00 - 6-ТИ ЦИЛИНДРОВЫЙ ДВИГАТЕЛЬ
(6D00-018) - 2004-2005 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 5 КОЛЛЕКТОР & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7)
12603990 TUBE, PCV (INCLS 292)
11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (PCV TUBE)
12616910 HOSE, PCV (INCLS 285, 286, 290-292) (DIRTY AIR)
12587556 MANIFOLD, UPR INT (INCLS 506)
12571079 MANIFOLD, LWR INT (INCLS 519)
12567371 GROMMET, UPR INT MANIF SIGHT SHLD [ВТУЛКА]
12606862 GROMMET, UPR INT MANIF SIGHT SHLD (32MM OD)
11518906 БОЛТ, HFH, RDUCD BDY, M8X1.25X165, 22 THD, 18 O.D., 8.8, GMW3359 (INT UPR MANIF) [БОЛТ]
11519176 БОЛТ, INT MANIF (M8X1.25X80) (4.081) [БОЛТ]
12577530 BRACE, INT MANIF
11588967 STUD, BALL W/HFH, M6X1X20.65, 14.2 O.D., 8.8, GMW3359 (INT MANIF BR)
11900286 БОЛТ, HFH, W/RDUCD BODY, M12X1.75X75.9, 30 THD, 26.6 OD, 10.9, GMW3359 (INT MANIF BR)
12595277 GASKET KIT, UPR INT MANIF (*KIT1) [ПРОКЛАДКА]
11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (LWR INT MANIF)
11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (F/INJN FUEL RL) [БОЛТ]
12584921 COVER, UPR INT MANIF
11517031 ГАЙКА, HFH, M8X1.25, 9.4THK, 17.4 O.D., 10, TIN ZN (UPR INT MANIF SIGHT SHLD)
12583604 SHIELD, UPR INT MANIF SIGHT (INCLS 595, 596) [ЗАЩИТА]
11588523 STUD, M6X1 (UPR INT MANIF SIGHT SHLD)
teamcadillac.ru
12576262 GASKET, EXH MANIF [ПРОКЛАДКА ВЫПУСКНОГО КОЛЛЕКТОРА]
12571102 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ]
12580706 SHIELD, EXH MANIF HT
11517516 БОЛТ, HFH, M6X1X13, 9.5 THD, 14.2 OD, 9.8, 6280M, MACH, HDR-PT (EXH MANIF H/SHLD)
12582663 INSULATOR, EXH MANIF UPR
12581806 INSULATOR, EXH MANIF LWR
12576263 GASKET, EXH MANIF
12571101 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ]
11518860 БОЛТ, HFH, M8X1.25X30, 20.9 THD, 18 O.D., 10.9, GMW3179 CODE G, GM6194M (EXH MANIF H/SHLD) [БОЛТ]
12617267 SHIELD, EXH MANIF HT
12581807 INSULATOR, EXH MANIF LWR
14093869 ГАЙКА, PUSH ON, M6, 2.25THK, 12.95 O.D., STL, POR (EXH MANIF H/SHLD INSL)
12571081 BODY, THROT (INCLS 716) (INCLS THROTTLE POSITION SENSOR) (INCLS ACT MTR) (ACDelco #12571081) (STAMPED 12571081) (FOR 2ND DES SEE 12589056)
12589056 BODY, THROT (INCLS 716) (INCLS THROTTLE POSITION SENSOR) (INCLS ACT MTR) (ACDelco #217-2253) (STAMPED 12589056) (FOR 1ST DES SEE 12571081)
11519972 БОЛТ, THROT BODY (M6X1.0X50)
12581398 GASKET, THROT BODY (ACDelco #217-1610) (USE T/W 88988585 HARNESS T/W 12589056 TBI WHEN REPLACING OLD DESIGN 12571081 TBI) [ПРОКЛАДКА]
12577831 CLIP, ENG WRG HARN (ЧАСТЬ OF 701) [ФИКСАТОР ПРОВОДКИ МОТОРНОГО ОТСЕКА]
12571136 SOLENOID, EVAP EMIS CNSTR C/VLV (INCLS 752) (ACDelco #214-1086)
11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (EVAP EMIS CNSTR PURGE SOL VLV BRKT)
12584171 HOSE, EVAP EMIS CNSTR SOL VLV
12586694 VALVE, INT MANIF TUNING (INCLS 756)
11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (INT MANIF TUNING VLV) [БОЛТ]
12575467 SENSOR, MAP (INCLS 778) (ACDelco #213-1584) [ДАТЧИК]
12572886 RAIL, F/INJN FUEL (СМ. ГРУППУ 03.000 "FUEL INJECTION RAIL" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #217-1551) [МАГИСТРАЛЬ ТОПЛИВНЫХ ФОРСУНОК ДВИГАТЕЛЯ]
12598158 GASKET KIT, INT MANIF (INCLS 521, 522) [ПРОКЛАДКА ДВИГАТЕЛЯ]
(6E00-003) - 2004-2006 E ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ-V8 (LH2/4.6A, M22)
11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT) [ГАЙКА М12]
25762620 BRACKET, ENG MT
11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (ENG MT BRKT) [БОЛТ, М10Х1.5Х30]
25892303 MOUNT, TRANS RR
11515775 БОЛТ, HFH, M12X1.75X30, 10.9, 7114M (TRANS MT) [БОЛТ]
teamcadillac.ru
25971086 MOUNT, ENG [ОПОРНЫЙ УЗЕЛ ДВИГАТЕЛЯ]
11517383 БОЛТ, HEX W/CON SPR WASH, M10X1.5X55, 28 OD, 37 THD, 10.9, 7114M (TRANS RR MT BRKT)
11517780 ГАЙКА, M12X1.75, 15 THK, 29 OD, 10, 7111M, ALL METAL PREV TORQ (ENG MT FRM SI) [ГАЙКА М12]
25971085 MOUNT, ENG [ШАРНИР ДВИГАТЕЛЯ]
25971087 MOUNT, ENG
25716470 BRACKET, ENG MT
25762621 BRACKET, ENG MT
(6E00-004) - 2004-2006 E ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ-V8 (LH2/4.6A, MV3)
15143640 MOUNT, TRANS RR
25892306 MOUNT, TRANS RR
teamcadillac.ru
(6E00-005) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ & ЧАСТЬIAL ДВИГАТЕЛЬ (LH2/4.6A)
teamcadillac.ru
19177068 ДВИГАТЕЛЬ, GASOLINE (GOODWRENCH NEW) (FOR 07 STS, SWP OIL FILT ADAPT, ENG OIL CLR FRM ORIG ENG.06 & PREV STS/SRX/XLR SWP МАСЛЯНЫЙ ПОДДОН, ENG OIL CLR IF APPL, WTR OTLT ASM, CAM ACTUATOR FRM ORIG) (ENG.05 & PREV STS/SRX/XLR SWP CAM CVRS & PVC TBE F
(6E00-006) - 2004-2005 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 1 БЛОК ЦИЛИНДРОВ & ВНУТРЕННИЕ ДЕТАЛИ (LH2/4.6A)
12573430 SEAL, LWR C/CASE (4.3MM WIDE X 5MM TALL) [ПРОКЛАДКА]
11515793 БОЛТ, HFH (LWR C/CASE)
03522376 БОЛТ, HFH, M6X1X23, 18 THD, 14.50 OD, 7T, ZP (ENG OIL MANIF)
03542310 БОЛТ, LWR C/CASE (M10X1.5X125, 30 THD) (8.900)
03542311 STUD, LWR C/CASE (M10X1.5X125-M9X1.0X13) (1.428)
03530355 PIN, LWR C/CASE LOC (M8X20)
12565564 CRANKSHAFT, (MCHG) [КОЛЕНЧАТЫЙ ВАЛ]
12585420 PIN, CR/SHF SPKT LOC
89017562 BEARING KIT, CR/SHF (STD) (POSN # 1, 2, 4, 5) [ПОДШИПНИК]
89017563 BEARING KIT, CR/SHF (STD) (POSN # 3) [ПОДШИПНИК]
12568025 SEAL, CR/SHF RR OIL [ПРОКЛАДКА]
12338076 PIN, TRANSAXLE LOC (19.5 MM X 18.5 MM) (TO CYL BLK)
03525915 PIN, ENG FRT CVR LOC (DOWEL, 5.99X17.25, CHAM BOTH ENDS, 10.9)
24503702 PLUG, ENG BLK COOL HOLE (8X1.25X12, 10.5 THD W/6MM OF 6124M ADHES, 17.6 OD, 9.8, PC)
03522422 PLUG, CM/SHF (CUP, W/LIP, 50.24X6.12X1.52, 52.58 OD, 1008, OIL)
12580474 FLYКОЛЕСО, ENG [МАХОВИК ДВИГАТЕЛЯ]
12561075 БОЛТ, FLYWHL
12568122 COVER, FLYWHL HSG
12570154 SPROCKET, CR/SHF
12581223 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (PRIMARY)
01647264 БОЛТ, TMG CHAIN TENSR (HFH, 8X1.25X42, 22 THD, 17.0 OD, 9.8, PC, MACH)
12564274 CHAIN, CM/SHF INTER DRV
12559388 GUIDE KIT, TMG CHAIN (PRIMARY CHAIN)
12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH)
12577433 SPROCKET, CM/SHF INTER DRV SHF
01647272 БОЛТ, CM/SHF SPKT
12577790 SHAFT, CM/SHF INTER DRV
15685550 БОЛТ, CM/SHF INTER DRV SHF RET (M6X1X20) (16.330) [ВИНТ]
12556023 GUIDE, TMG CHAIN (SECONDARY CHAIN GUIDE)
12556030 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (SECONDARY) [НАТЯЖИТЕЛЬ РЕМНЯ]
teamcadillac.ru
12567469 ROD, CONN (INCLS 201) (USES 23MM PIN)
12552947 БОЛТ, CONN ROD (ЧАСТЬ OF 200) (MJ9X1.0-4H6HX61.9 LONG) [БОЛТ]
89017430 PISTON, (W/PIN) (INCLS 211, 212)
12584576 BALANCER, CR/SHF [ШКИВ КОЛЕНВАЛА]
11569873 БОЛТ, CR/SHF BALR (M14X1.5X48.4)
12577394 BAFFLE, МАСЛЯНЫЙ ПОДДОН (B/W CRANK CASE AND PAN)
12567170 SENSOR, CR/SHF POSN (INCLS 721) (ACDelco #213-1511) [ДАТЧИК ПОЛОЖЕНИЯ КОЛЕНВАЛА]
11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (CR/SHF POSN SEN)
12567446 SENSOR, KNOCK (ACDelco #213-1525) [ДАТЧИК ДЕТОНАЦИИ ДВИГАТЕЛЯ]
10465558 STARTER, (REMAN) (STAMPED 12574832; FOR 2ND DES SEE 89017760) (ACDelco #323-1463) (DELCO PMGR SERIES PG260) [СТАРТЕР В СБОРЕ]
19136223 STARTER, (REMAN) (DELCO PMGR; 1.7 KW) (ACDelco #336-1914) (ALL MAKES)
88864293 STARTER, (REMAN) (DELCO PMGR; 1.7 KW) (ALL MAKES)
89017760 STARTER, (REMAN) (STAMPED 12587429; FOR 1ST DES SEE 10465558) (ACDelco #323-1633) (DELCO SERIES PG260H) [СТАРТЕР]
11515793 БОЛТ, HFH (STRTR)
12597445 HARNESS, CR/SHF POS SEN & KNOCK SEN WRG (INCLS 797)
12583228 BRACKET, CR/SHF POSN SEN WRG HARN CONN (ЧАСТЬ OF 796)
01647172 SPACER, FLYWHL
12559363 BEARING KIT, CONN ROD (STD) (INCLS 203, 204) [КОМПЛЕКТ ПОДШИПНИКОВ СКОЛЬЖЕНИЯ ШАТУНА (2ШТ)]
89017413 RING KIT, PSTN (INCLS 213-216)
(6E00-007) - 2004-2005 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 5 КОЛЛЕКТОР & FUEL ДЕТАЛИ КОМПЛЕКТА (LH2/4.6A)
12565545 TUBE, PCV (CLEAN AIR TUBE)
12577168 TUBE, PCV (INCLS 284) (DIRTY AIR TUBE)
11570614 CЛАМПА-ПРУЖИНАBAND, 15 NOMINAL DIA, 15 THK, STL, ROBO (ЧАСТЬ OF 283)
12583849 OUTLET, WAT (INCLS 382, 387, 908) (ACDelco #15-10427)
12590862 GASKET, WAT OTLT [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ]
12568102 FITTING, ENG COOL AIR BL HOSE (ЧАСТЬ OF 380)
12566109 HOSE, RAD BYPASS
15024902 CЛАМПА, HOSE ПРУЖИНА, 42MM - NOM SIZE, BLK (RAD BYPASS HOSE)
11519172 БОЛТ, HFH, 8X1.25X55, 18 OD, 22THD, 8.8, GMW3359, 6MM MATPOINT, REDUCED BODY (WAT OTLT)
12564771 MANIFOLD, INT (INCLS 502, 520, 902, 903) (INCLS PCV TUBE) (INTAKE DOES NOT NEED PRESSURE RELIEF VALVE)
12571222 FITTING, P/B BOOS VAC TUBE (ЧАСТЬ OF 500)
12579192 COVER, INT MANIF
12579193 COVER, INT MANIF
11588967 STUD, BALL W/HFH, M6X1X20.65, 14.2 O.D., 8.8, GMW3359 (IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ)
12557497 SEAL, UPR INT MANIF (ЧАСТЬ OF 500) (FITS UNDER INTAKE MANIFOLD TO ГОЛОВКА ЦИЛИНДРОВ) [УПЛОТНИТЕЛЬ]
12580250 PLENUM, INT MANIF (INCLS 526)
11588352 БОЛТ, INT MANIF (W/SPCR)
12557010 STUD, F/INJN FUEL RL (HEX, M6X1.022-M6X1.016, 45MM TOTAL LENGTH) (3.275)
12571212 SHIELD, UPR INT MANIF SIGHT (INCLS 595, 596) [ЗАЩИТНЫЙ КОЖУХ ДВИГАТЕЛЯ]
12600206 BRACKET, UPR INT MANIF SIGHT SHLD (INCLS 904)
03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (UPR INT MANIF SIGHT SHLD)
12567370 STUD, UPR INT MANIF SIGHT SHLD (3.265)
12567371 GROMMET, UPR INT MANIF SIGHT SHLD (ЧАСТЬ OF 590) [ВТУЛКА]
12567687 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 626, 906) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ]
12607338 SHIELD, EXH MANIF HT
24505098 БОЛТ, HFH, RND HD, 6X1X12.15, W/ANTI SEIZE, 14.2 O.D.DG PT, 10.9, 711 (EXH MANIF H/SHLD)
12567688 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 626, 635, 636, 906) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ]
11517031 ГАЙКА, HFH, M8X1.25, 9.4THK, 17.4 O.D., 10, TIN ZN (EXH MANIF)
11519171 БОЛТ, EXH MANIF CLA (M8X1.25X50) (3.275) [БОЛТ ВЫПУСКНОГО КОЛЛЕКТОРА]
12345493 SEALANT, TRANS БОЛТ ADHESIVE (GENERAL PURPOSE)
11562490 STUD, STRAIGHT, M8X1.25X20, M8X1.25X40, 69 TL, 9.8, GMW3179, EXT HEX SOCKET (EXH MANIF) [ШПИЛЬКА М8]
11609596 STUD, CTLTC CONV (ЧАСТЬ OF 600, 620) [ШПИЛЬКА]
12576372 SHIELD, EXH MANIF HT
12568289 SHIELD, EXH MANIF LWR HT (ЧАСТЬ OF 620)
10229247 RIVET, EXH MANIF H/SHLD (ЧАСТЬ OF 620) (3.601)
12567376 BODY, THROT (W/THROT ACTR) (INCLS 702) (ACDelco #217-2294) [ДРОССЕЛЬНАЯ ЗАСЛОНКА]
11519973 БОЛТ-HFH, M6X1X60, 18MM THD, 14.2 OD, 8.8, 3359GMW, REDUCED BODY, MAT PT. (ЧАСТЬ OF 701) [БОЛТ 6Х1Х60]
12571741 GASKET, THROT BODY (ACDelco #12571741) [ПРОКЛАДКА ДРОССЕЛЬНОГО КЛАПАНА]
09359409 SENSOR, MAP (INCLS SEAL) (INCLS 741) (ACDelco #9359409)
16194007 SEAL, MAP SEN (ЧАСТЬ OF 740) [УПЛОТНИТЕЛЬ ДАТЧИКА ДАВЛЕНИЯ ПОТОКА ВОЗДУХА]
12587812 BRACKET, MAP SEN
11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (MAP SEN) [БОЛТ]
12581282 VALVE, EVAP EMIS CNSTR PURGE SOL (INCLS 745) (ACDelco #214-1105) [КЛАПАН ТОПЛИВОИСПАРИТЕЛЬНОГО БАКА]
11519941 БОЛТ, HFH W/SHLDR, M6X1X22, 13.8 THD, 15 OD, 9.8, 6280M, MACH, DOG-PT (EVAP EMIS CNSTR PURGE SOL)
25917777 PIPE, EVAP EMIS CNSTR PURGE (INCLS 748, 749)
12567655 GASKET, EXH MANIF [ПРОКЛАДКА]
11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (WAT OTLT)
12575237 TUBE, PCV (ЧАСТЬ OF 500) (PLASTIC TUBE) (POA INTAKE MANIFOLD)
12571223 PLUG, P/B VAC SCE HOLE (ЧАСТЬ OF 500) (16.0 MM)
19167509 INSULATOR, UPR INT MANIF CVR (ЧАСТЬ OF 591) (3.405)
teamcadillac.ru
12575657 SENSOR, HTD OXY (POSN 1) (IN EXH MANIFOLD/CROSSOVER) (ACDelco #213-1572) (W/RECTANGULAR SHAPED CONNECTOR) (FOR 2ND DES SEE 12596327) [ДАТЧИК]
12596327 SENSOR, HTD OXY (POSN 1) (IN EXH MANIFOLD/CROSSOVER) (ACDelco #213-3240) (W/OVAL SHAPED CONNECTOR) (FOR 1ST DES SEE 12575657) [КИСЛОРОДНЫЙ ДАТЧИК]
25709703 SEAL, CTLTC CONV (ЧАСТЬ OF 600, 620) (ROUND METAL SEAL) [ПРОКЛАДКА НАСОСА]
12585313 PLUG, ENG COOL AIR BL (ЧАСТЬ OF 380)
12616537 COVER, INT MANIF (RR)
(6E00-008) - 2004-2006 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 3 ПЕРЕДНЯЯ КРЫШКА И ОХЛАЖДЕНИЕ (LH2/4.6A)
89017437 COVER, ENG FRT (INCLS 353) (STMPD 12569092 & USED W/PAPER GKT; FOR 2ND DESIGN SEE 89017798.) [КРЫШКА В СБОРЕ]
89017798 COVER, ENG FRT (INCLS 353) (STMPD 12584582 & USED W/METAL GKT; FOR 1ST DESIGN SEE 89017437)
12576673 GASKET, ENG FRT CVR (PAPER GASKET) (W/ПЕРЕДНЯЯ КРЫШКА STAMPED 12569092. FOR 2ND DESIGN SEE 12584580.)
12593627 GASKET, ENG FRT CVR (W/ ПЕРЕДНЯЯ КРЫШКА STAMPED 12584582; FOR 1ST DESIGN SEE 12576673.) [ПРОКЛАДКА ПЕРЕДНЕЙ КРЫШКИ ДВИГАТЕЛЯ]
11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (ENG FRT CVR) [БОЛТ]
12569545 PLUG, ENG FRT CVR HOLE
12595614 PUMP, WAT (W/SEAL) (INCLS 901) (ACDelco #251-699) [НАСОС ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ]
11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (W/PMP) [БОЛТ]
12604614 PULLEY, W/PMP
24503961 БОЛТ, W/PMP PUL (M6X1.0 6G THD W/WA) (8MM SOCKET HD)
12559807 THERMOSTAT, ENG COOL (W/O GSKT) (ACDelco #131-128) [КЛАПАН РЕГУЛИРОВКИ ТЕМПЕРАТУРЫ СИСТЕМЫ ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ]
12563623 GASKET, ENG COOL THERM (ACDelco #12563623) [ПРОКЛАДКА]
12596643 ШЛАНГИ, ENG COOL THERM (ACDelco #15-80869)
11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (ENG COOL THERM HSG) [БОЛТ]
12583849 OUTLET, WAT (INCLS 382, 387) (ACDelco #15-10427)
teamcadillac.ru
11519941 БОЛТ, HFH W/SHLDR, M6X1X22, 13.8 THD, 15 OD, 9.8, 6280M, MACH, DOG-PT (SOL VLV)
12563877 SEAL, W/PMP CVR (O RING) (ЧАСТЬ OF 360) [КОЛЬЦЕВОЕ УПЛОТНЕНИЕ ВОДЯННОГО НАСОСА]
(6E00-010) - 2004-2005 E КРЕПЛЕНИЕ ДВИГАТЕЛЯ TO ТРАНСМИССИЯ (LH2/4.6A)
12580474 FLYКОЛЕСО, ENG (INCLS 10) [МАХОВИК ДВИГАТЕЛЯ]
25771275 BRACKET, ENG WRG HARN (USED IN GENERATOR PACKAGE)
11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50]
24205900 COVER, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП]
teamcadillac.ru
11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15)
11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (TRANS CONV CVR) (ACDelco #11517518) [БОЛТ]
12568123 COVER, TRANS CONV
01647172 SPACER, FLYWHL (ЧАСТЬ OF 1)
(6E00-011) - 2004-2005 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 4 МАСЛЯНЫЙ НАСОС,МАСЛЯНЫЙ ПОДДОН & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7)
22531637 PIN, МАСЛЯНЫЙ ПОДДОН LOC (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ]
12584299 GUIDE, TMG CHAIN (ЧАСТЬ OF 463)
teamcadillac.ru
12610145 PAN, OIL (INCLS 404-406, 410-413, 420, 422, 424, 712, 713)
12575373 PIPE, O/PMP SUC (ЧАСТЬ OF 400)
12566837 SEAL, O/PMP SUC PIPE (ЧАСТЬ OF 400) [УПЛОТНЕНИЕ]
12566872 DEFLECTOR, CR/SHF OIL (ЧАСТЬ OF 400)
11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (ЧАСТЬ OF 400) [БОЛТ]
11562588 PLUG, МАСЛЯНЫЙ ПОДДОН DRN (ЧАСТЬ OF 400) (INCLS 413) (W/ SEAL) (EXC MAGNET) [ЗАГЛУШКА МАСЛЯНОГО ПОДДОНА]
11588364 БОЛТ, HFH, M8X1.25X34, 25 THD, 18 O.D., 9.8, GMW3359 (ЧАСТЬ OF 400) [БОЛТ М8]
11588424 БОЛТ, HFH, M6X1X145, 18 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 400) [ШЕСТИГРАННЫЙ ВИНТ]
12595327 INDICATOR, OIL LVL (INCLS 434)
12593211 TUBE, OIL LVL IND (INCLS 432)
24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 431) (BLACK) (6.07MM ID, 1.78MM DIA)
11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (OIL LVL IND TUBE)
24504091 SEAL, OIL LVL IND (O RING) (ЧАСТЬ OF 430) (BLACK) (6.07MM ID, 1.78MM DIA)
12591607 ADAPTER, OIL FLTR (INCLS 441-443, 446-451, 456, 458, 459, 728, 729) [АДАПТЕР МАСЛЯНОГО ФИЛЬТРА]
12591604 GASKET, OIL FLTR (ЧАСТЬ OF 440) (BETWEEN OIL FILTER ADAPTER AND BLOCK) [ПРОКЛАДКА МАСЛЯНОГО ФИЛЬТРА]
11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 440)
11519174 БОЛТ, HFH, W/REDUCED BODY, M8X1.25X65, THD 22, O.D. 18, 8.8, GMW3359 (ЧАСТЬ OF 440)
25014612 VALVE, OIL FLTR BYPASS (ЧАСТЬ OF 440, 450) (W/O VAPOR SEPARATOR) (OPENING PRESSURE 21 PSI NOMINAL) (ЧАСТЬ HAS A 16.10MM MAX OD & FITS A 15.84 HOLE IN BLOCK)
11519184 БОЛТ, OIL FLTR ADAP (ЧАСТЬ OF 440) (M10X1.5X45) (0.029)
19114105 ФИЛЬТР, МАСЛЯНЫЙ (ЧАСТЬ OF 440) (ACDelco #PF2129F) (DURAPACK) (BULK PKG, QTY 12)
25177917 ФИЛЬТР, МАСЛЯНЫЙ (ЧАСТЬ OF 440) (ACDelco #PF2129) [МАСЛЯНЫЙ ФИЛЬТР ДВИГАТЕЛЯ]
12583470 CAP, OIL FLTR (ЧАСТЬ OF 440) (INCLS 446, 451, 456) [КРЫШКА]
12577653 SEAL, OIL FLTR CAP (O RING) (ЧАСТЬ OF 440, 450) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КРЫШКИ МАСЛЯНОГО ФИЛЬТРА]
12590152 PUMP, OIL (INCLS 151, 154, 464-466, 468, 470-472, 474, 475) (INCLS GUIDE, БОЛТS) [МАСЛЕННЫЙ НАСОС]
11519172 БОЛТ, HFH, 8X1.25X55, 18 OD, 22THD, 8.8, GMW3359, 6MM MATPOINT, REDUCED BODY (ЧАСТЬ OF 463)
12590119 NOZZLE, PSTN OIL (INCLS 491)
11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ЧАСТЬ OF 490)
12603780 SENSOR, ENG OIL LVL & TEMP (ЧАСТЬ OF 400) (INCLS 713) (ACDelco #213-3945)
12621659 SENSOR, ENG OIL PRESS (INCLS 729) (ЧАСТЬ OF 440) (ACDelco #12621659)
(6E00-013) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ & ЧАСТЬIAL ДВИГАТЕЛЬ (LY7/3.6-7)
teamcadillac.ru
19206165 ДВИГАТЕЛЬ, (SERV ЧАСТЬIAL) (MAY NEED TO SWAP МАСЛЯНЫЙ ПОДДОН) (REQUIRES CRANKSHAFT BALANCER WITH KEYWAY. FOR SINGLE BELT, USE 12603181. FOR DUAL BELT BALANCER USE 12603180)
(6E00-014) - 2004-2009 E КРЕПЛЕНИЕ ДВИГАТЕЛЯ TO ТРАНСМИССИЯ (LY7/3.6-7)
12572042 PLATE, A/TRNS FLEX
11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП]
teamcadillac.ru
11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (TRANS CONV CVR) [БОЛТ]
24222918 COVER, TRANS CONV
(6E00-015) - 2004-2009 E ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ-V6 (LY7/3.6-7, M82)
11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (TRANS MT) [БОЛТ, М10Х1.5Х30]
teamcadillac.ru
25756321 BRACKET, ENG MT
25971088 MOUNT, ENG [ОПОРНЫЙ УЗЕЛ ДВИГАТЕЛЯ]
25971089 MOUNT, ENG
25756322 BRACKET, ENG MT
(6E00-016) - 2004-2009 E ДВИГАТЕЛЬ-ТРАНСМИССИЯ-КРЕПЛЕНИЕ-V6 (LY7/3.6-7, MX5)
teamcadillac.ru
25756320 BRACKET, ENG MT
(6M00-066) - 2005-2006 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 4 МАСЛЯНЫЙ НАСОС, PAN & ДЕТАЛИ КОМПЛЕКТА (LH2/4.6A)
12580850 MANIFOLD, ENG OIL (INCLS 107-109) (WITHOUT МАСЛЯНЫЙ ПОДДОН BAFFLE) [КОЛЛЕКТОР МАСЛЯНЫЙ]
12567511 PAN, OIL (INCLS 401, 412, 413, 420-422, 712, 713, 715) [КАРТЕР]
12568928 GASKET, МАСЛЯНЫЙ ПОДДОН (ЧАСТЬ OF 400) [ПРОКЛАДКА]
12567529 PIPE, O/PMP SUC (INCLS 406, 407)
12573569 GASKET, O/PMP SUC PIPE (ЧАСТЬ OF 405) [ПРОКЛАДКА МАСЛЯНОГО НАСОСА]
03522382 БОЛТ, O/PMP SUC PIPE (ЧАСТЬ OF 405) (HFH, M6X1.0X28)
03542258 ГАЙКА, O/PMP SUC PIPE (HFH, M9X1) (1.430)
90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 400, 412) (18 X 2) (1.456)
11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 400)
11519173 БОЛТ, HFH, REDUCED BODY, M8X1.25X60, 22THD, 18 OD, 8.8, GMW3359 (ЧАСТЬ OF 400)
11519178 БОЛТ HFH, M8X1.25X100, 13MM SOCKET, 8.8, GMW3359 (ЧАСТЬ OF 400)
12585398 INDICATOR, OIL LVL (INCLS 434) [ЩУП УРОВНЯ МАСЛА]
12570585 TUBE, OIL LVL IND (INCLS 432) [НАПРАВЛЯЮЩАЯ ТРУБКА ЩУПА УРОВНЯ МАСЛА]
24504091 SEAL, OIL LVL IND TUBE (O RING) (ЧАСТЬ OF 431) (BLACK) (6.07MM ID, 1.78MM DIA)
11515765 БОЛТ, HFH, M10X1.5X25, 22.30 O.D., HDR PT, 10.9, 7112M (OIL LVL IND TUBE)
12598047 ADAPTER, OIL FLTR (INCLS 441, 442, 445, 446, 449, 717, 718, 728, 729)
12573045 GASKET, OIL FLTR ADAP (ЧАСТЬ OF 440) [ПРОКЛАДКА МАСЛЯНОГО ФИЛЬТРА]
teamcadillac.ru
11519173 БОЛТ, HFH, REDUCED BODY, M8X1.25X60, 22THD, 18 OD, 8.8, GMW3359 (ЧАСТЬ OF 440)
24575062 FITTING, OIL FLTR (ЧАСТЬ OF 440)
25014612 VALVE, OIL FLTR BYPASS (ЧАСТЬ OF 440) (W/O VAPOR SEPARATOR) (OPENING PRESSURE 21 PSI NOMINAL) (ЧАСТЬ HAS A 16.10MM MAX OD & FITS A 15.84 HOLE IN BLOCK)
89017342 ФИЛЬТР, МАСЛЯНЫЙ (ЧАСТЬ OF 440) (FOR NON-CANADIAN ORDERS) (ACDelco #89017342)
11519833 PLUG ROUND HD, M16X1.5X22, 20 OD, 10 THD, 5.8, 4345M, SEALANT 9985490, MACH (OIL FLTR BYPASS HOLE)
12590890 PUMP, OIL (INCLS 464-472) [МАСЛЯНЫЙ НАСОС]
11518944 SCREW, PAN HD, M6X1X25, 20.9 THD, 11 OD, 8.8, GMW3359, 6 LOBED T-30 M-POINT (ЧАСТЬ OF 463) (8.913)
11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (O/PMP) (ACDelco #11517518) [БОЛТ]
12568009 TUBE, O/PMP OTLT (INCLS 481) [ТРУБКА]
12568320 SEAT, ENG OIL MANIF CHK VLV (ЧАСТЬ OF 480) (0.724) [КОЛЬЦЕВОЕ УПЛОТНЕНИЕ]
11518944 SCREW, PAN HD, M6X1X25, 20.9 THD, 11 OD, 8.8, GMW3359, 6 LOBED T-30 M-POINT (O/PMP OTLT TUBE) (8.913)
12603787 SWITCH, ENG OIL LVL IND (ЧАСТЬ OF 400) (INCLS 713)
11517519 БОЛТ, ENG OIL LVL SEN (ЧАСТЬ OF 400) (M6X1X25, 22 THD, 14.2) (8.900)
12573744 SHIELD, ENG OIL PRESS GA SEN HT (ЧАСТЬ OF 440)
11519964 БОЛТ, HFH, M6X1X13, 6 THD, 14.2 OD, 8.8, GMW3359, MAT POINT (ЧАСТЬ OF 440)
12567911 SENSOR, ENG OIL PRESS (ЧАСТЬ OF 440) (INCLS 729) (ACDelco #213-1547) [ДАТЧИК ДАВЛЕНИЯ МАСЛА]
(6Y00-003) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ-4.6L V8 ЧАСТЬ 2 ГОЛОВКА ЦИЛИНДРОВ & ДЕТАЛИ КОМПЛЕКТА (LH2/4.6A)
03522352 PIN, CYL HD LOC (HOLLOW DOWEL, 15.675X28, CHAM BOTH ENDS, SAE 12L14, ZP)
12564273 CHAIN, SECD TMG
12559389 SHOE KIT, TMG CHAIN TENSR (INCLS 174)
12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (ЧАСТЬ OF 173) (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH)
12559390 SHOE KIT, TMG CHAIN TENSR (INCLS 184)
12553743 БОЛТ, CM/SHF INTER DRV CHAIN TENSR (ЧАСТЬ OF 183) (HFH, 8X1.25X41.8, 16.34 THD, 19.0, 12.85 BODY, 9.8, PC MACH)
12576969 VALVE, CM/SHF POSN ACTR SOL
12567414 ACTUATOR, CM/SHF POSN (EXH)
12567415 ACTUATOR, CM/SHF POSN (EXH)
12567416 ACTUATOR, CM/SHF POSN (INT) [ПРИВОДНОЙ МЕХАНИЗМ]
12567417 ACTUATOR, CM/SHF POSN (INT) [ПРИВОДНОЙ МЕХАНИЗМ]
12589229 COVER, CM/SHF (INCLS 251, 254-256, 261, 908, 909)
12591265 COVER, CM/SHF (INCLS 251, 254-256, 261, 908, 909)
teamcadillac.ru
12576394 GASKET, CM/SHF CVR (ЧАСТЬ OF 250) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ ЦИЛИНДРОВ]
12576395 GASKET, CM/SHF CVR (ЧАСТЬ OF 250) (BETWEEN HEAD AND CAM COVER) [ПРОКЛАДКА]
12576396 GASKET, CM/SHF CVR (ЧАСТЬ OF 250) (СВЕЧИ HOLES) [ПРОКЛАДКА]
12557829 БОЛТ, CM/SHF CVR (ЧАСТЬ OF 250)
12573742 INSULATOR, CM/SHF CVR БОЛТ (ЧАСТЬ OF 250)
12577268 CAP, OIL FIL (MOBIL 1, SAE 5W30, NON-VENTED, W/SEAL, W/TURNING EARS, NOT ROUND) (INCLS 259) (ACDelco #FC209)
24100002 SEAL, OIL FIL CAP (O RING) (ЧАСТЬ OF 258) (27.94MM I.D.) (SIZE #320) (1.745) [ПРОКЛАДКА]
12578248 HEAD, CYL (MCHG) (INCLS 312, 313, 315, 334-337)
12578249 HEAD, CYL (MCHG) (INCLS 312, 313, 315, 334-337)
11589058 БОЛТ, CYL HD (M11X2.0X161) [БОЛТ М11]
01647218 БОЛТ, CYL HD (QTY 3-RH, 3-LH) (M6X1.0X50, 10.9) (HFH, MACH)
11562126 PLUG, CYL HD CORE HOLE (ЧАСТЬ OF 300) (CUP, 32.03X7.88X1.27, S30400 SS PER SAE J405.) [ЗАГЛУШКА ГОЛОВКИ БЛОКА ЦИЛИНДРОВ]
01647543 PLUG, CYL HD CORE HOLE (ЧАСТЬ OF 300) (ROUND HEAD, INT HEX, W/ALUM WASH, 20X1.5X17, 12.25 THD, C1010 RQ)
11588949 PLUG, M16X1.5X14, 24 OD, SAE 1010 STL, GMW3044, W/ AL WASHER (ЧАСТЬ OF 300) [ПРОБКА ЗАМКА]
12574785 RESTRICTOR, ENG BLK OIL GAL
12578258 VALVE, EXH [КЛАПАН ВЫПУСКНОЙ]
12590223 VALVE, INT
12565203 ARM, VLV RKR [КОРОМЫСЛО КЛАПАНА ДВИГАТЕЛЯ]
24100005 ADJUSTER, HYD VLV LASH (ACDelco #24100005) [ТОЛКАТЕЛЬ КЛАПАНА ДВИГАТЕЛЯ]
12574354 SEAL, VLV STEM OIL [УПЛОТНЕНИЕ ШТОКА КЛАПАНА]
12565199 ПРУЖИНА, VLV
12580385 CAP, VLV SPR
01647209 KEY, VLV STEM
12565171 CAMSHAFT, EXH (MCHG) (INCLS 338)
12565172 CAMSHAFT, EXH (MCHG) (INCLS 338) [РАСПРЕДВАЛ В СБОРЕ]
12563833 CAMSHAFT, INL (MCHG) (INCLS 338) [РАСПРЕДВАЛ]
12565168 CAMSHAFT, INL (MCHG) (INCLS 338) [КОЛЕНВАЛ]
01647553 БОЛТ, CM/SHF BRG CAP (ЧАСТЬ OF 300) (HFH, M6X1.0X39.5)
12596360 ШЛАНГИ, CM/SHF POSN ACTR (INCLS 342, 344, 345, 735-737)
12596361 ШЛАНГИ, CM/SHF POSN ACTR (INCLS 342, 344, 345, 735-737)
12567656 GASKET, CM/SHF POSN ACTR HSG (ЧАСТЬ OF 340) (0.423) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ]
12567657 GASKET, CM/SHF POSN ACTR HSG (ЧАСТЬ OF 340) (0.423) [УПЛОТНЕНИЕ ДВИГАТЕЛЯ]
11518706 STUD-HFH, M6X1X13.4, M6X1X40, 14.2 OD, 60 TL, 10.9, GM6280M (NON HEX CHROME) (ЧАСТЬ OF 340) (8.981)
11518707 STUD, HFH, M6X1X13 / M6X1X45, 14.2 O.D., 65 TL, 9.8, GM6280M (CM/SHF POSN ACTR HSG)
11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (IGN РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ)
15326386 SENSOR, ENG COOL TEMP (2-WAY MALE) (3.682) (ACDelco #213-928) [ДАТЧИК ТЕМПЕРАТУРЫ ДВИГАТЕЛЯ]
12571533 СВЕЧИ, (ACDelco #41-986) (PLATINUM PLUG) [СВЕЧА ЗАЖИГАНИЯ]
12569160 SENSOR, CM/SHF POSN (INCLS 726) (ACDelco #213-1512) [ДАТЧИК ПОЛОЖЕНИЯ РАСПРЕДВАЛА]
01647346 БОЛТ, HFH, M6X1X17, 17THD, 14.2 O.D., 8.8, ZF (CM/SHF POSN SEN)
12567085 MAGNET, CM/SHF POSN ACTR (INCLS 737) (ЧАСТЬ OF 340) [МАГНИТ]
11518845 SCREW PAN HD, M6X1X16, 15 THD, 12 OD, 8.8, 6280M, TORX, T30, HDR PT, W/SEALANT (ЧАСТЬ OF 340)
12567421 PLUG, CM/SHF POSN ACTR BORE (ЧАСТЬ OF 340, 735)
12581176 HARNESS, ELEK ICM WRG (INCLS 772)
11519976 БОЛТ, HFLGE, M8X1.25X20, 15.6 THD, 18 O.D., 8.8, GMW3359 (ELEK ICM WRG HARN CLIP)
11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (ЧАСТЬ OF 770) [БОЛТ М8]
11517094 SCREW, M5X.8X15.6, 10.4 THD, 10.2 OD, 6202M, 7114M, TAPER-POINT (ЧАСТЬ OF 250) (ACDelco #11517094)
89017450 GASKET KIT, CYL HD (INCLS 302, 310) (INCL GASKET AND M11X2.0 БОЛТS) [ПРОКЛАДКА ДВИГАТЕЛЯ]
89017451 GASKET KIT, CYL HD (INCLS 302, 310) (INCL GASKET AND M11X2.0 БОЛТS) [ПРОКЛАДКА ДВИГАТЕЛЯ]
(GM00-387) - 2004-2009 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 1 БЛОК ЦИЛИНДРОВ И ВНУТРЕННИЕ ДЕТАЛИ (LY7/3.6-7)
12560272 БОЛТ, CR/SHF BRG CAP (M10X2X102.5, 24.5) [ВИНТ]
11518861 БОЛТ, HFH, W/REDCD BODY, M8X1.25X90, 26 THD, 18 O.D., 10.9, GM4277M (CR/SHF BRG CAP) [БОЛТ]
11609410 БОЛТ, HFH, M8X1.25X25, 10.9, GMW3179 (CR/SHF BRG CAP) (0.056) [БОЛТ]
89021297 ADHESIVE/SEALANT, THREADLOCKER HI STRENGTH 10ML ERI (CR/SHF BRG CAP) [АДГЕЗИВ]
11589000 БОЛТ, HFH, M8X1.25X50, 24 THD, 18 OD, 10.9, GMW3359, RED BODY, W/ADH (CR/SHF BRG CAP)
12557520 PLUG, ENG BLK OIL GAL (CUP-.390IN OD, .040IN THK, STEEL)
12621351 CRANKSHAFT, (USE T/W 12601937, 12603180) [КОЛЕНВАЛ]
11561583 PLUG, ENG BLK OIL GAL (M14X1.5X16, 22 OD) (0.253)
12566587 PLUG, ENG BLK OIL GAL
11561751 PLUG, CYL HD WAT JKT HOLE (M20X1.5X30.5) (1.531)
00360571 PLUG, ENG BLK CORE HOLE (CUP DIA 34.3MM)
12597210 PIN, TRANS LOC
24229149 PIN, TRANS LOC
12620955 SEAL, CR/SHF RR OIL (INCLS 134) [ПРОКЛАДКА КОЛЕНВАЛА ДВИГАТЕЛЯ]
11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 133)
12608432 ROD, CONN (INCLS 201, 202)
11519680 БОЛТ, CONN ROD (ЧАСТЬ OF 200) (M9X1X53) [БОЛТ]
12598657 BEARING KIT, CONN ROD (UPPER) [ПОДШИПНИК СКОЛЬЖЕНИЯ ШАТУНА]
12585675 PISTON, (W/PIN) (INCLS 211, 212) (.25 O.S.)
12590866 PISTON, (W/PIN) (INCLS 211, 212) (STD)
12566186 RETAINER, PSTN PIN (ЧАСТЬ OF 210)
12597654 BALANCER, CR/SHF (DUAL BELT, W/O KEYWAY)
12582652 SENSOR, CR/SHF POSN (INCLS 721, 722) (ACDelco #213-1632) [ДАТЧИК]
11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (ЧАСТЬ OF 720) [БОЛТ]
12618603 SENSOR, KNOCK (W/O LEADS) (INCLS 724) (ACDelco #213-4335) [ДАТЧИК]
11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (ЧАСТЬ OF 723)
11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (EXH MANIF H/SHLD) [БОЛТ]
12610603 BEARING KIT, CR/SHF (#1, 2, 4 STD) (INCLS 122, 123) [ПОДШИПНИК СКОЛЬЖЕНИЯ КОЛЕНВАЛА]
teamcadillac.ru
12610604 BEARING KIT, CR/SHF (#3 STD) (INCLS 123, 124) [КОМПЛЕКТ ПОДШИПНИКОВ СКОЛЬЖЕНИЯ КОЛЕНВАЛА (3ШТ)]
12608615 RING KIT, PSTN (INCLS 213-216) (STD)
(GM00-389) - 2004-2006 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 3 ПЕРЕДНЯЯ КРЫШКА И ОХЛАЖДЕНИЕ (LY7/3.6-7)
22531637 PIN, ENG FRT CVR LOC (ЧАСТЬ OF 350) (8MM DIA, 12MM LONG) (DOWEL) (0.413) [ШТИФТ]
11519176 БОЛТ, ENG FRT CVR (ЧАСТЬ OF 350) (M8X1.25X80) (4.081) [БОЛТ]
12598349 COVER, ENG FRT (W/ W/PMP) (INCLS 132, 348, 351-353, 360-362, 725-727, 734, 900-903)
12593045 SEAL, W/PMP (ЧАСТЬ OF 350) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ]
11519171 БОЛТ, ENG FRT CVR (ЧАСТЬ OF 350) (M8X1.25X50) (3.275) [БОЛТ ВЫПУСКНОГО КОЛЛЕКТОРА]
12608750 SEAL, CR/SHF FRT OIL (ЧАСТЬ OF 350) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КОЛЕНВАЛА]
12618472 PUMP, WAT (W/GSKT) (ЧАСТЬ OF 350) (INCLS 900) (ACDelco #251-724) [НАСОС]
11562426 БОЛТ, HFH, M6X1X25, 18 THD, 14.2 OD, 10.9 STL GMW3359 (ЧАСТЬ OF 350)
12576326 GASKET, W/PMP (ЧАСТЬ OF 350) (ACDelco #251-2048) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ]
12574518 PULLEY, W/PMP (ADX)
11519512 БОЛТ, HFH, W/CON SPR WA, M6X1X13.4, 8.77 THD, 12.3 O.D., 8.8, GMW3359 (W/PMP PUL)
12582472 SEAL, ENG COOL THERM (ЧАСТЬ OF 367) (ACDelco #12582472) [УПЛОТНИТЕЛЬ]
12620259 ШЛАНГИ, ENG COOL THERM (INCLS 365, 366, 369, 371, 372) (INCLS THERMOSTAT) (ACDelco #15-81651) [КОРПУС В СБОРЕ, ТЕРМОСТАТА СИСТЕМЫ ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ]
11519973 БОЛТ-HFH, M6X1X60, 18MM THD, 14.2 OD, 8.8, 3359GMW, REDUCED BODY, MAT PT. (ENG COOL THERM HSG) [БОЛТ 6Х1Х60]
11519974 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3359 (ENG COOL THERM HSG) [БОЛТ]
12584325 SEAL, ENG COOL THERM HSG (O RING) (ЧАСТЬ OF 367) [КОЛЬЦЕ-ОБРАЗНОЕ УПЛОТНЕНИЕ]
12592527 GASKET, ENG COOL THERM HSG (ЧАСТЬ OF 367) (ACDelco #12592527) [ПРОКЛАДКА ТЕРМОСТАТА]
12566429 SEAL, WAT OTLT [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ]
12584040 SEAL, CLNT OTLT (O RING) (ACDelco #15-32584) [ПРОКЛАДКА НАСОСА ОХЛАЖДАЮЩЕЙ ЖИДКОСТИ]
11519974 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3359 (WAT OTLT) [БОЛТ]
12573984 OUTLET, WAT (INCLS 905) (INCLS БОЛТS, RETAINERS, SEALS & PIPE) (ACDelco #15-10429) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ]
12592250 SENSOR, CM/SHF POSN (ЧАСТЬ OF 350) (INCLS 726, 727) (ACDelco #213-1565)
11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (ЧАСТЬ OF 350, 725) [БОЛТ]
12615613 VALVE, CM/SHF POSN ACTR SOL
11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (CM/SHF POSN ACTR SOL VLV)
12593717 SEAL, CM/SHF POSN ACTR SOL VLV (O RING) (ЧАСТЬ OF 350)
teamcadillac.ru
(GM00-393) - 2005-2006 E ДВИГАТЕЛЬ В СБОРЕ-3.6L V6 ЧАСТЬ 2 ГОЛОВКА ЦИЛИНДРОВ & ДЕТАЛИ КОМПЛЕКТА (LY7/3.6-7)
12590921 SPROCKET, CR/SHF [ЦЕПНАЯ ЗВЕЗДОЧКА]
12609262 РОЛИК НАТЯЖИТЕЛЬ, CM/SHF INTER DRV CHAIN (INCLS 153, 164) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ]
11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 152) [БОЛТ М8]
12590920 CHAIN, CM/SHF INTER DRV (PRIMARY)
12597417 GUIDE, TMG CHAIN (INCLS 157) (UPPER PRIMARY)
11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 156) [БОЛТ М8]
11588252 БОЛТ, HFH, RDUCD BDY, M6X1X70, 18 THD, 14.2 O.D., 8.8, GMW3179 CODE G (ЧАСТЬ OF 165, 166)
12589477 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 152) (PRIMARY)
12597413 SPROCKET, CM/SHF (INCLS 161) (IDLER)
12597414 SPROCKET, CM/SHF (INCLS 161) (IDLER)
12589011 CHAIN, CM/SHF INTER DRV (92 PITCH) (SECONDARY)
12597416 GUIDE, TMG CHAIN (INCLS 172) (2 КРЕПЛЕНИЕ HOLES) (SECONDARY)
11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 171) [БОЛТ М8]
teamcadillac.ru
12586960 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАТЯЖИТЕЛЬ ЦЕПИ]
11518858 БОЛТ, HFH, M8X1.25X43, 16 THD, 18 O.D., 8.8, GMW3179 (TMG CHAIN TENSR) [БОЛТ М8]
12609260 РОЛИК НАТЯЖИТЕЛЬ, TMG CHAIN (INCLS 176, 177) (SECONDARY) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ]
11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 175) [БОЛТ М8]
12589478 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 175)
12597418 GUIDE, TMG CHAIN (INCLS 182) (2 КРЕПЛЕНИЕ HOLES) (SECONDARY)
11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 181) [БОЛТ М8]
12586961 GUIDE, TMG CHAIN (SINGLE КРЕПЛЕНИЕ HOLE) (PIVOT ARM) [НАПРАВЛЯЮЩАЯ ПРИВОДНОЙ ЦЕПИ]
12609258 РОЛИК НАТЯЖИТЕЛЬ, TMG CHAIN (INCLS 186, 187) (SECONDARY) (INCLS БОЛТS, RETAINER, GSKT) [РЫЧАГ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ]
11588255 БОЛТ, HFH, REDUCED BODY, M8X1.25X45, 22 THD, 18 O.D., 8.8, 3179GMW (ЧАСТЬ OF 185) [БОЛТ М8]
12589479 GASKET, TMG CHAIN HSG (ЧАСТЬ OF 185)
12588272 ACTUATOR, CM/SHF POSN (EXHAUST)
12588273 ACTUATOR, CM/SHF POSN (INTAKE)
11588279 БОЛТ, HFH, M10X1.5X80, 26 THD, 22.3 O.D., 10.9, GM4277M (CM/SHF POSN ACTR)
12604078 COVER, CM/SHF (INCLS 251, 254-257, 260, 263)
12591200 SEAL, CM/SHF CVR (ЧАСТЬ OF 250) (*KIT1) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ]
12591201 COVER, CM/SHF (INCLS 253-257, 261)
12591203 SEAL, CM/SHF CVR (ЧАСТЬ OF 252) (*KIT1) [ПРОКЛАДКА КРЫШКИ ГОЛОВКИ БЛОКА ЦИЛИНДРОВ]
11518859 БОЛТ, HFH W/SHLDR, M6X1X35, 11.85 THD, 18 O.D., 8.8, GMW3359 (ЧАСТЬ OF 250, 252)
12566250 INSULATOR, CM/SHF CVR БОЛТ (ЧАСТЬ OF 250, 252)
12583570 CAP, OIL FIL (ROUND W/HDL) (INCLS 904) (NON VENTED) (ACDelco #FC215)
24100002 SEAL, OIL FIL TUBE (O RING) (ЧАСТЬ OF 262) (27.94MM I.D.) (SIZE #320) [ПРОКЛАДКА]
12578316 FITTING, PCV (ЧАСТЬ OF 250) (INCLS 263)
12583384 FITTING, PCV (ЧАСТЬ OF 252)
12597946 TUBE, OIL FIL (INCLS 259) [ТРУБКА МАСЛОЗАЛИВНОЙ ГОРЛОВИНЫ ГОЛОВКИ БЛОКА]
12580962 HEAD, CYL (MCHG) (INCLS 313, 318, 319, 328, 336, 337) (TO BE USED WITH 2 ДВИГАТЕЛЬ OIL MANIF CHECK VALVE ASSEMBLIES) [ГОЛОВКА БЛОКА ЦИЛИНДРОВ]
12603901 HEAD, CYL (MCHG) (INCLS 313, 318, 319, 328, 336, 337) (DOES NOT INCL ENG OIL MANIF CHECK VALVES. DLR MUST INSTL)
11518863 БОЛТ, CYL HD [БОЛТ]
11519177 БОЛТ-HEX FLANGE HD, REDUCED BODY, M8X1.25X90, 8.8, GMW3359 (CYL HD) [ШЕСТИУГОЛЬНЫЙ ШУРУП]
12565988 PLUG - M20X1.5X30.5, 8.8, GMW3044, SEALANT PER GM9985490 (ЧАСТЬ OF 300, 301)
11562127 PLUG, CYL HD OIL GAL (ЧАСТЬ OF 300, 301) (CUP-14.22 OD, 6.6 THK, 304SS)
12575354 VALVE, EXH (STD) [КЛАПАН ВЫПУСКНОЙ]
12584760 VALVE, EXH (0.075 O.S.) [КЛАПАН ВЫПУСКНОЙ]
12575351 VALVE, INT (STD) [КЛАПАН ВПУСКНОЙ]
12584763 VALVE, INT (0.075MM O.S.) (0.297) [КЛАПАН ВПУСКНОЙ]
24100294 ARM, VLV RKR [РЫЧАГ]
12565836 SEAL, VLV STEM OIL [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КЛАПАНА ДВИГАТЕЛЯ]
12575355 ПРУЖИНА, VLV [ПРУЖИНА КЛАПАНА]
12575196 RETAINER, VLV SPR [КОМПАКТ ДИСК]
12575197 KEY, VLV STEM [КЛАПАННЫЙ КЛЮЧ]
12574477 RING, CM/SHF SPKT OIL SEAL (ЧАСТЬ OF 330-333) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО РАСПРЕДВАЛА ДВИГАТЕЛЯ (2 ШТ.)]
12566670 CAMSHAFT, EXH (INCLS 329)
12566669 CAMSHAFT, INT (INCLS 329)
12566672 CAMSHAFT, EXH (INCLS 329)
12566671 CAMSHAFT, INT (INCLS 329)
11518856 HFH, M6X1X43.4, 14.8 THD, 11 O.D., 8.8, GMW3179 CODE G (ЧАСТЬ OF 300, 301) [ШЕСТИУГОЛЬНЫЙ ШУРУП]
12580965 VALVE, ENG OIL MANIF CHK [КЛАПАН]
12613057 РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ, IGN (INCLS 705) (ACDelco #12613057)
12566778 SENSOR, ENG COOL TEMP (3.682) (ACDelco #213-1581) [СЕНСОР ТЕМПЕРАТУРЫ]
12597464 СВЕЧИ, (DO NOT CHANGE СВЕЧИ GAP) (ACDelco #41-990) (PLATINUM PLUG) [СВЕЧА ЗАЖИГАНИЯ]
12625785 GASKET KIT, CYL HD (INCLS 251, 253, 302, 303) [КОМПЛЕКТ ПРОКЛАДОК ГОЛОВКИ БЛОКА ЦИЛИНДРОВ (РЕЗ-7, МЕТ-8, ПАР-2)]
teamcadillac.ru
teamcadillac.ru
25971087 MOUNT, ENG
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
25971089 MOUNT, ENG
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
12590223 VALVE, INT
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
(6D01-034) - 2004-2009 E ПОДОГРЕВАТЕЛЬ БЛОКА ДВИГАТЕЛЯ (LY7/3.6-7, 110V ПОДОГРЕВАТЕЛЬ K05)
teamcadillac.ru
15257983 CORD, ENG COOL HTR (INCLS 2)
12337820 STRAP, 15" TIE STRAP (ЧАСТЬ OF 1) (ACDelco #12337820)
12587380 ПОДОГРЕВАТЕЛЬ, ENG COOL (USE W/2 PIN ПОДОГРЕВАТЕЛЬ) [НАГРЕВАТЕЛЬ]
(6D01-044) - 2004-2009 E РАДИАТОР ASM
19129971 РАДИАТОР, (INCLS 2) (ACDelco #21659) [РАДИАТОР]
19129973 РАДИАТОР, (W/TRAILER PROVISIONS) (INCLS 2) (ACDelco #21662)
88957419 РАДИАТОР, (INCLS 2) (ACDelco #21508)
(6E01-014) - 2004-2005 E РЕШЕТКА РАДИАТОРА
15284129 MOLDING, КАПОТ FRT (INCLS 2)
11519026 CLIP-U, 13X15X12, 1.5 PNL, 1050, 6280M (ЧАСТЬ OF 1) [ФИКСАТОР МОЛДИНГА КАПОТА]
25735038 BUMPER, КАПОТ STOP (ЧАСТЬ OF 6) (ATTACHED TO РАДИАТОР GRILLE) [ВТУЛКА БАМПЕРА]
21030249 RETAINER, EXPAN, 21 LG, 20. OD, 8.0 HOLE, 3.0-5.0 PNL, NYLON 6/6, BLK (ЧАСТЬ OF 6) (8.950) (PUSH IN) [ПИСТОН КРЕПЛЕНИЯ КОЖУХА РАДИАТОРА(ПЛАСТИК)]
teamcadillac.ru
25763160 GRILLE, RAD (INCLS 4, 5, 7-9) [РЕШЕТКА РАДИАТОРА]
25765149 EMBLEM, RAD GRL (ЧАСТЬ OF 6) (CHROME) ("CREST") [ЭМБЛЕМА]
25765150 EMBLEM, RAD GRL (ЧАСТЬ OF 6) ("WREATH") [ЭМБЛЕМА]
(6E01-015) - 2004-2009 E НАТЯЖИТЕЛЬ РЕМНЯ/ACCESSORY DRIVE (LH2/4.6A)
12593189 BELT, W/PMP & КОНДИЦИОНЕР CMPR & P/S PUMP [РЕМЕНЬ ДВИГАТЕЛЯ]
12578062 BELT, GEN (CODE WCN) [РЕМЕНЬ]
11518636 БОЛТ, HFH, M10X1.5X90, 25.9 THD, 22.3 OD, 10.9, GMW3359, 7.5 MAT-PT (ЧАСТЬ OF 4) [БОЛТ М10]
12568172 РОЛИК НАТЯЖИТЕЛЬ, DRV BELT (INCLS 3) (SMOOTH PULLEY) (USE T/W БОЛТ PN 11518636) [ШКИВ НАТЯЖИТЕЛЯ РЕМНЯ ГРМ]
teamcadillac.ru
11518636 БОЛТ, HFH, M10X1.5X90, 25.9 THD, 22.3 OD, 10.9, GMW3359, 7.5 MAT-PT (ЧАСТЬ OF 6) [БОЛТ М10]
12598023 РОЛИК НАТЯЖИТЕЛЬ, DRV BELT (INCLS 5) (RIBBED PULLEY) [МЕХАНИЗМ НАТЯЖЕНИЯ]
12604688 PULLEY, BELT IDLER (INCLS 7) (ACDelco #15-40051)
(6E01-016) - 2004-2006 E ШЛАНГИ И ТРУБКИ/РАДИАТОР (LH2/4.6A, EXC V92)
88956903 HOSE, RAD SURGE TK INL (INCLS 2) [ТРУБКА]
11570614 CЛАМПА-ПРУЖИНАBAND, 15 NOMINAL DIA, 15 THK, STL, ROBO (ЧАСТЬ OF 1)
11514517 ГАЙКА, HEX, W/CON SPR WA, M6X1, 5.7THK, 18 O.D., 9, 7111M (RAD SURGE TK) [ГАЙКА М6]
15075118 CAP, RAD SURGE TK (ЧАСТЬ OF 7) (15 PSI DUAL O-RING) (ENGLISH/FRENCH LABEL) (ACDelco #RC98) [КРЫШКА БАЧКА РАДИАТОРА]
11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (RAD SURGE TK) (ACDelco #11517518) [БОЛТ]
25757865 HOSE, RAD SURGE TK OVFL (ЧАСТЬ OF 7)
25767641 TANK, RAD SURGE (INCLS 4, 6) (INCLS LOW COOLANT SWITCH) (ACDelco #25767641) [БАЧОК В СБОРЕ]
89023438 HOSE, RAD INL (INCLS 9) [ШЛАНГ]
11516233 CЛАМПА-ПРУЖИНАBAND, TYPE A, 15 WID, 40 HOSE OD, 6150M, 7111M, MM (ЧАСТЬ OF 8) [ХОМУТ ШЛАНГА РАДИАТОРА]
25752529 BRACKET, RAD OTLT HOSE
11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (RAD OTLT HOSE BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16]
11516233 CЛАМПА-ПРУЖИНАBAND, TYPE A, 15 WID, 40 HOSE OD, 6150M, 7111M, MM (ЧАСТЬ OF 13) [ХОМУТ ШЛАНГА РАДИАТОРА]
89023433 HOSE, RAD OTLT (INCLS 12)
teamcadillac.ru
88956890 HOSE, RAD SURGE TK OTLT (INCLS 15) (8.846)
11518516 CЛАМПА, RAD SURGE TK ENG HOSE (ЧАСТЬ OF 14) (27MM) (BLACK & YELLOW T-CLIP) [ЗАЖИМ]
03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (RAD SURGE TK OTLT HOSE CLIP BRKT)
(6E01-017) - 2004-2006 E ШЛАНГИ И ТРУБКИ/РАДИАТОР (LH2/4.6A, V92)
teamcadillac.ru
89023434 HOSE, RAD INL (INCLS 9) [ТРУБКА]
15261734 BRACKET, RAD OTLT HOSE
89023436 HOSE, RAD OTLT (INCLS 12, 23)
11517136 CЛАМПА, HOSE SPR, 27 NOM, 25.2 MIN-28.9 MAX, 15MM WIDE, BLACK (ЧАСТЬ OF 20)
25746579 PUMP, AUX WAT (INCLS 16-18) (ACDelco #251-683)
88958083 HOSE, AUX W/PMP OTLT (ЧАСТЬ OF 15) (INCLS 18)
03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (AUX W/PMP)
88956890 HOSE, RAD SURGE TK OTLT (INCLS 14) (8.846)
11570614 CЛАМПА-ПРУЖИНАBAND, 15 NOMINAL DIA, 15 THK, STL, ROBO (ЧАСТЬ OF 13)
(6E01-018) - 2004-2006 E ВЕНТИЛЯТОР ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ-ELECTRIC PUSHER(V92)
89022529 BLADE, FAN (INCLS 2) (ACDelco #15-80710) [КРЫЛЬЧАТКА ВЕНТИЛЯТОРА]
89022527 SHROUD, ENG COOL FAN (INCLS 4) (ELECTRIC PUSH) [ОБТЕКАТЕЛЬ РАДИАТОРА]
89022526 MOTOR, ENG COOL FAN (ELECTRIC PUSH) (ACDelco #15-80542) [ЭЛЕКТРОДВИГАТЕЛЬ ВЕНТИЛЯТОРА 90 ВТ]
89022525 MOTOR, ENG COOL FAN (ELECTRIC PUSH) (ACDelco #15-80541) [ЭЛЕКТРОДВИГАТЕЛЬ ВЕНТИЛЯТОРА 90 ВТ]
89022544 БОЛТ KIT, ENG COOL FAN MOT [КОМПЛЕКТ БОЛТОВ ОБЛИЦОВКИ РАДИАТОРА (2 ШТ)]
89022528 BLADE, FAN (INCLS 2) (ACDelco #15-80709) [КРЫЛЬЧАТКА ВЕНТИЛЯТОРА]
(6E01-022) - 2004-2008 E РАДИАТОР КРЕПЛЕНИЕ & ДЕТАЛИ КОМПЛЕКТА
25718629 BRACKET, RAD UPR (INCLS 3)
25729351 BRACKET, RAD UPR (INCLS 3)
11517484 БОЛТ-HEX, M6X1X20, 9 THD, 17 OD, 9.8, 6280M, MACH, P-PT (RAD UPR MT BRKT)
11519444 PUSH-PIN, 10.0 HEADX26.0, 10.0 HOLE, PNL THK 6.2-8.71, NY 6.6 (RAD AIR LWR BFL (PUSH IN)) [ФИКСАТОР ПОДКРЫЛКА]
25802220 DEFLECTOR, FRT AIR (INCLS 18) [ОБТЕКАТЕЛЬ РАДИАТОРА]
teamcadillac.ru
11570323 БОЛТ, ENG COOL FAN SHRD (M6X1X18, 13 THD)
19130179 SHROUD, ENG COOL FAN (MECHANICAL PULL) [КОЖУХ ВЕНТИЛЯТОРА РАДИАТОРА]
89022523 SHROUD, ENG COOL FAN (MECHANICAL PULL) [ОБТЕКАТЕЛЬ РАДИАТОРА]
89023441 SEAL, RAD LH SI (INCLS 8) [ОПОРА РАДИАТОРА]
15932850 INSULATOR, RAD LWR [ДЕМПФЕР РАДИАТОРА]
11561026 БОЛТ-HFH, M6X1X25, 22 THD, 14.2 OD, 9.8, GMW3200, MACH, HDR-PT (КОНДИЦИОНЕР CNDSR)
19130354 CONDENSER, КОНДИЦИОНЕР (ACDelco #15-63540)
19130355 CONDENSER, КОНДИЦИОНЕР (ACDelco #15-63541)
25994576 BAR, FRT BPR IMP (СМ. ГРУППУ 07.000 "БАМПЕР ПЕРЕДНИЙ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [БАЛКА ПАНЕЛИ БАМПЕРА]
89023440 SEAL, RAD AIR SI (INCLS 8)
88957418 SEAL, RAD UPR
15932856 SHROUD, ENG COOL FAN (СМ. ГРУППУ 01.000 "ВЕНТИЛЯТОР ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ОБТЕКАТЕЛЬ РАДИАТОРА]
15248340 SEAL, RAD AIR LWR (ЧАСТЬ OF 5)
(6E01-023) - 2004-2009 E НАТЯЖИТЕЛЬ РЕМНЯ/ACCESSORY DRIVE (LY7/3.6-7)
12577655 РОЛИК НАТЯЖИТЕЛЬ, КОНДИЦИОНЕР CMPR & P/S PMP BELT (9.180) [НАТЯЖИТЕЛЬ РЕМНЯ]
12578000 BELT, КОНДИЦИОНЕР CMPR & P/S PUMP [НАСОС]
teamcadillac.ru
12621991 BELT, W/PMP & GEN [РЕМЕНЬ ГЕНЕРАТОРА L=120 СМ]
12577652 РОЛИК НАТЯЖИТЕЛЬ, W/PMP & GEN BELT [НАТЯЖИТЕЛЬ РЕМНЯ]
(6E01-024) - 2004-2009 E ПОДОГРЕВАТЕЛЬ БЛОКА ДВИГАТЕЛЯ (LH2/4.6A, 110V ПОДОГРЕВАТЕЛЬ K05)
15269262 CORD, ENG COOL HTR (TEMRO DIV)
(6E01-025) - 2004-2009 E ПОДОГРЕВАТЕЛЬ БЛОКА ДВИГАТЕЛЯ (LH2/4.6A, 220V ПОДОГРЕВАТЕЛЬ KA3)
25772264 CORD, ENG COOL HTR
12587379 ПОДОГРЕВАТЕЛЬ, ENG COOL
(6E01-026) - 2004-2006 E ШЛАНГИ И ТРУБКИ/РАДИАТОР (LY7/3.6-7)
88956900 HOSE, RAD SURGE TK OTLT (INCLS 2)
11517136 CЛАМПА, HOSE SPR, 27 NOM, 25.2 MIN-28.9 MAX, 15MM WIDE, BLACK (ЧАСТЬ OF 1)
11518624 БОЛТ, HFH, M10X1.5X30.4, 22.5 THD, 22.3 O.D., 10.9, GMW3359 (RAD SURGE TK ENG PIPE CLIP)
25757865 HOSE, RAD SURGE TK OVFL (ЧАСТЬ OF 6)
15075118 CAP, RAD SURGE TK (ЧАСТЬ OF 6) (15 PSI DUAL O-RING) (ENGLISH/FRENCH LABEL) (ACDelco #RC98) [КРЫШКА БАЧКА РАДИАТОРА]
25767641 TANK, RAD SURGE (INCLS 4, 5) (INCLS LOW COOLANT SWITCH) (ACDelco #25767641) [БАЧОК В СБОРЕ]
11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (RAD SURGE TK) [БОЛТ М6]
11570614 CЛАМПА-ПРУЖИНАBAND, 15 NOMINAL DIA, 15 THK, STL, ROBO (ЧАСТЬ OF 10)
88958088 HOSE, RAD SURGE TK INL (INCLS 9)
11516233 CЛАМПА-ПРУЖИНАBAND, TYPE A, 15 WID, 40 HOSE OD, 6150M, 7111M, MM (ЧАСТЬ OF 12) [ХОМУТ ШЛАНГА РАДИАТОРА]
89023435 HOSE, RAD INL (INCLS 11)
teamcadillac.ru
11516233 CЛАМПА-ПРУЖИНАBAND, TYPE A, 15 WID, 40 HOSE OD, 6150M, 7111M, MM (ЧАСТЬ OF 14) [ХОМУТ ШЛАНГА РАДИАТОРА]
89023445 HOSE, RAD OTLT (INCLS 13)
12603912 PIPE, RAD OTLT (INCLS 16) (WHEN USED IN PLACE OF 12587536 USE T/W РАДИАТОР OUTLET HOSE 19129967)
12623519 SEAL, RAD OTLT PIPE (O RING) (ЧАСТЬ OF 15)
11519977 БОЛТ- HFH, M8X1.25X25, 16 THD, 18 OD, 8.8, GMW3359, MAT-PT. (RAD OTLT PIPE)
11518624 БОЛТ, HFH, M10X1.5X30.4, 22.5 THD, 22.3 O.D., 10.9, GMW3359 (RAD OTLT PIPE)
25740076 BRACKET, RAD OTLT HOSE
(6E01-027) - 2004-2006 E ВЕНТИЛЯТОР ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ (EXC (V92))
25767914 FAN, ENG COOL (7 BLADE FAN FOR 160W MOTOR) (ACDelco #15-80192)
teamcadillac.ru
15932856 SHROUD, ENG COOL FAN (INCLS 4) [ОБТЕКАТЕЛЬ РАДИАТОРА]
88957423 MOTOR, ENG COOL FAN (INCLS 2, 8) (160W) (ACDelco #15-80516) [ЭЛЕКТРОДВИГАТЕЛЬ ВЕНТИЛЯТОРА 90 ВТ]
88957422 MOTOR, ENG COOL FAN (INCLS 2, 8) (160W) (ACDelco #15-80515) [ЭЛЕКТРОДВИГАТЕЛЬ ВЕНТИЛЯТОРА 90 ВТ]
25767915 FAN, ENG COOL (5 BLADES FOR 160W MOT) (ACDelco #15-80193)
(6M01-035) - 2004-2009 E ВЕНТИЛЯТОР ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ-ДВИГАТЕЛЬ MOUNTED (LH2/4.6A, V92)
11519170 БОЛТ-HFH, M8X1.25X45, 22 THD, 18 OD, 8.8, 3359GMW, REDUCED BODY. (ENG COOL FAN BRKT)
12597700 BRACKET, ENG COOL FAN (INCLS 7)
11516869 БОЛТ, HEX W/CON WA, M10X1.5X18, 13THD, 20 O.D., 9.8, GM6174M (FAN BLADE) (*KIT1)
12589532 STUD, AUX ENG CLG FAN BRKT
12586654 INSULATOR, ENG COOL FAN (ЧАСТЬ OF 2)
10382029 FAN, ENG COOL (INCLS 3-5) (1.050) (ACDelco #15-4972) [ЭЛЕКТРОМАГНИТНАЯ МУФТА ВЕНТИЛЯТОРА СИСТЕМЫ ОХЛАЖДЕНИЯ]
(6M01-036) - 2004-2006 E ВЕНТИЛЯТОР ОХЛАЖДЕНИЯ ДВИГАТЕЛЯ-ДВИГАТЕЛЬ MOUNTED (LY7/3.6-7, V92)
teamcadillac.ru
11518628 БОЛТ, HVY HEX ACORN FLG HD, M10X1.5X50, GMW25M (10.9) STL, GMW3358 (AUX ENG COOL FAN BRKT)
12586654 BUSHING, ENG CLG FAN BLADE (*KIT1) (1.055)
11516869 БОЛТ, HEX W/CON WA, M10X1.5X18, 13THD, 20 O.D., 9.8, GM6174M (FAN BLADE CLU)
10382026 FAN, ENG COOL (INCLS 8) (INCLS СЦЕПЛЕНИЕ) (ACDelco #15-80877)
11518633 БОЛТ, HFH, M10X1.5X75, 26 THD, 22.3 OD, 10.9, GMW3359, MAT- POINT. (AUX ENG COOL FAN BRKT) [БОЛТ М10]
12593813 ADAPTER, FAN BLADE CLU (INCLS 2-4) (1.055)
(6M01-037) - 2005-2006 E ПОДОГРЕВАТЕЛЬ БЛОКА ДВИГАТЕЛЯ (LY7/3.6-7, 220V ПОДОГРЕВАТЕЛЬ KA3)
25772574 CORD, ENG COOL HTR [КАБЕЛЬ ПИТАНИЯ СИСТЕМЫ ПОДОГРЕВА ДВС]
teamcadillac.ru
12588204 ПОДОГРЕВАТЕЛЬ, ENG COOL
(6D02-025) - 2004-2009 E КРЕПЛЕНИЕ ГЕНЕРАТОРА (LY7/3.6-7)
12597648 BRACKET, GEN & DRV BELT TENSR (2.277)
teamcadillac.ru
11518628 БОЛТ, HVY HEX ACORN FLG HD, M10X1.5X50, GMW25M (10.9) STL, GMW3358 (GEN BRKT)
11518636 БОЛТ, HFH, M10X1.5X90, 25.9 THD, 22.3 OD, 10.9, GMW3359, 7.5 MAT-PT (GEN BRKT) [БОЛТ М10]
11519176 БОЛТ, GEN BRKT (M8X1.25X80) (4.081) [БОЛТ]
25751146 GENERATOR, (ACDelco #25751146) [ГЕНЕРАТОР 150 А]
11518628 БОЛТ, HVY HEX ACORN FLG HD, M10X1.5X50, GMW25M (10.9) STL, GMW3358 (GEN)
11518633 БОЛТ, HFH, M10X1.5X75, 26 THD, 22.3 OD, 10.9, GMW3359, MAT- POINT. (GEN) [БОЛТ М10]
(6D02-035) - 2004-2009 E РЕЛЕ/BODY COMPARTMENT
88956531 COVER, BODY & I/P WRG HARN J/BLK (UPPER COVER FOR THE RIGHT ЗАДНИЙ)
12077863 BREAKER, CIRCUIT, 30 AMP, GREEN (ЧАСТЬ OF 10)
15319477 FUSE, 30AMP, PINK, J-CASE, FEMALE, REGULAR (ЧАСТЬ OF 10) [ПРЕДОХРАНИТЕЛЬ 30А]
15319478 FUSE, 40AMP, GREEN, J-CASE, FEMALE (ЧАСТЬ OF 10) (ACDelco #15319478) [ПРЕДОХРАНИТЕЛЬ 40А]
12092079 FUSE, 10A, MINI, RED (ЧАСТЬ OF 10)
88909754 FUSE, 15A, MINI, BLUE (ЧАСТЬ OF 10) (ACDelco #ATM15-25) [ПРЕДОХРАНИТЕЛЬ 15 А]
88953222 RELAY, INTR LP (ЧАСТЬ OF 10) (GRAY) (20AMP) (4 TERMINAL) (LOW-PROFILE MICRO 280) (2.485) (ACDelco #D1755A) [РЕЛЕ]
19116060 PULLER, FUSE (ЧАСТЬ OF 10)
21997408 RELAY, ACSRY TIME DELAY CUTOFF (ЧАСТЬ OF 10) (5-TERMINAL) (SPDT, 280 MINI, HI/LOW, BLACK) (1.055) (ACDelco #15-81106)
88956532 COVER, BODY & I/P WRG HARN J/BLK (UPPER COVER FOR THE LEFT ЗАДНИЙ)
89046748 BLOCK, BODY WRG HARN JUNC (ЧАСТЬ OF 10) (75-WAY FEMALE) (W/O LEADS) (BELOW LH ЗАДНИЙ SEAT)
teamcadillac.ru
89047326 COVER, PWR DISTR FUSE BLK (ЧАСТЬ OF 10)
89047327 COVER, PWR DISTR FUSE BLK (ЧАСТЬ OF 10)
89046747 BLOCK, BODY WRG HARN JUNC (ЧАСТЬ OF 10) (75-WAY FEMALE) (W/O LEADS) (BELOW RH ЗАДНИЙ SEAT)
(6E02-022) - 2004-2009 E ФАРООМЫВАТЕЛЬ (CE4)
teamcadillac.ru
25890367 HOSE, HDLP WA
12335720 COVER, HDLP WA NOZ
12335721 COVER, HDLP WA NOZ
25767592 NOZZLE, HDLP WA [ФОРСУНКА ФАРООМЫВАТЕЛЯ]
25767593 NOZZLE, HDLP WA [ФОРСУНКА СТЕКЛООМЫВАТЕЛЯ]
88958121 PUMP, HDLP WA (LOCATED IN WSW TANK) (ACDelco #88958121) [НАСОС СТЕКЛООМЫВАТЕЛЯ]
88958122 SEAL, HDLP WA PUMP
(6E02-023) - 2004-2009 E КРЕПЛЕНИЕ ГЕНЕРАТОРА (LH2/4.6A)
teamcadillac.ru
12565095 BRACKET, GEN
11515767 БОЛТ, HFH, M10X1.5X35, 32THD, 22.3 O.D., MACH, 10.9, 7114M (GEN BRKT) (T/W 12345493) [БОЛТ]
25756440 GENERATOR, (ACDelco #25756440) [ГЕНЕРАТОР В СБОРЕ]
11516360 БОЛТ, HFH M10X1.2X90, 9.8, 7114M, 22.3 OD HDR PT (GEN)
(6E02-024) - 2004-2005 E КРЕПЛЕНИЕ АККУМУЛЯТОРА И КАБЕЛИ (LH2/4.6A)
25747792 SHIELD, BAT HT (INSTALLED ON RH SIDE OF CAR)
11509853 БОЛТ, HEX W/CON WA, M8X1.25X45, 24 O.D., HDR PT, 9.8, PS (BAT HOLDN RET) [БОЛТ]
25558374 RETAINER, BAT HOLDN (CENTER SLOT) [ФИКСАТОР АККУМУЛЯТОРНОЙ БАТТАРЕИ]
teamcadillac.ru
88901964 АККУМУЛЯТОР, (CCA 650) (SIDE TERM) (260X178X168) (US DEALERS CONTACT ACDELCO WD FOR ORDERING & PRICING INFO) (ACDelco #101-6YR) (PROFESSIONAL - 6 YR)
15204281 LABEL, BAT WRNG (INCLUDES SYMBOLS ONLY)
11518646 БОЛТ, HEX HD, W/CON WA, M6X1X30, 24.33THD, 17 OD, 9.8, 6138M, BLK (BAT TRAY)
15812692 TRAY, BAT (INCLS 8)
11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (ЧАСТЬ OF 7) [ШАЙБА]
10369851 CABLE, BAT POS (INCLS 21) (ACDelco #10369851)
21021808 ГАЙКА, STRTR SOL BAT TERM (LARGER) (M8X1.25X6, BRASS) (2.343) [ГАЙКА М8]
11504568 ГАЙКА, HEX M5X0.8 PREV TORQ INSERT 9 ZC (STRTR SOL CBL)
11517070 БОЛТ, HVY HFH, M10X1.5X20 (BAT CBL TERM)
11515535 ГАЙКА, BAT WIRE (2.559)
15209171 CABLE, BAT NEG (INCLS 20) (ACDelco #15209171)
15695050 БОЛТ, BAT NEG CBL GND (SHOCK TOWER GRND) (M8 X 1.25 X 25) (HEX БОЛТ W/WASHER) (4.686) [БОЛТ КРЕПЛЕНИЯ ГЛУШИТЕЛЯ, М8Х1.25Х25]
11517031 ГАЙКА, HFH, M8X1.25, 9.4THK, 17.4 O.D., 10, TIN ZN (BAT POS CBL)
12160209 COVER, BAT NEG CBL TERM (ЧАСТЬ OF 17) (BLACK VINYL) (SURROUNDS CABLE END AT BATT SIDE TERM)
12010050 COVER, BAT POS CBL БОЛТ (ЧАСТЬ OF 10) (RED) (HAS SLOTTED HOLE) (SNAPS ON TO АККУМУЛЯТОР БОЛТ)
(6E02-025) - 2004-2009 E ЖГУТЫ ПРОВОДОВ/ПЕРЕДНИЕ ФАРЫ
15141492 HARNESS, FWD LP WRG (INCLS 2, 3)
15141494 HARNESS, FWD LP WRG (INCLS 2, 3)
15141495 HARNESS, FWD LP WRG (INCLS 2, 3)
15141496 HARNESS, FWD LP WRG (INCLS 2, 3)
15141497 HARNESS, FWD LP WRG (INCLS 2, 3)
15141499 HARNESS, FWD LP WRG (INCLS 2, 3)
15141500 HARNESS, FWD LP WRG (INCLS 2, 3) [К-Т ПРОВОДОВ ПЕРЕДНИХ ФАР]
15141501 HARNESS, FWD LP WRG (INCLS 2, 3)
15141502 HARNESS, FWD LP WRG (INCLS 2, 3)
15141503 HARNESS, FWD LP WRG (INCLS 2, 3)
teamcadillac.ru
25747284 HARNESS, S/LP WRG
(6E02-026) - 2004-2009 E ЖГУТЫ ПРОВОДОВ/ДВИГАТЕЛЬ (LH2/4.6A)
teamcadillac.ru
15241455 HARNESS, ENG WRG
19115853 HARNESS, ENG WRG
19115855 HARNESS, ENG WRG
19115856 HARNESS, ENG WRG
11517070 БОЛТ, HVY HFH, M10X1.5X20 (ENG WRG HARN GND)
11519861 БОЛТ, HEX W/FL WA, M10X1.5X30, 19 THD, 20 OD, 9.8, 6280M, MACH, MAT-PT (ENG WRG HARN GRD) [БОЛТ М10]
25773136 BRACKET, ENG WRG HARN (CHANNEL)
11517070 БОЛТ, HVY HFH, M10X1.5X20 (ENG WRG HARN SHLD)
(6E02-027) - 2004-2009 E ЖГУТЫ ПРОВОДОВ/ПРИБОРНАЯ ПАНЕЛЬ
15209203 HARNESS, I/P WRG
19115879 HARNESS, I/P WRG
19115880 HARNESS, I/P WRG
19115881 HARNESS, I/P WRG
19115882 HARNESS, I/P WRG
19115883 HARNESS, I/P WRG
19115884 HARNESS, I/P WRG
teamcadillac.ru
11516630 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (I/P WRG HARN)
(6E02-028) - 2004-2006 E РЕЛЕ & МОДУЛЬS/ДВИГАТЕЛЬНЫЙ ОТСЕК
15233126 COVER, MULTIUSE RLY & FUSE (USED ON CARS BLT W/BLOCKS 15870409, 15224195-95 & 25771220; 2ND DES 15869080) [КРЫШКА]
15869080 COVER, MULTIUSE RLY & FUSE (USED ON CARS BUILT W/BLOCKS 15869077-79; 1ST DES SEE 15233126)
21997408 RELAY, FAN CONT (ЧАСТЬ OF 14) (5-TERMINAL) (SPDT, 280 MINI, HI/LOW, BLACK) (ACDelco #15-81106)
15319477 FUSE, 30AMP, PINK, J-CASE, FEMALE, REGULAR (ЧАСТЬ OF 14) [ПРЕДОХРАНИТЕЛЬ 30А]
15319478 FUSE, 40AMP, GREEN, J-CASE, FEMALE (ЧАСТЬ OF 14) (ACDelco #15319478) [ПРЕДОХРАНИТЕЛЬ 40А]
15319479 FUSE, 50 AMP, RED, J-CASE, FEMALE, REGULAR BLOW (ЧАСТЬ OF 14)
15319480 FUSE, MAXI 60 A (ЧАСТЬ OF 14) (YELLOW) (J-CASE, FEMALE)
19116060 PULLER, FUSE (ЧАСТЬ OF 14)
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (MULTIUSE RLY & FUSE BRKT) [ГАЙКА М6]
25730750 BRACKET, MULTIUSE RLY & FUSE [ОПОРА ТОКОРАСПРЕДЕЛИТЕЛЬНОЙ КОРОБКИ]
11518094 БОЛТ-HES W/FL WA, M6X1X21, 11.75 THD, 24 OD, 9.8, 7114M, MACH, DOG-PT (MULTIUSE RLY & FUSE BRKT)
11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (MULTIUSE RLY & FUSE BRKT) [БОЛТ М6]
15870408 BLOCK, ENG WRG HARN JUNC (INCLS 3-6, 15-17)
15870409 BLOCK, ENG WRG HARN JUNC (INCLS 3-6, 15-17)
15870410 BLOCK, ENG WRG HARN JUNC (INCLS 3-6, 15-17)
12092075 FUSE, MINI (30A) (GREEN) (ЧАСТЬ OF 14) (ACDelco #12092075)
12092079 FUSE, 10A, MINI, RED (ЧАСТЬ OF 14)
12092080 FUSE, 7.5A, MINI, BROWN (ЧАСТЬ OF 14) [КОМПЛЕКТ ПРЕДОХРАНИТЕЛЕЙ 7.5 А (5 ШТ)]
88909754 FUSE, 15A, MINI, BLUE (ЧАСТЬ OF 14) (ACDelco #ATM15-25) [ПРЕДОХРАНИТЕЛЬ 15 А]
88909755 FUSE, 20A, MINI, YELLOW (ЧАСТЬ OF 14) (ACDelco #ATM20-25) [ПРЕДОХРАНИТЕЛЬ 20 А]
12193606 RELAY, HDLP LOW BEAM (ЧАСТЬ OF 14) (BLUE) (4-TERMINAL) (SPST 280 MINI) (4.720) (ACDelco #12193606)
88953222 RELAY, FOG LP (ЧАСТЬ OF 14) (GRAY) (20AMP) (4 TERMINAL) (LOW-PROFILE MICRO 280) (ACDelco #D1755A) [РЕЛЕ]
88953228 RELAY, HDLP WA PUMP (ЧАСТЬ OF 14) (2.485) (ACDelco #D1756A) [РЕЛЕ]
teamcadillac.ru
88953222 RELAY, ECM (ЧАСТЬ OF 14) (GRAY) (20AMP) (4 TERMINAL) (LOW-PROFILE MICRO 280) (2.485) (ACDelco #D1755A) [РЕЛЕ]
(6E02-029) - 2004-2009 E ДАТЧИКИ ПАРКОВКИ
15210240 МОДУЛЬ, RR OBJECT ALARM [МОДУЛЬ В СБОРЕ]
10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (RR OBJECT ALARM MDL) [ПИСТОН КРЕПЛЕНИЯ ОБЛИЦОВКИ БАМПЕРА (NYLON)]
25770821 HARNESS, RR OBJECT SEN WRG [ПРОВОДКА ДАТЧИКА ЗВУКОВОЙ СИГНАЛИЗАЦИИ КОНТРОЛЯ ПАРКОВКИ]
89047028 SENSOR KIT, RR OBJECT (INCLS 6-9) (CONSIST OF BEZEL RETAINERS, RING & SENSOR) (7.831) [ДАТЧИК ЗВУКОВОЙ СИГНАЛИЗАЦИИ КОНТРОЛЯ ПАРКОВКИ]
teamcadillac.ru
(6E02-030) - 2004-2009 E КЛЮЧ-ЦИЛИНДР-ЗАЖИГАНИЕ
25756071 TUMBLER, IGN LK CYL (ЧАСТЬ OF 4) (#5) (W/O WINGED BEZEL) (LARGE HEADED KEYS) (BRANDED) [ТУМБЛЕР]
25756072 TUMBLER, IGN LK CYL (ЧАСТЬ OF 4) (#4) (W/O WINGED BEZEL) (LARGE HEADED KEYS) (BRANDED) [ТУМБЛЕР]
25756073 TUMBLER, IGN LK CYL (ЧАСТЬ OF 4) (#3) (W/O WINGED BEZEL) (LARGE HEADED KEYS) (BRANDED) [КОМПЛЕКТ ЛИЧИНОК ЦИЛИНДРА ЗАМКА ЗАЖИГАНИЯ (4 ШТ)]
25756074 TUMBLER, IGN LK CYL (ЧАСТЬ OF 4) (#2) (W/O WINGED BEZEL) (LARGE HEADED KEYS) (BRANDED) [К-Т НАБОРНЫХ ПЛАСТИН ЦИЛИНДРА ЗАМКА ДВЕРИ (4 ШТ.)]
