18-20) (16.260) (ACDelco #20971730)
11589177 BOLT, HEX HD, M6X1.0X18.0, GMW25 9.8 STL, GMW3359 (FRT S/D WDO REG)
20873793 HARNESS, FRT S/D DR WRG (LABELED 20873793 OR 20918197)
20956783 HARNESS, FRT S/D DR WRG
20956786 HARNESS, FRT S/D DR WRG
20956788 HARNESS, FRT S/D DR WRG
20918198 HARNESS, FRT S/D DR WRG (LABELED 20918198)
22820553 HARNESS, FRT S/D DR WRG
22820556 HARNESS, FRT S/D DR WRG (LABELED 22820556)
22820555 HARNESS, FRT S/D DR WRG (LABELED 22820555)
20929437 LOCK, FRT S/D (INCLS 15)
22862025 LOCK, FRT S/D (INCLS 15)
22862024 LOCK, FRT S/D (INCLS 15)
15920704 HANDLE, FRT S/D I/S (EBONY) (W/CHROME HDL)
25906817 HANDLE, FRT S/D I/S (CASHMERE)
15920707 HANDLE, FRT S/D I/S (EBONY) (W/CHROME HDL) (W/ HOLE FOR MEMORY SEAT SWITCH)
22855631 HANDLE, FRT S/D I/S (CASHMERE)
22855634 HANDLE, FRT S/D I/S (CHROME HANDLE BEZEL)
22855632 HANDLE, FRT S/D I/S
11570136 BOLT, HEX HD, W/CON SPR WA, M6X1X23, 14 THD, 17 O.D., 8.8, GMW3359 (FRT S/D T/PNL)
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (FRT S/D WDO REG)
15807100 PLUG, FRT S/D DRN HOLE
15039965 BUMPER, RR S/D
15175184 ROD, FRT S/D LKG
20984750 ROD, FRT S/D LKG
20866212 DOOR, FRT SI (SEE GROUP 16.000 "SHEET METAL/BODYSIDE" FOR DETAILED ILLUSTRATED VIEW) (W/O HINGES)
20970076 DOOR, FRT SI (SEE GROUP 16.000 "SHEET METAL/BODYSIDE" FOR DETAILED ILLUSTRATED VIEW) (W/O HINGES)
11609385 NUT, U-TYPE, M6X1, 29.5 LEN, 12.5 WID, 19.5 CEN-END, 1050, GMW3359 (FRT S/D TR PNL)
15887813 CLIP, FRT S/D MLDG (PART OF 39) (16.225)
25784518 MOLDING, FRT S/D WDO GARN (INCLS 38)
25784519 MOLDING, FRT S/D WDO GARN (INCLS 38)
(TC16-975) 2007-2013 CK107(06) ФУРНИТУРА ДВЕРИ/SIDE REAR PART 1 (CADILLAC Z75)
15201414 PLATE, RR S/D LK STKR ANC
20951578 STRIKER, RR S/D LK (10.569)
11518445 BOLT, RR S/D LK STKR (8 X 1.25 X 25) (T40) (8.908)
22766416 WEATHERSTRIP, RR S/D
15792912 WEATHERSTRIP, RR S/D FRT AUX
15792913 WEATHERSTRIP, RR S/D FRT AUX
teamcadillac.ru
20772079 MOLDING, RR S/D WDO RVL
20772078 MOLDING, RR S/D WDO RVL
11516421 BOLT, HFH, M6X1X10, 14.2 O.D., 9.8, 7114M (RR S/D O/S HDL)
25960522 HANDLE, RR S/D O/S (CHROME) (PO HDL PKG)
20954815 HANDLE, RR S/D O/S (MOLDED IN BLACK)
22738725 HANDLE, RR S/D O/S (CHROME) (PO HDL PKG)
20954816 HANDLE, RR S/D O/S (MOLDED IN BLACK)
20954825 HANDLE, RR S/D O/S (PAINT TO MATCH) (USE T/W CLIP 20828232)
25890276 HANDLE, RR S/D O/S (PAINT TO MATCH)
25854398 HINGE, RR S/D UPR (BODY & DR SIDE) (REPL T/W 13307322 T/W ADHESIVE 89021297)
25854397 HINGE, RR S/D UPR (BODY & DR SIDE) (REPL T/W 13307322 T/W ADHESIVE 89021297)
11609733 BOLT, HEX W/CON WA, M8X1.25X30, 20 THD, 24 OD, 10.9, GMW4205, MAT POINT (RR S/D HGE (BODY SI))
13307322 BOLT, RR S/D HGE (USE T/W ADHESIVE 89021297)
20876300 HINGE, RR S/D LWR (BODY & DR SI)
20876301 HINGE, RR S/D LWR (BODY & DR SI)
20835978 WEATHERSTRIP, RR S/D LWR AUX (INCLS 18)
20835979 WEATHERSTRIP, RR S/D LWR AUX (INCLS 18)
25865733 SEALING STRIP, RR S/D WDO INR
20794451 MOLDING, RR S/D WDO GARN
20794452 MOLDING, RR S/D WDO GARN
12451685 SPACER, RR S/D LK STKR (10.571)
(TC16-977) 2007-2011 CK107(06) ФУРНИТУРА ДВЕРИ/SIDE REAR PART 2
15140723 WINDOW, RR S/D
15140724 WINDOW, RR S/D
15140725 WINDOW, RR S/D
15140726 WINDOW, RR S/D
11589177 BOLT, HEX HD, M6X1.0X18.0, GMW25 9.8 STL, GMW3359 (RR S/D WDO REG)
25885883 REGULATOR, RR S/D WDO (INCLS 3, 5, 6, 16, 17) (W/MOTOR) (ACDelco #25885883)
25885882 REGULATOR, RR S/D WDO (INCLS 3, 5, 6, 16, 17) (W/MOTOR) (ACDelco #25885882)
11589177 BOLT, HEX HD, M6X1.0X18.0, GMW25 9.8 STL, GMW3359 (PART OF 4)
15844876 MOTOR, RR S/D WDO REG (PART OF 4) (ACDelco #15844876)
15844877 MOTOR, RR S/D WDO REG (PART OF 4) (ACDelco #15844877)
88875596 MOTOR, RR S/D WDO REG (PART OF 4) (10.783) (ALL MAKES)
88875597 MOTOR, RR S/D WDO REG (PART OF 4) (10.783) (ALL MAKES)
20953403 HARNESS, RR S/D DR WRG (INCLS 7)
20953404 HARNESS, RR S/D DR WRG (INCLS 7)
22820455 HARNESS, RR S/D DR WRG (INCLS 7)
22896456 HARNESS, RR S/D DR WRG (INCLS 7)
22785475 LATCH, RR S/D (INCLS 9)
22785476 LATCH, RR S/D (INCLS 9)
teamcadillac.ru
22785479 LATCH, RR S/D (INCLS 9)
15175416 ROD, RR S/D LAT
15175417 ROD, RR S/D LAT
15844617 KNOB, RR S/D LKG ROD (CASHMERE)
15844618 KNOB, RR S/D LKG ROD (TITANIUM)
15844620 KNOB, RR S/D LKG ROD (COCOA)
20785356 KNOB, RR S/D LKG ROD (CASHMERE)
15844616 KNOB, RR S/D LKG ROD (EBONY)
25906817 HANDLE, RR S/D I/S (CASHMERE)
25906822 HANDLE, RR S/D I/S (CASHMERE)
25815293 HANDLE, RR S/D I/S (CHROME HANDLE BEZEL)
15920683 HANDLE, RR S/D I/S (EBONY) (W/CHROME HDL)
15920704 HANDLE, RR S/D I/S (EBONY) (W/CHROME HDL)
22855634 HANDLE, RR S/D I/S (CHROME HANDLE BEZEL)
11570136 BOLT, HEX HD, W/CON SPR WA, M6X1X23, 14 THD, 17 O.D., 8.8, GMW3359 (RR S/D T/PNL)
11609385 NUT, U-TYPE, M6X1, 29.5 LEN, 12.5 WID, 19.5 CEN-END, 1050, GMW3359 (RR S/D T/PNL)
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (RR S/D WDO REG)
21110669 PLUG, RR S/D O/S HDL ACC HOLE (35 MM DIA) (FITS HOLE 25MM) (ROUND) (12.179)
20880973 GROMMET, RR S/D LKG ROD
11609341 SCREW, RD WA HD M6X1X19, 13.55 THD, 16 OD, 10.9, GMW4205, W/ADH GM6175M, MATPT (RR S/D LAT)
15831547 ROD, RR S/D O/S HDL
15831548 ROD, RR S/D O/S HDL
25960522 HANDLE, RR S/D O/S (INCLS 28-30) (CHROME) (PO HDL PKG)
20954815 HANDLE, RR S/D O/S (INCLS 28-30) (MOLDED IN BLACK)
22738725 HANDLE, RR S/D O/S (INCLS 28-30) (CHROME) (PO HDL PKG)
20954816 HANDLE, RR S/D O/S (INCLS 28-30) (MOLDED IN BLACK)
20954825 HANDLE, RR S/D O/S (INCLS 28-30) (PAINT TO MATCH) (USE T/W CLIP 20828232)
25890276 HANDLE, RR S/D O/S (INCLS 28-30) (PAINT TO MATCH)
15832413 PIN, RR S/D PULL HDL PIV (PART OF 26) (16.353)
20828232 CLIP, RR S/D O/S HDL (PART OF 26) (16.350)
(TC16-978) 2007-2013 CK1,2(06) WINDOWS/BODY SIDE
teamcadillac.ru
25810433 WINDOW, BODY SI RR
20777487 WINDOW, BODY SI RR
20777488 WINDOW, BODY SI RR
25778988 WINDOW, BODY SI RR (INCLS ANTENNA)
25943786 MODULE, RDO ANT (SEE GROUP 09.000 "ANTENNA" FOR DETAILED ILLUSTRATED VIEW) (ACDelco #25943786)
(TC16-979) 2007-2013 CK1,2(06-36) ПОТОЛОЧНЫЙ ЛЮК (CF5)
22815953 WINDOW, SUN RF (INCLS 2, 3)
11611382 BOLT, SUN RF WDO (PART OF 1) (M5X.9X6.4)
15837594 SEAL, SUN RF WDO (PART OF 1)
25942826 FRAME, SUN RF (INCLS 8) (W/O MOTOR)
11518121 NUT, U, M6X1, MULTI THD, .5'-4.0' THK PNL (SUN RF MDL)
11561674 BOLT, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (SUN RF MDL)
11514623 BOLT, HEX W/CON WA, M6X1X20 (SUN RF MDL)
15905311 SUNSHADE, SUN RF (LINEN)
15846534 SUNSHADE, SUN RF (GRAY)
15837588 SUNSHADE, SUN RF (CASHMERE)
25874715 MOLDING, SUN RF PNL/WDO GARN (LINEN)
25874713 MOLDING, SUN RF PNL/WDO GARN (CASHMERE)
25874712 MOLDING, SUN RF PNL/WDO GARN (GRAY)
15837591 BRACKET, SUN RF MDL
teamcadillac.ru
15837589 HARNESS, SUN RF WRG
15934722 MOTOR, SUN RF ACTR (ACDelco #15934722)
20823530 COVER, SUN RF PNL SI OPG CLOSEOUT (BLACK)
20823531 COVER, SUN RF PNL SI OPG CLOSEOUT (BLACK)
15837592 DEFLECTOR, SUN RF AIR
15924423 STOP, SUN RF S/S (12.810)
15924424 BOLT, SUN RF A/DFL
(TC16-980) 2007-2013 CK1,2(06-36) ДРЕНАЖ ПОТОЛОЧНОГО ЛЮКА (CF5)
15164170 HOSE, SUN RF HSG RR DRN
15164171 HOSE, SUN RF HSG RR DRN
25836914 HOSE, SUN RF HSG FRT DRN
25836913 HOSE, SUN RF HSG FRT DRN
(TC16-986) 2010-2013 CK1(06) КОНСОЛЬ/КРЫША (CADILLAC Z75, CF5,UG1)
25786403 SWITCH, SUN RF (PART OF 4) (EBONY) (BLUE LAGOON BACK LIGHTING)
25786404 SWITCH, SUN RF (PART OF 4) (TRUE WHITE BACK LIGHTING)
15241529 MICROPHONE, MOBILE TEL (PART OF 4) (2-WAY CAVITY)
25845571 SWITCH, L/GATE ACTR (PART OF 4) (PART OF RF CONSOLE)
20811136 CONSOLE, RF (INCLS 1-3, 5-7, 9-14) (LINEN) (W/O SW ASM)
teamcadillac.ru
25977567 CONSOLE, RF (INCLS 1-3, 5-7, 9-14) (GRAY) (W/LEAR TRANSMITTER KIT 25807341)
25977569 CONSOLE, RF (INCLS 1-3, 5-7, 9-14) (CASHMERE)
15853948 PUSHBUTTON, RDG LP SW (PART OF 4) (AT CONSOLE)
15911049 LENS, DM LP (PART OF 4) (1ST ROW)
09431809 BULB, 6CP TRADE #212-2 (PART OF 4) (ACDelco #L212-2)
25828898 DISPLAY, I/P AIRBAG ARMING STATUS (W/WORDS ON AND OFF FOR AIRBAG)
25828899 DISPLAY, I/P AIRBAG ARMING STATUS (W/AIRBAG SYMBOLS FOR ON AND OFF)
22784270 TRANSMITTER, GARAGE DR OPENER (PART OF 4) (WHITE BACKLITE)
11516630 BOLT, RF CNSL (PART OF 4) (M4.2X1.41X20) (8.977)
11609345 NUT, PUSH-IN, 4.2, SAE 1050 STL, GMW3179 (PART OF 4)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 4)
(TC16-992) 2010-2013 CK1(06) КОНСОЛЬ/КРЫША (CADILLAC Z75, UG1, EXC CF5)
15911047 BRACKET, RF RR CNSL (PART OF 5)
11516630 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (PART OF 5)
15241529 MICROPHONE, MOBILE TEL (PART OF 5) (2-WAY CAVITY)
25845571 SWITCH, L/GATE ACTR (PART OF 5) (PART OF RF CONSOLE)
25977628 CONSOLE, RF (INCLS 1-4, 6-9, 11-16) (GRAY) (W/LEAR TRANSMITTER KIT 25807341)
25977630 CONSOLE, RF (INCLS 1-4, 6-9, 11-16) (CASHMERE) (W/LEAR TRANSMITTER KIT 25807341)
15853948 PUSHBUTTON, RDG LP SW (PART OF 5) (AT CONSOLE)
15911049 LENS, DM LP (PART OF 5) (1ST ROW)
09431809 BULB, 6CP TRADE #212-2 (PART OF 5) (ACDelco #L212-2)
11516630 BOLT, RF CNSL (PART OF 5) (M4.2X1.41X20) (8.977)
22784270 TRANSMITTER, GARAGE DR OPENER (PART OF 5) (WHITE BACKLITE)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 5)
teamcadillac.ru
11609345 NUT, PUSH-IN, 4.2, SAE 1050 STL, GMW3179 (PART OF 5)
(TC16-993) 2010-2013 K1(06) КОНСОЛЬ/КРЫША (CADILLAC Z75, EXC CF5,UG1)
15836915 CONSOLE, RF (INCLS 1-4, 6-9, 11-13) (GRAY) (NON-DVD CNSL)
25977622 CONSOLE, RF (INCLS 1-4, 6-9, 11-13) (CASHMERE)
teamcadillac.ru
(TK16-001) 2008-2011 CK1(06) CONSOLE/FLOOR-ARMREST DETAIL (CADILLAC Z75, PLATINUM EDITION ULT)
teamcadillac.ru
11609509 SCREW, LG RD WA HD, C/R, HI-LO, 4.2X1.41X13, 11.35-OD, B PT, 6010, GMW4205 (PART OF 3) (*KIT1)
22596346 BUMPER, F/FLR RR CNSL A/RST (PART OF 3) (W/DURAMETER 30) (LENGTH 29MM) (*KIT1) (10.242)
25778771 BUMPER, F/FLR RR CNSL A/RST (PART OF 2) (*KIT1)
25830489 MAT, F/FLR CNSL STOR TRAY (PART OF 1) (*KIT1)
20898288 LID, F/TOP STOW COMPT (INCLS 1-9) (COCOA) (COMPLETE ASSEMBLY)
22796245 LID, F/TOP STOW COMPT (INCLS 1-9) (EBONY) (COMPLETE ASM)
22796246 LID, F/TOP STOW COMPT (INCLS 1-9) (LT. CASHMERE) (COMPLETE ASSEMBLY)
(TK16-002) 2008-2011 CK1(06) CONSOLE/FLOOR-ARMREST DETAIL (CADILLAC Z75, EXC PLATINUM EDITION ULT)
20898302 PANEL, F/FLR CNSL COMPT DR INR (INCLS 8) (W/LATCH) (USE ON VEHICLES BUILT PRIOR TO 4/1/11) (*KIT1)
teamcadillac.ru
11609509 SCREW, LG RD WA HD, C/R, HI-LO, 4.2X1.41X13, 11.35-OD, B PT, 6010, GMW4205 (F/FLR COMPT) (*KIT1)
22596346 BUMPER, F/FLR RR CNSL A/RST (W/DURAMETER 30) (LENGTH 29MM) (*KIT1) (10.242)
22796245 LID, F/TOP STOW COMPT (COMPLETE ASM) (INCLS 1-3, 5-8) (EBONY) (COMPLETE ASM)
22796246 LID, F/TOP STOW COMPT (INCLS 1-3, 5-8) (LT. CASHMERE) (COMPLETE ASSEMBLY)
(TK16-012) 2010-2013 CK1,2(06-36) СИДЕНЬЕ ВОДИТЕЛЯ/BUCKET-BACK (AN3, EXC HEATED/VENTED HNE,KB6)
20772419 COVER, D/SEAT BK (EBONY)
20772421 COVER, D/SEAT BK (TITANIUM)
20987367 COVER, D/SEAT BK (CASHMERE)
20998443 RESTRAINT, D/SEAT HD (INCLS 2) (TITANIUM)
20912675 GUIDE, F/SEAT H/RST (CASHMERE) (W/BUTTON)
15279347 GUIDE, D/SEAT H/RST (EBONY) (W/BUTTON)
20912676 GUIDE, F/SEAT H/RST (TITANIUM) (W/BUTTON)
20912679 GUIDE, P/SEAT H/RST (EBONY) (W/O BUTTON)
20912680 GUIDE, D/SEAT H/RST (CASHMERE) (W/O BUTTON)
15279353 GUIDE, D/SEAT H/RST (TITANIUM) (W/O BUTTON)
20823362 BEZEL, F/SEAT BK OPG RR
20860379 PANEL, D/SEAT BK FIN (TITANIUM)
20926208 PANEL, D/SEAT BK FIN (CASHMERE) (WHEN REPL.TRIM WRAP PANELS; REPLACE BOTH DR & PASS PANELS)
20926207 PANEL, D/SEAT BK FIN (EBONY) (W/MAP POCKET) (W/O VENT HOLE)
11516075 NUT, HFH SELF LK, M6X1, 7.7THK, 14.2 O.D., 9, PZOR (F/SEAT)
20997499 AIRBAG, D/SEAT SI
20824892 GUIDE, D/SEAT SI AIRBAG
11515764 BOLT, HFH, M10X1.5X20, 18THD, 22.3 O.D., 10.9, 7114M (D/SEAT RECL)
15827131 COVER, F/SEAT RSR FIN (INCLS 18) (TITANIUM) (RIGHT & LEFT TOE KICK)
15827129 COVER, F/SEAT RSR FIN (INCLS 18) (EBONY) (RIGHT & LEFT TOE KICK)
15827130 COVER, F/SEAT RSR FIN (INCLS 18) (CASHMERE) (RIGHT & LEFT TOE KICK)
teamcadillac.ru
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 17)
25934810 BRACKET, D/SEAT RECL (I/B)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 25)
15243823 COVER, D/SEAT INR RECL FIN (INCLS 24) (EBONY) (INBOARD)
15243824 COVER, D/SEAT INR RECL FIN (INCLS 24) (CASHMERE) (INBOARD)
15243825 COVER, D/SEAT INR RECL FIN (INCLS 24) (TITANIUM) (INBOARD)
15855909 PROTECTOR, D/SEAT RECL FIN CVR (EBONY) (RECL CVR CARPET BOOT 40% LH)
15855911 PROTECTOR, D/SEAT RECL FIN CVR (EBONY) (RECL CVR CARPET BOOT 40% RH)
25911156 HEATER, D/SEAT BK (HEAT ONLY)
(TK16-013) 2010-2013 CK1,2(06-36) СИДЕНЬЕ ВОДИТЕЛЯ/BUCKET-CUSHION (AN3, EXC HEATED/VENTED HNE,KB6)
20779849 COVER, D/SEAT CUSH (EBONY) (CARPET INBOARD SIDE FACING) (REPLACES VINYL)
20779850 COVER, D/SEAT CUSH (CASHMERE) (CARPET INBOARD SIDE FACING) (REPLACES VINYL)
20779851 COVER, D/SEAT CUSH (TITANIUM) (CARPET INBOARD SIDE FACING) (REPLACES VINYL)
20792748 HEATER, D/SEAT CUSH
11513599 NUT, U-TYPE, M4.2X1.41, 0.65-3.80 PNL THK, PZ (F/SEAT) (ACDelco #11513599)
22804419 ADJUSTER, D/SEAT (POWER 6-WAY) (INCLS MOTORS) (W/MEMORY)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 11)
12451497 SWITCH, D/SEAT ADJR & RECL (8-WAY) (11.558)
teamcadillac.ru
25926717 SWITCH, D/SEAT LUMBAR CONT (CASHMERE) (4-PIN, BKWD & FORWD ONLY) (11.378)
25926718 SWITCH, D/SEAT LUMBAR CONT (LT TITANIUM) (4-PIN, BKWD & FORWD ONLY) (11.378)
25926719 SWITCH, D/SEAT LUMBAR CONT (EBONY) (4-PIN, BKWD & FORWD ONLY)
15232562 COVER, D/SEAT ADJR FIN (EBONY) (8 WAY POWER) (OUTBOARD)
15232563 COVER, D/SEAT ADJR FIN (CASHMERE) (8 WAY POWER)
15232564 COVER, D/SEAT ADJR FIN (TITANIUM) (8 WAY POWER)
15222985 KNOB, F/SEAT BK RECL (TITANIUM) (11.377)
10340136 KNOB, D/SEAT RECL LVR (EBONY) (11.377)
15222984 KNOB, F/SEAT BK RECL (CASHMERE) (11.377)
15222980 KNOB, D/SEAT ADJR SW (CASHMERE) (11.558)
10325879 KNOB, D/SEAT ADJR SW (EBONY) (11.558)
15222981 KNOB, D/SEAT ADJR SW (TITANIUM) (11.558)
11609539 SCREW, RD CROWNED WA HD, M4.2X1.41X16, STL ISO 2702, GMW4205 (F/SEAT)
15845152 BRACKET, D/SEAT BELT (RETR SI) (O/B)
15232584 COVER, D/SEAT OTR ADJR TRK RR FIN (INCLS 16) (EBONY) (OUTBOARD)
15232585 COVER, D/SEAT OTR ADJR TRK RR FIN (INCLS 16) (CASHMERE) (OUTBOARD)
15232586 COVER, D/SEAT OTR ADJR TRK RR FIN (INCLS 16) (TITANIUM) (OUTBOARD)
11517996 NUT, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (D/SEAT ADJR TOP PLT) (ACDelco #11517996)
15243864 COVER, D/SEAT OTR ADJR TRK RR FIN (EBONY) (INBOARD)
15243865 COVER, D/SEAT OTR ADJR TRK RR FIN (CASHMERE) (INBOARD)
15243866 COVER, D/SEAT OTR ADJR TRK RR FIN (TITANIUM) (INBOARD)
20763638 BRACKET, D/SEAT (DRIVER SIAB)
15243852 COVER, D/SEAT INR ADJR TRK FRT FIN (TITANIUM)
15243850 COVER, D/SEAT INR ADJR TRK FRT FIN (EBONY)
15243851 COVER, D/SEAT INR ADJR TRK FRT FIN (CASHMERE)