25756075 TUMBLER, IGN LK CYL (ЧАСТЬ OF 4) (#1) (W/O WINGED BEZEL) (LARGE HEADED KEYS) (BRANDED) [КОМПЛЕКТ НАБОРНЫХ ПЛАСТИН ЦИЛИНДРА ЗАМКА ЗАЖИГАНИЯ (4 ШТ)]
25756090 ПРУЖИНА, IGN LK CYL TUMB (ЧАСТЬ OF 4) (W/O WINGED BZL) (LRG HEADED KEYS) (BRANDED) (10.553)
19120038 CYLINDER, IGN LK (INCLS 1-3) (W/O WINGED BEZEL) (LARGE HEADED KEYS) (BRANDED)
19207864 КЛЮЧ, DR LK & IGN LK [КЛЮЧ ЗАМКА ДВЕРИ]
25756100 КЛЮЧ, DR LK & IGN LK VALET (UNCODED)
(6E02-032) - 2004-2006 E СИГНАЛ
25789208 СИГНАЛ, 400 & 500 HZ (INCLS 2, 3) (ACDelco #D1947F) [ЗВУКОВОЙ СИГНАЛ]
teamcadillac.ru
11517103 STUD, SPL W/KNURLED SHLDR, M6X1X27, 10 THD, 13 O.D., P-PT., 9.8, 7114M (ЧАСТЬ OF 1) [ШТИФТ]
11517102 ГАЙКА, HEX FLG, M6X1X15, 19.8 OD, 9, 7111M (ЧАСТЬ OF 1) [ГАЙКА]
(6E02-034) - 2004-2005 E КРЕПЛЕНИЕ АККУМУЛЯТОРА И КАБЕЛИ (LY7/3.6-7)
teamcadillac.ru
15889973 CABLE, BAT NEG (ACDelco #15889973)
25785031 CABLE, BAT POS (ACDelco #25785031)
15695050 БОЛТ, BAT NEG CBL GND (TO BODY) (M8 X 1.25 X 25) (HEX БОЛТ W/WASHER) (4.686) [БОЛТ КРЕПЛЕНИЯ ГЛУШИТЕЛЯ, М8Х1.25Х25]
11517274 STUD, HFH M8X1.25X20, M10X1.5X25, 22.3 OD, 9.8, 6280M. (BAT CBL TERM)
(6E02-035) - 2005-2009 E ПЕРЕДНИЕ ФАРЫ (EXPORT TT7,TT8)
15930599 ЛАМПА, FRT SI T/SIG (INCLS 2) [УКАЗАТЕЛЬ ПОВОРОТА]
01999382 BULB, (ЧАСТЬ OF 1) (ACDelco #W5WLL) (LONGER LIFE)
25760398 SENSOR, HDLP LVLG FRT SUSP HEIGHT (9X/-3NM (S)9X/-3NM) (INTEGRAL STUD) [ДАТЧИК НАКЛОНА ПЕРЕДНЕЙ ЧАСТИ КУЗОВА]
01999382 BULB, (ЧАСТЬ OF 10) (ACDelco #W5WLL) (LONGER LIFE)
10346260 BULB, FRT FOG LP (ЧАСТЬ OF 10) (TRADE 9145) (ACDelco #9145) [ЛАМПА НАКАЛИВАНИЯ]
15896707 ЛАМПА, FRT T/SIG & FOG (INCLS 5-9, 11)
15896708 ЛАМПА, FRT T/SIG & FOG (INCLS 5-9, 11)
11513599 ГАЙКА, U-TYPE, M4.2X1.41, 0.65-3.80 PNL THK, PZ (ЧАСТЬ OF 14) (ACDelco #11513599)
11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (FRT FOG LP) [ВИНТ М4]
15915312 BRACKET, FRT PARK & T/SIG & FOG LP (INCLS 12, 39) [ОПОРА ПРОТИВОТУМАННОЙ ФАРЫ]
15915313 BRACKET, FRT PARK & T/SIG & FOG LP (INCLS 12, 39) [КРОНШТЕЙН ПЕРЕДНЕЙ ФАРЫ]
11588795 RETAINER, HDLP (PUSH ON) (FITS 9 X 16 HOLE, 1.5 THICK PANEL) [ДЕМПФЕР КРЕПЛЕНИЯ ПЕРЕДНЕЙ ФАРЫ]
25735603 BULB, HDLP (LOW BEAM) (ЧАСТЬ OF 22) (TRADE #D1S) (ACDelco #D1S) [ЛАМПОЧКА ПЕРЕДНЕЙ ФАРЫ 50 ВТ]
25735601 BULB, HDLP (HIGH BEAM) (ЧАСТЬ OF 22) (TRADE #9005XSLL) (ACDelco #9005SX) [ЛАМПА ФАРЫ]
01999382 BULB, (ЧАСТЬ OF 22) (ACDelco #W5WLL) (LONGER LIFE)
15926963 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 16-21, 23-27)
teamcadillac.ru
15930600 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 16-21, 23-27) [ПЕРЕДНЯЯ ФАРА]
25766663 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 16-21, 23-27)
25766664 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 16-21, 23-27)
25768517 SENSOR, HDLP LVLG RR SUSP HEIGHT (INCLS 29) [ДАТЧИК ПОЛОЖЕНИЯ КУЗОВА]
25722303 HARNESS, HDLP LVLG ACTR WRG (ЧАСТЬ OF 28)
25753157 BRACKET, HDLP (INCLS 33)
11517397 ГАЙКА, HEX W/CON WA, 8X1.25, 28 O.D., 7.5 THK, 9, PEOR (FRT BPR ENGY ABS)
11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (ЧАСТЬ OF 31, 38) (ACDelco #11517518) [БОЛТ]
11518497 SCREW, ASM HEX HD W/FLAT WASHER, M6X1.0X25, 14 THD, 9.8 (HDLP)
11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (ЧАСТЬ OF 38) [ШАЙБА]
25753158 BRACKET, HDLP (INCLS 33, 37) [КРОНШТЕЙН В СБОРЕ]
11609459 SCREW, RND WA, M4.2X1.41X13, 7.2 THD, 11.35 OD, 6010M, GMW4205 (ЧАСТЬ OF 14) [ВИНТ]
(6E02-036) - 2005-2009 E ПЕРЕДНИЕ ФАРЫ (EXC EXPORT TT7,TT8)
10346260 BULB, FRT FOG LP (ЧАСТЬ OF 7) (TRADE 9145) (ACDelco #9145) [ЛАМПА НАКАЛИВАНИЯ]
15855631 BULB, T/SIG (ЧАСТЬ OF 7) (TRADE #3457NAK-LCP) (2.880) (ACDelco #15855631)
15862271 BULB, T/SIG (ЧАСТЬ OF 7) (TRADE #3757KA) (2.880) (ACDelco #23757NAK) [ЛАМПОЧКА СИГНАЛА ПОВОРОТА, 21 ВТ]
15896707 ЛАМПА, FRT T/SIG & FOG (INCLS 2-6, 8, 37)
15896708 ЛАМПА, FRT T/SIG & FOG (INCLS 2-6, 8, 37)
25735603 BULB, HDLP (LOW BEAM) (ЧАСТЬ OF 24) (TRADE #D1S) (ACDelco #D1S) [ЛАМПОЧКА ПЕРЕДНЕЙ ФАРЫ 50 ВТ]
09441732 BULB, HDLP (HIGH BEAM) (ЧАСТЬ OF 24, 31) (W/TRADE #9005) (ACDelco #9005)
01999382 BULB, (ЧАСТЬ OF 24) (ACDelco #W5WLL) (LONGER LIFE)
12335548 BALLAST, HDLP (ЧАСТЬ OF 24) (1ST DESIGN HAS A 12 PIN CONNECTOR. FOR 2ND DESIGN SEE 89024736) [БАЛЛАСТ]
89024736 BALLAST, HDLP (LH AND RH) (ЧАСТЬ OF 24) (2ND DESIGN HAS A 4 PIN CONNECTOR. FOR 1ST DESIGN SEE 12335548)
25753157 BRACKET, HDLP (INCLS 22)
11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (ЧАСТЬ OF 21, 27) [БОЛТ М6]
15260975 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 11-19, 29, 36)
teamcadillac.ru
15926960 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 11-19, 29, 36)
11518121 ГАЙКА, U, M6X1, MULTI THD, .5'-4.0' THK PNL (ЧАСТЬ OF 27)
25753158 BRACKET, HDLP (INCLS 22, 26) [КРОНШТЕЙН В СБОРЕ]
25735602 BULB, HDLP (LOW BEAM) (ЧАСТЬ OF 31) (TRADE #9006XSLL) (ACDelco #9006SXLL) [ЛАМПА НАКАЛИВАНИЯ]
01999382 BULB, (ЧАСТЬ OF 31) (ACDelco #W5WLL) (LONGER LIFE)
15926966 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 11, 12, 15, 14, 28-30, 38)
15926967 HEADЛАМПА, (W/FRT SI MKR LP) (INCLS 11, 12, 15, 14, 28-30, 38)
11513599 ГАЙКА, U-TYPE, M4.2X1.41, 0.65-3.80 PNL THK, PZ (FRT T/SIG LP) (ACDelco #11513599)
15915312 BRACKET, FRT PARK & T/SIG & FOG LP [ОПОРА ПРОТИВОТУМАННОЙ ФАРЫ]
15915313 BRACKET, FRT PARK & T/SIG & FOG LP [КРОНШТЕЙН ПЕРЕДНЕЙ ФАРЫ]
11609459 SCREW, RND WA, M4.2X1.41X13, 7.2 THD, 11.35 OD, 6010M, GMW4205 (FRT FOG LP) [ВИНТ]
25763464 BULB, FRT POSN LP (PARK FUNCTION BULB) (ЧАСТЬ OF 24) (BLUE TINT) (TRADE #W5WB50X2) (ACDelco #W5WB50X2) [ЛАМПОЧКА НАКАЛИВАНИЯ ФАРЫ 55 ВТ]
19120947 SOCKET, FRT T/SIG LP (ЧАСТЬ OF 7) (ACDelco #LS234)
(6E02-037) - 2005-2006 E СИГНАЛИЗАЦИЯ/ANTI THEFT (UA2)
10388029 SENSOR, THEFT DTRNT [ДАТЧИК ОБЬЕМА ДЛЯ ПРОТИВОУГОННОЙ СИГНАЛИЗАЦИИ]
90355463 SWITCH, КАПОТ AJAR IND LP (ANTI THEFT WARNING UNIT) [ДАТЧИК ОТКРЫТИЯ КАПОТА (КОНЦ. ВЫКЛЮЧАТЕЛЬ)]
03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (КАПОТ AJAR IND SW BRKT)
25765686 BRACKET, КАПОТ AJAR IND LP SW
11609599 STUD, SPL, M6X1X25, 13 THD, 11 OD HD W/26 WIDE CLIP, 9.8, 6280M, P-PT (THEFT DTRNT ALARM)
25734317 SENSOR, THEFT DTRNT VEH INCLINATION [ДАТЧИК НАКЛОНА КУЗОВА]
teamcadillac.ru
10362943 BRACKET, THEFT DTRNT ALARM
11514517 ГАЙКА, HEX, W/CON SPR WA, M6X1, 5.7THK, 18 O.D., 9, 7111M (THEFT DTRNT ALARM) [ГАЙКА М6]
15213135 ALARM, THEFT DTRNT [ЗВУКОВОЙ СИГНАЛ (СИРЕНА) СИГНАЛИЗАЦИИ]
(6E02-039) - 2005-2009 E ЗАДНИЕ ФАРЫ
25773051 WEATHERSTRIP, L/GATE UPR [БОКОВОЙ МОЛДИНГ]
11509428 БОЛТ/SCREW, HEX, W/FLAT WA, M4.2X1.4X13, 12.3 O.D., BHL PT, 6010M, NO (L/GATE APLQ) (8.977)
15211328 GASKET, HIGH MT S/LP (USED W/BEZEL 12335827) [ПРОКЛАДКА]
15211327 GASKET, HIGH MT S/LP (USED WITH BEZEL 12335827) (ON TAB SEAL-T/LP HSG S/LP (ON STUD) [ПРОКЛАДКА]
19121111 BEZEL, HIGH MT S/LP (MUST ALSO ORDER GASKETS 15211328, 15211327, 25759092.) [ОКАНТОВКА ФОНАРЯ ДОПОЛНИТЕЛЬНОГО СТОП-СИГНАЛА]
15930616 ЛАМПА, HIGH MT STOP [ЗАДНИЙ ФОНАРЬ]
15213960 GASKET, HIGH MT S/LP (USED WITH BEZEL 12335827) (ON STUD)
11588650 CLIP, 12X14X16.6, GM4345M (L/GATE APLQ) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
25759092 GASKET, HIGH MT S/LP (38 OD X 28 ID X 9.5 THICK) [ПРОКЛАДКА МОЛДИНГА ЗАДНЕЙ ОТКИДНОЙ ДВЕРИ]
01999382 BULB, (ЧАСТЬ OF 14, 24) (ACDelco #W5WLL) (LONGER LIFE)
12450108 BULB, TRADE #3157KX (ЧАСТЬ OF 14, 24) (2.679) (ACDelco #3157KX) (LONGER LIFE KRYPTON) [ЛАМПОЧКА НАКАЛИВАНИЯ ФАРЫ 15 ВТ]
25735605 BUMPER, RR LIC PLT PKT (ЧАСТЬ OF 14, 24) (2.662)
12335850 ЛАМПА, B/U & RR LIC (W/RR LIC PLT PKT) (INCLS 10-13) (КРАСКА TO MATCH)
25936964 ЛАМПА, TAIL
25936965 ЛАМПА, TAIL
25936966 ЛАМПА, TAIL [ЗАДНИЙ ФОНАРЬ]
25936967 ЛАМПА, TAIL [ЗАДНИЙ ФОНАРЬ]
25736754 RETAINER, T/LP (PUSH IN) (14 X 21MM HEAD)
11519918 RETAINER, T/LP (PUSH IN) (16MM ROUND HEAD) (2.664) [ФИКСАТОР ЗАДНЕГО ФОНАРЯ]
11517736 ГАЙКА, HEX, M6X1, 5.7 HIGH, 24 OD, 9, 7111M, W/2.5 THK SEALING WA (T/LP) [ГАЙКА М6]
11514517 ГАЙКА, HEX, W/CON SPR WA, M6X1, 5.7THK, 18 O.D., 9, 7111M (B/U & RR LIC PLT LP) [ГАЙКА М6]
11517230 БОЛТ, TORX, W/WA, W/ADH, M6X1X20, 16.2 O.D., DOG PT, 10.9, GM6138M (L/GATE UPR SI APLQ) [ВИНТ ЗАМКА ДВЕРИ М6]
teamcadillac.ru
89025118 GASKET, HIGH MT S/LP
15211652 HARNESS, L/GATE LK & R/WDO DEFG & R/WDO WPR WRG
15211653 HARNESS, L/GATE LK & R/WDO DEFG & R/WDO WPR WRG
12335851 ЛАМПА, B/U & RR FOG & RR LIC PLT (INCLS 10, 12, 13, 25, 26) (КРАСКА TO MATCH) (2.697) [ЛАМПА]
12450108 BULB, TRADE #3157KX (RR FOG LP) (ЧАСТЬ OF 24) (2.679) (ACDelco #3157KX) (LONGER LIFE KRYPTON) [ЛАМПОЧКА НАКАЛИВАНИЯ ФАРЫ 15 ВТ]
(6M02-029) - 2004-2009 E ЖГУТЫ ПРОВОДОВ/ДВИГАТЕЛЬНЫЙ ОТСЕК (LY7/3.6-7)
19115857 HARNESS, ENG WRG
19115858 HARNESS, ENG WRG
teamcadillac.ru
11562004 БОЛТ, HEX W/FL WA, M10X1.5X30, 19 THD, 20 OD, 8.8, GMW3200, MACH, M-PT (ENG WRG HARN SUPT)
11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ENG WRG HARN OXY SEN LEAD BRKT)
12589726 BRACKET, ENG WRG HARN OXY SEN LEAD (HOLD POST SENSOR CONN "POSITION 2 CONNECTOR" ЗАДНИЙ)
(6M02-036) - 2004-2006 E КРЕПЛЕНИЕ СТАРТЕРА (LY7/3.6-7)
teamcadillac.ru
12597349 STARTER, (REMAN) (ACDelco #323-1629) [СТАРТЕР]
11518627 БОЛТ, HFH, M10X1.5X45, 15MM SOCKET, 10.9, GMW3359 (STRTR) (ACDelco #11518627)
(6M02-038) - 2004-2009 E ЖГУТЫ ПРОВОДОВ/ДВИГАТЕЛЬ В СБОРЕ (LY7/3.6-7)
12597469 HARNESS PKG, ENG WRG (WITH OIL LEVEL SENSOR) (USE T/W 15306420 CONN T/W (2) 12575657 SENSOR) (WHEN REPLACING OLD HARNESS, CUSTOMER MAY NEED TO REPLACE ALL PARTS LISTED)
12599240 HARNESS PKG, ENG WRG (WITHOUT OIL LEVEL SENSOR) (USE T/W 15306420 CONN T/W (2) 12575657 SENSOR) (WHEN REPLACING OLD HARNESS, CUSTOMER MAY NEED TO REPLACE ALL PARTS LISTED)
11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (ENG WRG HARN)
11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (ECM) [БОЛТ]
teamcadillac.ru
24574534 STUD, ENG WRG HARN BRKT (M6X1X20) (1.166)
11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (ECM BRKT) [БОЛТ]
12585357 BRACKET, ENG WRG HARN OXY SEN LEAD (HOLDS THE PRE SENSOR CONNECTOR "POSITION 1 CONN")
11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (WRG HARN BRKT)
(6Y02-017) - 2004-2005 E РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ & МОДУЛЬ/ЗАЖИГАНИЕ (LH2/4.6A)
teamcadillac.ru
89017778 РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ, IGN (INCLS 704-707) (ACDelco #D593A) [КАТУШКА ЗАЖИГАНИЯ]
03 - ТОПЛИВНАЯ СИСТЕМА - ВЫХЛОПНАЯ - СИСТЕМА ВЫПУСКА ВОЗДУХА
(6E03-009) - 2004-2006 E АКСЕЛЕРАТОР (EXC JF4)
15263218 PEDAL, ACCEL (INCLS 2, 3) [ПЕДАЛЬ ГАЗА]
teamcadillac.ru
03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (ACCEL PED LVR)
(6E03-010) - 2004-2006 E АКСЕЛЕРАТОР (JF4)
25764209 REINFORCEMENT, DA PNL BRK PED BRKT (WITHOUT ТОРМОЗНОЙ УСИЛИТЕЛЬ BRACKET)
15263220 PEDAL, ACCEL (INCLS 3, 4) (INCLS SENSOR) [ПЕДАЛЬ АКСЕЛЕРАТОРА В СБОРЕ]
11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (BRK PED BRKT) [ГАЙКА]
89047780 MOTOR KIT, BRK & ACCEL PED ADJR ACTR (INCLS 9) [ЭЛЕКТРОДВИГАТЕЛЬ ПЕДАЛЬНОГО УЗЛА 19 ВТ]
teamcadillac.ru
89047778 CABLE, BRK PED ADJR ACTR [ЖГУТ ПРОВОДОВ]
89047779 CABLE, ACCEL CONT
(6E03-011) - 2004-2006 E СИСТЕМА ВПУСКА ВОЗДУХА (LH2/4.6A)
25798271 ELEMENT, КОНДИЦИОНЕРL (ACDelco #A2944C) [ВОЗДУШНЫЙ ФИЛЬТР ДВИГАТЕЛЯ]
19151529 COVER, КОНДИЦИОНЕРL HSG LWR (INCLS 4) [КРЫШКА ВОЗДУХОЗАБОРНИКА]
teamcadillac.ru
11588831 SCREW, HEX W/ CON WA, M6X1X35, 33.5 THD, 17 O.D.HDR PT, 9.8, BLK (КОНДИЦИОНЕРL)
19177871 INSULATOR, КОНДИЦИОНЕРL HSG (MOUNT TO MID RAIL)
12561695 БОЛТ, КОНДИЦИОНЕРL (M6X1X13MM)
88967332 БОЛТ, КОНДИЦИОНЕРL (30.7MM)
25744215 DUCT, RR INT AIR (W/RESO) (INCLS 9) [ТРУБКА ВОЗДУХОПРОВОДА]
12567377 SENSOR, MASS AIRFLOW (INCLS 11) (ACDelco #213-1594) [ДАТЧИК РАСХОДА ВОЗДУХА]
15147461 GASKET, MASS AIRFLOW SEN (ROUND)
15813321 GASKET, MASS AIRFLOW SEN (RECTANGULAR) (GASKET IS POA TO MAF SENSOR)
25314060 БОЛТ, M6X1X30, 11 THD, 12.5 OD, 4.8, 6047M, P-PT (КОНДИЦИОНЕРL HSG CVR)
15147459 COVER, КОНДИЦИОНЕРL HSG [КРЫШКА ВОЗДУХООЧИСТИТЕЛЯ]
(6E03-011) - 2004-2006 E СИСТЕМА ВПУСКА ВОЗДУХА (LY7/3.6-7)
19151528 COVER, КОНДИЦИОНЕРL HSG LWR (INCLS 4) [КРЫШКА ВОЗДУХООЧИСТИТЕЛЯ]
15744944 INSULATOR, КОНДИЦИОНЕРL HSG (ЧАСТЬ INCLUDES RUBBER INSULATOR AND METAL SPACER)
teamcadillac.ru
25733251 DUCT, RR INT AIR (W/RESO) (INCLS 9)
12566846 SENSOR, MASS AIRFLOW (INCLS 11) (ACDelco #213-1593) [ДАТЧИК]
15147456 GASKET, MASS AIRFLOW SEN
15147455 COVER, КОНДИЦИОНЕРL HSG [КРЫШКА ВОЗДУШНОГО ФИЛЬТРА]
(6E03-012) - 2004-2009 E ТОПЛИВНЫЙ БАК & КРЕПЛЕНИЕ
25862765 CAP, F/TNK FIL LK (0.1KGS) (ACDelco #GT264) [КРЫШКА ТОПЛИВОНАЛИВНОЙ ГОРЛОВИНЫ]
15775325 DOOR, F/TNK FIL (INCLS 6)
teamcadillac.ru
11509374 БОЛТ, SCR HEX W/FL WA, SELF TAP, 4.2X1.41X16, 12.5 O.D. (F/TNK FIL PIPE)
25773939 ШЛАНГИ, F/TNK FIL PIPE [КОЖУХ ТОПЛИВОЗАЛИВНОЙ ГОРЛОВИНЫ]
89047657 BUMPER, F/TNK FIL DR (ЧАСТЬ OF 3) (HINGE) [ВТУЛКА]
11609731 RIVET, F/TNK FIL DR (25" SHANK, .63 LEN, .50 OD, .06-.30 GRP RNG, 1008 STL, GMW3044) (8.967)
15868848 PIPE, F/TNK FIL (INCLS 9, 10, 15, 19, 20) [ТРУБКА ТОПЛИВОЗАЛИВНОЙ ГОРЛОВИНЫ]
01470030 CЛАМПА, WORM TYPE (11/16" TO 1 5/16") (ЧАСТЬ OF 8) (ACDelco #1470030)
09177063 CЛАМПА, F/TNK FIL HOSE (ЧАСТЬ OF 12) (25-40MM CЛАМПА RANGE)
15925741 HOSE, F/TNK FIL (INCLS 11) [ШЛАНГ ТОПЛИВНОЙ СИСТЕМЫ]
09177063 CЛАМПА, F/TNK FIL HOSE (25-40MM CЛАМПА RANGE)
11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (F/TNK FIL PIPE BRKT) [БОЛТ М8]
15638098 RETAINER, FUEL RTN PIPE FTG (ЧАСТЬ OF 8) (NATURAL) (NYLON) (5/16") (7.9MM)
11517101 БОЛТ, METRIC HEX FLANGE HD, M10X1.5X50 (F/TNK STRP) [БОЛТ М10]
25679207 STRAP, F/TNK [ЗАЖИМ БЕНЗОБАКА]
12337820 STRAP, 15" TIE STRAP (ЧАСТЬ OF 8) (ACDelco #12337820)
25880365 ПРУЖИНА, F/TNK FIL DR (PRIOR TO INSTALL SEAL VOIDS IN PLUNGER HSG W/FLEXIABLE SEALER) [ЗАЩЕЛКА ЛЮЧКА ТОПЛИВНОЙ ГОРЛОВИНЫ]
(6E03-013) - 2004-2009 E СИСТЕМА ТОПЛИВОСНАБЖЕНИЯ (LH2/4.6A)
15924706 HARNESS, FUEL SDR WRG (3.115)
88965813 SENDER KIT, FUEL (INCLS 24) (FOR AUXILARY МОДУЛЬ) (ACDelco #MU1579)
19177355 CANISTER, EVAP EMIS (CANISTER WITHOUT COVER OR FILTER) (INCLS 39, 43) (ACDelco #215-644)
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (EVAP EMIS CNSTR BRKT) [ГАЙКА М6]
15278918 PIPE, EVAP EMIS CNSTR PURGE
15219486 PIPE, FUEL FEED RR (INCLS 35)
15219484 PIPE, FUEL RTN RR
22514722 SEAL, FUEL FEED FRT PIPE (O RING) (ЧАСТЬ OF PIPE, FEED & RTN ASM BUNDLE) (7.35MM ID X 1.66MM THK) (ACDelco #217-452) [КОЛЬЦО УПЛОТНИТЕЛЬНОЕ, ТОПЛИВНОЙ ТРУБКИ]
25763176 ФИЛЬТР, FUEL (ACDelco #GF897) [ТОПЛИВНЫЙ ФИЛЬТР]
11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (FUEL FLTR BRKT) [БОЛТ М8]
25701014 RETAINER, FUEL FLTR
25688547 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (RETAINER W/5 HOLES (2)7.95, (2)4.76, (1)9.52MM)
15270078 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (USES RETAINER PIN FOR ATTACHMENT) [ЗАЖИМ ТРУБКИ ТОПЛИВНОЙ СИСТЕМЫ]
10360402 PIPE, FUEL FEED (INCLS 19) [ТРУБКА ТОПЛИВНОЙ СИСТЕМЫ, СТАЛЬ]
25917776 PIPE, FUEL FEED (INCLS 19)
25761218 BRACKET, FUEL PIPE
25761217 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (3.162)
25765594 CLIP, FUEL FEED & EVAP EMIS FRT PIPE (42.10MM LENGTH) (3.162) [ФИКСАТОР ТОРМОЗНЫХ ТРУБОК]
25679213 PIN, F/TNK UPR SHLD
25679209 SHIELD, F/TNK
25894460 TANK, FUEL (INCLS 21, 26, 27, 31, 33, 34) [ТОПЛИВНЫЙ БАК]
25901272 SEAL, FUEL SDR (ЧАСТЬ OF 2, 28, 44) (ACDelco #G37)
25740096 CAM, FUEL SDR (ACDelco #TR23)
19181827 МОДУЛЬ KIT, F/TNK F/PMP (W/O FUEL LVL SEN) (INCLS 24) (ACDelco #M10201) [ТОПЛИВНЫЙ НАСОС]
25679252 RETAINER, FUEL FEED & EVAP EMIS & RTN FRT PIPE (HOLDS 15.8/7.95/7.0 TUBES, HAS CHRISTMAS TREE RETAINER) (3.162)
15951521 PIPE, FUEL SDR FUEL FEED (INCLS CONN) (PIPE ATTACHES TO SENDING UNITS INSIDE OF GAS TANK) [ТРУБКА ТОПЛИВНОЙ СИСТЕМЫ]
16238399 SENSOR, F/TNK PRESS (ACDelco #16238399) [ДАТЧИК ДАВЛЕНИЯ ПАРОВ ТОПЛИВА]
25726788 RETAINER, BRK & FUEL PIPE (SQUARE HEAD PUSH PIN W/5 HOLES (2)4.76. (2)8.00 (1)9.52) [ФИКСАТОР ТОРМОЗНЫХ ТРУБОК]
25751324 RETAINER, FUEL FEED & EVAP EMIS & RTN FRT PIPE (HOLDS 7.95 & 9.5 DIA FUEL LINE, HAS CHRISTMAS TREE RETAINER) (3.162)
17114722 HOSE, EVAP EMIS CNSTR AIR INL (3.130) (ACDelco #219-366)
teamcadillac.ru
17114723 COVER, EVAP EMIS CNSTR AIR INL OPG (ЧАСТЬ OF 3)
19177365 FILTER KIT, EVAP EMIS CNSTR (W/ SEAL) (INCLS 40)
25932573 VALVE, EVAP EMIS CNSTR VENT SOL (ACDelco #214-2230) [КЛАПАН КОНТРОЛЯ СИСТЕМЫ РЕЦИРКУЛЯЦИИ ВЫХЛОПНЫХ ГАЗОВ]
88967139 SENSOR KIT, FUEL LVL (PRIMARY) (INCLS 24) (ACDelco #SK1161) [ТОПЛИВНЫЙ НАСОС]
(6E03-014) - 2004-2006 E РАМКА ТОПЛИВНОГО ИНЖЕКТОРА (LH2/4.6A)
teamcadillac.ru
12580644 RAIL, SEQ M/PORT F/INJN FUEL (INCLS 580, 581) (ACDelco #217-1556)
25532662 CAP, FUEL PRESS SERV VLV (ЧАСТЬ OF 566) (CAP FOR PRESSURE TEST SCHRADER VALVE) (3.163) (ACDelco #214-1044) [КРЫШКА]
12580648 VALVE KIT, FUEL PRESS SERV (INCLS 565) (ACDelco #12580648)
12580645 INJECTOR KIT, SEQ M/PORT FUEL (INCLS 561-564) (INCLS 1 INJECTOR, UPR AND LWR SEAL RINGS & RET) (ACDelco #217-1553) [ИНЖЕКТОР]
12580646 RETAINER KIT, F/INJR (INCLS 562) (INCLS 8 INJECTOR RET CLIPS) (ACDelco #12580646)
12580647 SEAL KIT, F/INJR (O RING) (INCLS 563, 564) (INCLS 8 UPR INJECTOR O-RINGS & 8 LWR INJECTOR O-RINGS) (ACDelco #217-1555) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО]
(6E03-015) - 2004-2006 E БЛОК ЭЛЕКТРОННОГО УПРАВЛЕНИЯ И СВЯЗАННЫЕ ДЕТАЛИ (LH2/4.6A)
teamcadillac.ru
12576523 МОДУЛЬ, ENG CONT (REQUIRES PROGRAMMING) (ACDelco #12576523) [БЛОК УПРАВЛЕНИЯ ДВИГАТЕЛЕМ]
25730751 BRACKET, ECM BRKT
11518646 БОЛТ, HEX HD, W/CON WA, M6X1X30, 24.33THD, 17 OD, 9.8, 6138M, BLK (ECM BRKT)
11514517 ГАЙКА, HEX, W/CON SPR WA, M6X1, 5.7THK, 18 O.D., 9, 7111M (ECM WRG HARN BRKT) [ГАЙКА М6]
(6E03-016) - 2004-2006 E СИСТЕМА ОТРАБОТАВШИХ ГАЗОВ (LH2/4.6A)
15240254 BRACKET, EXH TAIL PIPE HNGR (INCLS 3) [КРОНШТЕЙН]
25902027 BRACKET, EXH TAIL PIPE HNGR (INCLS 3)
25711603 INSULATOR, EXH MUFF HNGR BRKT (ЧАСТЬ OF 2)
15251184 PIPE, EXH TAIL (ЧАСТЬ OF 6) (3.701)
25711603 INSULATOR, EXH MUFF HNGR BRKT (ЧАСТЬ OF 6)
15290902 MUFFLER, EXH (W/RESO, EXH & TAIL PIPE) (INCLS 4, 5)
11517031 ГАЙКА, HFH, M8X1.25, 9.4THK, 17.4 O.D., 10, TIN ZN (EXH MUFF)
12590035 SENSOR, HTD OXY (POSN 3) (POST CONVERTER) (ACDelco #213-2823) [ДАТЧИК]
25709703 SEAL, CTLTC CONV (ЧАСТЬ OF 11) (ROUND METAL SEAL) [ПРОКЛАДКА НАСОСА]
11609596 STUD, CTLTC CONV (ЧАСТЬ OF 11) [ШПИЛЬКА]
12567687 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 9, 10) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ]
12567688 MANIFOLD, EXH (W/3WAY CTLTC CONV) (INCLS 9, 10) [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ]
teamcadillac.ru
(6E03-017) - 2004-2009 E СИСТЕМА ТОПЛИВОСНАБЖЕНИЯ (LY7/3.6-7)
19177355 CANISTER, EVAP EMIS (CANISTER WITHOUT COVER OR FILTER) (INCLS 46) (ACDelco #215-644)
22514722 SEAL, FUEL FEED FRT PIPE (O RING) (ЧАСТЬ OF PIPE, FEED & RTN ASM BUNDLE) (7.35MM ID X 1.66MM THK) (ЧАСТЬ OF 15) (ACDelco #217-452) [КОЛЬЦО УПЛОТНИТЕЛЬНОЕ, ТОПЛИВНОЙ ТРУБКИ]
25749839 RETAINER, BRK & FUEL FEED & FUEL RTN & EVAP EMIS PIPE (HOLDS 3 ТРУБКИ, FLAT SHAPE, SNAP-IN RETAINER)
15888146 PIPE, EVAP EMIS CNSTR PURGE (INCLS 37, 39)
15145717 PIPE, FUEL FEED (INCLS 8, 19)
25901272 SEAL, FUEL SDR (ЧАСТЬ OF 2, 28, 47) (ACDelco #G37)
11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (FUEL FEED & EVAP EMIS & RTN PIPE CLIP BRKT) [БОЛТ М6]
25654373 CLIP, FUEL FEED & RTN HOSE (PLASTIC) (ЧАСТЬ OF FUEL & BRAKELINE BUNDLE НИЖНЯЯ ЧАСТЬ; POSITION 2, 4, 5)
teamcadillac.ru
17114723 COVER, EVAP EMIS CNSTR AIR INL OPG (ЧАСТЬ OF 44)
19177365 FILTER KIT, EVAP EMIS CNSTR (W/ SEAL) (INCLS 42, 43)
(6E03-018) - 2004-2007 E СИСТЕМА ОТРАБОТАВШИХ ГАЗОВ (LY7/3.6-7)
15240254 BRACKET, EXH TAIL PIPE HNGR (INCLS 2) [КРОНШТЕЙН]
25902027 BRACKET, EXH TAIL PIPE HNGR (INCLS 2)
15284207 INSULATOR, EXH TAIL PIPE HNGR (ЧАСТЬ OF 1) [ДЕМПФЕР ГЛУШИТЕЛЯ]
25711603 INSULATOR, EXH MUFF HNGR BRKT (ЧАСТЬ OF 5)
15251183 PIPE, EXH TAIL (ЧАСТЬ OF 5)
15233284 MUFFLER, EXH (W/RESO, EXH & TAIL PIPE) (INCLS 3, 4)
15290901 MUFFLER, EXH (W/RESO, EXH & TAIL PIPE) (INCLS 3, 4)
teamcadillac.ru
25768055 SEAL, CTLTC CONV (ЧАСТЬ OF 9) (SEAL WITH COVER ATTACHED) [УПЛОТНЕНИЕ КАТАЛИТИЧЕСКОГО НЕЙТРАЛИЗАТОРА]
12622977 CONVERTER, 3WAY CTLTC (INCLS 8, 10, 12, 13) [КАТАЛИТИЧЕСКИЙ НЕЙТРАЛИЗАТОР ВЫХЛОПНЫХ ГАЗОВ]
12622978 CONVERTER, 3WAY CTLTC (INCLS 8, 10, 12, 13) [КАТАЛИТИЧЕСКИЙ НЕЙТРАЛИЗАТОР ВЫХЛОПНЫХ ГАЗОВ]
11609596 STUD, CTLTC CONV (ЧАСТЬ OF 9) [ШПИЛЬКА]
12575657 SENSOR, HTD OXY (POSN 1) (IN EXH MANIFOLD/CROSSOVER) (ACDelco #213-1572) (W/RECTANGULAR SHAPED CONNECTOR) (FOR 2ND DES SEE 12596327) [ДАТЧИК]
12596327 SENSOR, HTD OXY (POSN 1) (IN EXH MANIFOLD/CROSSOVER) (ACDelco #213-3240) (W/OVAL SHAPED CONNECTOR) (FOR 1ST DES SEE 12575657) [КИСЛОРОДНЫЙ ДАТЧИК]
11589264 STUD, STRAIGHT, M10X1.5X30, M10X1.5X16, 57 TL, SS (ЧАСТЬ OF 9) [ШПИЛЬКА М8]
12571101 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ]
12571102 MANIFOLD, EXH [ВЫПУСКНОЙ КОЛЛЕКТОР ДВИГАТЕЛЯ]
15709703 ГАЙКА, HEX 10X1.5THD, 21.8 OD SS (CTLTC CONV) [ГАЙКА М10]
(6M03-085) - 2004-2006 E БЛОК ЭЛЕКТРОННОГО УПРАВЛЕНИЯ И СВЯЗАННЫЕ ДЕТАЛИ (LY7/3.6-7)
12600071 BRACKET, ECM (INCLS 8, 10)
12592124 МОДУЛЬ, ENG CONT (REQUIRES PROGRAMMING) (ACDelco #12592124)
11562004 БОЛТ, HEX W/FL WA, M10X1.5X30, 19 THD, 20 OD, 8.8, GMW3200, MACH, M-PT (ECM GND STRP)
11519861 БОЛТ, HEX W/FL WA, M10X1.5X30, 19 THD, 20 OD, 9.8, 6280M, MACH, MAT-PT (ECM GND STRP) [БОЛТ М10]
11519172 БОЛТ, HFH, 8X1.25X55, 18 OD, 22THD, 8.8, GMW3359, 6MM MATPOINT, REDUCED BODY (ЧАСТЬ OF 1)
teamcadillac.ru
11588523 STUD, M6X1 (ЧАСТЬ OF 1)
(6M03-088) - 2004-2009 E РАМКА ТОПЛИВНОГО ИНЖЕКТОРА (LY7/3.6-7)
12596182 HARNESS, F/INJR WRG (INCLS 2) (IF REPL 12584312 MAY NEED TO INSTALL BRACKET FROM HARNESS.)
25532662 CAP, FUEL PRESS SERV VLV (CAP FOR PRESSURE TEST SCHRADER VALVE) (*KIT2) (3.163) (ACDelco #214-1044) [КРЫШКА]
12572886 RAIL, F/INJN FUEL (INCLS 5, 9) (ACDelco #217-1551) [МАГИСТРАЛЬ ТОПЛИВНЫХ ФОРСУНОК ДВИГАТЕЛЯ]
11588714 БОЛТ, HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8, GMW3359, M-PT. (F/INJN FUEL RL) [БОЛТ]
12571159 INJECTOR, M/PORT FUEL (INCLS 8, 11) (ACDelco #217-1552) [ИНЖЕКТОР]
12576479 SEAL KIT, M/PORT F/INJR (INCLS 8, 11) (ACDelco #217-1541) [КОМПЛЕКТ ПРОКЛАДОК ИНЖЕКТОРНОЙ ФОРСУНКИ (2 ШТ]
12584592 VALVE KIT, FUEL PRESS SERV (INCLS 4, 5) (INCLUDES CAP AND VALVE) (ACDelco #12584592) [КЛАПАН]
12584591 RETAINER KIT, F/INJR (INCLS 9) (ACDelco #12584591) [ОПОРНАЯ ПЛАСТИНА ТОПЛИВНОЙ ФОРСУНКИ]
(6D04-023) - 2004-2009 E СТОЯНОЧНЫЙ ТОРМОЗ ASM
88951984 PLATE, RR PARK BRK ANC BKG (4.591)
88951985 PLATE, RR PARK BRK ANC BKG (4.591)
88951982 ACTUATOR KIT, RR PARK BRK (INCLS 2) (ACDelco #179-2053) [АКТУАТОР]
88951983 ACTUATOR KIT, RR PARK BRK (INCLS 2) (ACDelco #179-2054) [АКТУАТОР]
teamcadillac.ru
89047676 SHOE KIT, RR PARK BRK (INCLS 5) (ACDelco #171-0915) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (2 ШТ)]
(6D04-031) - 2004-2009 E ТОРМОЗНОЙ СУППОРТ-ЗАДНИЙ
89047677 CALIPER KIT, RR BRK (INCLS 2, 3, 7-9) (ACDelco #172-2343)
89047678 CALIPER KIT, RR BRK (INCLS 2, 3, 7-9) (ACDelco #172-2344) [ТОРМОЗНОЙ СУППОРТ]
88951992 CAP, RR BRK BLEDR VLV (ЧАСТЬ OF 1)
88951991 VALVE, RR BRK CLPR BLEDR (ЧАСТЬ OF 1)
89047757 PAD KIT, RR DISC BRK (INCLS 4, 12) (ACDelco #171-859) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4 ШТ)]
89047758 PAD KIT, RR DISC BRK (INCLS 4, 12) (4.667) (ACDelco #171-0906) [ТОРМОЗНЫЕ КОЛОДКИ]
88957163 BRACKET, RR BRK CLPR [СКОБА ТОРМОЗНОГО СУППОРТА]
89047759 PIN KIT, RR BRK CLPR GDE (INCLS 4-6) (INCLS 2 PINS, 2 SEALS & 2 (2.75") БОЛТS) (ACDelco #179-2044) [НАПРАВЛЯЮЩАЯ ТОРМОЗНОГО СУППОРТА (2 ШТ)]
88957162 REPAIR KIT, RR BRK CLPR HYD (INCLS 4, 6, 8, 9)
(6D04-033) - 2004-2009 E ТОРМОЗНОЙ УСИЛИТЕЛЬ
88967237 BOOSTER, P/B (W/O VLV) (ACDelco #178-0695)
05461808 GROMMET, P/B BOOS VAC CHK VLV (*KIT1)
03817880 RETAINER, BRK PED PUSH ROD (0.80 IN) (PUSH IN)
18022219 VALVE KIT, P/B BOOS VAC CHK (INCLS 2, 3) (BLACK) (INCLS VLV & GROM) (ACDelco #179-1266)
(6E00-010) - 2004-2005 E ТРАНСМИССИЯ TO КРЕПЛЕНИЕ ДВИГАТЕЛЯ (LH2/4.6A)
12580474 FLYКОЛЕСО, ENG (INCLS 10) [МАХОВИК ДВИГАТЕЛЯ]
25771275 BRACKET, ENG WRG HARN (USED IN GENERATOR PACKAGE)
11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (TRANS) [БОЛТ М10Х1.5Х50]
24205900 COVER, T/CV HSG ACC HOLE (62MM W/3 TANGS) (LARGE CVR) (ACDelco #24205900) [ЗАГЛУШКА КАРТЕРА КПП]
12561075 БОЛТ, FLYWHL
12568122 COVER, FLYWHL HSG
11588468 БОЛТ, TRANSAXLE T/CV (M10X1.5X15)
11517518 БОЛТ, HFH, M6X1X20, 17.9 THD, 14.2 O.D., 9.8, TIN ZN (TRANS CONV CVR) (ACDelco #11517518) [БОЛТ]
12568123 COVER, TRANS CONV
teamcadillac.ru
01647172 SPACER, FLYWHL (ЧАСТЬ OF 1)
(6E00-014) - 2004-2009 E ТРАНСМИССИЯ TO КРЕПЛЕНИЕ ДВИГАТЕЛЯ (LY7/3.6-7)
11518950 STUD, HFH, M6X1X16, M6X1X14, 34.7 TL, 13 O.D., 10.9, GMW3359 (TRANS CVR) [БОЛТ]
teamcadillac.ru
(6E04-003) - 2004-2006 E УПРАВЛЕНИЕ АКПП/АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22,M82)
88967336 KNOB PKG, A/TRNS CONT LVR (INCLS 2, 13) (EBONY/BURL WALNUT)
88967337 KNOB PKG, A/TRNS CONT LVR (INCLS 2, 13) (EBONY LEATHER)
88967339 БОЛТ, A/TRNS CONT LVR KNOB (ЧАСТЬ OF 1)
25772994 PLATE, F/FLR CNSL TRANS SHFT OPG TR (INCLS TRAC CONT SWITCH)
25772995 PLATE, F/FLR CNSL TRANS SHFT OPG TR (WALNUT BURL) (INCLS TRAC CNTRL SW) [ПОДДОН]
88967342 BASE, A/TRNS CONT (INCLS 4, 6, 7) (4.010)
88967347 SOLENOID, A/TRNS SHFT LK CONT (ЧАСТЬ OF 5)
03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (A/TRNS RANGE SEL ROD ADJ)
15245220 LINK, A/TRNS RANGE SEL LVR (W/ADJUSTER SLEEVE) (FOR 1ST DES SEE 25756336) [ШАРНИР,КУЛИСА]
25756336 LINK, A/TRNS RANGE SEL LVR (NON-ADJUSTABLE) (FOR 2ND DES SEE 15245220) [ШАРНИР, КУЛИСА]
11519095 NUT-ACORN HEX, M8X1.0, 15MM THK, 9, 6047M, W/DOME. (A/TRNS RANGE SEL LVR) [ГАЙКА]
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (A/TRNS RANGE SEL LVR CBL BRKT) [ГАЙКА М6]
88967341 BULB, A/TRNS CONT POSN IND (INCLS BULB W/BLUE COVER) (4.020) (ACDelco #88967341) [ЛАМПОЧКА ФАРЫ]
teamcadillac.ru
88967340 COVER, A/TRNS CONT LVR HDL (ЧАСТЬ OF 1)
(6E04-004) - 2004-2006 E УПРАВЛЕНИЕ АКПП/АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3,MX5)
19167127 BEZEL, A/TRNS CONT HSG (W/SHIF LOCK SOLENOID COV)
88967343 BASE, A/TRNS CONT (4.010) [БЛОК]
15245219 LINK, A/TRNS RANGE SEL LVR (W/ADJUSTER SLEEVE) (FOR 1ST DES SEE 25756335)
teamcadillac.ru
25756335 LINK, A/TRNS RANGE SEL LVR (NON-ADJUSTABLE) (FOR 2ND DES SEE 15245219) [РЫЧАГ В СБОРЕ]
(6E04-005) - 2004-2005 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (EXC V92)(WITH THERMAL BYPASS VALVE)(1ST DES)
11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR PIPE BRKT) (ACDelco #11570082) [БОЛТ М8]
89022494 BRACKET, TRANS FLUID CLR
11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (TRANS FLUID CLR PIPE BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16]
11515792 БОЛТ, HFH, M8X1.25X40, 22THD, 18 O.D., MAC-PT, 10.9, 7112M (TRANS FLUID CLR PIPE CONN)
24221232 VALVE, TRANS FLUID CLR THERMAL BYPASS (INCLS 5) [КЛАПАН ЖИДКОСТИ ТРАНСМИССИОННОЙ]
19130214 SEAL, TRANS FLUID CLR HOSE CONN (O RING)
19129779 HOSE, TRANS FLUID CLR LWR (W/BLOCK) (BUILT W/OR AFTER VIN 1GYEE63A750180934 USE T/W 19129780 , 11515757 & REMOVE THERM BYPASS VLV.) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ]
19129781 HOSE, TRANS FLUID CLR LWR (W/BLOCK)
89022495 HOSE, TRANS FLUID CLR LWR
88957425 COOLER, TRANS FLUID (INCLS 9-13) (ACDelco #88957425) [ВЕНТИЛЯТОР]
teamcadillac.ru
19129780 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) (USE ON CARS BUILT W/OR AFTER VIN 1GYEE63A750180934) (FOR CARS BUILT PRIOR TO VIN REPL T/W 19129779 , 11515757 & REMOVE THERM BYPASS VLV.) [ТРУБКА]
19129782 HOSE, TRANS FLUID CLR UPR (W/O BLOCK) (USE ON CARS BUILT W/OR AFTER VIN 1GYEE637150180965) (FOR CARS BUILT PRIOR TO VIN REPL T/W 19129781 , 11515757 & REMOVE THERM BYPASS VLV.) [ТРУБКА МАСЛООХЛАДИТЕЛЯ]
89022496 HOSE, TRANS FLUID CLR UPR
(6E04-006) - 2004-2005 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (V92)(WITH THERMAL BYPASS VALVE)(1ST DES)
teamcadillac.ru
19129779 HOSE, TRANS FLUID CLR LWR (INCLS BLOCK) (W/BLOCK) (BUILT W/OR AFTER VIN 1GYEE63A750180934 USE T/W 19129780 , 11515757 & REMOVE THERM BYPASS VLV.) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ]
19129781 HOSE, TRANS FLUID CLR LWR (INCLS BLOCK) (W/BLOCK)
11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (TRANS FLUID CLR) (ACDelco #11570082) [БОЛТ М8]
89022522 COOLER, TRANS FLUID (INCLS 9-11)
(6E04-007) - 2004-2006 E ТОРМОЗНЫЕ ШЛАНГИ И ТРУБКИ
15933099 HOSE, FRT BRK (INCLS 15, 16) (ACDelco #176-1495)
11569742 RETAINER, FRT BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ]
12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (BRK & FUEL FEED & FUEL RTN & EVAP EMIS) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА]
teamcadillac.ru
12547207 TUBING, BULK, 3/16" X 20 FT ROLL, STL (FRT BRK) (8.964) [ТРУБКА, ЗАДНЕГО ТОРМОЗНОГО КОНТУРА]
10388788 PIPE, BRK PRESS MOD VLV FRT (INCLS 29)
10388794 PIPE, BRK PRESS MOD VLV RR (INCLS 29)
25763163 PIPE, BRK PRESS MOD VLV RR (9/16" FITTING AT EACH END. FOR 2ND DESIGN SEE 10388794.) (INCLS 29)
03541444 SPACER, FRT BRK PIPE
11516521 БОЛТ, HFH M6X1X20, 9.8, 7114M, DOG PT, 14.2 OD (FRT BRK HOSE)
15933098 HOSE, FRT BRK (INCLS 15, 16) (ACDelco #176-1487)
25743891 RETAINER, RR BRK FRT PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT)
15724653 FITTING, FRT BRK PIPE (ЧАСТЬ OF 1, 12) (7/16-24 X .36) (.30 THD, .56 LENGTH, .194 TUBE, STL, GM7113M)
25743891 RETAINER, FRT BRK PIPE (THREE WAY RETAINER SNAP LOCK CLOSURE SINGLE OFFSET FIR-TREE ATTACHMENT)
25737279 CLIP, FRT BRK PIPE (THREE WAY RETAINER SINGLE CENTRAL FIR-TREE ATTACHMENT)
25607191 RETAINER, BRK PIPE (21.5X10.0MM) (HOLDS (2) 4.68-4.82 TUBES)
11569742 RETAINER, RR BRK HOSE (1 SIDED RETAINER) [ОПОРНАЯ СКОБА ШЛАНГА ТОРМОЗНОЙ СИСТЕМЫ]
15724650 ГАЙКА, INVERTED FLARED TUBE, 9/16"-18, 1/4" TUBE, ZD (BRK PIPE) (4.686) [ГАЙКА]
25693890 RETAINER, RR BRK PIPE (HOLDS (1) 4.76 LINE) (W/TREE) [ЗАМОК, ФИКСАТОР]
11588803 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 7, 8) (1/2-20X.40, .32 THD) (INVERTED FLARED TUBE) (.62 LONG, 1/4 TUBE) [ГАЙКА М20]
15724650 FITTING, BRK PRESS MOD VLV FRT BRK PIPE (ЧАСТЬ OF 7, 8) (9/16-18 X .40) (INVERTED FLARED TUBE) [ГАЙКА]
15933091 HOSE, RR BRK (INCLS 22, 23) (ACDelco #15933091)
15933092 HOSE, RR BRK (INCLS 22, 23) (ACDelco #15933092) [ШЛАНГ ТОРМОЗНОЙ СИСТЕМЫ]
88964150 PROTECTOR, FRT BRK PIPE (FOR 3/16" PIPE) (HT SHRINK)
(6E04-008) - 2004-2006 E ТОРМОЗНАЯ ПЕДАЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (EXC (JF4))
25732428 BARRIER, BRK PED BRKT SND
25697461 RETAINER, BRK PED PUSH ROD BOOT
25732452 BOOT, BRK PED PUSH ROD
11609949 ГАЙКА, HEX PRVL TORQ, W/NYLON WA INSERT, M10X1.5X11.7, ZC (BRK M/CYL) [ГАЙКА]
teamcadillac.ru
15932827 HOSE, P/B BOOS VAC (ACDelco #176-1496)
25765419 PEDAL, BRK (W/BRKT) (INCLS 10, 11, 14, 16-18)
25771615 COVER, BRK PED (ЧАСТЬ OF 9)
89047699 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 9) [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ]
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (BRK PED BRKT SND BARR) [ГАЙКА М6]
11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 9)
10434956 BUSHING, BRK PED PUSH ROD
00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 9)
03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 9) (0.80 IN) (PUSH IN)
(6E04-010) - 2004-2006 E СТОЯНОЧНЫЙ ТОРМОЗ SYSTEM
teamcadillac.ru
10395687 LEVER, PARK BRK (INCLS 2-4, 13-15)
15797212 CABLE, PARK BRK INTER (INCLS 5, 10, 11) (ACDelco #15797212) [ТРОС СТОЯНОЧНОГО ТОРМОЗА В СБОРЕ]
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (PARK BRK INTER CBL GDE) [ГАЙКА М6]
11517484 БОЛТ-HEX, M6X1X20, 9 THD, 17 OD, 9.8, 6280M, MACH, P-PT (PARK BRK INTER CBL GDE)
25764260 CABLE, PARK BRK RR (28.2X28.5X811.7MM) (ACDelco #25764260) [ТРОС СТОЯНОЧНОГО ТОРМОЗА]
25880964 HANDLE, PARK BRK REL
89047821 CABLE, PARK BRK REL (ЧАСТЬ OF 1) (ACDelco #89047821)
22654577 SWITCH, PARK BRK IND (ЧАСТЬ OF 1) (ACDelco #22654577) [ВКЛЮЧАТЕЛЬ]
(6E04-011) - 2004-2006 E T.C.M. МОДУЛЬ
24240284 МОДУЛЬ, TRANS CONT [МОДУЛЬ]
teamcadillac.ru
(6E04-012) - 2004-2006 E КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS(MV3)
88996677 CASE, TRFER (FRT HALF) (INCLS 12-14)
teamcadillac.ru
19133265 CASE, TRFER (RR HALF) (INCLS 5, 7)
88996679 SNUBBER, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN
88996680 БОЛТ, TRFER CASE FRT ВЫХОДНОЙ SHF DRV CHAIN SNBR (M5X0.8X16)
88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 2)
25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL FILL) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА]
88996657 SEAL, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 2) [УПЛОТНИТЕЛЬ]
25522466 PLUG, 1/2-14 X 39/64 (TRFER CASE OIL DRN) (ACDelco #25522466) [КРЫШКА КУЛАЧКОВОГО ВАЛА]
88996680 БОЛТ, TRFER CASE VENT BFL (M5X0.8X16) (4.535)
88996658 BAFFLE, TRFER CASE VENT
89048123 БОЛТ, TRFER CASE HALF (M8X1.25X30)
88984499 PIN, TRFER CASE HALF LOC (ЧАСТЬ OF 1)
88996656 SEAL, TRFER CASE INPUT SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ]
88996657 SEAL, TRFER CASE FRT ВЫХОДНОЙ SHF (ЧАСТЬ OF 1) [УПЛОТНИТЕЛЬ]
(6E04-014) - 2004-2005 E КОРПУС КП КРЕПЛЕНИЕ (MV3,MX5)
teamcadillac.ru
11519347 БОЛТ, TRFER CASE (M10X1.5X65) (8.900) [БОЛТ]
(6E04-016) - 2004-2009 E КЛАПАН РЕГУЛИРОВКИ ДАВЛЕНИЯ В ТОРМОЗНОЙ СИСТЕМЕ
89060339 МОДУЛЬ KIT, ELEK BRK & TRACT CONT (REQS PROGRAMMING;BRK APPLY SEN REQS CALN;REFER TO SERV INFO) (ACDelco #89060339) [БЛОК УПРАВЛЕНИЯ ТОРМОЗНОЙ СИСТЕМОЙ]
89060233 VALVE KIT, BRK PRESS MOD (INCLS 3, 4) (ACDelco #89060233) [ГИДРАВЛИЧЕСКИЙ БЛОК АБС]
teamcadillac.ru
25743362 SENSOR, BRK PRESS MOD VLV PRESS (ЧАСТЬ OF 2) (ACDelco #25743362) [ДАТЧИК]
25741456 INSULATOR, BRK PRESS MOD VLV (ЧАСТЬ OF 2)
11588304 STUD, FLANGE DOUBLE END, M8X14 UNTHD, M8X1.25X13, 17 OD, 5.8, GM4345M (BRK PRESS MOD VLV BRKT)
11514596 ГАЙКА, HFH, M8X1.25, 17.9 OD, 738 THK, 13MM HEX, 10, ZF (BRK PRESS MOD VLV BRKT) (8.915) (ACDelco #11514596)
11508351 SCREW, PAN HD, C/R, 5X0.8X13, 9.3 OD, FULL THD, THD RLLR, 6171M, PC (BRK PRESS MOD VLV) (8.977)
(6E04-017) - 2004-2006 E ШЛАНГ ВЕНТИЛЯЦИИ ТРАНСМИССИИ
25764835 VENT, A/TRNS (INCLS 2, 3) (ACDelco #25764835)
25765121 VENT, A/TRNS (INCLS 2, 3) (ACDelco #25765121)
teamcadillac.ru
15955072 CLIP, TRANS VENT HOSE (ЧАСТЬ OF 1) (.650MM DIA) (2.343)
(6E04-018) - 2004-2009 E КОРПУС КП ЧАСТЬ 1 CASE COMPONENTS(MX5)
teamcadillac.ru
19180066 VENT, TRFER CASE
89048123 БОЛТ, TRFER CASE VIB DPNR (M8X1.25X30)
89048182 DAMPENER, TRFER CASE VIB
(6E04-021) - 2005 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (EXC V92)(WITHOUT THERMAL BYPASS VALVE)(2ND DES)
19129780 HOSE, TRANS FLUID CLR UPR (USE ON CARS BUILT W/OR AFTER VIN 1GYEE63A750180934. USE ON CARS BUILT PRIOR TO VIN 1GYEE63A750180934 REPL T/W 19129779 & REMOVE THERM BYPASS VLV.) (W/O BLOCK) [ТРУБКА]
19129782 HOSE, TRANS FLUID CLR UPR (USE ON CARS BUILT W/OR AFTER VIN 1GYEE637150180965. USE ON CARS BUILT PRIOR TO VIN 1GYEE637150180965 REPL T/W 19129781 & REMOVE THERM BYPASS VLV.) (W/O BLOCK) [ТРУБКА МАСЛООХЛАДИТЕЛЯ]
19129779 HOSE, TRANS FLUID CLR LWR (USE ON CARS BUILT W/OR AFTER VIN 1GYEE63A750180934. USE ON CARS BUILT PRIOR TO VIN 1GYEE63A750180934 REPL T/W 19129780 & REMOVE THERM BYPASS VLV.) (W/BLOCK) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ]
19129781 HOSE, TRANS FLUID CLR LWR (USE ON CARS BUILT W/OR AFTER VIN 1GYEE637150180965. USE ON CARS BUILT PRIOR TO VIN 1GYEE637150180965 REPL T/W 19129782 & REMOVE THERM BYPASS VLV.) (W/BLOCK)
teamcadillac.ru
88957425 COOLER, TRANS FLUID (INCLS 7-11) (ACDelco #88957425) [ВЕНТИЛЯТОР]
(6E04-022) - 2005 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ ТРУБКИ МАСЛОРАДИАТОРА (V92)(WITHOUT THERMAL BYPASS VALVE)(2ND DES)
teamcadillac.ru
89022522 COOLER, TRANS FLUID (INCLS 7-9)
(6E04-035) - 2005-2009 E BRAKE SYSTEM/ANTILOCK
teamcadillac.ru
12413103 HUB, FRT WHL (W/BRG) (СМ. ГРУППУ 06.000 "ПОДВЕСКА-ПЕРЕДНЯЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/WHL SPD SEN) (ACDelco #FW149) [СТУПИЦА КОЛЕСА]
12413105 HUB, FRT WHL (W/BRG) (СМ. ГРУППУ 06.000 "ПОДВЕСКА-ПЕРЕДНЯЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPEED SENSOR) (ACDelco #FW150) [СТУПИЦА КОЛЕСА]
89047639 HUB, RR WHL (W/WHL SPD SEN) (СМ. ГРУППУ 06.000 "ЗАДНЯЯ ПОДВЕСКА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (6 STUD HUB) (ACDelco #RW20-19) [СТУПИЦА КОЛЕСА]
10307709 SENSOR, VEH YAW (W/VEH LATL ACCLRM) [ДАТЧИК]
15906579 SENSOR, VEH YAW (W/ VEH LATL & LGTDNL ACCLRM) [ДАТЧИК]
11561645 ГАЙКА, HFH, M6X1X6.45, 13.5 OD, 10 STL, GMW3200 (VEH YAW SEN & LATL ACCLRM)
(6E04-036) - 2005-2006 E ТОРМОЗНАЯ ПЕДАЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА (JF4)
10368488 PEDAL, BRK (INCLS 12, 13, 15, 18-22)
25771615 COVER, BRK PED (ЧАСТЬ OF 11)
89047699 SENSOR KIT, BRK PED POSN (ЧАСТЬ OF 11) (INCLS 18) [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ]
teamcadillac.ru
89047780 MOTOR KIT, BRK & ACCEL PED ADJR ACTR [ЭЛЕКТРОДВИГАТЕЛЬ ПЕДАЛЬНОГО УЗЛА 19 ВТ]
11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 11, 13)
10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 11)
00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 11)
25697461 RETAINER, BRK PED PUSH ROD BOOT (ЧАСТЬ OF 11)
25741052 BRACKET, BRK PED BRKT
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (DA PNL REINF) [ГАЙКА М6]
(6M04-018) - 2004-2006 E КОРПУС КП ЧАСТЬ 2 INTERNAL COMPONENTS(MV3)
88984517 WASHER, TRFER CASE PLNT CARR SUN GR THR (25.8X52.0X2.2)
88984524 GEAR, TRFER CASE PLNT CARR SUN (INPUT) (STAMPED PM/POWDERED METAL)
88984493 RING, TRFER CASE RR ВЫХОДНОЙ SHF RR BRG RET (41MM I.D.) (ACDelco #88984493)
88996564 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT
88996665 BEARING, TRFER CASE MAIN SHF FRT (ВЫХОДНОЙ ВАЛ FRT)
19168733 BUSHING, TRFER CASE RR ВЫХОДНОЙ SHF (ЧАСТЬ OF 106) [ВТУЛКА РАЗДАТОЧНОЙ КОРОБКИ]
19178237 SHAFT, TRFER CASE RR ВЫХОДНОЙ (INCLS 105, 901)
19133264 SPROCKET, TRFER CASE FRT ВЫХОДНОЙ SHF DRV (INCLS 108) [ШЕСТЕРНЯ РАЗДАТОЧНОЙ КОРОБКИ]
19168732 BUSHING, TRFER CASE FRT ВЫХОДНОЙ SHF DRV SPKT (ЧАСТЬ OF 107) (ACDelco #19168732)
89059578 CHAIN, TRFER CASE TWO/FOUR WHL DRV [ЦЕПЬ РАЗДАТОЧНОЙ КОРОБКИ]
88984523 GEAR, TRFER CASE PLNT CARR SUN (ВЫХОДНОЙ)
89059279 КРОНШТЕЙН, TRFER CASE PLNT
89059284 SHAFT, TRFER CASE FRT ВЫХОДНОЙ (INCLS 900)
88996664 BEARING, TRFER CASE FRT ВЫХОДНОЙ SHF RR
88996671 RING, TRFER CASE FRT ВЫХОДНОЙ SHF BRG RET
88996666 SPROCKET, TRFER CASE TWO/FOUR WHL DRV DRVN [ЗВЕЗДОЧКА]
88996633 BEARING, TRFER CASE RR ВЫХОДНОЙ SHF RR (ACDelco #88996633) [ПОДШИПНИК РАЗДАТОЧНОЙ КОРОБКИ]
15580230 BEARING, TRFER CASE INPUT SHF (BORG-WARNER) (4.510)
19132966 SHAFT, TRFER CASE INPUT
teamcadillac.ru
88996681 DEFLECTOR, TRFER CASE FRT ВЫХОДНОЙ SHF SEAL DIRT (ЧАСТЬ OF 112)
(6M04-041) - 2004-2006 E26 ТОРМОЗНАЯ ПЕДАЛЬ (PWR ADJ PEDALS JF4)
11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (BRK PED POSN SEN)
89047699 SENSOR KIT, BRK PED POSN [ДАТЧИК ПОЛОЖЕНИЯ ПЕДАЛИ]
25697461 RETAINER, BRK PED PUSH ROD BOOT (ЧАСТЬ OF 21)
10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 21)
10368488 PEDAL, BRK (INCLS 5, 8-10, 13, 15-20, 22)
(6M04-042) - 2004-2006 E26 ТОРМОЗНАЯ ПЕДАЛЬ (EXC PWR ADJ PEDALS JF4)
11609999 SCREW, HEX HD FL WA, M4X0.7X20, 13 THD, 12 OD, 9.8, GMW3044, W/NYLON (ЧАСТЬ OF 18)
teamcadillac.ru
03817880 RETAINER, BRK PED PUSH ROD (ЧАСТЬ OF 18) (0.80 IN) (PUSH IN)
00410230 WASHER, ПРУЖИНА 29/64 I.D., 11/16 O.D., 5/64 THK, PL (ЧАСТЬ OF 18)
10434956 BUSHING, BRK PED PUSH ROD (ЧАСТЬ OF 18)
25771615 COVER, BRK PED (ЧАСТЬ OF 18)
25765419 PEDAL, BRK (W/BRKT) (INCLS 5-8, 10, 12-17, 19)
(6M04-044) - 2004-2009 E26 ТОРМОЗНОЙ УСИЛИТЕЛЬ & КРЕПЛЕНИЕ ГЛАВНОГО ЦИЛИНДРА
88967237 BOOSTER, P/B (СМ. ГРУППУ 04.000 "ТОРМОЗНОЙ УСИЛИТЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (W/O VLV) (ACDelco #178-0695)
10367561 CYLINDER, BRK MAS (СМ. ГРУППУ 4.000 "ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #174-1012) [ЦИЛИНДР]
11609949 ГАЙКА, BRK M/CYL (M10X1.5, 11.2 THK) (8.917) [ГАЙКА]
25873484 HOSE, P/B BOOS VAC (ACDelco #176-1497)
(GM04-064) - 2004-2009 E ТОРМОЗНОЙ СУППОРТ-ПЕРЕДНИЙ
18047980 CALIPER, FRT BRK (INCLS 2-4, 8-10) (IF DISCONTINUED USE DURASTOP EQUIVALENT) (4.667) (ACDelco #172-1643) [ТОРМОЗНОЙ СУППОРТ]
18047981 CALIPER, FRT BRK (INCLS 2-4, 8-10) (IF DISCONTINUED USE DURASTOP EQUIVALENT) (4.667) (ACDelco #172-1644) [ТОРМОЗНОЙ СУППОРТ]
18043178 COVER, FRT BRK BLEDR SCREW (ЧАСТЬ OF 1)
18047986 VALVE KIT, FRT BRK CLPR BLEDR (ЧАСТЬ OF 1) (ACDelco #18047986)
18046750 БОЛТ, FRT BRK CLPR GDE PIN (ЧАСТЬ OF 1, 11) (*KIT2) [БОЛТ]
18047985 PISTON KIT, FRT BRK CLPR (ЧАСТЬ OF 1)
18047988 PAD KIT, FRT DISC BRK (INCLS 4, 14) (ACDelco #171-665) [КОМПЛЕКТ ТОРМОЗНЫХ КОЛОДОК (4 ШТ)]
19122384 PAD KIT, FRT DISC BRK (INCLS 4, 14) (ACDelco #171-688)
18045221 SEAL, FRT BRK CLPR GDE PIN
18047987 BRACKET, FRT BRK CLPR (W/GUIDE PIN БОЛТS) [КРОНШТЕЙН]
18046698 ПРУЖИНА, FRT DISC BRK PAD RET (ЧАСТЬ OF 11) (ACDelco #179-2235)
18047989 PIN KIT, FRT BRK CLPR GDE (INCLS 5-7) (INCLS 2 (2.5") БОЛТS)
18047984 CALIPER KIT, FRT BRK (INCLS 4, 8, 9) (4.667) (ACDelco #173-0538)
(GM04-312) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (5L50-E M22,5L40-E M82)
teamcadillac.ru
96042884 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 5GDZ)
96042897 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 5GRG)
(GM04-376) - 2004-2009 E ГЛАВНЫЙ ТОРМОЗНОЙ ЦИЛИНДРР
18012741 SWITCH, BRK FLUID LVL IND (ЧАСТЬ OF 15) (ACDelco #18012741)
22688449 CAP, BRK M/CYL RSVR (ЧАСТЬ OF 15) (INCLS 3) [КРЫШКА БАЧКА ТОРМОЗНОЙ ЖИДКОСТИ]
18046711 RESERVOIR, BRK M/CYL (ЧАСТЬ OF 15) (INCLS 4, 6-7) (ACDelco #18046711)
teamcadillac.ru
18060168 PISTON, BRK M/CYL SECD (ЧАСТЬ OF 15)
10367561 CYLINDER, BRK MAS (INCLS 1-14) (ACDelco #174-1012) [ЦИЛИНДР]
18022002 CYLINDER KIT, BRK MAS (INCLS 8-12) (ACDelco #175-424)
(GM04-485) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ БЛОК (5L50-E MV3,5L40-E MX5)
96042890 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 5GGG) [АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ В СБОРЕ]
teamcadillac.ru
96042893 ТРАНСМИССИЯ, AUTO (GOODWRENCH REMAN) (CODE 5GFZ) [ТРАНСМИССИЯ В СБОРЕ]
(GM04-573) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) CASE & ДЕТАЛИ КОМПЛЕКТА
96042497 GASKET, A/TRNS CASE EXTN [ПРОКЛАДКА ТРАНСФОРМАТОРНОЙ КОРОБКИ]
96042882 EXTENSION, A/TRNS CASE (INCLS 26, 28, 29) (4.003)
96041851 SEAL, PROP SHF TRANS FLG FLUID (ЧАСТЬ OF 27) [ПРОКЛАДКА ТРАНСФОРМАТОРНОГО ВАЛА]
96042585 FLANGE, ВЫХОДНОЙ SHF [ФЛАНЕЦ]
96041805 NUT KIT, ВЫХОДНОЙ SHFT (INCLS 30, 32, 33) (M6X1.0X16)
96025472 БОЛТ, A/TRNS CASE EXTN (M8X1.25X33)
96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59)
96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39)
96042539 PLUG, A/TRNS FLUID PRESS TEST HOLE
96041860 SENSOR, A/TRNS INPUT & ВЫХОДНОЙ SPD (4.329)
96025052 БОЛТ, A/TRNS INPUT & ВЫХОДНОЙ SPD SEN (M 6 X 1.0)
teamcadillac.ru
96042962 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА)
96021290 БОЛТ, VLV BODY (M8X1X50)
96021012 БОЛТ, VLV BODY (M6X1X67.4)
96042712 DETENT, MAN SHFT
96017928 CLIP, WRG HARN
96042847 HARNESS, A/TRNS WRG
96041849 SEAL, A/TRNS WRG CONN (O RING)
96042545 FILTER KIT, A/TRNS FLUID (INCLS 36, 37, 57, 63, 64) (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ]
96042862 GASKET, A/TRNS FLUID PAN [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА]
08654701 MAGNET, A/TRNS FLUID PAN (ACDelco #8654701)
96043177 PAN KIT, A/TRNS FLUID (INCLS 63, 64)
90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (1.453)
90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (1.456)
96020254 БОЛТ, A/TRNS FLUID PAN (M6X1.0X16)
(GM04-573) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) CASE & ДЕТАЛИ КОМПЛЕКТА
96042497 GASKET, A/TRNS CASE EXTN (*KIT1) [ПРОКЛАДКА ТРАНСФОРМАТОРНОЙ КОРОБКИ]
96042496 EXTENSION, A/TRNS CASE (INCLS 26, 28, 29)
96041851 SEAL, PROP SHF TRANS FLG FLUID (ЧАСТЬ OF 27) (*KIT1) [ПРОКЛАДКА ТРАНСФОРМАТОРНОГО ВАЛА]
96042793 PLUG, A/TRNS FLUID LVL HOLE (ЧАСТЬ OF 59) (*KIT1)
96041778 SLEEVE, CTR SUPT FLUID PASG (INCLS 39) (*KIT1)
teamcadillac.ru
96042963 VALVE, CONT (W/BODY & VLV) (СМ. ГРУППУ 04.000 "CONTROL VALVE BODY" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS SPACER PLATE & GASKET)
96041849 SEAL, A/TRNS WRG CONN (O RING) (*KIT1)
96042862 GASKET, A/TRNS FLUID PAN (*KIT1) [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА]
90502556 PLUG, A/TRNS FLUID PAN DRN (ЧАСТЬ OF 59, 62) (INCLS 64) (M14) (*KIT1) (1.453)
90528145 SEAL, A/TRNS FLUID PAN DRN PLUG (O RING) (ЧАСТЬ OF 59, 62, 63) (18 X 2) (*KIT1) (1.456)
96042945 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/GSKT, SEAL, RET) (INCLS 25, 29, 36, 38, 46, 56, 60, 63, 64)
(GM04-574) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) CASE & ДЕТАЛИ КОМПЛЕКТА
96042887 GASKET, A/TRNS CASE EXTN [ПРОКЛАДКА КОРПУСА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ]
96042563 EXTENSION, A/TRNS CASE (INCLS 28, 69)
teamcadillac.ru
96042543 WASHER, INPUT & REACTION CARR THR
96042587 SEAL, PROP SHF TRANS FLG FLUID [ПРОКЛАДКА КРЫШКИ РАЗДАТОЧНОЙ КОРОБКИ]
(GM04-574) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) CASE & ДЕТАЛИ КОМПЛЕКТА
96042888 EXTENSION, A/TRNS CASE (INCLS 28, 69)
teamcadillac.ru
08677884 BEARING, ВЫХОДНОЙ SHF THR (ЧАСТЬ OF 27) (4.180) (ACDelco #8677884)
(GM04-575) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА
96042553 CONVERTER, TORQ (REMAN)
96042835 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС)
96042806 СЦЕПЛЕНИЕ, DIR & REV
96042831 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF)
96042823 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE)
96042824 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF)
teamcadillac.ru
96042701 WASHER, INPUT & REACTION CARR INR SHF THR
96042808 ШЛАНГИ, O/D CLU
96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB)
96042705 BEARING, CTR SUPT RLR (4.180)
96042826 SUPPORT, CTR
96042832 КРОНШТЕЙН, INPUT & REACTION
96042833 BEARING, INPUT & REACTION CARR THR
96042834 SHAFT, ВЫХОДНОЙ (W/RR INTL GR)
96042883 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/GSKT, SEAL, RET)
(GM04-575) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА
96042554 CONVERTER, TORQ (REMAN)
96042812 ШЛАНГИ KIT, T/CV (W/МАСЛЯНЫЙ НАСОС)
96042806 СЦЕПЛЕНИЕ, DIR & REV (СМ. ГРУППУ 04.000 "DIRECT AND REVERSE СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА)
96042807 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (СМ. ГРУППУ 04.000 "FORWARD AND COAST СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА)
96042698 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) (СМ. ГРУППУ 04.000 "INPUT SUN GEAR SHAFT AND FORWARD SPRAG СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА)
96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (СМ. ГРУППУ 04.000 "DIRECT СЦЕПЛЕНИЕ DRUM AND SHAFT" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА)
96042808 ШЛАНГИ, O/D CLU (СМ. ГРУППУ 04.000 "OVERDRIVE AND INTERMEDIATE СЦЕПЛЕНИЕ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА)
96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (СМ. ГРУППУ 04.000 "LOW СЦЕПЛЕНИЕ SPRAG" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА)
teamcadillac.ru
96042809 SUPPORT, CTR (СМ. ГРУППУ 04.000 "CENTER SUPPORT" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА)
96042707 КРОНШТЕЙН, INPUT & REACTION (СМ. ГРУППУ 04.000 "PLANETARY КРОНШТЕЙН" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (4.176)
96042708 BEARING, INPUT & REACTION CARR THR
96042709 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (СМ. ГРУППУ 04.000 "ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА)
96041847 WASHER, INPUT & REACTION CARR THR (4.265)
(GM04-576) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА
96042814 СЦЕПЛЕНИЕ, DIR & REV
96042822 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF)
teamcadillac.ru
96042827 КРОНШТЕЙН, INPUT & REACTION
96042818 BEARING, INPUT & REACTION CARR THR
96042837 SHAFT, ВЫХОДНОЙ (W/RR INTL GR)
(GM04-576) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) БЛОК СЦЕПЛЕНИЯ AND ДЕТАЛИ КОМПЛЕКТА
teamcadillac.ru
96042815 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF)
96042698 SHAFT, INPUT SUN GR (W/FWD CLU RLR INR RACE) (INCLS 9)
96042705 BEARING, CTR SUPT RLR (*KIT1) (4.180)
96042816 SUPPORT, CTR
96042817 КРОНШТЕЙН, INPUT & REACTION
96042813 SHAFT, ВЫХОДНОЙ (W/RR INTL GR)
(GM04-577) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС
teamcadillac.ru
96041855 SEAL, T/CV FLUID [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ]
96042835 ШЛАНГИ KIT, T/CV (INCLS 200-212, 214-215, 217-220, 223, 226, 227, 231-242) (W/МАСЛЯНЫЙ НАСОС)
(GM04-577) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС
96041855 SEAL, T/CV FLUID (*KIT1) [ДЕМПФЕРНЫЙ БЛОК АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ]
teamcadillac.ru
96042835 ШЛАНГИ KIT, T/CV (INCLS 200-242) (W/МАСЛЯНЫЙ НАСОС)
(GM04-577) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС
teamcadillac.ru
96042812 ШЛАНГИ KIT, T/CV (INCLS 200-215, 217-220, 223, 226-228, 231-242) (W/МАСЛЯНЫЙ НАСОС)
(GM04-577) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ГИДРОТРАНСФОРМАТОР ШЛАНГИ И ГИДРОНАСОС
teamcadillac.ru
(GM04-578) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ
96042987 GASKET KIT, A/TRNS (INCLS 303, 305, 306, 308, 309, 312, 314, 316, 330, 332) (4.265)
(GM04-578) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ
teamcadillac.ru
(GM04-578) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ
teamcadillac.ru
96042963 VALVE, CONT (W/BODY & VLV) (INCLS 300-309, 312-334) (INCLS SPACER PLATE & GASKET)
(GM04-578) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ
teamcadillac.ru
96042963 VALVE, CONT (W/BODY & VLV) (INCLS 300-334) (INCLS SPACER PLATE & GASKET)
(GM04-579) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ
teamcadillac.ru
96042599 VALVE, TCC PWM SOL
10478146 VALVE, PRESS CONT SOL (INCLS 355, 356) (ACDelco #10478146) [КЛАПАН СИСТЕМЫ АВС]
(GM04-579) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ
teamcadillac.ru
(GM04-579) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ
teamcadillac.ru
96042963 VALVE, CONT (W/BODY & VLV) (INCLS 340-351, 353-356) (INCLS SPACER PLATE & GASKET)
(GM04-579) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) FRONT БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ
teamcadillac.ru
96042963 VALVE, CONT (W/BODY & VLV) (INCLS 340-348, 351, 353-354) (INCLS SPACER PLATE & GASKET)
(GM04-580) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ
96041866 VALVE, 1-2 SHFT SOL [КЛАПАН]
96041866 VALVE, 4-5 SHFT SOL [КЛАПАН]
teamcadillac.ru
(GM04-580) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ
teamcadillac.ru
(GM04-580) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ
teamcadillac.ru
96042963 VALVE, CONT (W/BODY & VLV) (INCLS 343, 349, 350, 365-367, 370-375, 377-388) (INCLS SPACER PLATE & GASKET)
(GM04-580) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ЗАДНИЙ БЛОК УПРАВЛЕНИЯ КЛАПАНАМИ
teamcadillac.ru
96042963 VALVE, CONT (W/BODY & VLV) (INCLS 343, 351, 365-367, 370-375, 377-388) (INCLS SPACER PLATE & GASKET)
96042889 ТРАНСМИССИЯ KIT, AUTO (SERV OVERHAUL W/PLT, GSKT, SEAL) (INCLS 343, 351, 365-367, 370-375, 377-388)
(GM04-581) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК
teamcadillac.ru
(GM04-581) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК
teamcadillac.ru
96042814 СЦЕПЛЕНИЕ, DIR & REV (INCLS 400-420)
(GM04-581) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК
teamcadillac.ru
96042806 СЦЕПЛЕНИЕ, DIR & REV (INCLS 400-420)
(GM04-581) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) DIRECT & REVERSE СЦЕПЛЕНИЕ БЛОК
teamcadillac.ru
(GM04-582) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯ
teamcadillac.ru
96042831 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-432, 434-451)
(GM04-582) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯLY
teamcadillac.ru
96042822 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-451)
(GM04-582) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯ
96041856 SEAL, INPUT SHF (O RING) (*KIT1) [ПРОКЛАДКА АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ]
teamcadillac.ru
96042807 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-451)
(GM04-582) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) FORWARD & COAST ДЕТАЛИ СЦЕПЛЕНИЯ
teamcadillac.ru
96042815 СЦЕПЛЕНИЕ, FWD & COAST (W/INPUT SHF) (INCLS 430-451)
(GM04-583) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ
teamcadillac.ru
(GM04-583) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ
teamcadillac.ru
96042827 КРОНШТЕЙН, INPUT & REACTION (INCLS 455-462)
(GM04-583) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ
96042707 КРОНШТЕЙН, INPUT & REACTION (INCLS 455-462) (4.176)
(GM04-583) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) INPUT SUN GEAR SHAFT AND FORWARD SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ
teamcadillac.ru
96042817 КРОНШТЕЙН, INPUT & REACTION (INCLS 455-462)
(GM04-584) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ
teamcadillac.ru
96042824 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465)
(GM04-584) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ
teamcadillac.ru
(GM04-584) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ
teamcadillac.ru
96042700 HUB, DIR CLU (W/INPUT & REACTION CARR INR SHF) (INCLS 465)
(GM04-584) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) КОРЗИНА СЦЕПЛЕНИЯ И БЛОК ВАЛОВ
teamcadillac.ru
(GM04-585) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ
teamcadillac.ru
(GM04-585) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ
96042825 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 470-477)
(GM04-585) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ
teamcadillac.ru
96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 470-477)
(GM04-585) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) INTERMEDIATE SPRAG ДЕТАЛИ СЦЕПЛЕНИЯ
teamcadillac.ru
(GM04-586) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ
teamcadillac.ru
(GM04-586) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ
teamcadillac.ru
96042825 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 480-497)
(GM04-586) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ
teamcadillac.ru
96042702 HUB, INTER & O/D & REV CLU (W/ REACTION SUN GR SHF) (INCLS 480-497)
(GM04-586) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) OVERDRIVE & INTERMEDIATE ДЕТАЛИ СЦЕПЛЕНИЯ
teamcadillac.ru
(GM04-587) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК
teamcadillac.ru
(GM04-587) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК
96042704 ROLLER, LOW CLU (W/LOW & REV CLU HUB) (INCLS 500-505)
(GM04-587) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК
teamcadillac.ru
(GM04-587) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) LOW СЦЕПЛЕНИЕ SPRAG БЛОК
teamcadillac.ru
(GM04-588) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) КРЕПЛЕНИЕ
96042826 SUPPORT, CTR (INCLS 510-517, 519-535)
teamcadillac.ru
(GM04-588) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) КРЕПЛЕНИЕ
teamcadillac.ru
96042826 SUPPORT, CTR (INCLS 510-535)
(GM04-588) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) КРЕПЛЕНИЕ
teamcadillac.ru
96042809 SUPPORT, CTR (INCLS 510-535)
(GM04-588) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) КРЕПЛЕНИЕ
teamcadillac.ru
96042816 SUPPORT, CTR (INCLS 510-535)
(GM04-589) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) PLANETARY КРОНШТЕЙН БЛОК
96042832 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-552, 554)
teamcadillac.ru
(GM04-589) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) PLANETARY КРОНШТЕЙН БЛОК
teamcadillac.ru
96042827 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-554)
(GM04-589) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) PLANETARY КРОНШТЕЙН БЛОК
teamcadillac.ru
96042707 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-554) (4.176)
(GM04-589) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) PLANETARY КРОНШТЕЙН БЛОК
96042817 КРОНШТЕЙН, INPUT & REACTION (INCLS 540-554)
(GM04-590) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК
teamcadillac.ru
96042834 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560, 561, 563, 564)
(GM04-590) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК
teamcadillac.ru
96042709 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560-564)
(GM04-591) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК
teamcadillac.ru
96042837 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560-564)
(GM04-591) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) ЗАДНИЙ INTERNAL GEAR ВЫХОДНОЙ ВАЛ БЛОК
teamcadillac.ru
96042813 SHAFT, ВЫХОДНОЙ (W/RR INTL GR) (INCLS 560-561, 563-564)
(GM04-593) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M22) (5L50E) PARKING PAWL БЛОК
96042710 LEVER, MAN SHFT DTNT
96020016 PIN, MAN SHFT DTNT LVR [ШТИФТ]
96042540 SWITCH, A/TRNS MAN SHFT SHF POSN [ВЫКЛЮЧАТЕЛЬ ПРИВОДА]
08644709 SEAL, MAN SHFT SHF (W/O PTFE LUBRICANT APPLIED TO SEAL) (ACDelco #8644709)
96041857 SHAFT, MAN SHFT
teamcadillac.ru
96041852 PLUG, MAN SHFT SHF HOLE (4.279)
(GM04-593) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (M82) (5L40E) PARKING PAWL БЛОК
teamcadillac.ru
96042711 PAWL KIT, PARK
96041842 SPACER, MAN SHFT DTNT LVR
(GM04-594) - 2004-2006 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MV3) (5L50E) PARKING PAWL БЛОК
96042819 LEVER, MAN SHFT DTNT
96042544 SHAFT KIT, MAN SHFT
96042820 PAWL KIT, PARK
teamcadillac.ru
(GM04-594) - 2004-2009 E АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ (MX5) (5L40E) PARKING PAWL БЛОК
teamcadillac.ru
04 - ТОРМОЗА
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
12572042 PLATE, A/TRNS FLEX
11518862 БОЛТ, HEX, W/ADH, M10X1X15.5, 10.9, HDR-PT (A/TRNS FLEX PLT) [ШЕСТИУГОЛЬНЫЙ ШУРУП]
teamcadillac.ru
24222918 COVER, TRANS CONV
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (MULTIUSE RLY & FUSE BRKT) [БОЛТ М6]
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
04 - КОРПУС КП
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
04 - ТРАНСМИССИЯ - ТОРМОЗ
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
teamcadillac.ru
05 - ТОРМОЗА - ЗАДНЯЯ ОСЬ - ПРИВОДНОЙ ВАЛ - КОЛЕСА
(6D05-010) - 2004-2009 E DIFFERENTIAL КРОНШТЕЙН ЧАСТЬ 1
89058614 ГАЙКА, DIFF DRV P/GR [ВИНТ]
19179933 SEAL KIT, DIFF DRV P/GR (INCLS FLANGE (105MM), SEAL & NUT) (USE W/O CASTING NUMBER 6457038590 ON ШЛАНГИ DIFF DRV PINION GEAR, FOR 2ND DESIGN SEAL SERVICED SEPARATELY SEE 25861283.) [ФЛАНЕЦ ДИФФЕРЕНЦИАЛА]
19179935 SEAL KIT, DIFF DRV P/GR (INCLS FLANGE (96MM), SEAL & NUT) (W/VIN 50123823 AND EARLIER AND W/O CASTING #6457038590 ON HSG DIFF DRV PINION GEAR, FOR 2ND DES SEE 19179933 OR SEE 3RD DESIGN 25861283.) [ОПОРА ДИФФЕРЕНЦИАЛА]
25861283 SEAL, DIFF DRV P/GR (CAN USE SEAL ONLY W/CASTING #6457038590 ON ШЛАНГИ DIFF DRV PINION GEAR, FOR 1ST DESIGN MUST USE SEAL KIT 19179933.) [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО ДИФФЕРЕНЦИАЛА]
19178962 ШЛАНГИ, DIFF DRV P/GR BRG (INCLS 4, 8, 9) (USED ON VEHICLES WITH CASTING NUMBER 6457038590 ON DIFF P/GR ШЛАНГИ , SEE 89048176 FOR 1ST DESIGN W/O CASTING NUMBER 6457038590.)
89048176 ШЛАНГИ, DIFF DRV P/GR BRG (INCLS 4, 8, 9) (5.453) (USED ON VEHICLES W/O CASTING NUMBER 6457038590 ON DIFF P/GR ШЛАНГИ, SEE 19178962 FOR 2ND DESIGN WITH CASTING NUMBER 6457038590.)
89048209 SHIM, DIFF DRV P/GR BRG (118X168X1.30MM)
89048210 SHIM, DIFF DRV P/GR BRG (118X168X1.35MM)
89048211 SHIM, DIFF DRV P/GR BRG (118X168X1.40MM)
89048212 SHIM, DIFF DRV P/GR BRG (118X168X1.45MM)
89048213 SHIM, DIFF DRV P/GR BRG (118X168X1.50MM)
89048214 SHIM, DIFF DRV P/GR BRG (118X168X1.55MM)
89048215 SHIM, DIFF DRV P/GR BRG (118X168X1.60MM)
89048216 SHIM, DIFF DRV P/GR BRG (118X168X1.65MM)
89048217 SHIM, DIFF DRV P/GR BRG (118X168X1.70MM)
89048218 SHIM, DIFF DRV P/GR BRG (118X168X1.75MM)
89048219 SHIM, DIFF DRV P/GR BRG (118X168X1.80MM)
89048220 SHIM, DIFF DRV P/GR BRG (118X168X1.85MM)
89048221 SHIM, DIFF DRV P/GR BRG (118X168X1.90MM)
88984427 SEAL, DIFF DRV P/GR (O RING)
89058602 БОЛТ, DIFF CARR CVR (M8X1.25X30, 24 THD) (FLANGE HEAD) (5.476)
89058605 BUSHING, DIFF CARR SUPT (BUSHING W/METAL SLEEVE) [ВТУЛКА КОРПУСА ДИФФЕРЕНЦИАЛА]
88996591 SEAL, R/AXL SHF
89059039 PLUG, R/AXL HSG MAG DRN
89058621 SHIM, DIFF BRG (79X89.3X1.30MM)
89058622 SHIM, DIFF BRG (79X89.3X1.35MM)
89058623 SHIM, DIFF BRG (79X89.3X1.40MM)
89058624 SHIM, DIFF BRG (79X89.3X1.45MM)
89058625 SHIM, DIFF BRG (79X89.3X1.50MM)
89058626 SHIM, DIFF BRG (79X89.3X1.55MM)
89058627 SHIM, DIFF BRG (79X89.3X1.60MM)
89058628 SHIM, DIFF BRG (79X89.3X1.65MM)
89058629 SHIM, DIFF BRG (79X89.3X1.70MM)
89058630 SHIM, DIFF BRG (79X89.3X1.75MM)
89058631 SHIM, DIFF BRG (79X89.3X1.80MM)
89058632 SHIM, DIFF BRG (79X89.3X1.85MM)
89058633 SHIM, DIFF BRG (79X89.3X1.90MM)
89058634 SHIM, DIFF BRG (79X89.3X1.95MM)
89058635 SHIM, DIFF BRG (79X89.3X2.00MM)
89058636 SHIM, DIFF BRG (79X89.3X2.05MM)
89058637 SHIM, DIFF BRG (79X89.3X2.10MM)
89058638 SHIM, DIFF BRG (79X89.3X2.15MM)
89058639 SHIM, DIFF BRG (79X89.3X2.20MM)
teamcadillac.ru
89058640 SHIM, DIFF BRG (79X89.3X2.25MM)
89058641 SHIM, DIFF BRG (79X89.3X2.30MM)
89058642 SHIM, DIFF BRG (79X89.3X2.35MM)
89058643 SHIM, DIFF BRG (79X89.3X2.40MM)
88964481 BEARING, DIFF CARR
19133286 DIFFERENTIAL, (СМ. ГРУППУ 05.000 "DIFFERENTIAL КРОНШТЕЙН ЧАСТЬ 2" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА)
89058617 SEAL, DIFF CARR CVR
19207629 COVER, DIFF CARR
15852707 VENT, R/AXL HSG [КЛАПАН]
89059038 PLUG, DIFF CARR FILL (M20X1.5X14) (W/SEAL)
89048225 БОЛТ, RR DIFF R/GR (M12 X 25 MM)
89060126 БОЛТ, RR DIFF R/GR
19178776 КРОНШТЕЙН, DIFF (3.23 RATIO) (INCLS 1-24) (COMPLETE/USE T/W 25730853 HSG VENT WHEN ORDERING DIFF КРОНШТЕЙН) (WITH THE LAST 8 OF VIN# 50123823 AND EARLIER) (FOR 2ND DESIGN SEE 25978161.)
19178778 КРОНШТЕЙН, DIFF (3.73 RATIO) (INCLS 1-24)
19178779 КРОНШТЕЙН, DIFF (3.90 RATIO) (INCLS 1-24) (WITH THE LAST 8 OF VIN# 50123824 AND LATER) (FOR 1ST DESIGN SEE 19181710. ALSO NEED TO ORDER R/AXLE HSG VENT 25730853 WHEN ORDERING DIFF КРОНШТЕЙН)
19178781 КРОНШТЕЙН, DIFF (3.73 RATIO) (INCLS 1-24)
19178783 КРОНШТЕЙН, DIFF (3.73 RATIO) (INCLS 1-24) (WITH LAST 8 OF VIN OF 50123823 AND EARLIER) (FOR 2ND DES SEE 15208637)
19181709 КРОНШТЕЙН, DIFF (3.23 RATIO) (INCLS 1-24) (1ST DESIGN USED ON VEHICLES WITH THE LAST 8 OF VIN# 50123823 AND EARLIER FOR 2ND DESIGN SEE 25978161.)
19181710 КРОНШТЕЙН, DIFF (3.90 RATIO) (INCLS 1-24) (5.510) (WITH THE LAST 8 OF VIN# 50123823 AND EARLIER) (FOR 2ND DESIGN SEE 19178779)
25978161 КРОНШТЕЙН, DIFF (3.23 RATIO) (INCLS 1-24) (WITH THE LAST 8 OF VIN# 50123824 AND LATER) (FOR 1ST DESIGN SEE 19178776.) [РЕДУКТОР ДИФФЕРЕНЦИАЛА ВЕДУЩЕГО МОСТА]
25978162 КРОНШТЕЙН, DIFF (3.23 RATIO) (INCLS 1-24) (ALSO NEED TO ORDER R/AXLE HSG VENT 25730853 WHEN ORDERING DIFF КРОНШТЕЙН)
89048143 GEAR SET, DIFF RING & DRV PINION (3.91 RATIO) (INCLS 14)
89048144 GEAR SET, DIFF RING & DRV PINION (3.23 RATIO) (INCLS 14)
89048145 GEAR SET, DIFF RING & DRV PINION (3.73 RATIO) (INCLS 14)
19179933 SEAL KIT, DIFF DRV P/GR (INCLS 2) (INCLS FLANGE (105MM), SEAL & NUT) (USE W/O CASTING NUMBER 6457038590 ON ШЛАНГИ DIFF DRV PINION GEAR, FOR 2ND DESIGN SEAL SERVICED SEPARATELY SEE 25861283.) [ФЛАНЕЦ ДИФФЕРЕНЦИАЛА]
19179935 SEAL KIT, DIFF DRV P/GR (INCLS 2) (INCLS FLANGE (96MM), SEAL & NUT) (W/VIN 50123823 AND EARLIER AND W/O CASTING #6457038590 ON HSG DIFF DRV PINION GEAR, FOR 2ND DES SEE 19179933 OR SEE 3RD DESIGN 25861283.) [ОПОРА ДИФФЕРЕНЦИАЛА]
(6D05-012) - 2004-2009 E ВАЛ ЗАДНЕЙ ОСИ
90223082 RING, R/AXL SHF RET
88957217 CЛАМПА, RR WHL DRV SHF CV JT BOOT INR (*KIT1, KIT3)
88957218 CЛАМПА, RR WHL DRV SHF TRI-POT JT BOOT (*KIT1, KIT3)
88957222 CЛАМПА, RR WHL DRV SHF TRI-POT JT BOOT (*KIT1, KIT3)
teamcadillac.ru
15919079 SHAFT, RR WHL DRV (MUST ALSO ORDER DRV SHF NUT 10289657) [ВАЛ ПРИВОДА КОЛЕСА]
15919080 SHAFT, RR WHL DRV (MUST ALSO ORDER DRV SHF NUT 10289657)
89021677 LUBRICANT, GR SYNTHETIC, SAE 75W-90, 1 QT, (R/AXL) (*KIT1, KIT3) [ТРАНСМИССИОННОЕ МАСЛО ВЕДУЩЕГО МОСТА SAE 75W-90 (0.946Л)]
88957218 CЛАМПА, RR WHL DRV SHF CV JT BOOT (*KIT2, KIT4)
88957222 CЛАМПА, RR WHL DRV SHF CV JT BOOT (*KIT2, KIT4)
88957219 CЛАМПА, RR WHL DRV SHF CV JT BOOT OTR (*KIT2, KIT4)
88957223 CЛАМПА, RR WHL DRV SHF CV JT BOOT OTR (*KIT2, KIT4)
15850906 RING, RR WHL DRV SHF INR CV JT INR RACE RET (*KIT1, KIT2, KIT3, KIT4)
89021677 LUBRICANT, GR SYNTHETIC, SAE 75W-90, 1 QT, (R/AXL) (*KIT2, KIT4) [ТРАНСМИССИОННОЕ МАСЛО ВЕДУЩЕГО МОСТА SAE 75W-90 (0.946Л)]
10289657 ГАЙКА, RR WHL DRV UJT SHF (M24X2.0X19.6) (HEX W/WASHER, PREVAILING TORQUE) (6.056) [ГАЙКА М24]
15919079 SHAFT, RR WHL DRV (INCLS 1-20) (MUST ALSO ORDER DRV SHF NUT 10289657) [ВАЛ ПРИВОДА КОЛЕСА]
15919080 SHAFT, RR WHL DRV (INCLS 1-20) (MUST ALSO ORDER DRV SHF NUT 10289657)
89060333 SHAFT KIT, RR WHL DRV (INCLS 1-20) [ОСЬ]
89060334 SHAFT KIT, RR WHL DRV (INCLS 1-20) [ОСЬ]
88957227 BOOT KIT, RR WHL DRV SHF TRI-POT JT (INCLS 6-8, 10, 14) (INCLS RETAINING RING & NUT)
88957229 BOOT KIT, RR WHL DRV SHF TRI-POT JT (INCLS 6-8, 10, 14)
88957228 BOOT KIT, RR WHL DRV SHF CV JT (11-14, 18) (INCLS RETAINING RING & NUT)
88957230 BOOT KIT, RR WHL DRV SHF CV JT (11-14, 18) [ПЫЛЬНИК ПРИВОДНОГО ВАЛА]
(6D05-013) - 2004-2006 E ВАЛ ПРИВОДА-КАРДАННЫЙ ВАЛ КРЕПЛЕНИЕ (M22,M82)
25771589 SHAFT, PROP
25771590 SHAFT, PROP
11589166 БОЛТ, HEX W/CON WA, M10X1.5X39.8, 25.45 THD, 28 OD, 10.9, GMW3359, M-PT (PROP SHF BRG SUPT)
25708829 SHIM, PROP SHF CTR SUPT BRG (BLACK) (OVERALL HEIGHT 2MM) [ПРОКЛАДКА]
25708830 SHIM, PROP SHF CTR SUPT BRG (GREEN) (OVERALL HEIGHT 4MM) [ПРОКЛАДКА]
25708831 SHIM, PROP SHF CTR SUPT BRG (BLUE) (OVERALL HEIGHT 6MM) [ПРОКЛАДКА]
25708832 SHIM, PROP SHF CTR SUPT BRG (YELLOW) (OVERALL HEIGHT 8MM) [ШАЙБА]
teamcadillac.ru
25708833 SHIM, PROP SHF CTR SUPT BRG (WHITE) (OVERALL HEIGHT 10MM) [ШАЙБА]
25708834 SHIM, PROP SHF CTR SUPT BRG (PURPLE) (OVERALL HEIGHT 12MM) [ШАЙБА]
11588658 БОЛТ, FRT PROP SHF (M12X1.75X70) (HEX) (8.900) [БОЛТ]
11588689 WASHER, FRT PROP SHF (ID 12.25, OD 23.0, THK 3.38MM) [ШАЙБА]
11516073 ГАЙКА, FRT PROP SHF (M12X1.75X11.5, 10) (HEX LK PREV TORQ) (7111M ZE) (8.917) [ГАЙКА М12Х1.75Х11.5]
11588689 WASHER, RR PROP SHF (ID 12.25, OD 23.0, THK 3.38MM) [ШАЙБА]
11588658 БОЛТ, RR PROP SHF (M12X1.75X70) (HEX) (8.900) [БОЛТ]
(6D05-014) - 2004-2009 E DIFFERENTIAL КРОНШТЕЙН КРЕПЛЕНИЕ
11519079 БОЛТ, DIFF CARR FRT (M14X2X130, 71THD) (8.900)
11519150 БОЛТ, DIFF CARR FRT (M14X2X100) (5.383)
11516382 ГАЙКА, DIFF CARR FRT (M14X2X15) (W/O J CLIP RETAINER) (8.917) [ГАЙКА М10]
teamcadillac.ru
11519079 БОЛТ, DIFF CARR RR (M14X2X130, 71THD) (8.900)
(6D05-020) - 2005-2006 E DIFFERENTIAL КРОНШТЕЙН ЧАСТЬ 2 (G80)
teamcadillac.ru
89058607 CASE, DIFF (COVER HALF)
12458083 DISC KIT, L/SLIP DIFF CLU (INCLS 3, 4)
89048116 WASHER, LKG DIFF CLU DISC THR (5.511)
89058604 WASHER, DIFF P/GR THR
89058612 GEAR, DIFF PINION
19207615 GEAR, DIFF SI (5.528)
19180944 SHAFT, DIFF P/GR
89058606 CASE, DIFF (ШЛАНГИ HALF)
(6D05-021) - 2005-2006 E DIFFERENTIAL КРОНШТЕЙН ЧАСТЬ 2 (EXC (G80))
teamcadillac.ru
19133286 DIFFERENTIAL, (INCLS 2-8)
(6E05-007) - 2004-2005 E КОЛЕСА & КОЛЕСО COVERS
09596270 КОЛЕСО, 17X7.5 (КРАСКАED)
teamcadillac.ru
09594681 ГАЙКА, WHL (M12X1.5)
09596271 CAP, HUB (SILVER SPARKLE)
19209740 WEIGHT, WHL BAL (CLIP-ON REPLACEMENT) (TRIM AS REQUIRED) (WHL BAL)
00274288 STEM, ШИНА VLV (.453 HOLE, 1.25 LONG) (INCLS CAP)
09596273 КОЛЕСО, 18X8 (SILVER SPARKLE)
09596274 CAP, HUB (SPARKLE SILVER)
25774006 SENSOR, ШИНА PRESS IND (INCLS 9, 11, 12) (INCLS VALVE, GROMMET, CAP) (ACDelco #25774006) [ДАТЧИК]
25754190 GROMMET, ШИНА VLV STEM (ЧАСТЬ OF 8) [УПЛОТНЯЮЩЕЕ КОЛЬЦО]
15234846 ГАЙКА, ШИНА PRESS IND SEN (14 X 19) [ГАЙКА М8]
25715244 VALVE, ШИНА (ЧАСТЬ OF 8) [ОБРАТНЫЙ КЛАПАН ШИНЫ КОЛЕСА]
25731359 CAP, ШИНА PRESS IND SEN (ЧАСТЬ OF 8) (CHROME) [КОЛПАЧОК НИППЕЛЯ КОЛЕСА]
(6E05-009) - 2004-2006 E ВАЛ ПРИВОДА-КАРДАННЫЙ ВАЛ КРЕПЛЕНИЕ/FRONT (MV3,MX5)
15212141 SHAFT, F/AXL PROP (INCLS 2) [КАРДАННЫЙ ВАЛ]
teamcadillac.ru
10363385 RETAINER, FRT PROP SHF (ЧАСТЬ OF 1) (INCLS 2 M8X1.25X45 БОЛТS AND 1 БОЛТ LOCK) [СЕРЬГА КАРДАННОГО ВАЛА]
(6E05-015) - 2005-2006 E ВАЛ ПРИВОДА-КАРДАННЫЙ ВАЛ КРЕПЛЕНИЕ/ЗАДНИЙ (MV3,MX5)
15210791 SHAFT, PROP (USE WITH LAST 6 OF VIN 123824 AND LATER. FOR 1ST DESIGN SEE 25755438) (INCLS 6) [КАРДАННЫЙ ВАЛ]
teamcadillac.ru
25771588 SHAFT, PROP (USE WITH LAST 6 OF VIN 123823 AND EARLIER. FOR 2ND DESIGN SEE 15210791) (INCLS 6)
11516073 ГАЙКА, RR PROP SHF (M12X1.75X11.5, 10) (HEX LK PREV TORQ) (7111M ZE) (8.917) [ГАЙКА М12Х1.75Х11.5]
11517380 БОЛТ, HEX W/CON WA, M10X1.5X40, 21.52 THD, 28 OD, 10.9, 7114M, MACH, P-PT (PROP SHF BRG SUPT)
(GM05-007) - 2005-2009 E ШИНА