25815788 CAP, F/SEAT ADJR TRK END (BLACK)
20900194 COVER, AIRBAG D/SEAT POSN SEN
88981918 BOLT, D/SEAT ADJR (M6X1X13.5) (16.714)
25916854 BRACKET, D/SEAT BELT (BKL SI) (I/B) (INCLDS BKL MOUNT STUD)
19121538 BELT KIT, D/SEAT (BKL SI) (CASHMERE)
19121539 BELT KIT, D/SEAT (BKL SI) (TITANIUM)
19121537 BELT KIT, D/SEAT (BKL SI) (EBONY)
11516075 NUT, HFH SELF LK, M6X1, 7.7THK, 14.2 O.D., 9, PZOR (D/SEAT ADJR MEMORY SW)
25855630 MODULE, D/SEAT ADJR MEMORY (REQUIRES DEALER PROGRAMMING) (11.558) (LABELED 25855630, 25917599, 20870474, 15921044, 15193620, 15246159, 15804058, 15820413, 15826609, 21, 15833435, 15844068, 72, 15853219, 15895345, 48, 15896747)
15854391 FRAME, D/SEAT CUSH
(TK16-014) 2010-2011 CK1,2(06-36) СИДЕНЬЕ ВОДИТЕЛЯ/BUCKET-BACK (AN3, HEATED/VENTED HNE,KB6)
20763636 COVER, D/SEAT BK (COCOA)
20895494 COVER, D/SEAT BK (EBONY)
20895495 COVER, D/SEAT BK (CASHMERE)
20859084 RESTRAINT, D/SEAT HD (INCLS 2) (EBONY)
20859085 RESTRAINT, D/SEAT HD (INCLS 2) (CASHMERE)
20899211 RESTRAINT, D/SEAT HD (INCLS 2) (COCOA)
20998437 RESTRAINT, D/SEAT HD (NO OPENING FOR DVD PLAYER) (INCLS 2) (EBONY)
teamcadillac.ru
20912677 GUIDE, F/SEAT H/RST (COCOA) (W/BUTTON)
15279347 GUIDE, F/SEAT H/RST (EBONY) (W/BUTTON)
20912679 GUIDE, F/SEAT H/RST (EBONY) (W/O BUTTON)
20912680 GUIDE, F/SEAT H/RST (CASHMERE) (W/O BUTTON)
15279353 GUIDE, F/SEAT H/RST (TITANIUM) (W/O BUTTON)
25851751 GUIDE, F/SEAT H/RST (COCOA) (W/O BUTTON)
20763637 PAD, D/SEAT BK
22804410 FRAME, D/SEAT BK (INCLS 8, 17, 18, 21, 23, 24) (W/LUMBAR)
20987411 LUMBAR SUB, D/SEAT (PART OF 7) (4 WAY POWER METAL BASKET MEMORY W/HARNESS)
20926211 PANEL, D/SEAT BK FIN (EBONY)
20926221 PANEL, D/SEAT BK FIN (COCOA)
20926212 PANEL, D/SEAT BK FIN (CASHMERE)
20926185 PANEL, D/SEAT BK FIN (EBONY) (INCLS MAP POCKET W VENT HOLE) (WRAP IN VINYL)
20926186 PANEL, D/SEAT BK FIN (CASHMERE) (WRAP IN VINYL)
20926213 PANEL, D/SEAT BK FIN (TITANIUM)
20926215 PANEL, D/SEAT BK FIN (EBONY)
15232557 BLOWER, D/SEAT BACK VENTILATION HEAT & COOL (INCLS THERMAL ELECTRIC DEVICE, TEMP SENSOR & FILTER)
25924170 DUCT, D/SEAT BACK VENTILATION
15827131 COVER, F/SEAT RSR FIN (INCLS 20) (TITANIUM) (RIGHT & LEFT TOE KICK)
25851756 COVER, F/SEAT RSR FIN (INCLS 20) (COCOA)
15827129 COVER, F/SEAT RSR FIN (INCLS 20) (EBONY) (RIGHT & LEFT TOE KICK)
15827130 COVER, F/SEAT RSR FIN (INCLS 20) (CASHMERE) (RIGHT & LEFT TOE KICK)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 19)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 27)
15243823 COVER, D/SEAT INR RECL FIN (INCLS 26) (EBONY) (INBOARD)
15243824 COVER, D/SEAT INR RECL FIN (INCLS 26) (CASHMERE) (INBOARD)
15243825 COVER, D/SEAT INR RECL FIN (INCLS 26) (TITANIUM) (INBOARD)
25851757 COVER, D/SEAT INR RECL FIN (INCLS 26) (COCOA)
(TK16-015) 2010-2011 CK1,2(06-36) СИДЕНЬЕ ВОДИТЕЛЯ/BUCKET-CUSHION (AN3, HEATED/VENTED HNE,KB6)
25789849 PAD, D/SEAT CUSH (USED ON HEAT/COOL)
25851675 COVER, D/SEAT CUSH (COCOA)
22751125 COVER, D/SEAT CUSH (EBONY)
22751126 COVER, D/SEAT CUSH (CASHMERE)
20987428 ADJUSTER, D/SEAT (USED ON VEHICLES WITH POWER TILT STEERING COLUMN W/MEMORY) (INCLS MOTORS)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 10)
25909573 SWITCH, D/SEAT LUMBAR CONT (COCOA)
teamcadillac.ru
15232563 COVER, D/SEAT ADJR FIN (INCLS 7) (CASHMERE) (8 WAY POWER)
15232564 COVER, D/SEAT ADJR FIN (INCLS 7) (TITANIUM) (8 WAY POWER)
15882421 COVER, D/SEAT ADJR FIN (INCLS 7) (COCOA) (BELT UTILITY)
25851752 COVER, D/SEAT ADJR FIN (INCLS 7) (COCOA) (8 WAY POWER)
15232562 COVER, D/SEAT ADJR FIN (INCLS 7) (EBONY) (8 WAY POWER) (OUTBOARD)
15214529 COVER, D/SEAT ADJR FIN (INCLS 7) (TITANIUM) (BELT UTILITY)
15219925 COVER, D/SEAT ADJR FIN (INCLS 7) (CASHMERE) (BELT UTILITY)
15214527 COVER, D/SEAT ADJR FIN (INCLS 7) (EBONY) (BELT UTILITY)
15889098 KNOB, F/SEAT BK RECL (COCOA) (11.377)
10340136 KNOB, F/SEAT BK RECL (EBONY) (11.377)
15889097 KNOB, D/SEAT ADJR SW (COCOA) (11.558)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 16)
15232584 COVER, D/SEAT OTR ADJR TRK RR FIN (INCLS 15) (EBONY) (OUTBOARD)
15232585 COVER, D/SEAT OTR ADJR TRK RR FIN (INCLS 15) (CASHMERE) (OUTBOARD)
15232586 COVER, D/SEAT OTR ADJR TRK RR FIN (INCLS 15) (TITANIUM) (OUTBOARD)
25851754 COVER, D/SEAT OTR ADJR TRK RR FIN (INCLS 15) (COCOA) (OUTBOARD)
15232586 COVER, D/SEAT OTR ADJR TRK RR FIN (TITANIUM) (OUTBOARD)
25851754 COVER, D/SEAT OTR ADJR TRK RR FIN (COCOA) (OUTBOARD)
15232584 COVER, D/SEAT OTR ADJR TRK RR FIN (EBONY) (OUTBOARD)
15232585 COVER, D/SEAT OTR ADJR TRK RR FIN (CASHMERE) (OUTBOARD)
15827134 BRACKET, D/SEAT (MAIN BODY HARNESS CONNECTION)
25851758 COVER, D/SEAT INR ADJR TRK FRT FIN (COCOA)
22756568 HARNESS, D/SEAT ADJR WRG
25951880 SENSOR, AIRBAG D/SEAT POSN (MATING CONN W/LEADS USE 13577629)
19180587 BELT KIT, D/SEAT (BKL SI) (COCOA)
25862041 MODULE, D/SEAT ADJR MEMORY (REQUIRES DEALER PROGRAMMING) (ADJR & HTR CONTROL) (11.558)
20987427 BLOWER, D/SEAT CUSH VENTILATION HEAT & COOL (INCLS THERMAL ELECTRIC DEVICE, TEMP SENSOR & FILTER)
(TK16-016) 2010-2013 CK1,2(06-36) СИДЕНЬЕ ПАССАЖИРА/BUCKET-BACK (AN3, EXC HEATED/VENTED HNE,KB6)
20998443 RESTRAINT, P/SEAT HD (INCLS 2) (TITANIUM)
20912675 GUIDE, P/SEAT H/RST (CASHMERE) (W/BUTTON)
15279347 GUIDE, P/SEAT H/RST (EBONY) (W/BUTTON)
20912676 GUIDE, P/SEAT H/RST (TITANIUM) (W/BUTTON)
20912680 GUIDE, P/SEAT H/RST (CASHMERE) (W/O BUTTON)
15279353 GUIDE, P/SEAT H/RST (TITANIUM) (W/O BUTTON)
20772175 PAD, P/SEAT BK
25911156 HEATER, P/SEAT BK (HEAT ONLY)
15855911 PROTECTOR, P/SEAT RECL FIN CVR (EBONY) (RECL CVR CARPET BOOT 40% RH)
15855909 PROTECTOR, P/SEAT RECL FIN CVR (EBONY) (RECL CVR CARPET BOOT 40% LH)
11515764 BOLT, HFH, M10X1.5X20, 18THD, 22.3 O.D., 10.9, 7114M (P/SEAT RECL)
15827137 BRACKET, P/SEAT RECL (INBOARD)
15243830 COVER, P/SEAT INR RECL FIN (INCLS 12) (TITANIUM) (INBOARD)
15243828 COVER, P/SEAT INR RECL FIN (INCLS 12) (EBONY) (INBOARD)
15243829 COVER, P/SEAT INR RECL FIN (INCLS 12) (CASHMERE) (INBOARD)
teamcadillac.ru
15827131 COVER, F/SEAT RSR FIN (INCLS 16) (TITANIUM) (RIGHT & LEFT TOE KICK)
15827129 COVER, F/SEAT RSR FIN (INCLS 16) (EBONY) (RIGHT & LEFT TOE KICK)
15827130 COVER, F/SEAT RSR FIN (INCLS 16) (CASHMERE) (RIGHT & LEFT TOE KICK)
20997498 AIRBAG, P/SEAT SI
20824892 GUIDE, P/SEAT SI AIRBAG MDL
20860379 PANEL, P/SEAT BK FIN (TITANIUM)
20926208 PANEL, P/SEAT BK FIN (CASHMERE) (WHEN REPL.TRIM WRAP PANELS; REPLACE BOTH DR & PASS PANELS)
20926207 PANEL, P/SEAT BK FIN (EBONY) (W/MAP POCKET) (W/O VENT HOLE)
(TK16-017) 2010-2013 CK1,2(06-36) СИДЕНЬЕ ПАССАЖИРА/BUCKET-CUSHION (AN3, EXC HEATED/VENTED HNE,KB6)
20919641 MODULE KIT, AIRBAG FRT PASS PRESENCE (W/ SEN) (INCLS 4)
20779855 COVER, P/SEAT CUSH (EBONY) (CARPET INBOARD SIDE FACING) (REPLACES VINYL)
20779857 COVER, P/SEAT CUSH (TITANIUM) (CARPET INBOARD SIDE FACING) (REPLACES VINYL)
20779856 COVER, P/SEAT CUSH (CASHMERE) (CARPET INBOARD SIDE FACING) (REPLACES VINYL)
20792748 HEATER, P/SEAT CUSH
25864494 PAD, P/SEAT CUSH (PART OF 1)
11517996 NUT, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (P/SEAT ADJR TOP PLT) (ACDelco #11517996)
22781429 FRAME, P/SEAT CUSH
19121543 BELT KIT, P/SEAT (BKL SI) (TITANIUM)
19121541 BELT KIT, P/SEAT (BKL SI) (EBONY) (W/TENSIONER)
19121542 BELT KIT, P/SEAT (BKL SI) (CASHMERE)
25916855 BRACKET, P/SEAT BELT (BKL SI) (I/B)
20958089 COVER, AIRBAG P/SEAT POSN SEN
15243860 COVER, P/SEAT INR ADJR TRK FRT FIN (TITANIUM)
15243858 COVER, P/SEAT INR ADJR TRK FRT FIN (EBONY)
15243859 COVER, P/SEAT INR ADJR TRK FRT FIN (CASHMERE)
20779109 ADJUSTER, P/SEAT (POWER 6-WAY) (INCLS MOTORS) (W/O MEMORY)
15827135 BRACKET, P/SEAT FRT (DEALER WILL NEED TO ORDER NEW COVER 20970793) (FOR HD VEHICLES)
15243869 COVER, P/SEAT OTR ADJR TRK RR FIN (EBONY) (INBOARD)
15243870 COVER, P/SEAT OTR ADJR TRK RR FIN (CASHMERE) (INBOARD)
15243871 COVER, P/SEAT OTR ADJR TRK RR FIN (TITANIUM) (INBOARD)
15232589 COVER, P/SEAT OTR ADJR TRK RR FIN (INCLS 21) (EBONY) (OUTBOARD)
15232590 COVER, P/SEAT OTR ADJR TRK RR FIN (INCLS 21) (CASHMERE) (OUTBOARD)
15232591 COVER, P/SEAT OTR ADJR TRK RR FIN (INCLS 21) (TITANIUM) (OUTBOARD)
teamcadillac.ru
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 20)
15845154 BRACKET, P/SEAT BELT (RETR SI) (O/B)
10325879 KNOB, P/SEAT ADJR SW (EBONY) (11.558)
15222981 KNOB, P/SEAT ADJR SW (TITANIUM) (11.558)
15222980 KNOB, P/SEAT ADJR SW (CASHMERE) (11.558)
15232567 COVER, P/SEAT ADJR FIN (INCLS 24) (EBONY) (POWER)
15232568 COVER, P/SEAT ADJR FIN (INCLS 24) (CASHMERE) (POWER)
15232569 COVER, P/SEAT ADJR FIN (INCLS 24) (TITANIUM) (POWER)
25926717 SWITCH, P/SEAT LUMBAR CONT (CASHMERE) (4-PIN, BKWD & FORWD ONLY) (11.378)
25926718 SWITCH, P/SEAT LUMBAR CONT (LT TITANIUM) (4-PIN, BKWD & FORWD ONLY) (11.378)
25926719 SWITCH, P/SEAT LUMBAR CONT (EBONY) (4-PIN, BKWD & FORWD ONLY)
12451498 SWITCH, P/SEAT ADJR & RECL (8-WAY) (11.558)
(TK16-018) 2010-2011 CK1,2(06-36) СИДЕНЬЕ ПАССАЖИРА/BUCKET-BACK (AN3, HEATED/VENTED HNE,KB6)
20859084 RESTRAINT, P/SEAT HD (INCLS 2) (EBONY)
20859085 RESTRAINT, P/SEAT HD (INCLS 2) (CASHMERE)
20899211 RESTRAINT, P/SEAT HD (INCLS 2) (COCOA)
20998437 RESTRAINT, P/SEAT HD (NO OPENING FOR DVD PLAYER) (INCLS 2) (EBONY)
20771978 COVER, P/SEAT BK (COCOA)
20895480 COVER, P/SEAT BK (EBONY)
20895481 COVER, P/SEAT BK (CASHMERE)
20771979 PAD, P/SEAT BK
15243830 COVER, P/SEAT INR RECL FIN (INCLS 11) (TITANIUM) (INBOARD)
25851775 COVER, P/SEAT INR RECL FIN (INCLS 11) (COCOA) (INBOARD)
15243828 COVER, P/SEAT INR RECL FIN (INCLS 11) (EBONY) (INBOARD)
15243829 COVER, P/SEAT INR RECL FIN (INCLS 11) (CASHMERE) (INBOARD)
15827131 COVER, F/SEAT RSR FIN (INCLS 15) (TITANIUM) (RIGHT & LEFT TOE KICK)
25851756 COVER, F/SEAT RSR FIN (INCLS 15) (COCOA)
15827129 COVER, F/SEAT RSR FIN (INCLS 15) (EBONY) (RIGHT & LEFT TOE KICK)
15827130 COVER, F/SEAT RSR FIN (INCLS 15) (CASHMERE) (RIGHT & LEFT TOE KICK)
25924170 DUCT, P/SEAT BACK VENTILATION
22804414 FRAME, P/SEAT BK (INCLS 12, 14, 17, 18, 29)
15232557 BLOWER, P/SEAT BACK VENTILATION HEAT & COOL (INCLS THERMAL ELECTRIC DEVICE, TEMP SENSOR & FILTER)
teamcadillac.ru
20926211 PANEL, P/SEAT BK FIN (EBONY)
20926221 PANEL, P/SEAT BK FIN (COCOA)
20926212 PANEL, P/SEAT BK FIN (CASHMERE)
20926185 PANEL, P/SEAT BK FIN (EBONY) (INCLS MAP POCKET W VENT HOLE) (WRAP IN VINYL)
20926186 PANEL, P/SEAT BK FIN (CASHMERE) (WRAP IN VINYL)
20926213 PANEL, P/SEAT BK FIN (TITANIUM)
22856925 LUMBAR SUB, P/SEAT (PART OF 23)
(TK16-019) 2010-2011 CK1,2(06-36) СИДЕНЬЕ ПАССАЖИРА/BUCKET-CUSHION (AN3, HEATED/VENTED HNE,KB6)
20919642 MODULE KIT, AIRBAG FRT PASS PRESENCE (W/ SEN) (INCLS 3)
teamcadillac.ru
25851690 COVER, P/SEAT CUSH (COCOA)
22751128 COVER, P/SEAT CUSH (EBONY)
22751129 COVER, P/SEAT CUSH (CASHMERE)
19180588 BELT KIT, P/SEAT (BKL SI) (COCOA)
15232555 MODULE, P/SEAT CUSH VENTILATION HEAT & COOL (12 WAY MATING CONN W/OUT LEADS USE 15326110)
11516075 NUT, HFH SELF LK, M6X1, 7.7THK, 14.2 O.D., 9, PZOR (AIRBAG P/SEAT SUPPRESSION)
25954737 SENSOR, AIRBAG P/SEAT POSN
20818405 HARNESS, P/SEAT ADJR WRG (RH PWR W/HEAT/COOL)
25851776 COVER, P/SEAT INR ADJR TRK FRT FIN (COCOA)
25851777 COVER, P/SEAT OTR ADJR TRK RR FIN (COCOA) (INBOARD)
15232589 COVER, P/SEAT OTR ADJR TRK RR FIN (INCLS 22) (EBONY) (OUTBOARD)
15232590 COVER, P/SEAT OTR ADJR TRK RR FIN (INCLS 22) (CASHMERE) (OUTBOARD)
15232591 COVER, P/SEAT OTR ADJR TRK RR FIN (INCLS 22) (TITANIUM) (OUTBOARD)
25851774 COVER, P/SEAT OTR ADJR TRK RR FIN (INCLS 22) (COCOA) (OUTBOARD)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 21)
20987427 BLOWER, P/SEAT CUSH VENTILATION HEAT & COOL (INCLS THERMAL ELECTRIC DEVICE, TEMP SENSOR & FILTER)
15889097 KNOB, P/SEAT ADJR SW (COCOA) (11.558)
15232569 COVER, P/SEAT ADJR FIN (INCLS 26) (TITANIUM) (POWER)
15882423 COVER, P/SEAT ADJR FIN (INCLS 26) (COCOA) (BELT UTILITY)
25851773 COVER, P/SEAT ADJR FIN (INCLS 26) (COCOA)
15214530 COVER, P/SEAT ADJR FIN (INCLS 26) (EBONY) (OUTBOARD, BELT UTILITY)
15219924 COVER, P/SEAT ADJR FIN (INCLS 26) (CASHMERE) (BELT UTILITY)
15232567 COVER, P/SEAT ADJR FIN (INCLS 26) (EBONY) (POWER)
15232568 COVER, P/SEAT ADJR FIN (INCLS 26) (CASHMERE) (POWER)
15214532 COVER, P/SEAT ADJR FIN (INCLS 26) (TITANIUM) (BELT UTILITY)
25909573 SWITCH, P/SEAT LUMBAR CONT (COCOA)
(TK16-035) 2009-2013 CK107(06) ЗАДНЕЕ СИДЕНЬЕ/BENCH-60% SIDE (AM8, HYBRID HP2)
15291597 PAD, R/SEAT BK
15279450 PROTECTOR, R/SEAT SHLDR BELT (BLACK)
11570116 SCREW, PAN HD, M6X1X10, 10 THD, 12 OD, STL SAE J1237, S424, TAPTITE ITE (R/SEAT LAT FIN CVR) (8.913)
11562382 BOLT, HFH, M10X1.5X130, 26 THD, 22.3 OD, 10.9, 7114M, MACH, MAT-PT (R/SEAT BK FRM)
15289969 BRACKET, RR CTR SEAT BELT RETR
11562383 BOLT, HFH, M12X1.75X30.5, 17 THD, 26.6 OD, 10.9 STL, GMW3359, W/ADH 6175M (R/SEAT LAT)
15824670 RESTRAINT, R/SEAT HD (TITANIUM)
25928791 RESTRAINT, R/SEAT HD (CASHMERE)
15865813 RESTRAINT, R/SEAT HD (EBONY)
15824669 RESTRAINT, R/SEAT HD (CASHMERE)
25858321 RESTRAINT, R/SEAT HD (COCOA)
25928790 RESTRAINT, R/SEAT HD (EBONY)
15824676 RESTRAINT, R/SEAT HD (EBONY)
15279353 GUIDE, R/SEAT H/RST (TITANIUM) (W/O BUTTON)
25851751 GUIDE, R/SEAT H/RST (COCOA) (W/O BUTTON)
15279347 GUIDE, R/SEAT H/RST (EBONY) (W/BUTTON)
20912677 GUIDE, R/SEAT H/RST (COCOA) (W/BUTTON)
20912675 GUIDE, R/SEAT H/RST (CASHMERE) (W/BUTTON)
20912679 GUIDE, R/SEAT H/RST (EBONY) (W/O BUTTON)
20912680 GUIDE, R/SEAT H/RST (CASHMERE) (W/O BUTTON)
20912676 GUIDE, R/SEAT H/RST (TITANIUM) (W/BUTTON)
11562378 BOLT, HFH, M10X1.5X30, 18 THD, 22.3 OD, 10.9, GMW3359, W/ADH GM6175M (R/SEAT LAT)
15269762 FRAME, R/SEAT BK
25784336 RETAINER, R/SEAT BK OPG FIN CVR (PUSH IN) (16.720)
20761386 FRAME, R/SEAT CUSH
20789621 PANEL, R/SEAT CUSH TR (COCOA) (O/B INNER)
25816439 PANEL, R/SEAT CUSH TR (EBONY) (O/B INNER)
25816440 PANEL, R/SEAT CUSH TR (CASHMERE) (O/B INNER)
25816441 PANEL, R/SEAT CUSH TR (TITANIUM) (O/B INNER)
25816390 LATCH, R/SEAT BK (OUTBOARD)
15279416 HANDLE, R/SEAT RECL (INCLS 15) (TITANIUM)
15279414 HANDLE, R/SEAT RECL (INCLS 15) (EBONY)
15279415 HANDLE, R/SEAT RECL (INCLS 15) (CASHMERE)
25858332 HANDLE, R/SEAT RECL (INCLS 15) (COCOA)
20789620 PANEL, R/SEAT CUSH TR (COCOA) (SIDE SHIELD OUTER)
25816435 PANEL, R/SEAT CUSH TR (EBONY) (SIDE SHIELD OUTER)
25816436 PANEL, R/SEAT CUSH TR (CASHMERE) (SIDE SHIELD OUTER)
25816437 PANEL, R/SEAT CUSH TR (TITANIUM) (SIDE SHIELD OUTER)
25816392 LATCH, R/SEAT RSR (O/B FLOOR)
11562384 NUT, HFH, M4X.7 THD, 4.75 THK, 10.5 OD, GM510M (9)STL, GM4435M-CODE A (R/SEAT FLR FIL T/PNL)
20761389 PANEL, R/SEAT CUSH TR (EBONY) (LATCH COVER-TUB)
20761390 PANEL, R/SEAT CUSH TR (CASHMERE) (LATCH COVER-TUB)
20789622 PANEL, R/SEAT CUSH TR (COCOA) (LATCH COVER-TUB)
22772281 PANEL, R/SEAT CUSH TR (TITANIUM)
11571092 BOLT, R/SEAT HGE (M10X1.5X114)
11562380 BUSHING, R/SEAT HGE
25816394 SPRING, R/SEAT RECL
15275900 SPRING, R/SEAT RECL (TUMBLE)
25944144 RISER, R/SEAT
11514596 NUT, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (R/SEAT) (8.915) (ACDelco #11514596)
25949171 HARNESS, R/SEAT HTR (TO HEAT PAD)
25979119 HARNESS, R/SEAT HTR (TO HELLA MODULE)
25816396 CABLE, R/SEAT LAT (MASTER SYNC)
20825904 RETAINER, R/SEAT CUSH SI FAC (EBONY)
20825905 RETAINER, R/SEAT CUSH SI FAC (CASHMERE)
20825906 RETAINER, R/SEAT CUSH SI FAC (TITANIUM)
20825907 RETAINER, R/SEAT CUSH SI FAC (COCOA)
25816395 CABLE, R/SEAT LAT (MASTER SYNC)
20789625 PANEL, R/SEAT CUSH TR (COCOA) (HINGE COVER)
25816461 PANEL, R/SEAT CUSH TR (EBONY) (HINGE COVER)
25816462 PANEL, R/SEAT CUSH TR (CASHMERE) (HINGE COVER)
25816463 PANEL, R/SEAT CUSH TR (TITANIUM) (HINGE COVER)
15275914 CABLE, R/SEAT LAT (OUTBOARD) (FLOOR LATCH)
15275917 CABLE, R/SEAT LAT (INBOARD) (FLOOR LATCH)
25816393 LATCH, R/SEAT RSR (I/B FLOOR)
20789624 PANEL, R/SEAT CUSH TR (COCOA) (I/B INNER)
25816451 PANEL, R/SEAT CUSH TR (EBONY) (I/B INNER)
25816452 PANEL, R/SEAT CUSH TR (CASHMERE) (I/B INNER)
25816453 PANEL, R/SEAT CUSH TR (TITANIUM) (I/B INNER)
11562376 SCREW, PAN HD, M12X1.75X55, 42 THD, 27 OD, 10.9, S424, W/ADH GM6175M (R/SEAT LAT)
20761393 PANEL, R/SEAT CUSH TR (EBONY) (I/B OUTER COVER)
20761394 PANEL, R/SEAT CUSH TR (CASHMERE) (I/B OUTER COVER)
20761395 PANEL, R/SEAT CUSH TR (TITANIUM) (I/B OUTER COVER)
20789623 PANEL, R/SEAT CUSH TR (COCOA) (I/B OUTER COVER)
15279464 KNOB, R/SEAT LAT (EBONY) (16.716) (W/O NUMBER LABELS ON 3RD ROW SEAT) (FOR 2ND DES SEE 20963265)
20963265 KNOB, R/SEAT LAT (EBONY) (INNER) (W/NUMBER LABELS ON 3RD ROW SEAT) (FOR 1ST DES SEE 15279464)
19121589 BELT KIT, R/SEAT (BKL SI) (EBONY) (BKL/BKL)
19121591 BELT KIT, R/SEAT (BKL SI) (CASHMERE) (BKL/BKL)
19121592 BELT KIT, R/SEAT (BKL SI) (TITANIUM) (BKL/BKL)
25949169 PROTECTOR, R/SEAT CUSH FRM EDGE
11562386 BOLT, HFH, M8X1.25X24, 22.5 THD, 18 OD, GM6202M, STL, GM4435M.CODE G, TAPTITE (R/SEAT A/RST)
15275854 ARMREST, R/SEAT (EBONY)
15275855 ARMREST, R/SEAT (CASHMERE)
20789569 ARMREST, R/SEAT (COCOA)
15865493 ARMREST, R/SEAT (EBONY)
teamcadillac.ru
15279471 COVER, R/SEAT A/RST SUPT FIN (TITANIUM)
15279469 COVER, R/SEAT A/RST SUPT FIN (EBONY)
20789635 COVER, R/SEAT A/RST SUPT FIN (COCOA)
15279470 COVER, R/SEAT A/RST SUPT FIN (CASHMERE)
15279408 PIN, R/SEAT H/RST ADJ ROD LAT (TITANIUM)
15279406 PIN, R/SEAT H/RST ADJ ROD LAT (EBONY)
15279407 PIN, R/SEAT H/RST ADJ ROD LAT (CASHMERE)
25858342 PIN, R/SEAT H/RST ADJ ROD LAT (COCOA)
19151106 BELT KIT, R/SEAT CTR (RETR SI) (TITANIUM)
19210381 BELT KIT, R/SEAT CTR (RETR SI) (COCOA)
19151105 BELT KIT, R/SEAT CTR (RETR SI) (CASHMERE)
19151104 BELT KIT, R/SEAT CTR (RETR SI) (EBONY)
11562377 BOLT, HFH, M10X1.5X55, 43.45 THD, 22.3 OD, 10.9, GMW3359, W/ADH GM6175M (R/SEAT LAT)
25816391 LATCH, R/SEAT BK (INBOARD)
20792750 HEATER, R/SEAT CUSH
25816398 PAD, R/SEAT CUSH
25816425 COVER, R/SEAT CUSH (EBONY)
25816427 COVER, R/SEAT CUSH (TITANIUM)
20789573 COVER, R/SEAT CUSH (COCOA)
25816426 COVER, R/SEAT CUSH (CASHMERE)
22751166 COVER, R/SEAT CUSH (CASHMERE)
20895549 COVER, R/SEAT CUSH (EBONY)
20789571 COVER, R/SEAT BK (COCOA)
20895601 COVER, R/SEAT BK (EBONY)
15865521 COVER, R/SEAT BK (EBONY)
15865522 COVER, R/SEAT BK (CASHMERE)
15865523 COVER, R/SEAT BK (TITANIUM)
25908031 COVER, R/SEAT BK (CASHMERE)
(TK16-036) 2009-2013 CK107(06) ЗАДНЕЕ СИДЕНЬЕ/BENCH-40% SIDE (AM8, HYBRID HP2)
15269763 FRAME, R/SEAT BK
20789640 PANEL, R/SEAT CUSH TR (COCOA) (I/B INNER)
25816481 PANEL, R/SEAT CUSH TR (EBONY) (I/B INNER)
25816482 PANEL, R/SEAT CUSH TR (CASHMERE) (I/B INNER)
25816483 PANEL, R/SEAT CUSH TR (TITANIUM) (I/B INNER)
25816411 LATCH, R/SEAT BK (INBOARD)
20761401 PANEL, R/SEAT CUSH TR (INCLS 29) (EBONY) (I/B INNER COVER)
20761402 PANEL, R/SEAT CUSH TR (INCLS 29) (CASHMERE) (I/B INNER COVER)
20761403 PANEL, R/SEAT CUSH TR (INCLS 29) (TITANIUM) (I/B INNER COVER)
20789639 PANEL, R/SEAT CUSH TR (INCLS 29) (COCOA) (I/B INNER COVER)
19121596 BELT KIT, R/SEAT (BKL SI) (SINGLE BKL) (TITANIUM)
19121595 BELT KIT, R/SEAT (BKL SI) (CASHMERE)
19121593 BELT KIT, R/SEAT (BKL SI) (SINGLE BKL) (EBONY)
19180585 BELT KIT, R/SEAT (BKL SI) (COCOA)
11570520 BOLT, R/SEAT LAT (M12X1.75X64)
25816412 LATCH, R/SEAT BK (INBOARD FLOOR)
20761397 PANEL, R/SEAT CUSH TR (EBONY) (LATCH COVER-TUB)
20789638 PANEL, R/SEAT CUSH TR (COCOA) (LATCH COVER-TUB)
22772284 PANEL, R/SEAT CUSH TR (CASHMERE) (FLOOR LATCH 40% RR CTR)
22772401 PANEL, R/SEAT CUSH TR (TITANIUM) (FLOOR LATCH 40% RR CTR)
25944145 RISER, R/SEAT
15275903 SPRING, R/SEAT RECL (MANDREL)
25816414 SPRING, R/SEAT RECL
15843764 HARNESS, R/SEAT HTR
25949201 HARNESS, R/SEAT HTR
15275914 CABLE, R/SEAT LAT (FLOOR LATCH)
25816415 CABLE, R/SEAT LAT (OUTBOARD MASTER SYNC)
25816416 CABLE, R/SEAT LAT (INBOARD) (INBOARD MASTER SYNC)
11562379 BOLT, R/SEAT HGE (M10X1.5X92)
teamcadillac.ru
20789641 PANEL, R/SEAT CUSH TR (COCOA) (HINGE COVER)
25816485 PANEL, R/SEAT CUSH TR (EBONY) (HINGE COVER)
25816486 PANEL, R/SEAT CUSH TR (CASHMERE) (HINGE COVER)
25816487 PANEL, R/SEAT CUSH TR (TITANIUM) (HINGE COVER)
20761387 FRAME, R/SEAT CUSH (FOR 2008 & EARLY 2009 VEHICLES IT MAY BE NECESSARY TO CUT A SLIT IN THE SEAT COVER FOR THE BRACKET)
20789636 PANEL, R/SEAT CUSH TR (INCLS 29) (COCOA) (SIDE SHIELD OUTER)
25816465 PANEL, R/SEAT CUSH TR (INCLS 29) (EBONY) (SIDE SHIELD OUTER)
25816466 PANEL, R/SEAT CUSH TR (INCLS 29) (CASHMERE) (SIDE SHIELD OUTER)
25816467 PANEL, R/SEAT CUSH TR (INCLS 29) (TITANIUM) (SIDE SHIELD OUTER)
15279429 HANDLE, R/SEAT RECL (INCLS 32) (TITANIUM)
25858446 HANDLE, R/SEAT RECL (INCLS 32) (COCOA)
15279419 HANDLE, R/SEAT RECL (INCLS 32) (EBONY)
15279420 HANDLE, R/SEAT RECL (INCLS 32) (CASHMERE)
25816401 LATCH, R/SEAT BK (OUTBOARD)
20789637 PANEL, R/SEAT CUSH TR (COCOA) (O/B INNER)
25816469 PANEL, R/SEAT CUSH TR (EBONY) (O/B INNER)
25816470 PANEL, R/SEAT CUSH TR (CASHMERE) (O/B INNER)
25816471 PANEL, R/SEAT CUSH TR (TITANIUM) (O/B INNER)
15824761 HEATER, R/SEAT CUSH
25816418 PAD, R/SEAT CUSH
25816429 COVER, R/SEAT CUSH (EBONY)
25816431 COVER, R/SEAT CUSH (TITANIUM)
25949198 COVER, R/SEAT CUSH (EBONY)
20789580 COVER, R/SEAT CUSH (COCOA)
25816430 COVER, R/SEAT CUSH (CASHMERE)
25908033 COVER, R/SEAT BK (CASHMERE)
15865525 COVER, R/SEAT BK (EBONY)
15865526 COVER, R/SEAT BK (CASHMERE)
15865527 COVER, R/SEAT BK (TITANIUM)
20789578 COVER, R/SEAT BK (COCOA)
20895604 COVER, R/SEAT BK (EBONY)
15291598 PAD, R/SEAT BK
(TK16-037) 2010 CK107(06) ПОКРЫТИЕ ПОЛА И СВЯЗАННЫЕ ДЕТАЛИ (EXC HYBRID HP2)(2ND DES)
20922627 CARPET, R/FLR PNL (EBONY) (W/O PLASTIC STANCHION COVERS) (FOR 1ST DES SEE 15948218)
20922629 CARPET, R/FLR PNL (CASHMERE) (W/O PLASTIC STANCHION COVERS) (FOR 1ST DES SEE 25875643)
20922641 CARPET, R/FLR PNL (INCLS 2-4) (EBONY) (W/O PLASTIC STANCHION COVERS) (FOR 1ST DES SEE 25891808)
20922642 CARPET, R/FLR PNL (INCLS 2-4) (LINEN) (W/O PLASTIC STANCHION COVERS) (FOR 1ST DES SEE 25891811)
20922643 CARPET, R/FLR PNL (INCLS 2-4) (TITANIUM) (W/O PLASTIC STANCHION COVERS) (FOR 1ST DES SEE 25891812)
teamcadillac.ru
20922644 CARPET, R/FLR PNL (INCLS 2-4) (CASHMERE) (69" LENGTH) (W/O PLASTIC STANCHION COVERS) (FOR 1ST DES SEE 25902610)
22837756 INSULATOR, R/FLR PNL CTR
20922210 CARPET, F/FLR PNL (EBONY) (W/O PLASTIC STANCHION COVERS) (FOR 1ST DES SEE 25896628)
20922212 CARPET, F/FLR PNL (LINEN) (W/O PLASTIC STANCHION COVERS) (FOR 1ST DES SEE 25896632)
20922213 CARPET, F/FLR PNL (TITANIUM) (W/O PLASTIC STANCHION COVERS) (FOR 1ST DES SEE 25896633)
20922621 CARPET, F/FLR PNL (EBONY) (W/O PLASTIC STANCHION COVERS) (FOR 1ST DES SEE 25896635)
20922622 CARPET, F/FLR PNL (CASHMERE) (W/O PLASTIC STANCHION COVERS) (FOR 1ST DES SEE 25896637)
20922623 CARPET, F/FLR PNL (TITANIUM) (W/O PLASTIC STANCHION COVERS) (FOR 1ST DES SEE 25896638)
20922211 CARPET, F/FLR PNL (CASHMERE) (W/O PLASTIC STANCHION CVRS) (FOR 1ST DES SEE 20922211)
20922993 CARPET, R/FLR PNL CTR (LINEN)
22837738 CARPET, R/FLR PNL CTR (EBONY)
22837741 CARPET, R/FLR PNL CTR (CASHMERE)
22837739 CARPET, R/FLR PNL CTR (TITANIUM)
22837743 CARPET, R/FLR PNL CTR (EBONY)
22837745 CARPET, R/FLR PNL CTR (CASHMERE)
22837744 CARPET, R/FLR PNL CTR (TITANIUM)
(TK16-040) 2010 CK107(06) КРЕПЛЕНИЕ ЗАДНЕГО СИДЕНЬЯ (BUCKET AL4)(2ND DES)
03537772 NUT, M12X1.75, 10.6THK, 28 O.D., 10, 7111M (R/SEAT) (8.917)
(TK16-042) 2010 CK107(06) КРЕПЛЕНИЕ ЗАДНЕГО СИДЕНЬЯ (60/40 BENCH AM8, EXC HYBRID HP2)(2ND DES)
(TK16-882) 2010-2013 CK107(06) ОТДЕЛКА ВНУТРЕННЯЯ-ROOF (EXC SUNROOF CF5)
20886982 PANEL, HDLNG TR (INCLS 9, 30, 31) (GRAY)
20886983 PANEL, HDLNG TR (INCLS 9, 30, 31) (CASHMERE)
20931026 ASPIRATOR, I/S AIR TEMP SEN (ACDelco #15-51256)
15774330 BRACKET, R/RL RR ASST HDL
10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (R/RL RR ASST HDL (PUSH IN))
11588337 BOLT, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (R/RL RR ASST HDL BRKT)
20760388 HOOK, COAT (INCLS 7) (CASHMERE)
20760387 HOOK, COAT (INCLS 7) (GRAY) (BEZEL W/O FINGERS)
11609649 SCREW, PAN HD, M6X1X20, 15 THD 11.25 OD, 6202M STL, GMW3044, TAPTITE 200 (PART OF 6) (8.913)
15248143 RETAINER, HDLNG T/PNL (CASHMERE)
15126552 RETAINER, HDLNG T/PNL (GRAY) (26.3MM & DIA 6.85)
25835392 DEFLECTOR, AUX A/C AIR OTLT (PART OF 1, 37, 48) (OPEL GRAY)
25835393 DEFLECTOR, AUX A/C AIR OTLT (PART OF 1, 37, 48) (CASHMERE)
15940150 LAMP, DM & RDG (INCLS 11-13) (GRAY)
25850229 LAMP, DM & RDG (INCLS 11-13) (CASHMERE)
15853948 PUSHBUTTON, RDG LP SW (PART OF 10, 18) (AT CONSOLE)
15853945 LENS, DM & RDG LP (3RD ROW LAMP) (PART OF 10)
19116011 BULB, C/LP (PART OF 10, 18) (ACDelco #19116011)
15075507 GRILLE, I/S AIR TEMP SEN ASPIRATOR (GRAY)
15250566 GRILLE, I/S AIR TEMP SEN ASPIRATOR (CASHMERE)
25836770 HANDLE, R/RL RR ASST (INCLS 16) (GRAY)
25836768 HANDLE, R/RL RR ASST (INCLS 16) (GRAY)
25836769 HANDLE, R/RL RR ASST (INCLS 16) (CASHMERE)
25836771 HANDLE, R/RL RR ASST (INCLS 16) (CASHMERE)
11609649 SCREW, PAN HD, M6X1X20, 15 THD 11.25 OD, 6202M STL, GMW3044, TAPTITE 200 (PART OF 15) (8.913)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 18)
15940146 LAMP, DM & RDG (INCLS 11, 13, 17, 19) (OPEL GRAY)
25850223 LAMP, DM & RDG (INCLS 11, 13, 17, 19) (CASHMERE)
15853945 LENS, DM & RDG LP (2ND ROW LAMP) (PART OF 18)
15853951 LENS, S/S ILLUM MIR LP (PART OF 23) (CASHMERE)
15853950 LENS, S/S ILLUM MIR LP (PART OF 23) (GRAY)
13502343 BULB, S/S ILLUM MIR LP (PART OF 23) (8.991) (ACDelco #13502343)
22764796 SUNSHADE, (INCLS 21, 22, 24, 25) (GRAY)
22850311 SUNSHADE, (INCLS 21, 22, 24, 25) (CASHMERE)
22764800 SUNSHADE, (INCLS 21, 22, 24, 25) (GRAY)
22850307 SUNSHADE, (INCLS 21, 22, 24, 25) (CASHMERE)
11610271 SCREW, PAN HD, M4.2X1.41X25, 20.5 THD, 8 OD, 6010M, GMW4205, T15 TORX, AB-PT (PART OF 23)
15828264 COVER, S/S SUPT BOLT (GRAY)
15828266 COVER, S/S SUPT BOLT (CASHMERE)
15828268 COVER, S/S SUPT BOLT (GRAY)
15828270 COVER, S/S SUPT BOLT (CASHMERE)
11516440 SCREW (S/S SUPT)
15893661 RETAINER, S/S (CASHMERE)
15882854 RETAINER, S/S (GRAY)
11569965 CLIP, S/S SUPT (M4.2X1.41) (PUSH IN) (12.8 HOLE) (FOR .7-1.1 PANEL RNG) (10.219)
25994421 CABLE, RDO ANT (PART OF 1, 37, 48) (ACDelco #25994421)
20860277 MODULE, ELEK COMPASS (ACDelco #20860277)
10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (PART OF 33, 45)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 36)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 42)
09431809 BULB, 6CP TRADE #212-2 (PART OF 42) (ACDelco #L212-2)
15256562 BRACKET, VIDEO DISPLAY (INCLS 34)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 47)
25995624 RETAINER, RF RR CNSL (INCLS 46) (DVD BACKPLATE - 3RD ROW)
25995622 RETAINER, RF RR CNSL (INCLS 46) (DVD BACKPLATE - 2ND ROW)
20886985 PANEL, HDLNG TR (INCLS 9, 30, 31) (GRAY)
20886986 PANEL, HDLNG TR (INCLS 9, 30, 31) (CASHMERE)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 53)
09431809 BULB, 6CP TRADE #212-2 (PART OF 53) (ACDelco #L212-2)
15853942 LENS, VIDEO PLYR R/CON SEN (PART OF 53) (RH DVD PUSH-PUSH)
15853941 LENS, VIDEO PLYR R/CON SEN (PART OF 53) (LH DVD PUSH-PUSH)
teamcadillac.ru
15853943 LENS, VIDEO PLYR R/CON SEN (PART OF 53) (CTR DVD FIXED FREEDOM)
25853058 CONSOLE, RF (INCLS 49-52) (GRAY) (2ND ROW DVD)
25853059 CONSOLE, RF (INCLS 49-52) (CASHMERE) (2ND ROW DVD FACE PLT) (PO PNL ASM)
25951257 BRACKET, RF PNL (LOCATED AT FRONT ANC MIC) (W/X-MAS TREE POSTS)
15240415 MICROPHONE, RDO VOL COMP INTR NOISE
(TK16-884) 2010-2013 CK107(06) ОТДЕЛКА ВНУТРЕННЯЯ-ROOF (SUNROOF CF5)
20886975 PANEL, HDLNG TR (INCLS 9, 30, 31) (GRAY)
20886976 PANEL, HDLNG TR (INCLS 9, 30, 31) (CASHMERE)
20886979 PANEL, HDLNG TR (INCLS 9, 30, 31) (GRAY)
20886980 PANEL, HDLNG TR (INCLS 9, 30, 31) (CASHMERE)
25835392 DEFLECTOR, AUX A/C AIR OTLT (PART OF 1, 38) (OPEL GRAY)
25835393 DEFLECTOR, AUX A/C AIR OTLT (PART OF 1, 38) (CASHMERE)
15940150 LAMP, DM & RDG (3RD ROW) (INCLS 11-13) (GRAY)
25850229 LAMP, DM & RDG (3RD ROW) (INCLS 11-13) (CASHMERE)
19116011 BULB, C/LP (PART OF 10) (ACDelco #19116011)
15940146 LAMP, DM & RDG (INCLS 11, 17, 19) (OPEL GRAY)
25850223 LAMP, DM & RDG (INCLS 11, 17, 19) (CASHMERE)
15853945 LENS, DM & RDG LP (PART OF 18)
teamcadillac.ru
25994421 CABLE, RDO ANT (PART OF 1, 38) (ACDelco #25994421)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 37)
25995624 RETAINER, RF RR CNSL (INCLS 36) (DVD BACKPLATE - 3RD ROW)
25995622 RETAINER, RF RR CNSL (INCLS 36) (DVD BACKPLATE - 2ND ROW)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 41)
25853058 CONSOLE, RF (INCLS 40, 42-44) (GRAY) (2ND ROW DVD)
25853059 CONSOLE, RF (INCLS 40, 42-44) (CASHMERE) (2ND ROW DVD FACE PLT) (PO PNL ASM)
15853942 LENS, VIDEO PLYR R/CON SEN (PART OF 41) (RH DVD PUSH-PUSH)
15853941 LENS, VIDEO PLYR R/CON SEN (PART OF 41) (LH DVD PUSH-PUSH)
15853943 LENS, VIDEO PLYR R/CON SEN (PART OF 41) (CTR DVD FIXED FREEDOM)
09431809 BULB, 6CP TRADE #212-2 (PART OF 41) (ACDelco #L212-2)
(TK16-900) 2008-2013 CK107(06) ПОКРЫТИЕ ПОЛА И СВЯЗАННЫЕ ДЕТАЛИ (HYBRID HP2)
25871798 CARPET, R/FLR PNL (INCLS 2-4) (TITANIUM)
25875645 CARPET, R/FLR PNL (INCLS 2-4) (CASHMERE)
teamcadillac.ru
25891889 CARPET, R/FLR PNL (INCLS 2-4) (TITANIUM)
25902611 CARPET, R/FLR PNL (INCLS 2-4) (CASHMERE)
25783706 CARPET, R/FLR PNL (INCLS 2-4) (EBONY)
20764873 CARPET, R/FLR PNL (INCLS 2-4) (LINEN)
25891886 CARPET, R/FLR PNL (INCLS 2-4) (EBONY)
25813593 COVER, R/SEAT RSR INR FIN (SEE GROUP 16.000 "REAR SEAT MOUNTING" FOR DETAILED ILLUSTRATED VIEW) (EBONY)
25813595 COVER, R/SEAT RSR INR FIN (SEE GROUP 16.000 "REAR SEAT MOUNTING" FOR DETAILED ILLUSTRATED VIEW) (TITANIUM)
20820025 COVER, R/SEAT RSR INR FIN (SEE GROUP 16.000 "REAR SEAT MOUNTING" FOR DETAILED ILLUSTRATED VIEW) (LINEN)