89034137 ШИНА, FRT (ШИНА MFG # 94200) (INSTALL .25) (SINGLE 14.0KGS) (MICHELIN, PIL, HXMXM4, TL, 235/60R18) (ACDelco #M94200)
89049534 ШИНА, RR (ШИНА MFG # 732371500) (GOODYEAR, EAGLE RS-A, 255/60R17, VSB) (ACDelco #HN371500)
89049536 ШИНА, FRT (ШИНА MFG # 732957500) (GOODYEAR, EAGLE RS-A, 235/65R17, VSB) (ACDelco #HN957500)
89050131 ШИНА, RR (ШИНА MFG # 51820) (INSTALL .25) (SINGLE 15.2KGS) (MICHELIN, PIL, HXMXM4, 255/55R18) (ACDelco #M51820)
06 - ПЕРЕДНЯЯ ПОДВЕСКА - РУЛЕВОЕ УПРАВЛЕНИЕ
(6E06-002) - 2004-2009 E ПОДВЕСКА-ПЕРЕДНЯЯ
11519393 БОЛТ, HEX W/CON ПРУЖИНА WA, M12X1.75X50, 35 OD, 42 THD, 10.9, 7114M (FRT S/ABS UPR BRKT)
15815517 ГАЙКА, FRT S/ABS STUD
25700262 PLUG, FRT S/ABS ACC HOLE [ЗАГЛУШКА]
19181783 BRACKET, FRT UPR CONT ARM (INCLS 6-11, 44-46) [РЫЧАГ ПОДВЕСКИ С УСТАНОВОЧНЫМ УЗЛОМ]
19181784 BRACKET, FRT UPR CONT ARM (INCLS 6-11, 44-46) [РЫЧАГ ПОДВЕСКИ С УСТАНОВОЧНЫМ УЗЛОМ]
19181785 BRACKET, FRT UPR CONT ARM (INCLS 6-11, 44-46) [РЫЧАГ ПОДВЕСКИ]
25847433 BRACKET, FRT UPR CONT ARM (INCLS 6-11, 44-46)
11515784 БОЛТ, HEX FLNG HD (12X1.75X75) (PZOR 10.9) (ЧАСТЬ OF 3)
25807366 РАМА, DRIVETRAIN & FRT SUSP [РАМА]
25807367 РАМА, DRIVETRAIN & FRT SUSP
25807368 РАМА, DRIVETRAIN & FRT SUSP
25807369 РАМА, DRIVETRAIN & FRT SUSP
11519151 БОЛТ, FRT LWR CONT ARM (FRT) (HFH, M14X2X110) (POINTED POINT) (7.039)
03537773 ГАЙКА, FRT LWR CONT ARM RR (M14X2X11.92) (HEX W/CONICAL WA PREV TORQ) (5.383)
25862781 ARM, FRT LWR CONT (INCLS 16, 18, 31) [РЫЧАГ]
25862782 ARM, FRT LWR CONT (INCLS 16, 18, 31) [РЫЧАГ ПОДВЕСКИ]
18048936 KNUCKLE, STRG
18048937 KNUCKLE, STRG
11519879 ГАЙКА, FRT UPR CONT ARM BALL STUD (M12X1.75X16.75, 28 OD) (8.915) [ВИНТ В СБОРЕ]
18047194 SHIELD, FRT BRK (6.323)
18047195 SHIELD, FRT BRK (6.323)
18061004 SHIELD, FRT BRK
18061005 SHIELD, FRT BRK
09595178 STUD, FRT WHL (ЧАСТЬ OF 23) (БОЛТ-ROUND HEAD, M12X1.5X40, W/SERRATIONS, GM6177M STL, GMW14)
12413103 HUB, FRT WHL (W/BRG) (INCLS 22) (W/WHL SPD SEN) (ACDelco #FW149) [СТУПИЦА КОЛЕСА]
12413105 HUB, FRT WHL (W/BRG) (INCLS 22) (INCLS SPEED SENSOR) (ACDelco #FW150) [СТУПИЦА КОЛЕСА]
18048934 ROTOR, FRT BRK (ACDelco #18048934)
19175345 ROTOR, FRT BRK (ACDelco #18A1754) (DURASTOP)
19241906 ROTOR, FRT BRK (ACDELCO ADVANTAGE) [ТОРМОЗНОЙ ДИСК]
11515720 БОЛТ, FRT BRK ROT (M6X1X20, 12.3 OD) (FLAT 6 LOBED) (14.5 THD) (8.908) [ВИНТ]
10282253 ГАЙКА, S/KNU (M14X2.0 6H THD) (6.164) [ГАЙКА М14]
18060356 БОЛТ, FRT BRK CLPR
18060469 БОЛТ, FRT WHL HUB
11588357 ГАЙКА, FRT STAB SHF LINK (AT SHF) (M12X1.75, 13.5 THK) (14.875) [ВИНТ В СБОРЕ]
11519961 БОЛТ-HFH M12X1.75X75, 28.25 THD, 26.6 OD, 10.9, 7114M, MACH, HDR-PT (FRT S/ABS YOKE)
25764673 YOKE, FRT S/ABS
25764674 YOKE, FRT S/ABS
11516383 ГАЙКА, HFH LK 16X2X18.9 34.2 OD 10 7111M PREV TORQ (FRT LWR CONT ARM) [ГАЙКА]
11516078 ГАЙКА, HFH, M12X1.75, 14THK, 25 O.D., 10, PZOR (FRT S/ABS YOKE) [ГАЙКА]
03537773 ГАЙКА, FRT LWR CONT ARM FRT (M14X2X11.92) (HEX W/CONICAL WA PREV TORQ) (5.383)
11519151 БОЛТ, FRT LWR CONT ARM (HFH, M14X2X110) (POINTED POINT) (7.039)
25750245 RETAINER, FRT STAB SHF INSL [ФИКСАТОР ПОДВЕСКИ]
10368394 SHAFT, FRT STAB
25759231 INSULATOR, FRT STAB SHF [ВТУЛКА СТАБИЛИЗАТОРА ПОДВЕСКИ]
teamcadillac.ru
10364742 CЛАМПА, FRT STAB SHF INSL
11515775 БОЛТ, HFH, M12X1.75X30, 10.9, 7114M (FRT STAB SHF INSL CLA) [БОЛТ]
15231140 LINK, FRT STAB SHF [РЫЧАГ СТАБИЛИЗАТОРА ПОДВЕСКИ]
03537772 ГАЙКА, FRT UPR CONT ARM (ARM TO ARM BRKT) (ЧАСТЬ OF 3) (M12X1.75) (8.917)
15815517 ГАЙКА, FRT S/ABS STUD (ЧАСТЬ OF 12)
88952018 WASHER KIT, FRT S/ABS (INCLS 4, 5) (INCLS 2-WASHERS AND 1-NUT) [УПОР ПРУЖИНЫ ПОДВЕСКИ]
88955519 WASHER KIT, FRT S/ABS (INCLS 4, 5) (INCLS 1-WASHER AND 2-NUTS) [НАБОР ШАЙБ]
(6E06-004) - 2004-2006 E НАСОС РУЛЕВОГО УПРАВЛЕНИЯ LINES (LH2/4.6A, EXC V92)
88964536 CAP, P/S FLUID RSVR
19133714 RESERVOIR, P/S PUMP FLUID
88967187 BRACKET, P/S FLUID RSVR
88964537 БОЛТ, P/S FLUID RSVR BRKT
15251169 HOSE, P/S FLUID RSVR OTLT (INCLS 5)
03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (P/S FLUID RSVR BRKT)
88957180 SEAL, P/S GR INL HOSE FTG (O RING) (ЧАСТЬ OF 11)
teamcadillac.ru
88957182 FITTING, P/S GR INL HOSE (ЧАСТЬ OF 11)
19133715 HOSE, P/S GR INL (INCLS 9, 10, 13)
11517937 БОЛТ, HWH, M8X1.25X22.1, 13.85 THD, 15 OD, 9.8, 7114M, MACH, 6175M ADH, MAT-PT (P/S GR INL PIPE BRKT) [БОЛТ М8Х22]
10388415 HOSE, P/S GR OTLT (INCLS 14, 18) [ТРУБКА НАСОСА ГУРА]
10199206 БОЛТ, P/S GR INL & OTLT PIPE RET (M6X1.0X18) (4.785)
11516885 SCREW, HFH W/FL WA, TAP, M8X1.25X20, 7THD, 17 O.D., TR PT, 6202M, PZOR (P/S FLUID CLR HOSE CLIP)
15236156 COOLER, P/S FLUID (REFER TO BULLETIN 04-02-32-004 FOR INSTALLATION INSTRUCTION) [РАДИАТОР]
10376949 HOSE, P/S FLUID CLR OTLT (INCLS 19) (FOR USE W/ELECTRIC ОХЛАЖДЕНИЕ)
88964534 SEAL KIT, P/S GR OTLT HOSE CONN (INCLS 13, 14) [КОМПЛЕКТ ПРОКЛАДОК ТРУБКИ ГУРА (2 ШТ)]
(6E06-008) - 2004-2006 E НАСОС РУЛЕВОГО УПРАВЛЕНИЯ LINES (LH2/4.6A, V92)
25900771 PUMP, P/S (СМ. ГРУППУ 06.000 "НАСОС РУЛЕВОГО УПРАВЛЕНИЯ ASM" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [НАСОС ГУРА]
10376954 HOSE, P/S FLUID CLR INL & OTLT (INCLS 21) [ТРУБКА СИСТЕМЫ РУЛЕВОГО УПРАВЛЕНИЯ]
11516931 БОЛТ, FLAT WA & METRIC HEX HD MACHINE, M8X1.25X50 (P/S FLUID CLR BRKT)
10376952 HOSE, P/S FLUID CLR OTLT (INCLS 19) (FOR USE W/MECHANICAL ОХЛАЖДЕНИЕ) [ТРУБКА ГИДРОУСИЛИТЕЛЯ РУЛЯ]
teamcadillac.ru
19130354 CONDENSER, КОНДИЦИОНЕР (СМ. ГРУППУ 09.000 "КОНДИЦИОНЕР СИСТЕМА ОХЛАЖДЕНИЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #15-63540)
(6E06-009) - 2004-2009 E НАСОС РУЛЕВОГО УПРАВЛЕНИЯ КРЕПЛЕНИЕ (LH2/4.6A)
11519980 БОЛТ, HFH, M8X1.25X40, 22 THD, 18 OD, 8.8, GMW3359, 6MM MATPOINT. (P/S PUMP)
11515770 БОЛТ, HFH, RED BODY, M10X1.5X50, THD 22.3, 9.8, 7114, PZOR (P/S PUMP BRKT) [БОЛТ М10Х1.5Х50]
teamcadillac.ru
12565097 BRACKET, P/S PUMP
11516360 БОЛТ, HFH M10X1.2X90, 9.8, 7114M, 22.3 OD HDR PT (P/S PUMP BRKT)
12604687 PULLEY, P/S PUMP
(6E06-010) - 2004-2006 E DRIVE AXLE КРЕПЛЕНИЕ/FRONT (MV3,MX5)
25790586 SHIELD, F/AXL PROP SHF HT
11514139 БОЛТ, W/WA M6X1X26, 17 OD, HDR PNT, FULL THD, 9.8, POR (F/AXL PROP SHF HT SHLD) [БОЛТ]
11519346 БОЛТ, FRT DIFF CARR (БОЛТ-HFH W/CON WA, M12X1.75X60, 34 THD)
11518121 ГАЙКА, U, M6X1, MULTI THD, .5'-4.0' THK PNL (F/AXL PROP SHF HT SHLD PROPELLER SHAFT)
11519348 БОЛТ, HFH, M10X1.5X41.35, 29.2 THD, 22.3 OD, 10.9, GMW3359 (FRT WHL DRV INTER SHF HSG)
25714853 ШЛАНГИ, FRT WHL DRV INTER SHF (INCLS 8-10) (INCLS BEARING & RETAINER) [ЧЕХОЛ ПРИВОДА]
88996676 RETAINER, FRT WHL DRV INTER SHF BRG (ЧАСТЬ OF 7)
(6E06-011) - 2004-2009 E НАСОС РУЛЕВОГО УПРАВЛЕНИЯ ASM (LH2/4.6A)
25900771 PUMP, P/S (INCLS 2-5) [НАСОС ГУРА]
88957182 FITTING, P/S GR INL HOSE (ЧАСТЬ OF 1)
(6E06-012) - 2004-2009 E РУЛЕВОЙ МЕХАНИЗМ В СБОРЕ
25983243 GEAR, STRG (INCLS 1-3, 5-10) [РУЛЕВАЯ РЕЙКА В СБОРЕ]
11561800 CЛАМПА-CRIMP, 33.5 DIA, 304 STAINLESS STEEL (ЧАСТЬ OF 4)
88957175 ГАЙКА, STRG LNKG INR TIE ROD (ЧАСТЬ OF 4, 9)
19152532 ROD KIT, STRG LNKG INR TIE (ЧАСТЬ OF 4) (INCLS 8) (NO LONGER SERVICED, ONLY ЧАСТЬ OF РУЛЕВОЙ МЕХАНИЗМ)
88957172 ROD KIT, STRG LNKG OTR TIE (ЧАСТЬ OF 4) (INCLS 8) [НАКОНЕЧНИК РУЛЕВОЙ ТЯГИ]
88957176 ROD KIT, STRG LNKG OTR TIE (ЧАСТЬ OF 4) (INCLS 8) [НАКОНЕЧНИК РУЛЕВОЙ ТЯГИ]
teamcadillac.ru
19133662 SOLENOID, S/GR VLV (ЧАСТЬ OF 4) [КЛАПАН КОНТРОЛЯ ДАВЛЕНИЯ ЖИДКОСТИ ГУРА]
(6E06-013) - 2004-2006 E DRIVE SHAFT/FRONT КОЛЕСО (MV3,MX5)
88957231 JOINT KIT, FRT WHL DRV SHF TRI-POT (INCLS 1, 4-9) (ЧАСТЬ OF 10) [СОЕДИНИТЕЛЬНЫЙ ЭЛЕМЕНТ ПРИВОДА]
88957232 JOINT KIT, FRT WHL DRV SHF TRI-POT (INCLS 1, 4-9) (ЧАСТЬ OF 10)
88957213 CЛАМПА, FRT WHL DRV SHF TRI-POT JT BOOT OTR (ЧАСТЬ OF 2, 3, 10) (*KIT1)
88957214 CЛАМПА, FRT WHL DRV SHF TRI-POT JT BOOT INR (ЧАСТЬ OF 2, 3, 10) (*KIT1)
88957150 SHAFT KIT, FRT WHL DRV (INCLS 1-9, 11-18)
88957151 SHAFT KIT, FRT WHL DRV (INCLS 1-9, 11-18) [ПРИВОД КОЛЕСА В СБОРЕ]
88957214 CЛАМПА, FRT WHL DRV SHF CV JT BOOT INR (ЧАСТЬ OF 10) (*KIT2, KIT3)
88957215 CЛАМПА, FRT WHL DRV SHF CV JT BOOT OTR (ЧАСТЬ OF 10) (*KIT2, KIT3)
teamcadillac.ru
88957225 BOOT KIT, FRT WHL DRV SHF TRI-POT JT (INCLS 6, 8, 9) [ПЫЛЬНИК ШРУСА]
88957226 BOOT KIT, FRT WHL DRV SHF CV JT (INCLS 11-14) [ПЫЛЬНИК ШРУСА]
88957233 JOINT KIT, FRT WHL DRV SHF C/V (INCLS 11-18) [ШРУС В СБОРЕ]
(6E06-014) - 2004-2006 E СИСТЕМА РУЛЕВОГО УПРАВЛЕНИЯ & ДЕТАЛИ КОМПЛЕКТА
15235880 COLUMN, STRG (EBONY)
25773078 COLUMN, STRG (EBONY) (CODE 3058)
25773079 COLUMN, STRG (EBONY) (CODE 3059)
25773080 COLUMN, STRG (EBONY) (CODE 3060)
teamcadillac.ru
11514602 ГАЙКА, HEX, M8X1.25, 6.8THK, 13 O.D., 10, ZF (STRG COL UPR SUPT)
11509418 БОЛТ, INTER STRG SHF (M8 X 1.25 X 30.00) (8.900)
25763618 SEAL, INTER STRG SHF UPR
25767302 SHAFT, LWR INTER STRG [ВАЛ РУЛЕВОЙ КОЛОНКИ]
11518143 БОЛТ, INTER STRG SHF LWR (M10X1.5X38, 14.5) (8.900) [БОЛТ М10]
11516078 ГАЙКА, STRG LNKG OTR TIE ROD (M12X1.75X18) (8.917) [ГАЙКА]
11589135 БОЛТ, S/GR (M12X1.75X85, 60THD) (8.900)
11516245 ГАЙКА, HEX W/CON AND SEALING WA, M8X1.25, 7.5THK, 24 O.D., 9, PEOR (STRG COL SUPT BRKT)
25757655 BRACKET, STRG COL SUPT
25642753 ГАЙКА, STRG COL (ЧАСТЬ OF 1) (M8X1.25 X 47.91) (O/A DOUBLE END STUD W/E7 TORX STEM & ROUND SHOULDER)
11517031 ГАЙКА, HFH, M8X1.25, 9.4THK, 17.4 O.D., 10, TIN ZN (STRG COL SUPT BRKT)
25606907 ГАЙКА, STRG COL (ЧАСТЬ OF 1) (M8X1.25, 7.1THK) (SQUARE) (SUPT BRKT NUT) (6.760)
25767301 SHAFT, STRG [ВАЛ РУЛЕВОЙ КОЛОНКИ]
(6E06-015) - 2004-2009 E РУЛЕВАЯ КОЛОНКА
26097517 COVER KIT, STRG COL TR (INCLS 2) (EBONY)
26103612 COVER KIT, STRG COL TR (INCLS 2) (EBONY)
26094840 SWITCH, BRK & ACCEL PED ADJR (4.626)
11609659 ГАЙКА, STRG WHL (M14X1.5, 10THK, 27OD) (FLANGED) (8.917) [ГАЙКА]
00274414 RING, EXT, SNAP, FITS M19 OR.75" SHAFT, STL, PL (STRG WHL INFL RST MDL РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ RET)
26011609 WASHER, STRG WHL INFL RST MDL РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ [ШАЙБА D=14ММ]
05694191 RING, STRG SHF LK PLT RET (*KIT1) (6.524)
26094767 PLATE, STRG SHF LK (W/O SHIELD) (*KIT1)
26044739 CAM, T/SIG SW CANC (W/СИГНАЛ CONTACT) (*KIT1)
26055299 ПРУЖИНА, STRG SHF UPR BRG (*KIT1)
15231641 SEAT, STRG SHF UPR BRG RACE (*KIT1)
07845268 BEARING, STRG SHF UPR (INCLS 2 BRGS & GREASE) (*KIT1) (ACDelco #S1303)
26075818 BRACKET, IGN LK CYL CASE (*KIT1)
01999309 SWITCH, WSW & WSWA (ACDelco #D6377D)
10384710 МОДУЛЬ, THEFT DTRNT [БЛОК УПРАВЛЕНИЯ ЦЕНТРАЛЬНЫМ ЗАМКОМ]
26038049 БОЛТ, IGN & START SW (ЧАСТЬ OF 22) (TORX HD SCREW) (*KIT1) (6.760)
12450257 SWITCH, IGN & START (ЧАСТЬ OF 22) (*KIT1) (ACDelco #D1421E)
26034514 ПРУЖИНА, LK БОЛТ (ЧАСТЬ OF 22) (43MM) (*KIT1)
26036496 БОЛТ, STRG COL UPR CVR (M4.55 TAP X15) (2.188)
26081608 CASE, IGN LK CYL (INCLS 17-20, 23, 25) (*KIT1)
26038049 БОЛТ, IGN LK CYL SOL (WSW & WSWA SW) (ЧАСТЬ OF 22) (TORX HD SCREW) (*KIT1) (6.760)
26036497 БОЛТ, IGN LK CYL CASE (M5X.8X15) (*KIT1) (6.760) [БОЛТ М5]
26080208 SOLENOID, IGN LK CYL CONT (ЧАСТЬ OF 22) (*KIT1)
25743472 SWITCH, T/SIG & HDLP & HDLP DIMR & FOG LP (W/CRUISE CONTROL KNOB) (ACDelco #D6264C)
25743473 SWITCH, T/SIG & HDLP & HDLP DIMR & FOG LP (W/CRUISE CONTROL KNOB) (ACDelco #D6265C) [ВЫКЛЮЧАТЕЛЬ]
26087973 ШЛАНГИ, STRG COL (INCLS 28) (W/O STRG SHF, INCLS STRG COL INR RACE) (*KIT1)
26036317 PIN, STRG COL TILT LK REL LVR PIV (ЧАСТЬ OF 27) (M5X0.8) (T-25 TORX) (*KIT1)
26034561 GUIDE, STRG COL SPR
26065450 ПРУЖИНА, STRG COL TILT
26101884 STRAP, STRG COL GND
26097345 HARNESS, STRG COL WRG (INCLS 6) (РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ IS HARDWIRED INTO HARNESS)
26103420 HARNESS, STRG COL WRG (INCLS 6) (РАСПРЕДЕЛИТЕЛЬ ЗАЖИГАНИЯ IS HARDWIRED INTO HARNESS) [ПРОВОДА]
12355066 STRAP, PLASTIC ADJ TIE (215MM LG) (WRG HARN) (8.965) (ACDelco #16TS825) [ХОМУТ С ФИКСАТОРОМ]
26069932 БОЛТ, STRG COL LWR TR CVR (M5.2X1.81X15.12) (2.188)
26069955 KNOB, STRG COL TILT WHL REL LVR (ALL PLASTIC LVR & KNOB)
26074286 SHAFT, UPR STRG (*KIT1)
26057095 SPHERE KIT, STRG SHF (INCLS 39) (INCLS SPR JOINT PRELOAD, USE ALUMINUM TUB SHF W/STEEL YOKE)
19168051 SHAFT, LWR STRG
26036521 PIN, STRG COL PIV [НАПРАВЛЯЮЩАЯ РЕГУЛИРОВКИ РУЛЕВОЙ КОЛОНКИ]
26080725 JACKET, STRG COL (INCLS 49, 51) (INCLS ADAP, BRG, BRKT, SUPT & STRAP) (ACCEPTS 4 БОЛТS)
15231652 SENSOR, STRG WHL POSN [ДАТЧИК ПОЛОЖЕНИЯ РУЛЕВОГО КОЛЕСА]
26071758 ADAPTER, STRG ANGLE SEN (LOCATOR/SENSOR)
26077651 SEAL, STRG COL BOOT
11509418 БОЛТ, M8X1.25X30.00 (INTER STRG SHF)
15212408 SHAFT, UPR INTER STRG (6.524) [ВАЛ РУЛЕВОЙ КОЛОНКИ]
11514597 ГАЙКА, INTER STRG SHF (M10X1.5 6H, 21.8OD) (2.383)
93364414 BUMPER, STRG COL HSG (ЧАСТЬ OF 42) (PINK) (UPR)
26090176 БОЛТ, STRG COL LWR TR CVR (M5X.8X15.40)
26060501 BUMPER, STRG COL HSG (ЧАСТЬ OF 42) (NATURAL) (6.3MM HEIGHT) (LOWER)
teamcadillac.ru
26092319 ШЛАНГИ, STRG COL (W/UPR STRG SHF) (INCLS 8-14, 17-20, 22-25, 27, 28, 37)
(6E06-016) - 2004-2006 E DIFFERENTIAL КРОНШТЕЙН/FRONT AXLE (MV3,MX5)
25873547 КРОНШТЕЙН, FRT DIFF (INCLS 2-26, 102-111)
25978167 КРОНШТЕЙН, FRT DIFF (INCLS 2-26, 102-111) [РЕДУКТОР ДИФФЕРЕНЦИАЛА ВЕДУЩЕГО МОСТА]
89047861 ГАЙКА, FRT DIFF DRV P/GR (ЧАСТЬ OF 1) [ГАЙКА]
19132939 SEAL, FRT DIFF DRV P/GR (ЧАСТЬ OF 1) (4.515) (CAN USE SEAL ONLY W/CASTING #6507022390 ON ШЛАНГИ DIFF DRV PINION GEAR, FOR 1ST DESIGN MUST USE SEAL KIT 19179936.) [ПРОКЛАДКА]
89047930 БОЛТ, FRT DIFF CARR CVR (ЧАСТЬ OF 1)
89047834 SEAL, FRT DIFF DRV P/GR INR BRG HSG (O RING) (ЧАСТЬ OF 1) [ПРОКЛАДКА]
89047832 SEAL, FRT WHL DRV INTER SHF HSG (ЧАСТЬ OF 1) [ПРОКЛАДКА]
89059039 PLUG, FRT DIFF CARR OIL DRN (ЧАСТЬ OF 1) (5.400)
teamcadillac.ru
89047859 GASKET, FRT DIFF CARR CVR (ЧАСТЬ OF 1) [УПЛОТНЕНИЕ]
15852707 VENT, F/AXL (ЧАСТЬ OF 1) (5.387) [КЛАПАН]
88996591 SEAL, F/AXL SHF (ЧАСТЬ OF 1) (5.822)
89059038 PLUG, FRT DIFF CARR OIL FIL (ЧАСТЬ OF 1) (M20X1.5X14) (W/SEAL) (5.400)
89047934 SEAL, FRT WHL DRV INTER SHF (ЧАСТЬ OF 1) [ПРОКЛАДКА]
89047933 RETAINER, FRT WHL DRV INTER SHF (ЧАСТЬ OF 1)
89047931 SHAFT, FRT WHL DRV INTER (ЧАСТЬ OF 1)
89047929 БОЛТ, FRT DIFF R/GR (ЧАСТЬ OF 1)
19179936 SEAL KIT, FRT DIFF DRV P/GR (INCLS 5) (INCLS FLANGE, SEAL & NUT) (USE W/O CASTING NUMBER 6507022390 ON ШЛАНГИ FRT DIFF DRV PINION GEAR FOR 2ND DESIGN SEAL SERVICED SEPARATELY SEE 19132939.) [ФЛАНЕЦ ДИФФЕРЕНЦИАЛА]
(6E06-017) - 2004-2009 E НАСОС РУЛЕВОГО УПРАВЛЕНИЯ КРЕПЛЕНИЕ (LY7/3.6-7)
teamcadillac.ru
12602074 BRACKET, P/S PUMP
11518632 БОЛТ, P/S PUMP BRKT (M10X1.5X70, 25.9 THD) (HFH, MATPOINT) [БОЛТ]
12574521 PULLEY, P/S PUMP [ШКИВ НАСОСА ГУРА]
11518628 БОЛТ, HVY HEX ACORN FLG HD, M10X1.5X50, GMW25M (10.9) STL, GMW3358 (P/S PUMP BRKT)
(6E06-019) - 2004-2006 E НАСОС РУЛЕВОГО УПРАВЛЕНИЯ LINES (LY7/3.6-7)
88957188 BRACKET, P/S FLUID RSVR
teamcadillac.ru
11588712 БОЛТ, HFH, M6X1X20, 17.5 THD, 14.2 O.D., 8.8, GMW3359 (P/S FLUID RSVR)
15251170 HOSE, P/S FLUID RSVR OTLT (INCLS 7)
25900769 PUMP, P/S (СМ. ГРУППУ 06.000 "НАСОС РУЛЕВОГО УПРАВЛЕНИЯ ASM" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [НАСОС ГУРА]
19206605 HOSE, P/S GR INL (INCLS 8, 9, 13) (LHD) [ТРУБКА СИСТЕМЫ РУЛЕВОГО УПРАВЛЕНИЯ]
10388415 HOSE, P/S GR OTLT (INCLS 14, 17) [ТРУБКА НАСОСА ГУРА]
10376954 HOSE, P/S FLUID CLR INL & OTLT (INCLS 20) [ТРУБКА СИСТЕМЫ РУЛЕВОГО УПРАВЛЕНИЯ]
10376951 HOSE, P/S FLUID CLR OTLT (INCLS 19) [ТРУБКА СИСТЕМЫ РУЛЕВОГО УПРАВЛЕНИЯ]
25820474 HOSE, P/S FLUID CLR OTLT (INCLS 19) [ТРУБКА РУЛЕВОГО УПРАВЛЕНИЯ]
11515778 БОЛТ, HFH, M12X1.75X45, 40 THD, 26.6 OD, 10.9, 7114M, P-POINT. (P/S FLUID RSVR) [БОЛТ М12]
11514623 БОЛТ, HEX W/CON WA, M6X1X20 (P/S FLUID CLR HOSE CLIP)
19130355 CONDENSER, КОНДИЦИОНЕР (СМ. ГРУППУ 09.000 "КОНДИЦИОНЕР СИСТЕМА ОХЛАЖДЕНИЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (ACDelco #15-63541)
(6M06-045) - 2004-2009 E НАСОС РУЛЕВОГО УПРАВЛЕНИЯ ASM (LY7/3.6-7)
88957182 FITTING, P/S GR INL HOSE (ЧАСТЬ OF 2)
25900769 PUMP, P/S (INCLS 1, 3-5) [НАСОС ГУРА]
88955556 SEAL, P/S PUMP INL TUBE (O RING) (ЧАСТЬ OF 2) [ПРОКЛАДКА В СБОРЕ]
88955557 БОЛТ, P/S PUMP INL TUBE (ЧАСТЬ OF 2) (M6X1.0X 14MM)
(6Y06-002) - 2004-2007 E STEERING КОЛЕСО & СИГНАЛ PARTS
15817299 КОЛЕСО, STRG (INCLS 2, 3, 5) (EBONY)
15913730 КОЛЕСО, STRG (INCLS 2, 3, 5) (EBONY)
11505314 SCREW, PAN HD, TAP, M4X0.7X10, 7.8 O.D., 6170M, ZOR (ЧАСТЬ OF 1) (**VPI 1-877-846-8243)
16869281 HARNESS, STRG WHL PAD ACSRY WRG (ЧАСТЬ OF 1)
25749842 SWITCH, DRVR INFO DISPLAY & M/FUNC (ЧАСТЬ OF 1)
15814818 МОДУЛЬ, STRG WHL INFL RST (EBONY) (14.865)
teamcadillac.ru
07 - КУЗОВ - ПРУЖИНЫ - АМОРТИЗАТОРЫ - БАМПЕРЫ
(6E06-003) - 2004-2009 E АМОРТИЗАТОР/ПЕРЕДНЯЯ СТОЙКА & ПРУЖИНА
11517996 ГАЙКА, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (ЧАСТЬ OF 2, 8) [ГАЙКА М10]
88952018 WASHER KIT, FRT S/ABS (INCLS 1) (INCLS 2-WASHERS AND 1-NUT) [УПОР ПРУЖИНЫ ПОДВЕСКИ]
88955519 WASHER KIT, FRT S/ABS (INCLS 1) (INCLS 1-WASHER AND 2-NUTS) [НАБОР ШАЙБ]
88955522 INSULATOR, FRT S/ABS (INCLS CUP) [ИНСУЛЯТОР В СБОРЕ]
88957128 INSULATOR, FRT S/ABS [УПЛОТНИТЕЛЬ]
25810851 ПРУЖИНА, FRT
teamcadillac.ru
88955536 ПРУЖИНА, FRT [ПРУЖИНА]
88957131 SHIELD, FRT S/ABS DUST
19150593 АМОРТИЗАТОР KIT, FRT SHK (INCLS 1, 7) (ACDelco #580-275) [АМОРТИЗАТОР ПЕРЕДНИЙ, А/М CADILLAC SRX 3.6 Л ]
88964324 АМОРТИЗАТОР KIT, FRT SHK (INCLS 1, 7) (ACDelco #540-469)
(6E07-014) - 2004-2006 E БАМПЕР ЗАДНИЙ
25704358 RETAINER, RR BPR FASCIA (15X18X23.8)
25837515 BAR, RR BPR IMP (INCLS 19) (WHEN USED ON 2004-2006 VEHICLES W/O VD9 OPTION, NEED TO ORDER SUPPORT #15819522.) [БАЛКА ЗАДНЕГО БАМПЕРА]
25774084 BRACKET, RR BPR FASCIA (TO IMP BAR) [СУППОРТ ЗАДНЕГО БАМПЕРА]
11588831 SCREW, HEX W/ CON WA, M6X1X35, 33.5 THD, 17 O.D.HDR PT, 9.8, BLK (RR BPR FASCIA BRKT)
25705182 RETAINER, RR BPR FASCIA SUPT (M9.5X6.0 HI-LO, TL 47MM, 22 OD) (12.249) [ВИНТ М5]
15910293 SUPPORT, RR BPR FASCIA UPR [БАЛКА ЗАДНЕГО БАМПЕРА]
25770821 HARNESS, RR OBJECT SEN WRG [ПРОВОДКА ДАТЧИКА ЗВУКОВОЙ СИГНАЛИЗАЦИИ КОНТРОЛЯ ПАРКОВКИ]
12335713 FASCIA, RR BPR (INCLS 11, 26) (КРАСКА TO MATCH) [ПАНЕЛЬ БАМПЕРА]
11519116 БОЛТ, WASHER, M6.3X1.8X20, 14 THD, 17 OD, GM6010M, 7153M (RR BPR FASCIA) [БОЛТ]
11518017 RETAINER, 25 LG, 20.5 OD, 8.0 HOLE, 6.2-8.2 PNL, NYLON, 6/6, BLK (RR BPR LWR FASCIA) [ПИСТОН КРЕПЛЕНИЯ КОЖУХА РАДИАТОРА]
12335718 COVER, RR BPR FASCIA TOW HOOK ACC HOLE (ЧАСТЬ OF 8) (BOWED) [ЗАСЛОНКА БУКСИРНОЙ СЕРЬГИ]
11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (RR W/H PNL LNR) [ВИНТ М4]
11518017 RETAINER, 25 LG, 20.5 OD, 8.0 HOLE, 6.2-8.2 PNL, NYLON, 6/6, BLK (RR W/H PNL LNR) [ПИСТОН КРЕПЛЕНИЯ КОЖУХА РАДИАТОРА]
25848125 LINER, RR W/H PNL [ПОДКРЫЛОК]
25848126 LINER, RR W/H PNL [ПРОКЛАДКА]
11515638 ГАЙКА, U-TYPE, M4.2X1.41X10.5.5X22, .65-3.8 PNL THK, 1050, ZF (RR W/H PNL LNR) [ГАЙКА М4.2]
11519116 БОЛТ, WASHER, M6.3X1.8X20, 14 THD, 17 OD, GM6010M, 7153M (RR BPR FASCIA BRKT) [БОЛТ]
25757848 BRACKET, RR BPR FASCIA [ОПОРНАЯ ПЛАНКА ПАНЕЛИ ЗАДНЕГО БАМПЕРА]
25757849 BRACKET, RR BPR FASCIA [ОПОРНАЯ ПЛАНКА ПАНЕЛИ ЗАДНЕГО БАМПЕРА]
25704358 RETAINER, RR BPR FASCIA SI (15X18X23.8)
10009923 ГАЙКА, БОЛТ RETAINING ПРУЖИНА, M8X1.25, 25 O.D., ZOR (ЧАСТЬ OF 2)
15284207 INSULATOR, EXH TAIL PIPE HNGR (ЧАСТЬ OF 21) [ДЕМПФЕР ГЛУШИТЕЛЯ]
15240254 BRACKET, EXH TAIL PIPE HNGR (INCLS 20) [КРОНШТЕЙН]
25902027 BRACKET, EXH TAIL PIPE HNGR (INCLS 20)
11517397 ГАЙКА, HEX W/CON WA, 8X1.25, 28 O.D., 7.5 THK, 9, PEOR (RR BPR ENGY ABS)
11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (RR BPR FASCIA) [ВИНТ М4]
89047028 SENSOR KIT, RR OBJECT (INCLS 25, 27) (CONSIST OF BEZEL RETAINERS, RING & SENSOR) (7.831) [ДАТЧИК ЗВУКОВОЙ СИГНАЛИЗАЦИИ КОНТРОЛЯ ПАРКОВКИ]
teamcadillac.ru
25536302 ГАЙКА, RR BPR FASCIA (ЧАСТЬ OF 8) (4.2 X 1.41) (TAPPING NUT) (3.430) [ПРИЖИМНАЯ ПЛАСТИНА ПАНЕЛИ КУЗОВА]
(6E07-015) - 2004-2009 E РАМА & КРЕПЛЕНИЕ
teamcadillac.ru
11519737 БОЛТ, DRIVETRAIN & FRT SUSP FRM (M16X2X60, 30 THD, 35 OD, 10.9)
11518725 БОЛТ, DRIVETRAIN & FRT SUSP FRM (CRADLE TO BODY) (M14X2.0X95) (HVY HEX FLG HD W/CON SPR WA) (8.900) [БОЛТ М14Х95]
(6E07-016) - 2004-2009 E АВТОМАТИЧЕСКОЕ УПРАВЛЕНИЕ КОМПРЕССОРОМ (FE3,F55)
88957190 КОМПРЕССОР , AUTO LVL CONT AIR (INCLS 2-7, 11-20) [КОМПРЕССОР]
88957197 LOCK, TERM-WRG SECD (ЧАСТЬ OF 1, 11)
88957220 БОЛТ, AUTO LVL CONT AIR CMPR (ЧАСТЬ OF 1, 11) (M6X1X25) (PAN HD)
89047682 WASHER, AUTO LVL CONT AIR CMPR (ЧАСТЬ OF 1, 11) (7 ID, 23 OD, 1MM THK) (FLAT) (STEEL)
88957201 TUBE, AUTO LVL CONT AIR CMPR (INCLS 9, 10) [ТРУБКА]
88957192 BRACKET, AUTO LVL CONT AIR CMPR (INCLS 2, 3, 5, 6, 12, 15, 16) (ЧАСТЬ OF 1)
teamcadillac.ru
88957200 БОЛТ, AUTO LVL CONT AIR CMPR SHLD (ЧАСТЬ OF 1) (M5X0.8X9) (PAN HD)
(6E07-017) - 2004-2005 E РЕГУЛИРУЕМАЯ ПОДВЕСКА-ЭЛЕКТРИЧЕСКАЯ & LEVEL CONTROL(FE3,F55)
15145221 АМОРТИЗАТОР, RR SHK (W/UPR MT) (ACDelco #580-337) [АМОРТИЗАТОР ЗАДНИЙ, А/М CADILLAC SRX 3.6 Л]
15210815 АМОРТИЗАТОР, RR SHK (W/UPR MT)
88957148 LINK, ELEK SUSP RR POSN SEN [ШАРНИР,КУЛИСА]
03532785 STUD, ELEK SUSP RR POSN SEN LINK BALL (M5X1.0X25.5) (BALL STYLE)
88957145 SENSOR, ELEK SUSP RR POSN [ДАТЧИК]
88957146 SENSOR, ELEK SUSP RR POSN [ДАТЧИК]
88957147 LINK, ELEK SUSP FRT POSN SEN
88957143 SENSOR, ELEK SUSP FRT POSN (INCLS 19) [ДАТЧИК]
88957144 SENSOR, ELEK SUSP FRT POSN (INCLS 19) [ДАТЧИК ПОЛОЖЕНИЯ ПОДВЕСКИ]
teamcadillac.ru
25753010 BRACKET, ACTIVE SUSP CONT MDL
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (ACTIVE SUSP CONT MDL BRKT) [ГАЙКА М6]
25768353 МОДУЛЬ, ELEK SUSP CONT [БЛОК УПРАВЛЕНИЯ ПОЛОЖЕНИЕМ ПОДВЕСКИ]
15744933 БОЛТ, HEX HD, W/CON WA, M6X1X45 (AUTO LVL CONT AIR CMPR BRKT) (1.267)
11508388 ГАЙКА, HEX W/CON WA, M6X1, 23.75 O.D., 5.55THK, 9, POR (AUTO LVL CONT AIR CMPR BRKT) (8.915)
11517641 STUD, AUTO LVL CONT AIR CMPR BRKT (M6X1X25, 11 OD) (8.981)
(6E07-018) - 2004-2009 E ЗАДНЯЯ ПОДВЕСКА
25716358 ARM, RR SUSP TRAILING (INCLS 2)
25721399 ARM, RR SUSP TRAILING (INCLS 2)
11519149 БОЛТ, RR SUSP TRAILING ARM (ЗАДНИЙ) (HFH, M14X2X90, 34 THD, 30.5 OD, 10.9, 7.3) (6.172)
11516382 ГАЙКА, RR SUSP TRAILING ARM (ЗАДНИЙ) (M14X2X15) (W/O J CLIP RETAINER) (8.917) [ГАЙКА М10]
11519078 БОЛТ, RR SUSP ADJ LINK (OUTER) (M14X2X110) (W/CON WASHER) (5.506)
25821862 SUPPORT, RR SUSP (INCLS 8, 9)
25821863 SUPPORT, RR SUSP (INCLS 8, 9)
11516076 ГАЙКА, PREVAILING TORQUE TENSION FLG HD (M8X1.25X17.4 OD (RR S/ABS) [ГАЙКА]
11516382 ГАЙКА, RR SUSP UPR CONT ARM (INNER) (M14X2X15) (W/O J CLIP RETAINER) (8.917) [ГАЙКА М10]
21992495 АМОРТИЗАТОР, RR SHK (W/UPR MT) [АМОРТИЗАТОР ЗАДНИЙ, А/М CADILLAC 4.6Л]
11519150 БОЛТ, RR SUSP UPR CONT ARM (FRT) (M14X2X100)
11588419 БОЛТ, RR SUSP UPR CONT ARM (FRT INNER) (SILVER) (M14X2X105, 10.9, 38THD) (REDUCED BODY) (8.900)
11517901 БОЛТ-HEX, M14X2X90, 34 THD, 28 OD, 10.9, 7114, MACH, HDR-PT (RR S/ABS)
11516382 ГАЙКА, RR SUSP ADJ LINK (INNER) (M14X2X15) (W/O J CLIP RETAINER) (8.917) [ГАЙКА М10]
11519149 БОЛТ, RR SUSP ADJ LINK (INNER) (HFH, M14X2X90, 34 THD, 30.5 OD, 10.9, 7.3) (6.172)
25716355 LINK, RR SUSP ADJ (INCLS 17, 20)
03537773 ГАЙКА, RR SUSP UPR CONT ARM (OUTER) (M14X2X11.92) (HEX W/CONICAL WA PREV TORQ)
15267619 ARM, RR SUSP UPR CONT (INCLS 21, 24) [РЫЧАГ]
teamcadillac.ru
15267620 ARM, RR SUSP UPR CONT (INCLS 21, 24) [РЫЧАГ]
11588475 WASHER, RR SUSP (FLAT W/SLOT, 14.75X86X4, GMW2M STEEL, GMW3044)
11518653 БОЛТ, HFLGE, M14X2X136, 66 THD, 30.5 OD, 10.9, 7114M, MACH, DOG POINT (RR SUSP) [БОЛТ М14]
11515720 SCREW, FLAT 6 LOBED, M6X1X20, 14.5 THD, 9.8, T-30 TORX, HDR PT (RR BRK ROT (PUSH ON)) (8.908) [ВИНТ]
15235141 ROTOR, RR BRK (ACDelco #177-0911) [ТОРМОЗНОЙ ДИСК]
89047639 HUB, RR WHL (W/WHL SPD SEN) (INCLS 31) (6 STUD HUB) (ACDelco #RW20-19) [СТУПИЦА КОЛЕСА]
88951999 KNUCKLE, RR SUSP (INCLS 34, 36, 37) [ПОВОРОТНЫЙ КУЛАК ПОДВЕСКИ]
88952000 KNUCKLE, RR SUSP (INCLS 34, 36, 37) [КУЛАК ЗАДНЕЙ ПОДВЕСКИ]
11518337 БОЛТ, HFH M12X1.75X75, 26.6 OD, 30 THD, 10.9, 7114M, ADH 6194M, REDUCED BODY (RR BRK CLPR BRKT) [БОЛТ М12]
11519097 БОЛТ, HFH M12X1.75X55, 26.6 OD, 30 THD, 10.9, 7114M, ADH 6194M, RED BODY. (RR BRK CLPR BRKT)
25693149 BRACKET, PARK BRK CBL (ATTACHES TO RR SUSP)
25693150 BRACKET, PARK BRK CBL (ATTACHES TO RR SUSP)
11515771 БОЛТ, HFH, REDUCED BODY, M10X1.5X55, 30THD, 22.3 O.D., 10.9, 7114 (PARK BRK CBL BRKT)
11516078 ГАЙКА, RR STAB SHF LINK (M12X1.75X18) (8.917) [ГАЙКА]
20765234 INSULATOR, RR SPR UPR
10356529 ПРУЖИНА, RR
10356530 ПРУЖИНА, RR
15895319 LINK, RR STAB SHF [РЫЧАГ СТАБИЛИЗАТОРА ПОДВЕСКИ]
15895320 LINK, RR STAB SHF [РЫЧАГ СТАБИЛИЗАТОРА ПОДВЕСКИ]
11519707 БОЛТ, RR SUSP LWR CONT ARM (OUTER) (M14X2X76) (HEX HD W/CON WA)
11588481 WASHER, RR SUSP (FLAT W/SPL SLOT, 16.75X86X4.0, GMW2M-ST-S-HR1 STEEL, GMW3044)
25707735 INSULATOR, RR SPR LWR
11519151 БОЛТ, RR SUSP LWR CONT ARM (INNER) (HFH, M14X2X110) (POINTED POINT) (7.039)
25768320 ARM, RR SUSP LWR CONT (INCLS 53) [РЫЧАГ]
25768321 ARM, RR SUSP LWR CONT (INCLS 53)
03537773 ГАЙКА, RR SUSP LWR CONT ARM (INNER) (M14X2X11.92) (HEX W/CONICAL WA PREV TORQ)
11515764 БОЛТ, HFH, M10X1.5X20, 18THD, 22.3 O.D., 10.9, 7114M (RR STAB SHF BRKT)
25719675 BRACKET, RR STAB SHF [ОПОРНАЯ СКОБА ВТУЛКИ СТАБИЛИЗАТОРА]
25758596 INSULATOR, RR STAB SHF [ВТУЛКА СТАБИЛИЗАТОРА ПОДВЕСКИ]
25768322 SHAFT, RR STAB (22MM SOLID)
11518927 БОЛТ, RR SUSP (M16X2X136) (8.900)
(6E07-019) - 2005-2006 E БАМПЕР ПЕРЕДНИЙ
25763160 GRILLE, RAD (СМ. ГРУППУ 01.000 "РЕШЕТКА РАДИАТОРА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [РЕШЕТКА РАДИАТОРА]
25767592 NOZZLE, HDLP WA (СМ. ГРУППУ 02.000 "ФАРООМЫВАТЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ФОРСУНКА ФАРООМЫВАТЕЛЯ]
25767593 NOZZLE, HDLP WA (СМ. ГРУППУ 02.000 "ФАРООМЫВАТЕЛЬ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) [ФОРСУНКА СТЕКЛООМЫВАТЕЛЯ]
11561916 NUT-INSERT, M8X1.25, 13.5 HOLE, 0.7-3.8 GRIP, 24 LONG, 17.4 OD, 1008, GMW (ЧАСТЬ OF 6)
10009923 ГАЙКА, БОЛТ RETAINING ПРУЖИНА, M8X1.25, 25 O.D., ZOR (ЧАСТЬ OF 6)
11517397 ГАЙКА, HEX W/CON WA, 8X1.25, 28 O.D., 7.5 THK, 9, PEOR (FRT BPR ENGY ABS)
25994576 BAR, FRT BPR IMP (INCLS 3, 4) [БАЛКА ПАНЕЛИ БАМПЕРА]
11517103 STUD, SPL W/KNURLED SHLDR, M6X1X27, 10 THD, 13 O.D., P-PT., 9.8, 7114M (ЧАСТЬ OF 15) [ШТИФТ]
teamcadillac.ru
11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (FRT BPR FASCIA) [ВИНТ М4]
11517102 ГАЙКА, HEX FLG, M6X1X15, 19.8 OD, 9, 7111M (ЧАСТЬ OF 15) [ГАЙКА]
10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (ЧАСТЬ OF 15) [ПИСТОН КРЕПЛЕНИЯ ОБЛИЦОВКИ БАМПЕРА (NYLON)]
15248340 SEAL, RAD AIR LWR (ЧАСТЬ OF 13)
25802220 DEFLECTOR, FRT AIR (INCLS 12) [ОБТЕКАТЕЛЬ РАДИАТОРА]
11589291 RETAINER, PUSH-IN, FITS 6.5 HOLE IN 7-9.5 THK PNL, NYLON 6/6 (F/CMPT SPH SHLD (PUSH IN)) [ФИКСАТОР ПАНЕЛИ БАМПЕРА]
19121106 FASCIA, FRT BPR (INCLS 7, 9-11, 20) (MAY NEED TO ORDER FOG ЛАМПА BRACKETS #15790931, 15790932) [БАМПЕР ПЕРЕДНИЙ]
19121107 FASCIA, FRT BPR (INCLS 7, 9-11, 20) (MAY NEED TO ORDER FOG ЛАМПА BRACKETS #15790931, 15790932) [ПАНЕЛЬ БАМПЕРА]
11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (ЧАСТЬ OF 19) [ШАЙБА]
22579423 RIVET, FRT LIC PLT BRKT (5 X 25) (10.710) [ЗАКЛЕПКА D=6 ММ]
15213240 BRACKET, FRT LIC PLT (INCLS 17)
25729102 BRACKET, FRT LIC PLT (INCLS 17)
25758101 BRACKET, FRT LIC PLT (INCLS 17) (USED EUROPE & RUSSIA) [КРОНШТЕЙН ДЛЯ НОМЕРНОГО ЗНАКА]
25758559 BRACKET, FRT LIC PLT (INCLS 17) (USED KOREA & TAIWAN)
12335717 COVER, FRT BPR FASCIA TOW HOOK ACC HOLE (ЧАСТЬ OF 15) [ЗАГЛУШКА ПАНЕЛИ БАМПЕРА]
12335720 COVER, HDLP WA NOZ
12335721 COVER, HDLP WA NOZ
11509231 SCREW, RD HD C/R TAP, M4.2X1.41X13.0, GM6010M STL, GM813M NICKEL ORGANIC (FRT BPR FASCIA) [ВИНТ М6Х12]
11518017 RETAINER, 25 LG, 20.5 OD, 8.0 HOLE, 6.2-8.2 PNL, NYLON, 6/6, BLK (FRT BPR FASCIA (PUSH IN)) [ПИСТОН КРЕПЛЕНИЯ КОЖУХА РАДИАТОРА]
08 - КУЗОВНЫЕ ДЕТАЛИ ПЕРДНЯЯ ЧАСТЬ - ПОДОГРЕВАТЕЛЬ - ОБСЛУЖИВАНИЕ
(6D08-037) - 2004-2006 E ПЕРЕХОДНИКИ/ДВИГАТЕЛЬНЫЙ ОТСЕК
25733074 INSULATOR, DA PNL
25770800 INSULATOR, DA PNL (ДВИГАТЕЛЬ SI)
25883420 INSULATOR, DA PNL FRT
11588441 ГАЙКА, STAMP SPECIAL БОЛТ RETAINER, 24.05X17.42X2.5, SAE 1050 SPR STL, GMW3359 (DA PNL FRT INSL) (PUSH NUT)
25734326 INSULATOR, FRT W/H PNL [УПЛОТНИТЕЛЬ]
(6E08-035) - 2004-2009 E КАПОТ
89023030 КАПОТ, (WHEN SERVICING VEHICLES BUILT WITH DUAL STRUTS, ORDER T/W SINGLE STRUT # 15211910) (WHEN SERV. 2004-05 VEHICLES, ORDER T/W HINGE БОЛТS 11519387) [КАПОТ]
11609540 БОЛТ, HWASH, M6X1X20, 16.15 THD, 17 OD, 8.8, GMW4205, HDR PT. (КАПОТ PRIM LAT) [ВИНТ]
11609978 STUD, КАПОТ OPEN ASST ROD (STUD-SPL W/FL WA, M6X1X16, 14 THD, 14 OD, W/8MM BALL SIDE B, 1018, GMW4700) (M6X1X16) (W/8MM BALL SIDE B) [ШПИЛЬКА]
11519387 БОЛТ, HWASH, M8X1.25X20, 14 THD, 24 OD, GMW25 (8.8)STEEL, GMW3359, M-POINT. (КАПОТ HGE (КАПОТ SI)) [БОЛТ]
11561424 БОЛТ-HFH W/WASHER, 10.65X4.5 SHLDR, M6X1X27, 15 OD, 9.8 STL, GMW3179, M-P (КАПОТ HGE PIV) [БОЛТ М6]
11609540 БОЛТ, HWASH, M6X1X20, 16.15 THD, 17 OD, 8.8, GMW4205, HDR PT. (КАПОТ HGE (BODY SI)) [ВИНТ]
11516071 ГАЙКА, M8X1.25, 7.1THK, 13.05 O.D., 10, ZC (КАПОТ OPEN ASST ROD LWR BRKT)
25664724 CABLE, КАПОТ PRIM LAT REL [ТРОС ЗАМКА КАПОТА]
25772204 BRACE, F/END SH MET DIAG (MIDDLE SECTION OF THE BRACE ASM IS FLAT AND HAS A ЧАСТЬ NUMBER STAMPING OF 25772204) [ПЛАСТИНА]
11609540 БОЛТ, HWASH, M6X1X20, 16.15 THD, 17 OD, 8.8, GMW4205, HDR PT. (F/END SH MET DIAG BR) [ВИНТ]
25664742 LATCH, КАПОТ PRIM & SECD [ЗАЩЕЛКА КАПОТА]
10279121 BUMPER, КАПОТ ADJ FRT (ATTACHES TO КРЫЛО) (ADJUSTABLE) (12.212) [БАМПЕР]
25729401 BUMPER, КАПОТ SI [БАМПЕР]
11519393 БОЛТ, HEX W/CON ПРУЖИНА WA, M12X1.75X50, 35 OD, 42 THD, 10.9, 7114M (F/END SH MET CR BR)
15275361 BRACE, F/END SH MET CR
25747355 BRACE, F/END SH MET CR [ПОПЕРЕЧИНА МОТОРНОГО ОТСЕКА]
15211910 ROD, КАПОТ OPEN ASST
25895979 INSULATOR, КАПОТ [ШУМОИЗОЛЯЦИЯ КАПОТА]
25925190 SEAL, КАПОТ FRT (INCLS 23) (W/7 RETAINERS)
00332364 RETAINER - PUSH IN, FITS HOLE SIZE 0.245 - 0.260, GRIP LENGTH 0.52, 0.7 OD, MATERIAL NYLON 6/6 PER GMP.PA66.015 (ЧАСТЬ OF 22)
teamcadillac.ru
20064875 RETAINER, PUSH-IN, 20.5MMLG, 42.76MM 1.68HD DIA, PLASTIC (КАПОТ INSL) [КЛИПСА ШУМОИЗОЛЯЦИИ КАПОТА]
19207221 HINGE KIT, КАПОТ (INCLS 4, 8)
19207222 HINGE KIT, КАПОТ (INCLS 4, 8) [ПЕТЛЯ КАПОТА]
(6E08-036) - 2004-2006 E КРЫЛО & КОЛЕСНАЯ КОРОБКА ПЕРЕДНЯЯ
88890925 КРЫЛО, FRT (INCLS 12)
88890926 КРЫЛО, FRT (INCLS 12)
88890927 КРЫЛО, FRT (INCLS 12) [КРЫЛО]
88890928 КРЫЛО, FRT (INCLS 12) [ПЕРЕДНЕЕ КРЫЛО]
25734327 INSULATOR, F/FDR (INCLS 5) [ИЗОЛЯЦИЯ]
25734328 INSULATOR, F/FDR (INCLS 5) [УПЛОТНИТЕЛЬ]
25724779 BRACKET, F/FDR RR CTR [КРОНШТЕЙН]
10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (ЧАСТЬ OF 3) [ПИСТОН КРЕПЛЕНИЯ ОБЛИЦОВКИ БАМПЕРА (NYLON)]
11609540 БОЛТ, HWASH, M6X1X20, 16.15 THD, 17 OD, 8.8, GMW4205, HDR PT. (F/FDR) [ВИНТ]
15829491 LINER, FRT W/H FRT
15925401 LINER, FRT W/H FRT [ПОДКРЫЛОК]
11514517 ГАЙКА, HEX, W/CON SPR WA, M6X1, 5.7THK, 18 O.D., 9, 7111M (F/FDR RR CTR BRKT) [ГАЙКА М6]
11518017 RETAINER, 25 LG, 20.5 OD, 8.0 HOLE, 6.2-8.2 PNL, NYLON, 6/6, BLK (FRT W/H LNR) [ПИСТОН КРЕПЛЕНИЯ КОЖУХА РАДИАТОРА]
25772196 SHIELD, ENG FRT SPH (RUBBER FLAP) [БРЫЗГОВИК]
11518017 RETAINER, 25 LG, 20.5 OD, 8.0 HOLE, 6.2-8.2 PNL, NYLON, 6/6, BLK (ENG FRT SPH SHLD (PUSH IN)) [ПИСТОН КРЕПЛЕНИЯ КОЖУХА РАДИАТОРА]
14093088 RETAINER, F/CMPT SPH SHLD (PUSH IN) (NYLON) (8.153) [ФИКСАТОР КРЕПЛЕНИЯ БАМПЕРА]
25802220 DEFLECTOR, FRT AIR [ОБТЕКАТЕЛЬ РАДИАТОРА]
15926323 EXTENSION, FRT BPR FASCIA [РАСШИРИТЕЛЬНАЯ ПАНЕЛЬ БАМПЕРА]
25770515 EXTENSION, FRT BPR FASCIA [ПАНЕЛЬ ПОДКРЫЛКА]
14093088 RETAINER, FRT BPR FASCIA EXTN (NYLON) (8.153) [ФИКСАТОР КРЕПЛЕНИЯ БАМПЕРА]
21030249 RETAINER, EXPAN, 21 LG, 20. OD, 8.0 HOLE, 3.0-5.0 PNL, NYLON 6/6, BLK (FRT BPR FASCIA EXTN) (8.950) (PUSH IN) [ПИСТОН КРЕПЛЕНИЯ КОЖУХА РАДИАТОРА(ПЛАСТИК)]
(6E08-038) - 2004-2009 E ШЛАНГИИ ТРУБКИ НАГРЕВАТЕЛЯ (LH2/4.6A)
teamcadillac.ru
11517136 CЛАМПА, HOSE SPR, 27 NOM, 25.2 MIN-28.9 MAX, 15MM WIDE, BLACK (ЧАСТЬ OF 2)
11517133 CЛАМПА, ПРУЖИНА, 22-26MM, 24 NOM., BLK (HTR INL HOSE) (*KIT1) [ХОМУТ ТРУБОПРОВОДА]
03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (HTR INL & OTLT HOSE BRKT)
19129962 PIPE, HTR INL & OTLT (*KIT1)
11517133 CЛАМПА, ПРУЖИНА, 22-26MM, 24 NOM., BLK (COOL RCVY CHK VLV HOSE) (*KIT1) [ХОМУТ ТРУБОПРОВОДА]
88957400 HOSE, HTR OTLT (*KIT1) [ШЛАНГ]
11518516 CЛАМПА, HTR OTLT HOSE (27MM) (BLACK & YELLOW T-CLIP) (*KIT1) (1.240) [ЗАЖИМ]
88957399 HOSE, HTR INL (*KIT1) [ШЛАНГ]
19129962 HOSE, HTR INL & OTLT (INCLS 3, 5-9)
(6E08-039) - 2004-2005 E SPARE КОЛЕСО STOWAGE & JACK PARTS
25769884 LABEL, JK LOCATION INFO (ЧАСТЬ OF 4)
teamcadillac.ru
25636527 RETAINER, JK STOW (M6.3X1.81) (HEX CHROME FINISH) (2.697)
13500909 ДОМКРАТ, (INCLS 1, 3) [ДОМКРАТ]
88967333 БОЛТ/SCREW KIT, SPA WHL STOW
25752626 TAG, JK CAUTION & USAGE INFO
25755909 BAG, LOOSE PARTS
25729106 EYE, TOW (FRONT) [БУКСИРОВОЧНАЯ ПРОУШИНА]
25744730 STRAP, SPA WHL STOW
25762462 SHIELD, SPA WHL HT
11518201 RETAINER, EXPAN, 28 LG, 22 OD, 10.5 HOLE, .8-15.0 PNL, ACETAL, BLK (SPA WHL HT SHLD)
25762463 SHIELD, SPA WHL HT
15874936 HOIST, SPA WHL
11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (SPA WHL HOIST) (ACDelco #11570082) [БОЛТ М8]
09594308 КОЛЕСО, 17X4 COMPACT SPARE (ALUMINUM)
11589205 БОЛТ, W/22 WIDE CLIP, M6X1X110, 45 THD, 19 O.D.P-PT, 5.8, GMW3044 (JK STOW)
25771746 TRIM, R/CMPT FLR PNL STOW PKT (EBONY)
25892315 BAG, TOOL STOW (INCLS 6)
(6E08-041) - 2005      E ПАСПОРТНЫЕ ТАБЛИЧКИ И ДЕКАЛИ
15093589 LABEL, SPA WHL WRNG
25558496 LABEL, ШИНА COMPACT SPA MAX SPD WRNG (MAX 80 KM/H)
teamcadillac.ru
10324485 LABEL, ROADSIDE SERV INFO
15070503 LABEL, MERCURY DISPOSAL INFO
15053409 LABEL, КОНДИЦИОНЕР REFRIG & BAT & FAN BLADE & RAD FIL CAP CAUTION
12567697 LABEL, ALL WHL DRV CAUTION
19180225 LABEL, VEH EMIS CONT INFO (VIN MUST BE SUPPLIED WITH ORDER)
15204281 LABEL, BAT WRNG (INCLUDES SYMBOLS ONLY)
10447127 TAG, INFL RST I/P MDL CAUTION (HANGING)
10426427 LABEL, CHILD ST WRNG
15006352 LABEL, CHILD ST WRNG (ENGLISH/FRENCH)
12451193 LABEL, CHILD SECURITY LK OPERG INSTR
15749557 LABEL, JK USAGE INFO & WRNG (ARABIC)
15006352 LABEL, INFL RST SYS WRNG (ENGLISH/FRENCH)
15116388 LABEL, INFL RST SYS WRNG (ENGLISH/SPANISH) [НАКЛЕЙКА САМОКЛЕЯЩАЯСЯ]
15766601 LABEL, INFL RST SYS WRNG (ENGLISH/ARABIC)
(6M08-012) - 2004-2009 EB ШЛАНГИИ ТРУБКИ НАГРЕВАТЕЛЯ (LY7/3.6-7)
12576734 PIPE, HTR INL & OTLT (INCLS 6-8)
11516222 CЛАМПА, ПРУЖИНАBAND, HOSE DIA=23, WIDTH=15, 6298M, MM (ЧАСТЬ OF 3) [ЗАЖИМ, ХОМУТ]
88958007 HOSE, HTR OTLT (INCLS 2) [ШЛАНГ]
88958006 HOSE, HTR INL (INCLS 5) [ШЛАНГ]
11516225 CЛАМПА, 25MM DIA, 15MM WIDTH, 6298 MATL (ЧАСТЬ OF 4)
12588318 SEAL, HTR INL PIPE (O RING) (ЧАСТЬ OF 1) [УПЛОТНЕНИЕ ТРУБКИ ОТОПИТЕЛЯ САЛОНА]
teamcadillac.ru
12592627 GASKET, HTR OTLT PIPE (ЧАСТЬ OF 1) [ПРОКЛАДКА]
11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (ЧАСТЬ OF 1) [БОЛТ]
(GM08-009) - 2004-2009 E КРАСКА/TOUCH-UP
01052907 КРАСКА, TOUCH-UP TUBE (.5 OZ) (BLACK) (WA 8555)
12345116 КРАСКА, TOUCH-UP TUBE (.5 OZ) (PRIMER, FILLER SCRATCH) (GRAY)
12346575 КРАСКА, TOUCH-UP TUBE (.5 OZ) (DARK MING BLUE MET) (WA 722J)
12346585 КРАСКА, TOUCH-UP TUBE (.5 OZ) (WHITE DIAMOND PEARL) (WA 800J)
12346643 КРАСКА, TOUCH-UP TUBE (.5 OZ) (DARK SPIRAL GRAY MET) (WA 805K)
12346649 КРАСКА, TOUCH-UP TUBE (.5 OZ) (SILVER GREEN MET) (WA 816K)
teamcadillac.ru
12346693 КРАСКА, TOUCH-UP TUBE (.5 OZ) (LT TARNISH SILVER) (WA 994L)
12346745 КРАСКА, TOUCH-UP TUBE (.5 OZ) (SPORT RED TINTCOAT) (WA 964L)
12346747 КРАСКА, TOUCH-UP TUBE (.5 OZ) (DK TARNISHED SILVER MET) (WA 911L)
12346787 КРАСКА, TOUCH-UP TUBE (.5 OZ) (GOLD SLATE MET) (WA 918L)
12345117 КРАСКА, TOUCH-UP SPRAY (5 OZ) (PRIMER, FILLER, SCRATCH)
12345155 КРАСКА, TOUCH-UP SPRAY (5 OZ) (BLACK) (WA 8555)
12346576 КРАСКА, TOUCH-UP SPRAY (5 OZ) (DARK MING BLUE MET) (WA 722J)
12346586 КРАСКА, TOUCH-UP SPRAY (5 OZ) (WHITE DIAMOND PEARL) (WA 800J)
12346644 КРАСКА, TOUCH-UP SPRAY (5 OZ) (DARK SPIRAL GRAY MET) (WA 805K)
12346650 КРАСКА, TOUCH-UP SPRAY (5 OZ) (SILVER GREEN MET) (WA 816K)
12346694 КРАСКА, TOUCH-UP SPRAY (5 OZ) (LT TARNISH SILVER) (WA 994L)
12346746 КРАСКА, TOUCH-UP SPRAY (5 OZ) (SPORT RED TINTCOAT) (WA 964L)
12346748 КРАСКА, TOUCH-UP SPRAY (5 OZ) (DK TARNISHED SILVER MET) (WA 911L)
12346788 КРАСКА, TOUCH-UP SPRAY (5 OZ) (GOLD SLATE MET) (WA 918L)
09 - ВНУТРЕННЕЕ ОБОРУДОВАНИЕ - КОНДИЦИОНЕР - АУДИОСИСТЕМА
(6E09-007) - 2004-2009 E КОНДИЦИОНЕР СИСТЕМА ОХЛАЖДЕНИЯ (EXC C57)
25728831 CLIP, КОНДИЦИОНЕР EVPR TUBE (LIQUID FRONT OF DASH) (L=35M W=31M H=32M) [ЗАЖИМ]
25740418 SEAL, КОНДИЦИОНЕР EVPR TUBE (ЧАСТЬ OF 3) (8MM) (ACDelco #15-31874) [УПЛОТНЕНИЕ ТРУБКИ КОНДИЦИОНЕРА]
15908322 TUBE, КОНДИЦИОНЕР CNDSR (CONDENSER TO DASH) (INCLS 2, 4-6) (ACDelco #15-33794) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ]
88958095 VALVE, КОНДИЦИОНЕР REFRIG SERV (ЧАСТЬ OF 3, 25) (INCLS 4, 26) (ACDelco #15-50154) [ПРЕДОХРАНИТЕЛЬНЫЙ КЛАПАН СИСТЕМЫ ОХЛАЖДЕНИЯ]
88957401 CAP, КОНДИЦИОНЕР REFRIG SERV VLV (SUCTION) (ЧАСТЬ OF 3) (ACDelco #15-32562) [КРЫШКА]
15932848 TUBE, КОНДИЦИОНЕР CNDSR OTLT (INCLS 10, 30, 31) (ACDelco #15-33827) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ]
25728831 CLIP, КОНДИЦИОНЕР CNDSR TUBE (CONDENSER) (ЧАСТЬ OF 11) (L=35M W=31M H=32M) [ЗАЖИМ]
25740418 SEAL, КОНДИЦИОНЕР EVPR TUBE (ЧАСТЬ OF 7) (8MM) (ACDelco #15-31874) [УПЛОТНЕНИЕ ТРУБКИ КОНДИЦИОНЕРА]
19130354 CONDENSER, КОНДИЦИОНЕР (INCLS 8, 9, 12-17) (ACDelco #15-63540)
teamcadillac.ru
19130355 CONDENSER, КОНДИЦИОНЕР (INCLS 8, 9, 12-17) (ACDelco #15-63541)
89023442 PLUG, КОНДИЦИОНЕР RCVR & DEHYDR (ЧАСТЬ OF 11) (INCLS PLUG, O-RING & DESSICANT BAG) (*KIT1) (ACDelco #15-10636)
89022474 SEAL, КОНДИЦИОНЕР RCVR & DEHYDR CVR (O RING) (ЧАСТЬ OF 11) (*KIT1) (ACDelco #15-32578)
11517519 БОЛТ, HFH, M6X1X25, 22 THD, 14.2 O.D., 9.8, 6280M (ЧАСТЬ OF 11)
19130477 КОМПРЕССОР , КОНДИЦИОНЕР (ACDelco #15-21222) [КОМПРЕССОР КОНДИЦИОНЕРА 2.2 КВТ]
89025025 КОМПРЕССОР , КОНДИЦИОНЕР (ACDelco #89025025) [КОМПРЕССОР КОНДИЦИОНЕРА]
25740416 SEAL, КОНДИЦИОНЕР CMPR & CNDSR HOSE (1/2IN) (ЧАСТЬ OF 20) (ACDelco #15-31872) [ПРОКЛАДКА КОМПРЕССОРА КОНДИЦИОНЕРА]
25718623 HOSE, КОНДИЦИОНЕР CMPR & CNDSR (INCLS 19) (ACDelco #15-32490)
25735204 HOSE, КОНДИЦИОНЕР CMPR & CNDSR (INCLS 19) (ACDelco #15-32533)
11517590 БОЛТ, HFH M6X1X25, 21.5 THD, 14.2 OD, 9.8, 7114M, MACH, HDR-PT (КОНДИЦИОНЕР CMPR HOSE) [БОЛТ]
25728832 CLIP, КОНДИЦИОНЕР CMPR HOSE & EVPR TUBE (SUCTION FRONT OF DASH) (L=38M W=32M H=39M) [МОДУЛЬ]
25728831 CLIP, КОНДИЦИОНЕР CNDSR TUBE (CONDENSER) (L=35M W=31M H=32M) [ЗАЖИМ]
88958096 CLIP, КОНДИЦИОНЕР CMPR & CNDSR HOSE (ЧАСТЬ OF 25)
25730765 HOSE, КОНДИЦИОНЕР CMPR (CMPR TO DASH) (INCLS 5, 24, 26-28) (ACDelco #15-32492)
25735203 HOSE, КОНДИЦИОНЕР CMPR (INCLS 5, 24, 26-28) (ACDelco #15-32532)
88957401 CAP, КОНДИЦИОНЕР REFRIG SERV VLV (SUCTION) (ЧАСТЬ OF 25) (ACDelco #15-32562) [КРЫШКА]
25740419 SEAL, КОНДИЦИОНЕР CMPR HOSE (5/8IN) (ЧАСТЬ OF 25) (ACDelco #15-31873) [ПРОКЛАДКА ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ]
11517519 БОЛТ, HFH, M6X1X25, 22 THD, 14.2 O.D., 9.8, 6280M (КОНДИЦИОНЕР CNDSR BR LWR)
88958089 SWITCH, КОНДИЦИОНЕР CMPR REFRIG PRESS (ЧАСТЬ OF 7) (INCLS 31) (ACDelco #15-50153) [ВЫКЛЮЧАТЕЛЬ]
88958090 SEAL, КОНДИЦИОНЕР CMPR HIGH PRESS CUTOFF SW (O RING) (ЧАСТЬ OF 7, 30) (ACDelco #15-32579) [ПРОКЛАДКА КОНДИЦИОНЕРА]
89023442 PLUG, КОНДИЦИОНЕР RCVR & DEHYDR (INCLS 12-15) (INCLS PLUG, O-RING & DESSICANT BAG) (ACDelco #15-10636)
(6E09-008) - 2004-2006 E СИСТЕМА РАСПРЕДЕЛЕНИЯ ВОЗДУХА-FRONT
11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (AIR INL) [БОЛТ М6]
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (AIR INL HSG) [ГАЙКА М6]
25768129 PANEL, AIR INL HSG FRT (INCLS 4)
11517528 STUD, FLANGE M6X1X20, M6.3X1.69X16, 15 OD, 6010M, 4345M, TAP (ЧАСТЬ OF 3)
11517486 БОЛТ-HEX, M6X1X30, 19 THD, 17 OD, 9.8, 6280M (SN-ZN), MACH, P-PT (BAT TRAY)
25746570 VALVE, PLNM DRN [ОБРАТНЫЙ КЛАПАН СИСТЕМЫ ОХЛАЖДЕНИЯ]
25760173 PANEL, AIR INL HSG LWR (INCLS 12, 13)
11518121 ГАЙКА, U, M6X1, MULTI THD, .5'-4.0' THK PNL (ЧАСТЬ OF 11)
11517528 STUD, FLANGE M6X1X20, M6.3X1.69X16, 15 OD, 6010M, 4345M, TAP (ЧАСТЬ OF 11)
15216960 SEAL, AIR INL GRL PNL (1RH BTWN FDR AND АККУМУЛЯТОР TRAY)
19130428 COVER, PASS COMPT AIR FLTR ACC HOLE
25740406 ШЛАНГИ, PASS COMPT AIR FLTR (INCLS 17)
19130403 FILTER KIT, PASS COMPT AIR (ЧАСТЬICLE FILTER) (ACDelco #CF133) [ВОЗДУШНЫЙ ФИЛЬТР САЛОНА]
22702778 VALVE, QTR OTR PNL PRESS RLF (FRONT OF "D" RING) [КЛАПАН]
25719080 DUCT, FLR RR AIR OTLT (EXT USED ON LH & RH ENDS)
25763802 DUCT, FLR RR AIR OTLT
25763803 DUCT, FLR RR AIR OTLT
25718316 DUCT, FLR RR AIR OTLT
25744150 DUCT, FLR RR AIR OTLT
25749921 GRILLE, W/S DEFR NOZ (INCLS 5, 42-44, 46) (EBONY)
25749972 DEFLECTOR, I/P OTR AIR OTLT (EBONY)
25749915 GRILLE, I/S AIR TEMP SEN (EBONY) [РЕШЕТКА ВЕНТИЛЯЦИИ ИНСТРУМЕНТАЛЬНОГО ЩИТА]
11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (ЧАСТЬ OF 33) [ВИНТ М4]
15233494 CONTROL, HTR & КОНДИЦИОНЕР (ACDelco #15-73169) (REQUIRES DEALER REPROGRAMMING.)
25770602 CONTROL, HTR & КОНДИЦИОНЕР (ACDelco #15-73014) (REQUIRES DEALER REPROGRAMMING)
25749975 DEFLECTOR, I/P CTR AIR OTLT (EBONY) [ВОЗДУХОВОД ВЕНТИЛЯЦИИ САЛОНА]
22570333 RETAINER, I/P ACSRY TR PLT (ЧАСТЬ OF 31) (10.240) [ДЕРЖАТЕЛЬ]
teamcadillac.ru
10360647 PLATE, I/P ACSRY TR (INCLS 30) (WOOD FILM) (EXPORT)
25749919 PLATE, I/P ACSRY TR (INCLS 30) (EBONY) (INCLS SW & RET) (DOMESTIC, NON EUROPEAN & MID EASTERN COUNTRIES)
25749920 PLATE, I/P ACSRY TR (INCLS 30) (EBONY) (INCLS SW & RET) (EUROPEAN & MID EASTERN COUNTRIES) [ПЛАСТИНА В СБОРЕ]
25772306 PLATE, I/P ACSRY TR (INCLS 30) (WALNUT BURL) (WOOD FILM) (DOMESTIC-NON EXP) (W/CTR DEFLECTORS)
25749973 DEFLECTOR, I/P OTR AIR OTLT (EBONY) [ДЕФЛЕКТОР ПАНЕЛИ ПРИБОРОВ]
25687484 SENSOR, I/S AIR TEMP (INCLS 35) (ACDelco #15-5889) [ДАТЧИК ТЕМПЕРАТУРЫ ВОЗДУХА]
25725541 NOZZLE, W/S DEFR (ЧАСТЬ OF 36)
25687487 DUCT, AIR DISTR (DRIVER SIDE) (ЧАСТЬ OF 36)
25687489 DUCT, AIR DISTR (PASSENGER SIDE) (ЧАСТЬ OF 36)
22570333 RETAINER, W/S DEFR NOZ GRL (ЧАСТЬ OF 24) (10.240) [ДЕРЖАТЕЛЬ]
25713063 SENSOR, HDLP AUTO CONT AMB LGT (ЧАСТЬ OF 24) (DUAL SOLAR & TWILIGHT) [ДАТЧИК ОСВЕЩЕННОСТИ ДЛЯ АВТОМАТИЧ.ВКЛЮЧ.ГАБАРИТОВ]
(6E09-009) - 2004-2009 E КОМПРЕССОР КОНДИЦИОНЕРА КРЕПЛЕНИЕ (LH2/4.6A)
12567478 BRACKET, КОНДИЦИОНЕР CMPR
11519173 БОЛТ, HFH, REDUCED BODY, M8X1.25X60, 22THD, 18 OD, 8.8, GMW3359 (КОНДИЦИОНЕР CMPR)
03522360 БОЛТ, КОНДИЦИОНЕР CMPR (8X1.25X90) (6.606)
teamcadillac.ru
11516328 БОЛТ, HFH, M10X1.5X30, 22 O.D., HDR PT, 10.9, 7114M (КОНДИЦИОНЕР CMPR BRKT) [БОЛТ, М10Х1.5Х30]
(6E09-010) - 2004-2009 E КОНДИЦИОНЕР СИСТЕМА ОХЛАЖДЕНИЯ ЧАСТЬ 1 FRONT (C57)
25740418 SEAL, КОНДИЦИОНЕР EVPR TUBE (ЧАСТЬ OF 10, 31) (8MM) (ACDelco #15-31874) [УПЛОТНЕНИЕ ТРУБКИ КОНДИЦИОНЕРА]
89022470 CLIP, КОНДИЦИОНЕР EVPR HOSE (ЧАСТЬ OF 31)
25740418 SEAL, КОНДИЦИОНЕР EVPR TUBE (8MM) (ACDelco #15-31874) [УПЛОТНЕНИЕ ТРУБКИ КОНДИЦИОНЕРА]
25740419 SEAL, КОНДИЦИОНЕР CMPR HOSE (5/8IN) (ACDelco #15-31873) [ПРОКЛАДКА ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ]
25728832 CLIP, КОНДИЦИОНЕР CMPR HOSE (SUCTION ON TOWER) (L=38M W=32M H=39M) [МОДУЛЬ]
88958096 CLIP, КОНДИЦИОНЕР CMPR & CNDSR HOSE (ЧАСТЬ OF 31)
19130334 TUBE, КОНДИЦИОНЕР EVPR (LIQUID LINE) (ЧАСТЬ OF 31) (INCLS 2, 23, 24) (ACDelco #15-33796) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ]
15932848 TUBE, КОНДИЦИОНЕР CNDSR OTLT (INCLS 13, 33, 34) (ACDelco #15-33827) [ТРУБКА СИСТЕМЫ ОХЛАЖДЕНИЯ]
teamcadillac.ru
25740418 SEAL, КОНДИЦИОНЕР EVPR TUBE (ЧАСТЬ OF 12) (8MM) (ACDelco #15-31874) [УПЛОТНЕНИЕ ТРУБКИ КОНДИЦИОНЕРА]
11517519 БОЛТ, HFH, M6X1X25, 22 THD, 14.2 O.D., 9.8, 6280M (КОНДИЦИОНЕР CMPR & CNDSR HOSE)
19130354 CONDENSER, КОНДИЦИОНЕР (INCLS 35-38) (ACDelco #15-63540)
19130355 CONDENSER, КОНДИЦИОНЕР (INCLS 35-38) (ACDelco #15-63541)
25740416 SEAL, КОНДИЦИОНЕР CMPR & CNDSR HOSE (1/2IN) (ЧАСТЬ OF 18) (ACDelco #15-31872) [ПРОКЛАДКА КОМПРЕССОРА КОНДИЦИОНЕРА]
11516424 БОЛТ, HFH, M6X1X25, 14.2 O.D., HDR PT, 9.8, ZE (КОНДИЦИОНЕР CMPR HOSE) [БОЛТ М6]
25718623 HOSE, КОНДИЦИОНЕР CMPR & CNDSR (INCLS 16) (ACDelco #15-32490)
25735204 HOSE, КОНДИЦИОНЕР CMPR & CNDSR (INCLS 16) (ACDelco #15-32533)
25740419 SEAL, КОНДИЦИОНЕР CMPR HOSE (5/8IN) (ЧАСТЬ OF 22) (ACDelco #15-31873) [ПРОКЛАДКА ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ]
11516424 БОЛТ, HFH, M6X1X25, 14.2 O.D., HDR PT, 9.8, ZE (КОНДИЦИОНЕР CMPR & CNDSR HOSE) [БОЛТ М6]
25725440 HOSE, КОНДИЦИОНЕР CMPR (INCLS 20) (ACDelco #15-32491)
25735202 HOSE, КОНДИЦИОНЕР CMPR (INCLS 20) (ACDelco #15-32531)
88958095 VALVE, КОНДИЦИОНЕР REFRIG SERV (ЧАСТЬ OF 10, 30, 31) (ACDelco #15-50154) [ПРЕДОХРАНИТЕЛЬНЫЙ КЛАПАН СИСТЕМЫ ОХЛАЖДЕНИЯ]
88957401 CAP, КОНДИЦИОНЕР REFRIG SERV VLV (SUCTION) (ЧАСТЬ OF 10, 31) (ACDelco #15-32562) [КРЫШКА]
11513599 ГАЙКА, U-TYPE, M4.2X1.41, 0.65-3.80 PNL THK, PZ (ЧАСТЬ OF 31) (ACDelco #11513599)
25740419 SEAL, КОНДИЦИОНЕР CMPR HOSE (5/8IN) (ЧАСТЬ OF 30, 31) (ACDelco #15-31873) [ПРОКЛАДКА ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ]
25728831 CLIP, КОНДИЦИОНЕР CMPR HOSE & EVPR TUBE (LIQUID ЗАДНИЙ КОНДИЦИОНЕР) (L=35M W=31M H=32M) [ЗАЖИМ]
88957402 CAP, КОНДИЦИОНЕР REFRIG SERV VLV (LIQUID) (ЧАСТЬ OF 30, 31) (ACDelco #15-32563) [КОЛПАЧОК КЛАПАНА СИСТЕМЫ ОХЛАЖДЕНИЯ]
88958008 TUBE, КОНДИЦИОНЕР EVPR (SUCTION LINE (INCLS 23, 25, 27, 29, 31) (ACDelco #15-32560) [ТРУБКА В СБОРЕ]
25762792 TUBE, КОНДИЦИОНЕР EVPR FRT (L&S DASH TO TOWER ASSY) (INCLS 2, 3, 9, 10, 23, 24, 26, 27, 29, 30) (ACDelco #15-32555) [ТРУБКА]
88958089 SWITCH, КОНДИЦИОНЕР CMPR REFRIG PRESS (ЧАСТЬ OF 12) (INCLS 34) (ACDelco #15-50153) [ВЫКЛЮЧАТЕЛЬ]
88958090 SEAL, КОНДИЦИОНЕР CMPR HIGH PRESS CUTOFF SW (O RING) (ЧАСТЬ OF 12, 33) (ACDelco #15-32579) [ПРОКЛАДКА КОНДИЦИОНЕРА]
89022474 SEAL, КОНДИЦИОНЕР RCVR & DEHYDR CVR (O RING) (ЧАСТЬ OF 15) (*KIT1) (ACDelco #15-32578)
03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (КОНДИЦИОНЕР TUBE BRKT)
89023442 PLUG, КОНДИЦИОНЕР RCVR & DEHYDR (INCLS 35-38) (INCLS PLUG, O-RING & DESSICANT BAG) (ACDelco #15-10636)
(6E09-011) - 2004-2005 E КОНДИЦИОНЕР СИСТЕМА ОХЛАЖДЕНИЯ ЧАСТЬ 2 ЗАДНИЙ (C57)
teamcadillac.ru
25728832 CLIP, AUX КОНДИЦИОНЕР EVPR TUBE (SUCTION ЗАДНИЙ КОНДИЦИОНЕР) (L=38M W=32M H=39M) [МОДУЛЬ]
25740419 SEAL, КОНДИЦИОНЕР CMPR HOSE (5/8IN) (ЧАСТЬ OF 16) (ACDelco #15-31873) [ПРОКЛАДКА ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ]
89022471 CLIP, КОНДИЦИОНЕР EVPR RR HOSE (ЧАСТЬ OF 16)
89022472 CLIP, AUX КОНДИЦИОНЕР EVPR HOSE (ЧАСТЬ OF 16)
03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (AUX КОНДИЦИОНЕР EVPR TUBE)
25740418 SEAL, КОНДИЦИОНЕР EVPR TUBE (ЧАСТЬ OF 16) (8MM) (ACDelco #15-31874) [УПЛОТНЕНИЕ ТРУБКИ КОНДИЦИОНЕРА]
25728831 CLIP, КОНДИЦИОНЕР EVPR TUBE (L=35M W=31M H=32M) [ЗАЖИМ]
19130219 TUBE, AUX КОНДИЦИОНЕР EVPR RR (INCLS 4-8, 10, 11, 13, 15) (ACDelco #15-33733) (KENT-MORE TUBING REPAIR KIT J41425 IS REQD FOR INSTALLATION) [ТРУБКА]
(6E09-012) - 2004-2006 E ВХОД ВОЗДУХА - ВЕНТИЛЯТОР
88957404 INLET, AIR (INCLS 1, 3-6, 8, 9, 12, 14)
25740415 МОДУЛЬ, BLO MOT CONT (9.273) (ACDelco #15-72791) [ПАНЕЛЬ УПРАВЛЕНИЯ ОТОПИТЕЛЕМ И КОНДИЦИОНЕРОМ]
25740408 MOTOR, BLO (W/IMPLR) (ACDelco #15-80198) [МОТОР]
19129776 HARNESS, HTR & КОНДИЦИОНЕР CONT WRG (INCLS TEMP SENSOR) (USE ON VEHICLES W/VIN 1GYEE63A050155499 AND LATER. FOR 1ST DESS SEE 25740398)
25740398 HARNESS, HTR & КОНДИЦИОНЕР CONT WRG (USE ON VEHICLES W/VIN 1GYEE63A050155498 AND PRIOR. FOR 2ND DES SEE 19129776)
teamcadillac.ru
25740409 ACTUATOR, AIR INL VLV (ACDelco #15-72790)
(6E09-013) - 2004-2009 E КОНДИЦИОНЕР & НАГРЕВАТЕЛЬ ASM
15266665 CLIP, КОНДИЦИОНЕР EVPR CASE (9.215)
25740401 SEAL, HTR CORE CASE (THIN)
25740395 ACTUATOR, TEMP VLV (ACDelco #15-72803) (USE ON VEHICLES BUILT PRIOR TO VIN 1GYEE63A050155499, FOR 2ND DES SEE 89024960)
89024960 ACTUATOR, TEMP VLV (ACDelco #15-73209) (USE ON VEHICLES BUILT WITH VIN 1GYEE63A050155499 AND LATER, FOR 1ST DES SEE 25740395)