25813594 COVER, R/SEAT RSR INR FIN (SEE GROUP 16.000 "REAR SEAT MOUNTING" FOR DETAILED ILLUSTRATED VIEW) (CASHMERE)
20813429 INSULATOR, FLR PNL RR
20813430 INSULATOR, FLR PNL RR
25961362 INSULATOR, BAT (SEE GROUP 02.000 "BATTERY MOUNTING/DRIVE MOTOR" FOR DETAILED ILLUSTRATED VIEW)
20757791 INSULATOR, FLR PNL FRT
20764871 CARPET, F/FLR PNL (LINEN)
25896640 CARPET, F/FLR PNL (EBONY)
25896641 CARPET, F/FLR PNL (CASHMERE)
25896643 CARPET, F/FLR PNL (TITANIUM)
17800408 MAT PKG, FRONT CARPET (MOLDED EDGE) (EBONY) (2.03KGS) (CPT) (TWIN) (W/WREATH & CREST LOGO) (16.800)
17800409 MAT PKG, FRONT CARPET (MOLDED EDGE) (CASHMERE) (2.03KGS) (CPT) (TWIN) (W/WREATH & CREST LOGO) (16.800)
25871798 CARPET, R/FLR PNL (TITANIUM)
25875645 CARPET, R/FLR PNL (CASHMERE)
25783706 CARPET, R/FLR PNL (EBONY)
25891889 CARPET, R/FLR PNL (TITANIUM)
25902611 CARPET, R/FLR PNL (CASHMERE)
20764873 CARPET, R/FLR PNL (LINEN)
25891886 CARPET, R/FLR PNL (EBONY)
(TK16-904) 2009-2013 CK1(06) ПРИБОРНАЯ ПАНЕЛЬ И СВЯЗАННЫЕ ДЕТАЛИ PART 1 TRIM (CADILLAC Z75)
20844035 PANEL, I/P UPR TR (W/ W/S DEFR NOZ GRL) (INCLS 2, 57) (EBONY) (W/O SI OUTLET GRILLES)
20844038 PANEL, I/P UPR TR (W/ W/S DEFR NOZ GRL) (INCLS 2, 57) (COCOA)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 1)
15221850 GRILLE, RDO FRT SPKR (INCLS 4) (EBONY)
15221851 GRILLE, RDO FRT SPKR (INCLS 4) (COCOA)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 3)
15813116 GRILLE, SI WDO DEFG OTLT (EBONY) (*KIT2)
15813143 GRILLE, SI WDO DEFG OTLT (EBONY) (*KIT2)
15813144 GRILLE, SI WDO DEFG OTLT (COCOA) (*KIT2)
15813117 GRILLE, SI WDO DEFG OTLT (COCOA) (*KIT2)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (I/P UPR TR PAD) (9.665)
11610157 NUT, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (PART OF 9) (10.701)
22783170 PANEL, I/P LWR TR (INCLS 8, 53) (CASHMERE)
22783169 PANEL, I/P LWR TR (INCLS 8, 53) (EBONY)
22845822 PANEL, I/P LWR TR (INCLS 8, 53) (COCOA)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 12, 50)
20935580 DEFLECTOR, I/P OTR AIR OTLT (INCLS 59) (PART OF 12) (EBONY)
20935552 PLATE, I/P TR (INCLS 10, 11, 59) (RUBY)
20935553 PLATE, I/P TR (INCLS 10, 11, 59) (CHOCOLATE)
20935569 PLATE, I/P TR (INCLS 10, 11, 13) (CHOCOLATE)
20935555 PLATE, I/P TR (INCLS 10, 11, 59) (OLIVE)
20935568 PLATE, I/P TR (INCLS 10, 11, 13) (RUBY)
20935552 PLATE, I/P TR (INCLS 10, 11) (RUBY)
20935553 PLATE, I/P TR (INCLS 10, 11) (CHOCOLATE)
25971121 EMBLEM, I/P (PART OF 12)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 15)
15854787 COVER, I/P COMPT ACC HOLE (INCLS 14) (EBONY) (GLOVE BOX)
15854854 BUMPER, I/P COMPT DR STOP (BIN) (*KIT1) (16.110)
11609509 SCREW, LG RD WA HD, C/R, HI-LO, 4.2X1.41X13, 11.35-OD, B PT, 6010, GMW4205 (I/P COMPT DR) (*KIT1)
10446032 BUMPER, I/P COMPT (8.80 DIA) (CLOSED-STOP) (FRAME) (*KIT1) (10.263)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (I/P COMPT DR) (9.665)
11609539 SCREW, RD CROWNED WA HD, M4.2X1.41X16, STL ISO 2702, GMW4205 (I/P COMPT DR LAT STKR) (*KIT1)
11610157 NUT, PNL, M4.2X1.41, 8.5X11.9, 2.3-2.8 PNL, FITS 11.2X9.2 HOLE, 1050, GMW33 (I/P LWR TIE BAR) (*KIT1) (10.701)
11589015 BOLT, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (I/P COMPT DR HGE) (*KIT1)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (I/P ACSRY CTR TR PLT) (*KIT3)
20935618 DEFLECTOR, I/P CTR AIR OTLT (EBONY) (*KIT3)
25960447 LATCH, I/P COMPT DR (LINEN) (W/LOCK) (*KIT1) (10.268)
25960443 LATCH, I/P COMPT DR (EBONY) (W/LOCK HOLE) (*KIT1) (10.268)
25960448 LATCH, I/P COMPT DR (CASHMERE) (W/LOCK) (*KIT1) (10.268)
22819134 CYLINDER KIT, I/P COMPT DR LK (UNCODED)
25878605 PLATE, I/P ACSRY CTR TR (RUBY BURLWOOD) (W/O DEFLECTORS) (*KIT3)
25878606 PLATE, I/P ACSRY CTR TR (CHOCOLATE BURL) (W/O DEFLECTORS) (*KIT3)
20935616 DEFLECTOR, I/P CTR AIR OTLT (EBONY) (*KIT3)
10365827 INSULATOR, I/P (W/O FELT TAPE)
25790726 INSULATOR, I/P (W/FELT TAPE)
11517774 BOLT, HEX, M4.2X1.41X20, 14.25 OD, 6010M, 6138M, TAP, AB-PT (I/P INSL)
15238666 PANEL, F/FLR CNSL SI TR FRT (INCLS 36) (EBONY) (16.081)
15876585 PANEL, F/FLR CNSL SI TR FRT (INCLS 36-38, 58) (LINEN)
15876587 PANEL, F/FLR CNSL SI TR FRT (INCLS 36) (LINEN)
25901544 PANEL, F/FLR CNSL SI TR FRT (INCLS 36) (CASHMERE)
25844279 PANEL, F/FLR CNSL SI TR FRT (INCLS 36-38, 58) (EBONY)
25901545 PANEL, F/FLR CNSL SI TR FRT (INCLS 36-38, 58) (CASHMERE)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 35)
11588920 SCREW, W/RND WA, M3.5X1.59X9.5, 6 THD, 7 O.D., GM512M, GMW3044 (PART OF 35)
15240415 MICROPHONE, RDO VOL COMP INTR NOISE (PART OF 35)
15221547 PLATE, HDLP SW TR (INCLS 40, 41) (EBONY)
15907806 PLATE, HDLP SW TR (INCLS 40, 41) (EBONY)
teamcadillac.ru
11610112 CLIP, HDLP (PART OF 39) (10.4 X 13 X 9) (14.683)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 39)
22773450 BOLSTER, I/P KNEE (INCLS 42) (LINEN)
22773443 BOLSTER, I/P KNEE (INCLS 42) (EBONY)
22773448 BOLSTER, I/P KNEE (INCLS 42) (CASHMERE)
22773444 BOLSTER, I/P KNEE (INCLS 42) (CASHMERE)
22773447 BOLSTER, I/P KNEE (INCLS 42) (EBONY)
11589012 BOLT, HWH, M4.2X1.41X25, 16.4 THD, 12.5 OD, GM6010M STL, GMW4205 (I/P DRVR KNEE BOLS) (9.665)
25901548 COVER, I/P FUSE BLK ACC HOLE (INCLS 46) (CASHMERE)
25940492 COVER, I/P FUSE BLK ACC HOLE (INCLS 46-49) (EBONY)
25940498 COVER, I/P FUSE BLK ACC HOLE (INCLS 46-49) (CASHMERE)
25855840 COVER, I/P FUSE BLK ACC HOLE (INCLS 46) (EBONY)
25896366 COVER, I/P FUSE BLK ACC HOLE (INCLS 46) (LINEN)
22925347 COVER, I/P FUSE BLK ACC HOLE (INCLS 46-49) (LINEN) (IF VEH HAS 30 AMP FUSE ORDER LABEL 25940508)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 45)
88909749 FUSE, 3A, MINI, VIOLET (PART OF 45) (8.965) (ACDelco #ATM3-25)
88909754 FUSE, 15A, MINI, BLUE (PART OF 45) (ACDelco #ATM15-25)
88909756 FUSE, MINI (25 AMP) (CLEAR) (QTY 25 (PART OF 45) (ACDelco #ATM25-25)
12092079 FUSE, 10A, MINI, RED (PART OF 45)
88861352 FUSE, 20A, MINI, YELLOW (PART OF 45) (ACDelco #ATM20)
12084791 PULLER, FUSE (PART OF 45) (MINI) (I/P COVER)
25940508 LABEL, I/P WRG HARN FUSE BLK IDENT (PART OF 45) (2.483)
15876619 PLATE, I/P TR (INCLS 10, 51, 59) (BURL)
20935548 PLATE, I/P TR (INCLS 10, 51, 59) (CHOCOLATE)
20935547 PLATE, I/P TR (INCLS 10, 51, 59) (RUBY)
20935578 DEFLECTOR, I/P OTR AIR OTLT (PART OF 50) (INCLS 59) (EBONY)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 54)
11513599 NUT, U-TYPE, M4.2X1.41, 0.65-3.80 PNL THK, PZ (PART OF 9) (ACDelco #11513599)
25914313 PLATE, I/P CSTR TR (INCLS 52, 56) (EBONY)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (I/P UPR TR PLT) (*KIT2)
25603681 INSULATOR, I/P CSTR TR PLT (PART OF 54) (*KIT3)
11562257 RETAINER, I/P LWR TR PAD BRKT (PUSH ON) (PART OF 35) (19.5 X 30.4 X 1.8) (14.683)
22792288 KNOB, I/P OTR AIR OTLT (PART OF 11, 12, 50, 51)
25965505 DOOR, I/P COMPT (INCLS 16-19, 21-26, 29) (CASHMERE)
25965502 DOOR, I/P COMPT (INCLS 16-19, 21-26, 29) (LINEN)
20925891 DOOR, I/P COMPT (INCLS 16-19, 21-26, 29) (EBONY)
22845828 PANEL, I/P UPR TR (INCLS 5, 6, 55) (COCOA)
22818929 PANEL, I/P UPR TR (INCLS 5, 6, 55) (COCOA)
22845831 PANEL, I/P UPR TR (INCLS 5, 6, 55) (EBONY)
25878605 PLATE, I/P ACSRY CTR TR (INCLS 27, 28, 31, 32, 56) (RUBY BURLWOOD) (W/O DEFLECTORS)
25878606 PLATE, I/P ACSRY CTR TR (INCLS 27, 28, 31, 32, 56) (CHOCOLATE BURL) (W/O DEFLECTORS)
20935599 PLATE, I/P ACSRY CTR TR (INCLS 27, 28, 31, 32, 56) (PLATINUM) (W/PLATE & DEFLECTORS)
20935605 PLATE, I/P ACSRY CTR TR (INCLS 27, 28, 31, 32, 56) (RUBY) (W/PLATE & DEFLECTORS)
(TK16-910) 2009-2011 CK1,2(06) КАМЕРА ЗАДНЕГО ВИДА (UVC)
25872958 HARNESS, RR LIC PLT LP WRG
teamcadillac.ru
03530297 NUT, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (L/GATE CTR MLDG)
20945097 MIRROR, I/S RR VIEW (10.185)
15779345 COVER, I/S RR VIEW MIR WRG HARN (BETWEEN ISRVM & HDLNG TRIM)
(TK16-914) 2010 CK1(06) СИСТЕМА СТЕКЛООЧИСТИТЕЛЯ ВЕТРОВОГО СТЕКЛА (POLICE PACKAGE PPV)(1ST DES)
20959488 ARM, WSW (INCLS 2) (BLACK)
20959487 ARM, WSW (INCLS 2) (BLACK)
15776792 CAP, WSW ARM FIN (PART OF 1) (WINDSHIELD-CAP WIPER ARM NUT)
11609634 NUT, HEX WASH, M10X1.25, 7MM THK, 20 WA OD, 9 STL, 7111M, CON SPR WA. (WSW ARM)
25820729 PANEL, AIR INL GRL (INCLS 5) (BLACK)
25820730 PANEL, AIR INL GRL (INCLS 5) (BLACK)
11609796 CLIP, AIR INL GRL PNL (PART OF 4) (11.0 X 12.9 X 6.1MM) (8.950)
teamcadillac.ru
15780444 COVER, W/S O/S MSTRE SEN (COVERS MIR HARNESS)
25872303 PANEL, AIR INL GRL (CTR) (INCLS 10, 15, 18) (BLACK)
20908176 HOSE, WSWA NOZ (PART OF 9)
25923882 MODULE, WSW SYS
11513947 BOLT, HEX, W/WA, M6X1X35, 24 O.D., AC PT, 9.8, POR (WSW SYS MDL)
15999788 RETAINER, AIR INL GRL PNL (17X15.25X8.6) (U-SHAPED/CLIP)
11589183 NUT, PUSH IN, W/SEAL, 4.2X1.41, 6.35-6.48 SQ HL, 9.5 SQ HD, 0.787-2.765 PNL THK, NYL (AIR INL GRL PNL)
15200240 WEATHERSTRIP, HOOD RR (PART OF 9)
11609797 BOLT, AIR INL GRL PNL (10.268)
25877402 BLADE, WSW (22") (ONE PIECE FLAT BLADE) (W/SIDE LOCK RELEASE CONNECT ON CENTER)
15048061 RETAINER, AIR INL GRL PNL (PART OF 9) (PUSH IN)
25731418 CAP, WSWA SOLV CNTNR (10.154)
20999340 CONTAINER KIT, WSWA SOLV (INCLS 24, 25) (USE T/W 20999338 WHEN REPLACING 15248577, 15213911 OR 15942522.)
11516578 BOLT, HEX W/FL WA, M6X1X25, 16 THD, 24 OD, 9.8, 7114M, MACH, 6MM P PT. (WSWA SOLV CNTNR)
20999338 INDICATOR KIT, WSWA SOLV LVL (INCLS 24) (LEVEL SENSOR KIT W/GROMMET) (KIT HAS 16MM DIAM LVL SENSOR) (ACDelco #20999338) (USE T/W 20999340 WHEN REPLACING 15248577, 15213911 OR 15942522.)
15248578 GROMMET, WSWA SOLV CNTNR (PART OF 21, 23)
15927514 GROMMET, WSWA PUMP (PUMP GROMMET) (PART OF 21, 26, 27) (ACDelco #15927514)
15942524 PUMP KIT, WSWA W/SEAL (INCLS 25) (RR PUMP KIT W/GROMMET) (ACDelco #15942524)
15942523 PUMP KIT, WSWA W/SEAL (INCLS 25) (FRT PUMP KIT W/GROMMET) (ACDelco #15942523)
25887957 HOSE, R/WDO WA PUMP (SEE GROUP 16.000 "WIPER SYSTEM/ REAR WINDOW" FOR DETAILED ILLUSTRATED VIEW) (REAR JUMPER HOSE)
25887977 HOSE, WSWA PUMP (FRT JUMPER HOSE)
11516793 NUT, HEX, W/CON WA, M6X1X5.5, 16 O.D., 9, 7111M (WSWA SOLV HTR)
20779836 SPACER, AIR INL GRL PNL
(TK16-915) 2010-2013 CK1,2,3 СИСТЕМА ПОДУШЕК БЕЗОПАСНОСТИ
25812356 AIRBAG, I/P (CASHMERE)
25812357 AIRBAG, I/P (TITANIUM)
25819574 AIRBAG, I/P (COCOA)
teamcadillac.ru
25812358 AIRBAG, I/P (CASHMERE) (DUAL LEVEL)
25812355 AIRBAG, I/P (EBONY)
11588337 BOLT, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (I/P AIRBAG)
25784920 AIRBAG, STRG WHL (COCOA) (DUAL LEVEL)
25917968 AIRBAG, STRG WHL (EBONY) (LABELED 25917968) (DUAL LEVEL) (INCLS NON-SERVICE CABLE EMBLEM)
25917969 AIRBAG, STRG WHL (COCOA) (LABELED 25917969) (DUAL LEVEL)
21996989 TAG, I/P AIRBAG WRNG (HANGING)
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (AIRBAG SEN & DIAGN MDL CVR)
25898069 COVER, AIRBAG SEN & DIAGN
03530297 NUT, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (AIRBAG SEN & DIAGN MDL CVR)
13576628 MODULE, AIRBAG SEN & DIAGN
13502744 SENSOR, AIRBAG F/END DISCRM (MT ON FRT RAD SUPT)
(TK16-926) 2010-2013 CK1,2(06-36) РЕМНИ БЕЗОПАСНОСТИ/ПЕРЕДНИЕ
15257724 COVER, P/SEAT SHLDR BELT GDE ADJR OPG (GRAY)
25831268 COVER, D/SEAT SHLDR BELT GDE ADJR OPG (LINEN)
15257726 COVER, D/SEAT SHLDR BELT GDE ADJR OPG (CASHMERE)
15257724 COVER, D/SEAT SHLDR BELT GDE ADJR OPG (GRAY)
25901990 ADJUSTER, D/SEAT SHLDR BELT GDE (INCLS 4) (LINEN)
25901985 ADJUSTER, D/SEAT SHLDR BELT GDE (INCLS 4) (GRAY)
25901987 ADJUSTER, P/SEAT SHLDR BELT GDE (INCLS 4) (CASHMERE)
25901985 ADJUSTER, P/SEAT SHLDR BELT GDE (INCLS 4) (GRAY)
25901987 ADJUSTER, D/SEAT SHLDR BELT GDE (INCLS 4) (CASHMERE)
11609471 BOLT, D/SEAT BELT (RETR SI) (PART OF 8) (M12X1.75X28) (14.875)
19256120 BELT KIT, D/SEAT (RETR SI) (W/PRE-TENSR) (INCLS 2, 6, 7, 14) (CASHMERE) (BEZEL W/O LOCATOR BOSS) (FOR 1ST DES SEE 19210196)
19256121 BELT KIT, D/SEAT (RETR SI) (W/PRE-TENSR) (INCLS 2, 6, 7, 14) (TITANIUM) (BEZEL W/O LOCATOR BOSS) (FOR 1ST DES SEE 19210197)
19256138 BELT, P/SEAT (RETR SI) (INCLS 2, 6, 7, 14) (CASHMERE) (BEZEL W/O LOCATOR BOSS) (FOR 1ST DES SEE 19210204)
19256139 BELT, P/SEAT (RETR SI) (INCLS 2, 6, 7, 14) (TITANIUM) (BEZEL W/O LOCATOR BOSS) (FOR 1ST DES SEE 19210203)
19256126 BELT KIT, D/SEAT (RETR SI) (W/PRE-TENSR) (INCLS 2, 6, 7, 14) (EBONY)
19256144 BELT KIT, P/SEAT (RETR SI) (W/PRE-TENSR) (INCLS 2, 6, 7, 14) (EBONY)
teamcadillac.ru
19256127 BELT KIT, D/SEAT (RETR SI) (W/PRE-TENSR) (INCLS 2, 6, 7, 14) (CASHMERE)
19256128 BELT KIT, D/SEAT (RETR SI) (W/PRE-TENSR) (INCLS 2, 6, 7, 14) (TITANIUM)
19256146 BELT KIT, P/SEAT (RETR SI) (W/PRE-TENSR) (INCLS 2, 6, 7, 14) (TITANIUM)
19256130 BELT KIT, D/SEAT (RETR SI) (W/PRE-TENSR) (INCLS 2, 6, 7, 14) (COCOA)
19256148 BELT KIT, P/SEAT (RETR SI) (W/PRE-TENSR) (INCLS 2, 6, 7, 14) (COCOA)
19256145 BELT KIT, P/SEAT (RETR SI) (W/PRE-TENSR) (INCLS 2, 6, 7, 14) (CASHMERE)
19210196 BELT KIT, D/SEAT (RETR SI) (W/PRE-TENSR) (INCLS 2, 6, 7, 14) (CASHMERE) (BEZEL W/LOCATOR BOSS) (FOR 2ND DES SEE 19256120)
19210197 BELT KIT, D/SEAT (RETR SI) (W/PRE-TENSR) (INCLS 2, 6, 7, 14) (TITANIUM) (BEZEL W/LOCATOR BOSS) (FOR 2ND DES SEE 19256121)
19210202 BELT, P/SEAT (RETR SI) (INCLS 2, 6, 7, 14) (CASHMERE) (BEZEL W/LOCATOR BOSS) (FOR 2ND DES SEE 19256138)
19210203 BELT, P/SEAT (RETR SI) (INCLS 2, 6, 7, 14) (TITANIUM) (BEZEL W/LOCATOR BOSS) (FOR 2ND DES SEE 19256139)
20899406 RETRACTOR, F/SEAT BELT (RETR SI) (EBONY)
20899407 RETRACTOR, F/SEAT BELT (RETR SI) (CASHMERE)
20899448 RETRACTOR, F/SEAT BELT (RETR SI) (CASHMERE)
20899447 BELT, P/SEAT (RETR SI) (W/ TENSR) (INCLS 2, 6, 7, 14) (EBONY)
22856522 RETRACTOR, F/SEAT BELT (RETR SI) (EBONY) (W/PRETENSIONER)
22856557 RETRACTOR, F/SEAT BELT (RETR SI) (COCOA) (W/PRETENSIONER)
22856524 RETRACTOR, F/SEAT BELT (RETR SI) (COCOA) (W/PRETENSIONER)
15035434 NUT, D/SEAT BELT (RETR SI) (M10X1.5X10.8) (FLANGE NUT) (16.679)
11517996 NUT, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (D/SEAT BELT (BKL SI)) (ACDelco #11517996)
12473319 BOLT, F/CTR SEAT BELT BKL (M12X1.75X37) (HEX) (OUTER) (16.682)
19207765 STOP KIT, BELT LAT (RETR SI) (PART OF 8) (COCOA) (14.875)
19121445 STOP KIT, BELT LAT (RETR SI) (PART OF 8) (CASHMERE) (14.875)
19121443 STOP KIT, BELT LAT (RETR SI) (PART OF 8) (TITANIUM) (14.875)
19121446 STOP KIT, BELT LAT (RETR SI) (PART OF 8) (EBONY) (14.875)
(TK16-928) 2010-2013 CK107(06) ЛИСТОВОЙ МЕТАЛЛ/BODY SIDE FRONT
15934445 FRAME, S/D OPG (INCLS 16, 17, 29, 31)
15934444 FRAME, S/D OPG (INCLS 16, 17, 29, 31)
11609733 BOLT, HEX W/CON WA, M8X1.25X30, 20 THD, 24 OD, 10.9, GMW4205, MAT POINT (RR S/D HGE (DR SI))
15288880 EXTENSION, INTER FLR PNL
15288881 EXTENSION, INTER FLR PNL
20840663 PANEL, RR S/D OTR (PART OF 8)
20840664 PANEL, RR S/D OTR (PART OF 8)
20758530 DOOR, RR SI (INCLS 7)
20969014 DOOR, RR SI (INCLS 7)
20969645 HINGE, FRT S/D LWR (BODY & DR SI) (W/CHECK LINK)
20969646 HINGE, FRT S/D LWR (BODY & DR SI) (W/CHECK LINK)
11609733 BOLT, HEX W/CON WA, M8X1.25X30, 20 THD, 24 OD, 10.9, GMW4205, MAT POINT (FRT S/D HGE (BODY SI))
25854415 HINGE, FRT S/D UPR (BODY & DR SIDE) (REPL T/W 13307322 T/W ADHESIVE 89021297)
25854416 HINGE, FRT S/D UPR (BODY & DR SIDE) (REPL T/W 13307322 T/W ADHESIVE 89021297)
25891764 PANEL, FRT S/D OTR (PART OF 14)
25891763 PANEL, FRT S/D OTR (PART OF 14)
20866212 DOOR, FRT SI (INCLS 13) (W/O HINGES)
20970076 DOOR, FRT SI (INCLS 13) (W/O HINGES)
15837058 INSULATOR, S/D OPG FRM (LWR FRT BODY H-PLR)
15837057 INSULATOR, S/D OPG FRM (LWR FRT BODY H-PLR)
teamcadillac.ru
25815106 EXTENSION, FLR PNL (FRONT)
25815107 EXTENSION, FLR PNL (FRONT)
25858298 SEAL, CTR PLR LWR
25858299 SEAL, CTR PLR LWR
10393085 REINFORCEMENT, FRT S/D OPG FRM
10393086 REINFORCEMENT, FRT S/D OPG FRM
10393087 RAIL, RF SI (INCLS 23)
10393088 RAIL, RF SI (INCLS 23)
20899350 PANEL, CTR PLR INR UPR (INCLS 25)
22802201 PANEL, CTR PLR INR UPR (INCLS 25)
15854158 PANEL, BODY SI INR UPR
15858829 PANEL, BODY SI INR UPR
25893145 PLATE, R/SEAT SHLDR BELT ANC
25893144 PLATE, R/SEAT SHLDR BELT ANC
20957778 PANEL, CTR PLR INR LWR (INCLS 30)
20957779 PANEL, CTR PLR INR LWR (INCLS 30)
15232690 PLUG, BODY SI FRM ACC HOLE (SQUARE)
(TK16-930) 2010-2013 CK1,2,3(06-36-43) ОТДЕЛКА ВНУТРЕННЯЯ-BODY SIDE FRONT
20962796 MOLDING, W/S SI GARN (INCLS 2-7) (CASHMERE) (W/SPEAKER)
20986759 MOLDING, W/S SI GARN (INCLS 2-7) (GRAY)
20986760 MOLDING, W/S SI GARN (INCLS 2-7) (CASHMERE)
20962795 MOLDING, W/S SI GARN (INCLS 2-7) (GRAY) (W/SPEAKER)
20986758 MOLDING, W/S SI GARN (INCLS 2-7) (LINEN)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 1)
11609651 CLIP, W/S SI G/MLDG (PART OF 1) (METAL PUSH-IN NUT, M4.2X1.41, 21.8X15X20.5) (14.731)
11609465 BOLT, HWH, M4.2X1.41X18, 12.5 OD, 6010M, PS (PART OF 1) (8.977)
25827808 PLUG, W/S SI G/MLDG BOLT HOLE FIN (PART OF 1) (LINEN/COCOA) (LH)
15220492 PLUG, W/S SI G/MLDG BOLT HOLE FIN (PART OF 1) (GRAY)
15214074 PLUG, W/S SI G/MLDG BOLT HOLE FIN (PART OF 1) (GRAY) (RH & LH)
15214075 PLUG, W/S SI G/MLDG BOLT HOLE FIN (PART OF 1) (CASHMERE) (16.575)
15186674 SPEAKER, RDO W/S SI G/MLDG (PART OF 1, 23) (ACDelco #15186674)
25889857 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 1) (LINEN)
25889853 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 1) (GRAY)
25889855 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 1)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 9)
15877455 PANEL, BODY H/PLR TR (INCLS 8) (LINEN)
15877457 PANEL, BODY H/PLR TR (INCLS 8) (LINEN)
15904433 PANEL, BODY H/PLR TR (INCLS 8) (TITANIUM)
15904439 PANEL, BODY H/PLR TR (INCLS 8) (TITANIUM)
15904434 PANEL, BODY H/PLR TR (INCLS 8) (CASHMERE)
15904440 PANEL, BODY H/PLR TR (INCLS 8) (CASHMERE)
15904432 PANEL, BODY H/PLR TR (INCLS 8) (EBONY)
15904438 PANEL, BODY H/PLR TR (INCLS 8) (EBONY)
25902619 PLATE, FRT S/D SILL TR (INCLS 11) (CASHMERE)
25902620 PLATE, FRT S/D SILL TR (INCLS 11) (CASHMERE)
25962379 PLATE, FRT S/D SILL TR (INCLS 11) (EBONY)
25962380 PLATE, FRT S/D SILL TR (INCLS 11) (CASHMERE)
25962382 PLATE, FRT S/D SILL TR (INCLS 11) (EBONY)
25962383 PLATE, FRT S/D SILL TR (INCLS 11) (CASHMERE)
20765248 PLATE, FRT S/D SILL TR (INCLS 11) (LINEN)
20765249 PLATE, FRT S/D SILL TR (INCLS 11) (LINEN)
15877375 PLATE, FRT S/D SILL TR (INCLS 11) (LINEN)
15877377 PLATE, FRT S/D SILL TR (INCLS 11) (LINEN)
15848375 PLATE, FRT S/D SILL TR (INCLS 11) (EBONY) (W/CADILLAC INSERT)
15848379 PLATE, FRT S/D SILL TR (INCLS 11) (EBONY) (W/CADILLAC INSERT)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (PART OF 10)
20902384 MOLDING, CTR PLR LWR GARN (INCLS 13) (TITANIUM)
20902386 MOLDING, CTR PLR LWR GARN (INCLS 13) (LINEN)
20902389 MOLDING, CTR PLR LWR GARN (INCLS 13) (TITANIUM)
20902391 MOLDING, CTR PLR LWR GARN (INCLS 13) (LINEN)
20986854 MOLDING, CTR PLR LWR GARN (INCLS 13) (EBONY)
20986849 MOLDING, CTR PLR LWR GARN (INCLS 13) (EBONY)
20986847 MOLDING, CTR PLR LWR GARN (INCLS 13) (CASHMERE)
20986852 MOLDING, CTR PLR LWR GARN (INCLS 13) (CASHMERE)
11561654 RETAINER, CTR PLR UPR G/MLDG (PART OF 12, 15) (PLAIN) (BIRD'S BEAK SINGLE) (FITS 8.5 DIA HOLE) (12.800)
11609651 RETAINER, CTR PLR UPR G/MLDG (PART OF 12, 15) (METAL PUSH-IN NUT, M4.2X1.41, 21.8X15X20.5) (14.731)
11561654 RETAINER, CTR PLR G/MLDG (PART OF 12, 15) (PLAIN) (BIRD'S BEAK SINGLE) (FITS 8.5 DIA HOLE) (12.800)
teamcadillac.ru
15214078 COVER, D/SEAT SHLDR BELT GDE ADJR CLOSEOUT (PART OF 15) (GRAY)
25827825 COVER, P/SEAT SHLDR BELT GDE ADJR CLOSEOUT (PART OF 15) (LINEN)
15877439 MOLDING, CTR PLR UPR GARN (INCLS 13, 14, 16-19) (LINEN)
15877441 MOLDING, CTR PLR UPR GARN (INCLS 13, 14, 16-19) (LINEN)
20986782 MOLDING, CTR PLR UPR GARN (INCLS 13, 14, 16-19) (GRAY)
20986783 MOLDING, CTR PLR UPR GARN (INCLS 13, 14, 16-19) (CASHMERE)
20986787 MOLDING, CTR PLR UPR GARN (INCLS 13, 14, 16-19) (CASHMERE)
20986786 MOLDING, CTR PLR UPR GARN (INCLS 13, 14, 16-19) (GRAY)
15278044 PLUG, CTR PLR HOLE (PART OF 15) (GRANITE)
25827824 PLUG, CTR PLR HOLE (PART OF 15) (LINEN)
15278045 PLUG, CTR PLR HOLE (PART OF 15) (CASHMERE)
15278047 PLUG, CTR PLR HOLE (PART OF 15) (GRAY)
11609465 BOLT, HWH, M4.2X1.41X18, 12.5 OD, 6010M, PS (PART OF 15) (8.977)
11561654 RETAINER, CTR PLR UPR G/MLDG (PART OF 15) (PLAIN) (BIRD'S BEAK SINGLE) (FITS 8.5 DIA HOLE) (12.800)
11609651 RETAINER, CTR PLR UPR G/MLDG (PART OF 15) (METAL PUSH-IN NUT, M4.2X1.41, 21.8X15X20.5) (14.731)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 15)
11570136 BOLT, HEX HD, W/CON SPR WA, M6X1X23, 14 THD, 17 O.D., 8.8, GMW3359 (ASST HDL)
15936642 HANDLE, ASST (LINEN)
20776887 HANDLE, ASST (LINEN)
20986861 HANDLE, ASST (GRAY)
20986857 HANDLE, ASST (GRAY)
20986858 HANDLE, ASST (CASHMERE)
20986862 HANDLE, ASST (CASHMERE)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 23)
20986755 MOLDING, W/S SI GARN (INCLS 6, 22, 24) (GRAY)
20962773 MOLDING, W/S SI GARN (INCLS 6, 22, 24) (CASHMERE)
20986754 MOLDING, W/S SI GARN (INCLS 6, 22, 24) (LINEN)
20962772 MOLDING, W/S SI GARN (INCLS 6, 22, 24) (GRAY) (W/SPEAKER)
20986756 MOLDING, W/S SI GARN (INCLS 6, 22, 24) (CASHMERE)
25889863 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 23) (LINEN)
25889859 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 23) (GRAY)
25889861 GRILLE, RDO W/S SI G/MLDG SPKR (PART OF 23) (CASHMERE)
15936574 COVER, W/S PLR ASST HDL (PART OF 27) (LINEN) (UPPER)
15936575 COVER, W/S PLR ASST HDL (PART OF 27) (LINEN) (LOWER)
15255444 COVER, W/S PLR ASST HDL (PART OF 27) (CASHMERE) (LOWER)
15255445 COVER, W/S PLR ASST HDL (PART OF 27) (CASHMERE) (UPPER)
15220455 COVER, W/S PLR ASST HDL (PART OF 27) (GRAY) (UPPER)
15220459 COVER, W/S PLR ASST HDL (PART OF 27) (GRAY) (LOWER)
11609939 BOLT, HEX W/FLAT WA, M6X1X30, 21 THD, 17 OD, TAPPING (W/S PLR ASST HDL)
15936573 HANDLE, W/S PLR ASST (INCLS 25) (LINEN)
20986868 HANDLE, W/S PLR ASST (INCLS 25) (CASHMERE)
20986867 HANDLE, W/S PLR ASST (INCLS 25) (GRAY)
(TK16-934) 2010-2013 CK1(06-36) ОТДЕЛКА ДВЕРИ/SIDE FRONT-DRIVER (CADILLAC Z75)
25889237 DEFLECTOR, FRT S/D WAT (PART OF 23)
15844616 KNOB, FRT S/D LKG ROD (EBONY)
15844620 KNOB, FRT S/D LKG ROD (COCOA)
20785356 KNOB, FRT S/D LKG ROD (CASHMERE)
10410811 CLIP, FRT S/D C/LP (PART OF 9) (10.777)
20835555 SWITCH, FRT S/D WDO CONT (PART OF 9) (ACDelco #D1412H)
20877684 PLATE, FRT S/D ACSRY SW MT (INCLS 6-8) (WALNUT)
22769988 PLATE, FRT S/D ACSRY SW MT (INCLS 6-8) (BLACK)
20877686 PLATE, FRT S/D ACSRY SW MT (INCLS 6-8) (COCOA)
20980438 PLATE, FRT S/D ACSRY SW MT (INCLS 6-8) (MOCHA)
25857283 PANEL, FRT S/D UPR FRT TR (INCLS 11) (COCOA)
25906770 PANEL, FRT S/D UPR FRT TR (INCLS 11) (CASHMERE)
25857282 PANEL, FRT S/D UPR FRT TR (INCLS 11) (EBONY)
25870922 RETAINER, FRT S/D UPR FRT T/PNL (PART OF 10)
13500192 SEAL, FRT S/D (PART OF 23) (LOC PIN SEAL) (INCLS RIGHT & LEFT)
15905947 BOLT, FRT S/D T/PNL
25822439 SWITCH, D/SEAT ADJR MEMORY
15920707 HANDLE, FRT S/D I/S (PART OF 23) (EBONY) (W/CHROME HDL) (W/ HOLE FOR MEMORY SEAT SWITCH)
22855631 HANDLE, FRT S/D I/S (PART OF 23) (CASHMERE)
22855632 HANDLE, FRT S/D I/S (PART OF 23)
25906776 COVER, FRT S/D I/S HDL BZL FIN (CASHMERE)
25897910 COVER, FRT S/D I/S HDL BZL FIN (COCOA)
25897906 COVER, FRT S/D I/S HDL BZL FIN (EBONY)
11570136 BOLT, HEX HD, W/CON SPR WA, M6X1X23, 14 THD, 17 O.D., 8.8, GMW3359 (FRT S/D T/PNL)
20934187 COVER, FRT S/D T/PNL (EBONY)
20934190 COVER, FRT S/D T/PNL (LINEN)
22874310 COVER, FRT S/D T/PNL (CASHMERE)
15876516 LAMP, CTSY (INCLS 20, 22, 25) (FRT S/D)
09425542 BULB, LAMP #168 (PART OF 21) (ACDelco #L168)
22818536 PANEL, FRT S/D TR (INCLS 1, 2, 4, 5, 12, 15, 19, 24, 26-30, 33, 37) (EBONY)
22818547 PANEL, FRT S/D TR (INCLS 1, 2, 4, 5, 12, 15, 19, 24, 26-30, 33, 37) (LINEN)
teamcadillac.ru
22818537 PANEL, FRT S/D TR (INCLS 1, 2, 4, 5, 12, 15, 19, 24, 26-30, 33, 37) (CASHMERE)
11519031 RETAINER, PUSH IN, 19.5X26.1X1.8, ACETAL, NATURAL, FOAM SEALER (PART OF 23)
11569994 BOLT, FRT S/D I/S HDL (PART OF 23) (M4.2X1.41X16) (16.115)
11519032 RETAINER, PUSH IN, 19.5X28.4X1.8, FITS HOLE 9.1, ACETAL, BLK (PART OF 23)
20928037 ABSORBER, FRT S/D OTR PNL ENGY (INCLS 32)
01605396 RETAINER, PUSH-IN, FITS .250 HOLE, .92 LG.700-OD NYLON BLACK (PART OF 31)
15952332 RETAINER, FRT S/D WAT DFL (PART OF 23) (15MM) (16.165)
11570280 NUT, FRT S/D TR PNL
11609385 NUT, U-TYPE, M6X1, 29.5 LEN, 12.5 WID, 19.5 CEN-END, 1050, GMW3359 (FRT S/D I/S HDL)
(TK16-942) 2010-2013 CK1(06-36) ОТДЕЛКА ДВЕРИ/SIDE FRONT-PASSENGER (CADILLAC Z75)
25889238 DEFLECTOR, FRT S/D WAT (PART OF 14)
11588650 CLIP, 12X14X16.6, GM4345M (PART OF 14)
11570281 NUT, FRT S/D TR PNL
15952332 RETAINER, FRT S/D WAT DFL (PART OF 14) (15MM) (16.165)
01605396 RETAINER, PUSH-IN, FITS .250 HOLE, .92 LG.700-OD NYLON BLACK (PART OF 8)
20928038 ABSORBER, FRT S/D OTR PNL ENGY (INCLS 7)
11569994 BOLT, FRT S/D I/S HDL (PART OF 14) (M4.2X1.41X16) (16.115)
11519031 RETAINER, PUSH IN, 19.5X26.1X1.8, ACETAL, NATURAL, FOAM SEALER (PART OF 14)
20954923 PANEL, FRT S/D TR (INCLS 1, 2, 6, 9-11, 13, 17, 21, 22, 29-34) (CASHMERE)
22818533 PANEL, FRT S/D TR (INCLS 1, 2, 6, 9-11, 13, 17, 21, 22, 29-34) (EBONY)
teamcadillac.ru
22818545 PANEL, FRT S/D TR (INCLS 1, 2, 6, 9-11, 13, 17, 21, 22, 29-34) (LINEN)
09425542 BULB, LAMP #168 (PART OF 16) (ACDelco #L168)
15876517 LAMP, CTSY (INCLS 12, 15) (FRT S/D)
15939208 GRILLE, RDO FRT SPKR (PART OF 14) (EBONY) (W/O CHROME RING) (9.665)
22795287 GRILLE, RDO FRT SPKR (PART OF 14) (EBONY)
22795288 GRILLE, RDO FRT SPKR (PART OF 14) (CASHMERE)
22795289 GRILLE, RDO FRT SPKR (PART OF 14) (LINEN)
25906777 COVER, FRT S/D I/S HDL BZL FIN (CASHMERE)
25897912 COVER, FRT S/D I/S HDL BZL FIN (EBONY)
25897916 COVER, FRT S/D I/S HDL BZL FIN (COCOA)
15920704 HANDLE, FRT S/D I/S (PART OF 14) (EBONY) (W/CHROME HDL)
25906817 HANDLE, FRT S/D I/S (PART OF 14) (CASHMERE)
22855634 HANDLE, FRT S/D I/S (PART OF 14) (CHROME HANDLE BEZEL)
15905945 FILLER, FRT S/D T/PNL (PART OF 14)
25857287 PANEL, FRT S/D UPR FRT TR (INCLS 24) (COCOA)
25906771 PANEL, FRT S/D UPR FRT TR (INCLS 24) (CASHMERE)
25857286 PANEL, FRT S/D UPR FRT TR (INCLS 24) (EBONY)
25870922 RETAINER, FRT S/D UPR FRT T/PNL (PART OF 25)
11562492 BOLT, FRT S/D A/RST SW MT PLT (*KIT1)
20835556 SWITCH, DR LK & SI WDO (*KIT1)
22769989 PLATE, FRT S/D ACSRY SW MT (BLACK) (*KIT1)
20922544 PLATE, FRT S/D ACSRY SW MT (MOCHA) (*KIT1)
20922543 PLATE, FRT S/D ACSRY SW MT (WALNUT) (*KIT1)
20922545 PLATE, FRT S/D ACSRY SW MT (COCOA) (*KIT1)
22968531 PLATE, FRT S/D A/RST SW MT (CRIMSON WALNUT) (*KIT1)
22968532 PLATE, FRT S/D A/RST SW MT (MOCHA WALNUT) (*KIT1)
22968533 PLATE, FRT S/D A/RST SW MT (NEW PLATINUM COCOA) (*KIT1)
10410811 CLIP, FRT S/D C/LP (*KIT1) (10.777)
11519032 RETAINER, PUSH IN, 19.5X28.4X1.8, FITS HOLE 9.1, ACETAL, BLK (PART OF 14)
15844617 KNOB, FRT S/D LKG ROD (CASHMERE)
22769989 PLATE, FRT S/D ACSRY SW MT (INCLS 25-28) (BLACK)
20922544 PLATE, FRT S/D ACSRY SW MT (INCLS 25-28) (MOCHA)
20922543 PLATE, FRT S/D ACSRY SW MT (INCLS 25-28) (WALNUT)
20922545 PLATE, FRT S/D ACSRY SW MT (INCLS 25-28) (COCOA)
(TK16-945) 2009-2013 CK107(06) ОТДЕЛКА СИДЕНЬЯ/ЗАДНЕЕ СИДЕНЬЕ #2 STRIKERS(AS3)
11515775 BOLT, HFH, M12X1.75X30, 10.9, 7114M (3RD ROW SEAT RSR LAT STKR)
15013755 STRIKER, 3RD ROW SEAT LAT CTR (LOWER)
15038813 STRIKER, 3RD ROW SEAT LAT CTR (OUTER) (INCLS UPPER & LOWER)
teamcadillac.ru
15038814 STRIKER, 3RD ROW SEAT LAT CTR (CENTER)
(TK16-949) 2010 CK1(06) СИСТЕМА СТЕКЛООЧИСТИТЕЛЯ ВЕТРОВОГО СТЕКЛА (POLICE PACKAGE PPV)(2ND DES)
teamcadillac.ru
25820729 PANEL, AIR INL GRL (INCLS 6) (BLACK)
25820730 PANEL, AIR INL GRL (INCLS 6) (BLACK)
25872303 PANEL, AIR INL GRL (CTR) (INCLS 8, 24, 27) (BLACK)
20908176 HOSE, WSWA NOZ (PART OF 7)
15248577 INDICATOR, WSWA SOLV LVL (W/23MM DIAMETER LEVEL INDICATOR) (*KIT2)
15248578 GROMMET, WSWA SOLV CNTNR (*KIT1, KIT2)
15927514 GROMMET, WSWA PUMP (PUMP GROMMET) (*KIT1, KIT3) (ACDelco #15927514)
10150076 CLIP, WSWA NOZ HOSE (CLIP TO RET THE COWL HOSE IN THE FENDER) (18.8 MM DIA) (ROUND CLIP) (3.425)
15200240 WEATHERSTRIP, HOOD RR (PART OF 7)
15048061 RETAINER, AIR INL GRL PNL (PART OF 7) (PUSH IN)
20999340 CONTAINER KIT, WSWA SOLV (INCLS 13, 16, 17) (USE T/W 20999338 WHEN REPLACING 15248577, 15213911 OR 15942522.)
20999338 INDICATOR KIT, WSWA SOLV LVL (INCLS 15, 16) (LEVEL SENSOR KIT W/GROMMET) (KIT HAS 16MM DIAM LVL SENSOR) (ACDelco #20999338) (USE T/W 20999340 WHEN REPLACING 15248577, 15213911 OR 15942522.)
15942524 PUMP KIT, WSWA W/SEAL (INCLS 17-19) (RR PUMP KIT W/GROMMET) (ACDelco #15942524)
15942523 PUMP KIT, WSWA W/SEAL (INCLS 17-19) (FRT PUMP KIT W/GROMMET) (ACDelco #15942523)
(TK16-950) 2010-2013 CK1,2(06) СИСТЕМА СТЕКЛООЧИСТИТЕЛЯ ВЕТРОВОГО СТЕКЛА (EXC POLICE PACKAGE PPV)
25879116 ARM, WSW (W/NOZZLE & HOSE)
25879117 ARM, WSW (W/NOZZLE & HOSE)
15788727 CAP, WSW ARM FIN (10.147)
teamcadillac.ru
25872303 PANEL, AIR INL GRL (CTR) (INCLS 7, 23, 27) (BLACK)
20908176 HOSE, WSWA NOZ (PART OF 6)
11609989 BOLT, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (WSWA SOLV CNTNR)
15200240 WEATHERSTRIP, HOOD RR (PART OF 6)
11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (AIR INL GRL PNL)
12368668 WIPER, W/S (PART OF 26) (REFILL) (USED TO SERVICE 15214346 BLADE ASM)
22793882 BLADE, WSW (INCLS 25) (CONVENTIONAL BLADE)
15048061 RETAINER, AIR INL GRL PNL (PART OF 6) (PUSH IN)
20999340 CONTAINER KIT, WSWA SOLV (INCLS 12, 15, 16) (USE T/W 20999338 WHEN REPLACING 15248577, 15213911 OR 15942522.)
20999338 INDICATOR KIT, WSWA SOLV LVL (INCLS 14, 15) (LEVEL SENSOR KIT W/GROMMET) (KIT HAS 16MM DIAM LVL SENSOR) (ACDelco #20999338) (USE T/W 20999340 WHEN REPLACING 15248577, 15213911 OR 15942522.)