89023403 LEVER, MODE VLV
19129863 DUCT, FLR FRT AIR OTLT (WILL ALSO REQUIRE USE OF DUCT 19129864 AND CONTROL HEAD REPROGRAMMING.)
25740392 CORE, HTR (ACDelco #15-62716) [РАДИАТОР]
teamcadillac.ru
19129864 DUCT, FLR AIR OTLT (WILL ALSO REQUIRE USE OF DUCT 19129863 AND CONTROL HEAD REPROGRAMMING.)
25740400 HOSE, КОНДИЦИОНЕР EVPR & BLO MDL DRN
25740397 ASPIRATOR, I/S AIR TEMP SEN
19130407 ACTUATOR, MODE VLV (ACDelco #15-73826) (USE ON VEHICLES BUILT WITH VIN 1GYEE63A050155499 AND LATER, FOR 1ST DES SEE 89023402)
89023402 ACTUATOR, MODE VLV (ACDelco #15-73043) (USE ON VEHICLES BUILT PRIOR TO VIN 1GYEE63A050155499, FOR 2ND DES SEE 19130407)
25740393 VALVE KIT, КОНДИЦИОНЕР EVPR THERMAL EXPN (INCLS 30, 31, 38, 39) (ACDelco #15-50534)
25740420 TUBE KIT, КОНДИЦИОНЕР EVPR TXV (INCLS 33) (ACDelco #15-33185) [ТРУБКА]
89024954 EVAPORATOR KIT, КОНДИЦИОНЕР (INCLS 40) (ACDelco #15-62717)
25740391 CLIP, КОНДИЦИОНЕР REFRIG TEMP SEN LEAD
25740390 SENSOR, КОНДИЦИОНЕР EVAP TEMP (USED ON VEH @ THERMISTOR SEPARATE FROM HTR & AC CONT HARNESS) (THERMISTOR) (2.212)
88958097 МОДУЛЬ KIT, HTR & КОНДИЦИОНЕР EVPR & BLO (INCLS 1, 14) (ACDelco #15-80529) [КОМПЛЕКТ МОДУЛЕЙ]
(6E09-014) - 2004-2009 E AUXILIARY КОНДИЦИОНЕР EVAPORATOR - ВЕНТИЛЯТОР ASM (C57)
88957410 CASE, AUX КОНДИЦИОНЕР EVPR & BLO (INCLS 2, 6, 7, 12, 17, 19) (INCLS SEALS) (ACDelco #88957410)
teamcadillac.ru
88957408 RESISTOR, AUX BLO MOT (ACDelco #15-80513) [РЕЗИСТОР ВЕНТИЛЯТОРА 15 ВТ]
88957409 MOTOR, AUX BLO (IMPLR) (ACDelco #88957409)
25762949 SEAL, КОНДИЦИОНЕР EVPR & BLO MDL
88957416 SEAL, КОНДИЦИОНЕР EVPR & BLO MDL DRN HOSE OPG PLUG (ЧАСТЬ OF 1)
88957413 STUD, КОНДИЦИОНЕР EVPR & BLO MDL
19129799 VALVE, AUX КОНДИЦИОНЕР EVPR THERMAL EXPN (INCLS 9, 10, 12, 13) (ACDelco #15-50148)
25740419 SEAL, AUX КОНДИЦИОНЕР EVPR (5/8 INCH) (ЧАСТЬ OF 18) (9.222) (ACDelco #15-31873) [ПРОКЛАДКА ТРУБКИ СИСТЕМЫ ОХЛАЖДЕНИЯ]
25740416 SEAL, AUX КОНДИЦИОНЕР EVPR (1/2 INCH) (ЧАСТЬ OF 18) (9.222) (ACDelco #15-31872) [ПРОКЛАДКА КОМПРЕССОРА КОНДИЦИОНЕРА]
19129798 EVAPORATOR, AUX КОНДИЦИОНЕР (INCLS 14-16) (ACDelco #15-63039)
(6E09-018) - 2004-2009 E СИСТЕМА РАСПРЕДЕЛЕНИЯ ВОЗДУХА-AUX ЗАДНИЙ(C57)
25751056 DUCT, AUX КОНДИЦИОНЕР AIR OTLT (9.215)
11569768 RETAINER, PUSH-IN, FIT HOLE 6.35, 20.32 LENGTH, 17.78 OD, 2.79-14.22 THK P (AUX КОНДИЦИОНЕР AIR OTLT DUCT)
25725550 DUCT, AUX КОНДИЦИОНЕР AIR OTLT [ТРУБКА ВОЗДУХОВОДА]
10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (AUX КОНДИЦИОНЕР AIR OTLT DUCT) [ПИСТОН КРЕПЛЕНИЯ ОБЛИЦОВКИ БАМПЕРА (NYLON)]
teamcadillac.ru
11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (AUX КОНДИЦИОНЕР EVPR & BLO MDL) [БОЛТ М6]
11609385 ГАЙКА, U-TYPE, M6X1, 29.5 LEN, 12.5 WID, 19.5 CEN-END, 1050, GMW3359 (AUX КОНДИЦИОНЕР EVPR & BLO MDL) [ГАЙКА М 6]
(6E09-022) - 2004-2009 E АНТЕННА/AUDIO
25757629 МОДУЛЬ, RDO ANT (ACDelco #25757629) [МОДУЛЬ]
25757631 МОДУЛЬ, RDO ANT (ACDelco #25757631)
25773482 МОДУЛЬ, RDO ANT (ACDelco #25773482)
15207795 CABLE, RDO ANT CBL EXTN (FROM RH ANT МОДУЛЬ TO LH ANT МОДУЛЬ) (ACDelco #15207795)
19115773 RECEIVER, R/CON DR LK & THEFT DTRNT (9.645) (ACDelco #19115773)
89047510 RECEIVER, R/CON DR LK & THEFT DTRNT (10.485)
teamcadillac.ru
15207794 CABLE, RDO ANT CBL EXTN (FROM RT ANT MOD TO RADIO) (ACDelco #15207794)
25723801 CABLE, RDO ANT (4070MM LONG) (FROM RADIO TO HEADLINER) (ACDelco #25723801)
25723800 CABLE, RDO ANT CBL EXTN RDO END (850MM LONG) (ACDelco #25723800)
25752514 CABLE, RDO ANT CBL EXTN RDO END (850MM LONG) (ACDelco #25752514)
(6E09-024) - 2005-2009 E ТЕЛЕСИСТЕМА (U2X,U2Y)
teamcadillac.ru
25735406 CABLE, TV ANT AMPF COAX (RR) (2 ПРОВОДА, 2570MM & 3525MM LONG) (ACDelco #25735406)
25749683 УСИЛИТЕЛЬ, TV ANT (JAPAN/KOREA TV AMP/JPR ASM) (ACDelco #25749683)
25767968 УСИЛИТЕЛЬ, TV ANT (DOM/EURO TV AMP DOM/EUR ASM) (ACDelco #25767968)
11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (TV ANT MDL) [БОЛТ М8]
11517641 STUD, SPL, M6X1X25, 13 THD, 11 OD HD W/26 WIDE CLIP, 9.8, 6280M, P-PT (COMMUNICATION INTERFACE MDL)
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (COMMUNICATION INTERFACE MDL) [ГАЙКА М6]
15218692 TUNER, TV (INCLS 7, 8)
25735405 CABLE, TV ANT AMPF COAX (FRT) (2 ПРОВОДА, 5715MM & 7410MM LONG) (ACDelco #25735405)
(6E09-025) - 2004-2009 E ENTERTAINMENT SYSTEM (U42)
01999421 HEADPHONE, (INCLS 3) (WIRELESS) (FOR FOAM EARPADS CALL UNWIRED TECH. 1-888-293-3332) (ACDelco #1999421)
01999355 CONTROL, VIDEO PLYR REM (INCLS 6) (ACDelco #1999355)
(6E09-026) - 2004-2006 E АУДИОСИСТЕМА/ДИНАМИКИ & УСИЛИТЕЛЬ(U66)
15215743 SPEAKER, RDO W/S SI G/MLDG (LH & RH) (ACDelco #15215743)
25645757 ГАЙКА, RDO FRT S/D SPKR (EBONY) (20MM SQUARE, 16MM THK) (FITS 9.8MM HOLE)
25665738 ГАЙКА, RDO FRT S/D SPKR (12MM SQ X 16.7MMDP) (NYLON)
25755395 SPEAKER, RDO FRT S/D (ACDelco #25755395)
11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (RDO FRT S/D SPKR) [ВИНТ М4]
15888320 SPEAKER, RDO RR S/D (ACDelco #15888320)
11509231 SCREW, RD HD C/R TAP, M4.2X1.41X13.0, GM6010M STL, GM813M NICKEL ORGANIC (RDO RR S/D LWR SPKR (RPR)) [ВИНТ М6Х12]
11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (RDO RR SPKR) [ШАЙБА]
25745972 SPEAKER, RDO RR OTR (ACDelco #25745972)
11517896 БОЛТ, HEX W/FL WA, M6X1X40, 29.53 THD, 17 OD, 9.8, 6280M, MACH, P-PT, CONE-PT (RDO RR SPKR)
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (R/FLR PNL CPT RET BRKT) [ГАЙКА М6]
11517112 SCR TAP HEX WASHER HD T-30 6 LOBED SOCKET (RDO SPKR AMPF BRKT) (9.667)
teamcadillac.ru
25764619 УСИЛИТЕЛЬ, RDO SPKR (ACDelco #25764619)
03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (AUDIO PWR BOOS)
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (AUDIO PWR BOOS BRKT) [ГАЙКА М6]
25738231 BRACKET, AUDIO PWR BOOS
11517641 STUD, SPL, M6X1X25, 13 THD, 11 OD HD W/26 WIDE CLIP, 9.8, 6280M, P-PT (RDO SPKR AMPF BRKT)
(6E09-027) - 2004-2006 E АУДИОСИСТЕМА/ДИНАМИКИ & УСИЛИТЕЛЬ(U57)
15215744 SPEAKER, RDO W/S SI G/MLDG (LH & RH) (W/O GRILLE) (ACDelco #15215744)
15242215 SPEAKER, RDO FRT S/D (ACDelco #15242215)
11609370 БОЛТ-HWH, M4.2X1.41X20, HI - LOW THD, , OD 12, 6010 STL, GMW4205, TAP (RDO FRT S/D SPKR) (9.667)
teamcadillac.ru
15240415 MICROPHONE, RDO VOL COMP INTR NOISE (INCLS 7)
11509231 SCREW, RD HD C/R TAP, M4.2X1.41X13.0, GM6010M STL, GM813M NICKEL ORGANIC (F/FLR CNSL COMPT BZL) [ВИНТ М6Х12]
25660131 SPEAKER, RDO RR S/D (ACDelco #25660131) [ДИНАМИК 40ВТ]
25718355 SPEAKER, RDO RR OTR (ACDelco #25718355)
25684670 SPEAKER, RDO FRT (ACDelco #25684670)
11515196 SCREW, RND WA HD, M4.2X1.41X16, HILO SELF- TAP, 8.2 O.D., 6010M, NO (RDO FRT SPKR)
15231327 УСИЛИТЕЛЬ, RDO SPKR (ACDelco #15231327) [УСИЛИТЕЛЬ АКУСТИЧЕСКИЙ]
(6E09-028) - 2004-2006 E RADIO КРЕПЛЕНИЕ (U2R,U2S)
teamcadillac.ru
89046698 KNOB, RDO TUNING CONT (ЧАСТЬ OF 1) (EBONY) (9.652) (ACDelco #89046698)
89046698 KNOB, RDO VOL CONT (ЧАСТЬ OF 1) (EBONY) (9.652) (ACDelco #89046698)
11517722 STUD, M6X1X22.5, 12.2 THD, 14 OD, 9.8, 7113M, P-PT (RDO BRKT)
11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (RDO BRKT) [БОЛТ М6]
25714920 BRACKET, RDO (ACDelco #25714920)
11514517 ГАЙКА, HEX, W/CON SPR WA, M6X1, 5.7THK, 18 O.D., 9, 7111M (RDO BRKT) [ГАЙКА М6]
11570097 ГАЙКА, U-TYPE, M6X1, 21.4X15, 11.7 C/E, SAE 1050 STL, GMW3359. (I/P LWR EXTN) [ШАЙБА]
(6E09-029) - 2005-2006 E RADIO КРЕПЛЕНИЕ (U2V,U2X,U2Y)
89047007 PLAYER, AUDIO DISC (ЧАСТЬ OF 1)
89047294 PLAYER, AUDIO DISC (ЧАСТЬ OF 1) (ACDelco #89047294)
89047296 PLAYER, AUDIO DISC (ЧАСТЬ OF 1) (ACDelco #89047296)
89047514 PLAYER, AUDIO DISC (ЧАСТЬ OF 1) (ACDelco #89047514)
89047001 BRACKET KIT, RDO (INCLS 4-6) (ЧАСТЬ OF 1)
96068150 БОЛТ, 5X8X6 (ЧАСТЬ OF 1, 3) (8.906)
11560973 ГАЙКА, HEX W/CON WA, 5X0.8X5.1, 15 OD, 9 STL, GMW3044 (INCLS 5) (ЧАСТЬ OF 1, 3)
11509231 SCREW, RD HD C/R TAP, M4.2X1.41X13.0, GM6010M STL, GM813M NICKEL ORGANIC (RDO OPG CVR) [ВИНТ М6Х12]
15856035 BEZEL, RDO (WOODGRAIN)
teamcadillac.ru
10361083 АНТЕННА, ELEK NAVIGATION (ACDelco #10361083)
11518121 ГАЙКА, U, M6X1, MULTI THD, .5'-4.0' THK PNL (I/P LWR EXTN)
11589010 SCREW, M4.2X1.4X13 HWH W/FL WA 12.5-OD 6010M TAP GMW4205, BR-PT. (RDO ANT MDL)
(6E09-031) - 2004-2009 E КОМПРЕССОР КОНДИЦИОНЕРА КРЕПЛЕНИЕ (LY7/3.6-7)
12572043 BRACKET, КОНДИЦИОНЕР CMPR
11518628 БОЛТ, HVY HEX ACORN FLG HD, M10X1.5X50, GMW25M (10.9) STL, GMW3358 (КОНДИЦИОНЕР CMPR BRKT)
11519177 БОЛТ-HEX FLANGE HD, REDUCED BODY, M8X1.25X90, 8.8, GMW3359 (КОНДИЦИОНЕР CMPR) [ШЕСТИУГОЛЬНЫЙ ШУРУП]
teamcadillac.ru
(6E09-032) - 2005 E СИСТЕМА КОМУНИКАЦИИ "ONSTAR"(UE1)
teamcadillac.ru
15822996 MIRROR, I/S RR VIEW (USE T/W 15900947 (COVER) IF REPLACING 25743654) (W/MIC)
15850531 MIRROR, I/S RR VIEW (W/MIC) (USE T/W 15900947 (COVER) IF REPLACING PREVIOUS P/N 25743653)
25758073 АНТЕННА, M/TEL DIGITAL (INCLS 4) (66 MM) (АНТЕННА ONLY) (SHARKFIN DESIGN W/TWO TORX SCREWS) (ACDelco #25758073)
25840690 BASE, M/TEL & VEH LOC ANT (INCLS 6) (REQUIRES ANT MAST 10335503) (ACDelco #25840690)
19115112 CABLE, NAVIGATION ANT COAX (2025MM LONG)
11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (MULTIUSE RLY & FUSE BRKT) [БОЛТ М6]
21992664 BRACKET, COMMUNICATION INTERFACE MDL
(6E09-047) - 2005-2009 E АНТЕННА/АУДИОСИСТЕМА (U2K)
25758073 АНТЕННА, M/TEL DIGITAL (66 MM) (АНТЕННА ONLY) (SHARKFIN DESIGN W/TWO TORX SCREWS) (ACDelco #25758073)
25775153 BASE, DIGITAL RDO & M/TEL & VEH LOC (INCLS 9) (REQUIRES ANT MAST 10335503) (ACDelco #25775153)
19115114 CABLE, DIGITAL RDO АНТЕННА
15125061 RECEIVER, DIGITAL RDO (ACDelco #15125061)
25766240 BRACKET, DIGITAL RDO RCVR (INCLS 7)
10 - ВЕТРОВОЕ СТЕКЛО - СТЕКЛООЧИСТИТЕЛЬ - ЗЕРКАЛА - ПРИБОРНАЯ ПАНЕЛЬ - КОНСОЛЬ - ДВЕРИ
(6E10-022) - 2004-2006 E СТЕКЛООЧИСТИТЕЛЬ-ВЕТРОВОГО СТЕКЛА
25797175 CAP, WSW ARM NUT (FOR FINE THREAD PIVOT SHAFTS) [КРЫШКА ГАЙКИ ДЕРЖАТЕЛЯ СТЕКЛООЧИСТИТЕЛЯ]
11514597 ГАЙКА, HFH, 10X1.5 THD, 9.8 THK, 21.8 OD, 510M (10) ZF 7111M (WSW ARM) (2.383)
88958239 ARM, WSW
12487638 BLADE, WSW (INCLS 5) [ЩЕТКА СТЕКЛООЧИСТИТЕЛЯ]
88892785 WIPER, W/S (ЧАСТЬ OF 4) (21") (530MM) (DELMEX DE JUARE) (INSERT) [ЩЕТКА СТЕКЛООЧИСТИТЕЛЯ]
88958241 ARM, WSW
12487636 BLADE, WSW (INCLS 8) [ЩЕТКА СТЕКЛООЧИСТИТЕЛЯ]
12367281 WIPER, W/S (ЧАСТЬ OF 7) (22") (565MM) (DELMEX DE JUARE) (INSERT) [НАСАДКА ЩЕТКИ СТЕКЛООЧИСТИТЕЛЯ]
25773454 SEAL, КАПОТ RR (ЧАСТЬ OF 13)
11609489 БОЛТ, HEX W/ WASHER, 4.2X1.41X25, 14.5 THD17 OD, GM6010M STL, GMW4205 (AIR INL GRL PNL) [БОЛТ М4.2]
10134407 RETAINER, AIR INL GRL PNL (EBONY) (17.8 X 6.3 X 20.4MM) (NYLON) (ROUND PUSH-IN INCLS PUSH BUTTON LOCK) (1.272) [ФИКСАТОР КРЕПЛЕНИЯ ОБЛИЦОВКИ БАМПЕРА]
25902704 PANEL, AIR INL GRL (UPR) (INCLS 9, 10)
25768133 PANEL, AIR INL GRL (LWR) (INCLS 18-20)
11609489 БОЛТ, HEX W/ WASHER, 4.2X1.41X25, 14.5 THD17 OD, GM6010M STL, GMW4205 (AIR INL GRL) [БОЛТ М4.2]
11515638 ГАЙКА, U-TYPE, M4.2X1.41X10.5.5X22, .65-3.8 PNL THK, 1050, ZF (ЧАСТЬ OF 14) [ГАЙКА М4.2]
10125439 RIVET, FLAT HD, 3 LEG EXPANSION, M4.8 SHAFT, 23.5 LG, 9.8 O.D., AL (ЧАСТЬ OF 14) [ЗАКЛЕПКА D=4.8 ММ]
25764351 BRACKET, AIR INL GRL PNL (ЧАСТЬ OF 14)
11589267 ГАЙКА, AIR INL HSG (10.230)
11609411 ГАЙКА, AIR INL HSG (6 X 1, 5.07THK) (HEX-CHROME FREE FINISH) (8.917) [ГАЙКА М6]
19208922 МОДУЛЬ, WSW SYS (INCLS 22, 25, 26) (USE FINE THREAD CAP AND NUT) (10.159)
11519586 STUD, WSW SYS MDL (M6X1X11.5)
88958251 MOTOR, WSW (ЧАСТЬ OF 23) (ACDelco #88958251) [МОТОРЧИК СТЕКЛООЧИСТИТЕЛЯ В СБОРЕ]
88958172 COVER KIT, WSW MOT (ЧАСТЬ OF 23) [КРЫШКА МОТОРЧИКА СТЕКЛООЧИСТИТЕЛЯ]
10366565 NOZZLE, WSWA (HTD) [ФОРСУНКА СТЕКЛООМЫВАТЕЛЯ]
15778747 NOZZLE, WSWA [ФОРСУНКА СТЕКЛООМЫВАТЕЛЯ]
15218953 HOSE, WSWA SOLV CNTNR (СМ. ГРУППУ 12.000 "СТЕКЛООЧИСТИТЕЛЬ-ЗАДНЕГО СТЕКЛА" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (RR) (ACDelco #15218953) [ШЛАНГ СТЕКЛООМЫВАТЕЛЯ]
15218952 HOSE, WSWA SOLV CNTNR (TO I/P JUMPER)
teamcadillac.ru
15218962 HOSE, WSWA SOLV CNTNR (TO WSWA NOZ)
25731418 CAP, WSWA SOLV CNTNR (W/ISO SYMBOL)
88958248 CONTAINER, WSWA SOLV
88958249 CONTAINER, WSWA SOLV [БАЧОК СТЕКЛООМЫВАТЕЛЯ]
25767592 NOZZLE, HDLP WA [ФОРСУНКА ФАРООМЫВАТЕЛЯ]
25767593 NOZZLE, HDLP WA [ФОРСУНКА СТЕКЛООМЫВАТЕЛЯ]
25890367 HOSE, HDLP WA
11518121 ГАЙКА, U, M6X1, MULTI THD, .5'-4.0' THK PNL (WSWA SOLV CNTNR)
11517641 STUD, SPL, M6X1X25, 13 THD, 11 OD HD W/26 WIDE CLIP, 9.8, 6280M, P-PT (WSWA SOLV CNTNR)
11518094 БОЛТ-HES W/FL WA, M6X1X21, 11.75 THD, 24 OD, 9.8, 7114M, MACH, DOG-PT (WSWA SOLV CNTNR)
12487588 SEAL, WSWA SOLV LVL SW (16.065)
12487643 PUMP KIT, WSWA W/ SEAL (INCLS 40) (ACDelco #12487643) [НАСОС СТЕКЛООМЫВАТЕЛЯ]
88958155 PUMP, R/WDO WA (INCLS 40) (INCLS GROMMET) (ACDelco #88958155) [НАСОС СТЕКЛООМЫВАТЕЛЯ]
88958121 PUMP, HDLP WA (INCLS 39) (LOCATED IN WSW TANK) (ACDelco #88958121) [НАСОС СТЕКЛООМЫВАТЕЛЯ]
12487599 SWITCH, WSWA SOLV LVL (IF USING ORIG CNTR, CUSTOMER MAY NEED TO USE 12487589 IND) [ВЫКЛЮЧАТЕЛЬ НАСОСА СТЕКЛООМЫВАТЕЛЯ]
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (WSWA SOLV CNTNR) [ГАЙКА М6]
11589145 ГАЙКА, PUSH ON, M10, 20.0 OD, GMW3359 (AIR INL GRL PNL) [ШАЙБА 10 ММ]
(6E10-023) - 2004-2006 E ПРИБОРНАЯ ПАНЕЛЬ ЧАСТЬ 2 ELECTRICAL
11503749 ГАЙКА, M6X1 (INFL RST I/P MDL) (ACDelco #11503749)
25756980 МОДУЛЬ, I/P INFL RST
11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (I/P INFL RST MDL) [БОЛТ М6]
15845238 BRACKET, I/P CARR
25756514 BRACKET, I/P CARR
10391431 МОДУЛЬ, BODY CONT (ACDelco #10391431) [БЛОК УПРАВЛЕНИЯ СИСТЕМОЙ КОМФОРТА]
25769946 PANEL, INST (INCLS 45) (GRAY)
25769947 PANEL, INST (INCLS 45) (EBONY)
22570333 RETAINER, I/P ACSRY TR PLT (ЧАСТЬ OF 14) (10.240) [ДЕРЖАТЕЛЬ]
10360647 PLATE, I/P ACSRY TR (INCLS 12, 13) (WOOD FILM) (EXPORT)
25749919 PLATE, I/P ACSRY TR (INCLS 12, 13) (EBONY) (INCLS SW & RET) (DOMESTIC, NON EUROPEAN & MID EASTERN COUNTRIES)
25749920 PLATE, I/P ACSRY TR (INCLS 12, 13) (EBONY) (INCLS SW & RET) (EUROPEAN & MID EASTERN COUNTRIES) [ПЛАСТИНА В СБОРЕ]
25772306 PLATE, I/P ACSRY TR (INCLS 12, 13) (WALNUT BURL) (WOOD FILM) (DOMESTIC-NON EXP) (W/CTR DEFLECTORS)
11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (I/P LWR EXTN) [ВИНТ М4]
11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (I/P LWR EXTN) [БОЛТ М6]
25716163 COMPARTMENT, I/P (ЧАСТЬ OF 26) (CTR LWR, ЧАСТЬ OF ПЕПЕЛЬНИЦА PKG, FLOCKED BIN)
25716165 ПЕПЕЛЬНИЦА, I/P (ЧАСТЬ OF 50) [ПЕПЕЛЬНИЦА]
11516141 LIGHTER, CIG (ЧАСТЬ OF 50) (BLACK) (W/SMALL, PLASTIC KNOB END 14.0MM) [ПРИКУРИВАТЕЛЬ]
12385528 PLUG, ACSRY PWR RCPT OPG (ЧАСТЬ OF 26)
11516144 RETAINER, C/LTR HSG (I/P ПЕПЕЛЬНИЦА) (ЧАСТЬ OF 26, 50) (CASCO) (W/O CAP)
11516142 RECEPTACLE, C/LTR (ЧАСТЬ OF 26, 50) (MATES W/CONN 12085504, (CASCO) (1-PIN CONN)
89039649 LATCH, I/P ПЕПЕЛЬНИЦА (ЧАСТЬ OF 26, 50)
25758549 PANEL, I/P LWR EXTN TR (INCLS 18, 21-25, 27, 49) (EBONY)
25758553 PANEL, I/P LWR EXTN TR (INCLS 18, 21-25, 27, 49) (WOODGRAIN)
22570333 RETAINER, I/P ACSRY TR PLT (ЧАСТЬ OF 26, 50) (10.240) [ДЕРЖАТЕЛЬ]
11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (I/P LWR EXTN T/PNL) [ВИНТ М4]
25749981 EXTENSION, I/P LWR (INCLS 31) (EBONY)
25536302 ГАЙКА, I/P LWR EXTN (ЧАСТЬ OF 30) (4.2 X 1.41) (TAPPING NUT) (3.430) [ПРИЖИМНАЯ ПЛАСТИНА ПАНЕЛИ КУЗОВА]
25749976 PLATE, I/P CSTR TR (INCLS 32, 33) (EBONY)
25772409 CLUSTER, INST (ACDelco #25772409)
25772410 CLUSTER, INST (ACDelco #25772410)
11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (INST CSTR) [ВИНТ М4]
teamcadillac.ru
25687484 SENSOR, I/S AIR TEMP (ACDelco #15-5889) [ДАТЧИК ТЕМПЕРАТУРЫ ВОЗДУХА]
25687487 DUCT, AIR DISTR (DRIVER SIDE FACE) (TUBE, SENSOR)
25687489 DUCT, AIR DISTR (PASSENGER SIDE FACE) (TUBE, SENSOR)
11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (I/P) [ВИНТ М4]
25739307 BRACKET, BCM BRKT
11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (BCM BRKT) [ВИНТ М4]
11516993 ГАЙКА, M4.2X1.41 (BCM BRKT)
25718722 FLASHER, HAZARD LP & T/SIG LP (ACDelco #25718722) [РЕЛЕ ПРОБЛЕСКОВОГО СИГНАЛА]
11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (INST CARR BRKT) (ACDelco #11570082) [БОЛТ М8]
19207179 LINER, I/P COMPT (ЧАСТЬ OF 26)
25758550 PANEL, I/P LWR EXTN TR (INCLS 19, 20, 22-25, 27) (EBONY) [ПАНЕЛЬ В СБОРЕ]
25758552 PANEL, I/P LWR EXTN TR (INCLS 19, 20, 22-25, 27) (WOODGRAIN) [ПАНЕЛЬ ЦЕНТРАЛЬНОЙ КОНСОЛИ]
(6E10-024) - 2004-2006 E ПРИБОРНАЯ ПАНЕЛЬ ЧАСТЬ 1 TRIM
25749921 GRILLE, W/S DEFR NOZ (INCLS 2) (EBONY)
22570333 RETAINER, W/S DEFR NOZ GRL (ЧАСТЬ OF 1) (10.240) [ДЕРЖАТЕЛЬ]
11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (ЧАСТЬ OF 6) [ВИНТ М4]
11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (I/P) [БОЛТ М6]
25769946 PANEL, INST (INCLS 3, 4, 31, 33, 34, 49-51, 58, 59) (GRAY)
25769947 PANEL, INST (INCLS 3, 4, 31, 33, 34, 49-51, 58, 59) (EBONY)
25769948 PANEL, INST (INCLS 3, 4, 31, 33, 34, 49-51, 58, 59) (NEUTRAL)
22551452 CLIP, RETAINER, .051 THK, ZC (ЧАСТЬ OF 8) (10.240)
25756779 PANEL, I/P SI TR (INCLS 7) (EBONY)
25756780 PANEL, I/P SI TR (INCLS 7) (EBONY)
03525213 ЛАМПА, CTSY (INCLS 10) (WITHOUT LENS) (IN I/P)
09433102 ЛАМПА, CTSY (ЧАСТЬ OF 9) (ACDelco #564)
25725940 INSULATOR, I/P
15683368 BUMPER, F/FLR CNSL DR (ЧАСТЬ OF 28) (8.80 DIA) (CLOSED-STOP) (РАМА) (16.650)
11609461 БОЛТ, HX W/FL WA, M4.2X1.41X16, 9 THD, 12.5 OD, 6010M STL, GMW4205, SELFTA (I/P COMPT DR) [БОЛТ]
11516630 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (I/P INSL)
22549046 SCREW, M4.2X1.4X25, 11.1 O.D., 6010M, NZ (ЧАСТЬ OF 21)
11516630 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (I/P COMPT DR)
11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (ЧАСТЬ OF 21)
15820796 HANDLE, I/P COMPT DR LAT REL (ЧАСТЬ OF 21) (EBONY) (INCL HANDLE)
15820797 HANDLE, I/P COMPT DR LAT REL (ЧАСТЬ OF 21) (GRAY) (W/HDL)
25736545 HANDLE, I/P COMPT DR LAT REL (ЧАСТЬ OF 21) (NEUTRAL)
25749640 DOOR, I/P COMPT (INCLS 15, 18, 19, 22, 61, 62) (EBONY) (W/HANDLE)
25771235 DOOR, I/P COMPT (INCLS 15, 18, 19, 22, 61, 62) (GRAY) (W/HANDLE & LATCH)
25771236 DOOR, I/P COMPT (INCLS 15, 18, 19, 22, 61, 62) (NEUTRAL)
25701665 HINGE, I/P COMPT DR (ЧАСТЬ OF 21)
teamcadillac.ru
25767872 DAMPENER, I/P COMPT DR
11516630 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (I/P DRVR KNEE BOLS)
25728922 STOP, I/P COMPT DR (OUTBOARD)
25728923 STOP, I/P COMPT DR (INBOARD)
11516630 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (I/P COMPT)
25771233 COMPARTMENT, I/P (INCLS 12, 26, 29) (ЧАСТЬ OF PANEL PKG)
25536302 ГАЙКА, I/P (4.2 X 1.41) (TAPPING NUT) (3.430) [ПРИЖИМНАЯ ПЛАСТИНА ПАНЕЛИ КУЗОВА]
11570654 ГАЙКА, I/P REINF (ЧАСТЬ OF 6) (4.2 X 1.41) (FITS 8.75 SQ HOLE) (9.665)
11516630 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (I/P COMPT DR HGE)
25736546 STRIKER, I/P COMPT DR LAT (ЧАСТЬ OF 6)
11516630 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (ЧАСТЬ OF 6)
22570333 RETAINER, I/P DRVR KNEE BOLS (ЧАСТЬ OF 37) (10.240) [ДЕРЖАТЕЛЬ]
11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (I/P DRVR KNEE BOLS)
25750539 BOLSTER, I/P DRVR KNEE (INCLS 35, 38) (EBONY)
25750540 BOLSTER, I/P DRVR KNEE (INCLS 35, 38) (GRAY)
25750541 BOLSTER, I/P DRVR KNEE (INCLS 35, 38) (NEUTRAL)
11516993 ГАЙКА, M4.2X1.41 (ЧАСТЬ OF 37)
21994073 АМОРТИЗАТОР, I/P DRVR KNEE BOLS ENGY
25738907 BRACKET, I/P DRVR KNEE BOLS BRKT
25725939 INSULATOR, I/P
11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (КАПОТ PRIM LAT REL CBL) [ВИНТ М4]
11516630 SCREW, RD, M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (I/P DRVR KNEE BOLS BRKT)
11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (I/P BRKT) [ВИНТ М4]
25712639 HANDLE, КАПОТ PRIM LAT REL CBL [ФИКСАТОР ТРОСА ЗАМКА КАПОТА]
26043783 RETAINER, КАПОТ PRIM LAT REL CBL (3.880)
25536302 ГАЙКА, I/P (ЧАСТЬ OF 6) (4.2 X 1.41) (TAPPING NUT) (3.430) [ПРИЖИМНАЯ ПЛАСТИНА ПАНЕЛИ КУЗОВА]
11516993 ГАЙКА, M4.2X1.41 (ЧАСТЬ OF 6)
25714892 BRACKET, I/P (INCLS 54) (CLUSTER)
11516993 ГАЙКА, M4.2X1.41 (ЧАСТЬ OF 53, 56)
25741697 SEAL, I/P UPR T/PNL
25714893 BRACKET, I/P (INCLS 54) (CLUSTER)
25606251 RIVET, I/P (ЧАСТЬ OF 6) (.160 SHANK .125 LONG) (.063-.252 GRIP RANGE) (12.807)
15899309 DOOR, I/P COMPT (ЧАСТЬ OF 21) (GRAY) (W/O LATCH)
15899310 DOOR, I/P COMPT (ЧАСТЬ OF 21) (EBONY) (OUTER) (W/O HANDLE)
15899305 БОЛТ, I/P COMPT DR (ЧАСТЬ OF 21)
(6E10-025) - 2004-2006 E КОНСОЛЬ/ПОЛ (EXC U42)
25772994 PLATE, F/FLR CNSL TRANS SHFT OPG TR (INCLS 34) (INCLS TRAC CONT SWITCH)
25772995 PLATE, F/FLR CNSL TRANS SHFT OPG TR (INCLS 34) (WALNUT BURL) (INCLS TRAC CNTRL SW) [ПОДДОН]
89039923 PLATE, F/FLR UPR CNSL TR (PEWTER)
89039924 PLATE, F/FLR UPR CNSL TR (EBONY)
89039925 PLATE, F/FLR UPR CNSL TR
25762827 DOOR, F/FLR CNSL CUP HLDR (ЧАСТЬ OF 28, 32) (EBONY)
22611883 BUMPER, F/FLR RR CNSL A/RST (ЧАСТЬ OF 5) (BLACK) (6.6 DIA X 4.7 H) (10.263)
25625848 BUMPER, F/FLR RR CNSL A/RST (ЧАСТЬ OF 5) (8.8 DIA X 6.6 H) (10.263)
25766434 ARMREST, F/FLR CNSL (INCLS 4, 6, 7, 8, 9) (GRAY) (W/HINGE)
25766435 ARMREST, F/FLR CNSL (INCLS 4, 6, 7, 8, 9) (EBONY) (W/HINGE)
25766436 ARMREST, F/FLR CNSL (INCLS 4, 6, 7, 8, 9) (NEUTRAL)
25762833 ПРУЖИНА, F/FLR RR CNSL A/RST LAT (ЧАСТЬ OF 5)
25750149 LATCH, F/FLR RR CNSL A/RST (ЧАСТЬ OF 5) (EBONY) [ЗАЩЕЛКА ПЕРЧАТОЧНОГО ОТДЕЛЕНИЯ ЦЕНТР.КОНСОЛИ]
11509374 БОЛТ, SCR HEX W/FL WA, SELF TAP, 4.2X1.41X16, 12.5 O.D. (ЧАСТЬ OF 5, 28)
25762832 HINGE, F/FLR CNSL A/RST (ЧАСТЬ OF 5) (INCLS 13)
89039928 COMPARTMENT, F/FLR UPR (AUX STORAGE BIN)
89039927 COMPARTMENT, F/FLR CNSL (INCLS 10) (BASE)
03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (ЧАСТЬ OF 9)
25762843 COVER, F/FLR CNSL A/RST HGE (GRAY)
25762844 COVER, F/FLR CNSL A/RST HGE (EBONY)
25762845 COVER, F/FLR CNSL A/RST HGE (NEUTRAL)
89046337 COVER, F/FLR CNSL RR (INCLS 16) (EBONY) (END CAP LESS APO)
89046338 COVER, F/FLR CNSL RR (INCLS 16) (GRAY) (END CAP LESS APO)
89046339 COVER, F/FLR CNSL RR (INCLS 16) (NEUTRAL) ( (END CAP LESS APO) ALSO INCLUDES NET)
15187371 RETAINER, ACSRY PWR RCPT (EBONY) (INCLS COVER) [ОКАНТОВКА ГНЕЗДА ПРИКУРИВАТЕЛЯ]
25774623 RECEPTACLE, ACSRY PWR (ACSRY PWR RECEPTACLE ASSEM LABELED 4623) [ГНЕЗДО ПРИКУРИВАТЕЛЯ С КОНТАКТН. ЭЛЕМЕНТ., 12 ВТ]
11502553 ГАЙКА, STAMPED, M6.3 STUD, SELF THD, STL, PC (ЧАСТЬ OF 28) [ГАЙКА М6]
11561674 БОЛТ, HEX W/FL WA, M6X1X20, 12 THD, 24 OD, 9.8, GMW3359, M-PT (F/FLR CNSL) [БОЛТ М6]
25741044 COVER, F/FLR CNSL БОЛТ ACC HOLE (EBONY)
25752349 COVER, F/FLR CNSL БОЛТ ACC HOLE (GRAY)
25752350 COVER, F/FLR CNSL БОЛТ ACC HOLE (NEUTRAL)
25762739 SUPPORT, F/FLR CNSL FRT
03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (F/FLR CNSL FRT SUPT)
25761664 HARNESS, F/FLR CNSL WRG
89039972 КОНСОЛЬ, F/FLR (INCLS 3, 8, 14, 20-22, 29, 30) (GRAY)
89039973 КОНСОЛЬ, F/FLR (INCLS 3, 8, 14, 20-22, 29, 30) (EBONY)
89039974 КОНСОЛЬ, F/FLR (INCLS 3, 8, 14, 20-22, 29, 30) (NEUTRAL)
11516993 ГАЙКА, M4.2X1.41 (F/FLR CNSL)
teamcadillac.ru
25768249 ДЕРЖАТЕЛЬ, F/FLR CNSL CUP (INCLS 3) (EBONY)
25762825 LINER, F/FLR CNSL CUP HLDR (EBONY)
25749095 SWITCH, ELEK TRACT CONT (EBONY) (ACDelco #25749095)
(6E10-026) - 2004-2006 E КОНСОЛЬ/ПОЛ (U42)
25772994 PLATE, F/FLR CNSL TRANS SHFT OPG TR (INCLS 40) (INCLS TRAC CONT SWITCH)
25772995 PLATE, F/FLR CNSL TRANS SHFT OPG TR (INCLS 40) (WALNUT BURL) (INCLS TRAC CNTRL SW) [ПОДДОН]
89039923 PLATE, F/FLR UPR CNSL TR (ЧАСТЬ OF 33) (PEWTER)
89039924 PLATE, F/FLR UPR CNSL TR (ЧАСТЬ OF 33) (EBONY)
89039925 PLATE, F/FLR UPR CNSL TR (ЧАСТЬ OF 33)
25762827 DOOR, F/FLR CNSL CUP HLDR (ЧАСТЬ OF 33, 36) (EBONY)
25766434 ARMREST, F/FLR CNSL (INCLS 4, 7, 8, 37, 38) (GRAY) (W/HINGE)
25766435 ARMREST, F/FLR CNSL (INCLS 4, 7, 8, 37, 38) (EBONY) (W/HINGE)
25766436 ARMREST, F/FLR CNSL (INCLS 4, 7, 8, 37, 38) (NEUTRAL)
25762848 COVER, F/FLR CNSL A/RST HGE (EBONY) (UPPER)
25762849 COVER, F/FLR CNSL A/RST HGE (NEUTRAL) (UPPER)
89039935 COVER, F/FLR CNSL A/RST HGE (GRAY) (UPPER)
11509374 БОЛТ, SCR HEX W/FL WA, SELF TAP, 4.2X1.41X16, 12.5 O.D. (ЧАСТЬ OF 5, 33)
89039929 COMPARTMENT, F/FLR CNSL (INCLS 9) (W/DVD)
10377705 DISPLAY, VIDEO W/ DVD (INCLS 12, 13, 14, 16, 19, 42) (BLACK) (ACDelco #10377705) [МОНОБЛОК, ВКЛЮЧ.DVD-ПРОИГРЫВАТЕЛЬ С МОНИТОРОМ]
10377706 DISPLAY, VIDEO W/ DVD (INCLS 12, 13, 14, 16, 19, 42) (GRAY) (ACDelco #10377706) [МОНОБЛОК, ВКЛЮЧ.DVD-ПРОИГРЫВАТЕЛЬ С МОНИТОРОМ 18СМ, С ПИТАНИЕМ 12В]
10377707 DISPLAY, VIDEO W/ DVD (INCLS 12, 13, 14, 16, 19, 42) (ACDelco #10377707)
11609463 БОЛТ, HEX W/FLAT WASHER, M4.2X1.4X10, 12.5 OD, 6010M, GMW4205, TAP (ЧАСТЬ OF 11)
03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (F/FLR CNSL A/RST HGE)
15714276 SCREW, HWH, W/FL WA, SELF TAP, M4.2X1.41X18, 12.5 O.D., 6010M, PS (ЧАСТЬ OF 33) (8.977)
89039980 COVER, F/FLR CNSL A/RST HGE (GRAY) (LOWER)
89039981 COVER, F/FLR CNSL A/RST HGE (EBONY)
89039982 COVER, F/FLR CNSL A/RST HGE (NEUTRAL) (LOWER)
25759970 BEZEL, VIDEO DISPLAY (ЧАСТЬ OF 11) (INCLS 42)
89039931 COVER, F/FLR CNSL RR (INCLS 23) (GRAY)
89039932 COVER, F/FLR CNSL RR (INCLS 23) (EBONY)
89039933 COVER, F/FLR CNSL RR (INCLS 23) (NEUTRAL)
15965094 CLIP, F/FLR CNSL RR CVR (ЧАСТЬ OF 20, 33) (SILVER) (11 X 13) (16.041) [КРЕПЛЕНИЕ]
11609463 БОЛТ, HEX W/FLAT WASHER, M4.2X1.4X10, 12.5 OD, 6010M, GMW4205, TAP (VIDEO DISPLAY)
11501851 ГАЙКА, M6.3 STPD TYPE SFW W/SLR ZC (ЧАСТЬ OF 33)
11517342 БОЛТ, HEX HD, W/FL WA, M6X1X20, 9.53 THD, 17 O.D., P-PT, 9.8, 6280M (F/FLR CNSL)
teamcadillac.ru
25761663 HARNESS, F/FLR CNSL WRG
25771042 HARNESS, F/FLR CNSL WRG
89039976 КОНСОЛЬ, F/FLR (INCLS 2, 3, 7, 23, 26, 27, 35, 39, 41) (GRAY)
89039977 КОНСОЛЬ, F/FLR (INCLS 2, 3, 7, 23, 26, 27, 35, 39, 41) (EBONY)
89039978 КОНСОЛЬ, F/FLR (INCLS 2, 3, 7, 23, 26, 27, 35, 39, 41) (NEUTRAL)
25768249 ДЕРЖАТЕЛЬ, F/FLR CNSL CUP (INCLS 3, 39) (EBONY)
25762825 LINER, F/FLR CNSL CUP HLDR (ЧАСТЬ OF 33, 36) (EBONY)
25749095 SWITCH, ELEK TRACT CONT (ЧАСТЬ OF 1) (EBONY) (ACDelco #25749095)
(6E10-029) - 2004-2006 E АРМАТУРА ПЕРЕДНЕЙ ДВЕРИ
19207864 КЛЮЧ, DR LK & IGN LK [КЛЮЧ ЗАМКА ДВЕРИ]
19121213 HANDLE PKG, FRT S/D O/S (КРАСКА TO MATCH)
19121214 HANDLE PKG, FRT S/D O/S (КРАСКА TO MATCH)
15833810 WINDOW, FRT S/D [СТЕКЛО ПЕРЕДНЕЙ ДВЕРИ]
15833811 WINDOW, FRT S/D [СТЕКЛО ПЕРЕДНЕЙ ДВЕРИ]
25766237 ROD, FRT S/D O/S HDL
25766238 ROD, FRT S/D O/S HDL
25718638 ROD, FRT S/D LK CYL
25752069 DEADENER, FRT S/D
11517230 БОЛТ, TORX, W/WA, W/ADH, M6X1X20, 16.2 O.D., DOG PT, 10.9, GM6138M (FRT S/D LK) [ВИНТ ЗАМКА ДВЕРИ М6]
25758328 SEALING STRIP, FRT S/D WDO INR
25795707 SEALING STRIP, FRT S/D WDO INR
25718643 ROD, FRT S/D LKG
25718644 ROD, FRT S/D LKG
16608794 CLIP, FRT S/D LKG ROD
25718646 ROD, FRT S/D I/S HDL
25718647 ROD, FRT S/D I/S HDL
21110669 PLUG, FRT S/D INR PNL HOLE (35 MM) (ROUND) (12.179)
15218754 DEFLECTOR, FRT S/D WAT (INCLS 19)
25718631 DEFLECTOR, FRT S/D WAT (INCLS 19)
25759728 HANDLE, FRT S/D I/S (HIGH LUSTER)
25759729 HANDLE, FRT S/D I/S (HIGH LUSTER) [РУЧКА]
teamcadillac.ru
12337828 SCREW, HEX W/FLAT WA, TAP, M6.3X1.81X20, 13.2 O.D., AB PT, STL, PZ0R (FRT S/D I/S HDL)
25773048 REGULATOR, FRT S/D WDO (10.783) (ACDelco #25773048)
25773049 REGULATOR, FRT S/D WDO (10.783) (ACDelco #25773049) [РЕГУЛЯТОР]
11517517 БОЛТ, HFH, M6X1X16, 13.5 THD, 14.2 OD, 9.8, SN-ZN, MACH, HDR-PT (FRT S/D WDO REG)
15883427 HARNESS, FRT S/D DR WRG
15883428 HARNESS, FRT S/D DR WRG
25761145 HARNESS, FRT S/D DR WRG
25761146 HARNESS, FRT S/D DR WRG
10365428 МОДУЛЬ, DR LK & O/S RR VIEW MIR & P/W CONT (10.485)
10365429 МОДУЛЬ, DR LK & O/S RR VIEW MIR & P/W CONT (10.485) [БЛОК УПРАВЛЕНИЯ ЦЕНТРАЛЬНЫМ ЗАМКОМ]
25744679 BRACKET, ELEK SYS PWR SPLY MDL (FRT DR МОДУЛЬ)
25744680 BRACKET, ELEK SYS PWR SPLY MDL (FRT DR МОДУЛЬ)
11570209 БОЛТ, DR LK & P/W CONT MDL (2.510)
25733016 WEATHERSTRIP, FRT S/D LWR AUX
25733017 WEATHERSTRIP, FRT S/D LWR AUX
25701880 PLATE, FRT S/D HGE ANC (DR SI)
15932612 HINGE, FRT S/D LWR (10.460)
15932613 HINGE, FRT S/D LWR (10.460) [ПЕТЛЯ ДВЕРИ]
11519106 БОЛТ, CONICAL, M8X1.25X35, 23.5 THD, 24 OD, 10.9, 7114M, 6.0 DOG PT, MACH (FRT S/D LWR HGE (BODY SI))
11610041 БОЛТ, HFH W/SHLDR, M8X1.25X25, 12.55 THD, 21 OD, 10.9 (FRT S/D UPR HGE (DR SI)) [БОЛТ]
15932612 HINGE, FRT S/D UPR (10.460)
15932613 HINGE, FRT S/D UPR (10.460) [ПЕТЛЯ ДВЕРИ]
11569646 БОЛТ, FRT S/D CHK LINK (BODY SI)
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (FRT S/D CHK LINK (DR SI)) [ГАЙКА М6]
15783070 LINK, FRT S/D CHK
03907444 ГАЙКА, PUSH IN, SQUARE, UN THD, M9.5 SQ HOLE, NYLON (FRT S/D I/S HDL)
25751121 KNOB, FRT S/D LKG ROD (GRAY) [КНОПКА]
25751122 KNOB, FRT S/D LKG ROD (NEUTRAL) [КНОПКА]
25751335 KNOB, FRT S/D LKG ROD (EBONY) [КНОПКА]
25843196 LOCK, FRT S/D
25843197 LOCK, FRT S/D
25767129 WEATHERSTRIP, FRT S/D WDO
25767130 WEATHERSTRIP, FRT S/D WDO
25768297 APPLIQUE, FRT S/D WDO FRM RR (INCLS 49) (SMOOTH FINISH) (CUSTOMER MAY BE REQUIRED TO REPLACE ALL APPLIQUE TO MATCH) [МОЛДИНГ КУЗОВА]
25768298 APPLIQUE, FRT S/D WDO FRM RR (INCLS 49) (SMOOTH FINISH) (CUSTOMER MAY BE REQUIRED TO REPLACE ALL APPLIQUE TO MATCH) [ПАНЕЛЬ ДВЕРИ]
19120424 WEATHERSTRIP, FRT S/D (NEUTRAL)
19120426 WEATHERSTRIP, FRT S/D (EBONY)
19169082 WEATHERSTRIP, FRT S/D (GRAY) [УПЛОТНИТЕЛЬ ДВЕРИ]
20725768 SCREW, PAN HD W/FL WA, M4.2X1.41X13, 8.15 O.D., ABHL PT, 6010M, NO (FRT S/D WDO FRT CHAN BRKT)
11609460 SCREW, RND WA, M4.2X1.41X10, 4.2 THD, 11 OD, GM6010M, GMW4205, C/R, TAP (FRT S/D WDO FRM RR APLQ)
25804696 SEALING STRIP, FRT S/D WDO OTR (HIGH LUSTER FINISH) [УПЛОТНЕНИЕ ОКНА ДВЕРИ]
25804697 SEALING STRIP, FRT S/D WDO OTR (HIGH LUSTER FINISH) [УПЛОТНИТЕЛЬ ОКНА ДВЕРИ]
11518445 SCREW, FLAT-HD HEX ALLEN, CSINK, M8X1.25X25, 18.05 THD, 14.7 OD, 8.8, GMW3044. (FRT S/D LK STKR) [БОЛТ М8Х1.25]
15883584 STRIKER, FRT S/D LK
15297594 WEATHERSTRIP, FRT & RR S/D UPR
15297595 WEATHERSTRIP, FRT & RR S/D UPR
25676040 PLUG, FRT S/D ACC HOLE (AT O/S HDL ATTACH ACCESS) (25MM OD) (12.809)
11570654 ГАЙКА, FRT S/D WDO FRM RR APLQ (4.2 X 1.41) (FITS 8.75 SQ HOLE) (9.665)
25706593 GROMMET, SUN RF HSG FRT DRN HOSE [УПЛОТНИТЕЛЬНОЕ КОЛЬЦО КУЗОВА]
(6E10-030) - 2004-2006 E АРМАТУРА ЗАДНЕЙ ДВЕРИ
19121215 HANDLE, RR S/D O/S (КРАСКА TO MATCH)
19121216 HANDLE, RR S/D O/S (КРАСКА TO MATCH)
10385012 WINDOW, RR S/D (LT TINT) (W/CCC MARKING) (ALLOWS HIGHER PENETRATION OF GLASS BY 1.5 MM)
10385013 WINDOW, RR S/D (LT TINT) (W/CCC MARKING) (ALLOWS HIGHER PENETRATION OF GLASS BY 1.5 MM)
10385016 WINDOW, RR S/D (DARK TINT) [СТЕКЛО ЗАДНЕЙ ДВЕРИ]
10385017 WINDOW, RR S/D (DARK TINT) [СТЕКЛО ЗАДНЕЙ ДВЕРИ]
89025817 DOOR, RR SI (INCLS 22) (INCLS PANEL, PLATE, REINFORCEMENT) (DOES NOT REQUIRE LOWER AUXILLIARY WEATHERSTRIP) [ПАНЕЛЬ ДВЕРИ]
89025818 DOOR, RR SI (INCLS 22) (INCLS PANEL, PLATE, REINFORCEMENT) (DOES NOT REQUIRE LOWER AUXILLIARY WEATHERSTRIP) [ЗАДНЯЯ ДВЕРЬ]
25718652 ROD, RR S/D LKG
25718653 ROD, RR S/D LKG
10328154 SEAL, RR S/D I/S HDL (10.565)
25766235 ROD, RR S/D O/S HDL
25766236 ROD, RR S/D O/S HDL
11517230 БОЛТ, TORX, W/WA, W/ADH, M6X1X20, 16.2 O.D., DOG PT, 10.9, GM6138M (RR S/D LK) [ВИНТ ЗАМКА ДВЕРИ М6]
25843159 LOCK, RR S/D
25843160 LOCK, RR S/D
25758330 SEALING STRIP, RR S/D WDO INR
25795698 SEALING STRIP, RR S/D WDO INR
12337828 SCREW, HEX W/FLAT WA, TAP, M6.3X1.81X20, 13.2 O.D., AB PT, STL, PZ0R (RR S/D I/S HDL)
25759728 HANDLE, RR S/D I/S (HIGH LUSTER)
25759729 HANDLE, RR S/D I/S (HIGH LUSTER) [РУЧКА]
25718634 DEFLECTOR, RR S/D WAT (INCLS 10)
25718635 DEFLECTOR, RR S/D WAT (INCLS 10)
15269138 REGULATOR, RR S/D WDO (INCLS MOTOR) (ACDelco #15269138)
15269139 REGULATOR, RR S/D WDO (INCLS MOTOR) (ACDelco #15269139)
25718659 ROD, RR S/D I/S HDL
25718660 ROD, RR S/D I/S HDL
16608794 CLIP, RR S/D I/S HDL ROD
03907444 ГАЙКА, PUSH IN, SQUARE, UN THD, M9.5 SQ HOLE, NYLON (RR S/D I/S HDL)
11517517 БОЛТ, HFH, M6X1X16, 13.5 THD, 14.2 OD, 9.8, SN-ZN, MACH, HDR-PT (RR S/D WDO REG)
25733019 WEATHERSTRIP, RR S/D LWR AUX
25733020 WEATHERSTRIP, RR S/D LWR AUX
11569646 БОЛТ, RR S/D CHK LINK BODY SI (10.455)
25773003 LINK, RR S/D CHK
25701880 PLATE, RR S/D HGE ANC (DR SI) (ЧАСТЬ OF 3) (10.450)
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (RR S/D CHK LINK DR SI) [ГАЙКА М6]
15932612 HINGE, RR S/D LWR
15932613 HINGE, RR S/D LWR [ПЕТЛЯ ДВЕРИ]
11610041 БОЛТ, HFH W/SHLDR, M8X1.25X25, 12.55 THD, 21 OD, 10.9 (RR S/D LWR HGE (DR SI)) [БОЛТ]
15932614 HINGE, RR S/D UPR
15932615 HINGE, RR S/D UPR
25680445 HINGE, RR S/D UPR
25767131 WINDOW, RR S/D STA (W/RR S/D WDO W/STR) (LIGHT TINT)
25794904 WINDOW, RR S/D STA (W/RR S/D WDO W/STR) (DARK TINT)
25794905 WINDOW, RR S/D STA (W/RR S/D WDO W/STR) (DARK TINT)
25794906 WINDOW, RR S/D STA (W/RR S/D WDO W/STR) (LIGHT TINT)
25768299 APPLIQUE, RR S/D WDO FRM FRT (SMOOTH FINISH) (CUSTOMER MAY BE REQUIRED TO REPLACE ALL APPLIQUE TO MATCH) [НАКЛАДКА ДВЕРИ]
25768300 APPLIQUE, RR S/D WDO FRM FRT (SMOOTH FINISH) (CUSTOMER MAY BE REQUIRED TO REPLACE ALL APPLIQUE TO MATCH) [НАКЛАДКА ДВЕРИ]
25804694 SEALING STRIP, RR S/D WDO OTR (HIGH LUSTER FINISH)
25804695 SEALING STRIP, RR S/D WDO OTR (HIGH LUSTER FINISH) [УПЛОТНИТЕЛЬ СТЕКЛА ДВЕРИ]
11517484 БОЛТ-HEX, M6X1X20, 9 THD, 17 OD, 9.8, 6280M, MACH, P-PT (RR S/D STA WDO)
11609460 SCREW, RND WA, M4.2X1.41X10, 4.2 THD, 11 OD, GM6010M, GMW4205, C/R, TAP (RR S/D WDO FRM FRT APLQ)
19120427 WEATHERSTRIP, RR S/D (NEUTRAL)
19120429 WEATHERSTRIP, RR S/D (EBONY)
19169085 WEATHERSTRIP, RR S/D (GRAY)
15883584 STRIKER, RR S/D LK
11518445 БОЛТ, RR S/D LK STKR (8 X 1.25 X 25) (T40) (8.908) [БОЛТ М8Х1.25]
11570209 STUD, ELEK SYS PWR SPLY MDL BRKT
10365426 МОДУЛЬ, DR LK & P/W CONT (ЗАДНЯЯ ДВЕРЬ) (MANUAL FOLDING MIRROR)
10365427 МОДУЛЬ, DR LK & P/W CONT (LH ЗАДНЯЯ ДВЕРЬ M) [БЛОК УПРАВЛЕНИЯ ЦЕНТРАЛЬНЫМ ЗАМКОМ]
15144699 HARNESS, RR S/D DR WRG
15144700 HARNESS, RR S/D DR WRG
teamcadillac.ru
25676040 PLUG, RR S/D ACC HOLE (AT O/S HDL ATTACH ACCESS) (25MM OD) (12.809)
(6E10-031) - 2004-2009 E ЦЕНТРАЛЬНЫЙ ЗАМОК
12223085 TRANSMITTER, R/CON DR LK (INCLS 3) (TRANSMITTER #1)
12223086 TRANSMITTER, R/CON DR LK (INCLS 3) (TRANSMITTER #2)
12223108 TRANSMITTER, R/CON DR LK (INCLS 3) (TRANSMITTER #1) [ПЕРЕДАТЧИК В СБОРЕ]
12223109 TRANSMITTER, R/CON DR LK (INCLS 3) (TRANSMITTER #2)
teamcadillac.ru
12223130 TRANSMITTER, R/CON DR LK (INCLS 3) (TRANSMITTER #1)
12223131 TRANSMITTER, R/CON DR LK (INCLS 3) (TRANSMITTER #2)
(6E10-032) - 2004-2005 E ВЕТРОВОЕ СТЕКЛО TRIM & АРМАТУРА
15879005 ВЕТРОВОЕ СТЕКЛО, (INCLS 3) (INCLS UPPER REVEAL MOLDING)
25919737 ВЕТРОВОЕ СТЕКЛО, (INCLS 3)
25919739 ВЕТРОВОЕ СТЕКЛО, (INCLS 3) [ВЕТРОВОЕ СТЕКЛО]
15850530 MIRROR, I/S RR VIEW (USE T/W 15900947 (COVER) IF REPLACING PREVIOUS P/N 25731930)
25715946 COVER, I/S RR VIEW MIR WRG HARN UPR (70MM LONG) (FROM HDLNG) (10.187)
25691393 COVER, I/S RR VIEW MIR MT PLT (LOWER ISRVM COVER) (AT MIRROR)
teamcadillac.ru
12346392 ADHESIVE KIT, GLASS URETHANE (W/S) (FOR INSTALLATION OF ALL STATIONARY WINDOW GLASS)
11610050 RIVET - POP, 3.25X14.93, 6.65 OD, AA5052, 3.99 - 7.93 GRP RING, (W/S R/MLDG CLIP) (8.967)
25756944 CLIP, W/S R/MLDG
25763321 MOLDING, W/S SI RVL (WHITE)
25763322 MOLDING, W/S SI RVL (GREEN)
25763323 MOLDING, W/S SI RVL (GREEN)
25763324 MOLDING, W/S SI RVL (WHITE)
25763328 MOLDING, W/S SI RVL (GRAY)
25763329 MOLDING, W/S SI RVL (BLUE)
25763330 MOLDING, W/S SI RVL (BLACK)
25763331 MOLDING, W/S SI RVL (BLACK)
25763332 MOLDING, W/S SI RVL (BLUE)
25764000 MOLDING, W/S SI RVL (RED)
25764001 MOLDING, W/S SI RVL (RED)
25764002 MOLDING, W/S SI RVL (SILVER)
25764003 MOLDING, W/S SI RVL (SILVER)
25764004 MOLDING, W/S SI RVL (CHESTNUT)
25764005 MOLDING, W/S SI RVL (CHESTNUT)
25764006 MOLDING, W/S SI RVL (GRAY)
25765155 MOLDING, W/S SI RVL (GOLD)
25765156 MOLDING, W/S SI RVL (GOLD)
(6E10-033) - 2004-2006 E ЗЕРКАЛА ЗАДНЕГО ОБЗОРА(DR2)
88892799 GLASS, O/S RR VIEW MIR (W/BKG PLATE) (ЧАСТЬ OF 4)
89044604 GLASS, O/S RR VIEW MIR (ЧАСТЬ OF 4) (REFL GLASS ONLY)
teamcadillac.ru
10398146 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (WHITE)
10398147 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (WHITE)
10398148 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (BLUE)
10398149 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (BLUE)
10398150 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (BLACK)
10398151 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (BLACK)
10398152 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (GRAY)
10398153 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (GRAY)
10398154 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (GREEN)
10398156 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (RED)
10398158 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (SILVER)
10398159 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (SILVER)
10398160 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (SILVER)
10398161 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (SILVER)
10398162 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (GOLD)
10398163 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (GOLD)
19206456 MIRROR, O/S RR VIEW (USE T/W MIRROR #89044607 (ENGLISH TEXT), #89044606 (ARABIC TEXT), OR#89044605 (NO TEXT) (INCLS 1-3, 5) (КРАСКА TO MATCH) (REPL ALL COLORS) [ЗЕРКАЛО ЗАДНЕГО ОБЗОРА В СБОРЕ]
25763056 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (GREEN)
25763060 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (RED)
11508277 ГАЙКА, HEX W/CON WA M6X1 THD, OD-19 PEOR 9 (O/S RR VIEW MIR REINF) [ГАЙКА М6]
(6E10-033) - 2004-2006 E ЗЕРКАЛА ЗАДНЕГО ОБЗОРА(DR4)
88892799 GLASS, O/S RR VIEW MIR (W/BKG PLATE) (*KIT1)
88892804 GLASS, O/S RR VIEW MIR (W/BKG PLATE) (*KIT1) [СТЕКЛО ЗЕРКАЛА ЗАДНЕГО ВИДА]
88892805 GLASS, O/S RR VIEW MIR (W/BKG PLATE) (USE T/W 25804888 ШЛАНГИ) (*KIT1)
89044605 GLASS, O/S RR VIEW MIR (W/BKG PLATE) (*KIT1)
89044606 GLASS, O/S RR VIEW MIR (W/BKG PLATE) (*KIT1)
89044607 GLASS, O/S RR VIEW MIR (W/BKG PLATE) (*KIT1)
19206455 ШЛАНГИ, O/S RR VIEW MIR (DOES NOT INCL MIRROR (REFL GLASS & BKG PLT) (USE T/W MIRROR #88892799 (ENGLISH TEXT), #88892805 (ARABIC TEXT), OR #88892804 (NO TEXT) (INCLS 2, 3) (КРАСКА TO MATCH) (REPL ALL COLORS) (*KIT1) [ЗЕРКАЛО ЗАДНЕГО ОБЗОРА В СБОРЕ]
19206456 ШЛАНГИ, O/S RR VIEW MIR (DOES NOT INCL MIRROR (REFL GLASS & BKG PLT) (USE T/W MIRROR #89044607 (ENGLISH TEXT), #89044606 (ARABIC TEXT), OR #89044605 (NO TEXT) (INCLS 2, 3) (КРАСКА TO MATCH) (REPL ALL COLORS) (*KIT1) [ЗЕРКАЛО ЗАДНЕГО ОБЗОРА В СБОРЕ]
10384135 MIRROR, O/S RR VIEW (INCLS 1-5) (WHITE)
10384138 MIRROR, O/S RR VIEW (INCLS 1-5) (WHITE)
10398176 MIRROR, O/S RR VIEW (INCLS 1-5) (WHITE)
10398177 MIRROR, O/S RR VIEW (INCLS 1-5) (WHITE) [ЗЕРКАЛО ЗАДНЕГО ОБЗОРА]
10398179 MIRROR, O/S RR VIEW (INCLS 1-5) (BLUE) [ЗЕРКАЛО]
10398182 MIRROR, O/S RR VIEW (INCLS 1-5) (GRAY) [ЗЕРКАЛО]
10398184 MIRROR, O/S RR VIEW (INCLS 1-5) (GREEN)
10398185 MIRROR, O/S RR VIEW (INCLS 1-5) (GREEN) [ЗЕРКАЛО ЗАДНЕГО ВИДА]
10398186 MIRROR, O/S RR VIEW (INCLS 1-5) (RED)
10398187 MIRROR, O/S RR VIEW (INCLS 1-5) (RED)
10398188 MIRROR, O/S RR VIEW (INCLS 1-5) (SILVER)
10398192 MIRROR, O/S RR VIEW (INCLS 1-5) (GOLD) [ЗЕРКАЛО]
10398193 MIRROR, O/S RR VIEW (INCLS 1-5) (GOLD) [ЗЕРКАЛО В СБОРЕ]
10398209 MIRROR, O/S RR VIEW (INCLS 1-5) (BLUE)
10398212 MIRROR, O/S RR VIEW (INCLS 1-5) (GRAY)
10398213 MIRROR, O/S RR VIEW (INCLS 1-5) (GRAY)
10398215 MIRROR, O/S RR VIEW (INCLS 1-5) (GREEN)
teamcadillac.ru
10398216 MIRROR, O/S RR VIEW (INCLS 1-5) (RED)
10398217 MIRROR, O/S RR VIEW (INCLS 1-5) (RED)
10398218 MIRROR, O/S RR VIEW (INCLS 1-5) (SILVER)
10398219 MIRROR, O/S RR VIEW (INCLS 1-5) (SILVER)
10398221 MIRROR, O/S RR VIEW (INCLS 1-5) (SILVER)
10398248 MIRROR, O/S RR VIEW (INCLS 1-5) (SILVER)
10398249 MIRROR, O/S RR VIEW (INCLS 1-5) (SILVER)
10398251 MIRROR, O/S RR VIEW (INCLS 1-5) (SILVER)
19206455 MIRROR, O/S RR VIEW (USE T/W MIRROR #88892799 (ENGLISH TEXT), #88892805 (ARABIC TEXT), OR#88892804 (NO TEXT) (INCLS 1-5) (КРАСКА TO MATCH) (REPL ALL COLORS) [ЗЕРКАЛО ЗАДНЕГО ОБЗОРА В СБОРЕ]
19206456 MIRROR, O/S RR VIEW (USE T/W MIRROR #89044607 (ENGLISH TEXT), #89044606 (ARABIC TEXT), OR#89044605 (NO TEXT) (INCLS 1-5) (КРАСКА TO MATCH) (REPL ALL COLORS) [ЗЕРКАЛО ЗАДНЕГО ОБЗОРА В СБОРЕ]
21994778 MIRROR, O/S RR VIEW (INCLS 1-5) (GOLD)
25763085 MIRROR, O/S RR VIEW (INCLS 1-5) (BLACK)
25763100 MIRROR, O/S RR VIEW (INCLS 1-5) (SILVER)
25763108 MIRROR, O/S RR VIEW (INCLS 1-5) (GRAY)
25763109 MIRROR, O/S RR VIEW (INCLS 1-5) (GRAY)
25763114 MIRROR, O/S RR VIEW (INCLS 1-5) (RED)
(6E10-033) - 2004-2006 E ЗЕРКАЛА ЗАДНЕГО ОБЗОРА(DR5)
88892806 GLASS, O/S RR VIEW MIR (ЧАСТЬ OF 4) (REFL GLASS ONLY)
10384129 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (WHITE)
10384130 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (WHITE)
10398118 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (BLUE)
10398120 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (BLACK)
10398121 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (BLACK)
10398122 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (GRAY)
10398124 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (GREEN)
10398128 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (SILVER)
10398129 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (SILVER)
10398130 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (SILVER)
10398131 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (SILVER)
10398132 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (GOLD)
21994764 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (GOLD)
25763030 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (BLUE)
teamcadillac.ru
25763036 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (GRAY)
25763038 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (GREEN)
25763041 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (RED)
25763042 MIRROR, O/S RR VIEW (INCLS 1-3, 5) (RED)
(6E10-034) - 2004-2006 E ПРИБОРНАЯ ПАНЕЛЬ ЧАСТЬ 3 STRUCTURE
25764250 КРОНШТЕЙН, INST (INCLS 7-10, 14-16, 20)
11516466 БОЛТ/SCREW, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (I/P)
11570082 БОЛТ, HFH, M8X1.25X22, 19 THD, 18 OD, 10.9, GMW3359 (INST CARR) (ACDelco #11570082) [БОЛТ М8]
11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (INST CARR BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16]
11517792 ГАЙКА, HEX W/FL WA, M8X1.25, 10.75 THK, 24 OD, 10, 7111M (I/P CARR BRKT)
25536302 ГАЙКА, I/P (ЧАСТЬ OF 1) (4.2 X 1.41) (TAPPING NUT) (3.430) [ПРИЖИМНАЯ ПЛАСТИНА ПАНЕЛИ КУЗОВА]
11515638 ГАЙКА, U-TYPE, M4.2X1.41X10.5.5X22, .65-3.8 PNL THK, 1050, ZF (ЧАСТЬ OF 1) [ГАЙКА М4.2]
11609800 ГАЙКА, PUSH-IN, M6X1, 18.3X21, 2-2.5 PNL, 14.9 SQ HOLE, 1050, 7111M (ЧАСТЬ OF 1)
11508277 ГАЙКА, HEX W/CON WA M6X1 THD, OD-19 PEOR 9 (ЧАСТЬ OF 1) [ГАЙКА М6]
11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (INST CARR BRKT) [БОЛТ М6]
teamcadillac.ru
11519388 БОЛТ, HX HD CON WA, M8X1.25X25, 20 THD, 24 OD, 8.8, GMW3359 (SILVER), M-POINT (INST CARR BRKT) [БОЛТ]
11516372 ГАЙКА, U-TYPE, M5X1, MULTI THD, 2.0-5.0 PNL THK, PZ (ЧАСТЬ OF 1) [ГАЙКА М4]
25642753 ГАЙКА, STRG COL (ЧАСТЬ OF 1) (M8X1.25 X 47.91) (O/A DOUBLE END STUD W/E7 TORX STEM & ROUND SHOULDER)
11514519 ГАЙКА, HEX W/23.75 OD CON WA, M8X1.25, 7.32THK, 9, PZOR (STRG COL SUPT BRKT) [ГАЙКА]
11516245 ГАЙКА, HEX W/CON AND SEALING WA, M8X1.25, 7.5THK, 24 O.D., 9, PEOR (STRG COL SUPT BRKT)
25757655 BRACKET, STRG COL SUPT
25606907 ГАЙКА, STRG COL (ЧАСТЬ OF 1) (M8X1.25, 7.1THK) (SQUARE) (SUPT BRKT NUT) (6.760)
25687278 BRACKET, INST CARR (CTR) (CTR)
11516149 ГАЙКА, U, 8X1.25, MULTI THD, .08'-4.0' THK PNL, PZ (I/P CARR) [ГАЙКА М8]
25719156 BRACKET, INST CARR (TO FOD)
(GM10-003) - 2004-2009 E ЦИЛИНДР ЗАМКА ДВЕРИ
teamcadillac.ru
20766969 CYLINDER KIT, FRT S/D LK (UNCODED) (INCLS 2-13)
(GM10-005) - 2004-2009 E ЦИЛИНДР ЗАМКА SET-I/P COMPARTMENT
25756081 CYLINDER, I/P COMPT DR LK (*KIT1)
25756088 CAP, I/P COMPT DR LK CYL (BLACK PLATING ON CAP) (*KIT1)
25756082 TUMBLER, I/P COMPT DR LK CYL (#5) (*KIT1) [ВЫКЛЮЧАТЕЛЬ]
25756083 TUMBLER, I/P COMPT DR LK CYL (#4) (*KIT1) [ВЫКЛЮЧАТЕЛЬ]
teamcadillac.ru
25756084 TUMBLER, I/P COMPT DR LK CYL (#3) (*KIT1) [ВЫКЛЮЧАТЕЛЬ]
25756085 TUMBLER, I/P COMPT DR LK CYL (#2) (*KIT1) [ВЫКЛЮЧАТЕЛЬ]
25756086 TUMBLER, I/P COMPT DR LK CYL (#1) (*KIT1) [ВЫКЛЮЧАТЕЛЬ]
25756080 ПРУЖИНА, I/P COMPT DR LK CYL TUMB (*KIT1) [ПРУЖИНА]
25756087 TUMBLER, I/P COMPT DR LK CYL ANTI-ROTATION RET (*KIT1) [ВЫКЛЮЧАТЕЛЬ]
11 - ЗАДНЕЕ СТЕКЛО - ДЕТАЛИ СИДЕНЬЯ - РЕГУЛЯТОР
(6E11-005) - 2004-2009 E ФОРТОЧКА
25771873 WINDOW, QTR (35% ПРОПУСКАНИЕ СВЕТА)
89025334 WINDOW, QTR (25% ПРОПУСКАНИЕ СВЕТА)
89025336 WINDOW, QTR (25% ПРОПУСКАНИЕ СВЕТА)
25771876 WINDOW, QTR (INCLS 3, 4) (35% ПРОПУСКАНИЕ СВЕТА)
89025332 WINDOW, QTR (INCLS 3, 4) (70% ПРОПУСКАНИЕ СВЕТА)
teamcadillac.ru
89025335 WINDOW, QTR (INCLS 3, 4) (25% ПРОПУСКАНИЕ СВЕТА)
89025337 WINDOW, QTR (INCLS 3, 4) (25% ПРОПУСКАНИЕ СВЕТА)
(6E11-006) - 2004-2009 EB РЕГУЛЯТОР ВОДИТЕЛЬСКОГО СИДЕНЬЯ (ИСКЛЮЧАЯЯ ПАМЯТЬ)
88995057 ADJUSTER, D/SEAT (INCLS 2-16) (INCLS RECL)
88992806 MOTOR, D/SEAT RECL ACTR (ЧАСТЬ OF 6) (INCLS 3, 4)
88992550 RECLINER KIT, D/SEAT (INCLS 3-5)
teamcadillac.ru
88992553 ACTUATOR, D/SEAT ADJR VERT (INCLS 8) (VERTICAL) (RR) (W/BLACK CONNECTOR)
88957638 CABLE, D/SEAT HORIZ ADJR (ЧАСТЬ OF 13) (LONG CABLE W/O MEMORY)
88995195 MOTOR, D/SEAT ADJR ACTR (INCLS 11, 12, 14, 16) (HORIZONTAL)
88995197 CABLE, D/SEAT HORIZ ADJR (ЧАСТЬ OF 13) (SHORT CABLE)
88992551 ACTUATOR, D/SEAT ADJR VERT (INCLS 8) (VERTICAL) (FRT) (W/GRAY CONNECTOR)
(6E11-007) - 2004-2009 E РЕГУЛЯТОР ВОДИТЕЛЬСКОГО СИДЕНЬЯ (С ПАМЯТЬЮ)
88995059 ADJUSTER, D/SEAT (INCLS 2-20) (INCLS RECL) [ПЕРЕХОДНИК В СБОРЕ]
88992561 RECLINER KIT, D/SEAT (INCLS 3-5)
88992556 МОДУЛЬ, D/SEAT CONT
teamcadillac.ru
88992554 SENSOR, D/SEAT FRT VERT ADJR CBL POSN (ЗАДНИЙ) (W/BLUE COVER) (11.556)
88992553 ACTUATOR, D/SEAT ADJR VERT (INCLS 9) (VERTICAL) (RR) (W/BLACK CONNECTOR)
88957636 CABLE, D/SEAT HORIZ ADJR (ЧАСТЬ OF 16) (LONG CABLE W/MEMORY)
88992555 MOTOR, D/SEAT ADJR ACTR (INCLS 13-15, 17, 20) (HORIZONTAL)
88992552 SENSOR, D/SEAT FRT VERT ADJR CBL POSN (FRONT) (W/BLACK COVER) (11.556)
88992551 ACTUATOR, D/SEAT ADJR VERT (INCLS 9) (VERTICAL) (FRT) (W/GRAY CONNECTOR)
(6E11-008) - 2004-2009 E РЕГУЛЯТОР ПАССАЖИРСКОГО СИДЕНЬЯ С ПРИВОДОМ
88995058 ADJUSTER, P/SEAT (INCLS 2-16) (PWR)
teamcadillac.ru
88992551 ACTUATOR, P/SEAT ADJR VERT (INCLS 6) (VERTICAL) (FRT) (W/GRAY CONNECTOR)
88995197 CABLE, P/SEAT HORIZ ADJR (ЧАСТЬ OF 8) (SHORT CABLE)
88995195 MOTOR, P/SEAT ADJR ACTR (INCLS 3, 7, 9, 10) (HORIZONTAL)
88957638 CABLE, P/SEAT HORIZ ADJR (ЧАСТЬ OF 8) (LONG CABLE W/O MEMORY)
88992553 ACTUATOR, P/SEAT ADJR VERT (INCLS 6) (VERTICAL) (RR) (W/BLACK CONNECTOR)
88992561 RECLINER KIT, P/SEAT (INCLS 14-16)
88992805 MOTOR, P/SEAT RECL ACTR (ЧАСТЬ OF 13) (INCLS 15, 16) (11.377)
(6E11-009) - 2004-2009 E РЕГУЛЯТОР ПАССАЖИРСКОГО СИДЕНЬЯ- МЕХАНИЧЕСКИЙ
88898408 ADJUSTER, P/SEAT (INCLS 2-4) (MAN)
teamcadillac.ru
88992559 RECLINER, P/SEAT (ЧАСТЬ OF 1) (MANUAL)
12 - МОЛДИНГИ - КУЗОВ - ЗАДНЯЯ ЧАСТЬ - КРЫША
(6E12-041) - 2004-2009 E ЛЮК TRIM-GLASS(CF5)