15942524 PUMP KIT, WSWA W/SEAL (INCLS 16-18) (RR PUMP KIT W/GROMMET) (ACDelco #15942524)
15942523 PUMP KIT, WSWA W/SEAL (INCLS 16-18) (FRT PUMP KIT W/GROMMET) (ACDelco #15942523)
(TK16-952) 2009-2013 CK107(06) ОТДЕЛКА ДВЕРИ/SIDE REAR (CADILLAC Z75)
11571164 NUT, RR S/D I/S HDL (16.545)
22778726 DEFLECTOR, RR S/D WAT (PART OF 14)
22778727 DEFLECTOR, RR S/D WAT (PART OF 14)
15844620 KNOB, RR S/D LKG ROD (COCOA)
20785356 KNOB, RR S/D LKG ROD (CASHMERE)
15844616 KNOB, RR S/D LKG ROD (EBONY)
15905947 BOLT, RR S/D T/PNL (PART OF 14)
11589329 CLIP, 12X8.9X15.5, SAE 1050 SPR STL, GMW3044 (RR S/D ACSRY SW MT PLT)
25948861 BEZEL, RR S/D WDO SW (PLATINUM COCOA)
25948862 BEZEL, RR S/D WDO SW (PLATINUM COCOA)
25873126 BEZEL, RR S/D WDO SW (CRIMSON WALNUT)
25873127 BEZEL, RR S/D WDO SW (MOCHA WALNUT)
25873128 BEZEL, RR S/D WDO SW (CRIMSON WALNUT)
25873129 BEZEL, RR S/D WDO SW (MOCHA WALNUT)
22895547 SWITCH, RR S/D WDO
25906817 HANDLE, RR S/D I/S (PART OF 14) (CASHMERE)
25906822 HANDLE, RR S/D I/S (PART OF 14) (CASHMERE)
25815293 HANDLE, RR S/D I/S (PART OF 14) (CHROME HANDLE BEZEL)
15920683 HANDLE, RR S/D I/S (PART OF 14) (EBONY) (W/CHROME HDL)
15920704 HANDLE, RR S/D I/S (PART OF 14) (EBONY) (W/CHROME HDL)
22855634 HANDLE, RR S/D I/S (PART OF 14) (CHROME HANDLE BEZEL)
25906776 COVER, RR S/D I/S HDL BZL FIN (CASHMERE)
25906777 COVER, RR S/D I/S HDL BZL FIN (CASHMERE)
25897910 COVER, RR S/D I/S HDL BZL FIN (COCOA)
25897906 COVER, RR S/D I/S HDL BZL FIN (EBONY)
25897916 COVER, RR S/D I/S HDL BZL FIN (COCOA)
25897912 COVER, RR S/D I/S HDL BZL FIN (EBONY)
11570136 BOLT, HEX HD, W/CON SPR WA, M6X1X23, 14 THD, 17 O.D., 8.8, GMW3359 (RR S/D T/PNL)
15214092 COVER, RR S/D T/PNL (CASHMERE)
teamcadillac.ru
15214095 COVER, RR S/D T/PNL (CASHMERE)
15214091 COVER, RR S/D T/PNL (EBONY)
15214094 COVER, RR S/D T/PNL (EBONY)
25815660 COVER, RR S/D T/PNL (LINEN)
25815661 COVER, RR S/D T/PNL (LINEN)
20809068 PANEL, RR S/D TR (INCLS 2, 3, 5, 6, 10, 15, 16, 19) (LINEN)
20809072 PANEL, RR S/D TR (INCLS 2, 3, 5, 6, 10, 15, 16, 19) (LINEN)
20919794 PANEL, RR S/D TR (INCLS 2, 3, 5, 6, 10, 15, 16, 19) (CASHMERE)
20919796 PANEL, RR S/D TR (INCLS 2, 3, 5, 6, 10, 15, 16, 19) (EBONY)
20919793 PANEL, RR S/D TR (INCLS 2, 3, 5, 6, 10, 15, 16, 19) (EBONY)
20919797 PANEL, RR S/D TR (INCLS 2, 3, 5, 6, 10, 15, 16, 19) (CASHMERE)
11609385 NUT, U-TYPE, M6X1, 29.5 LEN, 12.5 WID, 19.5 CEN-END, 1050, GMW3359 (RR S/D T/PNL)
15952332 RETAINER, RR S/D WAT DFL (PART OF 14) (15MM)
(TK16-961) 2010-2013 CK107(06) СИСТЕМА ПОДУШЕК БЕЗОПАСНОСТИ/ROOF SIDE (SEAT THIRD ROW DELETE ATD)
25897886 AIRBAG, RF S/RL (INCLS 3, 5, 6) (1ST & 2ND ROW)
25897887 AIRBAG, RF S/RL (INCLS 3, 5, 6) (1ST & 2ND ROW)
teamcadillac.ru
11609939 BOLT, R/RL AIRBAG (M6X1X30, 21 THD, 17 OD) (8.977)
11562053 BOLT, R/RL AIRBAG (PART OF 1) (M6X1X23 18THD 19OD)
11609939 BOLT, R/RL AIRBAG (PART OF 1) (M6X1X30, 21 THD, 17 OD) (8.977)
20884470 SENSOR, AIRBAG SI IMP
(TK16-962) 2010-2013 CK107(06) СИСТЕМА ПОДУШЕК БЕЗОПАСНОСТИ/ROOF SIDE (REAR SEAT #2 AS3)
20955122 AIRBAG, RF S/RL (INCLS 2-4, 6) (1ST, 2ND, & 3RD ROW)
20955123 AIRBAG, RF S/RL (INCLS 2-4, 6) (1ST, 2ND, & 3RD ROW)
teamcadillac.ru
(TK16-994) 2007-2013 CK107(06) ЗАГЛУШКИ/КУЗОВ
15908858 PLUG, FLR PNL DRN HOLE (38.1 MM) (12.980)
25820734 PLUG, INTER FLR PNL ACC HOLE RR
teamcadillac.ru
15865167 INSULATOR, BODY SI INR PNL HOLE CVR (ACOUSTICAL FIBER/C-PILLAR)
15917242 INSULATOR, BODY SI INR PNL HOLE CVR
15043000 PLUG, R/CMPT SILL TR PLT HOLE (38.0 X 17.0 X 18.0MM) (OBLONG) (16.600)
15908858 PLUG, BODY SI INR LWR PNL HOLE (38.1 MM) (12.980)
10124752 PLUG, BODY SI INR LWR PNL HOLE (BLACK) (RUBBER) (FITS 30 X 18 MM OVAL HOLE) (12.966)
21110669 PLUG, RKR INR PNL HOLE (35 MM DIA) (FITS HOLE 25MM) (ROUND) (12.179)
20895614 PLUG, RKR INR PNL HOLE (48 X 8 X 35) (12.243)
15742557 PLUG, INTER FLR PNL ACC HOLE FRT (71.0 X 96.0 MM) (WELD ACCESS)
15895064 COVER, PLNM UPR PNL OPG
(TX16-004) 2007-2013 CK1,2,3 РЕМНИ БЕЗОПАСНОСТИ (EXTENSION KIT)
89024296 EXTENSION KIT, F/SEAT BELT (BLACK) (9") (14.875) (REFER TO GMSPO INFORMATION BULLETIN ON SEAT BELT EXTENDERS FOR DETAILED INFORMATION)
teamcadillac.ru
89024297 EXTENSION KIT, R/SEAT BELT (BLACK) (15") (14.875) (REFER TO GMSPO INFORMATION BULLETIN ON SEAT BELT EXTENDERS FOR DETAILED INFORMATION)
89024296 EXTENSION KIT, R/SEAT BELT (BLACK) (9") (14.875) (REFER TO GMSPO INFORMATION BULLETIN ON SEAT BELT EXTENDERS FOR DETAILED INFORMATION)
89024297 EXTENSION KIT, F/SEAT BELT (BLACK) (15") (14.875) (REFER TO GMSPO INFORMATION BULLETIN ON SEAT BELT EXTENDERS FOR DETAILED INFORMATION)
17 - ЗАДНЯЯ ЧАСТЬ КУЗОВА-МОЛДИНГИ И ОТДЕЛКА-ГРУЗОВОЙ ОТСЕК
(TC17-744) 2007-2013 CK107(06) БАГАЖНИК (CADILLAC Z75, V54)
15838222 RAIL, LUGG CARR CR (BLACK)
11518684 NUT, LUGG CARR SUPT (M6X1X16) (HEX CHROME FREE FINISH)
15916756 PLATE, LUGG CARR S/RL BRKT ANC
11609900 SCREW, PAN WASH, M6X1X39, 31 THD, 12.25 OD, 8.8, GMW4700, TORX, MACH, 'P'POI (LUGG CARR SUPT)
25892761 RAIL, LUGG CARR SI (CHROMED SS)
25996376 RAIL, LUGG CARR SI (CHROMED SS)
11570521 RETAINER, LUGG CARR S/RL FIN CVR (PUSH IN) (*KIT2, KIT3)
25832915 COVER KIT, LUGG CARR S/RL ACC HOLE RR (INCLS 2, 8) (INCLS PAINT TO MATCH CVR 25787589)
25832914 COVER KIT, LUGG CARR S/RL ACC HOLE RR (INCLS 2, 8) (INCLS PAINT TO MATCH CVR 25787590)
25832916 COVER KIT, LUGG CARR S/RL ACC HOLE FRT (INCLS 7, 8) (PAINT TO MATCH)
25832917 COVER KIT, LUGG CARR S/RL ACC HOLE FRT (INCLS 7, 8) (PAINT TO MATCH)
(TC17-909) 2007-2013 CK1(06) ФУРНИТУРА ЗАДНЕЙ ОТКИДНОЙ ДВЕРИ PART 1 (CADILLAC Z75)
25970601 APPLIQUE, Q/PNL UPR (PAINT TO MATCH)
11610510 NUT, PUSH-IN, M4.2X1.41, 0.7-2.15 PNL THK, SAE 1050-65, GMW3359 W/BLK SEAL (Q/PNL UPR APLQ)
11609406 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (Q/PNL UPR APLQ)
25916023 WINDOW, L/GATE (INCLS 25, 26)
25916024 WINDOW, L/GATE (INCLS 25, 26)
25949077 WEATHERSTRIP, L/GATE WDO
25867975 GATE, LIFT
15038385 BUMPER, L/GATE WDO
11562471 STUD, L/GATE STRUT BALL (L/GATE SI) (8.015)
15161943 STRUT, L/GATE WDO
15161944 STRUT, L/GATE WDO
15875510 HINGE, L/GATE
11519388 BOLT, HX HD CON WA, M8X1.25X25, 20 THD, 24 OD, 8.8, GMW3359 (SILVER), M-POINT (L/GATE HGE (L/GATE SI))
11609341 SCREW, RD WA HD M6X1X19, 13.55 THD, 16 OD, 10.9, GMW4205, W/ADH GM6175M, MATPT (L/GATE STRUT BRKT (L/GATE SI))
15891962 BRACKET, L/GATE STRUT (L/GATE SI)
11518445 SCREW, FLAT-HD HEX ALLEN, CSINK, M8X1.25X25, 18.05 THD, 14.7 OD, 8.8, GMW3044. (L/GATE LK STKR)
teamcadillac.ru
15134851 STRIKER, L/GATE LK
15827433 STRUT, L/GATE
22743451 STRUT, L/GATE
15892254 BUMPER, L/GATE
25970600 APPLIQUE, Q/PNL UPR (PAINT TO MATCH)
15816854 VALVE, BK BODY OPG FRM PRESS RLF
11561717 STUD, L/GATE STRUT (BODY SI) (M8X1.25X25) (STAINLESS STEEL)
11514519 NUT, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (L/GATE HGE (BODY SI))
22775503 WEATHERSTRIP, L/GATE
11610075 RING, FOR 6MM DIA SHAFT, SS (L/GATE HGE PIN)
22845014 WEATHERSTRIP, L/GATE UPR
22782015 TAPE, L/GATE ADJ BPR PAD
15273470 HANDLE, L/GATE WDO O/S (PART OF 4)
25916031 TERMINAL, R/WDO DEFG WIRE (PART OF 4) (2.480)
(TC17-911) 2007-2013 CK1(06) ФУРНИТУРА ЗАДНЕЙ ОТКИДНОЙ ДВЕРИ PART 2 (CADILLAC Z75)
15270012 SEAL, E/GATE CTR MLDG (PART OF 3)
11561972 BOLT, L/GATE APLQ (PART OF 3) (6 X 1 X 21)
25970660 APPLIQUE, L/GATE UPR (W/O HIGH MT S/LP #25779085, NUT #11609411, & WIRE HARNESS #15857136) (INCLS 1, 2) (PAINT TO MATCH)
25779085 LAMP, HIGH MT STOP (INCLS CZ2 STAMP)
11609411 NUT, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (HIGH MT S/LP)
15857136 WIRE, HIGH MT S/LP
11508277 NUT, HEX W/CON WA M6X1 THD, OD-19 PEOR 9 (L/GATE APLQ)
11569914 NUT, RR LIC PLT (SINGLE NUT) (EXCLS SEAL)
15106857 SWITCH, L/GATE REL (PART OF 11) (ACDelco #D1499F)
25838218 HANDLE, L/GATE O/S (INCLS 10, 12-14) (PAINT TO MATCH)
12335645 GASKET, L/GATE WDO O/S HDL (PART OF 11) (7.800)
25601643 NUT, HEX W/CON WA, M6X1X5.6, 24 OD, 9, ZF (L/GATE O/S HDL) (8.917)
15101589 PLUG, L/GATE INR PNL DRN HOLE (FITS HOLE SIZE 22 MM) (W/SPRING CLIP)
21110669 PLUG, L/GATE WRG HARN HOLE (35 MM DIA) (FITS HOLE 25MM) (ROUND) (12.179)
15259076 PLUG, L/GATE SEN ATCH HOLE (6.35MM) (ROUND) (10.571)
11562290 BOLT, L/GATE APLQ (M6X1X28) (26 OD, 9.8)
25886854 LATCH, L/GATE WDO (INCLS 22) (REFER TO BULLETIN 07-08-66-005A WHEN REPLACING LATCH W/ BRKT)
11589327 BOLT, L/GATE WDO LAT (PART OF 21) (M6X1X18)
11609341 SCREW, RD WA HD M6X1X19, 13.55 THD, 16 OD, 10.9, GMW4205, W/ADH GM6175M, MATPT (L/GATE LK)
13501871 LOCK, L/GATE (PO KIT ASM W/ACTUATOR) (12.242)
13581405 LOCK, L/GATE (12.242)
teamcadillac.ru
(TC17-918) 2007-2013 CK1,2(06) ФУРНИТУРА ЗАДНЕЙ ОТКИДНОЙ ДВЕРИ PART 4 ACTUATOR SYSTEM (POWER LIFTGATE E61)
25882453 MOTOR, L/GATE CLOSE ACTR (INCLS 2) (PART OF 4) (HIGH FREQUENCY) (12.243)
11562045 BOLT, L/GATE CLOSE ACTR MOT (PART OF 1, 4)
25778508 SENSOR, L/GATE SI (ANTI-PINCH) (W/RETAINERS)
22840998 SENSOR, L/GATE SI (ANTI-PINCH) (W/RETAINERS)
20821239 MODULE, L/GATE CLOSE ACTR MOT CONT (INCLS 1, 2, 5-8)
15299399 SWITCH, L/GATE ACTR (INCLS 6) (PART OF 4) (12.243) (ACDelco #15299399)
11562045 BOLT, L/GATE CLOSE ACTR MOT (PART OF 4)
teamcadillac.ru
15810321 BRACKET, L/GATE CLOSE ACTR (PART OF 4)
15836293 ROD, L/GATE ACTR
20821156 MODULE, ACSRY & L/GATE CONT (REQUIRES SOFTWARE PROGRAM AND CALIBRATION) (12.243)
11609410 BOLT, HFH, M8X1.25X25, 10.9, GMW3179 (L/GATE CLOSE ACTR) (0.056)
15173772 BRACKET, L/GATE ACTR ROD
11609341 SCREW, RD WA HD M6X1X19, 13.55 THD, 16 OD, 10.9, GMW4205, W/ADH GM6175M, MATPT (L/GATE ACTR ROD BRKT)
(TC17-958) 2009-2013 K107(06) FLARE/BODYSIDE (CADILLAC Z75, EXPORT PACKAGE VD1)
20758458 EXTENSION, RR W/H PNL (*KIT1)
teamcadillac.ru
20758459 EXTENSION, RR W/H PNL (*KIT1)
24501057 RETAINER, F/FDR EXTN (PUSH-IN) (6.9 HOLE DIA) (19MM LG) (*KIT1) (1.840)
20758461 EXTENSION, F/FDR (*KIT1)
20758462 EXTENSION, F/FDR (*KIT1)
20758463 PARTS, MISC BODY (VENDOR INSTALLED) (INCLS 1-4)
(TC17-959) 2009-2010 CK107(06) ДЕКАЛИ (CADILLAC Z75, HYBRID HP2)
25940046 DECAL, R/WDO NA (GUNMETAL) (HYBRID)
25975557 DECAL, FRT S/D LWR (GUNMETAL) (HYBRID)
25975558 DECAL, FRT S/D LWR (GUNMETAL) (HYBRID)
25975559 DECAL, FRT S/D LWR (SILVER) (HYBRID)
25975560 DECAL, FRT S/D LWR (SILVER) (HYBRID)
25940046 DECAL, W/S NA (GUNMETAL) (HYBRID) (16.475)
(TC17-962) 2009-2011 CK1(06) ФУРНИТУРА ЗАДНЕЙ ОТКИДНОЙ ДВЕРИ PART 3 CENTER APPLIQUE (CADILLAC Z75, REAR VIEW CAMERA UVC)
22777526 APPLIQUE, L/GATE CTR (INCLS 4, 6-11, 13, 14, 16, 17, 19) (CHROME) (INCLS CAMERA)
15798062 SWITCH, L/GATE WDO REL (ACDelco #D1994E)
20823396 EMBLEM, L/GATE (PART OF 2) (WREATH/CREST)
25778786 LAMP, RR LIC PLT
teamcadillac.ru
11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (RR LIC PLT LP LENS)
11562334 RETAINER, L/GATE CTR APLQ (INCLS 16) (PART OF 2)
13500812 BULB, RR LIC PLT LP (TRADE #W5WLL) (ACDelco #13500812)
(TC17-965) 2010-2013 CK107(06) NAMEPLATES (CADILLAC Z75)
20823396 EMBLEM, L/GATE (WREATH/CREST)
20903638 PLATE, L/GATE ENG NA (HYBRID 2-MODE)
15162148 EMBLEM, L/GATE (ESCALADE)
15102283 PLATE, E/GATE VEH NA (CHROME) (PLATINUM)
20900865 PLATE, E/GATE VEH NA (HYBRID - LRG) (8.147)
20903652 EMBLEM, L/GATE (GREEN) (FLEX FUEL E85 ETHANOL) (LARGE CURVED) (12.182)
20903627 PLATE, E/GATE VEH NA (GREEN) (FLEX POWER E85 ETHANOL)
25940049 PLATE, BODY SI NA ("H") (17.507)
teamcadillac.ru
15162148 PLATE, FRT S/D VEH NA (ESCALADE) (17.215)
(TC17-983) 2010-2013 CK1(06) ОТДЕЛКА ДВЕРИ БАГАЖНИКА (CADILLAC Z75)
15936906 MOLDING, L/GATE WDO UPR GARN (INCLS 2, 3) (LINEN)
20986936 MOLDING, L/GATE WDO UPR GARN (INCLS 2, 3) (CASHMERE)
teamcadillac.ru
20986937 MOLDING, L/GATE WDO UPR GARN (INCLS 2, 3) (TITANIUM)
20986938 MOLDING, L/GATE WDO UPR GARN (INCLS 2, 3) (EBONY)
11561654 RETAINER, L/GATE WDO UPR G/MLDG (PART OF 1) (PLAIN) (BIRD'S BEAK SINGLE) (FITS 8.5 DIA HOLE) (12.800)
11609242 NUT, L/GATE TR FIN PNL (M6X1, 18X17X14.3)
11561654 CLIP, L/GATE TR FIN PNL (PART OF 9) (PLAIN) (BIRD'S BEAK SINGLE) (FITS 8.5 DIA HOLE) (12.800)
15952904 HANDLE, L/GATE I/S PULL (PART OF 9) (LINEN)
15952901 HANDLE, L/GATE I/S PULL (PART OF 9) (TITANIUM)
15952900 HANDLE, L/GATE I/S PULL (PART OF 9) (EBONY)
15952902 HANDLE, L/GATE I/S PULL (PART OF 9) (CASHMERE)
11518329 SCREW, TORX PAN HD, W/WA, M6X1X25, 18 THD, 15 OD, 9.8, 6138M, TORX (L/GATE TR FIN PNL)
20986839 PANEL, L/GATE TR FIN (INCLS 4, 6, 7, 10) (TITANIUM) (NO LONGER INCLS PULL STRAP)
20986837 PANEL, L/GATE TR FIN (INCLS 4, 6, 7, 10) (LINEN) (NO LONGER INCLS PULL STRAP)
20986838 PANEL, L/GATE TR FIN (INCLS 4, 6, 7, 10) (CASHMERE) (NO LONGER INCLS PULL STRAP)
20986840 PANEL, L/GATE TR FIN (INCLS 4, 6, 7, 10) (EBONY) (NO LONGER INCLS PULL STRAP)
15211504 SWITCH, L/GATE ACTR (PART OF 9) (PART OF LIFT GATE PNL)
15120856 RETAINER, L/GATE WDO UPR G/MLDG (BLACK) (8.141)
20986931 PLUG, L/GATE TR FIN PNL HOLE (CASHMERE)
20986934 PLUG, L/GATE TR FIN PNL HOLE (LINEN)
20986933 PLUG, L/GATE TR FIN PNL HOLE (EBONY)
20986932 PLUG, L/GATE TR FIN PNL HOLE (TITANIUM)
(TC17-985) 2009-2013 CK1(06) МОЛДИНГИ (CADILLAC Z75)
20772075 MOLDING, FRT S/D WDO RVL (INCLS 2, 3) (W/RUN CHANNEL)
20772074 MOLDING, FRT S/D WDO RVL (INCLS 2, 3) (W/RUN CHANNEL)
25895275 CLIP, FRT S/D MLDG (PART OF 1, 4)
15286992 CLIP, FRT S/D MLDG (PART OF 1, 4) (12X10.7X7.4, 0.71-1.50 THK PNL, SAE 1050 STL, GMW3200) (10.352)
20772079 MOLDING, RR S/D WDO RVL (INCLS 2, 3)
20772078 MOLDING, RR S/D WDO RVL (INCLS 2, 3)
22743309 MOLDING, RF PNL JT FIN (20MM SHORTER THAN OE PART)
teamcadillac.ru
11609457 SCREW, ROUNDWA, M4.2X1.41X20, 14.1 THD, 11.35 OD, 6010M, GMW4205, TAP, (Q/PNL UPR APLQ)
15876401 MOLDING, RR S/D (CHROME)
15876402 MOLDING, RR S/D (CHROME)
15876405 MOLDING, FRT S/D (CHROME)
15876406 MOLDING, FRT S/D (CHROME)
15860253 INSERT, F/FDR CTR RR UPR MLDG (CHROME)
15860254 INSERT, F/FDR CTR RR UPR MLDG (CHROME)
25963661 PLATE, F/FDR FRT NA (PART OF 13)
25961847 ORNAMENT, F/FDR (INCLS 12) (CHROME)
25961848 ORNAMENT, F/FDR (INCLS 12) (CHROME)
21 - ДОПОЛНИТЕЛЬНОЕ ОБОРУДОВАНИЕ-АКСЕССУАРЫ
(1L21-014) 2007-2011 CK1,2,3 DVD ПЛЕЕР/ПОДГОЛОВНИК
19156228 PLAYER, VIDEO (W/VIDEO DISPLAY) (DVD PLAYER AND DVD DISPLAY) (ELECTRONICS ARE PRE-PROGRAMMED WITH CADILLAC LOGO SPLASH SCREEN) (HEADREST NOT INCL) (ELECTRONICS ONLY) (INSTALL .10) (0.69 KGS) (9.680)
19213544 RESTRAINT PKG, R/SEAT ENTERTAINMENT HD (W/O VIDEO DISPLAY) (CASHMERE) (INSTALL .20) (1.5 KGS) (LEATHER) (9.680) (FOR VEH BUILT W/H/RST W/ADDITIONAL SEWN SEAM APPROX 50MM FWD OF SEAM B/W POSTS) (FOR 2ND DES SEE 19244279)
22840199 PLAYER, VIDEO (W/VIDEO DISPLAY) (DVD PLAYER AND DVD DISPLAY, ELECTRONICS ARE PRE-PROGRAMMED WITH CADILLAC LOGO SPLASH SCREEN, HEADREST IS NOT INCLUDED, ELECTRONICS ONLY) (9.680)
(AC21-057) 2007-2013 CK1,2,3 CARRIER PKG/SKI (HITCH MOUNTED)(THULE)
19257870 CARRIER, SKI (HITCH MT) (FOR VEH'S W/REC HITCH) (7.068)
(AC21-064) 2007-2013 CK1,2,3 DVD PLAYER-SERVICE PARTS
teamcadillac.ru
19156570 HEADREST, DRVR SI (W/O VIDEO DISPLAY) (EBONY) (LEATHER W/VINYL SIDES) (9.680) (FOR VEH BUILT W/H/RST W/ADDITIONAL SEWN SEAM APPROX 50MM FWD OF SEAM B/W POSTS) (FOR 2ND DES SEE 19244281)
19213547 HEADREST, PASS SI (W/O VIDEO DISPLAY) (EBONY) (INSTALL .20) (1.5 KGS) (LEATHER) (9.680) (FOR VEH BUILT W/H/RST W/ADDITIONAL SEWN SEAM APPROX 50MM FWD OF SEAMB/W POSTS) (FOR 2ND DES SEE 19244282)
19244304 MODULE, AUDIO/VIDEO INTERFACE (0.13 KGS) (DUAL DVD CONTROL METAL BOX) (9.680)
19245159 RETAINER, ACSRY WRG HARN (9.680)
19159658 CABLE KIT, AUDIO & VIDEO MDL (0.32 KGS) (INCLS CABLES 3A & 3B USED TO CONN HD RESTS TO CTRL BOX) (0.029)
19132011 CONTROL, VIDEO REM (INCLS 9) (0.09KGS) (W/ROW OF FUNC BUTN LBL AUTO MEM, SEARCH/SKIP, ERASE/ADD, R-S) (9.680) (REMOTE WILL ONLY OPERATE WITH GMSPO DVD HEADREST SYSTEMS)
22797471 CONTROL, VIDEO REM (INCLS 9) (W/O ROW OF FUNC BUTN LBL AUTO MEM, SEARCH/SKIP, ERASE/ADD, R-S) (9.680) (ACDelco #22797471) (REMOTE WILL ONLY OPERATE WITH GMSPO DVD HEADREST SYSTEMS)
19165593 HARNESS, AUDIO PLYR WRG (INCLS DVD JUMPER HARN & POWER CORD #9) (9.680)
(AC21-548) 2007-2013 CK1,2,3 ROADSIDE ASSISTANCE PKG/ROLL-UP
88960625 ROADSIDE PKG, ACSRY MISC (INCLS BUNGEE CORDS, FLASHLIGHT, FUSE KIT, GLOVES, PLIERS, TAPE, RAG, PONCHO, SCREWDRIVER W/BITS, TIRE GAUGE, & BAG) (1.26KGS) (ROLL-UP) (8.808)
(AC21-560) 2007-2013 CK1,2 LOCK PKG/WHEEL
17801711 NUT PKG, SPL SECURITY WHL LK (CHROME) (INSTALL .10) (0.29 KGS) (INCLS 20 NUTS, 4 LOCKING NUTS, 1 KEY) (M14X1.5) (5.813) (PREFERRED USE ON WHLS W/EXPOSED LUGS & W/O NEED TO RETAIN A WHL CAP/COVER) (FOR USE W/20" & 22" SPO ACSRY WHL)