15212373 WINDOW, SUN RF (INCLS 19, 24, 25) (REFERENCE SERVICE BULLETIN 07-08-67-007, BEFORE ORDERING WDO ASM.)
teamcadillac.ru
15212371 WINDOW, RF VENT
25870708 SEAL, SUN RF WDO RR [УПЛОТНЕНИЕ ЛЮКА КРЫШИ]
25747526 БОЛТ, SUN RF WDO OPERG HDW ACC CVR [БОЛТ]
15212372 WINDOW, RF STA
21997574 WEATHERSTRIP, SUN RF PNL/WDO
25752741 SEAL, RF VENT WDO FRT
15140325 COVER, RF VENT RR TR [КОЖУХ ЛЮКА КРЫШИ]
25747526 БОЛТ, SUN RF TR CVR (12.810) [БОЛТ]
25752738 SEAL, SUN RF RR TR PNL FRT
25747543 SEAL, RF VENT WDO
25747542 SEAL, SUN RF & RF VENT WDO OPERG HDW ACC CVR
25748583 BRACKET, RF RR PNL
25748584 BRACKET, RF RR PNL
15294017 БОЛТ, RF VENT S/S TRK
25747526 БОЛТ, RF RR PNL [БОЛТ]
25747557 HINGE, RF VENT WDO
25747528 БОЛТ, RF VENT WDO HGE (M5-0.8 X 15LG) (W/ DOGPOINT) (12.810)
25752743 SEAL, SUN RF WDO (ЧАСТЬ OF 1)
25874773 COVER, SUN RF FRT TR [КОЖУХ ЛЮКА КРЫШИ]
21997575 SEAL, SUN RF WDO FRT [УПЛОТНИТЕЛЬ]
25874775 COVER, SUN RF FRT SI TR (WHEN REPLACING FRT APLQ MUST ALSO REPLACE RR APLQ #25843467)
25874776 COVER, SUN RF FRT SI TR (WHEN REPLACING FRT APLQ MUST ALSO REPLACE RR APLQ #25874774) [КОЖУХ ОБЛИЦОВКИ ЛЮКА ПАНОРАМНОЙ КРЫШИ]
25843467 COVER, RF VENT RR SI TR (WHEN REPLACING RR APLQ MUST ALSO REPLACE FRT APLQ #25874775)
25874774 COVER, RF VENT RR SI TR (WHEN REPLACING RR APLQ MUST ALSO REPLACE FRT APLQ #25874776)
89045564 CLIP, SUN RF WDO TRK RR EXTN (ЧАСТЬ OF 1)
25747529 БОЛТ, SUN RF PNL/WDO GDE (ЧАСТЬ OF 1)
(6E12-042) - 2004-2008 E ЛЮК TRIM-GLASS(C3B)
15212373 WINDOW, SUN RF (INCLS 14, 19, 20) (REFERENCE SERVICE BULLETIN 07-08-67-007, BEFORE ORDERING WDO ASM.)
teamcadillac.ru
(6E12-043) - 2004-2009 E СТЕКЛООЧИСТИТЕЛЬ-ЗАДНЕГО СТЕКЛА
88958155 PUMP, R/WDO WA (INCLS GROMMET) (ACDelco #88958155) [НАСОС СТЕКЛООМЫВАТЕЛЯ]
15218953 HOSE, WSWA SOLV CNTNR (RR) (ACDelco #15218953) [ШЛАНГ СТЕКЛООМЫВАТЕЛЯ]
25759097 COVER, R/WDO WA NOZ OPG [КОЛПАЧОК ДЕРЖАТЕЛЯ ЩЕТКИ СТЕКЛООЧИСТИТЕЛЯ]
15209058 ARM, R/WDO WPR [ДЕРЖАТЕЛЬ ЩЕТКИ СТЕКЛООЧИСТИТЕЛЯ]
12335716 WIPER, R/WDO (INSERT) [ЩЕТКА СТЕКЛООЧИСТИТЕЛЯ В СБОРЕ]
15209055 BLADE, R/WDO WPR (330MM) (WITHOUT ARM) [ЩЕТКА СТЕКЛООЧИСТИТЕЛЯ]
11589150 ГАЙКА, HEX, W/ADH, M8X1.25X6.80, 5, GMW3359 (R/WDO WPR ARM) [ГАЙКА]
25870667 HOSE, R/WDO WA NOZ (WITH CHECK VLV) [ШЛАНГ СТЕКЛООМЫВАТЕЛЯ]
15211652 HARNESS, L/GATE LK & R/WDO DEFG & R/WDO WPR WRG
teamcadillac.ru
15211653 HARNESS, L/GATE LK & R/WDO DEFG & R/WDO WPR WRG
25739991 GROMMET, R/WDO WPR MOT
25805170 MOTOR, R/WDO WPR (INCLS 14) (W/NOZZLE) (ACDelco #25805170) [ЭЛЕКТРОДВИГАТЕЛЬ СТЕКЛООЧИСТИТЕЛЯ 90 ВТ]
11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (R/WDO WPR MOT) [БОЛТ М6]
12335989 NOZZLE, R/WDO WA (ЧАСТЬ OF 12) [ДЕФЛЕКТОР ЗАДНЕГО ОКНА]
(6E12-044) - 2004-2006 E КУЗОВНЫЕ ДЕТАЛИ ЧАСТЬ 1-ДВИГАТЕЛЬНЫЙ ОТСЕК & DASH(M22,M82)
25696592 SUPPORT, PARK BRK FRT CBL
teamcadillac.ru
11518350 ГАЙКА, TRANS SUPT (ЧАСТЬ OF 13) (M10X1.5X24MM)
25723918 REINFORCEMENT, TRANS SUPT (INCLS 11, 12)
25723915 RAIL, TRANS MT SUPT FRT
25723914 RAIL, TRANS MT SUPT FRT
11518350 ГАЙКА, TRANS SUPT (ЧАСТЬ OF 19) (M10X1.5X24MM)
25723917 REINFORCEMENT, TRANS SUPT (INCLS 17, 18)
19153414 RAIL, F/CMPT FRT SI (ЧАСТЬ OF 43) (INCLS 23, 24, 36, 38-41)
11518595 NUT-HEX, M16X2, 24MM THK, 1008-1010 STL, PLAIN (ЧАСТЬ OF 43)
11518131 ГАЙКА, HEX M14X2.0X37.9, OD 50, SAE1010, PLAIN.TEFLON PER GM6076M. (ЧАСТЬ OF 43) (8.921)
25640395 ГАЙКА, ENG WRG HARN GND (ЧАСТЬ OF 28, 43) (COPPER) (9.647)
19209530 RAIL KIT, F/CMPT SI (INCLS 22-42)
89024837 RAIL KIT, F/CMPT SI (INCLS 22-42)
15903603 PANEL, FRT W/H (INCLS 44-49)
25783832 PANEL, FRT W/H (INCLS 44-49) [ПАНЕЛЬ КОЛЕСНОЙ АРКИ]
25711275 REINFORCEMENT, F/END UPR TIE BAR (INCLS 52)
25711276 REINFORCEMENT, F/END UPR TIE BAR (INCLS 52)
19153100 PANEL, BODY H/PLR INR (INCLS 54-59)
19153101 PANEL, BODY H/PLR INR (INCLS 54-59)
25640395 ГАЙКА, BODY WRG HARN GND (ЧАСТЬ OF 53) (COPPER) (9.647)
15211950 REINFORCEMENT, BODY H/PLR UPR (INCLS 60)
15211951 REINFORCEMENT, BODY H/PLR UPR (INCLS 60)
25772204 BRACE, F/END SH MET DIAG (MIDDLE SECTION OF THE BRACE ASM IS FLAT AND HAS A ЧАСТЬ NUMBER STAMPING OF 25772204) [ПЛАСТИНА]
15852778 BAR, F/END UPR TIE (INCLS 63) [ВЕРХНЯЯ ПОПЕРЕЧНАЯ ПАНЕЛЬ КУЗОВА]
25829789 RAIL, F/CMPT OTR SI UPR (*KIT1)
25829790 RAIL, F/CMPT OTR SI UPR (*KIT1)
11516071 ГАЙКА, M8X1.25, 7.1THK, 13.05 O.D., 10, ZC (КАПОТ OPEN ASST ROD LWR BRKT) (*KIT1)
11609978 STUD, КАПОТ OPEN ASST ROD (STUD-SPL W/FL WA, M6X1X16, 14 THD, 14 OD, W/8MM BALL SIDE B, 1018, GMW4700)) (M6X1X16) (W/8MM BALL SIDE B) (*KIT1) [ШПИЛЬКА]
25654985 STUD, КАПОТ OPEN ASST ROD (M8X12X30, W/8MM BALL) (LOWER) (*KIT1)
10384299 REINFORCEMENT, FRT W/H PNL RR BR
11609540 БОЛТ, HWASH, M6X1X20, 16.15 THD, 17 OD, 8.8, GMW4205, HDR PT. (FRT W/H PNL UPR RR BR) [ВИНТ]
15211905 RAIL, F/CMPT OTR SI UPR (INCLS 65-68) (USED ON VEHICLES WITH 1 КАПОТ STRUT) (FOR 1ST DES SEE 19168889) (INCLS BRKTS)
15211906 RAIL, F/CMPT OTR SI UPR (INCLS 65-68) (WHEN USED ON VEH WITH TWO КАПОТ STRUTS MAY ALSO REQUIRE 25654985 STUD AND 11516071 NUT) (INCLS BRKTS)
19168889 RAIL, F/CMPT OTR SI UPR (INCLS 65-68) (USED ON VEHICLES WITH 2 КАПОТ STRUTS) (FOR 2ND DES SEE 15211905) (MAY ALSO REQUIRE 25654985 STUD AND 11516071 NUT)
(6E12-046) - 2004-2009 E КУЗОВНЫЕ ДЕТАЛИ ЧАСТЬ 4-НИЖНЯЯ ЧАСТЬ & ЗАДНИЙ END
88956775 SILL, U/B RR CR (INCLS 1) (НИЖНЯЯ ЧАСТЬ)
15932358 REINFORCEMENT, BODY SI INR PNL
15932359 REINFORCEMENT, BODY SI INR PNL
25650571 BRACKET, JK STOW (7.629)
25731708 BRACKET, SPA WHL STOW
25759423 BRACKET, SPA WHL STOW (ANGLE BRKT)
89022238 PANEL, R/CMPT FLR (RR HALF ONLY, LESS RAILS)
15774787 BAR, FLR PNL #6 CR
25759312 EXTENSION, FLR PNL #6 C/BAR
25759313 EXTENSION, FLR PNL #6 C/BAR
15774787 BAR, FLR PNL #5
10394190 EXTENSION, FLR PNL #5 C/BAR
25664871 EXTENSION, R/CMPT FLR PNL RL (ЧАСТЬ OF 14) (FOR RH OR LH) [РАЗШИРИТЕЛЬ]
25752460 RAIL, R/CMPT FLR PNL (W/RR SUSP SUPT) (INCLS 12, 13)
25752461 RAIL, R/CMPT FLR PNL (W/RR SUSP SUPT) (INCLS 12, 13)
25737579 REINFORCEMENT, RR SUSP SUPT (FRONT) (INCLS 17) (ЧАСТЬ OF 18)
25741025 REINFORCEMENT, RR SUSP SUPT (FRONT) (INCLS 17) (ЧАСТЬ OF 18)
11519001 ГАЙКА, HEX M16X2.0X37.9, OD 50, SAE1010, PLAIN.TEFLON PER GM6076M (ЧАСТЬ OF 16, 18) (8.899)
19120704 RAIL KIT, R/CMPT FLR PNL (INCLS 15-17, 19) (RR)
88957626 RAIL, R/CMPT FLR PNL RR (INCLS 15-17, 19)
25773169 PANEL, RKR INR (INCLS 23, 24) [ПАНЕЛЬ]
25773170 PANEL, RKR INR (INCLS 23, 24)
teamcadillac.ru
25689604 BRACKET, PARK BRK CBL (218 X 83 X 59) (ATTACHES TO F/FLR PANEL)
25732502 BRACKET, CHILD ST RST SYS BELT
25640395 ГАЙКА, BODY WRG HARN GND (COPPER) (9.647)
25675853 BRACKET, F/TNK
25740361 REINFORCEMENT, FLR PNL #4 C/BAR (16.545)
11519387 БОЛТ, HWASH, M8X1.25X20, 14 THD, 24 OD, GMW25 (8.8)STEEL, GMW3359, M-POINT. (FLR PNL #4 C/BAR REINF) [БОЛТ]
(6E12-047) - 2004-2009 E АРМАТУРА ОТКРЫВАНИЯ (ПОДЪЕМА) ДВЕРИ ЧАСТЬ 1
teamcadillac.ru
15828682 GATE, LIFT (INCLS 20) (VEHICLES BUILT ON JAN 16, 2005 & PRIOR ORDER REINFORCEMENT 15141474 & LATCH 15243667) [ДВЕРЬ]
11517230 БОЛТ, TORX, W/WA, W/ADH, M6X1X20, 16.2 O.D., DOG PT, 10.9, GM6138M (L/GATE UPR SI APLQ) [ВИНТ ЗАМКА ДВЕРИ М6]
21110669 SEAL, L/GATE OTR PNL (35 MM) (ROUND)
15715312 RETAINER, L/GATE APLQ (PLUG) (16.125)
25769925 SEAL, L/GATE WDO (ЧАСТЬ OF 7) (INCLS PLASTIC FILLER)
25769926 SEAL, L/GATE WDO (ЧАСТЬ OF 7) (INCLS PLASTIC FILLER)
89023656 WINDOW, L/GATE (INCLS 6, 8) (TINTED) [СТЕКЛО БАГАЖНОЙ ДВЕРИ]
89023980 WINDOW, L/GATE (INCLS 6, 8) (TINTED) (W/POWER LIFT GATE)
89025180 WINDOW, L/GATE (INCLS 6, 8) (TINTED)
89025181 WINDOW, L/GATE (INCLS 6, 8) (CLEAR)
25739991 GROMMET, R/WDO WPR MOT (ЧАСТЬ OF 7)
12450108 BULB, TRADE #3157KX (ЧАСТЬ OF 19) (2.679) (ACDelco #3157KX) (LONGER LIFE KRYPTON) [ЛАМПОЧКА НАКАЛИВАНИЯ ФАРЫ 15 ВТ]
01999382 BULB, (ЧАСТЬ OF 19) (ACDelco #W5WLL) (LONGER LIFE)
25735605 BUMPER, RR LIC PLT PKT (ЧАСТЬ OF 19) (2.662)
11588650 CLIP, 12X14X16.6, GM4345M (ЧАСТЬ OF 19) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
10393803 HANDLE, L/GATE O/S PULL (GOLD)
15898424 HANDLE, L/GATE O/S PULL (BLACK)
25764676 HANDLE, L/GATE O/S PULL (SILVER)
25764677 HANDLE, L/GATE O/S PULL (BLUE)
25764680 HANDLE, L/GATE O/S PULL (GRAY)
25764681 HANDLE, L/GATE O/S PULL (GREEN)
25764682 HANDLE, L/GATE O/S PULL (WHITE)
25764683 HANDLE, L/GATE O/S PULL (RED)
25764684 HANDLE, L/GATE O/S PULL (SILVER)
25764924 WEATHERSTRIP, L/GATE (LICENSE PLATE APPLIQUE)
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (B/U & RR LIC PLT LP) [ГАЙКА М6]
15872898 STRUT, L/GATE [СТОЙКА ЗАДНЕЙ ОТКИДНОЙ ДВЕРИ]
15872899 STRUT, L/GATE [СТОЙКА ЗАДНЕЙ ОТКИДНОЙ ДВЕРИ]
25715007 STRIKER, L/GATE LAT (*KIT1)
11561656 SCREW, RND WA, M6X1X28, 23 THD, 16.38 OD, 10.9, GMW4205, ADH 6175M, TORX (ЧАСТЬ OF 31)
11519300 SCR, RNDWA W/SHLDR, M6X1X18, 10.5 THD, 16.36OD, 10.9, 6138M, TORX, MACH, 6175M (L/GATE WGE (BODY SI))
25740010 WEDGE, L/GATE (BODY SI) (INCLS 28, 30) (W/BRACKET, SEAL, NUT & БОЛТ)
11517792 ГАЙКА, HEX W/FL WA, M8X1.25, 10.75 THK, 24 OD, 10, 7111M (L/GATE HGE (BODY SI))
10371150 WEATHERSTRIP, L/GATE (BODY SI) [УПЛОТНЕНИЕ КУЗОВА]
11609990 STUD, L/GATE STRUT (L/GATE SI) (M8X1.25X20) (8.015) [ШПИЛЬКА М8]
25771255 GASKET, L/GATE BODY SI HGE
25771254 GASKET, L/GATE HGE (BODY SI)
11588310 БОЛТ, L/GATE HGE (L/GATE SI) (15.222)
25771996 HINGE, L/GATE (L/GATE SI)
25771997 HINGE, L/GATE (L/GATE SI)
25761411 WASHER, L/GATE HGE (L/GATE SI)
10349640 WEATHERSTRIP, L/GATE WDO (L=25XW=25XH=2) (SMALL)
25715007 STRIKER, L/GATE LAT (INCLS 27)
(6E12-048) - 2004-2009 E КУЗОВНЫЕ ДЕТАЛИ ЧАСТЬ 3-ДВЕРИ & КРЫША
25716955 PANEL, RF
25867281 PANEL, RF RR HDR
25717498 BOW, RF PNL INR
25730784 BOW, RF PNL INR
25773945 PANEL, RF FRT HDR
89025815 DOOR, FRT SI (INCLS 7, 12) (INCLS PANEL, PLATE, REINFORCEMENT) (DOES NOT REQUIRE LOWER AUXILLIARY WEATHERSTRIP) [ПЕРЕДНЯЯ ДВЕРЬ]
89025816 DOOR, FRT SI (INCLS 7, 12) (INCLS PANEL, PLATE, REINFORCEMENT) (DOES NOT REQUIRE LOWER AUXILLIARY WEATHERSTRIP)
teamcadillac.ru
25701880 PLATE, FRT S/D HGE ANC (DR SI) (ЧАСТЬ OF 6)
11610041 БОЛТ, HFH W/SHLDR, M8X1.25X25, 12.55 THD, 21 OD, 10.9 (FRT S/D LWR HGE (DR SI)) [БОЛТ]
89025813 PANEL, FRT S/D OTR (ЧАСТЬ OF 6)
89025814 PANEL, FRT S/D OTR (ЧАСТЬ OF 6)
89025811 PANEL, RR S/D OTR (ЧАСТЬ OF 19) (INCLS PANEL, FILLER, REINFORCEMENT)
89025812 PANEL, RR S/D OTR (ЧАСТЬ OF 19) (INCLS PANEL, FILLER, REINFORCEMENT)
25701880 PLATE, RR S/D HGE ANC (DR SI) (ЧАСТЬ OF 19) (10.450)
11610041 БОЛТ, HFH W/SHLDR, M8X1.25X25, 12.55 THD, 21 OD, 10.9 (RR S/D UPR HGE (DR SI)) [БОЛТ]
89025817 DOOR, RR SI (INCLS 13, 14) (INCLS PANEL, PLATE, REINFORCEMENT) (DOES NOT REQUIRE LOWER AUXILLIARY WEATHERSTRIP) [ПАНЕЛЬ ДВЕРИ]
89025818 DOOR, RR SI (INCLS 13, 14) (INCLS PANEL, PLATE, REINFORCEMENT) (DOES NOT REQUIRE LOWER AUXILLIARY WEATHERSTRIP) [ЗАДНЯЯ ДВЕРЬ]
(6E12-049) - 2004-2006 E КУЗОВНЫЕ ДЕТАЛИ ЧАСТЬ 1-ДВИГАТЕЛЬНЫЙ ОТСЕК & DASH(MV3,MX5)
25719541 REINFORCEMENT, TRANS SUPT (INCLS 11, 12)
25715343 RAIL, TRANS MT SUPT FRT
25715342 RAIL, TRANS MT SUPT FRT
25710948 REINFORCEMENT, TRANS SUPT (INCLS 17, 18)
25718784 EXTENSION, TRANS MT SUPT FRT RAIL (4.083)
teamcadillac.ru
11609978 STUD, КАПОТ OPEN ASST ROD (STUD-SPL W/FL WA, M6X1X16, 14 THD, 14 OD, W/8MM BALL SIDE B, 1018, GMW4700) (M6X1X16) (W/8MM BALL SIDE B) (*KIT1) [ШПИЛЬКА]
(6E12-050) - 2004-2009 E LUGGAGE КРОНШТЕЙН
11588878 CLIP, 50X9X8, STL, GM6173M (LUGG CAR S/RL (PUSH-IN)) [КЛИПСА]
19168626 MOLDING, LUGG CARR RR (КРАСКА TO MATCH) (EXCS PVC TRIM)
19168627 MOLDING, LUGG CARR RR (W/O PVC TRIM) [РЕЙЛИНГ КРЫШИ КУЗОВА]
25803927 COVER, LUGG CARR S/RL ACC HOLE FRT [КОЖУХ ОПОРЫ РЕЙЛИНГА КРЫШИ]
25803928 COVER, LUGG CARR S/RL ACC HOLE FRT [КОЖУХ ОСНОВАНИЯ РЕЙЛИНГА КРЫШИ]
11609378 NUT - M8X1.25, 14 OD, 10 ID, 23 DEPTH, 10 STEEL, GMW4205, GM6175M (LUGG CARR) [ГАЙКА М8]
19177190 RAIL, LUGG CARR SI (INCLS 5, 8) (BLACK)
19177191 RAIL, LUGG CARR SI (INCLS 5, 8) (BLACK)
19177192 RAIL, LUGG CARR SI (INCLS 5, 8) (CHROME WITH BLACK TRIM)
19177193 RAIL, LUGG CARR SI (INCLS 5, 8) (CHROME) (WITH BLACK TRIM)
15141688 COVER, LUGG CARR S/RL ACC HOLE RR (BLACK) (W/ LOCKING TAB) (IF USING TO SERVICE 6 E EA 00 VEHICLES BUILD PRIOR TO 10/16/03, MUST REPLACE T/W RAIL ASM LUGG CARR SIDE) [КРЫШКА]
15141689 COVER, LUGG CARR S/RL ACC HOLE RR (BLACK) (IF USING TO SERVICE 6 E EA 00 VECHILES BUILT PRIOR TO 10/16/03, MUST REPL T/W RAIL ASM CARR SIDE) [НАКЛАДКА БАГАЖНОГО ОТДЕЛЕНИЯ]
teamcadillac.ru
(6E12-052) - 2004-2009 E МОЛДИНГИ-ABOVE BELT
teamcadillac.ru
11509428 БОЛТ/SCREW, HEX, W/FLAT WA, M4.2X1.4X13, 12.3 O.D., BHL PT, 6010M, NO (FRT S/D WDO OTR S/STR) (8.977)
25768297 APPLIQUE, FRT S/D WDO FRM RR (INCLS 17) (SMOOTH FINISH) (CUSTOMER MAY BE REQUIRED TO REPLACE ALL APPLIQUE TO MATCH) [МОЛДИНГ КУЗОВА]
25768298 APPLIQUE, FRT S/D WDO FRM RR (INCLS 17) (SMOOTH FINISH) (CUSTOMER MAY BE REQUIRED TO REPLACE ALL APPLIQUE TO MATCH) [ПАНЕЛЬ ДВЕРИ]
25768299 APPLIQUE, RR S/D WDO FRM FRT (INCLS 16) (SMOOTH FINISH) (CUSTOMER MAY BE REQUIRED TO REPLACE ALL APPLIQUE TO MATCH) [НАКЛАДКА ДВЕРИ]
25768300 APPLIQUE, RR S/D WDO FRM FRT (INCLS 16) (SMOOTH FINISH) (CUSTOMER MAY BE REQUIRED TO REPLACE ALL APPLIQUE TO MATCH) [НАКЛАДКА ДВЕРИ]
11570654 ГАЙКА, RR S/D WDO FRM FRT APLQ (ЧАСТЬ OF 13) (4.2 X 1.41) (FITS 8.75 SQ HOLE) (9.665)
(6E12-053) - 2004-2005 E АРМАТУРА ОТКРЫВАНИЯ (ПОДЪЕМА) ДВЕРИ ЧАСТЬ 2
25771684 GROMMET, L/GATE WRG HARN (2.480)
15828682 GATE, LIFT (VEHICLES BUILT ON JAN 16, 2005 & PRIOR ORDER REINFORCEMENT 15141474 & LATCH 15243667) [ДВЕРЬ]
teamcadillac.ru
19235277 STRUT, L/GATE (ACDelco #510-1067) (ALL MAKES)
25766856 WEDGE, L/GATE (L/GATE SI)
11518446 SCREW-RD WA HD, M6X1X19, 16.38 OD, 12 THD, 10.9, 6138M. (L/GATE WGE (L/GATE SI))
25732248 PLUG, L/GATE INR PNL DRN HOLE
11518446 SCREW-RD WA HD, M6X1X19, 16.38 OD, 12 THD, 10.9, 6138M. (L/GATE LAT)
11518162 NUT-PANEL, M4.2X1.41, 15.9X8.4, .7-1.0 PNL, 1050, 7111M, 8.65 SQ HOLE (L/GATE OTR PNL)
25759086 DEADENER, R/CMPT PNL
25805170 MOTOR, R/WDO WPR (W/NOZZLE) (ACDelco #25805170) [ЭЛЕКТРОДВИГАТЕЛЬ СТЕКЛООЧИСТИТЕЛЯ 90 ВТ]
15243667 LATCH, L/GATE (INCLS 14) (INCLS ACTUATOR) (ON VEHS BUILT ON 1/16/05 & PRIOR, USE REINFORCEMENT 15141474 WITH THIS LATCH) [ФИКСАТОР]
15243666 CABLE, L/GATE O/S HDL (ЧАСТЬ OF 13)
25771685 GROMMET, L/GATE WRG HARN (2.480)
(6E12-054) - 2004-2009 E ЛЮК MECHANICAL(CF5)
25747606 NIPPLE, SUN RF W/RF VENT WDO DRN HOSE (INCLS 2, 3)
25870709 HOSE, SUN RF HSG RR DRN
21997807 LACE, SUN RF OPG TR FIN (NEUTRAL) (*KIT1)
21997808 LACE, SUN RF OPG TR FIN (GRAY) (*KIT1)
25747528 БОЛТ, S/S (M5-0.8 X 15LG) (W/ DOGPOINT) (*KIT1) (12.810)
25747527 БОЛТ, S/S (M5-0.8 X 36.5LG) (*KIT1)
10356110 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, SUN RF FRT (NEUTRAL) (*KIT1)
10356112 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, SUN RF FRT (GRAY) (*KIT1)
25747526 БОЛТ, SUN RF DRV & RTN CBL TUBE RET (*KIT1) [БОЛТ]
25748524 RETAINER, SUN RF & S/S DRV TUBE (*KIT1)
25748525 RETAINER, SUN RF & S/S DRV TUBE (*KIT1)
10356107 TRACK, SUN RF WDO FRT (*KIT1)
10356108 TRACK, SUN RF WDO FRT (*KIT1)
15144063 LINK, SUN RF S/S CBL (*KIT1)
15240746 GUIDE, SUN RF PNL/WDO FRT (INCLS 19) (INCLS ПРОВОДА) (*KIT1)
15240747 GUIDE, SUN RF PNL/WDO FRT (INCLS 19) (INCLS ПРОВОДА) (*KIT1)
25747529 БОЛТ, SUN RF PNL/WDO GDE (*KIT1)
25747528 БОЛТ, SUN RF WDO TRK (M5-0.8 X 15LG) (W/ DOGPOINT) (*KIT1)
25747577 EXTENSION, SUN RF WDO TRK FRT (*KIT1)
25747578 EXTENSION, SUN RF WDO TRK FRT (*KIT1)
25979460 CAP, SUN RF PNL/WDO GDE (ЧАСТЬ OF 14) [КОЖУХ НАПРАВЛЯЮЩЕЙ СОЛНЦЕЗАЩИТНОГО ЭКРАНА ЛЮКА КРЫШИ]
25747530 БОЛТ, SUN RF S/S CBL LINK (*KIT1)
25747587 CABLE, SUN RF S/S (*KIT1)
25755910 DEFLECTOR, SUN RF AIR (BLACK) (*KIT1)
25747528 БОЛТ, SUN RF A/DFL (M5-0.8 X 15LG) (W/ DOGPOINT) (*KIT1)
25754873 HARNESS, SUN RF WRG (*KIT1)
teamcadillac.ru
25747592 GUIDE, SUN RF PNL/WDO RR [НАПРАВЛЯЮЩАЯ ЛЮКА КРЫШИ]
25747593 GUIDE, SUN RF PNL/WDO RR [НАПРАВЛЯЮЩАЯ ЛЮКА КРЫШИ]
21997587 EXTENSION, SUN RF WDO TRK RR (*KIT1)
21997588 EXTENSION, SUN RF WDO TRK RR (*KIT1)
25752742 WEATHERSTRIP, RF RR PNL (*KIT1) [УПЛОТНИТЕЛЬ КУЗОВА]
25747581 TRACK, SUN RF WDO RR (*KIT1)
25747582 TRACK, SUN RF WDO RR (*KIT1)
15932104 MOTOR, SUN RF WDO (W/CONT MDL) (*KIT1) [ЭЛЕКТРОДВИГАТЕЛЬ ЛЮКА КРЫШИ 200 ВТ]
25747527 БОЛТ, SUN RF & RF VENT WDO MOT/BLOCK (M5-0.8 X 36.5LG) (10.219)
25747548 MOTOR, SUN RF FRT S/S (W/CONT MDL)
25747533 RETAINER, SUN RF & RF VENT WDO & S/S DRV & RTN CBL TUBE (*KIT1)
25747573 TUBE, SUN RF WDO CBL DRV (*KIT1)
25747565 TUBE, SUN RF WDO CBL RTN (*KIT1)
25747571 TUBE, SUN RF S/S CBL DRV (*KIT1)
25747563 TUBE, SUN RF S/S CBL RTN (*KIT1)
25747558 BLOCK, SUN RF & RF VENT WDO MOT CONT MDL W/DRV & RTN CBL TUBE (*KIT1) [БЛОК УПРАВЛЕНИЯ ЛЮКА КРЫШИ]
25747572 TUBE, SUN RF S/S CBL DRV (*KIT1)
25747564 TUBE, SUN RF S/S CBL RTN (*KIT1)
25747574 TUBE, SUN RF WDO CBL DRV (*KIT1)
25747566 TUBE, SUN RF WDO CBL RTN
25843462 МОДУЛЬ, SUN RF (INCLS 1, 6-15, 17, 18, 20-24, 26-29, 32-40) (GRAY)
25843463 МОДУЛЬ, SUN RF (INCLS 1, 6-15, 17, 18, 20-24, 26-29, 32-40) (CASHMERE)
(6E12-055) - 2004-2005 E ЛЮК MECHANICAL(C3B)
25747588 CAM, RF VENT WDO LIFT ARM
25747589 CAM, RF VENT WDO LIFT ARM
25747590 ARM, RF VENT WDO LNKG
25747591 ARM, RF VENT WDO LNKG
25747526 БОЛТ, RF VENT WDO (12.810) [БОЛТ]
10366583 LINK, RF VENT S/S CBL
teamcadillac.ru
25747585 CABLE, RF VENT S/S
15140326 TRACK, RF VENT S/S
15140327 TRACK, RF VENT S/S
25747526 БОЛТ, SUN RF DRV & RTN CBL TUBE RET [БОЛТ]
25747559 RETAINER, RF VENT & S/S DRV TUBE
25747560 RETAINER, RF VENT & S/S DRV TUBE
25747528 БОЛТ, S/S (M5-0.8 X 15LG) (W/ DOGPOINT) (12.810)
25747551 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, SUN RF RR (GRAY)
25747552 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, SUN RF RR (NEUTRAL)
15294671 LACE, RF VENT WDO OPG TR FIN (CASHMERE)
15240746 GUIDE, SUN RF PNL/WDO FRT (INCLS 29) (INCLS ПРОВОДА)
15240747 GUIDE, SUN RF PNL/WDO FRT (INCLS 29) (INCLS ПРОВОДА)
25754874 HARNESS, SUN RF WRG
25752742 WEATHERSTRIP, RF RR PNL [УПЛОТНИТЕЛЬ КУЗОВА]
15932104 MOTOR, SUN RF WDO (W/CONT MDL) [ЭЛЕКТРОДВИГАТЕЛЬ ЛЮКА КРЫШИ 200 ВТ]
25747558 BLOCK, SUN RF & RF VENT WDO MOT CONT MDL W/DRV & RTN CBL TUBE [БЛОК УПРАВЛЕНИЯ ЛЮКА КРЫШИ]
15140328 MOTOR, SUN RF RR S/S (W/CONT MDL)
25747561 TUBE, RF VENT S/S CBL RTN
25747567 TUBE, RF VENT S/S CBL DRV
25747569 TUBE, RF VENT WDO CBL DRV
25771957 TUBE, RF VENT WDO CBL RTN
25747545 MOTOR, RF VENT WDO (W/CONT MDL)
25747562 TUBE, RF VENT WDO CBL RTN
25747570 TUBE, RF VENT WDO CBL DRV
25747568 TUBE, RF VENT S/S CBL DRV
(6E12-056) - 2005 E МОЛДИНГИ-BELOW BELT
88980893 MOLDING, FRT S/D LWR (INCLS 2) (КРАСКА TO MATCH)
88980895 MOLDING, FRT S/D LWR (INCLS 2) (КРАСКА TO MATCH) [МОЛДИНГ]
25724529 RETAINER, FRT S/D LWR MLDG (ЧАСТЬ OF 1) (NATURAL) (20.0MM X 13.0MM) (EXCLUDES SEAL) (8.309) [ФИКСАТОР МОЛДИНГА ДВЕРИ]
25648693 RETAINER, RKR PNL MLDG LWR (ЧАСТЬ OF 5, 6) (GRAY) [ФИКСАТОР МОЛДИНГА ДВЕРИ]
11561820 CLIP, RKR PNL MLDG (ЧАСТЬ OF 5, 6) (51MM X 22.5MM)
25724529 CLIP, RKR PNL MLDG (ЧАСТЬ OF 5, 6) (NATURAL) (20.0MM X 13.0MM) (EXCLUDES SEAL) (2LH/2RH) [ФИКСАТОР МОЛДИНГА ДВЕРИ]
88980898 MOLDING, RKR PNL FRT (INCLS 3, 4) (PRIMED) (КРАСКА TO MATCH)
88980899 MOLDING, RKR PNL FRT (INCLS 3, 4) (PRIMED) (КРАСКА TO MATCH)
88980742 MOLDING, RKR PNL (INCLS 3, 4) (КРАСКА TO MATCH) [ПАНЕЛЬ ПОРОГА КУЗОВА]
88980743 MOLDING, RKR PNL (INCLS 3, 4) (КРАСКА TO MATCH) [МОЛДИНГ]
88980507 MOLDING, RKR PNL RR (PRIMED) (КРАСКА TO MATCH) [МОЛДИНГ]
88980508 MOLDING, RKR PNL RR (PRIMED) (КРАСКА TO MATCH) [МОЛДИНГ]
11518017 RETAINER, 25 LG, 20.5 OD, 8.0 HOLE, 6.2-8.2 PNL, NYLON, 6/6, BLK (RR W/H PNL LNR) [ПИСТОН КРЕПЛЕНИЯ КОЖУХА РАДИАТОРА]
11589015 БОЛТ, HWH W/FL WA M4.2X1.41X20, 12.5 O.D., DOG PT, 6010M, 7253M (RR W/H PNL LNR) [ВИНТ М4]
11515638 ГАЙКА, U-TYPE, M4.2X1.41X10.5.5X22, .65-3.8 PNL THK, 1050, ZF (RKR PNL RR MLDG) [ГАЙКА М4.2]
88980488 MOLDING, RR S/D LWR (INCLS 12) (КРАСКА TO MATCH) [МОЛДИНГ ДВЕРИ]
88980489 MOLDING, RR S/D LWR (INCLS 12) (КРАСКА TO MATCH) [МОЛДИНГ]
teamcadillac.ru
25724529 RETAINER, RR S/D LWR MLDG (ЧАСТЬ OF 11) (NATURAL) (20.0MM X 13.0MM) (EXCLUDES SEAL) (8.309) [ФИКСАТОР МОЛДИНГА ДВЕРИ]
10387855 EMBLEM, L/GATE (CHROME) (CADILLAC) (FOR EXPORT ONLY) [ЭМБЛЕМА CADILLAC]
10363600 PLATE, L/GATE NA (CHROME) ("SRX") [ЭМБЛЕМА SRX]
10334040 PLATE, L/GATE NA (V-8 NORTHSTAR) [ЭМБЛЕМА V8 NORTHSTAR]
25761283 EMBLEM, L/GATE (CHROME) (CREST) [ЭМБЛЕМА CADILLAC]
25761282 EMBLEM, L/GATE (CHROME) (WREATH) [ЭМБЛЕМА ЗАДНЕЙ ОТКИДНОЙ ДВЕРИ]
(6E12-060) - 2004-2009 E КЛАПАН РЕЦИРКУЛЯЦИИ КАБИНЫ
teamcadillac.ru
22702778 VALVE, QTR OTR PNL PRESS RLF (FRONT OF "D" RING) [КЛАПАН]
(6E12-062) - 2005-2007 E КУЗОВНЫЕ ДЕТАЛИ ЧАСТЬ 2-БОКОВЫЕ ЧАСТИ
19120680 РАМА, BODY SI OTR (INCLS 7, 47) [БОКОВАЯ ПАНЕЛЬ КУЗОВА]
19120681 РАМА, BODY SI OTR (INCLS 7, 47) [РАМА]
88957272 REINFORCEMENT, C/PLR OTR PNL (INCLS 3-5)
88957273 REINFORCEMENT, C/PLR OTR PNL (INCLS 3-5)
19120962 REINFORCEMENT, FRT S/D OPG FRM LWR (INCLS 8, 44)
19120963 REINFORCEMENT, FRT S/D OPG FRM LWR (INCLS 8, 44)
88956334 REINFORCEMENT, RF S/RL RR
88956335 REINFORCEMENT, RF S/RL RR
11588628 RETAINER-PLASTIC TREE, DIA 5.7X12.2, OD 18.6, FITS 4.75, 0.76-6.5 THK PNL (ЧАСТЬ OF 36)
25760114 FILLER, QTR OTR PNL (INCLS 13) (UPPER ЗАДНИЙ)
25767855 FILLER, QTR OTR PNL (INCLS 13) (UPPER ЗАДНИЙ)
25763389 FILLER, BODY SI INR FRM (TO QTR OTR PNL FIL)
25763390 FILLER, BODY SI INR FRM (TO QTR OTR PNL FIL)
89023928 FILLER, QTR OTR PNL (TO R/END PNL) (INCLS 15, 16, 58)
89023929 FILLER, QTR OTR PNL (TO R/END PNL) (INCLS 15, 16, 58) [ПАНЕЛЬ ЗАДНЕЙ ЧЕТВЕРТИ КУЗОВА]
25875792 PANEL, RR W/H INR (INCLS 19-21, 23-27, 43)
25875793 PANEL, RR W/H INR (INCLS 19-21, 23-27, 43)
10169777 RETAINER, RR W/H INR PNL DDN (ЧАСТЬ OF 22) (BLACK) (8.0 X 5.5) (10.695)
25716508 BRACKET, RR BPR FASCIA (ЧАСТЬ OF LH/RH RR W/H INR PNL) (ЧАСТЬ OF 22)
11518754 NUT-SPL, M12X1.75, 84.3MM PLATE, STL, 6076M (ЧАСТЬ OF 29)
10376000 REINFORCEMENT, QTR INR PNL UPR (INCLS 28, 30)
10376001 REINFORCEMENT, QTR INR PNL UPR (INCLS 28, 30)
25640395 ГАЙКА, INFL RST RF S/RL MDL (ЧАСТЬ OF 29) (COPPER) (9.647)
25724266 SHIELD, F/TNK FIL PIPE (INCLS 36)
25769106 FILLER, R/CMPT FLR PNL (TO QTR OTR PNL) (INCLS 33) (BOOTLEG POCKET)
25769107 FILLER, R/CMPT FLR PNL (TO QTR OTR PNL) (INCLS 33) (BOOTLEG POCKET)
25768058 PANEL, C/PLR INR LWR
25768059 PANEL, C/PLR INR LWR
88987546 РАМА, BODY SI INR (INCLS 10-12, 31, 35, 39-42, 53)
89023930 РАМА, BODY SI INR (INCLS 10-12, 31, 35, 39-42, 53)
88957270 REINFORCEMENT, RF FRT HDR PNL
88957271 REINFORCEMENT, RF FRT HDR PNL
25764024 RAIL, RF INR SI
25764025 RAIL, RF INR SI
25748226 REINFORCEMENT, C/PLR INR PNL UPR (ЧАСТЬ OF 36)
25748227 REINFORCEMENT, C/PLR INR PNL UPR (ЧАСТЬ OF 36)
10169777 RETAINER, RR W/H INR PNL DDN (ЧАСТЬ OF 36, 53) (BLACK) (8.0 X 5.5) (10.695)
25737260 BRACE, QTR INR & RR W/H PNL (USE WITH AFTERMARKET EXPANDABLE FOAM)
25965070 BRACE, QTR INR & RR W/H PNL
25724779 BRACKET, F/FDR RR CTR (ЧАСТЬ OF 1) [КРОНШТЕЙН]
15844817 RETAINER, FRT & RR S/D UPR AUX W/STR (INCLS 48)
25756581 RETAINER, FRT & RR S/D UPR AUX W/STR (INCLS 48)
15775325 DOOR, F/TNK FIL (INCLS 51, 52)
89047657 BUMPER, F/TNK FIL DR (ЧАСТЬ OF 50) (HINGE) [ВТУЛКА]
25911844 DEADENER, RR W/H PNL (ЧАСТЬ OF 36) (INCLS 40-42) (12.944)
teamcadillac.ru
11515174 INSULATOR, BODY SI INR PNL (4 1/4" X 7 1/2") (TRIM AS REQ'D)
15141472 REINFORCEMENT, BODY SI INR PNL (INCLS 60)
11589181 RETAINER, PUSHIN, FITS 6.24 HOLE IN 0.8-10 THK PNL, NYLON, BLACK (ЧАСТЬ OF 59) [ФИКСАТОР ПОДКРЫЛКА]
(6E12-064) - 2004-2008 E ВОДОСТОК КРЫШИ (CF5,C3B)
25870709 HOSE, SUN RF HSG RR DRN (INCLS 2)
25877191 GROMMET, SUN RF HSG RR DRN HOSE (ЧАСТЬ OF 1)
13 - ПРОВОДКА - ПОТОЛОК
(6E13-003) - 2004-2009 E ЖГУТЫ ПРОВОДОВ/КУЗОВ
15267203 HARNESS, BODY WRG (INCLS 2, 4, 6, 8, 14)
15267214 HARNESS, BODY WRG (INCLS 2, 4, 6, 8, 14)
19115865 HARNESS, BODY WRG (INCLS 2, 4, 6, 8, 14)
19115866 HARNESS, BODY WRG (INCLS 2, 4, 6, 8, 14)
19115867 HARNESS, BODY WRG (INCLS 2, 4, 6, 8, 14)
19115868 HARNESS, BODY WRG (INCLS 2, 4, 6, 8, 14)
19115869 HARNESS, BODY WRG (INCLS 2, 4, 6, 8, 14)
19115870 HARNESS, BODY WRG (INCLS 2, 4, 6, 8, 14)
19115871 HARNESS, BODY WRG (INCLS 2, 4, 6, 8, 14)
19115872 HARNESS, BODY WRG (INCLS 2, 4, 6, 8, 14)
19115873 HARNESS, BODY WRG (INCLS 2, 4, 6, 8, 14)
19115874 HARNESS, BODY WRG (INCLS 2, 4, 6, 8, 14)
19115875 HARNESS, BODY WRG (INCLS 2, 4, 6, 8, 14)
teamcadillac.ru
19115876 HARNESS, BODY WRG (INCLS 2, 4, 6, 8, 14)
19115877 HARNESS, BODY WRG (INCLS 2, 4, 6, 8, 14)
19115878 HARNESS, BODY WRG (INCLS 2, 4, 6, 8, 14)
89047599 HARNESS, BODY WRG (INCLS 2, 4, 6, 8, 14)
89047600 HARNESS, BODY WRG (INCLS 2, 4, 6, 8, 14)
89047601 HARNESS, BODY WRG (INCLS 2, 4, 6, 8, 14)
89047602 HARNESS, BODY WRG (INCLS 2, 4, 6, 8, 14)
25735406 CABLE, TV ANT AMPF COAX (ЧАСТЬ OF 1) (RR) (2 ПРОВОДА, 2570MM & 3525MM LONG) (ACDelco #25735406)
25735405 CABLE, TV ANT AMPF COAX (ЧАСТЬ OF 1) (FRT) (2 ПРОВОДА, 5715MM & 7410MM LONG) (ACDelco #25735405)
25723801 CABLE, RDO ANT (ЧАСТЬ OF 1) (4070MM LONG) (FROM RADIO TO HEADLINER) (ACDelco #25723801)
14 - ВНУТРЕННЯЯ ОТДЕЛКА - ПЕРЕДНИЕ СИДЕНЬЯ - РЕМНИ БЕЗОПАСНОСТИ
(6E10-027) - 2004-2008 E КРЫША HEADLINER (ИСКЛЮЧАЯ ЛЮК CF5,C3B)
19121463 RETAINER, RF CNSL (PUSH IN) (SUPT BK PLATE FOR VEHICLES WITH & WITHOUT INTRUSION) (FRT CNSL SUPT) (SUPT BK PLT FOR VEHS W/ & W/O INTRUSION)
88952102 RETAINER, ASST HDL BRKT (257X56X31)
25725191 CLIP, HDLNG T/PNL (ЧАСТЬ OF 28) (GREEN) (18X12.5, SAE 1050STL) (CLIP TO HOLD M4.2X1.41 SCREW, PNL RING 0.94-3.5) [ФИКСАТОР ПАНЕЛИ КРЫШИ КУЗОВА]
88952116 BRACKET, ASST HDL (HDLNR SUPT BRKT ASST HNDL)
88956192 RETAINER, RF CNSL (PUSH IN) (MIDDLE CNSL SUPPORT)
88956208 SUPPORT, L/GATE TR
89022467 SUPPORT, L/GATE TR
88956207 RETAINER, RF CNSL (PUSH IN) (SUPPORT TRIM BEZEL)
89026135 PANEL, HDLNG TR (INCLS 1, 35) (GRAY)
89026136 PANEL, HDLNG TR (INCLS 1, 35) (NEUTRAL)
89026139 PANEL, HDLNG TR (INCLS 1, 35) (NEUTRAL)
89026250 PANEL, HDLNG TR (INCLS 1, 35) (GRAY)
89026251 PANEL, HDLNG TR (INCLS 1, 35) (NEUTRAL)
89026722 PANEL, HDLNG TR (INCLS 1, 35) (GRAY)
22612024 CLIP, COAT HOOK (ЧАСТЬ OF 13) (55MM LONG) (PUSH-IN) (15.394) [КРОНШТЕЙН]
19115770 МОДУЛЬ, RDO ANT (ACDelco #19115770)
19115773 RECEIVER, R/CON DR LK & THEFT DTRNT (9.645) (ACDelco #19115773)
25757629 МОДУЛЬ, RDO ANT (ACDelco #25757629) [МОДУЛЬ]
25757631 МОДУЛЬ, RDO ANT (ACDelco #25757631)
25773482 МОДУЛЬ, RDO ANT (ACDelco #25773482)
89047510 RECEIVER, R/CON DR LK & THEFT DTRNT (10.485)
88956198 HOOK, COAT (INCLS 11, 14) (GRAY)
88956199 HOOK, COAT (INCLS 11, 14) (NEUTRAL)
11516633 SCREW, ROUND LARGE CROWN HD 4.2X1.4X35 11.3OD C/R TAP 6136M P-PT. (ЧАСТЬ OF 11)
88956201 BEZEL, RF CARGO NET (GRAY) (POA HDLNG TR MOD)
88956202 BEZEL, RF CARGO NET (NEUTRAL)
88956204 BEZEL, RF CARGO NET (GRAY) (POA HDLNG TR MOD)
88956205 BEZEL, RF CARGO NET (NEUTRAL)
11609257 БОЛТ, PAN HD, TORX, M12X1.75X34, 9.8 STEEL, GMW3179 (CARGO TIE DN HOOK) (8.907) [БОЛТ]
15766504 TELLTALE, INFO CTR (ACDelco #15766504)
88956226 BEZEL, COMMUNICATION CTR CALL SW (GRAY) (RPA TRIM BEZEL)
88956227 BEZEL, COMMUNICATION CTR CALL SW (NEUTRAL)
15032587 ШЛАНГИ, DM & RDG LP (INCLS 20) (16.494)
12450074 BULB, TRADE #578 (ЧАСТЬ OF 19) (ACDelco #578) [ПАТРОН ЛАМПЫ]
15032588 LENS, DM & RDG LP (3 BULB STYLE) (16.495)
15166059 PUSHBUTTON, RDG LP SW (EBONY) (16.494)
19177386 TRIM, L/GATE (GRAY)
19177387 TRIM, L/GATE (NEUTRAL)
19177390 TRIM, L/GATE (GRAY)
19177391 TRIM, L/GATE (NEUTRAL)
88956206 PLATE, RF CARGO NET BZL BKG (RETAINER FOR CARGO NET BEZEL) (R/H & L/H) (12.815)
88956195 BEZEL, RF CNSL ACSRY SW (MIDDLE OVERHEAD КОНСОЛЬ) (GRAY) (MIDDLE OH CNSL W/HVAC)
88956196 BEZEL, RF CNSL ACSRY SW (MIDDLE OVERHEAD КОНСОЛЬ) (NEUTRAL) (W/ HVAC)
21996233 CONTROL, AUX BLO (MID OVERHEAD КОНСОЛЬ) (USE ON VEHICLES WITH SNOWFLAKE GRAPHIC SYMBOL) (ACDelco #15-73085)
88956165 DUCT, RF AUX AIR OTLT (GRAY)
88956166 DUCT, RF AUX AIR OTLT (NEUTRAL)
25770386 HANDLE, ASST (INCLS 5, 29) (GRAY) (2ND SEAT B/PLR)
25770387 HANDLE, ASST (INCLS 5, 29) (NEUTRAL) (2ND SEAT B/PLR)
25770389 HANDLE, ASST (INCLS 5, 29) (GRAY) (2ND SEAT B/PLR)
25770390 HANDLE, ASST (INCLS 5, 29) (NEUTRAL) (2ND SEAT B/PLR)
11509231 SCREW, RD HD C/R TAP, M4.2X1.41X13.0, GM6010M STL, GM813M NICKEL ORGANIC (ЧАСТЬ OF 28) [ВИНТ М6Х12]
88951937 ESCUTCHEON, R/RL FRT ASST STRP (GRAY) (END CAP-ASSIST HANDLE) [НАКЛАДКА]
88951938 ESCUTCHEON, R/RL FRT ASST STRP (NEUTRAL)
88952150 RETAINER, S/S (INCLS 32, 42) (GRAY)
88952151 RETAINER, S/S (INCLS 32, 42) (NEUTRAL)
11515517 SCREW, PAN HD W/FLAT WA, C/R, M4.2X1.41X35, 8 OD, 6010M, NZ (ЧАСТЬ OF 31)
21996232 CONTROL, AUX BLO (FRT OVHD КОНСОЛЬ) (ACDelco #15-73084)
25749089 SWITCH, R/WDO WPR & WA (EBONY)
19121833 BEZEL, RF CNSL ACSRY SW (ЧАСТЬ OF 10) (GRAY) (STD BEZEL/ INTRUSION SENSOR HOLE)
19149350 BEZEL, RF CNSL ACSRY SW (ЧАСТЬ OF 10) (GRAY) (FRT OHC W/O HVAC, INCLS MECH CLIPS & DIMMER SWITCH W/DEFLECTOR) (16.745)
teamcadillac.ru
19149351 BEZEL, RF CNSL ACSRY SW (ЧАСТЬ OF 10) (NEUTRAL) (FRT OHC W/O HVAC, INCLS MECH CLIPS & DIMMER SWITCH W/DEFLECTOR) (16.745)
19149354 BEZEL, RF CNSL ACSRY SW (ЧАСТЬ OF 10) (GRAY) (FRT OHC W/HVAC, INCLS MECH CLIPS & DIMMER SWITCH W/DEFLECTOR)
19149355 BEZEL, RF CNSL ACSRY SW (ЧАСТЬ OF 10) (NEUTRAL) (FRT OHC W/HVAC, INCLS MECH CLIPS & DIMMER SWITCH W/DEFLECTOR)
88952168 LENS, S/S ILLUM MIR LP (ЧАСТЬ OF 37) (LESS BULB)
25756063 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, (INCLS 36, 38-41) (GRAY) (RH VISOR WITHOUT UGDO)
25756064 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, (INCLS 36, 38-41) (NEUTRAL) (RH VISOR WITHOUT UGDO) [КОЗЫРЕК]
25756066 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, (INCLS 36, 38-41) (GRAY) (LH VISOR W/O UGDO)
25756067 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, (INCLS 36, 38-41) (NEUTRAL) (LH VISOR W/O UGDO)
25756069 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, (INCLS 36, 38-41) (GRAY) (LH VISOR W/UGDO)
25756070 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, (INCLS 36, 38-41) (NEUTRAL) (LH VISOR W/UGDO)
15006352 LABEL, INFL RST SYS WRNG (ЧАСТЬ OF 37) (ENGLISH/FRENCH)
15116388 LABEL, INFL RST SYS WRNG (ЧАСТЬ OF 37) (ENGLISH/SPANISH) [НАКЛЕЙКА САМОКЛЕЯЩАЯСЯ]
15766601 LABEL, INFL RST SYS WRNG (ЧАСТЬ OF 37) (ENGLISH/ARABIC)
11516638 SCREW - TAP RND SM WASH HD TY, M4.2X1.4X25, 19.2THD, 8.5 OD (ЧАСТЬ OF 37) (8.906)
25759050 BULB-RDG LP (ЧАСТЬ OF 37) (ACDelco #25759050)
21031302 REINFORCEMENT, S/S SUPT (ЧАСТЬ OF 37) (ANCHOR PLT/SPIDER CLIP)
22612024 CLIP, S/S SUPT (ЧАСТЬ OF 31) (55MM LONG) (PUSH-IN) (15.394) [КРОНШТЕЙН]
(6E10-028) - 2004-2008 E КРЫША HEADLINER (ЛЮК CF5,C3B)
25725191 CLIP, HDLNG T/PNL (GREEN) (18X12.5, SAE 1050STL) (CLIP TO HOLD M4.2X1.41 SCREW, PNL RING 0.94-3.5) [ФИКСАТОР ПАНЕЛИ КРЫШИ КУЗОВА]
88956193 RETAINER, RF CNSL (PUSH IN) (ЛЮК MID OH CNSL SUPT)
19121768 PANEL, HDLNG TR (GRAY) (16.742) (W/TWO CUTOUTS IN ЗАДНИЙ FOR COAT HOOKS)
19121774 PANEL, HDLNG TR (GRAY) (16.742)
89026154 PANEL, HDLNG TR (GRAY) (MINI ЛЮК HEADLINER SUBSTRATE W/1 CUT-OUT FOR ЛЮК МОДУЛЬ)
89026155 PANEL, HDLNG TR (NEUTRAL)
89026158 PANEL, HDLNG TR (NEUTRAL) (W/TWO CUTOUTS IN ЗАДНИЙ FOR COAT HOOKS)
89026228 PANEL, HDLNG TR (GRAY)
89026229 PANEL, HDLNG TR (NEUTRAL)
89026232 PANEL, HDLNG TR (GRAY)
89026233 PANEL, HDLNG TR (NEUTRAL)
89026236 PANEL, HDLNG TR (GRAY)
89026237 PANEL, HDLNG TR (NEUTRAL)
89026241 PANEL, HDLNG TR (NEUTRAL)
22612024 CLIP, COAT HOOK (55MM LONG) (PUSH-IN) (15.394) [КРОНШТЕЙН]
19115773 МОДУЛЬ, RDO ANT (ACDelco #19115773)
88956198 HOOK, COAT (GRAY)
88956199 HOOK, COAT (NEUTRAL)
11516633 SCREW, ROUND LARGE CROWN HD 4.2X1.4X35 11.3OD C/R TAP 6136M P-PT. (COAT HOOK)
88956201 BEZEL, CARGO TIE DN LOOP (GRAY) (POA HDLNG TR MOD)
teamcadillac.ru
88956204 BEZEL, CARGO TIE DN LOOP (GRAY) (POA HDLNG TR MOD)
88956195 BEZEL, RF CNSL ACSRY SW (INCLS 29) (GRAY) (MIDDLE OH CNSL W/HVAC)
88956196 BEZEL, RF CNSL ACSRY SW (MIDDLE OVERHEAD КОНСОЛЬ) (INCLS 29) (NEUTRAL) (W/ HVAC)
89026119 BEZEL, RF CNSL ACSRY SW (INCLS 29) (GRAY) (MIDDLE OH CNSL W/O HVAC)
88952118 HANDLE, ASST (INCLS 37) (GRAY) (HDLING TRIM)
88952119 HANDLE, ASST (INCLS 37) (NEUTRAL) (HDLING TRIM)
15714276 SCREW, HWH, W/FL WA, SELF TAP, M4.2X1.41X18, 12.5 O.D., 6010M, PS (ЧАСТЬ OF 25) (8.977)
15141050 SWITCH, SUN RF (GRAY) (FOR ЗАДНИЙ GLASS СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК (NO VENT FUNCTION))
15141051 SWITCH, SUN RF (NEUTRAL) (FOR ЗАДНИЙ GLASS СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК (NO VENT FUNCTION))
21997743 SWITCH, SUN RF (GRAY) (FOR ЛЮК/СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК FRONT)
21997744 SWITCH, SUN RF (NEUTRAL) (FOR ЛЮК/СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК FRONT)
25749088 SWITCH, SUN RF (EBONY) (FOR ЗАДНИЙ VENT/СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК)
25749089 SWITCH, R/WDO WPR & WA (INCLS 37) (EBONY)
19121836 BEZEL, RF CNSL ACSRY SW (GRAY) (MINI SR BEZEL/ INTRUSION SENSOR HOLE)
19121839 BEZEL, RF CNSL ACSRY SW (GRAY) (MEGA ЛЮК, W/INTRUSION SENSOR HOLES)
19149350 BEZEL, RF CNSL ACSRY SW (GRAY) (FRT OHC W/O HVAC, INCLS MECH CLIPS & DIMMER SWITCH W/DEFLECTOR) (16.745) (FOR MY 04-05 VEHICLES, DLR MAY NEED TO USE ЧАСТЬ TW 19121463 (BK PLATE))
19149351 BEZEL, RF CNSL ACSRY SW (NEUTRAL) (FRT OHC W/O HVAC, INCLS MECH CLIPS & DIMMER SWITCH W/DEFLECTOR) (16.745) (FOR MY 04-05 VEHICLES, DLR MAY NEED TO USE ЧАСТЬ TW 19121463 (BK PLATE))
19149354 BEZEL, RF CNSL ACSRY SW (GRAY) (FRT OHC W/HVAC, INCLS MECH CLIPS & DIMMER SWITCH W/DEFLECTOR) (FOR MY 04-05 VEHICLES, DLR MAY NEED TO USE ЧАСТЬ TW 19121463 (BK PLATE))
19149358 BEZEL, RF CNSL ACSRY SW (MINI FRONT OVERHEAD КОНСОЛЬ) (GRAY) (16.745) (FOR MY 04-05 VEHICLES, DLR MAY NEED TO USE ЧАСТЬ TW 19121463 (BK PLATE)) [НАКЛАДКА]
19149359 BEZEL, RF CNSL ACSRY SW (MINI FRONT OVERHEAD КОНСОЛЬ) (NEUTRAL) (INCLS MECH CLIPS & DIMMER SWITCH W/DEFLECTOR) (16.745) (FOR MY 04-05 VEHICLES, DLR MAY NEED TO USE ЧАСТЬ TW 19121463 (BK PLATE))
19149362 BEZEL, RF CNSL ACSRY SW (GRAY) (FRT OHC (MEGA ЛЮК) W/MECH CLIPS & DIMMER SWITCH W/DFL) (16.745) (FOR MODEL YEAR 04-05 VEHICLES, DLR MAY NEED TO USE ЧАСТЬ T/W 19121463 (BK PLATE))
19149363 BEZEL, RF CNSL ACSRY SW (NEUTRAL) (FRT OHC (MEGA ЛЮК) W/MECH CLIPS & DIMMER SWITCH W/DFL) (16.745) (FOR MY 04-05 VEHICLES, DLR MAY NEED TO USE ЧАСТЬ TW 19121463 (BK PLATE))
88956195 BEZEL, RF CNSL ACSRY SW (GRAY) (MIDDLE OH CNSL W/HVAC)
89026119 BEZEL, RF CNSL ACSRY SW (GRAY) (MIDDLE OH CNSL W/O HVAC)
89026291 BEZEL, RF CNSL ACSRY SW (MIDDLE OVERHEAD КОНСОЛЬ) (NEUTRAL) (W/O HVAC)
11515517 SCREW, PAN HD W/FLAT WA, C/R, M4.2X1.41X35, 8 OD, 6010M, NZ (ЧАСТЬ OF 36)
88952150 RETAINER, S/S (INCLS 35, 43) (GRAY)
88952151 RETAINER, S/S (INCLS 35, 43) (NEUTRAL)
09442395 BULB, TRADE # 7065 (ЧАСТЬ OF 28, 33, 39) (ACDelco #L7065)
88952168 LENS, S/S ILLUM MIR LP (ЧАСТЬ OF 39) (LESS BULB)
25756063 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, (INCLS 37, 38, 40-42) (GRAY) (RH VISOR WITHOUT UGDO)
25756064 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, (INCLS 37, 38, 40-42) (NEUTRAL) (RH VISOR WITHOUT UGDO) [КОЗЫРЕК]
25756066 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, (INCLS 37, 38, 40-42) (GRAY) (LH VISOR W/O UGDO)
25756067 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, (INCLS 37, 38, 40-42) (NEUTRAL) (LH VISOR W/O UGDO)
25756069 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, (INCLS 37, 38, 40-42) (GRAY) (LH VISOR W/UGDO)
25756070 СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК, (INCLS 37, 38, 40-42) (NEUTRAL) (LH VISOR W/UGDO)
15006352 LABEL, INFL RST SYS WRNG (ЧАСТЬ OF 39) (ENGLISH/FRENCH)
15116388 LABEL, INFL RST SYS WRNG (ЧАСТЬ OF 39) (ENGLISH/SPANISH) [НАКЛЕЙКА САМОКЛЕЯЩАЯСЯ]
15766601 LABEL, INFL RST SYS WRNG (ЧАСТЬ OF 39) (ENGLISH/ARABIC)
11516638 SCREW - TAP RND SM WASH HD TY, M4.2X1.4X25, 19.2THD, 8.5 OD (ЧАСТЬ OF 39) (8.906)
21031302 REINFORCEMENT, S/S SUPT (ЧАСТЬ OF 39) (ANCHOR PLT/SPIDER CLIP)
22612024 CLIP, S/S SUPT (ЧАСТЬ OF 36) (55MM LONG) (PUSH-IN) (15.394) [КРОНШТЕЙН]
(6E14-007) - 2004-2009 E СИДЕНЬЕ В СБОРЕ/DRIVER (POWER LUMBAR AL2)
88994770 PAD, D/SEAT BK CUSH
88897970 COVER, D/SEAT H/RST (NEUTRAL)
88897971 COVER, D/SEAT H/RST (GRAY)
88992582 COVER, D/SEAT H/RST (EBONY)
88898400 PAD, D/SEAT H/RST
88897670 SUPPORT, D/SEAT H/RST
19122625 GUIDE, D/SEAT H/RST (EBONY) (W/O BUTTON)
19122627 GUIDE, D/SEAT H/RST (EBONY) (W/BUTTON)
88994276 GUIDE, D/SEAT H/RST (NEUTRAL) (W/BUTTON)
88994279 GUIDE, D/SEAT H/RST (NEUTRAL) (W/O BUTTON)
88994730 GUIDE, D/SEAT H/RST (GRAY) (W/BUTTON) (11.625)
88994731 GUIDE, D/SEAT H/RST (GRAY) (W/O BUTTON) (11.625)
88897640 ROLLER, D/SEAT SHLDR BELT
88897614 COVER, D/SEAT SHLDR BELT OPG BZL (11.573)
88897272 БОЛТ, D/SEAT (TOWER COVER)
88897644 БОЛТ, D/SEAT ADJR (ADJR TO FRM)
10421018 RETAINER, D/SEAT BK CUSH CVR (ЧАСТЬ OF 12) (NATURAL) (4MM HOLE, 33MM) (15.100)
88895401 PANEL, D/SEAT BK CUSH FIN (INCLS 11) (NEUTRAL) (W/MESH MAP PKT)
88895403 PANEL, D/SEAT BK CUSH FIN (INCLS 11) (GRAY) (W/MESH MAP PKT)
88992613 PANEL, D/SEAT BK CUSH FIN (INCLS 11) (EBONY) (W/MESH MAP PKT)
11517996 ГАЙКА, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (UPPER) [ГАЙКА М10]
88897618 BEZEL, D/SEAT SHLDR BELT OPG
88897616 PANEL, D/SEAT BK CUSH SI BOLS
15290832 МОДУЛЬ, D/SEAT SI INFL RST (EBONY)
25760565 МОДУЛЬ, D/SEAT SI INFL RST (GRAY)
25760566 МОДУЛЬ, D/SEAT SI INFL RST (EBONY)
25760567 МОДУЛЬ, D/SEAT SI INFL RST (NEUTRAL)
00332364 RETAINER - PUSH IN, FITS HOLE SIZE 0.245 - 0.260, GRIP LENGTH 0.52, 0.7 OD, MATERIAL NYLON 6/6 PER GMP.PA66.015 (D/SEAT BK CUSH OTR SUPT)
11514623 БОЛТ, HEX W/CON WA, M6X1X20 (D/SEAT SI INFL RST MDL)
88949040 BRACKET, INFL RST D/SEAT SI MDL (11.561)
11517068 NUT-METRIC HEX FLABGE, M6X1, 10MM SOCKET (INFL RST D/SEAT SI MDL)
88952627 ГАЙКА, D/SEAT BELT (BKL SI) (TUBE NUT) (11.556)
88897643 БОЛТ, D/SEAT RECL (RECL TO FRM)
25736516 HARNESS, INFL RST WRG (LESS TUBE-ST MEMORY SWITCH HARNESS)
88994763 COVER, D/SEAT RECL LWR FIN (INCLS 27) (NEUTRAL) (OTR) (W/LUMBAR SWITCH BEZEL)
88994764 COVER, D/SEAT RECL LWR FIN (INCLS 27) (EBONY) (OTR) (W/LUMBAR SWITCH BEZEL)
88994765 COVER, D/SEAT RECL LWR FIN (INCLS 27) (GRAY) (OTR) (W/LUMBAR SWITCH BEZEL)
10315826 SWITCH, D/SEAT LUMBAR CONT (EBONY) [ВЫКЛЮЧАТЕЛЬ РЕГУЛИРОВКИ ПОЛОЖЕНИЯ СИДЕНЬЯ]
25772912 SWITCH, D/SEAT LUMBAR CONT (NEUTRAL)
25772913 SWITCH, D/SEAT LUMBAR CONT (GRAY)
88995059 ADJUSTER, D/SEAT (INCLS RECL) [ПЕРЕХОДНИК В СБОРЕ]
88898321 COVER, D/SEAT ADJR FIN (NEUTRAL) (FRT)
88898399 COVER, D/SEAT ADJR FIN (GRAY) (FRT)
88993348 COVER, D/SEAT ADJR FIN (EBONY) (FRT)
11609257 БОЛТ, PAN HD, TORX, M12X1.75X34, 9.8 STEEL, GMW3179 (D/SEAT ADJR (W/BELT)) (8.907) [БОЛТ]
00332364 RETAINER - PUSH IN, FITS HOLE SIZE 0.245 - 0.260, GRIP LENGTH 0.52, 0.7 OD, MATERIAL NYLON 6/6 PER GMP.PA66.015 (D/SEAT SPCR)
88898393 COVER, D/SEAT ADJR FIN (INCLS 35) (NEUTRAL) (RR)
88898395 COVER, D/SEAT ADJR FIN (INCLS 35) (GRAY) (RR)
88993350 COVER, D/SEAT ADJR FIN (INCLS 35) (EBONY) (RR)
88994108 РАМА, D/SEAT BK CUSH (W/LUMBAR КРЕПЛЕНИЕ)
88952646 БОЛТ, D/SEAT BK CUSH FRM (INCLS 38) (11.628)
88895365 COVER, D/SEAT RECL LWR FIN (INCLS 41) (NEUTRAL) (INR)
88895367 COVER, D/SEAT RECL LWR FIN (INCLS 41) (GRAY) (INR)
88992615 COVER, D/SEAT RECL LWR FIN (INCLS 41) (EBONY) (INR)
88950767 HARNESS, D/SEAT WRG (INCLS 30)
88992986 HARNESS, D/SEAT WRG (INCLS 30)
88994874 HARNESS, D/SEAT LUMBAR CONT WRG (INCLS 30)
88994875 HARNESS, D/SEAT LUMBAR CONT WRG (INCLS 30)
88994876 HARNESS, D/SEAT LUMBAR CONT WRG (INCLS 30)
teamcadillac.ru
88994877 HARNESS, D/SEAT LUMBAR CONT WRG (INCLS 30) [ЖГУТ ПРОВОДОВ]
11509428 БОЛТ/SCREW, HEX, W/FLAT WA, M4.2X1.4X13, 12.3 O.D., BHL PT, 6010M, NO (D/SEAT) (8.977)
10399538 МОДУЛЬ, D/SEAT HTR CONT [МОДУЛЬ В СБОРЕ ЭЛЕКТР. ПРИВОД]
15783697 МОДУЛЬ, D/SEAT ADJR MEMORY (W/LUMBAR) (11.558) [МОДУЛЬ]
88895457 РАМА, D/SEAT CUSH (INCLS 55) (PWR)
12450263 SWITCH, D/SEAT RECL (INCLS ADJR SWITCH) (8-WAY)
88895393 BEZEL, D/SEAT ADJR SW (INCLS 49) (NEUTRAL)
88895395 BEZEL, D/SEAT ADJR SW (INCLS 49) (GRAY)
88992623 BEZEL, D/SEAT ADJR SW (INCLS 49) (EBONY)
25671087 KNOB, D/SEAT ADJR SW (NEUTRAL)
25721217 KNOB, D/SEAT ADJR SW (GRAY)
25749092 KNOB, D/SEAT ADJR SW (EBONY)
25671092 KNOB, D/SEAT RECL LVR (NEUTRAL)
25721207 KNOB, D/SEAT RECL LVR (GRAY)
25749093 KNOB, D/SEAT RECL LVR (EBONY)
88994088 LUMBAR SUB, D/SEAT (W/LUMBAR MOTOR)