17801712 NUT PKG, SPL SECURITY WHL LK (CHROME) (INSTALL .10) (SINGLE 0.29KGS) (INCLS 4 PACK OF 17801711) (M14X1.5) (5.813) (FOR USE WITH 20" SPO ACCESSORY WHEELS) (PREFERRED USE ON WHLS W/EXPOSED LUGS & W/O NEED TO RETAIN A WHL CAP/COVER)
12498075 LOCK PKG, SPL SECURITY WHL (NON-DECORATIVE) (INSTALL .10) (SINGLE 0.6KGS) (W/HEX FREE COATING) (4 NUTS & KEY) (M14X1.5 W/EXT THD) (5.875)
teamcadillac.ru
12498082 LOCK PKG, SPL SECURITY WHL (INSTALL .10) (SINGLE 0.6KGS) (W/HEX FREE COATING) (10 PC QTY OF 12498075) (M14X1.5 W/EXT THD) (5.875)
17802466 LOCK PKG, SPL SECURITY WHL (DECORATIVE) (CHROME) (INSTALL .10) (SINGLE 0.5 KGS) (W/HEX FREE COATING) (INCLS 4 LOCKING NUTS, 1 KEY) (M14X1.5 THD) (5.875) (PREFERED USE ON WHLS W/EXPOSED LUGS & W/O NEED TO RETAIN A WHL CAP/COVER)
12498076 LOCK PKG, SPL SECURITY WHL (NON-DECORATIVE) (INSTALL .10) (SINGLE 0.5KGS) (W/HEX FREE COATING) (4 NUTS & KEY) (M14X1.5 W/O EXT THD) (5.875)
(AC21-583) 2007-2013 CK1,2,3 ADAPTER PKG/TRAILER HARNESS (7-PIN TO 4-PIN ADAP)
12496599 ADAPTER PKG, TRLR WRG HARN RCPT (0.1 KGS) (CONVERTS HVY DUTY 7 PIN RND TO LGT DUTY 4 PIN FLAT) (7.068)
(AC21-589) 2007-2013 CK1,2,3 ADAPTER PKG/TRAILER HARNESS (7-PIN TO PWR ADAP)
12497781 ADAPTER PKG, TRLR WRG HARN RCPT (0.1 KGS) (7 TO 12V AUX ADAPTER) (7.068)
(AC21-667) 2007-2011 CK1,2,3 LOCK PKG/HITCH
12499511 PIN PKG, TRLR HITCH DRAW BAR (INSTALL .10) (0.4KGS) (REQ 2" HITCH PKG) (7.068)
88966128 KEY, TRLR HITCH THEFT DTRNT LK (#08) (INCLS 2 KEYS) (17.070) (**VPI 1-877-846-8243)
88966129 KEY, TRLR HITCH THEFT DTRNT LK (#09) (INCLS 2 KEYS) (17.070)
88963077 KEY, TRLR HITCH THEFT DTRNT LK (#01) (INCLS 2 KEYS) (12.815)
88966122 KEY, TRLR HITCH THEFT DTRNT LK (#02) (INCLS 2 KEYS) (17.070)
88966123 KEY, TRLR HITCH THEFT DTRNT LK (#03) (INCLS 2 KEYS) (17.070)
88966124 KEY, TRLR HITCH THEFT DTRNT LK (#04) (INCLS 2 KEYS) (17.070)
88966125 KEY, TRLR HITCH THEFT DTRNT LK (#05) (INCLS 2 KEYS) (17.070)
88966126 KEY, TRLR HITCH THEFT DTRNT LK (#06) (INCLS 2 KEYS) (17.070)
teamcadillac.ru
88966127 KEY, TRLR HITCH THEFT DTRNT LK (#07) (INCLS 2 KEYS) (17.070)
88966130 KEY, TRLR HITCH THEFT DTRNT LK (#00) (INCLS 2 KEYS) (17.070)
17800049 NUT PKG, TRLR HITCH DRAW BAR PIN (7.068) (SERV CMP OF PIN PKG 12499511)
(AC21-671) 2007-2013 CK1,2,3 FIRST AID PKG
12498312 MEDICAL PKG, 1ST AID (360 PC QTY OF 88960626) (8.808)
teamcadillac.ru
88960626 MEDICAL PKG, 1ST AID (BLACK) (0.19KGS) (WHITE GM BLOCK LOGO) (VINYL) (8.808)
(AC21-672) 2007-2013 CK1,2,3 CARRIER PKG/BICYCLE (WALL MOUNT)
teamcadillac.ru
12499175 HANGER PKG, BICYCLE CARR (WALL MOUNT) (6.35KGS) (INCLS BRKT, PLT & HDW) (REQ'S HITCH MTD BIKE CARR) (17.070)
(AC21-693) 2007-2013 CK1,2,3 MAT PKG/REAR FLOOR CARPET(MOLDED EDGE)
teamcadillac.ru
17800413 MAT PKG, REAR CARPET (MOLDED EDGE) (EBONY) (1.45KGS) (1 PC) (NO LOGO) (16.800)
17800414 MAT PKG, REAR CARPET (MOLDED EDGE) (CASHMERE) (1.45KGS) (1 PC) (NO LOGO) (16.800)
(AC21-736) 2007-2013 CK1,2(06-36) CARRIER PKG/HARD SHELL (LONG)
teamcadillac.ru
12499318 CONTAINER PKG, LUGG CARR STOW (CROSSRAILS REQUIRED) (HOLDS 5 PR OF SKIS) (BLACK) (INSTALL .50) (10.43 KGS) (TEXTURED) (LONG) (W/GM-THULE LOGO) (INCLS LK CYL) (89"LX21"WX15"H) (17.070)
12462636 LOCK PKG, LUGG CARR (0.050 KGS) (W/KEYS) (12.815) (SERV CMP OF CONTAINER PKGS 12499318-19)
(AC21-781) 2007-2013 CK1,2(06-36) CARRIER PKG/HARD SHELL (SHORT)
19243882 CONTAINER PKG, LUGG CARR STOW (CROSSRAILS REQUIRED) (BLACK) (INSTALL .50) (11.34 KGS) (TEXTURED) (GM/THULE LOGO) (56"L X 36"W X 15"H) (12.815)
(AC21-803) 2007-2013 CK1,2,3 CARRIER PKG/SKI (HITCH MOUNT)(SOFTRIDE)
88963077 KEY, SKI CARR LK (#01) (INCLS 2 KEYS) (12.815)
(AC21-824) 2007-2013 CK1 ACCESSORY PKG/TIRE
19107491 TIRE, P275/55R20-111S AL2 TL BW (18.6 KGS) (INSTALL .10) (INSTALL .25) (SINGLE 18.4KGS) (GOODYEAR, EAGLE LS2, 275/55R20) (5.880) (ACDelco #LU069165)
19143998 TIRE, P285/45R22-110H AL2 TL BW (18.6 KGS) (INSTALL .10) (INSTALL .25) (SINGLE 19.3KGS) (BRIDGESTONE, DUELER H/L ALENZA, P285/45R22, BW110H) (5.880) (ACDelco #FB053984)
19145377 TIRE, P275/55R20-111S AL2 TL BW (19.5 KGS) (INSTALL .10) (INSTALL .25) (SINGLE 19.5KGS) (BRIDGESTONE, DUELER H/L ALENZA W/UNI-T, P275/55R20, BL, 111S) (5.880) (ACDelco #FB053967)
teamcadillac.ru
19185719 TIRE, 285/45R22-114H XL AL3 BW (INSTALL .10) (SINGLE 17.2KGS) (TIRE, GOODYEAR_FORTERA SL_285/45R22_VSB114H) (5.880) (ACDelco #KY621163)
19190768 TIRE, P285/45R22-110H AT BW (USA&CANADA TIRE PROGRAM) (INSTALL .10) (20.6 KGS) (TIRE, BRIDGESTONE_DUELER A/T RH-S_P285/45R22_BW110H) (5.880) (ACDelco #FB107942)
89049423 TIRE, P265/70R17-113S OOR TL BW (TIRE MFG # 773422430) (17.5 KGS) (INSTALL .10) (GOODYEAR, WRANGLER ST, 265/70R17, BSL) (5.880) (ACDelco #HD422430)
19190769 TIRE, P275/55R20-111T AT BW (USA&CANADA TIRE PROGRAM) (INSTALL .25) (BRIDGESTONE, DUELER A/T RH-S, P275/55R20, BW111T) (5.880) (ACDelco #FB107925)
(AC21-855) 2007-2013 CK1,2,3 CARRIER PKG/BICYCLE (HITCH MOUNTED)
12499171 CARRIER, BICYCLE (HITCH MT) (INSTALL .10) (18.42KGS) (CARRIES 4 BIKES) (17.070) (REQUIRES 2" TRAILER HITCH AND LICENSE PLATE REMOUNT PKG-12495709)
12499718 PLATE, BICYCLE CARR RAIL MTG (12.815) (REQUIRES 2" HITCH PKG) (SERV CMP OF CARRIER PKG 12499171, 72)
12499722 RAIL PKG, BICYCLE CARR (HITCH MT) (17.070) (REQUIRES 2" HITCH PKG) (SERV CMP OF CARRIER PKG 12499171)
12499723 STRAP, BICYCLE CARR (BLACK) (PLASTIC) (QTY 8 PC PKG) (16.800) (REQUIRES 2" HITCH PKG)
12499724 LOCK, BICYCLE (0.91KGS) (INCLS 2 KEYS) (REQ 2" HITCH PKG) (12.815)
19242660 KEY SET, HITCH CARRIER (#010) (INCLS 2 KEYS) (17.070)
19242661 KEY SET, HITCH CARRIER (#011) (INCLS 2 KEYS) (17.070)
19242662 KEY SET, HITCH CARRIER (#012) (INCLS 2 KEYS) (17.070)
19242663 KEY SET, HITCH CARRIER (#013) (INCLS 2 KEYS) (17.070)
19242664 KEY SET, HITCH CARRIER (#014) (INCLS 2 KEYS) (17.070)
19242665 KEY SET, HITCH CARRIER (#015) (INCLS 2 KEYS) (17.070)
19242666 KEY SET, HITCH CARRIER (#016) (INCLS 2 KEYS) (17.070)
19242667 KEY SET, HITCH CARRIER (#017) (INCLS 2 KEYS) (17.070)
19242668 KEY SET, HITCH CARRIER (#018) (INCLS 2 KEYS) (17.070)
19242669 KEY SET, HITCH CARRIER (#019) (INCLS 2 KEYS) (17.070)
19242670 KEY SET, HITCH CARRIER (#020) (INCLS 2 KEYS) (17.070)
19242671 KEY SET, HITCH CARRIER (#021) (INCLS 2 KEYS) (17.070)
19242672 KEY SET, HITCH CARRIER (#022) (INCLS 2 KEYS) (17.070)
19242673 KEY SET, HITCH CARRIER (#023) (INCLS 2 KEYS) (17.070)
19242674 KEY SET, HITCH CARRIER (#024) (INCLS 2 KEYS) (17.070)
19242675 KEY SET, HITCH CARRIER (#025) (INCLS 2 KEYS) (17.070)
19242676 KEY SET, HITCH CARRIER (#026) (INCLS 2 KEYS) (17.070)
19242677 KEY SET, HITCH CARRIER (#027) (INCLS 2 KEYS) (17.070)
19242678 KEY SET, HITCH CARRIER (#028) (INCLS 2 KEYS) (17.070)
19242679 KEY SET, HITCH CARRIER (#029) (INCLS 2 KEYS) (17.070)
19242680 KEY SET, HITCH CARRIER (#030) (INCLS 2 KEYS) (17.070)
19242681 KEY SET, HITCH CARRIER (#031) (INCLS 2 KEYS) (17.070)
19242682 KEY SET, HITCH CARRIER (#032) (INCLS 2 KEYS) (17.070)
19242683 KEY SET, HITCH CARRIER (#033) (INCLS 2 KEYS) (17.070)
19242684 KEY SET, HITCH CARRIER (#034) (INCLS 2 KEYS) (17.070)
19242685 KEY SET, HITCH CARRIER (#035) (INCLS 2 KEYS) (17.070)
19242686 KEY SET, HITCH CARRIER (#036) (INCLS 2 KEYS) (17.070)
19242687 KEY SET, HITCH CARRIER (#037) (INCLS 2 KEYS) (17.070)
19242688 KEY SET, HITCH CARRIER (#038) (INCLS 2 KEYS) (17.070)
19242689 KEY SET, HITCH CARRIER (#039) (INCLS 2 KEYS) (17.070)
19242690 KEY SET, HITCH CARRIER (#040) (INCLS 2 KEYS) (17.070)
19242691 KEY SET, HITCH CARRIER (#041) (INCLS 2 KEYS) (17.070)
19242692 KEY SET, HITCH CARRIER (#042) (INCLS 2 KEYS) (17.070)
19242693 KEY SET, HITCH CARRIER (#043) (INCLS 2 KEYS) (17.070)
19242694 KEY SET, HITCH CARRIER (#044) (INCLS 2 KEYS) (17.070)
19242695 KEY SET, HITCH CARRIER (#045) (INCLS 2 KEYS) (17.070)
19242696 KEY SET, HITCH CARRIER (#046) (INCLS 2 KEYS) (17.070)
19242697 KEY SET, HITCH CARRIER (#047) (INCLS 2 KEYS) (17.070)
19242698 KEY SET, HITCH CARRIER (#048) (INCLS 2 KEYS) (17.070)
19242699 KEY SET, HITCH CARRIER (#049) (INCLS 2 KEYS) (17.070)
19242700 KEY SET, HITCH CARRIER (#050) (INCLS 2 KEYS) (17.070)
19242701 KEY SET, HITCH CARRIER (#051) (INCLS 2 KEYS) (17.070)
19242702 KEY SET, HITCH CARRIER (#052) (INCLS 2 KEYS) (17.070)
19242703 KEY SET, HITCH CARRIER (#053) (INCLS 2 KEYS) (17.070)
teamcadillac.ru
19242704 KEY SET, HITCH CARRIER (#054) (INCLS 2 KEYS) (17.070)
19242705 KEY SET, HITCH CARRIER (#055) (INCLS 2 KEYS) (17.070)
19242706 KEY SET, HITCH CARRIER (#056) (INCLS 2 KEYS) (17.070)
19242707 KEY SET, HITCH CARRIER (#057) (INCLS 2 KEYS) (17.070)
19242708 KEY SET, HITCH CARRIER (#058) (INCLS 2 KEYS) (17.070)
19242709 KEY SET, HITCH CARRIER (#059) (INCLS 2 KEYS) (17.070)
19242710 KEY SET, HITCH CARRIER (#060) (INCLS 2 KEYS) (17.070)
19242711 KEY SET, HITCH CARRIER (#061) (INCLS 2 KEYS) (17.070)
19242712 KEY SET, HITCH CARRIER (#062) (INCLS 2 KEYS) (17.070)
19242713 KEY SET, HITCH CARRIER (#063) (INCLS 2 KEYS) (17.070)
19242714 KEY SET, HITCH CARRIER (#064) (INCLS 2 KEYS) (17.070)
19242715 KEY SET, HITCH CARRIER (#065) (INCLS 2 KEYS) (17.070)
19242716 KEY SET, HITCH CARRIER (#066) (INCLS 2 KEYS) (17.070)
19242717 KEY SET, HITCH CARRIER (#067) (INCLS 2 KEYS) (17.070)
19242718 KEY SET, HITCH CARRIER (#068) (INCLS 2 KEYS) (17.070)
19242719 KEY SET, HITCH CARRIER (#069) (INCLS 2 KEYS) (17.070)
19242720 KEY SET, HITCH CARRIER (#070) (INCLS 2 KEYS) (17.070)
19242721 KEY SET, HITCH CARRIER (#071) (INCLS 2 KEYS) (17.070)
19242722 KEY SET, HITCH CARRIER (#072) (INCLS 2 KEYS) (17.070)
19242723 KEY SET, HITCH CARRIER (#073) (INCLS 2 KEYS) (17.070)
19242724 KEY SET, HITCH CARRIER (#074) (INCLS 2 KEYS) (17.070)
19242725 KEY SET, HITCH CARRIER (#075) (INCLS 2 KEYS) (17.070)
19242726 KEY SET, HITCH CARRIER (#076) (INCLS 2 KEYS) (17.070)
19242727 KEY SET, HITCH CARRIER (#077) (INCLS 2 KEYS) (17.070)
19242728 KEY SET, HITCH CARRIER (#078) (INCLS 2 KEYS) (17.070)
19242729 KEY SET, HITCH CARRIER (#079) (INCLS 2 KEYS) (17.070)
19242730 KEY SET, HITCH CARRIER (#080) (INCLS 2 KEYS) (17.070)
19242731 KEY SET, HITCH CARRIER (#081) (INCLS 2 KEYS) (17.070)
19242732 KEY SET, HITCH CARRIER (#082) (INCLS 2 KEYS) (17.070)
19242733 KEY SET, HITCH CARRIER (#083) (INCLS 2 KEYS) (17.070)
19242734 KEY SET, HITCH CARRIER (#084) (INCLS 2 KEYS) (17.070)
19242735 KEY SET, HITCH CARRIER (#085) (INCLS 2 KEYS) (17.070)
19242736 KEY SET, HITCH CARRIER (#086) (INCLS 2 KEYS) (17.070)
19242737 KEY SET, HITCH CARRIER (#087) (INCLS 2 KEYS) (17.070)
19242738 KEY SET, HITCH CARRIER (#088) (INCLS 2 KEYS) (17.070)
19242739 KEY SET, HITCH CARRIER (#089) (INCLS 2 KEYS) (17.070)
19242740 KEY SET, HITCH CARRIER (#090) (INCLS 2 KEYS) (17.070)
19242741 KEY SET, HITCH CARRIER (#091) (INCLS 2 KEYS) (17.070)
19242742 KEY SET, HITCH CARRIER (#092) (INCLS 2 KEYS) (17.070)
19242743 KEY SET, HITCH CARRIER (#093) (INCLS 2 KEYS) (17.070)
19242744 KEY SET, HITCH CARRIER (#094) (INCLS 2 KEYS) (17.070)
19242745 KEY SET, HITCH CARRIER (#095) (INCLS 2 KEYS) (17.070)
19242746 KEY SET, HITCH CARRIER (#096) (INCLS 2 KEYS) (17.070)
19242747 KEY SET, HITCH CARRIER (#097) (INCLS 2 KEYS) (17.070)
19242748 KEY SET, HITCH CARRIER (#098) (INCLS 2 KEYS) (17.070)
19242749 KEY SET, HITCH CARRIER (#099) (INCLS 2 KEYS) (17.070)
12499719 CARRIER, BICYCLE (HITCH MT CARRIER LOWER SUPPORT) (12.815) (SERV CMP OF CARRIER PKG 12499171)
88963912 STRAP, BICYCLE CARR (BLACK) (WEBBING) (16.800) (SERV CMP OF CARRIER PKGS)
88963077 KEY, BICYCLE CARR THEFT DTRNT LK (#01) (INCLS 2 KEYS) (12.815)
88966122 KEY, BICYCLE CARR THEFT DTRNT LK (#02) (INCLS 2 KEYS) (17.070)
88966123 KEY, BICYCLE CARR THEFT DTRNT LK (#03) (INCLS 2 KEYS) (17.070)
88966124 KEY, BICYCLE CARR THEFT DTRNT LK (#04) (INCLS 2 KEYS) (17.070)
88966125 KEY, BICYCLE CARR THEFT DTRNT LK (#05) (INCLS 2 KEYS) (17.070)
88966126 KEY, BICYCLE CARR THEFT DTRNT LK (#06) (INCLS 2 KEYS) (17.070)
88966127 KEY, BICYCLE CARR THEFT DTRNT LK (#07) (INCLS 2 KEYS) (17.070)
88966128 KEY, BICYCLE CARR THEFT DTRNT LK (#08) (INCLS 2 KEYS) (17.070) (**VPI 1-877-846-8243)
88966129 KEY, BICYCLE CARR THEFT DTRNT LK (#09) (INCLS 2 KEYS) (17.070)
88966130 KEY, BICYCLE CARR THEFT DTRNT LK (#00) (INCLS 2 KEYS) (17.070)
(AC21-857) 2007-2013 CK1,2(06) BAG PKG/ROOF LUGGAGE (SOFT)(Z88,Z75)
teamcadillac.ru
12497826 BAG PKG, LUGG CARR STOW (RF MT) (WATER RESISTANT/NOT WATERPROOF) (BLACK) (INSTALL .30) (2.29KGS) (FABRIC) (CADILLAC LOGO) (11.5X29.625X37) (12.816)
(AC21-864) 2007-2013 CK1,2(06-36) DOOR PKG/FUEL TANK FILLER
teamcadillac.ru
12497944 DOOR PKG, F/TNK FIL (CHROME) (INSTALL .60) (0.74 KGS) (ZINC DIE CAST) (INCLS SCREWS, NUTS & INSTR) (16.570)
(AC21-865) 2007-2013 CK1(06-36) GRILLE PKG/RADIATOR (Z75)
17801288 GRILLE PKG, FRT (WHITE) (INSTALL 1.5) (3.78KGS) (CHROME MESH W/BODY COLOR SURROUND) (1.266)
19156281 GRILLE PKG, FRT (BLACK) (INSTALL 1.5) (3.78KGS) (CHROME MESH W/BODY COLOR SURROUND) (1.266)
(AC21-866) 2007-2013 CK1,2,3 BALL PKG/TRAILER HITCH
12495788 BALL PKG, TRLR HITCH (CHROME) (INSTALL .10) (1.5KGS) (2 5/16" BALL;1"X2-7/8" SHANK;FLG THK 3/4" TO 1 7/8") (6000LB) (7.068)
19245478 BALL PKG, TRLR HITCH (CHROME) (INSTALL .10) (1.053 KGS) (1-7/8"BALL;1X3" SHANK;FLG THK 1/2 TO 1-3/4") (3500LB GROSS) (7.068) (USE W/BPR & HITCH FLG THK FROM 1/2" TO 1-3/4")
(AC21-867) 2007-2013 CK1,2,3 HITCH PKG/BALL MOUNT
12495777 BAR, TRLR HITCH DRAW (INSTALL .10) (3.0KGS) (STD) (INCLS BALL MT W/1" SHANK, 5/8 HITCH PIN & 1/8 HAIR PIN) (7.068) (2" RISE, 3-1/4" DROP, 5000 LB MAX LOAD, 500 LB TONGUE WT)
12495778 BAR, TRLR HITCH DRAW (INSTALL .10) (4.0KGS) (STD) (INCLS BALL MT W/1" SHANK, 5/8 HITCH PIN & 1/8 HAIR PIN) (7.068) (4" RISE, 5-1/4" DROP, 5000 LB MAX LOAD, 500 LB TONGUE WT)
19245486 BAR, TRLR HITCH DRAW (INSTALL .10) (2.9 KGS) (STD) (INCLS BALL MT W/1" SHANK, 5/8 HITCH PIN & 1/8 HAIR PIN) (7.068) (3/4" RISE, 2" DROP, 5000 LB MAX LOAD, 500 LB TONGUE WT)
(AC21-870) 2007-2010 CK1(06-36) HOOK PKG/TOW
teamcadillac.ru
19243784 HOOK PKG, FRT TOW (INSTALL .50) (CHROME) (7.068)
19158568 ATTACHMENT KIT, TOW HOOK (7.068) (SERV COMP OF CHROME TOW HOOK PKGS)
(AC21-873) 2007-2013 CK1 GUARD PKG/SPLASH (FLAT WITH CONTOUR) (NO LOGO)(Z75)
19154428 GUARD PKG, RR MUD (BLACK) (INSTALL .30) (0.76KGS) (NO LOGO) (FLAT W/CONTOUR) (446 MM LONG) (8.214)
teamcadillac.ru
19213392 FLAP PKG, MUD (FITS FRT OR RR) (BLACK) (INSTALL .30) (0.64 KGS) (FLAT W/CONTOUR) (NO LOGO) (500 MM LONG) (8.214)
(AC21-878) 2007-2013 CK1(06-36) HOIST PKG (EXC (HP2))
19158309 HOIST PKG, SPA WHL (INSTALL .50) (SINGLE 3.1KGS) (HOIST ONLY) (9.709) (FOR 22" WHEEL ONLY)
25974847 HOIST, SPA WHL (7.629) (SERV CMP OF HOIST PKG 19158309)
(AC21-879) 2007-2010 CK1,2,3 HEADPHONE/REAR SEAT ENTERTAINMENT (SERVICED COMPONENT)
teamcadillac.ru
19132012 HEADPHONE PKG, (0.36 KGS) (9.680)
(AC21-887) 2007-2013 CK1,2(06-36) MAT PKG/FRONT FLOOR CARPET (PRODUCTION)
19121915 MAT PKG, FRONT CARPET (EBONY) (TWIN) (NO LOGO) (15.286)
19206524 MAT PKG, FRONT CARPET (CASHMERE) (TWIN) (NO LOGO) (16.800)
(AC21-916) 2007-2013 CK1,2,3 LOCK PKG/BICYCLE & SKI CARRIER
teamcadillac.ru
(AC21-920) 2007-2013 CK1,2,3 PLATE PKG/LICENSE REMOUNT
12495709 BRACKET KIT, RR LIC PLT (INSTALL .30) (1.13 KGS) (INCLS HDW) (REQUIRES 2" HITCH PKG)
(AC21-952) 2007-2013 CK1,2,3 REFLECTIVE TRIANGLE PKG (CU8)
22745654 REFLECTOR PKG, DISABLED VEH WRNG TRIANGLE (1.4KGS) (2.575)
22745655 REFLECTOR PKG, DISABLED VEH WRNG TRIANGLE (BULK) (360 PC QTY OF 22745654) (2.575)
(AC21-980) 2007-2013 CK1(06-36) WHEEL PKG (CK945)(Z75)
12499427 CAP PKG, WHL NUT/BOLT (INSTALL .10) (SINGLE 0.01KGS) (CHROME PLASTIC) (24 PC QTY OF 15045768) (5.858)
12499428 CAP PKG, WHL NUT/BOLT (INSTALL .10) (SINGLE 0.01KGS) (CHROME PLASTIC) (480 PC QTY OF 15045768) (5.858)
teamcadillac.ru
12499308 CAP PKG, HUB (CHROME) (INSTALL .10) (SINGLE 0.04KGS) (W/CADILLAC LOGO) (80 PC QTY OF 88963142) (5.858)
12499423 CAP PKG, HUB (CHROME) (INSTALL .10) (SINGLE 0.04KGS) (W/CADILLAC LOGO) (4 PC QTY OF 88963142) (5.858)
19155564 NUT PKG, WHL (INSTALL .1) (SINGLE 0.062KGS) (STEEL W/ZINC PLATE) (24 PC QTY OF 9595175) (5.813)
17800945 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (CAST) (AL) (INCLS 1 WHL 88967789 & TAG) (5.803)
17800946 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (CAST) (AL) (4 PC QTY OF 88967789) (5.803)
17800947 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (CAST) (AL) (16 PC QTY OF 88967789) (5.803)
(AC21-981) 2007-2013 CK1(06-36) WHEEL PKG (CK948)(Z75)
17800948 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (AL, 6-SINGLE SPOKE) (INCLS 1 WHL 88967790 & TAG) (5.803)
teamcadillac.ru
17800949 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (AL, 6-SINGLE SPOKE) (4 PC QTY OF 88967790) (5.803)