88898332 PAD, D/SEAT CUSH
25764214 ПОДОГРЕВАТЕЛЬ, D/SEAT CUSH [ПОДОГРЕВ СИДЕНИЯ]
88994482 COVER, D/SEAT CUSH (NEUTRAL)
88994483 COVER, D/SEAT CUSH (GRAY)
88994484 COVER, D/SEAT CUSH (EBONY)
88994498 COVER, D/SEAT CUSH (NEUTRAL)
88994499 COVER, D/SEAT CUSH (GRAY)
88994500 COVER, D/SEAT CUSH (EBONY) [ОБШИВКА СИДЕНИЯ (КОЖА)]
88994458 COVER, D/SEAT BK CUSH (NEUTRAL)
88994459 COVER, D/SEAT BK CUSH (GRAY)
88994460 COVER, D/SEAT BK CUSH (EBONY)
88994467 COVER, D/SEAT BK CUSH (GRAY)
88994468 COVER, D/SEAT BK CUSH (EBONY) [ЧЕХОЛ СИДЕНИЯ]
(6E14-011) - 2004-2005 E ОТДЕЛКА/LIFTGATE
11588650 CLIP, 12X14X16.6, GM4345M (ЧАСТЬ OF 3) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
25759087 PANEL, L/GATE TR FIN (INCLS 2, 8) (EBONY)
25759088 PANEL, L/GATE TR FIN (INCLS 2, 8) (NEUTRAL)
25759089 PANEL, L/GATE TR FIN (INCLS 2, 8) (GRAY)
teamcadillac.ru
12376799 LENS, R/CMPT C/LP (ЧАСТЬ OF 7)
09431808 BULB, TRADE # 211-2 (ЧАСТЬ OF 7) (ACDelco #L211-2)
15028837 ЛАМПА, L/GATE CTSY (INCLS 5, 6) (EBONY) (INCLS BULB & LENS)
25754966 ЛАМПА, L/GATE CTSY (INCLS 5, 6) (NEUTRAL)
11519032 RETAINER, PUSH IN, 19.5X28.4X1.8, FITS HOLE 9.1, ACETAL, BLK (ЧАСТЬ OF 3) [ФИКСАТОР ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ]
11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (L/GATE TR)
(6E14-012) - 2004-2006 EB СИДЕНЬЕ ПАССАЖИРА (EXC POWER ADJUSTER AH8)
88895405 PANEL, P/SEAT BK CUSH FIN (INCLS 3) (NEUTRAL) (W/MESH MAP PKT)
88895407 PANEL, P/SEAT BK CUSH FIN (INCLS 3) (GRAY) (W/MESH MAP PKT) [НАКЛАДКА]
88992614 PANEL, P/SEAT BK CUSH FIN (INCLS 3) (EBONY) (W/MESH MAP PKT)
10421018 RETAINER, P/SEAT BK CUSH CVR (ЧАСТЬ OF 2) (NATURAL) (4MM HOLE, 33MM) (15.100)
88897272 БОЛТ, P/SEAT (TOWER COVER)
88897670 SUPPORT, P/SEAT H/RST
88898400 PAD, P/SEAT H/RST
88897970 COVER, P/SEAT H/RST (NEUTRAL)
88897971 COVER, P/SEAT H/RST (GRAY)
88992582 COVER, P/SEAT H/RST (EBONY)
19122625 GUIDE, P/SEAT H/RST (EBONY) (W/O BUTTON)
19122627 GUIDE, P/SEAT H/RST (EBONY) (W/BUTTON)
88994276 GUIDE, P/SEAT H/RST (NEUTRAL) (W/BUTTON)
88994279 GUIDE, P/SEAT H/RST (NEUTRAL) (W/O BUTTON)
88994730 GUIDE, P/SEAT H/RST (GRAY) (W/BUTTON) (11.625)
88994731 GUIDE, P/SEAT H/RST (GRAY) (W/O BUTTON) (11.625)
88898336 PAD, P/SEAT BK CUSH
88994454 COVER, P/SEAT BK CUSH (NEUTRAL)
teamcadillac.ru
88994455 COVER, P/SEAT BK CUSH (GRAY)
88994456 COVER, P/SEAT BK CUSH (EBONY)
88994470 COVER, P/SEAT CUSH (NEUTRAL)
88994471 COVER, P/SEAT CUSH (GRAY)
88994472 COVER, P/SEAT CUSH (EBONY)
88898333 PAD, P/SEAT CUSH
88897610 РАМА, P/SEAT CUSH (INCLS 14) (MAN)
88895369 COVER, P/SEAT RECL LWR FIN (INCLS 22) (NEUTRAL) (INR)
88895371 COVER, P/SEAT RECL LWR FIN (INCLS 22) (GRAY) (INR)
88992616 COVER, P/SEAT RECL LWR FIN (INCLS 22) (EBONY) (INR)
88952627 ГАЙКА, P/SEAT BELT (BKL SI) (PREРОЛИК НАТЯЖИТЕЛЬ) (TUBE NUT) (11.556)
88952646 БОЛТ, P/SEAT BK CUSH (INCLS 21) (11.628)
11517068 ГАЙКА, INFL RST P/SEAT SI MDL (M6X1X3, 14.2 O.D.) (8.917)
88898352 COVER, P/SEAT ADJR FIN (NEUTRAL) (FRT)
88898402 COVER, P/SEAT ADJR FIN (GRAY) (FRT)
88993349 COVER, P/SEAT ADJR FIN (EBONY) (FRT)
88898408 ADJUSTER, P/SEAT (СМ. ГРУППУ 11.000 "ADJUSTER ASM/PASSENGER" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (MAN)
88897411 HANDLE, P/SEAT RECL (INCLS 28) (NEUTRAL)
88949044 HANDLE, P/SEAT RECL (INCLS 28) (GRAY)
88992628 HANDLE, P/SEAT RECL (INCLS 28) (EBONY)
88994759 COVER, P/SEAT OTR RECL FIN (INCLS 29) (NEUTRAL) (MANUAL)
88994760 COVER, P/SEAT OTR RECL FIN (INCLS 29) (EBONY) (MANUAL)
88994761 COVER, P/SEAT OTR RECL FIN (INCLS 29) (GRAY) (MANUAL)
88895383 BEZEL, P/SEAT BELT OPG (BKL SI) (NEUTRAL)
88895385 BEZEL, P/SEAT BELT OPG (BKL SI) (GRAY)
88897619 BEZEL, P/SEAT SHLDR BELT OPG
88992618 BEZEL, P/SEAT SHLDR BELT OPG (EBONY)
88898393 COVER, P/SEAT ADJR FIN (INCLS 34) (NEUTRAL) (RR)
88898395 COVER, P/SEAT ADJR FIN (INCLS 34) (GRAY) (RR)
88993350 COVER, P/SEAT ADJR FIN (INCLS 34) (EBONY) (RR)
11609257 БОЛТ, P/SEAT ADJR (W/BELT) (M12X1.75X34) (8.907) [БОЛТ]
88849035 РАМА, P/SEAT BK CUSH (INCLS 13) (W/SUSPENSION & SUPPORT)
88897643 БОЛТ, P/SEAT RECL (RECL TO FRM)
00332364 RETAINER - PUSH IN, FITS HOLE SIZE 0.245 - 0.260, GRIP LENGTH 0.52, 0.7 OD, MATERIAL NYLON 6/6 PER GMP.PA66.015 (P/SEAT BK CUSH SI OTR FAC)
25760561 МОДУЛЬ, P/SEAT SI INFL RST (GRAY)
25760562 МОДУЛЬ, P/SEAT SI INFL RST (EBONY)
25760563 МОДУЛЬ, P/SEAT SI INFL RST (NEUTRAL)
88897617 PANEL, P/SEAT BK CUSH SI BOLS
11517996 ГАЙКА, P/SEAT BELT (BKL SI) (M10X1.5, 11.2 THK) (8.917) (ACDelco #11517996) [ГАЙКА М10]
11514623 БОЛТ, HEX W/CON WA, M6X1X20 (P/SEAT SI INFL RST MDL)
88949040 BRACKET, INFL RST P/SEAT SI MDL (11.561)
88897644 БОЛТ, P/SEAT ADJR (ADJR TO FRM)
88897641 ROLLER, P/SEAT SHLDR BELT
88897615 COVER, P/SEAT SHLDR BELT OPG BZL (11.573)
(6E14-013) - 2004-2005 E ПЕРЕДНЯЯ ОТДЕЛКА
15214908 MOLDING, W/S SI GARN (INCLS 2-4, 8-11) (NEUTRAL) (W/SPEAKER)
15214912 MOLDING, W/S SI GARN (INCLS 2-4, 8-11) (NEUTRAL) (W/SPEAKER)
15214916 MOLDING, W/S SI GARN (INCLS 2-4, 8-11) (NEUTRAL) (W/SPEAKER)
15214920 MOLDING, W/S SI GARN (INCLS 2-4, 8-11) (NEUTRAL) (W/SPEAKER)
15829544 MOLDING, W/S SI GARN (INCLS 2-4, 8-11) (GRAY)
15829546 MOLDING, W/S SI GARN (INCLS 2-4, 8-11) (GRAY)
teamcadillac.ru
15935494 MOLDING, W/S SI GARN (INCLS 2-4, 8-11) (GRAY) (BOSE) [ДИНАМИК 20ВТ]
15935495 MOLDING, W/S SI GARN (INCLS 2-4, 8-11) (GRAY) (BOSE)
11508765 SCREW, TORX, W/ RD WA, M4.2X1.41X16, 11.1 O.D., STL, NIOR (ЧАСТЬ OF 1)
89046860 BEZEL, RDO W/S SI G/MLDG SPKR GRL (ЧАСТЬ OF 1) (INCLS 4)
89046861 BEZEL, RDO W/S SI G/MLDG SPKR GRL (ЧАСТЬ OF 1) (INCLS 4)
89046862 BEZEL, RDO W/S SI G/MLDG SPKR GRL (ЧАСТЬ OF 1) (INCLS 4)
89046863 BEZEL, RDO W/S SI G/MLDG SPKR GRL (ЧАСТЬ OF 1) (INCLS 4)
89046864 BEZEL, RDO W/S SI G/MLDG SPKR GRL (ЧАСТЬ OF 1) (INCLS 4)
89046865 BEZEL, RDO W/S SI G/MLDG SPKR GRL (ЧАСТЬ OF 1) (INCLS 4)
89046866 BEZEL, RDO W/S SI G/MLDG SPKR GRL (ЧАСТЬ OF 1) (INCLS 4)
89046867 BEZEL, RDO W/S SI G/MLDG SPKR GRL (ЧАСТЬ OF 1) (INCLS 4)
15279190 PLATE, FRT S/D SILL TR (INCLS 6, 7) (EBONY)
25763788 PLATE, FRT S/D SILL TR (INCLS 6, 7) (GRAY)
25763789 PLATE, FRT S/D SILL TR (INCLS 6, 7)
25763890 PLATE, FRT S/D SILL TR (INCLS 6, 7) [ПОДДОН]
25799071 PLATE, FRT S/D SILL TR (INCLS 6, 7)
25799072 PLATE, FRT S/D SILL TR (INCLS 6, 7) (EBONY)
25672428 RETAINER, FRT S/D SILL TR PLT (ЧАСТЬ OF 5) (7 X 14MM HOLE) (RECTANGLE) (4LH/4RH) [ФИКСАТОР МОЛДИНГА ДВЕРИ]
11588650 CLIP, 12X14X16.6, GM4345M (ЧАСТЬ OF 5) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
15215743 SPEAKER, RDO W/S SI G/MLDG (LH & RH) (ЧАСТЬ OF 1) (ACDelco #15215743)
15215744 SPEAKER, RDO W/S SI G/MLDG (ЧАСТЬ OF 1) (LH & RH) (W/O GRILLE) (ACDelco #15215744)
11588650 CLIP, 12X14X16.6, GM4345M (ЧАСТЬ OF 1) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
22626098 CLIP, W/S SI G/MLDG (ЧАСТЬ OF 1) (M21.8X15.0X20.5) (14.645)
25772916 PLUG, C/PLR UPR G/MLDG БОЛТ HOLE FIN (ЧАСТЬ OF 1) (GRAY) (AIRBAG) (14.865) [НАКЛАДКА]
25772917 PLUG, C/PLR UPR G/MLDG БОЛТ HOLE FIN (ЧАСТЬ OF 1) (NEUTRAL) (AIRBAG) (14.865) [НАКЛАДКА AIRBAG]
(6E14-025) - 2004-2009 E ОТДЕЛКА/CENTER ПАНЕЛЬ ЗАДНЕЙ СТОЙКИ КУЗОВА & QUARTER
15935504 MOLDING, BODY SI WDO FRT GARN (C-PLR (SAIL) NO AIR) (INCLS 18-22) (GRAY)
15935505 MOLDING, BODY SI WDO FRT GARN (C-PLR (SAIL) NO AIR) (INCLS 18-22) (GRAY)
15935510 MOLDING, BODY SI WDO FRT GARN (INCLS 18-22) (GRAY)
15935511 MOLDING, BODY SI WDO FRT GARN (INCLS 18-22) (GRAY)
25770426 MOLDING, BODY SI WDO FRT GARN (INCLS 18-22) (NEUTRAL)
25770429 MOLDING, BODY SI WDO FRT GARN (INCLS 18-22) (NEUTRAL)
25770432 MOLDING, BODY SI WDO FRT GARN (INCLS 18-22) (NEUTRAL)
25770435 MOLDING, BODY SI WDO FRT GARN (INCLS 18-22) (NEUTRAL)
15935474 MOLDING, BODY SI WDO RR GARN (INCLS 2) (GRAY) [НАКЛАДКА ПАНЕЛИ БАГАЖНОГО ОТДЕЛЕНИЯ]
25766672 MOLDING, BODY SI WDO RR GARN (INCLS 2) (GRAY)
25766673 MOLDING, BODY SI WDO RR GARN (INCLS 2) (NEUTRAL)
25766676 MOLDING, BODY SI WDO RR GARN (INCLS 2) (NEUTRAL)
25766678 MOLDING, BODY SI WDO RR GARN (INCLS 2) (GRAY)
25766679 MOLDING, BODY SI WDO RR GARN (INCLS 2) (NEUTRAL)
25766682 MOLDING, BODY SI WDO RR GARN (INCLS 2) (NEUTRAL) [МОЛДИНГ]
25885623 MOLDING, BODY SI WDO RR GARN (INCLS 2) (GRAY)
25773792 PLATE, R/CMPT SILL TR (INCLS 5) (GRAY)
25773793 PLATE, R/CMPT SILL TR (INCLS 5) (NEUTRAL) [ПЛАСТИНА В СБОРЕ]
25800537 PLATE, R/CMPT SILL TR (INCLS 5) (EBONY)
11588650 CLIP, 12X14X16.6, GM4345M (ЧАСТЬ OF 4) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
15279198 PLATE, RR S/D SILL TR (INCLS 8, 9) (GRAY)
15279199 PLATE, RR S/D SILL TR (INCLS 8, 9) (EBONY) [ВНУТРЕННЯЯ ПАНЕЛЬ ПОРОГА КУЗОВА]
15279202 PLATE, RR S/D SILL TR (INCLS 8, 9) (GRAY)
15279203 PLATE, RR S/D SILL TR (INCLS 8, 9) (EBONY) [ПОДДОН]
25763796 PLATE, RR S/D SILL TR (INCLS 8, 9) (NEUTRAL)
25763800 PLATE, RR S/D SILL TR (INCLS 8, 9) (NEUTRAL)
11588650 CLIP, 12X14X16.6, GM4345M (ЧАСТЬ OF 7) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
25672428 RETAINER, RR S/D SILL TR PLT (ЧАСТЬ OF 7) (7 X 14MM HOLE) (RECTANGLE) (11.175) (2LH/2RH) [ФИКСАТОР МОЛДИНГА ДВЕРИ]
15935530 PANEL, C/PLR LWR TR (INCLS 11, 12) (GRAY)
15935531 PANEL, C/PLR LWR TR (INCLS 11, 12) (GRAY)
15935532 PANEL, C/PLR LWR TR (INCLS 11, 12) (EBONY)
15935533 PANEL, C/PLR LWR TR (INCLS 11, 12) (EBONY)
25738602 PANEL, C/PLR LWR TR (INCLS 11, 12) (NEUTRAL)
25738603 PANEL, C/PLR LWR TR (INCLS 11, 12) (NEUTRAL)
25732230 RETAINER, C/PLR LWR T/PNL (ЧАСТЬ OF 10) (CIRCULAR PUSH-PIN)
11588650 CLIP, 12X14X16.6, GM4345M (ЧАСТЬ OF 10) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
25765982 PANEL, C/PLR UPR TR (INCLS 14) (NEUTRAL)
25765985 PANEL, C/PLR UPR TR (INCLS 14) (NEUTRAL)
25925434 PANEL, C/PLR UPR TR (INCLS 14) (GRAY)
25925437 PANEL, C/PLR UPR TR (INCLS 14) (GRAY)
11588650 CLIP, 12X14X16.6, GM4345M (ЧАСТЬ OF 13) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
11517486 БОЛТ-HEX, M6X1X30, 19 THD, 17 OD, 9.8, 6280M (SN-ZN), MACH, P-PT (ASST HDL BRKT)
25770386 HANDLE, ASST (GRAY) (2ND SEAT B/PLR)
25770387 HANDLE, ASST (NEUTRAL) (2ND SEAT B/PLR)
25770389 HANDLE, ASST (GRAY) (2ND SEAT B/PLR)
25770390 HANDLE, ASST (NEUTRAL) (2ND SEAT B/PLR)
teamcadillac.ru
11518908 ГАЙКА, ASST HDL (M6X1X15) (7.840)
25772922 DEFLECTOR, AUX КОНДИЦИОНЕР AIR OTLT (1LH, 1RH) (ЧАСТЬ OF 1) (GRAY) [ЗАГЛУШКА ВНУТРЕННЕЙ ПАНЕЛИ КУЗОВА]
25772923 DEFLECTOR, AUX КОНДИЦИОНЕР AIR OTLT (1LH, 1RH) (ЧАСТЬ OF 1) (NEUTRAL L)
11588659 CLIP, BODY SI WDO FRT G/MLDG (ЧАСТЬ OF 1) (M12.7X45)
25764196 BEZEL, CARGO TIE DN LOOP (RR COMPT SILL PLATE) (GRAY)
25764197 BEZEL, CARGO TIE DN LOOP (RR COMPT SILL PLATE) (NEUTRAL)
25764198 BEZEL, CARGO TIE DN LOOP (RR COMPT SILL PLATE) (EBONY)
25764204 HOOK, CARGO TIE DN (W/STRAIGHT BRKT) [КРОНШТЕЙН КРЕПЕЖНЫЙ]
(6E14-026) - 2004-2006 EB СИДЕНЬЕ ПАССАЖИРА (POWER ADJUSTER AH8)
88994771 PAD, P/SEAT BK CUSH
88994462 COVER, P/SEAT BK CUSH (NEUTRAL)
88994463 COVER, P/SEAT BK CUSH (GRAY)
88994464 COVER, P/SEAT BK CUSH (EBONY) (W/2 TERMINALS) [ЧЕХОЛ СИДЕНИЯ]
88992579 COVER, P/SEAT CUSH (EBONY)
88994478 COVER, P/SEAT CUSH (NEUTRAL)
88994479 COVER, P/SEAT CUSH (GRAY)
88994494 COVER, P/SEAT CUSH (NEUTRAL)
88994495 COVER, P/SEAT CUSH (GRAY)
88994496 COVER, P/SEAT CUSH (EBONY) [ЧЕХОЛ СИДЕНИЯ]
88994089 LUMBAR SUB, P/SEAT (W/LUMBAR MOTOR)
88895458 РАМА, P/SEAT CUSH (INCLS 14) (PWR)
10399538 МОДУЛЬ, P/SEAT HTR CONT [МОДУЛЬ В СБОРЕ ЭЛЕКТР. ПРИВОД]
11509428 БОЛТ/SCREW, HEX, W/FLAT WA, M4.2X1.4X13, 12.3 O.D., BHL PT, 6010M, NO (P/SEAT) (8.977)
88897626 HARNESS, P/SEAT CONT MDL WRG (INCLS 19)
88994093 HARNESS, P/SEAT CONT MDL WRG (INCLS 19)
88994094 HARNESS, P/SEAT CONT MDL WRG (INCLS 19)
12450264 SWITCH, P/SEAT RECL (8-WAY)
25671087 KNOB, P/SEAT ADJR SW (NEUTRAL)
25721217 KNOB, P/SEAT ADJR SW (GRAY)
25749092 KNOB, P/SEAT ADJR SW (EBONY)
88895397 BEZEL, P/SEAT ADJR SW (INCLS 21) (NEUTRAL)
88895399 BEZEL, P/SEAT ADJR SW (INCLS 21) (GRAY)
88992624 BEZEL, P/SEAT ADJR SW (INCLS 21) (EBONY)
25671097 KNOB, P/SEAT RECL (NEUTRAL)
25721215 KNOB, P/SEAT RECL (GRAY)
25749094 KNOB, P/SEAT RECL (EBONY)
88895369 COVER, P/SEAT RECL LWR FIN (INCLS 29) (NEUTRAL) (INR)
88895371 COVER, P/SEAT RECL LWR FIN (INCLS 29) (GRAY) (INR)
88992616 COVER, P/SEAT RECL LWR FIN (INCLS 29) (EBONY) (INR)
88952646 БОЛТ, P/SEAT BK CUSH (INCLS 28) (11.628)
21303269 CLIP, NARROW POINT - 0.63 SPR STL SAE 1050, GM 4345M 6D 96/48 YELLOW CR (ЧАСТЬ OF 25)
88995058 ADJUSTER, P/SEAT (СМ. ГРУППУ 11.000 "ADJUSTER ASM/PASSENGER" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (PWR)
10285935 RETAINER, P/SEAT RECL (ЧАСТЬ OF 37) (WHITE) (4MM HOLE, 25.5MM LONG) (MALE PUSH-IN) (14.630) [ФИКСАТОР КРЕПЛЕНИЯ ОТДЕЛКИ САЛОНА]
10315826 SWITCH, P/SEAT LUMBAR CONT (EBONY) [ВЫКЛЮЧАТЕЛЬ РЕГУЛИРОВКИ ПОЛОЖЕНИЯ СИДЕНЬЯ]
25772912 SWITCH, P/SEAT LUMBAR CONT (NEUTRAL)
25772913 SWITCH, P/SEAT LUMBAR CONT (GRAY)
88994767 COVER, P/SEAT RECL LWR FIN (INCLS 34) (NEUTRAL) (OTR) (W/LUMBAR SWITCH BEZEL)
88994768 COVER, P/SEAT RECL LWR FIN (INCLS 34) (EBONY) (OTR) (W/LUMBAR SWITCH BEZEL)
88994769 COVER, P/SEAT RECL LWR FIN (INCLS 34) (GRAY) (OTR) (W/LUMBAR SWITCH BEZEL)
00332364 RETAINER - PUSH IN, FITS HOLE SIZE 0.245 - 0.260, GRIP LENGTH 0.52, 0.7 OD, MATERIAL NYLON 6/6 PER GMP.PA66.015 (P/SEAT SHLDR BELT)
88898393 COVER, P/SEAT ADJR FIN (INCLS 40) (NEUTRAL) (RR)
88898395 COVER, P/SEAT ADJR FIN (INCLS 40) (GRAY) (RR)
88993350 COVER, P/SEAT ADJR FIN (INCLS 40) (EBONY) (RR)
teamcadillac.ru
88849035 РАМА, P/SEAT BK CUSH (W/SUSPENSION & SUPPORT)
88994109 РАМА, P/SEAT BK CUSH (W/LUMBAR КРЕПЛЕНИЕ)
00332364 RETAINER - PUSH IN, FITS HOLE SIZE 0.245 - 0.260, GRIP LENGTH 0.52, 0.7 OD, MATERIAL NYLON 6/6 PER GMP.PA66.015 (P/SEAT BK CUSH)
(6E14-027) - 2004-2006 E ОБЛИЦОВКА ПЕРЕДНЕЙ ВОДИТЕЛЬСКОЙ ДВЕРИ
15218754 DEFLECTOR, FRT S/D WAT
20310739 ГАЙКА, FRT S/D PULL HDL (3.125 MM) (RECTANGULAR NYLON) (14.690) [ВТУЛКА ФИКСАТОРА РУЧКИ САЛОНА]
03907444 ГАЙКА, PUSH IN, SQUARE, UN THD, M9.5 SQ HOLE, NYLON (FRT S/D I/S HDL)
teamcadillac.ru
25746686 HARNESS, S/D WRG (LH&RH)
25746688 HARNESS, S/D WRG
25759729 HANDLE, FRT S/D I/S (HIGH LUSTER) [РУЧКА]
12337828 SCREW, HEX W/FLAT WA, TAP, M6.3X1.81X20, 13.2 O.D., AB PT, STL, PZ0R (FRT S/D I/S HDL)
11509231 SCREW, RD HD C/R TAP, M4.2X1.41X13.0, GM6010M STL, GM813M NICKEL ORGANIC (FRT S/D) [ВИНТ М6Х12]
25758328 SEALING STRIP, FRT S/D WDO INR
25795707 SEALING STRIP, FRT S/D WDO INR
89038823 PANEL, FRT S/D UPR FRT TR (INCLS 10-12)
88983972 BEZEL, SI WDO SW (INCLS 17) (EBONY)
88983974 BEZEL, SI WDO SW (INCLS 17) (EBONY)
88983975 BEZEL, SI WDO SW (INCLS 17) (EBONY) (MONOTONE W/O WOOD) (W/FOLD & MEMORY) (W/PLASTIC HANDLE)
89038787 BEZEL, SI WDO SW (INCLS 17) (PEWTER/NEUTRAL) (USED W/WOOD HANDLE)
89038788 BEZEL, SI WDO SW (INCLS 17) (PEWTER/GRAY) (USED W/WOOD HANDLE)
89038790 BEZEL, SI WDO SW (INCLS 17) (NEUTRAL) (USED W/PLASTIC HANDLE)
89038791 BEZEL, SI WDO SW (INCLS 17) (GRAY)
89038887 BEZEL, SI WDO SW (INCLS 17) (NEUTRAL)
10363778 SWITCH, SI WDO (MAS) (EBONY) (LOCK/UNLOCK, TRUNK REL, MEMORY, OSRV MIRROR)
10363780 SWITCH, SI WDO (MAS) (EBONY)
25749090 SWITCH, D/SEAT ADJR MEMORY (EBONY)
11519032 RETAINER, PUSH IN, 19.5X28.4X1.8, FITS HOLE 9.1, ACETAL, BLK (FRT S/D T/PNL) [ФИКСАТОР ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ]
25752613 SWITCH, DR LK (EBONY)
25752963 BEZEL, FRT S/D I/S HDL (EBONY) [РАМКА РУЧКИ ДВЕРИ]
89038827 GRILLE, RDO FRT SPKR (NEUTRAL)
89038828 GRILLE, RDO FRT SPKR (GRAY)
89038829 GRILLE, RDO FRT SPKR (EBONY)
89038836 COMPARTMENT, FRT S/D (NEUTRAL)
89038837 COMPARTMENT, FRT S/D (PEWTER)
89038838 COMPARTMENT, FRT S/D (EBONY)
88983942 HANDLE, FRT S/D PULL (EBONY) (MONO-TONE W/O WOOD) (КРАСКАED) (HANDLE & CAP COMBINED)
89038778 HANDLE, FRT S/D PULL (NEUTRAL) (BURL WALNUT WOOD HANDLE)
89038779 HANDLE, FRT S/D PULL (GRAY) (BURL WALNUT WOOD HANDLE)
89038781 HANDLE, FRT S/D PULL (NEUTRAL) (КРАСКАED)
89038782 HANDLE, FRT S/D PULL (GRAY) (КРАСКАED)
89040111 HANDLE, FRT S/D PULL (EBONY) (BURL WALNUT WOOD HANDLE)
89038831 POCKET, FRT S/D MAP (NEUTRAL)
89038832 POCKET, FRT S/D MAP (GRAY)
89038833 POCKET, FRT S/D MAP (EBONY)
89038834 LINER, FRT S/D PULL CUP
12482519 ЛАМПА, CTSY (IN DOOR)
25727743 COVER, FRT S/D T/PNL (GRAY)
25727745 COVER, FRT S/D T/PNL (NEUTRAL) [ЗАГЛУШКА ОТДЕЛКИ ДВЕРИ]
25748814 COVER, FRT S/D T/PNL (EBONY) [ЗАГЛУШКА ОТДЕЛКИ ДВЕРИ]
11519031 RETAINER, PUSH IN, 19.5X26.1X1.8, ACETAL, NATURAL, FOAM SEALER (FRT S/D T/PNL) [ФИКСАТОР ОБШИВКИ ДВЕРИ]
88952741 BRACKET, FRT S/D PULL HDL
88952714 BEZEL, FRT S/D LKG ROD P/BUT (GRAY)
88952716 BEZEL, FRT S/D LKG ROD P/BUT (NEUTRAL)
88983938 BEZEL, FRT S/D LKG ROD P/BUT (EBONY) (SATIN CHROME PULL CAP)
25751121 KNOB, FRT S/D LKG ROD (GRAY) [КНОПКА]
25751122 KNOB, FRT S/D LKG ROD (NEUTRAL) [КНОПКА]
25751335 KNOB, FRT S/D LKG ROD (EBONY) [КНОПКА]
89042150 TRIM, FRT S/D (INCLS 7, 28, 31) (NEUTRAL)
89042151 TRIM, FRT S/D (INCLS 7, 28, 31) (GRAY)
89042152 TRIM, FRT S/D (INCLS 7, 28, 31) (EBONY)
(6E14-028) - 2004-2006 E ОБЛИЦОВКА ПЕРЕДНЕЙ ПАССАЖИРСКОЙ ДВЕРИ
25718631 DEFLECTOR, FRT S/D WAT
88952742 BRACKET, FRT S/D PULL HDL
89038855 LINER, FRT S/D PULL CUP
89038848 POCKET, FRT S/D MAP (NEUTRAL)
89038849 POCKET, FRT S/D MAP (GRAY)
89038850 POCKET, FRT S/D MAP (EBONY)
89038852 COMPARTMENT, FRT S/D (NEUTRAL)
89038853 COMPARTMENT, FRT S/D (PEWTER) [ЛОТОК ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ]
89038854 COMPARTMENT, FRT S/D (EBONY)
89038844 GRILLE, RDO FRT SPKR (NEUTRAL)
teamcadillac.ru
89038845 GRILLE, RDO FRT SPKR (GRAY)
89038846 GRILLE, RDO FRT SPKR (EBONY)
25752962 BEZEL, FRT S/D I/S HDL (EBONY) [ГНЕЗДО]
25750263 SWITCH, SI WDO (EBONY) (FRT) [ПЕРЕКЛЮЧАТЕЛЬ В СБОРЕ]
88983972 BEZEL, SI WDO SW (INCLS 19) (EBONY)
88983974 BEZEL, SI WDO SW (INCLS 19) (EBONY)
88983975 BEZEL, SI WDO SW (INCLS 19) (EBONY) (MONOTONE W/O WOOD) (W/FOLD & MEMORY) (W/PLASTIC HANDLE)
88983976 BEZEL, SI WDO SW (INCLS 19) (EBONY) (USED W/WOOD HANDLE)
89038787 BEZEL, SI WDO SW (INCLS 19) (PEWTER/NEUTRAL) (USED W/WOOD HANDLE)
89038788 BEZEL, SI WDO SW (INCLS 19) (PEWTER/GRAY) (USED W/WOOD HANDLE)
89038790 BEZEL, SI WDO SW (INCLS 19) (NEUTRAL) (USED W/PLASTIC HANDLE)
89038791 BEZEL, SI WDO SW (INCLS 19) (GRAY)
89038793 BEZEL, SI WDO SW (INCLS 19) (NEUTRAL) (USED W/PLASTIC HANDLE)
89038794 BEZEL, SI WDO SW (INCLS 19) (GRAY) (USED W/PLASTIC HANDLE)
89038886 BEZEL, SI WDO SW (INCLS 19) (GRAY)
89038887 BEZEL, SI WDO SW (INCLS 19) (NEUTRAL)
89038825 PANEL, FRT S/D UPR FRT TR (INCLS 23-25)
89038841 TRIM, FRT S/D (INCLS 15, 26, 27, 33) (GRAY)
89042154 TRIM, FRT S/D (INCLS 15, 26, 27, 33) (NEUTRAL)
89042156 TRIM, FRT S/D (INCLS 15, 26, 27, 33) (EBONY)
25759728 HANDLE, FRT S/D I/S (HIGH LUSTER)
(6E14-029) - 2004-2006 E ОТДЕЛКА/ЗАДНЯЯ ДВЕРЬ
25718634 DEFLECTOR, RR S/D WAT
25718635 DEFLECTOR, RR S/D WAT
25722935 PLATE, RR S/D PULL HDL HNGR
25816341 PLATE, RR S/D PULL HDL HNGR
03530297 ГАЙКА, HFH, M6X1, 5.85THK, 14.2 O.D., 10, ZOR (RR S/D PULL HDL HNGR PLT)
03907444 ГАЙКА, PUSH IN, SQUARE, UN THD, M9.5 SQ HOLE, NYLON (RR S/D I/S HDL)
11509231 SCREW, RD HD C/R TAP, M4.2X1.41X13.0, GM6010M STL, GM813M NICKEL ORGANIC (ЧАСТЬ OF 16) [ВИНТ М6Х12]
25746684 HARNESS, RR S/D WRG (FRT & RR DRS)
25746685 HARNESS, RR S/D WRG (FRT & RR DRS)
88952742 BRACKET, RR S/D PULL HDL (14.691)
03539184 БОЛТ, RR S/D PULL HDL HNGR PLT (ATTACH TO HNGR PLT ASM) (14.683)
25759728 HANDLE, RR S/D I/S (HIGH LUSTER)
25759729 HANDLE, RR S/D I/S (HIGH LUSTER) [РУЧКА]
12337828 SCREW, HEX W/FLAT WA, TAP, M6.3X1.81X20, 13.2 O.D., AB PT, STL, PZ0R (RR S/D I/S HDL)
88952714 BEZEL, RR S/D LKG ROD P/BUT (GRAY)
88983938 BEZEL, RR S/D LKG ROD P/BUT (EBONY) (SATIN CHROME PULL CAP)
25751121 KNOB, RR S/D LKG ROD (GRAY) [КНОПКА]
25751122 KNOB, RR S/D LKG ROD (NEUTRAL) [КНОПКА]
25751335 KNOB, RR S/D LKG ROD (EBONY) [КНОПКА]
11519031 RETAINER, PUSH IN, 19.5X26.1X1.8, ACETAL, NATURAL, FOAM SEALER (RR S/D T/PNL) [ФИКСАТОР ОБШИВКИ ДВЕРИ]
89038796 TRIM, RR S/D (INCLS 4, 6, 24, 25) (NEUTRAL)
teamcadillac.ru
89038797 TRIM, RR S/D (INCLS 4, 6, 24, 25) (GRAY)
89038798 TRIM, RR S/D (INCLS 4, 6, 24, 25) (EBONY)
89038800 TRIM, RR S/D (INCLS 4, 6, 24, 25) (NEUTRAL)
89038801 TRIM, RR S/D (INCLS 4, 6, 24, 25) (GRAY)
89038802 TRIM, RR S/D (INCLS 4, 6, 24, 25) (EBONY)
89038811 TRIM, RR S/D (INCLS 4, 6, 24, 25) (NEUTRAL)
89038812 TRIM, RR S/D (INCLS 4, 6, 24, 25) (GRAY)
89038813 TRIM, RR S/D (INCLS 4, 6, 24, 25) (EBONY)
89038815 TRIM, RR S/D (INCLS 4, 6, 24, 25) (NEUTRAL)
89038816 TRIM, RR S/D (INCLS 4, 6, 24, 25) (GRAY)
89038817 TRIM, RR S/D (INCLS 4, 6, 24, 25) (EBONY)
89038804 GRILLE, RDO RR S/D SPKR
89038805 GRILLE, RDO RR S/D SPKR
89038806 GRILLE, RDO RR S/D SPKR
89038857 GRILLE, RDO RR S/D SPKR
89038858 GRILLE, RDO RR S/D SPKR
89038859 GRILLE, RDO RR S/D SPKR
88983942 HANDLE, RR S/D PULL (EBONY) (MONO-TONE W/O WOOD) (КРАСКАED) (HANDLE & CAP COMBINED) (14.691)
89038778 HANDLE, RR S/D PULL (NEUTRAL) (BURL WALNUT WOOD HANDLE) (14.691)
89038779 HANDLE, RR S/D PULL (GRAY) (BURL WALNUT WOOD HANDLE) (14.691)
89038781 HANDLE, RR S/D PULL (NEUTRAL) (КРАСКАED) (14.691)
89038782 HANDLE, RR S/D PULL (GRAY) (КРАСКАED) (14.691)
89040111 HANDLE, RR S/D PULL (EBONY) (BURL WALNUT WOOD HANDLE) (14.691)
89041933 HANDLE, RR S/D PULL (EBONY) (W/FAUX HYBRID WOOD INSERTS) (14.691)
25752964 BEZEL, RR S/D I/S HDL (EBONY)
25752965 BEZEL, RR S/D I/S HDL (EBONY)
15215743 SPEAKER, RDO W/S SI G/MLDG (LH & RH) (ACDelco #15215743)
15215744 SPEAKER, RDO W/S SI G/MLDG (LH & RH) (W/O GRILLE) (ACDelco #15215744)
25750264 SWITCH, SI WDO (EBONY) (RR) [ВЫКЛЮЧАТЕЛЬ]
88983977 PLATE, RR S/D ACSRY SW MT (INCLS 21) (EBONY)
88983978 PLATE, RR S/D ACSRY SW MT (INCLS 21) (EBONY)
89038775 PLATE, RR S/D ACSRY SW MT (INCLS 21) (NEUTRAL)
89038776 PLATE, RR S/D ACSRY SW MT (INCLS 21) (GRAY)
89038784 PLATE, RR S/D ACSRY SW MT (INCLS 21) (NEUTRAL)
89038785 PLATE, RR S/D ACSRY SW MT (INCLS 21) (GRAY)
25727743 COVER, RR S/D T/PNL (GRAY) (14.685)
25727745 COVER, RR S/D T/PNL (NEUTRAL) (14.685) [ЗАГЛУШКА ОТДЕЛКИ ДВЕРИ]
25748814 COVER, RR S/D T/PNL (EBONY) (14.685) [ЗАГЛУШКА ОТДЕЛКИ ДВЕРИ]
11519032 RETAINER, PUSH IN, 19.5X28.4X1.8, FITS HOLE 9.1, ACETAL, BLK (RR S/D T/PNL) [ФИКСАТОР ВНУТРЕННЕЙ ПАНЕЛИ ДВЕРИ]
25762304 ПЕПЕЛЬНИЦА, RR S/D (GRAY)
25762306 ПЕПЕЛЬНИЦА, RR S/D (NEUTRAL)
25762307 ПЕПЕЛЬНИЦА, RR S/D (EBONY)
11516665 SCREW, OVAL CNTSNK W/WA, SELF TAP, M4.2X1.41X20, 9.45 O.D., 1010M, NZ (RR S/D ПЕПЕЛЬНИЦА)
(6E14-030) - 2004-2009 E РЕМНИ БЕЗОПАСНОСТИ-ПЕРЕДНИЕ
10369728 BELT, D/SEAT (RETR SI) (GRAY)
10369729 BELT, D/SEAT (RETR SI) (NEUTRAL)
10369730 BELT, D/SEAT (RETR SI) (EBONY)
10369737 BELT, P/SEAT (RETR SI) (GRAY)
10369738 BELT, P/SEAT (RETR SI) (NEUTRAL)
10369739 BELT, P/SEAT (RETR SI) (EBONY)
teamcadillac.ru
88952474 BELT KIT, D/SEAT (RETR SI) (GRAY)
88952476 BELT KIT, D/SEAT (RETR SI) (NEUTRAL)
88952534 BELT KIT, P/SEAT (RETR SI) (GRAY)
88952536 BELT KIT, P/SEAT (RETR SI) (NEUTRAL)
88957483 BELT KIT, D/SEAT (RETR SI) (EBONY)
88957484 BELT KIT, P/SEAT (RETR SI) (EBONY)
11517996 ГАЙКА, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (P/SEAT BELT (RETR SI)) [ГАЙКА М10]
25604879 ГАЙКА, D/SEAT BELT (RETR SI) (SPL W/10X1.5 THREAD) (W/SILENCER (PLASTIC)ATTACHED)
11516077 ГАЙКА, HFH, M10X1.5, 11.7THK, 21.5 O.D., 10, 7111M (P/SEAT BELT (RETR SI))
10383803 BELT, D/SEAT (BKL SI) (GRAY) (FLAMMABLE SOLID)
10383811 BELT, P/SEAT (BKL SI) (GRAY)
10383812 BELT, P/SEAT (BKL SI) (EBONY)
10383813 BELT, P/SEAT (BKL SI) (NEUTRAL)
15144611 BELT, D/SEAT (BKL SI) (GRAY)
15144612 BELT, D/SEAT (BKL SI) (EBONY)
15144613 BELT, D/SEAT (BKL SI) (NEUTRAL)
89024400 BELT KIT, D/SEAT (BKL SI) (GRAY)
89024401 BELT KIT, D/SEAT (BKL SI) (EBONY)
89024402 BELT KIT, D/SEAT (BKL SI) (NEUTRAL)
89026033 BELT KIT, P/SEAT (BKL SI) (GRAY)
89026034 BELT KIT, P/SEAT (BKL SI) (EBONY)
89026035 BELT KIT, P/SEAT (BKL SI) (NEUTRAL)
12453517 STOP KIT, BELT LAT (RETR SI) (NEUTRAL)
12475408 STOP KIT, BELT LAT (RETR SI) (GRAY) (16.714)
19121446 STOP KIT, BELT LAT (RETR SI) (EBONY)
(6E14-031) - 2004-2009 E ЗАДНИЕ РЕМНИ БЕЗОПАСНОСТИ
10388611 BELT, R/SEAT (RETR SI) (INCLS 2, 3) (GRAY)
10388612 BELT, R/SEAT (RETR SI) (INCLS 2, 3) (NEUTRAL)
15830272 BELT, R/SEAT (RETR SI) (INCLS 2, 3) (EBONY)
89022857 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 3) (GRAY)
89022858 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 3) (NEUTRAL)
89022859 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 3) (EBONY)
11609257 БОЛТ, R/SEAT BELT (RETR SI) (M12X1.75X34) (8.907) [БОЛТ]
10388617 BELT, R/SEAT (RETR SI) (INCLS 2, 3) (EBONY)
25768095 BELT, R/SEAT (RETR SI) (INCLS 2, 3) (NEUTRAL)
25808636 BELT, R/SEAT (RETR SI) (INCLS 2, 3) (GRAY)
89022860 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 3) (GRAY)
89022861 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 3) (NEUTRAL)
89022862 BELT KIT, R/SEAT (RETR SI) (INCLS 2, 3) (EBONY)
11562368 БОЛТ, R/SEAT BELT (RETR SI) (M12X1.75X35.75) (16.714)
11609257 БОЛТ, R/SEAT #2 BELT (BKL SI) (M12X1.75X34) (8.907) [БОЛТ]
11516078 ГАЙКА, R/SEAT BELT (RETR SI) (CTR) (M12X1.75X18) (8.917) [ГАЙКА]
88993060 БОЛТ, R/SEAT BELT (LAT SI) (M10X1.5X28, 20 OD) (40% BK LATCH MTG)
88957462 BELT KIT, R/SEAT (BKL SI) (GRAY)
88957463 BELT KIT, R/SEAT (BKL SI) (NEUTRAL)
88957464 BELT KIT, R/SEAT (BKL SI) (EBONY)
11517996 ГАЙКА, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (R/SEAT BELT (BKL SI)) (ACDelco #11517996) [ГАЙКА М10]
25766446 COVER, CHILD ST TOP STRP BRKT ACC OPG (GRAY) (USED FOR BOTH FRT & RR SEATS)
25766447 COVER, CHILD ST TOP STRP BRKT ACC OPG (EBONY) (USED FOR BOTH FRT & RR SEATS)
25766448 COVER, CHILD ST TOP STRP BRKT ACC OPG (NEUTRAL) (USED FOR BOTH FRT & RR SEATS)
11609257 БОЛТ, PAN HD, TORX, M12X1.75X34, 9.8 STEEL, GMW3179 (CHILD ST TOP STRP BRKT) (8.907) [БОЛТ]
25766444 BRACKET, CHILD ST TOP STRP
15224766 BELT, R/SEAT CTR (RETR SI) (EBONY)
15224767 BELT, R/SEAT CTR (RETR SI) (NEUTRAL)
19178133 BELT KIT, R/SEAT CTR (RETR SI) (GRAY)
19178134 BELT KIT, R/SEAT CTR (RETR SI) (EBONY)
25833946 BELT, R/SEAT CTR (RETR SI) (GRAY)
88957469 BELT KIT, R/SEAT CTR (RETR SI) (NEUTRAL)
teamcadillac.ru
11516078 ГАЙКА, HFH, M12X1.75, 14THK, 25 O.D., 10, PZOR (CHILD ST RST SYS BELT BRKT) [ГАЙКА]
88957465 BELT KIT, R/SEAT (BKL SI) (INCLS 10, 12) (GRAY) (USED FOR BOTH LH & CTR POSITIONS)
88957466 BELT KIT, R/SEAT (BKL SI) (INCLS 10, 12) (NEUTRAL) (USED FOR BOTH LH & CTR POSITIONS)
88957467 BELT KIT, R/SEAT (BKL SI) (INCLS 10, 12) (EBONY) (USED FOR BOTH LH & CTR POSITIONS) [РЕМЕНЬ]
(6E14-032) - 2004-2009 E ЗАДНИЕ РЕМНИ БЕЗОПАСНОСТИ #2 (AM0)
21997301 BELT, R/SEAT #2 (RETR SI) (INCLS 4-7) (GRAY)
21997306 BELT, R/SEAT #2 (RETR SI) (INCLS 4-7) (NEUTRAL)
25768073 BELT, R/SEAT #2 (RETR SI) (INCLS 4-7) (GRAY)
25768076 BELT, R/SEAT #2 (RETR SI) (INCLS 4-7) (NEUTRAL)
25768080 BELT, R/SEAT #2 (RETR SI) (INCLS 4-7) (EBONY)
25768081 BELT, R/SEAT #2 (RETR SI) (INCLS 4-7) (EBONY)
25808645 BELT, R/SEAT #2 (RETR SI) (INCLS 4-7) (EBONY)
89025629 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 4-7) (GRAY)
teamcadillac.ru
89025630 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 4-7) (NEUTRAL)
89025631 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 4-7) (EBONY)
89025633 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 4-7) (GRAY)
89025634 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 4-7) (NEUTRAL)
89025635 BELT KIT, R/SEAT #2 (RETR SI) (INCLS 4-7) (EBONY)
89023039 BELT KIT, R/SEAT #2 (BKL SI) (GRAY)
89023040 BELT KIT, R/SEAT #2 (BKL SI) (EBONY)
89023041 BELT KIT, R/SEAT #2 (BKL SI) (NEUTRAL)
12453517 STOP KIT, BELT LAT (RETR SI) (ЧАСТЬ OF 1) (NEUTRAL)
12475408 STOP KIT, BELT LAT (RETR SI) (ЧАСТЬ OF 1) (GRAY) (16.714)
19121446 STOP KIT, BELT LAT (RETR SI) (ЧАСТЬ OF 1) (EBONY)
(6E14-033) - 2004-2005 E INFLATABLE RESTRAINT SYSTEM
15894730 МОДУЛЬ, RF S/RL INFL RST
15894731 МОДУЛЬ, RF S/RL INFL RST
11609989 БОЛТ, HEX W/FLAT WASHER, M6X1X25, 15 THD, 17 OD, 6202M STL, GMW3200, TAPTITE (I/P INFL RST MDL) [БОЛТ М6]
25756980 МОДУЛЬ, I/P INFL RST
11610115 БОЛТ, F/END INFL RST DISCRM SEN (M6X1X33, 17 OD) (8.900)
25763451 SENSOR, F/END INFL RST DISCRM
11609385 ГАЙКА, U-TYPE, M6X1, 29.5 LEN, 12.5 WID, 19.5 CEN-END, 1050, GMW3359 (INFL RST F/END DISCRM SEN) [ГАЙКА М 6]
15247500 МОДУЛЬ, INFL RST SEN & DIAGN [МОДУЛЬ В СБОРЕ]
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (INFL RST DIAGN ENGY RESV MDL) [ГАЙКА М6]
11588337 БОЛТ, HEX W/FL WA, M6X1X20, 9 THD, 17 OD, 6202M, GMW3200, TAP, DOG PT. (INFL RST CONT MDL) [БОЛТ М8]
11609411 ГАЙКА, FRT S/D SI IMP INFL RST MDL (6 X 1, 5.07THK) (HEX-CHROME FREE FINISH) (8.917) [ГАЙКА М6]
25763450 SENSOR, INFL RST SI IMP
11609411 ГАЙКА, INFL RST RF S/RL MDL (6 X 1, 5.07THK) (HEX-CHROME FREE FINISH) (8.917) [ГАЙКА М6]
15814818 МОДУЛЬ, STRG WHL INFL RST (EBONY) (14.865)
teamcadillac.ru
(6E14-035) - 2004-2009 EB СИДЕНЬЕ В СБОРЕ/DRIVER (EXC POWER LUMBAR AL2)
88898335 PAD, D/SEAT BK CUSH
11517996 ГАЙКА, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (D/SEAT BELT (RETR SI)) [ГАЙКА М10]
11517068 ГАЙКА, INFL RST D/SEAT SI MDL (M6X1X3, 14.2 O.D.) (8.917)
88898456 COVER, D/SEAT OTR RECL FIN (INCLS 27) (NEUTRAL) (POWER)
88993344 COVER, D/SEAT OTR RECL FIN (INCLS 27) (EBONY) (POWER)
88994752 COVER, D/SEAT OTR RECL FIN (INCLS 27) (GRAY) (POWER)
88995057 ADJUSTER, D/SEAT (СМ. ГРУППУ 11.000 "ADJUSTER ASM/СИДЕНЬЕ ВОДИТЕЛЯ" ДЛЯ ДЕТАЛЬНОГО ПРОСМОТРА) (INCLS RECL)
teamcadillac.ru
11609257 БОЛТ, D/SEAT ADJR (W/BELT) (M12X1.75X34) (8.907) [БОЛТ]
88895379 BEZEL, D/SEAT BELT OPG (BKL SI) (NEUTRAL)
88895381 BEZEL, D/SEAT BELT OPG (BKL SI) (GRAY)
88992617 BEZEL, D/SEAT BELT OPG (BKL SI) (EBONY) (INNER)
88849036 РАМА, D/SEAT BK CUSH (INCLS 53) (W/SUSPENSION)
88992985 HARNESS, D/SEAT WRG (INCLS 30)
88895457 РАМА, D/SEAT CUSH (INCLS 45) (PWR)
(TX16-004) - 2004-2009 E РЕМНИ БЕЗОПАСНОСТИ (EXTENSION KIT)
12533459 EXTENSION KIT, F/SEAT BELT (BLACK) (TYPE AB) (9") (REFER TO BULLETIN ON SEAT BELT EXTDRS FOR DETAILED INFO)
teamcadillac.ru
12533460 EXTENSION KIT, F/SEAT BELT (BLACK) (15") (TYPE AB) (REFER TO GMSPO INFORMATION BULLETIN ON SEAT BELT EXTENDERS FOR DETAILED INFORMATION)
22730279 EXTENSION KIT, R/SEAT BELT (BLACK) (15") (REFER TO GMSPO INFORMATION BULLETIN ON SEAT BELT EXTENDERS FOR DETAILED INFORMATION)
22730280 EXTENSION KIT, R/SEAT BELT (BLACK) (9") (REFER TO GMSPO INFORMATION BULLETIN ON SEAT BELT EXTENDERS FOR DETAILED INFORMATION)
15 - ЗАДНЕЕ СИДЕНЬЕ - ПОКРЫТИЕ
(6E15-007) - 2004-2009 E ЗАДНЕЕ СИДЕНЬЕ #2 BACK(AM0)
88898474 PANEL, R/SEAT BK CUSH FIL (INCLS 2, 5-7, 36-45) (NEUTRAL) (#2) (W/VINYL STRAP)
88898475 PANEL, R/SEAT BK CUSH FIL (INCLS 2, 5-7, 36-45) (EBONY) (#2) (W/VINYL STRAP)
88898476 PANEL, R/SEAT BK CUSH FIL (INCLS 2, 5-7, 36-45) (GRAY) (#2) (W/VINYL STRAP)
11509428 БОЛТ/SCREW, HEX, W/FLAT WA, M4.2X1.4X13, 12.3 O.D., BHL PT, 6010M, NO (ЧАСТЬ OF 1) (8.977)
88898388 SENSOR, R/SEAT #2 PASS/CARGO PRESENCE
11509428 БОЛТ/SCREW, HEX, W/FLAT WA, M4.2X1.4X13, 12.3 O.D., BHL PT, 6010M, NO (R/SEAT #2) (8.977)
19124438 RETAINER, R/SEAT BK CUSH (ЧАСТЬ OF 1) (GRAY) (#2)
19124439 RETAINER, R/SEAT BK CUSH (ЧАСТЬ OF 1) (EBONY) (#2)
19124441 RETAINER, R/SEAT BK CUSH (ЧАСТЬ OF 1) (NEUTRAL) (#2)
88898468 RETAINER, R/SEAT BK SI CUSH CVR (ЧАСТЬ OF 1) (NEUTRAL) (11.628)
88898469 RETAINER, R/SEAT BK SI CUSH CVR (ЧАСТЬ OF 1) (EBONY) (11.628)
88898470 RETAINER, R/SEAT BK SI CUSH CVR (ЧАСТЬ OF 1) (GRAY) (11.628)
88898445 SWITCH, R/SEAT #2 FLDG ACTR (ЧАСТЬ OF 1) (EBONY) (SEAT POSITION)
24503695 БОЛТ, HEX W/CON WA, M8X1.25X30, 25THD, 17 O.D., 9.8, PO (R/SEAT RECL)
88898389 РАМА, R/SEAT #2 BK CUSH
88993063 БОЛТ, R/SEAT (8-18X0.5, 0.44 OD) (CONTROL HEADS & BOTTOM PANEL MTG)
88898297 MOTOR, R/SEAT #2 BK PIV ACTR (180 DEGREE MOTOR) (LOCATED IN BK CUSHION ASM) (ACDelco #88898297)
88993014 INSULATOR, R/SEAT #2 BK PIV MTR MT
88992197 SHAFT, R/SEAT #2 BK PIV
25773273 SWITCH, R/SEAT #2 FLDG ACTR (ON BODY SIDE PANEL) (EBONY)
11509428 БОЛТ/SCREW, HEX, W/FLAT WA, M4.2X1.4X13, 12.3 O.D., BHL PT, 6010M, NO (PLASTICS TO РАМА) (8.977)
88898414 COVER, R/SEAT RECL INR FIN (NEUTRAL)
88898416 COVER, R/SEAT RECL INR FIN (GRAY)
88992535 COVER, R/SEAT RECL INR FIN (EBONY)
88898301 RECLINER, R/SEAT (#2)
11516941 БОЛТ, HEX HD & CONICAL SPR WA, M10X1.5X20 (R/SEAT RECL)
88898422 COVER, R/SEAT RECL OTR FIN (NEUTRAL) (UPPER)
88898424 COVER, R/SEAT RECL OTR FIN (GRAY) (UPPER) (#2)
88992533 COVER, R/SEAT RECL OTR FIN (EBONY) (UPPER) (#2)
88992526 SUPPORT, R/SEAT
88993013 БОЛТ, R/SEAT CUSH FRM
88992525 BUMPER, R/SEAT BK CUSH LAT [ВТУЛКА КАРКАСА СИДЕНЬЯ]
88898313 WIRE, R/SEAT #2 BK CUSH PAD
88898418 COVER, R/SEAT RECL OTR FIN (NEUTRAL)
88898420 COVER, R/SEAT RECL OTR FIN (GRAY) (#2)
88992534 COVER, R/SEAT RECL OTR FIN (EBONY) (#2)
88898300 RECLINER, R/SEAT (#2)
88898410 COVER, R/SEAT BK CUSH OTR (NEUTRAL) (11.620)
88898412 COVER, R/SEAT RECL INR FIN (GRAY)
88992536 COVER, R/SEAT RECL INR FIN (EBONY)
88898426 COVER, R/SEAT BK CUSH CTR PIV SUPT (NEUTRAL)
teamcadillac.ru
88898427 COVER, R/SEAT BK CUSH CTR PIV SUPT (EBONY)
88898428 COVER, R/SEAT BK CUSH CTR PIV SUPT (GRAY)
88992530 BEARING, R/SEAT #2 BK PIV SHF (12MM)
88897995 COVER, R/SEAT #2 BK CUSH (GRAY)
88994518 COVER, R/SEAT #2 BK CUSH (NEUTRAL)
88994520 COVER, R/SEAT #2 BK CUSH (EBONY)
88994526 COVER, R/SEAT #2 BK CUSH (NEUTRAL)
88994527 COVER, R/SEAT #2 BK CUSH (GRAY)
88994528 COVER, R/SEAT #2 BK CUSH (EBONY)
88898294 PAD, R/SEAT #2 BK CUSH (W/HEAD REST HOLES)
88993119 COVER, R/SEAT #2 H/RST (ЧАСТЬ OF 34) (EBONY)
88993121 COVER, R/SEAT #2 H/RST (ЧАСТЬ OF 34) (GRAY)
88993150 RESTRAINT, R/SEAT #2 HD (INCLS 33) (NEUTRAL) (W/COVER)
88993151 RESTRAINT, R/SEAT #2 HD (INCLS 33) (EBONY) (W/COVER)
88993152 RESTRAINT, R/SEAT #2 HD (INCLS 33) (GRAY) (W/COVER)
88993365 GUIDE, R/SEAT #2 H/RST (GRAY) (W/BUTTON)
88993366 GUIDE, R/SEAT #2 H/RST (NEUTRAL) (W/BUTTON)
88993367 GUIDE, R/SEAT #2 H/RST (EBONY) (W/BUTTON)
88993667 GUIDE, R/SEAT #2 H/RST (GRAY) (W/O BUTTON)
88993668 GUIDE, R/SEAT #2 H/RST (EBONY) (W/O BUTTON)
88993669 GUIDE, R/SEAT #2 H/RST (NEUTRAL) (W/O BUTTON)
19124501 STRAP, R/SEAT #2 PULL (ЧАСТЬ OF 1) (NEUTRAL) (W/WEBBED STRAP) (11.629)
19124502 STRAP, R/SEAT #2 PULL (ЧАСТЬ OF 1) (GRAY) (W/WEBBED STRAP) (11.629)
19124503 STRAP, R/SEAT #2 PULL (ЧАСТЬ OF 1) (EBONY) (W/WEBBED STRAP) (11.629)
19124432 BEZEL KIT, R/SEAT #2 BK CUSH LAT REL HDL (INCLS 40, 41) (ЧАСТЬ OF 1) (EBONY)
19124433 BEZEL KIT, R/SEAT #2 BK CUSH LAT REL HDL (INCLS 40, 41) (ЧАСТЬ OF 1) (GRAY)
19124434 BEZEL KIT, R/SEAT #2 BK CUSH LAT REL HDL (INCLS 40, 41) (ЧАСТЬ OF 1) (CASHMERE)
19124521 BEZEL KIT, R/SEAT #2 BK CUSH LAT REL HDL (INCLS 40, 41) (ЧАСТЬ OF 1) (NEUTRAL)
88994884 HANDLE, R/SEAT #2 PULL (ЧАСТЬ OF 1) (NEUTRAL)
88994885 HANDLE, R/SEAT #2 PULL (ЧАСТЬ OF 1) (EBONY)
88994886 HANDLE, R/SEAT #2 PULL (ЧАСТЬ OF 1) (GRAY)
25769663 LABEL, RR CTR ST SAFETY INFO (ЧАСТЬ OF 1)
(6E15-008) - 2004-2005 E ПОКРЫТИЕ ПОЛА (D7E)
25762814 BARRIER, DA PNL INTR SND
20030401 RETAINER, DA PNL SND BARR (BLACK)
10009923 ГАЙКА, БОЛТ RETAINING ПРУЖИНА, M8X1.25, 25 O.D., ZOR (DA PNL SND BARR)
25766135 ПОКРЫТИЕ, F/FLR PNL (GRAY)
25766136 ПОКРЫТИЕ, F/FLR PNL (GRAY)
25766137 ПОКРЫТИЕ, F/FLR PNL (GRAY)
25766138 ПОКРЫТИЕ, F/FLR PNL (GRAY)
25766139 ПОКРЫТИЕ, F/FLR PNL (NEUTRAL)
25766140 ПОКРЫТИЕ, F/FLR PNL (NEUTRAL)
25766141 ПОКРЫТИЕ, F/FLR PNL (NEUTRAL)
25766142 ПОКРЫТИЕ, F/FLR PNL (NEUTRAL)
25766143 ПОКРЫТИЕ, F/FLR PNL (EBONY)
25766144 ПОКРЫТИЕ, F/FLR PNL (EBONY)
25766145 ПОКРЫТИЕ, F/FLR PNL (EBONY)
25766146 ПОКРЫТИЕ, F/FLR PNL (EBONY)
25733062 BARRIER, F/FLR PNL F/FLR CNSL SND
25734207 BARRIER, F/FLR PNL F/FLR CNSL SND
25735478 MAT PKG, FRONT & ЗАДНИЙ ПОКРЫТИЕ (GRAY) (3.130 KGS) (NO LOGO) (15.286) [КОМПЛЕКТ КОВРИКОВ ПЕРЕДН., ЗАДН.]
25735479 MAT PKG, FRONT & ЗАДНИЙ ПОКРЫТИЕ (GRAY) (2.873 KGS) (NO LOGO) (15.286)
25738164 MAT PKG, FRONT & ЗАДНИЙ ПОКРЫТИЕ (NEUTRAL) (2.873 KGS) (NO LOGO) (15.286)
25739046 MAT PKG, FRONT & ЗАДНИЙ ПОКРЫТИЕ (NEUTRAL) (2.620 KGS) (NO LOGO) (15.286) [КОВРИК]
25748376 MAT PKG, FRONT & ЗАДНИЙ ПОКРЫТИЕ (EBONY) (2.876 KGS) (NO LOGO) (15.286) [КОВРИКИ ПЕРЕДН+ЗАДН]
25748378 MAT PKG, FRONT & ЗАДНИЙ ПОКРЫТИЕ (EBONY) (2.873 KGS) (NO LOGO)
25733073 BARRIER, RR W/H INR PNL SND
20030401 RETAINER, RR W/H INR PNL FRT SND BARR (BLACK) (12.804)
15944188 ПОКРЫТИЕ, LOAD FLR (GRAY)
15944189 ПОКРЫТИЕ, LOAD FLR (EBONY)
25766151 ПОКРЫТИЕ, LOAD FLR (NEUTRAL)
10121502 RETAINER, FITS .250 HOLE, 1.01LG.700-OD NYLON BLACK (FLR RR AIR OTLT DUCT (PUSH ON)) [ПИСТОН КРЕПЛЕНИЯ ОБЛИЦОВКИ БАМПЕРА (NYLON)]
10374313 BARRIER, RR W/H INR PNL SND
11609411 ГАЙКА, HEX W/CON WA, M6X1, 5.7 THK, 16 OD, 9, GMW3200 (R/FLR PNL CPT RET BRKT) [ГАЙКА М6]
25755415 BRACKET, R/FLR PNL CPT RET
teamcadillac.ru
15939897 ПОКРЫТИЕ, R/FLR PNL CTR (EBONY)
15944180 ПОКРЫТИЕ, R/FLR PNL CTR (GRAY)
25766128 ПОКРЫТИЕ, R/FLR PNL CTR (NEUTRAL)
25719080 DUCT, FLR RR AIR OTLT (EXT USED ON LH & RH ENDS)
15908858 PLUG, R/FLR PNL DRN HOLE (38.1 MM)
15908858 PLUG, F/FLR PNL DRN HOLE (38.1 MM)
25784232 INSULATOR, EXH H/SHLD (INCLS 28) (RWD) (12.980)
25964067 INSULATOR, EXH H/SHLD (INCLS 28) [ТЕРМОЗАЩИТНЫЙ ЭКРАН ВЫХЛОПНОЙ ТРУБЫ]
15908858 PLUG, DA HOLE (38.1 MM) (12.980)
25722024 BARRIER, DA PNL INTR SND (TWO PIECE)
21110669 BARRIER, RKR INR PNL SND (35 MM) (ROUND) (12.179)
11518598 PLUG, 45X65X10.6, FITS 30X50 HOLE IN 1MM THK , STL, PL (FLR PNL DRN HOLE)
25762949 SEAL, КОНДИЦИОНЕР EVPR & BLO MDL
(6E15-009) - 2004-2009 E ОТДЕЛКА/QUARTER-RH(AM0)
21996593 PANEL, BODY SI LWR TR (INCLS 2-6, 15-27, 34-41) (GRAY)
21996594 PANEL, BODY SI LWR TR (INCLS 2-6, 15-27, 34-41) (EBONY)
21996595 PANEL, BODY SI LWR TR (INCLS 2-6, 15-27, 34-41) (NEUTRAL)
21994244 HOOK, CONVENIENCE NET SNAP (ЧАСТЬ OF 1)
25773273 SWITCH, R/SEAT #2 FLDG ACTR (ON BODY SIDE PANEL) (ЧАСТЬ OF 1) (EBONY)
25773272 SWITCH, ST RECL (ЧАСТЬ OF 1)
15714276 SCREW, HWH, W/FL WA, SELF TAP, M4.2X1.41X18, 12.5 O.D., 6010M, PS (ЧАСТЬ OF 1) (8.977)
11509231 SCREW, RD HD C/R TAP, M4.2X1.41X13.0, GM6010M STL, GM813M NICKEL ORGANIC (ЧАСТЬ OF 1) [ВИНТ М6Х12]
11517484 БОЛТ-HEX, M6X1X20, 9 THD, 17 OD, 9.8, 6280M, MACH, P-PT (BODY SI RR LWR T/PNL BRKT)
11515755 БОЛТ, HEX, M8X1.25X16, 15 THD, 18 O.D., 10.9, 7114M (ASST HDL BRKT) (T/W 12345493 REPLCS 25534835) [БОЛТ М8Х1.25Х16]
25755417 BRACKET, ASST HDL (QTR TRIM)
25762935 BARRIER, C/PLR INR PNL SND
25762937 BARRIER, QTR INR PNL RR SND
25746641 HARNESS, ST RECL WRG (ELEMENT) (ЧАСТЬ OF 1)
25605716 ГАЙКА, ASST HDL (ЧАСТЬ OF 1) (13.8 X 14.9, 15.3) (U-SHAPED) (8.133)
11609374 БОЛТ-WASHER, M6X1X16, 17 OD, 12 THD, 9.8, GMW3359, 1.47 H-REG FL WA. (ЧАСТЬ OF 1)
25757234 SHADE, LUGG (ЧАСТЬ OF 1) (EBONY)
25757235 SHADE, LUGG (ЧАСТЬ OF 1) (GRAY)
25757236 SHADE, LUGG (ЧАСТЬ OF 1) (NEUTRAL)
25737727 LATCH, BODY SI T/PNL OPG ACC CVR (ЧАСТЬ OF 1) (PEWTER) (10.240)
25737728 ПРУЖИНА, BODY SI T/PNL OPG ACC CVR LAT (ЧАСТЬ OF 1) (10.240)
88957058 LID, CARGO BOX STOW BOX (ЧАСТЬ OF 1) (GRAY)
88957059 LID, CARGO BOX STOW BOX (ЧАСТЬ OF 1) (NEUTRAL)
15187371 RETAINER, ACSRY PWR RCPT (ЧАСТЬ OF 1) (EBONY) (INCLS COVER) [ОКАНТОВКА ГНЕЗДА ПРИКУРИВАТЕЛЯ]
25774623 RECEPTACLE, ACSRY PWR (ЧАСТЬ OF 1) (ACSRY PWR RECEPTACLE ASSEM LABELED 4623) [ГНЕЗДО ПРИКУРИВАТЕЛЯ С КОНТАКТН. ЭЛЕМЕНТ., 12 ВТ]
25625848 BUMPER, BODY SI T/PNL OPG ACC CVR (ЧАСТЬ OF 1) (8.8 DIA X 6.6 H) (10.263)
25764200 BEZEL, CARGO TIE DN LOOP (GRAY) (W/CHILD RESTRAINT)
25764201 BEZEL, CARGO TIE DN LOOP (NEUTRAL) (W/CHILD RESTRAINT)
25764202 BEZEL, CARGO TIE DN LOOP (EBONY) (W/CHILD RESTRAINT) [ЗАГЛУШКА ВНУТРЕННЕЙ ПАНЕЛИ БАГАЖНОГО ОТСЕКА]
25753659 INSULATOR, C/PLR INR PNL (STUFFER-SEAT BELT)
88957050 GRILLE, RDO R/Q TR PNL SPKR (ЧАСТЬ OF 1) (GRAY)
88957051 GRILLE, RDO R/Q TR PNL SPKR (ЧАСТЬ OF 1) (NEUTRAL)
88957052 GRILLE, RDO R/Q TR PNL SPKR (ЧАСТЬ OF 1) (BLACK)
25725191 CLIP, ASST HDL (ЧАСТЬ OF 1) (GREEN) (18X12.5, SAE 1050STL) (CLIP TO HOLD M4.2X1.41 SCREW, PNL RING 0.94-3.5) (14.640) [ФИКСАТОР ПАНЕЛИ КРЫШИ КУЗОВА]
19177898 BEZEL, ST ADJR SW (ЧАСТЬ OF 1) (GRAY) (DUAL SWITCH)
19177899 BEZEL, ST ADJR SW (ЧАСТЬ OF 1) (GRAY) (DUAL SWITCH)
19177900 BEZEL, ST ADJR SW (ЧАСТЬ OF 1) (DUAL)
teamcadillac.ru
19177890 ДЕРЖАТЕЛЬ, BODY SI T/PNL CUP (ЧАСТЬ OF 1) (INCLS 38, 39) (GRAY)
19177891 ДЕРЖАТЕЛЬ, BODY SI T/PNL CUP (ЧАСТЬ OF 1) (INCLS 38, 39) (EBONY)
19177892 ДЕРЖАТЕЛЬ, BODY SI T/PNL CUP (ЧАСТЬ OF 1) (INCLS 38, 39) (NEUTRAL) (FOR 2004 MODEL YEAR VEHICLES W/AMO DLR TO RE-USE CUP & BIN LINER.)
19177894 BEZEL, ST ADJR SW (ЧАСТЬ OF 1) (GRAY) (SINGLE SWITCH)
19177895 BEZEL, ST ADJR SW (ЧАСТЬ OF 1) (GRAY) (SINGLE SWITCH)
19177896 BEZEL, ST ADJR SW (ЧАСТЬ OF 1) (SINGLE)
(6E15-010) - 2004-2009 E ОТДЕЛКА/QUARTER-RH(EXC (AM0))
15221536 PANEL, BODY SI LWR TR (INCLS 4-6, 15-26, 32) (GRAY) (USED ON VEHICLES WITHOUT CUPДЕРЖАТЕЛЬ AND TRAY LINER) (FOR 1ST DES SEE 25764779)
15221537 PANEL, BODY SI LWR TR (INCLS 4-6, 15-26, 32) (EBONY) (USED ON VEHICLES WITHOUT CUPДЕРЖАТЕЛЬ AND TRAY LINER ) (FOR 1ST DES SEE 25764780)
15221538 PANEL, BODY SI LWR TR (INCLS 4-6, 15-26, 32) (NEUTRAL) (USED ON VEHICLES WITHOUT CUPДЕРЖАТЕЛЬ AND TRAY LINER) (FOR 1ST DES SEE 25764774)
25764774 PANEL, BODY SI LWR TR (INCLS 4-6, 15-26, 32) (NEUTRAL) (USED ON VEHICLES WITH CUPДЕРЖАТЕЛЬ AND TRAY LINER) (FOR 2ND DES SEE 15221538)
25764779 PANEL, BODY SI LWR TR (INCLS 4-6, 15-26, 32) (GRAY) (USED ON VEHICLES WITH CUPДЕРЖАТЕЛЬ AND TRAY LINER) (FOR 2ND DES SEE 15221536)
25764780 PANEL, BODY SI LWR TR (INCLS 4-6, 15-26, 32) (EBONY) (USED ON VEHICLES WITH CUPДЕРЖАТЕЛЬ AND TRAY LINER ) (FOR 2ND DES SEE 15221537)
25746640 HARNESS, ST RECL WRG (ELEMENT) (ЧАСТЬ OF 1)
22611883 BUMPER, BODY SI T/PNL OPG ACC CVR (ЧАСТЬ OF 1) (BLACK) (6.6 DIA X 4.7 H) (10.263)
25764200 BEZEL, CARGO TIE DN LOOP (BODY SI RR TRIM PNL) (GRAY) (W/CHILD RESTRAINT)
25764201 BEZEL, CARGO TIE DN LOOP (BODY SI RR TRIM PNL) (NEUTRAL) (W/CHILD RESTRAINT)
25764202 BEZEL, CARGO TIE DN LOOP (BODY SI RR TRIM PNL) (EBONY) (W/CHILD RESTRAINT) [ЗАГЛУШКА ВНУТРЕННЕЙ ПАНЕЛИ БАГАЖНОГО ОТСЕКА]
teamcadillac.ru
11609465 БОЛТ, HWH, M4.2X1.41X18, 12.5 OD, 6010M, PS (ASST HDL) (8.977) [ВИНТ М6]
(6E15-012) - 2004-2006 E COMPARTMENT/ЗАДНИЙ STORAGE
15231991 CONTAINER, CARGO (INCLS 1-4, 7-15) (NEUTRAL)
25833119 CONTAINER, CARGO (INCLS 1-4, 7-15) (GRAY)
25833120 CONTAINER, CARGO (INCLS 1-4, 7-15) (EBONY)
11609257 БОЛТ, PAN HD, TORX, M12X1.75X34, 9.8 STEEL, GMW3179 (CARGO CNTNR) (8.907) [БОЛТ]
teamcadillac.ru
25771208 STRUT, CARGO BOX CVR (ЧАСТЬ OF 5)
15117947 LATCH, R/CMPT FLR STOW COMPT (ЧАСТЬ OF 5) (BLACK) (16.565)
25773277 LATCH, R/CMPT FLR STOW COMPT (ЧАСТЬ OF 5) (GRAY)
25773278 LATCH, R/CMPT FLR STOW COMPT (ЧАСТЬ OF 5) (EBONY)
25773279 LATCH, R/CMPT FLR STOW COMPT (ЧАСТЬ OF 5) (NEUTRAL)
(6E15-013) - 2004-2006 E CARGO NET
teamcadillac.ru
25764203 NET, CARGO [СЕТКА БАГАЖНОГО ОТДЕЛЕНИЯ]
15224105 NET, CONVENIENCE (VERTICAL NET) [СЕТКА]
(6E15-014) - 2004-2005 E ПОКРЫТИЕ ПОЛА (EXC (D7E))
teamcadillac.ru
15944184 ПОКРЫТИЕ, LOAD FLR (INCLS 34-36) (GRAY)
15944185 ПОКРЫТИЕ, LOAD FLR (INCLS 34-36) (EBONY)
15944192 ПОКРЫТИЕ, LOAD FLR (INCLS 34-36) (GRAY)
15944193 ПОКРЫТИЕ, LOAD FLR (INCLS 34-36) (EBONY)
25766150 ПОКРЫТИЕ, LOAD FLR (INCLS 34-36) (NEUTRAL)
25766156 ПОКРЫТИЕ, LOAD FLR (INCLS 34-36) (NEUTRAL)
15117947 LATCH, R/CMPT FLR STOW COMPT (ЧАСТЬ OF 10) (BLACK) (16.565)
25769368 ПОКРЫТИЕ, R/END TR FIN PNL (EBONY)
25769369 ПОКРЫТИЕ, R/END TR FIN PNL (GRAY)
25769370 ПОКРЫТИЕ, R/END TR FIN PNL (NEUTRAL)
(6E15-015) - 2004-2009 E ЗАДНЕЕ СИДЕНЬЕ-CUSHION
88898379 SUPPORT, R/SEAT CUSH PAD WIRE (LH/RH) (OUTBOARD) (*KIT1)
88898380 SUPPORT, R/SEAT CUSH PAD WIRE (CTR) (*KIT1)
88995274 РАМА, R/SEAT CUSH (*KIT1) (11.419)
88992509 CAP, R/SEAT BK CUSH PNL БОЛТ (NEUTRAL) (FLIP & FOLD) (*KIT1)
88993147 CAP, R/SEAT BK CUSH PNL БОЛТ (EBONY) (INNER) (*KIT1)
88993148 CAP, R/SEAT BK CUSH PNL БОЛТ (GRAY) (INNER) (*KIT1)
88994634 COVER, R/SEAT HGE FIN (EBONY) (60% SIDE-OUTER) (*KIT1)
88995147 COVER, R/SEAT HGE FIN (GRAY) (60% SIDE-OUTER) (*KIT1)
88995149 COVER, R/SEAT HGE FIN (NEUTRAL) (60% SIDE-OUTER) (*KIT1)
88994576 COVER, R/SEAT HGE FIN (GRAY) (60% SIDE-INNER) (*KIT1)
88994577 COVER, R/SEAT HGE FIN (EBONY) (60% SIDE-INNER) (*KIT1)
88994578 COVER, R/SEAT HGE FIN (NEUTRAL) (60% SIDE-INNER) (*KIT1)
teamcadillac.ru
16512106 ГАЙКА, R/SEAT BK CUSH PIV SUPT (M4X0.7, 4.85MM THK) (*KIT1) (2.679)
88992359 COVER, R/SEAT HGE FIN (GRAY) (60% SIDE-CTR) (*KIT1)
88992360 COVER, R/SEAT HGE FIN (EBONY) (60% SIDE-CTR) (*KIT1)
88992361 COVER, R/SEAT HGE FIN (NEUTRAL) (60% SIDE-CTR) (*KIT1)
88994579 COVER, R/SEAT HGE FIN (GRAY) (60% SIDE-INNER) (*KIT1)
88994580 COVER, R/SEAT HGE FIN (EBONY) (60% SIDE-INNER) (*KIT1)
88994581 COVER, R/SEAT HGE FIN (NEUTRAL) (60% SIDE-INNER) (*KIT1)
88994564 COVER, R/SEAT HGE FIN (GRAY) (60% SIDE-CTR) (*KIT1)
88994565 COVER, R/SEAT HGE FIN (EBONY) (60% SIDE-CTR) (*KIT1)
88994566 COVER, R/SEAT HGE FIN (NEUTRAL) (CTR) (*KIT1)
11515893 SCREW, RD WA HD, SELF TAP, M4.2X1.4X13, 8.63 O.D., STL, NIOR (R/SEAT CUSH) (*KIT1)
88993131 COVER, R/SEAT HGE FIN (NEUTRAL) (60% SIDE-OUTER) (*KIT1)
88993132 COVER, R/SEAT HGE FIN (EBONY) (60% SIDE-OUTER) (*KIT1)
88994567 COVER, R/SEAT HGE FIN (GRAY) (60% SIDE-OUTER) (*KIT1)
11514598 ГАЙКА, HEX FLANGE, M12X1.75X12, 26 OD, 10, 7111M, (R/SEAT) [ГАЙКА М12]
88994828 ADJUSTER, R/SEAT (INCLS 23, 25, 35, 36) (W/АМОРТИЗАТОР PADS) (DEALER MAY ALSO NEED TO ORDER 88993028 CABLE) (*KIT1)
11517996 ГАЙКА, HFH, M10X1.5, 11.2THK, 21.5 O.D., 7111M (R/SEAT CUSH FRM) (*KIT1) [ГАЙКА М10]
88898360 COVER, R/SEAT ADJR FIN OTR LWR FRT (NEUTRAL) (*KIT1)
88898361 COVER, R/SEAT ADJR FIN OTR LWR FRT (EBONY) (*KIT1)
88898362 COVER, R/SEAT ADJR FIN OTR LWR FRT (GRAY) (*KIT1)
11515776 БОЛТ, HFH, M12X1.75X35, 31 THD, 26.6 OD, 10.9 MAT, 7114M FIN, MACH (R/SEAT) (*KIT1)
88993063 БОЛТ, R/SEAT (8-18X0.5, 0.44 OD) (CONTROL HEADS & BOTTOM PANEL MTG) (*KIT1)
88992995 COVER, R/SEAT LAT FIN (EBONY) (OUTBOARD) (*KIT1)
88993442 COVER, R/SEAT CUSH (EBONY) (UNDERSIDE) (*KIT1)
88992996 COVER, R/SEAT LAT FIN (K1) (EBONY) (INBOARD)
88957465 BELT KIT, R/SEAT (BKL SI) (GRAY) (USED FOR BOTH LH & CTR POSITIONS) (*KIT1)
88957466 BELT KIT, R/SEAT (BKL SI) (NEUTRAL) (USED FOR BOTH LH & CTR POSITIONS) (*KIT1)
88957467 BELT KIT, R/SEAT (BKL SI) (EBONY) (USED FOR BOTH LH & CTR POSITIONS) (*KIT1) [РЕМЕНЬ]
11517996 ГАЙКА, R/SEAT BELT (BKL SI) (M10X1.5, 11.2 THK) (*KIT1) (8.917) [ГАЙКА М10]
88993060 БОЛТ, R/SEAT BELT (LAT SI) (M10X1.5X28, 20 OD) (40% BK LATCH MTG) (*KIT1)
88957462 BELT KIT, R/SEAT (BKL SI) (GRAY) (*KIT1)
88957463 BELT KIT, R/SEAT (BKL SI) (NEUTRAL) (*KIT1)
88957464 BELT KIT, R/SEAT (BKL SI) (EBONY) (*KIT1)
25746134 BRACKET, R/SEAT RR (ПОЛ OUTBOARD) (*KIT1)
25768184 BRACKET, R/SEAT RR (W/WELD STUD ATTACH) (*KIT1)
11609257 БОЛТ, PAN HD, TORX, M12X1.75X34, 9.8 STEEL, GMW3179 (R/SEAT RR BRKT) (*KIT1) (8.907) [БОЛТ]
15251030 COVER, R/SEAT HGE FIN (INCLS 33) (GRAY) (SEAT LATCH ПОЛ TRIM) (*KIT1)
25756531 COVER, R/SEAT HGE FIN (INCLS 33) (NEUTRAL) (SEAT LATCH ПОЛ TRIM) (*KIT1)
25756532 COVER, R/SEAT HGE FIN (INCLS 33) (EBONY) (SEAT LATCH ПОЛ TRIM) (*KIT1)
11588650 CLIP, 12X14X16.6, GM4345M (ЧАСТЬ OF 32) (*KIT1) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
88898357 COVER, R/SEAT ADJR FIN OTR LWR FRT (NEUTRAL) (*KIT1)
88898358 COVER, R/SEAT ADJR FIN OTR LWR FRT (EBONY) (*KIT1)
88898359 COVER, R/SEAT ADJR FIN OTR LWR FRT (GRAY) (*KIT1)
11515759 БОЛТ, FLG HD (M8-1.25X35)9.8 ZOR (R/SEAT CUSH FRM) (*KIT1)
88993779 ПРУЖИНА, R/SEAT ADJR LAT (*KIT1)
88898278 PAD, R/SEAT CUSH (*KIT1)
88994570 COVER, R/SEAT HGE FIN (GRAY) (40% SIDE-OUTER) (*KIT1)
88994571 COVER, R/SEAT HGE FIN (EBONY) (40% SIDE-OUTER) (*KIT1)
88994572 COVER, R/SEAT HGE FIN (NEUTRAL) (40% SIDE-OUTER) (*KIT1)
88992380 COVER, R/SEAT HGE FIN (EBONY) (40% SIDE-INNER) (*KIT1)
88994582 COVER, R/SEAT HGE FIN (GRAY) (40% SIDE-INNER) (*KIT1)
88994584 COVER, R/SEAT HGE FIN (NEUTRAL) (40% SIDE-INNER) (*KIT1)
88993140 COVER, R/SEAT HGE FIN (NEUTRAL) (40% SIDE-OUTER) (*KIT1)
88994573 COVER, R/SEAT HGE FIN (GRAY) (40% SIDE-OUTER) (*KIT1)
88994574 COVER, R/SEAT HGE FIN (EBONY) (40% SIDE-OUTER) (*KIT1)
88994585 COVER, R/SEAT HGE FIN (GRAY) (40% SIDE-INNER) (*KIT1)
88994586 COVER, R/SEAT HGE FIN (EBONY) (40% SIDE-INNER) (*KIT1)
88994587 COVER, R/SEAT HGE FIN (NEUTRAL) (40% SIDE-INNER) (*KIT1)
88995692 COVER, R/SEAT CUSH (GRAY) (*KIT1)
88995693 COVER, R/SEAT CUSH (EBONY) (*KIT1)
88995694 COVER, R/SEAT CUSH (NEUTRAL) (*KIT1)
88995688 COVER, R/SEAT CUSH (GRAY) (*KIT1)
88995689 COVER, R/SEAT CUSH (EBONY) (*KIT1)
88995690 COVER, R/SEAT CUSH (NEUTRAL) (*KIT1)
88993665 PAD, R/SEAT CUSH (KICKUP) (*KIT1)
88898279 PAD, R/SEAT CUSH (*KIT1)
88995275 РАМА, R/SEAT CUSH (*KIT1)
(6E15-016) - 2005 E ОТДЕЛКА/QUARTER-LH
10374321 BARRIER, QTR INR PNL RR SND
25762934 BARRIER, C/PLR INR PNL SND
15714276 SCREW, HWH, W/FL WA, SELF TAP, M4.2X1.41X18, 12.5 O.D., 6010M, PS (ЧАСТЬ OF 14) (8.977)
25605716 ГАЙКА, ASST HDL (ЧАСТЬ OF 14) (13.8 X 14.9, 15.3) (U-SHAPED) (8.133)
11609257 БОЛТ, PAN HD, TORX, M12X1.75X34, 9.8 STEEL, GMW3179 (CARGO TIE DN HOOK) (8.907) [БОЛТ]
teamcadillac.ru
89022739 GRILLE, RDO R/Q TR PNL SPKR (ЧАСТЬ OF 14) (GRAY)
89022740 GRILLE, RDO R/Q TR PNL SPKR (ЧАСТЬ OF 14) (NEUTRAL)
89022741 GRILLE, RDO R/Q TR PNL SPKR (ЧАСТЬ OF 14) (BLACK)
25764782 PANEL, BODY SI LWR TR (INCLS 3, 4, 13, 15, 18-24) (GRAY)
25764783 PANEL, BODY SI LWR TR (INCLS 3, 4, 13, 15, 18-24) (EBONY)
25764784 PANEL, BODY SI LWR TR (INCLS 3, 4, 13, 15, 18-24) (NEUTRAL) [ВНУТРЕННЯЯ ПАНЕЛЬ БАГАЖНОГО ОТСЕКА]
21994244 HOOK, CONVENIENCE NET SNAP (ЧАСТЬ OF 14)
11588650 CLIP, 12X14X16.6, GM4345M (ЧАСТЬ OF 14) [ФИКСАТОР КРЫШКИ ПАНЕЛИ КРЫШИ КУЗОВА]
11609374 БОЛТ-WASHER, M6X1X16, 17 OD, 12 THD, 9.8, GMW3359, 1.47 H-REG FL WA. (ЧАСТЬ OF 14)
22611883 BUMPER, BODY SI T/PNL OPG ACC CVR (ЧАСТЬ OF 14) (BLACK) (6.6 DIA X 4.7 H) (10.263)
88957062 LID, CARGO BOX STOW BOX (ЧАСТЬ OF 14) (GRAY)
88957063 LID, CARGO BOX STOW BOX (ЧАСТЬ OF 14) (NEUTRAL)
11509231 SCREW, RD HD C/R TAP, M4.2X1.41X13.0, GM6010M STL, GM813M NICKEL ORGANIC (ЧАСТЬ OF 14) [ВИНТ М6Х12]
(6E15-022) - 2004-2009 E ЗАДНЕЕ СИДЕНЬЕ #2 CUSHION(AM0)
88994522 COVER, R/SEAT #2 CUSH (NEUTRAL) [КРЫШКА]
88994523 COVER, R/SEAT #2 CUSH (GRAY) [КРЫШКА]
88994524 COVER, R/SEAT #2 CUSH (EBONY)
88898295 PAD, R/SEAT #2 CUSH
88898436 COVER, R/SEAT RECL OTR FIN (NEUTRAL) (LOWER)
88898438 COVER, R/SEAT RECL OTR FIN (GRAY) (LOWER) (#2)
88992531 COVER, R/SEAT RECL OTR FIN (EBONY) (LOWER) (#2)
15659231 БОЛТ, R/SEAT #2 (PLASTICS TO РАМА) (M4.2X1.41X16 TORX RND HD) (16.069)
88898430 COVER, R/SEAT ADJR TRK FIN CVR CLOSEOUT (NEUTRAL)
88898432 COVER, R/SEAT ADJR TRK FIN CVR CLOSEOUT (GRAY)
88992539 COVER, R/SEAT ADJR TRK FIN CVR CLOSEOUT (EBONY)
11609257 БОЛТ, PAN HD, TORX, M12X1.75X34, 9.8 STEEL, GMW3179 (R/SEAT #2) (8.907) [БОЛТ]
88993012 БОЛТ, R/SEAT ADJR BRKT
88898384 ADJUSTER, R/SEAT (#2) (INCLS ACTUATOR)
88898446 RETAINER, R/SEAT #2 BELT (RETAINERS STRAP FOR BUCKLE)
88992521 RETAINER, R/SEAT BK CUSH (SEAT BELT STRAP) (#2)
88994077 COVER, R/SEAT ADJR TRK FIN (NEUTRAL)
88994078 COVER, R/SEAT ADJR TRK FIN (EBONY)
88994079 COVER, R/SEAT ADJR TRK FIN (GRAY)
88994080 COVER, R/SEAT ADJR TRK FIN (NEUTRAL)
88994081 COVER, R/SEAT ADJR TRK FIN (EBONY)
88994082 COVER, R/SEAT ADJR TRK FIN (GRAY)
88993016 INSULATOR, R/SEAT ADJR TRK (#2)
88994444 МОДУЛЬ, R/SEAT CONT [БЛОК УПРАВЛЕНИЯ СИДЕНИЕМ АВТОМОБИЛЯ]
11514527 ГАЙКА, HEX FLG M5X0.8 GRD 9 ZP (R/SEAT ADJR BRKT)
88992540 COVER, R/SEAT CUSH BTM (NEUTRAL)
88992541 COVER, R/SEAT CUSH BTM (GRAY) (#2)
88992542 COVER, R/SEAT CUSH BTM (EBONY) (#2)
88992522 RETAINER, R/SEAT BK CUSH (RECLINER SHAFT) (#2)
88992523 BEARING, R/SEAT #2 BK PIV SHF (25MM) (11.655)
88992520 SHAFT, R/SEAT #2 BK RECL PIV (11.377)
09134618 RETAINER, R/SEAT #2 CUSH (SHAFTS) (11.561)
88898365 BRACKET, R/SEAT RR (RECL MOTOR ATCH) (#2)
88993015 INSULATOR, R/SEAT #2 BK RECL MTR MT
88898296 MOTOR, R/SEAT #2 BK PIV ACTR (90 DEGREE MOTOR) (LOCATED IN CUSHION ASM)
88993156 BUMPER, R/SEAT
teamcadillac.ru
88898448 РАМА, R/SEAT #2 CUSH
22035124 БОЛТ, R/SEAT CUSH (HEX W/WA)
(6E15-023) - 2004-2009 E ЗАДНЕЕ СИДЕНЬЕ #2 КРЕПЛЕНИЕ(AM0)
25746011 SUPPORT, R/SEAT #2 BK CUSH
teamcadillac.ru
25746012 SUPPORT, R/SEAT #2 BK CUSH
(6E15-024) - 2004-2009 E ЗАДНЕЕ СИДЕНЬЕ-BACK
88994868 RESTRAINT, R/SEAT HD (NEUTRAL) (*KIT1)
88994869 RESTRAINT, R/SEAT HD (EBONY) (*KIT1)
88994870 RESTRAINT, R/SEAT HD (GRAY) (*KIT1)
88994871 RESTRAINT, R/SEAT HD (NEUTRAL) (*KIT1)
88994872 RESTRAINT, R/SEAT HD (EBONY) (*KIT1)
88994873 RESTRAINT, R/SEAT HD (GRAY) (*KIT1)
19122625 GUIDE, R/SEAT H/RST (EBONY) (W/O BUTTON) (*KIT1) (11.376)
88994279 GUIDE, R/SEAT H/RST (NEUTRAL) (W/O BUTTON) (*KIT1) (11.376)
88994731 GUIDE, R/SEAT H/RST (GRAY) (W/O BUTTON) (*KIT1)
88994941 РАМА, R/SEAT BK CUSH (*KIT1)
88994940 РАМА, R/SEAT BK CUSH (*KIT1)
19122627 GUIDE, R/SEAT H/RST (EBONY) (W/BUTTON) (*KIT1) (11.376)
88994276 GUIDE, R/SEAT H/RST (NEUTRAL) (W/BUTTON) (*KIT1) (11.376)
88994730 GUIDE, R/SEAT H/RST (GRAY) (W/BUTTON) (*KIT1)
88993438 RESTRAINT, RR CTR ST HD (NEUTRAL) (*KIT1)
88993439 RESTRAINT, RR CTR ST HD (EBONY) (*KIT1)
88993440 RESTRAINT, RR CTR ST HD (GRAY) (*KIT1)
88898330 COVER, R/SEAT SHLDR BELT RETR OPG TR (*KIT1)
88992409 HANDLE, R/SEAT BK CUSH LAT REL (GRAY) (FOLDING) (*KIT1)
88992410 HANDLE, R/SEAT BK CUSH LAT REL (EBONY) (FOLDING) (*KIT1)
88992411 HANDLE, R/SEAT BK CUSH LAT REL (NEUTRAL) (FOLDING) (*KIT1)
88994897 PANEL, R/SEAT BK CUSH (NEUTRAL) (40%) (*KIT1)
88994898 PANEL, R/SEAT BK CUSH (EBONY) (*KIT1)
88994899 PANEL, R/SEAT BK CUSH (GRAY) (*KIT1)
88994735 GUIDE, R/SEAT SHLDR BELT (INCLS 12) (EBONY) (*KIT1)
88994736 GUIDE, R/SEAT SHLDR BELT (INCLS 12) (NEUTRAL) (*KIT1)
teamcadillac.ru
88994737 GUIDE, R/SEAT SHLDR BELT (INCLS 12) (PEWTER) (*KIT1)
88992415 HANDLE, R/SEAT BK CUSH LAT REL (GRAY) (FLIP & FOLD) (*KIT1)
88992416 HANDLE, R/SEAT BK CUSH LAT REL (EBONY) (FLIP & FOLD) (*KIT1)
88992417 HANDLE, R/SEAT BK CUSH LAT REL (NEUTRAL) (FLIP & FOLD) (*KIT1)
88994560 PANEL, R/SEAT BK CUSH (NEUTRAL) (60% SIDE-CTR) (*KIT1)
88994561 PANEL, R/SEAT BK CUSH (EBONY) (*KIT1)
88994563 PANEL, R/SEAT BK CUSH (GRAY) (*KIT1)
88992503 CAP, R/SEAT BK CUSH PNL БОЛТ (GRAY) (FOLDING) (*KIT1)
88992504 CAP, R/SEAT BK CUSH PNL БОЛТ (EBONY) (FOLDING) (*KIT1)
88992505 CAP, R/SEAT BK CUSH PNL БОЛТ (NEUTRAL) (FOLDING) (*KIT1)
88993062 ГАЙКА, R/SEAT CUSH (*KIT1)
88994827 CABLE, R/SEAT BK CUSH LAT (MAY ALSO REQUIRE 88994828 ADJUSTER) (*KIT1)
88992487 БОЛТ, R/SEAT (M10X1.5, 9MM SHLDR) (OUTER ATTACHMENT) (*KIT1)
88992524 BUSHING, R/SEAT (*KIT1) (11.620)
12355066 STRAP, PLASTIC ADJ TIE (215MM LG) (R/SEAT HTR CONT WRG HARN CONN) (*KIT1) (8.965) (ACDelco #16TS825) [ХОМУТ С ФИКСАТОРОМ]
11516078 ГАЙКА, R/SEAT BELT (RETR SI) (CTR) (M12X1.75X18) (*KIT1) (8.917) [ГАЙКА]
15224766 BELT, R/SEAT CTR (RETR SI) (EBONY) (*KIT1)
15224767 BELT, R/SEAT CTR (RETR SI) (NEUTRAL) (*KIT1)
25833946 BELT, R/SEAT CTR (RETR SI) (GRAY) (*KIT1)
00332364 RETAINER - PUSH IN, FITS HOLE SIZE 0.245 - 0.260, GRIP LENGTH 0.52, 0.7 OD, MATERIAL NYLON 6/6 PER GMP.PA66.015 (R/SEAT BK CUSH CVR (PUSH IN)) (*KIT1)
11562368 БОЛТ, R/SEAT BELT (RETR SI) (M12X1.75X35.75) (*KIT1) (16.714)
11517068 NUT-METRIC HEX FLABGE, M6X1, 10MM SOCKET (R/SEAT A/RST FRM BRKT) (*KIT1)
88992524 BUSHING, R/SEAT (11.620)
22035124 БОЛТ, R/SEAT CUSH (HEX W/WA) (*KIT1)
88993029 CABLE, R/SEAT BK CUSH LAT (*KIT1)
88993615 БОЛТ, R/SEAT CUSH (INBOARD) (SHOULDER W/BUSHING) (*KIT1)
88993776 BRACKET, R/SEAT (CTR) (*KIT1)
88993777 BRACKET, R/SEAT (*KIT1)
88993778 BRACKET, R/SEAT (*KIT1)
11570654 ГАЙКА, R/SEAT (4.2 X 1.41) (FITS 8.75 SQ HOLE) (*KIT1) (9.665)
88993845 PAD, R/SEAT BK CUSH (PLASTIC INSERT) (*KIT1)
19124785 БОЛТ, R/SEAT A/RST TRAY (ЧАСТЬ OF 42) (*KIT1)
88993353 ARMREST, R/SEAT (INCLS 40, 41, 44, 45) (GRAY) (W/CUPДЕРЖАТЕЛЬ) (*KIT1)
88993354 ARMREST, R/SEAT (INCLS 40, 41, 44, 45) (EBONY) (W/CUPДЕРЖАТЕЛЬ) (*KIT1)
88993355 ARMREST, R/SEAT (INCLS 40, 41, 44, 45) (NEUTRAL) (W/CUPДЕРЖАТЕЛЬ) (*KIT1)
19123366 STRAP, R/SEAT A/RST (EBONY) (*KIT1) (PLACE LARGE LOOP AROUND BOTTOM CORNERS OF ARMREST) (SECURE CLIP TO D-RING ON FLR PAN & PULL STRAP FREE END TO ADJ)
19124749 SUPPORT, R/SEAT A/RST CUP HLDR CTR (ЧАСТЬ OF 42) (*KIT1)
19124748 ДЕРЖАТЕЛЬ, R/SEAT A/RST CUP (ЧАСТЬ OF 42) (*KIT1)
88994502 COVER, R/SEAT BK CUSH (NEUTRAL) (*KIT1)
88994503 COVER, R/SEAT BK CUSH (GRAY) (*KIT1)
88994504 COVER, R/SEAT BK CUSH (EBONY) (*KIT1)
88994850 PAD, R/SEAT BK CUSH (*KIT1)
88994510 COVER, R/SEAT BK CUSH (NEUTRAL) (*KIT1)
88994511 COVER, R/SEAT BK CUSH (GRAY) (*KIT1)
88994512 COVER, R/SEAT BK CUSH (EBONY) (*KIT1)
88994849 PAD, R/SEAT BK CUSH (*KIT1)
(6E15-025) - 2004-2009 E ЗАДНЕЕ СИДЕНЬЕ-КРЕПЛЕНИЕ
teamcadillac.ru
11589273 БОЛТ, HFH, M12X1.75X40, 30 THD, 26.6 OD, 10.9 MAT'L.GMW3359 (R/SEAT)
18 - ЗАПЧАСТИ - ЖИДКОСТИ - ЕМКОСТИ И ОБЪЕМЫ - НОВЫЕ ДЕТАЛИ - ЭЛЕКТРИЧЕСКИЕ СОЕДИНЕНИЯ
(OTOU-025) - 2004-2006 E ОБЫЧНОЕ ОБСЛУЖИВАНИЕ ЗАПАСНЫЕ ЧАСТИ (LH2/4.6A)(281 CID)(V8-ALUM/DOHC)
teamcadillac.ru
12571533 СВЕЧИ, (ACDelco #41-986) (PLATINUM PLUG) [СВЕЧА ЗАЖИГАНИЯ]
25798271 ELEMENT, КОНДИЦИОНЕРL (ACDelco #A2944C) [ВОЗДУШНЫЙ ФИЛЬТР ДВИГАТЕЛЯ]
89017342 ФИЛЬТР, МАСЛЯНЫЙ (FOR NON-CANADIAN ORDERS) (ACDelco #89017342)
89032612 ФИЛЬТР, МАСЛЯНЫЙ (ACDelco #89032612) (DURAPACK) (BULK PKG, QTY 12)
25763176 ФИЛЬТР, FUEL (ACDelco #GF897) [ТОПЛИВНЫЙ ФИЛЬТР]
96042545 FILTER KIT, A/TRNS FLUID (INCLS SEALS) (ACDelco #96042545) (CODE 3GBG) [МАСЛЯНЫЙ ФИЛЬТР АВТОМАТИЧЕСКАЯ КОРОБКА ПЕРЕДАЧ]
96042862 GASKET, A/TRNS FLUID PAN [ПРОКЛАДКА МАСЛЯНОГО ПОДДОНА]
(OTOU-025) - 2004-2006 E ОБЫЧНОЕ ОБСЛУЖИВАНИЕ ЗАПАСНЫЕ ЧАСТИ (LY7/3.6-7)(220 CID)(V6-ALUM/SFI)
teamcadillac.ru
12597464 СВЕЧИ, (DO NOT CHANGE СВЕЧИ GAP) (ACDelco #41-990) (PLATINUM PLUG) [СВЕЧА ЗАЖИГАНИЯ]
19114105 ФИЛЬТР, МАСЛЯНЫЙ (ACDelco #PF2129F) (DURAPACK) (BULK PKG, QTY 12)
25177917 ФИЛЬТР, МАСЛЯНЫЙ (ACDelco #PF2129) [МАСЛЯНЫЙ ФИЛЬТР ДВИГАТЕЛЯ]
(OTOU-081) - 2004-2009 E ОБЫЧНОЕ ОБСЛУЖИВАНИЕ ЗАПАСНЫЕ ЧАСТИ (LH2/4.6A)(281 CID)
teamcadillac.ru
(OTOU-081) - 2004-2009 E ОБЫЧНОЕ ОБСЛУЖИВАНИЕ ЗАПАСНЫЕ ЧАСТИ (LY7/3.7-7)(220 CID)
teamcadillac.ru
21 - АКСЕССУАРЫ
(6D21-014) - 2004-2008 EB26 PERFORMANCE PKG/MUFFLER PKG
teamcadillac.ru
19154783 MUFFLER PKG, EXH (INCLS RH & LH FRT PIPE, FRT MUFFR, RH & LH INTER PIPE, RH & LH MUFF, 4-2.5" CЛАМПАS, 2-2.0" CЛАМПАS & INSTR) (HAS WELD ON TIPS) (SS) (INSTALL 1.0) (29.5KGS) (HIGH POLISHED TIPS) (ANGLE CUT) (4" ROUND) (3.701)
(6E21-001) - 2005-2006 EB26 PROTECTOR PKG/ЗАДНИЙ BUMPER FASCIA
teamcadillac.ru
12499573 PROTECTOR PKG, RR BPR FASCIA (INSTALL .30) (0.3KGS) (INCLS LH & RH) (7.831) [ПРОТЕКТОР]
(6E21-002) - 2005-2006 EB26 ЧАСТЬITION PKG
12499463 MAT PKG, CARGO VINYL (EBONY) (1.55KGS) (ALL WEATHER VINYL) (W/WREATH & CREST LOGO) (OCTAGON CELL PATT) (15.306) [КОВРИК КОМПЛЕКТ БАГАЖНИК, ВИНИЛ]
12498786 ЧАСТЬITION PKG, INTR CARGO (BLACK) (INSTALL .10) (1.0KGS) (NET STYLE) (15.222)
12499111 LINER PKG, R/CMPT FLR (W/CONVENIENCE NET) (SAME AS ACT) (INSTALL .10) (2.55KGS) (INCLS ЧАСТЬITION NET PKG & VINYL MAT PKG) (12.981)
(6E21-003) - 2004-2009 E MAT PKG/FRONT & ЗАДНИЙ VINYL (NON-PRODUCTION)
teamcadillac.ru
12498727 MAT PKG, FRONT PREMIUM (ALL WEATHER) (AWD) (EBONY) (3.86 KGS) (TWIN) (W/EBONY SRX LOGO) (HONEYCOMB PATTERN) (15.286) [КОМПЛЕКТ КОВРИКОВ САЛОНА (2 ШТ)]
12498729 MAT PKG, FRONT PREMIUM (ALL WEATHER) (RWD) (EBONY) (4.32 KGS) (TWIN) (W/EBONY SRX LOGO) (HONEYCOMB PATTERN) (15.286) [КОМПЛЕКТ КОВРИКОВ ПЕРЕДНИЕ, ВИНИЛ]
12498728 MAT PKG, ЗАДНИЙ PREMIUM (ALL WEATHER) (EBONY) (TWIN) (NO LOGO) (HONEYCOMB PATTERN) (15.306) [КОМПЛЕКТ КОВРИКОВ САЛОНА (2 ШТ)]
(6E21-004) - 2004-2009 E EXTENSION PKG/FRONT BUMPER FASCIA
12498549 EXTENSION PKG, FRT BPR FASCIA (INSTALL .80) (INCLS LICENSE BRKT, UPR & LWR BRKT, ЗАЩИТА PNL, HDW, TEMPLATE) (7.828) (**VPI 1-877-846-8243) (NOT RECOMMENDED FOR USE WITH MAXIMIN TRAILER TOWING LOAD, MAY CAUSE OVERHEATING CONDITION.) [ЗАЩИТА]
19159825 EXTENSION PKG, FRT BPR FASCIA (INCLS LIC PLT BRKT, 1 LWR & 2 UPR BRKT'S, ЗАЩИТА PNL, RH & LH TEMPLATES & АРМАТУРА PKG.) (BLACK) (INSTALL .80) (3.2KGS) (7.831)
teamcadillac.ru
19159826 EXTENSION PKG, FRT BPR FASCIA (INCLS LIC PLT BRKT, 1 LWR & 2 UPR BRKT'S, ЗАЩИТА PNL, RH & LH TEMPLATES & АРМАТУРА PKG.) (RED) (INSTALL .80) (3.2KGS) (7.831)
19159827 EXTENSION PKG, FRT BPR FASCIA (INCLS LIC PLT BRKT, 1 LWR & 2 UPR BRKT'S, ЗАЩИТА PNL, RH & LH TEMPLATES & АРМАТУРА PKG.) (TARNISH) (INSTALL .80) (3.2KGS) (7.831)
19159828 EXTENSION PKG, FRT BPR FASCIA (INCLS LIC PLT BRKT, 1 LWR & 2 UPR BRKT'S, ЗАЩИТА PNL, RH & LH TEMPLATES & АРМАТУРА PKG.) (WHITE) (INSTALL .80) (3.2KGS) (7.831)
19159829 EXTENSION PKG, FRT BPR FASCIA (INCLS LIC PLT BRKT, 1 LWR & 2 UPR BRKT'S, ЗАЩИТА PNL, RH & LH TEMPLATES & АРМАТУРА PKG.) (PRIME) (INSTALL .80) (3.2KGS) (7.831)
(6E21-005) - 2004-2009 EB26 ЗАЩИТА PKG/SPLASH (MOLDED) (SRX LOGO)
12498913 ЗАЩИТА PKG, SPH (MOLDED) (BLACK) (INSTALL .50) (0.43KGS) (FRT) (W/SRX LOGO) (8.214) [КОМПЛЕКТ БРЫЗГОВИКОВ (2 ШТ)]
12498914 ЗАЩИТА PKG, SPH (MOLDED) (BLACK) (INSTALL .50) (0.43KGS) (RR) (W/SRX LOGO) (WORKS WITH OR WITHOUT FLARES) (8.214) [КОМПЛЕКТ БРЫЗГОВИКОВ (2 ШТ)]
12499189 ЗАЩИТА PKG, FRT & RR SPH (MOLDED) (SAME AS VH4) (BLACK) (INSTALL 1.0) (0.86KGS) (W/SRX LOGO) (8.214) [КОМПЛЕКТ БРЫЗГОВИКОВ (4 ШТ.)]
(6E21-006) - 2005-2009 E КОЛЕСО PKG (18"-7 DOUBLE SPOKES)
17800014 CAP PKG, HUB (INSTALL .10) (SINGLE 0.03KGS) (W/WREATH & CREST EMBLEM) (18") (4 PC QTY OF 9594376) (5.858) [КОЛПАК СТУПИЦЫ КОЛЕСА]
17800015 CAP PKG, HUB (POLISHED) (INSTALL .10) (SINGLE 0.03KGS) (18") (80 PC QTY OF 9594376) (5.858)
17800179 КОЛЕСО PKG, 18X8 (POLISHED) (INSTALL .25) (SINGLE 10.7KGS) (FORGED AL) (INCLS 1 WHL 88963136 & TAG) (5.803)
teamcadillac.ru
17800180 КОЛЕСО PKG, 18X8 (POLISHED) (INSTALL .25) (SINGLE 10.7KGS) (FORGED AL) (INCLS 4 PC QTY OF 88963136) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 8JX18]
17800181 КОЛЕСО PKG, 18X8 (POLISHED) (INSTALL .25) (SINGLE 10.7KGS) (FORGED AL) (INCLS 16 PC QTY OF 88963136) (5.803)
(6E21-007) - 2005-2009 EB26 КОЛЕСО PKG (18"- 12 SPOKE)
17801500 КОЛЕСО PKG, 18X8 (CHROME) (INSTALL .25) (SINGLE 11.8KGS) (CAST AL) (INCLS 1 WHL 88968802 & TAG) (5.803)
17801501 КОЛЕСО PKG, 18X8 (CHROME) (INSTALL .25) (SINGLE 11.8KGS) (CAST AL) (4 PC QTY OF 88968802) (5.803) [АЛЮМИНИЕВЫЙ КОЛЕСНЫЙ ДИСК 18Х8]
teamcadillac.ru
17801502 КОЛЕСО PKG, 18X8 (CHROME) (INSTALL .25) (SINGLE 11.8KGS) (CAST AL) (16 PC QTY OF 88968802) (5.803)
(6E21-008) - 2004-2009 EB26 MAT PKG/CARGO AREA (NON-PRODUCTION) (NON-SKID)
19154702 MAT PKG, CARGO NON-SKID (BLACK) (0.42KGS) (W/WREATH & CREST LOGO) (16.800)
(6E21-009) - 2004-2009 EB26 DEFLECTOR PKG/КАПОТ AIR
teamcadillac.ru
12498928 DEFLECTOR PKG, КАПОТ AIR (SMOKE) (INSTALL .20) (0.4KGS) (ACRYLIC) (NO LOGO) (8.010) [ДЕФЛЕКТОР]
(6E21-011) - 2004-2009 E EXTENSION PKG/ЗАДНИЙ BUMPER FASCIA
teamcadillac.ru
19159830 EXTENSION PKG, RR BPR FASCIA (BLACK) (INSTALL .80) (4.7KGS) (7.831)
19159831 EXTENSION PKG, RR BPR FASCIA (RED) (INSTALL .80) (4.7KGS) (7.831)
19159832 EXTENSION PKG, RR BPR FASCIA (TARNISH) (INSTALL .80) (4.7KGS) (7.831)
19159833 EXTENSION PKG, RR BPR FASCIA (WHITE) (INSTALL .80) (4.7KGS) (7.831)
19159834 EXTENSION PKG, RR BPR FASCIA (PRIME) (INSTALL .80) (4.7KGS) (7.831)
(6K21-005) - 2005-2007 EB26 COVER PKG/FRONT SEAT HEADREST
teamcadillac.ru
19166508 COVER PKG, F/SEAT HEADREST (GRAY) (INSTALL .10) (0.45KGS) (LEATHER W/VINYL SD) (INCLS 2 CVR'S) (16.718)
19166509 COVER PKG, F/SEAT HEADREST (EBONY) (INSTALL .10) (0.45KGS) (LEATHER W/VINYL SD) (INCLS 2 CVR'S) (16.718)
19166510 COVER PKG, F/SEAT HEADREST (CASHMERE) (INSTALL .10) (0.45KGS) (LEATHER W/VINYL) (INCLS 2 CVR'S) (16.718)
(AC21-473) - 2004-2005 E АВАРИЙНАЯ СИГНАЛИЗАЦИЯ
12370237 LIGHT PKG, DISTRESS (STROBE)
(AC21-476) - 2004-2009 EB АВАРИЙНЫЙ PKG
teamcadillac.ru
12497328 АВАРИЙНЫЙ PKG, HWY (INCLS PONCHO, GLOVES, BANNER, FLASHLIGHT, FUSE KIT, BUNGEE CORD, ELEC TAPE, PLIERS, RAG, SCREWDRIVER, BOOSTER ПРОВОДА, AND КОМПЛЕКТ ПЕРВОЙ ПОМОЩИ KIT) (2.28KGS) (W/GM ACSRY LOGO) (2.575)
(AC21-483) - 2004-2005 EB ORGANIZER PKG/MOBILE OFFICE
teamcadillac.ru
12497374 ORGANIZER PKG, MOBILE OFFICE (GRAY) (REQ 28" BETWEEN ST BK & DA) (14.880) [ОРГАНАЙЗЕР ДЛЯ БУМАГ И КАНЦ. ПРИНАДЛЕЖНОСТЕЙ ПЛАСТ]
(AC21-492) - 2004-2006 E HARNESS PKG/TRAILER WIRING
teamcadillac.ru
12499575 HARNESS PKG, TRLR WRG (INSTALL .20) (FLAT 4 PIN CONN) (7.068)
(AC21-545) - 2004-2005 E ОГРАНИЧИТЕЛЬ БАГАЖА
12498661 RESTRAINT PKG, PET (INCLS TETHER & HARNESS) (SMALL) (RR SEAT) (12-20" CHEST, MEAS AROUND BODY, BEHIND FRT LEGS) (8.810)
12498662 RESTRAINT PKG, PET (INCLS TETHER & HARNESS) (MED) (RR SEAT) (20-30" CHEST, MEAS AROUND BODY, BEHIND FRT LEGS) (8.810)
12498663 RESTRAINT PKG, PET (INCLS TETHER & HARNESS) (LG) (RR SEAT) (30-40" CHEST, MEAS AROUND BODY, BEHIND FRT LEGS)
88961353 HARNESS, PET (12-20 INCH CHEST, MEASURED AROUND BODY, BEHIND FRT LEGS) (SMALL) (SERV CMP OF RESTRAINT PKG 12498661) (8.810)
88961354 HARNESS, PET (20-30 INCH CHEST, MEASURED AROUND BODY, BEHIND FRT LEGS) (MED) (SERV CMP OF RESTRAINT PKG 12498662) (8.810)
teamcadillac.ru
88961355 HARNESS, PET (30-40 INCH CHEST, MEASURED AROUND BODY, BEHIND FRT LEGS) (LG) (SERV CMP OF RESTRAINT PKG 12498663)
88961356 TETHER, PET (12-20 INCH CHEST, MEASURED AROUND BODY, BEHIND FRT LEGS) (SMALL) (SERV CMP OF RESTRAINT PKG 12498661) (8.810)
88961357 TETHER, PET (20-30 INCH CHEST, MEASURED AROUND BODY, BEHIND FRT LEGS) (MED) (SERV CMP OF RESTRAINT PKG 12498662) (8.810)
88961358 TETHER, PET (30-40 INCH CHEST, MEASURED AROUND BODY, BEHIND FRT LEGS) (LG) (SERV CMP OF RESTRAINT PKG 12498663)
(AC21-548) - 2004-2009 E ROADSIDE ASSISTANCE PKG/ROLL-UP
12498311 ROADSIDE ASSISTANCE PKG, BULK (INTERNATIONAL) (360 PC QTY OF 88960625) (8.808)
teamcadillac.ru
88960625 ROADSIDE ASSISTANCE PKG, (1.26KGS) (ROLL-UP) (8.808)
(AC21-559) - 2004-2009 E ДЕРЖАТЕЛЬ PKG/СОЛНЦЕЗАЩИТНЫЙ КОЗЫРЕК CD
12495014 ДЕРЖАТЕЛЬ PKG, S/S CD STOW (0.12 KGS) (HOLDS 12 CD) (MOUNTED TO SUN VISOR) (10.203) [ДЕРЖАТЕЛЬ КОМПАКТ-ДИСКОВ ПЛАСТИКОВЫЙ]
(AC21-587) - 2004-2009 E LOCK PKG/КОЛЕСО
12498074 LOCK PKG, WHL (FOR WHL USING NUT #9594681) (STEEL) (INSTALL .10) (SINGLE 0.2 KGS) (W/HEX FREE COATING) (4 LOCKS & KEY) (M12X1.5) (W/EXT THD) (5.875) [КОМПЛЕКТ БОЛТОВ М14 (4ШТ)]
teamcadillac.ru
12498081 LOCK PKG, WHL (STEEL) (INSTALL .10) (SINGLE 0.2KGS) (W/HEX FREE COATING) (10 PC QTY OF 12498074) (M12X1.5) (W/EXT THD) (5.875) [К-КТ СЕКРЕТНЫХ БОЛТОВ]
(AC21-613) - 2004-2006 E HEADPHONE/WIRELESS (PRODUCTION)
teamcadillac.ru
10440840 HEADPHONE, (WIRED) (GM & KOSS BRAND) (9.665)
(AC21-671) - 2004-2009 E КОМПЛЕКТ ПЕРВОЙ ПОМОЩИ PKG
teamcadillac.ru
88960626 MEDICAL PKG, КОМПЛЕКТ ПЕРВОЙ ПОМОЩИ (BLACK) (0.19KGS) (WHITE GM BLOCK LOGO) (VINYL) (8.808)
12498312 MEDICAL PKG, BULK КОМПЛЕКТ ПЕРВОЙ ПОМОЩИ (INTERNATIONAL) (360 PC QTY OF 88960626) (8.808)
(AC21-672) - 2004-2009 E26 КРЕПЛЕНИЕ БАГАЖА, ВЕЛОСИПЕД (WALL MOUNT)
12499175 UNIT, BICYCLE/SKI КРОНШТЕЙН WALL MOUNT STORAGE (6.35KGS) (INCLS BRKT, PLT & HDW) (REQ'S HITCH MTD BIKE CARR) (17.070)
(AC21-716) - 2005-2008 EB COVER PKG/ДВИГАТЕЛЬ SHIELD
12499960 SHIELD PKG, ДВИГАТЕЛЬ APPEARANCE (INSTALL .20) (1.6KGS) (INCLS CVR & CAP) (0.029)
teamcadillac.ru
12499961 SHIELD PKG, ДВИГАТЕЛЬ APPEARANCE (INSTALL .20) (1.6KGS) (INCLS CVR & INSTR) (0.029)
(AC21-801) - 2004-2009 E MAT PKG/FRONT & ЗАДНИЙ ПОЛ ПОКРЫТИЕ (NON-PRODUCTION)
teamcadillac.ru
17800511 MAT PKG, FRONT & ЗАДНИЙ ПОКРЫТИЕ (EBONY) (AWD) (FRT W/WREATH & CREST LOGO) (15.286) [КОМПЛЕКТ КОВРИКОВ САЛОНА (4 ШТ)]
17800512 MAT PKG, FRONT & ЗАДНИЙ ПОКРЫТИЕ (CASHMERE) (AWD) (FRT W/WREATH & CREST LOGO) (15.286)
17800513 MAT PKG, FRONT & ЗАДНИЙ ПОКРЫТИЕ (GRAY) (AWD) (FRT W/WREATH & CREST LOGO) (15.286) [КОМПЛЕКТ КОВРИКОВ САЛОНА (4 ШТ)]
17800514 MAT PKG, FRONT & ЗАДНИЙ ПОКРЫТИЕ (EBONY) (3.5KGS) (RWD) (FRT W/WREATH & CREST LOGO) (15.286) [КОМПЛЕКТ КОВРИКОВ САЛОНА (4 ШТ)]
17800515 MAT PKG, FRONT & ЗАДНИЙ ПОКРЫТИЕ (CASHMERE) (3.4KGS) (RWD) (FRT W/WREATH & CREST LOGO) (15.286)
17800516 MAT PKG, FRONT & ЗАДНИЙ ПОКРЫТИЕ (GRAY) (3.4KGS) (RWD) (FRT W/WREATH & CREST LOGO) (15.286) [КОМПЛЕКТ КОВРИКОВ САЛОНА (4 ШТ)]
(AC21-824) - 2005-2009 E ACCESSORY PKG/ШИНА (18 INCH)
teamcadillac.ru
89034137 ШИНА, 18 INCH - ACCESSORY (INSTALL .25) (SINGLE 14.0KGS) (MICHELIN, PIL, HXMXM4, TL, 235/60R18) (5.880) (ACDelco #M94200)
89050131 ШИНА, 18 INCH - ACCESSORY (INSTALL .25) (SINGLE 15.2KGS) (MICHELIN, PIL, HXMXM4, 255/55R18) (5.880) (ACDelco #M51820)
(AC21-829) - 2004-2006 EB26 MAT PKG/FRONT ПОЛ ПОКРЫТИЕ (NON-PRODUCTION)
12344132 MAT PKG, FRONT ПОКРЫТИЕ (GRAY) (TWIN) (UNIVERSAL) (15.286)
teamcadillac.ru
12344136 MAT PKG, FRONT ПОКРЫТИЕ (BEIGE) (TWIN) (UNIVERSAL) (15.286)
(AC21-856) - 2004-2009 E26 КРОНШТЕЙН PKG/SKI (HITCH MOUNT)
12499173 КРОНШТЕЙН PKG, SKI (HITCH MT) (INCLS UPR & LWR ARMS, KEY SET & INSTR) (INSTALL .10) (11.38KGS) (CARRIES 5 PR SKIS OR 4 SNOWBOARDS & 1 PR SKIS) (17.070) (REQUIRES 1-1/4" HITCH PKG) (REQUIRES BIKE КРОНШТЕЙН PKG 12499172) [КРОНШТЕЙН ОТКИДНОЙ ДВЕРИ ДЛЯ КРЕПЛЕНИЯ СНОУБОРДА]
(AC21-916) - 2004-2006 E26 LOCK PKG/BICYCLE & SKI КРОНШТЕЙН
12499725 LOCK PKG, BICYCLE/SKI RACK (12.815)
19242660 KEY SET, HITCH КРОНШТЕЙН (#010) (INCLS 2 KEYS) (17.070)
19242661 KEY SET, HITCH КРОНШТЕЙН (#011) (INCLS 2 KEYS) (17.070)
19242662 KEY SET, HITCH КРОНШТЕЙН (#012) (INCLS 2 KEYS) (17.070)
19242663 KEY SET, HITCH КРОНШТЕЙН (#013) (INCLS 2 KEYS) (17.070)
19242664 KEY SET, HITCH КРОНШТЕЙН (#014) (INCLS 2 KEYS) (17.070)
19242665 KEY SET, HITCH КРОНШТЕЙН (#015) (INCLS 2 KEYS) (17.070)
19242666 KEY SET, HITCH КРОНШТЕЙН (#016) (INCLS 2 KEYS) (17.070)
19242667 KEY SET, HITCH КРОНШТЕЙН (#017) (INCLS 2 KEYS) (17.070)
19242668 KEY SET, HITCH КРОНШТЕЙН (#018) (INCLS 2 KEYS) (17.070)
19242669 KEY SET, HITCH КРОНШТЕЙН (#019) (INCLS 2 KEYS) (17.070)
19242670 KEY SET, HITCH КРОНШТЕЙН (#020) (INCLS 2 KEYS) (17.070)
19242671 KEY SET, HITCH КРОНШТЕЙН (#021) (INCLS 2 KEYS) (17.070)
19242672 KEY SET, HITCH КРОНШТЕЙН (#022) (INCLS 2 KEYS) (17.070)
19242673 KEY SET, HITCH КРОНШТЕЙН (#023) (INCLS 2 KEYS) (17.070)
19242674 KEY SET, HITCH КРОНШТЕЙН (#024) (INCLS 2 KEYS) (17.070)
19242675 KEY SET, HITCH КРОНШТЕЙН (#025) (INCLS 2 KEYS) (17.070)
19242676 KEY SET, HITCH КРОНШТЕЙН (#026) (INCLS 2 KEYS) (17.070)
19242677 KEY SET, HITCH КРОНШТЕЙН (#027) (INCLS 2 KEYS) (17.070)
19242678 KEY SET, HITCH КРОНШТЕЙН (#028) (INCLS 2 KEYS) (17.070)
19242679 KEY SET, HITCH КРОНШТЕЙН (#029) (INCLS 2 KEYS) (17.070)
19242680 KEY SET, HITCH КРОНШТЕЙН (#030) (INCLS 2 KEYS) (17.070)
19242681 KEY SET, HITCH КРОНШТЕЙН (#031) (INCLS 2 KEYS) (17.070)
19242682 KEY SET, HITCH КРОНШТЕЙН (#032) (INCLS 2 KEYS) (17.070)
19242683 KEY SET, HITCH КРОНШТЕЙН (#033) (INCLS 2 KEYS) (17.070)
19242684 KEY SET, HITCH КРОНШТЕЙН (#034) (INCLS 2 KEYS) (17.070)
19242685 KEY SET, HITCH КРОНШТЕЙН (#035) (INCLS 2 KEYS) (17.070)
19242686 KEY SET, HITCH КРОНШТЕЙН (#036) (INCLS 2 KEYS) (17.070)
19242687 KEY SET, HITCH КРОНШТЕЙН (#037) (INCLS 2 KEYS) (17.070)
19242688 KEY SET, HITCH КРОНШТЕЙН (#038) (INCLS 2 KEYS) (17.070)
19242689 KEY SET, HITCH КРОНШТЕЙН (#039) (INCLS 2 KEYS) (17.070)
19242690 KEY SET, HITCH КРОНШТЕЙН (#040) (INCLS 2 KEYS) (17.070)
19242691 KEY SET, HITCH КРОНШТЕЙН (#041) (INCLS 2 KEYS) (17.070)
19242692 KEY SET, HITCH КРОНШТЕЙН (#042) (INCLS 2 KEYS) (17.070)
19242693 KEY SET, HITCH КРОНШТЕЙН (#043) (INCLS 2 KEYS) (17.070)
19242694 KEY SET, HITCH КРОНШТЕЙН (#044) (INCLS 2 KEYS) (17.070)
19242695 KEY SET, HITCH КРОНШТЕЙН (#045) (INCLS 2 KEYS) (17.070)
19242696 KEY SET, HITCH КРОНШТЕЙН (#046) (INCLS 2 KEYS) (17.070)
19242697 KEY SET, HITCH КРОНШТЕЙН (#047) (INCLS 2 KEYS) (17.070)
19242698 KEY SET, HITCH КРОНШТЕЙН (#048) (INCLS 2 KEYS) (17.070)
19242699 KEY SET, HITCH КРОНШТЕЙН (#049) (INCLS 2 KEYS) (17.070)
19242700 KEY SET, HITCH КРОНШТЕЙН (#050) (INCLS 2 KEYS) (17.070)
19242701 KEY SET, HITCH КРОНШТЕЙН (#051) (INCLS 2 KEYS) (17.070)
19242702 KEY SET, HITCH КРОНШТЕЙН (#052) (INCLS 2 KEYS) (17.070)
19242703 KEY SET, HITCH КРОНШТЕЙН (#053) (INCLS 2 KEYS) (17.070)
19242704 KEY SET, HITCH КРОНШТЕЙН (#054) (INCLS 2 KEYS) (17.070)
19242705 KEY SET, HITCH КРОНШТЕЙН (#055) (INCLS 2 KEYS) (17.070)
19242706 KEY SET, HITCH КРОНШТЕЙН (#056) (INCLS 2 KEYS) (17.070)
19242707 KEY SET, HITCH КРОНШТЕЙН (#057) (INCLS 2 KEYS) (17.070)
19242708 KEY SET, HITCH КРОНШТЕЙН (#058) (INCLS 2 KEYS) (17.070)
19242709 KEY SET, HITCH КРОНШТЕЙН (#059) (INCLS 2 KEYS) (17.070)
19242710 KEY SET, HITCH КРОНШТЕЙН (#060) (INCLS 2 KEYS) (17.070)
19242711 KEY SET, HITCH КРОНШТЕЙН (#061) (INCLS 2 KEYS) (17.070)
19242712 KEY SET, HITCH КРОНШТЕЙН (#062) (INCLS 2 KEYS) (17.070)
19242713 KEY SET, HITCH КРОНШТЕЙН (#063) (INCLS 2 KEYS) (17.070)
19242714 KEY SET, HITCH КРОНШТЕЙН (#064) (INCLS 2 KEYS) (17.070)
19242715 KEY SET, HITCH КРОНШТЕЙН (#065) (INCLS 2 KEYS) (17.070)
19242716 KEY SET, HITCH КРОНШТЕЙН (#066) (INCLS 2 KEYS) (17.070)
19242717 KEY SET, HITCH КРОНШТЕЙН (#067) (INCLS 2 KEYS) (17.070)
19242718 KEY SET, HITCH КРОНШТЕЙН (#068) (INCLS 2 KEYS) (17.070)
19242719 KEY SET, HITCH КРОНШТЕЙН (#069) (INCLS 2 KEYS) (17.070)
19242720 KEY SET, HITCH КРОНШТЕЙН (#070) (INCLS 2 KEYS) (17.070)
19242721 KEY SET, HITCH КРОНШТЕЙН (#071) (INCLS 2 KEYS) (17.070)
19242722 KEY SET, HITCH КРОНШТЕЙН (#072) (INCLS 2 KEYS) (17.070)
19242723 KEY SET, HITCH КРОНШТЕЙН (#073) (INCLS 2 KEYS) (17.070)
19242724 KEY SET, HITCH КРОНШТЕЙН (#074) (INCLS 2 KEYS) (17.070)
19242725 KEY SET, HITCH КРОНШТЕЙН (#075) (INCLS 2 KEYS) (17.070)
19242726 KEY SET, HITCH КРОНШТЕЙН (#076) (INCLS 2 KEYS) (17.070)
19242727 KEY SET, HITCH КРОНШТЕЙН (#077) (INCLS 2 KEYS) (17.070)
19242728 KEY SET, HITCH КРОНШТЕЙН (#078) (INCLS 2 KEYS) (17.070)
19242729 KEY SET, HITCH КРОНШТЕЙН (#079) (INCLS 2 KEYS) (17.070)
19242730 KEY SET, HITCH КРОНШТЕЙН (#080) (INCLS 2 KEYS) (17.070)
19242731 KEY SET, HITCH КРОНШТЕЙН (#081) (INCLS 2 KEYS) (17.070)
19242732 KEY SET, HITCH КРОНШТЕЙН (#082) (INCLS 2 KEYS) (17.070)
19242733 KEY SET, HITCH КРОНШТЕЙН (#083) (INCLS 2 KEYS) (17.070)
19242734 KEY SET, HITCH КРОНШТЕЙН (#084) (INCLS 2 KEYS) (17.070)
19242735 KEY SET, HITCH КРОНШТЕЙН (#085) (INCLS 2 KEYS) (17.070)
19242736 KEY SET, HITCH КРОНШТЕЙН (#086) (INCLS 2 KEYS) (17.070)
19242737 KEY SET, HITCH КРОНШТЕЙН (#087) (INCLS 2 KEYS) (17.070)
19242738 KEY SET, HITCH КРОНШТЕЙН (#088) (INCLS 2 KEYS) (17.070)
19242739 KEY SET, HITCH КРОНШТЕЙН (#089) (INCLS 2 KEYS) (17.070)
19242740 KEY SET, HITCH КРОНШТЕЙН (#090) (INCLS 2 KEYS) (17.070)
19242741 KEY SET, HITCH КРОНШТЕЙН (#091) (INCLS 2 KEYS) (17.070)
19242742 KEY SET, HITCH КРОНШТЕЙН (#092) (INCLS 2 KEYS) (17.070)
19242743 KEY SET, HITCH КРОНШТЕЙН (#093) (INCLS 2 KEYS) (17.070)
19242744 KEY SET, HITCH КРОНШТЕЙН (#094) (INCLS 2 KEYS) (17.070)
19242745 KEY SET, HITCH КРОНШТЕЙН (#095) (INCLS 2 KEYS) (17.070)
19242746 KEY SET, HITCH КРОНШТЕЙН (#096) (INCLS 2 KEYS) (17.070)
19242747 KEY SET, HITCH КРОНШТЕЙН (#097) (INCLS 2 KEYS) (17.070)
19242748 KEY SET, HITCH КРОНШТЕЙН (#098) (INCLS 2 KEYS) (17.070)
teamcadillac.ru
19242749 KEY SET, HITCH КРОНШТЕЙН (#099) (INCLS 2 KEYS) (17.070)
88963077 KEY SET, HITCH КРОНШТЕЙН (#01) (INCLS 2 KEYS) (12.815)
88966122 KEY SET, HITCH КРОНШТЕЙН (#02) (INCLS 2 KEYS) (17.070)
88966123 KEY SET, HITCH КРОНШТЕЙН (#03) (INCLS 2 KEYS) (17.070)
88966124 KEY SET, HITCH КРОНШТЕЙН (#04) (INCLS 2 KEYS) (17.070)
88966125 KEY SET, HITCH КРОНШТЕЙН (#05) (INCLS 2 KEYS) (17.070)
88966126 KEY SET, HITCH КРОНШТЕЙН (#06) (INCLS 2 KEYS) (17.070)
88966127 KEY SET, HITCH КРОНШТЕЙН (#07) (INCLS 2 KEYS) (17.070)
88966128 KEY SET, HITCH КРОНШТЕЙН (#08) (INCLS 2 KEYS) (17.070)
88966129 KEY SET, HITCH КРОНШТЕЙН (#09) (INCLS 2 KEYS) (17.070)
88966130 KEY SET, HITCH КРОНШТЕЙН (#00) (INCLS 2 KEYS) (17.070)
(AC21-919) - 2004-2009 E26 КРЕПЛЕНИЕ БАГАЖА, ВЕЛОСИПЕД (HITCH MOUNT)
12499172 КРОНШТЕЙН PKG, BICYCLE (HITCH MT) (INCLS SUPT, PLT & LOCK PKG'S, ARM ASM, LK STRAP, SPACER & INSTR) (INSTALL .10) (18.55KGS) (CARRIES 4 BIKES) (17.070) (REQUIRES 1-1/4" TRAILER HITCH AND LICENSE PLATE REMOUNT PKG 12495709) [ЗАДНИЙ БАГАЖНИК ДЛЯ ВЕЛОСИПЕДА]
(AC21-952) - 2004-2009 E АВАРИЙНЫЙ ЗНАК PKG (CU8)
19201300 АВАРИЙНЫЙ ЗНАК PKG, (INTERNATIONAL) (1.60KGS) (2.575) [ДОРОЖНЫЙ ЗНАК - ТРЕУГОЛЬНИК]
19201301 АВАРИЙНЫЙ ЗНАК PKG, BULK (INTERNATIONAL) (2.575)
(GM21-007) - 2004-2006 E HITCH PKG/TRAILER
teamcadillac.ru
12498654 HITCH PKG, TRLR (SAME AS VR4) (INSTALL 1.4) (20.0KGS) (INCLS WIRING HARN) (3500 LB MAX LOAD, 350 LB TONGUE WT) (7.068) [ТРЕЙЛЕРНАЯ СЦЕПКА В СБОРЕ]
(GM21-009) - 2004-2005 EB26 APPEARANCE PKG/КОЛЕСО NUT CAP
17800816 NUT PKG, WHL (INSTALL .10) (SINGLE 0.055KGS) (STEEL W/DACROSEAL) (240 PC QTY OF 9594683) (5.813) (USED WITH 18" ACCESSORY КОЛЕСА) [ВИНТ]
teamcadillac.ru
17800817 CAP PKG, WHL NUT (USE WITH ACCESSORY 18" WHL) (INSTALL .10) (SINGLE 0.014KGS) (PLASTIC W/CHROME OVERLAY) (240 PC QTY OF 9593570) (5.813)
(GM21-020) - 2005-2009 E HEADPHONE/ЗАДНИЙ SEAT ENTERTAINMENT (UPGRADE)
17802612 HEADPHONE PKG, (00.2 KGS) (INCLS WIRELESS NOISE CANC HEADPHONE, OWN MAN, 2 AAA BAT) (9.665) [БЕСПРОВОДНОЙ НАУШНИК]
(GM21-023) - 2005-2009 EB26 ACCESSORY PKG/ШИНА PRESSURE INDICATOR SENSOR
17801718 SENSOR PKG, ШИНА PRESS IND (INSTALL .10) (SINGLE 0.03 KGS) (16 PC QTY OF 25774006) (5.890)
(GM21-026) - 2005-2009 EB26 ENTERTAINMENT PKG/R/SEAT VIDEO & T/PLYR
teamcadillac.ru
19153844 HEADREST PKG, DUAL DVD R/SEAT ENTERTAINMENT (INCLS 2 HEADRESTS, 2 HEADPHONES, REM CONT, JUMPER HARNESS, WIRE PULLLER, 6 AAA BATT, HDW BAG) (EBONY) (INSTALL 1.0) (LEATHER W/VINYL SIDES) (9.680)
19153846 HEADREST PKG, DUAL DVD R/SEAT ENTERTAINMENT (INCLS 2 HEADRESTS, 2 HEADPHONES, REM CONT, JUMPER HARN, WIRE PULLER, QUICK START QUIDE, OWNERS MAN, 6 AAA BATT, HDW BAG) (CASHMERE) (INSTALL 1.0) (LEATHER W/VINYL SIDES) (9.680)
19153847 HEADREST PKG, DUAL DVD R/SEAT ENTERTAINMENT (INCLS 2 HEADRESTS, 2 HEADPHONES, REM CONT, JUMPER HARN, WIRE PULLER, 6 AAA BATT, HDW BAG) (GRAY) (INSTALL 1.0) (LEATHER W/VINYL SIDES) (9.680)
(GM21-032) - 2004-2006 E ПЕПЕЛЬНИЦА PKG (BIN STYLE)
12499465 ПЕПЕЛЬНИЦА PKG, (BLACK) (INSTALL .10) (BIN STYLE) (PLSTC) (INCLS C/LTR) (12.009)
(GM21-035) - 2005-2009 EB26 ACCESSORY PKG/VIDEO DISPLAY REMOTE CONTROL
teamcadillac.ru
19132011 CONTROL, VIDEO DISPLAY REMOTE (0.09KGS) (9.680) (REMOTE WILL ONLY OPERATE WITH GMSPO DVD HEADREST SYSTEMS)