17800950 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 16.6KGS) (20X8.5) (AL, 6-SINGLE SPOKE) (16 PC QTY OF 88967790) (5.803)
(AC21-982) 2007-2013 CK1(06-36) WHEEL PKG (CK951)(Z75)
teamcadillac.ru
17800951 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (INCLS 1 WHL 88967791 & TAG) (5.803)
17800952 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (4 PC QTY OF 88967791) (5.803)
17800953 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (CAST AL) (16 PC QTY OF 88967791) (5.803)
(AC21-984) 2007-2013 CK1,2,3 STEP PKG/TUBULAR ASST (OVAL)
20921112 STEP PKG, ASST (CHROME) (INSTALL .50) (17.98 KGS) (6" OVAL) (AL) (SMOOTH TUBE) (RAISED RECT) (BLACK PAD) (8.225)
teamcadillac.ru
11609836 NUT, ASST STEP RIVET (M8X1.25X17) (3.023) (SERV CMP OF STEP PKGS 12499706, 07, 17801889, 90, 19202895-902)
19211749 BRACKET, ASST STEP (8.228) (SERV CMP OF STEP PKGS 19202895-19202896)
19211750 COVER, ASST STEP BRKT (8.228)
19212311 CAP PKG, ASST STEP FIN (INCLS FRT & RR CAPS) (USE ON STEP TUBE W/NOTCH AT END) (8.304) (SERV CMP OF STEP PKGS)
20919901 PAD, ASST STEP FRT (LONG) (8.228) (SERV CMP OF STEP PKGS 19202895-19202902)
(AC21-985) 2007-2013 CK1(06-36) WHEEL PKG (CK366)(Z75)
17800366 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (AL, 6-MULTI SPOKE) (W/1 WHL 88966246 OR 19170520 & TAG) (5.803)
17800367 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (AL, 6-MULTI SPOKE) (4 PC QTY OF 88966246 OR 19170520) (5.803)
teamcadillac.ru
17800368 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (AL, 6-MULTI SPOKE) (16 PC QTY OF 88966246 OR 19170520) (5.803)
(GM21-020) 2007-2012 CK1,2,3 HEADPHONE/REAR SEAT ENTERTAINMENT (UPGRADE)
17802612 HEADPHONE PKG, (00.2 KGS) (INCLS WIRELESS NOISE CANC HEADPHONE, OWN MAN, 2 AAA BAT) (9.665)
(GM21-024) 2007-2011 CK1 ACCESSORY PKG/TIRE PRESSURE INDICATOR SENSOR NUT
17800699 NUT PKG, TIRE PRESS IND SEN (INSTALL .10) (SINGLE 0.0013 KGS) (16 PC QTY OF 15234846) (5.890)
(GM21-037) 2007-2013 CK1,2,3 ADAPTER PKG/TRAILER HARNESS (7-PIN TO PWR ADAP & 7-PIN TO 4-PIN ADAP)
19201995 ADAPTER PKG, TRLR WRG HARN RCPT (0.1 KGS) (INCLS 7-4 ADAPTER, 7-POWER OUTLET ADAPTER) (7.068)
(GM21-038) 2007-2010 CK1,2,3 TRANSMITTER PKG/REMOTE CONTROL DOOR LOCK (W/INFO DISPLAY)
19157237 TRANSMITTER PKG, R/CON DR LK & THEFT DTRNT & REM START (INCLS TRANSMITTER, RCVR, ANT, H/W, OWNER MAN) (INSTALL 1.1) (0.2 KGS) (2-WAY) (8 FT CABLE) (W/GREEN CONN) (16.345)
19131628 RECEIVER, KEYLESS ENTRY (16.345) (SERV CMP OF 17802071, 19156555, 19157233, 19157237, 19171129)
20763454 LATCH, HOOD PRIM (W/SWITCH) (8.080) (SERV CMP OF XMTR PKGS)
19131603 TRANSMITTER, KEYLESS ENTRY (W/LGATE/LGLASS/TRUNK BUTTON) (10.485)
teamcadillac.ru
19131612 TRANSMITTER, KEYLESS ENTRY (W/O RR CLOSURE BUTTONS) (SERV CMP OF 2-WAY XMTR PKGS) (10.485)
19131613 TRANSMITTER, KEYLESS ENTRY (2-WAY) (W/INFO DISPLAY) (W/TWO RR CLOSURE BUTTONS) (16.345)
19172336 ANTENNA, R/CON DR LK RCVR (ANT LABELED 19131608) (16.345)
(GM21-042) 2007-2013 CK1,2,3 ACCESSORY PKG/FIRE EXTINGUISHER
teamcadillac.ru
19211598 EXTINGUISHER PKG, FIRE (INTERNATIONAL) (INSTALL .30) (2.25 KGS) (2.5LB ABC) (9.990)
(GM21-044) 2010-2013 CK1,2,3 ACCESSORY PKG/TIRE PRESSURE INDICATOR SENSOR
19118652 SENSOR PKG, TIRE PRESS IND (INSTALL .10) (SINGLE 0.03 KGS) (16 PC QTY OF 20923680) (SNAP-IN) (5.890)
(GM21-045) 2010-2013 CK1,2,3 HEADPHONE/REAR SEAT ENTERTAINMENT (FOLD FLAT)
teamcadillac.ru
19245199 HEADPHONE PKG, (FOLD FLAT)
(TC21-009) 2007-2011 CK1(06-36) RAIL PKG/LUGGAGE CARRIER CROSS (Z75)
teamcadillac.ru
12499282 RAIL PKG, LUGG CARR CR (BRI AN W/CHROME ENDCAPS) (INSTALL .25) (3.99KGS) (AL) (NO LOGO) (INCLS 2 RAILS & HDW) (17.070)
19157488 ATTACHMENT KIT, LUGG CARR CR RL (INCLS 4 BOLTS, 4 SUPT CVRS, 4 NUTS, 4 LOOPS, WRENCH & INSTR) (17.070)
19157494 STRIP, LUGG CARR CR RL RUB (17.070)
(TC21-013) 2007-2013 CK1 MAT PKG/FRONT FLOOR CARPET (NON-PRODUCTION) (MOLDED EDGE)(Z75)
17800408 MAT PKG, FRONT CARPET (MOLDED EDGE) (EBONY) (2.03KGS) (CPT) (TWIN) (W/WREATH & CREST LOGO) (16.800)
teamcadillac.ru
17800409 MAT PKG, FRONT CARPET (MOLDED EDGE) (CASHMERE) (2.03KGS) (CPT) (TWIN) (W/WREATH & CREST LOGO) (16.800)
(TC21-014) 2007-2013 CK1,2(06) MAT PKG/REAR PREMIUM (ALL WEATHER)(1 PIECE)
12499640 MAT PKG, REAR PREMIUM (ALL WEATHER) (EBONY) (3.1KGS) (1 PC) (NO LOGO) (VERTICAL RIBS) (16.800)
teamcadillac.ru
19166596 MAT PKG, REAR PREMIUM (ALL WEATHER) (CASHMERE) (3.1KGS) (1 PC) (NO LOGO) (VERTICAL RIBS) (16.800)
(TC21-015) 2007-2013 CK1,2(06) MAT PKG/REAR #2 PREMIUM (ALL WEATHER)(1 PIECE)
teamcadillac.ru
12499641 MAT PKG, REAR #2 PREMIUM (ALL WEATHER) (EBONY) (1.30KGS) (1 PC) (NO LOGO) (VERTICAL RIBS) (16.800)
19166599 MAT PKG, REAR #2 PREMIUM (ALL WEATHER) (CASHMERE) (1.30KGS) (1 PC) (VERTICAL RIBS) (16.800)
19166600 MAT PKG, REAR #2 PREMIUM (ALL WEATHER) (GRAY) (1.30KGS) (1 PC) (NO LOGO) (VERTICAL RIBS) (16.800)
(TC21-016) 2007-2013 CK107(06) MAT PKG/REAR #2 CARPET (MOLDED EDGE)
teamcadillac.ru
17800423 MAT PKG, REAR #2 CARPET (MOLDED EDGE) (EBONY) (1.30KGS) (1 PC) (NO LOGO) (16.800)
17800424 MAT PKG, REAR #2 CARPET (MOLDED EDGE) (CASHMERE) (1.30KGS) (1 PC) (NO LOGO) (16.800)
(TC21-018) 2007-2013 CK107(06) MAT PKG/CARGO PREMIUM (ALL WEATHER)(Z75)
17801325 MAT PKG, CARGO PREMIUM (ALL WEATHER) (EBONY) (2.0KGS) (W/ESCALADE LOGO) (USE W/3RD ROW SEAT) (8.214)
19166801 MAT PKG, CARGO PREMIUM (ALL WEATHER) (CASHMERE) (2.0KGS) (W/ESCALADE LOGO) (USE W/3RD ROW SEAT) (16.800)
(TC21-022) 2007-2013 CK1,2,3 SECURITY PKG/INCLINATION SENSOR
17800431 ALARM PKG, THEFT DTRNT (INSTALL .80) (0.0856KGS) (VEH SECURITY SHOCK) (INCLS HARN & INSTR) (2.195)
17800432 ALARM PKG, THEFT DTRNT (INSTALL .80) (0.0421KGS) (INCLS SENSOR & HARN) (2.195) (REQUIRES PROGRAMMING THRU TCSC) (REQUIRES UK3 OR ACSRY DIC SWITCH PKG.)
(TC21-023) 2007-2013 CK1,2,3 SHIELD PKG/DOOR SILL (NO LOGO)
17802414 PLATE PKG, S/D SILL TR (INSTALL .50) (SS) (BRUSHED) (NO LOGO) (INCLS FRT & RR) (16.603)
(TC21-032) 2007-2013 CK1 WHEEL PKG (CK997)(Z75)
17800997 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (AL) (INCLS 1 WHL 88967872 & TAG) (5.803)
teamcadillac.ru
17800998 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (AL) (4 PC QTY OF 88967872) (5.803)
17800999 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5) (ALUMINUM) (16 PC QTY OF 88967872) (5.803)
(TC21-033) 2007-2011 CK1 WHEEL PKG (CK925)(Z75)
teamcadillac.ru
17800925 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 19.0KGS) (20X8.5, CAST AL) (5 SINGLE SPOKE BORDERED) (INCLS 1 WHL 88967768) (5.803)
17800926 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 19.0KGS) (20X8.5, CAST AL) (5 SINGLE SPOKE BORDERED) (4 PC QTY OF 88967768) (5.803)
17800927 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 19.0KGS) (20X8.5, CAST AL) (5 SINGLE SPOKE BORDER) (16 PC QTY OF 88967768) (5.803)
(TC21-034) 2007-2011 CK1 WHEEL PKG (CK994)(Z75)
teamcadillac.ru
17800994 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 18.8KGS) (20X8.5, AL) (6 SPOKE MULTI-FEATURE) (INCLS 1 WHL 88967871 & TAG) (5.803)
17800995 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 18.8KGS) (20X8.5, AL) (6 SPOKE MULTI-FEATURED) (4 PC QTY OF 88967871) (5.803)
17800996 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 18.8KGS) (20X8.5, AL) (6 SPOKE MULTI-FEATURED) (16 PC QTY OF 88967871) (5.803)
(TC21-043) 2007-2013 CK1,2(06-36) MAT PKG/REAR FLOOR CARPET (PRODUCTION) (TWIN)
19121926 MAT PKG, REAR CARPET (EBONY) (TWIN) (16.800)
teamcadillac.ru
19206525 MAT PKG, REAR CARPET (CASHMERE) (TWIN) (16.800)
(TC21-052) 2009-2010 CK1(06-36) ACCESSORY PKG/MUFFLER
19156353 MUFFLER PKG, EXH (SS) (INSTALL 1.0) (20.41KGS) (SEMI POLISHED) (3.701)
teamcadillac.ru
19156354 MUFFLER PKG, EXH (SS) (INSTALL 1.0) (20.41KGS) (SEMI POLISHED) (3.701)
(TC21-054) 2007-2013 CK1,2(06) GUARD PKG/SPLASH (MOLDED) (FRONT)(NO LOGO)(FLAT BOTTOM)
teamcadillac.ru
19212577 GUARD PKG, F/FDR MUD (SILVER) (INSTALL .50) (.52 KGS) (MOLDED) (8.214)
19212579 GUARD PKG, F/FDR MUD (LABYRINTH) (INSTALL .50) (.52 KGS) (MOLDED) (8.214)
(TC21-057) 2007-2013 CK1,2(06-36) GUARD PKG/SPLASH (MOLDED) (FRONT)(NO LOGO)
19212797 GUARD PKG, F/FDR MUD (NOT FOR USE W/ACSRY ARTICULATING RUN BD, FDR FLARES, OR GND EFFECTS) (BLACK) (INSTALL .50) (0.52 KGS) (MOLDED) (W/EDGE SEAL) (SMOOTH FINISH)) (8.214)
19212799 GUARD PKG, F/FDR MUD (NOT FOR USE W/ACSRY ARTICULATING RUN BD) (WHITE) (INSTALL .50) (0.52 KGS) (MOLDED) (W/EDGE SEAL) (8.214)
teamcadillac.ru
19212801 GUARD PKG, F/FDR MUD (GRAY) (INSTALL .50) (0.52 KGS) (MOLDED) (W/EDGE SEAL) (CAN BE USED W/OR W/O RUNNING BOARD) (8.214)
(TC21-058) 2007-2013 CK1(06) GUARD PKG/SPLASH (MOLDED) (REAR)(NO LOGO)(Y91,Z75)
19212154 GUARD PKG, RR MUD (SILVER) (INSTALL .50) (0.6 KGS) (MOLDED) (NOT FOR USE W/ACSRY SPARE TIRE KIT 19172547) (8.214)
19212155 GUARD PKG, RR MUD (LABYRINTH) (INSTALL .50) (0.6 KGS) (MOLDED) (NOT FOR USE W/ACSRY SPARE TIRE KIT 19172547) (8.214)
19212817 GUARD PKG, RR MUD (GRAY) (INSTALL .50) (0.62 KGS) (MOLDED) (W/EDGE SEAL) (8.214)
19212807 GUARD PKG, RR MUD (NOT FOR USE W/ACSRY SPARE TIRE KIT 19172547) (BLACK) (INSTALL .50) (0.62 KGS) (MOLDED) (W/EDGE SEAL) (8.214)
19212809 GUARD PKG, RR MUD (WHITE) (INSTALL .50) (0.62 KGS) (MOLDED) (W/EDGE SEAL) (8.214)
(TC21-066) 2007-2013 CK1(06-36) SHIELD PKG/DOOR SILL (CADILLAC SCRIPT LOGO)(Z75)
teamcadillac.ru
17802527 PLATE PKG, S/D SILL TR (INSTALL .30) (1.46KGS) (SS) (BRUSHED) (W/CAD SCRIPT LOGO) (INCLS RH & LH FRT & 2 R/L RR) (16.603)
(TC21-082) 2007-2013 CK1 DEFLECTOR PKG/HOOD AIR (Z75)
teamcadillac.ru
19172570 DEFLECTOR PKG, HOOD AIR (SMOKE) (INSTALL .3) (0.6KGS) (ACRYLIC) (NO LOGO) (INCLS FASTENERS & INSTR) (8.010)
19172571 DEFLECTOR PKG, HOOD AIR (CHROME) (INSTALL .3) (0.7KGS) (ABS) (NO LOGO) (INCLS FASTENERS & INSTR) (8.010)
(TC21-089) 2007-2013 CK107,109(06) LAMP PKG/TAIL(Z75)
22884391 LAMP KIT, TAIL (CLEAR) (INSTALL .35) (3.98 KGS) (STOP LMP) (INCLS RH/LH) (2.679)
(TC21-091) 2007-2013 CK1 EXTENSION PKG/EXHAUST TAIL PIPE (OEM ONLY)(NO LOGO)(Z75)
22799816 EXTENSION KIT, EXH TAIL PIPE (INSTALL .50) (1.06 KGS) (DUAL WALL) (ANGLE CUT) (SS) (NO LOGO) (FOR USE W/GRND FX) (3.705)
19132693 CLAMP, EXH PIPE (SERV CMP OF EXT PKGS) (3.5" TORCA STYLE) (3.708)
(TC21-094) 2007-2013 CK1(06-36) WHEEL PKG (CK372)(Z75)
17800372 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 20.6KGS) (22X9) (CAST AL) (INCLS 1 WHL 88966248 & TAG) (5.803)
17800373 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 20.6KGS) (22X9) (CAST AL) (4 PC QTY OF 88966248) (5.803)
17800374 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 20.6KGS) (22X9) (CAST AL) (16 PC QTY OF 88966248) (5.803)
(TC21-097) 2007-2013 CK1(06-36) WHEEL PKG (CK375)(Z75)
teamcadillac.ru
17800376 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (AL) (4 PC QTY OF 88966249) (5.803)
17800377 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 20.8KGS) (22X9) (AL) (16 PC QTY OF 88966249) (5.803)
88966249 WHEEL PKG, (ALUM) (INCLS 1 WHL 88966249 & TAG) (SINGLE 20.8KGS) (INSTALL .25) (CHROME) (ALUM) (CHROME) (5.803)
(TC21-100) 2007-2013 CK1(06-36) WHEEL PKG (CK910)(Z75)
teamcadillac.ru
17800910 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 22.0KGS) (22X9) (AL, DESIGN 1) (INCLS 1 WHL 88967763 & TAG) (5.803)
17800911 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 22.0KSG) (22X9) (AL, DESIGN 1) (4 PC QTY OF 88967763) (5.803)
17800912 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 22.0KGS) (22X9) (AL, DESIGN 1) (16 PC QTY OF 88967763) (5.803)
(TC21-103) 2007-2013 CK1(06-36) WHEEL PKG (CK916)(Z75)
17800916 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 20.0KGS) (22X9) (CAST AL) (INCLS 1 WHL 88967765 & TAG) (5.803)
17800917 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 20.0KGS) (22X9) (CAST AL) (4 PC QTY OF 88967765) (5.803)
17800918 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 20.0KGS) (22X9) (CAST AL) (16 PC QTY OF 88967765) (5.803)
(TC21-119) 2007-2013 CK107,109(06) LAMP PKG/CENTER HIGH MOUNT STOP(Z75)
teamcadillac.ru
19172250 LAMP KIT, HIGH MT STOP (CLEAR) (INSTALL .50) (0.91KGS) (PLASTIC) (2.679)
(TC21-121) 2007-2013 CK1 MAT PKG/FRONT PREMIUM (ALL WEATHER)(Z75)
teamcadillac.ru
17803323 MAT PKG, FRONT PREMIUM (ALL WEATHER) (EBONY) (3.40KGS) (TWIN) (W/SILVER ESCALADE LOGO) (VERTICLE RIBS) (16.800)
19166595 MAT PKG, FRONT PREMIUM (ALL WEATHER) (CASHMERE) (3.40KGS) (TWIN) (W/SILVER ESCALADE LOGO) (VERTICAL RIBS) (16.800)
(TC21-137) 2009-2011 CK1,2,3 ACCESSORY PKG/REAR VIEW CAMERA
teamcadillac.ru
25872958 HARNESS, RR LIC PLT LP WRG (2.714) (SERV CMP OF CAMERA PKGS)
(TC21-142) 2007-2013 CK1 WHEEL PKG (CK798)
19170798 WHEEL PKG, (5.803)
19170799 WHEEL PKG, (5.803)
19170800 WHEEL PKG, (MACH./PAINTED) (INSTALL .25) (SINGLE 17.93KGS) (22X9) (CAST AL) (16 PC QTY OF 19170797) (5.803)
(TC21-143) 2007-2013 CK1 WHEEL PKG (CK919)
teamcadillac.ru
17800919 WHEEL PKG, (CHROME) (INSTALL .30) (20.4 KGS) (22X9) (INCLS 1 WHL 88967766 & TAG) (AL) (CAST) (5.803)
17800920 WHEEL PKG, (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9) (4 PC QTY OF 88967766) (AL) (CAST) (5.803)
17800921 WHEEL PKG, (5.803)
(TC21-144) 2007-2011 CK1 WHEEL PKG (CK922)
17800922 WHEEL PKG, (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9, CAST AL) (6 TAPERED SPOKE DES) (INCLS 1 WHL 88967767 & TAG) (5.803)
teamcadillac.ru
17800923 WHEEL PKG, (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9, CAST AL) (6 TAPERED SPOKE DES) (4 PC QTY OF 88967767) (5.803)
17800924 WHEEL PKG, (CHROME) (INSTALL .30) (SINGLE 20.4 KGS) (22X9, CAST AL) (6 TAPERED SPOKE DES) (16 PC QTY OF 88967767) (5.803)
(TC21-145) 2007-2011 CK1 WHEEL PKG (CK928)
17800928 WHEEL PKG, (CHROME) (INSTALL .25) (17.3KGS) (20X8.5, CAST AL) (8 SQUARE SPOKE DES) (1 PC QTY OF 88967769) (5.803)
17800929 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5, CAST AL) (8 SQUARE SPOKE DES) (4 PC QTY OF 88967769) (5.803)
teamcadillac.ru
17800930 WHEEL PKG, (CHROME) (INSTALL .25) (SINGLE 17.3KGS) (20X8.5, CAST AL) (8 SQUARE SPOKE DES) (16 PC QTY OF 88967769) (5.803)
(TC21-146) 2007-2013 CK1 WHEEL PKG (CK991)
17800991 WHEEL PKG,
teamcadillac.ru
17800992 WHEEL PKG,
17800993 WHEEL PKG,
(TC21-147) 2007-2013 CK1 WHEEL PKG (CK370)
teamcadillac.ru
19170370 WHEEL PKG, (CHROME) (INSTALL .30) (SINGLE 15.0KGS) (20X8.5) (AL, 6 TAPERED SPOKE) (INCLS 1 WHL 19170369 & TAG) (5.803)
19170371 WHEEL PKG, (CHROME) (INSTALL .30) (SINGLE 15.0KGS) (20X8.5) (AL, 6 TAPERED SPOKE) (4 PC QTY OF 19170369) (5.803)
19170372 WHEEL PKG, (CHROME) (INSTALL .30) (SINGLE 15.0KGS) (20X8.5) (AL, 6 TAPERED SPOKE) (16 PC QTY OF 19170369) (5.803)
(TC21-152) 2008-2010 CK107(06) ACCESSORY PKG/SPARE TIRE(HP2)
19172547 HOIST PKG, SPA WHL (INSTALL 1.5) (SINGLE 19.9KGS) (INCLS WHL, HOIST, & EXH KIT) (NOT FOR USE/ACSRY SPH GUARDS) (5.880) (P265/70R17 TIRE & FASCIA COVER NOT INCLUDED IN KIT)
25851500 RESONATOR KIT, EXH (W/TAIL PIPE) (400MM MUFFLER) (3.702) (SERV CMP OF SPA WHL PKG 19172547)
09595852 WHEEL, 17X7 SPA (ALUM) (5.803) (SERV CMP OF HOIST PKG)
10372326 GUIDE, SPA WHL HOIST SHF (7.629) (SERV CMP OF SPA WHL PKGS)
15101404 HANDLE, JK (508.0MM LG) (8.820) (SERV CMP OF SPA WHL PKG)
15295860 EXTENSION, JK HDL (406MM) (NON FLEXIBLE SHAFT) (8.820) (SERV CMP OF SPA WHL PKG)
15547900 BLOCK, WHL (8.820) (SERV CMP OF SPA WHL PKG)
15772593 NUT, WHL BLK (6MM) (8.820) (SERV CMP OF SPA WHL PKG)
15783357 BOLT, WHL BLK (8.820) (SERV CMP OF SPA WHL PKG)
15827206 CASE, SPA WHL LK CYL (7.680) (SERV CMP OF SPA WHL PKG)
15854614 HANDLE, JK/WHL WRENCH (NON-RATCHET TYPE) (8.821) (SERV CMP OF SPA WHL PKG)
25783810 SHIELD, SPA WHL HT (7.629) (SERV CMP OF SPA WHL PKG)
teamcadillac.ru
25851508 CLAMP, EXH PIPE (3.708) (SERV CMP OF SPA WHL PKG 19172547)
25974846 HOIST, SPA WHL (7.629) (SERV CMP OF HOIST PKG)
20782703 TOOL KIT, (8.821) (SERV CMP OF SPA WHL PKG)
15788798 JACK, (8.820) (SERV CMP OF HOIST PKG)
11610693 RETAINER, TOOL STOW (INCLS WINGNUT) (8.821) (SERV CMP OF HOIST PKG)
22895910 BRACKET, JK STOW (8.820) (SERV CMP OF SPA WHL PKG)
(TC21-153) 2007-2013 CK1,2(06) NET PKG/CONVENIENCE (FLAT STYLE)
17803346 NET PKG, CONVENIENCE (BLACK) (INSTALL .50) (2ND ROW) (FLAT STYLE) (INCLS 4-RET & 4-STUDS) (16.575)
(TC21-161) 2007-2013 CK107,109(06) TRAY PKG/REAR COMPARTMENT FLOOR STORAGE (Z75)
teamcadillac.ru
17803357 TRAY PKG, R/CMPT FLR STOW COMPT (EBONY) (2.3KGS) (GRD PLSTC) (W/ESCALADE SCRIPT LOGO) (INCLS LINER) (2" SIDE WALLS) (16.583) (TO BE USED WHEN THIRD ROW SEAT IS NOT IN VEHICLE)
(TN21-036) 2007-2011 CK1,2,3 SECURITY PKG/VEHICLE SHOCK SENSOR
teamcadillac.ru
  • Maxim locked this тему
